[U-Boot] [PATCH 1/1] DaVinci: Fix DM365 & DM644X build error
DM365 & DM644X builds 'davinci_emac_mii_mode_sel()', which uses 'davinci_syscfg_regs' macro, and the macro is valid iff CONFIG_SOC_DA8XX is defined.
Fix: Before compiling 'davinci_emac_mii_mode_sel()', make sure that CONFIG_SOC_DA8XX is defined.
Signed-off-by: Mohammed Afzal afzal@ti.com --- board/davinci/common/misc.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/davinci/common/misc.c b/board/davinci/common/misc.c index 08c898f..c0a6c41 100644 --- a/board/davinci/common/misc.c +++ b/board/davinci/common/misc.c @@ -80,7 +80,7 @@ err: /* * Set the mii mode as MII or RMII */ -#if defined(CONFIG_DRIVER_TI_EMAC) +#if defined(CONFIG_DRIVER_TI_EMAC) && defined(CONFIG_SOC_DA8XX) void davinci_emac_mii_mode_sel(int mode_sel) { int val;
Le 20/01/2011 12:27, Mohammed Afzal a écrit :
DM365& DM644X builds 'davinci_emac_mii_mode_sel()', which uses 'davinci_syscfg_regs' macro, and the macro is valid iff CONFIG_SOC_DA8XX is defined.
Signed-off-by: Mohammed Afzalafzal@ti.com
- Set the mii mode as MII or RMII
*/ -#if defined(CONFIG_DRIVER_TI_EMAC) +#if defined(CONFIG_DRIVER_TI_EMAC)&& defined(CONFIG_SOC_DA8XX) void davinci_emac_mii_mode_sel(int mode_sel) { int val;
Seems this is already fixed by commit 51861a953aa10fde5c861ca022f0833f326e3041 which is in u-boot-ti/master, right?
Amicalement,
Yes that is correct I believe. Before my vacation I was getting the entire Davinci series of SOCs compiling as they were broken for various reasons and this is one of the fixes I had made IIRC.
This commit should be in u-boot-arm/master as well
--Sandeep
Albert ARIBAUD
Mohammed Afzal
Paulraj, Sandeep
