[U-Boot] [PATCH 1/6 v2] powerpc/corenet_ds: Update README.srio-boot-corenet
Update some descriptions due to the implementation changes:
For master: Get rid of the SRIOBOOT_MASTER build target, and to support for serving as a SRIO boot master via environment variable. For slave: 1. When compile the slave image for boot from SRIO, no longer need to specify which SRIO port it will boot from. 2. All slave's cores should be in hold off.
Signed-off-by: Liu Gang Gang.Liu@freescale.com --- Changes in v2: - No.
doc/README.srio-boot-corenet | 70 ++++++++++++++++++++---------------------- 1 files changed, 33 insertions(+), 37 deletions(-)
diff --git a/doc/README.srio-boot-corenet b/doc/README.srio-boot-corenet index 56b094c..6a13e9c 100644 --- a/doc/README.srio-boot-corenet +++ b/doc/README.srio-boot-corenet @@ -18,7 +18,7 @@ Environment of the SRIO boot: U-Boot images, UCodes will be stored in this flash. d) Slave has its own EEPROM for RCW and PBI. e) Slave's RCW should configure the SerDes for SRIO boot port, set the boot - location to SRIO, and holdoff all the cores if needed. + location to SRIO, and holdoff all the cores.
---------- ----------- ----------- | | | | | | @@ -30,63 +30,55 @@ Environment of the SRIO boot:
The example based on P4080DS platform: Two P4080DS platforms can be used to implement the boot from SRIO. Their SRIO - ports 0 will be connected directly and will be used for the boot from SRIO. + ports 1 will be connected directly and will be used for the boot from SRIO.
- 1. Slave's RCW example for boot from SRIO port 0 and core 0 not in holdoff. - 00000000: aa55 aa55 010e 0100 0c58 0000 0000 0000 - 00000010: 1818 1818 0000 8888 7440 4000 0000 2000 - 00000020: f400 0000 0100 0000 0000 0000 0000 0000 - 00000030: 0000 0000 0083 0000 0000 0000 0000 0000 - 00000040: 0000 0000 0000 0000 0813 8040 698b 93fe - - 2. Slave's RCW example for boot from SRIO port 0 and all cores in holdoff. + 1. Slave's RCW example for boot from SRIO port 1 and all cores in holdoff. 00000000: aa55 aa55 010e 0100 0c58 0000 0000 0000 00000010: 1818 1818 0000 8888 7440 4000 0000 2000 00000020: f440 0000 0100 0000 0000 0000 0000 0000 00000030: 0000 0000 0083 0000 0000 0000 0000 0000 00000040: 0000 0000 0000 0000 0813 8040 063c 778f
- 3. Sequence in Step by Step. - a) Update RCW for slave with boot from SRIO port 0 configuration. + 2. Sequence in Step by Step. + a) Update RCW for slave with boot from SRIO port 1 configuration. b) Program slave's U-Boot image, UCode, and ENV parameters into master's NorFlash. - c) Start up master and it will boot up normally from its NorFlash. + c) Set environment variable "bootmaster" to "SRIO1" and save environment + for master. + setenv bootmaster SRIO1 + saveenv + d) Restart up master and it will boot up normally from its NorFlash. Then, it will finish necessary configurations for slave's boot from - SRIO port 0. - d) Master will set inbound SRIO windows covered slave's U-Boot image stored + SRIO port 1. + e) Master will set inbound SRIO windows covered slave's U-Boot image stored in master's NorFlash. - e) Master will set an inbound SRIO window covered slave's UCode stored in - master's NorFlash. - f) Master will set an inbound SRIO window covered slave's ENV stored in - master's NorFlash. - g) If need to release slave's core, master will set outbound SRIO windows - in order to configure slave's registers for the core's releasing. - h) If all cores of slave in holdoff, slave should be powered on before all - the above master's steps, and wait to be released by master. If not all - cores in holdoff, that means core 0 will start up normally, slave should - be powered on after all the above master's steps. In the startup phase - of the slave from SRIO, it will finish some necessary configurations. + f) Master will set an inbound SRIO window covered slave's UCode and ENV + stored in master's NorFlash. + g) Master will set outbound SRIO windows in order to configure slave's + registers for the core's releasing. + h) Since all cores of slave in holdoff, slave should be powered on before all + the above master's steps, and wait to be released by master. In the + startup phase of the slave from SRIO, it will finish some necessary + configurations. i) Slave will set a specific TLB entry for the boot process. - j) Slave will set a LAW entry with the TargetID SRIO port 0 for the boot. + j) Slave will set a LAW entry with the TargetID SRIO port 1 for the boot. k) Slave will set a specific TLB entry in order to fetch UCode and ENV from master. - l) Slave will set a LAW entry with the TargetID SRIO port 0 for UCode and ENV. + l) Slave will set a LAW entry with the TargetID SRIO port 1 for UCode and ENV.
How to use this feature: - To use this feature, you need to focus three points. + To use this feature, you need to focus those points.
1. Slave's RCW with SRIO boot configurations, and all cores in holdoff - configurations if needed. + configurations. Please refer to the examples given above.
2. U-Boot image's compilation. - For master, U-Boot image should be generated specifically by - - make xxxx_SRIOBOOT_MASTER_config. + For master, U-Boot image should be generated normally.
For example, master U-Boot image used on P4080DS should be compiled with
- make P4080DS_SRIOBOOT_MASTER_config. + make P4080DS_config.
For slave, U-Boot image should be generated specifically by
@@ -97,7 +89,11 @@ How to use this feature: make P4080DS_SRIOBOOT_SLAVE_config.
3. Necessary modifications based on a specific environment. - For a specific environment, the SRIO port for boot, the addresses of the - slave's U-Boot image, UCode, ENV stored in master's NorFlash, and any other - configurations can be modified in the file: + For a specific environment, the addresses of the slave's U-Boot image, + UCode, ENV stored in master's NorFlash, and any other configurations + can be modified in the file: include/configs/corenet_ds.h. + + 4. Set and save the environment variable "bootmaster" with "SRIO1" or "SRIO2" + for master, and then restart it in order to perform the role as a master + for boot from SRIO.
Get rid of the SRIOBOOT_MASTER build target, and to support for serving as a SRIO boot master via environment variable. Set the environment variable "bootmaster" to "SRIO1" or "SRIO2" using the following command:
setenv bootmaster SRIO1 saveenv
The "bootmaster" will enable the function of the SRIO boot master, and this has the following advantages compared with SRIOBOOT_MASTER build configuration: 1. Reduce a build configuration item in boards.cfg file. No longer need to build a special image for master, just use a normal target image and set the "bootmaster" variable. 2. No longer need to rebuild an image when change the SRIO port for boot from SRIO, just set the corresponding value to "bootmaster" based on the using SRIO port.
