[U-Boot] Pull request: u-boot-net.git master
Hi Tom,
The following changes since commit aa6aaf93211b7e22361e75f1068e1e565e731f25:
ARM: rockchip: rock: Correct test to use CONFIG_IS_ENABLED not defined (2017-08-14 13:33:07 -0400)
git://git.denx.de/u-boot-net.git master
for you to fetch changes up to a5fe87e829487cb5589afba3b5d8c3adff3b077d:
driver: net: ldpaa: Update priv->phydev after free() (2017-08-14 12:47:33 -0500)
---------------------------------------------------------------- Madalin Bucur (1): net: fman: add support RGMII_TXID to memac
Prabhakar Kushwaha (1): driver: net: ldpaa: Update priv->phydev after free()
Yuiko Oshino (2): net: Add mii_resolve_flowctrl_fdx() usb: net: Add support for Microchip LAN75xx and LAN78xx
drivers/net/fm/memac.c | 4 +- drivers/net/ldpaa_eth/ldpaa_eth.c | 4 +- drivers/usb/Kconfig | 2 + drivers/usb/eth/Kconfig | 17 ++ drivers/usb/eth/Makefile | 2 + drivers/usb/eth/lan75xx.c | 315 ++++++++++++++++++++++++ drivers/usb/eth/lan78xx.c | 477 ++++++++++++++++++++++++++++++++++++ drivers/usb/eth/lan7x.c | 499 ++++++++++++++++++++++++++++++++++++++ drivers/usb/eth/lan7x.h | 230 ++++++++++++++++++ include/linux/mii.h | 23 ++ 10 files changed, 1571 insertions(+), 2 deletions(-) create mode 100644 drivers/usb/eth/Kconfig create mode 100644 drivers/usb/eth/lan75xx.c create mode 100644 drivers/usb/eth/lan78xx.c create mode 100644 drivers/usb/eth/lan7x.c create mode 100644 drivers/usb/eth/lan7x.h
Thanks! -Joe
On Mon, Aug 14, 2017 at 12:48:43PM -0500, Joe Hershberger wrote:
Hi Tom,
Joe Hershberger
