[PATCH] xilinx: zynqmp: Allow multiboot environment write even in saved environment
Once the environment was saved, we could not retrieve information about the multiboot image used. When dealing with firmware updates, this information is necessary alongside the saved environment.
Move the multiboot environment set operation before the saved environment check to ensure this information is always available.
Signed-off-by: Kory Maincent kory.maincent@bootlin.com --- board/xilinx/zynqmp/zynqmp.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index f370fb7347a..16292ed1c7e 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -519,6 +519,10 @@ int board_late_init(void) usb_ether_init(); #endif
+ multiboot = multi_boot(); + if (multiboot >= 0) + env_set_hex("multiboot", multiboot); + if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { debug("Saved variables - Skipping\n"); return 0; @@ -531,10 +535,6 @@ int board_late_init(void) if (ret) return ret;
- multiboot = multi_boot(); - if (multiboot >= 0) - env_set_hex("multiboot", multiboot); - if (IS_ENABLED(CONFIG_DISTRO_DEFAULTS)) { ret = boot_targets_setup(); if (ret)
nit: use imperative mood.
what exactly are you trying to do?
that make sense.
likely make sense to remove this check to because you want to have even multiboot=0 too.
- if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { debug("Saved variables - Skipping\n"); return 0;
M
Ah indeed.
Retrieving the multiboot information to know which boot000x.bin image we have booted. This would allow to check the boot status of a firmware update.
that make sense.
I don't understand, this check is >= so it supports multiboot=0.
Regards,
Ah indeed.
that make sense.
Sorry my fault. You are right. It was there for catching the fault.
Thanks, Michal
Kory Maincent
Michal Simek
