[U-Boot] [PATCH v2 0/2] arm: qemu-arm: enable PL031 (RTC)
This is a revised version of my proposal[1].
[1] https://lists.denx.de/pipermail/u-boot/2018-July/333534.html
VMs provided by qemu for arm are equiped with PL031 device. In patch#1, pl031 driver is converted to driver model, and in patch#2, this driver is enabled in defconfig of qemu-arm.
This patch set is motivated by running UEFI SCT(Self-Certification Test) and measuring time on u-boot on qemu-arm. Heinrich has already posted UEFI's GetTime() implementation.
Changes in v2(July 4, 2018) * based on Heinrich's comments, * remove legacy mode interface * enable the driver in defconfig
AKASHI Takahiro (2): rtc: pl031: convert the driver to driver model arm: qemu-arm: enable PL031 (RTC) in defconfig
configs/qemu_arm64_defconfig | 2 + configs/qemu_arm_defconfig | 2 + drivers/rtc/Kconfig | 6 ++ drivers/rtc/pl031.c | 109 +++++++++++++++++---------- include/dm/platform_data/rtc_pl031.h | 12 +++ 5 files changed, 91 insertions(+), 40 deletions(-) create mode 100644 include/dm/platform_data/rtc_pl031.h
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- drivers/rtc/Kconfig | 6 ++ drivers/rtc/pl031.c | 109 +++++++++++++++++---------- include/dm/platform_data/rtc_pl031.h | 12 +++ 3 files changed, 87 insertions(+), 40 deletions(-) create mode 100644 include/dm/platform_data/rtc_pl031.h
diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index a3f8c8aecc..96c4cce410 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -55,6 +55,12 @@ config RTC_MV Enable Marvell RTC driver. This driver supports the rtc that is present on some Marvell SoCs.
+config RTC_PL031 + bool "Enable ARM PL031 driver" + depends on DM_RTC + help + Enable ARM PL031 driver. + config RTC_S35392A bool "Enable S35392A driver" select BITREVERSE diff --git a/drivers/rtc/pl031.c b/drivers/rtc/pl031.c index 8955805e3b..eecade8374 100644 --- a/drivers/rtc/pl031.c +++ b/drivers/rtc/pl031.c @@ -8,14 +8,10 @@
#include <common.h> #include <command.h> +#include <dm.h> +#include <dm/platform_data/rtc_pl031.h> #include <rtc.h>
-#if defined(CONFIG_CMD_DATE) - -#ifndef CONFIG_SYS_RTC_PL031_BASE -#error CONFIG_SYS_RTC_PL031_BASE is not defined! -#endif - /* * Register definitions */ @@ -30,78 +26,111 @@
#define RTC_CR_START (1 << 0)
-#define RTC_WRITE_REG(addr, val) \ - (*(volatile unsigned int *)(CONFIG_SYS_RTC_PL031_BASE + (addr)) = (val)) -#define RTC_READ_REG(addr) \ - (*(volatile unsigned int *)(CONFIG_SYS_RTC_PL031_BASE + (addr))) +#define RTC_WRITE_REG(base, addr, val) \ + (*(volatile unsigned int *)((base) + (addr)) = (val)) +#define RTC_READ_REG(base, addr) \ + (*(volatile unsigned int *)((base) + (addr)))
static int pl031_initted = 0;
/* Enable RTC Start in Control register*/ -void rtc_init(void) +void pl031_rtc_init(struct pl031_rtc_platdata *pdata) { - RTC_WRITE_REG(RTC_CR, RTC_CR_START); + RTC_WRITE_REG(pdata->base, RTC_CR, RTC_CR_START);
pl031_initted = 1; }
/* - * Reset the RTC. We set the date back to 1970-01-01. + * Get the current time from the RTC */ -void rtc_reset(void) +static int pl031_rtc_get(struct udevice *dev, struct rtc_time *tm) { - RTC_WRITE_REG(RTC_LR, 0x00); - if(!pl031_initted) - rtc_init(); + struct pl031_rtc_platdata *pdata = dev_get_platdata(dev); + ulong tim; + + if (!tm) { + puts("Error getting the date/time\n"); + return -1; + } + + if (!pl031_initted) + pl031_rtc_init(pdata); + + tim = RTC_READ_REG(pdata->base, RTC_DR); + + rtc_to_tm(tim, tm); + + debug("Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tm->tm_year, tm->tm_mon, tm->tm_mday, tm->tm_wday, + tm->tm_hour, tm->tm_min, tm->tm_sec); + + return 0; }
