[PATCH 1/1] scripts: add documentation-file-ref-check
'make refcheckdocs' requires scripts/documentation-file-ref-check. Adopt script from Linux v5.6-rc3.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- scripts/documentation-file-ref-check | 226 +++++++++++++++++++++++++++ 1 file changed, 226 insertions(+) create mode 100755 scripts/documentation-file-ref-check
diff --git a/scripts/documentation-file-ref-check b/scripts/documentation-file-ref-check new file mode 100755 index 0000000000..9978fc9a91 --- /dev/null +++ b/scripts/documentation-file-ref-check @@ -0,0 +1,226 @@ +#!/usr/bin/env perl +# SPDX-License-Identifier: GPL-2.0 +# +# Treewide grep for references to files under doc, and report +# non-existing files in stderr. + +use warnings; +use strict; +use Getopt::Long qw(:config no_auto_abbrev); + +# NOTE: only add things here when the file was gone, but the text wants +# to mention a past documentation file, for example, to give credits for +# the original work. +my %false_positives = ( +); + +my $scriptname = $0; +$scriptname =~ s,.*/([^/]+/),$1,; + +# Parse arguments +my $help = 0; +my $fix = 0; +my $warn = 0; + +if (! -d ".git") { + printf "Warning: can't check if file exists, as this is not a git tree"; + exit 0; +} + +GetOptions( + 'fix' => $fix, + 'warn' => $warn, + 'h|help|usage' => $help, +); + +if ($help != 0) { + print "$scriptname [--help] [--fix]\n"; + exit -1; +} + +# Step 1: find broken references +print "Finding broken references. This may take a while... " if ($fix); + +my %broken_ref; + +my $doc_fix = 0; + +open IN, "git grep ':doc:`' doc/|" + or die "Failed to run git grep"; +while (<IN>) { + next if (!m,^([^:]+):.*:doc:`([^`]+)`,); + + my $d = $1; + my $doc_ref = $2; + + my $f = $doc_ref; + + $d =~ s,(.*/).*,$1,; + $f =~ s,.*<([^>]+)>,$1,; + + $f ="$d$f.rst"; + + next if (grep -e, glob("$f")); + + if ($fix && !$doc_fix) { + print STDERR "\nWARNING: Currently, can't fix broken :doc:`` fields\n"; + } + $doc_fix++; + + print STDERR "$f: :doc:`$doc_ref`\n"; +} +close IN; + +open IN, "git grep 'doc/'|" + or die "Failed to run git grep"; +while (<IN>) { + next if (!m/^([^:]+):(.*)/); + + my $f = $1; + my $ln = $2; + + # On linux-next, discard the Next/ directory + next if ($f =~ m,^Next/,); + + # Makefiles and scripts contain nasty expressions to parse docs + next if ($f =~ m/Makefile/ || $f =~ m/.sh$/); + + # Skip this script + next if ($f eq $scriptname); + + # Ignore the dir where documentation will be built + next if ($ln =~ m,\b(\S*)doc/output,); + + if ($ln =~ m,\b(\S*)(doc/[A-Za-z0-9_.,~/*[]?+-]*)(.*),) { + my $prefix = $1; + my $ref = $2; + my $base = $2; + my $extra = $3; + + # some file references are like: + # /usr/src/linux/doc/DMA-{API,mapping}.txt + # For now, ignore them + next if ($extra =~ m/^{/); + + # Remove footnotes at the end like: + # doc/devicetree/dt-object-internal.txt[1] + $ref =~ s/(txt|rst)[\d+]$/$1/; + + # Remove ending ']' without any '[' + $ref =~ s/].*// if (!($ref =~ m/[/)); + + # Remove puntuation marks at the end + $ref =~ s/[,.]+$//; + + my $fulref = "$prefix$ref"; + + $fulref =~ s/^(<file|ref)://; + $fulref =~ s/^['`]+//; + $fulref =~ s,^$(.*)/,,; + $base =~ s,.*/,,; + + # Remove URL false-positives + next if ($fulref =~ m/^http/); + + # Check if exists, evaluating wildcards + next if (grep -e, glob("$ref $fulref")); + + # Accept relative doc patches for tools/ + if ($f =~ m/tools/) { + my $path = $f; + $path =~ s,(.*)/.*,$1,; + next if (grep -e, glob("$path/$ref $path/../$ref $path/$fulref")); + } + + # Discard known false-positives + if (defined($false_positives{$f})) { + next if ($false_positives{$f} eq $fulref); + } + + if ($fix) { + if (!