[PATCH 1/5] ARM: stm32: Permit multiple board targets
Setting TARGET_STM32MP1 in Kconfig always forces SYS_BOARD, SYS_VENDOR and SYS_CONFIG_NAME to values set by the ST reference platforms. Allow changing that by pulling out the TARGET_STM32MP157C_DK2 and making the ST reference platform settings conditional on TARGET_STM32MP157C_DK2 . Other platforms can now define a different TARGET_ and thus override the SYS_ settings in their Kconfig.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com --- board/st/stm32mp1/Kconfig | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/board/st/stm32mp1/Kconfig b/board/st/stm32mp1/Kconfig index 4fa2360b4f..c84aa41f06 100644 --- a/board/st/stm32mp1/Kconfig +++ b/board/st/stm32mp1/Kconfig @@ -1,4 +1,8 @@ -if TARGET_STM32MP1 +config TARGET_STM32MP157C_DK2 + bool "support of STMicroelectronics STM32MP157C-DK2 Discovery Board" + default y + +if TARGET_STM32MP157C_DK2
config SYS_BOARD default "stm32mp1" @@ -22,8 +26,4 @@ config CMD_STBOARD This compile the stboard command to read and write the board in the OTP.
-config TARGET_STM32MP157C_DK2 - bool "support of STMicroelectronics STM32MP157C-DK2 Discovery Board" - default y - endif
Let board code override setup_mac_address(), which is useful e.g. if the board derives the MAC address from another source, like an I2C EEPROM.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com --- V2: Add prototype to sys_proto.h --- arch/arm/mach-stm32mp/cpu.c | 2 +- arch/arm/mach-stm32mp/include/mach/sys_proto.h | 2 ++ 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 6a71465494..de7891b5c4 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -456,7 +456,7 @@ static void setup_boot_mode(void) * If there is no MAC address in the environment, then it will be initialized * (silently) from the value in the OTP. */ -static int setup_mac_address(void) +__weak int setup_mac_address(void) { #if defined(CONFIG_NET) int ret; diff --git a/arch/arm/mach-stm32mp/include/mach/sys_proto.h b/arch/arm/mach-stm32mp/include/mach/sys_proto.h index 99eefabf6e..47e57922d1 100644 --- a/arch/arm/mach-stm32mp/include/mach/sys_proto.h +++ b/arch/arm/mach-stm32mp/include/mach/sys_proto.h @@ -30,3 +30,5 @@ u32 get_cpu_package(void);
/* return boot mode */ u32 get_bootmode(void); + +int setup_mac_address(void);
Since CONFIG_LOADADDR is not set, the default value of $loadaddr variable is not set in the environment either. Set the default load address to 256 MiB from the start of DRAM.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com --- include/configs/stm32mp1.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 655833428e..b23dd38794 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -36,6 +36,7 @@ * Needed by "loadb" */ #define CONFIG_SYS_LOAD_ADDR STM32_DDR_BASE +#define CONFIG_LOADADDR 0xd0000000
/* ATAGs */ #define CONFIG_CMDLINE_TAG
Hi Marek,
From: Marek Vasut marex@denx.de Sent: vendredi 10 janvier 2020 01:29
- Needed by "loadb"
A offset a 256 MiB is really huge... And I don't sure that will fit all the commands (bootm with zImage as it is xpecting to be placed in the first 128 MiB of RAM) and all the products (with lower memory)
I propose to have the same value for the 2 defines which define the default loadaddr with 32MB offset (same value that kernel_addr_r).
in stm32mp1.h, the defines becomes:
/* * default load address used for command tftp, bootm , loadb, ... */ #define CONFIG_LOADADDR 0xc2000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
Regards Patrick
On 1/13/20 10:06 AM, Patrick DELAUNAY wrote:
Hi Marek,
- Needed by "loadb"
That's OK.
Hi Marek,
From: Marek Vasut marex@denx.de Sent: mercredi 15 janvier 2020 10:51
Hi Marek,
- Needed by "loadb"
STM32_DDR_BASE
That's OK.
I take the patch with thte proposed offset = 32MB.
/* - * Needed by "loadb" + * default load address used for command tftp, bootm , loadb, ... */ -#define CONFIG_SYS_LOAD_ADDR STM32_DDR_BASE +#define CONFIG_LOADADDR 0xc2000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
Applied to u-boot-stm32/master, thanks!
Regards Patrick
Add missing 'eth-ck' clock to the ethernet node. These clock are used to generate external clock signal for the PHY in case 'st,eth_ref_clk_sel' is specified.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com --- arch/arm/dts/stm32mp157c.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/stm32mp157c.dtsi b/arch/arm/dts/stm32mp157c.dtsi index 6c670cf9a3..41aea75213 100644 --- a/arch/arm/dts/stm32mp157c.dtsi +++ b/arch/arm/dts/stm32mp157c.dtsi @@ -1404,11 +1404,13 @@ clock-names = "stmmaceth", "mac-clk-tx", "mac-clk-rx", + "eth-ck", "ethstp", "syscfg-clk"; clocks = <&rcc ETHMAC>, <&rcc ETHTX>, <&rcc ETHRX>, + <&rcc ETHCK_K>, <&rcc ETHSTP>, <&rcc SYSCFG>; st,syscon = <&syscfg 0x4>;
Hi Marek
Adding Christophe Roullier
Adding this clock is a particular case, it should be added in the board DT file, not in the SoC DT one.
Our ethernet expert ( Christophe -in CC) is surprised that you don't need the following pin:
<STM32_PINMUX('G', 8, AF2)>, /* ETH_RMII_ETHCK */
To confirm, can you describe your ethernet config ?
Thanks
On 1/13/20 1:50 PM, Patrice CHOTARD wrote:
Hi Marek
I need 50 MHz RMII clock output for PHY on PA1, PG8 is completely unused.
Hi Marek,
+ Christophe (Maintainer in kernel)
This clock is optional, not needed by default for STM32MP15x: this clock is used only for a specific case: Phy without quartz, for all the other case we don't need to switch on this clock.
Normally if it is the case, it should be done in board part, not in SOC device tree (is is the strategy chosen by kernel). Moreover stm32mp157c.dtsi is just a copy of the kernel one, so this patch also need to be accepted by Kernel Maintainers.
NB: if you are in the Phy without crytal 50MHz (rmii + "st,eth_ref_clk_sel" + "eth-ck"), You should have also the associated pin in the device tree of the board :
+ <STM32_PINMUX('G', 8, AF2)>, /* ETH_RMII_ETHCK */
Christophe you can complete my answer if it is not enough clear.
regards
Patrick
On 1/13/20 2:26 PM, Patrick DELAUNAY wrote:
Hi Marek,
- Christophe (Maintainer in kernel)
That's the usecase here.
My PHY is _NOT_ connected to this pin, the output clock of the SoC are PA1.
I would expect that you should describe _all_ the clock which are routed into the ethernet IP in the DT and if the driver doesn't need some of those clock, the driver should just not enable such clock.
Hi Marek,
Hi Marek,
You are right, we will add by default all clocks used by stm32mp157, and modify driver to decide if we need to enable it or not.
So ACK to add ETHCK_K in stm32mp157c.dtsi
Regards,
Christophe
On 1/13/20 5:14 PM, Christophe ROULLIER wrote: [...]
Hi Marek,
Do you want me to send the kernel patch ? I have it somewhere here too, I can roll it out tomorrow-ish.
Hi Marek,
Hi Marek,
I have not changed yet, the kernel and uboot driver code, to manage this behavior. I will implement and push new code soon.
Regards
Christophe.
Hi Marek,
Hi Marek,
The kernel code already does what is needed. You only need similar patch to the DT, cfr attachment.
Hi Marek,
Hi Marek,
Yes, I'm aligned Marek (I've also done the glue driver in kernel :-))
But what I need to do in uboot and kernel driver it is to add by default all clocks in dtsi file
and modified driver to manage them in my driver (enable or disable it in function of phy mode, if with or without quartz in PHY etc..)
Regards,
Christophe.
Hi Marek,
From: Christophe ROULLIER christophe.roullier@st.com Sent: lundi 13 janvier 2020 17:15
Hi Marek,
"eth-ck"),
Hi Marek,
Christophe: thanks for ACK,
Reviewed-by: Patrick Delaunay patrick.delaunay@st.com
And I add the patch in U-Boot device tree by advance (the only possible impact is to switch on a not used clock).
Regards Patrick
Add support for DH Electronics DHCOM SoM and PDK2 rev. 400 carrier board. This is an SoM with STM32MP157C and an evaluation kit. The baseboard provides Ethernet, UART, USB, CAN and optional display.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com --- arch/arm/dts/Makefile | 1 + .../arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dts | 7 + arch/arm/dts/stm32mp157c-dhcom-pdk2.dts | 88 ++ arch/arm/dts/stm32mp157c-dhcom-u-boot.dtsi | 238 ++++++ arch/arm/dts/stm32mp157c-dhcom.dtsi | 379 +++++++++ arch/arm/mach-stm32mp/Kconfig | 1 + board/dhelectronics/dh_stm32mp1/Kconfig | 25 + board/dhelectronics/dh_stm32mp1/MAINTAINERS | 7 + board/dhelectronics/dh_stm32mp1/Makefile | 12 + board/dhelectronics/dh_stm32mp1/board.c | 777 ++++++++++++++++++ configs/stm32mp15_dhcom_basic_defconfig | 140 ++++ 11 files changed, 1675 insertions(+) create mode 100644 arch/arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dts create mode 100644 arch/arm/dts/stm32mp157c-dhcom-pdk2.dts create mode 100644 arch/arm/dts/stm32mp157c-dhcom-u-boot.dtsi create mode 100644 arch/arm/dts/stm32mp157c-dhcom.dtsi create mode 100644 board/dhelectronics/dh_stm32mp1/Kconfig create mode 100644 board/dhelectronics/dh_stm32mp1/MAINTAINERS create mode 100644 board/dhelectronics/dh_stm32mp1/Makefile create mode 100644 board/dhelectronics/dh_stm32mp1/board.c create mode 100644 configs/stm32mp15_dhcom_basic_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 983e235f44..82489bc09c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -859,6 +859,7 @@ dtb-$(CONFIG_ARCH_STI) += stih410-b2260.dtb dtb-$(CONFIG_TARGET_STM32MP1) += \ stm32mp157a-dk1.dtb \ stm32mp157a-avenger96.dtb \ + stm32mp157c-dhcom-pdk2-u-boot.dtb \ stm32mp157c-dk2.dtb \ stm32mp157c-ed1.dtb \ stm32mp157c-ev1.dtb diff --git a/arch/arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dts b/arch/arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dts new file mode 100644 index 0000000000..fd99988570 --- /dev/null +++ b/arch/arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dts @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2019 Marek Vasut marex@denx.de + */ + +#include "stm32mp157c-dhcom-pdk2.dts" +#include "stm32mp157c-dhcom-u-boot.dtsi" diff --git a/arch/arm/dts/stm32mp157c-dhcom-pdk2.dts b/arch/arm/dts/stm32mp157c-dhcom-pdk2.dts new file mode 100644 index 0000000000..05aa545f55 --- /dev/null +++ b/arch/arm/dts/stm32mp157c-dhcom-pdk2.dts @@ -0,0 +1,88 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2019 Marek Vasut marex@denx.de + */ + +#include "stm32mp157c-dhcom.dtsi" + +/ { + model = "STMicroelectronics STM32MP157C DHCOM Premium Developer Kit (2)"; + compatible = "dh,stm32mp157c-dhcom-pdk2", "st,stm32mp157"; + + aliases { + serial0 = &uart4; + ethernet0 = ðernet0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + ethernet_vio: vioregulator { + compatible = "regulator-fixed"; + regulator-name = "vio"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpiog 3 GPIO_ACTIVE_LOW>; + regulator-always-on; + regulator-boot-on; + }; +}; + +ðernet0 { + status = "okay"; + pinctrl-0 = <ðernet0_rmii_pins_a>; + pinctrl-1 = <ðernet0_rmii_pins_sleep_a>; + pinctrl-names = "default", "sleep"; + phy-mode = "rmii"; + max-speed = <100>; + phy-handle = <&phy0>; + st,eth_ref_clk_sel; + phy-reset-gpios = <&gpioh 15 GPIO_ACTIVE_LOW>; + + mdio0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + + phy0: ethernet-phy@1 { + reg = <1>; + }; + }; +}; + +&pinctrl { + ethernet0_rmii_pins_a: rmii-0 { + pins1 { + pinmux = <STM32_PINMUX('G', 13, AF11)>, /* ETH1_RMII_TXD0 */ + <STM32_PINMUX('G', 14, AF11)>, /* ETH1_RMII_TXD1 */ + <STM32_PINMUX('B', 11, AF11)>, /* ETH1_RMII_TX_EN */ + <STM32_PINMUX('A', 1, AF0)>, /* ETH1_RMII_REF_CLK */ + <STM32_PINMUX('A', 2, AF11)>, /* ETH1_MDIO */ + <STM32_PINMUX('C', 1, AF11)>; /* ETH1_MDC */ + bias-disable; + drive-push-pull; + slew-rate = <2>; + }; + pins2 { + pinmux = <STM32_PINMUX('C', 4, AF11)>, /* ETH1_RMII_RXD0 */ + <STM32_PINMUX('C', 5, AF11)>, /* ETH1_RMII_RXD1 */ + <STM32_PINMUX('A', 7, AF11)>; /* ETH1_RMII_CRS_DV */ + bias-disable; + }; + }; + + ethernet0_rmii_pins_sleep_a: rmii-sleep-0 { + pins1 { + pinmux = <STM32_PINMUX('G', 13, ANALOG)>, /* ETH1_RMII_TXD0 */ + <STM32_PINMUX('G', 14, ANALOG)>, /* ETH1_RMII_TXD1 */ + <STM32_PINMUX('B', 11, ANALOG)>, /* ETH1_RMII_TX_EN */ + <STM32_PINMUX('A', 2, ANALOG)>, /* ETH1_MDIO */ + <STM32_PINMUX('C', 1, ANALOG)>, /* ETH1_MDC */ + <STM32_PINMUX('C', 4, ANALOG)>, /* ETH1_RMII_RXD0 */ + <STM32_PINMUX('C', 5, ANALOG)>, /* ETH1_RMII_RXD1 */ + <STM32_PINMUX('A', 1, ANALOG)>, /* ETH1_RMII_REF_CLK */ + <STM32_PINMUX('A', 7, ANALOG)>; /* ETH1_RMII_CRS_DV */ + }; + }; +}; diff --git a/arch/arm/dts/stm32mp157c-dhcom-u-boot.dtsi b/arch/arm/dts/stm32mp157c-dhcom-u-boot.dtsi new file mode 100644 index 0000000000..320912edd8 --- /dev/null +++ b/arch/arm/dts/stm32mp157c-dhcom-u-boot.dtsi @@ -0,0 +1,238 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2019 Marek Vasut marex@denx.de + */ + +#include <dt-bindings/clock/stm32mp1-clksrc.h> +#include "stm32mp157-u-boot.dtsi" +#include "stm32mp15-ddr3-2x4Gb-1066-binG.dtsi" + +/ { + aliases { + i2c1 = &i2c2; + i2c3 = &i2c4; + i2c4 = &i2c5; + mmc0 = &sdmmc1; + mmc1 = &sdmmc2; + spi0 = &qspi; + usb0 = &usbotg_hs; + }; + + config { + u-boot,boot-led = "heartbeat"; + u-boot,error-led = "error"; + st,fastboot-gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; + st,stm32prog-gpios = <&gpioa 14 GPIO_ACTIVE_LOW>; + }; + + led { + red { + label = "error"; + gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; + default-state = "off"; + status = "okay"; + }; + + blue { + default-state = "on"; + }; + }; +}; + +&i2c4 { + u-boot,dm-pre-reloc; +}; + +&i2c4_pins_a { + u-boot,dm-pre-reloc; + pins { + u-boot,dm-pre-reloc; + }; +}; + +&pmic { + u-boot,dm-pre-reloc; +}; + +&flash0 { + u-boot,dm-spl; +}; + +&qspi { + u-boot,dm-spl; +}; + +&qspi_clk_pins_a { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +}; + +&qspi_bk1_pins_a { + u-boot,dm-spl; + pins1 { + u-boot,dm-spl; + }; + pins2 { + u-boot,dm-spl; + }; +}; + +&qspi_bk2_pins_a { + u-boot,dm-spl; + pins1 { + u-boot,dm-spl; + }; + pins2 { + u-boot,dm-spl; + }; +}; + +&rcc { + st,clksrc = < + CLK_MPU_PLL1P + CLK_AXI_PLL2P + CLK_MCU_PLL3P + CLK_PLL12_HSE + CLK_PLL3_HSE + CLK_PLL4_HSE + CLK_RTC_LSE + CLK_MCO1_DISABLED + CLK_MCO2_DISABLED + >; + + st,clkdiv = < + 1 /*MPU*/ + 0 /*AXI*/ + 0 /*MCU*/ + 1 /*APB1*/ + 1 /*APB2*/ + 1 /*APB3*/ + 1 /*APB4*/ + 2 /*APB5*/ + 23 /*RTC*/ + 0 /*MCO1*/ + 0 /*MCO2*/ + >; + + st,pkcs = < + CLK_CKPER_HSE + CLK_FMC_ACLK + CLK_QSPI_ACLK + CLK_ETH_PLL4P + CLK_SDMMC12_PLL4P + CLK_DSI_DSIPLL + CLK_STGEN_HSE + CLK_USBPHY_HSE + CLK_SPI2S1_PLL3Q + CLK_SPI2S23_PLL3Q + CLK_SPI45_HSI + CLK_SPI6_HSI + CLK_I2C46_HSI + CLK_SDMMC3_PLL4P + CLK_USBO_USBPHY + CLK_ADC_CKPER + CLK_CEC_LSE + CLK_I2C12_HSI + CLK_I2C35_HSI + CLK_UART1_HSI + CLK_UART24_HSI + CLK_UART35_HSI + CLK_UART6_HSI + CLK_UART78_HSI + CLK_SPDIF_PLL4P + CLK_FDCAN_PLL4Q + CLK_SAI1_PLL3Q + CLK_SAI2_PLL3Q + CLK_SAI3_PLL3Q + CLK_SAI4_PLL3Q + CLK_RNG1_LSI + CLK_RNG2_LSI + CLK_LPTIM1_PCLK1 + CLK_LPTIM23_PCLK3 + CLK_LPTIM45_LSE + >; + + /* VCO = 1300.0 MHz => P = 650 (CPU) */ + pll1: st,pll@0 { + cfg = < 2 80 0 0 0 PQR(1,0,0) >; + frac = < 0x800 >; + u-boot,dm-pre-reloc; + }; + + /* VCO = 1066.0 MHz => P = 266 (AXI), Q = 533 (GPU), R = 533 (DDR) */ + pll2: st,pll@1 { + cfg = < 2 65 1 0 0 PQR(1,1,1) >; + frac = < 0x1400 >; + u-boot,dm-pre-reloc; + }; + + /* VCO = 417.8 MHz => P = 209, Q = 24, R = 11 */ + pll3: st,pll@2 { + cfg = < 1 33 1 16 36 PQR(1,1,1) >; + frac = < 0x1a04 >; + u-boot,dm-pre-reloc; + }; + + /* VCO = 600.0 MHz => P = 50, Q = 50, R = 50 */ + pll4: st,pll@3 { + cfg = < 1 49 11 11 11 PQR(1,1,1) >; + u-boot,dm-pre-reloc; + }; +}; + +&sdmmc1 { + u-boot,dm-spl; +}; + +&sdmmc1_b4_pins_a { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +}; + +&sdmmc1_dir_pins_a { + u-boot,dm-spl; + pins1 { + u-boot,dm-spl; + }; + pins2 { + u-boot,dm-spl; + }; +}; + +&sdmmc2 { + u-boot,dm-spl; +}; + +&sdmmc2_b4_pins_a { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +}; + +&sdmmc2_d47_pins_a { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +}; + +&uart4 { + u-boot,dm-pre-reloc; +}; + +&uart4_pins_a { + u-boot,dm-pre-reloc; + pins1 { + u-boot,dm-pre-reloc; + }; + pins2 { + u-boot,dm-pre-reloc; + /* pull-up on rx to avoid floating level */ + bias-pull-up; + }; +}; diff --git a/arch/arm/dts/stm32mp157c-dhcom.dtsi b/arch/arm/dts/stm32mp157c-dhcom.dtsi new file mode 100644 index 0000000000..96661ae783 --- /dev/null +++ b/arch/arm/dts/stm32mp157c-dhcom.dtsi @@ -0,0 +1,379 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) 2019 Marek Vasut marex@denx.de + */ +/dts-v1/; + +#include "stm32mp157c.dtsi" +#include "stm32mp157xaa-pinctrl.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/mfd/st,stpmic1.h> + +/ { + memory@c0000000 { + device_type = "memory"; + reg = <0xC0000000 0x40000000>; + }; +}; + +&cec { + pinctrl-names = "default"; + pinctrl-0 = <&cec_pins_a>; + status = "okay"; +}; + +&dcmi { + status = "okay"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&dcmi_pins_a>; + pinctrl-1 = <&dcmi_sleep_pins_a>; +}; + +&dts { + status = "okay"; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins_a>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; +}; + +&i2c4 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c4_pins_a>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /* spare dmas for other usage */ + /delete-property/dmas; + /delete-property/dma-names; + + pmic: stpmic@33 { + compatible = "st,stpmic1"; + reg = <0x33>; + interrupts-extended = <&gpioa 0 IRQ_TYPE_EDGE_FALLING>; + interrupt-controller; + #interrupt-cells = <2>; + status = "okay"; + + regulators { + compatible = "st,stpmic1-regulators"; + ldo1-supply = <&v3v3>; + ldo2-supply = <&v3v3>; + ldo3-supply = <&vdd_ddr>; + ldo5-supply = <&v3v3>; + ldo6-supply = <&v3v3>; + pwr_sw1-supply = <&bst_out>; + pwr_sw2-supply = <&bst_out>; + + vddcore: buck1 { + regulator-name = "vddcore"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-initial-mode = <0>; + regulator-over-current-protection; + }; + + vdd_ddr: buck2 { + regulator-name = "vdd_ddr"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-initial-mode = <0>; + regulator-over-current-protection; + }; + + vdd: buck3 { + regulator-name = "vdd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + st,mask-reset; + regulator-initial-mode = <0>; + regulator-over-current-protection; + }; + + v3v3: buck4 { + regulator-name = "v3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-over-current-protection; + regulator-initial-mode = <0>; + }; + + vdda: ldo1 { + regulator-name = "vdda"; + regulator-min-microvolt = <2900000>; + regulator-max-microvolt = <2900000>; + interrupts = <IT_CURLIM_LDO1 0>; + }; + + v2v8: ldo2 { + regulator-name = "v2v8"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + interrupts = <IT_CURLIM_LDO2 0>; + }; + + vtt_ddr: ldo3 { + regulator-name = "vtt_ddr"; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <750000>; + regulator-always-on; + regulator-over-current-protection; + }; + + vdd_usb: ldo4 { + regulator-name = "vdd_usb"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + interrupts = <IT_CURLIM_LDO4 0>; + }; + + vdd_sd: ldo5 { + regulator-name = "vdd_sd"; + regulator-min-microvolt = <2900000>; + regulator-max-microvolt = <2900000>; + interrupts = <IT_CURLIM_LDO5 0>; + regulator-boot-on; + }; + + v1v8: ldo6 { + regulator-name = "v1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + interrupts = <IT_CURLIM_LDO6 0>; + }; + + vref_ddr: vref_ddr { + regulator-name = "vref_ddr"; + regulator-always-on; + regulator-over-current-protection; + }; + + bst_out: boost { + regulator-name = "bst_out"; + interrupts = <IT_OCP_BOOST 0>; + }; + + vbus_otg: pwr_sw1 { + regulator-name = "vbus_otg"; + interrupts = <IT_OCP_OTG 0>; + }; + + vbus_sw: pwr_sw2 { + regulator-name = "vbus_sw"; + interrupts = <IT_OCP_SWOUT 0>; + regulator-active-discharge; + }; + }; + + onkey { + compatible = "st,stpmic1-onkey"; + interrupts = <IT_PONKEY_F 0>, <IT_PONKEY_R 0>; + interrupt-names = "onkey-falling", "onkey-rising"; + power-off-time-sec = <10>; + status = "okay"; + }; + + watchdog { + compatible = "st,stpmic1-wdt"; + status = "disabled"; + }; + }; + + eeprom@50 { + compatible = "atmel,24c02"; + reg = <0x50>; + pagesize = <16>; + }; +}; + +&i2c5 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c5_pins_a>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; +}; + +&ipcc { + status = "okay"; +}; + +&iwdg2 { + timeout-sec = <32>; + status = "okay"; +}; + +&m4_rproc { + mboxes = <&ipcc 0>, <&ipcc 1>, <&ipcc 2>; + mbox-names = "vq0", "vq1", "shutdown"; + status = "okay"; +}; + +&pwr { + pwr-regulators { + vdd-supply = <&vdd>; + vdd_3v3_usbfs-supply = <&vdd_usb>; + }; +}; + +&qspi { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&qspi_clk_pins_a &qspi_bk1_pins_a &qspi_bk2_pins_a>; + pinctrl-1 = <&qspi_clk_sleep_pins_a &qspi_bk1_sleep_pins_a &qspi_bk2_sleep_pins_a>; + reg = <0x58003000 0x1000>, <0x70000000 0x4000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + flash0: mx66l51235l@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-rx-bus-width = <4>; + spi-max-frequency = <108000000>; + #address-cells = <1>; + #size-cells = <1>; + }; + + flash1: mx66l51235l@1 { + compatible = "jedec,spi-nor"; + reg = <1>; + spi-rx-bus-width = <4>; + spi-max-frequency = <108000000>; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&rng1 { + status = "okay"; +}; + +&rtc { + status = "okay"; +}; + +&sdmmc1 { + pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_a>; + pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_a>; + pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_a>; + broken-cd; + st,sig-dir; + st,neg-edge; + st,use-ckin; + bus-width = <4>; + vmmc-supply = <&vdd_sd>; + status = "okay"; +}; + +&sdmmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_a>; + non-removable; + no-sd; + no-sdio; + st,sig-dir; + st,neg-edge; + bus-width = <8>; + vmmc-supply = <&v3v3>; + status = "okay"; +}; + +&spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&spi1_pins_a>; + status = "disabled"; +}; + +&timers2 { + /* spare dmas for other usage (un-delete to enable pwm capture) */ + /delete-property/dmas; + /delete-property/dma-names; + status = "disabled"; + pwm { + pinctrl-0 = <&pwm2_pins_a>; + pinctrl-names = "default"; + status = "okay"; + }; + timer@1 { + status = "okay"; + }; +}; + +&timers6 { + status = "okay"; + /* spare dmas for other usage */ + /delete-property/dmas; + /delete-property/dma-names; + timer@5 { + status = "okay"; + }; +}; + +&timers8 { + /delete-property/dmas; + /delete-property/dma-names; + status = "disabled"; + pwm { + pinctrl-0 = <&pwm8_pins_a>; + pinctrl-names = "default"; + status = "okay"; + }; + timer@7 { + status = "okay"; + }; +}; + +&timers12 { + /delete-property/dmas; + /delete-property/dma-names; + status = "disabled"; + pwm { + pinctrl-0 = <&pwm12_pins_a>; + pinctrl-names = "default"; + status = "okay"; + }; + timer@11 { + status = "okay"; + }; +}; + +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&uart4_pins_a>; + status = "okay"; +}; + +&usbh_ehci { + phys = <&usbphyc_port0>; + phy-names = "usb"; + status = "okay"; +}; + +&usbotg_hs { + dr_mode = "peripheral"; + phys = <&usbphyc_port1 0>; + phy-names = "usb2-phy"; + vbus-supply = <&vbus_otg>; + status = "okay"; +}; + +&usbphyc { + status = "okay"; +}; + +&usbphyc_port0 { + phy-supply = <&vdd_usb>; +}; + +&usbphyc_port1 { + phy-supply = <&vdd_usb>; +}; diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index ae28f6e206..1aa5f8a122 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -147,5 +147,6 @@ config DEBUG_UART_CLOCK endif
source "board/st/stm32mp1/Kconfig" +source "board/dhelectronics/dh_stm32mp1/Kconfig"
endif diff --git a/board/dhelectronics/dh_stm32mp1/Kconfig b/board/dhelectronics/dh_stm32mp1/Kconfig new file mode 100644 index 0000000000..e751a3e5ed --- /dev/null +++ b/board/dhelectronics/dh_stm32mp1/Kconfig @@ -0,0 +1,25 @@ +config TARGET_DH_STM32MP1_PDK2 + bool "support of DH STM32MP1 PDK2" + default y + +if TARGET_DH_STM32MP1_PDK2 + +config SYS_BOARD + default "dh_stm32mp1" + +config SYS_VENDOR + default "dhelectronics" + +config SYS_CONFIG_NAME + default "stm32mp1" + +config ENV_SECT_SIZE + default 0x10000 if ENV_IS_IN_SPI_FLASH + +config ENV_OFFSET + default 0x1E0000 if ENV_IS_IN_SPI_FLASH + +config ENV_OFFSET_REDUND + default 0x1F0000 if ENV_IS_IN_SPI_FLASH + +endif diff --git a/board/dhelectronics/dh_stm32mp1/MAINTAINERS b/board/dhelectronics/dh_stm32mp1/MAINTAINERS new file mode 100644 index 0000000000..38f54a3da4 --- /dev/null +++ b/board/dhelectronics/dh_stm32mp1/MAINTAINERS @@ -0,0 +1,7 @@ +DH_STM32MP1_PDK2 BOARD +M: Marek Vasut marex@denx.de +S: Maintained +F: arch/arm/dts/stm32mp157c-dhcom* +F: board/dhelectronics/dh_stm32mp1/ +F: configs/stm32mp15_dhcom_basic_defconfig +F: include/configs/stm32mp1.h diff --git a/board/dhelectronics/dh_stm32mp1/Makefile b/board/dhelectronics/dh_stm32mp1/Makefile new file mode 100644 index 0000000000..a9d28218ef --- /dev/null +++ b/board/dhelectronics/dh_stm32mp1/Makefile @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +# +# Copyright (C) 2018, STMicroelectronics - All Rights Reserved +# + +ifdef CONFIG_SPL_BUILD +obj-y += ../../st/stm32mp1/spl.o +else +obj-$(CONFIG_CMD_STBOARD) += ../../st/stm32mp1/cmd_stboard.o +endif + +obj-y += ../../st/stm32mp1/board.o board.o diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c new file mode 100644 index 0000000000..54cc3b7587 --- /dev/null +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -0,0 +1,777 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2018, STMicroelectronics - All Rights Reserved + */ + +#include <common.h> +#include <adc.h> +#include <asm/arch/stm32.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <bootm.h> +#include <clk.h> +#include <config.h> +#include <dm.h> +#include <dm/device.h> +#include <dm/uclass.h> +#include <env.h> +#include <env_internal.h> +#include <g_dnl.h> +#include <generic-phy.h> +#include <i2c.h> +#include <i2c_eeprom.h> +#include <init.h> +#include <led.h> +#include <memalign.h> +#include <misc.h> +#include <mtd.h> +#include <mtd_node.h> +#include <netdev.h> +#include <phy.h> +#include <power/regulator.h> +#include <remoteproc.h> +#include <reset.h> +#include <syscon.h> +#include <usb.h> +#include <usb/dwc2_udc.h> +#include <watchdog.h> + +/* SYSCFG registers */ +#define SYSCFG_BOOTR 0x00 +#define SYSCFG_PMCSETR 0x04 +#define SYSCFG_IOCTRLSETR 0x18 +#define SYSCFG_ICNR 0x1C +#define SYSCFG_CMPCR 0x20 +#define SYSCFG_CMPENSETR 0x24 +#define SYSCFG_PMCCLRR 0x44 + +#define SYSCFG_BOOTR_BOOT_MASK GENMASK(2, 0) +#define SYSCFG_BOOTR_BOOTPD_SHIFT 4 + +#define SYSCFG_IOCTRLSETR_HSLVEN_TRACE BIT(0) +#define SYSCFG_IOCTRLSETR_HSLVEN_QUADSPI BIT(1) +#define SYSCFG_IOCTRLSETR_HSLVEN_ETH BIT(2) +#define SYSCFG_IOCTRLSETR_HSLVEN_SDMMC BIT(3) +#define SYSCFG_IOCTRLSETR_HSLVEN_SPI BIT(4) + +#define SYSCFG_CMPCR_SW_CTRL BIT(1) +#define SYSCFG_CMPCR_READY BIT(8) + +#define SYSCFG_CMPENSETR_MPU_EN BIT(0) + +#define SYSCFG_PMCSETR_ETH_CLK_SEL BIT(16) +#define SYSCFG_PMCSETR_ETH_REF_CLK_SEL BIT(17) + +#define SYSCFG_PMCSETR_ETH_SELMII BIT(20) + +#define SYSCFG_PMCSETR_ETH_SEL_MASK GENMASK(23, 21) +#define SYSCFG_PMCSETR_ETH_SEL_GMII_MII 0 +#define SYSCFG_PMCSETR_ETH_SEL_RGMII BIT(21) +#define SYSCFG_PMCSETR_ETH_SEL_RMII BIT(23) + +/* + * Get a global data pointer + */ +DECLARE_GLOBAL_DATA_PTR; + +int setup_mac_address(void) +{ + struct udevice *dev; + ofnode eeprom; + unsigned char enetaddr[6]; + int ret; + + ret = eth_env_get_enetaddr("ethaddr", enetaddr); + if (ret) /* ethaddr is already set */ + return 0; + + eeprom = ofnode_path("/soc/i2c@5c002000/eeprom@50"); + if (!ofnode_valid(eeprom)) { + printf("Invalid hardware path to EEPROM!\n"); + return -ENODEV; + } + + ret = uclass_get_device_by_ofnode(UCLASS_I2C_EEPROM, eeprom, &dev); + if (ret) { + printf("Cannot find EEPROM!\n"); + return ret; + } + + ret = i2c_eeprom_read(dev, 0xfa, enetaddr, 0x6); + if (ret) { + printf("Error reading configuration EEPROM!\n"); + return ret; + } + + if (is_valid_ethaddr(enetaddr)) + eth_env_set_enetaddr("ethaddr", enetaddr); + + return 0; +} + +int checkboard(void) +{ + int ret; + char *mode; + u32 otp; + struct udevice *dev; + const char *fdt_compat; + int fdt_compat_len; + + if (IS_ENABLED(CONFIG_STM32MP1_OPTEE)) + mode = "trusted with OP-TEE"; + else if (IS_ENABLED(CONFIG_STM32MP1_TRUSTED)) + mode = "trusted"; + else + mode = "basic"; + + printf("Board: stm32mp1 in %s mode", mode); + fdt_compat = fdt_getprop(gd->fdt_blob, 0, "compatible", + &fdt_compat_len); + if (fdt_compat && fdt_compat_len) + printf(" (%s)", fdt_compat); + puts("\n"); + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(stm32mp_bsec), + &dev); + + if (!ret) + ret = misc_read(dev, STM32_BSEC_SHADOW(BSEC_OTP_BOARD), + &otp, sizeof(otp)); + if (ret > 0 && otp) { + printf("Board: MB%04x Var%d Rev.%c-%02d\n", + otp >> 16, + (otp >> 12) & 0xF, + ((otp >> 8) & 0xF) - 1 + 'A', + otp & 0xF); + } + + return 0; +} + +static void board_key_check(void) +{ +#if defined(CONFIG_FASTBOOT) || defined(CONFIG_CMD_STM32PROG) + ofnode node; + struct gpio_desc gpio; + enum forced_boot_mode boot_mode = BOOT_NORMAL; + + node = ofnode_path("/config"); + if (!ofnode_valid(node)) { + debug("%s: no /config node?\n", __func__); + return; + } +#ifdef CONFIG_FASTBOOT + if (gpio_request_by_name_nodev(node, "st,fastboot-gpios", 0, + &gpio, GPIOD_IS_IN)) { + debug("%s: could not find a /config/st,fastboot-gpios\n", + __func__); + } else { + if (dm_gpio_get_value(&gpio)) { + puts("Fastboot key pressed, "); + boot_mode = BOOT_FASTBOOT; + } + + dm_gpio_free(NULL, &gpio); + } +#endif +#ifdef CONFIG_CMD_STM32PROG + if (gpio_request_by_name_nodev(node, "st,stm32prog-gpios", 0, + &gpio, GPIOD_IS_IN)) { + debug("%s: could not find a /config/st,stm32prog-gpios\n", + __func__); + } else { + if (dm_gpio_get_value(&gpio)) { + puts("STM32Programmer key pressed, "); + boot_mode = BOOT_STM32PROG; + } + dm_gpio_free(NULL, &gpio); + } +#endif + + if (boot_mode != BOOT_NORMAL) { + puts("entering download mode...\n"); + clrsetbits_le32(TAMP_BOOT_CONTEXT, + TAMP_BOOT_FORCED_MASK, + boot_mode); + } +#endif +} + +#if defined(CONFIG_USB_GADGET) && defined(CONFIG_USB_GADGET_DWC2_OTG) + +/* STMicroelectronics STUSB1600 Type-C controller */ +#define STUSB1600_CC_CONNECTION_STATUS 0x0E + +/* STUSB1600_CC_CONNECTION_STATUS bitfields */ +#define STUSB1600_CC_ATTACH BIT(0) + +static int stusb1600_init(struct udevice **dev_stusb1600) +{ + ofnode node; + struct udevice *dev, *bus; + int ret; + u32 chip_addr; + + *dev_stusb1600 = NULL; + + /* if node stusb1600 is present, means DK1 or DK2 board */ + node = ofnode_by_compatible(ofnode_null(), "st,stusb1600"); + if (!ofnode_valid(node)) + return -ENODEV; + + ret = ofnode_read_u32(node, "reg", &chip_addr); + if (ret) + return -EINVAL; + + ret = uclass_get_device_by_ofnode(UCLASS_I2C, ofnode_get_parent(node), + &bus); + if (ret) { + printf("bus for stusb1600 not found\n"); + return -ENODEV; + } + + ret = dm_i2c_probe(bus, chip_addr, 0, &dev); + if (!ret) + *dev_stusb1600 = dev; + + return ret; +} + +static int stusb1600_cable_connected(struct udevice *dev) +{ + u8 status; + + if (dm_i2c_read(dev, STUSB1600_CC_CONNECTION_STATUS, &status, 1)) + return 0; + + return status & STUSB1600_CC_ATTACH; +} + +#include <usb/dwc2_udc.h> +int g_dnl_board_usb_cable_connected(void) +{ + struct udevice *stusb1600; + struct udevice *dwc2_udc_otg; + int ret; + + if (!stusb1600_init(&stusb1600)) + return stusb1600_cable_connected(stusb1600); + + ret = uclass_get_device_by_driver(UCLASS_USB_GADGET_GENERIC, + DM_GET_DRIVER(dwc2_udc_otg), + &dwc2_udc_otg); + if (!ret) + debug("dwc2_udc_otg init failed\n"); + + return dwc2_udc_B_session_valid(dwc2_udc_otg); +} + +#define STM32MP1_G_DNL_DFU_PRODUCT_NUM 0xdf11 +#define STM32MP1_G_DNL_FASTBOOT_PRODUCT_NUM 0x0afb + +int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) +{ + if (!strcmp(name, "usb_dnl_dfu")) + put_unaligned(STM32MP1_G_DNL_DFU_PRODUCT_NUM, &dev->idProduct); + else if (!strcmp(name, "usb_dnl_fastboot")) + put_unaligned(STM32MP1_G_DNL_FASTBOOT_PRODUCT_NUM, + &dev->idProduct); + else + put_unaligned(CONFIG_USB_GADGET_PRODUCT_NUM, &dev->idProduct); + + return 0; +} + +#endif /* CONFIG_USB_GADGET */ + +#ifdef CONFIG_LED +static int get_led(struct udevice **dev, char *led_string) +{ + char *led_name; + int ret; + + led_name = fdtdec_get_config_string(gd->fdt_blob, led_string); + if (!led_name) { + pr_debug("%s: could not find %s config string\n", + __func__, led_string); + return -ENOENT; + } + ret = led_get_by_label(led_name, dev); + if (ret) { + debug("%s: get=%d\n", __func__, ret); + return ret; + } + + return 0; +} + +static int setup_led(enum led_state_t cmd) +{ + struct udevice *dev; + int ret; + + ret = get_led(&dev, "u-boot,boot-led"); + if (ret) + return ret; + + ret = led_set_state(dev, cmd); + return ret; +} +#endif + +static void __maybe_unused led_error_blink(u32 nb_blink) +{ +#ifdef CONFIG_LED + int ret; + struct udevice *led; + u32 i; +#endif + + if (!nb_blink) + return; + +#ifdef CONFIG_LED + ret = get_led(&led, "u-boot,error-led"); + if (!ret) { + /* make u-boot,error-led blinking */ + /* if U32_MAX and 125ms interval, for 17.02 years */ + for (i = 0; i < 2 * nb_blink; i++) { + led_set_state(led, LEDST_TOGGLE); + mdelay(125); + WATCHDOG_RESET(); + } + } +#endif + + /* infinite: the boot process must be stopped */ + if (nb_blink == U32_MAX) + hang(); +} + +static void sysconf_init(void) +{ +#ifndef CONFIG_STM32MP1_TRUSTED + u8 *syscfg; +#ifdef CONFIG_DM_REGULATOR + struct udevice *pwr_dev; + struct udevice *pwr_reg; + struct udevice *dev; + int ret; + u32 otp = 0; +#endif + u32 bootr; + + syscfg = (u8 *)syscon_get_first_range(STM32MP_SYSCON_SYSCFG); + + /* interconnect update : select master using the port 1 */ + /* LTDC = AXI_M9 */ + /* GPU = AXI_M8 */ + /* today information is hardcoded in U-Boot */ + writel(BIT(9), syscfg + SYSCFG_ICNR); + + /* disable Pull-Down for boot pin connected to VDD */ + bootr = readl(syscfg + SYSCFG_BOOTR); + bootr &= ~(SYSCFG_BOOTR_BOOT_MASK << SYSCFG_BOOTR_BOOTPD_SHIFT); + bootr |= (bootr & SYSCFG_BOOTR_BOOT_MASK) << SYSCFG_BOOTR_BOOTPD_SHIFT; + writel(bootr, syscfg + SYSCFG_BOOTR); + +#ifdef CONFIG_DM_REGULATOR + /* High Speed Low Voltage Pad mode Enable for SPI, SDMMC, ETH, QSPI + * and TRACE. Needed above ~50MHz and conditioned by AFMUX selection. + * The customer will have to disable this for low frequencies + * or if AFMUX is selected but the function not used, typically for + * TRACE. Otherwise, impact on power consumption. + * + * WARNING: + * enabling High Speed mode while VDD>2.7V + * with the OTP product_below_2v5 (OTP 18, BIT 13) + * erroneously set to 1 can damage the IC! + * => U-Boot set the register only if VDD < 2.7V (in DT) + * but this value need to be consistent with board design + */ + ret = uclass_get_device_by_driver(UCLASS_PMIC, + DM_GET_DRIVER(stm32mp_pwr_pmic), + &pwr_dev); + if (!ret) { + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(stm32mp_bsec), + &dev); + if (ret) { + pr_err("Can't find stm32mp_bsec driver\n"); + return; + } + + ret = misc_read(dev, STM32_BSEC_SHADOW(18), &otp, 4); + if (ret > 0) + otp = otp & BIT(13); + + /* get VDD = vdd-supply */ + ret = device_get_supply_regulator(pwr_dev, "vdd-supply", + &pwr_reg); + + /* check if VDD is Low Voltage */ + if (!ret) { + if (regulator_get_value(pwr_reg) < 2700000) { + writel(SYSCFG_IOCTRLSETR_HSLVEN_TRACE | + SYSCFG_IOCTRLSETR_HSLVEN_QUADSPI | + SYSCFG_IOCTRLSETR_HSLVEN_ETH | + SYSCFG_IOCTRLSETR_HSLVEN_SDMMC | + SYSCFG_IOCTRLSETR_HSLVEN_SPI, + syscfg + SYSCFG_IOCTRLSETR); + + if (!otp) + pr_err("product_below_2v5=0: HSLVEN protected by HW\n"); + } else { + if (otp) + pr_err("product_below_2v5=1: HSLVEN update is destructive, no update as VDD>2.7V\n"); + } + } else { + debug("VDD unknown"); + } + } +#endif + + /* activate automatic I/O compensation + * warning: need to ensure CSI enabled and ready in clock driver + */ + writel(SYSCFG_CMPENSETR_MPU_EN, syscfg + SYSCFG_CMPENSETR); + + while (!(readl(syscfg + SYSCFG_CMPCR) & SYSCFG_CMPCR_READY)) + ; + clrbits_le32(syscfg + SYSCFG_CMPCR, SYSCFG_CMPCR_SW_CTRL); +#endif +} + +/* board dependent setup after realloc */ +int board_init(void) +{ + struct udevice *dev; + + /* address of boot parameters */ + gd->bd->bi_boot_params = STM32_DDR_BASE + 0x100; + + /* probe all PINCTRL for hog */ + for (uclass_first_device(UCLASS_PINCTRL, &dev); + dev; + uclass_next_device(&dev)) { + pr_debug("probe pincontrol = %s\n", dev->name); + } + + board_key_check(); + +#ifdef CONFIG_DM_REGULATOR + regulators_enable_boot_on(_DEBUG); +#endif + + sysconf_init(); + + if (CONFIG_IS_ENABLED(CONFIG_LED)) + led_default_state(); + + return 0; +} + +int board_late_init(void) +{ + char *boot_device; +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + const void *fdt_compat; + int fdt_compat_len; + int ret; + u32 otp; + struct udevice *dev; + char buf[10]; + + fdt_compat = fdt_getprop(gd->fdt_blob, 0, "compatible", + &fdt_compat_len); + if (fdt_compat && fdt_compat_len) { + if (strncmp(fdt_compat, "st,", 3) != 0) + env_set("board_name", fdt_compat); + else + env_set("board_name", fdt_compat + 3); + } + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(stm32mp_bsec), + &dev); + + if (!ret) + ret = misc_read(dev, STM32_BSEC_SHADOW(BSEC_OTP_BOARD), + &otp, sizeof(otp)); + if (!ret && otp) { + snprintf(buf, sizeof(buf), "0x%04x", otp >> 16); + env_set("board_id", buf); + + snprintf(buf, sizeof(buf), "0x%04x", + ((otp >> 8) & 0xF) - 1 + 0xA); + env_set("board_rev", buf); + } +#endif + + /* Check the boot-source to disable bootdelay */ + boot_device = env_get("boot_device"); + if (!strcmp(boot_device, "serial") || !strcmp(boot_device, "usb")) + env_set("bootdelay", "0"); + + return 0; +} + +void board_quiesce_devices(void) +{ +#ifdef CONFIG_LED + setup_led(LEDST_OFF); +#endif +} + +/* eth init function : weak called in eqos driver */ +int board_interface_eth_init(struct udevice *dev, + phy_interface_t interface_type) +{ + u8 *syscfg; + u32 value; + bool eth_clk_sel_reg = false; + bool eth_ref_clk_sel_reg = false; + + /* Gigabit Ethernet 125MHz clock selection. */ + eth_clk_sel_reg = dev_read_bool(dev, "st,eth_clk_sel"); + + /* Ethernet 50Mhz RMII clock selection */ + eth_ref_clk_sel_reg = + dev_read_bool(dev, "st,eth_ref_clk_sel"); + + syscfg = (u8 *)syscon_get_first_range(STM32MP_SYSCON_SYSCFG); + + if (!syscfg) + return -ENODEV; + + switch (interface_type) { + case PHY_INTERFACE_MODE_MII: + value = SYSCFG_PMCSETR_ETH_SEL_GMII_MII | + SYSCFG_PMCSETR_ETH_REF_CLK_SEL; + debug("%s: PHY_INTERFACE_MODE_MII\n", __func__); + break; + case PHY_INTERFACE_MODE_GMII: + if (eth_clk_sel_reg) + value = SYSCFG_PMCSETR_ETH_SEL_GMII_MII | + SYSCFG_PMCSETR_ETH_CLK_SEL; + else + value = SYSCFG_PMCSETR_ETH_SEL_GMII_MII; + debug("%s: PHY_INTERFACE_MODE_GMII\n", __func__); + break; + case PHY_INTERFACE_MODE_RMII: + if (eth_ref_clk_sel_reg) + value = SYSCFG_PMCSETR_ETH_SEL_RMII | + SYSCFG_PMCSETR_ETH_REF_CLK_SEL; + else + value = SYSCFG_PMCSETR_ETH_SEL_RMII; + debug("%s: PHY_INTERFACE_MODE_RMII\n", __func__); + break; + case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_RGMII_ID: + case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_TXID: + if (eth_clk_sel_reg) + value = SYSCFG_PMCSETR_ETH_SEL_RGMII | + SYSCFG_PMCSETR_ETH_CLK_SEL; + else + value = SYSCFG_PMCSETR_ETH_SEL_RGMII; + debug("%s: PHY_INTERFACE_MODE_RGMII\n", __func__); + break; + default: + debug("%s: Do not manage %d interface\n", + __func__, interface_type); + /* Do not manage others interfaces */ + return -EINVAL; + } + + /* clear and set ETH configuration bits */ + writel(SYSCFG_PMCSETR_ETH_SEL_MASK | SYSCFG_PMCSETR_ETH_SELMII | + SYSCFG_PMCSETR_ETH_REF_CLK_SEL | SYSCFG_PMCSETR_ETH_CLK_SEL, + syscfg + SYSCFG_PMCCLRR); + writel(value, syscfg + SYSCFG_PMCSETR); + + return 0; +} + +enum env_location env_get_location(enum env_operation op, int prio) +{ + if (prio) + return ENVL_UNKNOWN; + +#ifdef CONFIG_ENV_IS_IN_SPI_FLASH + return ENVL_SPI_FLASH; +#else + return ENVL_NOWHERE; +#endif +} + +#ifdef CONFIG_SYS_MTDPARTS_RUNTIME + +#define MTDPARTS_LEN 256 +#define MTDIDS_LEN 128 + +/** + * The mtdparts_nand0 and mtdparts_nor0 variable tends to be long. + * If we need to access it before the env is relocated, then we need + * to use our own stack buffer. gd->env_buf will be too small. + * + * @param buf temporary buffer pointer MTDPARTS_LEN long + * @return mtdparts variable string, NULL if not found + */ +static const char *env_get_mtdparts(const char *str, char *buf) +{ + if (gd->flags & GD_FLG_ENV_READY) + return env_get(str); + if (env_get_f(str, buf, MTDPARTS_LEN) != -1) + return buf; + + return NULL; +} + +/** + * update the variables "mtdids" and "mtdparts" with content of mtdparts_<dev> + */ +static void board_get_mtdparts(const char *dev, + char *mtdids, + char *mtdparts) +{ + char env_name[32] = "mtdparts_"; + char tmp_mtdparts[MTDPARTS_LEN]; + const char *tmp; + + /* name of env variable to read = mtdparts_<dev> */ + strcat(env_name, dev); + tmp = env_get_mtdparts(env_name, tmp_mtdparts); + if (tmp) { + /* mtdids: "<dev>=<dev>, ...." */ + if (mtdids[0] != '\0') + strcat(mtdids, ","); + strcat(mtdids, dev); + strcat(mtdids, "="); + strcat(mtdids, dev); + + /* mtdparts: "mtdparts=<dev>:<mtdparts_<dev>>;..." */ + if (mtdparts[0] != '\0') + strncat(mtdparts, ";", MTDPARTS_LEN); + else + strcat(mtdparts, "mtdparts="); + strncat(mtdparts, dev, MTDPARTS_LEN); + strncat(mtdparts, ":", MTDPARTS_LEN); + strncat(mtdparts, tmp, MTDPARTS_LEN); + } +} + +void board_mtdparts_default(const char **mtdids, const char **mtdparts) +{ + struct udevice *dev; + static char parts[3 * MTDPARTS_LEN + 1]; + static char ids[MTDIDS_LEN + 1]; + static bool mtd_initialized; + + if (mtd_initialized) { + *mtdids = ids; + *mtdparts = parts; + return; + } + + memset(parts, 0, sizeof(parts)); + memset(ids, 0, sizeof(ids)); + + /* probe all MTD devices */ + for (uclass_first_device(UCLASS_MTD, &dev); + dev; + uclass_next_device(&dev)) { + pr_debug("mtd device = %s\n", dev->name); + } + + if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) + board_get_mtdparts("nor0", ids, parts); + + mtd_initialized = true; + *mtdids = ids; + *mtdparts = parts; + debug("%s:mtdids=%s & mtdparts=%s\n", __func__, ids, parts); +} +#endif + +#if defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + return 0; +} +#endif + +#ifdef CONFIG_SET_DFU_ALT_INFO +#define DFU_ALT_BUF_LEN SZ_1K + +static void board_get_alt_info(const char *dev, char *buff) +{ + char var_name[32] = "dfu_alt_info_"; + int ret; + + ALLOC_CACHE_ALIGN_BUFFER(char, tmp_alt, DFU_ALT_BUF_LEN); + + /* name of env variable to read = dfu_alt_info_<dev> */ + strcat(var_name, dev); + ret = env_get_f(var_name, tmp_alt, DFU_ALT_BUF_LEN); + if (ret) { + if (buff[0] != '\0') + strcat(buff, "&"); + strncat(buff, tmp_alt, DFU_ALT_BUF_LEN); + } +} + +void set_dfu_alt_info(char *interface, char *devstr) +{ + struct udevice *dev; + + ALLOC_CACHE_ALIGN_BUFFER(char, buf, DFU_ALT_BUF_LEN); + + if (env_get("dfu_alt_info")) + return; + + memset(buf, 0, sizeof(buf)); + + /* probe all MTD devices */ + mtd_probe_devices(); + + board_get_alt_info("ram", buf); + + if (!uclass_get_device(UCLASS_MMC, 0, &dev)) + board_get_alt_info("mmc0", buf); + + if (!uclass_get_device(UCLASS_MMC, 1, &dev)) + board_get_alt_info("mmc1", buf); + + if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) + board_get_alt_info("nor0", buf); + + env_set("dfu_alt_info", buf); + puts("DFU