[U-Boot] [PATCH 1/4] rsa: use new openssl API to create signature
Previous implementation of the rsa signature was using the openssl API EVP_Sign*, but the new openssl API EVP_DigestSign* is more flexible. So we move to this new API.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- lib/rsa/rsa-sign.c | 17 +++++++++++------ 1 file changed, 11 insertions(+), 6 deletions(-)
diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index 05ac67b..78e348e 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -393,7 +393,8 @@ static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, { EVP_PKEY *key; EVP_MD_CTX *context; - int size, ret = 0; + int ret = 0; + size_t size; uint8_t *sig; int i;
@@ -409,7 +410,7 @@ static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, size = EVP_PKEY_size(key); sig = malloc(size); if (!sig) { - fprintf(stderr, "Out of memory for signature (%d bytes)\n", + fprintf(stderr, "Out of memory for signature (%zu bytes)\n", size); ret = -ENOMEM; goto err_alloc; @@ -421,22 +422,26 @@ static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, goto err_create; } EVP_MD_CTX_init(context); - if (!EVP_SignInit(context, checksum_algo->calculate_sign())) { + if (EVP_DigestSignInit(context, NULL, + checksum_algo->calculate_sign(), + NULL, key) <= 0) { ret = rsa_err("Signer setup failed"); goto err_sign; }
for (i = 0; i < region_count; i++) { - if (!EVP_SignUpdate(context, region[i].data, region[i].size)) { + if (!EVP_DigestSignUpdate(context, region[i].data, + region[i].size)) { ret = rsa_err("Signing data failed"); goto err_sign; } }
- if (!EVP_SignFinal(context, sig, sig_size, key)) { + if (!EVP_DigestSignFinal(context, sig, &size)) { ret = rsa_err("Could not obtain signature"); goto err_sign; } + #if OPENSSL_VERSION_NUMBER < 0x10100000L || \ (defined(LIBRESSL_VERSION_NUMBER) && LIBRESSL_VERSION_NUMBER < 0x02070000fL) EVP_MD_CTX_cleanup(context); @@ -446,7 +451,7 @@ static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, EVP_MD_CTX_destroy(context); EVP_PKEY_free(key);
- debug("Got signature: %d bytes, expected %d\n", *sig_size, size); + debug("Got signature: %d bytes, expected %zu\n", *sig_size, size); *sigp = sig; *sig_size = size;
The rsa signature use a padding algorithm. By default, we use the padding pkcs-1.5. In order to add some new padding algorithm, we add a padding framework to manage several padding algorithm. The choice of the padding is done in the file .its.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- common/image-fit.c | 5 +++++ common/image-sig.c | 29 ++++++++++++++++++++++++++ include/image.h | 16 +++++++++++++++ include/u-boot/rsa.h | 13 ++++++++++++ lib/rsa/rsa-sign.c | 15 +++++++++++--- lib/rsa/rsa-verify.c | 57 ++++++++++++++++++++++++++++++++++------------------ tools/image-host.c | 4 ++++ 7 files changed, 116 insertions(+), 23 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 8d39a24..ac901e1 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -165,6 +165,7 @@ static void fit_image_print_data(const void *fit, int noffset, const char *p, uint8_t *value; int value_len; char *algo; + const char *padding; int required; int ret, i;
@@ -184,6 +185,10 @@ static void fit_image_print_data(const void *fit, int noffset, const char *p, printf(" (required)"); printf("\n");
+ padding = fdt_getprop(fit, noffset, "padding", NULL); + if (padding) + printf("%s %s padding: %s\n", p, type, padding); + ret = fit_image_hash_get_value(fit, noffset, &value, &value_len); printf("%s %s value: ", p, type); diff --git a/common/image-sig.c b/common/image-sig.c index 5a269d3..b7ca657 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -71,6 +71,13 @@ struct crypto_algo crypto_algos[] = {
