[U-Boot] [Patch 1/8] add at91 SoC access with c structures
* prepare board config files for Soc access update
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de --- include/configs/afeb9260.h | 4 ++ include/configs/at91cap9adk.h | 4 ++ include/configs/at91rm9200dk.h | 13 ++++- include/configs/at91rm9200ek.h | 11 ++++- include/configs/at91sam9260ek.h | 5 ++ include/configs/at91sam9261ek.h | 5 ++ include/configs/at91sam9263ek.h | 83 ++++++++++++++++++------------------ include/configs/at91sam9m10g45ek.h | 6 +++ include/configs/at91sam9rlek.h | 5 ++ include/configs/cmc_pu2.h | 10 ++++- include/configs/cpu9260.h | 4 ++ include/configs/cpuat91.h | 2 + include/configs/csb637.h | 10 ++++- include/configs/kb9202.h | 10 ++++- include/configs/m501sk.h | 11 ++++- include/configs/meesc.h | 5 ++ include/configs/mp2usb.h | 10 ++++- include/configs/pm9261.h | 7 +++ include/configs/pm9263.h | 5 ++ include/configs/sbc35_a9g20.h | 4 ++ include/configs/tny_a9260.h | 4 ++ 21 files changed, 166 insertions(+), 52 deletions(-)
diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 58b8c8c..ddd5f52 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -26,6 +26,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91_MAIN_CLOCK 18429952 /* from 18.432 MHz crystal */ #define CONFIG_SYS_HZ 1000 @@ -45,6 +47,7 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 @@ -107,6 +110,7 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13
+#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #endif
/* NOR flash - no real flash on this board */ diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 322718f..7679a09 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -27,6 +27,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ #define CONFIG_SYS_HZ 1000 @@ -47,6 +49,7 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 @@ -131,6 +134,7 @@ #define CONFIG_SYS_NAND_BASE 0x40000000 #define CONFIG_SYS_NAND_DBW_8 1
/* Ethernet */ diff --git a/include/configs/at91rm9200dk.h b/include/configs/at91rm9200dk.h index 590c69a..7480e25 100644 --- a/include/configs/at91rm9200dk.h +++ b/include/configs/at91rm9200dk.h @@ -25,6 +25,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91C_MAIN_CLOCK 179712000 /* from 18.432 MHz crystal (18432000 / 4 * 39) */ #define AT91C_MASTER_CLOCK 59904000 /* peripheral clock (AT91C_MASTER_CLOCK / 3) */ @@ -113,8 +115,6 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_MII
-#include <asm/arch/AT91RM9200.h> /* needed for port definitions */ - #define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM 0x20000000 #define PHYS_SDRAM_SIZE 0x2000000 /* 32 megs */ @@ -122,7 +122,14 @@ #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM #define CONFIG_SYS_MEMTEST_END CONFIG_SYS_MEMTEST_START + PHYS_SDRAM_SIZE - 262144
-#define CONFIG_DRIVER_ETHER +#define CONFIG_NET_MULTI 1 +#ifdef CONFIG_NET_MULTI +#define CONFIG_DRIVER_AT91EMAC 1 +#define CONFIG_SYS_RX_ETH_BUFFER 8 +#else +#define CONFIG_DRIVER_ETHER 1 +#endif + #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_AT91C_USE_RMII
diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index b4f075e..5b4175f 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -26,6 +26,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ /* * from 18.432 MHz crystal @@ -135,7 +137,6 @@ #undef CONFIG_CMD_MISC #undef CONFIG_CMD_LOADS
