[PATCH] configs: lx2160a: Define ENV_ADDR value
CONFIG_ENV_ADDR helps in picking environment from flash before DDR init. Define the value as 0x20500000 for lx2160ardb and lx2160aqds.
Signed-off-by: Kuldeep Singh kuldeep.singh@nxp.com --- Hi Priyanka, This patch can be applied after applying below patch. https://patchwork.ozlabs.org/project/uboot/list/?series=141023
configs/lx2160aqds_tfa_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/lx2160aqds_tfa_defconfig b/configs/lx2160aqds_tfa_defconfig index 987b8c3..36e7bbd 100644 --- a/configs/lx2160aqds_tfa_defconfig +++ b/configs/lx2160aqds_tfa_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_BOARD_FIXUP=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2160a-qds" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index 0b0a2b2..fdeacd8 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -34,6 +34,7 @@ CONFIG_OF_BOARD_FIXUP=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2160a-rdb" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Kuldeep Singh Sent: Tuesday, February 4, 2020 12:03 PM To: u-boot@lists.denx.de Subject: [PATCH] configs: lx2160a: Define ENV_ADDR value
Applied to u-boot-fsl-qoriq. Waiting upstream
Thanks Priyanka
Kuldeep Singh
Priyanka Jain (OSS)
