[PATCH 0/4] common: Drop remaining includes in common.h (part A)
This series continues the removal of include files in the common.h header.
Simon Glass (4): common: Drop asm/global_data.h from common header common: Drop display_options.h from common header common: Drop linux/printk.h from common header Fix code style for time functions
arch/arc/lib/bootm.c | 1 + arch/arc/lib/cache.c | 1 + arch/arc/lib/cpu.c | 1 + arch/arc/lib/relocate.c | 1 + arch/arm/cpu/arm1136/mx35/generic.c | 1 + arch/arm/cpu/arm920t/imx/timer.c | 2 +- arch/arm/cpu/arm926ejs/armada100/dram.c | 1 + arch/arm/cpu/arm926ejs/armada100/timer.c | 1 + arch/arm/cpu/arm926ejs/mx25/generic.c | 1 + arch/arm/cpu/arm926ejs/mx27/timer.c | 1 + arch/arm/cpu/arm926ejs/mxs/mxs.c | 1 + arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 1 + arch/arm/cpu/arm926ejs/mxs/timer.c | 1 + arch/arm/cpu/arm926ejs/spear/spr_misc.c | 1 + arch/arm/cpu/arm926ejs/spear/timer.c | 1 + arch/arm/cpu/armv7/arch_timer.c | 1 + arch/arm/cpu/armv7/ls102xa/clock.c | 1 + arch/arm/cpu/armv7/ls102xa/cpu.c | 1 + arch/arm/cpu/armv7/ls102xa/fdt.c | 1 + arch/arm/cpu/armv7/ls102xa/timer.c | 1 + arch/arm/cpu/armv7/s5p-common/cpu_info.c | 2 + arch/arm/cpu/armv7/s5p-common/timer.c | 1 + arch/arm/cpu/armv7/s5p4418/cpu.c | 1 + arch/arm/cpu/armv7/stv0991/timer.c | 1 + arch/arm/cpu/armv7/sunxi/timer.c | 1 + arch/arm/cpu/armv7/vf610/generic.c | 1 + arch/arm/cpu/armv7/vf610/timer.c | 1 + arch/arm/cpu/armv7m/systick-timer.c | 1 + arch/arm/cpu/armv8/cache_v8.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 1 + .../armv8/fsl-layerscape/fsl_lsch2_speed.c | 1 + .../armv8/fsl-layerscape/fsl_lsch3_speed.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/mp.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/ppa.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/spl.c | 1 + arch/arm/cpu/armv8/generic_timer.c | 1 + arch/arm/cpu/armv8/s32v234/generic.c | 1 + arch/arm/cpu/armv8/sec_firmware.c | 1 + arch/arm/cpu/sa1100/timer.c | 2 +- arch/arm/include/asm/arch-rockchip/clock.h | 2 + arch/arm/include/asm/arch-tegra/clock.h | 2 + arch/arm/include/asm/arch-tegra/tegra_i2c.h | 2 + arch/arm/include/asm/global_data.h | 3 + arch/arm/include/asm/mach-imx/video.h | 4 +- arch/arm/include/asm/secure.h | 1 + arch/arm/include/asm/spl.h | 1 + arch/arm/include/asm/string.h | 2 - arch/arm/include/asm/ti-common/sys_proto.h | 2 + arch/arm/lib/bdinfo.c | 1 + arch/arm/lib/bootm-fdt.c | 1 + arch/arm/lib/bootm.c | 1 + arch/arm/lib/cache-cp15.c | 1 + arch/arm/lib/cache.c | 1 + arch/arm/lib/gic-v3-its.c | 1 + arch/arm/lib/image.c | 1 + arch/arm/lib/interrupts.c | 1 + arch/arm/lib/interrupts_64.c | 1 + arch/arm/lib/spl.c | 1 + arch/arm/lib/stack.c | 1 + arch/arm/mach-aspeed/ast2500/board_common.c | 1 + arch/arm/mach-at91/arm920t/clock.c | 1 + arch/arm/mach-at91/arm920t/timer.c | 1 + arch/arm/mach-at91/arm926ejs/clock.c | 1 + arch/arm/mach-at91/arm926ejs/eflash.c | 1 + arch/arm/mach-at91/arm926ejs/timer.c | 1 + arch/arm/mach-at91/armv7/clock.c | 1 + arch/arm/mach-at91/armv7/timer.c | 1 + arch/arm/mach-at91/spl_at91.c | 1 + arch/arm/mach-bcm283x/init.c | 1 + arch/arm/mach-davinci/cpu.c | 1 + arch/arm/mach-davinci/misc.c | 1 + arch/arm/mach-davinci/timer.c | 1 + arch/arm/mach-exynos/spl_boot.c | 1 + arch/arm/mach-imx/hab.c | 1 + arch/arm/mach-imx/imx8/ahab.c | 1 + arch/arm/mach-imx/imx8/clock.c | 1 + arch/arm/mach-imx/imx8/cpu.c | 1 + arch/arm/mach-imx/imx8/fdt.c | 2 + arch/arm/mach-imx/imx8/iomux.c | 1 + arch/arm/mach-imx/imx8/snvs_security_sc.c | 1 + arch/arm/mach-imx/imx8m/clock_imx8mm.c | 1 + arch/arm/mach-imx/imx8m/soc.c | 1 + arch/arm/mach-imx/misc.c | 1 + arch/arm/mach-imx/mx5/mx53_dram.c | 1 + arch/arm/mach-imx/mx6/litesom.c | 1 + arch/arm/mach-imx/mx6/opos6ul.c | 1 + arch/arm/mach-imx/mx7/clock.c | 1 + arch/arm/mach-imx/mx7ulp/clock.c | 1 + arch/arm/mach-imx/speed.c | 1 + arch/arm/mach-imx/spl.c | 1 + arch/arm/mach-imx/spl_imx_romapi.c | 1 + arch/arm/mach-imx/syscounter.c | 1 + arch/arm/mach-k3/am6_init.c | 1 + arch/arm/mach-k3/common.c | 2 + arch/arm/mach-k3/sysfw-loader.c | 1 + arch/arm/mach-mediatek/mt7623/init.c | 1 + arch/arm/mach-mediatek/mt7629/init.c | 1 + arch/arm/mach-mediatek/mt8512/init.c | 1 + arch/arm/mach-mediatek/mt8516/init.c | 1 + arch/arm/mach-mediatek/mt8518/init.c | 1 + arch/arm/mach-meson/board-axg.c | 1 + arch/arm/mach-meson/board-common.c | 1 + arch/arm/mach-meson/board-g12a.c | 1 + arch/arm/mach-meson/board-gx.c | 2 + arch/arm/mach-meson/board-info.c | 1 + arch/arm/mach-meson/sm.c | 1 + arch/arm/mach-mvebu/arm64-common.c | 1 + arch/arm/mach-mvebu/armada3700/cpu.c | 1 + arch/arm/mach-mvebu/armada8k/dram.c | 1 + arch/arm/mach-mvebu/dram.c | 1 + arch/arm/mach-mvebu/spl.c | 1 + arch/arm/mach-nexell/cmd_boot_linux.c | 1 + arch/arm/mach-octeontx/cpu.c | 1 + arch/arm/mach-octeontx2/cpu.c | 1 + arch/arm/mach-omap2/am33xx/board.c | 2 + arch/arm/mach-omap2/boot-common.c | 1 + arch/arm/mach-omap2/hwinit-common.c | 1 + arch/arm/mach-omap2/omap-cache.c | 1 + arch/arm/mach-omap2/omap3/am35x_musb.c | 1 + arch/arm/mach-omap2/omap3/emif4.c | 1 + arch/arm/mach-omap2/omap3/sdrc.c | 1 + arch/arm/mach-omap2/timer.c | 1 + arch/arm/mach-omap2/utils.c | 1 + arch/arm/mach-orion5x/dram.c | 1 + arch/arm/mach-orion5x/timer.c | 1 + arch/arm/mach-owl/soc.c | 1 + arch/arm/mach-rmobile/memmap-gen3.c | 1 + arch/arm/mach-rockchip/board.c | 1 + arch/arm/mach-rockchip/boot_mode.c | 1 + arch/arm/mach-rockchip/rk3036-board-spl.c | 1 + arch/arm/mach-rockchip/rk3036/rk3036.c | 1 + arch/arm/mach-rockchip/rk3128/rk3128.c | 1 + arch/arm/mach-rockchip/rk3188/rk3188.c | 2 + arch/arm/mach-rockchip/rk3288/rk3288.c | 1 + arch/arm/mach-rockchip/rk3308/rk3308.c | 1 + arch/arm/mach-rockchip/rk3328/rk3328.c | 1 + arch/arm/mach-rockchip/rk3368/rk3368.c | 1 + arch/arm/mach-rockchip/rk3399/rk3399.c | 2 + arch/arm/mach-rockchip/sdram.c | 1 + arch/arm/mach-rockchip/spl-boot-order.c | 1 + arch/arm/mach-rockchip/spl.c | 1 + arch/arm/mach-snapdragon/pinctrl-snapdragon.h | 2 +- arch/arm/mach-socfpga/board.c | 1 + arch/arm/mach-socfpga/clock_manager.c | 1 + arch/arm/mach-socfpga/clock_manager_agilex.c | 1 + arch/arm/mach-socfpga/clock_manager_s10.c | 1 + arch/arm/mach-socfpga/mailbox_s10.c | 1 + arch/arm/mach-socfpga/misc.c | 2 + arch/arm/mach-socfpga/misc_gen5.c | 1 + arch/arm/mach-socfpga/misc_s10.c | 1 + arch/arm/mach-socfpga/mmu-arm64_s10.c | 1 + arch/arm/mach-socfpga/reset_manager_arria10.c | 1 + arch/arm/mach-socfpga/reset_manager_s10.c | 1 + arch/arm/mach-socfpga/spl_a10.c | 1 + arch/arm/mach-socfpga/spl_agilex.c | 1 + arch/arm/mach-socfpga/spl_gen5.c | 1 + arch/arm/mach-socfpga/spl_s10.c | 1 + arch/arm/mach-socfpga/system_manager_s10.c | 1 + arch/arm/mach-stm32mp/boot_params.c | 1 + arch/arm/mach-stm32mp/bsec.c | 1 + arch/arm/mach-stm32mp/cmd_stm32key.c | 1 + .../cmd_stm32prog/cmd_stm32prog.c | 1 + .../mach-stm32mp/cmd_stm32prog/stm32prog.c | 2 + .../mach-stm32mp/cmd_stm32prog/stm32prog.h | 2 + .../cmd_stm32prog/stm32prog_serial.c | 2 + .../cmd_stm32prog/stm32prog_usb.c | 1 + arch/arm/mach-stm32mp/cpu.c | 2 + arch/arm/mach-stm32mp/dram_init.c | 1 + arch/arm/mach-stm32mp/fdt.c | 1 + .../mach-stm32mp/include/mach/stm32mp1_smc.h | 1 + arch/arm/mach-stm32mp/spl.c | 1 + arch/arm/mach-tegra/board.c | 1 + arch/arm/mach-tegra/board2.c | 1 + arch/arm/mach-tegra/cboot.c | 2 + arch/arm/mach-tegra/emc.c | 1 + arch/arm/mach-tegra/ivc.c | 1 + arch/arm/mach-tegra/pmc.c | 1 + arch/arm/mach-tegra/tegra124/xusb-padctl.c | 2 + arch/arm/mach-tegra/tegra20/clock.c | 1 + arch/arm/mach-tegra/tegra20/warmboot.c | 1 + arch/arm/mach-tegra/tegra210/xusb-padctl.c | 2 + arch/arm/mach-tegra/tegra30/clock.c | 1 + arch/arm/mach-tegra/xusb-padctl-common.c | 1 + arch/arm/mach-uniphier/board_late_init.c | 1 + .../mach-uniphier/boot-device/boot-device.c | 1 + arch/arm/mach-uniphier/clk/dpll-ld4.c | 1 + arch/arm/mach-uniphier/clk/dpll-pro4.c | 1 + arch/arm/mach-uniphier/dram/umc-ld4.c | 1 + arch/arm/mach-uniphier/dram/umc-pro4.c | 1 + arch/arm/mach-uniphier/dram/umc-sld8.c | 1 + arch/arm/mach-uniphier/memconf.c | 1 + arch/arm/mach-uniphier/spl_board_init.c | 1 + arch/arm/mach-versal/clk.c | 1 + arch/arm/mach-versal/cpu.c | 1 + arch/arm/mach-versal/mp.c | 1 + arch/arm/mach-zynq/clk.c | 1 + arch/arm/mach-zynq/timer.c | 1 + arch/arm/mach-zynqmp-r5/cpu.c | 1 + arch/arm/mach-zynqmp/clk.c | 1 + arch/arm/mach-zynqmp/cpu.c | 1 + arch/m68k/cpu/mcf5227x/cpu.c | 1 + arch/m68k/cpu/mcf5227x/speed.c | 1 + arch/m68k/cpu/mcf523x/cpu.c | 1 + arch/m68k/cpu/mcf523x/speed.c | 1 + arch/m68k/cpu/mcf52x2/cpu.c | 1 + arch/m68k/cpu/mcf52x2/speed.c | 1 + arch/m68k/cpu/mcf530x/speed.c | 1 + arch/m68k/cpu/mcf532x/cpu.c | 1 + arch/m68k/cpu/mcf532x/speed.c | 1 + arch/m68k/cpu/mcf5445x/cpu.c | 1 + arch/m68k/cpu/mcf5445x/speed.c | 1 + arch/m68k/cpu/mcf547x_8x/cpu.c | 1 + arch/m68k/cpu/mcf547x_8x/slicetimer.c | 1 + arch/m68k/cpu/mcf547x_8x/speed.c | 1 + arch/m68k/include/asm/immap.h | 1 + arch/m68k/lib/bdinfo.c | 1 + arch/m68k/lib/bootm.c | 1 + arch/m68k/lib/fec.c | 1 + arch/m68k/lib/time.c | 1 + arch/microblaze/cpu/interrupts.c | 1 + arch/microblaze/cpu/timer.c | 3 +- arch/microblaze/lib/bootm.c | 1 + arch/mips/include/asm/io.h | 1 + arch/mips/include/asm/spl.h | 1 + arch/mips/lib/boot.c | 1 + arch/mips/lib/bootm.c | 1 + arch/mips/lib/cache.c | 1 + arch/mips/lib/reloc.c | 1 + arch/mips/lib/stack.c | 1 + arch/mips/lib/traps.c | 1 + arch/mips/mach-ath79/ar933x/clk.c | 1 + arch/mips/mach-ath79/ar934x/clk.c | 1 + arch/mips/mach-ath79/ar934x/ddr.c | 1 + arch/mips/mach-ath79/cpu.c | 1 + arch/mips/mach-ath79/dram.c | 1 + arch/mips/mach-ath79/include/mach/ath79.h | 1 + arch/mips/mach-ath79/qca953x/clk.c | 1 + arch/mips/mach-ath79/qca956x/clk.c | 1 + arch/mips/mach-ath79/qca956x/ddr.c | 1 + arch/mips/mach-bmips/dram.c | 1 + arch/mips/mach-jz47xx/jz4780/jz4780.c | 1 + arch/mips/mach-mscc/cpu.c | 1 + arch/mips/mach-mscc/dram.c | 1 + arch/mips/mach-mtmips/cpu.c | 1 + arch/mips/mach-mtmips/ddr_cal.c | 1 + arch/mips/mach-mtmips/mt7628/ddr.c | 1 + arch/mips/mach-mtmips/mt7628/init.c | 1 + arch/mips/mach-mtmips/spl.c | 2 +- arch/mips/mach-octeon/bootoctlinux.c | 1 + arch/mips/mach-pic32/cpu.c | 1 + arch/nds32/lib/bootm.c | 1 + arch/nios2/cpu/cpu.c | 1 + arch/nios2/include/asm/io.h | 3 + arch/nios2/lib/cache.c | 1 + arch/powerpc/cpu/mpc83xx/cpu.c | 1 + arch/powerpc/cpu/mpc83xx/cpu_init.c | 1 + arch/powerpc/cpu/mpc83xx/fdt.c | 1 + arch/powerpc/cpu/mpc83xx/interrupts.c | 1 + arch/powerpc/cpu/mpc83xx/pci.c | 1 + arch/powerpc/cpu/mpc83xx/pcie.c | 1 + arch/powerpc/cpu/mpc83xx/spd_sdram.c | 1 + arch/powerpc/cpu/mpc83xx/speed.c | 1 + arch/powerpc/cpu/mpc83xx/spl_minimal.c | 1 + arch/powerpc/cpu/mpc83xx/traps.c | 1 + arch/powerpc/cpu/mpc85xx/commproc.c | 1 + arch/powerpc/cpu/mpc85xx/cpu.c | 2 + arch/powerpc/cpu/mpc85xx/cpu_init.c | 1 + arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 1 + arch/powerpc/cpu/mpc85xx/fdt.c | 1 + arch/powerpc/cpu/mpc85xx/mp.c | 1 + arch/powerpc/cpu/mpc85xx/serial_scc.c | 1 + arch/powerpc/cpu/mpc85xx/speed.c | 1 + arch/powerpc/cpu/mpc85xx/tlb.c | 2 + arch/powerpc/cpu/mpc85xx/traps.c | 1 + arch/powerpc/cpu/mpc86xx/cpu.c | 2 + arch/powerpc/cpu/mpc86xx/cpu_init.c | 1 + arch/powerpc/cpu/mpc86xx/fdt.c | 1 + arch/powerpc/cpu/mpc86xx/mp.c | 1 + arch/powerpc/cpu/mpc86xx/speed.c | 1 + arch/powerpc/cpu/mpc86xx/traps.c | 1 + arch/powerpc/cpu/mpc8xx/cpu.c | 2 + arch/powerpc/cpu/mpc8xx/fdt.c | 1 + arch/powerpc/cpu/mpc8xx/immap.c | 1 + arch/powerpc/cpu/mpc8xx/speed.c | 1 + arch/powerpc/cpu/mpc8xxx/cpu.c | 1 + arch/powerpc/cpu/mpc8xxx/law.c | 2 + arch/powerpc/cpu/mpc8xxx/pamu_table.c | 1 + arch/powerpc/lib/bat_rw.c | 1 + arch/powerpc/lib/bdinfo.c | 1 + arch/powerpc/lib/bootm.c | 1 + arch/powerpc/lib/interrupts.c | 2 +- arch/powerpc/lib/stack.c | 1 + arch/powerpc/lib/time.c | 5 +- arch/riscv/cpu/fu540/cache.c | 1 + arch/riscv/cpu/fu540/dram.c | 1 + arch/riscv/cpu/generic/dram.c | 1 + arch/riscv/lib/andes_plic.c | 1 + arch/riscv/lib/asm-offsets.c | 1 + arch/riscv/lib/bootm.c | 1 + arch/riscv/lib/fdt_fixup.c | 1 + arch/riscv/lib/image.c | 1 + arch/riscv/lib/interrupts.c | 1 + arch/riscv/lib/sifive_clint.c | 1 + arch/riscv/lib/smp.c | 2 + arch/riscv/lib/spl.c | 1 + arch/sandbox/cpu/cpu.c | 1 + arch/sandbox/cpu/spl.c | 1 + arch/sandbox/cpu/start.c | 1 + arch/sh/lib/board.c | 1 + arch/x86/cpu/apollolake/cpu_spl.c | 1 + arch/x86/cpu/apollolake/fsp_s.c | 1 + arch/x86/cpu/baytrail/fsp_configs.c | 1 + arch/x86/cpu/braswell/fsp_configs.c | 1 + arch/x86/cpu/broadwell/cpu.c | 1 + arch/x86/cpu/broadwell/cpu_from_spl.c | 1 + arch/x86/cpu/broadwell/cpu_full.c | 1 + arch/x86/cpu/broadwell/lpc.c | 1 + arch/x86/cpu/broadwell/northbridge.c | 1 + arch/x86/cpu/broadwell/pch.c | 1 + arch/x86/cpu/broadwell/pinctrl_broadwell.c | 1 + arch/x86/cpu/broadwell/refcode.c | 1 + arch/x86/cpu/broadwell/sata.c | 1 + arch/x86/cpu/broadwell/sdram.c | 1 + arch/x86/cpu/coreboot/coreboot.c | 1 + arch/x86/cpu/coreboot/sdram.c | 1 + arch/x86/cpu/coreboot/tables.c | 1 + arch/x86/cpu/cpu.c | 1 + arch/x86/cpu/cpu_x86.c | 1 + arch/x86/cpu/efi/payload.c | 1 + arch/x86/cpu/efi/sdram.c | 1 + arch/x86/cpu/i386/cpu.c | 1 + arch/x86/cpu/i386/interrupt.c | 1 + arch/x86/cpu/intel_common/acpi.c | 1 + arch/x86/cpu/intel_common/cpu.c | 1 + arch/x86/cpu/intel_common/cpu_from_spl.c | 1 + arch/x86/cpu/intel_common/itss.c | 1 + arch/x86/cpu/intel_common/lpc.c | 1 + arch/x86/cpu/intel_common/microcode.c | 1 + arch/x86/cpu/intel_common/mrc.c | 1 + arch/x86/cpu/irq.c | 1 + arch/x86/cpu/ivybridge/bd82x6x.c | 1 + arch/x86/cpu/ivybridge/cpu.c | 1 + arch/x86/cpu/ivybridge/fsp_configs.c | 1 + arch/x86/cpu/ivybridge/lpc.c | 1 + arch/x86/cpu/ivybridge/model_206ax.c | 1 + arch/x86/cpu/ivybridge/northbridge.c | 1 + arch/x86/cpu/ivybridge/sata.c | 1 + arch/x86/cpu/ivybridge/sdram_nop.c | 1 + arch/x86/cpu/mp_init.c | 1 + arch/x86/cpu/mtrr.c | 1 + arch/x86/cpu/qemu/dram.c | 1 + arch/x86/cpu/qemu/e820.c | 1 + arch/x86/cpu/quark/acpi.c | 1 + arch/x86/cpu/quark/dram.c | 1 + arch/x86/cpu/slimbootloader/sdram.c | 1 + arch/x86/cpu/slimbootloader/serial.c | 1 + arch/x86/cpu/slimbootloader/slimbootloader.c | 1 + arch/x86/cpu/tangier/pinmux.c | 1 + arch/x86/cpu/tangier/sdram.c | 1 + arch/x86/cpu/turbo.c | 1 + arch/x86/cpu/x86_64/cpu.c | 1 + arch/x86/include/asm/cpu_common.h | 1 + arch/x86/include/asm/fast_spi.h | 4 +- arch/x86/include/asm/io.h | 2 +- arch/x86/include/asm/mp.h | 2 + arch/x86/include/asm/mrccache.h | 2 + arch/x86/include/asm/u-boot-x86.h | 1 + arch/x86/lib/acpi_s3.c | 1 + arch/x86/lib/acpi_table.c | 1 + arch/x86/lib/asm-offsets.c | 1 + arch/x86/lib/bios.c | 1 + arch/x86/lib/bootm.c | 1 + arch/x86/lib/cmd_boot.c | 1 + arch/x86/lib/coreboot_table.c | 1 + arch/x86/lib/e820.c | 1 + arch/x86/lib/fsp/fsp_common.c | 1 + arch/x86/lib/fsp/fsp_dram.c | 1 + arch/x86/lib/fsp/fsp_graphics.c | 1 + arch/x86/lib/fsp1/fsp_common.c | 1 + arch/x86/lib/fsp1/fsp_dram.c | 1 + arch/x86/lib/fsp2/fsp_dram.c | 1 + arch/x86/lib/fsp2/fsp_meminit.c | 1 + arch/x86/lib/fsp2/fsp_silicon_init.c | 1 + arch/x86/lib/fsp2/fsp_support.c | 1 + arch/x86/lib/init_helpers.c | 1 + arch/x86/lib/mpspec.c | 1 + arch/x86/lib/mrccache.c | 1 + arch/x86/lib/physmem.c | 1 + arch/x86/lib/pinctrl_ich6.c | 1 + arch/x86/lib/pirq_routing.c | 1 + arch/x86/lib/relocate.c | 1 + arch/x86/lib/spl.c | 1 + arch/x86/lib/tables.c | 1 + arch/x86/lib/tpl.c | 1 + arch/xtensa/lib/bootm.c | 1 + board/AndesTech/adp-ae3xx/adp-ae3xx.c | 1 + board/AndesTech/adp-ag101p/adp-ag101p.c | 1 + board/AndesTech/ax25-ae350/ax25-ae350.c | 1 + board/Arcturus/ucp1020/spl.c | 1 + board/BuR/brppt1/board.c | 1 + board/BuR/brppt2/board.c | 1 + board/BuR/brsmarc1/board.c | 1 + board/BuR/brxre1/board.c | 1 + board/BuR/common/common.c | 1 + board/BuS/eb_cpu5282/eb_cpu5282.c | 1 + board/CZ.NIC/turris_mox/turris_mox.c | 1 + board/CZ.NIC/turris_omnia/turris_omnia.c | 1 + board/CarMediaLab/flea3/flea3.c | 1 + board/LaCie/edminiv2/edminiv2.c | 1 + board/LaCie/net2big_v2/net2big_v2.c | 1 + board/LaCie/netspace_v2/netspace_v2.c | 1 + board/Marvell/aspenite/aspenite.c | 1 + board/Marvell/db-88f6281-bp/db-88f6281-bp.c | 1 + board/Marvell/db-88f6720/db-88f6720.c | 1 + board/Marvell/db-88f6820-amc/db-88f6820-amc.c | 1 + board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 1 + board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c | 1 + board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c | 1 + board/Marvell/dreamplug/dreamplug.c | 1 + board/Marvell/gplugd/gplugd.c | 1 + board/Marvell/guruplug/guruplug.c | 1 + board/Marvell/mvebu_armada-37xx/board.c | 1 + board/Marvell/mvebu_armada-8k/board.c | 1 + board/Marvell/octeontx/board.c | 2 + board/Marvell/octeontx2/board.c | 2 + board/Marvell/openrd/openrd.c | 1 + board/Marvell/sheevaplug/sheevaplug.c | 1 + board/Seagate/dockstar/dockstar.c | 1 + board/Seagate/goflexhome/goflexhome.c | 1 + board/Seagate/nas220/nas220.c | 1 + board/Synology/ds109/ds109.c | 1 + board/Synology/ds414/ds414.c | 1 + board/advantech/dms-ba16/dms-ba16.c | 1 + .../imx8qm_rom7720_a1/imx8qm_rom7720_a1.c | 1 + board/advantech/imx8qm_rom7720_a1/spl.c | 1 + board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c | 1 + .../alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c | 1 + board/alliedtelesis/common/gpio_hog.c | 1 + board/alliedtelesis/x530/x530.c | 1 + board/amazon/kc1/kc1.c | 1 + board/amlogic/vim3/vim3.c | 1 + board/aristainetos/aristainetos.c | 1 + board/armadeus/apf27/apf27.c | 1 + board/armltd/integrator/integrator.c | 1 + board/armltd/integrator/timer.c | 2 +- board/armltd/total_compute/total_compute.c | 1 + board/armltd/vexpress/vexpress_common.c | 1 + board/armltd/vexpress64/vexpress64.c | 1 + board/astro/mcf5373l/mcf5373l.c | 1 + .../armadillo-800eva/armadillo-800eva.c | 1 + board/atmel/at91rm9200ek/at91rm9200ek.c | 1 + board/atmel/at91sam9260ek/at91sam9260ek.c | 1 + board/atmel/at91sam9261ek/at91sam9261ek.c | 1 + board/atmel/at91sam9263ek/at91sam9263ek.c | 1 + .../atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 1 + board/atmel/at91sam9n12ek/at91sam9n12ek.c | 1 + board/atmel/at91sam9rlek/at91sam9rlek.c | 1 + board/atmel/at91sam9x5ek/at91sam9x5ek.c | 1 + board/atmel/common/video_display.c | 1 + board/atmel/sam9x60ek/sam9x60ek.c | 1 + .../atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 1 + .../sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 1 + board/atmel/sama5d2_icp/sama5d2_icp.c | 1 + board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c | 1 + .../atmel/sama5d2_xplained/sama5d2_xplained.c | 1 + .../atmel/sama5d3_xplained/sama5d3_xplained.c | 1 + board/atmel/sama5d3xek/sama5d3xek.c | 1 + .../atmel/sama5d4_xplained/sama5d4_xplained.c | 1 + board/atmel/sama5d4ek/sama5d4ek.c | 1 + board/bachmann/ot1200/ot1200.c | 1 + board/barco/platinum/platinum.c | 1 + board/barco/titanium/titanium.c | 1 + board/beacon/beacon-rzg2m/beacon-rzg2m.c | 1 + board/beacon/imx8mm/imx8mm_beacon.c | 1 + board/beacon/imx8mm/spl.c | 1 + board/beckhoff/mx53cx9020/mx53cx9020.c | 1 + board/bluegiga/apx4devkit/apx4devkit.c | 1 + board/bluewater/gurnard/gurnard.c | 1 + board/bluewater/snapper9260/snapper9260.c | 1 + board/bosch/guardian/board.c | 1 + board/bosch/shc/board.c | 1 + board/boundary/nitrogen6x/nitrogen6x.c | 1 + board/broadcom/bcm23550_w1d/bcm23550_w1d.c | 1 + board/broadcom/bcm28155_ap/bcm28155_ap.c | 1 + board/broadcom/bcm_ep/board.c | 1 + board/broadcom/bcmns2/northstar2.c | 1 + board/broadcom/bcmns3/ns3.c | 1 + board/broadcom/bcmstb/bcmstb.c | 1 + board/bticino/mamoj/mamoj.c | 1 + board/bticino/mamoj/spl.c | 1 + board/buffalo/lsxl/lsxl.c | 1 + board/calao/usb_a9263/usb_a9263.c | 1 + board/cavium/thunderx/thunderx.c | 1 + board/ccv/xpress/xpress.c | 1 + board/cirrus/edb93xx/edb93xx.c | 1 + board/cloudengines/pogo_e02/pogo_e02.c | 1 + board/cobra5272/cobra5272.c | 1 + board/compulab/cl-som-imx7/cl-som-imx7.c | 1 + board/compulab/cm_fx6/cm_fx6.c | 1 + board/compulab/cm_t335/cm_t335.c | 1 + board/compulab/cm_t43/cm_t43.c | 1 + board/congatec/cgtqmx6eval/cgtqmx6eval.c | 1 + board/corscience/tricorder/tricorder-eeprom.c | 1 + board/corscience/tricorder/tricorder.c | 1 + board/cortina/presidio-asic/presidio.c | 1 + board/creative/xfi3/xfi3.c | 1 + board/cssi/MCR3000/MCR3000.c | 1 + board/d-link/dns325/dns325.c | 1 + board/davinci/da8xxevm/da850evm.c | 1 + board/davinci/da8xxevm/omapl138_lcdk.c | 1 + board/dhelectronics/dh_imx6/dh_imx6.c | 1 + board/dhelectronics/dh_stm32mp1/board.c | 2 + board/ea/mx7ulp_com/mx7ulp_com.c | 1 + board/eets/pdu001/board.c | 1 + board/egnite/ethernut5/ethernut5.c | 1 + board/el/el6x/el6x.c | 1 + board/elgin/elgin_rv1108/elgin_rv1108.c | 1 + board/embest/mx6boards/mx6boards.c | 1 + board/engicam/common/board.c | 1 + board/esd/meesc/meesc.c | 1 + board/esd/vme8349/vme8349.c | 1 + board/firefly/firefly-rk3288/firefly-rk3288.c | 1 + board/freescale/common/arm_sleep.c | 1 + board/freescale/common/emc2305.c | 1 + board/freescale/common/mpc85xx_sleep.c | 1 + board/freescale/corenet_ds/corenet_ds.c | 1 + board/freescale/corenet_ds/ddr.c | 1 + board/freescale/imx8mm_evk/imx8mm_evk.c | 1 + board/freescale/imx8mm_evk/spl.c | 1 + board/freescale/imx8mn_evk/imx8mn_evk.c | 1 + board/freescale/imx8mn_evk/spl.c | 1 + board/freescale/imx8mp_evk/imx8mp_evk.c | 1 + board/freescale/imx8mp_evk/spl.c | 1 + board/freescale/imx8mq_evk/imx8mq_evk.c | 1 + board/freescale/imx8mq_evk/spl.c | 1 + board/freescale/imx8qm_mek/imx8qm_mek.c | 1 + board/freescale/imx8qm_mek/spl.c | 1 + board/freescale/imx8qxp_mek/imx8qxp_mek.c | 1 + board/freescale/imx8qxp_mek/spl.c | 1 + board/freescale/imxrt1020-evk/imxrt1020-evk.c | 1 + board/freescale/imxrt1050-evk/imxrt1050-evk.c | 1 + board/freescale/ls1012afrdm/ls1012afrdm.c | 1 + board/freescale/ls1012aqds/ls1012aqds.c | 1 + board/freescale/ls1012ardb/ls1012ardb.c | 1 + board/freescale/ls1021aiot/dcu.c | 1 + board/freescale/ls1021aiot/ls1021aiot.c | 1 + board/freescale/ls1021aqds/dcu.c | 1 + board/freescale/ls1021aqds/ddr.c | 1 + board/freescale/ls1021atsn/ls1021atsn.c | 1 + board/freescale/ls1021atwr/dcu.c | 1 + board/freescale/ls1021atwr/ls1021atwr.c | 1 + board/freescale/ls1028a/ddr.c | 1 + board/freescale/ls1028a/ls1028a.c | 2 + board/freescale/ls1043aqds/ddr.c | 1 + board/freescale/ls1043aqds/ls1043aqds.c | 1 + board/freescale/ls1043ardb/ddr.c | 1 + board/freescale/ls1043ardb/ls1043ardb.c | 1 + board/freescale/ls1046afrwy/ddr.c | 1 + board/freescale/ls1046afrwy/ls1046afrwy.c | 1 + board/freescale/ls1046aqds/ddr.c | 1 + board/freescale/ls1046aqds/ls1046aqds.c | 1 + board/freescale/ls1046ardb/ddr.c | 1 + board/freescale/ls1046ardb/ls1046ardb.c | 1 + board/freescale/ls1088a/ddr.c | 1 + board/freescale/ls1088a/ls1088a.c | 2 + board/freescale/ls2080a/ddr.c | 1 + board/freescale/ls2080a/ls2080a.c | 2 + board/freescale/ls2080aqds/ddr.c | 1 + board/freescale/ls2080aqds/ls2080aqds.c | 2 + board/freescale/ls2080ardb/ddr.c | 1 + board/freescale/ls2080ardb/eth_ls2080rdb.c | 1 + board/freescale/ls2080ardb/ls2080ardb.c | 2 + board/freescale/lx2160a/ddr.c | 1 + board/freescale/lx2160a/eth_lx2160aqds.c | 1 + board/freescale/lx2160a/eth_lx2160ardb.c | 1 + board/freescale/lx2160a/lx2160a.c | 2 + board/freescale/m5208evbe/m5208evbe.c | 1 + board/freescale/m52277evb/m52277evb.c | 1 + board/freescale/m5235evb/m5235evb.c | 1 + board/freescale/m5249evb/m5249evb.c | 1 + board/freescale/m5253demo/m5253demo.c | 1 + board/freescale/m5272c3/m5272c3.c | 1 + board/freescale/m5275evb/m5275evb.c | 1 + board/freescale/m5282evb/m5282evb.c | 1 + board/freescale/m53017evb/m53017evb.c | 1 + board/freescale/m5329evb/m5329evb.c | 1 + board/freescale/m5373evb/m5373evb.c | 1 + board/freescale/m54418twr/m54418twr.c | 1 + board/freescale/m54451evb/m54451evb.c | 1 + board/freescale/m54455evb/m54455evb.c | 1 + board/freescale/m547xevb/m547xevb.c | 1 + board/freescale/m548xevb/m548xevb.c | 1 + board/freescale/mpc8308rdb/sdram.c | 1 + board/freescale/mpc8313erdb/mpc8313erdb.c | 1 + board/freescale/mpc8313erdb/sdram.c | 1 + board/freescale/mpc8315erdb/mpc8315erdb.c | 1 + board/freescale/mpc8315erdb/sdram.c | 1 + board/freescale/mpc8323erdb/mpc8323erdb.c | 1 + board/freescale/mpc832xemds/mpc832xemds.c | 1 + board/freescale/mpc8349emds/mpc8349emds.c | 1 + board/freescale/mpc8349itx/mpc8349itx.c | 1 + board/freescale/mpc837xemds/mpc837xemds.c | 1 + board/freescale/mpc837xerdb/mpc837xerdb.c | 1 + board/freescale/mpc8541cds/mpc8541cds.c | 1 + board/freescale/mpc8548cds/mpc8548cds.c | 1 + board/freescale/mpc8555cds/mpc8555cds.c | 1 + board/freescale/mpc8568mds/mpc8568mds.c | 1 + board/freescale/mpc8610hpcd/mpc8610hpcd.c | 1 + board/freescale/mpc8641hpcn/mpc8641hpcn.c | 1 + board/freescale/mx23evk/mx23evk.c | 1 + board/freescale/mx25pdk/mx25pdk.c | 1 + board/freescale/mx28evk/mx28evk.c | 1 + board/freescale/mx35pdk/mx35pdk.c | 1 + board/freescale/mx51evk/mx51evk.c | 1 + board/freescale/mx53ard/mx53ard.c | 1 + board/freescale/mx53evk/mx53evk.c | 1 + board/freescale/mx53loco/mx53loco.c | 1 + board/freescale/mx53smd/mx53smd.c | 1 + board/freescale/mx6memcal/mx6memcal.c | 1 + board/freescale/mx6memcal/spl.c | 1 + board/freescale/mx6qarm2/mx6qarm2.c | 1 + board/freescale/mx6sabreauto/mx6sabreauto.c | 1 + board/freescale/mx6sabresd/mx6sabresd.c | 1 + board/freescale/mx6slevk/mx6slevk.c | 1 + board/freescale/mx6sllevk/mx6sllevk.c | 1 + .../freescale/mx6sxsabreauto/mx6sxsabreauto.c | 1 + board/freescale/mx6sxsabresd/mx6sxsabresd.c | 1 + .../mx6ul_14x14_evk/mx6ul_14x14_evk.c | 1 + board/freescale/mx6ullevk/mx6ullevk.c | 1 + board/freescale/mx7dsabresd/mx7dsabresd.c | 1 + board/freescale/mx7ulp_evk/mx7ulp_evk.c | 1 + board/freescale/p1010rdb/ddr.c | 1 + board/freescale/p1010rdb/p1010rdb.c | 1 + board/freescale/p1010rdb/spl.c | 1 + board/freescale/p1023rdb/p1023rdb.c | 161 +++++++++++++ board/freescale/p1_p2_rdb_pc/spl.c | 1 + board/freescale/p2041rdb/ddr.c | 1 + board/freescale/p2041rdb/p2041rdb.c | 1 + board/freescale/qemu-ppce500/qemu-ppce500.c | 1 + board/freescale/s32v234evb/s32v234evb.c | 1 + board/freescale/t102xrdb/ddr.c | 1 + board/freescale/t102xrdb/spl.c | 1 + board/freescale/t102xrdb/t102xrdb.c | 1 + board/freescale/t104xrdb/ddr.c | 1 + board/freescale/t104xrdb/spl.c | 1 + board/freescale/t104xrdb/t104xrdb.c | 1 + board/freescale/t208xqds/ddr.c | 1 + board/freescale/t208xqds/spl.c | 1 + board/freescale/t208xqds/t208xqds.c | 1 + board/freescale/t208xrdb/ddr.c | 1 + board/freescale/t208xrdb/spl.c | 1 + board/freescale/t208xrdb/t208xrdb.c | 1 + board/freescale/t4rdb/ddr.c | 1 + board/freescale/t4rdb/spl.c | 1 + board/freescale/t4rdb/t4240rdb.c | 1 + board/freescale/vf610twr/vf610twr.c | 1 + board/friendlyarm/nanopi2/board.c | 1 + board/gardena/smart-gateway-at91sam/board.c | 1 + board/gateworks/gw_ventana/gw_ventana.c | 1 + board/gdsys/a38x/controlcenterdc.c | 1 + board/gdsys/a38x/hydra.c | 1 + board/gdsys/mpc8308/gazerbeam.c | 1 + board/gdsys/mpc8308/sdram.c | 1 + board/gdsys/p1022/controlcenterd-id.c | 1 + board/ge/bx50v3/bx50v3.c | 1 + board/ge/mx53ppd/mx53ppd.c | 1 + .../google/imx8mq_phanbell/imx8mq_phanbell.c | 1 + board/google/imx8mq_phanbell/spl.c | 1 + board/google/veyron/veyron.c | 1 + board/grinn/chiliboard/board.c | 1 + board/grinn/liteboard/board.c | 1 + board/highbank/highbank.c | 1 + board/hisilicon/hikey/hikey.c | 1 + board/hisilicon/hikey960/hikey960.c | 1 + board/hisilicon/poplar/poplar.c | 1 + board/ids/ids8313/ids8313.c | 1 + board/imgtec/boston/ddr.c | 1 + board/imgtec/boston/dt.c | 1 + board/imgtec/ci20/ci20.c | 1 + board/imgtec/malta/malta.c | 1 + board/imgtec/xilfpga/xilfpga.c | 1 + board/inversepath/usbarmory/usbarmory.c | 1 + board/iomega/iconnect/iconnect.c | 1 + board/isee/igep003x/board.c | 1 + board/isee/igep00x0/common.c | 1 + board/k+p/kp_imx53/kp_imx53.c | 1 + board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c | 1 + board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c | 1 + board/keymile/common/common.c | 1 + board/keymile/km83xx/km83xx.c | 1 + board/keymile/km_arm/km_arm.c | 1 + board/keymile/kmp204x/ddr.c | 1 + board/kmc/kzm9g/kzm9g.c | 1 + board/kobol/helios4/helios4.c | 1 + board/kontron/sl28/ddr.c | 1 + board/kontron/sl28/sl28.c | 2 + board/kosagi/novena/novena.c | 2 + board/l+g/vinco/vinco.c | 1 + board/laird/wb45n/wb45n.c | 1 + board/laird/wb50n/wb50n.c | 1 + board/lego/ev3/legoev3.c | 1 + board/lg/sniper/sniper.c | 1 + board/liebherr/display5/display5.c | 1 + board/liebherr/display5/spl.c | 1 + board/liebherr/mccmon6/mccmon6.c | 1 + board/liebherr/xea/xea.c | 1 + board/logicpd/am3517evm/am3517evm.c | 1 + board/logicpd/imx6/imx6logic.c | 1 + board/logicpd/omap3som/omap3logic.c | 1 + board/maxbcm/maxbcm.c | 1 + board/mediatek/mt7622/mt7622_rfb.c | 1 + board/mediatek/mt7623/mt7623_rfb.c | 1 + board/mediatek/mt7629/mt7629_rfb.c | 1 + board/mediatek/mt8512/mt8512.c | 1 + board/mediatek/mt8518/mt8518_ap1.c | 2 + board/menlo/m53menlo/m53menlo.c | 1 + .../crs3xx-98dx3236/crs3xx-98dx3236.c | 1 + board/mini-box/picosam9g45/picosam9g45.c | 1 + board/mpc8308_p1m/sdram.c | 1 + board/mscc/jr2/jr2.c | 1 + board/mscc/luton/luton.c | 1 + board/mscc/ocelot/ocelot.c | 2 + board/mscc/serval/serval.c | 1 + board/mscc/servalt/servalt.c | 1 + board/myir/mys_6ulx/mys_6ulx.c | 1 + board/nokia/rx51/rx51.c | 1 + board/novtech/meerkat96/meerkat96.c | 1 + board/nvidia/jetson-tk1/jetson-tk1.c | 1 + board/olimex/mx23_olinuxino/mx23_olinuxino.c | 1 + board/phytec/pcl063/pcl063.c | 1 + board/phytec/pcm052/pcm052.c | 1 + board/phytec/pcm058/pcm058.c | 1 + board/phytec/pfla02/pfla02.c | 1 + board/phytec/phycore_am335x_r2/board.c | 1 + board/phytec/phycore_rk3288/phycore-rk3288.c | 1 + board/phytium/durian/durian.c | 1 + .../pinebook-pro-rk3399/pinebook-pro-rk3399.c | 1 + board/ppcag/bg0900/bg0900.c | 1 + board/qemu-mips/qemu-mips.c | 1 + .../dragonboard410c/dragonboard410c.c | 1 + .../dragonboard820c/dragonboard820c.c | 1 + board/raidsonic/ib62x0/ib62x0.c | 1 + board/renesas/alt/alt.c | 1 + board/renesas/blanche/blanche.c | 1 + board/renesas/condor/condor.c | 1 + board/renesas/draak/draak.c | 1 + board/renesas/eagle/eagle.c | 1 + board/renesas/ebisu/ebisu.c | 1 + board/renesas/gose/gose.c | 1 + board/renesas/grpeach/grpeach.c | 1 + board/renesas/koelsch/koelsch.c | 1 + board/renesas/lager/lager.c | 1 + board/renesas/porter/porter.c | 1 + board/renesas/rcar-common/common.c | 1 + board/renesas/salvator-x/salvator-x.c | 1 + board/renesas/silk/silk.c | 1 + board/renesas/stout/stout.c | 1 + board/renesas/ulcb/ulcb.c | 1 + board/rockchip/evb_rk3308/evb_rk3308.c | 1 + board/rockchip/evb_rv1108/evb_rv1108.c | 1 + board/ronetix/pm9261/pm9261.c | 1 + board/ronetix/pm9263/pm9263.c | 1 + board/ronetix/pm9g45/pm9g45.c | 1 + board/samsung/arndale/arndale.c | 1 + board/samsung/common/board.c | 1 + board/samsung/common/exynos5-dt-types.c | 1 + board/samsung/common/exynos5-dt.c | 2 + board/samsung/common/misc.c | 2 + board/samsung/goni/goni.c | 2 + board/samsung/odroid/odroid.c | 2 + board/samsung/smdkc100/smdkc100.c | 1 + board/samsung/smdkv310/smdkv310.c | 1 + board/samsung/universal_c210/universal.c | 1 + board/sandbox/sandbox.c | 1 + board/sandisk/sansa_fuze_plus/sfp.c | 1 + board/sbc8349/sbc8349.c | 1 + board/sbc8548/sbc8548.c | 1 + board/sbc8641d/sbc8641d.c | 1 + board/schulercontrol/sc_sps_1/sc_sps_1.c | 1 + board/seco/mx6quq7/mx6quq7.c | 1 + board/siemens/capricorn/spl.c | 1 + board/siemens/common/board.c | 1 + board/siemens/corvus/board.c | 1 + board/siemens/smartweb/smartweb.c | 1 + board/siemens/taurus/taurus.c | 1 + board/sks-kinkel/sksimx6/sksimx6.c | 1 + board/socrates/socrates.c | 1 + board/softing/vining_2000/vining_2000.c | 1 + board/softing/vining_fpga/socfpga.c | 1 + board/solidrun/clearfog/clearfog.c | 1 + board/solidrun/common/tlv_data.c | 1 + board/solidrun/mx6cuboxi/mx6cuboxi.c | 1 + board/somlabs/visionsom-6ull/visionsom-6ull.c | 1 + board/st/common/stm32mp_dfu.c | 1 + board/st/common/stm32mp_mtdparts.c | 2 + board/st/stih410-b2260/board.c | 1 + .../stm32f429-discovery/stm32f429-discovery.c | 1 + .../stm32f429-evaluation.c | 1 + .../stm32f469-discovery/stm32f469-discovery.c | 1 + board/st/stm32f746-disco/stm32f746-disco.c | 1 + board/st/stm32h743-disco/stm32h743-disco.c | 1 + board/st/stm32h743-eval/stm32h743-eval.c | 1 + board/st/stm32mp1/stm32mp1.c | 2 + board/st/stv0991/stv0991.c | 1 + board/ste/stemmy/stemmy.c | 1 + board/sunxi/board.c | 2 + board/synopsys/axs10x/axs10x.c | 1 + board/synopsys/emsdp/emsdp.c | 1 + board/synopsys/hsdk/clk-lib.c | 1 + board/synopsys/hsdk/env-lib.c | 1 + board/synopsys/hsdk/hsdk.c | 1 + board/synopsys/iot_devkit/iot_devkit.c | 1 + board/sysam/amcore/amcore.c | 1 + board/sysam/stmark2/stmark2.c | 1 + board/syteco/zmx25/zmx25.c | 1 + board/tbs/tbs2910/tbs2910.c | 2 + board/tcl/sl50/board.c | 1 + board/technexion/pico-imx6/pico-imx6.c | 3 +- board/technexion/pico-imx6ul/pico-imx6ul.c | 1 + board/technexion/pico-imx7d/pico-imx7d.c | 1 + board/technexion/pico-imx8mq/pico-imx8mq.c | 1 + board/technexion/pico-imx8mq/spl.c | 1 + board/technexion/tao3530/tao3530.c | 1 + board/technologic/ts4600/ts4600.c | 1 + board/technologic/ts4800/ts4800.c | 1 + board/theadorable/theadorable.c | 1 + board/ti/am335x/board.c | 1 + board/ti/am3517crane/am3517crane.c | 1 + board/ti/am43xx/board.c | 1 + board/ti/am57xx/board.c | 1 + board/ti/am65x/evm.c | 2 + board/ti/beagle/beagle.c | 1 + board/ti/common/board_detect.c | 1 + board/ti/dra7xx/evm.c | 1 + board/ti/evm/evm.c | 1 + board/ti/j721e/evm.c | 2 + board/ti/ks2_evm/board.c | 1 + board/ti/omap5_uevm/evm.c | 1 + board/ti/panda/panda.c | 1 + board/ti/sdp4430/sdp.c | 1 + board/ti/ti816x/evm.c | 1 + board/timll/devkit3250/devkit3250.c | 1 + board/timll/devkit8000/devkit8000.c | 1 + board/toradex/apalis-imx8/apalis-imx8.c | 1 + board/toradex/apalis-tk1/apalis-tk1.c | 1 + board/toradex/apalis_imx6/apalis_imx6.c | 1 + board/toradex/apalis_t30/apalis_t30.c | 1 + .../toradex/colibri-imx6ull/colibri-imx6ull.c | 1 + board/toradex/colibri-imx8x/colibri-imx8x.c | 1 + board/toradex/colibri_imx6/colibri_imx6.c | 1 + board/toradex/colibri_imx7/colibri_imx7.c | 1 + board/toradex/colibri_pxa270/colibri_pxa270.c | 1 + board/toradex/colibri_t20/colibri_t20.c | 1 + board/toradex/colibri_vf/colibri_vf.c | 1 + board/toradex/common/tdx-cfg-block.c | 1 + board/toradex/common/tdx-eeprom.c | 1 + board/toradex/verdin-imx8mm/spl.c | 1 + board/toradex/verdin-imx8mm/verdin-imx8mm.c | 1 + board/tqc/tqm834x/tqm834x.c | 1 + board/tqc/tqma6/tqma6.c | 1 + board/udoo/neo/neo.c | 1 + board/udoo/udoo.c | 1 + board/variscite/dart_6ul/dart_6ul.c | 1 + board/varisys/cyrus/ddr.c | 1 + board/ve8313/ve8313.c | 1 + board/vscom/baltos/board.c | 1 + board/wandboard/wandboard.c | 1 + board/warp/warp.c | 1 + board/warp7/warp7.c | 1 + board/work-microwave/work_92105/work_92105.c | 1 + board/xen/xenguest_arm64/xenguest_arm64.c | 1 + board/xes/xpedite517x/xpedite517x.c | 1 + board/xilinx/common/board.c | 1 + .../microblaze-generic/microblaze-generic.c | 1 + board/xilinx/versal/board.c | 1 + board/xilinx/zynq/board.c | 1 + board/xilinx/zynq/bootimg.c | 1 + board/xilinx/zynq/cmds.c | 1 + board/xilinx/zynqmp/zynqmp.c | 1 + board/zyxel/nsa310s/nsa310s.c | 1 + cmd/acpi.c | 2 + cmd/adc.c | 1 + cmd/axi.c | 1 + cmd/bcb.c | 1 + cmd/bdinfo.c | 1 + cmd/bedbug.c | 1 + cmd/bloblist.c | 1 + cmd/bootefi.c | 1 + cmd/booti.c | 1 + cmd/bootm.c | 1 + cmd/cpu.c | 1 + cmd/date.c | 1 + cmd/efi.c | 1 + cmd/fastboot.c | 1 + cmd/fpgad.c | 1 + cmd/io.c | 1 + cmd/load.c | 1 + cmd/log.c | 1 + cmd/mem.c | 2 + cmd/mmc.c | 1 + cmd/mtdparts.c | 1 + cmd/nvedit.c | 2 + cmd/onenand.c | 1 + cmd/pstore.c | 1 + cmd/pxe_utils.h | 2 + cmd/regulator.c | 1 + cmd/rtc.c | 1 + cmd/sb.c | 1 + cmd/sf.c | 1 + cmd/sound.c | 1 + cmd/spl.c | 1 + cmd/thordown.c | 1 + cmd/ti/ddr3.c | 1 + cmd/tlv_eeprom.c | 1 + cmd/tpm_test.c | 1 + cmd/usb_gadget_sdp.c | 1 + cmd/usb_mass_storage.c | 1 + cmd/version.c | 1 + cmd/x86/fsp.c | 1 + cmd/x86/hob.c | 1 + common/autoboot.c | 1 + common/bloblist.c | 2 + common/board_f.c | 2 + common/board_info.c | 1 + common/board_r.c | 2 + common/bootm.c | 1 + common/bootm_os.c | 1 + common/bootstage.c | 1 + common/cli.c | 1 + common/cli_hush.c | 1 + common/cli_readline.c | 1 + common/command.c | 1 + common/console.c | 2 + common/dfu.c | 1 + common/dlmalloc.c | 1 + common/exports.c | 1 + common/hash.c | 1 + common/hwconfig.c | 1 + common/image-android.c | 1 + common/image-cipher.c | 1 + common/image-fdt.c | 1 + common/image-fit-sig.c | 1 + common/image-fit.c | 1 + common/image-sig.c | 1 + common/image.c | 2 + common/init/board_init.c | 1 + common/init/handoff.c | 1 + common/iotrace.c | 1 + common/lcd.c | 1 + common/lcd_simplefb.c | 1 + common/log.c | 1 + common/log_console.c | 1 + common/log_syslog.c | 1 + common/malloc_simple.c | 1 + common/memsize.c | 1 + common/spl/spl.c | 1 + common/spl/spl_dfu.c | 1 + common/spl/spl_fit.c | 2 + common/spl/spl_opensbi.c | 2 + common/spl/spl_sdp.c | 1 + common/spl/spl_spi.c | 1 + common/splash.c | 1 + common/splash_source.c | 1 + common/stdio.c | 2 +- common/update.c | 1 + disk/part_efi.c | 2 + drivers/adc/adc-uclass.c | 1 + drivers/adc/exynos-adc.c | 1 + drivers/adc/meson-saradc.c | 1 + drivers/adc/rockchip-saradc.c | 1 + drivers/adc/sandbox.c | 1 + drivers/ata/dwc_ahci.c | 1 + drivers/ata/libata.c | 2 + drivers/ata/mtk_ahci.c | 1 + drivers/ata/sata_mv.c | 1 + drivers/bios_emulator/atibios.c | 1 + drivers/bios_emulator/include/x86emu/debug.h | 1 + drivers/bios_emulator/include/x86emu/regs.h | 1 + drivers/bios_emulator/x86emu/debug.c | 1 + drivers/bios_emulator/x86emu/decode.c | 1 + drivers/bios_emulator/x86emu/ops.c | 1 + drivers/bios_emulator/x86emu/ops2.c | 1 + drivers/bios_emulator/x86emu/sys.c | 1 + drivers/block/blkcache.c | 1 + drivers/block/sandbox.c | 1 + drivers/bootcount/bootcount-uclass.c | 1 + drivers/bootcount/bootcount_ram.c | 1 + drivers/cache/cache-v5l2.c | 1 + drivers/cache/sandbox_cache.c | 1 + drivers/clk/altera/clk-agilex.c | 1 + drivers/clk/altera/clk-arria10.c | 1 + drivers/clk/analogbits/wrpll-cln28hpc.c | 1 + drivers/clk/aspeed/clk_ast2500.c | 1 + drivers/clk/at91/clk-generated.c | 179 ++++++++++++++ drivers/clk/at91/clk-h32mx.c | 57 +++++ drivers/clk/at91/clk-main.c | 1 + drivers/clk/at91/clk-master.c | 1 + drivers/clk/at91/clk-plla.c | 55 +++++ drivers/clk/at91/clk-usb.c | 148 ++++++++++++ drivers/clk/at91/compat.c | 1 + drivers/clk/at91/pmc.c | 4 +- drivers/clk/clk-divider.c | 1 + drivers/clk/clk-gate.c | 1 + drivers/clk/clk-hsdk-cgu.c | 1 + drivers/clk/clk-mux.c | 1 + drivers/clk/clk-uclass.c | 1 + drivers/clk/clk_boston.c | 1 + drivers/clk/clk_octeon.c | 1 + drivers/clk/clk_pic32.c | 1 + drivers/clk/clk_stm32f.c | 1 + drivers/clk/clk_stm32h7.c | 1 + drivers/clk/clk_stm32mp1.c | 2 + drivers/clk/clk_zynq.c | 1 + drivers/clk/imx/clk-pll14xx.c | 1 + drivers/clk/mpc83xx_clk.c | 1 + drivers/clk/renesas/clk-rcar-gen2.c | 1 + drivers/clk/renesas/clk-rcar-gen3.c | 1 + drivers/clk/rockchip/clk_px30.c | 1 + drivers/clk/rockchip/clk_rk3288.c | 1 + drivers/clk/rockchip/clk_rk3308.c | 1 + drivers/clk/rockchip/clk_rk3368.c | 1 + drivers/clk/rockchip/clk_rk3399.c | 1 + drivers/clk/rockchip/clk_rv1108.c | 1 + drivers/core/acpi.c | 1 + drivers/core/device-remove.c | 1 + drivers/core/device.c | 2 + drivers/core/fdtaddr.c | 1 + drivers/core/of_access.c | 1 + drivers/core/of_addr.c | 1 + drivers/core/ofnode.c | 1 + drivers/core/read.c | 1 + drivers/core/regmap.c | 1 + drivers/core/root.c | 2 + drivers/core/uclass.c | 1 + drivers/cpu/bmips_cpu.c | 1 + drivers/cpu/imx8_cpu.c | 1 + drivers/cpu/riscv_cpu.c | 1 + drivers/crypto/rsa_mod_exp/mod_exp_uclass.c | 1 + drivers/ddr/altera/sdram_agilex.c | 1 + drivers/ddr/altera/sdram_arria10.c | 1 + drivers/ddr/altera/sdram_s10.c | 1 + drivers/ddr/altera/sdram_soc64.c | 1 + drivers/ddr/fsl/main.c | 1 + drivers/ddr/imx/imx8m/helper.c | 1 + drivers/demo/demo-shape.c | 1 + drivers/demo/demo-uclass.c | 1 + drivers/dfu/dfu.c | 1 + drivers/dfu/dfu_mmc.c | 1 + drivers/dfu/dfu_ram.c | 1 + drivers/dfu/dfu_tftp.c | 1 + drivers/dma/bcm6348-iudma.c | 1 + drivers/dma/dma-uclass.c | 1 + drivers/dma/lpc32xx_dma.c | 1 + drivers/dma/sandbox-dma-test.c | 1 + drivers/dma/ti-edma3.c | 1 + drivers/dma/ti/k3-udma.c | 1 + drivers/fastboot/fb_command.c | 1 + drivers/fastboot/fb_getvar.c | 1 + drivers/fastboot/fb_mmc.c | 1 + drivers/fastboot/fb_nand.c | 1 + drivers/fpga/ACEX1K.c | 4 +- drivers/fpga/socfpga_arria10.c | 1 + drivers/fpga/spartan2.c | 24 +- drivers/fpga/spartan3.c | 24 +- drivers/fpga/zynqmppl.c | 1 + drivers/gpio/74x164_gpio.c | 1 + drivers/gpio/altera_pio.c | 1 + drivers/gpio/atmel_pio4.c | 1 + drivers/gpio/da8xx_gpio.c | 1 + drivers/gpio/gpio-rcar.c | 1 + drivers/gpio/gpio-rza1.c | 1 + drivers/gpio/gpio-uclass.c | 1 + drivers/gpio/intel_broadwell_gpio.c | 1 + drivers/gpio/intel_ich6_gpio.c | 1 + drivers/gpio/msm_gpio.c | 1 + drivers/gpio/mxs_gpio.c | 1 + drivers/gpio/nx_gpio.c | 1 + drivers/gpio/omap_gpio.c | 1 + drivers/gpio/pcf8575_gpio.c | 1 + drivers/gpio/pic32_gpio.c | 1 + drivers/gpio/s5p_gpio.c | 1 + drivers/gpio/vybrid_gpio.c | 1 + drivers/hwspinlock/hwspinlock-uclass.c | 1 + drivers/i2c/at91_i2c.c | 1 + drivers/i2c/cros_ec_tunnel.c | 1 + drivers/i2c/exynos_hs_i2c.c | 1 + drivers/i2c/fsl_i2c.c | 1 + drivers/i2c/i2c-gpio.c | 2 + drivers/i2c/i2c_core.c | 1 + drivers/i2c/ihs_i2c.c | 1 + drivers/i2c/iproc_i2c.c | 2 + drivers/i2c/muxes/i2c-arb-gpio-challenge.c | 1 + drivers/i2c/muxes/i2c-mux-gpio.c | 1 + drivers/i2c/muxes/pca954x.c | 1 + drivers/i2c/mvtwsi.c | 1 + drivers/i2c/mxc_i2c.c | 1 + drivers/i2c/nx_i2c.c | 1 + drivers/i2c/omap24xx_i2c.c | 1 + drivers/i2c/s3c24x0_i2c.c | 1 + drivers/i2c/sh_i2c.c | 1 + drivers/i2c/soft_i2c.c | 1 + drivers/i2c/stm32f7_i2c.c | 1 + drivers/i2c/tegra186_bpmp_i2c.c | 1 + drivers/i2c/tegra_i2c.c | 1 + drivers/input/i8042.c | 1 + drivers/mailbox/k3-sec-proxy.c | 1 + drivers/misc/atsha204a-i2c.c | 1 + drivers/misc/fs_loader.c | 1 + drivers/misc/imx8/fuse.c | 1 + drivers/misc/imx8/scu.c | 1 + drivers/misc/imx8/scu_api.c | 1 + drivers/misc/sifive-otp.c | 1 + drivers/misc/tegra186_bpmp.c | 2 + drivers/mmc/atmel_sdhci.c | 1 + drivers/mmc/ca_dw_mmc.c | 1 + drivers/mmc/exynos_dw_mmc.c | 2 + drivers/mmc/fsl_esdhc.c | 1 + drivers/mmc/fsl_esdhc_imx.c | 2 + drivers/mmc/ftsdc010_mci.c | 1 + drivers/mmc/gen_atmel_mci.c | 1 + drivers/mmc/hi6220_dw_mmc.c | 1 + drivers/mmc/iproc_sdhci.c | 1 + drivers/mmc/jz_mmc.c | 1 + drivers/mmc/mmc.c | 1 + drivers/mmc/msm_sdhci.c | 1 + drivers/mmc/mtk-sd.c | 1 + drivers/mmc/mv_sdhci.c | 1 + drivers/mmc/mvebu_mmc.c | 1 + drivers/mmc/omap_hsmmc.c | 1 + drivers/mmc/pic32_sdhci.c | 3 + drivers/mmc/renesas-sdhi.c | 1 + drivers/mmc/s5p_sdhci.c | 1 + drivers/mmc/sdhci-cadence.c | 1 + drivers/mmc/sdhci.c | 1 + drivers/mmc/sh_mmcif.c | 1 + drivers/mmc/sh_sdhi.c | 1 + drivers/mmc/socfpga_dw_mmc.c | 1 + drivers/mmc/sti_sdhci.c | 2 + drivers/mmc/stm32_sdmmc2.c | 1 + drivers/mmc/tmio-common.c | 1 + drivers/mmc/xenon_sdhci.c | 2 + drivers/mtd/altera_qspi.c | 1 + drivers/mtd/cfi_flash.c | 1 + drivers/mtd/mtd_uboot.c | 1 + drivers/mtd/mtdconcat.c | 1 + drivers/mtd/mtdcore.c | 1 + drivers/mtd/mtdpart.c | 1 + drivers/mtd/nand/bbt.c | 1 + drivers/mtd/nand/core.c | 1 + drivers/mtd/nand/raw/arasan_nfc.c | 1 + drivers/mtd/nand/raw/atmel_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/bcm6368_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c | 1 + drivers/mtd/nand/raw/davinci_nand.c | 1 + drivers/mtd/nand/raw/lpc32xx_nand_mlc.c | 1 + drivers/mtd/nand/raw/lpc32xx_nand_slc.c | 1 + drivers/mtd/nand/raw/mxc_nand.c | 1 + drivers/mtd/nand/raw/nand_base.c | 2 + drivers/mtd/nand/raw/nand_bbt.c | 1 + drivers/mtd/nand/raw/nand_bch.c | 1 + drivers/mtd/nand/raw/octeontx_nand.c | 1 + drivers/mtd/nand/raw/pxa3xx_nand.c | 2 + drivers/mtd/nand/raw/stm32_fmc2_nand.c | 1 + drivers/mtd/nand/raw/sunxi_nand.c | 2 + drivers/mtd/nand/raw/tegra_nand.c | 2 + drivers/mtd/nand/raw/vf610_nfc.c | 1 + drivers/mtd/nand/raw/zynq_nand.c | 1 + drivers/mtd/nand/spi/core.c | 1 + drivers/mtd/onenand/onenand_base.c | 1 + drivers/mtd/onenand/onenand_bbt.c | 1 + drivers/mtd/onenand/onenand_uboot.c | 1 + drivers/mtd/onenand/samsung.c | 1 + drivers/mtd/pic32_flash.c | 1 + drivers/mtd/renesas_rpc_hf.c | 1 + drivers/mtd/spi/sf-uclass.c | 1 + drivers/mtd/spi/sf_dataflash.c | 1 + drivers/mtd/spi/spi-nor-core.c | 2 + drivers/mtd/spi/spi-nor-tiny.c | 1 + drivers/mtd/ubi/attach.c | 1 + drivers/mtd/ubi/build.c | 1 + drivers/mtd/ubi/debug.c | 1 + drivers/mtd/ubi/debug.h | 1 + drivers/mtd/ubi/ubi.h | 1 + drivers/net/ag7xxx.c | 1 + drivers/net/altera_tse.c | 1 + drivers/net/bcm-sf2-eth-gmac.c | 1 + drivers/net/bcm-sf2-eth.c | 1 + drivers/net/bcm6348-eth.c | 1 + drivers/net/bcm6368-eth.c | 1 + drivers/net/designware.c | 1 + drivers/net/dwc_eth_qos.c | 2 + drivers/net/dwmac_s700.c | 1 + drivers/net/ep93xx_eth.c | 1 + drivers/net/fec_mxc.c | 1 + drivers/net/fsl-mc/dpio/qbman_sys.h | 1 + drivers/net/fsl-mc/mc.c | 1 + drivers/net/fsl_mcdmafec.c | 1 + drivers/net/ftgmac100.c | 1 + drivers/net/ftmac100.c | 1 + drivers/net/gmac_rockchip.c | 1 + drivers/net/lan91c96.c | 4 +- drivers/net/ldpaa_eth/ldpaa_eth.c | 1 + drivers/net/macb.c | 1 + drivers/net/mcffec.c | 1 + drivers/net/mcfmii.c | 1 + drivers/net/mpc8xx_fec.c | 1 + drivers/net/mscc_eswitch/jr2_switch.c | 1 + drivers/net/mscc_eswitch/ocelot_switch.c | 1 + drivers/net/mscc_eswitch/serval_switch.c | 1 + drivers/net/mscc_eswitch/servalt_switch.c | 1 + drivers/net/mt7628-eth.c | 1 + drivers/net/mtk_eth.c | 1 + drivers/net/mvgbe.c | 1 + drivers/net/mvmdio.c | 1 + drivers/net/mvneta.c | 1 + drivers/net/mvpp2.c | 1 + drivers/net/ne2000_base.c | 4 +- drivers/net/octeontx/smi.c | 1 + drivers/net/phy/dp83867.c | 1 + drivers/net/phy/fixed.c | 1 + drivers/net/phy/miiphybb.c | 1 + drivers/net/phy/mscc.c | 1 + drivers/net/phy/phy.c | 1 + drivers/net/phy/xilinx_gmii2rgmii.c | 4 +- drivers/net/pic32_eth.c | 1 + drivers/net/qe/dm_qe_uec.c | 1 + drivers/net/ravb.c | 1 + drivers/net/rtl8169.c | 1 + drivers/net/sandbox-raw.c | 1 + drivers/net/sandbox.c | 1 + drivers/net/sh_eth.c | 1 + drivers/net/smc91111.c | 4 +- drivers/net/sni_ave.c | 2 + drivers/net/sun8i_emac.c | 1 + drivers/net/ti/am65-cpsw-nuss.c | 1 + drivers/net/ti/cpsw-common.c | 2 + drivers/net/ti/cpsw.c | 1 + drivers/net/ti/keystone_net.c | 2 + drivers/net/xilinx_axi_emac.c | 2 + drivers/net/xilinx_emaclite.c | 1 + drivers/pci/fsl_pci_init.c | 1 + drivers/pci/pci-uclass.c | 2 + drivers/pci/pci.c | 1 + drivers/pci/pci_mvebu.c | 2 + drivers/pci/pci_octeontx.c | 1 + drivers/pci/pci_rom.c | 1 + drivers/pci/pci_tegra.c | 1 + drivers/pci/pcie_dw_mvebu.c | 1 + drivers/pci/pcie_dw_ti.c | 1 + drivers/pci/pcie_ecam_generic.c | 2 + drivers/pci/pcie_fsl.c | 2 + drivers/pci/pcie_intel_fpga.c | 1 + drivers/pci/pcie_layerscape.c | 1 + drivers/pci/pcie_layerscape_ep.c | 1 + drivers/pci/pcie_layerscape_fixup_common.c | 1 + drivers/pci/pcie_layerscape_gen4.c | 1 + drivers/pci/pcie_layerscape_rc.c | 1 + drivers/pci/pcie_mediatek.c | 1 + drivers/pci/pcie_phytium.c | 2 + drivers/pci/pcie_rockchip.c | 1 + drivers/pci/pcie_xilinx.c | 2 + drivers/pci_endpoint/pci_ep-uclass.c | 1 + drivers/pci_endpoint/pcie-cadence-ep.c | 1 + drivers/phy/keystone-usb-phy.c | 1 + drivers/phy/marvell/comphy_a3700.c | 1 + drivers/phy/marvell/comphy_core.c | 1 + drivers/phy/marvell/comphy_cp110.c | 2 + drivers/phy/meson-g12a-usb2.c | 1 + drivers/phy/meson-g12a-usb3-pcie.c | 1 + drivers/phy/meson-gxbb-usb2.c | 1 + drivers/phy/meson-gxl-usb2.c | 1 + drivers/phy/meson-gxl-usb3.c | 220 ++++++++++++++++++ drivers/phy/omap-usb2-phy.c | 1 + drivers/phy/phy-rcar-gen3.c | 1 + drivers/phy/phy-stm32-usbphyc.c | 1 + drivers/phy/phy-uclass.c | 2 + drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 1 + drivers/phy/rockchip/phy-rockchip-pcie.c | 1 + drivers/phy/rockchip/phy-rockchip-typec.c | 1 + drivers/phy/sti_usb_phy.c | 2 + drivers/phy/ti-pipe3-phy.c | 2 + drivers/pinctrl/ath79/pinctrl_ar933x.c | 1 + drivers/pinctrl/ath79/pinctrl_qca953x.c | 1 + drivers/pinctrl/exynos/pinctrl-exynos.c | 1 + drivers/pinctrl/meson/pinctrl-meson.c | 1 + drivers/pinctrl/mtmips/pinctrl-mt7628.c | 1 + drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 2 + drivers/pinctrl/mvebu/pinctrl-mvebu.c | 1 + drivers/pinctrl/nexell/pinctrl-nexell.c | 1 + drivers/pinctrl/nexell/pinctrl-s5pxx18.c | 1 + drivers/pinctrl/nxp/pinctrl-imx.c | 1 + drivers/pinctrl/nxp/pinctrl-imx8.c | 1 + drivers/pinctrl/nxp/pinctrl-mxs.c | 1 + drivers/pinctrl/pinctrl-at91-pio4.c | 1 + drivers/pinctrl/pinctrl-at91.c | 1 + drivers/pinctrl/pinctrl-sti.c | 2 + drivers/pinctrl/pinctrl-uclass.c | 1 + drivers/pinctrl/pinctrl_pic32.c | 1 + drivers/pinctrl/pinctrl_stm32.c | 2 + drivers/pinctrl/renesas/pfc-r7s72100.c | 1 + .../pinctrl/rockchip/pinctrl-rockchip-core.c | 1 + .../power/domain/imx8-power-domain-legacy.c | 1 + drivers/power/domain/imx8m-power-domain.c | 1 + drivers/power/palmas.c | 1 + drivers/power/pmic/as3722.c | 1 + drivers/power/pmic/as3722_gpio.c | 1 + drivers/power/pmic/bd71837.c | 2 + drivers/power/pmic/da9063.c | 1 + drivers/power/pmic/fan53555.c | 1 + drivers/power/pmic/i2c_pmic_emul.c | 1 + drivers/power/pmic/lp873x.c | 1 + drivers/power/pmic/lp87565.c | 1 + drivers/power/pmic/max77686.c | 1 + drivers/power/pmic/max8997.c | 1 + drivers/power/pmic/max8998.c | 1 + drivers/power/pmic/mc34708.c | 1 + drivers/power/pmic/palmas.c | 1 + drivers/power/pmic/pca9450.c | 2 + drivers/power/pmic/pfuze100.c | 1 + drivers/power/pmic/pmic_tps65910_dm.c | 1 + drivers/power/pmic/s2mps11.c | 1 + drivers/power/pmic/s5m8767.c | 1 + drivers/power/pmic/sandbox.c | 1 + drivers/power/pmic/tps65090.c | 1 + drivers/power/pmic/tps65941.c | 1 + drivers/power/regulator/bd71837.c | 1 + drivers/power/regulator/fan53555.c | 1 + drivers/power/regulator/fixed.c | 2 + drivers/power/regulator/gpio-regulator.c | 2 + drivers/power/regulator/max77686.c | 1 + drivers/power/regulator/pbias_regulator.c | 1 + drivers/power/regulator/pwm_regulator.c | 1 + drivers/power/regulator/regulator_common.c | 2 + drivers/power/regulator/s2mps11_regulator.c | 1 + drivers/power/regulator/sandbox.c | 1 + drivers/power/regulator/tps65910_regulator.c | 1 + drivers/power/twl4030.c | 1 + drivers/power/twl6030.c | 1 + drivers/pwm/pwm-sifive.c | 1 + drivers/pwm/rk_pwm.c | 1 + drivers/pwm/sunxi_pwm.c | 1 + drivers/qe/fdt.c | 1 + drivers/qe/qe.c | 1 + drivers/ram/aspeed/sdram_ast2500.c | 1 + drivers/ram/imxrt_sdram.c | 1 + drivers/ram/mpc83xx_sdram.c | 1 + drivers/ram/octeon/octeon_ddr.c | 1 + drivers/ram/rockchip/dmc-rk3368.c | 1 + drivers/ram/rockchip/sdram_rk322x.c | 1 + drivers/ram/sandbox_ram.c | 1 + drivers/ram/sifive/fu540_ddr.c | 1 + drivers/ram/stm32_sdram.c | 1 + drivers/ram/stm32mp1/stm32mp1_ddr.c | 1 + drivers/ram/stm32mp1/stm32mp1_interactive.c | 1 + drivers/ram/stm32mp1/stm32mp1_ram.c | 1 + drivers/ram/stm32mp1/stm32mp1_tests.c | 1 + drivers/ram/stm32mp1/stm32mp1_tuning.c | 1 + drivers/remoteproc/rproc-elf-loader.c | 1 + drivers/remoteproc/rproc-uclass.c | 2 + drivers/remoteproc/sandbox_testproc.c | 1 + drivers/remoteproc/stm32_copro.c | 1 + drivers/remoteproc/ti_power_proc.c | 2 + drivers/remoteproc/ti_sci_proc.h | 1 + drivers/reset/sti-reset.c | 2 + drivers/serial/atmel_usart.c | 1 + drivers/serial/ns16550.c | 1 + drivers/serial/sandbox.c | 1 + drivers/serial/serial-uclass.c | 1 + drivers/serial/serial.c | 1 + drivers/serial/serial_arc.c | 1 + drivers/serial/serial_linflexuart.c | 1 + drivers/serial/serial_lpuart.c | 1 + drivers/serial/serial_mcf.c | 1 + drivers/serial/serial_mpc8xx.c | 1 + drivers/serial/serial_msm.c | 1 + drivers/serial/serial_mtk.c | 2 + drivers/serial/serial_mxc.c | 1 + drivers/serial/serial_ns16550.c | 1 + drivers/serial/serial_pic32.c | 1 + drivers/serial/serial_pl01x.c | 1 + drivers/serial/serial_pxa.c | 1 + drivers/serial/serial_s5p.c | 1 + drivers/serial/serial_sh.c | 1 + drivers/serial/serial_sifive.c | 1 + drivers/serial/serial_sti_asc.c | 1 + drivers/serial/serial_xen.c | 1 + drivers/smem/msm_smem.c | 1 + drivers/soc/ti/k3-navss-ringacc.c | 1 + drivers/sound/ivybridge_sound.c | 1 + drivers/spi/atcspi200_spi.c | 1 + drivers/spi/atmel_spi.c | 1 + drivers/spi/bcmstb_spi.c | 1 + drivers/spi/cf_spi.c | 1 + drivers/spi/davinci_spi.c | 1 + drivers/spi/exynos_spi.c | 1 + drivers/spi/fsl_dspi.c | 2 + drivers/spi/fsl_espi.c | 1 + drivers/spi/fsl_qspi.c | 1 + drivers/spi/mt7621_spi.c | 1 + drivers/spi/mvebu_a3700_spi.c | 1 + drivers/spi/mxc_spi.c | 2 + drivers/spi/omap3_spi.c | 1 + drivers/spi/pic32_spi.c | 1 + drivers/spi/pl022_spi.c | 2 + drivers/spi/renesas_rpc_spi.c | 1 + drivers/spi/soft_spi.c | 1 + drivers/spi/spi-sunxi.c | 1 + drivers/spi/spi-uclass.c | 1 + drivers/spi/stm32_qspi.c | 1 + drivers/spi/stm32_spi.c | 1 + drivers/spi/tegra20_sflash.c | 1 + drivers/spi/tegra20_slink.c | 1 + drivers/spi/tegra210_qspi.c | 1 + drivers/spi/ti_qspi.c | 1 + drivers/spi/uniphier_spi.c | 2 + drivers/spi/zynq_qspi.c | 1 + drivers/spi/zynq_spi.c | 1 + drivers/spi/zynqmp_gqspi.c | 1 + drivers/spmi/spmi-msm.c | 1 + drivers/sysreset/sysreset-uclass.c | 1 + drivers/sysreset/sysreset_mpc83xx.c | 1 + drivers/sysreset/sysreset_sti.c | 2 + drivers/sysreset/sysreset_syscon.c | 1 + drivers/sysreset/sysreset_watchdog.c | 1 + drivers/thermal/imx_scu_thermal.c | 1 + drivers/thermal/imx_tmu.c | 1 + drivers/timer/andes_plmt_timer.c | 1 + drivers/timer/arc_timer.c | 1 + drivers/timer/cadence-ttc.c | 1 + drivers/timer/mpc83xx_timer.c | 1 + drivers/timer/ostm_timer.c | 1 + drivers/timer/rockchip_timer.c | 1 + drivers/timer/timer-uclass.c | 1 + drivers/timer/tsc_timer.c | 1 + drivers/tpm/tpm2_tis_spi.c | 1 + drivers/tpm/tpm_atmel_twi.c | 1 + drivers/tpm/tpm_tis_infineon.c | 1 + drivers/tpm/tpm_tis_sandbox.c | 1 + drivers/usb/cdns3/gadget.c | 1 + drivers/usb/common/common.c | 2 + drivers/usb/dwc3/dwc3-generic.c | 1 + drivers/usb/dwc3/dwc3-meson-g12a.c | 1 + drivers/usb/dwc3/gadget.c | 1 + drivers/usb/eth/mcs7830.c | 1 + drivers/usb/gadget/at91_udc.c | 1 + drivers/usb/gadget/atmel_usba_udc.c | 1 + drivers/usb/gadget/dwc2_udc_otg.c | 1 + drivers/usb/gadget/ether.c | 1 + drivers/usb/gadget/f_fastboot.c | 1 + drivers/usb/gadget/f_sdp.c | 1 + drivers/usb/gadget/f_thor.c | 1 + drivers/usb/gadget/pxa27x_udc.c | 1 + drivers/usb/gadget/udc/udc-uclass.c | 1 + drivers/usb/host/dwc3-octeon-glue.c | 1 + drivers/usb/host/dwc3-sti-glue.c | 2 + drivers/usb/host/ehci-exynos.c | 1 + drivers/usb/host/ehci-fsl.c | 1 + drivers/usb/host/ehci-marvell.c | 1 + drivers/usb/host/ehci-mx5.c | 1 + drivers/usb/host/ehci-mx6.c | 1 + drivers/usb/host/ehci-vf.c | 1 + drivers/usb/host/xhci-exynos5.c | 1 + drivers/usb/musb-new/da8xx.c | 1 + drivers/usb/musb-new/mt85xx.c | 1 + drivers/usb/musb-new/musb_core.c | 1 + drivers/usb/musb-new/musb_debug.h | 1 + drivers/usb/musb-new/musb_dsps.c | 1 + drivers/usb/musb-new/musb_gadget.c | 1 + drivers/usb/musb-new/musb_gadget_ep0.c | 1 + drivers/usb/musb-new/omap2430.c | 2 + drivers/usb/musb-new/pic32.c | 1 + drivers/usb/musb-new/sunxi.c | 1 + drivers/usb/musb-new/ti-musb.c | 2 + drivers/usb/phy/rockchip_usb2_phy.c | 1 + drivers/video/am335x-fb.c | 2 + drivers/video/atmel_hlcdfb.c | 1 + drivers/video/atmel_lcdfb.c | 1 + drivers/video/bridge/ps862x.c | 1 + drivers/video/broadwell_igd.c | 1 + drivers/video/cfb_console.c | 1 + drivers/video/da8xx-fb.c | 1 + drivers/video/exynos/exynos_dp.c | 1 + drivers/video/exynos/exynos_fb.c | 1 + drivers/video/exynos/exynos_mipi_dsi.c | 1 + drivers/video/fsl_dcu_fb.c | 1 + drivers/video/ivybridge_igd.c | 1 + drivers/video/mali_dp.c | 1 + drivers/video/meson/meson_dw_hdmi.c | 1 + drivers/video/meson/meson_vclk.c | 1 + drivers/video/meson/meson_vpu.c | 1 + drivers/video/mxsfb.c | 1 + drivers/video/rockchip/rk3288_vop.c | 1 + drivers/video/rockchip/rk3399_vop.c | 1 + drivers/video/rockchip/rk_lvds.c | 1 + drivers/video/rockchip/rk_mipi.c | 1 + drivers/video/rockchip/rk_vop.c | 1 + drivers/video/sandbox_sdl.c | 1 + drivers/video/simplefb.c | 1 + drivers/video/stm32/stm32_dsi.c | 2 + drivers/video/stm32/stm32_ltdc.c | 2 + drivers/video/sunxi/sunxi_lcd.c | 1 + drivers/video/tegra.c | 1 + drivers/video/tegra124/sor.c | 1 + drivers/video/video-uclass.c | 1 + drivers/video/videomodes.c | 1 + drivers/watchdog/armada-37xx-wdt.c | 1 + drivers/watchdog/at91sam9_wdt.c | 1 + drivers/watchdog/mt7621_wdt.c | 1 + drivers/watchdog/octeontx_wdt.c | 1 + drivers/watchdog/orion_wdt.c | 1 + drivers/watchdog/sbsa_gwdt.c | 1 + drivers/watchdog/sp805_wdt.c | 1 + drivers/watchdog/stm32mp_wdt.c | 1 + drivers/watchdog/wdt-uclass.c | 1 + drivers/xen/gnttab.c | 2 + drivers/xen/pvblock.c | 1 + env/callback.c | 1 + env/common.c | 2 + env/eeprom.c | 1 + env/env.c | 1 + env/ext4.c | 1 + env/flash.c | 1 + env/mmc.c | 1 + env/nand.c | 1 + env/nowhere.c | 1 + env/nvram.c | 1 + env/onenand.c | 1 + env/remote.c | 1 + env/sf.c | 1 + env/ubi.c | 1 + examples/standalone/stubs.c | 1 + fs/ext4/ext4_journal.c | 1 + fs/ext4/ext4_journal.h | 1 + fs/ext4/ext4fs.c | 2 +- fs/fs.c | 2 + fs/reiserfs/reiserfs_private.h | 2 + fs/ubifs/debug.c | 1 + fs/ubifs/debug.h | 1 + fs/ubifs/lpt_commit.c | 1 + fs/ubifs/super.c | 1 + fs/ubifs/ubifs.c | 1 + fs/ubifs/ubifs.h | 1 + fs/yaffs2/yaffs_uboot_glue.c | 1 + include/audio_codec.h | 2 + include/axi.h | 2 + include/backlight.h | 2 + include/board.h | 3 + include/bootcount.h | 1 + include/cache.h | 2 + include/common.h | 3 - include/cpu.h | 2 + include/crypto/pkcs7_parser.h | 1 + include/display_options.h | 1 + include/dm/device-internal.h | 1 + include/dm/device_compat.h | 1 + include/dm/read.h | 1 + include/dm/root.h | 1 + include/dma.h | 2 + include/exports.h | 1 + include/ext_common.h | 2 + include/fsl_qe.h | 2 + include/i2c.h | 1 + include/image-sparse.h | 1 + include/init.h | 7 +- include/initcall.h | 1 + include/led.h | 2 + include/libata.h | 2 - include/linux/soc/ti/cppi5.h | 1 + include/misc.h | 2 + include/netdev.h | 2 + include/pci.h | 2 - include/power/as3722.h | 2 + include/power/regulator.h | 2 + include/pwm.h | 2 + include/ram.h | 2 + include/scsi.h | 2 + include/soc.h | 2 + include/sysreset.h | 2 + include/tee.h | 2 + include/tlv_eeprom.h | 2 + include/tpm-common.h | 2 + include/tpm-v1.h | 2 + include/tpm-v2.h | 2 + include/tps6586x.h | 2 + include/ufs.h | 3 + lib/acpi/acpi_table.c | 1 + lib/aes.c | 1 + lib/asm-offsets.c | 1 + lib/asn1_decoder.c | 1 + lib/bch.c | 1 + lib/crypto/asymmetric_type.c | 1 + lib/crypto/pkcs7_parser.c | 1 + lib/crypto/pkcs7_verify.c | 1 + lib/crypto/public_key.c | 1 + lib/crypto/rsa_helper.c | 1 + lib/crypto/x509_cert_parser.c | 1 + lib/crypto/x509_public_key.c | 1 + lib/display_options.c | 1 + lib/efi/efi_app.c | 1 + lib/efi/efi_info.c | 1 + lib/efi_loader/efi_boottime.c | 1 + lib/efi_loader/efi_gop.c | 1 + lib/efi_loader/efi_memory.c | 1 + lib/efi_loader/efi_rng.c | 1 + lib/efi_loader/efi_runtime.c | 1 + lib/fdtdec.c | 2 + lib/list_sort.c | 1 + lib/optee/optee.c | 1 + lib/time.c | 1 + lib/trace.c | 1 + lib/zlib/zlib.c | 1 + net/eth-uclass.c | 1 + net/eth_legacy.c | 1 + net/fastboot.c | 1 + net/nfs.c | 1 + net/tftp.c | 2 + post/drivers/memory.c | 1 + post/drivers/rtc.c | 4 +- post/post.c | 1 + test/bloblist.c | 1 + test/dm/acpi.c | 1 + test/dm/blk.c | 1 + test/dm/bus.c | 1 + test/dm/core.c | 1 + test/dm/fdtdec.c | 1 + test/dm/mux-emul.c | 1 + test/dm/ram.c | 1 + test/dm/test-fdt.c | 1 + test/dm/test-main.c | 1 + test/lib/test_print.c | 1 + test/log/cont_test.c | 1 + test/log/nolog_test.c | 1 + test/log/syslog_test.c | 1 + test/log/syslog_test_ndebug.c | 1 + test/ut.c | 1 + 1638 files changed, 2642 insertions(+), 68 deletions(-) create mode 100644 board/freescale/p1023rdb/p1023rdb.c create mode 100644 drivers/clk/at91/clk-generated.c create mode 100644 drivers/clk/at91/clk-h32mx.c create mode 100644 drivers/clk/at91/clk-plla.c create mode 100644 drivers/clk/at91/clk-usb.c create mode 100644 drivers/phy/meson-gxl-usb3.c
Move this out of the common header and include it only where needed.
arch/arc/lib/bootm.c | 1 + arch/arc/lib/cache.c | 1 + arch/arc/lib/cpu.c | 1 + arch/arc/lib/relocate.c | 1 + arch/arm/cpu/arm1136/mx35/generic.c | 1 + arch/arm/cpu/arm926ejs/armada100/dram.c | 1 + arch/arm/cpu/arm926ejs/armada100/timer.c | 1 + arch/arm/cpu/arm926ejs/mx25/generic.c | 1 + arch/arm/cpu/arm926ejs/mx27/timer.c | 1 + arch/arm/cpu/arm926ejs/mxs/mxs.c | 1 + arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 1 + arch/arm/cpu/arm926ejs/mxs/timer.c | 1 + arch/arm/cpu/arm926ejs/spear/spr_misc.c | 1 + arch/arm/cpu/arm926ejs/spear/timer.c | 1 + arch/arm/cpu/armv7/arch_timer.c | 1 + arch/arm/cpu/armv7/ls102xa/clock.c | 1 + arch/arm/cpu/armv7/ls102xa/cpu.c | 1 + arch/arm/cpu/armv7/ls102xa/fdt.c | 1 + arch/arm/cpu/armv7/ls102xa/timer.c | 1 + arch/arm/cpu/armv7/s5p-common/cpu_info.c | 1 + arch/arm/cpu/armv7/s5p-common/timer.c | 1 + arch/arm/cpu/armv7/s5p4418/cpu.c | 1 + arch/arm/cpu/armv7/stv0991/timer.c | 1 + arch/arm/cpu/armv7/sunxi/timer.c | 1 + arch/arm/cpu/armv7/vf610/generic.c | 1 + arch/arm/cpu/armv7/vf610/timer.c | 1 + arch/arm/cpu/armv7m/systick-timer.c | 1 + arch/arm/cpu/armv8/cache_v8.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 1 + .../armv8/fsl-layerscape/fsl_lsch2_speed.c | 1 + .../armv8/fsl-layerscape/fsl_lsch3_speed.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/mp.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/ppa.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/spl.c | 1 + arch/arm/cpu/armv8/generic_timer.c | 1 + arch/arm/cpu/armv8/s32v234/generic.c | 1 + arch/arm/cpu/armv8/sec_firmware.c | 1 + arch/arm/include/asm/arch-rockchip/clock.h | 2 + arch/arm/include/asm/arch-tegra/clock.h | 2 + arch/arm/include/asm/arch-tegra/tegra_i2c.h | 2 + arch/arm/include/asm/global_data.h | 3 + arch/arm/include/asm/mach-imx/video.h | 4 +- arch/arm/include/asm/secure.h | 1 + arch/arm/include/asm/spl.h | 1 + arch/arm/include/asm/string.h | 2 - arch/arm/include/asm/ti-common/sys_proto.h | 2 + arch/arm/lib/bdinfo.c | 1 + arch/arm/lib/bootm-fdt.c | 1 + arch/arm/lib/bootm.c | 1 + arch/arm/lib/cache-cp15.c | 1 + arch/arm/lib/cache.c | 1 + arch/arm/lib/image.c | 1 + arch/arm/lib/interrupts.c | 1 + arch/arm/lib/interrupts_64.c | 1 + arch/arm/lib/spl.c | 1 + arch/arm/lib/stack.c | 1 + arch/arm/mach-aspeed/ast2500/board_common.c | 1 + arch/arm/mach-at91/arm920t/clock.c | 1 + arch/arm/mach-at91/arm920t/timer.c | 1 + arch/arm/mach-at91/arm926ejs/clock.c | 1 + arch/arm/mach-at91/arm926ejs/timer.c | 1 + arch/arm/mach-at91/armv7/clock.c | 1 + arch/arm/mach-at91/armv7/timer.c | 1 + arch/arm/mach-at91/spl_at91.c | 1 + arch/arm/mach-bcm283x/init.c | 1 + arch/arm/mach-davinci/cpu.c | 1 + arch/arm/mach-davinci/misc.c | 1 + arch/arm/mach-davinci/timer.c | 1 + arch/arm/mach-exynos/spl_boot.c | 1 + arch/arm/mach-imx/imx8/ahab.c | 1 + arch/arm/mach-imx/imx8/clock.c | 1 + arch/arm/mach-imx/imx8/cpu.c | 1 + arch/arm/mach-imx/imx8/fdt.c | 1 + arch/arm/mach-imx/imx8/iomux.c | 1 + arch/arm/mach-imx/imx8/snvs_security_sc.c | 1 + arch/arm/mach-imx/imx8m/clock_imx8mm.c | 1 + arch/arm/mach-imx/imx8m/soc.c | 1 + arch/arm/mach-imx/misc.c | 1 + arch/arm/mach-imx/mx5/mx53_dram.c | 1 + arch/arm/mach-imx/mx6/litesom.c | 1 + arch/arm/mach-imx/mx6/opos6ul.c | 1 + arch/arm/mach-imx/mx7/clock.c | 1 + arch/arm/mach-imx/mx7ulp/clock.c | 1 + arch/arm/mach-imx/speed.c | 1 + arch/arm/mach-imx/spl.c | 1 + arch/arm/mach-imx/spl_imx_romapi.c | 1 + arch/arm/mach-imx/syscounter.c | 1 + arch/arm/mach-k3/am6_init.c | 1 + arch/arm/mach-k3/common.c | 1 + arch/arm/mach-k3/sysfw-loader.c | 1 + arch/arm/mach-mediatek/mt7623/init.c | 1 + arch/arm/mach-mediatek/mt7629/init.c | 1 + arch/arm/mach-mediatek/mt8512/init.c | 1 + arch/arm/mach-mediatek/mt8516/init.c | 1 + arch/arm/mach-mediatek/mt8518/init.c | 1 + arch/arm/mach-meson/board-axg.c | 1 + arch/arm/mach-meson/board-common.c | 1 + arch/arm/mach-meson/board-g12a.c | 1 + arch/arm/mach-meson/board-gx.c | 1 + arch/arm/mach-meson/board-info.c | 1 + arch/arm/mach-meson/sm.c | 1 + arch/arm/mach-mvebu/arm64-common.c | 1 + arch/arm/mach-mvebu/armada3700/cpu.c | 1 + arch/arm/mach-mvebu/armada8k/dram.c | 1 + arch/arm/mach-mvebu/dram.c | 1 + arch/arm/mach-mvebu/spl.c | 1 + arch/arm/mach-nexell/cmd_boot_linux.c | 1 + arch/arm/mach-octeontx/cpu.c | 1 + arch/arm/mach-octeontx2/cpu.c | 1 + arch/arm/mach-omap2/am33xx/board.c | 1 + arch/arm/mach-omap2/boot-common.c | 1 + arch/arm/mach-omap2/hwinit-common.c | 1 + arch/arm/mach-omap2/omap-cache.c | 1 + arch/arm/mach-omap2/omap3/am35x_musb.c | 1 + arch/arm/mach-omap2/omap3/emif4.c | 1 + arch/arm/mach-omap2/omap3/sdrc.c | 1 + arch/arm/mach-omap2/timer.c | 1 + arch/arm/mach-orion5x/dram.c | 1 + arch/arm/mach-orion5x/timer.c | 1 + arch/arm/mach-owl/soc.c | 1 + arch/arm/mach-rmobile/memmap-gen3.c | 1 + arch/arm/mach-rockchip/board.c | 1 + arch/arm/mach-rockchip/rk3036-board-spl.c | 1 + arch/arm/mach-rockchip/rk3036/rk3036.c | 1 + arch/arm/mach-rockchip/rk3128/rk3128.c | 1 + arch/arm/mach-rockchip/rk3188/rk3188.c | 1 + arch/arm/mach-rockchip/rk3288/rk3288.c | 1 + arch/arm/mach-rockchip/rk3308/rk3308.c | 1 + arch/arm/mach-rockchip/rk3328/rk3328.c | 1 + arch/arm/mach-rockchip/rk3368/rk3368.c | 1 + arch/arm/mach-rockchip/rk3399/rk3399.c | 1 + arch/arm/mach-rockchip/sdram.c | 1 + arch/arm/mach-rockchip/spl-boot-order.c | 1 + arch/arm/mach-rockchip/spl.c | 1 + arch/arm/mach-snapdragon/pinctrl-snapdragon.h | 2 +- arch/arm/mach-socfpga/board.c | 1 + arch/arm/mach-socfpga/clock_manager.c | 1 + arch/arm/mach-socfpga/clock_manager_agilex.c | 1 + arch/arm/mach-socfpga/clock_manager_s10.c | 1 + arch/arm/mach-socfpga/mailbox_s10.c | 1 + arch/arm/mach-socfpga/misc.c | 1 + arch/arm/mach-socfpga/misc_gen5.c | 1 + arch/arm/mach-socfpga/misc_s10.c | 1 + arch/arm/mach-socfpga/mmu-arm64_s10.c | 1 + arch/arm/mach-socfpga/reset_manager_arria10.c | 1 + arch/arm/mach-socfpga/reset_manager_s10.c | 1 + arch/arm/mach-socfpga/spl_a10.c | 1 + arch/arm/mach-socfpga/spl_agilex.c | 1 + arch/arm/mach-socfpga/spl_gen5.c | 1 + arch/arm/mach-socfpga/spl_s10.c | 1 + arch/arm/mach-socfpga/system_manager_s10.c | 1 + arch/arm/mach-stm32mp/boot_params.c | 1 + .../mach-stm32mp/cmd_stm32prog/stm32prog.c | 1 + .../cmd_stm32prog/stm32prog_serial.c | 1 + arch/arm/mach-stm32mp/cpu.c | 1 + arch/arm/mach-stm32mp/dram_init.c | 1 + arch/arm/mach-stm32mp/fdt.c | 1 + arch/arm/mach-stm32mp/spl.c | 1 + arch/arm/mach-tegra/board.c | 1 + arch/arm/mach-tegra/board2.c | 1 + arch/arm/mach-tegra/cboot.c | 1 + arch/arm/mach-tegra/emc.c | 1 + arch/arm/mach-tegra/pmc.c | 1 + arch/arm/mach-tegra/tegra124/xusb-padctl.c | 1 + arch/arm/mach-tegra/tegra20/warmboot.c | 1 + arch/arm/mach-tegra/tegra210/xusb-padctl.c | 1 + arch/arm/mach-uniphier/board_late_init.c | 1 + arch/arm/mach-versal/clk.c | 1 + arch/arm/mach-versal/cpu.c | 1 + arch/arm/mach-versal/mp.c | 1 + arch/arm/mach-zynq/clk.c | 1 + arch/arm/mach-zynq/timer.c | 1 + arch/arm/mach-zynqmp-r5/cpu.c | 1 + arch/arm/mach-zynqmp/clk.c | 1 + arch/arm/mach-zynqmp/cpu.c | 1 + arch/m68k/cpu/mcf5227x/cpu.c | 1 + arch/m68k/cpu/mcf5227x/speed.c | 1 + arch/m68k/cpu/mcf523x/cpu.c | 1 + arch/m68k/cpu/mcf523x/speed.c | 1 + arch/m68k/cpu/mcf52x2/cpu.c | 1 + arch/m68k/cpu/mcf52x2/speed.c | 1 + arch/m68k/cpu/mcf530x/speed.c | 1 + arch/m68k/cpu/mcf532x/cpu.c | 1 + arch/m68k/cpu/mcf532x/speed.c | 1 + arch/m68k/cpu/mcf5445x/cpu.c | 1 + arch/m68k/cpu/mcf5445x/speed.c | 1 + arch/m68k/cpu/mcf547x_8x/cpu.c | 1 + arch/m68k/cpu/mcf547x_8x/slicetimer.c | 1 + arch/m68k/cpu/mcf547x_8x/speed.c | 1 + arch/m68k/include/asm/immap.h | 1 + arch/m68k/lib/bdinfo.c | 1 + arch/m68k/lib/bootm.c | 1 + arch/m68k/lib/fec.c | 1 + arch/m68k/lib/time.c | 1 + arch/microblaze/cpu/interrupts.c | 1 + arch/microblaze/cpu/timer.c | 1 + arch/microblaze/lib/bootm.c | 1 + arch/mips/include/asm/io.h | 1 + arch/mips/include/asm/spl.h | 1 + arch/mips/lib/boot.c | 1 + arch/mips/lib/bootm.c | 1 + arch/mips/lib/cache.c | 1 + arch/mips/lib/reloc.c | 1 + arch/mips/lib/stack.c | 1 + arch/mips/lib/traps.c | 1 + arch/mips/mach-ath79/ar933x/clk.c | 1 + arch/mips/mach-ath79/ar934x/clk.c | 1 + arch/mips/mach-ath79/ar934x/ddr.c | 1 + arch/mips/mach-ath79/cpu.c | 1 + arch/mips/mach-ath79/dram.c | 1 + arch/mips/mach-ath79/include/mach/ath79.h | 1 + arch/mips/mach-ath79/qca953x/clk.c | 1 + arch/mips/mach-ath79/qca956x/clk.c | 1 + arch/mips/mach-ath79/qca956x/ddr.c | 1 + arch/mips/mach-bmips/dram.c | 1 + arch/mips/mach-jz47xx/jz4780/jz4780.c | 1 + arch/mips/mach-mscc/cpu.c | 1 + arch/mips/mach-mscc/dram.c | 1 + arch/mips/mach-mtmips/cpu.c | 1 + arch/mips/mach-mtmips/ddr_cal.c | 1 + arch/mips/mach-mtmips/mt7628/ddr.c | 1 + arch/mips/mach-mtmips/mt7628/init.c | 1 + arch/mips/mach-mtmips/spl.c | 2 +- arch/mips/mach-octeon/bootoctlinux.c | 1 + arch/mips/mach-pic32/cpu.c | 1 + arch/nds32/lib/bootm.c | 1 + arch/nios2/cpu/cpu.c | 1 + arch/nios2/include/asm/io.h | 3 + arch/nios2/lib/cache.c | 1 + arch/powerpc/cpu/mpc83xx/cpu.c | 1 + arch/powerpc/cpu/mpc83xx/cpu_init.c | 1 + arch/powerpc/cpu/mpc83xx/fdt.c | 1 + arch/powerpc/cpu/mpc83xx/interrupts.c | 1 + arch/powerpc/cpu/mpc83xx/pci.c | 1 + arch/powerpc/cpu/mpc83xx/pcie.c | 1 + arch/powerpc/cpu/mpc83xx/spd_sdram.c | 1 + arch/powerpc/cpu/mpc83xx/speed.c | 1 + arch/powerpc/cpu/mpc83xx/spl_minimal.c | 1 + arch/powerpc/cpu/mpc83xx/traps.c | 1 + arch/powerpc/cpu/mpc85xx/commproc.c | 1 + arch/powerpc/cpu/mpc85xx/cpu.c | 1 + arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 1 + arch/powerpc/cpu/mpc85xx/fdt.c | 1 + arch/powerpc/cpu/mpc85xx/mp.c | 1 + arch/powerpc/cpu/mpc85xx/serial_scc.c | 1 + arch/powerpc/cpu/mpc85xx/speed.c | 1 + arch/powerpc/cpu/mpc85xx/tlb.c | 1 + arch/powerpc/cpu/mpc85xx/traps.c | 1 + arch/powerpc/cpu/mpc86xx/cpu.c | 1 + arch/powerpc/cpu/mpc86xx/cpu_init.c | 1 + arch/powerpc/cpu/mpc86xx/fdt.c | 1 + arch/powerpc/cpu/mpc86xx/mp.c | 1 + arch/powerpc/cpu/mpc86xx/speed.c | 1 + arch/powerpc/cpu/mpc86xx/traps.c | 1 + arch/powerpc/cpu/mpc8xx/cpu.c | 1 + arch/powerpc/cpu/mpc8xx/fdt.c | 1 + arch/powerpc/cpu/mpc8xx/immap.c | 1 + arch/powerpc/cpu/mpc8xx/speed.c | 1 + arch/powerpc/cpu/mpc8xxx/cpu.c | 1 + arch/powerpc/cpu/mpc8xxx/law.c | 1 + arch/powerpc/cpu/mpc8xxx/pamu_table.c | 1 + arch/powerpc/lib/bat_rw.c | 1 + arch/powerpc/lib/bdinfo.c | 1 + arch/powerpc/lib/bootm.c | 1 + arch/powerpc/lib/stack.c | 1 + arch/riscv/cpu/fu540/cache.c | 1 + arch/riscv/cpu/fu540/dram.c | 1 + arch/riscv/cpu/generic/dram.c | 1 + arch/riscv/lib/andes_plic.c | 1 + arch/riscv/lib/asm-offsets.c | 1 + arch/riscv/lib/bootm.c | 1 + arch/riscv/lib/fdt_fixup.c | 1 + arch/riscv/lib/image.c | 1 + arch/riscv/lib/interrupts.c | 1 + arch/riscv/lib/sifive_clint.c | 1 + arch/riscv/lib/smp.c | 1 + arch/riscv/lib/spl.c | 1 + arch/sandbox/cpu/cpu.c | 1 + arch/sandbox/cpu/spl.c | 1 + arch/sandbox/cpu/start.c | 1 + arch/sh/lib/board.c | 1 + arch/x86/cpu/apollolake/cpu_spl.c | 1 + arch/x86/cpu/apollolake/fsp_s.c | 1 + arch/x86/cpu/baytrail/fsp_configs.c | 1 + arch/x86/cpu/braswell/fsp_configs.c | 1 + arch/x86/cpu/broadwell/cpu.c | 1 + arch/x86/cpu/broadwell/cpu_from_spl.c | 1 + arch/x86/cpu/broadwell/cpu_full.c | 1 + arch/x86/cpu/broadwell/lpc.c | 1 + arch/x86/cpu/broadwell/northbridge.c | 1 + arch/x86/cpu/broadwell/pch.c | 1 + arch/x86/cpu/broadwell/pinctrl_broadwell.c | 1 + arch/x86/cpu/broadwell/sata.c | 1 + arch/x86/cpu/broadwell/sdram.c | 1 + arch/x86/cpu/coreboot/coreboot.c | 1 + arch/x86/cpu/coreboot/sdram.c | 1 + arch/x86/cpu/coreboot/tables.c | 1 + arch/x86/cpu/cpu.c | 1 + arch/x86/cpu/cpu_x86.c | 1 + arch/x86/cpu/efi/payload.c | 1 + arch/x86/cpu/efi/sdram.c | 1 + arch/x86/cpu/i386/cpu.c | 1 + arch/x86/cpu/i386/interrupt.c | 1 + arch/x86/cpu/intel_common/acpi.c | 1 + arch/x86/cpu/intel_common/cpu.c | 1 + arch/x86/cpu/intel_common/cpu_from_spl.c | 1 + arch/x86/cpu/intel_common/itss.c | 1 + arch/x86/cpu/intel_common/lpc.c | 1 + arch/x86/cpu/intel_common/microcode.c | 1 + arch/x86/cpu/intel_common/mrc.c | 1 + arch/x86/cpu/irq.c | 1 + arch/x86/cpu/ivybridge/bd82x6x.c | 1 + arch/x86/cpu/ivybridge/cpu.c | 1 + arch/x86/cpu/ivybridge/fsp_configs.c | 1 + arch/x86/cpu/ivybridge/lpc.c | 1 + arch/x86/cpu/ivybridge/model_206ax.c | 1 + arch/x86/cpu/ivybridge/northbridge.c | 1 + arch/x86/cpu/ivybridge/sata.c | 1 + arch/x86/cpu/ivybridge/sdram_nop.c | 1 + arch/x86/cpu/mp_init.c | 1 + arch/x86/cpu/mtrr.c | 1 + arch/x86/cpu/qemu/dram.c | 1 + arch/x86/cpu/qemu/e820.c | 1 + arch/x86/cpu/quark/acpi.c | 1 + arch/x86/cpu/quark/dram.c | 1 + arch/x86/cpu/slimbootloader/sdram.c | 1 + arch/x86/cpu/slimbootloader/serial.c | 1 + arch/x86/cpu/slimbootloader/slimbootloader.c | 1 + arch/x86/cpu/turbo.c | 1 + arch/x86/cpu/x86_64/cpu.c | 1 + arch/x86/include/asm/cpu_common.h | 1 + arch/x86/include/asm/fast_spi.h | 4 +- arch/x86/include/asm/io.h | 2 +- arch/x86/include/asm/mp.h | 2 + arch/x86/include/asm/mrccache.h | 2 + arch/x86/include/asm/u-boot-x86.h | 1 + arch/x86/lib/acpi_s3.c | 1 + arch/x86/lib/acpi_table.c | 1 + arch/x86/lib/asm-offsets.c | 1 + arch/x86/lib/bios.c | 1 + arch/x86/lib/bootm.c | 1 + arch/x86/lib/cmd_boot.c | 1 + arch/x86/lib/coreboot_table.c | 1 + arch/x86/lib/e820.c | 1 + arch/x86/lib/fsp/fsp_common.c | 1 + arch/x86/lib/fsp/fsp_dram.c | 1 + arch/x86/lib/fsp/fsp_graphics.c | 1 + arch/x86/lib/fsp1/fsp_common.c | 1 + arch/x86/lib/fsp1/fsp_dram.c | 1 + arch/x86/lib/fsp2/fsp_dram.c | 1 + arch/x86/lib/fsp2/fsp_meminit.c | 1 + arch/x86/lib/fsp2/fsp_silicon_init.c | 1 + arch/x86/lib/fsp2/fsp_support.c | 1 + arch/x86/lib/init_helpers.c | 1 + arch/x86/lib/mpspec.c | 1 + arch/x86/lib/mrccache.c | 1 + arch/x86/lib/physmem.c | 1 + arch/x86/lib/pinctrl_ich6.c | 1 + arch/x86/lib/pirq_routing.c | 1 + arch/x86/lib/relocate.c | 1 + arch/x86/lib/spl.c | 1 + arch/x86/lib/tables.c | 1 + arch/x86/lib/tpl.c | 1 + arch/xtensa/lib/bootm.c | 1 + board/AndesTech/adp-ae3xx/adp-ae3xx.c | 1 + board/AndesTech/adp-ag101p/adp-ag101p.c | 1 + board/AndesTech/ax25-ae350/ax25-ae350.c | 1 + board/Arcturus/ucp1020/spl.c | 1 + board/BuR/brppt1/board.c | 1 + board/BuR/brppt2/board.c | 1 + board/BuR/brsmarc1/board.c | 1 + board/BuR/brxre1/board.c | 1 + board/BuR/common/common.c | 1 + board/BuS/eb_cpu5282/eb_cpu5282.c | 1 + board/CZ.NIC/turris_mox/turris_mox.c | 1 + board/CZ.NIC/turris_omnia/turris_omnia.c | 1 + board/CarMediaLab/flea3/flea3.c | 1 + board/LaCie/edminiv2/edminiv2.c | 1 + board/LaCie/net2big_v2/net2big_v2.c | 1 + board/LaCie/netspace_v2/netspace_v2.c | 1 + board/Marvell/aspenite/aspenite.c | 1 + board/Marvell/db-88f6281-bp/db-88f6281-bp.c | 1 + board/Marvell/db-88f6720/db-88f6720.c | 1 + board/Marvell/db-88f6820-amc/db-88f6820-amc.c | 1 + board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 1 + board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c | 1 + board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c | 1 + board/Marvell/dreamplug/dreamplug.c | 1 + board/Marvell/gplugd/gplugd.c | 1 + board/Marvell/guruplug/guruplug.c | 1 + board/Marvell/mvebu_armada-37xx/board.c | 1 + board/Marvell/mvebu_armada-8k/board.c | 1 + board/Marvell/octeontx/board.c | 2 + board/Marvell/octeontx2/board.c | 2 + board/Marvell/openrd/openrd.c | 1 + board/Marvell/sheevaplug/sheevaplug.c | 1 + board/Seagate/dockstar/dockstar.c | 1 + board/Seagate/goflexhome/goflexhome.c | 1 + board/Seagate/nas220/nas220.c | 1 + board/Synology/ds109/ds109.c | 1 + board/Synology/ds414/ds414.c | 1 + board/advantech/dms-ba16/dms-ba16.c | 1 + .../imx8qm_rom7720_a1/imx8qm_rom7720_a1.c | 1 + board/advantech/imx8qm_rom7720_a1/spl.c | 1 + board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c | 1 + .../alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c | 1 + board/alliedtelesis/common/gpio_hog.c | 1 + board/alliedtelesis/x530/x530.c | 1 + board/amazon/kc1/kc1.c | 1 + board/amlogic/vim3/vim3.c | 1 + board/aristainetos/aristainetos.c | 1 + board/armadeus/apf27/apf27.c | 1 + board/armltd/integrator/integrator.c | 1 + board/armltd/total_compute/total_compute.c | 1 + board/armltd/vexpress/vexpress_common.c | 1 + board/armltd/vexpress64/vexpress64.c | 1 + board/astro/mcf5373l/mcf5373l.c | 1 + .../armadillo-800eva/armadillo-800eva.c | 1 + board/atmel/at91rm9200ek/at91rm9200ek.c | 1 + board/atmel/at91sam9260ek/at91sam9260ek.c | 1 + board/atmel/at91sam9261ek/at91sam9261ek.c | 1 + board/atmel/at91sam9263ek/at91sam9263ek.c | 1 + .../atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 1 + board/atmel/at91sam9n12ek/at91sam9n12ek.c | 1 + board/atmel/at91sam9rlek/at91sam9rlek.c | 1 + board/atmel/at91sam9x5ek/at91sam9x5ek.c | 1 + board/atmel/common/video_display.c | 1 + board/atmel/sam9x60ek/sam9x60ek.c | 1 + .../atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 1 + .../sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 1 + board/atmel/sama5d2_icp/sama5d2_icp.c | 1 + board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c | 1 + .../atmel/sama5d2_xplained/sama5d2_xplained.c | 1 + .../atmel/sama5d3_xplained/sama5d3_xplained.c | 1 + board/atmel/sama5d3xek/sama5d3xek.c | 1 + .../atmel/sama5d4_xplained/sama5d4_xplained.c | 1 + board/atmel/sama5d4ek/sama5d4ek.c | 1 + board/bachmann/ot1200/ot1200.c | 1 + board/barco/platinum/platinum.c | 1 + board/barco/titanium/titanium.c | 1 + board/beacon/beacon-rzg2m/beacon-rzg2m.c | 1 + board/beacon/imx8mm/imx8mm_beacon.c | 1 + board/beacon/imx8mm/spl.c | 1 + board/beckhoff/mx53cx9020/mx53cx9020.c | 1 + board/bluegiga/apx4devkit/apx4devkit.c | 1 + board/bluewater/gurnard/gurnard.c | 1 + board/bluewater/snapper9260/snapper9260.c | 1 + board/bosch/guardian/board.c | 1 + board/bosch/shc/board.c | 1 + board/boundary/nitrogen6x/nitrogen6x.c | 1 + board/broadcom/bcm23550_w1d/bcm23550_w1d.c | 1 + board/broadcom/bcm28155_ap/bcm28155_ap.c | 1 + board/broadcom/bcm_ep/board.c | 1 + board/broadcom/bcmns2/northstar2.c | 1 + board/broadcom/bcmns3/ns3.c | 1 + board/broadcom/bcmstb/bcmstb.c | 1 + board/bticino/mamoj/mamoj.c | 1 + board/bticino/mamoj/spl.c | 1 + board/buffalo/lsxl/lsxl.c | 1 + board/calao/usb_a9263/usb_a9263.c | 1 + board/cavium/thunderx/thunderx.c | 1 + board/ccv/xpress/xpress.c | 1 + board/cirrus/edb93xx/edb93xx.c | 1 + board/cloudengines/pogo_e02/pogo_e02.c | 1 + board/cobra5272/cobra5272.c | 1 + board/compulab/cl-som-imx7/cl-som-imx7.c | 1 + board/compulab/cm_fx6/cm_fx6.c | 1 + board/compulab/cm_t335/cm_t335.c | 1 + board/compulab/cm_t43/cm_t43.c | 1 + board/congatec/cgtqmx6eval/cgtqmx6eval.c | 1 + board/corscience/tricorder/tricorder.c | 1 + board/cortina/presidio-asic/presidio.c | 1 + board/creative/xfi3/xfi3.c | 1 + board/cssi/MCR3000/MCR3000.c | 1 + board/d-link/dns325/dns325.c | 1 + board/davinci/da8xxevm/da850evm.c | 1 + board/davinci/da8xxevm/omapl138_lcdk.c | 1 + board/dhelectronics/dh_imx6/dh_imx6.c | 1 + board/dhelectronics/dh_stm32mp1/board.c | 1 + board/ea/mx7ulp_com/mx7ulp_com.c | 1 + board/eets/pdu001/board.c | 1 + board/egnite/ethernut5/ethernut5.c | 1 + board/el/el6x/el6x.c | 1 + board/elgin/elgin_rv1108/elgin_rv1108.c | 1 + board/embest/mx6boards/mx6boards.c | 1 + board/engicam/common/board.c | 1 + board/esd/meesc/meesc.c | 1 + board/esd/vme8349/vme8349.c | 1 + board/firefly/firefly-rk3288/firefly-rk3288.c | 1 + board/freescale/common/arm_sleep.c | 1 + board/freescale/common/emc2305.c | 1 + board/freescale/common/mpc85xx_sleep.c | 1 + board/freescale/corenet_ds/corenet_ds.c | 1 + board/freescale/corenet_ds/ddr.c | 1 + board/freescale/imx8mm_evk/imx8mm_evk.c | 1 + board/freescale/imx8mm_evk/spl.c | 1 + board/freescale/imx8mn_evk/imx8mn_evk.c | 1 + board/freescale/imx8mn_evk/spl.c | 1 + board/freescale/imx8mp_evk/imx8mp_evk.c | 1 + board/freescale/imx8mp_evk/spl.c | 1 + board/freescale/imx8mq_evk/imx8mq_evk.c | 1 + board/freescale/imx8mq_evk/spl.c | 1 + board/freescale/imx8qm_mek/imx8qm_mek.c | 1 + board/freescale/imx8qm_mek/spl.c | 1 + board/freescale/imx8qxp_mek/imx8qxp_mek.c | 1 + board/freescale/imx8qxp_mek/spl.c | 1 + board/freescale/imxrt1020-evk/imxrt1020-evk.c | 1 + board/freescale/imxrt1050-evk/imxrt1050-evk.c | 1 + board/freescale/ls1012afrdm/ls1012afrdm.c | 1 + board/freescale/ls1012aqds/ls1012aqds.c | 1 + board/freescale/ls1012ardb/ls1012ardb.c | 1 + board/freescale/ls1021aiot/dcu.c | 1 + board/freescale/ls1021aiot/ls1021aiot.c | 1 + board/freescale/ls1021aqds/dcu.c | 1 + board/freescale/ls1021aqds/ddr.c | 1 + board/freescale/ls1021atsn/ls1021atsn.c | 1 + board/freescale/ls1021atwr/dcu.c | 1 + board/freescale/ls1021atwr/ls1021atwr.c | 1 + board/freescale/ls1028a/ddr.c | 1 + board/freescale/ls1028a/ls1028a.c | 1 + board/freescale/ls1043aqds/ddr.c | 1 + board/freescale/ls1043aqds/ls1043aqds.c | 1 + board/freescale/ls1043ardb/ddr.c | 1 + board/freescale/ls1043ardb/ls1043ardb.c | 1 + board/freescale/ls1046afrwy/ddr.c | 1 + board/freescale/ls1046afrwy/ls1046afrwy.c | 1 + board/freescale/ls1046aqds/ddr.c | 1 + board/freescale/ls1046aqds/ls1046aqds.c | 1 + board/freescale/ls1046ardb/ddr.c | 1 + board/freescale/ls1046ardb/ls1046ardb.c | 1 + board/freescale/ls1088a/ddr.c | 1 + board/freescale/ls1088a/ls1088a.c | 1 + board/freescale/ls2080a/ddr.c | 1 + board/freescale/ls2080a/ls2080a.c | 1 + board/freescale/ls2080aqds/ddr.c | 1 + board/freescale/ls2080aqds/ls2080aqds.c | 1 + board/freescale/ls2080ardb/ddr.c | 1 + board/freescale/ls2080ardb/eth_ls2080rdb.c | 1 + board/freescale/ls2080ardb/ls2080ardb.c | 1 + board/freescale/lx2160a/ddr.c | 1 + board/freescale/lx2160a/eth_lx2160aqds.c | 1 + board/freescale/lx2160a/eth_lx2160ardb.c | 1 + board/freescale/lx2160a/lx2160a.c | 1 + board/freescale/m5208evbe/m5208evbe.c | 1 + board/freescale/m52277evb/m52277evb.c | 1 + board/freescale/m5235evb/m5235evb.c | 1 + board/freescale/m5249evb/m5249evb.c | 1 + board/freescale/m5253demo/m5253demo.c | 1 + board/freescale/m5272c3/m5272c3.c | 1 + board/freescale/m5275evb/m5275evb.c | 1 + board/freescale/m5282evb/m5282evb.c | 1 + board/freescale/m53017evb/m53017evb.c | 1 + board/freescale/m5329evb/m5329evb.c | 1 + board/freescale/m5373evb/m5373evb.c | 1 + board/freescale/m54418twr/m54418twr.c | 1 + board/freescale/m54451evb/m54451evb.c | 1 + board/freescale/m54455evb/m54455evb.c | 1 + board/freescale/m547xevb/m547xevb.c | 1 + board/freescale/m548xevb/m548xevb.c | 1 + board/freescale/mpc8308rdb/sdram.c | 1 + board/freescale/mpc8313erdb/mpc8313erdb.c | 1 + board/freescale/mpc8313erdb/sdram.c | 1 + board/freescale/mpc8315erdb/mpc8315erdb.c | 1 + board/freescale/mpc8315erdb/sdram.c | 1 + board/freescale/mpc8323erdb/mpc8323erdb.c | 1 + board/freescale/mpc832xemds/mpc832xemds.c | 1 + board/freescale/mpc8349emds/mpc8349emds.c | 1 + board/freescale/mpc8349itx/mpc8349itx.c | 1 + board/freescale/mpc837xemds/mpc837xemds.c | 1 + board/freescale/mpc837xerdb/mpc837xerdb.c | 1 + board/freescale/mpc8610hpcd/mpc8610hpcd.c | 1 + board/freescale/mpc8641hpcn/mpc8641hpcn.c | 1 + board/freescale/mx23evk/mx23evk.c | 1 + board/freescale/mx25pdk/mx25pdk.c | 1 + board/freescale/mx28evk/mx28evk.c | 1 + board/freescale/mx35pdk/mx35pdk.c | 1 + board/freescale/mx51evk/mx51evk.c | 1 + board/freescale/mx53ard/mx53ard.c | 1 + board/freescale/mx53evk/mx53evk.c | 1 + board/freescale/mx53loco/mx53loco.c | 1 + board/freescale/mx53smd/mx53smd.c | 1 + board/freescale/mx6memcal/mx6memcal.c | 1 + board/freescale/mx6memcal/spl.c | 1 + board/freescale/mx6qarm2/mx6qarm2.c | 1 + board/freescale/mx6sabreauto/mx6sabreauto.c | 1 + board/freescale/mx6sabresd/mx6sabresd.c | 1 + board/freescale/mx6slevk/mx6slevk.c | 1 + board/freescale/mx6sllevk/mx6sllevk.c | 1 + .../freescale/mx6sxsabreauto/mx6sxsabreauto.c | 1 + board/freescale/mx6sxsabresd/mx6sxsabresd.c | 1 + .../mx6ul_14x14_evk/mx6ul_14x14_evk.c | 1 + board/freescale/mx6ullevk/mx6ullevk.c | 1 + board/freescale/mx7dsabresd/mx7dsabresd.c | 1 + board/freescale/mx7ulp_evk/mx7ulp_evk.c | 1 + board/freescale/p1010rdb/ddr.c | 1 + board/freescale/p1010rdb/p1010rdb.c | 1 + board/freescale/p1010rdb/spl.c | 1 + board/freescale/p1023rdb/p1023rdb.c | 161 ++++++++++++++++ board/freescale/p1_p2_rdb_pc/spl.c | 1 + board/freescale/p2041rdb/ddr.c | 1 + board/freescale/p2041rdb/p2041rdb.c | 1 + board/freescale/qemu-ppce500/qemu-ppce500.c | 1 + board/freescale/s32v234evb/s32v234evb.c | 1 + board/freescale/t102xrdb/ddr.c | 1 + board/freescale/t102xrdb/spl.c | 1 + board/freescale/t102xrdb/t102xrdb.c | 1 + board/freescale/t104xrdb/ddr.c | 1 + board/freescale/t104xrdb/spl.c | 1 + board/freescale/t104xrdb/t104xrdb.c | 1 + board/freescale/t208xqds/ddr.c | 1 + board/freescale/t208xqds/spl.c | 1 + board/freescale/t208xqds/t208xqds.c | 1 + board/freescale/t208xrdb/ddr.c | 1 + board/freescale/t208xrdb/spl.c | 1 + board/freescale/t208xrdb/t208xrdb.c | 1 + board/freescale/t4rdb/ddr.c | 1 + board/freescale/t4rdb/spl.c | 1 + board/freescale/t4rdb/t4240rdb.c | 1 + board/freescale/vf610twr/vf610twr.c | 1 + board/friendlyarm/nanopi2/board.c | 1 + board/gardena/smart-gateway-at91sam/board.c | 1 + board/gateworks/gw_ventana/gw_ventana.c | 1 + board/gdsys/a38x/controlcenterdc.c | 1 + board/gdsys/a38x/hydra.c | 1 + board/gdsys/mpc8308/gazerbeam.c | 1 + board/gdsys/mpc8308/sdram.c | 1 + board/ge/bx50v3/bx50v3.c | 1 + board/ge/mx53ppd/mx53ppd.c | 1 + .../google/imx8mq_phanbell/imx8mq_phanbell.c | 1 + board/google/imx8mq_phanbell/spl.c | 1 + board/google/veyron/veyron.c | 1 + board/grinn/chiliboard/board.c | 1 + board/grinn/liteboard/board.c | 1 + board/highbank/highbank.c | 1 + board/hisilicon/hikey/hikey.c | 1 + board/hisilicon/hikey960/hikey960.c | 1 + board/hisilicon/poplar/poplar.c | 1 + board/ids/ids8313/ids8313.c | 1 + board/imgtec/boston/ddr.c | 1 + board/imgtec/boston/dt.c | 1 + board/imgtec/ci20/ci20.c | 1 + board/imgtec/malta/malta.c | 1 + board/imgtec/xilfpga/xilfpga.c | 1 + board/inversepath/usbarmory/usbarmory.c | 1 + board/iomega/iconnect/iconnect.c | 1 + board/isee/igep003x/board.c | 1 + board/isee/igep00x0/common.c | 1 + board/k+p/kp_imx53/kp_imx53.c | 1 + board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c | 1 + board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c | 1 + board/keymile/common/common.c | 1 + board/keymile/km83xx/km83xx.c | 1 + board/keymile/km_arm/km_arm.c | 1 + board/keymile/kmp204x/ddr.c | 1 + board/kmc/kzm9g/kzm9g.c | 1 + board/kobol/helios4/helios4.c | 1 + board/kontron/sl28/ddr.c | 1 + board/kontron/sl28/sl28.c | 1 + board/kosagi/novena/novena.c | 1 + board/l+g/vinco/vinco.c | 1 + board/laird/wb45n/wb45n.c | 1 + board/laird/wb50n/wb50n.c | 1 + board/lego/ev3/legoev3.c | 1 + board/lg/sniper/sniper.c | 1 + board/liebherr/display5/display5.c | 1 + board/liebherr/display5/spl.c | 1 + board/liebherr/mccmon6/mccmon6.c | 1 + board/liebherr/xea/xea.c | 1 + board/logicpd/am3517evm/am3517evm.c | 1 + board/logicpd/imx6/imx6logic.c | 1 + board/logicpd/omap3som/omap3logic.c | 1 + board/maxbcm/maxbcm.c | 1 + board/mediatek/mt7622/mt7622_rfb.c | 1 + board/mediatek/mt7623/mt7623_rfb.c | 1 + board/mediatek/mt7629/mt7629_rfb.c | 1 + board/mediatek/mt8512/mt8512.c | 1 + board/mediatek/mt8518/mt8518_ap1.c | 1 + board/menlo/m53menlo/m53menlo.c | 1 + .../crs3xx-98dx3236/crs3xx-98dx3236.c | 1 + board/mini-box/picosam9g45/picosam9g45.c | 1 + board/mpc8308_p1m/sdram.c | 1 + board/mscc/jr2/jr2.c | 1 + board/mscc/luton/luton.c | 1 + board/mscc/ocelot/ocelot.c | 1 + board/mscc/serval/serval.c | 1 + board/mscc/servalt/servalt.c | 1 + board/myir/mys_6ulx/mys_6ulx.c | 1 + board/nokia/rx51/rx51.c | 1 + board/novtech/meerkat96/meerkat96.c | 1 + board/olimex/mx23_olinuxino/mx23_olinuxino.c | 1 + board/phytec/pcl063/pcl063.c | 1 + board/phytec/pcm052/pcm052.c | 1 + board/phytec/pcm058/pcm058.c | 1 + board/phytec/pfla02/pfla02.c | 1 + board/phytec/phycore_am335x_r2/board.c | 1 + board/phytec/phycore_rk3288/phycore-rk3288.c | 1 + board/phytium/durian/durian.c | 1 + board/ppcag/bg0900/bg0900.c | 1 + board/qemu-mips/qemu-mips.c | 1 + .../dragonboard410c/dragonboard410c.c | 1 + .../dragonboard820c/dragonboard820c.c | 1 + board/raidsonic/ib62x0/ib62x0.c | 1 + board/renesas/alt/alt.c | 1 + board/renesas/blanche/blanche.c | 1 + board/renesas/condor/condor.c | 1 + board/renesas/draak/draak.c | 1 + board/renesas/eagle/eagle.c | 1 + board/renesas/ebisu/ebisu.c | 1 + board/renesas/gose/gose.c | 1 + board/renesas/grpeach/grpeach.c | 1 + board/renesas/koelsch/koelsch.c | 1 + board/renesas/lager/lager.c | 1 + board/renesas/porter/porter.c | 1 + board/renesas/rcar-common/common.c | 1 + board/renesas/salvator-x/salvator-x.c | 1 + board/renesas/silk/silk.c | 1 + board/renesas/stout/stout.c | 1 + board/renesas/ulcb/ulcb.c | 1 + board/rockchip/evb_rk3308/evb_rk3308.c | 1 + board/rockchip/evb_rv1108/evb_rv1108.c | 1 + board/ronetix/pm9261/pm9261.c | 1 + board/ronetix/pm9263/pm9263.c | 1 + board/ronetix/pm9g45/pm9g45.c | 1 + board/samsung/arndale/arndale.c | 1 + board/samsung/common/board.c | 1 + board/samsung/common/exynos5-dt-types.c | 1 + board/samsung/common/exynos5-dt.c | 1 + board/samsung/common/misc.c | 1 + board/samsung/goni/goni.c | 1 + board/samsung/odroid/odroid.c | 1 + board/samsung/smdkc100/smdkc100.c | 1 + board/samsung/smdkv310/smdkv310.c | 1 + board/samsung/universal_c210/universal.c | 1 + board/sandbox/sandbox.c | 1 + board/sandisk/sansa_fuze_plus/sfp.c | 1 + board/sbc8349/sbc8349.c | 1 + board/sbc8641d/sbc8641d.c | 1 + board/schulercontrol/sc_sps_1/sc_sps_1.c | 1 + board/seco/mx6quq7/mx6quq7.c | 1 + board/siemens/capricorn/spl.c | 1 + board/siemens/common/board.c | 1 + board/siemens/corvus/board.c | 1 + board/siemens/smartweb/smartweb.c | 1 + board/siemens/taurus/taurus.c | 1 + board/sks-kinkel/sksimx6/sksimx6.c | 1 + board/socrates/socrates.c | 1 + board/softing/vining_2000/vining_2000.c | 1 + board/softing/vining_fpga/socfpga.c | 1 + board/solidrun/clearfog/clearfog.c | 1 + board/solidrun/common/tlv_data.c | 1 + board/solidrun/mx6cuboxi/mx6cuboxi.c | 1 + board/somlabs/visionsom-6ull/visionsom-6ull.c | 1 + board/st/common/stm32mp_mtdparts.c | 1 + board/st/stih410-b2260/board.c | 1 + .../stm32f429-discovery/stm32f429-discovery.c | 1 + .../stm32f429-evaluation.c | 1 + .../stm32f469-discovery/stm32f469-discovery.c | 1 + board/st/stm32f746-disco/stm32f746-disco.c | 1 + board/st/stm32h743-disco/stm32h743-disco.c | 1 + board/st/stm32h743-eval/stm32h743-eval.c | 1 + board/st/stm32mp1/stm32mp1.c | 1 + board/st/stv0991/stv0991.c | 1 + board/ste/stemmy/stemmy.c | 1 + board/sunxi/board.c | 1 + board/synopsys/axs10x/axs10x.c | 1 + board/synopsys/emsdp/emsdp.c | 1 + board/synopsys/hsdk/hsdk.c | 1 + board/synopsys/iot_devkit/iot_devkit.c | 1 + board/sysam/amcore/amcore.c | 1 + board/sysam/stmark2/stmark2.c | 1 + board/syteco/zmx25/zmx25.c | 1 + board/tbs/tbs2910/tbs2910.c | 2 + board/tcl/sl50/board.c | 1 + board/technexion/pico-imx6/pico-imx6.c | 3 +- board/technexion/pico-imx6ul/pico-imx6ul.c | 1 + board/technexion/pico-imx7d/pico-imx7d.c | 1 + board/technexion/pico-imx8mq/pico-imx8mq.c | 1 + board/technexion/pico-imx8mq/spl.c | 1 + board/technexion/tao3530/tao3530.c | 1 + board/technologic/ts4600/ts4600.c | 1 + board/technologic/ts4800/ts4800.c | 1 + board/theadorable/theadorable.c | 1 + board/ti/am335x/board.c | 1 + board/ti/am3517crane/am3517crane.c | 1 + board/ti/am43xx/board.c | 1 + board/ti/am57xx/board.c | 1 + board/ti/am65x/evm.c | 1 + board/ti/beagle/beagle.c | 1 + board/ti/dra7xx/evm.c | 1 + board/ti/evm/evm.c | 1 + board/ti/j721e/evm.c | 1 + board/ti/ks2_evm/board.c | 1 + board/ti/omap5_uevm/evm.c | 1 + board/ti/panda/panda.c | 1 + board/ti/sdp4430/sdp.c | 1 + board/ti/ti816x/evm.c | 1 + board/timll/devkit3250/devkit3250.c | 1 + board/timll/devkit8000/devkit8000.c | 1 + board/toradex/apalis-imx8/apalis-imx8.c | 1 + board/toradex/apalis_imx6/apalis_imx6.c | 1 + board/toradex/apalis_t30/apalis_t30.c | 1 + .../toradex/colibri-imx6ull/colibri-imx6ull.c | 1 + board/toradex/colibri-imx8x/colibri-imx8x.c | 1 + board/toradex/colibri_imx6/colibri_imx6.c | 1 + board/toradex/colibri_imx7/colibri_imx7.c | 1 + board/toradex/colibri_pxa270/colibri_pxa270.c | 1 + board/toradex/colibri_t20/colibri_t20.c | 1 + board/toradex/colibri_vf/colibri_vf.c | 1 + board/toradex/common/tdx-cfg-block.c | 1 + board/toradex/common/tdx-eeprom.c | 1 + board/toradex/verdin-imx8mm/spl.c | 1 + board/toradex/verdin-imx8mm/verdin-imx8mm.c | 1 + board/tqc/tqm834x/tqm834x.c | 1 + board/tqc/tqma6/tqma6.c | 1 + board/udoo/neo/neo.c | 1 + board/udoo/udoo.c | 1 + board/variscite/dart_6ul/dart_6ul.c | 1 + board/varisys/cyrus/ddr.c | 1 + board/ve8313/ve8313.c | 1 + board/vscom/baltos/board.c | 1 + board/wandboard/wandboard.c | 1 + board/warp/warp.c | 1 + board/warp7/warp7.c | 1 + board/work-microwave/work_92105/work_92105.c | 1 + board/xen/xenguest_arm64/xenguest_arm64.c | 1 + board/xes/xpedite517x/xpedite517x.c | 1 + board/xilinx/common/board.c | 1 + .../microblaze-generic/microblaze-generic.c | 1 + board/xilinx/versal/board.c | 1 + board/xilinx/zynq/board.c | 1 + board/xilinx/zynq/bootimg.c | 1 + board/xilinx/zynq/cmds.c | 1 + board/xilinx/zynqmp/zynqmp.c | 1 + board/zyxel/nsa310s/nsa310s.c | 1 + cmd/acpi.c | 1 + cmd/bdinfo.c | 1 + cmd/bedbug.c | 1 + cmd/bloblist.c | 1 + cmd/bootefi.c | 1 + cmd/booti.c | 1 + cmd/bootm.c | 1 + cmd/date.c | 1 + cmd/efi.c | 1 + cmd/load.c | 1 + cmd/log.c | 1 + cmd/mem.c | 1 + cmd/mtdparts.c | 1 + cmd/nvedit.c | 1 + cmd/pstore.c | 1 + cmd/pxe_utils.h | 2 + cmd/sb.c | 1 + cmd/sound.c | 1 + cmd/spl.c | 1 + cmd/ti/ddr3.c | 1 + cmd/tlv_eeprom.c | 1 + cmd/x86/fsp.c | 1 + cmd/x86/hob.c | 1 + common/autoboot.c | 1 + common/bloblist.c | 1 + common/board_f.c | 1 + common/board_info.c | 1 + common/board_r.c | 1 + common/bootm.c | 1 + common/bootm_os.c | 1 + common/bootstage.c | 1 + common/cli.c | 1 + common/cli_hush.c | 1 + common/cli_readline.c | 1 + common/command.c | 1 + common/console.c | 1 + common/dlmalloc.c | 1 + common/exports.c | 1 + common/hash.c | 1 + common/hwconfig.c | 1 + common/image-android.c | 1 + common/image-cipher.c | 1 + common/image-fdt.c | 1 + common/image-fit-sig.c | 1 + common/image-fit.c | 1 + common/image-sig.c | 1 + common/image.c | 1 + common/init/board_init.c | 1 + common/init/handoff.c | 1 + common/iotrace.c | 1 + common/lcd.c | 1 + common/lcd_simplefb.c | 1 + common/log.c | 1 + common/log_console.c | 1 + common/log_syslog.c | 1 + common/malloc_simple.c | 1 + common/memsize.c | 1 + common/spl/spl.c | 1 + common/spl/spl_fit.c | 1 + common/spl/spl_opensbi.c | 1 + common/spl/spl_spi.c | 1 + common/splash_source.c | 1 + common/stdio.c | 2 +- disk/part_efi.c | 1 + drivers/ata/libata.c | 2 + drivers/ata/mtk_ahci.c | 1 + drivers/ata/sata_mv.c | 1 + drivers/bios_emulator/atibios.c | 1 + drivers/block/blkcache.c | 1 + drivers/block/sandbox.c | 1 + drivers/bootcount/bootcount_ram.c | 1 + drivers/cache/cache-v5l2.c | 1 + drivers/cache/sandbox_cache.c | 1 + drivers/clk/altera/clk-agilex.c | 1 + drivers/clk/altera/clk-arria10.c | 1 + drivers/clk/aspeed/clk_ast2500.c | 1 + drivers/clk/at91/clk-generated.c | 179 ++++++++++++++++++ drivers/clk/at91/clk-h32mx.c | 57 ++++++ drivers/clk/at91/clk-main.c | 1 + drivers/clk/at91/clk-master.c | 1 + drivers/clk/at91/clk-plla.c | 55 ++++++ drivers/clk/at91/clk-usb.c | 148 +++++++++++++++ drivers/clk/at91/compat.c | 1 + drivers/clk/at91/pmc.c | 4 +- drivers/clk/clk-uclass.c | 1 + drivers/clk/clk_octeon.c | 1 + drivers/clk/clk_pic32.c | 1 + drivers/clk/clk_stm32mp1.c | 1 + drivers/clk/clk_zynq.c | 1 + drivers/clk/mpc83xx_clk.c | 1 + drivers/clk/renesas/clk-rcar-gen2.c | 1 + drivers/clk/renesas/clk-rcar-gen3.c | 1 + drivers/clk/rockchip/clk_px30.c | 1 + drivers/clk/rockchip/clk_rk3288.c | 1 + drivers/clk/rockchip/clk_rk3308.c | 1 + drivers/clk/rockchip/clk_rv1108.c | 1 + drivers/core/device-remove.c | 1 + drivers/core/device.c | 1 + drivers/core/fdtaddr.c | 1 + drivers/core/of_access.c | 1 + drivers/core/ofnode.c | 1 + drivers/core/read.c | 1 + drivers/core/regmap.c | 1 + drivers/core/root.c | 1 + drivers/core/uclass.c | 1 + drivers/cpu/imx8_cpu.c | 1 + drivers/cpu/riscv_cpu.c | 1 + drivers/crypto/rsa_mod_exp/mod_exp_uclass.c | 1 + drivers/ddr/altera/sdram_agilex.c | 1 + drivers/ddr/altera/sdram_arria10.c | 1 + drivers/ddr/altera/sdram_s10.c | 1 + drivers/ddr/altera/sdram_soc64.c | 1 + drivers/ddr/imx/imx8m/helper.c | 1 + drivers/demo/demo-shape.c | 1 + drivers/demo/demo-uclass.c | 1 + drivers/fpga/socfpga_arria10.c | 1 + drivers/fpga/zynqmppl.c | 1 + drivers/gpio/74x164_gpio.c | 1 + drivers/gpio/altera_pio.c | 1 + drivers/gpio/atmel_pio4.c | 1 + drivers/gpio/da8xx_gpio.c | 1 + drivers/gpio/gpio-rcar.c | 1 + drivers/gpio/gpio-rza1.c | 1 + drivers/gpio/gpio-uclass.c | 1 + drivers/gpio/intel_broadwell_gpio.c | 1 + drivers/gpio/intel_ich6_gpio.c | 1 + drivers/gpio/msm_gpio.c | 1 + drivers/gpio/mxs_gpio.c | 1 + drivers/gpio/nx_gpio.c | 1 + drivers/gpio/omap_gpio.c | 1 + drivers/gpio/pcf8575_gpio.c | 1 + drivers/gpio/pic32_gpio.c | 1 + drivers/gpio/s5p_gpio.c | 1 + drivers/gpio/vybrid_gpio.c | 1 + drivers/hwspinlock/hwspinlock-uclass.c | 1 + drivers/i2c/at91_i2c.c | 1 + drivers/i2c/cros_ec_tunnel.c | 1 + drivers/i2c/exynos_hs_i2c.c | 1 + drivers/i2c/fsl_i2c.c | 1 + drivers/i2c/i2c-gpio.c | 1 + drivers/i2c/i2c_core.c | 1 + drivers/i2c/ihs_i2c.c | 1 + drivers/i2c/iproc_i2c.c | 1 + drivers/i2c/muxes/i2c-arb-gpio-challenge.c | 1 + drivers/i2c/muxes/i2c-mux-gpio.c | 1 + drivers/i2c/muxes/pca954x.c | 1 + drivers/i2c/mvtwsi.c | 1 + drivers/i2c/mxc_i2c.c | 1 + drivers/i2c/nx_i2c.c | 1 + drivers/i2c/s3c24x0_i2c.c | 1 + drivers/i2c/sh_i2c.c | 1 + drivers/i2c/soft_i2c.c | 1 + drivers/i2c/tegra186_bpmp_i2c.c | 1 + drivers/input/i8042.c | 1 + drivers/mailbox/k3-sec-proxy.c | 1 + drivers/misc/atsha204a-i2c.c | 1 + drivers/misc/fs_loader.c | 1 + drivers/misc/imx8/fuse.c | 1 + drivers/misc/imx8/scu.c | 1 + drivers/misc/imx8/scu_api.c | 1 + drivers/misc/tegra186_bpmp.c | 1 + drivers/mmc/atmel_sdhci.c | 1 + drivers/mmc/ca_dw_mmc.c | 1 + drivers/mmc/exynos_dw_mmc.c | 1 + drivers/mmc/fsl_esdhc.c | 1 + drivers/mmc/fsl_esdhc_imx.c | 1 + drivers/mmc/ftsdc010_mci.c | 1 + drivers/mmc/hi6220_dw_mmc.c | 1 + drivers/mmc/iproc_sdhci.c | 1 + drivers/mmc/jz_mmc.c | 1 + drivers/mmc/msm_sdhci.c | 1 + drivers/mmc/mv_sdhci.c | 1 + drivers/mmc/mvebu_mmc.c | 1 + drivers/mmc/omap_hsmmc.c | 1 + drivers/mmc/pic32_sdhci.c | 3 + drivers/mmc/renesas-sdhi.c | 1 + drivers/mmc/s5p_sdhci.c | 1 + drivers/mmc/sdhci-cadence.c | 1 + drivers/mmc/sh_mmcif.c | 1 + drivers/mmc/sh_sdhi.c | 1 + drivers/mmc/socfpga_dw_mmc.c | 1 + drivers/mmc/sti_sdhci.c | 1 + drivers/mmc/tmio-common.c | 1 + drivers/mmc/xenon_sdhci.c | 1 + drivers/mtd/altera_qspi.c | 1 + drivers/mtd/cfi_flash.c | 1 + drivers/mtd/mtd_uboot.c | 1 + drivers/mtd/nand/raw/nand_base.c | 1 + drivers/mtd/nand/raw/octeontx_nand.c | 1 + drivers/mtd/nand/raw/pxa3xx_nand.c | 1 + drivers/mtd/nand/raw/sunxi_nand.c | 1 + drivers/mtd/nand/raw/tegra_nand.c | 1 + drivers/mtd/pic32_flash.c | 1 + drivers/mtd/renesas_rpc_hf.c | 1 + drivers/mtd/spi/sf-uclass.c | 1 + drivers/net/ag7xxx.c | 1 + drivers/net/altera_tse.c | 1 + drivers/net/dwc_eth_qos.c | 1 + drivers/net/dwmac_s700.c | 1 + drivers/net/fec_mxc.c | 1 + drivers/net/fsl-mc/mc.c | 1 + drivers/net/fsl_mcdmafec.c | 1 + drivers/net/ftmac100.c | 1 + drivers/net/gmac_rockchip.c | 1 + drivers/net/ldpaa_eth/ldpaa_eth.c | 1 + drivers/net/macb.c | 1 + drivers/net/mcffec.c | 1 + drivers/net/mcfmii.c | 1 + drivers/net/mpc8xx_fec.c | 1 + drivers/net/mvgbe.c | 1 + drivers/net/mvneta.c | 1 + drivers/net/mvpp2.c | 1 + drivers/net/octeontx/smi.c | 1 + drivers/net/phy/fixed.c | 1 + drivers/net/phy/miiphybb.c | 1 + drivers/net/phy/phy.c | 1 + drivers/net/phy/xilinx_gmii2rgmii.c | 4 +- drivers/net/pic32_eth.c | 1 + drivers/net/qe/dm_qe_uec.c | 1 + drivers/net/ravb.c | 1 + drivers/net/sandbox-raw.c | 1 + drivers/net/sandbox.c | 1 + drivers/net/sh_eth.c | 1 + drivers/net/sni_ave.c | 1 + drivers/net/sun8i_emac.c | 1 + drivers/net/ti/cpsw-common.c | 1 + drivers/net/ti/keystone_net.c | 1 + drivers/net/xilinx_axi_emac.c | 1 + drivers/net/xilinx_emaclite.c | 1 + drivers/pci/fsl_pci_init.c | 1 + drivers/pci/pci-uclass.c | 1 + drivers/pci/pci.c | 1 + drivers/pci/pci_mvebu.c | 1 + drivers/pci/pci_octeontx.c | 1 + drivers/pci/pci_rom.c | 1 + drivers/pci/pcie_dw_mvebu.c | 1 + drivers/pci/pcie_dw_ti.c | 1 + drivers/pci/pcie_ecam_generic.c | 1 + drivers/pci/pcie_fsl.c | 1 + drivers/pci/pcie_intel_fpga.c | 1 + drivers/pci/pcie_layerscape.c | 1 + drivers/pci/pcie_layerscape_ep.c | 1 + drivers/pci/pcie_layerscape_fixup_common.c | 1 + drivers/pci/pcie_layerscape_gen4.c | 1 + drivers/pci/pcie_layerscape_rc.c | 1 + drivers/pci/pcie_phytium.c | 1 + drivers/pci/pcie_rockchip.c | 1 + drivers/pci/pcie_xilinx.c | 1 + drivers/pci_endpoint/pci_ep-uclass.c | 1 + drivers/pci_endpoint/pcie-cadence-ep.c | 1 + drivers/phy/marvell/comphy_a3700.c | 1 + drivers/phy/marvell/comphy_core.c | 1 + drivers/phy/marvell/comphy_cp110.c | 1 + drivers/phy/omap-usb2-phy.c | 1 + drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 1 + drivers/phy/rockchip/phy-rockchip-pcie.c | 1 + drivers/phy/rockchip/phy-rockchip-typec.c | 1 + drivers/phy/sti_usb_phy.c | 1 + drivers/phy/ti-pipe3-phy.c | 1 + drivers/pinctrl/ath79/pinctrl_ar933x.c | 1 + drivers/pinctrl/ath79/pinctrl_qca953x.c | 1 + drivers/pinctrl/exynos/pinctrl-exynos.c | 1 + drivers/pinctrl/meson/pinctrl-meson.c | 1 + drivers/pinctrl/mtmips/pinctrl-mt7628.c | 1 + drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 1 + drivers/pinctrl/mvebu/pinctrl-mvebu.c | 1 + drivers/pinctrl/nexell/pinctrl-nexell.c | 1 + drivers/pinctrl/nexell/pinctrl-s5pxx18.c | 1 + drivers/pinctrl/nxp/pinctrl-imx.c | 1 + drivers/pinctrl/nxp/pinctrl-imx8.c | 1 + drivers/pinctrl/nxp/pinctrl-mxs.c | 1 + drivers/pinctrl/pinctrl-at91-pio4.c | 1 + drivers/pinctrl/pinctrl-at91.c | 1 + drivers/pinctrl/pinctrl-sti.c | 1 + drivers/pinctrl/pinctrl-uclass.c | 1 + drivers/pinctrl/pinctrl_pic32.c | 1 + drivers/pinctrl/pinctrl_stm32.c | 1 + drivers/pinctrl/renesas/pfc-r7s72100.c | 1 + .../pinctrl/rockchip/pinctrl-rockchip-core.c | 1 + .../power/domain/imx8-power-domain-legacy.c | 1 + drivers/power/domain/imx8m-power-domain.c | 1 + drivers/power/pmic/bd71837.c | 1 + drivers/power/pmic/mc34708.c | 1 + drivers/power/pmic/pca9450.c | 1 + drivers/power/regulator/pwm_regulator.c | 1 + drivers/pwm/pwm-sifive.c | 1 + drivers/pwm/rk_pwm.c | 1 + drivers/pwm/sunxi_pwm.c | 1 + drivers/qe/fdt.c | 1 + drivers/qe/qe.c | 1 + drivers/ram/aspeed/sdram_ast2500.c | 1 + drivers/ram/mpc83xx_sdram.c | 1 + drivers/ram/octeon/octeon_ddr.c | 1 + drivers/ram/rockchip/sdram_rk322x.c | 1 + drivers/ram/sandbox_ram.c | 1 + drivers/ram/sifive/fu540_ddr.c | 1 + drivers/ram/stm32mp1/stm32mp1_interactive.c | 1 + drivers/ram/stm32mp1/stm32mp1_tests.c | 1 + drivers/remoteproc/rproc-uclass.c | 1 + drivers/remoteproc/ti_power_proc.c | 1 + drivers/reset/sti-reset.c | 1 + drivers/serial/atmel_usart.c | 1 + drivers/serial/ns16550.c | 1 + drivers/serial/sandbox.c | 1 + drivers/serial/serial-uclass.c | 1 + drivers/serial/serial.c | 1 + drivers/serial/serial_arc.c | 1 + drivers/serial/serial_linflexuart.c | 1 + drivers/serial/serial_lpuart.c | 1 + drivers/serial/serial_mcf.c | 1 + drivers/serial/serial_mpc8xx.c | 1 + drivers/serial/serial_msm.c | 1 + drivers/serial/serial_mtk.c | 1 + drivers/serial/serial_mxc.c | 1 + drivers/serial/serial_ns16550.c | 1 + drivers/serial/serial_pic32.c | 1 + drivers/serial/serial_pl01x.c | 1 + drivers/serial/serial_pxa.c | 1 + drivers/serial/serial_s5p.c | 1 + drivers/serial/serial_sh.c | 1 + drivers/serial/serial_sifive.c | 1 + drivers/serial/serial_sti_asc.c | 1 + drivers/serial/serial_xen.c | 1 + drivers/smem/msm_smem.c | 1 + drivers/sound/ivybridge_sound.c | 1 + drivers/spi/atcspi200_spi.c | 1 + drivers/spi/bcmstb_spi.c | 1 + drivers/spi/cf_spi.c | 1 + drivers/spi/davinci_spi.c | 1 + drivers/spi/exynos_spi.c | 1 + drivers/spi/fsl_dspi.c | 1 + drivers/spi/fsl_espi.c | 1 + drivers/spi/fsl_qspi.c | 1 + drivers/spi/mvebu_a3700_spi.c | 1 + drivers/spi/mxc_spi.c | 1 + drivers/spi/omap3_spi.c | 1 + drivers/spi/pic32_spi.c | 1 + drivers/spi/pl022_spi.c | 1 + drivers/spi/renesas_rpc_spi.c | 1 + drivers/spi/soft_spi.c | 1 + drivers/spi/spi-sunxi.c | 1 + drivers/spi/spi-uclass.c | 1 + drivers/spi/tegra20_sflash.c | 1 + drivers/spi/tegra20_slink.c | 1 + drivers/spi/tegra210_qspi.c | 1 + drivers/spi/ti_qspi.c | 1 + drivers/spi/uniphier_spi.c | 1 + drivers/spi/zynq_qspi.c | 1 + drivers/spi/zynq_spi.c | 1 + drivers/spi/zynqmp_gqspi.c | 1 + drivers/spmi/spmi-msm.c | 1 + drivers/sysreset/sysreset-uclass.c | 1 + drivers/sysreset/sysreset_mpc83xx.c | 1 + drivers/sysreset/sysreset_sti.c | 1 + drivers/thermal/imx_scu_thermal.c | 1 + drivers/thermal/imx_tmu.c | 1 + drivers/timer/andes_plmt_timer.c | 1 + drivers/timer/arc_timer.c | 1 + drivers/timer/cadence-ttc.c | 1 + drivers/timer/mpc83xx_timer.c | 1 + drivers/timer/ostm_timer.c | 1 + drivers/timer/rockchip_timer.c | 1 + drivers/timer/timer-uclass.c | 1 + drivers/timer/tsc_timer.c | 1 + drivers/tpm/tpm2_tis_spi.c | 1 + drivers/usb/common/common.c | 1 + drivers/usb/host/dwc3-octeon-glue.c | 1 + drivers/usb/host/dwc3-sti-glue.c | 1 + drivers/usb/host/ehci-exynos.c | 1 + drivers/usb/host/ehci-fsl.c | 1 + drivers/usb/host/ehci-marvell.c | 1 + drivers/usb/host/ehci-mx5.c | 1 + drivers/usb/host/ehci-mx6.c | 1 + drivers/usb/host/ehci-vf.c | 1 + drivers/usb/host/xhci-exynos5.c | 1 + drivers/usb/musb-new/da8xx.c | 1 + drivers/usb/musb-new/omap2430.c | 1 + drivers/usb/musb-new/pic32.c | 1 + drivers/usb/musb-new/ti-musb.c | 1 + drivers/usb/phy/rockchip_usb2_phy.c | 1 + drivers/video/am335x-fb.c | 1 + drivers/video/atmel_hlcdfb.c | 1 + drivers/video/atmel_lcdfb.c | 1 + drivers/video/bridge/ps862x.c | 1 + drivers/video/broadwell_igd.c | 1 + drivers/video/cfb_console.c | 1 + drivers/video/da8xx-fb.c | 1 + drivers/video/exynos/exynos_dp.c | 1 + drivers/video/exynos/exynos_fb.c | 1 + drivers/video/exynos/exynos_mipi_dsi.c | 1 + drivers/video/fsl_dcu_fb.c | 1 + drivers/video/ivybridge_igd.c | 1 + drivers/video/mali_dp.c | 1 + drivers/video/meson/meson_vpu.c | 1 + drivers/video/mxsfb.c | 1 + drivers/video/rockchip/rk3288_vop.c | 1 + drivers/video/rockchip/rk3399_vop.c | 1 + drivers/video/rockchip/rk_lvds.c | 1 + drivers/video/rockchip/rk_mipi.c | 1 + drivers/video/rockchip/rk_vop.c | 1 + drivers/video/sandbox_sdl.c | 1 + drivers/video/simplefb.c | 1 + drivers/video/stm32/stm32_dsi.c | 1 + drivers/video/stm32/stm32_ltdc.c | 1 + drivers/video/sunxi/sunxi_lcd.c | 1 + drivers/video/tegra.c | 1 + drivers/video/video-uclass.c | 1 + drivers/video/videomodes.c | 1 + drivers/watchdog/armada-37xx-wdt.c | 1 + drivers/watchdog/at91sam9_wdt.c | 1 + drivers/watchdog/mt7621_wdt.c | 1 + drivers/watchdog/octeontx_wdt.c | 1 + drivers/watchdog/orion_wdt.c | 1 + drivers/watchdog/sbsa_gwdt.c | 1 + drivers/watchdog/sp805_wdt.c | 1 + drivers/watchdog/wdt-uclass.c | 1 + drivers/xen/gnttab.c | 1 + drivers/xen/pvblock.c | 1 + env/callback.c | 1 + env/common.c | 1 + env/eeprom.c | 1 + env/env.c | 1 + env/ext4.c | 1 + env/flash.c | 1 + env/mmc.c | 1 + env/nand.c | 1 + env/nowhere.c | 1 + env/nvram.c | 1 + env/onenand.c | 1 + env/remote.c | 1 + env/sf.c | 1 + env/ubi.c | 1 + examples/standalone/stubs.c | 1 + fs/ext4/ext4_journal.c | 1 + fs/ext4/ext4_journal.h | 1 + fs/ext4/ext4fs.c | 2 +- fs/fs.c | 1 + fs/reiserfs/reiserfs_private.h | 2 + fs/ubifs/ubifs.c | 1 + include/audio_codec.h | 2 + include/axi.h | 2 + include/backlight.h | 2 + include/board.h | 3 + include/bootcount.h | 1 + include/cache.h | 2 + include/common.h | 1 - include/cpu.h | 2 + include/dm/device-internal.h | 1 + include/dm/read.h | 1 + include/dm/root.h | 1 + include/dma.h | 2 + include/exports.h | 1 + include/ext_common.h | 2 + include/i2c.h | 1 + include/image-sparse.h | 1 + include/init.h | 7 +- include/initcall.h | 1 + include/led.h | 2 + include/libata.h | 2 - include/misc.h | 2 + include/netdev.h | 2 + include/pci.h | 2 - include/power/as3722.h | 2 + include/power/regulator.h | 2 + include/pwm.h | 2 + include/ram.h | 2 + include/scsi.h | 2 + include/soc.h | 2 + include/sysreset.h | 2 + include/tee.h | 2 + include/tlv_eeprom.h | 2 + include/tpm-common.h | 2 + include/tpm-v1.h | 2 + include/tpm-v2.h | 2 + include/tps6586x.h | 2 + include/ufs.h | 3 + lib/acpi/acpi_table.c | 1 + lib/asm-offsets.c | 1 + lib/efi/efi_app.c | 1 + lib/efi/efi_info.c | 1 + lib/efi_loader/efi_boottime.c | 1 + lib/efi_loader/efi_gop.c | 1 + lib/efi_loader/efi_memory.c | 1 + lib/efi_loader/efi_rng.c | 1 + lib/efi_loader/efi_runtime.c | 1 + lib/fdtdec.c | 1 + lib/optee/optee.c | 1 + lib/time.c | 1 + lib/trace.c | 1 + lib/zlib/zlib.c | 1 + net/eth-uclass.c | 1 + net/eth_legacy.c | 1 + net/tftp.c | 1 + post/drivers/memory.c | 1 + post/post.c | 1 + test/bloblist.c | 1 + test/dm/acpi.c | 1 + test/dm/blk.c | 1 + test/dm/bus.c | 1 + test/dm/core.c | 1 + test/dm/fdtdec.c | 1 + test/dm/mux-emul.c | 1 + test/dm/ram.c | 1 + test/dm/test-fdt.c | 1 + test/dm/test-main.c | 1 + test/lib/test_print.c | 1 + test/log/cont_test.c | 1 + test/log/nolog_test.c | 1 + test/log/syslog_test.c | 1 + test/log/syslog_test_ndebug.c | 1 + test/ut.c | 1 + 1345 files changed, 1988 insertions(+), 25 deletions(-) create mode 100644 board/freescale/p1023rdb/p1023rdb.c create mode 100644 drivers/clk/at91/clk-generated.c create mode 100644 drivers/clk/at91/clk-h32mx.c create mode 100644 drivers/clk/at91/clk-plla.c create mode 100644 drivers/clk/at91/clk-usb.c
diff --git a/arch/arc/lib/bootm.c b/arch/arc/lib/bootm.c index 63d6207c047..8a8d394a5f0 100644 --- a/arch/arc/lib/bootm.c +++ b/arch/arc/lib/bootm.c @@ -11,6 +11,7 @@ #include <lmb.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/arch/arc/lib/cache.c b/arch/arc/lib/cache.c index 85651b219cf..f807cd83d6b 100644 --- a/arch/arc/lib/cache.c +++ b/arch/arc/lib/cache.c @@ -6,6 +6,7 @@ #include <config.h> #include <common.h> #include <cpu_func.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/compiler.h> #include <linux/kernel.h> diff --git a/arch/arc/lib/cpu.c b/arch/arc/lib/cpu.c index d66a8c867ac..07f57878ef1 100644 --- a/arch/arc/lib/cpu.c +++ b/arch/arc/lib/cpu.c @@ -9,6 +9,7 @@ #include <vsprintf.h> #include <asm/arcregs.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/bitops.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arc/lib/relocate.c b/arch/arc/lib/relocate.c index 6882ebec6d8..7f531c95eec 100644 --- a/arch/arc/lib/relocate.c +++ b/arch/arc/lib/relocate.c @@ -7,6 +7,7 @@ #include <elf.h> #include <log.h> #include <asm-generic/sections.h> +#include <asm/global_data.h>
extern ulong __image_copy_start; extern ulong __ivt_start; diff --git a/arch/arm/cpu/arm1136/mx35/generic.c b/arch/arm/cpu/arm1136/mx35/generic.c index 10f9ce42708..cbf76ab4fee 100644 --- a/arch/arm/cpu/arm1136/mx35/generic.c +++ b/arch/arm/cpu/arm1136/mx35/generic.c @@ -12,6 +12,7 @@ #include <div64.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/errno.h> #include <asm/arch/imx-regs.h> diff --git a/arch/arm/cpu/arm926ejs/armada100/dram.c b/arch/arm/cpu/arm926ejs/armada100/dram.c index da0615faf15..c97b5b1940a 100644 --- a/arch/arm/cpu/arm926ejs/armada100/dram.c +++ b/arch/arm/cpu/arm926ejs/armada100/dram.c @@ -8,6 +8,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/armada100.h>
diff --git a/arch/arm/cpu/arm926ejs/armada100/timer.c b/arch/arm/cpu/arm926ejs/armada100/timer.c index 0f1e68c8355..ec73393d0fc 100644 --- a/arch/arm/cpu/arm926ejs/armada100/timer.c +++ b/arch/arm/cpu/arm926ejs/armada100/timer.c @@ -12,6 +12,7 @@ #include <time.h> #include <asm/arch/cpu.h> #include <asm/arch/armada100.h> +#include <asm/global_data.h> #include <linux/delay.h>
/* diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index a4528cbaf52..9cd60abcccb 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -15,6 +15,7 @@ #include <net.h> #include <netdev.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-imx/cpu.h> #include <asm/arch/imx-regs.h> diff --git a/arch/arm/cpu/arm926ejs/mx27/timer.c b/arch/arm/cpu/arm926ejs/mx27/timer.c index 408e88aa129..4fd6a805968 100644 --- a/arch/arm/cpu/arm926ejs/mx27/timer.c +++ b/arch/arm/cpu/arm926ejs/mx27/timer.c @@ -19,6 +19,7 @@ #include <div64.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/ptrace.h> diff --git a/arch/arm/cpu/arm926ejs/mxs/mxs.c b/arch/arm/cpu/arm926ejs/mxs/mxs.c index 8243aeb2c0f..c9362136fbf 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mxs.c +++ b/arch/arm/cpu/arm926ejs/mxs/mxs.c @@ -15,6 +15,7 @@ #include <hang.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c index 1501d7df0dc..a16a15e79d8 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c @@ -11,6 +11,7 @@ #include <init.h> #include <log.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/cpu/arm926ejs/mxs/timer.c b/arch/arm/cpu/arm926ejs/mxs/timer.c index 5ab4ed0c5a3..3dff3d768d1 100644 --- a/arch/arm/cpu/arm926ejs/mxs/timer.c +++ b/arch/arm/cpu/arm926ejs/mxs/timer.c @@ -12,6 +12,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/cpu/arm926ejs/spear/spr_misc.c b/arch/arm/cpu/arm926ejs/spear/spr_misc.c index 998423b6525..044052b32f9 100644 --- a/arch/arm/cpu/arm926ejs/spear/spr_misc.c +++ b/arch/arm/cpu/arm926ejs/spear/spr_misc.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/mtd/st_smi.h> #include <asm/io.h> #include <asm/arch/hardware.h> diff --git a/arch/arm/cpu/arm926ejs/spear/timer.c b/arch/arm/cpu/arm926ejs/spear/timer.c index dd0f15c0cee..b42baa71506 100644 --- a/arch/arm/cpu/arm926ejs/spear/timer.c +++ b/arch/arm/cpu/arm926ejs/spear/timer.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/spr_gpt.h> diff --git a/arch/arm/cpu/armv7/arch_timer.c b/arch/arm/cpu/armv7/arch_timer.c index 871629c2333..d96406f7626 100644 --- a/arch/arm/cpu/armv7/arch_timer.c +++ b/arch/arm/cpu/armv7/arch_timer.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <bootstage.h> diff --git a/arch/arm/cpu/armv7/ls102xa/clock.c b/arch/arm/cpu/armv7/ls102xa/clock.c index f3bdb14c072..940995ef5af 100644 --- a/arch/arm/cpu/armv7/ls102xa/clock.c +++ b/arch/arm/cpu/armv7/ls102xa/clock.c @@ -5,6 +5,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> #include <asm/arch/clock.h> diff --git a/arch/arm/cpu/armv7/ls102xa/cpu.c b/arch/arm/cpu/armv7/ls102xa/cpu.c index ce472aa9bd5..cbc8254b42a 100644 --- a/arch/arm/cpu/armv7/ls102xa/cpu.c +++ b/arch/arm/cpu/armv7/ls102xa/cpu.c @@ -9,6 +9,7 @@ #include <net.h> #include <vsprintf.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> #include <asm/cache.h> diff --git a/arch/arm/cpu/armv7/ls102xa/fdt.c b/arch/arm/cpu/armv7/ls102xa/fdt.c index d8cb78ecc67..d1d09f93650 100644 --- a/arch/arm/cpu/armv7/ls102xa/fdt.c +++ b/arch/arm/cpu/armv7/ls102xa/fdt.c @@ -6,6 +6,7 @@ #include <common.h> #include <clock_legacy.h> #include <net.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/io.h> diff --git a/arch/arm/cpu/armv7/ls102xa/timer.c b/arch/arm/cpu/armv7/ls102xa/timer.c index 2a32b30999f..d79bf105f13 100644 --- a/arch/arm/cpu/armv7/ls102xa/timer.c +++ b/arch/arm/cpu/armv7/ls102xa/timer.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <asm/arch/immap_ls102xa.h> diff --git a/arch/arm/cpu/armv7/s5p-common/cpu_info.c b/arch/arm/cpu/armv7/s5p-common/cpu_info.c index 7790f087a09..d910282e2b2 100644 --- a/arch/arm/cpu/armv7/s5p-common/cpu_info.c +++ b/arch/arm/cpu/armv7/s5p-common/cpu_info.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdtdec.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clk.h>
diff --git a/arch/arm/cpu/armv7/s5p-common/timer.c b/arch/arm/cpu/armv7/s5p-common/timer.c index 3064fd25d4d..8141f40d5c0 100644 --- a/arch/arm/cpu/armv7/s5p-common/timer.c +++ b/arch/arm/cpu/armv7/s5p-common/timer.c @@ -10,6 +10,7 @@ #include <div64.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/pwm.h> #include <asm/arch/clk.h> diff --git a/arch/arm/cpu/armv7/s5p4418/cpu.c b/arch/arm/cpu/armv7/s5p4418/cpu.c index 8add9474ad2..3c71a37a74b 100644 --- a/arch/arm/cpu/armv7/s5p4418/cpu.c +++ b/arch/arm/cpu/armv7/s5p4418/cpu.c @@ -8,6 +8,7 @@ #include <command.h> #include <asm/system.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <asm/io.h> #include <asm/arch/nexell.h> diff --git a/arch/arm/cpu/armv7/stv0991/timer.c b/arch/arm/cpu/armv7/stv0991/timer.c index 919529aa1b0..07033acb5c1 100644 --- a/arch/arm/cpu/armv7/stv0991/timer.c +++ b/arch/arm/cpu/armv7/stv0991/timer.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-stv0991/hardware.h> #include <asm/arch-stv0991/stv0991_cgu.h> diff --git a/arch/arm/cpu/armv7/sunxi/timer.c b/arch/arm/cpu/armv7/sunxi/timer.c index 65b64b5ac75..b7585996369 100644 --- a/arch/arm/cpu/armv7/sunxi/timer.c +++ b/arch/arm/cpu/armv7/sunxi/timer.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/timer.h> #include <linux/delay.h> diff --git a/arch/arm/cpu/armv7/vf610/generic.c b/arch/arm/cpu/armv7/vf610/generic.c index 743bfced643..c23ddc12b45 100644 --- a/arch/arm/cpu/armv7/vf610/generic.c +++ b/arch/arm/cpu/armv7/vf610/generic.c @@ -10,6 +10,7 @@ #include <init.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> diff --git a/arch/arm/cpu/armv7/vf610/timer.c b/arch/arm/cpu/armv7/vf610/timer.c index fa8f8fae10a..a9c1a8fcebc 100644 --- a/arch/arm/cpu/armv7/vf610/timer.c +++ b/arch/arm/cpu/armv7/vf610/timer.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <asm/arch/imx-regs.h> diff --git a/arch/arm/cpu/armv7m/systick-timer.c b/arch/arm/cpu/armv7m/systick-timer.c index d2672fd40cd..556eaf8c74a 100644 --- a/arch/arm/cpu/armv7m/systick-timer.c +++ b/arch/arm/cpu/armv7m/systick-timer.c @@ -24,6 +24,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index 7c31d98a6f0..15cecb5e0b3 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -12,6 +12,7 @@ #include <hang.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/armv8/mmu.h>
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 596b88d3e29..fea170f8cd3 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -14,6 +14,7 @@ #include <net.h> #include <vsprintf.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/ptrace.h> #include <linux/errno.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index c56689086de..63d34e1ec03 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -7,6 +7,7 @@ #include <common.h> #include <clock_legacy.h> #include <cpu_func.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/io.h> #include <asm/processor.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c index 7f8178f72eb..767359fa5bd 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c @@ -9,6 +9,7 @@ #include <common.h> #include <clock_legacy.h> #include <cpu_func.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <fsl_ifc.h> #include <asm/processor.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/mp.c b/arch/arm/cpu/armv8/fsl-layerscape/mp.c index bd85351705a..5ac545f9df8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/mp.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/mp.c @@ -8,6 +8,7 @@ #include <image.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/system.h> #include <asm/arch/mp.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ppa.c b/arch/arm/cpu/armv8/fsl-layerscape/ppa.c index 1ddb267093c..f26be5a25b0 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ppa.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ppa.c @@ -8,6 +8,7 @@ #include <config.h> #include <errno.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/types.h> #include <asm/arch/soc.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c index 77724336d62..7d594a9f749 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/spl.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -12,6 +12,7 @@ #include <log.h> #include <spl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <fsl_ifc.h> #include <i2c.h> diff --git a/arch/arm/cpu/armv8/generic_timer.c b/arch/arm/cpu/armv8/generic_timer.c index e23629ab0bc..f27a74b9d09 100644 --- a/arch/arm/cpu/armv8/generic_timer.c +++ b/arch/arm/cpu/armv8/generic_timer.c @@ -8,6 +8,7 @@ #include <bootstage.h> #include <command.h> #include <time.h> +#include <asm/global_data.h> #include <asm/system.h> #include <linux/bitops.h>
diff --git a/arch/arm/cpu/armv8/s32v234/generic.c b/arch/arm/cpu/armv8/s32v234/generic.c index de5a098adb8..0fc98852228 100644 --- a/arch/arm/cpu/armv8/s32v234/generic.c +++ b/arch/arm/cpu/armv8/s32v234/generic.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> diff --git a/arch/arm/cpu/armv8/sec_firmware.c b/arch/arm/cpu/armv8/sec_firmware.c index bfc0fac3eff..c6c4fcc7e07 100644 --- a/arch/arm/cpu/armv8/sec_firmware.c +++ b/arch/arm/cpu/armv8/sec_firmware.c @@ -10,6 +10,7 @@ #include <image.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/kernel.h> #include <asm/io.h> diff --git a/arch/arm/include/asm/arch-rockchip/clock.h b/arch/arm/include/asm/arch-rockchip/clock.h index 22de0aef8dc..5108180ea77 100644 --- a/arch/arm/include/asm/arch-rockchip/clock.h +++ b/arch/arm/include/asm/arch-rockchip/clock.h @@ -6,6 +6,8 @@ #ifndef _ASM_ARCH_CLOCK_H #define _ASM_ARCH_CLOCK_H
+struct udevice; + /* define pll mode */ #define RKCLK_PLL_MODE_SLOW 0 #define RKCLK_PLL_MODE_NORMAL 1 diff --git a/arch/arm/include/asm/arch-tegra/clock.h b/arch/arm/include/asm/arch-tegra/clock.h index 8aa90d5c0c5..1d80d9e9461 100644 --- a/arch/arm/include/asm/arch-tegra/clock.h +++ b/arch/arm/include/asm/arch-tegra/clock.h @@ -8,6 +8,8 @@ #ifndef _TEGRA_CLOCK_H_ #define _TEGRA_CLOCK_H_
+struct udevice; + /* Set of oscillator frequencies supported in the internal API. */ enum clock_osc_freq { /* All in MHz, so 13_0 is 13.0MHz */ diff --git a/arch/arm/include/asm/arch-tegra/tegra_i2c.h b/arch/arm/include/asm/arch-tegra/tegra_i2c.h index 5316bc47e4b..e57b9ef9c47 100644 --- a/arch/arm/include/asm/arch-tegra/tegra_i2c.h +++ b/arch/arm/include/asm/arch-tegra/tegra_i2c.h @@ -10,6 +10,8 @@
+struct udevice; + enum { I2C_TIMEOUT_USEC = 10000, /* Wait time for completion */ I2C_FIFO_DEPTH = 8, /* I2C fifo depth */ diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index 2aafc6d2062..5a935d34e20 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -7,6 +7,9 @@ #ifndef __ASM_GBL_DATA_H #define __ASM_GBL_DATA_H
+#include <asm/types.h> +#include <linux/types.h> + /* Architecture-specific global data */ struct arch_global_data { #if defined(CONFIG_FSL_ESDHC) || defined(CONFIG_FSL_ESDHC_IMX) diff --git a/arch/arm/include/asm/mach-imx/video.h b/arch/arm/include/asm/mach-imx/video.h index d1a14ad7d34..1fdc2de662a 100644 --- a/arch/arm/include/asm/mach-imx/video.h +++ b/arch/arm/include/asm/mach-imx/video.h @@ -16,9 +16,7 @@ struct display_info_t { struct fb_videomode mode; };
-#ifdef CONFIG_IMX_HDMI -extern int detect_hdmi(struct display_info_t const *dev); -#endif +int detect_hdmi(struct display_info_t const *dev);
#ifdef CONFIG_IMX_VIDEO_SKIP extern struct display_info_t const displays[]; diff --git a/arch/arm/include/asm/secure.h b/arch/arm/include/asm/secure.h index 50582c972b7..64e5582c1f2 100644 --- a/arch/arm/include/asm/secure.h +++ b/arch/arm/include/asm/secure.h @@ -2,6 +2,7 @@ #define __ASM_SECURE_H
#include <config.h> +#include <asm/global_data.h>
#define __secure __attribute__ ((section ("._secure.text"))) #define __secure_data __attribute__ ((section ("._secure.data"))) diff --git a/arch/arm/include/asm/spl.h b/arch/arm/include/asm/spl.h index e568af25611..8954db61b88 100644 --- a/arch/arm/include/asm/spl.h +++ b/arch/arm/include/asm/spl.h @@ -41,4 +41,5 @@ extern char __bss_start[], __bss_end[]; extern gd_t gdata; #endif
+#include <asm/global_data.h> #endif diff --git a/arch/arm/include/asm/string.h b/arch/arm/include/asm/string.h index 11eaa34fab8..cefeddd73f1 100644 --- a/arch/arm/include/asm/string.h +++ b/arch/arm/include/asm/string.h @@ -1,8 +1,6 @@ #ifndef __ASM_ARM_STRING_H #define __ASM_ARM_STRING_H
-#include <config.h> - /* * We don't do inline string functions, since the * optimised inline asm versions are not small. diff --git a/arch/arm/include/asm/ti-common/sys_proto.h b/arch/arm/include/asm/ti-common/sys_proto.h index db042a1aef2..a96a8382fb6 100644 --- a/arch/arm/include/asm/ti-common/sys_proto.h +++ b/arch/arm/include/asm/ti-common/sys_proto.h @@ -6,6 +6,8 @@ #ifndef _TI_COMMON_SYS_PROTO_H_ #define _TI_COMMON_SYS_PROTO_H_
+#include <asm/global_data.h> + DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_ARCH_OMAP2PLUS diff --git a/arch/arm/lib/bdinfo.c b/arch/arm/lib/bdinfo.c index 25bc6e80f47..572f7fb2429 100644 --- a/arch/arm/lib/bdinfo.c +++ b/arch/arm/lib/bdinfo.c @@ -8,6 +8,7 @@
diff --git a/arch/arm/lib/bootm-fdt.c b/arch/arm/lib/bootm-fdt.c index 02a49a8e10f..e1970ea9f14 100644 --- a/arch/arm/lib/bootm-fdt.c +++ b/arch/arm/lib/bootm-fdt.c @@ -19,6 +19,7 @@ #ifdef CONFIG_ARMV7_NONSEC #include <asm/armv7.h> #endif +#include <asm/global_data.h> #include <asm/psci.h> #include <asm/spin_table.h>
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 1206e306db6..70c181e45b7 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -19,6 +19,7 @@ #include <hang.h> #include <lmb.h> #include <log.h> +#include <asm/global_data.h> #include <dm/root.h> #include <env.h> #include <image.h> diff --git a/arch/arm/lib/cache-cp15.c b/arch/arm/lib/cache-cp15.c index abd81d21c73..24050e5bdd3 100644 --- a/arch/arm/lib/cache-cp15.c +++ b/arch/arm/lib/cache-cp15.c @@ -7,6 +7,7 @@ #include <common.h> #include <cpu_func.h> #include <log.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/cache.h> #include <linux/compiler.h> diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index ee7d14b2d31..b494611d6e8 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <asm/cache.h> +#include <asm/global_data.h>
diff --git a/arch/arm/lib/image.c b/arch/arm/lib/image.c index 94590d3049a..e394c1ad909 100644 --- a/arch/arm/lib/image.c +++ b/arch/arm/lib/image.c @@ -7,6 +7,7 @@ #include <common.h> #include <image.h> #include <mapmem.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/sizes.h>
diff --git a/arch/arm/lib/interrupts.c b/arch/arm/lib/interrupts.c index 703be5a3209..05bb1a38b35 100644 --- a/arch/arm/lib/interrupts.c +++ b/arch/arm/lib/interrupts.c @@ -22,6 +22,7 @@ #include <cpu_func.h> #include <efi_loader.h> #include <irq_func.h> +#include <asm/global_data.h> #include <asm/proc-armv/ptrace.h> #include <asm/ptrace.h> #include <asm/u-boot-arm.h> diff --git a/arch/arm/lib/interrupts_64.c b/arch/arm/lib/interrupts_64.c index 52994890137..c653e67db28 100644 --- a/arch/arm/lib/interrupts_64.c +++ b/arch/arm/lib/interrupts_64.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <irq_func.h> #include <linux/compiler.h> diff --git a/arch/arm/lib/spl.c b/arch/arm/lib/spl.c index af0c9ad6bd6..b2b54f28fc4 100644 --- a/arch/arm/lib/spl.c +++ b/arch/arm/lib/spl.c @@ -14,6 +14,7 @@ #include <spl.h> #include <image.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mach-types.h>
diff --git a/arch/arm/lib/stack.c b/arch/arm/lib/stack.c index 96a248c0a90..b03e1cfc80c 100644 --- a/arch/arm/lib/stack.c +++ b/arch/arm/lib/stack.c @@ -12,6 +12,7 @@ */ #include <common.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-aspeed/ast2500/board_common.c b/arch/arm/mach-aspeed/ast2500/board_common.c index 3482ee91efd..aca20022312 100644 --- a/arch/arm/mach-aspeed/ast2500/board_common.c +++ b/arch/arm/mach-aspeed/ast2500/board_common.c @@ -8,6 +8,7 @@ #include <log.h> #include <ram.h> #include <timer.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/timer.h> #include <asm/arch/wdt.h> diff --git a/arch/arm/mach-at91/arm920t/clock.c b/arch/arm/mach-at91/arm920t/clock.c index 9a57dd40891..c7440278d8f 100644 --- a/arch/arm/mach-at91/arm920t/clock.c +++ b/arch/arm/mach-at91/arm920t/clock.c @@ -8,6 +8,7 @@ * Copyright (C) 2009 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com */ #include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pmc.h> diff --git a/arch/arm/mach-at91/arm920t/timer.c b/arch/arm/mach-at91/arm920t/timer.c index dca2d2c70c7..c400e878135 100644 --- a/arch/arm/mach-at91/arm920t/timer.c +++ b/arch/arm/mach-at91/arm920t/timer.c @@ -16,6 +16,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/io.h> diff --git a/arch/arm/mach-at91/arm926ejs/clock.c b/arch/arm/mach-at91/arm926ejs/clock.c index 7156185a46f..c68e0c0c3c4 100644 --- a/arch/arm/mach-at91/arm926ejs/clock.c +++ b/arch/arm/mach-at91/arm926ejs/clock.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pmc.h> diff --git a/arch/arm/mach-at91/arm926ejs/timer.c b/arch/arm/mach-at91/arm926ejs/timer.c index 42ef349966b..a8cf0e4bd79 100644 --- a/arch/arm/mach-at91/arm926ejs/timer.c +++ b/arch/arm/mach-at91/arm926ejs/timer.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pit.h> diff --git a/arch/arm/mach-at91/armv7/clock.c b/arch/arm/mach-at91/armv7/clock.c index 39268969580..aa6bb6bf31e 100644 --- a/arch/arm/mach-at91/armv7/clock.c +++ b/arch/arm/mach-at91/armv7/clock.c @@ -10,6 +10,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/arch/arm/mach-at91/armv7/timer.c b/arch/arm/mach-at91/armv7/timer.c index a6346c01b28..1f54c5dcad9 100644 --- a/arch/arm/mach-at91/armv7/timer.c +++ b/arch/arm/mach-at91/armv7/timer.c @@ -11,6 +11,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pit.h> diff --git a/arch/arm/mach-at91/spl_at91.c b/arch/arm/mach-at91/spl_at91.c index 35a3d5185d3..d0c73253924 100644 --- a/arch/arm/mach-at91/spl_at91.c +++ b/arch/arm/mach-at91/spl_at91.c @@ -12,6 +12,7 @@ #include <hang.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91sam9_matrix.h> diff --git a/arch/arm/mach-bcm283x/init.c b/arch/arm/mach-bcm283x/init.c index f2a54116237..b2708e4876e 100644 --- a/arch/arm/mach-bcm283x/init.c +++ b/arch/arm/mach-bcm283x/init.c @@ -9,6 +9,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h> #include <dm/device.h> #include <fdt_support.h>
diff --git a/arch/arm/mach-davinci/cpu.c b/arch/arm/mach-davinci/cpu.c index 40dd44af67e..aefd21dc458 100644 --- a/arch/arm/mach-davinci/cpu.c +++ b/arch/arm/mach-davinci/cpu.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/mach-davinci/misc.c b/arch/arm/mach-davinci/misc.c index 5bfc47dae45..90b38b7e020 100644 --- a/arch/arm/mach-davinci/misc.c +++ b/arch/arm/mach-davinci/misc.c @@ -15,6 +15,7 @@ #include <log.h> #include <net.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/davinci_misc.h>
diff --git a/arch/arm/mach-davinci/timer.c b/arch/arm/mach-davinci/timer.c index a6681821f6d..43e0574901e 100644 --- a/arch/arm/mach-davinci/timer.c +++ b/arch/arm/mach-davinci/timer.c @@ -23,6 +23,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/timer_defs.h> #include <div64.h> diff --git a/arch/arm/mach-exynos/spl_boot.c b/arch/arm/mach-exynos/spl_boot.c index 9c7ca49519b..27f0dac182d 100644 --- a/arch/arm/mach-exynos/spl_boot.c +++ b/arch/arm/mach-exynos/spl_boot.c @@ -7,6 +7,7 @@ #include <config.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
#include <asm/cache.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-imx/imx8/ahab.c b/arch/arm/mach-imx/imx8/ahab.c index 5dbe1d56e02..bbcefc8e9b6 100644 --- a/arch/arm/mach-imx/imx8/ahab.c +++ b/arch/arm/mach-imx/imx8/ahab.c @@ -7,6 +7,7 @@ #include <command.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sci/sci.h> #include <asm/mach-imx/sys_proto.h> diff --git a/arch/arm/mach-imx/imx8/clock.c b/arch/arm/mach-imx/imx8/clock.c index d747e1332f0..9941b57b4be 100644 --- a/arch/arm/mach-imx/imx8/clock.c +++ b/arch/arm/mach-imx/imx8/clock.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/arch/clock.h>
diff --git a/arch/arm/mach-imx/imx8/cpu.c b/arch/arm/mach-imx/imx8/cpu.c index 38b2c0926f5..293c931b2ff 100644 --- a/arch/arm/mach-imx/imx8/cpu.c +++ b/arch/arm/mach-imx/imx8/cpu.c @@ -11,6 +11,7 @@ #include <init.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/uclass.h> diff --git a/arch/arm/mach-imx/imx8/fdt.c b/arch/arm/mach-imx/imx8/fdt.c index 3e05b972a45..a132ce2e6a3 100644 --- a/arch/arm/mach-imx/imx8/fdt.c +++ b/arch/arm/mach-imx/imx8/fdt.c @@ -7,6 +7,7 @@ #include <log.h> #include <asm/arch/sci/sci.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <dm/ofnode.h> #include <fdt_support.h> #include <linux/libfdt.h> diff --git a/arch/arm/mach-imx/imx8/iomux.c b/arch/arm/mach-imx/imx8/iomux.c index b8e6f48a5f7..9c3cfbf0068 100644 --- a/arch/arm/mach-imx/imx8/iomux.c +++ b/arch/arm/mach-imx/imx8/iomux.c @@ -5,6 +5,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/iomux.h> #include <asm/arch/sci/sci.h> diff --git a/arch/arm/mach-imx/imx8/snvs_security_sc.c b/arch/arm/mach-imx/imx8/snvs_security_sc.c index 564d1bfdfb2..6f9b1c99fcd 100644 --- a/arch/arm/mach-imx/imx8/snvs_security_sc.c +++ b/arch/arm/mach-imx/imx8/snvs_security_sc.c @@ -18,6 +18,7 @@ #include <asm/arch/sci/sci.h> #include <asm/arch-imx8/imx8-pins.h> #include <asm/arch-imx8/snvs_security_sc.h> +#include <asm/global_data.h>
/* Access to gd */ DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/mach-imx/imx8m/clock_imx8mm.c b/arch/arm/mach-imx/imx8m/clock_imx8mm.c index 9dde11cdedf..4024dafca10 100644 --- a/arch/arm/mach-imx/imx8m/clock_imx8mm.c +++ b/arch/arm/mach-imx/imx8m/clock_imx8mm.c @@ -9,6 +9,7 @@ #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <errno.h> diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 9bca5bf9727..75e2357da73 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <asm/arch/imx-regs.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-imx/misc.c b/arch/arm/mach-imx/misc.c index 818f38e17dd..d82efa7f8f0 100644 --- a/arch/arm/mach-imx/misc.c +++ b/arch/arm/mach-imx/misc.c @@ -7,6 +7,7 @@ #include <lmb.h> #include <log.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/arch/arm/mach-imx/mx5/mx53_dram.c b/arch/arm/mach-imx/mx5/mx53_dram.c index a7f033f3f44..f7441441947 100644 --- a/arch/arm/mach-imx/mx5/mx53_dram.c +++ b/arch/arm/mach-imx/mx5/mx53_dram.c @@ -6,6 +6,7 @@
diff --git a/arch/arm/mach-imx/mx6/litesom.c b/arch/arm/mach-imx/mx6/litesom.c index 92176dc8615..699a3dc317f 100644 --- a/arch/arm/mach-imx/mx6/litesom.c +++ b/arch/arm/mach-imx/mx6/litesom.c @@ -12,6 +12,7 @@ #include <asm/arch/mx6ul_pins.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/arch/arm/mach-imx/mx6/opos6ul.c b/arch/arm/mach-imx/mx6/opos6ul.c index 4b3c59f7eef..e9d78740a15 100644 --- a/arch/arm/mach-imx/mx6/opos6ul.c +++ b/arch/arm/mach-imx/mx6/opos6ul.c @@ -8,6 +8,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <env.h> diff --git a/arch/arm/mach-imx/mx7/clock.c b/arch/arm/mach-imx/mx7/clock.c index aba9461d920..b1d7290704a 100644 --- a/arch/arm/mach-imx/mx7/clock.c +++ b/arch/arm/mach-imx/mx7/clock.c @@ -11,6 +11,7 @@ #include <command.h> #include <div64.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/errno.h> #include <asm/arch/imx-regs.h> diff --git a/arch/arm/mach-imx/mx7ulp/clock.c b/arch/arm/mach-imx/mx7ulp/clock.c index a987ff22dfd..467832074af 100644 --- a/arch/arm/mach-imx/mx7ulp/clock.c +++ b/arch/arm/mach-imx/mx7ulp/clock.c @@ -7,6 +7,7 @@ #include <clock_legacy.h> #include <command.h> #include <div64.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-imx/speed.c b/arch/arm/mach-imx/speed.c index e78b1fd71b6..b729187ec81 100644 --- a/arch/arm/mach-imx/speed.c +++ b/arch/arm/mach-imx/speed.c @@ -11,6 +11,7 @@ #include <clock_legacy.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> +#include <asm/global_data.h>
#ifdef CONFIG_FSL_ESDHC_IMX DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index aa2686bb921..d20221b556e 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -10,6 +10,7 @@ #include <hang.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-imx/spl_imx_romapi.c b/arch/arm/mach-imx/spl_imx_romapi.c index f588a5f5216..9f4d95982e5 100644 --- a/arch/arm/mach-imx/spl_imx_romapi.c +++ b/arch/arm/mach-imx/spl_imx_romapi.c @@ -7,6 +7,7 @@ #include <errno.h> #include <image.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <spl.h>
diff --git a/arch/arm/mach-imx/syscounter.c b/arch/arm/mach-imx/syscounter.c index 7da43c32e0d..6dfed365d29 100644 --- a/arch/arm/mach-imx/syscounter.c +++ b/arch/arm/mach-imx/syscounter.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <asm/arch/imx-regs.h> diff --git a/arch/arm/mach-k3/am6_init.c b/arch/arm/mach-k3/am6_init.c index 603834e5078..1e56a0917fd 100644 --- a/arch/arm/mach-k3/am6_init.c +++ b/arch/arm/mach-k3/am6_init.c @@ -9,6 +9,7 @@ #include <common.h> #include <fdt_support.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <spl.h> #include <asm/arch/hardware.h> diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index 8c903f14ff8..f01aeb40c9d 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -12,6 +12,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include "common.h" #include <dm.h> #include <remoteproc.h> diff --git a/arch/arm/mach-k3/sysfw-loader.c b/arch/arm/mach-k3/sysfw-loader.c index 78c158c63f7..91182d04b22 100644 --- a/arch/arm/mach-k3/sysfw-loader.c +++ b/arch/arm/mach-k3/sysfw-loader.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <remoteproc.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/soc/ti/ti_sci_protocol.h> #include <g_dnl.h> #include <usb.h> diff --git a/arch/arm/mach-mediatek/mt7623/init.c b/arch/arm/mach-mediatek/mt7623/init.c index 2778e260e02..5d837e05971 100644 --- a/arch/arm/mach-mediatek/mt7623/init.c +++ b/arch/arm/mach-mediatek/mt7623/init.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/io.h> #include <linux/sizes.h> #include <asm/arch/misc.h> diff --git a/arch/arm/mach-mediatek/mt7629/init.c b/arch/arm/mach-mediatek/mt7629/init.c index c260413a57a..617a77e9800 100644 --- a/arch/arm/mach-mediatek/mt7629/init.c +++ b/arch/arm/mach-mediatek/mt7629/init.c @@ -12,6 +12,7 @@ #include <log.h> #include <ram.h> #include <asm/arch/misc.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <dm/uclass.h> #include <linux/bitops.h> diff --git a/arch/arm/mach-mediatek/mt8512/init.c b/arch/arm/mach-mediatek/mt8512/init.c index aa779f43766..c14e7d22e6f 100644 --- a/arch/arm/mach-mediatek/mt8512/init.c +++ b/arch/arm/mach-mediatek/mt8512/init.c @@ -17,6 +17,7 @@ #include <asm/arch/misc.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <dm/uclass.h> #include <dt-bindings/clock/mt8512-clk.h> diff --git a/arch/arm/mach-mediatek/mt8516/init.c b/arch/arm/mach-mediatek/mt8516/init.c index 13be3912211..0eb65aa76b5 100644 --- a/arch/arm/mach-mediatek/mt8516/init.c +++ b/arch/arm/mach-mediatek/mt8516/init.c @@ -15,6 +15,7 @@ #include <asm/arch/misc.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <dm/uclass.h> #include <dt-bindings/clock/mt8516-clk.h> diff --git a/arch/arm/mach-mediatek/mt8518/init.c b/arch/arm/mach-mediatek/mt8518/init.c index 531a403da1b..28b00c3dec8 100644 --- a/arch/arm/mach-mediatek/mt8518/init.c +++ b/arch/arm/mach-mediatek/mt8518/init.c @@ -16,6 +16,7 @@ #include <asm/arch/misc.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <dm/uclass.h> #include <dt-bindings/clock/mt8518-clk.h> diff --git a/arch/arm/mach-meson/board-axg.c b/arch/arm/mach-meson/board-axg.c index 0d4eda93b8c..3b14bc99894 100644 --- a/arch/arm/mach-meson/board-axg.c +++ b/arch/arm/mach-meson/board-axg.c @@ -11,6 +11,7 @@ #include <asm/arch/eth.h> #include <asm/arch/axg.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv8/mmu.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-meson/board-common.c b/arch/arm/mach-meson/board-common.c index 7ea0ed47947..34b3c8f399d 100644 --- a/arch/arm/mach-meson/board-common.c +++ b/arch/arm/mach-meson/board-common.c @@ -11,6 +11,7 @@ #include <asm/arch/boot.h> #include <env.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/libfdt.h> #include <linux/err.h> diff --git a/arch/arm/mach-meson/board-g12a.c b/arch/arm/mach-meson/board-g12a.c index 14127ca737c..bb75d4f8ad3 100644 --- a/arch/arm/mach-meson/board-g12a.c +++ b/arch/arm/mach-meson/board-g12a.c @@ -13,6 +13,7 @@ #include <asm/arch/g12a.h> #include <asm/arch/mem.h> #include <asm/arch/meson-vpu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv8/mmu.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-meson/board-gx.c b/arch/arm/mach-meson/board-gx.c index 7a0e7035966..f5273f42af6 100644 --- a/arch/arm/mach-meson/board-gx.c +++ b/arch/arm/mach-meson/board-gx.c @@ -12,6 +12,7 @@ #include <asm/arch/gx.h> #include <asm/arch/mem.h> #include <asm/arch/meson-vpu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv8/mmu.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-meson/board-info.c b/arch/arm/mach-meson/board-info.c index 3abb27e03b4..28385488995 100644 --- a/arch/arm/mach-meson/board-info.c +++ b/arch/arm/mach-meson/board-info.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <linux/bitfield.h> diff --git a/arch/arm/mach-meson/sm.c b/arch/arm/mach-meson/sm.c index ebbb880b71e..1a8f23cb1fa 100644 --- a/arch/arm/mach-meson/sm.c +++ b/arch/arm/mach-meson/sm.c @@ -11,6 +11,7 @@ #include <log.h> #include <asm/arch/sm.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/bitops.h> #include <linux/err.h> diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index c8c065e93c3..fa687d8abbb 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -8,6 +8,7 @@ #include <fdtdec.h> #include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/libfdt.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-mvebu/armada3700/cpu.c b/arch/arm/mach-mvebu/armada3700/cpu.c index e438b4922e1..70f76c7d707 100644 --- a/arch/arm/mach-mvebu/armada3700/cpu.c +++ b/arch/arm/mach-mvebu/armada3700/cpu.c @@ -9,6 +9,7 @@ #include <dm.h> #include <fdtdec.h> #include <init.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/libfdt.h> #include <asm/io.h> diff --git a/arch/arm/mach-mvebu/armada8k/dram.c b/arch/arm/mach-mvebu/armada8k/dram.c index 3da9fa589d2..bab375e18ac 100644 --- a/arch/arm/mach-mvebu/armada8k/dram.c +++ b/arch/arm/mach-mvebu/armada8k/dram.c @@ -6,6 +6,7 @@ #include <common.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <asm/system.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-mvebu/dram.c b/arch/arm/mach-mvebu/dram.c index 6c6f8d8c5c5..349e0cc4c18 100644 --- a/arch/arm/mach-mvebu/dram.c +++ b/arch/arm/mach-mvebu/dram.c @@ -8,6 +8,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index f645befb2c0..16ebb7a59e5 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -11,6 +11,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/arch/arm/mach-nexell/cmd_boot_linux.c b/arch/arm/mach-nexell/cmd_boot_linux.c index f2dedfe1625..9b38d38ddb5 100644 --- a/arch/arm/mach-nexell/cmd_boot_linux.c +++ b/arch/arm/mach-nexell/cmd_boot_linux.c @@ -11,6 +11,7 @@ #include <errno.h> #include <image.h> #include <fdt_support.h> +#include <asm/global_data.h>
