[U-Boot] [PATCH] img2srec: use standard types
The img2srec code creates a lot of typedefs with common names. These easily clash with system headers that include these typedefs (like mingw).
Signed-off-by: Mike Frysinger vapier@gentoo.org --- tools/img2srec.c | 164 ++++++++++++++++++++--------------------------------- 1 files changed, 62 insertions(+), 102 deletions(-)
diff --git a/tools/img2srec.c b/tools/img2srec.c index f10379f..ec76964 100644 --- a/tools/img2srec.c +++ b/tools/img2srec.c @@ -53,6 +53,7 @@ |*************************************************************************/
#include "os_support.h" +#include <stdbool.h> #include <stddef.h> #include <stdio.h> #include <stdlib.h> @@ -63,63 +64,22 @@ #include <errno.h>
/************************************************************************* -| DEFINES -|*************************************************************************/ - -#define FALSE 0 -#define TRUE 1 - -/************************************************************************* -| MACROS -|*************************************************************************/ - -/************************************************************************* -| TYPEDEFS -|*************************************************************************/ - -typedef uint8_t CHAR; -typedef uint8_t BYTE; -typedef uint16_t WORD; -typedef uint32_t DWORD; -typedef int BOOL; - -/************************************************************************* -| LOCALS -|*************************************************************************/ - -/************************************************************************* -| PROTOTYPES -|*************************************************************************/ - -static char *ExtractHex(DWORD *value, char *getPtr); -static char *ExtractDecimal(DWORD *value, char *getPtr); -static void ExtractNumber(DWORD *value, char *getPtr); -static BYTE *ExtractWord(WORD *value, BYTE *buffer); -static BYTE *ExtractLong(DWORD *value, BYTE *buffer); -static BYTE *ExtractBlock(WORD count, BYTE *data, BYTE *buffer); -static char *WriteHex(char *pa, BYTE value, WORD *pCheckSum); -static char *BuildSRecord(char *pa, WORD sType, DWORD addr, - const BYTE *data, int nCount); -static void ConvertELF(char *fileName, DWORD loadOffset); -int main(int argc, char *argv[]); - -/************************************************************************* | FUNCTIONS |*************************************************************************/
-static char* ExtractHex (DWORD* value, char* getPtr) +static char* ExtractHex (uint32_t* value, char* getPtr) { - DWORD num; - DWORD digit; - BYTE c; + uint32_t num; + uint32_t digit; + uint8_t c;
while (*getPtr == ' ') getPtr++; num = 0; for (;;) { c = *getPtr; - if ((c >= '0') && (c <= '9')) digit = (DWORD)(c - '0'); - else if ((c >= 'A') && (c <= 'F')) digit = (DWORD)(c - 'A' + 10); - else if ((c >= 'a') && (c <= 'f')) digit = (DWORD)(c - 'a' + 10); + if ((c >= '0') && (c <= '9')) digit = (uint32_t)(c - '0'); + else if ((c >= 'A') && (c <= 'F')) digit = (uint32_t)(c - 'A' + 10); + else if ((c >= 'a') && (c <= 'f')) digit = (uint32_t)(c - 'a' + 10); else break; num <<= 4; num += digit; @@ -129,17 +89,17 @@ static char* ExtractHex (DWORD* value, char* getPtr) return getPtr; } /* ExtractHex */
-static char* ExtractDecimal (DWORD* value, char* getPtr) +static char* ExtractDecimal (uint32_t* value, char* getPtr) { - DWORD num; - DWORD digit; - BYTE c; + uint32_t num; + uint32_t digit; + uint8_t c;