Signed-off-by: Liu Gang Gang.Liu@freescale.com --- Changes in v2: - Rebase. - Resolve the building breakage for non-corenet platform - Add the support for p2041rdb platform
arch/powerpc/cpu/mpc85xx/cpu_init.c | 17 +++-- arch/powerpc/cpu/mpc8xxx/srio.c | 137 ++++++++++++----------------------- arch/powerpc/include/asm/fsl_srio.h | 8 +-- boards.cfg | 4 +- include/configs/P2041RDB.h | 59 +++++++++++++++ include/configs/corenet_ds.h | 32 ++------ 6 files changed, 131 insertions(+), 126 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index fc6c287..94a27f3 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -447,11 +447,18 @@ skip_l2:
#ifdef CONFIG_SYS_SRIO srio_init(); -#ifdef CONFIG_SRIOBOOT_MASTER - srio_boot_master(); -#ifdef CONFIG_SRIOBOOT_SLAVE_HOLDOFF - srio_boot_master_release_slave(); -#endif +#ifdef CONFIG_FSL_CORENET + char *s = getenv("bootmaster"); + if (s) { + if (!strcmp(s, "SRIO1")) { + srio_boot_master(1); + srio_boot_master_release_slave(1); + } + if (!strcmp(s, "SRIO2")) { + srio_boot_master(2); + srio_boot_master_release_slave(2); + } + } #endif #endif
diff --git a/arch/powerpc/cpu/mpc8xxx/srio.c b/arch/powerpc/cpu/mpc8xxx/srio.c index c7f3949..ae83d6e 100644 --- a/arch/powerpc/cpu/mpc8xxx/srio.c +++ b/arch/powerpc/cpu/mpc8xxx/srio.c @@ -95,126 +95,92 @@ void srio_init(void) } }
-#ifdef CONFIG_SRIOBOOT_MASTER -void srio_boot_master(void) +#ifdef CONFIG_FSL_CORENET +void srio_boot_master(int port) { struct ccsr_rio *srio = (void *)CONFIG_SYS_FSL_SRIO_ADDR;
/* set port accept-all */ - out_be32((void *)&srio->impl.port[CONFIG_SRIOBOOT_MASTER_PORT].ptaacr, + out_be32((void *)&srio->impl.port[port - 1].ptaacr, SRIO_PORT_ACCEPT_ALL);
- debug("SRIOBOOT - MASTER: Master port [ %d ] for srio boot.\n", - CONFIG_SRIOBOOT_MASTER_PORT); + debug("SRIOBOOT - MASTER: Master port [ %d ] for srio boot.\n", port); /* configure inbound window for slave's u-boot image */ debug("SRIOBOOT - MASTER: Inbound window for slave's image; " "Local = 0x%llx, Srio = 0x%llx, Size = 0x%x\n", - (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_LAW_PHYS1, - (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_SRIO_PHYS1, + (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS, + (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS1, CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[0].riwtar, - CONFIG_SRIOBOOT_SLAVE_IMAGE_LAW_PHYS1 >> 12); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[0].riwbar, - CONFIG_SRIOBOOT_SLAVE_IMAGE_SRIO_PHYS1 >> 12); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[0].riwar, + out_be32((void *)&srio->atmu.port[port - 1].inbw[0].riwtar, + CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS >> 12); + out_be32((void *)&srio->atmu.port[port - 1].inbw[0].riwbar, + CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS1 >> 12); + out_be32((void *)&srio->atmu.port[port - 1].inbw[0].riwar, SRIO_IB_ATMU_AR | atmu_size_mask(CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE));
/* configure inbound window for slave's u-boot image */ debug("SRIOBOOT - MASTER: Inbound window for slave's image; " "Local = 0x%llx, Srio = 0x%llx, Size = 0x%x\n", - (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_LAW_PHYS2, - (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_SRIO_PHYS2, + (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS, + (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS2, CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[1].riwtar, - CONFIG_SRIOBOOT_SLAVE_IMAGE_LAW_PHYS2 >> 12); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[1].riwbar, - CONFIG_SRIOBOOT_SLAVE_IMAGE_SRIO_PHYS2 >> 12); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[1].riwar, + out_be32((void *)&srio->atmu.port[port - 1].inbw[1].riwtar, + CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS >> 12); + out_be32((void *)&srio->atmu.port[port - 1].inbw[1].riwbar, + CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS2 >> 12); + out_be32((void *)&srio->atmu.port[port - 1].inbw[1].riwar, SRIO_IB_ATMU_AR | atmu_size_mask(CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE));
- /* configure inbound window for slave's ucode */ - debug("SRIOBOOT - MASTER: Inbound window for slave's ucode; " + /* configure inbound window for slave's ucode and ENV */ + debug("SRIOBOOT - MASTER: Inbound window for slave's ucode and ENV; " "Local = 0x%llx, Srio = 0x%llx, Size = 0x%x\n", - (u64)CONFIG_SRIOBOOT_SLAVE_UCODE_LAW_PHYS, - (u64)CONFIG_SRIOBOOT_SLAVE_UCODE_SRIO_PHYS, - CONFIG_SRIOBOOT_SLAVE_UCODE_SIZE); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[2].riwtar, - CONFIG_SRIOBOOT_SLAVE_UCODE_LAW_PHYS >> 12); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[2].riwbar, - CONFIG_SRIOBOOT_SLAVE_UCODE_SRIO_PHYS >> 12); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[2].riwar, - SRIO_IB_ATMU_AR - | atmu_size_mask(CONFIG_SRIOBOOT_SLAVE_UCODE_SIZE)); - - /* configure inbound window for slave's ENV */ - debug("SRIOBOOT - MASTER: Inbound window for slave's ENV; " - "Local = 0x%llx, Siro = 0x%llx, Size = 0x%x\n", - CONFIG_SRIOBOOT_SLAVE_ENV_LAW_PHYS, - CONFIG_SRIOBOOT_SLAVE_ENV_SRIO_PHYS, - CONFIG_SRIOBOOT_SLAVE_ENV_SIZE); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[3].riwtar, - CONFIG_SRIOBOOT_SLAVE_ENV_LAW_PHYS >> 12); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[3].riwbar, - CONFIG_SRIOBOOT_SLAVE_ENV_SRIO_PHYS >> 12); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT].inbw[3].riwar, + (u64)CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_PHYS, + (u64)CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_BUS, + CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_SIZE); + out_be32((void *)&srio->atmu.port[port - 1].inbw[2].riwtar, + CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_PHYS >> 12); + out_be32((void *)&srio->atmu.port[port - 1].inbw[2].riwbar, + CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_BUS >> 12); + out_be32((void *)&srio->atmu.port[port - 1].inbw[2].riwar, SRIO_IB_ATMU_AR - | atmu_size_mask(CONFIG_SRIOBOOT_SLAVE_ENV_SIZE)); + | atmu_size_mask(CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_SIZE)); }
-#ifdef CONFIG_SRIOBOOT_SLAVE_HOLDOFF -void srio_boot_master_release_slave(void) +void srio_boot_master_release_slave(int port) { struct ccsr_rio *srio = (void *)CONFIG_SYS_FSL_SRIO_ADDR; u32 escsr; debug("SRIOBOOT - MASTER: " "Check the port status and release slave core ...\n");
- escsr = in_be32((void *)&srio->lp_serial - .port[CONFIG_SRIOBOOT_MASTER_PORT].pescsr); + escsr = in_be32((void *)&srio->lp_serial.port[port - 1].pescsr); if (escsr & 0x2) { if (escsr & 0x10100) { debug("SRIOBOOT - MASTER: Port [ %d ] is error.\n", - CONFIG_SRIOBOOT_MASTER_PORT); + port); } else { debug("SRIOBOOT - MASTER: " - "Port [ %d ] is ready, now release slave's core ...\n", - CONFIG_SRIOBOOT_MASTER_PORT); + "Port [ %d ] is ready, now release slave's core ...\n", + port); /* * configure outbound window * with maintenance attribute to set slave's LCSBA1CSR */ - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT] + out_be32((void *)&srio->atmu.port[port - 1] .outbw[1].rowtar, 0); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT] + out_be32((void *)&srio->atmu.port[port - 1] .outbw[1].rowtear, 0); - if (CONFIG_SRIOBOOT_MASTER_PORT) - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT] + if (port - 1) + out_be32((void *)&srio->atmu.port[port - 1] .outbw[1].rowbar, CONFIG_SYS_SRIO2_MEM_PHYS >> 12); else - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT] + out_be32((void *)&srio->atmu.port[port - 1] .outbw[1].rowbar, CONFIG_SYS_SRIO1_MEM_PHYS >> 12); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT] + out_be32((void *)&srio->atmu.port[port - 1] .outbw[1].rowar, SRIO_OB_ATMU_AR_MAINT | atmu_size_mask(SRIO_MAINT_WIN_SIZE)); @@ -223,27 +189,22 @@ void srio_boot_master_release_slave(void) * configure outbound window * with R/W attribute to set slave's BRR */ - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT] + out_be32((void *)&srio->atmu.port[port - 1] .outbw[2].rowtar, SRIO_LCSBA1CSR >> 9); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT] + out_be32((void *)&srio->atmu.port[port - 1] .outbw[2].rowtear, 0); - if (CONFIG_SRIOBOOT_MASTER_PORT) - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT] + if (port - 1) + out_be32((void *)&srio->atmu.port[port - 1] .outbw[2].rowbar, (CONFIG_SYS_SRIO2_MEM_PHYS + SRIO_MAINT_WIN_SIZE) >> 12); else - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT] + out_be32((void *)&srio->atmu.port[port - 1] .outbw[2].rowbar, (CONFIG_SYS_SRIO1_MEM_PHYS + SRIO_MAINT_WIN_SIZE) >> 12); - out_be32((void *)&srio->atmu - .port[CONFIG_SRIOBOOT_MASTER_PORT] + out_be32((void *)&srio->atmu.port[port - 1] .outbw[2].rowar, SRIO_OB_ATMU_AR_RW | atmu_size_mask(SRIO_RW_WIN_SIZE)); @@ -252,7 +213,7 @@ void srio_boot_master_release_slave(void) * Set the LCSBA1CSR register in slave * by the maint-outbound window */ - if (CONFIG_SRIOBOOT_MASTER_PORT) { + if (port - 1) { out_be32((void *)CONFIG_SYS_SRIO2_MEM_VIRT + SRIO_LCSBA1CSR_OFFSET, SRIO_LCSBA1CSR); @@ -289,8 +250,6 @@ void srio_boot_master_release_slave(void) "Release slave successfully! Now the slave should start up!\n"); } } else - debug("SRIOBOOT - MASTER: Port [ %d ] is not ready.\n", - CONFIG_SRIOBOOT_MASTER_PORT); + debug("SRIOBOOT - MASTER: Port [ %d ] is not ready.\n", port); } #endif -#endif diff --git a/arch/powerpc/include/asm/fsl_srio.h b/arch/powerpc/include/asm/fsl_srio.h index a905a26..dfd8e08 100644 --- a/arch/powerpc/include/asm/fsl_srio.h +++ b/arch/powerpc/include/asm/fsl_srio.h @@ -55,10 +55,8 @@ enum atmu_size { #define atmu_size_bytes(x) (1ULL << ((x & 0x3f) + 1))