-#include <asm/arch/AT91RM9200.h> /* needed for port definitions */ /* Options for MMC/SD Card */ #define CONFIG_DOS_PARTITION 1 #undef CONFIG_MMC @@ -145,7 +146,13 @@ /* * Network Driver Setting */ -#define CONFIG_DRIVER_ETHER +#define CONFIG_NET_MULTI 1 +#ifdef CONFIG_NET_MULTI +#define CONFIG_DRIVER_AT91EMAC 1 +#define CONFIG_SYS_RX_ETH_BUFFER 8 +#else +#define CONFIG_DRIVER_ETHER 1 +#endif #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_AT91C_USE_RMII
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 0509011..4c3b0a2 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -27,6 +27,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ #define CONFIG_SYS_HZ 1000 @@ -52,6 +54,8 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 @@ -123,6 +127,7 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13
/* NOR flash - no real flash on this board */ diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index fbf7389..066f256 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -27,6 +27,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ #define CONFIG_SYS_HZ 1000 @@ -50,6 +52,8 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 @@ -133,6 +137,7 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC15
/* NOR flash - no real flash on this board */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 571351c..68e8310 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -49,6 +49,8 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 @@ -69,9 +71,9 @@
/* LED */ #define CONFIG_AT91_LED -#define CONFIG_RED_LED AT91_PIN_PB7 /* this is the power led */ -#define CONFIG_GREEN_LED AT91_PIN_PB8 /* this is the user1 led */ -#define CONFIG_YELLOW_LED AT91_PIN_PC29 /* this is the user2 led */ +#define CONFIG_RED_LED AT91_PORTPIN(B, 7) /* the power led */ +#define CONFIG_GREEN_LED AT91_PORTPIN(B, 8) /* the user1 led */ +#define CONFIG_YELLOW_LED AT91_PORTPIN(C, 29) /* the user2 led */
#define CONFIG_BOOTDELAY 3
@@ -147,39 +149,36 @@ #ifndef CONFIG_SKIP_LOWLEVEL_INIT #define MASTER_PLL_MUL 171 #define MASTER_PLL_DIV 14 +#define MASTER_PLL_OUT 3
/* clocks */ #define CONFIG_SYS_MOR_VAL \ - (AT91_PMC_MOSCEN | \ - (255 << 8)) /* Main Oscillator Start-up Time */ -#define CONFIG_SYS_PLLAR_VAL \ - (AT91_PMC_PLLA_WR_ERRATA | /* Bit 29 must be 1 when prog */ \ - AT91_PMC_OUT | \ - AT91_PMC_PLLCOUNT | /* PLL Counter */ \ - (2 << 28) | /* PLL Clock Frequency Range */ \ - ((MASTER_PLL_MUL - 1) << 16) | (MASTER_PLL_DIV)) + (AT91_PMC_MOR_MOSCEN | AT91_PMC_MOR_OSCOUNT(255)) +#define CONFIG_SYS_PLLAR_VAL \ + (AT91_PMC_PLLAR_29 | \ + AT91_PMC_PLLxR_OUT(MASTER_PLL_OUT) | \ + AT91_PMC_PLLxR_PLLCOUNT(63) | \ + AT91_PMC_PLLxR_MUL(MASTER_PLL_MUL - 1) | \ + AT91_PMC_PLLxR_DIV(MASTER_PLL_DIV))
/* PCK/2 = MCK Master Clock from PLLA */ #define CONFIG_SYS_MCKR1_VAL \ - (AT91_PMC_CSS_SLOW | \ - AT91_PMC_PRES_1 | \ - AT91SAM9_PMC_MDIV_2 | \ - AT91_PMC_PDIV_1) + (AT91_PMC_MCKR_CSS_SLOW | AT91_PMC_MCKR_PRES_1 | \ + AT91_PMC_MCKR_MDIV_2) + /* PCK/2 = MCK Master Clock from PLLA */ #define CONFIG_SYS_MCKR2_VAL \ - (AT91_PMC_CSS_PLLA | \ - AT91_PMC_PRES_1 | \ - AT91SAM9_PMC_MDIV_2 | \ - AT91_PMC_PDIV_1) + (AT91_PMC_MCKR_CSS_PLLA | AT91_PMC_MCKR_PRES_1 | \ + AT91_PMC_MCKR_MDIV_2)
