[U-Boot] [PATCH 0/3] mmc: sdhci: Add support for frequency constrained peripheral interfaces
The sdhci controller assumes that the base clock frequency is fully supported by the peripheral and doesn't support hardware limitations. Distinguish between base clock of the host controller and maximal supported peripheral clock frequency of the peripheral interface. This is needed for the zynq platform to support two sdhci ports with different IO routings.
Stefan Herbrechtsmeier (3): mmc: sdhci: Distinguish between base clock and maximum peripheral frequency mmc: zynq: Determine base clock frequency via clock framework mmc: zynq: Add fdt max-frequency support
arch/arm/mach-zynq/clk.c | 23 ++++++++++++++++++++ arch/arm/mach-zynq/include/mach/clk.h | 1 + drivers/mmc/atmel_sdhci.c | 7 ++++-- drivers/mmc/bcm2835_sdhci.c | 3 ++- drivers/mmc/ftsdc021_sdhci.c | 3 ++- drivers/mmc/kona_sdhci.c | 3 ++- drivers/mmc/msm_sdhci.c | 2 ++ drivers/mmc/mv_sdhci.c | 3 ++- drivers/mmc/pci_mmc.c | 1 + drivers/mmc/pic32_sdhci.c | 4 +++- drivers/mmc/rockchip_sdhci.c | 4 ++-- drivers/mmc/s5p_sdhci.c | 5 +++-- drivers/mmc/sdhci.c | 28 ++++++++++++------------ drivers/mmc/spear_sdhci.c | 3 ++- drivers/mmc/zynq_sdhci.c | 40 ++++++++++++++++++++++++++++++++++- include/sdhci.h | 13 ++++++------ 16 files changed, 111 insertions(+), 32 deletions(-)
The sdhci controller assumes that the base clock frequency is fully supported by the peripheral and doesn't support hardware limitations. The Linux kernel distinguishes between base clock (max_clk) of the host controller and maximum frequency (f_max) of the card interface. Use the same differentiation and allow the platform to constrain the peripheral interface.
Signed-off-by: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.de ---
drivers/mmc/atmel_sdhci.c | 7 +++++-- drivers/mmc/bcm2835_sdhci.c | 3 ++- drivers/mmc/ftsdc021_sdhci.c | 3 ++- drivers/mmc/kona_sdhci.c | 3 ++- drivers/mmc/msm_sdhci.c | 2 ++ drivers/mmc/mv_sdhci.c | 3 ++- drivers/mmc/pci_mmc.c | 1 + drivers/mmc/pic32_sdhci.c | 4 +++- drivers/mmc/rockchip_sdhci.c | 4 ++-- drivers/mmc/s5p_sdhci.c | 5 +++-- drivers/mmc/sdhci.c | 28 +++++++++++++++------------- drivers/mmc/spear_sdhci.c | 3 ++- drivers/mmc/zynq_sdhci.c | 4 +++- include/sdhci.h | 13 +++++++------ 14 files changed, 51 insertions(+), 32 deletions(-)
diff --git a/drivers/mmc/atmel_sdhci.c b/drivers/mmc/atmel_sdhci.c index 6654b54..62cb242 100644 --- a/drivers/mmc/atmel_sdhci.c +++ b/drivers/mmc/atmel_sdhci.c @@ -35,8 +35,9 @@ int atmel_sdhci_init(void *regbase, u32 id) free(host); return -ENODEV; } + host->max_clk = max_clk;
- add_sdhci(host, max_clk, min_clk); + add_sdhci(host, 0, min_clk);
return 0; } @@ -95,7 +96,9 @@ static int atmel_sdhci_probe(struct udevice *dev) if (!max_clk) return -EINVAL;
- ret = sdhci_setup_cfg(&plat->cfg, host, max_clk, ATMEL_SDHC_MIN_FREQ); + host->max_clk = max_clk; + + ret = sdhci_setup_cfg(&plat->cfg, host, 0, ATMEL_SDHC_MIN_FREQ); if (ret) return ret;