+struct padding_algo padding_algos[] = { + { + .name = "pkcs-1.5", + .verify = padding_pkcs_15_verify, + }, +}; + struct checksum_algo *image_get_checksum_algo(const char *full_name) { int i; @@ -106,6 +113,21 @@ struct crypto_algo *image_get_crypto_algo(const char *full_name) return NULL; }
+struct padding_algo *image_get_padding_algo(const char *name) +{ + int i; + + if (!name) + return NULL; + + for (i = 0; i < ARRAY_SIZE(padding_algos); i++) { + if (!strcmp(padding_algos[i].name, name)) + return &padding_algos[i]; + } + + return NULL; +} + /** * fit_region_make_list() - Make a list of image regions * @@ -155,6 +177,7 @@ static int fit_image_setup_verify(struct image_sign_info *info, char **err_msgp) { char *algo_name; + const char *padding_name;
if (fdt_totalsize(fit) > CONFIG_FIT_SIGNATURE_MAX_SIZE) { *err_msgp = "Total size too large"; @@ -165,6 +188,11 @@ static int fit_image_setup_verify(struct image_sign_info *info, *err_msgp = "Can't get hash algo property"; return -1; } + + padding_name = fdt_getprop(fit, noffset, "padding", NULL); + if (!padding_name) + padding_name = RSA_DEFAULT_PADDING_NAME; + memset(info, '\0', sizeof(*info)); info->keyname = fdt_getprop(fit, noffset, "key-name-hint", NULL); info->fit = (void *)fit; @@ -172,6 +200,7 @@ static int fit_image_setup_verify(struct image_sign_info *info, info->name = algo_name; info->checksum = image_get_checksum_algo(algo_name); info->crypto = image_get_crypto_algo(algo_name); + info->padding = image_get_padding_algo(padding_name); info->fdt_blob = gd_fdt_blob(); info->required_keynode = required_keynode; printf("%s:%s", algo_name, info->keyname); diff --git a/include/image.h b/include/image.h index 3bb7d29..5c8154e 100644 --- a/include/image.h +++ b/include/image.h @@ -1099,6 +1099,7 @@ struct image_sign_info { int node_offset; /* Offset of signature node */ const char *name; /* Algorithm name */ struct checksum_algo *checksum; /* Checksum algorithm information */ + struct padding_algo *padding; /* Padding algorithm information */ struct crypto_algo *crypto; /* Crypto algorithm information */ const void *fdt_blob; /* FDT containing public keys */ int required_keynode; /* Node offset of key to use: -1=any */ @@ -1184,6 +1185,13 @@ struct crypto_algo { uint8_t *sig, uint sig_len); };
+struct padding_algo { + const char *name; + int (*verify)(struct image_sign_info *info, + uint8_t *pad, int pad_len, + const uint8_t *hash, int hash_len); +}; + /** * image_get_checksum_algo() - Look up a checksum algorithm * @@ -1201,6 +1209,14 @@ struct checksum_algo *image_get_checksum_algo(const char *full_name); struct crypto_algo *image_get_crypto_algo(const char *full_name);
/** + * image_get_padding_algo() - Look up a padding algorithm + * + * @param name Name of padding algorithm + * @return pointer to algorithm information, or NULL if not found + */ +struct padding_algo *image_get_padding_algo(const char *name); + +/** * fit_image_verify_required_sigs() - Verify signatures marked as 'required' * * @fit: FIT to check diff --git a/include/u-boot/rsa.h b/include/u-boot/rsa.h index 68bcb14..16b4c4c 100644 --- a/include/u-boot/rsa.h +++ b/include/u-boot/rsa.h @@ -97,6 +97,10 @@ static inline int rsa_add_verify_data(struct image_sign_info *info, int rsa_verify(struct image_sign_info *info, const struct image_region region[], int region_count, uint8_t *sig, uint sig_len); + +int padding_pkcs_15_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len); #else static inline int rsa_verify(struct image_sign_info *info, const struct image_region region[], int region_count, @@ -104,8 +108,17 @@ static inline int rsa_verify(struct image_sign_info *info, { return -ENXIO; } + +static inline int padding_pkcs_15_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len) +{ + return -ENXIO; +} #endif
