[U-Boot] [PATCH 0/4] usb:gadget:composite: Support for composite gadget framework
This patch set provides support for composite gadget framework. Files from Linux kernel (2.6.36) - namely composite.{c|h} have been ported.
Some extra "compatibility" code has been added as well.
Lukasz Majewski (4): usb:gadget:composite Composite framework - files from Linux kernel usb:gadget:composite: Linux composite.{h/c} code adjustement for u-boot usb:gadget: Wrapper for extracting usb_gadget from linux's device usb:gadget: Extend device struct to device_data pointer
drivers/usb/gadget/composite.c | 1253 ++++++++++++++++++++++++++++++++++++++++ include/linux/usb/composite.h | 417 +++++++++++++ include/linux/usb/gadget.h | 6 + 3 files changed, 1676 insertions(+), 0 deletions(-) create mode 100644 drivers/usb/gadget/composite.c create mode 100644 include/linux/usb/composite.h
Two files from Linux kernel source tree have been ported to u-boot (Linux Kernel v2.6.36):
./include/linux/usb/composite.h ./drivers/usb/gadget/composite.c
commit d187abb9a83e6c6b6e9f2ca17962bdeafb4bc903 Author: Randy Dunlap randy.dunlap@oracle.com Date: Wed Aug 11 12:07:13 2010 -0700
USB: gadget: fix composite kernel-doc warnings
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/usb/gadget/composite.c | 1235 ++++++++++++++++++++++++++++++++++++++++ include/linux/usb/composite.h | 365 ++++++++++++ 2 files changed, 1600 insertions(+), 0 deletions(-) create mode 100644 drivers/usb/gadget/composite.c create mode 100644 include/linux/usb/composite.h
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c new file mode 100644 index 0000000..1160c55 --- /dev/null +++ b/drivers/usb/gadget/composite.c @@ -0,0 +1,1235 @@ +/* + * composite.c - infrastructure for Composite USB Gadgets + * + * Copyright (C) 2006-2008 David Brownell + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +/* #define VERBOSE_DEBUG */ + +#include <linux/kallsyms.h> +#include <linux/kernel.h> +#include <linux/slab.h> +#include <linux/device.h> + +#include <linux/usb/composite.h> + + +/* + * The code in this file is utility code, used to build a gadget driver + * from one or more "function" drivers, one or more "configuration" + * objects, and a "usb_composite_driver" by gluing them together along + * with the relevant device-wide data. + */ + +/* big enough to hold our biggest descriptor */ +#define USB_BUFSIZ 1024 + +static struct usb_composite_driver *composite; + +/* Some systems will need runtime overrides for the product identifers + * published in the device descriptor, either numbers or strings or both. + * String parameters are in UTF-8 (superset of ASCII's 7 bit characters). + */ + +static ushort idVendor; +module_param(idVendor, ushort, 0); +MODULE_PARM_DESC(idVendor, "USB Vendor ID"); + +static ushort idProduct; +module_param(idProduct, ushort, 0); +MODULE_PARM_DESC(idProduct, "USB Product ID"); + +static ushort bcdDevice; +module_param(bcdDevice, ushort, 0); +MODULE_PARM_DESC(bcdDevice, "USB Device version (BCD)"); + +static char *iManufacturer; +module_param(iManufacturer, charp, 0); +MODULE_PARM_DESC(iManufacturer, "USB Manufacturer string"); + +static char *iProduct; +module_param(iProduct, charp, 0); +MODULE_PARM_DESC(iProduct, "USB Product string"); + +static char *iSerialNumber; +module_param(iSerialNumber, charp, 0); +MODULE_PARM_DESC(iSerialNumber, "SerialNumber string"); + +/*-------------------------------------------------------------------------*/ + +/** + * usb_add_function() - add a function to a configuration + * @config: the configuration + * @function: the function being added + * Context: single threaded during gadget setup + * + * After initialization, each configuration must have one or more + * functions added to it. Adding a function involves calling its @bind() + * method to allocate resources such as interface and string identifiers + * and endpoints. + * + * This function returns the value of the function's bind(), which is + * zero for success else a negative errno value. + */ +int usb_add_function(struct usb_configuration *config, + struct usb_function *function) +{ + int value = -EINVAL; + + DBG(config->cdev, "adding '%s'/%p to config '%s'/%p\n", + function->name, function, + config->label, config); + + if (!function->set_alt || !function->disable) + goto done; + + function->config = config; + list_add_tail(&function->list, &config->functions); + + /* REVISIT *require* function->bind? */ + if (function->bind) { + value = function->bind(config, function); + if (value < 0) { + list_del(&function->list); + function->config = NULL; + } + } else + value = 0; + + /* We allow configurations that don't work at both speeds. + * If we run into a lowspeed Linux system, treat it the same + * as full speed ... it's the function drivers that will need + * to avoid bulk and ISO transfers. + */ + if (!config->fullspeed && function->descriptors) + config->fullspeed = true; + if (!config->highspeed && function->hs_descriptors) + config->highspeed = true; + +done: + if (value) + DBG(config->cdev, "adding '%s'/%p --> %d\n", + function->name, function, value); + return value; +} + +/** + * usb_function_deactivate - prevent function and gadget enumeration + * @function: the function that isn't yet ready to respond + * + * Blocks response of the gadget driver to host enumeration by + * preventing the data line pullup from being activated. This is + * normally called during @bind() processing to change from the + * initial "ready to respond" state, or when a required resource + * becomes available. + * + * For example, drivers that serve as a passthrough to a userspace + * daemon can block enumeration unless that daemon (such as an OBEX, + * MTP, or print server) is ready to handle host requests. + * + * Not all systems support software control of their USB peripheral + * data pullups. + * + * Returns zero on success, else negative errno. + */ +int usb_function_deactivate(struct usb_function *function) +{ + struct usb_composite_dev *cdev = function->config->cdev; + unsigned long flags; + int status = 0; + + spin_lock_irqsave(&cdev->lock, flags); + + if (cdev->deactivations == 0) + status = usb_gadget_disconnect(cdev->gadget); + if (status == 0) + cdev->deactivations++; + + spin_unlock_irqrestore(&cdev->lock, flags); + return status; +} + +/** + * usb_function_activate - allow function and gadget enumeration + * @function: function on which usb_function_activate() was called + * + * Reverses effect of usb_function_deactivate(). If no more functions + * are delaying their activation, the gadget driver will respond to + * host enumeration procedures. + * + * Returns zero on success, else negative errno. + */ +int usb_function_activate(struct usb_function *function) +{ + struct usb_composite_dev *cdev = function->config->cdev; + int status = 0; + + spin_lock(&cdev->lock); + + if (WARN_ON(cdev->deactivations == 0)) + status = -EINVAL; + else { + cdev->deactivations--; + if (cdev->deactivations == 0) + status = usb_gadget_connect(cdev->gadget); + } + + spin_unlock(&cdev->lock); + return status; +} + +/** + * usb_interface_id() - allocate an unused interface ID + * @config: configuration associated with the interface + * @function: function handling the interface + * Context: single threaded during gadget setup + * + * usb_interface_id() is called from usb_function.bind() callbacks to + * allocate new interface IDs. The function driver will then store that + * ID in interface, association, CDC union, and other descriptors. It + * will also handle any control requests targetted at that interface, + * particularly changing its altsetting via set_alt(). There may + * also be class-specific or vendor-specific requests to handle. + * + * All interface identifier should be allocated using this routine, to + * ensure that for example different functions don't wrongly assign + * different meanings to the same identifier. Note that since interface + * identifers are configuration-specific, functions used in more than + * one configuration (or more than once in a given configuration) need + * multiple versions of the relevant descriptors. + * + * Returns the interface ID which was allocated; or -ENODEV if no + * more interface IDs can be allocated. + */ +int usb_interface_id(struct usb_configuration *config, + struct usb_function *function) +{ + unsigned id = config->next_interface_id; + + if (id < MAX_CONFIG_INTERFACES) { + config->interface[id] = function; + config->next_interface_id = id + 1; + return id; + } + return -ENODEV; +} + +static int config_buf(struct usb_configuration *config, + enum usb_device_speed speed, void *buf, u8 type) +{ + struct usb_config_descriptor *c = buf; + void *next = buf + USB_DT_CONFIG_SIZE; + int len = USB_BUFSIZ - USB_DT_CONFIG_SIZE; + struct usb_function *f; + int status; + + /* write the config descriptor */ + c = buf; + c->bLength = USB_DT_CONFIG_SIZE; + c->bDescriptorType = type; + /* wTotalLength is written later */ + c->bNumInterfaces = config->next_interface_id; + c->bConfigurationValue = config->bConfigurationValue; + c->iConfiguration = config->iConfiguration; + c->bmAttributes = USB_CONFIG_ATT_ONE | config->bmAttributes; + c->bMaxPower = config->bMaxPower ? : (CONFIG_USB_GADGET_VBUS_DRAW / 2); + + /* There may be e.g. OTG descriptors */ + if (config->descriptors) { + status = usb_descriptor_fillbuf(next, len, + config->descriptors); + if (status < 0) + return status; + len -= status; + next += status; + } + + /* add each function's descriptors */ + list_for_each_entry(f, &config->functions, list) { + struct usb_descriptor_header **descriptors; + + if (speed == USB_SPEED_HIGH) + descriptors = f->hs_descriptors; + else + descriptors = f->descriptors; + if (!descriptors) + continue; + status = usb_descriptor_fillbuf(next, len, + (const struct usb_descriptor_header **) descriptors); + if (status < 0) + return status; + len -= status; + next += status; + } + + len = next - buf; + c->wTotalLength = cpu_to_le16(len); + return len; +} + +static int config_desc(struct usb_composite_dev *cdev, unsigned w_value) +{ + struct usb_gadget *gadget = cdev->gadget; + struct usb_configuration *c; + u8 type = w_value >> 8; + enum usb_device_speed speed = USB_SPEED_UNKNOWN; + + if (gadget_is_dualspeed(gadget)) { + int hs = 0; + + if (gadget->speed == USB_SPEED_HIGH) + hs = 1; + if (type == USB_DT_OTHER_SPEED_CONFIG) + hs = !hs; + if (hs) + speed = USB_SPEED_HIGH; + + } + + /* This is a lookup by config *INDEX* */ + w_value &= 0xff; + list_for_each_entry(c, &cdev->configs, list) { + /* ignore configs that won't work at this speed */ + if (speed == USB_SPEED_HIGH) { + if (!c->highspeed) + continue; + } else { + if (!c->fullspeed) + continue; + } + if (w_value == 0) + return config_buf(c, speed, cdev->req->buf, type); + w_value--; + } + return -EINVAL; +} + +static int count_configs(struct usb_composite_dev *cdev, unsigned type) +{ + struct usb_gadget *gadget = cdev->gadget; + struct usb_configuration *c; + unsigned count = 0; + int hs = 0; + + if (gadget_is_dualspeed(gadget)) { + if (gadget->speed == USB_SPEED_HIGH) + hs = 1; + if (type == USB_DT_DEVICE_QUALIFIER) + hs = !hs; + } + list_for_each_entry(c, &cdev->configs, list) { + /* ignore configs that won't work at this speed */ + if (hs) { + if (!c->highspeed) + continue; + } else { + if (!c->fullspeed) + continue; + } + count++; + } + return count; +} + +static void device_qual(struct usb_composite_dev *cdev) +{ + struct usb_qualifier_descriptor *qual = cdev->req->buf; + + qual->bLength = sizeof(*qual); + qual->bDescriptorType = USB_DT_DEVICE_QUALIFIER; + /* POLICY: same bcdUSB and device type info at both speeds */ + qual->bcdUSB = cdev->desc.bcdUSB; + qual->bDeviceClass = cdev->desc.bDeviceClass; + qual->bDeviceSubClass = cdev->desc.bDeviceSubClass; + qual->bDeviceProtocol = cdev->desc.bDeviceProtocol; + /* ASSUME same EP0 fifo size at both speeds */ + qual->bMaxPacketSize0 = cdev->desc.bMaxPacketSize0; + qual->bNumConfigurations = count_configs(cdev, USB_DT_DEVICE_QUALIFIER); + qual->bRESERVED = 0; +} + +/*-------------------------------------------------------------------------*/ + +static void reset_config(struct usb_composite_dev *cdev) +{ + struct usb_function *f; + + DBG(cdev, "reset config\n"); + + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->disable) + f->disable(f); + + bitmap_zero(f->endpoints, 32); + } + cdev->config = NULL; +} + +static int set_config(struct usb_composite_dev *cdev, + const struct usb_ctrlrequest *ctrl, unsigned number) +{ + struct usb_gadget *gadget = cdev->gadget; + struct usb_configuration *c = NULL; + int result = -EINVAL; + unsigned power = gadget_is_otg(gadget) ? 8 : 100; + int tmp; + + if (cdev->config) + reset_config(cdev); + + if (number) { + list_for_each_entry(c, &cdev->configs, list) { + if (c->bConfigurationValue == number) { + result = 0; + break; + } + } + if (result < 0) + goto done; + } else + result = 0; + + INFO(cdev, "%s speed config #%d: %s\n", + ({ char *speed; + switch (gadget->speed) { + case USB_SPEED_LOW: speed = "low"; break; + case USB_SPEED_FULL: speed = "full"; break; + case USB_SPEED_HIGH: speed = "high"; break; + default: speed = "?"; break; + } ; speed; }), number, c ? c->label : "unconfigured"); + + if (!c) + goto done; + + cdev->config = c; + + /* Initialize all interfaces by setting them to altsetting zero. */ + for (tmp = 0; tmp < MAX_CONFIG_INTERFACES; tmp++) { + struct usb_function *f = c->interface[tmp]; + struct usb_descriptor_header **descriptors; + + if (!f) + break; + + /* + * Record which endpoints are used by the function. This is used + * to dispatch control requests targeted at that endpoint to the + * function's setup callback instead of the current + * configuration's setup callback. + */ + if (gadget->speed == USB_SPEED_HIGH) + descriptors = f->hs_descriptors; + else + descriptors = f->descriptors; + + for (; *descriptors; ++descriptors) { + struct usb_endpoint_descriptor *ep; + int addr; + + if ((*descriptors)->bDescriptorType != USB_DT_ENDPOINT) + continue; + + ep = (struct usb_endpoint_descriptor *)*descriptors; + addr = ((ep->bEndpointAddress & 0x80) >> 3) + | (ep->bEndpointAddress & 0x0f); + set_bit(addr, f->endpoints); + } + + result = f->set_alt(f, tmp, 0); + if (result < 0) { + DBG(cdev, "interface %d (%s/%p) alt 0 --> %d\n", + tmp, f->name, f, result); + + reset_config(cdev); + goto done; + } + } + + /* when we return, be sure our power usage is valid */ + power = c->bMaxPower ? (2 * c->bMaxPower) : CONFIG_USB_GADGET_VBUS_DRAW; +done: + usb_gadget_vbus_draw(gadget, power); + return result; +} + +/** + * usb_add_config() - add a configuration to a device. + * @cdev: wraps the USB gadget + * @config: the configuration, with bConfigurationValue assigned + * Context: single threaded during gadget setup + * + * One of the main tasks of a composite driver's bind() routine is to + * add each of the configurations it supports, using this routine. + * + * This function returns the value of the configuration's bind(), which + * is zero for success else a negative errno value. Binding configurations + * assigns global resources including string IDs, and per-configuration + * resources such as interface IDs and endpoints. + */ +int usb_add_config(struct usb_composite_dev *cdev, + struct usb_configuration *config) +{ + int status = -EINVAL; + struct usb_configuration *c; + + DBG(cdev, "adding config #%u '%s'/%p\n", + config->bConfigurationValue, + config->label, config); + + if (!config->bConfigurationValue || !config->bind) + goto done; + + /* Prevent duplicate configuration identifiers */ + list_for_each_entry(c, &cdev->configs, list) { + if (c->bConfigurationValue == config->bConfigurationValue) { + status = -EBUSY; + goto done; + } + } + + config->cdev = cdev; + list_add_tail(&config->list, &cdev->configs); + + INIT_LIST_HEAD(&config->functions); + config->next_interface_id = 0; + + status = config->bind(config); + if (status < 0) { + list_del(&config->list); + config->cdev = NULL; + } else { + unsigned i; + + DBG(cdev, "cfg %d/%p speeds:%s%s\n", + config->bConfigurationValue, config, + config->highspeed ? " high" : "", + config->fullspeed + ? (gadget_is_dualspeed(cdev->gadget) + ? " full" + : " full/low") + : ""); + + for (i = 0; i < MAX_CONFIG_INTERFACES; i++) { + struct usb_function *f = config->interface[i]; + + if (!f) + continue; + DBG(cdev, " interface %d = %s/%p\n", + i, f->name, f); + } + } + + /* set_alt(), or next config->bind(), sets up + * ep->driver_data as needed. + */ + usb_ep_autoconfig_reset(cdev->gadget); + +done: + if (status) + DBG(cdev, "added config '%s'/%u --> %d\n", config->label, + config->bConfigurationValue, status); + return status; +} + +/*-------------------------------------------------------------------------*/ + +/* We support strings in multiple languages ... string descriptor zero + * says which languages are supported. The typical case will be that + * only one language (probably English) is used, with I18N handled on + * the host side. + */ + +static void collect_langs(struct usb_gadget_strings **sp, __le16 *buf) +{ + const struct usb_gadget_strings *s; + u16 language; + __le16 *tmp; + + while (*sp) { + s = *sp; + language = cpu_to_le16(s->language); + for (tmp = buf; *tmp && tmp < &buf[126]; tmp++) { + if (*tmp == language) + goto repeat; + } + *tmp++ = language; +repeat: + sp++; + } +} + +static int lookup_string( + struct usb_gadget_strings **sp, + void *buf, + u16 language, + int id +) +{ + struct usb_gadget_strings *s; + int value; + + while (*sp) { + s = *sp++; + if (s->language != language) + continue; + value = usb_gadget_get_string(s, id, buf); + if (value > 0) + return value; + } + return -EINVAL; +} + +static int get_string(struct usb_composite_dev *cdev, + void *buf, u16 language, int id) +{ + struct usb_configuration *c; + struct usb_function *f; + int len; + + /* Yes, not only is USB's I18N support probably more than most + * folk will ever care about ... also, it's all supported here. + * (Except for UTF8 support for Unicode's "Astral Planes".) + */ + + /* 0 == report all available language codes */ + if (id == 0) { + struct usb_string_descriptor *s = buf; + struct usb_gadget_strings **sp; + + memset(s, 0, 256); + s->bDescriptorType = USB_DT_STRING; + + sp = composite->strings; + if (sp) + collect_langs(sp, s->wData); + + list_for_each_entry(c, &cdev->configs, list) { + sp = c->strings; + if (sp) + collect_langs(sp, s->wData); + + list_for_each_entry(f, &c->functions, list) { + sp = f->strings; + if (sp) + collect_langs(sp, s->wData); + } + } + + for (len = 0; len <= 126 && s->wData[len]; len++) + continue; + if (!len) + return -EINVAL; + + s->bLength = 2 * (len + 1); + return s->bLength; + } + + /* Otherwise, look up and return a specified string. String IDs + * are device-scoped, so we look up each string table we're told + * about. These lookups are infrequent; simpler-is-better here. + */ + if (composite->strings) { + len = lookup_string(composite->strings, buf, language, id); + if (len > 0) + return len; + } + list_for_each_entry(c, &cdev->configs, list) { + if (c->strings) { + len = lookup_string(c->strings, buf, language, id); + if (len > 0) + return len; + } + list_for_each_entry(f, &c->functions, list) { + if (!f->strings) + continue; + len = lookup_string(f->strings, buf, language, id); + if (len > 0) + return len; + } + } + return -EINVAL; +} + +/** + * usb_string_id() - allocate an unused string ID + * @cdev: the device whose string descriptor IDs are being allocated + * Context: single threaded during gadget setup + * + * @usb_string_id() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then store that ID in the appropriate descriptors and string table. + * + * All string identifier should be allocated using this, + * @usb_string_ids_tab() or @usb_string_ids_n() routine, to ensure + * that for example different functions don't wrongly assign different + * meanings to the same identifier. + */ +int usb_string_id(struct usb_composite_dev *cdev) +{ + if (cdev->next_string_id < 254) { + /* string id 0 is reserved by USB spec for list of + * supported languages */ + /* 255 reserved as well? -- mina86 */ + cdev->next_string_id++; + return cdev->next_string_id; + } + return -ENODEV; +} + +/** + * usb_string_ids() - allocate unused string IDs in batch + * @cdev: the device whose string descriptor IDs are being allocated + * @str: an array of usb_string objects to assign numbers to + * Context: single threaded during gadget setup + * + * @usb_string_ids() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then copy IDs from the string table to the appropriate descriptors + * and string table for other languages. + * + * All string identifier should be allocated using this, + * @usb_string_id() or @usb_string_ids_n() routine, to ensure that for + * example different functions don't wrongly assign different meanings + * to the same identifier. + */ +int usb_string_ids_tab(struct usb_composite_dev *cdev, struct usb_string *str) +{ + int next = cdev->next_string_id; + + for (; str->s; ++str) { + if (unlikely(next >= 254)) + return -ENODEV; + str->id = ++next; + } + + cdev->next_string_id = next; + + return 0; +} + +/** + * usb_string_ids_n() - allocate unused string IDs in batch + * @c: the device whose string descriptor IDs are being allocated + * @n: number of string IDs to allocate + * Context: single threaded during gadget setup + * + * Returns the first requested ID. This ID and next @n-1 IDs are now + * valid IDs. At least provided that @n is non-zero because if it + * is, returns last requested ID which is now very useful information. + * + * @usb_string_ids_n() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then store that ID in the appropriate descriptors and string table. + * + * All string identifier should be allocated using this, + * @usb_string_id() or @usb_string_ids_n() routine, to ensure that for + * example different functions don't wrongly assign different meanings + * to the same identifier. + */ +int usb_string_ids_n(struct usb_composite_dev *c, unsigned n) +{ + unsigned next = c->next_string_id; + if (unlikely(n > 254 || (unsigned)next + n > 254)) + return -ENODEV; + c->next_string_id += n; + return next + 1; +} + + +/*-------------------------------------------------------------------------*/ + +static void composite_setup_complete(struct usb_ep *ep, struct usb_request *req) +{ + if (req->status || req->actual != req->length) + DBG((struct usb_composite_dev *) ep->driver_data, + "setup complete --> %d, %d/%d\n", + req->status, req->actual, req->length); +} + +/* + * The setup() callback implements all the ep0 functionality that's + * not handled lower down, in hardware or the hardware driver(like + * device and endpoint feature flags, and their status). It's all + * housekeeping for the gadget function we're implementing. Most of + * the work is in config and function specific setup. + */ +static int +composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_request *req = cdev->req; + int value = -EOPNOTSUPP; + u16 w_index = le16_to_cpu(ctrl->wIndex); + u8 intf = w_index & 0xFF; + u16 w_value = le16_to_cpu(ctrl->wValue); + u16 w_length = le16_to_cpu(ctrl->wLength); + struct usb_function *f = NULL; + u8 endp; + + /* partial re-init of the response message; the function or the + * gadget might need to intercept e.g. a control-OUT completion + * when we delegate to it. + */ + req->zero = 0; + req->complete = composite_setup_complete; + req->length = USB_BUFSIZ; + gadget->ep0->driver_data = cdev; + + switch (ctrl->bRequest) { + + /* we handle all standard USB descriptors */ + case USB_REQ_GET_DESCRIPTOR: + if (ctrl->bRequestType != USB_DIR_IN) + goto unknown; + switch (w_value >> 8) { + + case USB_DT_DEVICE: + cdev->desc.bNumConfigurations = + count_configs(cdev, USB_DT_DEVICE); + value = min(w_length, (u16) sizeof cdev->desc); + memcpy(req->buf, &cdev->desc, value); + break; + case USB_DT_DEVICE_QUALIFIER: + if (!gadget_is_dualspeed(gadget)) + break; + device_qual(cdev); + value = min_t(int, w_length, + sizeof(struct usb_qualifier_descriptor)); + break; + case USB_DT_OTHER_SPEED_CONFIG: + if (!gadget_is_dualspeed(gadget)) + break; + /* FALLTHROUGH */ + case USB_DT_CONFIG: + value = config_desc(cdev, w_value); + if (value >= 0) + value = min(w_length, (u16) value); + break; + case USB_DT_STRING: + value = get_string(cdev, req->buf, + w_index, w_value & 0xff); + if (value >= 0) + value = min(w_length, (u16) value); + break; + } + break; + + /* any number of configs can work */ + case USB_REQ_SET_CONFIGURATION: + if (ctrl->bRequestType != 0) + goto unknown; + if (gadget_is_otg(gadget)) { + if (gadget->a_hnp_support) + DBG(cdev, "HNP available\n"); + else if (gadget->a_alt_hnp_support) + DBG(cdev, "HNP on another port\n"); + else + VDBG(cdev, "HNP inactive\n"); + } + spin_lock(&cdev->lock); + value = set_config(cdev, ctrl, w_value); + spin_unlock(&cdev->lock); + break; + case USB_REQ_GET_CONFIGURATION: + if (ctrl->bRequestType != USB_DIR_IN) + goto unknown; + if (cdev->config) + *(u8 *)req->buf = cdev->config->bConfigurationValue; + else + *(u8 *)req->buf = 0; + value = min(w_length, (u16) 1); + break; + + /* function drivers must handle get/set altsetting; if there's + * no get() method, we know only altsetting zero works. + */ + case USB_REQ_SET_INTERFACE: + if (ctrl->bRequestType != USB_RECIP_INTERFACE) + goto unknown; + if (!cdev->config || w_index >= MAX_CONFIG_INTERFACES) + break; + f = cdev->config->interface[intf]; + if (!f) + break; + if (w_value && !f->set_alt) + break; + value = f->set_alt(f, w_index, w_value); + break; + case USB_REQ_GET_INTERFACE: + if (ctrl->bRequestType != (USB_DIR_IN|USB_RECIP_INTERFACE)) + goto unknown; + if (!cdev->config || w_index >= MAX_CONFIG_INTERFACES) + break; + f = cdev->config->interface[intf]; + if (!f) + break; + /* lots of interfaces only need altsetting zero... */ + value = f->get_alt ? f->get_alt(f, w_index) : 0; + if (value < 0) + break; + *((u8 *)req->buf) = value; + value = min(w_length, (u16) 1); + break; + default: +unknown: + VDBG(cdev, + "non-core control req%02x.%02x v%04x i%04x l%d\n", + ctrl->bRequestType, ctrl->bRequest, + w_value, w_index, w_length); + + /* functions always handle their interfaces and endpoints... + * punt other recipients (other, WUSB, ...) to the current + * configuration code. + * + * REVISIT it could make sense to let the composite device + * take such requests too, if that's ever needed: to work + * in config 0, etc. + */ + switch (ctrl->bRequestType & USB_RECIP_MASK) { + case USB_RECIP_INTERFACE: + f = cdev->config->interface[intf]; + break; + + case USB_RECIP_ENDPOINT: + endp = ((w_index & 0x80) >> 3) | (w_index & 0x0f); + list_for_each_entry(f, &cdev->config->functions, list) { + if (test_bit(endp, f->endpoints)) + break; + } + if (&f->list == &cdev->config->functions) + f = NULL; + break; + } + + if (f && f->setup) + value = f->setup(f, ctrl); + else { + struct usb_configuration *c; + + c = cdev->config; + if (c && c->setup) + value = c->setup(c, ctrl); + } + + goto done; + } + + /* respond with data transfer before status phase? */ + if (value >= 0) { + req->length = value; + req->zero = value < w_length; + value = usb_ep_queue(gadget->ep0, req, GFP_ATOMIC); + if (value < 0) { + DBG(cdev, "ep_queue --> %d\n", value); + req->status = 0; + composite_setup_complete(gadget->ep0, req); + } + } + +done: + /* device either stalls (value < 0) or reports success */ + return value; +} + +static void composite_disconnect(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + unsigned long flags; + + /* REVISIT: should we have config and device level + * disconnect callbacks? + */ + spin_lock_irqsave(&cdev->lock, flags); + if (cdev->config) + reset_config(cdev); + if (composite->disconnect) + composite->disconnect(cdev); + spin_unlock_irqrestore(&cdev->lock, flags); +} + +/*-------------------------------------------------------------------------*/ + +static ssize_t composite_show_suspended(struct device *dev, + struct device_attribute *attr, + char *buf) +{ + struct usb_gadget *gadget = dev_to_usb_gadget(dev); + struct usb_composite_dev *cdev = get_gadget_data(gadget); + + return sprintf(buf, "%d\n", cdev->suspended); +} + +static DEVICE_ATTR(suspended, 0444, composite_show_suspended, NULL); + +static void +composite_unbind(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + + /* composite_disconnect() must already have been called + * by the underlying peripheral controller driver! + * so there's no i/o concurrency that could affect the + * state protected by cdev->lock. + */ + WARN_ON(cdev->config); + + while (!list_empty(&cdev->configs)) { + struct usb_configuration *c; + + c = list_first_entry(&cdev->configs, + struct usb_configuration, list); + while (!list_empty(&c->functions)) { + struct usb_function *f; + + f = list_first_entry(&c->functions, + struct usb_function, list); + list_del(&f->list); + if (f->unbind) { + DBG(cdev, "unbind function '%s'/%p\n", + f->name, f); + f->unbind(c, f); + /* may free memory for "f" */ + } + } + list_del(&c->list); + if (c->unbind) { + DBG(cdev, "unbind config '%s'/%p\n", c->label, c); + c->unbind(c); + /* may free memory for "c" */ + } + } + if (composite->unbind) + composite->unbind(cdev); + + if (cdev->req) { + kfree(cdev->req->buf); + usb_ep_free_request(gadget->ep0, cdev->req); + } + kfree(cdev); + set_gadget_data(gadget, NULL); + device_remove_file(&gadget->dev, &dev_attr_suspended); + composite = NULL; +} + +static void +string_override_one(struct usb_gadget_strings *tab, u8 id, const char *s) +{ + struct usb_string *str = tab->strings; + + for (str = tab->strings; str->s; str++) { + if (str->id == id) { + str->s = s; + return; + } + } +} + +static void +string_override(struct usb_gadget_strings **tab, u8 id, const char *s) +{ + while (*tab) { + string_override_one(*tab, id, s); + tab++; + } +} + +static int composite_bind(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev; + int status = -ENOMEM; + + cdev = kzalloc(sizeof *cdev, GFP_KERNEL); + if (!cdev) + return status; + + spin_lock_init(&cdev->lock); + cdev->gadget = gadget; + set_gadget_data(gadget, cdev); + INIT_LIST_HEAD(&cdev->configs); + + /* preallocate control response and buffer */ + cdev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL); + if (!cdev->req) + goto fail; + cdev->req->buf = kmalloc(USB_BUFSIZ, GFP_KERNEL); + if (!cdev->req->buf) + goto fail; + cdev->req->complete = composite_setup_complete; + gadget->ep0->driver_data = cdev; + + cdev->bufsiz = USB_BUFSIZ; + cdev->driver = composite; + + usb_gadget_set_selfpowered(gadget); + + /* interface and string IDs start at zero via kzalloc. + * we force endpoints to start unassigned; few controller + * drivers will zero ep->driver_data. + */ + usb_ep_autoconfig_reset(cdev->gadget); + + /* standardized runtime overrides for device ID data */ + if (idVendor) + cdev->desc.idVendor = cpu_to_le16(idVendor); + if (idProduct) + cdev->desc.idProduct = cpu_to_le16(idProduct); + if (bcdDevice) + cdev->desc.bcdDevice = cpu_to_le16(bcdDevice); + + /* composite gadget needs to assign strings for whole device (like + * serial number), register function drivers, potentially update + * power state and consumption, etc + */ + status = composite->bind(cdev); + if (status < 0) + goto fail; + + cdev->desc = *composite->dev; + cdev->desc.bMaxPacketSize0 = gadget->ep0->maxpacket; + + /* strings can't be assigned before bind() allocates the + * releavnt identifiers + */ + if (cdev->desc.iManufacturer && iManufacturer) + string_override(composite->strings, + cdev->desc.iManufacturer, iManufacturer); + if (cdev->desc.iProduct && iProduct) + string_override(composite->strings, + cdev->desc.iProduct, iProduct); + if (cdev->desc.iSerialNumber && iSerialNumber) + string_override(composite->strings, + cdev->desc.iSerialNumber, iSerialNumber); + + status = device_create_file(&gadget->dev, &dev_attr_suspended); + if (status) + goto fail; + + INFO(cdev, "%s ready\n", composite->name); + return 0; + +fail: + composite_unbind(gadget); + return status; +} + +/*-------------------------------------------------------------------------*/ + +static void +composite_suspend(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_function *f; + + /* REVISIT: should we have config level + * suspend/resume callbacks? + */ + DBG(cdev, "suspend\n"); + if (cdev->config) { + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->suspend) + f->suspend(f); + } + } + if (composite->suspend) + composite->suspend(cdev); + + cdev->suspended = 1; +} + +static void +composite_resume(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_function *f; + + /* REVISIT: should we have config level + * suspend/resume callbacks? + */ + DBG(cdev, "resume\n"); + if (composite->resume) + composite->resume(cdev); + if (cdev->config) { + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->resume) + f->resume(f); + } + } + + cdev->suspended = 0; +} + +/*-------------------------------------------------------------------------*/ + +static struct usb_gadget_driver composite_driver = { + .speed = USB_SPEED_HIGH, + + .bind = composite_bind, + .unbind = composite_unbind, + + .setup = composite_setup, + .disconnect = composite_disconnect, + + .suspend = composite_suspend, + .resume = composite_resume, + + .driver = { + .owner = THIS_MODULE, + }, +}; + +/** + * usb_composite_register() - register a composite driver + * @driver: the driver to register + * Context: single threaded during gadget setup + * + * This function is used to register drivers using the composite driver + * framework. The return value is zero, or a negative errno value. + * Those values normally come from the driver's @bind method, which does + * all the work of setting up the driver to match the hardware. + * + * On successful return, the gadget is ready to respond to requests from + * the host, unless one of its components invokes usb_gadget_disconnect() + * while it was binding. That would usually be done in order to wait for + * some userspace participation. + */ +int usb_composite_register(struct usb_composite_driver *driver) +{ + if (!driver || !driver->dev || !driver->bind || composite) + return -EINVAL; + + if (!driver->name) + driver->name = "composite"; + composite_driver.function = (char *) driver->name; + composite_driver.driver.name = driver->name; + composite = driver; + + return usb_gadget_register_driver(&composite_driver); +} + +/** + * usb_composite_unregister() - unregister a composite driver + * @driver: the driver to unregister + * + * This function is used to unregister drivers using the composite + * driver framework. + */ +void usb_composite_unregister(struct usb_composite_driver *driver) +{ + if (composite != driver) + return; + usb_gadget_unregister_driver(&composite_driver); +} diff --git a/include/linux/usb/composite.h b/include/linux/usb/composite.h new file mode 100644 index 0000000..6170681 --- /dev/null +++ b/include/linux/usb/composite.h @@ -0,0 +1,365 @@ +/* + * composite.h -- framework for usb gadgets which are composite devices + * + * Copyright (C) 2006-2008 David Brownell + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef __LINUX_USB_COMPOSITE_H +#define __LINUX_USB_COMPOSITE_H + +/* + * This framework is an optional layer on top of the USB Gadget interface, + * making it easier to build (a) Composite devices, supporting multiple + * functions within any single configuration, and (b) Multi-configuration + * devices, also supporting multiple functions but without necessarily + * having more than one function per configuration. + * + * Example: a device with a single configuration supporting both network + * link and mass storage functions is a composite device. Those functions + * might alternatively be packaged in individual configurations, but in + * the composite model the host can use both functions at the same time. + */ + +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> + + +struct usb_configuration; + +/** + * struct usb_function - describes one function of a configuration + * @name: For diagnostics, identifies the function. + * @strings: tables of strings, keyed by identifiers assigned during bind() + * and by language IDs provided in control requests + * @descriptors: Table of full (or low) speed descriptors, using interface and + * string identifiers assigned during @bind(). If this pointer is null, + * the function will not be available at full speed (or at low speed). + * @hs_descriptors: Table of high speed descriptors, using interface and + * string identifiers assigned during @bind(). If this pointer is null, + * the function will not be available at high speed. + * @config: assigned when @usb_add_function() is called; this is the + * configuration with which this function is associated. + * @bind: Before the gadget can register, all of its functions bind() to the + * available resources including string and interface identifiers used + * in interface or class descriptors; endpoints; I/O buffers; and so on. + * @unbind: Reverses @bind; called as a side effect of unregistering the + * driver which added this function. + * @set_alt: (REQUIRED) Reconfigures altsettings; function drivers may + * initialize usb_ep.driver data at this time (when it is used). + * Note that setting an interface to its current altsetting resets + * interface state, and that all interfaces have a disabled state. + * @get_alt: Returns the active altsetting. If this is not provided, + * then only altsetting zero is supported. + * @disable: (REQUIRED) Indicates the function should be disabled. Reasons + * include host resetting or reconfiguring the gadget, and disconnection. + * @setup: Used for interface-specific control requests. + * @suspend: Notifies functions when the host stops sending USB traffic. + * @resume: Notifies functions when the host restarts USB traffic. + * + * A single USB function uses one or more interfaces, and should in most + * cases support operation at both full and high speeds. Each function is + * associated by @usb_add_function() with a one configuration; that function + * causes @bind() to be called so resources can be allocated as part of + * setting up a gadget driver. Those resources include endpoints, which + * should be allocated using @usb_ep_autoconfig(). + * + * To support dual speed operation, a function driver provides descriptors + * for both high and full speed operation. Except in rare cases that don't + * involve bulk endpoints, each speed needs different endpoint descriptors. + * + * Function drivers choose their own strategies for managing instance data. + * The simplest strategy just declares it "static', which means the function + * can only be activated once. If the function needs to be exposed in more + * than one configuration at a given speed, it needs to support multiple + * usb_function structures (one for each configuration). + * + * A more complex strategy might encapsulate a @usb_function structure inside + * a driver-specific instance structure to allows multiple activations. An + * example of multiple activations might be a CDC ACM function that supports + * two or more distinct instances within the same configuration, providing + * several independent logical data links to a USB host. + */ +struct usb_function { + const char *name; + struct usb_gadget_strings **strings; + struct usb_descriptor_header **descriptors; + struct usb_descriptor_header **hs_descriptors; + + struct usb_configuration *config; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching. + * Related: unbind() may kfree() but bind() won't... + */ + + /* configuration management: bind/unbind */ + int (*bind)(struct usb_configuration *, + struct usb_function *); + void (*unbind)(struct usb_configuration *, + struct usb_function *); + + /* runtime state management */ + int (*set_alt)(struct usb_function *, + unsigned interface, unsigned alt); + int (*get_alt)(struct usb_function *, + unsigned interface); + void (*disable)(struct usb_function *); + int (*setup)(struct usb_function *, + const struct usb_ctrlrequest *); + void (*suspend)(struct usb_function *); + void (*resume)(struct usb_function *); + + /* private: */ + /* internals */ + struct list_head list; + DECLARE_BITMAP(endpoints, 32); +}; + +int usb_add_function(struct usb_configuration *, struct usb_function *); + +int usb_function_deactivate(struct usb_function *); +int usb_function_activate(struct usb_function *); + +int usb_interface_id(struct usb_configuration *, struct usb_function *); + +/** + * ep_choose - select descriptor endpoint at current device speed + * @g: gadget, connected and running at some speed + * @hs: descriptor to use for high speed operation + * @fs: descriptor to use for full or low speed operation + */ +static inline struct usb_endpoint_descriptor * +ep_choose(struct usb_gadget *g, struct usb_endpoint_descriptor *hs, + struct usb_endpoint_descriptor *fs) +{ + if (gadget_is_dualspeed(g) && g->speed == USB_SPEED_HIGH) + return hs; + return fs; +} + +#define MAX_CONFIG_INTERFACES 16 /* arbitrary; max 255 */ + +/** + * struct usb_configuration - represents one gadget configuration + * @label: For diagnostics, describes the configuration. + * @strings: Tables of strings, keyed by identifiers assigned during @bind() + * and by language IDs provided in control requests. + * @descriptors: Table of descriptors preceding all function descriptors. + * Examples include OTG and vendor-specific descriptors. + * @bind: Called from @usb_add_config() to allocate resources unique to this + * configuration and to call @usb_add_function() for each function used. + * @unbind: Reverses @bind; called as a side effect of unregistering the + * driver which added this configuration. + * @setup: Used to delegate control requests that aren't handled by standard + * device infrastructure or directed at a specific interface. + * @bConfigurationValue: Copied into configuration descriptor. + * @iConfiguration: Copied into configuration descriptor. + * @bmAttributes: Copied into configuration descriptor. + * @bMaxPower: Copied into configuration descriptor. + * @cdev: assigned by @usb_add_config() before calling @bind(); this is + * the device associated with this configuration. + * + * Configurations are building blocks for gadget drivers structured around + * function drivers. Simple USB gadgets require only one function and one + * configuration, and handle dual-speed hardware by always providing the same + * functionality. Slightly more complex gadgets may have more than one + * single-function configuration at a given speed; or have configurations + * that only work at one speed. + * + * Composite devices are, by definition, ones with configurations which + * include more than one function. + * + * The lifecycle of a usb_configuration includes allocation, initialization + * of the fields described above, and calling @usb_add_config() to set up + * internal data and bind it to a specific device. The configuration's + * @bind() method is then used to initialize all the functions and then + * call @usb_add_function() for them. + * + * Those functions would normally be independant of each other, but that's + * not mandatory. CDC WMC devices are an example where functions often + * depend on other functions, with some functions subsidiary to others. + * Such interdependency may be managed in any way, so long as all of the + * descriptors complete by the time the composite driver returns from + * its bind() routine. + */ +struct usb_configuration { + const char *label; + struct usb_gadget_strings **strings; + const struct usb_descriptor_header **descriptors; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching... + */ + + /* configuration management: bind/unbind */ + int (*bind)(struct usb_configuration *); + void (*unbind)(struct usb_configuration *); + int (*setup)(struct usb_configuration *, + const struct usb_ctrlrequest *); + + /* fields in the config descriptor */ + u8 bConfigurationValue; + u8 iConfiguration; + u8 bmAttributes; + u8 bMaxPower; + + struct usb_composite_dev *cdev; + + /* private: */ + /* internals */ + struct list_head list; + struct list_head functions; + u8 next_interface_id; + unsigned highspeed:1; + unsigned fullspeed:1; + struct usb_function *interface[MAX_CONFIG_INTERFACES]; +}; + +int usb_add_config(struct usb_composite_dev *, + struct usb_configuration *); + +/** + * struct usb_composite_driver - groups configurations into a gadget + * @name: For diagnostics, identifies the driver. + * @dev: Template descriptor for the device, including default device + * identifiers. + * @strings: tables of strings, keyed by identifiers assigned during bind() + * and language IDs provided in control requests + * @bind: (REQUIRED) Used to allocate resources that are shared across the + * whole device, such as string IDs, and add its configurations using + * @usb_add_config(). This may fail by returning a negative errno + * value; it should return zero on successful initialization. + * @unbind: Reverses @bind(); called as a side effect of unregistering + * this driver. + * @disconnect: optional driver disconnect method + * @suspend: Notifies when the host stops sending USB traffic, + * after function notifications + * @resume: Notifies configuration when the host restarts USB traffic, + * before function notifications + * + * Devices default to reporting self powered operation. Devices which rely + * on bus powered operation should report this in their @bind() method. + * + * Before returning from @bind, various fields in the template descriptor + * may be overridden. These include the idVendor/idProduct/bcdDevice values + * normally to bind the appropriate host side driver, and the three strings + * (iManufacturer, iProduct, iSerialNumber) normally used to provide user + * meaningful device identifiers. (The strings will not be defined unless + * they are defined in @dev and @strings.) The correct ep0 maxpacket size + * is also reported, as defined by the underlying controller driver. + */ +struct usb_composite_driver { + const char *name; + const struct usb_device_descriptor *dev; + struct usb_gadget_strings **strings; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching... + */ + + int (*bind)(struct usb_composite_dev *); + int (*unbind)(struct usb_composite_dev *); + + void (*disconnect)(struct usb_composite_dev *); + + /* global suspend hooks */ + void (*suspend)(struct usb_composite_dev *); + void (*resume)(struct usb_composite_dev *); +}; + +extern int usb_composite_register(struct usb_composite_driver *); +extern void usb_composite_unregister(struct usb_composite_driver *); + + +/** + * struct usb_composite_device - represents one composite usb gadget + * @gadget: read-only, abstracts the gadget's usb peripheral controller + * @req: used for control responses; buffer is pre-allocated + * @bufsiz: size of buffer pre-allocated in @req + * @config: the currently active configuration + * + * One of these devices is allocated and initialized before the + * associated device driver's bind() is called. + * + * OPEN ISSUE: it appears that some WUSB devices will need to be + * built by combining a normal (wired) gadget with a wireless one. + * This revision of the gadget framework should probably try to make + * sure doing that won't hurt too much. + * + * One notion for how to handle Wireless USB devices involves: + * (a) a second gadget here, discovery mechanism TBD, but likely + * needing separate "register/unregister WUSB gadget" calls; + * (b) updates to usb_gadget to include flags "is it wireless", + * "is it wired", plus (presumably in a wrapper structure) + * bandgroup and PHY info; + * (c) presumably a wireless_ep wrapping a usb_ep, and reporting + * wireless-specific parameters like maxburst and maxsequence; + * (d) configurations that are specific to wireless links; + * (e) function drivers that understand wireless configs and will + * support wireless for (additional) function instances; + * (f) a function to support association setup (like CBAF), not + * necessarily requiring a wireless adapter; + * (g) composite device setup that can create one or more wireless + * configs, including appropriate association setup support; + * (h) more, TBD. + */ +struct usb_composite_dev { + struct usb_gadget *gadget; + struct usb_request *req; + unsigned bufsiz; + + struct usb_configuration *config; + + /* private: */ + /* internals */ + unsigned int suspended:1; + struct usb_device_descriptor desc; + struct list_head configs; + struct usb_composite_driver *driver; + u8 next_string_id; + + /* the gadget driver won't enable the data pullup + * while the deactivation count is nonzero. + */ + unsigned deactivations; + + /* protects at least deactivation count */ + spinlock_t lock; +}; + +extern int usb_string_id(struct usb_composite_dev *c); +extern int usb_string_ids_tab(struct usb_composite_dev *c, + struct usb_string *str); +extern int usb_string_ids_n(struct usb_composite_dev *c, unsigned n); + + +/* messaging utils */ +#define DBG(d, fmt, args...) \ + dev_dbg(&(d)->gadget->dev , fmt , ## args) +#define VDBG(d, fmt, args...) \ + dev_vdbg(&(d)->gadget->dev , fmt , ## args) +#define ERROR(d, fmt, args...) \ + dev_err(&(d)->gadget->dev , fmt , ## args) +#define WARNING(d, fmt, args...) \ + dev_warn(&(d)->gadget->dev , fmt , ## args) +#define INFO(d, fmt, args...) \ + dev_info(&(d)->gadget->dev , fmt , ## args) + +#endif /* __LINUX_USB_COMPOSITE_H */
Dear Lukasz Majewski,
- composite.c - infrastructure for Composite USB Gadgets
- Copyright (C) 2006-2008 David Brownell
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307
USA + */
- The code in this file is utility code, used to build a gadget driver
- from one or more "function" drivers, one or more "configuration"
- objects, and a "usb_composite_driver" by gluing them together along
- with the relevant device-wide data.
- published in the device descriptor, either numbers or strings or both.
- String parameters are in UTF-8 (superset of ASCII's 7 bit characters).
Does all this even compile? Do we need it?
- usb_add_function() - add a function to a configuration
- @config: the configuration
- @function: the function being added
- Context: single threaded during gadget setup
- After initialization, each configuration must have one or more
- functions added to it. Adding a function involves calling its @bind()
- method to allocate resources such as interface and string identifiers
- and endpoints.
- This function returns the value of the function's bind(), which is
- zero for success else a negative errno value.
- int value = -EINVAL;
- DBG(config->cdev, "adding '%s'/%p to config '%s'/%p\n",
- if (!function->set_alt || !function->disable)
goto done;
- function->config = config;
- list_add_tail(&function->list, &config->functions);
- /* REVISIT *require* function->bind? */
Revisit :)
- if (function->bind) {
if (value < 0) {
- } else
value = 0;
- /* We allow configurations that don't work at both speeds.
- if (!config->fullspeed && function->descriptors)
- if (!config->highspeed && function->hs_descriptors)
+done:
- if (value)
Replace DBG with debug() ?
- return value;
- usb_function_deactivate - prevent function and gadget enumeration
- @function: the function that isn't yet ready to respond
- Blocks response of the gadget driver to host enumeration by
- preventing the data line pullup from being activated. This is
- normally called during @bind() processing to change from the
- initial "ready to respond" state, or when a required resource
- becomes available.
- For example, drivers that serve as a passthrough to a userspace
- daemon can block enumeration unless that daemon (such as an OBEX,
- MTP, or print server) is ready to handle host requests.
- Not all systems support software control of their USB peripheral
- data pullups.
- Returns zero on success, else negative errno.
- struct usb_composite_dev *cdev = function->config->cdev;
- unsigned long flags;
- int status = 0;
- spin_lock_irqsave(&cdev->lock, flags);
- if (cdev->deactivations == 0)
- if (status == 0)
- spin_unlock_irqrestore(&cdev->lock, flags);
So you implement spinlocks?
Actually, can you please strip this to bare minimum ?
Thanks!
- return status;
- usb_function_activate - allow function and gadget enumeration
- @function: function on which usb_function_activate() was called
- Reverses effect of usb_function_deactivate(). If no more functions
- are delaying their activation, the gadget driver will respond to
- host enumeration procedures.
- int status = 0;
- spin_lock(&cdev->lock);
- if (WARN_ON(cdev->deactivations == 0))
status = -EINVAL;
- else {
- spin_unlock(&cdev->lock);
- return status;
- usb_interface_id() - allocate an unused interface ID
- @config: configuration associated with the interface
- @function: function handling the interface
- usb_interface_id() is called from usb_function.bind() callbacks to
- allocate new interface IDs. The function driver will then store that
- ID in interface, association, CDC union, and other descriptors. It
- will also handle any control requests targetted at that interface,
- particularly changing its altsetting via set_alt(). There may
- also be class-specific or vendor-specific requests to handle.
- All interface identifier should be allocated using this routine, to
- ensure that for example different functions don't wrongly assign
- different meanings to the same identifier. Note that since interface
- identifers are configuration-specific, functions used in more than
- one configuration (or more than once in a given configuration) need
- multiple versions of the relevant descriptors.
- Returns the interface ID which was allocated; or -ENODEV if no
- more interface IDs can be allocated.
- unsigned id = config->next_interface_id;
- if (id < MAX_CONFIG_INTERFACES) {
return id;
- return -ENODEV;
- struct usb_config_descriptor *c = buf;
- void *next = buf + USB_DT_CONFIG_SIZE;
- int len = USB_BUFSIZ - USB_DT_CONFIG_SIZE;
- struct usb_function *f;
- int status;
- /* write the config descriptor */
- c = buf;
- c->bLength = USB_DT_CONFIG_SIZE;
- c->bDescriptorType = type;
- /* wTotalLength is written later */
- c->bNumInterfaces = config->next_interface_id;
- c->bConfigurationValue = config->bConfigurationValue;
- c->iConfiguration = config->iConfiguration;
- c->bmAttributes = USB_CONFIG_ATT_ONE | config->bmAttributes;
- c->bMaxPower = config->bMaxPower ? : (CONFIG_USB_GADGET_VBUS_DRAW / 2);
- /* There may be e.g. OTG descriptors */
- if (config->descriptors) {
if (status < 0)
return status;
len -= status;
next += status;
- /* add each function's descriptors */
- list_for_each_entry(f, &config->functions, list) {
else
if (!descriptors)
continue;
if (status < 0)
return status;
len -= status;
next += status;
- len = next - buf;
- c->wTotalLength = cpu_to_le16(len);
- return len;
- struct usb_gadget *gadget = cdev->gadget;
- struct usb_configuration *c;
- u8 type = w_value >> 8;
- enum usb_device_speed speed = USB_SPEED_UNKNOWN;
- if (gadget_is_dualspeed(gadget)) {
int hs = 0;
hs = 1;
hs = !hs;
if (hs)
- /* This is a lookup by config *INDEX* */
- w_value &= 0xff;
- list_for_each_entry(c, &cdev->configs, list) {
if (!c->highspeed)
continue;
} else {
if (!c->fullspeed)
continue;
if (w_value == 0)
w_value--;
- return -EINVAL;
- unsigned count = 0;
- int hs = 0;
hs = 1;
hs = !hs;
if (hs) {
if (!c->highspeed)
continue;
} else {
if (!c->fullspeed)
continue;
count++;
- return count;
- struct usb_qualifier_descriptor *qual = cdev->req->buf;
- qual->bLength = sizeof(*qual);
- qual->bDescriptorType = USB_DT_DEVICE_QUALIFIER;
- /* POLICY: same bcdUSB and device type info at both speeds */
- qual->bcdUSB = cdev->desc.bcdUSB;
- qual->bDeviceClass = cdev->desc.bDeviceClass;
- qual->bDeviceSubClass = cdev->desc.bDeviceSubClass;
- qual->bDeviceProtocol = cdev->desc.bDeviceProtocol;
- /* ASSUME same EP0 fifo size at both speeds */
- qual->bMaxPacketSize0 = cdev->desc.bMaxPacketSize0;
- qual->bNumConfigurations = count_configs(cdev, USB_DT_DEVICE_QUALIFIER);
- qual->bRESERVED = 0;
+/*------------------------------------------------------------------------ -*/ + +static void reset_config(struct usb_composite_dev *cdev) +{
- DBG(cdev, "reset config\n");
- list_for_each_entry(f, &cdev->config->functions, list) {
if (f->disable)
f->disable(f);
- cdev->config = NULL;
- struct usb_configuration *c = NULL;
- int result = -EINVAL;
- unsigned power = gadget_is_otg(gadget) ? 8 : 100;
- int tmp;
- if (cdev->config)
reset_config(cdev);
- if (number) {
result = 0;
break;
if (result < 0)
goto done;
- } else
result = 0;
- INFO(cdev, "%s speed config #%d: %s\n",
({ char *speed;
- if (!c)
goto done;
- cdev->config = c;
- /* Initialize all interfaces by setting them to altsetting zero. */
- for (tmp = 0; tmp < MAX_CONFIG_INTERFACES; tmp++) {
if (!f)
break;
else
int addr;
continue;
if (result < 0) {
reset_config(cdev);
goto done;
- /* when we return, be sure our power usage is valid */
- power = c->bMaxPower ? (2 * c->bMaxPower) : CONFIG_USB_GADGET_VBUS_DRAW;
+done:
- usb_gadget_vbus_draw(gadget, power);
- return result;
- usb_add_config() - add a configuration to a device.
- @cdev: wraps the USB gadget
- @config: the configuration, with bConfigurationValue assigned
- One of the main tasks of a composite driver's bind() routine is to
- add each of the configurations it supports, using this routine.
- This function returns the value of the configuration's bind(), which
- is zero for success else a negative errno value. Binding
- int status = -EINVAL;
- DBG(cdev, "adding config #%u '%s'/%p\n",
- if (!config->bConfigurationValue || !config->bind)
goto done;
- /* Prevent duplicate configuration identifiers */
status = -EBUSY;
goto done;
- config->cdev = cdev;
- list_add_tail(&config->list, &cdev->configs);
- INIT_LIST_HEAD(&config->functions);
- config->next_interface_id = 0;
- status = config->bind(config);
- if (status < 0) {
- } else {
unsigned i;
config->fullspeed
? " full"
: " full/low")
if (!f)
continue;
i, f->name, f);
- /* set_alt(), or next config->bind(), sets up
- usb_ep_autoconfig_reset(cdev->gadget);
+done:
- if (status)
- return status;
+/*------------------------------------------------------------------------ -*/ + +/* We support strings in multiple languages ... string descriptor zero
- says which languages are supported. The typical case will be that
- only one language (probably English) is used, with I18N handled on
- the host side.
- const struct usb_gadget_strings *s;
- u16 language;
- __le16 *tmp;
- while (*sp) {
s = *sp;
goto repeat;
*tmp++ = language;
+repeat:
sp++;
- struct usb_gadget_strings **sp,
- void *buf,
- u16 language,
- int id
- struct usb_gadget_strings *s;
- int value;
- while (*sp) {
s = *sp++;
continue;
if (value > 0)
return value;
- return -EINVAL;
- int len;
- /* Yes, not only is USB's I18N support probably more than most
- /* 0 == report all available language codes */
- if (id == 0) {
memset(s, 0, 256);
if (sp)
sp = c->strings;
if (sp)
sp = f->strings;
if (sp)
continue;
if (!len)
return -EINVAL;
return s->bLength;
- /* Otherwise, look up and return a specified string. String IDs
- if (composite->strings) {
if (len > 0)
return len;
if (c->strings) {
if (len > 0)
return len;
if (!f->strings)
continue;
if (len > 0)
return len;
- return -EINVAL;
- usb_string_id() - allocate an unused string ID
- @cdev: the device whose string descriptor IDs are being allocated
- @usb_string_id() is called from bind() callbacks to allocate
- string IDs. Drivers for functions, configurations, or gadgets will
- then store that ID in the appropriate descriptors and string table.
- All string identifier should be allocated using this,
- @usb_string_ids_tab() or @usb_string_ids_n() routine, to ensure
- that for example different functions don't wrongly assign different
- meanings to the same identifier.
- if (cdev->next_string_id < 254) {
- return -ENODEV;
- usb_string_ids() - allocate unused string IDs in batch
- @str: an array of usb_string objects to assign numbers to
- @usb_string_ids() is called from bind() callbacks to allocate
- then copy IDs from the string table to the appropriate descriptors
- and string table for other languages.
- @usb_string_id() or @usb_string_ids_n() routine, to ensure that for
- example different functions don't wrongly assign different meanings
- to the same identifier.
- int next = cdev->next_string_id;
- for (; str->s; ++str) {
return -ENODEV;
str->id = ++next;
- cdev->next_string_id = next;
- usb_string_ids_n() - allocate unused string IDs in batch
- @c: the device whose string descriptor IDs are being allocated
- @n: number of string IDs to allocate
- Returns the first requested ID. This ID and next @n-1 IDs are now
- valid IDs. At least provided that @n is non-zero because if it
- is, returns last requested ID which is now very useful information.
- @usb_string_ids_n() is called from bind() callbacks to allocate
- unsigned next = c->next_string_id;
- if (unlikely(n > 254 || (unsigned)next + n > 254))
return -ENODEV;
- c->next_string_id += n;
- return next + 1;
+/*------------------------------------------------------------------------ -*/ + +static void composite_setup_complete(struct usb_ep *ep, struct usb_request *req) +{
- if (req->status || req->actual != req->length)
- The setup() callback implements all the ep0 functionality that's
- not handled lower down, in hardware or the hardware driver(like
- device and endpoint feature flags, and their status). It's all
- housekeeping for the gadget function we're implementing. Most of
- the work is in config and function specific setup.
- struct usb_composite_dev *cdev = get_gadget_data(gadget);
- struct usb_request *req = cdev->req;
- int value = -EOPNOTSUPP;
- u16 w_index = le16_to_cpu(ctrl->wIndex);
- u8 intf = w_index & 0xFF;
- u16 w_value = le16_to_cpu(ctrl->wValue);
- u16 w_length = le16_to_cpu(ctrl->wLength);
- struct usb_function *f = NULL;
- u8 endp;
- /* partial re-init of the response message; the function or the
- req->zero = 0;
- req->complete = composite_setup_complete;
- req->length = USB_BUFSIZ;
- gadget->ep0->driver_data = cdev;
- switch (ctrl->bRequest) {
- /* we handle all standard USB descriptors */
- case USB_REQ_GET_DESCRIPTOR:
goto unknown;
case USB_DT_DEVICE:
break;
break;
device_qual(cdev);
break;
break;
/* FALLTHROUGH */
case USB_DT_CONFIG:
if (value >= 0)
break;
case USB_DT_STRING:
if (value >= 0)
break;
break;
- /* any number of configs can work */
- case USB_REQ_SET_CONFIGURATION:
goto unknown;
else
break;
- case USB_REQ_GET_CONFIGURATION:
goto unknown;
if (cdev->config)
else
break;
- /* function drivers must handle get/set altsetting; if there's
- case USB_REQ_SET_INTERFACE:
goto unknown;
break;
if (!f)
break;
break;
break;
- case USB_REQ_GET_INTERFACE:
goto unknown;
break;
if (!f)
break;
if (value < 0)
break;
break;
- default:
+unknown:
VDBG(cdev,
* in config 0, etc.
break;
break;
f = NULL;
break;
if (f && f->setup)
else {
c = cdev->config;
if (c && c->setup)
goto done;
- /* respond with data transfer before status phase? */
- if (value >= 0) {
if (value < 0) {
req->status = 0;
+done:
- /* device either stalls (value < 0) or reports success */
- return value;
- /* REVISIT: should we have config and device level
- if (cdev->config)
reset_config(cdev);
- if (composite->disconnect)
+/*------------------------------------------------------------------------ -*/ + +static ssize_t composite_show_suspended(struct device *dev,
char *buf)
- struct usb_gadget *gadget = dev_to_usb_gadget(dev);
- return sprintf(buf, "%d\n", cdev->suspended);
- /* composite_disconnect() must already have been called
- WARN_ON(cdev->config);
- while (!list_empty(&cdev->configs)) {
list_del(&f->list);
if (f->unbind) {
f->name, f);
f->unbind(c, f);
list_del(&c->list);
if (c->unbind) {
c->unbind(c);
- if (composite->unbind)
- if (cdev->req) {
- kfree(cdev);
- set_gadget_data(gadget, NULL);
- device_remove_file(&gadget->dev, &dev_attr_suspended);
- composite = NULL;
- struct usb_string *str = tab->strings;
- for (str = tab->strings; str->s; str++) {
str->s = s;
return;
- while (*tab) {
tab++;
- struct usb_composite_dev *cdev;
- int status = -ENOMEM;
- cdev = kzalloc(sizeof *cdev, GFP_KERNEL);
- if (!cdev)
return status;
- spin_lock_init(&cdev->lock);
- cdev->gadget = gadget;
- set_gadget_data(gadget, cdev);
- INIT_LIST_HEAD(&cdev->configs);
- /* preallocate control response and buffer */
- cdev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL);
- if (!cdev->req)
goto fail;
- cdev->req->buf = kmalloc(USB_BUFSIZ, GFP_KERNEL);
- if (!cdev->req->buf)
goto fail;
- cdev->req->complete = composite_setup_complete;
- cdev->bufsiz = USB_BUFSIZ;
- cdev->driver = composite;
- usb_gadget_set_selfpowered(gadget);
- /* interface and string IDs start at zero via kzalloc.
