[PATCH 1/7] amlogic: Remove ARCH= references from documentation
When building U-Boot we select the architecture via Kconfig and not ARCH being passed in via the environment or make cmdline.
Cc: Beniamino Galvani b.galvani@gmail.com Cc: Neil Armstrong narmstrong@baylibre.com Cc: u-boot-amlogic@groups.io Signed-off-by: Tom Rini trini@konsulko.com --- As an aside, these files should be converted rST and moved to doc/board/ and the MAINTAINERS file updated to include the new documentation file too. Thanks! --- board/amlogic/p200/README.nanopi-k2 | 1 - board/amlogic/p200/README.odroid-c2 | 1 - board/amlogic/p200/README.p200 | 1 - board/amlogic/p201/README.p201 | 1 - board/amlogic/p212/README.khadas-vim | 1 - board/amlogic/p212/README.libretech-ac | 1 - board/amlogic/p212/README.libretech-cc | 1 - board/amlogic/p212/README.p212 | 1 - board/amlogic/q200/README.khadas-vim2 | 1 - board/amlogic/q200/README.q200 | 1 - board/amlogic/s400/README | 1 - board/amlogic/sei510/README | 1 - board/amlogic/sei610/README | 1 - board/amlogic/u200/README | 1 - board/amlogic/w400/README.khadas-vim3 | 1 - board/amlogic/w400/README.khadas-vim3l | 1 - board/amlogic/w400/README.odroid-n2 | 1 - board/amlogic/w400/README.w400 | 1 - 18 files changed, 18 deletions(-)
diff --git a/board/amlogic/p200/README.nanopi-k2 b/board/amlogic/p200/README.nanopi-k2 index d450d3c2b2af..c8dec3569b4d 100644 --- a/board/amlogic/p200/README.nanopi-k2 +++ b/board/amlogic/p200/README.nanopi-k2 @@ -24,7 +24,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make nanopi-k2_defconfig make
diff --git a/board/amlogic/p200/README.odroid-c2 b/board/amlogic/p200/README.odroid-c2 index bed48c5728ba..3b9f80df29d8 100644 --- a/board/amlogic/p200/README.odroid-c2 +++ b/board/amlogic/p200/README.odroid-c2 @@ -29,7 +29,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make odroid-c2_defconfig make
diff --git a/board/amlogic/p200/README.p200 b/board/amlogic/p200/README.p200 index 01d82d1e79e3..84d5ca535691 100644 --- a/board/amlogic/p200/README.p200 +++ b/board/amlogic/p200/README.p200 @@ -31,7 +31,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make p200_defconfig make
diff --git a/board/amlogic/p201/README.p201 b/board/amlogic/p201/README.p201 index c251096ce142..4bb5e9590532 100644 --- a/board/amlogic/p201/README.p201 +++ b/board/amlogic/p201/README.p201 @@ -31,7 +31,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make p201_defconfig make
diff --git a/board/amlogic/p212/README.khadas-vim b/board/amlogic/p212/README.khadas-vim index a2c7606454f8..ccf933861b79 100644 --- a/board/amlogic/p212/README.khadas-vim +++ b/board/amlogic/p212/README.khadas-vim @@ -30,7 +30,6 @@ Currently the u-boot port supports the following devices: U-Boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make khadas-vim_defconfig make
diff --git a/board/amlogic/p212/README.libretech-ac b/board/amlogic/p212/README.libretech-ac index 538604261b84..3f713ec32634 100644 --- a/board/amlogic/p212/README.libretech-ac +++ b/board/amlogic/p212/README.libretech-ac @@ -25,7 +25,6 @@ Currently the U-Boot port supports the following devices: U-Boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make libretech-ac_defconfig make
diff --git a/board/amlogic/p212/README.libretech-cc b/board/amlogic/p212/README.libretech-cc index 6af7de3cfa79..74434d4435ec 100644 --- a/board/amlogic/p212/README.libretech-cc +++ b/board/amlogic/p212/README.libretech-cc @@ -30,7 +30,6 @@ Currently the U-Boot port supports the following devices: U-Boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make libretech-cc_defconfig make
