[RESEND PATCH v2] efi_loader: Fix UEFI variable error handling
Try to catch error the earlier way.
Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- lib/efi_loader/efi_var_file.c | 4 +++- lib/efi_loader/efi_variable.c | 2 -- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/lib/efi_loader/efi_var_file.c b/lib/efi_loader/efi_var_file.c index 62e071bd83..fe1c462f17 100644 --- a/lib/efi_loader/efi_var_file.c +++ b/lib/efi_loader/efi_var_file.c @@ -192,8 +192,10 @@ efi_status_t efi_var_restore(struct efi_var_file *buf, bool safe) ret = efi_var_mem_ins(var->name, &var->guid, var->attr, var->length, data, 0, NULL, var->time); - if (ret != EFI_SUCCESS) + if (ret != EFI_SUCCESS) { log_err("Failed to set EFI variable %ls\n", var->name); + return ret; + } } return EFI_SUCCESS; } diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index be95ed44e6..2b2ca8c090 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -350,8 +350,6 @@ efi_status_t efi_set_variable_int(const u16 *variable_name,
if (var_type == EFI_AUTH_VAR_PK) ret = efi_init_secure_state(); - else - ret = EFI_SUCCESS;
/* * Write non-volatile EFI variables to file
return ret;
This change implies that if a failure occurs, initialization of the EFI sub-system fails and you will not be able to boot via EFI.
Such a failure will occur if ubootefi.var contains more variables than fit into the memory buffer.
Please, describe why you want to disable U-Boot's EFI sub-system in this case.
} return EFI_SUCCESS; }}
- else
ret = EFI_SUCCESS;
This change is ok.
Best regards
Heinrich
On Wed, Nov 15, 2023 at 6:15 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
return ret;
Hi Heinrich,
In my case, if a variable wants to persist as a non-volatile variable to ubootefi.var, we should keep the same behavior as runtime variable does. Otherwise the ubootefi.var cannot be trusted.
BR, Weizhao
}} } return EFI_SUCCESS;
else
ret = EFI_SUCCESS;
This change is ok.
Best regards
Heinrich
Weizhao Ouyang