#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_CLI_FRAMEWORK)
diff --git a/arch/arm/mach-octeontx/cpu.c b/arch/arm/mach-octeontx/cpu.c index 9c29c31393c..ce5f2b42d72 100644 --- a/arch/arm/mach-octeontx/cpu.c +++ b/arch/arm/mach-octeontx/cpu.c @@ -7,6 +7,7 @@
#include <common.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/board.h>
diff --git a/arch/arm/mach-octeontx2/cpu.c b/arch/arm/mach-octeontx2/cpu.c index 2a6d5e86613..87868152b7b 100644 --- a/arch/arm/mach-octeontx2/cpu.c +++ b/arch/arm/mach-octeontx2/cpu.c @@ -7,6 +7,7 @@
diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index 2888390d240..852d36132a5 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -26,6 +26,7 @@ #include <asm/arch/mem.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index cb9d7fdb156..05efe04dc35 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -11,6 +11,7 @@ #include <ahci.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/omap_common.h> #include <asm/arch/omap.h> #include <asm/arch/mmc_host_def.h> diff --git a/arch/arm/mach-omap2/hwinit-common.c b/arch/arm/mach-omap2/hwinit-common.c index 7a7086776ee..3da50f974dc 100644 --- a/arch/arm/mach-omap2/hwinit-common.c +++ b/arch/arm/mach-omap2/hwinit-common.c @@ -16,6 +16,7 @@ #include <init.h> #include <spl.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/emif.h> #include <asm/omap_common.h> diff --git a/arch/arm/mach-omap2/omap-cache.c b/arch/arm/mach-omap2/omap-cache.c index 502ea6987ab..1b246f844a8 100644 --- a/arch/arm/mach-omap2/omap-cache.c +++ b/arch/arm/mach-omap2/omap-cache.c @@ -15,6 +15,7 @@ #include <cpu_func.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-omap2/omap3/am35x_musb.c b/arch/arm/mach-omap2/omap3/am35x_musb.c index 026e5d2d130..95e15c1a51b 100644 --- a/arch/arm/mach-omap2/omap3/am35x_musb.c +++ b/arch/arm/mach-omap2/omap3/am35x_musb.c @@ -9,6 +9,7 @@ */
#include <common.h> +#include <dm.h> #include <log.h> #include <asm/io.h> #include <asm/arch/am35x_def.h> diff --git a/arch/arm/mach-omap2/omap3/emif4.c b/arch/arm/mach-omap2/omap3/emif4.c index 4cfa1323881..df6e9ce1d6c 100644 --- a/arch/arm/mach-omap2/omap3/emif4.c +++ b/arch/arm/mach-omap2/omap3/emif4.c @@ -11,6 +11,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mem.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-omap2/omap3/sdrc.c b/arch/arm/mach-omap2/omap3/sdrc.c index 1d65ed62270..4d85b1dee99 100644 --- a/arch/arm/mach-omap2/omap3/sdrc.c +++ b/arch/arm/mach-omap2/omap3/sdrc.c @@ -23,6 +23,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mem.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-omap2/timer.c b/arch/arm/mach-omap2/timer.c index bcfba16a08e..82b10f6b248 100644 --- a/arch/arm/mach-omap2/timer.c +++ b/arch/arm/mach-omap2/timer.c @@ -18,6 +18,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-orion5x/dram.c b/arch/arm/mach-orion5x/dram.c index 33f65db48ea..c9a3750e48d 100644 --- a/arch/arm/mach-orion5x/dram.c +++ b/arch/arm/mach-orion5x/dram.c @@ -12,6 +12,7 @@ #include <config.h> #include <init.h> #include <asm/arch/cpu.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-orion5x/timer.c b/arch/arm/mach-orion5x/timer.c index 4926bb77796..0adf3dcc648 100644 --- a/arch/arm/mach-orion5x/timer.c +++ b/arch/arm/mach-orion5x/timer.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/arch/arm/mach-owl/soc.c b/arch/arm/mach-owl/soc.c index fd6ee7c1c0f..4d2b9d0b0eb 100644 --- a/arch/arm/mach-owl/soc.c +++ b/arch/arm/mach-owl/soc.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/arm-smccc.h> #include <linux/psci.h> #include <common.h> diff --git a/arch/arm/mach-rmobile/memmap-gen3.c b/arch/arm/mach-rmobile/memmap-gen3.c index 578cb9bfd3f..a68eb806b35 100644 --- a/arch/arm/mach-rmobile/memmap-gen3.c +++ b/arch/arm/mach-rmobile/memmap-gen3.c @@ -8,6 +8,7 @@ #include <common.h> #include <cpu_func.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h>
#define GEN3_NR_REGIONS 16
diff --git a/arch/arm/mach-rockchip/board.c b/arch/arm/mach-rockchip/board.c index ba4da72b391..c386b52987e 100644 --- a/arch/arm/mach-rockchip/board.c +++ b/arch/arm/mach-rockchip/board.c @@ -12,6 +12,7 @@ #include <ram.h> #include <syscon.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/boot_mode.h> #include <asm/arch-rockchip/clock.h> diff --git a/arch/arm/mach-rockchip/rk3036-board-spl.c b/arch/arm/mach-rockchip/rk3036-board-spl.c index 6eb89e15b81..964e981b863 100644 --- a/arch/arm/mach-rockchip/rk3036-board-spl.c +++ b/arch/arm/mach-rockchip/rk3036-board-spl.c @@ -6,6 +6,7 @@ #include <common.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/sdram_rk3036.h> diff --git a/arch/arm/mach-rockchip/rk3036/rk3036.c b/arch/arm/mach-rockchip/rk3036/rk3036.c index e9e020ff3f5..0a072cf03a8 100644 --- a/arch/arm/mach-rockchip/rk3036/rk3036.c +++ b/arch/arm/mach-rockchip/rk3036/rk3036.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/grf_rk3036.h> #include <asm/arch-rockchip/hardware.h> diff --git a/arch/arm/mach-rockchip/rk3128/rk3128.c b/arch/arm/mach-rockchip/rk3128/rk3128.c index 740bd2ba077..01dbfa75cb2 100644 --- a/arch/arm/mach-rockchip/rk3128/rk3128.c +++ b/arch/arm/mach-rockchip/rk3128/rk3128.c @@ -4,6 +4,7 @@ */ #include <common.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-rockchip/rk3188/rk3188.c b/arch/arm/mach-rockchip/rk3188/rk3188.c index 222953ab94a..ad8c6cd1d79 100644 --- a/arch/arm/mach-rockchip/rk3188/rk3188.c +++ b/arch/arm/mach-rockchip/rk3188/rk3188.c @@ -9,6 +9,7 @@ #include <led.h> #include <log.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> diff --git a/arch/arm/mach-rockchip/rk3288/rk3288.c b/arch/arm/mach-rockchip/rk3288/rk3288.c index 1a4ecdf6254..bc20bc5ab90 100644 --- a/arch/arm/mach-rockchip/rk3288/rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/rk3288.c @@ -10,6 +10,7 @@ #include <init.h> #include <malloc.h> #include <asm/armv7.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> diff --git a/arch/arm/mach-rockchip/rk3308/rk3308.c b/arch/arm/mach-rockchip/rk3308/rk3308.c index 8e8214cf7ec..70fe0d0ac35 100644 --- a/arch/arm/mach-rockchip/rk3308/rk3308.c +++ b/arch/arm/mach-rockchip/rk3308/rk3308.c @@ -5,6 +5,7 @@ #include <common.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/grf_rk3308.h> #include <asm/arch-rockchip/hardware.h> diff --git a/arch/arm/mach-rockchip/rk3328/rk3328.c b/arch/arm/mach-rockchip/rk3328/rk3328.c index 7c85b2663c8..ec3336cb49a 100644 --- a/arch/arm/mach-rockchip/rk3328/rk3328.c +++ b/arch/arm/mach-rockchip/rk3328/rk3328.c @@ -10,6 +10,7 @@ #include <asm/arch-rockchip/grf_rk3328.h> #include <asm/arch-rockchip/uart.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/mach-rockchip/rk3368/rk3368.c b/arch/arm/mach-rockchip/rk3368/rk3368.c index 1c6d65a5887..9b7132d471c 100644 --- a/arch/arm/mach-rockchip/rk3368/rk3368.c +++ b/arch/arm/mach-rockchip/rk3368/rk3368.c @@ -8,6 +8,7 @@ #include <init.h> #include <syscon.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index c6434839719..869d2159bea 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -11,6 +11,7 @@ #include <spl_gpio.h> #include <syscon.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> diff --git a/arch/arm/mach-rockchip/sdram.c b/arch/arm/mach-rockchip/sdram.c index 4c637b77673..ed07ece15a4 100644 --- a/arch/arm/mach-rockchip/sdram.c +++ b/arch/arm/mach-rockchip/sdram.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <ram.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/sdram.h> #include <dm/uclass-internal.h> diff --git a/arch/arm/mach-rockchip/spl-boot-order.c b/arch/arm/mach-rockchip/spl-boot-order.c index 94673f34c9b..e05c12e0cd3 100644 --- a/arch/arm/mach-rockchip/spl-boot-order.c +++ b/arch/arm/mach-rockchip/spl-boot-order.c @@ -8,6 +8,7 @@ #include <log.h> #include <mmc.h> #include <spl.h> +#include <asm/global_data.h>
#if CONFIG_IS_ENABLED(OF_LIBFDT) /** diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index f148d48b6a3..4b5c22dc138 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -13,6 +13,7 @@ #include <ram.h> #include <spl.h> #include <asm/arch-rockchip/bootrom.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/arch/arm/mach-snapdragon/pinctrl-snapdragon.h b/arch/arm/mach-snapdragon/pinctrl-snapdragon.h index 24f8863f59b..61d466f4d84 100644 --- a/arch/arm/mach-snapdragon/pinctrl-snapdragon.h +++ b/arch/arm/mach-snapdragon/pinctrl-snapdragon.h @@ -8,7 +8,7 @@ #ifndef _PINCTRL_SNAPDRAGON_H #define _PINCTRL_SNAPDRAGON_H
-#include <common.h> +struct udevice;
struct msm_pinctrl_data { int pin_count; diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach-socfpga/board.c index 340abf9305c..bdd5b863c45 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -12,6 +12,7 @@ #include <asm/arch/reset_manager.h> #include <asm/arch/clock_manager.h> #include <asm/arch/misc.h> +#include <asm/global_data.h> #include <asm/io.h>
#include <usb.h> diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index a4a97b6a0fc..f0b15f770cc 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -7,6 +7,7 @@ #include <command.h> #include <init.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock_manager.h>
diff --git a/arch/arm/mach-socfpga/clock_manager_agilex.c b/arch/arm/mach-socfpga/clock_manager_agilex.c index 6188a8c3d2d..4bf01f3c8ae 100644 --- a/arch/arm/mach-socfpga/clock_manager_agilex.c +++ b/arch/arm/mach-socfpga/clock_manager_agilex.c @@ -11,6 +11,7 @@ #include <malloc.h> #include <asm/arch/clock_manager.h> #include <asm/arch/system_manager.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dt-bindings/clock/agilex-clock.h>
diff --git a/arch/arm/mach-socfpga/clock_manager_s10.c b/arch/arm/mach-socfpga/clock_manager_s10.c index 05e42127b57..642dcbb0ac0 100644 --- a/arch/arm/mach-socfpga/clock_manager_s10.c +++ b/arch/arm/mach-socfpga/clock_manager_s10.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock_manager.h> #include <asm/arch/handoff_s10.h> diff --git a/arch/arm/mach-socfpga/mailbox_s10.c b/arch/arm/mach-socfpga/mailbox_s10.c index 18d44924e62..3332e44f3b6 100644 --- a/arch/arm/mach-socfpga/mailbox_s10.c +++ b/arch/arm/mach-socfpga/mailbox_s10.c @@ -7,6 +7,7 @@ #include <common.h> #include <hang.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mailbox_s10.h> #include <asm/arch/system_manager.h> diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index ac2b891fade..64a7c9d652c 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -9,6 +9,7 @@ #include <hang.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <fdtdec.h> diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index 7209e8d6db7..4edf4f9b5c1 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -6,6 +6,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <env.h> #include <errno.h> diff --git a/arch/arm/mach-socfpga/misc_s10.c b/arch/arm/mach-socfpga/misc_s10.c index 0d67b0fd836..50c7f19ae14 100644 --- a/arch/arm/mach-socfpga/misc_s10.c +++ b/arch/arm/mach-socfpga/misc_s10.c @@ -10,6 +10,7 @@ #include <errno.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mailbox_s10.h> #include <asm/arch/misc.h> diff --git a/arch/arm/mach-socfpga/mmu-arm64_s10.c b/arch/arm/mach-socfpga/mmu-arm64_s10.c index 670ceb92ae3..a55b7b7cf3b 100644 --- a/arch/arm/mach-socfpga/mmu-arm64_s10.c +++ b/arch/arm/mach-socfpga/mmu-arm64_s10.c @@ -6,6 +6,7 @@
diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index aa5299415a7..27c03080113 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -3,6 +3,7 @@ * Copyright (C) 2016-2017 Intel Corporation */
+#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/fpga_manager.h> #include <asm/arch/misc.h> diff --git a/arch/arm/mach-socfpga/reset_manager_s10.c b/arch/arm/mach-socfpga/reset_manager_s10.c index 3746e6a60c3..dc521fb3e75 100644 --- a/arch/arm/mach-socfpga/reset_manager_s10.c +++ b/arch/arm/mach-socfpga/reset_manager_s10.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h> diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c index 45aea4ab6cc..92231b5ba3c 100644 --- a/arch/arm/mach-socfpga/spl_a10.c +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -7,6 +7,7 @@ #include <cpu_func.h> #include <hang.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/pl310.h> #include <asm/u-boot.h> diff --git a/arch/arm/mach-socfpga/spl_agilex.c b/arch/arm/mach-socfpga/spl_agilex.c index 78b5d7c8d98..71b17ce3a59 100644 --- a/arch/arm/mach-socfpga/spl_agilex.c +++ b/arch/arm/mach-socfpga/spl_agilex.c @@ -6,6 +6,7 @@
#include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/u-boot.h> #include <asm/utils.h> diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index 5a7c5ef76d5..7c716117685 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -7,6 +7,7 @@ #include <hang.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/u-boot.h> #include <asm/utils.h> diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index daed05653ad..955a1161e89 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -7,6 +7,7 @@ #include <hang.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/u-boot.h> #include <asm/utils.h> diff --git a/arch/arm/mach-socfpga/system_manager_s10.c b/arch/arm/mach-socfpga/system_manager_s10.c index cdda881efd7..c123cc96445 100644 --- a/arch/arm/mach-socfpga/system_manager_s10.c +++ b/arch/arm/mach-socfpga/system_manager_s10.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/system_manager.h>
diff --git a/arch/arm/mach-stm32mp/boot_params.c b/arch/arm/mach-stm32mp/boot_params.c index 37ee9e1612c..c4fba9e33af 100644 --- a/arch/arm/mach-stm32mp/boot_params.c +++ b/arch/arm/mach-stm32mp/boot_params.c @@ -7,6 +7,7 @@ #include <log.h> #include <asm/sections.h> #include <asm/system.h> +#include <linux/libfdt.h>
/* * Force data-section, as .bss will not be valid diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index a777827c55e..ddf8b68f9a0 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -11,6 +11,7 @@ #include <mmc.h> #include <part.h> #include <asm/arch/stm32mp1_smc.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <jffs2/load_kernel.h> #include <linux/list.h> diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c index 8aad4be467e..0150d2d5412 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <serial.h> #include <watchdog.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/device-internal.h> #include <linux/delay.h> diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 6785ab6b582..f273d84492f 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -11,6 +11,7 @@ #include <log.h> #include <misc.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/bsec.h> #include <asm/arch/stm32.h> diff --git a/arch/arm/mach-stm32mp/dram_init.c b/arch/arm/mach-stm32mp/dram_init.c index 0e8ce63f4a2..611e0ff0eb7 100644 --- a/arch/arm/mach-stm32mp/dram_init.c +++ b/arch/arm/mach-stm32mp/dram_init.c @@ -10,6 +10,7 @@ #include <lmb.h> #include <log.h> #include <ram.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-stm32mp/fdt.c b/arch/arm/mach-stm32mp/fdt.c index 0de1d822912..9dbc595cc4f 100644 --- a/arch/arm/mach-stm32mp/fdt.c +++ b/arch/arm/mach-stm32mp/fdt.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <fdtdec.h> #include <fdt_support.h> #include <log.h> #include <tee.h> diff --git a/arch/arm/mach-stm32mp/spl.c b/arch/arm/mach-stm32mp/spl.c index b679b0a6454..969eaa1dadd 100644 --- a/arch/arm/mach-stm32mp/spl.c +++ b/arch/arm/mach-stm32mp/spl.c @@ -11,6 +11,7 @@ #include <log.h> #include <spl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <linux/libfdt.h> diff --git a/arch/arm/mach-tegra/board.c b/arch/arm/mach-tegra/board.c index 03faacbd577..ecdfcdde921 100644 --- a/arch/arm/mach-tegra/board.c +++ b/arch/arm/mach-tegra/board.c @@ -12,6 +12,7 @@ #include <ns16550.h> #include <spl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #if IS_ENABLED(CONFIG_TEGRA_CLKRST) #include <asm/arch/clock.h> diff --git a/arch/arm/mach-tegra/board2.c b/arch/arm/mach-tegra/board2.c index 48c4f32d6f9..66376dd39a2 100644 --- a/arch/arm/mach-tegra/board2.c +++ b/arch/arm/mach-tegra/board2.c @@ -12,6 +12,7 @@ #include <log.h> #include <ns16550.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-tegra/ap.h> #include <asm/arch-tegra/board.h> diff --git a/arch/arm/mach-tegra/cboot.c b/arch/arm/mach-tegra/cboot.c index 16c4cf306ec..bb46fb23ff7 100644 --- a/arch/arm/mach-tegra/cboot.c +++ b/arch/arm/mach-tegra/cboot.c @@ -14,6 +14,7 @@ #include <net.h> #include <stdlib.h> #include <string.h> +#include <asm/global_data.h>
#include <linux/ctype.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-tegra/emc.c b/arch/arm/mach-tegra/emc.c index 66628933b65..2eea14b5a74 100644 --- a/arch/arm/mach-tegra/emc.c +++ b/arch/arm/mach-tegra/emc.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include "emc.h" #include <asm/io.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-tegra/pmc.c b/arch/arm/mach-tegra/pmc.c index cdc8493efd8..93db63e104a 100644 --- a/arch/arm/mach-tegra/pmc.c +++ b/arch/arm/mach-tegra/pmc.c @@ -6,6 +6,7 @@ #include <common.h> #include <cpu_func.h> #include <log.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-tegra/tegra124/xusb-padctl.c b/arch/arm/mach-tegra/tegra124/xusb-padctl.c index 38afc3cbe6d..c95ca048d5e 100644 --- a/arch/arm/mach-tegra/tegra124/xusb-padctl.c +++ b/arch/arm/mach-tegra/tegra124/xusb-padctl.c @@ -8,6 +8,7 @@ #include <common.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <dm/of_access.h> #include <dm/ofnode.h> #include <linux/delay.h> diff --git a/arch/arm/mach-tegra/tegra20/warmboot.c b/arch/arm/mach-tegra/tegra20/warmboot.c index ddde4a66772..3d3758f6e6f 100644 --- a/arch/arm/mach-tegra/tegra20/warmboot.c +++ b/arch/arm/mach-tegra/tegra20/warmboot.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/errno.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-tegra/tegra210/xusb-padctl.c b/arch/arm/mach-tegra/tegra210/xusb-padctl.c index d160ce4c999..c414dfd3b86 100644 --- a/arch/arm/mach-tegra/tegra210/xusb-padctl.c +++ b/arch/arm/mach-tegra/tegra210/xusb-padctl.c @@ -8,6 +8,7 @@ #include <common.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <dm/of_access.h> #include <dm/ofnode.h> #include <linux/delay.h> diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index 8c5e5bb58f6..b33c4b19389 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -8,6 +8,7 @@ #include <env.h> #include <init.h> #include <spl.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <stdio.h> #include <linux/printk.h> diff --git a/arch/arm/mach-versal/clk.c b/arch/arm/mach-versal/clk.c index b1e34796d0d..249e050cc8d 100644 --- a/arch/arm/mach-versal/clk.c +++ b/arch/arm/mach-versal/clk.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-versal/cpu.c b/arch/arm/mach-versal/cpu.c index 61c0b663fcf..a35aac2c02c 100644 --- a/arch/arm/mach-versal/cpu.c +++ b/arch/arm/mach-versal/cpu.c @@ -8,6 +8,7 @@ #include <init.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-versal/mp.c b/arch/arm/mach-versal/mp.c index 4b434b0ac3f..c97c311d313 100644 --- a/arch/arm/mach-versal/mp.c +++ b/arch/arm/mach-versal/mp.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-zynq/clk.c b/arch/arm/mach-zynq/clk.c index 1ace117fc8e..9bab393e211 100644 --- a/arch/arm/mach-zynq/clk.c +++ b/arch/arm/mach-zynq/clk.c @@ -9,6 +9,7 @@ #include <init.h> #include <malloc.h> #include <asm/arch/clk.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-zynq/timer.c b/arch/arm/mach-zynq/timer.c index cc0e24cbfed..08cb4406cc3 100644 --- a/arch/arm/mach-zynq/timer.c +++ b/arch/arm/mach-zynq/timer.c @@ -34,6 +34,7 @@ #include <init.h> #include <time.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/clk.h> diff --git a/arch/arm/mach-zynqmp-r5/cpu.c b/arch/arm/mach-zynqmp-r5/cpu.c index 87c1d75f9f3..d841c3a5b37 100644 --- a/arch/arm/mach-zynqmp-r5/cpu.c +++ b/arch/arm/mach-zynqmp-r5/cpu.c @@ -7,6 +7,7 @@ #include <cpu_func.h> #include <init.h> #include <asm/armv7_mpu.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-zynqmp/clk.c b/arch/arm/mach-zynqmp/clk.c index 5067b339c21..1e6e726e879 100644 --- a/arch/arm/mach-zynqmp/clk.c +++ b/arch/arm/mach-zynqmp/clk.c @@ -10,6 +10,7 @@ #include <asm/arch/clk.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-zynqmp/cpu.c b/arch/arm/mach-zynqmp/cpu.c index 3eb8e8f4487..29743cae5aa 100644 --- a/arch/arm/mach-zynqmp/cpu.c +++ b/arch/arm/mach-zynqmp/cpu.c @@ -11,6 +11,7 @@ #include <asm/arch/sys_proto.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <zynqmp_firmware.h> #include <asm/cache.h> diff --git a/arch/m68k/cpu/mcf5227x/cpu.c b/arch/m68k/cpu/mcf5227x/cpu.c index 5ea6158c809..a7adf64f0de 100644 --- a/arch/m68k/cpu/mcf5227x/cpu.c +++ b/arch/m68k/cpu/mcf5227x/cpu.c @@ -13,6 +13,7 @@ #include <vsprintf.h> #include <watchdog.h> #include <command.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf5227x/speed.c b/arch/m68k/cpu/mcf5227x/speed.c index 207f4534807..fa9d5cb7887 100644 --- a/arch/m68k/cpu/mcf5227x/speed.c +++ b/arch/m68k/cpu/mcf5227x/speed.c @@ -7,6 +7,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <asm/processor.h>
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf523x/cpu.c b/arch/m68k/cpu/mcf523x/cpu.c index 8664231b5a1..8d3ab6f3fb2 100644 --- a/arch/m68k/cpu/mcf523x/cpu.c +++ b/arch/m68k/cpu/mcf523x/cpu.c @@ -15,6 +15,7 @@ #include <watchdog.h> #include <command.h> #include <netdev.h> +#include <asm/global_data.h>
#include <asm/immap.h> #include <asm/io.h> diff --git a/arch/m68k/cpu/mcf523x/speed.c b/arch/m68k/cpu/mcf523x/speed.c index 2f65ac23182..f41f977d7f5 100644 --- a/arch/m68k/cpu/mcf523x/speed.c +++ b/arch/m68k/cpu/mcf523x/speed.c @@ -10,6 +10,7 @@
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf52x2/cpu.c b/arch/m68k/cpu/mcf52x2/cpu.c index 8898a7562ad..0676e391410 100644 --- a/arch/m68k/cpu/mcf52x2/cpu.c +++ b/arch/m68k/cpu/mcf52x2/cpu.c @@ -19,6 +19,7 @@ #include <vsprintf.h> #include <watchdog.h> #include <command.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <netdev.h> diff --git a/arch/m68k/cpu/mcf52x2/speed.c b/arch/m68k/cpu/mcf52x2/speed.c index 751c83a4fc0..045908a13d4 100644 --- a/arch/m68k/cpu/mcf52x2/speed.c +++ b/arch/m68k/cpu/mcf52x2/speed.c @@ -9,6 +9,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/immap.h> #include <asm/io.h> diff --git a/arch/m68k/cpu/mcf530x/speed.c b/arch/m68k/cpu/mcf530x/speed.c index cf53dfeb150..03d9abeb182 100644 --- a/arch/m68k/cpu/mcf530x/speed.c +++ b/arch/m68k/cpu/mcf530x/speed.c @@ -6,6 +6,7 @@
diff --git a/arch/m68k/cpu/mcf532x/cpu.c b/arch/m68k/cpu/mcf532x/cpu.c index f1e6f734eb4..d37dd3defb7 100644 --- a/arch/m68k/cpu/mcf532x/cpu.c +++ b/arch/m68k/cpu/mcf532x/cpu.c @@ -15,6 +15,7 @@ #include <watchdog.h> #include <command.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf532x/speed.c b/arch/m68k/cpu/mcf532x/speed.c index 0f54ea4b6a8..e2985792d96 100644 --- a/arch/m68k/cpu/mcf532x/speed.c +++ b/arch/m68k/cpu/mcf532x/speed.c @@ -10,6 +10,7 @@
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf5445x/cpu.c b/arch/m68k/cpu/mcf5445x/cpu.c index ebe15ca518c..ac1e5916816 100644 --- a/arch/m68k/cpu/mcf5445x/cpu.c +++ b/arch/m68k/cpu/mcf5445x/cpu.c @@ -15,6 +15,7 @@ #include <watchdog.h> #include <command.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf5445x/speed.c b/arch/m68k/cpu/mcf5445x/speed.c index eaa3b39bec6..a0b9af8866b 100644 --- a/arch/m68k/cpu/mcf5445x/speed.c +++ b/arch/m68k/cpu/mcf5445x/speed.c @@ -7,6 +7,7 @@
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf547x_8x/cpu.c b/arch/m68k/cpu/mcf547x_8x/cpu.c index e53adeb46b5..c1361e70579 100644 --- a/arch/m68k/cpu/mcf547x_8x/cpu.c +++ b/arch/m68k/cpu/mcf547x_8x/cpu.c @@ -15,6 +15,7 @@ #include <watchdog.h> #include <command.h> #include <netdev.h> +#include <asm/global_data.h>
#include <asm/immap.h> #include <asm/io.h> diff --git a/arch/m68k/cpu/mcf547x_8x/slicetimer.c b/arch/m68k/cpu/mcf547x_8x/slicetimer.c index 33b4cff4ec7..dc076fc6e81 100644 --- a/arch/m68k/cpu/mcf547x_8x/slicetimer.c +++ b/arch/m68k/cpu/mcf547x_8x/slicetimer.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <irq_func.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/timer.h> diff --git a/arch/m68k/cpu/mcf547x_8x/speed.c b/arch/m68k/cpu/mcf547x_8x/speed.c index bc22560ed2c..bbcf601f38f 100644 --- a/arch/m68k/cpu/mcf547x_8x/speed.c +++ b/arch/m68k/cpu/mcf547x_8x/speed.c @@ -10,6 +10,7 @@
#include <asm/immap.h> diff --git a/arch/m68k/include/asm/immap.h b/arch/m68k/include/asm/immap.h index 9e84fb9d260..9551e047d02 100644 --- a/arch/m68k/include/asm/immap.h +++ b/arch/m68k/include/asm/immap.h @@ -30,6 +30,7 @@
#define CONFIG_SYS_INTR_BASE (MMAP_INTC0) #define CONFIG_SYS_NUM_IRQS (128) +#include <asm/global_data.h> #endif /* CONFIG_M520x */
#ifdef CONFIG_M52277 diff --git a/arch/m68k/lib/bdinfo.c b/arch/m68k/lib/bdinfo.c index 404e5f19ed8..9ec56fd3418 100644 --- a/arch/m68k/lib/bdinfo.c +++ b/arch/m68k/lib/bdinfo.c @@ -8,6 +8,7 @@
diff --git a/arch/m68k/lib/bootm.c b/arch/m68k/lib/bootm.c index 320451144fd..51a6f938586 100644 --- a/arch/m68k/lib/bootm.c +++ b/arch/m68k/lib/bootm.c @@ -11,6 +11,7 @@ #include <image.h> #include <lmb.h> #include <log.h> +#include <asm/global_data.h> #include <u-boot/zlib.h> #include <bzlib.h> #include <watchdog.h> diff --git a/arch/m68k/lib/fec.c b/arch/m68k/lib/fec.c index dde353ad17f..eecea7a0235 100644 --- a/arch/m68k/lib/fec.c +++ b/arch/m68k/lib/fec.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h>
diff --git a/arch/m68k/lib/time.c b/arch/m68k/lib/time.c index a3eb6db54be..cbe29e72a86 100644 --- a/arch/m68k/lib/time.c +++ b/arch/m68k/lib/time.c @@ -10,6 +10,7 @@ #include <init.h> #include <irq_func.h> #include <time.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/timer.h> diff --git a/arch/microblaze/cpu/interrupts.c b/arch/microblaze/cpu/interrupts.c index 829ae26ad27..fe65f3728fd 100644 --- a/arch/microblaze/cpu/interrupts.c +++ b/arch/microblaze/cpu/interrupts.c @@ -13,6 +13,7 @@ #include <irq_func.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/microblaze_intc.h> #include <asm/asm.h>
diff --git a/arch/microblaze/cpu/timer.c b/arch/microblaze/cpu/timer.c index 1b4617311c5..647bdcd5ba5 100644 --- a/arch/microblaze/cpu/timer.c +++ b/arch/microblaze/cpu/timer.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <asm/microblaze_timer.h> #include <asm/microblaze_intc.h> #include <linux/delay.h> diff --git a/arch/microblaze/lib/bootm.c b/arch/microblaze/lib/bootm.c index d2ea1453be0..6695ac63c77 100644 --- a/arch/microblaze/lib/bootm.c +++ b/arch/microblaze/lib/bootm.c @@ -18,6 +18,7 @@ #include <lmb.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <u-boot/zlib.h> #include <asm/byteorder.h>
diff --git a/arch/mips/include/asm/io.h b/arch/mips/include/asm/io.h index 7c40e415c74..d3ad6693013 100644 --- a/arch/mips/include/asm/io.h +++ b/arch/mips/include/asm/io.h @@ -16,6 +16,7 @@ #include <asm/addrspace.h> #include <asm/byteorder.h> #include <asm/cpu-features.h> +#include <asm/global_data.h> #include <asm/pgtable-bits.h> #include <asm/processor.h> #include <asm/string.h> diff --git a/arch/mips/include/asm/spl.h b/arch/mips/include/asm/spl.h index 0a847edec89..4ff5af2eb9a 100644 --- a/arch/mips/include/asm/spl.h +++ b/arch/mips/include/asm/spl.h @@ -6,6 +6,7 @@ #ifndef _ASM_SPL_H_ #define _ASM_SPL_H_
+#include <asm/global_data.h> enum { BOOT_DEVICE_RAM, BOOT_DEVICE_MMC1, diff --git a/arch/mips/lib/boot.c b/arch/mips/lib/boot.c index 6ef9109022e..1b29d637ce9 100644 --- a/arch/mips/lib/boot.c +++ b/arch/mips/lib/boot.c @@ -6,6 +6,7 @@ #include <common.h> #include <command.h> #include <cpu_func.h> +#include <asm/global_data.h>
diff --git a/arch/mips/lib/bootm.c b/arch/mips/lib/bootm.c index d5c99d891cd..fde90fced44 100644 --- a/arch/mips/lib/bootm.c +++ b/arch/mips/lib/bootm.c @@ -12,6 +12,7 @@ #include <lmb.h> #include <log.h> #include <asm/addrspace.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/mips/lib/cache.c b/arch/mips/lib/cache.c index cf29994a7ae..51a8f433475 100644 --- a/arch/mips/lib/cache.c +++ b/arch/mips/lib/cache.c @@ -9,6 +9,7 @@ #include <asm/cache.h> #include <asm/cacheops.h> #include <asm/cm.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mipsregs.h> #include <asm/system.h> diff --git a/arch/mips/lib/reloc.c b/arch/mips/lib/reloc.c index 67c8af2f35a..c1c04bc08e8 100644 --- a/arch/mips/lib/reloc.c +++ b/arch/mips/lib/reloc.c @@ -29,6 +29,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h> #include <asm/relocs.h> #include <asm/sections.h> #include <linux/bitops.h> diff --git a/arch/mips/lib/stack.c b/arch/mips/lib/stack.c index 8f523fd6fb7..930d21856d9 100644 --- a/arch/mips/lib/stack.c +++ b/arch/mips/lib/stack.c @@ -3,6 +3,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
diff --git a/arch/mips/lib/traps.c b/arch/mips/lib/traps.c index df8b63f383b..7c2fdf4a1a9 100644 --- a/arch/mips/lib/traps.c +++ b/arch/mips/lib/traps.c @@ -11,6 +11,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <cpu_func.h> #include <hang.h> diff --git a/arch/mips/mach-ath79/ar933x/clk.c b/arch/mips/mach-ath79/ar933x/clk.c index 3feb25ce71d..68d48939d7d 100644 --- a/arch/mips/mach-ath79/ar933x/clk.c +++ b/arch/mips/mach-ath79/ar933x/clk.c @@ -5,6 +5,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/ar934x/clk.c b/arch/mips/mach-ath79/ar934x/clk.c index 9fa2225ed2b..6ed4057353a 100644 --- a/arch/mips/mach-ath79/ar934x/clk.c +++ b/arch/mips/mach-ath79/ar934x/clk.c @@ -7,6 +7,7 @@ #include <clock_legacy.h> #include <command.h> #include <hang.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/ar934x/ddr.c b/arch/mips/mach-ath79/ar934x/ddr.c index 218f60a96cc..9df48b97ef4 100644 --- a/arch/mips/mach-ath79/ar934x/ddr.c +++ b/arch/mips/mach-ath79/ar934x/ddr.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/cpu.c b/arch/mips/mach-ath79/cpu.c index 31e87d62060..ed190e8f9b0 100644 --- a/arch/mips/mach-ath79/cpu.c +++ b/arch/mips/mach-ath79/cpu.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/dram.c b/arch/mips/mach-ath79/dram.c index 1abe2a49e66..545b1199e10 100644 --- a/arch/mips/mach-ath79/dram.c +++ b/arch/mips/mach-ath79/dram.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/addrspace.h> #include <mach/ddr.h> diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h index 0fde5079b16..2eda38885e3 100644 --- a/arch/mips/mach-ath79/include/mach/ath79.h +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -11,6 +11,7 @@ #ifndef __ASM_MACH_ATH79_H #define __ASM_MACH_ATH79_H
+#include <asm/global_data.h> #include <linux/types.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/mips/mach-ath79/qca953x/clk.c b/arch/mips/mach-ath79/qca953x/clk.c index d450ad86523..f5438ef1c8d 100644 --- a/arch/mips/mach-ath79/qca953x/clk.c +++ b/arch/mips/mach-ath79/qca953x/clk.c @@ -5,6 +5,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/qca956x/clk.c b/arch/mips/mach-ath79/qca956x/clk.c index 5adf6cd8159..6a58dba91f3 100644 --- a/arch/mips/mach-ath79/qca956x/clk.c +++ b/arch/mips/mach-ath79/qca956x/clk.c @@ -6,6 +6,7 @@ #include <common.h> #include <clock_legacy.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/qca956x/ddr.c b/arch/mips/mach-ath79/qca956x/ddr.c index e61a368141b..f9cf8daa224 100644 --- a/arch/mips/mach-ath79/qca956x/ddr.c +++ b/arch/mips/mach-ath79/qca956x/ddr.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-bmips/dram.c b/arch/mips/mach-bmips/dram.c index a772a655d92..bba6cd6f4aa 100644 --- a/arch/mips/mach-bmips/dram.c +++ b/arch/mips/mach-bmips/dram.c @@ -9,6 +9,7 @@ #include <log.h> #include <ram.h> #include <dm.h> +#include <asm/global_data.h>
diff --git a/arch/mips/mach-jz47xx/jz4780/jz4780.c b/arch/mips/mach-jz47xx/jz4780/jz4780.c index 26fcfc842c2..43f5651f832 100644 --- a/arch/mips/mach-jz47xx/jz4780/jz4780.c +++ b/arch/mips/mach-jz47xx/jz4780/jz4780.c @@ -12,6 +12,7 @@ #include <hang.h> #include <image.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/sections.h> #include <mach/jz4780.h> diff --git a/arch/mips/mach-mscc/cpu.c b/arch/mips/mach-mscc/cpu.c index b4ffd44ea44..5bc31006aa1 100644 --- a/arch/mips/mach-mscc/cpu.c +++ b/arch/mips/mach-mscc/cpu.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/bitops.h>
#include <asm/io.h> diff --git a/arch/mips/mach-mscc/dram.c b/arch/mips/mach-mscc/dram.c index b12bac63c27..c53a4202e0d 100644 --- a/arch/mips/mach-mscc/dram.c +++ b/arch/mips/mach-mscc/dram.c @@ -5,6 +5,7 @@
#include <asm/io.h> #include <asm/types.h> diff --git a/arch/mips/mach-mtmips/cpu.c b/arch/mips/mach-mtmips/cpu.c index 2ddf8cb0967..76ad4f63205 100644 --- a/arch/mips/mach-mtmips/cpu.c +++ b/arch/mips/mach-mtmips/cpu.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <linux/sizes.h> diff --git a/arch/mips/mach-mtmips/ddr_cal.c b/arch/mips/mach-mtmips/ddr_cal.c index 71a53c3c9cb..762619a960f 100644 --- a/arch/mips/mach-mtmips/ddr_cal.c +++ b/arch/mips/mach-mtmips/ddr_cal.c @@ -8,6 +8,7 @@ #include <common.h> #include <asm/addrspace.h> #include <asm/cacheops.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <mach/mc.h> diff --git a/arch/mips/mach-mtmips/mt7628/ddr.c b/arch/mips/mach-mtmips/mt7628/ddr.c index 3df85cd144a..b091f2ecffc 100644 --- a/arch/mips/mach-mtmips/mt7628/ddr.c +++ b/arch/mips/mach-mtmips/mt7628/ddr.c @@ -7,6 +7,7 @@
#include <common.h> #include <asm/addrspace.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/sizes.h> diff --git a/arch/mips/mach-mtmips/mt7628/init.c b/arch/mips/mach-mtmips/mt7628/init.c index 77d1f2ea0dc..27241050aaf 100644 --- a/arch/mips/mach-mtmips/mt7628/init.c +++ b/arch/mips/mach-mtmips/mt7628/init.c @@ -8,6 +8,7 @@ #include <common.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <dt-bindings/clock/mt7628-clk.h> #include <linux/io.h> diff --git a/arch/mips/mach-mtmips/spl.c b/arch/mips/mach-mtmips/spl.c index 38d9e9160d2..95201b8d7ab 100644 --- a/arch/mips/mach-mtmips/spl.c +++ b/arch/mips/mach-mtmips/spl.c @@ -6,10 +6,10 @@ */
#include <common.h> -#include <fdt.h> #include <init.h> #include <spl.h> #include <asm/sections.h> +#include <linux/libfdt.h> #include <linux/sizes.h> #include <mach/serial.h>
diff --git a/arch/mips/mach-octeon/bootoctlinux.c b/arch/mips/mach-octeon/bootoctlinux.c index 75d7e83bd71..e43f6088fe3 100644 --- a/arch/mips/mach-octeon/bootoctlinux.c +++ b/arch/mips/mach-octeon/bootoctlinux.c @@ -10,6 +10,7 @@ #include <elf.h> #include <env.h> #include <ram.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <linux/compat.h> diff --git a/arch/mips/mach-pic32/cpu.c b/arch/mips/mach-pic32/cpu.c index 1d8c3971441..eac2fe5f8c9 100644 --- a/arch/mips/mach-pic32/cpu.c +++ b/arch/mips/mach-pic32/cpu.c @@ -9,6 +9,7 @@ #include <dm.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <mach/pic32.h> #include <mach/ddr.h> #include <dt-bindings/clock/microchip,clock.h> diff --git a/arch/nds32/lib/bootm.c b/arch/nds32/lib/bootm.c index e552a342300..b3b8bc29037 100644 --- a/arch/nds32/lib/bootm.c +++ b/arch/nds32/lib/bootm.c @@ -12,6 +12,7 @@ #include <hang.h> #include <image.h> #include <log.h> +#include <asm/global_data.h> #include <u-boot/zlib.h> #include <asm/byteorder.h> #include <asm/bootm.h> diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index e7ca9882fc5..b55c8fbc584 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -13,6 +13,7 @@ #include <init.h> #include <irq_func.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/nios2/include/asm/io.h b/arch/nios2/include/asm/io.h index 41e6bd4ee10..817cd72e00b 100644 --- a/arch/nios2/include/asm/io.h +++ b/arch/nios2/include/asm/io.h @@ -7,6 +7,8 @@ #ifndef __ASM_NIOS2_IO_H_ #define __ASM_NIOS2_IO_H_
+#include <asm/global_data.h> + static inline void sync(void) { __asm__ __volatile__ ("sync" : : : "memory"); @@ -170,5 +172,6 @@ static inline void outsl (unsigned long port, const void *src, unsigned long cou #define memcpy_toio(a, b, c) memcpy((void *)(a), (b), (c))
#include <asm-generic/io.h> +#include <asm/global_data.h>
#endif /* __ASM_NIOS2_IO_H_ */ diff --git a/arch/nios2/lib/cache.c b/arch/nios2/lib/cache.c index 0b961ac6762..5864d8f0f47 100644 --- a/arch/nios2/lib/cache.c +++ b/arch/nios2/lib/cache.c @@ -8,6 +8,7 @@ #include <common.h> #include <cpu_func.h> #include <asm/cache.h> +#include <asm/global_data.h>
diff --git a/arch/powerpc/cpu/mpc83xx/cpu.c b/arch/powerpc/cpu/mpc83xx/cpu.c index 843f2df649e..8d531898bd8 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu.c +++ b/arch/powerpc/cpu/mpc83xx/cpu.c @@ -18,6 +18,7 @@ #include <watchdog.h> #include <command.h> #include <mpc83xx.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <linux/delay.h> #include <linux/libfdt.h> diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 840f907acb8..e6dcb8a3350 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -7,6 +7,7 @@ #include <asm-offsets.h> #include <mpc83xx.h> #include <ioports.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/processor.h> #include <fsl_qe.h> diff --git a/arch/powerpc/cpu/mpc83xx/fdt.c b/arch/powerpc/cpu/mpc83xx/fdt.c index 4ea7b27ef41..3393ad562e8 100644 --- a/arch/powerpc/cpu/mpc83xx/fdt.c +++ b/arch/powerpc/cpu/mpc83xx/fdt.c @@ -8,6 +8,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/processor.h> diff --git a/arch/powerpc/cpu/mpc83xx/interrupts.c b/arch/powerpc/cpu/mpc83xx/interrupts.c index 05380674dc7..f9486678af3 100644 --- a/arch/powerpc/cpu/mpc83xx/interrupts.c +++ b/arch/powerpc/cpu/mpc83xx/interrupts.c @@ -10,6 +10,7 @@ #include <command.h> #include <irq_func.h> #include <mpc83xx.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/ptrace.h>
diff --git a/arch/powerpc/cpu/mpc83xx/pci.c b/arch/powerpc/cpu/mpc83xx/pci.c index d057cd6351c..5c289d00226 100644 --- a/arch/powerpc/cpu/mpc83xx/pci.c +++ b/arch/powerpc/cpu/mpc83xx/pci.c @@ -10,6 +10,7 @@ #include <init.h> #include <pci.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <linux/delay.h>
#if defined(CONFIG_OF_LIBFDT) diff --git a/arch/powerpc/cpu/mpc83xx/pcie.c b/arch/powerpc/cpu/mpc83xx/pcie.c index 785d4805a46..84797c871c9 100644 --- a/arch/powerpc/cpu/mpc83xx/pcie.c +++ b/arch/powerpc/cpu/mpc83xx/pcie.c @@ -10,6 +10,7 @@ #include <common.h> #include <pci.h> #include <mpc83xx.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/arch/powerpc/cpu/mpc83xx/spd_sdram.c b/arch/powerpc/cpu/mpc83xx/spd_sdram.c index aeff007fb06..a861e8dd2dd 100644 --- a/arch/powerpc/cpu/mpc83xx/spd_sdram.c +++ b/arch/powerpc/cpu/mpc83xx/spd_sdram.c @@ -24,6 +24,7 @@ #include <asm/mmu.h> #include <spd_sdram.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <linux/delay.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/powerpc/cpu/mpc83xx/speed.c b/arch/powerpc/cpu/mpc83xx/speed.c index 5c14aa1f32e..58e197f1208 100644 --- a/arch/powerpc/cpu/mpc83xx/speed.c +++ b/arch/powerpc/cpu/mpc83xx/speed.c @@ -13,6 +13,7 @@ #include <mpc83xx.h> #include <command.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/processor.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/powerpc/cpu/mpc83xx/spl_minimal.c b/arch/powerpc/cpu/mpc83xx/spl_minimal.c index 2c61f2b81db..00cb2bd044e 100644 --- a/arch/powerpc/cpu/mpc83xx/spl_minimal.c +++ b/arch/powerpc/cpu/mpc83xx/spl_minimal.c @@ -8,6 +8,7 @@ #include <clock_legacy.h> #include <mpc83xx.h> #include <time.h> +#include <asm/global_data.h>
#include "lblaw/lblaw.h" #include "elbc/elbc.h" diff --git a/arch/powerpc/cpu/mpc83xx/traps.c b/arch/powerpc/cpu/mpc83xx/traps.c index ea8bc6c1528..22e451c58d6 100644 --- a/arch/powerpc/cpu/mpc83xx/traps.c +++ b/arch/powerpc/cpu/mpc83xx/traps.c @@ -12,6 +12,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <command.h> #include <kgdb.h> diff --git a/arch/powerpc/cpu/mpc85xx/commproc.c b/arch/powerpc/cpu/mpc85xx/commproc.c index 95215a0b829..8e8427a08bb 100644 --- a/arch/powerpc/cpu/mpc85xx/commproc.c +++ b/arch/powerpc/cpu/mpc85xx/commproc.c @@ -24,6 +24,7 @@ #include <common.h> #include <asm-offsets.h> #include <asm/cpm_85xx.h> +#include <asm/global_data.h>
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 3ff1ef45658..5170610f041 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -20,6 +20,7 @@ #include <command.h> #include <fsl_esdhc.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mmu.h> #include <fsl_ifc.h> diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index c519e8bd4b0..4195ecc5c98 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -5,6 +5,7 @@
#include <common.h> #include <asm-offsets.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #include <asm/fsl_law.h> diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 0d8353ceb26..7d168e3c9a0 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -11,6 +11,7 @@ #include <env.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/processor.h> diff --git a/arch/powerpc/cpu/mpc85xx/mp.c b/arch/powerpc/cpu/mpc85xx/mp.c index 8822cf29fef..653efe09f93 100644 --- a/arch/powerpc/cpu/mpc85xx/mp.c +++ b/arch/powerpc/cpu/mpc85xx/mp.c @@ -7,6 +7,7 @@ #include <cpu_func.h> #include <env.h> #include <log.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <env.h> #include <ioports.h> diff --git a/arch/powerpc/cpu/mpc85xx/serial_scc.c b/arch/powerpc/cpu/mpc85xx/serial_scc.c index a5c418570fa..a2505d1ffc1 100644 --- a/arch/powerpc/cpu/mpc85xx/serial_scc.c +++ b/arch/powerpc/cpu/mpc85xx/serial_scc.c @@ -18,6 +18,7 @@ #include <common.h> #include <asm/cpm_85xx.h> #include <serial.h> +#include <asm/global_data.h> #include <linux/compiler.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index 773ae08dd3b..09653c70125 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -12,6 +12,7 @@ #include <common.h> #include <cpu_func.h> #include <ppc_asm.tmpl> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/processor.h> #include <asm/io.h> diff --git a/arch/powerpc/cpu/mpc85xx/tlb.c b/arch/powerpc/cpu/mpc85xx/tlb.c index 4465ae7565a..973b6fbe4b7 100644 --- a/arch/powerpc/cpu/mpc85xx/tlb.c +++ b/arch/powerpc/cpu/mpc85xx/tlb.c @@ -8,6 +8,7 @@
#include <common.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #ifdef CONFIG_ADDR_MAP diff --git a/arch/powerpc/cpu/mpc85xx/traps.c b/arch/powerpc/cpu/mpc85xx/traps.c index db6ed1fc92e..def47285ba3 100644 --- a/arch/powerpc/cpu/mpc85xx/traps.c +++ b/arch/powerpc/cpu/mpc85xx/traps.c @@ -20,6 +20,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <command.h> #include <init.h> diff --git a/arch/powerpc/cpu/mpc86xx/cpu.c b/arch/powerpc/cpu/mpc86xx/cpu.c index 9f5bce3992b..98b42bff7a3 100644 --- a/arch/powerpc/cpu/mpc86xx/cpu.c +++ b/arch/powerpc/cpu/mpc86xx/cpu.c @@ -13,6 +13,7 @@ #include <watchdog.h> #include <command.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <mpc86xx.h> #include <asm/fsl_law.h> diff --git a/arch/powerpc/cpu/mpc86xx/cpu_init.c b/arch/powerpc/cpu/mpc86xx/cpu_init.c index a17091d2ff8..73779f862c2 100644 --- a/arch/powerpc/cpu/mpc86xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc86xx/cpu_init.c @@ -14,6 +14,7 @@ #include <common.h> #include <init.h> #include <mpc86xx.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <asm/fsl_law.h> #include <asm/fsl_serdes.h> diff --git a/arch/powerpc/cpu/mpc86xx/fdt.c b/arch/powerpc/cpu/mpc86xx/fdt.c index 010b6d4fe60..1313d8adde6 100644 --- a/arch/powerpc/cpu/mpc86xx/fdt.c +++ b/arch/powerpc/cpu/mpc86xx/fdt.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/mp.h> diff --git a/arch/powerpc/cpu/mpc86xx/mp.c b/arch/powerpc/cpu/mpc86xx/mp.c index 08d11ad4f2e..e6795e06c98 100644 --- a/arch/powerpc/cpu/mpc86xx/mp.c +++ b/arch/powerpc/cpu/mpc86xx/mp.c @@ -5,6 +5,7 @@
#include <common.h> #include <cpu_func.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #include <ioports.h> diff --git a/arch/powerpc/cpu/mpc86xx/speed.c b/arch/powerpc/cpu/mpc86xx/speed.c index 50014458622..86c1709c4ca 100644 --- a/arch/powerpc/cpu/mpc86xx/speed.c +++ b/arch/powerpc/cpu/mpc86xx/speed.c @@ -11,6 +11,7 @@ #include <common.h> #include <clock_legacy.h> #include <mpc86xx.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/io.h>
diff --git a/arch/powerpc/cpu/mpc86xx/traps.c b/arch/powerpc/cpu/mpc86xx/traps.c index 3ee0ec859cf..46006ece416 100644 --- a/arch/powerpc/cpu/mpc86xx/traps.c +++ b/arch/powerpc/cpu/mpc86xx/traps.c @@ -14,6 +14,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <command.h> #include <init.h> diff --git a/arch/powerpc/cpu/mpc8xx/cpu.c b/arch/powerpc/cpu/mpc8xx/cpu.c index 7c93e35003f..893aecef21c 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu.c +++ b/arch/powerpc/cpu/mpc8xx/cpu.c @@ -27,6 +27,7 @@ #include <netdev.h> #include <asm/cache.h> #include <asm/cpm_8xx.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/io.h>
diff --git a/arch/powerpc/cpu/mpc8xx/fdt.c b/arch/powerpc/cpu/mpc8xx/fdt.c index 226e258f0ea..b4a26efe302 100644 --- a/arch/powerpc/cpu/mpc8xx/fdt.c +++ b/arch/powerpc/cpu/mpc8xx/fdt.c @@ -7,6 +7,7 @@
#include <common.h> #include <time.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h>
diff --git a/arch/powerpc/cpu/mpc8xx/immap.c b/arch/powerpc/cpu/mpc8xx/immap.c index e5b62e9f4ac..40793c26e12 100644 --- a/arch/powerpc/cpu/mpc8xx/immap.c +++ b/arch/powerpc/cpu/mpc8xx/immap.c @@ -10,6 +10,7 @@
#include <common.h> #include <command.h> +#include <asm/global_data.h>
#include <asm/immap_8xx.h> #include <asm/cpm_8xx.h> diff --git a/arch/powerpc/cpu/mpc8xx/speed.c b/arch/powerpc/cpu/mpc8xx/speed.c index 77d4f8e47f7..ad3d3f9101c 100644 --- a/arch/powerpc/cpu/mpc8xx/speed.c +++ b/arch/powerpc/cpu/mpc8xx/speed.c @@ -7,6 +7,7 @@ #include <common.h> #include <clock_legacy.h> #include <mpc8xx.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/io.h>
diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index b2d1dc5b481..eda64861ee6 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -17,6 +17,7 @@ #include <fm_eth.h> #include <netdev.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <vsc9953.h>
diff --git a/arch/powerpc/cpu/mpc8xxx/law.c b/arch/powerpc/cpu/mpc8xxx/law.c index e388386ad42..cf03f410190 100644 --- a/arch/powerpc/cpu/mpc8xxx/law.c +++ b/arch/powerpc/cpu/mpc8xxx/law.c @@ -8,6 +8,7 @@
#include <common.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/fsl_law.h> #include <asm/io.h> diff --git a/arch/powerpc/cpu/mpc8xxx/pamu_table.c b/arch/powerpc/cpu/mpc8xxx/pamu_table.c index 7dd71d2e0c4..d917e9dfb62 100644 --- a/arch/powerpc/cpu/mpc8xxx/pamu_table.c +++ b/arch/powerpc/cpu/mpc8xxx/pamu_table.c @@ -6,6 +6,7 @@ #include <common.h> #include <log.h> #include <asm/fsl_pamu.h> +#include <asm/global_data.h>
diff --git a/arch/powerpc/lib/bat_rw.c b/arch/powerpc/lib/bat_rw.c index ac56e3aeddb..24dd30615bd 100644 --- a/arch/powerpc/lib/bat_rw.c +++ b/arch/powerpc/lib/bat_rw.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #include <asm/io.h> diff --git a/arch/powerpc/lib/bdinfo.c b/arch/powerpc/lib/bdinfo.c index 36c9c99ee6f..39062804ccf 100644 --- a/arch/powerpc/lib/bdinfo.c +++ b/arch/powerpc/lib/bdinfo.c @@ -8,6 +8,7 @@
diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index b903e6ec8dc..31c17b5bb38 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -18,6 +18,7 @@ #include <command.h> #include <image.h> #include <malloc.h> +#include <asm/global_data.h> #include <u-boot/zlib.h> #include <bzlib.h> #include <asm/byteorder.h> diff --git a/arch/powerpc/lib/stack.c b/arch/powerpc/lib/stack.c index 5840fe63490..f2a4652e081 100644 --- a/arch/powerpc/lib/stack.c +++ b/arch/powerpc/lib/stack.c @@ -12,6 +12,7 @@ */ #include <common.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/arch/riscv/cpu/fu540/cache.c b/arch/riscv/cpu/fu540/cache.c index 78f5ad9d602..0fc4ef6c007 100644 --- a/arch/riscv/cpu/fu540/cache.c +++ b/arch/riscv/cpu/fu540/cache.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/arch/riscv/cpu/fu540/dram.c b/arch/riscv/cpu/fu540/dram.c index 1dc77efeca5..cec130ec8dc 100644 --- a/arch/riscv/cpu/fu540/dram.c +++ b/arch/riscv/cpu/fu540/dram.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdtdec.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/riscv/cpu/generic/dram.c b/arch/riscv/cpu/generic/dram.c index 1dc77efeca5..cec130ec8dc 100644 --- a/arch/riscv/cpu/generic/dram.c +++ b/arch/riscv/cpu/generic/dram.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdtdec.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/riscv/lib/andes_plic.c b/arch/riscv/lib/andes_plic.c index 267d6a191b2..221a5fe324e 100644 --- a/arch/riscv/lib/andes_plic.c +++ b/arch/riscv/lib/andes_plic.c @@ -9,6 +9,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/uclass-internal.h> diff --git a/arch/riscv/lib/asm-offsets.c b/arch/riscv/lib/asm-offsets.c index 7301c1b98e2..f1fe089b3d8 100644 --- a/arch/riscv/lib/asm-offsets.c +++ b/arch/riscv/lib/asm-offsets.c @@ -9,6 +9,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/kbuild.h>
int main(void) diff --git a/arch/riscv/lib/bootm.c b/arch/riscv/lib/bootm.c index c4137ded834..8dd18205403 100644 --- a/arch/riscv/lib/bootm.c +++ b/arch/riscv/lib/bootm.c @@ -13,6 +13,7 @@ #include <fdt_support.h> #include <hang.h> #include <log.h> +#include <asm/global_data.h> #include <dm/root.h> #include <image.h> #include <asm/byteorder.h> diff --git a/arch/riscv/lib/fdt_fixup.c b/arch/riscv/lib/fdt_fixup.c index d02062fd5bd..1f3f23621c3 100644 --- a/arch/riscv/lib/fdt_fixup.c +++ b/arch/riscv/lib/fdt_fixup.c @@ -10,6 +10,7 @@ #include <fdt_support.h> #include <log.h> #include <mapmem.h> +#include <asm/global_data.h>
diff --git a/arch/riscv/lib/image.c b/arch/riscv/lib/image.c index 91b7f1624e9..47f2edcf7fc 100644 --- a/arch/riscv/lib/image.c +++ b/arch/riscv/lib/image.c @@ -10,6 +10,7 @@ #include <image.h> #include <mapmem.h> #include <errno.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <linux/stddef.h>
diff --git a/arch/riscv/lib/interrupts.c b/arch/riscv/lib/interrupts.c index 35de98e8ce6..4bc81a94e23 100644 --- a/arch/riscv/lib/interrupts.c +++ b/arch/riscv/lib/interrupts.c @@ -13,6 +13,7 @@ #include <efi_loader.h> #include <hang.h> #include <irq_func.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <asm/system.h> #include <asm/encoding.h> diff --git a/arch/riscv/lib/sifive_clint.c b/arch/riscv/lib/sifive_clint.c index c8079dc510c..0911e3d399d 100644 --- a/arch/riscv/lib/sifive_clint.c +++ b/arch/riscv/lib/sifive_clint.c @@ -10,6 +10,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/smp.h> #include <linux/err.h> diff --git a/arch/riscv/lib/smp.c b/arch/riscv/lib/smp.c index 8f33ce1fe36..ba992100adf 100644 --- a/arch/riscv/lib/smp.c +++ b/arch/riscv/lib/smp.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <dm.h> #include <asm/barrier.h> +#include <asm/global_data.h> #include <asm/smp.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/riscv/lib/spl.c b/arch/riscv/lib/spl.c index 5e19d0f36ab..8baee07beac 100644 --- a/arch/riscv/lib/spl.c +++ b/arch/riscv/lib/spl.c @@ -9,6 +9,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/smp.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/sandbox/cpu/cpu.c b/arch/sandbox/cpu/cpu.c index fb857e53d59..edd48e2c1b7 100644 --- a/arch/sandbox/cpu/cpu.c +++ b/arch/sandbox/cpu/cpu.c @@ -9,6 +9,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <os.h> diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 7ab8919eb90..17a3507406c 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -10,6 +10,7 @@ #include <log.h> #include <os.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/spl.h> #include <asm/state.h>
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index c6a2bbe4689..c50d14eaf22 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -11,6 +11,7 @@ #include <cli.h> #include <sort.h> #include <asm/getopt.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/malloc.h> #include <asm/sections.h> diff --git a/arch/sh/lib/board.c b/arch/sh/lib/board.c index a6a8f07e6f2..3fa093a02ea 100644 --- a/arch/sh/lib/board.c +++ b/arch/sh/lib/board.c @@ -5,6 +5,7 @@
diff --git a/arch/x86/cpu/apollolake/cpu_spl.c b/arch/x86/cpu/apollolake/cpu_spl.c index 9f32f2e27e1..a52bc288617 100644 --- a/arch/x86/cpu/apollolake/cpu_spl.c +++ b/arch/x86/cpu/apollolake/cpu_spl.c @@ -18,6 +18,7 @@ #include <asm/cpu_common.h> #include <asm/cpu_x86.h> #include <asm/fast_spi.h> +#include <asm/global_data.h> #include <asm/intel_pinctrl.h> #include <asm/intel_regs.h> #include <asm/io.h> diff --git a/arch/x86/cpu/apollolake/fsp_s.c b/arch/x86/cpu/apollolake/fsp_s.c index 715ceab6ac7..5ca2e1074bd 100644 --- a/arch/x86/cpu/apollolake/fsp_s.c +++ b/arch/x86/cpu/apollolake/fsp_s.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <p2sb.h> #include <acpi/acpi_s3.h> +#include <asm/global_data.h> #include <asm/intel_pinctrl.h> #include <asm/io.h> #include <asm/intel_regs.h> diff --git a/arch/x86/cpu/baytrail/fsp_configs.c b/arch/x86/cpu/baytrail/fsp_configs.c index 21816ce5b88..fb3f946c45f 100644 --- a/arch/x86/cpu/baytrail/fsp_configs.c +++ b/arch/x86/cpu/baytrail/fsp_configs.c @@ -9,6 +9,7 @@ #include <fdtdec.h> #include <log.h> #include <asm/fsp1/fsp_support.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/braswell/fsp_configs.c b/arch/x86/cpu/braswell/fsp_configs.c index 9e710a940ca..243298fd571 100644 --- a/arch/x86/cpu/braswell/fsp_configs.c +++ b/arch/x86/cpu/braswell/fsp_configs.c @@ -7,6 +7,7 @@ #include <fdtdec.h> #include <log.h> #include <asm/fsp1/fsp_support.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/broadwell/cpu.c b/arch/x86/cpu/broadwell/cpu.c index b77301118cd..3832a97f2c7 100644 --- a/arch/x86/cpu/broadwell/cpu.c +++ b/arch/x86/cpu/broadwell/cpu.c @@ -13,6 +13,7 @@ #include <asm/cpu.h> #include <asm/cpu_x86.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/lpc_common.h> #include <asm/msr.h> diff --git a/arch/x86/cpu/broadwell/cpu_from_spl.c b/arch/x86/cpu/broadwell/cpu_from_spl.c index 4d4cdafa2b0..e5f62e7187c 100644 --- a/arch/x86/cpu/broadwell/cpu_from_spl.c +++ b/arch/x86/cpu/broadwell/cpu_from_spl.c @@ -11,6 +11,7 @@ #include <handoff.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mtrr.h>
int misc_init_r(void) diff --git a/arch/x86/cpu/broadwell/cpu_full.c b/arch/x86/cpu/broadwell/cpu_full.c index 706f68f63d6..4debddce8ad 100644 --- a/arch/x86/cpu/broadwell/cpu_full.c +++ b/arch/x86/cpu/broadwell/cpu_full.c @@ -13,6 +13,7 @@ #include <asm/cpu.h> #include <asm/cpu_x86.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/msr.h> #include <asm/post.h> diff --git a/arch/x86/cpu/broadwell/lpc.c b/arch/x86/cpu/broadwell/lpc.c index 5669a028cf3..d2638a4e7a6 100644 --- a/arch/x86/cpu/broadwell/lpc.c +++ b/arch/x86/cpu/broadwell/lpc.c @@ -9,6 +9,7 @@ #include <dm.h> #include <log.h> #include <pch.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/lpc_common.h> diff --git a/arch/x86/cpu/broadwell/northbridge.c b/arch/x86/cpu/broadwell/northbridge.c index 4bcab785560..141babc51c3 100644 --- a/arch/x86/cpu/broadwell/northbridge.c +++ b/arch/x86/cpu/broadwell/northbridge.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mrc_common.h> #include <asm/arch/iomap.h> diff --git a/arch/x86/cpu/broadwell/pch.c b/arch/x86/cpu/broadwell/pch.c index 9bcf211af99..f012db9debe 100644 --- a/arch/x86/cpu/broadwell/pch.c +++ b/arch/x86/cpu/broadwell/pch.c @@ -8,6 +8,7 @@ #include <log.h> #include <pch.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/i8259.h> #include <asm/intel_regs.h> diff --git a/arch/x86/cpu/broadwell/pinctrl_broadwell.c b/arch/x86/cpu/broadwell/pinctrl_broadwell.c index 0ead13af62a..85bd37101ba 100644 --- a/arch/x86/cpu/broadwell/pinctrl_broadwell.c +++ b/arch/x86/cpu/broadwell/pinctrl_broadwell.c @@ -11,6 +11,7 @@ #include <pch.h> #include <pci.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/pci.h> diff --git a/arch/x86/cpu/broadwell/sata.c b/arch/x86/cpu/broadwell/sata.c index 641da515c8f..27d6bf706e2 100644 --- a/arch/x86/cpu/broadwell/sata.c +++ b/arch/x86/cpu/broadwell/sata.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/intel_regs.h> diff --git a/arch/x86/cpu/broadwell/sdram.c b/arch/x86/cpu/broadwell/sdram.c index 72f59a0a573..c104a849a54 100644 --- a/arch/x86/cpu/broadwell/sdram.c +++ b/arch/x86/cpu/broadwell/sdram.c @@ -12,6 +12,7 @@ #include <pci.h> #include <syscon.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/lpc_common.h> #include <asm/mrccache.h> diff --git a/arch/x86/cpu/coreboot/coreboot.c b/arch/x86/cpu/coreboot/coreboot.c index 22a93254a93..15c3ad879a0 100644 --- a/arch/x86/cpu/coreboot/coreboot.c +++ b/arch/x86/cpu/coreboot/coreboot.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <init.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/msr.h> #include <asm/mtrr.h> diff --git a/arch/x86/cpu/coreboot/sdram.c b/arch/x86/cpu/coreboot/sdram.c index 27e859885e8..a2e47d196a2 100644 --- a/arch/x86/cpu/coreboot/sdram.c +++ b/arch/x86/cpu/coreboot/sdram.c @@ -9,6 +9,7 @@ #include <init.h> #include <asm/e820.h> #include <asm/arch/sysinfo.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/coreboot/tables.c b/arch/x86/cpu/coreboot/tables.c index 1594b4a8b2a..c52741ac9da 100644 --- a/arch/x86/cpu/coreboot/tables.c +++ b/arch/x86/cpu/coreboot/tables.c @@ -9,6 +9,7 @@ #include <common.h> #include <net.h> #include <asm/arch/sysinfo.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index f8692753963..eda1e4f81c7 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -35,6 +35,7 @@ #include <asm/control_regs.h> #include <asm/coreboot_tables.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/lapic.h> #include <asm/microcode.h> #include <asm/mp.h> diff --git a/arch/x86/cpu/cpu_x86.c b/arch/x86/cpu/cpu_x86.c index 7e83051646c..dc7c8116d04 100644 --- a/arch/x86/cpu/cpu_x86.c +++ b/arch/x86/cpu/cpu_x86.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <asm/cpu.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/efi/payload.c b/arch/x86/cpu/efi/payload.c index 71619f6f01b..9a73b768e9b 100644 --- a/arch/x86/cpu/efi/payload.c +++ b/arch/x86/cpu/efi/payload.c @@ -13,6 +13,7 @@ #include <usb.h> #include <asm/bootparam.h> #include <asm/e820.h> +#include <asm/global_data.h> #include <asm/post.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/x86/cpu/efi/sdram.c b/arch/x86/cpu/efi/sdram.c index 3143c079adb..af65982fd0c 100644 --- a/arch/x86/cpu/efi/sdram.c +++ b/arch/x86/cpu/efi/sdram.c @@ -6,6 +6,7 @@ #include <common.h> #include <efi.h> #include <init.h> +#include <asm/global_data.h> #include <asm/u-boot-x86.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/x86/cpu/i386/cpu.c b/arch/x86/cpu/i386/cpu.c index 7517b756f43..7ba7c94506a 100644 --- a/arch/x86/cpu/i386/cpu.c +++ b/arch/x86/cpu/i386/cpu.c @@ -27,6 +27,7 @@ #include <asm/control_regs.h> #include <asm/coreboot_tables.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/mp.h> #include <asm/msr.h> #include <asm/mtrr.h> diff --git a/arch/x86/cpu/i386/interrupt.c b/arch/x86/cpu/i386/interrupt.c index c0c4bc95fd9..67a72146de8 100644 --- a/arch/x86/cpu/i386/interrupt.c +++ b/arch/x86/cpu/i386/interrupt.c @@ -18,6 +18,7 @@ #include <irq.h> #include <irq_func.h> #include <asm/control_regs.h> +#include <asm/global_data.h> #include <asm/i8259.h> #include <asm/interrupt.h> #include <asm/io.h> diff --git a/arch/x86/cpu/intel_common/acpi.c b/arch/x86/cpu/intel_common/acpi.c index 4496bbfd999..7899b17d775 100644 --- a/arch/x86/cpu/intel_common/acpi.c +++ b/arch/x86/cpu/intel_common/acpi.c @@ -17,6 +17,7 @@ #include <asm/acpi_table.h> #include <asm/cpu.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_acpi.h> #include <asm/ioapic.h> #include <asm/mpspec.h> diff --git a/arch/x86/cpu/intel_common/cpu.c b/arch/x86/cpu/intel_common/cpu.c index 39aa0f63c65..5dc0bba9cec 100644 --- a/arch/x86/cpu/intel_common/cpu.c +++ b/arch/x86/cpu/intel_common/cpu.c @@ -15,6 +15,7 @@ #include <acpi/acpigen.h> #include <asm/cpu.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/lapic.h> #include <asm/lpc_common.h> diff --git a/arch/x86/cpu/intel_common/cpu_from_spl.c b/arch/x86/cpu/intel_common/cpu_from_spl.c index e4157c5734c..1c0dcedb582 100644 --- a/arch/x86/cpu/intel_common/cpu_from_spl.c +++ b/arch/x86/cpu/intel_common/cpu_from_spl.c @@ -9,6 +9,7 @@ #include <handoff.h> #include <init.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/lapic.h> #include <asm/lpc_common.h> diff --git a/arch/x86/cpu/intel_common/itss.c b/arch/x86/cpu/intel_common/itss.c index fe84ebe29f7..2f47bfe20e7 100644 --- a/arch/x86/cpu/intel_common/itss.c +++ b/arch/x86/cpu/intel_common/itss.c @@ -17,6 +17,7 @@ #include <malloc.h> #include <p2sb.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/itss.h>
struct itss_platdata { diff --git a/arch/x86/cpu/intel_common/lpc.c b/arch/x86/cpu/intel_common/lpc.c index 3420f03ccaa..23befbef15f 100644 --- a/arch/x86/cpu/intel_common/lpc.c +++ b/arch/x86/cpu/intel_common/lpc.c @@ -9,6 +9,7 @@ #include <fdtdec.h> #include <pch.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/lpc_common.h> diff --git a/arch/x86/cpu/intel_common/microcode.c b/arch/x86/cpu/intel_common/microcode.c index 0355d3c1da6..4d8e1d21083 100644 --- a/arch/x86/cpu/intel_common/microcode.c +++ b/arch/x86/cpu/intel_common/microcode.c @@ -10,6 +10,7 @@ #include <errno.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <asm/cpu.h> #include <asm/microcode.h> diff --git a/arch/x86/cpu/intel_common/mrc.c b/arch/x86/cpu/intel_common/mrc.c index 73bfd123321..a97b0b7ceb4 100644 --- a/arch/x86/cpu/intel_common/mrc.c +++ b/arch/x86/cpu/intel_common/mrc.c @@ -9,6 +9,7 @@ #include <log.h> #include <syscon.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/intel_regs.h> #include <asm/mrc_common.h> diff --git a/arch/x86/cpu/irq.c b/arch/x86/cpu/irq.c index 836a0e8b86e..001c8913fad 100644 --- a/arch/x86/cpu/irq.c +++ b/arch/x86/cpu/irq.c @@ -10,6 +10,7 @@ #include <irq.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/irq.h> #include <asm/pci.h> diff --git a/arch/x86/cpu/ivybridge/bd82x6x.c b/arch/x86/cpu/ivybridge/bd82x6x.c index 5448f064fcb..0540b021618 100644 --- a/arch/x86/cpu/ivybridge/bd82x6x.c +++ b/arch/x86/cpu/ivybridge/bd82x6x.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <pch.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/lapic.h> diff --git a/arch/x86/cpu/ivybridge/cpu.c b/arch/x86/cpu/ivybridge/cpu.c index cb6eded9c98..bddba3eddec 100644 --- a/arch/x86/cpu/ivybridge/cpu.c +++ b/arch/x86/cpu/ivybridge/cpu.c @@ -20,6 +20,7 @@ #include <pch.h> #include <asm/cpu.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/lapic.h> diff --git a/arch/x86/cpu/ivybridge/fsp_configs.c b/arch/x86/cpu/ivybridge/fsp_configs.c index 41d7d2a2b42..3c4ea6c267f 100644 --- a/arch/x86/cpu/ivybridge/fsp_configs.c +++ b/arch/x86/cpu/ivybridge/fsp_configs.c @@ -7,6 +7,7 @@ #include <fdtdec.h> #include <log.h> #include <asm/fsp1/fsp_support.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/ivybridge/lpc.c b/arch/x86/cpu/ivybridge/lpc.c index 85fd2a965ab..f931d2be1b5 100644 --- a/arch/x86/cpu/ivybridge/lpc.c +++ b/arch/x86/cpu/ivybridge/lpc.c @@ -12,6 +12,7 @@ #include <log.h> #include <rtc.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/interrupt.h> #include <asm/io.h> diff --git a/arch/x86/cpu/ivybridge/model_206ax.c b/arch/x86/cpu/ivybridge/model_206ax.c index 55f7cc2b2ec..788e589b26d 100644 --- a/arch/x86/cpu/ivybridge/model_206ax.c +++ b/arch/x86/cpu/ivybridge/model_206ax.c @@ -15,6 +15,7 @@ #include <asm/cpu.h> #include <asm/cpu_common.h> #include <asm/cpu_x86.h> +#include <asm/global_data.h> #include <asm/msr.h> #include <asm/msr-index.h> #include <asm/mtrr.h> diff --git a/arch/x86/cpu/ivybridge/northbridge.c b/arch/x86/cpu/ivybridge/northbridge.c index b713fcb1cfe..994f8a4ff6a 100644 --- a/arch/x86/cpu/ivybridge/northbridge.c +++ b/arch/x86/cpu/ivybridge/northbridge.c @@ -9,6 +9,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <asm/msr.h> #include <asm/cpu.h> #include <asm/intel_regs.h> diff --git a/arch/x86/cpu/ivybridge/sata.c b/arch/x86/cpu/ivybridge/sata.c index 025b20be31b..f47ecdffae7 100644 --- a/arch/x86/cpu/ivybridge/sata.c +++ b/arch/x86/cpu/ivybridge/sata.c @@ -9,6 +9,7 @@ #include <dm.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/pch_common.h> #include <asm/pci.h> diff --git a/arch/x86/cpu/ivybridge/sdram_nop.c b/arch/x86/cpu/ivybridge/sdram_nop.c index 54e6acf2621..51dfe23f94d 100644 --- a/arch/x86/cpu/ivybridge/sdram_nop.c +++ b/arch/x86/cpu/ivybridge/sdram_nop.c @@ -5,6 +5,7 @@
diff --git a/arch/x86/cpu/mp_init.c b/arch/x86/cpu/mp_init.c index d2f1ee38cf0..03bd71c261a 100644 --- a/arch/x86/cpu/mp_init.c +++ b/arch/x86/cpu/mp_init.c @@ -14,6 +14,7 @@ #include <qfw.h> #include <asm/atomic.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/interrupt.h> #include <asm/io.h> #include <asm/lapic.h> diff --git a/arch/x86/cpu/mtrr.c b/arch/x86/cpu/mtrr.c index 5180eb06fcd..cab858bc302 100644 --- a/arch/x86/cpu/mtrr.c +++ b/arch/x86/cpu/mtrr.c @@ -21,6 +21,7 @@ #include <log.h> #include <sort.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mp.h> #include <asm/msr.h> diff --git a/arch/x86/cpu/qemu/dram.c b/arch/x86/cpu/qemu/dram.c index 19d92f27d80..c1745501294 100644 --- a/arch/x86/cpu/qemu/dram.c +++ b/arch/x86/cpu/qemu/dram.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/post.h> #include <asm/arch/qemu.h>
diff --git a/arch/x86/cpu/qemu/e820.c b/arch/x86/cpu/qemu/e820.c index 0da36bddeae..19e54c5202a 100644 --- a/arch/x86/cpu/qemu/e820.c +++ b/arch/x86/cpu/qemu/e820.c @@ -11,6 +11,7 @@ #include <malloc.h> #include <asm/e820.h> #include <asm/arch/qemu.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/quark/acpi.c b/arch/x86/cpu/quark/acpi.c index b0406a04e92..82b776ff65f 100644 --- a/arch/x86/cpu/quark/acpi.c +++ b/arch/x86/cpu/quark/acpi.c @@ -5,6 +5,7 @@
#include <common.h> #include <acpi/acpi_table.h> +#include <asm/processor.h> #include <asm/tables.h> #include <asm/arch/global_nvs.h> #include <asm/arch/iomap.h> diff --git a/arch/x86/cpu/quark/dram.c b/arch/x86/cpu/quark/dram.c index 72937139ed7..2287dce12b5 100644 --- a/arch/x86/cpu/quark/dram.c +++ b/arch/x86/cpu/quark/dram.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/mrccache.h> #include <asm/mtrr.h> #include <asm/post.h> diff --git a/arch/x86/cpu/slimbootloader/sdram.c b/arch/x86/cpu/slimbootloader/sdram.c index 33e91fb6366..36d0d4da553 100644 --- a/arch/x86/cpu/slimbootloader/sdram.c +++ b/arch/x86/cpu/slimbootloader/sdram.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/e820.h> #include <asm/arch/slimbootloader.h> diff --git a/arch/x86/cpu/slimbootloader/serial.c b/arch/x86/cpu/slimbootloader/serial.c index 9813f7977b5..8b84565ce62 100644 --- a/arch/x86/cpu/slimbootloader/serial.c +++ b/arch/x86/cpu/slimbootloader/serial.c @@ -9,6 +9,7 @@ #include <ns16550.h> #include <serial.h> #include <asm/arch/slimbootloader.h> +#include <asm/global_data.h>
/** * The serial port info hob is generated by Slim Bootloader, so eligible for diff --git a/arch/x86/cpu/slimbootloader/slimbootloader.c b/arch/x86/cpu/slimbootloader/slimbootloader.c index f61fe814e94..ec5b87cfd63 100644 --- a/arch/x86/cpu/slimbootloader/slimbootloader.c +++ b/arch/x86/cpu/slimbootloader/slimbootloader.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <asm/arch/slimbootloader.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/turbo.c b/arch/x86/cpu/turbo.c index f8d85d5a339..cbb10a00320 100644 --- a/arch/x86/cpu/turbo.c +++ b/arch/x86/cpu/turbo.c @@ -8,6 +8,7 @@ #include <common.h> #include <log.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/msr.h> #include <asm/processor.h> #include <asm/turbo.h> diff --git a/arch/x86/cpu/x86_64/cpu.c b/arch/x86/cpu/x86_64/cpu.c index 90a766c3c57..1d6376e4cd3 100644 --- a/arch/x86/cpu/x86_64/cpu.c +++ b/arch/x86/cpu/x86_64/cpu.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h>
/* * Global declaration of gd. diff --git a/arch/x86/include/asm/cpu_common.h b/arch/x86/include/asm/cpu_common.h index 48f56c2aad9..99387bcbd9f 100644 --- a/arch/x86/include/asm/cpu_common.h +++ b/arch/x86/include/asm/cpu_common.h @@ -14,6 +14,7 @@ enum { };
struct cpu_info; +struct udevice;
/** * cpu_common_init() - Set up common CPU init diff --git a/arch/x86/include/asm/fast_spi.h b/arch/x86/include/asm/fast_spi.h index 7a81d4f05c6..82e3d8f63ef 100644 --- a/arch/x86/include/asm/fast_spi.h +++ b/arch/x86/include/asm/fast_spi.h @@ -6,8 +6,10 @@ #ifndef ASM_FAST_SPI_H #define ASM_FAST_SPI_H
-/* Register offsets from the MMIO region base (PCI_BASE_ADDRESS_0) */ +#include <pci.h> #include <linux/bitops.h> + +/* Register offsets from the MMIO region base (PCI_BASE_ADDRESS_0) */ struct fast_spi_regs { u32 bfp; u32 hsfsts_ctl; diff --git a/arch/x86/include/asm/io.h b/arch/x86/include/asm/io.h index cf6c33cbe3a..83dc09757e0 100644 --- a/arch/x86/include/asm/io.h +++ b/arch/x86/include/asm/io.h @@ -7,7 +7,7 @@ #ifndef _ASM_IO_H #define _ASM_IO_H
-#include <linux/compiler.h> +#include <compiler.h>
/* * This file contains the definitions for the x86 IO instructions diff --git a/arch/x86/include/asm/mp.h b/arch/x86/include/asm/mp.h index 5f9b8c65643..25edabbdd39 100644 --- a/arch/x86/include/asm/mp.h +++ b/arch/x86/include/asm/mp.h @@ -11,6 +11,8 @@ #include <asm/atomic.h> #include <asm/cache.h>
+struct udevice; + enum { /* Indicates that the function should run on all CPUs */ MP_SELECT_ALL = -1, diff --git a/arch/x86/include/asm/mrccache.h b/arch/x86/include/asm/mrccache.h index b60d1171f77..8b104a2f0b8 100644 --- a/arch/x86/include/asm/mrccache.h +++ b/arch/x86/include/asm/mrccache.h @@ -7,6 +7,8 @@ #ifndef _ASM_MRCCACHE_H #define _ASM_MRCCACHE_H
+#include <compiler.h> + #define MRC_DATA_ALIGN 0x100 #define MRC_DATA_SIGNATURE (('M' << 0) | ('R' << 8) | \ ('C' << 16) | ('D'<<24)) diff --git a/arch/x86/include/asm/u-boot-x86.h b/arch/x86/include/asm/u-boot-x86.h index d732661f6d4..a518977d633 100644 --- a/arch/x86/include/asm/u-boot-x86.h +++ b/arch/x86/include/asm/u-boot-x86.h @@ -7,6 +7,7 @@ #ifndef _U_BOOT_I386_H_ #define _U_BOOT_I386_H_ 1
+#include <asm/global_data.h> struct global_data;
extern char gdt_rom[]; diff --git a/arch/x86/lib/acpi_s3.c b/arch/x86/lib/acpi_s3.c index 52410a515df..2c70acbe7b0 100644 --- a/arch/x86/lib/acpi_s3.c +++ b/arch/x86/lib/acpi_s3.c @@ -7,6 +7,7 @@ #include <acpi/acpi_s3.h> #include <acpi/acpi_table.h> #include <asm/acpi.h> +#include <asm/global_data.h> #include <asm/post.h> #include <linux/linkage.h>
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 6d405b09fde..bd93ff2f405 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -13,6 +13,7 @@ #include <cpu.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/uclass-internal.h> #include <mapmem.h> #include <serial.h> diff --git a/arch/x86/lib/asm-offsets.c b/arch/x86/lib/asm-offsets.c index 47b38cd9e78..8df67db65c3 100644 --- a/arch/x86/lib/asm-offsets.c +++ b/arch/x86/lib/asm-offsets.c @@ -12,6 +12,7 @@ */
int main(void) diff --git a/arch/x86/lib/bios.c b/arch/x86/lib/bios.c index 3ab432e2623..fbdc3b04e36 100644 --- a/arch/x86/lib/bios.c +++ b/arch/x86/lib/bios.c @@ -6,6 +6,7 @@ * Copyright (C) 2009-2010 coresystems GmbH */ #include <common.h> +#include <compiler.h> #include <bios_emul.h> #include <irq_func.h> #include <log.h> diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index da6b8ce1ec1..aa5f0bf6b72 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -12,6 +12,7 @@ #include <command.h> #include <hang.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/root.h> #include <errno.h> diff --git a/arch/x86/lib/cmd_boot.c b/arch/x86/lib/cmd_boot.c index baaf3d13ad4..4facbe5f32f 100644 --- a/arch/x86/lib/cmd_boot.c +++ b/arch/x86/lib/cmd_boot.c @@ -17,6 +17,7 @@ #include <common.h> #include <command.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/u-boot-x86.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/x86/lib/coreboot_table.c b/arch/x86/lib/coreboot_table.c index 6cd32443012..6eab0452fda 100644 --- a/arch/x86/lib/coreboot_table.c +++ b/arch/x86/lib/coreboot_table.c @@ -10,6 +10,7 @@ #include <acpi/acpi_s3.h> #include <asm/coreboot_tables.h> #include <asm/e820.h> +#include <asm/global_data.h>
diff --git a/arch/x86/lib/e820.c b/arch/x86/lib/e820.c index 1f20c5c8c6b..12fcff12380 100644 --- a/arch/x86/lib/e820.c +++ b/arch/x86/lib/e820.c @@ -6,6 +6,7 @@ #include <common.h> #include <efi_loader.h> #include <asm/e820.h> +#include <asm/global_data.h>
diff --git a/arch/x86/lib/fsp/fsp_common.c b/arch/x86/lib/fsp/fsp_common.c index 4061fa244c4..6365b0a50a7 100644 --- a/arch/x86/lib/fsp/fsp_common.c +++ b/arch/x86/lib/fsp/fsp_common.c @@ -13,6 +13,7 @@ #include <acpi/acpi_s3.h> #include <asm/cmos_layout.h> #include <asm/early_cmos.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mrccache.h> #include <asm/post.h> diff --git a/arch/x86/lib/fsp/fsp_dram.c b/arch/x86/lib/fsp/fsp_dram.c index a76497d4e01..6819213dc61 100644 --- a/arch/x86/lib/fsp/fsp_dram.c +++ b/arch/x86/lib/fsp/fsp_dram.c @@ -9,6 +9,7 @@ #include <log.h> #include <asm/fsp/fsp_support.h> #include <asm/e820.h> +#include <asm/global_data.h> #include <asm/mrccache.h> #include <asm/mtrr.h> #include <asm/post.h> diff --git a/arch/x86/lib/fsp/fsp_graphics.c b/arch/x86/lib/fsp/fsp_graphics.c index 858d7942fed..b37b2c84f51 100644 --- a/arch/x86/lib/fsp/fsp_graphics.c +++ b/arch/x86/lib/fsp/fsp_graphics.c @@ -13,6 +13,7 @@ #include <video.h> #include <acpi/acpi_table.h> #include <asm/fsp/fsp_support.h> +#include <asm/global_data.h> #include <asm/intel_opregion.h> #include <asm/mtrr.h> #include <dm/acpi.h> diff --git a/arch/x86/lib/fsp1/fsp_common.c b/arch/x86/lib/fsp1/fsp_common.c index da351cf097c..20926171822 100644 --- a/arch/x86/lib/fsp1/fsp_common.c +++ b/arch/x86/lib/fsp1/fsp_common.c @@ -13,6 +13,7 @@ #include <acpi/acpi_s3.h> #include <asm/cmos_layout.h> #include <asm/early_cmos.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mrccache.h> #include <asm/post.h> diff --git a/arch/x86/lib/fsp1/fsp_dram.c b/arch/x86/lib/fsp1/fsp_dram.c index e3f9e30f6a6..cfd9b9f48c3 100644 --- a/arch/x86/lib/fsp1/fsp_dram.c +++ b/arch/x86/lib/fsp1/fsp_dram.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <asm/fsp/fsp_support.h> +#include <asm/global_data.h>
int dram_init(void) { diff --git a/arch/x86/lib/fsp2/fsp_dram.c b/arch/x86/lib/fsp2/fsp_dram.c index c9f6402e6a4..c31e2a11b7a 100644 --- a/arch/x86/lib/fsp2/fsp_dram.c +++ b/arch/x86/lib/fsp2/fsp_dram.c @@ -14,6 +14,7 @@ #include <asm/fsp/fsp_support.h> #include <asm/fsp2/fsp_api.h> #include <asm/fsp2/fsp_internal.h> +#include <asm/global_data.h> #include <linux/sizes.h>
int dram_init(void) diff --git a/arch/x86/lib/fsp2/fsp_meminit.c b/arch/x86/lib/fsp2/fsp_meminit.c index ce0b0aff76b..022e2cb64e5 100644 --- a/arch/x86/lib/fsp2/fsp_meminit.c +++ b/arch/x86/lib/fsp2/fsp_meminit.c @@ -11,6 +11,7 @@ #include <bootstage.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mrccache.h> #include <asm/fsp/fsp_infoheader.h> #include <asm/fsp2/fsp_api.h> diff --git a/arch/x86/lib/fsp2/fsp_silicon_init.c b/arch/x86/lib/fsp2/fsp_silicon_init.c index ead3493de82..a96d2b183f6 100644 --- a/arch/x86/lib/fsp2/fsp_silicon_init.c +++ b/arch/x86/lib/fsp2/fsp_silicon_init.c @@ -17,6 +17,7 @@ #include <asm/arch/fsp/fsp_s_upd.h> #include <asm/fsp/fsp_infoheader.h> #include <asm/fsp2/fsp_internal.h> +#include <asm/global_data.h>
int fsp_silicon_init(bool s3wake, bool use_spi_flash) { diff --git a/arch/x86/lib/fsp2/fsp_support.c b/arch/x86/lib/fsp2/fsp_support.c index f220ef498b0..503f97d5f33 100644 --- a/arch/x86/lib/fsp2/fsp_support.c +++ b/arch/x86/lib/fsp2/fsp_support.c @@ -10,6 +10,7 @@ #include <spi_flash.h> #include <asm/fsp/fsp_support.h> #include <asm/fsp2/fsp_internal.h> +#include <asm/global_data.h>
/* The amount of the FSP header to probe to obtain what we need */ #define PROBE_BUF_SIZE 0x180 diff --git a/arch/x86/lib/init_helpers.c b/arch/x86/lib/init_helpers.c index d906b528b35..066dc404a2d 100644 --- a/arch/x86/lib/init_helpers.c +++ b/arch/x86/lib/init_helpers.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/mtrr.h>
diff --git a/arch/x86/lib/mpspec.c b/arch/x86/lib/mpspec.c index 1c49c41b310..8021d8f75a4 100644 --- a/arch/x86/lib/mpspec.c +++ b/arch/x86/lib/mpspec.c @@ -12,6 +12,7 @@ #include <fdtdec.h> #include <log.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/irq.h> #include <asm/ioapic.h> #include <asm/lapic.h> diff --git a/arch/x86/lib/mrccache.c b/arch/x86/lib/mrccache.c index f181e8100cb..b5269156801 100644 --- a/arch/x86/lib/mrccache.c +++ b/arch/x86/lib/mrccache.c @@ -15,6 +15,7 @@ #include <net.h> #include <spi.h> #include <spi_flash.h> +#include <asm/global_data.h> #include <asm/mrccache.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> diff --git a/arch/x86/lib/physmem.c b/arch/x86/lib/physmem.c index 4578046169a..c11101b44ec 100644 --- a/arch/x86/lib/physmem.c +++ b/arch/x86/lib/physmem.c @@ -12,6 +12,7 @@ #include <log.h> #include <physmem.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <linux/compiler.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/x86/lib/pinctrl_ich6.c b/arch/x86/lib/pinctrl_ich6.c index 482599478b8..fd5e311b291 100644 --- a/arch/x86/lib/pinctrl_ich6.c +++ b/arch/x86/lib/pinctrl_ich6.c @@ -11,6 +11,7 @@ #include <pch.h> #include <pci.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/pci.h> diff --git a/arch/x86/lib/pirq_routing.c b/arch/x86/lib/pirq_routing.c index eb6a7d96de1..caeaec9287f 100644 --- a/arch/x86/lib/pirq_routing.c +++ b/arch/x86/lib/pirq_routing.c @@ -8,6 +8,7 @@ #include <common.h> #include <log.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/pci.h> #include <asm/pirq_routing.h>
diff --git a/arch/x86/lib/relocate.c b/arch/x86/lib/relocate.c index ecbd0927e07..6fe51516477 100644 --- a/arch/x86/lib/relocate.c +++ b/arch/x86/lib/relocate.c @@ -17,6 +17,7 @@ #include <common.h> #include <log.h> #include <relocate.h> +#include <asm/global_data.h> #include <asm/u-boot-x86.h> #include <asm/sections.h> #include <elf.h> diff --git a/arch/x86/lib/spl.c b/arch/x86/lib/spl.c index cf22fa2d7b5..a220c71b576 100644 --- a/arch/x86/lib/spl.c +++ b/arch/x86/lib/spl.c @@ -17,6 +17,7 @@ #include <syscon.h> #include <asm/cpu.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/mrccache.h> #include <asm/mtrr.h> #include <asm/pci.h> diff --git a/arch/x86/lib/tables.c b/arch/x86/lib/tables.c index 7bad5dd3032..730552a0ea5 100644 --- a/arch/x86/lib/tables.c +++ b/arch/x86/lib/tables.c @@ -8,6 +8,7 @@ #include <malloc.h> #include <smbios.h> #include <acpi/acpi_table.h> +#include <asm/global_data.h> #include <asm/sfi.h> #include <asm/mpspec.h> #include <asm/tables.h> diff --git a/arch/x86/lib/tpl.c b/arch/x86/lib/tpl.c index 6f7eb43a172..789472bc9a2 100644 --- a/arch/x86/lib/tpl.c +++ b/arch/x86/lib/tpl.c @@ -12,6 +12,7 @@ #include <log.h> #include <spl.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/mtrr.h> #include <asm/processor.h> #include <asm-generic/sections.h> diff --git a/arch/xtensa/lib/bootm.c b/arch/xtensa/lib/bootm.c index 0e564507f94..bb1e2886abc 100644 --- a/arch/xtensa/lib/bootm.c +++ b/arch/xtensa/lib/bootm.c @@ -9,6 +9,7 @@ #include <command.h> #include <cpu_func.h> #include <env.h> +#include <asm/global_data.h> #include <u-boot/zlib.h> #include <asm/byteorder.h> #include <asm/addrspace.h> diff --git a/board/AndesTech/adp-ae3xx/adp-ae3xx.c b/board/AndesTech/adp-ae3xx/adp-ae3xx.c index b52cbd4d861..3c4a27d63f6 100644 --- a/board/AndesTech/adp-ae3xx/adp-ae3xx.c +++ b/board/AndesTech/adp-ae3xx/adp-ae3xx.c @@ -7,6 +7,7 @@
#include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <common.h> #include <flash.h> diff --git a/board/AndesTech/adp-ag101p/adp-ag101p.c b/board/AndesTech/adp-ag101p/adp-ag101p.c index 3dd880f3d6c..8848b7f9738 100644 --- a/board/AndesTech/adp-ag101p/adp-ag101p.c +++ b/board/AndesTech/adp-ag101p/adp-ag101p.c @@ -12,6 +12,7 @@ #if defined(CONFIG_FTMAC100) && !defined(CONFIG_DM_ETH) #include <netdev.h> #endif +#include <asm/global_data.h> #include <linux/io.h> #include <asm/io.h> #include <asm/mach-types.h> diff --git a/board/AndesTech/ax25-ae350/ax25-ae350.c b/board/AndesTech/ax25-ae350/ax25-ae350.c index 59a43e4dcc4..d781038de28 100644 --- a/board/AndesTech/ax25-ae350/ax25-ae350.c +++ b/board/AndesTech/ax25-ae350/ax25-ae350.c @@ -12,6 +12,7 @@ #if defined(CONFIG_FTMAC100) && !defined(CONFIG_DM_ETH) #include <netdev.h> #endif +#include <asm/global_data.h> #include <linux/io.h> #include <faraday/ftsmc020.h> #include <fdtdec.h> diff --git a/board/Arcturus/ucp1020/spl.c b/board/Arcturus/ucp1020/spl.c index 0fd9532d748..cf42f52b36c 100644 --- a/board/Arcturus/ucp1020/spl.c +++ b/board/Arcturus/ucp1020/spl.c @@ -20,6 +20,7 @@ #include <i2c.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h>
diff --git a/board/BuR/brppt1/board.c b/board/BuR/brppt1/board.c index 8aa03eac283..7df37e4e66a 100644 --- a/board/BuR/brppt1/board.c +++ b/board/BuR/brppt1/board.c @@ -23,6 +23,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/BuR/brppt2/board.c b/board/BuR/brppt2/board.c index f156b552a76..e6eb403fc3d 100644 --- a/board/BuR/brppt2/board.c +++ b/board/BuR/brppt2/board.c @@ -21,6 +21,7 @@ # include <asm/arch/mx6-ddr.h> #endif #include <asm/arch/clock.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h>
diff --git a/board/BuR/brsmarc1/board.c b/board/BuR/brsmarc1/board.c index 5b9108a89f9..738a5d2ff94 100644 --- a/board/BuR/brsmarc1/board.c +++ b/board/BuR/brsmarc1/board.c @@ -19,6 +19,7 @@ #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/emif.h> diff --git a/board/BuR/brxre1/board.c b/board/BuR/brxre1/board.c index 5d57e19fde0..ef692b006d5 100644 --- a/board/BuR/brxre1/board.c +++ b/board/BuR/brxre1/board.c @@ -21,6 +21,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/BuR/common/common.c b/board/BuR/common/common.c index 0a5104a48f9..d2d4ea5835b 100644 --- a/board/BuR/common/common.c +++ b/board/BuR/common/common.c @@ -15,6 +15,7 @@ #include <fdtdec.h> #include <i2c.h> #include <lcd.h> +#include <asm/global_data.h> #include <linux/delay.h> #include "bur_common.h"
diff --git a/board/BuS/eb_cpu5282/eb_cpu5282.c b/board/BuS/eb_cpu5282/eb_cpu5282.c index f5e4de3c418..153ed0e963b 100644 --- a/board/BuS/eb_cpu5282/eb_cpu5282.c +++ b/board/BuS/eb_cpu5282/eb_cpu5282.c @@ -9,6 +9,7 @@
#include <common.h> #include <command.h> +#include <asm/global_data.h> #include "asm/m5282.h" #include <bmp_layout.h> #include <env.h> diff --git a/board/CZ.NIC/turris_mox/turris_mox.c b/board/CZ.NIC/turris_mox/turris_mox.c index 679f3eb7014..486680a49e8 100644 --- a/board/CZ.NIC/turris_mox/turris_mox.c +++ b/board/CZ.NIC/turris_mox/turris_mox.c @@ -7,6 +7,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <clk.h> diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 2da878d3648..0353d58a361 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -15,6 +15,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/CarMediaLab/flea3/flea3.c b/board/CarMediaLab/flea3/flea3.c index 11fcecb94e5..12c5ac331f9 100644 --- a/board/CarMediaLab/flea3/flea3.c +++ b/board/CarMediaLab/flea3/flea3.c @@ -9,6 +9,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <env.h> #include <linux/delay.h> diff --git a/board/LaCie/edminiv2/edminiv2.c b/board/LaCie/edminiv2/edminiv2.c index b5ffe8162f3..9c066a283c9 100644 --- a/board/LaCie/edminiv2/edminiv2.c +++ b/board/LaCie/edminiv2/edminiv2.c @@ -11,6 +11,7 @@ #include <miiphy.h> #include <net.h> #include <asm/arch/orion5x.h> +#include <asm/global_data.h> #include "../common/common.h" #include <spl.h> #include <ns16550.h> diff --git a/board/LaCie/net2big_v2/net2big_v2.c b/board/LaCie/net2big_v2/net2big_v2.c index e94c9a6dce9..695d6f6ed47 100644 --- a/board/LaCie/net2big_v2/net2big_v2.c +++ b/board/LaCie/net2big_v2/net2big_v2.c @@ -14,6 +14,7 @@ #include <i2c.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/LaCie/netspace_v2/netspace_v2.c b/board/LaCie/netspace_v2/netspace_v2.c index 33246b20152..730eab7e703 100644 --- a/board/LaCie/netspace_v2/netspace_v2.c +++ b/board/LaCie/netspace_v2/netspace_v2.c @@ -13,6 +13,7 @@ #include <env.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/aspenite/aspenite.c b/board/Marvell/aspenite/aspenite.c index c1406d7489c..1f9389c0a7a 100644 --- a/board/Marvell/aspenite/aspenite.c +++ b/board/Marvell/aspenite/aspenite.c @@ -9,6 +9,7 @@ #include <common.h> #include <init.h> #include <mvmfp.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/mfp.h> diff --git a/board/Marvell/db-88f6281-bp/db-88f6281-bp.c b/board/Marvell/db-88f6281-bp/db-88f6281-bp.c index 62027bd6385..08f79d4b532 100644 --- a/board/Marvell/db-88f6281-bp/db-88f6281-bp.c +++ b/board/Marvell/db-88f6281-bp/db-88f6281-bp.c @@ -3,6 +3,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <miiphy.h> diff --git a/board/Marvell/db-88f6720/db-88f6720.c b/board/Marvell/db-88f6720/db-88f6720.c index 271535b7637..26c30647fbb 100644 --- a/board/Marvell/db-88f6720/db-88f6720.c +++ b/board/Marvell/db-88f6720/db-88f6720.c @@ -8,6 +8,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/db-88f6820-amc/db-88f6820-amc.c b/board/Marvell/db-88f6820-amc/db-88f6820-amc.c index 9cd9ea2c068..163a1b3de9d 100644 --- a/board/Marvell/db-88f6820-amc/db-88f6820-amc.c +++ b/board/Marvell/db-88f6820-amc/db-88f6820-amc.c @@ -9,6 +9,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/db-88f6820-gp/db-88f6820-gp.c b/board/Marvell/db-88f6820-gp/db-88f6820-gp.c index 2bdd55329d0..06307e582ce 100644 --- a/board/Marvell/db-88f6820-gp/db-88f6820-gp.c +++ b/board/Marvell/db-88f6820-gp/db-88f6820-gp.c @@ -9,6 +9,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c b/board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c index 8d1dbebdb7a..9e1fdecfca4 100644 --- a/board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c +++ b/board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c @@ -8,6 +8,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c b/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c index 5f12a27002f..0abdca1cd21 100644 --- a/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c +++ b/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c @@ -6,6 +6,7 @@ #include <common.h> #include <i2c.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/bitops.h> #include <linux/mbus.h> diff --git a/board/Marvell/dreamplug/dreamplug.c b/board/Marvell/dreamplug/dreamplug.c index 7d188c32795..e1c64b52246 100644 --- a/board/Marvell/dreamplug/dreamplug.c +++ b/board/Marvell/dreamplug/dreamplug.c @@ -15,6 +15,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> +#include <asm/global_data.h> #include "dreamplug.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/Marvell/gplugd/gplugd.c b/board/Marvell/gplugd/gplugd.c index 58e433fd347..c6376cdf6a9 100644 --- a/board/Marvell/gplugd/gplugd.c +++ b/board/Marvell/gplugd/gplugd.c @@ -18,6 +18,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/mfp.h> #include <asm/arch/armada100.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <miiphy.h> #include <asm/mach-types.h> diff --git a/board/Marvell/guruplug/guruplug.c b/board/Marvell/guruplug/guruplug.c index f3981c66d20..8e7dbb3f3f6 100644 --- a/board/Marvell/guruplug/guruplug.c +++ b/board/Marvell/guruplug/guruplug.c @@ -9,6 +9,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index 73d69e03880..6e9c0ad37ff 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -9,6 +9,7 @@ #include <i2c.h> #include <init.h> #include <phy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/mvebu_armada-8k/board.c b/board/Marvell/mvebu_armada-8k/board.c index bf8a929ec1e..7da5d9f96b1 100644 --- a/board/Marvell/mvebu_armada-8k/board.c +++ b/board/Marvell/mvebu_armada-8k/board.c @@ -7,6 +7,7 @@ #include <dm.h> #include <i2c.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/octeontx/board.c b/board/Marvell/octeontx/board.c index 940faacbe37..dcd69d38cff 100644 --- a/board/Marvell/octeontx/board.c +++ b/board/Marvell/octeontx/board.c @@ -5,6 +5,7 @@ * https://spdx.org/licenses */
+#include <common.h> #include <dm.h> #include <malloc.h> #include <errno.h> @@ -13,6 +14,7 @@ #include <log.h> #include <netdev.h> #include <pci_ids.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/compiler.h> #include <linux/libfdt.h> diff --git a/board/Marvell/octeontx2/board.c b/board/Marvell/octeontx2/board.c index 50e903d9aa9..ea229f191ed 100644 --- a/board/Marvell/octeontx2/board.c +++ b/board/Marvell/octeontx2/board.c @@ -5,10 +5,12 @@ * https://spdx.org/licenses */
+#include <common.h> #include <command.h> #include <console.h> #include <cpu_func.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/uclass-internal.h> #include <env.h> #include <init.h> diff --git a/board/Marvell/openrd/openrd.c b/board/Marvell/openrd/openrd.c index d9b5b213fea..f44ac3315eb 100644 --- a/board/Marvell/openrd/openrd.c +++ b/board/Marvell/openrd/openrd.c @@ -14,6 +14,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/sheevaplug/sheevaplug.c b/board/Marvell/sheevaplug/sheevaplug.c index 6311ed3b2e5..0cc7f2b3924 100644 --- a/board/Marvell/sheevaplug/sheevaplug.c +++ b/board/Marvell/sheevaplug/sheevaplug.c @@ -9,6 +9,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Seagate/dockstar/dockstar.c b/board/Seagate/dockstar/dockstar.c index 85dd10e55a2..380e37be550 100644 --- a/board/Seagate/dockstar/dockstar.c +++ b/board/Seagate/dockstar/dockstar.c @@ -16,6 +16,7 @@ #include <asm/arch/soc.h> #include <asm/arch/mpp.h> #include <asm/arch/cpu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include "dockstar.h" diff --git a/board/Seagate/goflexhome/goflexhome.c b/board/Seagate/goflexhome/goflexhome.c index de1ec544667..4c19fa7195e 100644 --- a/board/Seagate/goflexhome/goflexhome.c +++ b/board/Seagate/goflexhome/goflexhome.c @@ -16,6 +16,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> diff --git a/board/Seagate/nas220/nas220.c b/board/Seagate/nas220/nas220.c index 3a027d083a7..cd2bbdad1cd 100644 --- a/board/Seagate/nas220/nas220.c +++ b/board/Seagate/nas220/nas220.c @@ -12,6 +12,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> diff --git a/board/Synology/ds109/ds109.c b/board/Synology/ds109/ds109.c index aa2987d924f..bf57ffff438 100644 --- a/board/Synology/ds109/ds109.c +++ b/board/Synology/ds109/ds109.c @@ -9,6 +9,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/setup.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Synology/ds414/ds414.c b/board/Synology/ds414/ds414.c index 632205164eb..9c4ce670ddf 100644 --- a/board/Synology/ds414/ds414.c +++ b/board/Synology/ds414/ds414.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <miiphy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/advantech/dms-ba16/dms-ba16.c b/board/advantech/dms-ba16/dms-ba16.c index 20820fdf076..07a47e9fbb0 100644 --- a/board/advantech/dms-ba16/dms-ba16.c +++ b/board/advantech/dms-ba16/dms-ba16.c @@ -11,6 +11,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/advantech/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c b/board/advantech/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c index ea057d27cf3..8492e7603b4 100644 --- a/board/advantech/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c +++ b/board/advantech/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c @@ -9,6 +9,7 @@ #include <env.h> #include <errno.h> #include <init.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <asm/io.h> diff --git a/board/advantech/imx8qm_rom7720_a1/spl.c b/board/advantech/imx8qm_rom7720_a1/spl.c index a2386c9ef00..8493bb01588 100644 --- a/board/advantech/imx8qm_rom7720_a1/spl.c +++ b/board/advantech/imx8qm_rom7720_a1/spl.c @@ -9,6 +9,7 @@ #include <log.h> #include <spl.h> #include <fsl_esdhc.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <asm/gpio.h> diff --git a/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c b/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c index 668484b71b6..d8b9fdfe356 100644 --- a/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c +++ b/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/io.h> diff --git a/board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c b/board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c index e4bf507cc3f..52b8eba92fc 100644 --- a/board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c +++ b/board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c @@ -10,6 +10,7 @@ #include <net.h> #include <netdev.h> #include <led.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <asm/arch/cpu.h> diff --git a/board/alliedtelesis/common/gpio_hog.c b/board/alliedtelesis/common/gpio_hog.c index 1f87b3ac1b7..4aecf7e2cef 100644 --- a/board/alliedtelesis/common/gpio_hog.c +++ b/board/alliedtelesis/common/gpio_hog.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <asm/gpio.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/alliedtelesis/x530/x530.c b/board/alliedtelesis/x530/x530.c index c7438aeaf14..d602092d732 100644 --- a/board/alliedtelesis/x530/x530.c +++ b/board/alliedtelesis/x530/x530.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <init.h> #include <wdt.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/bitops.h> #include <linux/mbus.h> diff --git a/board/amazon/kc1/kc1.c b/board/amazon/kc1/kc1.c index 973bc5a9272..75fb14025c1 100644 --- a/board/amazon/kc1/kc1.c +++ b/board/amazon/kc1/kc1.c @@ -10,6 +10,7 @@ #include <env.h> #include <fastboot.h> #include <init.h> +#include <asm/global_data.h> #include <linux/ctype.h> #include <linux/usb/musb.h> #include <asm/omap_musb.h> diff --git a/board/amlogic/vim3/vim3.c b/board/amlogic/vim3/vim3.c index 09ef39ff30a..bb680444b26 100644 --- a/board/amlogic/vim3/vim3.c +++ b/board/amlogic/vim3/vim3.c @@ -9,6 +9,7 @@ #include <env_internal.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/eth.h> #include <i2c.h> diff --git a/board/aristainetos/aristainetos.c b/board/aristainetos/aristainetos.c index 14931120f6f..a28f67a0b13 100644 --- a/board/aristainetos/aristainetos.c +++ b/board/aristainetos/aristainetos.c @@ -16,6 +16,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/armadeus/apf27/apf27.c b/board/armadeus/apf27/apf27.c index 29e0bf388d0..5e3fdd36fa2 100644 --- a/board/armadeus/apf27/apf27.c +++ b/board/armadeus/apf27/apf27.c @@ -9,6 +9,7 @@ #include <common.h> #include <hang.h> #include <init.h> +#include <asm/global_data.h> #include <jffs2/jffs2.h> #include <nand.h> #include <netdev.h> diff --git a/board/armltd/integrator/integrator.c b/board/armltd/integrator/integrator.c index 19871bee146..a730f15c7a3 100644 --- a/board/armltd/integrator/integrator.c +++ b/board/armltd/integrator/integrator.c @@ -24,6 +24,7 @@ #include <init.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/platform_data/serial_pl01x.h> #include "arm-ebi.h" diff --git a/board/armltd/total_compute/total_compute.c b/board/armltd/total_compute/total_compute.c index 0be6435fe3b..526eb3e9702 100644 --- a/board/armltd/total_compute/total_compute.c +++ b/board/armltd/total_compute/total_compute.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_pl01x.h> #include <asm/armv8/mmu.h>
diff --git a/board/armltd/vexpress/vexpress_common.c b/board/armltd/vexpress/vexpress_common.c index 70f6cd80d5a..d34c03bf9dd 100644 --- a/board/armltd/vexpress/vexpress_common.c +++ b/board/armltd/vexpress/vexpress_common.c @@ -23,6 +23,7 @@ #include <errno.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include <asm/arch/systimer.h> diff --git a/board/armltd/vexpress64/vexpress64.c b/board/armltd/vexpress64/vexpress64.c index 52ada0f6bce..6bf2ed23190 100644 --- a/board/armltd/vexpress64/vexpress64.c +++ b/board/armltd/vexpress64/vexpress64.c @@ -12,6 +12,7 @@ #include <errno.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/compiler.h> #include <dm/platform_data/serial_pl01x.h> diff --git a/board/astro/mcf5373l/mcf5373l.c b/board/astro/mcf5373l/mcf5373l.c index e7c2b909300..3e2f79a1cf4 100644 --- a/board/astro/mcf5373l/mcf5373l.c +++ b/board/astro/mcf5373l/mcf5373l.c @@ -10,6 +10,7 @@ #include <serial.h> #include <watchdog.h> #include <command.h> +#include <asm/global_data.h> #include <asm/m5329.h> #include <asm/immap_5329.h> #include <asm/io.h> diff --git a/board/atmark-techno/armadillo-800eva/armadillo-800eva.c b/board/atmark-techno/armadillo-800eva/armadillo-800eva.c index a18fb275d9f..1bae2832522 100644 --- a/board/atmark-techno/armadillo-800eva/armadillo-800eva.c +++ b/board/atmark-techno/armadillo-800eva/armadillo-800eva.c @@ -24,6 +24,7 @@ #include <cpu_func.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mach-types.h> #include <asm/io.h> diff --git a/board/atmel/at91rm9200ek/at91rm9200ek.c b/board/atmel/at91rm9200ek/at91rm9200ek.c index 8844bc75419..a314ced5e4a 100644 --- a/board/atmel/at91rm9200ek/at91rm9200ek.c +++ b/board/atmel/at91rm9200ek/at91rm9200ek.c @@ -13,6 +13,7 @@ #include <init.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pio.h> diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index 42fa7627724..38f97bce204 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -9,6 +9,7 @@ #include <debug_uart.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index f467a4f566c..0318eeaa94e 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -9,6 +9,7 @@ #include <debug_uart.h> #include <init.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9261.h> #include <asm/arch/at91sam9261_matrix.h> diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index be132bc185f..3218e14e860 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -11,6 +11,7 @@ #include <init.h> #include <net.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/arch/at91sam9263.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index 8aabc559519..8cb2808e058 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -10,6 +10,7 @@ #include <init.h> #include <net.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clk.h> #include <asm/arch/at91sam9g45_matrix.h> diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c index d7ff2e13352..a3fc55bbc34 100644 --- a/board/atmel/at91sam9n12ek/at91sam9n12ek.c +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -8,6 +8,7 @@ #include <init.h> #include <net.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9x5_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index f81dccc9ccc..f427ee658bf 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -9,6 +9,7 @@ #include <debug_uart.h> #include <init.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include <asm/arch/at91sam9rl.h> diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 2c071075bac..e0abe4aeb08 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9x5_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/atmel/common/video_display.c b/board/atmel/common/video_display.c index 2666b0b3cd5..a5049f4aad4 100644 --- a/board/atmel/common/video_display.c +++ b/board/atmel/common/video_display.c @@ -13,6 +13,7 @@ #include <video.h> #include <video_console.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clk.h>
diff --git a/board/atmel/sam9x60ek/sam9x60ek.c b/board/atmel/sam9x60ek/sam9x60ek.c index fbd05c78a94..32e5a2bf23a 100644 --- a/board/atmel/sam9x60ek/sam9x60ek.c +++ b/board/atmel/sam9x60ek/sam9x60ek.c @@ -7,6 +7,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> diff --git a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c index 376562cd0e7..1b7d946b50c 100644 --- a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c +++ b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c @@ -7,6 +7,7 @@ #include <common.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c index c8c2e958167..32d51bba7d9 100644 --- a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c +++ b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c @@ -8,6 +8,7 @@ #include <common.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/atmel/sama5d2_icp/sama5d2_icp.c b/board/atmel/sama5d2_icp/sama5d2_icp.c index 7c34df48b87..3f33fcfc466 100644 --- a/board/atmel/sama5d2_icp/sama5d2_icp.c +++ b/board/atmel/sama5d2_icp/sama5d2_icp.c @@ -7,6 +7,7 @@ #include <common.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c b/board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c index b0a23b02db2..a6937e7d524 100644 --- a/board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c +++ b/board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c @@ -11,6 +11,7 @@ #include <init.h> #include <nand.h> #include <version.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/atmel/sama5d2_xplained/sama5d2_xplained.c b/board/atmel/sama5d2_xplained/sama5d2_xplained.c index 01636fb73d0..5110ec89697 100644 --- a/board/atmel/sama5d2_xplained/sama5d2_xplained.c +++ b/board/atmel/sama5d2_xplained/sama5d2_xplained.c @@ -7,6 +7,7 @@ #include <common.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/atmel/sama5d3_xplained/sama5d3_xplained.c b/board/atmel/sama5d3_xplained/sama5d3_xplained.c index 84c561be6fc..db9603f5847 100644 --- a/board/atmel/sama5d3_xplained/sama5d3_xplained.c +++ b/board/atmel/sama5d3_xplained/sama5d3_xplained.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sama5d3_smc.h> #include <asm/arch/at91_common.h> diff --git a/board/atmel/sama5d3xek/sama5d3xek.c b/board/atmel/sama5d3xek/sama5d3xek.c index 7f6a3198592..b6f8dcd91dc 100644 --- a/board/atmel/sama5d3xek/sama5d3xek.c +++ b/board/atmel/sama5d3xek/sama5d3xek.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sama5d3_smc.h> #include <asm/arch/at91_common.h> diff --git a/board/atmel/sama5d4_xplained/sama5d4_xplained.c b/board/atmel/sama5d4_xplained/sama5d4_xplained.c index 93cc183a5b4..2088b48b7ee 100644 --- a/board/atmel/sama5d4_xplained/sama5d4_xplained.c +++ b/board/atmel/sama5d4_xplained/sama5d4_xplained.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_rstc.h> diff --git a/board/atmel/sama5d4ek/sama5d4ek.c b/board/atmel/sama5d4ek/sama5d4ek.c index 4b3883e20f8..46ec1eb3246 100644 --- a/board/atmel/sama5d4ek/sama5d4ek.c +++ b/board/atmel/sama5d4ek/sama5d4ek.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_rstc.h> diff --git a/board/bachmann/ot1200/ot1200.c b/board/bachmann/ot1200/ot1200.c index d3af634e3ab..69d1b106b07 100644 --- a/board/bachmann/ot1200/ot1200.c +++ b/board/bachmann/ot1200/ot1200.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/barco/platinum/platinum.c b/board/barco/platinum/platinum.c index f96106cb75e..ec8d5528887 100644 --- a/board/barco/platinum/platinum.c +++ b/board/barco/platinum/platinum.c @@ -11,6 +11,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/barco/titanium/titanium.c b/board/barco/titanium/titanium.c index 7a52e94c7ee..efd1dc35ef4 100644 --- a/board/barco/titanium/titanium.c +++ b/board/barco/titanium/titanium.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/beacon/beacon-rzg2m/beacon-rzg2m.c b/board/beacon/beacon-rzg2m/beacon-rzg2m.c index 86a24dd0658..c343de51023 100644 --- a/board/beacon/beacon-rzg2m/beacon-rzg2m.c +++ b/board/beacon/beacon-rzg2m/beacon-rzg2m.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/rcar-mstp.h>
diff --git a/board/beacon/imx8mm/imx8mm_beacon.c b/board/beacon/imx8mm/imx8mm_beacon.c index c61d25fbead..87ffebb5713 100644 --- a/board/beacon/imx8mm/imx8mm_beacon.c +++ b/board/beacon/imx8mm/imx8mm_beacon.c @@ -6,6 +6,7 @@ #include <common.h> #include <miiphy.h> #include <netdev.h> +#include <asm/global_data.h>
#include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> diff --git a/board/beacon/imx8mm/spl.c b/board/beacon/imx8mm/spl.c index 4ee10cf8555..12266b22a42 100644 --- a/board/beacon/imx8mm/spl.c +++ b/board/beacon/imx8mm/spl.c @@ -6,6 +6,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/arch/clock.h> diff --git a/board/beckhoff/mx53cx9020/mx53cx9020.c b/board/beckhoff/mx53cx9020/mx53cx9020.c index 617b545232a..a3657db8266 100644 --- a/board/beckhoff/mx53cx9020/mx53cx9020.c +++ b/board/beckhoff/mx53cx9020/mx53cx9020.c @@ -13,6 +13,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/clock.h> #include <asm/arch/iomux-mx53.h> +#include <asm/global_data.h> #include <asm/mach-imx/mx5_video.h> #include <ACEX1K.h> #include <asm/gpio.h> diff --git a/board/bluegiga/apx4devkit/apx4devkit.c b/board/bluegiga/apx4devkit/apx4devkit.c index 739f71f5c4d..ed0885f724c 100644 --- a/board/bluegiga/apx4devkit/apx4devkit.c +++ b/board/bluegiga/apx4devkit/apx4devkit.c @@ -16,6 +16,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/setup.h> diff --git a/board/bluewater/gurnard/gurnard.c b/board/bluewater/gurnard/gurnard.c index dc9871d4469..c5c8bcc598e 100644 --- a/board/bluewater/gurnard/gurnard.c +++ b/board/bluewater/gurnard/gurnard.c @@ -19,6 +19,7 @@ #ifndef CONFIG_DM_ETH #include <netdev.h> #endif +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/mach-types.h> diff --git a/board/bluewater/snapper9260/snapper9260.c b/board/bluewater/snapper9260/snapper9260.c index 9b0a75ac5df..87fb967ea05 100644 --- a/board/bluewater/snapper9260/snapper9260.c +++ b/board/bluewater/snapper9260/snapper9260.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/mach-types.h> diff --git a/board/bosch/guardian/board.c b/board/bosch/guardian/board.c index 1d8fa781545..113838f8b72 100644 --- a/board/bosch/guardian/board.c +++ b/board/bosch/guardian/board.c @@ -19,6 +19,7 @@ #include <led.h> #include <miiphy.h> #include <panel.h> +#include <asm/global_data.h> #include <power/tps65217.h> #include <power/tps65910.h> #include <spl.h> diff --git a/board/bosch/shc/board.c b/board/bosch/shc/board.c index b8f1b56502e..bfce291691a 100644 --- a/board/bosch/shc/board.c +++ b/board/bosch/shc/board.c @@ -29,6 +29,7 @@ #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 5b2d675a557..84e14d1124f 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -9,6 +9,7 @@ #include <env.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/broadcom/bcm23550_w1d/bcm23550_w1d.c b/board/broadcom/bcm23550_w1d/bcm23550_w1d.c index a1e3b25c2e0..90685c072a3 100644 --- a/board/broadcom/bcm23550_w1d/bcm23550_w1d.c +++ b/board/broadcom/bcm23550_w1d/bcm23550_w1d.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include <env.h> diff --git a/board/broadcom/bcm28155_ap/bcm28155_ap.c b/board/broadcom/bcm28155_ap/bcm28155_ap.c index 79ce54993dd..43726f79bde 100644 --- a/board/broadcom/bcm28155_ap/bcm28155_ap.c +++ b/board/broadcom/bcm28155_ap/bcm28155_ap.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include <env.h> diff --git a/board/broadcom/bcm_ep/board.c b/board/broadcom/bcm_ep/board.c index ad9af92b559..6064eb43db1 100644 --- a/board/broadcom/bcm_ep/board.c +++ b/board/broadcom/bcm_ep/board.c @@ -8,6 +8,7 @@ #include <init.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <config.h> #include <netdev.h> diff --git a/board/broadcom/bcmns2/northstar2.c b/board/broadcom/bcmns2/northstar2.c index 91f489aad3f..494e457ff65 100644 --- a/board/broadcom/bcmns2/northstar2.c +++ b/board/broadcom/bcmns2/northstar2.c @@ -6,6 +6,7 @@ #include <cpu_func.h> #include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/armv8/mmu.h>
diff --git a/board/broadcom/bcmns3/ns3.c b/board/broadcom/bcmns3/ns3.c index 10ae344a06d..9d2df92fa1d 100644 --- a/board/broadcom/bcmns3/ns3.c +++ b/board/broadcom/bcmns3/ns3.c @@ -8,6 +8,7 @@ #include <fdt_support.h> #include <asm/io.h> #include <asm/gic-v3.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/armv8/mmu.h> #include <asm/arch-bcmns3/bl33_info.h> diff --git a/board/broadcom/bcmstb/bcmstb.c b/board/broadcom/bcmstb/bcmstb.c index add4285db31..f6bdf1f5f40 100644 --- a/board/broadcom/bcmstb/bcmstb.c +++ b/board/broadcom/bcmstb/bcmstb.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <linux/types.h> #include <common.h> #include <env.h> diff --git a/board/bticino/mamoj/mamoj.c b/board/bticino/mamoj/mamoj.c index b7d37b70044..c9da42b43bf 100644 --- a/board/bticino/mamoj/mamoj.c +++ b/board/bticino/mamoj/mamoj.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h>
diff --git a/board/bticino/mamoj/spl.c b/board/bticino/mamoj/spl.c index a9bb2a55e5d..883b7f4133b 100644 --- a/board/bticino/mamoj/spl.c +++ b/board/bticino/mamoj/spl.c @@ -9,6 +9,7 @@ #include <init.h> #include <serial.h> #include <spl.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/io.h> diff --git a/board/buffalo/lsxl/lsxl.c b/board/buffalo/lsxl/lsxl.c index 64daa456b3c..34be601fdde 100644 --- a/board/buffalo/lsxl/lsxl.c +++ b/board/buffalo/lsxl/lsxl.c @@ -24,6 +24,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/mpp.h> #include <asm/arch/gpio.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include "lsxl.h" diff --git a/board/calao/usb_a9263/usb_a9263.c b/board/calao/usb_a9263/usb_a9263.c index 1fcaff60455..c0a5c518ca8 100644 --- a/board/calao/usb_a9263/usb_a9263.c +++ b/board/calao/usb_a9263/usb_a9263.c @@ -15,6 +15,7 @@ #include <asm/arch/clk.h> #include <asm/arch/gpio.h> #include <asm-generic/gpio.h> +#include <asm/global_data.h> #include <asm/io.h> #include <net.h> #include <netdev.h> diff --git a/board/cavium/thunderx/thunderx.c b/board/cavium/thunderx/thunderx.c index f8c2913eace..ccb6b26c91b 100644 --- a/board/cavium/thunderx/thunderx.c +++ b/board/cavium/thunderx/thunderx.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <errno.h> #include <net.h> +#include <asm/global_data.h> #include <linux/compiler.h>
#include <cavium/atf.h> diff --git a/board/ccv/xpress/xpress.c b/board/ccv/xpress/xpress.c index 27beaeb101a..9f5e78ce680 100644 --- a/board/ccv/xpress/xpress.c +++ b/board/ccv/xpress/xpress.c @@ -12,6 +12,7 @@ #include <asm/arch/mx6ul_pins.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/cirrus/edb93xx/edb93xx.c b/board/cirrus/edb93xx/edb93xx.c index cbed98b0e36..7a7f62fe88e 100644 --- a/board/cirrus/edb93xx/edb93xx.c +++ b/board/cirrus/edb93xx/edb93xx.c @@ -21,6 +21,7 @@ #include <net.h> #include <netdev.h> #include <status_led.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include <asm/arch/ep93xx.h> diff --git a/board/cloudengines/pogo_e02/pogo_e02.c b/board/cloudengines/pogo_e02/pogo_e02.c index 8df039168c9..039fd6e3dd6 100644 --- a/board/cloudengines/pogo_e02/pogo_e02.c +++ b/board/cloudengines/pogo_e02/pogo_e02.c @@ -17,6 +17,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> +#include <asm/global_data.h> #include "pogo_e02.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/cobra5272/cobra5272.c b/board/cobra5272/cobra5272.c index a79884cb506..3e2418866c7 100644 --- a/board/cobra5272/cobra5272.c +++ b/board/cobra5272/cobra5272.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/compulab/cl-som-imx7/cl-som-imx7.c b/board/compulab/cl-som-imx7/cl-som-imx7.c index 1eef1d55076..454c93a572f 100644 --- a/board/compulab/cl-som-imx7/cl-som-imx7.c +++ b/board/compulab/cl-som-imx7/cl-som-imx7.c @@ -15,6 +15,7 @@ #include <phy.h> #include <netdev.h> #include <fsl_esdhc_imx.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <power/pmic.h> #include <power/pfuze3000_pmic.h> diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index e2712680f95..2b11b7ee189 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c @@ -27,6 +27,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/iomux.h> #include <asm/arch/mxc_hdmi.h> +#include <asm/global_data.h> #include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/sata.h> #include <asm/mach-imx/video.h> diff --git a/board/compulab/cm_t335/cm_t335.c b/board/compulab/cm_t335/cm_t335.c index a9ba2b7e002..1d4a3aceef5 100644 --- a/board/compulab/cm_t335/cm_t335.c +++ b/board/compulab/cm_t335/cm_t335.c @@ -14,6 +14,7 @@ #include <net.h> #include <status_led.h> #include <cpsw.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/arch/sys_proto.h> diff --git a/board/compulab/cm_t43/cm_t43.c b/board/compulab/cm_t43/cm_t43.c index 4b097c8f8f7..efdade155b5 100644 --- a/board/compulab/cm_t43/cm_t43.c +++ b/board/compulab/cm_t43/cm_t43.c @@ -8,6 +8,7 @@ #include <miiphy.h> #include <cpsw.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/sys_proto.h> #include <asm/emif.h> diff --git a/board/congatec/cgtqmx6eval/cgtqmx6eval.c b/board/congatec/cgtqmx6eval/cgtqmx6eval.c index 9316b2c3772..6ae4a1af892 100644 --- a/board/congatec/cgtqmx6eval/cgtqmx6eval.c +++ b/board/congatec/cgtqmx6eval/cgtqmx6eval.c @@ -9,6 +9,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/corscience/tricorder/tricorder.c b/board/corscience/tricorder/tricorder.c index 41675677de2..3f4a40fd659 100644 --- a/board/corscience/tricorder/tricorder.c +++ b/board/corscience/tricorder/tricorder.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <twl4030.h> #include <status_led.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/mmc_host_def.h> diff --git a/board/cortina/presidio-asic/presidio.c b/board/cortina/presidio-asic/presidio.c index 3c132f12717..5c735222637 100644 --- a/board/cortina/presidio-asic/presidio.c +++ b/board/cortina/presidio-asic/presidio.c @@ -8,6 +8,7 @@ #include <malloc.h> #include <errno.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <linux/compiler.h> diff --git a/board/creative/xfi3/xfi3.c b/board/creative/xfi3/xfi3.c index b5f0d313074..2aa2435e49c 100644 --- a/board/creative/xfi3/xfi3.c +++ b/board/creative/xfi3/xfi3.c @@ -13,6 +13,7 @@ #include <errno.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/iomux-mx23.h> diff --git a/board/cssi/MCR3000/MCR3000.c b/board/cssi/MCR3000/MCR3000.c index 55e955c36bb..c20e8714949 100644 --- a/board/cssi/MCR3000/MCR3000.c +++ b/board/cssi/MCR3000/MCR3000.c @@ -14,6 +14,7 @@ #include <mpc8xx.h> #include <fdt_support.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/uclass.h> #include <wdt.h> diff --git a/board/d-link/dns325/dns325.c b/board/d-link/dns325/dns325.c index 0ae2e7d88c1..055783f63ad 100644 --- a/board/d-link/dns325/dns325.c +++ b/board/d-link/dns325/dns325.c @@ -19,6 +19,7 @@ #include <asm/arch/soc.h> #include <asm/arch/mpp.h> #include <asm/arch/gpio.h> +#include <asm/global_data.h> #include "dns325.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index 683e8b452ad..383a8617384 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -17,6 +17,7 @@ #include <spi.h> #include <spi_flash.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/ti-common/davinci_nand.h> #include <asm/arch/emac_defs.h> #include <asm/arch/pinmux_defs.h> diff --git a/board/davinci/da8xxevm/omapl138_lcdk.c b/board/davinci/da8xxevm/omapl138_lcdk.c index 6bab7b18d44..7607e313b75 100644 --- a/board/davinci/da8xxevm/omapl138_lcdk.c +++ b/board/davinci/da8xxevm/omapl138_lcdk.c @@ -14,6 +14,7 @@ #include <init.h> #include <net.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/ti-common/davinci_nand.h> #include <asm/io.h> #include <ns16550.h> diff --git a/board/dhelectronics/dh_imx6/dh_imx6.c b/board/dhelectronics/dh_imx6/dh_imx6.c index 9937d6b0106..2969e90a707 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6.c +++ b/board/dhelectronics/dh_imx6/dh_imx6.c @@ -11,6 +11,7 @@ #include <image.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <asm/arch/clock.h> #include <asm/arch/crm_regs.h> diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index f42d395098b..a7bde9de58f 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -9,6 +9,7 @@ #include <net.h> #include <asm/arch/stm32.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <bootm.h> diff --git a/board/ea/mx7ulp_com/mx7ulp_com.c b/board/ea/mx7ulp_com/mx7ulp_com.c index a9b8a321082..5b2d444366c 100644 --- a/board/ea/mx7ulp_com/mx7ulp_com.c +++ b/board/ea/mx7ulp_com/mx7ulp_com.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mx7ulp-pins.h> diff --git a/board/eets/pdu001/board.c b/board/eets/pdu001/board.c index a602b623adb..f806d1e7672 100644 --- a/board/eets/pdu001/board.c +++ b/board/eets/pdu001/board.c @@ -18,6 +18,7 @@ #include <i2c.h> #include <watchdog.h> #include <debug_uart.h> +#include <asm/global_data.h> #include <dm/ofnode.h> #include <power/pmic.h> #include <power/regulator.h> diff --git a/board/egnite/ethernut5/ethernut5.c b/board/egnite/ethernut5/ethernut5.c index 0674b300109..559fdd2f646 100644 --- a/board/egnite/ethernut5/ethernut5.c +++ b/board/egnite/ethernut5/ethernut5.c @@ -60,6 +60,7 @@ #include <i2c.h> #include <mmc.h> #include <atmel_mci.h> +#include <asm/global_data.h>
#include <asm/arch/at91sam9260.h> #include <asm/arch/at91sam9260_matrix.h> diff --git a/board/el/el6x/el6x.c b/board/el/el6x/el6x.c index bdc0558eda2..ddac58f73d2 100644 --- a/board/el/el6x/el6x.c +++ b/board/el/el6x/el6x.c @@ -13,6 +13,7 @@ #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> #include <env.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/elgin/elgin_rv1108/elgin_rv1108.c b/board/elgin/elgin_rv1108/elgin_rv1108.c index 245e5abcaeb..eb7a322d847 100644 --- a/board/elgin/elgin_rv1108/elgin_rv1108.c +++ b/board/elgin/elgin_rv1108/elgin_rv1108.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/grf_rv1108.h> diff --git a/board/embest/mx6boards/mx6boards.c b/board/embest/mx6boards/mx6boards.c index 752242bd54c..65b3942e399 100644 --- a/board/embest/mx6boards/mx6boards.c +++ b/board/embest/mx6boards/mx6boards.c @@ -20,6 +20,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/engicam/common/board.c b/board/engicam/common/board.c index 5a2003d5098..df9149e0d6d 100644 --- a/board/engicam/common/board.c +++ b/board/engicam/common/board.c @@ -16,6 +16,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> #include <watchdog.h> +#include <asm/global_data.h>
#include "board.h"
diff --git a/board/esd/meesc/meesc.c b/board/esd/meesc/meesc.c index deed3a9b84e..eaa525eb004 100644 --- a/board/esd/meesc/meesc.c +++ b/board/esd/meesc/meesc.c @@ -15,6 +15,7 @@ #include <net.h> #include <serial.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/mach-types.h> diff --git a/board/esd/vme8349/vme8349.c b/board/esd/vme8349/vme8349.c index 8d3d26e3c70..d388fc6d490 100644 --- a/board/esd/vme8349/vme8349.c +++ b/board/esd/vme8349/vme8349.c @@ -17,6 +17,7 @@ #include <ioports.h> #include <mpc83xx.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mpc8349_pci.h> #if defined(CONFIG_OF_LIBFDT) #include <linux/libfdt.h> diff --git a/board/firefly/firefly-rk3288/firefly-rk3288.c b/board/firefly/firefly-rk3288/firefly-rk3288.c index bd8a32cf7b3..41c49e5daa7 100644 --- a/board/firefly/firefly-rk3288/firefly-rk3288.c +++ b/board/firefly/firefly-rk3288/firefly-rk3288.c @@ -7,6 +7,7 @@ #include <hang.h> #include <led.h> #include <log.h> +#include <asm/global_data.h>
#ifdef CONFIG_SPL_BUILD DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/common/arm_sleep.c b/board/freescale/common/arm_sleep.c index bb1ef997927..733940860f5 100644 --- a/board/freescale/common/arm_sleep.c +++ b/board/freescale/common/arm_sleep.c @@ -5,6 +5,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #ifndef CONFIG_ARMV7_NONSEC #error " Deep sleep needs non-secure mode support. " diff --git a/board/freescale/common/emc2305.c b/board/freescale/common/emc2305.c index 050b679f3c5..12ad4b3e08a 100644 --- a/board/freescale/common/emc2305.c +++ b/board/freescale/common/emc2305.c @@ -7,6 +7,7 @@ #include <common.h> #include <command.h> #include <i2c.h> +#include <asm/global_data.h> #include <asm/io.h>
#include "emc2305.h" diff --git a/board/freescale/common/mpc85xx_sleep.c b/board/freescale/common/mpc85xx_sleep.c index 6f6f4d40fcb..d2bb173c183 100644 --- a/board/freescale/common/mpc85xx_sleep.c +++ b/board/freescale/common/mpc85xx_sleep.c @@ -5,6 +5,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/immap_85xx.h> #include "sleep.h" #ifdef CONFIG_U_QE diff --git a/board/freescale/corenet_ds/corenet_ds.c b/board/freescale/corenet_ds/corenet_ds.c index 15d11ed81ab..3a83e65f2fe 100644 --- a/board/freescale/corenet_ds/corenet_ds.c +++ b/board/freescale/corenet_ds/corenet_ds.c @@ -10,6 +10,7 @@ #include <image.h> #include <init.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/corenet_ds/ddr.c b/board/freescale/corenet_ds/ddr.c index 19f6e8700d5..2c440673e7c 100644 --- a/board/freescale/corenet_ds/ddr.c +++ b/board/freescale/corenet_ds/ddr.c @@ -9,6 +9,7 @@ #include <init.h> #include <log.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/imx8mm_evk/imx8mm_evk.c b/board/freescale/imx8mm_evk/imx8mm_evk.c index 6af71006966..ab55135a972 100644 --- a/board/freescale/imx8mm_evk/imx8mm_evk.c +++ b/board/freescale/imx8mm_evk/imx8mm_evk.c @@ -8,6 +8,7 @@ #include <init.h> #include <miiphy.h> #include <netdev.h> +#include <asm/global_data.h>
#include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/imx8mm_evk/spl.c b/board/freescale/imx8mm_evk/spl.c index 19c8a5aa235..64bc60651d3 100644 --- a/board/freescale/imx8mm_evk/spl.c +++ b/board/freescale/imx8mm_evk/spl.c @@ -11,6 +11,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/arch/clock.h> diff --git a/board/freescale/imx8mn_evk/imx8mn_evk.c b/board/freescale/imx8mn_evk/imx8mn_evk.c index e5ca54f9ae7..9a0a0488bf4 100644 --- a/board/freescale/imx8mn_evk/imx8mn_evk.c +++ b/board/freescale/imx8mn_evk/imx8mn_evk.c @@ -6,6 +6,7 @@ #include <common.h> #include <env.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/board/freescale/imx8mn_evk/spl.c b/board/freescale/imx8mn_evk/spl.c index dd38c1015cf..6d5c7a5b467 100644 --- a/board/freescale/imx8mn_evk/spl.c +++ b/board/freescale/imx8mn_evk/spl.c @@ -12,6 +12,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/arch/clock.h> diff --git a/board/freescale/imx8mp_evk/imx8mp_evk.c b/board/freescale/imx8mp_evk/imx8mp_evk.c index 034a349236e..56da4d4c6a3 100644 --- a/board/freescale/imx8mp_evk/imx8mp_evk.c +++ b/board/freescale/imx8mp_evk/imx8mp_evk.c @@ -7,6 +7,7 @@ #include <env.h> #include <errno.h> #include <init.h> +#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <asm-generic/gpio.h> #include <asm/arch/imx8mp_pins.h> diff --git a/board/freescale/imx8mp_evk/spl.c b/board/freescale/imx8mp_evk/spl.c index 3214718e62b..ebfd94dc1fa 100644 --- a/board/freescale/imx8mp_evk/spl.c +++ b/board/freescale/imx8mp_evk/spl.c @@ -12,6 +12,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <asm/io.h> diff --git a/board/freescale/imx8mq_evk/imx8mq_evk.c b/board/freescale/imx8mq_evk/imx8mq_evk.c index 1ad670b8ccf..93da67d7798 100644 --- a/board/freescale/imx8mq_evk/imx8mq_evk.c +++ b/board/freescale/imx8mq_evk/imx8mq_evk.c @@ -8,6 +8,7 @@ #include <init.h> #include <malloc.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/freescale/imx8mq_evk/spl.c b/board/freescale/imx8mq_evk/spl.c index 42183ed5aa0..82753585f2f 100644 --- a/board/freescale/imx8mq_evk/spl.c +++ b/board/freescale/imx8mq_evk/spl.c @@ -10,6 +10,7 @@ #include <image.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <asm/io.h> diff --git a/board/freescale/imx8qm_mek/imx8qm_mek.c b/board/freescale/imx8qm_mek/imx8qm_mek.c index fba3baa1267..c6772206244 100644 --- a/board/freescale/imx8qm_mek/imx8qm_mek.c +++ b/board/freescale/imx8qm_mek/imx8qm_mek.c @@ -8,6 +8,7 @@ #include <env.h> #include <errno.h> #include <init.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/io.h> diff --git a/board/freescale/imx8qm_mek/spl.c b/board/freescale/imx8qm_mek/spl.c index 9dee12a2c6a..944ba745c09 100644 --- a/board/freescale/imx8qm_mek/spl.c +++ b/board/freescale/imx8qm_mek/spl.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <dm/device.h> #include <dm/uclass-internal.h> diff --git a/board/freescale/imx8qxp_mek/imx8qxp_mek.c b/board/freescale/imx8qxp_mek/imx8qxp_mek.c index da55933e21b..7179823a223 100644 --- a/board/freescale/imx8qxp_mek/imx8qxp_mek.c +++ b/board/freescale/imx8qxp_mek/imx8qxp_mek.c @@ -8,6 +8,7 @@ #include <env.h> #include <errno.h> #include <init.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <fsl_esdhc_imx.h> diff --git a/board/freescale/imx8qxp_mek/spl.c b/board/freescale/imx8qxp_mek/spl.c index 881d297cf17..ae6b64ff6ea 100644 --- a/board/freescale/imx8qxp_mek/spl.c +++ b/board/freescale/imx8qxp_mek/spl.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <dm/device.h> #include <dm/uclass-internal.h> diff --git a/board/freescale/imxrt1020-evk/imxrt1020-evk.c b/board/freescale/imxrt1020-evk/imxrt1020-evk.c index 0cef6071feb..35241acd224 100644 --- a/board/freescale/imxrt1020-evk/imxrt1020-evk.c +++ b/board/freescale/imxrt1020-evk/imxrt1020-evk.c @@ -10,6 +10,7 @@ #include <log.h> #include <ram.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv7m.h>
diff --git a/board/freescale/imxrt1050-evk/imxrt1050-evk.c b/board/freescale/imxrt1050-evk/imxrt1050-evk.c index edc7fb176bb..b8d852f097b 100644 --- a/board/freescale/imxrt1050-evk/imxrt1050-evk.c +++ b/board/freescale/imxrt1050-evk/imxrt1050-evk.c @@ -10,6 +10,7 @@ #include <log.h> #include <ram.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv7m.h>
diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrdm/ls1012afrdm.c index 4770eadabd7..2cd651b943f 100644 --- a/board/freescale/ls1012afrdm/ls1012afrdm.c +++ b/board/freescale/ls1012afrdm/ls1012afrdm.c @@ -8,6 +8,7 @@ #include <i2c.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1012aqds/ls1012aqds.c b/board/freescale/ls1012aqds/ls1012aqds.c index 7bea45c8ae5..b77808ea57b 100644 --- a/board/freescale/ls1012aqds/ls1012aqds.c +++ b/board/freescale/ls1012aqds/ls1012aqds.c @@ -8,6 +8,7 @@ #include <fdt_support.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index 30b43ea135a..ed6dc9ff712 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1021aiot/dcu.c b/board/freescale/ls1021aiot/dcu.c index 77732a6ab15..e4fbcbcaad3 100644 --- a/board/freescale/ls1021aiot/dcu.c +++ b/board/freescale/ls1021aiot/dcu.c @@ -7,6 +7,7 @@
#include <common.h> #include <fsl_dcu_fb.h> +#include <asm/global_data.h> #include "div64.h" #include "../common/dcu_sii9022a.h"
diff --git a/board/freescale/ls1021aiot/ls1021aiot.c b/board/freescale/ls1021aiot/ls1021aiot.c index 2e5cc590666..bfe61376042 100644 --- a/board/freescale/ls1021aiot/ls1021aiot.c +++ b/board/freescale/ls1021aiot/ls1021aiot.c @@ -12,6 +12,7 @@ #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch/ls102xa_stream_id.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/arch/ls102xa_devdis.h> diff --git a/board/freescale/ls1021aqds/dcu.c b/board/freescale/ls1021aqds/dcu.c index b648a7872bc..f66961ca590 100644 --- a/board/freescale/ls1021aqds/dcu.c +++ b/board/freescale/ls1021aqds/dcu.c @@ -6,6 +6,7 @@ * FSL DCU Framebuffer driver */
+#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <fsl_dcu_fb.h> diff --git a/board/freescale/ls1021aqds/ddr.c b/board/freescale/ls1021aqds/ddr.c index f84bce95a84..66fe1519cc6 100644 --- a/board/freescale/ls1021aqds/ddr.c +++ b/board/freescale/ls1021aqds/ddr.c @@ -8,6 +8,7 @@ #include <fsl_ddr_dimm_params.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <linux/delay.h> diff --git a/board/freescale/ls1021atsn/ls1021atsn.c b/board/freescale/ls1021atsn/ls1021atsn.c index 878306b2d0f..c1acd3040c4 100644 --- a/board/freescale/ls1021atsn/ls1021atsn.c +++ b/board/freescale/ls1021atsn/ls1021atsn.c @@ -11,6 +11,7 @@ #include <asm/arch/immap_ls102xa.h> #include <asm/arch/ls102xa_soc.h> #include <asm/arch/fsl_serdes.h> +#include <asm/global_data.h> #include <linux/delay.h> #include "../common/sleep.h" #include <fsl_validate.h> diff --git a/board/freescale/ls1021atwr/dcu.c b/board/freescale/ls1021atwr/dcu.c index bdf7f7645c2..7bf283e3d66 100644 --- a/board/freescale/ls1021atwr/dcu.c +++ b/board/freescale/ls1021atwr/dcu.c @@ -7,6 +7,7 @@
diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 2889bd8dedd..0cd38a14b83 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> #include <asm/arch/clock.h> diff --git a/board/freescale/ls1028a/ddr.c b/board/freescale/ls1028a/ddr.c index 74d3af5c359..3e976da6b30 100644 --- a/board/freescale/ls1028a/ddr.c +++ b/board/freescale/ls1028a/ddr.c @@ -6,6 +6,7 @@ #include <common.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> +#include <asm/global_data.h>
diff --git a/board/freescale/ls1028a/ls1028a.c b/board/freescale/ls1028a/ls1028a.c index e37e3a3c16d..f3c1d958b72 100644 --- a/board/freescale/ls1028a/ls1028a.c +++ b/board/freescale/ls1028a/ls1028a.c @@ -9,6 +9,7 @@ #include <errno.h> #include <fsl_ddr.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <hwconfig.h> #include <fdt_support.h> diff --git a/board/freescale/ls1043aqds/ddr.c b/board/freescale/ls1043aqds/ddr.c index c0fc9aadf04..23947bdb84c 100644 --- a/board/freescale/ls1043aqds/ddr.c +++ b/board/freescale/ls1043aqds/ddr.c @@ -11,6 +11,7 @@ #endif #include <log.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls1043aqds/ls1043aqds.c b/board/freescale/ls1043aqds/ls1043aqds.c index ef0f2e61224..44e4c61eab2 100644 --- a/board/freescale/ls1043aqds/ls1043aqds.c +++ b/board/freescale/ls1043aqds/ls1043aqds.c @@ -10,6 +10,7 @@ #include <fsl_ddr_sdram.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1043ardb/ddr.c b/board/freescale/ls1043ardb/ddr.c index f16e036d0e8..08b43ff5e4c 100644 --- a/board/freescale/ls1043ardb/ddr.c +++ b/board/freescale/ls1043ardb/ddr.c @@ -6,6 +6,7 @@ #include <common.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> +#include <asm/global_data.h> #include "ddr.h" #include <log.h> #include <vsprintf.h> diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index dc32c030eca..beef26b084b 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -6,6 +6,7 @@ #include <common.h> #include <i2c.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1046afrwy/ddr.c b/board/freescale/ls1046afrwy/ddr.c index daf17e01693..256397b52b6 100644 --- a/board/freescale/ls1046afrwy/ddr.c +++ b/board/freescale/ls1046afrwy/ddr.c @@ -5,6 +5,7 @@
#include <common.h> #include <fsl_ddr_sdram.h> +#include <asm/global_data.h>
diff --git a/board/freescale/ls1046afrwy/ls1046afrwy.c b/board/freescale/ls1046afrwy/ls1046afrwy.c index 4ebf77b1ad1..9813a36ca07 100644 --- a/board/freescale/ls1046afrwy/ls1046afrwy.c +++ b/board/freescale/ls1046afrwy/ls1046afrwy.c @@ -7,6 +7,7 @@ #include <i2c.h> #include <fdt_support.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1046aqds/ddr.c b/board/freescale/ls1046aqds/ddr.c index f3cfbc4c39b..9a96de27178 100644 --- a/board/freescale/ls1046aqds/ddr.c +++ b/board/freescale/ls1046aqds/ddr.c @@ -11,6 +11,7 @@ #endif #include <log.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls1046aqds/ls1046aqds.c b/board/freescale/ls1046aqds/ls1046aqds.c index 33b10277af7..3c96c900c32 100644 --- a/board/freescale/ls1046aqds/ls1046aqds.c +++ b/board/freescale/ls1046aqds/ls1046aqds.c @@ -9,6 +9,7 @@ #include <fdt_support.h> #include <fsl_ddr_sdram.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1046ardb/ddr.c b/board/freescale/ls1046ardb/ddr.c index 0e07df52119..befb556bd30 100644 --- a/board/freescale/ls1046ardb/ddr.c +++ b/board/freescale/ls1046ardb/ddr.c @@ -6,6 +6,7 @@ #include <common.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> +#include <asm/global_data.h> #include "ddr.h" #ifdef CONFIG_FSL_DEEP_SLEEP #include <fsl_sleep.h> diff --git a/board/freescale/ls1046ardb/ls1046ardb.c b/board/freescale/ls1046ardb/ls1046ardb.c index e107c8471b3..93ef903f299 100644 --- a/board/freescale/ls1046ardb/ls1046ardb.c +++ b/board/freescale/ls1046ardb/ls1046ardb.c @@ -7,6 +7,7 @@ #include <i2c.h> #include <fdt_support.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c index fd9549bfbc8..995c4296017 100644 --- a/board/freescale/ls1088a/ddr.c +++ b/board/freescale/ls1088a/ddr.c @@ -9,6 +9,7 @@ #include <log.h> #include <asm/arch/soc.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 5d19702a05c..2ba6a3990d9 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -13,6 +13,7 @@ #include <fsl_ifc.h> #include <fsl_ddr.h> #include <fsl_sec.h> +#include <asm/global_data.h> #include <asm/io.h> #include <fdt_support.h> #include <linux/delay.h> diff --git a/board/freescale/ls2080a/ddr.c b/board/freescale/ls2080a/ddr.c index 229fc9cc30e..29d7bd1c5ee 100644 --- a/board/freescale/ls2080a/ddr.c +++ b/board/freescale/ls2080a/ddr.c @@ -9,6 +9,7 @@ #include <log.h> #include <asm/arch/soc.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index 62da2a7af11..48437a52e40 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -10,6 +10,7 @@ #include <netdev.h> #include <fsl_ifc.h> #include <fsl_ddr.h> +#include <asm/global_data.h> #include <asm/io.h> #include <fdt_support.h> #include <linux/libfdt.h> diff --git a/board/freescale/ls2080aqds/ddr.c b/board/freescale/ls2080aqds/ddr.c index 3fb2c4448c2..2767d058cc9 100644 --- a/board/freescale/ls2080aqds/ddr.c +++ b/board/freescale/ls2080aqds/ddr.c @@ -9,6 +9,7 @@ #include <log.h> #include <asm/arch/soc.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 3eb40f5e2a2..a6f6897eb09 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -10,6 +10,7 @@ #include <netdev.h> #include <fsl_ifc.h> #include <fsl_ddr.h> +#include <asm/global_data.h> #include <asm/io.h> #include <fdt_support.h> #include <linux/libfdt.h> diff --git a/board/freescale/ls2080ardb/ddr.c b/board/freescale/ls2080ardb/ddr.c index 4571a228c59..07fa8473332 100644 --- a/board/freescale/ls2080ardb/ddr.c +++ b/board/freescale/ls2080ardb/ddr.c @@ -9,6 +9,7 @@ #include <log.h> #include <asm/arch/soc.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls2080ardb/eth_ls2080rdb.c b/board/freescale/ls2080ardb/eth_ls2080rdb.c index 018d1dc6720..21b4c16ff27 100644 --- a/board/freescale/ls2080ardb/eth_ls2080rdb.c +++ b/board/freescale/ls2080ardb/eth_ls2080rdb.c @@ -13,6 +13,7 @@ #include <miiphy.h> #include <phy.h> #include <fm_eth.h> +#include <asm/global_data.h> #include <asm/io.h> #include <exports.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index c7e9c1dacf4..26ce5a80edf 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -11,6 +11,7 @@ #include <netdev.h> #include <fsl_ifc.h> #include <fsl_ddr.h> +#include <asm/global_data.h> #include <asm/io.h> #include <hwconfig.h> #include <fdt_support.h> diff --git a/board/freescale/lx2160a/ddr.c b/board/freescale/lx2160a/ddr.c index cd422bf2bc5..7ab7a9e6ca8 100644 --- a/board/freescale/lx2160a/ddr.c +++ b/board/freescale/lx2160a/ddr.c @@ -6,6 +6,7 @@ #include <common.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> +#include <asm/global_data.h>
diff --git a/board/freescale/lx2160a/eth_lx2160aqds.c b/board/freescale/lx2160a/eth_lx2160aqds.c index fcace029360..437f0bc4cf6 100644 --- a/board/freescale/lx2160a/eth_lx2160aqds.c +++ b/board/freescale/lx2160a/eth_lx2160aqds.c @@ -17,6 +17,7 @@ #include <miiphy.h> #include <phy.h> #include <fm_eth.h> +#include <asm/global_data.h> #include <asm/io.h> #include <exports.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/lx2160a/eth_lx2160ardb.c b/board/freescale/lx2160a/eth_lx2160ardb.c index b448883ee14..02f36f4f5f5 100644 --- a/board/freescale/lx2160a/eth_lx2160ardb.c +++ b/board/freescale/lx2160a/eth_lx2160ardb.c @@ -14,6 +14,7 @@ #include <miiphy.h> #include <phy.h> #include <fm_eth.h> +#include <asm/global_data.h> #include <asm/io.h> #include <exports.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index 0ff987eeb4e..80a42c147cc 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -7,6 +7,7 @@ #include <clock_legacy.h> #include <dm.h> #include <init.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_pl01x.h> #include <i2c.h> #include <malloc.h> diff --git a/board/freescale/m5208evbe/m5208evbe.c b/board/freescale/m5208evbe/m5208evbe.c index a950030eb39..7bfb4557dd5 100644 --- a/board/freescale/m5208evbe/m5208evbe.c +++ b/board/freescale/m5208evbe/m5208evbe.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m52277evb/m52277evb.c b/board/freescale/m52277evb/m52277evb.c index 144e490479e..510af33e4c3 100644 --- a/board/freescale/m52277evb/m52277evb.c +++ b/board/freescale/m52277evb/m52277evb.c @@ -9,6 +9,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m5235evb/m5235evb.c b/board/freescale/m5235evb/m5235evb.c index 5d403937553..e7c7a94036b 100644 --- a/board/freescale/m5235evb/m5235evb.c +++ b/board/freescale/m5235evb/m5235evb.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h>
diff --git a/board/freescale/m5249evb/m5249evb.c b/board/freescale/m5249evb/m5249evb.c index a89d5100586..48c00791114 100644 --- a/board/freescale/m5249evb/m5249evb.c +++ b/board/freescale/m5249evb/m5249evb.c @@ -8,6 +8,7 @@ #include <command.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <linux/delay.h>
diff --git a/board/freescale/m5253demo/m5253demo.c b/board/freescale/m5253demo/m5253demo.c index 9a157db6014..2a4703579da 100644 --- a/board/freescale/m5253demo/m5253demo.c +++ b/board/freescale/m5253demo/m5253demo.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <netdev.h> #include <asm/io.h> diff --git a/board/freescale/m5272c3/m5272c3.c b/board/freescale/m5272c3/m5272c3.c index 1017ef0c2a5..9580cf2a039 100644 --- a/board/freescale/m5272c3/m5272c3.c +++ b/board/freescale/m5272c3/m5272c3.c @@ -8,6 +8,7 @@
diff --git a/board/freescale/m5275evb/m5275evb.c b/board/freescale/m5275evb/m5275evb.c index e65e6d0af58..1c4fb7232af 100644 --- a/board/freescale/m5275evb/m5275evb.c +++ b/board/freescale/m5275evb/m5275evb.c @@ -10,6 +10,7 @@
diff --git a/board/freescale/m5282evb/m5282evb.c b/board/freescale/m5282evb/m5282evb.c index 251be667d46..e1ea9b3a58f 100644 --- a/board/freescale/m5282evb/m5282evb.c +++ b/board/freescale/m5282evb/m5282evb.c @@ -6,6 +6,7 @@
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/m53017evb/m53017evb.c b/board/freescale/m53017evb/m53017evb.c index f13b6931ea2..c9f89353ce4 100644 --- a/board/freescale/m53017evb/m53017evb.c +++ b/board/freescale/m53017evb/m53017evb.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m5329evb/m5329evb.c b/board/freescale/m5329evb/m5329evb.c index 531894f6516..7a75b04dd0d 100644 --- a/board/freescale/m5329evb/m5329evb.c +++ b/board/freescale/m5329evb/m5329evb.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m5373evb/m5373evb.c b/board/freescale/m5373evb/m5373evb.c index 29ff55f1596..cfa5ca4a477 100644 --- a/board/freescale/m5373evb/m5373evb.c +++ b/board/freescale/m5373evb/m5373evb.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m54418twr/m54418twr.c b/board/freescale/m54418twr/m54418twr.c index a418fba1401..ca8993197e3 100644 --- a/board/freescale/m54418twr/m54418twr.c +++ b/board/freescale/m54418twr/m54418twr.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/immap.h> #include <mmc.h> diff --git a/board/freescale/m54451evb/m54451evb.c b/board/freescale/m54451evb/m54451evb.c index 1298bd324e9..a4ddc69166b 100644 --- a/board/freescale/m54451evb/m54451evb.c +++ b/board/freescale/m54451evb/m54451evb.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m54455evb/m54455evb.c b/board/freescale/m54455evb/m54455evb.c index 286300645b4..c749ee407e7 100644 --- a/board/freescale/m54455evb/m54455evb.c +++ b/board/freescale/m54455evb/m54455evb.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m547xevb/m547xevb.c b/board/freescale/m547xevb/m547xevb.c index 908a500f4b9..1568f455e92 100644 --- a/board/freescale/m547xevb/m547xevb.c +++ b/board/freescale/m547xevb/m547xevb.c @@ -11,6 +11,7 @@ #include <common.h> #include <init.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m548xevb/m548xevb.c b/board/freescale/m548xevb/m548xevb.c index 796b808e6f9..b62355a7ae7 100644 --- a/board/freescale/m548xevb/m548xevb.c +++ b/board/freescale/m548xevb/m548xevb.c @@ -11,6 +11,7 @@ #include <common.h> #include <init.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/mpc8308rdb/sdram.c b/board/freescale/mpc8308rdb/sdram.c index 6e0922cd53c..6340fd16ea9 100644 --- a/board/freescale/mpc8308rdb/sdram.c +++ b/board/freescale/mpc8308rdb/sdram.c @@ -14,6 +14,7 @@ #include <common.h> #include <init.h> #include <mpc83xx.h> +#include <asm/global_data.h>
#include <asm/bitops.h> #include <asm/io.h> diff --git a/board/freescale/mpc8313erdb/mpc8313erdb.c b/board/freescale/mpc8313erdb/mpc8313erdb.c index 65a10c345ae..f309961dca8 100644 --- a/board/freescale/mpc8313erdb/mpc8313erdb.c +++ b/board/freescale/mpc8313erdb/mpc8313erdb.c @@ -20,6 +20,7 @@ #if defined(CONFIG_MPC83XX_GPIO) && !defined(CONFIG_SPL_BUILD) #include <asm/gpio.h> #endif +#include <asm/global_data.h>
