[U-Boot] [PATCH][v2] powerpc/mpc85xx: SECURE BOOT - Bypass PAMU in case of secure boot
By default, PAMU's (IOMMU) are enabled in case of secure boot. Disable/bypass them , once the control reached the bootloader.
For non-secure boot, PAMU's are already bypassed in the default SoC configuration
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com --- Changes from v1: PAMU is available only in platforms with CORENET. Moved the changes under #define CONFIG_FSL_CORENET to fix build issues for non-corenet platforms
arch/powerpc/cpu/mpc85xx/cpu_init.c | 9 ++++++++- arch/powerpc/include/asm/immap_85xx.h | 1 + 2 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 21c3194..c522625 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -424,7 +424,8 @@ ulong cpu_init_f(void) { ulong flag = 0; extern void m8560_cpm_reset (void); -#ifdef CONFIG_SYS_DCSRBAR_PHYS +#if defined(CONFIG_SYS_DCSRBAR_PHYS) || \ + (defined(CONFIG_SECURE_BOOT) && defined(CONFIG_FSL_CORENET)) ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif #if defined(CONFIG_SECURE_BOOT) @@ -456,6 +457,12 @@ ulong cpu_init_f(void) #if defined(CONFIG_SYS_CPC_REINIT_F) disable_cpc_sram(); #endif + +#if defined(CONFIG_FSL_CORENET) + /* Put PAMU in bypass mode */ + out_be32(&gur->pamubypenr, FSL_CORENET_PAMU_BYPASS); +#endif + #endif
#ifdef CONFIG_CPM2 diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 88c1e08..0264523 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1912,6 +1912,7 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) u8 res24[64]; u32 pblsr; /* Preboot loader status */ u32 pamubypenr; /* PAMU bypass enable */ +#define FSL_CORENET_PAMU_BYPASS 0xffff0000 u32 dmacr1; /* DMA control */ u8 res25[4]; u32 gensr1; /* General status */
Ruchika Gupta