diff --git a/drivers/mmc/bcm2835_sdhci.c b/drivers/mmc/bcm2835_sdhci.c index cb2bd40..29c2a85 100644 --- a/drivers/mmc/bcm2835_sdhci.c +++ b/drivers/mmc/bcm2835_sdhci.c @@ -181,10 +181,11 @@ int bcm2835_sdhci_init(u32 regbase, u32 emmc_freq) host->ioaddr = (void *)(unsigned long)regbase; host->quirks = SDHCI_QUIRK_BROKEN_VOLTAGE | SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_NO_HISPD_BIT; + host->max_clk = emmc_freq; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; host->ops = &bcm2835_ops;
- add_sdhci(host, emmc_freq, MIN_FREQ); + add_sdhci(host, 0, MIN_FREQ);
return 0; } diff --git a/drivers/mmc/ftsdc021_sdhci.c b/drivers/mmc/ftsdc021_sdhci.c index 6e9fefa..4940ccb 100644 --- a/drivers/mmc/ftsdc021_sdhci.c +++ b/drivers/mmc/ftsdc021_sdhci.c @@ -27,7 +27,8 @@ int ftsdc021_sdhci_init(u32 regbase) host->name = "FTSDC021"; host->ioaddr = (void __iomem *)regbase; host->quirks = 0; - add_sdhci(host, freq, 0); + host->max_clk = freq; + add_sdhci(host, 0, 0);
return 0; } diff --git a/drivers/mmc/kona_sdhci.c b/drivers/mmc/kona_sdhci.c index 549f6bc..ddd821b 100644 --- a/drivers/mmc/kona_sdhci.c +++ b/drivers/mmc/kona_sdhci.c @@ -121,12 +121,13 @@ int kona_sdhci_init(int dev_index, u32 min_clk, u32 quirks) host->name = "kona-sdhci"; host->ioaddr = reg_base; host->quirks = quirks; + host->max_clk = max_clk;
if (init_kona_mmc_core(host)) { free(host); return -EINVAL; }
- add_sdhci(host, max_clk, min_clk); + add_sdhci(host, 0, min_clk); return ret; } diff --git a/drivers/mmc/msm_sdhci.c b/drivers/mmc/msm_sdhci.c index f33714b..1db683d 100644 --- a/drivers/mmc/msm_sdhci.c +++ b/drivers/mmc/msm_sdhci.c @@ -96,6 +96,8 @@ static int msm_sdc_probe(struct udevice *dev)
host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_BROKEN_R1B;
+ host->max_clk = 0; + /* Init clocks */ ret = msm_sdc_clk_init(dev); if (ret) diff --git a/drivers/mmc/mv_sdhci.c b/drivers/mmc/mv_sdhci.c index e388ad1..69aa87b 100644 --- a/drivers/mmc/mv_sdhci.c +++ b/drivers/mmc/mv_sdhci.c @@ -77,6 +77,7 @@ int mv_sdh_init(unsigned long regbase, u32 max_clk, u32 min_clk, u32 quirks) host->name = MVSDH_NAME; host->ioaddr = (void *)regbase; host->quirks = quirks; + host->max_clk = max_clk; #ifdef CONFIG_MMC_SDHCI_IO_ACCESSORS memset(&mv_ops, 0, sizeof(struct sdhci_ops)); mv_ops.write_b = mv_sdhci_writeb; @@ -88,5 +89,5 @@ int mv_sdh_init(unsigned long regbase, u32 max_clk, u32 min_clk, u32 quirks) sdhci_mvebu_mbus_config((void __iomem *)regbase); }
- return add_sdhci(host, max_clk, min_clk); + return add_sdhci(host, 0, min_clk); } diff --git a/drivers/mmc/pci_mmc.c b/drivers/mmc/pci_mmc.c index 3d587cc..e39b476 100644 --- a/drivers/mmc/pci_mmc.c +++ b/drivers/mmc/pci_mmc.c @@ -32,6 +32,7 @@ int pci_mmc_init(const char *name, struct pci_device_id *mmc_supported) dm_pci_read_config32(dev, PCI_BASE_ADDRESS_0, &iobase); mmc_host->ioaddr = (void *)(ulong)iobase; mmc_host->quirks = 0; + mmc_host->max_clk = 0; ret = add_sdhci(mmc_host, 0, 0); if (ret) return ret; diff --git a/drivers/mmc/pic32_sdhci.c b/drivers/mmc/pic32_sdhci.c index 2abf943..c562aec 100644 --- a/drivers/mmc/pic32_sdhci.c +++ b/drivers/mmc/pic32_sdhci.c @@ -41,7 +41,9 @@ static int pic32_sdhci_probe(struct udevice *dev) return ret; }
- ret = add_sdhci(host, f_min_max[1], f_min_max[0]); + host->max_clk = f_min_max[1]; + + ret = add_sdhci(host, 0, f_min_max[0]); if (ret) return ret; host->mmc->dev = dev; diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index c56e1a3..4456a02 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -35,9 +35,9 @@ static int arasan_sdhci_probe(struct udevice *dev) int ret;