alt info setting: done\n"); +} +#endif + +static void board_copro_image_process(ulong fw_image, size_t fw_size) +{ + int ret, id = 0; /* Copro id fixed to 0 as only one coproc on mp1 */ + + if (!rproc_is_initialized()) + if (rproc_init()) { + printf("Remote Processor %d initialization failed\n", + id); + return; + } + + ret = rproc_load(id, fw_image, fw_size); + printf("Load Remote Processor %d with data@addr=0x%08lx %u bytes:%s\n", + id, fw_image, fw_size, ret ? " Failed!" : " Success!"); + + if (!ret) { + rproc_start(id); + env_set("copro_state", "booted"); + } +} + +U_BOOT_FIT_LOADABLE_HANDLER(IH_TYPE_COPRO, board_copro_image_process); diff --git a/configs/stm32mp15_dhcom_basic_defconfig b/configs/stm32mp15_dhcom_basic_defconfig new file mode 100644 index 0000000000..e4f331a913 --- /dev/null +++ b/configs/stm32mp15_dhcom_basic_defconfig @@ -0,0 +1,140 @@ +CONFIG_ARM=y +CONFIG_ARCH_STM32MP=y +CONFIG_SYS_MALLOC_F_LEN=0x3000 +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_SPL=y +CONFIG_TARGET_STM32MP1=y +# CONFIG_TARGET_STM32MP157C_DK2 is not set +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +# CONFIG_ARMV7_VIRT is not set +CONFIG_SPL_TEXT_BASE=0x2FFC2500 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +# CONFIG_BOOTSTAGE is not set +CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 +CONFIG_SYS_PROMPT="STM32MP> " +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +CONFIG_CMD_EEPROM=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_ADC=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_REMOTEPROC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_MTDPARTS=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-dhcom-pdk2-u-boot" +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-names interrupts-extended interrupt-controller \#interrupt-cells interrupt-parent dmas dma-names assigned-clocks assigned-clock-rates assigned-clock-parents hwlocks" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=0 +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=0 +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=10000000 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0x0 +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_IP_DEFRAG=y +CONFIG_TFTP_BLOCKSIZE=1536 +CONFIG_STM32_ADC=y +CONFIG_SPL_BLOCK_CACHE=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_VIRT=y +CONFIG_DM_HWSPINLOCK=y +CONFIG_HWSPINLOCK_STM32=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_STM32F7=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_DM_MAILBOX=y +CONFIG_STM32_IPCC=y +CONFIG_I2C_EEPROM=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_STM32_SDMMC2=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPL_SPI_FLASH_MTD=y +CONFIG_DM_ETH=y +CONFIG_DWC_ETH_QOS=y +CONFIG_PHY=y +CONFIG_PHY_STM32_USBPHYC=y +CONFIG_PINCONF=y +# CONFIG_SPL_PINCTRL_FULL is not set +CONFIG_PINCTRL_STMFX=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_PMIC_STPMIC1=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_REGULATOR_STM32_VREFBUF=y +CONFIG_DM_REGULATOR_STPMIC1=y +CONFIG_REMOTEPROC_STM32_COPRO=y +CONFIG_DM_RTC=y +CONFIG_RTC_STM32=y +CONFIG_SERIAL_RX_BUFFER=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_STM32_QSPI=y +CONFIG_STM32_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="dh" +CONFIG_USB_GADGET_VENDOR_NUM=0x0483 +CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y +CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y +CONFIG_VIDEO_LCD_RAYDIUM_RM68200=y +CONFIG_VIDEO_STM32=y +CONFIG_VIDEO_STM32_DSI=y +CONFIG_VIDEO_STM32_MAX_XRES=1280 +CONFIG_VIDEO_STM32_MAX_YRES=800 +CONFIG_LZO=y +CONFIG_FDT_FIXUP_PARTITIONS=y
Hi Marek,
From: Marek Vasut marex@denx.de Sent: vendredi 10 janvier 2020 01:29 To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Patrick DELAUNAY patrick.delaunay@st.com; Patrice CHOTARD patrice.chotard@st.com Subject: [PATCH 5/5] ARM: dts: stm32: Add DH Electronics DHCOM SoM and PDK2 board Importance: High
Add support for DH Electronics DHCOM SoM and PDK2 rev. 400 carrier board. This is an SoM with STM32MP157C and an evaluation kit. The baseboard provides Ethernet, UART, USB, CAN and optional display. Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com
- stm32mp157c-dhcom-pdk2-u-boot.dtb \ stm32mp157c-dk2.dtb \ stm32mp157c-ed1.dtb \ stm32mp157c-ev1.dtb
- Copyright (C) 2019 Marek Vasut marex@denx.de */
- model = "STMicroelectronics STM32MP157C DHCOM Premium
Developer Kit (2)";
- compatible = "dh,stm32mp157c-dhcom-pdk2", "st,stm32mp157";
- aliases {
serial0 = &uart4;
- chosen {
- ethernet_vio: vioregulator {
regulator-boot-on;
+ðernet0 {
- status = "okay";
- pinctrl-0 = <ðernet0_rmii_pins_a>;
- pinctrl-1 = <ðernet0_rmii_pins_sleep_a>;
- pinctrl-names = "default", "sleep";
- phy-mode = "rmii";
- max-speed = <100>;
- phy-handle = <&phy0>;
- st,eth_ref_clk_sel;
- phy-reset-gpios = <&gpioh 15 GPIO_ACTIVE_LOW>;
- mdio0 {
#size-cells = <0>;
reg = <1>;
+&pinctrl {
- ethernet0_rmii_pins_a: rmii-0 {
pins1 {
ETH1_RMII_TXD0 */
ETH1_RMII_TXD1 */
ETH1_RMII_TX_EN */
bias-disable;
drive-push-pull;
slew-rate = <2>;
pins2 {
ETH1_RMII_RXD0 */
ETH1_RMII_RXD1 */
ETH1_RMII_CRS_DV */
bias-disable;
- ethernet0_rmii_pins_sleep_a: rmii-sleep-0 {
pins1 {
ETH1_RMII_TXD0 */
ETH1_RMII_TXD1 */
ETH1_RMII_TX_EN */
ETH1_MDIO */
ETH1_MDC */
ETH1_RMII_RXD0 */
ETH1_RMII_RXD1 */
ETH1_RMII_CRS_DV */
- aliases {
i2c1 = &i2c2;
i2c3 = &i2c4;
i2c4 = &i2c5;
mmc0 = &sdmmc1;
mmc1 = &sdmmc2;
spi0 = &qspi;
usb0 = &usbotg_hs;
- config {
Excpet if I miss something, You have no led on your board (named = "heartbeat" or "error" ) This 2 line can be remove I think
- led {
red {
label = "error";
status = "okay";
blue {
This blue overridde can be remove I think.
+&i2c4 {
- u-boot,dm-pre-reloc;
+&i2c4_pins_a {
- pins {
+&pmic {
+&flash0 {
- u-boot,dm-spl;
+&qspi {
- u-boot,dm-spl;
+&qspi_clk_pins_a {
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&qspi_bk1_pins_a {
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
+&qspi_bk2_pins_a {
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
+&rcc {
- st,clksrc = <
CLK_MPU_PLL1P
CLK_AXI_PLL2P
CLK_MCU_PLL3P
CLK_PLL12_HSE
CLK_PLL3_HSE
CLK_PLL4_HSE
CLK_RTC_LSE
CLK_MCO1_DISABLED
CLK_MCO2_DISABLED
;- st,clkdiv = <
1 /*MPU*/
0 /*AXI*/
0 /*MCU*/
1 /*APB1*/
1 /*APB2*/
1 /*APB3*/
1 /*APB4*/
2 /*APB5*/
23 /*RTC*/
0 /*MCO1*/
0 /*MCO2*/
;- st,pkcs = <
CLK_CKPER_HSE
CLK_FMC_ACLK
CLK_QSPI_ACLK
CLK_ETH_PLL4P
CLK_SDMMC12_PLL4P
CLK_DSI_DSIPLL
CLK_STGEN_HSE
CLK_USBPHY_HSE
CLK_SPI2S1_PLL3Q
CLK_SPI2S23_PLL3Q
CLK_SPI45_HSI
CLK_SPI6_HSI
CLK_I2C46_HSI
CLK_SDMMC3_PLL4P
CLK_USBO_USBPHY
CLK_ADC_CKPER
CLK_CEC_LSE
CLK_I2C12_HSI
CLK_I2C35_HSI
CLK_UART1_HSI
CLK_UART24_HSI
CLK_UART35_HSI
CLK_UART6_HSI
CLK_UART78_HSI
CLK_SPDIF_PLL4P
CLK_FDCAN_PLL4Q
CLK_SAI1_PLL3Q
CLK_SAI2_PLL3Q
CLK_SAI3_PLL3Q
CLK_SAI4_PLL3Q
CLK_RNG1_LSI
CLK_RNG2_LSI
CLK_LPTIM1_PCLK1
CLK_LPTIM23_PCLK3
CLK_LPTIM45_LSE
;- /* VCO = 1300.0 MHz => P = 650 (CPU) */
- pll1: st,pll@0 {
frac = < 0x800 >;
- /* VCO = 1066.0 MHz => P = 266 (AXI), Q = 533 (GPU), R = 533 (DDR) */
- pll2: st,pll@1 {
frac = < 0x1400 >;
- /* VCO = 417.8 MHz => P = 209, Q = 24, R = 11 */
- pll3: st,pll@2 {
frac = < 0x1a04 >;
- /* VCO = 600.0 MHz => P = 50, Q = 50, R = 50 */
- pll4: st,pll@3 {
+&sdmmc1 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
+&sdmmc2 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&uart4 {
+&uart4_pins_a {
- pins1 {
- pins2 {
bias-pull-up;
+}; diff --git a/arch/arm/dts/stm32mp157c-dhcom.dtsi b/arch/arm/dts/stm32mp157c- dhcom.dtsi new file mode 100644 index 0000000000..96661ae783 --- /dev/null +++ b/arch/arm/dts/stm32mp157c-dhcom.dtsi @@ -0,0 +1,379 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/*
- Copyright (C) 2019 Marek Vasut marex@denx.de */ /dts-v1/;
- memory@c0000000 {
+&cec {
- pinctrl-names = "default";
- pinctrl-0 = <&cec_pins_a>;
- status = "okay";
+&dcmi {
- status = "okay";
- pinctrl-0 = <&dcmi_pins_a>;
- pinctrl-1 = <&dcmi_sleep_pins_a>;
+&dts {
- status = "okay";
+&i2c2 {
- pinctrl-0 = <&i2c2_pins_a>;
- i2c-scl-rising-time-ns = <185>;
- i2c-scl-falling-time-ns = <20>;
- status = "okay";
+&i2c4 {
- pinctrl-0 = <&i2c4_pins_a>;
- status = "okay";
- /* spare dmas for other usage */
- /delete-property/dmas;
- /delete-property/dma-names;
- pmic: stpmic@33 {
reg = <0x33>;
status = "okay";
regulators {
vddcore: buck1 {
vdd_ddr: buck2 {
vdd: buck3 {
st,mask-reset;
v3v3: buck4 {
vdda: ldo1 {
v2v8: ldo2 {
vtt_ddr: ldo3 {
vdd_usb: ldo4 {
vdd_sd: ldo5 {
regulator-boot-on;
v1v8: ldo6 {
bst_out: boost {
vbus_otg: pwr_sw1 {
vbus_sw: pwr_sw2 {
onkey {
status = "okay";
watchdog {
- eeprom@50 {
reg = <0x50>;
pagesize = <16>;
+&i2c5 {
- pinctrl-0 = <&i2c5_pins_a>;
- status = "okay";
+&ipcc {
- status = "okay";
+&iwdg2 {
- timeout-sec = <32>;
- status = "okay";
+&m4_rproc {
- mboxes = <&ipcc 0>, <&ipcc 1>, <&ipcc 2>;
- mbox-names = "vq0", "vq1", "shutdown";
- status = "okay";
+&pwr {
- pwr-regulators {
+&qspi {
- pinctrl-0 = <&qspi_clk_pins_a &qspi_bk1_pins_a &qspi_bk2_pins_a>;
- pinctrl-1 = <&qspi_clk_sleep_pins_a &qspi_bk1_sleep_pins_a
- reg = <0x58003000 0x1000>, <0x70000000 0x4000000>;
- #address-cells = <1>;
- #size-cells = <0>;
- status = "okay";
- flash0: mx66l51235l@0 {
reg = <0>;
#size-cells = <1>;
- flash1: mx66l51235l@1 {
reg = <1>;
#size-cells = <1>;
+&rng1 {
- status = "okay";
+&rtc {
- status = "okay";
+&sdmmc1 {
- pinctrl-names = "default", "opendrain", "sleep";
- pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_a>;
- pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_a>;
- pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_a>;
- broken-cd;
- st,sig-dir;
- st,neg-edge;
- st,use-ckin;
- bus-width = <4>;
- vmmc-supply = <&vdd_sd>;
- status = "okay";
+&sdmmc2 {
- pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_a>;
- non-removable;
- no-sd;
- no-sdio;
- st,sig-dir;
- st,neg-edge;
- bus-width = <8>;
- vmmc-supply = <&v3v3>;
- status = "okay";
+&spi1 {
- pinctrl-0 = <&spi1_pins_a>;
- status = "disabled";
+&timers2 {
- /* spare dmas for other usage (un-delete to enable pwm capture) */
- pwm {
status = "okay";
- timer@1 {
status = "okay";
+&timers6 {
- status = "okay";
- timer@5 {
status = "okay";
+&timers8 {
- pwm {
status = "okay";
- timer@7 {
status = "okay";
+&timers12 {
- pwm {
status = "okay";
- timer@11 {
status = "okay";
+&uart4 {
- pinctrl-0 = <&uart4_pins_a>;
- status = "okay";
+&usbh_ehci {
- phys = <&usbphyc_port0>;
- phy-names = "usb";
- status = "okay";
+&usbotg_hs {
- dr_mode = "peripheral";
- phys = <&usbphyc_port1 0>;
- phy-names = "usb2-phy";
- vbus-supply = <&vbus_otg>;
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
- phy-supply = <&vdd_usb>;
+&usbphyc_port1 {
- bool "support of DH STM32MP1 PDK2"
- default y
Avoid set default y here.... to avoid to activate this config for ST board.
