[PATCH v2 00/25] arm: Introduce Marvell/Cavium OcteonTX/TX2
This series will add support for OcteonTX and OcteonTX2 processsor based platforms. The Marvell/Cavium Octeon-TX 64-bit ARM based SoCs include the CN80XX, CN81XX and CN83XX while Octeon-TX2 64-bit ARM based SoCs include support for CN96XX and CN95XX. These SoC's have peripheral drivers based on PCI ECAM.
Some comments on the individual patches: [1 -13] Add requied changes to PCI framework [15 - 16] Add OcteonTX/TX2 platform header files [18 - 23] Add OcteonTX/TX2 drivers [24 - 25] Add OcteonTX/TX2 board files and configurations
Update from RFC -> v1 (Stefan): I took over upstreaming the patchset from Suneel. Suneel addressed some of the review comments. I addressed some more.
Some of the drivers originally included in this patchset have already been integrated into mainline (like I2C) and some are part of the MIPS Octeon patchset mentioned above. The reason being, that MIPS Octeon and Octen TX/TX2 share most of the peripherals, so a re-use of the drivers in all Octeon platforms makes much sense.
Thanks, Stefan
Changes in v2: - Add Reviewed-by tag from Simon - New patch - Add Reviewed-by tag from Simon - Split changes in board/renesas/rcar-common/common.c into separate patch - Add Reviewed-by tag from Simon - Correct patch subject - Correct patch description in commit text - Minor spelling update - Add Reviewed-by tag from Simon - Add sandbox test - Add Reviewed-by tag from Simon - Add Reviewed-by tag from Simon - Add Reviewed-by tag from Simon - Add note about adding a Kconfig option for AHCI quirks, once there are multiple quirks - Add Reviewed-by tag from Simon - Add comments to enum declaration and "type" declaration - Return -EINVAL in default case statement for unsupported length - Add helper function octeontx_bdf_invalid() and return -EPERM in case of an errror - Use livetree API - Remove local mmc_power_init() call - Add Reviewed-by tag from Simon - Add CORE0_POKE_OFFSET_MASK and calculate poke register address in _probe() instead of repeatedly in _reset() - Slightly change the Kconfig entry: use "default y", it already depends on "WDT && (ARCH_OCTEONTX || ARCH_OCTEONTX2)" - Select CONFIG_OF_LIVE - Select CONFIG_OF_LIVE
Changes in v1: - Add return value description to function prototype in header - Changed from using be32_to_cpup() to fdt32_to_cpu() - New patch - New patch, replaces increase of MAX_PCI_REGIONS to 10 - Change patch subject - Change patch subject - Change patch subject - Enhance Kconfig help descrition - Use if() instead of #if - Change patch subject - Change patch subject - Enhance commit text: expanded the abbreviations - Changed some printf() to debug() - Changed 0 to '\0' in memset() - Comments for variables in struct pci_child_platdata added - Comments for newly introduced functions added in prototype / header - Change patch subject - Fixed multi-line comment style - Moved "feature" into new function which is only called, when CONFIG_PCI_SRIOV is enabled, so that the code is not increased in all cases - Changed variable declaration to use reverse xmas tree order - Change patch subject - Fixed multi-line comment style - Added CONFIG_PCI_ARID and enabled the new code optionally, so that the code size is not increased in all cases - New patch - Change patch subject - Add small commit text - Also add clr/setbits_64 (without endianess extension), which is needed for the updated Octeon device drivers - Change patch subject - Change patch subject - Change patch subject - Use constants from pci_ids.h instead of hardcoded values - Change patch subject - Remove inclusion of common.h - Remove #ifdef's and use driver specific data instead - Add comments to struct - Add some helper functions to reduce code size - Misc coding style changes (blank lines etc) - Use debug() instead of printf() in some cases - Change patch subject - Rebased on latest TOT - Removed inclusion of common.h - Fix most checkpatch errors / warnings (use IS_ENABLED etc) - Change patch subject - Change patch subject - Rebased on latest TOT - Removed inclusion of common.h - Change patch subject - Rebased on latest TOT - Removed inclusion of common.h - Change patch subject - Remove inclusion of common.h - Remove global wdt_dev as its unused - Remove #ifdef's - Remove optional fixed register access - only use address passed via DT while probing - Use dev_remap_addr() instead of dev_read_addr_index() - Changed patch subject - Rebased on latest TOT - Removed inclusion of common.h - Moved MEMTEST defines to Kconfig - *.c files checkpatch cleanup - Changed patch subject - Rebased on latest TOT - Removed inclusion of common.h - Moved MEMTEST defines to Kconfig - *.c files checkpatch cleanup - Add go_uboot cmd for U-Boot starting from RAM
Stefan Roese (4): dm: core: Add API to read PCI bus-range property pci: pci-uclass: Remove #ifdef CONFIG_NR_DRAM_BANKS as its always set ARM: renesas: Drop unnecessary function ft_board_setup() pci: pci-uclass: Dynamically allocate the PCI regions
Suneel Garapati (21): fdtdec: Add API to read pci bus-range property pci: pci-uclass: Fix incorrect argument in map_physmem pci: pci-uclass: Make DT subnode parse optional pci: pci-uclass: Add multi entry support for memory regions pci: pci-uclass: Add support for Enhanced Allocation in Bridges pci: pci-uclass: Add support for Single-Root I/O Virtualization pci: pci-uclass: Add VF BAR map support for Enhanced Allocation pci: pci-uclass: Add support for Alternate-RoutingID capability pci: pci-uclass: Check validity of ofnode arm: include/asm/io.h: Add 64bit clrbits and setbits helpers arm: octeontx: Add headers for OcteonTX arm: octeontx2: Add headers for OcteonTX2 ata: ahci: Add BAR index quirk for Cavium PCI SATA device pci: Add PCI controller driver for OcteonTX / TX2 mmc: Add MMC controller driver for OcteonTX / TX2 mtd: nand: Add NAND controller driver for OcteonTX net: Add NIC controller driver for OcteonTX net: Add NIC controller driver for OcteonTX2 watchdog: Add reset support for OcteonTX / TX2 arm: octeontx: Add support for OcteonTX SoC platforms arm: octeontx2: Add support for OcteonTX2 SoC platforms
arch/arm/Kconfig | 24 + arch/arm/Makefile | 2 + arch/arm/include/asm/arch-octeontx/board.h | 123 + arch/arm/include/asm/arch-octeontx/clock.h | 25 + .../asm/arch-octeontx/csrs/csrs-mio_emm.h | 1193 ++ .../include/asm/arch-octeontx/csrs/csrs-xcv.h | 428 + arch/arm/include/asm/arch-octeontx/gpio.h | 6 + arch/arm/include/asm/arch-octeontx/smc.h | 20 + arch/arm/include/asm/arch-octeontx/soc.h | 33 + arch/arm/include/asm/arch-octeontx2/board.h | 128 + arch/arm/include/asm/arch-octeontx2/clock.h | 24 + .../asm/arch-octeontx2/csrs/csrs-cgx.h | 7851 ++++++++++++ .../asm/arch-octeontx2/csrs/csrs-lmt.h | 60 + .../asm/arch-octeontx2/csrs/csrs-mio_emm.h | 1193 ++ .../asm/arch-octeontx2/csrs/csrs-nix.h | 10404 ++++++++++++++++ .../asm/arch-octeontx2/csrs/csrs-npa.h | 2294 ++++ .../asm/arch-octeontx2/csrs/csrs-npc.h | 1629 +++ .../asm/arch-octeontx2/csrs/csrs-rvu.h | 2276 ++++ arch/arm/include/asm/arch-octeontx2/gpio.h | 6 + arch/arm/include/asm/arch-octeontx2/smc-id.h | 32 + arch/arm/include/asm/arch-octeontx2/smc.h | 18 + arch/arm/include/asm/arch-octeontx2/soc.h | 33 + arch/arm/include/asm/io.h | 16 + arch/arm/mach-octeontx/Kconfig | 23 + arch/arm/mach-octeontx/Makefile | 9 + arch/arm/mach-octeontx/clock.c | 35 + arch/arm/mach-octeontx/cpu.c | 76 + arch/arm/mach-octeontx/lowlevel_init.S | 33 + arch/arm/mach-octeontx2/Kconfig | 23 + arch/arm/mach-octeontx2/Makefile | 9 + arch/arm/mach-octeontx2/clock.c | 35 + arch/arm/mach-octeontx2/config.mk | 4 + arch/arm/mach-octeontx2/cpu.c | 72 + arch/arm/mach-octeontx2/lowlevel_init.S | 33 + arch/sandbox/dts/test.dts | 5 +- board/Marvell/octeontx/Kconfig | 14 + board/Marvell/octeontx/MAINTAINERS | 8 + board/Marvell/octeontx/Makefile | 9 + board/Marvell/octeontx/board-fdt.c | 311 + board/Marvell/octeontx/board.c | 152 + board/Marvell/octeontx/smc.c | 25 + board/Marvell/octeontx/soc-utils.c | 50 + board/Marvell/octeontx2/Kconfig | 14 + board/Marvell/octeontx2/MAINTAINERS | 8 + board/Marvell/octeontx2/Makefile | 9 + board/Marvell/octeontx2/board-fdt.c | 221 + board/Marvell/octeontx2/board.c | 247 + board/Marvell/octeontx2/smc.c | 58 + board/Marvell/octeontx2/soc-utils.c | 49 + board/renesas/rcar-common/common.c | 48 - configs/octeontx2_95xx_defconfig | 105 + configs/octeontx2_96xx_defconfig | 131 + configs/octeontx_81xx_defconfig | 134 + configs/octeontx_83xx_defconfig | 129 + configs/sandbox_defconfig | 1 + drivers/ata/ahci.c | 15 + drivers/core/read.c | 17 + drivers/mmc/Kconfig | 9 + drivers/mmc/Makefile | 1 + drivers/mmc/octeontx_hsmmc.c | 3897 ++++++ drivers/mmc/octeontx_hsmmc.h | 207 + drivers/mtd/nand/raw/Kconfig | 16 + drivers/mtd/nand/raw/Makefile | 2 + drivers/mtd/nand/raw/octeontx_bch.c | 426 + drivers/mtd/nand/raw/octeontx_bch.h | 133 + drivers/mtd/nand/raw/octeontx_bch_regs.h | 169 + drivers/mtd/nand/raw/octeontx_nand.c | 2264 ++++ drivers/net/Kconfig | 31 + drivers/net/Makefile | 4 + drivers/net/octeontx/Makefile | 9 + drivers/net/octeontx/bgx.c | 1572 +++ drivers/net/octeontx/bgx.h | 259 + drivers/net/octeontx/nic.h | 510 + drivers/net/octeontx/nic_main.c | 780 ++ drivers/net/octeontx/nic_reg.h | 252 + drivers/net/octeontx/nicvf_main.c | 583 + drivers/net/octeontx/nicvf_queues.c | 1142 ++ drivers/net/octeontx/nicvf_queues.h | 355 + drivers/net/octeontx/q_struct.h | 697 ++ drivers/net/octeontx/smi.c | 383 + drivers/net/octeontx/xcv.c | 129 + drivers/net/octeontx2/Makefile | 11 + drivers/net/octeontx2/cgx.c | 298 + drivers/net/octeontx2/cgx.h | 107 + drivers/net/octeontx2/cgx_intf.c | 717 ++ drivers/net/octeontx2/cgx_intf.h | 450 + drivers/net/octeontx2/lmt.h | 51 + drivers/net/octeontx2/nix.c | 833 ++ drivers/net/octeontx2/nix.h | 355 + drivers/net/octeontx2/nix_af.c | 1104 ++ drivers/net/octeontx2/npc.h | 92 + drivers/net/octeontx2/rvu.h | 121 + drivers/net/octeontx2/rvu_af.c | 173 + drivers/net/octeontx2/rvu_common.c | 73 + drivers/net/octeontx2/rvu_pf.c | 118 + drivers/pci/Kconfig | 37 + drivers/pci/Makefile | 1 + drivers/pci/pci-uclass.c | 288 +- drivers/pci/pci_octeontx.c | 364 + drivers/watchdog/Kconfig | 10 + drivers/watchdog/Makefile | 1 + drivers/watchdog/octeontx_wdt.c | 66 + include/configs/octeontx2_common.h | 72 + include/configs/octeontx_common.h | 89 + include/dm/read.h | 12 + include/fdtdec.h | 13 + include/pci.h | 45 +- lib/fdtdec.c | 16 + test/dm/pci.c | 22 + 109 files changed, 49204 insertions(+), 95 deletions(-) create mode 100644 arch/arm/include/asm/arch-octeontx/board.h create mode 100644 arch/arm/include/asm/arch-octeontx/clock.h create mode 100644 arch/arm/include/asm/arch-octeontx/csrs/csrs-mio_emm.h create mode 100644 arch/arm/include/asm/arch-octeontx/csrs/csrs-xcv.h create mode 100644 arch/arm/include/asm/arch-octeontx/gpio.h create mode 100644 arch/arm/include/asm/arch-octeontx/smc.h create mode 100644 arch/arm/include/asm/arch-octeontx/soc.h create mode 100644 arch/arm/include/asm/arch-octeontx2/board.h create mode 100644 arch/arm/include/asm/arch-octeontx2/clock.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-cgx.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-lmt.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-mio_emm.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-nix.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-npa.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-npc.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-rvu.h create mode 100644 arch/arm/include/asm/arch-octeontx2/gpio.h create mode 100644 arch/arm/include/asm/arch-octeontx2/smc-id.h create mode 100644 arch/arm/include/asm/arch-octeontx2/smc.h create mode 100644 arch/arm/include/asm/arch-octeontx2/soc.h create mode 100644 arch/arm/mach-octeontx/Kconfig create mode 100644 arch/arm/mach-octeontx/Makefile create mode 100644 arch/arm/mach-octeontx/clock.c create mode 100644 arch/arm/mach-octeontx/cpu.c create mode 100644 arch/arm/mach-octeontx/lowlevel_init.S create mode 100644 arch/arm/mach-octeontx2/Kconfig create mode 100644 arch/arm/mach-octeontx2/Makefile create mode 100644 arch/arm/mach-octeontx2/clock.c create mode 100644 arch/arm/mach-octeontx2/config.mk create mode 100644 arch/arm/mach-octeontx2/cpu.c create mode 100644 arch/arm/mach-octeontx2/lowlevel_init.S create mode 100644 board/Marvell/octeontx/Kconfig create mode 100644 board/Marvell/octeontx/MAINTAINERS create mode 100644 board/Marvell/octeontx/Makefile create mode 100644 board/Marvell/octeontx/board-fdt.c create mode 100644 board/Marvell/octeontx/board.c create mode 100644 board/Marvell/octeontx/smc.c create mode 100644 board/Marvell/octeontx/soc-utils.c create mode 100644 board/Marvell/octeontx2/Kconfig create mode 100644 board/Marvell/octeontx2/MAINTAINERS create mode 100644 board/Marvell/octeontx2/Makefile create mode 100644 board/Marvell/octeontx2/board-fdt.c create mode 100644 board/Marvell/octeontx2/board.c create mode 100644 board/Marvell/octeontx2/smc.c create mode 100644 board/Marvell/octeontx2/soc-utils.c create mode 100644 configs/octeontx2_95xx_defconfig create mode 100644 configs/octeontx2_96xx_defconfig create mode 100644 configs/octeontx_81xx_defconfig create mode 100644 configs/octeontx_83xx_defconfig create mode 100644 drivers/mmc/octeontx_hsmmc.c create mode 100644 drivers/mmc/octeontx_hsmmc.h create mode 100644 drivers/mtd/nand/raw/octeontx_bch.c create mode 100644 drivers/mtd/nand/raw/octeontx_bch.h create mode 100644 drivers/mtd/nand/raw/octeontx_bch_regs.h create mode 100644 drivers/mtd/nand/raw/octeontx_nand.c create mode 100644 drivers/net/octeontx/Makefile create mode 100644 drivers/net/octeontx/bgx.c create mode 100644 drivers/net/octeontx/bgx.h create mode 100644 drivers/net/octeontx/nic.h create mode 100644 drivers/net/octeontx/nic_main.c create mode 100644 drivers/net/octeontx/nic_reg.h create mode 100644 drivers/net/octeontx/nicvf_main.c create mode 100644 drivers/net/octeontx/nicvf_queues.c create mode 100644 drivers/net/octeontx/nicvf_queues.h create mode 100644 drivers/net/octeontx/q_struct.h create mode 100644 drivers/net/octeontx/smi.c create mode 100644 drivers/net/octeontx/xcv.c create mode 100644 drivers/net/octeontx2/Makefile create mode 100644 drivers/net/octeontx2/cgx.c create mode 100644 drivers/net/octeontx2/cgx.h create mode 100644 drivers/net/octeontx2/cgx_intf.c create mode 100644 drivers/net/octeontx2/cgx_intf.h create mode 100644 drivers/net/octeontx2/lmt.h create mode 100644 drivers/net/octeontx2/nix.c create mode 100644 drivers/net/octeontx2/nix.h create mode 100644 drivers/net/octeontx2/nix_af.c create mode 100644 drivers/net/octeontx2/npc.h create mode 100644 drivers/net/octeontx2/rvu.h create mode 100644 drivers/net/octeontx2/rvu_af.c create mode 100644 drivers/net/octeontx2/rvu_common.c create mode 100644 drivers/net/octeontx2/rvu_pf.c create mode 100644 drivers/pci/pci_octeontx.c create mode 100644 drivers/watchdog/octeontx_wdt.c create mode 100644 include/configs/octeontx2_common.h create mode 100644 include/configs/octeontx_common.h
Add fdtdec_get_pci_bus_range to read bus-range property values.
