[PATCH V3 0/3] arm: dts: Sync k3-am62 with upstream kernel
Hopefully, third time is a charm.. ;)
I have picked up part of Sjoerd's series[1] to keep it constrained just to dts sync at this point rather than adding newer functionality on top.
You can find the full series in [2].
Attempting am625 as a start of a series of clean ups for device tree for u-boot, but will love to get any review comments to improve this series up.
This series also depends on: https://lore.kernel.org/r/20230724-ti-mdio-pinmux-v4-1-18541f976501@kernel.o... https://lore.kernel.org/r/20230722193151.117345-2-rogerq@kernel.org https://lore.kernel.org/r/20230722193151.117345-3-rogerq@kernel.org
baseline: master 197aa22e6506 Merge branch 'master' of git://git.denx.de/u-boot-coldfire
Boot log: https://gist.github.com/nmenon/a1705c385189c2367d8cad1debcf8155
changes since v2: * Typo fixups in commit messages - patches 1 and 3 * Picked up Roger's Reviewed-by
V2: https://lore.kernel.org/all/20230726151027.2517151-1-nm@ti.com/
Changes since V1: * Added dependency on CPSW cleanup patches. * Dropped the hack done in u-boot.dtsi to use kernel dts as is for cpsw
V1: https://lore.kernel.org/all/20230725125856.1807742-1-nm@ti.com/
Changes since RFC: * dependencies are all merged on master now. * No new dependencies in this series, though the issue with uboot dtb not working for kernel is not a regression, it should probably be handled as a fixup part of RC Cycle.
RFC: https://lore.kernel.org/u-boot/20230713072019.3153871-1-nm@ti.com/
Nishanth Menon (1): arm: dts: k3-am62: Bump dtsi from linux v6.5-rc1
Sjoerd Simons (2): omap: timer: add ti,am654-timer compatibility arm: mach-k3: am62: Add timer0 id to the dev list
arch/arm/dts/k3-am62-main.dtsi | 389 +++++++++++++++++++++++-- arch/arm/dts/k3-am62-mcu.dtsi | 66 +++++ arch/arm/dts/k3-am62-thermal.dtsi | 33 +++ arch/arm/dts/k3-am62-wakeup.dtsi | 33 ++- arch/arm/dts/k3-am62.dtsi | 11 +- arch/arm/dts/k3-am625-r5-sk.dts | 92 +----- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 33 +-- arch/arm/dts/k3-am625-sk.dts | 286 ++----------------- arch/arm/dts/k3-am625.dtsi | 54 +++- arch/arm/dts/k3-am62x-sk-common.dtsi | 412 +++++++++++++++++++++++++++ arch/arm/dts/k3-pinctrl.h | 53 ++++ arch/arm/mach-k3/am62x/dev-data.c | 1 + drivers/timer/omap-timer.c | 1 + 13 files changed, 1066 insertions(+), 398 deletions(-) create mode 100644 arch/arm/dts/k3-am62-thermal.dtsi create mode 100644 arch/arm/dts/k3-am62x-sk-common.dtsi create mode 100644 arch/arm/dts/k3-pinctrl.h
[1] https://lore.kernel.org/all/20230406185542.1179073-1-sjoerd@collabora.com/ [2] https://github.com/nmenon/fix-k3-dt-u-boot/commits/fdt-fixup-s1-am625-rev4
The TI AM654 timer is compatible with the omap-timer implementation, so add it to the compatible id list.
Signed-off-by: Sjoerd Simons sjoerd@collabora.com Reviewed-by: Roger Quadros rogerq@kernel.org Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Ravi Gunasekaran r-gunasekaran@ti.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Cc: Francesco Dolcini francesco@dolcini.it Cc: Wadim Egorov w.egorov@phytec.de Signed-off-by: Nishanth Menon nm@ti.com --- Changes since V2: - Fixup typos in commit message noticed by Andrew (Thanks) - Added Roger's reviewed-by V2: https://lore.kernel.org/all/20230726151027.2517151-2-nm@ti.com/ V1: https://lore.kernel.org/all/20230725125856.1807742-2-nm@ti.com/ Original Patch: https://lore.kernel.org/r/20230406185542.1179073-2-sjoerd@collabora.com
drivers/timer/omap-timer.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/timer/omap-timer.c b/drivers/timer/omap-timer.c index aa2e4360c1bb..9b6d97dae677 100644 --- a/drivers/timer/omap-timer.c +++ b/drivers/timer/omap-timer.c @@ -114,6 +114,7 @@ static const struct udevice_id omap_timer_ids[] = { { .compatible = "ti,am335x-timer" }, { .compatible = "ti,am4372-timer" }, { .compatible = "ti,omap5430-timer" }, + { .compatible = "ti,am654-timer" }, {} };
Timer0 is used by u-boot as the tick timer; Add it to the soc devices list so it can be enabled via the k3 power controller.
Signed-off-by: Sjoerd Simons sjoerd@collabora.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Roger Quadros rogerq@kernel.org Tested-by: Ravi Gunasekaran r-gunasekaran@ti.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Cc: Francesco Dolcini francesco@dolcini.it Cc: Wadim Egorov w.egorov@phytec.de Signed-off-by: Nishanth Menon nm@ti.com --- Changes since V2: - Added Roger's reviewed-by V2: https://lore.kernel.org/all/20230726151027.2517151-3-nm@ti.com/ V1: https://lore.kernel.org/all/20230725125856.1807742-3-nm@ti.com/ Original patch: https://lore.kernel.org/r/20230406185542.1179073-3-sjoerd@collabora.com
arch/arm/mach-k3/am62x/dev-data.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-k3/am62x/dev-data.c b/arch/arm/mach-k3/am62x/dev-data.c index 1a6f9e2ca03e..59c95df2a887 100644 --- a/arch/arm/mach-k3/am62x/dev-data.c +++ b/arch/arm/mach-k3/am62x/dev-data.c @@ -58,6 +58,7 @@ static struct ti_dev soc_dev_list[] = { PSC_DEV(161, &soc_lpsc_list[8]), PSC_DEV(162, &soc_lpsc_list[9]), PSC_DEV(75, &soc_lpsc_list[10]), + PSC_DEV(36, &soc_lpsc_list[11]), PSC_DEV(102, &soc_lpsc_list[11]), PSC_DEV(146, &soc_lpsc_list[11]), PSC_DEV(13, &soc_lpsc_list[12]),
Update the am62 and am625 device-trees from linux v6.5-rc1. This needed the following tweaks to the u-boot specific dtsi as well: - Switch tick-timer to the main_timer as it's now defined in the main dtsi - Secure proxies are defined in SoC dtsi - Drop duplicate nodes - u-boot.dtsi is includes in r5-sk, no need for either the definitions from main.dtsi OR duplication from u-boot.dtsi
Reviewed-by: Roger Quadros rogerq@kernel.org Cc: Francesco Dolcini francesco@dolcini.it Cc: Sjoerd Simons sjoerd@collabora.com Cc: Wadim Egorov w.egorov@phytec.de Signed-off-by: Nishanth Menon nm@ti.com --- Changes since V2: - Fixup typos in commit message (it was 6.5-rc1 rather than the 6.3-rc2) - Added Roger's reviewed-by
V2: https://lore.kernel.org/all/20230726151027.2517151-4-nm@ti.com/ V1: https://lore.kernel.org/all/20230725125856.1807742-4-nm@ti.com/
arch/arm/dts/k3-am62-main.dtsi | 389 +++++++++++++++++++++++-- arch/arm/dts/k3-am62-mcu.dtsi | 66 +++++ arch/arm/dts/k3-am62-thermal.dtsi | 33 +++ arch/arm/dts/k3-am62-wakeup.dtsi | 33 ++- arch/arm/dts/k3-am62.dtsi | 11 +- arch/arm/dts/k3-am625-r5-sk.dts | 92 +----- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 33 +-- arch/arm/dts/k3-am625-sk.dts | 286 ++----------------- arch/arm/dts/k3-am625.dtsi | 54 +++- arch/arm/dts/k3-am62x-sk-common.dtsi | 412 +++++++++++++++++++++++++++ arch/arm/dts/k3-pinctrl.h | 53 ++++ 11 files changed, 1064 insertions(+), 398 deletions(-) create mode 100644 arch/arm/dts/k3-am62-thermal.dtsi create mode 100644 arch/arm/dts/k3-am62x-sk-common.dtsi create mode 100644 arch/arm/dts/k3-pinctrl.h
diff --git a/arch/arm/dts/k3-am62-main.dtsi b/arch/arm/dts/k3-am62-main.dtsi index 4a42f1b2e314..2488e3a537fe 100644 --- a/arch/arm/dts/k3-am62-main.dtsi +++ b/arch/arm/dts/k3-am62-main.dtsi @@ -54,6 +54,12 @@ reg = <0x4044 0x8>; #phy-cells = <1>; }; + + epwm_tbclk: clock@4130 { + compatible = "ti,am62-epwm-tbclk", "syscon"; + reg = <0x4130 0x4>; + #clock-cells = <1>; + }; };
