[PATCH v5] fdt: Allow the devicetree to come from a bloblist
Standard passage provides for a bloblist to be passed from one firmware phase to the next. That can be used to pass the devicetree along as well. Add an option to support this.
Tests for this will be added as part of the Universal Payload work.
Signed-off-by: Simon Glass sjg@chromium.org --- The discussion on this was not resolved and is now important due to the bloblist series from Raymond. So I am sending it again since I believe this is a better starting point than building on OF_BOARD
Changes in v5: - Make OF_BLOBLIST default y - Make OF_BLOBLIST optional at runtime
Changes in v4: - Rebase to -next
common/bloblist.c | 1 + doc/develop/devicetree/control.rst | 3 ++ dts/Kconfig | 13 +++++++++ include/bloblist.h | 5 ++++ include/fdtdec.h | 6 ++-- lib/fdtdec.c | 44 +++++++++++++++++++++++------- 6 files changed, 60 insertions(+), 12 deletions(-)
diff --git a/common/bloblist.c b/common/bloblist.c index a22f6c12b0c..b07ede11cfe 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -48,6 +48,7 @@ static struct tag_name { { BLOBLISTT_ACPI_TABLES, "ACPI tables for x86" }, { BLOBLISTT_SMBIOS_TABLES, "SMBIOS tables for x86" }, { BLOBLISTT_VBOOT_CTX, "Chrome OS vboot context" }, + { BLOBLISTT_CONTROL_FDT, "Control FDT" },
/* BLOBLISTT_PROJECT_AREA */ { BLOBLISTT_U_BOOT_SPL_HANDOFF, "SPL hand-off" }, diff --git a/doc/develop/devicetree/control.rst b/doc/develop/devicetree/control.rst index cbb65c9b177..444c55de4e4 100644 --- a/doc/develop/devicetree/control.rst +++ b/doc/develop/devicetree/control.rst @@ -108,6 +108,9 @@ If CONFIG_OF_BOARD is defined, a board-specific routine will provide the devicetree at runtime, for example if an earlier bootloader stage creates it and passes it to U-Boot.
+If CONFIG_OF_BLOBLIST is defined, the devicetree comes from a bloblist passed +from a previous stage, if present. + If CONFIG_SANDBOX is defined, then it will be read from a file on startup. Use the -d flag to U-Boot to specify the file to read, -D for the default and -T for the test devicetree, used to run sandbox unit tests. diff --git a/dts/Kconfig b/dts/Kconfig index 00c0aeff893..352431d59a3 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -105,6 +105,19 @@ config OF_EMBED
endchoice
+config OF_BLOBLIST + bool "Provided by a bloblist at runtime" + depends on BLOBLIST + default y + help + Select this to read the devicetree from the bloblist. This allows + using a bloblist to transfer the devicetree between U-Boot phases. + The devicetree is stored in the bloblist by an early phase so that + U-Boot can read it. + + If the bloblist does not contain a devicetree, then other methods will + be used. + config OF_BOARD bool "Provided by the board (e.g a previous loader) at runtime" default y if SANDBOX || OF_HAS_PRIOR_STAGE diff --git a/include/bloblist.h b/include/bloblist.h index 080cc46a126..e16d122f4fb 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -103,6 +103,11 @@ enum bloblist_tag_t { BLOBLISTT_ACPI_TABLES = 0x104, /* ACPI tables for x86 */ BLOBLISTT_SMBIOS_TABLES = 0x105, /* SMBIOS tables for x86 */ BLOBLISTT_VBOOT_CTX = 0x106, /* Chromium OS verified boot context */ + /* + * Devicetree for use by firmware. On some platforms this is passed to + * the OS also + */ + BLOBLISTT_CONTROL_FDT = 0x107,