diff --git a/board/freescale/mpc8313erdb/sdram.c b/board/freescale/mpc8313erdb/sdram.c index 99f6bcd5a93..f146ae5d43c 100644 --- a/board/freescale/mpc8313erdb/sdram.c +++ b/board/freescale/mpc8313erdb/sdram.c @@ -11,6 +11,7 @@ #include <init.h> #include <mpc83xx.h> #include <spd_sdram.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/bitops.h> diff --git a/board/freescale/mpc8315erdb/mpc8315erdb.c b/board/freescale/mpc8315erdb/mpc8315erdb.c index f8e4599f13f..795162b3c0c 100644 --- a/board/freescale/mpc8315erdb/mpc8315erdb.c +++ b/board/freescale/mpc8315erdb/mpc8315erdb.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <fdt_support.h> diff --git a/board/freescale/mpc8315erdb/sdram.c b/board/freescale/mpc8315erdb/sdram.c index 8a828207f93..ffbb79aaec1 100644 --- a/board/freescale/mpc8315erdb/sdram.c +++ b/board/freescale/mpc8315erdb/sdram.c @@ -11,6 +11,7 @@ #include <init.h> #include <mpc83xx.h> #include <spd_sdram.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/bitops.h> diff --git a/board/freescale/mpc8323erdb/mpc8323erdb.c b/board/freescale/mpc8323erdb/mpc8323erdb.c index 3cde715e96b..cef3216a6fe 100644 --- a/board/freescale/mpc8323erdb/mpc8323erdb.c +++ b/board/freescale/mpc8323erdb/mpc8323erdb.c @@ -19,6 +19,7 @@ #include <i2c.h> #include <miiphy.h> #include <command.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <u-boot/crc.h> diff --git a/board/freescale/mpc832xemds/mpc832xemds.c b/board/freescale/mpc832xemds/mpc832xemds.c index 6139cbd0409..f34758a9470 100644 --- a/board/freescale/mpc832xemds/mpc832xemds.c +++ b/board/freescale/mpc832xemds/mpc832xemds.c @@ -16,6 +16,7 @@ #if defined(CONFIG_PCI) #include <pci.h> #endif +#include <asm/global_data.h> #include <asm/mmu.h> #if defined(CONFIG_OF_LIBFDT) #include <linux/libfdt.h> diff --git a/board/freescale/mpc8349emds/mpc8349emds.c b/board/freescale/mpc8349emds/mpc8349emds.c index 46be5ccd92c..5f38639afd4 100644 --- a/board/freescale/mpc8349emds/mpc8349emds.c +++ b/board/freescale/mpc8349emds/mpc8349emds.c @@ -10,6 +10,7 @@ #include <ioports.h> #include <mpc83xx.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/mpc8349_pci.h> #include <i2c.h> #include <spi.h> diff --git a/board/freescale/mpc8349itx/mpc8349itx.c b/board/freescale/mpc8349itx/mpc8349itx.c index a265a8380fe..5b4c290df14 100644 --- a/board/freescale/mpc8349itx/mpc8349itx.c +++ b/board/freescale/mpc8349itx/mpc8349itx.c @@ -18,6 +18,7 @@ #endif #include <spd_sdram.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/mmu.h> #if defined(CONFIG_OF_LIBFDT) #include <linux/libfdt.h> diff --git a/board/freescale/mpc837xemds/mpc837xemds.c b/board/freescale/mpc837xemds/mpc837xemds.c index f515299bc9a..71875cf8f8e 100644 --- a/board/freescale/mpc837xemds/mpc837xemds.c +++ b/board/freescale/mpc837xemds/mpc837xemds.c @@ -10,6 +10,7 @@ #include <init.h> #include <net.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/fsl_mpc83xx_serdes.h> #include <spd_sdram.h> diff --git a/board/freescale/mpc837xerdb/mpc837xerdb.c b/board/freescale/mpc837xerdb/mpc837xerdb.c index 39673ad076a..81d31f19c4c 100644 --- a/board/freescale/mpc837xerdb/mpc837xerdb.c +++ b/board/freescale/mpc837xerdb/mpc837xerdb.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <init.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/fsl_mpc83xx_serdes.h> #include <fdt_support.h> diff --git a/board/freescale/mpc8610hpcd/mpc8610hpcd.c b/board/freescale/mpc8610hpcd/mpc8610hpcd.c index 52bf4da98ea..74b0e45b4f8 100644 --- a/board/freescale/mpc8610hpcd/mpc8610hpcd.c +++ b/board/freescale/mpc8610hpcd/mpc8610hpcd.c @@ -9,6 +9,7 @@ #include <log.h> #include <net.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/immap_86xx.h> #include <asm/fsl_pci.h> diff --git a/board/freescale/mpc8641hpcn/mpc8641hpcn.c b/board/freescale/mpc8641hpcn/mpc8641hpcn.c index 0f9aea469b1..b30b86364d5 100644 --- a/board/freescale/mpc8641hpcn/mpc8641hpcn.c +++ b/board/freescale/mpc8641hpcn/mpc8641hpcn.c @@ -8,6 +8,7 @@ #include <log.h> #include <net.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/immap_86xx.h> #include <asm/fsl_pci.h> diff --git a/board/freescale/mx23evk/mx23evk.c b/board/freescale/mx23evk/mx23evk.c index 3fbac6b5cc3..605cdec218a 100644 --- a/board/freescale/mx23evk/mx23evk.c +++ b/board/freescale/mx23evk/mx23evk.c @@ -13,6 +13,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> diff --git a/board/freescale/mx25pdk/mx25pdk.c b/board/freescale/mx25pdk/mx25pdk.c index 1cffdd93317..3b445a46dd7 100644 --- a/board/freescale/mx25pdk/mx25pdk.c +++ b/board/freescale/mx25pdk/mx25pdk.c @@ -7,6 +7,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/imx-regs.h> diff --git a/board/freescale/mx28evk/mx28evk.c b/board/freescale/mx28evk/mx28evk.c index a6b66d99ccb..21c9cb11283 100644 --- a/board/freescale/mx28evk/mx28evk.c +++ b/board/freescale/mx28evk/mx28evk.c @@ -14,6 +14,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/freescale/mx35pdk/mx35pdk.c b/board/freescale/mx35pdk/mx35pdk.c index fc024c47dbd..4039d9f049a 100644 --- a/board/freescale/mx35pdk/mx35pdk.c +++ b/board/freescale/mx35pdk/mx35pdk.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h> #include <linux/errno.h> diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 4250efddde7..ac48e7668c0 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/imx-regs.h> diff --git a/board/freescale/mx53ard/mx53ard.c b/board/freescale/mx53ard/mx53ard.c index d265d3adaa6..f9ec5ca6ef3 100644 --- a/board/freescale/mx53ard/mx53ard.c +++ b/board/freescale/mx53ard/mx53ard.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/mx53evk/mx53evk.c b/board/freescale/mx53evk/mx53evk.c index ef6c6ec1ed6..b006638e2c1 100644 --- a/board/freescale/mx53evk/mx53evk.c +++ b/board/freescale/mx53evk/mx53evk.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index 1da263bb5d5..ee54a61d874 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/mx53smd/mx53smd.c b/board/freescale/mx53smd/mx53smd.c index 7c0f98a1321..2f91a0525c4 100644 --- a/board/freescale/mx53smd/mx53smd.c +++ b/board/freescale/mx53smd/mx53smd.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/mx6memcal/mx6memcal.c b/board/freescale/mx6memcal/mx6memcal.c index ea7a56369d6..1cc744fa9ba 100644 --- a/board/freescale/mx6memcal/mx6memcal.c +++ b/board/freescale/mx6memcal/mx6memcal.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h>
diff --git a/board/freescale/mx6memcal/spl.c b/board/freescale/mx6memcal/spl.c index c11eee51b61..c82b532f6d5 100644 --- a/board/freescale/mx6memcal/spl.c +++ b/board/freescale/mx6memcal/spl.c @@ -7,6 +7,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/iomux.h> #include <asm/arch/clock.h> diff --git a/board/freescale/mx6qarm2/mx6qarm2.c b/board/freescale/mx6qarm2/mx6qarm2.c index ddde245869a..c06fd643677 100644 --- a/board/freescale/mx6qarm2/mx6qarm2.c +++ b/board/freescale/mx6qarm2/mx6qarm2.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index c031cf8538e..e92ef26d0ad 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -9,6 +9,7 @@ #include <image.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 0d343da519f..bc28173668e 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -12,6 +12,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <asm/mach-imx/spi.h> #include <env.h> #include <linux/errno.h> diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index 5d2f815d234..2c90a35e2c9 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -14,6 +14,7 @@ #include <asm/arch/mx6-ddr.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> diff --git a/board/freescale/mx6sllevk/mx6sllevk.c b/board/freescale/mx6sllevk/mx6sllevk.c index 0a36b46e9e8..b4fddafe640 100644 --- a/board/freescale/mx6sllevk/mx6sllevk.c +++ b/board/freescale/mx6sllevk/mx6sllevk.c @@ -10,6 +10,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c b/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c index 1640f465bad..7340a344023 100644 --- a/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c +++ b/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c @@ -13,6 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index 7fb8de177bc..57fab238641 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -13,6 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index 9cb17594013..b916ea01029 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -12,6 +12,7 @@ #include <asm/arch/mx6ul_pins.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/freescale/mx6ullevk/mx6ullevk.c b/board/freescale/mx6ullevk/mx6ullevk.c index 3f1ecce10f8..86c11c7bd3a 100644 --- a/board/freescale/mx6ullevk/mx6ullevk.c +++ b/board/freescale/mx6ullevk/mx6ullevk.c @@ -10,6 +10,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index f12e9d4cfef..2777ae13bce 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -9,6 +9,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/board/freescale/mx7ulp_evk/mx7ulp_evk.c b/board/freescale/mx7ulp_evk/mx7ulp_evk.c index fd21591ad6f..01e32136532 100644 --- a/board/freescale/mx7ulp_evk/mx7ulp_evk.c +++ b/board/freescale/mx7ulp_evk/mx7ulp_evk.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdt_support.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mx7ulp-pins.h> diff --git a/board/freescale/p1010rdb/ddr.c b/board/freescale/p1010rdb/ddr.c index 71f6259b60e..2625195f81b 100644 --- a/board/freescale/p1010rdb/ddr.c +++ b/board/freescale/p1010rdb/ddr.c @@ -5,6 +5,7 @@
#include <common.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <asm/immap_85xx.h> #include <asm/processor.h> diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index 4c3a03e7cd9..7e007da87c5 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -9,6 +9,7 @@ #include <image.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #include <asm/cache.h> diff --git a/board/freescale/p1010rdb/spl.c b/board/freescale/p1010rdb/spl.c index fbaa6a65142..f1239f9c502 100644 --- a/board/freescale/p1010rdb/spl.c +++ b/board/freescale/p1010rdb/spl.c @@ -15,6 +15,7 @@ #include <i2c.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/spl.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/p1023rdb/p1023rdb.c b/board/freescale/p1023rdb/p1023rdb.c new file mode 100644 index 00000000000..50c42a1b8ee --- /dev/null +++ b/board/freescale/p1023rdb/p1023rdb.c @@ -0,0 +1,161 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Authors: Roy Zang tie-fei.zang@freescale.com + * Chunhe Lan Chunhe.Lan@freescale.com + */ + +#include <common.h> +#include <command.h> +#include <env.h> +#include <image.h> +#include <init.h> +#include <net.h> +#include <pci.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/cache.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_pci.h> +#include <fsl_ddr_sdram.h> +#include <asm/fsl_portals.h> +#include <fsl_qbman.h> +#include <linux/libfdt.h> +#include <fdt_support.h> +#include <netdev.h> +#include <malloc.h> +#include <fm_eth.h> +#include <fsl_mdio.h> +#include <miiphy.h> +#include <phy.h> +#include <fsl_dtsec.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + fsl_lbc_t *lbc = LBC_BASE_ADDR; + + /* Set ABSWP to implement conversion of addresses in the LBC */ + setbits_be32(&lbc->lbcr, CONFIG_SYS_LBC_LBCR); + + return 0; +} + +int checkboard(void) +{ + printf("Board: P1023 RDB\n"); + + return 0; +} + +#ifdef CONFIG_PCI +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} +#endif + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + int flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + if (flash_esel == -1) { + /* very unlikely unless something is messed up */ + puts("Error: Could not find TLB for FLASH BASE\n"); + flash_esel = 2; /* give our best effort to continue */ + } else { + /* invalidate existing TLB entry for flash + promjet */ + disable_tlb(flash_esel); + } + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + setup_qbman_portals(); + + return 0; +} + +unsigned long get_board_sys_clk(ulong dummy) +{ + return gd->bus_clk; +} + +unsigned long get_board_ddr_clk(ulong dummy) +{ + return gd->mem_clk; +} + +int board_eth_init(struct bd_info *bis) +{ + ccsr_gur_t *gur = (ccsr_gur_t *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + struct fsl_pq_mdio_info dtsec_mdio_info; + + /* + * Need to set dTSEC 1 pin multiplexing to TSEC. The default setting + * is not correct. + */ + setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_TSEC1_1); + + dtsec_mdio_info.regs = + (struct tsec_mii_mng *)CONFIG_SYS_FM1_DTSEC1_MDIO_ADDR; + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fsl_pq_mdio_init(bis, &dtsec_mdio_info); + + fm_info_set_phy_address(FM1_DTSEC1, CONFIG_SYS_FM1_DTSEC1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, CONFIG_SYS_FM1_DTSEC2_PHY_ADDR); + + fm_info_set_mdio(FM1_DTSEC1, + miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME)); + fm_info_set_mdio(FM1_DTSEC2, + miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME)); + +#ifdef CONFIG_FMAN_ENET + cpu_eth_init(bis); +#endif + + return pci_eth_init(bis); +} + +#if defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, struct bd_info *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = env_get_bootm_low(); + size = env_get_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + +#ifdef CONFIG_HAS_FSL_DR_USB + fsl_fdt_fixup_dr_usb(blob, bd); +#endif + +#ifdef CONFIG_SYS_DPAA_FMAN +#ifndef CONFIG_DM_ETH + fdt_fixup_fman_ethernet(blob); +#endif +#endif + return 0; +} +#endif diff --git a/board/freescale/p1_p2_rdb_pc/spl.c b/board/freescale/p1_p2_rdb_pc/spl.c index 8aceceb56a3..c916651e8af 100644 --- a/board/freescale/p1_p2_rdb_pc/spl.c +++ b/board/freescale/p1_p2_rdb_pc/spl.c @@ -16,6 +16,7 @@ #include <i2c.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/spl.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/p2041rdb/ddr.c b/board/freescale/p2041rdb/ddr.c index 7a06c7af3dc..910058cefe1 100644 --- a/board/freescale/p2041rdb/ddr.c +++ b/board/freescale/p2041rdb/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/p2041rdb/p2041rdb.c b/board/freescale/p2041rdb/p2041rdb.c index 720d304fe42..4ece1e6ea0a 100644 --- a/board/freescale/p2041rdb/p2041rdb.c +++ b/board/freescale/p2041rdb/p2041rdb.c @@ -10,6 +10,7 @@ #include <image.h> #include <init.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/qemu-ppce500/qemu-ppce500.c b/board/freescale/qemu-ppce500/qemu-ppce500.c index 3395377b4fe..aa5774fd797 100644 --- a/board/freescale/qemu-ppce500/qemu-ppce500.c +++ b/board/freescale/qemu-ppce500/qemu-ppce500.c @@ -12,6 +12,7 @@ #include <net.h> #include <pci.h> #include <time.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #include <asm/fsl_pci.h> diff --git a/board/freescale/s32v234evb/s32v234evb.c b/board/freescale/s32v234evb/s32v234evb.c index f381cfc2ad0..304f5acf3be 100644 --- a/board/freescale/s32v234evb/s32v234evb.c +++ b/board/freescale/s32v234evb/s32v234evb.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/siul.h> diff --git a/board/freescale/t102xrdb/ddr.c b/board/freescale/t102xrdb/ddr.c index 3640a479574..818c20cf1b5 100644 --- a/board/freescale/t102xrdb/ddr.c +++ b/board/freescale/t102xrdb/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/t102xrdb/spl.c b/board/freescale/t102xrdb/spl.c index 09dd88ac4ea..cb754a13712 100644 --- a/board/freescale/t102xrdb/spl.c +++ b/board/freescale/t102xrdb/spl.c @@ -14,6 +14,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/sleep.h" #include "../common/spl.h"
diff --git a/board/freescale/t102xrdb/t102xrdb.c b/board/freescale/t102xrdb/t102xrdb.c index bb775eb2d32..2770e104ee6 100644 --- a/board/freescale/t102xrdb/t102xrdb.c +++ b/board/freescale/t102xrdb/t102xrdb.c @@ -12,6 +12,7 @@ #include <image.h> #include <init.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/t104xrdb/ddr.c b/board/freescale/t104xrdb/ddr.c index e313bf99cf2..8351f7ce9db 100644 --- a/board/freescale/t104xrdb/ddr.c +++ b/board/freescale/t104xrdb/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/t104xrdb/spl.c b/board/freescale/t104xrdb/spl.c index e7922954de7..6694e1de24d 100644 --- a/board/freescale/t104xrdb/spl.c +++ b/board/freescale/t104xrdb/spl.c @@ -14,6 +14,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/sleep.h" #include "../common/spl.h"
diff --git a/board/freescale/t104xrdb/t104xrdb.c b/board/freescale/t104xrdb/t104xrdb.c index c7290e5a342..780043483df 100644 --- a/board/freescale/t104xrdb/t104xrdb.c +++ b/board/freescale/t104xrdb/t104xrdb.c @@ -12,6 +12,7 @@ #include <init.h> #include <log.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/t208xqds/ddr.c b/board/freescale/t208xqds/ddr.c index 3317f99c81f..56471b3988b 100644 --- a/board/freescale/t208xqds/ddr.c +++ b/board/freescale/t208xqds/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/t208xqds/spl.c b/board/freescale/t208xqds/spl.c index d8c2bbe28df..147c3e9f33f 100644 --- a/board/freescale/t208xqds/spl.c +++ b/board/freescale/t208xqds/spl.c @@ -14,6 +14,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/qixis.h" #include "t208xqds_qixis.h" #include "../common/spl.h" diff --git a/board/freescale/t208xqds/t208xqds.c b/board/freescale/t208xqds/t208xqds.c index f3af8d52925..dedf722c695 100644 --- a/board/freescale/t208xqds/t208xqds.c +++ b/board/freescale/t208xqds/t208xqds.c @@ -13,6 +13,7 @@ #include <init.h> #include <log.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/t208xrdb/ddr.c b/board/freescale/t208xrdb/ddr.c index 6a09d1cd221..1fbab36e1a2 100644 --- a/board/freescale/t208xrdb/ddr.c +++ b/board/freescale/t208xrdb/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/t208xrdb/spl.c b/board/freescale/t208xrdb/spl.c index c64bd871159..f4be05be0a2 100644 --- a/board/freescale/t208xrdb/spl.c +++ b/board/freescale/t208xrdb/spl.c @@ -14,6 +14,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/spl.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/t208xrdb/t208xrdb.c b/board/freescale/t208xrdb/t208xrdb.c index d37abb7ef3b..a18459841c6 100644 --- a/board/freescale/t208xrdb/t208xrdb.c +++ b/board/freescale/t208xrdb/t208xrdb.c @@ -11,6 +11,7 @@ #include <image.h> #include <init.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/t4rdb/ddr.c b/board/freescale/t4rdb/ddr.c index 5b7d10c9798..57cbde154f0 100644 --- a/board/freescale/t4rdb/ddr.c +++ b/board/freescale/t4rdb/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/t4rdb/spl.c b/board/freescale/t4rdb/spl.c index 9aa0a9b0523..2dabee9d5a9 100644 --- a/board/freescale/t4rdb/spl.c +++ b/board/freescale/t4rdb/spl.c @@ -10,6 +10,7 @@ #include <console.h> #include <env_internal.h> #include <init.h> +#include <asm/global_data.h> #include <asm/spl.h> #include <malloc.h> #include <ns16550.h> diff --git a/board/freescale/t4rdb/t4240rdb.c b/board/freescale/t4rdb/t4240rdb.c index 5c2a75b905e..6ab35ca9185 100644 --- a/board/freescale/t4rdb/t4240rdb.c +++ b/board/freescale/t4rdb/t4240rdb.c @@ -11,6 +11,7 @@ #include <image.h> #include <init.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/vf610twr/vf610twr.c b/board/freescale/vf610twr/vf610twr.c index bd125bc17e0..98cb0140ad0 100644 --- a/board/freescale/vf610twr/vf610twr.c +++ b/board/freescale/vf610twr/vf610twr.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux-vf610.h> diff --git a/board/friendlyarm/nanopi2/board.c b/board/friendlyarm/nanopi2/board.c index 68980536abe..c0fe2d546f6 100644 --- a/board/friendlyarm/nanopi2/board.c +++ b/board/friendlyarm/nanopi2/board.c @@ -12,6 +12,7 @@ #ifdef CONFIG_PWM_NX #include <pwm.h> #endif +#include <asm/global_data.h> #include <asm/io.h>
#include <asm/arch/nexell.h> diff --git a/board/gardena/smart-gateway-at91sam/board.c b/board/gardena/smart-gateway-at91sam/board.c index 45c947fcbb4..3f402cfeee8 100644 --- a/board/gardena/smart-gateway-at91sam/board.c +++ b/board/gardena/smart-gateway-at91sam/board.c @@ -11,6 +11,7 @@ #include <led.h> #include <asm/arch/at91_common.h> #include <asm/arch/clk.h> +#include <asm/global_data.h>
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 9f043d815ab..bf4d6913067 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -15,6 +15,7 @@ #include <asm/arch/mx6-pins.h> #include <asm/arch/mxc_hdmi.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/sata.h> diff --git a/board/gdsys/a38x/controlcenterdc.c b/board/gdsys/a38x/controlcenterdc.c index a2287f9deb1..ba57a272187 100644 --- a/board/gdsys/a38x/controlcenterdc.c +++ b/board/gdsys/a38x/controlcenterdc.c @@ -11,6 +11,7 @@ #include <miiphy.h> #include <net.h> #include <tpm-v1.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm-generic/gpio.h> diff --git a/board/gdsys/a38x/hydra.c b/board/gdsys/a38x/hydra.c index daade6da0af..495a9769188 100644 --- a/board/gdsys/a38x/hydra.c +++ b/board/gdsys/a38x/hydra.c @@ -1,6 +1,7 @@ #include <common.h> #include <command.h> #include <console.h> /* ctrlc */ +#include <pci.h> #include <asm/io.h>
#include "hydra.h" diff --git a/board/gdsys/mpc8308/gazerbeam.c b/board/gdsys/mpc8308/gazerbeam.c index c317260251e..68a9595511c 100644 --- a/board/gdsys/mpc8308/gazerbeam.c +++ b/board/gdsys/mpc8308/gazerbeam.c @@ -17,6 +17,7 @@ #include <misc.h> #include <tpm-v1.h> #include <video_osd.h> +#include <asm/global_data.h>
#include "../common/ihs_mdio.h" #include "../../../drivers/board/gazerbeam.h" diff --git a/board/gdsys/mpc8308/sdram.c b/board/gdsys/mpc8308/sdram.c index 9695fb0a10d..bfd55f54e4e 100644 --- a/board/gdsys/mpc8308/sdram.c +++ b/board/gdsys/mpc8308/sdram.c @@ -19,6 +19,7 @@ #include <spd_sdram.h>
#include <asm/processor.h> diff --git a/board/ge/bx50v3/bx50v3.c b/board/ge/bx50v3/bx50v3.c index cf76cf7a338..be5fb0e49cc 100644 --- a/board/ge/bx50v3/bx50v3.c +++ b/board/ge/bx50v3/bx50v3.c @@ -12,6 +12,7 @@ #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> #include <env.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <linux/libfdt.h> diff --git a/board/ge/mx53ppd/mx53ppd.c b/board/ge/mx53ppd/mx53ppd.c index 7627e9c370f..4de82cd5cd2 100644 --- a/board/ge/mx53ppd/mx53ppd.c +++ b/board/ge/mx53ppd/mx53ppd.c @@ -10,6 +10,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/google/imx8mq_phanbell/imx8mq_phanbell.c b/board/google/imx8mq_phanbell/imx8mq_phanbell.c index 746071b4150..d0a740dd3f4 100644 --- a/board/google/imx8mq_phanbell/imx8mq_phanbell.c +++ b/board/google/imx8mq_phanbell/imx8mq_phanbell.c @@ -8,6 +8,7 @@ #include <init.h> #include <malloc.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/google/imx8mq_phanbell/spl.c b/board/google/imx8mq_phanbell/spl.c index 06a3f4c1aa8..eec3f3d931b 100644 --- a/board/google/imx8mq_phanbell/spl.c +++ b/board/google/imx8mq_phanbell/spl.c @@ -6,6 +6,7 @@
#include <common.h> #include <hang.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <init.h> diff --git a/board/google/veyron/veyron.c b/board/google/veyron/veyron.c index 391d973c0b6..32dbcdc4d10 100644 --- a/board/google/veyron/veyron.c +++ b/board/google/veyron/veyron.c @@ -9,6 +9,7 @@ #include <init.h> #include <log.h> #include <asm/arch-rockchip/clock.h> +#include <asm/global_data.h> #include <dt-bindings/clock/rk3288-cru.h> #include <linux/delay.h> #include <linux/err.h> diff --git a/board/grinn/chiliboard/board.c b/board/grinn/chiliboard/board.c index 8cc9278287b..12480f5729d 100644 --- a/board/grinn/chiliboard/board.c +++ b/board/grinn/chiliboard/board.c @@ -16,6 +16,7 @@ #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> #include <asm/emif.h> +#include <asm/global_data.h> #include <asm/io.h> #include <cpsw.h> #include <env.h> diff --git a/board/grinn/liteboard/board.c b/board/grinn/liteboard/board.c index 578d75aed3d..48392c48e5c 100644 --- a/board/grinn/liteboard/board.c +++ b/board/grinn/liteboard/board.c @@ -15,6 +15,7 @@ #include <asm/arch/mx6ul_pins.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/highbank/highbank.c b/board/highbank/highbank.c index e07295c7b5c..a790d453da0 100644 --- a/board/highbank/highbank.c +++ b/board/highbank/highbank.c @@ -12,6 +12,7 @@ #include <net.h> #include <netdev.h> #include <scsi.h> +#include <asm/global_data.h>
#include <linux/sizes.h> #include <asm/io.h> diff --git a/board/hisilicon/hikey/hikey.c b/board/hisilicon/hikey/hikey.c index e89ff1a43de..5a858dec64e 100644 --- a/board/hisilicon/hikey/hikey.c +++ b/board/hisilicon/hikey/hikey.c @@ -9,6 +9,7 @@ #include <fdt_support.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_pl01x.h> #include <errno.h> #include <malloc.h> diff --git a/board/hisilicon/hikey960/hikey960.c b/board/hisilicon/hikey960/hikey960.c index db485db10a9..a14b9e44fa5 100644 --- a/board/hisilicon/hikey960/hikey960.c +++ b/board/hisilicon/hikey960/hikey960.c @@ -10,6 +10,7 @@ #include <errno.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hi3660.h> #include <asm/armv8/mmu.h> diff --git a/board/hisilicon/poplar/poplar.c b/board/hisilicon/poplar/poplar.c index 371c3c33fc8..486e37f90a6 100644 --- a/board/hisilicon/poplar/poplar.c +++ b/board/hisilicon/poplar/poplar.c @@ -9,6 +9,7 @@ #include <dm.h> #include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/platform_data/serial_pl01x.h> #include <asm/arch/hi3798cv200.h> diff --git a/board/ids/ids8313/ids8313.c b/board/ids/ids8313/ids8313.c index ac35b5b0d0c..45c77a249a9 100644 --- a/board/ids/ids8313/ids8313.c +++ b/board/ids/ids8313/ids8313.c @@ -17,6 +17,7 @@ #include <mpc83xx.h> #include <spi.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h>
diff --git a/board/imgtec/boston/ddr.c b/board/imgtec/boston/ddr.c index 241b3846687..182f79b9182 100644 --- a/board/imgtec/boston/ddr.c +++ b/board/imgtec/boston/ddr.c @@ -5,6 +5,7 @@
#include <asm/io.h>
diff --git a/board/imgtec/boston/dt.c b/board/imgtec/boston/dt.c index 44b56416ff9..bf772ff5dec 100644 --- a/board/imgtec/boston/dt.c +++ b/board/imgtec/boston/dt.c @@ -5,6 +5,7 @@
#include <common.h> #include <fdt_support.h> +#include <asm/global_data.h>
int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/imgtec/ci20/ci20.c b/board/imgtec/ci20/ci20.c index 038dbdd74f0..7ee175d40a5 100644 --- a/board/imgtec/ci20/ci20.c +++ b/board/imgtec/ci20/ci20.c @@ -11,6 +11,7 @@ #include <init.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <linux/bitops.h> diff --git a/board/imgtec/malta/malta.c b/board/imgtec/malta/malta.c index 252cc813c6e..c04f727961d 100644 --- a/board/imgtec/malta/malta.c +++ b/board/imgtec/malta/malta.c @@ -13,6 +13,7 @@ #include <pci_gt64120.h> #include <pci_msc01.h> #include <rtc.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/addrspace.h> diff --git a/board/imgtec/xilfpga/xilfpga.c b/board/imgtec/xilfpga/xilfpga.c index 0b68bbde50f..6a836370e36 100644 --- a/board/imgtec/xilfpga/xilfpga.c +++ b/board/imgtec/xilfpga/xilfpga.c @@ -10,6 +10,7 @@
diff --git a/board/inversepath/usbarmory/usbarmory.c b/board/inversepath/usbarmory/usbarmory.c index 56a2a7c4a6e..086d0522c78 100644 --- a/board/inversepath/usbarmory/usbarmory.c +++ b/board/inversepath/usbarmory/usbarmory.c @@ -11,6 +11,7 @@ #include <command.h> #include <fs.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/iomega/iconnect/iconnect.c b/board/iomega/iconnect/iconnect.c index 79c794bfc89..fe4be28b13c 100644 --- a/board/iomega/iconnect/iconnect.c +++ b/board/iomega/iconnect/iconnect.c @@ -11,6 +11,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> +#include <asm/global_data.h> #include "iconnect.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/isee/igep003x/board.c b/board/isee/igep003x/board.c index 9b4cb91b341..02ae7df04db 100644 --- a/board/isee/igep003x/board.c +++ b/board/isee/igep003x/board.c @@ -21,6 +21,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/isee/igep00x0/common.c b/board/isee/igep00x0/common.c index 58c713f0f32..3fdf83e845c 100644 --- a/board/isee/igep00x0/common.c +++ b/board/isee/igep00x0/common.c @@ -2,6 +2,7 @@
#include <common.h> #include <twl4030.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/omap_mmc.h> #include <asm/arch/mux.h> diff --git a/board/k+p/kp_imx53/kp_imx53.c b/board/k+p/kp_imx53/kp_imx53.c index eb5b67d1e62..a5ee4a8a519 100644 --- a/board/k+p/kp_imx53/kp_imx53.c +++ b/board/k+p/kp_imx53/kp_imx53.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c index e60d556b303..110496d9950 100644 --- a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c +++ b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c @@ -12,6 +12,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/boot_mode.h> #include <env.h> #include <errno.h> diff --git a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c index 75fb6acfb3c..103c4531a64 100644 --- a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c +++ b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c @@ -13,6 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-ddr.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <spl.h> diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 03c7ce9da7d..d85a5eac165 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -15,6 +15,7 @@ #include <cli_hush.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/ctype.h> #include <linux/delay.h> diff --git a/board/keymile/km83xx/km83xx.c b/board/keymile/km83xx/km83xx.c index 9eb000cca4d..75284cc8cf2 100644 --- a/board/keymile/km83xx/km83xx.c +++ b/board/keymile/km83xx/km83xx.c @@ -22,6 +22,7 @@ #include <mpc83xx.h> #include <i2c.h> #include <miiphy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c index 7d191ab860b..f4235b377fc 100644 --- a/board/keymile/km_arm/km_arm.c +++ b/board/keymile/km_arm/km_arm.c @@ -20,6 +20,7 @@ #include <netdev.h> #include <miiphy.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/keymile/kmp204x/ddr.c b/board/keymile/kmp204x/ddr.c index d9c9ddf2bac..77a00c55c95 100644 --- a/board/keymile/kmp204x/ddr.c +++ b/board/keymile/kmp204x/ddr.c @@ -11,6 +11,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/kmc/kzm9g/kzm9g.c b/board/kmc/kzm9g/kzm9g.c index 4b406042180..02c87a031c3 100644 --- a/board/kmc/kzm9g/kzm9g.c +++ b/board/kmc/kzm9g/kzm9g.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <asm/gpio.h> diff --git a/board/kobol/helios4/helios4.c b/board/kobol/helios4/helios4.c index 17d2489415d..adb091ce4fd 100644 --- a/board/kobol/helios4/helios4.c +++ b/board/kobol/helios4/helios4.c @@ -10,6 +10,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/kontron/sl28/ddr.c b/board/kontron/sl28/ddr.c index d111b6d4c32..41426996ab9 100644 --- a/board/kontron/sl28/ddr.c +++ b/board/kontron/sl28/ddr.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <fsl_ddr_sdram.h>
diff --git a/board/kontron/sl28/sl28.c b/board/kontron/sl28/sl28.c index b18127c4d18..a3f5142525d 100644 --- a/board/kontron/sl28/sl28.c +++ b/board/kontron/sl28/sl28.c @@ -5,6 +5,7 @@ #include <errno.h> #include <fsl_ddr.h> #include <fdt_support.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <env_internal.h> #include <asm/arch-fsl-layerscape/soc.h> diff --git a/board/kosagi/novena/novena.c b/board/kosagi/novena/novena.c index b1939f8a56e..0e1b4a0a46c 100644 --- a/board/kosagi/novena/novena.c +++ b/board/kosagi/novena/novena.c @@ -10,6 +10,7 @@ #include <eeprom.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <ahci.h> #include <env.h> diff --git a/board/l+g/vinco/vinco.c b/board/l+g/vinco/vinco.c index b1593bab5eb..f221f05261a 100644 --- a/board/l+g/vinco/vinco.c +++ b/board/l+g/vinco/vinco.c @@ -11,6 +11,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> diff --git a/board/laird/wb45n/wb45n.c b/board/laird/wb45n/wb45n.c index df6eeb62434..5e1ef8a49ac 100644 --- a/board/laird/wb45n/wb45n.c +++ b/board/laird/wb45n/wb45n.c @@ -4,6 +4,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9x5_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/laird/wb50n/wb50n.c b/board/laird/wb50n/wb50n.c index 9cc21b2abd3..8fa989a2a4f 100644 --- a/board/laird/wb50n/wb50n.c +++ b/board/laird/wb50n/wb50n.c @@ -4,6 +4,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_sfr.h> #include <asm/arch/sama5d3_smc.h> diff --git a/board/lego/ev3/legoev3.c b/board/lego/ev3/legoev3.c index 51b669a891b..5e5c8c1198f 100644 --- a/board/lego/ev3/legoev3.c +++ b/board/lego/ev3/legoev3.c @@ -19,6 +19,7 @@ #include <spi_flash.h> #include <asm/arch/hardware.h> #include <asm/arch/pinmux_defs.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/davinci_misc.h> #include <linux/errno.h> diff --git a/board/lg/sniper/sniper.c b/board/lg/sniper/sniper.c index dff159025b1..0af833d5591 100644 --- a/board/lg/sniper/sniper.c +++ b/board/lg/sniper/sniper.c @@ -11,6 +11,7 @@ #include <env.h> #include <fastboot.h> #include <init.h> +#include <asm/global_data.h> #include <linux/ctype.h> #include <linux/usb/musb.h> #include <asm/omap_musb.h> diff --git a/board/liebherr/display5/display5.c b/board/liebherr/display5/display5.c index 5f447143019..e3a59dbec00 100644 --- a/board/liebherr/display5/display5.c +++ b/board/liebherr/display5/display5.c @@ -9,6 +9,7 @@ #include <fdt_support.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/liebherr/display5/spl.c b/board/liebherr/display5/spl.c index 23959c25573..b8658c8d617 100644 --- a/board/liebherr/display5/spl.c +++ b/board/liebherr/display5/spl.c @@ -12,6 +12,7 @@ #include <log.h> #include <serial.h> #include <spl.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <asm/io.h> diff --git a/board/liebherr/mccmon6/mccmon6.c b/board/liebherr/mccmon6/mccmon6.c index 71f75d877d2..1b49526fba4 100644 --- a/board/liebherr/mccmon6/mccmon6.c +++ b/board/liebherr/mccmon6/mccmon6.c @@ -12,6 +12,7 @@ #include <asm/arch/iomux.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c index 9286f4c755b..cd11b0ada77 100644 --- a/board/liebherr/xea/xea.c +++ b/board/liebherr/xea/xea.c @@ -18,6 +18,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/logicpd/am3517evm/am3517evm.c b/board/logicpd/am3517evm/am3517evm.c index cba51f54d41..f0141659282 100644 --- a/board/logicpd/am3517evm/am3517evm.c +++ b/board/logicpd/am3517evm/am3517evm.c @@ -16,6 +16,7 @@ #include <net.h> #include <ns16550.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/omap_musb.h> #include <asm/arch/am35x_def.h> diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index ba69c966869..0d53548dcb4 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -16,6 +16,7 @@ #include <mmc.h> #include <fsl_esdhc_imx.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <linux/sizes.h> diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 496886fea25..2379b521904 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -20,6 +20,7 @@ #include <i2c.h> #include <serial.h> #include <twl4030.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/mux.h> diff --git a/board/maxbcm/maxbcm.c b/board/maxbcm/maxbcm.c index 3c6422214f7..e92132ad19a 100644 --- a/board/maxbcm/maxbcm.c +++ b/board/maxbcm/maxbcm.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <miiphy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/mediatek/mt7622/mt7622_rfb.c b/board/mediatek/mt7622/mt7622_rfb.c index 6a5f936635c..0504d6177fd 100644 --- a/board/mediatek/mt7622/mt7622_rfb.c +++ b/board/mediatek/mt7622/mt7622_rfb.c @@ -8,6 +8,7 @@ #include <config.h> #include <env.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/board/mediatek/mt7623/mt7623_rfb.c b/board/mediatek/mt7623/mt7623_rfb.c index 984e75ccaf2..755e879085c 100644 --- a/board/mediatek/mt7623/mt7623_rfb.c +++ b/board/mediatek/mt7623/mt7623_rfb.c @@ -5,6 +5,7 @@
#include <common.h> #include <mmc.h> +#include <asm/global_data.h>
diff --git a/board/mediatek/mt7629/mt7629_rfb.c b/board/mediatek/mt7629/mt7629_rfb.c index 08468b50ea2..d1bca6d62ef 100644 --- a/board/mediatek/mt7629/mt7629_rfb.c +++ b/board/mediatek/mt7629/mt7629_rfb.c @@ -4,6 +4,7 @@ */
diff --git a/board/mediatek/mt8512/mt8512.c b/board/mediatek/mt8512/mt8512.c index 4ad62b73a6c..ac3adb80122 100644 --- a/board/mediatek/mt8512/mt8512.c +++ b/board/mediatek/mt8512/mt8512.c @@ -7,6 +7,7 @@ #include <dm.h> #include <log.h> #include <wdt.h> +#include <asm/global_data.h>
diff --git a/board/mediatek/mt8518/mt8518_ap1.c b/board/mediatek/mt8518/mt8518_ap1.c index c9acfcb1a56..fce5de6767c 100644 --- a/board/mediatek/mt8518/mt8518_ap1.c +++ b/board/mediatek/mt8518/mt8518_ap1.c @@ -7,6 +7,7 @@ #include <dm.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
diff --git a/board/menlo/m53menlo/m53menlo.c b/board/menlo/m53menlo/m53menlo.c index 893f6255999..c34baca602c 100644 --- a/board/menlo/m53menlo/m53menlo.c +++ b/board/menlo/m53menlo/m53menlo.c @@ -10,6 +10,7 @@ #include <dm.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/mikrotik/crs3xx-98dx3236/crs3xx-98dx3236.c b/board/mikrotik/crs3xx-98dx3236/crs3xx-98dx3236.c index 8b419ef6f7e..315169ba661 100644 --- a/board/mikrotik/crs3xx-98dx3236/crs3xx-98dx3236.c +++ b/board/mikrotik/crs3xx-98dx3236/crs3xx-98dx3236.c @@ -6,6 +6,7 @@ #include <common.h> #include <i2c.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/bitops.h> #include <linux/mbus.h> diff --git a/board/mini-box/picosam9g45/picosam9g45.c b/board/mini-box/picosam9g45/picosam9g45.c index e8e1ac3eb19..5d6cb24966d 100644 --- a/board/mini-box/picosam9g45/picosam9g45.c +++ b/board/mini-box/picosam9g45/picosam9g45.c @@ -13,6 +13,7 @@ #include <common.h> #include <init.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clk.h> #include <asm/arch/at91sam9g45_matrix.h> diff --git a/board/mpc8308_p1m/sdram.c b/board/mpc8308_p1m/sdram.c index cbf8781746e..62a2d8a53af 100644 --- a/board/mpc8308_p1m/sdram.c +++ b/board/mpc8308_p1m/sdram.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <mpc83xx.h> +#include <asm/global_data.h>
#include <asm/bitops.h> #include <asm/io.h> diff --git a/board/mscc/jr2/jr2.c b/board/mscc/jr2/jr2.c index 51700f4acff..1cd720c7d84 100644 --- a/board/mscc/jr2/jr2.c +++ b/board/mscc/jr2/jr2.c @@ -6,6 +6,7 @@ #include <common.h> #include <image.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <led.h> #include <miiphy.h> diff --git a/board/mscc/luton/luton.c b/board/mscc/luton/luton.c index acc26157c77..038902d08a9 100644 --- a/board/mscc/luton/luton.c +++ b/board/mscc/luton/luton.c @@ -6,6 +6,7 @@ #include <common.h> #include <image.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <led.h> #include <miiphy.h> diff --git a/board/mscc/ocelot/ocelot.c b/board/mscc/ocelot/ocelot.c index 74e8bfc4314..c462890bb85 100644 --- a/board/mscc/ocelot/ocelot.c +++ b/board/mscc/ocelot/ocelot.c @@ -7,6 +7,7 @@ #include <image.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/board/mscc/serval/serval.c b/board/mscc/serval/serval.c index ed1aea55cc2..94c1c42b79b 100644 --- a/board/mscc/serval/serval.c +++ b/board/mscc/serval/serval.c @@ -6,6 +6,7 @@ #include <common.h> #include <image.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <led.h> #include <miiphy.h> diff --git a/board/mscc/servalt/servalt.c b/board/mscc/servalt/servalt.c index 879f5de5067..252d8e3156d 100644 --- a/board/mscc/servalt/servalt.c +++ b/board/mscc/servalt/servalt.c @@ -6,6 +6,7 @@ #include <common.h> #include <image.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <led.h>
diff --git a/board/myir/mys_6ulx/mys_6ulx.c b/board/myir/mys_6ulx/mys_6ulx.c index d886af05bea..847497bcba7 100644 --- a/board/myir/mys_6ulx/mys_6ulx.c +++ b/board/myir/mys_6ulx/mys_6ulx.c @@ -9,6 +9,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> #include <fsl_esdhc_imx.h> diff --git a/board/nokia/rx51/rx51.c b/board/nokia/rx51/rx51.c index f624dbfbebc..65be1719c2c 100644 --- a/board/nokia/rx51/rx51.c +++ b/board/nokia/rx51/rx51.c @@ -29,6 +29,7 @@ #include <twl4030.h> #include <i2c.h> #include <video_fb.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/setup.h> #include <asm/bitops.h> diff --git a/board/novtech/meerkat96/meerkat96.c b/board/novtech/meerkat96/meerkat96.c index b13e7ce3b18..1edebe5db9b 100644 --- a/board/novtech/meerkat96/meerkat96.c +++ b/board/novtech/meerkat96/meerkat96.c @@ -9,6 +9,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> #include <common.h> diff --git a/board/olimex/mx23_olinuxino/mx23_olinuxino.c b/board/olimex/mx23_olinuxino/mx23_olinuxino.c index f13fdb8d47e..d1e189cbb6e 100644 --- a/board/olimex/mx23_olinuxino/mx23_olinuxino.c +++ b/board/olimex/mx23_olinuxino/mx23_olinuxino.c @@ -7,6 +7,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/iomux-mx23.h> diff --git a/board/phytec/pcl063/pcl063.c b/board/phytec/pcl063/pcl063.c index 9e6940f9c76..b2e435f6908 100644 --- a/board/phytec/pcl063/pcl063.c +++ b/board/phytec/pcl063/pcl063.c @@ -11,6 +11,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> #include <fsl_esdhc_imx.h> diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index b0c56a29f1f..f9cf4abd474 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -8,6 +8,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux-vf610.h> diff --git a/board/phytec/pcm058/pcm058.c b/board/phytec/pcm058/pcm058.c index 79c666588f4..5e5b129ef1f 100644 --- a/board/phytec/pcm058/pcm058.c +++ b/board/phytec/pcm058/pcm058.c @@ -14,6 +14,7 @@ #include <net.h> #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-ddr.h> +#include <asm/global_data.h> #include <asm/mach-imx/boot_mode.h> #include <asm/arch/sys_proto.h> #include <dm.h> diff --git a/board/phytec/pfla02/pfla02.c b/board/phytec/pfla02/pfla02.c index 3b10cc0f9f1..076ce6711ef 100644 --- a/board/phytec/pfla02/pfla02.c +++ b/board/phytec/pfla02/pfla02.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/phytec/phycore_am335x_r2/board.c b/board/phytec/phycore_am335x_r2/board.c index fb589068471..5ca94152049 100644 --- a/board/phytec/phycore_am335x_r2/board.c +++ b/board/phytec/phycore_am335x_r2/board.c @@ -17,6 +17,7 @@ #include <asm/arch/ddr_defs.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <power/tps65910.h> #include <jffs2/load_kernel.h> #include <mtd_node.h> diff --git a/board/phytec/phycore_rk3288/phycore-rk3288.c b/board/phytec/phycore_rk3288/phycore-rk3288.c index ecc73227a02..f588fc3b0c7 100644 --- a/board/phytec/phycore_rk3288/phycore-rk3288.c +++ b/board/phytec/phycore_rk3288/phycore-rk3288.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <dm.h> diff --git a/board/phytium/durian/durian.c b/board/phytium/durian/durian.c index b80688ae864..8a82a4591ac 100644 --- a/board/phytium/durian/durian.c +++ b/board/phytium/durian/durian.c @@ -12,6 +12,7 @@ #include <log.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/io.h> #include <linux/arm-smccc.h> diff --git a/board/ppcag/bg0900/bg0900.c b/board/ppcag/bg0900/bg0900.c index e8168e34682..578f5c73b6c 100644 --- a/board/ppcag/bg0900/bg0900.c +++ b/board/ppcag/bg0900/bg0900.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/qemu-mips/qemu-mips.c b/board/qemu-mips/qemu-mips.c index 7553d0b00de..f57091739ec 100644 --- a/board/qemu-mips/qemu-mips.c +++ b/board/qemu-mips/qemu-mips.c @@ -8,6 +8,7 @@ #include <command.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mipsregs.h> #include <asm/io.h> #include <netdev.h> diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 4d1dbd696dc..646013cfc93 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -13,6 +13,7 @@ #include <net.h> #include <usb.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <fdt_support.h> #include <asm/arch/dram.h> diff --git a/board/qualcomm/dragonboard820c/dragonboard820c.c b/board/qualcomm/dragonboard820c/dragonboard820c.c index c1ade5ce43a..877e34c2101 100644 --- a/board/qualcomm/dragonboard820c/dragonboard820c.c +++ b/board/qualcomm/dragonboard820c/dragonboard820c.c @@ -10,6 +10,7 @@ #include <asm/arch/sysmap-apq8096.h> #include <env.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/arm-smccc.h> #include <linux/psci.h> #include <common.h> diff --git a/board/raidsonic/ib62x0/ib62x0.c b/board/raidsonic/ib62x0/ib62x0.c index db1b0adc382..f9bc07649e0 100644 --- a/board/raidsonic/ib62x0/ib62x0.c +++ b/board/raidsonic/ib62x0/ib62x0.c @@ -9,6 +9,7 @@ #include <common.h> #include <init.h> #include <miiphy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index 279ed487216..854c47636d3 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -12,6 +12,7 @@ #include <init.h> #include <malloc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/blanche/blanche.c b/board/renesas/blanche/blanche.c index 2450fca7a58..9671382f2a3 100644 --- a/board/renesas/blanche/blanche.c +++ b/board/renesas/blanche/blanche.c @@ -15,6 +15,7 @@ #include <asm/arch/rmobile.h> #include <asm/arch/sh_sdhi.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/mach-types.h> diff --git a/board/renesas/condor/condor.c b/board/renesas/condor/condor.c index 8054511d9d6..4454061e071 100644 --- a/board/renesas/condor/condor.c +++ b/board/renesas/condor/condor.c @@ -10,6 +10,7 @@ #include <cpu_func.h> #include <hang.h> #include <init.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mach-types.h> #include <asm/io.h> diff --git a/board/renesas/draak/draak.c b/board/renesas/draak/draak.c index 9993f5bbe32..ffd52ebfe43 100644 --- a/board/renesas/draak/draak.c +++ b/board/renesas/draak/draak.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/renesas/eagle/eagle.c b/board/renesas/eagle/eagle.c index 6228f22e010..f9e553feaa7 100644 --- a/board/renesas/eagle/eagle.c +++ b/board/renesas/eagle/eagle.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/renesas/ebisu/ebisu.c b/board/renesas/ebisu/ebisu.c index c8d180566d4..82cd2a5800f 100644 --- a/board/renesas/ebisu/ebisu.c +++ b/board/renesas/ebisu/ebisu.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/renesas/gose/gose.c b/board/renesas/gose/gose.c index c6a93c25e6d..56cdc73b1a7 100644 --- a/board/renesas/gose/gose.c +++ b/board/renesas/gose/gose.c @@ -12,6 +12,7 @@ #include <init.h> #include <malloc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/grpeach/grpeach.c b/board/renesas/grpeach/grpeach.c index b92e01ca984..ac989eb29c2 100644 --- a/board/renesas/grpeach/grpeach.c +++ b/board/renesas/grpeach/grpeach.c @@ -7,6 +7,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h>
diff --git a/board/renesas/koelsch/koelsch.c b/board/renesas/koelsch/koelsch.c index 1b3acc8fd1f..b0a66ea2669 100644 --- a/board/renesas/koelsch/koelsch.c +++ b/board/renesas/koelsch/koelsch.c @@ -13,6 +13,7 @@ #include <init.h> #include <malloc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/lager/lager.c b/board/renesas/lager/lager.c index 36a35a9a9cf..add4eef3d53 100644 --- a/board/renesas/lager/lager.c +++ b/board/renesas/lager/lager.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/renesas/porter/porter.c b/board/renesas/porter/porter.c index 793e02cb440..b3e4c08d74d 100644 --- a/board/renesas/porter/porter.c +++ b/board/renesas/porter/porter.c @@ -13,6 +13,7 @@ #include <init.h> #include <malloc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/rcar-common/common.c b/board/renesas/rcar-common/common.c index 9762fb26384..e77357968a3 100644 --- a/board/renesas/rcar-common/common.c +++ b/board/renesas/rcar-common/common.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <init.h> +#include <asm/global_data.h> #include <dm/uclass-internal.h> #include <asm/arch/rmobile.h> #include <linux/libfdt.h> diff --git a/board/renesas/salvator-x/salvator-x.c b/board/renesas/salvator-x/salvator-x.c index c78c2a42b02..08ed725521c 100644 --- a/board/renesas/salvator-x/salvator-x.c +++ b/board/renesas/salvator-x/salvator-x.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/renesas/silk/silk.c b/board/renesas/silk/silk.c index 171d06f3175..05af5f4d68b 100644 --- a/board/renesas/silk/silk.c +++ b/board/renesas/silk/silk.c @@ -13,6 +13,7 @@ #include <init.h> #include <malloc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/stout/stout.c b/board/renesas/stout/stout.c index babcce9aa1c..3fdf936ddca 100644 --- a/board/renesas/stout/stout.c +++ b/board/renesas/stout/stout.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/ulcb/ulcb.c b/board/renesas/ulcb/ulcb.c index efbffa0ee77..7ba1948659f 100644 --- a/board/renesas/ulcb/ulcb.c +++ b/board/renesas/ulcb/ulcb.c @@ -12,6 +12,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/rockchip/evb_rk3308/evb_rk3308.c b/board/rockchip/evb_rk3308/evb_rk3308.c index 180f1fe4f00..e0c96fd70a2 100644 --- a/board/rockchip/evb_rk3308/evb_rk3308.c +++ b/board/rockchip/evb_rk3308/evb_rk3308.c @@ -5,6 +5,7 @@
#include <common.h> #include <adc.h> +#include <asm/global_data.h>
diff --git a/board/rockchip/evb_rv1108/evb_rv1108.c b/board/rockchip/evb_rv1108/evb_rv1108.c index fc31c493116..e6ac598648d 100644 --- a/board/rockchip/evb_rv1108/evb_rv1108.c +++ b/board/rockchip/evb_rv1108/evb_rv1108.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/grf_rv1108.h> diff --git a/board/ronetix/pm9261/pm9261.c b/board/ronetix/pm9261/pm9261.c index 0ce6a6e44e9..5be2c5e192b 100644 --- a/board/ronetix/pm9261/pm9261.c +++ b/board/ronetix/pm9261/pm9261.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/io.h> #include <asm/gpio.h> diff --git a/board/ronetix/pm9263/pm9263.c b/board/ronetix/pm9263/pm9263.c index 62dfe6e33d7..95c0dec4db5 100644 --- a/board/ronetix/pm9263/pm9263.c +++ b/board/ronetix/pm9263/pm9263.c @@ -9,6 +9,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/io.h> #include <asm/gpio.h> diff --git a/board/ronetix/pm9g45/pm9g45.c b/board/ronetix/pm9g45/pm9g45.c index c7d22db0aba..8d5825c7f13 100644 --- a/board/ronetix/pm9g45/pm9g45.c +++ b/board/ronetix/pm9g45/pm9g45.c @@ -12,6 +12,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/io.h> #include <asm/gpio.h> diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c index 91813763cec..2742a7f32b2 100644 --- a/board/samsung/arndale/arndale.c +++ b/board/samsung/arndale/arndale.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/dwmmc.h> diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 470531fdbb2..104d2a65746 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -16,6 +16,7 @@ #include <spi.h> #include <tmu.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/board.h> diff --git a/board/samsung/common/exynos5-dt-types.c b/board/samsung/common/exynos5-dt-types.c index f1ecb7d2c39..e2d5a7c9ba7 100644 --- a/board/samsung/common/exynos5-dt-types.c +++ b/board/samsung/common/exynos5-dt-types.c @@ -9,6 +9,7 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <power/pmic.h> #include <power/regulator.h> diff --git a/board/samsung/common/exynos5-dt.c b/board/samsung/common/exynos5-dt.c index 69aa2120e12..4463cdcb87b 100644 --- a/board/samsung/common/exynos5-dt.c +++ b/board/samsung/common/exynos5-dt.c @@ -9,6 +9,7 @@ #include <env.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <i2c.h> diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index 837463ba78f..7d3b9846e39 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -9,6 +9,7 @@ #include <env.h> #include <lcd.h> #include <libtizen.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <samsung/misc.h> #include <errno.h> diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index 2f0ef22c417..b32b82fc2da 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/mmc.h> #include <dm.h> diff --git a/board/samsung/odroid/odroid.c b/board/samsung/odroid/odroid.c index 7d7e722892e..90aab62d33b 100644 --- a/board/samsung/odroid/odroid.c +++ b/board/samsung/odroid/odroid.c @@ -10,6 +10,7 @@ #include <asm/arch/power.h> #include <asm/arch/clock.h> #include <asm/arch/gpio.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/cpu.h> #include <dm.h> diff --git a/board/samsung/smdkc100/smdkc100.c b/board/samsung/smdkc100/smdkc100.c index d034f53d68b..69ed715403f 100644 --- a/board/samsung/smdkc100/smdkc100.c +++ b/board/samsung/smdkc100/smdkc100.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/sromc.h> diff --git a/board/samsung/smdkv310/smdkv310.c b/board/samsung/smdkv310/smdkv310.c index 24273f1214b..8811cbb9ad0 100644 --- a/board/samsung/smdkv310/smdkv310.c +++ b/board/samsung/smdkv310/smdkv310.c @@ -7,6 +7,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <netdev.h> diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index f50da6be724..9ef11b8471c 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -10,6 +10,7 @@ #include <log.h> #include <spi.h> #include <lcd.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/adc.h> diff --git a/board/sandbox/sandbox.c b/board/sandbox/sandbox.c index 937ce284111..c78e90accbc 100644 --- a/board/sandbox/sandbox.c +++ b/board/sandbox/sandbox.c @@ -11,6 +11,7 @@ #include <init.h> #include <led.h> #include <os.h> +#include <asm/global_data.h> #include <asm/test.h> #include <asm/u-boot-sandbox.h>
diff --git a/board/sandisk/sansa_fuze_plus/sfp.c b/board/sandisk/sansa_fuze_plus/sfp.c index 42004098b37..f46b02e38e5 100644 --- a/board/sandisk/sansa_fuze_plus/sfp.c +++ b/board/sandisk/sansa_fuze_plus/sfp.c @@ -13,6 +13,7 @@ #include <errno.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/iomux-mx23.h> diff --git a/board/sbc8349/sbc8349.c b/board/sbc8349/sbc8349.c index 824479c099b..b440a0b17e9 100644 --- a/board/sbc8349/sbc8349.c +++ b/board/sbc8349/sbc8349.c @@ -13,6 +13,7 @@ #include <ioports.h> #include <mpc83xx.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/mpc8349_pci.h> #include <i2c.h> #include <spd_sdram.h> diff --git a/board/sbc8641d/sbc8641d.c b/board/sbc8641d/sbc8641d.c index 34e46d4ea4c..a67092daf47 100644 --- a/board/sbc8641d/sbc8641d.c +++ b/board/sbc8641d/sbc8641d.c @@ -16,6 +16,7 @@ #include <init.h> #include <log.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/immap_86xx.h> #include <asm/fsl_pci.h> diff --git a/board/schulercontrol/sc_sps_1/sc_sps_1.c b/board/schulercontrol/sc_sps_1/sc_sps_1.c index 8011871fc8f..3a04b1a634c 100644 --- a/board/schulercontrol/sc_sps_1/sc_sps_1.c +++ b/board/schulercontrol/sc_sps_1/sc_sps_1.c @@ -9,6 +9,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/seco/mx6quq7/mx6quq7.c b/board/seco/mx6quq7/mx6quq7.c index c7e3d425eac..a061d7d8afb 100644 --- a/board/seco/mx6quq7/mx6quq7.c +++ b/board/seco/mx6quq7/mx6quq7.c @@ -13,6 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/siemens/capricorn/spl.c b/board/siemens/capricorn/spl.c index 8435bd3863b..8e077d73aef 100644 --- a/board/siemens/capricorn/spl.c +++ b/board/siemens/capricorn/spl.c @@ -9,6 +9,7 @@ #include <init.h> #include <spl.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <dm/device.h> #include <dm/uclass-internal.h> diff --git a/board/siemens/common/board.c b/board/siemens/common/board.c index e0bd8590bc9..1bdf404ac3e 100644 --- a/board/siemens/common/board.c +++ b/board/siemens/common/board.c @@ -25,6 +25,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/siemens/corvus/board.c b/board/siemens/corvus/board.c index eed055aedb3..2acd3226cf2 100644 --- a/board/siemens/corvus/board.c +++ b/board/siemens/corvus/board.c @@ -14,6 +14,7 @@ #include <dm.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9g45_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/siemens/smartweb/smartweb.c b/board/siemens/smartweb/smartweb.c index c6bdd970837..d500a6214d5 100644 --- a/board/siemens/smartweb/smartweb.c +++ b/board/siemens/smartweb/smartweb.c @@ -19,6 +19,7 @@ #include <dm.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9_sdramc.h> #include <asm/arch/at91sam9260_matrix.h> diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 91e29f06f60..cad16f90656 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -17,6 +17,7 @@ #include <env.h> #include <flash.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/sks-kinkel/sksimx6/sksimx6.c b/board/sks-kinkel/sksimx6/sksimx6.c index 9fdbeac82fd..cec3ade96cf 100644 --- a/board/sks-kinkel/sksimx6/sksimx6.c +++ b/board/sks-kinkel/sksimx6/sksimx6.c @@ -11,6 +11,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/socrates/socrates.c b/board/socrates/socrates.c index 25bc664328a..0c9262d3540 100644 --- a/board/socrates/socrates.c +++ b/board/socrates/socrates.c @@ -16,6 +16,7 @@ #include <init.h> #include <pci.h> #include <uuid.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/immap_85xx.h> #include <ioports.h> diff --git a/board/softing/vining_2000/vining_2000.c b/board/softing/vining_2000/vining_2000.c index 4e9d351582f..aaeeee361e5 100644 --- a/board/softing/vining_2000/vining_2000.c +++ b/board/softing/vining_2000/vining_2000.c @@ -14,6 +14,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/board/softing/vining_fpga/socfpga.c b/board/softing/vining_fpga/socfpga.c index 7e311b7a1c3..aaedf034504 100644 --- a/board/softing/vining_fpga/socfpga.c +++ b/board/softing/vining_fpga/socfpga.c @@ -10,6 +10,7 @@ #include <net.h> #include <status_led.h> #include <asm/arch/reset_manager.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <i2c.h> diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index 92443d5177d..7b2accf01de 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -10,6 +10,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/solidrun/common/tlv_data.c b/board/solidrun/common/tlv_data.c index f08ac8975a6..11d6e4a1380 100644 --- a/board/solidrun/common/tlv_data.c +++ b/board/solidrun/common/tlv_data.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <compiler.h> #include <tlv_eeprom.h> #include "tlv_data.h"
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index ae1c04df87d..3eadc38f6fd 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -23,6 +23,7 @@ #include <asm/arch/mx6-pins.h> #include <asm/arch/mxc_hdmi.h> #include <env.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/somlabs/visionsom-6ull/visionsom-6ull.c b/board/somlabs/visionsom-6ull/visionsom-6ull.c index bc7257be405..076c641d8a9 100644 --- a/board/somlabs/visionsom-6ull/visionsom-6ull.c +++ b/board/somlabs/visionsom-6ull/visionsom-6ull.c @@ -11,6 +11,7 @@ #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/st/common/stm32mp_mtdparts.c b/board/st/common/stm32mp_mtdparts.c index 9f5897f8c86..ef32df04fef 100644 --- a/board/st/common/stm32mp_mtdparts.c +++ b/board/st/common/stm32mp_mtdparts.c @@ -13,6 +13,7 @@ #include <tee.h> #include <asm/arch/stm32prog.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h>
#define MTDPARTS_LEN 256 #define MTDIDS_LEN 128 diff --git a/board/st/stih410-b2260/board.c b/board/st/stih410-b2260/board.c index b1147f2e1a7..b87468cca21 100644 --- a/board/st/stih410-b2260/board.c +++ b/board/st/stih410-b2260/board.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/usb/otg.h> #include <dwc3-sti-glue.h> #include <dwc3-uboot.h> diff --git a/board/st/stm32f429-discovery/stm32f429-discovery.c b/board/st/stm32f429-discovery/stm32f429-discovery.c index ee6a90c9fdd..9d8fc9f5a2e 100644 --- a/board/st/stm32f429-discovery/stm32f429-discovery.c +++ b/board/st/stm32f429-discovery/stm32f429-discovery.c @@ -15,6 +15,7 @@ #include <env.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <asm/arch/stm32.h> diff --git a/board/st/stm32f429-evaluation/stm32f429-evaluation.c b/board/st/stm32f429-evaluation/stm32f429-evaluation.c index 92e3d40a1b6..35e71380b89 100644 --- a/board/st/stm32f429-evaluation/stm32f429-evaluation.c +++ b/board/st/stm32f429-evaluation/stm32f429-evaluation.c @@ -9,6 +9,7 @@ #include <env.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <asm/arch/stm32.h> diff --git a/board/st/stm32f469-discovery/stm32f469-discovery.c b/board/st/stm32f469-discovery/stm32f469-discovery.c index 85988acb241..fcc34e7955a 100644 --- a/board/st/stm32f469-discovery/stm32f469-discovery.c +++ b/board/st/stm32f469-discovery/stm32f469-discovery.c @@ -9,6 +9,7 @@ #include <env.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <asm/arch/stm32.h> diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 0f728fd9f9e..40450ca914b 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -17,6 +17,7 @@ #include <splash.h> #include <st_logo_data.h> #include <video.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv7m.h> #include <asm/arch/stm32.h> diff --git a/board/st/stm32h743-disco/stm32h743-disco.c b/board/st/stm32h743-disco/stm32h743-disco.c index 0484c3c2504..53bf0922197 100644 --- a/board/st/stm32h743-disco/stm32h743-disco.c +++ b/board/st/stm32h743-disco/stm32h743-disco.c @@ -8,6 +8,7 @@ #include <dm.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
diff --git a/board/st/stm32h743-eval/stm32h743-eval.c b/board/st/stm32h743-eval/stm32h743-eval.c index 0484c3c2504..53bf0922197 100644 --- a/board/st/stm32h743-eval/stm32h743-eval.c +++ b/board/st/stm32h743-eval/stm32h743-eval.c @@ -8,6 +8,7 @@ #include <dm.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 03a19af9302..f1df06caa49 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -29,6 +29,7 @@ #include <syscon.h> #include <usb.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/stm32.h> diff --git a/board/st/stv0991/stv0991.c b/board/st/stv0991/stv0991.c index 8c827adc2ed..72399cf5f65 100644 --- a/board/st/stv0991/stv0991.c +++ b/board/st/stv0991/stv0991.c @@ -15,6 +15,7 @@ #include <asm/arch/hardware.h> #include <asm/arch/gpio.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/platform_data/serial_pl01x.h>
diff --git a/board/ste/stemmy/stemmy.c b/board/ste/stemmy/stemmy.c index f7834c08fc2..b9b2a6fddc2 100644 --- a/board/ste/stemmy/stemmy.c +++ b/board/ste/stemmy/stemmy.c @@ -4,6 +4,7 @@ */ #include <common.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index a5cf0b65c7b..aa727272be4 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -28,6 +28,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/mmc.h> #include <asm/arch/spl.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <u-boot/crc.h> #ifndef CONFIG_ARM64 diff --git a/board/synopsys/axs10x/axs10x.c b/board/synopsys/axs10x/axs10x.c index b4a1d4c5dff..75e4d037623 100644 --- a/board/synopsys/axs10x/axs10x.c +++ b/board/synopsys/axs10x/axs10x.c @@ -9,6 +9,7 @@ #include <init.h> #include <malloc.h> #include <asm/arcregs.h> +#include <asm/global_data.h> #include "axs10x.h" #include <asm/cache.h>
diff --git a/board/synopsys/emsdp/emsdp.c b/board/synopsys/emsdp/emsdp.c index 91fa94a638e..997120ec5e1 100644 --- a/board/synopsys/emsdp/emsdp.c +++ b/board/synopsys/emsdp/emsdp.c @@ -9,6 +9,7 @@ #include <dwmmc.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/bitops.h>
#include <asm/arcregs.h> diff --git a/board/synopsys/hsdk/hsdk.c b/board/synopsys/hsdk/hsdk.c index cd11f9dac06..892b94bb083 100644 --- a/board/synopsys/hsdk/hsdk.c +++ b/board/synopsys/hsdk/hsdk.c @@ -14,6 +14,7 @@ #include <irq_func.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/printk.h> diff --git a/board/synopsys/iot_devkit/iot_devkit.c b/board/synopsys/iot_devkit/iot_devkit.c index 497ea186d3a..c6051363c1f 100644 --- a/board/synopsys/iot_devkit/iot_devkit.c +++ b/board/synopsys/iot_devkit/iot_devkit.c @@ -8,6 +8,7 @@ #include <init.h> #include <malloc.h> #include <dwmmc.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/libfdt.h> #include <fdtdec.h> diff --git a/board/sysam/amcore/amcore.c b/board/sysam/amcore/amcore.c index 4502005941f..9e1b8022705 100644 --- a/board/sysam/amcore/amcore.c +++ b/board/sysam/amcore/amcore.c @@ -9,6 +9,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <dm.h> diff --git a/board/sysam/stmark2/stmark2.c b/board/sysam/stmark2/stmark2.c index ce8b541ccdf..d48da48b69d 100644 --- a/board/sysam/stmark2/stmark2.c +++ b/board/sysam/stmark2/stmark2.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/immap.h> #include <mmc.h> diff --git a/board/syteco/zmx25/zmx25.c b/board/syteco/zmx25/zmx25.c index d5393d70597..2d4c5cce892 100644 --- a/board/syteco/zmx25/zmx25.c +++ b/board/syteco/zmx25/zmx25.c @@ -17,6 +17,7 @@ #include <cpu_func.h> #include <env.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/tbs/tbs2910/tbs2910.c b/board/tbs/tbs2910/tbs2910.c index d32517f998a..ac1b8231281 100644 --- a/board/tbs/tbs2910/tbs2910.c +++ b/board/tbs/tbs2910/tbs2910.c @@ -3,11 +3,13 @@ * Copyright (C) 2014 Soeren Moch smoch@web.de */
+#include <common.h> #include <init.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/tcl/sl50/board.c b/board/tcl/sl50/board.c index 230481be0de..4821925c026 100644 --- a/board/tcl/sl50/board.c +++ b/board/tcl/sl50/board.c @@ -23,6 +23,7 @@ #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/technexion/pico-imx6/pico-imx6.c b/board/technexion/pico-imx6/pico-imx6.c index da82244b397..6b9c4f4373c 100644 --- a/board/technexion/pico-imx6/pico-imx6.c +++ b/board/technexion/pico-imx6/pico-imx6.c @@ -6,6 +6,7 @@ * Author: Fabio Estevam festevam@gmail.com */
+#include <common.h> #include <env.h> #include <init.h> #include <net.h> @@ -15,6 +16,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/mxc_hdmi.h> #include <asm/mach-imx/video.h> @@ -22,7 +24,6 @@ #include <asm/io.h> #include <linux/delay.h> #include <linux/sizes.h> -#include <common.h> #include <miiphy.h> #include <netdev.h> #include <phy.h> diff --git a/board/technexion/pico-imx6ul/pico-imx6ul.c b/board/technexion/pico-imx6ul/pico-imx6ul.c index 126823fce09..62a54d0c8eb 100644 --- a/board/technexion/pico-imx6ul/pico-imx6ul.c +++ b/board/technexion/pico-imx6ul/pico-imx6ul.c @@ -13,6 +13,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/board/technexion/pico-imx7d/pico-imx7d.c b/board/technexion/pico-imx7d/pico-imx7d.c index a6fd49d729c..2d749dac19a 100644 --- a/board/technexion/pico-imx7d/pico-imx7d.c +++ b/board/technexion/pico-imx7d/pico-imx7d.c @@ -10,6 +10,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> diff --git a/board/technexion/pico-imx8mq/pico-imx8mq.c b/board/technexion/pico-imx8mq/pico-imx8mq.c index 330de7137c3..951e3e1985b 100644 --- a/board/technexion/pico-imx8mq/pico-imx8mq.c +++ b/board/technexion/pico-imx8mq/pico-imx8mq.c @@ -8,6 +8,7 @@ #include <init.h> #include <malloc.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/technexion/pico-imx8mq/spl.c b/board/technexion/pico-imx8mq/spl.c index b181f797a77..8b853a914e8 100644 --- a/board/technexion/pico-imx8mq/spl.c +++ b/board/technexion/pico-imx8mq/spl.c @@ -11,6 +11,7 @@ #include <asm/arch/ddr.h> #include <asm/arch/imx8mq_pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/gpio.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/technexion/tao3530/tao3530.c b/board/technexion/tao3530/tao3530.c index 84db131de2b..0c9dca31e67 100644 --- a/board/technexion/tao3530/tao3530.c +++ b/board/technexion/tao3530/tao3530.c @@ -9,6 +9,7 @@ #include <malloc.h> #include <netdev.h> #include <twl4030.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/mem.h> diff --git a/board/technologic/ts4600/ts4600.c b/board/technologic/ts4600/ts4600.c index 0ef306d58a2..b9cce821d96 100644 --- a/board/technologic/ts4600/ts4600.c +++ b/board/technologic/ts4600/ts4600.c @@ -15,6 +15,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/technologic/ts4800/ts4800.c b/board/technologic/ts4800/ts4800.c index fe36fb7ffab..a309e58b27f 100644 --- a/board/technologic/ts4800/ts4800.c +++ b/board/technologic/ts4800/ts4800.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/imx-regs.h> diff --git a/board/theadorable/theadorable.c b/board/theadorable/theadorable.c index 67bc00b65b0..3c4133083f5 100644 --- a/board/theadorable/theadorable.c +++ b/board/theadorable/theadorable.c @@ -13,6 +13,7 @@ #if !defined(CONFIG_SPL_BUILD) #include <bootcount.h> #endif +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/cpu.h> diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 984cc5e3ba5..211a9bf7446 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -27,6 +27,7 @@ #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/ti/am3517crane/am3517crane.c b/board/ti/am3517crane/am3517crane.c index f32d1757db7..b1017d6c9b7 100644 --- a/board/ti/am3517crane/am3517crane.c +++ b/board/ti/am3517crane/am3517crane.c @@ -11,6 +11,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/mem.h> diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index de495900315..8f5bf3581f4 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -10,6 +10,7 @@ #include <common.h> #include <eeprom.h> #include <image.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <env.h> #include <fdt_support.h> diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 78098755106..73063faee69 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -20,6 +20,7 @@ #include <serial.h> #include <usb.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/omap_common.h> #include <asm/omap_sec_common.h> #include <asm/emif.h> diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c index 36063b11383..3d44c70fe42 100644 --- a/board/ti/am65x/evm.c +++ b/board/ti/am65x/evm.c @@ -15,6 +15,7 @@ #include <net.h> #include <asm/arch/sys_proto.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/omap_common.h> diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index 6bd59eb10c2..888a9584919 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -24,6 +24,7 @@ #include <status_led.h> #endif #include <twl4030.h> +#include <asm/global_data.h> #include <linux/mtd/rawnand.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index ca1976e16a5..05f251f7782 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -20,6 +20,7 @@ #include <palmas.h> #include <sata.h> #include <serial.h> +#include <asm/global_data.h> #include <linux/string.h> #include <asm/gpio.h> #include <usb.h> diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index ecbd843676a..96434b3ba0f 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -17,6 +17,7 @@ #include <net.h> #include <ns16550.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mem.h> #include <asm/arch/mux.h> diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index d8711eb9005..fb602950233 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -16,6 +16,7 @@ #include <net.h> #include <asm/arch/sys_proto.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <spl.h> diff --git a/board/ti/ks2_evm/board.c b/board/ti/ks2_evm/board.c index c7be5400289..9e5f08e3372 100644 --- a/board/ti/ks2_evm/board.c +++ b/board/ti/ks2_evm/board.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include "board.h" #include <env.h> #include <hang.h> diff --git a/board/ti/omap5_uevm/evm.c b/board/ti/omap5_uevm/evm.c index 88f56edc54e..4777622156b 100644 --- a/board/ti/omap5_uevm/evm.c +++ b/board/ti/omap5_uevm/evm.c @@ -15,6 +15,7 @@ #include <serial.h> #include <tca642x.h> #include <usb.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/usb/gadget.h> #include <dwc3-uboot.h> diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index f718e69e85d..fda8d5f3c83 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -9,6 +9,7 @@ #include <log.h> #include <net.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h> diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c index 3fd973049a8..4895bfafd80 100644 --- a/board/ti/sdp4430/sdp.c +++ b/board/ti/sdp4430/sdp.c @@ -12,6 +12,7 @@ #include <serial.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h> +#include <asm/global_data.h>
#include "sdp4430_mux_data.h"
diff --git a/board/ti/ti816x/evm.c b/board/ti/ti816x/evm.c index becece1c205..2d42af6b809 100644 --- a/board/ti/ti816x/evm.c +++ b/board/ti/ti816x/evm.c @@ -12,6 +12,7 @@ #include <net.h> #include <spl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/cpu.h> diff --git a/board/timll/devkit3250/devkit3250.c b/board/timll/devkit3250/devkit3250.c index f4eaf15970b..3c744b943f4 100644 --- a/board/timll/devkit3250/devkit3250.c +++ b/board/timll/devkit3250/devkit3250.c @@ -12,6 +12,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/emc.h> #include <asm/arch/wdt.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index 2420c28974c..5af88318062 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -22,6 +22,7 @@ #include <malloc.h> #include <ns16550.h> #include <twl4030.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/mux.h> diff --git a/board/toradex/apalis-imx8/apalis-imx8.c b/board/toradex/apalis-imx8/apalis-imx8.c index 9263b0f51fa..6e8594a6472 100644 --- a/board/toradex/apalis-imx8/apalis-imx8.c +++ b/board/toradex/apalis-imx8/apalis-imx8.c @@ -6,6 +6,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h>
#include <asm/arch/clock.h> #include <asm/arch/imx8-pins.h> diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 3961c4df9e2..17f6094687b 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -12,6 +12,7 @@ #include <image.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h>
diff --git a/board/toradex/apalis_t30/apalis_t30.c b/board/toradex/apalis_t30/apalis_t30.c index f718dc855d4..0396eea56b5 100644 --- a/board/toradex/apalis_t30/apalis_t30.c +++ b/board/toradex/apalis_t30/apalis_t30.c @@ -11,6 +11,7 @@ #include <asm/arch/pinmux.h> #include <asm/arch-tegra/ap.h> #include <asm/arch-tegra/tegra.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <dm.h> diff --git a/board/toradex/colibri-imx6ull/colibri-imx6ull.c b/board/toradex/colibri-imx6ull/colibri-imx6ull.c index 45f8da3c42f..4435c7c0f86 100644 --- a/board/toradex/colibri-imx6ull/colibri-imx6ull.c +++ b/board/toradex/colibri-imx6ull/colibri-imx6ull.c @@ -4,6 +4,7 @@ */ #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/arch/clock.h> diff --git a/board/toradex/colibri-imx8x/colibri-imx8x.c b/board/toradex/colibri-imx8x/colibri-imx8x.c index f981c11a37c..9531ec64a5d 100644 --- a/board/toradex/colibri-imx8x/colibri-imx8x.c +++ b/board/toradex/colibri-imx8x/colibri-imx8x.c @@ -6,6 +6,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h>
#include <asm/arch/clock.h> #include <asm/arch/imx8-pins.h> diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index a416b5e54b3..64a8406ec77 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -12,6 +12,7 @@ #include <env.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h>
diff --git a/board/toradex/colibri_imx7/colibri_imx7.c b/board/toradex/colibri_imx7/colibri_imx7.c index 8afe1bfd5eb..8f7ef992a7f 100644 --- a/board/toradex/colibri_imx7/colibri_imx7.c +++ b/board/toradex/colibri_imx7/colibri_imx7.c @@ -12,6 +12,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/board/toradex/colibri_pxa270/colibri_pxa270.c b/board/toradex/colibri_pxa270/colibri_pxa270.c index 273a17f608d..bc7a79f0b34 100644 --- a/board/toradex/colibri_pxa270/colibri_pxa270.c +++ b/board/toradex/colibri_pxa270/colibri_pxa270.c @@ -15,6 +15,7 @@ #include <asm/arch/pxa.h> #include <asm/arch/regs-mmc.h> #include <asm/arch/regs-uart.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/platdata.h> #include <dm/platform_data/pxa_mmc_gen.h> diff --git a/board/toradex/colibri_t20/colibri_t20.c b/board/toradex/colibri_t20/colibri_t20.c index f44ca90ce96..73ef4d2db32 100644 --- a/board/toradex/colibri_t20/colibri_t20.c +++ b/board/toradex/colibri_t20/colibri_t20.c @@ -12,6 +12,7 @@ #include <asm/arch-tegra/ap.h> #include <asm/arch-tegra/board.h> #include <asm/arch-tegra/tegra.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <i2c.h> diff --git a/board/toradex/colibri_vf/colibri_vf.c b/board/toradex/colibri_vf/colibri_vf.c index 7194ede01cb..e9c5bc06322 100644 --- a/board/toradex/colibri_vf/colibri_vf.c +++ b/board/toradex/colibri_vf/colibri_vf.c @@ -8,6 +8,7 @@
#include <asm/arch/clock.h> #include <asm/arch/crm_regs.h> diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index bf27b2fa66a..ab561237e6f 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include "tdx-cfg-block.h" #include "tdx-eeprom.h"
diff --git a/board/toradex/common/tdx-eeprom.c b/board/toradex/common/tdx-eeprom.c index fbc267dab62..81bd9e68c2d 100644 --- a/board/toradex/common/tdx-eeprom.c +++ b/board/toradex/common/tdx-eeprom.c @@ -5,6 +5,7 @@
#include <dm.h> #include <i2c_eeprom.h> +#include <asm/global_data.h> #include <linux/errno.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/toradex/verdin-imx8mm/spl.c b/board/toradex/verdin-imx8mm/spl.c index cc78c5666bb..588da0aeba6 100644 --- a/board/toradex/verdin-imx8mm/spl.c +++ b/board/toradex/verdin-imx8mm/spl.c @@ -12,6 +12,7 @@ #include <asm/arch/ddr.h> #include <asm/arch/imx8mm_pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/toradex/verdin-imx8mm/verdin-imx8mm.c b/board/toradex/verdin-imx8mm/verdin-imx8mm.c index 66950ed218b..1161b5c31d9 100644 --- a/board/toradex/verdin-imx8mm/verdin-imx8mm.c +++ b/board/toradex/verdin-imx8mm/verdin-imx8mm.c @@ -7,6 +7,7 @@ #include <init.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/tqc/tqm834x/tqm834x.c b/board/tqc/tqm834x/tqm834x.c index c16784324c9..17b4662c167 100644 --- a/board/tqc/tqm834x/tqm834x.c +++ b/board/tqc/tqm834x/tqm834x.c @@ -10,6 +10,7 @@ #include <ioports.h> #include <log.h> #include <mpc83xx.h> +#include <asm/global_data.h> #include <asm/mpc8349_pci.h> #include <i2c.h> #include <miiphy.h> diff --git a/board/tqc/tqma6/tqma6.c b/board/tqc/tqma6/tqma6.c index 2df901a584c..26d557cece9 100644 --- a/board/tqc/tqma6/tqma6.c +++ b/board/tqc/tqma6/tqma6.c @@ -15,6 +15,7 @@ #include <asm/arch/sys_proto.h> #include <env.h> #include <fdt_support.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/gpio.h> #include <asm/io.h> diff --git a/board/udoo/neo/neo.c b/board/udoo/neo/neo.c index c6edc724405..653ca1ca5a6 100644 --- a/board/udoo/neo/neo.c +++ b/board/udoo/neo/neo.c @@ -15,6 +15,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <env.h> diff --git a/board/udoo/udoo.c b/board/udoo/udoo.c index 62b32ae7595..d83f23dd358 100644 --- a/board/udoo/udoo.c +++ b/board/udoo/udoo.c @@ -13,6 +13,7 @@ #include <env.h> #include <malloc.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/variscite/dart_6ul/dart_6ul.c b/board/variscite/dart_6ul/dart_6ul.c index d8e383d323e..1c52cfd882e 100644 --- a/board/variscite/dart_6ul/dart_6ul.c +++ b/board/variscite/dart_6ul/dart_6ul.c @@ -10,6 +10,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> #include <fsl_esdhc_imx.h> diff --git a/board/varisys/cyrus/ddr.c b/board/varisys/cyrus/ddr.c index 7949eb88c07..184948094db 100644 --- a/board/varisys/cyrus/ddr.c +++ b/board/varisys/cyrus/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/ve8313/ve8313.c b/board/ve8313/ve8313.c index 6cdb1104716..78d401e955e 100644 --- a/board/ve8313/ve8313.c +++ b/board/ve8313/ve8313.c @@ -11,6 +11,7 @@ #include <common.h> #include <fdt_support.h> #include <init.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <pci.h> diff --git a/board/vscom/baltos/board.c b/board/vscom/baltos/board.c index afe12466df3..4175d414694 100644 --- a/board/vscom/baltos/board.c +++ b/board/vscom/baltos/board.c @@ -13,6 +13,7 @@ #include <init.h> #include <net.h> #include <serial.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <spl.h> #include <asm/arch/cpu.h> diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index e0e01b1a4a4..53299c87010 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -17,6 +17,7 @@ #include <asm/arch/mx6-pins.h> #include <asm/arch/mxc_hdmi.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> diff --git a/board/warp/warp.c b/board/warp/warp.c index 85da9c1bd43..0f1d038fabd 100644 --- a/board/warp/warp.c +++ b/board/warp/warp.c @@ -13,6 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> diff --git a/board/warp7/warp7.c b/board/warp7/warp7.c index aaa7006d3b2..0f202241dd7 100644 --- a/board/warp7/warp7.c +++ b/board/warp7/warp7.c @@ -10,6 +10,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/hab.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/work-microwave/work_92105/work_92105.c b/board/work-microwave/work_92105/work_92105.c index 2e0def5b64f..bdcecff7308 100644 --- a/board/work-microwave/work_92105/work_92105.c +++ b/board/work-microwave/work_92105/work_92105.c @@ -8,6 +8,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <asm/arch/cpu.h> diff --git a/board/xen/xenguest_arm64/xenguest_arm64.c b/board/xen/xenguest_arm64/xenguest_arm64.c index 4660f3fff20..7d0d782a239 100644 --- a/board/xen/xenguest_arm64/xenguest_arm64.c +++ b/board/xen/xenguest_arm64/xenguest_arm64.c @@ -13,6 +13,7 @@ #include <errno.h> #include <malloc.h> #include <xen.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <asm/armv8/mmu.h> diff --git a/board/xes/xpedite517x/xpedite517x.c b/board/xes/xpedite517x/xpedite517x.c index 2c9499ab20b..8a5b52c4952 100644 --- a/board/xes/xpedite517x/xpedite517x.c +++ b/board/xes/xpedite517x/xpedite517x.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <fsl_ddr_sdram.h> #include <asm/mmu.h> diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index b0f60c40a5c..96a565f6d93 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -7,6 +7,7 @@ #include <common.h> #include <env.h> #include <log.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <dm/uclass.h> #include <i2c.h> diff --git a/board/xilinx/microblaze-generic/microblaze-generic.c b/board/xilinx/microblaze-generic/microblaze-generic.c index 4e569e910d9..7729ce915ea 100644 --- a/board/xilinx/microblaze-generic/microblaze-generic.c +++ b/board/xilinx/microblaze-generic/microblaze-generic.c @@ -15,6 +15,7 @@ #include <env.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <fdtdec.h> #include <linux/sizes.h> diff --git a/board/xilinx/versal/board.c b/board/xilinx/versal/board.c index a5ca4ca8740..46101516c30 100644 --- a/board/xilinx/versal/board.c +++ b/board/xilinx/versal/board.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <time.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 7ac069aaafd..49ff3f0dc0e 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -16,6 +16,7 @@ #include <watchdog.h> #include <wdt.h> #include <zynqpl.h> +#include <asm/global_data.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> #include "../common/board.h" diff --git a/board/xilinx/zynq/bootimg.c b/board/xilinx/zynq/bootimg.c index 481f012c282..2f55078dd76 100644 --- a/board/xilinx/zynq/bootimg.c +++ b/board/xilinx/zynq/bootimg.c @@ -6,6 +6,7 @@ #include <common.h> #include <log.h> #include <part.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> diff --git a/board/xilinx/zynq/cmds.c b/board/xilinx/zynq/cmds.c index 73e2b0eac7e..6c697caa625 100644 --- a/board/xilinx/zynq/cmds.c +++ b/board/xilinx/zynq/cmds.c @@ -6,6 +6,7 @@ #include <common.h> #include <command.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 28f067a2515..078d52b8bc7 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -23,6 +23,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/psu_init_gpl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/ptrace.h> #include <dm/device.h> diff --git a/board/zyxel/nsa310s/nsa310s.c b/board/zyxel/nsa310s/nsa310s.c index 3f71e3da446..cd4a7723b12 100644 --- a/board/zyxel/nsa310s/nsa310s.c +++ b/board/zyxel/nsa310s/nsa310s.c @@ -12,6 +12,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> +#include <asm/global_data.h> #include <asm/io.h> #include "nsa310s.h"
diff --git a/cmd/acpi.c b/cmd/acpi.c index a3419b42b55..157261bffbe 100644 --- a/cmd/acpi.c +++ b/cmd/acpi.c @@ -8,6 +8,7 @@ #include <mapmem.h> #include <acpi/acpi_table.h> #include <asm/acpi_table.h> +#include <asm/global_data.h> #include <dm/acpi.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/cmd/bdinfo.c b/cmd/bdinfo.c index 8d8daa6336a..84dab7d2d33 100644 --- a/cmd/bdinfo.c +++ b/cmd/bdinfo.c @@ -15,6 +15,7 @@ #include <video.h> #include <vsprintf.h> #include <asm/cache.h> +#include <asm/global_data.h>
diff --git a/cmd/bedbug.c b/cmd/bedbug.c index 684e4a9ea5c..bef617b6a4f 100644 --- a/cmd/bedbug.c +++ b/cmd/bedbug.c @@ -6,6 +6,7 @@ #include <cli.h> #include <command.h> #include <console.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/ctype.h> #include <net.h> diff --git a/cmd/bloblist.c b/cmd/bloblist.c index bb2e682ff84..97b57341617 100644 --- a/cmd/bloblist.c +++ b/cmd/bloblist.c @@ -9,6 +9,7 @@ #include <common.h> #include <bloblist.h> #include <command.h> +#include <asm/global_data.h>
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index fdf909f8da2..45a359cdce8 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -18,6 +18,7 @@ #include <image.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <linux/libfdt_env.h> #include <mapmem.h> diff --git a/cmd/booti.c b/cmd/booti.c index 76d1255ec58..3df70ea9caa 100644 --- a/cmd/booti.c +++ b/cmd/booti.c @@ -12,6 +12,7 @@ #include <lmb.h> #include <log.h> #include <mapmem.h> +#include <asm/global_data.h> #include <linux/kernel.h> #include <linux/sizes.h>
diff --git a/cmd/bootm.c b/cmd/bootm.c index e6b0e04413c..7732b97f635 100644 --- a/cmd/bootm.c +++ b/cmd/bootm.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <nand.h> #include <asm/byteorder.h> +#include <asm/global_data.h> #include <linux/ctype.h> #include <linux/err.h> #include <u-boot/zlib.h> diff --git a/cmd/date.c b/cmd/date.c index 75a032cd277..0e118947531 100644 --- a/cmd/date.c +++ b/cmd/date.c @@ -12,6 +12,7 @@ #include <dm.h> #include <rtc.h> #include <i2c.h> +#include <asm/global_data.h>
diff --git a/cmd/efi.c b/cmd/efi.c index 1558cb17eb0..f2ed26bd4b2 100644 --- a/cmd/efi.c +++ b/cmd/efi.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <sort.h> +#include <asm/global_data.h>
static const char *const type_name[] = { "reserved", diff --git a/cmd/load.c b/cmd/load.c index 9a3a16979c7..8a46059e868 100644 --- a/cmd/load.c +++ b/cmd/load.c @@ -20,6 +20,7 @@ #include <serial.h> #include <xyzModem.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/delay.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/cmd/log.c b/cmd/log.c index 6afe6ead251..ccefb0cbb8c 100644 --- a/cmd/log.c +++ b/cmd/log.c @@ -8,6 +8,7 @@ #include <command.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h>
static char log_fmt_chars[LOGF_COUNT] = "clFLfm";
diff --git a/cmd/mem.c b/cmd/mem.c index 56e1d0755b6..e6c65c9ef8a 100644 --- a/cmd/mem.c +++ b/cmd/mem.c @@ -22,6 +22,7 @@ #include <mapmem.h> #include <rand.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <linux/compiler.h> diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 5220142b9ab..ed373a8c4da 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -75,6 +75,7 @@ #include <env.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <jffs2/load_kernel.h> #include <linux/list.h> #include <linux/ctype.h> diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 7fce723800d..e73bc4dfa02 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -35,6 +35,7 @@ #include <errno.h> #include <malloc.h> #include <mapmem.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <u-boot/crc.h> #include <watchdog.h> diff --git a/cmd/pstore.c b/cmd/pstore.c index 9a8b38c7f26..a498f593054 100644 --- a/cmd/pstore.c +++ b/cmd/pstore.c @@ -10,6 +10,7 @@ #include <mapmem.h> #include <memalign.h> #include <part.h> +#include <asm/global_data.h>
struct persistent_ram_buffer { u32 sig; diff --git a/cmd/pxe_utils.h b/cmd/pxe_utils.h index 77d25888758..b5a7d278011 100644 --- a/cmd/pxe_utils.h +++ b/cmd/pxe_utils.h @@ -3,6 +3,8 @@ #ifndef __PXE_UTILS_H #define __PXE_UTILS_H
+#include <linux/list.h> + /* * A note on the pxe file parser. * diff --git a/cmd/sb.c b/cmd/sb.c index f7eb921f43e..0d55818e3c6 100644 --- a/cmd/sb.c +++ b/cmd/sb.c @@ -8,6 +8,7 @@ #include <command.h> #include <dm.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/state.h>
static int do_sb_handoff(struct cmd_tbl *cmdtp, int flag, int argc, diff --git a/cmd/sound.c b/cmd/sound.c index 7fc19678ea8..fdcde365339 100644 --- a/cmd/sound.c +++ b/cmd/sound.c @@ -9,6 +9,7 @@ #include <dm.h> #include <fdtdec.h> #include <sound.h> +#include <asm/global_data.h>
diff --git a/cmd/spl.c b/cmd/spl.c index 28b40dd31e1..472703f8fe1 100644 --- a/cmd/spl.c +++ b/cmd/spl.c @@ -10,6 +10,7 @@ #include <env.h> #include <image.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/cmd/ti/ddr3.c b/cmd/ti/ddr3.c index 623b63b0f94..6b43a738683 100644 --- a/cmd/ti/ddr3.c +++ b/cmd/ti/ddr3.c @@ -14,6 +14,7 @@ #include <asm/emif.h> #include <common.h> #include <command.h> +#include <asm/global_data.h>
diff --git a/cmd/tlv_eeprom.c b/cmd/tlv_eeprom.c index eab0531c96b..5099cbdd95e 100644 --- a/cmd/tlv_eeprom.c +++ b/cmd/tlv_eeprom.c @@ -17,6 +17,7 @@ #include <env.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/ctype.h> #include <u-boot/crc.h>
diff --git a/cmd/x86/fsp.c b/cmd/x86/fsp.c index 8017eda387c..82e4415b16e 100644 --- a/cmd/x86/fsp.c +++ b/cmd/x86/fsp.c @@ -6,6 +6,7 @@ #include <common.h> #include <command.h> #include <asm/fsp/fsp_support.h> +#include <asm/global_data.h>
diff --git a/cmd/x86/hob.c b/cmd/x86/hob.c index 9e555c778c2..01db93eb3e1 100644 --- a/cmd/x86/hob.c +++ b/cmd/x86/hob.c @@ -7,6 +7,7 @@ #include <command.h> #include <efi.h> #include <uuid.h> +#include <asm/global_data.h> #include <asm/hob.h> #include <asm/fsp/fsp_hob.h>
diff --git a/common/autoboot.c b/common/autoboot.c index e628baffb89..99ed57f70fd 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -19,6 +19,7 @@ #include <menu.h> #include <post.h> #include <time.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <u-boot/sha256.h> #include <bootcount.h> diff --git a/common/bloblist.c b/common/bloblist.c index 33b58623807..f7fbbeaedbd 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -9,6 +9,7 @@ #include <log.h> #include <mapmem.h> #include <spl.h> +#include <asm/global_data.h> #include <u-boot/crc.h>
/* diff --git a/common/board_f.c b/common/board_f.c index 9f441c44f17..b9bf0329578 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -49,6 +49,7 @@ #if defined(CONFIG_MP) && defined(CONFIG_PPC) #include <asm/mp.h> #endif +#include <asm/global_data.h> #include <asm/io.h> #include <asm/sections.h> #include <dm/root.h> diff --git a/common/board_info.c b/common/board_info.c index a6db087f960..b54aa30a944 100644 --- a/common/board_info.c +++ b/common/board_info.c @@ -2,6 +2,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <linux/compiler.h>
diff --git a/common/board_r.c b/common/board_r.c index b9217b2e27f..ad932a0b582 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -21,6 +21,7 @@ #include <log.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <u-boot/crc.h> /* TODO: can we just include all these headers whether needed or not? */ #if defined(CONFIG_CMD_BEDBUG) diff --git a/common/bootm.c b/common/bootm.c index 167eea4a1e9..34a24dbf187 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -18,6 +18,7 @@ #include <mapmem.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #if defined(CONFIG_CMD_USB) #include <usb.h> diff --git a/common/bootm_os.c b/common/bootm_os.c index e9aaddf3e61..0b6325db660 100644 --- a/common/bootm_os.c +++ b/common/bootm_os.c @@ -14,6 +14,7 @@ #include <image.h> #include <lmb.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <malloc.h> #include <mapmem.h> diff --git a/common/bootstage.c b/common/bootstage.c index 5f87358fd85..d5b78b9f487 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <sort.h> #include <spl.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <linux/libfdt.h>
diff --git a/common/cli.c b/common/cli.c index 6635ab2bcf8..048eacb9ef9 100644 --- a/common/cli.c +++ b/common/cli.c @@ -18,6 +18,7 @@ #include <fdtdec.h> #include <hang.h> #include <malloc.h> +#include <asm/global_data.h>
diff --git a/common/cli_hush.c b/common/cli_hush.c index 66995c255b5..6e850ffc10b 100644 --- a/common/cli_hush.c +++ b/common/cli_hush.c @@ -87,6 +87,7 @@ #ifndef CONFIG_SYS_PROMPT_HUSH_PS2 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #endif +#include <asm/global_data.h> #endif #ifndef __U_BOOT__ #include <ctype.h> /* isalpha, isdigit */ diff --git a/common/cli_readline.c b/common/cli_readline.c index 47b876285cc..10d32f5fa8b 100644 --- a/common/cli_readline.c +++ b/common/cli_readline.c @@ -14,6 +14,7 @@ #include <command.h> #include <time.h> #include <watchdog.h> +#include <asm/global_data.h>
diff --git a/common/command.c b/common/command.c index 2c491e20a74..6a87bb54abf 100644 --- a/common/command.c +++ b/common/command.c @@ -14,6 +14,7 @@ #include <console.h> #include <env.h> #include <log.h> +#include <asm/global_data.h> #include <linux/ctype.h>
/* diff --git a/common/console.c b/common/console.c index 3348436da6f..aaa2b0c0d7e 100644 --- a/common/console.c +++ b/common/console.c @@ -19,6 +19,7 @@ #include <exports.h> #include <env_internal.h> #include <watchdog.h> +#include <asm/global_data.h> #include <linux/delay.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/common/dlmalloc.c b/common/dlmalloc.c index b29a7cfd93d..cf0270a9c11 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -1,5 +1,6 @@ #include <common.h> #include <log.h> +#include <asm/global_data.h>
#if CONFIG_IS_ENABLED(UNIT_TEST) #define DEBUG diff --git a/common/exports.c b/common/exports.c index 6253b55694b..eea47ededd4 100644 --- a/common/exports.c +++ b/common/exports.c @@ -4,6 +4,7 @@ #include <malloc.h> #include <spi.h> #include <i2c.h> +#include <asm/global_data.h>
diff --git a/common/hash.c b/common/hash.c index 05238a8ba91..fc64002f736 100644 --- a/common/hash.c +++ b/common/hash.c @@ -18,6 +18,7 @@ #include <mapmem.h> #include <hw_sha.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/errno.h> #include <u-boot/crc.h> diff --git a/common/hwconfig.c b/common/hwconfig.c index daf3eea5f96..26a561c365b 100644 --- a/common/hwconfig.c +++ b/common/hwconfig.c @@ -15,6 +15,7 @@ #include <exports.h> #include <hwconfig.h> #include <log.h> +#include <asm/global_data.h> #include <linux/types.h> #include <linux/string.h> #else diff --git a/common/image-android.c b/common/image-android.c index 18f7c8db03b..d07b0e0f09b 100644 --- a/common/image-android.c +++ b/common/image-android.c @@ -12,6 +12,7 @@ #include <errno.h> #include <asm/unaligned.h> #include <mapmem.h> +#include <linux/libfdt.h>
#define ANDROID_IMAGE_DEFAULT_KERNEL_ADDR 0x10008000
diff --git a/common/image-cipher.c b/common/image-cipher.c index 4ca9eec4ef1..b9061489396 100644 --- a/common/image-cipher.c +++ b/common/image-cipher.c @@ -9,6 +9,7 @@ #else #include <common.h> #include <malloc.h> +#include <asm/global_data.h> DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSdTCC*/ #include <image.h> diff --git a/common/image-fdt.c b/common/image-fdt.c index 327a8c4c395..64d148a20e4 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -17,6 +17,7 @@ #include <lmb.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <mapmem.h> #include <asm/io.h> diff --git a/common/image-fit-sig.c b/common/image-fit-sig.c index 5401d9411b9..eabdf1d7876 100644 --- a/common/image-fit-sig.c +++ b/common/image-fit-sig.c @@ -10,6 +10,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/ #include <fdt_region.h> diff --git a/common/image-fit.c b/common/image-fit.c index d54eff9033c..973a37969f6 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -22,6 +22,7 @@ #include <mapmem.h> #include <asm/io.h> #include <malloc.h> +#include <asm/global_data.h> DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/
diff --git a/common/image-sig.c b/common/image-sig.c index f3c209ae8b7..4abd3c080f7 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -12,6 +12,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/ #include <image.h> diff --git a/common/image.c b/common/image.c index 451fc689a89..ba78363123a 100644 --- a/common/image.c +++ b/common/image.c @@ -36,6 +36,7 @@ #include <xilinx.h> #endif
+#include <asm/global_data.h> #include <u-boot/md5.h> #include <u-boot/sha1.h> #include <linux/errno.h> diff --git a/common/init/board_init.c b/common/init/board_init.c index 8c8a5eac057..3f183ee1132 100644 --- a/common/init/board_init.c +++ b/common/init/board_init.c @@ -9,6 +9,7 @@ #include <common.h> #include <bootstage.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/common/init/handoff.c b/common/init/handoff.c index 62071bd0179..d0be1bb17a2 100644 --- a/common/init/handoff.c +++ b/common/init/handoff.c @@ -7,6 +7,7 @@
#include <common.h> #include <handoff.h> +#include <asm/global_data.h>
diff --git a/common/iotrace.c b/common/iotrace.c index 7225ee44041..63d0cca3a00 100644 --- a/common/iotrace.c +++ b/common/iotrace.c @@ -8,6 +8,7 @@ #include <common.h> #include <mapmem.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bug.h> #include <u-boot/crc.h> diff --git a/common/lcd.c b/common/lcd.c index 02f2db3a99e..ab5614ad0e3 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -15,6 +15,7 @@ #include <log.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <linux/types.h> #include <stdio_dev.h> #include <lcd.h> diff --git a/common/lcd_simplefb.c b/common/lcd_simplefb.c index fca600691e9..6dd7972f709 100644 --- a/common/lcd_simplefb.c +++ b/common/lcd_simplefb.c @@ -10,6 +10,7 @@ #include <dm.h> #include <lcd.h> #include <fdt_support.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <video.h>
diff --git a/common/log.c b/common/log.c index 9f98e9aff8b..dc235343e0f 100644 --- a/common/log.c +++ b/common/log.c @@ -9,6 +9,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/uclass.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/common/log_console.c b/common/log_console.c index 8776fd47039..6abb13c93b8 100644 --- a/common/log_console.c +++ b/common/log_console.c @@ -8,6 +8,7 @@
diff --git a/common/log_syslog.c b/common/log_syslog.c index 4eb09157bb9..53c4def5d1c 100644 --- a/common/log_syslog.c +++ b/common/log_syslog.c @@ -8,6 +8,7 @@ #include <common.h> #include <log.h> #include <net.h> +#include <asm/global_data.h>
diff --git a/common/malloc_simple.c b/common/malloc_simple.c index 34f0b490938..0267fb6bec8 100644 --- a/common/malloc_simple.c +++ b/common/malloc_simple.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <mapmem.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/common/memsize.c b/common/memsize.c index e95c68265ab..d5d13d51bf1 100644 --- a/common/memsize.c +++ b/common/memsize.c @@ -6,6 +6,7 @@
diff --git a/common/spl/spl.c b/common/spl/spl.c index 63c48fbf33d..e825ee41410 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -18,6 +18,7 @@ #include <log.h> #include <serial.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/u-boot.h> #include <nand.h> #include <fat.h> diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index fd6086a65c3..7f06081854f 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <spl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/libfdt.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/common/spl/spl_opensbi.c b/common/spl/spl_opensbi.c index 14f335f75f0..90c4a5f9704 100644 --- a/common/spl/spl_opensbi.c +++ b/common/spl/spl_opensbi.c @@ -11,6 +11,7 @@ #include <hang.h> #include <image.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/smp.h> #include <opensbi.h> #include <linux/libfdt.h> diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index 2744fb5d520..6a4e0332870 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -15,6 +15,7 @@ #include <spi_flash.h> #include <errno.h> #include <spl.h> +#include <asm/global_data.h>
diff --git a/common/splash_source.c b/common/splash_source.c index f51ca5ddf37..2737fc6e7ff 100644 --- a/common/splash_source.c +++ b/common/splash_source.c @@ -20,6 +20,7 @@ #include <spi_flash.h> #include <splash.h> #include <usb.h> +#include <asm/global_data.h>
diff --git a/common/stdio.c b/common/stdio.c index a15f30804bf..3a6d97c5687 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -19,7 +19,7 @@ #include <serial.h> #include <splash.h> #include <i2c.h> - +#include <asm/global_data.h> #include <dm/device-internal.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/disk/part_efi.c b/disk/part_efi.c index 60b1c1d7618..530a2f30f3d 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -15,6 +15,7 @@ #include <part.h> #include <uuid.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/unaligned.h> #include <command.h> #include <fdtdec.h> diff --git a/drivers/ata/libata.c b/drivers/ata/libata.c index d41200f6c26..47e2c5c1cc4 100644 --- a/drivers/ata/libata.c +++ b/drivers/ata/libata.c @@ -5,6 +5,8 @@ * port from the libata of linux kernel */
+#include <common.h> +#include <compiler.h> #include <libata.h>
u64 ata_id_n_sectors(u16 *id) diff --git a/drivers/ata/mtk_ahci.c b/drivers/ata/mtk_ahci.c index 4ad260a5bb9..47fa62bae75 100644 --- a/drivers/ata/mtk_ahci.c +++ b/drivers/ata/mtk_ahci.c @@ -10,6 +10,7 @@
#include <common.h> #include <ahci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <dm/of_access.h> diff --git a/drivers/ata/sata_mv.c b/drivers/ata/sata_mv.c index b2b5c699ad1..9021a00cdb6 100644 --- a/drivers/ata/sata_mv.c +++ b/drivers/ata/sata_mv.c @@ -38,6 +38,7 @@ #include <dm.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <fis.h> diff --git a/drivers/bios_emulator/atibios.c b/drivers/bios_emulator/atibios.c index 9c7f14e98f4..6c7cc24cbd9 100644 --- a/drivers/bios_emulator/atibios.c +++ b/drivers/bios_emulator/atibios.c @@ -46,6 +46,7 @@ * BIOS in u-boot. ****************************************************************************/ #include <common.h> +#include <compiler.h> #include <bios_emul.h> #include <errno.h> #include <log.h> diff --git a/drivers/block/blkcache.c b/drivers/block/blkcache.c index eca66198edf..b53420a3a88 100644 --- a/drivers/block/blkcache.c +++ b/drivers/block/blkcache.c @@ -9,6 +9,7 @@ #include <log.h> #include <malloc.h> #include <part.h> +#include <asm/global_data.h> #include <linux/ctype.h> #include <linux/list.h>
diff --git a/drivers/block/sandbox.c b/drivers/block/sandbox.c index cca2237136a..11ebdd52d77 100644 --- a/drivers/block/sandbox.c +++ b/drivers/block/sandbox.c @@ -11,6 +11,7 @@ #include <os.h> #include <malloc.h> #include <sandboxblockdev.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/errno.h> #include <dm/device-internal.h> diff --git a/drivers/bootcount/bootcount_ram.c b/drivers/bootcount/bootcount_ram.c index 078c84d5eca..8cc30cf40ef 100644 --- a/drivers/bootcount/bootcount_ram.c +++ b/drivers/bootcount/bootcount_ram.c @@ -7,6 +7,7 @@ #include <common.h> #include <cpu_func.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/cache/cache-v5l2.c b/drivers/cache/cache-v5l2.c index 51c074bfe23..305a737d3b3 100644 --- a/drivers/cache/cache-v5l2.c +++ b/drivers/cache/cache-v5l2.c @@ -9,6 +9,7 @@ #include <cache.h> #include <dm.h> #include <hang.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/ofnode.h> #include <linux/bitops.h> diff --git a/drivers/cache/sandbox_cache.c b/drivers/cache/sandbox_cache.c index 9050c4cf340..0fb767e4339 100644 --- a/drivers/cache/sandbox_cache.c +++ b/drivers/cache/sandbox_cache.c @@ -7,6 +7,7 @@ #include <cache.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h>
diff --git a/drivers/clk/altera/clk-agilex.c b/drivers/clk/altera/clk-agilex.c index a539889d5be..4c7c6531651 100644 --- a/drivers/clk/altera/clk-agilex.c +++ b/drivers/clk/altera/clk-agilex.c @@ -5,6 +5,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk-uclass.h> #include <dm.h> diff --git a/drivers/clk/altera/clk-arria10.c b/drivers/clk/altera/clk-arria10.c index 732ed4d79b9..a2f105a415f 100644 --- a/drivers/clk/altera/clk-arria10.c +++ b/drivers/clk/altera/clk-arria10.c @@ -5,6 +5,7 @@
#include <common.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk-uclass.h> #include <dm.h> diff --git a/drivers/clk/aspeed/clk_ast2500.c b/drivers/clk/aspeed/clk_ast2500.c index aab7d14deb7..0e0e5fb2ee3 100644 --- a/drivers/clk/aspeed/clk_ast2500.c +++ b/drivers/clk/aspeed/clk_ast2500.c @@ -7,6 +7,7 @@ #include <clk-uclass.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/scu_ast2500.h> #include <dm/lists.h> diff --git a/drivers/clk/at91/clk-generated.c b/drivers/clk/at91/clk-generated.c new file mode 100644 index 00000000000..a65cadee372 --- /dev/null +++ b/drivers/clk/at91/clk-generated.c @@ -0,0 +1,179 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <log.h> +#include <malloc.h> +#include <asm/global_data.h> +#include <linux/err.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define GENERATED_SOURCE_MAX 6 +#define GENERATED_MAX_DIV 255 + +/** + * generated_clk_bind() - for the generated clock driver + * Recursively bind its children as clk devices. + * + * @return: 0 on success, or negative error code on failure + */ +static int generated_clk_bind(struct udevice *dev) +{ + return at91_clk_sub_device_bind(dev, "generic-clk"); +} + +static const struct udevice_id generated_clk_match[] = { + { .compatible = "atmel,sama5d2-clk-generated" }, + {} +}; + +U_BOOT_DRIVER(generated_clk) = { + .name = "generated-clk", + .id = UCLASS_MISC, + .of_match = generated_clk_match, + .bind = generated_clk_bind, +}; + +/*-------------------------------------------------------------*/ + +struct generic_clk_priv { + u32 num_parents; +}; + +static ulong generic_clk_get_rate(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + struct clk parent; + ulong clk_rate; + u32 tmp, gckdiv; + u8 clock_source, parent_index; + int ret; + + writel(clk->id & AT91_PMC_PCR_PID_MASK, &pmc->pcr); + tmp = readl(&pmc->pcr); + clock_source = (tmp >> AT91_PMC_PCR_GCKCSS_OFFSET) & + AT91_PMC_PCR_GCKCSS_MASK; + gckdiv = (tmp >> AT91_PMC_PCR_GCKDIV_OFFSET) & AT91_PMC_PCR_GCKDIV_MASK; + + parent_index = clock_source - 1; + ret = clk_get_by_index(dev_get_parent(clk->dev), parent_index, &parent); + if (ret) + return 0; + + clk_rate = clk_get_rate(&parent) / (gckdiv + 1); + + clk_free(&parent); + + return clk_rate; +} + +static ulong generic_clk_set_rate(struct clk *clk, ulong rate) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + struct generic_clk_priv *priv = dev_get_priv(clk->dev); + struct clk parent, best_parent; + ulong tmp_rate, best_rate = rate, parent_rate; + int tmp_diff, best_diff = -1; + u32 div, best_div = 0; + u8 best_parent_index, best_clock_source = 0; + u8 i; + u32 tmp; + int ret; + + for (i = 0; i < priv->num_parents; i++) { + ret = clk_get_by_index(dev_get_parent(clk->dev), i, &parent); + if (ret) + return ret; + + parent_rate = clk_get_rate(&parent); + if (IS_ERR_VALUE(parent_rate)) + return parent_rate; + + for (div = 1; div < GENERATED_MAX_DIV + 2; div++) { + tmp_rate = DIV_ROUND_CLOSEST(parent_rate, div); + tmp_diff = abs(rate - tmp_rate); + + if (best_diff < 0 || best_diff > tmp_diff) { + best_rate = tmp_rate; + best_diff = tmp_diff; + + best_div = div - 1; + best_parent = parent; + best_parent_index = i; + best_clock_source = best_parent_index + 1; + } + + if (!best_diff || tmp_rate < rate) + break; + } + + if (!best_diff) + break; + } + + debug("GCK: best parent: %s, best_rate = %ld, best_div = %d\n", + best_parent.dev->name, best_rate, best_div); + + ret = clk_enable(&best_parent); + if (ret) + return ret; + + writel(clk->id & AT91_PMC_PCR_PID_MASK, &pmc->pcr); + tmp = readl(&pmc->pcr); + tmp &= ~(AT91_PMC_PCR_GCKDIV | AT91_PMC_PCR_GCKCSS); + tmp |= AT91_PMC_PCR_GCKCSS_(best_clock_source) | + AT91_PMC_PCR_CMD_WRITE | + AT91_PMC_PCR_GCKDIV_(best_div) | + AT91_PMC_PCR_GCKEN; + writel(tmp, &pmc->pcr); + + while (!(readl(&pmc->sr) & AT91_PMC_GCKRDY)) + ; + + return 0; +} + +static struct clk_ops generic_clk_ops = { + .of_xlate = at91_clk_of_xlate, + .get_rate = generic_clk_get_rate, + .set_rate = generic_clk_set_rate, +}; + +static int generic_clk_ofdata_to_platdata(struct udevice *dev) +{ + struct generic_clk_priv *priv = dev_get_priv(dev); + u32 cells[GENERATED_SOURCE_MAX]; + u32 num_parents; + + num_parents = fdtdec_get_int_array_count(gd->fdt_blob, + dev_of_offset(dev_get_parent(dev)), "clocks", cells, + GENERATED_SOURCE_MAX); + + if (!num_parents) + return -1; + + priv->num_parents = num_parents; + + return 0; +} + +U_BOOT_DRIVER(generic_clk) = { + .name = "generic-clk", + .id = UCLASS_CLK, + .probe = at91_clk_probe, + .ofdata_to_platdata = generic_clk_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct generic_clk_priv), + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &generic_clk_ops, +}; diff --git a/drivers/clk/at91/clk-h32mx.c b/drivers/clk/at91/clk-h32mx.c new file mode 100644 index 00000000000..b27aeacc7e9 --- /dev/null +++ b/drivers/clk/at91/clk-h32mx.c @@ -0,0 +1,57 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <asm/global_data.h> +#include <dm/device_compat.h> +#include <dm/util.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define H32MX_MAX_FREQ 90000000 + +static ulong sama5d4_h32mx_clk_get_rate(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + ulong rate = gd->arch.mck_rate_hz; + + if (readl(&pmc->mckr) & AT91_PMC_MCKR_H32MXDIV) + rate /= 2; + + if (rate > H32MX_MAX_FREQ) + dev_dbg(clk->dev, "H32MX clock is too fast\n"); + + return rate; +} + +static struct clk_ops sama5d4_h32mx_clk_ops = { + .get_rate = sama5d4_h32mx_clk_get_rate, +}; + +static int sama5d4_h32mx_clk_probe(struct udevice *dev) +{ + return at91_pmc_core_probe(dev); +} + +static const struct udevice_id sama5d4_h32mx_clk_match[] = { + { .compatible = "atmel,sama5d4-clk-h32mx" }, + {} +}; + +U_BOOT_DRIVER(sama5d4_h32mx_clk) = { + .name = "sama5d4-h32mx-clk", + .id = UCLASS_CLK, + .of_match = sama5d4_h32mx_clk_match, + .probe = sama5d4_h32mx_clk_probe, + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &sama5d4_h32mx_clk_ops, +}; diff --git a/drivers/clk/at91/clk-main.c b/drivers/clk/at91/clk-main.c index b52d926f339..2b6878338d6 100644 --- a/drivers/clk/at91/clk-main.c +++ b/drivers/clk/at91/clk-main.c @@ -13,6 +13,7 @@ #include <common.h> #include <clk-uclass.h> #include <dm.h> +#include <asm/global_data.h> #include <linux/clk-provider.h> #include <linux/clk/at91_pmc.h> #include <linux/delay.h> diff --git a/drivers/clk/at91/clk-master.c b/drivers/clk/at91/clk-master.c index 5d93e6a7e52..9ad2e73d3fb 100644 --- a/drivers/clk/at91/clk-master.c +++ b/drivers/clk/at91/clk-master.c @@ -13,6 +13,7 @@ #include <clk-uclass.h> #include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <linux/clk-provider.h> #include <linux/clk/at91_pmc.h>
diff --git a/drivers/clk/at91/clk-plla.c b/drivers/clk/at91/clk-plla.c new file mode 100644 index 00000000000..4f246afa18a --- /dev/null +++ b/drivers/clk/at91/clk-plla.c @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <asm/global_data.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +DECLARE_GLOBAL_DATA_PTR; + +static int plla_clk_enable(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + + if (readl(&pmc->sr) & AT91_PMC_LOCKA) + return 0; + + return -EINVAL; +} + +static ulong plla_clk_get_rate(struct clk *clk) +{ + return gd->arch.plla_rate_hz; +} + +static struct clk_ops plla_clk_ops = { + .enable = plla_clk_enable, + .get_rate = plla_clk_get_rate, +}; + +static int plla_clk_probe(struct udevice *dev) +{ + return at91_pmc_core_probe(dev); +} + +static const struct udevice_id plla_clk_match[] = { + { .compatible = "atmel,sama5d3-clk-pll" }, + {} +}; + +U_BOOT_DRIVER(at91_plla_clk) = { + .name = "at91-plla-clk", + .id = UCLASS_CLK, + .of_match = plla_clk_match, + .probe = plla_clk_probe, + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &plla_clk_ops, +}; diff --git a/drivers/clk/at91/clk-usb.c b/drivers/clk/at91/clk-usb.c new file mode 100644 index 00000000000..416a5007f68 --- /dev/null +++ b/drivers/clk/at91/clk-usb.c @@ -0,0 +1,148 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Microhip / Atmel Corporation + * Wenyou.Yang wenyou.yang@microchip.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <log.h> +#include <asm/global_data.h> +#include <dm/device.h> +#include <linux/err.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define AT91_USB_CLK_SOURCE_MAX 2 +#define AT91_USB_CLK_MAX_DIV 15 + +struct at91_usb_clk_priv { + u32 num_clksource; +}; + +static ulong at91_usb_clk_get_rate(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + struct clk source; + u32 tmp, usbdiv; + u8 source_index; + int ret; + + tmp = readl(&pmc->pcr); + source_index = (tmp >> AT91_PMC_USB_USBS_OFFSET) & + AT91_PMC_USB_USBS_MASK; + usbdiv = (tmp >> AT91_PMC_USB_DIV_OFFSET) & AT91_PMC_USB_DIV_MASK; + + ret = clk_get_by_index(clk->dev, source_index, &source); + if (ret) + return 0; + + return clk_get_rate(&source) / (usbdiv + 1); +} + +static ulong at91_usb_clk_set_rate(struct clk *clk, ulong rate) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + struct at91_usb_clk_priv *priv = dev_get_priv(clk->dev); + struct clk source, best_source; + ulong tmp_rate, best_rate = rate, source_rate; + int tmp_diff, best_diff = -1; + u32 div, best_div = 0; + u8 best_source_index = 0; + u8 i; + u32 tmp; + int ret; + + for (i = 0; i < priv->num_clksource; i++) { + ret = clk_get_by_index(clk->dev, i, &source); + if (ret) + return ret; + + source_rate = clk_get_rate(&source); + if (IS_ERR_VALUE(source_rate)) + return source_rate; + + for (div = 1; div < AT91_USB_CLK_MAX_DIV + 2; div++) { + tmp_rate = DIV_ROUND_CLOSEST(source_rate, div); + tmp_diff = abs(rate - tmp_rate); + + if (best_diff < 0 || best_diff > tmp_diff) { + best_rate = tmp_rate; + best_diff = tmp_diff; + + best_div = div - 1; + best_source = source; + best_source_index = i; + } + + if (!best_diff || tmp_rate < rate) + break; + } + + if (!best_diff) + break; + } + + debug("AT91 USB: best sourc: %s, best_rate = %ld, best_div = %d\n", + best_source.dev->name, best_rate, best_div); + + ret = clk_enable(&best_source); + if (ret) + return ret; + + tmp = AT91_PMC_USB_USBS_(best_source_index) | + AT91_PMC_USB_DIV_(best_div); + writel(tmp, &pmc->usb); + + return 0; +} + +static struct clk_ops at91_usb_clk_ops = { + .get_rate = at91_usb_clk_get_rate, + .set_rate = at91_usb_clk_set_rate, +}; + +static int at91_usb_clk_ofdata_to_platdata(struct udevice *dev) +{ + struct at91_usb_clk_priv *priv = dev_get_priv(dev); + u32 cells[AT91_USB_CLK_SOURCE_MAX]; + u32 num_clksource; + + num_clksource = fdtdec_get_int_array_count(gd->fdt_blob, + dev_of_offset(dev), + "clocks", cells, + AT91_USB_CLK_SOURCE_MAX); + + if (!num_clksource) + return -1; + + priv->num_clksource = num_clksource; + + return 0; +} + +static int at91_usb_clk_probe(struct udevice *dev) +{ + return at91_pmc_core_probe(dev); +} + +static const struct udevice_id at91_usb_clk_match[] = { + { .compatible = "atmel,at91sam9x5-clk-usb" }, + {} +}; + +U_BOOT_DRIVER(at91_usb_clk) = { + .name = "at91-usb-clk", + .id = UCLASS_CLK, + .of_match = at91_usb_clk_match, + .probe = at91_usb_clk_probe, + .ofdata_to_platdata = at91_usb_clk_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct at91_usb_clk_priv), + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &at91_usb_clk_ops, +}; diff --git a/drivers/clk/at91/compat.c b/drivers/clk/at91/compat.c index 9563285674b..4a1f0e50aa1 100644 --- a/drivers/clk/at91/compat.c +++ b/drivers/clk/at91/compat.c @@ -9,6 +9,7 @@ #include <common.h> #include <clk-uclass.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/lists.h> #include <dm/util.h> diff --git a/drivers/clk/at91/pmc.c b/drivers/clk/at91/pmc.c index 660e2319214..3f3b15a2332 100644 --- a/drivers/clk/at91/pmc.c +++ b/drivers/clk/at91/pmc.c @@ -4,10 +4,10 @@ * Wenyou.Yang wenyou.yang@atmel.com */
+#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk-uclass.h> -#include <common.h> - #include "pmc.h"
static int at91_clk_of_xlate(struct clk *clk, struct ofnode_phandle_args *args) diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 31c5997aead..6db4a3eee81 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -14,6 +14,7 @@ #include <errno.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/devres.h> #include <dm/read.h> diff --git a/drivers/clk/clk_octeon.c b/drivers/clk/clk_octeon.c index fd559e05fc7..5dfcf7877ba 100644 --- a/drivers/clk/clk_octeon.c +++ b/drivers/clk/clk_octeon.c @@ -5,6 +5,7 @@
#include <clk-uclass.h> #include <dm.h> +#include <asm/global_data.h> #include <dt-bindings/clock/octeon-clock.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/clk/clk_pic32.c b/drivers/clk/clk_pic32.c index dc46de2a7cf..78daf2cbad3 100644 --- a/drivers/clk/clk_pic32.c +++ b/drivers/clk/clk_pic32.c @@ -10,6 +10,7 @@ #include <div64.h> #include <time.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <asm/io.h> #include <linux/bitops.h> diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index c8840b9e5f1..65ffd32d08e 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -14,6 +14,7 @@ #include <syscon.h> #include <time.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <linux/iopoll.h> diff --git a/drivers/clk/clk_zynq.c b/drivers/clk/clk_zynq.c index a699a3664c3..b00fe1d13b0 100644 --- a/drivers/clk/clk_zynq.c +++ b/drivers/clk/clk_zynq.c @@ -11,6 +11,7 @@ #include <clk-uclass.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/lists.h> #include <errno.h> diff --git a/drivers/clk/mpc83xx_clk.c b/drivers/clk/mpc83xx_clk.c index 8d96ec767ac..9ec41d7705a 100644 --- a/drivers/clk/mpc83xx_clk.c +++ b/drivers/clk/mpc83xx_clk.c @@ -11,6 +11,7 @@ #include <dm.h> #include <log.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dt-bindings/clk/mpc83xx-clk.h> #include <asm/arch/soc.h> diff --git a/drivers/clk/renesas/clk-rcar-gen2.c b/drivers/clk/renesas/clk-rcar-gen2.c index 16da10c8dd8..b423c9414b2 100644 --- a/drivers/clk/renesas/clk-rcar-gen2.c +++ b/drivers/clk/renesas/clk-rcar-gen2.c @@ -15,6 +15,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h>
#include <dt-bindings/clock/renesas-cpg-mssr.h> diff --git a/drivers/clk/renesas/clk-rcar-gen3.c b/drivers/clk/renesas/clk-rcar-gen3.c index 30a101fe862..3223becd753 100644 --- a/drivers/clk/renesas/clk-rcar-gen3.c +++ b/drivers/clk/renesas/clk-rcar-gen3.c @@ -16,6 +16,7 @@ #include <errno.h> #include <log.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/clk/rockchip/clk_px30.c b/drivers/clk/rockchip/clk_px30.c index 71916dbf3b1..0ef449159d9 100644 --- a/drivers/clk/rockchip/clk_px30.c +++ b/drivers/clk/rockchip/clk_px30.c @@ -14,6 +14,7 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_px30.h> #include <asm/arch-rockchip/hardware.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/lists.h> #include <dt-bindings/clock/px30-cru.h> diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index a1dd642eefe..be1f646c070 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <mapmem.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru.h> diff --git a/drivers/clk/rockchip/clk_rk3308.c b/drivers/clk/rockchip/clk_rk3308.c index d3633b69795..4a72fe29375 100644 --- a/drivers/clk/rockchip/clk_rk3308.c +++ b/drivers/clk/rockchip/clk_rk3308.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cru_rk3308.h> #include <asm/arch-rockchip/clock.h> diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index aa1d98ca2a2..9e6bb9cd88d 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -12,6 +12,7 @@ #include <log.h> #include <malloc.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_rv1108.h> diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index efdb0f29058..360cfa72bc1 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -12,6 +12,7 @@ #include <errno.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/device-internal.h> #include <dm/uclass.h> diff --git a/drivers/core/device.c b/drivers/core/device.c index e90d70101c2..01670996dc8 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -11,6 +11,7 @@ #include <common.h> #include <cpu_func.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk.h> #include <fdtdec.h> diff --git a/drivers/core/fdtaddr.c b/drivers/core/fdtaddr.c index 8b48aa5bc5b..b9874c743d1 100644 --- a/drivers/core/fdtaddr.c +++ b/drivers/core/fdtaddr.c @@ -12,6 +12,7 @@ #include <dm.h> #include <fdt_support.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device-internal.h>
diff --git a/drivers/core/of_access.c b/drivers/core/of_access.c index 0a12e9b26f8..9960e6b310b 100644 --- a/drivers/core/of_access.c +++ b/drivers/core/of_access.c @@ -22,6 +22,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/bug.h> #include <linux/libfdt.h> #include <dm/of_access.h> diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 7d1b89514c7..22a6e8c4cea 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -10,6 +10,7 @@ #include <fdt_support.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <dm/of_access.h> #include <dm/of_addr.h> diff --git a/drivers/core/read.c b/drivers/core/read.c index 076125824ca..fbe75f98624 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/of_access.h> #include <mapmem.h> #include <asm/types.h> diff --git a/drivers/core/regmap.c b/drivers/core/regmap.c index c2bed88eac4..95309171ea9 100644 --- a/drivers/core/regmap.c +++ b/drivers/core/regmap.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <malloc.h> #include <mapmem.h> diff --git a/drivers/core/root.c b/drivers/core/root.c index 0726be6b795..b5446b1db02 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <dm/acpi.h> #include <dm/device.h> diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index c3f1b73cd6b..95c37db5ad0 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -13,6 +13,7 @@ #include <errno.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/device-internal.h> #include <dm/lists.h> diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index 502c8ebb433..aca14157ad5 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -7,6 +7,7 @@ #include <cpu.h> #include <dm.h> #include <thermal.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/arch/sci/sci.h> #include <asm/arch/sys_proto.h> diff --git a/drivers/cpu/riscv_cpu.c b/drivers/cpu/riscv_cpu.c index 93ce708f652..3c7395a9f20 100644 --- a/drivers/cpu/riscv_cpu.c +++ b/drivers/cpu/riscv_cpu.c @@ -10,6 +10,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <linux/bitops.h> diff --git a/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c b/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c index e91fe644580..f5ae35e1325 100644 --- a/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c +++ b/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <u-boot/rsa-mod-exp.h> #include <errno.h> #include <fdtdec.h> diff --git a/drivers/ddr/altera/sdram_agilex.c b/drivers/ddr/altera/sdram_agilex.c index d6e7a175d0d..d554df87eba 100644 --- a/drivers/ddr/altera/sdram_agilex.c +++ b/drivers/ddr/altera/sdram_agilex.c @@ -13,6 +13,7 @@ #include <log.h> #include <ram.h> #include <reset.h> +#include <asm/global_data.h> #include "sdram_soc64.h" #include <wait_bit.h> #include <asm/arch/firewall.h> diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index 3c58f59f3ab..4a8f8dea1c4 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -13,6 +13,7 @@ #include <wait_bit.h> #include <watchdog.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/fpga_manager.h> #include <asm/arch/misc.h> diff --git a/drivers/ddr/altera/sdram_s10.c b/drivers/ddr/altera/sdram_s10.c index 2945f1e1df5..6235bd959fe 100644 --- a/drivers/ddr/altera/sdram_s10.c +++ b/drivers/ddr/altera/sdram_s10.c @@ -15,6 +15,7 @@ #include <log.h> #include <ram.h> #include <reset.h> +#include <asm/global_data.h> #include "sdram_s10.h" #include <wait_bit.h> #include <asm/arch/firewall.h> diff --git a/drivers/ddr/altera/sdram_soc64.c b/drivers/ddr/altera/sdram_soc64.c index 8cb75fe02a2..40fcc8d2e0f 100644 --- a/drivers/ddr/altera/sdram_soc64.c +++ b/drivers/ddr/altera/sdram_soc64.c @@ -15,6 +15,7 @@ #include <log.h> #include <ram.h> #include <reset.h> +#include <asm/global_data.h> #include "sdram_soc64.h" #include <wait_bit.h> #include <asm/arch/firewall.h> diff --git a/drivers/ddr/imx/imx8m/helper.c b/drivers/ddr/imx/imx8m/helper.c index 5ebf54f5f4a..f23904bf712 100644 --- a/drivers/ddr/imx/imx8m/helper.c +++ b/drivers/ddr/imx/imx8m/helper.c @@ -6,6 +6,7 @@ #include <common.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <asm/io.h> diff --git a/drivers/demo/demo-shape.c b/drivers/demo/demo-shape.c index 8686c998457..d0c0c736551 100644 --- a/drivers/demo/demo-shape.c +++ b/drivers/demo/demo-shape.c @@ -10,6 +10,7 @@ #include <log.h> #include <malloc.h> #include <dm-demo.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h>
diff --git a/drivers/demo/demo-uclass.c b/drivers/demo/demo-uclass.c index 6c36f03254f..5856a9891e8 100644 --- a/drivers/demo/demo-uclass.c +++ b/drivers/demo/demo-uclass.c @@ -13,6 +13,7 @@ #include <fdtdec.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/list.h>
diff --git a/drivers/fpga/socfpga_arria10.c b/drivers/fpga/socfpga_arria10.c index 44e1ac54c3f..4bea7fd900d 100644 --- a/drivers/fpga/socfpga_arria10.c +++ b/drivers/fpga/socfpga_arria10.c @@ -4,6 +4,7 @@ */ #include <image.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/fpga_manager.h> #include <asm/arch/reset_manager.h> diff --git a/drivers/fpga/zynqmppl.c b/drivers/fpga/zynqmppl.c index 8ce140a2e1a..6b394869dbf 100644 --- a/drivers/fpga/zynqmppl.c +++ b/drivers/fpga/zynqmppl.c @@ -7,6 +7,7 @@
#include <console.h> #include <common.h> +#include <compiler.h> #include <cpu_func.h> #include <log.h> #include <zynqmppl.h> diff --git a/drivers/gpio/74x164_gpio.c b/drivers/gpio/74x164_gpio.c index 64717a6780e..045685fcd9c 100644 --- a/drivers/gpio/74x164_gpio.c +++ b/drivers/gpio/74x164_gpio.c @@ -13,6 +13,7 @@ #include <dm.h> #include <fdtdec.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <dm/device_compat.h> diff --git a/drivers/gpio/altera_pio.c b/drivers/gpio/altera_pio.c index 75800d9f31c..e52124dbd50 100644 --- a/drivers/gpio/altera_pio.c +++ b/drivers/gpio/altera_pio.c @@ -9,6 +9,7 @@ #include <errno.h> #include <malloc.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h>
diff --git a/drivers/gpio/atmel_pio4.c b/drivers/gpio/atmel_pio4.c index 18f365fa411..3256469ddc1 100644 --- a/drivers/gpio/atmel_pio4.c +++ b/drivers/gpio/atmel_pio4.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <malloc.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/bitops.h> #include <mach/gpio.h> diff --git a/drivers/gpio/da8xx_gpio.c b/drivers/gpio/da8xx_gpio.c index f8758885101..614c489e45d 100644 --- a/drivers/gpio/da8xx_gpio.c +++ b/drivers/gpio/da8xx_gpio.c @@ -10,6 +10,7 @@ #include <dm.h> #include <fdtdec.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <dt-bindings/gpio/gpio.h> diff --git a/drivers/gpio/gpio-rcar.c b/drivers/gpio/gpio-rcar.c index a993fd4d700..2e80196905d 100644 --- a/drivers/gpio/gpio-rcar.c +++ b/drivers/gpio/gpio-rcar.c @@ -7,6 +7,7 @@ #include <clk.h> #include <dm.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/pinctrl.h> #include <errno.h> diff --git a/drivers/gpio/gpio-rza1.c b/drivers/gpio/gpio-rza1.c index 86804ac2f5f..aa600e483a6 100644 --- a/drivers/gpio/gpio-rza1.c +++ b/drivers/gpio/gpio-rza1.c @@ -7,6 +7,7 @@ #include <clk.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <linux/bitops.h> diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 0c01413b587..cabd3767522 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -16,6 +16,7 @@ #include <fdtdec.h> #include <malloc.h> #include <acpi/acpi_device.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <dm/device_compat.h> #include <linux/bug.h> diff --git a/drivers/gpio/intel_broadwell_gpio.c b/drivers/gpio/intel_broadwell_gpio.c index 95f8b2ba6cd..4323f0ba760 100644 --- a/drivers/gpio/intel_broadwell_gpio.c +++ b/drivers/gpio/intel_broadwell_gpio.c @@ -12,6 +12,7 @@ #include <pci.h> #include <syscon.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/pci.h> diff --git a/drivers/gpio/intel_ich6_gpio.c b/drivers/gpio/intel_ich6_gpio.c index 73d98fde554..4a2757d1ac6 100644 --- a/drivers/gpio/intel_ich6_gpio.c +++ b/drivers/gpio/intel_ich6_gpio.c @@ -34,6 +34,7 @@ #include <pch.h> #include <pci.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/pci.h> diff --git a/drivers/gpio/msm_gpio.c b/drivers/gpio/msm_gpio.c index 416fb56a98d..710994b4e12 100644 --- a/drivers/gpio/msm_gpio.c +++ b/drivers/gpio/msm_gpio.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h>
diff --git a/drivers/gpio/mxs_gpio.c b/drivers/gpio/mxs_gpio.c index aaabb0216be..0340786712e 100644 --- a/drivers/gpio/mxs_gpio.c +++ b/drivers/gpio/mxs_gpio.c @@ -9,6 +9,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/drivers/gpio/nx_gpio.c b/drivers/gpio/nx_gpio.c index 5ec73c43599..c51e2b9f608 100644 --- a/drivers/gpio/nx_gpio.c +++ b/drivers/gpio/nx_gpio.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h>
diff --git a/drivers/gpio/omap_gpio.c b/drivers/gpio/omap_gpio.c index 6eaa0a08a26..4200afba121 100644 --- a/drivers/gpio/omap_gpio.c +++ b/drivers/gpio/omap_gpio.c @@ -20,6 +20,7 @@ #include <common.h> #include <dm.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <linux/errno.h> diff --git a/drivers/gpio/pcf8575_gpio.c b/drivers/gpio/pcf8575_gpio.c index 1b9a18fe5dc..8a9214dec3e 100644 --- a/drivers/gpio/pcf8575_gpio.c +++ b/drivers/gpio/pcf8575_gpio.c @@ -28,6 +28,7 @@ #include <i2c.h> #include <log.h> #include <asm-generic/gpio.h> +#include <asm/global_data.h> #include <linux/bitops.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/gpio/pic32_gpio.c b/drivers/gpio/pic32_gpio.c index bb1ad256fac..50c5376e00d 100644 --- a/drivers/gpio/pic32_gpio.c +++ b/drivers/gpio/pic32_gpio.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <linux/bitops.h> diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index c78227f4da3..14f262739d2 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <dm/device-internal.h> diff --git a/drivers/gpio/vybrid_gpio.c b/drivers/gpio/vybrid_gpio.c index 4efff5c3643..82ae6d88941 100644 --- a/drivers/gpio/vybrid_gpio.c +++ b/drivers/gpio/vybrid_gpio.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/drivers/hwspinlock/hwspinlock-uclass.c b/drivers/hwspinlock/hwspinlock-uclass.c index 9da79455ed3..fdc90c3f0e0 100644 --- a/drivers/hwspinlock/hwspinlock-uclass.c +++ b/drivers/hwspinlock/hwspinlock-uclass.c @@ -8,6 +8,7 @@ #include <errno.h> #include <hwspinlock.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device_compat.h> #include <linux/compat.h> diff --git a/drivers/i2c/at91_i2c.c b/drivers/i2c/at91_i2c.c index 9d6c6d80e2a..ee5dc1db96c 100644 --- a/drivers/i2c/at91_i2c.c +++ b/drivers/i2c/at91_i2c.c @@ -6,6 +6,7 @@ */
#include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <clk.h> diff --git a/drivers/i2c/cros_ec_tunnel.c b/drivers/i2c/cros_ec_tunnel.c index a630817352e..2853a984fbe 100644 --- a/drivers/i2c/cros_ec_tunnel.c +++ b/drivers/i2c/cros_ec_tunnel.c @@ -9,6 +9,7 @@ #include <cros_ec.h> #include <errno.h> #include <i2c.h> +#include <asm/global_data.h>
diff --git a/drivers/i2c/exynos_hs_i2c.c b/drivers/i2c/exynos_hs_i2c.c index 5785adedb6d..34d10abde06 100644 --- a/drivers/i2c/exynos_hs_i2c.c +++ b/drivers/i2c/exynos_hs_i2c.c @@ -13,6 +13,7 @@ #include <asm/arch/clk.h> #include <asm/arch/cpu.h> #include <asm/arch/pinmux.h> +#include <asm/global_data.h> #include <linux/delay.h> #include "s3c24x0_i2c.h"
diff --git a/drivers/i2c/fsl_i2c.c b/drivers/i2c/fsl_i2c.c index da933452f51..e7a8dcc8212 100644 --- a/drivers/i2c/fsl_i2c.c +++ b/drivers/i2c/fsl_i2c.c @@ -11,6 +11,7 @@ #include <i2c.h> /* Functional interface */ #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/fsl_i2c.h> /* HW definitions */ #include <clk.h> diff --git a/drivers/i2c/i2c-gpio.c b/drivers/i2c/i2c-gpio.c index 381938c956f..917cdf4e62e 100644 --- a/drivers/i2c/i2c-gpio.c +++ b/drivers/i2c/i2c-gpio.c @@ -10,6 +10,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/delay.h>
diff --git a/drivers/i2c/i2c_core.c b/drivers/i2c/i2c_core.c index da50d86cc8b..85cf75ecd92 100644 --- a/drivers/i2c/i2c_core.c +++ b/drivers/i2c/i2c_core.c @@ -10,6 +10,7 @@ #include <common.h> #include <i2c.h> #include <linker_lists.h> +#include <asm/global_data.h>
struct i2c_adapter *i2c_get_adapter(int index) { diff --git a/drivers/i2c/ihs_i2c.c b/drivers/i2c/ihs_i2c.c index cec38538da4..1c39b8c9dfc 100644 --- a/drivers/i2c/ihs_i2c.c +++ b/drivers/i2c/ihs_i2c.c @@ -13,6 +13,7 @@ #include <gdsys_fpga.h> #endif #include <log.h> +#include <asm/global_data.h> #include <asm/unaligned.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/i2c/iproc_i2c.c b/drivers/i2c/iproc_i2c.c index b7e9ced8983..b90c0ddba7c 100644 --- a/drivers/i2c/iproc_i2c.c +++ b/drivers/i2c/iproc_i2c.c @@ -4,6 +4,7 @@ * */
+#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <config.h> diff --git a/drivers/i2c/muxes/i2c-arb-gpio-challenge.c b/drivers/i2c/muxes/i2c-arb-gpio-challenge.c index 584d0a4fef1..4be32a1b38c 100644 --- a/drivers/i2c/muxes/i2c-arb-gpio-challenge.c +++ b/drivers/i2c/muxes/i2c-arb-gpio-challenge.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/delay.h>
diff --git a/drivers/i2c/muxes/i2c-mux-gpio.c b/drivers/i2c/muxes/i2c-mux-gpio.c index 83dcb402133..52da26ab182 100644 --- a/drivers/i2c/muxes/i2c-mux-gpio.c +++ b/drivers/i2c/muxes/i2c-mux-gpio.c @@ -7,6 +7,7 @@ * Peng Fan peng.fan@nxp.com */
+#include <asm/global_data.h> #include <asm/io.h> #include <asm-generic/gpio.h> #include <common.h> diff --git a/drivers/i2c/muxes/pca954x.c b/drivers/i2c/muxes/pca954x.c index 7360e162eeb..87e9f9cb21d 100644 --- a/drivers/i2c/muxes/pca954x.c +++ b/drivers/i2c/muxes/pca954x.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h>
diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index fdb8fd42e5c..c7dcafbef1b 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -10,6 +10,7 @@ #include <common.h> #include <i2c.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 7609594bd01..4bcab34514a 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -18,6 +18,7 @@ #include <log.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/delay.h> #include <linux/errno.h> diff --git a/drivers/i2c/nx_i2c.c b/drivers/i2c/nx_i2c.c index ca14a0ecac7..1aeeaa93682 100644 --- a/drivers/i2c/nx_i2c.c +++ b/drivers/i2c/nx_i2c.c @@ -7,6 +7,7 @@ #include <asm/arch/reset.h> #include <asm/arch/clk.h> #include <asm/arch/nx_gpio.h> +#include <asm/global_data.h> #include <linux/delay.h>
#define I2C_WRITE 0 diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index cb45d3c100f..43699fc2410 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -16,6 +16,7 @@ #else #include <asm/arch/s3c24x0_cpu.h> #endif +#include <asm/global_data.h> #include <asm/io.h> #include <i2c.h> #include "s3c24x0_i2c.h" diff --git a/drivers/i2c/sh_i2c.c b/drivers/i2c/sh_i2c.c index f857307e6a4..26a87006698 100644 --- a/drivers/i2c/sh_i2c.c +++ b/drivers/i2c/sh_i2c.c @@ -10,6 +10,7 @@ #include <common.h> #include <i2c.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index 1031066b8c4..db69c18cb6d 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -25,6 +25,7 @@ #endif #endif #include <i2c.h> +#include <asm/global_data.h> #include <linux/delay.h>
#if defined(CONFIG_SOFT_I2C_GPIO_SCL) diff --git a/drivers/i2c/tegra186_bpmp_i2c.c b/drivers/i2c/tegra186_bpmp_i2c.c index 37204718ca1..0a507079a2d 100644 --- a/drivers/i2c/tegra186_bpmp_i2c.c +++ b/drivers/i2c/tegra186_bpmp_i2c.c @@ -9,6 +9,7 @@ #include <log.h> #include <misc.h> #include <asm/arch-tegra/bpmp_abi.h> +#include <asm/global_data.h> #include <linux/bitops.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/input/i8042.c b/drivers/input/i8042.c index 7beaccca2c8..ca2978e79d5 100644 --- a/drivers/input/i8042.c +++ b/drivers/input/i8042.c @@ -14,6 +14,7 @@ #include <input.h> #include <keyboard.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/drivers/mailbox/k3-sec-proxy.c b/drivers/mailbox/k3-sec-proxy.c index 27ccc6eab06..77a98d15a4a 100644 --- a/drivers/mailbox/k3-sec-proxy.c +++ b/drivers/mailbox/k3-sec-proxy.c @@ -9,6 +9,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <linux/types.h> diff --git a/drivers/misc/atsha204a-i2c.c b/drivers/misc/atsha204a-i2c.c index 422ea6f3e5a..c79c260783e 100644 --- a/drivers/misc/atsha204a-i2c.c +++ b/drivers/misc/atsha204a-i2c.c @@ -16,6 +16,7 @@ #include <errno.h> #include <atsha204a-i2c.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <u-boot/crc.h>
diff --git a/drivers/misc/fs_loader.c b/drivers/misc/fs_loader.c index 56406aa1dd2..f6383a02398 100644 --- a/drivers/misc/fs_loader.c +++ b/drivers/misc/fs_loader.c @@ -11,6 +11,7 @@ #include <fs.h> #include <fs_loader.h> #include <log.h> +#include <asm/global_data.h> #include <linux/string.h> #include <mapmem.h> #include <malloc.h> diff --git a/drivers/misc/imx8/fuse.c b/drivers/misc/imx8/fuse.c index be181229370..38111c52548 100644 --- a/drivers/misc/imx8/fuse.c +++ b/drivers/misc/imx8/fuse.c @@ -9,6 +9,7 @@ #include <fuse.h> #include <asm/arch/sci/sci.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <linux/arm-smccc.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/misc/imx8/scu.c b/drivers/misc/imx8/scu.c index 223aac8518a..fc9320fa993 100644 --- a/drivers/misc/imx8/scu.c +++ b/drivers/misc/imx8/scu.c @@ -7,6 +7,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <dm/lists.h> diff --git a/drivers/misc/imx8/scu_api.c b/drivers/misc/imx8/scu_api.c index 20b74fbb18d..27ecce710fc 100644 --- a/drivers/misc/imx8/scu_api.c +++ b/drivers/misc/imx8/scu_api.c @@ -8,6 +8,7 @@ #include <common.h> #include <hang.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <asm/arch/sci/sci.h> diff --git a/drivers/misc/tegra186_bpmp.c b/drivers/misc/tegra186_bpmp.c index 18da138507c..1f4437226e7 100644 --- a/drivers/misc/tegra186_bpmp.c +++ b/drivers/misc/tegra186_bpmp.c @@ -8,6 +8,7 @@ #include <log.h> #include <malloc.h> #include <time.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/root.h> #include <mailbox.h> diff --git a/drivers/mmc/atmel_sdhci.c b/drivers/mmc/atmel_sdhci.c index f56ae63bc2c..8e212ca90e6 100644 --- a/drivers/mmc/atmel_sdhci.c +++ b/drivers/mmc/atmel_sdhci.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <sdhci.h> #include <asm/arch/clk.h> +#include <asm/global_data.h>
#define ATMEL_SDHC_MIN_FREQ 400000 #define ATMEL_SDHC_GCK_RATE 240000000 diff --git a/drivers/mmc/ca_dw_mmc.c b/drivers/mmc/ca_dw_mmc.c index 198c41f451f..562dcb8ee35 100644 --- a/drivers/mmc/ca_dw_mmc.c +++ b/drivers/mmc/ca_dw_mmc.c @@ -7,6 +7,7 @@ #include <common.h> #include <dwmmc.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <malloc.h> #include <errno.h> diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index 435ccac5942..94af116d10c 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -7,6 +7,7 @@ #include <common.h> #include <dwmmc.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <malloc.h> #include <errno.h> diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 642784e1f35..4bf12d9b2b8 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -21,6 +21,7 @@ #include <fsl_esdhc.h> #include <fdt_support.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <dm/device_compat.h> diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 1c015ab7646..5d841580c23 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -21,6 +21,7 @@ #include <mmc.h> #include <part.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/mmc/ftsdc010_mci.c b/drivers/mmc/ftsdc010_mci.c index bc0d5ffed51..71818f964d3 100644 --- a/drivers/mmc/ftsdc010_mci.c +++ b/drivers/mmc/ftsdc010_mci.c @@ -15,6 +15,7 @@ #include <malloc.h> #include <part.h> #include <mmc.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <linux/errno.h> diff --git a/drivers/mmc/hi6220_dw_mmc.c b/drivers/mmc/hi6220_dw_mmc.c index 67d6a05b3b5..61c209cb0a7 100644 --- a/drivers/mmc/hi6220_dw_mmc.c +++ b/drivers/mmc/hi6220_dw_mmc.c @@ -10,6 +10,7 @@ #include <errno.h> #include <fdtdec.h> #include <malloc.h> +#include <asm/global_data.h>
diff --git a/drivers/mmc/iproc_sdhci.c b/drivers/mmc/iproc_sdhci.c index 9f530638e31..7eda1d606fd 100644 --- a/drivers/mmc/iproc_sdhci.c +++ b/drivers/mmc/iproc_sdhci.c @@ -9,6 +9,7 @@ #include <errno.h> #include <malloc.h> #include <sdhci.h> +#include <asm/global_data.h> #include <linux/delay.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/mmc/jz_mmc.c b/drivers/mmc/jz_mmc.c index b33f0850738..eec432a0df6 100644 --- a/drivers/mmc/jz_mmc.c +++ b/drivers/mmc/jz_mmc.c @@ -9,6 +9,7 @@ #include <common.h> #include <malloc.h> #include <mmc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/unaligned.h> #include <errno.h> diff --git a/drivers/mmc/msm_sdhci.c b/drivers/mmc/msm_sdhci.c index 2a1f412278e..5d426e8378b 100644 --- a/drivers/mmc/msm_sdhci.c +++ b/drivers/mmc/msm_sdhci.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <sdhci.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/mmc/mv_sdhci.c b/drivers/mmc/mv_sdhci.c index 9b3dfa13e61..fa7c12837d1 100644 --- a/drivers/mmc/mv_sdhci.c +++ b/drivers/mmc/mv_sdhci.c @@ -7,6 +7,7 @@ #include <dm.h> #include <malloc.h> #include <sdhci.h> +#include <asm/global_data.h> #include <linux/mbus.h>
#define MVSDH_NAME "mv_sdh" diff --git a/drivers/mmc/mvebu_mmc.c b/drivers/mmc/mvebu_mmc.c index 03d5150b207..8ec1f57a1b7 100644 --- a/drivers/mmc/mvebu_mmc.c +++ b/drivers/mmc/mvebu_mmc.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <part.h> #include <mmc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index 715eee0e3e0..c5e57528660 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -35,6 +35,7 @@ #include <palmas.h> #endif #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #ifdef CONFIG_OMAP54XX diff --git a/drivers/mmc/pic32_sdhci.c b/drivers/mmc/pic32_sdhci.c index e201bdb8f4e..55dd25ff176 100644 --- a/drivers/mmc/pic32_sdhci.c +++ b/drivers/mmc/pic32_sdhci.c @@ -9,6 +9,9 @@ #include <dm.h> #include <sdhci.h> #include <clk.h> +#include <asm/global_data.h> +#include <linux/errno.h> +#include <mach/pic32.h>
struct pic32_sdhci_plat { struct mmc_config cfg; diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index d80b3fc28f3..83153c5c4c4 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -11,6 +11,7 @@ #include <malloc.h> #include <mmc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/compat.h> diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 24f599e868a..240db8a7569 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <sdhci.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <asm/gpio.h> #include <asm/arch/mmc.h> diff --git a/drivers/mmc/sdhci-cadence.c b/drivers/mmc/sdhci-cadence.c index cc99bebc305..b1e53e8d425 100644 --- a/drivers/mmc/sdhci-cadence.c +++ b/drivers/mmc/sdhci-cadence.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitfield.h> #include <linux/bitops.h> diff --git a/drivers/mmc/sh_mmcif.c b/drivers/mmc/sh_mmcif.c index ad386909e90..f7dd2aadc3e 100644 --- a/drivers/mmc/sh_mmcif.c +++ b/drivers/mmc/sh_mmcif.c @@ -14,6 +14,7 @@ #include <clk.h> #include <dm.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/mmc/sh_sdhi.c b/drivers/mmc/sh_sdhi.c index 29f83b65542..3047889cc82 100644 --- a/drivers/mmc/sh_sdhi.c +++ b/drivers/mmc/sh_sdhi.c @@ -15,6 +15,7 @@ #include <mmc.h> #include <dm.h> #include <part.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/mmc/socfpga_dw_mmc.c b/drivers/mmc/socfpga_dw_mmc.c index 0022f943bd7..16a6e3056dc 100644 --- a/drivers/mmc/socfpga_dw_mmc.c +++ b/drivers/mmc/socfpga_dw_mmc.c @@ -12,6 +12,7 @@ #include <dwmmc.h> #include <errno.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/libfdt.h> #include <linux/err.h> diff --git a/drivers/mmc/sti_sdhci.c b/drivers/mmc/sti_sdhci.c index 5578feebef7..db0b566a8b7 100644 --- a/drivers/mmc/sti_sdhci.c +++ b/drivers/mmc/sti_sdhci.c @@ -11,6 +11,7 @@ #include <reset-uclass.h> #include <sdhci.h> #include <asm/arch/sdhci.h> +#include <asm/global_data.h>