dmss: bus@48000000 { @@ -144,8 +150,8 @@ compatible = "ti,k2g-sci"; ti,host-id = <12>; mbox-names = "rx", "tx"; - mboxes= <&secure_proxy_main 12>, - <&secure_proxy_main 13>; + mboxes = <&secure_proxy_main 12>, + <&secure_proxy_main 13>; reg-names = "debug_messages"; reg = <0x00 0x44043000 0x00 0xfe0>;
@@ -178,6 +184,21 @@ dma-names = "tx", "rx1", "rx2"; };
+ secure_proxy_sa3: mailbox@43600000 { + compatible = "ti,am654-secure-proxy"; + #mbox-cells = <1>; + reg-names = "target_data", "rt", "scfg"; + reg = <0x00 0x43600000 0x00 0x10000>, + <0x00 0x44880000 0x00 0x20000>, + <0x00 0x44860000 0x00 0x20000>; + /* + * Marked Disabled: + * Node is incomplete as it is meant for bootloaders and + * firmware on non-MPU processors + */ + status = "disabled"; + }; + main_pmx0: pinctrl@f4000 { compatible = "pinctrl-single"; reg = <0x00 0xf4000 0x00 0x2ac>; @@ -186,6 +207,108 @@ pinctrl-single,function-mask = <0xffffffff>; };
+ main_esm: esm@420000 { + compatible = "ti,j721e-esm"; + reg = <0x00 0x420000 0x00 0x1000>; + ti,esm-pins = <160>, <161>, <162>, <163>, <177>, <178>; + }; + + main_timer0: timer@2400000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2400000 0x00 0x400>; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 36 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 36 2>; + assigned-clock-parents = <&k3_clks 36 3>; + power-domains = <&k3_pds 36 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer1: timer@2410000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2410000 0x00 0x400>; + interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 37 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 37 2>; + assigned-clock-parents = <&k3_clks 37 3>; + power-domains = <&k3_pds 37 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer2: timer@2420000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2420000 0x00 0x400>; + interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 38 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 38 2>; + assigned-clock-parents = <&k3_clks 38 3>; + power-domains = <&k3_pds 38 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer3: timer@2430000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2430000 0x00 0x400>; + interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 39 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 39 2>; + assigned-clock-parents = <&k3_clks 39 3>; + power-domains = <&k3_pds 39 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer4: timer@2440000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2440000 0x00 0x400>; + interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 40 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 40 2>; + assigned-clock-parents = <&k3_clks 40 3>; + power-domains = <&k3_pds 40 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer5: timer@2450000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2450000 0x00 0x400>; + interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 41 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 41 2>; + assigned-clock-parents = <&k3_clks 41 3>; + power-domains = <&k3_pds 41 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer6: timer@2460000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2460000 0x00 0x400>; + interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 42 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 42 2>; + assigned-clock-parents = <&k3_clks 42 3>; + power-domains = <&k3_pds 42 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer7: timer@2470000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2470000 0x00 0x400>; + interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 43 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 43 2>; + assigned-clock-parents = <&k3_clks 43 3>; + power-domains = <&k3_pds 43 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + main_uart0: serial@2800000 { compatible = "ti,am64-uart", "ti,am654-uart"; reg = <0x00 0x02800000 0x00 0x100>; @@ -193,6 +316,7 @@ power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 146 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart1: serial@2810000 { @@ -202,6 +326,7 @@ power-domains = <&k3_pds 152 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 152 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart2: serial@2820000 { @@ -211,6 +336,7 @@ power-domains = <&k3_pds 153 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 153 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart3: serial@2830000 { @@ -220,6 +346,7 @@ power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 154 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart4: serial@2840000 { @@ -229,6 +356,7 @@ power-domains = <&k3_pds 155 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 155 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart5: serial@2850000 { @@ -238,6 +366,7 @@ power-domains = <&k3_pds 156 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 156 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart6: serial@2860000 { @@ -247,6 +376,7 @@ power-domains = <&k3_pds 158 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 158 0>; clock-names = "fclk"; + status = "disabled"; };
main_i2c0: i2c@20000000 { @@ -258,6 +388,7 @@ power-domains = <&k3_pds 102 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 102 2>; clock-names = "fck"; + status = "disabled"; };
main_i2c1: i2c@20010000 { @@ -269,6 +400,7 @@ power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 103 2>; clock-names = "fck"; + status = "disabled"; };
main_i2c2: i2c@20020000 { @@ -280,6 +412,7 @@ power-domains = <&k3_pds 104 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 104 2>; clock-names = "fck"; + status = "disabled"; };
main_i2c3: i2c@20030000 { @@ -291,6 +424,7 @@ power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 105 2>; clock-names = "fck"; + status = "disabled"; };
main_spi0: spi@20100000 { @@ -300,7 +434,8 @@ #address-cells = <1>; #size-cells = <0>; power-domains = <&k3_pds 141 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 172 0>; + clocks = <&k3_clks 141 0>; + status = "disabled"; };
main_spi1: spi@20110000 { @@ -310,7 +445,8 @@ #address-cells = <1>; #size-cells = <0>; power-domains = <&k3_pds 142 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 173 0>; + clocks = <&k3_clks 142 0>; + status = "disabled"; };
main_spi2: spi@20120000 { @@ -320,7 +456,8 @@ #address-cells = <1>; #size-cells = <0>; power-domains = <&k3_pds 143 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 174 0>; + clocks = <&k3_clks 143 0>; + status = "disabled"; };
main_gpio_intr: interrupt-controller@a00000 { @@ -345,7 +482,7 @@ <193>, <194>, <195>; interrupt-controller; #interrupt-cells = <2>; - ti,ngpio = <87>; + ti,ngpio = <92>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 77 0>; @@ -362,7 +499,7 @@ <183>, <184>, <185>; interrupt-controller; #interrupt-cells = <2>; - ti,ngpio = <88>; + ti,ngpio = <52>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 78 0>; @@ -385,8 +522,11 @@ ti,clkbuf-sel = <0x7>; ti,otap-del-sel-legacy = <0x0>; ti,otap-del-sel-mmc-hs = <0x0>; - ti,otap-del-sel-ddr52 = <0x9>; - ti,otap-del-sel-hs200 = <0x6>; + ti,otap-del-sel-ddr52 = <0x5>; + ti,otap-del-sel-hs200 = <0x5>; + ti,itap-del-sel-legacy = <0xa>; + ti,itap-del-sel-mmc-hs = <0x1>; + status = "disabled"; };
