[PATCH v3 1/4] cmd: add temperature command
Currently, there is no way for users to check the readings from thermal sensors from U-boot console, only some boards print it during boot.
So, lets add a simple "temperature" command that allows listing thermal uclass devices and getting their value.
Note that the thermal devices are intenionally probed if list is used as almost always they will not get probed otherwise and there is no way for users to manually call probe on a certain device from console.
Assumption is made that temperature is returned in degrees C and not milidegrees like in Linux as this is what most drivers seem to return.
Signed-off-by: Robert Marko robert.marko@sartura.hr Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v2: * Drop <dm/uclass-internal.h> by using uclass_get_device_by_name() * Make the unit clear in help * Expand Kconfig boolean and help * Drop degree symbol as test doesnt work with it. --- cmd/Kconfig | 6 ++++ cmd/Makefile | 1 + cmd/temperature.c | 85 +++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 92 insertions(+) create mode 100644 cmd/temperature.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 8ea064b8d2..4376909ca8 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1445,6 +1445,12 @@ config DEFAULT_SPI_MODE depends on CMD_SPI default 0
+config CMD_TEMPERATURE + bool "temperature - display the temperature from thermal sensors" + depends on DM_THERMAL + help + Provides a way to list thermal sensors and to get their readings. + config CMD_TSI148 bool "tsi148 - Command to access tsi148 device" help diff --git a/cmd/Makefile b/cmd/Makefile index 6e87522b62..141e440d01 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -152,6 +152,7 @@ obj-$(CONFIG_CMD_STRINGS) += strings.o obj-$(CONFIG_CMD_SMC) += smccc.o obj-$(CONFIG_CMD_SYSBOOT) += sysboot.o obj-$(CONFIG_CMD_STACKPROTECTOR_TEST) += stackprot_test.o +obj-$(CONFIG_CMD_TEMPERATURE) += temperature.o obj-$(CONFIG_CMD_TERMINAL) += terminal.o obj-$(CONFIG_CMD_TIME) += time.o obj-$(CONFIG_CMD_TIMER) += timer.o diff --git a/cmd/temperature.c b/cmd/temperature.c new file mode 100644 index 0000000000..420965de14 --- /dev/null +++ b/cmd/temperature.c @@ -0,0 +1,85 @@ +// SPDX-License-Identifier: GPL-2.0-or-later + +/* + * Copyright (c) 2022 Sartura Ltd. + * Written by Robert Marko robert.marko@sartura.hr + */ + +#include <common.h> +#include <command.h> +#include <dm.h> +#include <thermal.h> + +#define LIMIT_DEVNAME 30 + +static int do_get(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct udevice *dev; + int ret, temp; + + if (argc < 2) { + printf("thermal device not selected\n"); + return CMD_RET_FAILURE; + } + + ret = uclass_get_device_by_name(UCLASS_THERMAL, argv[1], &dev); + if (ret) { + printf("thermal device not found\n"); + return CMD_RET_FAILURE; + } + + ret = thermal_get_temp(dev, &temp); + if (ret) + return CMD_RET_FAILURE; + + printf("%s: %d C\n", dev->name, temp); + + return CMD_RET_SUCCESS; +} + +static int do_list(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct udevice *dev; + + printf("| %-*.*s| %-*.*s| %s\n", + LIMIT_DEVNAME, LIMIT_DEVNAME, "Device", + LIMIT_DEVNAME, LIMIT_DEVNAME, "Driver", + "Parent"); + + uclass_foreach_dev_probe(UCLASS_THERMAL, dev) { + printf("| %-*.*s| %-*.*s| %s\n", + LIMIT_DEVNAME, LIMIT_DEVNAME, dev->name, + LIMIT_DEVNAME, LIMIT_DEVNAME, dev->driver->name, + dev->parent->name); + } + + return CMD_RET_SUCCESS; +} + +static struct cmd_tbl temperature_subcmd[] = { + U_BOOT_CMD_MKENT(list, 1, 1, do_list, "", ""), + U_BOOT_CMD_MKENT(get, 2, 1, do_get, "", ""), +}; + +static int do_temperature(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct cmd_tbl *cmd; + + argc--; + argv++; + + cmd = find_cmd_tbl(argv[0], temperature_subcmd, ARRAY_SIZE(temperature_subcmd)); + if (!cmd || argc > cmd->maxargs) + return CMD_RET_USAGE; + + return cmd->cmd(cmdtp, flag, argc, argv); +} + +U_BOOT_CMD(temperature, CONFIG_SYS_MAXARGS, 1, do_temperature, + "thermal sensor temperature", + "list\t\tshow list of temperature sensors\n" + "get [thermal device name]\tprint temperature in degrees C" +);
Add documentation for the temperature command.