($ref =~ m/(scripts|Kconfig|Kbuild)/)) { + $broken_ref{$ref}++; + } + } elsif ($warn) { + print STDERR "Warning: $f references a file that doesn't exist: $fulref\n"; + } else { + print STDERR "$f: $fulref\n"; + } + } +} +close IN; + +exit 0 if (!$fix); + +# Step 2: Seek for file name alternatives +print "Auto-fixing broken references. Please double-check the results\n"; + +foreach my $ref (keys %broken_ref) { + my $new =$ref; + + my $basedir = "."; + # On translations, only seek inside the translations directory + $basedir = $1 if ($ref =~ m,(doc/translations/[^/]+),); + + # get just the basename + $new =~ s,.*/,,; + + my $f=""; + + # usual reason for breakage: DT file moved around + if ($ref =~ /devicetree/) { + # usual reason for breakage: DT file renamed to .yaml + if (!$f) { + my $new_ref = $ref; + $new_ref =~ s/.txt$/.yaml/; + $f=$new_ref if (-f $new_ref); + } + + if (!$f) { + my $search = $new; + $search =~ s,^.*/,,; + $f = qx(find doc/devicetree/ -iname "*$search*") if ($search); + if (!$f) { + # Manufacturer name may have changed + $search =~ s/^.*,//; + $f = qx(find doc/devicetree/ -iname "*$search*") if ($search); + } + } + } + + # usual reason for breakage: file renamed to .rst + if (!$f) { + $new =~ s/.txt$/.rst/; + $f=qx(find $basedir -iname $new) if ($new); + } + + # usual reason for breakage: use dash or underline + if (!$f) { + $new =~ s/[-_]/[-_]/g; + $f=qx(find $basedir -iname $new) if ($new); + } + + # Wild guess: seek for the same name on another place + if (!$f) { + $f = qx(find $basedir -iname $new) if ($new); + } + + my @find = split /\s+/, $f; + + if (!$f) { + print STDERR "ERROR: Didn't find a replacement for $ref\n"; + } elsif (scalar(@find) > 1) { + print STDERR "WARNING: Won't auto-replace, as found multiple files close to $ref:\n"; + foreach my $j (@find) { + $j =~ s,^./,,; + print STDERR " $j\n"; + } + } else { + $f = $find[0]; + $f =~ s,^./,,; + print "INFO: Replacing $ref to $f\n"; + foreach my $j (qx(git grep -l $ref)) { + qx(sed "s@$ref@$f@g" -i $j); + } + } +} -- 2.25.0
Hi Heinrich,
From: Heinrich Schuchardt xypron.glpk@gmx.de Sent: mardi 25 février 2020 20:52
Reviewed-by: Patrick Delaunay Patrick.delaunay@st.com
It is just a copy of kernel script with + "/Documentation" => "/doc" + remove kernel specific rules
Just 2 remarks on ftp and binding directory (for --fix option)
diff --git a/scripts/documentation-file-ref-check b/scripts/documentation-file-ref- check new file mode 100755 index 0000000000..9978fc9a91 --- /dev/null +++ b/scripts/documentation-file-ref-check @@ -0,0 +1,226 @@ +#!/usr/bin/env perl +# SPDX-License-Identifier: GPL-2.0 +# +# Treewide grep for references to files under doc, and report # +non-existing files in stderr.
+# NOTE: only add things here when the file was gone, but the text wants +# to mention a past documentation file, for example, to give credits +for # the original work. +my %false_positives = ( +);
+if (! -d ".git") {
- printf "Warning: can't check if file exists, as this is not a git tree";
- exit 0;
+GetOptions(
- 'fix' => $fix,
- 'warn' => $warn,
- 'h|help|usage' => $help,
+if ($help != 0) {
- print "$scriptname [--help] [--fix]\n";
- exit -1;
+# Step 1: find broken references +print "Finding broken references. This may take a while... " if +($fix);
+my %broken_ref;
+my $doc_fix = 0;
+while (<IN>) {
- next if (!m,^([^:]+):.*:doc:`([^`]+)`,);
- my $d = $1;
- my $doc_ref = $2;
- my $f = $doc_ref;
- $d =~ s,(.*/).*,$1,;
- $f =~ s,.*<([^>]+)>,$1,;
- $f ="$d$f.rst";
- next if (grep -e, glob("$f"));