extern void srio_init(void); -#ifdef CONFIG_SRIOBOOT_MASTER -extern void srio_boot_master(void); -#ifdef CONFIG_SRIOBOOT_SLAVE_HOLDOFF -extern void srio_boot_master_release_slave(void); -#endif +#ifdef CONFIG_FSL_CORENET +extern void srio_boot_master(int port); +extern void srio_boot_master_release_slave(int port); #endif #endif diff --git a/boards.cfg b/boards.cfg index 1af87c0..878e343 100644 --- a/boards.cfg +++ b/boards.cfg @@ -778,12 +778,12 @@ P2041RDB_NAND powerpc mpc85xx p2041rdb freescale P2041RDB_SDCARD powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P2041RDB_SECURE_BOOT powerpc mpc85xx p2041rdb freescale - P2041RDB:SECURE_BOOT P2041RDB_SPIFLASH powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 +P2041RDB_SRIOBOOT_SLAVE powerpc mpc85xx p2041rdb freescale - P2041RDB:SRIOBOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 P3041DS powerpc mpc85xx corenet_ds freescale P3041DS_NAND powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 P3041DS_SDCARD powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P3041DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P3041DS:SECURE_BOOT P3041DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P3041DS_SRIOBOOT_MASTER powerpc mpc85xx corenet_ds freescale - P3041DS:SRIOBOOT_MASTER P3041DS_SRIOBOOT_SLAVE powerpc mpc85xx corenet_ds freescale - P3041DS:SRIOBOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 P3060QDS powerpc mpc85xx p3060qds freescale P3060QDS_NAND powerpc mpc85xx p3060qds freescale - P3060QDS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 @@ -792,14 +792,12 @@ P4080DS powerpc mpc85xx corenet_ds freesca P4080DS_SDCARD powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P4080DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P4080DS:SECURE_BOOT P4080DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P4080DS_SRIOBOOT_MASTER powerpc mpc85xx corenet_ds freescale - P4080DS:SRIOBOOT_MASTER P4080DS_SRIOBOOT_SLAVE powerpc mpc85xx corenet_ds freescale - P4080DS:SRIOBOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 P5020DS powerpc mpc85xx corenet_ds freescale P5020DS_NAND powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 P5020DS_SDCARD powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P5020DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P5020DS:SECURE_BOOT P5020DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P5020DS_SRIOBOOT_MASTER powerpc mpc85xx corenet_ds freescale - P5020DS:SRIOBOOT_MASTER P5020DS_SRIOBOOT_SLAVE powerpc mpc85xx corenet_ds freescale - P5020DS:SRIOBOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 BSC9131RDB_SPIFLASH powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,SPIFLASH stxgp3 powerpc mpc85xx stxgp3 stx diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 1251b5c..f67fbf7 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -36,6 +36,15 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #endif
+#ifdef CONFIG_SRIOBOOT_SLAVE +/* Set 1M boot space */ +#define CONFIG_SYS_SRIOBOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) +#define CONFIG_SYS_SRIOBOOT_SLAVE_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIOBOOT_SLAVE_ADDR) +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_SYS_NO_FLASH +#endif + /* High Level Configuration Options */ #define CONFIG_BOOKE #define CONFIG_E500 /* BOOKE e500 family */ @@ -73,7 +82,9 @@ #define CONFIG_ENV_OVERWRITE
#ifdef CONFIG_SYS_NO_FLASH +#ifndef CONFIG_SRIOBOOT_SLAVE #define CONFIG_ENV_IS_NOWHERE +#endif #else #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI @@ -101,6 +112,12 @@ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIOBOOT_SLAVE) +#define CONFIG_ENV_IS_IN_REMOTE +#define CONFIG_ENV_ADDR 0xffe20000 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_ENV_IS_NOWHERE) +#define CONFIG_ENV_SIZE 0x2000 #else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE \ @@ -369,6 +386,38 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */
/* + * for slave u-boot IMAGE instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS 0xfef080000ull +#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS1 0xfff80000ull +#define CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE 0x80000 /* 512K */ +#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS2 0x3fff80000ull +/* + * for slave UCODE and ENV instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_PHYS 0xfef040000ull +#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_BUS 0x3ffe00000ull +#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_SIZE 0x40000 /* 256K */ + +/* slave core release by master*/ +#define CONFIG_SRIOBOOT_SLAVE_BRR_OFFSET 0xe00e4 +#define CONFIG_SRIOBOOT_SLAVE_RELEASE_MASK 0x00000001 /* release core 0 */ + +/* + * SRIOBOOT - SLAVE + */ +#ifdef CONFIG_SRIOBOOT_SLAVE +/* slave port for srioboot */ +#define CONFIG_SRIOBOOT_SLAVE_PORT0 +/* #define CONFIG_SRIOBOOT_SLAVE_PORT1 */ +#define CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR 0xFFE00000 +#define CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR) +#endif + +/* * eSPI - Enhanced SPI */ #define CONFIG_FSL_ESPI @@ -480,6 +529,16 @@ unsigned long get_board_sys_clk(unsigned long dummy); #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND #define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIOBOOT_SLAVE) +/* + * Slave has no ucode locally, it can fetch this from remote. When implementing + * in two corenet boards, slave's ucode could be stored in master's memory + * space, the address can be mapped from slave TLB->slave LAW-> + * slave SRIO outbound window->master inbound window->master LAW-> + * the ucode address in master's NOR flash. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR #define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEF000000 diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 52a5ba9..ba2b0d6 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -389,40 +389,24 @@ #define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */
/* - * SRIOBOOT - MASTER - */ -#ifdef CONFIG_SRIOBOOT_MASTER -/* master port for srioboot*/ -#define CONFIG_SRIOBOOT_MASTER_PORT 0 -/* #define CONFIG_SRIOBOOT_MASTER_PORT 1 */ -/* * for slave u-boot IMAGE instored in master memory space, * PHYS must be aligned based on the SIZE */ -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_LAW_PHYS1 0xfef080000ull -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_SRIO_PHYS1 0xfff80000ull +#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS 0xfef080000ull +#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS1 0xfff80000ull #define CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE 0x80000 /* 512K */ -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_LAW_PHYS2 0xfef080000ull -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_SRIO_PHYS2 0x3fff80000ull +#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS2 0x3fff80000ull /* - * for slave UCODE instored in master memory space, + * for slave UCODE and ENV instored in master memory space, * PHYS must be aligned based on the SIZE */ -#define CONFIG_SRIOBOOT_SLAVE_UCODE_LAW_PHYS 0xfef020000ull -#define CONFIG_SRIOBOOT_SLAVE_UCODE_SRIO_PHYS 0x3ffe00000ull -#define CONFIG_SRIOBOOT_SLAVE_UCODE_SIZE 0x10000 /* 64K */ -/* - * for slave ENV instored in master memory space, - * PHYS must be aligned based on the SIZE - */ -#define CONFIG_SRIOBOOT_SLAVE_ENV_LAW_PHYS 0xfef060000ull -#define CONFIG_SRIOBOOT_SLAVE_ENV_SRIO_PHYS 0x3ffe20000ull -#define CONFIG_SRIOBOOT_SLAVE_ENV_SIZE 0x20000 /* 128K */ +#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_PHYS 0xfef040000ull +#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_BUS 0x3ffe00000ull +#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_SIZE 0x40000 /* 256K */ + /* slave core release by master*/ -#define CONFIG_SRIOBOOT_SLAVE_HOLDOFF #define CONFIG_SRIOBOOT_SLAVE_BRR_OFFSET 0xe00e4 #define CONFIG_SRIOBOOT_SLAVE_RELEASE_MASK 0x00000001 /* release core 0 */ -#endif
/* * SRIOBOOT - SLAVE
When compile the slave image for boot from SRIO, no longer need to specify which SRIO port it will boot from. The code will get this information from RCW and then finishes corresponding configurations.