diff --git a/board/amlogic/p212/README.p212 b/board/amlogic/p212/README.p212 index ef5370c763c4..3776f2449391 100644 --- a/board/amlogic/p212/README.p212 +++ b/board/amlogic/p212/README.p212 @@ -31,7 +31,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make p212_defconfig make
diff --git a/board/amlogic/q200/README.khadas-vim2 b/board/amlogic/q200/README.khadas-vim2 index 8bcfc296f3e0..595998c4fabb 100644 --- a/board/amlogic/q200/README.khadas-vim2 +++ b/board/amlogic/q200/README.khadas-vim2 @@ -31,7 +31,6 @@ Currently the u-boot port supports the following devices: U-Boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make khadas-vim2_defconfig make
diff --git a/board/amlogic/q200/README.q200 b/board/amlogic/q200/README.q200 index 55d730a0d200..d4142c88bd42 100644 --- a/board/amlogic/q200/README.q200 +++ b/board/amlogic/q200/README.q200 @@ -30,7 +30,6 @@ Currently the u-boot port supports the following devices: U-Boot compilation ==================
- > export ARCH=arm
diff --git a/board/amlogic/s400/README b/board/amlogic/s400/README index ab21998dc836..a48db22a4282 100644 --- a/board/amlogic/s400/README +++ b/board/amlogic/s400/README @@ -31,7 +31,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make s400_defconfig make
diff --git a/board/amlogic/sei510/README b/board/amlogic/sei510/README index e47ebc7b3a5a..d9358aa50183 100644 --- a/board/amlogic/sei510/README +++ b/board/amlogic/sei510/README @@ -22,7 +22,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make sei510_defconfig make
diff --git a/board/amlogic/sei610/README b/board/amlogic/sei610/README index 1cc2b3c2a4e9..d96a94b5e970 100644 --- a/board/amlogic/sei610/README +++ b/board/amlogic/sei610/README @@ -18,7 +18,6 @@ specifications: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make sei610_defconfig make
diff --git a/board/amlogic/u200/README b/board/amlogic/u200/README index bffac5e7ae0a..a4080eb299c4 100644 --- a/board/amlogic/u200/README +++ b/board/amlogic/u200/README @@ -27,7 +27,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make u200_defconfig make
diff --git a/board/amlogic/w400/README.khadas-vim3 b/board/amlogic/w400/README.khadas-vim3 index 45ef90c1b0a9..399bf49295f6 100644 --- a/board/amlogic/w400/README.khadas-vim3 +++ b/board/amlogic/w400/README.khadas-vim3 @@ -29,7 +29,6 @@ Currently the U-Boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make khadas-vim3_defconfig make
diff --git a/board/amlogic/w400/README.khadas-vim3l b/board/amlogic/w400/README.khadas-vim3l index 0afff16c0c26..b2d9abbfd9b2 100644 --- a/board/amlogic/w400/README.khadas-vim3l +++ b/board/amlogic/w400/README.khadas-vim3l @@ -29,7 +29,6 @@ Currently the U-Boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make khadas-vim3l_defconfig make
diff --git a/board/amlogic/w400/README.odroid-n2 b/board/amlogic/w400/README.odroid-n2 index a8f2c3d7daa6..8142eebea007 100644 --- a/board/amlogic/w400/README.odroid-n2 +++ b/board/amlogic/w400/README.odroid-n2 @@ -28,7 +28,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make odroid-n2_defconfig make
diff --git a/board/amlogic/w400/README.w400 b/board/amlogic/w400/README.w400 index 25b786d817c4..c129717a1189 100644 --- a/board/amlogic/w400/README.w400 +++ b/board/amlogic/w400/README.w400 @@ -27,7 +27,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