diff --git a/drivers/mmc/tmio-common.c b/drivers/mmc/tmio-common.c index c6539736766..b56f650f8a7 100644 --- a/drivers/mmc/tmio-common.c +++ b/drivers/mmc/tmio-common.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <mmc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/pinctrl.h> #include <linux/compat.h> diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c index 6ce9d00d0ae..aaec3c43fef 100644 --- a/drivers/mmc/xenon_sdhci.c +++ b/drivers/mmc/xenon_sdhci.c @@ -17,6 +17,7 @@ #include <common.h> #include <dm.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/libfdt.h> diff --git a/drivers/mtd/altera_qspi.c b/drivers/mtd/altera_qspi.c index cd4d32959a0..346244e1110 100644 --- a/drivers/mtd/altera_qspi.c +++ b/drivers/mtd/altera_qspi.c @@ -11,6 +11,7 @@ #include <flash.h> #include <log.h> #include <mtd.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 9e3a652f445..b4512e3a5fc 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -26,6 +26,7 @@ #include <init.h> #include <irq_func.h> #include <log.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/io.h> #include <asm/byteorder.h> diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 9360d4ed172..2499cb52d8c 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -7,6 +7,7 @@ #include <env.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/uclass-internal.h> #include <linux/err.h> diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index 698968bc116..ebb40f93325 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -35,6 +35,7 @@ #include <log.h> #include <malloc.h> #include <watchdog.h> +#include <asm/global_data.h> #include <dm/devres.h> #include <linux/bitops.h> #include <linux/bug.h> diff --git a/drivers/mtd/nand/raw/octeontx_nand.c b/drivers/mtd/nand/raw/octeontx_nand.c index ad219171e9c..3922c5475f7 100644 --- a/drivers/mtd/nand/raw/octeontx_nand.c +++ b/drivers/mtd/nand/raw/octeontx_nand.c @@ -4,6 +4,7 @@ */
#include <dm.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/devres.h> #include <dm/of_access.h> diff --git a/drivers/mtd/nand/raw/pxa3xx_nand.c b/drivers/mtd/nand/raw/pxa3xx_nand.c index 5fb3081c839..58d527acbd4 100644 --- a/drivers/mtd/nand/raw/pxa3xx_nand.c +++ b/drivers/mtd/nand/raw/pxa3xx_nand.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <fdtdec.h> #include <nand.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/devres.h> #include <linux/bitops.h> diff --git a/drivers/mtd/nand/raw/sunxi_nand.c b/drivers/mtd/nand/raw/sunxi_nand.c index 12fc065b320..7bc6ec7beea 100644 --- a/drivers/mtd/nand/raw/sunxi_nand.c +++ b/drivers/mtd/nand/raw/sunxi_nand.c @@ -29,6 +29,7 @@ #include <malloc.h> #include <memalign.h> #include <nand.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/devres.h> #include <linux/bitops.h> diff --git a/drivers/mtd/nand/raw/tegra_nand.c b/drivers/mtd/nand/raw/tegra_nand.c index b9f5bdd9535..dd14c34738a 100644 --- a/drivers/mtd/nand/raw/tegra_nand.c +++ b/drivers/mtd/nand/raw/tegra_nand.c @@ -8,6 +8,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <memalign.h> #include <nand.h> diff --git a/drivers/mtd/pic32_flash.c b/drivers/mtd/pic32_flash.c index a58a2c4b6c3..ea0dbe9eeee 100644 --- a/drivers/mtd/pic32_flash.c +++ b/drivers/mtd/pic32_flash.c @@ -12,6 +12,7 @@ #include <flash.h> #include <init.h> #include <irq_func.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <mach/pic32.h> #include <wait_bit.h> diff --git a/drivers/mtd/renesas_rpc_hf.c b/drivers/mtd/renesas_rpc_hf.c index 8a644ad9b38..b62f7971a34 100644 --- a/drivers/mtd/renesas_rpc_hf.c +++ b/drivers/mtd/renesas_rpc_hf.c @@ -9,6 +9,7 @@
#include <common.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk.h> #include <dm.h> diff --git a/drivers/mtd/spi/sf-uclass.c b/drivers/mtd/spi/sf-uclass.c index 09c11439b08..121804e3269 100644 --- a/drivers/mtd/spi/sf-uclass.c +++ b/drivers/mtd/spi/sf-uclass.c @@ -9,6 +9,7 @@ #include <malloc.h> #include <spi.h> #include <spi_flash.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include "sf_internal.h"
diff --git a/drivers/net/ag7xxx.c b/drivers/net/ag7xxx.c index ccba3947ac5..c7ea60f5acc 100644 --- a/drivers/net/ag7xxx.c +++ b/drivers/net/ag7xxx.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/compiler.h> #include <linux/delay.h> diff --git a/drivers/net/altera_tse.c b/drivers/net/altera_tse.c index 93b26da3926..2097718057b 100644 --- a/drivers/net/altera_tse.c +++ b/drivers/net/altera_tse.c @@ -18,6 +18,7 @@ #include <miiphy.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/dma-mapping.h> #include <asm/io.h> #include "altera_tse.h" diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index db1102562f6..3bb4955e4a9 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -42,6 +42,7 @@ #include <reset.h> #include <wait_bit.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <eth_phy.h> diff --git a/drivers/net/dwmac_s700.c b/drivers/net/dwmac_s700.c index 9d3f3ac5d93..2cf36f40494 100644 --- a/drivers/net/dwmac_s700.c +++ b/drivers/net/dwmac_s700.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <clk.h> diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index bb55be9a267..468be69886c 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -18,6 +18,7 @@ #include <net.h> #include <netdev.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <power/regulator.h>
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index 84db6be624a..26e9523288e 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -11,6 +11,7 @@ #include <image.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/bug.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/drivers/net/fsl_mcdmafec.c b/drivers/net/fsl_mcdmafec.c index e27f7e5321a..f3eea57fb9a 100644 --- a/drivers/net/fsl_mcdmafec.c +++ b/drivers/net/fsl_mcdmafec.c @@ -18,6 +18,7 @@ #include <config.h> #include <net.h> #include <miiphy.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/mii.h> #include <asm/immap.h> diff --git a/drivers/net/ftmac100.c b/drivers/net/ftmac100.c index 292690de961..d45f17eb8dd 100644 --- a/drivers/net/ftmac100.c +++ b/drivers/net/ftmac100.c @@ -12,6 +12,7 @@ #include <env.h> #include <malloc.h> #include <net.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/io.h>
diff --git a/drivers/net/gmac_rockchip.c b/drivers/net/gmac_rockchip.c index 8d95ee15ffd..98d7c39f9fe 100644 --- a/drivers/net/gmac_rockchip.c +++ b/drivers/net/gmac_rockchip.c @@ -12,6 +12,7 @@ #include <net.h> #include <phy.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/periph.h> #include <asm/arch-rockchip/clock.h> diff --git a/drivers/net/ldpaa_eth/ldpaa_eth.c b/drivers/net/ldpaa_eth/ldpaa_eth.c index 42eaf49d712..220fd7bb62b 100644 --- a/drivers/net/ldpaa_eth/ldpaa_eth.c +++ b/drivers/net/ldpaa_eth/ldpaa_eth.c @@ -15,6 +15,7 @@ #include <miiphy.h> #include <net.h> #include <phy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/types.h> #include <linux/bug.h> diff --git a/drivers/net/macb.c b/drivers/net/macb.c index b80a259ff75..cda9b16cc24 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -7,6 +7,7 @@ #include <cpu_func.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h>
/* diff --git a/drivers/net/mcffec.c b/drivers/net/mcffec.c index f94a2d8123c..d881c5eb871 100644 --- a/drivers/net/mcffec.c +++ b/drivers/net/mcffec.c @@ -18,6 +18,7 @@ #include <net.h> #include <miiphy.h> #include <asm/fec.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <linux/delay.h> #include <linux/mii.h> diff --git a/drivers/net/mcfmii.c b/drivers/net/mcfmii.c index 393605512d9..da5075172fa 100644 --- a/drivers/net/mcfmii.c +++ b/drivers/net/mcfmii.c @@ -8,6 +8,7 @@ #include <config.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/delay.h>
#ifdef CONFIG_MCF547x_8x diff --git a/drivers/net/mpc8xx_fec.c b/drivers/net/mpc8xx_fec.c index 12be584638f..282c2599d3c 100644 --- a/drivers/net/mpc8xx_fec.c +++ b/drivers/net/mpc8xx_fec.c @@ -11,6 +11,7 @@ #include <net.h> #include <netdev.h> #include <asm/cpm_8xx.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 2f9464b961a..bf5f6f4b672 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -18,6 +18,7 @@ #include <malloc.h> #include <miiphy.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h> #include <linux/errno.h> diff --git a/drivers/net/mvneta.c b/drivers/net/mvneta.c index 83f99e5d8ab..a0b18f82675 100644 --- a/drivers/net/mvneta.c +++ b/drivers/net/mvneta.c @@ -21,6 +21,7 @@ #include <config.h> #include <malloc.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <dm/devres.h> diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 8f790a8b44c..22248dee60c 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -17,6 +17,7 @@ #include <cpu_func.h> #include <dm.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device_compat.h> #include <dm/devres.h> diff --git a/drivers/net/octeontx/smi.c b/drivers/net/octeontx/smi.c index 8e2c3ca5a30..4f90da91272 100644 --- a/drivers/net/octeontx/smi.c +++ b/drivers/net/octeontx/smi.c @@ -10,6 +10,7 @@ #include <pci.h> #include <pci_ids.h> #include <phy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/ctype.h> #include <linux/delay.h> diff --git a/drivers/net/phy/fixed.c b/drivers/net/phy/fixed.c index 9d9f746e1db..3228672fc4a 100644 --- a/drivers/net/phy/fixed.c +++ b/drivers/net/phy/fixed.c @@ -11,6 +11,7 @@ #include <phy.h> #include <dm.h> #include <fdt_support.h> +#include <asm/global_data.h>
diff --git a/drivers/net/phy/miiphybb.c b/drivers/net/phy/miiphybb.c index ba97a54c067..bb5aa3513b6 100644 --- a/drivers/net/phy/miiphybb.c +++ b/drivers/net/phy/miiphybb.c @@ -16,6 +16,7 @@ #include <ioports.h> #include <ppc_asm.tmpl> #include <miiphy.h> +#include <asm/global_data.h>
#define BB_MII_RELOCATE(v,off) (v += (v?off:0))
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 9587e6b9fae..b772aae0cff 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -17,6 +17,7 @@ #include <miiphy.h> #include <phy.h> #include <errno.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> diff --git a/drivers/net/phy/xilinx_gmii2rgmii.c b/drivers/net/phy/xilinx_gmii2rgmii.c index e2feb17048c..74105c0b7d6 100644 --- a/drivers/net/phy/xilinx_gmii2rgmii.c +++ b/drivers/net/phy/xilinx_gmii2rgmii.c @@ -5,11 +5,11 @@ * Copyright (C) 2018 Xilinx, Inc. */
+#include <common.h> #include <dm.h> #include <log.h> #include <phy.h> -#include <config.h> -#include <common.h> +#include <asm/global_data.h>
diff --git a/drivers/net/pic32_eth.c b/drivers/net/pic32_eth.c index 6a2084947b0..bbc305f81db 100644 --- a/drivers/net/pic32_eth.c +++ b/drivers/net/pic32_eth.c @@ -14,6 +14,7 @@ #include <console.h> #include <time.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/delay.h> #include <linux/mii.h> diff --git a/drivers/net/qe/dm_qe_uec.c b/drivers/net/qe/dm_qe_uec.c index 3482b3ff178..472c55f84fa 100644 --- a/drivers/net/qe/dm_qe_uec.c +++ b/drivers/net/qe/dm_qe_uec.c @@ -12,6 +12,7 @@ #include <errno.h> #include <memalign.h> #include <miiphy.h> +#include <asm/global_data.h> #include <asm/io.h>
#include "dm_qe_uec.h" diff --git a/drivers/net/ravb.c b/drivers/net/ravb.c index 98883cd15b4..f5c9fcddf68 100644 --- a/drivers/net/ravb.c +++ b/drivers/net/ravb.c @@ -17,6 +17,7 @@ #include <miiphy.h> #include <malloc.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/mii.h> diff --git a/drivers/net/sandbox-raw.c b/drivers/net/sandbox-raw.c index 4bd94c31031..6dddae911b0 100644 --- a/drivers/net/sandbox-raw.c +++ b/drivers/net/sandbox-raw.c @@ -13,6 +13,7 @@ #include <env.h> #include <malloc.h> #include <net.h> +#include <asm/global_data.h>
diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index 4f7e3d42438..51d80f54967 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -12,6 +12,7 @@ #include <malloc.h> #include <net.h> #include <asm/eth.h> +#include <asm/global_data.h> #include <asm/test.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 4cbffb14c51..49b4a91875a 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -18,6 +18,7 @@ #include <netdev.h> #include <miiphy.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/drivers/net/sni_ave.c b/drivers/net/sni_ave.c index 0f7ada8c3e2..c11a1c443ee 100644 --- a/drivers/net/sni_ave.c +++ b/drivers/net/sni_ave.c @@ -16,6 +16,7 @@ #include <reset.h> #include <syscon.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 4524604126c..40b1404f423 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -13,6 +13,7 @@ #include <cpu_func.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/gpio.h> diff --git a/drivers/net/ti/cpsw-common.c b/drivers/net/ti/cpsw-common.c index ca93edb70e3..3140f2515fb 100644 --- a/drivers/net/ti/cpsw-common.c +++ b/drivers/net/ti/cpsw-common.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <fdt_support.h> +#include <asm/global_data.h> #include <asm/io.h> #include <cpsw.h> #include <dm/device_compat.h> diff --git a/drivers/net/ti/keystone_net.c b/drivers/net/ti/keystone_net.c index 50f0d33a83b..c25902a7032 100644 --- a/drivers/net/ti/keystone_net.c +++ b/drivers/net/ti/keystone_net.c @@ -8,6 +8,7 @@ #include <common.h> #include <command.h> #include <console.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <dm.h> diff --git a/drivers/net/xilinx_axi_emac.c b/drivers/net/xilinx_axi_emac.c index 8af37112046..5aaa6a177d0 100644 --- a/drivers/net/xilinx_axi_emac.c +++ b/drivers/net/xilinx_axi_emac.c @@ -12,6 +12,7 @@ #include <log.h> #include <net.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <phy.h> #include <miiphy.h> diff --git a/drivers/net/xilinx_emaclite.c b/drivers/net/xilinx_emaclite.c index 64c18bae74b..9f2327b92cd 100644 --- a/drivers/net/xilinx_emaclite.c +++ b/drivers/net/xilinx_emaclite.c @@ -13,6 +13,7 @@ #include <dm.h> #include <console.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <phy.h> #include <miiphy.h> diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 1d09c5ac4f6..e72a60c1318 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -9,6 +9,7 @@ #include <log.h> #include <malloc.h> #include <asm/fsl_serdes.h> +#include <asm/global_data.h> #include <linux/delay.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index eb07d253011..571c6e3c1d6 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device-internal.h> #include <dm/lists.h> diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 664e8379eb5..25a755627c0 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -17,6 +17,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <command.h> diff --git a/drivers/pci/pci_mvebu.c b/drivers/pci/pci_mvebu.c index c9afe751501..167fe026e8b 100644 --- a/drivers/pci/pci_mvebu.c +++ b/drivers/pci/pci_mvebu.c @@ -13,6 +13,7 @@ #include <dm.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/of_access.h> diff --git a/drivers/pci/pci_octeontx.c b/drivers/pci/pci_octeontx.c index 30537543a0f..86af01a19e2 100644 --- a/drivers/pci/pci_octeontx.c +++ b/drivers/pci/pci_octeontx.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <pci.h> +#include <asm/global_data.h>
#include <asm/io.h>
diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index fa29d69e859..39284badf20 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -38,6 +38,7 @@ #include <video.h> #include <video_fb.h> #include <acpi/acpi_s3.h> +#include <asm/global_data.h> #include <linux/screen_info.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/pci/pcie_dw_mvebu.c b/drivers/pci/pcie_dw_mvebu.c index c773f8d28d2..33ecd25f848 100644 --- a/drivers/pci/pcie_dw_mvebu.c +++ b/drivers/pci/pcie_dw_mvebu.c @@ -14,6 +14,7 @@ #include <dm.h> #include <log.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm-generic/gpio.h> #include <linux/delay.h> diff --git a/drivers/pci/pcie_dw_ti.c b/drivers/pci/pcie_dw_ti.c index 742dd93633e..16b2a2da7e7 100644 --- a/drivers/pci/pcie_dw_ti.c +++ b/drivers/pci/pcie_dw_ti.c @@ -11,6 +11,7 @@ #include <power-domain.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm-generic/gpio.h> #include <dm/device_compat.h> diff --git a/drivers/pci/pcie_ecam_generic.c b/drivers/pci/pcie_ecam_generic.c index 890b6a8fb69..354a1454a9f 100644 --- a/drivers/pci/pcie_ecam_generic.c +++ b/drivers/pci/pcie_ecam_generic.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <pci.h> +#include <asm/global_data.h>
#include <asm/io.h>
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index fb50b8f5180..ee779be8f88 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -13,6 +13,7 @@ #include <pci.h> #include <asm/fsl_pci.h> #include <asm/fsl_serdes.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h> #include "pcie_fsl.h" diff --git a/drivers/pci/pcie_intel_fpga.c b/drivers/pci/pcie_intel_fpga.c index 9f102c64c60..2aedbdd0e56 100644 --- a/drivers/pci/pcie_intel_fpga.c +++ b/drivers/pci/pcie_intel_fpga.c @@ -9,6 +9,7 @@ #include <common.h> #include <dm.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <linux/bitops.h> diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index 25b5272d4ed..3c7c4ca18e8 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -7,6 +7,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <malloc.h> diff --git a/drivers/pci/pcie_layerscape_ep.c b/drivers/pci/pcie_layerscape_ep.c index eba230e3a5f..6de93fac997 100644 --- a/drivers/pci/pcie_layerscape_ep.c +++ b/drivers/pci/pcie_layerscape_ep.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/devres.h> #include <errno.h> #include <pci_ep.h> diff --git a/drivers/pci/pcie_layerscape_fixup_common.c b/drivers/pci/pcie_layerscape_fixup_common.c index 0a42997696b..adc9422580b 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.c +++ b/drivers/pci/pcie_layerscape_fixup_common.c @@ -11,6 +11,7 @@ #include <init.h> #include <asm/arch/clock.h> #include <asm/arch/soc.h> +#include <linux/libfdt.h> #include "pcie_layerscape_fixup_common.h"
void ft_pci_setup(void *blob, struct bd_info *bd) diff --git a/drivers/pci/pcie_layerscape_gen4.c b/drivers/pci/pcie_layerscape_gen4.c index 428bfcab09f..96c6527f806 100644 --- a/drivers/pci/pcie_layerscape_gen4.c +++ b/drivers/pci/pcie_layerscape_gen4.c @@ -10,6 +10,7 @@ #include <log.h> #include <asm/arch/fsl_serdes.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <malloc.h> diff --git a/drivers/pci/pcie_layerscape_rc.c b/drivers/pci/pcie_layerscape_rc.c index 25c6ddebce0..7ae5b48bb92 100644 --- a/drivers/pci/pcie_layerscape_rc.c +++ b/drivers/pci/pcie_layerscape_rc.c @@ -7,6 +7,7 @@ #include <common.h> #include <asm/arch/fsl_serdes.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <malloc.h> diff --git a/drivers/pci/pcie_phytium.c b/drivers/pci/pcie_phytium.c index 51b2171f9fa..35ca104300b 100644 --- a/drivers/pci/pcie_phytium.c +++ b/drivers/pci/pcie_phytium.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h>
/** diff --git a/drivers/pci/pcie_rockchip.c b/drivers/pci/pcie_rockchip.c index 04609f12962..7d84be36be9 100644 --- a/drivers/pci/pcie_rockchip.c +++ b/drivers/pci/pcie_rockchip.c @@ -14,6 +14,7 @@ #include <common.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <generic-phy.h> #include <pci.h> diff --git a/drivers/pci/pcie_xilinx.c b/drivers/pci/pcie_xilinx.c index 713ad49d045..88660a9957a 100644 --- a/drivers/pci/pcie_xilinx.c +++ b/drivers/pci/pcie_xilinx.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <pci.h> +#include <asm/global_data.h> #include <linux/bitops.h>
#include <asm/io.h> diff --git a/drivers/pci_endpoint/pci_ep-uclass.c b/drivers/pci_endpoint/pci_ep-uclass.c index 38a5f083769..71b6bfa6382 100644 --- a/drivers/pci_endpoint/pci_ep-uclass.c +++ b/drivers/pci_endpoint/pci_ep-uclass.c @@ -12,6 +12,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <linux/log2.h> #include <pci_ep.h>
diff --git a/drivers/pci_endpoint/pcie-cadence-ep.c b/drivers/pci_endpoint/pcie-cadence-ep.c index 74dfdde154e..e392fae338a 100644 --- a/drivers/pci_endpoint/pcie-cadence-ep.c +++ b/drivers/pci_endpoint/pcie-cadence-ep.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <pci_ep.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <linux/log2.h> #include "pcie-cadence.h" diff --git a/drivers/phy/marvell/comphy_a3700.c b/drivers/phy/marvell/comphy_a3700.c index 4606de6f48e..12523d18a80 100644 --- a/drivers/phy/marvell/comphy_a3700.c +++ b/drivers/phy/marvell/comphy_a3700.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/drivers/phy/marvell/comphy_core.c b/drivers/phy/marvell/comphy_core.c index 5e8ce740cd6..124a63ed96a 100644 --- a/drivers/phy/marvell/comphy_core.c +++ b/drivers/phy/marvell/comphy_core.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <linux/err.h> diff --git a/drivers/phy/marvell/comphy_cp110.c b/drivers/phy/marvell/comphy_cp110.c index 15e80049def..484b28745e0 100644 --- a/drivers/phy/marvell/comphy_cp110.c +++ b/drivers/phy/marvell/comphy_cp110.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/drivers/phy/omap-usb2-phy.c b/drivers/phy/omap-usb2-phy.c index a981cb2f8d6..d9a3bae8e6e 100644 --- a/drivers/phy/omap-usb2-phy.c +++ b/drivers/phy/omap-usb2-phy.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <errno.h> diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index c5ea6ca31f1..29749b4c3fa 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -9,6 +9,7 @@ #include <common.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/lists.h> #include <generic-phy.h> diff --git a/drivers/phy/rockchip/phy-rockchip-pcie.c b/drivers/phy/rockchip/phy-rockchip-pcie.c index 617943fd821..0ffd8a62633 100644 --- a/drivers/phy/rockchip/phy-rockchip-pcie.c +++ b/drivers/phy/rockchip/phy-rockchip-pcie.c @@ -10,6 +10,7 @@ #include <common.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <generic-phy.h> #include <reset.h> diff --git a/drivers/phy/rockchip/phy-rockchip-typec.c b/drivers/phy/rockchip/phy-rockchip-typec.c index da00daa4476..0e7f78efc9c 100644 --- a/drivers/phy/rockchip/phy-rockchip-typec.c +++ b/drivers/phy/rockchip/phy-rockchip-typec.c @@ -11,6 +11,7 @@ #include <common.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/lists.h> #include <generic-phy.h> diff --git a/drivers/phy/sti_usb_phy.c b/drivers/phy/sti_usb_phy.c index 2a20f7601c0..c6b1dc297ab 100644 --- a/drivers/phy/sti_usb_phy.c +++ b/drivers/phy/sti_usb_phy.c @@ -6,6 +6,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <bitfield.h> #include <dm.h> diff --git a/drivers/phy/ti-pipe3-phy.c b/drivers/phy/ti-pipe3-phy.c index 3f49851bcab..41cee0eb740 100644 --- a/drivers/phy/ti-pipe3-phy.c +++ b/drivers/phy/ti-pipe3-phy.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device.h> #include <generic-phy.h> #include <asm/io.h> diff --git a/drivers/pinctrl/ath79/pinctrl_ar933x.c b/drivers/pinctrl/ath79/pinctrl_ar933x.c index 61e80818743..b3f9f6a01fd 100644 --- a/drivers/pinctrl/ath79/pinctrl_ar933x.c +++ b/drivers/pinctrl/ath79/pinctrl_ar933x.c @@ -7,6 +7,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/pinctrl.h> #include <mach/ar71xx_regs.h> diff --git a/drivers/pinctrl/ath79/pinctrl_qca953x.c b/drivers/pinctrl/ath79/pinctrl_qca953x.c index 2d5a4a3ab23..d27848c1ddd 100644 --- a/drivers/pinctrl/ath79/pinctrl_qca953x.c +++ b/drivers/pinctrl/ath79/pinctrl_qca953x.c @@ -7,6 +7,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/pinctrl.h> #include <mach/ar71xx_regs.h> diff --git a/drivers/pinctrl/exynos/pinctrl-exynos.c b/drivers/pinctrl/exynos/pinctrl-exynos.c index 4cdc071d559..cc7ef799895 100644 --- a/drivers/pinctrl/exynos/pinctrl-exynos.c +++ b/drivers/pinctrl/exynos/pinctrl-exynos.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include "pinctrl-exynos.h"
diff --git a/drivers/pinctrl/meson/pinctrl-meson.c b/drivers/pinctrl/meson/pinctrl-meson.c index d4539b02d88..664af76d584 100644 --- a/drivers/pinctrl/meson/pinctrl-meson.c +++ b/drivers/pinctrl/meson/pinctrl-meson.c @@ -7,6 +7,7 @@ #include <dm.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device_compat.h> #include <dm/lists.h> diff --git a/drivers/pinctrl/mtmips/pinctrl-mt7628.c b/drivers/pinctrl/mtmips/pinctrl-mt7628.c index fc9d8b5ad10..1b51c229271 100644 --- a/drivers/pinctrl/mtmips/pinctrl-mt7628.c +++ b/drivers/pinctrl/mtmips/pinctrl-mt7628.c @@ -7,6 +7,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/pinctrl.h> #include <linux/bitops.h> #include <linux/io.h> diff --git a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c index fb497803b93..1f61a84c29d 100644 --- a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c +++ b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c @@ -20,6 +20,7 @@ #include <config.h> #include <dm.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device_compat.h> #include <dm/devres.h> diff --git a/drivers/pinctrl/mvebu/pinctrl-mvebu.c b/drivers/pinctrl/mvebu/pinctrl-mvebu.c index 146f5c6e426..61d62e2058d 100644 --- a/drivers/pinctrl/mvebu/pinctrl-mvebu.c +++ b/drivers/pinctrl/mvebu/pinctrl-mvebu.c @@ -10,6 +10,7 @@ #include <errno.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/pinctrl.h> #include <dm/root.h> #include <asm/system.h> diff --git a/drivers/pinctrl/nexell/pinctrl-nexell.c b/drivers/pinctrl/nexell/pinctrl-nexell.c index 4518c05d468..6b01f47657c 100644 --- a/drivers/pinctrl/nexell/pinctrl-nexell.c +++ b/drivers/pinctrl/nexell/pinctrl-nexell.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include "pinctrl-nexell.h" #include "pinctrl-s5pxx18.h" diff --git a/drivers/pinctrl/nexell/pinctrl-s5pxx18.c b/drivers/pinctrl/nexell/pinctrl-s5pxx18.c index 96a2ed38a05..b603192fbd3 100644 --- a/drivers/pinctrl/nexell/pinctrl-s5pxx18.c +++ b/drivers/pinctrl/nexell/pinctrl-s5pxx18.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/pinctrl.h> #include <dm/root.h> diff --git a/drivers/pinctrl/nxp/pinctrl-imx.c b/drivers/pinctrl/nxp/pinctrl-imx.c index 48c7bde3752..1596dcc4747 100644 --- a/drivers/pinctrl/nxp/pinctrl-imx.c +++ b/drivers/pinctrl/nxp/pinctrl-imx.c @@ -6,6 +6,7 @@ #include <common.h> #include <malloc.h> #include <mapmem.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/devres.h> #include <linux/bitops.h> diff --git a/drivers/pinctrl/nxp/pinctrl-imx8.c b/drivers/pinctrl/nxp/pinctrl-imx8.c index c1b0ca438aa..7af9506d504 100644 --- a/drivers/pinctrl/nxp/pinctrl-imx8.c +++ b/drivers/pinctrl/nxp/pinctrl-imx8.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/pinctrl.h>
diff --git a/drivers/pinctrl/nxp/pinctrl-mxs.c b/drivers/pinctrl/nxp/pinctrl-mxs.c index db463fc04b9..1067654e07e 100644 --- a/drivers/pinctrl/nxp/pinctrl-mxs.c +++ b/drivers/pinctrl/nxp/pinctrl-mxs.c @@ -6,6 +6,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/devres.h> #include <linux/io.h> diff --git a/drivers/pinctrl/pinctrl-at91-pio4.c b/drivers/pinctrl/pinctrl-at91-pio4.c index bf85cc916a7..5d09eea7acf 100644 --- a/drivers/pinctrl/pinctrl-at91-pio4.c +++ b/drivers/pinctrl/pinctrl-at91-pio4.c @@ -8,6 +8,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/pinctrl.h> #include <linux/bitops.h> #include <linux/io.h> diff --git a/drivers/pinctrl/pinctrl-at91.c b/drivers/pinctrl/pinctrl-at91.c index cd7b32ce346..30f2bebbc78 100644 --- a/drivers/pinctrl/pinctrl-at91.c +++ b/drivers/pinctrl/pinctrl-at91.c @@ -9,6 +9,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/pinctrl.h> #include <asm/hardware.h> #include <linux/bitops.h> diff --git a/drivers/pinctrl/pinctrl-sti.c b/drivers/pinctrl/pinctrl-sti.c index 8e942a82802..7d6bdc1d2bd 100644 --- a/drivers/pinctrl/pinctrl-sti.c +++ b/drivers/pinctrl/pinctrl-sti.c @@ -12,6 +12,7 @@ #include <errno.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/pinctrl.h> #include <linux/bug.h> diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index aba88104747..79a52333053 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -5,6 +5,7 @@
#include <common.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/libfdt.h> #include <linux/err.h> diff --git a/drivers/pinctrl/pinctrl_pic32.c b/drivers/pinctrl/pinctrl_pic32.c index 899c279975a..4fed323761f 100644 --- a/drivers/pinctrl/pinctrl_pic32.c +++ b/drivers/pinctrl/pinctrl_pic32.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/pinctrl.h> #include <linux/bitops.h> diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index dbea99532cb..b58a68e26f5 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -9,6 +9,7 @@ #include <log.h> #include <malloc.h> #include <asm/arch/gpio.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <dm/device_compat.h> diff --git a/drivers/pinctrl/renesas/pfc-r7s72100.c b/drivers/pinctrl/renesas/pfc-r7s72100.c index 9d7814a5f25..b368336c887 100644 --- a/drivers/pinctrl/renesas/pfc-r7s72100.c +++ b/drivers/pinctrl/renesas/pfc-r7s72100.c @@ -7,6 +7,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/pinctrl.h> #include <linux/bitops.h> diff --git a/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c b/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c index ec1cb9b652f..8abad950431 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c +++ b/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/pinctrl.h> #include <regmap.h> #include <syscon.h> diff --git a/drivers/power/domain/imx8-power-domain-legacy.c b/drivers/power/domain/imx8-power-domain-legacy.c index 889b65a47ff..961382f33e1 100644 --- a/drivers/power/domain/imx8-power-domain-legacy.c +++ b/drivers/power/domain/imx8-power-domain-legacy.c @@ -8,6 +8,7 @@ #include <log.h> #include <malloc.h> #include <power-domain-uclass.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/power-domain.h> #include <dm/device-internal.h> diff --git a/drivers/power/domain/imx8m-power-domain.c b/drivers/power/domain/imx8m-power-domain.c index 0ef460df8c2..f6681c7b0b5 100644 --- a/drivers/power/domain/imx8m-power-domain.c +++ b/drivers/power/domain/imx8m-power-domain.c @@ -7,6 +7,7 @@ #include <dm.h> #include <malloc.h> #include <power-domain-uclass.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/power-domain.h> #include <asm/mach-imx/sys_proto.h> diff --git a/drivers/power/pmic/bd71837.c b/drivers/power/pmic/bd71837.c index 31c9139c646..cb9238972f2 100644 --- a/drivers/power/pmic/bd71837.c +++ b/drivers/power/pmic/bd71837.c @@ -8,6 +8,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <asm/global_data.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/bd71837.h> diff --git a/drivers/power/pmic/mc34708.c b/drivers/power/pmic/mc34708.c index 66253a4a43b..40d732224b6 100644 --- a/drivers/power/pmic/mc34708.c +++ b/drivers/power/pmic/mc34708.c @@ -10,6 +10,7 @@ #include <errno.h> #include <fsl_pmic.h> #include <i2c.h> +#include <asm/global_data.h> #include <power/pmic.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/power/pmic/pca9450.c b/drivers/power/pmic/pca9450.c index 0c9d9a366e8..786baa5e259 100644 --- a/drivers/power/pmic/pca9450.c +++ b/drivers/power/pmic/pca9450.c @@ -9,6 +9,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <asm/global_data.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/pca9450.h> diff --git a/drivers/power/regulator/pwm_regulator.c b/drivers/power/regulator/pwm_regulator.c index f8706227058..185e38e32a4 100644 --- a/drivers/power/regulator/pwm_regulator.c +++ b/drivers/power/regulator/pwm_regulator.c @@ -12,6 +12,7 @@ #include <errno.h> #include <log.h> #include <pwm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <power/regulator.h>
diff --git a/drivers/pwm/pwm-sifive.c b/drivers/pwm/pwm-sifive.c index 77bc659fefe..0b819cfbf78 100644 --- a/drivers/pwm/pwm-sifive.c +++ b/drivers/pwm/pwm-sifive.c @@ -18,6 +18,7 @@ #include <dm.h> #include <pwm.h> #include <regmap.h> +#include <asm/global_data.h> #include <linux/io.h> #include <linux/log2.h> #include <linux/bitfield.h> diff --git a/drivers/pwm/rk_pwm.c b/drivers/pwm/rk_pwm.c index 911da1d4261..0fb894804b5 100644 --- a/drivers/pwm/rk_pwm.c +++ b/drivers/pwm/rk_pwm.c @@ -12,6 +12,7 @@ #include <pwm.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/pwm.h> #include <linux/bitops.h> diff --git a/drivers/pwm/sunxi_pwm.c b/drivers/pwm/sunxi_pwm.c index e2ae1a80091..ffcf60c5584 100644 --- a/drivers/pwm/sunxi_pwm.c +++ b/drivers/pwm/sunxi_pwm.c @@ -10,6 +10,7 @@ #include <pwm.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/pwm.h> #include <asm/arch/gpio.h> diff --git a/drivers/qe/fdt.c b/drivers/qe/fdt.c index fd7f14955ad..6195c7c4442 100644 --- a/drivers/qe/fdt.c +++ b/drivers/qe/fdt.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <fsl_qe.h> diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index 1a829b5a4cf..81737a0689d 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -9,6 +9,7 @@ #include <common.h> #include <malloc.h> #include <command.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/io.h> #include <linux/immap_qe.h> diff --git a/drivers/ram/aspeed/sdram_ast2500.c b/drivers/ram/aspeed/sdram_ast2500.c index 9f4304cb663..4025cf5f3f8 100644 --- a/drivers/ram/aspeed/sdram_ast2500.c +++ b/drivers/ram/aspeed/sdram_ast2500.c @@ -13,6 +13,7 @@ #include <ram.h> #include <regmap.h> #include <reset.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/scu_ast2500.h> #include <asm/arch/sdram_ast2500.h> diff --git a/drivers/ram/mpc83xx_sdram.c b/drivers/ram/mpc83xx_sdram.c index a226bac2cc3..2a78291deb5 100644 --- a/drivers/ram/mpc83xx_sdram.c +++ b/drivers/ram/mpc83xx_sdram.c @@ -10,6 +10,7 @@ #include <log.h> #include <ram.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <dt-bindings/memory/mpc83xx-sdram.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/ram/octeon/octeon_ddr.c b/drivers/ram/octeon/octeon_ddr.c index 757436b9d37..ed4f9907af9 100644 --- a/drivers/ram/octeon/octeon_ddr.c +++ b/drivers/ram/octeon/octeon_ddr.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <ram.h> #include <time.h> +#include <asm/global_data.h>
#include <asm/sections.h> #include <linux/io.h> diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index 094693ce247..4a24854a3df 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -11,6 +11,7 @@ #include <ram.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_rk322x.h> diff --git a/drivers/ram/sandbox_ram.c b/drivers/ram/sandbox_ram.c index be4abed0c02..910dce623e9 100644 --- a/drivers/ram/sandbox_ram.c +++ b/drivers/ram/sandbox_ram.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <ram.h> +#include <asm/global_data.h> #include <asm/test.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/ram/sifive/fu540_ddr.c b/drivers/ram/sifive/fu540_ddr.c index 60d4945f848..fa98a9538c7 100644 --- a/drivers/ram/sifive/fu540_ddr.c +++ b/drivers/ram/sifive/fu540_ddr.c @@ -12,6 +12,7 @@ #include <init.h> #include <ram.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk.h> #include <wait_bit.h> diff --git a/drivers/ram/stm32mp1/stm32mp1_interactive.c b/drivers/ram/stm32mp1/stm32mp1_interactive.c index 5a5d0670461..2ac1c9db127 100644 --- a/drivers/ram/stm32mp1/stm32mp1_interactive.c +++ b/drivers/ram/stm32mp1/stm32mp1_interactive.c @@ -12,6 +12,7 @@ #include <malloc.h> #include <ram.h> #include <reset.h> +#include <asm/global_data.h> #include "stm32mp1_ddr.h" #include "stm32mp1_tests.h"
diff --git a/drivers/ram/stm32mp1/stm32mp1_tests.c b/drivers/ram/stm32mp1/stm32mp1_tests.c index 952006aa149..b0c510ad5e9 100644 --- a/drivers/ram/stm32mp1/stm32mp1_tests.c +++ b/drivers/ram/stm32mp1/stm32mp1_tests.c @@ -8,6 +8,7 @@ #include <log.h> #include <rand.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/log2.h> #include "stm32mp1_tests.h" diff --git a/drivers/remoteproc/rproc-uclass.c b/drivers/remoteproc/rproc-uclass.c index 9640a81e534..22779d0cb0d 100644 --- a/drivers/remoteproc/rproc-uclass.c +++ b/drivers/remoteproc/rproc-uclass.c @@ -10,6 +10,7 @@ #include <log.h> #include <malloc.h> #include <remoteproc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device-internal.h> #include <dm.h> diff --git a/drivers/remoteproc/ti_power_proc.c b/drivers/remoteproc/ti_power_proc.c index 350450d1fb4..1a5dddbe0d2 100644 --- a/drivers/remoteproc/ti_power_proc.c +++ b/drivers/remoteproc/ti_power_proc.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <log.h> #include <remoteproc.h> +#include <asm/global_data.h> #include <mach/psc_defs.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/reset/sti-reset.c b/drivers/reset/sti-reset.c index ac3a99f9bff..2fdc069ce16 100644 --- a/drivers/reset/sti-reset.c +++ b/drivers/reset/sti-reset.c @@ -13,6 +13,7 @@ #include <reset-uclass.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <dt-bindings/reset/stih407-resets.h> #include <linux/bitops.h>
diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index f759ea8893d..f2065935886 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -13,6 +13,7 @@ #include <watchdog.h> #include <serial.h> #include <debug_uart.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <linux/delay.h>
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 702109b23b6..840d89f16fa 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -14,6 +14,7 @@ #include <reset.h> #include <serial.h> #include <watchdog.h> +#include <asm/global_data.h> #include <linux/err.h> #include <linux/types.h> #include <asm/io.h> diff --git a/drivers/serial/sandbox.c b/drivers/serial/sandbox.c index f09d291e043..8a7f171e041 100644 --- a/drivers/serial/sandbox.c +++ b/drivers/serial/sandbox.c @@ -17,6 +17,7 @@ #include <os.h> #include <serial.h> #include <video.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/state.h>
diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index f3c25d42167..489fd4f1668 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -12,6 +12,7 @@ #include <serial.h> #include <stdio_dev.h> #include <watchdog.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/device-internal.h> #include <dm/of_access.h> diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index 355659ba056..dea25a049c8 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -10,6 +10,7 @@ #include <serial.h> #include <stdio_dev.h> #include <post.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <errno.h> #include <linux/delay.h> diff --git a/drivers/serial/serial_arc.c b/drivers/serial/serial_arc.c index 04063fbe399..c1be34960ec 100644 --- a/drivers/serial/serial_arc.c +++ b/drivers/serial/serial_arc.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <serial.h> +#include <asm/global_data.h>
diff --git a/drivers/serial/serial_linflexuart.c b/drivers/serial/serial_linflexuart.c index 83dc96c449c..d8482ba7047 100644 --- a/drivers/serial/serial_linflexuart.c +++ b/drivers/serial/serial_linflexuart.c @@ -7,6 +7,7 @@ #include <dm.h> #include <errno.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <serial.h> #include <linux/compiler.h> diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index 95cbe63b3d1..8631d790e6f 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -10,6 +10,7 @@ #include <fsl_lpuart.h> #include <log.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <serial.h> #include <dm/device_compat.h> diff --git a/drivers/serial/serial_mcf.c b/drivers/serial/serial_mcf.c index 402fd5343c1..6b907fe1920 100644 --- a/drivers/serial/serial_mcf.c +++ b/drivers/serial/serial_mcf.c @@ -17,6 +17,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_coldfire.h> #include <serial.h> #include <linux/compiler.h> diff --git a/drivers/serial/serial_mpc8xx.c b/drivers/serial/serial_mpc8xx.c index 50d6e70f177..0978930dcd4 100644 --- a/drivers/serial/serial_mpc8xx.c +++ b/drivers/serial/serial_mpc8xx.c @@ -10,6 +10,7 @@ #include <serial.h> #include <watchdog.h> #include <asm/cpm_8xx.h> +#include <asm/global_data.h> #include <linux/compiler.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/serial/serial_msm.c b/drivers/serial/serial_msm.c index c8946c3aae8..13c7f9d809e 100644 --- a/drivers/serial/serial_msm.c +++ b/drivers/serial/serial_msm.c @@ -15,6 +15,7 @@ #include <malloc.h> #include <serial.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/compiler.h> #include <dm/pinctrl.h> diff --git a/drivers/serial/serial_mtk.c b/drivers/serial/serial_mtk.c index 778a04d87e0..9715f372ecf 100644 --- a/drivers/serial/serial_mtk.c +++ b/drivers/serial/serial_mtk.c @@ -14,6 +14,7 @@ #include <log.h> #include <serial.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/types.h> #include <linux/err.h> diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index de6cefcd3ac..1f8eeb2cbfe 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -9,6 +9,7 @@ #include <watchdog.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_mxc.h> #include <serial.h> #include <linux/compiler.h> diff --git a/drivers/serial/serial_ns16550.c b/drivers/serial/serial_ns16550.c index ef394b72350..1353e2f7ccb 100644 --- a/drivers/serial/serial_ns16550.c +++ b/drivers/serial/serial_ns16550.c @@ -8,6 +8,7 @@ #include <clock_legacy.h> #include <ns16550.h> #include <serial.h> +#include <asm/global_data.h> #include <linux/compiler.h>
#ifndef CONFIG_NS16550_MIN_FUNCTIONS diff --git a/drivers/serial/serial_pic32.c b/drivers/serial/serial_pic32.c index a492063e39c..ce6c5db762f 100644 --- a/drivers/serial/serial_pic32.c +++ b/drivers/serial/serial_pic32.c @@ -9,6 +9,7 @@ #include <malloc.h> #include <serial.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <mach/pic32.h> #include <dt-bindings/clock/microchip,clock.h> diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index 2772c25f1d2..1ae5bac249a 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -11,6 +11,7 @@ /* Simple U-Boot driver for the PrimeCell PL010/PL011 UARTs */
#include <common.h> +#include <asm/global_data.h> /* For get_bus_freq() */ #include <clock_legacy.h> #include <dm.h> diff --git a/drivers/serial/serial_pxa.c b/drivers/serial/serial_pxa.c index 6f8f7e1198a..6fc126f404b 100644 --- a/drivers/serial/serial_pxa.c +++ b/drivers/serial/serial_pxa.c @@ -23,6 +23,7 @@ #include <hang.h> #include <asm/arch/pxa-regs.h> #include <asm/arch/regs-uart.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <dm/platform_data/serial_pxa.h> diff --git a/drivers/serial/serial_s5p.c b/drivers/serial/serial_s5p.c index 9bb2be21e7b..986c5ca8107 100644 --- a/drivers/serial/serial_s5p.c +++ b/drivers/serial/serial_s5p.c @@ -11,6 +11,7 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/io.h> #include <asm/arch/clk.h> diff --git a/drivers/serial/serial_sh.c b/drivers/serial/serial_sh.c index e27d256574f..d6bc940efdc 100644 --- a/drivers/serial/serial_sh.c +++ b/drivers/serial/serial_sh.c @@ -10,6 +10,7 @@ #include <errno.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/processor.h> #include <serial.h> diff --git a/drivers/serial/serial_sifive.c b/drivers/serial/serial_sifive.c index fcc47fb348f..c3f0a3cb65d 100644 --- a/drivers/serial/serial_sifive.c +++ b/drivers/serial/serial_sifive.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <log.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/compiler.h> #include <serial.h> diff --git a/drivers/serial/serial_sti_asc.c b/drivers/serial/serial_sti_asc.c index 33ff396bff7..aa3c9efc8a0 100644 --- a/drivers/serial/serial_sti_asc.c +++ b/drivers/serial/serial_sti_asc.c @@ -10,6 +10,7 @@ #include <dm.h> #include <log.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/serial/serial_xen.c b/drivers/serial/serial_xen.c index ba6504b9479..d586cad4a3c 100644 --- a/drivers/serial/serial_xen.c +++ b/drivers/serial/serial_xen.c @@ -8,6 +8,7 @@ #include <dm.h> #include <serial.h> #include <watchdog.h> +#include <asm/global_data.h>
diff --git a/drivers/smem/msm_smem.c b/drivers/smem/msm_smem.c index 597d425d11f..ff322805bc9 100644 --- a/drivers/smem/msm_smem.c +++ b/drivers/smem/msm_smem.c @@ -8,6 +8,7 @@ #include <common.h> #include <errno.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/devres.h> #include <dm/of_access.h> diff --git a/drivers/sound/ivybridge_sound.c b/drivers/sound/ivybridge_sound.c index bc3c1e85f8c..a7423d46c18 100644 --- a/drivers/sound/ivybridge_sound.c +++ b/drivers/sound/ivybridge_sound.c @@ -18,6 +18,7 @@ #include <log.h> #include <pch.h> #include <sound.h> +#include <asm/global_data.h> #include <linux/bitops.h>
static int bd82x6x_azalia_probe(struct udevice *dev) diff --git a/drivers/spi/atcspi200_spi.c b/drivers/spi/atcspi200_spi.c index 39c6e226ba7..9e7d40d0a81 100644 --- a/drivers/spi/atcspi200_spi.c +++ b/drivers/spi/atcspi200_spi.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h>
diff --git a/drivers/spi/bcmstb_spi.c b/drivers/spi/bcmstb_spi.c index fb1dc46b704..f400a0f5732 100644 --- a/drivers/spi/bcmstb_spi.c +++ b/drivers/spi/bcmstb_spi.c @@ -5,6 +5,7 @@ * Author: Thomas Fitzsimmons fitzsim@fitzsim.org */
+#include <asm/global_data.h> #include <asm/io.h> #include <command.h> #include <config.h> diff --git a/drivers/spi/cf_spi.c b/drivers/spi/cf_spi.c index 8fa6d351075..242dc9d8909 100644 --- a/drivers/spi/cf_spi.c +++ b/drivers/spi/cf_spi.c @@ -16,6 +16,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/platform_data/spi_coldfire.h> #include <spi.h> #include <malloc.h> diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c index a11433db1e9..c1b21a8cd35 100644 --- a/drivers/spi/davinci_spi.c +++ b/drivers/spi/davinci_spi.c @@ -12,6 +12,7 @@ #include <log.h> #include <spi.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <dm.h> diff --git a/drivers/spi/exynos_spi.c b/drivers/spi/exynos_spi.c index d338ff5a0bd..03c03ab4874 100644 --- a/drivers/spi/exynos_spi.c +++ b/drivers/spi/exynos_spi.c @@ -18,6 +18,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/drivers/spi/fsl_dspi.c b/drivers/spi/fsl_dspi.c index b22c9b3a09d..1912d676a68 100644 --- a/drivers/spi/fsl_dspi.c +++ b/drivers/spi/fsl_dspi.c @@ -9,6 +9,7 @@ * Haikun Wang (B53464@freescale.com) */
+#include <asm/global_data.h> #include <linux/math64.h> #include <common.h> #include <dm.h> diff --git a/drivers/spi/fsl_espi.c b/drivers/spi/fsl_espi.c index 5c76fd962e9..3dd98aadbaa 100644 --- a/drivers/spi/fsl_espi.c +++ b/drivers/spi/fsl_espi.c @@ -10,6 +10,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h>
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 128f95877f2..d4935a493c6 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -29,6 +29,7 @@ #include <log.h> #include <spi.h> #include <spi-mem.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/libfdt.h> diff --git a/drivers/spi/mvebu_a3700_spi.c b/drivers/spi/mvebu_a3700_spi.c index eb13cf349ef..58592a1dc4b 100644 --- a/drivers/spi/mvebu_a3700_spi.c +++ b/drivers/spi/mvebu_a3700_spi.c @@ -12,6 +12,7 @@ #include <spi.h> #include <clk.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <linux/bitops.h> diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index e90a06a66de..466355b0178 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -8,6 +8,7 @@ #include <log.h> #include <malloc.h> #include <spi.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index 56cb2174868..2db6163b31a 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -20,6 +20,7 @@ #include <dm.h> #include <spi.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <omap3_spi.h> diff --git a/drivers/spi/pic32_spi.c b/drivers/spi/pic32_spi.c index 52e9eff743c..ffba2d84f1f 100644 --- a/drivers/spi/pic32_spi.c +++ b/drivers/spi/pic32_spi.c @@ -10,6 +10,7 @@ #include <clk.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/compat.h> #include <malloc.h> diff --git a/drivers/spi/pl022_spi.c b/drivers/spi/pl022_spi.c index 32bb8c8d212..01ffaea4c34 100644 --- a/drivers/spi/pl022_spi.c +++ b/drivers/spi/pl022_spi.c @@ -12,6 +12,7 @@ #include <clk.h> #include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/spi_pl022.h> #include <linux/io.h> #include <spi.h> diff --git a/drivers/spi/renesas_rpc_spi.c b/drivers/spi/renesas_rpc_spi.c index d0ff918af88..bf991ae3825 100644 --- a/drivers/spi/renesas_rpc_spi.c +++ b/drivers/spi/renesas_rpc_spi.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk.h> #include <dm.h> diff --git a/drivers/spi/soft_spi.c b/drivers/spi/soft_spi.c index 153bbf8b255..87e1e2417ce 100644 --- a/drivers/spi/soft_spi.c +++ b/drivers/spi/soft_spi.c @@ -16,6 +16,7 @@ #include <log.h> #include <malloc.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/spi/spi-sunxi.c b/drivers/spi/spi-sunxi.c index 0844a5a0a6a..b48fdb5b547 100644 --- a/drivers/spi/spi-sunxi.c +++ b/drivers/spi/spi-sunxi.c @@ -27,6 +27,7 @@ #include <fdt_support.h> #include <reset.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h>
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 55a8eed8901..11b8137ec0a 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -9,6 +9,7 @@ #include <log.h> #include <malloc.h> #include <spi.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> #include <dm/lists.h> diff --git a/drivers/spi/tegra20_sflash.c b/drivers/spi/tegra20_sflash.c index 771744dfe43..5066f43ba61 100644 --- a/drivers/spi/tegra20_sflash.c +++ b/drivers/spi/tegra20_sflash.c @@ -10,6 +10,7 @@ #include <errno.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/clock.h> diff --git a/drivers/spi/tegra20_slink.c b/drivers/spi/tegra20_slink.c index f9846ee3665..d725a957485 100644 --- a/drivers/spi/tegra20_slink.c +++ b/drivers/spi/tegra20_slink.c @@ -9,6 +9,7 @@ #include <dm.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch-tegra/clk_rst.h> diff --git a/drivers/spi/tegra210_qspi.c b/drivers/spi/tegra210_qspi.c index ae16b45dcb4..293b16c6fe9 100644 --- a/drivers/spi/tegra210_qspi.c +++ b/drivers/spi/tegra210_qspi.c @@ -10,6 +10,7 @@ #include <dm.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch-tegra/clk_rst.h> diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index 5fdbb494420..26cd83be76a 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -9,6 +9,7 @@ #include <cpu_func.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/omap.h> #include <malloc.h> diff --git a/drivers/spi/uniphier_spi.c b/drivers/spi/uniphier_spi.c index b6456685f8d..a6d3d6abb6f 100644 --- a/drivers/spi/uniphier_spi.c +++ b/drivers/spi/uniphier_spi.c @@ -9,6 +9,7 @@ #include <dm.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitfield.h> #include <linux/bitops.h> diff --git a/drivers/spi/zynq_qspi.c b/drivers/spi/zynq_qspi.c index 3f39ef05f2d..1358bd10355 100644 --- a/drivers/spi/zynq_qspi.c +++ b/drivers/spi/zynq_qspi.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/spi/zynq_spi.c b/drivers/spi/zynq_spi.c index 9923931e36e..b4604a4b202 100644 --- a/drivers/spi/zynq_spi.c +++ b/drivers/spi/zynq_spi.c @@ -12,6 +12,7 @@ #include <malloc.h> #include <spi.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/spi/zynqmp_gqspi.c b/drivers/spi/zynqmp_gqspi.c index e0e66870377..22e20db8bd4 100644 --- a/drivers/spi/zynqmp_gqspi.c +++ b/drivers/spi/zynqmp_gqspi.c @@ -10,6 +10,7 @@ #include <log.h> #include <asm/arch/sys_proto.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk.h> #include <dm.h> diff --git a/drivers/spmi/spmi-msm.c b/drivers/spmi/spmi-msm.c index 2f430aed9cb..6b12a96ee3c 100644 --- a/drivers/spmi/spmi-msm.c +++ b/drivers/spmi/spmi-msm.c @@ -11,6 +11,7 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <spmi/spmi.h> diff --git a/drivers/sysreset/sysreset-uclass.c b/drivers/sysreset/sysreset-uclass.c index 3f5414ed1f8..d1b47eebac7 100644 --- a/drivers/sysreset/sysreset-uclass.c +++ b/drivers/sysreset/sysreset-uclass.c @@ -15,6 +15,7 @@ #include <dm.h> #include <errno.h> #include <regmap.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/root.h> diff --git a/drivers/sysreset/sysreset_mpc83xx.c b/drivers/sysreset/sysreset_mpc83xx.c index 4e89971840f..f43fea0e8d8 100644 --- a/drivers/sysreset/sysreset_mpc83xx.c +++ b/drivers/sysreset/sysreset_mpc83xx.c @@ -10,6 +10,7 @@ #include <log.h> #include <sysreset.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include "sysreset_mpc83xx.h" diff --git a/drivers/sysreset/sysreset_sti.c b/drivers/sysreset/sysreset_sti.c index 3482d2a0787..8465a62e185 100644 --- a/drivers/sysreset/sysreset_sti.c +++ b/drivers/sysreset/sysreset_sti.c @@ -9,6 +9,7 @@ #include <regmap.h> #include <syscon.h> #include <sysreset.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/thermal/imx_scu_thermal.c b/drivers/thermal/imx_scu_thermal.c index 83ec753802a..dc92e6b603e 100644 --- a/drivers/thermal/imx_scu_thermal.c +++ b/drivers/thermal/imx_scu_thermal.c @@ -9,6 +9,7 @@ #include <errno.h> #include <log.h> #include <thermal.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device.h> #include <asm/arch/sci/sci.h> diff --git a/drivers/thermal/imx_tmu.c b/drivers/thermal/imx_tmu.c index 4ca22089b8b..d8acfef4925 100644 --- a/drivers/thermal/imx_tmu.c +++ b/drivers/thermal/imx_tmu.c @@ -6,6 +6,7 @@
#include <config.h> #include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> diff --git a/drivers/timer/andes_plmt_timer.c b/drivers/timer/andes_plmt_timer.c index cec86718c7f..041c4a9f324 100644 --- a/drivers/timer/andes_plmt_timer.c +++ b/drivers/timer/andes_plmt_timer.c @@ -11,6 +11,7 @@ #include <common.h> #include <dm.h> #include <timer.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/err.h>
diff --git a/drivers/timer/arc_timer.c b/drivers/timer/arc_timer.c index 2dea9f40cba..3101e3bf53b 100644 --- a/drivers/timer/arc_timer.c +++ b/drivers/timer/arc_timer.c @@ -8,6 +8,7 @@ #include <errno.h> #include <timer.h> #include <asm/arcregs.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/timer/cadence-ttc.c b/drivers/timer/cadence-ttc.c index bebb2c2e904..1baa30bdbae 100644 --- a/drivers/timer/cadence-ttc.c +++ b/drivers/timer/cadence-ttc.c @@ -9,6 +9,7 @@ #include <errno.h> #include <init.h> #include <timer.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <linux/err.h> diff --git a/drivers/timer/mpc83xx_timer.c b/drivers/timer/mpc83xx_timer.c index ba7704225a3..775529ff6de 100644 --- a/drivers/timer/mpc83xx_timer.c +++ b/drivers/timer/mpc83xx_timer.c @@ -14,6 +14,7 @@ #include <time.h> #include <timer.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/bitops.h>
diff --git a/drivers/timer/ostm_timer.c b/drivers/timer/ostm_timer.c index bb0636a0719..567f30232bf 100644 --- a/drivers/timer/ostm_timer.c +++ b/drivers/timer/ostm_timer.c @@ -7,6 +7,7 @@
#include <common.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <clk.h> diff --git a/drivers/timer/rockchip_timer.c b/drivers/timer/rockchip_timer.c index 53cdf09810d..422d863d378 100644 --- a/drivers/timer/rockchip_timer.c +++ b/drivers/timer/rockchip_timer.c @@ -8,6 +8,7 @@ #include <dm.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <dm/ofnode.h> #include <mapmem.h> #include <asm/arch-rockchip/timer.h> diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index 62d0e860e80..c383fde8651 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -7,6 +7,7 @@ #include <clk.h> #include <cpu.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/device_compat.h> #include <dm/device-internal.h> diff --git a/drivers/timer/tsc_timer.c b/drivers/timer/tsc_timer.c index abc0a1da05e..3f6c9299d78 100644 --- a/drivers/timer/tsc_timer.c +++ b/drivers/timer/tsc_timer.c @@ -14,6 +14,7 @@ #include <time.h> #include <timer.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/i8254.h> #include <asm/ibmpc.h> diff --git a/drivers/tpm/tpm2_tis_spi.c b/drivers/tpm/tpm2_tis_spi.c index 9a8145e6ba1..8ff6c461f19 100644 --- a/drivers/tpm/tpm2_tis_spi.c +++ b/drivers/tpm/tpm2_tis_spi.c @@ -19,6 +19,7 @@ #include <log.h> #include <spi.h> #include <tpm-v2.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/errno.h> diff --git a/drivers/usb/common/common.c b/drivers/usb/common/common.c index 5e5c3c3e3dc..2a47f40bbab 100644 --- a/drivers/usb/common/common.c +++ b/drivers/usb/common/common.c @@ -8,6 +8,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <linux/usb/otg.h> #include <linux/usb/ch9.h> #include <linux/usb/phy.h> diff --git a/drivers/usb/host/dwc3-octeon-glue.c b/drivers/usb/host/dwc3-octeon-glue.c index c3cac9c5abd..9b91df88c53 100644 --- a/drivers/usb/host/dwc3-octeon-glue.c +++ b/drivers/usb/host/dwc3-octeon-glue.c @@ -12,6 +12,7 @@ #include <dm.h> #include <errno.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <dm/lists.h> diff --git a/drivers/usb/host/dwc3-sti-glue.c b/drivers/usb/host/dwc3-sti-glue.c index 3e6c1429d66..febbfe5d243 100644 --- a/drivers/usb/host/dwc3-sti-glue.c +++ b/drivers/usb/host/dwc3-sti-glue.c @@ -8,6 +8,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <errno.h> diff --git a/drivers/usb/host/ehci-exynos.c b/drivers/usb/host/ehci-exynos.c index 6a37c5d982a..9f1ec7ea926 100644 --- a/drivers/usb/host/ehci-exynos.c +++ b/drivers/usb/host/ehci-exynos.c @@ -10,6 +10,7 @@ #include <dm.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <malloc.h> diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c index 5423d10abe7..eed67e77dc6 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/drivers/usb/host/ehci-fsl.c @@ -12,6 +12,7 @@ #include <log.h> #include <pci.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h> #include <usb/ehci-ci.h> diff --git a/drivers/usb/host/ehci-marvell.c b/drivers/usb/host/ehci-marvell.c index 62414bb1102..9f6b8a2ae5f 100644 --- a/drivers/usb/host/ehci-marvell.c +++ b/drivers/usb/host/ehci-marvell.c @@ -7,6 +7,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <usb.h> #include <linux/delay.h> diff --git a/drivers/usb/host/ehci-mx5.c b/drivers/usb/host/ehci-mx5.c index caafa688993..516d6495359 100644 --- a/drivers/usb/host/ehci-mx5.c +++ b/drivers/usb/host/ehci-mx5.c @@ -8,6 +8,7 @@ #include <log.h> #include <usb.h> #include <errno.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <linux/delay.h> #include <usb/ehci-ci.h> diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 37b59758bb3..f9e72ba0d96 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -9,6 +9,7 @@ #include <usb.h> #include <errno.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <linux/delay.h> #include <usb/ehci-ci.h> diff --git a/drivers/usb/host/ehci-vf.c b/drivers/usb/host/ehci-vf.c index 2768d409749..86eac41ea66 100644 --- a/drivers/usb/host/ehci-vf.c +++ b/drivers/usb/host/ehci-vf.c @@ -11,6 +11,7 @@ #include <log.h> #include <usb.h> #include <errno.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/io.h> #include <asm-generic/gpio.h> diff --git a/drivers/usb/host/xhci-exynos5.c b/drivers/usb/host/xhci-exynos5.c index 6fb7a7f6e09..77c2534da44 100644 --- a/drivers/usb/host/xhci-exynos5.c +++ b/drivers/usb/host/xhci-exynos5.c @@ -16,6 +16,7 @@ #include <dm.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <malloc.h> diff --git a/drivers/usb/musb-new/da8xx.c b/drivers/usb/musb-new/da8xx.c index 67488ddb504..e13a6810b8d 100644 --- a/drivers/usb/musb-new/da8xx.c +++ b/drivers/usb/musb-new/da8xx.c @@ -16,6 +16,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device_compat.h> #include <dm/lists.h> diff --git a/drivers/usb/musb-new/omap2430.c b/drivers/usb/musb-new/omap2430.c index da63cc2c224..fbd5f98f368 100644 --- a/drivers/usb/musb-new/omap2430.c +++ b/drivers/usb/musb-new/omap2430.c @@ -12,6 +12,7 @@ #include <dm.h> #include <log.h> #include <serial.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device_compat.h> #include <dm/lists.h> diff --git a/drivers/usb/musb-new/pic32.c b/drivers/usb/musb-new/pic32.c index 2fbe9bebf17..8995e78fee4 100644 --- a/drivers/usb/musb-new/pic32.c +++ b/drivers/usb/musb-new/pic32.c @@ -11,6 +11,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/usb/musb-new/ti-musb.c b/drivers/usb/musb-new/ti-musb.c index f4f26d86b3f..bf58f13480b 100644 --- a/drivers/usb/musb-new/ti-musb.c +++ b/drivers/usb/musb-new/ti-musb.c @@ -11,6 +11,7 @@ #include <dm.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/usb/otg.h> #include <dm/device-internal.h> #include <dm/lists.h> diff --git a/drivers/usb/phy/rockchip_usb2_phy.c b/drivers/usb/phy/rockchip_usb2_phy.c index f1cf9160d56..93caa821a1d 100644 --- a/drivers/usb/phy/rockchip_usb2_phy.c +++ b/drivers/usb/phy/rockchip_usb2_phy.c @@ -6,6 +6,7 @@ #include <common.h> #include <hang.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/video/am335x-fb.c b/drivers/video/am335x-fb.c index 2707ff59c7d..2bf4d85d021 100644 --- a/drivers/video/am335x-fb.c +++ b/drivers/video/am335x-fb.c @@ -20,6 +20,7 @@ #include <asm/arch/hardware.h> #include <asm/arch/omap.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/utils.h> #include <linux/delay.h> diff --git a/drivers/video/atmel_hlcdfb.c b/drivers/video/atmel_hlcdfb.c index 38def2816b2..bfe76349fda 100644 --- a/drivers/video/atmel_hlcdfb.c +++ b/drivers/video/atmel_hlcdfb.c @@ -10,6 +10,7 @@ #include <log.h> #include <malloc.h> #include <part.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> diff --git a/drivers/video/atmel_lcdfb.c b/drivers/video/atmel_lcdfb.c index ae8ec26468f..e5e0aeec350 100644 --- a/drivers/video/atmel_lcdfb.c +++ b/drivers/video/atmel_lcdfb.c @@ -12,6 +12,7 @@ #include <log.h> #include <part.h> #include <video.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> diff --git a/drivers/video/bridge/ps862x.c b/drivers/video/bridge/ps862x.c index 8399c6f74cf..7e9c6da4545 100644 --- a/drivers/video/bridge/ps862x.c +++ b/drivers/video/bridge/ps862x.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <log.h> #include <video_bridge.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <power/regulator.h>
diff --git a/drivers/video/broadwell_igd.c b/drivers/video/broadwell_igd.c index df6a761d2db..416a1c07b13 100644 --- a/drivers/video/broadwell_igd.c +++ b/drivers/video/broadwell_igd.c @@ -14,6 +14,7 @@ #include <vbe.h> #include <video.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/mtrr.h> diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 3f07f4eb297..27ff7163f34 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -74,6 +74,7 @@ #include <version.h> #include <malloc.h> #include <video.h> +#include <asm/global_data.h> #include <linux/compiler.h>
#if defined(CONFIG_VIDEO_MXS) diff --git a/drivers/video/da8xx-fb.c b/drivers/video/da8xx-fb.c index 4984dda8477..462c318126d 100644 --- a/drivers/video/da8xx-fb.c +++ b/drivers/video/da8xx-fb.c @@ -17,6 +17,7 @@ #include <malloc.h> #include <memalign.h> #include <video_fb.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/list.h> #include <linux/fb.h> diff --git a/drivers/video/exynos/exynos_dp.c b/drivers/video/exynos/exynos_dp.c index 999ee1c14af..36595556f13 100644 --- a/drivers/video/exynos/exynos_dp.c +++ b/drivers/video/exynos/exynos_dp.c @@ -11,6 +11,7 @@ #include <display.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <malloc.h> diff --git a/drivers/video/exynos/exynos_fb.c b/drivers/video/exynos/exynos_fb.c index 979b9091827..26068ab056f 100644 --- a/drivers/video/exynos/exynos_fb.c +++ b/drivers/video/exynos/exynos_fb.c @@ -13,6 +13,7 @@ #include <dm.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <panel.h> #include <video.h> diff --git a/drivers/video/exynos/exynos_mipi_dsi.c b/drivers/video/exynos/exynos_mipi_dsi.c index 042aa9a5b9e..c56eadc8237 100644 --- a/drivers/video/exynos/exynos_mipi_dsi.c +++ b/drivers/video/exynos/exynos_mipi_dsi.c @@ -10,6 +10,7 @@ #include <log.h> #include <malloc.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <dm/devres.h> #include <linux/libfdt.h> #include <linux/compat.h> diff --git a/drivers/video/fsl_dcu_fb.c b/drivers/video/fsl_dcu_fb.c index e9d05c93946..60b97e40633 100644 --- a/drivers/video/fsl_dcu_fb.c +++ b/drivers/video/fsl_dcu_fb.c @@ -8,6 +8,7 @@
#include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <dm.h> diff --git a/drivers/video/ivybridge_igd.c b/drivers/video/ivybridge_igd.c index 2587f53ac1d..cd742b2273c 100644 --- a/drivers/video/ivybridge_igd.c +++ b/drivers/video/ivybridge_igd.c @@ -12,6 +12,7 @@ #include <pci_rom.h> #include <vbe.h> #include <video.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/mtrr.h> diff --git a/drivers/video/mali_dp.c b/drivers/video/mali_dp.c index 1e6da0e1e25..7f9443828b2 100644 --- a/drivers/video/mali_dp.c +++ b/drivers/video/mali_dp.c @@ -13,6 +13,7 @@ #include <display.h> #endif #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/io.h> #include <os.h> #include <fdt_support.h> diff --git a/drivers/video/meson/meson_vpu.c b/drivers/video/meson/meson_vpu.c index 4868839ff7d..2d095c6a28e 100644 --- a/drivers/video/meson/meson_vpu.c +++ b/drivers/video/meson/meson_vpu.c @@ -13,6 +13,7 @@ #include <fdt_support.h> #include <log.h> #include <part.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/arch/mem.h> #include <dm/device-internal.h> diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 6589a2a09d2..d84adb004bc 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -10,6 +10,7 @@ #include <env.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/delay.h> #include <linux/errno.h> diff --git a/drivers/video/rockchip/rk3288_vop.c b/drivers/video/rockchip/rk3288_vop.c index 68d1507cda4..d1bf82c5b27 100644 --- a/drivers/video/rockchip/rk3288_vop.c +++ b/drivers/video/rockchip/rk3288_vop.c @@ -11,6 +11,7 @@ #include <regmap.h> #include <syscon.h> #include <video.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/grf_rk3288.h> diff --git a/drivers/video/rockchip/rk3399_vop.c b/drivers/video/rockchip/rk3399_vop.c index d5a7aa8ac1b..fe424d51f73 100644 --- a/drivers/video/rockchip/rk3399_vop.c +++ b/drivers/video/rockchip/rk3399_vop.c @@ -12,6 +12,7 @@ #include <regmap.h> #include <video.h> #include <asm/arch-rockchip/hardware.h> +#include <asm/global_data.h> #include <asm/io.h> #include "rk_vop.h"
diff --git a/drivers/video/rockchip/rk_lvds.c b/drivers/video/rockchip/rk_lvds.c index 04f795a213c..24f3caabb01 100644 --- a/drivers/video/rockchip/rk_lvds.c +++ b/drivers/video/rockchip/rk_lvds.c @@ -11,6 +11,7 @@ #include <panel.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> diff --git a/drivers/video/rockchip/rk_mipi.c b/drivers/video/rockchip/rk_mipi.c index f811913ce5e..2e235cb6c2c 100644 --- a/drivers/video/rockchip/rk_mipi.c +++ b/drivers/video/rockchip/rk_mipi.c @@ -11,6 +11,7 @@ #include <log.h> #include <panel.h> #include <regmap.h> +#include <asm/global_data.h> #include "rk_mipi.h" #include <syscon.h> #include <asm/gpio.h> diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index 9032eb430e7..7e864698697 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -13,6 +13,7 @@ #include <regmap.h> #include <syscon.h> #include <video.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> diff --git a/drivers/video/sandbox_sdl.c b/drivers/video/sandbox_sdl.c index d806f35debb..48470e6f556 100644 --- a/drivers/video/sandbox_sdl.c +++ b/drivers/video/sandbox_sdl.c @@ -8,6 +8,7 @@ #include <fdtdec.h> #include <log.h> #include <video.h> +#include <asm/global_data.h> #include <asm/sdl.h> #include <asm/state.h> #include <asm/u-boot-sandbox.h> diff --git a/drivers/video/simplefb.c b/drivers/video/simplefb.c index 0c5b40c30b8..e7c2e184ba5 100644 --- a/drivers/video/simplefb.c +++ b/drivers/video/simplefb.c @@ -9,6 +9,7 @@ #include <fdt_support.h> #include <log.h> #include <video.h> +#include <asm/global_data.h>
static int simple_video_probe(struct udevice *dev) { diff --git a/drivers/video/stm32/stm32_dsi.c b/drivers/video/stm32/stm32_dsi.c index 9d5abacc2bf..8fae9f2246e 100644 --- a/drivers/video/stm32/stm32_dsi.c +++ b/drivers/video/stm32/stm32_dsi.c @@ -18,6 +18,7 @@ #include <reset.h> #include <video.h> #include <video_bridge.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/gpio.h> #include <dm/device-internal.h> diff --git a/drivers/video/stm32/stm32_ltdc.c b/drivers/video/stm32/stm32_ltdc.c index 7fff735930b..bfd9d5991d3 100644 --- a/drivers/video/stm32/stm32_ltdc.c +++ b/drivers/video/stm32/stm32_ltdc.c @@ -14,6 +14,7 @@ #include <reset.h> #include <video.h> #include <video_bridge.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/gpio.h> #include <dm/device-internal.h> diff --git a/drivers/video/sunxi/sunxi_lcd.c b/drivers/video/sunxi/sunxi_lcd.c index 49bf083a8d1..10f7e2ac234 100644 --- a/drivers/video/sunxi/sunxi_lcd.c +++ b/drivers/video/sunxi/sunxi_lcd.c @@ -12,6 +12,7 @@ #include <backlight.h> #include <dm.h> #include <edid.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/lcdc.h> diff --git a/drivers/video/tegra.c b/drivers/video/tegra.c index 827ea13d13a..a32478ea627 100644 --- a/drivers/video/tegra.c +++ b/drivers/video/tegra.c @@ -12,6 +12,7 @@ #include <pwm.h> #include <video.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/gpio.h> #include <asm/io.h> diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 650891e49dd..1654d02860b 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -14,6 +14,7 @@ #include <video.h> #include <video_console.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> diff --git a/drivers/video/videomodes.c b/drivers/video/videomodes.c index 89003eea727..ed7373eac84 100644 --- a/drivers/video/videomodes.c +++ b/drivers/video/videomodes.c @@ -60,6 +60,7 @@ #include <edid.h> #include <env.h> #include <errno.h> +#include <fdtdec.h> #include <linux/ctype.h>
#include "videomodes.h" diff --git a/drivers/watchdog/armada-37xx-wdt.c b/drivers/watchdog/armada-37xx-wdt.c index 5da8e56505f..7af680a5c25 100644 --- a/drivers/watchdog/armada-37xx-wdt.c +++ b/drivers/watchdog/armada-37xx-wdt.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <wdt.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/drivers/watchdog/at91sam9_wdt.c b/drivers/watchdog/at91sam9_wdt.c index 33f5c351d5b..e64831132dc 100644 --- a/drivers/watchdog/at91sam9_wdt.c +++ b/drivers/watchdog/at91sam9_wdt.c @@ -15,6 +15,7 @@ */
#include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_wdt.h> #include <common.h> diff --git a/drivers/watchdog/mt7621_wdt.c b/drivers/watchdog/mt7621_wdt.c index 1cd8866ef8d..ff5c3243ce7 100644 --- a/drivers/watchdog/mt7621_wdt.c +++ b/drivers/watchdog/mt7621_wdt.c @@ -12,6 +12,7 @@ #include <common.h> #include <dm.h> #include <wdt.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h>
diff --git a/drivers/watchdog/octeontx_wdt.c b/drivers/watchdog/octeontx_wdt.c index 88708dc5e1c..c1b3e425c1c 100644 --- a/drivers/watchdog/octeontx_wdt.c +++ b/drivers/watchdog/octeontx_wdt.c @@ -9,6 +9,7 @@ #include <dm.h> #include <errno.h> #include <wdt.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitfield.h>
diff --git a/drivers/watchdog/orion_wdt.c b/drivers/watchdog/orion_wdt.c index d33e2ac3dc1..3284321299d 100644 --- a/drivers/watchdog/orion_wdt.c +++ b/drivers/watchdog/orion_wdt.c @@ -17,6 +17,7 @@ #include <clk.h> #include <log.h> #include <wdt.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/kernel.h> #include <asm/io.h> diff --git a/drivers/watchdog/sbsa_gwdt.c b/drivers/watchdog/sbsa_gwdt.c index 2eae431ba6c..b837b045fa5 100644 --- a/drivers/watchdog/sbsa_gwdt.c +++ b/drivers/watchdog/sbsa_gwdt.c @@ -5,6 +5,7 @@ * Copyright 2020 NXP */
+#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <dm/device.h> diff --git a/drivers/watchdog/sp805_wdt.c b/drivers/watchdog/sp805_wdt.c index 23fef2147f8..0eea0ab388e 100644 --- a/drivers/watchdog/sp805_wdt.c +++ b/drivers/watchdog/sp805_wdt.c @@ -6,6 +6,7 @@ */
#include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <clk.h> diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index e632f077f34..28f7918c467 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -10,6 +10,7 @@ #include <log.h> #include <time.h> #include <wdt.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h>
diff --git a/drivers/xen/gnttab.c b/drivers/xen/gnttab.c index 9bf1091ab32..778729d646e 100644 --- a/drivers/xen/gnttab.c +++ b/drivers/xen/gnttab.c @@ -15,6 +15,7 @@ * [1] - http://xenbits.xen.org/gitweb/?p=mini-os.git;a=summary */ #include <common.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <log.h> #include <malloc.h> diff --git a/drivers/xen/pvblock.c b/drivers/xen/pvblock.c index 1b3325bbe2a..84f2aca6ae7 100644 --- a/drivers/xen/pvblock.c +++ b/drivers/xen/pvblock.c @@ -6,6 +6,7 @@ #include <blk.h> #include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <malloc.h> #include <part.h> diff --git a/env/callback.c b/env/callback.c index 4054b9ef58b..638a02b28f7 100644 --- a/env/callback.c +++ b/env/callback.c @@ -7,6 +7,7 @@ #include <common.h> #include <env.h> #include <env_internal.h> +#include <asm/global_data.h>
#if defined(CONFIG_NEEDS_MANUAL_RELOC) DECLARE_GLOBAL_DATA_PTR; diff --git a/env/common.c b/env/common.c index ed18378000f..d6d1fa3a1f7 100644 --- a/env/common.c +++ b/env/common.c @@ -14,6 +14,7 @@ #include <env_internal.h> #include <log.h> #include <sort.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <search.h> #include <errno.h> diff --git a/env/eeprom.c b/env/eeprom.c index e300470ad0f..ba168014e24 100644 --- a/env/eeprom.c +++ b/env/eeprom.c @@ -12,6 +12,7 @@ #include <eeprom.h> #include <env.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <u-boot/crc.h> #if defined(CONFIG_I2C_ENV_EEPROM_BUS) diff --git a/env/env.c b/env/env.c index 42c7d8155e1..51f55ec3fe8 100644 --- a/env/env.c +++ b/env/env.c @@ -8,6 +8,7 @@ #include <env.h> #include <env_internal.h> #include <log.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/bug.h>
diff --git a/env/ext4.c b/env/ext4.c index e666f7b9455..ec643f2226a 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -31,6 +31,7 @@ #include <errno.h> #include <ext4fs.h> #include <mmc.h> +#include <asm/global_data.h>
diff --git a/env/flash.c b/env/flash.c index 722d5adf8b6..ebee9069e4e 100644 --- a/env/flash.c +++ b/env/flash.c @@ -15,6 +15,7 @@ #include <env_internal.h> #include <flash.h> #include <log.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <malloc.h> #include <search.h> diff --git a/env/mmc.c b/env/mmc.c index 4e67180b23a..c9ccaef461c 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -6,6 +6,7 @@ /* #define DEBUG */
#include <command.h> #include <env.h> diff --git a/env/nand.c b/env/nand.c index 0d7ee19bc23..be82e97d69c 100644 --- a/env/nand.c +++ b/env/nand.c @@ -17,6 +17,7 @@ #include <command.h> #include <env.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <malloc.h> #include <memalign.h> diff --git a/env/nowhere.c b/env/nowhere.c index d33fdf27d0c..23028661084 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -11,6 +11,7 @@ #include <command.h> #include <env.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/env/nvram.c b/env/nvram.c index 7c8ea26f968..f4126858b5b 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -27,6 +27,7 @@ #include <command.h> #include <env.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <search.h> #include <errno.h> diff --git a/env/onenand.c b/env/onenand.c index a2477cef9be..c8da3ff8114 100644 --- a/env/onenand.c +++ b/env/onenand.c @@ -10,6 +10,7 @@ #include <common.h> #include <command.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <malloc.h> #include <search.h> diff --git a/env/remote.c b/env/remote.c index d93a137376e..166bebf52b5 100644 --- a/env/remote.c +++ b/env/remote.c @@ -8,6 +8,7 @@ #include <common.h> #include <command.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <u-boot/crc.h>
diff --git a/env/sf.c b/env/sf.c index 937778aa37d..f01d1dbcb21 100644 --- a/env/sf.c +++ b/env/sf.c @@ -20,6 +20,7 @@ #include <errno.h> #include <uuid.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <u-boot/crc.h>
diff --git a/env/ubi.c b/env/ubi.c index 5502efe28b6..eb21c4f38b4 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -5,6 +5,7 @@ */
#include <command.h> #include <env.h> diff --git a/examples/standalone/stubs.c b/examples/standalone/stubs.c index 5fb460454f2..3e326fc6405 100644 --- a/examples/standalone/stubs.c +++ b/examples/standalone/stubs.c @@ -1,5 +1,6 @@ #include <common.h> #include <exports.h> +#include <asm/global_data.h> #include <linux/compiler.h>
struct cmd_tbl; diff --git a/fs/ext4/ext4_journal.c b/fs/ext4/ext4_journal.c index 1a340b4764c..361baa35c92 100644 --- a/fs/ext4/ext4_journal.c +++ b/fs/ext4/ext4_journal.c @@ -19,6 +19,7 @@ #include <log.h> #include <malloc.h> #include <ext_common.h> +#include <asm/global_data.h> #include "ext4_common.h"
static struct revoke_blk_list *revk_blk_list; diff --git a/fs/ext4/ext4_journal.h b/fs/ext4/ext4_journal.h index 43fb8e76641..8c974cff609 100644 --- a/fs/ext4/ext4_journal.h +++ b/fs/ext4/ext4_journal.h @@ -17,6 +17,7 @@ #ifndef __EXT4_JRNL__ #define __EXT4_JRNL__
+#include <asm/global_data.h> #define EXT4_FEATURE_COMPAT_HAS_JOURNAL 0x0004
#define EXT2_JOURNAL_INO 8 /* Journal inode */ diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c index 4c89152ce4a..691d7e29b6d 100644 --- a/fs/ext4/ext4fs.c +++ b/fs/ext4/ext4fs.c @@ -24,11 +24,11 @@ #include <blk.h> #include <ext_common.h> #include <ext4fs.h> -#include "ext4_common.h" #include <div64.h> #include <malloc.h> #include <part.h> #include <uuid.h> +#include "ext4_common.h"
int ext4fs_symlinknest; struct ext_filesystem ext_fs; diff --git a/fs/fs.c b/fs/fs.c index 29ad4d1a695..634e7cea81d 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -20,6 +20,7 @@ #include <sandboxfs.h> #include <ubifs_uboot.h> #include <btrfs.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <linux/math64.h> diff --git a/fs/reiserfs/reiserfs_private.h b/fs/reiserfs/reiserfs_private.h index c8867e24fef..5936f214005 100644 --- a/fs/reiserfs/reiserfs_private.h +++ b/fs/reiserfs/reiserfs_private.h @@ -15,6 +15,8 @@ * from the original reiser fs code, as found in the linux kernel. */
+#include <compiler.h> + #ifndef __BYTE_ORDER #if defined(__LITTLE_ENDIAN) && !defined(__BIG_ENDIAN) #define __BYTE_ORDER __LITTLE_ENDIAN diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 70beb848e1b..d6be5c947d7 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -17,6 +17,7 @@ #include <log.h> #include <malloc.h> #include <memalign.h> +#include <asm/global_data.h> #include "ubifs.h" #include <part.h> #include <dm/devres.h> diff --git a/include/audio_codec.h b/include/audio_codec.h index 25870995469..2ea4ff096e6 100644 --- a/include/audio_codec.h +++ b/include/audio_codec.h @@ -7,6 +7,8 @@ #ifndef __AUDIO_CODEC_H__ #define __AUDIO_CODEC_H__
+struct udevice; + /* * An audio codec turns digital data into sound with various parameters to * control its operation. diff --git a/include/axi.h b/include/axi.h index 3e40692cdfd..59fb0b2e458 100644 --- a/include/axi.h +++ b/include/axi.h @@ -7,6 +7,8 @@ #ifndef _AXI_H_ #define _AXI_H_
+struct udevice; + /** * enum axi_size_t - Determine size of AXI transfer * @AXI_SIZE_8: AXI sransfer is 8-bit wide diff --git a/include/backlight.h b/include/backlight.h index ac59eb293b4..b44da50bc30 100644 --- a/include/backlight.h +++ b/include/backlight.h @@ -7,6 +7,8 @@ #ifndef _BACKLIGHT_H #define _BACKLIGHT_H
+struct udevice; + enum { BACKLIGHT_MAX = 100, BACKLIGHT_MIN = 0, diff --git a/include/board.h b/include/board.h index 678b652b0aa..a43f35a021b 100644 --- a/include/board.h +++ b/include/board.h @@ -4,6 +4,8 @@ * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc */
+struct udevice; + /* * This uclass encapsulates hardware methods to gather information about a * board or a specific device such as hard-wired GPIOs on GPIO expanders, @@ -32,6 +34,7 @@ */
#if CONFIG_IS_ENABLED(BOARD) + struct board_ops { /** * detect() - Run the hardware info detection procedure for this diff --git a/include/bootcount.h b/include/bootcount.h index cd304039849..bb235407e30 100644 --- a/include/bootcount.h +++ b/include/bootcount.h @@ -7,6 +7,7 @@ #define _BOOTCOUNT_H__
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/byteorder.h> #include <env.h> diff --git a/include/cache.h b/include/cache.h index 32f59fd8f71..ecb7956efd5 100644 --- a/include/cache.h +++ b/include/cache.h @@ -6,6 +6,8 @@ #ifndef __CACHE_H #define __CACHE_H
+struct udevice; + /* * Structure for the cache controller */ diff --git a/include/common.h b/include/common.h index f0679ac7054..71df59bca0e 100644 --- a/include/common.h +++ b/include/common.h @@ -23,7 +23,6 @@ #include <stdio.h> #include <linux/kernel.h> #include <asm/u-boot.h> /* boot information for Linux kernel */ -#include <asm/global_data.h> /* global data used for startup functions */ #include <display_options.h> #include <vsprintf.h> #endif /* __ASSEMBLY__ */ diff --git a/include/cpu.h b/include/cpu.h index 78e88b9ed09..089e74c262b 100644 --- a/include/cpu.h +++ b/include/cpu.h @@ -7,6 +7,8 @@ #ifndef __CPU_H #define __CPU_H
+struct udevice; + /** * struct cpu_platdata - platform data for a CPU * @cpu_id: Platform-specific way of identifying the CPU. diff --git a/include/dm/device-internal.h b/include/dm/device-internal.h index 1dcc22f6891..a26e92ed350 100644 --- a/include/dm/device-internal.h +++ b/include/dm/device-internal.h @@ -10,6 +10,7 @@ #ifndef _DM_DEVICE_INTERNAL_H #define _DM_DEVICE_INTERNAL_H
struct device_node; diff --git a/include/dm/read.h b/include/dm/read.h index 0585eb12281..a131f3fba3c 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -9,6 +9,7 @@ #ifndef _DM_READ_H #define _DM_READ_H
#include <dm/device.h> diff --git a/include/dm/root.h b/include/dm/root.h index c8d629ba9bf..3a3cc106b11 100644 --- a/include/dm/root.h +++ b/include/dm/root.h @@ -9,6 +9,7 @@ #ifndef _DM_ROOT_H_ #define _DM_ROOT_H_
+#include <asm/global_data.h> struct udevice;
/** diff --git a/include/dma.h b/include/dma.h index 6ff591977b1..a64580a61ff 100644 --- a/include/dma.h +++ b/include/dma.h @@ -13,6 +13,8 @@ #include <linux/errno.h> #include <linux/types.h>
+struct udevice; + /* * enum dma_direction - dma transfer direction indicator * @DMA_MEM_TO_MEM: Memcpy mode diff --git a/include/exports.h b/include/exports.h index b3005540916..e89cc333e52 100644 --- a/include/exports.h +++ b/include/exports.h @@ -2,6 +2,7 @@ #define __EXPORTS_H__
#include <irq_func.h> +#include <asm/global_data.h> #include <linux/delay.h>
#ifndef __ASSEMBLY__ diff --git a/include/ext_common.h b/include/ext_common.h index bc3324172a0..30a0c248414 100644 --- a/include/ext_common.h +++ b/include/ext_common.h @@ -20,6 +20,8 @@ #ifndef __EXT_COMMON__ #define __EXT_COMMON__
+#include <compiler.h> + struct cmd_tbl;
#define SECTOR_SIZE 0x200 diff --git a/include/i2c.h b/include/i2c.h index 880aa8032b7..3e7dcb5bad2 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -17,6 +17,7 @@ #define _I2C_H_
#include <linker_lists.h> +#include <asm/global_data.h>
/* * For now there are essentially two parts to this file - driver model diff --git a/include/image-sparse.h b/include/image-sparse.h index 234c237b845..0572dbd0a28 100644 --- a/include/image-sparse.h +++ b/include/image-sparse.h @@ -3,6 +3,7 @@ * Copyright 2014 Broadcom Corporation. */
+#include <compiler.h> #include <part.h> #include <sparse_format.h>
diff --git a/include/init.h b/include/init.h index 0f48ccb57ad..3b00e1d8aca 100644 --- a/include/init.h +++ b/include/init.h @@ -10,16 +10,15 @@ #ifndef __INIT_H_ #define __INIT_H_ 1
-#include <linux/types.h> - -struct global_data; - #ifndef __ASSEMBLY__ /* put C only stuff in this section */
+#include <linux/types.h> + /* Avoid using CONFIG_EFI_STUB directly as we may boot from other loaders */ #ifdef CONFIG_EFI_STUB #define ll_boot_init() false #else +#include <asm/global_data.h> #define ll_boot_init() (!(gd->flags & GD_FLG_SKIP_LL_INIT)) #endif
diff --git a/include/initcall.h b/include/initcall.h index 41b74dc52d2..e367a2ba044 100644 --- a/include/initcall.h +++ b/include/initcall.h @@ -6,6 +6,7 @@ #ifndef __INITCALL_H #define __INITCALL_H
+#include <asm/global_data.h> typedef int (*init_fnc_t)(void);
#include <log.h> diff --git a/include/led.h b/include/led.h index 7bfdddfd6fa..02766fa56fb 100644 --- a/include/led.h +++ b/include/led.h @@ -7,6 +7,8 @@ #ifndef __LED_H #define __LED_H
+struct udevice; + /** * struct led_uc_plat - Platform data the uclass stores about each device * diff --git a/include/libata.h b/include/libata.h index b03b29960df..10e6057ef4a 100644 --- a/include/libata.h +++ b/include/libata.h @@ -10,8 +10,6 @@ #ifndef __LIBATA_H__ #define __LIBATA_H__
-#include <common.h> - enum { /* various global constants */ ATA_MAX_DEVICES = 2, /* per bus/port */ diff --git a/include/misc.h b/include/misc.h index 12d1325ee26..82ec2ce7936 100644 --- a/include/misc.h +++ b/include/misc.h @@ -6,6 +6,8 @@ #ifndef _MISC_H_ #define _MISC_H_
+struct udevice; + /** * misc_read() - Read the device to buffer, optional. * @dev: the device diff --git a/include/netdev.h b/include/netdev.h index b1eb5fc1046..0ad9f8dc3a5 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -12,6 +12,8 @@ #define _NETDEV_H_ #include <phy_interface.h>
+struct udevice; + /* * Board and CPU-specific initialization functions * board_eth_init() has highest priority. cpu_eth_init() only diff --git a/include/pci.h b/include/pci.h index d1ccf6c9636..bcc9f07e805 100644 --- a/include/pci.h +++ b/include/pci.h @@ -843,9 +843,7 @@ int pci_last_busno(void); extern void pci_mpc85xx_init (struct pci_controller *hose); #endif
-#ifdef CONFIG_PCIE_IMX extern void imx_pcie_remove(void); -#endif
#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) /** diff --git a/include/power/as3722.h b/include/power/as3722.h index 27828570559..f5398123f2a 100644 --- a/include/power/as3722.h +++ b/include/power/as3722.h @@ -6,6 +6,8 @@ #ifndef __POWER_AS3722_H__ #define __POWER_AS3722_H__
+struct udevice; + #define AS3722_GPIO_OUTPUT_VDDH (1 << 0) #define AS3722_GPIO_INVERT (1 << 1)
diff --git a/include/power/regulator.h b/include/power/regulator.h index 7f278e8c7dc..46a3c131e2a 100644 --- a/include/power/regulator.h +++ b/include/power/regulator.h @@ -7,6 +7,8 @@ #ifndef _INCLUDE_REGULATOR_H_ #define _INCLUDE_REGULATOR_H_
+struct udevice; + /** * U-Boot Voltage/Current Regulator * ================================ diff --git a/include/pwm.h b/include/pwm.h index 54ae3e64c31..f9959706ceb 100644 --- a/include/pwm.h +++ b/include/pwm.h @@ -10,6 +10,8 @@ #ifndef _pwm_h_ #define _pwm_h_
+struct udevice; + /* struct pwm_ops: Operations for the PWM uclass */ struct pwm_ops { /** diff --git a/include/ram.h b/include/ram.h index 67e22d76c93..273d4153940 100644 --- a/include/ram.h +++ b/include/ram.h @@ -7,6 +7,8 @@ #ifndef __RAM_H #define __RAM_H
+struct udevice; + struct ram_info { phys_addr_t base; size_t size; diff --git a/include/scsi.h b/include/scsi.h index 96cb7266762..61619e89a7f 100644 --- a/include/scsi.h +++ b/include/scsi.h @@ -9,6 +9,8 @@ #include <asm/cache.h> #include <linux/dma-direction.h>
+struct udevice; + struct scsi_cmd { unsigned char cmd[16]; /* command */ /* for request sense */ diff --git a/include/soc.h b/include/soc.h index a55eb1b5724..a52a300a84a 100644 --- a/include/soc.h +++ b/include/soc.h @@ -9,6 +9,8 @@
#define SOC_MAX_STR_SIZE 128
+struct udevice; + /** * struct soc_attr - Contains SoC identify information to be used in * SoC matching. An array of these structs diff --git a/include/sysreset.h b/include/sysreset.h index 61295e3fcbb..8bb094d463b 100644 --- a/include/sysreset.h +++ b/include/sysreset.h @@ -7,6 +7,8 @@ #ifndef __SYSRESET_H #define __SYSRESET_H
+struct udevice; + enum sysreset_t { SYSRESET_WARM, /* Reset CPU, keep GPIOs active */ SYSRESET_COLD, /* Reset CPU and GPIOs */ diff --git a/include/tee.h b/include/tee.h index 8207d0c02af..99367b258e2 100644 --- a/include/tee.h +++ b/include/tee.h @@ -7,6 +7,8 @@ #define __TEE_H
#include <linux/bitops.h> +#include <linux/list.h> + #define TEE_UUID_LEN 16
#define TEE_GEN_CAP_GP BIT(0) /* GlobalPlatform compliant TEE */ diff --git a/include/tlv_eeprom.h b/include/tlv_eeprom.h index 1de2fe2337c..9f4a109dca9 100644 --- a/include/tlv_eeprom.h +++ b/include/tlv_eeprom.h @@ -7,6 +7,8 @@ #ifndef __TLV_EEPROM_H_ #define __TLV_EEPROM_H_
+#include <compiler.h> + /* * The Definition of the TlvInfo EEPROM format can be found at onie.org or * github.com/onie diff --git a/include/tpm-common.h b/include/tpm-common.h index e29b10b1766..c1309a2735d 100644 --- a/include/tpm-common.h +++ b/include/tpm-common.h @@ -9,6 +9,8 @@
+struct udevice; + enum tpm_duration { TPM_SHORT = 0, TPM_MEDIUM = 1, diff --git a/include/tpm-v1.h b/include/tpm-v1.h index 59ad4aecf42..8f6cc28a9ea 100644 --- a/include/tpm-v1.h +++ b/include/tpm-v1.h @@ -10,6 +10,8 @@ #include <tpm-common.h> #include <linux/bitops.h>
+struct udevice; + /* Useful constants */ enum { TPM_REQUEST_HEADER_LENGTH = 10, diff --git a/include/tpm-v2.h b/include/tpm-v2.h index f6c045d3548..3b2fe449007 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -11,6 +11,8 @@
#define TPM2_DIGEST_LEN 32
+struct udevice; + /** * TPM2 Structure Tags for command/response buffers. * diff --git a/include/tps6586x.h b/include/tps6586x.h index 785eb39229d..aa4270c65e3 100644 --- a/include/tps6586x.h +++ b/include/tps6586x.h @@ -7,6 +7,8 @@ #ifndef _TPS6586X_H_ #define _TPS6586X_H_
+struct udevice; + enum { /* SM0-2 PWM/PFM Mode Selection */ TPS6586X_PWM_SM0 = 1 << 0, diff --git a/include/ufs.h b/include/ufs.h index 0592a763dd9..bda135cf184 100644 --- a/include/ufs.h +++ b/include/ufs.h @@ -1,6 +1,9 @@ /* SPDX-License-Identifier: GPL-2.0+ */ #ifndef _UFS_H #define _UFS_H + +struct udevice; + /** * ufs_probe() - initialize all devices in the UFS uclass * diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 908d8903893..413d9048d29 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -13,6 +13,7 @@ #include <tables_csum.h> #include <version.h> #include <acpi/acpi_table.h> +#include <asm/global_data.h> #include <dm/acpi.h>
int acpi_create_dmar(struct acpi_dmar *dmar, enum dmar_flags flags) diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c index b17651ed63d..ee592cfda1c 100644 --- a/lib/asm-offsets.c +++ b/lib/asm-offsets.c @@ -13,6 +13,7 @@
#include <common.h> #include <asm-offsets.h> +#include <asm/global_data.h>
#include <linux/kbuild.h>
diff --git a/lib/efi/efi_app.c b/lib/efi/efi_app.c index b7e19c34750..907bacd716a 100644 --- a/lib/efi/efi_app.c +++ b/lib/efi/efi_app.c @@ -15,6 +15,7 @@ #include <errno.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/err.h> #include <linux/types.h> #include <efi.h> diff --git a/lib/efi/efi_info.c b/lib/efi/efi_info.c index 35a8a9325f8..4d78923c4d4 100644 --- a/lib/efi/efi_info.c +++ b/lib/efi/efi_info.c @@ -9,6 +9,7 @@ #include <efi.h> #include <errno.h> #include <mapmem.h> +#include <asm/global_data.h>
int efi_info_get(enum efi_entry_t type, void **datap, int *sizep) { diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index b26ac9fbfc7..7be5b089e36 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -19,6 +19,7 @@ #include <u-boot/crc.h> #include <usb.h> #include <watchdog.h> +#include <asm/global_data.h> #include <linux/libfdt_env.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/lib/efi_loader/efi_gop.c b/lib/efi_loader/efi_gop.c index 53f6d970f73..1206b2d7a2c 100644 --- a/lib/efi_loader/efi_gop.c +++ b/lib/efi_loader/efi_gop.c @@ -12,6 +12,7 @@ #include <log.h> #include <malloc.h> #include <video.h> +#include <asm/global_data.h>
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 11e755363e4..448e8231d38 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -12,6 +12,7 @@ #include <mapmem.h> #include <watchdog.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/list_sort.h> #include <linux/sizes.h>
diff --git a/lib/efi_loader/efi_rng.c b/lib/efi_loader/efi_rng.c index a8a87007b65..2ff0fdf9db1 100644 --- a/lib/efi_loader/efi_rng.c +++ b/lib/efi_loader/efi_rng.c @@ -11,6 +11,7 @@ #include <efi_rng.h> #include <log.h> #include <rng.h> +#include <asm/global_data.h>
diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index 1fa1595e402..dd17cbefe7d 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -14,6 +14,7 @@ #include <log.h> #include <malloc.h> #include <rtc.h> +#include <asm/global_data.h> #include <u-boot/crc.h>
/* For manual relocation support */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index ee1bd41b081..5990b161b14 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -21,6 +21,7 @@ #include <mapmem.h> #include <linux/libfdt.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <linux/ctype.h> #include <linux/lzo.h> diff --git a/lib/optee/optee.c b/lib/optee/optee.c index 9e6606568f3..4dcf6f93099 100644 --- a/lib/optee/optee.c +++ b/lib/optee/optee.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <fdtdec.h> #include <image.h> #include <log.h> #include <malloc.h> diff --git a/lib/time.c b/lib/time.c index 88bc50405ff..2a0246ade11 100644 --- a/lib/time.c +++ b/lib/time.c @@ -13,6 +13,7 @@ #include <timer.h> #include <watchdog.h> #include <div64.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/lib/trace.c b/lib/trace.c index defc9716d80..9e34b195375 100644 --- a/lib/trace.c +++ b/lib/trace.c @@ -7,6 +7,7 @@ #include <mapmem.h> #include <time.h> #include <trace.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/sections.h>
diff --git a/lib/zlib/zlib.c b/lib/zlib/zlib.c index 90e05e7d4d9..85193d1aa34 100644 --- a/lib/zlib/zlib.c +++ b/lib/zlib/zlib.c @@ -13,6 +13,7 @@ */
#include <common.h> +#include <compiler.h>
#ifdef CONFIG_GZIP_COMPRESSED #define NO_DUMMY_DECL diff --git a/net/eth-uclass.c b/net/eth-uclass.c index e14695c0f16..2ba348876a2 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -11,6 +11,7 @@ #include <env.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> #include <net/pcap.h> diff --git a/net/eth_legacy.c b/net/eth_legacy.c index 6e0c0587616..1f86f89b8f5 100644 --- a/net/eth_legacy.c +++ b/net/eth_legacy.c @@ -13,6 +13,7 @@ #include <log.h> #include <net.h> #include <phy.h> +#include <asm/global_data.h> #include <linux/bug.h> #include <linux/errno.h> #include <net/pcap.h> diff --git a/net/tftp.c b/net/tftp.c index 6fdb1a821a8..ecbb64122f5 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -14,6 +14,7 @@ #include <log.h> #include <mapmem.h> #include <net.h> +#include <asm/global_data.h> #include <net/tftp.h> #include "bootp.h" #ifdef CONFIG_SYS_DIRECT_FLASH_TFTP diff --git a/post/drivers/memory.c b/post/drivers/memory.c index e90ada3ce85..281989da6fa 100644 --- a/post/drivers/memory.c +++ b/post/drivers/memory.c @@ -6,6 +6,7 @@
/* Memory test * diff --git a/post/post.c b/post/post.c index 0f1fe8d9057..c0b466ffef7 100644 --- a/post/post.c +++ b/post/post.c @@ -14,6 +14,7 @@ #include <watchdog.h> #include <div64.h> #include <post.h> +#include <asm/global_data.h>
#ifdef CONFIG_SYS_POST_HOTKEYS_GPIO #include <asm/gpio.h> diff --git a/test/bloblist.c b/test/bloblist.c index 0bb9e2d81e7..799e822224f 100644 --- a/test/bloblist.c +++ b/test/bloblist.c @@ -7,6 +7,7 @@ #include <bloblist.h> #include <log.h> #include <mapmem.h> +#include <asm/global_data.h> #include <asm/state.h> #include <test/suites.h> #include <test/test.h> diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 1f252a8d454..eaa10015b0b 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -17,6 +17,7 @@ #include <acpi/acpigen.h> #include <acpi/acpi_device.h> #include <acpi/acpi_table.h> +#include <asm/global_data.h> #include <dm/acpi.h> #include <dm/test.h> #include <test/ut.h> diff --git a/test/dm/blk.c b/test/dm/blk.c index f34c13f7511..4eef4048de4 100644 --- a/test/dm/blk.c +++ b/test/dm/blk.c @@ -7,6 +7,7 @@ #include <dm.h> #include <part.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/state.h> #include <dm/test.h> #include <test/test.h> diff --git a/test/dm/bus.c b/test/dm/bus.c index 27b72666457..9cab1d769f3 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -9,6 +9,7 @@ #include <os.h> #endif #include <dm.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/device-internal.h> #include <dm/test.h> diff --git a/test/dm/core.c b/test/dm/core.c index 6f380a574cf..4dac4cd103b 100644 --- a/test/dm/core.c +++ b/test/dm/core.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/root.h> #include <dm/util.h> diff --git a/test/dm/fdtdec.c b/test/dm/fdtdec.c index 017157a2ecd..1f630ea3eee 100644 --- a/test/dm/fdtdec.c +++ b/test/dm/fdtdec.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/of_extra.h> #include <dm/test.h> #include <test/ut.h> diff --git a/test/dm/mux-emul.c b/test/dm/mux-emul.c index 141fd4d9083..0bc8ef07697 100644 --- a/test/dm/mux-emul.c +++ b/test/dm/mux-emul.c @@ -7,6 +7,7 @@ #include <dm.h> #include <mux.h> #include <mux-internal.h> +#include <asm/global_data.h> #include <dm/test.h> #include <test/ut.h>
diff --git a/test/dm/ram.c b/test/dm/ram.c index f01236c8cd5..f624343138d 100644 --- a/test/dm/ram.c +++ b/test/dm/ram.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <ram.h> +#include <asm/global_data.h> #include <dm/test.h> #include <test/test.h> #include <test/ut.h> diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index cc12419ea0f..7c4ffea58d9 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -9,6 +9,7 @@ #include <fdtdec.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/test.h> #include <dm/root.h> diff --git a/test/dm/test-main.c b/test/dm/test-main.c index 38b7b1481a7..8dc59fc636f 100644 --- a/test/dm/test-main.c +++ b/test/dm/test-main.c @@ -10,6 +10,7 @@ #include <errno.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/state.h> #include <dm/test.h> #include <dm/root.h> diff --git a/test/lib/test_print.c b/test/lib/test_print.c index 1d497d00413..12972f1bcd6 100644 --- a/test/lib/test_print.c +++ b/test/lib/test_print.c @@ -8,6 +8,7 @@ #include <common.h> #include <command.h> #include <display_options.h> +#include <asm/global_data.h> #include <test/lib.h> #include <test/test.h> #include <test/ut.h> diff --git a/test/log/cont_test.c b/test/log/cont_test.c index 68ca1d262c4..16379a74be6 100644 --- a/test/log/cont_test.c +++ b/test/log/cont_test.c @@ -7,6 +7,7 @@
#include <common.h> #include <console.h> +#include <asm/global_data.h> #include <test/log.h> #include <test/test.h> #include <test/suites.h> diff --git a/test/log/nolog_test.c b/test/log/nolog_test.c index c418ed07c9a..cb4fb3db9a2 100644 --- a/test/log/nolog_test.c +++ b/test/log/nolog_test.c @@ -10,6 +10,7 @@
#include <common.h> #include <console.h> +#include <asm/global_data.h> #include <test/log.h> #include <test/test.h> #include <test/suites.h> diff --git a/test/log/syslog_test.c b/test/log/syslog_test.c index a058d8f5695..4db649db822 100644 --- a/test/log/syslog_test.c +++ b/test/log/syslog_test.c @@ -11,6 +11,7 @@ #define LOG_DEBUG
#include <common.h> +#include <asm/global_data.h> #include <dm/device.h> #include <hexdump.h> #include <test/log.h> diff --git a/test/log/syslog_test_ndebug.c b/test/log/syslog_test_ndebug.c index 84844a39440..4438791044d 100644 --- a/test/log/syslog_test_ndebug.c +++ b/test/log/syslog_test_ndebug.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <dm/device.h> #include <hexdump.h> #include <test/log.h> diff --git a/test/ut.c b/test/ut.c index 95bdd66de6a..556e9694ee1 100644 --- a/test/ut.c +++ b/test/ut.c @@ -8,6 +8,7 @@ #include <common.h> #include <console.h> #include <malloc.h> +#include <asm/global_data.h> #include <test/test.h> #include <test/ut.h>
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include.
Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Tom Rini trini@konsulko.com --- arch/arc/lib/bootm.c | 1 + arch/arc/lib/cache.c | 1 + arch/arc/lib/cpu.c | 1 + arch/arc/lib/relocate.c | 1 + arch/arm/cpu/arm1136/mx35/generic.c | 1 + arch/arm/cpu/arm926ejs/armada100/dram.c | 1 + arch/arm/cpu/arm926ejs/armada100/timer.c | 1 + arch/arm/cpu/arm926ejs/mx25/generic.c | 1 + arch/arm/cpu/arm926ejs/mx27/timer.c | 1 + arch/arm/cpu/arm926ejs/mxs/mxs.c | 1 + arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 1 + arch/arm/cpu/arm926ejs/mxs/timer.c | 1 + arch/arm/cpu/arm926ejs/spear/spr_misc.c | 1 + arch/arm/cpu/arm926ejs/spear/timer.c | 1 + arch/arm/cpu/armv7/arch_timer.c | 1 + arch/arm/cpu/armv7/ls102xa/clock.c | 1 + arch/arm/cpu/armv7/ls102xa/cpu.c | 1 + arch/arm/cpu/armv7/ls102xa/fdt.c | 1 + arch/arm/cpu/armv7/ls102xa/timer.c | 1 + arch/arm/cpu/armv7/s5p-common/cpu_info.c | 1 + arch/arm/cpu/armv7/s5p-common/timer.c | 1 + arch/arm/cpu/armv7/s5p4418/cpu.c | 1 + arch/arm/cpu/armv7/stv0991/timer.c | 1 + arch/arm/cpu/armv7/sunxi/timer.c | 1 + arch/arm/cpu/armv7/vf610/generic.c | 1 + arch/arm/cpu/armv7/vf610/timer.c | 1 + arch/arm/cpu/armv7/virt-dt.c | 1 - arch/arm/cpu/armv7m/systick-timer.c | 1 + arch/arm/cpu/armv8/cache_v8.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/mp.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/ppa.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/spl.c | 1 + arch/arm/cpu/armv8/generic_timer.c | 1 + arch/arm/cpu/armv8/s32v234/generic.c | 1 + arch/arm/cpu/armv8/sec_firmware.c | 1 + arch/arm/include/asm/arch-rockchip/clock.h | 2 ++ arch/arm/include/asm/arch-tegra/clock.h | 2 ++ arch/arm/include/asm/arch-tegra/tegra_i2c.h | 2 ++ arch/arm/include/asm/global_data.h | 3 +++ arch/arm/include/asm/secure.h | 1 + arch/arm/include/asm/ti-common/sys_proto.h | 2 ++ arch/arm/lib/bdinfo.c | 1 + arch/arm/lib/bootm-fdt.c | 1 + arch/arm/lib/bootm.c | 1 + arch/arm/lib/cache-cp15.c | 1 + arch/arm/lib/cache.c | 1 + arch/arm/lib/image.c | 1 + arch/arm/lib/interrupts.c | 1 + arch/arm/lib/interrupts_64.c | 1 + arch/arm/lib/spl.c | 1 + arch/arm/lib/stack.c | 1 + arch/arm/mach-aspeed/ast2500/board_common.c | 1 + arch/arm/mach-aspeed/ast2600/board_common.c | 1 + arch/arm/mach-aspeed/ast2600/spl.c | 1 + arch/arm/mach-at91/arm920t/clock.c | 1 + arch/arm/mach-at91/arm920t/timer.c | 1 + arch/arm/mach-at91/arm926ejs/clock.c | 1 + arch/arm/mach-at91/arm926ejs/timer.c | 1 + arch/arm/mach-at91/armv7/clock.c | 1 + arch/arm/mach-at91/armv7/timer.c | 1 + arch/arm/mach-at91/spl_at91.c | 1 + arch/arm/mach-bcm283x/init.c | 1 + arch/arm/mach-davinci/cpu.c | 1 + arch/arm/mach-davinci/misc.c | 1 + arch/arm/mach-davinci/timer.c | 1 + arch/arm/mach-exynos/spl_boot.c | 1 + arch/arm/mach-imx/imx8/ahab.c | 1 + arch/arm/mach-imx/imx8/clock.c | 1 + arch/arm/mach-imx/imx8/cpu.c | 1 + arch/arm/mach-imx/imx8/fdt.c | 1 + arch/arm/mach-imx/imx8/iomux.c | 1 + arch/arm/mach-imx/imx8/snvs_security_sc.c | 1 + arch/arm/mach-imx/imx8m/clock_imx8mm.c | 1 + arch/arm/mach-imx/imx8m/soc.c | 1 + arch/arm/mach-imx/misc.c | 1 + arch/arm/mach-imx/mx5/mx53_dram.c | 1 + arch/arm/mach-imx/mx6/litesom.c | 1 + arch/arm/mach-imx/mx6/opos6ul.c | 1 + arch/arm/mach-imx/mx7/clock.c | 1 + arch/arm/mach-imx/mx7ulp/clock.c | 1 + arch/arm/mach-imx/speed.c | 1 + arch/arm/mach-imx/spl.c | 1 + arch/arm/mach-imx/spl_imx_romapi.c | 1 + arch/arm/mach-imx/syscounter.c | 1 + arch/arm/mach-imx/timer.c | 1 + arch/arm/mach-k3/am6_init.c | 1 + arch/arm/mach-k3/common.c | 1 + arch/arm/mach-k3/sysfw-loader.c | 1 + arch/arm/mach-mediatek/mt7623/init.c | 1 + arch/arm/mach-mediatek/mt7629/init.c | 1 + arch/arm/mach-mediatek/mt8512/init.c | 1 + arch/arm/mach-mediatek/mt8516/init.c | 1 + arch/arm/mach-mediatek/mt8518/init.c | 1 + arch/arm/mach-meson/board-axg.c | 1 + arch/arm/mach-meson/board-common.c | 1 + arch/arm/mach-meson/board-g12a.c | 1 + arch/arm/mach-meson/board-gx.c | 1 + arch/arm/mach-meson/board-info.c | 1 + arch/arm/mach-meson/sm.c | 1 + arch/arm/mach-mvebu/arm64-common.c | 1 + arch/arm/mach-mvebu/armada3700/cpu.c | 1 + arch/arm/mach-mvebu/armada8k/dram.c | 1 + arch/arm/mach-mvebu/dram.c | 1 + arch/arm/mach-mvebu/spl.c | 1 + arch/arm/mach-nexell/cmd_boot_linux.c | 1 + arch/arm/mach-octeontx/cpu.c | 1 + arch/arm/mach-octeontx2/cpu.c | 1 + arch/arm/mach-omap2/am33xx/board.c | 1 + arch/arm/mach-omap2/boot-common.c | 1 + arch/arm/mach-omap2/hwinit-common.c | 1 + arch/arm/mach-omap2/omap-cache.c | 1 + arch/arm/mach-omap2/omap3/am35x_musb.c | 1 + arch/arm/mach-omap2/omap3/emif4.c | 1 + arch/arm/mach-omap2/omap3/sdrc.c | 1 + arch/arm/mach-omap2/timer.c | 1 + arch/arm/mach-orion5x/dram.c | 1 + arch/arm/mach-orion5x/timer.c | 1 + arch/arm/mach-owl/soc.c | 1 + arch/arm/mach-rmobile/memmap-gen3.c | 1 + arch/arm/mach-rockchip/board.c | 1 + arch/arm/mach-rockchip/rk3036/rk3036.c | 1 + arch/arm/mach-rockchip/rk3128/rk3128.c | 1 + arch/arm/mach-rockchip/rk3188/rk3188.c | 1 + arch/arm/mach-rockchip/rk3288/rk3288.c | 1 + arch/arm/mach-rockchip/rk3308/rk3308.c | 1 + arch/arm/mach-rockchip/rk3328/rk3328.c | 1 + arch/arm/mach-rockchip/rk3368/rk3368.c | 1 + arch/arm/mach-rockchip/rk3399/rk3399.c | 1 + arch/arm/mach-rockchip/sdram.c | 1 + arch/arm/mach-rockchip/spl-boot-order.c | 1 + arch/arm/mach-rockchip/spl.c | 1 + arch/arm/mach-snapdragon/pinctrl-snapdragon.h | 2 +- arch/arm/mach-socfpga/board.c | 1 + arch/arm/mach-socfpga/clock_manager.c | 1 + arch/arm/mach-socfpga/clock_manager_agilex.c | 1 + arch/arm/mach-socfpga/clock_manager_s10.c | 1 + arch/arm/mach-socfpga/mailbox_s10.c | 1 + arch/arm/mach-socfpga/misc.c | 1 + arch/arm/mach-socfpga/misc_gen5.c | 1 + arch/arm/mach-socfpga/misc_s10.c | 1 + arch/arm/mach-socfpga/mmu-arm64_s10.c | 1 + arch/arm/mach-socfpga/reset_manager_arria10.c | 1 + arch/arm/mach-socfpga/reset_manager_s10.c | 1 + arch/arm/mach-socfpga/spl_a10.c | 1 + arch/arm/mach-socfpga/spl_agilex.c | 1 + arch/arm/mach-socfpga/spl_gen5.c | 1 + arch/arm/mach-socfpga/spl_s10.c | 1 + arch/arm/mach-socfpga/system_manager_s10.c | 1 + arch/arm/mach-stm32mp/boot_params.c | 1 + arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c | 1 + arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c | 1 + arch/arm/mach-stm32mp/cpu.c | 1 + arch/arm/mach-stm32mp/dram_init.c | 1 + arch/arm/mach-stm32mp/fdt.c | 1 + arch/arm/mach-stm32mp/spl.c | 1 + arch/arm/mach-tegra/board.c | 1 + arch/arm/mach-tegra/board2.c | 1 + arch/arm/mach-tegra/cboot.c | 1 + arch/arm/mach-tegra/emc.c | 1 + arch/arm/mach-tegra/pmc.c | 1 + arch/arm/mach-tegra/tegra124/xusb-padctl.c | 1 + arch/arm/mach-tegra/tegra20/warmboot.c | 1 + arch/arm/mach-tegra/tegra210/xusb-padctl.c | 1 + arch/arm/mach-uniphier/board_late_init.c | 1 + arch/arm/mach-versal/clk.c | 1 + arch/arm/mach-versal/cpu.c | 1 + arch/arm/mach-versal/mp.c | 1 + arch/arm/mach-zynq/clk.c | 1 + arch/arm/mach-zynq/timer.c | 1 + arch/arm/mach-zynqmp-r5/cpu.c | 1 + arch/arm/mach-zynqmp/clk.c | 1 + arch/arm/mach-zynqmp/cpu.c | 1 + arch/m68k/cpu/mcf5227x/cpu.c | 1 + arch/m68k/cpu/mcf5227x/speed.c | 1 + arch/m68k/cpu/mcf523x/cpu.c | 1 + arch/m68k/cpu/mcf523x/speed.c | 1 + arch/m68k/cpu/mcf52x2/cpu.c | 1 + arch/m68k/cpu/mcf52x2/speed.c | 1 + arch/m68k/cpu/mcf530x/speed.c | 1 + arch/m68k/cpu/mcf532x/cpu.c | 1 + arch/m68k/cpu/mcf532x/speed.c | 1 + arch/m68k/cpu/mcf5445x/cpu.c | 1 + arch/m68k/cpu/mcf5445x/speed.c | 1 + arch/m68k/cpu/mcf547x_8x/cpu.c | 1 + arch/m68k/cpu/mcf547x_8x/slicetimer.c | 1 + arch/m68k/cpu/mcf547x_8x/speed.c | 1 + arch/m68k/lib/bdinfo.c | 1 + arch/m68k/lib/bootm.c | 1 + arch/m68k/lib/fec.c | 1 + arch/m68k/lib/time.c | 1 + arch/microblaze/cpu/interrupts.c | 1 + arch/microblaze/cpu/timer.c | 1 + arch/microblaze/lib/bootm.c | 1 + arch/mips/include/asm/io.h | 1 + arch/mips/lib/boot.c | 1 + arch/mips/lib/bootm.c | 1 + arch/mips/lib/cache.c | 1 + arch/mips/lib/stack.c | 1 + arch/mips/lib/traps.c | 1 + arch/mips/mach-ath79/ar933x/clk.c | 1 + arch/mips/mach-ath79/ar934x/clk.c | 1 + arch/mips/mach-ath79/ar934x/ddr.c | 1 + arch/mips/mach-ath79/cpu.c | 1 + arch/mips/mach-ath79/dram.c | 1 + arch/mips/mach-ath79/include/mach/ath79.h | 1 + arch/mips/mach-ath79/qca953x/clk.c | 1 + arch/mips/mach-ath79/qca956x/clk.c | 1 + arch/mips/mach-ath79/qca956x/ddr.c | 1 + arch/mips/mach-bmips/dram.c | 1 + arch/mips/mach-jz47xx/jz4780/jz4780.c | 1 + arch/mips/mach-mscc/cpu.c | 1 + arch/mips/mach-mscc/dram.c | 1 + arch/mips/mach-mtmips/cpu.c | 1 + arch/mips/mach-mtmips/ddr_cal.c | 1 + arch/mips/mach-mtmips/mt7628/ddr.c | 1 + arch/mips/mach-mtmips/mt7628/init.c | 1 + arch/mips/mach-mtmips/spl.c | 2 +- arch/mips/mach-octeon/bootoctlinux.c | 1 + arch/mips/mach-pic32/cpu.c | 1 + arch/nds32/lib/bootm.c | 1 + arch/nios2/cpu/cpu.c | 1 + arch/nios2/include/asm/io.h | 3 +++ arch/nios2/lib/cache.c | 1 + arch/powerpc/cpu/mpc83xx/cpu.c | 1 + arch/powerpc/cpu/mpc83xx/cpu_init.c | 1 + arch/powerpc/cpu/mpc83xx/fdt.c | 1 + arch/powerpc/cpu/mpc83xx/interrupts.c | 1 + arch/powerpc/cpu/mpc83xx/pci.c | 1 + arch/powerpc/cpu/mpc83xx/pcie.c | 1 + arch/powerpc/cpu/mpc83xx/spd_sdram.c | 1 + arch/powerpc/cpu/mpc83xx/speed.c | 1 + arch/powerpc/cpu/mpc83xx/spl_minimal.c | 1 + arch/powerpc/cpu/mpc83xx/traps.c | 1 + arch/powerpc/cpu/mpc85xx/commproc.c | 1 + arch/powerpc/cpu/mpc85xx/cpu.c | 1 + arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 1 + arch/powerpc/cpu/mpc85xx/fdt.c | 1 + arch/powerpc/cpu/mpc85xx/mp.c | 1 + arch/powerpc/cpu/mpc85xx/serial_scc.c | 1 + arch/powerpc/cpu/mpc85xx/speed.c | 1 + arch/powerpc/cpu/mpc85xx/tlb.c | 1 + arch/powerpc/cpu/mpc85xx/traps.c | 1 + arch/powerpc/cpu/mpc86xx/cpu.c | 1 + arch/powerpc/cpu/mpc86xx/cpu_init.c | 1 + arch/powerpc/cpu/mpc86xx/fdt.c | 1 + arch/powerpc/cpu/mpc86xx/mp.c | 1 + arch/powerpc/cpu/mpc86xx/speed.c | 1 + arch/powerpc/cpu/mpc86xx/traps.c | 1 + arch/powerpc/cpu/mpc8xx/cpu.c | 1 + arch/powerpc/cpu/mpc8xx/fdt.c | 1 + arch/powerpc/cpu/mpc8xx/immap.c | 1 + arch/powerpc/cpu/mpc8xx/speed.c | 1 + arch/powerpc/cpu/mpc8xxx/cpu.c | 1 + arch/powerpc/cpu/mpc8xxx/law.c | 1 + arch/powerpc/cpu/mpc8xxx/pamu_table.c | 1 + arch/powerpc/lib/bat_rw.c | 1 + arch/powerpc/lib/bdinfo.c | 1 + arch/powerpc/lib/bootm.c | 1 + arch/powerpc/lib/stack.c | 1 + arch/powerpc/lib/traps.c | 2 +- arch/riscv/cpu/fu540/cache.c | 1 + arch/riscv/cpu/fu540/dram.c | 1 + arch/riscv/cpu/generic/dram.c | 1 + arch/riscv/lib/andes_plic.c | 1 + arch/riscv/lib/asm-offsets.c | 1 + arch/riscv/lib/bootm.c | 1 + arch/riscv/lib/fdt_fixup.c | 1 + arch/riscv/lib/image.c | 1 + arch/riscv/lib/interrupts.c | 1 + arch/riscv/lib/sifive_clint.c | 1 + arch/riscv/lib/smp.c | 1 + arch/riscv/lib/spl.c | 1 + arch/sandbox/cpu/cpu.c | 1 + arch/sandbox/cpu/spl.c | 1 + arch/sandbox/cpu/start.c | 1 + arch/sandbox/lib/interrupts.c | 1 + arch/sh/lib/board.c | 1 + arch/x86/cpu/apollolake/cpu.c | 1 + arch/x86/cpu/apollolake/cpu_spl.c | 1 + arch/x86/cpu/apollolake/fsp_s.c | 1 + arch/x86/cpu/baytrail/fsp_configs.c | 1 + arch/x86/cpu/braswell/fsp_configs.c | 1 + arch/x86/cpu/broadwell/cpu.c | 1 + arch/x86/cpu/broadwell/cpu_from_spl.c | 1 + arch/x86/cpu/broadwell/cpu_full.c | 1 + arch/x86/cpu/broadwell/lpc.c | 1 + arch/x86/cpu/broadwell/northbridge.c | 1 + arch/x86/cpu/broadwell/pch.c | 1 + arch/x86/cpu/broadwell/pinctrl_broadwell.c | 1 + arch/x86/cpu/broadwell/sata.c | 1 + arch/x86/cpu/broadwell/sdram.c | 1 + arch/x86/cpu/call32.S | 1 - arch/x86/cpu/coreboot/coreboot.c | 1 + arch/x86/cpu/coreboot/sdram.c | 1 + arch/x86/cpu/coreboot/tables.c | 1 + arch/x86/cpu/cpu.c | 1 + arch/x86/cpu/cpu_x86.c | 1 + arch/x86/cpu/efi/payload.c | 1 + arch/x86/cpu/efi/sdram.c | 1 + arch/x86/cpu/i386/call64.S | 1 - arch/x86/cpu/i386/cpu.c | 1 + arch/x86/cpu/i386/interrupt.c | 1 + arch/x86/cpu/intel_common/acpi.c | 1 + arch/x86/cpu/intel_common/cpu.c | 1 + arch/x86/cpu/intel_common/cpu_from_spl.c | 1 + arch/x86/cpu/intel_common/itss.c | 1 + arch/x86/cpu/intel_common/lpc.c | 1 + arch/x86/cpu/intel_common/microcode.c | 1 + arch/x86/cpu/intel_common/mrc.c | 1 + arch/x86/cpu/irq.c | 1 + arch/x86/cpu/ivybridge/bd82x6x.c | 1 + arch/x86/cpu/ivybridge/cpu.c | 1 + arch/x86/cpu/ivybridge/fsp_configs.c | 1 + arch/x86/cpu/ivybridge/lpc.c | 1 + arch/x86/cpu/ivybridge/model_206ax.c | 1 + arch/x86/cpu/ivybridge/northbridge.c | 1 + arch/x86/cpu/ivybridge/sata.c | 1 + arch/x86/cpu/ivybridge/sdram_nop.c | 1 + arch/x86/cpu/mp_init.c | 1 + arch/x86/cpu/mtrr.c | 1 + arch/x86/cpu/qemu/dram.c | 1 + arch/x86/cpu/qemu/e820.c | 1 + arch/x86/cpu/quark/acpi.c | 1 + arch/x86/cpu/quark/dram.c | 1 + arch/x86/cpu/sipi_vector.S | 1 - arch/x86/cpu/slimbootloader/sdram.c | 1 + arch/x86/cpu/slimbootloader/serial.c | 1 + arch/x86/cpu/slimbootloader/slimbootloader.c | 1 + arch/x86/cpu/start.S | 1 - arch/x86/cpu/start16.S | 1 - arch/x86/cpu/turbo.c | 1 + arch/x86/include/asm/acpi_table.h | 2 ++ arch/x86/include/asm/arch-apollolake/systemagent.h | 3 +++ arch/x86/include/asm/cpu_common.h | 1 + arch/x86/include/asm/fast_spi.h | 4 +++- arch/x86/include/asm/io.h | 2 +- arch/x86/include/asm/mp.h | 2 ++ arch/x86/include/asm/mrccache.h | 2 ++ arch/x86/lib/acpi_s3.c | 1 + arch/x86/lib/acpi_table.c | 1 + arch/x86/lib/asm-offsets.c | 1 + arch/x86/lib/bios.c | 1 + arch/x86/lib/bootm.c | 1 + arch/x86/lib/cmd_boot.c | 1 + arch/x86/lib/coreboot_table.c | 1 + arch/x86/lib/e820.c | 1 + arch/x86/lib/fsp/fsp_common.c | 1 + arch/x86/lib/fsp/fsp_dram.c | 1 + arch/x86/lib/fsp/fsp_graphics.c | 1 + arch/x86/lib/fsp1/fsp_common.c | 1 + arch/x86/lib/fsp1/fsp_dram.c | 1 + arch/x86/lib/fsp2/fsp_dram.c | 1 + arch/x86/lib/fsp2/fsp_meminit.c | 1 + arch/x86/lib/fsp2/fsp_silicon_init.c | 1 + arch/x86/lib/fsp2/fsp_support.c | 1 + arch/x86/lib/init_helpers.c | 1 + arch/x86/lib/mpspec.c | 1 + arch/x86/lib/mrccache.c | 1 + arch/x86/lib/physmem.c | 1 + arch/x86/lib/pinctrl_ich6.c | 1 + arch/x86/lib/pirq_routing.c | 1 + arch/x86/lib/relocate.c | 1 + arch/x86/lib/spl.c | 1 + arch/x86/lib/tables.c | 1 + arch/x86/lib/tpl.c | 1 + arch/xtensa/lib/bootm.c | 1 + board/AndesTech/adp-ae3xx/adp-ae3xx.c | 1 + board/AndesTech/adp-ag101p/adp-ag101p.c | 1 + board/AndesTech/ax25-ae350/ax25-ae350.c | 1 + board/Arcturus/ucp1020/spl.c | 1 + board/BuR/brppt1/board.c | 1 + board/BuR/brppt2/board.c | 1 + board/BuR/brsmarc1/board.c | 1 + board/BuR/brxre1/board.c | 1 + board/BuR/common/common.c | 1 + board/BuS/eb_cpu5282/eb_cpu5282.c | 1 + board/CZ.NIC/turris_mox/turris_mox.c | 1 + board/CZ.NIC/turris_omnia/turris_omnia.c | 1 + board/CarMediaLab/flea3/flea3.c | 1 + board/LaCie/edminiv2/edminiv2.c | 1 + board/LaCie/net2big_v2/net2big_v2.c | 1 + board/LaCie/netspace_v2/netspace_v2.c | 1 + board/Marvell/aspenite/aspenite.c | 1 + board/Marvell/db-88f6281-bp/db-88f6281-bp.c | 1 + board/Marvell/db-88f6720/db-88f6720.c | 1 + board/Marvell/db-88f6820-amc/db-88f6820-amc.c | 1 + board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 1 + board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c | 1 + board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c | 1 + board/Marvell/dreamplug/dreamplug.c | 1 + board/Marvell/gplugd/gplugd.c | 1 + board/Marvell/guruplug/guruplug.c | 1 + board/Marvell/mvebu_armada-37xx/board.c | 1 + board/Marvell/mvebu_armada-8k/board.c | 1 + board/Marvell/octeontx/board.c | 1 + board/Marvell/octeontx2/board.c | 1 + board/Marvell/openrd/openrd.c | 1 + board/Marvell/sheevaplug/sheevaplug.c | 1 + board/Seagate/dockstar/dockstar.c | 1 + board/Seagate/goflexhome/goflexhome.c | 1 + board/Seagate/nas220/nas220.c | 1 + board/Synology/ds109/ds109.c | 1 + board/Synology/ds414/ds414.c | 1 + board/advantech/dms-ba16/dms-ba16.c | 1 + board/advantech/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c | 1 + board/advantech/imx8qm_rom7720_a1/spl.c | 1 + board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c | 1 + board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c | 1 + board/alliedtelesis/common/gpio_hog.c | 1 + board/alliedtelesis/x530/x530.c | 1 + board/amazon/kc1/kc1.c | 1 + board/amlogic/vim3/vim3.c | 1 + board/aristainetos/aristainetos.c | 1 + board/armadeus/apf27/apf27.c | 1 + board/armltd/integrator/integrator.c | 1 + board/armltd/total_compute/total_compute.c | 1 + board/armltd/vexpress/vexpress_common.c | 1 + board/armltd/vexpress64/vexpress64.c | 1 + board/astro/mcf5373l/mcf5373l.c | 1 + board/atmark-techno/armadillo-800eva/armadillo-800eva.c | 1 + board/atmel/at91rm9200ek/at91rm9200ek.c | 1 + board/atmel/at91sam9260ek/at91sam9260ek.c | 1 + board/atmel/at91sam9261ek/at91sam9261ek.c | 1 + board/atmel/at91sam9263ek/at91sam9263ek.c | 1 + board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 1 + board/atmel/at91sam9n12ek/at91sam9n12ek.c | 1 + board/atmel/at91sam9rlek/at91sam9rlek.c | 1 + board/atmel/at91sam9x5ek/at91sam9x5ek.c | 1 + board/atmel/common/video_display.c | 1 + board/atmel/sam9x60ek/sam9x60ek.c | 1 + board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 1 + board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 1 + board/atmel/sama5d2_icp/sama5d2_icp.c | 1 + board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c | 1 + board/atmel/sama5d2_xplained/sama5d2_xplained.c | 1 + board/atmel/sama5d3_xplained/sama5d3_xplained.c | 1 + board/atmel/sama5d3xek/sama5d3xek.c | 1 + board/atmel/sama5d4_xplained/sama5d4_xplained.c | 1 + board/atmel/sama5d4ek/sama5d4ek.c | 1 + board/atmel/sama7g5ek/sama7g5ek.c | 1 + board/bachmann/ot1200/ot1200.c | 1 + board/barco/platinum/platinum.c | 1 + board/barco/titanium/titanium.c | 1 + board/beacon/beacon-rzg2m/beacon-rzg2m.c | 1 + board/beacon/imx8mm/imx8mm_beacon.c | 1 + board/beacon/imx8mm/spl.c | 1 + board/beacon/imx8mn/imx8mn_beacon.c | 1 + board/beacon/imx8mn/spl.c | 1 + board/beckhoff/mx53cx9020/mx53cx9020.c | 1 + board/bluegiga/apx4devkit/apx4devkit.c | 1 + board/bluewater/gurnard/gurnard.c | 1 + board/bluewater/snapper9260/snapper9260.c | 1 + board/bosch/guardian/board.c | 1 + board/bosch/shc/board.c | 1 + board/boundary/nitrogen6x/nitrogen6x.c | 1 + board/broadcom/bcm23550_w1d/bcm23550_w1d.c | 1 + board/broadcom/bcm28155_ap/bcm28155_ap.c | 1 + board/broadcom/bcm_ep/board.c | 1 + board/broadcom/bcmns2/northstar2.c | 1 + board/broadcom/bcmns3/ns3.c | 1 + board/broadcom/bcmstb/bcmstb.c | 1 + board/bticino/mamoj/mamoj.c | 1 + board/bticino/mamoj/spl.c | 1 + board/buffalo/lsxl/lsxl.c | 1 + board/calao/usb_a9263/usb_a9263.c | 1 + board/cavium/thunderx/thunderx.c | 1 + board/ccv/xpress/xpress.c | 1 + board/cirrus/edb93xx/edb93xx.c | 1 + board/cloudengines/pogo_e02/pogo_e02.c | 1 + board/cobra5272/cobra5272.c | 1 + board/compulab/cl-som-imx7/cl-som-imx7.c | 1 + board/compulab/cm_fx6/cm_fx6.c | 1 + board/compulab/cm_t335/cm_t335.c | 1 + board/compulab/cm_t43/cm_t43.c | 1 + board/congatec/cgtqmx6eval/cgtqmx6eval.c | 1 + board/coreboot/coreboot/coreboot.c | 1 + board/corscience/tricorder/tricorder.c | 1 + board/cortina/presidio-asic/presidio.c | 1 + board/creative/xfi3/xfi3.c | 1 + board/cssi/MCR3000/MCR3000.c | 1 + board/d-link/dns325/dns325.c | 1 + board/davinci/da8xxevm/da850evm.c | 1 + board/davinci/da8xxevm/omapl138_lcdk.c | 1 + board/dhelectronics/dh_imx6/dh_imx6.c | 1 + board/dhelectronics/dh_stm32mp1/board.c | 1 + board/ea/mx7ulp_com/mx7ulp_com.c | 1 + board/eets/pdu001/board.c | 1 + board/egnite/ethernut5/ethernut5.c | 1 + board/el/el6x/el6x.c | 1 + board/elgin/elgin_rv1108/elgin_rv1108.c | 1 + board/embest/mx6boards/mx6boards.c | 1 + board/emulation/common/qemu_capsule.c | 1 + board/engicam/common/board.c | 1 + board/esd/meesc/meesc.c | 1 + board/esd/vme8349/vme8349.c | 1 + board/firefly/firefly-rk3288/firefly-rk3288.c | 1 + board/freescale/common/arm_sleep.c | 1 + board/freescale/common/emc2305.c | 1 + board/freescale/common/mpc85xx_sleep.c | 1 + board/freescale/corenet_ds/corenet_ds.c | 1 + board/freescale/corenet_ds/ddr.c | 1 + board/freescale/imx8mm_evk/imx8mm_evk.c | 1 + board/freescale/imx8mm_evk/spl.c | 1 + board/freescale/imx8mn_evk/imx8mn_evk.c | 1 + board/freescale/imx8mn_evk/spl.c | 1 + board/freescale/imx8mp_evk/imx8mp_evk.c | 1 + board/freescale/imx8mp_evk/spl.c | 1 + board/freescale/imx8mq_evk/imx8mq_evk.c | 1 + board/freescale/imx8mq_evk/spl.c | 1 + board/freescale/imx8qm_mek/imx8qm_mek.c | 1 + board/freescale/imx8qm_mek/spl.c | 1 + board/freescale/imx8qxp_mek/imx8qxp_mek.c | 1 + board/freescale/imx8qxp_mek/spl.c | 1 + board/freescale/imxrt1020-evk/imxrt1020-evk.c | 1 + board/freescale/imxrt1050-evk/imxrt1050-evk.c | 1 + board/freescale/ls1012afrdm/ls1012afrdm.c | 1 + board/freescale/ls1012aqds/ls1012aqds.c | 1 + board/freescale/ls1012ardb/ls1012ardb.c | 1 + board/freescale/ls1021aiot/dcu.c | 1 + board/freescale/ls1021aiot/ls1021aiot.c | 1 + board/freescale/ls1021aqds/dcu.c | 1 + board/freescale/ls1021aqds/ddr.c | 1 + board/freescale/ls1021atsn/ls1021atsn.c | 1 + board/freescale/ls1021atwr/dcu.c | 1 + board/freescale/ls1021atwr/ls1021atwr.c | 1 + board/freescale/ls1028a/ddr.c | 1 + board/freescale/ls1028a/ls1028a.c | 1 + board/freescale/ls1043aqds/ddr.c | 1 + board/freescale/ls1043aqds/ls1043aqds.c | 1 + board/freescale/ls1043ardb/ddr.c | 1 + board/freescale/ls1043ardb/ls1043ardb.c | 1 + board/freescale/ls1046afrwy/ddr.c | 1 + board/freescale/ls1046afrwy/ls1046afrwy.c | 1 + board/freescale/ls1046aqds/ddr.c | 1 + board/freescale/ls1046aqds/ls1046aqds.c | 1 + board/freescale/ls1046ardb/ddr.c | 1 + board/freescale/ls1046ardb/ls1046ardb.c | 1 + board/freescale/ls1088a/ddr.c | 1 + board/freescale/ls1088a/ls1088a.c | 1 + board/freescale/ls2080a/ddr.c | 1 + board/freescale/ls2080a/ls2080a.c | 1 + board/freescale/ls2080aqds/ddr.c | 1 + board/freescale/ls2080aqds/ls2080aqds.c | 1 + board/freescale/ls2080ardb/ddr.c | 1 + board/freescale/ls2080ardb/eth_ls2080rdb.c | 1 + board/freescale/ls2080ardb/ls2080ardb.c | 1 + board/freescale/lx2160a/ddr.c | 1 + board/freescale/lx2160a/eth_lx2160aqds.c | 1 + board/freescale/lx2160a/eth_lx2160ardb.c | 1 + board/freescale/lx2160a/eth_lx2162aqds.c | 1 + board/freescale/lx2160a/lx2160a.c | 1 + board/freescale/m5208evbe/m5208evbe.c | 1 + board/freescale/m52277evb/m52277evb.c | 1 + board/freescale/m5235evb/m5235evb.c | 1 + board/freescale/m5249evb/m5249evb.c | 1 + board/freescale/m5253demo/m5253demo.c | 1 + board/freescale/m5272c3/m5272c3.c | 1 + board/freescale/m5275evb/m5275evb.c | 1 + board/freescale/m5282evb/m5282evb.c | 1 + board/freescale/m53017evb/m53017evb.c | 1 + board/freescale/m5329evb/m5329evb.c | 1 + board/freescale/m5373evb/m5373evb.c | 1 + board/freescale/m54418twr/m54418twr.c | 1 + board/freescale/m54451evb/m54451evb.c | 1 + board/freescale/m54455evb/m54455evb.c | 1 + board/freescale/m547xevb/m547xevb.c | 1 + board/freescale/m548xevb/m548xevb.c | 1 + board/freescale/mpc8308rdb/sdram.c | 1 + board/freescale/mpc8313erdb/mpc8313erdb.c | 1 + board/freescale/mpc8313erdb/sdram.c | 1 + board/freescale/mpc8315erdb/mpc8315erdb.c | 1 + board/freescale/mpc8315erdb/sdram.c | 1 + board/freescale/mpc8323erdb/mpc8323erdb.c | 1 + board/freescale/mpc832xemds/mpc832xemds.c | 1 + board/freescale/mpc8349emds/mpc8349emds.c | 1 + board/freescale/mpc8349itx/mpc8349itx.c | 1 + board/freescale/mpc837xemds/mpc837xemds.c | 1 + board/freescale/mpc837xerdb/mpc837xerdb.c | 1 + board/freescale/mpc8610hpcd/mpc8610hpcd.c | 1 + board/freescale/mpc8641hpcn/mpc8641hpcn.c | 1 + board/freescale/mx23evk/mx23evk.c | 1 + board/freescale/mx25pdk/mx25pdk.c | 1 + board/freescale/mx28evk/mx28evk.c | 1 + board/freescale/mx35pdk/mx35pdk.c | 1 + board/freescale/mx51evk/mx51evk.c | 1 + board/freescale/mx53ard/mx53ard.c | 1 + board/freescale/mx53evk/mx53evk.c | 1 + board/freescale/mx53loco/mx53loco.c | 1 + board/freescale/mx53smd/mx53smd.c | 1 + board/freescale/mx6memcal/mx6memcal.c | 1 + board/freescale/mx6memcal/spl.c | 1 + board/freescale/mx6qarm2/mx6qarm2.c | 1 + board/freescale/mx6sabreauto/mx6sabreauto.c | 1 + board/freescale/mx6sabresd/mx6sabresd.c | 1 + board/freescale/mx6slevk/mx6slevk.c | 1 + board/freescale/mx6sllevk/mx6sllevk.c | 1 + board/freescale/mx6sxsabreauto/mx6sxsabreauto.c | 1 + board/freescale/mx6sxsabresd/mx6sxsabresd.c | 1 + board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 1 + board/freescale/mx6ullevk/mx6ullevk.c | 1 + board/freescale/mx7dsabresd/mx7dsabresd.c | 1 + board/freescale/mx7ulp_evk/mx7ulp_evk.c | 1 + board/freescale/p1010rdb/ddr.c | 1 + board/freescale/p1010rdb/p1010rdb.c | 1 + board/freescale/p1010rdb/spl.c | 1 + board/freescale/p1_p2_rdb_pc/spl.c | 1 + board/freescale/p2041rdb/ddr.c | 1 + board/freescale/p2041rdb/p2041rdb.c | 1 + board/freescale/qemu-ppce500/qemu-ppce500.c | 1 + board/freescale/s32v234evb/s32v234evb.c | 1 + board/freescale/t102xrdb/ddr.c | 1 + board/freescale/t102xrdb/spl.c | 1 + board/freescale/t102xrdb/t102xrdb.c | 1 + board/freescale/t104xrdb/ddr.c | 1 + board/freescale/t104xrdb/spl.c | 1 + board/freescale/t104xrdb/t104xrdb.c | 1 + board/freescale/t208xqds/ddr.c | 1 + board/freescale/t208xqds/spl.c | 1 + board/freescale/t208xqds/t208xqds.c | 1 + board/freescale/t208xrdb/ddr.c | 1 + board/freescale/t208xrdb/spl.c | 1 + board/freescale/t208xrdb/t208xrdb.c | 1 + board/freescale/t4rdb/ddr.c | 1 + board/freescale/t4rdb/spl.c | 1 + board/freescale/t4rdb/t4240rdb.c | 1 + board/freescale/vf610twr/vf610twr.c | 1 + board/friendlyarm/nanopi2/board.c | 1 + board/gardena/smart-gateway-at91sam/board.c | 1 + board/gateworks/gw_ventana/gw_ventana.c | 1 + board/gdsys/a38x/controlcenterdc.c | 1 + board/gdsys/a38x/hydra.c | 1 + board/gdsys/mpc8308/gazerbeam.c | 1 + board/gdsys/mpc8308/sdram.c | 1 + board/ge/b1x5v2/b1x5v2.c | 1 + board/ge/bx50v3/bx50v3.c | 1 + board/ge/mx53ppd/mx53ppd.c | 1 + board/google/imx8mq_phanbell/imx8mq_phanbell.c | 1 + board/google/imx8mq_phanbell/spl.c | 1 + board/google/veyron/veyron.c | 1 + board/grinn/chiliboard/board.c | 1 + board/grinn/liteboard/board.c | 1 + board/highbank/highbank.c | 1 + board/hisilicon/hikey/hikey.c | 1 + board/hisilicon/hikey960/hikey960.c | 1 + board/hisilicon/poplar/poplar.c | 1 + board/ids/ids8313/ids8313.c | 1 + board/imgtec/boston/ddr.c | 1 + board/imgtec/boston/dt.c | 1 + board/imgtec/ci20/ci20.c | 1 + board/imgtec/malta/malta.c | 1 + board/imgtec/xilfpga/xilfpga.c | 1 + board/inversepath/usbarmory/usbarmory.c | 1 + board/iomega/iconnect/iconnect.c | 1 + board/isee/igep003x/board.c | 1 + board/isee/igep00x0/common.c | 1 + board/k+p/kp_imx53/kp_imx53.c | 1 + board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c | 1 + board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c | 1 + board/keymile/common/common.c | 1 + board/keymile/km83xx/km83xx.c | 1 + board/keymile/km_arm/km_arm.c | 1 + board/keymile/kmp204x/ddr.c | 1 + board/kmc/kzm9g/kzm9g.c | 1 + board/kobol/helios4/helios4.c | 1 + board/kontron/sl28/ddr.c | 1 + board/kontron/sl28/sl28.c | 1 + board/kontron/sl28/spl_atf.c | 1 + board/kosagi/novena/novena.c | 1 + board/l+g/vinco/vinco.c | 1 + board/laird/wb45n/wb45n.c | 1 + board/laird/wb50n/wb50n.c | 1 + board/lego/ev3/legoev3.c | 1 + board/lg/sniper/sniper.c | 1 + board/liebherr/display5/display5.c | 1 + board/liebherr/display5/spl.c | 1 + board/liebherr/mccmon6/mccmon6.c | 1 + board/liebherr/xea/xea.c | 1 + board/logicpd/am3517evm/am3517evm.c | 1 + board/logicpd/imx6/imx6logic.c | 1 + board/logicpd/omap3som/omap3logic.c | 1 + board/maxbcm/maxbcm.c | 1 + board/mediatek/mt7622/mt7622_rfb.c | 1 + board/mediatek/mt7623/mt7623_rfb.c | 1 + board/mediatek/mt7629/mt7629_rfb.c | 1 + board/mediatek/mt8512/mt8512.c | 1 + board/mediatek/mt8518/mt8518_ap1.c | 1 + board/menlo/m53menlo/m53menlo.c | 1 + board/microchip/mpfs_icicle/mpfs_icicle.c | 1 + board/mikrotik/crs3xx-98dx3236/crs3xx-98dx3236.c | 1 + board/mini-box/picosam9g45/picosam9g45.c | 1 + board/mpc8308_p1m/sdram.c | 1 + board/mscc/jr2/jr2.c | 1 + board/mscc/luton/luton.c | 1 + board/mscc/ocelot/ocelot.c | 1 + board/mscc/serval/serval.c | 1 + board/mscc/servalt/servalt.c | 1 + board/myir/mys_6ulx/mys_6ulx.c | 1 + board/nokia/rx51/rx51.c | 1 + board/novtech/meerkat96/meerkat96.c | 1 + board/olimex/mx23_olinuxino/mx23_olinuxino.c | 1 + board/phytec/pcl063/pcl063.c | 1 + board/phytec/pcm052/pcm052.c | 1 + board/phytec/pcm058/pcm058.c | 1 + board/phytec/pfla02/pfla02.c | 1 + board/phytec/phycore_am335x_r2/board.c | 1 + board/phytec/phycore_imx8mm/phycore-imx8mm.c | 1 + board/phytec/phycore_imx8mm/spl.c | 1 + board/phytec/phycore_imx8mp/phycore-imx8mp.c | 1 + board/phytec/phycore_imx8mp/spl.c | 1 + board/phytec/phycore_rk3288/phycore-rk3288.c | 1 + board/phytium/durian/durian.c | 1 + board/ppcag/bg0900/bg0900.c | 1 + board/qemu-mips/qemu-mips.c | 1 + board/qualcomm/dragonboard410c/dragonboard410c.c | 1 + board/qualcomm/dragonboard820c/dragonboard820c.c | 1 + board/raidsonic/ib62x0/ib62x0.c | 1 + board/renesas/alt/alt.c | 1 + board/renesas/blanche/blanche.c | 1 + board/renesas/condor/condor.c | 1 + board/renesas/draak/draak.c | 1 + board/renesas/eagle/eagle.c | 1 + board/renesas/ebisu/ebisu.c | 1 + board/renesas/gose/gose.c | 1 + board/renesas/grpeach/grpeach.c | 1 + board/renesas/koelsch/koelsch.c | 1 + board/renesas/lager/lager.c | 1 + board/renesas/porter/porter.c | 1 + board/renesas/rcar-common/common.c | 1 + board/renesas/salvator-x/salvator-x.c | 1 + board/renesas/silk/silk.c | 1 + board/renesas/stout/stout.c | 1 + board/renesas/ulcb/ulcb.c | 1 + board/rockchip/evb_rk3308/evb_rk3308.c | 1 + board/rockchip/evb_rv1108/evb_rv1108.c | 1 + board/ronetix/pm9261/pm9261.c | 1 + board/ronetix/pm9263/pm9263.c | 1 + board/ronetix/pm9g45/pm9g45.c | 1 + board/samsung/arndale/arndale.c | 1 + board/samsung/common/board.c | 1 + board/samsung/common/exynos5-dt-types.c | 1 + board/samsung/common/exynos5-dt.c | 1 + board/samsung/common/misc.c | 1 + board/samsung/goni/goni.c | 1 + board/samsung/odroid/odroid.c | 1 + board/samsung/smdkc100/smdkc100.c | 1 + board/samsung/smdkv310/smdkv310.c | 1 + board/samsung/universal_c210/universal.c | 1 + board/sandbox/sandbox.c | 1 + board/sandisk/sansa_fuze_plus/sfp.c | 1 + board/sbc8349/sbc8349.c | 1 + board/sbc8641d/sbc8641d.c | 1 + board/schulercontrol/sc_sps_1/sc_sps_1.c | 1 + board/seco/mx6quq7/mx6quq7.c | 1 + board/siemens/capricorn/spl.c | 1 + board/siemens/common/board.c | 1 + board/siemens/corvus/board.c | 1 + board/siemens/smartweb/smartweb.c | 1 + board/siemens/taurus/taurus.c | 1 + board/sks-kinkel/sksimx6/sksimx6.c | 1 + board/socrates/socrates.c | 1 + board/softing/vining_2000/vining_2000.c | 1 + board/softing/vining_fpga/socfpga.c | 1 + board/solidrun/clearfog/clearfog.c | 1 + board/solidrun/common/tlv_data.c | 1 + board/solidrun/mx6cuboxi/mx6cuboxi.c | 1 + board/somlabs/visionsom-6ull/visionsom-6ull.c | 1 + board/st/common/stm32mp_mtdparts.c | 1 + board/st/stih410-b2260/board.c | 1 + board/st/stm32f429-discovery/stm32f429-discovery.c | 1 + board/st/stm32f429-evaluation/stm32f429-evaluation.c | 1 + board/st/stm32f469-discovery/stm32f469-discovery.c | 1 + board/st/stm32f746-disco/stm32f746-disco.c | 1 + board/st/stm32h743-disco/stm32h743-disco.c | 1 + board/st/stm32h743-eval/stm32h743-eval.c | 1 + board/st/stm32mp1/stm32mp1.c | 1 + board/st/stv0991/stv0991.c | 1 + board/ste/stemmy/stemmy.c | 1 + board/sunxi/board.c | 1 + board/synopsys/axs10x/axs10x.c | 1 + board/synopsys/emsdp/emsdp.c | 1 + board/synopsys/hsdk/hsdk.c | 1 + board/synopsys/iot_devkit/iot_devkit.c | 1 + board/sysam/amcore/amcore.c | 1 + board/sysam/stmark2/stmark2.c | 1 + board/syteco/zmx25/zmx25.c | 1 + board/tbs/tbs2910/tbs2910.c | 1 + board/tcl/sl50/board.c | 1 + board/technexion/pico-imx6/pico-imx6.c | 3 ++- board/technexion/pico-imx6ul/pico-imx6ul.c | 1 + board/technexion/pico-imx7d/pico-imx7d.c | 1 + board/technexion/pico-imx8mq/pico-imx8mq.c | 1 + board/technexion/pico-imx8mq/spl.c | 1 + board/technexion/tao3530/tao3530.c | 1 + board/technologic/ts4600/ts4600.c | 1 + board/technologic/ts4800/ts4800.c | 1 + board/theadorable/theadorable.c | 1 + board/ti/am335x/board.c | 1 + board/ti/am3517crane/am3517crane.c | 1 + board/ti/am43xx/board.c | 1 + board/ti/am57xx/board.c | 1 + board/ti/am65x/evm.c | 1 + board/ti/beagle/beagle.c | 1 + board/ti/dra7xx/evm.c | 1 + board/ti/evm/evm.c | 1 + board/ti/j721e/evm.c | 1 + board/ti/ks2_evm/board.c | 1 + board/ti/omap5_uevm/evm.c | 1 + board/ti/panda/panda.c | 1 + board/ti/sdp4430/sdp.c | 1 + board/ti/ti816x/evm.c | 1 + board/timll/devkit3250/devkit3250.c | 1 + board/timll/devkit8000/devkit8000.c | 1 + board/toradex/apalis-imx8/apalis-imx8.c | 1 + board/toradex/apalis-imx8x/apalis-imx8x.c | 1 + board/toradex/apalis_imx6/apalis_imx6.c | 1 + board/toradex/apalis_t30/apalis_t30.c | 1 + board/toradex/colibri-imx6ull/colibri-imx6ull.c | 1 + board/toradex/colibri-imx8x/colibri-imx8x.c | 1 + board/toradex/colibri_imx6/colibri_imx6.c | 1 + board/toradex/colibri_imx7/colibri_imx7.c | 1 + board/toradex/colibri_pxa270/colibri_pxa270.c | 1 + board/toradex/colibri_t20/colibri_t20.c | 1 + board/toradex/colibri_vf/colibri_vf.c | 1 + board/toradex/common/tdx-cfg-block.c | 1 + board/toradex/common/tdx-eeprom.c | 1 + board/toradex/verdin-imx8mm/spl.c | 1 + board/toradex/verdin-imx8mm/verdin-imx8mm.c | 1 + board/tqc/tqm834x/tqm834x.c | 1 + board/tqc/tqma6/tqma6.c | 1 + board/udoo/neo/neo.c | 1 + board/udoo/udoo.c | 1 + board/variscite/dart_6ul/dart_6ul.c | 1 + board/varisys/cyrus/ddr.c | 1 + board/ve8313/ve8313.c | 1 + board/vscom/baltos/board.c | 1 + board/wandboard/wandboard.c | 1 + board/warp/warp.c | 1 + board/warp7/warp7.c | 1 + board/work-microwave/work_92105/work_92105.c | 1 + board/xen/xenguest_arm64/xenguest_arm64.c | 1 + board/xes/xpedite517x/xpedite517x.c | 1 + board/xilinx/common/board.c | 1 + board/xilinx/microblaze-generic/microblaze-generic.c | 1 + board/xilinx/versal/board.c | 1 + board/xilinx/zynq/board.c | 1 + board/xilinx/zynq/bootimg.c | 1 + board/xilinx/zynq/cmds.c | 1 + board/xilinx/zynqmp/zynqmp.c | 1 + board/zyxel/nsa310s/nsa310s.c | 1 + cmd/acpi.c | 1 + cmd/bdinfo.c | 1 + cmd/bedbug.c | 1 + cmd/bloblist.c | 1 + cmd/bootefi.c | 1 + cmd/booti.c | 1 + cmd/bootm.c | 1 + cmd/date.c | 1 + cmd/efi.c | 1 + cmd/load.c | 1 + cmd/log.c | 1 + cmd/mem.c | 1 + cmd/mtdparts.c | 1 + cmd/nvedit.c | 1 + cmd/pstore.c | 1 + cmd/pxe_utils.h | 2 ++ cmd/sb.c | 1 + cmd/sound.c | 1 + cmd/spl.c | 1 + cmd/ti/ddr3.c | 1 + cmd/tlv_eeprom.c | 1 + cmd/x86/fsp.c | 1 + cmd/x86/hob.c | 1 + common/autoboot.c | 1 + common/bloblist.c | 1 + common/board_f.c | 1 + common/board_info.c | 1 + common/board_r.c | 1 + common/bootm.c | 1 + common/bootm_os.c | 1 + common/bootstage.c | 1 + common/cli.c | 1 + common/cli_hush.c | 1 + common/cli_readline.c | 1 + common/command.c | 1 + common/console.c | 1 + common/dlmalloc.c | 1 + common/exports.c | 1 + common/hash.c | 1 + common/hwconfig.c | 1 + common/image-android.c | 1 + common/image-cipher.c | 1 + common/image-fdt.c | 1 + common/image-fit-sig.c | 1 + common/image-fit.c | 1 + common/image-sig.c | 1 + common/image.c | 1 + common/init/board_init.c | 1 + common/init/handoff.c | 1 + common/iotrace.c | 1 + common/lcd.c | 1 + common/lcd_simplefb.c | 1 + common/log.c | 1 + common/log_console.c | 1 + common/log_syslog.c | 1 + common/malloc_simple.c | 1 + common/memsize.c | 1 + common/spl/spl.c | 1 + common/spl/spl_fit.c | 1 + common/spl/spl_opensbi.c | 1 + common/spl/spl_spi.c | 1 + common/splash_source.c | 1 + common/stdio.c | 2 +- disk/part_efi.c | 1 + drivers/ata/libata.c | 2 ++ drivers/ata/mtk_ahci.c | 1 + drivers/ata/sata_mv.c | 1 + drivers/bios_emulator/atibios.c | 1 + drivers/block/blkcache.c | 1 + drivers/block/sandbox.c | 1 + drivers/bootcount/bootcount_ram.c | 1 + drivers/cache/cache-v5l2.c | 1 + drivers/cache/sandbox_cache.c | 1 + drivers/clk/altera/clk-agilex.c | 1 + drivers/clk/altera/clk-arria10.c | 1 + drivers/clk/aspeed/clk_ast2500.c | 1 + drivers/clk/aspeed/clk_ast2600.c | 1 + drivers/clk/at91/compat.c | 1 + drivers/clk/at91/pmc.c | 3 +-- drivers/clk/clk-uclass.c | 1 + drivers/clk/clk_octeon.c | 1 + drivers/clk/clk_pic32.c | 1 + drivers/clk/clk_stm32mp1.c | 1 + drivers/clk/clk_zynq.c | 1 + drivers/clk/mpc83xx_clk.c | 1 + drivers/clk/renesas/clk-rcar-gen2.c | 1 + drivers/clk/renesas/clk-rcar-gen3.c | 1 + drivers/clk/rockchip/clk_px30.c | 1 + drivers/clk/rockchip/clk_rk3288.c | 1 + drivers/clk/rockchip/clk_rk3308.c | 1 + drivers/clk/rockchip/clk_rk3399.c | 1 + drivers/clk/rockchip/clk_rv1108.c | 1 + drivers/clk/ti/clk.c | 1 + drivers/core/device-remove.c | 1 + drivers/core/device.c | 1 + drivers/core/fdtaddr.c | 1 + drivers/core/of_access.c | 1 + drivers/core/ofnode.c | 1 + drivers/core/read.c | 1 + drivers/core/regmap.c | 1 + drivers/core/root.c | 1 + drivers/core/uclass.c | 1 + drivers/cpu/imx8_cpu.c | 1 + drivers/cpu/riscv_cpu.c | 1 + drivers/crypto/rsa_mod_exp/mod_exp_uclass.c | 1 + drivers/ddr/altera/sdram_agilex.c | 1 + drivers/ddr/altera/sdram_arria10.c | 1 + drivers/ddr/altera/sdram_s10.c | 1 + drivers/ddr/altera/sdram_soc64.c | 1 + drivers/ddr/imx/imx8m/helper.c | 1 + drivers/demo/demo-shape.c | 1 + drivers/demo/demo-uclass.c | 1 + drivers/fpga/socfpga_arria10.c | 1 + drivers/fpga/zynqmppl.c | 1 + drivers/gpio/74x164_gpio.c | 1 + drivers/gpio/altera_pio.c | 1 + drivers/gpio/atmel_pio4.c | 1 + drivers/gpio/da8xx_gpio.c | 1 + drivers/gpio/gpio-rcar.c | 1 + drivers/gpio/gpio-rza1.c | 1 + drivers/gpio/gpio-uclass.c | 1 + drivers/gpio/intel_broadwell_gpio.c | 1 + drivers/gpio/intel_ich6_gpio.c | 1 + drivers/gpio/msm_gpio.c | 1 + drivers/gpio/mxs_gpio.c | 1 + drivers/gpio/nx_gpio.c | 1 + drivers/gpio/omap_gpio.c | 1 + drivers/gpio/pcf8575_gpio.c | 1 + drivers/gpio/pic32_gpio.c | 1 + drivers/gpio/s5p_gpio.c | 1 + drivers/gpio/vybrid_gpio.c | 1 + drivers/hwspinlock/hwspinlock-uclass.c | 1 + drivers/i2c/at91_i2c.c | 1 + drivers/i2c/cros_ec_tunnel.c | 1 + drivers/i2c/exynos_hs_i2c.c | 1 + drivers/i2c/fsl_i2c.c | 1 + drivers/i2c/i2c_core.c | 1 + drivers/i2c/ihs_i2c.c | 1 + drivers/i2c/iproc_i2c.c | 1 + drivers/i2c/muxes/i2c-arb-gpio-challenge.c | 1 + drivers/i2c/muxes/i2c-mux-gpio.c | 1 + drivers/i2c/muxes/pca954x.c | 1 + drivers/i2c/mvtwsi.c | 1 + drivers/i2c/mxc_i2c.c | 1 + drivers/i2c/nx_i2c.c | 1 + drivers/i2c/ocores_i2c.c | 1 + drivers/i2c/s3c24x0_i2c.c | 1 + drivers/i2c/sh_i2c.c | 1 + drivers/i2c/soft_i2c.c | 1 + drivers/i2c/tegra186_bpmp_i2c.c | 1 + drivers/input/i8042.c | 1 + drivers/mailbox/k3-sec-proxy.c | 1 + drivers/misc/atsha204a-i2c.c | 1 + drivers/misc/fs_loader.c | 1 + drivers/misc/imx8/fuse.c | 1 + drivers/misc/imx8/scu.c | 1 + drivers/misc/imx8/scu_api.c | 1 + drivers/misc/tegra186_bpmp.c | 1 + drivers/misc/test_drv.c | 1 + drivers/mmc/atmel_sdhci.c | 1 + drivers/mmc/ca_dw_mmc.c | 1 + drivers/mmc/exynos_dw_mmc.c | 1 + drivers/mmc/fsl_esdhc.c | 1 + drivers/mmc/fsl_esdhc_imx.c | 1 + drivers/mmc/ftsdc010_mci.c | 1 + drivers/mmc/hi6220_dw_mmc.c | 1 + drivers/mmc/iproc_sdhci.c | 1 + drivers/mmc/jz_mmc.c | 1 + drivers/mmc/msm_sdhci.c | 1 + drivers/mmc/mv_sdhci.c | 1 + drivers/mmc/mvebu_mmc.c | 1 + drivers/mmc/omap_hsmmc.c | 1 + drivers/mmc/pic32_sdhci.c | 2 ++ drivers/mmc/renesas-sdhi.c | 1 + drivers/mmc/s5p_sdhci.c | 1 + drivers/mmc/sdhci-cadence.c | 1 + drivers/mmc/sh_mmcif.c | 1 + drivers/mmc/sh_sdhi.c | 1 + drivers/mmc/socfpga_dw_mmc.c | 1 + drivers/mmc/sti_sdhci.c | 1 + drivers/mmc/tmio-common.c | 1 + drivers/mmc/xenon_sdhci.c | 1 + drivers/mtd/altera_qspi.c | 1 + drivers/mtd/cfi_flash.c | 1 + drivers/mtd/mtd_uboot.c | 1 + drivers/mtd/nand/raw/nand_base.c | 1 + drivers/mtd/nand/raw/octeontx_nand.c | 1 + drivers/mtd/nand/raw/pxa3xx_nand.c | 1 + drivers/mtd/nand/raw/sunxi_nand.c | 1 + drivers/mtd/nand/raw/tegra_nand.c | 1 + drivers/mtd/pic32_flash.c | 1 + drivers/mtd/renesas_rpc_hf.c | 1 + drivers/mtd/spi/sf-uclass.c | 1 + drivers/net/ag7xxx.c | 1 + drivers/net/altera_tse.c | 1 + drivers/net/dwmac_s700.c | 1 + drivers/net/fec_mxc.c | 1 + drivers/net/fsl-mc/mc.c | 1 + drivers/net/fsl_mcdmafec.c | 1 + drivers/net/ftmac100.c | 1 + drivers/net/gmac_rockchip.c | 1 + drivers/net/ldpaa_eth/ldpaa_eth.c | 1 + drivers/net/macb.c | 1 + drivers/net/mcffec.c | 1 + drivers/net/mcfmii.c | 1 + drivers/net/mpc8xx_fec.c | 1 + drivers/net/mvgbe.c | 1 + drivers/net/mvneta.c | 1 + drivers/net/mvpp2.c | 1 + drivers/net/octeontx/smi.c | 1 + drivers/net/phy/fixed.c | 1 + drivers/net/phy/miiphybb.c | 1 + drivers/net/phy/phy.c | 1 + drivers/net/phy/xilinx_gmii2rgmii.c | 4 ++-- drivers/net/pic32_eth.c | 1 + drivers/net/qe/dm_qe_uec.c | 1 + drivers/net/ravb.c | 1 + drivers/net/sandbox-raw.c | 1 + drivers/net/sandbox.c | 1 + drivers/net/sh_eth.c | 1 + drivers/net/sni_ave.c | 1 + drivers/net/sun8i_emac.c | 1 + drivers/net/ti/cpsw-common.c | 1 + drivers/net/ti/keystone_net.c | 1 + drivers/net/xilinx_axi_emac.c | 1 + drivers/net/xilinx_emaclite.c | 1 + drivers/pci/fsl_pci_init.c | 1 + drivers/pci/pci-uclass.c | 1 + drivers/pci/pci.c | 1 + drivers/pci/pci_mvebu.c | 1 + drivers/pci/pci_octeontx.c | 1 + drivers/pci/pci_rom.c | 1 + drivers/pci/pcie_dw_mvebu.c | 1 + drivers/pci/pcie_dw_rockchip.c | 1 + drivers/pci/pcie_dw_ti.c | 1 + drivers/pci/pcie_ecam_generic.c | 1 + drivers/pci/pcie_fsl.c | 1 + drivers/pci/pcie_intel_fpga.c | 1 + drivers/pci/pcie_layerscape.c | 1 + drivers/pci/pcie_layerscape_ep.c | 1 + drivers/pci/pcie_layerscape_fixup_common.c | 1 + drivers/pci/pcie_layerscape_gen4.c | 1 + drivers/pci/pcie_layerscape_rc.c | 1 + drivers/pci/pcie_phytium.c | 1 + drivers/pci/pcie_rockchip.c | 1 + drivers/pci/pcie_xilinx.c | 1 + drivers/pci_endpoint/pci_ep-uclass.c | 1 + drivers/pci_endpoint/pcie-cadence-ep.c | 1 + drivers/phy/marvell/comphy_a3700.c | 1 + drivers/phy/marvell/comphy_core.c | 1 + drivers/phy/marvell/comphy_cp110.c | 1 + drivers/phy/omap-usb2-phy.c | 1 + drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 1 + drivers/phy/rockchip/phy-rockchip-pcie.c | 1 + drivers/phy/rockchip/phy-rockchip-typec.c | 1 + drivers/phy/sti_usb_phy.c | 1 + drivers/phy/ti-pipe3-phy.c | 1 + drivers/pinctrl/ath79/pinctrl_ar933x.c | 1 + drivers/pinctrl/ath79/pinctrl_qca953x.c | 1 + drivers/pinctrl/exynos/pinctrl-exynos.c | 1 + drivers/pinctrl/meson/pinctrl-meson.c | 1 + drivers/pinctrl/mtmips/pinctrl-mt7628.c | 1 + drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 1 + drivers/pinctrl/mvebu/pinctrl-mvebu.c | 1 + drivers/pinctrl/nexell/pinctrl-nexell.c | 1 + drivers/pinctrl/nexell/pinctrl-s5pxx18.c | 1 + drivers/pinctrl/nxp/pinctrl-imx.c | 1 + drivers/pinctrl/nxp/pinctrl-imx8.c | 1 + drivers/pinctrl/nxp/pinctrl-mxs.c | 1 + drivers/pinctrl/pinctrl-at91-pio4.c | 1 + drivers/pinctrl/pinctrl-at91.c | 1 + drivers/pinctrl/pinctrl-sti.c | 1 + drivers/pinctrl/pinctrl-uclass.c | 1 + drivers/pinctrl/pinctrl_pic32.c | 1 + drivers/pinctrl/renesas/pfc-r7s72100.c | 1 + drivers/pinctrl/rockchip/pinctrl-rockchip-core.c | 1 + drivers/power/domain/imx8-power-domain-legacy.c | 1 + drivers/power/domain/imx8m-power-domain.c | 1 + drivers/power/pmic/bd71837.c | 1 + drivers/power/pmic/mc34708.c | 1 + drivers/power/pmic/mp5416.c | 1 + drivers/power/pmic/pca9450.c | 1 + drivers/power/regulator/pwm_regulator.c | 1 + drivers/pwm/pwm-sifive.c | 1 + drivers/pwm/rk_pwm.c | 1 + drivers/pwm/sunxi_pwm.c | 1 + drivers/qe/fdt.c | 1 + drivers/qe/qe.c | 1 + drivers/ram/aspeed/sdram_ast2500.c | 1 + drivers/ram/aspeed/sdram_ast2600.c | 1 + drivers/ram/mpc83xx_sdram.c | 1 + drivers/ram/octeon/octeon_ddr.c | 1 + drivers/ram/rockchip/sdram_rk322x.c | 1 + drivers/ram/sandbox_ram.c | 1 + drivers/ram/sifive/fu540_ddr.c | 1 + drivers/ram/stm32mp1/stm32mp1_interactive.c | 1 + drivers/ram/stm32mp1/stm32mp1_tests.c | 1 + drivers/remoteproc/rproc-uclass.c | 1 + drivers/remoteproc/ti_power_proc.c | 1 + drivers/reset/sti-reset.c | 1 + drivers/serial/atmel_usart.c | 1 + drivers/serial/ns16550.c | 1 + drivers/serial/sandbox.c | 1 + drivers/serial/serial-uclass.c | 1 + drivers/serial/serial.c | 1 + drivers/serial/serial_arc.c | 1 + drivers/serial/serial_linflexuart.c | 1 + drivers/serial/serial_lpuart.c | 1 + drivers/serial/serial_mcf.c | 1 + drivers/serial/serial_mpc8xx.c | 1 + drivers/serial/serial_msm.c | 1 + drivers/serial/serial_mtk.c | 1 + drivers/serial/serial_mxc.c | 1 + drivers/serial/serial_ns16550.c | 1 + drivers/serial/serial_pic32.c | 1 + drivers/serial/serial_pl01x.c | 1 + drivers/serial/serial_pxa.c | 1 + drivers/serial/serial_s5p.c | 1 + drivers/serial/serial_sh.c | 1 + drivers/serial/serial_sifive.c | 1 + drivers/serial/serial_sti_asc.c | 1 + drivers/serial/serial_xen.c | 1 + drivers/smem/msm_smem.c | 1 + drivers/sound/ivybridge_sound.c | 1 + drivers/spi/atcspi200_spi.c | 1 + drivers/spi/bcmstb_spi.c | 1 + drivers/spi/ca_sflash.c | 1 + drivers/spi/cf_spi.c | 1 + drivers/spi/davinci_spi.c | 1 + drivers/spi/exynos_spi.c | 1 + drivers/spi/fsl_dspi.c | 1 + drivers/spi/fsl_espi.c | 1 + drivers/spi/fsl_qspi.c | 1 + drivers/spi/mvebu_a3700_spi.c | 1 + drivers/spi/mxc_spi.c | 1 + drivers/spi/omap3_spi.c | 1 + drivers/spi/pic32_spi.c | 1 + drivers/spi/pl022_spi.c | 1 + drivers/spi/renesas_rpc_spi.c | 1 + drivers/spi/soft_spi.c | 1 + drivers/spi/spi-sunxi.c | 1 + drivers/spi/spi-uclass.c | 1 + drivers/spi/tegra20_sflash.c | 1 + drivers/spi/tegra20_slink.c | 1 + drivers/spi/tegra210_qspi.c | 1 + drivers/spi/ti_qspi.c | 1 + drivers/spi/uniphier_spi.c | 1 + drivers/spi/zynq_qspi.c | 1 + drivers/spi/zynq_spi.c | 1 + drivers/spi/zynqmp_gqspi.c | 1 + drivers/spmi/spmi-msm.c | 1 + drivers/sysreset/sysreset-uclass.c | 1 + drivers/sysreset/sysreset_mpc83xx.c | 1 + drivers/sysreset/sysreset_sti.c | 1 + drivers/thermal/imx_scu_thermal.c | 1 + drivers/thermal/imx_tmu.c | 1 + drivers/timer/arc_timer.c | 1 + drivers/timer/cadence-ttc.c | 1 + drivers/timer/mpc83xx_timer.c | 1 + drivers/timer/ostm_timer.c | 1 + drivers/timer/rockchip_timer.c | 1 + drivers/timer/timer-uclass.c | 1 + drivers/timer/tsc_timer.c | 1 + drivers/usb/common/common.c | 1 + drivers/usb/host/dwc3-octeon-glue.c | 1 + drivers/usb/host/dwc3-sti-glue.c | 1 + drivers/usb/host/ehci-exynos.c | 1 + drivers/usb/host/ehci-fsl.c | 1 + drivers/usb/host/ehci-marvell.c | 1 + drivers/usb/host/ehci-mx5.c | 1 + drivers/usb/host/ehci-mx6.c | 1 + drivers/usb/host/ehci-vf.c | 1 + drivers/usb/host/xhci-exynos5.c | 1 + drivers/usb/musb-new/da8xx.c | 1 + drivers/usb/musb-new/omap2430.c | 1 + drivers/usb/musb-new/pic32.c | 1 + drivers/usb/musb-new/ti-musb.c | 1 + drivers/usb/phy/rockchip_usb2_phy.c | 1 + drivers/video/atmel_hlcdfb.c | 1 + drivers/video/atmel_lcdfb.c | 1 + drivers/video/bridge/ps862x.c | 1 + drivers/video/broadwell_igd.c | 1 + drivers/video/cfb_console.c | 1 + drivers/video/da8xx-fb.c | 1 + drivers/video/exynos/exynos_dp.c | 1 + drivers/video/exynos/exynos_fb.c | 1 + drivers/video/exynos/exynos_mipi_dsi.c | 1 + drivers/video/fsl_dcu_fb.c | 1 + drivers/video/ivybridge_igd.c | 1 + drivers/video/mali_dp.c | 1 + drivers/video/meson/meson_vpu.c | 1 + drivers/video/mxsfb.c | 1 + drivers/video/rockchip/rk3288_vop.c | 1 + drivers/video/rockchip/rk3399_vop.c | 1 + drivers/video/rockchip/rk_lvds.c | 1 + drivers/video/rockchip/rk_mipi.c | 1 + drivers/video/rockchip/rk_vop.c | 1 + drivers/video/sandbox_sdl.c | 1 + drivers/video/simplefb.c | 1 + drivers/video/sunxi/sunxi_lcd.c | 1 + drivers/video/tegra.c | 1 + drivers/video/ti/am335x-fb.c | 1 + drivers/video/ti/tilcdc.c | 1 + drivers/video/video-uclass.c | 1 + drivers/video/videomodes.c | 1 + drivers/watchdog/armada-37xx-wdt.c | 1 + drivers/watchdog/at91sam9_wdt.c | 1 + drivers/watchdog/mt7621_wdt.c | 1 + drivers/watchdog/octeontx_wdt.c | 1 + drivers/watchdog/orion_wdt.c | 1 + drivers/watchdog/sbsa_gwdt.c | 1 + drivers/watchdog/sp805_wdt.c | 1 + drivers/watchdog/wdt-uclass.c | 1 + drivers/xen/gnttab.c | 1 + drivers/xen/pvblock.c | 1 + env/callback.c | 1 + env/common.c | 1 + env/eeprom.c | 1 + env/env.c | 1 + env/ext4.c | 1 + env/flash.c | 1 + env/mmc.c | 1 + env/nand.c | 1 + env/nowhere.c | 1 + env/nvram.c | 1 + env/onenand.c | 1 + env/remote.c | 1 + env/sf.c | 1 + env/ubi.c | 1 + fs/fs.c | 1 + fs/reiserfs/reiserfs_private.h | 2 ++ fs/ubifs/ubifs.c | 1 + include/audio_codec.h | 2 ++ include/axi.h | 2 ++ include/backlight.h | 2 ++ include/bootcount.h | 1 + include/cache.h | 2 ++ include/common.h | 1 - include/cpu.h | 2 ++ include/dm/acpi.h | 1 + include/dm/ofnode.h | 2 ++ include/dm/read.h | 1 + include/dma.h | 2 ++ include/exports.h | 1 + include/ext_common.h | 2 ++ include/fsl_qe.h | 2 ++ include/image-sparse.h | 1 + include/init.h | 8 ++++---- include/initcall.h | 1 + include/led.h | 2 ++ include/misc.h | 2 ++ include/netdev.h | 2 ++ include/power/as3722.h | 2 ++ include/power/regulator.h | 2 ++ include/pwm.h | 2 ++ include/ram.h | 2 ++ include/scsi.h | 2 ++ include/soc.h | 2 ++ include/sysinfo.h | 2 ++ include/sysreset.h | 2 ++ include/tee.h | 2 ++ include/tpm-common.h | 2 ++ include/tpm-v1.h | 2 ++ include/tpm-v2.h | 2 ++ include/tps6586x.h | 2 ++ include/ufs.h | 3 +++ lib/acpi/acpi_table.c | 1 + lib/asm-offsets.c | 1 + lib/efi/efi_app.c | 1 + lib/efi/efi_info.c | 1 + lib/efi_loader/efi_boottime.c | 1 + lib/efi_loader/efi_dt_fixup.c | 1 + lib/efi_loader/efi_gop.c | 1 + lib/efi_loader/efi_memory.c | 1 + lib/efi_loader/efi_rng.c | 1 + lib/efi_loader/efi_runtime.c | 1 + lib/efi_selftest/dtbdump.c | 1 + lib/fdtdec.c | 1 + lib/optee/optee.c | 1 + lib/time.c | 1 + lib/trace.c | 1 + lib/zlib/zlib.c | 2 +- net/eth-uclass.c | 1 + net/eth_legacy.c | 1 + net/tftp.c | 1 + post/drivers/memory.c | 1 + post/post.c | 1 + test/bloblist.c | 1 + test/bootm.c | 1 + test/cmd/test_echo.c | 1 + test/dm/acpi.c | 1 + test/dm/blk.c | 1 + test/dm/bus.c | 1 + test/dm/core.c | 1 + test/dm/fdtdec.c | 1 + test/dm/mux-emul.c | 1 + test/dm/of_platdata.c | 1 + test/dm/ram.c | 1 + test/dm/test-fdt.c | 1 + test/dm/test-main.c | 1 + test/lib/test_print.c | 1 + test/log/cont_test.c | 1 + test/log/log_filter.c | 1 + test/log/log_test.c | 1 + test/log/nolog_test.c | 1 + test/log/pr_cont_test.c | 1 + test/log/syslog_test.c | 1 + test/log/syslog_test_ndebug.c | 1 + test/ut.c | 1 + 1361 files changed, 1405 insertions(+), 23 deletions(-)