/* * Set the RTC -*/ -int rtc_set(struct rtc_time *tmp) + */ +static int pl031_rtc_set(struct udevice *dev, const struct rtc_time *tm) { + struct pl031_rtc_platdata *pdata = dev_get_platdata(dev); unsigned long tim;
- if(!pl031_initted) - rtc_init(); - - if (tmp == NULL) { + if (!tm) { puts("Error setting the date/time\n"); return -1; }
+ if (!pl031_initted) + pl031_rtc_init(pdata); + /* Calculate number of seconds this incoming time represents */ - tim = rtc_mktime(tmp); + tim = rtc_mktime(tm);
- RTC_WRITE_REG(RTC_LR, tim); + RTC_WRITE_REG(pdata->base, RTC_LR, tim);
return -1; }
/* - * Get the current time from the RTC + * Reset the RTC. We set the date back to 1970-01-01. */ -int rtc_get(struct rtc_time *tmp) +static int pl031_rtc_reset(struct udevice *dev) { - ulong tim; + struct pl031_rtc_platdata *pdata = dev_get_platdata(dev);
- if(!pl031_initted) - rtc_init(); + RTC_WRITE_REG(pdata->base, RTC_LR, 0x00);
- if (tmp == NULL) { - puts("Error getting the date/time\n"); - return -1; - } + if (!pl031_initted) + pl031_rtc_init(pdata);
- tim = RTC_READ_REG(RTC_DR); + return 0; +} + +static const struct rtc_ops pl031_rtc_ops = { + .get = pl031_rtc_get, + .set = pl031_rtc_set, + .reset = pl031_rtc_reset, +};
- rtc_to_tm(tim, tmp); +static const struct udevice_id pl031_rtc_ids[] = { + { .compatible = "arm,pl031" }, + { } +};
- debug ( "Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", - tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, - tmp->tm_hour, tmp->tm_min, tmp->tm_sec); +static int pl031_rtc_ofdata_to_platdata(struct udevice *dev) +{ + struct pl031_rtc_platdata *pdata = dev_get_platdata(dev);
+ pdata->base = devfdt_get_addr(dev); return 0; }
-#endif +U_BOOT_DRIVER(rtc_pl031) = { + .name = "rtc-pl031", + .id = UCLASS_RTC, + .of_match = pl031_rtc_ids, + .ofdata_to_platdata = pl031_rtc_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct pl031_rtc_platdata), + .ops = &pl031_rtc_ops, +}; diff --git a/include/dm/platform_data/rtc_pl031.h b/include/dm/platform_data/rtc_pl031.h new file mode 100644 index 0000000000..8e4ba1ce69 --- /dev/null +++ b/include/dm/platform_data/rtc_pl031.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __rtc_pl031_h +#define __rtc_pl031_h + +#include <asm/types.h> + +struct pl031_rtc_platdata { + phys_addr_t base; +}; + +#endif
On 07/04/2018 09:36 AM, AKASHI Takahiro wrote:
This patch is missing a patch description. I'm not the maintainer of the rtc code base so it's not my call, but I personally just reject all patches with empty patch descriptions ;).
And thanks a lot for doing the conversion! I think it's a very good step forward.
+config RTC_PL031
- bool "Enable ARM PL031 driver"
- depends on DM_RTC
- help
- config RTC_S35392A bool "Enable S35392A driver" select BITREVERSE
- Register definitions
Any particular reason you don't pass in pdata? While at it you could then also convert the macros into inline functions. That would make the code slightly more readable and result in pretty much the same binary output.