This has the following advantages: 1. No longer need to rebuild an image when change the SRIO port for boot from SRIO, just rewrite the new RCW with selected port, then the code will get the port information by reading new RCW. 2. It will be easier to support other boot location options, for example, boot from PCIE.
Signed-off-by: Liu Gang Gang.Liu@freescale.com --- Changes in v2: - Rebase. - Add the support for p2041rdb platform
arch/powerpc/include/asm/immap_85xx.h | 1 + board/freescale/common/p_corenet/law.c | 13 ------------- drivers/misc/fsl_law.c | 27 +++++++++++++++++++++++++++ include/configs/P2041RDB.h | 3 --- include/configs/corenet_ds.h | 3 --- 5 files changed, 28 insertions(+), 19 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 53d563e..91228e7 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1758,6 +1758,7 @@ typedef struct ccsr_gur { #define FSL_CORENET_RCWSR5_DDR_SYNC 0x00000080 #define FSL_CORENET_RCWSR5_DDR_SYNC_SHIFT 7 #define FSL_CORENET_RCWSR5_SRDS_EN 0x00002000 +#define FSL_CORENET_RCWSR6_BOOT_LOC 0x0f800000 #define FSL_CORENET_RCWSRn_SRDS_LPD_B2 0x3c000000 /* bits 162..165 */ #define FSL_CORENET_RCWSRn_SRDS_LPD_B3 0x003c0000 /* bits 170..173 */ #define FSL_CORENET_RCWSR7_MCK_TO_PLAT_RAT 0x00400000 diff --git a/board/freescale/common/p_corenet/law.c b/board/freescale/common/p_corenet/law.c index c4566dd..09ef561 100644 --- a/board/freescale/common/p_corenet/law.c +++ b/board/freescale/common/p_corenet/law.c @@ -48,19 +48,6 @@ struct law_entry law_table[] = { #ifdef CONFIG_SYS_NAND_BASE_PHYS SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), #endif -#ifdef CONFIG_SRIOBOOT_SLAVE -#if defined(CONFIG_SRIOBOOT_SLAVE_PORT0) - SET_LAW(CONFIG_SYS_SRIOBOOT_SLAVE_ADDR_PHYS, - LAW_SIZE_1M, LAW_TRGT_IF_RIO_1), - SET_LAW(CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS, - LAW_SIZE_1M, LAW_TRGT_IF_RIO_1), -#elif defined(CONFIG_SRIOBOOT_SLAVE_PORT1) - SET_LAW(CONFIG_SYS_SRIOBOOT_SLAVE_ADDR_PHYS, - LAW_SIZE_1M, LAW_TRGT_IF_RIO_2), - SET_LAW(CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS, - LAW_SIZE_1M, LAW_TRGT_IF_RIO_2), -#endif -#endif };
int num_law_entries = ARRAY_SIZE(law_table); diff --git a/drivers/misc/fsl_law.c b/drivers/misc/fsl_law.c index a7d04b7..a71a0ce 100644 --- a/drivers/misc/fsl_law.c +++ b/drivers/misc/fsl_law.c @@ -275,5 +275,32 @@ void init_laws(void) law_table[i].size, law_table[i].trgt_id); }
+#ifdef CONFIG_SRIOBOOT_SLAVE + /* check RCW to get which port is used for boot */ + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + u32 bootloc = in_be32(&gur->rcwsr[6]); + /* in SRIO boot we need to set specail LAWs for SRIO interfaces */ + switch ((bootloc & FSL_CORENET_RCWSR6_BOOT_LOC) >> 23) { + case 0x8: /* boot from SRIO1 */ + set_next_law(CONFIG_SYS_SRIOBOOT_SLAVE_ADDR_PHYS, + LAW_SIZE_1M, + LAW_TRGT_IF_RIO_1); + set_next_law(CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS, + LAW_SIZE_1M, + LAW_TRGT_IF_RIO_1); + break; + case 0x9: /* boot from SRIO2 */ + set_next_law(CONFIG_SYS_SRIOBOOT_SLAVE_ADDR_PHYS, + LAW_SIZE_1M, + LAW_TRGT_IF_RIO_2); + set_next_law(CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS, + LAW_SIZE_1M, + LAW_TRGT_IF_RIO_2); + break; + default: + break; + } +#endif + return ; } diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index f67fbf7..abd9ae0 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -409,9 +409,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); * SRIOBOOT - SLAVE */ #ifdef CONFIG_SRIOBOOT_SLAVE -/* slave port for srioboot */ -#define CONFIG_SRIOBOOT_SLAVE_PORT0 -/* #define CONFIG_SRIOBOOT_SLAVE_PORT1 */ #define CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR 0xFFE00000 #define CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS \ (0x300000000ull | CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR) diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index ba2b0d6..6d4ce48 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -412,9 +412,6 @@ * SRIOBOOT - SLAVE */ #ifdef CONFIG_SRIOBOOT_SLAVE -/* slave port for srioboot */ -#define CONFIG_SRIOBOOT_SLAVE_PORT0 -/* #define CONFIG_SRIOBOOT_SLAVE_PORT1 */ #define CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR 0xFFE00000 #define CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS \ (0x300000000ull | CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR)
Added descriptions about boot from PCIE in the files README and doc/README.srio-pcie-boot-corenet, and changed the name of the doc/README.srio-boot-corenet to doc/README.srio-pcie-boot-corenet.
README | 12 ++-- doc/README.srio-boot-corenet | 99 -------------------------------- doc/README.srio-pcie-boot-corenet | 112 +++++++++++++++++++++++++++++++++++++ 3 files changed, 118 insertions(+), 105 deletions(-) delete mode 100644 doc/README.srio-boot-corenet create mode 100644 doc/README.srio-pcie-boot-corenet
diff --git a/README b/README index fb9d904..81ee7d4 100644 --- a/README +++ b/README @@ -3092,12 +3092,12 @@ to save the current settings. These two #defines specify the address and size of the environment area within the remote memory space. The local device can get the environment from remote memory - space by SRIO or other links. + space by SRIO or PCIE links.
BE CAREFUL! For some special cases, the local device can not use "saveenv" command. For example, the local device will get the -environment stored in a remote NOR flash by SRIO link, but it can -not erase, write this NOR flash by SRIO interface. +environment stored in a remote NOR flash by SRIO or PCIE link, +but it can not erase, write this NOR flash by SRIO or PCIE interface.
- CONFIG_ENV_IS_IN_NAND:
@@ -3538,9 +3538,9 @@ within that device. - CONFIG_SYS_QE_FMAN_FW_IN_REMOTE Specifies that QE/FMAN firmware is located in the remote (master) memory space. CONFIG_SYS_FMAN_FW_ADDR is a virtual address which - can be mapped from slave TLB->slave LAW->slave SRIO outbound window - ->master inbound window->master LAW->the ucode address in master's - NOR flash. + can be mapped from slave TLB->slave LAW->slave SRIO or PCIE outbound + window->master inbound window->master LAW->the ucode address in + master's memory space.
