[PATCH v4 00/13] riscv: Switch to use binman to generate u-boot.itb
This series updates binman to handle creation of u-boot.itb image for RISC-V boards.
Azure results: PASS https://dev.azure.com/bmeng/GitHub/_build/results?buildId=363&view=resul...
The following tests were performed: * booting qemu-riscv{32|64}_spl_defconfig on QEMU virt * booting sifive_unleashed_defconfig on QEMU sifive_u
AE350 SPL defconfigs are not tested. @Rick, could you please test and report?
The series is available at u-boot-x86/riscv_binman for testing.
Changes in v4: - update the makefile dependency on u-boot.img instead of u-boot.bin
Changes in v3: - Fix the opensbi entry type in binman.dtsi - new patch: "lib: kconfig: Limit BINMAN_FDT for OF_SEPARATE or OF_EMBED" - rename the Kconfig option name to BINMAN_STANDALONE_FDT - make BINMAN_STANDALONE_FDT default y for OF_BOARD as well - reword the Kconfig option help message a little bit - new patch: "riscv: ae350: Switch to use binman to generate u-boot.itb" - remove USE_SPL_FIT_GENERATOR in ae350_ defconfigs
Changes in v2: - drop patch: "binman: test: Correct the name of 170_fit_fdt_missing_prop.dts", as it was based on a wrong version - drop patch: "makefile: Update clean rule to remove files generated by binman", as it is better to refactor binman to generate all intermediate files for makefile to clean - drop "size = <16>" in the binman node - new patch: "binman: Support packaging U-Boot for scenarios like OF_PRIOR_STAGE" - new patch: "riscv: dts: Sort build targets in alphabetical order" - new patch: "riscv: qemu: Switch to use binman to generate u-boot.itb" - new patch: "riscv: Drop USE_SPL_FIT_GENERATOR"
Bin Meng (13): common: kconfig: Correct a typo in SPL_LOAD_FIT binman: Correct '-a' description in the doc binman: Correct the comment for ATF entry type binman: test: Rename 172_fit_fdt.dts to 170_fit_fdt.dts binman: Add support for RISC-V OpenSBI fw_dynamic blob makefile: Pass OpenSBI blob to binman make rules riscv: sifive: unleashed: Switch to use binman to generate u-boot.itb lib: kconfig: Limit BINMAN_FDT for OF_SEPARATE or OF_EMBED binman: Support packaging U-Boot for scenarios like OF_BOARD or OF_PRIOR_STAGE riscv: dts: Sort build targets in alphabetical order riscv: qemu: Switch to use binman to generate u-boot.itb riscv: ae350: Switch to use binman to generate u-boot.itb riscv: Drop USE_SPL_FIT_GENERATOR
Makefile | 4 +- arch/riscv/cpu/generic/Kconfig | 1 + arch/riscv/dts/Makefile | 3 +- arch/riscv/dts/ae350_32.dts | 2 + arch/riscv/dts/ae350_64.dts | 2 + arch/riscv/dts/binman.dtsi | 78 ++++++++++++++ .../dts/hifive-unleashed-a00-u-boot.dtsi | 1 + arch/riscv/dts/qemu-virt.dts | 8 ++ arch/riscv/lib/mkimage_fit_opensbi.sh | 100 ------------------ board/AndesTech/ax25-ae350/Kconfig | 1 + board/sifive/unleashed/Kconfig | 1 + common/Kconfig.boot | 5 +- configs/ae350_rv32_spl_defconfig | 1 + configs/ae350_rv32_spl_xip_defconfig | 1 + configs/ae350_rv64_spl_defconfig | 1 + configs/ae350_rv64_spl_xip_defconfig | 1 + configs/qemu-riscv32_spl_defconfig | 1 + configs/qemu-riscv64_spl_defconfig | 1 + dts/Kconfig | 18 ++++ lib/Kconfig | 2 +- tools/binman/binman.rst | 4 +- tools/binman/entries.rst | 13 +++ tools/binman/etype/atf_bl31.py | 2 +- tools/binman/etype/opensbi.py | 23 ++++ tools/binman/ftest.py | 17 ++- .../test/{172_fit_fdt.dts => 170_fit_fdt.dts} | 0 tools/binman/test/201_opensbi.dts | 14 +++ 27 files changed, 191 insertions(+), 114 deletions(-) create mode 100644 arch/riscv/dts/binman.dtsi create mode 100644 arch/riscv/dts/qemu-virt.dts delete mode 100755 arch/riscv/lib/mkimage_fit_opensbi.sh create mode 100644 tools/binman/etype/opensbi.py rename tools/binman/test/{172_fit_fdt.dts => 170_fit_fdt.dts} (100%) create mode 100644 tools/binman/test/201_opensbi.dts
It should be FDT, not FTD.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
(no changes since v1)
common/Kconfig.boot | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/Kconfig.boot b/common/Kconfig.boot index 5a18d62d78..94d82c27dd 100644 --- a/common/Kconfig.boot +++ b/common/Kconfig.boot @@ -204,7 +204,7 @@ config SPL_LOAD_FIT
This path has the following limitations:
- 1. "loadables" images, other than FTDs, which do not have a "load" + 1. "loadables" images, other than FDTs, which do not have a "load" property will not be loaded. This limitation also applies to FPGA images with the correct "compatible" string. 2. For FPGA images, only the "compatible" = "u-boot,fpga-legacy"
It needs a space around '-a'.