- > export ARCH=arm
export CROSS_COMPILE=aarch64-none-elf- make w400_defconfig make
Cc: Adam Ford aford173@gmail.com Cc: Vanessa Maegima vanessa.maegima@nxp.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Igor Opaniuk igor.opaniuk@toradex.com Cc: Amit Singh Tomar amittomer25@gmail.com Cc: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Signed-off-by: Tom Rini trini@konsulko.com --- As an aside, the README files that haven't already been converted to rST should be converted rST and moved to doc/board/ and the MAINTAINERS file updated to include the new documentation file too. Thanks! --- board/beacon/imx8mm/README | 2 +- board/logicpd/imx6/README | 2 +- board/technexion/pico-imx7d/README.pico-imx7d_BL33 | 2 +- doc/board/actions/cubieboard7.rst | 2 +- doc/board/toradex/colibri_imx7.rst | 1 - 5 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/board/beacon/imx8mm/README b/board/beacon/imx8mm/README index 4223fbd15dd6..dce176fa0b23 100644 --- a/board/beacon/imx8mm/README +++ b/board/beacon/imx8mm/README @@ -26,7 +26,7 @@ $ cp firmware-imx-8.5/firmware/ddr/synopsys/lpddr4*.bin $(srctree) Build U-Boot ============ $ make imx8mm_beacon_defconfig -$ make flash.bin ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- ATF_LOAD_ADDR=0x920000 +$ make flash.bin CROSS_COMPILE=aarch64-linux-gnu- ATF_LOAD_ADDR=0x920000
Burn U-Boot to microSD Card =========================== diff --git a/board/logicpd/imx6/README b/board/logicpd/imx6/README index 26d053a32c3b..19f79c5734bc 100644 --- a/board/logicpd/imx6/README +++ b/board/logicpd/imx6/README @@ -17,7 +17,7 @@ Building U-Boot for Logic PD Development Kit To build U-Boot for the Dual and Quad variants:
make imx6q_logic_defconfig - make u-boot.imx ARCH=arm CROSS_COMPILE=arm-linux- + make u-boot.imx CROSS_COMPILE=arm-linux-
Flashing U-Boot into the SD card diff --git a/board/technexion/pico-imx7d/README.pico-imx7d_BL33 b/board/technexion/pico-imx7d/README.pico-imx7d_BL33 index 40324ffe5f34..1b346093b88d 100644 --- a/board/technexion/pico-imx7d/README.pico-imx7d_BL33 +++ b/board/technexion/pico-imx7d/README.pico-imx7d_BL33 @@ -4,7 +4,7 @@ The boot sequence is ATF -> OPTEE -> U-Boot -> Linux. U-Boot is in non-secure world in this case.
- Build u-boot - Set environment variable of CROSS_COMPILE for your toolchain and ARCH=arm + Set environment variable of CROSS_COMPILE for your toolchain $ make pico-imx7d_bl33_defconfig $ make all
diff --git a/doc/board/actions/cubieboard7.rst b/doc/board/actions/cubieboard7.rst index e01d2d0370a1..74f2b12e41fe 100644 --- a/doc/board/actions/cubieboard7.rst +++ b/doc/board/actions/cubieboard7.rst @@ -102,7 +102,7 @@ Building U-BOOT proper image
$ make clean $ export CROSS_COMPILE=aarch64-linux-gnu- - $ make ARCH=arm cubieboard7_defconfig + $ make cubieboard7_defconfig $ make u-boot-dtb.img -j16
u-boot-dtb.img can now be flashed to debian image partition mounted on host machine. diff --git a/doc/board/toradex/colibri_imx7.rst b/doc/board/toradex/colibri_imx7.rst index 6fb952666661..a30e721379ee 100644 --- a/doc/board/toradex/colibri_imx7.rst +++ b/doc/board/toradex/colibri_imx7.rst @@ -18,7 +18,6 @@ Build U-Boot .. code-block:: bash
$ export CROSS_COMPILE=arm-linux-gnueabi- - $ export ARCH=arm $ make colibri_imx7_emmc_defconfig # For NAND: colibri_imx7_defconfig $ make
Hi
It is clubbed with imx platform but cubieboard7.rst is for Actions platform which is completely different from imx.
