[U-Boot] [PATCH v2 0/3] sunxi-mmc: enable new clock mode on A64
A64 requires new clock mode on SD and eMMC controllers. Not using new clock mode causes stability issues of the driver - SPL may occasionally fail to load u-boot from SD for some particular SD card on some particular devices.
This series depends on "sunxi: add support for automatic delay calibration" from my Pinebook series.
Tested on Pinebook and Pine64-LTS. Fixes eMMC failures on Olinuxino-A64 [1]
[1] https://github.com/armbian/build/commit/03199b3879af24c94029460b8cdf0d41048a...
Vasily Khoruzhick (3): sunxi-mmc: introduce new MMC_SUNXI_HAS_MODE_SWITCH option sunxi-mmc: don't double clock for new mode unconditionally sunxi-mmc: use new mode on both controllers on A64
arch/arm/mach-sunxi/Kconfig | 2 ++ drivers/mmc/Kconfig | 4 ++++ drivers/mmc/sunxi_mmc.c | 19 +++++++++---------- 3 files changed, 15 insertions(+), 10 deletions(-)
A64 doesn't have a mode switch in CCM, and CCM_MMC_CTRL_MODE_SEL_NEW is not defined, so compilation fails if MMC_SUNXI_HAS_NEW_MODE is enabled
Introduce new MMC_SUNXI_HAS_MODE_SWITCH option to be able to ifdef usage of CCM_MMC_CTRL_MODE_SEL_NEW
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- arch/arm/mach-sunxi/Kconfig | 1 + drivers/mmc/Kconfig | 4 ++++ drivers/mmc/sunxi_mmc.c | 2 ++ 3 files changed, 7 insertions(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 560dc9b25d..66fff6c6d3 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -230,6 +230,7 @@ config MACH_SUN8I_A83T select PHY_SUN4I_USB select SUNXI_GEN_SUN6I select MMC_SUNXI_HAS_NEW_MODE + select MMC_SUNXI_HAS_MODE_SWITCH select SUPPORT_SPL
config MACH_SUN8I_H3 diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 27246ee465..3f7458d409 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -569,6 +569,10 @@ config MMC_SUNXI_HAS_NEW_MODE bool depends on MMC_SUNXI
+config MMC_SUNXI_HAS_MODE_SWITCH + bool + depends on MMC_SUNXI + config GENERIC_ATMEL_MCI bool "Atmel Multimedia Card Interface support" depends on DM_MMC && BLK && ARCH_AT91 diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 147eb9b4d5..b3526f5e3f 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -176,7 +176,9 @@ static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz)
if (new_mode) { #ifdef CONFIG_MMC_SUNXI_HAS_NEW_MODE +#ifdef CONFIG_MMC_SUNXI_HAS_MODE_SWITCH val = CCM_MMC_CTRL_MODE_SEL_NEW; +#endif setbits_le32(&priv->reg->ntsr, SUNXI_MMC_NTSR_MODE_SEL_NEW); #endif } else if (!calibrate) {
Simple update on commit message.
Tested-by: Jagan Teki jagan@amarulasolutions.com # Amarula A64-Relic
Applied to u-boot-sunxi/master
Comment in Linux driver says that clock needs to be doubled only if we use DDR modes, moreover divider has to be set accordingly.
U-boot driver doesn't declare support for any DDR modes and doesn't set internal clock divider in CLKCR, so it doubles clock unconditionally when new mode is used.
Some cards can't handle that and as result SPL fails to load u-boot.
Fixes: de9b1771c3b ("mmc: sunxi: Support new mode") Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- drivers/mmc/sunxi_mmc.c | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index b3526f5e3f..e50b2c3343 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -109,13 +109,6 @@ static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) calibrate = true; #endif
- /* - * The MMC clock has an extra /2 post-divider when operating in the new - * mode. - */ - if (new_mode) - hz = hz * 2; - if (hz <= 24000000) { pll = CCM_MMC_CTRL_OSCM24; pll_hz = 24000000;
Using new mode improves stability of eMMC and SD cards. Without it SPL fails to load u-boot from SD on Pinebook.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com Reviewed-by: Chen-Yu Tsai wens@csie.org --- arch/arm/mach-sunxi/Kconfig | 1 + drivers/mmc/sunxi_mmc.c | 10 +++++++--- 2 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 66fff6c6d3..3c54f5106d 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -282,6 +282,7 @@ config MACH_SUN50I select SUN6I_PRCM select SUNXI_DE2 select SUNXI_GEN_SUN6I + select MMC_SUNXI_HAS_NEW_MODE select SUPPORT_SPL select SUNXI_DRAM_DW select SUNXI_DRAM_DW_32BIT diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index e50b2c3343..2b6f3c2234 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -98,12 +98,16 @@ static int mmc_resource_init(int sdc_no) static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) { unsigned int pll, pll_hz, div, n, oclk_dly, sclk_dly; - bool new_mode = false; + bool new_mode = true; bool calibrate = false; u32 val = 0;
- if (IS_ENABLED(CONFIG_MMC_SUNXI_HAS_NEW_MODE) && (priv->mmc_no == 2)) - new_mode = true; + if (!IS_ENABLED(CONFIG_MMC_SUNXI_HAS_NEW_MODE)) + new_mode = false; + + /* A83 support new mode only on eMMC */ + if (IS_ENABLED(CONFIG_MACH_SUN8I_A83T) && priv->mmc_no != 2) + new_mode = false;
#if defined(CONFIG_MACH_SUN50I) || defined(CONFIG_MACH_SUN50I_H6) calibrate = true;
new_mode = true;
new_mode = false;
s/A83/A83T
Ping? I've got reports from several users that it fixes issues with different SD cards on Pinebook and Sopine. It would be nice to have it merged.
-- 2.19.1
Another gentle reminder - patches has been sitting in ML for almost 2 weeks with no review.
-- 2.19.1
Be wait for some time, I understand your concern and I'm working on priority basic (that I mentioned in IRC). will come to this series.
Jagan Teki
Vasily Khoruzhick