tools/binman/binman.rst | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/binman/binman.rst b/tools/binman/binman.rst index 1aa2459d50..b3df3a6428 100644 --- a/tools/binman/binman.rst +++ b/tools/binman/binman.rst @@ -322,9 +322,9 @@ Sometimes it is useful to pass binman the value of an entry property from the command line. For example some entries need access to files and it is not always convenient to put these filenames in the image definition (device tree).
-The-a option supports this:: +The -a option supports this::
- -a<prop>=<value> + -a <prop>=<value>
where::
This is wrongly referring to Intel ME, which should be ATF.
tools/binman/etype/atf_bl31.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/binman/etype/atf_bl31.py b/tools/binman/etype/atf_bl31.py index 163d714184..2041da416c 100644 --- a/tools/binman/etype/atf_bl31.py +++ b/tools/binman/etype/atf_bl31.py @@ -2,7 +2,7 @@ # Copyright 2020 Google LLC # Written by Simon Glass sjg@chromium.org # -# Entry-type module for Intel Management Engine binary blob +# Entry-type module for ARM Trusted Firmware binary blob #
from binman.etype.blob_named_by_arg import Entry_blob_named_by_arg
Currently there are 2 binman test cases using the same 172 number. It seems that 172_fit_fdt.dts was originally named as 170_, but commit c0f1ebe9c1b9 ("binman: Allow selecting default FIT configuration") changed its name to 172_ for no reason. Let's change it back.
tools/binman/ftest.py | 10 +++++----- tools/binman/test/{172_fit_fdt.dts => 170_fit_fdt.dts} | 0 2 files changed, 5 insertions(+), 5 deletions(-) rename tools/binman/test/{172_fit_fdt.dts => 170_fit_fdt.dts} (100%)
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index f36823f51b..b0daccbc3b 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -3826,7 +3826,7 @@ class TestFunctional(unittest.TestCase): 'default-dt': 'test-fdt2', } data = self._DoReadFileDtb( - '172_fit_fdt.dts', + '170_fit_fdt.dts', entry_args=entry_args, extra_indirs=[os.path.join(self._indir, TEST_FDT_SUBDIR)])[0] self.assertEqual(U_BOOT_NODTB_DATA, data[-len(U_BOOT_NODTB_DATA):]) @@ -3848,7 +3848,7 @@ class TestFunctional(unittest.TestCase): def testFitFdtMissingList(self): """Test handling of a missing 'of-list' entry arg""" with self.assertRaises(ValueError) as e: - self._DoReadFile('172_fit_fdt.dts') + self._DoReadFile('170_fit_fdt.dts') self.assertIn("Generator node requires 'of-list' entry argument", str(e.exception))
@@ -3871,7 +3871,7 @@ class TestFunctional(unittest.TestCase): entry_args = { 'of-list': '', } - data = self._DoReadFileDtb('172_fit_fdt.dts', entry_args=entry_args)[0] + data = self._DoReadFileDtb('170_fit_fdt.dts', entry_args=entry_args)[0]
def testFitFdtMissing(self): """Test handling of a missing 'default-dt' entry arg""" @@ -3880,7 +3880,7 @@ class TestFunctional(unittest.TestCase): } with self.assertRaises(ValueError) as e: self._DoReadFileDtb( - '172_fit_fdt.dts', + '170_fit_fdt.dts', entry_args=entry_args, extra_indirs=[os.path.join(self._indir, TEST_FDT_SUBDIR)])[0] self.assertIn("Generated 'default' node requires default-dt entry argument", @@ -3894,7 +3894,7 @@ class TestFunctional(unittest.TestCase): } with self.assertRaises(ValueError) as e: self._DoReadFileDtb( - '172_fit_fdt.dts', + '170_fit_fdt.dts', entry_args=entry_args, extra_indirs=[os.path.join(self._indir, TEST_FDT_SUBDIR)])[0] self.assertIn("default-dt entry argument 'test-fdt3' not found in fdt list: test-fdt1, test-fdt2", diff --git a/tools/binman/test/172_fit_fdt.dts b/tools/binman/test/170_fit_fdt.dts similarity index 100% rename from tools/binman/test/172_fit_fdt.dts rename to tools/binman/test/170_fit_fdt.dts
Add an entry for RISC-V OpenSBI's 'fw_dynamic' firmware payload.
