[U-Boot] [PATCH v1 0/3] Enable PSCI services for booting Linux
Add "SYTEM_RESET" (cold reset) and "CPU_ON" (SMP) PSCI support for booting Linux on Stratix 10 platform.
Ang, Chee Hong (3): ARM: socfpga: stratix10: Enable PSCI system reset ARM: socfpga: stratix10: Enable PSCI CPU_ON ARM: socfpga: stratix10: Enable PSCI support for Stratix 10
arch/arm/mach-socfpga/Kconfig | 9 ++++++- arch/arm/mach-socfpga/Makefile | 3 +++ arch/arm/mach-socfpga/psci.c | 56 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 67 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-socfpga/psci.c
Enable psci_system_reset support for Stratix10. This PSCI function will eventually trigger the mailbox HPS_REBOOT to SDM.
Signed-off-by: Ang, Chee Hong chee.hong.ang@intel.com --- arch/arm/mach-socfpga/Makefile | 3 +++ arch/arm/mach-socfpga/psci.c | 21 +++++++++++++++++++++ 2 files changed, 24 insertions(+) create mode 100644 arch/arm/mach-socfpga/psci.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index e667204..f77b229 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -38,6 +38,9 @@ obj-y += system_manager_s10.o obj-y += timer_s10.o obj-y += wrap_pinmux_config_s10.o obj-y += wrap_pll_config_s10.o +ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_ARMV8_PSCI) += psci.o +endif endif
ifdef CONFIG_SPL_BUILD diff --git a/arch/arm/mach-socfpga/psci.c b/arch/arm/mach-socfpga/psci.c new file mode 100644 index 0000000..9ef3931 --- /dev/null +++ b/arch/arm/mach-socfpga/psci.c @@ -0,0 +1,21 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/psci.h> +#include <errno.h> +#include <asm/arch/mailbox_s10.h> +#include <asm/secure.h> + +void __noreturn __secure psci_system_reset(void) +{ + mbox_send_cmd_psci(MBOX_ID_UBOOT, MBOX_REBOOT_HPS, + MBOX_CMD_DIRECT, 0, NULL, 0, 0, NULL); + + while (1) + ; +}
Enable psci_cpu_on support for Stratix10. This PSCI function will pass the cpu release address for CPU1-CPU3. Then send event signal shall be triggered to get these CPUs running Linux code.
Signed-off-by: Ang, Chee Hong chee.hong.ang@intel.com --- arch/arm/mach-socfpga/psci.c | 35 +++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/arch/arm/mach-socfpga/psci.c b/arch/arm/mach-socfpga/psci.c index 9ef3931..0af3eb1 100644 --- a/arch/arm/mach-socfpga/psci.c +++ b/arch/arm/mach-socfpga/psci.c @@ -11,6 +11,9 @@ #include <asm/arch/mailbox_s10.h> #include <asm/secure.h>
+static u64 psci_cpu_on_64_cpuid __secure_data; +static u64 psci_cpu_on_64_entry_point __secure_data; + void __noreturn __secure psci_system_reset(void) { mbox_send_cmd_psci(MBOX_ID_UBOOT, MBOX_REBOOT_HPS, @@ -19,3 +22,35 @@ void __noreturn __secure psci_system_reset(void) while (1) ; } + +/* This function will handle multiple core release based PSCI */ +void __secure psci_cpu_on_64_mpidr(void) +{ + asm volatile( + ".align 5 \n" + "1: wfe \n" + " ldr x0, [%0] \n" + " ldr x1, [%1] \n" + " mrs x2, mpidr_el1 \n" + " and x2, x2, #0xff \n" + " cmp x0, x2 \n" + " b.ne 1b \n" + " br x1 \n" + : : "r"(&psci_cpu_on_64_cpuid), "r"(&psci_cpu_on_64_entry_point) + : "x0", "x1", "x2", "memory", "cc"); +} + +int __secure psci_cpu_on_64(u32 function_id, u64 cpuid, u64 entry_point) +{ + /* Releases all secondary CPUs to jump into psci_cpu_on_64_mpidr */ + writeq(0, &psci_cpu_on_64_cpuid); + writeq(0, &psci_cpu_on_64_entry_point); + writeq((u64)&psci_cpu_on_64_mpidr, CPU_RELEASE_ADDR); + + /* to store in global so psci_cpu_on_64_mpidr function can refer */ + writeq(entry_point, &psci_cpu_on_64_entry_point); + writeq(cpuid, &psci_cpu_on_64_cpuid); + asm volatile("sev"); + + return ARM_PSCI_RET_SUCCESS; +}
The address of PSCI text, data and stack sections start at 0x00001000 (SDRAM).
Signed-off-by: Ang, Chee Hong chee.hong.ang@intel.com --- arch/arm/mach-socfpga/Kconfig | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 8f7b79f..6fb508e 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -12,6 +12,12 @@ config SPL_SYS_MALLOC_F_LEN config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE default 0xa2
+config ARMV8_SECURE_BASE + default 0x00001000 if TARGET_SOCFPGA_STRATIX10 + +config SYS_HAS_ARMV8_SECURE_BASE + default y if TARGET_SOCFPGA_STRATIX10 + config SYS_MALLOC_F_LEN default 0x2000 if TARGET_SOCFPGA_ARRIA10 default 0x2000 if TARGET_SOCFPGA_GEN5 @@ -56,8 +62,9 @@ config TARGET_SOCFPGA_GEN5 config TARGET_SOCFPGA_STRATIX10 bool select ARMV8_MULTIENTRY + select ARMV8_PSCI + select ARMV8_SEC_FIRMWARE_SUPPORT select ARMV8_SET_SMPEN - select ARMV8_SPIN_TABLE select FPGA_STRATIX10
choice
Hi Marek,
Any comment on this ? These PSCI patches are needed for booting Linux on our S10 platform.
BR, Ang
Hi Marek,
Same questions as in Re: [PATCH v1 0/3] Enable HPS execution stage notification , can we stop adding more and more stuff to arch/ and instead add it to drivers/ ? As you might have noticed, we are trying to remove stuff from arch/ and move as much as possible to drivers/ , but S10 is doing the exact opposite :(
Hi Marek,
Not all PSCI code fit in DM (drivers/). There should be a good place to keep the PSCI code for our platform. Can you advise us where should we place those PSCI implementation other than arch/ ?
Hi Marek,
Look through this discussion: https://www.mail-archive.com/u-boot@lists.denx.de/msg319458.html and possibly follow up on it.
Ang, Chee Hong
