[U-Boot] [PATCH 1/4] powerpc/85xx: Expanding the window of CCSRBAR in AS=1 from 4k to 1M
For an IFC Erratum (A-003399) we will need to access IFC registers in cpu_init_early_f() so expand the TLB covering CCSR to 1M.
Since we need a TLB to cover 1M we move to using TLB1 array for all the early mappings so we can cover various sizes beyond 4k.
Additionally removed volatile from ccsr_virt declaration as its not needed for IO accessors
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 25 +++++++++++++++++-------- 1 files changed, 17 insertions(+), 8 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index 32aa94b..97e8424 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -21,15 +21,24 @@ #include <asm/processor.h> #include <asm/mmu.h> #include <asm/fsl_law.h> +#include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR;
+/* + * We need a dummy virtual address to access the first 4k of CCSRBAR at. This + * virtual address is while we are in AS=1 address space and should not conflict + * with CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_CCSRBAR or CONFIG_SYS_MONITOR_BASE. + * We use 0x1000 to make sure NULL access still cause some fault error + */ +#define CCSRBAR_VIRT_DUMMY (0x1000) + #if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR_PHYS) #ifdef CONFIG_FSL_CORENET static void setup_ccsrbar(void) { u32 temp; - volatile u32 *ccsr_virt = (volatile u32 *)(CONFIG_SYS_CCSRBAR + 0x1000); + u32 *ccsr_virt = (u32 *)(CCSRBAR_VIRT_DUMMY); volatile ccsr_local_t *ccm;
/* @@ -60,7 +69,7 @@ static void setup_ccsrbar(void) static void setup_ccsrbar(void) { u32 temp; - volatile u32 *ccsr_virt = (volatile u32 *)(CONFIG_SYS_CCSRBAR + 0x1000); + u32 *ccsr_virt = (u32 *)(CCSRBAR_VIRT_DUMMY);
temp = in_be32(ccsr_virt); out_be32(ccsr_virt, CONFIG_SYS_CCSRBAR_PHYS >> 12); @@ -85,8 +94,8 @@ void cpu_init_early_f(void) for (i = 0; i < sizeof(gd_t); i++) ((char *)gd)[i] = 0;
- mas0 = MAS0_TLBSEL(0) | MAS0_ESEL(0); - mas1 = MAS1_VALID | MAS1_TID(0) | MAS1_TS | MAS1_TSIZE(BOOKE_PAGESZ_4K); + mas0 = MAS0_TLBSEL(1) | MAS0_ESEL(13); + mas1 = MAS1_VALID | MAS1_TID(0) | MAS1_TS | MAS1_TSIZE(BOOKE_PAGESZ_1M); mas2 = FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR, MAS2_I|MAS2_G); mas3 = FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_PHYS, 0, MAS3_SW|MAS3_SR); mas7 = FSL_BOOKE_MAS7(CONFIG_SYS_CCSRBAR_PHYS); @@ -95,9 +104,9 @@ void cpu_init_early_f(void)
/* set up CCSR if we want it moved */ #if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR_PHYS) - mas0 = MAS0_TLBSEL(0) | MAS0_ESEL(1); - /* mas1 is the same as above */ - mas2 = FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0x1000, MAS2_I|MAS2_G); + mas0 = MAS0_TLBSEL(1) | MAS0_ESEL(12); + mas1 = MAS1_VALID | MAS1_TID(0) | MAS1_TS | MAS1_TSIZE(BOOKE_PAGESZ_4K); + mas2 = FSL_BOOKE_MAS2(CCSRBAR_VIRT_DUMMY, MAS2_I|MAS2_G); mas3 = FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_DEFAULT, 0, MAS3_SW|MAS3_SR); mas7 = FSL_BOOKE_MAS7(CONFIG_SYS_CCSRBAR_DEFAULT);
@@ -107,6 +116,6 @@ void cpu_init_early_f(void) #endif
init_laws(); - invalidate_tlb(0); + invalidate_tlb(1); init_tlbs(); }
Issue: The NOR-FCM does not support access to unaligned addresses for 16 bit port size
Impact: When 16 bit port size is used, accesses not aligned to 16 bit address boundary will result in incorrect data
Workaround: The workaround is to switch to GPCM mode for NOR Flash access.