(no changes since v2)
Changes in v2: - drop "size = <16>" in the binman node
tools/binman/entries.rst | 13 +++++++++++++ tools/binman/etype/opensbi.py | 23 +++++++++++++++++++++++ tools/binman/ftest.py | 7 +++++++ tools/binman/test/201_opensbi.dts | 14 ++++++++++++++ 4 files changed, 57 insertions(+) create mode 100644 tools/binman/etype/opensbi.py create mode 100644 tools/binman/test/201_opensbi.dts
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index f1c3b7de7a..dcac700c46 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -761,6 +761,19 @@ binman.
+Entry: opensbi: RISC-V OpenSBI fw_dynamic blob +---------------------------------------------- + +Properties / Entry arguments: + - opensbi-path: Filename of file to read into entry. This is typically + called fw_dynamic.bin + +This entry holds the run-time firmware, typically started by U-Boot SPL. +See the U-Boot README for your architecture or board for how to use it. See +https://github.com/riscv/opensbi for more information about OpenSBI. + + + Entry: powerpc-mpc85xx-bootpg-resetvec: PowerPC mpc85xx bootpg + resetvec code for U-Boot -----------------------------------------------------------------------------------------
diff --git a/tools/binman/etype/opensbi.py b/tools/binman/etype/opensbi.py new file mode 100644 index 0000000000..74d473d535 --- /dev/null +++ b/tools/binman/etype/opensbi.py @@ -0,0 +1,23 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2021, Bin Meng bmeng.cn@gmail.com +# +# Entry-type module for RISC-V OpenSBI binary blob +# + +from binman.etype.blob_named_by_arg import Entry_blob_named_by_arg + +class Entry_opensbi(Entry_blob_named_by_arg): + """RISC-V OpenSBI fw_dynamic blob + + Properties / Entry arguments: + - opensbi-path: Filename of file to read into entry. This is typically + called fw_dynamic.bin + + This entry holds the run-time firmware, typically started by U-Boot SPL. + See the U-Boot README for your architecture or board for how to use it. See + https://github.com/riscv/opensbi for more information about OpenSBI. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node, 'opensbi') + self.external = True diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index b0daccbc3b..5383eec489 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -76,6 +76,7 @@ FSP_M_DATA = b'fsp_m' FSP_S_DATA = b'fsp_s' FSP_T_DATA = b'fsp_t' ATF_BL31_DATA = b'bl31' +OPENSBI_DATA = b'opensbi' SCP_DATA = b'scp' TEST_FDT1_DATA = b'fdt1' TEST_FDT2_DATA = b'test-fdt2' @@ -178,6 +179,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('compress', COMPRESS_DATA) TestFunctional._MakeInputFile('compress_big', COMPRESS_DATA_BIG) TestFunctional._MakeInputFile('bl31.bin', ATF_BL31_DATA) + TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA)
# Add a few .dtb files for testing @@ -4535,5 +4537,10 @@ class TestFunctional(unittest.TestCase): expected += tools.GetBytes(0, 88 - len(expected)) + U_BOOT_NODTB_DATA self.assertEqual(expected, data)
+ def testPackOpenSBI(self): + """Test that an image with an OpenSBI binary can be created""" + data = self._DoReadFile('201_opensbi.dts') + self.assertEqual(OPENSBI_DATA, data[:len(OPENSBI_DATA)]) + if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/201_opensbi.dts b/tools/binman/test/201_opensbi.dts new file mode 100644 index 0000000000..942183f990 --- /dev/null +++ b/tools/binman/test/201_opensbi.dts @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + opensbi { + filename = "fw_dynamic.bin"; + }; + }; +};
This updates the make rules to pass OpenSBI blob to binman.
Makefile | 1 + 1 file changed, 1 insertion(+)
diff --git a/Makefile b/Makefile index 404977efa5..3d88559b67 100644 --- a/Makefile +++ b/Makefile @@ -1287,6 +1287,7 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ -I . -I $(srctree) -I $(srctree)/board/$(BOARDDIR) \ -I arch/$(ARCH)/dts -a of-list=$(CONFIG_OF_LIST) \ -a atf-bl31-path=${BL31} \ + -a opensbi-path=${OPENSBI} \ -a default-dt=$(default_dt) \ -a scp-path=$(SCP) \ -a spl-bss-pad=$(if $(CONFIG_SPL_SEPARATE_BSS),,1) \
At present SiFive Unleashed board uses the Makefile to create the FIT, using USE_SPL_FIT_GENERATOR, which is deprecated as per the Makefile warning. Update to use binman instead.