sdhci1: mmc@fa00000 { @@ -397,19 +537,20 @@ clocks = <&k3_clks 58 5>, <&k3_clks 58 6>; clock-names = "clk_ahb", "clk_xin"; ti,trm-icp = <0x2>; - ti,otap-del-sel-legacy = <0x0>; + ti,otap-del-sel-legacy = <0x8>; ti,otap-del-sel-sd-hs = <0x0>; - ti,otap-del-sel-sdr12 = <0xf>; - ti,otap-del-sel-sdr25 = <0xf>; - ti,otap-del-sel-sdr50 = <0xc>; - ti,otap-del-sel-sdr104 = <0x6>; - ti,otap-del-sel-ddr50 = <0x9>; - ti,itap-del-sel-legacy = <0x0>; - ti,itap-del-sel-sd-hs = <0x0>; - ti,itap-del-sel-sdr12 = <0x0>; - ti,itap-del-sel-sdr25 = <0x0>; + ti,otap-del-sel-sdr12 = <0x0>; + ti,otap-del-sel-sdr25 = <0x0>; + ti,otap-del-sel-sdr50 = <0x8>; + ti,otap-del-sel-sdr104 = <0x7>; + ti,otap-del-sel-ddr50 = <0x4>; + ti,itap-del-sel-legacy = <0xa>; + ti,itap-del-sel-sd-hs = <0x1>; + ti,itap-del-sel-sdr12 = <0xa>; + ti,itap-del-sel-sdr25 = <0x1>; ti,clkbuf-sel = <0x7>; bus-width = <4>; + status = "disabled"; };
sdhci2: mmc@fa20000 { @@ -420,18 +561,65 @@ clocks = <&k3_clks 184 5>, <&k3_clks 184 6>; clock-names = "clk_ahb", "clk_xin"; ti,trm-icp = <0x2>; - ti,otap-del-sel-legacy = <0x0>; + ti,otap-del-sel-legacy = <0x8>; ti,otap-del-sel-sd-hs = <0x0>; - ti,otap-del-sel-sdr12 = <0xf>; - ti,otap-del-sel-sdr25 = <0xf>; - ti,otap-del-sel-sdr50 = <0xc>; - ti,otap-del-sel-sdr104 = <0x6>; - ti,otap-del-sel-ddr50 = <0x9>; - ti,itap-del-sel-legacy = <0x0>; - ti,itap-del-sel-sd-hs = <0x0>; - ti,itap-del-sel-sdr12 = <0x0>; - ti,itap-del-sel-sdr25 = <0x0>; + ti,otap-del-sel-sdr12 = <0x0>; + ti,otap-del-sel-sdr25 = <0x0>; + ti,otap-del-sel-sdr50 = <0x8>; + ti,otap-del-sel-sdr104 = <0x7>; + ti,otap-del-sel-ddr50 = <0x8>; + ti,itap-del-sel-legacy = <0xa>; + ti,itap-del-sel-sd-hs = <0xa>; + ti,itap-del-sel-sdr12 = <0xa>; + ti,itap-del-sel-sdr25 = <0x1>; ti,clkbuf-sel = <0x7>; + status = "disabled"; + }; + + usbss0: dwc3-usb@f900000 { + compatible = "ti,am62-usb"; + reg = <0x00 0x0f900000 0x00 0x800>; + clocks = <&k3_clks 161 3>; + clock-names = "ref"; + ti,syscon-phy-pll-refclk = <&wkup_conf 0x4008>; + #address-cells = <2>; + #size-cells = <2>; + power-domains = <&k3_pds 178 TI_SCI_PD_EXCLUSIVE>; + ranges; + status = "disabled"; + + usb0: usb@31000000 { + compatible = "snps,dwc3"; + reg =<0x00 0x31000000 0x00 0x50000>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ + <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; /* irq.0 */ + interrupt-names = "host", "peripheral"; + maximum-speed = "high-speed"; + dr_mode = "otg"; + }; + }; + + usbss1: dwc3-usb@f910000 { + compatible = "ti,am62-usb"; + reg = <0x00 0x0f910000 0x00 0x800>; + clocks = <&k3_clks 162 3>; + clock-names = "ref"; + ti,syscon-phy-pll-refclk = <&wkup_conf 0x4018>; + #address-cells = <2>; + #size-cells = <2>; + power-domains = <&k3_pds 179 TI_SCI_PD_EXCLUSIVE>; + ranges; + status = "disabled"; + + usb1: usb@31100000 { + compatible = "snps,dwc3"; + reg =<0x00 0x31100000 0x00 0x50000>; + interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ + <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; /* irq.0 */ + interrupt-names = "host", "peripheral"; + maximum-speed = "high-speed"; + dr_mode = "otg"; + }; };
fss: bus@fc00000 { @@ -456,6 +644,7 @@ power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>; #address-cells = <1>; #size-cells = <0>; + status = "disabled"; }; };
@@ -514,12 +703,13 @@ clocks = <&k3_clks 13 0>; clock-names = "fck"; bus_freq = <1000000>; + status = "disabled"; };
cpts@3d000 { compatible = "ti,j721e-cpts"; reg = <0x00 0x3d000 0x00 0x400>; - clocks = <&k3_clks 13 1>; + clocks = <&k3_clks 13 3>; clock-names = "cpts"; interrupts-extended = <&gic500 GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "cpts"; @@ -551,6 +741,7 @@ power-domains = <&k3_pds 51 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 51 0>; clock-names = "fck"; + status = "disabled"; };
ecap1: pwm@23110000 { @@ -560,6 +751,7 @@ power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 52 0>; clock-names = "fck"; + status = "disabled"; };
ecap2: pwm@23120000 { @@ -569,6 +761,7 @@ power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 53 0>; clock-names = "fck"; + status = "disabled"; };
main_mcan0: can@20701000 { @@ -583,5 +776,141 @@ <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; + }; + + main_rti0: watchdog@e000000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x00 0x0e000000 0x00 0x100>; + clocks = <&k3_clks 125 0>; + power-domains = <&k3_pds 125 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 125 0>; + assigned-clock-parents = <&k3_clks 125 2>; + }; + + main_rti1: watchdog@e010000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x00 0x0e010000 0x00 0x100>; + clocks = <&k3_clks 126 0>; + power-domains = <&k3_pds 126 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 126 0>; + assigned-clock-parents = <&k3_clks 126 2>; + }; + + main_rti2: watchdog@e020000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x00 0x0e020000 0x00 0x100>; + clocks = <&k3_clks 127 0>; + power-domains = <&k3_pds 127 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 127 0>; + assigned-clock-parents = <&k3_clks 127 2>; + }; + + main_rti3: watchdog@e030000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x00 0x0e030000 0x00 0x100>; + clocks = <&k3_clks 128 0>; + power-domains = <&k3_pds 128 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 128 0>; + assigned-clock-parents = <&k3_clks 128 2>; + }; + + main_rti15: watchdog@e0f0000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x00 0x0e0f0000 0x00 0x100>; + clocks = <&k3_clks 130 0>; + power-domains = <&k3_pds 130 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 130 0>; + assigned-clock-parents = <&k3_clks 130 2>; + }; + + epwm0: pwm@23000000 { + compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x23000000 0x00 0x100>; + power-domains = <&k3_pds 86 TI_SCI_PD_EXCLUSIVE>; + clocks = <&epwm_tbclk 0>, <&k3_clks 86 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + + epwm1: pwm@23010000 { + compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x23010000 0x00 0x100>; + power-domains = <&k3_pds 87 TI_SCI_PD_EXCLUSIVE>; + clocks = <&epwm_tbclk 1>, <&k3_clks 87 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + + epwm2: pwm@23020000 { + compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x23020000 0x00 0x100>; + power-domains = <&k3_pds 88 TI_SCI_PD_EXCLUSIVE>; + clocks = <&epwm_tbclk 2>, <&k3_clks 88 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + + mcasp0: audio-controller@2b00000 { + compatible = "ti,am33xx-mcasp-audio"; + reg = <0x00 0x02b00000 0x00 0x2000>, + <0x00 0x02b08000 0x00 0x400>; + reg-names = "mpu", "dat"; + interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "tx", "rx"; + + dmas = <&main_bcdma 0 0xc500 0>, <&main_bcdma 0 0x4500 0>; + dma-names = "tx", "rx"; + + clocks = <&k3_clks 190 0>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 190 0>; + assigned-clock-parents = <&k3_clks 190 2>; + power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; + }; + + mcasp1: audio-controller@2b10000 { + compatible = "ti,am33xx-mcasp-audio"; + reg = <0x00 0x02b10000 0x00 0x2000>, + <0x00 0x02b18000 0x00 0x400>; + reg-names = "mpu", "dat"; + interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "tx", "rx"; + + dmas = <&main_bcdma 0 0xc501 0>, <&main_bcdma 0 0x4501 0>; + dma-names = "tx", "rx"; + + clocks = <&k3_clks 191 0>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 191 0>; + assigned-clock-parents = <&k3_clks 191 2>; + power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; + }; + + mcasp2: audio-controller@2b20000 { + compatible = "ti,am33xx-mcasp-audio"; + reg = <0x00 0x02b20000 0x00 0x2000>, + <0x00 0x02b28000 0x00 0x400>; + reg-names = "mpu", "dat"; + interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "tx", "rx"; + + dmas = <&main_bcdma 0 0xc502 0>, <&main_bcdma 0 0x4502 0>; + dma-names = "tx", "rx"; + + clocks = <&k3_clks 192 0>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 192 0>; + assigned-clock-parents = <&k3_clks 192 2>; + power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; }; }; diff --git a/arch/arm/dts/k3-am62-mcu.dtsi b/arch/arm/dts/k3-am62-mcu.dtsi index f56c803560f2..19fc38157d94 100644 --- a/arch/arm/dts/k3-am62-mcu.dtsi +++ b/arch/arm/dts/k3-am62-mcu.dtsi @@ -14,6 +14,57 @@ pinctrl-single,function-mask = <0xffffffff>; };
+ mcu_esm: esm@4100000 { + compatible = "ti,j721e-esm"; + reg = <0x00 0x4100000 0x00 0x1000>; + ti,esm-pins = <0>, <1>, <2>, <85>; + }; + + /* + * The MCU domain timer interrupts are routed only to the ESM module, + * and not currently available for Linux. The MCU domain timers are + * of limited use without interrupts, and likely reserved by the ESM. + */ + mcu_timer0: timer@4800000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x4800000 0x00 0x400>; + clocks = <&k3_clks 35 2>; + clock-names = "fck"; + power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + status = "reserved"; + }; + + mcu_timer1: timer@4810000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x4810000 0x00 0x400>; + clocks = <&k3_clks 48 2>; + clock-names = "fck"; + power-domains = <&k3_pds 48 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + status = "reserved"; + }; + + mcu_timer2: timer@4820000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x4820000 0x00 0x400>; + clocks = <&k3_clks 49 2>; + clock-names = "fck"; + power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + status = "reserved"; + }; + + mcu_timer3: timer@4830000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x4830000 0x00 0x400>; + clocks = <&k3_clks 50 2>; + clock-names = "fck"; + power-domains = <&k3_pds 50 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + status = "reserved"; + }; + mcu_uart0: serial@4a00000 { compatible = "ti,am64-uart", "ti,am654-uart"; reg = <0x00 0x04a00000 0x00 0x100>; @@ -21,6 +72,7 @@ power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 149 0>; clock-names = "fclk"; + status = "disabled"; };
mcu_i2c0: i2c@4900000 { @@ -32,6 +84,7 @@ power-domains = <&k3_pds 106 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 106 2>; clock-names = "fck"; + status = "disabled"; };
mcu_spi0: spi@4b00000 { @@ -42,6 +95,7 @@ #size-cells = <0>; power-domains = <&k3_pds 147 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 147 0>; + status = "disabled"; };
mcu_spi1: spi@4b10000 { @@ -52,6 +106,7 @@ #size-cells = <0>; power-domains = <&k3_pds 148 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 148 0>; + status = "disabled"; };
mcu_gpio_intr: interrupt-controller@4210000 { @@ -81,4 +136,15 @@ clocks = <&k3_clks 79 0>; clock-names = "gpio"; }; + + mcu_rti0: watchdog@4880000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x00 0x04880000 0x00 0x100>; + clocks = <&k3_clks 131 0>; + power-domains = <&k3_pds 131 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 131 0>; + assigned-clock-parents = <&k3_clks 131 2>; + /* Tightly coupled to M4F */ + status = "reserved"; + }; }; diff --git a/arch/arm/dts/k3-am62-thermal.dtsi b/arch/arm/dts/k3-am62-thermal.dtsi new file mode 100644 index 000000000000..a358757e26f0 --- /dev/null +++ b/arch/arm/dts/k3-am62-thermal.dtsi @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include <dt-bindings/thermal/thermal.h> + +thermal_zones: thermal-zones { + main0_thermal: main0-thermal { + polling-delay-passive = <250>; /* milliSeconds */ + polling-delay = <500>; /* milliSeconds */ + thermal-sensors = <&wkup_vtm0 0>; + + trips { + main0_crit: main0-crit { + temperature = <105000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; + }; + + main1_thermal: main1-thermal { + polling-delay-passive = <250>; /* milliSeconds */ + polling-delay = <500>; /* milliSeconds */ + thermal-sensors = <&wkup_vtm0 1>; + + trips { + main1_crit: main1-crit { + temperature = <105000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; + }; +}; diff --git a/arch/arm/dts/k3-am62-wakeup.dtsi b/arch/arm/dts/k3-am62-wakeup.dtsi index 4090134676cf..eae052887186 100644 --- a/arch/arm/dts/k3-am62-wakeup.dtsi +++ b/arch/arm/dts/k3-am62-wakeup.dtsi @@ -26,16 +26,47 @@ power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 114 0>; clock-names = "fclk"; + status = "disabled"; };
wkup_i2c0: i2c@2b200000 { compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x02b200000 0x00 0x100>; + reg = <0x00 0x2b200000 0x00 0x100>; interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 107 4>; clock-names = "fck"; + status = "disabled"; + }; + + wkup_rtc0: rtc@2b1f0000 { + compatible = "ti,am62-rtc"; + reg = <0x00 0x2b1f0000 0x00 0x100>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 117 6> , <&k3_clks 117 0>; + clock-names = "vbus", "osc32k"; + power-domains = <&k3_pds 117 TI_SCI_PD_EXCLUSIVE>; + wakeup-source; + }; + + wkup_rti0: watchdog@2b000000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x00 0x2b000000 0x00 0x100>; + clocks = <&k3_clks 132 0>; + power-domains = <&k3_pds 132 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 132 0>; + assigned-clock-parents = <&k3_clks 132 2>; + /* Used by DM firmware */ + status = "reserved"; + }; + + wkup_vtm0: temperature-sensor@b00000 { + compatible = "ti,j7200-vtm"; + reg = <0x00 0xb00000 0x00 0x400>, + <0x00 0xb01000 0x00 0x400>; + power-domains = <&k3_pds 95 TI_SCI_PD_EXCLUSIVE>; + #thermal-sensor-cells = <1>; }; }; diff --git a/arch/arm/dts/k3-am62.dtsi b/arch/arm/dts/k3-am62.dtsi index 37fcbe7a3c33..5e72c445f37a 100644 --- a/arch/arm/dts/k3-am62.dtsi +++ b/arch/arm/dts/k3-am62.dtsi @@ -8,9 +8,10 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/pinctrl/k3.h> #include <dt-bindings/soc/ti,sci_pm_domain.h>
+#include "k3-pinctrl.h" + / { model = "Texas Instruments K3 AM625 SoC"; compatible = "ti,am625"; @@ -80,6 +81,7 @@ <0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>,
/* Wakeup Domain Range */ + <0x00 0x00b00000 0x00 0x00b00000 0x00 0x00002400>, /* VTM */ <0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>, <0x00 0x43000000 0x00 0x43000000 0x00 0x00020000>;
@@ -90,14 +92,17 @@ ranges = <0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>; /* Peripheral window */ };
