[U-Boot] [PATCH v2 2/5] arm64: mvebu: a8k: Add support for NAND clock get
Implement mvebu_get_nand_clock call for A8K family. This function is used by PXA3XX NAND driver.
Signed-off-by: Konstantin Porotchkin kostap@marvell.com Cc: Stefan Roese sr@denx.de Cc: Igal Liberman igall@marvell.com Cc: Nadav Haklai nadavh@marvell.com --- Changes from v1: - Add TODO notice for moving the functionality to a future clock driver
arch/arm/mach-mvebu/armada8k/cpu.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/arm/mach-mvebu/armada8k/cpu.c b/arch/arm/mach-mvebu/armada8k/cpu.c index 2325e9a..38e7d33 100644 --- a/arch/arm/mach-mvebu/armada8k/cpu.c +++ b/arch/arm/mach-mvebu/armada8k/cpu.c @@ -110,3 +110,21 @@ void reset_cpu(ulong ignored) reg &= ~(1 << RFU_SW_RESET_OFFSET); writel(reg, RFU_GLOBAL_SW_RST); } + +/* + * TODO - implement this functionality using platform + * clock driver once it gets available + * Return NAND clock in Hz + */ +u32 mvebu_get_nand_clock(void) +{ + unsigned long NAND_FLASH_CLK_CTRL = 0xF2440700UL; + unsigned long NF_CLOCK_SEL_MASK = 0x1; + u32 reg; + + reg = readl(NAND_FLASH_CLK_CTRL); + if (reg & NF_CLOCK_SEL_MASK) + return 400 * 1000000; + else + return 250 * 1000000; +}
Add NAND to CP master device tree. Add armada-7040-db-nand device tree for the board configured with NAND boot device. Add comment about boot device ID to armada-7040-db DTS.
Signed-off-by: Konstantin Porotchkin kostap@marvell.com Cc: Stefan Roese sr@denx.de Cc: Igal Liberman igall@marvell.com Cc: Nadav Haklai nadavh@marvell.com --- Changes from v1: - Minor changes following review: Add compatibility string Mention NAND in board model description
arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-7040-db-nand.dts | 223 ++++++++++++++++++++++++++++++++++ arch/arm/dts/armada-7040-db.dts | 1 + arch/arm/dts/armada-cp110-master.dtsi | 14 +++ 4 files changed, 239 insertions(+) create mode 100644 arch/arm/dts/armada-7040-db-nand.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 462c690..9ccff58 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -78,6 +78,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-388-gp.dtb \ armada-385-amc.dtb \ armada-7040-db.dtb \ + armada-7040-db-nand.dtb \ armada-8040-db.dtb \ armada-8040-mcbin.dtb \ armada-xp-gp.dtb \ diff --git a/arch/arm/dts/armada-7040-db-nand.dts b/arch/arm/dts/armada-7040-db-nand.dts new file mode 100644 index 0000000..3a9df21 --- /dev/null +++ b/arch/arm/dts/armada-7040-db-nand.dts @@ -0,0 +1,223 @@ +/* + * Copyright (C) 2017 Marvell Technology Group Ltd. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPLv2 or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/* + * Device Tree file for Marvell Armada 7040 Development board platform + * Boot device: NAND, 0xE (SW3) + */ + +#include "armada-7040.dtsi" + +/ { + model = "Marvell Armada 7040 DB board with NAND"; + compatible = "marvell,armada7040-db-nand", "marvell,armada7040-db", + "marvell,armada7040", "marvell,armada-ap806-quad", + "marvell,armada-ap806"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + i2c0 = &cpm_i2c0; + spi0 = &cpm_spi1; + }; + + memory@00000000 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; +}; + +&ap_pinctl { + /* MPP Bus: + * SDIO [0-5] + * UART0 [11,19] + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0x1 0x1 0x1 0x1 0x1 0x1 0x0 0x0 0x0 0x0 + 0x0 0x3 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x3 >; +}; + +&uart0 { + status = "okay"; +}; + + +&cpm_pcie2 { + status = "okay"; +}; + +&cpm_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&cpm_i2c0_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +&cpm_pinctl { + /* MPP Bus: + * AUDIO [0-5] + * GBE [6-11] + * SS_PWDN [12] + * NF_RBn [13] + * GPIO [14] + * DEV_BUS [15-27] + * SATA1 [28] + * UART0 [29-30] + * MSS_VTT_EN [31] + * SMI [32,34] + * XSMI [35-36] + * I2C [37-38] + * RGMII1 [44-55] + * SD [56-61] + * GPIO [62] + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0x2 0x2 0x2 0x2 0x2 0x2 0x3 0x3 0x3 0x3 + 0x3 0x3 0x0 0x2 0x0 0x1 0x1 0x1 0x1 0x1 + 0x1 0x1 0x1 0x1 0x1 0x1 0x1 0x1 0x9 0xa + 0xa 0x0 0x7 0x0 0x7 0x7 0x7 0x2 0x2 0x0 + 0x0 0x0 0x0 0x0 0x1 0x1 0x1 0x1 0x1 0x1 + 0x1 0x1 0x1 0x1 0x1 0x1 0xe 0xe 0xe 0xe + 0xe 0xe 0x0>; +}; + +&cpm_spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&cpm_spi0_pins>; + status = "disabled"; + + spi-flash@0 { + #address-cells = <0x1>; + #size-cells = <0x1>; + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-max-frequency = <20000000>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "U-Boot"; + reg = <0x0 0x200000>; + }; + + partition@400000 { + label = "Filesystem"; + reg = <0x200000 0xe00000>; + }; + }; + }; +}; + +&cpm_sata0 { + status = "okay"; +}; + +&cpm_usb3_0 { + status = "okay"; +}; + +&cpm_usb3_1 { + status = "okay"; +}; + +&cpm_comphy { + phy0 { + phy-type = <PHY_TYPE_SGMII2>; + phy-speed = <PHY_SPEED_3_125G>; + }; + + phy1 { + phy-type = <PHY_TYPE_USB3_HOST0>; + phy-speed = <PHY_SPEED_5G>; + }; + + phy2 { + phy-type = <PHY_TYPE_SGMII0>; + phy-speed = <PHY_SPEED_1_25G>; + }; + + phy3 { + phy-type = <PHY_TYPE_SATA1>; + phy-speed = <PHY_SPEED_5G>; + }; + + phy4 { + phy-type = <PHY_TYPE_USB3_HOST1>; + phy-speed = <PHY_SPEED_5G>; + }; + + phy5 { + phy-type = <PHY_TYPE_PEX2>; + phy-speed = <PHY_SPEED_5G>; + }; +}; + +&cpm_nand { + status = "okay"; +}; + +&cpm_utmi0 { + status = "okay"; +}; + +&cpm_utmi1 { + status = "okay"; +}; + +&ap_sdhci0 { + status = "okay"; + bus-width = <4>; + no-1-8-v; + non-removable; +}; + +&cpm_sdhci0 { + status = "okay"; + bus-width = <4>; + no-1-8-v; + non-removable; +}; diff --git a/arch/arm/dts/armada-7040-db.dts b/arch/arm/dts/armada-7040-db.dts index 84e0dbd..c1a0f46 100644 --- a/arch/arm/dts/armada-7040-db.dts +++ b/arch/arm/dts/armada-7040-db.dts @@ -42,6 +42,7 @@
/* * Device Tree file for Marvell Armada 7040 Development board platform + * Boot device: SPI NOR, 0x32 (SW3) */
#include "armada-7040.dtsi" diff --git a/arch/arm/dts/armada-cp110-master.dtsi b/arch/arm/dts/armada-cp110-master.dtsi index 229046f..56c1a12 100644 --- a/arch/arm/dts/armada-cp110-master.dtsi +++ b/arch/arm/dts/armada-cp110-master.dtsi @@ -273,6 +273,20 @@ dma-coherent; status = "disabled"; }; + + cpm_nand: nand@720000 { + compatible = "marvell,mvebu-pxa3xx-nand"; + reg = <0x720000 0x100>; + #address-cells = <1>; + + clocks = <&cpm_syscon0 1 2>; + nand-enable-arbiter; + num-cs = <1>; + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; + status = "disabled"; + }; + };
cpm_pcie0: pcie@f2600000 {
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
Add NAND configuration parameters to A8K shared config file. Add defconfig for db-88f7040 board with boot from NAND setup.
Signed-off-by: Konstantin Porotchkin kostap@marvell.com Cc: Stefan Roese sr@denx.de Cc: Igal Liberman igall@marvell.com Cc: Nadav Haklai nadavh@marvell.com --- Changes from v1: - Rebase on top of latest master branch changes
configs/mvebu_db-88f7040-nand_defconfig | 72 +++++++++++++++++++++++++++++++++ include/configs/mvebu_armada-8k.h | 11 +++++ 2 files changed, 83 insertions(+) create mode 100644 configs/mvebu_db-88f7040-nand_defconfig
diff --git a/configs/mvebu_db-88f7040-nand_defconfig b/configs/mvebu_db-88f7040-nand_defconfig new file mode 100644 index 0000000..d86c18e --- /dev/null +++ b/configs/mvebu_db-88f7040-nand_defconfig @@ -0,0 +1,72 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_MVEBU_ARMADA_8K=y +CONFIG_DEFAULT_DEVICE_TREE="armada-7040-db-nand" +CONFIG_SMBIOS_PRODUCT_NAME="" +CONFIG_AHCI=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_BOARD_LATE_INIT=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_NAND=y +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +CONFIG_BLOCK_CACHE=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_MVEBU_NAND_BOOT=y +CONFIG_NAND_PXA3XX=y +CONFIG_PHYLIB=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_DW_MVEBU=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0xf0512000 +CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_SMBIOS_MANUFACTURER="" diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index 8ee5f27..9d3aeef 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -76,11 +76,22 @@ #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE
/* Environment in SPI NOR flash */ +#ifdef CONFIG_MVEBU_SPI_BOOT #define CONFIG_ENV_IS_IN_SPI_FLASH +/* Environment in NAND flash */ +#elif defined(CONFIG_MVEBU_NAND_BOOT) +#define CONFIG_ENV_IS_IN_NAND +#endif + #define CONFIG_ENV_OFFSET 0x180000 /* as Marvell U-Boot version */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */
+#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_MAX_CHIPS 1 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_NAND_USE_FLASH_BBT + /* * Ethernet Driver configuration */
Thanks, Stefan
Thanks, Stefan
Thanks, Stefan
Thanks, Stefan
kostap@marvell.com
Stefan Roese