(no changes since v3)
arch/riscv/dts/binman.dtsi | 70 +++++++++++++++++++ .../dts/hifive-unleashed-a00-u-boot.dtsi | 1 + board/sifive/unleashed/Kconfig | 1 + configs/sifive_unleashed_defconfig | 1 + 4 files changed, 73 insertions(+) create mode 100644 arch/riscv/dts/binman.dtsi
diff --git a/arch/riscv/dts/binman.dtsi b/arch/riscv/dts/binman.dtsi new file mode 100644 index 0000000000..e02597e73d --- /dev/null +++ b/arch/riscv/dts/binman.dtsi @@ -0,0 +1,70 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021, Bin Meng bmeng.cn@gmail.com + */ + +#include <config.h> + +/ { + binman: binman { + multiple-images; + }; +}; + +&binman { + itb { + filename = "u-boot.itb"; + + fit { + description = "Configuration to load OpenSBI before U-Boot"; + #address-cells = <1>; + fit,fdt-list = "of-list"; + + images { + uboot { + description = "U-Boot"; + type = "standalone"; + os = "U-Boot"; + arch = "riscv"; + compression = "none"; + load = <CONFIG_SYS_TEXT_BASE>; + + uboot_blob: blob-ext { + filename = "u-boot-nodtb.bin"; + }; + }; + + opensbi { + description = "OpenSBI fw_dynamic Firmware"; + type = "firmware"; + os = "opensbi"; + arch = "riscv"; + compression = "none"; + load = <CONFIG_SPL_OPENSBI_LOAD_ADDR>; + entry = <CONFIG_SPL_OPENSBI_LOAD_ADDR>; + + opensbi_blob: opensbi { + filename = "fw_dynamic.bin"; + }; + }; + + @fdt-SEQ { + description = "NAME"; + type = "flat_dt"; + compression = "none"; + }; + }; + + configurations { + default = "conf-1"; + + @conf-SEQ { + description = "NAME"; + firmware = "opensbi"; + loadables = "uboot"; + fdt = "fdt-SEQ"; + }; + }; + }; + }; +}; diff --git a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi index 1996149c95..51b566116d 100644 --- a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi +++ b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi @@ -3,6 +3,7 @@ * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */
+#include "binman.dtsi" #include "fu540-c000-u-boot.dtsi" #include "fu540-hifive-unleashed-a00-ddr.dtsi"
diff --git a/board/sifive/unleashed/Kconfig b/board/sifive/unleashed/Kconfig index dbffd59c98..502916e86a 100644 --- a/board/sifive/unleashed/Kconfig +++ b/board/sifive/unleashed/Kconfig @@ -27,6 +27,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select SIFIVE_FU540 select ENV_IS_IN_SPI_FLASH + select BINMAN imply CMD_DHCP imply CMD_EXT2 imply CMD_EXT4 diff --git a/configs/sifive_unleashed_defconfig b/configs/sifive_unleashed_defconfig index 62416a7c1d..dc9313e572 100644 --- a/configs/sifive_unleashed_defconfig +++ b/configs/sifive_unleashed_defconfig @@ -14,6 +14,7 @@ CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x84000000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y CONFIG_MISC_INIT_R=y
Generally speaking BINMAN_FDT makes sense for OF_SEPARATE or OF_EMBED. For the other OF_CONTROL methods, it's quite possible binman node is not available as binman is invoked during the build phase instead of runtime. Let's only turn it on for OF_SEPARATE or OF_EMBED by default.
Changes in v3: - new patch: "lib: kconfig: Limit BINMAN_FDT for OF_SEPARATE or OF_EMBED"
lib/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/Kconfig b/lib/Kconfig index 6d2d41de30..7d5990c940 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -25,7 +25,7 @@ config BCH config BINMAN_FDT bool "Allow access to binman information in the device tree" depends on BINMAN && DM && OF_CONTROL - default y + default y if OF_SEPARATE || OF_EMBED help This enables U-Boot to access information about binman entries, stored in the device tree in a binman node. Typical uses are to
For scenarios like OF_BOARD or OF_PRIOR_STAGE, no device tree blob is provided in the U-Boot build phase hence the binman node information is not available. In order to support such use case, a new Kconfig option BINMAN_STANDALONE_FDT is introduced, to tell the build system that a device tree blob containing binman node is explicitly required when using binman to package U-Boot.