In fact it should be a choice between the 2 targets - TARGET_DH_STM32MP1_PDK2 - TARGET_ST_STM32MP1
+config SYS_BOARD
- default "dh_stm32mp1"
+config SYS_VENDOR
- default "dhelectronics"
- default "stm32mp1"
- default 0x10000 if ENV_IS_IN_SPI_FLASH
+config ENV_OFFSET
- default 0x1E0000 if ENV_IS_IN_SPI_FLASH
- default 0x1F0000 if ENV_IS_IN_SPI_FLASH
+endif diff --git a/board/dhelectronics/dh_stm32mp1/MAINTAINERS b/board/dhelectronics/dh_stm32mp1/MAINTAINERS new file mode 100644 index 0000000000..38f54a3da4 --- /dev/null +++ b/board/dhelectronics/dh_stm32mp1/MAINTAINERS @@ -0,0 +1,7 @@ +DH_STM32MP1_PDK2 BOARD +M: Marek Vasut marex@denx.de +S: Maintained +F: arch/arm/dts/stm32mp157c-dhcom* +F: board/dhelectronics/dh_stm32mp1/ +F: configs/stm32mp15_dhcom_basic_defconfig +F: include/configs/stm32mp1.h diff --git a/board/dhelectronics/dh_stm32mp1/Makefile b/board/dhelectronics/dh_stm32mp1/Makefile new file mode 100644 index 0000000000..a9d28218ef --- /dev/null +++ b/board/dhelectronics/dh_stm32mp1/Makefile @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause # # Copyright (C) +2018, STMicroelectronics - All Rights Reserved #
+ifdef CONFIG_SPL_BUILD +obj-y += ../../st/stm32mp1/spl.o +else +obj-$(CONFIG_CMD_STBOARD) += ../../st/stm32mp1/cmd_stboard.o endif
I don't think you wee to support the command STMicroelctronics board (ref MBxxxx). it is only a internal command for ST : save/read board id in OTP.
- Copyright (C) 2018, STMicroelectronics - All Rights Reserved */
- Get a global data pointer
- struct udevice *dev;
- ofnode eeprom;
- unsigned char enetaddr[6];
- int ret;
- ret = eth_env_get_enetaddr("ethaddr", enetaddr);
- if (ret) /* ethaddr is already set */
- eeprom = ofnode_path("/soc/i2c@5c002000/eeprom@50");
- if (!ofnode_valid(eeprom)) {
return -ENODEV;
- ret = uclass_get_device_by_ofnode(UCLASS_I2C_EEPROM, eeprom,
&dev);
- if (ret) {
return ret;
- ret = i2c_eeprom_read(dev, 0xfa, enetaddr, 0x6);
- if (ret) {
return ret;
- if (is_valid_ethaddr(enetaddr))
- int ret;
- char *mode;
- u32 otp;
- const char *fdt_compat;
- int fdt_compat_len;
- if (IS_ENABLED(CONFIG_STM32MP1_OPTEE))
- else if (IS_ENABLED(CONFIG_STM32MP1_TRUSTED))
mode = "trusted";
- else
mode = "basic";
- printf("Board: stm32mp1 in %s mode", mode);
- fdt_compat = fdt_getprop(gd->fdt_blob, 0, "compatible",
&fdt_compat_len);
- if (fdt_compat && fdt_compat_len)
- puts("\n");
- ret = uclass_get_device_by_driver(UCLASS_MISC,
&dev);
- if (!ret)
&otp, sizeof(otp));
- if (ret > 0 && otp) {
otp >> 16,
(otp >> 12) & 0xF,
otp & 0xF);
This part (read OTP / / display MBxxx ) can be dropped for your board (it is a ST specific part).
- ofnode node;
- struct gpio_desc gpio;
- enum forced_boot_mode boot_mode = BOOT_NORMAL;
- node = ofnode_path("/config");
- if (!ofnode_valid(node)) {
return;
- if (gpio_request_by_name_nodev(node, "st,fastboot-gpios", 0,
__func__);
- } else {
- if (gpio_request_by_name_nodev(node, "st,stm32prog-gpios", 0,
__func__);
- } else {
- if (boot_mode != BOOT_NORMAL) {
boot_mode);
+#endif +}
Do you support GPIO key press on GPAIOA14 / 15 (as it is done in ST boards EV1 : DK1 / DK2) If no all this function can be dropped.
+static int stusb1600_init(struct udevice **dev_stusb1600) {
- ofnode node;
- struct udevice *dev, *bus;
- int ret;
- u32 chip_addr;
- *dev_stusb1600 = NULL;
- /* if node stusb1600 is present, means DK1 or DK2 board */
- node = ofnode_by_compatible(ofnode_null(), "st,stusb1600");
return -ENODEV;
- ret = ofnode_read_u32(node, "reg", &chip_addr);
- if (ret)
return -EINVAL;
- ret = uclass_get_device_by_ofnode(UCLASS_I2C,
&bus);
- if (ret) {
return -ENODEV;
- ret = dm_i2c_probe(bus, chip_addr, 0, &dev);
- if (!ret)
- return ret;
+static int stusb1600_cable_connected(struct udevice *dev) {
- u8 status;
- if (dm_i2c_read(dev, STUSB1600_CC_CONNECTION_STATUS, &status,
1))
- return status & STUSB1600_CC_ATTACH;
- struct udevice *stusb1600;
- struct udevice *dwc2_udc_otg;
- int ret;
- if (!stusb1600_init(&stusb1600))
- ret = uclass_get_device_by_driver(UCLASS_USB_GADGET_GENERIC,
&dwc2_udc_otg);
- if (!ret)
- return dwc2_udc_B_session_valid(dwc2_udc_otg);
If you don't have STUSB1600 (external usb typeC controller) All this part can dropped.
+#define STM32MP1_G_DNL_DFU_PRODUCT_NUM 0xdf11 #define +STM32MP1_G_DNL_FASTBOOT_PRODUCT_NUM 0x0afb
+int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char +*name) {
- if (!strcmp(name, "usb_dnl_dfu"))
idProduct);
- else if (!strcmp(name, "usb_dnl_fastboot"))
- put_unaligned(STM32MP1_G_DNL_FASTBOOT_PRODUCT_NUM,
&dev->idProduct);
- else
idProduct);
+#ifdef CONFIG_LED +static int get_led(struct udevice **dev, char *led_string) {
- char *led_name;
- int ret;
- led_name = fdtdec_get_config_string(gd->fdt_blob, led_string);
- if (!led_name) {
return -ENOENT;
- ret = led_get_by_label(led_name, dev);
- if (ret) {
return ret;
+static int setup_led(enum led_state_t cmd) {
- int ret;
- ret = get_led(&dev, "u-boot,boot-led");
- if (ret)
return ret;
- ret = led_set_state(dev, cmd);
- return ret;
+} +#endif
+static void __maybe_unused led_error_blink(u32 nb_blink) { #ifdef +CONFIG_LED
- int ret;
- struct udevice *led;
- u32 i;
- if (!nb_blink)
return;
+#ifdef CONFIG_LED
- ret = get_led(&led, "u-boot,error-led");
- if (!ret) {
mdelay(125);
WATCHDOG_RESET();
- /* infinite: the boot process must be stopped */
- if (nb_blink == U32_MAX)
hang();
- u8 *syscfg;
- struct udevice *pwr_dev;
- struct udevice *pwr_reg;
- int ret;
- u32 otp = 0;
- u32 bootr;
- syscfg = (u8 *)syscon_get_first_range(STM32MP_SYSCON_SYSCFG);
- /* interconnect update : select master using the port 1 */
- /* LTDC = AXI_M9 */
- /* GPU = AXI_M8 */
- /* today information is hardcoded in U-Boot */
- writel(BIT(9), syscfg + SYSCFG_ICNR);
- /* disable Pull-Down for boot pin connected to VDD */
- bootr = readl(syscfg + SYSCFG_BOOTR);
- bootr &= ~(SYSCFG_BOOTR_BOOT_MASK <<
- bootr |= (bootr & SYSCFG_BOOTR_BOOT_MASK) <<
- writel(bootr, syscfg + SYSCFG_BOOTR);
- /* High Speed Low Voltage Pad mode Enable for SPI, SDMMC, ETH,
QSPI
selection.
* WARNING:
- ret = uclass_get_device_by_driver(UCLASS_PMIC,
&pwr_dev);
- if (!ret) {
&dev);
if (ret) {
return;
if (ret > 0)
&pwr_reg);
if (!ret) {
if (!otp)
} else {
if (otp)
} else {
- /* activate automatic I/O compensation
- writel(SYSCFG_CMPENSETR_MPU_EN, syscfg +
SYSCFG_CMPENSETR);
- while (!(readl(syscfg + SYSCFG_CMPCR) & SYSCFG_CMPCR_READY))
- clrbits_le32(syscfg + SYSCFG_CMPCR, SYSCFG_CMPCR_SW_CTRL);
#endif }
+/* board dependent setup after realloc */ int board_init(void) {
- /* address of boot parameters */
- gd->bd->bi_boot_params = STM32_DDR_BASE + 0x100;
- /* probe all PINCTRL for hog */
- for (uclass_first_device(UCLASS_PINCTRL, &dev);
dev;
- board_key_check();
- regulators_enable_boot_on(_DEBUG);
- sysconf_init();
- if (CONFIG_IS_ENABLED(CONFIG_LED))
- char *boot_device;
- const void *fdt_compat;
- int ret;
- u32 otp;
- char buf[10];
&fdt_compat_len);
- if (fdt_compat && fdt_compat_len) {
else
&dev);
- if (!ret)
&otp, sizeof(otp));
- if (!ret && otp) {
- /* Check the boot-source to disable bootdelay */
- boot_device = env_get("boot_device");
- if (!strcmp(boot_device, "serial") || !strcmp(boot_device, "usb"))
- setup_led(LEDST_OFF);
+#endif +}
+/* eth init function : weak called in eqos driver */ int +board_interface_eth_init(struct udevice *dev,
phy_interface_t interface_type) {
- u8 *syscfg;
- u32 value;
- bool eth_clk_sel_reg = false;
- bool eth_ref_clk_sel_reg = false;
- /* Gigabit Ethernet 125MHz clock selection. */
- eth_clk_sel_reg = dev_read_bool(dev, "st,eth_clk_sel");
- /* Ethernet 50Mhz RMII clock selection */
- eth_ref_clk_sel_reg =
- if (!syscfg)
return -ENODEV;
- switch (interface_type) {
- case PHY_INTERFACE_MODE_MII:
break;
- case PHY_INTERFACE_MODE_GMII:
else
break;
- case PHY_INTERFACE_MODE_RMII:
else
break;
- case PHY_INTERFACE_MODE_RGMII:
- case PHY_INTERFACE_MODE_RGMII_ID:
- case PHY_INTERFACE_MODE_RGMII_RXID:
- case PHY_INTERFACE_MODE_RGMII_TXID:
else
break;
- default:
return -EINVAL;
- /* clear and set ETH configuration bits */
- writel(SYSCFG_PMCSETR_ETH_SEL_MASK |
- writel(value, syscfg + SYSCFG_PMCSETR);
+enum env_location env_get_location(enum env_operation op, int prio) {
- if (prio)
- return ENVL_SPI_FLASH;
+#else
- return ENVL_NOWHERE;
+#endif +}
- The mtdparts_nand0 and mtdparts_nor0 variable tends to be long.