host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD; + host->max_clk = CONFIG_ROCKCHIP_SDHCI_MAX_FREQ;
- ret = sdhci_setup_cfg(&plat->cfg, host, CONFIG_ROCKCHIP_SDHCI_MAX_FREQ, - EMMC_MIN_FREQ); + ret = sdhci_setup_cfg(&plat->cfg, host, 0, EMMC_MIN_FREQ);
host->mmc = &plat->mmc; if (ret) diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index b329bef..50bd8dc 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -80,6 +80,7 @@ static int s5p_sdhci_core_init(struct sdhci_host *host) host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | SDHCI_QUIRK_32BIT_DMA_ADDR | SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_USE_WIDE8; + host->max_clk = 52000000; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195;
host->set_control_reg = &s5p_sdhci_set_control_reg; @@ -89,7 +90,7 @@ static int s5p_sdhci_core_init(struct sdhci_host *host) host->host_caps |= MMC_MODE_8BIT;
#ifndef CONFIG_BLK - return add_sdhci(host, 52000000, 400000); + return add_sdhci(host, 0, 400000); #else return 0; #endif @@ -245,7 +246,7 @@ static int s5p_sdhci_probe(struct udevice *dev) if (ret) return ret;
- ret = sdhci_setup_cfg(&plat->cfg, host, 52000000, 400000); + ret = sdhci_setup_cfg(&plat->cfg, host, 0, 400000); if (ret) return ret;
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 766e9ee..d57c4dc 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -325,7 +325,7 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) */ if (host->clk_mul) { for (div = 1; div <= 1024; div++) { - if ((mmc->cfg->f_max * host->clk_mul / div) + if ((host->max_clk * host->clk_mul / div) <= clock) break; } @@ -338,13 +338,13 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) div--; } else { /* Version 3.00 divisors must be a multiple of 2. */ - if (mmc->cfg->f_max <= clock) { + if (host->max_clk <= clock) { div = 1; } else { for (div = 2; div < SDHCI_MAX_DIV_SPEC_300; div += 2) { - if ((mmc->cfg->f_max / div) <= clock) + if ((host->max_clk / div) <= clock) break; } } @@ -353,7 +353,7 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) } else { /* Version 2.00 divisors must be a power of 2. */ for (div = 1; div < SDHCI_MAX_DIV_SPEC_200; div *= 2) { - if ((mmc->cfg->f_max / div) <= clock) + if ((host->max_clk / div) <= clock) break; } div >>= 1; @@ -557,22 +557,24 @@ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, #ifndef CONFIG_DM_MMC_OPS cfg->ops = &sdhci_ops; #endif - if (max_clk) - cfg->f_max = max_clk; - else { + if (host->max_clk == 0) { if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) - cfg->f_max = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> + host->max_clk = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT; else - cfg->f_max = (caps & SDHCI_CLOCK_BASE_MASK) >> + host->max_clk = (caps & SDHCI_CLOCK_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT; - cfg->f_max *= 1000000; + host->max_clk *= 1000000; } - if (cfg->f_max == 0) { + if (host->max_clk == 0) { printf("%s: Hardware doesn't specify base clock frequency\n", __func__); return -EINVAL; } + if (max_clk && (max_clk < host->max_clk)) + cfg->f_max = max_clk; + else + cfg->f_max = host->max_clk; if (min_clk) cfg->f_min = min_clk; else { @@ -623,11 +625,11 @@ int sdhci_bind(struct udevice *dev, struct mmc *mmc, struct mmc_config *cfg) return mmc_bind(dev, mmc, cfg); } #else -int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) +int add_sdhci(struct sdhci_host *host, u32 f_max, u32 f_min) { int ret;
