[PATCH] watchdog: use time_after_eq() in watchdog_reset()
Some boards don't work with the rate-limiting done in the generic watchdog_reset() provided by wdt-uclass.
For example, on powerpc, get_timer() ceases working during bootm since interrupts are disabled before the kernel image gets decompressed, and when the decompression takes longer than the watchdog device allows (or enough of the budget that the kernel doesn't get far enough to assume responsibility for petting the watchdog), the result is a non-booting board.
As a somewhat hacky workaround (because DT is supposed to describe hardware), allow specifying hw_margin_ms=0 in device tree to effectively disable the ratelimiting and actually ping the watchdog every time watchdog_reset() is called. For that to work, the "has enough time passed" check just needs to be tweaked a little to allow the now==next_reset case as well.
Suggested-by: Christophe Leroy christophe.leroy@csgroup.eu Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk ---
It's the option I dislike the most (because of the DT abuse), but I also do accept that it's the one with the minimal code impact, and apparently the path of least resistance. So here it is.
drivers/watchdog/wdt-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 0603ffbd36..2687135296 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -148,7 +148,7 @@ void watchdog_reset(void)
/* Do not reset the watchdog too often */ now = get_timer(0); - if (time_after(now, next_reset)) { + if (time_after_eq(now, next_reset)) { next_reset = now + reset_period; wdt_reset(gd->watchdog_dev); }
Right. An alternative way would have been to add a new Kconfig symbol to define the default value of "reset_period" so that it can be configured to different values via Kconfig as well.
- if (time_after_eq(now, next_reset)) { next_reset = now + reset_period; wdt_reset(gd->watchdog_dev); }
Thanks, Stefan
No, I don't think we should not go in that direction.
Another thing I have on my todo-list is to rewrite the watchdog_reset() in wdt-uclass to handle _all_ DM watchdogs, not just the first one. Some boards make use of both the one in the CPU/SOC as well as some gpio-triggered one. Both the hw_margin_ms/reset_period and the last_reset data would then have to live with the device, not be static variables. Last I looked, it does seem that the DM code supports having a piece of class-owned, per-device data, so it shouldn't be too hard to do.
Rasmus
Great. This is a current flaw in the U-Boot WDT implementation.
Thanks for looking into this.
Thanks, Stefan
Double negation ....
You mean: I think we should go ?
Rasmus
No, there's a "not" too many. "I don't think we should go in that direction.". Thanks. Leftover from last-second rephrasing.
Rasmus
Applied to u-boot-marvell/master
Thanks, Stefan
Viele Grüße, Stefan
Christophe Leroy
Rasmus Villemoes
Stefan Roese