- cbass_wakeup: bus@2b000000 { + cbass_wakeup: bus@b00000 { compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; - ranges = <0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>, /* Peripheral Window */ + ranges = <0x00 0x00b00000 0x00 0x00b00000 0x00 0x00002400>, /* VTM */ + <0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>, /* Peripheral Window */ <0x00 0x43000000 0x00 0x43000000 0x00 0x00020000>; }; }; + + #include "k3-am62-thermal.dtsi" };
/* Now include the peripherals for each bus segments */ diff --git a/arch/arm/dts/k3-am625-r5-sk.dts b/arch/arm/dts/k3-am625-r5-sk.dts index 3ec5bad73503..bf219226b974 100644 --- a/arch/arm/dts/k3-am625-r5-sk.dts +++ b/arch/arm/dts/k3-am625-r5-sk.dts @@ -9,7 +9,6 @@ #include "k3-am62-ddr.dtsi"
#include "k3-am625-sk-u-boot.dtsi" -#include "k3-am625-sk-binman.dtsi"
/ { aliases { @@ -19,31 +18,6 @@ serial3 = &main_uart1; };
- chosen { - stdout-path = "serial2:115200n8"; - tick-timer = &timer1; - }; - - memory@80000000 { - device_type = "memory"; - /* 2G RAM */ - reg = <0x00000000 0x80000000 0x00000000 0x80000000>; - - bootph-pre-ram; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - secure_ddr: optee@9e800000 { - reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ - alignment = <0x1000>; - no-map; - }; - }; - a53_0: a53@0 { compatible = "ti,am654-rproc"; reg = <0x00 0x00a90000 0x00 0x10>; @@ -81,80 +55,44 @@ ti,secure-host; };
-&cbass_mcu { - mcu_esm: esm@4100000 { - compatible = "ti,j721e-esm"; - reg = <0x0 0x4100000 0x0 0x1000>; - ti,esm-pins = <0>, <1>, <2>, <85>; - bootph-pre-ram; - }; +&mcu_esm { + bootph-pre-ram; };
-&cbass_main { - sa3_secproxy: secproxy@44880000 { - bootph-pre-ram; - compatible = "ti,am654-secure-proxy"; - #mbox-cells = <1>; - reg-names = "rt", "scfg", "target_data"; - reg = <0x00 0x44880000 0x00 0x20000>, - <0x0 0x44860000 0x0 0x20000>, - <0x0 0x43600000 0x0 0x10000>; - }; +&secure_proxy_sa3 { + bootph-pre-ram; + /* We require this for boot handshake */ + status = "okay"; +}; + +&main_esm { + bootph-pre-ram; +};
+&cbass_main { sysctrler: sysctrler { compatible = "ti,am654-system-controller"; - mboxes= <&secure_proxy_main 1>, <&secure_proxy_main 0>, <&sa3_secproxy 0>; + mboxes= <&secure_proxy_main 1>, <&secure_proxy_main 0>, <&secure_proxy_sa3 0>; mbox-names = "tx", "rx", "boot_notify"; bootph-pre-ram; }; - - main_esm: esm@420000 { - compatible = "ti,j721e-esm"; - reg = <0x0 0x420000 0x0 0x1000>; - ti,esm-pins = <160>, <161>, <162>, <163>, <177>, <178>; - bootph-pre-ram; - }; };
-&mcu_pmx0 { +&wkup_uart0_pins_default { bootph-pre-ram; - wkup_uart0_pins_default: wkup-uart0-pins-default { - pinctrl-single,pins = < - AM62X_MCU_IOPAD(0x02c, PIN_INPUT, 0) /* (C6) WKUP_UART0_CTSn */ - AM62X_MCU_IOPAD(0x030, PIN_OUTPUT, 0) /* (A4) WKUP_UART0_RTSn */ - AM62X_MCU_IOPAD(0x024, PIN_INPUT, 0) /* (B4) WKUP_UART0_RXD */ - AM62X_MCU_IOPAD(0x028, PIN_OUTPUT, 0) /* (C5) WKUP_UART0_TXD */ - >; - bootph-pre-ram; - }; };
-&main_pmx0 { +&main_uart1_pins_default { bootph-pre-ram; - main_uart1_pins_default: main-uart1-pins-default { - pinctrl-single,pins = < - AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19) MCASP0_AXR3.UART1_CTSn */ - AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19) MCASP0_AXR2.UART1_RTSn */ - AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19) MCASP0_AFSR.UART1_RXD */ - AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20) MCASP0_ACLKR.UART1_TXD */ - >; - bootph-pre-ram; - }; };
/* WKUP UART0 is used for DM firmware logs */ &wkup_uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&wkup_uart0_pins_default>; - status = "okay"; bootph-pre-ram; };
/* Main UART1 is used for TIFS firmware logs */ &main_uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&main_uart1_pins_default>; - status = "okay"; bootph-pre-ram; };
diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index a60c37f1dbf0..c1685bc9ca39 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -9,7 +9,7 @@ / { chosen { stdout-path = "serial2:115200n8"; - tick-timer = &timer1; + tick-timer = &main_timer0; };
aliases { @@ -21,16 +21,13 @@ }; };
-&cbass_main{ +&cbass_main { bootph-pre-ram; +};
- timer1: timer@2400000 { - compatible = "ti,omap5430-timer"; - reg = <0x00 0x2400000 0x00 0x80>; - ti,timer-alwon; - clock-frequency = <25000000>; - bootph-pre-ram; - }; +&main_timer0 { + clock-frequency = <25000000>; + bootph-pre-ram; };
&dmss { @@ -77,10 +74,6 @@ bootph-pre-ram; };
-&main_uart1 { - bootph-pre-ram; -}; - &cbass_mcu { bootph-pre-ram; }; @@ -93,10 +86,6 @@ bootph-pre-ram; };
-&wkup_uart0 { - bootph-pre-ram; -}; - &sdhci1 { bootph-pre-ram; }; @@ -130,17 +119,7 @@ };
&cpsw3g { - reg = <0x0 0x8000000 0x0 0x200000>, - <0x0 0x43000200 0x0 0x8>; - reg-names = "cpsw_nuss", "mac_efuse"; - /delete-property/ ranges; bootph-pre-ram; - - cpsw-phy-sel@04044 { - compatible = "ti,am64-phy-gmii-sel"; - reg = <0x0 0x00104044 0x0 0x8>; - bootph-pre-ram; - }; };
&cpsw_port1 { diff --git a/arch/arm/dts/k3-am625-sk.dts b/arch/arm/dts/k3-am625-sk.dts index af5617ff44d2..3f9ef4053aa6 100644 --- a/arch/arm/dts/k3-am625-sk.dts +++ b/arch/arm/dts/k3-am625-sk.dts @@ -7,28 +7,19 @@
/dts-v1/;
-#include <dt-bindings/leds/common.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/net/ti-dp83867.h> -#include "k3-am625.dtsi" +#include "k3-am62x-sk-common.dtsi"
/ { - compatible = "ti,am625-sk", "ti,am625"; + compatible = "ti,am625-sk", "ti,am625"; model = "Texas Instruments AM625 SK";
- aliases { - serial2 = &main_uart0; - mmc0 = &sdhci0; - mmc1 = &sdhci1; - mmc2 = &sdhci2; - spi0 = &ospi0; - ethernet0 = &cpsw_port1; - ethernet1 = &cpsw_port2; - }; - - chosen { - stdout-path = "serial2:115200n8"; - bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000"; + opp-table { + /* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */ + opp-1400000000 { + opp-hz = /bits/ 64 <1400000000>; + opp-supported-hw = <0x01 0x0004>; + clock-latency-ns = <6000000>; + }; };
memory@80000000 { @@ -38,39 +29,6 @@
- reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - ramoops@9ca00000 { - compatible = "ramoops"; - reg = <0x00 0x9ca00000 0x00 0x00100000>; - record-size = <0x8000>; - console-size = <0x8000>; - ftrace-size = <0x00>; - pmsg-size = <0x8000>; - }; - - secure_tfa_ddr: tfa@9e780000 { - reg = <0x00 0x9e780000 0x00 0x80000>; - alignment = <0x1000>; - no-map; - }; - - secure_ddr: optee@9e800000 { - reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ - alignment = <0x1000>; - no-map; - }; - - wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 { - compatible = "shared-dma-pool"; - reg = <0x00 0x9db00000 0x00 0xc00000>; - no-map; - }; - }; - vmain_pd: regulator-0 { /* TPS65988 PD CONTROLLER OUTPUT */ compatible = "regulator-fixed"; @@ -130,108 +88,20 @@ <3300000 0x1>; };
- leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&usr_led_pins_default>; - - led-0 { - label = "am62-sk:green:heartbeat"; - gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - function = LED_FUNCTION_HEARTBEAT; - default-state = "off"; - }; + vcc_1v8: regulator-5 { + /* output of TPS6282518DMQ */ + compatible = "regulator-fixed"; + regulator-name = "vcc_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3_sys>; + regulator-always-on; + regulator-boot-on; }; };