Thanks -Amit
On Tue, May 19, 2020 at 08:41:45PM +0530, Amit Tomer wrote:
Hi
Whoops, gotta update my mental mapping, sorry.
Cc: Po Liu po.liu@nxp.com Cc: Qiang Zhao qiang.zhao@nxp.com Signed-off-by: Tom Rini trini@konsulko.com --- As an aside, these files should be converted rST and moved to doc/board/ and the MAINTAINERS file updated to include the new documentation file too. Thanks! --- board/freescale/c29xpcie/README | 1 - board/freescale/p1010rdb/README.P1010RDB-PA | 1 - board/freescale/p1010rdb/README.P1010RDB-PB | 1 - 3 files changed, 3 deletions(-)
diff --git a/board/freescale/c29xpcie/README b/board/freescale/c29xpcie/README index 2e249cbb3a2e..a6120f1845d2 100644 --- a/board/freescale/c29xpcie/README +++ b/board/freescale/c29xpcie/README @@ -56,7 +56,6 @@ Note: 1 stands for 'off', 0 stands for 'on' Build and program U-Boot to NOR flash ================================== 1. Build u-boot.bin image example: - export ARCH=powerpc export CROSS_COMPILE=/your_path/powerpc-linux-gnu- make C293PCIE
diff --git a/board/freescale/p1010rdb/README.P1010RDB-PA b/board/freescale/p1010rdb/README.P1010RDB-PA index 105942f7a54f..46c61237c727 100644 --- a/board/freescale/p1010rdb/README.P1010RDB-PA +++ b/board/freescale/p1010rdb/README.P1010RDB-PA @@ -98,7 +98,6 @@ instead of to CAN/UART1. Build and burn U-Boot to NOR flash ================================== 1. Build u-boot.bin image - export ARCH=powerpc export CROSS_COMPILE=/your_path/powerpc-linux-gnu- make P1010RDB_NOR
diff --git a/board/freescale/p1010rdb/README.P1010RDB-PB b/board/freescale/p1010rdb/README.P1010RDB-PB index dc82f0df0984..4a3b389877fc 100644 --- a/board/freescale/p1010rdb/README.P1010RDB-PB +++ b/board/freescale/p1010rdb/README.P1010RDB-PB @@ -128,7 +128,6 @@ To enable IFC in case of SD boot Build images for different boot mode ==================================== First setup cross compile environment on build host - $ export ARCH=powerpc $ export CROSS_COMPILE=<your-compiler-path>/powerpc-linux-gnu-
1. For NOR boot
Cc: Kever Yang kever.yang@rock-chips.com Cc: Simon Glass sjg@chromium.org Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Klaus Goger klaus.goger@theobroma-systems.com Cc: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Tom Rini trini@konsulko.com --- As an aside, these files should be converted rST and moved to doc/board/ and the MAINTAINERS file updated to include the new documentation file too. Thanks! --- board/rockchip/evb_rk3229/README | 1 - board/rockchip/evb_rk3399/README | 1 - board/theobroma-systems/lion_rk3368/README | 4 ++-- board/vamrs/rock960_rk3399/README | 1 - 4 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/board/rockchip/evb_rk3229/README b/board/rockchip/evb_rk3229/README index 93328c75b204..9068225e2721 100644 --- a/board/rockchip/evb_rk3229/README +++ b/board/rockchip/evb_rk3229/README @@ -22,7 +22,6 @@ Compile the U-Boot