- ret = sdhci_setup_cfg(&host->cfg, host, max_clk, min_clk); + ret = sdhci_setup_cfg(&host->cfg, host, f_max, f_min); if (ret) return ret;
diff --git a/drivers/mmc/spear_sdhci.c b/drivers/mmc/spear_sdhci.c index 06179cd..d3f8669 100644 --- a/drivers/mmc/spear_sdhci.c +++ b/drivers/mmc/spear_sdhci.c @@ -21,7 +21,8 @@ int spear_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks) host->name = "sdhci"; host->ioaddr = (void *)regbase; host->quirks = quirks; + host->max_clk = max_clk;
- add_sdhci(host, max_clk, min_clk); + add_sdhci(host, 0, min_clk); return 0; } diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 3da1385..69efa38 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -36,7 +36,9 @@ static int arasan_sdhci_probe(struct udevice *dev) host->quirks |= SDHCI_QUIRK_NO_HISPD_BIT; #endif
- ret = sdhci_setup_cfg(&plat->cfg, host, CONFIG_ZYNQ_SDHCI_MAX_FREQ, + host->max_clk = CONFIG_ZYNQ_SDHCI_MAX_FREQ; + + ret = sdhci_setup_cfg(&plat->cfg, host, 0, CONFIG_ZYNQ_SDHCI_MIN_FREQ); host->mmc = &plat->mmc; if (ret) diff --git a/include/sdhci.h b/include/sdhci.h index 144570f..6c9f7a7 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -243,6 +243,7 @@ struct sdhci_host { unsigned int quirks; unsigned int host_caps; unsigned int version; + unsigned int max_clk; /* Maximum Base Clock frequency */ unsigned int clk_mul; /* Clock Multiplier value */ unsigned int clock; struct mmc *mmc; @@ -372,11 +373,11 @@ static inline u8 sdhci_readb(struct sdhci_host *host, int reg) * * @cfg: Configuration structure to fill in (generally &plat->mmc) * @host: SDHCI host structure - * @max_clk: Maximum supported clock speed in HZ (0 for default) - * @min_clk: Minimum supported clock speed in HZ (0 for default) + * @f_max: Maximum supported clock frequency in HZ (0 for default) + * @f_min: Minimum supported clock frequency in HZ (0 for default) */ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, - u32 max_clk, u32 min_clk); + u32 f_max, u32 f_min);
/** * sdhci_bind() - Set up a new MMC block device @@ -402,11 +403,11 @@ int sdhci_bind(struct udevice *dev, struct mmc *mmc, struct mmc_config *cfg); * This is used when you are not using CONFIG_BLK. Convert your driver over! * * @host: SDHCI host structure - * @max_clk: Maximum supported clock speed in HZ (0 for default) - * @min_clk: Minimum supported clock speed in HZ (0 for default) + * @f_max: Maximum supported clock frequency in HZ (0 for default) + * @f_min: Minimum supported clock frequency in HZ (0 for default) * @return 0 if OK, -ve on error */ -int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk); +int add_sdhci(struct sdhci_host *host, u32 f_max, u32 f_min); #endif /* !CONFIG_BLK */
#ifdef CONFIG_DM_MMC_OPS
Hi Stefan,
Are there issues for not distinguishing clocks?