&main_pmx0 { - main_uart0_pins_default: main-uart0-pins-default { - pinctrl-single,pins = < - AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */ - AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */ - >; - }; - - main_i2c0_pins_default: main-i2c0-pins-default { - pinctrl-single,pins = < - AM62X_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */ - AM62X_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */ - >; - }; - - main_i2c1_pins_default: main-i2c1-pins-default { - pinctrl-single,pins = < - AM62X_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */ - AM62X_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */ - >; - }; - - main_i2c2_pins_default: main-i2c2-pins-default { - pinctrl-single,pins = < - AM62X_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */ - AM62X_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */ - >; - }; - - main_mmc0_pins_default: main-mmc0-pins-default { - pinctrl-single,pins = < - AM62X_IOPAD(0x220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */ - AM62X_IOPAD(0x218, PIN_INPUT, 0) /* (AB1) MMC0_CLK */ - AM62X_IOPAD(0x214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */ - AM62X_IOPAD(0x210, PIN_INPUT, 0) /* (AA1) MMC0_DAT1 */ - AM62X_IOPAD(0x20c, PIN_INPUT, 0) /* (AA3) MMC0_DAT2 */ - AM62X_IOPAD(0x208, PIN_INPUT, 0) /* (Y4) MMC0_DAT3 */ - AM62X_IOPAD(0x204, PIN_INPUT, 0) /* (AB2) MMC0_DAT4 */ - AM62X_IOPAD(0x200, PIN_INPUT, 0) /* (AC1) MMC0_DAT5 */ - AM62X_IOPAD(0x1fc, PIN_INPUT, 0) /* (AD2) MMC0_DAT6 */ - AM62X_IOPAD(0x1f8, PIN_INPUT, 0) /* (AC2) MMC0_DAT7 */ - >; - }; - - main_mmc1_pins_default: main-mmc1-pins-default { - pinctrl-single,pins = < - AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ - AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22) MMC1_CLK */ - AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */ - AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */ - AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */ - AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */ - AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17) MMC1_SDCD */ - >; - }; - - usr_led_pins_default: usr-led-pins-default { - pinctrl-single,pins = < - AM62X_IOPAD(0x244, PIN_OUTPUT, 7) /* (C17) MMC1_SDWP.GPIO1_49 */ - >; - }; - - main_mdio1_pins_default: main-mdio1-pins-default { - pinctrl-single,pins = < - AM62X_IOPAD(0x160, PIN_OUTPUT, 0) /* (AD24) MDIO0_MDC */ - AM62X_IOPAD(0x15c, PIN_INPUT, 0) /* (AB22) MDIO0_MDIO */ - >; - }; - - main_rgmii1_pins_default: main-rgmii1-pins-default { - pinctrl-single,pins = < - AM62X_IOPAD(0x14c, PIN_INPUT, 0) /* (AB17) RGMII1_RD0 */ - AM62X_IOPAD(0x150, PIN_INPUT, 0) /* (AC17) RGMII1_RD1 */ - AM62X_IOPAD(0x154, PIN_INPUT, 0) /* (AB16) RGMII1_RD2 */ - AM62X_IOPAD(0x158, PIN_INPUT, 0) /* (AA15) RGMII1_RD3 */ - AM62X_IOPAD(0x148, PIN_INPUT, 0) /* (AD17) RGMII1_RXC */ - AM62X_IOPAD(0x144, PIN_INPUT, 0) /* (AE17) RGMII1_RX_CTL */ - AM62X_IOPAD(0x134, PIN_OUTPUT, 0) /* (AE20) RGMII1_TD0 */ - AM62X_IOPAD(0x138, PIN_OUTPUT, 0) /* (AD20) RGMII1_TD1 */ - AM62X_IOPAD(0x13c, PIN_OUTPUT, 0) /* (AE18) RGMII1_TD2 */ - AM62X_IOPAD(0x140, PIN_OUTPUT, 0) /* (AD18) RGMII1_TD3 */ - AM62X_IOPAD(0x130, PIN_OUTPUT, 0) /* (AE19) RGMII1_TXC */ - AM62X_IOPAD(0x12c, PIN_OUTPUT, 0) /* (AD19) RGMII1_TX_CTL */ - >; - }; - - main_rgmii2_pins_default: main-rgmii2-pins-default { + main_rgmii2_pins_default: main-rgmii2-default-pins { pinctrl-single,pins = < AM62X_IOPAD(0x184, PIN_INPUT, 0) /* (AE23) RGMII2_RD0 */ AM62X_IOPAD(0x188, PIN_INPUT, 0) /* (AB20) RGMII2_RD1 */ @@ -248,7 +118,7 @@ >; };
- ospi0_pins_default: ospi0-pins-default { + ospi0_pins_default: ospi0-default-pins { pinctrl-single,pins = < AM62X_IOPAD(0x000, PIN_OUTPUT, 0) /* (H24) OSPI0_CLK */ AM62X_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F23) OSPI0_CSn0 */ @@ -264,77 +134,20 @@ >; };
- vdd_sd_dv_pins_default: vdd-sd-dv-pins-default { + vdd_sd_dv_pins_default: vdd-sd-dv-default-pins { pinctrl-single,pins = < AM62X_IOPAD(0x07c, PIN_OUTPUT, 7) /* (P25) GPMC0_CLK.GPIO0_31 */ >; };
- main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-pins-default { + main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-default-pins { pinctrl-single,pins = < AM62X_IOPAD(0x01d4, PIN_INPUT, 7) /* (B15) UART0_RTSn.GPIO1_23 */ >; }; };
-&wkup_uart0 { - /* WKUP UART0 is used by DM firmware */ - status = "reserved"; -}; - -&mcu_uart0 { - status = "disabled"; -}; - -&main_uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&main_uart0_pins_default>; -}; - -&main_uart1 { - /* Main UART1 is used by TIFS firmware */ - status = "reserved"; -}; - -&main_uart2 { - status = "disabled"; -}; - -&main_uart3 { - status = "disabled"; -}; - -&main_uart4 { - status = "disabled"; -}; - -&main_uart5 { - status = "disabled"; -}; - -&main_uart6 { - status = "disabled"; -}; - -&mcu_i2c0 { - status = "disabled"; -}; - -&wkup_i2c0 { - status = "disabled"; -}; - -&main_i2c0 { - status = "disabled"; - pinctrl-0 = <&main_i2c0_pins_default>; - clock-frequency = <400000>; -}; - &main_i2c1 { - status = "disabled"; - pinctrl-0 = <&main_i2c1_pins_default>; - clock-frequency = <400000>; - exp1: gpio@22 { compatible = "ti,tca6424"; reg = <0x22>; @@ -348,7 +161,7 @@ "UART1_FET_BUF_EN", "WL_LT_EN", "GPIO_HDMI_RSTn", "CSI_GPIO1", "CSI_GPIO2", "PRU_3V3_EN", - "HDMI_INTn", "TEST_GPIO2", + "HDMI_INTn", "PD_I2C_IRQ", "MCASP1_FET_EN", "MCASP1_BUF_BT_EN", "MCASP1_FET_SEL", "UART1_FET_SEL", "TSINT#", "IO_EXP_TEST_LED"; @@ -363,41 +176,14 @@ }; };
-&main_i2c2 { - status = "disabled"; -}; - -&main_i2c3 { - status = "disabled"; -}; - -&sdhci0 { - pinctrl-names = "default"; - pinctrl-0 = <&main_mmc0_pins_default>; - ti,driver-strength-ohm = <50>; - disable-wp; -}; - &sdhci1 { - /* SD/MMC */ vmmc-supply = <&vdd_mmc1>; vqmmc-supply = <&vdd_sd_dv>; - pinctrl-names = "default"; - pinctrl-0 = <&main_mmc1_pins_default>; - ti,driver-strength-ohm = <50>; - disable-wp; };
&cpsw3g { pinctrl-names = "default"; - pinctrl-0 = <&main_mdio1_pins_default - &main_rgmii1_pins_default - &main_rgmii2_pins_default>; -}; - -&cpsw_port1 { - phy-mode = "rgmii-rxid"; - phy-handle = <&cpsw3g_phy0>; + pinctrl-0 = <&main_rgmii1_pins_default>, <&main_rgmii2_pins_default>; };
&cpsw_port2 { @@ -406,13 +192,6 @@ };
&cpsw3g_mdio { - cpsw3g_phy0: ethernet-phy@0 { - reg = <0>; - ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; - ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; - ti,min-output-impedance; - }; - cpsw3g_phy1: ethernet-phy@1 { reg = <1>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; @@ -429,6 +208,7 @@ };
&ospi0 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&ospi0_pins_default>;
@@ -487,18 +267,6 @@ }; };
-&ecap0 { - status = "disabled"; -}; - -&ecap1 { - status = "disabled"; -}; - -&ecap2 { - status = "disabled"; -}; - -&main_mcan0 { - status = "disabled"; +&tlv320aic3106 { + DVDD-supply = <&vcc_1v8>; }; diff --git a/arch/arm/dts/k3-am625.dtsi b/arch/arm/dts/k3-am625.dtsi index 887f31c23fef..4193c2b3eed6 100644 --- a/arch/arm/dts/k3-am625.dtsi +++ b/arch/arm/dts/k3-am625.dtsi @@ -48,6 +48,8 @@ d-cache-line-size = <64>; d-cache-sets = <128>; next-level-cache = <&L2_0>; + operating-points-v2 = <&a53_opp_table>; + clocks = <&k3_clks 135 0>; };