diff --git a/arch/arc/lib/bootm.c b/arch/arc/lib/bootm.c index 63d6207c0477..8a8d394a5f0c 100644 --- a/arch/arc/lib/bootm.c +++ b/arch/arc/lib/bootm.c @@ -11,6 +11,7 @@ #include <lmb.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h>
diff --git a/arch/arc/lib/cache.c b/arch/arc/lib/cache.c index 85651b219cf8..f807cd83d6b5 100644 --- a/arch/arc/lib/cache.c +++ b/arch/arc/lib/cache.c @@ -6,6 +6,7 @@ #include <config.h> #include <common.h> #include <cpu_func.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/compiler.h> #include <linux/kernel.h> diff --git a/arch/arc/lib/cpu.c b/arch/arc/lib/cpu.c index d66a8c867acd..07f57878ef14 100644 --- a/arch/arc/lib/cpu.c +++ b/arch/arc/lib/cpu.c @@ -9,6 +9,7 @@ #include <vsprintf.h> #include <asm/arcregs.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/bitops.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arc/lib/relocate.c b/arch/arc/lib/relocate.c index 6882ebec6d88..7f531c95eec6 100644 --- a/arch/arc/lib/relocate.c +++ b/arch/arc/lib/relocate.c @@ -7,6 +7,7 @@ #include <elf.h> #include <log.h> #include <asm-generic/sections.h> +#include <asm/global_data.h>
extern ulong __image_copy_start; extern ulong __ivt_start; diff --git a/arch/arm/cpu/arm1136/mx35/generic.c b/arch/arm/cpu/arm1136/mx35/generic.c index 10f9ce42708e..cbf76ab4feec 100644 --- a/arch/arm/cpu/arm1136/mx35/generic.c +++ b/arch/arm/cpu/arm1136/mx35/generic.c @@ -12,6 +12,7 @@ #include <div64.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/errno.h> #include <asm/arch/imx-regs.h> diff --git a/arch/arm/cpu/arm926ejs/armada100/dram.c b/arch/arm/cpu/arm926ejs/armada100/dram.c index da0615faf159..c97b5b1940a5 100644 --- a/arch/arm/cpu/arm926ejs/armada100/dram.c +++ b/arch/arm/cpu/arm926ejs/armada100/dram.c @@ -8,6 +8,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/armada100.h>
diff --git a/arch/arm/cpu/arm926ejs/armada100/timer.c b/arch/arm/cpu/arm926ejs/armada100/timer.c index 0f1e68c8355f..ec73393d0fc7 100644 --- a/arch/arm/cpu/arm926ejs/armada100/timer.c +++ b/arch/arm/cpu/arm926ejs/armada100/timer.c @@ -12,6 +12,7 @@ #include <time.h> #include <asm/arch/cpu.h> #include <asm/arch/armada100.h> +#include <asm/global_data.h> #include <linux/delay.h>
/* diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index a4528cbaf529..9cd60abcccbd 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -15,6 +15,7 @@ #include <net.h> #include <netdev.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-imx/cpu.h> #include <asm/arch/imx-regs.h> diff --git a/arch/arm/cpu/arm926ejs/mx27/timer.c b/arch/arm/cpu/arm926ejs/mx27/timer.c index 408e88aa129e..4fd6a8059685 100644 --- a/arch/arm/cpu/arm926ejs/mx27/timer.c +++ b/arch/arm/cpu/arm926ejs/mx27/timer.c @@ -19,6 +19,7 @@ #include <div64.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/ptrace.h> diff --git a/arch/arm/cpu/arm926ejs/mxs/mxs.c b/arch/arm/cpu/arm926ejs/mxs/mxs.c index 8243aeb2c0f6..c9362136fbf9 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mxs.c +++ b/arch/arm/cpu/arm926ejs/mxs/mxs.c @@ -15,6 +15,7 @@ #include <hang.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c index 1501d7df0dc6..a16a15e79d83 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c @@ -11,6 +11,7 @@ #include <init.h> #include <log.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/cpu/arm926ejs/mxs/timer.c b/arch/arm/cpu/arm926ejs/mxs/timer.c index 5ab4ed0c5a3d..3dff3d768d1c 100644 --- a/arch/arm/cpu/arm926ejs/mxs/timer.c +++ b/arch/arm/cpu/arm926ejs/mxs/timer.c @@ -12,6 +12,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/cpu/arm926ejs/spear/spr_misc.c b/arch/arm/cpu/arm926ejs/spear/spr_misc.c index 998423b6525c..044052b32f93 100644 --- a/arch/arm/cpu/arm926ejs/spear/spr_misc.c +++ b/arch/arm/cpu/arm926ejs/spear/spr_misc.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/mtd/st_smi.h> #include <asm/io.h> #include <asm/arch/hardware.h> diff --git a/arch/arm/cpu/arm926ejs/spear/timer.c b/arch/arm/cpu/arm926ejs/spear/timer.c index dd0f15c0ceee..b42baa71506f 100644 --- a/arch/arm/cpu/arm926ejs/spear/timer.c +++ b/arch/arm/cpu/arm926ejs/spear/timer.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/spr_gpt.h> diff --git a/arch/arm/cpu/armv7/arch_timer.c b/arch/arm/cpu/armv7/arch_timer.c index 871629c2333b..d96406f7626f 100644 --- a/arch/arm/cpu/armv7/arch_timer.c +++ b/arch/arm/cpu/armv7/arch_timer.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <bootstage.h> diff --git a/arch/arm/cpu/armv7/ls102xa/clock.c b/arch/arm/cpu/armv7/ls102xa/clock.c index f3bdb14c0722..940995ef5af1 100644 --- a/arch/arm/cpu/armv7/ls102xa/clock.c +++ b/arch/arm/cpu/armv7/ls102xa/clock.c @@ -5,6 +5,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> #include <asm/arch/clock.h> diff --git a/arch/arm/cpu/armv7/ls102xa/cpu.c b/arch/arm/cpu/armv7/ls102xa/cpu.c index ce472aa9bd54..cbc8254b42a0 100644 --- a/arch/arm/cpu/armv7/ls102xa/cpu.c +++ b/arch/arm/cpu/armv7/ls102xa/cpu.c @@ -9,6 +9,7 @@ #include <net.h> #include <vsprintf.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> #include <asm/cache.h> diff --git a/arch/arm/cpu/armv7/ls102xa/fdt.c b/arch/arm/cpu/armv7/ls102xa/fdt.c index 2556980cde67..0daf8234fb14 100644 --- a/arch/arm/cpu/armv7/ls102xa/fdt.c +++ b/arch/arm/cpu/armv7/ls102xa/fdt.c @@ -6,6 +6,7 @@ #include <common.h> #include <clock_legacy.h> #include <net.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/io.h> diff --git a/arch/arm/cpu/armv7/ls102xa/timer.c b/arch/arm/cpu/armv7/ls102xa/timer.c index 2a32b30999fe..d79bf105f13a 100644 --- a/arch/arm/cpu/armv7/ls102xa/timer.c +++ b/arch/arm/cpu/armv7/ls102xa/timer.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <asm/arch/immap_ls102xa.h> diff --git a/arch/arm/cpu/armv7/s5p-common/cpu_info.c b/arch/arm/cpu/armv7/s5p-common/cpu_info.c index 7790f087a09d..d910282e2b29 100644 --- a/arch/arm/cpu/armv7/s5p-common/cpu_info.c +++ b/arch/arm/cpu/armv7/s5p-common/cpu_info.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdtdec.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clk.h>
diff --git a/arch/arm/cpu/armv7/s5p-common/timer.c b/arch/arm/cpu/armv7/s5p-common/timer.c index 3064fd25d4d0..8141f40d5c09 100644 --- a/arch/arm/cpu/armv7/s5p-common/timer.c +++ b/arch/arm/cpu/armv7/s5p-common/timer.c @@ -10,6 +10,7 @@ #include <div64.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/pwm.h> #include <asm/arch/clk.h> diff --git a/arch/arm/cpu/armv7/s5p4418/cpu.c b/arch/arm/cpu/armv7/s5p4418/cpu.c index 8add9474ad23..3c71a37a74bf 100644 --- a/arch/arm/cpu/armv7/s5p4418/cpu.c +++ b/arch/arm/cpu/armv7/s5p4418/cpu.c @@ -8,6 +8,7 @@ #include <command.h> #include <asm/system.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <asm/io.h> #include <asm/arch/nexell.h> diff --git a/arch/arm/cpu/armv7/stv0991/timer.c b/arch/arm/cpu/armv7/stv0991/timer.c index 919529aa1b03..07033acb5c18 100644 --- a/arch/arm/cpu/armv7/stv0991/timer.c +++ b/arch/arm/cpu/armv7/stv0991/timer.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-stv0991/hardware.h> #include <asm/arch-stv0991/stv0991_cgu.h> diff --git a/arch/arm/cpu/armv7/sunxi/timer.c b/arch/arm/cpu/armv7/sunxi/timer.c index 65b64b5ac75b..b7585996369f 100644 --- a/arch/arm/cpu/armv7/sunxi/timer.c +++ b/arch/arm/cpu/armv7/sunxi/timer.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/timer.h> #include <linux/delay.h> diff --git a/arch/arm/cpu/armv7/vf610/generic.c b/arch/arm/cpu/armv7/vf610/generic.c index 743bfced6438..c23ddc12b456 100644 --- a/arch/arm/cpu/armv7/vf610/generic.c +++ b/arch/arm/cpu/armv7/vf610/generic.c @@ -10,6 +10,7 @@ #include <init.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> diff --git a/arch/arm/cpu/armv7/vf610/timer.c b/arch/arm/cpu/armv7/vf610/timer.c index fa8f8fae10a0..a9c1a8fcebc1 100644 --- a/arch/arm/cpu/armv7/vf610/timer.c +++ b/arch/arm/cpu/armv7/vf610/timer.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <asm/arch/imx-regs.h> diff --git a/arch/arm/cpu/armv7/virt-dt.c b/arch/arm/cpu/armv7/virt-dt.c index 61c82f64699c..c0422485ba4e 100644 --- a/arch/arm/cpu/armv7/virt-dt.c +++ b/arch/arm/cpu/armv7/virt-dt.c @@ -21,7 +21,6 @@ #include <stdio_dev.h> #include <linux/ctype.h> #include <linux/types.h> -#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/armv7.h> diff --git a/arch/arm/cpu/armv7m/systick-timer.c b/arch/arm/cpu/armv7m/systick-timer.c index d2672fd40cdb..556eaf8c74ad 100644 --- a/arch/arm/cpu/armv7m/systick-timer.c +++ b/arch/arm/cpu/armv7m/systick-timer.c @@ -24,6 +24,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index 7c31d98a6f03..15cecb5e0b34 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -12,6 +12,7 @@ #include <hang.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/armv8/mmu.h>
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 1a5d26b5372e..3a5bf7782603 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -14,6 +14,7 @@ #include <net.h> #include <vsprintf.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/ptrace.h> #include <linux/errno.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index c56689086de6..63d34e1ec039 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -7,6 +7,7 @@ #include <common.h> #include <clock_legacy.h> #include <cpu_func.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/io.h> #include <asm/processor.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c index bf153c720e13..25a1c36d2ac0 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c @@ -9,6 +9,7 @@ #include <common.h> #include <clock_legacy.h> #include <cpu_func.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <fsl_ifc.h> #include <asm/processor.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/mp.c b/arch/arm/cpu/armv8/fsl-layerscape/mp.c index bd85351705a7..5ac545f9df81 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/mp.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/mp.c @@ -8,6 +8,7 @@ #include <image.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/system.h> #include <asm/arch/mp.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ppa.c b/arch/arm/cpu/armv8/fsl-layerscape/ppa.c index 2285296ea008..b9894d41bbdd 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ppa.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ppa.c @@ -8,6 +8,7 @@ #include <config.h> #include <errno.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/types.h> #include <asm/arch/soc.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c index 215ed9759e32..d5131bcf4b39 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/spl.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -12,6 +12,7 @@ #include <log.h> #include <spl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <fsl_ifc.h> #include <i2c.h> diff --git a/arch/arm/cpu/armv8/generic_timer.c b/arch/arm/cpu/armv8/generic_timer.c index e23629ab0bc3..f27a74b9d09b 100644 --- a/arch/arm/cpu/armv8/generic_timer.c +++ b/arch/arm/cpu/armv8/generic_timer.c @@ -8,6 +8,7 @@ #include <bootstage.h> #include <command.h> #include <time.h> +#include <asm/global_data.h> #include <asm/system.h> #include <linux/bitops.h>
diff --git a/arch/arm/cpu/armv8/s32v234/generic.c b/arch/arm/cpu/armv8/s32v234/generic.c index de5a098adb8f..0fc98852228a 100644 --- a/arch/arm/cpu/armv8/s32v234/generic.c +++ b/arch/arm/cpu/armv8/s32v234/generic.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> diff --git a/arch/arm/cpu/armv8/sec_firmware.c b/arch/arm/cpu/armv8/sec_firmware.c index bfc0fac3eff2..c6c4fcc7e073 100644 --- a/arch/arm/cpu/armv8/sec_firmware.c +++ b/arch/arm/cpu/armv8/sec_firmware.c @@ -10,6 +10,7 @@ #include <image.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/kernel.h> #include <asm/io.h> diff --git a/arch/arm/include/asm/arch-rockchip/clock.h b/arch/arm/include/asm/arch-rockchip/clock.h index 22de0aef8dc0..5108180ea77f 100644 --- a/arch/arm/include/asm/arch-rockchip/clock.h +++ b/arch/arm/include/asm/arch-rockchip/clock.h @@ -6,6 +6,8 @@ #ifndef _ASM_ARCH_CLOCK_H #define _ASM_ARCH_CLOCK_H
+struct udevice; + /* define pll mode */ #define RKCLK_PLL_MODE_SLOW 0 #define RKCLK_PLL_MODE_NORMAL 1 diff --git a/arch/arm/include/asm/arch-tegra/clock.h b/arch/arm/include/asm/arch-tegra/clock.h index 8aa90d5c0c56..1d80d9e94617 100644 --- a/arch/arm/include/asm/arch-tegra/clock.h +++ b/arch/arm/include/asm/arch-tegra/clock.h @@ -8,6 +8,8 @@ #ifndef _TEGRA_CLOCK_H_ #define _TEGRA_CLOCK_H_
+struct udevice; + /* Set of oscillator frequencies supported in the internal API. */ enum clock_osc_freq { /* All in MHz, so 13_0 is 13.0MHz */ diff --git a/arch/arm/include/asm/arch-tegra/tegra_i2c.h b/arch/arm/include/asm/arch-tegra/tegra_i2c.h index 5316bc47e4b3..e57b9ef9c474 100644 --- a/arch/arm/include/asm/arch-tegra/tegra_i2c.h +++ b/arch/arm/include/asm/arch-tegra/tegra_i2c.h @@ -10,6 +10,8 @@
+struct udevice; + enum { I2C_TIMEOUT_USEC = 10000, /* Wait time for completion */ I2C_FIFO_DEPTH = 8, /* I2C fifo depth */ diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index 2aafc6d2062e..5a935d34e20e 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -7,6 +7,9 @@ #ifndef __ASM_GBL_DATA_H #define __ASM_GBL_DATA_H
+#include <asm/types.h> +#include <linux/types.h> + /* Architecture-specific global data */ struct arch_global_data { #if defined(CONFIG_FSL_ESDHC) || defined(CONFIG_FSL_ESDHC_IMX) diff --git a/arch/arm/include/asm/secure.h b/arch/arm/include/asm/secure.h index 50582c972b7a..64e5582c1f2a 100644 --- a/arch/arm/include/asm/secure.h +++ b/arch/arm/include/asm/secure.h @@ -2,6 +2,7 @@ #define __ASM_SECURE_H
#include <config.h> +#include <asm/global_data.h>
#define __secure __attribute__ ((section ("._secure.text"))) #define __secure_data __attribute__ ((section ("._secure.data"))) diff --git a/arch/arm/include/asm/ti-common/sys_proto.h b/arch/arm/include/asm/ti-common/sys_proto.h index db042a1aef2d..a96a8382fb6e 100644 --- a/arch/arm/include/asm/ti-common/sys_proto.h +++ b/arch/arm/include/asm/ti-common/sys_proto.h @@ -6,6 +6,8 @@ #ifndef _TI_COMMON_SYS_PROTO_H_ #define _TI_COMMON_SYS_PROTO_H_
+#include <asm/global_data.h> + DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_ARCH_OMAP2PLUS diff --git a/arch/arm/lib/bdinfo.c b/arch/arm/lib/bdinfo.c index 25bc6e80f476..572f7fb2429f 100644 --- a/arch/arm/lib/bdinfo.c +++ b/arch/arm/lib/bdinfo.c @@ -8,6 +8,7 @@
diff --git a/arch/arm/lib/bootm-fdt.c b/arch/arm/lib/bootm-fdt.c index fe46a7d7c98d..29020bd1c6bc 100644 --- a/arch/arm/lib/bootm-fdt.c +++ b/arch/arm/lib/bootm-fdt.c @@ -19,6 +19,7 @@ #ifdef CONFIG_ARMV7_NONSEC #include <asm/armv7.h> #endif +#include <asm/global_data.h> #include <asm/psci.h> #include <asm/spin_table.h>
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 1206e306db65..70c181e45b7e 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -19,6 +19,7 @@ #include <hang.h> #include <lmb.h> #include <log.h> +#include <asm/global_data.h> #include <dm/root.h> #include <env.h> #include <image.h> diff --git a/arch/arm/lib/cache-cp15.c b/arch/arm/lib/cache-cp15.c index abd81d21c73c..24050e5bdd30 100644 --- a/arch/arm/lib/cache-cp15.c +++ b/arch/arm/lib/cache-cp15.c @@ -7,6 +7,7 @@ #include <common.h> #include <cpu_func.h> #include <log.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/cache.h> #include <linux/compiler.h> diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index bdde9cdad5d0..a2bf2e57b941 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <asm/cache.h> +#include <asm/global_data.h>
diff --git a/arch/arm/lib/image.c b/arch/arm/lib/image.c index 94590d3049ad..e394c1ad9093 100644 --- a/arch/arm/lib/image.c +++ b/arch/arm/lib/image.c @@ -7,6 +7,7 @@ #include <common.h> #include <image.h> #include <mapmem.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/sizes.h>
diff --git a/arch/arm/lib/interrupts.c b/arch/arm/lib/interrupts.c index 703be5a3209c..05bb1a38b35e 100644 --- a/arch/arm/lib/interrupts.c +++ b/arch/arm/lib/interrupts.c @@ -22,6 +22,7 @@ #include <cpu_func.h> #include <efi_loader.h> #include <irq_func.h> +#include <asm/global_data.h> #include <asm/proc-armv/ptrace.h> #include <asm/ptrace.h> #include <asm/u-boot-arm.h> diff --git a/arch/arm/lib/interrupts_64.c b/arch/arm/lib/interrupts_64.c index 529948901376..c653e67db286 100644 --- a/arch/arm/lib/interrupts_64.c +++ b/arch/arm/lib/interrupts_64.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <irq_func.h> #include <linux/compiler.h> diff --git a/arch/arm/lib/spl.c b/arch/arm/lib/spl.c index af0c9ad6bd6c..b2b54f28fc4b 100644 --- a/arch/arm/lib/spl.c +++ b/arch/arm/lib/spl.c @@ -14,6 +14,7 @@ #include <spl.h> #include <image.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mach-types.h>
diff --git a/arch/arm/lib/stack.c b/arch/arm/lib/stack.c index 96a248c0a907..b03e1cfc80c9 100644 --- a/arch/arm/lib/stack.c +++ b/arch/arm/lib/stack.c @@ -12,6 +12,7 @@ */ #include <common.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-aspeed/ast2500/board_common.c b/arch/arm/mach-aspeed/ast2500/board_common.c index 3482ee91efd8..aca200223129 100644 --- a/arch/arm/mach-aspeed/ast2500/board_common.c +++ b/arch/arm/mach-aspeed/ast2500/board_common.c @@ -8,6 +8,7 @@ #include <log.h> #include <ram.h> #include <timer.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/timer.h> #include <asm/arch/wdt.h> diff --git a/arch/arm/mach-aspeed/ast2600/board_common.c b/arch/arm/mach-aspeed/ast2600/board_common.c index a53e1632f6cf..82ff21908f26 100644 --- a/arch/arm/mach-aspeed/ast2600/board_common.c +++ b/arch/arm/mach-aspeed/ast2600/board_common.c @@ -12,6 +12,7 @@ #include <linux/err.h> #include <dm/uclass.h> #include <asm/arch/scu_ast2600.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-aspeed/ast2600/spl.c b/arch/arm/mach-aspeed/ast2600/spl.c index 9201d4a4d442..0d8cb29678b2 100644 --- a/arch/arm/mach-aspeed/ast2600/spl.c +++ b/arch/arm/mach-aspeed/ast2600/spl.c @@ -9,6 +9,7 @@ #include <init.h> #include <asm/io.h> #include <asm/arch/scu_ast2600.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-at91/arm920t/clock.c b/arch/arm/mach-at91/arm920t/clock.c index 9a57dd40891b..c7440278d8f8 100644 --- a/arch/arm/mach-at91/arm920t/clock.c +++ b/arch/arm/mach-at91/arm920t/clock.c @@ -8,6 +8,7 @@ * Copyright (C) 2009 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com */ #include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pmc.h> diff --git a/arch/arm/mach-at91/arm920t/timer.c b/arch/arm/mach-at91/arm920t/timer.c index dca2d2c70c77..c400e8781356 100644 --- a/arch/arm/mach-at91/arm920t/timer.c +++ b/arch/arm/mach-at91/arm920t/timer.c @@ -16,6 +16,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/io.h> diff --git a/arch/arm/mach-at91/arm926ejs/clock.c b/arch/arm/mach-at91/arm926ejs/clock.c index 7156185a46fa..c68e0c0c3c44 100644 --- a/arch/arm/mach-at91/arm926ejs/clock.c +++ b/arch/arm/mach-at91/arm926ejs/clock.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pmc.h> diff --git a/arch/arm/mach-at91/arm926ejs/timer.c b/arch/arm/mach-at91/arm926ejs/timer.c index 42ef349966b0..a8cf0e4bd799 100644 --- a/arch/arm/mach-at91/arm926ejs/timer.c +++ b/arch/arm/mach-at91/arm926ejs/timer.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pit.h> diff --git a/arch/arm/mach-at91/armv7/clock.c b/arch/arm/mach-at91/armv7/clock.c index 39268969580b..aa6bb6bf31e0 100644 --- a/arch/arm/mach-at91/armv7/clock.c +++ b/arch/arm/mach-at91/armv7/clock.c @@ -10,6 +10,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/arch/arm/mach-at91/armv7/timer.c b/arch/arm/mach-at91/armv7/timer.c index a6346c01b285..1f54c5dcad98 100644 --- a/arch/arm/mach-at91/armv7/timer.c +++ b/arch/arm/mach-at91/armv7/timer.c @@ -11,6 +11,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pit.h> diff --git a/arch/arm/mach-at91/spl_at91.c b/arch/arm/mach-at91/spl_at91.c index 35a3d5185d3f..d0c732539248 100644 --- a/arch/arm/mach-at91/spl_at91.c +++ b/arch/arm/mach-at91/spl_at91.c @@ -12,6 +12,7 @@ #include <hang.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91sam9_matrix.h> diff --git a/arch/arm/mach-bcm283x/init.c b/arch/arm/mach-bcm283x/init.c index f2a541162370..49027ce0a2e6 100644 --- a/arch/arm/mach-bcm283x/init.c +++ b/arch/arm/mach-bcm283x/init.c @@ -11,6 +11,7 @@ #include <init.h> #include <dm/device.h> #include <fdt_support.h> +#include <asm/global_data.h>
#define BCM2711_RPI4_PCIE_XHCI_MMIO_PHYS 0x600000000UL #define BCM2711_RPI4_PCIE_XHCI_MMIO_SIZE 0x800000UL diff --git a/arch/arm/mach-davinci/cpu.c b/arch/arm/mach-davinci/cpu.c index 40dd44af67eb..aefd21dc458a 100644 --- a/arch/arm/mach-davinci/cpu.c +++ b/arch/arm/mach-davinci/cpu.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/mach-davinci/misc.c b/arch/arm/mach-davinci/misc.c index 5bfc47dae457..90b38b7e020e 100644 --- a/arch/arm/mach-davinci/misc.c +++ b/arch/arm/mach-davinci/misc.c @@ -15,6 +15,7 @@ #include <log.h> #include <net.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/davinci_misc.h>
diff --git a/arch/arm/mach-davinci/timer.c b/arch/arm/mach-davinci/timer.c index a6681821f6dd..43e0574901ee 100644 --- a/arch/arm/mach-davinci/timer.c +++ b/arch/arm/mach-davinci/timer.c @@ -23,6 +23,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/timer_defs.h> #include <div64.h> diff --git a/arch/arm/mach-exynos/spl_boot.c b/arch/arm/mach-exynos/spl_boot.c index 9c7ca49519b9..27f0dac182d3 100644 --- a/arch/arm/mach-exynos/spl_boot.c +++ b/arch/arm/mach-exynos/spl_boot.c @@ -7,6 +7,7 @@ #include <config.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
#include <asm/cache.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-imx/imx8/ahab.c b/arch/arm/mach-imx/imx8/ahab.c index 600a1108ceca..6392fe267a01 100644 --- a/arch/arm/mach-imx/imx8/ahab.c +++ b/arch/arm/mach-imx/imx8/ahab.c @@ -7,6 +7,7 @@ #include <command.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sci/sci.h> #include <asm/mach-imx/sys_proto.h> diff --git a/arch/arm/mach-imx/imx8/clock.c b/arch/arm/mach-imx/imx8/clock.c index d747e1332f04..9941b57b4be5 100644 --- a/arch/arm/mach-imx/imx8/clock.c +++ b/arch/arm/mach-imx/imx8/clock.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/arch/clock.h>
diff --git a/arch/arm/mach-imx/imx8/cpu.c b/arch/arm/mach-imx/imx8/cpu.c index 911d6a51d1e4..02db322f51af 100644 --- a/arch/arm/mach-imx/imx8/cpu.c +++ b/arch/arm/mach-imx/imx8/cpu.c @@ -11,6 +11,7 @@ #include <init.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/uclass.h> diff --git a/arch/arm/mach-imx/imx8/fdt.c b/arch/arm/mach-imx/imx8/fdt.c index 3e05b972a450..a132ce2e6a3a 100644 --- a/arch/arm/mach-imx/imx8/fdt.c +++ b/arch/arm/mach-imx/imx8/fdt.c @@ -7,6 +7,7 @@ #include <log.h> #include <asm/arch/sci/sci.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <dm/ofnode.h> #include <fdt_support.h> #include <linux/libfdt.h> diff --git a/arch/arm/mach-imx/imx8/iomux.c b/arch/arm/mach-imx/imx8/iomux.c index b8e6f48a5f77..9c3cfbf0068c 100644 --- a/arch/arm/mach-imx/imx8/iomux.c +++ b/arch/arm/mach-imx/imx8/iomux.c @@ -5,6 +5,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/iomux.h> #include <asm/arch/sci/sci.h> diff --git a/arch/arm/mach-imx/imx8/snvs_security_sc.c b/arch/arm/mach-imx/imx8/snvs_security_sc.c index 564d1bfdfb20..6f9b1c99fcd2 100644 --- a/arch/arm/mach-imx/imx8/snvs_security_sc.c +++ b/arch/arm/mach-imx/imx8/snvs_security_sc.c @@ -18,6 +18,7 @@ #include <asm/arch/sci/sci.h> #include <asm/arch-imx8/imx8-pins.h> #include <asm/arch-imx8/snvs_security_sc.h> +#include <asm/global_data.h>
/* Access to gd */ DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/mach-imx/imx8m/clock_imx8mm.c b/arch/arm/mach-imx/imx8m/clock_imx8mm.c index 9dde11cdedff..4024dafca10c 100644 --- a/arch/arm/mach-imx/imx8m/clock_imx8mm.c +++ b/arch/arm/mach-imx/imx8m/clock_imx8mm.c @@ -9,6 +9,7 @@ #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <errno.h> diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 5df8e175101d..5456c10fb177 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <asm/arch/imx-regs.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-imx/misc.c b/arch/arm/mach-imx/misc.c index 818f38e17ddb..d82efa7f8f0a 100644 --- a/arch/arm/mach-imx/misc.c +++ b/arch/arm/mach-imx/misc.c @@ -7,6 +7,7 @@ #include <lmb.h> #include <log.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/arch/arm/mach-imx/mx5/mx53_dram.c b/arch/arm/mach-imx/mx5/mx53_dram.c index a7f033f3f44d..f74414419470 100644 --- a/arch/arm/mach-imx/mx5/mx53_dram.c +++ b/arch/arm/mach-imx/mx5/mx53_dram.c @@ -6,6 +6,7 @@
diff --git a/arch/arm/mach-imx/mx6/litesom.c b/arch/arm/mach-imx/mx6/litesom.c index 92176dc86158..699a3dc317f0 100644 --- a/arch/arm/mach-imx/mx6/litesom.c +++ b/arch/arm/mach-imx/mx6/litesom.c @@ -12,6 +12,7 @@ #include <asm/arch/mx6ul_pins.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/arch/arm/mach-imx/mx6/opos6ul.c b/arch/arm/mach-imx/mx6/opos6ul.c index 4b3c59f7eef4..e9d78740a157 100644 --- a/arch/arm/mach-imx/mx6/opos6ul.c +++ b/arch/arm/mach-imx/mx6/opos6ul.c @@ -8,6 +8,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <env.h> diff --git a/arch/arm/mach-imx/mx7/clock.c b/arch/arm/mach-imx/mx7/clock.c index 6a1bad855eb2..304a0303134a 100644 --- a/arch/arm/mach-imx/mx7/clock.c +++ b/arch/arm/mach-imx/mx7/clock.c @@ -11,6 +11,7 @@ #include <command.h> #include <div64.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/errno.h> #include <asm/arch/imx-regs.h> diff --git a/arch/arm/mach-imx/mx7ulp/clock.c b/arch/arm/mach-imx/mx7ulp/clock.c index 51aaa5001e77..6191153917f7 100644 --- a/arch/arm/mach-imx/mx7ulp/clock.c +++ b/arch/arm/mach-imx/mx7ulp/clock.c @@ -7,6 +7,7 @@ #include <clock_legacy.h> #include <command.h> #include <div64.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-imx/speed.c b/arch/arm/mach-imx/speed.c index e78b1fd71b6e..b729187ec817 100644 --- a/arch/arm/mach-imx/speed.c +++ b/arch/arm/mach-imx/speed.c @@ -11,6 +11,7 @@ #include <clock_legacy.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> +#include <asm/global_data.h>
#ifdef CONFIG_FSL_ESDHC_IMX DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index 2d15f62445c9..be4da0f7023a 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -10,6 +10,7 @@ #include <hang.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-imx/spl_imx_romapi.c b/arch/arm/mach-imx/spl_imx_romapi.c index f588a5f52160..9f4d95982e59 100644 --- a/arch/arm/mach-imx/spl_imx_romapi.c +++ b/arch/arm/mach-imx/spl_imx_romapi.c @@ -7,6 +7,7 @@ #include <errno.h> #include <image.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <spl.h>
diff --git a/arch/arm/mach-imx/syscounter.c b/arch/arm/mach-imx/syscounter.c index 7da43c32e0db..6dfed365d295 100644 --- a/arch/arm/mach-imx/syscounter.c +++ b/arch/arm/mach-imx/syscounter.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <asm/arch/imx-regs.h> diff --git a/arch/arm/mach-imx/timer.c b/arch/arm/mach-imx/timer.c index a3c47889f135..fcd45f09f181 100644 --- a/arch/arm/mach-imx/timer.c +++ b/arch/arm/mach-imx/timer.c @@ -11,6 +11,7 @@ #include <time.h> #include <asm/io.h> #include <div64.h> +#include <asm/global_data.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-k3/am6_init.c b/arch/arm/mach-k3/am6_init.c index dea470c02f70..d78d2b87519c 100644 --- a/arch/arm/mach-k3/am6_init.c +++ b/arch/arm/mach-k3/am6_init.c @@ -9,6 +9,7 @@ #include <common.h> #include <fdt_support.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <spl.h> #include <asm/arch/hardware.h> diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index 8b54e0cf5296..4fbf14843e0b 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -12,6 +12,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include "common.h" #include <dm.h> #include <remoteproc.h> diff --git a/arch/arm/mach-k3/sysfw-loader.c b/arch/arm/mach-k3/sysfw-loader.c index 708d9c8508e8..0bacfc4d0770 100644 --- a/arch/arm/mach-k3/sysfw-loader.c +++ b/arch/arm/mach-k3/sysfw-loader.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <remoteproc.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/soc/ti/ti_sci_protocol.h> #include <g_dnl.h> #include <usb.h> diff --git a/arch/arm/mach-mediatek/mt7623/init.c b/arch/arm/mach-mediatek/mt7623/init.c index 2778e260e024..5d837e059719 100644 --- a/arch/arm/mach-mediatek/mt7623/init.c +++ b/arch/arm/mach-mediatek/mt7623/init.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/io.h> #include <linux/sizes.h> #include <asm/arch/misc.h> diff --git a/arch/arm/mach-mediatek/mt7629/init.c b/arch/arm/mach-mediatek/mt7629/init.c index 1f102dddd4f9..0130554ff35c 100644 --- a/arch/arm/mach-mediatek/mt7629/init.c +++ b/arch/arm/mach-mediatek/mt7629/init.c @@ -12,6 +12,7 @@ #include <log.h> #include <ram.h> #include <asm/arch/misc.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <dm/uclass.h> #include <linux/bitops.h> diff --git a/arch/arm/mach-mediatek/mt8512/init.c b/arch/arm/mach-mediatek/mt8512/init.c index aa779f437663..c14e7d22e6fc 100644 --- a/arch/arm/mach-mediatek/mt8512/init.c +++ b/arch/arm/mach-mediatek/mt8512/init.c @@ -17,6 +17,7 @@ #include <asm/arch/misc.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <dm/uclass.h> #include <dt-bindings/clock/mt8512-clk.h> diff --git a/arch/arm/mach-mediatek/mt8516/init.c b/arch/arm/mach-mediatek/mt8516/init.c index 2ffa5595cfc2..3771152fb3ce 100644 --- a/arch/arm/mach-mediatek/mt8516/init.c +++ b/arch/arm/mach-mediatek/mt8516/init.c @@ -15,6 +15,7 @@ #include <asm/arch/misc.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <dm/uclass.h> #include <dt-bindings/clock/mt8516-clk.h> diff --git a/arch/arm/mach-mediatek/mt8518/init.c b/arch/arm/mach-mediatek/mt8518/init.c index 531a403da1b0..28b00c3dec89 100644 --- a/arch/arm/mach-mediatek/mt8518/init.c +++ b/arch/arm/mach-mediatek/mt8518/init.c @@ -16,6 +16,7 @@ #include <asm/arch/misc.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <dm/uclass.h> #include <dt-bindings/clock/mt8518-clk.h> diff --git a/arch/arm/mach-meson/board-axg.c b/arch/arm/mach-meson/board-axg.c index 0d4eda93b8c3..3b14bc998944 100644 --- a/arch/arm/mach-meson/board-axg.c +++ b/arch/arm/mach-meson/board-axg.c @@ -11,6 +11,7 @@ #include <asm/arch/eth.h> #include <asm/arch/axg.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv8/mmu.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-meson/board-common.c b/arch/arm/mach-meson/board-common.c index 7ea0ed479474..34b3c8f399dd 100644 --- a/arch/arm/mach-meson/board-common.c +++ b/arch/arm/mach-meson/board-common.c @@ -11,6 +11,7 @@ #include <asm/arch/boot.h> #include <env.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/libfdt.h> #include <linux/err.h> diff --git a/arch/arm/mach-meson/board-g12a.c b/arch/arm/mach-meson/board-g12a.c index 14127ca737c1..bb75d4f8ad37 100644 --- a/arch/arm/mach-meson/board-g12a.c +++ b/arch/arm/mach-meson/board-g12a.c @@ -13,6 +13,7 @@ #include <asm/arch/g12a.h> #include <asm/arch/mem.h> #include <asm/arch/meson-vpu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv8/mmu.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-meson/board-gx.c b/arch/arm/mach-meson/board-gx.c index 7a0e70359662..f5273f42af66 100644 --- a/arch/arm/mach-meson/board-gx.c +++ b/arch/arm/mach-meson/board-gx.c @@ -12,6 +12,7 @@ #include <asm/arch/gx.h> #include <asm/arch/mem.h> #include <asm/arch/meson-vpu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv8/mmu.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-meson/board-info.c b/arch/arm/mach-meson/board-info.c index 90e7dfaa3ce9..d16d3f194dba 100644 --- a/arch/arm/mach-meson/board-info.c +++ b/arch/arm/mach-meson/board-info.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <linux/bitfield.h> diff --git a/arch/arm/mach-meson/sm.c b/arch/arm/mach-meson/sm.c index ebbb880b71ea..1a8f23cb1faa 100644 --- a/arch/arm/mach-meson/sm.c +++ b/arch/arm/mach-meson/sm.c @@ -11,6 +11,7 @@ #include <log.h> #include <asm/arch/sm.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/bitops.h> #include <linux/err.h> diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index c8c065e93c3b..fa687d8abbbd 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -8,6 +8,7 @@ #include <fdtdec.h> #include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/libfdt.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-mvebu/armada3700/cpu.c b/arch/arm/mach-mvebu/armada3700/cpu.c index e438b4922e14..70f76c7d7074 100644 --- a/arch/arm/mach-mvebu/armada3700/cpu.c +++ b/arch/arm/mach-mvebu/armada3700/cpu.c @@ -9,6 +9,7 @@ #include <dm.h> #include <fdtdec.h> #include <init.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/libfdt.h> #include <asm/io.h> diff --git a/arch/arm/mach-mvebu/armada8k/dram.c b/arch/arm/mach-mvebu/armada8k/dram.c index 3da9fa589d27..bab375e18acc 100644 --- a/arch/arm/mach-mvebu/armada8k/dram.c +++ b/arch/arm/mach-mvebu/armada8k/dram.c @@ -6,6 +6,7 @@ #include <common.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <asm/system.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-mvebu/dram.c b/arch/arm/mach-mvebu/dram.c index 6c6f8d8c5c57..349e0cc4c180 100644 --- a/arch/arm/mach-mvebu/dram.c +++ b/arch/arm/mach-mvebu/dram.c @@ -8,6 +8,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index f645befb2c04..16ebb7a59e55 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -11,6 +11,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/arch/arm/mach-nexell/cmd_boot_linux.c b/arch/arm/mach-nexell/cmd_boot_linux.c index f2dedfe16257..9b38d38ddb5b 100644 --- a/arch/arm/mach-nexell/cmd_boot_linux.c +++ b/arch/arm/mach-nexell/cmd_boot_linux.c @@ -11,6 +11,7 @@ #include <errno.h> #include <image.h> #include <fdt_support.h> +#include <asm/global_data.h>
#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_CLI_FRAMEWORK)
diff --git a/arch/arm/mach-octeontx/cpu.c b/arch/arm/mach-octeontx/cpu.c index 9c29c31393cc..ce5f2b42d72f 100644 --- a/arch/arm/mach-octeontx/cpu.c +++ b/arch/arm/mach-octeontx/cpu.c @@ -7,6 +7,7 @@
#include <common.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/board.h>
diff --git a/arch/arm/mach-octeontx2/cpu.c b/arch/arm/mach-octeontx2/cpu.c index 2a6d5e86613c..87868152b7bb 100644 --- a/arch/arm/mach-octeontx2/cpu.c +++ b/arch/arm/mach-octeontx2/cpu.c @@ -7,6 +7,7 @@
diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index e17898d8fbfe..ef33b3ca1b4a 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -26,6 +26,7 @@ #include <asm/arch/mem.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index cb9d7fdb1563..05efe04dc359 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -11,6 +11,7 @@ #include <ahci.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/omap_common.h> #include <asm/arch/omap.h> #include <asm/arch/mmc_host_def.h> diff --git a/arch/arm/mach-omap2/hwinit-common.c b/arch/arm/mach-omap2/hwinit-common.c index 7a7086776ee0..3da50f974dc0 100644 --- a/arch/arm/mach-omap2/hwinit-common.c +++ b/arch/arm/mach-omap2/hwinit-common.c @@ -16,6 +16,7 @@ #include <init.h> #include <spl.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/emif.h> #include <asm/omap_common.h> diff --git a/arch/arm/mach-omap2/omap-cache.c b/arch/arm/mach-omap2/omap-cache.c index 502ea6987ab7..1b246f844a84 100644 --- a/arch/arm/mach-omap2/omap-cache.c +++ b/arch/arm/mach-omap2/omap-cache.c @@ -15,6 +15,7 @@ #include <cpu_func.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-omap2/omap3/am35x_musb.c b/arch/arm/mach-omap2/omap3/am35x_musb.c index 026e5d2d130b..1121acc00589 100644 --- a/arch/arm/mach-omap2/omap3/am35x_musb.c +++ b/arch/arm/mach-omap2/omap3/am35x_musb.c @@ -10,6 +10,7 @@
#include <common.h> #include <log.h> +#include <dm/device.h> #include <asm/io.h> #include <asm/arch/am35x_def.h>
diff --git a/arch/arm/mach-omap2/omap3/emif4.c b/arch/arm/mach-omap2/omap3/emif4.c index 4cfa13238810..df6e9ce1d6ce 100644 --- a/arch/arm/mach-omap2/omap3/emif4.c +++ b/arch/arm/mach-omap2/omap3/emif4.c @@ -11,6 +11,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mem.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-omap2/omap3/sdrc.c b/arch/arm/mach-omap2/omap3/sdrc.c index 1d65ed622704..4d85b1dee991 100644 --- a/arch/arm/mach-omap2/omap3/sdrc.c +++ b/arch/arm/mach-omap2/omap3/sdrc.c @@ -23,6 +23,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mem.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-omap2/timer.c b/arch/arm/mach-omap2/timer.c index bcfba16a08e5..82b10f6b2487 100644 --- a/arch/arm/mach-omap2/timer.c +++ b/arch/arm/mach-omap2/timer.c @@ -18,6 +18,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-orion5x/dram.c b/arch/arm/mach-orion5x/dram.c index 33f65db48ea4..c9a3750e48de 100644 --- a/arch/arm/mach-orion5x/dram.c +++ b/arch/arm/mach-orion5x/dram.c @@ -12,6 +12,7 @@ #include <config.h> #include <init.h> #include <asm/arch/cpu.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-orion5x/timer.c b/arch/arm/mach-orion5x/timer.c index 4926bb777960..0adf3dcc6483 100644 --- a/arch/arm/mach-orion5x/timer.c +++ b/arch/arm/mach-orion5x/timer.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/arch/arm/mach-owl/soc.c b/arch/arm/mach-owl/soc.c index fd6ee7c1c0f2..4d2b9d0b0ebc 100644 --- a/arch/arm/mach-owl/soc.c +++ b/arch/arm/mach-owl/soc.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/arm-smccc.h> #include <linux/psci.h> #include <common.h> diff --git a/arch/arm/mach-rmobile/memmap-gen3.c b/arch/arm/mach-rmobile/memmap-gen3.c index 578cb9bfd3f8..a68eb806b353 100644 --- a/arch/arm/mach-rmobile/memmap-gen3.c +++ b/arch/arm/mach-rmobile/memmap-gen3.c @@ -8,6 +8,7 @@ #include <common.h> #include <cpu_func.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h>
#define GEN3_NR_REGIONS 16
diff --git a/arch/arm/mach-rockchip/board.c b/arch/arm/mach-rockchip/board.c index ba4da72b3910..c386b52987e8 100644 --- a/arch/arm/mach-rockchip/board.c +++ b/arch/arm/mach-rockchip/board.c @@ -12,6 +12,7 @@ #include <ram.h> #include <syscon.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/boot_mode.h> #include <asm/arch-rockchip/clock.h> diff --git a/arch/arm/mach-rockchip/rk3036/rk3036.c b/arch/arm/mach-rockchip/rk3036/rk3036.c index e9e020ff3f58..0a072cf03a88 100644 --- a/arch/arm/mach-rockchip/rk3036/rk3036.c +++ b/arch/arm/mach-rockchip/rk3036/rk3036.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/grf_rk3036.h> #include <asm/arch-rockchip/hardware.h> diff --git a/arch/arm/mach-rockchip/rk3128/rk3128.c b/arch/arm/mach-rockchip/rk3128/rk3128.c index 740bd2ba0770..01dbfa75cb2b 100644 --- a/arch/arm/mach-rockchip/rk3128/rk3128.c +++ b/arch/arm/mach-rockchip/rk3128/rk3128.c @@ -4,6 +4,7 @@ */ #include <common.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-rockchip/rk3188/rk3188.c b/arch/arm/mach-rockchip/rk3188/rk3188.c index 222953ab94ad..ad8c6cd1d794 100644 --- a/arch/arm/mach-rockchip/rk3188/rk3188.c +++ b/arch/arm/mach-rockchip/rk3188/rk3188.c @@ -9,6 +9,7 @@ #include <led.h> #include <log.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> diff --git a/arch/arm/mach-rockchip/rk3288/rk3288.c b/arch/arm/mach-rockchip/rk3288/rk3288.c index 1a4ecdf62546..bc20bc5ab909 100644 --- a/arch/arm/mach-rockchip/rk3288/rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/rk3288.c @@ -10,6 +10,7 @@ #include <init.h> #include <malloc.h> #include <asm/armv7.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> diff --git a/arch/arm/mach-rockchip/rk3308/rk3308.c b/arch/arm/mach-rockchip/rk3308/rk3308.c index 8e8214cf7ecb..70fe0d0ac350 100644 --- a/arch/arm/mach-rockchip/rk3308/rk3308.c +++ b/arch/arm/mach-rockchip/rk3308/rk3308.c @@ -5,6 +5,7 @@ #include <common.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/grf_rk3308.h> #include <asm/arch-rockchip/hardware.h> diff --git a/arch/arm/mach-rockchip/rk3328/rk3328.c b/arch/arm/mach-rockchip/rk3328/rk3328.c index 7c85b2663c88..ec3336cb49af 100644 --- a/arch/arm/mach-rockchip/rk3328/rk3328.c +++ b/arch/arm/mach-rockchip/rk3328/rk3328.c @@ -10,6 +10,7 @@ #include <asm/arch-rockchip/grf_rk3328.h> #include <asm/arch-rockchip/uart.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/mach-rockchip/rk3368/rk3368.c b/arch/arm/mach-rockchip/rk3368/rk3368.c index 1c6d65a58870..9b7132d471c3 100644 --- a/arch/arm/mach-rockchip/rk3368/rk3368.c +++ b/arch/arm/mach-rockchip/rk3368/rk3368.c @@ -8,6 +8,7 @@ #include <init.h> #include <syscon.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index c6434839719d..869d2159bea6 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -11,6 +11,7 @@ #include <spl_gpio.h> #include <syscon.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> diff --git a/arch/arm/mach-rockchip/sdram.c b/arch/arm/mach-rockchip/sdram.c index 4c637b776735..ed07ece15a4d 100644 --- a/arch/arm/mach-rockchip/sdram.c +++ b/arch/arm/mach-rockchip/sdram.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <ram.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/sdram.h> #include <dm/uclass-internal.h> diff --git a/arch/arm/mach-rockchip/spl-boot-order.c b/arch/arm/mach-rockchip/spl-boot-order.c index 8ccd5afb5609..93b8e7de4d0d 100644 --- a/arch/arm/mach-rockchip/spl-boot-order.c +++ b/arch/arm/mach-rockchip/spl-boot-order.c @@ -8,6 +8,7 @@ #include <log.h> #include <mmc.h> #include <spl.h> +#include <asm/global_data.h>
#if CONFIG_IS_ENABLED(OF_LIBFDT) /** diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index f148d48b6a35..4b5c22dc1382 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -13,6 +13,7 @@ #include <ram.h> #include <spl.h> #include <asm/arch-rockchip/bootrom.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/arch/arm/mach-snapdragon/pinctrl-snapdragon.h b/arch/arm/mach-snapdragon/pinctrl-snapdragon.h index 24f8863f59b5..61d466f4d84b 100644 --- a/arch/arm/mach-snapdragon/pinctrl-snapdragon.h +++ b/arch/arm/mach-snapdragon/pinctrl-snapdragon.h @@ -8,7 +8,7 @@ #ifndef _PINCTRL_SNAPDRAGON_H #define _PINCTRL_SNAPDRAGON_H
-#include <common.h> +struct udevice;
struct msm_pinctrl_data { int pin_count; diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach-socfpga/board.c index 7993c27646cf..2a6af9d1f8ae 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -12,6 +12,7 @@ #include <asm/arch/reset_manager.h> #include <asm/arch/clock_manager.h> #include <asm/arch/misc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <log.h> #include <usb.h> diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index a4a97b6a0fcf..f0b15f770cc5 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -7,6 +7,7 @@ #include <command.h> #include <init.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock_manager.h>
diff --git a/arch/arm/mach-socfpga/clock_manager_agilex.c b/arch/arm/mach-socfpga/clock_manager_agilex.c index a960176da77c..6377f2ce3bf9 100644 --- a/arch/arm/mach-socfpga/clock_manager_agilex.c +++ b/arch/arm/mach-socfpga/clock_manager_agilex.c @@ -11,6 +11,7 @@ #include <malloc.h> #include <asm/arch/clock_manager.h> #include <asm/arch/system_manager.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dt-bindings/clock/agilex-clock.h>
diff --git a/arch/arm/mach-socfpga/clock_manager_s10.c b/arch/arm/mach-socfpga/clock_manager_s10.c index 05e42127b57b..642dcbb0ac04 100644 --- a/arch/arm/mach-socfpga/clock_manager_s10.c +++ b/arch/arm/mach-socfpga/clock_manager_s10.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock_manager.h> #include <asm/arch/handoff_s10.h> diff --git a/arch/arm/mach-socfpga/mailbox_s10.c b/arch/arm/mach-socfpga/mailbox_s10.c index 429444f06940..7dcdae813615 100644 --- a/arch/arm/mach-socfpga/mailbox_s10.c +++ b/arch/arm/mach-socfpga/mailbox_s10.c @@ -7,6 +7,7 @@ #include <common.h> #include <hang.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mailbox_s10.h> #include <asm/arch/system_manager.h> diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index ac2b891fadea..64a7c9d652c7 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -9,6 +9,7 @@ #include <hang.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <fdtdec.h> diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index 7209e8d6db78..4edf4f9b5c16 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -6,6 +6,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <env.h> #include <errno.h> diff --git a/arch/arm/mach-socfpga/misc_s10.c b/arch/arm/mach-socfpga/misc_s10.c index 0d67b0fd8360..50c7f19ae14b 100644 --- a/arch/arm/mach-socfpga/misc_s10.c +++ b/arch/arm/mach-socfpga/misc_s10.c @@ -10,6 +10,7 @@ #include <errno.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mailbox_s10.h> #include <asm/arch/misc.h> diff --git a/arch/arm/mach-socfpga/mmu-arm64_s10.c b/arch/arm/mach-socfpga/mmu-arm64_s10.c index 670ceb92ae3d..a55b7b7cf3b5 100644 --- a/arch/arm/mach-socfpga/mmu-arm64_s10.c +++ b/arch/arm/mach-socfpga/mmu-arm64_s10.c @@ -6,6 +6,7 @@
diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index aa5299415a74..27c030801134 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -3,6 +3,7 @@ * Copyright (C) 2016-2017 Intel Corporation */
+#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/fpga_manager.h> #include <asm/arch/misc.h> diff --git a/arch/arm/mach-socfpga/reset_manager_s10.c b/arch/arm/mach-socfpga/reset_manager_s10.c index af8f2c087310..d2337bd4d626 100644 --- a/arch/arm/mach-socfpga/reset_manager_s10.c +++ b/arch/arm/mach-socfpga/reset_manager_s10.c @@ -6,6 +6,7 @@
#include <common.h> #include <hang.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/reset_manager.h> #include <asm/arch/smc_api.h> diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c index 45aea4ab6cc3..92231b5ba3c6 100644 --- a/arch/arm/mach-socfpga/spl_a10.c +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -7,6 +7,7 @@ #include <cpu_func.h> #include <hang.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/pl310.h> #include <asm/u-boot.h> diff --git a/arch/arm/mach-socfpga/spl_agilex.c b/arch/arm/mach-socfpga/spl_agilex.c index 78b5d7c8d987..71b17ce3a599 100644 --- a/arch/arm/mach-socfpga/spl_agilex.c +++ b/arch/arm/mach-socfpga/spl_agilex.c @@ -6,6 +6,7 @@
#include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/u-boot.h> #include <asm/utils.h> diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index 5a7c5ef76d5d..7c716117685c 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -7,6 +7,7 @@ #include <hang.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/u-boot.h> #include <asm/utils.h> diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index daed05653ad1..955a1161e898 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -7,6 +7,7 @@ #include <hang.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/u-boot.h> #include <asm/utils.h> diff --git a/arch/arm/mach-socfpga/system_manager_s10.c b/arch/arm/mach-socfpga/system_manager_s10.c index cdda881efd71..c123cc96445d 100644 --- a/arch/arm/mach-socfpga/system_manager_s10.c +++ b/arch/arm/mach-socfpga/system_manager_s10.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/system_manager.h>
diff --git a/arch/arm/mach-stm32mp/boot_params.c b/arch/arm/mach-stm32mp/boot_params.c index 13322e34d606..84647e70398b 100644 --- a/arch/arm/mach-stm32mp/boot_params.c +++ b/arch/arm/mach-stm32mp/boot_params.c @@ -7,6 +7,7 @@
#include <common.h> #include <log.h> +#include <linux/libfdt.h> #include <asm/sections.h> #include <asm/system.h>
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index a8e7158c1f41..d0518d12235f 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -11,6 +11,7 @@ #include <mmc.h> #include <part.h> #include <asm/arch/stm32mp1_smc.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <jffs2/load_kernel.h> #include <linux/list.h> diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c index 68d841bd9d18..373ca2088611 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c @@ -13,6 +13,7 @@ #include <dm/lists.h> #include <dm/device-internal.h> #include <linux/delay.h> +#include <asm/global_data.h> #include "stm32prog.h"
/* - configuration part -----------------------------*/ diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 717f80e9ff3d..3faa4ec18a4f 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -18,6 +18,7 @@ #include <asm/arch/bsec.h> #include <asm/arch/stm32.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/uclass.h> #include <linux/bitops.h> diff --git a/arch/arm/mach-stm32mp/dram_init.c b/arch/arm/mach-stm32mp/dram_init.c index 32b177bb798b..ad6977fd4454 100644 --- a/arch/arm/mach-stm32mp/dram_init.c +++ b/arch/arm/mach-stm32mp/dram_init.c @@ -12,6 +12,7 @@ #include <lmb.h> #include <log.h> #include <ram.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-stm32mp/fdt.c b/arch/arm/mach-stm32mp/fdt.c index aaedeac8d5bc..ce2fe0206f04 100644 --- a/arch/arm/mach-stm32mp/fdt.c +++ b/arch/arm/mach-stm32mp/fdt.c @@ -6,6 +6,7 @@ #define LOG_CATEGORY LOGC_ARCH
#include <common.h> +#include <fdtdec.h> #include <fdt_support.h> #include <log.h> #include <tee.h> diff --git a/arch/arm/mach-stm32mp/spl.c b/arch/arm/mach-stm32mp/spl.c index 0c50ad54df6a..b53659a698ad 100644 --- a/arch/arm/mach-stm32mp/spl.c +++ b/arch/arm/mach-stm32mp/spl.c @@ -13,6 +13,7 @@ #include <log.h> #include <spl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <linux/libfdt.h> diff --git a/arch/arm/mach-tegra/board.c b/arch/arm/mach-tegra/board.c index 9de9836c8d25..21852e2388f7 100644 --- a/arch/arm/mach-tegra/board.c +++ b/arch/arm/mach-tegra/board.c @@ -12,6 +12,7 @@ #include <ns16550.h> #include <spl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #if IS_ENABLED(CONFIG_TEGRA_CLKRST) #include <asm/arch/clock.h> diff --git a/arch/arm/mach-tegra/board2.c b/arch/arm/mach-tegra/board2.c index 8569ad7c6fcb..8950e678a619 100644 --- a/arch/arm/mach-tegra/board2.c +++ b/arch/arm/mach-tegra/board2.c @@ -12,6 +12,7 @@ #include <log.h> #include <ns16550.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-tegra/ap.h> #include <asm/arch-tegra/board.h> diff --git a/arch/arm/mach-tegra/cboot.c b/arch/arm/mach-tegra/cboot.c index 16c4cf306ec8..bb46fb23ff79 100644 --- a/arch/arm/mach-tegra/cboot.c +++ b/arch/arm/mach-tegra/cboot.c @@ -14,6 +14,7 @@ #include <net.h> #include <stdlib.h> #include <string.h> +#include <asm/global_data.h>
#include <linux/ctype.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-tegra/emc.c b/arch/arm/mach-tegra/emc.c index 66628933b653..2eea14b5a744 100644 --- a/arch/arm/mach-tegra/emc.c +++ b/arch/arm/mach-tegra/emc.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include "emc.h" #include <asm/io.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-tegra/pmc.c b/arch/arm/mach-tegra/pmc.c index cdc8493efd8e..93db63e104a1 100644 --- a/arch/arm/mach-tegra/pmc.c +++ b/arch/arm/mach-tegra/pmc.c @@ -6,6 +6,7 @@ #include <common.h> #include <cpu_func.h> #include <log.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-tegra/tegra124/xusb-padctl.c b/arch/arm/mach-tegra/tegra124/xusb-padctl.c index 38afc3cbe6de..d3c7719c3dda 100644 --- a/arch/arm/mach-tegra/tegra124/xusb-padctl.c +++ b/arch/arm/mach-tegra/tegra124/xusb-padctl.c @@ -11,6 +11,7 @@ #include <dm/of_access.h> #include <dm/ofnode.h> #include <linux/delay.h> +#include <asm/global_data.h>
#include "../xusb-padctl-common.h"
diff --git a/arch/arm/mach-tegra/tegra20/warmboot.c b/arch/arm/mach-tegra/tegra20/warmboot.c index ddde4a667726..3d3758f6e6f4 100644 --- a/arch/arm/mach-tegra/tegra20/warmboot.c +++ b/arch/arm/mach-tegra/tegra20/warmboot.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/errno.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-tegra/tegra210/xusb-padctl.c b/arch/arm/mach-tegra/tegra210/xusb-padctl.c index d160ce4c999e..c414dfd3b86f 100644 --- a/arch/arm/mach-tegra/tegra210/xusb-padctl.c +++ b/arch/arm/mach-tegra/tegra210/xusb-padctl.c @@ -8,6 +8,7 @@ #include <common.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <dm/of_access.h> #include <dm/ofnode.h> #include <linux/delay.h> diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index 8c5e5bb58f65..b33c4b19389b 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -8,6 +8,7 @@ #include <env.h> #include <init.h> #include <spl.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <stdio.h> #include <linux/printk.h> diff --git a/arch/arm/mach-versal/clk.c b/arch/arm/mach-versal/clk.c index b1e34796d0d1..249e050cc8d6 100644 --- a/arch/arm/mach-versal/clk.c +++ b/arch/arm/mach-versal/clk.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <time.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-versal/cpu.c b/arch/arm/mach-versal/cpu.c index 61c0b663fcfe..a35aac2c02c2 100644 --- a/arch/arm/mach-versal/cpu.c +++ b/arch/arm/mach-versal/cpu.c @@ -8,6 +8,7 @@ #include <init.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-versal/mp.c b/arch/arm/mach-versal/mp.c index 4b434b0ac3f7..c97c311d3130 100644 --- a/arch/arm/mach-versal/mp.c +++ b/arch/arm/mach-versal/mp.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-zynq/clk.c b/arch/arm/mach-zynq/clk.c index 856047613c19..27f6bf218321 100644 --- a/arch/arm/mach-zynq/clk.c +++ b/arch/arm/mach-zynq/clk.c @@ -9,6 +9,7 @@ #include <init.h> #include <malloc.h> #include <asm/arch/clk.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-zynq/timer.c b/arch/arm/mach-zynq/timer.c index 37193157d9ec..a51822a53059 100644 --- a/arch/arm/mach-zynq/timer.c +++ b/arch/arm/mach-zynq/timer.c @@ -34,6 +34,7 @@ #include <init.h> #include <time.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/clk.h> diff --git a/arch/arm/mach-zynqmp-r5/cpu.c b/arch/arm/mach-zynqmp-r5/cpu.c index 87c1d75f9f3c..d841c3a5b377 100644 --- a/arch/arm/mach-zynqmp-r5/cpu.c +++ b/arch/arm/mach-zynqmp-r5/cpu.c @@ -7,6 +7,7 @@ #include <cpu_func.h> #include <init.h> #include <asm/armv7_mpu.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-zynqmp/clk.c b/arch/arm/mach-zynqmp/clk.c index 5067b339c218..1e6e726e8792 100644 --- a/arch/arm/mach-zynqmp/clk.c +++ b/arch/arm/mach-zynqmp/clk.c @@ -10,6 +10,7 @@ #include <asm/arch/clk.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h>
diff --git a/arch/arm/mach-zynqmp/cpu.c b/arch/arm/mach-zynqmp/cpu.c index 3eb8e8f44875..29743cae5aab 100644 --- a/arch/arm/mach-zynqmp/cpu.c +++ b/arch/arm/mach-zynqmp/cpu.c @@ -11,6 +11,7 @@ #include <asm/arch/sys_proto.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <zynqmp_firmware.h> #include <asm/cache.h> diff --git a/arch/m68k/cpu/mcf5227x/cpu.c b/arch/m68k/cpu/mcf5227x/cpu.c index 5ea6158c8094..a7adf64f0de0 100644 --- a/arch/m68k/cpu/mcf5227x/cpu.c +++ b/arch/m68k/cpu/mcf5227x/cpu.c @@ -13,6 +13,7 @@ #include <vsprintf.h> #include <watchdog.h> #include <command.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf5227x/speed.c b/arch/m68k/cpu/mcf5227x/speed.c index 207f4534807e..fa9d5cb7887c 100644 --- a/arch/m68k/cpu/mcf5227x/speed.c +++ b/arch/m68k/cpu/mcf5227x/speed.c @@ -7,6 +7,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <asm/processor.h>
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf523x/cpu.c b/arch/m68k/cpu/mcf523x/cpu.c index 8664231b5a14..8d3ab6f3fb25 100644 --- a/arch/m68k/cpu/mcf523x/cpu.c +++ b/arch/m68k/cpu/mcf523x/cpu.c @@ -15,6 +15,7 @@ #include <watchdog.h> #include <command.h> #include <netdev.h> +#include <asm/global_data.h>
#include <asm/immap.h> #include <asm/io.h> diff --git a/arch/m68k/cpu/mcf523x/speed.c b/arch/m68k/cpu/mcf523x/speed.c index 2f65ac23182c..f41f977d7f5f 100644 --- a/arch/m68k/cpu/mcf523x/speed.c +++ b/arch/m68k/cpu/mcf523x/speed.c @@ -10,6 +10,7 @@
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf52x2/cpu.c b/arch/m68k/cpu/mcf52x2/cpu.c index 8898a7562adf..0676e3914105 100644 --- a/arch/m68k/cpu/mcf52x2/cpu.c +++ b/arch/m68k/cpu/mcf52x2/cpu.c @@ -19,6 +19,7 @@ #include <vsprintf.h> #include <watchdog.h> #include <command.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <netdev.h> diff --git a/arch/m68k/cpu/mcf52x2/speed.c b/arch/m68k/cpu/mcf52x2/speed.c index 751c83a4fc08..045908a13d40 100644 --- a/arch/m68k/cpu/mcf52x2/speed.c +++ b/arch/m68k/cpu/mcf52x2/speed.c @@ -9,6 +9,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/immap.h> #include <asm/io.h> diff --git a/arch/m68k/cpu/mcf530x/speed.c b/arch/m68k/cpu/mcf530x/speed.c index cf53dfeb150a..03d9abeb182b 100644 --- a/arch/m68k/cpu/mcf530x/speed.c +++ b/arch/m68k/cpu/mcf530x/speed.c @@ -6,6 +6,7 @@
diff --git a/arch/m68k/cpu/mcf532x/cpu.c b/arch/m68k/cpu/mcf532x/cpu.c index f1e6f734eb44..d37dd3defb73 100644 --- a/arch/m68k/cpu/mcf532x/cpu.c +++ b/arch/m68k/cpu/mcf532x/cpu.c @@ -15,6 +15,7 @@ #include <watchdog.h> #include <command.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf532x/speed.c b/arch/m68k/cpu/mcf532x/speed.c index 0f54ea4b6a8b..e2985792d96f 100644 --- a/arch/m68k/cpu/mcf532x/speed.c +++ b/arch/m68k/cpu/mcf532x/speed.c @@ -10,6 +10,7 @@
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf5445x/cpu.c b/arch/m68k/cpu/mcf5445x/cpu.c index ebe15ca518c4..ac1e59168161 100644 --- a/arch/m68k/cpu/mcf5445x/cpu.c +++ b/arch/m68k/cpu/mcf5445x/cpu.c @@ -15,6 +15,7 @@ #include <watchdog.h> #include <command.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf5445x/speed.c b/arch/m68k/cpu/mcf5445x/speed.c index eaa3b39bec69..a0b9af8866b3 100644 --- a/arch/m68k/cpu/mcf5445x/speed.c +++ b/arch/m68k/cpu/mcf5445x/speed.c @@ -7,6 +7,7 @@
#include <asm/immap.h> diff --git a/arch/m68k/cpu/mcf547x_8x/cpu.c b/arch/m68k/cpu/mcf547x_8x/cpu.c index e53adeb46b55..c1361e705799 100644 --- a/arch/m68k/cpu/mcf547x_8x/cpu.c +++ b/arch/m68k/cpu/mcf547x_8x/cpu.c @@ -15,6 +15,7 @@ #include <watchdog.h> #include <command.h> #include <netdev.h> +#include <asm/global_data.h>
#include <asm/immap.h> #include <asm/io.h> diff --git a/arch/m68k/cpu/mcf547x_8x/slicetimer.c b/arch/m68k/cpu/mcf547x_8x/slicetimer.c index 33b4cff4ec72..dc076fc6e814 100644 --- a/arch/m68k/cpu/mcf547x_8x/slicetimer.c +++ b/arch/m68k/cpu/mcf547x_8x/slicetimer.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <irq_func.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/timer.h> diff --git a/arch/m68k/cpu/mcf547x_8x/speed.c b/arch/m68k/cpu/mcf547x_8x/speed.c index bc22560ed2cf..bbcf601f38fb 100644 --- a/arch/m68k/cpu/mcf547x_8x/speed.c +++ b/arch/m68k/cpu/mcf547x_8x/speed.c @@ -10,6 +10,7 @@
#include <asm/immap.h> diff --git a/arch/m68k/lib/bdinfo.c b/arch/m68k/lib/bdinfo.c index 404e5f19ed82..9ec56fd3418f 100644 --- a/arch/m68k/lib/bdinfo.c +++ b/arch/m68k/lib/bdinfo.c @@ -8,6 +8,7 @@
diff --git a/arch/m68k/lib/bootm.c b/arch/m68k/lib/bootm.c index 320451144fd3..51a6f938586d 100644 --- a/arch/m68k/lib/bootm.c +++ b/arch/m68k/lib/bootm.c @@ -11,6 +11,7 @@ #include <image.h> #include <lmb.h> #include <log.h> +#include <asm/global_data.h> #include <u-boot/zlib.h> #include <bzlib.h> #include <watchdog.h> diff --git a/arch/m68k/lib/fec.c b/arch/m68k/lib/fec.c index dde353ad17fd..eecea7a02354 100644 --- a/arch/m68k/lib/fec.c +++ b/arch/m68k/lib/fec.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h>
diff --git a/arch/m68k/lib/time.c b/arch/m68k/lib/time.c index a3eb6db54be7..cbe29e72a86e 100644 --- a/arch/m68k/lib/time.c +++ b/arch/m68k/lib/time.c @@ -10,6 +10,7 @@ #include <init.h> #include <irq_func.h> #include <time.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/timer.h> diff --git a/arch/microblaze/cpu/interrupts.c b/arch/microblaze/cpu/interrupts.c index 829ae26ad274..fe65f3728fdb 100644 --- a/arch/microblaze/cpu/interrupts.c +++ b/arch/microblaze/cpu/interrupts.c @@ -13,6 +13,7 @@ #include <irq_func.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/microblaze_intc.h> #include <asm/asm.h>
diff --git a/arch/microblaze/cpu/timer.c b/arch/microblaze/cpu/timer.c index 1b4617311c57..647bdcd5ba52 100644 --- a/arch/microblaze/cpu/timer.c +++ b/arch/microblaze/cpu/timer.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <asm/microblaze_timer.h> #include <asm/microblaze_intc.h> #include <linux/delay.h> diff --git a/arch/microblaze/lib/bootm.c b/arch/microblaze/lib/bootm.c index d2ea1453be04..6695ac63c774 100644 --- a/arch/microblaze/lib/bootm.c +++ b/arch/microblaze/lib/bootm.c @@ -18,6 +18,7 @@ #include <lmb.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <u-boot/zlib.h> #include <asm/byteorder.h>
diff --git a/arch/mips/include/asm/io.h b/arch/mips/include/asm/io.h index 7c40e415c74f..d3ad66930131 100644 --- a/arch/mips/include/asm/io.h +++ b/arch/mips/include/asm/io.h @@ -16,6 +16,7 @@ #include <asm/addrspace.h> #include <asm/byteorder.h> #include <asm/cpu-features.h> +#include <asm/global_data.h> #include <asm/pgtable-bits.h> #include <asm/processor.h> #include <asm/string.h> diff --git a/arch/mips/lib/boot.c b/arch/mips/lib/boot.c index 6ef9109022e3..1b29d637ce9b 100644 --- a/arch/mips/lib/boot.c +++ b/arch/mips/lib/boot.c @@ -6,6 +6,7 @@ #include <common.h> #include <command.h> #include <cpu_func.h> +#include <asm/global_data.h>
diff --git a/arch/mips/lib/bootm.c b/arch/mips/lib/bootm.c index d5c99d891cd0..fde90fced44f 100644 --- a/arch/mips/lib/bootm.c +++ b/arch/mips/lib/bootm.c @@ -12,6 +12,7 @@ #include <lmb.h> #include <log.h> #include <asm/addrspace.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/mips/lib/cache.c b/arch/mips/lib/cache.c index cf29994a7ae8..51a8f4334750 100644 --- a/arch/mips/lib/cache.c +++ b/arch/mips/lib/cache.c @@ -9,6 +9,7 @@ #include <asm/cache.h> #include <asm/cacheops.h> #include <asm/cm.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mipsregs.h> #include <asm/system.h> diff --git a/arch/mips/lib/stack.c b/arch/mips/lib/stack.c index 8f523fd6fb75..930d21856d90 100644 --- a/arch/mips/lib/stack.c +++ b/arch/mips/lib/stack.c @@ -3,6 +3,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
diff --git a/arch/mips/lib/traps.c b/arch/mips/lib/traps.c index 540ea48e32f7..7577fdd25d79 100644 --- a/arch/mips/lib/traps.c +++ b/arch/mips/lib/traps.c @@ -11,6 +11,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <cpu_func.h> #include <hang.h> diff --git a/arch/mips/mach-ath79/ar933x/clk.c b/arch/mips/mach-ath79/ar933x/clk.c index 3feb25ce71df..68d48939d7d2 100644 --- a/arch/mips/mach-ath79/ar933x/clk.c +++ b/arch/mips/mach-ath79/ar933x/clk.c @@ -5,6 +5,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/ar934x/clk.c b/arch/mips/mach-ath79/ar934x/clk.c index 9fa2225ed2be..6ed4057353a8 100644 --- a/arch/mips/mach-ath79/ar934x/clk.c +++ b/arch/mips/mach-ath79/ar934x/clk.c @@ -7,6 +7,7 @@ #include <clock_legacy.h> #include <command.h> #include <hang.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/ar934x/ddr.c b/arch/mips/mach-ath79/ar934x/ddr.c index 218f60a96cce..9df48b97ef46 100644 --- a/arch/mips/mach-ath79/ar934x/ddr.c +++ b/arch/mips/mach-ath79/ar934x/ddr.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/cpu.c b/arch/mips/mach-ath79/cpu.c index 31e87d620603..79f419088a99 100644 --- a/arch/mips/mach-ath79/cpu.c +++ b/arch/mips/mach-ath79/cpu.c @@ -7,6 +7,7 @@ #include <init.h> #include <asm/io.h> #include <asm/addrspace.h> +#include <asm/global_data.h> #include <asm/types.h> #include <mach/ath79.h> #include <mach/ar71xx_regs.h> diff --git a/arch/mips/mach-ath79/dram.c b/arch/mips/mach-ath79/dram.c index 1abe2a49e661..545b1199e106 100644 --- a/arch/mips/mach-ath79/dram.c +++ b/arch/mips/mach-ath79/dram.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/addrspace.h> #include <mach/ddr.h> diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h index 0fde5079b167..2eda38885e36 100644 --- a/arch/mips/mach-ath79/include/mach/ath79.h +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -11,6 +11,7 @@ #ifndef __ASM_MACH_ATH79_H #define __ASM_MACH_ATH79_H
+#include <asm/global_data.h> #include <linux/types.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/mips/mach-ath79/qca953x/clk.c b/arch/mips/mach-ath79/qca953x/clk.c index d450ad865233..f5438ef1c8d9 100644 --- a/arch/mips/mach-ath79/qca953x/clk.c +++ b/arch/mips/mach-ath79/qca953x/clk.c @@ -5,6 +5,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/qca956x/clk.c b/arch/mips/mach-ath79/qca956x/clk.c index 5adf6cd8159b..6a58dba91f3f 100644 --- a/arch/mips/mach-ath79/qca956x/clk.c +++ b/arch/mips/mach-ath79/qca956x/clk.c @@ -6,6 +6,7 @@ #include <common.h> #include <clock_legacy.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-ath79/qca956x/ddr.c b/arch/mips/mach-ath79/qca956x/ddr.c index e61a368141ba..f9cf8daa2242 100644 --- a/arch/mips/mach-ath79/qca956x/ddr.c +++ b/arch/mips/mach-ath79/qca956x/ddr.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/arch/mips/mach-bmips/dram.c b/arch/mips/mach-bmips/dram.c index a772a655d921..bba6cd6f4aaf 100644 --- a/arch/mips/mach-bmips/dram.c +++ b/arch/mips/mach-bmips/dram.c @@ -9,6 +9,7 @@ #include <log.h> #include <ram.h> #include <dm.h> +#include <asm/global_data.h>
diff --git a/arch/mips/mach-jz47xx/jz4780/jz4780.c b/arch/mips/mach-jz47xx/jz4780/jz4780.c index 26fcfc842c28..43f5651f8326 100644 --- a/arch/mips/mach-jz47xx/jz4780/jz4780.c +++ b/arch/mips/mach-jz47xx/jz4780/jz4780.c @@ -12,6 +12,7 @@ #include <hang.h> #include <image.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/sections.h> #include <mach/jz4780.h> diff --git a/arch/mips/mach-mscc/cpu.c b/arch/mips/mach-mscc/cpu.c index b4ffd44ea441..5bc31006aa15 100644 --- a/arch/mips/mach-mscc/cpu.c +++ b/arch/mips/mach-mscc/cpu.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/bitops.h>
#include <asm/io.h> diff --git a/arch/mips/mach-mscc/dram.c b/arch/mips/mach-mscc/dram.c index b12bac63c27d..c53a4202e0d9 100644 --- a/arch/mips/mach-mscc/dram.c +++ b/arch/mips/mach-mscc/dram.c @@ -5,6 +5,7 @@
#include <asm/io.h> #include <asm/types.h> diff --git a/arch/mips/mach-mtmips/cpu.c b/arch/mips/mach-mtmips/cpu.c index ca1967055a2e..a4b5cff61d98 100644 --- a/arch/mips/mach-mtmips/cpu.c +++ b/arch/mips/mach-mtmips/cpu.c @@ -7,6 +7,7 @@ #include <init.h> #include <malloc.h> #include <asm/addrspace.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <linux/sizes.h> diff --git a/arch/mips/mach-mtmips/ddr_cal.c b/arch/mips/mach-mtmips/ddr_cal.c index 71a53c3c9cbf..762619a960f3 100644 --- a/arch/mips/mach-mtmips/ddr_cal.c +++ b/arch/mips/mach-mtmips/ddr_cal.c @@ -8,6 +8,7 @@ #include <common.h> #include <asm/addrspace.h> #include <asm/cacheops.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <mach/mc.h> diff --git a/arch/mips/mach-mtmips/mt7628/ddr.c b/arch/mips/mach-mtmips/mt7628/ddr.c index 3df85cd144a3..b091f2ecffc7 100644 --- a/arch/mips/mach-mtmips/mt7628/ddr.c +++ b/arch/mips/mach-mtmips/mt7628/ddr.c @@ -7,6 +7,7 @@
#include <common.h> #include <asm/addrspace.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/sizes.h> diff --git a/arch/mips/mach-mtmips/mt7628/init.c b/arch/mips/mach-mtmips/mt7628/init.c index 33538647a2d6..7c531ff68679 100644 --- a/arch/mips/mach-mtmips/mt7628/init.c +++ b/arch/mips/mach-mtmips/mt7628/init.c @@ -8,6 +8,7 @@ #include <common.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <dt-bindings/clock/mt7628-clk.h> #include <linux/io.h> diff --git a/arch/mips/mach-mtmips/spl.c b/arch/mips/mach-mtmips/spl.c index 38d9e9160d2e..95201b8d7ab2 100644 --- a/arch/mips/mach-mtmips/spl.c +++ b/arch/mips/mach-mtmips/spl.c @@ -6,10 +6,10 @@ */
#include <common.h> -#include <fdt.h> #include <init.h> #include <spl.h> #include <asm/sections.h> +#include <linux/libfdt.h> #include <linux/sizes.h> #include <mach/serial.h>
diff --git a/arch/mips/mach-octeon/bootoctlinux.c b/arch/mips/mach-octeon/bootoctlinux.c index 26136902f341..f661c16d4768 100644 --- a/arch/mips/mach-octeon/bootoctlinux.c +++ b/arch/mips/mach-octeon/bootoctlinux.c @@ -9,6 +9,7 @@ #include <dm.h> #include <elf.h> #include <env.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <linux/compat.h> diff --git a/arch/mips/mach-pic32/cpu.c b/arch/mips/mach-pic32/cpu.c index 1d8c39714411..eac2fe5f8c94 100644 --- a/arch/mips/mach-pic32/cpu.c +++ b/arch/mips/mach-pic32/cpu.c @@ -9,6 +9,7 @@ #include <dm.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <mach/pic32.h> #include <mach/ddr.h> #include <dt-bindings/clock/microchip,clock.h> diff --git a/arch/nds32/lib/bootm.c b/arch/nds32/lib/bootm.c index e552a3423005..b3b8bc290378 100644 --- a/arch/nds32/lib/bootm.c +++ b/arch/nds32/lib/bootm.c @@ -12,6 +12,7 @@ #include <hang.h> #include <image.h> #include <log.h> +#include <asm/global_data.h> #include <u-boot/zlib.h> #include <asm/byteorder.h> #include <asm/bootm.h> diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index e7ca9882fc58..b55c8fbc5841 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -13,6 +13,7 @@ #include <init.h> #include <irq_func.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/nios2/include/asm/io.h b/arch/nios2/include/asm/io.h index 41e6bd4ee104..817cd72e00bd 100644 --- a/arch/nios2/include/asm/io.h +++ b/arch/nios2/include/asm/io.h @@ -7,6 +7,8 @@ #ifndef __ASM_NIOS2_IO_H_ #define __ASM_NIOS2_IO_H_
+#include <asm/global_data.h> + static inline void sync(void) { __asm__ __volatile__ ("sync" : : : "memory"); @@ -170,5 +172,6 @@ static inline void outsl (unsigned long port, const void *src, unsigned long cou #define memcpy_toio(a, b, c) memcpy((void *)(a), (b), (c))
#include <asm-generic/io.h> +#include <asm/global_data.h>
#endif /* __ASM_NIOS2_IO_H_ */ diff --git a/arch/nios2/lib/cache.c b/arch/nios2/lib/cache.c index 0b961ac67620..5864d8f0f473 100644 --- a/arch/nios2/lib/cache.c +++ b/arch/nios2/lib/cache.c @@ -8,6 +8,7 @@ #include <common.h> #include <cpu_func.h> #include <asm/cache.h> +#include <asm/global_data.h>
diff --git a/arch/powerpc/cpu/mpc83xx/cpu.c b/arch/powerpc/cpu/mpc83xx/cpu.c index 843f2df649ec..8d531898bd89 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu.c +++ b/arch/powerpc/cpu/mpc83xx/cpu.c @@ -18,6 +18,7 @@ #include <watchdog.h> #include <command.h> #include <mpc83xx.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <linux/delay.h> #include <linux/libfdt.h> diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 840f907acb8e..e6dcb8a33507 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -7,6 +7,7 @@ #include <asm-offsets.h> #include <mpc83xx.h> #include <ioports.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/processor.h> #include <fsl_qe.h> diff --git a/arch/powerpc/cpu/mpc83xx/fdt.c b/arch/powerpc/cpu/mpc83xx/fdt.c index 4ea7b27ef412..3393ad562e8d 100644 --- a/arch/powerpc/cpu/mpc83xx/fdt.c +++ b/arch/powerpc/cpu/mpc83xx/fdt.c @@ -8,6 +8,7 @@
#include <common.h> #include <clock_legacy.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/processor.h> diff --git a/arch/powerpc/cpu/mpc83xx/interrupts.c b/arch/powerpc/cpu/mpc83xx/interrupts.c index 05380674dc74..f9486678af33 100644 --- a/arch/powerpc/cpu/mpc83xx/interrupts.c +++ b/arch/powerpc/cpu/mpc83xx/interrupts.c @@ -10,6 +10,7 @@ #include <command.h> #include <irq_func.h> #include <mpc83xx.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/ptrace.h>
diff --git a/arch/powerpc/cpu/mpc83xx/pci.c b/arch/powerpc/cpu/mpc83xx/pci.c index d057cd6351c1..5c289d002260 100644 --- a/arch/powerpc/cpu/mpc83xx/pci.c +++ b/arch/powerpc/cpu/mpc83xx/pci.c @@ -10,6 +10,7 @@ #include <init.h> #include <pci.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <linux/delay.h>
#if defined(CONFIG_OF_LIBFDT) diff --git a/arch/powerpc/cpu/mpc83xx/pcie.c b/arch/powerpc/cpu/mpc83xx/pcie.c index 785d4805a469..84797c871c95 100644 --- a/arch/powerpc/cpu/mpc83xx/pcie.c +++ b/arch/powerpc/cpu/mpc83xx/pcie.c @@ -10,6 +10,7 @@ #include <common.h> #include <pci.h> #include <mpc83xx.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/arch/powerpc/cpu/mpc83xx/spd_sdram.c b/arch/powerpc/cpu/mpc83xx/spd_sdram.c index aeff007fb063..a861e8dd2ddc 100644 --- a/arch/powerpc/cpu/mpc83xx/spd_sdram.c +++ b/arch/powerpc/cpu/mpc83xx/spd_sdram.c @@ -24,6 +24,7 @@ #include <asm/mmu.h> #include <spd_sdram.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <linux/delay.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/powerpc/cpu/mpc83xx/speed.c b/arch/powerpc/cpu/mpc83xx/speed.c index 5c14aa1f32e7..58e197f12082 100644 --- a/arch/powerpc/cpu/mpc83xx/speed.c +++ b/arch/powerpc/cpu/mpc83xx/speed.c @@ -13,6 +13,7 @@ #include <mpc83xx.h> #include <command.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/processor.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/powerpc/cpu/mpc83xx/spl_minimal.c b/arch/powerpc/cpu/mpc83xx/spl_minimal.c index 2c61f2b81dbf..00cb2bd044ef 100644 --- a/arch/powerpc/cpu/mpc83xx/spl_minimal.c +++ b/arch/powerpc/cpu/mpc83xx/spl_minimal.c @@ -8,6 +8,7 @@ #include <clock_legacy.h> #include <mpc83xx.h> #include <time.h> +#include <asm/global_data.h>
#include "lblaw/lblaw.h" #include "elbc/elbc.h" diff --git a/arch/powerpc/cpu/mpc83xx/traps.c b/arch/powerpc/cpu/mpc83xx/traps.c index ea8bc6c15280..22e451c58d68 100644 --- a/arch/powerpc/cpu/mpc83xx/traps.c +++ b/arch/powerpc/cpu/mpc83xx/traps.c @@ -12,6 +12,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <command.h> #include <kgdb.h> diff --git a/arch/powerpc/cpu/mpc85xx/commproc.c b/arch/powerpc/cpu/mpc85xx/commproc.c index 95215a0b8292..8e8427a08bbe 100644 --- a/arch/powerpc/cpu/mpc85xx/commproc.c +++ b/arch/powerpc/cpu/mpc85xx/commproc.c @@ -24,6 +24,7 @@ #include <common.h> #include <asm-offsets.h> #include <asm/cpm_85xx.h> +#include <asm/global_data.h>
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 3ff1ef45658b..5170610f0413 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -20,6 +20,7 @@ #include <command.h> #include <fsl_esdhc.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mmu.h> #include <fsl_ifc.h> diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index c519e8bd4b03..4195ecc5c98f 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -5,6 +5,7 @@
#include <common.h> #include <asm-offsets.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #include <asm/fsl_law.h> diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 0d8353ceb26c..7d168e3c9a0e 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -11,6 +11,7 @@ #include <env.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/processor.h> diff --git a/arch/powerpc/cpu/mpc85xx/mp.c b/arch/powerpc/cpu/mpc85xx/mp.c index 8822cf29fefd..653efe09f935 100644 --- a/arch/powerpc/cpu/mpc85xx/mp.c +++ b/arch/powerpc/cpu/mpc85xx/mp.c @@ -7,6 +7,7 @@ #include <cpu_func.h> #include <env.h> #include <log.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <env.h> #include <ioports.h> diff --git a/arch/powerpc/cpu/mpc85xx/serial_scc.c b/arch/powerpc/cpu/mpc85xx/serial_scc.c index a5c418570fa2..a2505d1ffc1d 100644 --- a/arch/powerpc/cpu/mpc85xx/serial_scc.c +++ b/arch/powerpc/cpu/mpc85xx/serial_scc.c @@ -18,6 +18,7 @@ #include <common.h> #include <asm/cpm_85xx.h> #include <serial.h> +#include <asm/global_data.h> #include <linux/compiler.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index 773ae08dd3b7..09653c70125f 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -12,6 +12,7 @@ #include <common.h> #include <cpu_func.h> #include <ppc_asm.tmpl> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/processor.h> #include <asm/io.h> diff --git a/arch/powerpc/cpu/mpc85xx/tlb.c b/arch/powerpc/cpu/mpc85xx/tlb.c index 4465ae7565a4..973b6fbe4b74 100644 --- a/arch/powerpc/cpu/mpc85xx/tlb.c +++ b/arch/powerpc/cpu/mpc85xx/tlb.c @@ -8,6 +8,7 @@
#include <common.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #ifdef CONFIG_ADDR_MAP diff --git a/arch/powerpc/cpu/mpc85xx/traps.c b/arch/powerpc/cpu/mpc85xx/traps.c index db6ed1fc92e9..def47285ba3b 100644 --- a/arch/powerpc/cpu/mpc85xx/traps.c +++ b/arch/powerpc/cpu/mpc85xx/traps.c @@ -20,6 +20,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <command.h> #include <init.h> diff --git a/arch/powerpc/cpu/mpc86xx/cpu.c b/arch/powerpc/cpu/mpc86xx/cpu.c index 9f5bce3992b8..98b42bff7a3b 100644 --- a/arch/powerpc/cpu/mpc86xx/cpu.c +++ b/arch/powerpc/cpu/mpc86xx/cpu.c @@ -13,6 +13,7 @@ #include <watchdog.h> #include <command.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <mpc86xx.h> #include <asm/fsl_law.h> diff --git a/arch/powerpc/cpu/mpc86xx/cpu_init.c b/arch/powerpc/cpu/mpc86xx/cpu_init.c index a17091d2ff8c..73779f862c2a 100644 --- a/arch/powerpc/cpu/mpc86xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc86xx/cpu_init.c @@ -14,6 +14,7 @@ #include <common.h> #include <init.h> #include <mpc86xx.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <asm/fsl_law.h> #include <asm/fsl_serdes.h> diff --git a/arch/powerpc/cpu/mpc86xx/fdt.c b/arch/powerpc/cpu/mpc86xx/fdt.c index 010b6d4fe606..1313d8adde66 100644 --- a/arch/powerpc/cpu/mpc86xx/fdt.c +++ b/arch/powerpc/cpu/mpc86xx/fdt.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/mp.h> diff --git a/arch/powerpc/cpu/mpc86xx/mp.c b/arch/powerpc/cpu/mpc86xx/mp.c index 08d11ad4f2e5..e6795e06c98b 100644 --- a/arch/powerpc/cpu/mpc86xx/mp.c +++ b/arch/powerpc/cpu/mpc86xx/mp.c @@ -5,6 +5,7 @@
#include <common.h> #include <cpu_func.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #include <ioports.h> diff --git a/arch/powerpc/cpu/mpc86xx/speed.c b/arch/powerpc/cpu/mpc86xx/speed.c index 500144586229..86c1709c4ca2 100644 --- a/arch/powerpc/cpu/mpc86xx/speed.c +++ b/arch/powerpc/cpu/mpc86xx/speed.c @@ -11,6 +11,7 @@ #include <common.h> #include <clock_legacy.h> #include <mpc86xx.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/io.h>
diff --git a/arch/powerpc/cpu/mpc86xx/traps.c b/arch/powerpc/cpu/mpc86xx/traps.c index 3ee0ec859cf8..46006ece4160 100644 --- a/arch/powerpc/cpu/mpc86xx/traps.c +++ b/arch/powerpc/cpu/mpc86xx/traps.c @@ -14,6 +14,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <command.h> #include <init.h> diff --git a/arch/powerpc/cpu/mpc8xx/cpu.c b/arch/powerpc/cpu/mpc8xx/cpu.c index 7c93e35003ff..893aecef21c2 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu.c +++ b/arch/powerpc/cpu/mpc8xx/cpu.c @@ -27,6 +27,7 @@ #include <netdev.h> #include <asm/cache.h> #include <asm/cpm_8xx.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/io.h>
diff --git a/arch/powerpc/cpu/mpc8xx/fdt.c b/arch/powerpc/cpu/mpc8xx/fdt.c index 226e258f0ea7..b4a26efe3027 100644 --- a/arch/powerpc/cpu/mpc8xx/fdt.c +++ b/arch/powerpc/cpu/mpc8xx/fdt.c @@ -7,6 +7,7 @@
#include <common.h> #include <time.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h>
diff --git a/arch/powerpc/cpu/mpc8xx/immap.c b/arch/powerpc/cpu/mpc8xx/immap.c index e5b62e9f4acf..40793c26e120 100644 --- a/arch/powerpc/cpu/mpc8xx/immap.c +++ b/arch/powerpc/cpu/mpc8xx/immap.c @@ -10,6 +10,7 @@
#include <common.h> #include <command.h> +#include <asm/global_data.h>
#include <asm/immap_8xx.h> #include <asm/cpm_8xx.h> diff --git a/arch/powerpc/cpu/mpc8xx/speed.c b/arch/powerpc/cpu/mpc8xx/speed.c index 77d4f8e47f74..ad3d3f9101cc 100644 --- a/arch/powerpc/cpu/mpc8xx/speed.c +++ b/arch/powerpc/cpu/mpc8xx/speed.c @@ -7,6 +7,7 @@ #include <common.h> #include <clock_legacy.h> #include <mpc8xx.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/io.h>
diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index b2d1dc5b4819..eda64861ee6f 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -17,6 +17,7 @@ #include <fm_eth.h> #include <netdev.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <vsc9953.h>
diff --git a/arch/powerpc/cpu/mpc8xxx/law.c b/arch/powerpc/cpu/mpc8xxx/law.c index e388386ad42e..cf03f4101906 100644 --- a/arch/powerpc/cpu/mpc8xxx/law.c +++ b/arch/powerpc/cpu/mpc8xxx/law.c @@ -8,6 +8,7 @@
#include <common.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/fsl_law.h> #include <asm/io.h> diff --git a/arch/powerpc/cpu/mpc8xxx/pamu_table.c b/arch/powerpc/cpu/mpc8xxx/pamu_table.c index 7dd71d2e0c4a..d917e9dfb62f 100644 --- a/arch/powerpc/cpu/mpc8xxx/pamu_table.c +++ b/arch/powerpc/cpu/mpc8xxx/pamu_table.c @@ -6,6 +6,7 @@ #include <common.h> #include <log.h> #include <asm/fsl_pamu.h> +#include <asm/global_data.h>
diff --git a/arch/powerpc/lib/bat_rw.c b/arch/powerpc/lib/bat_rw.c index ac56e3aeddba..24dd30615bd3 100644 --- a/arch/powerpc/lib/bat_rw.c +++ b/arch/powerpc/lib/bat_rw.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #include <asm/io.h> diff --git a/arch/powerpc/lib/bdinfo.c b/arch/powerpc/lib/bdinfo.c index 36c9c99ee6ff..39062804ccfe 100644 --- a/arch/powerpc/lib/bdinfo.c +++ b/arch/powerpc/lib/bdinfo.c @@ -8,6 +8,7 @@
diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index b903e6ec8dc5..31c17b5bb388 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -18,6 +18,7 @@ #include <command.h> #include <image.h> #include <malloc.h> +#include <asm/global_data.h> #include <u-boot/zlib.h> #include <bzlib.h> #include <asm/byteorder.h> diff --git a/arch/powerpc/lib/stack.c b/arch/powerpc/lib/stack.c index 5840fe63490f..f2a4652e081d 100644 --- a/arch/powerpc/lib/stack.c +++ b/arch/powerpc/lib/stack.c @@ -12,6 +12,7 @@ */ #include <common.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/arch/powerpc/lib/traps.c b/arch/powerpc/lib/traps.c index 288e37763284..c7bce82a44b3 100644 --- a/arch/powerpc/lib/traps.c +++ b/arch/powerpc/lib/traps.c @@ -4,8 +4,8 @@ * Wolfgang Denk, DENX Software Engineering, wd@denx.de. */
-#include <common.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/arch/riscv/cpu/fu540/cache.c b/arch/riscv/cpu/fu540/cache.c index 78f5ad9d602f..0fc4ef6c0076 100644 --- a/arch/riscv/cpu/fu540/cache.c +++ b/arch/riscv/cpu/fu540/cache.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/arch/riscv/cpu/fu540/dram.c b/arch/riscv/cpu/fu540/dram.c index 1dc77efeca55..cec130ec8dc6 100644 --- a/arch/riscv/cpu/fu540/dram.c +++ b/arch/riscv/cpu/fu540/dram.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdtdec.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/riscv/cpu/generic/dram.c b/arch/riscv/cpu/generic/dram.c index 1dc77efeca55..cec130ec8dc6 100644 --- a/arch/riscv/cpu/generic/dram.c +++ b/arch/riscv/cpu/generic/dram.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdtdec.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/riscv/lib/andes_plic.c b/arch/riscv/lib/andes_plic.c index 267d6a191b21..221a5fe324e2 100644 --- a/arch/riscv/lib/andes_plic.c +++ b/arch/riscv/lib/andes_plic.c @@ -9,6 +9,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/uclass-internal.h> diff --git a/arch/riscv/lib/asm-offsets.c b/arch/riscv/lib/asm-offsets.c index 7301c1b98e23..f1fe089b3d8f 100644 --- a/arch/riscv/lib/asm-offsets.c +++ b/arch/riscv/lib/asm-offsets.c @@ -9,6 +9,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/kbuild.h>
int main(void) diff --git a/arch/riscv/lib/bootm.c b/arch/riscv/lib/bootm.c index c4137ded834b..8dd18205403c 100644 --- a/arch/riscv/lib/bootm.c +++ b/arch/riscv/lib/bootm.c @@ -13,6 +13,7 @@ #include <fdt_support.h> #include <hang.h> #include <log.h> +#include <asm/global_data.h> #include <dm/root.h> #include <image.h> #include <asm/byteorder.h> diff --git a/arch/riscv/lib/fdt_fixup.c b/arch/riscv/lib/fdt_fixup.c index d02062fd5bd6..1f3f23621c33 100644 --- a/arch/riscv/lib/fdt_fixup.c +++ b/arch/riscv/lib/fdt_fixup.c @@ -10,6 +10,7 @@ #include <fdt_support.h> #include <log.h> #include <mapmem.h> +#include <asm/global_data.h>
diff --git a/arch/riscv/lib/image.c b/arch/riscv/lib/image.c index 91b7f1624e9f..47f2edcf7fc2 100644 --- a/arch/riscv/lib/image.c +++ b/arch/riscv/lib/image.c @@ -10,6 +10,7 @@ #include <image.h> #include <mapmem.h> #include <errno.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <linux/stddef.h>
diff --git a/arch/riscv/lib/interrupts.c b/arch/riscv/lib/interrupts.c index fb3ce118c177..7525c152b890 100644 --- a/arch/riscv/lib/interrupts.c +++ b/arch/riscv/lib/interrupts.c @@ -13,6 +13,7 @@ #include <efi_loader.h> #include <hang.h> #include <irq_func.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <asm/system.h> #include <asm/encoding.h> diff --git a/arch/riscv/lib/sifive_clint.c b/arch/riscv/lib/sifive_clint.c index cfa288a01a84..ab22395c5529 100644 --- a/arch/riscv/lib/sifive_clint.c +++ b/arch/riscv/lib/sifive_clint.c @@ -10,6 +10,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/smp.h> #include <linux/err.h> diff --git a/arch/riscv/lib/smp.c b/arch/riscv/lib/smp.c index 8f33ce1fe369..ba992100adf1 100644 --- a/arch/riscv/lib/smp.c +++ b/arch/riscv/lib/smp.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <dm.h> #include <asm/barrier.h> +#include <asm/global_data.h> #include <asm/smp.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/riscv/lib/spl.c b/arch/riscv/lib/spl.c index 5e19d0f36ab2..8baee07beac1 100644 --- a/arch/riscv/lib/spl.c +++ b/arch/riscv/lib/spl.c @@ -9,6 +9,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/smp.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/sandbox/cpu/cpu.c b/arch/sandbox/cpu/cpu.c index fb857e53d592..edd48e2c1b74 100644 --- a/arch/sandbox/cpu/cpu.c +++ b/arch/sandbox/cpu/cpu.c @@ -9,6 +9,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <os.h> diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 9a77da15619c..e7b4b50681ac 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -10,6 +10,7 @@ #include <log.h> #include <os.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/spl.h> #include <asm/state.h> #include <test/test.h> diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 254258097474..483a26404046 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -14,6 +14,7 @@ #include <cli.h> #include <sort.h> #include <asm/getopt.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/malloc.h> #include <asm/sections.h> diff --git a/arch/sandbox/lib/interrupts.c b/arch/sandbox/lib/interrupts.c index 9c2c60b8c685..4d7cbff802c6 100644 --- a/arch/sandbox/lib/interrupts.c +++ b/arch/sandbox/lib/interrupts.c @@ -9,6 +9,7 @@ #include <efi_loader.h> #include <irq_func.h> #include <os.h> +#include <asm/global_data.h> #include <asm-generic/signal.h> #include <asm/u-boot-sandbox.h>
diff --git a/arch/sh/lib/board.c b/arch/sh/lib/board.c index a6a8f07e6f26..3fa093a02ea3 100644 --- a/arch/sh/lib/board.c +++ b/arch/sh/lib/board.c @@ -5,6 +5,7 @@
diff --git a/arch/x86/cpu/apollolake/cpu.c b/arch/x86/cpu/apollolake/cpu.c index 328f79255f8c..fbc016d0e0ba 100644 --- a/arch/x86/cpu/apollolake/cpu.c +++ b/arch/x86/cpu/apollolake/cpu.c @@ -11,6 +11,7 @@ #include <acpi/acpi_table.h> #include <asm/cpu_common.h> #include <asm/cpu_x86.h> +#include <asm/global_data.h> #include <asm/intel_acpi.h> #include <asm/msr.h> #include <asm/mtrr.h> diff --git a/arch/x86/cpu/apollolake/cpu_spl.c b/arch/x86/cpu/apollolake/cpu_spl.c index fafe4dbc0a04..9a18476b22c8 100644 --- a/arch/x86/cpu/apollolake/cpu_spl.c +++ b/arch/x86/cpu/apollolake/cpu_spl.c @@ -18,6 +18,7 @@ #include <asm/cpu_common.h> #include <asm/cpu_x86.h> #include <asm/fast_spi.h> +#include <asm/global_data.h> #include <asm/intel_pinctrl.h> #include <asm/intel_regs.h> #include <asm/io.h> diff --git a/arch/x86/cpu/apollolake/fsp_s.c b/arch/x86/cpu/apollolake/fsp_s.c index 288188027a41..a9b13c0c7047 100644 --- a/arch/x86/cpu/apollolake/fsp_s.c +++ b/arch/x86/cpu/apollolake/fsp_s.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <p2sb.h> #include <acpi/acpi_s3.h> +#include <asm/global_data.h> #include <asm/intel_pinctrl.h> #include <asm/io.h> #include <asm/intel_regs.h> diff --git a/arch/x86/cpu/baytrail/fsp_configs.c b/arch/x86/cpu/baytrail/fsp_configs.c index 21816ce5b883..fb3f946c45f9 100644 --- a/arch/x86/cpu/baytrail/fsp_configs.c +++ b/arch/x86/cpu/baytrail/fsp_configs.c @@ -9,6 +9,7 @@ #include <fdtdec.h> #include <log.h> #include <asm/fsp1/fsp_support.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/braswell/fsp_configs.c b/arch/x86/cpu/braswell/fsp_configs.c index 9e710a940cad..243298fd5718 100644 --- a/arch/x86/cpu/braswell/fsp_configs.c +++ b/arch/x86/cpu/braswell/fsp_configs.c @@ -7,6 +7,7 @@ #include <fdtdec.h> #include <log.h> #include <asm/fsp1/fsp_support.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/broadwell/cpu.c b/arch/x86/cpu/broadwell/cpu.c index b77301118cdf..3832a97f2c73 100644 --- a/arch/x86/cpu/broadwell/cpu.c +++ b/arch/x86/cpu/broadwell/cpu.c @@ -13,6 +13,7 @@ #include <asm/cpu.h> #include <asm/cpu_x86.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/lpc_common.h> #include <asm/msr.h> diff --git a/arch/x86/cpu/broadwell/cpu_from_spl.c b/arch/x86/cpu/broadwell/cpu_from_spl.c index 4d4cdafa2b0a..e5f62e7187cb 100644 --- a/arch/x86/cpu/broadwell/cpu_from_spl.c +++ b/arch/x86/cpu/broadwell/cpu_from_spl.c @@ -11,6 +11,7 @@ #include <handoff.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mtrr.h>
int misc_init_r(void) diff --git a/arch/x86/cpu/broadwell/cpu_full.c b/arch/x86/cpu/broadwell/cpu_full.c index ea9e98dde69f..2049dbfe24a5 100644 --- a/arch/x86/cpu/broadwell/cpu_full.c +++ b/arch/x86/cpu/broadwell/cpu_full.c @@ -13,6 +13,7 @@ #include <asm/cpu.h> #include <asm/cpu_x86.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/msr.h> #include <asm/post.h> diff --git a/arch/x86/cpu/broadwell/lpc.c b/arch/x86/cpu/broadwell/lpc.c index 5669a028cf34..d2638a4e7a6b 100644 --- a/arch/x86/cpu/broadwell/lpc.c +++ b/arch/x86/cpu/broadwell/lpc.c @@ -9,6 +9,7 @@ #include <dm.h> #include <log.h> #include <pch.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/lpc_common.h> diff --git a/arch/x86/cpu/broadwell/northbridge.c b/arch/x86/cpu/broadwell/northbridge.c index 4bcab785560f..141babc51c3a 100644 --- a/arch/x86/cpu/broadwell/northbridge.c +++ b/arch/x86/cpu/broadwell/northbridge.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mrc_common.h> #include <asm/arch/iomap.h> diff --git a/arch/x86/cpu/broadwell/pch.c b/arch/x86/cpu/broadwell/pch.c index 9bcf211af99c..f012db9debe8 100644 --- a/arch/x86/cpu/broadwell/pch.c +++ b/arch/x86/cpu/broadwell/pch.c @@ -8,6 +8,7 @@ #include <log.h> #include <pch.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/i8259.h> #include <asm/intel_regs.h> diff --git a/arch/x86/cpu/broadwell/pinctrl_broadwell.c b/arch/x86/cpu/broadwell/pinctrl_broadwell.c index 0ead13af62aa..85bd37101ba2 100644 --- a/arch/x86/cpu/broadwell/pinctrl_broadwell.c +++ b/arch/x86/cpu/broadwell/pinctrl_broadwell.c @@ -11,6 +11,7 @@ #include <pch.h> #include <pci.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/pci.h> diff --git a/arch/x86/cpu/broadwell/sata.c b/arch/x86/cpu/broadwell/sata.c index ceb395ddcfd3..be3c9e764ef3 100644 --- a/arch/x86/cpu/broadwell/sata.c +++ b/arch/x86/cpu/broadwell/sata.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/intel_regs.h> diff --git a/arch/x86/cpu/broadwell/sdram.c b/arch/x86/cpu/broadwell/sdram.c index 72f59a0a5734..c104a849a545 100644 --- a/arch/x86/cpu/broadwell/sdram.c +++ b/arch/x86/cpu/broadwell/sdram.c @@ -12,6 +12,7 @@ #include <pci.h> #include <syscon.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/lpc_common.h> #include <asm/mrccache.h> diff --git a/arch/x86/cpu/call32.S b/arch/x86/cpu/call32.S index e641e781c04c..b28d58a317d3 100644 --- a/arch/x86/cpu/call32.S +++ b/arch/x86/cpu/call32.S @@ -4,7 +4,6 @@ * Written by Simon Glass sjg@chromium.org */
-#include <asm/global_data.h> #include <asm/msr-index.h> #include <asm/processor-flags.h>
diff --git a/arch/x86/cpu/coreboot/coreboot.c b/arch/x86/cpu/coreboot/coreboot.c index 22a93254a939..15c3ad879a00 100644 --- a/arch/x86/cpu/coreboot/coreboot.c +++ b/arch/x86/cpu/coreboot/coreboot.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <init.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/msr.h> #include <asm/mtrr.h> diff --git a/arch/x86/cpu/coreboot/sdram.c b/arch/x86/cpu/coreboot/sdram.c index 27e859885e8c..a2e47d196a2e 100644 --- a/arch/x86/cpu/coreboot/sdram.c +++ b/arch/x86/cpu/coreboot/sdram.c @@ -9,6 +9,7 @@ #include <init.h> #include <asm/e820.h> #include <asm/arch/sysinfo.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/coreboot/tables.c b/arch/x86/cpu/coreboot/tables.c index 1594b4a8b2ab..c52741ac9da6 100644 --- a/arch/x86/cpu/coreboot/tables.c +++ b/arch/x86/cpu/coreboot/tables.c @@ -9,6 +9,7 @@ #include <common.h> #include <net.h> #include <asm/arch/sysinfo.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index 71351262f66d..9c4edfcbfdaa 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -37,6 +37,7 @@ #include <asm/control_regs.h> #include <asm/coreboot_tables.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/lapic.h> #include <asm/microcode.h> #include <asm/mp.h> diff --git a/arch/x86/cpu/cpu_x86.c b/arch/x86/cpu/cpu_x86.c index bfb511a5101b..59da41f38333 100644 --- a/arch/x86/cpu/cpu_x86.c +++ b/arch/x86/cpu/cpu_x86.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <asm/cpu.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/efi/payload.c b/arch/x86/cpu/efi/payload.c index 71619f6f01b5..9a73b768e9b8 100644 --- a/arch/x86/cpu/efi/payload.c +++ b/arch/x86/cpu/efi/payload.c @@ -13,6 +13,7 @@ #include <usb.h> #include <asm/bootparam.h> #include <asm/e820.h> +#include <asm/global_data.h> #include <asm/post.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/x86/cpu/efi/sdram.c b/arch/x86/cpu/efi/sdram.c index 3143c079adbd..af65982fd0c0 100644 --- a/arch/x86/cpu/efi/sdram.c +++ b/arch/x86/cpu/efi/sdram.c @@ -6,6 +6,7 @@ #include <common.h> #include <efi.h> #include <init.h> +#include <asm/global_data.h> #include <asm/u-boot-x86.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/x86/cpu/i386/call64.S b/arch/x86/cpu/i386/call64.S index 0ffc1006bbf7..d81bcc6f8f4c 100644 --- a/arch/x86/cpu/i386/call64.S +++ b/arch/x86/cpu/i386/call64.S @@ -6,7 +6,6 @@ * Parts of this copied from Linux arch/x86/boot/compressed/head_64.S */
diff --git a/arch/x86/cpu/i386/cpu.c b/arch/x86/cpu/i386/cpu.c index 6fa0f4d32baa..e59215cc20ea 100644 --- a/arch/x86/cpu/i386/cpu.c +++ b/arch/x86/cpu/i386/cpu.c @@ -27,6 +27,7 @@ #include <asm/control_regs.h> #include <asm/coreboot_tables.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/mp.h> #include <asm/msr.h> #include <asm/mtrr.h> diff --git a/arch/x86/cpu/i386/interrupt.c b/arch/x86/cpu/i386/interrupt.c index d85f84b29a75..fae2544c456f 100644 --- a/arch/x86/cpu/i386/interrupt.c +++ b/arch/x86/cpu/i386/interrupt.c @@ -18,6 +18,7 @@ #include <irq.h> #include <irq_func.h> #include <asm/control_regs.h> +#include <asm/global_data.h> #include <asm/i8259.h> #include <asm/interrupt.h> #include <asm/io.h> diff --git a/arch/x86/cpu/intel_common/acpi.c b/arch/x86/cpu/intel_common/acpi.c index 6a3456f47605..15f19da2067a 100644 --- a/arch/x86/cpu/intel_common/acpi.c +++ b/arch/x86/cpu/intel_common/acpi.c @@ -17,6 +17,7 @@ #include <asm/acpi_table.h> #include <asm/cpu.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_acpi.h> #include <asm/ioapic.h> #include <asm/mpspec.h> diff --git a/arch/x86/cpu/intel_common/cpu.c b/arch/x86/cpu/intel_common/cpu.c index a51bf86f7abc..96d05e2eb3a1 100644 --- a/arch/x86/cpu/intel_common/cpu.c +++ b/arch/x86/cpu/intel_common/cpu.c @@ -15,6 +15,7 @@ #include <acpi/acpigen.h> #include <asm/cpu.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/lapic.h> #include <asm/lpc_common.h> diff --git a/arch/x86/cpu/intel_common/cpu_from_spl.c b/arch/x86/cpu/intel_common/cpu_from_spl.c index e4157c5734c5..1c0dcedb5824 100644 --- a/arch/x86/cpu/intel_common/cpu_from_spl.c +++ b/arch/x86/cpu/intel_common/cpu_from_spl.c @@ -9,6 +9,7 @@ #include <handoff.h> #include <init.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/lapic.h> #include <asm/lpc_common.h> diff --git a/arch/x86/cpu/intel_common/itss.c b/arch/x86/cpu/intel_common/itss.c index ae4de4ca8c6c..588a512ecd44 100644 --- a/arch/x86/cpu/intel_common/itss.c +++ b/arch/x86/cpu/intel_common/itss.c @@ -17,6 +17,7 @@ #include <malloc.h> #include <p2sb.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/itss.h>
static int set_polarity(struct udevice *dev, uint irq, bool active_low) diff --git a/arch/x86/cpu/intel_common/lpc.c b/arch/x86/cpu/intel_common/lpc.c index 3420f03ccaa2..23befbef15ff 100644 --- a/arch/x86/cpu/intel_common/lpc.c +++ b/arch/x86/cpu/intel_common/lpc.c @@ -9,6 +9,7 @@ #include <fdtdec.h> #include <pch.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/lpc_common.h> diff --git a/arch/x86/cpu/intel_common/microcode.c b/arch/x86/cpu/intel_common/microcode.c index 0355d3c1da69..4d8e1d210838 100644 --- a/arch/x86/cpu/intel_common/microcode.c +++ b/arch/x86/cpu/intel_common/microcode.c @@ -10,6 +10,7 @@ #include <errno.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <asm/cpu.h> #include <asm/microcode.h> diff --git a/arch/x86/cpu/intel_common/mrc.c b/arch/x86/cpu/intel_common/mrc.c index 73bfd123321f..a97b0b7ceb41 100644 --- a/arch/x86/cpu/intel_common/mrc.c +++ b/arch/x86/cpu/intel_common/mrc.c @@ -9,6 +9,7 @@ #include <log.h> #include <syscon.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/intel_regs.h> #include <asm/mrc_common.h> diff --git a/arch/x86/cpu/irq.c b/arch/x86/cpu/irq.c index 8b53b96822d7..766b2451a2cc 100644 --- a/arch/x86/cpu/irq.c +++ b/arch/x86/cpu/irq.c @@ -10,6 +10,7 @@ #include <irq.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/irq.h> #include <asm/pci.h> diff --git a/arch/x86/cpu/ivybridge/bd82x6x.c b/arch/x86/cpu/ivybridge/bd82x6x.c index 5448f064fcbf..0540b021618f 100644 --- a/arch/x86/cpu/ivybridge/bd82x6x.c +++ b/arch/x86/cpu/ivybridge/bd82x6x.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <pch.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/lapic.h> diff --git a/arch/x86/cpu/ivybridge/cpu.c b/arch/x86/cpu/ivybridge/cpu.c index cb6eded9c98d..bddba3eddecd 100644 --- a/arch/x86/cpu/ivybridge/cpu.c +++ b/arch/x86/cpu/ivybridge/cpu.c @@ -20,6 +20,7 @@ #include <pch.h> #include <asm/cpu.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/lapic.h> diff --git a/arch/x86/cpu/ivybridge/fsp_configs.c b/arch/x86/cpu/ivybridge/fsp_configs.c index 41d7d2a2b420..3c4ea6c267f8 100644 --- a/arch/x86/cpu/ivybridge/fsp_configs.c +++ b/arch/x86/cpu/ivybridge/fsp_configs.c @@ -7,6 +7,7 @@ #include <fdtdec.h> #include <log.h> #include <asm/fsp1/fsp_support.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/ivybridge/lpc.c b/arch/x86/cpu/ivybridge/lpc.c index 85fd2a965abd..f931d2be1b52 100644 --- a/arch/x86/cpu/ivybridge/lpc.c +++ b/arch/x86/cpu/ivybridge/lpc.c @@ -12,6 +12,7 @@ #include <log.h> #include <rtc.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/interrupt.h> #include <asm/io.h> diff --git a/arch/x86/cpu/ivybridge/model_206ax.c b/arch/x86/cpu/ivybridge/model_206ax.c index 598ebcdf0840..3906a69796f3 100644 --- a/arch/x86/cpu/ivybridge/model_206ax.c +++ b/arch/x86/cpu/ivybridge/model_206ax.c @@ -15,6 +15,7 @@ #include <asm/cpu.h> #include <asm/cpu_common.h> #include <asm/cpu_x86.h> +#include <asm/global_data.h> #include <asm/msr.h> #include <asm/msr-index.h> #include <asm/mtrr.h> diff --git a/arch/x86/cpu/ivybridge/northbridge.c b/arch/x86/cpu/ivybridge/northbridge.c index b713fcb1cfe7..994f8a4ff6a5 100644 --- a/arch/x86/cpu/ivybridge/northbridge.c +++ b/arch/x86/cpu/ivybridge/northbridge.c @@ -9,6 +9,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <asm/msr.h> #include <asm/cpu.h> #include <asm/intel_regs.h> diff --git a/arch/x86/cpu/ivybridge/sata.c b/arch/x86/cpu/ivybridge/sata.c index 025b20be31bd..f47ecdffae76 100644 --- a/arch/x86/cpu/ivybridge/sata.c +++ b/arch/x86/cpu/ivybridge/sata.c @@ -9,6 +9,7 @@ #include <dm.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/pch_common.h> #include <asm/pci.h> diff --git a/arch/x86/cpu/ivybridge/sdram_nop.c b/arch/x86/cpu/ivybridge/sdram_nop.c index 54e6acf26211..51dfe23f94d0 100644 --- a/arch/x86/cpu/ivybridge/sdram_nop.c +++ b/arch/x86/cpu/ivybridge/sdram_nop.c @@ -5,6 +5,7 @@
diff --git a/arch/x86/cpu/mp_init.c b/arch/x86/cpu/mp_init.c index 0e61c7b5d7fa..c09762aee6c9 100644 --- a/arch/x86/cpu/mp_init.c +++ b/arch/x86/cpu/mp_init.c @@ -14,6 +14,7 @@ #include <qfw.h> #include <asm/atomic.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/interrupt.h> #include <asm/io.h> #include <asm/lapic.h> diff --git a/arch/x86/cpu/mtrr.c b/arch/x86/cpu/mtrr.c index 6f095c53a57b..166aff380c64 100644 --- a/arch/x86/cpu/mtrr.c +++ b/arch/x86/cpu/mtrr.c @@ -21,6 +21,7 @@ #include <log.h> #include <sort.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mp.h> #include <asm/msr.h> diff --git a/arch/x86/cpu/qemu/dram.c b/arch/x86/cpu/qemu/dram.c index 19d92f27d80c..c1745501294c 100644 --- a/arch/x86/cpu/qemu/dram.c +++ b/arch/x86/cpu/qemu/dram.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/post.h> #include <asm/arch/qemu.h>
diff --git a/arch/x86/cpu/qemu/e820.c b/arch/x86/cpu/qemu/e820.c index 0da36bddeaec..19e54c5202a9 100644 --- a/arch/x86/cpu/qemu/e820.c +++ b/arch/x86/cpu/qemu/e820.c @@ -11,6 +11,7 @@ #include <malloc.h> #include <asm/e820.h> #include <asm/arch/qemu.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/quark/acpi.c b/arch/x86/cpu/quark/acpi.c index b0406a04e92b..82b776ff65f6 100644 --- a/arch/x86/cpu/quark/acpi.c +++ b/arch/x86/cpu/quark/acpi.c @@ -5,6 +5,7 @@
#include <common.h> #include <acpi/acpi_table.h> +#include <asm/processor.h> #include <asm/tables.h> #include <asm/arch/global_nvs.h> #include <asm/arch/iomap.h> diff --git a/arch/x86/cpu/quark/dram.c b/arch/x86/cpu/quark/dram.c index 72937139ed73..2287dce12b52 100644 --- a/arch/x86/cpu/quark/dram.c +++ b/arch/x86/cpu/quark/dram.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/mrccache.h> #include <asm/mtrr.h> #include <asm/post.h> diff --git a/arch/x86/cpu/sipi_vector.S b/arch/x86/cpu/sipi_vector.S index fa1e6cb19af4..6d2da963bcdb 100644 --- a/arch/x86/cpu/sipi_vector.S +++ b/arch/x86/cpu/sipi_vector.S @@ -11,7 +11,6 @@ * C code */
-#include <asm/global_data.h> #include <asm/msr-index.h> #include <asm/processor.h> #include <asm/processor-flags.h> diff --git a/arch/x86/cpu/slimbootloader/sdram.c b/arch/x86/cpu/slimbootloader/sdram.c index 33e91fb6366b..36d0d4da5531 100644 --- a/arch/x86/cpu/slimbootloader/sdram.c +++ b/arch/x86/cpu/slimbootloader/sdram.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/e820.h> #include <asm/arch/slimbootloader.h> diff --git a/arch/x86/cpu/slimbootloader/serial.c b/arch/x86/cpu/slimbootloader/serial.c index 772a94c31cb7..d28b280890d3 100644 --- a/arch/x86/cpu/slimbootloader/serial.c +++ b/arch/x86/cpu/slimbootloader/serial.c @@ -9,6 +9,7 @@ #include <ns16550.h> #include <serial.h> #include <asm/arch/slimbootloader.h> +#include <asm/global_data.h>
/** * The serial port info hob is generated by Slim Bootloader, so eligible for diff --git a/arch/x86/cpu/slimbootloader/slimbootloader.c b/arch/x86/cpu/slimbootloader/slimbootloader.c index f61fe814e94a..ec5b87cfd63f 100644 --- a/arch/x86/cpu/slimbootloader/slimbootloader.c +++ b/arch/x86/cpu/slimbootloader/slimbootloader.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <asm/arch/slimbootloader.h> +#include <asm/global_data.h>
diff --git a/arch/x86/cpu/start.S b/arch/x86/cpu/start.S index 3d0d95295f64..897fd926c0a3 100644 --- a/arch/x86/cpu/start.S +++ b/arch/x86/cpu/start.S @@ -22,7 +22,6 @@ */
#include <config.h> -#include <asm/global_data.h> #include <asm/post.h> #include <asm/processor.h> #include <asm/processor-flags.h> diff --git a/arch/x86/cpu/start16.S b/arch/x86/cpu/start16.S index 54f4ff6662a8..865a49731e57 100644 --- a/arch/x86/cpu/start16.S +++ b/arch/x86/cpu/start16.S @@ -9,7 +9,6 @@ * Daniel Engström, Omicron Ceti AB, daniel@omicron.se */
-#include <asm/global_data.h> #include <asm/processor-flags.h>
#define BOOT_SEG 0xffff0000 /* linear segment of boot code */ diff --git a/arch/x86/cpu/turbo.c b/arch/x86/cpu/turbo.c index 4a73cb240dac..e2c84cddec8e 100644 --- a/arch/x86/cpu/turbo.c +++ b/arch/x86/cpu/turbo.c @@ -8,6 +8,7 @@ #include <common.h> #include <log.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/msr.h> #include <asm/processor.h> #include <asm/turbo.h> diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index 1b49ccadc0c1..d5c8805df38a 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -11,6 +11,8 @@
#ifndef __ACPI__
+#include <pci.h> + struct acpi_facs; struct acpi_fadt; struct acpi_global_nvs; diff --git a/arch/x86/include/asm/arch-apollolake/systemagent.h b/arch/x86/include/asm/arch-apollolake/systemagent.h index 788a63d79997..48e76c2bb0a9 100644 --- a/arch/x86/include/asm/arch-apollolake/systemagent.h +++ b/arch/x86/include/asm/arch-apollolake/systemagent.h @@ -9,6 +9,9 @@
/* Device 0:0.0 PCI configuration space */ #include <linux/bitops.h> + +struct udevice; + #define MCHBAR 0x48
/* RAPL Package Power Limit register under MCHBAR */ diff --git a/arch/x86/include/asm/cpu_common.h b/arch/x86/include/asm/cpu_common.h index 2a5779a8e1a7..e41ceda73a84 100644 --- a/arch/x86/include/asm/cpu_common.h +++ b/arch/x86/include/asm/cpu_common.h @@ -14,6 +14,7 @@ enum { };
struct cpu_info; +struct udevice;
/** * cpu_common_init() - Set up common CPU init diff --git a/arch/x86/include/asm/fast_spi.h b/arch/x86/include/asm/fast_spi.h index 7a81d4f05c66..82e3d8f63ef1 100644 --- a/arch/x86/include/asm/fast_spi.h +++ b/arch/x86/include/asm/fast_spi.h @@ -6,8 +6,10 @@ #ifndef ASM_FAST_SPI_H #define ASM_FAST_SPI_H
-/* Register offsets from the MMIO region base (PCI_BASE_ADDRESS_0) */ +#include <pci.h> #include <linux/bitops.h> + +/* Register offsets from the MMIO region base (PCI_BASE_ADDRESS_0) */ struct fast_spi_regs { u32 bfp; u32 hsfsts_ctl; diff --git a/arch/x86/include/asm/io.h b/arch/x86/include/asm/io.h index cf6c33cbe3af..83dc09757e0c 100644 --- a/arch/x86/include/asm/io.h +++ b/arch/x86/include/asm/io.h @@ -7,7 +7,7 @@ #ifndef _ASM_IO_H #define _ASM_IO_H
-#include <linux/compiler.h> +#include <compiler.h>
/* * This file contains the definitions for the x86 IO instructions diff --git a/arch/x86/include/asm/mp.h b/arch/x86/include/asm/mp.h index 1e4e35321dec..1a3ae8e39503 100644 --- a/arch/x86/include/asm/mp.h +++ b/arch/x86/include/asm/mp.h @@ -11,6 +11,8 @@ #include <asm/atomic.h> #include <asm/cache.h>
+struct udevice; + enum { /* Indicates that the function should run on all CPUs */ MP_SELECT_ALL = -1, diff --git a/arch/x86/include/asm/mrccache.h b/arch/x86/include/asm/mrccache.h index b60d1171f771..8b104a2f0b8e 100644 --- a/arch/x86/include/asm/mrccache.h +++ b/arch/x86/include/asm/mrccache.h @@ -7,6 +7,8 @@ #ifndef _ASM_MRCCACHE_H #define _ASM_MRCCACHE_H
+#include <compiler.h> + #define MRC_DATA_ALIGN 0x100 #define MRC_DATA_SIGNATURE (('M' << 0) | ('R' << 8) | \ ('C' << 16) | ('D'<<24)) diff --git a/arch/x86/lib/acpi_s3.c b/arch/x86/lib/acpi_s3.c index 52410a515dfa..2c70acbe7b0b 100644 --- a/arch/x86/lib/acpi_s3.c +++ b/arch/x86/lib/acpi_s3.c @@ -7,6 +7,7 @@ #include <acpi/acpi_s3.h> #include <acpi/acpi_table.h> #include <asm/acpi.h> +#include <asm/global_data.h> #include <asm/post.h> #include <linux/linkage.h>
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 9a41ecb587d8..5ec31301d0b8 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -22,6 +22,7 @@ #include <acpi/acpi_table.h> #include <asm/acpi/global_nvs.h> #include <asm/ioapic.h> +#include <asm/global_data.h> #include <asm/lapic.h> #include <asm/mpspec.h> #include <asm/tables.h> diff --git a/arch/x86/lib/asm-offsets.c b/arch/x86/lib/asm-offsets.c index 47b38cd9e782..8df67db65c39 100644 --- a/arch/x86/lib/asm-offsets.c +++ b/arch/x86/lib/asm-offsets.c @@ -12,6 +12,7 @@ */
int main(void) diff --git a/arch/x86/lib/bios.c b/arch/x86/lib/bios.c index 3ab432e2623c..fbdc3b04e361 100644 --- a/arch/x86/lib/bios.c +++ b/arch/x86/lib/bios.c @@ -6,6 +6,7 @@ * Copyright (C) 2009-2010 coresystems GmbH */ #include <common.h> +#include <compiler.h> #include <bios_emul.h> #include <irq_func.h> #include <log.h> diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index da6b8ce1ec16..aa5f0bf6b728 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -12,6 +12,7 @@ #include <command.h> #include <hang.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/root.h> #include <errno.h> diff --git a/arch/x86/lib/cmd_boot.c b/arch/x86/lib/cmd_boot.c index baaf3d13ad4b..4facbe5f32fb 100644 --- a/arch/x86/lib/cmd_boot.c +++ b/arch/x86/lib/cmd_boot.c @@ -17,6 +17,7 @@ #include <common.h> #include <command.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/u-boot-x86.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/x86/lib/coreboot_table.c b/arch/x86/lib/coreboot_table.c index 6cd324430121..6eab0452fda6 100644 --- a/arch/x86/lib/coreboot_table.c +++ b/arch/x86/lib/coreboot_table.c @@ -10,6 +10,7 @@ #include <acpi/acpi_s3.h> #include <asm/coreboot_tables.h> #include <asm/e820.h> +#include <asm/global_data.h>
diff --git a/arch/x86/lib/e820.c b/arch/x86/lib/e820.c index 1f20c5c8c6bb..12fcff123805 100644 --- a/arch/x86/lib/e820.c +++ b/arch/x86/lib/e820.c @@ -6,6 +6,7 @@ #include <common.h> #include <efi_loader.h> #include <asm/e820.h> +#include <asm/global_data.h>
diff --git a/arch/x86/lib/fsp/fsp_common.c b/arch/x86/lib/fsp/fsp_common.c index 4061fa244c49..6365b0a50a72 100644 --- a/arch/x86/lib/fsp/fsp_common.c +++ b/arch/x86/lib/fsp/fsp_common.c @@ -13,6 +13,7 @@ #include <acpi/acpi_s3.h> #include <asm/cmos_layout.h> #include <asm/early_cmos.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mrccache.h> #include <asm/post.h> diff --git a/arch/x86/lib/fsp/fsp_dram.c b/arch/x86/lib/fsp/fsp_dram.c index 3ffd40ce7478..8ad9aeedac0e 100644 --- a/arch/x86/lib/fsp/fsp_dram.c +++ b/arch/x86/lib/fsp/fsp_dram.c @@ -9,6 +9,7 @@ #include <log.h> #include <asm/fsp/fsp_support.h> #include <asm/e820.h> +#include <asm/global_data.h> #include <asm/mrccache.h> #include <asm/mtrr.h> #include <asm/post.h> diff --git a/arch/x86/lib/fsp/fsp_graphics.c b/arch/x86/lib/fsp/fsp_graphics.c index a029237d08ef..cc909e0e16aa 100644 --- a/arch/x86/lib/fsp/fsp_graphics.c +++ b/arch/x86/lib/fsp/fsp_graphics.c @@ -13,6 +13,7 @@ #include <video.h> #include <acpi/acpi_table.h> #include <asm/fsp/fsp_support.h> +#include <asm/global_data.h> #include <asm/intel_opregion.h> #include <asm/mtrr.h> #include <dm/acpi.h> diff --git a/arch/x86/lib/fsp1/fsp_common.c b/arch/x86/lib/fsp1/fsp_common.c index da351cf097c0..20926171822d 100644 --- a/arch/x86/lib/fsp1/fsp_common.c +++ b/arch/x86/lib/fsp1/fsp_common.c @@ -13,6 +13,7 @@ #include <acpi/acpi_s3.h> #include <asm/cmos_layout.h> #include <asm/early_cmos.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mrccache.h> #include <asm/post.h> diff --git a/arch/x86/lib/fsp1/fsp_dram.c b/arch/x86/lib/fsp1/fsp_dram.c index e3f9e30f6a63..cfd9b9f48c34 100644 --- a/arch/x86/lib/fsp1/fsp_dram.c +++ b/arch/x86/lib/fsp1/fsp_dram.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <asm/fsp/fsp_support.h> +#include <asm/global_data.h>
int dram_init(void) { diff --git a/arch/x86/lib/fsp2/fsp_dram.c b/arch/x86/lib/fsp2/fsp_dram.c index a95fdc46c1b2..42d3892b7626 100644 --- a/arch/x86/lib/fsp2/fsp_dram.c +++ b/arch/x86/lib/fsp2/fsp_dram.c @@ -16,6 +16,7 @@ #include <asm/fsp/fsp_support.h> #include <asm/fsp2/fsp_api.h> #include <asm/fsp2/fsp_internal.h> +#include <asm/global_data.h> #include <linux/sizes.h>
int dram_init(void) diff --git a/arch/x86/lib/fsp2/fsp_meminit.c b/arch/x86/lib/fsp2/fsp_meminit.c index ce0b0aff76be..022e2cb64e5a 100644 --- a/arch/x86/lib/fsp2/fsp_meminit.c +++ b/arch/x86/lib/fsp2/fsp_meminit.c @@ -11,6 +11,7 @@ #include <bootstage.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mrccache.h> #include <asm/fsp/fsp_infoheader.h> #include <asm/fsp2/fsp_api.h> diff --git a/arch/x86/lib/fsp2/fsp_silicon_init.c b/arch/x86/lib/fsp2/fsp_silicon_init.c index ead3493de824..a96d2b183f6e 100644 --- a/arch/x86/lib/fsp2/fsp_silicon_init.c +++ b/arch/x86/lib/fsp2/fsp_silicon_init.c @@ -17,6 +17,7 @@ #include <asm/arch/fsp/fsp_s_upd.h> #include <asm/fsp/fsp_infoheader.h> #include <asm/fsp2/fsp_internal.h> +#include <asm/global_data.h>
int fsp_silicon_init(bool s3wake, bool use_spi_flash) { diff --git a/arch/x86/lib/fsp2/fsp_support.c b/arch/x86/lib/fsp2/fsp_support.c index f220ef498b04..503f97d5f334 100644 --- a/arch/x86/lib/fsp2/fsp_support.c +++ b/arch/x86/lib/fsp2/fsp_support.c @@ -10,6 +10,7 @@ #include <spi_flash.h> #include <asm/fsp/fsp_support.h> #include <asm/fsp2/fsp_internal.h> +#include <asm/global_data.h>
/* The amount of the FSP header to probe to obtain what we need */ #define PROBE_BUF_SIZE 0x180 diff --git a/arch/x86/lib/init_helpers.c b/arch/x86/lib/init_helpers.c index d906b528b35b..066dc404a2d8 100644 --- a/arch/x86/lib/init_helpers.c +++ b/arch/x86/lib/init_helpers.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/mtrr.h>
diff --git a/arch/x86/lib/mpspec.c b/arch/x86/lib/mpspec.c index 562a27c55799..8e97d9ff36d9 100644 --- a/arch/x86/lib/mpspec.c +++ b/arch/x86/lib/mpspec.c @@ -12,6 +12,7 @@ #include <fdtdec.h> #include <log.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/irq.h> #include <asm/ioapic.h> #include <asm/lapic.h> diff --git a/arch/x86/lib/mrccache.c b/arch/x86/lib/mrccache.c index f181e8100cb7..b52691568012 100644 --- a/arch/x86/lib/mrccache.c +++ b/arch/x86/lib/mrccache.c @@ -15,6 +15,7 @@ #include <net.h> #include <spi.h> #include <spi_flash.h> +#include <asm/global_data.h> #include <asm/mrccache.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> diff --git a/arch/x86/lib/physmem.c b/arch/x86/lib/physmem.c index 4578046169a7..c11101b44ece 100644 --- a/arch/x86/lib/physmem.c +++ b/arch/x86/lib/physmem.c @@ -12,6 +12,7 @@ #include <log.h> #include <physmem.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <linux/compiler.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/x86/lib/pinctrl_ich6.c b/arch/x86/lib/pinctrl_ich6.c index 482599478b80..fd5e311b2916 100644 --- a/arch/x86/lib/pinctrl_ich6.c +++ b/arch/x86/lib/pinctrl_ich6.c @@ -11,6 +11,7 @@ #include <pch.h> #include <pci.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/pci.h> diff --git a/arch/x86/lib/pirq_routing.c b/arch/x86/lib/pirq_routing.c index eb6a7d96de10..caeaec9287fe 100644 --- a/arch/x86/lib/pirq_routing.c +++ b/arch/x86/lib/pirq_routing.c @@ -8,6 +8,7 @@ #include <common.h> #include <log.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/pci.h> #include <asm/pirq_routing.h>
diff --git a/arch/x86/lib/relocate.c b/arch/x86/lib/relocate.c index ecbd0927e07c..6fe515164773 100644 --- a/arch/x86/lib/relocate.c +++ b/arch/x86/lib/relocate.c @@ -17,6 +17,7 @@ #include <common.h> #include <log.h> #include <relocate.h> +#include <asm/global_data.h> #include <asm/u-boot-x86.h> #include <asm/sections.h> #include <elf.h> diff --git a/arch/x86/lib/spl.c b/arch/x86/lib/spl.c index 6699de49c636..1bae1f4f321b 100644 --- a/arch/x86/lib/spl.c +++ b/arch/x86/lib/spl.c @@ -17,6 +17,7 @@ #include <syscon.h> #include <asm/cpu.h> #include <asm/cpu_common.h> +#include <asm/global_data.h> #include <asm/mrccache.h> #include <asm/mtrr.h> #include <asm/pci.h> diff --git a/arch/x86/lib/tables.c b/arch/x86/lib/tables.c index c4007fa48669..1779bb3e11ae 100644 --- a/arch/x86/lib/tables.c +++ b/arch/x86/lib/tables.c @@ -9,6 +9,7 @@ #include <malloc.h> #include <smbios.h> #include <acpi/acpi_table.h> +#include <asm/global_data.h> #include <asm/sfi.h> #include <asm/mpspec.h> #include <asm/tables.h> diff --git a/arch/x86/lib/tpl.c b/arch/x86/lib/tpl.c index c84a0c9bc7d9..ac6b6efbccd6 100644 --- a/arch/x86/lib/tpl.c +++ b/arch/x86/lib/tpl.c @@ -12,6 +12,7 @@ #include <log.h> #include <spl.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/mtrr.h> #include <asm/processor.h> #include <asm-generic/sections.h> diff --git a/arch/xtensa/lib/bootm.c b/arch/xtensa/lib/bootm.c index 0e564507f94f..bb1e2886abc7 100644 --- a/arch/xtensa/lib/bootm.c +++ b/arch/xtensa/lib/bootm.c @@ -9,6 +9,7 @@ #include <command.h> #include <cpu_func.h> #include <env.h> +#include <asm/global_data.h> #include <u-boot/zlib.h> #include <asm/byteorder.h> #include <asm/addrspace.h> diff --git a/board/AndesTech/adp-ae3xx/adp-ae3xx.c b/board/AndesTech/adp-ae3xx/adp-ae3xx.c index b52cbd4d8615..3c4a27d63f6a 100644 --- a/board/AndesTech/adp-ae3xx/adp-ae3xx.c +++ b/board/AndesTech/adp-ae3xx/adp-ae3xx.c @@ -7,6 +7,7 @@
#include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <common.h> #include <flash.h> diff --git a/board/AndesTech/adp-ag101p/adp-ag101p.c b/board/AndesTech/adp-ag101p/adp-ag101p.c index 3dd880f3d6c4..8848b7f97386 100644 --- a/board/AndesTech/adp-ag101p/adp-ag101p.c +++ b/board/AndesTech/adp-ag101p/adp-ag101p.c @@ -12,6 +12,7 @@ #if defined(CONFIG_FTMAC100) && !defined(CONFIG_DM_ETH) #include <netdev.h> #endif +#include <asm/global_data.h> #include <linux/io.h> #include <asm/io.h> #include <asm/mach-types.h> diff --git a/board/AndesTech/ax25-ae350/ax25-ae350.c b/board/AndesTech/ax25-ae350/ax25-ae350.c index 59a43e4dcc4d..d781038de285 100644 --- a/board/AndesTech/ax25-ae350/ax25-ae350.c +++ b/board/AndesTech/ax25-ae350/ax25-ae350.c @@ -12,6 +12,7 @@ #if defined(CONFIG_FTMAC100) && !defined(CONFIG_DM_ETH) #include <netdev.h> #endif +#include <asm/global_data.h> #include <linux/io.h> #include <faraday/ftsmc020.h> #include <fdtdec.h> diff --git a/board/Arcturus/ucp1020/spl.c b/board/Arcturus/ucp1020/spl.c index 4ed06a80b798..437e975fdf7d 100644 --- a/board/Arcturus/ucp1020/spl.c +++ b/board/Arcturus/ucp1020/spl.c @@ -20,6 +20,7 @@ #include <i2c.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h>
diff --git a/board/BuR/brppt1/board.c b/board/BuR/brppt1/board.c index 8aa03eac2838..7df37e4e66ac 100644 --- a/board/BuR/brppt1/board.c +++ b/board/BuR/brppt1/board.c @@ -23,6 +23,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/BuR/brppt2/board.c b/board/BuR/brppt2/board.c index f156b552a761..e6eb403fc3d9 100644 --- a/board/BuR/brppt2/board.c +++ b/board/BuR/brppt2/board.c @@ -21,6 +21,7 @@ # include <asm/arch/mx6-ddr.h> #endif #include <asm/arch/clock.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h>
diff --git a/board/BuR/brsmarc1/board.c b/board/BuR/brsmarc1/board.c index 5b9108a89f91..738a5d2ff944 100644 --- a/board/BuR/brsmarc1/board.c +++ b/board/BuR/brsmarc1/board.c @@ -19,6 +19,7 @@ #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/emif.h> diff --git a/board/BuR/brxre1/board.c b/board/BuR/brxre1/board.c index 5d57e19fde03..ef692b006d51 100644 --- a/board/BuR/brxre1/board.c +++ b/board/BuR/brxre1/board.c @@ -21,6 +21,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/BuR/common/common.c b/board/BuR/common/common.c index f676d7baa6af..78bf7d622882 100644 --- a/board/BuR/common/common.c +++ b/board/BuR/common/common.c @@ -15,6 +15,7 @@ #include <fdtdec.h> #include <i2c.h> #include <lcd.h> +#include <asm/global_data.h> #include <linux/delay.h> #include "bur_common.h"
diff --git a/board/BuS/eb_cpu5282/eb_cpu5282.c b/board/BuS/eb_cpu5282/eb_cpu5282.c index f5e4de3c4183..153ed0e963b0 100644 --- a/board/BuS/eb_cpu5282/eb_cpu5282.c +++ b/board/BuS/eb_cpu5282/eb_cpu5282.c @@ -9,6 +9,7 @@
#include <common.h> #include <command.h> +#include <asm/global_data.h> #include "asm/m5282.h" #include <bmp_layout.h> #include <env.h> diff --git a/board/CZ.NIC/turris_mox/turris_mox.c b/board/CZ.NIC/turris_mox/turris_mox.c index 679f3eb7014c..486680a49e88 100644 --- a/board/CZ.NIC/turris_mox/turris_mox.c +++ b/board/CZ.NIC/turris_mox/turris_mox.c @@ -7,6 +7,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <clk.h> diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 2da878d3648b..0353d58a361b 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -15,6 +15,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/CarMediaLab/flea3/flea3.c b/board/CarMediaLab/flea3/flea3.c index 11fcecb94e57..12c5ac331f97 100644 --- a/board/CarMediaLab/flea3/flea3.c +++ b/board/CarMediaLab/flea3/flea3.c @@ -9,6 +9,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <env.h> #include <linux/delay.h> diff --git a/board/LaCie/edminiv2/edminiv2.c b/board/LaCie/edminiv2/edminiv2.c index b5ffe8162f32..9c066a283c99 100644 --- a/board/LaCie/edminiv2/edminiv2.c +++ b/board/LaCie/edminiv2/edminiv2.c @@ -11,6 +11,7 @@ #include <miiphy.h> #include <net.h> #include <asm/arch/orion5x.h> +#include <asm/global_data.h> #include "../common/common.h" #include <spl.h> #include <ns16550.h> diff --git a/board/LaCie/net2big_v2/net2big_v2.c b/board/LaCie/net2big_v2/net2big_v2.c index e94c9a6dce96..695d6f6ed470 100644 --- a/board/LaCie/net2big_v2/net2big_v2.c +++ b/board/LaCie/net2big_v2/net2big_v2.c @@ -14,6 +14,7 @@ #include <i2c.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/LaCie/netspace_v2/netspace_v2.c b/board/LaCie/netspace_v2/netspace_v2.c index 33246b201528..730eab7e7031 100644 --- a/board/LaCie/netspace_v2/netspace_v2.c +++ b/board/LaCie/netspace_v2/netspace_v2.c @@ -13,6 +13,7 @@ #include <env.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/aspenite/aspenite.c b/board/Marvell/aspenite/aspenite.c index c1406d7489cf..1f9389c0a7ab 100644 --- a/board/Marvell/aspenite/aspenite.c +++ b/board/Marvell/aspenite/aspenite.c @@ -9,6 +9,7 @@ #include <common.h> #include <init.h> #include <mvmfp.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/mfp.h> diff --git a/board/Marvell/db-88f6281-bp/db-88f6281-bp.c b/board/Marvell/db-88f6281-bp/db-88f6281-bp.c index 62027bd6385e..08f79d4b5320 100644 --- a/board/Marvell/db-88f6281-bp/db-88f6281-bp.c +++ b/board/Marvell/db-88f6281-bp/db-88f6281-bp.c @@ -3,6 +3,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <miiphy.h> diff --git a/board/Marvell/db-88f6720/db-88f6720.c b/board/Marvell/db-88f6720/db-88f6720.c index 271535b76376..26c30647fbb0 100644 --- a/board/Marvell/db-88f6720/db-88f6720.c +++ b/board/Marvell/db-88f6720/db-88f6720.c @@ -8,6 +8,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/db-88f6820-amc/db-88f6820-amc.c b/board/Marvell/db-88f6820-amc/db-88f6820-amc.c index 9cd9ea2c0689..163a1b3de9d2 100644 --- a/board/Marvell/db-88f6820-amc/db-88f6820-amc.c +++ b/board/Marvell/db-88f6820-amc/db-88f6820-amc.c @@ -9,6 +9,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/db-88f6820-gp/db-88f6820-gp.c b/board/Marvell/db-88f6820-gp/db-88f6820-gp.c index 2bdd55329d05..06307e582cec 100644 --- a/board/Marvell/db-88f6820-gp/db-88f6820-gp.c +++ b/board/Marvell/db-88f6820-gp/db-88f6820-gp.c @@ -9,6 +9,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c b/board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c index 8d1dbebdb7a6..9e1fdecfca4d 100644 --- a/board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c +++ b/board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c @@ -8,6 +8,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c b/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c index 5f12a27002f0..0abdca1cd210 100644 --- a/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c +++ b/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c @@ -6,6 +6,7 @@ #include <common.h> #include <i2c.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/bitops.h> #include <linux/mbus.h> diff --git a/board/Marvell/dreamplug/dreamplug.c b/board/Marvell/dreamplug/dreamplug.c index 7d188c327955..e1c64b52246b 100644 --- a/board/Marvell/dreamplug/dreamplug.c +++ b/board/Marvell/dreamplug/dreamplug.c @@ -15,6 +15,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> +#include <asm/global_data.h> #include "dreamplug.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/Marvell/gplugd/gplugd.c b/board/Marvell/gplugd/gplugd.c index 58e433fd3472..c6376cdf6a94 100644 --- a/board/Marvell/gplugd/gplugd.c +++ b/board/Marvell/gplugd/gplugd.c @@ -18,6 +18,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/mfp.h> #include <asm/arch/armada100.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <miiphy.h> #include <asm/mach-types.h> diff --git a/board/Marvell/guruplug/guruplug.c b/board/Marvell/guruplug/guruplug.c index f3981c66d20b..8e7dbb3f3f60 100644 --- a/board/Marvell/guruplug/guruplug.c +++ b/board/Marvell/guruplug/guruplug.c @@ -9,6 +9,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index 1b9e7520cc7a..447365b97c41 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -11,6 +11,7 @@ #include <init.h> #include <mmc.h> #include <phy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/mvebu_armada-8k/board.c b/board/Marvell/mvebu_armada-8k/board.c index bf8a929ec1e6..7da5d9f96b1a 100644 --- a/board/Marvell/mvebu_armada-8k/board.c +++ b/board/Marvell/mvebu_armada-8k/board.c @@ -7,6 +7,7 @@ #include <dm.h> #include <i2c.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/octeontx/board.c b/board/Marvell/octeontx/board.c index 940faacbe375..059ebf8f1727 100644 --- a/board/Marvell/octeontx/board.c +++ b/board/Marvell/octeontx/board.c @@ -13,6 +13,7 @@ #include <log.h> #include <netdev.h> #include <pci_ids.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/compiler.h> #include <linux/libfdt.h> diff --git a/board/Marvell/octeontx2/board.c b/board/Marvell/octeontx2/board.c index 50e903d9aa91..9b973a4acebb 100644 --- a/board/Marvell/octeontx2/board.c +++ b/board/Marvell/octeontx2/board.c @@ -9,6 +9,7 @@ #include <console.h> #include <cpu_func.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/uclass-internal.h> #include <env.h> #include <init.h> diff --git a/board/Marvell/openrd/openrd.c b/board/Marvell/openrd/openrd.c index d9b5b213feab..f44ac3315ebc 100644 --- a/board/Marvell/openrd/openrd.c +++ b/board/Marvell/openrd/openrd.c @@ -14,6 +14,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Marvell/sheevaplug/sheevaplug.c b/board/Marvell/sheevaplug/sheevaplug.c index 6311ed3b2e59..0cc7f2b39243 100644 --- a/board/Marvell/sheevaplug/sheevaplug.c +++ b/board/Marvell/sheevaplug/sheevaplug.c @@ -9,6 +9,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Seagate/dockstar/dockstar.c b/board/Seagate/dockstar/dockstar.c index 85dd10e55a2c..380e37be5502 100644 --- a/board/Seagate/dockstar/dockstar.c +++ b/board/Seagate/dockstar/dockstar.c @@ -16,6 +16,7 @@ #include <asm/arch/soc.h> #include <asm/arch/mpp.h> #include <asm/arch/cpu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include "dockstar.h" diff --git a/board/Seagate/goflexhome/goflexhome.c b/board/Seagate/goflexhome/goflexhome.c index de1ec544667c..4c19fa7195e8 100644 --- a/board/Seagate/goflexhome/goflexhome.c +++ b/board/Seagate/goflexhome/goflexhome.c @@ -16,6 +16,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> diff --git a/board/Seagate/nas220/nas220.c b/board/Seagate/nas220/nas220.c index 3a027d083a7b..cd2bbdad1cd6 100644 --- a/board/Seagate/nas220/nas220.c +++ b/board/Seagate/nas220/nas220.c @@ -12,6 +12,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> diff --git a/board/Synology/ds109/ds109.c b/board/Synology/ds109/ds109.c index fe3b0eb554ff..eaac95460c6e 100644 --- a/board/Synology/ds109/ds109.c +++ b/board/Synology/ds109/ds109.c @@ -9,6 +9,7 @@ #include <init.h> #include <miiphy.h> #include <net.h> +#include <asm/global_data.h> #include <asm/setup.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/Synology/ds414/ds414.c b/board/Synology/ds414/ds414.c index 632205164ebf..9c4ce670ddfb 100644 --- a/board/Synology/ds414/ds414.c +++ b/board/Synology/ds414/ds414.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <miiphy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/advantech/dms-ba16/dms-ba16.c b/board/advantech/dms-ba16/dms-ba16.c index 20820fdf0762..07a47e9fbb04 100644 --- a/board/advantech/dms-ba16/dms-ba16.c +++ b/board/advantech/dms-ba16/dms-ba16.c @@ -11,6 +11,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/advantech/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c b/board/advantech/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c index ea057d27cf35..8492e7603b46 100644 --- a/board/advantech/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c +++ b/board/advantech/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c @@ -9,6 +9,7 @@ #include <env.h> #include <errno.h> #include <init.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <asm/io.h> diff --git a/board/advantech/imx8qm_rom7720_a1/spl.c b/board/advantech/imx8qm_rom7720_a1/spl.c index a2386c9ef005..8493bb01588d 100644 --- a/board/advantech/imx8qm_rom7720_a1/spl.c +++ b/board/advantech/imx8qm_rom7720_a1/spl.c @@ -9,6 +9,7 @@ #include <log.h> #include <spl.h> #include <fsl_esdhc.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <asm/gpio.h> diff --git a/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c b/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c index 668484b71b6a..d8b9fdfe356f 100644 --- a/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c +++ b/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/io.h> diff --git a/board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c b/board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c index e4bf507cc3f0..52b8eba92fc1 100644 --- a/board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c +++ b/board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c @@ -10,6 +10,7 @@ #include <net.h> #include <netdev.h> #include <led.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <asm/arch/cpu.h> diff --git a/board/alliedtelesis/common/gpio_hog.c b/board/alliedtelesis/common/gpio_hog.c index 1f87b3ac1b72..4aecf7e2cef7 100644 --- a/board/alliedtelesis/common/gpio_hog.c +++ b/board/alliedtelesis/common/gpio_hog.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <asm/gpio.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/alliedtelesis/x530/x530.c b/board/alliedtelesis/x530/x530.c index c7438aeaf148..d602092d7329 100644 --- a/board/alliedtelesis/x530/x530.c +++ b/board/alliedtelesis/x530/x530.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <init.h> #include <wdt.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/bitops.h> #include <linux/mbus.h> diff --git a/board/amazon/kc1/kc1.c b/board/amazon/kc1/kc1.c index 973bc5a92729..75fb14025c12 100644 --- a/board/amazon/kc1/kc1.c +++ b/board/amazon/kc1/kc1.c @@ -10,6 +10,7 @@ #include <env.h> #include <fastboot.h> #include <init.h> +#include <asm/global_data.h> #include <linux/ctype.h> #include <linux/usb/musb.h> #include <asm/omap_musb.h> diff --git a/board/amlogic/vim3/vim3.c b/board/amlogic/vim3/vim3.c index 7145dbe18ecb..7b09617cdc6b 100644 --- a/board/amlogic/vim3/vim3.c +++ b/board/amlogic/vim3/vim3.c @@ -13,6 +13,7 @@ #include <asm/arch/boot.h> #include <asm/arch/eth.h> #include <asm/arch/sm.h> +#include <asm/global_data.h> #include <i2c.h> #include "khadas-mcu.h"
diff --git a/board/aristainetos/aristainetos.c b/board/aristainetos/aristainetos.c index 07d2e3ec7bb0..f13fa1163747 100644 --- a/board/aristainetos/aristainetos.c +++ b/board/aristainetos/aristainetos.c @@ -16,6 +16,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/armadeus/apf27/apf27.c b/board/armadeus/apf27/apf27.c index 29e0bf388d07..5e3fdd36fa21 100644 --- a/board/armadeus/apf27/apf27.c +++ b/board/armadeus/apf27/apf27.c @@ -9,6 +9,7 @@ #include <common.h> #include <hang.h> #include <init.h> +#include <asm/global_data.h> #include <jffs2/jffs2.h> #include <nand.h> #include <netdev.h> diff --git a/board/armltd/integrator/integrator.c b/board/armltd/integrator/integrator.c index 3c56fa1c019f..3e864e8e7a5c 100644 --- a/board/armltd/integrator/integrator.c +++ b/board/armltd/integrator/integrator.c @@ -24,6 +24,7 @@ #include <init.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/platform_data/serial_pl01x.h> #include "arm-ebi.h" diff --git a/board/armltd/total_compute/total_compute.c b/board/armltd/total_compute/total_compute.c index da24b32333bb..01c65e4db813 100644 --- a/board/armltd/total_compute/total_compute.c +++ b/board/armltd/total_compute/total_compute.c @@ -8,6 +8,7 @@ #include <dm.h> #include <dm/platform_data/serial_pl01x.h> #include <asm/armv8/mmu.h> +#include <asm/global_data.h>
static const struct pl01x_serial_plat serial_plat = { .base = UART0_BASE, diff --git a/board/armltd/vexpress/vexpress_common.c b/board/armltd/vexpress/vexpress_common.c index 8fea8ff35294..df4cbd320430 100644 --- a/board/armltd/vexpress/vexpress_common.c +++ b/board/armltd/vexpress/vexpress_common.c @@ -23,6 +23,7 @@ #include <errno.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include <asm/arch/systimer.h> diff --git a/board/armltd/vexpress64/vexpress64.c b/board/armltd/vexpress64/vexpress64.c index bd66d52cb7b4..9d294903e968 100644 --- a/board/armltd/vexpress64/vexpress64.c +++ b/board/armltd/vexpress64/vexpress64.c @@ -12,6 +12,7 @@ #include <errno.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/compiler.h> #include <dm/platform_data/serial_pl01x.h> diff --git a/board/astro/mcf5373l/mcf5373l.c b/board/astro/mcf5373l/mcf5373l.c index e7c2b909300d..3e2f79a1cf4c 100644 --- a/board/astro/mcf5373l/mcf5373l.c +++ b/board/astro/mcf5373l/mcf5373l.c @@ -10,6 +10,7 @@ #include <serial.h> #include <watchdog.h> #include <command.h> +#include <asm/global_data.h> #include <asm/m5329.h> #include <asm/immap_5329.h> #include <asm/io.h> diff --git a/board/atmark-techno/armadillo-800eva/armadillo-800eva.c b/board/atmark-techno/armadillo-800eva/armadillo-800eva.c index a18fb275d9f5..1bae2832522f 100644 --- a/board/atmark-techno/armadillo-800eva/armadillo-800eva.c +++ b/board/atmark-techno/armadillo-800eva/armadillo-800eva.c @@ -24,6 +24,7 @@ #include <cpu_func.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mach-types.h> #include <asm/io.h> diff --git a/board/atmel/at91rm9200ek/at91rm9200ek.c b/board/atmel/at91rm9200ek/at91rm9200ek.c index 8844bc754193..a314ced5e4a5 100644 --- a/board/atmel/at91rm9200ek/at91rm9200ek.c +++ b/board/atmel/at91rm9200ek/at91rm9200ek.c @@ -13,6 +13,7 @@ #include <init.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pio.h> diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index 42fa7627724e..38f97bce2042 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -9,6 +9,7 @@ #include <debug_uart.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index f467a4f566c9..0318eeaa94e9 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -9,6 +9,7 @@ #include <debug_uart.h> #include <init.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9261.h> #include <asm/arch/at91sam9261_matrix.h> diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index be132bc185fb..3218e14e860a 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -11,6 +11,7 @@ #include <init.h> #include <net.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/arch/at91sam9263.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index 8aabc5595196..8cb2808e058a 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -10,6 +10,7 @@ #include <init.h> #include <net.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clk.h> #include <asm/arch/at91sam9g45_matrix.h> diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c index d7ff2e13352f..a3fc55bbc34b 100644 --- a/board/atmel/at91sam9n12ek/at91sam9n12ek.c +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -8,6 +8,7 @@ #include <init.h> #include <net.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9x5_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index f81dccc9cccb..f427ee658bff 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -9,6 +9,7 @@ #include <debug_uart.h> #include <init.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include <asm/arch/at91sam9rl.h> diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 2c071075bac5..e0abe4aeb08b 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9x5_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/atmel/common/video_display.c b/board/atmel/common/video_display.c index 2666b0b3cd5d..a5049f4aad41 100644 --- a/board/atmel/common/video_display.c +++ b/board/atmel/common/video_display.c @@ -13,6 +13,7 @@ #include <video.h> #include <video_console.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clk.h>