Best Regards, Jaehoon Chung
- host->max_clk = max_clk;
- ret = sdhci_setup_cfg(&plat->cfg, host, 0, ATMEL_SDHC_MIN_FREQ); if (ret) return ret;
- host->max_clk = emmc_freq; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; host->ops = &bcm2835_ops;
- add_sdhci(host, 0, min_clk); return ret;
- host->max_clk = 0;
- /* Init clocks */ ret = msm_sdc_clk_init(dev); if (ret)
- return add_sdhci(host, 0, min_clk);
ret = add_sdhci(mmc_host, 0, 0); if (ret) return ret;mmc_host->max_clk = 0;
- host->max_clk = f_min_max[1];
- ret = add_sdhci(host, 0, f_min_max[0]); if (ret) return ret; host->mmc->dev = dev;
- host->max_clk = CONFIG_ROCKCHIP_SDHCI_MAX_FREQ;
EMMC_MIN_FREQ);
#ifndef CONFIG_BLK
- return add_sdhci(host, 0, 400000);
- ret = sdhci_setup_cfg(&plat->cfg, host, 0, 400000); if (ret) return ret;
} div >>= 1;if ((host->max_clk / div) <= clock) break;
- if (max_clk)
- else {
- if (host->max_clk == 0) { if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300)
elsehost->max_clk = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT;
}host->max_clk *= 1000000;
- if (host->max_clk == 0) { printf("%s: Hardware doesn't specify base clock frequency\n", __func__); return -EINVAL; }
- if (max_clk && (max_clk < host->max_clk))
- else
if (min_clk) cfg->f_min = min_clk; else {cfg->f_max = host->max_clk;
- ret = sdhci_setup_cfg(&host->cfg, host, f_max, f_min); if (ret) return ret;
- add_sdhci(host, 0, min_clk); return 0;
- host->max_clk = CONFIG_ZYNQ_SDHCI_MAX_FREQ;
- ret = sdhci_setup_cfg(&plat->cfg, host, 0, CONFIG_ZYNQ_SDHCI_MIN_FREQ); host->mmc = &plat->mmc; if (ret)
- unsigned int max_clk; /* Maximum Base Clock frequency */ unsigned int clk_mul; /* Clock Multiplier value */ unsigned int clock; struct mmc *mmc;
- @cfg: Configuration structure to fill in (generally &plat->mmc)
- @host: SDHCI host structure
- @max_clk: Maximum supported clock speed in HZ (0 for default)
- @min_clk: Minimum supported clock speed in HZ (0 for default)
- @f_max: Maximum supported clock frequency in HZ (0 for default)
- @f_min: Minimum supported clock frequency in HZ (0 for default)
- sdhci_bind() - Set up a new MMC block device
- This is used when you are not using CONFIG_BLK. Convert your driver over!
- @return 0 if OK, -ve on error
-----Ursprüngliche Nachricht----- Von: Jaehoon Chung [mailto:jh80.chung@samsung.com] Gesendet: Freitag, 25. November 2016 06:35 An: Herbrechtsmeier, Stefan; u-boot@lists.denx.de Cc: Simon Glass; Masahiro Yamada; Stephen Warren; Heiko Schocher; Minkyu Kang; Wenyou Yang Betreff: Re: [PATCH 1/3] mmc: sdhci: Distinguish between base clock and maximum peripheral frequency
Hi Stefan,
I don't know why the code doesn't distinguish between the different clocks, but the current implementation leads to issues. For example the zynq driver assumes that the clock represents the maximum supported frequency and not the frequency of the base clock. The omap_hsmmc driver assume the same and use its own clock calculation (omap_hsmmc_set_ios) with a fixed base frequency.
Best regards Stefan
emmc_freq)
index
u32 quirks)
EMMC_MIN_FREQ);
*host)
+90,7
#ifndef CONFIG_BLK
unsigned int clock)
unsigned int clock)
unsigned int clock)
- if (max_clk)
- else {
frequency\n",
- else
index
*host, int reg)
default)
default)
- sdhci_bind() - Set up a new MMC block device @@ -402,11 +403,11
mmc_config *cfg);
driver over!
default)
default)
Kommanditgesellschaft - Sitz: Detmold - Amtsgericht Lemgo HRA 2790 - Komplementärin: Weidmüller Interface Führungsgesellschaft mbH - Sitz: Detmold - Amtsgericht Lemgo HRB 3924; Geschäftsführer: José Carlos Álvarez Tobar, Elke Eckstein, Dr. Peter Köhler, Jörg Timmermann; USt-ID-Nr. DE124599660
The zynq_sdhci controller driver use CONFIG_ZYNQ_SDHCI_MAX_FREQ as base clock frequency but this clock is not fixed and depends on the hardware configuration. Additionally the value of CONFIG_ZYNQ_SDHCI_MAX_FREQ doesn't match the real base clock frequency of SDIO_FREQ. Use the clock framework to determine the frequency at run time.