while (*getPtr == ' ') getPtr++; num = 0; for (;;) { c = *getPtr; - if ((c >= '0') && (c <= '9')) digit = (DWORD)(c - '0'); + if ((c >= '0') && (c <= '9')) digit = (uint32_t)(c - '0'); else break; num *= 10; num += digit; @@ -150,13 +110,13 @@ static char* ExtractDecimal (DWORD* value, char* getPtr) } /* ExtractDecimal */
-static void ExtractNumber (DWORD* value, char* getPtr) +static void ExtractNumber (uint32_t* value, char* getPtr) { - BOOL neg = FALSE;; + bool neg = false;;
while (*getPtr == ' ') getPtr++; if (*getPtr == '-') { - neg = TRUE; + neg = true; getPtr++; } /* if */ if ((*getPtr == '0') && ((*(getPtr+1) == 'x') || (*(getPtr+1) == 'X'))) { @@ -170,38 +130,38 @@ static void ExtractNumber (DWORD* value, char* getPtr) } /* ExtractNumber */
-static BYTE* ExtractWord(WORD* value, BYTE* buffer) +static uint8_t* ExtractWord(uint16_t* value, uint8_t* buffer) { - WORD x; - x = (WORD)*buffer++; - x = (x<<8) + (WORD)*buffer++; + uint16_t x; + x = (uint16_t)*buffer++; + x = (x<<8) + (uint16_t)*buffer++; *value = x; return buffer; } /* ExtractWord */
-static BYTE* ExtractLong(DWORD* value, BYTE* buffer) +static uint8_t* ExtractLong(uint32_t* value, uint8_t* buffer) { - DWORD x; - x = (DWORD)*buffer++; - x = (x<<8) + (DWORD)*buffer++; - x = (x<<8) + (DWORD)*buffer++; - x = (x<<8) + (DWORD)*buffer++; + uint32_t x; + x = (uint32_t)*buffer++; + x = (x<<8) + (uint32_t)*buffer++; + x = (x<<8) + (uint32_t)*buffer++; + x = (x<<8) + (uint32_t)*buffer++; *value = x; return buffer; } /* ExtractLong */
-static BYTE* ExtractBlock(WORD count, BYTE* data, BYTE* buffer) +static uint8_t* ExtractBlock(uint16_t count, uint8_t* data, uint8_t* buffer) { while (count--) *data++ = *buffer++; return buffer; } /* ExtractBlock */
-static char* WriteHex(char* pa, BYTE value, WORD* pCheckSum) +static char* WriteHex(char* pa, uint8_t value, uint16_t* pCheckSum) { - WORD temp; + uint16_t temp;
static char ByteToHex[] = "0123456789ABCDEF";
@@ -214,13 +174,13 @@ static char* WriteHex(char* pa, BYTE value, WORD* pCheckSum) }
-static char* BuildSRecord(char* pa, WORD sType, DWORD addr, - const BYTE* data, int nCount) +static char* BuildSRecord(char* pa, uint16_t sType, uint32_t addr, + const uint8_t* data, int nCount) { - WORD addrLen; - WORD sRLen; - WORD checkSum; - WORD i; + uint16_t addrLen; + uint16_t sRLen; + uint16_t checkSum; + uint16_t i;
switch (sType) { case 0: @@ -244,11 +204,11 @@ static char* BuildSRecord(char* pa, WORD sType, DWORD addr, *pa++ = (char)(sType + '0'); sRLen = addrLen + nCount + 1; checkSum = 0; - pa = WriteHex(pa, (BYTE)sRLen, &checkSum); + pa = WriteHex(pa, (uint8_t)sRLen, &checkSum);
/* Write address field */ for (i = 1; i <= addrLen; i++) { - pa = WriteHex(pa, (BYTE)(addr >> (8 * (addrLen - i))), &checkSum); + pa = WriteHex(pa, (uint8_t)(addr >> (8 * (addrLen - i))), &checkSum); } /* for */
/* Write code/data fields */ @@ -258,25 +218,25 @@ static char* BuildSRecord(char* pa, WORD sType, DWORD addr,
/* Write checksum field */ checkSum = ~checkSum; - pa = WriteHex(pa, (BYTE)checkSum, &checkSum); + pa = WriteHex(pa, (uint8_t)checkSum, &checkSum); *pa++ = '\0'; return pa; }
-static void ConvertELF(char* fileName, DWORD loadOffset) +static void ConvertELF(char* fileName, uint32_t loadOffset) { FILE* file; int i; int rxCount; - BYTE rxBlock[1024]; - DWORD loadSize; - DWORD firstAddr; - DWORD loadAddr; - DWORD loadDiff = 0; + uint8_t rxBlock[1024]; + uint32_t loadSize; + uint32_t firstAddr; + uint32_t loadAddr; + uint32_t loadDiff = 0; Elf32_Ehdr elfHeader; Elf32_Shdr sectHeader[32]; - BYTE* getPtr; + uint8_t* getPtr; char srecLine[128]; char *hdr_name;
