[U-Boot] Mips, U-Boot and ramdisk
Hello,
Can anybody help me? I'm working on this for a few days...
I'm working on a custom developed board, with Au1200, and I'd like to use the U-Boot as bootloader. I ported the U-Boot to my board, made a Linux kernel image, and a ramdisk image.
To try out the configuration, I burn the U-Boot image into the flash (it works well), and after I start the board, it download the kernel image and the ramdisk image through TFTP. I'm using the following two commands:
tftp 81000000 uImage tftp 81FFFFC0 uRamdisk
I set the bootargs variable to: root=\dev\ram (I used: set bootargs root=/dev/ram) But when I'm trying to start the Linux with the
bootm 81000000 81FFFFC0
the Linux can't find the ramdisk. It write out:
Initrd not found or empty - disabling initrd
But when I set its address into the bootargs (so the bootargs: root=/dev/ram rd_start=0x82000000 rd_size=0x191160), it works well; it successfully find the image, and can mount it.
How does the U-Boot pass the ramdisk information? It sets some kind of environment variables in the bootm.c. But it doesn't work for me. Why? (I could use the bootargs solution in this case, but I'm afraid, it can't pass other arguments too, like ethernet address, etc.)
Thanks in advance!
Best regards, Robert Hodaszi
Hi Robert,
root=/dev/ram is definitely correct. It was MS-DOS a while ago, which switched the '/'s to ''s on stealing the hierarchical file system concept from Unix ;)
This is highly specific to the architecture. Looking into MIPS code, it an environment like datastructure is built and passes that to the kernel (lib_mips/bootm.c).
Right, that's what I see also.
I can't help you here, the best thing would be to debug this. Maybe the MIPS kernel changed the way the environment is passed?
Cheers Detlev
Hi Detlev,
Thanks for the answer!
Hi Robert,
Sorry! Yes I used '/'. I just missed it.
I thought... But I didn't find any description about this.
Cheers Detlev
I'm trying, but it's not so easy to debug the Au1200 with the BDI3000. If I want to single step the code, I should set the "Enable single step mode" flag in the processor's debug CP0 register, and clear when I'm using breakpoints, and other goodies... :)
Hi Robert.
Do you see U-Boot detecting and loading the ram disk image once you invoke your bootm command above? eg:
## Loading RAMDisk Image at 00500000 ... Image Name: uboot ext2 ramdisk rootfs Created: 2009-06-15 14:39:13 UTC Image Type: M68K Linux RAMDisk Image (gzip compressed) Data Size: 5219290 Bytes = 5 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Loading Ramdisk to 4fa79000, end 4ff733da ... OK
I believe that for U-Boot to pass the ram disk image information to the kernel, it needs to be able to detect the ram disk image in the first place. You can use U-Boot's mkimage utility to add a header onto your ram disk image.
This is because you're explicitly telling the kernel where to find the ram disk image in memory. Take a look at drivers/block/brd.c in the kernel src.
This is arch specific in U-Boot but I'd also check that your MIPS kernel has support for a) correctly parsing the U-Boot environment provided to it and b) providing the required data to other parts of the kernel for utilisation of the ram disk, eg initrd_start / initrd_end as an example.
If you're struggling to pass other args to the kernel then it sounds like there is more of a fundamental issue somewhere, though. Maybe just double check Documentation/kernel-parameters.txt to make sure you're passing syntax in a form that the kernel will recognise?
Hope that helps.
Cheers, -- Matt
Hi Matthew,
Hi Robert.
I used the mkimage, the U-Boot successfully recognized the ramdisk image, and it set the ramdisk_start and ramdisk_end variables (I turned on the debug feature). See the followings:
* kernel: cmdline image address = 0x81000000 ## Booting kernel from Legacy Image at 81000000 ... Image Name: Linux-2.6.30-dirty Created: 2009-06-23 10:11:33 UTC Image Type: MIPS Linux Kernel Image (gzip compressed) Data Size: 1589415 Bytes = 1.5 MB Load Address: 80100000 Entry Point: 80104530 Verifying Checksum ... OK kernel data at 0x81000040, len = 0x001840a7 (1589415) * ramdisk: cmdline image address = 0x81ffffc0 ## Loading init Ramdisk from Legacy Image at 81ffffc0 ... Image Name: Simple Embedded Linux Framework Created: 2007-01-21 18:52:48 UTC Image Type: MIPS Linux RAMDisk Image (gzip compressed) Data Size: 1642848 Bytes = 1.6 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ramdisk start = 0x82000000, ramdisk end = 0x82191160 Uncompressing Kernel Image ... OK kernel loaded at 0x80100000, end = 0x8044a200 ## Transferring control to Linux (at address 80104530) ... ## Giving linux memsize in bytes, 134217728
As I saw, the arch/mips/kernel/setup.c (rd_start_early and rd_size_early) set these informations.
Hope that helps.
Cheers, -- Matt
I don't know yet, if it can or can't pass other arguments. I check only that one so far. But the command line parameters work well, I tried the kgdb, the ramdisk, etc. It's only a problem with this environment variable. But I'm just debugging...
Hope that helps.
Cheers, -- Matt
I checked, and it seems, that the kernel doesn't check anywhere nor the initrd_start and initrd_size, nor the flash_start and flash_size environment parameters, but checks the memsize and ethaddr parameters. At least I couldn't find it. Is it true, or I'm blind? Did anybody use this U-Boot feature?
Detlev Zundel
Matthew Lear
Robert Hodaszi