cpu1: cpu@1 { @@ -62,6 +64,8 @@ d-cache-line-size = <64>; d-cache-sets = <128>; next-level-cache = <&L2_0>; + operating-points-v2 = <&a53_opp_table>; + clocks = <&k3_clks 136 0>; };
cpu2: cpu@2 { @@ -76,6 +80,8 @@ d-cache-line-size = <64>; d-cache-sets = <128>; next-level-cache = <&L2_0>; + operating-points-v2 = <&a53_opp_table>; + clocks = <&k3_clks 137 0>; };
cpu3: cpu@3 { @@ -90,13 +96,59 @@ d-cache-line-size = <64>; d-cache-sets = <128>; next-level-cache = <&L2_0>; + operating-points-v2 = <&a53_opp_table>; + clocks = <&k3_clks 138 0>; + }; + }; + + a53_opp_table: opp-table { + compatible = "operating-points-v2-ti-cpu"; + opp-shared; + syscon = <&wkup_conf>; + + opp-200000000 { + opp-hz = /bits/ 64 <200000000>; + opp-supported-hw = <0x01 0x0007>; + clock-latency-ns = <6000000>; + }; + + opp-400000000 { + opp-hz = /bits/ 64 <400000000>; + opp-supported-hw = <0x01 0x0007>; + clock-latency-ns = <6000000>; + }; + + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-supported-hw = <0x01 0x0007>; + clock-latency-ns = <6000000>; + }; + + opp-800000000 { + opp-hz = /bits/ 64 <800000000>; + opp-supported-hw = <0x01 0x0007>; + clock-latency-ns = <6000000>; + }; + + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-supported-hw = <0x01 0x0006>; + clock-latency-ns = <6000000>; + }; + + opp-1250000000 { + opp-hz = /bits/ 64 <1250000000>; + opp-supported-hw = <0x01 0x0004>; + clock-latency-ns = <6000000>; + opp-suspend; }; };
L2_0: l2-cache0 { compatible = "cache"; + cache-unified; cache-level = <2>; - cache-size = <0x40000>; + cache-size = <0x80000>; cache-line-size = <64>; cache-sets = <512>; }; diff --git a/arch/arm/dts/k3-am62x-sk-common.dtsi b/arch/arm/dts/k3-am62x-sk-common.dtsi new file mode 100644 index 000000000000..34c8ffc553ec --- /dev/null +++ b/arch/arm/dts/k3-am62x-sk-common.dtsi @@ -0,0 +1,412 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Common dtsi for AM62x SK and derivatives + * + * Copyright (C) 2021-2023 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include <dt-bindings/leds/common.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/net/ti-dp83867.h> +#include "k3-am625.dtsi" + +/ { + aliases { + serial2 = &main_uart0; + mmc0 = &sdhci0; + mmc1 = &sdhci1; + mmc2 = &sdhci2; + spi0 = &ospi0; + ethernet0 = &cpsw_port1; + ethernet1 = &cpsw_port2; + usb0 = &usb0; + usb1 = &usb1; + }; + + chosen { + stdout-path = "serial2:115200n8"; + }; + + memory@80000000 { + device_type = "memory"; + /* 2G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x80000000>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + ramoops@9ca00000 { + compatible = "ramoops"; + reg = <0x00 0x9ca00000 0x00 0x00100000>; + record-size = <0x8000>; + console-size = <0x8000>; + ftrace-size = <0x00>; + pmsg-size = <0x8000>; + }; + + secure_tfa_ddr: tfa@9e780000 { + reg = <0x00 0x9e780000 0x00 0x80000>; + alignment = <0x1000>; + no-map; + }; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ + alignment = <0x1000>; + no-map; + }; + + wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 { + compatible = "shared-dma-pool"; + reg = <0x00 0x9db00000 0x00 0xc00000>; + no-map; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&usr_led_pins_default>; + + led-0 { + label = "am62-sk:green:heartbeat"; + gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + function = LED_FUNCTION_HEARTBEAT; + default-state = "off"; + }; + }; + + tlv320_mclk: clk-0 { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12288000>; + }; + + codec_audio: sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "AM62x-SKEVM"; + simple-audio-card,widgets = + "Headphone", "Headphone Jack", + "Line", "Line In", + "Microphone", "Microphone Jack"; + simple-audio-card,routing = + "Headphone Jack", "HPLOUT", + "Headphone Jack", "HPROUT", + "LINE1L", "Line In", + "LINE1R", "Line In", + "MIC3R", "Microphone Jack", + "Microphone Jack", "Mic Bias"; + simple-audio-card,format = "dsp_b"; + simple-audio-card,bitclock-master = <&sound_master>; + simple-audio-card,frame-master = <&sound_master>; + simple-audio-card,bitclock-inversion; + + simple-audio-card,cpu { + sound-dai = <&mcasp1>; + }; + + sound_master: simple-audio-card,codec { + sound-dai = <&tlv320aic3106>; + clocks = <&tlv320_mclk>; + }; + }; +}; + +&main_pmx0 { + /* First pad number is ALW package and second is AMC package */ + main_uart0_pins_default: main-uart0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14/A13) UART0_RXD */ + AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14/E11) UART0_TXD */ + >; + }; + + main_uart1_pins_default: main-uart1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19/B18) MCASP0_AXR3.UART1_CTSn */ + AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19/B17) MCASP0_AXR2.UART1_RTSn */ + AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19/D15) MCASP0_AFSR.UART1_RXD */ + AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20/D16) MCASP0_ACLKR.UART1_TXD */ + >; + }; + + main_i2c0_pins_default: main-i2c0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16/E12) I2C0_SCL */ + AM62X_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16/D14) I2C0_SDA */ + >; + }; + + main_i2c1_pins_default: main-i2c1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17/A17) I2C1_SCL */ + AM62X_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17/A16) I2C1_SDA */ + >; + }; + + main_i2c2_pins_default: main-i2c2-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22/H18) GPMC0_CSn2.I2C2_SCL */ + AM62X_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24/H19) GPMC0_CSn3.I2C2_SDA */ + >; + }; + + main_mmc0_pins_default: main-mmc0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x220, PIN_INPUT, 0) /* (Y3/V3) MMC0_CMD */ + AM62X_IOPAD(0x218, PIN_INPUT, 0) /* (AB1/Y1) MMC0_CLK */ + AM62X_IOPAD(0x214, PIN_INPUT, 0) /* (AA2/V2) MMC0_DAT0 */ + AM62X_IOPAD(0x210, PIN_INPUT, 0) /* (AA1/V1) MMC0_DAT1 */ + AM62X_IOPAD(0x20c, PIN_INPUT, 0) /* (AA3/W2) MMC0_DAT2 */ + AM62X_IOPAD(0x208, PIN_INPUT, 0) /* (Y4/W1) MMC0_DAT3 */ + AM62X_IOPAD(0x204, PIN_INPUT, 0) /* (AB2/Y2) MMC0_DAT4 */ + AM62X_IOPAD(0x200, PIN_INPUT, 0) /* (AC1/W3) MMC0_DAT5 */ + AM62X_IOPAD(0x1fc, PIN_INPUT, 0) /* (AD2/W4) MMC0_DAT6 */ + AM62X_IOPAD(0x1f8, PIN_INPUT, 0) /* (AC2/V4) MMC0_DAT7 */ + >; + }; + + main_mmc1_pins_default: main-mmc1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21/C18) MMC1_CMD */ + AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22/A20) MMC1_CLK */ + AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22/A19) MMC1_DAT0 */ + AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21/B19) MMC1_DAT1 */ + AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21/B20) MMC1_DAT2 */ + AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22/C19) MMC1_DAT3 */ + AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17/C15) MMC1_SDCD */ + >; + }; + + usr_led_pins_default: usr-led-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x244, PIN_OUTPUT, 7) /* (C17/B15) MMC1_SDWP.GPIO1_49 */ + >; + }; + + main_mdio1_pins_default: main-mdio1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x160, PIN_OUTPUT, 