[U-Boot] [PATCH v4 1/2] nitrogen6x: Fix RAM size variable
Fix the following build error when buildig nitrogen6s1g:
nitrogen6x.c:89:17: error: 'CONFIG_DDR_MB' undeclared (first use in this function) nitrogen6x.c:89:17: note: each undeclared identifier is reported only once for each function it appears in
Reported-by: Albert Aribaud albert.u.boot@aribaud.net Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v3: - No changes Changes since v2: - No changes Changes since v1: - Rebased against u-boot-imx tree
boards.cfg | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/boards.cfg b/boards.cfg index fb3b197..84f96e0 100644 --- a/boards.cfg +++ b/boards.cfg @@ -260,7 +260,7 @@ nitrogen6dl2g arm armv7 nitrogen6x boundar nitrogen6q arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024 nitrogen6q2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 nitrogen6s arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 -nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,SDRAM_MB=1024 +nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024 cm_t35 arm armv7 cm_t35 - omap3 omap3_overo arm armv7 overo - omap3 omap3_pandora arm armv7 pandora - omap3
When building for the nitrogen boards with 2GiB the following warning happens:
nitrogen6x.c:89:38: warning: integer overflow in expression [-Woverflow]
2GiB can not fit in 32-bits, so use ulong instead.
Reported-by: Albert Aribaud albert.u.boot@aribaud.net Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v3: - Use GiB Changes since v2: - move casting inside expression to force using unsigned long (from Stefano) Changes since v1: - No changes board/boundary/nitrogen6x/nitrogen6x.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 0dbb6d2..e5634d8 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -86,7 +86,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { - gd->ram_size = CONFIG_DDR_MB * 1024 * 1024; + gd->ram_size = ((ulong)CONFIG_DDR_MB * 1024 * 1024);
return 0; }
Fabio Estevam
