[PATCH] Kconfig: hide options not intended for users in arch/Kconfig
Those options show up in menuconfig when selecting ARM or MIPS which is dangerous if a user accidently sets them. This also clutters up the menuconfig top-level screen. Because those options should only be set by SoC specific or board specific configs, make them invisible.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
arch/Kconfig | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 12de8a1165..e3e28d0628 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -365,7 +365,7 @@ config SYS_DISABLE_DCACHE_OPS this functionality.
config SYS_IMMR - hex "Address for the Internal Memory-Mapped Registers (IMMR) window" + hex depends on PPC || FSL_LSCH2 || FSL_LSCH3 || ARCH_LS1021A default 0xFF000000 if MPC8xx default 0xF0000000 if ARCH_MPC8313 @@ -377,7 +377,7 @@ config SYS_IMMR to configure the features of many Freescale / NXP SoCs.
config SKIP_LOWLEVEL_INIT - bool "Skip the calls to certain low level initialization functions" + bool depends on ARM || MIPS || RISCV help If enabled, then certain low level initializations (like setting up @@ -388,7 +388,7 @@ config SKIP_LOWLEVEL_INIT debugger which performs these initializations itself.
config SPL_SKIP_LOWLEVEL_INIT - bool "Skip the calls to certain low level initialization functions" + bool depends on SPL && (ARM || MIPS || RISCV) help If enabled, then certain low level initializations (like setting up @@ -399,7 +399,7 @@ config SPL_SKIP_LOWLEVEL_INIT debugger which performs these initializations itself.
config TPL_SKIP_LOWLEVEL_INIT - bool "Skip the calls to certain low level initialization functions" + bool depends on SPL && ARM help If enabled, then certain low level initializations (like setting up @@ -410,7 +410,7 @@ config TPL_SKIP_LOWLEVEL_INIT debugger which performs these initializations itself.
config SKIP_LOWLEVEL_INIT_ONLY - bool "Skip the call to lowlevel_init during early boot ONLY" + bool depends on ARM help This allows just the call to lowlevel_init() to be skipped. The @@ -418,7 +418,7 @@ config SKIP_LOWLEVEL_INIT_ONLY performed.
config SPL_SKIP_LOWLEVEL_INIT_ONLY - bool "Skip the call to lowlevel_init during early boot ONLY" + bool depends on SPL && ARM help This allows just the call to lowlevel_init() to be skipped. The @@ -426,7 +426,7 @@ config SPL_SKIP_LOWLEVEL_INIT_ONLY performed.
config TPL_SKIP_LOWLEVEL_INIT_ONLY - bool "Skip the call to lowlevel_init during early boot ONLY" + bool depends on TPL && ARM help This allows just the call to lowlevel_init() to be skipped. The
config SYS_IMMR
- hex depends on PPC || FSL_LSCH2 || FSL_LSCH3 || ARCH_LS1021A default 0xFF000000 if MPC8xx default 0xF0000000 if ARCH_MPC8313
But now these aren't user selectable on the right platforms either. Maybe we need more menu organization, and so can have sub-menus depend on PPC, or whatever, and so things aren't cluttered on other architectures?
config SYS_IMMR
my main concern was with SKIP_LOWLEVEL_INIT which definitely should not be selectable by the user. Maybe I was to overambitious with changing the SYS_IMMR option too, I could revert that part ;)
BTW: SYS_IMMR seems to be specific for PPC. Maybe it could be moved to arch/powerpc/Kconfig?
diff --git a/arch/Kconfig b/arch/Kconfig index 12de8a1165..e3e28d0628 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -365,7 +365,7 @@ config SYS_DISABLE_DCACHE_OPS this functionality. config SYS_IMMR
I'd be agreeable to a patch that makes everyone that enables it today select it instead.
It's PowerPC or the 64bit ARM Layerscape platforms. There's I think only several imperfect places today for the options that are present in both due to the IP blocks / etc being updated by NXP for use in their current ARM HW.
I'll look into it. Would moving this to top-level Kconfig and the "General setup" menu be an option?
Sure. Note that it's only used on ARM and some MIPS platforms today, so we could also tighten the dependncy line.
Daniel Schwierzeck