- If we need to access it before the env is relocated, then we need
- to use our own stack buffer. gd->env_buf will be too small.
- @param buf temporary buffer pointer MTDPARTS_LEN long
- @return mtdparts variable string, NULL if not found */ static const
+char *env_get_mtdparts(const char *str, char *buf) {
- if (gd->flags & GD_FLG_ENV_READY)
- if (env_get_f(str, buf, MTDPARTS_LEN) != -1)
return buf;
- return NULL;
- update the variables "mtdids" and "mtdparts" with content of
+mtdparts_<dev> */ static void board_get_mtdparts(const char *dev,
char *mtdids,
char *mtdparts)
- char env_name[32] = "mtdparts_";
- char tmp_mtdparts[MTDPARTS_LEN];
- const char *tmp;
- /* name of env variable to read = mtdparts_<dev> */
- strcat(env_name, dev);
- tmp = env_get_mtdparts(env_name, tmp_mtdparts);
- if (tmp) {
else
- static char parts[3 * MTDPARTS_LEN + 1];
- static char ids[MTDIDS_LEN + 1];
- static bool mtd_initialized;
- if (mtd_initialized) {
*mtdids = ids;
*mtdparts = parts;
return;
- memset(parts, 0, sizeof(parts));
- memset(ids, 0, sizeof(ids));
- /* probe all MTD devices */
- for (uclass_first_device(UCLASS_MTD, &dev);
dev;
- if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev))
- mtd_initialized = true;
- *mtdids = ids;
- *mtdparts = parts;
- debug("%s:mtdids=%s & mtdparts=%s\n", __func__, ids, parts); } #endif
+#if defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) {
+} +#endif
+static void board_get_alt_info(const char *dev, char *buff) {
- char var_name[32] = "dfu_alt_info_";
- int ret;
- ALLOC_CACHE_ALIGN_BUFFER(char, tmp_alt, DFU_ALT_BUF_LEN);
- /* name of env variable to read = dfu_alt_info_<dev> */
- strcat(var_name, dev);
- ret = env_get_f(var_name, tmp_alt, DFU_ALT_BUF_LEN);
- if (ret) {
strcat(buff, "&");
+void set_dfu_alt_info(char *interface, char *devstr) {
- ALLOC_CACHE_ALIGN_BUFFER(char, buf, DFU_ALT_BUF_LEN);
- if (env_get("dfu_alt_info"))
return;
- memset(buf, 0, sizeof(buf));
- mtd_probe_devices();
- board_get_alt_info("ram", buf);
- if (!uclass_get_device(UCLASS_MMC, 0, &dev))
- if (!uclass_get_device(UCLASS_MMC, 1, &dev))
- env_set("dfu_alt_info", buf);
- puts("DFU alt info setting: done\n");
+} +#endif
+static void board_copro_image_process(ulong fw_image, size_t fw_size) {
- int ret, id = 0; /* Copro id fixed to 0 as only one coproc on mp1 */
- if (!rproc_is_initialized())
if (rproc_init()) {
id);
return;
- ret = rproc_load(id, fw_image, fw_size);
- printf("Load Remote Processor %d with data@addr=0x%08lx %u
bytes:%s\n",
- if (!ret) {
rproc_start(id);
CONFIG_TARGET_DH_STM32MP1_PDK2=y
+CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y # +CONFIG_ARMV7_VIRT is not set +CONFIG_SPL_TEXT_BASE=0x2FFC2500 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +# CONFIG_BOOTSTAGE is not set +CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 +CONFIG_SYS_PROMPT="STM32MP> " +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +CONFIG_CMD_EEPROM=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_ADC=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_REMOTEPROC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_MTDPARTS=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-dhcom-pdk2-u-boot" +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-names interrupts- extended interrupt-controller \#interrupt-cells interrupt-parent dmas dma-names assigned-clocks assigned-clock-rates assigned-clock-parents hwlocks" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=0 +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=0 +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=10000000 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0x0 +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_IP_DEFRAG=y +CONFIG_TFTP_BLOCKSIZE=1536 +CONFIG_STM32_ADC=y +CONFIG_SPL_BLOCK_CACHE=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_VIRT=y +CONFIG_DM_HWSPINLOCK=y +CONFIG_HWSPINLOCK_STM32=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_STM32F7=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_DM_MAILBOX=y +CONFIG_STM32_IPCC=y +CONFIG_I2C_EEPROM=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_STM32_SDMMC2=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_SPI_FLASH_MTD=y +CONFIG_SPL_SPI_FLASH_MTD=y CONFIG_DM_ETH=y CONFIG_DWC_ETH_QOS=y +CONFIG_PHY=y CONFIG_PHY_STM32_USBPHYC=y CONFIG_PINCONF=y # +CONFIG_SPL_PINCTRL_FULL is not set CONFIG_PINCTRL_STMFX=y +CONFIG_DM_PMIC=y # CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_PMIC_STPMIC1=y CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_REGULATOR_STM32_VREFBUF=y +CONFIG_DM_REGULATOR_STPMIC1=y +CONFIG_REMOTEPROC_STM32_COPRO=y +CONFIG_DM_RTC=y +CONFIG_RTC_STM32=y +CONFIG_SERIAL_RX_BUFFER=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_STM32_QSPI=y +CONFIG_STM32_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="dh" +CONFIG_USB_GADGET_VENDOR_NUM=0x0483 +CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y +CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y +CONFIG_VIDEO_LCD_RAYDIUM_RM68200=y +CONFIG_VIDEO_STM32=y +CONFIG_VIDEO_STM32_DSI=y +CONFIG_VIDEO_STM32_MAX_XRES=1280 +CONFIG_VIDEO_STM32_MAX_YRES=800 +CONFIG_LZO=y
2.24.1
Regards
Patrick
Hi Marek,
From: Patrick DELAUNAY Sent: lundi 13 janvier 2020 15:05
Hi Marek,
For information, I merge the serie, except this patch 5/5 on master brach and I sent a pull request for u-boot-stm32-20200117.
For this patch, I propose a rebase and also many modification liked to my previous remark (I remove ST only parts for stboard command, and also led and key management) .
This proposal is present in the branch https://gitlab.denx.de/u-boot/custodians/u-boot-stm/tree/next https://gitlab.denx.de/u-boot/custodians/u-boot-stm/commit/db48e11b1eccf23f3...
your initial patch is in applied https://gitlab.denx.de/u-boot/custodians/u-boot-stm/tree/dh
Can you test the "next" branch and check the difference with your initial patch ( applied in dh branch https://gitlab.denx.de/u-boot/custodians/u-boot-stm/tree/dh => https://gitlab.denx.de/u-boot/custodians/u-boot-stm/commit/0ab3ce72f82b946ac... )
I hope that I don't remove something really present on the SOM.
If you are OK, can you send a V2 version with the "next" branch content and I will integrate it in master branch for next pull request.
Thanks,
Patrick
arch/arm/dts/Makefile | 1 + .../arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dts | 7 + arch/arm/dts/stm32mp157c-dhcom-pdk2.dts | 88 ++ arch/arm/dts/stm32mp157c-dhcom-u-boot.dtsi | 238 ++++++ arch/arm/dts/stm32mp157c-dhcom.dtsi | 379 +++++++++ arch/arm/mach-stm32mp/Kconfig | 1 + board/dhelectronics/dh_stm32mp1/Kconfig | 25 + board/dhelectronics/dh_stm32mp1/MAINTAINERS | 7 + board/dhelectronics/dh_stm32mp1/Makefile | 12 + board/dhelectronics/dh_stm32mp1/board.c | 777 ++++++++++++++++++ configs/stm32mp15_dhcom_basic_defconfig | 140 ++++ 11 files changed, 1675 insertions(+) create mode 100644 arch/arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dts create mode 100644 arch/arm/dts/stm32mp157c-dhcom-pdk2.dts create mode 100644 arch/arm/dts/stm32mp157c-dhcom-u-boot.dtsi create mode 100644 arch/arm/dts/stm32mp157c-dhcom.dtsi create mode 100644 board/dhelectronics/dh_stm32mp1/Kconfig create mode 100644 board/dhelectronics/dh_stm32mp1/MAINTAINERS create mode 100644 board/dhelectronics/dh_stm32mp1/Makefile create mode 100644 board/dhelectronics/dh_stm32mp1/board.c create mode 100644 configs/stm32mp15_dhcom_basic_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 983e235f44..82489bc09c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -859,6 +859,7 @@ dtb-$(CONFIG_ARCH_STI) += stih410-b2260.dtb dtb-$(CONFIG_TARGET_STM32MP1) += \ stm32mp157a-dk1.dtb \ stm32mp157a-avenger96.dtb \
diff --git a/arch/arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dts b/arch/arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dts new file mode 100644 index 0000000000..fd99988570 --- /dev/null +++ b/arch/arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dts @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/*
+#include "stm32mp157c-dhcom-pdk2.dts" +#include "stm32mp157c-dhcom-u-boot.dtsi" diff --git a/arch/arm/dts/stm32mp157c-dhcom-pdk2.dts b/arch/arm/dts/stm32mp157c-dhcom-pdk2.dts new file mode 100644 index 0000000000..05aa545f55 --- /dev/null +++ b/arch/arm/dts/stm32mp157c-dhcom-pdk2.dts @@ -0,0 +1,88 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/*
+#include "stm32mp157c-dhcom.dtsi"
Developer Kit (2)";
- aliases {
serial0 = &uart4;
ethernet0 = ðernet0;
- chosen {
stdout-path = "serial0:115200n8";
compatible = "regulator-fixed";
regulator-name = "vio";
gpio = <&gpiog 3 GPIO_ACTIVE_LOW>;
regulator-boot-on;
+ðernet0 {
- status = "okay";
- mdio0 {
#size-cells = <0>;
compatible = "snps,dwmac-mdio";
phy0: ethernet-phy@1 {
reg = <1>;
+&pinctrl {
pins1 {
pinmux = <STM32_PINMUX('G', 13, AF11)>, /*
ETH1_RMII_TXD0 */
<STM32_PINMUX('G', 14, AF11)>, /*
ETH1_RMII_TXD1 */
<STM32_PINMUX('B', 11, AF11)>, /*
ETH1_RMII_TX_EN */
<STM32_PINMUX('A', 1, AF0)>, /*
ETH1_RMII_REF_CLK */
<STM32_PINMUX('A', 2, AF11)>, /* ETH1_MDIO
<STM32_PINMUX('C', 1, AF11)>; /* ETH1_MDC
bias-disable;
drive-push-pull;
slew-rate = <2>;
pins2 {
pinmux = <STM32_PINMUX('C', 4, AF11)>, /*
ETH1_RMII_RXD0 */
<STM32_PINMUX('C', 5, AF11)>, /*
ETH1_RMII_RXD1 */
<STM32_PINMUX('A', 7, AF11)>; /*
ETH1_RMII_CRS_DV */
bias-disable;
pins1 {
pinmux = <STM32_PINMUX('G', 13, ANALOG)>, /*
ETH1_RMII_TXD0 */
<STM32_PINMUX('G', 14, ANALOG)>, /*
ETH1_RMII_TXD1 */
<STM32_PINMUX('B', 11, ANALOG)>, /*
ETH1_RMII_TX_EN */
<STM32_PINMUX('A', 2, ANALOG)>, /*
ETH1_MDIO */
<STM32_PINMUX('C', 1, ANALOG)>, /*
ETH1_MDC */
<STM32_PINMUX('C', 4, ANALOG)>, /*
ETH1_RMII_RXD0 */
<STM32_PINMUX('C', 5, ANALOG)>, /*
ETH1_RMII_RXD1 */
<STM32_PINMUX('A', 1, ANALOG)>, /*
<STM32_PINMUX('A', 7, ANALOG)>; /*
ETH1_RMII_CRS_DV */
+}; diff --git a/arch/arm/dts/stm32mp157c-dhcom-u-boot.dtsi b/arch/arm/dts/stm32mp157c-dhcom-u-boot.dtsi new file mode 100644 index 0000000000..320912edd8 --- /dev/null +++ b/arch/arm/dts/stm32mp157c-dhcom-u-boot.dtsi @@ -0,0 +1,238 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/*
