[PATCH v5 1/3] command.h: Clean-up patch, remove extern from the header
Remove the extern of the header because they are useless.
Signed-off-by: Kory Maincent kory.maincent@bootlin.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- include/command.h | 56 +++++++++++++++++++++++------------------------ 1 file changed, 28 insertions(+), 28 deletions(-)
diff --git a/include/command.h b/include/command.h index e229bf2825..27604758a4 100644 --- a/include/command.h +++ b/include/command.h @@ -55,8 +55,8 @@ struct cmd_tbl { };
#if defined(CONFIG_CMD_RUN) -extern int do_run(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); +int do_run(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]); #endif
/* common/command.c */ @@ -69,7 +69,7 @@ int complete_subcmdv(struct cmd_tbl *cmdtp, int count, int argc, char *const argv[], char last_char, int maxv, char *cmdv[]);
-extern int cmd_usage(const struct cmd_tbl *cmdtp); +int cmd_usage(const struct cmd_tbl *cmdtp);
/* Dummy ->cmd and ->cmd_rep wrappers. */ int cmd_always_repeatable(struct cmd_tbl *cmdtp, int flag, int argc, @@ -85,10 +85,10 @@ static inline bool cmd_is_repeatable(struct cmd_tbl *cmdtp) }
#ifdef CONFIG_AUTO_COMPLETE -extern int var_complete(int argc, char *const argv[], char last_char, int maxv, - char *cmdv[]); -extern int cmd_auto_complete(const char *const prompt, char *buf, int *np, - int *colp); +int var_complete(int argc, char *const argv[], char last_char, int maxv, + char *cmdv[]); +int cmd_auto_complete(const char *const prompt, char *buf, int *np, + int *colp); #endif
/** @@ -145,13 +145,13 @@ int cmd_get_data_size(char *arg, int default_size); #endif
#ifdef CONFIG_CMD_BOOTD -extern int do_bootd(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); +int do_bootd(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]); #endif #ifdef CONFIG_CMD_BOOTM -extern int do_bootm(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); -extern int bootm_maybe_autostart(struct cmd_tbl *cmdtp, const char *cmd); +int do_bootm(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]); +int bootm_maybe_autostart(struct cmd_tbl *cmdtp, const char *cmd); #else static inline int bootm_maybe_autostart(struct cmd_tbl *cmdtp, const char *cmd) { @@ -159,28 +159,28 @@ static inline int bootm_maybe_autostart(struct cmd_tbl *cmdtp, const char *cmd) } #endif
-extern int do_bootz(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); +int do_bootz(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]);
-extern int do_booti(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); +int do_booti(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]);
-extern int common_diskboot(struct cmd_tbl *cmdtp, const char *intf, int argc, - char *const argv[]); - -extern int do_reset(struct cmd_tbl *cmdtp, int flag, int argc, +int common_diskboot(struct cmd_tbl *cmdtp, const char *intf, int argc, char *const argv[]); -extern int do_poweroff(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]);
-extern unsigned long do_go_exec(ulong (*entry)(int, char * const []), int argc, - char *const argv[]); +int do_reset(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]); +int do_poweroff(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]); + +unsigned long do_go_exec(ulong (*entry)(int, char * const []), int argc, + char *const argv[]);
#if defined(CONFIG_CMD_NVEDIT_EFI) -extern int do_env_print_efi(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); -extern int do_env_set_efi(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); +int do_env_print_efi(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]); +int do_env_set_efi(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]); #endif
Replace all the macro ifdef by IS_ENABLED. All of these configs are set in the defconfig files and not in the include board headers files.
Signed-off-by: Kory Maincent kory.maincent@bootlin.com ---
Change since v4: - Use 'if (IS_ENABLED(CONFIG...))' instead of '#if or #ifdef' where possible
cmd/pxe_utils.c | 52 ++++++++++++++++++++++++------------------------- 1 file changed, 25 insertions(+), 27 deletions(-)
diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c index 3526a651d7..e062c9edcf 100644 --- a/cmd/pxe_utils.c +++ b/cmd/pxe_utils.c @@ -340,7 +340,7 @@ static int label_localboot(struct pxe_label *label) /* * Loads fdt overlays specified in 'fdtoverlays'. */ -#ifdef CONFIG_OF_LIBFDT_OVERLAY +#if (IS_ENABLED(CONFIG_OF_LIBFDT_OVERLAY)) static void label_boot_fdtoverlay(struct cmd_tbl *cmdtp, struct pxe_label *label) { char *fdtoverlay = label->fdtoverlays; @@ -492,16 +492,16 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) env_get("gatewayip"), env_get("netmask")); }