cd ../u-boot export CROSS_COMPILE=arm-linux-gnueabihf-
- > export ARCH=arm
make evb-rk3229_defconfig make make u-boot.itb
diff --git a/board/rockchip/evb_rk3399/README b/board/rockchip/evb_rk3399/README index da7ae89ab1e9..c6f58203ebe9 100644 --- a/board/rockchip/evb_rk3399/README +++ b/board/rockchip/evb_rk3399/README @@ -54,7 +54,6 @@ Compile U-Boot ==============
cd ../u-boot
- > export ARCH=arm64
export CROSS_COMPILE=aarch64-linux-gnu- make evb-rk3399_defconfig
for firefly-rk3399, use below instead: diff --git a/board/theobroma-systems/lion_rk3368/README b/board/theobroma-systems/lion_rk3368/README index ad3ac93bd44b..7488b18326b9 100644 --- a/board/theobroma-systems/lion_rk3368/README +++ b/board/theobroma-systems/lion_rk3368/README @@ -17,12 +17,12 @@ Configure U-Boot Build the TPL/SPL stage =======================
- > make CROSS_COMPILE=aarch64-unknown-elf- ARCH=arm + > make CROSS_COMPILE=aarch64-unknown-elf-
Build the full U-Boot and a FIT image including the ATF =======================================================
- > make CROSS_COMPILE=aarch64-unknown-elf- ARCH=arm u-boot.itb + > make CROSS_COMPILE=aarch64-unknown-elf- u-boot.itb
Flash the image =============== diff --git a/board/vamrs/rock960_rk3399/README b/board/vamrs/rock960_rk3399/README index c5c675c4ead1..15df027fbcd4 100644 --- a/board/vamrs/rock960_rk3399/README +++ b/board/vamrs/rock960_rk3399/README @@ -57,7 +57,6 @@ Compile the U-Boot
cd ../u-boot cp ../rkbin/rk33/rk3399_bl31_v1.00.elf ./bl31.elf
export CROSS_COMPILE=aarch64-linux-gnu- make rock960-rk3399_defconfig make
export ARCH=arm make evb-rk3229_defconfig make make u-boot.itbdiff --git a/board/rockchip/evb_rk3399/README b/board/rockchip/evb_rk3399/README index da7ae89ab1e9..c6f58203ebe9 100644 --- a/board/rockchip/evb_rk3399/README +++ b/board/rockchip/evb_rk3399/README @@ -54,7 +54,6 @@ Compile U-Boot ==============
cd ../u-boot
export ARCH=arm64 export CROSS_COMPILE=aarch64-linux-gnu- make evb-rk3399_defconfigfor firefly-rk3399, use below instead:diff --git a/board/theobroma-systems/lion_rk3368/README b/board/theobroma-systems/lion_rk3368/README index ad3ac93bd44b..7488b18326b9 100644 --- a/board/theobroma-systems/lion_rk3368/README +++ b/board/theobroma-systems/lion_rk3368/README @@ -17,12 +17,12 @@ Configure U-Boot Build the TPL/SPL stage =======================
make CROSS_COMPILE=aarch64-unknown-elf-Build the full U-Boot and a FIT image including the ATF
make CROSS_COMPILE=aarch64-unknown-elf- u-boot.itbFlash the image
export ARCH=arm64 export CROSS_COMPILE=aarch64-linux-gnu- make rock960-rk3399_defconfig make
Reviewed-by: Klaus Goger klaus.goger@theobroma-systems.com
Thanks for the hint about converting to rST. Will send patches for at least the boards that list me as maintainer.