+#define RSA_DEFAULT_PADDING_NAME "pkcs-1.5" + #define RSA2048_BYTES (2048 / 8) #define RSA4096_BYTES (4096 / 8)
diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index 78e348e..6aa0e2a 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -387,11 +387,13 @@ static void rsa_engine_remove(ENGINE *e) } }
-static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, +static int rsa_sign_with_key(RSA *rsa, struct padding_algo *padding_algo, + struct checksum_algo *checksum_algo, const struct image_region region[], int region_count, uint8_t **sigp, uint *sig_size) { EVP_PKEY *key; + EVP_PKEY_CTX *ckey; EVP_MD_CTX *context; int ret = 0; size_t size; @@ -422,7 +424,14 @@ static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, goto err_create; } EVP_MD_CTX_init(context); - if (EVP_DigestSignInit(context, NULL, + + ckey = EVP_PKEY_CTX_new(key, NULL); + if (!ckey) { + ret = rsa_err("EVP key context creation failed"); + goto err_create; + } + + if (EVP_DigestSignInit(context, &ckey, checksum_algo->calculate_sign(), NULL, key) <= 0) { ret = rsa_err("Signer setup failed"); @@ -488,7 +497,7 @@ int rsa_sign(struct image_sign_info *info, ret = rsa_get_priv_key(info->keydir, info->keyname, e, &rsa); if (ret) goto err_priv; - ret = rsa_sign_with_key(rsa, info->checksum, region, + ret = rsa_sign_with_key(rsa, info->padding, info->checksum, region, region_count, sigp, sig_len); if (ret) goto err_sign; diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index bc83354..279a9ba 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -57,31 +57,57 @@ static int rsa_verify_padding(const uint8_t *msg, const int pad_len, return ret; }
+int padding_pkcs_15_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len) +{ + struct checksum_algo *checksum = info->checksum; + int ret, pad_len = msg_len - checksum->checksum_len; + + /* Check pkcs1.5 padding bytes. */ + ret = rsa_verify_padding(msg, pad_len, checksum); + if (ret) { + debug("In RSAVerify(): Padding check failed!\n"); + return -EINVAL; + } + + /* Check hash. */ + if (memcmp((uint8_t *)msg + pad_len, hash, msg_len - pad_len)) { + debug("In RSAVerify(): Hash check failed!\n"); + return -EACCES; + } + + return 0; +} + /** * rsa_verify_key() - Verify a signature against some data using RSA Key * * Verify a RSA PKCS1.5 signature against an expected hash using * the RSA Key properties in prop structure. * + * @info: Specifies key and FIT information * @prop: Specifies key * @sig: Signature * @sig_len: Number of bytes in signature * @hash: Pointer to the expected hash * @key_len: Number of bytes in rsa key - * @algo: Checksum algo structure having information on DER encoding etc. * @return 0 if verified, -ve on error */ -static int rsa_verify_key(struct key_prop *prop, const uint8_t *sig, +static int rsa_verify_key(struct image_sign_info *info, + struct key_prop *prop, const uint8_t *sig, const uint32_t sig_len, const uint8_t *hash, - const uint32_t key_len, struct checksum_algo *algo) + const uint32_t key_len) { - int pad_len; int ret; #if !defined(USE_HOSTCC) struct udevice *mod_exp_dev; #endif + struct checksum_algo *checksum = info->checksum; + struct padding_algo *padding = info->padding; + int hash_len = checksum->checksum_len;