- /* standardized runtime overrides for device ID data */
- if (idVendor)
- if (idProduct)
- if (bcdDevice)
- /* composite gadget needs to assign strings for whole device (like
- status = composite->bind(cdev);
- if (status < 0)
goto fail;
- cdev->desc = *composite->dev;
- cdev->desc.bMaxPacketSize0 = gadget->ep0->maxpacket;
- /* strings can't be assigned before bind() allocates the
- if (cdev->desc.iManufacturer && iManufacturer)
- if (cdev->desc.iProduct && iProduct)
- if (cdev->desc.iSerialNumber && iSerialNumber)
- status = device_create_file(&gadget->dev, &dev_attr_suspended);
- if (status)
goto fail;
- INFO(cdev, "%s ready\n", composite->name);
+fail:
- composite_unbind(gadget);
- return status;
+/*------------------------------------------------------------------------ -*/ + +static void +composite_suspend(struct usb_gadget *gadget) +{
- /* REVISIT: should we have config level
- DBG(cdev, "suspend\n");
- if (cdev->config) {
if (f->suspend)
f->suspend(f);
- if (composite->suspend)
- cdev->suspended = 1;
- DBG(cdev, "resume\n");
- if (composite->resume)
if (f->resume)
f->resume(f);
- cdev->suspended = 0;
+/*------------------------------------------------------------------------ -*/ + +static struct usb_gadget_driver composite_driver = {
- .speed = USB_SPEED_HIGH,
- .bind = composite_bind,
- .unbind = composite_unbind,
- .setup = composite_setup,
- .disconnect = composite_disconnect,
- .suspend = composite_suspend,
- .resume = composite_resume,
- .driver = {
- usb_composite_register() - register a composite driver
- @driver: the driver to register
- This function is used to register drivers using the composite driver
- framework. The return value is zero, or a negative errno value.
- Those values normally come from the driver's @bind method, which does
- all the work of setting up the driver to match the hardware.
- On successful return, the gadget is ready to respond to requests from
- the host, unless one of its components invokes usb_gadget_disconnect()
- while it was binding. That would usually be done in order to wait for
- some userspace participation.
- if (!driver || !driver->dev || !driver->bind || composite)
return -EINVAL;
- if (!driver->name)
- composite_driver.function = (char *) driver->name;
- composite_driver.driver.name = driver->name;
- composite = driver;
- return usb_gadget_register_driver(&composite_driver);
- usb_composite_unregister() - unregister a composite driver
- @driver: the driver to unregister
- This function is used to unregister drivers using the composite
- driver framework.
- if (composite != driver)
return;
- usb_gadget_unregister_driver(&composite_driver);
- composite.h -- framework for usb gadgets which are composite devices
- Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301
USA + */
- This framework is an optional layer on top of the USB Gadget interface,
- making it easier to build (a) Composite devices, supporting multiple
- functions within any single configuration, and (b) Multi-configuration
- devices, also supporting multiple functions but without necessarily
- having more than one function per configuration.
- Example: a device with a single configuration supporting both network
- link and mass storage functions is a composite device. Those functions
- might alternatively be packaged in individual configurations, but in
- the composite model the host can use both functions at the same time.
- struct usb_function - describes one function of a configuration
- @name: For diagnostics, identifies the function.
- @strings: tables of strings, keyed by identifiers assigned during
- @descriptors: Table of full (or low) speed descriptors, using interface
- @config: assigned when @usb_add_function() is called; this is the
- configuration with which this function is associated.
- @bind: Before the gadget can register, all of its functions bind() to
so
- @set_alt: (REQUIRED) Reconfigures altsettings; function drivers may
- initialize usb_ep.driver data at this time (when it is used).
- Note that setting an interface to its current altsetting resets
- interface state, and that all interfaces have a disabled state.
- @get_alt: Returns the active altsetting. If this is not provided,
- then only altsetting zero is supported.
- @disable: (REQUIRED) Indicates the function should be disabled.
- @suspend: Notifies functions when the host stops sending USB traffic.
- @resume: Notifies functions when the host restarts USB traffic.
- A single USB function uses one or more interfaces, and should in most
- cases support operation at both full and high speeds. Each function is
- associated by @usb_add_function() with a one configuration; that
- To support dual speed operation, a function driver provides descriptors
- for both high and full speed operation. Except in rare cases that
- Function drivers choose their own strategies for managing instance
- A more complex strategy might encapsulate a @usb_function structure
- const char *name;
- struct usb_gadget_strings **strings;
- struct usb_descriptor_header **descriptors;
- struct usb_descriptor_header **hs_descriptors;
- struct usb_configuration *config;
- /* REVISIT: bind() functions can be marked __init, which
- /* configuration management: bind/unbind */
- int (*bind)(struct usb_configuration *,
- void (*unbind)(struct usb_configuration *,
- /* runtime state management */
- int (*set_alt)(struct usb_function *,
- int (*get_alt)(struct usb_function *,
- void (*disable)(struct usb_function *);
- int (*setup)(struct usb_function *,
- void (*suspend)(struct usb_function *);
- void (*resume)(struct usb_function *);
- /* private: */
- /* internals */
- struct list_head list;
- DECLARE_BITMAP(endpoints, 32);
- ep_choose - select descriptor endpoint at current device speed
- @g: gadget, connected and running at some speed
- @hs: descriptor to use for high speed operation
- @fs: descriptor to use for full or low speed operation
- if (gadget_is_dualspeed(g) && g->speed == USB_SPEED_HIGH)
return hs;
- return fs;
- struct usb_configuration - represents one gadget configuration
- @label: For diagnostics, describes the configuration.
- @strings: Tables of strings, keyed by identifiers assigned during
- @descriptors: Table of descriptors preceding all function descriptors.
- Examples include OTG and vendor-specific descriptors.
- @bind: Called from @usb_add_config() to allocate resources unique to
- @setup: Used to delegate control requests that aren't handled by
- @bConfigurationValue: Copied into configuration descriptor.
- @iConfiguration: Copied into configuration descriptor.
- @bmAttributes: Copied into configuration descriptor.
- @bMaxPower: Copied into configuration descriptor.
- @cdev: assigned by @usb_add_config() before calling @bind(); this is
- the device associated with this configuration.
- Configurations are building blocks for gadget drivers structured around
- function drivers. Simple USB gadgets require only one function and one
- configuration, and handle dual-speed hardware by always providing the
- Composite devices are, by definition, ones with configurations which
- include more than one function.
- The lifecycle of a usb_configuration includes allocation,
- Those functions would normally be independant of each other, but that's
- not mandatory. CDC WMC devices are an example where functions often
- depend on other functions, with some functions subsidiary to others.
- Such interdependency may be managed in any way, so long as all of the
- descriptors complete by the time the composite driver returns from
- its bind() routine.
- const char *label;
- const struct usb_descriptor_header **descriptors;
- int (*bind)(struct usb_configuration *);
- void (*unbind)(struct usb_configuration *);
- int (*setup)(struct usb_configuration *,
- /* fields in the config descriptor */
- u8 bConfigurationValue;
- u8 iConfiguration;
- u8 bmAttributes;
- u8 bMaxPower;
- /* private: */
- /* internals */
- struct list_head functions;
- u8 next_interface_id;
- unsigned highspeed:1;
- unsigned fullspeed:1;
- struct usb_function *interface[MAX_CONFIG_INTERFACES];
- struct usb_composite_driver - groups configurations into a gadget
- @name: For diagnostics, identifies the driver.
- @dev: Template descriptor for the device, including default device
- identifiers.
- @bind: (REQUIRED) Used to allocate resources that are shared across the
- whole device, such as string IDs, and add its configurations using
- @usb_add_config(). This may fail by returning a negative errno
- value; it should return zero on successful initialization.
- @unbind: Reverses @bind(); called as a side effect of unregistering
- this driver.
- @disconnect: optional driver disconnect method
- @suspend: Notifies when the host stops sending USB traffic,
- after function notifications
- @resume: Notifies configuration when the host restarts USB traffic,
- before function notifications
- Devices default to reporting self powered operation. Devices which
- Before returning from @bind, various fields in the template descriptor
- may be overridden. These include the idVendor/idProduct/bcdDevice
- const char *name;
- const struct usb_device_descriptor *dev;
- int (*bind)(struct usb_composite_dev *);
- int (*unbind)(struct usb_composite_dev *);
- void (*disconnect)(struct usb_composite_dev *);
- /* global suspend hooks */
- void (*suspend)(struct usb_composite_dev *);
- void (*resume)(struct usb_composite_dev *);
- struct usb_composite_device - represents one composite usb gadget
- @gadget: read-only, abstracts the gadget's usb peripheral controller
- @req: used for control responses; buffer is pre-allocated
- @bufsiz: size of buffer pre-allocated in @req
- @config: the currently active configuration
- One of these devices is allocated and initialized before the
- associated device driver's bind() is called.
- OPEN ISSUE: it appears that some WUSB devices will need to be
- built by combining a normal (wired) gadget with a wireless one.
- This revision of the gadget framework should probably try to make
- sure doing that won't hurt too much.
- One notion for how to handle Wireless USB devices involves:
- (a) a second gadget here, discovery mechanism TBD, but likely
- (b) updates to usb_gadget to include flags "is it wireless",
- (c) presumably a wireless_ep wrapping a usb_ep, and reporting
- (d) configurations that are specific to wireless links;
- (e) function drivers that understand wireless configs and will
- (f) a function to support association setup (like CBAF), not
- (g) composite device setup that can create one or more wireless
- (h) more, TBD.
- struct usb_gadget *gadget;
- struct usb_request *req;
- unsigned bufsiz;
- /* private: */
- /* internals */
- unsigned int suspended:1;
- struct usb_device_descriptor desc;
- struct list_head configs;
- struct usb_composite_driver *driver;
- u8 next_string_id;
- /* the gadget driver won't enable the data pullup
- unsigned deactivations;
- /* protects at least deactivation count */
- spinlock_t lock;
- dev_dbg(&(d)->gadget->dev , fmt , ## args)
- dev_vdbg(&(d)->gadget->dev , fmt , ## args)
- dev_err(&(d)->gadget->dev , fmt , ## args)
- dev_warn(&(d)->gadget->dev , fmt , ## args)
- dev_info(&(d)->gadget->dev , fmt , ## args)
In message 1334214931-19480-2-git-send-email-l.majewski@samsung.com you wrote:
Two files from Linux kernel source tree have been ported to u-boot (Linux Kernel v2.6.36):
./include/linux/usb/composite.h ./drivers/usb/gadget/composite.c
Please fix checkpatch errors.
BTW - would it not make sense to use more recent code as reference?
Hi Wolfgang,
Recent composite driver lacks the bind method at struct usb_gadget_driver. U-boot's gadgets however use this bind (e.g. ether.c). Also ./include/linux/usb/gadget.h defines bind in this struct.
I've choose this version for this backward compatibility reason.
This makes little sense to me. Instead, the U-Boto gadget driver shouldbe adapted as well.
This commit fixes Linux kernel's composite.{h/c} code to work with u-boot.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Andrzej Pietrasiewicz andrzej.p@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/usb/gadget/composite.c | 58 ++++++++++++++++++++++++++-------------- include/linux/usb/composite.h | 52 +++++++++++++++++++++++++++++++++++ 2 files changed, 90 insertions(+), 20 deletions(-)
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c index 1160c55..6a20278 100644 --- a/drivers/usb/gadget/composite.c +++ b/drivers/usb/gadget/composite.c @@ -18,13 +18,14 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA */
-/* #define VERBOSE_DEBUG */ +#define VERBOSE_DEBUG
-#include <linux/kallsyms.h> -#include <linux/kernel.h> -#include <linux/slab.h> -#include <linux/device.h> +/* #include <linux/kallsyms.h> */ +/* #include <linux/kernel.h> */ +/* #include <linux/slab.h> */ +/* #include <linux/device.h> */
+#include <linux/bitops.h> #include <linux/usb/composite.h>
@@ -36,7 +37,7 @@ */
/* big enough to hold our biggest descriptor */ -#define USB_BUFSIZ 1024 +#define USB_BUFSIZ 4096
static struct usb_composite_driver *composite;
@@ -404,13 +405,23 @@ static int set_config(struct usb_composite_dev *cdev, result = 0;
INFO(cdev, "%s speed config #%d: %s\n", - ({ char *speed; - switch (gadget->speed) { - case USB_SPEED_LOW: speed = "low"; break; - case USB_SPEED_FULL: speed = "full"; break; - case USB_SPEED_HIGH: speed = "high"; break; - default: speed = "?"; break; - } ; speed; }), number, c ? c->label : "unconfigured"); + ({ char *speed; + switch (gadget->speed) { + case USB_SPEED_LOW: + speed = "low"; + break; + case USB_SPEED_FULL: + speed = "full"; + break; + case USB_SPEED_HIGH: + speed = "high"; + break; + default: + speed = "?"; + break; + }; + speed; + }), number, c ? c->label : "unconfigured");
if (!c) goto done; @@ -779,6 +790,7 @@ composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) u16 w_length = le16_to_cpu(ctrl->wLength); struct usb_function *f = NULL; u8 endp; + bool standard;
/* partial re-init of the response message; the function or the * gadget might need to intercept e.g. a control-OUT completion @@ -788,6 +800,10 @@ composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) req->complete = composite_setup_complete; req->length = USB_BUFSIZ; gadget->ep0->driver_data = cdev; + standard = (ctrl->bRequestType & USB_TYPE_MASK) + == USB_TYPE_STANDARD; + if (!standard) + goto unknown;
@@ -825,6 +841,8 @@ composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) if (value >= 0) value = min(w_length, (u16) value); break; + default: + goto unknown; } break;
@@ -963,7 +981,7 @@ static void composite_disconnect(struct usb_gadget *gadget)
-static ssize_t composite_show_suspended(struct device *dev, +/* static ssize_t composite_show_suspended(struct device *dev, struct device_attribute *attr, char *buf) { @@ -973,7 +991,7 @@ static ssize_t composite_show_suspended(struct device *dev, return sprintf(buf, "%d\n", cdev->suspended); }
-static DEVICE_ATTR(suspended, 0444, composite_show_suspended, NULL); +static DEVICE_ATTR(suspended, 0444, composite_show_suspended, NULL); */
static void composite_unbind(struct usb_gadget *gadget) @@ -985,7 +1003,7 @@ composite_unbind(struct usb_gadget *gadget) * so there's no i/o concurrency that could affect the * state protected by cdev->lock. */ - WARN_ON(cdev->config); + BUG_ON(cdev->config);
while (!list_empty(&cdev->configs)) { struct usb_configuration *c; @@ -1186,9 +1204,9 @@ static struct usb_gadget_driver composite_driver = { .suspend = composite_suspend, .resume = composite_resume,
- .driver = { + /* .driver = { .owner = THIS_MODULE, - }, + }, */ };
/** @@ -1213,8 +1231,8 @@ int usb_composite_register(struct usb_composite_driver *driver)
if (!driver->name) driver->name = "composite"; - composite_driver.function = (char *) driver->name; - composite_driver.driver.name = driver->name; + /* composite_driver.function = (char *) driver->name; */ + /* composite_driver.driver.name = driver->name; */ composite = driver;
return usb_gadget_register_driver(&composite_driver); diff --git a/include/linux/usb/composite.h b/include/linux/usb/composite.h index 6170681..0c50a26 100644 --- a/include/linux/usb/composite.h +++ b/include/linux/usb/composite.h @@ -22,6 +22,58 @@ #define __LINUX_USB_COMPOSITE_H
/* + * Linux kernel compatibility layer + */ +#define true 1 +#define false 0 +#define GFP_ATOMIC ((gfp_t) 0) +#define GFP_KERNEL ((gfp_t) 0) +#define BITS_PER_BYTE 8 +#define BITS_TO_LONGS(nr) \ + DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) +#define DECLARE_BITMAP(name, bits) \ + unsigned long name[BITS_TO_LONGS(bits)] +#define min_t(type, x, y) \ + ({ type __x = (x); type __y = (y); __x < __y ? __x : __y; }) +#define dev_dbg(...) do {} while (0) +#define dev_vdbg(...) do {} while (0) +#define dev_err(...) do {} while (0) +#define dev_warn(...) do {} while (0) +#define dev_info(...) do {} while (0) +#define pr_warning(...) do {} while (0) +#define spin_lock_init(lock) do {} while (0) +#define spin_lock(lock) do {} while (0) +#define spin_unlock(lock) do {} while (0) +#define spin_lock_irqsave(lock, flags) do {flags = 1; } while (0) +#define spin_unlock_irqrestore(lock, flags) do {flags = 0; } while (0) +#define kmalloc(x, y) malloc(x) +#define kfree(x) free(x) +#define kzalloc(size, flags) calloc((size), 1) +#define module_param(...) +#define MODULE_PARM_DESC(...) +#define WARN_ON(x) x +#define device_remove_file(...) +#define device_create_file(...) 0 +#define set_bit __set_bit +typedef int spinlock_t; +typedef int bool; +#define small_const_nbits(nbits) \ + (__builtin_constant_p(nbits) && (nbits) <= BITS_PER_LONG) + +static inline void bitmap_zero(unsigned long *dst, int nbits) +{ + if (small_const_nbits(nbits)) + *dst = 0UL; + else { + int len = BITS_TO_LONGS(nbits) * sizeof(unsigned long); + memset(dst, 0, len); + } +} +/* + * end compatibility layer + */ + +/* * This framework is an optional layer on top of the USB Gadget interface, * making it easier to build (a) Composite devices, supporting multiple * functions within any single configuration, and (b) Multi-configuration
In message 1334214931-19480-3-git-send-email-l.majewski@samsung.com you wrote:
You mean you added non-working code first, and fix it later? This is not bisectable. Please squash.
NAK. Please use standard debug() faclities.
Please remove dead code. Fix globally.
({ char *speed;
Indentation by TAB only.
- Linux kernel compatibility layer
NAK. It makes no sense to add this here, on such a low level.
If this is considered useful or even necessary, it should be added with global scope and visibility.
I rather tend to ask to clean up the code.
Hi Wolfgang,
I'm a bit confused about the policy with porting files:
http://www.denx.de/wiki/U-Boot/Patches
This says clearly: document from where the code comes from. I wanted to show from where the file has been taken.
Those files doesn't compile as is, but no one enabled them in u-boot, so code is still bisectable.
I can squash those commits (the original one and the compatibility layer) + remove unneeded code, but then there will be no link with the original file.
For me it would be even better to provide one commit providing composite driver :-), but I wanted to stick to the policy.
I'll prepare one concise commit then :-)
This is perfectly fine.
You must not expect that Linux kernel code can be used _unchanged_ for U-Boot's purposes. Adding a ton of #defines that make no sense in U-Boot context at all is misleading at best.
Please strip down the driver and remove the parts that do not fit.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Marek Vasut marex@denx.de --- include/linux/usb/gadget.h | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 275cb5f..b0a0e1f 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -481,6 +481,11 @@ static inline void *get_gadget_data(struct usb_gadget *gadget) return gadget->dev.driver_data; }
+static inline struct usb_gadget *dev_to_usb_gadget(struct device *dev) +{ + return container_of(dev, struct usb_gadget, dev); +} + /* iterates the non-control endpoints; 'tmp' is a struct usb_ep pointer */ #define gadget_for_each_ep(tmp, gadget) \ list_for_each_entry(tmp, &(gadget)->ep_list, ep_list)
- return container_of(dev, struct usb_gadget, dev);
Maybe you should put all these patches together and show us only the product -- the stripped down version of this composite driver.
Best regards, Marek Vasut
Add device data pointer to the USB gadget's device struct.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Marek Vasut marex@denx.de --- include/linux/usb/gadget.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index b0a0e1f..eba865e 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -411,6 +411,7 @@ struct usb_gadget_ops {
struct device { void *driver_data; /* data private to the driver */ + void *device_data; /* data private to the device */ };
This patch set provides support for composite gadget framework. Files from Linux kernel (2.6.36) - namely composite.{c|h} have been ported to u-boot.
Code supporting this framework has been added to gadget.h and Samsung's UDC driver as well.
--- Changes for v2: - Squash the kernel files with u-boot compatibility layer. - Removal of dead/kernel specific code. - Comments corrected according to u-boot coding style. - Two separate patches regarding gadget.h file squashed together.
Lukasz Majewski (3): usb:gadget:composite USB composite gadget support usb:gadget:composite: Support for composite at gadget.h usb:udc:samsung Add functions for storing private gadget data in UDC driver
drivers/usb/gadget/composite.c | 1091 ++++++++++++++++++++++++++++++++++++++ drivers/usb/gadget/s3c_udc_otg.c | 12 + include/linux/usb/composite.h | 350 ++++++++++++ include/linux/usb/gadget.h | 6 + include/usb/lin_gadget_compat.h | 25 +- 5 files changed, 1482 insertions(+), 2 deletions(-) create mode 100644 drivers/usb/gadget/composite.c create mode 100644 include/linux/usb/composite.h
USB Composite gadget implementation for u-boot. It builds on top of USB UDC drivers.
This commit is based on following files from Linux Kernel v2.6.36:
SHA1: d187abb9a83e6c6b6e9f2ca17962bdeafb4bc903
--- Changes for v2: - Squash the kernel files with u-boot compatibility layer. - Removal of dead/kernel specific code - Comments corrected according to u-boot coding style --- drivers/usb/gadget/composite.c | 1091 +++++++++++++++++++++++++++++++++++++++ include/linux/usb/composite.h | 350 +++++++++++++ include/usb/lin_gadget_compat.h | 25 +- 3 files changed, 1464 insertions(+), 2 deletions(-) create mode 100644 drivers/usb/gadget/composite.c create mode 100644 include/linux/usb/composite.h
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c new file mode 100644 index 0000000..e7b4835 --- /dev/null +++ b/drivers/usb/gadget/composite.c @@ -0,0 +1,1091 @@ +/* + * composite.c - infrastructure for Composite USB Gadgets + * + * Copyright (C) 2006-2008 David Brownell + * U-boot porting: Lukasz Majewski l.majewski@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ +#undef DEBUG + +#include <linux/bitops.h> +#include <linux/usb/composite.h> + +/* big enough to hold our biggest descriptor */ +#define USB_BUFSIZ 4096 + +static struct usb_composite_driver *composite; + +/** + * usb_add_function() - add a function to a configuration + * @config: the configuration + * @function: the function being added + * Context: single threaded during gadget setup + * + * After initialization, each configuration must have one or more + * functions added to it. Adding a function involves calling its @bind() + * method to allocate resources such as interface and string identifiers + * and endpoints. + * + * This function returns the value of the function's bind(), which is + * zero for success else a negative errno value. + */ +int usb_add_function(struct usb_configuration *config, + struct usb_function *function) +{ + int value = -EINVAL; + + debug("adding '%s'/%p to config '%s'/%p\n", + function->name, function, + config->label, config); + + if (!function->set_alt || !function->disable) + goto done; + + function->config = config; + list_add_tail(&function->list, &config->functions); + + if (function->bind) { + value = function->bind(config, function); + if (value < 0) { + list_del(&function->list); + function->config = NULL; + } + } else + value = 0; + + if (!config->fullspeed && function->descriptors) + config->fullspeed = 1; + if (!config->highspeed && function->hs_descriptors) + config->highspeed = 1; + +done: + if (value) + debug("adding '%s'/%p --> %d\n", + function->name, function, value); + return value; +} + +/** + * usb_function_deactivate - prevent function and gadget enumeration + * @function: the function that isn't yet ready to respond + * + * Blocks response of the gadget driver to host enumeration by + * preventing the data line pullup from being activated. This is + * normally called during @bind() processing to change from the + * initial "ready to respond" state, or when a required resource + * becomes available. + * + * For example, drivers that serve as a passthrough to a userspace + * daemon can block enumeration unless that daemon (such as an OBEX, + * MTP, or print server) is ready to handle host requests. + * + * Not all systems support software control of their USB peripheral + * data pullups. + * + * Returns zero on success, else negative errno. + */ +int usb_function_deactivate(struct usb_function *function) +{ + struct usb_composite_dev *cdev = function->config->cdev; + int status = 0; + + if (cdev->deactivations == 0) + status = usb_gadget_disconnect(cdev->gadget); + if (status == 0) + cdev->deactivations++; + + return status; +} + +/** + * usb_function_activate - allow function and gadget enumeration + * @function: function on which usb_function_activate() was called + * + * Reverses effect of usb_function_deactivate(). If no more functions + * are delaying their activation, the gadget driver will respond to + * host enumeration procedures. + * + * Returns zero on success, else negative errno. + */ +int usb_function_activate(struct usb_function *function) +{ + struct usb_composite_dev *cdev = function->config->cdev; + int status = 0; + + if (cdev->deactivations == 0) { + printf("WARNING in %s line %d\n", __FILE__, __LINE__); + status = -EINVAL; + } else { + cdev->deactivations--; + if (cdev->deactivations == 0) + status = usb_gadget_connect(cdev->gadget); + } + + return status; +} + +/** + * usb_interface_id() - allocate an unused interface ID + * @config: configuration associated with the interface + * @function: function handling the interface + * Context: single threaded during gadget setup + * + * usb_interface_id() is called from usb_function.bind() callbacks to + * allocate new interface IDs. The function driver will then store that + * ID in interface, association, CDC union, and other descriptors. It + * will also handle any control requests targetted at that interface, + * particularly changing its altsetting via set_alt(). There may + * also be class-specific or vendor-specific requests to handle. + * + * All interface identifier should be allocated using this routine, to + * ensure that for example different functions don't wrongly assign + * different meanings to the same identifier. Note that since interface + * identifers are configuration-specific, functions used in more than + * one configuration (or more than once in a given configuration) need + * multiple versions of the relevant descriptors. + * + * Returns the interface ID which was allocated; or -ENODEV if no + * more interface IDs can be allocated. + */ +int usb_interface_id(struct usb_configuration *config, + struct usb_function *function) +{ + unsigned id = config->next_interface_id; + + if (id < MAX_CONFIG_INTERFACES) { + config->interface[id] = function; + config->next_interface_id = id + 1; + return id; + } + return -ENODEV; +} + +static int config_buf(struct usb_configuration *config, + enum usb_device_speed speed, void *buf, u8 type) +{ + struct usb_config_descriptor *c = buf; + void *next = buf + USB_DT_CONFIG_SIZE; + int len = USB_BUFSIZ - USB_DT_CONFIG_SIZE; + struct usb_function *f; + int status; + + /* write the config descriptor */ + c = buf; + c->bLength = USB_DT_CONFIG_SIZE; + c->bDescriptorType = type; + + c->bNumInterfaces = config->next_interface_id; + c->bConfigurationValue = config->bConfigurationValue; + c->iConfiguration = config->iConfiguration; + c->bmAttributes = USB_CONFIG_ATT_ONE | config->bmAttributes; + c->bMaxPower = config->bMaxPower ? : (CONFIG_USB_GADGET_VBUS_DRAW / 2); + + /* There may be e.g. OTG descriptors */ + if (config->descriptors) { + status = usb_descriptor_fillbuf(next, len, + config->descriptors); + if (status < 0) + return status; + len -= status; + next += status; + } + + /* add each function's descriptors */ + list_for_each_entry(f, &config->functions, list) { + struct usb_descriptor_header **descriptors; + + if (speed == USB_SPEED_HIGH) + descriptors = f->hs_descriptors; + else + descriptors = f->descriptors; + if (!descriptors) + continue; + status = usb_descriptor_fillbuf(next, len, + (const struct usb_descriptor_header **) descriptors); + if (status < 0) + return status; + len -= status; + next += status; + } + + len = next - buf; + c->wTotalLength = cpu_to_le16(len); + return len; +} + +static int config_desc(struct usb_composite_dev *cdev, unsigned w_value) +{ + struct usb_gadget *gadget = cdev->gadget; + struct usb_configuration *c; + u8 type = w_value >> 8; + enum usb_device_speed speed = USB_SPEED_UNKNOWN; + + if (gadget_is_dualspeed(gadget)) { + int hs = 0; + + if (gadget->speed == USB_SPEED_HIGH) + hs = 1; + if (type == USB_DT_OTHER_SPEED_CONFIG) + hs = !hs; + if (hs) + speed = USB_SPEED_HIGH; + + } + + w_value &= 0xff; + list_for_each_entry(c, &cdev->configs, list) { + if (speed == USB_SPEED_HIGH) { + if (!c->highspeed) + continue; + } else { + if (!c->fullspeed) + continue; + } + if (w_value == 0) + return config_buf(c, speed, cdev->req->buf, type); + w_value--; + } + return -EINVAL; +} + +static int count_configs(struct usb_composite_dev *cdev, unsigned type) +{ + struct usb_gadget *gadget = cdev->gadget; + struct usb_configuration *c; + unsigned count = 0; + int hs = 0; + + if (gadget_is_dualspeed(gadget)) { + if (gadget->speed == USB_SPEED_HIGH) + hs = 1; + if (type == USB_DT_DEVICE_QUALIFIER) + hs = !hs; + } + list_for_each_entry(c, &cdev->configs, list) { + /* ignore configs that won't work at this speed */ + if (hs) { + if (!c->highspeed) + continue; + } else { + if (!c->fullspeed) + continue; + } + count++; + } + return count; +} + +static void device_qual(struct usb_composite_dev *cdev) +{ + struct usb_qualifier_descriptor *qual = cdev->req->buf; + + qual->bLength = sizeof(*qual); + qual->bDescriptorType = USB_DT_DEVICE_QUALIFIER; + /* POLICY: same bcdUSB and device type info at both speeds */ + qual->bcdUSB = cdev->desc.bcdUSB; + qual->bDeviceClass = cdev->desc.bDeviceClass; + qual->bDeviceSubClass = cdev->desc.bDeviceSubClass; + qual->bDeviceProtocol = cdev->desc.bDeviceProtocol; + /* ASSUME same EP0 fifo size at both speeds */ + qual->bMaxPacketSize0 = cdev->desc.bMaxPacketSize0; + qual->bNumConfigurations = count_configs(cdev, USB_DT_DEVICE_QUALIFIER); + qual->bRESERVED = 0; +} + +static void reset_config(struct usb_composite_dev *cdev) +{ + struct usb_function *f; + + debug("%s:\n", __func__); + + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->disable) + f->disable(f); + + bitmap_zero(f->endpoints, 32); + } + cdev->config = NULL; +} + +static int set_config(struct usb_composite_dev *cdev, + const struct usb_ctrlrequest *ctrl, unsigned number) +{ + struct usb_gadget *gadget = cdev->gadget; + struct usb_configuration *c = NULL; + int result = -EINVAL; + unsigned power = gadget_is_otg(gadget) ? 