[U-Boot] [PATCH] MMC: Do not write to mmc_uclass_priv if it was not allocated
Signed-off-by: Matt Corallo git@bluematt.me --- drivers/mmc/mmc.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index aabfc71..eba20f0 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1734,7 +1734,8 @@ int mmc_init(struct mmc *mmc) #ifdef CONFIG_DM_MMC struct mmc_uclass_priv *upriv = dev_get_uclass_priv(mmc->dev);
- upriv->mmc = mmc; + if (upriv) + upriv->mmc = mmc; #endif if (mmc->has_init) return 0;
Hi Matt,
upriv->mmc = mmc;
if (upriv)
upriv->mmc = mmc;
#endif if (mmc->has_init) return 0; -- 2.1.4
Can you please add a commit message explaining why this is needed and what it fixes? How can mmc_init() be called before the MMC device is there? Is this related to this patch?
http://patchwork.ozlabs.org/patch/640735/
On 29.06.2016 05:27, Simon Glass wrote:
Hi Matt,
upriv->mmc = mmc;
if (upriv)
upriv->mmc = mmc;
It's related in a way that it fixed crash of dragonboard before I submitted my patch :)
Not sure if it meant to fix dragonboard or some other board.
Although - imho - it's nice to make check like that.. or at least some kind of assert.
Mateusz
Hi Meteusz,
On 30 June 2016 at 12:18, Mateusz Kulikowski mateusz.kulikowski@gmail.com wrote:
Hi Matt,
upriv->mmc = mmc;
if (upriv)
upriv->mmc = mmc;
An assert() would be fine with me.
Sorry, this was related to https://patchwork.ozlabs.org/patch/624614/, not dragonboard, and yes, is the same issue that was addressed by the patch you linked.
With this patch the MMC worked fine, but, indeed, as with dragonboard, its better to assign mmc instead of removing this (this seems to be the only place where mmc is actually used during boot for me, so maybe not?).
Matt
On 06/30/16 19:28, Simon Glass wrote:
Hi Meteusz,
Hi Matt,
upriv->mmc = mmc;
if (upriv)
upriv->mmc = mmc;
On 07/01/2016 04:28 AM, Simon Glass wrote:
Hi Meteusz,
Hi Matt,
upriv->mmc = mmc;
if (upriv)
upriv->mmc = mmc;
I have just one question..Maybe it's not related with this patch.. But i saw other driver did that upriv->mmc is assigned to mmc in each drivers.
What's difference with "upriv->mmc = mmc" in mmc.c?
./drivers/mmc/fsl_esdhc.c:972: upriv->mmc = priv->mmc; ./drivers/mmc/mmc.c:1606: upriv->mmc = mmc; ./drivers/mmc/mmc-uclass.c:91: return upriv->mmc; ./drivers/mmc/msm_sdhci.c:147: upriv->mmc = host->mmc; ./drivers/mmc/omap_hsmmc.c:830: upriv->mmc = mmc; ./drivers/mmc/rockchip_dw_mmc.c:114: upriv->mmc = host->mmc; ./drivers/mmc/socfpga_dw_mmc.c:110: upriv->mmc = host->mmc; ./drivers/mmc/uniphier-sd.c:727: upriv->mmc = priv->mmc; ./drivers/mmc/zynq_sdhci.c:52: upriv->mmc = host->mmc;
Is it duplicated? (I didn't see in more detail.)
Best Regards, Jaehoon Chung
Regards, Simon _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Meteusz,
Hi Matt,
upriv->mmc = mmc;
if (upriv)
upriv->mmc = mmc;
I am actually not happy with how this is at present. It should be handled by a function call. If you'd like to look at this please do, otherwise I will take a pass at it. It should be clear at this point what we need.
Hi Meteusz,
Hi Matt,
upriv->mmc = mmc;
if (upriv)
upriv->mmc = mmc;
I will send the patch for cleaning.
Jaehoon Chung
Mateusz Kulikowski
Matt Corallo
