[U-Boot] [PATCH] efi_loader: move efi_init_obj_list() to a new efi_setup.c
The function, efi_init_obj_list(), can be shared in different pseudo efi applications, like bootefi/bootmgr as well as my efishell. Moreover, it will be utilized to extend efi initialization, for example, my "removable disk support" patch and "capsule-on-disk support" patch in the future.
So with this patch, it will be moved to a new file, efi_setup.c, under lib/efi_loader and exported, making no changes in functionality.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- cmd/bootefi.c | 75 ------------------------- include/efi_loader.h | 2 + lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_setup.c | 112 +++++++++++++++++++++++++++++++++++++ 4 files changed, 115 insertions(+), 75 deletions(-) create mode 100644 lib/efi_loader/efi_setup.c
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 38679ffc56a9..7012d72ab50d 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -30,84 +30,9 @@ DECLARE_GLOBAL_DATA_PTR;
#define OBJ_LIST_NOT_INITIALIZED 1
-static efi_status_t efi_obj_list_initialized = OBJ_LIST_NOT_INITIALIZED; - static struct efi_device_path *bootefi_image_path; static struct efi_device_path *bootefi_device_path;
-/* Initialize and populate EFI object list */ -efi_status_t efi_init_obj_list(void) -{ - efi_status_t ret = EFI_SUCCESS; - - /* - * On the ARM architecture gd is mapped to a fixed register (r9 or x18). - * As this register may be overwritten by an EFI payload we save it here - * and restore it on every callback entered. - */ - efi_save_gd(); - - /* Initialize once only */ - if (efi_obj_list_initialized != OBJ_LIST_NOT_INITIALIZED) - return efi_obj_list_initialized; - - /* Initialize system table */ - ret = efi_initialize_system_table(); - if (ret != EFI_SUCCESS) - goto out; - - /* Initialize root node */ - ret = efi_root_node_register(); - if (ret != EFI_SUCCESS) - goto out; - - /* Initialize EFI driver uclass */ - ret = efi_driver_init(); - if (ret != EFI_SUCCESS) - goto out; - - ret = efi_console_register(); - if (ret != EFI_SUCCESS) - goto out; -#ifdef CONFIG_PARTITIONS - ret = efi_disk_register(); - if (ret != EFI_SUCCESS) - goto out; -#endif -#if defined(CONFIG_LCD) || defined(CONFIG_DM_VIDEO) - ret = efi_gop_register(); - if (ret != EFI_SUCCESS) - goto out; -#endif -#ifdef CONFIG_NET - ret = efi_net_register(); - if (ret != EFI_SUCCESS) - goto out; -#endif -#ifdef CONFIG_GENERATE_ACPI_TABLE - ret = efi_acpi_register(); - if (ret != EFI_SUCCESS) - goto out; -#endif -#ifdef CONFIG_GENERATE_SMBIOS_TABLE - ret = efi_smbios_register(); - if (ret != EFI_SUCCESS) - goto out; -#endif - ret = efi_watchdog_register(); - if (ret != EFI_SUCCESS) - goto out; - - /* Initialize EFI runtime services */ - ret = efi_reset_system_init(); - if (ret != EFI_SUCCESS) - goto out; - -out: - efi_obj_list_initialized = ret; - return ret; -} - /* * Allow unaligned memory access. * diff --git a/include/efi_loader.h b/include/efi_loader.h index 16633d6da0d5..dd68cfce5c65 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -252,6 +252,8 @@ extern struct list_head efi_obj_list; /* List of all events */ extern struct list_head efi_events;