Signed-off-by: Suneel Garapati sgarapati@marvell.com Reviewed-by: Simon Glass sjg@chromium.org
Signed-off-by: Stefan Roese sr@denx.de ---
include/fdtdec.h | 13 +++++++++++++ lib/fdtdec.c | 16 ++++++++++++++++ 2 files changed, 29 insertions(+)
diff --git a/include/fdtdec.h b/include/fdtdec.h index 760b392bdf..f6759c7f8e 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -444,6 +444,19 @@ int fdtdec_get_pci_vendev(const void *blob, int node, int fdtdec_get_pci_bar32(const struct udevice *dev, struct fdt_pci_addr *addr, u32 *bar);
+/** + * Look at the bus range property of a device node and return the pci bus + * range for this node. + * The property must hold one fdt_pci_addr with a length. + * @param blob FDT blob + * @param node node to examine + * @param res the resource structure to return the bus range + * @return 0 if ok, negative on error + */ + +int fdtdec_get_pci_bus_range(const void *blob, int node, + struct fdt_resource *res); + /** * Look up a 32-bit integer property in a node and return it. The property * must have at least 4 bytes of data. The value of the first cell is diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 78576b530f..0b40fa374a 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -242,6 +242,22 @@ int fdtdec_get_pci_bar32(const struct udevice *dev, struct fdt_pci_addr *addr,
return 0; } + +int fdtdec_get_pci_bus_range(const void *blob, int node, + struct fdt_resource *res) +{ + const u32 *values; + int len; + + values = fdt_getprop(blob, node, "bus-range", &len); + if (!values || len < sizeof(*values) * 2) + return -EINVAL; + + res->start = fdt32_to_cpu(*values++); + res->end = fdt32_to_cpu(*values); + + return 0; +} #endif
uint64_t fdtdec_get_uint64(const void *blob, int node, const char *prop_name,
Add dev_read_pci_bus_range() to read bus-range property values
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org
Changes in v2: - New patch
drivers/core/read.c | 17 +++++++++++++++++ include/dm/read.h | 12 ++++++++++++ 2 files changed, 29 insertions(+)
diff --git a/drivers/core/read.c b/drivers/core/read.c index 8bb456bc3f..86f3f88170 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -10,6 +10,7 @@ #include <mapmem.h> #include <asm/types.h> #include <asm/io.h> +#include <linux/ioport.h>
int dev_read_u32(const struct udevice *dev, const char *propname, u32 *outp) { @@ -359,3 +360,19 @@ int dev_get_child_count(const struct udevice *dev) { return ofnode_get_child_count(dev_ofnode(dev)); } + +int dev_read_pci_bus_range(const struct udevice *dev, + struct resource *res) +{ + const u32 *values; + int len; + + values = dev_read_prop(dev, "bus-range", &len); + if (!values || len < sizeof(*values) * 2) + return -EINVAL; + + res->start = *values++; + res->end = *values; + + return 0; +} diff --git a/include/dm/read.h b/include/dm/read.h index 487ec9e9c9..ac7ec5dd79 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -680,6 +680,18 @@ int dev_read_alias_highest_id(const char *stem); */ int dev_get_child_count(const struct udevice *dev);
+/** + * dev_read_pci_bus_range - Read PCI bus-range resource + * + * Look at the bus range property of a device node and return the pci bus + * range for this node. + * + * @dev: device to examine + * @res returns the resource + * @return 0 if ok, negative on error + */ +int dev_read_pci_bus_range(const struct udevice *dev, struct resource *res); + #else /* CONFIG_DM_DEV_READ_INLINE is enabled */
static inline int dev_read_u32(const struct udevice *dev,
Changes in v2:
- New patch
Since the migration to Kconfig, CONFIG_NR_DRAM_BANKS is configured for all boards. Hence we can remove the conditional compilation and the code path that will never get compiled.
Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Bin Meng bmeng.cn@gmail.com
Changes in v1: - New patch
drivers/pci/pci-uclass.c | 17 +---------------- 1 file changed, 1 insertion(+), 16 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 40cc9f1090..601557a875 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -871,6 +871,7 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, ofnode node) { int pci_addr_cells, addr_cells, size_cells; + struct bd_info *bd = gd->bd; int cells_per_record; const u32 *prop; int len; @@ -938,9 +939,6 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, }
/* Add a region for our local memory */ -#ifdef CONFIG_NR_DRAM_BANKS - struct bd_info *bd = gd->bd; - if (!bd) return;
@@ -958,19 +956,6 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); } } -#else - phys_addr_t base = 0, size; - - size = gd->ram_size; -#ifdef CONFIG_SYS_SDRAM_BASE - base = CONFIG_SYS_SDRAM_BASE; -#endif - if (gd->pci_ram_top && gd->pci_ram_top < base + size) - size = gd->pci_ram_top - base; - if (size) - pci_set_region(hose->regions + hose->region_count++, base, - base, size, PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); -#endif
return; }
Marek explained on IRC, that ft_board_setup() is not used / necessary at all. So its best to just drop it completely, as it interferes with the cleanup of CONFIG_MAX_PCI_REGIONS (completely removed).
Signed-off-by: Stefan Roese sr@denx.de Suggested-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Simon Glass sjg@chromium.org ---
(no changes since v1)
board/renesas/rcar-common/common.c | 48 ------------------------------ 1 file changed, 48 deletions(-)
diff --git a/board/renesas/rcar-common/common.c b/board/renesas/rcar-common/common.c index 83dd288847..777d8c8e0f 100644 --- a/board/renesas/rcar-common/common.c +++ b/board/renesas/rcar-common/common.c @@ -42,51 +42,3 @@ int dram_init_banksize(void)
return 0; } - -#if CONFIG_IS_ENABLED(OF_BOARD_SETUP) && CONFIG_IS_ENABLED(PCI) -int ft_board_setup(void *blob, struct bd_info *bd) -{ - struct udevice *dev; - struct uclass *uc; - fdt_addr_t regs_addr; - int i, off, ret; - - ret = uclass_get(UCLASS_PCI, &uc); - if (ret) - return ret; - - uclass_foreach_dev(dev, uc) { - struct pci_controller hose = { 0 }; - - for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { - if (hose.region_count == MAX_PCI_REGIONS) { - printf("maximum number of regions parsed, aborting\n"); - break; - } - - if (bd->bi_dram[i].size) { - pci_set_region(&hose.regions[hose.region_count++], - bd->bi_dram[i].start, - bd->bi_dram[i].start, - bd->bi_dram[i].size, - PCI_REGION_MEM | - PCI_REGION_PREFETCH | - PCI_REGION_SYS_MEMORY); - } - } - - regs_addr = devfdt_get_addr_index(dev, 0); - off = fdt_node_offset_by_compat_reg(blob, - "renesas,pcie-rcar-gen3", regs_addr); - if (off < 0) { - printf("Failed to find PCIe node@%llx\n", regs_addr); - return off; - } - - fdt_pci_dma_ranges(blob, off, &hose); - } - - return 0; -} -#endif -#endif
Instead of using a fixed length pre-allocated array of regions, this patch moves to dynamically allocating the regions based on the number of available regions plus the necessary regions for DRAM banks.
Since MAX_PCI_REGIONS is not needed any more, its removed completely with this patch.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Thierry Reding treding@nvidia.com Cc: Marek Vasut marek.vasut+renesas@gmail.com
Changes in v2: - Split changes in board/renesas/rcar-common/common.c into separate patch
Changes in v1: - New patch, replaces increase of MAX_PCI_REGIONS to 10
drivers/pci/pci-uclass.c | 14 ++++++++------ include/pci.h | 4 +--- 2 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 601557a875..337ac137d1 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -874,6 +874,7 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, struct bd_info *bd = gd->bd; int cells_per_record; const u32 *prop; + int max_regions; int len; int i;
@@ -893,7 +894,13 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, hose->region_count = 0; debug("%s: len=%d, cells_per_record=%d\n", __func__, len, cells_per_record); - for (i = 0; i < MAX_PCI_REGIONS; i++, len -= cells_per_record) { + + /* Dynamically allocate the regions array */ + max_regions = len / cells_per_record + CONFIG_NR_DRAM_BANKS; + hose->regions = (struct pci_region *) + calloc(1, max_regions * sizeof(struct pci_region)); + + for (i = 0; i < max_regions; i++, len -= cells_per_record) { u64 pci_addr, addr, size; int space_code; u32 flags; @@ -943,11 +950,6 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, return;
for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { - if (hose->region_count == MAX_PCI_REGIONS) { - pr_err("maximum number of regions parsed, aborting\n"); - break; - } - if (bd->bi_dram[i].size) { pci_set_region(hose->regions + hose->region_count++, bd->bi_dram[i].start, diff --git a/include/pci.h b/include/pci.h index 2089db9f16..da755af852 100644 --- a/include/pci.h +++ b/include/pci.h @@ -590,8 +590,6 @@ extern void pci_cfgfunc_do_nothing(struct pci_controller* hose, pci_dev_t dev, extern void pci_cfgfunc_config_device(struct pci_controller* hose, pci_dev_t dev, struct pci_config_table *);
-#define MAX_PCI_REGIONS 7 - #define INDIRECT_TYPE_NO_PCIE_LINK 1
/** @@ -632,7 +630,7 @@ struct pci_controller { * for PCI controllers and a separate UCLASS (or perhaps * UCLASS_PCI_GENERIC) is used for bridges. */ - struct pci_region regions[MAX_PCI_REGIONS]; + struct pci_region *regions; int region_count;
struct pci_config_table *config_table;
Changes in v2:
Changes in v1:
Fix argument ordering for map_physmem() called in dm_pci_map_ea_bar(). Additinally minor spelling correction.
Signed-off-by: Suneel Garapati sgarapati@marvell.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com
Changes in v2: - Add Reviewed-by tag from Simon - Correct patch subject - Correct patch description in commit text - Minor spelling update
Changes in v1: - Change patch subject
drivers/pci/pci-uclass.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 337ac137d1..fde5b83adf 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -1424,7 +1424,7 @@ static void *dm_pci_map_ea_bar(struct udevice *dev, int bar, int flags, }
/* size ignored for now */ - return map_physmem(addr, flags, 0); + return map_physmem(addr, 0, flags); }
return 0; @@ -1450,7 +1450,7 @@ void *dm_pci_map_bar(struct udevice *dev, int bar, int flags)
/* * Pass "0" as the length argument to pci_bus_to_virt. The arg - * isn't actualy used on any platform because u-boot assumes a static + * isn't actually used on any platform because U-Boot assumes a static * linear mapping. In the future, this could read the BAR size * and pass that as the size if needed. */
Parse subnode DT properties only if parent node is valid. Otherwise, assert is triggered on ofnode_valid in ofnode_first_subnode from dev_for_each_subnode.
drivers/pci/pci-uclass.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index fde5b83adf..cf1bbccbba 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -696,7 +696,8 @@ static int pci_find_and_bind_driver(struct udevice *parent, find_id->vendor, find_id->device);
/* Determine optional OF node */ - pci_dev_find_ofnode(parent, bdf, &node); + if (ofnode_valid(dev_ofnode(parent))) + pci_dev_find_ofnode(parent, bdf, &node);
if (ofnode_valid(node) && !ofnode_is_available(node)) { debug("%s: Ignoring disabled device\n", __func__);
Enable PCI memory regions in ranges property to be of multiple entry. This helps to add support for SoC's like OcteonTX/TX2 where every peripheral is on PCI bus.
Signed-off-by: Suneel Garapati sgarapati@marvell.com Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com
Changes in v2: - Add sandbox test
Changes in v1: - Change patch subject - Enhance Kconfig help descrition - Use if() instead of #if
arch/sandbox/dts/test.dts | 5 +++-- configs/sandbox_defconfig | 1 + drivers/pci/Kconfig | 10 ++++++++++ drivers/pci/pci-uclass.c | 9 ++++++--- test/dm/pci.c | 22 ++++++++++++++++++++++ 5 files changed, 42 insertions(+), 5 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 491893a17d..d3c18eee71 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -652,8 +652,9 @@ bus-range = <0x00 0xff>; #address-cells = <3>; #size-cells = <2>; - ranges = <0x02000000 0 0x30000000 0x30000000 0 0x2000 - 0x01000000 0 0x40000000 0x40000000 0 0x2000>; + ranges = <0x02000000 0 0x30000000 0x30000000 0 0x2000 // MEM0 + 0x02000000 0 0x31000000 0x31000000 0 0x2000 // MEM1 + 0x01000000 0 0x40000000 0x40000000 0 0x2000>; sandbox,dev-info = <0x08 0x00 0x1234 0x5678 0x0c 0x00 0x1234 0x5678 0x10 0x00 0x1234 0x5678>; diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index fe11128904..cc2f8c287c 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -180,6 +180,7 @@ CONFIG_NVME=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PCI_SANDBOX=y CONFIG_PHY=y CONFIG_PHY_SANDBOX=y diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 5e0a39396b..1c47a21101 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -43,6 +43,16 @@ config PCI_PNP help Enable PCI memory and I/O space resource allocation and assignment.