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/include/asm/config_mpc85xx.h | 2 ++ arch/powerpc/include/asm/fsl_ifc.h | 5 +++++ 3 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 7b9f773..446f759 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -87,6 +87,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) puts("Work-around for Erratum DDR111 enabled\n"); puts("Work-around for Erratum DDR134 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_IFC_A002769 + puts("Work-around for Erratum IFC-A002769 enabled\n"); +#endif return 0; }
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index aa0f312..ccd8246 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -112,6 +112,7 @@ #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +#define CONFIG_SYS_FSL_ERRATUM_IFC_A002769
/* P1011 is single core version of P1020 */ #elif defined(CONFIG_P1011) @@ -160,6 +161,7 @@ #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +#define CONFIG_SYS_FSL_ERRATUM_IFC_A002769
/* P1015 is single core version of P1024 */ #elif defined(CONFIG_P1015) diff --git a/arch/powerpc/include/asm/fsl_ifc.h b/arch/powerpc/include/asm/fsl_ifc.h index fb12363..7d95eb4 100644 --- a/arch/powerpc/include/asm/fsl_ifc.h +++ b/arch/powerpc/include/asm/fsl_ifc.h @@ -951,5 +951,10 @@ struct fsl_ifc { struct fsl_ifc_gpcm ifc_gpcm; };
+#ifdef CONFIG_SYS_FSL_ERRATUM_IFC_A002769 +#undef CSPR_MSEL_NOR +#define CSPR_MSEL_NOR CSPR_MSEL_GPCM +#endif + #endif /* __ASSEMBLY__ */ #endif /* __ASM_PPC_FSL_IFC_H */
Issue: Peripheral connected to IFC_CS3 may hamper booting from IFC.
Impact: Boot from IFC may not be successful if IFC_CS3 is used.
Workaround: If IFC_CS3 is used, gate IFC_CS3 while booting from NAND or NOR. Also Software should select IFC_CS3 using PMUXCR[26:27] = 0x01.
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 12 ++++++++++++ arch/powerpc/include/asm/config_mpc85xx.h | 2 ++ 3 files changed, 17 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 446f759..c2fb5b8 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -90,6 +90,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_IFC_A002769 puts("Work-around for Erratum IFC-A002769 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_P1010_A003549 + puts("Work-around for Erratum P1010-A003549 enabled\n"); +#endif return 0; }
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index 97e8424..05097b9 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -83,6 +83,9 @@ void cpu_init_early_f(void) { u32 mas0, mas1, mas2, mas3, mas7; int i; +#ifdef CONFIG_SYS_FSL_ERRATUM_P1010_A003549 + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); +#endif
/* Pointer is writable since we allocated a register for it */ gd = (gd_t *) (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET); @@ -115,6 +118,15 @@ void cpu_init_early_f(void) setup_ccsrbar(); #endif
+/* + * Work Around for IFC Erratum A-003549. This issue is P1010 + * specific. LCLK(a free running clk signal) is muxed with IFC_CS3 on P1010 SOC + * Hence specifically selecting CS3. + */ +#ifdef CONFIG_SYS_FSL_ERRATUM_P1010_A003549 + setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_LCLK_IFC_CS3); +#endif + init_laws(); invalidate_tlb(1); init_tlbs(); diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index ccd8246..171ea12 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -113,6 +113,7 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_IFC_A002769 +#define CONFIG_SYS_FSL_ERRATUM_P1010_A003549
/* P1011 is single core version of P1020 */ #elif defined(CONFIG_P1011) @@ -162,6 +163,7 @@ #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_IFC_A002769 +#define CONFIG_SYS_FSL_ERRATUM_P1010_A003549
Issue: Address masking doesn't work properly. When sum of the base address, defined by BA, and memory bank size, defined by AM, exceeds 4GB (0xffff_ffff) then AMASKn[AM] doesn't mask CSPRn[BA] bits.
Impact: This will impact booting when we are reprogramming CSPR0(BA) and AMASK0(AMASK) while executing from NOR Flash.
Workaround: Re-programming of CSPR(BA) and AMASK is done while not executing from NOR Flash. The code which programs the BA and AMASK is executed from L2-SRAM.