+/* Initialize efi execution environment */ +efi_status_t efi_init_obj_list(void); /* Called by bootefi to initialize root node */ efi_status_t efi_root_node_register(void); /* Called by bootefi to initialize runtime */ diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 26b999bf7c51..3ba539314aee 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -29,6 +29,7 @@ obj-y += efi_image_loader.o obj-y += efi_memory.o obj-y += efi_root_node.o obj-y += efi_runtime.o +obj-y += efi_setup.o obj-y += efi_unicode_collation.o obj-y += efi_variable.o obj-y += efi_watchdog.o diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c new file mode 100644 index 000000000000..215c163380ee --- /dev/null +++ b/lib/efi_loader/efi_setup.c @@ -0,0 +1,112 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * EFI setup code + * + * Copyright (c) 2016 Alexander Graf + * Copyright (c) 2018 AKASHI Takahiro, Linaro Limited + */ + +#if 1 /* TODO: cleanup */ +#include <common.h> +#include <efi_loader.h> +#else +#include <charset.h> +#include <common.h> +#include <command.h> +#include <dm.h> +#include <efi_loader.h> +#include <efi_selftest.h> +#include <errno.h> +#include <linux/libfdt.h> +#include <linux/libfdt_env.h> +#include <mapmem.h> +#include <memalign.h> +#include <asm/global_data.h> +#include <asm-generic/sections.h> +#include <asm-generic/unaligned.h> +#include <linux/linkage.h> + +#ifdef CONFIG_ARMV7_NONSEC +#include <asm/armv7.h> +#include <asm/secure.h> +#endif +#endif + +DECLARE_GLOBAL_DATA_PTR; + +#define OBJ_LIST_NOT_INITIALIZED 1 + +static efi_status_t efi_obj_list_initialized = OBJ_LIST_NOT_INITIALIZED; + +/* Initialize and populate EFI object list */ +efi_status_t efi_init_obj_list(void) +{ + efi_status_t ret = EFI_SUCCESS; + + /* + * On the ARM architecture gd is mapped to a fixed register (r9 or x18). + * As this register may be overwritten by an EFI payload we save it here + * and restore it on every callback entered. + */ + efi_save_gd(); + + /* Initialize once only */ + if (efi_obj_list_initialized != OBJ_LIST_NOT_INITIALIZED) + return efi_obj_list_initialized; + + /* Initialize system table */ + ret = efi_initialize_system_table(); + if (ret != EFI_SUCCESS) + goto out; + + /* Initialize root node */ + ret = efi_root_node_register(); + if (ret != EFI_SUCCESS) + goto out; + + /* Initialize EFI driver uclass */ + ret = efi_driver_init(); + if (ret != EFI_SUCCESS) + goto out; + + ret = efi_console_register(); + if (ret != EFI_SUCCESS) + goto out; +#ifdef CONFIG_PARTITIONS + ret = efi_disk_register(); + if (ret != EFI_SUCCESS) + goto out; +#endif +#if defined(CONFIG_LCD) || defined(CONFIG_DM_VIDEO) + ret = efi_gop_register(); + if (ret != EFI_SUCCESS) + goto out; +#endif +#ifdef CONFIG_NET + ret = efi_net_register(); + if (ret != EFI_SUCCESS) + goto out; +#endif +#ifdef CONFIG_GENERATE_ACPI_TABLE + ret = efi_acpi_register(); + if (ret != EFI_SUCCESS) + goto out; +#endif +#ifdef CONFIG_GENERATE_SMBIOS_TABLE + ret = efi_smbios_register(); + if (ret != EFI_SUCCESS) + goto out; +#endif + ret = efi_watchdog_register(); + if (ret != EFI_SUCCESS) + goto out; + + /* Initialize EFI runtime services */ + ret = efi_reset_system_init(); + if (ret != EFI_SUCCESS) + goto out; + +out: + efi_obj_list_initialized = ret; + return ret; +}
- efi_save_gd();
goto out;
goto out;
goto out;
goto out;
goto out;
goto out;
goto out;
goto out;
goto out;
-#endif
goto out;
goto out;
-out:
- return ret;
- Allow unaligned memory access.
- EFI setup code
- Copyright (c) 2016 Alexander Graf
- Copyright (c) 2018 AKASHI Takahiro, Linaro Limited
Ahem ... :)
Alex
- efi_save_gd();
goto out;
goto out;
goto out;
goto out;
goto out;
goto out;
goto out;
goto out;
goto out;
-#endif
goto out;
goto out;
-out:
- return ret;
- EFI setup code
Ahem ... :)
Ah, thanks! # I must have had bunch of cleanups.
-Takahiro Akashi
Alex
AKASHI Takahiro
Alexander Graf