Building the Software: ====================== diff --git a/doc/README.srio-boot-corenet b/doc/README.srio-boot-corenet deleted file mode 100644 index 6a13e9c..0000000 --- a/doc/README.srio-boot-corenet +++ /dev/null @@ -1,99 +0,0 @@ ------------------------------- -SRIO Boot on Corenet Platforms ------------------------------- - -For some PowerPC processors with SRIO interface, boot location can be configured -to SRIO by RCW. The processor booting from SRIO can do without flash for u-boot -image, ucode and ENV. All the images can be fetched from another processor's -memory space by SRIO link connected between them. - -This document describes the processes based on an example implemented on P4080DS -platforms and a RCW example with boot from SRIO configuration. - -Environment of the SRIO boot: - a) Master and slave can be SOCs in one board or SOCs in separate boards. - b) They are connected with SRIO links, whether 1x or 4x, and directly or - through switch system. - c) Only Master has NorFlash for booting, and all the Master's and Slave's - U-Boot images, UCodes will be stored in this flash. - d) Slave has its own EEPROM for RCW and PBI. - e) Slave's RCW should configure the SerDes for SRIO boot port, set the boot - location to SRIO, and holdoff all the cores. - - ---------- ----------- ----------- - | | | | | | - | | | | | | - | NorFlash|<----->| Master | SRIO | Slave |<---->[EEPROM] - | | | |<===========>| | - | | | | | | - ---------- ----------- ----------- - -The example based on P4080DS platform: - Two P4080DS platforms can be used to implement the boot from SRIO. Their SRIO - ports 1 will be connected directly and will be used for the boot from SRIO. - - 1. Slave's RCW example for boot from SRIO port 1 and all cores in holdoff. - 00000000: aa55 aa55 010e 0100 0c58 0000 0000 0000 - 00000010: 1818 1818 0000 8888 7440 4000 0000 2000 - 00000020: f440 0000 0100 0000 0000 0000 0000 0000 - 00000030: 0000 0000 0083 0000 0000 0000 0000 0000 - 00000040: 0000 0000 0000 0000 0813 8040 063c 778f - - 2. Sequence in Step by Step. - a) Update RCW for slave with boot from SRIO port 1 configuration. - b) Program slave's U-Boot image, UCode, and ENV parameters into master's - NorFlash. - c) Set environment variable "bootmaster" to "SRIO1" and save environment - for master. - setenv bootmaster SRIO1 - saveenv - d) Restart up master and it will boot up normally from its NorFlash. - Then, it will finish necessary configurations for slave's boot from - SRIO port 1. - e) Master will set inbound SRIO windows covered slave's U-Boot image stored - in master's NorFlash. - f) Master will set an inbound SRIO window covered slave's UCode and ENV - stored in master's NorFlash. - g) Master will set outbound SRIO windows in order to configure slave's - registers for the core's releasing. - h) Since all cores of slave in holdoff, slave should be powered on before all - the above master's steps, and wait to be released by master. In the - startup phase of the slave from SRIO, it will finish some necessary - configurations. - i) Slave will set a specific TLB entry for the boot process. - j) Slave will set a LAW entry with the TargetID SRIO port 1 for the boot. - k) Slave will set a specific TLB entry in order to fetch UCode and ENV - from master. - l) Slave will set a LAW entry with the TargetID SRIO port 1 for UCode and ENV. - -How to use this feature: - To use this feature, you need to focus those points. - - 1. Slave's RCW with SRIO boot configurations, and all cores in holdoff - configurations. - Please refer to the examples given above. - - 2. U-Boot image's compilation. - For master, U-Boot image should be generated normally. - - For example, master U-Boot image used on P4080DS should be compiled with - - make P4080DS_config. - - For slave, U-Boot image should be generated specifically by - - make xxxx_SRIOBOOT_SLAVE_config. - - For example, slave U-Boot image used on P4080DS should be compiled with - - make P4080DS_SRIOBOOT_SLAVE_config. - - 3. Necessary modifications based on a specific environment. - For a specific environment, the addresses of the slave's U-Boot image, - UCode, ENV stored in master's NorFlash, and any other configurations - can be modified in the file: - include/configs/corenet_ds.h. - - 4. Set and save the environment variable "bootmaster" with "SRIO1" or "SRIO2" - for master, and then restart it in order to perform the role as a master - for boot from SRIO. diff --git a/doc/README.srio-pcie-boot-corenet b/doc/README.srio-pcie-boot-corenet new file mode 100644 index 0000000..cd7e7ee --- /dev/null +++ b/doc/README.srio-pcie-boot-corenet @@ -0,0 +1,112 @@ +--------------------------------------- +SRIO and PCIE Boot on Corenet Platforms +--------------------------------------- + +For some PowerPC processors with SRIO or PCIE interface, boot location can be +configured to SRIO or PCIE by RCW. The processor booting from SRIO or PCIE can +do without flash for u-boot image, ucode and ENV. All the images can be fetched +from another processor's memory space by SRIO or PCIE link connected between +them. + +This document describes the processes based on an example implemented on P4080DS +platforms and a RCW example with boot from SRIO or PCIE configuration. + +Environment of the SRIO or PCIE boot: + a) Master and slave can be SOCs in one board or SOCs in separate boards. + b) They are connected with SRIO or PCIE links, whether 1x, 2x or 4x, and + directly or through switch system. + c) Only Master has NorFlash for booting, and all the Master's and Slave's + U-Boot images, UCodes will be stored in this flash. + d) Slave has its own EEPROM for RCW and PBI. + e) Slave's RCW should configure the SerDes for SRIO or PCIE boot port, set + the boot location to SRIO or PCIE, and holdoff all the cores. + + ---------- ----------- ----------- + | | | | | | + | | | | | | + | NorFlash|<----->| Master |SRIO or PCIE | Slave |<---->[EEPROM] + | | | |<===========>| | + | | | | | | + ---------- ----------- ----------- + +The example based on P4080DS platform: + Two P4080DS platforms can be used to implement the boot from SRIO or PCIE. + Their SRIO or PCIE ports 1 will be connected directly and will be used for + the boot from SRIO or PCIE. + + 1. Slave's RCW example for boot from SRIO port 1 and all cores in holdoff. + 00000000: aa55 aa55 010e 0100 0c58 0000 0000 0000 + 00000010: 1818 1818 0000 8888 7440 4000 0000 2000 + 00000020: f440 0000 0100 0000 0000 0000 0000 0000 + 00000030: 0000 0000 0083 0000 0000 0000 0000 0000 + 00000040: 0000 0000 0000 0000 0813 8040 063c 778f + + 2. Slave's RCW example for boot from PCIE port 1 and all cores in holdoff. + 00000000: aa55 aa55 010e 0100 0c58 0000 0000 0000 + 00000010: 1818 1818 0000 8888 1440 4000 0000 2000 + 00000020: f040 0000 0100 0000 0020 0000 0000 0000 + 00000030: 0000 0000 0083 0000 0000 0000 0000 0000 + 00000040: 0000 0000 0000 0000 0813 8040 547e ffc9 + + 3. Sequence in Step by Step. + a) Update RCW for slave with boot from SRIO or PCIE port 1 configuration. + b) Program slave's U-Boot image, UCode, and ENV parameters into master's + NorFlash. + c) Set environment variable "bootmaster" to "SRIO1" or "PCIE1" and save + environment for master. + setenv bootmaster SRIO1 + or + setenv bootmaster PCIE1 + saveenv + d) Restart up master and it will boot up normally from its NorFlash. + Then, it will finish necessary configurations for slave's boot from + SRIO or PCIE port 1. + e) Master will set inbound SRIO or PCIE windows covered slave's U-Boot + image stored in master's NorFlash. + f) Master will set an inbound SRIO or PCIE window covered slave's UCode + and ENV stored in master's NorFlash. + g) Master will set outbound SRIO or PCIE windows in order to configure + slave's registers for the core's releasing. + h) Since all cores of slave in holdoff, slave should be powered on before + all the above master's steps, and wait to be released by master. In the + startup phase of the slave from SRIO or PCIE, it will finish some + necessary configurations. + i) Slave will set a specific TLB entry for the boot process. + j) Slave will set a LAW entry with the TargetID SRIO or PCIE port 1 for + the boot. + k) Slave will set a specific TLB entry in order to fetch UCode and ENV + from master. + l) Slave will set a LAW entry with the TargetID SRIO or PCIE port 1 for + UCode and ENV. + +How to use this feature: + To use this feature, you need to focus those points. + + 1. Slave's RCW with SRIO or PCIE boot configurations, and all cores in holdoff + configurations. + Please refer to the examples given above. + + 2. U-Boot image's compilation. + For master, U-Boot image should be generated normally. + + For example, master U-Boot image used on P4080DS should be compiled with + + make P4080DS_config. + + For slave, U-Boot image should be generated specifically by + + make xxxx_SRIO_PCIE_BOOT_config. + + For example, slave U-Boot image used on P4080DS should be compiled with + + make P4080DS_SRIO_PCIE_BOOT_config. + + 3. Necessary modifications based on a specific environment. + For a specific environment, the addresses of the slave's U-Boot image, + UCode, ENV stored in master's NorFlash, and any other configurations + can be modified in the file: + include/configs/corenet_ds.h. + + 4. Set and save the environment variable "bootmaster" with "SRIO1", "SRIO2" + or "PCIE1", "PCIE2", "PCIE3" for master, and then restart it in order to + perform the role as a master for boot from SRIO or PCIE.