+config PCI_REGION_MULTI_ENTRY + bool "Enable Multiple entries of region type MEMORY in ranges for PCI" + depends on PCI || DM_PCI + default n + help + Enable PCI memory regions to be of multiple entry. Multiple entry + here refers to allow more than one count of address ranges for MEMORY + region type. This helps to add support for SoC's like OcteonTX/TX2 + where every peripheral is on the PCI bus. + config PCIE_ECAM_GENERIC bool "Generic ECAM-based PCI host controller support" default n diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index cf1bbccbba..19ea3ae9c1 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -936,10 +936,13 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, }
pos = -1; - for (i = 0; i < hose->region_count; i++) { - if (hose->regions[i].flags == type) - pos = i; + if (!IS_ENABLED(CONFIG_PCI_REGION_MULTI_ENTRY)) { + for (i = 0; i < hose->region_count; i++) { + if (hose->regions[i].flags == type) + pos = i; + } } + if (pos == -1) pos = hose->region_count++; debug(" - type=%d, pos=%d\n", type, pos); diff --git a/test/dm/pci.c b/test/dm/pci.c index fd66ed7899..76490befdf 100644 --- a/test/dm/pci.c +++ b/test/dm/pci.c @@ -354,3 +354,25 @@ static int dm_test_pci_on_bus(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_pci_on_bus, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +/* + * Test support for multiple memory regions enabled via + * CONFIG_PCI_REGION_MULTI_ENTRY. When this feature is not enabled, + * only the last region of one type is stored. In this test-case, + * we have 2 memory regions, the first at 0x3000.0000 and the 2nd + * at 0x3100.0000. A correct test results now in BAR1 located at + * 0x3000.0000. + */ +static int dm_test_pci_region_multi(struct unit_test_state *uts) +{ + struct udevice *dev; + ulong mem_addr; + + /* Test memory BAR1 on bus#1 */ + ut_assertok(dm_pci_bus_find_bdf(PCI_BDF(1, 0x08, 0), &dev)); + mem_addr = dm_pci_read_bar32(dev, 1); + ut_asserteq(mem_addr, 0x30000000); + + return 0; +} +DM_TEST(dm_test_pci_region_multi, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
Changes in v2:
- Add sandbox test
Changes in v1:
If Enhanced Allocation capability is present in bridges, use it to read the fixed sub-ordinate bus number.
drivers/pci/pci-uclass.c | 24 ++++++++++++++++++------ 1 file changed, 18 insertions(+), 6 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 19ea3ae9c1..fa6115a105 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -620,10 +620,19 @@ int dm_pci_hose_probe_bus(struct udevice *bus) { int sub_bus; int ret; + int ea_pos; + u8 reg;
debug("%s\n", __func__);
- sub_bus = pci_get_bus_max() + 1; + ea_pos = dm_pci_find_capability(bus, PCI_CAP_ID_EA); + if (ea_pos) { + dm_pci_read_config8(bus, ea_pos + sizeof(u32) + sizeof(u8), + ®); + sub_bus = reg; + } else { + sub_bus = pci_get_bus_max() + 1; + } debug("%s: bus = %d/%s\n", __func__, sub_bus, bus->name); dm_pciauto_prescan_setup_bridge(bus, sub_bus);
@@ -633,12 +642,15 @@ int dm_pci_hose_probe_bus(struct udevice *bus) ret); return ret; } - if (sub_bus != bus->seq) { - printf("%s: Internal error, bus '%s' got seq %d, expected %d\n", - __func__, bus->name, bus->seq, sub_bus); - return -EPIPE; + + if (!ea_pos) { + if (sub_bus != bus->seq) { + debug("%s: Internal error, bus '%s' got seq %d, expected %d\n", + __func__, bus->name, bus->seq, sub_bus); + return -EPIPE; + } + sub_bus = pci_get_bus_max(); } - sub_bus = pci_get_bus_max(); dm_pciauto_postscan_setup_bridge(bus, sub_bus);
return sub_bus;
SR-IOV - Single Root I/O Virtualization PF - Physical Function VF - Virtual Function
If SR-IOV capability is present, use it to initialize Virtual Function PCI device instances. pci_sriov_init function will read SR-IOV registers to create VF devices under the PF PCI device and also bind driver if available. This function needs to be invoked from Physical function device driver which expects VF device support, creating minimal impact on existing framework.
Changes in v1: - Change patch subject - Enhance commit text: expanded the abbreviations - Changed some printf() to debug() - Changed 0 to '\0' in memset() - Comments for variables in struct pci_child_platdata added - Comments for newly introduced functions added in prototype / header
drivers/pci/Kconfig | 10 ++++ drivers/pci/pci-uclass.c | 114 +++++++++++++++++++++++++++++++++++++++ include/pci.h | 38 +++++++++++++ 3 files changed, 162 insertions(+)
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 1c47a21101..4635752a95 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -53,6 +53,16 @@ config PCI_REGION_MULTI_ENTRY region type. This helps to add support for SoC's like OcteonTX/TX2 where every peripheral is on the PCI bus.
+config PCI_SRIOV + bool "Enable Single Root I/O Virtualization support for PCI" + depends on PCI || DM_PCI + default n + help + Say Y here if you want to enable PCI Single Root I/O Virtualization + capability support. This helps to enumerate Virtual Function devices + if available on a PCI Physical Function device and probe for + applicable drivers. + config PCIE_ECAM_GENERIC bool "Generic ECAM-based PCI host controller support" default n diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index fa6115a105..51871bfe62 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -1586,6 +1586,120 @@ int dm_pci_flr(struct udevice *dev) return 0; }
+#if defined(CONFIG_PCI_SRIOV) +int pci_sriov_init(struct udevice *pdev, int vf_en) +{ + u16 vendor, device; + struct udevice *bus; + struct udevice *dev; + pci_dev_t bdf; + u16 ctrl; + u16 num_vfs; + u16 total_vf; + u16 vf_offset; + u16 vf_stride; + int vf, ret; + int pos; + + pos = dm_pci_find_ext_capability(pdev, PCI_EXT_CAP_ID_SRIOV); + if (!pos) { + debug("Error: SRIOV capability not found\n"); + return -ENOENT; + } + + dm_pci_read_config16(pdev, pos + PCI_SRIOV_CTRL, &ctrl); + + dm_pci_read_config16(pdev, pos + PCI_SRIOV_TOTAL_VF, &total_vf); + if (vf_en > total_vf) + vf_en = total_vf; + dm_pci_write_config16(pdev, pos + PCI_SRIOV_NUM_VF, vf_en); + + ctrl |= PCI_SRIOV_CTRL_VFE | PCI_SRIOV_CTRL_MSE; + dm_pci_write_config16(pdev, pos + PCI_SRIOV_CTRL, ctrl); + + dm_pci_read_config16(pdev, pos + PCI_SRIOV_NUM_VF, &num_vfs); + if (num_vfs > vf_en) + num_vfs = vf_en; + + dm_pci_read_config16(pdev, pos + PCI_SRIOV_VF_OFFSET, &vf_offset); + dm_pci_read_config16(pdev, pos + PCI_SRIOV_VF_STRIDE, &vf_stride); + + dm_pci_read_config16(pdev, PCI_VENDOR_ID, &vendor); + dm_pci_read_config16(pdev, pos + PCI_SRIOV_VF_DID, &device); + + bdf = dm_pci_get_bdf(pdev); + + pci_get_bus(PCI_BUS(bdf), &bus); + + if (!bus) + return -ENODEV; + + bdf += PCI_BDF(0, 0, vf_offset); + + for (vf = 0; vf < num_vfs; vf++) { + struct pci_child_platdata *pplat; + ulong class; + + pci_bus_read_config(bus, bdf, PCI_CLASS_DEVICE, + &class, PCI_SIZE_16); + + debug("%s: bus %d/%s: found VF %x:%x\n", __func__, + bus->seq, bus->name, PCI_DEV(bdf), PCI_FUNC(bdf)); + + /* Find this device in the device tree */ + ret = pci_bus_find_devfn(bus, PCI_MASK_BUS(bdf), &dev); + + if (ret == -ENODEV) { + struct pci_device_id find_id; + + memset(&find_id, '\0', sizeof(find_id)); + find_id.vendor = vendor; + find_id.device = device; + find_id.class = class; + + ret = pci_find_and_bind_driver(bus, &find_id, + bdf, &dev); + + if (ret) + return ret; + } + + /* Update the platform data */ + pplat = dev_get_parent_platdata(dev); + pplat->devfn = PCI_MASK_BUS(bdf); + pplat->vendor = vendor; + pplat->device = device; + pplat->class = class; + pplat->is_virtfn = true; + pplat->pfdev = pdev; + pplat->virtid = vf * vf_stride + vf_offset; + + debug("%s: bus %d/%s: found VF %x:%x %x:%x class %lx id %x\n", + __func__, dev->seq, dev->name, PCI_DEV(bdf), + PCI_FUNC(bdf), vendor, device, class, pplat->virtid); + bdf += PCI_BDF(0, 0, vf_stride); + } + + return 0; +} + +int pci_sriov_get_totalvfs(struct udevice *pdev) +{ + u16 total_vf; + int pos; + + pos = dm_pci_find_ext_capability(pdev, PCI_EXT_CAP_ID_SRIOV); + if (!pos) { + debug("Error: SRIOV capability not found\n"); + return -ENOENT; + } + + dm_pci_read_config16(pdev, pos + PCI_SRIOV_TOTAL_VF, &total_vf); + + return total_vf; +} +#endif /* SRIOV */ + UCLASS_DRIVER(pci) = { .id = UCLASS_PCI, .name = "pci", diff --git a/include/pci.h b/include/pci.h index da755af852..115d3312a4 100644 --- a/include/pci.h +++ b/include/pci.h @@ -493,6 +493,17 @@ #define PCI_EXP_SLTCAP 20 /* Slot Capabilities */ #define PCI_EXP_SLTCAP_PSN 0xfff80000 /* Physical Slot Number */ #define PCI_EXP_LNKCTL2 48 /* Link Control 2 */ +/* Single Root I/O Virtualization Registers */ +#define PCI_SRIOV_CAP 0x04 /* SR-IOV Capabilities */ +#define PCI_SRIOV_CTRL 0x08 /* SR-IOV Control */ +#define PCI_SRIOV_CTRL_VFE 0x01 /* VF Enable */ +#define PCI_SRIOV_CTRL_MSE 0x08 /* VF Memory Space Enable */ +#define PCI_SRIOV_INITIAL_VF 0x0c /* Initial VFs */ +#define PCI_SRIOV_TOTAL_VF 0x0e /* Total VFs */ +#define PCI_SRIOV_NUM_VF 0x10 /* Number of VFs */ +#define PCI_SRIOV_VF_OFFSET 0x14 /* First VF Offset */ +#define PCI_SRIOV_VF_STRIDE 0x16 /* Following VF Stride */ +#define PCI_SRIOV_VF_DID 0x1a /* VF Device ID */
/* Include the ID list */
@@ -890,12 +901,20 @@ struct udevice; * @vendor: PCI vendor ID (see pci_ids.h) * @device: PCI device ID (see pci_ids.h) * @class: PCI class, 3 bytes: (base, sub, prog-if) + * @is_virtfn: True for Virtual Function device + * @pfdev: Handle to Physical Function device + * @virtid: Virtual Function Index */ struct pci_child_platdata { int devfn; unsigned short vendor; unsigned short device; unsigned int class; + + /* Variables for CONFIG_PCI_SRIOV */ + bool is_virtfn; + struct udevice *pfdev; + int virtid; };
/* PCI bus operations */ @@ -1208,6 +1227,25 @@ int pci_generic_mmap_read_config( ulong *valuep, enum pci_size_t size);
+#if defined(CONFIG_PCI_SRIOV) +/** + * pci_sriov_init() - Scan Virtual Function devices + * + * @pdev: Physical Function udevice handle + * @vf_en: Number of Virtual Function devices to enable + * @return 0 on success, -ve on error + */ +int pci_sriov_init(struct udevice *pdev, int vf_en); + +/** + * pci_sriov_get_totalvfs() - Get total available Virtual Function devices + * + * @pdev: Physical Function udevice handle + * @return count on success, -ve on error + */ +int pci_sriov_get_totalvfs(struct udevice *pdev); +#endif + #ifdef CONFIG_DM_PCI_COMPAT /* Compatibility with old naming */ static inline int pci_write_config_dword(pci_dev_t pcidev, int offset,
Makes dm_pci_map_bar API available to map BAR for Virtual function PCI devices which support Enhanced Allocation.
Changes in v1: - Change patch subject - Fixed multi-line comment style - Moved "feature" into new function which is only called, when CONFIG_PCI_SRIOV is enabled, so that the code is not increased in all cases - Changed variable declaration to use reverse xmas tree order
drivers/pci/pci-uclass.c | 67 +++++++++++++++++++++++++++++++++++++--- include/pci.h | 3 ++ 2 files changed, 65 insertions(+), 5 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 51871bfe62..23135ebe04 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -1409,14 +1409,55 @@ pci_addr_t dm_pci_phys_to_bus(struct udevice *dev, phys_addr_t phys_addr, return bus_addr; }
+static phys_addr_t dm_pci_map_ea_virt(struct udevice *dev, int ea_off, + struct pci_child_platdata *pdata) +{ + phys_addr_t addr = 0; + + /* + * In the case of a Virtual Function device using BAR + * base and size, add offset for VFn BAR(1, 2, 3...n) + */ + if (pdata->is_virtfn) { + size_t sz; + u32 ea_entry; + + /* MaxOffset, 1st DW */ + dm_pci_read_config32(dev, ea_off + 8, &ea_entry); + sz = ea_entry & PCI_EA_FIELD_MASK; + /* Fill up lower 2 bits */ + sz |= (~PCI_EA_FIELD_MASK); + + if (ea_entry & PCI_EA_IS_64) { + /* MaxOffset 2nd DW */ + dm_pci_read_config32(dev, ea_off + 16, &ea_entry); + sz |= ((u64)ea_entry) << 32; + } + + addr = (pdata->virtid - 1) * (sz + 1); + } + + return addr; +} + static void *dm_pci_map_ea_bar(struct udevice *dev, int bar, int flags, - int ea_off) + int ea_off, struct pci_child_platdata *pdata) { int ea_cnt, i, entry_size; int bar_id = (bar - PCI_BASE_ADDRESS_0) >> 2; u32 ea_entry; phys_addr_t addr;
+ if (IS_ENABLED(CONFIG_PCI_SRIOV)) { + /* + * In the case of a Virtual Function device, device is + * Physical function, so pdata will point to required VF + * specific data. + */ + if (pdata->is_virtfn) + bar_id += PCI_EA_BEI_VF_BAR0; + } + /* EA capability structure header */ dm_pci_read_config32(dev, ea_off, &ea_entry); ea_cnt = (ea_entry >> 16) & PCI_EA_NUM_ENT_MASK; @@ -1439,6 +1480,9 @@ static void *dm_pci_map_ea_bar(struct udevice *dev, int bar, int flags, addr |= ((u64)ea_entry) << 32; }
+ if (IS_ENABLED(CONFIG_PCI_SRIOV)) + addr += dm_pci_map_ea_virt(dev, ea_off, pdata); + /* size ignored for now */ return map_physmem(addr, 0, flags); } @@ -1448,20 +1492,33 @@ static void *dm_pci_map_ea_bar(struct udevice *dev, int bar, int flags,
void *dm_pci_map_bar(struct udevice *dev, int bar, int flags) { + struct pci_child_platdata *pdata = dev_get_parent_platdata(dev); + struct udevice *udev = dev; pci_addr_t pci_bus_addr; u32 bar_response; int ea_off;
+ if (IS_ENABLED(CONFIG_PCI_SRIOV)) { + /* + * In case of Virtual Function devices, use PF udevice + * as EA capability is defined in Physical Function + */ + if (pdata->is_virtfn) + udev = pdata->pfdev; + } + /* * if the function supports Enhanced Allocation use that instead of * BARs + * Incase of virtual functions, pdata will help read VF BEI + * and EA entry size. */ - ea_off = dm_pci_find_capability(dev, PCI_CAP_ID_EA); + ea_off = dm_pci_find_capability(udev, PCI_CAP_ID_EA); if (ea_off) - return dm_pci_map_ea_bar(dev, bar, flags, ea_off); + return dm_pci_map_ea_bar(udev, bar, flags, ea_off, pdata);
/* read BAR address */ - dm_pci_read_config32(dev, bar, &bar_response); + dm_pci_read_config32(udev, bar, &bar_response); pci_bus_addr = (pci_addr_t)(bar_response & ~0xf);
/* @@ -1470,7 +1527,7 @@ void *dm_pci_map_bar(struct udevice *dev, int bar, int flags) * linear mapping. In the future, this could read the BAR size * and pass that as the size if needed. */ - return dm_pci_bus_to_virt(dev, pci_bus_addr, flags, 0, MAP_NOCACHE); + return dm_pci_bus_to_virt(udev, pci_bus_addr, flags, 0, MAP_NOCACHE); }
static int _dm_pci_find_next_capability(struct udevice *dev, u8 pos, int cap) diff --git a/include/pci.h b/include/pci.h index 115d3312a4..1c5b36617e 100644 --- a/include/pci.h +++ b/include/pci.h @@ -465,6 +465,9 @@ #define PCI_EA_FIRST_ENT 4 /* First EA Entry in List */ #define PCI_EA_ES 0x00000007 /* Entry Size */ #define PCI_EA_BEI 0x000000f0 /* BAR Equivalent Indicator */ +/* 9-14 map to VF BARs 0-5 respectively */ +#define PCI_EA_BEI_VF_BAR0 9 +#define PCI_EA_BEI_VF_BAR5 14 /* Base, MaxOffset registers */ /* bit 0 is reserved */ #define PCI_EA_IS_64 0x00000002 /* 64-bit field flag */
If ARI capability is found on device, use it to update next function number in bus scan and also helps to skip unnecessary bdf scans.