/* define PDC[31:16] as DATA[31:16] */ #define CONFIG_SYS_PIOD_PDR_VAL1 0xFFFF0000 /* no pull-up for D[31:16] */ #define CONFIG_SYS_PIOD_PPUDR_VAL 0xFFFF0000 /* EBI0_CSA, CS1 SDRAM, CS3 NAND Flash, 3.3V memories */ -#define CONFIG_SYS_MATRIX_EBI0CSA_VAL \ - (AT91_MATRIX_EBI0_DBPUC | AT91_MATRIX_EBI0_VDDIOMSEL_3_3V | \ - AT91_MATRIX_EBI0_CS1A_SDRAMC) +#define CONFIG_SYS_MATRIX_EBICSA_VAL \ + (AT91_MATRIX_CSA_DBPUC | AT91_MATRIX_CSA_VDDIOMSEL_3_3V | \ + AT91_MATRIX_CSA_EBI_CS1A)
/* SDRAM */ /* SDRAMC_MR Mode register */ @@ -221,33 +220,32 @@ #define CONFIG_SYS_SDRAM_VAL12 0 /* SDRAM_BASE */
/* setup SMC0, CS0 (NOR Flash) - 16-bit, 15 WS */ -#define CONFIG_SYS_SMC0_SETUP0_VAL \ - (AT91_SMC_NWESETUP_(10) | AT91_SMC_NCS_WRSETUP_(10) | \ - AT91_SMC_NRDSETUP_(10) | AT91_SMC_NCS_RDSETUP_(10)) -#define CONFIG_SYS_SMC0_PULSE0_VAL \ - (AT91_SMC_NWEPULSE_(11) | AT91_SMC_NCS_WRPULSE_(11) | \ - AT91_SMC_NRDPULSE_(11) | AT91_SMC_NCS_RDPULSE_(11)) +#define CONFIG_SYS_SMC0_SETUP0_VAL \ + (AT91_SMC_SETUP_NWE(10) | AT91_SMC_SETUP_NCS_WR(10) | \ + AT91_SMC_SETUP_NRD(10) | AT91_SMC_SETUP_NCS_RD(10)) +#define CONFIG_SYS_SMC0_PULSE0_VAL \ + (AT91_SMC_PULSE_NWE(11) | AT91_SMC_PULSE_NCS_WR(11) | \ + AT91_SMC_PULSE_NRD(11) | AT91_SMC_PULSE_NCS_RD(11)) #define CONFIG_SYS_SMC0_CYCLE0_VAL \ - (AT91_SMC_NWECYCLE_(22) | AT91_SMC_NRDCYCLE_(22)) + (AT91_SMC_CYCLE_NWE(22) | AT91_SMC_CYCLE_NRD(22)) #define CONFIG_SYS_SMC0_MODE0_VAL \ - (AT91_SMC_READMODE | AT91_SMC_WRITEMODE | \ - AT91_SMC_DBW_16 | \ - AT91_SMC_TDFMODE | \ - AT91_SMC_TDF_(6)) + (AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | \ + AT91_SMC_MODE_DBW_16 | \ + AT91_SMC_MODE_TDF | AT91_SMC_MODE_TDF_CYCLE(6))
/* user reset enable */ #define CONFIG_SYS_RSTC_RMR_VAL \ (AT91_RSTC_KEY | \ - AT91_RSTC_PROCRST | \ - AT91_RSTC_RSTTYP_WAKEUP | \ - AT91_RSTC_RSTTYP_WATCHDOG) + AT91_RSTC_MR_URSTEN | \ + AT91_RSTC_MR_ERSTL(15))
/* Disable Watchdog */ #define CONFIG_SYS_WDTC_WDMR_VAL \ - (AT91_WDT_WDIDLEHLT | AT91_WDT_WDDBGHLT | \ - AT91_WDT_WDV | \ - AT91_WDT_WDDIS | \ - AT91_WDT_WDD) + (AT91_WDT_MR_WDIDLEHLT | AT91_WDT_MR_WDDBGHLT | \ + AT91_WDT_MR_WDV(0xfff) | \ + AT91_WDT_MR_WDDIS | \ + AT91_WDT_MR_WDD(0xfff)) + #endif
#else @@ -264,9 +262,10 @@ #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) /* our CLE is AD22 */ #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) -#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 -#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA22 +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PORTPIN(D, 15) +#define CONFIG_SYS_NAND_READY_PIN AT91_PORTPIN(A, 22)
/* Ethernet */ diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 06184e7..cc1bf9a 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -27,6 +27,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ #define CONFIG_SYS_HZ 1000 @@ -50,6 +52,8 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 @@ -118,6 +122,7 @@ /* NOR flash, if populated */ #ifndef CONFIG_CMD_NAND #define CONFIG_SYS_NO_FLASH 1 +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #else #define CONFIG_SYS_FLASH_CFI 1 #define CONFIG_FLASH_CFI_DRIVER 1 @@ -141,6 +146,7 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC8