Also, you don't want to have the explicit casts here as they may get compiled into something that is not explicitly valid as MMIO access opcode. Instead, please convert it to readl()/writel() while you're at it.
Does this have to be global still? I guess we can now make this function static, no?
- Reset the RTC. We set the date back to 1970-01-01.
- Get the current time from the RTC
rtc_init();
- struct pl031_rtc_platdata *pdata = dev_get_platdata(dev);
- ulong tim;
- if (!tm) {
return -1;
- if (!pl031_initted)
In theory with dm you can now have multiple instances of the device, right? So we can no longer have a global variable that indicates if a device is initialized. Instead, this needs to move into device private data.
rtc_to_tm(tim, tm);
return 0; }
- Set the RTC
- struct pl031_rtc_platdata *pdata = dev_get_platdata(dev); unsigned long tim;
rtc_init();
if (!pl031_initted)
- tim = rtc_mktime(tm);
return -1; }
- ulong tim;
rtc_init();
- RTC_WRITE_REG(pdata->base, RTC_LR, 0x00);
return -1;
After reset, don't you have to reset the initted bool as well?
Alex
- .get = pl031_rtc_get,
- .set = pl031_rtc_set,
- .reset = pl031_rtc_reset,
- { .compatible = "arm,pl031" },
- .name = "rtc-pl031",
- .id = UCLASS_RTC,
- .of_match = pl031_rtc_ids,
- .ofdata_to_platdata = pl031_rtc_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct pl031_rtc_platdata),
- .ops = &pl031_rtc_ops,
- phys_addr_t base;
...snip...
I think the initialization code in rtc_init() should be move to the .probe callback instead, so there's no need to keep the bool aroun.
diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index a3f8c8aecc..96c4cce410 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -55,6 +55,12 @@ config RTC_MV Enable Marvell RTC driver. This driver supports the rtc that is present on some Marvell SoCs. +config RTC_PL031
- depends on DM_RTC
- help
config RTC_S35392A bool "Enable S35392A driver" select BITREVERSE diff --git a/drivers/rtc/pl031.c b/drivers/rtc/pl031.c index 8955805e3b..eecade8374 100644 --- a/drivers/rtc/pl031.c +++ b/drivers/rtc/pl031.c @@ -8,14 +8,10 @@ #include <common.h> #include <command.h> +#include <dm.h> +#include <dm/platform_data/rtc_pl031.h> #include <rtc.h> -#if defined(CONFIG_CMD_DATE)
*/ @@ -30,78 +26,111 @@ #define RTC_CR_START (1 << 0) -#define RTC_WRITE_REG(addr, val) \
OK.
static int pl031_initted = 0; /* Enable RTC Start in Control register*/ -void rtc_init(void) +void pl031_rtc_init(struct pl031_rtc_platdata *pdata)
See the comment below.
- RTC_WRITE_REG(pdata->base, RTC_CR, RTC_CR_START); pl031_initted = 1;
rtc_init();
- ulong tim;
- if (!tm) {
return -1;
('date' command assumes that there is only one RTC device on system.)
As Tuomas suggested, init routine should go into probe function, so this global will be no longer needed.
- tim = RTC_READ_REG(pdata->base, RTC_DR);
- rtc_to_tm(tim, tm);
- debug("Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n",
- Set the RTC
rtc_init();
- if (!tm) { puts("Error setting the date/time\n"); return -1; }
- /* Calculate number of seconds this incoming time represents */
- RTC_WRITE_REG(pdata->base, RTC_LR, tim); return -1;
- ulong tim;
rtc_init();
return -1;
Anyhow, this code (rtc_init) will be gone, and RTC will stay activated after reset.
Writing 0 to CR(control) will also reset current RTC value to 0, but I don't want to change the logic.
# "date reset" shows the current date: # Reset RTC... # Date: 2000-01-01 (Saturday) Time: 0:00:00 # Is this correct behavior?
Thanks, -Takahiro AKASHI
Alex
- pdata->base = devfdt_get_addr(dev); return 0;
} -#endif +U_BOOT_DRIVER(rtc_pl031) = {
- .id = UCLASS_RTC,
- phys_addr_t base;
+config RTC_PL031
- depends on DM_RTC
- help
pl031_initted = 1;
rtc_init();
- ulong tim;
- if (!tm) {
return -1;
Please, check the return code. The RTC may contain invalid data.