Best, Klaus
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
> cd ../u-boot > export CROSS_COMPILE=arm-linux-gnueabihf-
> cd ../u-boot
Flash the image
> cd ../u-boot > cp ../rkbin/rk33/rk3399_bl31_v1.00.elf ./bl31.elf
Cc: Lokesh Vutla lokeshvutla@ti.com Cc: Vitaly Andrianov vitalya@ti.com Signed-off-by: Tom Rini trini@konsulko.com --- As an aside, these README files should be converted rST and moved to doc/board/ and the MAINTAINERS file updated to include the new documentation file too. Thanks! --- board/ti/am65x/README | 8 ++++---- board/ti/j721e/README | 8 ++++---- board/ti/ks2_evm/README | 2 +- doc/uImage.FIT/beaglebone_vboot.txt | 1 - 4 files changed, 9 insertions(+), 10 deletions(-)
diff --git a/board/ti/am65x/README b/board/ti/am65x/README index 00be1ffe44d6..67081ce349dc 100644 --- a/board/ti/am65x/README +++ b/board/ti/am65x/README @@ -133,12 +133,12 @@ $ make PLATFORM=k3-am65x CFG_ARM64_core=y 4. U-Boot:
4.1. R5: -$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- am65x_evm_r5_defconfig O=/tmp/r5 -$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- O=/tmp/r5 +$ make CROSS_COMPILE=arm-linux-gnueabihf- am65x_evm_r5_defconfig O=/tmp/r5 +$ make CROSS_COMPILE=arm-linux-gnueabihf- O=/tmp/r5
4.2. A53: -$ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- am65x_evm_a53_defconfig O=/tmp/a53 -$ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin O=/tmp/a53 +$ make CROSS_COMPILE=aarch64-linux-gnu- am65x_evm_a53_defconfig O=/tmp/a53 +$ make CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin O=/tmp/a53
Target Images -------------- diff --git a/board/ti/j721e/README b/board/ti/j721e/README index 7dcf33633294..757a59cdb44a 100644 --- a/board/ti/j721e/README +++ b/board/ti/j721e/README @@ -149,12 +149,12 @@ $ make PLATFORM=k3-j721e CFG_ARM64_core=y 4. U-Boot:
4.1. R5: -$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- j721e_evm_r5_defconfig O=/tmp/r5 -$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- O=/tmp/r5 +$ make CROSS_COMPILE=arm-linux-gnueabihf- j721e_evm_r5_defconfig O=/tmp/r5 +$ make CROSS_COMPILE=arm-linux-gnueabihf- O=/tmp/r5
4.2. A72: -$ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- j721e_evm_a72_defconfig O=/tmp/a72 -$ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin O=/tmp/a72 +$ make CROSS_COMPILE=aarch64-linux-gnu- j721e_evm_a72_defconfig O=/tmp/a72 +$ make CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin O=/tmp/a72
Target Images -------------- diff --git a/board/ti/ks2_evm/README b/board/ti/ks2_evm/README index a26b7f813131..ff0ec5a36377 100644 --- a/board/ti/ks2_evm/README +++ b/board/ti/ks2_evm/README @@ -74,7 +74,7 @@ Supported image formats: Build instructions: =================== Examples for k2hk, for k2e, k2l and k2g just replace k2hk prefix accordingly. -Don't forget to add ARCH=arm and CROSS_COMPILE. +Don't forget to add CROSS_COMPILE.
To build u-boot.bin, u-boot-spi.gph, MLO:
make k2hk_evm_defconfig
diff --git a/doc/uImage.FIT/beaglebone_vboot.txt b/doc/uImage.FIT/beaglebone_vboot.txt index 685ec1f46d96..ebd2068ed38d 100644 --- a/doc/uImage.FIT/beaglebone_vboot.txt +++ b/doc/uImage.FIT/beaglebone_vboot.txt @@ -67,7 +67,6 @@ or if you just installed gcc-arm-linux-gnueabi then it might be
b. Configure and build U-Boot with verified boot enabled:
- export ARCH=arm export UBOOT=/path/to/u-boot cd $UBOOT # You can add -j10 if you have 10 CPUs to make it faster
While in here, add the doc file to the MAINTAINERS entry for coldfire.
Cc: Huan Wang alison.wang@nxp.com Cc: Angelo Dureghello angelo@sysam.it Signed-off-by: Tom Rini trini@konsulko.com --- MAINTAINERS | 1 + doc/arch/m68k.rst | 6 +++--- 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 8add9d4c2ae9..893cac398f84 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -590,6 +590,7 @@ M: Angelo Dureghello angelo@sysam.it S: Maintained T: git https://gitlab.denx.de/u-boot/custodians/u-boot-coldfire.git F: arch/m68k/ +F: doc/arch/m68k.rst
DFU M: Lukasz Majewski lukma@denx.de diff --git a/doc/arch/m68k.rst b/doc/arch/m68k.rst index 34b2593eb85b..44e1a5dfa384 100644 --- a/doc/arch/m68k.rst +++ b/doc/arch/m68k.rst @@ -35,7 +35,7 @@ development boards. Supported CPU families ----------------------
-Please "make menuconfig" with ARCH=m68k, or check arch/m68k/cpu to see the +Please "make menuconfig" and select "m68k" or check arch/m68k/cpu to see the currently supported processor and families.