diff --git a/board/atmel/sam9x60ek/sam9x60ek.c b/board/atmel/sam9x60ek/sam9x60ek.c index fbd05c78a948..32e5a2bf23af 100644 --- a/board/atmel/sam9x60ek/sam9x60ek.c +++ b/board/atmel/sam9x60ek/sam9x60ek.c @@ -7,6 +7,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> diff --git a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c index 376562cd0e7d..1b7d946b50c3 100644 --- a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c +++ b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c @@ -7,6 +7,7 @@ #include <common.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c index c8c2e9581679..32d51bba7d96 100644 --- a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c +++ b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c @@ -8,6 +8,7 @@ #include <common.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/atmel/sama5d2_icp/sama5d2_icp.c b/board/atmel/sama5d2_icp/sama5d2_icp.c index 7c34df48b871..3f33fcfc4665 100644 --- a/board/atmel/sama5d2_icp/sama5d2_icp.c +++ b/board/atmel/sama5d2_icp/sama5d2_icp.c @@ -7,6 +7,7 @@ #include <common.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c b/board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c index b0a23b02db2b..a6937e7d5243 100644 --- a/board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c +++ b/board/atmel/sama5d2_ptc_ek/sama5d2_ptc_ek.c @@ -11,6 +11,7 @@ #include <init.h> #include <nand.h> #include <version.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/atmel/sama5d2_xplained/sama5d2_xplained.c b/board/atmel/sama5d2_xplained/sama5d2_xplained.c index 01636fb73d01..5110ec89697f 100644 --- a/board/atmel/sama5d2_xplained/sama5d2_xplained.c +++ b/board/atmel/sama5d2_xplained/sama5d2_xplained.c @@ -7,6 +7,7 @@ #include <common.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/atmel/sama5d3_xplained/sama5d3_xplained.c b/board/atmel/sama5d3_xplained/sama5d3_xplained.c index 84c561be6fc3..db9603f58477 100644 --- a/board/atmel/sama5d3_xplained/sama5d3_xplained.c +++ b/board/atmel/sama5d3_xplained/sama5d3_xplained.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sama5d3_smc.h> #include <asm/arch/at91_common.h> diff --git a/board/atmel/sama5d3xek/sama5d3xek.c b/board/atmel/sama5d3xek/sama5d3xek.c index 7f6a31985920..b6f8dcd91dc0 100644 --- a/board/atmel/sama5d3xek/sama5d3xek.c +++ b/board/atmel/sama5d3xek/sama5d3xek.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sama5d3_smc.h> #include <asm/arch/at91_common.h> diff --git a/board/atmel/sama5d4_xplained/sama5d4_xplained.c b/board/atmel/sama5d4_xplained/sama5d4_xplained.c index 93cc183a5b47..2088b48b7ee2 100644 --- a/board/atmel/sama5d4_xplained/sama5d4_xplained.c +++ b/board/atmel/sama5d4_xplained/sama5d4_xplained.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_rstc.h> diff --git a/board/atmel/sama5d4ek/sama5d4ek.c b/board/atmel/sama5d4ek/sama5d4ek.c index 4b3883e20f85..46ec1eb32467 100644 --- a/board/atmel/sama5d4ek/sama5d4ek.c +++ b/board/atmel/sama5d4ek/sama5d4ek.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_rstc.h> diff --git a/board/atmel/sama7g5ek/sama7g5ek.c b/board/atmel/sama7g5ek/sama7g5ek.c index b5cece08ac3d..4df43d81f827 100644 --- a/board/atmel/sama7g5ek/sama7g5ek.c +++ b/board/atmel/sama7g5ek/sama7g5ek.c @@ -7,6 +7,7 @@ #include <common.h> #include <debug_uart.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/atmel_pio4.h> diff --git a/board/bachmann/ot1200/ot1200.c b/board/bachmann/ot1200/ot1200.c index d3af634e3aba..69d1b106b072 100644 --- a/board/bachmann/ot1200/ot1200.c +++ b/board/bachmann/ot1200/ot1200.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/barco/platinum/platinum.c b/board/barco/platinum/platinum.c index f96106cb75ed..ec8d55288876 100644 --- a/board/barco/platinum/platinum.c +++ b/board/barco/platinum/platinum.c @@ -11,6 +11,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/barco/titanium/titanium.c b/board/barco/titanium/titanium.c index 7a52e94c7eeb..efd1dc35ef4c 100644 --- a/board/barco/titanium/titanium.c +++ b/board/barco/titanium/titanium.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/beacon/beacon-rzg2m/beacon-rzg2m.c b/board/beacon/beacon-rzg2m/beacon-rzg2m.c index 86a24dd0658f..c343de510232 100644 --- a/board/beacon/beacon-rzg2m/beacon-rzg2m.c +++ b/board/beacon/beacon-rzg2m/beacon-rzg2m.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/rcar-mstp.h>
diff --git a/board/beacon/imx8mm/imx8mm_beacon.c b/board/beacon/imx8mm/imx8mm_beacon.c index c61d25fbead7..87ffebb5713d 100644 --- a/board/beacon/imx8mm/imx8mm_beacon.c +++ b/board/beacon/imx8mm/imx8mm_beacon.c @@ -6,6 +6,7 @@ #include <common.h> #include <miiphy.h> #include <netdev.h> +#include <asm/global_data.h>
#include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> diff --git a/board/beacon/imx8mm/spl.c b/board/beacon/imx8mm/spl.c index 4ee10cf8555e..12266b22a42f 100644 --- a/board/beacon/imx8mm/spl.c +++ b/board/beacon/imx8mm/spl.c @@ -6,6 +6,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/arch/clock.h> diff --git a/board/beacon/imx8mn/imx8mn_beacon.c b/board/beacon/imx8mn/imx8mn_beacon.c index 51deb7b4e665..7fe252b262b1 100644 --- a/board/beacon/imx8mn/imx8mn_beacon.c +++ b/board/beacon/imx8mn/imx8mn_beacon.c @@ -9,6 +9,7 @@
#include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/beacon/imx8mn/spl.c b/board/beacon/imx8mn/spl.c index 6f076f544525..b5263ccfd78d 100644 --- a/board/beacon/imx8mn/spl.c +++ b/board/beacon/imx8mn/spl.c @@ -10,6 +10,7 @@ #include <log.h> #include <asm/io.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/ddr.h> #include <asm/arch/imx8mn_pins.h> diff --git a/board/beckhoff/mx53cx9020/mx53cx9020.c b/board/beckhoff/mx53cx9020/mx53cx9020.c index 617b545232a2..a3657db8266c 100644 --- a/board/beckhoff/mx53cx9020/mx53cx9020.c +++ b/board/beckhoff/mx53cx9020/mx53cx9020.c @@ -13,6 +13,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/clock.h> #include <asm/arch/iomux-mx53.h> +#include <asm/global_data.h> #include <asm/mach-imx/mx5_video.h> #include <ACEX1K.h> #include <asm/gpio.h> diff --git a/board/bluegiga/apx4devkit/apx4devkit.c b/board/bluegiga/apx4devkit/apx4devkit.c index 739f71f5c4d1..ed0885f724c4 100644 --- a/board/bluegiga/apx4devkit/apx4devkit.c +++ b/board/bluegiga/apx4devkit/apx4devkit.c @@ -16,6 +16,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/setup.h> diff --git a/board/bluewater/gurnard/gurnard.c b/board/bluewater/gurnard/gurnard.c index 17ecdb679e10..e217b95b4f2f 100644 --- a/board/bluewater/gurnard/gurnard.c +++ b/board/bluewater/gurnard/gurnard.c @@ -19,6 +19,7 @@ #ifndef CONFIG_DM_ETH #include <netdev.h> #endif +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/mach-types.h> diff --git a/board/bluewater/snapper9260/snapper9260.c b/board/bluewater/snapper9260/snapper9260.c index 58fab15c1126..df53a651c395 100644 --- a/board/bluewater/snapper9260/snapper9260.c +++ b/board/bluewater/snapper9260/snapper9260.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/mach-types.h> diff --git a/board/bosch/guardian/board.c b/board/bosch/guardian/board.c index 1d8fa781545d..113838f8b723 100644 --- a/board/bosch/guardian/board.c +++ b/board/bosch/guardian/board.c @@ -19,6 +19,7 @@ #include <led.h> #include <miiphy.h> #include <panel.h> +#include <asm/global_data.h> #include <power/tps65217.h> #include <power/tps65910.h> #include <spl.h> diff --git a/board/bosch/shc/board.c b/board/bosch/shc/board.c index b8f1b56502e6..bfce291691a0 100644 --- a/board/bosch/shc/board.c +++ b/board/bosch/shc/board.c @@ -29,6 +29,7 @@ #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 5b2d675a557e..84e14d1124fc 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -9,6 +9,7 @@ #include <env.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/broadcom/bcm23550_w1d/bcm23550_w1d.c b/board/broadcom/bcm23550_w1d/bcm23550_w1d.c index a1e3b25c2e00..90685c072a3b 100644 --- a/board/broadcom/bcm23550_w1d/bcm23550_w1d.c +++ b/board/broadcom/bcm23550_w1d/bcm23550_w1d.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include <env.h> diff --git a/board/broadcom/bcm28155_ap/bcm28155_ap.c b/board/broadcom/bcm28155_ap/bcm28155_ap.c index 79ce54993dd0..43726f79bde3 100644 --- a/board/broadcom/bcm28155_ap/bcm28155_ap.c +++ b/board/broadcom/bcm28155_ap/bcm28155_ap.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include <env.h> diff --git a/board/broadcom/bcm_ep/board.c b/board/broadcom/bcm_ep/board.c index ad9af92b5591..6064eb43db11 100644 --- a/board/broadcom/bcm_ep/board.c +++ b/board/broadcom/bcm_ep/board.c @@ -8,6 +8,7 @@ #include <init.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <config.h> #include <netdev.h> diff --git a/board/broadcom/bcmns2/northstar2.c b/board/broadcom/bcmns2/northstar2.c index 91f489aad3f2..494e457ff65b 100644 --- a/board/broadcom/bcmns2/northstar2.c +++ b/board/broadcom/bcmns2/northstar2.c @@ -6,6 +6,7 @@ #include <cpu_func.h> #include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/armv8/mmu.h>
diff --git a/board/broadcom/bcmns3/ns3.c b/board/broadcom/bcmns3/ns3.c index 10ae344a06df..9d2df92fa1d7 100644 --- a/board/broadcom/bcmns3/ns3.c +++ b/board/broadcom/bcmns3/ns3.c @@ -8,6 +8,7 @@ #include <fdt_support.h> #include <asm/io.h> #include <asm/gic-v3.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/armv8/mmu.h> #include <asm/arch-bcmns3/bl33_info.h> diff --git a/board/broadcom/bcmstb/bcmstb.c b/board/broadcom/bcmstb/bcmstb.c index add4285db31d..f6bdf1f5f400 100644 --- a/board/broadcom/bcmstb/bcmstb.c +++ b/board/broadcom/bcmstb/bcmstb.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <linux/types.h> #include <common.h> #include <env.h> diff --git a/board/bticino/mamoj/mamoj.c b/board/bticino/mamoj/mamoj.c index b7d37b700447..c9da42b43bf5 100644 --- a/board/bticino/mamoj/mamoj.c +++ b/board/bticino/mamoj/mamoj.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h>
diff --git a/board/bticino/mamoj/spl.c b/board/bticino/mamoj/spl.c index a9bb2a55e5de..883b7f4133b9 100644 --- a/board/bticino/mamoj/spl.c +++ b/board/bticino/mamoj/spl.c @@ -9,6 +9,7 @@ #include <init.h> #include <serial.h> #include <spl.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/io.h> diff --git a/board/buffalo/lsxl/lsxl.c b/board/buffalo/lsxl/lsxl.c index 64daa456b3c7..34be601fdde6 100644 --- a/board/buffalo/lsxl/lsxl.c +++ b/board/buffalo/lsxl/lsxl.c @@ -24,6 +24,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/mpp.h> #include <asm/arch/gpio.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include "lsxl.h" diff --git a/board/calao/usb_a9263/usb_a9263.c b/board/calao/usb_a9263/usb_a9263.c index 1fcaff604558..c0a5c518ca8b 100644 --- a/board/calao/usb_a9263/usb_a9263.c +++ b/board/calao/usb_a9263/usb_a9263.c @@ -15,6 +15,7 @@ #include <asm/arch/clk.h> #include <asm/arch/gpio.h> #include <asm-generic/gpio.h> +#include <asm/global_data.h> #include <asm/io.h> #include <net.h> #include <netdev.h> diff --git a/board/cavium/thunderx/thunderx.c b/board/cavium/thunderx/thunderx.c index fd234728980f..b09f72cad5c3 100644 --- a/board/cavium/thunderx/thunderx.c +++ b/board/cavium/thunderx/thunderx.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <errno.h> #include <net.h> +#include <asm/global_data.h> #include <linux/compiler.h>
#include <cavium/atf.h> diff --git a/board/ccv/xpress/xpress.c b/board/ccv/xpress/xpress.c index 27beaeb101af..9f5e78ce6804 100644 --- a/board/ccv/xpress/xpress.c +++ b/board/ccv/xpress/xpress.c @@ -12,6 +12,7 @@ #include <asm/arch/mx6ul_pins.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/cirrus/edb93xx/edb93xx.c b/board/cirrus/edb93xx/edb93xx.c index cbed98b0e368..7a7f62fe88e4 100644 --- a/board/cirrus/edb93xx/edb93xx.c +++ b/board/cirrus/edb93xx/edb93xx.c @@ -21,6 +21,7 @@ #include <net.h> #include <netdev.h> #include <status_led.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-types.h> #include <asm/arch/ep93xx.h> diff --git a/board/cloudengines/pogo_e02/pogo_e02.c b/board/cloudengines/pogo_e02/pogo_e02.c index 8df039168c99..039fd6e3dd67 100644 --- a/board/cloudengines/pogo_e02/pogo_e02.c +++ b/board/cloudengines/pogo_e02/pogo_e02.c @@ -17,6 +17,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> +#include <asm/global_data.h> #include "pogo_e02.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/cobra5272/cobra5272.c b/board/cobra5272/cobra5272.c index a79884cb506f..3e2418866c73 100644 --- a/board/cobra5272/cobra5272.c +++ b/board/cobra5272/cobra5272.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/compulab/cl-som-imx7/cl-som-imx7.c b/board/compulab/cl-som-imx7/cl-som-imx7.c index 1eef1d550761..454c93a572f8 100644 --- a/board/compulab/cl-som-imx7/cl-som-imx7.c +++ b/board/compulab/cl-som-imx7/cl-som-imx7.c @@ -15,6 +15,7 @@ #include <phy.h> #include <netdev.h> #include <fsl_esdhc_imx.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <power/pmic.h> #include <power/pfuze3000_pmic.h> diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index 7520e96e078e..f29b08247ecc 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c @@ -27,6 +27,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/iomux.h> #include <asm/arch/mxc_hdmi.h> +#include <asm/global_data.h> #include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/sata.h> #include <asm/mach-imx/video.h> diff --git a/board/compulab/cm_t335/cm_t335.c b/board/compulab/cm_t335/cm_t335.c index a9ba2b7e0023..1d4a3aceef54 100644 --- a/board/compulab/cm_t335/cm_t335.c +++ b/board/compulab/cm_t335/cm_t335.c @@ -14,6 +14,7 @@ #include <net.h> #include <status_led.h> #include <cpsw.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/arch/sys_proto.h> diff --git a/board/compulab/cm_t43/cm_t43.c b/board/compulab/cm_t43/cm_t43.c index 4b097c8f8f7c..efdade155b57 100644 --- a/board/compulab/cm_t43/cm_t43.c +++ b/board/compulab/cm_t43/cm_t43.c @@ -8,6 +8,7 @@ #include <miiphy.h> #include <cpsw.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/sys_proto.h> #include <asm/emif.h> diff --git a/board/congatec/cgtqmx6eval/cgtqmx6eval.c b/board/congatec/cgtqmx6eval/cgtqmx6eval.c index 9316b2c37720..6ae4a1af8921 100644 --- a/board/congatec/cgtqmx6eval/cgtqmx6eval.c +++ b/board/congatec/cgtqmx6eval/cgtqmx6eval.c @@ -9,6 +9,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/coreboot/coreboot/coreboot.c b/board/coreboot/coreboot/coreboot.c index 55aeced54220..9aafb8920cd3 100644 --- a/board/coreboot/coreboot/coreboot.c +++ b/board/coreboot/coreboot/coreboot.c @@ -5,6 +5,7 @@
#include <common.h> #include <asm/arch/sysinfo.h> +#include <asm/global_data.h> #include <init.h> #include <smbios.h>
diff --git a/board/corscience/tricorder/tricorder.c b/board/corscience/tricorder/tricorder.c index 41675677de2a..3f4a40fd6593 100644 --- a/board/corscience/tricorder/tricorder.c +++ b/board/corscience/tricorder/tricorder.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <twl4030.h> #include <status_led.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/mmc_host_def.h> diff --git a/board/cortina/presidio-asic/presidio.c b/board/cortina/presidio-asic/presidio.c index 3c132f127179..5c7352226373 100644 --- a/board/cortina/presidio-asic/presidio.c +++ b/board/cortina/presidio-asic/presidio.c @@ -8,6 +8,7 @@ #include <malloc.h> #include <errno.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <linux/compiler.h> diff --git a/board/creative/xfi3/xfi3.c b/board/creative/xfi3/xfi3.c index b5f0d3130745..2aa2435e49c2 100644 --- a/board/creative/xfi3/xfi3.c +++ b/board/creative/xfi3/xfi3.c @@ -13,6 +13,7 @@ #include <errno.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/iomux-mx23.h> diff --git a/board/cssi/MCR3000/MCR3000.c b/board/cssi/MCR3000/MCR3000.c index 55e955c36bbf..c20e87149493 100644 --- a/board/cssi/MCR3000/MCR3000.c +++ b/board/cssi/MCR3000/MCR3000.c @@ -14,6 +14,7 @@ #include <mpc8xx.h> #include <fdt_support.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/uclass.h> #include <wdt.h> diff --git a/board/d-link/dns325/dns325.c b/board/d-link/dns325/dns325.c index 0ae2e7d88c10..055783f63ada 100644 --- a/board/d-link/dns325/dns325.c +++ b/board/d-link/dns325/dns325.c @@ -19,6 +19,7 @@ #include <asm/arch/soc.h> #include <asm/arch/mpp.h> #include <asm/arch/gpio.h> +#include <asm/global_data.h> #include "dns325.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index 683e8b452ada..383a86173849 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -17,6 +17,7 @@ #include <spi.h> #include <spi_flash.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/ti-common/davinci_nand.h> #include <asm/arch/emac_defs.h> #include <asm/arch/pinmux_defs.h> diff --git a/board/davinci/da8xxevm/omapl138_lcdk.c b/board/davinci/da8xxevm/omapl138_lcdk.c index a08858550d49..d5f43bf52044 100644 --- a/board/davinci/da8xxevm/omapl138_lcdk.c +++ b/board/davinci/da8xxevm/omapl138_lcdk.c @@ -14,6 +14,7 @@ #include <init.h> #include <net.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/ti-common/davinci_nand.h> #include <asm/io.h> #include <ns16550.h> diff --git a/board/dhelectronics/dh_imx6/dh_imx6.c b/board/dhelectronics/dh_imx6/dh_imx6.c index 9937d6b0106a..2969e90a707d 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6.c +++ b/board/dhelectronics/dh_imx6/dh_imx6.c @@ -11,6 +11,7 @@ #include <image.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <asm/arch/clock.h> #include <asm/arch/crm_regs.h> diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index 35669c252bf6..49b12c4c0420 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -9,6 +9,7 @@ #include <net.h> #include <asm/arch/stm32.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <bootm.h> diff --git a/board/ea/mx7ulp_com/mx7ulp_com.c b/board/ea/mx7ulp_com/mx7ulp_com.c index a9b8a3210828..5b2d444366c7 100644 --- a/board/ea/mx7ulp_com/mx7ulp_com.c +++ b/board/ea/mx7ulp_com/mx7ulp_com.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mx7ulp-pins.h> diff --git a/board/eets/pdu001/board.c b/board/eets/pdu001/board.c index a602b623adb0..f806d1e7672a 100644 --- a/board/eets/pdu001/board.c +++ b/board/eets/pdu001/board.c @@ -18,6 +18,7 @@ #include <i2c.h> #include <watchdog.h> #include <debug_uart.h> +#include <asm/global_data.h> #include <dm/ofnode.h> #include <power/pmic.h> #include <power/regulator.h> diff --git a/board/egnite/ethernut5/ethernut5.c b/board/egnite/ethernut5/ethernut5.c index 0674b3001096..559fdd2f646d 100644 --- a/board/egnite/ethernut5/ethernut5.c +++ b/board/egnite/ethernut5/ethernut5.c @@ -60,6 +60,7 @@ #include <i2c.h> #include <mmc.h> #include <atmel_mci.h> +#include <asm/global_data.h>
#include <asm/arch/at91sam9260.h> #include <asm/arch/at91sam9260_matrix.h> diff --git a/board/el/el6x/el6x.c b/board/el/el6x/el6x.c index bdc0558eda21..ddac58f73d28 100644 --- a/board/el/el6x/el6x.c +++ b/board/el/el6x/el6x.c @@ -13,6 +13,7 @@ #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> #include <env.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/elgin/elgin_rv1108/elgin_rv1108.c b/board/elgin/elgin_rv1108/elgin_rv1108.c index 245e5abcaebd..eb7a322d847d 100644 --- a/board/elgin/elgin_rv1108/elgin_rv1108.c +++ b/board/elgin/elgin_rv1108/elgin_rv1108.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/grf_rv1108.h> diff --git a/board/embest/mx6boards/mx6boards.c b/board/embest/mx6boards/mx6boards.c index 752242bd54c4..65b3942e3991 100644 --- a/board/embest/mx6boards/mx6boards.c +++ b/board/embest/mx6boards/mx6boards.c @@ -20,6 +20,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/emulation/common/qemu_capsule.c b/board/emulation/common/qemu_capsule.c index f1d403501a94..5cb461d52bce 100644 --- a/board/emulation/common/qemu_capsule.c +++ b/board/emulation/common/qemu_capsule.c @@ -8,6 +8,7 @@ #include <efi_loader.h> #include <env.h> #include <fdtdec.h> +#include <asm/global_data.h>
diff --git a/board/engicam/common/board.c b/board/engicam/common/board.c index 5a2003d50988..df9149e0d6d8 100644 --- a/board/engicam/common/board.c +++ b/board/engicam/common/board.c @@ -16,6 +16,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> #include <watchdog.h> +#include <asm/global_data.h>
#include "board.h"
diff --git a/board/esd/meesc/meesc.c b/board/esd/meesc/meesc.c index deed3a9b84ec..eaa525eb0049 100644 --- a/board/esd/meesc/meesc.c +++ b/board/esd/meesc/meesc.c @@ -15,6 +15,7 @@ #include <net.h> #include <serial.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/mach-types.h> diff --git a/board/esd/vme8349/vme8349.c b/board/esd/vme8349/vme8349.c index 8d3d26e3c703..d388fc6d4901 100644 --- a/board/esd/vme8349/vme8349.c +++ b/board/esd/vme8349/vme8349.c @@ -17,6 +17,7 @@ #include <ioports.h> #include <mpc83xx.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mpc8349_pci.h> #if defined(CONFIG_OF_LIBFDT) #include <linux/libfdt.h> diff --git a/board/firefly/firefly-rk3288/firefly-rk3288.c b/board/firefly/firefly-rk3288/firefly-rk3288.c index bd8a32cf7b39..41c49e5daa72 100644 --- a/board/firefly/firefly-rk3288/firefly-rk3288.c +++ b/board/firefly/firefly-rk3288/firefly-rk3288.c @@ -7,6 +7,7 @@ #include <hang.h> #include <led.h> #include <log.h> +#include <asm/global_data.h>
#ifdef CONFIG_SPL_BUILD DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/common/arm_sleep.c b/board/freescale/common/arm_sleep.c index bb1ef9979279..733940860f55 100644 --- a/board/freescale/common/arm_sleep.c +++ b/board/freescale/common/arm_sleep.c @@ -5,6 +5,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #ifndef CONFIG_ARMV7_NONSEC #error " Deep sleep needs non-secure mode support. " diff --git a/board/freescale/common/emc2305.c b/board/freescale/common/emc2305.c index 050b679f3c57..12ad4b3e08a2 100644 --- a/board/freescale/common/emc2305.c +++ b/board/freescale/common/emc2305.c @@ -7,6 +7,7 @@ #include <common.h> #include <command.h> #include <i2c.h> +#include <asm/global_data.h> #include <asm/io.h>
#include "emc2305.h" diff --git a/board/freescale/common/mpc85xx_sleep.c b/board/freescale/common/mpc85xx_sleep.c index 6f6f4d40fcb8..d2bb173c1833 100644 --- a/board/freescale/common/mpc85xx_sleep.c +++ b/board/freescale/common/mpc85xx_sleep.c @@ -5,6 +5,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/immap_85xx.h> #include "sleep.h" #ifdef CONFIG_U_QE diff --git a/board/freescale/corenet_ds/corenet_ds.c b/board/freescale/corenet_ds/corenet_ds.c index 15d11ed81abf..3a83e65f2fe5 100644 --- a/board/freescale/corenet_ds/corenet_ds.c +++ b/board/freescale/corenet_ds/corenet_ds.c @@ -10,6 +10,7 @@ #include <image.h> #include <init.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/corenet_ds/ddr.c b/board/freescale/corenet_ds/ddr.c index 19f6e8700d5f..2c440673e7c3 100644 --- a/board/freescale/corenet_ds/ddr.c +++ b/board/freescale/corenet_ds/ddr.c @@ -9,6 +9,7 @@ #include <init.h> #include <log.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/imx8mm_evk/imx8mm_evk.c b/board/freescale/imx8mm_evk/imx8mm_evk.c index 6af71006966c..ab55135a9720 100644 --- a/board/freescale/imx8mm_evk/imx8mm_evk.c +++ b/board/freescale/imx8mm_evk/imx8mm_evk.c @@ -8,6 +8,7 @@ #include <init.h> #include <miiphy.h> #include <netdev.h> +#include <asm/global_data.h>
#include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/imx8mm_evk/spl.c b/board/freescale/imx8mm_evk/spl.c index 19c8a5aa2354..64bc60651d3e 100644 --- a/board/freescale/imx8mm_evk/spl.c +++ b/board/freescale/imx8mm_evk/spl.c @@ -11,6 +11,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/arch/clock.h> diff --git a/board/freescale/imx8mn_evk/imx8mn_evk.c b/board/freescale/imx8mn_evk/imx8mn_evk.c index e5ca54f9ae75..9a0a0488bf4f 100644 --- a/board/freescale/imx8mn_evk/imx8mn_evk.c +++ b/board/freescale/imx8mn_evk/imx8mn_evk.c @@ -6,6 +6,7 @@ #include <common.h> #include <env.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/board/freescale/imx8mn_evk/spl.c b/board/freescale/imx8mn_evk/spl.c index dd38c1015cf4..6d5c7a5b4676 100644 --- a/board/freescale/imx8mn_evk/spl.c +++ b/board/freescale/imx8mn_evk/spl.c @@ -12,6 +12,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/arch/clock.h> diff --git a/board/freescale/imx8mp_evk/imx8mp_evk.c b/board/freescale/imx8mp_evk/imx8mp_evk.c index 330b47fa5f92..89cc17cbeac5 100644 --- a/board/freescale/imx8mp_evk/imx8mp_evk.c +++ b/board/freescale/imx8mp_evk/imx8mp_evk.c @@ -10,6 +10,7 @@ #include <miiphy.h> #include <netdev.h> #include <linux/delay.h> +#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <asm-generic/gpio.h> #include <asm/arch/imx8mp_pins.h> diff --git a/board/freescale/imx8mp_evk/spl.c b/board/freescale/imx8mp_evk/spl.c index 3214718e62b2..ebfd94dc1fa0 100644 --- a/board/freescale/imx8mp_evk/spl.c +++ b/board/freescale/imx8mp_evk/spl.c @@ -12,6 +12,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <asm/io.h> diff --git a/board/freescale/imx8mq_evk/imx8mq_evk.c b/board/freescale/imx8mq_evk/imx8mq_evk.c index 1ad670b8ccf0..93da67d77983 100644 --- a/board/freescale/imx8mq_evk/imx8mq_evk.c +++ b/board/freescale/imx8mq_evk/imx8mq_evk.c @@ -8,6 +8,7 @@ #include <init.h> #include <malloc.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/freescale/imx8mq_evk/spl.c b/board/freescale/imx8mq_evk/spl.c index 42183ed5aa0a..82753585f2f0 100644 --- a/board/freescale/imx8mq_evk/spl.c +++ b/board/freescale/imx8mq_evk/spl.c @@ -10,6 +10,7 @@ #include <image.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <asm/io.h> diff --git a/board/freescale/imx8qm_mek/imx8qm_mek.c b/board/freescale/imx8qm_mek/imx8qm_mek.c index fba3baa1267e..c6772206244c 100644 --- a/board/freescale/imx8qm_mek/imx8qm_mek.c +++ b/board/freescale/imx8qm_mek/imx8qm_mek.c @@ -8,6 +8,7 @@ #include <env.h> #include <errno.h> #include <init.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <asm/io.h> diff --git a/board/freescale/imx8qm_mek/spl.c b/board/freescale/imx8qm_mek/spl.c index 9dee12a2c6a2..944ba745c09f 100644 --- a/board/freescale/imx8qm_mek/spl.c +++ b/board/freescale/imx8qm_mek/spl.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <dm/device.h> #include <dm/uclass-internal.h> diff --git a/board/freescale/imx8qxp_mek/imx8qxp_mek.c b/board/freescale/imx8qxp_mek/imx8qxp_mek.c index da55933e21b2..7179823a2235 100644 --- a/board/freescale/imx8qxp_mek/imx8qxp_mek.c +++ b/board/freescale/imx8qxp_mek/imx8qxp_mek.c @@ -8,6 +8,7 @@ #include <env.h> #include <errno.h> #include <init.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <fsl_esdhc_imx.h> diff --git a/board/freescale/imx8qxp_mek/spl.c b/board/freescale/imx8qxp_mek/spl.c index 881d297cf17f..ae6b64ff6ea1 100644 --- a/board/freescale/imx8qxp_mek/spl.c +++ b/board/freescale/imx8qxp_mek/spl.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <dm/device.h> #include <dm/uclass-internal.h> diff --git a/board/freescale/imxrt1020-evk/imxrt1020-evk.c b/board/freescale/imxrt1020-evk/imxrt1020-evk.c index 0cef6071feba..35241acd224c 100644 --- a/board/freescale/imxrt1020-evk/imxrt1020-evk.c +++ b/board/freescale/imxrt1020-evk/imxrt1020-evk.c @@ -10,6 +10,7 @@ #include <log.h> #include <ram.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv7m.h>
diff --git a/board/freescale/imxrt1050-evk/imxrt1050-evk.c b/board/freescale/imxrt1050-evk/imxrt1050-evk.c index edc7fb176bbc..b8d852f097b0 100644 --- a/board/freescale/imxrt1050-evk/imxrt1050-evk.c +++ b/board/freescale/imxrt1050-evk/imxrt1050-evk.c @@ -10,6 +10,7 @@ #include <log.h> #include <ram.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv7m.h>
diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrdm/ls1012afrdm.c index 4770eadabd79..2cd651b943fb 100644 --- a/board/freescale/ls1012afrdm/ls1012afrdm.c +++ b/board/freescale/ls1012afrdm/ls1012afrdm.c @@ -8,6 +8,7 @@ #include <i2c.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1012aqds/ls1012aqds.c b/board/freescale/ls1012aqds/ls1012aqds.c index 7bea45c8ae53..b77808ea57b7 100644 --- a/board/freescale/ls1012aqds/ls1012aqds.c +++ b/board/freescale/ls1012aqds/ls1012aqds.c @@ -8,6 +8,7 @@ #include <fdt_support.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index 30b43ea135ad..ed6dc9ff712f 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1021aiot/dcu.c b/board/freescale/ls1021aiot/dcu.c index 77732a6ab158..e4fbcbcaad35 100644 --- a/board/freescale/ls1021aiot/dcu.c +++ b/board/freescale/ls1021aiot/dcu.c @@ -7,6 +7,7 @@
#include <common.h> #include <fsl_dcu_fb.h> +#include <asm/global_data.h> #include "div64.h" #include "../common/dcu_sii9022a.h"
diff --git a/board/freescale/ls1021aiot/ls1021aiot.c b/board/freescale/ls1021aiot/ls1021aiot.c index 2e5cc5906665..bfe613760427 100644 --- a/board/freescale/ls1021aiot/ls1021aiot.c +++ b/board/freescale/ls1021aiot/ls1021aiot.c @@ -12,6 +12,7 @@ #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch/ls102xa_stream_id.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/arch/ls102xa_devdis.h> diff --git a/board/freescale/ls1021aqds/dcu.c b/board/freescale/ls1021aqds/dcu.c index b648a7872bcc..f66961ca5907 100644 --- a/board/freescale/ls1021aqds/dcu.c +++ b/board/freescale/ls1021aqds/dcu.c @@ -6,6 +6,7 @@ * FSL DCU Framebuffer driver */
+#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <fsl_dcu_fb.h> diff --git a/board/freescale/ls1021aqds/ddr.c b/board/freescale/ls1021aqds/ddr.c index f84bce95a845..66fe1519cc6d 100644 --- a/board/freescale/ls1021aqds/ddr.c +++ b/board/freescale/ls1021aqds/ddr.c @@ -8,6 +8,7 @@ #include <fsl_ddr_dimm_params.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <linux/delay.h> diff --git a/board/freescale/ls1021atsn/ls1021atsn.c b/board/freescale/ls1021atsn/ls1021atsn.c index 878306b2d0fc..c1acd3040c42 100644 --- a/board/freescale/ls1021atsn/ls1021atsn.c +++ b/board/freescale/ls1021atsn/ls1021atsn.c @@ -11,6 +11,7 @@ #include <asm/arch/immap_ls102xa.h> #include <asm/arch/ls102xa_soc.h> #include <asm/arch/fsl_serdes.h> +#include <asm/global_data.h> #include <linux/delay.h> #include "../common/sleep.h" #include <fsl_validate.h> diff --git a/board/freescale/ls1021atwr/dcu.c b/board/freescale/ls1021atwr/dcu.c index bdf7f7645c2f..7bf283e3d66c 100644 --- a/board/freescale/ls1021atwr/dcu.c +++ b/board/freescale/ls1021atwr/dcu.c @@ -7,6 +7,7 @@
diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 2889bd8deddb..0cd38a14b830 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> #include <asm/arch/clock.h> diff --git a/board/freescale/ls1028a/ddr.c b/board/freescale/ls1028a/ddr.c index 74d3af5c359d..3e976da6b305 100644 --- a/board/freescale/ls1028a/ddr.c +++ b/board/freescale/ls1028a/ddr.c @@ -6,6 +6,7 @@ #include <common.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> +#include <asm/global_data.h>
diff --git a/board/freescale/ls1028a/ls1028a.c b/board/freescale/ls1028a/ls1028a.c index e37e3a3c16d4..f3c1d958b72a 100644 --- a/board/freescale/ls1028a/ls1028a.c +++ b/board/freescale/ls1028a/ls1028a.c @@ -9,6 +9,7 @@ #include <errno.h> #include <fsl_ddr.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <hwconfig.h> #include <fdt_support.h> diff --git a/board/freescale/ls1043aqds/ddr.c b/board/freescale/ls1043aqds/ddr.c index c0fc9aadf041..23947bdb84c9 100644 --- a/board/freescale/ls1043aqds/ddr.c +++ b/board/freescale/ls1043aqds/ddr.c @@ -11,6 +11,7 @@ #endif #include <log.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls1043aqds/ls1043aqds.c b/board/freescale/ls1043aqds/ls1043aqds.c index ef0f2e612242..44e4c61eab27 100644 --- a/board/freescale/ls1043aqds/ls1043aqds.c +++ b/board/freescale/ls1043aqds/ls1043aqds.c @@ -10,6 +10,7 @@ #include <fsl_ddr_sdram.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1043ardb/ddr.c b/board/freescale/ls1043ardb/ddr.c index f16e036d0e8c..08b43ff5e4c5 100644 --- a/board/freescale/ls1043ardb/ddr.c +++ b/board/freescale/ls1043ardb/ddr.c @@ -6,6 +6,7 @@ #include <common.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> +#include <asm/global_data.h> #include "ddr.h" #include <log.h> #include <vsprintf.h> diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index dc32c030ecac..beef26b084bf 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -6,6 +6,7 @@ #include <common.h> #include <i2c.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1046afrwy/ddr.c b/board/freescale/ls1046afrwy/ddr.c index daf17e016934..256397b52b65 100644 --- a/board/freescale/ls1046afrwy/ddr.c +++ b/board/freescale/ls1046afrwy/ddr.c @@ -5,6 +5,7 @@
#include <common.h> #include <fsl_ddr_sdram.h> +#include <asm/global_data.h>
diff --git a/board/freescale/ls1046afrwy/ls1046afrwy.c b/board/freescale/ls1046afrwy/ls1046afrwy.c index 4ebf77b1ad1f..9813a36ca07e 100644 --- a/board/freescale/ls1046afrwy/ls1046afrwy.c +++ b/board/freescale/ls1046afrwy/ls1046afrwy.c @@ -7,6 +7,7 @@ #include <i2c.h> #include <fdt_support.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1046aqds/ddr.c b/board/freescale/ls1046aqds/ddr.c index f3cfbc4c39be..9a96de271786 100644 --- a/board/freescale/ls1046aqds/ddr.c +++ b/board/freescale/ls1046aqds/ddr.c @@ -11,6 +11,7 @@ #endif #include <log.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls1046aqds/ls1046aqds.c b/board/freescale/ls1046aqds/ls1046aqds.c index 33b10277af7c..3c96c900c320 100644 --- a/board/freescale/ls1046aqds/ls1046aqds.c +++ b/board/freescale/ls1046aqds/ls1046aqds.c @@ -9,6 +9,7 @@ #include <fdt_support.h> #include <fsl_ddr_sdram.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1046ardb/ddr.c b/board/freescale/ls1046ardb/ddr.c index 0e07df521190..befb556bd30b 100644 --- a/board/freescale/ls1046ardb/ddr.c +++ b/board/freescale/ls1046ardb/ddr.c @@ -6,6 +6,7 @@ #include <common.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> +#include <asm/global_data.h> #include "ddr.h" #ifdef CONFIG_FSL_DEEP_SLEEP #include <fsl_sleep.h> diff --git a/board/freescale/ls1046ardb/ls1046ardb.c b/board/freescale/ls1046ardb/ls1046ardb.c index e107c8471b30..93ef903f2998 100644 --- a/board/freescale/ls1046ardb/ls1046ardb.c +++ b/board/freescale/ls1046ardb/ls1046ardb.c @@ -7,6 +7,7 @@ #include <i2c.h> #include <fdt_support.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c index fd9549bfbc8c..995c42960178 100644 --- a/board/freescale/ls1088a/ddr.c +++ b/board/freescale/ls1088a/ddr.c @@ -9,6 +9,7 @@ #include <log.h> #include <asm/arch/soc.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 5d19702a05cf..2ba6a3990d90 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -13,6 +13,7 @@ #include <fsl_ifc.h> #include <fsl_ddr.h> #include <fsl_sec.h> +#include <asm/global_data.h> #include <asm/io.h> #include <fdt_support.h> #include <linux/delay.h> diff --git a/board/freescale/ls2080a/ddr.c b/board/freescale/ls2080a/ddr.c index 229fc9cc30ea..29d7bd1c5ee6 100644 --- a/board/freescale/ls2080a/ddr.c +++ b/board/freescale/ls2080a/ddr.c @@ -9,6 +9,7 @@ #include <log.h> #include <asm/arch/soc.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index 62da2a7af11a..48437a52e401 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -10,6 +10,7 @@ #include <netdev.h> #include <fsl_ifc.h> #include <fsl_ddr.h> +#include <asm/global_data.h> #include <asm/io.h> #include <fdt_support.h> #include <linux/libfdt.h> diff --git a/board/freescale/ls2080aqds/ddr.c b/board/freescale/ls2080aqds/ddr.c index 3fb2c4448c24..2767d058cc96 100644 --- a/board/freescale/ls2080aqds/ddr.c +++ b/board/freescale/ls2080aqds/ddr.c @@ -9,6 +9,7 @@ #include <log.h> #include <asm/arch/soc.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 3eb40f5e2a21..a6f6897eb09d 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -10,6 +10,7 @@ #include <netdev.h> #include <fsl_ifc.h> #include <fsl_ddr.h> +#include <asm/global_data.h> #include <asm/io.h> #include <fdt_support.h> #include <linux/libfdt.h> diff --git a/board/freescale/ls2080ardb/ddr.c b/board/freescale/ls2080ardb/ddr.c index 4571a228c59e..07fa84733324 100644 --- a/board/freescale/ls2080ardb/ddr.c +++ b/board/freescale/ls2080ardb/ddr.c @@ -9,6 +9,7 @@ #include <log.h> #include <asm/arch/soc.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls2080ardb/eth_ls2080rdb.c b/board/freescale/ls2080ardb/eth_ls2080rdb.c index 018d1dc6720c..21b4c16ff27c 100644 --- a/board/freescale/ls2080ardb/eth_ls2080rdb.c +++ b/board/freescale/ls2080ardb/eth_ls2080rdb.c @@ -13,6 +13,7 @@ #include <miiphy.h> #include <phy.h> #include <fm_eth.h> +#include <asm/global_data.h> #include <asm/io.h> #include <exports.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index c7e9c1dacf43..26ce5a80edf7 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -11,6 +11,7 @@ #include <netdev.h> #include <fsl_ifc.h> #include <fsl_ddr.h> +#include <asm/global_data.h> #include <asm/io.h> #include <hwconfig.h> #include <fdt_support.h> diff --git a/board/freescale/lx2160a/ddr.c b/board/freescale/lx2160a/ddr.c index cd422bf2bc5c..7ab7a9e6ca83 100644 --- a/board/freescale/lx2160a/ddr.c +++ b/board/freescale/lx2160a/ddr.c @@ -6,6 +6,7 @@ #include <common.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> +#include <asm/global_data.h>
diff --git a/board/freescale/lx2160a/eth_lx2160aqds.c b/board/freescale/lx2160a/eth_lx2160aqds.c index fcace0293605..437f0bc4cf68 100644 --- a/board/freescale/lx2160a/eth_lx2160aqds.c +++ b/board/freescale/lx2160a/eth_lx2160aqds.c @@ -17,6 +17,7 @@ #include <miiphy.h> #include <phy.h> #include <fm_eth.h> +#include <asm/global_data.h> #include <asm/io.h> #include <exports.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/lx2160a/eth_lx2160ardb.c b/board/freescale/lx2160a/eth_lx2160ardb.c index b3125b7748d5..15cbc58d59a7 100644 --- a/board/freescale/lx2160a/eth_lx2160ardb.c +++ b/board/freescale/lx2160a/eth_lx2160ardb.c @@ -14,6 +14,7 @@ #include <miiphy.h> #include <phy.h> #include <fm_eth.h> +#include <asm/global_data.h> #include <asm/io.h> #include <exports.h> #include <asm/arch/fsl_serdes.h> diff --git a/board/freescale/lx2160a/eth_lx2162aqds.c b/board/freescale/lx2160a/eth_lx2162aqds.c index 4683f674f0e1..b742c1ff5288 100644 --- a/board/freescale/lx2160a/eth_lx2162aqds.c +++ b/board/freescale/lx2160a/eth_lx2162aqds.c @@ -19,6 +19,7 @@ #include <fm_eth.h> #include <asm/io.h> #include <exports.h> +#include <asm/global_data.h> #include <asm/arch/fsl_serdes.h> #include <fsl-mc/fsl_mc.h> #include <fsl-mc/ldpaa_wriop.h> diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index ea027bec5676..1d203ec6da0f 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -7,6 +7,7 @@ #include <clock_legacy.h> #include <dm.h> #include <init.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_pl01x.h> #include <i2c.h> #include <malloc.h> diff --git a/board/freescale/m5208evbe/m5208evbe.c b/board/freescale/m5208evbe/m5208evbe.c index a950030eb397..7bfb4557dd5b 100644 --- a/board/freescale/m5208evbe/m5208evbe.c +++ b/board/freescale/m5208evbe/m5208evbe.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m52277evb/m52277evb.c b/board/freescale/m52277evb/m52277evb.c index 144e490479ed..510af33e4c3c 100644 --- a/board/freescale/m52277evb/m52277evb.c +++ b/board/freescale/m52277evb/m52277evb.c @@ -9,6 +9,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m5235evb/m5235evb.c b/board/freescale/m5235evb/m5235evb.c index 5d4039375530..e7c7a94036b5 100644 --- a/board/freescale/m5235evb/m5235evb.c +++ b/board/freescale/m5235evb/m5235evb.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h>
diff --git a/board/freescale/m5249evb/m5249evb.c b/board/freescale/m5249evb/m5249evb.c index a89d5100586f..48c00791114d 100644 --- a/board/freescale/m5249evb/m5249evb.c +++ b/board/freescale/m5249evb/m5249evb.c @@ -8,6 +8,7 @@ #include <command.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <linux/delay.h>
diff --git a/board/freescale/m5253demo/m5253demo.c b/board/freescale/m5253demo/m5253demo.c index 9a157db60142..2a4703579dab 100644 --- a/board/freescale/m5253demo/m5253demo.c +++ b/board/freescale/m5253demo/m5253demo.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <netdev.h> #include <asm/io.h> diff --git a/board/freescale/m5272c3/m5272c3.c b/board/freescale/m5272c3/m5272c3.c index 1017ef0c2a53..9580cf2a0390 100644 --- a/board/freescale/m5272c3/m5272c3.c +++ b/board/freescale/m5272c3/m5272c3.c @@ -8,6 +8,7 @@
diff --git a/board/freescale/m5275evb/m5275evb.c b/board/freescale/m5275evb/m5275evb.c index e65e6d0af585..1c4fb7232afb 100644 --- a/board/freescale/m5275evb/m5275evb.c +++ b/board/freescale/m5275evb/m5275evb.c @@ -10,6 +10,7 @@
diff --git a/board/freescale/m5282evb/m5282evb.c b/board/freescale/m5282evb/m5282evb.c index 251be667d46b..e1ea9b3a58f8 100644 --- a/board/freescale/m5282evb/m5282evb.c +++ b/board/freescale/m5282evb/m5282evb.c @@ -6,6 +6,7 @@
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/m53017evb/m53017evb.c b/board/freescale/m53017evb/m53017evb.c index f13b6931ea25..c9f89353ce4b 100644 --- a/board/freescale/m53017evb/m53017evb.c +++ b/board/freescale/m53017evb/m53017evb.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m5329evb/m5329evb.c b/board/freescale/m5329evb/m5329evb.c index 531894f65161..7a75b04dd0d2 100644 --- a/board/freescale/m5329evb/m5329evb.c +++ b/board/freescale/m5329evb/m5329evb.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m5373evb/m5373evb.c b/board/freescale/m5373evb/m5373evb.c index 29ff55f15966..cfa5ca4a477c 100644 --- a/board/freescale/m5373evb/m5373evb.c +++ b/board/freescale/m5373evb/m5373evb.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m54418twr/m54418twr.c b/board/freescale/m54418twr/m54418twr.c index a418fba1401b..ca8993197e3e 100644 --- a/board/freescale/m54418twr/m54418twr.c +++ b/board/freescale/m54418twr/m54418twr.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/immap.h> #include <mmc.h> diff --git a/board/freescale/m54451evb/m54451evb.c b/board/freescale/m54451evb/m54451evb.c index 1298bd324e9f..a4ddc69166b3 100644 --- a/board/freescale/m54451evb/m54451evb.c +++ b/board/freescale/m54451evb/m54451evb.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m54455evb/m54455evb.c b/board/freescale/m54455evb/m54455evb.c index 286300645b4a..c749ee407e77 100644 --- a/board/freescale/m54455evb/m54455evb.c +++ b/board/freescale/m54455evb/m54455evb.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m547xevb/m547xevb.c b/board/freescale/m547xevb/m547xevb.c index 908a500f4b9f..1568f455e927 100644 --- a/board/freescale/m547xevb/m547xevb.c +++ b/board/freescale/m547xevb/m547xevb.c @@ -11,6 +11,7 @@ #include <common.h> #include <init.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/m548xevb/m548xevb.c b/board/freescale/m548xevb/m548xevb.c index 796b808e6f90..b62355a7ae7b 100644 --- a/board/freescale/m548xevb/m548xevb.c +++ b/board/freescale/m548xevb/m548xevb.c @@ -11,6 +11,7 @@ #include <common.h> #include <init.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/board/freescale/mpc8308rdb/sdram.c b/board/freescale/mpc8308rdb/sdram.c index 6e0922cd53c9..6340fd16ea9b 100644 --- a/board/freescale/mpc8308rdb/sdram.c +++ b/board/freescale/mpc8308rdb/sdram.c @@ -14,6 +14,7 @@ #include <common.h> #include <init.h> #include <mpc83xx.h> +#include <asm/global_data.h>
#include <asm/bitops.h> #include <asm/io.h> diff --git a/board/freescale/mpc8313erdb/mpc8313erdb.c b/board/freescale/mpc8313erdb/mpc8313erdb.c index 7e1a31f2650d..3bf5cff1e100 100644 --- a/board/freescale/mpc8313erdb/mpc8313erdb.c +++ b/board/freescale/mpc8313erdb/mpc8313erdb.c @@ -20,6 +20,7 @@ #if defined(CONFIG_MPC83XX_GPIO) && !defined(CONFIG_SPL_BUILD) #include <asm/gpio.h> #endif +#include <asm/global_data.h>
diff --git a/board/freescale/mpc8313erdb/sdram.c b/board/freescale/mpc8313erdb/sdram.c index 99f6bcd5a933..f146ae5d43c4 100644 --- a/board/freescale/mpc8313erdb/sdram.c +++ b/board/freescale/mpc8313erdb/sdram.c @@ -11,6 +11,7 @@ #include <init.h> #include <mpc83xx.h> #include <spd_sdram.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/bitops.h> diff --git a/board/freescale/mpc8315erdb/mpc8315erdb.c b/board/freescale/mpc8315erdb/mpc8315erdb.c index 05b983a3f26f..e89d5d495595 100644 --- a/board/freescale/mpc8315erdb/mpc8315erdb.c +++ b/board/freescale/mpc8315erdb/mpc8315erdb.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <fdt_support.h> diff --git a/board/freescale/mpc8315erdb/sdram.c b/board/freescale/mpc8315erdb/sdram.c index 8a828207f935..ffbb79aaec14 100644 --- a/board/freescale/mpc8315erdb/sdram.c +++ b/board/freescale/mpc8315erdb/sdram.c @@ -11,6 +11,7 @@ #include <init.h> #include <mpc83xx.h> #include <spd_sdram.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/bitops.h> diff --git a/board/freescale/mpc8323erdb/mpc8323erdb.c b/board/freescale/mpc8323erdb/mpc8323erdb.c index 3cde715e96b7..cef3216a6fe5 100644 --- a/board/freescale/mpc8323erdb/mpc8323erdb.c +++ b/board/freescale/mpc8323erdb/mpc8323erdb.c @@ -19,6 +19,7 @@ #include <i2c.h> #include <miiphy.h> #include <command.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <u-boot/crc.h> diff --git a/board/freescale/mpc832xemds/mpc832xemds.c b/board/freescale/mpc832xemds/mpc832xemds.c index 6139cbd04091..f34758a9470a 100644 --- a/board/freescale/mpc832xemds/mpc832xemds.c +++ b/board/freescale/mpc832xemds/mpc832xemds.c @@ -16,6 +16,7 @@ #if defined(CONFIG_PCI) #include <pci.h> #endif +#include <asm/global_data.h> #include <asm/mmu.h> #if defined(CONFIG_OF_LIBFDT) #include <linux/libfdt.h> diff --git a/board/freescale/mpc8349emds/mpc8349emds.c b/board/freescale/mpc8349emds/mpc8349emds.c index 46be5ccd92cf..5f38639afd42 100644 --- a/board/freescale/mpc8349emds/mpc8349emds.c +++ b/board/freescale/mpc8349emds/mpc8349emds.c @@ -10,6 +10,7 @@ #include <ioports.h> #include <mpc83xx.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/mpc8349_pci.h> #include <i2c.h> #include <spi.h> diff --git a/board/freescale/mpc8349itx/mpc8349itx.c b/board/freescale/mpc8349itx/mpc8349itx.c index a265a8380fef..5b4c290df149 100644 --- a/board/freescale/mpc8349itx/mpc8349itx.c +++ b/board/freescale/mpc8349itx/mpc8349itx.c @@ -18,6 +18,7 @@ #endif #include <spd_sdram.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/mmu.h> #if defined(CONFIG_OF_LIBFDT) #include <linux/libfdt.h> diff --git a/board/freescale/mpc837xemds/mpc837xemds.c b/board/freescale/mpc837xemds/mpc837xemds.c index f515299bc9a8..71875cf8f8ec 100644 --- a/board/freescale/mpc837xemds/mpc837xemds.c +++ b/board/freescale/mpc837xemds/mpc837xemds.c @@ -10,6 +10,7 @@ #include <init.h> #include <net.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/fsl_mpc83xx_serdes.h> #include <spd_sdram.h> diff --git a/board/freescale/mpc837xerdb/mpc837xerdb.c b/board/freescale/mpc837xerdb/mpc837xerdb.c index 39673ad076a3..81d31f19c4c1 100644 --- a/board/freescale/mpc837xerdb/mpc837xerdb.c +++ b/board/freescale/mpc837xerdb/mpc837xerdb.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <init.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/fsl_mpc83xx_serdes.h> #include <fdt_support.h> diff --git a/board/freescale/mpc8610hpcd/mpc8610hpcd.c b/board/freescale/mpc8610hpcd/mpc8610hpcd.c index 52bf4da98eaa..74b0e45b4f82 100644 --- a/board/freescale/mpc8610hpcd/mpc8610hpcd.c +++ b/board/freescale/mpc8610hpcd/mpc8610hpcd.c @@ -9,6 +9,7 @@ #include <log.h> #include <net.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/immap_86xx.h> #include <asm/fsl_pci.h> diff --git a/board/freescale/mpc8641hpcn/mpc8641hpcn.c b/board/freescale/mpc8641hpcn/mpc8641hpcn.c index 0f9aea469b11..b30b86364d5d 100644 --- a/board/freescale/mpc8641hpcn/mpc8641hpcn.c +++ b/board/freescale/mpc8641hpcn/mpc8641hpcn.c @@ -8,6 +8,7 @@ #include <log.h> #include <net.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/immap_86xx.h> #include <asm/fsl_pci.h> diff --git a/board/freescale/mx23evk/mx23evk.c b/board/freescale/mx23evk/mx23evk.c index 3fbac6b5cc31..605cdec218a3 100644 --- a/board/freescale/mx23evk/mx23evk.c +++ b/board/freescale/mx23evk/mx23evk.c @@ -13,6 +13,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> diff --git a/board/freescale/mx25pdk/mx25pdk.c b/board/freescale/mx25pdk/mx25pdk.c index 1cffdd933172..3b445a46dd7b 100644 --- a/board/freescale/mx25pdk/mx25pdk.c +++ b/board/freescale/mx25pdk/mx25pdk.c @@ -7,6 +7,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/imx-regs.h> diff --git a/board/freescale/mx28evk/mx28evk.c b/board/freescale/mx28evk/mx28evk.c index a6b66d99ccb1..21c9cb112836 100644 --- a/board/freescale/mx28evk/mx28evk.c +++ b/board/freescale/mx28evk/mx28evk.c @@ -14,6 +14,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/freescale/mx35pdk/mx35pdk.c b/board/freescale/mx35pdk/mx35pdk.c index fc024c47dbdd..4039d9f049a6 100644 --- a/board/freescale/mx35pdk/mx35pdk.c +++ b/board/freescale/mx35pdk/mx35pdk.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h> #include <linux/errno.h> diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 4250efddde77..ac48e7668c0e 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/imx-regs.h> diff --git a/board/freescale/mx53ard/mx53ard.c b/board/freescale/mx53ard/mx53ard.c index d265d3adaa64..f9ec5ca6ef35 100644 --- a/board/freescale/mx53ard/mx53ard.c +++ b/board/freescale/mx53ard/mx53ard.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/mx53evk/mx53evk.c b/board/freescale/mx53evk/mx53evk.c index ef6c6ec1ed6e..b006638e2c12 100644 --- a/board/freescale/mx53evk/mx53evk.c +++ b/board/freescale/mx53evk/mx53evk.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index 1da263bb5d5f..ee54a61d874e 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/mx53smd/mx53smd.c b/board/freescale/mx53smd/mx53smd.c index 7c0f98a13216..2f91a0525c4b 100644 --- a/board/freescale/mx53smd/mx53smd.c +++ b/board/freescale/mx53smd/mx53smd.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/mx6memcal/mx6memcal.c b/board/freescale/mx6memcal/mx6memcal.c index ea7a56369d6e..1cc744fa9ba0 100644 --- a/board/freescale/mx6memcal/mx6memcal.c +++ b/board/freescale/mx6memcal/mx6memcal.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h>
diff --git a/board/freescale/mx6memcal/spl.c b/board/freescale/mx6memcal/spl.c index c11eee51b612..c82b532f6d53 100644 --- a/board/freescale/mx6memcal/spl.c +++ b/board/freescale/mx6memcal/spl.c @@ -7,6 +7,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/iomux.h> #include <asm/arch/clock.h> diff --git a/board/freescale/mx6qarm2/mx6qarm2.c b/board/freescale/mx6qarm2/mx6qarm2.c index ddde245869af..c06fd643677d 100644 --- a/board/freescale/mx6qarm2/mx6qarm2.c +++ b/board/freescale/mx6qarm2/mx6qarm2.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index c031cf8538e7..e92ef26d0ad0 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -9,6 +9,7 @@ #include <image.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 9a176f471182..8c352308553a 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -12,6 +12,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <asm/mach-imx/spi.h> #include <env.h> #include <linux/errno.h> diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index 5d2f815d2348..2c90a35e2c95 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -14,6 +14,7 @@ #include <asm/arch/mx6-ddr.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> diff --git a/board/freescale/mx6sllevk/mx6sllevk.c b/board/freescale/mx6sllevk/mx6sllevk.c index 0a36b46e9e8b..b4fddafe6402 100644 --- a/board/freescale/mx6sllevk/mx6sllevk.c +++ b/board/freescale/mx6sllevk/mx6sllevk.c @@ -10,6 +10,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c b/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c index 1640f465bad3..7340a3440231 100644 --- a/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c +++ b/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c @@ -13,6 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index 7fb8de177bcd..57fab2386415 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -13,6 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index 9cb17594013e..b916ea010290 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -12,6 +12,7 @@ #include <asm/arch/mx6ul_pins.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/freescale/mx6ullevk/mx6ullevk.c b/board/freescale/mx6ullevk/mx6ullevk.c index 3f1ecce10f88..86c11c7bd3a5 100644 --- a/board/freescale/mx6ullevk/mx6ullevk.c +++ b/board/freescale/mx6ullevk/mx6ullevk.c @@ -10,6 +10,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index f12e9d4cfefe..2777ae13bce0 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -9,6 +9,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/board/freescale/mx7ulp_evk/mx7ulp_evk.c b/board/freescale/mx7ulp_evk/mx7ulp_evk.c index fd21591ad6fc..01e32136532d 100644 --- a/board/freescale/mx7ulp_evk/mx7ulp_evk.c +++ b/board/freescale/mx7ulp_evk/mx7ulp_evk.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdt_support.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mx7ulp-pins.h> diff --git a/board/freescale/p1010rdb/ddr.c b/board/freescale/p1010rdb/ddr.c index 71f6259b60e4..2625195f81b1 100644 --- a/board/freescale/p1010rdb/ddr.c +++ b/board/freescale/p1010rdb/ddr.c @@ -5,6 +5,7 @@
#include <common.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <asm/immap_85xx.h> #include <asm/processor.h> diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index 4c3a03e7cd95..7e007da87c5d 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -9,6 +9,7 @@ #include <image.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #include <asm/cache.h> diff --git a/board/freescale/p1010rdb/spl.c b/board/freescale/p1010rdb/spl.c index 35b95e083890..6c84eef398e2 100644 --- a/board/freescale/p1010rdb/spl.c +++ b/board/freescale/p1010rdb/spl.c @@ -15,6 +15,7 @@ #include <i2c.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/spl.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/p1_p2_rdb_pc/spl.c b/board/freescale/p1_p2_rdb_pc/spl.c index b16f701ae1a6..010f4639ee16 100644 --- a/board/freescale/p1_p2_rdb_pc/spl.c +++ b/board/freescale/p1_p2_rdb_pc/spl.c @@ -16,6 +16,7 @@ #include <i2c.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/spl.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/p2041rdb/ddr.c b/board/freescale/p2041rdb/ddr.c index 7a06c7af3dce..910058cefe16 100644 --- a/board/freescale/p2041rdb/ddr.c +++ b/board/freescale/p2041rdb/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/p2041rdb/p2041rdb.c b/board/freescale/p2041rdb/p2041rdb.c index 720d304fe428..4ece1e6ea0a4 100644 --- a/board/freescale/p2041rdb/p2041rdb.c +++ b/board/freescale/p2041rdb/p2041rdb.c @@ -10,6 +10,7 @@ #include <image.h> #include <init.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/qemu-ppce500/qemu-ppce500.c b/board/freescale/qemu-ppce500/qemu-ppce500.c index 3395377b4feb..aa5774fd7974 100644 --- a/board/freescale/qemu-ppce500/qemu-ppce500.c +++ b/board/freescale/qemu-ppce500/qemu-ppce500.c @@ -12,6 +12,7 @@ #include <net.h> #include <pci.h> #include <time.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mmu.h> #include <asm/fsl_pci.h> diff --git a/board/freescale/s32v234evb/s32v234evb.c b/board/freescale/s32v234evb/s32v234evb.c index f381cfc2ad08..304f5acf3be7 100644 --- a/board/freescale/s32v234evb/s32v234evb.c +++ b/board/freescale/s32v234evb/s32v234evb.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/siul.h> diff --git a/board/freescale/t102xrdb/ddr.c b/board/freescale/t102xrdb/ddr.c index 3640a4795740..818c20cf1b5e 100644 --- a/board/freescale/t102xrdb/ddr.c +++ b/board/freescale/t102xrdb/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/t102xrdb/spl.c b/board/freescale/t102xrdb/spl.c index 66d2f3bda7bc..71566851d01d 100644 --- a/board/freescale/t102xrdb/spl.c +++ b/board/freescale/t102xrdb/spl.c @@ -14,6 +14,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/sleep.h" #include "../common/spl.h"
diff --git a/board/freescale/t102xrdb/t102xrdb.c b/board/freescale/t102xrdb/t102xrdb.c index bb775eb2d325..2770e104ee61 100644 --- a/board/freescale/t102xrdb/t102xrdb.c +++ b/board/freescale/t102xrdb/t102xrdb.c @@ -12,6 +12,7 @@ #include <image.h> #include <init.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/t104xrdb/ddr.c b/board/freescale/t104xrdb/ddr.c index e313bf99cf22..8351f7ce9db2 100644 --- a/board/freescale/t104xrdb/ddr.c +++ b/board/freescale/t104xrdb/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/t104xrdb/spl.c b/board/freescale/t104xrdb/spl.c index 28ac12a1fd0d..f5fe73e62dca 100644 --- a/board/freescale/t104xrdb/spl.c +++ b/board/freescale/t104xrdb/spl.c @@ -14,6 +14,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/sleep.h" #include "../common/spl.h"
diff --git a/board/freescale/t104xrdb/t104xrdb.c b/board/freescale/t104xrdb/t104xrdb.c index c7290e5a3426..780043483dff 100644 --- a/board/freescale/t104xrdb/t104xrdb.c +++ b/board/freescale/t104xrdb/t104xrdb.c @@ -12,6 +12,7 @@ #include <init.h> #include <log.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/t208xqds/ddr.c b/board/freescale/t208xqds/ddr.c index 3317f99c81fb..56471b3988b9 100644 --- a/board/freescale/t208xqds/ddr.c +++ b/board/freescale/t208xqds/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/t208xqds/spl.c b/board/freescale/t208xqds/spl.c index 13e61f083f6b..e934a3ca6f70 100644 --- a/board/freescale/t208xqds/spl.c +++ b/board/freescale/t208xqds/spl.c @@ -14,6 +14,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/qixis.h" #include "t208xqds_qixis.h" #include "../common/spl.h" diff --git a/board/freescale/t208xqds/t208xqds.c b/board/freescale/t208xqds/t208xqds.c index f3af8d52925e..dedf722c6957 100644 --- a/board/freescale/t208xqds/t208xqds.c +++ b/board/freescale/t208xqds/t208xqds.c @@ -13,6 +13,7 @@ #include <init.h> #include <log.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/t208xrdb/ddr.c b/board/freescale/t208xrdb/ddr.c index 6a09d1cd221b..1fbab36e1a20 100644 --- a/board/freescale/t208xrdb/ddr.c +++ b/board/freescale/t208xrdb/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/t208xrdb/spl.c b/board/freescale/t208xrdb/spl.c index 2bba94da7bc4..b0ce9af0007a 100644 --- a/board/freescale/t208xrdb/spl.c +++ b/board/freescale/t208xrdb/spl.c @@ -14,6 +14,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <spi_flash.h> +#include <asm/global_data.h> #include "../common/spl.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/t208xrdb/t208xrdb.c b/board/freescale/t208xrdb/t208xrdb.c index d37abb7ef3bb..a18459841c62 100644 --- a/board/freescale/t208xrdb/t208xrdb.c +++ b/board/freescale/t208xrdb/t208xrdb.c @@ -11,6 +11,7 @@ #include <image.h> #include <init.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/t4rdb/ddr.c b/board/freescale/t4rdb/ddr.c index 5b7d10c9798b..57cbde154f0e 100644 --- a/board/freescale/t4rdb/ddr.c +++ b/board/freescale/t4rdb/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/freescale/t4rdb/spl.c b/board/freescale/t4rdb/spl.c index fc624efbe632..e2f9c9b3de29 100644 --- a/board/freescale/t4rdb/spl.c +++ b/board/freescale/t4rdb/spl.c @@ -10,6 +10,7 @@ #include <console.h> #include <env_internal.h> #include <init.h> +#include <asm/global_data.h> #include <asm/spl.h> #include <malloc.h> #include <ns16550.h> diff --git a/board/freescale/t4rdb/t4240rdb.c b/board/freescale/t4rdb/t4240rdb.c index 5c2a75b905e6..6ab35ca9185b 100644 --- a/board/freescale/t4rdb/t4240rdb.c +++ b/board/freescale/t4rdb/t4240rdb.c @@ -11,6 +11,7 @@ #include <image.h> #include <init.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/freescale/vf610twr/vf610twr.c b/board/freescale/vf610twr/vf610twr.c index bd125bc17e05..98cb0140ad02 100644 --- a/board/freescale/vf610twr/vf610twr.c +++ b/board/freescale/vf610twr/vf610twr.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux-vf610.h> diff --git a/board/friendlyarm/nanopi2/board.c b/board/friendlyarm/nanopi2/board.c index 68980536abe9..c0fe2d546f63 100644 --- a/board/friendlyarm/nanopi2/board.c +++ b/board/friendlyarm/nanopi2/board.c @@ -12,6 +12,7 @@ #ifdef CONFIG_PWM_NX #include <pwm.h> #endif +#include <asm/global_data.h> #include <asm/io.h>
#include <asm/arch/nexell.h> diff --git a/board/gardena/smart-gateway-at91sam/board.c b/board/gardena/smart-gateway-at91sam/board.c index 45c947fcbb47..3f402cfeee8c 100644 --- a/board/gardena/smart-gateway-at91sam/board.c +++ b/board/gardena/smart-gateway-at91sam/board.c @@ -11,6 +11,7 @@ #include <led.h> #include <asm/arch/at91_common.h> #include <asm/arch/clk.h> +#include <asm/global_data.h>
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 048f624c3529..71de80c1b91c 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -15,6 +15,7 @@ #include <asm/arch/mx6-pins.h> #include <asm/arch/mxc_hdmi.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/sata.h> diff --git a/board/gdsys/a38x/controlcenterdc.c b/board/gdsys/a38x/controlcenterdc.c index a2287f9deb13..ba57a272187e 100644 --- a/board/gdsys/a38x/controlcenterdc.c +++ b/board/gdsys/a38x/controlcenterdc.c @@ -11,6 +11,7 @@ #include <miiphy.h> #include <net.h> #include <tpm-v1.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm-generic/gpio.h> diff --git a/board/gdsys/a38x/hydra.c b/board/gdsys/a38x/hydra.c index daade6da0af4..495a97691881 100644 --- a/board/gdsys/a38x/hydra.c +++ b/board/gdsys/a38x/hydra.c @@ -1,6 +1,7 @@ #include <common.h> #include <command.h> #include <console.h> /* ctrlc */ +#include <pci.h> #include <asm/io.h>
#include "hydra.h" diff --git a/board/gdsys/mpc8308/gazerbeam.c b/board/gdsys/mpc8308/gazerbeam.c index 0e7fa1e333e4..4e974c56d2c8 100644 --- a/board/gdsys/mpc8308/gazerbeam.c +++ b/board/gdsys/mpc8308/gazerbeam.c @@ -17,6 +17,7 @@ #include <sysinfo.h> #include <tpm-v1.h> #include <video_osd.h> +#include <asm/global_data.h>
#include "../common/ihs_mdio.h" #include "../../../drivers/sysinfo/gazerbeam.h" diff --git a/board/gdsys/mpc8308/sdram.c b/board/gdsys/mpc8308/sdram.c index 9695fb0a10df..bfd55f54e4e1 100644 --- a/board/gdsys/mpc8308/sdram.c +++ b/board/gdsys/mpc8308/sdram.c @@ -19,6 +19,7 @@ #include <spd_sdram.h>
#include <asm/processor.h> diff --git a/board/ge/b1x5v2/b1x5v2.c b/board/ge/b1x5v2/b1x5v2.c index 1cb347fd9e54..de4cb0d5afaa 100644 --- a/board/ge/b1x5v2/b1x5v2.c +++ b/board/ge/b1x5v2/b1x5v2.c @@ -12,6 +12,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/mach-imx/video.h> diff --git a/board/ge/bx50v3/bx50v3.c b/board/ge/bx50v3/bx50v3.c index 3ea9425fd1ea..c11fc40abe54 100644 --- a/board/ge/bx50v3/bx50v3.c +++ b/board/ge/bx50v3/bx50v3.c @@ -12,6 +12,7 @@ #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> #include <env.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <linux/libfdt.h> diff --git a/board/ge/mx53ppd/mx53ppd.c b/board/ge/mx53ppd/mx53ppd.c index ef689733c41d..6174125e728a 100644 --- a/board/ge/mx53ppd/mx53ppd.c +++ b/board/ge/mx53ppd/mx53ppd.c @@ -10,6 +10,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/google/imx8mq_phanbell/imx8mq_phanbell.c b/board/google/imx8mq_phanbell/imx8mq_phanbell.c index 746071b4150f..d0a740dd3f40 100644 --- a/board/google/imx8mq_phanbell/imx8mq_phanbell.c +++ b/board/google/imx8mq_phanbell/imx8mq_phanbell.c @@ -8,6 +8,7 @@ #include <init.h> #include <malloc.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/google/imx8mq_phanbell/spl.c b/board/google/imx8mq_phanbell/spl.c index 06a3f4c1aa86..eec3f3d931b2 100644 --- a/board/google/imx8mq_phanbell/spl.c +++ b/board/google/imx8mq_phanbell/spl.c @@ -6,6 +6,7 @@
#include <common.h> #include <hang.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <init.h> diff --git a/board/google/veyron/veyron.c b/board/google/veyron/veyron.c index 391d973c0b6d..32dbcdc4d10a 100644 --- a/board/google/veyron/veyron.c +++ b/board/google/veyron/veyron.c @@ -9,6 +9,7 @@ #include <init.h> #include <log.h> #include <asm/arch-rockchip/clock.h> +#include <asm/global_data.h> #include <dt-bindings/clock/rk3288-cru.h> #include <linux/delay.h> #include <linux/err.h> diff --git a/board/grinn/chiliboard/board.c b/board/grinn/chiliboard/board.c index 8cc9278287b4..12480f5729d6 100644 --- a/board/grinn/chiliboard/board.c +++ b/board/grinn/chiliboard/board.c @@ -16,6 +16,7 @@ #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> #include <asm/emif.h> +#include <asm/global_data.h> #include <asm/io.h> #include <cpsw.h> #include <env.h> diff --git a/board/grinn/liteboard/board.c b/board/grinn/liteboard/board.c index 578d75aed3d1..48392c48e5cc 100644 --- a/board/grinn/liteboard/board.c +++ b/board/grinn/liteboard/board.c @@ -15,6 +15,7 @@ #include <asm/arch/mx6ul_pins.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> diff --git a/board/highbank/highbank.c b/board/highbank/highbank.c index e07295c7b5c0..a790d453da04 100644 --- a/board/highbank/highbank.c +++ b/board/highbank/highbank.c @@ -12,6 +12,7 @@ #include <net.h> #include <netdev.h> #include <scsi.h> +#include <asm/global_data.h>
#include <linux/sizes.h> #include <asm/io.h> diff --git a/board/hisilicon/hikey/hikey.c b/board/hisilicon/hikey/hikey.c index 65a8179adbfb..afe324c89070 100644 --- a/board/hisilicon/hikey/hikey.c +++ b/board/hisilicon/hikey/hikey.c @@ -9,6 +9,7 @@ #include <fdt_support.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_pl01x.h> #include <errno.h> #include <malloc.h> diff --git a/board/hisilicon/hikey960/hikey960.c b/board/hisilicon/hikey960/hikey960.c index 3fe4c60d02ee..62073aa9541e 100644 --- a/board/hisilicon/hikey960/hikey960.c +++ b/board/hisilicon/hikey960/hikey960.c @@ -10,6 +10,7 @@ #include <errno.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hi3660.h> #include <asm/armv8/mmu.h> diff --git a/board/hisilicon/poplar/poplar.c b/board/hisilicon/poplar/poplar.c index bfb2c66a17a3..fda9a3405df8 100644 --- a/board/hisilicon/poplar/poplar.c +++ b/board/hisilicon/poplar/poplar.c @@ -9,6 +9,7 @@ #include <dm.h> #include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/platform_data/serial_pl01x.h> #include <asm/arch/hi3798cv200.h> diff --git a/board/ids/ids8313/ids8313.c b/board/ids/ids8313/ids8313.c index ac35b5b0d0c1..45c77a249a9b 100644 --- a/board/ids/ids8313/ids8313.c +++ b/board/ids/ids8313/ids8313.c @@ -17,6 +17,7 @@ #include <mpc83xx.h> #include <spi.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h>
diff --git a/board/imgtec/boston/ddr.c b/board/imgtec/boston/ddr.c index 241b3846687a..182f79b9182d 100644 --- a/board/imgtec/boston/ddr.c +++ b/board/imgtec/boston/ddr.c @@ -5,6 +5,7 @@
#include <asm/io.h>
diff --git a/board/imgtec/boston/dt.c b/board/imgtec/boston/dt.c index 44b56416ff91..bf772ff5dec4 100644 --- a/board/imgtec/boston/dt.c +++ b/board/imgtec/boston/dt.c @@ -5,6 +5,7 @@
#include <common.h> #include <fdt_support.h> +#include <asm/global_data.h>
int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/imgtec/ci20/ci20.c b/board/imgtec/ci20/ci20.c index 038dbdd74f06..7ee175d40a5b 100644 --- a/board/imgtec/ci20/ci20.c +++ b/board/imgtec/ci20/ci20.c @@ -11,6 +11,7 @@ #include <init.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <linux/bitops.h> diff --git a/board/imgtec/malta/malta.c b/board/imgtec/malta/malta.c index 252cc813c6ea..c04f727961de 100644 --- a/board/imgtec/malta/malta.c +++ b/board/imgtec/malta/malta.c @@ -13,6 +13,7 @@ #include <pci_gt64120.h> #include <pci_msc01.h> #include <rtc.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/addrspace.h> diff --git a/board/imgtec/xilfpga/xilfpga.c b/board/imgtec/xilfpga/xilfpga.c index 0b68bbde50fc..6a836370e36d 100644 --- a/board/imgtec/xilfpga/xilfpga.c +++ b/board/imgtec/xilfpga/xilfpga.c @@ -10,6 +10,7 @@
diff --git a/board/inversepath/usbarmory/usbarmory.c b/board/inversepath/usbarmory/usbarmory.c index 56a2a7c4a6e6..086d0522c78a 100644 --- a/board/inversepath/usbarmory/usbarmory.c +++ b/board/inversepath/usbarmory/usbarmory.c @@ -11,6 +11,7 @@ #include <command.h> #include <fs.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/iomega/iconnect/iconnect.c b/board/iomega/iconnect/iconnect.c index 79c794bfc896..fe4be28b13ce 100644 --- a/board/iomega/iconnect/iconnect.c +++ b/board/iomega/iconnect/iconnect.c @@ -11,6 +11,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> +#include <asm/global_data.h> #include "iconnect.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/isee/igep003x/board.c b/board/isee/igep003x/board.c index 9b4cb91b3418..02ae7df04db9 100644 --- a/board/isee/igep003x/board.c +++ b/board/isee/igep003x/board.c @@ -21,6 +21,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/isee/igep00x0/common.c b/board/isee/igep00x0/common.c index 58c713f0f322..3fdf83e845c9 100644 --- a/board/isee/igep00x0/common.c +++ b/board/isee/igep00x0/common.c @@ -2,6 +2,7 @@
#include <common.h> #include <twl4030.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/omap_mmc.h> #include <asm/arch/mux.h> diff --git a/board/k+p/kp_imx53/kp_imx53.c b/board/k+p/kp_imx53/kp_imx53.c index efca3e0965f8..cc8118b4ad4f 100644 --- a/board/k+p/kp_imx53/kp_imx53.c +++ b/board/k+p/kp_imx53/kp_imx53.c @@ -6,6 +6,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c index e60d556b3032..110496d99505 100644 --- a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c +++ b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c @@ -12,6 +12,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/boot_mode.h> #include <env.h> #include <errno.h> diff --git a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c index 75fb6acfb3c3..103c4531a64c 100644 --- a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c +++ b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c @@ -13,6 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-ddr.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <spl.h> diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index df507e27907e..c8b617ab570f 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -15,6 +15,7 @@ #include <cli_hush.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/ctype.h> #include <linux/delay.h> diff --git a/board/keymile/km83xx/km83xx.c b/board/keymile/km83xx/km83xx.c index a984165e241e..ecc8c786b6b8 100644 --- a/board/keymile/km83xx/km83xx.c +++ b/board/keymile/km83xx/km83xx.c @@ -22,6 +22,7 @@ #include <mpc83xx.h> #include <i2c.h> #include <miiphy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mmu.h> #include <asm/processor.h> diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c index 60187bd8d294..e9af090a3bc9 100644 --- a/board/keymile/km_arm/km_arm.c +++ b/board/keymile/km_arm/km_arm.c @@ -20,6 +20,7 @@ #include <netdev.h> #include <miiphy.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/keymile/kmp204x/ddr.c b/board/keymile/kmp204x/ddr.c index d9c9ddf2bac5..77a00c55c951 100644 --- a/board/keymile/kmp204x/ddr.c +++ b/board/keymile/kmp204x/ddr.c @@ -11,6 +11,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/kmc/kzm9g/kzm9g.c b/board/kmc/kzm9g/kzm9g.c index 4b406042180c..02c87a031c30 100644 --- a/board/kmc/kzm9g/kzm9g.c +++ b/board/kmc/kzm9g/kzm9g.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <asm/gpio.h> diff --git a/board/kobol/helios4/helios4.c b/board/kobol/helios4/helios4.c index 17d2489415de..adb091ce4fd3 100644 --- a/board/kobol/helios4/helios4.c +++ b/board/kobol/helios4/helios4.c @@ -10,6 +10,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/kontron/sl28/ddr.c b/board/kontron/sl28/ddr.c index d111b6d4c320..41426996ab9f 100644 --- a/board/kontron/sl28/ddr.c +++ b/board/kontron/sl28/ddr.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <fsl_ddr_sdram.h>
diff --git a/board/kontron/sl28/sl28.c b/board/kontron/sl28/sl28.c index 34f17b486bd4..d0372accaf33 100644 --- a/board/kontron/sl28/sl28.c +++ b/board/kontron/sl28/sl28.c @@ -5,6 +5,7 @@ #include <errno.h> #include <fsl_ddr.h> #include <fdt_support.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <env_internal.h> #include <asm/arch-fsl-layerscape/soc.h> diff --git a/board/kontron/sl28/spl_atf.c b/board/kontron/sl28/spl_atf.c index 5438b5239c6f..a9cd6850e983 100644 --- a/board/kontron/sl28/spl_atf.c +++ b/board/kontron/sl28/spl_atf.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <atf_common.h> #include <spl.h> diff --git a/board/kosagi/novena/novena.c b/board/kosagi/novena/novena.c index b1939f8a56e2..0e1b4a0a46ce 100644 --- a/board/kosagi/novena/novena.c +++ b/board/kosagi/novena/novena.c @@ -10,6 +10,7 @@ #include <eeprom.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <ahci.h> #include <env.h> diff --git a/board/l+g/vinco/vinco.c b/board/l+g/vinco/vinco.c index b1593bab5ebd..f221f05261ae 100644 --- a/board/l+g/vinco/vinco.c +++ b/board/l+g/vinco/vinco.c @@ -11,6 +11,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> diff --git a/board/laird/wb45n/wb45n.c b/board/laird/wb45n/wb45n.c index df6eeb624347..5e1ef8a49ac4 100644 --- a/board/laird/wb45n/wb45n.c +++ b/board/laird/wb45n/wb45n.c @@ -4,6 +4,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9x5_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/laird/wb50n/wb50n.c b/board/laird/wb50n/wb50n.c index 9cc21b2abd3c..8fa989a2a4ff 100644 --- a/board/laird/wb50n/wb50n.c +++ b/board/laird/wb50n/wb50n.c @@ -4,6 +4,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_sfr.h> #include <asm/arch/sama5d3_smc.h> diff --git a/board/lego/ev3/legoev3.c b/board/lego/ev3/legoev3.c index 51b669a891b6..5e5c8c1198f7 100644 --- a/board/lego/ev3/legoev3.c +++ b/board/lego/ev3/legoev3.c @@ -19,6 +19,7 @@ #include <spi_flash.h> #include <asm/arch/hardware.h> #include <asm/arch/pinmux_defs.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/davinci_misc.h> #include <linux/errno.h> diff --git a/board/lg/sniper/sniper.c b/board/lg/sniper/sniper.c index 118ab269d6fc..3065461be5b7 100644 --- a/board/lg/sniper/sniper.c +++ b/board/lg/sniper/sniper.c @@ -11,6 +11,7 @@ #include <env.h> #include <fastboot.h> #include <init.h> +#include <asm/global_data.h> #include <linux/ctype.h> #include <linux/usb/musb.h> #include <asm/omap_musb.h> diff --git a/board/liebherr/display5/display5.c b/board/liebherr/display5/display5.c index 5f447143019a..e3a59dbec009 100644 --- a/board/liebherr/display5/display5.c +++ b/board/liebherr/display5/display5.c @@ -9,6 +9,7 @@ #include <fdt_support.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/liebherr/display5/spl.c b/board/liebherr/display5/spl.c index 23959c255731..b8658c8d6174 100644 --- a/board/liebherr/display5/spl.c +++ b/board/liebherr/display5/spl.c @@ -12,6 +12,7 @@ #include <log.h> #include <serial.h> #include <spl.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <asm/io.h> diff --git a/board/liebherr/mccmon6/mccmon6.c b/board/liebherr/mccmon6/mccmon6.c index 71f75d877d2f..1b49526fba4f 100644 --- a/board/liebherr/mccmon6/mccmon6.c +++ b/board/liebherr/mccmon6/mccmon6.c @@ -12,6 +12,7 @@ #include <asm/arch/iomux.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c index 9286f4c755bc..cd11b0ada77c 100644 --- a/board/liebherr/xea/xea.c +++ b/board/liebherr/xea/xea.c @@ -18,6 +18,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/logicpd/am3517evm/am3517evm.c b/board/logicpd/am3517evm/am3517evm.c index cba51f54d41d..f0141659282a 100644 --- a/board/logicpd/am3517evm/am3517evm.c +++ b/board/logicpd/am3517evm/am3517evm.c @@ -16,6 +16,7 @@ #include <net.h> #include <ns16550.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/omap_musb.h> #include <asm/arch/am35x_def.h> diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index ba69c966869d..0d53548dcb4b 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -16,6 +16,7 @@ #include <mmc.h> #include <fsl_esdhc_imx.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <linux/sizes.h> diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 496886fea25a..2379b521904a 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -20,6 +20,7 @@ #include <i2c.h> #include <serial.h> #include <twl4030.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/mux.h> diff --git a/board/maxbcm/maxbcm.c b/board/maxbcm/maxbcm.c index 3c6422214f77..e92132ad19a1 100644 --- a/board/maxbcm/maxbcm.c +++ b/board/maxbcm/maxbcm.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <miiphy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/mediatek/mt7622/mt7622_rfb.c b/board/mediatek/mt7622/mt7622_rfb.c index 6a5f936635c1..0504d6177fd5 100644 --- a/board/mediatek/mt7622/mt7622_rfb.c +++ b/board/mediatek/mt7622/mt7622_rfb.c @@ -8,6 +8,7 @@ #include <config.h> #include <env.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/board/mediatek/mt7623/mt7623_rfb.c b/board/mediatek/mt7623/mt7623_rfb.c index 984e75ccaf26..755e879085c2 100644 --- a/board/mediatek/mt7623/mt7623_rfb.c +++ b/board/mediatek/mt7623/mt7623_rfb.c @@ -5,6 +5,7 @@
#include <common.h> #include <mmc.h> +#include <asm/global_data.h>
diff --git a/board/mediatek/mt7629/mt7629_rfb.c b/board/mediatek/mt7629/mt7629_rfb.c index 08468b50ea2a..d1bca6d62ef8 100644 --- a/board/mediatek/mt7629/mt7629_rfb.c +++ b/board/mediatek/mt7629/mt7629_rfb.c @@ -4,6 +4,7 @@ */
diff --git a/board/mediatek/mt8512/mt8512.c b/board/mediatek/mt8512/mt8512.c index 4ad62b73a6c0..ac3adb801222 100644 --- a/board/mediatek/mt8512/mt8512.c +++ b/board/mediatek/mt8512/mt8512.c @@ -7,6 +7,7 @@ #include <dm.h> #include <log.h> #include <wdt.h> +#include <asm/global_data.h>
diff --git a/board/mediatek/mt8518/mt8518_ap1.c b/board/mediatek/mt8518/mt8518_ap1.c index c9acfcb1a56d..fce5de6767cd 100644 --- a/board/mediatek/mt8518/mt8518_ap1.c +++ b/board/mediatek/mt8518/mt8518_ap1.c @@ -7,6 +7,7 @@ #include <dm.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
diff --git a/board/menlo/m53menlo/m53menlo.c b/board/menlo/m53menlo/m53menlo.c index 893f62559994..c34baca602cd 100644 --- a/board/menlo/m53menlo/m53menlo.c +++ b/board/menlo/m53menlo/m53menlo.c @@ -10,6 +10,7 @@ #include <dm.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> diff --git a/board/microchip/mpfs_icicle/mpfs_icicle.c b/board/microchip/mpfs_icicle/mpfs_icicle.c index 0e34409067a3..afef719dffda 100644 --- a/board/microchip/mpfs_icicle/mpfs_icicle.c +++ b/board/microchip/mpfs_icicle/mpfs_icicle.c @@ -8,6 +8,7 @@ #include <dm.h> #include <env.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/mikrotik/crs3xx-98dx3236/crs3xx-98dx3236.c b/board/mikrotik/crs3xx-98dx3236/crs3xx-98dx3236.c index 8b419ef6f7ea..315169ba661d 100644 --- a/board/mikrotik/crs3xx-98dx3236/crs3xx-98dx3236.c +++ b/board/mikrotik/crs3xx-98dx3236/crs3xx-98dx3236.c @@ -6,6 +6,7 @@ #include <common.h> #include <i2c.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/bitops.h> #include <linux/mbus.h> diff --git a/board/mini-box/picosam9g45/picosam9g45.c b/board/mini-box/picosam9g45/picosam9g45.c index e8e1ac3eb195..5d6cb24966d6 100644 --- a/board/mini-box/picosam9g45/picosam9g45.c +++ b/board/mini-box/picosam9g45/picosam9g45.c @@ -13,6 +13,7 @@ #include <common.h> #include <init.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clk.h> #include <asm/arch/at91sam9g45_matrix.h> diff --git a/board/mpc8308_p1m/sdram.c b/board/mpc8308_p1m/sdram.c index cbf8781746eb..62a2d8a53afa 100644 --- a/board/mpc8308_p1m/sdram.c +++ b/board/mpc8308_p1m/sdram.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <mpc83xx.h> +#include <asm/global_data.h>
#include <asm/bitops.h> #include <asm/io.h> diff --git a/board/mscc/jr2/jr2.c b/board/mscc/jr2/jr2.c index 51700f4acffe..1c516aacd881 100644 --- a/board/mscc/jr2/jr2.c +++ b/board/mscc/jr2/jr2.c @@ -11,6 +11,7 @@ #include <miiphy.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <asm/global_data.h>
enum { BOARD_TYPE_PCB110 = 0xAABBCE00, diff --git a/board/mscc/luton/luton.c b/board/mscc/luton/luton.c index acc26157c771..038902d08a9d 100644 --- a/board/mscc/luton/luton.c +++ b/board/mscc/luton/luton.c @@ -6,6 +6,7 @@ #include <common.h> #include <image.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <led.h> #include <miiphy.h> diff --git a/board/mscc/ocelot/ocelot.c b/board/mscc/ocelot/ocelot.c index 74e8bfc43147..c462890bb853 100644 --- a/board/mscc/ocelot/ocelot.c +++ b/board/mscc/ocelot/ocelot.c @@ -7,6 +7,7 @@ #include <image.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/addrspace.h> #include <asm/types.h> diff --git a/board/mscc/serval/serval.c b/board/mscc/serval/serval.c index ed1aea55cc2f..94c1c42b79b2 100644 --- a/board/mscc/serval/serval.c +++ b/board/mscc/serval/serval.c @@ -6,6 +6,7 @@ #include <common.h> #include <image.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <led.h> #include <miiphy.h> diff --git a/board/mscc/servalt/servalt.c b/board/mscc/servalt/servalt.c index 879f5de50675..252d8e3156d5 100644 --- a/board/mscc/servalt/servalt.c +++ b/board/mscc/servalt/servalt.c @@ -6,6 +6,7 @@ #include <common.h> #include <image.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <led.h>
diff --git a/board/myir/mys_6ulx/mys_6ulx.c b/board/myir/mys_6ulx/mys_6ulx.c index d886af05bea4..847497bcba7c 100644 --- a/board/myir/mys_6ulx/mys_6ulx.c +++ b/board/myir/mys_6ulx/mys_6ulx.c @@ -9,6 +9,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> #include <fsl_esdhc_imx.h> diff --git a/board/nokia/rx51/rx51.c b/board/nokia/rx51/rx51.c index ceb4317901ce..a6b4db503a66 100644 --- a/board/nokia/rx51/rx51.c +++ b/board/nokia/rx51/rx51.c @@ -30,6 +30,7 @@ #include <twl4030.h> #include <i2c.h> #include <video_fb.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/setup.h> #include <asm/bitops.h> diff --git a/board/novtech/meerkat96/meerkat96.c b/board/novtech/meerkat96/meerkat96.c index b13e7ce3b18d..1edebe5db9be 100644 --- a/board/novtech/meerkat96/meerkat96.c +++ b/board/novtech/meerkat96/meerkat96.c @@ -9,6 +9,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> #include <common.h> diff --git a/board/olimex/mx23_olinuxino/mx23_olinuxino.c b/board/olimex/mx23_olinuxino/mx23_olinuxino.c index f13fdb8d47e7..d1e189cbb6eb 100644 --- a/board/olimex/mx23_olinuxino/mx23_olinuxino.c +++ b/board/olimex/mx23_olinuxino/mx23_olinuxino.c @@ -7,6 +7,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/iomux-mx23.h> diff --git a/board/phytec/pcl063/pcl063.c b/board/phytec/pcl063/pcl063.c index 9e6940f9c76a..b2e435f6908d 100644 --- a/board/phytec/pcl063/pcl063.c +++ b/board/phytec/pcl063/pcl063.c @@ -11,6 +11,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> #include <fsl_esdhc_imx.h> diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c index b0c56a29f1f8..f9cf4abd474b 100644 --- a/board/phytec/pcm052/pcm052.c +++ b/board/phytec/pcm052/pcm052.c @@ -8,6 +8,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux-vf610.h> diff --git a/board/phytec/pcm058/pcm058.c b/board/phytec/pcm058/pcm058.c index 79c666588f4e..5e5b129ef1ff 100644 --- a/board/phytec/pcm058/pcm058.c +++ b/board/phytec/pcm058/pcm058.c @@ -14,6 +14,7 @@ #include <net.h> #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-ddr.h> +#include <asm/global_data.h> #include <asm/mach-imx/boot_mode.h> #include <asm/arch/sys_proto.h> #include <dm.h> diff --git a/board/phytec/pfla02/pfla02.c b/board/phytec/pfla02/pfla02.c index 3b10cc0f9f11..076ce6711ef0 100644 --- a/board/phytec/pfla02/pfla02.c +++ b/board/phytec/pfla02/pfla02.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/board/phytec/phycore_am335x_r2/board.c b/board/phytec/phycore_am335x_r2/board.c index fb5890684714..5ca94152049f 100644 --- a/board/phytec/phycore_am335x_r2/board.c +++ b/board/phytec/phycore_am335x_r2/board.c @@ -17,6 +17,7 @@ #include <asm/arch/ddr_defs.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <power/tps65910.h> #include <jffs2/load_kernel.h> #include <mtd_node.h> diff --git a/board/phytec/phycore_imx8mm/phycore-imx8mm.c b/board/phytec/phycore_imx8mm/phycore-imx8mm.c index d2f3d23b7ead..ef6472916903 100644 --- a/board/phytec/phycore_imx8mm/phycore-imx8mm.c +++ b/board/phytec/phycore_imx8mm/phycore-imx8mm.c @@ -6,6 +6,7 @@
#include <common.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/boot_mode.h> #include <env.h> diff --git a/board/phytec/phycore_imx8mm/spl.c b/board/phytec/phycore_imx8mm/spl.c index 863374d800d9..64f0780f6e65 100644 --- a/board/phytec/phycore_imx8mm/spl.c +++ b/board/phytec/phycore_imx8mm/spl.c @@ -9,6 +9,7 @@ #include <asm/arch/ddr.h> #include <asm/arch/imx8mm_pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/iomux-v3.h> #include <dm/device.h> diff --git a/board/phytec/phycore_imx8mp/phycore-imx8mp.c b/board/phytec/phycore_imx8mp/phycore-imx8mp.c index 6cb2ba5fc21c..67649078c201 100644 --- a/board/phytec/phycore_imx8mp/phycore-imx8mp.c +++ b/board/phytec/phycore_imx8mp/phycore-imx8mp.c @@ -6,6 +6,7 @@
#include <common.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/boot_mode.h> #include <env.h> diff --git a/board/phytec/phycore_imx8mp/spl.c b/board/phytec/phycore_imx8mp/spl.c index 6de5d07bbfe1..eefdd7fdda3d 100644 --- a/board/phytec/phycore_imx8mp/spl.c +++ b/board/phytec/phycore_imx8mp/spl.c @@ -9,6 +9,7 @@ #include <asm/arch/ddr.h> #include <asm/arch/imx8mp_pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/gpio.h> #include <asm/mach-imx/mxc_i2c.h> diff --git a/board/phytec/phycore_rk3288/phycore-rk3288.c b/board/phytec/phycore_rk3288/phycore-rk3288.c index ecc73227a023..f588fc3b0c70 100644 --- a/board/phytec/phycore_rk3288/phycore-rk3288.c +++ b/board/phytec/phycore_rk3288/phycore-rk3288.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <dm.h> diff --git a/board/phytium/durian/durian.c b/board/phytium/durian/durian.c index b80688ae864c..8a82a4591ac2 100644 --- a/board/phytium/durian/durian.c +++ b/board/phytium/durian/durian.c @@ -12,6 +12,7 @@ #include <log.h> #include <asm/armv8/mmu.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/io.h> #include <linux/arm-smccc.h> diff --git a/board/ppcag/bg0900/bg0900.c b/board/ppcag/bg0900/bg0900.c index e8168e346824..578f5c73b6cb 100644 --- a/board/ppcag/bg0900/bg0900.c +++ b/board/ppcag/bg0900/bg0900.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/qemu-mips/qemu-mips.c b/board/qemu-mips/qemu-mips.c index 7553d0b00de5..f57091739ec9 100644 --- a/board/qemu-mips/qemu-mips.c +++ b/board/qemu-mips/qemu-mips.c @@ -8,6 +8,7 @@ #include <command.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/mipsregs.h> #include <asm/io.h> #include <netdev.h> diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 4d1dbd696dcf..646013cfc93d 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -13,6 +13,7 @@ #include <net.h> #include <usb.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <fdt_support.h> #include <asm/arch/dram.h> diff --git a/board/qualcomm/dragonboard820c/dragonboard820c.c b/board/qualcomm/dragonboard820c/dragonboard820c.c index c1ade5ce43a6..877e34c21017 100644 --- a/board/qualcomm/dragonboard820c/dragonboard820c.c +++ b/board/qualcomm/dragonboard820c/dragonboard820c.c @@ -10,6 +10,7 @@ #include <asm/arch/sysmap-apq8096.h> #include <env.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/arm-smccc.h> #include <linux/psci.h> #include <common.h> diff --git a/board/raidsonic/ib62x0/ib62x0.c b/board/raidsonic/ib62x0/ib62x0.c index db1b0adc3826..f9bc07649e0a 100644 --- a/board/raidsonic/ib62x0/ib62x0.c +++ b/board/raidsonic/ib62x0/ib62x0.c @@ -9,6 +9,7 @@ #include <common.h> #include <init.h> #include <miiphy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index 279ed4872165..854c47636d3f 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -12,6 +12,7 @@ #include <init.h> #include <malloc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/blanche/blanche.c b/board/renesas/blanche/blanche.c index 2450fca7a58b..9671382f2a3e 100644 --- a/board/renesas/blanche/blanche.c +++ b/board/renesas/blanche/blanche.c @@ -15,6 +15,7 @@ #include <asm/arch/rmobile.h> #include <asm/arch/sh_sdhi.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/mach-types.h> diff --git a/board/renesas/condor/condor.c b/board/renesas/condor/condor.c index 8054511d9d6c..4454061e071b 100644 --- a/board/renesas/condor/condor.c +++ b/board/renesas/condor/condor.c @@ -10,6 +10,7 @@ #include <cpu_func.h> #include <hang.h> #include <init.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/mach-types.h> #include <asm/io.h> diff --git a/board/renesas/draak/draak.c b/board/renesas/draak/draak.c index 9993f5bbe321..ffd52ebfe431 100644 --- a/board/renesas/draak/draak.c +++ b/board/renesas/draak/draak.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/renesas/eagle/eagle.c b/board/renesas/eagle/eagle.c index 6228f22e0103..f9e553feaa70 100644 --- a/board/renesas/eagle/eagle.c +++ b/board/renesas/eagle/eagle.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/renesas/ebisu/ebisu.c b/board/renesas/ebisu/ebisu.c index c8d180566d43..82cd2a5800fe 100644 --- a/board/renesas/ebisu/ebisu.c +++ b/board/renesas/ebisu/ebisu.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/renesas/gose/gose.c b/board/renesas/gose/gose.c index c6a93c25e6d2..56cdc73b1a77 100644 --- a/board/renesas/gose/gose.c +++ b/board/renesas/gose/gose.c @@ -12,6 +12,7 @@ #include <init.h> #include <malloc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/grpeach/grpeach.c b/board/renesas/grpeach/grpeach.c index b92e01ca9847..ac989eb29c2f 100644 --- a/board/renesas/grpeach/grpeach.c +++ b/board/renesas/grpeach/grpeach.c @@ -7,6 +7,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h>
diff --git a/board/renesas/koelsch/koelsch.c b/board/renesas/koelsch/koelsch.c index 1b3acc8fd1f1..b0a66ea2669e 100644 --- a/board/renesas/koelsch/koelsch.c +++ b/board/renesas/koelsch/koelsch.c @@ -13,6 +13,7 @@ #include <init.h> #include <malloc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/lager/lager.c b/board/renesas/lager/lager.c index 36a35a9a9cfb..add4eef3d53c 100644 --- a/board/renesas/lager/lager.c +++ b/board/renesas/lager/lager.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/renesas/porter/porter.c b/board/renesas/porter/porter.c index 793e02cb440a..b3e4c08d74d3 100644 --- a/board/renesas/porter/porter.c +++ b/board/renesas/porter/porter.c @@ -13,6 +13,7 @@ #include <init.h> #include <malloc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/rcar-common/common.c b/board/renesas/rcar-common/common.c index 9762fb26384a..e77357968a34 100644 --- a/board/renesas/rcar-common/common.c +++ b/board/renesas/rcar-common/common.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <init.h> +#include <asm/global_data.h> #include <dm/uclass-internal.h> #include <asm/arch/rmobile.h> #include <linux/libfdt.h> diff --git a/board/renesas/salvator-x/salvator-x.c b/board/renesas/salvator-x/salvator-x.c index c78c2a42b02a..08ed725521c2 100644 --- a/board/renesas/salvator-x/salvator-x.c +++ b/board/renesas/salvator-x/salvator-x.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/renesas/silk/silk.c b/board/renesas/silk/silk.c index 171d06f3175c..05af5f4d68b1 100644 --- a/board/renesas/silk/silk.c +++ b/board/renesas/silk/silk.c @@ -13,6 +13,7 @@ #include <init.h> #include <malloc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/stout/stout.c b/board/renesas/stout/stout.c index babcce9aa1c3..3fdf936ddcac 100644 --- a/board/renesas/stout/stout.c +++ b/board/renesas/stout/stout.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <env_internal.h> #include <asm/processor.h> diff --git a/board/renesas/ulcb/ulcb.c b/board/renesas/ulcb/ulcb.c index efbffa0ee77c..7ba1948659f9 100644 --- a/board/renesas/ulcb/ulcb.c +++ b/board/renesas/ulcb/ulcb.c @@ -12,6 +12,7 @@ #include <malloc.h> #include <netdev.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_sh.h> #include <asm/processor.h> #include <asm/mach-types.h> diff --git a/board/rockchip/evb_rk3308/evb_rk3308.c b/board/rockchip/evb_rk3308/evb_rk3308.c index 180f1fe4f00b..e0c96fd70a28 100644 --- a/board/rockchip/evb_rk3308/evb_rk3308.c +++ b/board/rockchip/evb_rk3308/evb_rk3308.c @@ -5,6 +5,7 @@
#include <common.h> #include <adc.h> +#include <asm/global_data.h>
diff --git a/board/rockchip/evb_rv1108/evb_rv1108.c b/board/rockchip/evb_rv1108/evb_rv1108.c index fc31c4931169..e6ac598648db 100644 --- a/board/rockchip/evb_rv1108/evb_rv1108.c +++ b/board/rockchip/evb_rv1108/evb_rv1108.c @@ -7,6 +7,7 @@ #include <common.h> #include <init.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/grf_rv1108.h> diff --git a/board/ronetix/pm9261/pm9261.c b/board/ronetix/pm9261/pm9261.c index 0ce6a6e44e90..5be2c5e192bb 100644 --- a/board/ronetix/pm9261/pm9261.c +++ b/board/ronetix/pm9261/pm9261.c @@ -10,6 +10,7 @@ #include <common.h> #include <init.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/io.h> #include <asm/gpio.h> diff --git a/board/ronetix/pm9263/pm9263.c b/board/ronetix/pm9263/pm9263.c index 62dfe6e33d75..95c0dec4db5f 100644 --- a/board/ronetix/pm9263/pm9263.c +++ b/board/ronetix/pm9263/pm9263.c @@ -9,6 +9,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/io.h> #include <asm/gpio.h> diff --git a/board/ronetix/pm9g45/pm9g45.c b/board/ronetix/pm9g45/pm9g45.c index c7d22db0aba8..8d5825c7f131 100644 --- a/board/ronetix/pm9g45/pm9g45.c +++ b/board/ronetix/pm9g45/pm9g45.c @@ -12,6 +12,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <asm/io.h> #include <asm/gpio.h> diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c index d283ef6275ab..b43242fd3f40 100644 --- a/board/samsung/arndale/arndale.c +++ b/board/samsung/arndale/arndale.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/dwmmc.h> diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 470531fdbb28..104d2a657469 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -16,6 +16,7 @@ #include <spi.h> #include <tmu.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/board.h> diff --git a/board/samsung/common/exynos5-dt-types.c b/board/samsung/common/exynos5-dt-types.c index f1ecb7d2c396..e2d5a7c9ba77 100644 --- a/board/samsung/common/exynos5-dt-types.c +++ b/board/samsung/common/exynos5-dt-types.c @@ -9,6 +9,7 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <power/pmic.h> #include <power/regulator.h> diff --git a/board/samsung/common/exynos5-dt.c b/board/samsung/common/exynos5-dt.c index 69aa2120e126..4463cdcb87b6 100644 --- a/board/samsung/common/exynos5-dt.c +++ b/board/samsung/common/exynos5-dt.c @@ -9,6 +9,7 @@ #include <env.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <i2c.h> diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index 837463ba78f8..7d3b9846e39f 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -9,6 +9,7 @@ #include <env.h> #include <lcd.h> #include <libtizen.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <samsung/misc.h> #include <errno.h> diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index 2f0ef22c4171..b32b82fc2dad 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/mmc.h> #include <dm.h> diff --git a/board/samsung/odroid/odroid.c b/board/samsung/odroid/odroid.c index 7d7e722892e7..90aab62d33b0 100644 --- a/board/samsung/odroid/odroid.c +++ b/board/samsung/odroid/odroid.c @@ -10,6 +10,7 @@ #include <asm/arch/power.h> #include <asm/arch/clock.h> #include <asm/arch/gpio.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/cpu.h> #include <dm.h> diff --git a/board/samsung/smdkc100/smdkc100.c b/board/samsung/smdkc100/smdkc100.c index d034f53d68b5..69ed715403fb 100644 --- a/board/samsung/smdkc100/smdkc100.c +++ b/board/samsung/smdkc100/smdkc100.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/sromc.h> diff --git a/board/samsung/smdkv310/smdkv310.c b/board/samsung/smdkv310/smdkv310.c index 24273f1214b0..8811cbb9ad0b 100644 --- a/board/samsung/smdkv310/smdkv310.c +++ b/board/samsung/smdkv310/smdkv310.c @@ -7,6 +7,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <netdev.h> diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index f50da6be7245..9ef11b8471ca 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -10,6 +10,7 @@ #include <log.h> #include <spi.h> #include <lcd.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/adc.h> diff --git a/board/sandbox/sandbox.c b/board/sandbox/sandbox.c index d152703b1540..3c63d45dd3e1 100644 --- a/board/sandbox/sandbox.c +++ b/board/sandbox/sandbox.c @@ -11,6 +11,7 @@ #include <init.h> #include <led.h> #include <os.h> +#include <asm/global_data.h> #include <asm/test.h> #include <asm/u-boot-sandbox.h>
diff --git a/board/sandisk/sansa_fuze_plus/sfp.c b/board/sandisk/sansa_fuze_plus/sfp.c index 42004098b377..f46b02e38e59 100644 --- a/board/sandisk/sansa_fuze_plus/sfp.c +++ b/board/sandisk/sansa_fuze_plus/sfp.c @@ -13,6 +13,7 @@ #include <errno.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/iomux-mx23.h> diff --git a/board/sbc8349/sbc8349.c b/board/sbc8349/sbc8349.c index 824479c099b6..b440a0b17e97 100644 --- a/board/sbc8349/sbc8349.c +++ b/board/sbc8349/sbc8349.c @@ -13,6 +13,7 @@ #include <ioports.h> #include <mpc83xx.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <asm/mpc8349_pci.h> #include <i2c.h> #include <spd_sdram.h> diff --git a/board/sbc8641d/sbc8641d.c b/board/sbc8641d/sbc8641d.c index 34e46d4ea4c8..a67092daf47f 100644 --- a/board/sbc8641d/sbc8641d.c +++ b/board/sbc8641d/sbc8641d.c @@ -16,6 +16,7 @@ #include <init.h> #include <log.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/immap_86xx.h> #include <asm/fsl_pci.h> diff --git a/board/schulercontrol/sc_sps_1/sc_sps_1.c b/board/schulercontrol/sc_sps_1/sc_sps_1.c index 8011871fc8fb..3a04b1a634cc 100644 --- a/board/schulercontrol/sc_sps_1/sc_sps_1.c +++ b/board/schulercontrol/sc_sps_1/sc_sps_1.c @@ -9,6 +9,7 @@ #include <common.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/seco/mx6quq7/mx6quq7.c b/board/seco/mx6quq7/mx6quq7.c index c7e3d425eacd..a061d7d8afbc 100644 --- a/board/seco/mx6quq7/mx6quq7.c +++ b/board/seco/mx6quq7/mx6quq7.c @@ -13,6 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/siemens/capricorn/spl.c b/board/siemens/capricorn/spl.c index 8435bd3863bf..8e077d73aef9 100644 --- a/board/siemens/capricorn/spl.c +++ b/board/siemens/capricorn/spl.c @@ -9,6 +9,7 @@ #include <init.h> #include <spl.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <dm/device.h> #include <dm/uclass-internal.h> diff --git a/board/siemens/common/board.c b/board/siemens/common/board.c index e0bd8590bc9d..1bdf404ac3eb 100644 --- a/board/siemens/common/board.c +++ b/board/siemens/common/board.c @@ -25,6 +25,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/siemens/corvus/board.c b/board/siemens/corvus/board.c index 25d85a8f1705..a6e1737be022 100644 --- a/board/siemens/corvus/board.c +++ b/board/siemens/corvus/board.c @@ -14,6 +14,7 @@ #include <dm.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9g45_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/siemens/smartweb/smartweb.c b/board/siemens/smartweb/smartweb.c index c6bdd9708372..d500a6214d56 100644 --- a/board/siemens/smartweb/smartweb.c +++ b/board/siemens/smartweb/smartweb.c @@ -19,6 +19,7 @@ #include <dm.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9_sdramc.h> #include <asm/arch/at91sam9260_matrix.h> diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 91e29f06f60f..cad16f906564 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -17,6 +17,7 @@ #include <env.h> #include <flash.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> diff --git a/board/sks-kinkel/sksimx6/sksimx6.c b/board/sks-kinkel/sksimx6/sksimx6.c index 9fdbeac82fd3..cec3ade96cfd 100644 --- a/board/sks-kinkel/sksimx6/sksimx6.c +++ b/board/sks-kinkel/sksimx6/sksimx6.c @@ -11,6 +11,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/socrates/socrates.c b/board/socrates/socrates.c index 25bc664328aa..0c9262d35400 100644 --- a/board/socrates/socrates.c +++ b/board/socrates/socrates.c @@ -16,6 +16,7 @@ #include <init.h> #include <pci.h> #include <uuid.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/immap_85xx.h> #include <ioports.h> diff --git a/board/softing/vining_2000/vining_2000.c b/board/softing/vining_2000/vining_2000.c index 4e9d351582ff..aaeeee361e54 100644 --- a/board/softing/vining_2000/vining_2000.c +++ b/board/softing/vining_2000/vining_2000.c @@ -14,6 +14,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/board/softing/vining_fpga/socfpga.c b/board/softing/vining_fpga/socfpga.c index 7e311b7a1c38..aaedf0345045 100644 --- a/board/softing/vining_fpga/socfpga.c +++ b/board/softing/vining_fpga/socfpga.c @@ -10,6 +10,7 @@ #include <net.h> #include <status_led.h> #include <asm/arch/reset_manager.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <i2c.h> diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index 92443d5177d9..7b2accf01de6 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -10,6 +10,7 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/board/solidrun/common/tlv_data.c b/board/solidrun/common/tlv_data.c index f08ac8975a6a..11d6e4a13807 100644 --- a/board/solidrun/common/tlv_data.c +++ b/board/solidrun/common/tlv_data.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <compiler.h> #include <tlv_eeprom.h> #include "tlv_data.h"
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index ae1c04df87da..3eadc38f6fd4 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -23,6 +23,7 @@ #include <asm/arch/mx6-pins.h> #include <asm/arch/mxc_hdmi.h> #include <env.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/somlabs/visionsom-6ull/visionsom-6ull.c b/board/somlabs/visionsom-6ull/visionsom-6ull.c index bc7257be405b..076c641d8a90 100644 --- a/board/somlabs/visionsom-6ull/visionsom-6ull.c +++ b/board/somlabs/visionsom-6ull/visionsom-6ull.c @@ -11,6 +11,7 @@ #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/st/common/stm32mp_mtdparts.c b/board/st/common/stm32mp_mtdparts.c index 71a0b449adfe..69eb10844d4e 100644 --- a/board/st/common/stm32mp_mtdparts.c +++ b/board/st/common/stm32mp_mtdparts.c @@ -14,6 +14,7 @@ #include <tee.h> #include <asm/arch/stm32prog.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h>
#define MTDPARTS_LEN 256 #define MTDIDS_LEN 128 diff --git a/board/st/stih410-b2260/board.c b/board/st/stih410-b2260/board.c index e06f05bfa482..cd3a7dc51a2f 100644 --- a/board/st/stih410-b2260/board.c +++ b/board/st/stih410-b2260/board.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/usb/otg.h> #include <dwc3-sti-glue.h> #include <dwc3-uboot.h> diff --git a/board/st/stm32f429-discovery/stm32f429-discovery.c b/board/st/stm32f429-discovery/stm32f429-discovery.c index ee6a90c9fdd0..9d8fc9f5a2e1 100644 --- a/board/st/stm32f429-discovery/stm32f429-discovery.c +++ b/board/st/stm32f429-discovery/stm32f429-discovery.c @@ -15,6 +15,7 @@ #include <env.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <asm/arch/stm32.h> diff --git a/board/st/stm32f429-evaluation/stm32f429-evaluation.c b/board/st/stm32f429-evaluation/stm32f429-evaluation.c index 22a193d8fc31..96b4c2572632 100644 --- a/board/st/stm32f429-evaluation/stm32f429-evaluation.c +++ b/board/st/stm32f429-evaluation/stm32f429-evaluation.c @@ -9,6 +9,7 @@ #include <env.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <asm/arch/stm32.h> diff --git a/board/st/stm32f469-discovery/stm32f469-discovery.c b/board/st/stm32f469-discovery/stm32f469-discovery.c index 4ad4ee69c7c7..742fd67b98e9 100644 --- a/board/st/stm32f469-discovery/stm32f469-discovery.c +++ b/board/st/stm32f469-discovery/stm32f469-discovery.c @@ -9,6 +9,7 @@ #include <env.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <asm/arch/stm32.h> diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 0f728fd9f9e2..40450ca914be 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -17,6 +17,7 @@ #include <splash.h> #include <st_logo_data.h> #include <video.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/armv7m.h> #include <asm/arch/stm32.h> diff --git a/board/st/stm32h743-disco/stm32h743-disco.c b/board/st/stm32h743-disco/stm32h743-disco.c index 0b5afa05ac78..405836aba398 100644 --- a/board/st/stm32h743-disco/stm32h743-disco.c +++ b/board/st/stm32h743-disco/stm32h743-disco.c @@ -8,6 +8,7 @@ #include <dm.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
diff --git a/board/st/stm32h743-eval/stm32h743-eval.c b/board/st/stm32h743-eval/stm32h743-eval.c index 0b5afa05ac78..405836aba398 100644 --- a/board/st/stm32h743-eval/stm32h743-eval.c +++ b/board/st/stm32h743-eval/stm32h743-eval.c @@ -8,6 +8,7 @@ #include <dm.h> #include <init.h> #include <log.h> +#include <asm/global_data.h>
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 78362d24a281..ab85d8ba683d 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -32,6 +32,7 @@ #include <syscon.h> #include <usb.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/stm32.h> diff --git a/board/st/stv0991/stv0991.c b/board/st/stv0991/stv0991.c index 95e203ff0ea4..3b0de82db283 100644 --- a/board/st/stv0991/stv0991.c +++ b/board/st/stv0991/stv0991.c @@ -15,6 +15,7 @@ #include <asm/arch/hardware.h> #include <asm/arch/gpio.h> #include <netdev.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/platform_data/serial_pl01x.h>
diff --git a/board/ste/stemmy/stemmy.c b/board/ste/stemmy/stemmy.c index f7834c08fc2c..b9b2a6fddc2a 100644 --- a/board/ste/stemmy/stemmy.c +++ b/board/ste/stemmy/stemmy.c @@ -4,6 +4,7 @@ */ #include <common.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index e42b61e9068a..c150810d16d7 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -29,6 +29,7 @@ #include <asm/arch/mmc.h> #include <asm/arch/prcm.h> #include <asm/arch/spl.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <u-boot/crc.h> #ifndef CONFIG_ARM64 diff --git a/board/synopsys/axs10x/axs10x.c b/board/synopsys/axs10x/axs10x.c index b4a1d4c5dff6..75e4d037623e 100644 --- a/board/synopsys/axs10x/axs10x.c +++ b/board/synopsys/axs10x/axs10x.c @@ -9,6 +9,7 @@ #include <init.h> #include <malloc.h> #include <asm/arcregs.h> +#include <asm/global_data.h> #include "axs10x.h" #include <asm/cache.h>
diff --git a/board/synopsys/emsdp/emsdp.c b/board/synopsys/emsdp/emsdp.c index 91fa94a638ef..997120ec5e17 100644 --- a/board/synopsys/emsdp/emsdp.c +++ b/board/synopsys/emsdp/emsdp.c @@ -9,6 +9,7 @@ #include <dwmmc.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/bitops.h>
#include <asm/arcregs.h> diff --git a/board/synopsys/hsdk/hsdk.c b/board/synopsys/hsdk/hsdk.c index cd11f9dac06b..892b94bb0836 100644 --- a/board/synopsys/hsdk/hsdk.c +++ b/board/synopsys/hsdk/hsdk.c @@ -14,6 +14,7 @@ #include <irq_func.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/printk.h> diff --git a/board/synopsys/iot_devkit/iot_devkit.c b/board/synopsys/iot_devkit/iot_devkit.c index 497ea186d3a8..c6051363c1f9 100644 --- a/board/synopsys/iot_devkit/iot_devkit.c +++ b/board/synopsys/iot_devkit/iot_devkit.c @@ -8,6 +8,7 @@ #include <init.h> #include <malloc.h> #include <dwmmc.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/libfdt.h> #include <fdtdec.h> diff --git a/board/sysam/amcore/amcore.c b/board/sysam/amcore/amcore.c index 65fc60e2b46d..beab4e9d1884 100644 --- a/board/sysam/amcore/amcore.c +++ b/board/sysam/amcore/amcore.c @@ -9,6 +9,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <asm/io.h> #include <dm.h> diff --git a/board/sysam/stmark2/stmark2.c b/board/sysam/stmark2/stmark2.c index ce8b541ccdf7..d48da48b69d6 100644 --- a/board/sysam/stmark2/stmark2.c +++ b/board/sysam/stmark2/stmark2.c @@ -8,6 +8,7 @@ #include <common.h> #include <init.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/immap.h> #include <mmc.h> diff --git a/board/syteco/zmx25/zmx25.c b/board/syteco/zmx25/zmx25.c index d5393d705976..2d4c5cce8920 100644 --- a/board/syteco/zmx25/zmx25.c +++ b/board/syteco/zmx25/zmx25.c @@ -17,6 +17,7 @@ #include <cpu_func.h> #include <env.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/tbs/tbs2910/tbs2910.c b/board/tbs/tbs2910/tbs2910.c index d32517f998a8..faf73cc218c9 100644 --- a/board/tbs/tbs2910/tbs2910.c +++ b/board/tbs/tbs2910/tbs2910.c @@ -8,6 +8,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/tcl/sl50/board.c b/board/tcl/sl50/board.c index 230481be0de6..4821925c026d 100644 --- a/board/tcl/sl50/board.c +++ b/board/tcl/sl50/board.c @@ -23,6 +23,7 @@ #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/technexion/pico-imx6/pico-imx6.c b/board/technexion/pico-imx6/pico-imx6.c index da82244b3975..6b9c4f4373cc 100644 --- a/board/technexion/pico-imx6/pico-imx6.c +++ b/board/technexion/pico-imx6/pico-imx6.c @@ -6,6 +6,7 @@ * Author: Fabio Estevam festevam@gmail.com */
+#include <common.h> #include <env.h> #include <init.h> #include <net.h> @@ -15,6 +16,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/arch/mxc_hdmi.h> #include <asm/mach-imx/video.h> @@ -22,7 +24,6 @@ #include <asm/io.h> #include <linux/delay.h> #include <linux/sizes.h> -#include <common.h> #include <miiphy.h> #include <netdev.h> #include <phy.h> diff --git a/board/technexion/pico-imx6ul/pico-imx6ul.c b/board/technexion/pico-imx6ul/pico-imx6ul.c index 126823fce099..62a54d0c8eb5 100644 --- a/board/technexion/pico-imx6ul/pico-imx6ul.c +++ b/board/technexion/pico-imx6ul/pico-imx6ul.c @@ -13,6 +13,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/board/technexion/pico-imx7d/pico-imx7d.c b/board/technexion/pico-imx7d/pico-imx7d.c index a6fd49d729c4..2d749dac19a4 100644 --- a/board/technexion/pico-imx7d/pico-imx7d.c +++ b/board/technexion/pico-imx7d/pico-imx7d.c @@ -10,6 +10,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> diff --git a/board/technexion/pico-imx8mq/pico-imx8mq.c b/board/technexion/pico-imx8mq/pico-imx8mq.c index 330de7137c3d..951e3e1985bc 100644 --- a/board/technexion/pico-imx8mq/pico-imx8mq.c +++ b/board/technexion/pico-imx8mq/pico-imx8mq.c @@ -8,6 +8,7 @@ #include <init.h> #include <malloc.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/technexion/pico-imx8mq/spl.c b/board/technexion/pico-imx8mq/spl.c index b181f797a77a..8b853a914e85 100644 --- a/board/technexion/pico-imx8mq/spl.c +++ b/board/technexion/pico-imx8mq/spl.c @@ -11,6 +11,7 @@ #include <asm/arch/ddr.h> #include <asm/arch/imx8mq_pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/gpio.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/technexion/tao3530/tao3530.c b/board/technexion/tao3530/tao3530.c index 84db131de2b8..0c9dca31e67e 100644 --- a/board/technexion/tao3530/tao3530.c +++ b/board/technexion/tao3530/tao3530.c @@ -9,6 +9,7 @@ #include <malloc.h> #include <netdev.h> #include <twl4030.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/mem.h> diff --git a/board/technologic/ts4600/ts4600.c b/board/technologic/ts4600/ts4600.c index 0ef306d58a27..b9cce821d96d 100644 --- a/board/technologic/ts4600/ts4600.c +++ b/board/technologic/ts4600/ts4600.c @@ -15,6 +15,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> diff --git a/board/technologic/ts4800/ts4800.c b/board/technologic/ts4800/ts4800.c index fe36fb7ffab4..a309e58b27fd 100644 --- a/board/technologic/ts4800/ts4800.c +++ b/board/technologic/ts4800/ts4800.c @@ -10,6 +10,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/imx-regs.h> diff --git a/board/theadorable/theadorable.c b/board/theadorable/theadorable.c index 67bc00b65b03..3c4133083f54 100644 --- a/board/theadorable/theadorable.c +++ b/board/theadorable/theadorable.c @@ -13,6 +13,7 @@ #if !defined(CONFIG_SPL_BUILD) #include <bootcount.h> #endif +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/cpu.h> diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 3cc0e4b91c0b..2cd0a1281f9a 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -27,6 +27,7 @@ #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> diff --git a/board/ti/am3517crane/am3517crane.c b/board/ti/am3517crane/am3517crane.c index f32d1757db79..b1017d6c9b76 100644 --- a/board/ti/am3517crane/am3517crane.c +++ b/board/ti/am3517crane/am3517crane.c @@ -11,6 +11,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/mem.h> diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 62ed37cb4889..ac0d79264331 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -10,6 +10,7 @@ #include <common.h> #include <eeprom.h> #include <image.h> +#include <asm/global_data.h> #include <dm/uclass.h> #include <env.h> #include <fdt_support.h> diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 78098755106b..73063faee690 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -20,6 +20,7 @@ #include <serial.h> #include <usb.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/omap_common.h> #include <asm/omap_sec_common.h> #include <asm/emif.h> diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c index 4438f14e4ff1..fbe33cbea551 100644 --- a/board/ti/am65x/evm.c +++ b/board/ti/am65x/evm.c @@ -15,6 +15,7 @@ #include <net.h> #include <asm/arch/sys_proto.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/omap_common.h> diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index 6bd59eb10c2e..888a95849190 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -24,6 +24,7 @@ #include <status_led.h> #endif #include <twl4030.h> +#include <asm/global_data.h> #include <linux/mtd/rawnand.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index ca1976e16a5f..05f251f7782c 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -20,6 +20,7 @@ #include <palmas.h> #include <sata.h> #include <serial.h> +#include <asm/global_data.h> #include <linux/string.h> #include <asm/gpio.h> #include <usb.h> diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index ecbd843676a7..96434b3ba0f4 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -17,6 +17,7 @@ #include <net.h> #include <ns16550.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mem.h> #include <asm/arch/mux.h> diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 44969e80b4d5..b9a9f1955222 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -16,6 +16,7 @@ #include <net.h> #include <asm/arch/sys_proto.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <spl.h> diff --git a/board/ti/ks2_evm/board.c b/board/ti/ks2_evm/board.c index 53bc12791d2b..0c5c2c9146fb 100644 --- a/board/ti/ks2_evm/board.c +++ b/board/ti/ks2_evm/board.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include "board.h" #include <env.h> #include <hang.h> diff --git a/board/ti/omap5_uevm/evm.c b/board/ti/omap5_uevm/evm.c index 88f56edc54ed..4777622156b8 100644 --- a/board/ti/omap5_uevm/evm.c +++ b/board/ti/omap5_uevm/evm.c @@ -15,6 +15,7 @@ #include <serial.h> #include <tca642x.h> #include <usb.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/usb/gadget.h> #include <dwc3-uboot.h> diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index f718e69e85dc..fda8d5f3c838 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -9,6 +9,7 @@ #include <log.h> #include <net.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/mach-types.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h> diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c index 3fd973049a87..4895bfafd80a 100644 --- a/board/ti/sdp4430/sdp.c +++ b/board/ti/sdp4430/sdp.c @@ -12,6 +12,7 @@ #include <serial.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h> +#include <asm/global_data.h>
#include "sdp4430_mux_data.h"
diff --git a/board/ti/ti816x/evm.c b/board/ti/ti816x/evm.c index becece1c2057..2d42af6b809d 100644 --- a/board/ti/ti816x/evm.c +++ b/board/ti/ti816x/evm.c @@ -12,6 +12,7 @@ #include <net.h> #include <spl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/cpu.h> diff --git a/board/timll/devkit3250/devkit3250.c b/board/timll/devkit3250/devkit3250.c index f4eaf15970bb..3c744b943f40 100644 --- a/board/timll/devkit3250/devkit3250.c +++ b/board/timll/devkit3250/devkit3250.c @@ -12,6 +12,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/emc.h> #include <asm/arch/wdt.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index 0731fb764569..0808ca1a54c0 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -22,6 +22,7 @@ #include <malloc.h> #include <ns16550.h> #include <twl4030.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/mux.h> diff --git a/board/toradex/apalis-imx8/apalis-imx8.c b/board/toradex/apalis-imx8/apalis-imx8.c index 2ed66261d286..76faa6e78fd0 100644 --- a/board/toradex/apalis-imx8/apalis-imx8.c +++ b/board/toradex/apalis-imx8/apalis-imx8.c @@ -6,6 +6,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h>
#include <asm/arch/clock.h> #include <asm/arch/imx8-pins.h> diff --git a/board/toradex/apalis-imx8x/apalis-imx8x.c b/board/toradex/apalis-imx8x/apalis-imx8x.c index 739d2e51554d..b6f3bdd7eda7 100644 --- a/board/toradex/apalis-imx8x/apalis-imx8x.c +++ b/board/toradex/apalis-imx8x/apalis-imx8x.c @@ -12,6 +12,7 @@ #include <asm/arch/iomux.h> #include <asm/arch/sci/sci.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <env.h> diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 5ae5274584a4..0c857b599da6 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -12,6 +12,7 @@ #include <image.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h>
diff --git a/board/toradex/apalis_t30/apalis_t30.c b/board/toradex/apalis_t30/apalis_t30.c index f718dc855d4d..0396eea56b55 100644 --- a/board/toradex/apalis_t30/apalis_t30.c +++ b/board/toradex/apalis_t30/apalis_t30.c @@ -11,6 +11,7 @@ #include <asm/arch/pinmux.h> #include <asm/arch-tegra/ap.h> #include <asm/arch-tegra/tegra.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <dm.h> diff --git a/board/toradex/colibri-imx6ull/colibri-imx6ull.c b/board/toradex/colibri-imx6ull/colibri-imx6ull.c index 6ff55ce57b95..01f5561596ea 100644 --- a/board/toradex/colibri-imx6ull/colibri-imx6ull.c +++ b/board/toradex/colibri-imx6ull/colibri-imx6ull.c @@ -4,6 +4,7 @@ */ #include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <asm/arch/clock.h> diff --git a/board/toradex/colibri-imx8x/colibri-imx8x.c b/board/toradex/colibri-imx8x/colibri-imx8x.c index da081e30bec7..562199a51a62 100644 --- a/board/toradex/colibri-imx8x/colibri-imx8x.c +++ b/board/toradex/colibri-imx8x/colibri-imx8x.c @@ -6,6 +6,7 @@ #include <common.h> #include <cpu_func.h> #include <init.h> +#include <asm/global_data.h>
#include <asm/arch/clock.h> #include <asm/arch/imx8-pins.h> diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 57d3e526b4c0..74d59e586a8c 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -12,6 +12,7 @@ #include <env.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h>
diff --git a/board/toradex/colibri_imx7/colibri_imx7.c b/board/toradex/colibri_imx7/colibri_imx7.c index 8afe1bfd5ebb..8f7ef992a7fa 100644 --- a/board/toradex/colibri_imx7/colibri_imx7.c +++ b/board/toradex/colibri_imx7/colibri_imx7.c @@ -12,6 +12,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/board/toradex/colibri_pxa270/colibri_pxa270.c b/board/toradex/colibri_pxa270/colibri_pxa270.c index 645751a37ec8..25fbf4120955 100644 --- a/board/toradex/colibri_pxa270/colibri_pxa270.c +++ b/board/toradex/colibri_pxa270/colibri_pxa270.c @@ -15,6 +15,7 @@ #include <asm/arch/pxa.h> #include <asm/arch/regs-mmc.h> #include <asm/arch/regs-uart.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/platdata.h> #include <dm/platform_data/pxa_mmc_gen.h> diff --git a/board/toradex/colibri_t20/colibri_t20.c b/board/toradex/colibri_t20/colibri_t20.c index f44ca90ce96e..73ef4d2db32c 100644 --- a/board/toradex/colibri_t20/colibri_t20.c +++ b/board/toradex/colibri_t20/colibri_t20.c @@ -12,6 +12,7 @@ #include <asm/arch-tegra/ap.h> #include <asm/arch-tegra/board.h> #include <asm/arch-tegra/tegra.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <i2c.h> diff --git a/board/toradex/colibri_vf/colibri_vf.c b/board/toradex/colibri_vf/colibri_vf.c index 7194ede01cbe..e9c5bc063223 100644 --- a/board/toradex/colibri_vf/colibri_vf.c +++ b/board/toradex/colibri_vf/colibri_vf.c @@ -8,6 +8,7 @@
#include <asm/arch/clock.h> #include <asm/arch/crm_regs.h> diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index adab0a080209..b00467f97685 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include "tdx-cfg-block.h" #include "tdx-eeprom.h"
diff --git a/board/toradex/common/tdx-eeprom.c b/board/toradex/common/tdx-eeprom.c index fbc267dab62f..81bd9e68c2d2 100644 --- a/board/toradex/common/tdx-eeprom.c +++ b/board/toradex/common/tdx-eeprom.c @@ -5,6 +5,7 @@
#include <dm.h> #include <i2c_eeprom.h> +#include <asm/global_data.h> #include <linux/errno.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/toradex/verdin-imx8mm/spl.c b/board/toradex/verdin-imx8mm/spl.c index 72e2e09e256f..97d6a31da150 100644 --- a/board/toradex/verdin-imx8mm/spl.c +++ b/board/toradex/verdin-imx8mm/spl.c @@ -12,6 +12,7 @@ #include <asm/arch/ddr.h> #include <asm/arch/imx8mm_pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/toradex/verdin-imx8mm/verdin-imx8mm.c b/board/toradex/verdin-imx8mm/verdin-imx8mm.c index 7cfae8767cec..76f4a1e209af 100644 --- a/board/toradex/verdin-imx8mm/verdin-imx8mm.c +++ b/board/toradex/verdin-imx8mm/verdin-imx8mm.c @@ -7,6 +7,7 @@ #include <init.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <i2c.h> #include <miiphy.h> diff --git a/board/tqc/tqm834x/tqm834x.c b/board/tqc/tqm834x/tqm834x.c index c16784324c92..17b4662c167f 100644 --- a/board/tqc/tqm834x/tqm834x.c +++ b/board/tqc/tqm834x/tqm834x.c @@ -10,6 +10,7 @@ #include <ioports.h> #include <log.h> #include <mpc83xx.h> +#include <asm/global_data.h> #include <asm/mpc8349_pci.h> #include <i2c.h> #include <miiphy.h> diff --git a/board/tqc/tqma6/tqma6.c b/board/tqc/tqma6/tqma6.c index 2df901a584cb..26d557cece94 100644 --- a/board/tqc/tqma6/tqma6.c +++ b/board/tqc/tqma6/tqma6.c @@ -15,6 +15,7 @@ #include <asm/arch/sys_proto.h> #include <env.h> #include <fdt_support.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/gpio.h> #include <asm/io.h> diff --git a/board/udoo/neo/neo.c b/board/udoo/neo/neo.c index c6edc724405e..653ca1ca5a62 100644 --- a/board/udoo/neo/neo.c +++ b/board/udoo/neo/neo.c @@ -15,6 +15,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <env.h> diff --git a/board/udoo/udoo.c b/board/udoo/udoo.c index 62b32ae7595c..d83f23dd3581 100644 --- a/board/udoo/udoo.c +++ b/board/udoo/udoo.c @@ -13,6 +13,7 @@ #include <env.h> #include <malloc.h> #include <asm/arch/mx6-pins.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/gpio.h> diff --git a/board/variscite/dart_6ul/dart_6ul.c b/board/variscite/dart_6ul/dart_6ul.c index 764aaa8b6b1b..7326daa1798d 100644 --- a/board/variscite/dart_6ul/dart_6ul.c +++ b/board/variscite/dart_6ul/dart_6ul.c @@ -11,6 +11,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> #include <dm.h> diff --git a/board/varisys/cyrus/ddr.c b/board/varisys/cyrus/ddr.c index 7949eb88c07b..184948094db0 100644 --- a/board/varisys/cyrus/ddr.c +++ b/board/varisys/cyrus/ddr.c @@ -8,6 +8,7 @@ #include <hwconfig.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <asm/mmu.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> diff --git a/board/ve8313/ve8313.c b/board/ve8313/ve8313.c index 6cdb11047165..78d401e955eb 100644 --- a/board/ve8313/ve8313.c +++ b/board/ve8313/ve8313.c @@ -11,6 +11,7 @@ #include <common.h> #include <fdt_support.h> #include <init.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <pci.h> diff --git a/board/vscom/baltos/board.c b/board/vscom/baltos/board.c index afe12466df31..4175d414694b 100644 --- a/board/vscom/baltos/board.c +++ b/board/vscom/baltos/board.c @@ -13,6 +13,7 @@ #include <init.h> #include <net.h> #include <serial.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <spl.h> #include <asm/arch/cpu.h> diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index e0e01b1a4a43..53299c87010a 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -17,6 +17,7 @@ #include <asm/arch/mx6-pins.h> #include <asm/arch/mxc_hdmi.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> diff --git a/board/warp/warp.c b/board/warp/warp.c index 85da9c1bd435..0f1d038fabdf 100644 --- a/board/warp/warp.c +++ b/board/warp/warp.c @@ -13,6 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> diff --git a/board/warp7/warp7.c b/board/warp7/warp7.c index aaa7006d3b2d..0f202241dd78 100644 --- a/board/warp7/warp7.c +++ b/board/warp7/warp7.c @@ -10,6 +10,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/hab.h> #include <asm/mach-imx/iomux-v3.h> diff --git a/board/work-microwave/work_92105/work_92105.c b/board/work-microwave/work_92105/work_92105.c index 2e0def5b64f0..bdcecff7308f 100644 --- a/board/work-microwave/work_92105/work_92105.c +++ b/board/work-microwave/work_92105/work_92105.c @@ -8,6 +8,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <asm/arch/cpu.h> diff --git a/board/xen/xenguest_arm64/xenguest_arm64.c b/board/xen/xenguest_arm64/xenguest_arm64.c index 4660f3fff20d..7d0d782a2395 100644 --- a/board/xen/xenguest_arm64/xenguest_arm64.c +++ b/board/xen/xenguest_arm64/xenguest_arm64.c @@ -13,6 +13,7 @@ #include <errno.h> #include <malloc.h> #include <xen.h> +#include <asm/global_data.h>
#include <asm/io.h> #include <asm/armv8/mmu.h> diff --git a/board/xes/xpedite517x/xpedite517x.c b/board/xes/xpedite517x/xpedite517x.c index 2c9499ab20b3..8a5b52c49527 100644 --- a/board/xes/xpedite517x/xpedite517x.c +++ b/board/xes/xpedite517x/xpedite517x.c @@ -5,6 +5,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <fsl_ddr_sdram.h> #include <asm/mmu.h> diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index df19aeadd0b2..4a83d93a85e8 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -7,6 +7,7 @@ #include <common.h> #include <env.h> #include <log.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <dm/uclass.h> #include <i2c.h> diff --git a/board/xilinx/microblaze-generic/microblaze-generic.c b/board/xilinx/microblaze-generic/microblaze-generic.c index d4095c07c1e9..a427ac94a170 100644 --- a/board/xilinx/microblaze-generic/microblaze-generic.c +++ b/board/xilinx/microblaze-generic/microblaze-generic.c @@ -15,6 +15,7 @@ #include <env.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <fdtdec.h> #include <linux/sizes.h> diff --git a/board/xilinx/versal/board.c b/board/xilinx/versal/board.c index 2782a346f07c..c644fe8dc068 100644 --- a/board/xilinx/versal/board.c +++ b/board/xilinx/versal/board.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <time.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 7ac069aaafdf..49ff3f0dc0e9 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -16,6 +16,7 @@ #include <watchdog.h> #include <wdt.h> #include <zynqpl.h> +#include <asm/global_data.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> #include "../common/board.h" diff --git a/board/xilinx/zynq/bootimg.c b/board/xilinx/zynq/bootimg.c index 481f012c282d..2f55078dd768 100644 --- a/board/xilinx/zynq/bootimg.c +++ b/board/xilinx/zynq/bootimg.c @@ -6,6 +6,7 @@ #include <common.h> #include <log.h> #include <part.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> diff --git a/board/xilinx/zynq/cmds.c b/board/xilinx/zynq/cmds.c index 73e2b0eac7e5..6c697caa625b 100644 --- a/board/xilinx/zynq/cmds.c +++ b/board/xilinx/zynq/cmds.c @@ -6,6 +6,7 @@ #include <common.h> #include <command.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 459d9b1e47e1..43e322f71517 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -23,6 +23,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/psu_init_gpl.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/ptrace.h> #include <dm/device.h> diff --git a/board/zyxel/nsa310s/nsa310s.c b/board/zyxel/nsa310s/nsa310s.c index 3f71e3da4461..cd4a7723b120 100644 --- a/board/zyxel/nsa310s/nsa310s.c +++ b/board/zyxel/nsa310s/nsa310s.c @@ -12,6 +12,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> +#include <asm/global_data.h> #include <asm/io.h> #include "nsa310s.h"
diff --git a/cmd/acpi.c b/cmd/acpi.c index a3419b42b556..157261bffbe1 100644 --- a/cmd/acpi.c +++ b/cmd/acpi.c @@ -8,6 +8,7 @@ #include <mapmem.h> #include <acpi/acpi_table.h> #include <asm/acpi_table.h> +#include <asm/global_data.h> #include <dm/acpi.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/cmd/bdinfo.c b/cmd/bdinfo.c index 8d8daa6336af..84dab7d2d33d 100644 --- a/cmd/bdinfo.c +++ b/cmd/bdinfo.c @@ -15,6 +15,7 @@ #include <video.h> #include <vsprintf.h> #include <asm/cache.h> +#include <asm/global_data.h>
diff --git a/cmd/bedbug.c b/cmd/bedbug.c index 684e4a9ea5cf..bef617b6a4f8 100644 --- a/cmd/bedbug.c +++ b/cmd/bedbug.c @@ -6,6 +6,7 @@ #include <cli.h> #include <command.h> #include <console.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/ctype.h> #include <net.h> diff --git a/cmd/bloblist.c b/cmd/bloblist.c index bb2e682ff849..97b57341617c 100644 --- a/cmd/bloblist.c +++ b/cmd/bloblist.c @@ -9,6 +9,7 @@ #include <common.h> #include <bloblist.h> #include <command.h> +#include <asm/global_data.h>
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 81dd8e0284f7..1583a96be14e 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -19,6 +19,7 @@ #include <image.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <linux/libfdt_env.h> #include <mapmem.h> diff --git a/cmd/booti.c b/cmd/booti.c index 76d1255ec584..3df70ea9caaf 100644 --- a/cmd/booti.c +++ b/cmd/booti.c @@ -12,6 +12,7 @@ #include <lmb.h> #include <log.h> #include <mapmem.h> +#include <asm/global_data.h> #include <linux/kernel.h> #include <linux/sizes.h>
diff --git a/cmd/bootm.c b/cmd/bootm.c index e6b0e04413cd..7732b97f635d 100644 --- a/cmd/bootm.c +++ b/cmd/bootm.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <nand.h> #include <asm/byteorder.h> +#include <asm/global_data.h> #include <linux/ctype.h> #include <linux/err.h> #include <u-boot/zlib.h> diff --git a/cmd/date.c b/cmd/date.c index 75a032cd2777..0e1189475313 100644 --- a/cmd/date.c +++ b/cmd/date.c @@ -12,6 +12,7 @@ #include <dm.h> #include <rtc.h> #include <i2c.h> +#include <asm/global_data.h>
diff --git a/cmd/efi.c b/cmd/efi.c index 1558cb17eb0a..f2ed26bd4b23 100644 --- a/cmd/efi.c +++ b/cmd/efi.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <sort.h> +#include <asm/global_data.h>
static const char *const type_name[] = { "reserved", diff --git a/cmd/load.c b/cmd/load.c index f252c748948a..5bbc39baeadd 100644 --- a/cmd/load.c +++ b/cmd/load.c @@ -20,6 +20,7 @@ #include <serial.h> #include <xyzModem.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/delay.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/cmd/log.c b/cmd/log.c index ca1c51e0672e..72380c5691c0 100644 --- a/cmd/log.c +++ b/cmd/log.c @@ -10,6 +10,7 @@ #include <getopt.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h>
static char log_fmt_chars[LOGF_COUNT] = "clFLfm";
diff --git a/cmd/mem.c b/cmd/mem.c index 1d4f2bab2f9a..1eb83b757030 100644 --- a/cmd/mem.c +++ b/cmd/mem.c @@ -22,6 +22,7 @@ #include <mapmem.h> #include <rand.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <linux/compiler.h> diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 5220142b9ab2..ed373a8c4dad 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -75,6 +75,7 @@ #include <env.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <jffs2/load_kernel.h> #include <linux/list.h> #include <linux/ctype.h> diff --git a/cmd/nvedit.c b/cmd/nvedit.c index d0d2eca90472..d14ba10cefaa 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -35,6 +35,7 @@ #include <errno.h> #include <malloc.h> #include <mapmem.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <u-boot/crc.h> #include <watchdog.h> diff --git a/cmd/pstore.c b/cmd/pstore.c index 9a8b38c7f26e..5656bae6d3ef 100644 --- a/cmd/pstore.c +++ b/cmd/pstore.c @@ -5,6 +5,7 @@
#include <config.h> #include <command.h> +#include <fdtdec.h> #include <fs.h> #include <log.h> #include <mapmem.h> diff --git a/cmd/pxe_utils.h b/cmd/pxe_utils.h index 6af952373430..bf58e15347ce 100644 --- a/cmd/pxe_utils.h +++ b/cmd/pxe_utils.h @@ -3,6 +3,8 @@ #ifndef __PXE_UTILS_H #define __PXE_UTILS_H
+#include <linux/list.h> + /* * A note on the pxe file parser. * diff --git a/cmd/sb.c b/cmd/sb.c index f7eb921f43e9..0d55818e3c67 100644 --- a/cmd/sb.c +++ b/cmd/sb.c @@ -8,6 +8,7 @@ #include <command.h> #include <dm.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/state.h>
static int do_sb_handoff(struct cmd_tbl *cmdtp, int flag, int argc, diff --git a/cmd/sound.c b/cmd/sound.c index 7fc19678ea8f..fdcde3653390 100644 --- a/cmd/sound.c +++ b/cmd/sound.c @@ -9,6 +9,7 @@ #include <dm.h> #include <fdtdec.h> #include <sound.h> +#include <asm/global_data.h>
diff --git a/cmd/spl.c b/cmd/spl.c index 28b40dd31e10..472703f8fe15 100644 --- a/cmd/spl.c +++ b/cmd/spl.c @@ -10,6 +10,7 @@ #include <env.h> #include <image.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/cmd/ti/ddr3.c b/cmd/ti/ddr3.c index 623b63b0f94c..6b43a7386832 100644 --- a/cmd/ti/ddr3.c +++ b/cmd/ti/ddr3.c @@ -14,6 +14,7 @@ #include <asm/emif.h> #include <common.h> #include <command.h> +#include <asm/global_data.h>
diff --git a/cmd/tlv_eeprom.c b/cmd/tlv_eeprom.c index eab0531c96b9..5099cbdd95ee 100644 --- a/cmd/tlv_eeprom.c +++ b/cmd/tlv_eeprom.c @@ -17,6 +17,7 @@ #include <env.h> #include <init.h> #include <net.h> +#include <asm/global_data.h> #include <linux/ctype.h> #include <u-boot/crc.h>
diff --git a/cmd/x86/fsp.c b/cmd/x86/fsp.c index 8017eda387c2..82e4415b16eb 100644 --- a/cmd/x86/fsp.c +++ b/cmd/x86/fsp.c @@ -6,6 +6,7 @@ #include <common.h> #include <command.h> #include <asm/fsp/fsp_support.h> +#include <asm/global_data.h>
diff --git a/cmd/x86/hob.c b/cmd/x86/hob.c index 9e555c778c26..01db93eb3e15 100644 --- a/cmd/x86/hob.c +++ b/cmd/x86/hob.c @@ -7,6 +7,7 @@ #include <command.h> #include <efi.h> #include <uuid.h> +#include <asm/global_data.h> #include <asm/hob.h> #include <asm/fsp/fsp_hob.h>
diff --git a/common/autoboot.c b/common/autoboot.c index b025fd99a0bf..0bb08e7a4cf9 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -19,6 +19,7 @@ #include <menu.h> #include <post.h> #include <time.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <u-boot/sha256.h> #include <bootcount.h> diff --git a/common/bloblist.c b/common/bloblist.c index 0e6448becbcf..eab63e9ca518 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -9,6 +9,7 @@ #include <log.h> #include <mapmem.h> #include <spl.h> +#include <asm/global_data.h> #include <u-boot/crc.h>
/* diff --git a/common/board_f.c b/common/board_f.c index 4327a43a33b6..0cddf0359dca 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -49,6 +49,7 @@ #if defined(CONFIG_MP) && defined(CONFIG_PPC) #include <asm/mp.h> #endif +#include <asm/global_data.h> #include <asm/io.h> #include <asm/sections.h> #include <dm/root.h> diff --git a/common/board_info.c b/common/board_info.c index a6db087f9604..b54aa30a9442 100644 --- a/common/board_info.c +++ b/common/board_info.c @@ -2,6 +2,7 @@
#include <common.h> #include <init.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <linux/compiler.h>
diff --git a/common/board_r.c b/common/board_r.c index 9fa4d4b42e5e..9793439adff0 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -21,6 +21,7 @@ #include <log.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <u-boot/crc.h> /* TODO: can we just include all these headers whether needed or not? */ #if defined(CONFIG_CMD_BEDBUG) diff --git a/common/bootm.c b/common/bootm.c index 8298693900d5..defaed8426df 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -19,6 +19,7 @@ #include <mapmem.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/sizes.h> #if defined(CONFIG_CMD_USB) diff --git a/common/bootm_os.c b/common/bootm_os.c index e9aaddf3e615..0b6325db6605 100644 --- a/common/bootm_os.c +++ b/common/bootm_os.c @@ -14,6 +14,7 @@ #include <image.h> #include <lmb.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <malloc.h> #include <mapmem.h> diff --git a/common/bootstage.c b/common/bootstage.c index 5f87358fd854..d5b78b9f4872 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <sort.h> #include <spl.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <linux/libfdt.h>
diff --git a/common/cli.c b/common/cli.c index 6635ab2bcf85..048eacb9ef97 100644 --- a/common/cli.c +++ b/common/cli.c @@ -18,6 +18,7 @@ #include <fdtdec.h> #include <hang.h> #include <malloc.h> +#include <asm/global_data.h>
diff --git a/common/cli_hush.c b/common/cli_hush.c index b7f0f0ff4184..9466651d1a2c 100644 --- a/common/cli_hush.c +++ b/common/cli_hush.c @@ -84,6 +84,7 @@ #include <cli.h> #include <cli_hush.h> #include <command.h> /* find_cmd */ +#include <asm/global_data.h> #endif #ifndef __U_BOOT__ #include <ctype.h> /* isalpha, isdigit */ diff --git a/common/cli_readline.c b/common/cli_readline.c index 5c158d03b4ad..c7614a4c90ff 100644 --- a/common/cli_readline.c +++ b/common/cli_readline.c @@ -14,6 +14,7 @@ #include <command.h> #include <time.h> #include <watchdog.h> +#include <asm/global_data.h>
diff --git a/common/command.c b/common/command.c index 3fe6791edaa2..95af73f17b59 100644 --- a/common/command.c +++ b/common/command.c @@ -14,6 +14,7 @@ #include <console.h> #include <env.h> #include <log.h> +#include <asm/global_data.h> #include <linux/ctype.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/common/console.c b/common/console.c index f3cc45cab548..567273a0ce8b 100644 --- a/common/console.c +++ b/common/console.c @@ -19,6 +19,7 @@ #include <exports.h> #include <env_internal.h> #include <watchdog.h> +#include <asm/global_data.h> #include <linux/delay.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/common/dlmalloc.c b/common/dlmalloc.c index b29a7cfd93d3..cf0270a9c115 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -1,5 +1,6 @@ #include <common.h> #include <log.h> +#include <asm/global_data.h>
#if CONFIG_IS_ENABLED(UNIT_TEST) #define DEBUG diff --git a/common/exports.c b/common/exports.c index 4578f07021f3..20d8b759bc25 100644 --- a/common/exports.c +++ b/common/exports.c @@ -4,6 +4,7 @@ #include <malloc.h> #include <spi.h> #include <i2c.h> +#include <asm/global_data.h>
diff --git a/common/hash.c b/common/hash.c index 05238a8ba91e..fc64002f736a 100644 --- a/common/hash.c +++ b/common/hash.c @@ -18,6 +18,7 @@ #include <mapmem.h> #include <hw_sha.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/errno.h> #include <u-boot/crc.h> diff --git a/common/hwconfig.c b/common/hwconfig.c index daf3eea5f968..26a561c365b7 100644 --- a/common/hwconfig.c +++ b/common/hwconfig.c @@ -15,6 +15,7 @@ #include <exports.h> #include <hwconfig.h> #include <log.h> +#include <asm/global_data.h> #include <linux/types.h> #include <linux/string.h> #else diff --git a/common/image-android.c b/common/image-android.c index 18f7c8db03ba..d07b0e0f09b4 100644 --- a/common/image-android.c +++ b/common/image-android.c @@ -12,6 +12,7 @@ #include <errno.h> #include <asm/unaligned.h> #include <mapmem.h> +#include <linux/libfdt.h>
#define ANDROID_IMAGE_DEFAULT_KERNEL_ADDR 0x10008000
diff --git a/common/image-cipher.c b/common/image-cipher.c index 4ca9eec4ef15..b9061489396c 100644 --- a/common/image-cipher.c +++ b/common/image-cipher.c @@ -9,6 +9,7 @@ #else #include <common.h> #include <malloc.h> +#include <asm/global_data.h> DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSdTCC*/ #include <image.h> diff --git a/common/image-fdt.c b/common/image-fdt.c index 707b44a69d74..0157cce32d58 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -17,6 +17,7 @@ #include <lmb.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <mapmem.h> #include <asm/io.h> diff --git a/common/image-fit-sig.c b/common/image-fit-sig.c index 31cc580941ae..897e04c7a38b 100644 --- a/common/image-fit-sig.c +++ b/common/image-fit-sig.c @@ -10,6 +10,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/ #include <fdt_region.h> diff --git a/common/image-fit.c b/common/image-fit.c index 33210ef3c034..adc3e551de98 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -21,6 +21,7 @@ #include <mapmem.h> #include <asm/io.h> #include <malloc.h> +#include <asm/global_data.h> DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/
diff --git a/common/image-sig.c b/common/image-sig.c index f3c209ae8b72..4abd3c080f78 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -12,6 +12,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/ #include <image.h> diff --git a/common/image.c b/common/image.c index 6923dac7c079..a6500f5f5c7e 100644 --- a/common/image.c +++ b/common/image.c @@ -36,6 +36,7 @@ #include <xilinx.h> #endif
+#include <asm/global_data.h> #include <u-boot/md5.h> #include <u-boot/sha1.h> #include <linux/errno.h> diff --git a/common/init/board_init.c b/common/init/board_init.c index 8c8a5eac0571..3f183ee11326 100644 --- a/common/init/board_init.c +++ b/common/init/board_init.c @@ -9,6 +9,7 @@ #include <common.h> #include <bootstage.h> #include <init.h> +#include <asm/global_data.h>