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 + arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 86 +++++++++++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/cpu_init_nand.c | 2 + arch/powerpc/cpu/mpc8xxx/fsl_ifc.c | 2 + arch/powerpc/include/asm/config_mpc85xx.h | 2 + 5 files changed, 95 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index c2fb5b8..0478ec1 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -93,6 +93,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_P1010_A003549 puts("Work-around for Erratum P1010-A003549 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_IFC_A003399 + puts("Work-around for Erratum IFC A-003399 enabled\n"); +#endif return 0; }
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index 05097b9..77c33bf 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -78,6 +78,42 @@ static void setup_ccsrbar(void) #endif #endif
+#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) && !defined(CONFIG_SYS_RAMBOOT) +void setup_ifc(void) +{ + struct fsl_ifc *ifc_regs = (void *)CONFIG_SYS_IFC_ADDR; + u32 _mas0, _mas1, _mas2, _mas3, _mas7; + phys_addr_t flash_phys = CONFIG_SYS_FLASH_BASE_PHYS; + + /* + * Adjust the TLB we were running out of to match the phys addr of the + * chip select we are adjusting and will return to. + */ + flash_phys += (~CONFIG_SYS_AMASK0) + 1 - 4*1024*1024; + + _mas0 = MAS0_TLBSEL(1) | MAS0_ESEL(15); + _mas1 = MAS1_VALID | MAS1_TID(0) | MAS1_TS | MAS1_IPROT | + MAS1_TSIZE(BOOKE_PAGESZ_4M); + _mas2 = FSL_BOOKE_MAS2(CONFIG_SYS_TEXT_BASE, MAS2_I|MAS2_G); + _mas3 = FSL_BOOKE_MAS3(flash_phys, 0, MAS3_SW|MAS3_SR|MAS3_SX); + _mas7 = FSL_BOOKE_MAS7(flash_phys); + + mtspr(MAS0, _mas0); + mtspr(MAS1, _mas1); + mtspr(MAS2, _mas2); + mtspr(MAS3, _mas3); + mtspr(MAS7, _mas7); + + asm volatile("isync;msync;tlbwe;isync"); + + out_be32(&(ifc_regs->cspr_cs[0].cspr), CONFIG_SYS_CSPR0); + out_be32(&(ifc_regs->csor_cs[0].csor), CONFIG_SYS_CSOR0); + out_be32(&(ifc_regs->amask_cs[0].amask), CONFIG_SYS_AMASK0); + + return ; +} +#endif + /* We run cpu_init_early_f in AS = 1 */ void cpu_init_early_f(void) { @@ -86,6 +122,11 @@ void cpu_init_early_f(void) #ifdef CONFIG_SYS_FSL_ERRATUM_P1010_A003549 ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif +#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) && !defined(CONFIG_SYS_RAMBOOT) + ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR; + u32 *l2srbar, *dst, *src; + void (*setup_ifc_sram)(void); +#endif
/* Pointer is writable since we allocated a register for it */ gd = (gd_t *) (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET); @@ -128,6 +169,51 @@ void cpu_init_early_f(void) #endif
init_laws(); + +/* + * Work Around for IFC Erratum A003399, issue will hit only when execution + * from NOR Flash + */ +#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) && !defined(CONFIG_SYS_RAMBOOT) +#define SRAM_BASE_ADDR (0x00000000) + /* TLB for SRAM */ + mas0 = MAS0_TLBSEL(1) | MAS0_ESEL(9); + mas1 = MAS1_VALID | MAS1_TID(0) | MAS1_TS | + MAS1_TSIZE(BOOKE_PAGESZ_1M); + mas2 = FSL_BOOKE_MAS2(SRAM_BASE_ADDR, MAS2_I); + mas3 = FSL_BOOKE_MAS3(SRAM_BASE_ADDR, 0, MAS3_SX|MAS3_SW|MAS3_SR); + mas7 = FSL_BOOKE_MAS7(0); + + write_tlb(mas0, mas1, mas2, mas3, mas7); + + out_be32(&l2cache->l2srbar0, SRAM_BASE_ADDR); + + out_be32(&l2cache->l2errdis, + (MPC85xx_L2ERRDIS_MBECC | MPC85xx_L2ERRDIS_SBECC)); + + out_be32(&l2cache->l2ctl, + (MPC85xx_L2CTL_L2E | MPC85xx_L2CTL_L2SRAM_ENTIRE)); + + /* + * Copy the code in setup_ifc to L2SRAM. Do a