@@ -292,11 +252,11 @@ static void ConvertELF(char* fileName, DWORD loadOffset) getPtr = ExtractBlock(sizeof elfHeader.e_ident, elfHeader.e_ident, rxBlock); getPtr = ExtractWord(&elfHeader.e_type, getPtr); getPtr = ExtractWord(&elfHeader.e_machine, getPtr); - getPtr = ExtractLong((DWORD *)&elfHeader.e_version, getPtr); - getPtr = ExtractLong((DWORD *)&elfHeader.e_entry, getPtr); - getPtr = ExtractLong((DWORD *)&elfHeader.e_phoff, getPtr); - getPtr = ExtractLong((DWORD *)&elfHeader.e_shoff, getPtr); - getPtr = ExtractLong((DWORD *)&elfHeader.e_flags, getPtr); + getPtr = ExtractLong((uint32_t *)&elfHeader.e_version, getPtr); + getPtr = ExtractLong((uint32_t *)&elfHeader.e_entry, getPtr); + getPtr = ExtractLong((uint32_t *)&elfHeader.e_phoff, getPtr); + getPtr = ExtractLong((uint32_t *)&elfHeader.e_shoff, getPtr); + getPtr = ExtractLong((uint32_t *)&elfHeader.e_flags, getPtr); getPtr = ExtractWord(&elfHeader.e_ehsize, getPtr); getPtr = ExtractWord(&elfHeader.e_phentsize, getPtr); getPtr = ExtractWord(&elfHeader.e_phnum, getPtr); @@ -319,16 +279,16 @@ static void ConvertELF(char* fileName, DWORD loadOffset) fseek(file, elfHeader.e_shoff, SEEK_SET); for (i = 0; i < elfHeader.e_shnum; i++) { rxCount = fread(rxBlock, 1, sizeof sectHeader[0], file); - getPtr = ExtractLong((DWORD *)§Header[i].sh_name, rxBlock); - getPtr = ExtractLong((DWORD *)§Header[i].sh_type, getPtr); - getPtr = ExtractLong((DWORD *)§Header[i].sh_flags, getPtr); - getPtr = ExtractLong((DWORD *)§Header[i].sh_addr, getPtr); - getPtr = ExtractLong((DWORD *)§Header[i].sh_offset, getPtr); - getPtr = ExtractLong((DWORD *)§Header[i].sh_size, getPtr); - getPtr = ExtractLong((DWORD *)§Header[i].sh_link, getPtr); - getPtr = ExtractLong((DWORD *)§Header[i].sh_info, getPtr); - getPtr = ExtractLong((DWORD *)§Header[i].sh_addralign, getPtr); - getPtr = ExtractLong((DWORD *)§Header[i].sh_entsize, getPtr); + getPtr = ExtractLong((uint32_t *)§Header[i].sh_name, rxBlock); + getPtr = ExtractLong((uint32_t *)§Header[i].sh_type, getPtr); + getPtr = ExtractLong((uint32_t *)§Header[i].sh_flags, getPtr); + getPtr = ExtractLong((uint32_t *)§Header[i].sh_addr, getPtr); + getPtr = ExtractLong((uint32_t *)§Header[i].sh_offset, getPtr); + getPtr = ExtractLong((uint32_t *)§Header[i].sh_size, getPtr); + getPtr = ExtractLong((uint32_t *)§Header[i].sh_link, getPtr); + getPtr = ExtractLong((uint32_t *)§Header[i].sh_info, getPtr); + getPtr = ExtractLong((uint32_t *)§Header[i].sh_addralign, getPtr); + getPtr = ExtractLong((uint32_t *)§Header[i].sh_entsize, getPtr); if (rxCount != sizeof sectHeader[0]) { fclose(file); fprintf (stderr, "*** illegal file format\n"); @@ -342,7 +302,7 @@ static void ConvertELF(char* fileName, DWORD loadOffset) ++hdr_name; } /* write start record */ - (void)BuildSRecord(srecLine, 0, 0, (BYTE *)hdr_name, strlen(hdr_name)); + (void)BuildSRecord(srecLine, 0, 0, (uint8_t *)hdr_name, strlen(hdr_name)); printf("%s\r\n",srecLine);
/* write data records */ @@ -395,7 +355,7 @@ static void ConvertELF(char* fileName, DWORD loadOffset)
int main( int argc, char *argv[ ]) { - DWORD offset; + uint32_t offset;
if (argc == 2) { ConvertELF(argv[1], 0);
Dear Mike Frysinger,
Applied, thanks.
Mike Frysinger
