[PATCH] imx6: aristainetos: fix NAND detection with latest mainline
commit 88718be30010 ("mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NAND") moved CONFIG_NAND -> CONFIG_MTD_RAW_NAND. Adapt board code to this change, as last merge did not respect the above commit.
Signed-off-by: Heiko Schocher hs@denx.de ---
board/aristainetos/aristainetos.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/aristainetos/aristainetos.c b/board/aristainetos/aristainetos.c index c79ac1d339..3541717873 100644 --- a/board/aristainetos/aristainetos.c +++ b/board/aristainetos/aristainetos.c @@ -521,7 +521,7 @@ struct display_info_t const displays[] = { }; size_t display_count = ARRAY_SIZE(displays);
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) iomux_v3_cfg_t nfc_pads[] = { MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL), MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL),
commit 88718be30010 ("mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NAND") moved CONFIG_NAND -> CONFIG_MTD_RAW_NAND. Adapt board code to this change, as last merge did not respect the above commit. Signed-off-by: Heiko Schocher hs@denx.de
Best regards, Stefano Babic
Heiko Schocher
sbabic@denx.de