arch/arm/mach-zynq/clk.c | 23 +++++++++++++++++++++++ arch/arm/mach-zynq/include/mach/clk.h | 1 + drivers/mmc/zynq_sdhci.c | 33 +++++++++++++++++++++++++++++++-- 3 files changed, 55 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-zynq/clk.c b/arch/arm/mach-zynq/clk.c index 40383c1..0129549 100644 --- a/arch/arm/mach-zynq/clk.c +++ b/arch/arm/mach-zynq/clk.c @@ -573,6 +573,29 @@ unsigned long get_uart_clk(int dev_index) }
/** + * get_sdio_clk() - Get SDIO input frequency + * @dev_index: SDIO ID + * Returns SDIO input clock frequency in Hz. + * + * Compared to zynq_clk_get_rate() this function is designed to work before + * relocation and can be called when the SDIO is set up. + */ +unsigned long get_sdio_clk(int dev_index) +{ + u32 reg = readl(&slcr_base->sdio_clk_ctrl); + u32 div = (reg & CLK_CTRL_DIV0_MASK) >> CLK_CTRL_DIV0_SHIFT; + u32 srcsel = (reg & CLK_CTRL_SRCSEL_MASK) >> CLK_CTRL_SRCSEL_SHIFT; + enum zynq_clk parent = __zynq_clk_periph_get_parent(srcsel); + u32 *pllreg = clkid_2_register(parent); + unsigned long prate = __zynq_clk_pll_get_rate(pllreg); + + if (!div) + div = 1; + + return DIV_ROUND_CLOSEST(prate, div); +} + +/** * set_cpu_clk_info() - Initialize clock framework * Always returns zero. * diff --git a/arch/arm/mach-zynq/include/mach/clk.h b/arch/arm/mach-zynq/include/mach/clk.h index 250c5bc..fcb7842 100644 --- a/arch/arm/mach-zynq/include/mach/clk.h +++ b/arch/arm/mach-zynq/include/mach/clk.h @@ -25,5 +25,6 @@ int zynq_clk_set_rate(enum zynq_clk clk, unsigned long rate); unsigned long zynq_clk_get_rate(enum zynq_clk clk); const char *zynq_clk_get_name(enum zynq_clk clk); unsigned long get_uart_clk(int dev_id); +unsigned long get_sdio_clk(int dev_id);
#endif diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 69efa38..1b75c5a 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -6,6 +6,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <clk.h> #include <common.h> #include <dm.h> #include <fdtdec.h> @@ -13,6 +14,8 @@ #include <malloc.h> #include <sdhci.h>
+#include <asm/arch/clk.h> + #ifndef CONFIG_ZYNQ_SDHCI_MIN_FREQ # define CONFIG_ZYNQ_SDHCI_MIN_FREQ 0 #endif @@ -27,8 +30,34 @@ static int arasan_sdhci_probe(struct udevice *dev) struct arasan_sdhci_plat *plat = dev_get_platdata(dev); struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); struct sdhci_host *host = dev_get_priv(dev); + unsigned long clock; int ret;
+#if defined(CONFIG_CLK) || defined(CONFIG_SPL_CLK) + struct clk clk; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) { + dev_err(dev, "failed to get clock\n"); + return ret; + } + + clock = clk_get_rate(&clk); + if (IS_ERR_VALUE(clock)) { + dev_err(dev, "failed to get rate\n"); + return clock; + } + debug("%s: CLK %ld\n", __func__, clock); + + ret = clk_enable(&clk); + if (ret && ret != -ENOSYS) { + dev_err(dev, "failed to enable clock\n"); + return ret; + } +#else + clock = get_sdio_clk(0); +#endif + host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_BROKEN_R1B;
@@ -36,9 +65,9 @@ static int arasan_sdhci_probe(struct udevice *dev) host->quirks |= SDHCI_QUIRK_NO_HISPD_BIT; #endif
- host->max_clk = CONFIG_ZYNQ_SDHCI_MAX_FREQ; + host->max_clk = clock;
- ret = sdhci_setup_cfg(&plat->cfg, host, 0, + ret = sdhci_setup_cfg(&plat->cfg, host, CONFIG_ZYNQ_SDHCI_MAX_FREQ, CONFIG_ZYNQ_SDHCI_MIN_FREQ); host->mmc = &plat->mmc; if (ret)
- get_sdio_clk() - Get SDIO input frequency
- @dev_index: SDIO ID
- Returns SDIO input clock frequency in Hz.
- Compared to zynq_clk_get_rate() this function is designed to work before
- relocation and can be called when the SDIO is set up.
Where did "dev_index" use?
- u32 reg = readl(&slcr_base->sdio_clk_ctrl);
- u32 div = (reg & CLK_CTRL_DIV0_MASK) >> CLK_CTRL_DIV0_SHIFT;
- u32 srcsel = (reg & CLK_CTRL_SRCSEL_MASK) >> CLK_CTRL_SRCSEL_SHIFT;
- enum zynq_clk parent = __zynq_clk_periph_get_parent(srcsel);
- u32 *pllreg = clkid_2_register(parent);
- unsigned long prate = __zynq_clk_pll_get_rate(pllreg);
Could you clean these codes? it's not readable..