8 : 100; + int tmp; + + if (cdev->config) + reset_config(cdev); + + if (number) { + list_for_each_entry(c, &cdev->configs, list) { + if (c->bConfigurationValue == number) { + result = 0; + break; + } + } + if (result < 0) + goto done; + } else + result = 0; + + debug("%s: %s speed config #%d: %s\n", __func__, + ({ char *speed; + switch (gadget->speed) { + case USB_SPEED_LOW: + speed = "low"; + break; + case USB_SPEED_FULL: + speed = "full"; + break; + case USB_SPEED_HIGH: + speed = "high"; + break; + default: + speed = "?"; + break; + }; + speed; + }), number, c ? c->label : "unconfigured"); + + if (!c) + goto done; + + cdev->config = c; + + /* Initialize all interfaces by setting them to altsetting zero. */ + for (tmp = 0; tmp < MAX_CONFIG_INTERFACES; tmp++) { + struct usb_function *f = c->interface[tmp]; + struct usb_descriptor_header **descriptors; + + if (!f) + break; + + /* + * Record which endpoints are used by the function. This is used + * to dispatch control requests targeted at that endpoint to the + * function's setup callback instead of the current + * configuration's setup callback. + */ + if (gadget->speed == USB_SPEED_HIGH) + descriptors = f->hs_descriptors; + else + descriptors = f->descriptors; + + for (; *descriptors; ++descriptors) { + struct usb_endpoint_descriptor *ep; + int addr; + + if ((*descriptors)->bDescriptorType != USB_DT_ENDPOINT) + continue; + + ep = (struct usb_endpoint_descriptor *)*descriptors; + addr = ((ep->bEndpointAddress & 0x80) >> 3) + | (ep->bEndpointAddress & 0x0f); + __set_bit(addr, f->endpoints); + } + + result = f->set_alt(f, tmp, 0); + if (result < 0) { + debug("interface %d (%s/%p) alt 0 --> %d\n", + tmp, f->name, f, result); + + reset_config(cdev); + goto done; + } + } + + /* when we return, be sure our power usage is valid */ + power = c->bMaxPower ? (2 * c->bMaxPower) : CONFIG_USB_GADGET_VBUS_DRAW; +done: + usb_gadget_vbus_draw(gadget, power); + return result; +} + +/** + * usb_add_config() - add a configuration to a device. + * @cdev: wraps the USB gadget + * @config: the configuration, with bConfigurationValue assigned + * Context: single threaded during gadget setup + * + * One of the main tasks of a composite driver's bind() routine is to + * add each of the configurations it supports, using this routine. + * + * This function returns the value of the configuration's bind(), which + * is zero for success else a negative errno value. Binding configurations + * assigns global resources including string IDs, and per-configuration + * resources such as interface IDs and endpoints. + */ +int usb_add_config(struct usb_composite_dev *cdev, + struct usb_configuration *config) +{ + int status = -EINVAL; + struct usb_configuration *c; + + debug("%s: adding config #%u '%s'/%p\n", __func__, + config->bConfigurationValue, + config->label, config); + + if (!config->bConfigurationValue || !config->bind) + goto done; + + /* Prevent duplicate configuration identifiers */ + list_for_each_entry(c, &cdev->configs, list) { + if (c->bConfigurationValue == config->bConfigurationValue) { + status = -EBUSY; + goto done; + } + } + + config->cdev = cdev; + list_add_tail(&config->list, &cdev->configs); + + INIT_LIST_HEAD(&config->functions); + config->next_interface_id = 0; + + status = config->bind(config); + if (status < 0) { + list_del(&config->list); + config->cdev = NULL; + } else { + unsigned i; + + debug("cfg %d/%p speeds:%s%s\n", + config->bConfigurationValue, config, + config->highspeed ? " high" : "", + config->fullspeed + ? (gadget_is_dualspeed(cdev->gadget) + ? " full" + : " full/low") + : ""); + + for (i = 0; i < MAX_CONFIG_INTERFACES; i++) { + struct usb_function *f = config->interface[i]; + + if (!f) + continue; + debug(" interface %d = %s/%p\n", + i, f->name, f); + } + } + + usb_ep_autoconfig_reset(cdev->gadget); + +done: + if (status) + debug("added config '%s'/%u --> %d\n", config->label, + config->bConfigurationValue, status); + return status; +} + +/* + * We support strings in multiple languages ... string descriptor zero + * says which languages are supported. The typical case will be that + * only one language (probably English) is used, with I18N handled on + * the host side. + */ + +static void collect_langs(struct usb_gadget_strings **sp, __le16 *buf) +{ + const struct usb_gadget_strings *s; + u16 language; + __le16 *tmp; + + while (*sp) { + s = *sp; + language = cpu_to_le16(s->language); + for (tmp = buf; *tmp && tmp < &buf[126]; tmp++) { + if (*tmp == language) + goto repeat; + } + *tmp++ = language; +repeat: + sp++; + } +} + +static int lookup_string( + struct usb_gadget_strings **sp, + void *buf, + u16 language, + int id +) +{ + struct usb_gadget_strings *s; + int value; + + while (*sp) { + s = *sp++; + if (s->language != language) + continue; + value = usb_gadget_get_string(s, id, buf); + if (value > 0) + return value; + } + return -EINVAL; +} + +static int get_string(struct usb_composite_dev *cdev, + void *buf, u16 language, int id) +{ + struct usb_configuration *c; + struct usb_function *f; + int len; + + /* + * Yes, not only is USB's I18N support probably more than most + * folk will ever care about ... also, it's all supported here. + * (Except for UTF8 support for Unicode's "Astral Planes".) + */ + + /* 0 == report all available language codes */ + if (id == 0) { + struct usb_string_descriptor *s = buf; + struct usb_gadget_strings **sp; + + memset(s, 0, 256); + s->bDescriptorType = USB_DT_STRING; + + sp = composite->strings; + if (sp) + collect_langs(sp, s->wData); + + list_for_each_entry(c, &cdev->configs, list) { + sp = c->strings; + if (sp) + collect_langs(sp, s->wData); + + list_for_each_entry(f, &c->functions, list) { + sp = f->strings; + if (sp) + collect_langs(sp, s->wData); + } + } + + for (len = 0; len <= 126 && s->wData[len]; len++) + continue; + if (!len) + return -EINVAL; + + s->bLength = 2 * (len + 1); + return s->bLength; + } + + /* + * Otherwise, look up and return a specified string. String IDs + * are device-scoped, so we look up each string table we're told + * about. These lookups are infrequent; simpler-is-better here. + */ + if (composite->strings) { + len = lookup_string(composite->strings, buf, language, id); + if (len > 0) + return len; + } + list_for_each_entry(c, &cdev->configs, list) { + if (c->strings) { + len = lookup_string(c->strings, buf, language, id); + if (len > 0) + return len; + } + list_for_each_entry(f, &c->functions, list) { + if (!f->strings) + continue; + len = lookup_string(f->strings, buf, language, id); + if (len > 0) + return len; + } + } + return -EINVAL; +} + +/** + * usb_string_id() - allocate an unused string ID + * @cdev: the device whose string descriptor IDs are being allocated + * Context: single threaded during gadget setup + * + * @usb_string_id() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then store that ID in the appropriate descriptors and string table. + * + * All string identifier should be allocated using this, + * @usb_string_ids_tab() or @usb_string_ids_n() routine, to ensure + * that for example different functions don't wrongly assign different + * meanings to the same identifier. + */ +int usb_string_id(struct usb_composite_dev *cdev) +{ + if (cdev->next_string_id < 254) { + /* + * string id 0 is reserved by USB spec for list of + * supported languages + * 255 reserved as well? -- mina86 + */ + cdev->next_string_id++; + return cdev->next_string_id; + } + return -ENODEV; +} + +/** + * usb_string_ids() - allocate unused string IDs in batch + * @cdev: the device whose string descriptor IDs are being allocated + * @str: an array of usb_string objects to assign numbers to + * Context: single threaded during gadget setup + * + * @usb_string_ids() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then copy IDs from the string table to the appropriate descriptors + * and string table for other languages. + * + * All string identifier should be allocated using this, + * @usb_string_id() or @usb_string_ids_n() routine, to ensure that for + * example different functions don't wrongly assign different meanings + * to the same identifier. + */ +int usb_string_ids_tab(struct usb_composite_dev *cdev, struct usb_string *str) +{ + int next = cdev->next_string_id; + + for (; str->s; ++str) { + if (unlikely(next >= 254)) + return -ENODEV; + str->id = ++next; + } + + cdev->next_string_id = next; + + return 0; +} + +/** + * usb_string_ids_n() - allocate unused string IDs in batch + * @c: the device whose string descriptor IDs are being allocated + * @n: number of string IDs to allocate + * Context: single threaded during gadget setup + * + * Returns the first requested ID. This ID and next @n-1 IDs are now + * valid IDs. At least provided that @n is non-zero because if it + * is, returns last requested ID which is now very useful information. + * + * @usb_string_ids_n() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then store that ID in the appropriate descriptors and string table. + * + * All string identifier should be allocated using this, + * @usb_string_id() or @usb_string_ids_n() routine, to ensure that for + * example different functions don't wrongly assign different meanings + * to the same identifier. + */ +int usb_string_ids_n(struct usb_composite_dev *c, unsigned n) +{ + unsigned next = c->next_string_id; + if (unlikely(n > 254 || (unsigned)next + n > 254)) + return -ENODEV; + c->next_string_id += n; + return next + 1; +} + +static void composite_setup_complete(struct usb_ep *ep, struct usb_request *req) +{ + if (req->status || req->actual != req->length) + debug("%s: setup complete --> %d, %d/%d\n", __func__, + req->status, req->actual, req->length); +} + +/* + * The setup() callback implements all the ep0 functionality that's + * not handled lower down, in hardware or the hardware driver(like + * device and endpoint feature flags, and their status). It's all + * housekeeping for the gadget function we're implementing. Most of + * the work is in config and function specific setup. + */ +static int +composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_request *req = cdev->req; + int value = -EOPNOTSUPP; + u16 w_index = le16_to_cpu(ctrl->wIndex); + u8 intf = w_index & 0xFF; + u16 w_value = le16_to_cpu(ctrl->wValue); + u16 w_length = le16_to_cpu(ctrl->wLength); + struct usb_function *f = NULL; + u8 endp; + int standard; + + /* + * partial re-init of the response message; the function or the + * gadget might need to intercept e.g. a control-OUT completion + * when we delegate to it. + */ + req->zero = 0; + req->complete = composite_setup_complete; + req->length = USB_BUFSIZ; + gadget->ep0->driver_data = cdev; + standard = (ctrl->bRequestType & USB_TYPE_MASK) + == USB_TYPE_STANDARD; + if (!standard) + goto unknown; + + switch (ctrl->bRequest) { + + /* we handle all standard USB descriptors */ + case USB_REQ_GET_DESCRIPTOR: + if (ctrl->bRequestType != USB_DIR_IN) + goto unknown; + switch (w_value >> 8) { + + case USB_DT_DEVICE: + cdev->desc.bNumConfigurations = + count_configs(cdev, USB_DT_DEVICE); + value = min(w_length, (u16) sizeof cdev->desc); + memcpy(req->buf, &cdev->desc, value); + break; + case USB_DT_DEVICE_QUALIFIER: + if (!gadget_is_dualspeed(gadget)) + break; + device_qual(cdev); + value = min_t(w_length, + sizeof(struct usb_qualifier_descriptor)); + break; + case USB_DT_OTHER_SPEED_CONFIG: + if (!gadget_is_dualspeed(gadget)) + break; + + case USB_DT_CONFIG: + value = config_desc(cdev, w_value); + if (value >= 0) + value = min(w_length, (u16) value); + break; + case USB_DT_STRING: + value = get_string(cdev, req->buf, + w_index, w_value & 0xff); + if (value >= 0) + value = min(w_length, (u16) value); + break; + default: + goto unknown; + } + break; + + /* any number of configs can work */ + case USB_REQ_SET_CONFIGURATION: + if (ctrl->bRequestType != 0) + goto unknown; + if (gadget_is_otg(gadget)) { + if (gadget->a_hnp_support) + debug("HNP available\n"); + else if (gadget->a_alt_hnp_support) + debug("HNP on another port\n"); + else + debug("HNP inactive\n"); + } + + value = set_config(cdev, ctrl, w_value); + break; + case USB_REQ_GET_CONFIGURATION: + if (ctrl->bRequestType != USB_DIR_IN) + goto unknown; + if (cdev->config) + *(u8 *)req->buf = cdev->config->bConfigurationValue; + else + *(u8 *)req->buf = 0; + value = min(w_length, (u16) 1); + break; + + /* + * function drivers must handle get/set altsetting; if there's + * no get() method, we know only altsetting zero works. + */ + case USB_REQ_SET_INTERFACE: + if (ctrl->bRequestType != USB_RECIP_INTERFACE) + goto unknown; + if (!cdev->config || w_index >= MAX_CONFIG_INTERFACES) + break; + f = cdev->config->interface[intf]; + if (!f) + break; + if (w_value && !f->set_alt) + break; + value = f->set_alt(f, w_index, w_value); + break; + case USB_REQ_GET_INTERFACE: + if (ctrl->bRequestType != (USB_DIR_IN|USB_RECIP_INTERFACE)) + goto unknown; + if (!cdev->config || w_index >= MAX_CONFIG_INTERFACES) + break; + f = cdev->config->interface[intf]; + if (!f) + break; + /* lots of interfaces only need altsetting zero... */ + value = f->get_alt ? f->get_alt(f, w_index) : 0; + if (value < 0) + break; + *((u8 *)req->buf) = value; + value = min(w_length, (u16) 1); + break; + default: +unknown: + debug("non-core control req%02x.%02x v%04x i%04x l%d\n", + ctrl->bRequestType, ctrl->bRequest, + w_value, w_index, w_length); + + /* + * functions always handle their interfaces and endpoints... + * punt other recipients (other, WUSB, ...) to the current + * configuration code. + */ + switch (ctrl->bRequestType & USB_RECIP_MASK) { + case USB_RECIP_INTERFACE: + f = cdev->config->interface[intf]; + break; + + case USB_RECIP_ENDPOINT: + endp = ((w_index & 0x80) >> 3) | (w_index & 0x0f); + list_for_each_entry(f, &cdev->config->functions, list) { + if (test_bit(endp, f->endpoints)) + break; + } + if (&f->list == &cdev->config->functions) + f = NULL; + break; + } + + if (f && f->setup) + value = f->setup(f, ctrl); + else { + struct usb_configuration *c; + + c = cdev->config; + if (c && c->setup) + value = c->setup(c, ctrl); + } + + goto done; + } + + /* respond with data transfer before status phase? */ + if (value >= 0) { + req->length = value; + req->zero = value < w_length; + value = usb_ep_queue(gadget->ep0, req, GFP_ATOMIC); + if (value < 0) { + debug("ep_queue --> %d\n", value); + req->status = 0; + composite_setup_complete(gadget->ep0, req); + } + } + +done: + /* device either stalls (value < 0) or reports success */ + return value; +} + +static void composite_disconnect(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + + if (cdev->config) + reset_config(cdev); + if (composite->disconnect) + composite->disconnect(cdev); +} + +static void composite_unbind(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + + /* + * composite_disconnect() must already have been called + * by the underlying peripheral controller driver! + * so there's no i/o concurrency that could affect the + * state protected by cdev->lock. + */ + BUG_ON(cdev->config); + + while (!list_empty(&cdev->configs)) { + struct usb_configuration *c; + + c = list_first_entry(&cdev->configs, + struct usb_configuration, list); + while (!list_empty(&c->functions)) { + struct usb_function *f; + + f = list_first_entry(&c->functions, + struct usb_function, list); + list_del(&f->list); + if (f->unbind) { + debug("unbind function '%s'/%p\n", + f->name, f); + f->unbind(c, f); + } + } + list_del(&c->list); + if (c->unbind) { + debug("unbind config '%s'/%p\n", c->label, c); + c->unbind(c); + } + } + if (composite->unbind) + composite->unbind(cdev); + + if (cdev->req) { + kfree(cdev->req->buf); + usb_ep_free_request(gadget->ep0, cdev->req); + } + kfree(cdev); + set_gadget_data(gadget, NULL); + + composite = NULL; +} + +static int composite_bind(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev; + int status = -ENOMEM; + + cdev = calloc(sizeof *cdev, 1); + if (!cdev) + return status; + + cdev->gadget = gadget; + set_gadget_data(gadget, cdev); + INIT_LIST_HEAD(&cdev->configs); + + /* preallocate control response and buffer */ + cdev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL); + if (!cdev->req) + goto fail; + cdev->req->buf = kmalloc(USB_BUFSIZ, GFP_KERNEL); + if (!cdev->req->buf) + goto fail; + cdev->req->complete = composite_setup_complete; + gadget->ep0->driver_data = cdev; + + cdev->bufsiz = USB_BUFSIZ; + cdev->driver = composite; + + usb_gadget_set_selfpowered(gadget); + usb_ep_autoconfig_reset(cdev->gadget); + + status = composite->bind(cdev); + if (status < 0) + goto fail; + + cdev->desc = *composite->dev; + cdev->desc.bMaxPacketSize0 = gadget->ep0->maxpacket; + + debug("%s: ready\n", composite->name); + return 0; + +fail: + composite_unbind(gadget); + return status; +} + +static void +composite_suspend(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_function *f; + + debug("%s: suspend\n", __func__); + if (cdev->config) { + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->suspend) + f->suspend(f); + } + } + if (composite->suspend) + composite->suspend(cdev); + + cdev->suspended = 1; +} + +static void +composite_resume(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_function *f; + + debug("%s: resume\n", __func__); + if (composite->resume) + composite->resume(cdev); + if (cdev->config) { + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->resume) + f->resume(f); + } + } + + cdev->suspended = 0; +} + +static struct usb_gadget_driver composite_driver = { + .speed = USB_SPEED_HIGH, + + .bind = composite_bind, + .unbind = composite_unbind, + + .setup = composite_setup, + .disconnect = composite_disconnect, + + .suspend = composite_suspend, + .resume = composite_resume, +}; + +/** + * usb_composite_register() - register a composite driver + * @driver: the driver to register + * Context: single threaded during gadget setup + * + * This function is used to register drivers using the composite driver + * framework. The return value is zero, or a negative errno value. + * Those values normally come from the driver's @bind method, which does + * all the work of setting up the driver to match the hardware. + * + * On successful return, the gadget is ready to respond to requests from + * the host, unless one of its components invokes usb_gadget_disconnect() + * while it was binding. That would usually be done in order to wait for + * some userspace participation. + */ +int usb_composite_register(struct usb_composite_driver *driver) +{ + if (!driver || !driver->dev || !driver->bind || composite) + return -EINVAL; + + if (!driver->name) + driver->name = "composite"; + composite = driver; + + return usb_gadget_register_driver(&composite_driver); +} + +/** + * usb_composite_unregister() - unregister a composite driver + * @driver: the driver to unregister + * + * This function is used to unregister drivers using the composite + * driver framework. + */ +void usb_composite_unregister(struct usb_composite_driver *driver) +{ + if (composite != driver) + return; + usb_gadget_unregister_driver(&composite_driver); +} diff --git a/include/linux/usb/composite.h b/include/linux/usb/composite.h new file mode 100644 index 0000000..53cb095 --- /dev/null +++ b/include/linux/usb/composite.h @@ -0,0 +1,350 @@ +/* + * composite.h -- framework for usb gadgets which are composite devices + * + * Copyright (C) 2006-2008 David Brownell + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef __LINUX_USB_COMPOSITE_H +#define __LINUX_USB_COMPOSITE_H + +/* + * This framework is an optional layer on top of the USB Gadget interface, + * making it easier to build (a) Composite devices, supporting multiple + * functions within any single configuration, and (b) Multi-configuration + * devices, also supporting multiple functions but without necessarily + * having more than one function per configuration. + * + * Example: a device with a single configuration supporting both network + * link and mass storage functions is a composite device. Those functions + * might alternatively be packaged in individual configurations, but in + * the composite model the host can use both functions at the same time. + */ + +#include <common.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <usb/lin_gadget_compat.h> + +struct usb_configuration; + +/** + * struct usb_function - describes one function of a configuration + * @name: For diagnostics, identifies the function. + * @strings: tables of strings, keyed by identifiers assigned during bind() + * and by language IDs provided in control requests + * @descriptors: Table of full (or low) speed descriptors, using interface and + * string identifiers assigned during @bind(). If this pointer is null, + * the function will not be available at full speed (or at low speed). + * @hs_descriptors: Table of high speed descriptors, using interface and + * string identifiers assigned during @bind(). If this pointer is null, + * the function will not be available at high speed. + * @config: assigned when @usb_add_function() is called; this is the + * configuration with which this function is associated. + * @bind: Before the gadget can register, all of its functions bind() to the + * available resources including string and interface identifiers used + * in interface or class descriptors; endpoints; I/O buffers; and so on. + * @unbind: Reverses @bind; called as a side effect of unregistering the + * driver which added this function. + * @set_alt: (REQUIRED) Reconfigures altsettings; function drivers may + * initialize usb_ep.driver data at this time (when it is used). + * Note that setting an interface to its current altsetting resets + * interface state, and that all interfaces have a disabled state. + * @get_alt: Returns the active altsetting. If this is not provided, + * then only altsetting zero is supported. + * @disable: (REQUIRED) Indicates the function should be disabled. Reasons + * include host resetting or reconfiguring the gadget, and disconnection. + * @setup: Used for interface-specific control requests. + * @suspend: Notifies functions when the host stops sending USB traffic. + * @resume: Notifies functions when the host restarts USB traffic. + * + * A single USB function uses one or more interfaces, and should in most + * cases support operation at both full and high speeds. Each function is + * associated by @usb_add_function() with a one configuration; that function + * causes @bind() to be called so resources can be allocated as part of + * setting up a gadget driver. Those resources include endpoints, which + * should be allocated using @usb_ep_autoconfig(). + * + * To support dual speed operation, a function driver provides descriptors + * for both high and full speed operation. Except in rare cases that don't + * involve bulk endpoints, each speed needs different endpoint descriptors. + * + * Function drivers choose their own strategies for managing instance data. + * The simplest strategy just declares it "static', which means the function + * can only be activated once. If the function needs to be exposed in more + * than one configuration at a given speed, it needs to support multiple + * usb_function structures (one for each configuration). + * + * A more complex strategy might encapsulate a @usb_function structure inside + * a driver-specific instance structure to allows multiple activations. An + * example of multiple activations might be a CDC ACM function that supports + * two or more distinct instances within the same configuration, providing + * several independent logical data links to a USB host. + */ +struct usb_function { + const char *name; + struct usb_gadget_strings **strings; + struct usb_descriptor_header **descriptors; + struct usb_descriptor_header **hs_descriptors; + + struct usb_configuration *config; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching. + * Related: unbind() may kfree() but bind() won't... + */ + + /* configuration management: bind/unbind */ + int (*bind)(struct usb_configuration *, + struct usb_function *); + void (*unbind)(struct usb_configuration *, + struct usb_function *); + + /* runtime state management */ + int (*set_alt)(struct usb_function *, + unsigned interface, unsigned alt); + int (*get_alt)(struct usb_function *, + unsigned interface); + void (*disable)(struct usb_function *); + int (*setup)(struct usb_function *, + const struct usb_ctrlrequest *); + void (*suspend)(struct usb_function *); + void (*resume)(struct usb_function *); + + /* private: */ + /* internals */ + struct list_head list; + DECLARE_BITMAP(endpoints, 32); +}; + +int usb_add_function(struct usb_configuration *, struct usb_function *); + +int usb_function_deactivate(struct usb_function *); +int usb_function_activate(struct usb_function *); + +int usb_interface_id(struct usb_configuration *, struct usb_function *); + +/** + * ep_choose - select descriptor endpoint at current device speed + * @g: gadget, connected and running at some speed + * @hs: descriptor to use for high speed operation + * @fs: descriptor to use for full or low speed operation + */ +static inline struct usb_endpoint_descriptor * +ep_choose(struct usb_gadget *g, struct usb_endpoint_descriptor *hs, + struct usb_endpoint_descriptor *fs) +{ + if (gadget_is_dualspeed(g) && g->speed == USB_SPEED_HIGH) + return hs; + return fs; +} + +#define MAX_CONFIG_INTERFACES 16 /* arbitrary; max 255 */ + +/** + * struct usb_configuration - represents one gadget configuration + * @label: For diagnostics, describes the configuration. + * @strings: Tables of strings, keyed by identifiers assigned during @bind() + * and by language IDs provided in control requests. + * @descriptors: Table of descriptors preceding all function descriptors. + * Examples include OTG and vendor-specific descriptors. + * @bind: Called from @usb_add_config() to allocate resources unique to this + * configuration and to call @usb_add_function() for each function used. + * @unbind: Reverses @bind; called as a side effect of unregistering the + * driver which added this configuration. + * @setup: Used to delegate control requests that aren't handled by standard + * device infrastructure or directed at a specific interface. + * @bConfigurationValue: Copied into configuration descriptor. + * @iConfiguration: Copied into configuration descriptor. + * @bmAttributes: Copied into configuration descriptor. + * @bMaxPower: Copied into configuration descriptor. + * @cdev: assigned by @usb_add_config() before calling @bind(); this is + * the device associated with this configuration. + * + * Configurations are building blocks for gadget drivers structured around + * function drivers. Simple USB gadgets require only one function and one + * configuration, and handle dual-speed hardware by always providing the same + * functionality. Slightly more complex gadgets may have more than one + * single-function configuration at a given speed; or have configurations + * that only work at one speed. + * + * Composite devices are, by definition, ones with configurations which + * include more than one function. + * + * The lifecycle of a usb_configuration includes allocation, initialization + * of the fields described above, and calling @usb_add_config() to set up + * internal data and bind it to a specific device. The configuration's + * @bind() method is then used to initialize all the functions and then + * call @usb_add_function() for them. + * + * Those functions would normally be independant of each other, but that's + * not mandatory. CDC WMC devices are an example where functions often + * depend on other functions, with some functions subsidiary to others. + * Such interdependency may be managed in any way, so long as all of the + * descriptors complete by the time the composite driver returns from + * its bind() routine. + */ +struct usb_configuration { + const char *label; + struct usb_gadget_strings **strings; + const struct usb_descriptor_header **descriptors; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching... + */ + + /* configuration management: bind/unbind */ + int (*bind)(struct usb_configuration *); + void (*unbind)(struct usb_configuration *); + int (*setup)(struct usb_configuration *, + const struct usb_ctrlrequest *); + + /* fields in the config descriptor */ + u8 bConfigurationValue; + u8 iConfiguration; + u8 bmAttributes; + u8 bMaxPower; + + struct usb_composite_dev *cdev; + + /* private: */ + /* internals */ + struct list_head list; + struct list_head functions; + u8 next_interface_id; + unsigned highspeed:1; + unsigned fullspeed:1; + struct usb_function *interface[MAX_CONFIG_INTERFACES]; +}; + +int usb_add_config(struct usb_composite_dev *, + struct usb_configuration *); + +/** + * struct usb_composite_driver - groups configurations into a gadget + * @name: For diagnostics, identifies the driver. + * @dev: Template descriptor for the device, including default device + * identifiers. + * @strings: tables of strings, keyed by identifiers assigned during bind() + * and language IDs provided in control requests + * @bind: (REQUIRED) Used to allocate resources that are shared across the + * whole device, such as string IDs, and add its configurations using + * @usb_add_config(). This may fail by returning a negative errno + * value; it should return zero on successful initialization. + * @unbind: Reverses @bind(); called as a side effect of unregistering + * this driver. + * @disconnect: optional driver disconnect method + * @suspend: Notifies when the host stops sending USB traffic, + * after function notifications + * @resume: Notifies configuration when the host restarts USB traffic, + * before function notifications + * + * Devices default to reporting self powered operation. Devices which rely + * on bus powered operation should report this in their @bind() method. + * + * Before returning from @bind, various fields in the template descriptor + * may be overridden. These include the idVendor/idProduct/bcdDevice values + * normally to bind the appropriate host side driver, and the three strings + * (iManufacturer, iProduct, iSerialNumber) normally used to provide user + * meaningful device identifiers. (The strings will not be defined unless + * they are defined in @dev and @strings.) The correct ep0 maxpacket size + * is also reported, as defined by the underlying controller driver. + */ +struct usb_composite_driver { + const char *name; + const struct usb_device_descriptor *dev; + struct usb_gadget_strings **strings; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching... + */ + + int (*bind)(struct usb_composite_dev *); + int (*unbind)(struct usb_composite_dev *); + + void (*disconnect)(struct usb_composite_dev *); + + /* global suspend hooks */ + void (*suspend)(struct usb_composite_dev *); + void (*resume)(struct usb_composite_dev *); +}; + +extern int usb_composite_register(struct usb_composite_driver *); +extern void usb_composite_unregister(struct usb_composite_driver *); + + +/** + * struct usb_composite_device - represents one composite usb gadget + * @gadget: read-only, abstracts the gadget's usb peripheral controller + * @req: used for control responses; buffer is pre-allocated + * @bufsiz: size of buffer pre-allocated in @req + * @config: the currently active configuration + * + * One of these devices is allocated and initialized before the + * associated device driver's bind() is called. + * + * OPEN ISSUE: it appears that some WUSB devices will need to be + * built by combining a normal (wired) gadget with a wireless one. + * This revision of the gadget framework should probably try to make + * sure doing that won't hurt too much. + * + * One notion for how to handle Wireless USB devices involves: + * (a) a second gadget here, discovery mechanism TBD, but likely + * needing separate "register/unregister WUSB gadget" calls; + * (b) updates to usb_gadget to include flags "is it wireless", + * "is it wired", plus (presumably in a wrapper structure) + * bandgroup and PHY info; + * (c) presumably a wireless_ep wrapping a usb_ep, and reporting + * wireless-specific parameters like maxburst and maxsequence; + * (d) configurations that are specific to wireless links; + * (e) function drivers that understand wireless configs and will + * support wireless for (additional) function instances; + * (f) a function to support association setup (like CBAF), not + * necessarily requiring a wireless adapter; + * (g) composite device setup that can create one or more wireless + * configs, including appropriate association setup support; + * (h) more, TBD. + */ +struct usb_composite_dev { + struct usb_gadget *gadget; + struct usb_request *req; + unsigned bufsiz; + + struct usb_configuration *config; + + /* private: */ + /* internals */ + unsigned int suspended:1; + struct usb_device_descriptor desc; + struct list_head configs; + struct usb_composite_driver *driver; + u8 next_string_id; + + /* the gadget driver won't enable the data pullup + * while the deactivation count is nonzero. + */ + unsigned deactivations; +}; + +extern int usb_string_id(struct usb_composite_dev *c); +extern int usb_string_ids_tab(struct usb_composite_dev *c, + struct usb_string *str); +extern int usb_string_ids_n(struct usb_composite_dev *c, unsigned n); + +#endif /* __LINUX_USB_COMPOSITE_H */ diff --git a/include/usb/lin_gadget_compat.h b/include/usb/lin_gadget_compat.h index fce3be7..01c576a 100644 --- a/include/usb/lin_gadget_compat.h +++ b/include/usb/lin_gadget_compat.h @@ -36,8 +36,8 @@ #define mutex_lock(...) #define mutex_unlock(...)
