[U-Boot] [U-Boot,v2] mpc85xx: inhibit bman portals by default
Not all portals might be managed and therefore visible. Set the isdr register so that the corresponding isr register won't be set. This is needed for deepsleep.
Signed-off-by: Jeffrey Ladouceur Jeffrey.Ladouceur@freescale.com ---
The following dependent patches should be applied first: http://patchwork.ozlabs.org/patch/403532 http://patchwork.ozlabs.org/patch/403533 http://patchwork.ozlabs.org/patch/403540 http://patchwork.ozlabs.org/patch/403534 http://patchwork.ozlabs.org/patch/403535 http://patchwork.ozlabs.org/patch/403538 http://patchwork.ozlabs.org/patch/403536 http://patchwork.ozlabs.org/patch/403539
Changes in v2: - Removed P1023RDS as it is no longer supported.
arch/powerpc/cpu/mpc85xx/portals.c | 41 +++++++++++++++++++++++++++++++++++ include/configs/B4860QDS.h | 8 +++++++ include/configs/P1023RDB.h | 8 +++++++ include/configs/P2041RDB.h | 8 +++++++ include/configs/T102xQDS.h | 8 +++++++ include/configs/T102xRDB.h | 8 +++++++ include/configs/T1040QDS.h | 8 +++++++ include/configs/T104xRDB.h | 8 +++++++ include/configs/T208xQDS.h | 8 +++++++ include/configs/T208xRDB.h | 8 +++++++ include/configs/T4240EMU.h | 8 +++++++ include/configs/T4240QDS.h | 8 +++++++ include/configs/T4240RDB.h | 8 +++++++ include/configs/corenet_ds.h | 8 +++++++ include/configs/km/kmp204x-common.h | 8 +++++++ 15 files changed, 153 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/portals.c b/arch/powerpc/cpu/mpc85xx/portals.c index 98815f8..4c2ee98 100644 --- a/arch/powerpc/cpu/mpc85xx/portals.c +++ b/arch/powerpc/cpu/mpc85xx/portals.c @@ -14,6 +14,44 @@ #include <asm/fsl_portals.h> #include <asm/fsl_liodn.h>
+#define MAX_PORTALS (CONFIG_SYS_BMAN_CINH_SIZE / CONFIG_SYS_BMAN_SP_CINH_SIZE) +void inhibit_bman_portals(void) +{ + void __iomem *addr = (void *)CONFIG_SYS_BMAN_CINH_BASE + + CONFIG_SYS_BMAN_SWP_ISDR_REG; + uint32_t val; + int portal_count = 0; + + /* Dynamically determine number of portals */ + do { + val = in_be32(addr); + if (val) { + printf("ERROR: should be zero at 0x%p\n", addr); + goto done; + } + out_be32(addr, -1); + val = in_be32(addr); + if (!val) { + /* end of portals */ + if (!portal_count) + printf("ERROR: No portals\n"); + goto done; + } + portal_count++; + addr += CONFIG_SYS_BMAN_SP_CINH_SIZE; + if (portal_count >= MAX_PORTALS) + goto done; + } while (1); + +done: + +#ifdef DEBUG + printf("BMan portal counted %u, defined is %u\n", + portal_count, CONFIG_SYS_BMAN_NUM_PORTALS); +#endif + return; +} + void setup_portals(void) { ccsr_qman_t *qman = (void *)CONFIG_SYS_FSL_QMAN_ADDR; @@ -38,6 +76,9 @@ void setup_portals(void) out_be32(&qman->qcsp_bare, (u32)(CONFIG_SYS_QMAN_MEM_PHYS >> 32)); #endif out_be32(&qman->qcsp_bar, (u32)CONFIG_SYS_QMAN_MEM_PHYS); + + /* Change default state of BMan ISDR portals to all 1s */ + inhibit_bman_portals(); }
/* Update portal containter to match LAW setup of portal in phy map */ diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index dc1a9bc..31f1d3f 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -641,6 +641,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index ba3da06..107db72 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -347,6 +347,14 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xff200000 #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08
/* For FM */ #define CONFIG_SYS_DPAA_FMAN diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 2e11aaa..686fc73 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -489,6 +489,14 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 10 #define CONFIG_SYS_QMAN_MEM_BASE 0xf4200000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 5f8f749..35834fa 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -724,6 +724,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 2960bd1..e54e100 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -685,6 +685,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 1d0664d..e6b8e10 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -607,6 +607,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 2bb86e4..e81a384 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -630,6 +630,14 @@ #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 2733358..002ac0b 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -617,6 +617,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 18 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 400d979..5e9680d 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -567,6 +567,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 18 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T4240EMU.h b/include/configs/T4240EMU.h index 53c69b0..4df8f10 100644 --- a/include/configs/T4240EMU.h +++ b/include/configs/T4240EMU.h @@ -85,6 +85,14 @@ #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 50 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 1e0f5ec..d26852c 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -417,6 +417,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 50 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 13f4bd3..e66383d 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -554,6 +554,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 50 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 72b7efa..d25e65a 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -495,6 +495,14 @@ #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 10 #define CONFIG_SYS_QMAN_MEM_BASE 0xf4200000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index a0f9d29..7862446 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -336,6 +336,14 @@ int get_scl(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 10 #define CONFIG_SYS_QMAN_MEM_BASE 0xf4200000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff4200000ull
Jeffrey Ladouceur
