Re: Re: [U-Boot-Users] mtmsr causes an exception (it was "Problem wi
What is the value you are moving into the MSR? What processor are you using? Is this a board with existing support or a custom board? Does it work if you don't step through that instruction using the BDI2000? gvb
Hi Gerald. I'm using the IBM evaluation board for the PPC 405EP. I debug the code in the SRAM connected to the PerCS0 chip select (it can be exchanged with the boot Flash). The first instructions are: b _start ... _start: addi r4,r0,0x0000 mtspr sgr,r4 mtspr dcwr,r4 mtesr r4 /* clear Exception Syndrome Reg */ mttcr r4 /* clear Timer Control Reg */ mtxer r4 /* clear Fixed-Point Exception Reg */ mtevpr r4 /* clear Exception Vector Prefix Reg */ addi r4,r0,0x1000 /* set ME bit (Machine Exceptions) */ oris r4,r4,0x0002 /* set CE bit (Critical Exceptions) */ mtmsr r4 /* change MSR */ addi r4,r0,(0xFFFF-0x10000) /* set r4 to 0xFFFFFFFF (status in the */ ...
When I execute step-by-step this code, the instruction mtmsr makes the CPU to jump to 0x700. I suspect it is due to the uncorrect script I use for the Abatron BDI2000. For convenience I copied it at the bottom of the message. I derived it from the example shipped with the BDI that is written for the 405GP board (Walnut). In order to simulate the state of the hardware just after a reset, I removed a lot of initializations. If I burn the code into Flash, that instruction works (but it crashes somewhere after).
;bdiGDB configuration file for IBM 405EP Reference Board for U-Boot ; ----------------------------------------------------------------- ; [INIT] ; init core register ;WSPR 954 0x00000000 ;DCWR: Disable data cache write-thru ;WSPR 1018 0x00000000 ;DCCR: Disable data cache ;WSPR 1019 0x00000000 ;ICCR: Disable instruction cache ;WSPR 982 0x00000000 ;EVPR: Exception Vector Table @0x00000000
; Setup Peripheral Bus WDCR 18 0x00000010 ;Select PB0AP WDCR 19 0x9B015480 ;PB0AP: Flash and SRAM WDCR 18 0x00000000 ;Select PB0CR WDCR 19 0xFFF18000 ;PB0CR: 1MB at 0xFFF00000, r/w, 8bit
;WDCR 18 0x00000011 ;Select PB1AP ;WDCR 19 0x02815480 ;PB1AP: NVRAM and RTC ;WDCR 18 0x00000001 ;Select PB1CR ;WDCR 19 0xF0018000 ;PB1CR: 1MB at 0xF0000000, r/w, 8bit ;WDCR 18 0x00000012 ;Select PB2AP ;WDCR 19 0x04815A80 ;PB2AP: Keyboard and Mouse ;WDCR 18 0x00000002 ;Select PB2CR ;WDCR 19 0xF0118000 ;PB2CR: 1MB at 0xF0100000, r/w, 8bit ;WDCR 18 0x00000013 ;Select PB3AP ;WDCR 19 0x01815280 ;PB3AP: IRDA ;WDCR 18 0x00000003 ;Select PB3CR ;WDCR 19 0xF0218000 ;PB3CR: 1MB at 0xF0200000, r/w, 8bit ;WDCR 18 0x00000017 ;Select PB7AP ;WDCR 19 0x01815280 ;PB7AP: FPGA ;WDCR 18 0x00000007 ;Select PB7CR ;WDCR 19 0xF0318000 ;PB7CR: 1MB at 0xF0300000, r/w, 8bit
; Setup SDRAM Controller ;WDCR 16 0x00000080 ;Select SDTR1 ;WDCR 17 0x0086400D ;SDTR1: SDRAM Timing Register ;WDCR 16 0x00000040 ;Select MB0CF ;WDCR 17 0x00046001 ;MB0CF: 16MB @ 0x00000000 ;WDCR 16 0x00000048 ;Select MB2CF ;WDCR 17 0x01046001 ;MB2CF: 16MB @ 0x01000000 ;WDCR 16 0x00000030 ;Select RTR ;WDCR 17 0x05F00000 ;RTR: Refresh Timing Register ;WDCR 16 0x00000020 ;Select MCOPT1 ;WDCR 17 0x80800000 ;MCOPT1: Enable SDRAM Controller
; Setup MMU info ;WM32 0x000000f4 0x00000000 ;invalidate kernel page table base ;WM32 0x000000f8 0x00000000 ;invalidate process page table base ;WM32 0x000000f0 0xc00000f4 ;invalidate page table base
[TARGET] JTAGCLOCK 0 ;use 16 MHz JTAG clock CPUTYPE 405 ;the used target CPU type BDIMODE AGENT ;the BDI working mode (LOADONLY | AGENT) ;WAKEUP 3000 ;wakeup time after reset BREAKMODE HARD ;SOFT or HARD, HARD uses PPC hardware breakpoint STEPMODE HWBP ;JTAG or HWBP, HWPB uses one or two hardware breakpoints ;VECTOR CATCH ;catch unhandled exceptions ;MMU XLAT 0xC0000000 ;enable virtual address mode ;PTBASE 0x000000f0 ;address where kernel/user stores pointer to page table ;SIO 7 9600 ;TCP port for serial IO
;REGLIST SPR ;select register to transfer to GDB REGLIST ALL ;select register to transfer to GDB ;SCANPRED 2 2 ;JTAG devices connected before PPC400 ;SCANSUCC 3 3 ;JTAG devices connected after PPC400
[HOST] IP 192.168.10.6 ;Linux host ;IP 151.120.25.119 ;Windows host ;FILE E:\cygwin\home\bdidemo\evb405\vxworks ;FORMAT ELF FILE /tftpboot/u-boot FILE u-boot FORMAT ELF START 0xFFFFFFFC LOAD MANUAL ;load code MANUAL or AUTO after reset ;LOAD AUTO DEBUGPORT 2001 ;DUMP E:\temp\dump.bin DUMP dump.bin ;Linux: dump.bin must already exist and public writable PROMPT PPC405EP>
[FLASH] WORKSPACE 0x00004000 ;workspace in target RAM for fast programming algorithm CHIPTYPE AM29F ;Flash type (AM29F | AM29BX8 | AM29BX16 | I28BX8 | I28BX16) CHIPSIZE 0x80000 ;The size of one flash chip in bytes (e.g. AM29F040 = 0x80000) BUSWIDTH 8 ;The width of the flash memory bus in bits (8 | 16 | 32) FILE E:\cygwin\home\bdidemo\evb405\evb405gp.sss ;The file to program ERASE 0xFFF80000 ;erase sector 0 of flash in U7 (AM29F040) ERASE 0xFFF90000 ;erase sector 1 of flash ERASE 0xFFFA0000 ;erase sector 2 of flash ERASE 0xFFFB0000 ;erase sector 3 of flash ERASE 0xFFFC0000 ;erase sector 4 of flash ERASE 0xFFFD0000 ;erase sector 5 of flash ERASE 0xFFFE0000 ;erase sector 6 of flash ERASE 0xFFFF0000 ;erase sector 7 of flash
[REGS] IDCR1 0x010 0x011 ;MEMCFGADR and MEMCFGDATA IDCR2 0x012 0x013 ;EBCCFGADR and EBCCFGDATA ;IDCR3 0x014 0x015 ;KIAR and KIDR ;FILE E:\cygwin\home\bdidemo\evb405\reg405gp.def FILE reg405ep.def
llandre
llandre