-#define WARN_ON(x) if (x) {printf("WARNING in %s line %d\n" \ - , __FILE__, __LINE__); } +#define WARN_ON(x) do { if (x) printf("WARNING in %s line %d\n" \ + , __FILE__, __LINE__); } while (0)
#define KERN_WARNING #define KERN_ERR @@ -45,6 +45,7 @@ #define KERN_DEBUG
#define GFP_KERNEL 0 +#define GFP_ATOMIC 0
#define IRQ_HANDLED 1
@@ -56,6 +57,26 @@
#define __iomem #define min_t min + +#define BITS_PER_BYTE 8 +#define BITS_TO_LONGS(nr) \ + DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) +#define DECLARE_BITMAP(name, bits) \ + unsigned long name[BITS_TO_LONGS(bits)] + +#define small_const_nbits(nbits) \ + (__builtin_constant_p(nbits) && (nbits) <= BITS_PER_LONG) + +static inline void bitmap_zero(unsigned long *dst, int nbits) +{ + if (small_const_nbits(nbits)) + *dst = 0UL; + else { + int len = BITS_TO_LONGS(nbits) * sizeof(unsigned long); + memset(dst, 0, len); + } +} + #define dma_cache_maint(addr, size, mode) cache_flush() void cache_flush(void);
Dear Lukasz Majewski,
Changes for v2:
- unsigned next = c->next_string_id;
- if (unlikely(n > 254 || (unsigned)next + n > 254))
This unlikely() call is unlikely part of uboot :)
return -ENODEV;
- c->next_string_id += n;
- return next + 1;
- if (req->status || req->actual != req->length)
- struct usb_composite_dev *cdev = get_gadget_data(gadget);
- BUG_ON(cdev->config);
Do we have BUG_ON() defined in uboot ?
- while (!list_empty(&cdev->configs)) {
list_del(&f->list);
if (f->unbind) {
f->name, f);
f->unbind(c, f);
list_del(&c->list);
if (c->unbind) {
c->unbind(c);
- if (composite->unbind)
- if (cdev->req) {
- kfree(cdev);
- set_gadget_data(gadget, NULL);
- composite = NULL;
- struct usb_composite_dev *cdev;
- int status = -ENOMEM;
- cdev = calloc(sizeof *cdev, 1);
- if (!cdev)
return status;
- cdev->gadget = gadget;
- set_gadget_data(gadget, cdev);
- INIT_LIST_HEAD(&cdev->configs);
- /* preallocate control response and buffer */
- cdev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL);
- if (!cdev->req)
goto fail;
- cdev->req->buf = kmalloc(USB_BUFSIZ, GFP_KERNEL);
- if (!cdev->req->buf)
goto fail;
- cdev->req->complete = composite_setup_complete;
- gadget->ep0->driver_data = cdev;
- cdev->bufsiz = USB_BUFSIZ;
- cdev->driver = composite;
- usb_gadget_set_selfpowered(gadget);
- usb_ep_autoconfig_reset(cdev->gadget);
- status = composite->bind(cdev);
- if (status < 0)
goto fail;
- cdev->desc = *composite->dev;
- cdev->desc.bMaxPacketSize0 = gadget->ep0->maxpacket;
- debug("%s: ready\n", composite->name);
+fail:
- composite_unbind(gadget);
- return status;
- struct usb_function *f;
- debug("%s: suspend\n", __func__);
- if (cdev->config) {
if (f->suspend)
f->suspend(f);
- if (composite->suspend)
- cdev->suspended = 1;
- debug("%s: resume\n", __func__);
- if (composite->resume)
if (f->resume)
f->resume(f);
- cdev->suspended = 0;
- .speed = USB_SPEED_HIGH,
- .bind = composite_bind,
- .unbind = composite_unbind,
You have some weird indent in here?
- .setup = composite_setup,
- .disconnect = composite_disconnect,
- .suspend = composite_suspend,
- .resume = composite_resume,
I think this patch is getting much better ;-)
Hi Marek,
Nope, but will be removed :-)
It is defined at include/common.h
But it can be removed if you wish.
Nice to hear :-)
Add device data pointer to the USB gadget's device struct. Wrapper for extracting usb_gadget from Linux's usb device
--- Changes for v2: - Two separate patches regarding gadget.h file squashed together --- include/linux/usb/gadget.h | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 275cb5f..eba865e 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -411,6 +411,7 @@ struct usb_gadget_ops {
/** @@ -481,6 +482,11 @@ static inline void *get_gadget_data(struct usb_gadget *gadget) return gadget->dev.driver_data; }
This commit adds support for storing private data to Samsung's UDC driver. This data is afterward used by usb gadget.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/usb/gadget/s3c_udc_otg.c | 12 ++++++++++++ 1 files changed, 12 insertions(+), 0 deletions(-)
diff --git a/drivers/usb/gadget/s3c_udc_otg.c b/drivers/usb/gadget/s3c_udc_otg.c index f7f7b54..cb4916c 100644 --- a/drivers/usb/gadget/s3c_udc_otg.c +++ b/drivers/usb/gadget/s3c_udc_otg.c @@ -133,6 +133,18 @@ static void nuke(struct s3c_ep *ep, int status); static int s3c_udc_set_halt(struct usb_ep *_ep, int value); static void s3c_udc_set_nak(struct s3c_ep *ep);
+void set_udc_gadget_private_data(void *p) +{ + printf("%s: the_controller: 0x%p, p: 0x%p\n", __func__, + the_controller, p); + the_controller->gadget.dev.device_data = p; +} + +void *get_udc_gadget_private_data(struct usb_gadget *gadget) +{ + return gadget->dev.device_data; +} + static struct usb_ep_ops s3c_ep_ops = { .enable = s3c_ep_enable, .disable = s3c_ep_disable,
- printf("%s: the_controller: 0x%p, p: 0x%p\n", __func__,
the_controller, p);
debug()
- the_controller->gadget.dev.device_data = p;
- return gadget->dev.device_data;
--- Changes for v2: - Squash the kernel files with u-boot compatibility layer. - Removal of dead/kernel specific code. - Comments corrected according to u-boot coding style. - Two separate patches regarding gadget.h file squashed together. Changes for v3: - Remove unlikely function call - Code indentation fixup Lukasz Majewski (3): usb:gadget:composite USB composite gadget support usb:gadget:composite: Support for composite at gadget.h usb:udc:samsung Add functions for storing private gadget data in UDC driver
./include/linux/usb/composite.h ./drivers/usb/gadget/composite.c
--- Changes for v2: - Squash the strict kernel files with u-boot compatibility layer. - Removal of dead/kernel specific code - Comments corrected according to u-boot coding style Changes for v3: - Remove unlikely function call - Code indentation fixup
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c new file mode 100644 index 0000000..0415aa4 --- /dev/null +++ b/drivers/usb/gadget/composite.c @@ -0,0 +1,1091 @@ +/* + * composite.c - infrastructure for Composite USB Gadgets + * + * Copyright (C) 2006-2008 David Brownell + * U-boot porting: Lukasz Majewski l.majewski@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ +#undef DEBUG + +#include <linux/bitops.h> +#include <linux/usb/composite.h> + +/* big enough to hold our biggest descriptor */ +#define USB_BUFSIZ 4096 + +static struct usb_composite_driver *composite; + +/** + * usb_add_function() - add a function to a configuration + * @config: the configuration + * @function: the function being added + * Context: single threaded during gadget setup + * + * After initialization, each configuration must have one or more + * functions added to it. Adding a function involves calling its @bind() + * method to allocate resources such as interface and string identifiers + * and endpoints. + * + * This function returns the value of the function's bind(), which is + * zero for success else a negative errno value. + */ +int usb_add_function(struct usb_configuration *config, + struct usb_function *function) +{ + int value = -EINVAL; + + debug("adding '%s'/%p to config '%s'/%p\n", + function->name, function, + config->label, config); + + if (!function->set_alt || !function->disable) + goto done; + + function->config = config; + list_add_tail(&function->list, &config->functions); + + if (function->bind) { + value = function->bind(config, function); + if (value < 0) { + list_del(&function->list); + function->config = NULL; + } + } else + value = 0; + + if (!config->fullspeed && function->descriptors) + config->fullspeed = 1; + if (!config->highspeed && function->hs_descriptors) + config->highspeed = 1; + +done: + if (value) + debug("adding '%s'/%p --> %d\n", + function->name, function, value); + return value; +} + +/** + * usb_function_deactivate - prevent function and gadget enumeration + * @function: the function that isn't yet ready to respond + * + * Blocks response of the gadget driver to host enumeration by + * preventing the data line pullup from being activated. This is + * normally called during @bind() processing to change from the + * initial "ready to respond" state, or when a required resource + * becomes available. + * + * For example, drivers that serve as a passthrough to a userspace + * daemon can block enumeration unless that daemon (such as an OBEX, + * MTP, or print server) is ready to handle host requests. + * + * Not all systems support software control of their USB peripheral + * data pullups. + * + * Returns zero on success, else negative errno. + */ +int usb_function_deactivate(struct usb_function *function) +{ + struct usb_composite_dev *cdev = function->config->cdev; + int status = 0; + + if (cdev->deactivations == 0) + status = usb_gadget_disconnect(cdev->gadget); + if (status == 0) + cdev->deactivations++; + + return status; +} + +/** + * usb_function_activate - allow function and gadget enumeration + * @function: function on which usb_function_activate() was called + * + * Reverses effect of usb_function_deactivate(). If no more functions + * are delaying their activation, the gadget driver will respond to + * host enumeration procedures. + * + * Returns zero on success, else negative errno. + */ +int usb_function_activate(struct usb_function *function) +{ + struct usb_composite_dev *cdev = function->config->cdev; + int status = 0; + + if (cdev->deactivations == 0) { + printf("WARNING in %s line %d\n", __FILE__, __LINE__); + status = -EINVAL; + } else { + cdev->deactivations--; + if (cdev->deactivations == 0) + status = usb_gadget_connect(cdev->gadget); + } + + return status; +} + +/** + * usb_interface_id() - allocate an unused interface ID + * @config: configuration associated with the interface + * @function: function handling the interface + * Context: single threaded during gadget setup + * + * usb_interface_id() is called from usb_function.bind() callbacks to + * allocate new interface IDs. The function driver will then store that + * ID in interface, association, CDC union, and other descriptors. It + * will also handle any control requests targetted at that interface, + * particularly changing its altsetting via set_alt(). There may + * also be class-specific or vendor-specific requests to handle. + * + * All interface identifier should be allocated using this routine, to + * ensure that for example different functions don't wrongly assign + * different meanings to the same identifier. Note that since interface + * identifers are configuration-specific, functions used in more than + * one configuration (or more than once in a given configuration) need + * multiple versions of the relevant descriptors. + * + * Returns the interface ID which was allocated; or -ENODEV if no + * more interface IDs can be allocated. + */ +int usb_interface_id(struct usb_configuration *config, + struct usb_function *function) +{ + unsigned id = config->next_interface_id; + + if (id < MAX_CONFIG_INTERFACES) { + config->interface[id] = function; + config->next_interface_id = id + 1; + return id; + } + return -ENODEV; +} + +static int config_buf(struct usb_configuration *config, + enum usb_device_speed speed, void *buf, u8 type) +{ + struct usb_config_descriptor *c = buf; + void *next = buf + USB_DT_CONFIG_SIZE; + int len = USB_BUFSIZ - USB_DT_CONFIG_SIZE; + struct usb_function *f; + int status; + + /* write the config descriptor */ + c = buf; + c->bLength = USB_DT_CONFIG_SIZE; + c->bDescriptorType = type; + + c->bNumInterfaces = config->next_interface_id; + c->bConfigurationValue = config->bConfigurationValue; + c->iConfiguration = config->iConfiguration; + c->bmAttributes = USB_CONFIG_ATT_ONE | config->bmAttributes; + c->bMaxPower = config->bMaxPower ? : (CONFIG_USB_GADGET_VBUS_DRAW / 2); + + /* There may be e.g. OTG descriptors */ + if (config->descriptors) { + status = usb_descriptor_fillbuf(next, len, + config->descriptors); + if (status < 0) + return status; + len -= status; + next += status; + } + + /* add each function's descriptors */ + list_for_each_entry(f, &config->functions, list) { + struct usb_descriptor_header **descriptors; + + if (speed == USB_SPEED_HIGH) + descriptors = f->hs_descriptors; + else + descriptors = f->descriptors; + if (!descriptors) + continue; + status = usb_descriptor_fillbuf(next, len, + (const struct usb_descriptor_header **) descriptors); + if (status < 0) + return status; + len -= status; + next += status; + } + + len = next - buf; + c->wTotalLength = cpu_to_le16(len); + return len; +} + +static int config_desc(struct usb_composite_dev *cdev, unsigned w_value) +{ + struct usb_gadget *gadget = cdev->gadget; + struct usb_configuration *c; + u8 type = w_value >> 8; + enum usb_device_speed speed = USB_SPEED_UNKNOWN; + + if (gadget_is_dualspeed(gadget)) { + int hs = 0; + + if (gadget->speed == USB_SPEED_HIGH) + hs = 1; + if (type == USB_DT_OTHER_SPEED_CONFIG) + hs = !hs; + if (hs) + speed = USB_SPEED_HIGH; + + } + + w_value &= 0xff; + list_for_each_entry(c, &cdev->configs, list) { + if (speed == USB_SPEED_HIGH) { + if (!c->highspeed) + continue; + } else { + if (!c->fullspeed) + continue; + } + if (w_value == 0) + return config_buf(c, speed, cdev->req->buf, type); + w_value--; + } + return -EINVAL; +} + +static int count_configs(struct usb_composite_dev *cdev, unsigned type) +{ + struct usb_gadget *gadget = cdev->gadget; + struct usb_configuration *c; + unsigned count = 0; + int hs = 0; + + if (gadget_is_dualspeed(gadget)) { + if (gadget->speed == USB_SPEED_HIGH) + hs = 1; + if (type == USB_DT_DEVICE_QUALIFIER) + hs = !hs; + } + list_for_each_entry(c, &cdev->configs, list) { + /* ignore configs that won't work at this speed */ + if (hs) { + if (!c->highspeed) + continue; + } else { + if (!c->fullspeed) + continue; + } + count++; + } + return count; +} + +static void device_qual(struct usb_composite_dev *cdev) +{ + struct usb_qualifier_descriptor *qual = cdev->req->buf; + + qual->bLength = sizeof(*qual); + qual->bDescriptorType = USB_DT_DEVICE_QUALIFIER; + /* POLICY: same bcdUSB and device type info at both speeds */ + qual->bcdUSB = cdev->desc.bcdUSB; + qual->bDeviceClass = cdev->desc.bDeviceClass; + qual->bDeviceSubClass = cdev->desc.bDeviceSubClass; + qual->bDeviceProtocol = cdev->desc.bDeviceProtocol; + /* ASSUME same EP0 fifo size at both speeds */ + qual->bMaxPacketSize0 = cdev->desc.bMaxPacketSize0; + qual->bNumConfigurations = count_configs(cdev, USB_DT_DEVICE_QUALIFIER); + qual->bRESERVED = 0; +} + +static void reset_config(struct usb_composite_dev *cdev) +{ + struct usb_function *f; + + debug("%s:\n", __func__); + + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->disable) + f->disable(f); + + bitmap_zero(f->endpoints, 32); + } + cdev->config = NULL; +} + +static int set_config(struct usb_composite_dev *cdev, + const struct usb_ctrlrequest *ctrl, unsigned number) +{ + struct usb_gadget *gadget = cdev->gadget; + struct usb_configuration *c = NULL; + int result = -EINVAL; + unsigned power = gadget_is_otg(gadget) ? 8 : 100; + int tmp; + + if (cdev->config) + reset_config(cdev); + + if (number) { + list_for_each_entry(c, &cdev->configs, list) { + if (c->bConfigurationValue == number) { + result = 0; + break; + } + } + if (result < 0) + goto done; + } else + result = 0; + + debug("%s: %s speed config #%d: %s\n", __func__, + ({ char *speed; + switch (gadget->speed) { + case USB_SPEED_LOW: + speed = "low"; + break; + case USB_SPEED_FULL: + speed = "full"; + break; + case USB_SPEED_HIGH: + speed = "high"; + break; + default: + speed = "?"; + break; + }; + speed; + }), number, c ? c->label : "unconfigured"); + + if (!c) + goto done; + + cdev->config = c; + + /* Initialize all interfaces by setting them to altsetting zero. */ + for (tmp = 0; tmp < MAX_CONFIG_INTERFACES; tmp++) { + struct usb_function *f = c->interface[tmp]; + struct usb_descriptor_header **descriptors; + + if (!f) + break; + + /* + * Record which endpoints are used by the function. This is used + * to dispatch control requests targeted at that endpoint to the + * function's setup callback instead of the current + * configuration's setup callback. + */ + if (gadget->speed == USB_SPEED_HIGH) + descriptors = f->hs_descriptors; + else + descriptors = f->descriptors; + + for (; *descriptors; ++descriptors) { + struct usb_endpoint_descriptor *ep; + int addr; + + if ((*descriptors)->bDescriptorType != USB_DT_ENDPOINT) + continue; + + ep = (struct usb_endpoint_descriptor *)*descriptors; + addr = ((ep->bEndpointAddress & 0x80) >> 3) + | (ep->bEndpointAddress & 0x0f); + __set_bit(addr, f->endpoints); + } + + result = f->set_alt(f, tmp, 0); + if (result < 0) { + debug("interface %d (%s/%p) alt 0 --> %d\n", + tmp, f->name, f, result); + + reset_config(cdev); + goto done; + } + } + + /* when we return, be sure our power usage is valid */ + power = c->bMaxPower ? (2 * c->bMaxPower) : CONFIG_USB_GADGET_VBUS_DRAW; +done: + usb_gadget_vbus_draw(gadget, power); + return result; +} + +/** + * usb_add_config() - add a configuration to a device. + * @cdev: wraps the USB gadget + * @config: the configuration, with bConfigurationValue assigned + * Context: single threaded during gadget setup + * + * One of the main tasks of a composite driver's bind() routine is to + * add each of the configurations it supports, using this routine. + * + * This function returns the value of the configuration's bind(), which + * is zero for success else a negative errno value. Binding configurations + * assigns global resources including string IDs, and per-configuration + * resources such as interface IDs and endpoints. + */ +int usb_add_config(struct usb_composite_dev *cdev, + struct usb_configuration *config) +{ + int status = -EINVAL; + struct usb_configuration *c; + + debug("%s: adding config #%u '%s'/%p\n", __func__, + config->bConfigurationValue, + config->label, config); + + if (!config->bConfigurationValue || !config->bind) + goto done; + + /* Prevent duplicate configuration identifiers */ + list_for_each_entry(c, &cdev->configs, list) { + if (c->bConfigurationValue == config->bConfigurationValue) { + status = -EBUSY; + goto done; + } + } + + config->cdev = cdev; + list_add_tail(&config->list, &cdev->configs); + + INIT_LIST_HEAD(&config->functions); + config->next_interface_id = 0; + + status = config->bind(config); + if (status < 0) { + list_del(&config->list); + config->cdev = NULL; + } else { + unsigned i; + + debug("cfg %d/%p speeds:%s%s\n", + config->bConfigurationValue, config, + config->highspeed ? " high" : "", + config->fullspeed + ? (gadget_is_dualspeed(cdev->gadget) + ? " full" + : " full/low") + : ""); + + for (i = 0; i < MAX_CONFIG_INTERFACES; i++) { + struct usb_function *f = config->interface[i]; + + if (!f) + continue; + debug("%s: interface %d = %s/%p\n", + __func__, i, f->name, f); + } + } + + usb_ep_autoconfig_reset(cdev->gadget); + +done: + if (status) + debug("added config '%s'/%u --> %d\n", config->label, + config->bConfigurationValue, status); + return status; +} + +/* + * We support strings in multiple languages ... string descriptor zero + * says which languages are supported. The typical case will be that + * only one language (probably English) is used, with I18N handled on + * the host side. + */ + +static void collect_langs(struct usb_gadget_strings **sp, __le16 *buf) +{ + const struct usb_gadget_strings *s; + u16 language; + __le16 *tmp; + + while (*sp) { + s = *sp; + language = cpu_to_le16(s->language); + for (tmp = buf; *tmp && tmp < &buf[126]; tmp++) { + if (*tmp == language) + goto repeat; + } + *tmp++ = language; +repeat: + sp++; + } +} + +static int lookup_string( + struct usb_gadget_strings **sp, + void *buf, + u16 language, + int id +) +{ + struct usb_gadget_strings *s; + int value; + + while (*sp) { + s = *sp++; + if (s->language != language) + continue; + value = usb_gadget_get_string(s, id, buf); + if (value > 0) + return value; + } + return -EINVAL; +} + +static int get_string(struct usb_composite_dev *cdev, + void *buf, u16 language, int id) +{ + struct usb_configuration *c; + struct usb_function *f; + int len; + + /* + * Yes, not only is USB's I18N support probably more than most + * folk will ever care about ... also, it's all supported here. + * (Except for UTF8 support for Unicode's "Astral Planes".) + */ + + /* 0 == report all available language codes */ + if (id == 0) { + struct usb_string_descriptor *s = buf; + struct usb_gadget_strings **sp; + + memset(s, 0, 256); + s->bDescriptorType = USB_DT_STRING; + + sp = composite->strings; + if (sp) + collect_langs(sp, s->wData); + + list_for_each_entry(c, &cdev->configs, list) { + sp = c->strings; + if (sp) + collect_langs(sp, s->wData); + + list_for_each_entry(f, &c->functions, list) { + sp = f->strings; + if (sp) + collect_langs(sp, s->wData); + } + } + + for (len = 0; len <= 126 && s->wData[len]; len++) + continue; + if (!len) + return -EINVAL; + + s->bLength = 2 * (len + 1); + return s->bLength; + } + + /* + * Otherwise, look up and return a specified string. String IDs + * are device-scoped, so we look up each string table we're told + * about. These lookups are infrequent; simpler-is-better here. + */ + if (composite->strings) { + len = lookup_string(composite->strings, buf, language, id); + if (len > 0) + return len; + } + list_for_each_entry(c, &cdev->configs, list) { + if (c->strings) { + len = lookup_string(c->strings, buf, language, id); + if (len > 0) + return len; + } + list_for_each_entry(f, &c->functions, list) { + if (!f->strings) + continue; + len = lookup_string(f->strings, buf, language, id); + if (len > 0) + return len; + } + } + return -EINVAL; +} + +/** + * usb_string_id() - allocate an unused string ID + * @cdev: the device whose string descriptor IDs are being allocated + * Context: single threaded during gadget setup + * + * @usb_string_id() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then store that ID in the appropriate descriptors and string table. + * + * All string identifier should be allocated using this, + * @usb_string_ids_tab() or @usb_string_ids_n() routine, to ensure + * that for example different functions don't wrongly assign different + * meanings to the same identifier. + */ +int usb_string_id(struct usb_composite_dev *cdev) +{ + if (cdev->next_string_id < 254) { + /* + * string id 0 is reserved by USB spec for list of + * supported languages + * 255 reserved as well? -- mina86 + */ + cdev->next_string_id++; + return cdev->next_string_id; + } + return -ENODEV; +} + +/** + * usb_string_ids() - allocate unused string IDs in batch + * @cdev: the device whose string descriptor IDs are being allocated + * @str: an array of usb_string objects to assign numbers to + * Context: single threaded during gadget setup + * + * @usb_string_ids() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then copy IDs from the string table to the appropriate descriptors + * and string table for other languages. + * + * All string identifier should be allocated using this, + * @usb_string_id() or @usb_string_ids_n() routine, to ensure that for + * example different functions don't wrongly assign different meanings + * to the same identifier. + */ +int usb_string_ids_tab(struct usb_composite_dev *cdev, struct usb_string *str) +{ + int next = cdev->next_string_id; + + for (; str->s; ++str) { + if (next >= 254) + return -ENODEV; + str->id = ++next; + } + + cdev->next_string_id = next; + + return 0; +} + +/** + * usb_string_ids_n() - allocate unused string IDs in batch + * @c: the device whose string descriptor IDs are being allocated + * @n: number of string IDs to allocate + * Context: single threaded during gadget setup + * + * Returns the first requested ID. This ID and next @n-1 IDs are now + * valid IDs. At least provided that @n is non-zero because if it + * is, returns last requested ID which is now very useful information. + * + * @usb_string_ids_n() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then store that ID in the appropriate descriptors and string table. + * + * All string identifier should be allocated using this, + * @usb_string_id() or @usb_string_ids_n() routine, to ensure that for + * example different functions don't wrongly assign different meanings + * to the same identifier. + */ +int usb_string_ids_n(struct usb_composite_dev *c, unsigned n) +{ + unsigned next = c->next_string_id; + if (n > 254 || (unsigned)next + n > 254) + return -ENODEV; + c->next_string_id += n; + return next + 1; +} + +static void composite_setup_complete(struct usb_ep *ep, struct usb_request *req) +{ + if (req->status || req->actual != req->length) + debug("%s: setup complete --> %d, %d/%d\n", __func__, + req->status, req->actual, req->length); +} + +/* + * The setup() callback implements all the ep0 functionality that's + * not handled lower down, in hardware or the hardware driver(like + * device and endpoint feature flags, and their status). It's all + * housekeeping for the gadget function we're implementing. Most of + * the work is in config and function specific setup. + */ +static int +composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_request *req = cdev->req; + int value = -EOPNOTSUPP; + u16 w_index = le16_to_cpu(ctrl->wIndex); + u8 intf = w_index & 0xFF; + u16 w_value = le16_to_cpu(ctrl->wValue); + u16 w_length = le16_to_cpu(ctrl->wLength); + struct usb_function *f = NULL; + u8 endp; + int standard; + + /* + * partial re-init of the response message; the function or the + * gadget might need to intercept e.g. a control-OUT completion + * when we delegate to it. + */ + req->zero = 0; + req->complete = composite_setup_complete; + req->length = USB_BUFSIZ; + gadget->ep0->driver_data = cdev; + standard = (ctrl->bRequestType & USB_TYPE_MASK) + == USB_TYPE_STANDARD; + if (!standard) + goto unknown; + + switch (ctrl->bRequest) { + + /* we handle all standard USB descriptors */ + case USB_REQ_GET_DESCRIPTOR: + if (ctrl->bRequestType != USB_DIR_IN) + goto unknown; + switch (w_value >> 8) { + + case USB_DT_DEVICE: + cdev->desc.bNumConfigurations = + count_configs(cdev, USB_DT_DEVICE); + value = min(w_length, (u16) sizeof cdev->desc); + memcpy(req->buf, &cdev->desc, value); + break; + case USB_DT_DEVICE_QUALIFIER: + if (!gadget_is_dualspeed(gadget)) + break; + device_qual(cdev); + value = min_t(w_length, + sizeof(struct usb_qualifier_descriptor)); + break; + case USB_DT_OTHER_SPEED_CONFIG: + if (!gadget_is_dualspeed(gadget)) + break; + + case USB_DT_CONFIG: + value = config_desc(cdev, w_value); + if (value >= 0) + value = min(w_length, (u16) value); + break; + case USB_DT_STRING: + value = get_string(cdev, req->buf, + w_index, w_value & 0xff); + if (value >= 0) + value = min(w_length, (u16) value); + break; + default: + goto unknown; + } + break; + + /* any number of configs can work */ + case USB_REQ_SET_CONFIGURATION: + if (ctrl->bRequestType != 0) + goto unknown; + if (gadget_is_otg(gadget)) { + if (gadget->a_hnp_support) + debug("HNP available\n"); + else if (gadget->a_alt_hnp_support) + debug("HNP on another port\n"); + else + debug("HNP inactive\n"); + } + + value = set_config(cdev, ctrl, w_value); + break; + case USB_REQ_GET_CONFIGURATION: + if (ctrl->bRequestType != USB_DIR_IN) + goto unknown; + if (cdev->config) + *(u8 *)req->buf = cdev->config->bConfigurationValue; + else + *(u8 *)req->buf = 0; + value = min(w_length, (u16) 1); + break; + + /* + * function drivers must handle get/set altsetting; if there's + * no get() method, we know only altsetting zero works. + */ + case USB_REQ_SET_INTERFACE: + if (ctrl->bRequestType != USB_RECIP_INTERFACE) + goto unknown; + if (!cdev->config || w_index >= MAX_CONFIG_INTERFACES) + break; + f = cdev->config->interface[intf]; + if (!f) + break; + if (w_value && !f->set_alt) + break; + value = f->set_alt(f, w_index, w_value); + break; + case USB_REQ_GET_INTERFACE: + if (ctrl->bRequestType != (USB_DIR_IN|USB_RECIP_INTERFACE)) + goto unknown; + if (!cdev->config || w_index >= MAX_CONFIG_INTERFACES) + break; + f = cdev->config->interface[intf]; + if (!f) + break; + /* lots of interfaces only need altsetting zero... */ + value = f->get_alt ? f->get_alt(f, w_index) : 0; + if (value < 0) + break; + *((u8 *)req->buf) = value; + value = min(w_length, (u16) 1); + break; + default: +unknown: + debug("non-core control req%02x.%02x v%04x i%04x l%d\n", + ctrl->bRequestType, ctrl->bRequest, + w_value, w_index, w_length); + + /* + * functions always handle their interfaces and endpoints... + * punt other recipients (other, WUSB, ...) to the current + * configuration code. + */ + switch (ctrl->bRequestType & USB_RECIP_MASK) { + case USB_RECIP_INTERFACE: + f = cdev->config->interface[intf]; + break; + + case USB_RECIP_ENDPOINT: + endp = ((w_index & 0x80) >> 3) | (w_index & 0x0f); + list_for_each_entry(f, &cdev->config->functions, list) { + if (test_bit(endp, f->endpoints)) + break; + } + if (&f->list == &cdev->config->functions) + f = NULL; + break; + } + + if (f && f->setup) + value = f->setup(f, ctrl); + else { + struct usb_configuration *c; + + c = cdev->config; + if (c && c->setup) + value = c->setup(c, ctrl); + } + + goto done; + } + + /* respond with data transfer before status phase? */ + if (value >= 0) { + req->length = value; + req->zero = value < w_length; + value = usb_ep_queue(gadget->ep0, req, GFP_ATOMIC); + if (value < 0) { + debug("ep_queue --> %d\n", value); + req->status = 0; + composite_setup_complete(gadget->ep0, req); + } + } + +done: + /* device either stalls (value < 0) or reports success */ + return value; +} + +static void composite_disconnect(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + + if (cdev->config) + reset_config(cdev); + if (composite->disconnect) + composite->disconnect(cdev); +} + +static void composite_unbind(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + + /* + * composite_disconnect() must already have been called + * by the underlying peripheral controller driver! + * so there's no i/o concurrency that could affect the + * state protected by cdev->lock. + */ + BUG_ON(cdev->config); + + while (!list_empty(&cdev->configs)) { + struct usb_configuration *c; + + c = list_first_entry(&cdev->configs, + struct usb_configuration, list); + while (!list_empty(&c->functions)) { + struct usb_function *f; + + f = list_first_entry(&c->functions, + struct usb_function, list); + list_del(&f->list); + if (f->unbind) { + debug("unbind function '%s'/%p\n", + f->name, f); + f->unbind(c, f); + } + } + list_del(&c->list); + if (c->unbind) { + debug("unbind config '%s'/%p\n", c->label, c); + c->unbind(c); + } + } + if (composite->unbind) + composite->unbind(cdev); + + if (cdev->req) { + kfree(cdev->req->buf); + usb_ep_free_request(gadget->ep0, cdev->req); + } + kfree(cdev); + set_gadget_data(gadget, NULL); + + composite = NULL; +} + +static int composite_bind(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev; + int status = -ENOMEM; + + cdev = calloc(sizeof *cdev, 1); + if (!cdev) + return status; + + cdev->gadget = gadget; + set_gadget_data(gadget, cdev); + INIT_LIST_HEAD(&cdev->configs); + + /* preallocate control response and buffer */ + cdev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL); + if (!cdev->req) + goto fail; + cdev->req->buf = kmalloc(USB_BUFSIZ, GFP_KERNEL); + if (!cdev->req->buf) + goto fail; + cdev->req->complete = composite_setup_complete; + gadget->ep0->driver_data = cdev; + + cdev->bufsiz = USB_BUFSIZ; + cdev->driver = composite; + + usb_gadget_set_selfpowered(gadget); + usb_ep_autoconfig_reset(cdev->gadget); + + status = composite->bind(cdev); + if (status < 0) + goto fail; + + cdev->desc = *composite->dev; + cdev->desc.bMaxPacketSize0 = gadget->ep0->maxpacket; + + debug("%s: ready\n", composite->name); + return 0; + +fail: + composite_unbind(gadget); + return status; +} + +static void +composite_suspend(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_function *f; + + debug("%s: suspend\n", __func__); + if (cdev->config) { + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->suspend) + f->suspend(f); + } + } + if (composite->suspend) + composite->suspend(cdev); + + cdev->suspended = 1; +} + +static void +composite_resume(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_function *f; + + debug("%s: resume\n", __func__); + if (composite->resume) + composite->resume(cdev); + if (cdev->config) { + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->resume) + f->resume(f); + } + } + + cdev->suspended = 0; +} + +static struct usb_gadget_driver composite_driver = { + .speed = USB_SPEED_HIGH, + + .bind = composite_bind, + .unbind = composite_unbind, + + .setup = composite_setup, + .disconnect = composite_disconnect, + + .suspend = composite_suspend, + .resume = composite_resume, +}; + +/** + * usb_composite_register() - register a composite driver + * @driver: the driver to register + * Context: single threaded during gadget setup + * + * This function is used to register drivers using the composite driver + * framework. The return value is zero, or a negative errno value. + * Those values normally come from the driver's @bind method, which does + * all the work of setting up the driver to match the hardware. + * + * On successful return, the gadget is ready to respond to requests from + * the host, unless one of its components invokes usb_gadget_disconnect() + * while it was binding. That would usually be done in order to wait for + * some userspace participation. + */ +int usb_composite_register(struct usb_composite_driver *driver) +{ + if (!driver || !driver->dev || !driver->bind || composite) + return -EINVAL; + + if (!driver->name) + driver->name = "composite"; + composite = driver; + + return usb_gadget_register_driver(&composite_driver); +} + +/** + * usb_composite_unregister() - unregister a composite driver + * @driver: the driver to unregister + * + * This function is used to unregister drivers using the composite + * driver framework. + */ +void usb_composite_unregister(struct usb_composite_driver *driver) +{ + if (composite != driver) + return; + usb_gadget_unregister_driver(&composite_driver); +} diff --git a/include/linux/usb/composite.h b/include/linux/usb/composite.h new file mode 100644 index 0000000..53cb095 --- /dev/null +++ b/include/linux/usb/composite.h @@ -0,0 +1,350 @@ +/* + * composite.h -- framework for usb gadgets which are composite devices + * + * Copyright (C) 2006-2008 David Brownell + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef __LINUX_USB_COMPOSITE_H +#define __LINUX_USB_COMPOSITE_H + +/* + * This framework is an optional layer on top of the USB Gadget interface, + * making it easier to build (a) Composite devices, supporting multiple + * functions within any single configuration, and (b) Multi-configuration + * devices, also supporting multiple functions but without necessarily + * having more than one function per configuration. + * + * Example: a device with a single configuration supporting both network + * link and mass storage functions is a composite device. Those functions + * might alternatively be packaged in individual configurations, but in + * the composite model the host can use both functions at the same time. + */ + +#include <common.