[U-Boot] RR v3 PATCH: SMDK6400 Fix some build bug
Change from V1: patch 1: patch 2: Delete some compile information from commit. patch 3: Add LED modify information and Delete some compile information from commit. patch 4: Add new patch for SDRAM init.
Change frome v2: patch2: Modify Makefile for arch/arm/cpu/arm1176/s3c64xx/cpu_init.s in build error. It will generat redefine information for "mem_ctrl_asm_init" before the Modify. patch4: Modify the Sergei Shtylyov comments and change the SDRAM size variable for PHYS_SDRAM_SIZE_1.
I apply this patch and build ok.
Fix CONFIG_SYS_INIT_SP_ADDR undefined issue.
Signed-off-by: seedshope bocui107@gmail.com
diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h index 671f2c7..c9acf58 100644 --- a/include/configs/smdk6400.h +++ b/include/configs/smdk6400.h @@ -44,6 +44,11 @@ #define CONFIG_PERIPORT_BASE 0x70000000 #define CONFIG_PERIPORT_SIZE 0x13
+#define CONFIG_SYS_IRAM_BASE 0x0c000000 /* Internal SRAM base address */ +#define CONFIG_SYS_IRAM_SIZE 0x2000 /* 8 KB of internal SRAM memory */ +#define CONFIG_SYS_IRAM_END (CONFIG_SYS_IRAM_BASE + CONFIG_SYS_IRAM_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_IRAM_END - GENERATED_GBL_DATA_SIZE) + #define CONFIG_SYS_SDRAM_BASE 0x50000000
/* input clock of PLL: SMDK6400 has 12MHz input clock */
Modify Makefile for cpu_init.c and Start.s use some label,this defined u-boot.lds of arch/arm/cpu/arm1176. But SMDK6400 use the link script board/samsung/smdk6400/u-boot-nand.lds. So add some label form u-boot.lds to u-boot-nand.lds
diff --git a/arch/arm/cpu/arm1176/s3c64xx/Makefile b/arch/arm/cpu/arm1176/s3c64xx/Makefile index 0785b19..f4b9574 100644 --- a/arch/arm/cpu/arm1176/s3c64xx/Makefile +++ b/arch/arm/cpu/arm1176/s3c64xx/Makefile @@ -30,12 +30,15 @@ LIB = $(obj)lib$(SOC).o
SOBJS = reset.o
-COBJS-$(CONFIG_S3C6400) += cpu_init.o speed.o +COBJS-$(CONFIG_S3C6400) += speed.o COBJS-y += timer.o
+CPUINIT = cpu_init.o + OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) +CPUINIT := $(addprefix $(obj),$(CPUINIT))
-all: $(obj).depend $(START) $(LIB) +all: $(obj).depend $(START) $(LIB) $(CPUINIT)
$(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS)) diff --git a/board/samsung/smdk6400/u-boot-nand.lds b/board/samsung/smdk6400/u-boot-nand.lds index 29a4f61..2b87fc6 100644 --- a/board/samsung/smdk6400/u-boot-nand.lds +++ b/board/samsung/smdk6400/u-boot-nand.lds @@ -55,8 +55,29 @@ SECTIONS . = ALIGN(4); .mmudata : { *(.mmudata) }
- . = ALIGN(4); - __bss_start = .; - .bss : { *(.bss) . = ALIGN(4); } - _end = .; + . = ALIGN(4); + + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } + + .bss __rel_dyn_start (OVERLAY) : { + __bss_start = .; + *(.bss) + . = ALIGN(4); + _end = .; + } + + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } }
Signed-off-by: seedshopebocui107@gmail.com
SOBJS = reset.o
- OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y))
Not sure I get what's the problem and how exactly this changes solves it. Can you detail this particular issue?
Amicalement,
SOBJS = reset.o
The issue is mem_ctrl_asm_init redefine in arch/arm/cpu/arm1176/s3c64xx/cpu_init.s.
At first, the link script file include cpu_init.s in board/samsung/smd6400/u-boot-nand.s, If I separate the cpu_init.o from COBJS-$(CONFIG_S3C6400), I guess cmd_link_o_target will deal with cpu_init.o. So the link script will double link the cpu_init file.
I have two method to solve it. first: see the patch second: Modify the link script
But I feel, the first method is safe.
I asked a question. I will RR on next, The patch1 and patch3 have already ok, Do I only send patch2 and patch4?
Amicalement,
SOBJS = reset.o
The part of u-boot-nand.lds as following:
. = ALIGN(4); .text : { arch/arm/cpu/arm1176/start.o (.text) arch/arm/cpu/arm1176/s3c64xx/cpu_init.o (.text) *(.text) }
I reference start.s to get the patch.;-)
Thanks, seedshope
Amicalement,
Hi seedshope,
SOBJS = reset.o
From what follows it seems the problem is rather cpu_init.o being linked in twice. Correct?