- if (!prop || !sig || !hash || !algo) + if (!prop || !sig || !hash || !checksum) return -EIO;
if (sig_len != (prop->num_bits / 8)) { @@ -89,7 +115,7 @@ static int rsa_verify_key(struct key_prop *prop, const uint8_t *sig, return -EINVAL; }
- debug("Checksum algorithm: %s", algo->name); + debug("Checksum algorithm: %s", checksum->name);
/* Sanity check for stack size */ if (sig_len > RSA_MAX_SIG_BITS / 8) { @@ -116,19 +142,10 @@ static int rsa_verify_key(struct key_prop *prop, const uint8_t *sig, return ret; }
- pad_len = key_len - algo->checksum_len; - - /* Check pkcs1.5 padding bytes. */ - ret = rsa_verify_padding(buf, pad_len, algo); + ret = padding->verify(info, buf, key_len, hash, hash_len); if (ret) { - debug("In RSAVerify(): Padding check failed!\n"); - return -EINVAL; - } - - /* Check hash. */ - if (memcmp((uint8_t *)buf + pad_len, hash, sig_len - pad_len)) { - debug("In RSAVerify(): Hash check failed!\n"); - return -EACCES; + debug("In RSAVerify(): padding check failed!\n"); + return ret; }
return 0; @@ -182,8 +199,8 @@ static int rsa_verify_with_keynode(struct image_sign_info *info, return -EFAULT; }
- ret = rsa_verify_key(&prop, sig, sig_len, hash, - info->crypto->key_len, info->checksum); + ret = rsa_verify_key(info, &prop, sig, sig_len, hash, + info->crypto->key_len);
return ret; } diff --git a/tools/image-host.c b/tools/image-host.c index 09e4f47..88b3295 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -157,6 +157,7 @@ static int fit_image_setup_sig(struct image_sign_info *info, { const char *node_name; char *algo_name; + const char *padding_name;
node_name = fit_get_name(fit, noffset, NULL); if (fit_image_hash_get_algo(fit, noffset, &algo_name)) { @@ -165,6 +166,8 @@ static int fit_image_setup_sig(struct image_sign_info *info, return -1; }
+ padding_name = fdt_getprop(fit, noffset, "padding", NULL); + memset(info, '\0', sizeof(*info)); info->keydir = keydir; info->keyname = fdt_getprop(fit, noffset, "key-name-hint", NULL); @@ -173,6 +176,7 @@ static int fit_image_setup_sig(struct image_sign_info *info, info->name = strdup(algo_name); info->checksum = image_get_checksum_algo(algo_name); info->crypto = image_get_crypto_algo(algo_name); + info->padding = image_get_padding_algo(padding_name); info->require_keys = require_keys; info->engine_id = engine_id; if (!info->checksum || !info->crypto) {
On 2 October 2018 at 10:32, Philippe Reynes philippe.reynes@softathome.com wrote:
Pleaseupdate the docs in doc/uImage with the new device-tree setting.
We add the support of the padding pss for rsa signature. This new padding is often recommended instead of pkcs-1.5.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- common/image-sig.c | 4 ++ include/u-boot/rsa.h | 11 ++++ lib/rsa/rsa-sign.c | 8 +++ lib/rsa/rsa-verify.c | 173 +++++++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 196 insertions(+)
diff --git a/common/image-sig.c b/common/image-sig.c index b7ca657..0aa1f2d 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -76,6 +76,10 @@ struct padding_algo padding_algos[] = { .name = "pkcs-1.5", .verify = padding_pkcs_15_verify, }, + { + .name = "pss", + .verify = padding_pss_verify, + } };