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <usb/lin_gadget_compat.h> + +struct usb_configuration; + +/** + * struct usb_function - describes one function of a configuration + * @name: For diagnostics, identifies the function. + * @strings: tables of strings, keyed by identifiers assigned during bind() + * and by language IDs provided in control requests + * @descriptors: Table of full (or low) speed descriptors, using interface and + * string identifiers assigned during @bind(). If this pointer is null, + * the function will not be available at full speed (or at low speed). + * @hs_descriptors: Table of high speed descriptors, using interface and + * string identifiers assigned during @bind(). If this pointer is null, + * the function will not be available at high speed. + * @config: assigned when @usb_add_function() is called; this is the + * configuration with which this function is associated. + * @bind: Before the gadget can register, all of its functions bind() to the + * available resources including string and interface identifiers used + * in interface or class descriptors; endpoints; I/O buffers; and so on. + * @unbind: Reverses @bind; called as a side effect of unregistering the + * driver which added this function. + * @set_alt: (REQUIRED) Reconfigures altsettings; function drivers may + * initialize usb_ep.driver data at this time (when it is used). + * Note that setting an interface to its current altsetting resets + * interface state, and that all interfaces have a disabled state. + * @get_alt: Returns the active altsetting. If this is not provided, + * then only altsetting zero is supported. + * @disable: (REQUIRED) Indicates the function should be disabled. Reasons + * include host resetting or reconfiguring the gadget, and disconnection. + * @setup: Used for interface-specific control requests. + * @suspend: Notifies functions when the host stops sending USB traffic. + * @resume: Notifies functions when the host restarts USB traffic. + * + * A single USB function uses one or more interfaces, and should in most + * cases support operation at both full and high speeds. Each function is + * associated by @usb_add_function() with a one configuration; that function + * causes @bind() to be called so resources can be allocated as part of + * setting up a gadget driver. Those resources include endpoints, which + * should be allocated using @usb_ep_autoconfig(). + * + * To support dual speed operation, a function driver provides descriptors + * for both high and full speed operation. Except in rare cases that don't + * involve bulk endpoints, each speed needs different endpoint descriptors. + * + * Function drivers choose their own strategies for managing instance data. + * The simplest strategy just declares it "static', which means the function + * can only be activated once. If the function needs to be exposed in more + * than one configuration at a given speed, it needs to support multiple + * usb_function structures (one for each configuration). + * + * A more complex strategy might encapsulate a @usb_function structure inside + * a driver-specific instance structure to allows multiple activations. An + * example of multiple activations might be a CDC ACM function that supports + * two or more distinct instances within the same configuration, providing + * several independent logical data links to a USB host. + */ +struct usb_function { + const char *name; + struct usb_gadget_strings **strings; + struct usb_descriptor_header **descriptors; + struct usb_descriptor_header **hs_descriptors; + + struct usb_configuration *config; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching. + * Related: unbind() may kfree() but bind() won't... + */ + + /* configuration management: bind/unbind */ + int (*bind)(struct usb_configuration *, + struct usb_function *); + void (*unbind)(struct usb_configuration *, + struct usb_function *); + + /* runtime state management */ + int (*set_alt)(struct usb_function *, + unsigned interface, unsigned alt); + int (*get_alt)(struct usb_function *, + unsigned interface); + void (*disable)(struct usb_function *); + int (*setup)(struct usb_function *, + const struct usb_ctrlrequest *); + void (*suspend)(struct usb_function *); + void (*resume)(struct usb_function *); + + /* private: */ + /* internals */ + struct list_head list; + DECLARE_BITMAP(endpoints, 32); +}; + +int usb_add_function(struct usb_configuration *, struct usb_function *); + +int usb_function_deactivate(struct usb_function *); +int usb_function_activate(struct usb_function *); + +int usb_interface_id(struct usb_configuration *, struct usb_function *); + +/** + * ep_choose - select descriptor endpoint at current device speed + * @g: gadget, connected and running at some speed + * @hs: descriptor to use for high speed operation + * @fs: descriptor to use for full or low speed operation + */ +static inline struct usb_endpoint_descriptor * +ep_choose(struct usb_gadget *g, struct usb_endpoint_descriptor *hs, + struct usb_endpoint_descriptor *fs) +{ + if (gadget_is_dualspeed(g) && g->speed == USB_SPEED_HIGH) + return hs; + return fs; +} + +#define MAX_CONFIG_INTERFACES 16 /* arbitrary; max 255 */ + +/** + * struct usb_configuration - represents one gadget configuration + * @label: For diagnostics, describes the configuration. + * @strings: Tables of strings, keyed by identifiers assigned during @bind() + * and by language IDs provided in control requests. + * @descriptors: Table of descriptors preceding all function descriptors. + * Examples include OTG and vendor-specific descriptors. + * @bind: Called from @usb_add_config() to allocate resources unique to this + * configuration and to call @usb_add_function() for each function used. + * @unbind: Reverses @bind; called as a side effect of unregistering the + * driver which added this configuration. + * @setup: Used to delegate control requests that aren't handled by standard + * device infrastructure or directed at a specific interface. + * @bConfigurationValue: Copied into configuration descriptor. + * @iConfiguration: Copied into configuration descriptor. + * @bmAttributes: Copied into configuration descriptor. + * @bMaxPower: Copied into configuration descriptor. + * @cdev: assigned by @usb_add_config() before calling @bind(); this is + * the device associated with this configuration. + * + * Configurations are building blocks for gadget drivers structured around + * function drivers. Simple USB gadgets require only one function and one + * configuration, and handle dual-speed hardware by always providing the same + * functionality. Slightly more complex gadgets may have more than one + * single-function configuration at a given speed; or have configurations + * that only work at one speed. + * + * Composite devices are, by definition, ones with configurations which + * include more than one function. + * + * The lifecycle of a usb_configuration includes allocation, initialization + * of the fields described above, and calling @usb_add_config() to set up + * internal data and bind it to a specific device. The configuration's + * @bind() method is then used to initialize all the functions and then + * call @usb_add_function() for them. + * + * Those functions would normally be independant of each other, but that's + * not mandatory. CDC WMC devices are an example where functions often + * depend on other functions, with some functions subsidiary to others. + * Such interdependency may be managed in any way, so long as all of the + * descriptors complete by the time the composite driver returns from + * its bind() routine. + */ +struct usb_configuration { + const char *label; + struct usb_gadget_strings **strings; + const struct usb_descriptor_header **descriptors; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching... + */ + + /* configuration management: bind/unbind */ + int (*bind)(struct usb_configuration *); + void (*unbind)(struct usb_configuration *); + int (*setup)(struct usb_configuration *, + const struct usb_ctrlrequest *); + + /* fields in the config descriptor */ + u8 bConfigurationValue; + u8 iConfiguration; + u8 bmAttributes; + u8 bMaxPower; + + struct usb_composite_dev *cdev; + + /* private: */ + /* internals */ + struct list_head list; + struct list_head functions; + u8 next_interface_id; + unsigned highspeed:1; + unsigned fullspeed:1; + struct usb_function *interface[MAX_CONFIG_INTERFACES]; +}; + +int usb_add_config(struct usb_composite_dev *, + struct usb_configuration *); + +/** + * struct usb_composite_driver - groups configurations into a gadget + * @name: For diagnostics, identifies the driver. + * @dev: Template descriptor for the device, including default device + * identifiers. + * @strings: tables of strings, keyed by identifiers assigned during bind() + * and language IDs provided in control requests + * @bind: (REQUIRED) Used to allocate resources that are shared across the + * whole device, such as string IDs, and add its configurations using + * @usb_add_config(). This may fail by returning a negative errno + * value; it should return zero on successful initialization. + * @unbind: Reverses @bind(); called as a side effect of unregistering + * this driver. + * @disconnect: optional driver disconnect method + * @suspend: Notifies when the host stops sending USB traffic, + * after function notifications + * @resume: Notifies configuration when the host restarts USB traffic, + * before function notifications + * + * Devices default to reporting self powered operation. Devices which rely + * on bus powered operation should report this in their @bind() method. + * + * Before returning from @bind, various fields in the template descriptor + * may be overridden. These include the idVendor/idProduct/bcdDevice values + * normally to bind the appropriate host side driver, and the three strings + * (iManufacturer, iProduct, iSerialNumber) normally used to provide user + * meaningful device identifiers. (The strings will not be defined unless + * they are defined in @dev and @strings.) The correct ep0 maxpacket size + * is also reported, as defined by the underlying controller driver. + */ +struct usb_composite_driver { + const char *name; + const struct usb_device_descriptor *dev; + struct usb_gadget_strings **strings; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching... + */ + + int (*bind)(struct usb_composite_dev *); + int (*unbind)(struct usb_composite_dev *); + + void (*disconnect)(struct usb_composite_dev *); + + /* global suspend hooks */ + void (*suspend)(struct usb_composite_dev *); + void (*resume)(struct usb_composite_dev *); +}; + +extern int usb_composite_register(struct usb_composite_driver *); +extern void usb_composite_unregister(struct usb_composite_driver *); + + +/** + * struct usb_composite_device - represents one composite usb gadget + * @gadget: read-only, abstracts the gadget's usb peripheral controller + * @req: used for control responses; buffer is pre-allocated + * @bufsiz: size of buffer pre-allocated in @req + * @config: the currently active configuration + * + * One of these devices is allocated and initialized before the + * associated device driver's bind() is called. + * + * OPEN ISSUE: it appears that some WUSB devices will need to be + * built by combining a normal (wired) gadget with a wireless one. + * This revision of the gadget framework should probably try to make + * sure doing that won't hurt too much. + * + * One notion for how to handle Wireless USB devices involves: + * (a) a second gadget here, discovery mechanism TBD, but likely + * needing separate "register/unregister WUSB gadget" calls; + * (b) updates to usb_gadget to include flags "is it wireless", + * "is it wired", plus (presumably in a wrapper structure) + * bandgroup and PHY info; + * (c) presumably a wireless_ep wrapping a usb_ep, and reporting + * wireless-specific parameters like maxburst and maxsequence; + * (d) configurations that are specific to wireless links; + * (e) function drivers that understand wireless configs and will + * support wireless for (additional) function instances; + * (f) a function to support association setup (like CBAF), not + * necessarily requiring a wireless adapter; + * (g) composite device setup that can create one or more wireless + * configs, including appropriate association setup support; + * (h) more, TBD. + */ +struct usb_composite_dev { + struct usb_gadget *gadget; + struct usb_request *req; + unsigned bufsiz; + + struct usb_configuration *config; + + /* private: */ + /* internals */ + unsigned int suspended:1; + struct usb_device_descriptor desc; + struct list_head configs; + struct usb_composite_driver *driver; + u8 next_string_id; + + /* the gadget driver won't enable the data pullup + * while the deactivation count is nonzero. + */ + unsigned deactivations; +}; + +extern int usb_string_id(struct usb_composite_dev *c); +extern int usb_string_ids_tab(struct usb_composite_dev *c, + struct usb_string *str); +extern int usb_string_ids_n(struct usb_composite_dev *c, unsigned n); + +#endif /* __LINUX_USB_COMPOSITE_H */ diff --git a/include/usb/lin_gadget_compat.h b/include/usb/lin_gadget_compat.h index fce3be7..01c576a 100644 --- a/include/usb/lin_gadget_compat.h +++ b/include/usb/lin_gadget_compat.h @@ -36,8 +36,8 @@ #define mutex_lock(...) #define mutex_unlock(...)
@@ -56,6 +57,26 @@
USB Composite gadget implementation for u-boot. It builds on top of USB UDC drivers.
This commit is based on following files from Linux Kernel v2.6.36:
SHA1: d187abb9a83e6c6b6e9f2ca17962bdeafb4bc903
Changes for v2:
Changes for v3:
drivers/usb/gadget/composite.c | 1091 +++++++++++++++++++++++++++++++++++++++ include/linux/usb/composite.h | 350 +++++++++++++ include/usb/lin_gadget_compat.h | 25 +- 3 files changed, 1464 insertions(+), 2 deletions(-) create mode 100644 drivers/usb/gadget/composite.c create mode 100644 include/linux/usb/composite.h
- composite.c - infrastructure for Composite USB Gadgets
- Copyright (C) 2006-2008 David Brownell
- U-boot porting: Lukasz Majewski l.majewski@samsung.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307
- usb_add_function() - add a function to a configuration
- @config: the configuration
- @function: the function being added
- Context: single threaded during gadget setup
- After initialization, each configuration must have one or more
- functions added to it. Adding a function involves calling its @bind()
- method to allocate resources such as interface and string identifiers
- and endpoints.
- This function returns the value of the function's bind(), which is
- zero for success else a negative errno value.
- int value = -EINVAL;
- debug("adding '%s'/%p to config '%s'/%p\n",
- if (!function->set_alt || !function->disable)
goto done;
- function->config = config;
- list_add_tail(&function->list, &config->functions);
- if (function->bind) {
if (value < 0) {
- } else
value = 0;
- if (!config->fullspeed && function->descriptors)
- if (!config->highspeed && function->hs_descriptors)
+done:
- if (value)
- return value;
- usb_function_deactivate - prevent function and gadget enumeration
- @function: the function that isn't yet ready to respond
- Blocks response of the gadget driver to host enumeration by
- preventing the data line pullup from being activated. This is
- normally called during @bind() processing to change from the
- initial "ready to respond" state, or when a required resource
- becomes available.
- For example, drivers that serve as a passthrough to a userspace
- daemon can block enumeration unless that daemon (such as an OBEX,
- MTP, or print server) is ready to handle host requests.
- Not all systems support software control of their USB peripheral
- data pullups.
- Returns zero on success, else negative errno.
- struct usb_composite_dev *cdev = function->config->cdev;
- int status = 0;
- if (cdev->deactivations == 0)
- if (status == 0)
- return status;
- usb_function_activate - allow function and gadget enumeration
- @function: function on which usb_function_activate() was called
- Reverses effect of usb_function_deactivate(). If no more functions
- are delaying their activation, the gadget driver will respond to
- host enumeration procedures.
- int status = 0;
- if (cdev->deactivations == 0) {
This should be certainly more descriptive ;-)
status = -EINVAL;
- } else {
- return status;
- usb_interface_id() - allocate an unused interface ID
- @config: configuration associated with the interface
- @function: function handling the interface
- usb_interface_id() is called from usb_function.bind() callbacks to
- allocate new interface IDs. The function driver will then store that
- ID in interface, association, CDC union, and other descriptors. It
- will also handle any control requests targetted at that interface,
- particularly changing its altsetting via set_alt(). There may
- also be class-specific or vendor-specific requests to handle.
- All interface identifier should be allocated using this routine, to
- ensure that for example different functions don't wrongly assign
- different meanings to the same identifier. Note that since interface
- identifers are configuration-specific, functions used in more than
- one configuration (or more than once in a given configuration) need
- multiple versions of the relevant descriptors.
- Returns the interface ID which was allocated; or -ENODEV if no
- more interface IDs can be allocated.
- unsigned id = config->next_interface_id;
- if (id < MAX_CONFIG_INTERFACES) {
return id;
- return -ENODEV;
- struct usb_config_descriptor *c = buf;
- void *next = buf + USB_DT_CONFIG_SIZE;
- int len = USB_BUFSIZ - USB_DT_CONFIG_SIZE;
- int status;
- /* write the config descriptor */
- c = buf;
- c->bLength = USB_DT_CONFIG_SIZE;
- c->bDescriptorType = type;
- c->bNumInterfaces = config->next_interface_id;
- c->bConfigurationValue = config->bConfigurationValue;
- c->iConfiguration = config->iConfiguration;
- c->bmAttributes = USB_CONFIG_ATT_ONE | config->bmAttributes;
- c->bMaxPower = config->bMaxPower ? : (CONFIG_USB_GADGET_VBUS_DRAW / 2);
- /* There may be e.g. OTG descriptors */
- if (config->descriptors) {
if (status < 0)
return status;
len -= status;
next += status;
- /* add each function's descriptors */
- list_for_each_entry(f, &config->functions, list) {
Please define all variables at the begining.
else
if (!descriptors)
continue;
if (status < 0)
return status;
len -= status;
next += status;
- len = next - buf;
- c->wTotalLength = cpu_to_le16(len);
- return len;
- struct usb_gadget *gadget = cdev->gadget;
- struct usb_configuration *c;
- u8 type = w_value >> 8;
- enum usb_device_speed speed = USB_SPEED_UNKNOWN;
- if (gadget_is_dualspeed(gadget)) {
int hs = 0;
hs = 1;
hs = !hs;
if (hs)
- w_value &= 0xff;
- list_for_each_entry(c, &cdev->configs, list) {
if (!c->highspeed)
continue;
} else {
if (!c->fullspeed)
continue;
if (w_value == 0)
w_value--;
- return -EINVAL;
- unsigned count = 0;
- int hs = 0;
hs = 1;
hs = !hs;
if (hs) {
if (!c->highspeed)
continue;
} else {
if (!c->fullspeed)
continue;
count++;
- return count;
- struct usb_qualifier_descriptor *qual = cdev->req->buf;
- qual->bLength = sizeof(*qual);
- qual->bDescriptorType = USB_DT_DEVICE_QUALIFIER;
- /* POLICY: same bcdUSB and device type info at both speeds */
- qual->bcdUSB = cdev->desc.bcdUSB;
- qual->bDeviceClass = cdev->desc.bDeviceClass;
- qual->bDeviceSubClass = cdev->desc.bDeviceSubClass;
- qual->bDeviceProtocol = cdev->desc.bDeviceProtocol;
- /* ASSUME same EP0 fifo size at both speeds */
- qual->bMaxPacketSize0 = cdev->desc.bMaxPacketSize0;
- qual->bNumConfigurations = count_configs(cdev, USB_DT_DEVICE_QUALIFIER);
- qual->bRESERVED = 0;
- debug("%s:\n", __func__);
- list_for_each_entry(f, &cdev->config->functions, list) {
if (f->disable)
f->disable(f);
- cdev->config = NULL;
- struct usb_configuration *c = NULL;
- int result = -EINVAL;
- unsigned power = gadget_is_otg(gadget) ? 8 : 100;
- int tmp;
- if (cdev->config)
reset_config(cdev);
- if (number) {
result = 0;
break;
if (result < 0)
goto done;
- } else
result = 0;
- debug("%s: %s speed config #%d: %s\n", __func__,
({ char *speed;
case USB_SPEED_LOW:
speed = "low";
break;
speed = "full";
break;
speed = "high";
break;
default:
speed = "?";
break;
speed;
- if (!c)
goto done;
- cdev->config = c;
- /* Initialize all interfaces by setting them to altsetting zero. */
- for (tmp = 0; tmp < MAX_CONFIG_INTERFACES; tmp++) {
if (!f)
break;
else
int addr;
continue;
if (result < 0) {
reset_config(cdev);
goto done;
- /* when we return, be sure our power usage is valid */
- power = c->bMaxPower ? (2 * c->bMaxPower) : CONFIG_USB_GADGET_VBUS_DRAW;
+done:
- usb_gadget_vbus_draw(gadget, power);
- return result;
- usb_add_config() - add a configuration to a device.
- @cdev: wraps the USB gadget
- @config: the configuration, with bConfigurationValue assigned
- One of the main tasks of a composite driver's bind() routine is to
- add each of the configurations it supports, using this routine.
- This function returns the value of the configuration's bind(), which
- is zero for success else a negative errno value. Binding
- int status = -EINVAL;
- debug("%s: adding config #%u '%s'/%p\n", __func__,
- if (!config->bConfigurationValue || !config->bind)
goto done;
- /* Prevent duplicate configuration identifiers */
status = -EBUSY;
goto done;
- config->cdev = cdev;
- list_add_tail(&config->list, &cdev->configs);
- INIT_LIST_HEAD(&config->functions);
- config->next_interface_id = 0;
- status = config->bind(config);
- if (status < 0) {
- } else {
unsigned i;
config->fullspeed
? " full"
: " full/low")
if (!f)
continue;
+done:
- if (status)
- return status;
- We support strings in multiple languages ... string descriptor zero
- says which languages are supported. The typical case will be that
- only one language (probably English) is used, with I18N handled on
- the host side.
- const struct usb_gadget_strings *s;
- u16 language;
- __le16 *tmp;
- while (*sp) {
s = *sp;
goto repeat;
*tmp++ = language;
+repeat:
sp++;
- struct usb_gadget_strings **sp,
- void *buf,
- u16 language,
- int id
- struct usb_gadget_strings *s;
- int value;
- while (*sp) {
s = *sp++;
continue;
if (value > 0)
return value;
- return -EINVAL;
- int len;
- /* 0 == report all available language codes */
- if (id == 0) {
memset(s, 0, 256);
if (sp)
sp = c->strings;
if (sp)
sp = f->strings;
if (sp)
continue;
if (!len)
return -EINVAL;
return s->bLength;
- if (composite->strings) {
if (len > 0)
return len;
if (c->strings) {
if (len > 0)
return len;
if (!f->strings)
continue;
if (len > 0)
return len;
- return -EINVAL;
- usb_string_id() - allocate an unused string ID
- @cdev: the device whose string descriptor IDs are being allocated
- @usb_string_id() is called from bind() callbacks to allocate
- string IDs. Drivers for functions, configurations, or gadgets will
- then store that ID in the appropriate descriptors and string table.
- All string identifier should be allocated using this,
- @usb_string_ids_tab() or @usb_string_ids_n() routine, to ensure
- that for example different functions don't wrongly assign different
- meanings to the same identifier.
- if (cdev->next_string_id < 254) {
- return -ENODEV;
- usb_string_ids() - allocate unused string IDs in batch
- @str: an array of usb_string objects to assign numbers to
- @usb_string_ids() is called from bind() callbacks to allocate
- then copy IDs from the string table to the appropriate descriptors
- and string table for other languages.
- @usb_string_id() or @usb_string_ids_n() routine, to ensure that for
- example different functions don't wrongly assign different meanings
- to the same identifier.
- int next = cdev->next_string_id;
- for (; str->s; ++str) {
if (next >= 254)
return -ENODEV;
str->id = ++next;
- cdev->next_string_id = next;
- usb_string_ids_n() - allocate unused string IDs in batch
- @c: the device whose string descriptor IDs are being allocated
- @n: number of string IDs to allocate
- Returns the first requested ID. This ID and next @n-1 IDs are now
- valid IDs. At least provided that @n is non-zero because if it
- is, returns last requested ID which is now very useful information.
- @usb_string_ids_n() is called from bind() callbacks to allocate
- unsigned next = c->next_string_id;
- if (n > 254 || (unsigned)next + n > 254)
Why the cast here? Fix also in linux?
return -ENODEV;
- c->next_string_id += n;
- return next + 1;
- if (req->status || req->actual != req->length)
- The setup() callback implements all the ep0 functionality that's
- not handled lower down, in hardware or the hardware driver(like
- device and endpoint feature flags, and their status). It's all
- housekeeping for the gadget function we're implementing. Most of
- the work is in config and function specific setup.
- struct usb_composite_dev *cdev = get_gadget_data(gadget);
- struct usb_request *req = cdev->req;
- int value = -EOPNOTSUPP;
- u16 w_index = le16_to_cpu(ctrl->wIndex);
- u8 intf = w_index & 0xFF;
- u16 w_value = le16_to_cpu(ctrl->wValue);
- u16 w_length = le16_to_cpu(ctrl->wLength);
- struct usb_function *f = NULL;
- u8 endp;
- int standard;
- req->zero = 0;
- req->complete = composite_setup_complete;
- req->length = USB_BUFSIZ;
- gadget->ep0->driver_data = cdev;
- standard = (ctrl->bRequestType & USB_TYPE_MASK)
- if (!standard)
goto unknown;
- switch (ctrl->bRequest) {
- /* we handle all standard USB descriptors */
- case USB_REQ_GET_DESCRIPTOR:
goto unknown;
case USB_DT_DEVICE:
break;
break;
device_qual(cdev);
break;
break;
case USB_DT_CONFIG:
if (value >= 0)
break;
case USB_DT_STRING:
if (value >= 0)
break;
default:
goto unknown;
break;
- /* any number of configs can work */
- case USB_REQ_SET_CONFIGURATION:
goto unknown;
else
break;
- case USB_REQ_GET_CONFIGURATION:
goto unknown;
if (cdev->config)
else
break;
- case USB_REQ_SET_INTERFACE:
goto unknown;
break;
if (!f)
break;
break;
break;
- case USB_REQ_GET_INTERFACE:
goto unknown;
break;
if (!f)
break;
if (value < 0)
break;
break;
- default:
+unknown:
break;
break;
f = NULL;
break;
if (f && f->setup)
else {
c = cdev->config;
if (c && c->setup)
goto done;
- /* respond with data transfer before status phase? */
- if (value >= 0) {
GFP_ATOMIC? In U-Boot?
if (value < 0) {
req->status = 0;
+done:
- /* device either stalls (value < 0) or reports success */
- return value;
- if (cdev->config)
reset_config(cdev);
- if (composite->disconnect)
- BUG_ON(cdev->config);
- while (!list_empty(&cdev->configs)) {
list_del(&f->list);
if (f->unbind) {
f->name, f);
f->unbind(c, f);
list_del(&c->list);
if (c->unbind) {
c->unbind(c);
- if (composite->unbind)
- if (cdev->req) {
- kfree(cdev);
- set_gadget_data(gadget, NULL);
- composite = NULL;
- struct usb_composite_dev *cdev;
- int status = -ENOMEM;
- cdev = calloc(sizeof *cdev, 1);
- if (!cdev)
return status;
- cdev->gadget = gadget;
- set_gadget_data(gadget, cdev);
- INIT_LIST_HEAD(&cdev->configs);
- /* preallocate control response and buffer */
- cdev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL);
- if (!cdev->req)
goto fail;
- cdev->req->buf = kmalloc(USB_BUFSIZ, GFP_KERNEL);
- if (!cdev->req->buf)
goto fail;
- cdev->req->complete = composite_setup_complete;
- cdev->bufsiz = USB_BUFSIZ;
- cdev->driver = composite;
- usb_gadget_set_selfpowered(gadget);
- usb_ep_autoconfig_reset(cdev->gadget);
- status = composite->bind(cdev);
- if (status < 0)
goto fail;
- cdev->desc = *composite->dev;
- cdev->desc.bMaxPacketSize0 = gadget->ep0->maxpacket;
- debug("%s: ready\n", composite->name);
+fail:
- composite_unbind(gadget);
- return status;
- struct usb_function *f;
- debug("%s: suspend\n", __func__);
- if (cdev->config) {
if (f->suspend)
f->suspend(f);
- if (composite->suspend)
- cdev->suspended = 1;
- debug("%s: resume\n", __func__);
- if (composite->resume)
if (f->resume)
f->resume(f);
- cdev->suspended = 0;
- .speed = USB_SPEED_HIGH,
- .bind = composite_bind,
- .unbind = composite_unbind,
- .setup = composite_setup,
- .disconnect = composite_disconnect,
- .suspend = composite_suspend,
- .resume = composite_resume,
- usb_composite_register() - register a composite driver
- @driver: the driver to register
- This function is used to register drivers using the composite driver
- framework. The return value is zero, or a negative errno value.
- Those values normally come from the driver's @bind method, which does
- all the work of setting up the driver to match the hardware.
- On successful return, the gadget is ready to respond to requests from
- the host, unless one of its components invokes usb_gadget_disconnect()
- while it was binding. That would usually be done in order to wait for
- some userspace participation.
- if (!driver || !driver->dev || !driver->bind || composite)
return -EINVAL;
- if (!driver->name)
- composite = driver;
- return usb_gadget_register_driver(&composite_driver);
- usb_composite_unregister() - unregister a composite driver
- @driver: the driver to unregister
- This function is used to unregister drivers using the composite
- driver framework.
- if (composite != driver)
return;
- usb_gadget_unregister_driver(&composite_driver);
- composite.h -- framework for usb gadgets which are composite devices
- Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301
USA + */
- This framework is an optional layer on top of the USB Gadget interface,
- making it easier to build (a) Composite devices, supporting multiple
- functions within any single configuration, and (b) Multi-configuration
- devices, also supporting multiple functions but without necessarily
- having more than one function per configuration.