- if (!div)
div = 1;
- return DIV_ROUND_CLOSEST(prate, div);
- set_cpu_clk_info() - Initialize clock framework
- Always returns zero.
- unsigned long clock; int ret;
- struct clk clk;
- ret = clk_get_by_index(dev, 0, &clk);
- if (ret < 0) {
return ret;
- clock = clk_get_rate(&clk);
- if (IS_ERR_VALUE(clock)) {
return clock;
- debug("%s: CLK %ld\n", __func__, clock);
- ret = clk_enable(&clk);
- if (ret && ret != -ENOSYS) {
return ret;
+#else
- clock = get_sdio_clk(0);
I already mentioned..0 is meaningless.
- host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_BROKEN_R1B;
- host->max_clk = clock;
- ret = sdhci_setup_cfg(&plat->cfg, host, CONFIG_ZYNQ_SDHCI_MAX_FREQ, CONFIG_ZYNQ_SDHCI_MIN_FREQ);
It's strange..in PATCH[1/3], you changed from CONFIG_ZYNQ_SDHCI_MAX_FREQ to 0. why did you change again?
frequency
run time.
index
+before
The mmc controllers use the same clock. I will remove the variable.
It is an adapted copy of the get_uart_clk function.
I will introduce a common clean function.
- if (!div)
div = 1;
- return DIV_ROUND_CLOSEST(prate, div); }
index
- struct clk clk;
- if (ret < 0) {
return ret;
return clock;
return ret;
+#else
Will remove it.
PATCH[1/3] introduces a new feature without functional changes and this patch fix an issue.
In PATCH[1/3] I move the max_clk to the host. In this patch I replace the max_clk with the real clock and move the MAX_FREQ to the f_max.
Kommanditgesellschaft - Sitz: Detmold - Amtsgericht Lemgo HRA 2790 - Komplement�rin: Weidm�ller Interface F�hrungsgesellschaft mbH - Sitz: Detmold - Amtsgericht Lemgo HRB 3924; Gesch�ftsf�hrer: Jos� Carlos �lvarez Tobar, Elke Eckstein, Dr. Peter K�hler, J�rg Timmermann; USt-ID-Nr. DE124599660
The maximum supported peripheral clock frequency of the zynq depends on the IO routing. The MIO and EMIO support a maximum frequency of 50 MHz respectively 25 MHz. Use the max-frequency value of the device tree to determine the maximal supported peripheral clock frequency.
drivers/mmc/zynq_sdhci.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 1b75c5a..c6c46b8 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -16,6 +16,8 @@
+DECLARE_GLOBAL_DATA_PTR; + #ifndef CONFIG_ZYNQ_SDHCI_MIN_FREQ # define CONFIG_ZYNQ_SDHCI_MIN_FREQ 0 #endif @@ -23,6 +25,7 @@ struct arasan_sdhci_plat { struct mmc_config cfg; struct mmc mmc; + unsigned int f_max; };
static int arasan_sdhci_probe(struct udevice *dev) @@ -67,7 +70,7 @@ static int arasan_sdhci_probe(struct udevice *dev)
- ret = sdhci_setup_cfg(&plat->cfg, host, CONFIG_ZYNQ_SDHCI_MAX_FREQ, + ret = sdhci_setup_cfg(&plat->cfg, host, plat->f_max, CONFIG_ZYNQ_SDHCI_MIN_FREQ); host->mmc = &plat->mmc; if (ret) @@ -81,11 +84,15 @@ static int arasan_sdhci_probe(struct udevice *dev)
static int arasan_sdhci_ofdata_to_platdata(struct udevice *dev) { + struct arasan_sdhci_plat *plat = dev_get_platdata(dev); struct sdhci_host *host = dev_get_priv(dev);
host->name = dev->name; host->ioaddr = (void *)dev_get_addr(dev);
+ plat->f_max = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "max-frequency", CONFIG_ZYNQ_SDHCI_MAX_FREQ); + return 0; }
Jaehoon Chung
Stefan.Herbrechtsmeier@weidmueller.de
