[U-Boot] [PATCH 1/1] efi_selftest: allow building on ARMv7-M
ARMv7-M only supports the Thumb instruction set. Our current crt0 code does not support it. With the patch we can build all unit tests of the EFI subsystem that do not require crt0.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/arm/lib/Makefile | 6 +++++- lib/efi_selftest/Makefile | 6 +++--- 2 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 655727f431..48ee6c3c60 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -106,5 +106,9 @@ CFLAGS_$(EFI_RELOC) := $(CFLAGS_EFI) CFLAGS_REMOVE_$(EFI_RELOC) := $(CFLAGS_NON_EFI)
extra-$(CONFIG_CMD_BOOTEFI_HELLO_COMPILE) += $(EFI_CRT0) $(EFI_RELOC) -extra-$(CONFIG_CMD_BOOTEFI_SELFTEST) += $(EFI_CRT0) $(EFI_RELOC) +# TODO: As of v2019.01 the relocation code for the EFI application cannot +# be built on ARMv7-M. +ifndef CONFIG_CPU_V7M +#extra-$(CONFIG_CMD_BOOTEFI_SELFTEST) += $(EFI_CRT0) $(EFI_RELOC) +endif extra-$(CONFIG_EFI) += $(EFI_CRT0) $(EFI_RELOC) diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 743b482044..5b804692aa 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -45,9 +45,9 @@ ifeq ($(CONFIG_BLK)$(CONFIG_PARTITIONS),yy) obj-y += efi_selftest_block_device.o endif
-# TODO: As of v2018.01 the relocation code for the EFI application cannot -# be built on x86_64. -ifeq ($(CONFIG_X86_64)$(CONFIG_SANDBOX),) +# TODO: As of v2019.01 the relocation code for the EFI application cannot +# be built on ARMv7-M, Sandbox, and x86_64. +ifeq ($(CONFIG_SANDBOX)$(CONFIG_CPU_V7M)$(CONFIG_X86_64),)
obj-y += \ efi_selftest_startimage_exit.o \