- Example: a device with a single configuration supporting both network
- link and mass storage functions is a composite device. Those functions
- might alternatively be packaged in individual configurations, but in
- the composite model the host can use both functions at the same time.
- struct usb_function - describes one function of a configuration
- @name: For diagnostics, identifies the function.
- @strings: tables of strings, keyed by identifiers assigned during
- @descriptors: Table of full (or low) speed descriptors, using interface
- @config: assigned when @usb_add_function() is called; this is the
- configuration with which this function is associated.
- @bind: Before the gadget can register, all of its functions bind() to
so
- @set_alt: (REQUIRED) Reconfigures altsettings; function drivers may
- initialize usb_ep.driver data at this time (when it is used).
- Note that setting an interface to its current altsetting resets
- interface state, and that all interfaces have a disabled state.
- @get_alt: Returns the active altsetting. If this is not provided,
- then only altsetting zero is supported.
- @disable: (REQUIRED) Indicates the function should be disabled.
- @suspend: Notifies functions when the host stops sending USB traffic.
- @resume: Notifies functions when the host restarts USB traffic.
- A single USB function uses one or more interfaces, and should in most
- cases support operation at both full and high speeds. Each function is
- associated by @usb_add_function() with a one configuration; that
- To support dual speed operation, a function driver provides descriptors
- for both high and full speed operation. Except in rare cases that
- Function drivers choose their own strategies for managing instance
- A more complex strategy might encapsulate a @usb_function structure
- const char *name;
- struct usb_gadget_strings **strings;
- struct usb_descriptor_header **descriptors;
- struct usb_descriptor_header **hs_descriptors;
- struct usb_configuration *config;
- /* REVISIT: bind() functions can be marked __init, which
- /* configuration management: bind/unbind */
- int (*bind)(struct usb_configuration *,
- void (*unbind)(struct usb_configuration *,
- /* runtime state management */
- int (*set_alt)(struct usb_function *,
- int (*get_alt)(struct usb_function *,
- void (*disable)(struct usb_function *);
- int (*setup)(struct usb_function *,
- void (*suspend)(struct usb_function *);
- void (*resume)(struct usb_function *);
- /* private: */
- /* internals */
- struct list_head list;
- DECLARE_BITMAP(endpoints, 32);
- ep_choose - select descriptor endpoint at current device speed
- @g: gadget, connected and running at some speed
- @hs: descriptor to use for high speed operation
- @fs: descriptor to use for full or low speed operation
- if (gadget_is_dualspeed(g) && g->speed == USB_SPEED_HIGH)
return hs;
- return fs;
- struct usb_configuration - represents one gadget configuration
- @label: For diagnostics, describes the configuration.
- @strings: Tables of strings, keyed by identifiers assigned during
- @descriptors: Table of descriptors preceding all function descriptors.
- Examples include OTG and vendor-specific descriptors.
- @bind: Called from @usb_add_config() to allocate resources unique to
- @setup: Used to delegate control requests that aren't handled by
- @bConfigurationValue: Copied into configuration descriptor.
- @iConfiguration: Copied into configuration descriptor.
- @bmAttributes: Copied into configuration descriptor.
- @bMaxPower: Copied into configuration descriptor.
- @cdev: assigned by @usb_add_config() before calling @bind(); this is
- the device associated with this configuration.
- Configurations are building blocks for gadget drivers structured around
- function drivers. Simple USB gadgets require only one function and one
- configuration, and handle dual-speed hardware by always providing the
- Composite devices are, by definition, ones with configurations which
- include more than one function.
- The lifecycle of a usb_configuration includes allocation,
- Those functions would normally be independant of each other, but that's
- not mandatory. CDC WMC devices are an example where functions often
- depend on other functions, with some functions subsidiary to others.
- Such interdependency may be managed in any way, so long as all of the
- descriptors complete by the time the composite driver returns from
- its bind() routine.
- const char *label;
- const struct usb_descriptor_header **descriptors;
- int (*bind)(struct usb_configuration *);
- void (*unbind)(struct usb_configuration *);
- int (*setup)(struct usb_configuration *,
- /* fields in the config descriptor */
- u8 bConfigurationValue;
- u8 iConfiguration;
- u8 bmAttributes;
- u8 bMaxPower;
- /* private: */
- /* internals */
- struct list_head functions;
- u8 next_interface_id;
- unsigned highspeed:1;
- unsigned fullspeed:1;
- struct usb_function *interface[MAX_CONFIG_INTERFACES];
- struct usb_composite_driver - groups configurations into a gadget
- @name: For diagnostics, identifies the driver.
- @dev: Template descriptor for the device, including default device
- identifiers.
- @bind: (REQUIRED) Used to allocate resources that are shared across the
- whole device, such as string IDs, and add its configurations using
- @usb_add_config(). This may fail by returning a negative errno
- value; it should return zero on successful initialization.
- @unbind: Reverses @bind(); called as a side effect of unregistering
- this driver.
- @disconnect: optional driver disconnect method
- @suspend: Notifies when the host stops sending USB traffic,
- after function notifications
- @resume: Notifies configuration when the host restarts USB traffic,
- before function notifications
- Devices default to reporting self powered operation. Devices which
- Before returning from @bind, various fields in the template descriptor
- may be overridden. These include the idVendor/idProduct/bcdDevice
- const char *name;
- const struct usb_device_descriptor *dev;
- int (*bind)(struct usb_composite_dev *);
- int (*unbind)(struct usb_composite_dev *);
- void (*disconnect)(struct usb_composite_dev *);
- /* global suspend hooks */
- void (*suspend)(struct usb_composite_dev *);
- void (*resume)(struct usb_composite_dev *);
- struct usb_composite_device - represents one composite usb gadget
- @gadget: read-only, abstracts the gadget's usb peripheral controller
- @req: used for control responses; buffer is pre-allocated
- @bufsiz: size of buffer pre-allocated in @req
- @config: the currently active configuration
- One of these devices is allocated and initialized before the
- associated device driver's bind() is called.
- OPEN ISSUE: it appears that some WUSB devices will need to be
- built by combining a normal (wired) gadget with a wireless one.
- This revision of the gadget framework should probably try to make
- sure doing that won't hurt too much.
- One notion for how to handle Wireless USB devices involves:
- (a) a second gadget here, discovery mechanism TBD, but likely
- (b) updates to usb_gadget to include flags "is it wireless",
- (c) presumably a wireless_ep wrapping a usb_ep, and reporting
- (d) configurations that are specific to wireless links;
- (e) function drivers that understand wireless configs and will
- (f) a function to support association setup (like CBAF), not
- (g) composite device setup that can create one or more wireless
- (h) more, TBD.
- struct usb_gadget *gadget;
- struct usb_request *req;
- unsigned bufsiz;
- /* private: */
- /* internals */
- unsigned int suspended:1;
- struct usb_device_descriptor desc;
- struct list_head configs;
- struct usb_composite_driver *driver;
- u8 next_string_id;
- /* the gadget driver won't enable the data pullup
- unsigned deactivations;
-#define WARN_ON(x) if (x) {printf("WARNING in %s line %d\n" \
, __FILE__, __LINE__); }
+#define WARN_ON(x) do { if (x) printf("WARNING in %s line %d\n" \
, __FILE__, __LINE__); } while (0)
#define KERN_WARNING #define KERN_ERR @@ -45,6 +45,7 @@ #define KERN_DEBUG
#define GFP_KERNEL 0 +#define GFP_ATOMIC 0
#define IRQ_HANDLED 1
@@ -56,6 +57,26 @@
#define __iomem #define min_t min
+#define BITS_PER_BYTE 8 +#define BITS_TO_LONGS(nr) \
- DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long))
+#define DECLARE_BITMAP(name, bits) \
- unsigned long name[BITS_TO_LONGS(bits)]
+#define small_const_nbits(nbits) \
- (__builtin_constant_p(nbits) && (nbits) <= BITS_PER_LONG)
+static inline void bitmap_zero(unsigned long *dst, int nbits) +{
- if (small_const_nbits(nbits))
*dst = 0UL;
- else {
int len = BITS_TO_LONGS(nbits) * sizeof(unsigned long);
memset(dst, 0, len);
#define dma_cache_maint(addr, size, mode) cache_flush() void cache_flush(void);
Add device data pointer to the USB gadget's device struct. Wrapper for extracting usb_gadget from Linux's usb device
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Marek Vasut marex@denx.de
--- Changes for v2: - Two separate patches regarding gadget.h file squashed together --- include/linux/usb/gadget.h | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 275cb5f..eba865e 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -411,6 +411,7 @@ struct usb_gadget_ops {
struct device { void *driver_data; /* data private to the driver */ + void *device_data; /* data private to the device */ };
/** @@ -481,6 +482,11 @@ static inline void *get_gadget_data(struct usb_gadget *gadget) return gadget->dev.driver_data; }
+static inline struct usb_gadget *dev_to_usb_gadget(struct device *dev) +{ + return container_of(dev, struct usb_gadget, dev); +} + /* iterates the non-control endpoints; 'tmp' is a struct usb_ep pointer */ #define gadget_for_each_ep(tmp, gadget) \ list_for_each_entry(tmp, &(gadget)->ep_list, ep_list)
This commit adds support for storing private data to Samsung's UDC driver. This data is afterward used by usb gadget.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/usb/gadget/s3c_udc_otg.c | 12 ++++++++++++ 1 files changed, 12 insertions(+), 0 deletions(-)
diff --git a/drivers/usb/gadget/s3c_udc_otg.c b/drivers/usb/gadget/s3c_udc_otg.c index f7f7b54..925d2f2 100644 --- a/drivers/usb/gadget/s3c_udc_otg.c +++ b/drivers/usb/gadget/s3c_udc_otg.c @@ -133,6 +133,18 @@ static void nuke(struct s3c_ep *ep, int status); static int s3c_udc_set_halt(struct usb_ep *_ep, int value); static void s3c_udc_set_nak(struct s3c_ep *ep);
+void set_udc_gadget_private_data(void *p) +{ + DEBUG_SETUP("%s: the_controller: 0x%p, p: 0x%p\n", __func__, + the_controller, p); + the_controller->gadget.dev.device_data = p; +} + +void *get_udc_gadget_private_data(struct usb_gadget *gadget) +{ + return gadget->dev.device_data; +} + static struct usb_ep_ops s3c_ep_ops = { .enable = s3c_ep_enable, .disable = s3c_ep_disable,
This patch set provides support for composite gadget framework. Files from Linux kernel (2.6.36) - namely composite.{c|h} have been ported to u-boot.
Code supporting this framework has been added to gadget.h and Samsung's UDC driver as well.
--- Changes for v2: - Squash the kernel files with u-boot compatibility layer. - Removal of dead/kernel specific code. - Comments corrected according to u-boot coding style. - Two separate patches regarding gadget.h file squashed together. Changes for v3: - Remove unlikely function call - Code indentation fixup Changes for v4: - Move variables definition to function beginning - CaMeL case declaration fixed
Lukasz Majewski (3): usb:gadget:composite USB composite gadget support usb:gadget:composite: Support for composite at gadget.h usb:udc:samsung Add functions for storing private gadget data in UDC driver
drivers/usb/gadget/composite.c | 1082 ++++++++++++++++++++++++++++++++++++++ drivers/usb/gadget/s3c_udc_otg.c | 12 + include/linux/usb/composite.h | 350 ++++++++++++ include/linux/usb/gadget.h | 6 + include/usb/lin_gadget_compat.h | 24 +- 5 files changed, 1472 insertions(+), 2 deletions(-) create mode 100644 drivers/usb/gadget/composite.c create mode 100644 include/linux/usb/composite.h
./include/linux/usb/composite.h ./drivers/usb/gadget/composite.c
--- drivers/usb/gadget/composite.c | 1082 +++++++++++++++++++++++++++++++++++++++ include/linux/usb/composite.h | 350 +++++++++++++ include/usb/lin_gadget_compat.h | 24 +- 3 files changed, 1454 insertions(+), 2 deletions(-) create mode 100644 drivers/usb/gadget/composite.c create mode 100644 include/linux/usb/composite.h
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c new file mode 100644 index 0000000..905077d --- /dev/null +++ b/drivers/usb/gadget/composite.c @@ -0,0 +1,1082 @@ +/* + * composite.c - infrastructure for Composite USB Gadgets + * + * Copyright (C) 2006-2008 David Brownell + * U-boot porting: Lukasz Majewski l.majewski@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ +#undef DEBUG + +#include <linux/bitops.h> +#include <linux/usb/composite.h> + +#define USB_BUFSIZ 4096 + +static struct usb_composite_driver *composite; + +/** + * usb_add_function() - add a function to a configuration + * @config: the configuration + * @function: the function being added + * Context: single threaded during gadget setup + * + * After initialization, each configuration must have one or more + * functions added to it. Adding a function involves calling its @bind() + * method to allocate resources such as interface and string identifiers + * and endpoints. + * + * This function returns the value of the function's bind(), which is + * zero for success else a negative errno value. + */ +int usb_add_function(struct usb_configuration *config, + struct usb_function *function) +{ + int value = -EINVAL; + + debug("adding '%s'/%p to config '%s'/%p\n", + function->name, function, + config->label, config); + + if (!function->set_alt || !function->disable) + goto done; + + function->config = config; + list_add_tail(&function->list, &config->functions); + + if (function->bind) { + value = function->bind(config, function); + if (value < 0) { + list_del(&function->list); + function->config = NULL; + } + } else + value = 0; + + if (!config->fullspeed && function->descriptors) + config->fullspeed = 1; + if (!config->highspeed && function->hs_descriptors) + config->highspeed = 1; + +done: + if (value) + debug("adding '%s'/%p --> %d\n", + function->name, function, value); + return value; +} + +/** + * usb_function_deactivate - prevent function and gadget enumeration + * @function: the function that isn't yet ready to respond + * + * Blocks response of the gadget driver to host enumeration by + * preventing the data line pullup from being activated. This is + * normally called during @bind() processing to change from the + * initial "ready to respond" state, or when a required resource + * becomes available. + * + * For example, drivers that serve as a passthrough to a userspace + * daemon can block enumeration unless that daemon (such as an OBEX, + * MTP, or print server) is ready to handle host requests. + * + * Not all systems support software control of their USB peripheral + * data pullups. + * + * Returns zero on success, else negative errno. + */ +int usb_function_deactivate(struct usb_function *function) +{ + struct usb_composite_dev *cdev = function->config->cdev; + int status = 0; + + if (cdev->deactivations == 0) + status = usb_gadget_disconnect(cdev->gadget); + if (status == 0) + cdev->deactivations++; + + return status; +} + +/** + * usb_function_activate - allow function and gadget enumeration + * @function: function on which usb_function_activate() was called + * + * Reverses effect of usb_function_deactivate(). If no more functions + * are delaying their activation, the gadget driver will respond to + * host enumeration procedures. + * + * Returns zero on success, else negative errno. + */ +int usb_function_activate(struct usb_function *function) +{ + struct usb_composite_dev *cdev = function->config->cdev; + int status = 0; + + if (cdev->deactivations == 0) + status = -EINVAL; + else { + cdev->deactivations--; + if (cdev->deactivations == 0) + status = usb_gadget_connect(cdev->gadget); + } + + return status; +} + +/** + * usb_interface_id() - allocate an unused interface ID + * @config: configuration associated with the interface + * @function: function handling the interface + * Context: single threaded during gadget setup + * + * usb_interface_id() is called from usb_function.bind() callbacks to + * allocate new interface IDs. The function driver will then store that + * ID in interface, association, CDC union, and other descriptors. It + * will also handle any control requests targetted at that interface, + * particularly changing its altsetting via set_alt(). There may + * also be class-specific or vendor-specific requests to handle. + * + * All interface identifier should be allocated using this routine, to + * ensure that for example different functions don't wrongly assign + * different meanings to the same identifier. Note that since interface + * identifers are configuration-specific, functions used in more than + * one configuration (or more than once in a given configuration) need + * multiple versions of the relevant descriptors. + * + * Returns the interface ID which was allocated; or -ENODEV if no + * more interface IDs can be allocated. + */ +int usb_interface_id(struct usb_configuration *config, + struct usb_function *function) +{ + unsigned char id = config->next_interface_id; + + if (id < MAX_CONFIG_INTERFACES) { + config->interface[id] = function; + config->next_interface_id = id + 1; + return id; + } + return -ENODEV; +} + +static int config_buf(struct usb_configuration *config, + enum usb_device_speed speed, void *buf, u8 type) +{ + int len = USB_BUFSIZ - USB_DT_CONFIG_SIZE; + void *next = buf + USB_DT_CONFIG_SIZE; + struct usb_descriptor_header **descriptors; + struct usb_config_descriptor *c = buf; + int status; + struct usb_function *f; + + /* write the config descriptor */ + c = buf; + c->bLength = USB_DT_CONFIG_SIZE; + c->bDescriptorType = type; + + c->bNumInterfaces = config->next_interface_id; + c->bConfigurationValue = config->bConfigurationValue; + c->iConfiguration = config->iConfiguration; + c->bmAttributes = USB_CONFIG_ATT_ONE | config->bmAttributes; + c->bMaxPower = config->bMaxPower ? : (CONFIG_USB_GADGET_VBUS_DRAW / 2); + + /* There may be e.g. OTG descriptors */ + if (config->descriptors) { + status = usb_descriptor_fillbuf(next, len, + config->descriptors); + if (status < 0) + return status; + len -= status; + next += status; + } + + /* add each function's descriptors */ + list_for_each_entry(f, &config->functions, list) { + if (speed == USB_SPEED_HIGH) + descriptors = f->hs_descriptors; + else + descriptors = f->descriptors; + if (!descriptors) + continue; + status = usb_descriptor_fillbuf(next, len, + (const struct usb_descriptor_header **) descriptors); + if (status < 0) + return status; + len -= status; + next += status; + } + + len = next - buf; + c->wTotalLength = cpu_to_le16(len); + return len; +} + +static int config_desc(struct usb_composite_dev *cdev, unsigned w_value) +{ + enum usb_device_speed speed = USB_SPEED_UNKNOWN; + struct usb_gadget *gadget = cdev->gadget; + u8 type = w_value >> 8; + int hs = 0; + struct usb_configuration *c; + + if (gadget_is_dualspeed(gadget)) { + if (gadget->speed == USB_SPEED_HIGH) + hs = 1; + if (type == USB_DT_OTHER_SPEED_CONFIG) + hs = !hs; + if (hs) + speed = USB_SPEED_HIGH; + } + + w_value &= 0xff; + list_for_each_entry(c, &cdev->configs, list) { + if (speed == USB_SPEED_HIGH) { + if (!c->highspeed) + continue; + } else { + if (!c->fullspeed) + continue; + } + if (w_value == 0) + return config_buf(c, speed, cdev->req->buf, type); + w_value--; + } + return -EINVAL; +} + +static int count_configs(struct usb_composite_dev *cdev, unsigned type) +{ + struct usb_gadget *gadget = cdev->gadget; + unsigned count = 0; + int hs = 0; + struct usb_configuration *c; + + if (gadget_is_dualspeed(gadget)) { + if (gadget->speed == USB_SPEED_HIGH) + hs = 1; + if (type == USB_DT_DEVICE_QUALIFIER) + hs = !hs; + } + list_for_each_entry(c, &cdev->configs, list) { + /* ignore configs that won't work at this speed */ + if (hs) { + if (!c->highspeed) + continue; + } else { + if (!c->fullspeed) + continue; + } + count++; + } + return count; +} + +static void device_qual(struct usb_composite_dev *cdev) +{ + struct usb_qualifier_descriptor *qual = cdev->req->buf; + + qual->bLength = sizeof(*qual); + qual->bDescriptorType = USB_DT_DEVICE_QUALIFIER; + /* POLICY: same bcdUSB and device type info at both speeds */ + qual->bcdUSB = cdev->desc.bcdUSB; + qual->bDeviceClass = cdev->desc.bDeviceClass; + qual->bDeviceSubClass = cdev->desc.bDeviceSubClass; + qual->bDeviceProtocol = cdev->desc.bDeviceProtocol; + /* ASSUME same EP0 fifo size at both speeds */ + qual->bMaxPacketSize0 = cdev->desc.bMaxPacketSize0; + qual->bNumConfigurations = count_configs(cdev, USB_DT_DEVICE_QUALIFIER); + qual->bRESERVED = 0; +} + +static void reset_config(struct usb_composite_dev *cdev) +{ + struct usb_function *f; + + debug("%s:\n", __func__); + + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->disable) + f->disable(f); + + bitmap_zero(f->endpoints, 32); + } + cdev->config = NULL; +} + +static int set_config(struct usb_composite_dev *cdev, + const struct usb_ctrlrequest *ctrl, unsigned number) +{ + struct usb_gadget *gadget = cdev->gadget; + unsigned power = gadget_is_otg(gadget) ? 8 : 100; + struct usb_descriptor_header **descriptors; + int result = -EINVAL; + struct usb_endpoint_descriptor *ep; + struct usb_configuration *c = NULL; + int addr; + int tmp; + struct usb_function *f; + + if (cdev->config) + reset_config(cdev); + + if (number) { + list_for_each_entry(c, &cdev->configs, list) { + if (c->bConfigurationValue == number) { + result = 0; + break; + } + } + if (result < 0) + goto done; + } else + result = 0; + + debug("%s: %s speed config #%d: %s\n", __func__, + ({ char *speed; + switch (gadget->speed) { + case USB_SPEED_LOW: + speed = "low"; + break; + case USB_SPEED_FULL: + speed = "full"; + break; + case USB_SPEED_HIGH: + speed = "high"; + break; + default: + speed = "?"; + break; + }; + speed; + }), number, c ? c->label : "unconfigured"); + + if (!c) + goto done; + + cdev->config = c; + + /* Initialize all interfaces by setting them to altsetting zero. */ + for (tmp = 0; tmp < MAX_CONFIG_INTERFACES; tmp++) { + f = c->interface[tmp]; + if (!f) + break; + + /* + * Record which endpoints are used by the function. This is used + * to dispatch control requests targeted at that endpoint to the + * function's setup callback instead of the current + * configuration's setup callback. + */ + if (gadget->speed == USB_SPEED_HIGH) + descriptors = f->hs_descriptors; + else + descriptors = f->descriptors; + + for (; *descriptors; ++descriptors) { + if ((*descriptors)->bDescriptorType != USB_DT_ENDPOINT) + continue; + + ep = (struct usb_endpoint_descriptor *)*descriptors; + addr = ((ep->bEndpointAddress & 0x80) >> 3) + | (ep->bEndpointAddress & 0x0f); + __set_bit(addr, f->endpoints); + } + + result = f->set_alt(f, tmp, 0); + if (result < 0) { + debug("interface %d (%s/%p) alt 0 --> %d\n", + tmp, f->name, f, result); + + reset_config(cdev); + goto done; + } + } + + /* when we return, be sure our power usage is valid */ + power = c->bMaxPower ? (2 * c->bMaxPower) : CONFIG_USB_GADGET_VBUS_DRAW; +done: + usb_gadget_vbus_draw(gadget, power); + return result; +} + +/** + * usb_add_config() - add a configuration to a device. + * @cdev: wraps the USB gadget + * @config: the configuration, with bConfigurationValue assigned + * Context: single threaded during gadget setup + * + * One of the main tasks of a composite driver's bind() routine is to + * add each of the configurations it supports, using this routine. + * + * This function returns the value of the configuration's bind(), which + * is zero for success else a negative errno value. Binding configurations + * assigns global resources including string IDs, and per-configuration + * resources such as interface IDs and endpoints. + */ +int usb_add_config(struct usb_composite_dev *cdev, + struct usb_configuration *config) +{ + int status = -EINVAL; + struct usb_configuration *c; + struct usb_function *f; + unsigned int i; + + debug("%s: adding config #%u '%s'/%p\n", __func__, + config->bConfigurationValue, + config->label, config); + + if (!config->bConfigurationValue || !config->bind) + goto done; + + /* Prevent duplicate configuration identifiers */ + list_for_each_entry(c, &cdev->configs, list) { + if (c->bConfigurationValue == config->bConfigurationValue) { + status = -EBUSY; + goto done; + } + } + + config->cdev = cdev; + list_add_tail(&config->list, &cdev->configs); + + INIT_LIST_HEAD(&config->functions); + config->next_interface_id = 0; + + status = config->bind(config); + if (status < 0) { + list_del(&config->list); + config->cdev = NULL; + } else { + debug("cfg %d/%p speeds:%s%s\n", + config->bConfigurationValue, config, + config->highspeed ? " high" : "", + config->fullspeed + ? (gadget_is_dualspeed(cdev->gadget) + ? " full" + : " full/low") + : ""); + + for (i = 0; i < MAX_CONFIG_INTERFACES; i++) { + f = config->interface[i]; + if (!f) + continue; + debug("%s: interface %d = %s/%p\n", + __func__, i, f->name, f); + } + } + + usb_ep_autoconfig_reset(cdev->gadget); + +done: + if (status) + debug("added config '%s'/%u --> %d\n", config->label, + config->bConfigurationValue, status); + return status; +} + +/* + * We support strings in multiple languages ... string descriptor zero + * says which languages are supported. The typical case will be that + * only one language (probably English) is used, with I18N handled on + * the host side. + */ + +static void collect_langs(struct usb_gadget_strings **sp, __le16 *buf) +{ + const struct usb_gadget_strings *s; + u16 language; + __le16 *tmp; + + while (*sp) { + s = *sp; + language = cpu_to_le16(s->language); + for (tmp = buf; *tmp && tmp < &buf[126]; tmp++) { + if (*tmp == language) + goto repeat; + } + *tmp++ = language; +repeat: + sp++; + } +} + +static int lookup_string( + struct usb_gadget_strings **sp, + void *buf, + u16 language, + int id +) +{ + int value; + struct usb_gadget_strings *s; + + while (*sp) { + s = *sp++; + if (s->language != language) + continue; + value = usb_gadget_get_string(s, id, buf); + if (value > 0) + return value; + } + return -EINVAL; +} + +static int get_string(struct usb_composite_dev *cdev, + void *buf, u16 language, int id) +{ + struct usb_string_descriptor *s = buf; + struct usb_gadget_strings **sp; + int len; + struct usb_configuration *c; + struct usb_function *f; + + /* + * Yes, not only is USB's I18N support probably more than most + * folk will ever care about ... also, it's all supported here. + * (Except for UTF8 support for Unicode's "Astral Planes".) + */ + + /* 0 == report all available language codes */ + if (id == 0) { + memset(s, 0, 256); + s->bDescriptorType = USB_DT_STRING; + + sp = composite->strings; + if (sp) + collect_langs(sp, s->wData); + + list_for_each_entry(c, &cdev->configs, list) { + sp = c->strings; + if (sp) + collect_langs(sp, s->wData); + + list_for_each_entry(f, &c->functions, list) { + sp = f->strings; + if (sp) + collect_langs(sp, s->wData); + } + } + + for (len = 0; len <= 126 && s->wData[len]; len++) + continue; + if (!len) + return -EINVAL; + + s->bLength = 2 * (len + 1); + return s->bLength; + } + + /* + * Otherwise, look up and return a specified string. String IDs + * are device-scoped, so we look up each string table we're told + * about. These lookups are infrequent; simpler-is-better here. + */ + if (composite->strings) { + len = lookup_string(composite->strings, buf, language, id); + if (len > 0) + return len; + } + list_for_each_entry(c, &cdev->configs, list) { + if (c->strings) { + len = lookup_string(c->strings, buf, language, id); + if (len > 0) + return len; + } + list_for_each_entry(f, &c->functions, list) { + if (!f->strings) + continue; + len = lookup_string(f->strings, buf, language, id); + if (len > 0) + return len; + } + } + return -EINVAL; +} + +/** + * usb_string_id() - allocate an unused string ID + * @cdev: the device whose string descriptor IDs are being allocated + * Context: single threaded during gadget setup + * + * @usb_string_id() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then store that ID in the appropriate descriptors and string table. + * + * All string identifier should be allocated using this, + * @usb_string_ids_tab() or @usb_string_ids_n() routine, to ensure + * that for example different functions don't wrongly assign different + * meanings to the same identifier. + */ +int usb_string_id(struct usb_composite_dev *cdev) +{ + if (cdev->next_string_id < 254) { + /* + * string id 0 is reserved by USB spec for list of + * supported languages + * 255 reserved as well? -- mina86 + */ + cdev->next_string_id++; + return cdev->next_string_id; + } + return -ENODEV; +} + +/** + * usb_string_ids() - allocate unused string IDs in batch + * @cdev: the device whose string descriptor IDs are being allocated + * @str: an array of usb_string objects to assign numbers to + * Context: single threaded during gadget setup + * + * @usb_string_ids() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then copy IDs from the string table to the appropriate descriptors + * and string table for other languages. + * + * All string identifier should be allocated using this, + * @usb_string_id() or @usb_string_ids_n() routine, to ensure that for + * example different functions don't wrongly assign different meanings + * to the same identifier. + */ +int usb_string_ids_tab(struct usb_composite_dev *cdev, struct usb_string *str) +{ + u8 next = cdev->next_string_id; + + for (; str->s; ++str) { + if (next >= 254) + return -ENODEV; + str->id = ++next; + } + + cdev->next_string_id = next; + + return 0; +} + +/** + * usb_string_ids_n() - allocate unused string IDs in batch + * @c: the device whose string descriptor IDs are being allocated + * @n: number of string IDs to allocate + * Context: single threaded during gadget setup + * + * Returns the first requested ID. This ID and next @n-1 IDs are now + * valid IDs. At least provided that @n is non-zero because if it + * is, returns last requested ID which is now very useful information. + * + * @usb_string_ids_n() is called from bind() callbacks to allocate + * string IDs. Drivers for functions, configurations, or gadgets will + * then store that ID in the appropriate descriptors and string table. + * + * All string identifier should be allocated using this, + * @usb_string_id() or @usb_string_ids_n() routine, to ensure that for + * example different functions don't wrongly assign different meanings + * to the same identifier. + */ +int usb_string_ids_n(struct usb_composite_dev *c, unsigned n) +{ + u8 next = c->next_string_id; + + if (n > 254 || next + n > 254) + return -ENODEV; + + c->next_string_id += n; + return next + 1; +} + +static void composite_setup_complete(struct usb_ep *ep, struct usb_request *req) +{ + if (req->status || req->actual != req->length) + debug("%s: setup complete --> %d, %d/%d\n", __func__, + req->status, req->actual, req->length); +} + +/* + * The setup() callback implements all the ep0 functionality that's + * not handled lower down, in hardware or the hardware driver(like + * device and endpoint feature flags, and their status). It's all + * housekeeping for the gadget function we're implementing. Most of + * the work is in config and function specific setup. + */ +static int +composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) +{ + u16 w_length = le16_to_cpu(ctrl->wLength); + u16 w_index = le16_to_cpu(ctrl->wIndex); + u16 w_value = le16_to_cpu(ctrl->wValue); + struct usb_composite_dev *cdev = get_gadget_data(gadget); + u8 intf = w_index & 0xFF; + int value = -EOPNOTSUPP; + struct usb_request *req = cdev->req; + struct usb_function *f = NULL; + int standard; + u8 endp; + struct usb_configuration *c; + + /* + * partial re-init of the response message; the function or the + * gadget might need to intercept e.g. a control-OUT completion + * when we delegate to it. + */ + req->zero = 0; + req->complete = composite_setup_complete; + req->length = USB_BUFSIZ; + gadget->ep0->driver_data = cdev; + standard = (ctrl->bRequestType & USB_TYPE_MASK) + == USB_TYPE_STANDARD; + if (!standard) + goto unknown; + + switch (ctrl->bRequest) { + + /* we handle all standard USB descriptors */ + case USB_REQ_GET_DESCRIPTOR: + if (ctrl->bRequestType != USB_DIR_IN) + goto unknown; + switch (w_value >> 8) { + + case USB_DT_DEVICE: + cdev->desc.bNumConfigurations = + count_configs(cdev, USB_DT_DEVICE); + value = min(w_length, (u16) sizeof cdev->desc); + memcpy(req->buf, &cdev->desc, value); + break; + case USB_DT_DEVICE_QUALIFIER: + if (!gadget_is_dualspeed(gadget)) + break; + device_qual(cdev); + value = min_t(w_length, + sizeof(struct usb_qualifier_descriptor)); + break; + case USB_DT_OTHER_SPEED_CONFIG: + if (!gadget_is_dualspeed(gadget)) + break; + + case USB_DT_CONFIG: + value = config_desc(cdev, w_value); + if (value >= 0) + value = min(w_length, (u16) value); + break; + case USB_DT_STRING: + value = get_string(cdev, req->buf, + w_index, w_value & 0xff); + if (value >= 0) + value = min(w_length, (u16) value); + break; + default: + goto unknown; + } + break; + + /* any number of configs can work */ + case USB_REQ_SET_CONFIGURATION: + if (ctrl->bRequestType != 0) + goto unknown; + if (gadget_is_otg(gadget)) { + if (gadget->a_hnp_support) + debug("HNP available\n"); + else if (gadget->a_alt_hnp_support) + debug("HNP on another port\n"); + else + debug("HNP inactive\n"); + } + + value = set_config(cdev, ctrl, w_value); + break; + case USB_REQ_GET_CONFIGURATION: + if (ctrl->bRequestType != USB_DIR_IN) + goto unknown; + if (cdev->config) + *(u8 *)req->buf = cdev->config->bConfigurationValue; + else + *(u8 *)req->buf = 0; + value = min(w_length, (u16) 1); + break; + + /* + * function drivers must handle get/set altsetting; if there's + * no get() method, we know only altsetting zero works. + */ + case USB_REQ_SET_INTERFACE: + if (ctrl->bRequestType != USB_RECIP_INTERFACE) + goto unknown; + if (!cdev->config || w_index >= MAX_CONFIG_INTERFACES) + break; + f = cdev->config->interface[intf]; + if (!f) + break; + if (w_value && !f->set_alt) + break; + value = f->set_alt(f, w_index, w_value); + break; + case USB_REQ_GET_INTERFACE: + if (ctrl->bRequestType != (USB_DIR_IN|USB_RECIP_INTERFACE)) + goto unknown; + if (!cdev->config || w_index >= MAX_CONFIG_INTERFACES) + break; + f = cdev->config->interface[intf]; + if (!f) + break; + /* lots of interfaces only need altsetting zero... */ + value = f->get_alt ? f->get_alt(f, w_index) : 0; + if (value < 0) + break; + *((u8 *)req->buf) = value; + value = min(w_length, (u16) 1); + break; + default: +unknown: + debug("non-core control req%02x.