diff --git a/common/init/handoff.c b/common/init/handoff.c index 62071bd0179d..d0be1bb17a2c 100644 --- a/common/init/handoff.c +++ b/common/init/handoff.c @@ -7,6 +7,7 @@
#include <common.h> #include <handoff.h> +#include <asm/global_data.h>
diff --git a/common/iotrace.c b/common/iotrace.c index 7225ee440418..63d0cca3a004 100644 --- a/common/iotrace.c +++ b/common/iotrace.c @@ -8,6 +8,7 @@ #include <common.h> #include <mapmem.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bug.h> #include <u-boot/crc.h> diff --git a/common/lcd.c b/common/lcd.c index 02f2db3a99e5..ab5614ad0e3d 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -15,6 +15,7 @@ #include <log.h> #include <asm/cache.h> #include <init.h> +#include <asm/global_data.h> #include <linux/types.h> #include <stdio_dev.h> #include <lcd.h> diff --git a/common/lcd_simplefb.c b/common/lcd_simplefb.c index 246eb4c4955c..1650615cdb9f 100644 --- a/common/lcd_simplefb.c +++ b/common/lcd_simplefb.c @@ -10,6 +10,7 @@ #include <dm.h> #include <lcd.h> #include <fdt_support.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <video.h>
diff --git a/common/log.c b/common/log.c index 767f0febc51e..6b0034c3ba2e 100644 --- a/common/log.c +++ b/common/log.c @@ -9,6 +9,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/uclass.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/common/log_console.c b/common/log_console.c index 8776fd470391..6abb13c93b80 100644 --- a/common/log_console.c +++ b/common/log_console.c @@ -8,6 +8,7 @@
diff --git a/common/log_syslog.c b/common/log_syslog.c index 4eb09157bb96..53c4def5d1c0 100644 --- a/common/log_syslog.c +++ b/common/log_syslog.c @@ -8,6 +8,7 @@ #include <common.h> #include <log.h> #include <net.h> +#include <asm/global_data.h>
diff --git a/common/malloc_simple.c b/common/malloc_simple.c index 34f0b4909387..0267fb6bec87 100644 --- a/common/malloc_simple.c +++ b/common/malloc_simple.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <mapmem.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/common/memsize.c b/common/memsize.c index e95c68265ab9..d5d13d51bf1f 100644 --- a/common/memsize.c +++ b/common/memsize.c @@ -6,6 +6,7 @@
diff --git a/common/spl/spl.c b/common/spl/spl.c index cdd7b05f279e..e3d84082f441 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -18,6 +18,7 @@ #include <log.h> #include <serial.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/u-boot.h> #include <nand.h> #include <fat.h> diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index a6ad094e91aa..a2612b45a59d 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -14,6 +14,7 @@ #include <spl.h> #include <sysinfo.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/libfdt.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/common/spl/spl_opensbi.c b/common/spl/spl_opensbi.c index 41e0746bb012..1c0abf8553a8 100644 --- a/common/spl/spl_opensbi.c +++ b/common/spl/spl_opensbi.c @@ -11,6 +11,7 @@ #include <hang.h> #include <image.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/smp.h> #include <opensbi.h> #include <linux/libfdt.h> diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index 2744fb5d520c..6a4e03328709 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -15,6 +15,7 @@ #include <spi_flash.h> #include <errno.h> #include <spl.h> +#include <asm/global_data.h>
diff --git a/common/splash_source.c b/common/splash_source.c index f51ca5ddf37c..2737fc6e7ffa 100644 --- a/common/splash_source.c +++ b/common/splash_source.c @@ -20,6 +20,7 @@ #include <spi_flash.h> #include <splash.h> #include <usb.h> +#include <asm/global_data.h>
diff --git a/common/stdio.c b/common/stdio.c index abf9b1e91588..2b883fddbeae 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -19,7 +19,7 @@ #include <serial.h> #include <splash.h> #include <i2c.h> - +#include <asm/global_data.h> #include <dm/device-internal.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/disk/part_efi.c b/disk/part_efi.c index 7a24e33d189f..e5636ea7e699 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -15,6 +15,7 @@ #include <part.h> #include <uuid.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/unaligned.h> #include <command.h> #include <fdtdec.h> diff --git a/drivers/ata/libata.c b/drivers/ata/libata.c index d41200f6c26c..47e2c5c1cc40 100644 --- a/drivers/ata/libata.c +++ b/drivers/ata/libata.c @@ -5,6 +5,8 @@ * port from the libata of linux kernel */
+#include <common.h> +#include <compiler.h> #include <libata.h>
u64 ata_id_n_sectors(u16 *id) diff --git a/drivers/ata/mtk_ahci.c b/drivers/ata/mtk_ahci.c index 46b7677783fe..554175bc0051 100644 --- a/drivers/ata/mtk_ahci.c +++ b/drivers/ata/mtk_ahci.c @@ -10,6 +10,7 @@
#include <common.h> #include <ahci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <dm/of_access.h> diff --git a/drivers/ata/sata_mv.c b/drivers/ata/sata_mv.c index b78e311fc3bc..1012cb537427 100644 --- a/drivers/ata/sata_mv.c +++ b/drivers/ata/sata_mv.c @@ -38,6 +38,7 @@ #include <dm.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <fis.h> diff --git a/drivers/bios_emulator/atibios.c b/drivers/bios_emulator/atibios.c index 9c7f14e98f47..6c7cc24cbd92 100644 --- a/drivers/bios_emulator/atibios.c +++ b/drivers/bios_emulator/atibios.c @@ -46,6 +46,7 @@ * BIOS in u-boot. ****************************************************************************/ #include <common.h> +#include <compiler.h> #include <bios_emul.h> #include <errno.h> #include <log.h> diff --git a/drivers/block/blkcache.c b/drivers/block/blkcache.c index eca66198edf7..b53420a3a88c 100644 --- a/drivers/block/blkcache.c +++ b/drivers/block/blkcache.c @@ -9,6 +9,7 @@ #include <log.h> #include <malloc.h> #include <part.h> +#include <asm/global_data.h> #include <linux/ctype.h> #include <linux/list.h>
diff --git a/drivers/block/sandbox.c b/drivers/block/sandbox.c index f57f690d3c06..9d7d68c007f6 100644 --- a/drivers/block/sandbox.c +++ b/drivers/block/sandbox.c @@ -11,6 +11,7 @@ #include <os.h> #include <malloc.h> #include <sandboxblockdev.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/errno.h> #include <dm/device-internal.h> diff --git a/drivers/bootcount/bootcount_ram.c b/drivers/bootcount/bootcount_ram.c index 078c84d5ecab..8cc30cf40eff 100644 --- a/drivers/bootcount/bootcount_ram.c +++ b/drivers/bootcount/bootcount_ram.c @@ -7,6 +7,7 @@ #include <common.h> #include <cpu_func.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/cache/cache-v5l2.c b/drivers/cache/cache-v5l2.c index cb9ebbb4f9cb..2c7983d0ceaf 100644 --- a/drivers/cache/cache-v5l2.c +++ b/drivers/cache/cache-v5l2.c @@ -9,6 +9,7 @@ #include <cache.h> #include <dm.h> #include <hang.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/ofnode.h> #include <linux/bitops.h> diff --git a/drivers/cache/sandbox_cache.c b/drivers/cache/sandbox_cache.c index 9050c4cf3406..0fb767e43399 100644 --- a/drivers/cache/sandbox_cache.c +++ b/drivers/cache/sandbox_cache.c @@ -7,6 +7,7 @@ #include <cache.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h>
diff --git a/drivers/clk/altera/clk-agilex.c b/drivers/clk/altera/clk-agilex.c index bac1d98e1975..cca6d6741221 100644 --- a/drivers/clk/altera/clk-agilex.c +++ b/drivers/clk/altera/clk-agilex.c @@ -5,6 +5,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk-uclass.h> #include <dm.h> diff --git a/drivers/clk/altera/clk-arria10.c b/drivers/clk/altera/clk-arria10.c index 1812152d56f8..578597a16e81 100644 --- a/drivers/clk/altera/clk-arria10.c +++ b/drivers/clk/altera/clk-arria10.c @@ -13,6 +13,7 @@ #include <dm/lists.h> #include <dm/util.h> #include <linux/bitops.h> +#include <asm/global_data.h>
#include <asm/arch/clock_manager.h>
diff --git a/drivers/clk/aspeed/clk_ast2500.c b/drivers/clk/aspeed/clk_ast2500.c index a0906716250a..97f00f505dd4 100644 --- a/drivers/clk/aspeed/clk_ast2500.c +++ b/drivers/clk/aspeed/clk_ast2500.c @@ -7,6 +7,7 @@ #include <clk-uclass.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/scu_ast2500.h> #include <dm/lists.h> diff --git a/drivers/clk/aspeed/clk_ast2600.c b/drivers/clk/aspeed/clk_ast2600.c index f72d384047f3..acb7eca74144 100644 --- a/drivers/clk/aspeed/clk_ast2600.c +++ b/drivers/clk/aspeed/clk_ast2600.c @@ -10,6 +10,7 @@ #include <dm/lists.h> #include <linux/delay.h> #include <asm/arch/scu_ast2600.h> +#include <asm/global_data.h> #include <dt-bindings/clock/ast2600-clock.h> #include <dt-bindings/reset/ast2600-reset.h>
diff --git a/drivers/clk/at91/compat.c b/drivers/clk/at91/compat.c index e514f26656e2..ba288cab9dc4 100644 --- a/drivers/clk/at91/compat.c +++ b/drivers/clk/at91/compat.c @@ -9,6 +9,7 @@ #include <common.h> #include <clk-uclass.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/lists.h> #include <dm/util.h> diff --git a/drivers/clk/at91/pmc.c b/drivers/clk/at91/pmc.c index 660e23192149..1fa42d728b59 100644 --- a/drivers/clk/at91/pmc.c +++ b/drivers/clk/at91/pmc.c @@ -4,10 +4,9 @@ * Wenyou.Yang wenyou.yang@atmel.com */
+#include <common.h> #include <asm/io.h> #include <clk-uclass.h> -#include <common.h> - #include "pmc.h"
static int at91_clk_of_xlate(struct clk *clk, struct ofnode_phandle_args *args) diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index d5c4e3cbe510..b87288da7a2a 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -20,6 +20,7 @@ #include <linux/bug.h> #include <linux/clk-provider.h> #include <linux/err.h> +#include <asm/global_data.h>
static inline const struct clk_ops *clk_dev_ops(struct udevice *dev) { diff --git a/drivers/clk/clk_octeon.c b/drivers/clk/clk_octeon.c index ce274549da00..fa50265184f0 100644 --- a/drivers/clk/clk_octeon.c +++ b/drivers/clk/clk_octeon.c @@ -5,6 +5,7 @@
#include <clk-uclass.h> #include <dm.h> +#include <asm/global_data.h> #include <dt-bindings/clock/octeon-clock.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/clk/clk_pic32.c b/drivers/clk/clk_pic32.c index 5a10d4640d7f..ef06a7fb9f6c 100644 --- a/drivers/clk/clk_pic32.c +++ b/drivers/clk/clk_pic32.c @@ -10,6 +10,7 @@ #include <div64.h> #include <time.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <asm/io.h> #include <linux/bitops.h> diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index d4f10485919f..0df87e7bf446 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -17,6 +17,7 @@ #include <time.h> #include <vsprintf.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dt-bindings/clock/stm32mp1-clks.h> #include <dt-bindings/clock/stm32mp1-clksrc.h> diff --git a/drivers/clk/clk_zynq.c b/drivers/clk/clk_zynq.c index bf32d8317ab2..3e3320900d56 100644 --- a/drivers/clk/clk_zynq.c +++ b/drivers/clk/clk_zynq.c @@ -11,6 +11,7 @@ #include <clk-uclass.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/lists.h> #include <errno.h> diff --git a/drivers/clk/mpc83xx_clk.c b/drivers/clk/mpc83xx_clk.c index c5ced1f132cf..0255ccaf8a48 100644 --- a/drivers/clk/mpc83xx_clk.c +++ b/drivers/clk/mpc83xx_clk.c @@ -11,6 +11,7 @@ #include <dm.h> #include <log.h> #include <vsprintf.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dt-bindings/clk/mpc83xx-clk.h> #include <asm/arch/soc.h> diff --git a/drivers/clk/renesas/clk-rcar-gen2.c b/drivers/clk/renesas/clk-rcar-gen2.c index 16da10c8dd88..b423c9414b2e 100644 --- a/drivers/clk/renesas/clk-rcar-gen2.c +++ b/drivers/clk/renesas/clk-rcar-gen2.c @@ -15,6 +15,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h>
#include <dt-bindings/clock/renesas-cpg-mssr.h> diff --git a/drivers/clk/renesas/clk-rcar-gen3.c b/drivers/clk/renesas/clk-rcar-gen3.c index 30a101fe8621..3223becd753b 100644 --- a/drivers/clk/renesas/clk-rcar-gen3.c +++ b/drivers/clk/renesas/clk-rcar-gen3.c @@ -16,6 +16,7 @@ #include <errno.h> #include <log.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/clk/rockchip/clk_px30.c b/drivers/clk/rockchip/clk_px30.c index a2a5939d4b12..6b746f4c658b 100644 --- a/drivers/clk/rockchip/clk_px30.c +++ b/drivers/clk/rockchip/clk_px30.c @@ -14,6 +14,7 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_px30.h> #include <asm/arch-rockchip/hardware.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device-internal.h> #include <dm/lists.h> diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index 6226d55658ea..221a5bd400f6 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <mapmem.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru.h> diff --git a/drivers/clk/rockchip/clk_rk3308.c b/drivers/clk/rockchip/clk_rk3308.c index a05efcfbabaf..5a838b9e9a58 100644 --- a/drivers/clk/rockchip/clk_rk3308.c +++ b/drivers/clk/rockchip/clk_rk3308.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cru_rk3308.h> #include <asm/arch-rockchip/clock.h> diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 55ebac7057d1..f8cbda44551e 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -18,6 +18,7 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru.h> #include <asm/arch-rockchip/hardware.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dt-bindings/clock/rk3399-cru.h> diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index 1e22db0cb71d..555155b16da6 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -12,6 +12,7 @@ #include <log.h> #include <malloc.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_rv1108.h> diff --git a/drivers/clk/ti/clk.c b/drivers/clk/ti/clk.c index e44b90ad6abe..c999df213a81 100644 --- a/drivers/clk/ti/clk.c +++ b/drivers/clk/ti/clk.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <fdtdec.h> #include <asm/io.h> #include "clk.h"
diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index 7e8f3afb2d60..da1509b043ad 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -18,6 +18,7 @@ #include <dm/uclass-internal.h> #include <dm/util.h> #include <power-domain.h> +#include <asm/global_data.h>
int device_chld_unbind(struct udevice *dev, struct driver *drv) { diff --git a/drivers/core/device.c b/drivers/core/device.c index 8629df8defb8..82a00989604a 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -11,6 +11,7 @@ #include <common.h> #include <cpu_func.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk.h> #include <fdtdec.h> diff --git a/drivers/core/fdtaddr.c b/drivers/core/fdtaddr.c index ed55f69de124..83a50b6a3a7c 100644 --- a/drivers/core/fdtaddr.c +++ b/drivers/core/fdtaddr.c @@ -12,6 +12,7 @@ #include <dm.h> #include <fdt_support.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device-internal.h>
diff --git a/drivers/core/of_access.c b/drivers/core/of_access.c index 0a12e9b26f89..9960e6b310b8 100644 --- a/drivers/core/of_access.c +++ b/drivers/core/of_access.c @@ -22,6 +22,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/bug.h> #include <linux/libfdt.h> #include <dm/of_access.h> diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 7a5f4c0a73da..26c9d0405645 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -16,6 +16,7 @@ #include <dm/ofnode.h> #include <linux/err.h> #include <linux/ioport.h> +#include <asm/global_data.h>
int ofnode_read_u32(ofnode node, const char *propname, u32 *outp) { diff --git a/drivers/core/read.c b/drivers/core/read.c index 4d9b5dd03842..14fd1214d623 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -8,6 +8,7 @@ #include <dm.h> #include <dm/of_access.h> #include <mapmem.h> +#include <asm/global_data.h> #include <asm/types.h> #include <asm/io.h> #include <linux/ioport.h> diff --git a/drivers/core/regmap.c b/drivers/core/regmap.c index 4baacabd0156..b51ce108c143 100644 --- a/drivers/core/regmap.c +++ b/drivers/core/regmap.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <malloc.h> #include <mapmem.h> diff --git a/drivers/core/root.c b/drivers/core/root.c index 2bfa75b47250..26dd79dcffd3 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <dm/acpi.h> #include <dm/device.h> diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index f38122d54b56..1a4ea7a57a69 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -13,6 +13,7 @@ #include <errno.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/device-internal.h> #include <dm/lists.h> diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index 1d1e49efea9b..abddbef57b89 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -7,6 +7,7 @@ #include <cpu.h> #include <dm.h> #include <thermal.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/arch/sci/sci.h> #include <asm/arch/sys_proto.h> diff --git a/drivers/cpu/riscv_cpu.c b/drivers/cpu/riscv_cpu.c index 0b10c173a3ec..b30dceba37c5 100644 --- a/drivers/cpu/riscv_cpu.c +++ b/drivers/cpu/riscv_cpu.c @@ -10,6 +10,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <linux/bitops.h> diff --git a/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c b/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c index e91fe644580b..f5ae35e13254 100644 --- a/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c +++ b/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <u-boot/rsa-mod-exp.h> #include <errno.h> #include <fdtdec.h> diff --git a/drivers/ddr/altera/sdram_agilex.c b/drivers/ddr/altera/sdram_agilex.c index a4ceb36461dc..65ecdd022c43 100644 --- a/drivers/ddr/altera/sdram_agilex.c +++ b/drivers/ddr/altera/sdram_agilex.c @@ -13,6 +13,7 @@ #include <log.h> #include <ram.h> #include <reset.h> +#include <asm/global_data.h> #include "sdram_soc64.h" #include <wait_bit.h> #include <asm/arch/firewall.h> diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index 3c58f59f3ab6..4a8f8dea1c4d 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -13,6 +13,7 @@ #include <wait_bit.h> #include <watchdog.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/fpga_manager.h> #include <asm/arch/misc.h> diff --git a/drivers/ddr/altera/sdram_s10.c b/drivers/ddr/altera/sdram_s10.c index 03a270f2639b..3caa2e14f946 100644 --- a/drivers/ddr/altera/sdram_s10.c +++ b/drivers/ddr/altera/sdram_s10.c @@ -15,6 +15,7 @@ #include <log.h> #include <ram.h> #include <reset.h> +#include <asm/global_data.h> #include "sdram_s10.h" #include <wait_bit.h> #include <asm/arch/firewall.h> diff --git a/drivers/ddr/altera/sdram_soc64.c b/drivers/ddr/altera/sdram_soc64.c index 5aba655e5f1f..a08f0953e554 100644 --- a/drivers/ddr/altera/sdram_soc64.c +++ b/drivers/ddr/altera/sdram_soc64.c @@ -21,6 +21,7 @@ #include <asm/arch/system_manager.h> #include <asm/arch/reset_manager.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <linux/sizes.h> diff --git a/drivers/ddr/imx/imx8m/helper.c b/drivers/ddr/imx/imx8m/helper.c index 5ebf54f5f4af..f23904bf7124 100644 --- a/drivers/ddr/imx/imx8m/helper.c +++ b/drivers/ddr/imx/imx8m/helper.c @@ -6,6 +6,7 @@ #include <common.h> #include <log.h> #include <spl.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <asm/io.h> diff --git a/drivers/demo/demo-shape.c b/drivers/demo/demo-shape.c index 8129317ba1bc..b6b29bcb31b3 100644 --- a/drivers/demo/demo-shape.c +++ b/drivers/demo/demo-shape.c @@ -10,6 +10,7 @@ #include <log.h> #include <malloc.h> #include <dm-demo.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h>
diff --git a/drivers/demo/demo-uclass.c b/drivers/demo/demo-uclass.c index a020ecb24fa4..815f8de6453b 100644 --- a/drivers/demo/demo-uclass.c +++ b/drivers/demo/demo-uclass.c @@ -13,6 +13,7 @@ #include <fdtdec.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/list.h>
diff --git a/drivers/fpga/socfpga_arria10.c b/drivers/fpga/socfpga_arria10.c index 44e1ac54c3f1..4bea7fd900d8 100644 --- a/drivers/fpga/socfpga_arria10.c +++ b/drivers/fpga/socfpga_arria10.c @@ -4,6 +4,7 @@ */ #include <image.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/fpga_manager.h> #include <asm/arch/reset_manager.h> diff --git a/drivers/fpga/zynqmppl.c b/drivers/fpga/zynqmppl.c index 8ce140a2e1ab..6b394869dbf6 100644 --- a/drivers/fpga/zynqmppl.c +++ b/drivers/fpga/zynqmppl.c @@ -7,6 +7,7 @@
#include <console.h> #include <common.h> +#include <compiler.h> #include <cpu_func.h> #include <log.h> #include <zynqmppl.h> diff --git a/drivers/gpio/74x164_gpio.c b/drivers/gpio/74x164_gpio.c index 0c06301a81cb..7a7cfe86114b 100644 --- a/drivers/gpio/74x164_gpio.c +++ b/drivers/gpio/74x164_gpio.c @@ -13,6 +13,7 @@ #include <dm.h> #include <fdtdec.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <dm/device_compat.h> diff --git a/drivers/gpio/altera_pio.c b/drivers/gpio/altera_pio.c index f4582b1467ce..edc5a8093b0c 100644 --- a/drivers/gpio/altera_pio.c +++ b/drivers/gpio/altera_pio.c @@ -9,6 +9,7 @@ #include <errno.h> #include <malloc.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h>
diff --git a/drivers/gpio/atmel_pio4.c b/drivers/gpio/atmel_pio4.c index e7b8f231ccf4..f615fce32e1f 100644 --- a/drivers/gpio/atmel_pio4.c +++ b/drivers/gpio/atmel_pio4.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <malloc.h> #include <asm/arch/hardware.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/bitops.h> #include <mach/gpio.h> diff --git a/drivers/gpio/da8xx_gpio.c b/drivers/gpio/da8xx_gpio.c index 9a52a5e414f5..d106e9846dfb 100644 --- a/drivers/gpio/da8xx_gpio.c +++ b/drivers/gpio/da8xx_gpio.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <malloc.h> #include <asm/io.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <dt-bindings/gpio/gpio.h>
diff --git a/drivers/gpio/gpio-rcar.c b/drivers/gpio/gpio-rcar.c index beae34f233ab..daaac5e78442 100644 --- a/drivers/gpio/gpio-rcar.c +++ b/drivers/gpio/gpio-rcar.c @@ -7,6 +7,7 @@ #include <clk.h> #include <dm.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/pinctrl.h> #include <errno.h> diff --git a/drivers/gpio/gpio-rza1.c b/drivers/gpio/gpio-rza1.c index ee7de4c17e91..f14be871e8d0 100644 --- a/drivers/gpio/gpio-rza1.c +++ b/drivers/gpio/gpio-rza1.c @@ -7,6 +7,7 @@ #include <clk.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <linux/bitops.h> diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index bad6b71e0c38..4a9b74e1ca1a 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -16,6 +16,7 @@ #include <fdtdec.h> #include <malloc.h> #include <acpi/acpi_device.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <dm/device_compat.h> #include <linux/bug.h> diff --git a/drivers/gpio/intel_broadwell_gpio.c b/drivers/gpio/intel_broadwell_gpio.c index 68d72eedc5a7..20af35de2cf5 100644 --- a/drivers/gpio/intel_broadwell_gpio.c +++ b/drivers/gpio/intel_broadwell_gpio.c @@ -12,6 +12,7 @@ #include <pci.h> #include <syscon.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/pci.h> diff --git a/drivers/gpio/intel_ich6_gpio.c b/drivers/gpio/intel_ich6_gpio.c index 11d4be04f562..63a07b9592a0 100644 --- a/drivers/gpio/intel_ich6_gpio.c +++ b/drivers/gpio/intel_ich6_gpio.c @@ -34,6 +34,7 @@ #include <pch.h> #include <pci.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/pci.h> diff --git a/drivers/gpio/msm_gpio.c b/drivers/gpio/msm_gpio.c index af6c8383aa67..e1ff84c1c03d 100644 --- a/drivers/gpio/msm_gpio.c +++ b/drivers/gpio/msm_gpio.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h>
diff --git a/drivers/gpio/mxs_gpio.c b/drivers/gpio/mxs_gpio.c index 4b2b18fdb538..5775a22abd43 100644 --- a/drivers/gpio/mxs_gpio.c +++ b/drivers/gpio/mxs_gpio.c @@ -9,6 +9,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/drivers/gpio/nx_gpio.c b/drivers/gpio/nx_gpio.c index 52851e58b69f..e2565d709535 100644 --- a/drivers/gpio/nx_gpio.c +++ b/drivers/gpio/nx_gpio.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h>
diff --git a/drivers/gpio/omap_gpio.c b/drivers/gpio/omap_gpio.c index 336ece47785b..316a28efa6bb 100644 --- a/drivers/gpio/omap_gpio.c +++ b/drivers/gpio/omap_gpio.c @@ -20,6 +20,7 @@ #include <common.h> #include <dm.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <dm/device-internal.h> diff --git a/drivers/gpio/pcf8575_gpio.c b/drivers/gpio/pcf8575_gpio.c index 6d38646ef66a..359646266c93 100644 --- a/drivers/gpio/pcf8575_gpio.c +++ b/drivers/gpio/pcf8575_gpio.c @@ -28,6 +28,7 @@ #include <i2c.h> #include <log.h> #include <asm-generic/gpio.h> +#include <asm/global_data.h> #include <linux/bitops.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/gpio/pic32_gpio.c b/drivers/gpio/pic32_gpio.c index 253a9ba2f84c..975a2af3ccb8 100644 --- a/drivers/gpio/pic32_gpio.c +++ b/drivers/gpio/pic32_gpio.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <linux/bitops.h> diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index 796fe3e11043..76f35ac5d925 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <dm/device-internal.h> diff --git a/drivers/gpio/vybrid_gpio.c b/drivers/gpio/vybrid_gpio.c index fcce90c53c26..339392dcd35a 100644 --- a/drivers/gpio/vybrid_gpio.c +++ b/drivers/gpio/vybrid_gpio.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> diff --git a/drivers/hwspinlock/hwspinlock-uclass.c b/drivers/hwspinlock/hwspinlock-uclass.c index 9da79455ed3c..8997243421c0 100644 --- a/drivers/hwspinlock/hwspinlock-uclass.c +++ b/drivers/hwspinlock/hwspinlock-uclass.c @@ -11,6 +11,7 @@ #include <dm/device-internal.h> #include <dm/device_compat.h> #include <linux/compat.h> +#include <asm/global_data.h>
static inline const struct hwspinlock_ops * hwspinlock_dev_ops(struct udevice *dev) diff --git a/drivers/i2c/at91_i2c.c b/drivers/i2c/at91_i2c.c index 3eb6db4878d1..aca8de943690 100644 --- a/drivers/i2c/at91_i2c.c +++ b/drivers/i2c/at91_i2c.c @@ -6,6 +6,7 @@ */
#include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <clk.h> diff --git a/drivers/i2c/cros_ec_tunnel.c b/drivers/i2c/cros_ec_tunnel.c index 970b91cfd30c..75828b6e7c27 100644 --- a/drivers/i2c/cros_ec_tunnel.c +++ b/drivers/i2c/cros_ec_tunnel.c @@ -9,6 +9,7 @@ #include <cros_ec.h> #include <errno.h> #include <i2c.h> +#include <asm/global_data.h>
diff --git a/drivers/i2c/exynos_hs_i2c.c b/drivers/i2c/exynos_hs_i2c.c index 879ddc67b692..39bcacc17a7e 100644 --- a/drivers/i2c/exynos_hs_i2c.c +++ b/drivers/i2c/exynos_hs_i2c.c @@ -13,6 +13,7 @@ #include <asm/arch/clk.h> #include <asm/arch/cpu.h> #include <asm/arch/pinmux.h> +#include <asm/global_data.h> #include <linux/delay.h> #include "s3c24x0_i2c.h"
diff --git a/drivers/i2c/fsl_i2c.c b/drivers/i2c/fsl_i2c.c index 875d30762e3b..528357596860 100644 --- a/drivers/i2c/fsl_i2c.c +++ b/drivers/i2c/fsl_i2c.c @@ -11,6 +11,7 @@ #include <i2c.h> /* Functional interface */ #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/fsl_i2c.h> /* HW definitions */ #include <clk.h> diff --git a/drivers/i2c/i2c_core.c b/drivers/i2c/i2c_core.c index da50d86cc8b4..85cf75ecd922 100644 --- a/drivers/i2c/i2c_core.c +++ b/drivers/i2c/i2c_core.c @@ -10,6 +10,7 @@ #include <common.h> #include <i2c.h> #include <linker_lists.h> +#include <asm/global_data.h>
struct i2c_adapter *i2c_get_adapter(int index) { diff --git a/drivers/i2c/ihs_i2c.c b/drivers/i2c/ihs_i2c.c index f91a96a3aa31..ba7817478c3a 100644 --- a/drivers/i2c/ihs_i2c.c +++ b/drivers/i2c/ihs_i2c.c @@ -13,6 +13,7 @@ #include <gdsys_fpga.h> #endif #include <log.h> +#include <asm/global_data.h> #include <asm/unaligned.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/i2c/iproc_i2c.c b/drivers/i2c/iproc_i2c.c index 83301bbf1b33..d975e782649a 100644 --- a/drivers/i2c/iproc_i2c.c +++ b/drivers/i2c/iproc_i2c.c @@ -4,6 +4,7 @@ * */
+#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <config.h> diff --git a/drivers/i2c/muxes/i2c-arb-gpio-challenge.c b/drivers/i2c/muxes/i2c-arb-gpio-challenge.c index 928e02b7af17..ad730e0e79ff 100644 --- a/drivers/i2c/muxes/i2c-arb-gpio-challenge.c +++ b/drivers/i2c/muxes/i2c-arb-gpio-challenge.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/delay.h>
diff --git a/drivers/i2c/muxes/i2c-mux-gpio.c b/drivers/i2c/muxes/i2c-mux-gpio.c index 8d6e208a0b86..4ca206115f85 100644 --- a/drivers/i2c/muxes/i2c-mux-gpio.c +++ b/drivers/i2c/muxes/i2c-mux-gpio.c @@ -7,6 +7,7 @@ * Peng Fan peng.fan@nxp.com */
+#include <asm/global_data.h> #include <asm/io.h> #include <asm-generic/gpio.h> #include <common.h> diff --git a/drivers/i2c/muxes/pca954x.c b/drivers/i2c/muxes/pca954x.c index d21a84c4fa88..55858cf653f2 100644 --- a/drivers/i2c/muxes/pca954x.c +++ b/drivers/i2c/muxes/pca954x.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h>
diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index 37b1a06ee032..5df69f145980 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -10,6 +10,7 @@ #include <common.h> #include <i2c.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/errno.h> #include <asm/io.h> diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 0362ec676327..3c91515bffb3 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -18,6 +18,7 @@ #include <log.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/delay.h> #include <linux/errno.h> diff --git a/drivers/i2c/nx_i2c.c b/drivers/i2c/nx_i2c.c index c63a73255769..07cda0fa6793 100644 --- a/drivers/i2c/nx_i2c.c +++ b/drivers/i2c/nx_i2c.c @@ -7,6 +7,7 @@ #include <asm/arch/reset.h> #include <asm/arch/clk.h> #include <asm/arch/nx_gpio.h> +#include <asm/global_data.h> #include <linux/delay.h>
#define I2C_WRITE 0 diff --git a/drivers/i2c/ocores_i2c.c b/drivers/i2c/ocores_i2c.c index 48ed1d5bffb8..088ba9a6a3cd 100644 --- a/drivers/i2c/ocores_i2c.c +++ b/drivers/i2c/ocores_i2c.c @@ -13,6 +13,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk.h> #include <dm.h> diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index 0c8915605dbc..56f0f69885e4 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -16,6 +16,7 @@ #else #include <asm/arch/s3c24x0_cpu.h> #endif +#include <asm/global_data.h> #include <asm/io.h> #include <i2c.h> #include "s3c24x0_i2c.h" diff --git a/drivers/i2c/sh_i2c.c b/drivers/i2c/sh_i2c.c index f857307e6a4f..26a87006698e 100644 --- a/drivers/i2c/sh_i2c.c +++ b/drivers/i2c/sh_i2c.c @@ -10,6 +10,7 @@ #include <common.h> #include <i2c.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index 1031066b8c41..db69c18cb6de 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -25,6 +25,7 @@ #endif #endif #include <i2c.h> +#include <asm/global_data.h> #include <linux/delay.h>
#if defined(CONFIG_SOFT_I2C_GPIO_SCL) diff --git a/drivers/i2c/tegra186_bpmp_i2c.c b/drivers/i2c/tegra186_bpmp_i2c.c index 88e4e9a5c9dd..588f6bdcc4b4 100644 --- a/drivers/i2c/tegra186_bpmp_i2c.c +++ b/drivers/i2c/tegra186_bpmp_i2c.c @@ -9,6 +9,7 @@ #include <log.h> #include <misc.h> #include <asm/arch-tegra/bpmp_abi.h> +#include <asm/global_data.h> #include <linux/bitops.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/input/i8042.c b/drivers/input/i8042.c index 1ea11fd67b44..565d99e7e57f 100644 --- a/drivers/input/i8042.c +++ b/drivers/input/i8042.c @@ -14,6 +14,7 @@ #include <input.h> #include <keyboard.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/drivers/mailbox/k3-sec-proxy.c b/drivers/mailbox/k3-sec-proxy.c index 8dd93a3e11e9..ff21a08388a9 100644 --- a/drivers/mailbox/k3-sec-proxy.c +++ b/drivers/mailbox/k3-sec-proxy.c @@ -9,6 +9,7 @@ #include <common.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <linux/types.h> diff --git a/drivers/misc/atsha204a-i2c.c b/drivers/misc/atsha204a-i2c.c index 90f9cd246a04..af65c559dc69 100644 --- a/drivers/misc/atsha204a-i2c.c +++ b/drivers/misc/atsha204a-i2c.c @@ -16,6 +16,7 @@ #include <errno.h> #include <atsha204a-i2c.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <u-boot/crc.h>
diff --git a/drivers/misc/fs_loader.c b/drivers/misc/fs_loader.c index f460b1a64c8a..e77b3af770e5 100644 --- a/drivers/misc/fs_loader.c +++ b/drivers/misc/fs_loader.c @@ -11,6 +11,7 @@ #include <fs.h> #include <fs_loader.h> #include <log.h> +#include <asm/global_data.h> #include <linux/string.h> #include <mapmem.h> #include <malloc.h> diff --git a/drivers/misc/imx8/fuse.c b/drivers/misc/imx8/fuse.c index be181229370e..38111c525485 100644 --- a/drivers/misc/imx8/fuse.c +++ b/drivers/misc/imx8/fuse.c @@ -9,6 +9,7 @@ #include <fuse.h> #include <asm/arch/sci/sci.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <linux/arm-smccc.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/misc/imx8/scu.c b/drivers/misc/imx8/scu.c index 72a347326376..035a600f71cf 100644 --- a/drivers/misc/imx8/scu.c +++ b/drivers/misc/imx8/scu.c @@ -7,6 +7,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <dm/lists.h> diff --git a/drivers/misc/imx8/scu_api.c b/drivers/misc/imx8/scu_api.c index 20b74fbb18d1..27ecce710fcb 100644 --- a/drivers/misc/imx8/scu_api.c +++ b/drivers/misc/imx8/scu_api.c @@ -8,6 +8,7 @@ #include <common.h> #include <hang.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <asm/arch/sci/sci.h> diff --git a/drivers/misc/tegra186_bpmp.c b/drivers/misc/tegra186_bpmp.c index f2366d6592db..dbee7f77db3f 100644 --- a/drivers/misc/tegra186_bpmp.c +++ b/drivers/misc/tegra186_bpmp.c @@ -8,6 +8,7 @@ #include <log.h> #include <malloc.h> #include <time.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/root.h> #include <mailbox.h> diff --git a/drivers/misc/test_drv.c b/drivers/misc/test_drv.c index 7dd3de34c999..827a50e954f7 100644 --- a/drivers/misc/test_drv.c +++ b/drivers/misc/test_drv.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <dm/test.h> +#include <asm/global_data.h>
/* Records the last testbus device that was removed */ static struct udevice *testbus_removed; diff --git a/drivers/mmc/atmel_sdhci.c b/drivers/mmc/atmel_sdhci.c index d7dbc23fd0b6..2b5ceeab94b5 100644 --- a/drivers/mmc/atmel_sdhci.c +++ b/drivers/mmc/atmel_sdhci.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <sdhci.h> #include <asm/arch/clk.h> +#include <asm/global_data.h>
#define ATMEL_SDHC_MIN_FREQ 400000 #define ATMEL_SDHC_GCK_RATE 240000000 diff --git a/drivers/mmc/ca_dw_mmc.c b/drivers/mmc/ca_dw_mmc.c index 2b79356a20ed..a17ed8c11cbe 100644 --- a/drivers/mmc/ca_dw_mmc.c +++ b/drivers/mmc/ca_dw_mmc.c @@ -7,6 +7,7 @@ #include <common.h> #include <dwmmc.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <malloc.h> #include <errno.h> diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index b4ff1c3fb4b3..544798bb71d1 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -7,6 +7,7 @@ #include <common.h> #include <dwmmc.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <malloc.h> #include <errno.h> diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index b5f3fd134d41..6014e1c5cac9 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -21,6 +21,7 @@ #include <fsl_esdhc.h> #include <fdt_support.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <dm/device_compat.h> diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 8ac859797f04..e0e132698e30 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -21,6 +21,7 @@ #include <mmc.h> #include <part.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/mmc/ftsdc010_mci.c b/drivers/mmc/ftsdc010_mci.c index fa6181d85fa6..0fa037224fbe 100644 --- a/drivers/mmc/ftsdc010_mci.c +++ b/drivers/mmc/ftsdc010_mci.c @@ -15,6 +15,7 @@ #include <malloc.h> #include <part.h> #include <mmc.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h> #include <linux/errno.h> diff --git a/drivers/mmc/hi6220_dw_mmc.c b/drivers/mmc/hi6220_dw_mmc.c index bb5d0922bebe..2cec5b9ae324 100644 --- a/drivers/mmc/hi6220_dw_mmc.c +++ b/drivers/mmc/hi6220_dw_mmc.c @@ -10,6 +10,7 @@ #include <errno.h> #include <fdtdec.h> #include <malloc.h> +#include <asm/global_data.h>
diff --git a/drivers/mmc/iproc_sdhci.c b/drivers/mmc/iproc_sdhci.c index f931e4b3c1d6..6e4f527e5d83 100644 --- a/drivers/mmc/iproc_sdhci.c +++ b/drivers/mmc/iproc_sdhci.c @@ -9,6 +9,7 @@ #include <errno.h> #include <malloc.h> #include <sdhci.h> +#include <asm/global_data.h> #include <linux/delay.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/mmc/jz_mmc.c b/drivers/mmc/jz_mmc.c index ae3af3927db5..61e48ee0f62d 100644 --- a/drivers/mmc/jz_mmc.c +++ b/drivers/mmc/jz_mmc.c @@ -9,6 +9,7 @@ #include <common.h> #include <malloc.h> #include <mmc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/unaligned.h> #include <errno.h> diff --git a/drivers/mmc/msm_sdhci.c b/drivers/mmc/msm_sdhci.c index bfbba46c5dc3..d63d7b3a2c10 100644 --- a/drivers/mmc/msm_sdhci.c +++ b/drivers/mmc/msm_sdhci.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <sdhci.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/mmc/mv_sdhci.c b/drivers/mmc/mv_sdhci.c index 556dd380466b..2096a67f54e5 100644 --- a/drivers/mmc/mv_sdhci.c +++ b/drivers/mmc/mv_sdhci.c @@ -7,6 +7,7 @@ #include <dm.h> #include <malloc.h> #include <sdhci.h> +#include <asm/global_data.h> #include <linux/mbus.h>
#define MVSDH_NAME "mv_sdh" diff --git a/drivers/mmc/mvebu_mmc.c b/drivers/mmc/mvebu_mmc.c index 03d5150b207a..8ec1f57a1b70 100644 --- a/drivers/mmc/mvebu_mmc.c +++ b/drivers/mmc/mvebu_mmc.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <part.h> #include <mmc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index 52f044e37a16..da44511d9896 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -35,6 +35,7 @@ #include <palmas.h> #endif #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #ifdef CONFIG_OMAP54XX diff --git a/drivers/mmc/pic32_sdhci.c b/drivers/mmc/pic32_sdhci.c index fb37c6756c4a..fe555106a1d3 100644 --- a/drivers/mmc/pic32_sdhci.c +++ b/drivers/mmc/pic32_sdhci.c @@ -9,6 +9,8 @@ #include <dm.h> #include <sdhci.h> #include <clk.h> +#include <linux/errno.h> +#include <mach/pic32.h>
struct pic32_sdhci_plat { struct mmc_config cfg; diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 2acb8c6efa04..9ad92648a344 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -11,6 +11,7 @@ #include <malloc.h> #include <mmc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/compat.h> diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 3cf56e0ac408..dee84263c3fd 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <sdhci.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <asm/gpio.h> #include <asm/arch/mmc.h> diff --git a/drivers/mmc/sdhci-cadence.c b/drivers/mmc/sdhci-cadence.c index 2b726c26b870..327a05ad11d0 100644 --- a/drivers/mmc/sdhci-cadence.c +++ b/drivers/mmc/sdhci-cadence.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitfield.h> #include <linux/bitops.h> diff --git a/drivers/mmc/sh_mmcif.c b/drivers/mmc/sh_mmcif.c index af342f2c290b..830e29cdd414 100644 --- a/drivers/mmc/sh_mmcif.c +++ b/drivers/mmc/sh_mmcif.c @@ -22,6 +22,7 @@ #include <linux/io.h> #include <linux/sizes.h> #include "sh_mmcif.h" +#include <asm/global_data.h>
#define DRIVER_NAME "sh_mmcif"
diff --git a/drivers/mmc/sh_sdhi.c b/drivers/mmc/sh_sdhi.c index b8865b1ca6e7..b2d0fac96368 100644 --- a/drivers/mmc/sh_sdhi.c +++ b/drivers/mmc/sh_sdhi.c @@ -24,6 +24,7 @@ #include <linux/sizes.h> #include <asm/arch/rmobile.h> #include <asm/arch/sh_sdhi.h> +#include <asm/global_data.h> #include <clk.h>
#define DRIVER_NAME "sh-sdhi" diff --git a/drivers/mmc/socfpga_dw_mmc.c b/drivers/mmc/socfpga_dw_mmc.c index aa0d3a222211..d6d2d5721411 100644 --- a/drivers/mmc/socfpga_dw_mmc.c +++ b/drivers/mmc/socfpga_dw_mmc.c @@ -13,6 +13,7 @@ #include <dwmmc.h> #include <errno.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/intel-smc.h> #include <linux/libfdt.h> diff --git a/drivers/mmc/sti_sdhci.c b/drivers/mmc/sti_sdhci.c index 8ecd575152d9..6194768fd727 100644 --- a/drivers/mmc/sti_sdhci.c +++ b/drivers/mmc/sti_sdhci.c @@ -11,6 +11,7 @@ #include <reset-uclass.h> #include <sdhci.h> #include <asm/arch/sdhci.h> +#include <asm/global_data.h>
diff --git a/drivers/mmc/tmio-common.c b/drivers/mmc/tmio-common.c index 6c0c840bbb10..e9c7d3a2e004 100644 --- a/drivers/mmc/tmio-common.c +++ b/drivers/mmc/tmio-common.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <mmc.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/pinctrl.h> #include <linux/compat.h> diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c index d63569440197..e292f2903d85 100644 --- a/drivers/mmc/xenon_sdhci.c +++ b/drivers/mmc/xenon_sdhci.c @@ -17,6 +17,7 @@ #include <common.h> #include <dm.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/libfdt.h> diff --git a/drivers/mtd/altera_qspi.c b/drivers/mtd/altera_qspi.c index 0011811250b0..7bac599a54a1 100644 --- a/drivers/mtd/altera_qspi.c +++ b/drivers/mtd/altera_qspi.c @@ -11,6 +11,7 @@ #include <flash.h> #include <log.h> #include <mtd.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 9e3a652f4451..b4512e3a5fc4 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -26,6 +26,7 @@ #include <init.h> #include <irq_func.h> #include <log.h> +#include <asm/global_data.h> #include <asm/processor.h> #include <asm/io.h> #include <asm/byteorder.h> diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 9360d4ed1720..c53ec657a34d 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -12,6 +12,7 @@ #include <linux/err.h> #include <linux/mtd/mtd.h> #include <linux/mtd/partitions.h> +#include <asm/global_data.h> #include <mtd.h>
#define MTD_NAME_MAX_LEN 20 diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index 698968bc1163..6557faddf943 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -4574,6 +4574,7 @@ ident_done: EXPORT_SYMBOL(nand_get_flash_type);
#if CONFIG_IS_ENABLED(OF_CONTROL) +#include <asm/global_data.h> DECLARE_GLOBAL_DATA_PTR;
static int nand_dt_init(struct mtd_info *mtd, struct nand_chip *chip, int node) diff --git a/drivers/mtd/nand/raw/octeontx_nand.c b/drivers/mtd/nand/raw/octeontx_nand.c index 9997135ef937..e0ccc7b0d90d 100644 --- a/drivers/mtd/nand/raw/octeontx_nand.c +++ b/drivers/mtd/nand/raw/octeontx_nand.c @@ -23,6 +23,7 @@ #include <linux/mtd/mtd.h> #include <linux/mtd/nand_bch.h> #include <linux/mtd/nand_ecc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/types.h> #include <asm/dma-mapping.h> diff --git a/drivers/mtd/nand/raw/pxa3xx_nand.c b/drivers/mtd/nand/raw/pxa3xx_nand.c index f6233756d853..8ff58a703876 100644 --- a/drivers/mtd/nand/raw/pxa3xx_nand.c +++ b/drivers/mtd/nand/raw/pxa3xx_nand.c @@ -10,6 +10,7 @@ #include <malloc.h> #include <fdtdec.h> #include <nand.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/devres.h> #include <linux/bitops.h> diff --git a/drivers/mtd/nand/raw/sunxi_nand.c b/drivers/mtd/nand/raw/sunxi_nand.c index 12fc065b320c..7bc6ec7beea2 100644 --- a/drivers/mtd/nand/raw/sunxi_nand.c +++ b/drivers/mtd/nand/raw/sunxi_nand.c @@ -29,6 +29,7 @@ #include <malloc.h> #include <memalign.h> #include <nand.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/devres.h> #include <linux/bitops.h> diff --git a/drivers/mtd/nand/raw/tegra_nand.c b/drivers/mtd/nand/raw/tegra_nand.c index a530127cb779..6310253efa6a 100644 --- a/drivers/mtd/nand/raw/tegra_nand.c +++ b/drivers/mtd/nand/raw/tegra_nand.c @@ -8,6 +8,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <memalign.h> #include <nand.h> diff --git a/drivers/mtd/pic32_flash.c b/drivers/mtd/pic32_flash.c index a58a2c4b6c31..ea0dbe9eeee5 100644 --- a/drivers/mtd/pic32_flash.c +++ b/drivers/mtd/pic32_flash.c @@ -12,6 +12,7 @@ #include <flash.h> #include <init.h> #include <irq_func.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <mach/pic32.h> #include <wait_bit.h> diff --git a/drivers/mtd/renesas_rpc_hf.c b/drivers/mtd/renesas_rpc_hf.c index 8a644ad9b384..2c61ce7b6e69 100644 --- a/drivers/mtd/renesas_rpc_hf.c +++ b/drivers/mtd/renesas_rpc_hf.c @@ -21,6 +21,7 @@ #include <wait_bit.h> #include <linux/bitops.h> #include <mtd/cfi_flash.h> +#include <asm/global_data.h>
#define RPC_CMNCR 0x0000 /* R/W */ #define RPC_CMNCR_MD BIT(31) diff --git a/drivers/mtd/spi/sf-uclass.c b/drivers/mtd/spi/sf-uclass.c index 3017022abbbc..12d132152d32 100644 --- a/drivers/mtd/spi/sf-uclass.c +++ b/drivers/mtd/spi/sf-uclass.c @@ -9,6 +9,7 @@ #include <malloc.h> #include <spi.h> #include <spi_flash.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include "sf_internal.h"
diff --git a/drivers/net/ag7xxx.c b/drivers/net/ag7xxx.c index c16dff959b1d..632ab3c1e5d1 100644 --- a/drivers/net/ag7xxx.c +++ b/drivers/net/ag7xxx.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/compiler.h> #include <linux/delay.h> diff --git a/drivers/net/altera_tse.c b/drivers/net/altera_tse.c index 456b7b98e913..eb4cd96763bd 100644 --- a/drivers/net/altera_tse.c +++ b/drivers/net/altera_tse.c @@ -18,6 +18,7 @@ #include <miiphy.h> #include <net.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/dma-mapping.h> #include <asm/io.h> #include "altera_tse.h" diff --git a/drivers/net/dwmac_s700.c b/drivers/net/dwmac_s700.c index efe3d1dade62..744b58bdd1a6 100644 --- a/drivers/net/dwmac_s700.c +++ b/drivers/net/dwmac_s700.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <clk.h> diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index e3b29a9c3e7d..ec21157d7105 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -18,6 +18,7 @@ #include <net.h> #include <netdev.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <power/regulator.h>
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index 5bfe3781a17d..c9cf6a987e11 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -11,6 +11,7 @@ #include <image.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/bug.h> #include <asm/io.h> #include <linux/delay.h> diff --git a/drivers/net/fsl_mcdmafec.c b/drivers/net/fsl_mcdmafec.c index c36d40c91112..c20aef4ab28d 100644 --- a/drivers/net/fsl_mcdmafec.c +++ b/drivers/net/fsl_mcdmafec.c @@ -18,6 +18,7 @@ #include <config.h> #include <net.h> #include <miiphy.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/mii.h> #include <asm/immap.h> diff --git a/drivers/net/ftmac100.c b/drivers/net/ftmac100.c index 0d672374fda0..af3d076160f6 100644 --- a/drivers/net/ftmac100.c +++ b/drivers/net/ftmac100.c @@ -12,6 +12,7 @@ #include <env.h> #include <malloc.h> #include <net.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/io.h>
diff --git a/drivers/net/gmac_rockchip.c b/drivers/net/gmac_rockchip.c index a50a5b3f33a0..f9096604840e 100644 --- a/drivers/net/gmac_rockchip.c +++ b/drivers/net/gmac_rockchip.c @@ -12,6 +12,7 @@ #include <net.h> #include <phy.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/periph.h> #include <asm/arch-rockchip/clock.h> diff --git a/drivers/net/ldpaa_eth/ldpaa_eth.c b/drivers/net/ldpaa_eth/ldpaa_eth.c index ef013c9c97e3..725173f62737 100644 --- a/drivers/net/ldpaa_eth/ldpaa_eth.c +++ b/drivers/net/ldpaa_eth/ldpaa_eth.c @@ -20,6 +20,7 @@ #include <linux/bug.h> #include <linux/compat.h> #include <linux/delay.h> +#include <asm/global_data.h> #include "ldpaa_eth.h"
#ifdef CONFIG_PHYLIB diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 6e26467700a5..57ea45e2dc7f 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -7,6 +7,7 @@ #include <cpu_func.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h>
/* diff --git a/drivers/net/mcffec.c b/drivers/net/mcffec.c index cb343b446f59..43bb761483e3 100644 --- a/drivers/net/mcffec.c +++ b/drivers/net/mcffec.c @@ -18,6 +18,7 @@ #include <net.h> #include <miiphy.h> #include <asm/fec.h> +#include <asm/global_data.h> #include <asm/immap.h> #include <linux/delay.h> #include <linux/mii.h> diff --git a/drivers/net/mcfmii.c b/drivers/net/mcfmii.c index ec81320a86d1..0987266c96ef 100644 --- a/drivers/net/mcfmii.c +++ b/drivers/net/mcfmii.c @@ -8,6 +8,7 @@ #include <config.h> #include <net.h> #include <netdev.h> +#include <asm/global_data.h> #include <linux/delay.h>
#ifdef CONFIG_MCF547x_8x diff --git a/drivers/net/mpc8xx_fec.c b/drivers/net/mpc8xx_fec.c index 12be584638fa..282c2599d3c4 100644 --- a/drivers/net/mpc8xx_fec.c +++ b/drivers/net/mpc8xx_fec.c @@ -11,6 +11,7 @@ #include <net.h> #include <netdev.h> #include <asm/cpm_8xx.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 2452859f8145..ce5b8eed64b4 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -18,6 +18,7 @@ #include <malloc.h> #include <miiphy.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h> #include <linux/errno.h> diff --git a/drivers/net/mvneta.c b/drivers/net/mvneta.c index 3192cf550911..4a4268c2b2cc 100644 --- a/drivers/net/mvneta.c +++ b/drivers/net/mvneta.c @@ -21,6 +21,7 @@ #include <config.h> #include <malloc.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <dm/devres.h> diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index d266e6d0f378..1cf522b8fe57 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -17,6 +17,7 @@ #include <cpu_func.h> #include <dm.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device_compat.h> #include <dm/devres.h> diff --git a/drivers/net/octeontx/smi.c b/drivers/net/octeontx/smi.c index 58436419f1b9..91dcd05e4b38 100644 --- a/drivers/net/octeontx/smi.c +++ b/drivers/net/octeontx/smi.c @@ -10,6 +10,7 @@ #include <pci.h> #include <pci_ids.h> #include <phy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/ctype.h> #include <linux/delay.h> diff --git a/drivers/net/phy/fixed.c b/drivers/net/phy/fixed.c index 9d9f746e1dba..3228672fc4ae 100644 --- a/drivers/net/phy/fixed.c +++ b/drivers/net/phy/fixed.c @@ -11,6 +11,7 @@ #include <phy.h> #include <dm.h> #include <fdt_support.h> +#include <asm/global_data.h>
diff --git a/drivers/net/phy/miiphybb.c b/drivers/net/phy/miiphybb.c index 59a32c491301..24d617553e71 100644 --- a/drivers/net/phy/miiphybb.c +++ b/drivers/net/phy/miiphybb.c @@ -16,6 +16,7 @@ #include <ioports.h> #include <ppc_asm.tmpl> #include <miiphy.h> +#include <asm/global_data.h>
#define BB_MII_RELOCATE(v,off) (v += (v?off:0))
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 662ea2b98cc0..a2be3987364c 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -17,6 +17,7 @@ #include <miiphy.h> #include <phy.h> #include <errno.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> diff --git a/drivers/net/phy/xilinx_gmii2rgmii.c b/drivers/net/phy/xilinx_gmii2rgmii.c index e2feb17048cc..74105c0b7d6b 100644 --- a/drivers/net/phy/xilinx_gmii2rgmii.c +++ b/drivers/net/phy/xilinx_gmii2rgmii.c @@ -5,11 +5,11 @@ * Copyright (C) 2018 Xilinx, Inc. */
+#include <common.h> #include <dm.h> #include <log.h> #include <phy.h> -#include <config.h> -#include <common.h> +#include <asm/global_data.h>
diff --git a/drivers/net/pic32_eth.c b/drivers/net/pic32_eth.c index 9eba55affb19..5a678d1cf952 100644 --- a/drivers/net/pic32_eth.c +++ b/drivers/net/pic32_eth.c @@ -14,6 +14,7 @@ #include <console.h> #include <time.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/delay.h> #include <linux/mii.h> diff --git a/drivers/net/qe/dm_qe_uec.c b/drivers/net/qe/dm_qe_uec.c index a33068cc706e..b08c79244c92 100644 --- a/drivers/net/qe/dm_qe_uec.c +++ b/drivers/net/qe/dm_qe_uec.c @@ -12,6 +12,7 @@ #include <errno.h> #include <memalign.h> #include <miiphy.h> +#include <asm/global_data.h> #include <asm/io.h>
#include "dm_qe_uec.h" diff --git a/drivers/net/ravb.c b/drivers/net/ravb.c index 34e2b8f9e968..6953b7286a39 100644 --- a/drivers/net/ravb.c +++ b/drivers/net/ravb.c @@ -22,6 +22,7 @@ #include <linux/mii.h> #include <wait_bit.h> #include <asm/io.h> +#include <asm/global_data.h> #include <asm/gpio.h>
/* Registers */ diff --git a/drivers/net/sandbox-raw.c b/drivers/net/sandbox-raw.c index 8273f73c9119..ce66ff781ffe 100644 --- a/drivers/net/sandbox-raw.c +++ b/drivers/net/sandbox-raw.c @@ -13,6 +13,7 @@ #include <env.h> #include <malloc.h> #include <net.h> +#include <asm/global_data.h>
diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index a389e2bd0d1d..37459dfa0a40 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -12,6 +12,7 @@ #include <malloc.h> #include <net.h> #include <asm/eth.h> +#include <asm/global_data.h> #include <asm/test.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 1666a8cdb212..3143a5813a6d 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -20,6 +20,7 @@ #include <asm/cache.h> #include <linux/delay.h> #include <linux/errno.h> +#include <asm/global_data.h> #include <asm/io.h>
#ifdef CONFIG_DM_ETH diff --git a/drivers/net/sni_ave.c b/drivers/net/sni_ave.c index 0ebe86a333b3..ab51552ed88b 100644 --- a/drivers/net/sni_ave.c +++ b/drivers/net/sni_ave.c @@ -16,6 +16,7 @@ #include <reset.h> #include <syscon.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 0f6b6bb537e0..a6cdda81a76c 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -13,6 +13,7 @@ #include <cpu_func.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/gpio.h> diff --git a/drivers/net/ti/cpsw-common.c b/drivers/net/ti/cpsw-common.c index ca93edb70e31..3140f2515fbf 100644 --- a/drivers/net/ti/cpsw-common.c +++ b/drivers/net/ti/cpsw-common.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <fdt_support.h> +#include <asm/global_data.h> #include <asm/io.h> #include <cpsw.h> #include <dm/device_compat.h> diff --git a/drivers/net/ti/keystone_net.c b/drivers/net/ti/keystone_net.c index 35b796c91369..5e8f683c29e3 100644 --- a/drivers/net/ti/keystone_net.c +++ b/drivers/net/ti/keystone_net.c @@ -8,6 +8,7 @@ #include <common.h> #include <command.h> #include <console.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <dm.h> diff --git a/drivers/net/xilinx_axi_emac.c b/drivers/net/xilinx_axi_emac.c index 343ab69d1943..2ce6271afe82 100644 --- a/drivers/net/xilinx_axi_emac.c +++ b/drivers/net/xilinx_axi_emac.c @@ -12,6 +12,7 @@ #include <log.h> #include <net.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <phy.h> #include <miiphy.h> diff --git a/drivers/net/xilinx_emaclite.c b/drivers/net/xilinx_emaclite.c index 6b447537f66d..43fc36dc6a82 100644 --- a/drivers/net/xilinx_emaclite.c +++ b/drivers/net/xilinx_emaclite.c @@ -13,6 +13,7 @@ #include <dm.h> #include <console.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <phy.h> #include <miiphy.h> diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 1d09c5ac4f6b..e72a60c13180 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -9,6 +9,7 @@ #include <log.h> #include <malloc.h> #include <asm/fsl_serdes.h> +#include <asm/global_data.h> #include <linux/delay.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index ba65f47e808b..dfd54b339f45 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device-internal.h> #include <dm/lists.h> diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index a7453e57552b..d8f9239523cd 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -17,6 +17,7 @@ #include <common.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h>
#include <command.h> diff --git a/drivers/pci/pci_mvebu.c b/drivers/pci/pci_mvebu.c index 374c4aa2432e..9a440f57d6e7 100644 --- a/drivers/pci/pci_mvebu.c +++ b/drivers/pci/pci_mvebu.c @@ -13,6 +13,7 @@ #include <dm.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/of_access.h> diff --git a/drivers/pci/pci_octeontx.c b/drivers/pci/pci_octeontx.c index 16932839a586..46855c5cd3a3 100644 --- a/drivers/pci/pci_octeontx.c +++ b/drivers/pci/pci_octeontx.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <pci.h> +#include <asm/global_data.h>
#include <asm/io.h>
diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index 4a21813a82fd..a14a4db3c2f1 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -38,6 +38,7 @@ #include <video.h> #include <video_fb.h> #include <acpi/acpi_s3.h> +#include <asm/global_data.h> #include <linux/screen_info.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/pci/pcie_dw_mvebu.c b/drivers/pci/pcie_dw_mvebu.c index 7ec149d178c5..93e57cf0cf14 100644 --- a/drivers/pci/pcie_dw_mvebu.c +++ b/drivers/pci/pcie_dw_mvebu.c @@ -14,6 +14,7 @@ #include <dm.h> #include <log.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm-generic/gpio.h> #include <linux/delay.h> diff --git a/drivers/pci/pcie_dw_rockchip.c b/drivers/pci/pcie_dw_rockchip.c index 15270627b0db..77f1a1b48f1e 100644 --- a/drivers/pci/pcie_dw_rockchip.c +++ b/drivers/pci/pcie_dw_rockchip.c @@ -14,6 +14,7 @@ #include <reset.h> #include <syscon.h> #include <asm/arch-rockchip/clock.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm-generic/gpio.h> #include <dm/device_compat.h> diff --git a/drivers/pci/pcie_dw_ti.c b/drivers/pci/pcie_dw_ti.c index 5e00fcda97a2..33a5c3cc208b 100644 --- a/drivers/pci/pcie_dw_ti.c +++ b/drivers/pci/pcie_dw_ti.c @@ -11,6 +11,7 @@ #include <power-domain.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm-generic/gpio.h> #include <dm/device_compat.h> diff --git a/drivers/pci/pcie_ecam_generic.c b/drivers/pci/pcie_ecam_generic.c index 7d1f13d637c0..e83e5aff206b 100644 --- a/drivers/pci/pcie_ecam_generic.c +++ b/drivers/pci/pcie_ecam_generic.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <pci.h> +#include <asm/global_data.h>
#include <asm/io.h>
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index b061b31cae59..3c2a2a476111 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -13,6 +13,7 @@ #include <pci.h> #include <asm/fsl_pci.h> #include <asm/fsl_serdes.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h> #include "pcie_fsl.h" diff --git a/drivers/pci/pcie_intel_fpga.c b/drivers/pci/pcie_intel_fpga.c index b4964757c783..60195cfe1b6e 100644 --- a/drivers/pci/pcie_intel_fpga.c +++ b/drivers/pci/pcie_intel_fpga.c @@ -9,6 +9,7 @@ #include <common.h> #include <dm.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <linux/bitops.h> diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index 25b5272d4ed7..3c7c4ca18e8b 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -7,6 +7,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <malloc.h> diff --git a/drivers/pci/pcie_layerscape_ep.c b/drivers/pci/pcie_layerscape_ep.c index 041a526f0b51..14983cce4f2b 100644 --- a/drivers/pci/pcie_layerscape_ep.c +++ b/drivers/pci/pcie_layerscape_ep.c @@ -7,6 +7,7 @@ #include <common.h> #include <asm/arch/fsl_serdes.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/devres.h> #include <errno.h> #include <pci_ep.h> diff --git a/drivers/pci/pcie_layerscape_fixup_common.c b/drivers/pci/pcie_layerscape_fixup_common.c index 40f0ef10ac4b..8b924d404c2d 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.c +++ b/drivers/pci/pcie_layerscape_fixup_common.c @@ -11,6 +11,7 @@ #include <init.h> #include <asm/arch/clock.h> #include <asm/arch/soc.h> +#include <linux/libfdt.h> #include "pcie_layerscape_fixup_common.h"
void ft_pci_setup(void *blob, struct bd_info *bd) diff --git a/drivers/pci/pcie_layerscape_gen4.c b/drivers/pci/pcie_layerscape_gen4.c index be9cb6285c8c..255e73181d59 100644 --- a/drivers/pci/pcie_layerscape_gen4.c +++ b/drivers/pci/pcie_layerscape_gen4.c @@ -10,6 +10,7 @@ #include <log.h> #include <asm/arch/fsl_serdes.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <malloc.h> diff --git a/drivers/pci/pcie_layerscape_rc.c b/drivers/pci/pcie_layerscape_rc.c index 517e7b5cebd2..b055ed516546 100644 --- a/drivers/pci/pcie_layerscape_rc.c +++ b/drivers/pci/pcie_layerscape_rc.c @@ -7,6 +7,7 @@ #include <common.h> #include <asm/arch/fsl_serdes.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <errno.h> #include <malloc.h> diff --git a/drivers/pci/pcie_phytium.c b/drivers/pci/pcie_phytium.c index 03ea04ceaa9b..752e1703215b 100644 --- a/drivers/pci/pcie_phytium.c +++ b/drivers/pci/pcie_phytium.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <pci.h> +#include <asm/global_data.h> #include <asm/io.h>
/** diff --git a/drivers/pci/pcie_rockchip.c b/drivers/pci/pcie_rockchip.c index 027745e42e80..b0c91c0f430e 100644 --- a/drivers/pci/pcie_rockchip.c +++ b/drivers/pci/pcie_rockchip.c @@ -14,6 +14,7 @@ #include <common.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <generic-phy.h> #include <pci.h> diff --git a/drivers/pci/pcie_xilinx.c b/drivers/pci/pcie_xilinx.c index 00879a2d7290..ae9a65b0a9e1 100644 --- a/drivers/pci/pcie_xilinx.c +++ b/drivers/pci/pcie_xilinx.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <pci.h> +#include <asm/global_data.h> #include <linux/bitops.h>
#include <asm/io.h> diff --git a/drivers/pci_endpoint/pci_ep-uclass.c b/drivers/pci_endpoint/pci_ep-uclass.c index aa89701de8fb..5555cf5a8c9e 100644 --- a/drivers/pci_endpoint/pci_ep-uclass.c +++ b/drivers/pci_endpoint/pci_ep-uclass.c @@ -12,6 +12,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <linux/log2.h> #include <pci_ep.h>
diff --git a/drivers/pci_endpoint/pcie-cadence-ep.c b/drivers/pci_endpoint/pcie-cadence-ep.c index 7313428fe0ca..d58c64982b27 100644 --- a/drivers/pci_endpoint/pcie-cadence-ep.c +++ b/drivers/pci_endpoint/pcie-cadence-ep.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <pci_ep.h> +#include <asm/global_data.h> #include <linux/sizes.h> #include <linux/log2.h> #include "pcie-cadence.h" diff --git a/drivers/phy/marvell/comphy_a3700.c b/drivers/phy/marvell/comphy_a3700.c index 4606de6f48ec..12523d18a805 100644 --- a/drivers/phy/marvell/comphy_a3700.c +++ b/drivers/phy/marvell/comphy_a3700.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/drivers/phy/marvell/comphy_core.c b/drivers/phy/marvell/comphy_core.c index b2203277c410..cd54e7f88907 100644 --- a/drivers/phy/marvell/comphy_core.c +++ b/drivers/phy/marvell/comphy_core.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <linux/err.h> diff --git a/drivers/phy/marvell/comphy_cp110.c b/drivers/phy/marvell/comphy_cp110.c index b0fcb13f1c9a..a323de7c76d0 100644 --- a/drivers/phy/marvell/comphy_cp110.c +++ b/drivers/phy/marvell/comphy_cp110.c @@ -6,6 +6,7 @@ #include <common.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/ptrace.h> #include <asm/arch/cpu.h> diff --git a/drivers/phy/omap-usb2-phy.c b/drivers/phy/omap-usb2-phy.c index cb9914373218..2a9604cdcc49 100644 --- a/drivers/phy/omap-usb2-phy.c +++ b/drivers/phy/omap-usb2-phy.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <errno.h> diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index 6744b8b22756..62b8ba3a4a89 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -9,6 +9,7 @@ #include <common.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/lists.h> #include <generic-phy.h> diff --git a/drivers/phy/rockchip/phy-rockchip-pcie.c b/drivers/phy/rockchip/phy-rockchip-pcie.c index bc6c0feed04f..44ca4bc7919e 100644 --- a/drivers/phy/rockchip/phy-rockchip-pcie.c +++ b/drivers/phy/rockchip/phy-rockchip-pcie.c @@ -10,6 +10,7 @@ #include <common.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <generic-phy.h> #include <reset.h> diff --git a/drivers/phy/rockchip/phy-rockchip-typec.c b/drivers/phy/rockchip/phy-rockchip-typec.c index a45a318e4742..ca63b856e13b 100644 --- a/drivers/phy/rockchip/phy-rockchip-typec.c +++ b/drivers/phy/rockchip/phy-rockchip-typec.c @@ -11,6 +11,7 @@ #include <common.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/lists.h> #include <generic-phy.h> diff --git a/drivers/phy/sti_usb_phy.c b/drivers/phy/sti_usb_phy.c index 87c1bcddb4a0..ce4caafce7e4 100644 --- a/drivers/phy/sti_usb_phy.c +++ b/drivers/phy/sti_usb_phy.c @@ -6,6 +6,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <bitfield.h> #include <dm.h> diff --git a/drivers/phy/ti-pipe3-phy.c b/drivers/phy/ti-pipe3-phy.c index 98fe6c6fce36..b5b3c3f1522a 100644 --- a/drivers/phy/ti-pipe3-phy.c +++ b/drivers/phy/ti-pipe3-phy.c @@ -8,6 +8,7 @@ #include <dm.h> #include <dm/device.h> #include <generic-phy.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <syscon.h> diff --git a/drivers/pinctrl/ath79/pinctrl_ar933x.c b/drivers/pinctrl/ath79/pinctrl_ar933x.c index 14408da2e7e5..eb673a9f69cb 100644 --- a/drivers/pinctrl/ath79/pinctrl_ar933x.c +++ b/drivers/pinctrl/ath79/pinctrl_ar933x.c @@ -7,6 +7,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/pinctrl.h> #include <mach/ar71xx_regs.h> diff --git a/drivers/pinctrl/ath79/pinctrl_qca953x.c b/drivers/pinctrl/ath79/pinctrl_qca953x.c index b1c78bead3b6..0d534268e966 100644 --- a/drivers/pinctrl/ath79/pinctrl_qca953x.c +++ b/drivers/pinctrl/ath79/pinctrl_qca953x.c @@ -7,6 +7,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/pinctrl.h> #include <mach/ar71xx_regs.h> diff --git a/drivers/pinctrl/exynos/pinctrl-exynos.c b/drivers/pinctrl/exynos/pinctrl-exynos.c index 64d78213a86e..2640c8fcefc1 100644 --- a/drivers/pinctrl/exynos/pinctrl-exynos.c +++ b/drivers/pinctrl/exynos/pinctrl-exynos.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include "pinctrl-exynos.h"
diff --git a/drivers/pinctrl/meson/pinctrl-meson.c b/drivers/pinctrl/meson/pinctrl-meson.c index b11a40e11a3d..ee362d8464fc 100644 --- a/drivers/pinctrl/meson/pinctrl-meson.c +++ b/drivers/pinctrl/meson/pinctrl-meson.c @@ -7,6 +7,7 @@ #include <dm.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device_compat.h> #include <dm/lists.h> diff --git a/drivers/pinctrl/mtmips/pinctrl-mt7628.c b/drivers/pinctrl/mtmips/pinctrl-mt7628.c index c15da6be0ead..79c63c7caec6 100644 --- a/drivers/pinctrl/mtmips/pinctrl-mt7628.c +++ b/drivers/pinctrl/mtmips/pinctrl-mt7628.c @@ -7,6 +7,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/pinctrl.h> #include <linux/bitops.h> #include <linux/io.h> diff --git a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c index 4797d3250f91..b9d389e70f5d 100644 --- a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c +++ b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c @@ -20,6 +20,7 @@ #include <config.h> #include <dm.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device_compat.h> #include <dm/devres.h> diff --git a/drivers/pinctrl/mvebu/pinctrl-mvebu.c b/drivers/pinctrl/mvebu/pinctrl-mvebu.c index 5ced4fea8885..536c6aff96e5 100644 --- a/drivers/pinctrl/mvebu/pinctrl-mvebu.c +++ b/drivers/pinctrl/mvebu/pinctrl-mvebu.c @@ -10,6 +10,7 @@ #include <errno.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/pinctrl.h> #include <dm/root.h> #include <asm/system.h> diff --git a/drivers/pinctrl/nexell/pinctrl-nexell.c b/drivers/pinctrl/nexell/pinctrl-nexell.c index 4518c05d4685..6b01f47657ca 100644 --- a/drivers/pinctrl/nexell/pinctrl-nexell.c +++ b/drivers/pinctrl/nexell/pinctrl-nexell.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include "pinctrl-nexell.h" #include "pinctrl-s5pxx18.h" diff --git a/drivers/pinctrl/nexell/pinctrl-s5pxx18.c b/drivers/pinctrl/nexell/pinctrl-s5pxx18.c index adc687a3b57a..863eb1455d23 100644 --- a/drivers/pinctrl/nexell/pinctrl-s5pxx18.c +++ b/drivers/pinctrl/nexell/pinctrl-s5pxx18.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/pinctrl.h> #include <dm/root.h> diff --git a/drivers/pinctrl/nxp/pinctrl-imx.c b/drivers/pinctrl/nxp/pinctrl-imx.c index 48c7bde37526..1596dcc4747e 100644 --- a/drivers/pinctrl/nxp/pinctrl-imx.c +++ b/drivers/pinctrl/nxp/pinctrl-imx.c @@ -6,6 +6,7 @@ #include <common.h> #include <malloc.h> #include <mapmem.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/devres.h> #include <linux/bitops.h> diff --git a/drivers/pinctrl/nxp/pinctrl-imx8.c b/drivers/pinctrl/nxp/pinctrl-imx8.c index 2e5db2c6c2fe..46af44ecb1f2 100644 --- a/drivers/pinctrl/nxp/pinctrl-imx8.c +++ b/drivers/pinctrl/nxp/pinctrl-imx8.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/pinctrl.h>
diff --git a/drivers/pinctrl/nxp/pinctrl-mxs.c b/drivers/pinctrl/nxp/pinctrl-mxs.c index 449a0aa8b5fb..e6b10a377b6c 100644 --- a/drivers/pinctrl/nxp/pinctrl-mxs.c +++ b/drivers/pinctrl/nxp/pinctrl-mxs.c @@ -6,6 +6,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/devres.h> #include <linux/io.h> diff --git a/drivers/pinctrl/pinctrl-at91-pio4.c b/drivers/pinctrl/pinctrl-at91-pio4.c index 3a5143adc381..b7ae2f6adab2 100644 --- a/drivers/pinctrl/pinctrl-at91-pio4.c +++ b/drivers/pinctrl/pinctrl-at91-pio4.c @@ -8,6 +8,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/pinctrl.h> #include <linux/bitops.h> #include <linux/io.h> diff --git a/drivers/pinctrl/pinctrl-at91.c b/drivers/pinctrl/pinctrl-at91.c index ddaad55ddc51..b7aab12f11c1 100644 --- a/drivers/pinctrl/pinctrl-at91.c +++ b/drivers/pinctrl/pinctrl-at91.c @@ -9,6 +9,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/pinctrl.h> #include <asm/hardware.h> #include <linux/bitops.h> diff --git a/drivers/pinctrl/pinctrl-sti.c b/drivers/pinctrl/pinctrl-sti.c index c5baf5d211e4..20cdbb0702e6 100644 --- a/drivers/pinctrl/pinctrl-sti.c +++ b/drivers/pinctrl/pinctrl-sti.c @@ -12,6 +12,7 @@ #include <errno.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/pinctrl.h> #include <linux/bug.h> diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index 7919e54e8de8..b0f30aa1f758 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -5,6 +5,7 @@
#include <common.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/libfdt.h> #include <linux/err.h> diff --git a/drivers/pinctrl/pinctrl_pic32.c b/drivers/pinctrl/pinctrl_pic32.c index a19758d59d78..54d97ac0ae37 100644 --- a/drivers/pinctrl/pinctrl_pic32.c +++ b/drivers/pinctrl/pinctrl_pic32.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/pinctrl.h> #include <linux/bitops.h> diff --git a/drivers/pinctrl/renesas/pfc-r7s72100.c b/drivers/pinctrl/renesas/pfc-r7s72100.c index 82bdf05b24b4..a445cdba7130 100644 --- a/drivers/pinctrl/renesas/pfc-r7s72100.c +++ b/drivers/pinctrl/renesas/pfc-r7s72100.c @@ -7,6 +7,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/pinctrl.h> #include <linux/bitops.h> diff --git a/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c b/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c index ec1cb9b652f3..630513ba3a22 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c +++ b/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c @@ -12,6 +12,7 @@ #include <fdtdec.h> #include <linux/bitops.h> #include <linux/libfdt.h> +#include <asm/global_data.h>
#include "pinctrl-rockchip.h"
diff --git a/drivers/power/domain/imx8-power-domain-legacy.c b/drivers/power/domain/imx8-power-domain-legacy.c index ec369aedd325..e2fae2dbc860 100644 --- a/drivers/power/domain/imx8-power-domain-legacy.c +++ b/drivers/power/domain/imx8-power-domain-legacy.c @@ -8,6 +8,7 @@ #include <log.h> #include <malloc.h> #include <power-domain-uclass.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/power-domain.h> #include <dm/device-internal.h> diff --git a/drivers/power/domain/imx8m-power-domain.c b/drivers/power/domain/imx8m-power-domain.c index 341c83b1365b..c4cd07ffaf4a 100644 --- a/drivers/power/domain/imx8m-power-domain.c +++ b/drivers/power/domain/imx8m-power-domain.c @@ -7,6 +7,7 @@ #include <dm.h> #include <malloc.h> #include <power-domain-uclass.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/power-domain.h> #include <asm/mach-imx/sys_proto.h> diff --git a/drivers/power/pmic/bd71837.c b/drivers/power/pmic/bd71837.c index 31c9139c646d..cb9238972f27 100644 --- a/drivers/power/pmic/bd71837.c +++ b/drivers/power/pmic/bd71837.c @@ -8,6 +8,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <asm/global_data.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/bd71837.h> diff --git a/drivers/power/pmic/mc34708.c b/drivers/power/pmic/mc34708.c index 66253a4a43b0..40d732224b6c 100644 --- a/drivers/power/pmic/mc34708.c +++ b/drivers/power/pmic/mc34708.c @@ -10,6 +10,7 @@ #include <errno.h> #include <fsl_pmic.h> #include <i2c.h> +#include <asm/global_data.h> #include <power/pmic.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/power/pmic/mp5416.c b/drivers/power/pmic/mp5416.c index 458c4df688c2..6180adf77e2d 100644 --- a/drivers/power/pmic/mp5416.c +++ b/drivers/power/pmic/mp5416.c @@ -10,6 +10,7 @@ #include <power/pmic.h> #include <power/regulator.h> #include <power/mp5416.h> +#include <asm/global_data.h>
diff --git a/drivers/power/pmic/pca9450.c b/drivers/power/pmic/pca9450.c index c7f8b8095407..a886647f1937 100644 --- a/drivers/power/pmic/pca9450.c +++ b/drivers/power/pmic/pca9450.c @@ -9,6 +9,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <asm/global_data.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/pca9450.h> diff --git a/drivers/power/regulator/pwm_regulator.c b/drivers/power/regulator/pwm_regulator.c index 18e57db07638..ca59f3ae3e18 100644 --- a/drivers/power/regulator/pwm_regulator.c +++ b/drivers/power/regulator/pwm_regulator.c @@ -12,6 +12,7 @@ #include <errno.h> #include <log.h> #include <pwm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <power/regulator.h>
diff --git a/drivers/pwm/pwm-sifive.c b/drivers/pwm/pwm-sifive.c index 30c30430bea7..01212d630a92 100644 --- a/drivers/pwm/pwm-sifive.c +++ b/drivers/pwm/pwm-sifive.c @@ -18,6 +18,7 @@ #include <dm.h> #include <pwm.h> #include <regmap.h> +#include <asm/global_data.h> #include <linux/io.h> #include <linux/log2.h> #include <linux/bitfield.h> diff --git a/drivers/pwm/rk_pwm.c b/drivers/pwm/rk_pwm.c index a64fc4a0527a..9cf098034571 100644 --- a/drivers/pwm/rk_pwm.c +++ b/drivers/pwm/rk_pwm.c @@ -12,6 +12,7 @@ #include <pwm.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/pwm.h> #include <linux/bitops.h> diff --git a/drivers/pwm/sunxi_pwm.c b/drivers/pwm/sunxi_pwm.c index 614635526fee..e3d5ee456b00 100644 --- a/drivers/pwm/sunxi_pwm.c +++ b/drivers/pwm/sunxi_pwm.c @@ -10,6 +10,7 @@ #include <pwm.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/pwm.h> #include <asm/arch/gpio.h> diff --git a/drivers/qe/fdt.c b/drivers/qe/fdt.c index fd7f14955adb..6195c7c4442c 100644 --- a/drivers/qe/fdt.c +++ b/drivers/qe/fdt.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <fdt_support.h> #include <fsl_qe.h> diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index 259e4e3e6781..97883ffc8792 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -9,6 +9,7 @@ #include <common.h> #include <malloc.h> #include <command.h> +#include <asm/global_data.h> #include <linux/errno.h> #include <asm/io.h> #include <linux/immap_qe.h> diff --git a/drivers/ram/aspeed/sdram_ast2500.c b/drivers/ram/aspeed/sdram_ast2500.c index 905ef304e252..141b19b57ac0 100644 --- a/drivers/ram/aspeed/sdram_ast2500.c +++ b/drivers/ram/aspeed/sdram_ast2500.c @@ -13,6 +13,7 @@ #include <ram.h> #include <regmap.h> #include <reset.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/scu_ast2500.h> #include <asm/arch/sdram_ast2500.h> diff --git a/drivers/ram/aspeed/sdram_ast2600.c b/drivers/ram/aspeed/sdram_ast2600.c index fd4235225a46..9ad398d24155 100644 --- a/drivers/ram/aspeed/sdram_ast2600.c +++ b/drivers/ram/aspeed/sdram_ast2600.c @@ -12,6 +12,7 @@ #include <asm/io.h> #include <asm/arch/scu_ast2600.h> #include <asm/arch/sdram_ast2600.h> +#include <asm/global_data.h> #include <linux/err.h> #include <linux/kernel.h> #include <dt-bindings/clock/ast2600-clock.h> diff --git a/drivers/ram/mpc83xx_sdram.c b/drivers/ram/mpc83xx_sdram.c index 783834c9f574..a53ff93a6b06 100644 --- a/drivers/ram/mpc83xx_sdram.c +++ b/drivers/ram/mpc83xx_sdram.c @@ -10,6 +10,7 @@ #include <log.h> #include <ram.h> #include <asm/bitops.h> +#include <asm/global_data.h> #include <dt-bindings/memory/mpc83xx-sdram.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/ram/octeon/octeon_ddr.c b/drivers/ram/octeon/octeon_ddr.c index 6bec68d1daed..1f75dc15fa0b 100644 --- a/drivers/ram/octeon/octeon_ddr.c +++ b/drivers/ram/octeon/octeon_ddr.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <ram.h> #include <time.h> +#include <asm/global_data.h>
#include <asm/sections.h> #include <linux/io.h> diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index 66235bd420ac..9057ccacd96e 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -11,6 +11,7 @@ #include <ram.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_rk322x.h> diff --git a/drivers/ram/sandbox_ram.c b/drivers/ram/sandbox_ram.c index be4abed0c022..910dce623e90 100644 --- a/drivers/ram/sandbox_ram.c +++ b/drivers/ram/sandbox_ram.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <ram.h> +#include <asm/global_data.h> #include <asm/test.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/ram/sifive/fu540_ddr.c b/drivers/ram/sifive/fu540_ddr.c index 5a7484ce4882..c0653bb8974c 100644 --- a/drivers/ram/sifive/fu540_ddr.c +++ b/drivers/ram/sifive/fu540_ddr.c @@ -12,6 +12,7 @@ #include <init.h> #include <ram.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk.h> #include <wait_bit.h> diff --git a/drivers/ram/stm32mp1/stm32mp1_interactive.c b/drivers/ram/stm32mp1/stm32mp1_interactive.c index e45a2489c508..8c2310ac9064 100644 --- a/drivers/ram/stm32mp1/stm32mp1_interactive.c +++ b/drivers/ram/stm32mp1/stm32mp1_interactive.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <ram.h> #include <reset.h> +#include <asm/global_data.h> #include "stm32mp1_ddr.h" #include "stm32mp1_tests.h"
diff --git a/drivers/ram/stm32mp1/stm32mp1_tests.c b/drivers/ram/stm32mp1/stm32mp1_tests.c index 1fcc7cfd6923..64262f1aa901 100644 --- a/drivers/ram/stm32mp1/stm32mp1_tests.c +++ b/drivers/ram/stm32mp1/stm32mp1_tests.c @@ -11,6 +11,7 @@ #include <log.h> #include <rand.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/log2.h> #include "stm32mp1_tests.h" diff --git a/drivers/remoteproc/rproc-uclass.c b/drivers/remoteproc/rproc-uclass.c index c2d6a4e0c17e..5919c8bb978b 100644 --- a/drivers/remoteproc/rproc-uclass.c +++ b/drivers/remoteproc/rproc-uclass.c @@ -10,6 +10,7 @@ #include <log.h> #include <malloc.h> #include <remoteproc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device-internal.h> #include <dm.h> diff --git a/drivers/remoteproc/ti_power_proc.c b/drivers/remoteproc/ti_power_proc.c index 9dbbb44e955d..86d544cc8540 100644 --- a/drivers/remoteproc/ti_power_proc.c +++ b/drivers/remoteproc/ti_power_proc.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <log.h> #include <remoteproc.h> +#include <asm/global_data.h> #include <mach/psc_defs.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/reset/sti-reset.c b/drivers/reset/sti-reset.c index 8041490630cb..9287f28952cf 100644 --- a/drivers/reset/sti-reset.c +++ b/drivers/reset/sti-reset.c @@ -13,6 +13,7 @@ #include <reset-uclass.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <dt-bindings/reset/stih407-resets.h> #include <linux/bitops.h>
diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index 7edec23e6482..bd14f3e78192 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -13,6 +13,7 @@ #include <watchdog.h> #include <serial.h> #include <debug_uart.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <linux/delay.h>
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 65c6db073ec4..b9e99babebb1 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -14,6 +14,7 @@ #include <reset.h> #include <serial.h> #include <watchdog.h> +#include <asm/global_data.h> #include <linux/err.h> #include <linux/types.h> #include <asm/io.h> diff --git a/drivers/serial/sandbox.c b/drivers/serial/sandbox.c index 756738c2d212..5243c955fbf4 100644 --- a/drivers/serial/sandbox.c +++ b/drivers/serial/sandbox.c @@ -16,6 +16,7 @@ #include <os.h> #include <serial.h> #include <video.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/serial.h> #include <asm/state.h> diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index ead0193ad444..8a87eed68397 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -12,6 +12,7 @@ #include <serial.h> #include <stdio_dev.h> #include <watchdog.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/device-internal.h> #include <dm/of_access.h> diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index 355659ba0560..dea25a049c88 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -10,6 +10,7 @@ #include <serial.h> #include <stdio_dev.h> #include <post.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <errno.h> #include <linux/delay.h> diff --git a/drivers/serial/serial_arc.c b/drivers/serial/serial_arc.c index 445eacc8aac6..8f3e4dd44f15 100644 --- a/drivers/serial/serial_arc.c +++ b/drivers/serial/serial_arc.c @@ -10,6 +10,7 @@ #include <common.h> #include <dm.h> #include <serial.h> +#include <asm/global_data.h>
diff --git a/drivers/serial/serial_linflexuart.c b/drivers/serial/serial_linflexuart.c index c3714e1e1ec2..876a4baa9fc6 100644 --- a/drivers/serial/serial_linflexuart.c +++ b/drivers/serial/serial_linflexuart.c @@ -7,6 +7,7 @@ #include <dm.h> #include <errno.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <serial.h> #include <linux/compiler.h> diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index a35e5be303f6..2b473d70f648 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -10,6 +10,7 @@ #include <fsl_lpuart.h> #include <log.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <serial.h> #include <dm/device_compat.h> diff --git a/drivers/serial/serial_mcf.c b/drivers/serial/serial_mcf.c index e6e21b2ce8c7..bb2afd0d8cd6 100644 --- a/drivers/serial/serial_mcf.c +++ b/drivers/serial/serial_mcf.c @@ -17,6 +17,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_coldfire.h> #include <serial.h> #include <linux/compiler.h> diff --git a/drivers/serial/serial_mpc8xx.c b/drivers/serial/serial_mpc8xx.c index 50d6e70f1773..0978930dcd4f 100644 --- a/drivers/serial/serial_mpc8xx.c +++ b/drivers/serial/serial_mpc8xx.c @@ -10,6 +10,7 @@ #include <serial.h> #include <watchdog.h> #include <asm/cpm_8xx.h> +#include <asm/global_data.h> #include <linux/compiler.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/serial/serial_msm.c b/drivers/serial/serial_msm.c index 024c2c956e47..d8c6c2f6b5fc 100644 --- a/drivers/serial/serial_msm.c +++ b/drivers/serial/serial_msm.c @@ -15,6 +15,7 @@ #include <malloc.h> #include <serial.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/compiler.h> #include <dm/pinctrl.h> diff --git a/drivers/serial/serial_mtk.c b/drivers/serial/serial_mtk.c index 665b2aa3b2c9..6d416021deef 100644 --- a/drivers/serial/serial_mtk.c +++ b/drivers/serial/serial_mtk.c @@ -14,6 +14,7 @@ #include <log.h> #include <serial.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/types.h> #include <linux/err.h> diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index e5795da99d95..e4970a169bd8 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -9,6 +9,7 @@ #include <watchdog.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> +#include <asm/global_data.h> #include <dm/platform_data/serial_mxc.h> #include <serial.h> #include <linux/compiler.h> diff --git a/drivers/serial/serial_ns16550.c b/drivers/serial/serial_ns16550.c index b5beca976d35..97b6a4ff40d2 100644 --- a/drivers/serial/serial_ns16550.c +++ b/drivers/serial/serial_ns16550.c @@ -8,6 +8,7 @@ #include <clock_legacy.h> #include <ns16550.h> #include <serial.h> +#include <asm/global_data.h> #include <linux/compiler.h>
#ifndef CONFIG_NS16550_MIN_FUNCTIONS diff --git a/drivers/serial/serial_pic32.c b/drivers/serial/serial_pic32.c index 5d1dbe7a9179..ccdda9f03344 100644 --- a/drivers/serial/serial_pic32.c +++ b/drivers/serial/serial_pic32.c @@ -9,6 +9,7 @@ #include <malloc.h> #include <serial.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <mach/pic32.h> #include <dt-bindings/clock/microchip,clock.h> diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index b21e943d2106..4f9de0da767f 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -11,6 +11,7 @@ /* Simple U-Boot driver for the PrimeCell PL010/PL011 UARTs */
#include <common.h> +#include <asm/global_data.h> /* For get_bus_freq() */ #include <clock_legacy.h> #include <dm.h> diff --git a/drivers/serial/serial_pxa.c b/drivers/serial/serial_pxa.c index 669841ede4d7..330fc127ecb3 100644 --- a/drivers/serial/serial_pxa.c +++ b/drivers/serial/serial_pxa.c @@ -23,6 +23,7 @@ #include <hang.h> #include <asm/arch/pxa-regs.h> #include <asm/arch/regs-uart.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <dm/platform_data/serial_pxa.h> diff --git a/drivers/serial/serial_s5p.c b/drivers/serial/serial_s5p.c index 0eac0d53a50a..6d09952a5dcb 100644 --- a/drivers/serial/serial_s5p.c +++ b/drivers/serial/serial_s5p.c @@ -11,6 +11,7 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/io.h> #include <asm/arch/clk.h> diff --git a/drivers/serial/serial_sh.c b/drivers/serial/serial_sh.c index d74f89023366..e6c23cedff11 100644 --- a/drivers/serial/serial_sh.c +++ b/drivers/serial/serial_sh.c @@ -10,6 +10,7 @@ #include <errno.h> #include <clk.h> #include <dm.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/processor.h> #include <serial.h> diff --git a/drivers/serial/serial_sifive.c b/drivers/serial/serial_sifive.c index d26fe7e77043..23790707f937 100644 --- a/drivers/serial/serial_sifive.c +++ b/drivers/serial/serial_sifive.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <log.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/compiler.h> #include <serial.h> diff --git a/drivers/serial/serial_sti_asc.c b/drivers/serial/serial_sti_asc.c index 5d1a46c6bced..2cada4efbfc1 100644 --- a/drivers/serial/serial_sti_asc.c +++ b/drivers/serial/serial_sti_asc.c @@ -10,6 +10,7 @@ #include <dm.h> #include <log.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/serial/serial_xen.c b/drivers/serial/serial_xen.c index dbb7b22b51c7..e1d5b229bd7d 100644 --- a/drivers/serial/serial_xen.c +++ b/drivers/serial/serial_xen.c @@ -8,6 +8,7 @@ #include <dm.h> #include <serial.h> #include <watchdog.h> +#include <asm/global_data.h>
diff --git a/drivers/smem/msm_smem.c b/drivers/smem/msm_smem.c index 597d425d11f9..ff322805bc9d 100644 --- a/drivers/smem/msm_smem.c +++ b/drivers/smem/msm_smem.c @@ -8,6 +8,7 @@ #include <common.h> #include <errno.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/devres.h> #include <dm/of_access.h> diff --git a/drivers/sound/ivybridge_sound.c b/drivers/sound/ivybridge_sound.c index 492a86cafe15..d982219e06de 100644 --- a/drivers/sound/ivybridge_sound.c +++ b/drivers/sound/ivybridge_sound.c @@ -19,6 +19,7 @@ #include <pch.h> #include <sound.h> #include <linux/bitops.h> +#include <asm/global_data.h>
static int bd82x6x_azalia_probe(struct udevice *dev) { diff --git a/drivers/spi/atcspi200_spi.c b/drivers/spi/atcspi200_spi.c index 0f05158c84c6..634cd565610c 100644 --- a/drivers/spi/atcspi200_spi.c +++ b/drivers/spi/atcspi200_spi.c @@ -11,6 +11,7 @@ #include <log.h> #include <malloc.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h>
diff --git a/drivers/spi/bcmstb_spi.c b/drivers/spi/bcmstb_spi.c index dc4fdacdc997..503c47a2716f 100644 --- a/drivers/spi/bcmstb_spi.c +++ b/drivers/spi/bcmstb_spi.c @@ -5,6 +5,7 @@ * Author: Thomas Fitzsimmons fitzsim@fitzsim.org */
+#include <asm/global_data.h> #include <asm/io.h> #include <command.h> #include <config.h> diff --git a/drivers/spi/ca_sflash.c b/drivers/spi/ca_sflash.c index 84569845b74c..38bddd38619e 100644 --- a/drivers/spi/ca_sflash.c +++ b/drivers/spi/ca_sflash.c @@ -21,6 +21,7 @@ #include <spi.h> #include <spi-mem.h> #include <reset.h> +#include <asm/global_data.h>
diff --git a/drivers/spi/cf_spi.c b/drivers/spi/cf_spi.c index 298f350ef398..6511c0e0e541 100644 --- a/drivers/spi/cf_spi.c +++ b/drivers/spi/cf_spi.c @@ -16,6 +16,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <dm/platform_data/spi_coldfire.h> #include <spi.h> #include <malloc.h> diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c index 53a791ea292e..15557a62306a 100644 --- a/drivers/spi/davinci_spi.c +++ b/drivers/spi/davinci_spi.c @@ -12,6 +12,7 @@ #include <log.h> #include <spi.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/hardware.h> #include <dm.h> diff --git a/drivers/spi/exynos_spi.c b/drivers/spi/exynos_spi.c index 30b1a77a7328..1bcc3ad318db 100644 --- a/drivers/spi/exynos_spi.c +++ b/drivers/spi/exynos_spi.c @@ -18,6 +18,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/drivers/spi/fsl_dspi.c b/drivers/spi/fsl_dspi.c index c17a5522bccd..8fe3508c6409 100644 --- a/drivers/spi/fsl_dspi.c +++ b/drivers/spi/fsl_dspi.c @@ -9,6 +9,7 @@ * Haikun Wang (B53464@freescale.com) */
+#include <asm/global_data.h> #include <linux/math64.h> #include <common.h> #include <dm.h> diff --git a/drivers/spi/fsl_espi.c b/drivers/spi/fsl_espi.c index abc28e37d2ae..387b5471598c 100644 --- a/drivers/spi/fsl_espi.c +++ b/drivers/spi/fsl_espi.c @@ -15,6 +15,7 @@
#include <malloc.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/immap_85xx.h> #include <dm.h> #include <errno.h> diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 8bc7038a82ad..c27c60674b62 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -29,6 +29,7 @@ #include <log.h> #include <spi.h> #include <spi-mem.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/libfdt.h> diff --git a/drivers/spi/mvebu_a3700_spi.c b/drivers/spi/mvebu_a3700_spi.c index c40d7d17be47..b1dce048ad24 100644 --- a/drivers/spi/mvebu_a3700_spi.c +++ b/drivers/spi/mvebu_a3700_spi.c @@ -12,6 +12,7 @@ #include <spi.h> #include <clk.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <linux/bitops.h> diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 553a0315df5d..bb68eb90e919 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -9,6 +9,7 @@ #include <log.h> #include <malloc.h> #include <spi.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index 74931768c0fc..c69f8fee6e57 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -20,6 +20,7 @@ #include <dm.h> #include <spi.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <omap3_spi.h> diff --git a/drivers/spi/pic32_spi.c b/drivers/spi/pic32_spi.c index 34d7d3e2ac32..45f07f083da8 100644 --- a/drivers/spi/pic32_spi.c +++ b/drivers/spi/pic32_spi.c @@ -10,6 +10,7 @@ #include <clk.h> #include <dm.h> #include <log.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/compat.h> #include <malloc.h> diff --git a/drivers/spi/pl022_spi.c b/drivers/spi/pl022_spi.c index 133363ea7d9e..9856a5669ca1 100644 --- a/drivers/spi/pl022_spi.c +++ b/drivers/spi/pl022_spi.c @@ -14,6 +14,7 @@ #include <dm.h> #include <dm/platform_data/spi_pl022.h> #include <linux/io.h> +#include <asm/global_data.h> #include <spi.h>
#define SSP_CR0 0x000 diff --git a/drivers/spi/renesas_rpc_spi.c b/drivers/spi/renesas_rpc_spi.c index 105765168e52..26b6aa85c92b 100644 --- a/drivers/spi/renesas_rpc_spi.c +++ b/drivers/spi/renesas_rpc_spi.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk.h> #include <dm.h> diff --git a/drivers/spi/soft_spi.c b/drivers/spi/soft_spi.c index 3425d9950a81..f3602a25ba30 100644 --- a/drivers/spi/soft_spi.c +++ b/drivers/spi/soft_spi.c @@ -16,6 +16,7 @@ #include <log.h> #include <malloc.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/spi/spi-sunxi.c b/drivers/spi/spi-sunxi.c index 11453800788e..4ca5d3a93acf 100644 --- a/drivers/spi/spi-sunxi.c +++ b/drivers/spi/spi-sunxi.c @@ -27,6 +27,7 @@ #include <fdt_support.h> #include <reset.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h>
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 3fe351f8a706..7155d4aebd6d 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -12,6 +12,7 @@ #include <malloc.h> #include <spi.h> #include <dm/device_compat.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> #include <dm/lists.h> diff --git a/drivers/spi/tegra20_sflash.c b/drivers/spi/tegra20_sflash.c index 4384a48ec849..10e38cf839dc 100644 --- a/drivers/spi/tegra20_sflash.c +++ b/drivers/spi/tegra20_sflash.c @@ -10,6 +10,7 @@ #include <errno.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/clock.h> diff --git a/drivers/spi/tegra20_slink.c b/drivers/spi/tegra20_slink.c index 3057fe1a2226..209ba8b0ccf2 100644 --- a/drivers/spi/tegra20_slink.c +++ b/drivers/spi/tegra20_slink.c @@ -9,6 +9,7 @@ #include <dm.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch-tegra/clk_rst.h> diff --git a/drivers/spi/tegra210_qspi.c b/drivers/spi/tegra210_qspi.c index b464b9ccb0ef..5c8c1859cc96 100644 --- a/drivers/spi/tegra210_qspi.c +++ b/drivers/spi/tegra210_qspi.c @@ -10,6 +10,7 @@ #include <dm.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch-tegra/clk_rst.h> diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index 76bc480f4335..c542f40c7df6 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -9,6 +9,7 @@ #include <cpu_func.h> #include <log.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/omap.h> #include <malloc.h> diff --git a/drivers/spi/uniphier_spi.c b/drivers/spi/uniphier_spi.c index e47ed5b221b2..fcc1bfe64b65 100644 --- a/drivers/spi/uniphier_spi.c +++ b/drivers/spi/uniphier_spi.c @@ -9,6 +9,7 @@ #include <dm.h> #include <log.h> #include <time.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitfield.h> #include <linux/bitops.h> diff --git a/drivers/spi/zynq_qspi.c b/drivers/spi/zynq_qspi.c index 845f2d2f5f41..3d829bcb73be 100644 --- a/drivers/spi/zynq_qspi.c +++ b/drivers/spi/zynq_qspi.c @@ -13,6 +13,7 @@ #include <log.h> #include <malloc.h> #include <spi.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/spi/zynq_spi.c b/drivers/spi/zynq_spi.c index 2971e55f41b1..52b8fbc8744a 100644 --- a/drivers/spi/zynq_spi.c +++ b/drivers/spi/zynq_spi.c @@ -14,6 +14,7 @@ #include <spi.h> #include <time.h> #include <clk.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/spi/zynqmp_gqspi.c b/drivers/spi/zynqmp_gqspi.c index efcbd0557fbd..f669974af17b 100644 --- a/drivers/spi/zynqmp_gqspi.c +++ b/drivers/spi/zynqmp_gqspi.c @@ -10,6 +10,7 @@ #include <log.h> #include <asm/arch/sys_proto.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <clk.h> #include <dm.h> diff --git a/drivers/spmi/spmi-msm.c b/drivers/spmi/spmi-msm.c index 7f21443f6ae3..5a335e50aa64 100644 --- a/drivers/spmi/spmi-msm.c +++ b/drivers/spmi/spmi-msm.c @@ -11,6 +11,7 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <spmi/spmi.h> diff --git a/drivers/sysreset/sysreset-uclass.c b/drivers/sysreset/sysreset-uclass.c index e69fb2255b6a..a9908ebf7956 100644 --- a/drivers/sysreset/sysreset-uclass.c +++ b/drivers/sysreset/sysreset-uclass.c @@ -21,6 +21,7 @@ #include <dm/root.h> #include <linux/delay.h> #include <linux/err.h> +#include <asm/global_data.h>
int sysreset_request(struct udevice *dev, enum sysreset_t type) { diff --git a/drivers/sysreset/sysreset_mpc83xx.c b/drivers/sysreset/sysreset_mpc83xx.c index 4e89971840f2..81fccf957679 100644 --- a/drivers/sysreset/sysreset_mpc83xx.c +++ b/drivers/sysreset/sysreset_mpc83xx.c @@ -11,6 +11,7 @@ #include <sysreset.h> #include <wait_bit.h> #include <linux/delay.h> +#include <asm/global_data.h>
#include "sysreset_mpc83xx.h"
diff --git a/drivers/sysreset/sysreset_sti.c b/drivers/sysreset/sysreset_sti.c index 29e88dbcd10c..f0f445f22edc 100644 --- a/drivers/sysreset/sysreset_sti.c +++ b/drivers/sysreset/sysreset_sti.c @@ -9,6 +9,7 @@ #include <regmap.h> #include <syscon.h> #include <sysreset.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h>
diff --git a/drivers/thermal/imx_scu_thermal.c b/drivers/thermal/imx_scu_thermal.c index b785be7bd050..e704bcbea869 100644 --- a/drivers/thermal/imx_scu_thermal.c +++ b/drivers/thermal/imx_scu_thermal.c @@ -9,6 +9,7 @@ #include <errno.h> #include <log.h> #include <thermal.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/device.h> #include <asm/arch/sci/sci.h> diff --git a/drivers/thermal/imx_tmu.c b/drivers/thermal/imx_tmu.c index 1bd0340410ac..02cefecd0d22 100644 --- a/drivers/thermal/imx_tmu.c +++ b/drivers/thermal/imx_tmu.c @@ -6,6 +6,7 @@
#include <config.h> #include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> diff --git a/drivers/timer/arc_timer.c b/drivers/timer/arc_timer.c index 904950457c7f..497f8a04155f 100644 --- a/drivers/timer/arc_timer.c +++ b/drivers/timer/arc_timer.c @@ -8,6 +8,7 @@ #include <errno.h> #include <timer.h> #include <asm/arcregs.h> +#include <asm/global_data.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/timer/cadence-ttc.c b/drivers/timer/cadence-ttc.c index 3cac2ec4220d..2f95d45ecd7a 100644 --- a/drivers/timer/cadence-ttc.c +++ b/drivers/timer/cadence-ttc.c @@ -9,6 +9,7 @@ #include <errno.h> #include <init.h> #include <timer.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <linux/err.h> diff --git a/drivers/timer/mpc83xx_timer.c b/drivers/timer/mpc83xx_timer.c index 2f2b8be3dca9..f4f6e9038739 100644 --- a/drivers/timer/mpc83xx_timer.c +++ b/drivers/timer/mpc83xx_timer.c @@ -14,6 +14,7 @@ #include <time.h> #include <timer.h> #include <watchdog.h> +#include <asm/global_data.h> #include <asm/ptrace.h> #include <linux/bitops.h>
diff --git a/drivers/timer/ostm_timer.c b/drivers/timer/ostm_timer.c index 99bd36f9f251..24813de26530 100644 --- a/drivers/timer/ostm_timer.c +++ b/drivers/timer/ostm_timer.c @@ -7,6 +7,7 @@
#include <common.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <clk.h> diff --git a/drivers/timer/rockchip_timer.c b/drivers/timer/rockchip_timer.c index 8d3eceb8d8d2..18c61450aff5 100644 --- a/drivers/timer/rockchip_timer.c +++ b/drivers/timer/rockchip_timer.c @@ -8,6 +8,7 @@ #include <dm.h> #include <init.h> #include <log.h> +#include <asm/global_data.h> #include <dm/ofnode.h> #include <mapmem.h> #include <asm/arch-rockchip/timer.h> diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index da1a72f0252b..6f00a5d0dba2 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -7,6 +7,7 @@ #include <clk.h> #include <cpu.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/device_compat.h> #include <dm/device-internal.h> diff --git a/drivers/timer/tsc_timer.c b/drivers/timer/tsc_timer.c index 7d0fc66cc75a..7d19a99622b5 100644 --- a/drivers/timer/tsc_timer.c +++ b/drivers/timer/tsc_timer.c @@ -14,6 +14,7 @@ #include <time.h> #include <timer.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/i8254.h> #include <asm/ibmpc.h> diff --git a/drivers/usb/common/common.c b/drivers/usb/common/common.c index 5e5c3c3e3dc9..2a47f40bbabb 100644 --- a/drivers/usb/common/common.c +++ b/drivers/usb/common/common.c @@ -8,6 +8,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <linux/usb/otg.h> #include <linux/usb/ch9.h> #include <linux/usb/phy.h> diff --git a/drivers/usb/host/dwc3-octeon-glue.c b/drivers/usb/host/dwc3-octeon-glue.c index 742e156cbb94..975f375e15ad 100644 --- a/drivers/usb/host/dwc3-octeon-glue.c +++ b/drivers/usb/host/dwc3-octeon-glue.c @@ -12,6 +12,7 @@ #include <dm.h> #include <errno.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/device_compat.h> #include <dm/lists.h> diff --git a/drivers/usb/host/dwc3-sti-glue.c b/drivers/usb/host/dwc3-sti-glue.c index 1234399f33b3..239b671ac381 100644 --- a/drivers/usb/host/dwc3-sti-glue.c +++ b/drivers/usb/host/dwc3-sti-glue.c @@ -8,6 +8,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm.h> #include <errno.h> diff --git a/drivers/usb/host/ehci-exynos.c b/drivers/usb/host/ehci-exynos.c index fda04c493359..c1cdd4b0889a 100644 --- a/drivers/usb/host/ehci-exynos.c +++ b/drivers/usb/host/ehci-exynos.c @@ -10,6 +10,7 @@ #include <dm.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <malloc.h> diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c index 8e79bdd84722..cf1f882441bf 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/drivers/usb/host/ehci-fsl.c @@ -12,6 +12,7 @@ #include <log.h> #include <pci.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h> #include <usb/ehci-ci.h> diff --git a/drivers/usb/host/ehci-marvell.c b/drivers/usb/host/ehci-marvell.c index 3ecbfd032ff8..5420bb9772b5 100644 --- a/drivers/usb/host/ehci-marvell.c +++ b/drivers/usb/host/ehci-marvell.c @@ -7,6 +7,7 @@
#include <common.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <usb.h> #include <linux/delay.h> diff --git a/drivers/usb/host/ehci-mx5.c b/drivers/usb/host/ehci-mx5.c index 0af02ba27378..ab863f41b24e 100644 --- a/drivers/usb/host/ehci-mx5.c +++ b/drivers/usb/host/ehci-mx5.c @@ -11,6 +11,7 @@ #include <linux/compiler.h> #include <linux/delay.h> #include <usb/ehci-ci.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index ef3a63afa440..aeea5399995f 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -9,6 +9,7 @@ #include <usb.h> #include <errno.h> #include <wait_bit.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <linux/delay.h> #include <usb/ehci-ci.h> diff --git a/drivers/usb/host/ehci-vf.c b/drivers/usb/host/ehci-vf.c index 25f76c9fa918..648e136447d9 100644 --- a/drivers/usb/host/ehci-vf.c +++ b/drivers/usb/host/ehci-vf.c @@ -11,6 +11,7 @@ #include <log.h> #include <usb.h> #include <errno.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <asm/io.h> #include <asm-generic/gpio.h> diff --git a/drivers/usb/host/xhci-exynos5.c b/drivers/usb/host/xhci-exynos5.c index 9893a8ccceeb..270be934e7fc 100644 --- a/drivers/usb/host/xhci-exynos5.c +++ b/drivers/usb/host/xhci-exynos5.c @@ -16,6 +16,7 @@ #include <dm.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <malloc.h> diff --git a/drivers/usb/musb-new/da8xx.c b/drivers/usb/musb-new/da8xx.c index f42803533d73..68fc0c36146d 100644 --- a/drivers/usb/musb-new/da8xx.c +++ b/drivers/usb/musb-new/da8xx.c @@ -23,6 +23,7 @@ #include <asm/arch/da8xx-usb.h> #include <linux/delay.h> #include <linux/usb/otg.h> +#include <asm/global_data.h> #include <asm/omap_musb.h> #include <generic-phy.h> #include "linux-compat.h" diff --git a/drivers/usb/musb-new/omap2430.c b/drivers/usb/musb-new/omap2430.c index 3fdcaeaa5d01..7d15b94a6c43 100644 --- a/drivers/usb/musb-new/omap2430.c +++ b/drivers/usb/musb-new/omap2430.c @@ -17,6 +17,7 @@ #include <dm/lists.h> #include <linux/err.h> #include <linux/usb/otg.h> +#include <asm/global_data.h> #include <asm/omap_common.h> #include <asm/omap_musb.h> #include <twl4030.h> diff --git a/drivers/usb/musb-new/pic32.c b/drivers/usb/musb-new/pic32.c index b833f10f4bab..4ed5e6e90c6c 100644 --- a/drivers/usb/musb-new/pic32.c +++ b/drivers/usb/musb-new/pic32.c @@ -11,6 +11,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/usb/musb-new/ti-musb.c b/drivers/usb/musb-new/ti-musb.c index 75cf1811f7aa..91042935b07b 100644 --- a/drivers/usb/musb-new/ti-musb.c +++ b/drivers/usb/musb-new/ti-musb.c @@ -11,6 +11,7 @@ #include <dm.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/usb/otg.h> #include <dm/device-internal.h> #include <dm/lists.h> diff --git a/drivers/usb/phy/rockchip_usb2_phy.c b/drivers/usb/phy/rockchip_usb2_phy.c index f1cf9160d565..93caa821a1d2 100644 --- a/drivers/usb/phy/rockchip_usb2_phy.c +++ b/drivers/usb/phy/rockchip_usb2_phy.c @@ -6,6 +6,7 @@ #include <common.h> #include <hang.h> #include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/video/atmel_hlcdfb.c b/drivers/video/atmel_hlcdfb.c index 0485ae24366f..c7b59b71e1d7 100644 --- a/drivers/video/atmel_hlcdfb.c +++ b/drivers/video/atmel_hlcdfb.c @@ -10,6 +10,7 @@ #include <log.h> #include <malloc.h> #include <part.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> diff --git a/drivers/video/atmel_lcdfb.c b/drivers/video/atmel_lcdfb.c index f87c0224a1ab..c38cac174ab8 100644 --- a/drivers/video/atmel_lcdfb.c +++ b/drivers/video/atmel_lcdfb.c @@ -12,6 +12,7 @@ #include <log.h> #include <part.h> #include <video.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> diff --git a/drivers/video/bridge/ps862x.c b/drivers/video/bridge/ps862x.c index 76115b7bc561..c8e105857fd9 100644 --- a/drivers/video/bridge/ps862x.c +++ b/drivers/video/bridge/ps862x.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <log.h> #include <video_bridge.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <power/regulator.h>
diff --git a/drivers/video/broadwell_igd.c b/drivers/video/broadwell_igd.c index cba105c19a4e..2551f162e8f9 100644 --- a/drivers/video/broadwell_igd.c +++ b/drivers/video/broadwell_igd.c @@ -14,6 +14,7 @@ #include <vbe.h> #include <video.h> #include <asm/cpu.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/mtrr.h> diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 3f07f4eb297f..27ff7163f348 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -74,6 +74,7 @@ #include <version.h> #include <malloc.h> #include <video.h> +#include <asm/global_data.h> #include <linux/compiler.h>
#if defined(CONFIG_VIDEO_MXS) diff --git a/drivers/video/da8xx-fb.c b/drivers/video/da8xx-fb.c index 4984dda8477d..462c318126dd 100644 --- a/drivers/video/da8xx-fb.c +++ b/drivers/video/da8xx-fb.c @@ -17,6 +17,7 @@ #include <malloc.h> #include <memalign.h> #include <video_fb.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/list.h> #include <linux/fb.h> diff --git a/drivers/video/exynos/exynos_dp.c b/drivers/video/exynos/exynos_dp.c index 63b5b8e61a27..a532d5ae1abb 100644 --- a/drivers/video/exynos/exynos_dp.c +++ b/drivers/video/exynos/exynos_dp.c @@ -11,6 +11,7 @@ #include <display.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <malloc.h> diff --git a/drivers/video/exynos/exynos_fb.c b/drivers/video/exynos/exynos_fb.c index 7b4459ced853..69992b3c2ba0 100644 --- a/drivers/video/exynos/exynos_fb.c +++ b/drivers/video/exynos/exynos_fb.c @@ -13,6 +13,7 @@ #include <dm.h> #include <fdtdec.h> #include <log.h> +#include <asm/global_data.h> #include <linux/libfdt.h> #include <panel.h> #include <video.h> diff --git a/drivers/video/exynos/exynos_mipi_dsi.c b/drivers/video/exynos/exynos_mipi_dsi.c index 042aa9a5b9eb..c56eadc8237b 100644 --- a/drivers/video/exynos/exynos_mipi_dsi.c +++ b/drivers/video/exynos/exynos_mipi_dsi.c @@ -10,6 +10,7 @@ #include <log.h> #include <malloc.h> #include <fdtdec.h> +#include <asm/global_data.h> #include <dm/devres.h> #include <linux/libfdt.h> #include <linux/compat.h> diff --git a/drivers/video/fsl_dcu_fb.c b/drivers/video/fsl_dcu_fb.c index 4ea0f1248701..dc5b24c98bb8 100644 --- a/drivers/video/fsl_dcu_fb.c +++ b/drivers/video/fsl_dcu_fb.c @@ -8,6 +8,7 @@
#include <init.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <dm.h> diff --git a/drivers/video/ivybridge_igd.c b/drivers/video/ivybridge_igd.c index e7db0cbcef15..1aa5317dd5f3 100644 --- a/drivers/video/ivybridge_igd.c +++ b/drivers/video/ivybridge_igd.c @@ -12,6 +12,7 @@ #include <pci_rom.h> #include <vbe.h> #include <video.h> +#include <asm/global_data.h> #include <asm/intel_regs.h> #include <asm/io.h> #include <asm/mtrr.h> diff --git a/drivers/video/mali_dp.c b/drivers/video/mali_dp.c index dc4f542256d7..ba1ddd64e08c 100644 --- a/drivers/video/mali_dp.c +++ b/drivers/video/mali_dp.c @@ -13,6 +13,7 @@ #include <display.h> #endif #include <fdtdec.h> +#include <asm/global_data.h> #include <asm/io.h> #include <os.h> #include <fdt_support.h> diff --git a/drivers/video/meson/meson_vpu.c b/drivers/video/meson/meson_vpu.c index ca6933a6c54f..e39844571f89 100644 --- a/drivers/video/meson/meson_vpu.c +++ b/drivers/video/meson/meson_vpu.c @@ -15,6 +15,7 @@ #include <part.h> #include <linux/sizes.h> #include <asm/arch/mem.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h>
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index b43732a77ab3..e1fd36a62d6a 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -20,6 +20,7 @@ #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/mach-imx/dma.h> #include <asm/io.h>
diff --git a/drivers/video/rockchip/rk3288_vop.c b/drivers/video/rockchip/rk3288_vop.c index 3f6ee744871c..44f32bb5fa2b 100644 --- a/drivers/video/rockchip/rk3288_vop.c +++ b/drivers/video/rockchip/rk3288_vop.c @@ -11,6 +11,7 @@ #include <regmap.h> #include <syscon.h> #include <video.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/grf_rk3288.h> diff --git a/drivers/video/rockchip/rk3399_vop.c b/drivers/video/rockchip/rk3399_vop.c index 30e81b88b690..a34b491058f2 100644 --- a/drivers/video/rockchip/rk3399_vop.c +++ b/drivers/video/rockchip/rk3399_vop.c @@ -12,6 +12,7 @@ #include <regmap.h> #include <video.h> #include <asm/arch-rockchip/hardware.h> +#include <asm/global_data.h> #include <asm/io.h> #include "rk_vop.h"
diff --git a/drivers/video/rockchip/rk_lvds.c b/drivers/video/rockchip/rk_lvds.c index 03c8257a3572..9cf3e3ca7688 100644 --- a/drivers/video/rockchip/rk_lvds.c +++ b/drivers/video/rockchip/rk_lvds.c @@ -11,6 +11,7 @@ #include <panel.h> #include <regmap.h> #include <syscon.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> diff --git a/drivers/video/rockchip/rk_mipi.c b/drivers/video/rockchip/rk_mipi.c index 159201a59168..8813220671d8 100644 --- a/drivers/video/rockchip/rk_mipi.c +++ b/drivers/video/rockchip/rk_mipi.c @@ -11,6 +11,7 @@ #include <log.h> #include <panel.h> #include <regmap.h> +#include <asm/global_data.h> #include "rk_mipi.h" #include <syscon.h> #include <asm/gpio.h> diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index fcb393b906c5..145c3330203b 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -13,6 +13,7 @@ #include <regmap.h> #include <syscon.h> #include <video.h> +#include <asm/global_data.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> diff --git a/drivers/video/sandbox_sdl.c b/drivers/video/sandbox_sdl.c index 12edf9c90c98..5956b59ce49d 100644 --- a/drivers/video/sandbox_sdl.c +++ b/drivers/video/sandbox_sdl.c @@ -8,6 +8,7 @@ #include <fdtdec.h> #include <log.h> #include <video.h> +#include <asm/global_data.h> #include <asm/sdl.h> #include <asm/state.h> #include <asm/u-boot-sandbox.h> diff --git a/drivers/video/simplefb.c b/drivers/video/simplefb.c index b5fb6f62bb78..fd58426cf5d3 100644 --- a/drivers/video/simplefb.c +++ b/drivers/video/simplefb.c @@ -9,6 +9,7 @@ #include <fdt_support.h> #include <log.h> #include <video.h> +#include <asm/global_data.h>
static int simple_video_probe(struct udevice *dev) { diff --git a/drivers/video/sunxi/sunxi_lcd.c b/drivers/video/sunxi/sunxi_lcd.c index 635edf6dd3bb..7a9eba1ed42a 100644 --- a/drivers/video/sunxi/sunxi_lcd.c +++ b/drivers/video/sunxi/sunxi_lcd.c @@ -16,6 +16,7 @@ #include <asm/arch/clock.h> #include <asm/arch/lcdc.h> #include <asm/arch/gpio.h> +#include <asm/global_data.h> #include <asm/gpio.h>
struct sunxi_lcd_priv { diff --git a/drivers/video/tegra.c b/drivers/video/tegra.c index 08b006b469b6..d60132eb7732 100644 --- a/drivers/video/tegra.c +++ b/drivers/video/tegra.c @@ -12,6 +12,7 @@ #include <pwm.h> #include <video.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <asm/system.h> #include <asm/gpio.h> #include <asm/io.h> diff --git a/drivers/video/ti/am335x-fb.c b/drivers/video/ti/am335x-fb.c index 5fa6f794ecce..8b41dac66d0d 100644 --- a/drivers/video/ti/am335x-fb.c +++ b/drivers/video/ti/am335x-fb.c @@ -18,6 +18,7 @@ #include <asm/arch/hardware.h> #include <asm/arch/omap.h> #include <asm/arch/sys_proto.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h> #include <linux/err.h> diff --git a/drivers/video/ti/tilcdc.c b/drivers/video/ti/tilcdc.c index 814126af6664..90c1edd87e6f 100644 --- a/drivers/video/ti/tilcdc.c +++ b/drivers/video/ti/tilcdc.c @@ -11,6 +11,7 @@ #include <log.h> #include <panel.h> #include <video.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/utils.h> #include "tilcdc.h" diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 91d078a9d5f3..96ec6f80af3b 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -14,6 +14,7 @@ #include <video.h> #include <video_console.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/lists.h> #include <dm/device_compat.h> #include <dm/device-internal.h> diff --git a/drivers/video/videomodes.c b/drivers/video/videomodes.c index 89003eea7276..ed7373eac84b 100644 --- a/drivers/video/videomodes.c +++ b/drivers/video/videomodes.c @@ -60,6 +60,7 @@ #include <edid.h> #include <env.h> #include <errno.h> +#include <fdtdec.h> #include <linux/ctype.h>
#include "videomodes.h" diff --git a/drivers/watchdog/armada-37xx-wdt.c b/drivers/watchdog/armada-37xx-wdt.c index dd97a17a7014..6b5e1ab6fc35 100644 --- a/drivers/watchdog/armada-37xx-wdt.c +++ b/drivers/watchdog/armada-37xx-wdt.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <wdt.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> diff --git a/drivers/watchdog/at91sam9_wdt.c b/drivers/watchdog/at91sam9_wdt.c index 9e0d89be62d5..647ae325e9ae 100644 --- a/drivers/watchdog/at91sam9_wdt.c +++ b/drivers/watchdog/at91sam9_wdt.c @@ -15,6 +15,7 @@ */
#include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/arch/at91_wdt.h> #include <common.h> diff --git a/drivers/watchdog/mt7621_wdt.c b/drivers/watchdog/mt7621_wdt.c index 8b5ed28ebd30..f7d201b921a1 100644 --- a/drivers/watchdog/mt7621_wdt.c +++ b/drivers/watchdog/mt7621_wdt.c @@ -12,6 +12,7 @@ #include <common.h> #include <dm.h> #include <wdt.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/io.h>
diff --git a/drivers/watchdog/octeontx_wdt.c b/drivers/watchdog/octeontx_wdt.c index 5f586ef68379..01b244db8075 100644 --- a/drivers/watchdog/octeontx_wdt.c +++ b/drivers/watchdog/octeontx_wdt.c @@ -9,6 +9,7 @@ #include <dm.h> #include <errno.h> #include <wdt.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/bitfield.h>
diff --git a/drivers/watchdog/orion_wdt.c b/drivers/watchdog/orion_wdt.c index 167af904dc22..cebea426fbb6 100644 --- a/drivers/watchdog/orion_wdt.c +++ b/drivers/watchdog/orion_wdt.c @@ -17,6 +17,7 @@ #include <clk.h> #include <log.h> #include <wdt.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/kernel.h> #include <asm/io.h> diff --git a/drivers/watchdog/sbsa_gwdt.c b/drivers/watchdog/sbsa_gwdt.c index b7cb199c9238..f43cd3fd2fb2 100644 --- a/drivers/watchdog/sbsa_gwdt.c +++ b/drivers/watchdog/sbsa_gwdt.c @@ -5,6 +5,7 @@ * Copyright 2020 NXP */
+#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <dm/device.h> diff --git a/drivers/watchdog/sp805_wdt.c b/drivers/watchdog/sp805_wdt.c index 291aad757012..bec8827ceb15 100644 --- a/drivers/watchdog/sp805_wdt.c +++ b/drivers/watchdog/sp805_wdt.c @@ -6,6 +6,7 @@ */
#include <log.h> +#include <asm/global_data.h> #include <asm/io.h> #include <common.h> #include <clk.h> diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index e632f077f342..28f7918c4673 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -10,6 +10,7 @@ #include <log.h> #include <time.h> #include <wdt.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h>
diff --git a/drivers/xen/gnttab.c b/drivers/xen/gnttab.c index 9bf1091ab321..778729d646e1 100644 --- a/drivers/xen/gnttab.c +++ b/drivers/xen/gnttab.c @@ -15,6 +15,7 @@ * [1] - http://xenbits.xen.org/gitweb/?p=mini-os.git;a=summary */ #include <common.h> +#include <asm/global_data.h> #include <linux/compiler.h> #include <log.h> #include <malloc.h> diff --git a/drivers/xen/pvblock.c b/drivers/xen/pvblock.c index 6455dfd5c963..1c5d039ef052 100644 --- a/drivers/xen/pvblock.c +++ b/drivers/xen/pvblock.c @@ -11,6 +11,7 @@ #include <part.h>
#include <asm/armv8/mmu.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/xen/system.h>
diff --git a/env/callback.c b/env/callback.c index 4054b9ef58b3..638a02b28f78 100644 --- a/env/callback.c +++ b/env/callback.c @@ -7,6 +7,7 @@ #include <common.h> #include <env.h> #include <env_internal.h> +#include <asm/global_data.h>
#if defined(CONFIG_NEEDS_MANUAL_RELOC) DECLARE_GLOBAL_DATA_PTR; diff --git a/env/common.c b/env/common.c index 6c32a9b47960..2ee423beb5c8 100644 --- a/env/common.c +++ b/env/common.c @@ -14,6 +14,7 @@ #include <env_internal.h> #include <log.h> #include <sort.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <search.h> #include <errno.h> diff --git a/env/eeprom.c b/env/eeprom.c index e300470ad0fc..ba168014e248 100644 --- a/env/eeprom.c +++ b/env/eeprom.c @@ -12,6 +12,7 @@ #include <eeprom.h> #include <env.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <u-boot/crc.h> #if defined(CONFIG_I2C_ENV_EEPROM_BUS) diff --git a/env/env.c b/env/env.c index 37b4b54cb75f..caefa33e1d48 100644 --- a/env/env.c +++ b/env/env.c @@ -8,6 +8,7 @@ #include <env.h> #include <env_internal.h> #include <log.h> +#include <asm/global_data.h> #include <linux/bitops.h> #include <linux/bug.h>
diff --git a/env/ext4.c b/env/ext4.c index e666f7b9455a..ec643f2226ab 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -31,6 +31,7 @@ #include <errno.h> #include <ext4fs.h> #include <mmc.h> +#include <asm/global_data.h>
diff --git a/env/flash.c b/env/flash.c index 722d5adf8b69..ebee9069e4e3 100644 --- a/env/flash.c +++ b/env/flash.c @@ -15,6 +15,7 @@ #include <env_internal.h> #include <flash.h> #include <log.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <malloc.h> #include <search.h> diff --git a/env/mmc.c b/env/mmc.c index ee376c3e0c3c..9b226be1d5bf 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -6,6 +6,7 @@ /* #define DEBUG */
#include <command.h> #include <env.h> diff --git a/env/nand.c b/env/nand.c index 0d7ee19bc232..be82e97d69cd 100644 --- a/env/nand.c +++ b/env/nand.c @@ -17,6 +17,7 @@ #include <command.h> #include <env.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <malloc.h> #include <memalign.h> diff --git a/env/nowhere.c b/env/nowhere.c index d43a2d6b513f..41557f5ce44f 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -11,6 +11,7 @@ #include <command.h> #include <env.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/env/nvram.c b/env/nvram.c index 7c8ea26f9682..f4126858b5b4 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -27,6 +27,7 @@ #include <command.h> #include <env.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <search.h> #include <errno.h> diff --git a/env/onenand.c b/env/onenand.c index a2477cef9bed..c8da3ff8114b 100644 --- a/env/onenand.c +++ b/env/onenand.c @@ -10,6 +10,7 @@ #include <common.h> #include <command.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <malloc.h> #include <search.h> diff --git a/env/remote.c b/env/remote.c index d93a137376e3..166bebf52b5b 100644 --- a/env/remote.c +++ b/env/remote.c @@ -8,6 +8,7 @@ #include <common.h> #include <command.h> #include <env_internal.h> +#include <asm/global_data.h> #include <linux/stddef.h> #include <u-boot/crc.h>
diff --git a/env/sf.c b/env/sf.c index 42d762714eca..88ec1108b681 100644 --- a/env/sf.c +++ b/env/sf.c @@ -20,6 +20,7 @@ #include <errno.h> #include <uuid.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <u-boot/crc.h>
diff --git a/env/ubi.c b/env/ubi.c index 5502efe28b62..eb21c4f38b49 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -5,6 +5,7 @@ */
#include <command.h> #include <env.h> diff --git a/fs/fs.c b/fs/fs.c index 0c8f577a798a..900928c39459 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -20,6 +20,7 @@ #include <sandboxfs.h> #include <ubifs_uboot.h> #include <btrfs.h> +#include <asm/global_data.h> #include <asm/io.h> #include <div64.h> #include <linux/math64.h> diff --git a/fs/reiserfs/reiserfs_private.h b/fs/reiserfs/reiserfs_private.h index c8867e24fefa..5936f2140056 100644 --- a/fs/reiserfs/reiserfs_private.h +++ b/fs/reiserfs/reiserfs_private.h @@ -15,6 +15,8 @@ * from the original reiser fs code, as found in the linux kernel. */
+#include <compiler.h> + #ifndef __BYTE_ORDER #if defined(__LITTLE_ENDIAN) && !defined(__BIG_ENDIAN) #define __BYTE_ORDER __LITTLE_ENDIAN diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 70beb848e1b0..d6be5c947d7e 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -17,6 +17,7 @@ #include <log.h> #include <malloc.h> #include <memalign.h> +#include <asm/global_data.h> #include "ubifs.h" #include <part.h> #include <dm/devres.h> diff --git a/include/audio_codec.h b/include/audio_codec.h index 258709954693..2ea4ff096e62 100644 --- a/include/audio_codec.h +++ b/include/audio_codec.h @@ -7,6 +7,8 @@ #ifndef __AUDIO_CODEC_H__ #define __AUDIO_CODEC_H__
+struct udevice; + /* * An audio codec turns digital data into sound with various parameters to * control its operation. diff --git a/include/axi.h b/include/axi.h index 3e40692cdfda..59fb0b2e4584 100644 --- a/include/axi.h +++ b/include/axi.h @@ -7,6 +7,8 @@ #ifndef _AXI_H_ #define _AXI_H_
+struct udevice; + /** * enum axi_size_t - Determine size of AXI transfer * @AXI_SIZE_8: AXI sransfer is 8-bit wide diff --git a/include/backlight.h b/include/backlight.h index ac59eb293b45..b44da50bc306 100644 --- a/include/backlight.h +++ b/include/backlight.h @@ -7,6 +7,8 @@ #ifndef _BACKLIGHT_H #define _BACKLIGHT_H
+struct udevice; + enum { BACKLIGHT_MAX = 100, BACKLIGHT_MIN = 0, diff --git a/include/bootcount.h b/include/bootcount.h index b1d1fe53d1a9..796b237c8f61 100644 --- a/include/bootcount.h +++ b/include/bootcount.h @@ -7,6 +7,7 @@ #define _BOOTCOUNT_H__
#include <common.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/byteorder.h> #include <env.h> diff --git a/include/cache.h b/include/cache.h index 32f59fd8f714..ecb7956efd5c 100644 --- a/include/cache.h +++ b/include/cache.h @@ -6,6 +6,8 @@ #ifndef __CACHE_H #define __CACHE_H
+struct udevice; + /* * Structure for the cache controller */ diff --git a/include/common.h b/include/common.h index f0679ac70544..71df59bca0e5 100644 --- a/include/common.h +++ b/include/common.h @@ -23,7 +23,6 @@ #include <stdio.h> #include <linux/kernel.h> #include <asm/u-boot.h> /* boot information for Linux kernel */ -#include <asm/global_data.h> /* global data used for startup functions */ #include <display_options.h> #include <vsprintf.h> #endif /* __ASSEMBLY__ */ diff --git a/include/cpu.h b/include/cpu.h index 5831bfa74214..be02a1671298 100644 --- a/include/cpu.h +++ b/include/cpu.h @@ -7,6 +7,8 @@ #ifndef __CPU_H #define __CPU_H
+struct udevice; + /** * struct cpu_plat - platform data for a CPU * @cpu_id: Platform-specific way of identifying the CPU. diff --git a/include/dm/acpi.h b/include/dm/acpi.h index e6951b6a25d9..7f1f2ef2cb60 100644 --- a/include/dm/acpi.h +++ b/include/dm/acpi.h @@ -28,6 +28,7 @@ #if !defined(__ACPI__)
struct nhlt; +struct udevice;
/** enum acpi_dump_option - selects what ACPI information to dump */ enum acpi_dump_option { diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 5b088650d3bc..5318d6503579 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -379,6 +379,8 @@ bool ofnode_read_bool(ofnode node, const char *propname); ofnode ofnode_find_subnode(ofnode node, const char *subnode_name);
#if CONFIG_IS_ENABLED(DM_INLINE_OFNODE) +#include <asm/global_data.h> + static inline bool ofnode_is_enabled(ofnode node) { if (ofnode_is_np(node)) { diff --git a/include/dm/read.h b/include/dm/read.h index 03ba98232a61..97575bcad044 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -695,6 +695,7 @@ int dev_decode_display_timing(const struct udevice *dev, int index, struct display_timing *config);
#else /* CONFIG_DM_DEV_READ_INLINE is enabled */ +#include <asm/global_data.h>
static inline int dev_read_u32(const struct udevice *dev, const char *propname, u32 *outp) diff --git a/include/dma.h b/include/dma.h index 6ff591977b14..a64580a61ff7 100644 --- a/include/dma.h +++ b/include/dma.h @@ -13,6 +13,8 @@ #include <linux/errno.h> #include <linux/types.h>
+struct udevice; + /* * enum dma_direction - dma transfer direction indicator * @DMA_MEM_TO_MEM: Memcpy mode diff --git a/include/exports.h b/include/exports.h index faf0f5924432..99436e413252 100644 --- a/include/exports.h +++ b/include/exports.h @@ -2,6 +2,7 @@ #define __EXPORTS_H__
#include <irq_func.h> +#include <asm/global_data.h> #include <linux/delay.h>
#ifndef __ASSEMBLY__ diff --git a/include/ext_common.h b/include/ext_common.h index bc3324172a08..30a0c248414a 100644 --- a/include/ext_common.h +++ b/include/ext_common.h @@ -20,6 +20,8 @@ #ifndef __EXT_COMMON__ #define __EXT_COMMON__
+#include <compiler.h> + struct cmd_tbl;
#define SECTOR_SIZE 0x200 diff --git a/include/fsl_qe.h b/include/fsl_qe.h index 1c6941347f7f..cd8fca95b4a0 100644 --- a/include/fsl_qe.h +++ b/include/fsl_qe.h @@ -20,6 +20,8 @@ #define QE_DATAONLY_BASE 0 #define QE_DATAONLY_SIZE (QE_MURAM_SIZE - QE_DATAONLY_BASE)
+struct udevice; + /* QE threads SNUM */ typedef enum qe_snum_state { diff --git a/include/image-sparse.h b/include/image-sparse.h index 234c237b845f..0572dbd0a283 100644 --- a/include/image-sparse.h +++ b/include/image-sparse.h @@ -3,6 +3,7 @@ * Copyright 2014 Broadcom Corporation. */
+#include <compiler.h> #include <part.h> #include <sparse_format.h>
diff --git a/include/init.h b/include/init.h index 980be2799369..f8f69a54e005 100644 --- a/include/init.h +++ b/include/init.h @@ -10,16 +10,16 @@ #ifndef __INIT_H_ #define __INIT_H_ 1
-#include <linux/types.h> - -struct global_data; - #ifndef __ASSEMBLY__ /* put C only stuff in this section */
+#include <linux/types.h> + /* Avoid using CONFIG_EFI_STUB directly as we may boot from other loaders */ #ifdef CONFIG_EFI_STUB #define ll_boot_init() false #else +#include <asm/global_data.h> + #define ll_boot_init() (!(gd->flags & GD_FLG_SKIP_LL_INIT)) #endif
diff --git a/include/initcall.h b/include/initcall.h index 41b74dc52d2f..69ce26807051 100644 --- a/include/initcall.h +++ b/include/initcall.h @@ -12,6 +12,7 @@ typedef int (*init_fnc_t)(void); #ifdef CONFIG_EFI_APP #include <efi.h> #endif +#include <asm/global_data.h>
/* * To enable debugging. add #define DEBUG at the top of the including file. diff --git a/include/led.h b/include/led.h index 7bfdddfd6fab..02766fa56fb6 100644 --- a/include/led.h +++ b/include/led.h @@ -7,6 +7,8 @@ #ifndef __LED_H #define __LED_H
+struct udevice; + /** * struct led_uc_plat - Platform data the uclass stores about each device * diff --git a/include/misc.h b/include/misc.h index 12d1325ee26e..82ec2ce79368 100644 --- a/include/misc.h +++ b/include/misc.h @@ -6,6 +6,8 @@ #ifndef _MISC_H_ #define _MISC_H_
+struct udevice; + /** * misc_read() - Read the device to buffer, optional. * @dev: the device diff --git a/include/netdev.h b/include/netdev.h index b1eb5fc10467..0ad9f8dc3a5c 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -12,6 +12,8 @@ #define _NETDEV_H_ #include <phy_interface.h>
+struct udevice; + /* * Board and CPU-specific initialization functions * board_eth_init() has highest priority. cpu_eth_init() only diff --git a/include/power/as3722.h b/include/power/as3722.h index 27828570559e..f5398123f2a9 100644 --- a/include/power/as3722.h +++ b/include/power/as3722.h @@ -6,6 +6,8 @@ #ifndef __POWER_AS3722_H__ #define __POWER_AS3722_H__
+struct udevice; + #define AS3722_GPIO_OUTPUT_VDDH (1 << 0) #define AS3722_GPIO_INVERT (1 << 1)
diff --git a/include/power/regulator.h b/include/power/regulator.h index 19a3b7b502a3..da9a065bdde0 100644 --- a/include/power/regulator.h +++ b/include/power/regulator.h @@ -7,6 +7,8 @@ #ifndef _INCLUDE_REGULATOR_H_ #define _INCLUDE_REGULATOR_H_
+struct udevice; + /** * U-Boot Voltage/Current Regulator * ================================ diff --git a/include/pwm.h b/include/pwm.h index 54ae3e64c310..f9959706ceb6 100644 --- a/include/pwm.h +++ b/include/pwm.h @@ -10,6 +10,8 @@ #ifndef _pwm_h_ #define _pwm_h_
+struct udevice; + /* struct pwm_ops: Operations for the PWM uclass */ struct pwm_ops { /** diff --git a/include/ram.h b/include/ram.h index 67e22d76c930..273d41539400 100644 --- a/include/ram.h +++ b/include/ram.h @@ -7,6 +7,8 @@ #ifndef __RAM_H #define __RAM_H
+struct udevice; + struct ram_info { phys_addr_t base; size_t size; diff --git a/include/scsi.h b/include/scsi.h index 90cec99e322b..0a475a8ca4c0 100644 --- a/include/scsi.h +++ b/include/scsi.h @@ -9,6 +9,8 @@ #include <asm/cache.h> #include <linux/dma-direction.h>
+struct udevice; + struct scsi_cmd { unsigned char cmd[16]; /* command */ /* for request sense */ diff --git a/include/soc.h b/include/soc.h index a55eb1b5724e..a52a300a84a6 100644 --- a/include/soc.h +++ b/include/soc.h @@ -9,6 +9,8 @@
#define SOC_MAX_STR_SIZE 128
+struct udevice; + /** * struct soc_attr - Contains SoC identify information to be used in * SoC matching. An array of these structs diff --git a/include/sysinfo.h b/include/sysinfo.h index c045d316b072..c0da4932d4af 100644 --- a/include/sysinfo.h +++ b/include/sysinfo.h @@ -4,6 +4,8 @@ * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc */
+struct udevice; + /* * This uclass encapsulates hardware methods to gather information about a * sysinfo or a specific device such as hard-wired GPIOs on GPIO expanders, diff --git a/include/sysreset.h b/include/sysreset.h index 61295e3fcbb7..8bb094d463b3 100644 --- a/include/sysreset.h +++ b/include/sysreset.h @@ -7,6 +7,8 @@ #ifndef __SYSRESET_H #define __SYSRESET_H
+struct udevice; + enum sysreset_t { SYSRESET_WARM, /* Reset CPU, keep GPIOs active */ SYSRESET_COLD, /* Reset CPU and GPIOs */ diff --git a/include/tee.h b/include/tee.h index 8207d0c02afb..99367b258e29 100644 --- a/include/tee.h +++ b/include/tee.h @@ -7,6 +7,8 @@ #define __TEE_H
#include <linux/bitops.h> +#include <linux/list.h> + #define TEE_UUID_LEN 16
#define TEE_GEN_CAP_GP BIT(0) /* GlobalPlatform compliant TEE */ diff --git a/include/tpm-common.h b/include/tpm-common.h index e29b10b1766e..c1309a2735d1 100644 --- a/include/tpm-common.h +++ b/include/tpm-common.h @@ -9,6 +9,8 @@
+struct udevice; + enum tpm_duration { TPM_SHORT = 0, TPM_MEDIUM = 1, diff --git a/include/tpm-v1.h b/include/tpm-v1.h index 59ad4aecf42c..8f6cc28a9ea6 100644 --- a/include/tpm-v1.h +++ b/include/tpm-v1.h @@ -10,6 +10,8 @@ #include <tpm-common.h> #include <linux/bitops.h>
+struct udevice; + /* Useful constants */ enum { TPM_REQUEST_HEADER_LENGTH = 10, diff --git a/include/tpm-v2.h b/include/tpm-v2.h index fab6b86ca2fa..56eaa65815f2 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -16,6 +16,8 @@
+struct udevice; + #define TPM2_DIGEST_LEN 32
#define TPM2_SHA1_DIGEST_SIZE 20 diff --git a/include/tps6586x.h b/include/tps6586x.h index 785eb39229d0..aa4270c65e33 100644 --- a/include/tps6586x.h +++ b/include/tps6586x.h @@ -7,6 +7,8 @@ #ifndef _TPS6586X_H_ #define _TPS6586X_H_
+struct udevice; + enum { /* SM0-2 PWM/PFM Mode Selection */ TPS6586X_PWM_SM0 = 1 << 0, diff --git a/include/ufs.h b/include/ufs.h index 0592a763dd9f..bda135cf1841 100644 --- a/include/ufs.h +++ b/include/ufs.h @@ -1,6 +1,9 @@ /* SPDX-License-Identifier: GPL-2.0+ */ #ifndef _UFS_H #define _UFS_H + +struct udevice; + /** * ufs_probe() - initialize all devices in the UFS uclass * diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index a0f0961be5bc..2f0774178412 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -13,6 +13,7 @@ #include <tables_csum.h> #include <version.h> #include <acpi/acpi_table.h> +#include <asm/global_data.h> #include <dm/acpi.h>
int acpi_create_dmar(struct acpi_dmar *dmar, enum dmar_flags flags) diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c index b17651ed63d8..ee592cfda1cc 100644 --- a/lib/asm-offsets.c +++ b/lib/asm-offsets.c @@ -13,6 +13,7 @@
#include <common.h> #include <asm-offsets.h> +#include <asm/global_data.h>
#include <linux/kbuild.h>
diff --git a/lib/efi/efi_app.c b/lib/efi/efi_app.c index b7e19c347509..907bacd716a7 100644 --- a/lib/efi/efi_app.c +++ b/lib/efi/efi_app.c @@ -15,6 +15,7 @@ #include <errno.h> #include <init.h> #include <malloc.h> +#include <asm/global_data.h> #include <linux/err.h> #include <linux/types.h> #include <efi.h> diff --git a/lib/efi/efi_info.c b/lib/efi/efi_info.c index 35a8a9325f84..4d78923c4d40 100644 --- a/lib/efi/efi_info.c +++ b/lib/efi/efi_info.c @@ -9,6 +9,7 @@ #include <efi.h> #include <errno.h> #include <mapmem.h> +#include <asm/global_data.h>
int efi_info_get(enum efi_entry_t type, void **datap, int *sizep) { diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index ce658a8e7331..41b8949b0424 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -19,6 +19,7 @@ #include <u-boot/crc.h> #include <usb.h> #include <watchdog.h> +#include <asm/global_data.h> #include <linux/libfdt_env.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/lib/efi_loader/efi_dt_fixup.c b/lib/efi_loader/efi_dt_fixup.c index 3850ab3b0fe6..580551b1f122 100644 --- a/lib/efi_loader/efi_dt_fixup.c +++ b/lib/efi_loader/efi_dt_fixup.c @@ -8,6 +8,7 @@ #include <common.h> #include <efi_dt_fixup.h> #include <efi_loader.h> +#include <fdtdec.h> #include <mapmem.h>
const efi_guid_t efi_guid_dt_fixup_protocol = EFI_DT_FIXUP_PROTOCOL_GUID; diff --git a/lib/efi_loader/efi_gop.c b/lib/efi_loader/efi_gop.c index 53f6d970f735..1206b2d7a2c8 100644 --- a/lib/efi_loader/efi_gop.c +++ b/lib/efi_loader/efi_gop.c @@ -12,6 +12,7 @@ #include <log.h> #include <malloc.h> #include <video.h> +#include <asm/global_data.h>
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index a3106aba7f25..be2f655dffdb 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -12,6 +12,7 @@ #include <mapmem.h> #include <watchdog.h> #include <asm/cache.h> +#include <asm/global_data.h> #include <linux/list_sort.h> #include <linux/sizes.h>
diff --git a/lib/efi_loader/efi_rng.c b/lib/efi_loader/efi_rng.c index 8bdadad0a953..0e0654685623 100644 --- a/lib/efi_loader/efi_rng.c +++ b/lib/efi_loader/efi_rng.c @@ -11,6 +11,7 @@ #include <efi_rng.h> #include <log.h> #include <rng.h> +#include <asm/global_data.h>
diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index 93c9478b2250..93a695fc27e2 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -14,6 +14,7 @@ #include <log.h> #include <malloc.h> #include <rtc.h> +#include <asm/global_data.h> #include <u-boot/crc.h>
/* For manual relocation support */ diff --git a/lib/efi_selftest/dtbdump.c b/lib/efi_selftest/dtbdump.c index 953b264d9d45..844d08246ee3 100644 --- a/lib/efi_selftest/dtbdump.c +++ b/lib/efi_selftest/dtbdump.c @@ -9,6 +9,7 @@ #include <common.h> #include <efi_api.h> #include <efi_dt_fixup.h> +#include <linux/libfdt.h>
#define BUFFER_SIZE 64 #define ESC 0x17 diff --git a/lib/fdtdec.c b/lib/fdtdec.c index a2d2fb4e1fe6..2b2503799996 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -21,6 +21,7 @@ #include <mapmem.h> #include <linux/libfdt.h> #include <serial.h> +#include <asm/global_data.h> #include <asm/sections.h> #include <linux/ctype.h> #include <linux/lzo.h> diff --git a/lib/optee/optee.c b/lib/optee/optee.c index 9e6606568f32..4dcf6f930990 100644 --- a/lib/optee/optee.c +++ b/lib/optee/optee.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <fdtdec.h> #include <image.h> #include <log.h> #include <malloc.h> diff --git a/lib/time.c b/lib/time.c index cc6944ec345d..38a9758292a5 100644 --- a/lib/time.c +++ b/lib/time.c @@ -14,6 +14,7 @@ #include <timer.h> #include <watchdog.h> #include <div64.h> +#include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h>
diff --git a/lib/trace.c b/lib/trace.c index defc9716d80f..9e34b1953755 100644 --- a/lib/trace.c +++ b/lib/trace.c @@ -7,6 +7,7 @@ #include <mapmem.h> #include <time.h> #include <trace.h> +#include <asm/global_data.h> #include <asm/io.h> #include <asm/sections.h>
diff --git a/lib/zlib/zlib.c b/lib/zlib/zlib.c index 90e05e7d4d95..493fe19eda6f 100644 --- a/lib/zlib/zlib.c +++ b/lib/zlib/zlib.c @@ -12,7 +12,7 @@ * - added inflateIncomp */
-#include <common.h> +#include <compiler.h>
#ifdef CONFIG_GZIP_COMPRESSED #define NO_DUMMY_DECL diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 35842f577dd7..34ca731d1e31 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -11,6 +11,7 @@ #include <env.h> #include <log.h> #include <net.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> #include <net/pcap.h> diff --git a/net/eth_legacy.c b/net/eth_legacy.c index 6870afb505c7..96ed5a472026 100644 --- a/net/eth_legacy.c +++ b/net/eth_legacy.c @@ -13,6 +13,7 @@ #include <log.h> #include <net.h> #include <phy.h> +#include <asm/global_data.h> #include <linux/bug.h> #include <linux/errno.h> #include <net/pcap.h> diff --git a/net/tftp.c b/net/tftp.c index 03079ded34e3..d8cb12120bbc 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -14,6 +14,7 @@ #include <log.h> #include <mapmem.h> #include <net.h> +#include <asm/global_data.h> #include <net/tftp.h> #include "bootp.h" #ifdef CONFIG_SYS_DIRECT_FLASH_TFTP diff --git a/post/drivers/memory.c b/post/drivers/memory.c index e90ada3ce854..281989da6fa7 100644 --- a/post/drivers/memory.c +++ b/post/drivers/memory.c @@ -6,6 +6,7 @@
/* Memory test * diff --git a/post/post.c b/post/post.c index 7d6a64731281..d67c43ed8ae8 100644 --- a/post/post.c +++ b/post/post.c @@ -14,6 +14,7 @@ #include <watchdog.h> #include <div64.h> #include <post.h> +#include <asm/global_data.h>
#ifdef CONFIG_SYS_POST_HOTKEYS_GPIO #include <asm/gpio.h> diff --git a/test/bloblist.c b/test/bloblist.c index 85a6c39680e4..6953d3010a65 100644 --- a/test/bloblist.c +++ b/test/bloblist.c @@ -7,6 +7,7 @@ #include <bloblist.h> #include <log.h> #include <mapmem.h> +#include <asm/global_data.h> #include <test/suites.h> #include <test/test.h> #include <test/ut.h> diff --git a/test/bootm.c b/test/bootm.c index 92dc2b6e1738..563d6ebaa5a6 100644 --- a/test/bootm.c +++ b/test/bootm.c @@ -7,6 +7,7 @@
#include <common.h> #include <bootm.h> +#include <asm/global_data.h> #include <test/suites.h> #include <test/test.h> #include <test/ut.h> diff --git a/test/cmd/test_echo.c b/test/cmd/test_echo.c index 4183cf75bb63..aa5cebc4e78f 100644 --- a/test/cmd/test_echo.c +++ b/test/cmd/test_echo.c @@ -7,6 +7,7 @@
#include <common.h> #include <command.h> +#include <asm/global_data.h> #include <display_options.h> #include <test/lib.h> #include <test/test.h> diff --git a/test/dm/acpi.c b/test/dm/acpi.c index e0a323ecd40f..240187c52350 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -17,6 +17,7 @@ #include <acpi/acpigen.h> #include <acpi/acpi_device.h> #include <acpi/acpi_table.h> +#include <asm/global_data.h> #include <dm/acpi.h> #include <dm/test.h> #include <test/ut.h> diff --git a/test/dm/blk.c b/test/dm/blk.c index a39a1ebd289a..b7f4304e9e99 100644 --- a/test/dm/blk.c +++ b/test/dm/blk.c @@ -7,6 +7,7 @@ #include <dm.h> #include <part.h> #include <usb.h> +#include <asm/global_data.h> #include <asm/state.h> #include <dm/test.h> #include <test/test.h> diff --git a/test/dm/bus.c b/test/dm/bus.c index e768eab6957a..89a6aa6554cb 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -9,6 +9,7 @@ #include <os.h> #endif #include <dm.h> +#include <asm/global_data.h> #include <dm/device.h> #include <dm/device-internal.h> #include <dm/test.h> diff --git a/test/dm/core.c b/test/dm/core.c index 1f5ca570dc7a..ea1d1908968b 100644 --- a/test/dm/core.c +++ b/test/dm/core.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/root.h> #include <dm/util.h> diff --git a/test/dm/fdtdec.c b/test/dm/fdtdec.c index 017157a2ecd1..1f630ea3eee1 100644 --- a/test/dm/fdtdec.c +++ b/test/dm/fdtdec.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <asm/global_data.h> #include <dm/of_extra.h> #include <dm/test.h> #include <test/ut.h> diff --git a/test/dm/mux-emul.c b/test/dm/mux-emul.c index 45154cea5004..58233edc9b29 100644 --- a/test/dm/mux-emul.c +++ b/test/dm/mux-emul.c @@ -9,6 +9,7 @@ #include <mux-internal.h> #include <dm/test.h> #include <test/ut.h> +#include <asm/global_data.h>
struct mux_emul_priv { u32 state; diff --git a/test/dm/of_platdata.c b/test/dm/of_platdata.c index 26c50922c569..e9804cc27fa8 100644 --- a/test/dm/of_platdata.c +++ b/test/dm/of_platdata.c @@ -6,6 +6,7 @@ #include <dm/test.h> #include <test/test.h> #include <test/ut.h> +#include <asm/global_data.h>
/* Test that we can find a device using of-platdata */ static int dm_test_of_plat_base(struct unit_test_state *uts) diff --git a/test/dm/ram.c b/test/dm/ram.c index f01236c8cd5c..f624343138d6 100644 --- a/test/dm/ram.c +++ b/test/dm/ram.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <ram.h> +#include <asm/global_data.h> #include <dm/test.h> #include <test/test.h> #include <test/ut.h> diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index b5ac9bba24eb..6e83aeecd928 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/io.h> #include <dm/test.h> #include <dm/root.h> diff --git a/test/dm/test-main.c b/test/dm/test-main.c index 69458d62c869..560f8d63ec64 100644 --- a/test/dm/test-main.c +++ b/test/dm/test-main.c @@ -10,6 +10,7 @@ #include <errno.h> #include <log.h> #include <malloc.h> +#include <asm/global_data.h> #include <asm/state.h> #include <dm/test.h> #include <dm/root.h> diff --git a/test/lib/test_print.c b/test/lib/test_print.c index 1d497d00413c..12972f1bcd60 100644 --- a/test/lib/test_print.c +++ b/test/lib/test_print.c @@ -8,6 +8,7 @@ #include <common.h> #include <command.h> #include <display_options.h> +#include <asm/global_data.h> #include <test/lib.h> #include <test/test.h> #include <test/ut.h> diff --git a/test/log/cont_test.c b/test/log/cont_test.c index 68ca1d262c4d..16379a74be62 100644 --- a/test/log/cont_test.c +++ b/test/log/cont_test.c @@ -7,6 +7,7 @@
#include <common.h> #include <console.h> +#include <asm/global_data.h> #include <test/log.h> #include <test/test.h> #include <test/suites.h> diff --git a/test/log/log_filter.c b/test/log/log_filter.c index e8a6e01a5cc6..b644b40a850d 100644 --- a/test/log/log_filter.c +++ b/test/log/log_filter.c @@ -6,6 +6,7 @@ #include <common.h> #include <console.h> #include <log.h> +#include <asm/global_data.h> #include <test/log.h> #include <test/ut.h>
diff --git a/test/log/log_test.c b/test/log/log_test.c index 82234a69942d..4a814ff41320 100644 --- a/test/log/log_test.c +++ b/test/log/log_test.c @@ -9,6 +9,7 @@ #include <common.h> #include <command.h> #include <log.h> +#include <asm/global_data.h> #include <test/log.h> #include <test/ut.h>
diff --git a/test/log/nolog_test.c b/test/log/nolog_test.c index c418ed07c9a2..cb4fb3db9a20 100644 --- a/test/log/nolog_test.c +++ b/test/log/nolog_test.c @@ -10,6 +10,7 @@
#include <common.h> #include <console.h> +#include <asm/global_data.h> #include <test/log.h> #include <test/test.h> #include <test/suites.h> diff --git a/test/log/pr_cont_test.c b/test/log/pr_cont_test.c index 236eff4b33b3..6abddf7a1195 100644 --- a/test/log/pr_cont_test.c +++ b/test/log/pr_cont_test.c @@ -11,6 +11,7 @@ #include <test/test.h> #include <test/suites.h> #include <test/ut.h> +#include <asm/global_data.h> #include <linux/printk.h>
#define BUFFSIZE 64 diff --git a/test/log/syslog_test.c b/test/log/syslog_test.c index a058d8f56959..4db649db8226 100644 --- a/test/log/syslog_test.c +++ b/test/log/syslog_test.c @@ -11,6 +11,7 @@ #define LOG_DEBUG
#include <common.h> +#include <asm/global_data.h> #include <dm/device.h> #include <hexdump.h> #include <test/log.h> diff --git a/test/log/syslog_test_ndebug.c b/test/log/syslog_test_ndebug.c index 84844a394402..4438791044d0 100644 --- a/test/log/syslog_test_ndebug.c +++ b/test/log/syslog_test_ndebug.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <asm/global_data.h> #include <dm/device.h> #include <hexdump.h> #include <test/log.h> diff --git a/test/ut.c b/test/ut.c index 44ed1ba2d313..7328338731c1 100644 --- a/test/ut.c +++ b/test/ut.c @@ -11,6 +11,7 @@ #ifdef CONFIG_SANDBOX #include <asm/state.h> #endif +#include <asm/global_data.h> #include <test/test.h> #include <test/ut.h>
On Wed, Feb 03, 2021 at 09:19:51AM -0500, Tom Rini wrote:
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include.
Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Tom Rini trini@konsulko.com
arch/arm/cpu/armv7/s5p-common/cpu_info.c | 1 + arch/arm/mach-at91/arm926ejs/eflash.c | 1 + arch/arm/mach-imx/hab.c | 1 + arch/powerpc/cpu/mpc85xx/cpu.c | 1 + arch/powerpc/cpu/mpc85xx/cpu_init.c | 1 + arch/powerpc/cpu/mpc85xx/tlb.c | 1 + arch/powerpc/cpu/mpc86xx/cpu.c | 1 + arch/powerpc/cpu/mpc8xx/cpu.c | 1 + arch/powerpc/cpu/mpc8xxx/law.c | 1 + arch/x86/cpu/broadwell/refcode.c | 1 + board/corscience/tricorder/tricorder-eeprom.c | 1 + board/freescale/ls1028a/ls1028a.c | 1 + board/freescale/ls1088a/ls1088a.c | 1 + board/freescale/ls2080a/ls2080a.c | 1 + board/freescale/ls2080aqds/ls2080aqds.c | 1 + board/freescale/ls2080ardb/ls2080ardb.c | 1 + board/freescale/lx2160a/lx2160a.c | 1 + board/freescale/mpc8541cds/mpc8541cds.c | 1 + board/freescale/mpc8548cds/mpc8548cds.c | 1 + board/freescale/mpc8555cds/mpc8555cds.c | 1 + board/freescale/mpc8568mds/mpc8568mds.c | 1 + board/gdsys/p1022/controlcenterd-id.c | 1 + board/kontron/sl28/sl28.c | 1 + board/kosagi/novena/novena.c | 1 + board/sbc8548/sbc8548.c | 1 + cmd/acpi.c | 1 + cmd/axi.c | 1 + cmd/bcb.c | 1 + cmd/cpu.c | 1 + cmd/fpgad.c | 1 + cmd/io.c | 1 + cmd/mem.c | 1 + cmd/mmc.c | 1 + cmd/rtc.c | 1 + cmd/sf.c | 1 + cmd/version.c | 1 + common/bloblist.c | 1 + common/board_f.c | 1 + common/board_r.c | 1 + common/console.c | 1 + common/image.c | 1 + common/splash.c | 1 + drivers/core/acpi.c | 1 + drivers/cpu/bmips_cpu.c | 1 + drivers/ddr/fsl/main.c | 1 + drivers/mmc/gen_atmel_mci.c | 1 + drivers/mtd/onenand/onenand_uboot.c | 1 + drivers/mtd/spi/sf_dataflash.c | 1 + drivers/mtd/spi/spi-nor-core.c | 1 + drivers/net/xilinx_axi_emac.c | 1 + drivers/tpm/tpm_atmel_twi.c | 1 + drivers/tpm/tpm_tis_sandbox.c | 1 + drivers/usb/gadget/pxa27x_udc.c | 1 + drivers/xen/gnttab.c | 1 + fs/fs.c | 1 + include/common.h | 1 - include/display_options.h | 1 + include/fsl_qe.h | 2 ++ lib/aes.c | 1 + lib/display_options.c | 1 + lib/fdtdec.c | 1 + net/nfs.c | 1 + net/tftp.c | 1 + 63 files changed, 63 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/s5p-common/cpu_info.c b/arch/arm/cpu/armv7/s5p-common/cpu_info.c index d910282e2b2..fb2920950d4 100644 --- a/arch/arm/cpu/armv7/s5p-common/cpu_info.c +++ b/arch/arm/cpu/armv7/s5p-common/cpu_info.c @@ -4,6 +4,7 @@ * Minkyu Kang mk7.kang@samsung.com */ #include <common.h> +#include <display_options.h> #include <fdtdec.h> #include <init.h> #include <asm/global_data.h> diff --git a/arch/arm/mach-at91/arm926ejs/eflash.c b/arch/arm/mach-at91/arm926ejs/eflash.c index 23c24936edf..ef579e6089c 100644 --- a/arch/arm/mach-at91/arm926ejs/eflash.c +++ b/arch/arm/mach-at91/arm926ejs/eflash.c @@ -43,6 +43,7 @@ * do a read-modify-write for partially programmed pages */ #include <common.h> +#include <display_options.h> #include <flash.h> #include <log.h> #include <asm/io.h> diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index d0757d8b66a..7510735bf46 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -6,6 +6,7 @@ #include <common.h> #include <command.h> #include <config.h> +#include <display_options.h> #include <fuse.h> #include <mapmem.h> #include <image.h> diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 5170610f041..d35c9780172 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -11,6 +11,7 @@ #include <config.h> #include <common.h> #include <cpu_func.h> +#include <display_options.h> #include <init.h> #include <irq_func.h> #include <log.h> diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index e0f0f7ecda6..fcc2c7be31a 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -10,6 +10,7 @@ */
#include <common.h> +#include <display_options.h> #include <env.h> #include <init.h> #include <net.h> diff --git a/arch/powerpc/cpu/mpc85xx/tlb.c b/arch/powerpc/cpu/mpc85xx/tlb.c index 973b6fbe4b7..927df4e5b66 100644 --- a/arch/powerpc/cpu/mpc85xx/tlb.c +++ b/arch/powerpc/cpu/mpc85xx/tlb.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <display_options.h> #include <asm/bitops.h> #include <asm/global_data.h> #include <asm/processor.h> diff --git a/arch/powerpc/cpu/mpc86xx/cpu.c b/arch/powerpc/cpu/mpc86xx/cpu.c index 98b42bff7a3..05160778566 100644 --- a/arch/powerpc/cpu/mpc86xx/cpu.c +++ b/arch/powerpc/cpu/mpc86xx/cpu.c @@ -7,6 +7,7 @@
#include <common.h> #include <cpu_func.h> +#include <display_options.h> #include <log.h> #include <time.h> #include <vsprintf.h> diff --git a/arch/powerpc/cpu/mpc8xx/cpu.c b/arch/powerpc/cpu/mpc8xx/cpu.c index 893aecef21c..f79a06d19a2 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu.c +++ b/arch/powerpc/cpu/mpc8xx/cpu.c @@ -18,6 +18,7 @@
#include <common.h> #include <cpu_func.h> +#include <display_options.h> #include <net.h> #include <time.h> #include <vsprintf.h> diff --git a/arch/powerpc/cpu/mpc8xxx/law.c b/arch/powerpc/cpu/mpc8xxx/law.c index cf03f410190..ff4b878aa9c 100644 --- a/arch/powerpc/cpu/mpc8xxx/law.c +++ b/arch/powerpc/cpu/mpc8xxx/law.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <display_options.h> #include <asm/bitops.h> #include <asm/global_data.h> #include <linux/compiler.h> diff --git a/arch/x86/cpu/broadwell/refcode.c b/arch/x86/cpu/broadwell/refcode.c index 6c04dde992d..1e0a34de0c8 100644 --- a/arch/x86/cpu/broadwell/refcode.c +++ b/arch/x86/cpu/broadwell/refcode.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <display_options.h> #include <errno.h> #include <init.h> #include <log.h> diff --git a/board/corscience/tricorder/tricorder-eeprom.c b/board/corscience/tricorder/tricorder-eeprom.c index 192af304d9f..d0b91864c27 100644 --- a/board/corscience/tricorder/tricorder-eeprom.c +++ b/board/corscience/tricorder/tricorder-eeprom.c @@ -6,6 +6,7 @@ */ #include <common.h> #include <command.h> +#include <display_options.h> #include <eeprom.h> #include <i2c.h> #include <u-boot/crc.h> diff --git a/board/freescale/ls1028a/ls1028a.c b/board/freescale/ls1028a/ls1028a.c index f3c1d958b72..984883bb00f 100644 --- a/board/freescale/ls1028a/ls1028a.c +++ b/board/freescale/ls1028a/ls1028a.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <display_options.h> #include <init.h> #include <malloc.h> #include <errno.h> diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 2ba6a3990d9..41453709eac 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -3,6 +3,7 @@ * Copyright 2017-2018 NXP */ #include <common.h> +#include <display_options.h> #include <env.h> #include <i2c.h> #include <init.h> diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index 48437a52e40..020e7bfcb5c 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -3,6 +3,7 @@ * Copyright 2014 Freescale Semiconductor */ #include <common.h> +#include <display_options.h> #include <init.h> #include <malloc.h> #include <errno.h> diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index a6f6897eb09..3ab93388724 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -3,6 +3,7 @@ * Copyright 2015 Freescale Semiconductor */ #include <common.h> +#include <display_options.h> #include <env.h> #include <init.h> #include <malloc.h> diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index 26ce5a80edf..a6ece49c01e 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -4,6 +4,7 @@ * Copyright 2017 NXP */ #include <common.h> +#include <display_options.h> #include <env.h> #include <init.h> #include <malloc.h> diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index 80a42c147cc..33222e851ea 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -5,6 +5,7 @@
#include <common.h> #include <clock_legacy.h> +#include <display_options.h> #include <dm.h> #include <init.h> #include <asm/global_data.h> diff --git a/board/freescale/mpc8541cds/mpc8541cds.c b/board/freescale/mpc8541cds/mpc8541cds.c index 5b4fbd5e304..3986d81c62d 100644 --- a/board/freescale/mpc8541cds/mpc8541cds.c +++ b/board/freescale/mpc8541cds/mpc8541cds.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <display_options.h> #include <init.h> #include <pci.h> #include <vsprintf.h> diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index a1a9742bfa4..fd51c0e8018 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <display_options.h> #include <init.h> #include <net.h> #include <pci.h> diff --git a/board/freescale/mpc8555cds/mpc8555cds.c b/board/freescale/mpc8555cds/mpc8555cds.c index 3bb8e769c80..d91763ae800 100644 --- a/board/freescale/mpc8555cds/mpc8555cds.c +++ b/board/freescale/mpc8555cds/mpc8555cds.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <display_options.h> #include <init.h> #include <pci.h> #include <vsprintf.h> diff --git a/board/freescale/mpc8568mds/mpc8568mds.c b/board/freescale/mpc8568mds/mpc8568mds.c index 7b379464cd5..1acdf93e4d7 100644 --- a/board/freescale/mpc8568mds/mpc8568mds.c +++ b/board/freescale/mpc8568mds/mpc8568mds.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <display_options.h> #include <flash.h> #include <init.h> #include <log.h> diff --git a/board/gdsys/p1022/controlcenterd-id.c b/board/gdsys/p1022/controlcenterd-id.c index 1b5aa9042f5..495ef8e1f83 100644 --- a/board/gdsys/p1022/controlcenterd-id.c +++ b/board/gdsys/p1022/controlcenterd-id.c @@ -13,6 +13,7 @@ #include <common.h> #include <bootstage.h> #include <command.h> +#include <display_options.h> #include <dm.h> #include <env.h> #include <hang.h> diff --git a/board/kontron/sl28/sl28.c b/board/kontron/sl28/sl28.c index a3f5142525d..b39f14fa6ee 100644 --- a/board/kontron/sl28/sl28.c +++ b/board/kontron/sl28/sl28.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+
#include <common.h> +#include <display_options.h> #include <malloc.h> #include <errno.h> #include <fsl_ddr.h> diff --git a/board/kosagi/novena/novena.c b/board/kosagi/novena/novena.c index 0e1b4a0a46c..815ecf55c4d 100644 --- a/board/kosagi/novena/novena.c +++ b/board/kosagi/novena/novena.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <display_options.h> #include <dm.h> #include <eeprom.h> #include <init.h> diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index bd4b528d03f..13a66507ffc 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -10,6 +10,7 @@ */
#include <common.h> +#include <display_options.h> #include <init.h> #include <log.h> #include <net.h> diff --git a/cmd/acpi.c b/cmd/acpi.c index 157261bffbe..d5c785c46ae 100644 --- a/cmd/acpi.c +++ b/cmd/acpi.c @@ -5,6 +5,7 @@ */ #include <common.h> #include <command.h> +#include <display_options.h> #include <mapmem.h> #include <acpi/acpi_table.h> #include <asm/acpi_table.h> diff --git a/cmd/axi.c b/cmd/axi.c index c9d53c049e8..36508223c34 100644 --- a/cmd/axi.c +++ b/cmd/axi.c @@ -13,6 +13,7 @@ #include <axi.h> #include <command.h> #include <console.h> +#include <display_options.h> #include <dm.h> #include <log.h>
diff --git a/cmd/bcb.c b/cmd/bcb.c index e03218066bf..81e099fbb1b 100644 --- a/cmd/bcb.c +++ b/cmd/bcb.c @@ -8,6 +8,7 @@ #include <android_bootloader_message.h> #include <command.h> #include <common.h> +#include <display_options.h> #include <log.h> #include <part.h>
diff --git a/cmd/cpu.c b/cmd/cpu.c index ff553c16c4e..b3dd7e57449 100644 --- a/cmd/cpu.c +++ b/cmd/cpu.c @@ -8,6 +8,7 @@ #include <common.h> #include <command.h> #include <cpu.h> +#include <display_options.h> #include <dm.h> #include <errno.h>
diff --git a/cmd/fpgad.c b/cmd/fpgad.c index fb2fe63e78a..89b34f86425 100644 --- a/cmd/fpgad.c +++ b/cmd/fpgad.c @@ -11,6 +11,7 @@ #include <common.h> #include <command.h> #include <console.h> +#include <display_options.h>
#include <gdsys_fpga.h>
diff --git a/cmd/io.c b/cmd/io.c index c7e964153b8..dd770a20ce1 100644 --- a/cmd/io.c +++ b/cmd/io.c @@ -9,6 +9,7 @@
#include <common.h> #include <command.h> +#include <display_options.h> #include <asm/io.h>
/* Display values from last command */ diff --git a/cmd/mem.c b/cmd/mem.c index e6c65c9ef8a..f0f7ffa6af1 100644 --- a/cmd/mem.c +++ b/cmd/mem.c @@ -16,6 +16,7 @@ #include <cli.h> #include <command.h> #include <console.h> +#include <display_options.h> #include <flash.h> #include <hash.h> #include <log.h> diff --git a/cmd/mmc.c b/cmd/mmc.c index 1529a3e05dd..e3e75d0fc0e 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -8,6 +8,7 @@ #include <blk.h> #include <command.h> #include <console.h> +#include <display_options.h> #include <memalign.h> #include <mmc.h> #include <part.h> diff --git a/cmd/rtc.c b/cmd/rtc.c index b4f61b2e835..4ac49d228cb 100644 --- a/cmd/rtc.c +++ b/cmd/rtc.c @@ -2,6 +2,7 @@
#include <common.h> #include <command.h> +#include <display_options.h> #include <dm.h> #include <hexdump.h> #include <i2c.h> diff --git a/cmd/sf.c b/cmd/sf.c index c0d6a8f8a06..b3ff4b5773c 100644 --- a/cmd/sf.c +++ b/cmd/sf.c @@ -7,6 +7,7 @@
#include <common.h> #include <command.h> +#include <display_options.h> #include <div64.h> #include <dm.h> #include <flash.h> diff --git a/cmd/version.c b/cmd/version.c index 3686b873324..2c321a92f9b 100644 --- a/cmd/version.c +++ b/cmd/version.c @@ -6,6 +6,7 @@
#include <common.h> #include <command.h> +#include <display_options.h> #include <version.h> #include <linux/compiler.h> #ifdef CONFIG_SYS_COREBOOT diff --git a/common/bloblist.c b/common/bloblist.c index f7fbbeaedbd..b92edd156c6 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -6,6 +6,7 @@
#include <common.h> #include <bloblist.h> +#include <display_options.h> #include <log.h> #include <mapmem.h> #include <spl.h> diff --git a/common/board_f.c b/common/board_f.c index b9bf0329578..c2f3bd42d1e 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -16,6 +16,7 @@ #include <console.h> #include <cpu.h> #include <cpu_func.h> +#include <display_options.h> #include <dm.h> #include <env.h> #include <env_internal.h> diff --git a/common/board_r.c b/common/board_r.c index ad932a0b582..abafd732a8a 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -13,6 +13,7 @@ #include <api.h> #include <bootstage.h> #include <cpu_func.h> +#include <display_options.h> #include <exports.h> #include <flash.h> #include <hang.h> diff --git a/common/console.c b/common/console.c index aaa2b0c0d7e..0935f8f8b42 100644 --- a/common/console.c +++ b/common/console.c @@ -7,6 +7,7 @@ #include <common.h> #include <console.h> #include <debug_uart.h> +#include <display_options.h> #include <dm.h> #include <env.h> #include <stdarg.h> diff --git a/common/image.c b/common/image.c index ba78363123a..6689bb47611 100644 --- a/common/image.c +++ b/common/image.c @@ -10,6 +10,7 @@ #include <common.h> #include <bootstage.h> #include <cpu_func.h> +#include <display_options.h> #include <env.h> #include <lmb.h> #include <log.h> diff --git a/common/splash.c b/common/splash.c index 2b9313e03f1..e26b366cb23 100644 --- a/common/splash.c +++ b/common/splash.c @@ -21,6 +21,7 @@ */
#include <common.h> +#include <display_options.h> #include <env.h> #include <splash.h> #include <lcd.h> diff --git a/drivers/core/acpi.c b/drivers/core/acpi.c index 7fe93992b5f..99c0da500eb 100644 --- a/drivers/core/acpi.c +++ b/drivers/core/acpi.c @@ -9,6 +9,7 @@ #define LOG_CATEOGRY LOGC_ACPI
#include <common.h> +#include <display_options.h> #include <dm.h> #include <log.h> #include <malloc.h> diff --git a/drivers/cpu/bmips_cpu.c b/drivers/cpu/bmips_cpu.c index 421cc7a9a4c..8419adb3cc3 100644 --- a/drivers/cpu/bmips_cpu.c +++ b/drivers/cpu/bmips_cpu.c @@ -9,6 +9,7 @@
#include <common.h> #include <cpu.h> +#include <display_options.h> #include <dm.h> #include <errno.h> #include <init.h> diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index c02badd4a88..5d421d2c1e3 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -10,6 +10,7 @@ */
#include <common.h> +#include <display_options.h> #include <dm.h> #include <i2c.h> #include <fsl_ddr_sdram.h> diff --git a/drivers/mmc/gen_atmel_mci.c b/drivers/mmc/gen_atmel_mci.c index 0a347b2fb20..9e814c378ca 100644 --- a/drivers/mmc/gen_atmel_mci.c +++ b/drivers/mmc/gen_atmel_mci.c @@ -10,6 +10,7 @@
#include <common.h> #include <clk.h> +#include <display_options.h> #include <dm.h> #include <log.h> #include <mmc.h> diff --git a/drivers/mtd/onenand/onenand_uboot.c b/drivers/mtd/onenand/onenand_uboot.c index 6893394e089..3a8c7b867eb 100644 --- a/drivers/mtd/onenand/onenand_uboot.c +++ b/drivers/mtd/onenand/onenand_uboot.c @@ -14,6 +14,7 @@ */
#include <common.h> +#include <display_options.h> #include <linux/compat.h> #include <linux/mtd/mtd.h> #include <linux/mtd/onenand.h> diff --git a/drivers/mtd/spi/sf_dataflash.c b/drivers/mtd/spi/sf_dataflash.c index 27d847d4218..b1034ac2086 100644 --- a/drivers/mtd/spi/sf_dataflash.c +++ b/drivers/mtd/spi/sf_dataflash.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <display_options.h> #include <dm.h> #include <errno.h> #include <fdtdec.h> diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index e16b0e1462d..40784312149 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -10,6 +10,7 @@ */
#include <common.h> +#include <display_options.h> #include <log.h> #include <dm.h> #include <dm/device_compat.h> diff --git a/drivers/net/xilinx_axi_emac.c b/drivers/net/xilinx_axi_emac.c index 5aaa6a177d0..d1340db2603 100644 --- a/drivers/net/xilinx_axi_emac.c +++ b/drivers/net/xilinx_axi_emac.c @@ -8,6 +8,7 @@ #include <config.h> #include <common.h> #include <cpu_func.h> +#include <display_options.h> #include <dm.h> #include <log.h> #include <net.h> diff --git a/drivers/tpm/tpm_atmel_twi.c b/drivers/tpm/tpm_atmel_twi.c index d9e4877c5c2..5489e728b6e 100644 --- a/drivers/tpm/tpm_atmel_twi.c +++ b/drivers/tpm/tpm_atmel_twi.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <display_options.h> #include <dm.h> #include <tpm-v1.h> #include <i2c.h> diff --git a/drivers/tpm/tpm_tis_sandbox.c b/drivers/tpm/tpm_tis_sandbox.c index e167d0a2fe3..f35d6920442 100644 --- a/drivers/tpm/tpm_tis_sandbox.c +++ b/drivers/tpm/tpm_tis_sandbox.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <display_options.h> #include <dm.h> #include <tpm-v1.h> #include <asm/state.h> diff --git a/drivers/usb/gadget/pxa27x_udc.c b/drivers/usb/gadget/pxa27x_udc.c index ba362b8f258..7c67c2e3b3e 100644 --- a/drivers/usb/gadget/pxa27x_udc.c +++ b/drivers/usb/gadget/pxa27x_udc.c @@ -9,6 +9,7 @@
#include <common.h> +#include <display_options.h> #include <asm/arch/hardware.h> #include <asm/byteorder.h> #include <asm/io.h> diff --git a/drivers/xen/gnttab.c b/drivers/xen/gnttab.c index 778729d646e..79dd684e00d 100644 --- a/drivers/xen/gnttab.c +++ b/drivers/xen/gnttab.c @@ -21,6 +21,7 @@ #include <malloc.h>
diff --git a/fs/fs.c b/fs/fs.c index 634e7cea81d..5f9d9187598 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -7,6 +7,7 @@
#include <command.h> #include <config.h> +#include <display_options.h> #include <errno.h> #include <common.h> #include <env.h> diff --git a/include/common.h b/include/common.h index 71df59bca0e..25c317f4439 100644 --- a/include/common.h +++ b/include/common.h @@ -23,7 +23,6 @@ #include <stdio.h> #include <linux/kernel.h> #include <asm/u-boot.h> /* boot information for Linux kernel */ -#include <display_options.h> #include <vsprintf.h> #endif /* __ASSEMBLY__ */
diff --git a/include/display_options.h b/include/display_options.h index 049688e39e8..e1af598857a 100644 --- a/include/display_options.h +++ b/include/display_options.h @@ -19,6 +19,7 @@ * @size: Size to print * @suffix String to print after the size */ +#include <display_options.h> void print_size(uint64_t size, const char *suffix);
/** diff --git a/include/fsl_qe.h b/include/fsl_qe.h index 1c6941347f7..737cdbd952c 100644 --- a/include/fsl_qe.h +++ b/include/fsl_qe.h @@ -14,6 +14,8 @@ #include <linux/immap_qe.h> #endif
+struct udevice; + #define QE_NUM_OF_BRGS 16 #define UCC_MAX_NUM 8
diff --git a/lib/aes.c b/lib/aes.c index c998aecb3c7..bc6d4dfd4e0 100644 --- a/lib/aes.c +++ b/lib/aes.c @@ -23,6 +23,7 @@
#ifndef USE_HOSTCC #include <common.h> +#include <display_options.h> #include <log.h> #else #include <string.h> diff --git a/lib/display_options.c b/lib/display_options.c index b2025eeb5cf..824427765da 100644 --- a/lib/display_options.c +++ b/lib/display_options.c @@ -7,6 +7,7 @@ #include <common.h> #include <compiler.h> #include <console.h> +#include <display_options.h> #include <div64.h> #include <version.h> #include <linux/ctype.h> diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 5990b161b14..fea1b7153b4 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -6,6 +6,7 @@ #ifndef USE_HOSTCC #include <common.h> #include <boot_fit.h> +#include <display_options.h> #include <dm.h> #include <hang.h> #include <init.h> diff --git a/net/nfs.c b/net/nfs.c index 70d0e08bde9..8a3b04adcdc 100644 --- a/net/nfs.c +++ b/net/nfs.c @@ -28,6 +28,7 @@
#include <common.h> #include <command.h> +#include <display_options.h> #include <flash.h> #include <image.h> #include <log.h> diff --git a/net/tftp.c b/net/tftp.c index ecbb64122f5..950efacaeb3 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -7,6 +7,7 @@ */ #include <common.h> #include <command.h> +#include <display_options.h> #include <efi_loader.h> #include <env.h> #include <image.h>
arch/arm/lib/gic-v3-its.c | 1 + arch/arm/mach-imx/imx8/fdt.c | 1 + arch/arm/mach-k3/common.c | 1 + arch/arm/mach-meson/board-gx.c | 1 + arch/arm/mach-omap2/am33xx/board.c | 1 + arch/arm/mach-omap2/utils.c | 1 + arch/arm/mach-rockchip/boot_mode.c | 1 + arch/arm/mach-rockchip/rk3188/rk3188.c | 1 + arch/arm/mach-rockchip/rk3399/rk3399.c | 1 + arch/arm/mach-socfpga/misc.c | 1 + arch/arm/mach-stm32mp/bsec.c | 1 + arch/arm/mach-stm32mp/cmd_stm32key.c | 1 + .../cmd_stm32prog/cmd_stm32prog.c | 1 + .../mach-stm32mp/cmd_stm32prog/stm32prog.c | 1 + .../mach-stm32mp/cmd_stm32prog/stm32prog.h | 2 + .../cmd_stm32prog/stm32prog_serial.c | 1 + .../cmd_stm32prog/stm32prog_usb.c | 1 + arch/arm/mach-stm32mp/cpu.c | 1 + .../mach-stm32mp/include/mach/stm32mp1_smc.h | 1 + arch/arm/mach-tegra/cboot.c | 1 + arch/arm/mach-tegra/ivc.c | 1 + arch/arm/mach-tegra/tegra124/xusb-padctl.c | 1 + arch/arm/mach-tegra/tegra20/clock.c | 1 + arch/arm/mach-tegra/tegra210/xusb-padctl.c | 1 + arch/arm/mach-tegra/tegra30/clock.c | 1 + arch/arm/mach-tegra/xusb-padctl-common.c | 1 + .../mach-uniphier/boot-device/boot-device.c | 1 + arch/arm/mach-uniphier/clk/dpll-ld4.c | 1 + arch/arm/mach-uniphier/clk/dpll-pro4.c | 1 + arch/arm/mach-uniphier/dram/umc-ld4.c | 1 + arch/arm/mach-uniphier/dram/umc-pro4.c | 1 + arch/arm/mach-uniphier/dram/umc-sld8.c | 1 + arch/arm/mach-uniphier/memconf.c | 1 + arch/arm/mach-uniphier/spl_board_init.c | 1 + arch/riscv/lib/smp.c | 1 + arch/x86/cpu/tangier/pinmux.c | 1 + arch/x86/cpu/tangier/sdram.c | 1 + board/dhelectronics/dh_stm32mp1/board.c | 1 + board/mediatek/mt8518/mt8518_ap1.c | 1 + board/mscc/ocelot/ocelot.c | 1 + board/nvidia/jetson-tk1/jetson-tk1.c | 1 + .../pinebook-pro-rk3399/pinebook-pro-rk3399.c | 1 + board/samsung/common/exynos5-dt.c | 1 + board/samsung/common/misc.c | 1 + board/samsung/goni/goni.c | 1 + board/samsung/odroid/odroid.c | 1 + board/st/common/stm32mp_dfu.c | 1 + board/st/common/stm32mp_mtdparts.c | 1 + board/st/stm32mp1/stm32mp1.c | 1 + board/sunxi/board.c | 1 + board/synopsys/hsdk/clk-lib.c | 1 + board/synopsys/hsdk/env-lib.c | 1 + board/ti/am65x/evm.c | 1 + board/ti/common/board_detect.c | 1 + board/ti/j721e/evm.c | 1 + board/toradex/apalis-tk1/apalis-tk1.c | 1 + cmd/adc.c | 1 + cmd/fastboot.c | 1 + cmd/nvedit.c | 1 + cmd/onenand.c | 1 + cmd/regulator.c | 1 + cmd/thordown.c | 1 + cmd/tpm_test.c | 1 + cmd/usb_gadget_sdp.c | 1 + cmd/usb_mass_storage.c | 1 + common/dfu.c | 1 + common/spl/spl_dfu.c | 1 + common/spl/spl_fit.c | 1 + common/spl/spl_opensbi.c | 1 + common/spl/spl_sdp.c | 1 + common/update.c | 1 + disk/part_efi.c | 1 + drivers/adc/adc-uclass.c | 1 + drivers/adc/exynos-adc.c | 1 + drivers/adc/meson-saradc.c | 1 + drivers/adc/rockchip-saradc.c | 1 + drivers/adc/sandbox.c | 1 + drivers/ata/dwc_ahci.c | 1 + drivers/bios_emulator/include/x86emu/debug.h | 1 + drivers/bios_emulator/include/x86emu/regs.h | 1 + drivers/bios_emulator/x86emu/debug.c | 1 + drivers/bios_emulator/x86emu/decode.c | 1 + drivers/bios_emulator/x86emu/ops.c | 1 + drivers/bios_emulator/x86emu/ops2.c | 1 + drivers/bios_emulator/x86emu/sys.c | 1 + drivers/bootcount/bootcount-uclass.c | 1 + drivers/clk/analogbits/wrpll-cln28hpc.c | 1 + drivers/clk/clk-divider.c | 1 + drivers/clk/clk-gate.c | 1 + drivers/clk/clk-hsdk-cgu.c | 1 + drivers/clk/clk-mux.c | 1 + drivers/clk/clk_boston.c | 1 + drivers/clk/clk_stm32f.c | 1 + drivers/clk/clk_stm32h7.c | 1 + drivers/clk/clk_stm32mp1.c | 1 + drivers/clk/imx/clk-pll14xx.c | 1 + drivers/clk/rockchip/clk_rk3368.c | 1 + drivers/clk/rockchip/clk_rk3399.c | 1 + drivers/core/device.c | 1 + drivers/core/of_addr.c | 1 + drivers/core/root.c | 1 + drivers/dfu/dfu.c | 1 + drivers/dfu/dfu_mmc.c | 1 + drivers/dfu/dfu_ram.c | 1 + drivers/dfu/dfu_tftp.c | 1 + drivers/dma/bcm6348-iudma.c | 1 + drivers/dma/dma-uclass.c | 1 + drivers/dma/lpc32xx_dma.c | 1 + drivers/dma/sandbox-dma-test.c | 1 + drivers/dma/ti-edma3.c | 1 + drivers/dma/ti/k3-udma.c | 1 + drivers/fastboot/fb_command.c | 1 + drivers/fastboot/fb_getvar.c | 1 + drivers/fastboot/fb_mmc.c | 1 + drivers/fastboot/fb_nand.c | 1 + drivers/i2c/i2c-gpio.c | 1 + drivers/i2c/iproc_i2c.c | 1 + drivers/i2c/omap24xx_i2c.c | 1 + drivers/i2c/stm32f7_i2c.c | 1 + drivers/i2c/tegra_i2c.c | 1 + drivers/misc/sifive-otp.c | 1 + drivers/misc/tegra186_bpmp.c | 1 + drivers/mmc/exynos_dw_mmc.c | 1 + drivers/mmc/fsl_esdhc_imx.c | 1 + drivers/mmc/mmc.c | 1 + drivers/mmc/mtk-sd.c | 1 + drivers/mmc/sdhci.c | 1 + drivers/mmc/sti_sdhci.c | 1 + drivers/mmc/stm32_sdmmc2.c | 1 + drivers/mmc/xenon_sdhci.c | 1 + drivers/mtd/mtdconcat.c | 1 + drivers/mtd/mtdcore.c | 1 + drivers/mtd/mtdpart.c | 1 + drivers/mtd/nand/bbt.c | 1 + drivers/mtd/nand/core.c | 1 + drivers/mtd/nand/raw/arasan_nfc.c | 1 + drivers/mtd/nand/raw/atmel_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/bcm6368_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c | 1 + drivers/mtd/nand/raw/davinci_nand.c | 1 + drivers/mtd/nand/raw/lpc32xx_nand_mlc.c | 1 + drivers/mtd/nand/raw/lpc32xx_nand_slc.c | 1 + drivers/mtd/nand/raw/mxc_nand.c | 1 + drivers/mtd/nand/raw/nand_base.c | 1 + drivers/mtd/nand/raw/nand_bbt.c | 1 + drivers/mtd/nand/raw/nand_bch.c | 1 + drivers/mtd/nand/raw/pxa3xx_nand.c | 1 + drivers/mtd/nand/raw/stm32_fmc2_nand.c | 1 + drivers/mtd/nand/raw/sunxi_nand.c | 1 + drivers/mtd/nand/raw/tegra_nand.c | 1 + drivers/mtd/nand/raw/vf610_nfc.c | 1 + drivers/mtd/nand/raw/zynq_nand.c | 1 + drivers/mtd/nand/spi/core.c | 1 + drivers/mtd/onenand/onenand_base.c | 1 + drivers/mtd/onenand/onenand_bbt.c | 1 + drivers/mtd/onenand/samsung.c | 1 + drivers/mtd/spi/spi-nor-core.c | 1 + drivers/mtd/spi/spi-nor-tiny.c | 1 + drivers/mtd/ubi/attach.c | 1 + drivers/mtd/ubi/build.c | 1 + drivers/mtd/ubi/debug.c | 1 + drivers/mtd/ubi/debug.h | 1 + drivers/mtd/ubi/ubi.h | 1 + drivers/net/bcm-sf2-eth-gmac.c | 1 + drivers/net/bcm-sf2-eth.c | 1 + drivers/net/bcm6348-eth.c | 1 + drivers/net/bcm6368-eth.c | 1 + drivers/net/designware.c | 1 + drivers/net/dwc_eth_qos.c | 1 + drivers/net/ep93xx_eth.c | 1 + drivers/net/fsl-mc/dpio/qbman_sys.h | 1 + drivers/net/ftgmac100.c | 1 + drivers/net/mscc_eswitch/jr2_switch.c | 1 + drivers/net/mscc_eswitch/ocelot_switch.c | 1 + drivers/net/mscc_eswitch/serval_switch.c | 1 + drivers/net/mscc_eswitch/servalt_switch.c | 1 + drivers/net/mt7628-eth.c | 1 + drivers/net/mtk_eth.c | 1 + drivers/net/mvmdio.c | 1 + drivers/net/phy/dp83867.c | 1 + drivers/net/phy/mscc.c | 1 + drivers/net/rtl8169.c | 1 + drivers/net/sni_ave.c | 1 + drivers/net/ti/am65-cpsw-nuss.c | 1 + drivers/net/ti/cpsw-common.c | 1 + drivers/net/ti/cpsw.c | 1 + drivers/net/ti/keystone_net.c | 1 + drivers/pci/pci-uclass.c | 1 + drivers/pci/pci_mvebu.c | 1 + drivers/pci/pci_tegra.c | 1 + drivers/pci/pcie_ecam_generic.c | 1 + drivers/pci/pcie_fsl.c | 1 + drivers/pci/pcie_mediatek.c | 1 + drivers/pci/pcie_phytium.c | 1 + drivers/pci/pcie_xilinx.c | 1 + drivers/phy/keystone-usb-phy.c | 1 + drivers/phy/marvell/comphy_cp110.c | 1 + drivers/phy/meson-g12a-usb2.c | 1 + drivers/phy/meson-g12a-usb3-pcie.c | 1 + drivers/phy/meson-gxbb-usb2.c | 1 + drivers/phy/meson-gxl-usb2.c | 1 + drivers/phy/meson-gxl-usb3.c | 220 ++++++++++++++++++ drivers/phy/phy-rcar-gen3.c | 1 + drivers/phy/phy-stm32-usbphyc.c | 1 + drivers/phy/phy-uclass.c | 2 + drivers/phy/sti_usb_phy.c | 1 + drivers/phy/ti-pipe3-phy.c | 1 + drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 1 + drivers/pinctrl/pinctrl-sti.c | 1 + drivers/pinctrl/pinctrl_stm32.c | 1 + drivers/power/palmas.c | 1 + drivers/power/pmic/as3722.c | 1 + drivers/power/pmic/as3722_gpio.c | 1 + drivers/power/pmic/bd71837.c | 1 + drivers/power/pmic/da9063.c | 1 + drivers/power/pmic/fan53555.c | 1 + drivers/power/pmic/i2c_pmic_emul.c | 1 + drivers/power/pmic/lp873x.c | 1 + drivers/power/pmic/lp87565.c | 1 + drivers/power/pmic/max77686.c | 1 + drivers/power/pmic/max8997.c | 1 + drivers/power/pmic/max8998.c | 1 + drivers/power/pmic/palmas.c | 1 + drivers/power/pmic/pca9450.c | 1 + drivers/power/pmic/pfuze100.c | 1 + drivers/power/pmic/pmic_tps65910_dm.c | 1 + drivers/power/pmic/s2mps11.c | 1 + drivers/power/pmic/s5m8767.c | 1 + drivers/power/pmic/sandbox.c | 1 + drivers/power/pmic/tps65090.c | 1 + drivers/power/pmic/tps65941.c | 1 + drivers/power/regulator/bd71837.c | 1 + drivers/power/regulator/fan53555.c | 1 + drivers/power/regulator/fixed.c | 2 + drivers/power/regulator/gpio-regulator.c | 2 + drivers/power/regulator/max77686.c | 1 + drivers/power/regulator/pbias_regulator.c | 1 + drivers/power/regulator/regulator_common.c | 2 + drivers/power/regulator/s2mps11_regulator.c | 1 + drivers/power/regulator/sandbox.c | 1 + drivers/power/regulator/tps65910_regulator.c | 1 + drivers/power/twl4030.c | 1 + drivers/power/twl6030.c | 1 + drivers/ram/imxrt_sdram.c | 1 + drivers/ram/rockchip/dmc-rk3368.c | 1 + drivers/ram/stm32_sdram.c | 1 + drivers/ram/stm32mp1/stm32mp1_ddr.c | 1 + drivers/ram/stm32mp1/stm32mp1_ram.c | 1 + drivers/ram/stm32mp1/stm32mp1_tuning.c | 1 + drivers/remoteproc/rproc-elf-loader.c | 1 + drivers/remoteproc/rproc-uclass.c | 1 + drivers/remoteproc/sandbox_testproc.c | 1 + drivers/remoteproc/stm32_copro.c | 1 + drivers/remoteproc/ti_power_proc.c | 1 + drivers/remoteproc/ti_sci_proc.h | 1 + drivers/reset/sti-reset.c | 1 + drivers/serial/serial_mtk.c | 1 + drivers/soc/ti/k3-navss-ringacc.c | 1 + drivers/spi/atmel_spi.c | 1 + drivers/spi/fsl_dspi.c | 1 + drivers/spi/mt7621_spi.c | 1 + drivers/spi/mxc_spi.c | 1 + drivers/spi/pl022_spi.c | 1 + drivers/spi/stm32_qspi.c | 1 + drivers/spi/stm32_spi.c | 1 + drivers/spi/uniphier_spi.c | 1 + drivers/sysreset/sysreset_sti.c | 1 + drivers/sysreset/sysreset_syscon.c | 1 + drivers/sysreset/sysreset_watchdog.c | 1 + drivers/tpm/tpm_tis_infineon.c | 1 + drivers/usb/cdns3/gadget.c | 1 + drivers/usb/common/common.c | 1 + drivers/usb/dwc3/dwc3-generic.c | 1 + drivers/usb/dwc3/dwc3-meson-g12a.c | 1 + drivers/usb/dwc3/gadget.c | 1 + drivers/usb/eth/mcs7830.c | 1 + drivers/usb/gadget/at91_udc.c | 1 + drivers/usb/gadget/atmel_usba_udc.c | 1 + drivers/usb/gadget/dwc2_udc_otg.c | 1 + drivers/usb/gadget/ether.c | 1 + drivers/usb/gadget/f_fastboot.c | 1 + drivers/usb/gadget/f_sdp.c | 1 + drivers/usb/gadget/f_thor.c | 1 + drivers/usb/gadget/udc/udc-uclass.c | 1 + drivers/usb/host/dwc3-sti-glue.c | 1 + drivers/usb/musb-new/mt85xx.c | 1 + drivers/usb/musb-new/musb_core.c | 1 + drivers/usb/musb-new/musb_debug.h | 1 + drivers/usb/musb-new/musb_dsps.c | 1 + drivers/usb/musb-new/musb_gadget.c | 1 + drivers/usb/musb-new/musb_gadget_ep0.c | 1 + drivers/usb/musb-new/omap2430.c | 1 + drivers/usb/musb-new/sunxi.c | 1 + drivers/usb/musb-new/ti-musb.c | 1 + drivers/video/am335x-fb.c | 1 + drivers/video/meson/meson_dw_hdmi.c | 1 + drivers/video/meson/meson_vclk.c | 1 + drivers/video/stm32/stm32_dsi.c | 1 + drivers/video/stm32/stm32_ltdc.c | 1 + drivers/video/tegra124/sor.c | 1 + drivers/watchdog/stm32mp_wdt.c | 1 + env/common.c | 1 + fs/ubifs/debug.c | 1 + fs/ubifs/debug.h | 1 + fs/ubifs/lpt_commit.c | 1 + fs/ubifs/super.c | 1 + fs/ubifs/ubifs.h | 1 + fs/yaffs2/yaffs_uboot_glue.c | 1 + include/common.h | 1 - include/crypto/pkcs7_parser.h | 1 + include/dm/device_compat.h | 1 + include/linux/soc/ti/cppi5.h | 1 + lib/asn1_decoder.c | 1 + lib/bch.c | 1 + lib/crypto/asymmetric_type.c | 1 + lib/crypto/pkcs7_parser.c | 1 + lib/crypto/pkcs7_verify.c | 1 + lib/crypto/public_key.c | 1 + lib/crypto/rsa_helper.c | 1 + lib/crypto/x509_cert_parser.c | 1 + lib/crypto/x509_public_key.c | 1 + lib/list_sort.c | 1 + net/fastboot.c | 1 + 326 files changed, 549 insertions(+), 1 deletion(-) create mode 100644 drivers/phy/meson-gxl-usb3.c
diff --git a/arch/arm/lib/gic-v3-its.c b/arch/arm/lib/gic-v3-its.c index a1657e38536..6cdcd1ed60c 100644 --- a/arch/arm/lib/gic-v3-its.c +++ b/arch/arm/lib/gic-v3-its.c @@ -10,6 +10,7 @@ #include <asm/gic-v3.h> #include <asm/io.h> #include <linux/bitops.h> +#include <linux/printk.h> #include <linux/sizes.h>
static u32 lpi_id_bits; diff --git a/arch/arm/mach-imx/imx8/fdt.c b/arch/arm/mach-imx/imx8/fdt.c index a132ce2e6a3..776d2b24345 100644 --- a/arch/arm/mach-imx/imx8/fdt.c +++ b/arch/arm/mach-imx/imx8/fdt.c @@ -11,6 +11,7 @@ #include <dm/ofnode.h> #include <fdt_support.h> #include <linux/libfdt.h> +#include <linux/printk.h>
diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index f01aeb40c9d..3b36e36102c 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -13,6 +13,7 @@ #include <log.h> #include <spl.h> #include <asm/global_data.h> +#include <linux/printk.h> #include "common.h" #include <dm.h> #include <remoteproc.h> diff --git a/arch/arm/mach-meson/board-gx.c b/arch/arm/mach-meson/board-gx.c index f5273f42af6..0ce8b5cee48 100644 --- a/arch/arm/mach-meson/board-gx.c +++ b/arch/arm/mach-meson/board-gx.c @@ -15,6 +15,7 @@ #include <asm/global_data.h> #include <asm/io.h> #include <asm/armv8/mmu.h> +#include <linux/printk.h> #include <linux/sizes.h> #include <usb.h> #include <linux/usb/otg.h> diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index 852d36132a5..b7320ff00bf 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -37,6 +37,7 @@ #include <linux/delay.h> #include <linux/errno.h> #include <linux/compiler.h> +#include <linux/printk.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <linux/usb/musb.h> diff --git a/arch/arm/mach-omap2/utils.c b/arch/arm/mach-omap2/utils.c index 6e6791fc659..095b5d3c36f 100644 --- a/arch/arm/mach-omap2/utils.c +++ b/arch/arm/mach-omap2/utils.c @@ -9,6 +9,7 @@ #include <asm/setup.h> #include <asm/arch/sys_proto.h> #include <asm/omap_common.h> +#include <linux/printk.h>
static void do_cancel_out(u32 *num, u32 *den, u32 factor) { diff --git a/arch/arm/mach-rockchip/boot_mode.c b/arch/arm/mach-rockchip/boot_mode.c index 2158934159a..c6d19541ac7 100644 --- a/arch/arm/mach-rockchip/boot_mode.c +++ b/arch/arm/mach-rockchip/boot_mode.c @@ -12,6 +12,7 @@ #include <asm/arch-rockchip/boot_mode.h> #include <dm/device.h> #include <dm/uclass.h> +#include <linux/printk.h>
#if (CONFIG_ROCKCHIP_BOOT_MODE_REG == 0)
diff --git a/arch/arm/mach-rockchip/rk3188/rk3188.c b/arch/arm/mach-rockchip/rk3188/rk3188.c index ad8c6cd1d79..3862e6bb739 100644 --- a/arch/arm/mach-rockchip/rk3188/rk3188.c +++ b/arch/arm/mach-rockchip/rk3188/rk3188.c @@ -16,6 +16,7 @@ #include <asm/arch-rockchip/grf_rk3188.h> #include <asm/arch-rockchip/hardware.h> #include <linux/err.h> +#include <linux/printk.h>
#define GRF_BASE 0x20008000
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index 869d2159bea..f8f6799a7fd 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -19,6 +19,7 @@ #include <asm/arch-rockchip/grf_rk3399.h> #include <asm/arch-rockchip/hardware.h> #include <linux/bitops.h> +#include <linux/printk.h> #include <power/regulator.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 64a7c9d652c..6813279e6ae 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -25,6 +25,7 @@ #include <asm/arch/nic301.h> #include <asm/arch/scu.h> #include <asm/pl310.h> +#include <linux/printk.h>
diff --git a/arch/arm/mach-stm32mp/bsec.c b/arch/arm/mach-stm32mp/bsec.c index a9b9bd09027..566961ae391 100644 --- a/arch/arm/mach-stm32mp/bsec.c +++ b/arch/arm/mach-stm32mp/bsec.c @@ -12,6 +12,7 @@ #include <asm/arch/stm32mp1_smc.h> #include <linux/arm-smccc.h> #include <linux/iopoll.h> +#include <linux/printk.h>
#define BSEC_OTP_MAX_VALUE 95 #define BSEC_TIMEOUT_US 10000 diff --git a/arch/arm/mach-stm32mp/cmd_stm32key.c b/arch/arm/mach-stm32mp/cmd_stm32key.c index f191085a12d..eb3d74bc836 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32key.c +++ b/arch/arm/mach-stm32mp/cmd_stm32key.c @@ -9,6 +9,7 @@ #include <misc.h> #include <dm/device.h> #include <dm/uclass.h> +#include <linux/printk.h>
#define STM32_OTP_HASH_KEY_START 24 #define STM32_OTP_HASH_KEY_SIZE 8 diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c index 49dd25b28f4..d241dbde20e 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c @@ -8,6 +8,7 @@ #include <dfu.h> #include <image.h> #include <asm/arch/stm32prog.h> +#include <linux/printk.h> #include "stm32prog.h"
struct stm32prog_data *stm32prog_data; diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index ddf8b68f9a0..d58a7fd1b86 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -17,6 +17,7 @@ #include <linux/list.h> #include <linux/list_sort.h> #include <linux/mtd/mtd.h> +#include <linux/printk.h> #include <linux/sizes.h>
#include "stm32prog.h" diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h index bae4e91c01d..002b4d39be6 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h @@ -6,6 +6,8 @@ #ifndef _STM32PROG_H_ #define _STM32PROG_H_
+#include <linux/printk.h> + /* - phase defines ------------------------------------------------*/ #define PHASE_FLASHLAYOUT 0x00 #define PHASE_FIRST_USER 0x10 diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c index 0150d2d5412..8481a45f65b 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c @@ -14,6 +14,7 @@ #include <dm/lists.h> #include <dm/device-internal.h> #include <linux/delay.h> +#include <linux/printk.h> #include "stm32prog.h"
/* - configuration part -----------------------------*/ diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c index 30547f94c94..134c3b117f5 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c @@ -9,6 +9,7 @@ #include <usb.h> #include <asm/arch/stm32prog.h> #include <asm/arch/sys_proto.h> +#include <linux/printk.h> #include "stm32prog.h"
static int stm32prog_set_phase(struct stm32prog_data *data, u8 phase, diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index f273d84492f..9a5de2b283e 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -19,6 +19,7 @@ #include <dm/device.h> #include <dm/uclass.h> #include <linux/bitops.h> +#include <linux/printk.h>
/* RCC register */ #define RCC_TZCR (STM32_RCC_BASE + 0x00) diff --git a/arch/arm/mach-stm32mp/include/mach/stm32mp1_smc.h b/arch/arm/mach-stm32mp/include/mach/stm32mp1_smc.h index 4ad14f963b4..1b2bba3d34c 100644 --- a/arch/arm/mach-stm32mp/include/mach/stm32mp1_smc.h +++ b/arch/arm/mach-stm32mp/include/mach/stm32mp1_smc.h @@ -7,6 +7,7 @@ #define __STM32MP1_SMC_H__
#include <linux/arm-smccc.h> +#include <linux/printk.h>
/* * SMC function IDs for STM32 Service queries diff --git a/arch/arm/mach-tegra/cboot.c b/arch/arm/mach-tegra/cboot.c index bb46fb23ff7..6a47c104b72 100644 --- a/arch/arm/mach-tegra/cboot.c +++ b/arch/arm/mach-tegra/cboot.c @@ -15,6 +15,7 @@ #include <stdlib.h> #include <string.h> #include <asm/global_data.h> +#include <linux/printk.h>
#include <linux/ctype.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-tegra/ivc.c b/arch/arm/mach-tegra/ivc.c index b69a458fdf0..66c1276f4b8 100644 --- a/arch/arm/mach-tegra/ivc.c +++ b/arch/arm/mach-tegra/ivc.c @@ -8,6 +8,7 @@ #include <asm/io.h> #include <asm/arch-tegra/ivc.h> #include <linux/bug.h> +#include <linux/printk.h>
#define TEGRA_IVC_ALIGN 64
diff --git a/arch/arm/mach-tegra/tegra124/xusb-padctl.c b/arch/arm/mach-tegra/tegra124/xusb-padctl.c index c95ca048d5e..5b88d6e5e7b 100644 --- a/arch/arm/mach-tegra/tegra124/xusb-padctl.c +++ b/arch/arm/mach-tegra/tegra124/xusb-padctl.c @@ -12,6 +12,7 @@ #include <dm/of_access.h> #include <dm/ofnode.h> #include <linux/delay.h> +#include <linux/printk.h>
#include "../xusb-padctl-common.h"
diff --git a/arch/arm/mach-tegra/tegra20/clock.c b/arch/arm/mach-tegra/tegra20/clock.c index 24e8a13b1f9..b1e2c87e629 100644 --- a/arch/arm/mach-tegra/tegra20/clock.c +++ b/arch/arm/mach-tegra/tegra20/clock.c @@ -19,6 +19,7 @@ #include <div64.h> #include <fdtdec.h> #include <linux/delay.h> +#include <linux/printk.h>
/* * Clock types that we can use as a source. The Tegra20 has muxes for the diff --git a/arch/arm/mach-tegra/tegra210/xusb-padctl.c b/arch/arm/mach-tegra/tegra210/xusb-padctl.c index c414dfd3b86..30d0395bb0e 100644 --- a/arch/arm/mach-tegra/tegra210/xusb-padctl.c +++ b/arch/arm/mach-tegra/tegra210/xusb-padctl.c @@ -12,6 +12,7 @@ #include <dm/of_access.h> #include <dm/ofnode.h> #include <linux/delay.h> +#include <linux/printk.h>
diff --git a/arch/arm/mach-tegra/tegra30/clock.c b/arch/arm/mach-tegra/tegra30/clock.c index b0641c6a41a..d516ac5f4cb 100644 --- a/arch/arm/mach-tegra/tegra30/clock.c +++ b/arch/arm/mach-tegra/tegra30/clock.c @@ -18,6 +18,7 @@ #include <div64.h> #include <fdtdec.h> #include <linux/delay.h> +#include <linux/printk.h>
/* * Clock types that we can use as a source. The Tegra30 has muxes for the diff --git a/arch/arm/mach-tegra/xusb-padctl-common.c b/arch/arm/mach-tegra/xusb-padctl-common.c index e56e27c8b6e..5de403c30e4 100644 --- a/arch/arm/mach-tegra/xusb-padctl-common.c +++ b/arch/arm/mach-tegra/xusb-padctl-common.c @@ -8,6 +8,7 @@ #include <common.h> #include <errno.h> #include <log.h> +#include <linux/printk.h>
#include "xusb-padctl-common.h"
diff --git a/arch/arm/mach-uniphier/boot-device/boot-device.c b/arch/arm/mach-uniphier/boot-device/boot-device.c index 98ff34cfa71..1e6bc8433f7 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device.c +++ b/arch/arm/mach-uniphier/boot-device/boot-device.c @@ -12,6 +12,7 @@ #include <linux/errno.h> #include <linux/io.h> #include <linux/log2.h> +#include <linux/printk.h>
#include "../init.h" #include "../sg-regs.h" diff --git a/arch/arm/mach-uniphier/clk/dpll-ld4.c b/arch/arm/mach-uniphier/clk/dpll-ld4.c index 3ccaf02242c..f24a0eb0b82 100644 --- a/arch/arm/mach-uniphier/clk/dpll-ld4.c +++ b/arch/arm/mach-uniphier/clk/dpll-ld4.c @@ -7,6 +7,7 @@ #include <linux/delay.h> #include <linux/errno.h> #include <linux/io.h> +#include <linux/printk.h>
#include "../init.h" #include "../sc-regs.h" diff --git a/arch/arm/mach-uniphier/clk/dpll-pro4.c b/arch/arm/mach-uniphier/clk/dpll-pro4.c index 44006ae6dc4..204aee1a62c 100644 --- a/arch/arm/mach-uniphier/clk/dpll-pro4.c +++ b/arch/arm/mach-uniphier/clk/dpll-pro4.c @@ -7,6 +7,7 @@ #include <linux/delay.h> #include <linux/errno.h> #include <linux/io.h> +#include <linux/printk.h>
#include "../init.h" #include "../sc-regs.h" diff --git a/arch/arm/mach-uniphier/dram/umc-ld4.c b/arch/arm/mach-uniphier/dram/umc-ld4.c index 96acca2562f..1eb15b611fd 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld4.c +++ b/arch/arm/mach-uniphier/dram/umc-ld4.c @@ -7,6 +7,7 @@
#include <linux/errno.h> #include <linux/io.h> +#include <linux/printk.h> #include <linux/sizes.h> #include <asm/processor.h>
diff --git a/arch/arm/mach-uniphier/dram/umc-pro4.c b/arch/arm/mach-uniphier/dram/umc-pro4.c index cde39b499bf..0114df782b4 100644 --- a/arch/arm/mach-uniphier/dram/umc-pro4.c +++ b/arch/arm/mach-uniphier/dram/umc-pro4.c @@ -7,6 +7,7 @@
diff --git a/arch/arm/mach-uniphier/dram/umc-sld8.c b/arch/arm/mach-uniphier/dram/umc-sld8.c index a11586952d8..583a1bad8b7 100644 --- a/arch/arm/mach-uniphier/dram/umc-sld8.c +++ b/arch/arm/mach-uniphier/dram/umc-sld8.c @@ -7,6 +7,7 @@
diff --git a/arch/arm/mach-uniphier/memconf.c b/arch/arm/mach-uniphier/memconf.c index 57192f0154a..ab0d187a1fa 100644 --- a/arch/arm/mach-uniphier/memconf.c +++ b/arch/arm/mach-uniphier/memconf.c @@ -7,6 +7,7 @@
#include "sg-regs.h" diff --git a/arch/arm/mach-uniphier/spl_board_init.c b/arch/arm/mach-uniphier/spl_board_init.c index a93b8cdc04d..0f2e3504c81 100644 --- a/arch/arm/mach-uniphier/spl_board_init.c +++ b/arch/arm/mach-uniphier/spl_board_init.c @@ -7,6 +7,7 @@ #include <debug_uart.h> #include <hang.h> #include <spl.h> +#include <linux/printk.h>
#include "init.h" #include "micro-support-card.h" diff --git a/arch/riscv/lib/smp.c b/arch/riscv/lib/smp.c index ba992100adf..a0730f93bf5 100644 --- a/arch/riscv/lib/smp.c +++ b/arch/riscv/lib/smp.c @@ -10,6 +10,7 @@ #include <asm/barrier.h> #include <asm/global_data.h> #include <asm/smp.h> +#include <linux/printk.h>
diff --git a/arch/x86/cpu/tangier/pinmux.c b/arch/x86/cpu/tangier/pinmux.c index 5b0e106011a..596c2c177ce 100644 --- a/arch/x86/cpu/tangier/pinmux.c +++ b/arch/x86/cpu/tangier/pinmux.c @@ -13,6 +13,7 @@ #include <asm/cpu.h> #include <asm/scu.h> #include <linux/io.h> +#include <linux/printk.h>
#define BUFCFG_OFFSET 0x100
diff --git a/arch/x86/cpu/tangier/sdram.c b/arch/x86/cpu/tangier/sdram.c index df3b9e4ec97..0f0ab4102be 100644 --- a/arch/x86/cpu/tangier/sdram.c +++ b/arch/x86/cpu/tangier/sdram.c @@ -9,6 +9,7 @@ #include <asm/e820.h> #include <asm/global_data.h> #include <asm/sfi.h> +#include <linux/printk.h>
diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index a7bde9de58f..ec5311f84e6 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -35,6 +35,7 @@ #include <phy.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h> #include <power/regulator.h> #include <remoteproc.h> #include <reset.h> diff --git a/board/mediatek/mt8518/mt8518_ap1.c b/board/mediatek/mt8518/mt8518_ap1.c index fce5de6767c..5a300821c9b 100644 --- a/board/mediatek/mt8518/mt8518_ap1.c +++ b/board/mediatek/mt8518/mt8518_ap1.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <asm/global_data.h> +#include <linux/printk.h>
diff --git a/board/mscc/ocelot/ocelot.c b/board/mscc/ocelot/ocelot.c index c462890bb85..51e1aeccf57 100644 --- a/board/mscc/ocelot/ocelot.c +++ b/board/mscc/ocelot/ocelot.c @@ -16,6 +16,7 @@ #include <wait_bit.h> #include <miiphy.h> #include <linux/bitops.h> +#include <linux/printk.h>
diff --git a/board/nvidia/jetson-tk1/jetson-tk1.c b/board/nvidia/jetson-tk1/jetson-tk1.c index 9eccdc4a832..ae1c76b133d 100644 --- a/board/nvidia/jetson-tk1/jetson-tk1.c +++ b/board/nvidia/jetson-tk1/jetson-tk1.c @@ -7,6 +7,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <linux/printk.h> #include <power/as3722.h> #include <power/pmic.h>
diff --git a/board/pine64/pinebook-pro-rk3399/pinebook-pro-rk3399.c b/board/pine64/pinebook-pro-rk3399/pinebook-pro-rk3399.c index 516292aaa59..4ad780767ea 100644 --- a/board/pine64/pinebook-pro-rk3399/pinebook-pro-rk3399.c +++ b/board/pine64/pinebook-pro-rk3399/pinebook-pro-rk3399.c @@ -12,6 +12,7 @@ #include <asm/arch-rockchip/grf_rk3399.h> #include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/misc.h> +#include <linux/printk.h> #include <power/regulator.h>
#define GRF_IO_VSEL_BT565_SHIFT 0 diff --git a/board/samsung/common/exynos5-dt.c b/board/samsung/common/exynos5-dt.c index 4463cdcb87b..97f4097cbcd 100644 --- a/board/samsung/common/exynos5-dt.c +++ b/board/samsung/common/exynos5-dt.c @@ -26,6 +26,7 @@ #include <asm/arch/pinmux.h> #include <asm/arch/power.h> #include <asm/arch/sromc.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/max77686_pmic.h> #include <power/regulator.h> diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index 7d3b9846e39..0243d8971c8 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -11,6 +11,7 @@ #include <libtizen.h> #include <asm/global_data.h> #include <linux/delay.h> +#include <linux/printk.h> #include <samsung/misc.h> #include <errno.h> #include <version.h> diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index b32b82fc2da..5fb01bba055 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -13,6 +13,7 @@ #include <asm/arch/mmc.h> #include <dm.h> #include <linux/delay.h> +#include <linux/printk.h> #include <power/pmic.h> #include <usb/dwc2_udc.h> #include <asm/arch/cpu.h> diff --git a/board/samsung/odroid/odroid.c b/board/samsung/odroid/odroid.c index 90aab62d33b..19e5bccbdb5 100644 --- a/board/samsung/odroid/odroid.c +++ b/board/samsung/odroid/odroid.c @@ -15,6 +15,7 @@ #include <asm/arch/cpu.h> #include <dm.h> #include <env.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/max77686_pmic.h> diff --git a/board/st/common/stm32mp_dfu.c b/board/st/common/stm32mp_dfu.c index aab7d741ac6..04b56f7a6c4 100644 --- a/board/st/common/stm32mp_dfu.c +++ b/board/st/common/stm32mp_dfu.c @@ -13,6 +13,7 @@ #include <mtd.h> #include <mtd_node.h> #include <asm/arch/stm32prog.h> +#include <linux/printk.h>
#define DFU_ALT_BUF_LEN SZ_1K
diff --git a/board/st/common/stm32mp_mtdparts.c b/board/st/common/stm32mp_mtdparts.c index ef32df04fef..7151cad6d0f 100644 --- a/board/st/common/stm32mp_mtdparts.c +++ b/board/st/common/stm32mp_mtdparts.c @@ -14,6 +14,7 @@ #include <asm/arch/stm32prog.h> #include <asm/arch/sys_proto.h> #include <asm/global_data.h> +#include <linux/printk.h>
#define MTDPARTS_LEN 256 #define MTDIDS_LEN 128 diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index f1df06caa49..97dce65c436 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -39,6 +39,7 @@ #include <linux/delay.h> #include <linux/err.h> #include <linux/iopoll.h> +#include <linux/printk.h> #include <power/regulator.h> #include <usb/dwc2_udc.h>
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index aa727272be4..6f0f10814ad 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -30,6 +30,7 @@ #include <asm/arch/spl.h> #include <asm/global_data.h> #include <linux/delay.h> +#include <linux/printk.h> #include <u-boot/crc.h> #ifndef CONFIG_ARM64 #include <asm/armv7.h> diff --git a/board/synopsys/hsdk/clk-lib.c b/board/synopsys/hsdk/clk-lib.c index 1c74bfb93a3..eed0fa15b19 100644 --- a/board/synopsys/hsdk/clk-lib.c +++ b/board/synopsys/hsdk/clk-lib.c @@ -8,6 +8,7 @@ #include <log.h> #include <malloc.h> #include <dm/device.h> +#include <linux/printk.h>
#include "clk-lib.h"
diff --git a/board/synopsys/hsdk/env-lib.c b/board/synopsys/hsdk/env-lib.c index 235f29565f9..dbec12c8a7b 100644 --- a/board/synopsys/hsdk/env-lib.c +++ b/board/synopsys/hsdk/env-lib.c @@ -7,6 +7,7 @@ #include "env-lib.h" #include <env.h> #include <log.h> +#include <linux/printk.h>
#define MAX_CMD_LEN 25
diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c index 3d44c70fe42..0f5ec260b16 100644 --- a/board/ti/am65x/evm.c +++ b/board/ti/am65x/evm.c @@ -22,6 +22,7 @@ #include <env.h> #include <spl.h> #include <asm/arch/sys_proto.h> +#include <linux/printk.h>
#include "../common/board_detect.h"
diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index 8b3b4bc8253..ea78eeb054a 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -19,6 +19,7 @@ #include <mmc.h> #include <errno.h> #include <malloc.h> +#include <linux/printk.h>
#include "board_detect.h"
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index fb602950233..e04d030b48e 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -23,6 +23,7 @@ #include <asm/arch/sys_proto.h> #include <dm.h> #include <dm/uclass-internal.h> +#include <linux/printk.h>
diff --git a/board/toradex/apalis-tk1/apalis-tk1.c b/board/toradex/apalis-tk1/apalis-tk1.c index e7a2186c2c4..349b3119370 100644 --- a/board/toradex/apalis-tk1/apalis-tk1.c +++ b/board/toradex/apalis-tk1/apalis-tk1.c @@ -16,6 +16,7 @@ #include <env_internal.h> #include <pci_tegra.h> #include <linux/delay.h> +#include <linux/printk.h> #include <power/as3722.h> #include <power/pmic.h>
diff --git a/cmd/adc.c b/cmd/adc.c index 16f914a030e..557a2c1f5d0 100644 --- a/cmd/adc.c +++ b/cmd/adc.c @@ -7,6 +7,7 @@ #include <command.h> #include <dm.h> #include <adc.h> +#include <linux/printk.h>
static int do_adc_list(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) diff --git a/cmd/fastboot.c b/cmd/fastboot.c index ad5c0649118..48b891b28fc 100644 --- a/cmd/fastboot.c +++ b/cmd/fastboot.c @@ -14,6 +14,7 @@ #include <net.h> #include <usb.h> #include <watchdog.h> +#include <linux/printk.h> #include <linux/stringify.h>
static int do_fastboot_udp(int argc, char *const argv[], diff --git a/cmd/nvedit.c b/cmd/nvedit.c index e73bc4dfa02..b0f0bee33b6 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -37,6 +37,7 @@ #include <mapmem.h> #include <asm/global_data.h> #include <linux/bitops.h> +#include <linux/printk.h> #include <u-boot/crc.h> #include <watchdog.h> #include <linux/stddef.h> diff --git a/cmd/onenand.c b/cmd/onenand.c index 216458bb474..fa403369faa 100644 --- a/cmd/onenand.c +++ b/cmd/onenand.c @@ -12,6 +12,7 @@ #include <common.h> #include <command.h> #include <malloc.h> +#include <linux/printk.h>
#include <linux/compat.h> #include <linux/mtd/mtd.h> diff --git a/cmd/regulator.c b/cmd/regulator.c index aa06c9a9fc8..0d97334a901 100644 --- a/cmd/regulator.c +++ b/cmd/regulator.c @@ -8,6 +8,7 @@ #include <errno.h> #include <dm.h> #include <dm/uclass-internal.h> +#include <linux/printk.h> #include <power/regulator.h>
#define LIMIT_DEVNAME 20 diff --git a/cmd/thordown.c b/cmd/thordown.c index ae20dddfddb..f36fb20e26e 100644 --- a/cmd/thordown.c +++ b/cmd/thordown.c @@ -12,6 +12,7 @@ #include <dfu.h> #include <g_dnl.h> #include <usb.h> +#include <linux/printk.h>
int do_thor_down(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { diff --git a/cmd/tpm_test.c b/cmd/tpm_test.c index ebfb25cab0a..d7044336ff2 100644 --- a/cmd/tpm_test.c +++ b/cmd/tpm_test.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <log.h> #include <tpm-v1.h> +#include <linux/printk.h> #include "tpm-user-utils.h"
/* Prints error and returns on failure */ diff --git a/cmd/usb_gadget_sdp.c b/cmd/usb_gadget_sdp.c index 1af82e11366..651a3ebcb5d 100644 --- a/cmd/usb_gadget_sdp.c +++ b/cmd/usb_gadget_sdp.c @@ -11,6 +11,7 @@ #include <g_dnl.h> #include <sdp.h> #include <usb.h> +#include <linux/printk.h>
static int do_sdp(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index cf2f55994e0..a80bcbf13c7 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -18,6 +18,7 @@ #include <usb_mass_storage.h> #include <watchdog.h> #include <linux/delay.h> +#include <linux/printk.h>
static int ums_read_sector(struct ums *ums_dev, ulong start, lbaint_t blkcnt, void *buf) diff --git a/common/dfu.c b/common/dfu.c index d23cf67f194..c879e8d6a8f 100644 --- a/common/dfu.c +++ b/common/dfu.c @@ -19,6 +19,7 @@ #include <g_dnl.h> #include <usb.h> #include <net.h> +#include <linux/printk.h>
int run_usb_dnl_gadget(int usbctrl_index, char *usb_dnl_gadget) { diff --git a/common/spl/spl_dfu.c b/common/spl/spl_dfu.c index 5728d43ad3f..8a779da8fa1 100644 --- a/common/spl/spl_dfu.c +++ b/common/spl/spl_dfu.c @@ -15,6 +15,7 @@ #include <g_dnl.h> #include <usb.h> #include <dfu.h> +#include <linux/printk.h>
static int run_dfu(int usb_index, char *interface, char *devstring) { diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 7f06081854f..7758a9ed583 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -16,6 +16,7 @@ #include <asm/cache.h> #include <asm/global_data.h> #include <linux/libfdt.h> +#include <linux/printk.h>
diff --git a/common/spl/spl_opensbi.c b/common/spl/spl_opensbi.c index 90c4a5f9704..4bde3bb4687 100644 --- a/common/spl/spl_opensbi.c +++ b/common/spl/spl_opensbi.c @@ -15,6 +15,7 @@ #include <asm/smp.h> #include <opensbi.h> #include <linux/libfdt.h> +#include <linux/printk.h>
diff --git a/common/spl/spl_sdp.c b/common/spl/spl_sdp.c index ae9c09883a4..a72f393764c 100644 --- a/common/spl/spl_sdp.c +++ b/common/spl/spl_sdp.c @@ -10,6 +10,7 @@ #include <usb.h> #include <g_dnl.h> #include <sdp.h> +#include <linux/printk.h>
static int spl_sdp_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) diff --git a/common/update.c b/common/update.c index 36b6b7523d5..81be5a1aae9 100644 --- a/common/update.c +++ b/common/update.c @@ -9,6 +9,7 @@ #include <common.h> #include <cpu_func.h> #include <image.h> +#include <linux/printk.h>
#if !(defined(CONFIG_FIT) && defined(CONFIG_OF_LIBFDT)) #error "CONFIG_FIT and CONFIG_OF_LIBFDT are required for auto-update feature" diff --git a/disk/part_efi.c b/disk/part_efi.c index 530a2f30f3d..aec5755fe16 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -25,6 +25,7 @@ #include <part_efi.h> #include <linux/compiler.h> #include <linux/ctype.h> +#include <linux/printk.h> #include <u-boot/crc.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/adc/adc-uclass.c b/drivers/adc/adc-uclass.c index d4356672581..7c033a6855b 100644 --- a/drivers/adc/adc-uclass.c +++ b/drivers/adc/adc-uclass.c @@ -13,6 +13,7 @@ #include <dm/uclass-internal.h> #include <adc.h> #include <linux/delay.h> +#include <linux/printk.h> #include <power/regulator.h>
#define ADC_UCLASS_PLATDATA_SIZE sizeof(struct adc_uclass_platdata) diff --git a/drivers/adc/exynos-adc.c b/drivers/adc/exynos-adc.c index b459b570507..973533d261a 100644 --- a/drivers/adc/exynos-adc.c +++ b/drivers/adc/exynos-adc.c @@ -8,6 +8,7 @@ #include <dm.h> #include <adc.h> #include <asm/arch/adc.h> +#include <linux/printk.h>
struct exynos_adc_priv { int active_channel; diff --git a/drivers/adc/meson-saradc.c b/drivers/adc/meson-saradc.c index 72b0cc4e5bd..d4abb6b943d 100644 --- a/drivers/adc/meson-saradc.c +++ b/drivers/adc/meson-saradc.c @@ -18,6 +18,7 @@ #include <linux/delay.h> #include <linux/math64.h> #include <linux/bitfield.h> +#include <linux/printk.h>
#define MESON_SAR_ADC_REG0 0x00 #define MESON_SAR_ADC_REG0_PANEL_DETECT BIT(31) diff --git a/drivers/adc/rockchip-saradc.c b/drivers/adc/rockchip-saradc.c index 561740f63b5..61e3f2cef90 100644 --- a/drivers/adc/rockchip-saradc.c +++ b/drivers/adc/rockchip-saradc.c @@ -13,6 +13,7 @@ #include <asm/io.h> #include <linux/bitops.h> #include <linux/err.h> +#include <linux/printk.h>
#define SARADC_CTRL_CHN_MASK GENMASK(2, 0) #define SARADC_CTRL_POWER_CTRL BIT(3) diff --git a/drivers/adc/sandbox.c b/drivers/adc/sandbox.c index 1f32289f603..fa1174bbaa3 100644 --- a/drivers/adc/sandbox.c +++ b/drivers/adc/sandbox.c @@ -8,6 +8,7 @@ #include <dm.h> #include <adc.h> #include <sandbox-adc.h> +#include <linux/printk.h>
/** * struct sandbox_adc_priv - sandbox ADC device's operation status and data diff --git a/drivers/ata/dwc_ahci.c b/drivers/ata/dwc_ahci.c index ed0527c9768..04505ca4f27 100644 --- a/drivers/ata/dwc_ahci.c +++ b/drivers/ata/dwc_ahci.c @@ -16,6 +16,7 @@ #include <asm/arch/sata.h> #include <asm/io.h> #include <generic-phy.h> +#include <linux/printk.h>
struct dwc_ahci_priv { void *base; diff --git a/drivers/bios_emulator/include/x86emu/debug.h b/drivers/bios_emulator/include/x86emu/debug.h index 4962a2acaf1..859b54d8600 100644 --- a/drivers/bios_emulator/include/x86emu/debug.h +++ b/drivers/bios_emulator/include/x86emu/debug.h @@ -43,6 +43,7 @@
/* checks to be enabled for "runtime" */
+#include <linux/printk.h> #define CHECK_IP_FETCH_F 0x1 #define CHECK_SP_ACCESS_F 0x2 #define CHECK_MEM_ACCESS_F 0x4 /*using regular linear pointer */ diff --git a/drivers/bios_emulator/include/x86emu/regs.h b/drivers/bios_emulator/include/x86emu/regs.h index 29341297d96..4b4c5908923 100644 --- a/drivers/bios_emulator/include/x86emu/regs.h +++ b/drivers/bios_emulator/include/x86emu/regs.h @@ -41,6 +41,7 @@
/*---------------------- Macros and type definitions ----------------------*/
+#include <linux/printk.h> #pragma pack(1)
/* diff --git a/drivers/bios_emulator/x86emu/debug.c b/drivers/bios_emulator/x86emu/debug.c index 27e90e441aa..95f3cc09aad 100644 --- a/drivers/bios_emulator/x86emu/debug.c +++ b/drivers/bios_emulator/x86emu/debug.c @@ -40,6 +40,7 @@ #include <stdarg.h> #include <common.h> #include <linux/ctype.h> +#include <linux/printk.h> #include "x86emu/x86emui.h"
/*----------------------------- Implementation ----------------------------*/ diff --git a/drivers/bios_emulator/x86emu/decode.c b/drivers/bios_emulator/x86emu/decode.c index a9a01b52d6c..e2028eaf083 100644 --- a/drivers/bios_emulator/x86emu/decode.c +++ b/drivers/bios_emulator/x86emu/decode.c @@ -37,6 +37,7 @@ * ****************************************************************************/ #include <common.h> +#include <linux/printk.h> #include "x86emu/x86emui.h"
/*----------------------------- Implementation ----------------------------*/ diff --git a/drivers/bios_emulator/x86emu/ops.c b/drivers/bios_emulator/x86emu/ops.c index ba18135fe13..8c1a146165c 100644 --- a/drivers/bios_emulator/x86emu/ops.c +++ b/drivers/bios_emulator/x86emu/ops.c @@ -73,6 +73,7 @@ ****************************************************************************/
/*----------------------------- Implementation ----------------------------*/ diff --git a/drivers/bios_emulator/x86emu/ops2.c b/drivers/bios_emulator/x86emu/ops2.c index be4ef364432..6cd1ac39825 100644 --- a/drivers/bios_emulator/x86emu/ops2.c +++ b/drivers/bios_emulator/x86emu/ops2.c @@ -43,6 +43,7 @@
#include <common.h> #include <linux/compiler.h> +#include <linux/printk.h> #include "x86emu/x86emui.h"
/*----------------------------- Implementation ----------------------------*/ diff --git a/drivers/bios_emulator/x86emu/sys.c b/drivers/bios_emulator/x86emu/sys.c index c2db1213fe6..53891960c0c 100644 --- a/drivers/bios_emulator/x86emu/sys.c +++ b/drivers/bios_emulator/x86emu/sys.c @@ -40,6 +40,7 @@ ****************************************************************************/
/*------------------------- Global Variables ------------------------------*/ diff --git a/drivers/bootcount/bootcount-uclass.c b/drivers/bootcount/bootcount-uclass.c index 34ac08d59a6..2a492c87ebd 100644 --- a/drivers/bootcount/bootcount-uclass.c +++ b/drivers/bootcount/bootcount-uclass.c @@ -8,6 +8,7 @@ #include <errno.h> #include <bootcount.h> #include <log.h> +#include <linux/printk.h>
int dm_bootcount_get(struct udevice *dev, u32 *bootcount) { diff --git a/drivers/clk/analogbits/wrpll-cln28hpc.c b/drivers/clk/analogbits/wrpll-cln28hpc.c index 776ead319ae..a3cb109d357 100644 --- a/drivers/clk/analogbits/wrpll-cln28hpc.c +++ b/drivers/clk/analogbits/wrpll-cln28hpc.c @@ -26,6 +26,7 @@ #include <linux/log2.h> #include <linux/math64.h> #include <linux/clk/analogbits-wrpll-cln28hpc.h> +#include <linux/printk.h>
/* MIN_INPUT_FREQ: minimum input clock frequency, in Hz (Fref_min) */ #define MIN_INPUT_FREQ 7000000 diff --git a/drivers/clk/clk-divider.c b/drivers/clk/clk-divider.c index 8f59d7fb72c..b28f47db0f2 100644 --- a/drivers/clk/clk-divider.c +++ b/drivers/clk/clk-divider.c @@ -24,6 +24,7 @@ #include <linux/log2.h> #include <div64.h> #include <clk.h> +#include <linux/printk.h> #include "clk.h"
#define UBOOT_DM_CLK_CCF_DIVIDER "ccf_clk_divider" diff --git a/drivers/clk/clk-gate.c b/drivers/clk/clk-gate.c index 006d3b6629c..8d6ab8f2a38 100644 --- a/drivers/clk/clk-gate.c +++ b/drivers/clk/clk-gate.c @@ -16,6 +16,7 @@ #include <linux/bitops.h> #include <linux/clk-provider.h> #include <clk.h> +#include <linux/printk.h> #include "clk.h" #include <linux/err.h>
diff --git a/drivers/clk/clk-hsdk-cgu.c b/drivers/clk/clk-hsdk-cgu.c index 3eb93a55fc4..2067316e672 100644 --- a/drivers/clk/clk-hsdk-cgu.c +++ b/drivers/clk/clk-hsdk-cgu.c @@ -19,6 +19,7 @@ #include <linux/delay.h> #include <linux/io.h> #include <asm/arcregs.h> +#include <linux/printk.h>
#include <dt-bindings/clock/snps,hsdk-cgu.h>
diff --git a/drivers/clk/clk-mux.c b/drivers/clk/clk-mux.c index f1becd20d8b..66588e5403f 100644 --- a/drivers/clk/clk-mux.c +++ b/drivers/clk/clk-mux.c @@ -31,6 +31,7 @@ #include <malloc.h> #include <asm/io.h> #include <linux/clk-provider.h> +#include <linux/printk.h> #include <linux/err.h> #include "clk.h"
diff --git a/drivers/clk/clk_boston.c b/drivers/clk/clk_boston.c index 2318dcf6a45..47424d8f533 100644 --- a/drivers/clk/clk_boston.c +++ b/drivers/clk/clk_boston.c @@ -10,6 +10,7 @@ #include <regmap.h> #include <syscon.h> #include <linux/bitops.h> +#include <linux/printk.h>
struct clk_boston { struct regmap *regmap; diff --git a/drivers/clk/clk_stm32f.c b/drivers/clk/clk_stm32f.c index 93722f74ae4..cc48905df54 100644 --- a/drivers/clk/clk_stm32f.c +++ b/drivers/clk/clk_stm32f.c @@ -10,6 +10,7 @@ #include <log.h> #include <stm32_rcc.h> #include <linux/bitops.h> +#include <linux/printk.h>
#include <asm/io.h> #include <asm/arch/stm32.h> diff --git a/drivers/clk/clk_stm32h7.c b/drivers/clk/clk_stm32h7.c index 5e6abca56fa..c1856d8678b 100644 --- a/drivers/clk/clk_stm32h7.c +++ b/drivers/clk/clk_stm32h7.c @@ -13,6 +13,7 @@ #include <asm/io.h> #include <dm/root.h> #include <linux/bitops.h> +#include <linux/printk.h>
#include <dt-bindings/clock/stm32h7-clks.h>
diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index 65ffd32d08e..8244b7c99fc 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -21,6 +21,7 @@ #include <asm/arch/sys_proto.h> #include <dt-bindings/clock/stm32mp1-clks.h> #include <dt-bindings/clock/stm32mp1-clksrc.h> +#include <linux/printk.h>
diff --git a/drivers/clk/imx/clk-pll14xx.c b/drivers/clk/imx/clk-pll14xx.c index b0ccb6c8eda..ac2461948d2 100644 --- a/drivers/clk/imx/clk-pll14xx.c +++ b/drivers/clk/imx/clk-pll14xx.c @@ -18,6 +18,7 @@ #include <linux/iopoll.h> #include <clk.h> #include <div64.h> +#include <linux/printk.h>
#include "clk.h"
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index d1804c6e168..b87be9a0341 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -22,6 +22,7 @@ #include <dm/lists.h> #include <dt-bindings/clock/rk3368-cru.h> #include <linux/delay.h> +#include <linux/printk.h> #include <linux/stringify.h>
#if CONFIG_IS_ENABLED(OF_PLATDATA) diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 1ea41f3c5b2..2b021411bc7 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -22,6 +22,7 @@ #include <dt-bindings/clock/rk3399-cru.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h>
#if CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3399_clk_plat { diff --git a/drivers/core/device.c b/drivers/core/device.c index 01670996dc8..5b12e570ba5 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -31,6 +31,7 @@ #include <linux/err.h> #include <linux/list.h> #include <power-domain.h> +#include <linux/printk.h>
diff --git a/drivers/core/of_addr.c b/drivers/core/of_addr.c index ca34d84922b..3a67d9bc760 100644 --- a/drivers/core/of_addr.c +++ b/drivers/core/of_addr.c @@ -14,6 +14,7 @@ #include <dm/of_addr.h> #include <linux/err.h> #include <linux/ioport.h> +#include <linux/printk.h>
/* Max address size we deal with */ #define OF_MAX_ADDR_CELLS 4 diff --git a/drivers/core/root.c b/drivers/core/root.c index b5446b1db02..1e9d580c494 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -25,6 +25,7 @@ #include <dm/uclass.h> #include <dm/util.h> #include <linux/list.h> +#include <linux/printk.h>
diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index a298c2c4399..3d5de92ecae 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -17,6 +17,7 @@ #include <hash.h> #include <linux/list.h> #include <linux/compiler.h> +#include <linux/printk.h>
static LIST_HEAD(dfu_list); static int dfu_alt_num; diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 691d01c7ebd..ac5ea2c7d79 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -16,6 +16,7 @@ #include <fat.h> #include <mmc.h> #include <part.h> +#include <linux/printk.h>
static unsigned char *dfu_file_buf; static u64 dfu_file_buf_len; diff --git a/drivers/dfu/dfu_ram.c b/drivers/dfu/dfu_ram.c index ab0ce9e6fa9..ec425a55169 100644 --- a/drivers/dfu/dfu_ram.c +++ b/drivers/dfu/dfu_ram.c @@ -13,6 +13,7 @@ #include <mapmem.h> #include <errno.h> #include <dfu.h> +#include <linux/printk.h>
static int dfu_transfer_medium_ram(enum dfu_op op, struct dfu_entity *dfu, u64 offset, void *buf, long *len) diff --git a/drivers/dfu/dfu_tftp.c b/drivers/dfu/dfu_tftp.c index ffae4bb54f8..0f2c114668e 100644 --- a/drivers/dfu/dfu_tftp.c +++ b/drivers/dfu/dfu_tftp.c @@ -9,6 +9,7 @@ #include <malloc.h> #include <errno.h> #include <dfu.h> +#include <linux/printk.h>
int dfu_tftp_write(char *dfu_entity_name, unsigned int addr, unsigned int len, char *interface, char *devstring) diff --git a/drivers/dma/bcm6348-iudma.c b/drivers/dma/bcm6348-iudma.c index 91172d483c7..ceb8de9b8af 100644 --- a/drivers/dma/bcm6348-iudma.c +++ b/drivers/dma/bcm6348-iudma.c @@ -28,6 +28,7 @@ #include <asm/io.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h>
#define DMA_RX_DESC 6 #define DMA_TX_DESC 1 diff --git a/drivers/dma/dma-uclass.c b/drivers/dma/dma-uclass.c index 50403148d6d..aeaf1606919 100644 --- a/drivers/dma/dma-uclass.c +++ b/drivers/dma/dma-uclass.c @@ -19,6 +19,7 @@ #include <dma-uclass.h> #include <dt-structs.h> #include <errno.h> +#include <linux/printk.h>
#ifdef CONFIG_DMA_CHANNELS static inline struct dma_ops *dma_dev_ops(struct udevice *dev) diff --git a/drivers/dma/lpc32xx_dma.c b/drivers/dma/lpc32xx_dma.c index ab58e97bfe2..0efdfd028cf 100644 --- a/drivers/dma/lpc32xx_dma.c +++ b/drivers/dma/lpc32xx_dma.c @@ -17,6 +17,7 @@ #include <asm/io.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h>
/* DMA controller channel register structure */ struct dmac_chan_reg { diff --git a/drivers/dma/sandbox-dma-test.c b/drivers/dma/sandbox-dma-test.c index 838596b24b6..18e8fe3806c 100644 --- a/drivers/dma/sandbox-dma-test.c +++ b/drivers/dma/sandbox-dma-test.c @@ -15,6 +15,7 @@ #include <dma-uclass.h> #include <dt-structs.h> #include <errno.h> +#include <linux/printk.h>
#define SANDBOX_DMA_CH_CNT 3 #define SANDBOX_DMA_BUF_SIZE 1024 diff --git a/drivers/dma/ti-edma3.c b/drivers/dma/ti-edma3.c index 13ab9670890..c73ab579cf6 100644 --- a/drivers/dma/ti-edma3.c +++ b/drivers/dma/ti-edma3.c @@ -15,6 +15,7 @@ #include <dma-uclass.h> #include <asm/omap_common.h> #include <asm/ti-common/ti-edma3.h> +#include <linux/printk.h>
#define EDMA3_SL_BASE(slot) (0x4000 + ((slot) << 5)) #define EDMA3_SL_MAX_NUM 512 diff --git a/drivers/dma/ti/k3-udma.c b/drivers/dma/ti/k3-udma.c index 94216045ccc..405d591edf5 100644 --- a/drivers/dma/ti/k3-udma.c +++ b/drivers/dma/ti/k3-udma.c @@ -24,6 +24,7 @@ #include <linux/delay.h> #include <linux/bitmap.h> #include <linux/err.h> +#include <linux/printk.h> #include <linux/soc/ti/k3-navss-ringacc.h> #include <linux/soc/ti/cppi5.h> #include <linux/soc/ti/ti-udma.h> diff --git a/drivers/fastboot/fb_command.c b/drivers/fastboot/fb_command.c index d3c578672dc..12ba4bca129 100644 --- a/drivers/fastboot/fb_command.c +++ b/drivers/fastboot/fb_command.c @@ -13,6 +13,7 @@ #include <flash.h> #include <part.h> #include <stdlib.h> +#include <linux/printk.h>
/** * image_size - final fastboot image size diff --git a/drivers/fastboot/fb_getvar.c b/drivers/fastboot/fb_getvar.c index d43f2cfee66..1112be7893b 100644 --- a/drivers/fastboot/fb_getvar.c +++ b/drivers/fastboot/fb_getvar.c @@ -12,6 +12,7 @@ #include <fs.h> #include <part.h> #include <version.h> +#include <linux/printk.h>
static void getvar_version(char *var_parameter, char *response); static void getvar_version_bootloader(char *var_parameter, char *response); diff --git a/drivers/fastboot/fb_mmc.c b/drivers/fastboot/fb_mmc.c index ae8e8e512f2..910713b5a10 100644 --- a/drivers/fastboot/fb_mmc.c +++ b/drivers/fastboot/fb_mmc.c @@ -19,6 +19,7 @@ #include <div64.h> #include <linux/compat.h> #include <android_image.h> +#include <linux/printk.h>
#define FASTBOOT_MAX_BLK_WRITE 16384
diff --git a/drivers/fastboot/fb_nand.c b/drivers/fastboot/fb_nand.c index eb8a36f2922..1bf7ccb960b 100644 --- a/drivers/fastboot/fb_nand.c +++ b/drivers/fastboot/fb_nand.c @@ -8,6 +8,7 @@ #include <common.h> #include <blk.h> #include <flash.h> +#include <linux/printk.h>
#include <fastboot.h> #include <image-sparse.h> diff --git a/drivers/i2c/i2c-gpio.c b/drivers/i2c/i2c-gpio.c index 917cdf4e62e..d24079b96a4 100644 --- a/drivers/i2c/i2c-gpio.c +++ b/drivers/i2c/i2c-gpio.c @@ -13,6 +13,7 @@ #include <asm/global_data.h> #include <asm/gpio.h> #include <linux/delay.h> +#include <linux/printk.h>
#define DEFAULT_UDELAY 5 #define RETRIES 0 diff --git a/drivers/i2c/iproc_i2c.c b/drivers/i2c/iproc_i2c.c index b90c0ddba7c..4231c0c617f 100644 --- a/drivers/i2c/iproc_i2c.c +++ b/drivers/i2c/iproc_i2c.c @@ -9,6 +9,7 @@ #include <common.h> #include <config.h> #include <dm.h> +#include <linux/printk.h> #include "errno.h" #include <i2c.h> #include "iproc_i2c.h" diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 0af4e333c41..aaf2d10f6fd 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -43,6 +43,7 @@ #include <i2c.h> #include <log.h> #include <linux/delay.h> +#include <linux/printk.h>
#include <asm/io.h> #include <asm/omap_i2c.h> diff --git a/drivers/i2c/stm32f7_i2c.c b/drivers/i2c/stm32f7_i2c.c index 2f609115494..6c2fff1c52b 100644 --- a/drivers/i2c/stm32f7_i2c.c +++ b/drivers/i2c/stm32f7_i2c.c @@ -13,6 +13,7 @@ #include <syscon.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h>
#include <dm/device.h> #include <linux/err.h> diff --git a/drivers/i2c/tegra_i2c.c b/drivers/i2c/tegra_i2c.c index 65b3734348b..96a436a8dc1 100644 --- a/drivers/i2c/tegra_i2c.c +++ b/drivers/i2c/tegra_i2c.c @@ -21,6 +21,7 @@ #include <asm/arch-tegra/tegra_i2c.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/printk.h>
enum i2c_type { TYPE_114, diff --git a/drivers/misc/sifive-otp.c b/drivers/misc/sifive-otp.c index 92f08dde011..0a4fa67f335 100644 --- a/drivers/misc/sifive-otp.c +++ b/drivers/misc/sifive-otp.c @@ -24,6 +24,7 @@ #include <linux/delay.h> #include <linux/io.h> #include <misc.h> +#include <linux/printk.h>
#define BYTES_PER_FUSE 4
diff --git a/drivers/misc/tegra186_bpmp.c b/drivers/misc/tegra186_bpmp.c index 1f4437226e7..73cc2666e49 100644 --- a/drivers/misc/tegra186_bpmp.c +++ b/drivers/misc/tegra186_bpmp.c @@ -17,6 +17,7 @@ #include <asm/arch-tegra/ivc.h> #include <linux/bitops.h> #include <linux/err.h> +#include <linux/printk.h>
#define BPMP_IVC_FRAME_COUNT 1 #define BPMP_IVC_FRAME_SIZE 128 diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index 94af116d10c..499fafe8f5e 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -16,6 +16,7 @@ #include <asm/arch/pinmux.h> #include <asm/arch/power.h> #include <asm/gpio.h> +#include <linux/printk.h>
#define DWMMC_MAX_CH_NUM 4 #define DWMMC_MAX_FREQ 52000000 diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 5d841580c23..59a4e43965b 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -26,6 +26,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/printk.h> #include <power/regulator.h> #include <malloc.h> #include <fsl_esdhc_imx.h> diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index a47700e313c..ad8c59d9f38 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -19,6 +19,7 @@ #include <part.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h> #include <power/regulator.h> #include <malloc.h> #include <memalign.h> diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index 4f9fa7d0ec3..4964282dbf7 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -20,6 +20,7 @@ #include <linux/bitops.h> #include <linux/io.h> #include <linux/iopoll.h> +#include <linux/printk.h>
/* MSDC_CFG */ #define MSDC_CFG_HS400_CK_MODE_EXT BIT(22) diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index d549a264d73..e545c5427b5 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -20,6 +20,7 @@ #include <linux/delay.h> #include <linux/dma-mapping.h> #include <phys2bus.h> +#include <linux/printk.h>
static void sdhci_reset(struct sdhci_host *host, u8 mask) { diff --git a/drivers/mmc/sti_sdhci.c b/drivers/mmc/sti_sdhci.c index db0b566a8b7..11ae392734c 100644 --- a/drivers/mmc/sti_sdhci.c +++ b/drivers/mmc/sti_sdhci.c @@ -12,6 +12,7 @@ #include <sdhci.h> #include <asm/arch/sdhci.h> #include <asm/global_data.h> +#include <linux/printk.h>
diff --git a/drivers/mmc/stm32_sdmmc2.c b/drivers/mmc/stm32_sdmmc2.c index 77871d5afc9..92fa7a74f4a 100644 --- a/drivers/mmc/stm32_sdmmc2.c +++ b/drivers/mmc/stm32_sdmmc2.c @@ -22,6 +22,7 @@ #include <asm/gpio.h> #include <linux/iopoll.h> #include <watchdog.h> +#include <linux/printk.h>
struct stm32_sdmmc2_plat { struct mmc_config cfg; diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c index aaec3c43fef..67f1b81ed79 100644 --- a/drivers/mmc/xenon_sdhci.c +++ b/drivers/mmc/xenon_sdhci.c @@ -23,6 +23,7 @@ #include <linux/libfdt.h> #include <malloc.h> #include <sdhci.h> +#include <linux/printk.h> #include <power/regulator.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/mtd/mtdconcat.c b/drivers/mtd/mtdconcat.c index 684bc949985..1baaa6e9475 100644 --- a/drivers/mtd/mtdconcat.c +++ b/drivers/mtd/mtdconcat.c @@ -23,6 +23,7 @@ #include <div64.h> #include <linux/bug.h> #include <linux/compat.h> +#include <linux/printk.h> #endif
#include <linux/mtd/mtd.h> diff --git a/drivers/mtd/mtdcore.c b/drivers/mtd/mtdcore.c index 1a4dec34d93..6b0ea195312 100644 --- a/drivers/mtd/mtdcore.c +++ b/drivers/mtd/mtdcore.c @@ -32,6 +32,7 @@ #include <linux/bug.h> #include <linux/err.h> #include <ubi_uboot.h> +#include <linux/printk.h> #endif
#include <linux/log2.h> diff --git a/drivers/mtd/mtdpart.c b/drivers/mtd/mtdpart.c index d064ac30480..cad11805690 100644 --- a/drivers/mtd/mtdpart.c +++ b/drivers/mtd/mtdpart.c @@ -25,6 +25,7 @@ #include <linux/errno.h> #include <linux/compat.h> #include <ubi_uboot.h> +#include <linux/printk.h>
#include <linux/mtd/mtd.h> #include <linux/mtd/partitions.h> diff --git a/drivers/mtd/nand/bbt.c b/drivers/mtd/nand/bbt.c index 294daee7b22..972aec6e266 100644 --- a/drivers/mtd/nand/bbt.c +++ b/drivers/mtd/nand/bbt.c @@ -16,6 +16,7 @@ #ifndef __UBOOT__ #include <linux/slab.h> #endif +#include <linux/printk.h>
/** * nanddev_bbt_init() - Initialize the BBT (Bad Block Table) diff --git a/drivers/mtd/nand/core.c b/drivers/mtd/nand/core.c index 6fbd24ba749..45d827f686c 100644 --- a/drivers/mtd/nand/core.c +++ b/drivers/mtd/nand/core.c @@ -16,6 +16,7 @@ #endif #include <linux/bitops.h> #include <linux/mtd/nand.h> +#include <linux/printk.h>
/** * nanddev_isbad() - Check if a block is bad diff --git a/drivers/mtd/nand/raw/arasan_nfc.c b/drivers/mtd/nand/raw/arasan_nfc.c index 0615e503780..fee67fc1fce 100644 --- a/drivers/mtd/nand/raw/arasan_nfc.c +++ b/drivers/mtd/nand/raw/arasan_nfc.c @@ -18,6 +18,7 @@ #include <asm/arch/sys_proto.h> #include <dm.h> #include <nand.h> +#include <linux/printk.h>
struct nand_config { u32 page; diff --git a/drivers/mtd/nand/raw/atmel_nand.c b/drivers/mtd/nand/raw/atmel_nand.c index abc432c8626..6e10c76a1c9 100644 --- a/drivers/mtd/nand/raw/atmel_nand.c +++ b/drivers/mtd/nand/raw/atmel_nand.c @@ -19,6 +19,7 @@ #include <linux/bitops.h> #include <linux/bug.h> #include <linux/delay.h> +#include <linux/printk.h>
#include <malloc.h> #include <nand.h> diff --git a/drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c index 6313403cd65..89c981096ba 100644 --- a/drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c +++ b/drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c @@ -10,6 +10,7 @@ #include <linux/io.h> #include <linux/ioport.h> #include <dm.h> +#include <linux/printk.h>
#include "brcmnand.h"
diff --git a/drivers/mtd/nand/raw/brcmnand/bcm6368_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm6368_nand.c index cd4b24a51a1..3223d9aacff 100644 --- a/drivers/mtd/nand/raw/brcmnand/bcm6368_nand.c +++ b/drivers/mtd/nand/raw/brcmnand/bcm6368_nand.c @@ -9,6 +9,7 @@ #include <linux/io.h> #include <linux/ioport.h> #include <dm.h> +#include <linux/printk.h>
diff --git a/drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c index aa042bef158..b8e7b6b2921 100644 --- a/drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c +++ b/drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c @@ -9,6 +9,7 @@ #include <linux/io.h> #include <linux/ioport.h> #include <dm.h> +#include <linux/printk.h>
diff --git a/drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c index 07884550906..071b16c217a 100644 --- a/drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c +++ b/drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c @@ -10,6 +10,7 @@ #include <linux/io.h> #include <linux/ioport.h> #include <dm.h> +#include <linux/printk.h>
diff --git a/drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c index 818eae8a7c6..e9d23377d47 100644 --- a/drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c +++ b/drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c @@ -10,6 +10,7 @@ #include <linux/io.h> #include <linux/ioport.h> #include <dm.h> +#include <linux/printk.h>
diff --git a/drivers/mtd/nand/raw/davinci_nand.c b/drivers/mtd/nand/raw/davinci_nand.c index 4416b8fa1e6..f64de80bf2b 100644 --- a/drivers/mtd/nand/raw/davinci_nand.c +++ b/drivers/mtd/nand/raw/davinci_nand.c @@ -34,6 +34,7 @@ #include <nand.h> #include <dm/uclass.h> #include <asm/ti-common/davinci_nand.h> +#include <linux/printk.h>
/* Definitions for 4-bit hardware ECC */ #define NAND_TIMEOUT 10240 diff --git a/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c b/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c index b3232ed59d5..588fb010ee8 100644 --- a/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c +++ b/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c @@ -27,6 +27,7 @@ #include <nand.h> #include <asm/arch/clk.h> #include <asm/arch/sys_proto.h> +#include <linux/printk.h>
/* * MLC NAND controller registers. diff --git a/drivers/mtd/nand/raw/lpc32xx_nand_slc.c b/drivers/mtd/nand/raw/lpc32xx_nand_slc.c index 9cca3c55cc0..5e8e76c3e5f 100644 --- a/drivers/mtd/nand/raw/lpc32xx_nand_slc.c +++ b/drivers/mtd/nand/raw/lpc32xx_nand_slc.c @@ -22,6 +22,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/dma.h> #include <asm/arch/cpu.h> +#include <linux/printk.h>
struct lpc32xx_nand_slc_regs { u32 data; diff --git a/drivers/mtd/nand/raw/mxc_nand.c b/drivers/mtd/nand/raw/mxc_nand.c index 59cef205754..c5e56c05873 100644 --- a/drivers/mtd/nand/raw/mxc_nand.c +++ b/drivers/mtd/nand/raw/mxc_nand.c @@ -15,6 +15,7 @@ defined(CONFIG_MX51) || defined(CONFIG_MX53) #include <asm/arch/imx-regs.h> #endif +#include <linux/printk.h> #include "mxc_nand.h"
#define DRIVER_NAME "mxc_nand" diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index ebb40f93325..7cd1e133c22 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -51,6 +51,7 @@ #endif #include <asm/io.h> #include <linux/errno.h> +#include <linux/printk.h>
/* Define default oob placement schemes for large and small page devices */ #ifndef CONFIG_SYS_NAND_DRIVER_ECC_LAYOUT diff --git a/drivers/mtd/nand/raw/nand_bbt.c b/drivers/mtd/nand/raw/nand_bbt.c index 911472e91e1..4f3c3223ca7 100644 --- a/drivers/mtd/nand/raw/nand_bbt.c +++ b/drivers/mtd/nand/raw/nand_bbt.c @@ -67,6 +67,7 @@ #include <linux/mtd/bbm.h> #include <linux/mtd/rawnand.h> #include <linux/bitops.h> +#include <linux/printk.h> #include <linux/string.h>
#define BBT_BLOCK_GOOD 0x00 diff --git a/drivers/mtd/nand/raw/nand_bch.c b/drivers/mtd/nand/raw/nand_bch.c index 734d1c6204e..bb48ebbb96c 100644 --- a/drivers/mtd/nand/raw/nand_bch.c +++ b/drivers/mtd/nand/raw/nand_bch.c @@ -10,6 +10,7 @@ #include <common.h> #include <log.h> #include <dm/devres.h> +#include <linux/printk.h> /*#include <asm/io.h>*/ #include <linux/types.h>
diff --git a/drivers/mtd/nand/raw/pxa3xx_nand.c b/drivers/mtd/nand/raw/pxa3xx_nand.c index 58d527acbd4..794c20ebe82 100644 --- a/drivers/mtd/nand/raw/pxa3xx_nand.c +++ b/drivers/mtd/nand/raw/pxa3xx_nand.c @@ -22,6 +22,7 @@ #include <asm/arch/cpu.h> #include <linux/mtd/mtd.h> #include <linux/mtd/rawnand.h> +#include <linux/printk.h> #include <linux/types.h>
#include "pxa3xx_nand.h" diff --git a/drivers/mtd/nand/raw/stm32_fmc2_nand.c b/drivers/mtd/nand/raw/stm32_fmc2_nand.c index 47fe61090da..c1e884af950 100644 --- a/drivers/mtd/nand/raw/stm32_fmc2_nand.c +++ b/drivers/mtd/nand/raw/stm32_fmc2_nand.c @@ -16,6 +16,7 @@ #include <linux/err.h> #include <linux/iopoll.h> #include <linux/ioport.h> +#include <linux/printk.h>
/* Bad block marker length */ #define FMC2_BBM_LEN 2 diff --git a/drivers/mtd/nand/raw/sunxi_nand.c b/drivers/mtd/nand/raw/sunxi_nand.c index 7bc6ec7beea..c19ff338707 100644 --- a/drivers/mtd/nand/raw/sunxi_nand.c +++ b/drivers/mtd/nand/raw/sunxi_nand.c @@ -35,6 +35,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/printk.h>
#include <linux/kernel.h> #include <linux/mtd/mtd.h> diff --git a/drivers/mtd/nand/raw/tegra_nand.c b/drivers/mtd/nand/raw/tegra_nand.c index dd14c34738a..a28f830e8cd 100644 --- a/drivers/mtd/nand/raw/tegra_nand.c +++ b/drivers/mtd/nand/raw/tegra_nand.c @@ -23,6 +23,7 @@ #include <fdtdec.h> #include <bouncebuf.h> #include <dm.h> +#include <linux/printk.h> #include "tegra_nand.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/mtd/nand/raw/vf610_nfc.c b/drivers/mtd/nand/raw/vf610_nfc.c index 4e6fdc607ff..f66f527485f 100644 --- a/drivers/mtd/nand/raw/vf610_nfc.c +++ b/drivers/mtd/nand/raw/vf610_nfc.c @@ -24,6 +24,7 @@ #include <common.h> #include <malloc.h> #include <dm/device_compat.h> +#include <linux/printk.h>
#include <linux/mtd/mtd.h> #include <linux/mtd/rawnand.h> diff --git a/drivers/mtd/nand/raw/zynq_nand.c b/drivers/mtd/nand/raw/zynq_nand.c index 92db2aa19c8..bb9106d2e02 100644 --- a/drivers/mtd/nand/raw/zynq_nand.c +++ b/drivers/mtd/nand/raw/zynq_nand.c @@ -21,6 +21,7 @@ #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> #include <dm.h> +#include <linux/printk.h>
/* The NAND flash driver defines */ #define ZYNQ_NAND_CMD_PHASE 1 diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index 8c7e07d4630..a2b4dbad292 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -29,6 +29,7 @@ #include <linux/bitops.h> #include <linux/bug.h> #include <linux/mtd/spinand.h> +#include <linux/printk.h> #endif
/* SPI NAND index visible in MTD names */ diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 36daef01aec..ad9b61f396f 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -26,6 +26,7 @@ #include <linux/bitops.h> #include <linux/compat.h> #include <linux/mtd/mtd.h> +#include <linux/printk.h> #include "linux/mtd/flashchip.h" #include <linux/mtd/onenand.h>
diff --git a/drivers/mtd/onenand/onenand_bbt.c b/drivers/mtd/onenand/onenand_bbt.c index eca9edff603..cc1e449f4a7 100644 --- a/drivers/mtd/onenand/onenand_bbt.c +++ b/drivers/mtd/onenand/onenand_bbt.c @@ -20,6 +20,7 @@ #include <linux/mtd/mtd.h> #include <linux/mtd/onenand.h> #include <malloc.h> +#include <linux/printk.h>
diff --git a/drivers/mtd/onenand/samsung.c b/drivers/mtd/onenand/samsung.c index 657abaab8f4..c415e5149a0 100644 --- a/drivers/mtd/onenand/samsung.c +++ b/drivers/mtd/onenand/samsung.c @@ -16,6 +16,7 @@ #include <linux/mtd/onenand.h> #include <linux/mtd/flashchip.h> #include <linux/mtd/samsung_onenand.h> +#include <linux/printk.h>
#include <asm/io.h> #include <linux/errno.h> diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 40784312149..2726e3d746c 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -20,6 +20,7 @@ #include <linux/errno.h> #include <linux/log2.h> #include <linux/math64.h> +#include <linux/printk.h> #include <linux/sizes.h>
#include <linux/mtd/mtd.h> diff --git a/drivers/mtd/spi/spi-nor-tiny.c b/drivers/mtd/spi/spi-nor-tiny.c index 07c8c7b82b1..ab7ecad8469 100644 --- a/drivers/mtd/spi/spi-nor-tiny.c +++ b/drivers/mtd/spi/spi-nor-tiny.c @@ -16,6 +16,7 @@ #include <linux/errno.h> #include <linux/log2.h> #include <linux/math64.h> +#include <linux/printk.h> #include <linux/sizes.h>
#include <linux/mtd/mtd.h> diff --git a/drivers/mtd/ubi/attach.c b/drivers/mtd/ubi/attach.c index e488caa5547..2ef8fde3d32 100644 --- a/drivers/mtd/ubi/attach.c +++ b/drivers/mtd/ubi/attach.c @@ -81,6 +81,7 @@ #include <div64.h> #include <linux/bug.h> #include <linux/err.h> +#include <linux/printk.h> #endif
#include <linux/math64.h> diff --git a/drivers/mtd/ubi/build.c b/drivers/mtd/ubi/build.c index 61e38ba1ab7..f4e72ae7e56 100644 --- a/drivers/mtd/ubi/build.c +++ b/drivers/mtd/ubi/build.c @@ -33,6 +33,7 @@ #else #include <linux/bug.h> #include <linux/log2.h> +#include <linux/printk.h> #endif #include <linux/err.h> #include <ubi_uboot.h> diff --git a/drivers/mtd/ubi/debug.c b/drivers/mtd/ubi/debug.c index d2b7ca5e33f..b119cb6e9c0 100644 --- a/drivers/mtd/ubi/debug.c +++ b/drivers/mtd/ubi/debug.c @@ -8,6 +8,7 @@ #include <hexdump.h> #include <malloc.h> #include <ubi_uboot.h> +#include <linux/printk.h> #include "ubi.h" #ifndef __UBOOT__ #include <linux/debugfs.h> diff --git a/drivers/mtd/ubi/debug.h b/drivers/mtd/ubi/debug.h index 2c2faaf1b4d..c27d0ead427 100644 --- a/drivers/mtd/ubi/debug.h +++ b/drivers/mtd/ubi/debug.h @@ -17,6 +17,7 @@ void ubi_dump_vid_hdr(const struct ubi_vid_hdr *vid_hdr); #endif
#include <hexdump.h> +#include <linux/printk.h>
#ifndef __UBOOT__ #define ubi_assert(expr) do { \ diff --git a/drivers/mtd/ubi/ubi.h b/drivers/mtd/ubi/ubi.h index f44960186bb..175988899c3 100644 --- a/drivers/mtd/ubi/ubi.h +++ b/drivers/mtd/ubi/ubi.h @@ -28,6 +28,7 @@ #include <asm/pgtable.h> #else #include <ubi_uboot.h> +#include <linux/printk.h> #endif #include <linux/mtd/mtd.h> #include <linux/mtd/ubi.h> diff --git a/drivers/net/bcm-sf2-eth-gmac.c b/drivers/net/bcm-sf2-eth-gmac.c index 3caf0f33109..cbe1e85222f 100644 --- a/drivers/net/bcm-sf2-eth-gmac.c +++ b/drivers/net/bcm-sf2-eth-gmac.c @@ -6,6 +6,7 @@ #ifdef BCM_GMAC_DEBUG #ifndef DEBUG #define DEBUG +#include <linux/printk.h> #endif #endif
diff --git a/drivers/net/bcm-sf2-eth.c b/drivers/net/bcm-sf2-eth.c index c862c141461..040b72e6db0 100644 --- a/drivers/net/bcm-sf2-eth.c +++ b/drivers/net/bcm-sf2-eth.c @@ -9,6 +9,7 @@ #include <net.h> #include <config.h> #include <linux/delay.h> +#include <linux/printk.h>
#include <phy.h> #include <miiphy.h> diff --git a/drivers/net/bcm6348-eth.c b/drivers/net/bcm6348-eth.c index 9ddc0f938f2..8849195f248 100644 --- a/drivers/net/bcm6348-eth.c +++ b/drivers/net/bcm6348-eth.c @@ -18,6 +18,7 @@ #include <reset.h> #include <wait_bit.h> #include <asm/io.h> +#include <linux/printk.h>
#define ETH_RX_DESC PKTBUFSRX #define ETH_MAX_MTU_SIZE 1518 diff --git a/drivers/net/bcm6368-eth.c b/drivers/net/bcm6368-eth.c index 38a2a30fe6c..0bfc0432d32 100644 --- a/drivers/net/bcm6368-eth.c +++ b/drivers/net/bcm6368-eth.c @@ -19,6 +19,7 @@ #include <asm/io.h> #include <dm/device_compat.h> #include <linux/delay.h> +#include <linux/printk.h>
#define ETH_PORT_STR "brcm,enetsw-port"
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 4c19abbaf0c..ef9b6a3ddee 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -27,6 +27,7 @@ #include <linux/err.h> #include <linux/kernel.h> #include <asm/io.h> +#include <linux/printk.h> #include <power/regulator.h> #include "designware.h"
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 3bb4955e4a9..e4aa7c4e988 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -52,6 +52,7 @@ #endif #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h>
/* Core registers */
diff --git a/drivers/net/ep93xx_eth.c b/drivers/net/ep93xx_eth.c index 0218349b045..d1d881d6bd9 100644 --- a/drivers/net/ep93xx_eth.c +++ b/drivers/net/ep93xx_eth.c @@ -25,6 +25,7 @@ #include <malloc.h> #include <miiphy.h> #include <linux/bug.h> +#include <linux/printk.h> #include <linux/types.h> #include "ep93xx_eth.h"
diff --git a/drivers/net/fsl-mc/dpio/qbman_sys.h b/drivers/net/fsl-mc/dpio/qbman_sys.h index 8be38e11a84..fb760b94f85 100644 --- a/drivers/net/fsl-mc/dpio/qbman_sys.h +++ b/drivers/net/fsl-mc/dpio/qbman_sys.h @@ -21,6 +21,7 @@ /* Trace the 3 different classes of read/write access to QBMan. #undef as * required. */ #include <linux/bug.h> +#include <linux/printk.h> #undef QBMAN_CCSR_TRACE #undef QBMAN_CINH_TRACE #undef QBMAN_CENA_TRACE diff --git a/drivers/net/ftgmac100.c b/drivers/net/ftgmac100.c index 00bda24f1fd..fb093da1dd5 100644 --- a/drivers/net/ftgmac100.c +++ b/drivers/net/ftgmac100.c @@ -25,6 +25,7 @@ #include <linux/bitops.h> #include <linux/io.h> #include <linux/iopoll.h> +#include <linux/printk.h>
#include "ftgmac100.h"
diff --git a/drivers/net/mscc_eswitch/jr2_switch.c b/drivers/net/mscc_eswitch/jr2_switch.c index 1c9a401de81..97b2b081efb 100644 --- a/drivers/net/mscc_eswitch/jr2_switch.c +++ b/drivers/net/mscc_eswitch/jr2_switch.c @@ -17,6 +17,7 @@ #include <miiphy.h> #include <net.h> #include <wait_bit.h> +#include <linux/printk.h>
#include <dt-bindings/mscc/jr2_data.h> #include "mscc_xfer.h" diff --git a/drivers/net/mscc_eswitch/ocelot_switch.c b/drivers/net/mscc_eswitch/ocelot_switch.c index 2a48dc6a190..bdadaa13c72 100644 --- a/drivers/net/mscc_eswitch/ocelot_switch.c +++ b/drivers/net/mscc_eswitch/ocelot_switch.c @@ -17,6 +17,7 @@ #include <miiphy.h> #include <net.h> #include <wait_bit.h> +#include <linux/printk.h>
#include "mscc_xfer.h" #include "mscc_mac_table.h" diff --git a/drivers/net/mscc_eswitch/serval_switch.c b/drivers/net/mscc_eswitch/serval_switch.c index d8ee1a76989..bbced95f7e4 100644 --- a/drivers/net/mscc_eswitch/serval_switch.c +++ b/drivers/net/mscc_eswitch/serval_switch.c @@ -17,6 +17,7 @@ #include <miiphy.h> #include <net.h> #include <wait_bit.h> +#include <linux/printk.h>
#include "mscc_xfer.h" #include "mscc_mac_table.h" diff --git a/drivers/net/mscc_eswitch/servalt_switch.c b/drivers/net/mscc_eswitch/servalt_switch.c index 1cf2273142b..c8aaf7d4897 100644 --- a/drivers/net/mscc_eswitch/servalt_switch.c +++ b/drivers/net/mscc_eswitch/servalt_switch.c @@ -16,6 +16,7 @@ #include <miiphy.h> #include <net.h> #include <wait_bit.h> +#include <linux/printk.h>
#include "mscc_xfer.h" #include "mscc_miim.h" diff --git a/drivers/net/mt7628-eth.c b/drivers/net/mt7628-eth.c index 64f1c8c828d..8b278c62ba7 100644 --- a/drivers/net/mt7628-eth.c +++ b/drivers/net/mt7628-eth.c @@ -28,6 +28,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/printk.h>
/* Ethernet frame engine register */ #define PDMA_RELATED 0x0800 diff --git a/drivers/net/mtk_eth.c b/drivers/net/mtk_eth.c index 5183c08e14c..24a18ce9687 100644 --- a/drivers/net/mtk_eth.c +++ b/drivers/net/mtk_eth.c @@ -26,6 +26,7 @@ #include <linux/ioport.h> #include <linux/mdio.h> #include <linux/mii.h> +#include <linux/printk.h>
#include "mtk_eth.h"
diff --git a/drivers/net/mvmdio.c b/drivers/net/mvmdio.c index a8e93e80fc0..deaba8aee4f 100644 --- a/drivers/net/mvmdio.c +++ b/drivers/net/mvmdio.c @@ -13,6 +13,7 @@ #include <asm/io.h> #include <wait_bit.h> #include <linux/bitops.h> +#include <linux/printk.h>
#define MVMDIO_SMI_DATA_SHIFT 0 #define MVMDIO_SMI_PHY_ADDR_SHIFT 16 diff --git a/drivers/net/phy/dp83867.c b/drivers/net/phy/dp83867.c index eada4541c9c..e4081244f21 100644 --- a/drivers/net/phy/dp83867.c +++ b/drivers/net/phy/dp83867.c @@ -10,6 +10,7 @@ #include <linux/bitops.h> #include <linux/compat.h> #include <malloc.h> +#include <linux/printk.h>
#include <dm.h> #include <dt-bindings/net/ti-dp83867.h> diff --git a/drivers/net/phy/mscc.c b/drivers/net/phy/mscc.c index d1a643cf5a0..f154cd9d958 100644 --- a/drivers/net/phy/mscc.c +++ b/drivers/net/phy/mscc.c @@ -15,6 +15,7 @@ #include <time.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h>
/* Microsemi PHY ID's */ #define PHY_ID_VSC8530 0x00070560 diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index 2e1304e44d1..3f6805791f4 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -54,6 +54,7 @@ #include <asm/io.h> #include <pci.h> #include <linux/delay.h> +#include <linux/printk.h>
#undef DEBUG_RTL8169 #undef DEBUG_RTL8169_TX diff --git a/drivers/net/sni_ave.c b/drivers/net/sni_ave.c index c11a1c443ee..6e228da2984 100644 --- a/drivers/net/sni_ave.c +++ b/drivers/net/sni_ave.c @@ -23,6 +23,7 @@ #include <linux/err.h> #include <linux/io.h> #include <linux/iopoll.h> +#include <linux/printk.h>
#define AVE_GRST_DELAY_MSEC 40 #define AVE_MIN_XMITSIZE 60 diff --git a/drivers/net/ti/am65-cpsw-nuss.c b/drivers/net/ti/am65-cpsw-nuss.c index 971bdcdfda9..08cd26b3c4b 100644 --- a/drivers/net/ti/am65-cpsw-nuss.c +++ b/drivers/net/ti/am65-cpsw-nuss.c @@ -22,6 +22,7 @@ #include <phy.h> #include <power-domain.h> #include <linux/bitops.h> +#include <linux/printk.h> #include <linux/soc/ti/ti-udma.h>
#include "cpsw_mdio.h" diff --git a/drivers/net/ti/cpsw-common.c b/drivers/net/ti/cpsw-common.c index 3140f2515fb..d5428274d19 100644 --- a/drivers/net/ti/cpsw-common.c +++ b/drivers/net/ti/cpsw-common.c @@ -12,6 +12,7 @@ #include <asm/io.h> #include <cpsw.h> #include <dm/device_compat.h> +#include <linux/printk.h>
diff --git a/drivers/net/ti/cpsw.c b/drivers/net/ti/cpsw.c index 1c11257839c..4157d0f0e67 100644 --- a/drivers/net/ti/cpsw.c +++ b/drivers/net/ti/cpsw.c @@ -24,6 +24,7 @@ #include <phy.h> #include <asm/arch/cpu.h> #include <dm.h> +#include <linux/printk.h>
diff --git a/drivers/net/ti/keystone_net.c b/drivers/net/ti/keystone_net.c index c25902a7032..5e44215e223 100644 --- a/drivers/net/ti/keystone_net.c +++ b/drivers/net/ti/keystone_net.c @@ -10,6 +10,7 @@ #include <console.h> #include <asm/global_data.h> #include <linux/delay.h> +#include <linux/printk.h>
#include <dm.h> #include <dm/lists.h> diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 571c6e3c1d6..614bc9609fa 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -19,6 +19,7 @@ #include <asm/fsp/fsp_support.h> #endif #include <linux/delay.h> +#include <linux/printk.h> #include "pci_internal.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/pci/pci_mvebu.c b/drivers/pci/pci_mvebu.c index 167fe026e8b..95ed1730358 100644 --- a/drivers/pci/pci_mvebu.c +++ b/drivers/pci/pci_mvebu.c @@ -25,6 +25,7 @@ #include <linux/errno.h> #include <linux/ioport.h> #include <linux/mbus.h> +#include <linux/printk.h>
diff --git a/drivers/pci/pci_tegra.c b/drivers/pci/pci_tegra.c index 82f5c59d917..d15fabd9226 100644 --- a/drivers/pci/pci_tegra.c +++ b/drivers/pci/pci_tegra.c @@ -22,6 +22,7 @@ #include <power-domain.h> #include <reset.h> #include <linux/delay.h> +#include <linux/printk.h>
#include <asm/io.h> #include <asm/gpio.h> diff --git a/drivers/pci/pcie_ecam_generic.c b/drivers/pci/pcie_ecam_generic.c index 354a1454a9f..6e18d5ba552 100644 --- a/drivers/pci/pcie_ecam_generic.c +++ b/drivers/pci/pcie_ecam_generic.c @@ -11,6 +11,7 @@ #include <dm.h> #include <pci.h> #include <asm/global_data.h> +#include <linux/printk.h>
#include <asm/io.h>
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index ee779be8f88..0fec9b3b72b 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -16,6 +16,7 @@ #include <asm/global_data.h> #include <asm/io.h> #include <linux/delay.h> +#include <linux/printk.h> #include "pcie_fsl.h" #include <dm/device_compat.h>
diff --git a/drivers/pci/pcie_mediatek.c b/drivers/pci/pcie_mediatek.c index 55b6a40f254..4fd985647fa 100644 --- a/drivers/pci/pcie_mediatek.c +++ b/drivers/pci/pcie_mediatek.c @@ -20,6 +20,7 @@ #include <linux/bitops.h> #include <linux/iopoll.h> #include <linux/list.h> +#include <linux/printk.h> #include "pci_internal.h"
/* PCIe shared registers */ diff --git a/drivers/pci/pcie_phytium.c b/drivers/pci/pcie_phytium.c index 35ca104300b..926e7b33a86 100644 --- a/drivers/pci/pcie_phytium.c +++ b/drivers/pci/pcie_phytium.c @@ -12,6 +12,7 @@ #include <pci.h> #include <asm/global_data.h> #include <asm/io.h> +#include <linux/printk.h>
/** * struct phytium_pcie - phytium PCIe controller state diff --git a/drivers/pci/pcie_xilinx.c b/drivers/pci/pcie_xilinx.c index 88660a9957a..600c69e20cf 100644 --- a/drivers/pci/pcie_xilinx.c +++ b/drivers/pci/pcie_xilinx.c @@ -10,6 +10,7 @@ #include <pci.h> #include <asm/global_data.h> #include <linux/bitops.h> +#include <linux/printk.h>
#include <asm/io.h>
diff --git a/drivers/phy/keystone-usb-phy.c b/drivers/phy/keystone-usb-phy.c index 9faf5010033..27e1d35fc12 100644 --- a/drivers/phy/keystone-usb-phy.c +++ b/drivers/phy/keystone-usb-phy.c @@ -13,6 +13,7 @@ #include <asm/arch/psc_defs.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h>
/* USB PHY control register offsets */ #define USB_PHY_CTL_UTMI 0x0000 diff --git a/drivers/phy/marvell/comphy_cp110.c b/drivers/phy/marvell/comphy_cp110.c index 484b28745e0..35da55c4fee 100644 --- a/drivers/phy/marvell/comphy_cp110.c +++ b/drivers/phy/marvell/comphy_cp110.c @@ -11,6 +11,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <linux/delay.h> +#include <linux/printk.h>
#include "comphy_core.h" #include "comphy_hpipe.h" diff --git a/drivers/phy/meson-g12a-usb2.c b/drivers/phy/meson-g12a-usb2.c index a1e62197586..734c79b78aa 100644 --- a/drivers/phy/meson-g12a-usb2.c +++ b/drivers/phy/meson-g12a-usb2.c @@ -17,6 +17,7 @@ #include <generic-phy.h> #include <regmap.h> #include <linux/delay.h> +#include <linux/printk.h> #include <power/regulator.h> #include <reset.h> #include <clk.h> diff --git a/drivers/phy/meson-g12a-usb3-pcie.c b/drivers/phy/meson-g12a-usb3-pcie.c index 4e9696fd590..dc5dd62381f 100644 --- a/drivers/phy/meson-g12a-usb3-pcie.c +++ b/drivers/phy/meson-g12a-usb3-pcie.c @@ -18,6 +18,7 @@ #include <bitfield.h> #include <generic-phy.h> #include <linux/delay.h> +#include <linux/printk.h>
#include <linux/bitops.h> #include <linux/compat.h> diff --git a/drivers/phy/meson-gxbb-usb2.c b/drivers/phy/meson-gxbb-usb2.c index d1beebee43e..6ae06364a57 100644 --- a/drivers/phy/meson-gxbb-usb2.c +++ b/drivers/phy/meson-gxbb-usb2.c @@ -12,6 +12,7 @@ #include <clk.h> #include <dm.h> #include <generic-phy.h> +#include <linux/printk.h> #include <power/regulator.h> #include <regmap.h> #include <reset.h> diff --git a/drivers/phy/meson-gxl-usb2.c b/drivers/phy/meson-gxl-usb2.c index 2267bd08c2c..4bddd0eed9e 100644 --- a/drivers/phy/meson-gxl-usb2.c +++ b/drivers/phy/meson-gxl-usb2.c @@ -16,6 +16,7 @@ #include <generic-phy.h> #include <regmap.h> #include <linux/delay.h> +#include <linux/printk.h> #include <power/regulator.h> #include <clk.h> #include <linux/usb/otg.h> diff --git a/drivers/phy/meson-gxl-usb3.c b/drivers/phy/meson-gxl-usb3.c new file mode 100644 index 00000000000..1d688acc27a --- /dev/null +++ b/drivers/phy/meson-gxl-usb3.c @@ -0,0 +1,220 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Meson GXL USB3 PHY driver + * + * Copyright (C) 2018 Martin Blumenstingl martin.blumenstingl@googlemail.com + * Copyright (C) 2018 BayLibre, SAS + * Author: Neil Armstrong narmstron@baylibre.com + */ + +#include <common.h> +#include <malloc.h> +#include <asm/io.h> +#include <bitfield.h> +#include <dm.h> +#include <errno.h> +#include <generic-phy.h> +#include <regmap.h> +#include <clk.h> +#include <linux/printk.h> +#include <linux/usb/otg.h> + +#include <asm/arch/usb-gx.h> + +#include <linux/bitops.h> +#include <linux/compat.h> +#include <linux/bitfield.h> + +#define USB_R0 0x00 + #define USB_R0_P30_FSEL_MASK GENMASK(5, 0) + #define USB_R0_P30_PHY_RESET BIT(6) + #define USB_R0_P30_TEST_POWERDOWN_HSP BIT(7) + #define USB_R0_P30_TEST_POWERDOWN_SSP BIT(8) + #define USB_R0_P30_ACJT_LEVEL_MASK GENMASK(13, 9) + #define USB_R0_P30_TX_BOOST_LEVEL_MASK GENMASK(16, 14) + #define USB_R0_P30_LANE0_TX2RX_LOOPBACK BIT(17) + #define USB_R0_P30_LANE0_EXT_PCLK_REQ BIT(18) + #define USB_R0_P30_PCS_RX_LOS_MASK_VAL_MASK GENMASK(28, 19) + #define USB_R0_U2D_SS_SCALEDOWN_MODE_MASK GENMASK(30, 29) + #define USB_R0_U2D_ACT BIT(31) + +#define USB_R1 0x04 + #define USB_R1_U3H_BIGENDIAN_GS BIT(0) + #define USB_R1_U3H_PME_ENABLE BIT(1) + #define USB_R1_U3H_HUB_PORT_OVERCURRENT_MASK GENMASK(6, 2) + #define USB_R1_U3H_HUB_PORT_PERM_ATTACH_MASK GENMASK(11, 7) + #define USB_R1_U3H_HOST_U2_PORT_DISABLE_MASK GENMASK(15, 12) + #define USB_R1_U3H_HOST_U3_PORT_DISABLE BIT(16) + #define USB_R1_U3H_HOST_PORT_POWER_CONTROL_PRESENT BIT(17) + #define USB_R1_U3H_HOST_MSI_ENABLE BIT(18) + #define USB_R1_U3H_FLADJ_30MHZ_REG_MASK GENMASK(24, 19) + #define USB_R1_P30_PCS_TX_SWING_FULL_MASK GENMASK(31, 25) + +#define USB_R2 0x08 + #define USB_R2_P30_CR_DATA_IN_MASK GENMASK(15, 0) + #define USB_R2_P30_CR_READ BIT(16) + #define USB_R2_P30_CR_WRITE BIT(17) + #define USB_R2_P30_CR_CAP_ADDR BIT(18) + #define USB_R2_P30_CR_CAP_DATA BIT(19) + #define USB_R2_P30_PCS_TX_DEEMPH_3P5DB_MASK GENMASK(25, 20) + #define USB_R2_P30_PCS_TX_DEEMPH_6DB_MASK GENMASK(31, 26) + +#define USB_R3 0x0c + #define USB_R3_P30_SSC_ENABLE BIT(0) + #define USB_R3_P30_SSC_RANGE_MASK GENMASK(3, 1) + #define USB_R3_P30_SSC_REF_CLK_SEL_MASK GENMASK(12, 4) + #define USB_R3_P30_REF_SSP_EN BIT(13) + #define USB_R3_P30_LOS_BIAS_MASK GENMASK(18, 16) + #define USB_R3_P30_LOS_LEVEL_MASK GENMASK(23, 19) + #define USB_R3_P30_MPLL_MULTIPLIER_MASK GENMASK(30, 24) + +#define USB_R4 0x10 + #define USB_R4_P21_PORT_RESET_0 BIT(0) + #define USB_R4_P21_SLEEP_M0 BIT(1) + #define USB_R4_MEM_PD_MASK GENMASK(3, 2) + #define USB_R4_P21_ONLY BIT(4) + +#define USB_R5 0x14 + #define USB_R5_ID_DIG_SYNC BIT(0) + #define USB_R5_ID_DIG_REG BIT(1) + #define USB_R5_ID_DIG_CFG_MASK GENMASK(3, 2) + #define USB_R5_ID_DIG_EN_0 BIT(4) + #define USB_R5_ID_DIG_EN_1 BIT(5) + #define USB_R5_ID_DIG_CURR BIT(6) + #define USB_R5_ID_DIG_IRQ BIT(7) + #define USB_R5_ID_DIG_TH_MASK GENMASK(15, 8) + #define USB_R5_ID_DIG_CNT_MASK GENMASK(23, 16) + +/* read-only register */ +#define USB_R6 0x18 + #define USB_R6_P30_CR_DATA_OUT_MASK GENMASK(15, 0) + #define USB_R6_P30_CR_ACK BIT(16) + +struct phy_meson_gxl_usb3_priv { + struct regmap *regmap; +#if CONFIG_IS_ENABLED(CLK) + struct clk clk; +#endif +}; + +void phy_meson_gxl_usb3_set_mode(struct phy *phy, enum usb_dr_mode mode) +{ + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb3_priv *priv = dev_get_priv(dev); + uint val; + + switch (mode) { + case USB_DR_MODE_UNKNOWN: + case USB_DR_MODE_HOST: + case USB_DR_MODE_OTG: + regmap_read(priv->regmap, USB_R0, &val); + val &= ~USB_R0_U2D_ACT; + regmap_write(priv->regmap, USB_R0, val); + + regmap_read(priv->regmap, USB_R4, &val); + val &= ~USB_R4_P21_SLEEP_M0; + regmap_write(priv->regmap, USB_R4, val); + break; + + case USB_DR_MODE_PERIPHERAL: + regmap_read(priv->regmap, USB_R0, &val); + val |= USB_R0_U2D_ACT; + regmap_write(priv->regmap, USB_R0, val); + + regmap_read(priv->regmap, USB_R4, &val); + val |= USB_R4_P21_SLEEP_M0; + regmap_write(priv->regmap, USB_R4, val); + break; + } +} + +static int phy_meson_gxl_usb3_power_on(struct phy *phy) +{ + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb3_priv *priv = dev_get_priv(dev); + uint val; + + regmap_read(priv->regmap, USB_R5, &val); + val |= USB_R5_ID_DIG_EN_0; + val |= USB_R5_ID_DIG_EN_1; + val &= ~USB_R5_ID_DIG_TH_MASK; + val |= FIELD_PREP(USB_R5_ID_DIG_TH_MASK, 0xff); + regmap_write(priv->regmap, USB_R5, val); + + phy_meson_gxl_usb3_set_mode(phy, USB_DR_MODE_HOST); + + return 0; +} + +static int phy_meson_gxl_usb3_power_off(struct phy *phy) +{ + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb3_priv *priv = dev_get_priv(dev); + uint val; + + regmap_read(priv->regmap, USB_R5, &val); + val &= ~USB_R5_ID_DIG_EN_0; + val &= ~USB_R5_ID_DIG_EN_1; + regmap_write(priv->regmap, USB_R5, val); + + return 0; +} + +static int phy_meson_gxl_usb3_init(struct phy *phy) +{ + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb3_priv *priv = dev_get_priv(dev); + uint val; + + regmap_read(priv->regmap, USB_R1, &val); + val &= ~USB_R1_U3H_FLADJ_30MHZ_REG_MASK; + val |= FIELD_PREP(USB_R1_U3H_FLADJ_30MHZ_REG_MASK, 0x20); + regmap_write(priv->regmap, USB_R1, val); + + return 0; +} + +struct phy_ops meson_gxl_usb3_phy_ops = { + .init = phy_meson_gxl_usb3_init, + .power_on = phy_meson_gxl_usb3_power_on, + .power_off = phy_meson_gxl_usb3_power_off, +}; + +int meson_gxl_usb3_phy_probe(struct udevice *dev) +{ + struct phy_meson_gxl_usb3_priv *priv = dev_get_priv(dev); + int ret; + + ret = regmap_init_mem(dev_ofnode(dev), &priv->regmap); + if (ret) + return ret; + +#if CONFIG_IS_ENABLED(CLK) + ret = clk_get_by_index(dev, 0, &priv->clk); + if (ret < 0) + return ret; + + ret = clk_enable(&priv->clk); + if (ret && ret != -ENOSYS && ret != -ENOTSUPP) { + pr_err("failed to enable PHY clock\n"); + clk_free(&priv->clk); + return ret; + } +#endif + + return 0; +} + +static const struct udevice_id meson_gxl_usb3_phy_ids[] = { + { .compatible = "amlogic,meson-gxl-usb3-phy" }, + { } +}; + +U_BOOT_DRIVER(meson_gxl_usb3_phy) = { + .name = "meson_gxl_usb3_phy", + .id = UCLASS_PHY, + .of_match = meson_gxl_usb3_phy_ids, + .probe = meson_gxl_usb3_phy_probe, + .ops = &meson_gxl_usb3_phy_ops, + .priv_auto_alloc_size = sizeof(struct phy_meson_gxl_usb3_priv), +}; diff --git a/drivers/phy/phy-rcar-gen3.c b/drivers/phy/phy-rcar-gen3.c index ce39cd8f9e2..4afdb791505 100644 --- a/drivers/phy/phy-rcar-gen3.c +++ b/drivers/phy/phy-rcar-gen3.c @@ -17,6 +17,7 @@ #include <usb.h> #include <asm/io.h> #include <linux/bitops.h> +#include <linux/printk.h> #include <power/regulator.h>
/* USB2.0 Host registers (original offset is +0x200) */ diff --git a/drivers/phy/phy-stm32-usbphyc.c b/drivers/phy/phy-stm32-usbphyc.c index 9d4296d6491..132c5a81007 100644 --- a/drivers/phy/phy-stm32-usbphyc.c +++ b/drivers/phy/phy-stm32-usbphyc.c @@ -17,6 +17,7 @@ #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h> #include <power/regulator.h>
/* USBPHYC registers */ diff --git a/drivers/phy/phy-uclass.c b/drivers/phy/phy-uclass.c index ef03e3a5025..4c8a7b0b272 100644 --- a/drivers/phy/phy-uclass.c +++ b/drivers/phy/phy-uclass.c @@ -9,6 +9,8 @@ #include <dm/device_compat.h> #include <dm/devres.h> #include <generic-phy.h> +#include <log.h> +#include <linux/printk.h>
static inline struct phy_ops *phy_dev_ops(struct udevice *dev) { diff --git a/drivers/phy/sti_usb_phy.c b/drivers/phy/sti_usb_phy.c index c6b1dc297ab..cfc24e76b24 100644 --- a/drivers/phy/sti_usb_phy.c +++ b/drivers/phy/sti_usb_phy.c @@ -18,6 +18,7 @@ #include <reset-uclass.h> #include <syscon.h> #include <wait_bit.h> +#include <linux/printk.h>
#include <linux/bitops.h> #include <linux/compat.h> diff --git a/drivers/phy/ti-pipe3-phy.c b/drivers/phy/ti-pipe3-phy.c index 41cee0eb740..5953d118bae 100644 --- a/drivers/phy/ti-pipe3-phy.c +++ b/drivers/phy/ti-pipe3-phy.c @@ -16,6 +16,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/printk.h>
/* PLLCTRL Registers */ #define PLL_STATUS 0x00000004 diff --git a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c index 1f61a84c29d..b64ad9a21c6 100644 --- a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c +++ b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c @@ -35,6 +35,7 @@ #include <asm/io.h> #include <linux/bitops.h> #include <linux/libfdt.h> +#include <linux/printk.h>
diff --git a/drivers/pinctrl/pinctrl-sti.c b/drivers/pinctrl/pinctrl-sti.c index 7d6bdc1d2bd..09414f6627f 100644 --- a/drivers/pinctrl/pinctrl-sti.c +++ b/drivers/pinctrl/pinctrl-sti.c @@ -17,6 +17,7 @@ #include <dm/pinctrl.h> #include <linux/bug.h> #include <linux/libfdt.h> +#include <linux/printk.h>
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index b58a68e26f5..add18dbb441 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -18,6 +18,7 @@ #include <linux/bitops.h> #include <linux/err.h> #include <linux/libfdt.h> +#include <linux/printk.h>
#define MAX_PINS_ONE_IP 70 #define MODE_BITS_MASK 3 diff --git a/drivers/power/palmas.c b/drivers/power/palmas.c index 2584bea38d0..d2083a51ac9 100644 --- a/drivers/power/palmas.c +++ b/drivers/power/palmas.c @@ -5,6 +5,7 @@ */ #include <config.h> #include <palmas.h> +#include <linux/printk.h>
void palmas_init_settings(void) { diff --git a/drivers/power/pmic/as3722.c b/drivers/power/pmic/as3722.c index 3aa3cce945e..c7dd9705d18 100644 --- a/drivers/power/pmic/as3722.c +++ b/drivers/power/pmic/as3722.c @@ -12,6 +12,7 @@ #include <i2c.h> #include <log.h> #include <dm/lists.h> +#include <linux/printk.h> #include <power/as3722.h> #include <power/pmic.h>
diff --git a/drivers/power/pmic/as3722_gpio.c b/drivers/power/pmic/as3722_gpio.c index 96943bc1ad5..987fbdf9bc0 100644 --- a/drivers/power/pmic/as3722_gpio.c +++ b/drivers/power/pmic/as3722_gpio.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <asm/gpio.h> +#include <linux/printk.h> #include <power/as3722.h> #include <power/pmic.h>
diff --git a/drivers/power/pmic/bd71837.c b/drivers/power/pmic/bd71837.c index cb9238972f2..da9aa541979 100644 --- a/drivers/power/pmic/bd71837.c +++ b/drivers/power/pmic/bd71837.c @@ -9,6 +9,7 @@ #include <i2c.h> #include <log.h> #include <asm/global_data.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/bd71837.h> diff --git a/drivers/power/pmic/da9063.c b/drivers/power/pmic/da9063.c index 25101d18f74..ca95b82e6d0 100644 --- a/drivers/power/pmic/da9063.c +++ b/drivers/power/pmic/da9063.c @@ -10,6 +10,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/da9063_pmic.h> diff --git a/drivers/power/pmic/fan53555.c b/drivers/power/pmic/fan53555.c index 4d1e686d274..c9b15d5b68f 100644 --- a/drivers/power/pmic/fan53555.c +++ b/drivers/power/pmic/fan53555.c @@ -10,6 +10,7 @@ #include <dm/device_compat.h> #include <dm/lists.h> #include <i2c.h> +#include <linux/printk.h> #include <power/fan53555.h> #include <power/pmic.h> #include <power/regulator.h> diff --git a/drivers/power/pmic/i2c_pmic_emul.c b/drivers/power/pmic/i2c_pmic_emul.c index 404fe008fe6..83d3c292044 100644 --- a/drivers/power/pmic/i2c_pmic_emul.c +++ b/drivers/power/pmic/i2c_pmic_emul.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <log.h> #include <malloc.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/sandbox_pmic.h>
diff --git a/drivers/power/pmic/lp873x.c b/drivers/power/pmic/lp873x.c index 2b1260ec6b1..fda5bc15164 100644 --- a/drivers/power/pmic/lp873x.c +++ b/drivers/power/pmic/lp873x.c @@ -10,6 +10,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/lp873x.h> diff --git a/drivers/power/pmic/lp87565.c b/drivers/power/pmic/lp87565.c index f4a4bd03d70..904e02c4d81 100644 --- a/drivers/power/pmic/lp87565.c +++ b/drivers/power/pmic/lp87565.c @@ -10,6 +10,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/lp87565.h> diff --git a/drivers/power/pmic/max77686.c b/drivers/power/pmic/max77686.c index 9f02c0b6f6f..7e6f7d1966f 100644 --- a/drivers/power/pmic/max77686.c +++ b/drivers/power/pmic/max77686.c @@ -10,6 +10,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/max77686_pmic.h> diff --git a/drivers/power/pmic/max8997.c b/drivers/power/pmic/max8997.c index dbae155fb34..504a63bf743 100644 --- a/drivers/power/pmic/max8997.c +++ b/drivers/power/pmic/max8997.c @@ -7,6 +7,7 @@ #include <common.h> #include <dm.h> #include <i2c.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/max8997_pmic.h> #include <errno.h> diff --git a/drivers/power/pmic/max8998.c b/drivers/power/pmic/max8998.c index f58d9f2d74c..d155474447f 100644 --- a/drivers/power/pmic/max8998.c +++ b/drivers/power/pmic/max8998.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <i2c.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/max8998_pmic.h>
diff --git a/drivers/power/pmic/palmas.c b/drivers/power/pmic/palmas.c index 6080cbff0be..eb83c88d564 100644 --- a/drivers/power/pmic/palmas.c +++ b/drivers/power/pmic/palmas.c @@ -10,6 +10,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/palmas.h> diff --git a/drivers/power/pmic/pca9450.c b/drivers/power/pmic/pca9450.c index 786baa5e259..b61dac193f2 100644 --- a/drivers/power/pmic/pca9450.c +++ b/drivers/power/pmic/pca9450.c @@ -10,6 +10,7 @@ #include <i2c.h> #include <log.h> #include <asm/global_data.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/pca9450.h> diff --git a/drivers/power/pmic/pfuze100.c b/drivers/power/pmic/pfuze100.c index 65c4456977c..15420acb472 100644 --- a/drivers/power/pmic/pfuze100.c +++ b/drivers/power/pmic/pfuze100.c @@ -10,6 +10,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/pfuze100_pmic.h> diff --git a/drivers/power/pmic/pmic_tps65910_dm.c b/drivers/power/pmic/pmic_tps65910_dm.c index e03ddc98d73..8ead1db802a 100644 --- a/drivers/power/pmic/pmic_tps65910_dm.c +++ b/drivers/power/pmic/pmic_tps65910_dm.c @@ -7,6 +7,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/tps65910_pmic.h> diff --git a/drivers/power/pmic/s2mps11.c b/drivers/power/pmic/s2mps11.c index 1ba1640a8df..5ff4f205211 100644 --- a/drivers/power/pmic/s2mps11.c +++ b/drivers/power/pmic/s2mps11.c @@ -10,6 +10,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/s2mps11.h>
diff --git a/drivers/power/pmic/s5m8767.c b/drivers/power/pmic/s5m8767.c index db6d0357ee4..eea072ae824 100644 --- a/drivers/power/pmic/s5m8767.c +++ b/drivers/power/pmic/s5m8767.c @@ -9,6 +9,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/s5m8767.h> diff --git a/drivers/power/pmic/sandbox.c b/drivers/power/pmic/sandbox.c index d7870915de8..398b72341bd 100644 --- a/drivers/power/pmic/sandbox.c +++ b/drivers/power/pmic/sandbox.c @@ -9,6 +9,7 @@ #include <errno.h> #include <dm.h> #include <i2c.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/sandbox_pmic.h> diff --git a/drivers/power/pmic/tps65090.c b/drivers/power/pmic/tps65090.c index b81df0dff1a..2a04d5948a5 100644 --- a/drivers/power/pmic/tps65090.c +++ b/drivers/power/pmic/tps65090.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/tps65090.h>
diff --git a/drivers/power/pmic/tps65941.c b/drivers/power/pmic/tps65941.c index 3dfc1918d5b..e464d2984e4 100644 --- a/drivers/power/pmic/tps65941.c +++ b/drivers/power/pmic/tps65941.c @@ -10,6 +10,7 @@ #include <dm.h> #include <i2c.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/tps65941.h> diff --git a/drivers/power/regulator/bd71837.c b/drivers/power/regulator/bd71837.c index 931d753e344..3499bd2c56b 100644 --- a/drivers/power/regulator/bd71837.c +++ b/drivers/power/regulator/bd71837.c @@ -9,6 +9,7 @@ #include <dm.h> #include <log.h> #include <linux/bitops.h> +#include <linux/printk.h> #include <power/bd71837.h> #include <power/pmic.h> #include <power/regulator.h> diff --git a/drivers/power/regulator/fan53555.c b/drivers/power/regulator/fan53555.c index b407f555fe3..a7fa01f787b 100644 --- a/drivers/power/regulator/fan53555.c +++ b/drivers/power/regulator/fan53555.c @@ -12,6 +12,7 @@ #include <log.h> #include <asm/gpio.h> #include <linux/bitops.h> +#include <linux/printk.h> #include <power/fan53555.h> #include <power/pmic.h> #include <power/regulator.h> diff --git a/drivers/power/regulator/fixed.c b/drivers/power/regulator/fixed.c index 2fa6c7e6b29..56d84a90e5e 100644 --- a/drivers/power/regulator/fixed.c +++ b/drivers/power/regulator/fixed.c @@ -9,8 +9,10 @@ #include <errno.h> #include <dm.h> #include <log.h> +#include <asm/gpio.h> #include <power/pmic.h> #include <power/regulator.h> +#include "regulator_common.h"
diff --git a/drivers/power/regulator/gpio-regulator.c b/drivers/power/regulator/gpio-regulator.c index 28c9e222e2b..c945752c5e6 100644 --- a/drivers/power/regulator/gpio-regulator.c +++ b/drivers/power/regulator/gpio-regulator.c @@ -11,8 +11,10 @@ #include <i2c.h> #include <log.h> #include <asm/gpio.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> +#include "regulator_common.h"
diff --git a/drivers/power/regulator/max77686.c b/drivers/power/regulator/max77686.c index 752dc88c401..4d3ac980fc8 100644 --- a/drivers/power/regulator/max77686.c +++ b/drivers/power/regulator/max77686.c @@ -11,6 +11,7 @@ #include <errno.h> #include <dm.h> #include <i2c.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/max77686_pmic.h> diff --git a/drivers/power/regulator/pbias_regulator.c b/drivers/power/regulator/pbias_regulator.c index 28a9a1470b1..0bc8562b317 100644 --- a/drivers/power/regulator/pbias_regulator.c +++ b/drivers/power/regulator/pbias_regulator.c @@ -10,6 +10,7 @@ #include <log.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <regmap.h> diff --git a/drivers/power/regulator/regulator_common.c b/drivers/power/regulator/regulator_common.c index 13906b9c6e2..46497e0fde2 100644 --- a/drivers/power/regulator/regulator_common.c +++ b/drivers/power/regulator/regulator_common.c @@ -7,8 +7,10 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <asm/gpio.h> #include <linux/delay.h> #include <power/regulator.h> +#include "regulator_common.h"
diff --git a/drivers/power/regulator/s2mps11_regulator.c b/drivers/power/regulator/s2mps11_regulator.c index a6b4f158ef7..295e1d2c62a 100644 --- a/drivers/power/regulator/s2mps11_regulator.c +++ b/drivers/power/regulator/s2mps11_regulator.c @@ -10,6 +10,7 @@ #include <dm.h> #include <i2c.h> #include <linux/delay.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/s2mps11.h> diff --git a/drivers/power/regulator/sandbox.c b/drivers/power/regulator/sandbox.c index 9893a6b5f3d..18596770b37 100644 --- a/drivers/power/regulator/sandbox.c +++ b/drivers/power/regulator/sandbox.c @@ -9,6 +9,7 @@ #include <errno.h> #include <dm.h> #include <i2c.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/sandbox_pmic.h> diff --git a/drivers/power/regulator/tps65910_regulator.c b/drivers/power/regulator/tps65910_regulator.c index 171afd34a5f..2c0dd0604b3 100644 --- a/drivers/power/regulator/tps65910_regulator.c +++ b/drivers/power/regulator/tps65910_regulator.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <linux/printk.h> #include <power/pmic.h> #include <power/regulator.h> #include <power/tps65910_pmic.h> diff --git a/drivers/power/twl4030.c b/drivers/power/twl4030.c index b0d5cba2c49..34e7fa3d720 100644 --- a/drivers/power/twl4030.c +++ b/drivers/power/twl4030.c @@ -25,6 +25,7 @@ #include <command.h> #include <twl4030.h> #include <linux/delay.h> +#include <linux/printk.h>
/* * Power Reset diff --git a/drivers/power/twl6030.c b/drivers/power/twl6030.c index 60a5aaaf19f..2c5e4960e54 100644 --- a/drivers/power/twl6030.c +++ b/drivers/power/twl6030.c @@ -5,6 +5,7 @@ */ #include <config.h> #include <linux/delay.h> +#include <linux/printk.h>
#include <twl6030.h>
diff --git a/drivers/ram/imxrt_sdram.c b/drivers/ram/imxrt_sdram.c index b6ee02d2279..9572dc22837 100644 --- a/drivers/ram/imxrt_sdram.c +++ b/drivers/ram/imxrt_sdram.c @@ -15,6 +15,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/printk.h>
/* SDRAM Command Code */ #define SD_CC_ARD 0x0 /* Master Bus (AXI) command - Read */ diff --git a/drivers/ram/rockchip/dmc-rk3368.c b/drivers/ram/rockchip/dmc-rk3368.c index 4fa632152fd..41773893fd7 100644 --- a/drivers/ram/rockchip/dmc-rk3368.c +++ b/drivers/ram/rockchip/dmc-rk3368.c @@ -23,6 +23,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/printk.h>
struct dram_info { struct ram_info info; diff --git a/drivers/ram/stm32_sdram.c b/drivers/ram/stm32_sdram.c index 3fddf4df961..de5a9bc0569 100644 --- a/drivers/ram/stm32_sdram.c +++ b/drivers/ram/stm32_sdram.c @@ -14,6 +14,7 @@ #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h>
#define MEM_MODE_MASK GENMASK(2, 0) #define SWP_FMC_OFFSET 10 diff --git a/drivers/ram/stm32mp1/stm32mp1_ddr.c b/drivers/ram/stm32mp1/stm32mp1_ddr.c index bf3a4c97a41..8b59903e6bf 100644 --- a/drivers/ram/stm32mp1/stm32mp1_ddr.c +++ b/drivers/ram/stm32mp1/stm32mp1_ddr.c @@ -14,6 +14,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/iopoll.h> +#include <linux/printk.h> #include "stm32mp1_ddr.h" #include "stm32mp1_ddr_regs.h"
diff --git a/drivers/ram/stm32mp1/stm32mp1_ram.c b/drivers/ram/stm32mp1/stm32mp1_ram.c index 9022679703b..63333a1b1b6 100644 --- a/drivers/ram/stm32mp1/stm32mp1_ram.c +++ b/drivers/ram/stm32mp1/stm32mp1_ram.c @@ -12,6 +12,7 @@ #include <regmap.h> #include <syscon.h> #include <asm/io.h> +#include <linux/printk.h> #include "stm32mp1_ddr.h"
static const char *const clkname[] = { diff --git a/drivers/ram/stm32mp1/stm32mp1_tuning.c b/drivers/ram/stm32mp1/stm32mp1_tuning.c index a8d6892bb09..2fc8e32847c 100644 --- a/drivers/ram/stm32mp1/stm32mp1_tuning.c +++ b/drivers/ram/stm32mp1/stm32mp1_tuning.c @@ -13,6 +13,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/iopoll.h> +#include <linux/printk.h>
#include "stm32mp1_ddr_regs.h" #include "stm32mp1_ddr.h" diff --git a/drivers/remoteproc/rproc-elf-loader.c b/drivers/remoteproc/rproc-elf-loader.c index b185a6cafb8..5e070e5076e 100644 --- a/drivers/remoteproc/rproc-elf-loader.c +++ b/drivers/remoteproc/rproc-elf-loader.c @@ -11,6 +11,7 @@ #include <asm/cache.h> #include <dm/device_compat.h> #include <linux/compat.h> +#include <linux/printk.h>
/** * struct resource_table - firmware resource table header diff --git a/drivers/remoteproc/rproc-uclass.c b/drivers/remoteproc/rproc-uclass.c index 22779d0cb0d..0c2b601c472 100644 --- a/drivers/remoteproc/rproc-uclass.c +++ b/drivers/remoteproc/rproc-uclass.c @@ -16,6 +16,7 @@ #include <dm.h> #include <dm/uclass.h> #include <dm/uclass-internal.h> +#include <linux/printk.h>
diff --git a/drivers/remoteproc/sandbox_testproc.c b/drivers/remoteproc/sandbox_testproc.c index 2b58b27947c..4317af78d29 100644 --- a/drivers/remoteproc/sandbox_testproc.c +++ b/drivers/remoteproc/sandbox_testproc.c @@ -10,6 +10,7 @@ #include <log.h> #include <remoteproc.h> #include <asm/io.h> +#include <linux/printk.h>
/** * enum sandbox_state - different device states diff --git a/drivers/remoteproc/stm32_copro.c b/drivers/remoteproc/stm32_copro.c index 33b574b1bd3..e09d2b9a646 100644 --- a/drivers/remoteproc/stm32_copro.c +++ b/drivers/remoteproc/stm32_copro.c @@ -15,6 +15,7 @@ #include <asm/io.h> #include <dm/device_compat.h> #include <linux/err.h> +#include <linux/printk.h>
#define RCC_GCR_HOLD_BOOT 0 #define RCC_GCR_RELEASE_BOOT 1 diff --git a/drivers/remoteproc/ti_power_proc.c b/drivers/remoteproc/ti_power_proc.c index 1a5dddbe0d2..86fa6457ede 100644 --- a/drivers/remoteproc/ti_power_proc.c +++ b/drivers/remoteproc/ti_power_proc.c @@ -11,6 +11,7 @@ #include <log.h> #include <remoteproc.h> #include <asm/global_data.h> +#include <linux/printk.h> #include <mach/psc_defs.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/remoteproc/ti_sci_proc.h b/drivers/remoteproc/ti_sci_proc.h index f8299d1aff9..36351da63fc 100644 --- a/drivers/remoteproc/ti_sci_proc.h +++ b/drivers/remoteproc/ti_sci_proc.h @@ -10,6 +10,7 @@ #ifndef REMOTEPROC_TI_SCI_PROC_H #define REMOTEPROC_TI_SCI_PROC_H
+#include <linux/printk.h> #define TISCI_INVALID_HOST 0xff
/** diff --git a/drivers/reset/sti-reset.c b/drivers/reset/sti-reset.c index 2fdc069ce16..12000d05cc8 100644 --- a/drivers/reset/sti-reset.c +++ b/drivers/reset/sti-reset.c @@ -16,6 +16,7 @@ #include <asm/global_data.h> #include <dt-bindings/reset/stih407-resets.h> #include <linux/bitops.h> +#include <linux/printk.h>
diff --git a/drivers/serial/serial_mtk.c b/drivers/serial/serial_mtk.c index 9715f372ecf..0d2a9dc7e3e 100644 --- a/drivers/serial/serial_mtk.c +++ b/drivers/serial/serial_mtk.c @@ -18,6 +18,7 @@ #include <asm/io.h> #include <asm/types.h> #include <linux/err.h> +#include <linux/printk.h>
struct mtk_serial_regs { u32 rbr; diff --git a/drivers/soc/ti/k3-navss-ringacc.c b/drivers/soc/ti/k3-navss-ringacc.c index c48e9befe4b..fb04da2717d 100644 --- a/drivers/soc/ti/k3-navss-ringacc.c +++ b/drivers/soc/ti/k3-navss-ringacc.c @@ -21,6 +21,7 @@ #include <linux/compat.h> #include <linux/dma-mapping.h> #include <linux/err.h> +#include <linux/printk.h> #include <linux/soc/ti/k3-navss-ringacc.h> #include <linux/soc/ti/ti_sci_protocol.h>
diff --git a/drivers/spi/atmel_spi.c b/drivers/spi/atmel_spi.c index c65733c87ac..33bf382998e 100644 --- a/drivers/spi/atmel_spi.c +++ b/drivers/spi/atmel_spi.c @@ -17,6 +17,7 @@ #include <asm/gpio.h> #endif #include <linux/bitops.h> +#include <linux/printk.h>
/* * Register definitions for the Atmel AT32/AT91 SPI Controller diff --git a/drivers/spi/fsl_dspi.c b/drivers/spi/fsl_dspi.c index 1912d676a68..eae6b379a9c 100644 --- a/drivers/spi/fsl_dspi.c +++ b/drivers/spi/fsl_dspi.c @@ -26,6 +26,7 @@ #include <fsl_dspi.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h>
/* linux/include/time.h */ #define NSEC_PER_SEC 1000000000L diff --git a/drivers/spi/mt7621_spi.c b/drivers/spi/mt7621_spi.c index 3a0738eb2b7..f13d21f5b2c 100644 --- a/drivers/spi/mt7621_spi.c +++ b/drivers/spi/mt7621_spi.c @@ -16,6 +16,7 @@ #include <wait_bit.h> #include <linux/bitops.h> #include <linux/io.h> +#include <linux/printk.h>
#define MT7621_RX_FIFO_LEN 32 #define MT7621_TX_FIFO_LEN 36 diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 466355b0178..14f68da2ee6 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -18,6 +18,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> #include <asm/mach-imx/spi.h> +#include <linux/printk.h>
diff --git a/drivers/spi/pl022_spi.c b/drivers/spi/pl022_spi.c index 01ffaea4c34..7cf19a1a661 100644 --- a/drivers/spi/pl022_spi.c +++ b/drivers/spi/pl022_spi.c @@ -16,6 +16,7 @@ #include <dm/platform_data/spi_pl022.h> #include <linux/io.h> #include <spi.h> +#include <linux/printk.h>
#define SSP_CR0 0x000 #define SSP_CR1 0x004 diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index a53b941410d..8e91475ef95 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -19,6 +19,7 @@ #include <linux/delay.h> #include <linux/iopoll.h> #include <linux/ioport.h> +#include <linux/printk.h> #include <linux/sizes.h>
struct stm32_qspi_regs { diff --git a/drivers/spi/stm32_spi.c b/drivers/spi/stm32_spi.c index 4a0833b6fa9..09711b0aabc 100644 --- a/drivers/spi/stm32_spi.c +++ b/drivers/spi/stm32_spi.c @@ -15,6 +15,7 @@ #include <dm/device_compat.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h>
#include <asm/io.h> #include <asm/gpio.h> diff --git a/drivers/spi/uniphier_spi.c b/drivers/spi/uniphier_spi.c index a6d3d6abb6f..59d6ebd083a 100644 --- a/drivers/spi/uniphier_spi.c +++ b/drivers/spi/uniphier_spi.c @@ -17,6 +17,7 @@ #include <linux/io.h> #include <spi.h> #include <wait_bit.h> +#include <linux/printk.h>
diff --git a/drivers/sysreset/sysreset_sti.c b/drivers/sysreset/sysreset_sti.c index 8465a62e185..c1b22873ff4 100644 --- a/drivers/sysreset/sysreset_sti.c +++ b/drivers/sysreset/sysreset_sti.c @@ -12,6 +12,7 @@ #include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> +#include <linux/printk.h>
diff --git a/drivers/sysreset/sysreset_syscon.c b/drivers/sysreset/sysreset_syscon.c index 1c474866145..0dfa91fc90e 100644 --- a/drivers/sysreset/sysreset_syscon.c +++ b/drivers/sysreset/sysreset_syscon.c @@ -14,6 +14,7 @@ #include <sysreset.h> #include <syscon.h> #include <linux/err.h> +#include <linux/printk.h>
struct syscon_reboot_priv { struct regmap *regmap; diff --git a/drivers/sysreset/sysreset_watchdog.c b/drivers/sysreset/sysreset_watchdog.c index d500d413261..3493c5e8e45 100644 --- a/drivers/sysreset/sysreset_watchdog.c +++ b/drivers/sysreset/sysreset_watchdog.c @@ -8,6 +8,7 @@ #include <errno.h> #include <sysreset.h> #include <wdt.h> +#include <linux/printk.h>
struct wdt_reboot_priv { struct udevice *wdt; diff --git a/drivers/tpm/tpm_tis_infineon.c b/drivers/tpm/tpm_tis_infineon.c index f47813e76d0..32c3a335420 100644 --- a/drivers/tpm/tpm_tis_infineon.c +++ b/drivers/tpm/tpm_tis_infineon.c @@ -28,6 +28,7 @@ #include <linux/delay.h> #include <linux/errno.h> #include <linux/compiler.h> +#include <linux/printk.h> #include <linux/types.h> #include <linux/unaligned/be_byteshift.h>
diff --git a/drivers/usb/cdns3/gadget.c b/drivers/usb/cdns3/gadget.c index 83dbb5a103d..640f259dc67 100644 --- a/drivers/usb/cdns3/gadget.c +++ b/drivers/usb/cdns3/gadget.c @@ -62,6 +62,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/printk.h> #include <linux/usb/gadget.h> #include <linux/compat.h> #include <linux/iopoll.h> diff --git a/drivers/usb/common/common.c b/drivers/usb/common/common.c index 2a47f40bbab..d4cfda72e68 100644 --- a/drivers/usb/common/common.c +++ b/drivers/usb/common/common.c @@ -9,6 +9,7 @@ #include <common.h> #include <dm.h> #include <asm/global_data.h> +#include <linux/printk.h> #include <linux/usb/otg.h> #include <linux/usb/ch9.h> #include <linux/usb/phy.h> diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 36fa16ad4e2..2a76443b42b 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -16,6 +16,7 @@ #include <dwc3-uboot.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <malloc.h> diff --git a/drivers/usb/dwc3/dwc3-meson-g12a.c b/drivers/usb/dwc3/dwc3-meson-g12a.c index 6567502cdd1..6fdf686af8d 100644 --- a/drivers/usb/dwc3/dwc3-meson-g12a.c +++ b/drivers/usb/dwc3/dwc3-meson-g12a.c @@ -15,6 +15,7 @@ #include <dwc3-uboot.h> #include <generic-phy.h> #include <linux/delay.h> +#include <linux/printk.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <malloc.h> diff --git a/drivers/usb/dwc3/gadget.c b/drivers/usb/dwc3/gadget.c index 4e68fb0a82f..5da0cea1f3a 100644 --- a/drivers/usb/dwc3/gadget.c +++ b/drivers/usb/dwc3/gadget.c @@ -24,6 +24,7 @@ #include <linux/delay.h> #include <linux/dma-mapping.h> #include <linux/list.h> +#include <linux/printk.h>
#include <linux/usb/ch9.h> #include <linux/usb/gadget.h> diff --git a/drivers/usb/eth/mcs7830.c b/drivers/usb/eth/mcs7830.c index c829a436a34..02eef9b269d 100644 --- a/drivers/usb/eth/mcs7830.c +++ b/drivers/usb/eth/mcs7830.c @@ -19,6 +19,7 @@ #include <malloc.h> #include <memalign.h> #include <usb.h> +#include <linux/printk.h>
#include "usb_ether.h"
diff --git a/drivers/usb/gadget/at91_udc.c b/drivers/usb/gadget/at91_udc.c index 1feed417d68..e198ef1d34d 100644 --- a/drivers/usb/gadget/at91_udc.c +++ b/drivers/usb/gadget/at91_udc.c @@ -21,6 +21,7 @@ #include <asm/io.h> #include <asm/gpio.h> #include <asm/hardware.h> +#include <linux/printk.h> #include <mach/at91_matrix.h> #include <linux/list.h> #include <linux/usb/ch9.h> diff --git a/drivers/usb/gadget/atmel_usba_udc.c b/drivers/usb/gadget/atmel_usba_udc.c index 7d51821497b..ed3b3c14e60 100644 --- a/drivers/usb/gadget/atmel_usba_udc.c +++ b/drivers/usb/gadget/atmel_usba_udc.c @@ -13,6 +13,7 @@ #include <asm/gpio.h> #include <asm/hardware.h> #include <linux/list.h> +#include <linux/printk.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <linux/usb/atmel_usba_udc.h> diff --git a/drivers/usb/gadget/dwc2_udc_otg.c b/drivers/usb/gadget/dwc2_udc_otg.c index eaa5dcb9b13..f548cbc9eb2 100644 --- a/drivers/usb/gadget/dwc2_udc_otg.c +++ b/drivers/usb/gadget/dwc2_udc_otg.c @@ -28,6 +28,7 @@ #include <dm/devres.h> #include <linux/bug.h> #include <linux/delay.h> +#include <linux/printk.h>
#include <linux/errno.h> #include <linux/list.h> diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index a8e8bfc04b4..e4572ec6481 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -14,6 +14,7 @@ #include <part.h> #include <linux/errno.h> #include <linux/netdevice.h> +#include <linux/printk.h> #include <linux/usb/ch9.h> #include <linux/usb/cdc.h> #include <linux/usb/gadget.h> diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index d1d087e12b2..44354bdc01c 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -17,6 +17,7 @@ #include <fastboot.h> #include <log.h> #include <malloc.h> +#include <linux/printk.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <linux/usb/composite.h> diff --git a/drivers/usb/gadget/f_sdp.c b/drivers/usb/gadget/f_sdp.c index e48aa2f90df..b7c97cf4579 100644 --- a/drivers/usb/gadget/f_sdp.c +++ b/drivers/usb/gadget/f_sdp.c @@ -22,6 +22,7 @@ #include <env.h> #include <log.h> #include <malloc.h> +#include <linux/printk.h>
#include <linux/usb/ch9.h> #include <linux/usb/gadget.h> diff --git a/drivers/usb/gadget/f_thor.c b/drivers/usb/gadget/f_thor.c index 88fc87f2e90..3c47e6251b1 100644 --- a/drivers/usb/gadget/f_thor.c +++ b/drivers/usb/gadget/f_thor.c @@ -24,6 +24,7 @@ #include <memalign.h> #include <version.h> #include <linux/delay.h> +#include <linux/printk.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <linux/usb/composite.h> diff --git a/drivers/usb/gadget/udc/udc-uclass.c b/drivers/usb/gadget/udc/udc-uclass.c index 3053ccf7d97..384aa47a98f 100644 --- a/drivers/usb/gadget/udc/udc-uclass.c +++ b/drivers/usb/gadget/udc/udc-uclass.c @@ -7,6 +7,7 @@ #include <common.h> #include <dm.h> #include <dm/device-internal.h> +#include <linux/printk.h> #include <linux/usb/gadget.h>
#if CONFIG_IS_ENABLED(DM_USB_GADGET) diff --git a/drivers/usb/host/dwc3-sti-glue.c b/drivers/usb/host/dwc3-sti-glue.c index febbfe5d243..95514a4c593 100644 --- a/drivers/usb/host/dwc3-sti-glue.c +++ b/drivers/usb/host/dwc3-sti-glue.c @@ -17,6 +17,7 @@ #include <reset-uclass.h> #include <syscon.h> #include <usb.h> +#include <linux/printk.h>
#include <linux/usb/dwc3.h> #include <linux/usb/otg.h> diff --git a/drivers/usb/musb-new/mt85xx.c b/drivers/usb/musb-new/mt85xx.c index 8f0561eeba3..d76c65c899c 100644 --- a/drivers/usb/musb-new/mt85xx.c +++ b/drivers/usb/musb-new/mt85xx.c @@ -16,6 +16,7 @@ #include <dm/lists.h> #include <dm/root.h> #include <linux/delay.h> +#include <linux/printk.h> #include <linux/usb/musb.h> #include <usb.h> #include "linux-compat.h" diff --git a/drivers/usb/musb-new/musb_core.c b/drivers/usb/musb-new/musb_core.c index 22811a5efb2..0d94e11f96a 100644 --- a/drivers/usb/musb-new/musb_core.c +++ b/drivers/usb/musb-new/musb_core.c @@ -86,6 +86,7 @@ #include <linux/bitops.h> #include <linux/bug.h> #include <linux/errno.h> +#include <linux/printk.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <linux/usb/musb.h> diff --git a/drivers/usb/musb-new/musb_debug.h b/drivers/usb/musb-new/musb_debug.h index c468bda9ff2..94375b72c70 100644 --- a/drivers/usb/musb-new/musb_debug.h +++ b/drivers/usb/musb-new/musb_debug.h @@ -10,6 +10,7 @@ #ifndef __MUSB_LINUX_DEBUG_H__ #define __MUSB_LINUX_DEBUG_H__
+#include <linux/printk.h> #define yprintk(facility, format, args...) \ do { printk(facility "%s %d: " format , \ __func__, __LINE__ , ## args); } while (0) diff --git a/drivers/usb/musb-new/musb_dsps.c b/drivers/usb/musb-new/musb_dsps.c index d55a920ae59..a8ff7434c9f 100644 --- a/drivers/usb/musb-new/musb_dsps.c +++ b/drivers/usb/musb-new/musb_dsps.c @@ -35,6 +35,7 @@ #include <dm.h> #include <dm/device_compat.h> #include <asm/omap_musb.h> +#include <linux/printk.h> #include "linux-compat.h" #endif
diff --git a/drivers/usb/musb-new/musb_gadget.c b/drivers/usb/musb-new/musb_gadget.c index 5b149dac6dd..251355f4ee1 100644 --- a/drivers/usb/musb-new/musb_gadget.c +++ b/drivers/usb/musb-new/musb_gadget.c @@ -26,6 +26,7 @@ #include <dm.h> #include <dm/device_compat.h> #include <linux/bug.h> +#include <linux/printk.h> #include <linux/usb/ch9.h> #include "linux-compat.h" #endif diff --git a/drivers/usb/musb-new/musb_gadget_ep0.c b/drivers/usb/musb-new/musb_gadget_ep0.c index cbd92fca6b6..9df856f32e0 100644 --- a/drivers/usb/musb-new/musb_gadget_ep0.c +++ b/drivers/usb/musb-new/musb_gadget_ep0.c @@ -22,6 +22,7 @@ #include <dm.h> #include <dm/device_compat.h> #include <asm/processor.h> +#include <linux/printk.h> #include "linux-compat.h" #endif
diff --git a/drivers/usb/musb-new/omap2430.c b/drivers/usb/musb-new/omap2430.c index fbd5f98f368..c41b9147fa5 100644 --- a/drivers/usb/musb-new/omap2430.c +++ b/drivers/usb/musb-new/omap2430.c @@ -17,6 +17,7 @@ #include <dm/device_compat.h> #include <dm/lists.h> #include <linux/err.h> +#include <linux/printk.h> #include <linux/usb/otg.h> #include <asm/omap_common.h> #include <asm/omap_musb.h> diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index 187db7794b6..c7cb27fcaae 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -32,6 +32,7 @@ #include <dm/root.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <linux/printk.h> #include <linux/usb/musb.h> #include "linux-compat.h" #include "musb_core.h" diff --git a/drivers/usb/musb-new/ti-musb.c b/drivers/usb/musb-new/ti-musb.c index bf58f13480b..d447baf13bb 100644 --- a/drivers/usb/musb-new/ti-musb.c +++ b/drivers/usb/musb-new/ti-musb.c @@ -12,6 +12,7 @@ #include <log.h> #include <malloc.h> #include <asm/global_data.h> +#include <linux/printk.h> #include <linux/usb/otg.h> #include <dm/device-internal.h> #include <dm/lists.h> diff --git a/drivers/video/am335x-fb.c b/drivers/video/am335x-fb.c index 2bf4d85d021..4354c3efac1 100644 --- a/drivers/video/am335x-fb.c +++ b/drivers/video/am335x-fb.c @@ -25,6 +25,7 @@ #include <asm/utils.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/printk.h> #include "am335x-fb.h"
#define LCDC_FMAX 200000000 diff --git a/drivers/video/meson/meson_dw_hdmi.c b/drivers/video/meson/meson_dw_hdmi.c index 7b2ff94eba5..ec550b57fda 100644 --- a/drivers/video/meson/meson_dw_hdmi.c +++ b/drivers/video/meson/meson_dw_hdmi.c @@ -14,6 +14,7 @@ #include <dm/device-internal.h> #include <dm/uclass-internal.h> #include <linux/bitops.h> +#include <linux/printk.h> #include <power/regulator.h> #include <clk.h> #include <linux/delay.h> diff --git a/drivers/video/meson/meson_vclk.c b/drivers/video/meson/meson_vclk.c index cd1e69040f7..e718a0074ed 100644 --- a/drivers/video/meson/meson_vclk.c +++ b/drivers/video/meson/meson_vclk.c @@ -10,6 +10,7 @@ #include <dm.h> #include <edid.h> #include <linux/bitops.h> +#include <linux/printk.h> #include "meson_vpu.h" #include <log.h> #include <linux/iopoll.h> diff --git a/drivers/video/stm32/stm32_dsi.c b/drivers/video/stm32/stm32_dsi.c index 8fae9f2246e..174d7418865 100644 --- a/drivers/video/stm32/stm32_dsi.c +++ b/drivers/video/stm32/stm32_dsi.c @@ -26,6 +26,7 @@ #include <dm/lists.h> #include <linux/bitops.h> #include <linux/iopoll.h> +#include <linux/printk.h> #include <power/regulator.h>
#define HWVER_130 0x31333000 /* IP version 1.30 */ diff --git a/drivers/video/stm32/stm32_ltdc.c b/drivers/video/stm32/stm32_ltdc.c index bfd9d5991d3..d051fef8c49 100644 --- a/drivers/video/stm32/stm32_ltdc.c +++ b/drivers/video/stm32/stm32_ltdc.c @@ -20,6 +20,7 @@ #include <dm/device-internal.h> #include <dm/device_compat.h> #include <linux/bitops.h> +#include <linux/printk.h>
struct stm32_ltdc_priv { void __iomem *regs; diff --git a/drivers/video/tegra124/sor.c b/drivers/video/tegra124/sor.c index 49f33c15b5c..52ab1b52915 100644 --- a/drivers/video/tegra124/sor.c +++ b/drivers/video/tegra124/sor.c @@ -15,6 +15,7 @@ #include <asm/arch/clock.h> #include <asm/arch-tegra/dc.h> #include <linux/delay.h> +#include <linux/printk.h> #include "displayport.h" #include "sor.h" #include <linux/err.h> diff --git a/drivers/watchdog/stm32mp_wdt.c b/drivers/watchdog/stm32mp_wdt.c index f673fce327c..89ce5588a37 100644 --- a/drivers/watchdog/stm32mp_wdt.c +++ b/drivers/watchdog/stm32mp_wdt.c @@ -12,6 +12,7 @@ #include <asm/io.h> #include <linux/bitops.h> #include <linux/iopoll.h> +#include <linux/printk.h>
/* IWDG registers */ #define IWDG_KR 0x00 /* Key register */ diff --git a/env/common.c b/env/common.c index d6d1fa3a1f7..b6a1f45271c 100644 --- a/env/common.c +++ b/env/common.c @@ -15,6 +15,7 @@ #include <log.h> #include <sort.h> #include <asm/global_data.h> +#include <linux/printk.h> #include <linux/stddef.h> #include <search.h> #include <errno.h> diff --git a/fs/ubifs/debug.c b/fs/ubifs/debug.c index 2ff8f1a5f9b..4a8fd88cdd7 100644 --- a/fs/ubifs/debug.c +++ b/fs/ubifs/debug.c @@ -18,6 +18,7 @@ #include <hexdump.h> #include <log.h> #include <dm/devres.h> +#include <linux/printk.h>
#ifndef __UBOOT__ #include <linux/module.h> diff --git a/fs/ubifs/debug.h b/fs/ubifs/debug.h index 5f6e12702de..85f760e41a1 100644 --- a/fs/ubifs/debug.h +++ b/fs/ubifs/debug.h @@ -12,6 +12,7 @@ #define __UBIFS_DEBUG_H__
/* Checking helper functions */ +#include <linux/printk.h> typedef int (*dbg_leaf_callback)(struct ubifs_info *c, struct ubifs_zbranch *zbr, void *priv); typedef int (*dbg_znode_callback)(struct ubifs_info *c, diff --git a/fs/ubifs/lpt_commit.c b/fs/ubifs/lpt_commit.c index 897d0014306..3ca8d704aaf 100644 --- a/fs/ubifs/lpt_commit.c +++ b/fs/ubifs/lpt_commit.c @@ -23,6 +23,7 @@ #include <linux/bitops.h> #include <linux/compat.h> #include <linux/err.h> +#include <linux/printk.h> #include "crc16.h" #endif #include "ubifs.h" diff --git a/fs/ubifs/super.c b/fs/ubifs/super.c index e3a4c0bca27..347f8365642 100644 --- a/fs/ubifs/super.c +++ b/fs/ubifs/super.c @@ -35,6 +35,7 @@ #include <linux/bitops.h> #include <linux/bug.h> #include <linux/log2.h> +#include <linux/printk.h> #include <linux/stat.h> #include <linux/err.h> #include "ubifs.h" diff --git a/fs/ubifs/ubifs.h b/fs/ubifs/ubifs.h index 512fdaa1444..efa7a69cb6d 100644 --- a/fs/ubifs/ubifs.h +++ b/fs/ubifs/ubifs.h @@ -35,6 +35,7 @@ #include <asm-generic/atomic-long.h> #include <ubi_uboot.h> #include <ubifs_uboot.h> +#include <linux/printk.h>
#include <linux/ctype.h> #include <linux/time.h> diff --git a/fs/yaffs2/yaffs_uboot_glue.c b/fs/yaffs2/yaffs_uboot_glue.c index 7a15a02974d..913eb323f38 100644 --- a/fs/yaffs2/yaffs_uboot_glue.c +++ b/fs/yaffs2/yaffs_uboot_glue.c @@ -22,6 +22,7 @@ #include <common.h> #include <div64.h> #include <malloc.h> +#include <linux/printk.h>
#include <config.h> #include "nand.h" diff --git a/include/common.h b/include/common.h index 25c317f4439..a79c2bb4993 100644 --- a/include/common.h +++ b/include/common.h @@ -17,7 +17,6 @@ #include <errno.h> #include <time.h> #include <linux/types.h> -#include <linux/printk.h> #include <linux/string.h> #include <stdarg.h> #include <stdio.h> diff --git a/include/crypto/pkcs7_parser.h b/include/crypto/pkcs7_parser.h index 906033a90eb..2c45cce5234 100644 --- a/include/crypto/pkcs7_parser.h +++ b/include/crypto/pkcs7_parser.h @@ -11,6 +11,7 @@ #include <linux/oid_registry.h> #include <crypto/pkcs7.h> #include <crypto/x509_parser.h> +#include <linux/printk.h>
#define kenter(FMT, ...) \ pr_devel("==> %s("FMT")\n", __func__, ##__VA_ARGS__) diff --git a/include/dm/device_compat.h b/include/dm/device_compat.h index 82d7a7d4924..aa9a6fbb5e3 100644 --- a/include/dm/device_compat.h +++ b/include/dm/device_compat.h @@ -14,6 +14,7 @@ #include <log.h> #include <linux/build_bug.h> #include <linux/compat.h> +#include <linux/printk.h>
/* * Define a new identifier which can be tested on by C code. A similar diff --git a/include/linux/soc/ti/cppi5.h b/include/linux/soc/ti/cppi5.h index cfdf7ea29fc..3a55c3ec46f 100644 --- a/include/linux/soc/ti/cppi5.h +++ b/include/linux/soc/ti/cppi5.h @@ -11,6 +11,7 @@ #include <hexdump.h> #include <linux/bitops.h> #include <linux/bug.h> +#include <linux/printk.h>
/** * Descriptor header, present in all types of descriptors diff --git a/lib/asn1_decoder.c b/lib/asn1_decoder.c index bcb0390eb41..1191fc36487 100644 --- a/lib/asn1_decoder.c +++ b/lib/asn1_decoder.c @@ -8,6 +8,7 @@ #ifdef __UBOOT__ #include <log.h> #include <linux/compat.h> +#include <linux/printk.h> #else #include <linux/export.h> #endif diff --git a/lib/bch.c b/lib/bch.c index de66b1acba5..72b4fdcc9c4 100644 --- a/lib/bch.c +++ b/lib/bch.c @@ -61,6 +61,7 @@ #include <dm/devres.h>
#include <linux/bitops.h> +#include <linux/printk.h> #else #include <errno.h> #if defined(__FreeBSD__) diff --git a/lib/crypto/asymmetric_type.c b/lib/crypto/asymmetric_type.c index 1d0532d0f2e..24c2d15ef97 100644 --- a/lib/crypto/asymmetric_type.c +++ b/lib/crypto/asymmetric_type.c @@ -18,6 +18,7 @@ #include <linux/compat.h> #include <linux/ctype.h> #include <linux/err.h> +#include <linux/printk.h> #include <linux/string.h> #else #include <linux/seq_file.h> diff --git a/lib/crypto/pkcs7_parser.c b/lib/crypto/pkcs7_parser.c index 0b85fe8286c..d5efa828d6a 100644 --- a/lib/crypto/pkcs7_parser.c +++ b/lib/crypto/pkcs7_parser.c @@ -11,6 +11,7 @@ #include <dm/devres.h> #include <linux/bitops.h> #include <linux/compat.h> +#include <linux/printk.h> #endif #include <linux/kernel.h> #ifndef __UBOOT__ diff --git a/lib/crypto/pkcs7_verify.c b/lib/crypto/pkcs7_verify.c index 320ba49f79d..db02f346f76 100644 --- a/lib/crypto/pkcs7_verify.c +++ b/lib/crypto/pkcs7_verify.c @@ -15,6 +15,7 @@ #include <linux/bitops.h> #include <linux/compat.h> #include <linux/asn1.h> +#include <linux/printk.h> #include <u-boot/rsa-checksum.h> #include <crypto/public_key.h> #include <crypto/pkcs7_parser.h> diff --git a/lib/crypto/public_key.c b/lib/crypto/public_key.c index df6033cdb49..8eb14aac20d 100644 --- a/lib/crypto/public_key.c +++ b/lib/crypto/public_key.c @@ -13,6 +13,7 @@ #include <linux/bug.h> #include <linux/compat.h> #include <linux/err.h> +#include <linux/printk.h> #else #include <linux/module.h> #include <linux/export.h> diff --git a/lib/crypto/rsa_helper.c b/lib/crypto/rsa_helper.c index cc0c0d6637b..c941d40fd7a 100644 --- a/lib/crypto/rsa_helper.c +++ b/lib/crypto/rsa_helper.c @@ -15,6 +15,7 @@ #include <linux/fips.h> #endif #include <crypto/internal/rsa.h> +#include <linux/printk.h> #include "rsapubkey.asn1.h" #ifndef __UBOOT__ #include "rsaprivkey.asn1.h" diff --git a/lib/crypto/x509_cert_parser.c b/lib/crypto/x509_cert_parser.c index eb24349460c..a0f0689118f 100644 --- a/lib/crypto/x509_cert_parser.c +++ b/lib/crypto/x509_cert_parser.c @@ -16,6 +16,7 @@ #include <linux/err.h> #include <linux/oid_registry.h> #ifdef __UBOOT__ +#include <linux/printk.h> #include <linux/string.h> #endif #include <crypto/public_key.h> diff --git a/lib/crypto/x509_public_key.c b/lib/crypto/x509_public_key.c index 91810a86404..518dc906731 100644 --- a/lib/crypto/x509_public_key.c +++ b/lib/crypto/x509_public_key.c @@ -13,6 +13,7 @@ #include <linux/compat.h> #include <linux/err.h> #include <linux/errno.h> +#include <linux/printk.h> #else #include <linux/module.h> #endif diff --git a/lib/list_sort.c b/lib/list_sort.c index 58e1e1614a5..1c9e0617327 100644 --- a/lib/list_sort.c +++ b/lib/list_sort.c @@ -8,6 +8,7 @@ #include <linux/compat.h> #include <common.h> #include <malloc.h> +#include <linux/printk.h> #endif #include <linux/list.h> #include <linux/list_sort.h> diff --git a/net/fastboot.c b/net/fastboot.c index 7e7a601b9fe..efba7016c97 100644 --- a/net/fastboot.c +++ b/net/fastboot.c @@ -7,6 +7,7 @@ #include <command.h> #include <fastboot.h> #include <net.h> +#include <linux/printk.h> #include <net/fastboot.h>
/* Fastboot port # defined in spec */
Fix the code style used for some time functions.
arch/arm/cpu/arm920t/imx/timer.c | 2 +- arch/arm/cpu/sa1100/timer.c | 2 +- arch/microblaze/cpu/timer.c | 2 +- arch/powerpc/lib/interrupts.c | 2 +- arch/powerpc/lib/time.c | 5 +++-- board/armltd/integrator/timer.c | 2 +- drivers/fpga/ACEX1K.c | 4 ++-- drivers/fpga/spartan2.c | 24 ++++++++++++------------ drivers/fpga/spartan3.c | 24 ++++++++++++------------ drivers/net/lan91c96.c | 4 ++-- drivers/net/ne2000_base.c | 4 ++-- drivers/net/smc91111.c | 4 ++-- post/drivers/rtc.c | 4 ++-- 13 files changed, 42 insertions(+), 41 deletions(-)
diff --git a/arch/arm/cpu/arm920t/imx/timer.c b/arch/arm/cpu/arm920t/imx/timer.c index e9d55779214..b559db75f12 100644 --- a/arch/arm/cpu/arm920t/imx/timer.c +++ b/arch/arm/cpu/arm920t/imx/timer.c @@ -44,7 +44,7 @@ static ulong get_timer_masked (void) return TCN1; }
-ulong get_timer (ulong base) +ulong get_timer(ulong base) { return get_timer_masked() - base; } diff --git a/arch/arm/cpu/sa1100/timer.c b/arch/arm/cpu/sa1100/timer.c index a5cdaf5a66c..5d597dd1ab4 100644 --- a/arch/arm/cpu/sa1100/timer.c +++ b/arch/arm/cpu/sa1100/timer.c @@ -19,7 +19,7 @@ static ulong get_timer_masked (void) return OSCR; }
-ulong get_timer (ulong base) +ulong get_timer(ulong base) { return get_timer_masked (); } diff --git a/arch/microblaze/cpu/timer.c b/arch/microblaze/cpu/timer.c index 647bdcd5ba5..05ab0e1b157 100644 --- a/arch/microblaze/cpu/timer.c +++ b/arch/microblaze/cpu/timer.c @@ -20,7 +20,7 @@ DECLARE_GLOBAL_DATA_PTR; volatile int timestamp = 0; microblaze_timer_t *tmr;
-ulong get_timer (ulong base) +ulong get_timer(ulong base) { if (tmr) return timestamp - base; diff --git a/arch/powerpc/lib/interrupts.c b/arch/powerpc/lib/interrupts.c index 73f270002cf..bda0999327d 100644 --- a/arch/powerpc/lib/interrupts.c +++ b/arch/powerpc/lib/interrupts.c @@ -89,7 +89,7 @@ void timer_interrupt(struct pt_regs *regs) #endif /* CONFIG_LED_STATUS */ }
-ulong get_timer (ulong base) +ulong get_timer(ulong base) { return (timestamp - base); } diff --git a/arch/powerpc/lib/time.c b/arch/powerpc/lib/time.c index 8d6babfb83d..d27432c23af 100644 --- a/arch/powerpc/lib/time.c +++ b/arch/powerpc/lib/time.c @@ -39,8 +39,9 @@ unsigned long usec2ticks(unsigned long usec) */ void __udelay(unsigned long usec) { - ulong ticks = usec2ticks (usec); - wait_ticks (ticks); + ulong ticks = usec2ticks(usec); + + wait_ticks(ticks); }
/* ------------------------------------------------------------------------- */ diff --git a/board/armltd/integrator/timer.c b/board/armltd/integrator/timer.c index d220b877d66..53d1c0ec303 100644 --- a/board/armltd/integrator/timer.c +++ b/board/armltd/integrator/timer.c @@ -119,7 +119,7 @@ static ulong get_timer_masked (void) return timestamp; }
-ulong get_timer (ulong base_ticks) +ulong get_timer(ulong base_ticks) { return get_timer_masked () - base_ticks; } diff --git a/drivers/fpga/ACEX1K.c b/drivers/fpga/ACEX1K.c index aca8049c56a..30a3727433e 100644 --- a/drivers/fpga/ACEX1K.c +++ b/drivers/fpga/ACEX1K.c @@ -140,10 +140,10 @@ static int ACEX1K_ps_load(Altera_desc *desc, const void *buf, size_t bsize) udelay(2); /* T_cf2st1 < 4us */
/* Wait for nSTATUS to be released (i.e. deasserted) */ - ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ do { CONFIG_FPGA_DELAY (); - if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for STATUS to go high.\n"); (*fn->abort) (cookie); return FPGA_FAIL; diff --git a/drivers/fpga/spartan2.c b/drivers/fpga/spartan2.c index 3435400e58b..fae94f9663a 100644 --- a/drivers/fpga/spartan2.c +++ b/drivers/fpga/spartan2.c @@ -151,11 +151,11 @@ static int spartan2_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) CONFIG_FPGA_DELAY (); (*fn->pgm) (false, true, cookie); /* Deassert the program, commit */
- ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ /* Now wait for INIT and BUSY to go high */ do { CONFIG_FPGA_DELAY (); - if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for INIT to clear.\n"); (*fn->abort) (cookie); /* abort the burn */ return FPGA_FAIL; @@ -178,7 +178,7 @@ static int spartan2_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) (*fn->clk) (true, true, cookie); /* Assert the clock pin */
#ifdef CONFIG_SYS_FPGA_CHECK_BUSY - ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ while ((*fn->busy) (cookie)) { /* XXX - we should have a check in here somewhere to * make sure we aren't busy forever... */ @@ -188,7 +188,7 @@ static int spartan2_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) CONFIG_FPGA_DELAY (); (*fn->clk) (true, true, cookie); /* Assert the clock pin */
- if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for BUSY to clear.\n"); (*fn->abort) (cookie); /* abort the burn */ return FPGA_FAIL; @@ -211,7 +211,7 @@ static int spartan2_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) #endif
/* now check for done signal */ - ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ ret_val = FPGA_SUCCESS; while ((*fn->done) (cookie) == FPGA_FAIL) {
@@ -220,7 +220,7 @@ static int spartan2_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) CONFIG_FPGA_DELAY (); (*fn->clk) (true, true, cookie); /* Assert the clock pin */
- if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for DONE to clear.\n"); (*fn->abort) (cookie); /* abort the burn */ ret_val = FPGA_FAIL; @@ -337,10 +337,10 @@ static int spartan2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) (*fn->pgm) (true, true, cookie); /* Assert the program, commit */
/* Wait for INIT state (init low) */ - ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ do { CONFIG_FPGA_DELAY (); - if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for INIT to start.\n"); return FPGA_FAIL; } @@ -350,11 +350,11 @@ static int spartan2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) CONFIG_FPGA_DELAY (); (*fn->pgm) (false, true, cookie); /* Deassert the program, commit */
- ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ /* Now wait for INIT to go high */ do { CONFIG_FPGA_DELAY (); - if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for INIT to clear.\n"); return FPGA_FAIL; } @@ -398,7 +398,7 @@ static int spartan2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) #endif
/* now check for done signal */ - ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ ret_val = FPGA_SUCCESS; (*fn->wr) (true, true, cookie);
@@ -411,7 +411,7 @@ static int spartan2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize)
putc ('*');
- if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for DONE to clear.\n"); ret_val = FPGA_FAIL; break; diff --git a/drivers/fpga/spartan3.c b/drivers/fpga/spartan3.c index 4850c99352d..e40e427a25f 100644 --- a/drivers/fpga/spartan3.c +++ b/drivers/fpga/spartan3.c @@ -155,11 +155,11 @@ static int spartan3_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) CONFIG_FPGA_DELAY (); (*fn->pgm) (false, true, cookie); /* Deassert the program, commit */
- ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ /* Now wait for INIT and BUSY to go high */ do { CONFIG_FPGA_DELAY (); - if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for INIT to clear.\n"); (*fn->abort) (cookie); /* abort the burn */ return FPGA_FAIL; @@ -182,7 +182,7 @@ static int spartan3_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) (*fn->clk) (true, true, cookie); /* Assert the clock pin */
#ifdef CONFIG_SYS_FPGA_CHECK_BUSY - ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ while ((*fn->busy) (cookie)) { /* XXX - we should have a check in here somewhere to * make sure we aren't busy forever... */ @@ -192,7 +192,7 @@ static int spartan3_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) CONFIG_FPGA_DELAY (); (*fn->clk) (true, true, cookie); /* Assert the clock pin */
- if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for BUSY to clear.\n"); (*fn->abort) (cookie); /* abort the burn */ return FPGA_FAIL; @@ -215,7 +215,7 @@ static int spartan3_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) #endif
/* now check for done signal */ - ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ ret_val = FPGA_SUCCESS; while ((*fn->done) (cookie) == FPGA_FAIL) { /* XXX - we should have a check in here somewhere to @@ -226,7 +226,7 @@ static int spartan3_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) CONFIG_FPGA_DELAY (); (*fn->clk) (true, true, cookie); /* Assert the clock pin */
- if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for DONE to clear.\n"); (*fn->abort) (cookie); /* abort the burn */ ret_val = FPGA_FAIL; @@ -343,10 +343,10 @@ static int spartan3_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) (*fn->pgm) (true, true, cookie); /* Assert the program, commit */
/* Wait for INIT state (init low) */ - ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ do { CONFIG_FPGA_DELAY (); - if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for INIT to start.\n"); if (*fn->abort) (*fn->abort) (cookie); @@ -358,11 +358,11 @@ static int spartan3_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) CONFIG_FPGA_DELAY (); (*fn->pgm) (false, true, cookie); /* Deassert the program, commit */
- ts = get_timer (0); /* get current time */ + ts = get_timer(0); /* get current time */ /* Now wait for INIT to go high */ do { CONFIG_FPGA_DELAY (); - if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for INIT to clear.\n"); if (*fn->abort) (*fn->abort) (cookie); @@ -414,7 +414,7 @@ static int spartan3_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) #endif
@@ -429,7 +429,7 @@ static int spartan3_ss_load(xilinx_desc *desc, const void *buf, size_t bsize)
putc ('*');
- if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ + if (get_timer(ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for DONE to clear.\n"); ret_val = FPGA_FAIL; break; diff --git a/drivers/net/lan91c96.c b/drivers/net/lan91c96.c index c2f611144db..470c68467cd 100644 --- a/drivers/net/lan91c96.c +++ b/drivers/net/lan91c96.c @@ -164,14 +164,14 @@ static void print_packet (byte *, int);
static int poll4int (struct eth_device *dev, byte mask, int timeout) { - int tmo = get_timer (0) + timeout * CONFIG_SYS_HZ; + int tmo = get_timer(0) + timeout * CONFIG_SYS_HZ; int is_timeout = 0; word old_bank = SMC_inw(dev, LAN91C96_BANK_SELECT);
PRINTK2 ("Polling...\n"); SMC_SELECT_BANK(dev, 2); while ((SMC_inw(dev, LAN91C96_INT_STATS) & mask) == 0) { - if (get_timer (0) >= tmo) { + if (get_timer(0) >= tmo) { is_timeout = 1; break; } diff --git a/drivers/net/ne2000_base.c b/drivers/net/ne2000_base.c index f6673f5e4c6..09cc8398003 100644 --- a/drivers/net/ne2000_base.c +++ b/drivers/net/ne2000_base.c @@ -750,14 +750,14 @@ static int ne2k_send(struct eth_device *dev, void *packet, int length) pkey = -1;
dp83902a_send((u8 *) packet, length, 666); - tmo = get_timer (0) + TOUT * CONFIG_SYS_HZ; + tmo = get_timer(0) + TOUT * CONFIG_SYS_HZ; while(1) { dp83902a_poll(); if (pkey != -1) { PRINTK("Packet sucesfully sent\n"); return 0; } - if (get_timer (0) >= tmo) { + if (get_timer(0) >= tmo) { printf("transmission error (timoeut)\n"); return 0; } diff --git a/drivers/net/smc91111.c b/drivers/net/smc91111.c index ec4e8e928cb..fea6ba8caaa 100644 --- a/drivers/net/smc91111.c +++ b/drivers/net/smc91111.c @@ -238,14 +238,14 @@ static void print_packet( byte *, int );
static int poll4int (struct eth_device *dev, byte mask, int timeout) { - int tmo = get_timer (0) + timeout * CONFIG_SYS_HZ; + int tmo = get_timer(0) + timeout * CONFIG_SYS_HZ; int is_timeout = 0; word old_bank = SMC_inw (dev, BSR_REG);
PRINTK2 ("Polling...\n"); SMC_SELECT_BANK (dev, 2); while ((SMC_inw (dev, SMC91111_INT_REG) & mask) == 0) { - if (get_timer (0) >= tmo) { + if (get_timer(0) >= tmo) { is_timeout = 1; break; } diff --git a/post/drivers/rtc.c b/post/drivers/rtc.c index c603f0e6728..af701e464d3 100644 --- a/post/drivers/rtc.c +++ b/post/drivers/rtc.c @@ -36,11 +36,11 @@ static int rtc_post_skip (ulong * diff) ulong start2;
rtc_get (&tm1); - start1 = get_timer (0); + start1 = get_timer(0);
while (1) { rtc_get (&tm2); - start2 = get_timer (0); + start2 = get_timer(0); if (tm1.tm_sec != tm2.tm_sec) break; if (start2 - start1 > 1500)