For the powerpc processors with PCIE interface, boot location can be configured from one PCIE interface by RCW. The processor booting from PCIE can do without flash for u-boot image. The image can be fetched from another processor's memory space by PCIE link connected between them.
The processor booting from PCIE is slave, the processor booting from normal flash memory space is master, and it can help slave to boot from master's memory space.
When boot from PCIE, slave's core should be in holdoff after powered on for some specific requirements. Master will release the slave's core at the right time by PCIE interface.
Environment and requirement:
master: 1. NOR flash for its own u-boot image, ucode and ENV space. 2. Slave's u-boot image is in master NOR flash. 3. Normally boot from local NOR flash. 4. Configure PCIE system if needed. slave: 1. Just has EEPROM for RCW. No flash for u-boot image, ucode and ENV. 2. Boot location should be set to one PCIE interface by RCW. 3. RCW should configure the SerDes, PCIE interfaces correctly. 4. Must set all the cores in holdoff by RCW. 5. Must be powered on before master's boot.
For the master module, need to finish these processes: 1. Initialize the PCIE port and address space. 2. Set inbound PCIE windows covered slave's u-boot image stored in master's NOR flash. 3. Set outbound windows in order to configure slave's registers for the core's releasing. 4. Should set the environment variable "bootmaster" to "PCIE1", "PCIE2" or "PCIE3" using the following command:
setenv bootmaster PCIE1 saveenv
Signed-off-by: Liu Gang Gang.Liu@freescale.com --- Changes in v2: - Rebase. - Resolve the building breakage for non-corenet platform. - Add the support for p2041rdb platform.
arch/powerpc/cpu/mpc8xxx/srio.c | 44 +++++++------- drivers/pci/fsl_pci_init.c | 116 +++++++++++++++++++++++++++++++++++++++ include/configs/P2041RDB.h | 18 +++--- include/configs/corenet_ds.h | 18 +++--- 4 files changed, 156 insertions(+), 40 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/srio.c b/arch/powerpc/cpu/mpc8xxx/srio.c index ae83d6e..0cb65b3 100644 --- a/arch/powerpc/cpu/mpc8xxx/srio.c +++ b/arch/powerpc/cpu/mpc8xxx/srio.c @@ -108,44 +108,44 @@ void srio_boot_master(int port) /* configure inbound window for slave's u-boot image */ debug("SRIOBOOT - MASTER: Inbound window for slave's image; " "Local = 0x%llx, Srio = 0x%llx, Size = 0x%x\n", - (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS, - (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS1, - CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE); + (u64)CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS, + (u64)CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1, + CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE); out_be32((void *)&srio->atmu.port[port - 1].inbw[0].riwtar, - CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS >> 12); + CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS >> 12); out_be32((void *)&srio->atmu.port[port - 1].inbw[0].riwbar, - CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS1 >> 12); + CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 >> 12); out_be32((void *)&srio->atmu.port[port - 1].inbw[0].riwar, SRIO_IB_ATMU_AR - | atmu_size_mask(CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE)); + | atmu_size_mask(CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE));
/* configure inbound window for slave's u-boot image */ debug("SRIOBOOT - MASTER: Inbound window for slave's image; " "Local = 0x%llx, Srio = 0x%llx, Size = 0x%x\n", - (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS, - (u64)CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS2, - CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE); + (u64)CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS, + (u64)CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2, + CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE); out_be32((void *)&srio->atmu.port[port - 1].inbw[1].riwtar, - CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS >> 12); + CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS >> 12); out_be32((void *)&srio->atmu.port[port - 1].inbw[1].riwbar, - CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS2 >> 12); + CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 >> 12); out_be32((void *)&srio->atmu.port[port - 1].inbw[1].riwar, SRIO_IB_ATMU_AR - | atmu_size_mask(CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE)); + | atmu_size_mask(CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE));
/* configure inbound window for slave's ucode and ENV */ debug("SRIOBOOT - MASTER: Inbound window for slave's ucode and ENV; " "Local = 0x%llx, Srio = 0x%llx, Size = 0x%x\n", - (u64)CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_PHYS, - (u64)CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_BUS, - CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_SIZE); + (u64)CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS, + (u64)CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS, + CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE); out_be32((void *)&srio->atmu.port[port - 1].inbw[2].riwtar, - CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_PHYS >> 12); + CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS >> 12); out_be32((void *)&srio->atmu.port[port - 1].inbw[2].riwbar, - CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_BUS >> 12); + CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS >> 12); out_be32((void *)&srio->atmu.port[port - 1].inbw[2].riwar, SRIO_IB_ATMU_AR - | atmu_size_mask(CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_SIZE)); + | atmu_size_mask(CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE)); }
void srio_boot_master_release_slave(int port) @@ -227,8 +227,8 @@ void srio_boot_master_release_slave(int port) */ out_be32((void *)CONFIG_SYS_SRIO2_MEM_VIRT + SRIO_MAINT_WIN_SIZE - + CONFIG_SRIOBOOT_SLAVE_BRR_OFFSET, - CONFIG_SRIOBOOT_SLAVE_RELEASE_MASK); + + CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET, + CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK); } else { out_be32((void *)CONFIG_SYS_SRIO1_MEM_VIRT + SRIO_LCSBA1CSR_OFFSET, @@ -243,8 +243,8 @@ void srio_boot_master_release_slave(int port) */ out_be32((void *)CONFIG_SYS_SRIO1_MEM_VIRT + SRIO_MAINT_WIN_SIZE - + CONFIG_SRIOBOOT_SLAVE_BRR_OFFSET, - CONFIG_SRIOBOOT_SLAVE_RELEASE_MASK); + + CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET, + CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK); } debug("SRIOBOOT - MASTER: " "Release slave successfully! Now the slave should start up!\n"); diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 1d75a82..0d46c96 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -211,6 +211,95 @@ static int fsl_pci_setup_inbound_windows(struct pci_controller *hose, return 1; }
+#ifdef CONFIG_FSL_CORENET +static void fsl_pcie_boot_master(pit_t *pi) +{ + /* configure inbound window for slave's u-boot image */ + debug("PCIEBOOT - MASTER: Inbound window for slave's image; " + "Local = 0x%llx, Bus = 0x%llx, Size = 0x%x\n", + (u64)CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS, + (u64)CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1, + CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE); + struct pci_region r_inbound; + u32 sz_inbound = __ilog2_u64(CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE) + - 1; + pci_set_region(&r_inbound, + CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1, + CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS, + sz_inbound, + PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); + + set_inbound_window(pi--, &r_inbound, + CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE); + + /* configure inbound window for slave's u-boot image */ + debug("PCIEBOOT - MASTER: Inbound window for slave's image; " + "Local = 0x%llx, Bus = 0x%llx, Size = 0x%x\n", + (u64)CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS, + (u64)CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2, + CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE); + pci_set_region(&r_inbound, + CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2, + CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS, + sz_inbound, + PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); + + set_inbound_window(pi--, &r_inbound, + CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE); + + /* configure