0) /* (AD24/V17) MDIO0_MDC */ + AM62X_IOPAD(0x15c, PIN_INPUT, 0) /* (AB22/U16) MDIO0_MDIO */ + >; + }; + + main_rgmii1_pins_default: main-rgmii1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x14c, PIN_INPUT, 0) /* (AB17/W15) RGMII1_RD0 */ + AM62X_IOPAD(0x150, PIN_INPUT, 0) /* (AC17/Y16) RGMII1_RD1 */ + AM62X_IOPAD(0x154, PIN_INPUT, 0) /* (AB16/AA17) RGMII1_RD2 */ + AM62X_IOPAD(0x158, PIN_INPUT, 0) /* (AA15/Y15) RGMII1_RD3 */ + AM62X_IOPAD(0x148, PIN_INPUT, 0) /* (AD17/AA16) RGMII1_RXC */ + AM62X_IOPAD(0x144, PIN_INPUT, 0) /* (AE17/W14) RGMII1_RX_CTL */ + AM62X_IOPAD(0x134, PIN_OUTPUT, 0) /* (AE20/U14) RGMII1_TD0 */ + AM62X_IOPAD(0x138, PIN_OUTPUT, 0) /* (AD20/AA19) RGMII1_TD1 */ + AM62X_IOPAD(0x13c, PIN_OUTPUT, 0) /* (AE18/Y17) RGMII1_TD2 */ + AM62X_IOPAD(0x140, PIN_OUTPUT, 0) /* (AD18/AA18) RGMII1_TD3 */ + AM62X_IOPAD(0x130, PIN_OUTPUT, 0) /* (AE19/W16) RGMII1_TXC */ + AM62X_IOPAD(0x12c, PIN_OUTPUT, 0) /* (AD19/V15) RGMII1_TX_CTL */ + >; + }; + + main_usb1_pins_default: main-usb1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18/E16) USB1_DRVVBUS */ + >; + }; + + main_mcasp1_pins_default: main-mcasp1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x090, PIN_INPUT, 2) /* (M24/K17) GPMC0_BE0N_CLE.MCASP1_ACLKX */ + AM62X_IOPAD(0x098, PIN_INPUT, 2) /* (U23/P21) GPMC0_WAIT0.MCASP1_AFSX */ + AM62X_IOPAD(0x08c, PIN_OUTPUT, 2) /* (L25/J17) GPMC0_WEN.MCASP1_AXR0 */ + AM62X_IOPAD(0x084, PIN_INPUT, 2) /* (L23/K20) GPMC0_ADVN_ALE.MCASP1_AXR2 */ + >; + }; +}; + +&mcu_pmx0 { + wkup_uart0_pins_default: wkup-uart0-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x02c, PIN_INPUT, 0) /* (C6/A7) WKUP_UART0_CTSn */ + AM62X_MCU_IOPAD(0x030, PIN_OUTPUT, 0) /* (A4/B4) WKUP_UART0_RTSn */ + AM62X_MCU_IOPAD(0x024, PIN_INPUT, 0) /* (B4/B5) WKUP_UART0_RXD */ + AM62X_MCU_IOPAD(0x028, PIN_OUTPUT, 0) /* (C5/C6) WKUP_UART0_TXD */ + >; + }; +}; + +&wkup_uart0 { + /* WKUP UART0 is used by DM firmware */ + status = "reserved"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; +}; + +&main_uart0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; +}; + +&main_uart1 { + /* Main UART1 is used by TIFS firmware */ + status = "reserved"; + pinctrl-names = "default"; + pinctrl-0 = <&main_uart1_pins_default>; +}; + +&main_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c0_pins_default>; + clock-frequency = <400000>; + + eeprom@51 { + /* AT24C512C-MAHM-T or M24512-DFMC6TG */ + compatible = "atmel,24c512"; + reg = <0x51>; + }; + + typec_pd0: tps6598x@3f { + compatible = "ti,tps6598x"; + reg = <0x3f>; + + connector { + compatible = "usb-c-connector"; + label = "USB-C"; + self-powered; + data-role = "dual"; + power-role = "sink"; + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + usb_con_hs: endpoint { + remote-endpoint = <&usb0_hs_ep>; + }; + }; + }; + }; + }; +}; + +&main_i2c1 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c1_pins_default>; + clock-frequency = <400000>; + + tlv320aic3106: audio-codec@1b { + #sound-dai-cells = <0>; + compatible = "ti,tlv320aic3106"; + reg = <0x1b>; + ai3x-micbias-vg = <1>; /* 2.0V */ + + /* Regulators */ + AVDD-supply = <&vcc_3v3_sys>; + IOVDD-supply = <&vcc_3v3_sys>; + DRVDD-supply = <&vcc_3v3_sys>; + }; +}; + +&sdhci0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_mmc0_pins_default>; + ti,driver-strength-ohm = <50>; + disable-wp; +}; + +&sdhci1 { + /* SD/MMC */ + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_mmc1_pins_default>; + ti,driver-strength-ohm = <50>; + disable-wp; +}; + +&cpsw3g { + pinctrl-names = "default"; + pinctrl-0 = <&main_rgmii1_pins_default>; +}; + +&cpsw_port1 { + phy-mode = "rgmii-rxid"; + phy-handle = <&cpsw3g_phy0>; +}; + +&cpsw3g_mdio { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_mdio1_pins_default>; + + cpsw3g_phy0: ethernet-phy@0 { + reg = <0>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + ti,min-output-impedance; + }; +}; + +&mailbox0_cluster0 { + mbox_m4_0: mbox-m4-0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; +}; + +&usbss0 { + status = "okay"; + ti,vbus-divider; +}; + +&usbss1 { + status = "okay"; + ti,vbus-divider; +}; + +&usb0 { + #address-cells = <1>; + #size-cells = <0>; + usb-role-switch; + + port@0 { + reg = <0>; + usb0_hs_ep: endpoint { + remote-endpoint = <&usb_con_hs>; + }; + }; +}; + +&usb1 { + dr_mode = "host"; + pinctrl-names = "default"; + pinctrl-0 = <&main_usb1_pins_default>; +}; + +&mcasp1 { + status = "okay"; + #sound-dai-cells = <0>; + + pinctrl-names = "default"; + pinctrl-0 = <&main_mcasp1_pins_default>; + + op-mode = <0>; /* MCASP_IIS_MODE */ + tdm-slots = <2>; + + serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ + 1 0 2 0 + 0 0 0 0 + 0 0 0 0 + 0 0 0 0 + >; + tx-num-evt = <32>; + rx-num-evt = <32>; +}; diff --git a/arch/arm/dts/k3-pinctrl.h b/arch/arm/dts/k3-pinctrl.h new file mode 100644 index 000000000000..c97548a3f42d --- /dev/null +++ b/arch/arm/dts/k3-pinctrl.h @@ -0,0 +1,53 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides constants for pinctrl bindings for TI's K3 SoC + * family. + * + * Copyright (C) 2018-2023 Texas Instruments Incorporated - https://www.ti.com/ + */ +#ifndef DTS_ARM64_TI_K3_PINCTRL_H +#define DTS_ARM64_TI_K3_PINCTRL_H + +#define PULLUDEN_SHIFT (16) +#define PULLTYPESEL_SHIFT (17) +#define RXACTIVE_SHIFT (18) + +#define PULL_DISABLE (1 << PULLUDEN_SHIFT) +#define PULL_ENABLE (0 << PULLUDEN_SHIFT) + +#define PULL_UP (1 << PULLTYPESEL_SHIFT | PULL_ENABLE) +#define PULL_DOWN (0 << PULLTYPESEL_SHIFT | PULL_ENABLE) + +#define INPUT_EN (1 << RXACTIVE_SHIFT) +#define INPUT_DISABLE (0 << RXACTIVE_SHIFT) + +/* Only these macros are expected be used directly in device tree files */ +#define PIN_OUTPUT (INPUT_DISABLE | PULL_DISABLE) +#define PIN_OUTPUT_PULLUP (INPUT_DISABLE | PULL_UP) +#define PIN_OUTPUT_PULLDOWN (INPUT_DISABLE | PULL_DOWN) +#define PIN_INPUT (INPUT_EN | PULL_DISABLE) +#define PIN_INPUT_PULLUP (INPUT_EN | PULL_UP) +#define PIN_INPUT_PULLDOWN (INPUT_EN | PULL_DOWN) + +#define AM62AX_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) +#define AM62AX_MCU_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) + +#define AM62X_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) +#define AM62X_MCU_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) + +#define AM64X_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) +#define AM64X_MCU_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) + +#define AM65X_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) +#define AM65X_WKUP_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) + +#define J721E_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) +#define J721E_WKUP_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) + +#define J721S2_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) +#define J721S2_WKUP_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) + +#define J784S4_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) +#define J784S4_WKUP_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) + +#endif
Reviewed-by: Maxime Ripard mripard@kernel.org
Thanks! Maxime
Tested-by: Maxime Ripard mripard@kernel.org
Thanks! Maxime
Maxime Ripard
Nishanth Menon