word copy + * because NOR Flash on P1010 does not support byte + * access (Erratum IFC-A002769) + */ + setup_ifc_sram = (void *)SRAM_BASE_ADDR; + dst = (u32 *) SRAM_BASE_ADDR; + src = (u32 *) setup_ifc; + for (i = 0; i < 1024; i++) + *l2srbar++ = *src++; + + setup_ifc_sram(); + + /* CLEANUP */ + clrbits_be32(&l2cache->l2ctl, + (MPC85xx_L2CTL_L2E | + MPC85xx_L2CTL_L2SRAM_ENTIRE)); + out_be32(&l2cache->l2srbar0, 0x0); +#endif + invalidate_tlb(1); init_tlbs(); } diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c b/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c index 6d01479..f33db02 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c @@ -43,12 +43,14 @@ void cpu_init_f(void) #endif #endif #ifdef CONFIG_FSL_IFC +#ifndef CONFIG_SYS_FSL_ERRATUM_IFC_A003399 #if defined(CONFIG_SYS_CSPR0) && defined(CONFIG_SYS_CSOR0) set_ifc_cspr(IFC_CS0, CONFIG_SYS_CSPR0); set_ifc_amask(IFC_CS0, CONFIG_SYS_AMASK0); set_ifc_csor(IFC_CS0, CONFIG_SYS_CSOR0); #endif #endif +#endif
#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L2_ADDR) ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR; diff --git a/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c b/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c index e794821..6682496 100644 --- a/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c +++ b/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c @@ -43,10 +43,12 @@ void init_early_memctl_regs(void) set_ifc_ftim(IFC_CS0, IFC_FTIM2, CONFIG_SYS_CS0_FTIM2); set_ifc_ftim(IFC_CS0, IFC_FTIM3, CONFIG_SYS_CS0_FTIM3);
+#if !defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) || defined(CONFIG_SYS_RAMBOOT) set_ifc_cspr(IFC_CS0, CONFIG_SYS_CSPR0); set_ifc_amask(IFC_CS0, CONFIG_SYS_AMASK0); set_ifc_csor(IFC_CS0, CONFIG_SYS_CSOR0); #endif +#endif
#if defined(CONFIG_SYS_CSPR1) && defined(CONFIG_SYS_CSOR1) set_ifc_ftim(IFC_CS1, IFC_FTIM0, CONFIG_SYS_CS1_FTIM0); diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 171ea12..eeb2b41 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -114,6 +114,7 @@ #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_IFC_A002769 #define CONFIG_SYS_FSL_ERRATUM_P1010_A003549 +#define CONFIG_SYS_FSL_ERRATUM_IFC_A003399
/* P1011 is single core version of P1020 */ #elif defined(CONFIG_P1011) @@ -164,6 +165,7 @@ #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_IFC_A002769 #define CONFIG_SYS_FSL_ERRATUM_P1010_A003549 +#define CONFIG_SYS_FSL_ERRATUM_IFC_A003399
Dear Kumar Gala,
In message 1312180248-28528-4-git-send-email-galak@kernel.crashing.org you wrote:
Checkpatch says:
ERROR: trailing whitespace #148: FILE: arch/powerpc/cpu/mpc85xx/cpu_init_early.c:95: +^I_mas1 = MAS1_VALID | MAS1_TID(0) | MAS1_TS | MAS1_IPROT | $
Please cleanup.
Kumar, could you __please__ get used to running your patches throuch checkpatch __before__ submitting? Thanks.
On Aug 1, 2011, at 5:21 AM, Wolfgang Denk wrote:
Dear Kumar Gala,
Checkpatch says:
Please cleanup.
I try to, but not all of them are by me ;)
Will be nice when have a version of checkpatch in u-boot source tree.
- k
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Fix whitespace issue
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index 05097b9..724c3cf 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -78,6 +78,42 @@ static void setup_ccsrbar(void) #endif #endif
Dear Kumar Gala,
In message 08144324-BE32-4A54-BC2D-B920F18F3D43@kernel.crashing.org you wrote:
I know. But you submitted them, so you are responsible.
Indeed. Submit a patch?
Kumar Gala