struct checksum_algo *image_get_checksum_algo(const char *full_name) diff --git a/include/u-boot/rsa.h b/include/u-boot/rsa.h index 16b4c4c..6193c10 100644 --- a/include/u-boot/rsa.h +++ b/include/u-boot/rsa.h @@ -101,6 +101,10 @@ int rsa_verify(struct image_sign_info *info, int padding_pkcs_15_verify(struct image_sign_info *info, uint8_t *msg, int msg_len, const uint8_t *hash, int hash_len); + +int padding_pss_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len); #else static inline int rsa_verify(struct image_sign_info *info, const struct image_region region[], int region_count, @@ -115,6 +119,13 @@ static inline int padding_pkcs_15_verify(struct image_sign_info *info, { return -ENXIO; } + +static inline int padding_pss_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len) +{ + return -ENXIO; +} #endif
#define RSA_DEFAULT_PADDING_NAME "pkcs-1.5" diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index 6aa0e2a..13c035e 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -438,6 +438,14 @@ static int rsa_sign_with_key(RSA *rsa, struct padding_algo *padding_algo, goto err_sign; }
+ if (padding_algo && !strcmp(padding_algo->name, "pss")) { + if (EVP_PKEY_CTX_set_rsa_padding(ckey, + RSA_PKCS1_PSS_PADDING) <= 0) { + ret = rsa_err("Signer padding setup failed"); + goto err_sign; + } + } + for (i = 0; i < region_count; i++) { if (!EVP_DigestSignUpdate(context, region[i].data, region[i].size)) { diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index 279a9ba..ca5c1fc 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -80,6 +80,179 @@ int padding_pkcs_15_verify(struct image_sign_info *info, return 0; }
+static void u32_i2osp(uint32_t val, uint8_t *buf) +{ + buf[0] = (uint8_t)((val >> 24) & 0xff); + buf[1] = (uint8_t)((val >> 16) & 0xff); + buf[2] = (uint8_t)((val >> 8) & 0xff); + buf[3] = (uint8_t)((val >> 0) & 0xff); +} + +int mfg(struct checksum_algo *checksum, uint8_t *seed, int seed_len, + uint8_t *output, int output_len) +{ + struct image_region region[2]; + int ret = 0, i, i_output = 0, region_count = 2; + uint32_t counter = 0; + uint8_t buf_counter[4], *tmp; + int hash_len = checksum->checksum_len; + + memset(output, 0, output_len); + + region[0].data = seed; + region[0].size = seed_len; + region[1].data = &buf_counter[0]; + region[1].size = 4; + + tmp = malloc(hash_len); + if (!tmp) { + debug("%s: can't allocate array tmp\n", __func__); + ret = -ENOMEM; + goto out; + } + + while (i_output < output_len) { + u32_i2osp(counter, &buf_counter[0]); + + ret = checksum->calculate(checksum->name, + region, region_count, + tmp); + if (ret < 0) { + debug("%s: Error in checksum calculation\n", __func__); + goto out; + } + + i = 0; + while ((i_output < output_len) && (i < hash_len)) { + output[i_output] = tmp[i]; + i_output++; + i++; + } + + counter++; + } + +out: + free(tmp); + return ret; +} + +int compute_hash_prime(struct checksum_algo *checksum, + uint8_t *pad, int pad_len, + uint8_t *hash, int hash_len, + uint8_t *salt, int salt_len, + uint8_t *hprime) +{ + struct image_region region[3]; + int ret, region_count = 3; + + region[0].data = pad; + region[0].size = pad_len; + region[1].data = hash; + region[1].size = hash_len; + region[2].data = salt; + region[2].size = salt_len; + + ret = checksum->calculate(checksum->name, region, region_count, hprime); + if (ret < 0) { + debug("%s: Error in checksum calculation\n", __func__); + goto out; + } + +out: + return ret; +} + +int padding_pss_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len) +{ + uint8_t *masked_db = NULL; + int masked_db_len = msg_len - hash_len - 1; + uint8_t *h = NULL, *hprime = NULL; + int h_len = hash_len; + uint8_t *db_mask = NULL; + int db_mask_len = masked_db_len; + uint8_t *db = NULL, *salt = NULL; + int db_len = masked_db_len, salt_len = msg_len - hash_len - 2; + uint8_t pad_zero[8] = { 0 }; + int ret, i, leftmost_bits = 1; + uint8_t leftmost_mask; + struct