+#include <dt-bindings/clock/stm32mp1-clksrc.h> +#include "stm32mp157-u-boot.dtsi" +#include "stm32mp15-ddr3-2x4Gb-1066-binG.dtsi"
- aliases {
i2c1 = &i2c2;
i2c3 = &i2c4;
i2c4 = &i2c5;
mmc0 = &sdmmc1;
mmc1 = &sdmmc2;
spi0 = &qspi;
usb0 = &usbotg_hs;
- config {
u-boot,boot-led = "heartbeat";
u-boot,error-led = "error";
st,fastboot-gpios = <&gpioa 13 GPIO_ACTIVE_LOW>;
st,stm32prog-gpios = <&gpioa 14 GPIO_ACTIVE_LOW>;
- led {
red {
label = "error";
default-state = "off";
status = "okay";
blue {
default-state = "on";
+&i2c4 {
+&i2c4_pins_a {
- pins {
+&pmic {
+&flash0 {
- u-boot,dm-spl;
+&qspi {
- u-boot,dm-spl;
+&qspi_clk_pins_a {
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&qspi_bk1_pins_a {
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
+&qspi_bk2_pins_a {
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
+&rcc {
- st,clksrc = <
CLK_MPU_PLL1P
CLK_AXI_PLL2P
CLK_MCU_PLL3P
CLK_PLL12_HSE
CLK_PLL3_HSE
CLK_PLL4_HSE
CLK_RTC_LSE
CLK_MCO1_DISABLED
CLK_MCO2_DISABLED
;- st,clkdiv = <
1 /*MPU*/
0 /*AXI*/
0 /*MCU*/
1 /*APB1*/
1 /*APB2*/
1 /*APB3*/
1 /*APB4*/
2 /*APB5*/
23 /*RTC*/
0 /*MCO1*/
0 /*MCO2*/
;- st,pkcs = <
CLK_CKPER_HSE
CLK_FMC_ACLK
CLK_QSPI_ACLK
CLK_ETH_PLL4P
CLK_SDMMC12_PLL4P
CLK_DSI_DSIPLL
CLK_STGEN_HSE
CLK_USBPHY_HSE
CLK_SPI2S1_PLL3Q
CLK_SPI2S23_PLL3Q
CLK_SPI45_HSI
CLK_SPI6_HSI
CLK_I2C46_HSI
CLK_SDMMC3_PLL4P
CLK_USBO_USBPHY
CLK_ADC_CKPER
CLK_CEC_LSE
CLK_I2C12_HSI
CLK_I2C35_HSI
CLK_UART1_HSI
CLK_UART24_HSI
CLK_UART35_HSI
CLK_UART6_HSI
CLK_UART78_HSI
CLK_SPDIF_PLL4P
CLK_FDCAN_PLL4Q
CLK_SAI1_PLL3Q
CLK_SAI2_PLL3Q
CLK_SAI3_PLL3Q
CLK_SAI4_PLL3Q
CLK_RNG1_LSI
CLK_RNG2_LSI
CLK_LPTIM1_PCLK1
CLK_LPTIM23_PCLK3
CLK_LPTIM45_LSE
- pll1: st,pll@0 {
cfg = < 2 80 0 0 0 PQR(1,0,0) >;
frac = < 0x800 >;
- pll2: st,pll@1 {
cfg = < 2 65 1 0 0 PQR(1,1,1) >;
frac = < 0x1400 >;
- pll3: st,pll@2 {
cfg = < 1 33 1 16 36 PQR(1,1,1) >;
frac = < 0x1a04 >;
- pll4: st,pll@3 {
cfg = < 1 49 11 11 11 PQR(1,1,1) >;
+&sdmmc1 {
- u-boot,dm-spl;
+&sdmmc1_b4_pins_a {
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&sdmmc1_dir_pins_a {
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
+&sdmmc2 {
- u-boot,dm-spl;
+&sdmmc2_b4_pins_a {
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&sdmmc2_d47_pins_a {
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&uart4 {
+&uart4_pins_a {
- pins1 {
- pins2 {
/* pull-up on rx to avoid floating level */
bias-pull-up;
+#include "stm32mp157c.dtsi" +#include "stm32mp157xaa-pinctrl.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/mfd/st,stpmic1.h>
- memory@c0000000 {
device_type = "memory";
reg = <0xC0000000 0x40000000>;
+&cec {
- status = "okay";
+&dcmi {
- status = "okay";
+&dts {
- status = "okay";
+&i2c2 {
- status = "okay";
+&i2c4 {
- status = "okay";
- pmic: stpmic@33 {
compatible = "st,stpmic1";
reg = <0x33>;
interrupts-extended = <&gpioa 0 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
status = "okay";
regulators {
compatible = "st,stpmic1-regulators";
ldo1-supply = <&v3v3>;
ldo2-supply = <&v3v3>;
ldo3-supply = <&vdd_ddr>;
ldo5-supply = <&v3v3>;
ldo6-supply = <&v3v3>;
pwr_sw1-supply = <&bst_out>;
pwr_sw2-supply = <&bst_out>;
vddcore: buck1 {
regulator-name = "vddcore";
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <1350000>;
regulator-initial-mode = <0>;
vdd_ddr: buck2 {
regulator-name = "vdd_ddr";
regulator-min-microvolt = <1350000>;
vdd: buck3 {
regulator-name = "vdd";
st,mask-reset;
v3v3: buck4 {
regulator-name = "v3v3";
vdda: ldo1 {
regulator-name = "vdda";
interrupts = <IT_CURLIM_LDO1 0>;
v2v8: ldo2 {
regulator-name = "v2v8";
regulator-min-microvolt = <2800000>;
regulator-max-microvolt = <2800000>;
interrupts = <IT_CURLIM_LDO2 0>;
vtt_ddr: ldo3 {
regulator-name = "vtt_ddr";
regulator-min-microvolt = <500000>;
regulator-max-microvolt = <750000>;
vdd_usb: ldo4 {
regulator-name = "vdd_usb";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
interrupts = <IT_CURLIM_LDO4 0>;
vdd_sd: ldo5 {
regulator-name = "vdd_sd";
regulator-min-microvolt = <2900000>;
regulator-max-microvolt = <2900000>;
interrupts = <IT_CURLIM_LDO5 0>;
regulator-boot-on;
v1v8: ldo6 {
regulator-name = "v1v8";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
interrupts = <IT_CURLIM_LDO6 0>;
vref_ddr: vref_ddr {
regulator-name = "vref_ddr";
regulator-always-on;
regulator-over-current-protection;
bst_out: boost {
regulator-name = "bst_out";
interrupts = <IT_OCP_BOOST 0>;
vbus_otg: pwr_sw1 {
regulator-name = "vbus_otg";
interrupts = <IT_OCP_OTG 0>;
vbus_sw: pwr_sw2 {
regulator-name = "vbus_sw";
interrupts = <IT_OCP_SWOUT 0>;
regulator-active-discharge;
onkey {
compatible = "st,stpmic1-onkey";
interrupts = <IT_PONKEY_F 0>, <IT_PONKEY_R 0>;
interrupt-names = "onkey-falling", "onkey-rising";
power-off-time-sec = <10>;
status = "okay";
watchdog {
compatible = "st,stpmic1-wdt";
- eeprom@50 {
compatible = "atmel,24c02";
reg = <0x50>;
pagesize = <16>;
+&i2c5 {
- status = "okay";
+&ipcc {
- status = "okay";
+&iwdg2 {
- status = "okay";
+&m4_rproc {
- status = "okay";
+&pwr {
- pwr-regulators {
+&qspi {
- status = "okay";
reg = <0>;
#size-cells = <1>;
reg = <1>;
#size-cells = <1>;
+&rng1 {
- status = "okay";
+&rtc {
- status = "okay";
+&sdmmc1 {
- broken-cd;
- st,sig-dir;
- st,neg-edge;
- st,use-ckin;
- bus-width = <4>;
- status = "okay";
+&sdmmc2 {
- non-removable;
- no-sd;
- no-sdio;
- st,sig-dir;
- st,neg-edge;
- bus-width = <8>;
- status = "okay";
+&spi1 {
+&timers2 {
- pwm {
status = "okay";
- timer@1 {
status = "okay";
+&timers6 {
- status = "okay";
- timer@5 {
status = "okay";
+&timers8 {
- pwm {
status = "okay";
- timer@7 {
status = "okay";
+&timers12 {
- pwm {
status = "okay";
- timer@11 {
status = "okay";
+&uart4 {
- status = "okay";
+&usbh_ehci {
- status = "okay";
+&usbotg_hs {
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
- default y
+config SYS_BOARD
+config SYS_VENDOR
+config ENV_OFFSET
- ofnode eeprom;
- int ret;
return -ENODEV;
&dev);
- if (ret) {
return ret;
- if (ret) {
return ret;
- int ret;
- char *mode;
- u32 otp;
mode = "trusted";
- else
mode = "basic";
&fdt_compat_len);
- puts("\n");
&dev);
- if (!ret)
&otp, sizeof(otp));
otp >> 16,
(otp >> 12) & 0xF,
otp & 0xF);
- ofnode node;
return;
__func__);
- } else {
__func__);
- } else {
boot_mode);
+#endif +}
- ofnode node;
- int ret;
- u32 chip_addr;
return -ENODEV;
- if (ret)
return -EINVAL;
&bus);
- if (ret) {
return -ENODEV;
- if (!ret)
- return ret;
- u8 status;
1))
- return status & STUSB1600_CC_ATTACH; }
- int ret;
&dwc2_udc_otg);
- if (!ret)
idProduct);
&dev->idProduct);
- else
idProduct);
- char *led_name;
- int ret;
- if (!led_name) {
return -ENOENT;
- if (ret) {
return ret;
- int ret;
- if (ret)
return ret;
- return ret;
+} +#endif
- int ret;
- u32 i;
- if (!nb_blink)
return;
+#ifdef CONFIG_LED
- if (!ret) {
mdelay(125);
WATCHDOG_RESET();
hang();
- u8 *syscfg;
- int ret;
- u32 otp = 0;
- u32 bootr;
QSPI
selection.
* WARNING:
&pwr_dev);
- if (!ret) {
&dev);
if (ret) {
return;
if (ret > 0)
&pwr_reg);
if (!ret) {
if (!otp)
} else {
if (otp)
} else {
SYSCFG_CMPENSETR);
#endif }
dev;
- sysconf_init();
- int ret;
- u32 otp;
- char buf[10];
&fdt_compat_len);
else
&dev);
- if (!ret)
&otp, sizeof(otp));
+#endif +}
- u8 *syscfg;
- u32 value;
- if (!syscfg)
return -ENODEV;
break;
else
break;
else
break;
else
break;
- default:
return -EINVAL;
- if (prio)
+#else
+#endif +}
+const char *env_get_mtdparts(const char *str, char *buf) {
return buf;
- return NULL;
char *mtdids,
char *mtdparts)
- const char *tmp;
- if (tmp) {
else
+void board_mtdparts_default(const char **mtdids, const char +**mtdparts) {
*mtdids = ids;
*mtdparts = parts;
return;
dev;
- *mtdids = ids;
+} +#endif
- int ret;
- if (ret) {
strcat(buff, "&");
return;
- puts("DFU alt info setting: done\n"); } #endif
if (rproc_init()) {
id);
return;
bytes:%s\n",
- if (!ret) {
rproc_start(id);
parents hwlocks"
2.24.1
Regards
Patrick
On 1/17/20 5:32 PM, Patrick DELAUNAY wrote:
Hi Marek,
Hi Marek,
Will do. I will rebase on master once your PR is in and then send V2.
Hi Marek,
Setting TARGET_STM32MP1 in Kconfig always forces SYS_BOARD, SYS_VENDOR and SYS_CONFIG_NAME to values set by the ST reference platforms. Allow changing that by pulling out the TARGET_STM32MP157C_DK2 and making the ST reference platform settings conditional on TARGET_STM32MP157C_DK2 . Other platforms can now define a different TARGET_ and thus override the SYS_ settings in their Kconfig.
Reviewed-by: Patrick Delaunay patrick.delaunay@st.com
It seens my configuration between SOC (STM32MP15x) and BOARD is not clean...
So I prepare a patchset to change it. But I will apply it after your serie... to avoid regression on your board
Regards Patrick
On 1/13/20 11:58 AM, Patrick DELAUNAY wrote:
Hi Marek,
Regards Patrick
Can you apply whatever you feel applicable from the series I posted and push it to some git repo, so I don't have to reset all things over and over again ?
Hi Marek,
From: Marek Vasut marex@denx.de Sent: lundi 13 janvier 2020 12:08
Hi Marek,
clean...
Regards Patrick
Sure.
https://gitlab.denx.de/u-boot/custodians/u-boot-stm.git
=> branch master : the paches accepted [V3] stm32mp1: configs: Make all boot devices in distro boot conditional
[2/5] ARM: stm32: Allow overriding setup_mac_address() They will be included in my next pull request
=> branch next + my serie = http://patchwork.ozlabs.org/project/uboot/list/?series=152828 + your serie (including my proposals of update) http://patchwork.ozlabs.org/project/uboot/list/?series=152293
[3/5] ARM: stm32: Fill in missing loadaddr => I change address to 0xc2000000
[5/5] ARM: dts: stm32: Add DH Electronics DHCOM SoM and PDK2 board I make a lot of modification after my serie and my review....
Can you check the delta and tell me if it is working...
NB: no more needed after my serie => [1/5] ARM: stm32: Permit multiple board targets i
PS: [4/5] ARM: dts: stm32: Add missing ETHCK clock to ethernet node I ma waiting Christophe / kernel feedback....
Patrick
On 1/13/20 4:07 PM, Patrick DELAUNAY wrote:
Hi Marek,
Hi Marek,
clean...
Regards Patrick
Sure.
=> branch next
Should be OK, thanks.
Christophe ROULLIER
Patrice CHOTARD
Patrick DELAUNAY