%02x v%04x i%04x l%d\n", + ctrl->bRequestType, ctrl->bRequest, + w_value, w_index, w_length); + + /* + * functions always handle their interfaces and endpoints... + * punt other recipients (other, WUSB, ...) to the current + * configuration code. + */ + switch (ctrl->bRequestType & USB_RECIP_MASK) { + case USB_RECIP_INTERFACE: + f = cdev->config->interface[intf]; + break; + + case USB_RECIP_ENDPOINT: + endp = ((w_index & 0x80) >> 3) | (w_index & 0x0f); + list_for_each_entry(f, &cdev->config->functions, list) { + if (test_bit(endp, f->endpoints)) + break; + } + if (&f->list == &cdev->config->functions) + f = NULL; + break; + } + + if (f && f->setup) + value = f->setup(f, ctrl); + else { + c = cdev->config; + if (c && c->setup) + value = c->setup(c, ctrl); + } + + goto done; + } + + /* respond with data transfer before status phase? */ + if (value >= 0) { + req->length = value; + req->zero = value < w_length; + value = usb_ep_queue(gadget->ep0, req, GFP_KERNEL); + if (value < 0) { + debug("ep_queue --> %d\n", value); + req->status = 0; + composite_setup_complete(gadget->ep0, req); + } + } + +done: + /* device either stalls (value < 0) or reports success */ + return value; +} + +static void composite_disconnect(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + + if (cdev->config) + reset_config(cdev); + if (composite->disconnect) + composite->disconnect(cdev); +} + +static void composite_unbind(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_configuration *c; + struct usb_function *f; + + /* + * composite_disconnect() must already have been called + * by the underlying peripheral controller driver! + * so there's no i/o concurrency that could affect the + * state protected by cdev->lock. + */ + BUG_ON(cdev->config); + + while (!list_empty(&cdev->configs)) { + c = list_first_entry(&cdev->configs, + struct usb_configuration, list); + while (!list_empty(&c->functions)) { + f = list_first_entry(&c->functions, + struct usb_function, list); + list_del(&f->list); + if (f->unbind) { + debug("unbind function '%s'/%p\n", + f->name, f); + f->unbind(c, f); + } + } + list_del(&c->list); + if (c->unbind) { + debug("unbind config '%s'/%p\n", c->label, c); + c->unbind(c); + } + } + if (composite->unbind) + composite->unbind(cdev); + + if (cdev->req) { + kfree(cdev->req->buf); + usb_ep_free_request(gadget->ep0, cdev->req); + } + kfree(cdev); + set_gadget_data(gadget, NULL); + + composite = NULL; +} + +static int composite_bind(struct usb_gadget *gadget) +{ + int status = -ENOMEM; + struct usb_composite_dev *cdev; + + cdev = calloc(sizeof *cdev, 1); + if (!cdev) + return status; + + cdev->gadget = gadget; + set_gadget_data(gadget, cdev); + INIT_LIST_HEAD(&cdev->configs); + + /* preallocate control response and buffer */ + cdev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL); + if (!cdev->req) + goto fail; + cdev->req->buf = kmalloc(USB_BUFSIZ, GFP_KERNEL); + if (!cdev->req->buf) + goto fail; + cdev->req->complete = composite_setup_complete; + gadget->ep0->driver_data = cdev; + + cdev->bufsiz = USB_BUFSIZ; + cdev->driver = composite; + + usb_gadget_set_selfpowered(gadget); + usb_ep_autoconfig_reset(cdev->gadget); + + status = composite->bind(cdev); + if (status < 0) + goto fail; + + cdev->desc = *composite->dev; + cdev->desc.bMaxPacketSize0 = gadget->ep0->maxpacket; + + debug("%s: ready\n", composite->name); + return 0; + +fail: + composite_unbind(gadget); + return status; +} + +static void +composite_suspend(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_function *f; + + debug("%s: suspend\n", __func__); + if (cdev->config) { + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->suspend) + f->suspend(f); + } + } + if (composite->suspend) + composite->suspend(cdev); + + cdev->suspended = 1; +} + +static void +composite_resume(struct usb_gadget *gadget) +{ + struct usb_composite_dev *cdev = get_gadget_data(gadget); + struct usb_function *f; + + debug("%s: resume\n", __func__); + if (composite->resume) + composite->resume(cdev); + if (cdev->config) { + list_for_each_entry(f, &cdev->config->functions, list) { + if (f->resume) + f->resume(f); + } + } + + cdev->suspended = 0; +} + +static struct usb_gadget_driver composite_driver = { + .speed = USB_SPEED_HIGH, + + .bind = composite_bind, + .unbind = composite_unbind, + + .setup = composite_setup, + .disconnect = composite_disconnect, + + .suspend = composite_suspend, + .resume = composite_resume, +}; + +/** + * usb_composite_register() - register a composite driver + * @driver: the driver to register + * Context: single threaded during gadget setup + * + * This function is used to register drivers using the composite driver + * framework. The return value is zero, or a negative errno value. + * Those values normally come from the driver's @bind method, which does + * all the work of setting up the driver to match the hardware. + * + * On successful return, the gadget is ready to respond to requests from + * the host, unless one of its components invokes usb_gadget_disconnect() + * while it was binding. That would usually be done in order to wait for + * some userspace participation. + */ +int usb_composite_register(struct usb_composite_driver *driver) +{ + if (!driver || !driver->dev || !driver->bind || composite) + return -EINVAL; + + if (!driver->name) + driver->name = "composite"; + composite = driver; + + return usb_gadget_register_driver(&composite_driver); +} + +/** + * usb_composite_unregister() - unregister a composite driver + * @driver: the driver to unregister + * + * This function is used to unregister drivers using the composite + * driver framework. + */ +void usb_composite_unregister(struct usb_composite_driver *driver) +{ + if (composite != driver) + return; + usb_gadget_unregister_driver(&composite_driver); +} diff --git a/include/linux/usb/composite.h b/include/linux/usb/composite.h new file mode 100644 index 0000000..53cb095 --- /dev/null +++ b/include/linux/usb/composite.h @@ -0,0 +1,350 @@ +/* + * composite.h -- framework for usb gadgets which are composite devices + * + * Copyright (C) 2006-2008 David Brownell + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef __LINUX_USB_COMPOSITE_H +#define __LINUX_USB_COMPOSITE_H + +/* + * This framework is an optional layer on top of the USB Gadget interface, + * making it easier to build (a) Composite devices, supporting multiple + * functions within any single configuration, and (b) Multi-configuration + * devices, also supporting multiple functions but without necessarily + * having more than one function per configuration. + * + * Example: a device with a single configuration supporting both network + * link and mass storage functions is a composite device. Those functions + * might alternatively be packaged in individual configurations, but in + * the composite model the host can use both functions at the same time. + */ + +#include <common.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <usb/lin_gadget_compat.h> + +struct usb_configuration; + +/** + * struct usb_function - describes one function of a configuration + * @name: For diagnostics, identifies the function. + * @strings: tables of strings, keyed by identifiers assigned during bind() + * and by language IDs provided in control requests + * @descriptors: Table of full (or low) speed descriptors, using interface and + * string identifiers assigned during @bind(). If this pointer is null, + * the function will not be available at full speed (or at low speed). + * @hs_descriptors: Table of high speed descriptors, using interface and + * string identifiers assigned during @bind(). If this pointer is null, + * the function will not be available at high speed. + * @config: assigned when @usb_add_function() is called; this is the + * configuration with which this function is associated. + * @bind: Before the gadget can register, all of its functions bind() to the + * available resources including string and interface identifiers used + * in interface or class descriptors; endpoints; I/O buffers; and so on. + * @unbind: Reverses @bind; called as a side effect of unregistering the + * driver which added this function. + * @set_alt: (REQUIRED) Reconfigures altsettings; function drivers may + * initialize usb_ep.driver data at this time (when it is used). + * Note that setting an interface to its current altsetting resets + * interface state, and that all interfaces have a disabled state. + * @get_alt: Returns the active altsetting. If this is not provided, + * then only altsetting zero is supported. + * @disable: (REQUIRED) Indicates the function should be disabled. Reasons + * include host resetting or reconfiguring the gadget, and disconnection. + * @setup: Used for interface-specific control requests. + * @suspend: Notifies functions when the host stops sending USB traffic. + * @resume: Notifies functions when the host restarts USB traffic. + * + * A single USB function uses one or more interfaces, and should in most + * cases support operation at both full and high speeds. Each function is + * associated by @usb_add_function() with a one configuration; that function + * causes @bind() to be called so resources can be allocated as part of + * setting up a gadget driver. Those resources include endpoints, which + * should be allocated using @usb_ep_autoconfig(). + * + * To support dual speed operation, a function driver provides descriptors + * for both high and full speed operation. Except in rare cases that don't + * involve bulk endpoints, each speed needs different endpoint descriptors. + * + * Function drivers choose their own strategies for managing instance data. + * The simplest strategy just declares it "static', which means the function + * can only be activated once. If the function needs to be exposed in more + * than one configuration at a given speed, it needs to support multiple + * usb_function structures (one for each configuration). + * + * A more complex strategy might encapsulate a @usb_function structure inside + * a driver-specific instance structure to allows multiple activations. An + * example of multiple activations might be a CDC ACM function that supports + * two or more distinct instances within the same configuration, providing + * several independent logical data links to a USB host. + */ +struct usb_function { + const char *name; + struct usb_gadget_strings **strings; + struct usb_descriptor_header **descriptors; + struct usb_descriptor_header **hs_descriptors; + + struct usb_configuration *config; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching. + * Related: unbind() may kfree() but bind() won't... + */ + + /* configuration management: bind/unbind */ + int (*bind)(struct usb_configuration *, + struct usb_function *); + void (*unbind)(struct usb_configuration *, + struct usb_function *); + + /* runtime state management */ + int (*set_alt)(struct usb_function *, + unsigned interface, unsigned alt); + int (*get_alt)(struct usb_function *, + unsigned interface); + void (*disable)(struct usb_function *); + int (*setup)(struct usb_function *, + const struct usb_ctrlrequest *); + void (*suspend)(struct usb_function *); + void (*resume)(struct usb_function *); + + /* private: */ + /* internals */ + struct list_head list; + DECLARE_BITMAP(endpoints, 32); +}; + +int usb_add_function(struct usb_configuration *, struct usb_function *); + +int usb_function_deactivate(struct usb_function *); +int usb_function_activate(struct usb_function *); + +int usb_interface_id(struct usb_configuration *, struct usb_function *); + +/** + * ep_choose - select descriptor endpoint at current device speed + * @g: gadget, connected and running at some speed + * @hs: descriptor to use for high speed operation + * @fs: descriptor to use for full or low speed operation + */ +static inline struct usb_endpoint_descriptor * +ep_choose(struct usb_gadget *g, struct usb_endpoint_descriptor *hs, + struct usb_endpoint_descriptor *fs) +{ + if (gadget_is_dualspeed(g) && g->speed == USB_SPEED_HIGH) + return hs; + return fs; +} + +#define MAX_CONFIG_INTERFACES 16 /* arbitrary; max 255 */ + +/** + * struct usb_configuration - represents one gadget configuration + * @label: For diagnostics, describes the configuration. + * @strings: Tables of strings, keyed by identifiers assigned during @bind() + * and by language IDs provided in control requests. + * @descriptors: Table of descriptors preceding all function descriptors. + * Examples include OTG and vendor-specific descriptors. + * @bind: Called from @usb_add_config() to allocate resources unique to this + * configuration and to call @usb_add_function() for each function used. + * @unbind: Reverses @bind; called as a side effect of unregistering the + * driver which added this configuration. + * @setup: Used to delegate control requests that aren't handled by standard + * device infrastructure or directed at a specific interface. + * @bConfigurationValue: Copied into configuration descriptor. + * @iConfiguration: Copied into configuration descriptor. + * @bmAttributes: Copied into configuration descriptor. + * @bMaxPower: Copied into configuration descriptor. + * @cdev: assigned by @usb_add_config() before calling @bind(); this is + * the device associated with this configuration. + * + * Configurations are building blocks for gadget drivers structured around + * function drivers. Simple USB gadgets require only one function and one + * configuration, and handle dual-speed hardware by always providing the same + * functionality. Slightly more complex gadgets may have more than one + * single-function configuration at a given speed; or have configurations + * that only work at one speed. + * + * Composite devices are, by definition, ones with configurations which + * include more than one function. + * + * The lifecycle of a usb_configuration includes allocation, initialization + * of the fields described above, and calling @usb_add_config() to set up + * internal data and bind it to a specific device. The configuration's + * @bind() method is then used to initialize all the functions and then + * call @usb_add_function() for them. + * + * Those functions would normally be independant of each other, but that's + * not mandatory. CDC WMC devices are an example where functions often + * depend on other functions, with some functions subsidiary to others. + * Such interdependency may be managed in any way, so long as all of the + * descriptors complete by the time the composite driver returns from + * its bind() routine. + */ +struct usb_configuration { + const char *label; + struct usb_gadget_strings **strings; + const struct usb_descriptor_header **descriptors; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching... + */ + + /* configuration management: bind/unbind */ + int (*bind)(struct usb_configuration *); + void (*unbind)(struct usb_configuration *); + int (*setup)(struct usb_configuration *, + const struct usb_ctrlrequest *); + + /* fields in the config descriptor */ + u8 bConfigurationValue; + u8 iConfiguration; + u8 bmAttributes; + u8 bMaxPower; + + struct usb_composite_dev *cdev; + + /* private: */ + /* internals */ + struct list_head list; + struct list_head functions; + u8 next_interface_id; + unsigned highspeed:1; + unsigned fullspeed:1; + struct usb_function *interface[MAX_CONFIG_INTERFACES]; +}; + +int usb_add_config(struct usb_composite_dev *, + struct usb_configuration *); + +/** + * struct usb_composite_driver - groups configurations into a gadget + * @name: For diagnostics, identifies the driver. + * @dev: Template descriptor for the device, including default device + * identifiers. + * @strings: tables of strings, keyed by identifiers assigned during bind() + * and language IDs provided in control requests + * @bind: (REQUIRED) Used to allocate resources that are shared across the + * whole device, such as string IDs, and add its configurations using + * @usb_add_config(). This may fail by returning a negative errno + * value; it should return zero on successful initialization. + * @unbind: Reverses @bind(); called as a side effect of unregistering + * this driver. + * @disconnect: optional driver disconnect method + * @suspend: Notifies when the host stops sending USB traffic, + * after function notifications + * @resume: Notifies configuration when the host restarts USB traffic, + * before function notifications + * + * Devices default to reporting self powered operation. Devices which rely + * on bus powered operation should report this in their @bind() method. + * + * Before returning from @bind, various fields in the template descriptor + * may be overridden. These include the idVendor/idProduct/bcdDevice values + * normally to bind the appropriate host side driver, and the three strings + * (iManufacturer, iProduct, iSerialNumber) normally used to provide user + * meaningful device identifiers. (The strings will not be defined unless + * they are defined in @dev and @strings.) The correct ep0 maxpacket size + * is also reported, as defined by the underlying controller driver. + */ +struct usb_composite_driver { + const char *name; + const struct usb_device_descriptor *dev; + struct usb_gadget_strings **strings; + + /* REVISIT: bind() functions can be marked __init, which + * makes trouble for section mismatch analysis. See if + * we can't restructure things to avoid mismatching... + */ + + int (*bind)(struct usb_composite_dev *); + int (*unbind)(struct usb_composite_dev *); + + void (*disconnect)(struct usb_composite_dev *); + + /* global suspend hooks */ + void (*suspend)(struct usb_composite_dev *); + void (*resume)(struct usb_composite_dev *); +}; + +extern int usb_composite_register(struct usb_composite_driver *); +extern void usb_composite_unregister(struct usb_composite_driver *); + + +/** + * struct usb_composite_device - represents one composite usb gadget + * @gadget: read-only, abstracts the gadget's usb peripheral controller + * @req: used for control responses; buffer is pre-allocated + * @bufsiz: size of buffer pre-allocated in @req + * @config: the currently active configuration + * + * One of these devices is allocated and initialized before the + * associated device driver's bind() is called. + * + * OPEN ISSUE: it appears that some WUSB devices will need to be + * built by combining a normal (wired) gadget with a wireless one. + * This revision of the gadget framework should probably try to make + * sure doing that won't hurt too much. + * + * One notion for how to handle Wireless USB devices involves: + * (a) a second gadget here, discovery mechanism TBD, but likely + * needing separate "register/unregister WUSB gadget" calls; + * (b) updates to usb_gadget to include flags "is it wireless", + * "is it wired", plus (presumably in a wrapper structure) + * bandgroup and PHY info; + * (c) presumably a wireless_ep wrapping a usb_ep, and reporting + * wireless-specific parameters like maxburst and maxsequence; + * (d) configurations that are specific to wireless links; + * (e) function drivers that understand wireless configs and will + * support wireless for (additional) function instances; + * (f) a function to support association setup (like CBAF), not + * necessarily requiring a wireless adapter; + * (g) composite device setup that can create one or more wireless + * configs, including appropriate association setup support; + * (h) more, TBD. + */ +struct usb_composite_dev { + struct usb_gadget *gadget; + struct usb_request *req; + unsigned bufsiz; + + struct usb_configuration *config; + + /* private: */ + /* internals */ + unsigned int suspended:1; + struct usb_device_descriptor desc; + struct list_head configs; + struct usb_composite_driver *driver; + u8 next_string_id; + + /* the gadget driver won't enable the data pullup + * while the deactivation count is nonzero. + */ + unsigned deactivations; +}; + +extern int usb_string_id(struct usb_composite_dev *c); +extern int usb_string_ids_tab(struct usb_composite_dev *c, + struct usb_string *str); +extern int usb_string_ids_n(struct usb_composite_dev *c, unsigned n); + +#endif /* __LINUX_USB_COMPOSITE_H */ diff --git a/include/usb/lin_gadget_compat.h b/include/usb/lin_gadget_compat.h index fce3be7..47c6387 100644 --- a/include/usb/lin_gadget_compat.h +++ b/include/usb/lin_gadget_compat.h @@ -36,8 +36,8 @@ #define mutex_lock(...) #define mutex_unlock(...)
-#define WARN_ON(x) if (x) {printf("WARNING in %s line %d\n" \ - , __FILE__, __LINE__); } +#define WARN_ON(x) do { if (x) printf("WARNING in %s line %d\n" \ + , __FILE__, __LINE__); } while (0)
#define KERN_WARNING #define KERN_ERR @@ -56,6 +56,26 @@
#define __iomem #define min_t min + +#define BITS_PER_BYTE 8 +#define BITS_TO_LONGS(nr) \ + DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) +#define DECLARE_BITMAP(name, bits) \ + unsigned long name[BITS_TO_LONGS(bits)] + +#define small_const_nbits(nbits) \ + (__builtin_constant_p(nbits) && (nbits) <= BITS_PER_LONG) + +static inline void bitmap_zero(unsigned long *dst, int nbits) +{ + if (small_const_nbits(nbits)) + *dst = 0UL; + else { + int len = BITS_TO_LONGS(nbits) * sizeof(unsigned long); + memset(dst, 0, len); + } +} + #define dma_cache_maint(addr, size, mode) cache_flush() void cache_flush(void);
Dear Lukasz Majewski,
USB Composite gadget implementation for u-boot. It builds on top of USB UDC drivers.
This commit is based on following files from Linux Kernel v2.6.36:
SHA1: d187abb9a83e6c6b6e9f2ca17962bdeafb4bc903
Quick glance through this looks fine, I'll preempt here and check the rest in a few days ... sorry for the delays, I'm overloaded, please understand :-(
Best regards, Marek Vasut
Ok, no problem :-)
I just remind about those patches.
Since I'm developing the composite gadget for u-boot, it is important for me to have the UDC composite driver "stabilized" in u-boot mainline.
Ok, no problem :-)
They keep being on my mind, and now it looks like I'll get to reviewing them tomorrow ;-)
Acked-by: Marek Vasut marex@denx.de
- void *device_data; /* data private to the device */
Can't device_data be wrapped into driver_data? I guess not ...
- return container_of(dev, struct usb_gadget, dev);
- DEBUG_SETUP("%s: the_controller: 0x%p, p: 0x%p\n", __func__,
the_controller, p);
debug() and fix this message, otherwise:
Damn, I shouldn't have avoided reviewing them if I knew the remaining ones were so short. But after the first one, I was quite scared of what's coming next. Either way, here you go, fix these few issues and you're in mainline ;-)
- the_controller->gadget.dev.device_data = p;
- return gadget->dev.device_data;
Hi Marek,
__func__,
the_controller, p);
The DEBUG_SETUP macro has been used to be in sync with the already available udc driver. This driver has different DEBUG_* macros, which helps in debugging different parts of UDC driver.
If this is MUST, then I will change it, otherwise I'd like to leave it alone.
Is it OK with you?
Thanks, please pull them to your u-boot-usb tree. (and also the patch: http://patchwork.ozlabs.org/patch/151983/ is also acked-by)
Hi Marek,
__func__,
the_controller, p);
Ok, so be it.
Is it OK with you?
It's fine then, thanks for clearing this.
Will do, thanks for pointing out the other patch :) One more time, sorry for the delay.
Hi Marek,
No problem :-)
__func__,
the_controller, p);
I think Marek has a good point here. It was an oversight that this "private" DEBUG_ stuff slipped into mainline. This should never have happened. We tried hard to get rid of such conditionally compiled code for debug() with the rest of the code, so we should not start re-adding all this again.
Is it OK with you?
Sorry, but I object.
At the moment, only include/usb/s3c_udc.h defines this, i. e. it is not a generally usable feature anyway. In anyu case, this implementation needs to get fixed. See the code for the debug() implementation for an example.
Instead of defining your own set of private macros, you can use debug_cond() instead - this works without #ifdef's.
Thanks.
__func__,
the_controller, p);
Is it OK with you?
So I will change this patch accordingly and replace DEBUG_SETUP with debug macro.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/usb/gadget/s3c_udc_otg.c | 14 +++++++++++++- 1 files changed, 13 insertions(+), 1 deletions(-)
diff --git a/drivers/usb/gadget/s3c_udc_otg.c b/drivers/usb/gadget/s3c_udc_otg.c index f7f7b54..1b589b2 100644 --- a/drivers/usb/gadget/s3c_udc_otg.c +++ b/drivers/usb/gadget/s3c_udc_otg.c @@ -30,7 +30,7 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA * */ - +#undef DEBUG #include <common.h> #include <asm/errno.h> #include <linux/list.h> @@ -133,6 +133,18 @@ static void nuke(struct s3c_ep *ep, int status); static int s3c_udc_set_halt(struct usb_ep *_ep, int value); static void s3c_udc_set_nak(struct s3c_ep *ep);
+void set_udc_gadget_private_data(void *p) +{ + debug("%s: the_controller: 0x%p, p: 0x%p\n", __func__, + the_controller, p); + the_controller->gadget.dev.device_data = p; +} + +void *get_udc_gadget_private_data(struct usb_gadget *gadget) +{ + return gadget->dev.device_data; +} + static struct usb_ep_ops s3c_ep_ops = { .enable = s3c_ep_enable, .disable = s3c_ep_disable,
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307
USA * */
+#undef DEBUG
You don't need to undef it :)
- debug("%s: the_controller: 0x%p, p: 0x%p\n", __func__,
the_controller, p);
In message 1335797479-1091-1-git-send-email-l.majewski@samsung.com you wrote:
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+#undef DEBUG
Sorry, but please do not define what is not defined anyway.
the_controller, p);
Hm... you chose the easy way.
My hope was that you would pick up my hint and keep the functionality, and just convert it to debug_cond() instead.
For example, as is DEBUG_SETUP() would become "active" only when DEBUG_S3C_UDC_SETUP is defined; see "include/usb/s3c_udc.h". If we change the plain "#define DEBUG_S3C_UDC_SETUP" into a "#define DEBUG_S3C_UDC_SETUP 1", then we can replace all use of
DEBUG_SETUP(foo, ...);
by the standard
debug_cond(DEBUG_S3C_UDC_SETUP != 0, foo, ...);
And similar for all the other DEBUG_S3C_* macros in "include/usb/s3c_udc.h"
That would be much more useful, wouldn't it?
Hi Wolfgang,
02111-1307 USA * */
+#undef DEBUG
the_controller, p);
by the standard
Thank you for detailed debug_cond explanation.
I will look into the code and refactor it.
Hi Marek,
Can you look into this code? Since the 2012.04.01 is out (stable u-boot), I would like to improve the USB subsystem.
Moreover one commit: http://patchwork.ozlabs.org/patch/151983/
has been acked-by you, but it hasn't been added to u-boot-usb/next. Would it be possible to pull this code?
Hi Marek,
driver
Yes, it's on my slate ... I'm slightly congested now, I appologize for not reviewing these quickly, would you mind giving me a few more days please?
This patch set provides support for composite gadget framework. Files from Linux kernel (2.6.36) - namely composite.{c|h} have been ported.
Some extra "compatibility" code has been added as well.
Lukasz Majewski (4): usb:gadget:composite Composite framework - files from Linux kernel usb:gadget:composite: Linux composite.{h/c} code adjustement for u-boot usb:gadget: Wrapper for extracting usb_gadget from linux's device usb:gadget: Extend device struct to device_data pointer
I just pushed new u-boot-usb (rebased on current u-boot head), can you please rebase your patches ?
Is it correct to assume I can drop the following patches as we'll be seeing new revision?
[U-Boot,6/6] usb:g_dnl: Support for g_dnl download usb gadget for TRATS board 2012-04-12 Łukasz Majewski marex Under Review [U-Boot,5/6] usb:g_dnl: Support for g_dnl download usb gadget for GONI board 2012-04-12 Łukasz Majewski marex Under Review [U-Boot,4/6] usb:command: Support for USB Download command 2012-04-12 Łukasz Majewski marex Under Review [U-Boot,3/6] usb:g_dnl:thor: THOR protocol back end support for f_usbd_thor function 2012-04-12 Łukasz Majewski marex Under Review [U-Boot,2/6] usb:g_dnl:f_usbd_thor: USB Download function to support THOR protocol 2012-04-12 Łukasz Majewski marex Under Review [U-Boot,1/6] usb:composite:g_dnl: Composite gadget (g_dnl) for USB downloading functions 2012-04-12 Łukasz Majewski marex Under Review [U-Boot] usb:udc:samsung Add functions for storing private gadget data in UDC driver 2012-04-12 Łukasz Majewski marex Under Review [U-Boot,4/4] usb:gadget: Extend device struct to device_data pointer 2012-04-12 Łukasz Majewski marex Under Review [U-Boot,3/4] usb:gadget: Wrapper for extracting usb_gadget from linux's device 2012-04-12 Łukasz Majewski marex Under Review [U-Boot,2/4] usb:gadget:composite: Linux composite.{h/c} code adjustement for u- boot 2012-04-12 Łukasz Majewski marex Under Review [U-Boot,1/4] usb:gadget:composite Composite framework - files from Linux kernel 2012-04-12 Łukasz Majewski marex Under Review [U-Boot] usb:udc: Remove duplicated USB definitions from include/linux/usb/ch9.h file 2012-04-12 Łukasz Majewski marex Under Review
drivers/usb/gadget/composite.c | 1253 ++++++++++++++++++++++++++++++++++++++++ include/linux/usb/composite.h | 417 +++++++++++++ include/linux/usb/gadget.h | 6 + 3 files changed, 1676 insertions(+), 0 deletions(-) create mode 100644 drivers/usb/gadget/composite.c create mode 100644 include/linux/usb/composite.h
Hi Marek,
It is a little bit messy with so many patches flying around :-)
To make it a bit clear:
It is possible to apply following patches to u-boot-usb/next branch (or u-boot-usb/master which are the same) on denx.de (in this order):
http://patchwork.ozlabs.org/patch/151983/ http://patchwork.ozlabs.org/patch/153532/ http://patchwork.ozlabs.org/patch/153533/
Please apply above patches to usb next/master branch.
Moreover the following patch
http://patchwork.ozlabs.org/patch/153531/
was criticized by Wolfgang for the DEBUG_SETUP( macro.
You can pull it to the next/master and I will make the patch for UDC to remove those macros, or I will prepare the UDC patch and then resend this one.
The first solution is more convenient for me, but it is up to You how we will proceed.
Other patches can be dropped (for now).
Hi Marek,
u-boot
Thanks for clearing this up, can you please rebase them? I think they don't apply :(
Lukasz Majewski