/* Ethernet */ diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 6fad75d..62e760f 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -27,6 +27,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ #define CONFIG_SYS_HZ 1000 @@ -47,6 +49,8 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 @@ -119,6 +123,7 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PB6 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PD17
/* Ethernet - not present */ diff --git a/include/configs/cmc_pu2.h b/include/configs/cmc_pu2.h index be478b2..ffe83f0 100644 --- a/include/configs/cmc_pu2.h +++ b/include/configs/cmc_pu2.h @@ -25,6 +25,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91C_MAIN_CLOCK 179712000 /* from 18.432 MHz crystal (18432000 / 4 * 39) */ #define AT91C_MASTER_CLOCK (AT91C_MAIN_CLOCK/3) /* peripheral clock */ @@ -152,7 +154,13 @@ #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM #define CONFIG_SYS_MEMTEST_END CONFIG_SYS_MEMTEST_START + PHYS_SDRAM_SIZE - 262144
diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h index 4ef8566..50e31ff 100644 --- a/include/configs/cpu9260.h +++ b/include/configs/cpu9260.h @@ -31,6 +31,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + #define CONFIG_DISPLAY_CPUINFO 1
#define AT91_MAIN_CLOCK 18432000 @@ -242,6 +244,8 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 diff --git a/include/configs/cpuat91.h b/include/configs/cpuat91.h index 8746f70..9f0ac03 100644 --- a/include/configs/cpuat91.h +++ b/include/configs/cpuat91.h @@ -26,6 +26,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + #ifdef CONFIG_CPUAT91_RAM #define CONFIG_SKIP_LOWLEVEL_INIT 1 #define CONFIG_SKIP_RELOCATE_UBOOT 1 diff --git a/include/configs/csb637.h b/include/configs/csb637.h index f4fd808..efa2780 100644 --- a/include/configs/csb637.h +++ b/include/configs/csb637.h @@ -26,6 +26,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91C_MAIN_CLOCK 184320000 /* from 3.6864 MHz crystal (3686400 * 50) */ #define AT91C_MASTER_CLOCK 46080000 /* (AT91C_MAIN_CLOCK/4) peripheral clock */ @@ -126,7 +128,13 @@ #define CONFIG_SYS_ALT_MEMTEST 1 #define CONFIG_SYS_MEMTEST_SCRATCH CONFIG_SYS_MEMTEST_START + PHYS_SDRAM_SIZE - 4
-#define CONFIG_DRIVER_ETHER +#define CONFIG_NET_MULTI 1 +#ifdef CONFIG_NET_MULTI +#define CONFIG_DRIVER_AT91EMAC 1 +#define CONFIG_SYS_RX_ETH_BUFFER 8 +#else +#define CONFIG_DRIVER_ETHER 1 +#endif #define CONFIG_NET_RETRY_COUNT 20 #undef CONFIG_AT91C_USE_RMII
diff --git a/include/configs/kb9202.h b/include/configs/kb9202.h index 7dd81e6..41ec1d5 100644 --- a/include/configs/kb9202.h +++ b/include/configs/kb9202.h @@ -29,6 +29,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91C_MAIN_CLOCK 180000000 /* from 10 MHz crystal */ #define AT91C_MASTER_CLOCK 60000000 /* peripheral clock (AT91C_MASTER_CLOCK / 3) */ @@ -115,7 +117,13 @@ #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM #define CONFIG_SYS_MEMTEST_END CONFIG_SYS_MEMTEST_START + PHYS_SDRAM_SIZE - (512*1024)
#define CONFIG_SYS_FLASH_BASE 0x10000000 diff --git a/include/configs/m501sk.h b/include/configs/m501sk.h index 5c06642..26c2bcb 100644 --- a/include/configs/m501sk.h +++ b/include/configs/m501sk.h @@ -27,6 +27,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ /* from 18.432 MHz crystal (18432000 / 4 * 39) */ #define AT91C_MAIN_CLOCK 179712000 @@ -34,6 +36,7 @@ #define AT91C_MASTER_CLOCK 59904000 #define AT91_SLOW_CLOCK 32768 /* slow clock */
