[U-Boot-Users] Re: [uClinux-dev] [Announcement] U-Boot for Motorola M5272C3 and M5282EVB
Dear Bernhard,
in message 3FC7B02C.6070007@metrowerks.com you wrote:
I have attached the main patch plus two additional patches. Please note that you can't use the 5282 stuff at the moment, because there may be some licensing issues: the initialisation "templates" have been downloaded from the offical Motorola website and slightly adopted in order to be usable as u-boot pre-loader. The files didn't came along with a copyright notice, so i thought it's probably ok to use them "as is", but it seems that there may be some common "Motorola software license agreement" that excludes the code to be used in GPL environemt - means: no u-boot for 5282 for now, sorry! You may use it anyhow, but then you need do it on your own legal risk! M5272C3 is ok concerning licensing/copyrights.
As discussed before, this means I will not be able to merge your work into the public U-Boot source tree. This is a pity because (1) this stuff is interesting for a couple of people and (2) this means that the patches will be obsolete soon as the U-Boot sources change.
BTW: Richard, Wolfgang doesn't like the dual-stage boot variant i have introduced for the Coldfire (with compressed u-boot in flash). This scheme was adopted for the AT91RM9200, btw., but in this case, the pre-bootloader is not included in the u-boot tarball (or CVS tree). We could apply the same method for Coldfire as well, means the pre-bootloader needs to be downloaded and compiled seperatly. This would
As discussed before, such a design is really breaking very basic design principles of U-Boot. If not dictated by some (stupid) hardware it is not acceptable to me.
also sort out the potential licensing issue for the 5282 decribed above, as well, since the pre-bootloader is actually not linked with u-boot: the pre-bootloader and the compressed u-boot are just concaternated into the same file (and could be flashed seperatly).
Will anybody implement such a cleanup? Bernhard? Richard?
True, U-Boot is then not the "real" bootloader but just an "application" that is decompressed from flash to ram through the pre-bootloader, keeping pre-bootloader + variables + compressed u-boot typically below 64 KiB of flash. In low memory environments, such as the the M5272C3 EVB or the AT75C221-DK with only 2 MiB of flash, it makes a difference if the bootloader takes 128 KiB or only 64 KiB, but YMMV :-)
That's actually ease: the pre-bootloaders are placed in the "pre" directory and compiled seperatly from u-boot. Means: after deleting the "pre" directory, u-boot will still build for coldfire and is independendly flashable from the pre-bootloader. Without the "pre" directory, the rest of the coldfire patch looks pretty much the same way it was done for other architectures - in fact i started with some ppc directories and renamed/modified the files until it worked out. The resulting u-boot images btw. will work "stand alone" (without pre-bootloader) when being downloaded to ram through a JTAG debugger such as the BDI 2000.
best regards
Bernhard
Bernhard Kuhn