checksum_algo *checksum = info->checksum; + + /* first, allocate everything */ + masked_db = malloc(masked_db_len); + h = malloc(h_len); + db_mask = malloc(db_mask_len); + db = malloc(db_len); + salt = malloc(salt_len); + hprime = malloc(hash_len); + if (!masked_db || !h || !db_mask || !db || !salt || !hprime) { + printf("%s: can't allocate some buffer\n", __func__); + ret = -ENOMEM; + goto out; + } + + /* step 4: check if the last byte is 0xbc */ + if (msg[msg_len - 1] != 0xbc) { + printf("%s: invalid pss padding (0xbc is missing)\n", __func__); + ret = -EINVAL; + goto out; + } + + /* step 5 */ + memcpy(masked_db, msg, masked_db_len); + memcpy(h, msg + masked_db_len, h_len); + + /* step 6 */ + leftmost_mask = (0xff >> (8 - leftmost_bits)) << (8 - leftmost_bits); + if (masked_db[0] & leftmost_mask) { + printf("%s: invalid pss padding ", __func__); + printf("(leftmost bit of maskedDB not zero)\n"); + ret = -EINVAL; + goto out; + } + + /* step 7 */ + mfg(checksum, h, h_len, db_mask, db_mask_len); + + /* step 8 */ + for (i = 0; i < db_len; i++) + db[i] = masked_db[i] ^ db_mask[i]; + + /* step 9 */ + db[0] &= 0xff >> leftmost_bits; + + /* step 10 */ + if (db[0] != 0x01) { + printf("%s: invalid pss padding ", __func__); + printf("(leftmost byte of db isn't 0x01)\n"); + ret = EINVAL; + goto out; + } + + /* step 11 */ + memcpy(salt, &db[1], salt_len); + + /* step 12 & 13 */ + compute_hash_prime(checksum, pad_zero, 8, + (uint8_t *)hash, hash_len, + salt, salt_len, hprime); + + /* step 14 */ + ret = memcmp(h, hprime, hash_len); + +out: + free(hprime); + free(salt); + free(db); + free(db_mask); + free(h); + free(masked_db); + + return ret; +} + /** * rsa_verify_key() - Verify a signature against some data using RSA Key *
Hi Philippe,
Needs a doc update somewhere.
.name = "pss",
I think this feature should be controlled by a new Kconfig option as it presumably increases code size a bit.
return -ENXIO;
+} #endif
goto err_sign;
What is the name mfg? Can you make this a little longer please? Also, did you mean to export it or should it be static? Finally, it needs a function comment somewhere.
region[1].size = 4;
if (!tmp) {
ret = -ENOMEM;
goto out;
tmp);
if (ret < 0) {
goto out;
i = 0;
i_output++;
i++;
counter++;
+out:
free(tmp);
Please put a blank line before the final 'return' in a function.
return ret;
uint8_t *hprime)
if (ret < 0) {
goto out;
+out:
return ret;
h = malloc(h_len);
ret = -ENOMEM;
goto out;
ret = -EINVAL;
goto out;
/* step 5 */
/* step 6 */
ret = -EINVAL;
goto out;
/* step 7 */
/* step 8 */
/* step 9 */
/* step 10 */
ret = EINVAL;
goto out;
/* step 11 */
/* step 12 & 13 */
/* step 14 */
+out:
free(hprime);
free(salt);
free(db);
free(db_mask);
free(h);
free(masked_db);
return ret;
- rsa_verify_key() - Verify a signature against some data using RSA Key
-- 2.7.4
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- doc/uImage.FIT/signature.txt | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/doc/uImage.FIT/signature.txt b/doc/uImage.FIT/signature.txt index a765722..bfff6fd 100644 --- a/doc/uImage.FIT/signature.txt +++ b/doc/uImage.FIT/signature.txt @@ -106,6 +106,9 @@ When the image is signed, the following properties are optional:
- comment: Additional information about the signer or image
+- padding: The padding algorithm, it may be pkcs-1.5 or pss, + if no value is provided we assume pkcs-1.5 + For config bindings (see Signed Configurations below), the following additional properties are optional:
Please also adjust the vboot test to check this new feature.
Philippe Reynes