inbound window for slave's ucode and ENV */ + debug("PCIEBOOT - MASTER: Inbound window for slave's " + "ucode and ENV; " + "Local = 0x%llx, Bus = 0x%llx, Size = 0x%x\n", + (u64)CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS, + (u64)CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS, + CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE); + sz_inbound = __ilog2_u64(CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE) + - 1; + pci_set_region(&r_inbound, + CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS, + CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS, + sz_inbound, + PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); + + set_inbound_window(pi--, &r_inbound, + CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE); +} + +static void fsl_pcie_boot_master_release_slave(int port) +{ + unsigned long release_addr; + + /* now release slave's core 0 */ + switch (port) { + case 1: + release_addr = CONFIG_SYS_PCIE1_MEM_VIRT + + CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET; + break; + case 2: + release_addr = CONFIG_SYS_PCIE2_MEM_VIRT + + CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET; + break; + case 3: + release_addr = CONFIG_SYS_PCIE3_MEM_VIRT + + CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET; + break; + default: + release_addr = 0; + break; + } + if (release_addr != 0) { + out_be32((void *)release_addr, + CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK); + debug("PCIEBOOT - MASTER: " + "Release slave successfully! Now the slave should start up!\n"); + } else { + debug("PCIEBOOT - MASTER: " + "Release slave failed!\n"); + } +} +#endif + void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) { u32 cfg_addr = (u32)&((ccsr_fsl_pci_t *)pci_info->regs)->cfg_addr; @@ -295,8 +384,25 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) /* see if we are a PCIe or PCI controller */ pci_hose_read_config_byte(hose, dev, FSL_PCIE_CAP_ID, &pcie_cap);
+#ifdef CONFIG_FSL_CORENET + /* boot from PCIE --master */ + char *s = getenv("bootmaster"); + char pcie[6]; + sprintf(pcie, "PCIE%d", pci_info->pci_num); + + if (s && (strcmp(s, pcie) == 0)) { + debug("PCIEBOOT - MASTER: Master port [ %d ] for pcie boot.\n", + pci_info->pci_num); + fsl_pcie_boot_master((pit_t *)pi); + } else { + /* inbound */ + inbound = fsl_pci_setup_inbound_windows(hose, + out_lo, pcie_cap, pi); + } +#else /* inbound */ inbound = fsl_pci_setup_inbound_windows(hose, out_lo, pcie_cap, pi); +#endif
for (r = 0; r < hose->region_count; r++) debug("PCI reg:%d %016llx:%016llx %016llx %08lx\n", r, @@ -488,6 +594,16 @@ int fsl_pci_init_port(struct fsl_pci_info *pci_info, if (fsl_is_pci_agent(hose)) { fsl_pci_config_unlock(hose); hose->last_busno = hose->first_busno; +#ifdef CONFIG_FSL_CORENET + } else { + /* boot from PCIE --master releases slave's core 0 */ + char *s = getenv("bootmaster"); + char pcie[6]; + sprintf(pcie, "PCIE%d", pci_info->pci_num); + + if (s && (strcmp(s, pcie) == 0)) + fsl_pcie_boot_master_release_slave(pci_info->pci_num); +#endif }
pci_hose_read_config_byte(hose, dev, FSL_PCIE_CAP_ID, &pcie_cap); diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index abd9ae0..725bfce 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -389,21 +389,21 @@ unsigned long get_board_sys_clk(unsigned long dummy); * for slave u-boot IMAGE instored in master memory space, * PHYS must be aligned based on the SIZE */ -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS 0xfef080000ull -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS1 0xfff80000ull -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE 0x80000 /* 512K */ -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS2 0x3fff80000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS 0xfef080000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 0xfff80000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE 0x80000 /* 512K */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 0x3fff80000ull /* * for slave UCODE and ENV instored in master memory space, * PHYS must be aligned based on the SIZE */ -#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_PHYS 0xfef040000ull -#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_BUS 0x3ffe00000ull -#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_SIZE 0x40000 /* 256K */ +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS 0xfef040000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS 0x3ffe00000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE 0x40000 /* 256K */
/* slave core release by master*/ -#define CONFIG_SRIOBOOT_SLAVE_BRR_OFFSET 0xe00e4 -#define CONFIG_SRIOBOOT_SLAVE_RELEASE_MASK 0x00000001 /* release core 0 */ +#define CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET 0xe00e4 +#define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */
/* * SRIOBOOT - SLAVE diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 6d4ce48..ac1b5f8 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -392,21 +392,21 @@ * for slave u-boot IMAGE instored in master memory space, * PHYS must be aligned based on the SIZE */ -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_PHYS 0xfef080000ull -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS1 0xfff80000ull -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_SIZE 0x80000 /* 512K */ -#define CONFIG_SRIOBOOT_SLAVE_IMAGE_MEM_BUS2 0x3fff80000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS 0xfef080000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 0xfff80000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE 0x80000 /* 512K */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 0x3fff80000ull /* * for slave UCODE and ENV instored in master memory space, * PHYS must be aligned based on the SIZE */ -#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_PHYS 0xfef040000ull -#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_MEM_BUS 0x3ffe00000ull -#define CONFIG_SRIOBOOT_SLAVE_UCODE_ENV_SIZE 0x40000 /* 256K */ +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS 0xfef040000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS 0x3ffe00000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE 0x40000 /* 256K */
Slave's ucode and ENV can be stored in master's memory space, then slave can fetch them through PCIE interface. For the corenet platform, ucode is for Fman.
NOTE: Because the slave can not erase, write master's NOR flash by PCIE interface, so it can not modify the ENV parameters stored in master's NOR flash using "saveenv" or other commands.
environment and requirement:
master: 1. NOR flash for its own u-boot image, ucode and ENV space. 2. Slave's u-boot image is in master NOR flash. 3. Put the slave's ucode and ENV into it's own memory space. 4. Normally boot from local NOR flash. 5. Configure PCIE system if needed. slave: 1. Just has EEPROM for RCW. No flash for u-boot image, ucode and ENV. 2. Boot location should be set to one PCIE interface by RCW. 3. RCW should configure the SerDes, PCIE interfaces correctly. 4. Must set all the cores in holdoff by RCW. 5. Must be powered on before master's boot.
For the slave module, need to finish these processes: 1. Set the boot location to one PCIE interface by RCW. 2. Set a specific TLB entry for the boot process. 3. Set a LAW entry with the TargetID of one PCIE for the boot. 4. Set a specific TLB entry in order to fetch ucode and ENV from master. 5. Set a LAW entry with the TargetID one of the PCIE ports for ucode and ENV. 6. Slave's u-boot image should be generated specifically by make xxxx_SRIO_PCIE_BOOT_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
In addition, the processes are very similar between boot from SRIO and boot from PCIE. Some configurations like the address spaces can be set to the same. So the module of boot from PCIE was added based on the existing module of boot from SRIO, and the following changes were needed: 1. Updated the README.srio-boot-corenet to add descriptions about boot from PCIE, and change the name to README.srio-pcie-boot-corenet. 2. Changed the compile config "xxxx_SRIOBOOT_SLAVE" to "xxxx_SRIO_PCIE_BOOT", and the image builded with "xxxx_SRIO_PCIE_BOOT" can support both the boot from SRIO and from PCIE. 3. Updated other macros and documents if needed to add information about boot from PCIE.
