[U-Boot] [PATCH] arm: socfpga: revert "set the fpga global bit to disable HPS to FPGA signals"
Revert "arm: socfpga: set the fpga global bit to disable HPS to FPGA signals"
Apparently, the logic for the FPGA global bit is not universal between Gen5 and Gen10 devices is not the same. Disabling this bit, while applicable to Gen10 devices, will break FPGA programming on Gen5 devices.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- drivers/fpga/socfpga.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index 431e159..4448250 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -269,7 +269,7 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) /* Prior programming the FPGA, all bridges need to be shut off */
/* Disable all signals from hps peripheral controller to fpga */ - writel(0, &sysmgr_regs->fpgaintfgrp_gbl); + writel(0, &sysmgr_regs->fpgaintfgrp_module);
/* Disable all signals from FPGA to HPS SDRAM */ #define SDR_CTRLGRP_FPGAPORTRST_ADDRESS 0x5080
Hi Marek,
I apologize for the original patch "arm: socfpga: set the fpga global bit to disable HPS to FPGA signals". I did not test the patch when it was sent out. I did go back to testing it after I was able to consolidate a bit the FPGA driver for Gen5 and Gen10 devices, and found out that behavior for the global FPGA bit is different.
Dinh
On Tuesday, January 19, 2016 at 04:50:06 PM, Dinh Nguyen wrote:
Hi Marek,
Hi Dinh,
Good thing it went in after 2016.01 was out, so nothing that bad really happened. Thanks for finding this.
Best regards, Marek Vasut
Applied, thanks.
Dinh Nguyen