+#define CONFIG_AT91RM9200 1 /* It's an Atmel AT91RM9200 SoC */ #define CONFIG_AT91RM9200DK 1 /* on an AT91RM9200DK Board */ #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ #define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ @@ -166,7 +169,13 @@ /* CONFIG_SYS_MEMTEST_START + PHYS_SDRAM_SIZE - 262144 */ #define CONFIG_SYS_MEMTEST_END 0x00100000
diff --git a/include/configs/meesc.h b/include/configs/meesc.h index ab5cbca..621b606 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -31,6 +31,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* Common stuff */ #define CONFIG_SYS_HZ 1000 /* decrementer freq */ #define CONFIG_MEESC 1 /* Board is esd MEESC */ @@ -56,6 +58,8 @@ */
/* Console output */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 @@ -121,6 +125,7 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA22
/* Ethernet */ diff --git a/include/configs/mp2usb.h b/include/configs/mp2usb.h index 0c2ee60..3138b49 100644 --- a/include/configs/mp2usb.h +++ b/include/configs/mp2usb.h @@ -28,6 +28,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91C_MAIN_CLOCK 179712000 /* from 18.432 MHz crystal (18432000 / 4 * 45) */ #define AT91C_MASTER_CLOCK (AT91C_MAIN_CLOCK/3) /* peripheral clock */ @@ -181,7 +183,13 @@ #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM #define CONFIG_SYS_MEMTEST_END CONFIG_SYS_MEMTEST_START + PHYS_SDRAM_SIZE - 262144
diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 399d15f..65bc920 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -28,6 +28,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define AT91_CPU_NAME "AT91SAM9261"
@@ -157,6 +159,8 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 @@ -236,6 +240,9 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA16
+#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ + + /* NOR flash */ #define CONFIG_SYS_FLASH_CFI 1 #define CONFIG_FLASH_CFI_DRIVER 1 diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 0af1280..b44c713 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -28,6 +28,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + /* ARM asynchronous clock */ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO @@ -171,6 +173,8 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1 @@ -259,6 +263,7 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PB30
#define CONFIG_CMD_JFFS2 1 diff --git a/include/configs/sbc35_a9g20.h b/include/configs/sbc35_a9g20.h index f4b3477..3f0723f 100644 --- a/include/configs/sbc35_a9g20.h +++ b/include/configs/sbc35_a9g20.h @@ -26,6 +26,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + #if defined(CONFIG_SBC35_A9G20_NANDFLASH) || defined(CONFIG_SBC35_A9G20_EEPROM) #define CONFIG_SBC35_A9G20 #endif @@ -57,6 +59,8 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART #define CONFIG_USART0 #undef CONFIG_USART1 diff --git a/include/configs/tny_a9260.h b/include/configs/tny_a9260.h index 4ad081b..466d27b 100644 --- a/include/configs/tny_a9260.h +++ b/include/configs/tny_a9260.h @@ -30,6 +30,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_AT91_LEGACY + #if defined(CONFIG_TNY_A9260_NANDFLASH) || defined(CONFIG_TNY_A9260_EEPROM) #define CONFIG_TNY_A9260 #elif defined(CONFIG_TNY_A9G20_NANDFLASH) || defined(CONFIG_TNY_A9G20_EEPROM) @@ -66,6 +68,8 @@ /* * Hardware drivers */ +#define CONFIG_AT91_GPIO 1 + #define CONFIG_ATMEL_USART 1 #undef CONFIG_USART0 #undef CONFIG_USART1
Jens Scharsig