board/freescale/common/p_corenet/tlb.c | 18 +++++++------- boards.cfg | 8 +++--- common/env_remote.c | 4 +- drivers/misc/fsl_law.c | 39 +++++++++++++++++++++++++++----- include/configs/P2041RDB.h | 28 +++++++++++----------- include/configs/corenet_ds.h | 28 +++++++++++----------- 6 files changed, 76 insertions(+), 49 deletions(-)
diff --git a/board/freescale/common/p_corenet/tlb.c b/board/freescale/common/p_corenet/tlb.c index da21627..e5cf208 100644 --- a/board/freescale/common/p_corenet/tlb.c +++ b/board/freescale/common/p_corenet/tlb.c @@ -66,13 +66,13 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 0, BOOKE_PAGESZ_1M, 1), -#elif defined(CONFIG_SRIOBOOT_SLAVE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* - * SRIOBOOT-SLAVE. When slave boot, the address of the + * SRIO_PCIE_BOOT-SLAVE. When slave boot, the address of the * space is at 0xfff00000, it covered the 0xfffff000. */ - SET_TLB_ENTRY(1, CONFIG_SYS_SRIOBOOT_SLAVE_ADDR, - CONFIG_SYS_SRIOBOOT_SLAVE_ADDR_PHYS, + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, 0, 0, BOOKE_PAGESZ_1M, 1), #else @@ -147,13 +147,13 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 16, BOOKE_PAGESZ_1M, 1), #endif -#ifdef CONFIG_SRIOBOOT_SLAVE +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE /* - * SRIOBOOT-SLAVE. 1M space from 0xffe00000 for fetching ucode - * and ENV from master + * SRIO_PCIE_BOOT-SLAVE. 1M space from 0xffe00000 for + * fetching ucode and ENV from master */ - SET_TLB_ENTRY(1, CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR, - CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS, + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, 0, 17, BOOKE_PAGESZ_1M, 1), #endif diff --git a/boards.cfg b/boards.cfg index 878e343..1f9f8af 100644 --- a/boards.cfg +++ b/boards.cfg @@ -778,13 +778,13 @@ P2041RDB_NAND powerpc mpc85xx p2041rdb freescale P2041RDB_SDCARD powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P2041RDB_SECURE_BOOT powerpc mpc85xx p2041rdb freescale - P2041RDB:SECURE_BOOT P2041RDB_SPIFLASH powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P2041RDB_SRIOBOOT_SLAVE powerpc mpc85xx p2041rdb freescale - P2041RDB:SRIOBOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 +P2041RDB_SRIO_PCIE_BOOT powerpc mpc85xx p2041rdb freescale - P2041RDB:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 P3041DS powerpc mpc85xx corenet_ds freescale P3041DS_NAND powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 P3041DS_SDCARD powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P3041DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P3041DS:SECURE_BOOT P3041DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P3041DS_SRIOBOOT_SLAVE powerpc mpc85xx corenet_ds freescale - P3041DS:SRIOBOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 +P3041DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P3041DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 P3060QDS powerpc mpc85xx p3060qds freescale P3060QDS_NAND powerpc mpc85xx p3060qds freescale - P3060QDS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 P3060QDS_SECURE_BOOT powerpc mpc85xx p3060qds freescale - P3060QDS:SECURE_BOOT @@ -792,13 +792,13 @@ P4080DS powerpc mpc85xx corenet_ds freesca P4080DS_SDCARD powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P4080DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P4080DS:SECURE_BOOT P4080DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P4080DS_SRIOBOOT_SLAVE powerpc mpc85xx corenet_ds freescale - P4080DS:SRIOBOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 +P4080DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P4080DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 P5020DS powerpc mpc85xx corenet_ds freescale P5020DS_NAND powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 P5020DS_SDCARD powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P5020DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P5020DS:SECURE_BOOT P5020DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P5020DS_SRIOBOOT_SLAVE powerpc mpc85xx corenet_ds freescale - P5020DS:SRIOBOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 +P5020DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P5020DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 BSC9131RDB_SPIFLASH powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,SPIFLASH stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa diff --git a/common/env_remote.c b/common/env_remote.c index 3bf0f95..a7b147b 100644 --- a/common/env_remote.c +++ b/common/env_remote.c @@ -62,8 +62,8 @@ int env_init(void) #ifdef CONFIG_CMD_SAVEENV int saveenv(void) { -#ifdef CONFIG_SRIOBOOT_SLAVE - printf("Can not support the 'saveenv' when boot from SRIO!\n"); +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE + printf("Can not support the 'saveenv' when boot from SRIO or PCIE!\n"); return 1; #else return 0; diff --git a/drivers/misc/fsl_law.c b/drivers/misc/fsl_law.c index a71a0ce..223cd5d 100644 --- a/drivers/misc/fsl_law.c +++ b/drivers/misc/fsl_law.c @@ -275,25 +275,52 @@ void init_laws(void) law_table[i].size, law_table[i].trgt_id); }
-#ifdef CONFIG_SRIOBOOT_SLAVE +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE /* check RCW to get which port is used for boot */ ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; u32 bootloc = in_be32(&gur->rcwsr[6]); - /* in SRIO boot we need to set specail LAWs for SRIO interfaces */ + /* + * in SRIO or PCIE boot we need to set specail LAWs for + * SRIO or PCIE interfaces. + */ switch ((bootloc & FSL_CORENET_RCWSR6_BOOT_LOC) >> 23) { + case 0x0: /* boot from PCIE1 */ + set_next_law(CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, + LAW_SIZE_1M, + LAW_TRGT_IF_PCIE_1); + set_next_law(CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, + LAW_SIZE_1M, + LAW_TRGT_IF_PCIE_1); + break; + case 0x1: /* boot from PCIE2 */ + set_next_law(CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, + LAW_SIZE_1M, + LAW_TRGT_IF_PCIE_2); + set_next_law(CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, + LAW_SIZE_1M, + LAW_TRGT_IF_PCIE_2); + break; + case 0x2: /* boot from PCIE3 */ + set_next_law(CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, + LAW_SIZE_1M, + LAW_TRGT_IF_PCIE_3); + set_next_law(CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, + LAW_SIZE_1M, + LAW_TRGT_IF_PCIE_3); + break; case 0x8: /* boot from SRIO1 */ - set_next_law(CONFIG_SYS_SRIOBOOT_SLAVE_ADDR_PHYS, + set_next_law(CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_RIO_1); - set_next_law(CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS, + set_next_law(CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_RIO_1); break; case 0x9: /* boot from SRIO2 */ - set_next_law(CONFIG_SYS_SRIOBOOT_SLAVE_ADDR_PHYS, + set_next_law(CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_RIO_2); - set_next_law(CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS, + set_next_law(CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_RIO_2); break; diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 725bfce..f355349 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -36,11 +36,11 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #endif
-#ifdef CONFIG_SRIOBOOT_SLAVE +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE /* Set 1M boot space */ -#define CONFIG_SYS_SRIOBOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) -#define CONFIG_SYS_SRIOBOOT_SLAVE_ADDR_PHYS \ - (0x300000000ull | CONFIG_SYS_SRIOBOOT_SLAVE_ADDR) +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR) #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #define CONFIG_SYS_NO_FLASH #endif @@ -82,7 +82,7 @@ #define CONFIG_ENV_OVERWRITE
#ifdef CONFIG_SYS_NO_FLASH -#ifndef CONFIG_SRIOBOOT_SLAVE +#ifndef CONFIG_SRIO_PCIE_BOOT_SLAVE #define CONFIG_ENV_IS_NOWHERE #endif #else @@ -112,7 +112,7 @@ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIOBOOT_SLAVE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) #define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 #define CONFIG_ENV_SIZE 0x2000 @@ -406,12 +406,12 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */
/* - * SRIOBOOT - SLAVE + * SRIO_PCIE_BOOT - SLAVE */ -#ifdef CONFIG_SRIOBOOT_SLAVE -#define CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR 0xFFE00000 -#define CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR_PHYS \ - (0x300000000ull | CONFIG_SYS_SRIOBOOT_UCODE_ENV_ADDR) +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR 0xFFE00000 +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR) #endif
/* @@ -526,13 +526,13 @@ unsigned long get_board_sys_clk(unsigned long dummy); #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND #define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIOBOOT_SLAVE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing * in two corenet boards, slave's ucode could be stored in master's memory * space, the address can be mapped from slave TLB->slave LAW-> - * slave SRIO outbound window->master inbound window->master LAW-> - * the ucode address in master's NOR flash. + * slave SRIO or PCIE outbound window->master inbound window-> + * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE #define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index ac1b5f8..8872451 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -33,11 +33,11 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #endif
-#ifdef CONFIG_SRIOBOOT_SLAVE +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE /* Set 1M boot space */ -#define CONFIG_SYS_SRIOBOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) -#define CONFIG_SYS_SRIOBOOT_SLAVE_ADDR_PHYS \ - (0x300000000ull | CONFIG_SYS_SRIOBOOT_SLAVE_ADDR) +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR) #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #define CONFIG_SYS_NO_FLASH #endif @@ -77,7 +77,7 @@ #define CONFIG_ENV_OVERWRITE
#ifdef CONFIG_SYS_NO_FLASH -#ifndef CONFIG_SRIOBOOT_SLAVE +#ifndef CONFIG_SRIO_PCIE_BOOT_SLAVE #define CONFIG_ENV_IS_NOWHERE #endif #else @@ -108,7 +108,7 @@ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIOBOOT_SLAVE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) #define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 #define CONFIG_ENV_SIZE 0x2000 @@ -409,12 +409,12 @@ #define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */
/* @@ -537,13 +537,13 @@ #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND #define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIOBOOT_SLAVE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing * in two corenet boards, slave's ucode could be stored in master's memory * space, the address can be mapped from slave TLB->slave LAW-> - * slave SRIO outbound window->master inbound window->master LAW-> - * the ucode address in master's NOR flash. + * slave SRIO or PCIE outbound window->master inbound window-> + * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE #define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000
Liu Gang