-#ifdef CONFIG_CMD_NET - if (label->ipappend & 0x2) { - int err; + if (IS_ENABLED(CONFIG_CMD_NET)) { + if (label->ipappend & 0x2) { + int err;
- strcpy(mac_str, " BOOTIF="); - err = format_mac_pxe(mac_str + 8, sizeof(mac_str) - 8); - if (err < 0) - mac_str[0] = '\0'; + strcpy(mac_str, " BOOTIF="); + err = format_mac_pxe(mac_str + 8, sizeof(mac_str) - 8); + if (err < 0) + mac_str[0] = '\0'; + } } -#endif
if ((label->ipappend & 0x3) || label->append) { char bootargs[CONFIG_SYS_CBSIZE] = ""; @@ -626,7 +626,7 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) } }
-#ifdef CONFIG_OF_LIBFDT_OVERLAY +#if IS_ENABLED(CONFIG_OF_LIBFDT_OVERLAY) if (label->fdtoverlays) label_boot_fdtoverlay(cmdtp, label); #endif @@ -649,15 +649,13 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) /* Try bootm for legacy and FIT format image */ if (genimg_get_format(buf) != IMAGE_FORMAT_INVALID) do_bootm(cmdtp, 0, bootm_argc, bootm_argv); -#ifdef CONFIG_CMD_BOOTI /* Try booting an AArch64 Linux kernel image */ - else + else if (IS_ENABLED(CONFIG_CMD_BOOTI)) do_booti(cmdtp, 0, bootm_argc, bootm_argv); -#elif defined(CONFIG_CMD_BOOTZ) /* Try booting a Image */ - else + else if (IS_ENABLED(CONFIG_CMD_BOOTZ)) do_bootz(cmdtp, 0, bootm_argc, bootm_argv); -#endif + unmap_sysmem(buf);
cleanup: @@ -1424,20 +1422,20 @@ void handle_pxe_menu(struct cmd_tbl *cmdtp, struct pxe_menu *cfg) struct menu *m; int err;
-#ifdef CONFIG_CMD_BMP - /* display BMP if available */ - if (cfg->bmp) { - if (get_relfile(cmdtp, cfg->bmp, image_load_addr)) { - if (CONFIG_IS_ENABLED(CMD_CLS)) - run_command("cls", 0); - bmp_display(image_load_addr, - BMP_ALIGN_CENTER, BMP_ALIGN_CENTER); - } else { - printf("Skipping background bmp %s for failure\n", - cfg->bmp); + if (IS_ENABLED(CONFIG_CMD_BMP)) { + /* display BMP if available */ + if (cfg->bmp) { + if (get_relfile(cmdtp, cfg->bmp, image_load_addr)) { + if (CONFIG_IS_ENABLED(CMD_CLS)) + run_command("cls", 0); + bmp_display(image_load_addr, + BMP_ALIGN_CENTER, BMP_ALIGN_CENTER); + } else { + printf("Skipping background bmp %s for failure\n", + cfg->bmp); + } } } -#endif
m = pxe_menu_to_menu(cfg); if (!m)
On Tue, Feb 2, 2021 at 11:42 PM Kory Maincent kory.maincent@bootlin.com wrote:
Change since v4:
applied to u-boot-x86, thanks!
Hi Kory,
Change since v4:
- Loads fdt overlays specified in 'fdtoverlays'.
int err;
int err;
if (err < 0)
mac_str[0] = '\0';
if (err < 0)
mac_str[0] = '\0';
-#endif
There is actually no point in doing that...just leave it as it is. IS_ENABLED() is useful when we can move things to the compiler instead of the preprocessor.
else
else
-#endif
unmap_sysmem(buf);
if (cfg->bmp) {
} else {
cfg->bmp);
if (cfg->bmp) {
} else {
cfg->bmp);
-#endif
-- 2.17.1
On Wed, Feb 3, 2021 at 9:00 PM Simon Glass sjg@chromium.org wrote:
Hi Kory,
Change since v4:
int err;
int err;
if (err < 0)
mac_str[0] = '\0';
if (err < 0)
mac_str[0] = '\0';
-#endif
I will fix this up in the tree. Thanks!
Regards, Bin
Add "zboot" command to the list of supported boot in the label_boot function.
Signed-off-by: Kory Maincent kory.maincent@bootlin.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Change since v1: - Modify comment.
Change since v2: - Update do_zboot to do_zboot_parent function to follow the patch: 5588e776b0
Change since v3: - Follow review from Simon Glass - Add clean-up paches
cmd/pxe_utils.c | 3 +++ include/command.h | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c index e062c9edcf..4cf31119f4 100644 --- a/cmd/pxe_utils.c +++ b/cmd/pxe_utils.c @@ -655,6 +655,9 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) /* Try booting a Image */ else if (IS_ENABLED(CONFIG_CMD_BOOTZ)) do_bootz(cmdtp, 0, bootm_argc, bootm_argv); + /* Try booting an x86_64 Linux kernel image */ + else if (IS_ENABLED(CONFIG_CMD_ZBOOT)) + do_zboot_parent(cmdtp, 0, bootm_argc, bootm_argv, NULL);
unmap_sysmem(buf);
diff --git a/include/command.h b/include/command.h index 27604758a4..747f8f8095 100644 --- a/include/command.h +++ b/include/command.h @@ -165,6 +165,9 @@ int do_bootz(struct cmd_tbl *cmdtp, int flag, int argc, int do_booti(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
+int do_zboot_parent(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[], int *repeatable); + int common_diskboot(struct cmd_tbl *cmdtp, const char *intf, int argc, char *const argv[]);
Change since v1:
- Modify comment.
Change since v2:
Change since v3:
Change since v4:
Bin Meng
Kory Maincent