Changes in v3: - rename the Kconfig option name to BINMAN_STANDALONE_FDT - make BINMAN_STANDALONE_FDT default y for OF_BOARD as well - reword the Kconfig option help message a little bit
Changes in v2: - new patch: "binman: Support packaging U-Boot for scenarios like OF_PRIOR_STAGE"
Makefile | 3 ++- dts/Kconfig | 18 ++++++++++++++++++ 2 files changed, 20 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 3d88559b67..1dbf0b0b8c 100644 --- a/Makefile +++ b/Makefile @@ -918,6 +918,7 @@ endif endif INPUTS-$(CONFIG_TPL) += tpl/u-boot-tpl.bin INPUTS-$(CONFIG_OF_SEPARATE) += u-boot.dtb +INPUTS-$(CONFIG_BINMAN_STANDALONE_FDT) += u-boot.dtb ifeq ($(CONFIG_SPL_FRAMEWORK),y) INPUTS-$(CONFIG_OF_SEPARATE) += u-boot-dtb.img endif @@ -1392,7 +1393,7 @@ u-boot-lzma.img: u-boot.bin.lzma FORCE
u-boot-dtb.img u-boot.img u-boot.kwb u-boot.pbl u-boot-ivt.img: \ $(if $(CONFIG_SPL_LOAD_FIT),u-boot-nodtb.bin \ - $(if $(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_OF_HOSTFILE),dts/dt.dtb) \ + $(if $(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_OF_HOSTFILE)$(CONFIG_BINMAN_STANDALONE_FDT),dts/dt.dtb) \ ,$(UBOOT_BIN)) FORCE $(call if_changed,mkimage) $(BOARD_SIZE_CHECK) diff --git a/dts/Kconfig b/dts/Kconfig index 99ce75e1a2..dabe0080c1 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -19,6 +19,24 @@ config BINMAN bool select DTOC
+config BINMAN_STANDALONE_FDT + bool + depends on BINMAN + default y if OF_BOARD || OF_PRIOR_STAGE + help + This option tells U-Boot build system that a standalone device tree + source is explicitly required when using binman to package U-Boot. + + This is not necessary in a common scenario where a device tree source + that contains the binman node is provided in the arch/<arch>/dts + directory for a specific board. Such device tree sources are built for + OF_SEPARATE or OF_EMBED. However for a scenario like the board device + tree blob is not provided in the U-Boot build tree, but fed to U-Boot + in the runtime, e.g.: in the OF_PRIOR_STAGE case that it is passed by + a prior stage bootloader. For such scenario, a standalone device tree + blob containing binman node to describe how to package U-Boot should + be provided explicitly. + menu "Device Tree Control" depends on SUPPORT_OF_CONTROL
Sort the RISC-V DTS build targets by their Kconfig target names in alphabetical order.
Changes in v2: - new patch: "riscv: dts: Sort build targets in alphabetical order"
arch/riscv/dts/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 8138d89d84..3780334875 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -1,9 +1,9 @@ # SPDX-License-Identifier: GPL-2.0+
dtb-$(CONFIG_TARGET_AX25_AE350) += ae350_32.dtb ae350_64.dtb +dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += microchip-mpfs-icicle-kit.dtb dtb-$(CONFIG_TARGET_SIFIVE_UNLEASHED) += hifive-unleashed-a00.dtb dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb -dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += microchip-mpfs-icicle-kit.dtb
targets += $(dtb-y)
By utilizing the newly introduced BINMAN_STANDALONE_FDT option, along with a new dedicated device tree source file for the QEMU virt target used for binman only, we can now use binman to generate u-boot.itb.
Changes in v2: - new patch: "riscv: qemu: Switch to use binman to generate u-boot.itb"
arch/riscv/cpu/generic/Kconfig | 1 + arch/riscv/dts/Makefile | 1 + arch/riscv/dts/binman.dtsi | 8 ++++++++ arch/riscv/dts/qemu-virt.dts | 8 ++++++++ configs/qemu-riscv32_spl_defconfig | 2 ++ configs/qemu-riscv64_spl_defconfig | 2 ++ 6 files changed, 22 insertions(+) create mode 100644 arch/riscv/dts/qemu-virt.dts
diff --git a/arch/riscv/cpu/generic/Kconfig b/arch/riscv/cpu/generic/Kconfig index 198e36e969..a4934bb957 100644 --- a/arch/riscv/cpu/generic/Kconfig +++ b/arch/riscv/cpu/generic/Kconfig @@ -4,6 +4,7 @@
