[PATCH v2 1/1] riscv: reset after crash
If an exception occurs on ARM or x86, we call panic() which will try to reset the board. Do the same on RISC-V.
To avoid -Werror=format-zero-length move a '\n' to the string passed to panic. We don't need a message here as depending on CONFIG_PANIC_HANG we will either see
### ERROR ### Please RESET the board ###
or
resetting ...
as next message.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: Remove a superfluous message passed to panic(). --- arch/riscv/lib/interrupts.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/lib/interrupts.c b/arch/riscv/lib/interrupts.c index 8ff40f0f36..43b10a2b9b 100644 --- a/arch/riscv/lib/interrupts.c +++ b/arch/riscv/lib/interrupts.c @@ -27,7 +27,7 @@ static void show_efi_loaded_images(uintptr_t epc) static void show_regs(struct pt_regs *regs) { #ifdef CONFIG_SHOW_REGS - printf("SP: " REG_FMT " GP: " REG_FMT " TP: " REG_FMT "\n", + printf("\nSP: " REG_FMT " GP: " REG_FMT " TP: " REG_FMT "\n", regs->sp, regs->gp, regs->tp); printf("T0: " REG_FMT " T1: " REG_FMT " T2: " REG_FMT "\n", regs->t0, regs->t1, regs->t2); @@ -45,7 +45,7 @@ static void show_regs(struct pt_regs *regs) regs->s7, regs->s8, regs->s9); printf("S10: " REG_FMT " S11: " REG_FMT " T3: " REG_FMT "\n", regs->s10, regs->s11, regs->t3); - printf("T4: " REG_FMT " T5: " REG_FMT " T6: " REG_FMT "\n\n", + printf("T4: " REG_FMT " T5: " REG_FMT " T6: " REG_FMT "\n", regs->t4, regs->t5, regs->t6); #endif } @@ -79,12 +79,12 @@ static void _exit_trap(ulong code, ulong epc, ulong tval, struct pt_regs *regs) printf("EPC: " REG_FMT " RA: " REG_FMT " TVAL: " REG_FMT "\n", epc, regs->ra, tval); if (gd->flags & GD_FLG_RELOC) - printf("EPC: " REG_FMT " RA: " REG_FMT " reloc adjusted\n\n", + printf("EPC: " REG_FMT " RA: " REG_FMT " reloc adjusted\n", epc - gd->reloc_off, regs->ra - gd->reloc_off);
show_regs(regs); show_efi_loaded_images(epc); - hang(); + panic("\n"); }
int interrupt_init(void) -- 2.28.0