- Set the RTC
Please, add a debug statement here, too.
rtc_init();
if (!pl031_initted)
return -1;
No error has occurred. Please, return 0.
- ulong tim;
rtc_init();
return -1;
nits:
There is no English word initted. I would prefer pl031_initialized.
Best regards
Heinrich
- .id = UCLASS_RTC,
- phys_addr_t base;
+config RTC_PL031
- depends on DM_RTC
- help
pl031_initted = 1;
rtc_init();
- ulong tim;
- if (!tm) {
return -1;
But how do we know if the value is bogus or not?
- Set the RTC
OK.
rtc_init();
if (!pl031_initted)
return -1;
Ouch.
- ulong tim;
rtc_init();
return -1;
nits:
This variable will go away.
Best regards
Heinrich
- .id = UCLASS_RTC,
- phys_addr_t base;
Hi Akashi,
Thank you for the DM conversion.
On 07/04/2018 10:36 AM, AKASHI Takahiro wrote: <..snip..>
- phys_addr_t base;
I think this file won't be necessary, the structure can stay private to pl031.c. PL031 is an ARM IP block and U-Boot on ARM uses the device tree to locate devices.
On Wed, Jul 04, 2018 at 02:35:19PM +0300, Tuomas Tynkkynen wrote:
Hi Akashi,
- phys_addr_t base;
I think that you are suggesting we would use udevice.priv instead of udevice.platdata, right? That will be fine with device-tree based devices. But don't we have to take care of no-device-tree (probably legacy) devices here?
Thanks, -Takhairo AKASHI
Hi Akashi,
- phys_addr_t base;
Does anybody have a comment on this? I will be able to go either with priv or platdata once agreed.
Hi Akashi,
- phys_addr_t base;
There is no need to support legacy (non-DM) options unless there is a board that doesn't build without it. Even then, the hour is late and DM conversions should be well underway, so just removing that driver from the board is probably acceptable until the maintainer gets around to it.
You should really use platdata to hold info read from the device tree, so to me what you have looks correct, except that I think the struct can be private to your driver.
Instead of devfdt_get_addr(), please use dev_read_addr() which is the livetree version.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- configs/qemu_arm64_defconfig | 2 ++ configs/qemu_arm_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index cdf5072fe4..f3e3963860 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -28,3 +28,5 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y +CONFIG_DM_RTC=y +CONFIG_RTC_PL031=y diff --git a/configs/qemu_arm_defconfig b/configs/qemu_arm_defconfig index bbce6cd719..28dfba0283 100644 --- a/configs/qemu_arm_defconfig +++ b/configs/qemu_arm_defconfig @@ -28,3 +28,5 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y +CONFIG_DM_RTC=y +CONFIG_RTC_PL031=y
Is there any particular reason you don't just do select statements in the ARCH_QEMU definition? Or maybe imply?
Alex
'select' makes it impossible to switch configuration options off. We should only use it if really needed. 'imply' is fine here.
Configuration options should appear in *_defconfig files in the same sequence as in the generated .config file. CONFIG_RTC_PL031 precedes CONFIG_SCSI.
Please, add a commit message to the next version of the patch.
Best regards
Heinrich
Alex
Basically I don't care whether those two go into defconfig or ARCH_QEMU, but as far as RTC_PL031 is concerned, it always comes with qemu's VM and "selecting" it at ARCH_QEMU is quite reasonable. Turning off this option only saves hundreds of bytes for VM. Who cares?
That's said, we will go for 'imply.'
For CMD_DATE, it will be automatically turned on if DM_RTC.
To make RTC_PL031 independent from CMD_DATE, we also have to modify rtc/date.c's dependency (DM_RTC).
So they will go away from *_defconfig.
Best regards
Heinrich
Alex
participants (5)
AKASHI Takahiro
Alexander Graf
Tuomas Tynkkynen