Changes in v1: - Change patch subject - Fixed multi-line comment style - Added CONFIG_PCI_ARID and enabled the new code optionally, so that the code size is not increased in all cases
drivers/pci/Kconfig | 9 +++++++++ drivers/pci/pci-uclass.c | 26 ++++++++++++++++++++++++++ 2 files changed, 35 insertions(+)
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 4635752a95..377806f3b0 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -63,6 +63,15 @@ config PCI_SRIOV if available on a PCI Physical Function device and probe for applicable drivers.
+config PCI_ARID + bool "Enable Alternate Routing-ID support for PCI" + depends on PCI || DM_PCI + default n + help + Say Y here if you want to enable Alternate Routing-ID capability + support on PCI devices. This helps to skip some devices in BDF + scan that are not present. + config PCIE_ECAM_GENERIC bool "Generic ECAM-based PCI host controller support" default n diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 23135ebe04..fc60dfe395 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -798,6 +798,7 @@ int pci_bind_bus_devices(struct udevice *bus) ulong header_type; pci_dev_t bdf, end; bool found_multi; + int ari_off; int ret;
found_multi = false; @@ -871,6 +872,31 @@ int pci_bind_bus_devices(struct udevice *bus) pplat->vendor = vendor; pplat->device = device; pplat->class = class; + + if (IS_ENABLED(CONFIG_PCI_ARID)) { + ari_off = dm_pci_find_ext_capability(dev, + PCI_EXT_CAP_ID_ARI); + if (ari_off) { + u16 ari_cap; + + /* + * Read Next Function number in ARI Cap + * Register + */ + dm_pci_read_config16(dev, ari_off + 4, + &ari_cap); + /* + * Update next scan on this function number, + * subtract 1 in BDF to satisfy loop increment. + */ + if (ari_cap & 0xff00) { + bdf = PCI_BDF(PCI_BUS(bdf), + PCI_DEV(ari_cap), + PCI_FUNC(ari_cap)); + bdf = bdf - 0x100; + } + } + } }
Add check if the referenced ofnode is valid.
drivers/pci/pci-uclass.c | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index fc60dfe395..d8a6647a1d 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -539,7 +539,8 @@ int pci_auto_config_devices(struct udevice *bus) int ret;
debug("%s: device %s\n", __func__, dev->name); - if (dev_read_bool(dev, "pci,no-autoconfig")) + if (dev_of_valid(dev) && + dev_read_bool(dev, "pci,no-autoconfig")) continue; ret = dm_pciauto_config_device(dev); if (ret < 0) @@ -1025,8 +1026,11 @@ static int pci_uclass_pre_probe(struct udevice *bus) hose->bus = bus; hose->first_busno = bus->seq; hose->last_busno = bus->seq; - hose->skip_auto_config_until_reloc = - dev_read_bool(bus, "u-boot,skip-auto-config-until-reloc"); + if (dev_of_valid(bus)) { + hose->skip_auto_config_until_reloc = + dev_read_bool(bus, + "u-boot,skip-auto-config-until-reloc"); + }
return 0; }
Add 64bit API for clrbits and setbits.
Changes in v1: - Change patch subject - Add small commit text - Also add clr/setbits_64 (without endianess extension), which is needed for the updated Octeon device drivers
arch/arm/include/asm/io.h | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/include/asm/io.h b/arch/arm/include/asm/io.h index ade1401f3b..df264a170b 100644 --- a/arch/arm/include/asm/io.h +++ b/arch/arm/include/asm/io.h @@ -180,16 +180,20 @@ static inline void __raw_readsl(unsigned long addr, void *data, int longlen) #define in_le32(a) in_arch(l,le32,a) #define in_le16(a) in_arch(w,le16,a)
+#define out_be64(a,v) out_arch(l,be64,a,v) #define out_be32(a,v) out_arch(l,be32,a,v) #define out_be16(a,v) out_arch(w,be16,a,v)
+#define in_be64(a) in_arch(l,be64,a) #define in_be32(a) in_arch(l,be32,a) #define in_be16(a) in_arch(w,be16,a)
+#define out_64(a,v) __raw_writeq(v,a) #define out_32(a,v) __raw_writel(v,a) #define out_16(a,v) __raw_writew(v,a) #define out_8(a,v) __raw_writeb(v,a)
+#define in_64(a) __raw_readq(a) #define in_32(a) __raw_readl(a) #define in_16(a) __raw_readw(a) #define in_8(a) __raw_readb(a) @@ -231,6 +235,18 @@ static inline void __raw_readsl(unsigned long addr, void *data, int longlen) #define setbits_8(addr, set) setbits(8, addr, set) #define clrsetbits_8(addr, clear, set) clrsetbits(8, addr, clear, set)
+#define clrbits_be64(addr, clear) clrbits(be64, addr, clear) +#define setbits_be64(addr, set) setbits(be64, addr, set) +#define clrsetbits_be64(addr, clear, set) clrsetbits(be64, addr, clear, set) + +#define clrbits_le64(addr, clear) clrbits(le64, addr, clear) +#define setbits_le64(addr, set) setbits(le64, addr, set) +#define clrsetbits_le64(addr, clear, set) clrsetbits(le64, addr, clear, set) + +#define clrbits_64(addr, clear) clrbits(64, addr, clear) +#define setbits_64(addr, set) setbits(64, addr, set) +#define clrsetbits_64(addr, clear, set) clrsetbits(64, addr, clear, set) + /* * Now, pick up the machine-defined IO definitions */
arch/arm/include/asm/arch-octeontx/board.h | 123 ++ arch/arm/include/asm/arch-octeontx/clock.h | 25 + .../asm/arch-octeontx/csrs/csrs-mio_emm.h | 1193 +++++++++++++++++ .../include/asm/arch-octeontx/csrs/csrs-xcv.h | 428 ++++++ arch/arm/include/asm/arch-octeontx/gpio.h | 6 + arch/arm/include/asm/arch-octeontx/smc.h | 20 + arch/arm/include/asm/arch-octeontx/soc.h | 33 + 7 files changed, 1828 insertions(+) create mode 100644 arch/arm/include/asm/arch-octeontx/board.h create mode 100644 arch/arm/include/asm/arch-octeontx/clock.h create mode 100644 arch/arm/include/asm/arch-octeontx/csrs/csrs-mio_emm.h create mode 100644 arch/arm/include/asm/arch-octeontx/csrs/csrs-xcv.h create mode 100644 arch/arm/include/asm/arch-octeontx/gpio.h create mode 100644 arch/arm/include/asm/arch-octeontx/smc.h create mode 100644 arch/arm/include/asm/arch-octeontx/soc.h
diff --git a/arch/arm/include/asm/arch-octeontx/board.h b/arch/arm/include/asm/arch-octeontx/board.h new file mode 100644 index 0000000000..c9fc3993f8 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx/board.h @@ -0,0 +1,123 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __BOARD_H__ +#define __BOARD_H__ + +#include <asm/arch/soc.h> + +#define MAX_LMAC_PER_BGX 4 +#define LMAC_CNT MAX_LMAC_PER_BGX + +#if defined(CONFIG_TARGET_OCTEONTX_81XX) + +/** Maximum number of BGX interfaces per CPU node */ +#define MAX_BGX_PER_NODE 3 +#define OCTEONTX_XCV /* RGMII Interface */ + +#elif defined(CONFIG_TARGET_OCTEONTX_83XX) + +/** Maximum number of BGX interfaces per CPU node */ +#define MAX_BGX_PER_NODE 4 + +#endif + +/** Reg offsets */ +#define RST_BOOT 0x87E006001600ULL + +/** Structure definitions */ + +/** + * Register (RSL) rst_boot + * + * RST Boot Register This register is not accessible through ROM scripts; + * see SCR_WRITE32_S[ADDR]. + */ +union rst_boot { + u64 u; + struct rst_boot_s { + u64 rboot_pin : 1; + u64 rboot : 1; + u64 reserved_2_32 : 31; + u64 pnr_mul : 6; + u64 reserved_39 : 1; + u64 c_mul : 7; + u64 reserved_47_52 : 6; + u64 gpio_ejtag : 1; + u64 mcp_jtagdis : 1; + u64 dis_scan : 1; + u64 dis_huk : 1; + u64 vrm_err : 1; + u64 jt_tstmode : 1; + u64 ckill_ppdis : 1; + u64 trusted_mode : 1; + u64 reserved_61_62 : 2; + u64 chipkill : 1; + } s; + struct rst_boot_cn81xx { + u64 rboot_pin : 1; + u64 rboot : 1; + u64 lboot : 10; + u64 lboot_ext23 : 6; + u64 lboot_ext45 : 6; + u64 lboot_jtg : 1; + u64 lboot_ckill : 1; + u64 reserved_26_29 : 4; + u64 lboot_oci : 3; + u64 pnr_mul : 6; + u64 reserved_39 : 1; + u64 c_mul : 7; + u64 reserved_47_54 : 8; + u64 dis_scan : 1; + u64 dis_huk : 1; + u64 vrm_err : 1; + u64 jt_tstmode : 1; + u64 ckill_ppdis : 1; + u64 trusted_mode : 1; + u64 ejtagdis : 1; + u64 jtcsrdis : 1; + u64 chipkill : 1; + } cn81xx; + struct rst_boot_cn83xx { + u64 rboot_pin : 1; + u64 rboot : 1; + u64 lboot : 10; + u64 lboot_ext23 : 6; + u64 lboot_ext45 : 6; + u64 lboot_jtg : 1; + u64 lboot_ckill : 1; + u64 lboot_pf_flr : 4; + u64 lboot_oci : 3; + u64 pnr_mul : 6; + u64 reserved_39 : 1; + u64 c_mul : 7; + u64 reserved_47_54 : 8; + u64 dis_scan : 1; + u64 dis_huk : 1; + u64 vrm_err : 1; + u64 jt_tstmode : 1; + u64 ckill_ppdis : 1; + u64 trusted_mode : 1; + u64 ejtagdis : 1; + u64 jtcsrdis : 1; + u64 chipkill : 1; + } cn83xx; +}; + +extern unsigned long fdt_base_addr; + +/** Function definitions */ +void mem_map_fill(void); +int octeontx_board_has_pmp(void); +const char *fdt_get_board_model(void); +const char *fdt_get_board_serial(void); +const char *fdt_get_board_revision(void); +void fdt_parse_phy_info(void); +void fdt_board_get_ethaddr(int bgx, int lmac, unsigned char *eth); +void bgx_set_board_info(int bgx_id, int *mdio_bus, int *phy_addr, + bool *autoneg_dis, bool *lmac_reg, bool *lmac_enable); +#endif /* __BOARD_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx/clock.h b/arch/arm/include/asm/arch-octeontx/clock.h new file mode 100644 index 0000000000..7bf600a1f2 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx/clock.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __CLOCK_H__ +#define __CLOCK_H__ + +/** System PLL reference clock */ +#define PLL_REF_CLK 50000000 /* 50 MHz */ +#define NS_PER_REF_CLK_TICK (1000000000 / PLL_REF_CLK) + +/** + * Returns the I/O clock speed in Hz + */ +u64 octeontx_get_io_clock(void); + +/** + * Returns the core clock speed in Hz + */ +u64 octeontx_get_core_clock(void); + +#endif /* __CLOCK_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx/csrs/csrs-mio_emm.h b/arch/arm/include/asm/arch-octeontx/csrs/csrs-mio_emm.h new file mode 100644 index 0000000000..a5a4740833 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx/csrs/csrs-mio_emm.h @@ -0,0 +1,1193 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Marvell International Ltd. + * + * https://spdx.org/licenses + */ +#ifndef __CSRS_MIO_EMM_H__ +#define __CSRS_MIO_EMM_H__ + +/** + * @file + * + * Configuration and status register (CSR) address and type definitions for + * MIO_EMM. + * + * This file is auto generated. Do not edit. + * + */ + +/** + * Enumeration mio_emm_bar_e + * + * eMMC Base Address Register Enumeration Enumerates the base address + * registers. + */ +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR0_CN8 (0x87e009000000ll) +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR0_CN8_SIZE 0x800000ull +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR0_CN9 (0x87e009000000ll) +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR0_CN9_SIZE 0x10000ull +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR4 (0x87e009f00000ll) +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR4_SIZE 0x100000ull + +/** + * Enumeration mio_emm_int_vec_e + * + * eMMC MSI-X Vector Enumeration Enumerates the MSI-X interrupt vectors. + */ +#define MIO_EMM_INT_VEC_E_DMA_INT_DONE (8) +#define MIO_EMM_INT_VEC_E_DMA_INT_FIFO (7) +#define MIO_EMM_INT_VEC_E_EMM_BUF_DONE (0) +#define MIO_EMM_INT_VEC_E_EMM_CMD_DONE (1) +#define MIO_EMM_INT_VEC_E_EMM_CMD_ERR (3) +#define MIO_EMM_INT_VEC_E_EMM_DMA_DONE (2) +#define MIO_EMM_INT_VEC_E_EMM_DMA_ERR (4) +#define MIO_EMM_INT_VEC_E_EMM_SWITCH_DONE (5) +#define MIO_EMM_INT_VEC_E_EMM_SWITCH_ERR (6) +#define MIO_EMM_INT_VEC_E_NCB_FLT (9) +#define MIO_EMM_INT_VEC_E_NCB_RAS (0xa) + +/** + * Register (RSL) mio_emm_access_wdog + * + * eMMC Access Watchdog Register + */ +union mio_emm_access_wdog { + u64 u; + struct mio_emm_access_wdog_s { + u64 clk_cnt : 32; + u64 reserved_32_63 : 32; + } s; + /* struct mio_emm_access_wdog_s cn; */ +}; + +static inline u64 MIO_EMM_ACCESS_WDOG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_ACCESS_WDOG(void) +{ + return 0x20f0; +} + +/** + * Register (RSL) mio_emm_buf_dat + * + * eMMC Data Buffer Access Register + */ +union mio_emm_buf_dat { + u64 u; + struct mio_emm_buf_dat_s { + u64 dat : 64; + } s; + /* struct mio_emm_buf_dat_s cn; */ +}; + +static inline u64 MIO_EMM_BUF_DAT(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_BUF_DAT(void) +{ + return 0x20e8; +} + +/** + * Register (RSL) mio_emm_buf_idx + * + * eMMC Data Buffer Address Register + */ +union mio_emm_buf_idx { + u64 u; + struct mio_emm_buf_idx_s { + u64 offset : 6; + u64 buf_num : 1; + u64 reserved_7_15 : 9; + u64 inc : 1; + u64 reserved_17_63 : 47; + } s; + /* struct mio_emm_buf_idx_s cn; */ +}; + +static inline u64 MIO_EMM_BUF_IDX(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_BUF_IDX(void) +{ + return 0x20e0; +} + +/** + * Register (RSL) mio_emm_calb + * + * eMMC Calbration Register This register initiates delay line + * characterization. + */ +union mio_emm_calb { + u64 u; + struct mio_emm_calb_s { + u64 start : 1; + u64 reserved_1_63 : 63; + } s; + /* struct mio_emm_calb_s cn; */ +}; + +static inline u64 MIO_EMM_CALB(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_CALB(void) +{ + return 0x20c0; +} + +/** + * Register (RSL) mio_emm_cfg + * + * eMMC Configuration Register + */ +union mio_emm_cfg { + u64 u; + struct mio_emm_cfg_s { + u64 bus_ena : 4; + u64 reserved_4_63 : 60; + } s; + /* struct mio_emm_cfg_s cn; */ +}; + +static inline u64 MIO_EMM_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_CFG(void) +{ + return 0x2000; +} + +/** + * Register (RSL) mio_emm_cmd + * + * eMMC Command Register + */ +union mio_emm_cmd { + u64 u; + struct mio_emm_cmd_s { + u64 arg : 32; + u64 cmd_idx : 6; + u64 rtype_xor : 3; + u64 ctype_xor : 2; + u64 reserved_43_48 : 6; + u64 offset : 6; + u64 dbuf : 1; + u64 reserved_56_58 : 3; + u64 cmd_val : 1; + u64 bus_id : 2; + u64 skip_busy : 1; + u64 reserved_63 : 1; + } s; + /* struct mio_emm_cmd_s cn; */ +}; + +static inline u64 MIO_EMM_CMD(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_CMD(void) +{ + return 0x2058; +} + +/** + * Register (RSL) mio_emm_comp + * + * eMMC Compensation Register + */ +union mio_emm_comp { + u64 u; + struct mio_emm_comp_s { + u64 nctl : 3; + u64 reserved_3_7 : 5; + u64 pctl : 3; + u64 reserved_11_63 : 53; + } s; + /* struct mio_emm_comp_s cn; */ +}; + +static inline u64 MIO_EMM_COMP(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_COMP(void) +{ + return 0x2040; +} + +/** + * Register (RSL) mio_emm_debug + * + * eMMC Debug Register + */ +union mio_emm_debug { + u64 u; + struct mio_emm_debug_s { + u64 clk_on : 1; + u64 reserved_1_7 : 7; + u64 cmd_sm : 4; + u64 data_sm : 4; + u64 dma_sm : 4; + u64 emmc_clk_disable : 1; + u64 rdsync_rst : 1; + u64 reserved_22_63 : 42; + } s; + struct mio_emm_debug_cn96xxp1 { + u64 clk_on : 1; + u64 reserved_1_7 : 7; + u64 cmd_sm : 4; + u64 data_sm : 4; + u64 dma_sm : 4; + u64 reserved_20_63 : 44; + } cn96xxp1; + /* struct mio_emm_debug_s cn96xxp3; */ + /* struct mio_emm_debug_cn96xxp1 cnf95xx; */ +}; + +static inline u64 MIO_EMM_DEBUG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DEBUG(void) +{ + return 0x20f8; +} + +/** + * Register (RSL) mio_emm_dma + * + * eMMC External DMA Configuration Register + */ +union mio_emm_dma { + u64 u; + struct mio_emm_dma_s { + u64 card_addr : 32; + u64 block_cnt : 16; + u64 multi : 1; + u64 rw : 1; + u64 rel_wr : 1; + u64 thres : 6; + u64 dat_null : 1; + u64 sector : 1; + u64 dma_val : 1; + u64 bus_id : 2; + u64 skip_busy : 1; + u64 extra_args : 1; + } s; + struct mio_emm_dma_cn8 { + u64 card_addr : 32; + u64 block_cnt : 16; + u64 multi : 1; + u64 rw : 1; + u64 rel_wr : 1; + u64 thres : 6; + u64 dat_null : 1; + u64 sector : 1; + u64 dma_val : 1; + u64 bus_id : 2; + u64 skip_busy : 1; + u64 reserved_63 : 1; + } cn8; + struct mio_emm_dma_cn9 { + u64 card_addr : 32; + u64 block_cnt : 16; + u64 multi : 1; + u64 rw : 1; + u64 reserved_50 : 1; + u64 thres : 6; + u64 dat_null : 1; + u64 sector : 1; + u64 dma_val : 1; + u64 bus_id : 2; + u64 skip_busy : 1; + u64 extra_args : 1; + } cn9; +}; + +static inline u64 MIO_EMM_DMA(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA(void) +{ + return 0x2050; +} + +/** + * Register (RSL) mio_emm_dma_adr + * + * eMMC DMA Address Register This register sets the address for eMMC/SD + * flash transfers to/from memory. Sixty-four-bit operations must be used + * to access this register. This register is updated by the DMA hardware + * and can be reloaded by the values placed in the MIO_EMM_DMA_FIFO_ADR. + */ +union mio_emm_dma_adr { + u64 u; + struct mio_emm_dma_adr_s { + u64 adr : 53; + u64 reserved_53_63 : 11; + } s; + struct mio_emm_dma_adr_cn8 { + u64 adr : 49; + u64 reserved_49_63 : 15; + } cn8; + /* struct mio_emm_dma_adr_s cn9; */ +}; + +static inline u64 MIO_EMM_DMA_ADR(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_ADR(void) +{ + return 0x188; +} + +/** + * Register (RSL) mio_emm_dma_arg + * + * eMMC External DMA Extra Arguments Register + */ +union mio_emm_dma_arg { + u64 u; + struct mio_emm_dma_arg_s { + u64 cmd23_args : 8; + u64 force_pgm : 1; + u64 context_id : 4; + u64 tag_req : 1; + u64 pack_cmd : 1; + u64 rel_wr : 1; + u64 alt_cmd : 6; + u64 skip_blk_cmd : 1; + u64 reserved_23_31 : 9; + u64 alt_cmd_arg : 32; + } s; + /* struct mio_emm_dma_arg_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_ARG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_ARG(void) +{ + return 0x2090; +} + +/** + * Register (RSL) mio_emm_dma_cfg + * + * eMMC DMA Configuration Register This register controls the internal + * DMA engine used with the eMMC/SD flash controller. Sixty- four-bit + * operations must be used to access this register. This register is + * updated by the hardware DMA engine and can also be reloaded by writes + * to the MIO_EMM_DMA_FIFO_CMD register. + */ +union mio_emm_dma_cfg { + u64 u; + struct mio_emm_dma_cfg_s { + u64 reserved_0_35 : 36; + u64 size : 20; + u64 endian : 1; + u64 swap8 : 1; + u64 swap16 : 1; + u64 swap32 : 1; + u64 reserved_60 : 1; + u64 clr : 1; + u64 rw : 1; + u64 en : 1; + } s; + /* struct mio_emm_dma_cfg_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_CFG(void) +{ + return 0x180; +} + +/** + * Register (RSL) mio_emm_dma_fifo_adr + * + * eMMC Internal DMA FIFO Address Register This register specifies the + * internal address that is loaded into the eMMC internal DMA FIFO. The + * FIFO is used to queue up operations for the + * MIO_EMM_DMA_CFG/MIO_EMM_DMA_ADR when the DMA completes successfully. + */ +union mio_emm_dma_fifo_adr { + u64 u; + struct mio_emm_dma_fifo_adr_s { + u64 reserved_0_2 : 3; + u64 adr : 50; + u64 reserved_53_63 : 11; + } s; + struct mio_emm_dma_fifo_adr_cn8 { + u64 reserved_0_2 : 3; + u64 adr : 46; + u64 reserved_49_63 : 15; + } cn8; + /* struct mio_emm_dma_fifo_adr_s cn9; */ +}; + +static inline u64 MIO_EMM_DMA_FIFO_ADR(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_FIFO_ADR(void) +{ + return 0x170; +} + +/** + * Register (RSL) mio_emm_dma_fifo_cfg + * + * eMMC Internal DMA FIFO Configuration Register This register controls + * DMA FIFO operations. + */ +union mio_emm_dma_fifo_cfg { + u64 u; + struct mio_emm_dma_fifo_cfg_s { + u64 count : 5; + u64 reserved_5_7 : 3; + u64 int_lvl : 5; + u64 reserved_13_15 : 3; + u64 clr : 1; + u64 reserved_17_63 : 47; + } s; + /* struct mio_emm_dma_fifo_cfg_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_FIFO_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_FIFO_CFG(void) +{ + return 0x160; +} + +/** + * Register (RSL) mio_emm_dma_fifo_cmd + * + * eMMC Internal DMA FIFO Command Register This register specifies a + * command that is loaded into the eMMC internal DMA FIFO. The FIFO is + * used to queue up operations for the MIO_EMM_DMA_CFG/MIO_EMM_DMA_ADR + * when the DMA completes successfully. Writes to this register store + * both the MIO_EMM_DMA_FIFO_CMD and the MIO_EMM_DMA_FIFO_ADR contents + * into the FIFO and increment the MIO_EMM_DMA_FIFO_CFG[COUNT] field. + * Note: This register has a similar format to MIO_EMM_DMA_CFG with the + * exception that the EN and CLR fields are absent. These are supported + * in MIO_EMM_DMA_FIFO_CFG. + */ +union mio_emm_dma_fifo_cmd { + u64 u; + struct mio_emm_dma_fifo_cmd_s { + u64 reserved_0_35 : 36; + u64 size : 20; + u64 endian : 1; + u64 swap8 : 1; + u64 swap16 : 1; + u64 swap32 : 1; + u64 intdis : 1; + u64 reserved_61 : 1; + u64 rw : 1; + u64 reserved_63 : 1; + } s; + /* struct mio_emm_dma_fifo_cmd_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_FIFO_CMD(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_FIFO_CMD(void) +{ + return 0x178; +} + +/** + * Register (RSL) mio_emm_dma_int + * + * eMMC DMA Interrupt Register Sixty-four-bit operations must be used to + * access this register. + */ +union mio_emm_dma_int { + u64 u; + struct mio_emm_dma_int_s { + u64 done : 1; + u64 fifo : 1; + u64 reserved_2_63 : 62; + } s; + /* struct mio_emm_dma_int_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_INT(void) +{ + return 0x190; +} + +/** + * Register (RSL) mio_emm_dma_int_ena_w1c + * + * eMMC DMA Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union mio_emm_dma_int_ena_w1c { + u64 u; + struct mio_emm_dma_int_ena_w1c_s { + u64 done : 1; + u64 fifo : 1; + u64 reserved_2_63 : 62; + } s; + /* struct mio_emm_dma_int_ena_w1c_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_INT_ENA_W1C(void) +{ + return 0x1a8; +} + +/** + * Register (RSL) mio_emm_dma_int_ena_w1s + * + * eMMC DMA Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union mio_emm_dma_int_ena_w1s { + u64 u; + struct mio_emm_dma_int_ena_w1s_s { + u64 done : 1; + u64 fifo : 1; + u64 reserved_2_63 : 62; + } s; + /* struct mio_emm_dma_int_ena_w1s_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_INT_ENA_W1S(void) +{ + return 0x1a0; +} + +/** + * Register (RSL) mio_emm_dma_int_w1s + * + * eMMC DMA Interrupt Set Register This register sets interrupt bits. + */ +union mio_emm_dma_int_w1s { + u64 u; + struct mio_emm_dma_int_w1s_s { + u64 done : 1; + u64 fifo : 1; + u64 reserved_2_63 : 62; + } s; + /* struct mio_emm_dma_int_w1s_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_INT_W1S(void) +{ + return 0x198; +} + +/** + * Register (RSL) mio_emm_int + * + * eMMC Interrupt Register + */ +union mio_emm_int { + u64 u; + struct mio_emm_int_s { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 ncb_flt : 1; + u64 ncb_ras : 1; + u64 reserved_9_63 : 55; + } s; + struct mio_emm_int_cn8 { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 reserved_7_63 : 57; + } cn8; + /* struct mio_emm_int_s cn9; */ +}; + +static inline u64 MIO_EMM_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_INT(void) +{ + return 0x2078; +} + +/** + * Register (RSL) mio_emm_int_ena_w1c + * + * eMMC Interrupt Enable Clear Register This register clears interrupt + * enable bits. + */ +union mio_emm_int_ena_w1c { + u64 u; + struct mio_emm_int_ena_w1c_s { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 ncb_flt : 1; + u64 ncb_ras : 1; + u64 reserved_9_63 : 55; + } s; + struct mio_emm_int_ena_w1c_cn8 { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 reserved_7_63 : 57; + } cn8; + /* struct mio_emm_int_ena_w1c_s cn9; */ +}; + +static inline u64 MIO_EMM_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_INT_ENA_W1C(void) +{ + return 0x20b8; +} + +/** + * Register (RSL) mio_emm_int_ena_w1s + * + * eMMC Interrupt Enable Set Register This register sets interrupt enable + * bits. + */ +union mio_emm_int_ena_w1s { + u64 u; + struct mio_emm_int_ena_w1s_s { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 ncb_flt : 1; + u64 ncb_ras : 1; + u64 reserved_9_63 : 55; + } s; + struct mio_emm_int_ena_w1s_cn8 { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 reserved_7_63 : 57; + } cn8; + /* struct mio_emm_int_ena_w1s_s cn9; */ +}; + +static inline u64 MIO_EMM_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_INT_ENA_W1S(void) +{ + return 0x20b0; +} + +/** + * Register (RSL) mio_emm_int_w1s + * + * eMMC Interrupt Set Register This register sets interrupt bits. + */ +union mio_emm_int_w1s { + u64 u; + struct mio_emm_int_w1s_s { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 ncb_flt : 1; + u64 ncb_ras : 1; + u64 reserved_9_63 : 55; + } s; + struct mio_emm_int_w1s_cn8 { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 reserved_7_63 : 57; + } cn8; + /* struct mio_emm_int_w1s_s cn9; */ +}; + +static inline u64 MIO_EMM_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_INT_W1S(void) +{ + return 0x2080; +} + +/** + * Register (RSL) mio_emm_io_ctl + * + * eMMC I/O Control Register + */ +union mio_emm_io_ctl { + u64 u; + struct mio_emm_io_ctl_s { + u64 slew : 1; + u64 reserved_1 : 1; + u64 drive : 2; + u64 reserved_4_63 : 60; + } s; + /* struct mio_emm_io_ctl_s cn; */ +}; + +static inline u64 MIO_EMM_IO_CTL(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_IO_CTL(void) +{ + return 0x2040; +} + +/** + * Register (RSL) mio_emm_mode# + * + * eMMC Operating Mode Register + */ +union mio_emm_modex { + u64 u; + struct mio_emm_modex_s { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 clk_swap : 1; + u64 reserved_37_39 : 3; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 hs200_timing : 1; + u64 hs400_timing : 1; + u64 reserved_51_63 : 13; + } s; + struct mio_emm_modex_cn8 { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 reserved_36_39 : 4; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 reserved_49_63 : 15; + } cn8; + struct mio_emm_modex_cn96xxp1 { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 reserved_36_39 : 4; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 hs200_timing : 1; + u64 hs400_timing : 1; + u64 reserved_51_63 : 13; + } cn96xxp1; + /* struct mio_emm_modex_s cn96xxp3; */ + /* struct mio_emm_modex_s