- if ($fix && !$doc_fix) {
fields\n";
- $doc_fix++;
- print STDERR "$f: :doc:`$doc_ref`\n";
+} +close IN;
+while (<IN>) {
- next if (!m/^([^:]+):(.*)/);
- my $f = $1;
- my $ln = $2;
- # On linux-next, discard the Next/ directory
- next if ($f =~ m,^Next/,);
- # Makefiles and scripts contain nasty expressions to parse docs
- next if ($f =~ m/Makefile/ || $f =~ m/.sh$/);
- # Skip this script
- next if ($f eq $scriptname);
- # Ignore the dir where documentation will be built
- next if ($ln =~ m,\b(\S*)doc/output,);
- if ($ln =~ m,\b(\S*)(doc/[A-Za-z0-9_.,~/*[]?+-]*)(.*),) {
my $prefix = $1;
my $ref = $2;
my $base = $2;
my $extra = $3;
$ref =~ s/(txt|rst)\[\d+]$/$1/;
$ref =~ s/\].*// if (!($ref =~ m/\[/));
$ref =~ s/[\,\.]+$//;
$fulref =~ s/^(\<file|ref)://;
$fulref =~ s/^[\'\`]+//;
$fulref =~ s,^\$\(.*\)/,,;
$base =~ s,.*/,,;
next if ($fulref =~ m/^ftp/);
To avoid issue on ftp URL =
include/ata.h: ftp://ftp.fee.vutbr.cz/pub/doc/io/ata/ata-3/ata3r5v.zip lib/zlib/trees.c: ftp.uu.net:/pub/archiving/zip/doc/deflate-1.1.do
my $path = $f;
$path/$fulref"));
if ($fix) {
} elsif ($warn) {
exist: $fulref\n";
} else {
+} +close IN;
+exit 0 if (!$fix);
+# Step 2: Seek for file name alternatives print "Auto-fixing broken +references. Please double-check the results\n";
- my $new =$ref;
- my $basedir = ".";
- # On translations, only seek inside the translations directory
- $basedir = $1 if ($ref =~ m,(doc/translations/[^/]+),);
- # get just the basename
- $new =~ s,.*/,,;
- my $f="";
- # usual reason for breakage: DT file moved around
- if ($ref =~ /devicetree/) {
if (!$f) {
my $new_ref = $ref;
$new_ref =~ s/\.txt$/.yaml/;
if (!$f) {
my $search = $new;
($search);
No "devicetree/ bindings/" directory in U-boot => I think "doc/device-tree-bindings/" should be used here
+ $f = qx(find doc/device-tree-bindings/ -iname "*$search*") if ($search);
if (!$f) {
($search);
- # usual reason for breakage: file renamed to .rst
- if (!$f) {
$new =~ s/\.txt$/.rst/;
- # usual reason for breakage: use dash or underline
- if (!$f) {
- # Wild guess: seek for the same name on another place
- if (!$f) {
- my @find = split /\s+/, $f;
- if (!$f) {
- } elsif (scalar(@find) > 1) {
$j =~ s,^./,,;
- } else {
$f = $find[0];
$f =~ s,^./,,;
qx(sed "s\@$ref\@$f\@g" -i $j);
2.25.0
Regard,
Patrick
On 2/28/20 2:24 PM, Patrick DELAUNAY wrote:
Hi Heinrich,
- "/Documentation" => "/doc"
- remove kernel specific rules
+if (! -d ".git") {
- exit 0;
+GetOptions(
- 'fix' => $fix,
- 'warn' => $warn,
+if ($help != 0) {
- exit -1;
+my %broken_ref;
+my $doc_fix = 0;
+while (<IN>) {
- my $d = $1;
- my $doc_ref = $2;
- my $f = $doc_ref;
- $f ="$d$f.rst";
fields\n";
- $doc_fix++;
+} +close IN;
+while (<IN>) {
- my $f = $1;
- my $ln = $2;
my $prefix = $1;
my $ref = $2;
my $base = $2;
my $extra = $3;
$base =~ s,.*/,,;
The servers have no DNS entry. Anyway the FTP protocol is at end of life:
Cf."Intent to Deprecate: FTP Support" https://docs.google.com/document/d/1JUra5HnsbR_xmtQctkb2iVxRPuhPWhMB5M_zpbuG...
Cf. [PATCH v2 1/1] include/ata.h: remove invalid links https://lists.denx.de/pipermail/u-boot/2020-February/401324.html
my $path = $f;
$path/$fulref"));
if ($fix) {
} elsif ($warn) {
exist: $fulref\n";
} else {
+} +close IN;
+exit 0 if (!$fix);
- my $new =$ref;
- $new =~ s,.*/,,;
- my $f="";
if (!$f) {
my $new_ref = $ref;
if (!$f) {
my $search = $new;
($search);
Yes, this should be changed.
if (!$f) {
($search);
Same here.
Best regards
Heinrich
- if (!$f) {
- if (!$f) {
- if (!$f) {
- if (!$f) {
$j =~ s,^./,,;
- } else {
$f = $find[0];
$f =~ s,^./,,;
2.25.0
Regard,
Patrick
Patrick DELAUNAY