config GENERIC_RISCV bool + select BINMAN if SPL select ARCH_EARLY_INIT_R imply CPU imply CPU_RISCV diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 3780334875..26ef853282 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -2,6 +2,7 @@
dtb-$(CONFIG_TARGET_AX25_AE350) += ae350_32.dtb ae350_64.dtb dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += microchip-mpfs-icicle-kit.dtb +dtb-$(CONFIG_TARGET_QEMU_VIRT) += qemu-virt.dtb dtb-$(CONFIG_TARGET_SIFIVE_UNLEASHED) += hifive-unleashed-a00.dtb dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb
diff --git a/arch/riscv/dts/binman.dtsi b/arch/riscv/dts/binman.dtsi index e02597e73d..d26cfdb78a 100644 --- a/arch/riscv/dts/binman.dtsi +++ b/arch/riscv/dts/binman.dtsi @@ -48,21 +48,29 @@ }; };
+#ifndef CONFIG_OF_PRIOR_STAGE @fdt-SEQ { description = "NAME"; type = "flat_dt"; compression = "none"; }; +#endif };
configurations { default = "conf-1";
+#ifndef CONFIG_OF_PRIOR_STAGE @conf-SEQ { +#else + conf-1 { +#endif description = "NAME"; firmware = "opensbi"; loadables = "uboot"; +#ifndef CONFIG_OF_PRIOR_STAGE fdt = "fdt-SEQ"; +#endif }; }; }; diff --git a/arch/riscv/dts/qemu-virt.dts b/arch/riscv/dts/qemu-virt.dts new file mode 100644 index 0000000000..fecff542b9 --- /dev/null +++ b/arch/riscv/dts/qemu-virt.dts @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021, Bin Meng bmeng.cn@gmail.com + */ + +/dts-v1/; + +#include "binman.dtsi" diff --git a/configs/qemu-riscv32_spl_defconfig b/configs/qemu-riscv32_spl_defconfig index 18dfe33ca8..a4c156612a 100644 --- a/configs/qemu-riscv32_spl_defconfig +++ b/configs/qemu-riscv32_spl_defconfig @@ -2,11 +2,13 @@ CONFIG_RISCV=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x20000 CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="qemu-virt" CONFIG_TARGET_QEMU_VIRT=y CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set diff --git a/configs/qemu-riscv64_spl_defconfig b/configs/qemu-riscv64_spl_defconfig index 897adf6a29..6c680483ce 100644 --- a/configs/qemu-riscv64_spl_defconfig +++ b/configs/qemu-riscv64_spl_defconfig @@ -2,12 +2,14 @@ CONFIG_RISCV=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x20000 CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="qemu-virt" CONFIG_TARGET_QEMU_VIRT=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set
Use the new BINMAN_STANDALONE_FDT option for AE350 based SPL defconfigs, so that binman is now used to generate u-boot.itb.
Changes in v3: - new patch: "riscv: ae350: Switch to use binman to generate u-boot.itb"
arch/riscv/dts/ae350_32.dts | 2 ++ arch/riscv/dts/ae350_64.dts | 2 ++ board/AndesTech/ax25-ae350/Kconfig | 1 + configs/ae350_rv32_spl_defconfig | 2 ++ configs/ae350_rv32_spl_xip_defconfig | 2 ++ configs/ae350_rv64_spl_defconfig | 2 ++ configs/ae350_rv64_spl_xip_defconfig | 2 ++ 7 files changed, 13 insertions(+)
diff --git a/arch/riscv/dts/ae350_32.dts b/arch/riscv/dts/ae350_32.dts index 3f8525fe56..a0ab5e9be2 100644 --- a/arch/riscv/dts/ae350_32.dts +++ b/arch/riscv/dts/ae350_32.dts @@ -1,5 +1,7 @@ /dts-v1/;
+#include "binman.dtsi" + / { #address-cells = <1>; #size-cells = <1>; diff --git a/arch/riscv/dts/ae350_64.dts b/arch/riscv/dts/ae350_64.dts index 482c707503..f654f4809a 100644 --- a/arch/riscv/dts/ae350_64.dts +++ b/arch/riscv/dts/ae350_64.dts @@ -1,5 +1,7 @@ /dts-v1/;
+#include "binman.dtsi" + / { #address-cells = <2>; #size-cells = <2>; diff --git a/board/AndesTech/ax25-ae350/Kconfig b/board/AndesTech/ax25-ae350/Kconfig index 321dd0cb10..e50f505a2b 100644 --- a/board/AndesTech/ax25-ae350/Kconfig +++ b/board/AndesTech/ax25-ae350/Kconfig @@ -31,6 +31,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select RISCV_NDS select SUPPORT_SPL + select BINMAN if SPL imply SMP imply SPL_RAM_SUPPORT imply SPL_RAM_DEVICE diff --git a/configs/ae350_rv32_spl_defconfig b/configs/ae350_rv32_spl_defconfig index 153266f647..47c8e9a621 100644 --- a/configs/ae350_rv32_spl_defconfig +++ b/configs/ae350_rv32_spl_defconfig @@ -3,11 +3,13 @@ CONFIG_SYS_TEXT_BASE=0x01200000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="ae350_32" CONFIG_TARGET_AX25_AE350=y CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x00200000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="RISC-V # " diff --git a/configs/ae350_rv32_spl_xip_defconfig b/configs/ae350_rv32_spl_xip_defconfig index 651b1eb733..206ffe2720 100644 --- a/configs/ae350_rv32_spl_xip_defconfig +++ b/configs/ae350_rv32_spl_xip_defconfig @@ -4,12 +4,14 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="ae350_32" CONFIG_TARGET_AX25_AE350=y CONFIG_RISCV_SMODE=y CONFIG_XIP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="RISC-V # " diff --git a/configs/ae350_rv64_spl_defconfig b/configs/ae350_rv64_spl_defconfig index f434091d47..ef04e4a4b6 100644 --- a/configs/ae350_rv64_spl_defconfig +++ b/configs/ae350_rv64_spl_defconfig @@ -3,12 +3,14 @@ CONFIG_SYS_TEXT_BASE=0x01200000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="ae350_64" CONFIG_TARGET_AX25_AE350=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x00200000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="RISC-V # " diff --git a/configs/ae350_rv64_spl_xip_defconfig b/configs/ae350_rv64_spl_xip_defconfig index b0afdb4cfe..21b7e8895b 100644 --- a/configs/ae350_rv64_spl_xip_defconfig +++ b/configs/ae350_rv64_spl_xip_defconfig @@ -4,6 +4,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="ae350_64" CONFIG_TARGET_AX25_AE350=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y @@ -11,6 +12,7 @@ CONFIG_XIP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="RISC-V # "
Now that we have switched to binman to generate u-boot.itb for all RISC-V boards, USE_SPL_FIT_GENERATOR is no longer needed and can be dropped.
Changes in v3: - remove USE_SPL_FIT_GENERATOR in ae350_ defconfigs
Changes in v2: - new patch: "riscv: Drop USE_SPL_FIT_GENERATOR"
arch/riscv/lib/mkimage_fit_opensbi.sh | 100 -------------------------- common/Kconfig.boot | 3 +- configs/ae350_rv32_spl_defconfig | 1 - configs/ae350_rv32_spl_xip_defconfig | 1 - configs/ae350_rv64_spl_defconfig | 1 - configs/ae350_rv64_spl_xip_defconfig | 1 - configs/qemu-riscv32_spl_defconfig | 1 - configs/qemu-riscv64_spl_defconfig | 1 - configs/sifive_unleashed_defconfig | 1 - 9 files changed, 1 insertion(+), 109 deletions(-) delete mode 100755 arch/riscv/lib/mkimage_fit_opensbi.sh
diff --git a/arch/riscv/lib/mkimage_fit_opensbi.sh b/arch/riscv/lib/mkimage_fit_opensbi.sh deleted file mode 100755 index d6f95e5bfd..0000000000 --- a/arch/riscv/lib/mkimage_fit_opensbi.sh +++ /dev/null @@ -1,100 +0,0 @@ -#!/bin/sh -# SPDX-License-Identifier: GPL-2.0+ -# -# script to generate FIT image source for RISC-V boards with OpenSBI -# and, optionally, multiple device trees (given on the command line). -# -# usage: $0 [<dt_name> [<dt_name] ...] - -[ -z "$OPENSBI" ] && OPENSBI="fw_dynamic.bin" - -if [ -z "$UBOOT_LOAD_ADDR" ]; then - UBOOT_LOAD_ADDR="$(grep "^CONFIG_SYS_TEXT_BASE=" .config | awk 'BEGIN{FS="="} {print $2}')" -fi - -if [ -z "$OPENSBI_LOAD_ADDR" ]; then - OPENSBI_LOAD_ADDR="$(grep "^CONFIG_SPL_OPENSBI_LOAD_ADDR=" .config | awk 'BEGIN{FS="="} {print $2}')" -fi - -if [ ! -f $OPENSBI ]; then - echo "WARNING: OpenSBI binary "$OPENSBI" not found, resulting binary is not functional." >&2 - OPENSBI=/dev/null -fi - -cat << __HEADER_EOF -/dts-v1/; - -/ { - description = "Configuration to load OpenSBI before U-Boot"; - - images { - uboot { - description = "U-Boot"; - data = /incbin/("u-boot-nodtb.bin"); - type = "standalone"; - os = "U-Boot"; - arch = "riscv"; - compression = "none"; - load = <$UBOOT_LOAD_ADDR>; - }; - opensbi { - description = "RISC-V OpenSBI"; - data = /incbin/("$OPENSBI"); - type = "firmware"; - os = "opensbi"; - arch = "riscv"; - compression = "none"; - load = <$OPENSBI_LOAD_ADDR>; - entry = <$OPENSBI_LOAD_ADDR>; - }; -__HEADER_EOF - -cnt=1 -for dtname in $* -do - cat << __FDT_IMAGE_EOF - fdt_$cnt { - description = "$(basename $dtname .dtb)"; - data = /incbin/("$dtname"); - type = "flat_dt"; - compression = "none"; - }; -__FDT_IMAGE_EOF -cnt=$((cnt+1)) -done - -cat << __CONF_HEADER_EOF - }; - configurations { - default = "config_1"; - -__CONF_HEADER_EOF - -if [ $# -eq 0 ]; then -cat << __CONF_SECTION_EOF - config_1 { - description = "U-Boot FIT"; - firmware = "opensbi"; - loadables = "uboot"; - }; -__CONF_SECTION_EOF -else -cnt=1 -for dtname in $* -do -cat << __CONF_SECTION_EOF - config_$cnt { - description = "$(basename $dtname .dtb)"; - firmware = "opensbi"; - loadables = "uboot"; - fdt = "fdt_$cnt"; - }; -__CONF_SECTION_EOF -cnt=$((cnt+1)) -done -fi - -cat << __ITS_EOF - }; -}; -__ITS_EOF diff --git a/common/Kconfig.boot b/common/Kconfig.boot index 94d82c27dd..89a3161f1f 100644 --- a/common/Kconfig.boot +++ b/common/Kconfig.boot @@ -273,14 +273,13 @@ config SPL_FIT_SOURCE
config USE_SPL_FIT_GENERATOR bool "Use a script to generate the .its script" - default y if SPL_FIT && !ARCH_SUNXI + default y if SPL_FIT && (!ARCH_SUNXI && !RISCV)
config SPL_FIT_GENERATOR string ".its file generator script for U-Boot FIT image" depends on USE_SPL_FIT_GENERATOR default "arch/arm/mach-rockchip/make_fit_atf.py" if SPL_LOAD_FIT && ARCH_ROCKCHIP default "arch/arm/mach-zynqmp/mkimage_fit_atf.sh" if SPL_LOAD_FIT && ARCH_ZYNQMP - default "arch/riscv/lib/mkimage_fit_opensbi.sh" if SPL_LOAD_FIT && RISCV help Specifies a (platform specific) script file to generate the FIT source file used to build the U-Boot FIT image file. This gets diff --git a/configs/ae350_rv32_spl_defconfig b/configs/ae350_rv32_spl_defconfig index 47c8e9a621..25b4ada427 100644 --- a/configs/ae350_rv32_spl_defconfig +++ b/configs/ae350_rv32_spl_defconfig @@ -9,7 +9,6 @@ CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x00200000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="RISC-V # " diff --git a/configs/ae350_rv32_spl_xip_defconfig b/configs/ae350_rv32_spl_xip_defconfig index 206ffe2720..c5d7ac3bc1 100644 --- a/configs/ae350_rv32_spl_xip_defconfig +++ b/configs/ae350_rv32_spl_xip_defconfig @@ -11,7 +11,6 @@ CONFIG_XIP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="RISC-V # " diff --git a/configs/ae350_rv64_spl_defconfig b/configs/ae350_rv64_spl_defconfig index ef04e4a4b6..61637a916e 100644 --- a/configs/ae350_rv64_spl_defconfig +++ b/configs/ae350_rv64_spl_defconfig @@ -10,7 +10,6 @@ CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x00200000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="RISC-V # " diff --git a/configs/ae350_rv64_spl_xip_defconfig b/configs/ae350_rv64_spl_xip_defconfig index 21b7e8895b..6c63382f75 100644 --- a/configs/ae350_rv64_spl_xip_defconfig +++ b/configs/ae350_rv64_spl_xip_defconfig @@ -12,7 +12,6 @@ CONFIG_XIP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="RISC-V # " diff --git a/configs/qemu-riscv32_spl_defconfig b/configs/qemu-riscv32_spl_defconfig index a4c156612a..f30bd5f0a0 100644 --- a/configs/qemu-riscv32_spl_defconfig +++ b/configs/qemu-riscv32_spl_defconfig @@ -8,7 +8,6 @@ CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set diff --git a/configs/qemu-riscv64_spl_defconfig b/configs/qemu-riscv64_spl_defconfig index 6c680483ce..ee91ece0ec 100644 --- a/configs/qemu-riscv64_spl_defconfig +++ b/configs/qemu-riscv64_spl_defconfig @@ -9,7 +9,6 @@ CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set diff --git a/configs/sifive_unleashed_defconfig b/configs/sifive_unleashed_defconfig index dc9313e572..62416a7c1d 100644 --- a/configs/sifive_unleashed_defconfig +++ b/configs/sifive_unleashed_defconfig @@ -14,7 +14,6 @@ CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x84000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y CONFIG_MISC_INIT_R=y
- booting qemu-riscv{32|64}_spl_defconfig on QEMU virt
- booting sifive_unleashed_defconfig on QEMU sifive_u
+Leo
Changes in v4:
Bin Meng