cnf95xx; */ +}; + +static inline u64 MIO_EMM_MODEX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_MODEX(u64 a) +{ + return 0x2008 + 8 * a; +} + +/** + * Register (RSL) mio_emm_msix_pba# + * + * eMMC MSI-X Pending Bit Array Registers This register is the MSI-X PBA + * table; the bit number is indexed by the MIO_EMM_INT_VEC_E enumeration. + */ +union mio_emm_msix_pbax { + u64 u; + struct mio_emm_msix_pbax_s { + u64 pend : 64; + } s; + /* struct mio_emm_msix_pbax_s cn; */ +}; + +static inline u64 MIO_EMM_MSIX_PBAX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_MSIX_PBAX(u64 a) +{ + return 0xf0000 + 8 * a; +} + +/** + * Register (RSL) mio_emm_msix_vec#_addr + * + * eMMC MSI-X Vector-Table Address Register This register is the MSI-X + * vector table, indexed by the MIO_EMM_INT_VEC_E enumeration. + */ +union mio_emm_msix_vecx_addr { + u64 u; + struct mio_emm_msix_vecx_addr_s { + u64 secvec : 1; + u64 reserved_1 : 1; + u64 addr : 51; + u64 reserved_53_63 : 11; + } s; + struct mio_emm_msix_vecx_addr_cn8 { + u64 secvec : 1; + u64 reserved_1 : 1; + u64 addr : 47; + u64 reserved_49_63 : 15; + } cn8; + /* struct mio_emm_msix_vecx_addr_s cn9; */ +}; + +static inline u64 MIO_EMM_MSIX_VECX_ADDR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_MSIX_VECX_ADDR(u64 a) +{ + return 0 + 0x10 * a; +} + +/** + * Register (RSL) mio_emm_msix_vec#_ctl + * + * eMMC MSI-X Vector-Table Control and Data Register This register is the + * MSI-X vector table, indexed by the MIO_EMM_INT_VEC_E enumeration. + */ +union mio_emm_msix_vecx_ctl { + u64 u; + struct mio_emm_msix_vecx_ctl_s { + u64 data : 32; + u64 mask : 1; + u64 reserved_33_63 : 31; + } s; + struct mio_emm_msix_vecx_ctl_cn8 { + u64 data : 20; + u64 reserved_20_31 : 12; + u64 mask : 1; + u64 reserved_33_63 : 31; + } cn8; + /* struct mio_emm_msix_vecx_ctl_s cn9; */ +}; + +static inline u64 MIO_EMM_MSIX_VECX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_MSIX_VECX_CTL(u64 a) +{ + return 8 + 0x10 * a; +} + +/** + * Register (RSL) mio_emm_rca + * + * eMMC Relative Card Address Register + */ +union mio_emm_rca { + u64 u; + struct mio_emm_rca_s { + u64 card_rca : 16; + u64 reserved_16_63 : 48; + } s; + /* struct mio_emm_rca_s cn; */ +}; + +static inline u64 MIO_EMM_RCA(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_RCA(void) +{ + return 0x20a0; +} + +/** + * Register (RSL) mio_emm_rsp_hi + * + * eMMC Response Data High Register + */ +union mio_emm_rsp_hi { + u64 u; + struct mio_emm_rsp_hi_s { + u64 dat : 64; + } s; + /* struct mio_emm_rsp_hi_s cn; */ +}; + +static inline u64 MIO_EMM_RSP_HI(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_RSP_HI(void) +{ + return 0x2070; +} + +/** + * Register (RSL) mio_emm_rsp_lo + * + * eMMC Response Data Low Register + */ +union mio_emm_rsp_lo { + u64 u; + struct mio_emm_rsp_lo_s { + u64 dat : 64; + } s; + /* struct mio_emm_rsp_lo_s cn; */ +}; + +static inline u64 MIO_EMM_RSP_LO(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_RSP_LO(void) +{ + return 0x2068; +} + +/** + * Register (RSL) mio_emm_rsp_sts + * + * eMMC Response Status Register + */ +union mio_emm_rsp_sts { + u64 u; + struct mio_emm_rsp_sts_s { + u64 cmd_done : 1; + u64 cmd_idx : 6; + u64 cmd_type : 2; + u64 rsp_type : 3; + u64 rsp_val : 1; + u64 rsp_bad_sts : 1; + u64 rsp_crc_err : 1; + u64 rsp_timeout : 1; + u64 stp_val : 1; + u64 stp_bad_sts : 1; + u64 stp_crc_err : 1; + u64 stp_timeout : 1; + u64 rsp_busybit : 1; + u64 blk_crc_err : 1; + u64 blk_timeout : 1; + u64 dbuf : 1; + u64 reserved_24_27 : 4; + u64 dbuf_err : 1; + u64 reserved_29_54 : 26; + u64 acc_timeout : 1; + u64 dma_pend : 1; + u64 dma_val : 1; + u64 switch_val : 1; + u64 cmd_val : 1; + u64 bus_id : 2; + u64 reserved_62_63 : 2; + } s; + /* struct mio_emm_rsp_sts_s cn; */ +}; + +static inline u64 MIO_EMM_RSP_STS(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_RSP_STS(void) +{ + return 0x2060; +} + +/** + * Register (RSL) mio_emm_sample + * + * eMMC Sampling Register + */ +union mio_emm_sample { + u64 u; + struct mio_emm_sample_s { + u64 dat_cnt : 10; + u64 reserved_10_15 : 6; + u64 cmd_cnt : 10; + u64 reserved_26_63 : 38; + } s; + /* struct mio_emm_sample_s cn; */ +}; + +static inline u64 MIO_EMM_SAMPLE(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_SAMPLE(void) +{ + return 0x2090; +} + +/** + * Register (RSL) mio_emm_sts_mask + * + * eMMC Status Mask Register + */ +union mio_emm_sts_mask { + u64 u; + struct mio_emm_sts_mask_s { + u64 sts_msk : 32; + u64 reserved_32_63 : 32; + } s; + /* struct mio_emm_sts_mask_s cn; */ +}; + +static inline u64 MIO_EMM_STS_MASK(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_STS_MASK(void) +{ + return 0x2098; +} + +/** + * Register (RSL) mio_emm_switch + * + * eMMC Operating Mode Switch Register This register allows software to + * change eMMC related parameters associated with a specific BUS_ID. The + * MIO_EMM_MODE() registers contain the current setting for each BUS. + * This register is also used to switch the [CLK_HI] and [CLK_LO] + * settings associated with the common EMMC_CLK. These settings can only + * be changed when [BUS_ID] = 0. + */ +union mio_emm_switch { + u64 u; + struct mio_emm_switch_s { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 clk_swap : 1; + u64 reserved_37_39 : 3; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 hs200_timing : 1; + u64 hs400_timing : 1; + u64 reserved_51_55 : 5; + u64 switch_err2 : 1; + u64 switch_err1 : 1; + u64 switch_err0 : 1; + u64 switch_exe : 1; + u64 bus_id : 2; + u64 reserved_62_63 : 2; + } s; + struct mio_emm_switch_cn8 { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 reserved_36_39 : 4; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 reserved_49_55 : 7; + u64 switch_err2 : 1; + u64 switch_err1 : 1; + u64 switch_err0 : 1; + u64 switch_exe : 1; + u64 bus_id : 2; + u64 reserved_62_63 : 2; + } cn8; + struct mio_emm_switch_cn96xxp1 { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 reserved_36_39 : 4; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 hs200_timing : 1; + u64 hs400_timing : 1; + u64 reserved_51_55 : 5; + u64 switch_err2 : 1; + u64 switch_err1 : 1; + u64 switch_err0 : 1; + u64 switch_exe : 1; + u64 bus_id : 2; + u64 reserved_62_63 : 2; + } cn96xxp1; + /* struct mio_emm_switch_s cn96xxp3; */ + /* struct mio_emm_switch_s cnf95xx; */ +}; + +static inline u64 MIO_EMM_SWITCH(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_SWITCH(void) +{ + return 0x2048; +} + +/** + * Register (RSL) mio_emm_tap + * + * eMMC TAP Delay Register This register indicates the delay line + * characteristics. + */ +union mio_emm_tap { + u64 u; + struct mio_emm_tap_s { + u64 delay : 8; + u64 reserved_8_63 : 56; + } s; + /* struct mio_emm_tap_s cn; */ +}; + +static inline u64 MIO_EMM_TAP(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_TAP(void) +{ + return 0x20c8; +} + +/** + * Register (RSL) mio_emm_timing + * + * eMMC Timing Register This register determines the number of tap delays + * the EMM_DAT, EMM_DS, and EMM_CMD lines are transmitted or received in + * relation to EMM_CLK. These values should only be changed when the eMMC + * bus is idle. + */ +union mio_emm_timing { + u64 u; + struct mio_emm_timing_s { + u64 data_out_tap : 6; + u64 reserved_6_15 : 10; + u64 data_in_tap : 6; + u64 reserved_22_31 : 10; + u64 cmd_out_tap : 6; + u64 reserved_38_47 : 10; + u64 cmd_in_tap : 6; + u64 reserved_54_63 : 10; + } s; + /* struct mio_emm_timing_s cn; */ +}; + +static inline u64 MIO_EMM_TIMING(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_TIMING(void) +{ + return 0x20d0; +} + +/** + * Register (RSL) mio_emm_wdog + * + * eMMC Watchdog Register + */ +union mio_emm_wdog { + u64 u; + struct mio_emm_wdog_s { + u64 clk_cnt : 26; + u64 reserved_26_63 : 38; + } s; + /* struct mio_emm_wdog_s cn; */ +}; + +static inline u64 MIO_EMM_WDOG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_WDOG(void) +{ + return 0x2088; +} + +#endif /* __CSRS_MIO_EMM_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx/csrs/csrs-xcv.h b/arch/arm/include/asm/arch-octeontx/csrs/csrs-xcv.h new file mode 100644 index 0000000000..159f58ace2 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx/csrs/csrs-xcv.h @@ -0,0 +1,428 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Marvell International Ltd. + * + * https://spdx.org/licenses + */ +#ifndef __CSRS_XCV_H__ +#define __CSRS_XCV_H__ + +/** + * @file + * + * Configuration and status register (CSR) address and type definitions for + * XCV. + * + * This file is auto generated. Do not edit. + * + */ + +/** + * Enumeration xcv_bar_e + * + * XCV Base Address Register Enumeration Enumerates the base address + * registers. + */ +#define XCV_BAR_E_XCVX_PF_BAR0(a) (0x87e0db000000ll + 0ll * (a)) +#define XCV_BAR_E_XCVX_PF_BAR0_SIZE 0x100000ull +#define XCV_BAR_E_XCVX_PF_BAR4(a) (0x87e0dbf00000ll + 0ll * (a)) +#define XCV_BAR_E_XCVX_PF_BAR4_SIZE 0x100000ull + +/** + * Enumeration xcv_int_vec_e + * + * XCV MSI-X Vector Enumeration Enumerates the MSI-X interrupt vectors. + */ +#define XCV_INT_VEC_E_INT (0) + +/** + * Register (RSL) xcv#_batch_crd_ret + * + * XCV Batch Credit Return Register + */ +union xcvx_batch_crd_ret { + u64 u; + struct xcvx_batch_crd_ret_s { + u64 crd_ret : 1; + u64 reserved_1_63 : 63; + } s; + /* struct xcvx_batch_crd_ret_s cn; */ +}; + +static inline u64 XCVX_BATCH_CRD_RET(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_BATCH_CRD_RET(u64 a) +{ + return 0x100 + 0 * a; +} + +/** + * Register (RSL) xcv#_comp_ctl + * + * XCV Compensation Controller Register This register controls + * programmable compensation. + */ +union xcvx_comp_ctl { + u64 u; + struct xcvx_comp_ctl_s { + u64 nctl_sat : 1; + u64 reserved_1_26 : 26; + u64 nctl_lock : 1; + u64 reserved_28 : 1; + u64 pctl_sat : 1; + u64 pctl_lock : 1; + u64 reserved_31 : 1; + u64 drv_nctl : 5; + u64 reserved_37_39 : 3; + u64 drv_pctl : 5; + u64 reserved_45_47 : 3; + u64 cmp_nctl : 5; + u64 reserved_53_55 : 3; + u64 cmp_pctl : 5; + u64 reserved_61_62 : 2; + u64 drv_byp : 1; + } s; + /* struct xcvx_comp_ctl_s cn; */ +}; + +static inline u64 XCVX_COMP_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_COMP_CTL(u64 a) +{ + return 0x20 + 0 * a; +} + +/** + * Register (RSL) xcv#_ctl + * + * XCV Control Register This register contains the status control bits. + */ +union xcvx_ctl { + u64 u; + struct xcvx_ctl_s { + u64 speed : 2; + u64 lpbk_int : 1; + u64 lpbk_ext : 1; + u64 reserved_4_63 : 60; + } s; + /* struct xcvx_ctl_s cn; */ +}; + +static inline u64 XCVX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_CTL(u64 a) +{ + return 0x30 + 0 * a; +} + +/** + * Register (RSL) xcv#_dll_ctl + * + * XCV DLL Controller Register The RGMII timing specification requires + * that devices transmit clock and data synchronously. The specification + * requires external sources (namely the PC board trace routes) to + * introduce the appropriate 1.5 to 2.0 ns of delay. To eliminate the + * need for the PC board delays, the RGMII interface has optional on- + * board DLLs for both transmit and receive. For correct operation, at + * most one of the transmitter, board, or receiver involved in an RGMII + * link should introduce delay. By default/reset, the RGMII receivers + * delay the received clock, and the RGMII transmitters do not delay the + * transmitted clock. Whether this default works as-is with a given link + * partner depends on the behavior of the link partner and the PC board. + * These are the possible modes of RGMII receive operation: * + * XCV()_DLL_CTL[CLKRX_BYP] = 0 (reset value) - The RGMII receive + * interface introduces clock delay using its internal DLL. This mode is + * appropriate if neither the remote transmitter nor the PC board delays + * the clock. * XCV()_DLL_CTL[CLKRX_BYP] = 1, [CLKRX_SET] = 0x0 - The + * RGMII receive interface introduces no clock delay. This mode is + * appropriate if either the remote transmitter or the PC board delays + * the clock. These are the possible modes of RGMII transmit operation: + * * XCV()_DLL_CTL[CLKTX_BYP] = 1, [CLKTX_SET] = 0x0 (reset value) - The + * RGMII transmit interface introduces no clock delay. This mode is + * appropriate is either the remote receiver or the PC board delays the + * clock. * XCV()_DLL_CTL[CLKTX_BYP] = 0 - The RGMII transmit interface + * introduces clock delay using its internal DLL. This mode is + * appropriate if neither the remote receiver nor the PC board delays the + * clock. + */ +union xcvx_dll_ctl { + u64 u; + struct xcvx_dll_ctl_s { + u64 refclk_sel : 2; + u64 reserved_2_7 : 6; + u64 clktx_set : 