[U-Boot] [PATCH v2] net/phy: refactor RTL8211F initialization
RTL8211F needs to enalbe TXDLY for RGMII during phy initialization, so move it to rtl8211f_config for early initialization.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com cc: Joe Hershberger joe.hershberger@gmail.com --- v2: add default page and use macro instead of magic number.
drivers/net/phy/realtek.c | 33 +++++++++++++++++++++++++-------- 1 file changed, 25 insertions(+), 8 deletions(-)
diff --git a/drivers/net/phy/realtek.c b/drivers/net/phy/realtek.c index 3917c82..7e1c316 100644 --- a/drivers/net/phy/realtek.c +++ b/drivers/net/phy/realtek.c @@ -32,6 +32,7 @@ #define MIIM_RTL8211F_PHYSTAT_LINK 0x0004
#define MIIM_RTL8211F_PAGE_SELECT 0x1f +#define MIIM_RTL8211F_TX_DELAY 0x100
/* RealTek RTL8211x */ static int rtl8211x_config(struct phy_device *phydev) @@ -43,6 +44,29 @@ static int rtl8211x_config(struct phy_device *phydev) return 0; }
+static int rtl8211f_config(struct phy_device *phydev) +{ + u16 reg; + + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII) { + /* enable TXDLY */ + phy_write(phydev, MDIO_DEVAD_NONE, + MIIM_RTL8211F_PAGE_SELECT, 0xd08); + reg = phy_read(phydev, MDIO_DEVAD_NONE, 0x11); + reg |= MIIM_RTL8211F_TX_DELAY; + phy_write(phydev, MDIO_DEVAD_NONE, 0x11, reg); + /* restore to default page 0 */ + phy_write(phydev, MDIO_DEVAD_NONE, + MIIM_RTL8211F_PAGE_SELECT, 0x0); + } + + genphy_config_aneg(phydev); + + return 0; +} + static int rtl8211x_parse_status(struct phy_device *phydev) { unsigned int speed; @@ -142,13 +166,6 @@ static int rtl8211f_parse_status(struct phy_device *phydev) phydev->speed = SPEED_10; }
- if (phydev->interface == PHY_INTERFACE_MODE_RGMII) { - /* enable TXDLY */ - phy_write(phydev, MDIO_DEVAD_NONE, - MIIM_RTL8211F_PAGE_SELECT, 0xd08); - phy_write(phydev, MDIO_DEVAD_NONE, 0x11, 0x109); - } - return 0; }
@@ -209,7 +226,7 @@ static struct phy_driver RTL8211F_driver = { .uid = 0x1cc916, .mask = 0xffffff, .features = PHY_GBIT_FEATURES, - .config = &rtl8211x_config, + .config = &rtl8211f_config, .startup = &rtl8211f_startup, .shutdown = &genphy_shutdown, };
On Fri, Apr 24, 2015 at 3:57 AM, Shengzhou Liu Shengzhou.Liu@freescale.com wrote:
Applied to u-boot-net/next, thanks! -Joe
Joe Hershberger
Shengzhou Liu