@@ -75,8 +75,8 @@ A bash script similar to the one below may be used: board=M5475DFE
make distclean - make ARCH=m68k ${board}_defconfig - make ARCH=m68k KBUILD_VERBOSE=1 + make ${board}_defconfig + make KBUILD_VERBOSE=1
Adopted toolchains
Cc: Paul Walmsley paul.walmsley@sifive.com Cc: Palmer Dabbelt palmer@sifive.com Cc: Anup Patel anup.patel@wdc.com Cc: Atish Patra atish.patra@wdc.com Signed-off-by: Tom Rini trini@konsulko.com --- board/sifive/fu540/MAINTAINERS | 1 + doc/board/sifive/fu540.rst | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/sifive/fu540/MAINTAINERS b/board/sifive/fu540/MAINTAINERS index 702d803ad809..93df97913355 100644 --- a/board/sifive/fu540/MAINTAINERS +++ b/board/sifive/fu540/MAINTAINERS @@ -5,5 +5,6 @@ M: Anup Patel anup.patel@wdc.com M: Atish Patra atish.patra@wdc.com S: Maintained F: board/sifive/fu540/ +F: doc/board/sifive/fu540.rst F: include/configs/sifive-fu540.h F: configs/sifive_fu540_defconfig diff --git a/doc/board/sifive/fu540.rst b/doc/board/sifive/fu540.rst index 610ba87074b4..43402cb2e51e 100644 --- a/doc/board/sifive/fu540.rst +++ b/doc/board/sifive/fu540.rst @@ -39,7 +39,6 @@ Building
.. code-block:: none
- export ARCH=riscv export CROSS_COMPILE=<riscv64 toolchain prefix>
3. make sifive_fu540_defconfig
I've reworded this locally to just be: While in here, add the doc file to the MAINTAINERS entry.
Adding this to my TODO list !
Thanks, Neil
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make nanopi-k2_defconfig makediff --git a/board/amlogic/p200/README.odroid-c2 b/board/amlogic/p200/README.odroid-c2 index bed48c5728ba..3b9f80df29d8 100644 --- a/board/amlogic/p200/README.odroid-c2 +++ b/board/amlogic/p200/README.odroid-c2 @@ -29,7 +29,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make odroid-c2_defconfig makediff --git a/board/amlogic/p200/README.p200 b/board/amlogic/p200/README.p200 index 01d82d1e79e3..84d5ca535691 100644 --- a/board/amlogic/p200/README.p200 +++ b/board/amlogic/p200/README.p200 @@ -31,7 +31,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make p200_defconfig makediff --git a/board/amlogic/p201/README.p201 b/board/amlogic/p201/README.p201 index c251096ce142..4bb5e9590532 100644 --- a/board/amlogic/p201/README.p201 +++ b/board/amlogic/p201/README.p201 @@ -31,7 +31,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make p201_defconfig makediff --git a/board/amlogic/p212/README.khadas-vim b/board/amlogic/p212/README.khadas-vim index a2c7606454f8..ccf933861b79 100644 --- a/board/amlogic/p212/README.khadas-vim +++ b/board/amlogic/p212/README.khadas-vim @@ -30,7 +30,6 @@ Currently the u-boot port supports the following devices: U-Boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make khadas-vim_defconfig makediff --git a/board/amlogic/p212/README.libretech-ac b/board/amlogic/p212/README.libretech-ac index 538604261b84..3f713ec32634 100644 --- a/board/amlogic/p212/README.libretech-ac +++ b/board/amlogic/p212/README.libretech-ac @@ -25,7 +25,6 @@ Currently the U-Boot port supports the following devices: U-Boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make libretech-ac_defconfig makediff --git a/board/amlogic/p212/README.libretech-cc b/board/amlogic/p212/README.libretech-cc index 6af7de3cfa79..74434d4435ec 100644 --- a/board/amlogic/p212/README.libretech-cc +++ b/board/amlogic/p212/README.libretech-cc @@ -30,7 +30,6 @@ Currently the U-Boot port supports the following devices: U-Boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make libretech-cc_defconfig makediff --git