7; + u64 clktx_byp : 1; + u64 clkrx_set : 7; + u64 clkrx_byp : 1; + u64 clk_set : 7; + u64 lock : 1; + u64 reserved_32_63 : 32; + } s; + /* struct xcvx_dll_ctl_s cn; */ +}; + +static inline u64 XCVX_DLL_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_DLL_CTL(u64 a) +{ + return 0x10 + 0 * a; +} + +/** + * Register (RSL) xcv#_eco + * + * INTERNAL: XCV ECO Register + */ +union xcvx_eco { + u64 u; + struct xcvx_eco_s { + u64 eco_rw : 16; + u64 reserved_16_63 : 48; + } s; + /* struct xcvx_eco_s cn; */ +}; + +static inline u64 XCVX_ECO(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_ECO(u64 a) +{ + return 0x200 + 0 * a; +} + +/** + * Register (RSL) xcv#_inbnd_status + * + * XCV Inband Status Register This register contains RGMII inband status. + */ +union xcvx_inbnd_status { + u64 u; + struct xcvx_inbnd_status_s { + u64 link : 1; + u64 speed : 2; + u64 duplex : 1; + u64 reserved_4_63 : 60; + } s; + /* struct xcvx_inbnd_status_s cn; */ +}; + +static inline u64 XCVX_INBND_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_INBND_STATUS(u64 a) +{ + return 0x80 + 0 * a; +} + +/** + * Register (RSL) xcv#_int + * + * XCV Interrupt Register This register flags error for TX FIFO overflow, + * TX FIFO underflow and incomplete byte for 10/100 Mode. It also flags + * status change for link duplex, link speed and link up/down. + */ +union xcvx_int { + u64 u; + struct xcvx_int_s { + u64 link : 1; + u64 speed : 1; + u64 reserved_2 : 1; + u64 duplex : 1; + u64 incomp_byte : 1; + u64 tx_undflw : 1; + u64 tx_ovrflw : 1; + u64 reserved_7_63 : 57; + } s; + /* struct xcvx_int_s cn; */ +}; + +static inline u64 XCVX_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_INT(u64 a) +{ + return 0x40 + 0 * a; +} + +/** + * Register (RSL) xcv#_int_ena_w1c + * + * Loopback Error Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union xcvx_int_ena_w1c { + u64 u; + struct xcvx_int_ena_w1c_s { + u64 link : 1; + u64 speed : 1; + u64 reserved_2 : 1; + u64 duplex : 1; + u64 incomp_byte : 1; + u64 tx_undflw : 1; + u64 tx_ovrflw : 1; + u64 reserved_7_63 : 57; + } s; + /* struct xcvx_int_ena_w1c_s cn; */ +}; + +static inline u64 XCVX_INT_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_INT_ENA_W1C(u64 a) +{ + return 0x50 + 0 * a; +} + +/** + * Register (RSL) xcv#_int_ena_w1s + * + * Loopback Error Interrupt Enable Set Register This register sets + * interrupt enable bits. + */ +union xcvx_int_ena_w1s { + u64 u; + struct xcvx_int_ena_w1s_s { + u64 link : 1; + u64 speed : 1; + u64 reserved_2 : 1; + u64 duplex : 1; + u64 incomp_byte : 1; + u64 tx_undflw : 1; + u64 tx_ovrflw : 1; + u64 reserved_7_63 : 57; + } s; + /* struct xcvx_int_ena_w1s_s cn; */ +}; + +static inline u64 XCVX_INT_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_INT_ENA_W1S(u64 a) +{ + return 0x58 + 0 * a; +} + +/** + * Register (RSL) xcv#_int_w1s + * + * Loopback Error Interrupt Set Register This register sets interrupt + * bits. + */ +union xcvx_int_w1s { + u64 u; + struct xcvx_int_w1s_s { + u64 link : 1; + u64 speed : 1; + u64 reserved_2 : 1; + u64 duplex : 1; + u64 incomp_byte : 1; + u64 tx_undflw : 1; + u64 tx_ovrflw : 1; + u64 reserved_7_63 : 57; + } s; + /* struct xcvx_int_w1s_s cn; */ +}; + +static inline u64 XCVX_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_INT_W1S(u64 a) +{ + return 0x48 + 0 * a; +} + +/** + * Register (RSL) xcv#_msix_pba# + * + * XCV MSI-X Pending Bit Array Registers This register is the MSI-X PBA + * table; the bit number is indexed by the XCV_INT_VEC_E enumeration. + */ +union xcvx_msix_pbax { + u64 u; + struct xcvx_msix_pbax_s { + u64 pend : 64; + } s; + /* struct xcvx_msix_pbax_s cn; */ +}; + +static inline u64 XCVX_MSIX_PBAX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_MSIX_PBAX(u64 a, u64 b) +{ + return 0xf0000 + 0 * a + 8 * b; +} + +/** + * Register (RSL) xcv#_msix_vec#_addr + * + * XCV MSI-X Vector-Table Address Register This register is the MSI-X + * vector table, indexed by the XCV_INT_VEC_E enumeration. + */ +union xcvx_msix_vecx_addr { + u64 u; + struct xcvx_msix_vecx_addr_s { + u64 secvec : 1; + u64 reserved_1 : 1; + u64 addr : 47; + u64 reserved_49_63 : 15; + } s; + /* struct xcvx_msix_vecx_addr_s cn; */ +}; + +static inline u64 XCVX_MSIX_VECX_ADDR(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_MSIX_VECX_ADDR(u64 a, u64 b) +{ + return 0 + 0 * a + 0x10 * b; +} + +/** + * Register (RSL) xcv#_msix_vec#_ctl + * + * XCV MSI-X Vector-Table Control and Data Register This register is the + * MSI-X vector table, indexed by the XCV_INT_VEC_E enumeration. + */ +union xcvx_msix_vecx_ctl { + u64 u; + struct xcvx_msix_vecx_ctl_s { + u64 data : 20; + u64 reserved_20_31 : 12; + u64 mask : 1; + u64 reserved_33_63 : 31; + } s; + /* struct xcvx_msix_vecx_ctl_s cn; */ +}; + +static inline u64 XCVX_MSIX_VECX_CTL(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_MSIX_VECX_CTL(u64 a, u64 b) +{ + return 8 + 0 * a + 0x10 * b; +} + +/** + * Register (RSL) xcv#_reset + * + * XCV Reset Registers This register controls reset. + */ +union xcvx_reset { + u64 u; + struct xcvx_reset_s { + u64 rx_dat_rst_n : 1; + u64 rx_pkt_rst_n : 1; + u64 tx_dat_rst_n : 1; + u64 tx_pkt_rst_n : 1; + u64 reserved_4_6 : 3; + u64 comp : 1; + u64 reserved_8_10 : 3; + u64 dllrst : 1; + u64 reserved_12_14 : 3; + u64 clkrst : 1; + u64 reserved_16_62 : 47; + u64 enable : 1; + } s; + /* struct xcvx_reset_s cn; */ +}; + +static inline u64 XCVX_RESET(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 XCVX_RESET(u64 a) +{ + return 0 + 0 * a; +} + +#endif /* __CSRS_XCV_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx/gpio.h b/arch/arm/include/asm/arch-octeontx/gpio.h new file mode 100644 index 0000000000..3943ffd952 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx/gpio.h @@ -0,0 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ diff --git a/arch/arm/include/asm/arch-octeontx/smc.h b/arch/arm/include/asm/arch-octeontx/smc.h new file mode 100644 index 0000000000..beff4d158f --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx/smc.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __SMC_H__ +#define __SMC_H__ + +/* OcteonTX Service Calls version numbers */ +#define OCTEONTX_VERSION_MAJOR 0x1 +#define OCTEONTX_VERSION_MINOR 0x0 + +/* x1 - node number */ +#define OCTEONTX_DRAM_SIZE 0xc2000301 + +ssize_t smc_dram_size(unsigned int node); + +#endif /* __SMC_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx/soc.h b/arch/arm/include/asm/arch-octeontx/soc.h new file mode 100644 index 0000000000..dc081c70b2 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx/soc.h @@ -0,0 +1,33 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __SOC_H__ +#define __SOC_H__ + +/* Product PARTNUM */ +#define CN81XX 0xA2 +#define CN83XX 0xA3 +#define CN96XX 0xB2 +#define CN95XX 0xB3 + +#define otx_is_altpkg() read_alt_pkg() +#define otx_is_soc(soc) (read_partnum() == (soc)) +#define otx_is_board(model) (!strcmp(read_board_name(), model)) +#define otx_is_platform(platform) (read_platform() == (platform)) + +enum platform { + PLATFORM_HW = 0, + PLATFORM_EMULATOR = 1, + PLATFORM_ASIM = 3, +}; + +int read_platform(void); +u8 read_partnum(void); +const char *read_board_name(void); +bool read_alt_pkg(void); + +#endif /* __SOC_H */
Signed-off-by: Suneel Garapati sgarapati@marvell.com
Signed-off-by: Stefan Roese sr@denx.de ---
(no changes since v1)
arch/arm/include/asm/arch-octeontx2/board.h | 128 + arch/arm/include/asm/arch-octeontx2/clock.h | 24 + .../asm/arch-octeontx2/csrs/csrs-cgx.h | 7851 ++++++++++++ .../asm/arch-octeontx2/csrs/csrs-lmt.h | 60 + .../asm/arch-octeontx2/csrs/csrs-mio_emm.h | 1193 ++ .../asm/arch-octeontx2/csrs/csrs-nix.h | 10404 ++++++++++++++++ .../asm/arch-octeontx2/csrs/csrs-npa.h | 2294 ++++ .../asm/arch-octeontx2/csrs/csrs-npc.h | 1629 +++ .../asm/arch-octeontx2/csrs/csrs-rvu.h | 2276 ++++ arch/arm/include/asm/arch-octeontx2/gpio.h | 6 + arch/arm/include/asm/arch-octeontx2/smc-id.h | 32 + arch/arm/include/asm/arch-octeontx2/smc.h | 18 + arch/arm/include/asm/arch-octeontx2/soc.h | 33 + 13 files changed, 25948 insertions(+) create mode 100644 arch/arm/include/asm/arch-octeontx2/board.h create mode 100644 arch/arm/include/asm/arch-octeontx2/clock.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-cgx.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-lmt.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-mio_emm.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-nix.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-npa.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-npc.h create mode 100644 arch/arm/include/asm/arch-octeontx2/csrs/csrs-rvu.h create mode 100644 arch/arm/include/asm/arch-octeontx2/gpio.h create mode 100644 arch/arm/include/asm/arch-octeontx2/smc-id.h create mode 100644 arch/arm/include/asm/arch-octeontx2/smc.h create mode 100644 arch/arm/include/asm/arch-octeontx2/soc.h
diff --git a/arch/arm/include/asm/arch-octeontx2/board.h b/arch/arm/include/asm/arch-octeontx2/board.h new file mode 100644 index 0000000000..1c9ec113ca --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/board.h @@ -0,0 +1,128 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __BOARD_H__ +#define __BOARD_H__ + +#include <asm/arch/soc.h> + +/** Reg offsets */ +#define RST_BOOT 0x87E006001600ULL + +#define CPC_BOOT_OWNERX(a) 0x86D000000160ULL + (8 * (a)) + +/** Structure definitions */ +/** + * Register (NCB32b) cpc_boot_owner# + * + * CPC Boot Owner Registers These registers control an external arbiter + * for the boot device (SPI/eMMC) across multiple external devices. There + * is a register for each requester: _ <0> - SCP - reset on + * SCP reset _ <1> - MCP - reset on MCP reset _ <2> - AP + * Secure - reset on core reset _ <3> - AP Nonsecure - reset on core + * reset These register is only writable to the corresponding + * requestor(s) permitted with CPC_PERMIT. + */ +union cpc_boot_ownerx { + u32 u; + struct cpc_boot_ownerx_s { + u32 boot_req : 1; + u32 reserved_1_7 : 7; + u32 boot_wait : 1; + u32 reserved_9_31 : 23; + } s; +}; + +/** + * Register (RSL) rst_boot + * + * RST Boot Register This register is not accessible through ROM scripts; + * see SCR_WRITE32_S[ADDR]. + */ +union rst_boot { + u64 u; + struct rst_boot_s { + u64 rboot_pin : 1; + u64 rboot : 1; + u64 reserved_2_32 : 31; + u64 pnr_mul : 6; + u64 reserved_39 : 1; + u64 c_mul : 7; + u64 reserved_47_52 : 6; + u64 gpio_ejtag : 1; + u64 mcp_jtagdis : 1; + u64 dis_scan : 1; + u64 dis_huk : 1; + u64 vrm_err : 1; + u64 jt_tstmode : 1; + u64 ckill_ppdis : 1; + u64 trusted_mode : 1; + u64 reserved_61_62 : 2; + u64 chipkill : 1; + } s; + struct rst_boot_cn96xx { + u64 rboot_pin : 1; + u64 rboot : 1; + u64 reserved_2_23 : 22; + u64 cpt_mul : 7; + u64 reserved_31_32 : 2; + u64 pnr_mul : 6; + u64 reserved_39 : 1; + u64 c_mul : 7; + u64 reserved_47_52 : 6; + u64 gpio_ejtag : 1; + u64 mcp_jtagdis : 1; + u64 dis_scan : 1; + u64 dis_huk : 1; + u64 vrm_err : 1; + u64 reserved_58_59 : 2; + u64 trusted_mode : 1; + u64 scp_jtagdis : 1; + u64 jtagdis : 1; + u64 chipkill : 1; + } cn96xx; + struct rst_boot_cnf95xx { + u64 rboot_pin : 1; + u64 rboot : 1; + u64 reserved_2_7 : 6; + u64 bphy_mul : 7; + u64 reserved_15 : 1; + u64 dsp_mul : 7; + u64 reserved_23 : 1; + u64 cpt_mul : 7; + u64 reserved_31_32 : 2; + u64 pnr_mul : 6; + u64 reserved_39 : 1; + u64 c_mul : 7; + u64 reserved_47_52 : 6; + u64 gpio_ejtag : 1; + u64 mcp_jtagdis : 1; + u64 dis_scan : 1; + u64 dis_huk : 1; + u64 vrm_err : 1; + u64 reserved_58_59 : 2; + u64 trusted_mode : 1; + u64 scp_jtagdis : 1; + u64 jtagdis : 1; + u64 chipkill : 1; + } cnf95xx; +}; + +extern unsigned long fdt_base_addr; + +/** Function definitions */ +void mem_map_fill(void); +int fdt_get_board_mac_cnt(void); +u64 fdt_get_board_mac_addr(void); +const char *fdt_get_board_model(void); +const char *fdt_get_board_serial(void); +const char *fdt_get_board_revision(void); +void octeontx2_board_get_mac_addr(u8 index, u8 *mac_addr); +void board_acquire_flash_arb(bool acquire); +void cgx_intf_shutdown(void); + +#endif /* __BOARD_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx2/clock.h b/arch/arm/include/asm/arch-octeontx2/clock.h new file mode 100644 index 0000000000..7be8852a55 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/clock.