Signed-off-by: Robert Marko robert.marko@sartura.hr Reviewed-by: Simon Glass sjg@chromium.org --- doc/usage/cmd/temperature.rst | 50 +++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 51 insertions(+) create mode 100644 doc/usage/cmd/temperature.rst
diff --git a/doc/usage/cmd/temperature.rst b/doc/usage/cmd/temperature.rst new file mode 100644 index 0000000000..a5144ec50f --- /dev/null +++ b/doc/usage/cmd/temperature.rst @@ -0,0 +1,50 @@ +.. SPDX-License-Identifier: GPL-2.0-or-later + +temperature command +=================== + +Synopsis +-------- + +:: + + temperature list + temperature get [thermal device name] + +Description +----------- + +The *temperature* command is used to list thermal sensors and get their +readings. + +The 'temperature list' command diplays the available thermal devices. + +The 'temperature get' command is used to get the reading in degrees C from +the desired device which is selected by passing its device name. + + thermal device name + device name of thermal sensor to select + +Example +------- + +:: + + + => temperature list + | Device | Driver | Parent + | tmon@610508110 | sparx5-temp | axi@600000000 + => + => temperature get tmon@610508110 + tmon@610508110: 42 C + +Configuration +------------- + +The *temperature* command is only available if CONFIG_CMD_TEMPERATURE=y. + +Return value +------------ + +The return value $? is set to 0 (true) if the command succeeded and to 1 (false) +otherwise. diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 28f9683a3e..92967efdd2 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -63,6 +63,7 @@ Shell commands cmd/scp03 cmd/setexpr cmd/size + cmd/temperature cmd/true cmd/ums cmd/wdt
Provide a simple sandbox driver for the thermal uclass. It simply registers and returns 100 degrees C if requested.
Signed-off-by: Robert Marko robert.marko@sartura.hr Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v3: * Enable thermal class and temperature command in Sandbox SPL, flattree and noinstall defconfigs as well to fix make check failing --- arch/sandbox/dts/sandbox.dtsi | 4 ++++ arch/sandbox/dts/test.dts | 4 ++++ configs/sandbox_defconfig | 2 ++ configs/sandbox_flattree_defconfig | 2 ++ configs/sandbox_noinst_defconfig | 2 ++ configs/sandbox_spl_defconfig | 2 ++ drivers/thermal/Makefile | 1 + drivers/thermal/thermal_sandbox.c | 36 ++++++++++++++++++++++++++++++ 8 files changed, 53 insertions(+) create mode 100644 drivers/thermal/thermal_sandbox.c
diff --git a/arch/sandbox/dts/sandbox.dtsi b/arch/sandbox/dts/sandbox.dtsi index 56e6b38bfa..a7b6a010ea 100644 --- a/arch/sandbox/dts/sandbox.dtsi +++ b/arch/sandbox/dts/sandbox.dtsi @@ -439,6 +439,10 @@ sandbox_tee { compatible = "sandbox,tee"; }; + + thermal { + compatible = "sandbox,thermal"; + }; };
&cros_ec { diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 2761588f0d..e7cc5384d5 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -1683,6 +1683,10 @@ compatible = "sandbox,regmap_test"; }; }; + + thermal { + compatible = "sandbox,thermal"; + }; };
#include "sandbox_pmic.dtsi" diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index ab5d3f19bf..80397a4a38 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -77,6 +77,7 @@ CONFIG_CMD_PCI=y CONFIG_CMD_READ=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SPI=y +CONFIG_CMD_TEMPERATURE=y CONFIG_CMD_USB=y CONFIG_CMD_AXI=y CONFIG_CMD_SETEXPR_FMT=y @@ -280,6 +281,7 @@ CONFIG_SYSINFO=y CONFIG_SYSINFO_SANDBOX=y CONFIG_SYSINFO_GPIO=y CONFIG_SYSRESET=y +CONFIG_DM_THERMAL=y CONFIG_TIMER=y CONFIG_TIMER_EARLY=y CONFIG_SANDBOX_TIMER=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index a8b439faa9..4c206afe53 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SPI=y +CONFIG_CMD_TEMPERATURE=y CONFIG_CMD_USB=y CONFIG_BOOTP_DNS2=y CONFIG_CMD_TFTPPUT=y @@ -185,6 +186,7 @@ CONFIG_SYSINFO=y CONFIG_SYSINFO_SANDBOX=y CONFIG_SYSINFO_GPIO=y CONFIG_SYSRESET=y +CONFIG_DM_THERMAL=y CONFIG_TIMER=y CONFIG_TIMER_EARLY=y CONFIG_SANDBOX_TIMER=y diff --git a/configs/sandbox_noinst_defconfig b/configs/sandbox_noinst_defconfig index 3d34d81731..c3d84bc61c 100644 --- a/configs/sandbox_noinst_defconfig +++ b/configs/sandbox_noinst_defconfig @@ -62,6 +62,7 @@ CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SPI=y +CONFIG_CMD_TEMPERATURE=y CONFIG_CMD_USB=y CONFIG_BOOTP_DNS2=y CONFIG_CMD_TFTPPUT=y @@ -212,6 +213,7 @@ CONFIG_SYSINFO_SANDBOX=y CONFIG_SYSINFO_GPIO=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y +CONFIG_DM_THERMAL=y CONFIG_TIMER=y CONFIG_TIMER_EARLY=y CONFIG_SANDBOX_TIMER=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 76e8acd126..53c48d1285 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -62,6 +62,7 @@ CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SPI=y +CONFIG_CMD_TEMPERATURE=y CONFIG_CMD_USB=y CONFIG_BOOTP_DNS2=y CONFIG_CMD_TFTPPUT=y @@ -215,6 +216,7 @@ CONFIG_SYSINFO_SANDBOX=y CONFIG_SYSINFO_GPIO=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y +CONFIG_DM_THERMAL=y CONFIG_TIMER=y CONFIG_TIMER_EARLY=y CONFIG_SANDBOX_TIMER=y diff --git a/drivers/thermal/Makefile b/drivers/thermal/Makefile index 6dda62bcd1..f2ee1df394 100644 --- a/drivers/thermal/Makefile +++ b/drivers/thermal/Makefile @@ -4,6 +4,7 @@ # Author: Nitin Garg nitin.garg@freescale.com
obj-$(CONFIG_DM_THERMAL) += thermal-uclass.o +obj-$(CONFIG_SANDBOX) += thermal_sandbox.o obj-$(CONFIG_IMX_THERMAL) += imx_thermal.o obj-$(CONFIG_IMX_SCU_THERMAL) += imx_scu_thermal.o obj-$(CONFIG_SPARX5_THERMAL) += sparx5-temp.o diff --git a/drivers/thermal/thermal_sandbox.c b/drivers/thermal/thermal_sandbox.c new file mode 100644 index 0000000000..acc364feb0 --- /dev/null +++ b/drivers/thermal/thermal_sandbox.c @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2022 Sartura Ltd. + * Written by Robert Marko robert.marko@sartura.hr + * + * Sandbox driver for the thermal uclass. + */ + +#include <common.h> +#include <dm.h> +#include <thermal.h> + +int sandbox_thermal_get_temp(struct udevice *dev, int *temp) +{ + /* Simply return 100°C */ + *temp = 100; + + return 0; +} + +static const struct dm_thermal_ops sandbox_thermal_ops = { + .get_temp = sandbox_thermal_get_temp, +}; + +static const struct udevice_id sandbox_thermal_ids[] = { + { .compatible = "sandbox,thermal" }, + { } +}; + +U_BOOT_DRIVER(thermal_sandbox) = { + .name = "thermal-sandbox", + .id = UCLASS_THERMAL, + .of_match = sandbox_thermal_ids, + .ops = &sandbox_thermal_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Add simple test for the temperature command.
Signed-off-by: Robert Marko robert.marko@sartura.hr Reviewed-by: Simon Glass sjg@chromium.org --- test/cmd/Makefile | 1 + test/cmd/temperature.c | 39 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 40 insertions(+) create mode 100644 test/cmd/temperature.c
diff --git a/test/cmd/Makefile b/test/cmd/Makefile index c331757425..f9493357a5 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -13,3 +13,4 @@ obj-$(CONFIG_CMD_MEM_SEARCH) += mem_search.o obj-$(CONFIG_CMD_PINMUX) += pinmux.o obj-$(CONFIG_CMD_PWM) += pwm.o obj-$(CONFIG_CMD_SETEXPR) += setexpr.o +obj-$(CONFIG_CMD_TEMPERATURE) += temperature.o diff --git a/test/cmd/temperature.c b/test/cmd/temperature.c new file mode 100644 index 0000000000..2a1ea0611d --- /dev/null +++ b/test/cmd/temperature.c @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Executes tests for temperature command + * + * Copyright (C) 2022 Sartura Ltd. + */ + +#include <common.h> +#include <command.h> +#include <dm.h> +#include <dm/test.h> +#include <test/test.h> +#include <test/ut.h> + +static int dm_test_cmd_temperature(struct unit_test_state *uts) +{ + struct udevice *dev; + + ut_assertok(uclass_get_device(UCLASS_THERMAL, 0, &dev)); + ut_assertnonnull(dev); + + ut_assertok(console_record_reset_enable()); + + /* Test that "temperature list" shows the sandbox device */ + ut_assertok(run_command("temperature list", 0)); + ut_assert_nextline("| Device | Driver | Parent"); + ut_assert_nextline("| thermal | thermal-sandbox | root_driver"); + ut_assert_console_end(); + + /* Test that "temperature get thermal" returns expected value */ + console_record_reset(); + ut_assertok(run_command("temperature get thermal", 0)); + ut_assert_nextline("thermal: 100 C"); + ut_assert_console_end(); + + return 0; +} + +DM_TEST(dm_test_cmd_temperature, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC);
Robert Marko
