[U-Boot] [PATCH] mx5 iomux: Fix GPIO with SION
IOMUX_CONFIG_GPIO may be used together with IOMUX_CONFIG_SION, so don't break the iomux function value set to the register in this case.
Define the value of IOMUX_CONFIG_GPIO in a way showing that it should have only 1 bit set.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Stefano Babic sbabic@denx.de --- .../arch/arm/cpu/armv7/mx5/iomux.c | 5 +++-- .../arch/arm/include/asm/arch-mx5/iomux.h | 2 +- 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git u-boot-4d3c95f.orig/arch/arm/cpu/armv7/mx5/iomux.c u-boot-4d3c95f/arch/arm/cpu/armv7/mx5/iomux.c index d4e3bbb..7adf08f 100644 --- u-boot-4d3c95f.orig/arch/arm/cpu/armv7/mx5/iomux.c +++ u-boot-4d3c95f/arch/arm/cpu/armv7/mx5/iomux.c @@ -124,8 +124,9 @@ static void iomux_config_mux(iomux_pin_name_t pin, iomux_pin_cfg_t cfg)
if ((mux_reg > get_mux_end()) || (mux_reg < IOMUXSW_MUX_CTL)) return ; - if (cfg == IOMUX_CONFIG_GPIO) - writel(PIN_TO_ALT_GPIO(pin), mux_reg); + if (cfg & IOMUX_CONFIG_GPIO) + writel((cfg & ~IOMUX_CONFIG_GPIO) | PIN_TO_ALT_GPIO(pin), + mux_reg); else writel(cfg, mux_reg); } diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx5/iomux.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx5/iomux.h index e3765a3..8b6e56a 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx5/iomux.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx5/iomux.h @@ -40,7 +40,7 @@ typedef enum iomux_config { IOMUX_CONFIG_ALT5, /*!< used as alternate function 5 */ IOMUX_CONFIG_ALT6, /*!< used as alternate function 6 */ IOMUX_CONFIG_ALT7, /*!< used as alternate function 7 */ - IOMUX_CONFIG_GPIO, /*!< added to help user use GPIO mode */ + IOMUX_CONFIG_GPIO = 0x1 << 3, /*!< added to help user use GPIO mode */ IOMUX_CONFIG_SION = 0x1 << 4, /*!< used as LOOPBACK:MUX SION bit */ } iomux_pin_cfg_t;
Hi Benoît,
to my understanding. The SION bit is used to set a predefined function, independently from the value of the iomux. So I have the choice to set the SION bit or I select the function I want, including GPIO, clearing the SION bit, and setting optionally the daisy chain register if the GPIO requires.
So why should we use both SION and GPIO ?
Regards, Stefano
- if (cfg & IOMUX_CONFIG_GPIO)
else writel(cfg, mux_reg);mux_reg);
- IOMUX_CONFIG_GPIO = 0x1 << 3, /*!< added to help user use GPIO mode */ IOMUX_CONFIG_SION = 0x1 << 4, /*!< used as LOOPBACK:MUX SION bit */
} iomux_pin_cfg_t;
Hi Stefano,
Hi Benoît,
No. See "A.3.2 SW Loopback through SION Bit" and "Figure A-3. IOMUX Cell Block Diagram" in the i.MX51 RM.
Whether SION is set or not, the selected IOMUX function will drive the pin.
If SION is cleared, the input from the pin will be either disabled or go to the selected IOMUX function depending on the activation of the input by this function.
If SION is set, the input from the pin is always enabled and goes to all IOMUX alternate functions at once (if their input connection to this pin is activated through the daisy chain).
So SION does not invalidate the function bit-field.
Then, you could wonder what kind of real life use case could be useful with both SION and GPIO set. This could be used for instance as a workaround to an erratum if an IOMUX function does not drive its output properly, but it needs to read back the pin status to work fine. Thus, the GPIO function output could be used to drive the pin, with SION set so that the flawed IOMUX function can still probe the pin and function properly internally. Note that it's only a theoretical example; I don't remember such an erratum.
Best regards, Benoît
On 17/08/2012 18:21, Benoît Thébaudeau wrote:
Hi Stefano,
Hi Benoît,
And this is clear..
and also thi point is clear.
but I am asking myself why I should do this, that is the function drive the pin, using the input as source for another funtion.
This is exactly the point !
I am really impressed about your attention reading the manuals, but we have the rule in u-boot that we add code / feature when we have a use case (the same is in kernel). At the moment, it is pure theory, and nobody will use it. We will reconsider this patch when its introduction will be required to fix a SOC bug, if any.
Best regards, Stefano Babic
Hi Stefano,
Hi Stefano,
Hi Benoît,
And this is clear..
Sure, but this is neither new code nor a new feature. It is only a fix that makes sure that the code won't break any potential use case in the future. This is weird to keep a known issue in the code until someone gets in trouble because of it and hence wastes time.
But anyway, this file will probably disappear in the near future because of the new pin definitions, so that won't make a big difference.
Benoît Thébaudeau
Stefano Babic