Then you should fix the double linking by i) determining why the double linking happens and ii) properly linking once only.
It may be safe, but IIUC it does not properly address the issue and its root cause.
My personal practice is to re-send the whole patchset for each new version, because i) people can easily see the whole of the changes without having to go pick parts of previous versions and ii) it makes clear when a patch is removed or added to the set.
Amicalement,
Amicalement,
On 01/15/2011 12:39 AM, Albert ARIBAUD wrote:
Hi seedshope,
SOBJS = reset.o
maybe
Hi Alvert ARIBAUD,
I see the code for smdk6400. I found this code is very old. Before It can not add cmd_link_o_target in Makefile(arch/arm/cpu/arm1176/s3c64xx/Makefile), The file will only to compile. So the link script is ok.
But, Now, It is not. As far as I know, The linker script can do to link the first specified file for user. Since I do not full understand the cmd_link_o_target mechanism. So I only guess the command do some link work.
Maybe I am correct.
yes
ok
Thanks, seedshope
Amicalement,
Amicalement,
Hi seedshope,
SOBJS = reset.o
maybe
Hi Alvert ARIBAUD,
Maybe I am correct.
I don't want to accept this change on the off chance that it might be correct; before your next patch submission, please try building your code without this specific patch and positively find why the build fails.
Amicalement,
Hi seedshope,
SOBJS = reset.o
maybe
Hi Alvert ARIBAUD,
Maybe I am correct.
ok,
Thanks seedshope
Amicalement,
Hi seedshope,
SOBJS = reset.o
maybe
Hi Alvert ARIBAUD,
Maybe I am correct.
Hi Amicalement
I trace the issue, I find cmd_link_o_target will link the cpu_init.o file. If I add the file to u-boot-nand.lds file, The file will be link twice.
Now, It is good method to delete the file in u-boot-nand.s. Why? Before I think Nand Booting for the 4kb, If you don't link the file to the first 4kB, the system will be generate error. Because the mem initialization function will can't find.
But , Now , The nand booting will be generate in nand_spl, the generate u-boot img is limit for 4KB, So this is ok.
Do you think about?
Thanks, seedshope
Amicalement,
Add some relocation symbols to u-boot.lds and disable LED functions in start.s to support nand_spl.
diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 237dcfe..ae3706a 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -354,9 +354,11 @@ clbss_l:str r2, [r0] /* clear loop... */ cmp r0, r1 bne clbss_l
+#ifndef CONFIG_NAND_SPL bl coloured_LED_init bl red_LED_on #endif +#endif
/* * We are done. Do not return, instead branch to second part of board diff --git a/nand_spl/board/samsung/smdk6400/u-boot.lds b/nand_spl/board/samsung/smdk6400/u-boot.lds index 3ac6aa1..30b1573 100644 --- a/nand_spl/board/samsung/smdk6400/u-boot.lds +++ b/nand_spl/board/samsung/smdk6400/u-boot.lds @@ -55,7 +55,22 @@ SECTIONS __u_boot_cmd_end = .;
. = ALIGN(4); + + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } + + .bss __rel_dyn_start (OVERLAY) : { __bss_start = .; - .bss : { *(.bss) . = ALIGN(4); } + *(.bss) + . = ALIGN(4); _end = .; + } }
Since SDRAM init function have already change, So the SDRAM initial function must be change.
diff --git a/board/samsung/smdk6400/smdk6400.c b/board/samsung/smdk6400/smdk6400.c index 35aa40b..043d553 100644 --- a/board/samsung/smdk6400/smdk6400.c +++ b/board/samsung/smdk6400/smdk6400.c @@ -78,10 +78,18 @@ int board_init(void) return 0; }
-int dram_init(void) +void dram_init_banksize(void) { + DECLARE_GLOBAL_DATA_PTR; + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, \ + PHYS_SDRAM_1_SIZE);
return 0; }
Dear seedshope,
- DECLARE_GLOBAL_DATA_PTR;
Please move it to out of function.
- gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, \
Please remove "".
- PHYS_SDRAM_1_SIZE);
return 0; } -- 1.7.1
Thanks Minkyu Kang
On 01/14/2011 08:53 AM, Minkyu Kang wrote:
Dear seedshope,
I am sorry, DECLARE_GLOBAL_DATA_PTR have already defind in the head of the file, I will drop this declare.
Please remove "".
ok
Thanks, seedshope
PHYS_SDRAM_1_SIZE); return 0;
-- 1.7.1
Thanks Minkyu Kang
Albert ARIBAUD
Minkyu Kang
seedshope