/* * Project-specific tags are permitted here. Projects can be open source diff --git a/include/fdtdec.h b/include/fdtdec.h index bd1149f46d0..e80de24076c 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -72,7 +72,7 @@ struct bd_info; * U-Boot is packaged as an ELF file, e.g. for debugging purposes * @FDTSRC_ENV: Provided by the fdtcontroladdr environment variable. This should * be used for debugging/development only - * @FDTSRC_NONE: No devicetree at all + * @FDTSRC_BLOBLIST: Provided by a bloblist from an earlier phase */ enum fdt_source_t { FDTSRC_SEPARATE, @@ -80,6 +80,7 @@ enum fdt_source_t { FDTSRC_BOARD, FDTSRC_EMBED, FDTSRC_ENV, + FDTSRC_BLOBLIST, };
/* @@ -1190,7 +1191,8 @@ int fdtdec_resetup(int *rescan); * * The existing devicetree is available at gd->fdt_blob * - * @err internal error code if we fail to setup a DTB + * @err: 0 on success, -EEXIST if the devicetree is already correct, or other + * internal error code if we fail to setup a DTB * @returns new devicetree blob pointer */ void *board_fdt_blob_setup(int *err); diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 4016bf3c113..af3026dd42b 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -7,6 +7,10 @@ */
#ifndef USE_HOSTCC + +#define LOG_CATEGORY LOGC_DT + +#include <bloblist.h> #include <boot_fit.h> #include <display_options.h> #include <dm.h> @@ -86,6 +90,7 @@ static const char *const fdt_src_name[] = { [FDTSRC_BOARD] = "board", [FDTSRC_EMBED] = "embed", [FDTSRC_ENV] = "env", + [FDTSRC_BLOBLIST] = "bloblist", };
const char *fdtdec_get_srcname(void) @@ -1662,23 +1667,42 @@ static void setup_multi_dtb_fit(void)
int fdtdec_setup(void) { - int ret; + int ret = -ENOENT; + + /* If allowing a bloblist, check that first */ + if (CONFIG_IS_ENABLED(OF_BLOBLIST)) { + ret = bloblist_maybe_init(); + if (!ret) { + gd->fdt_blob = bloblist_find(BLOBLISTT_CONTROL_FDT, 0); + if (gd->fdt_blob) { + gd->fdt_src = FDTSRC_BLOBLIST; + log_debug("Devicetree is in bloblist at %p\n", + gd->fdt_blob); + } else { + log_debug("No FDT found in bloblist\n"); + ret = -ENOENT; + } + } + }
- /* The devicetree is typically appended to U-Boot */ - if (IS_ENABLED(CONFIG_OF_SEPARATE)) { - gd->fdt_blob = fdt_find_separate(); - gd->fdt_src = FDTSRC_SEPARATE; - } else { /* embed dtb in ELF file for testing / development */ - gd->fdt_blob = dtb_dt_embedded(); - gd->fdt_src = FDTSRC_EMBED; + /* Otherwise, the devicetree is typically appended to U-Boot */ + if (ret) { + if (IS_ENABLED(CONFIG_OF_SEPARATE)) { + gd->fdt_blob = fdt_find_separate(); + gd->fdt_src = FDTSRC_SEPARATE; + } else { /* embed dtb in ELF file for testing / development */ + gd->fdt_blob = dtb_dt_embedded(); + gd->fdt_src = FDTSRC_EMBED; + } }
/* Allow the board to override the fdt address. */ if (IS_ENABLED(CONFIG_OF_BOARD)) { gd->fdt_blob = board_fdt_blob_setup(&ret); - if (ret) + if (!ret) + gd->fdt_src = FDTSRC_BOARD; + else if (ret != -EEXIST) return ret; - gd->fdt_src = FDTSRC_BOARD; }
/* Allow the early environment to override the fdt address */
[snip]
- int ret;
- int ret = -ENOENT;
- /* If allowing a bloblist, check that first */
- if (CONFIG_IS_ENABLED(OF_BLOBLIST)) {
if (!ret) {
if (gd->fdt_blob) {
gd->fdt_blob);
} else {
ret = -ENOENT;
- /* Otherwise, the devicetree is typically appended to U-Boot */
- if (ret) {
This whole if/else tree looks wrong today, and then wrong with this patch. If we have an embedded device tree, which should only be used for development (or special case needs, I _think_ some users today are using this for security type needs), it must win and be used. The over-ride switch was set, and should be used. Then, I don't know if we should be saying "the user provided a tree via OF_SEPARATE, it should be used" or "the device has passed us a tree via standard mechanism, it should be used" is the higher priority. I really don't know which is more valid.
