[U-Boot] [PATCH v2 0/8] Add support for Synology DS414 and some related fixes
This is version 2 of my patch series to support Synology DS414 NAS after rebasing it onto mvebu-dm-spl-2015-12-14 branch of u-boot-a38x.git. Due to this, some things became unnecessary or could be solved differently. In addition to that, static env settings have been added. In detail:
* Dropped patch 2, already fixed upstream. * Dropped patch 7, board IDs now start at 1. * Dropped patch 8, ECC is now selectable from board headers. * Changed patch 9: * Use switch() statement in mvebu_soc_family(). * Move changes to ctrl_model_get() here from DS414 support patch since it belongs to SoC support. * Changed patch 10: * Added U-Boot specific things to DT file. * Static env settings added. * Updated ds414_defconfig and ds414.h to incorporate changes done for other Armada XP boards as well. * Fixed comment in ds414.h. * Added partition types and VFAT support to ds414.h.
The new summary is as follows: * Patches 1, 2 and 4 fix various files for enabled debugging. * Patch 3 updates the board porting guide in README file. * Patch 5 holds a crucial pci_mvebu fix necessary for DS414 support. * Patches 6 and 7 contain the actual board support, split into a generic part for MV78230 SoC and a board specific part for clarity. * Patch 8 adds a new command to deal with Synology specialties.
In case you would like me to split this into multiple series, just let me know and I will resend.
Phil Sutter (8): drivers/pci: Fix for debug builds without CONFIG_PCI_ENUM_ONLY mvebu: Fix for non-DM ehci-marvell support README: Review the u-boot porting guide list axp: Fix debugging support in DDR3 write leveling drivers/pci/pci_mvebu: Fix for boards with X4 lanes mvebu: Add rudimental MV78320 support mvebu: Support Synology DS414 common: Implement Synology specific command set
README | 11 +- arch/arm/Kconfig | 1 + arch/arm/dts/Makefile | 2 + arch/arm/dts/armada-xp-synology-ds414.dts | 337 +++++++++++++++++++++ arch/arm/mach-mvebu/Kconfig | 3 + arch/arm/mach-mvebu/cpu.c | 37 ++- arch/arm/mach-mvebu/include/mach/cpu.h | 3 + arch/arm/mach-mvebu/include/mach/soc.h | 10 +- arch/arm/mach-mvebu/serdes/axp/board_env_spec.h | 5 +- .../arm/mach-mvebu/serdes/axp/high_speed_env_lib.c | 9 +- board/Synology/ds414/Kconfig | 12 + board/Synology/ds414/Makefile | 1 + board/Synology/ds414/ds414.c | 173 +++++++++++ board/Synology/ds414/kwbimage.cfg | 12 + common/Makefile | 1 + common/cmd_syno.c | 225 ++++++++++++++ configs/ds414_defconfig | 18 ++ drivers/ddr/marvell/axp/ddr3_write_leveling.c | 4 +- drivers/pci/pci_auto_old.c | 2 +- drivers/pci/pci_mvebu.c | 21 ++ include/configs/ds414.h | 165 ++++++++++ 21 files changed, 1033 insertions(+), 19 deletions(-) create mode 100644 arch/arm/dts/armada-xp-synology-ds414.dts create mode 100644 board/Synology/ds414/Kconfig create mode 100644 board/Synology/ds414/Makefile create mode 100644 board/Synology/ds414/ds414.c create mode 100644 board/Synology/ds414/kwbimage.cfg create mode 100644 common/cmd_syno.c create mode 100644 configs/ds414_defconfig create mode 100644 include/configs/ds414.h
Phil Sutter