a/board/amlogic/p212/README.p212 b/board/amlogic/p212/README.p212 index ef5370c763c4..3776f2449391 100644 --- a/board/amlogic/p212/README.p212 +++ b/board/amlogic/p212/README.p212 @@ -31,7 +31,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make p212_defconfig makediff --git a/board/amlogic/q200/README.khadas-vim2 b/board/amlogic/q200/README.khadas-vim2 index 8bcfc296f3e0..595998c4fabb 100644 --- a/board/amlogic/q200/README.khadas-vim2 +++ b/board/amlogic/q200/README.khadas-vim2 @@ -31,7 +31,6 @@ Currently the u-boot port supports the following devices: U-Boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make khadas-vim2_defconfig makediff --git a/board/amlogic/q200/README.q200 b/board/amlogic/q200/README.q200 index 55d730a0d200..d4142c88bd42 100644 --- a/board/amlogic/q200/README.q200 +++ b/board/amlogic/q200/README.q200 @@ -30,7 +30,6 @@ Currently the u-boot port supports the following devices: U-Boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make khadas-vim2_defconfig makediff --git a/board/amlogic/s400/README b/board/amlogic/s400/README index ab21998dc836..a48db22a4282 100644 --- a/board/amlogic/s400/README +++ b/board/amlogic/s400/README @@ -31,7 +31,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make s400_defconfig makediff --git a/board/amlogic/sei510/README b/board/amlogic/sei510/README index e47ebc7b3a5a..d9358aa50183 100644 --- a/board/amlogic/sei510/README +++ b/board/amlogic/sei510/README @@ -22,7 +22,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make sei510_defconfig makediff --git a/board/amlogic/sei610/README b/board/amlogic/sei610/README index 1cc2b3c2a4e9..d96a94b5e970 100644 --- a/board/amlogic/sei610/README +++ b/board/amlogic/sei610/README @@ -18,7 +18,6 @@ specifications: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make sei610_defconfig makediff --git a/board/amlogic/u200/README b/board/amlogic/u200/README index bffac5e7ae0a..a4080eb299c4 100644 --- a/board/amlogic/u200/README +++ b/board/amlogic/u200/README @@ -27,7 +27,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make u200_defconfig makediff --git a/board/amlogic/w400/README.khadas-vim3 b/board/amlogic/w400/README.khadas-vim3 index 45ef90c1b0a9..399bf49295f6 100644 --- a/board/amlogic/w400/README.khadas-vim3 +++ b/board/amlogic/w400/README.khadas-vim3 @@ -29,7 +29,6 @@ Currently the U-Boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make khadas-vim3_defconfig makediff --git a/board/amlogic/w400/README.khadas-vim3l b/board/amlogic/w400/README.khadas-vim3l index 0afff16c0c26..b2d9abbfd9b2 100644 --- a/board/amlogic/w400/README.khadas-vim3l +++ b/board/amlogic/w400/README.khadas-vim3l @@ -29,7 +29,6 @@ Currently the U-Boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make khadas-vim3l_defconfig makediff --git a/board/amlogic/w400/README.odroid-n2 b/board/amlogic/w400/README.odroid-n2 index a8f2c3d7daa6..8142eebea007 100644 --- a/board/amlogic/w400/README.odroid-n2 +++ b/board/amlogic/w400/README.odroid-n2 @@ -28,7 +28,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make odroid-n2_defconfig makediff --git a/board/amlogic/w400/README.w400 b/board/amlogic/w400/README.w400 index 25b786d817c4..c129717a1189 100644 --- a/board/amlogic/w400/README.w400 +++ b/board/amlogic/w400/README.w400 @@ -27,7 +27,6 @@ Currently the u-boot port supports the following devices: u-boot compilation ==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make w400_defconfig make
Acked-by: Neil Armstrong narmstrong@baylibre.com
participants (5)
Amit Tomer
Kever Yang
Neil Armstrong