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __CLOCK_H__ + +/** System PLL reference clock */ +#define PLL_REF_CLK 50000000 /* 50 MHz */ +#define NS_PER_REF_CLK_TICK (1000000000 / PLL_REF_CLK) + +/** + * Returns the I/O clock speed in Hz + */ +u64 octeontx_get_io_clock(void); + +/** + * Returns the core clock speed in Hz + */ +u64 octeontx_get_core_clock(void); + +#endif /* __CLOCK_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx2/csrs/csrs-cgx.h b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-cgx.h new file mode 100644 index 0000000000..34e7db3da6 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-cgx.h @@ -0,0 +1,7851 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Marvell International Ltd. + * + * https://spdx.org/licenses + */ +#ifndef __CSRS_CGX_H__ +#define __CSRS_CGX_H__ + +/** + * @file + * + * Configuration and status register (CSR) address and type definitions for + * CGX. + * + * This file is auto generated. Do not edit. + * + */ + +/** + * Enumeration cgx_bar_e + * + * CGX Base Address Register Enumeration Enumerates the base address + * registers. + */ +#define CGX_BAR_E_CGXX_PF_BAR0(a) (0x87e0e0000000ll + 0x1000000ll * (a)) +#define CGX_BAR_E_CGXX_PF_BAR0_SIZE 0x100000ull +#define CGX_BAR_E_CGXX_PF_BAR4(a) (0x87e0e0400000ll + 0x1000000ll * (a)) +#define CGX_BAR_E_CGXX_PF_BAR4_SIZE 0x100000ull + +/** + * Enumeration cgx_int_vec_e + * + * CGX MSI-X Vector Enumeration Enumeration the MSI-X interrupt vectors. + */ +#define CGX_INT_VEC_E_CMRX_INT(a) (0 + 9 * (a)) +#define CGX_INT_VEC_E_CMRX_SW(a) (0x26 + (a)) +#define CGX_INT_VEC_E_CMR_MEM_INT (0x24) +#define CGX_INT_VEC_E_GMPX_GMI_RX_INT(a) (5 + 9 * (a)) +#define CGX_INT_VEC_E_GMPX_GMI_TX_INT(a) (6 + 9 * (a)) +#define CGX_INT_VEC_E_GMPX_GMI_WOL_INT(a) (7 + 9 * (a)) +#define CGX_INT_VEC_E_GMPX_PCS_INT(a) (4 + 9 * (a)) +#define CGX_INT_VEC_E_SMUX_RX_INT(a) (2 + 9 * (a)) +#define CGX_INT_VEC_E_SMUX_RX_WOL_INT(a) (8 + 9 * (a)) +#define CGX_INT_VEC_E_SMUX_TX_INT(a) (3 + 9 * (a)) +#define CGX_INT_VEC_E_SPUX_INT(a) (1 + 9 * (a)) +#define CGX_INT_VEC_E_SW (0x25) + +/** + * Enumeration cgx_lmac_types_e + * + * CGX LMAC Type Enumeration Enumerates the LMAC Types that CGX supports. + */ +#define CGX_LMAC_TYPES_E_FIFTYG_R (8) +#define CGX_LMAC_TYPES_E_FORTYG_R (4) +#define CGX_LMAC_TYPES_E_HUNDREDG_R (9) +#define CGX_LMAC_TYPES_E_QSGMII (6) +#define CGX_LMAC_TYPES_E_RGMII (5) +#define CGX_LMAC_TYPES_E_RXAUI (2) +#define CGX_LMAC_TYPES_E_SGMII (0) +#define CGX_LMAC_TYPES_E_TENG_R (3) +#define CGX_LMAC_TYPES_E_TWENTYFIVEG_R (7) +#define CGX_LMAC_TYPES_E_USXGMII (0xa) +#define CGX_LMAC_TYPES_E_XAUI (1) + +/** + * Enumeration cgx_opcode_e + * + * INTERNAL: CGX Error Opcode Enumeration Enumerates the error opcodes + * created by CGX and presented to NCSI/NIX. + */ +#define CGX_OPCODE_E_RE_FCS (7) +#define CGX_OPCODE_E_RE_FCS_RCV (8) +#define CGX_OPCODE_E_RE_JABBER (2) +#define CGX_OPCODE_E_RE_NONE (0) +#define CGX_OPCODE_E_RE_PARTIAL (1) +#define CGX_OPCODE_E_RE_RX_CTL (0xb) +#define CGX_OPCODE_E_RE_SKIP (0xc) +#define CGX_OPCODE_E_RE_TERMINATE (9) + +/** + * Enumeration cgx_spu_br_train_cst_e + * + * INTERNAL: CGX Training Coefficient Status Enumeration 2-bit status + * for each coefficient as defined in IEEE 802.3, Table 72-5. + */ +#define CGX_SPU_BR_TRAIN_CST_E_MAXIMUM (3) +#define CGX_SPU_BR_TRAIN_CST_E_MINIMUM (2) +#define CGX_SPU_BR_TRAIN_CST_E_NOT_UPDATED (0) +#define CGX_SPU_BR_TRAIN_CST_E_UPDATED (1) + +/** + * Enumeration cgx_spu_br_train_cup_e + * + * INTERNAL:CGX Training Coefficient Enumeration 2-bit command for each + * coefficient as defined in IEEE 802.3, Table 72-4. + */ +#define CGX_SPU_BR_TRAIN_CUP_E_DECREMENT (1) +#define CGX_SPU_BR_TRAIN_CUP_E_HOLD (0) +#define CGX_SPU_BR_TRAIN_CUP_E_INCREMENT (2) +#define CGX_SPU_BR_TRAIN_CUP_E_RSV_CMD (3) + +/** + * Enumeration cgx_usxgmii_rate_e + * + * CGX USXGMII Rate Enumeration Enumerates the USXGMII sub-port type + * rate, CGX()_SPU()_CONTROL1[USXGMII_RATE]. Selecting a rate higher + * than the maximum allowed for a given port sub-type (specified by + * CGX()_SPU()_CONTROL1[USXGMII_TYPE]), e.g., selecting ::RATE_2HG (2.5 + * Gbps) for CGX_USXGMII_TYPE_E::SXGMII_2G, will cause unpredictable + * behavior. USXGMII hardware-based autonegotiation may change this + * setting. + */ +#define CGX_USXGMII_RATE_E_RATE_100M (1) +#define CGX_USXGMII_RATE_E_RATE_10G (5) +#define CGX_USXGMII_RATE_E_RATE_10M (0) +#define CGX_USXGMII_RATE_E_RATE_1G (2) +#define CGX_USXGMII_RATE_E_RATE_20G (6) +#define CGX_USXGMII_RATE_E_RATE_2HG (3) +#define CGX_USXGMII_RATE_E_RATE_5G (4) +#define CGX_USXGMII_RATE_E_RSV_RATE (7) + +/** + * Enumeration cgx_usxgmii_type_e + * + * CGX USXGMII Port Sub-Type Enumeration Enumerates the USXGMII sub-port + * type, CGX()_SPU()_CONTROL1[USXGMII_TYPE]. The description indicates + * the maximum rate and the maximum number of ports (LMACs) for each sub- + * type. The minimum rate for any port is 10M. The rate selection for + * each LMAC is made using CGX()_SPU()_CONTROL1[USXGMII_RATE] and the + * number of active ports/LMACs is implicitly determined by the value + * given to CGX()_CMR()_CONFIG[ENABLE] for each LMAC. Selecting a rate + * higher than the maximum allowed for a given port sub-type or enabling + * more LMACs than the maximum allowed for a given port sub-type will + * cause unpredictable behavior. + */ +#define CGX_USXGMII_TYPE_E_DXGMII_10G (3) +#define CGX_USXGMII_TYPE_E_DXGMII_20G (5) +#define CGX_USXGMII_TYPE_E_DXGMII_5G (4) +#define CGX_USXGMII_TYPE_E_QXGMII_10G (7) +#define CGX_USXGMII_TYPE_E_QXGMII_20G (6) +#define CGX_USXGMII_TYPE_E_SXGMII_10G (0) +#define CGX_USXGMII_TYPE_E_SXGMII_2G (2) +#define CGX_USXGMII_TYPE_E_SXGMII_5G (1) + +/** + * Structure cgx_spu_br_lane_train_status_s + * + * INTERNAL:CGX Lane Training Status Structure This is the group of lane + * status bits for a single lane in the BASE-R PMD status register (MDIO + * address 1.151) as defined in IEEE 802.3ba-2010, Table 45-55. + */ +union cgx_spu_br_lane_train_status_s { + u32 u; + struct cgx_spu_br_lane_train_status_s_s { + u32 rx_trained : 1; + u32 frame_lock : 1; + u32 training : 1; + u32 training_failure : 1; + u32 reserved_4_31 : 28; + } s; + /* struct cgx_spu_br_lane_train_status_s_s cn; */ +}; + +/** + * Structure cgx_spu_br_train_cup_s + * + * INTERNAL:CGX Lane Training Coefficient Structure This is the + * coefficient update field of the BASE-R link training packet as defined + * in IEEE 802.3, Table 72-4. + */ +union cgx_spu_br_train_cup_s { + u32 u; + struct cgx_spu_br_train_cup_s_s { + u32 pre_cup : 2; + u32 main_cup : 2; + u32 post_cup : 2; + u32 reserved_6_11 : 6; + u32 init : 1; + u32 preset : 1; + u32 reserved_14_31 : 18; + } s; + struct cgx_spu_br_train_cup_s_cn { + u32 pre_cup : 2; + u32 main_cup : 2; + u32 post_cup : 2; + u32 reserved_6_11 : 6; + u32 init : 1; + u32 preset : 1; + u32 reserved_14_15 : 2; + u32 reserved_16_31 : 16; + } cn; +}; + +/** + * Structure cgx_spu_br_train_rep_s + * + * INTERNAL:CGX Training Report Structure This is the status report + * field of the BASE-R link training packet as defined in IEEE 802.3, + * Table 72-5. + */ +union cgx_spu_br_train_rep_s { + u32 u; + struct cgx_spu_br_train_rep_s_s { + u32 pre_cst : 2; + u32 main_cst : 2; + u32 post_cst : 2; + u32 reserved_6_14 : 9; + u32 rx_ready : 1; + u32 reserved_16_31 : 16; + } s; + /* struct cgx_spu_br_train_rep_s_s cn; */ +}; + +/** + * Structure cgx_spu_sds_cu_s + * + * INTERNAL: CGX Training Coeffiecient Structure This structure is + * similar to CGX_SPU_BR_TRAIN_CUP_S format, but with reserved fields + * removed and [RCVR_READY] field added. + */ +union cgx_spu_sds_cu_s { + u32 u; + struct cgx_spu_sds_cu_s_s { + u32 pre_cu : 2; + u32 main_cu : 2; + u32 post_cu : 2; + u32 initialize : 1; + u32 preset : 1; + u32 rcvr_ready : 1; + u32 reserved_9_31 : 23; + } s; + /* struct cgx_spu_sds_cu_s_s cn; */ +}; + +/** + * Structure cgx_spu_sds_skew_status_s + * + * CGX Skew Status Structure Provides receive skew information detected + * for a physical SerDes lane when it is assigned to a multilane + * LMAC/LPCS. Contents are valid when RX deskew is done for the + * associated LMAC/LPCS. + */ +union cgx_spu_sds_skew_status_s { + u32 u; + struct cgx_spu_sds_skew_status_s_s { + u32 am_timestamp : 12; + u32 reserved_12_15 : 4; + u32 am_lane_id : 5; + u32 reserved_21_22 : 2; + u32 lane_skew : 7; + u32 reserved_30_31 : 2; + } s; + /* struct cgx_spu_sds_skew_status_s_s cn; */ +}; + +/** + * Structure cgx_spu_sds_sr_s + * + * INTERNAL: CGX Lane Training Coefficient Structure Similar to + * CGX_SPU_BR_TRAIN_REP_S format, but with reserved and RX ready fields + * removed. + */ +union cgx_spu_sds_sr_s { + u32 u; + struct cgx_spu_sds_sr_s_s { + u32 pre_status : 2; + u32 main_status : 2; + u32 post_status : 2; + u32 reserved_6_31 : 26; + } s; + /* struct cgx_spu_sds_sr_s_s cn; */ +}; + +/** + * Register (RSL) cgx#_active_pc + * + * CGX ACTIVE PC Register This register counts the conditional clocks for + * power management. + */ +union cgxx_active_pc { + u64 u; + struct cgxx_active_pc_s { + u64 cnt : 64; + } s; + /* struct cgxx_active_pc_s cn; */ +}; + +static inline u64 CGXX_ACTIVE_PC(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_ACTIVE_PC(void) +{ + return 0x2010; +} + +/** + * Register (RSL) cgx#_cmr#_activity + * + * CGX CMR Activity Registers + */ +union cgxx_cmrx_activity { + u64 u; + struct cgxx_cmrx_activity_s { + u64 act_tx_lo : 1; + u64 act_tx_hi : 1; + u64 pause_tx : 1; + u64 act_rx_lo : 1; + u64 act_rx_hi : 1; + u64 pause_rx : 1; + u64 reserved_6_63 : 58; + } s; + /* struct cgxx_cmrx_activity_s cn; */ +}; + +static inline u64 CGXX_CMRX_ACTIVITY(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_ACTIVITY(u64 a) +{ + return 0x5f8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_config + * + * CGX CMR Configuration Registers Logical MAC/PCS configuration + * registers; one per LMAC. The maximum number of LMACs (and maximum LMAC + * ID) that can be enabled by these registers is limited by + * CGX()_CMR_RX_LMACS[LMACS] and CGX()_CMR_TX_LMACS[LMACS]. Internal: + * <pre> Example configurations: ------------------------------------ + * --------------------------------------- Configuration + * LMACS Register [ENABLE] [LMAC_TYPE] ---------------- + * ----------------------------------------------------------- + * 1x50G+1x25G+1xSGMII 4 CGXn_CMR0_CONFIG 1 8 + * CGXn_CMR1_CONFIG 0 -- + * CGXn_CMR2_CONFIG 1 7 + * CGXn_CMR3_CONFIG 1 0 --------------------------------- + * ------------------------------------------ USXGMII + * 1-4 CGXn_CMR0_CONFIG 1 a + * CGXn_CMR1_CONFIG 1 a + * CGXn_CMR2_CONFIG 1 a + * CGXn_CMR3_CONFIG 1 a --------------------------------- + * ------------------------------------------ 1x100GBASE-R4 1 + * CGXn_CMR0_CONFIG 1 9 + * CGXn_CMR1_CONFIG 0 -- + * CGXn_CMR2_CONFIG 0 -- + * CGXn_CMR3_CONFIG 0 -- -------------------------------- + * ------------------------------------------- 2x50GBASE-R2 + * 2 CGXn_CMR0_CONFIG 1 8 + * CGXn_CMR1_CONFIG 1 8 + * CGXn_CMR2_CONFIG 0 -- + * CGXn_CMR3_CONFIG 0 -- -------------------------------- + * ------------------------------------------- 4x25GBASE-R + * 4 CGXn_CMR0_CONFIG 1 7 + * CGXn_CMR1_CONFIG 1 7 + * CGXn_CMR2_CONFIG 1 7 + * CGXn_CMR3_CONFIG 1 7 --------------------------------- + * ------------------------------------------ QSGMII 4 + * CGXn_CMR0_CONFIG 1 6 + * CGXn_CMR1_CONFIG 1 6 + * CGXn_CMR2_CONFIG 1 6 + * CGXn_CMR3_CONFIG 1 6 --------------------------------- + * ------------------------------------------ 1x40GBASE-R4 1 + * CGXn_CMR0_CONFIG 1 4 + * CGXn_CMR1_CONFIG 0 -- + * CGXn_CMR2_CONFIG 0 -- + * CGXn_CMR3_CONFIG 0 -- -------------------------------- + * ------------------------------------------- 4x10GBASE-R + * 4 CGXn_CMR0_CONFIG 1 3 + * CGXn_CMR1_CONFIG 1 3 + * CGXn_CMR2_CONFIG 1 3 + * CGXn_CMR3_CONFIG 1 3 --------------------------------- + * ------------------------------------------ 2xRXAUI 2 + * CGXn_CMR0_CONFIG 1 2 + * CGXn_CMR1_CONFIG 1 2 + * CGXn_CMR2_CONFIG 0 -- + * CGXn_CMR3_CONFIG 0 -- -------------------------------- + * ------------------------------------------- 1x10GBASE-X/XAUI/DXAUI + * 1 CGXn_CMR0_CONFIG 1 1 + * CGXn_CMR1_CONFIG 0 -- + * CGXn_CMR2_CONFIG 0 -- + * CGXn_CMR3_CONFIG 0 -- -------------------------------- + * ------------------------------------------- 4xSGMII/1000BASE-X + * 4 CGXn_CMR0_CONFIG 1 0 + * CGXn_CMR1_CONFIG 1 0 + * CGXn_CMR2_CONFIG 1 0 + * CGXn_CMR3_CONFIG 1 0 --------------------------------- + * ------------------------------------------ </pre> + */ +union cgxx_cmrx_config { + u64 u; + struct cgxx_cmrx_config_s { + u64 lane_to_sds : 8; + u64 reserved_8_39 : 32; + u64 lmac_type : 4; + u64 unused : 8; + u64 int_beat_gen : 1; + u64 data_pkt_tx_en : 1; + u64 data_pkt_rx_en : 1; + u64 enable : 1; + u64 x2p_select : 3; + u64 p2x_select : 3; + u64 reserved_62_63 : 2; + } s; + /* struct cgxx_cmrx_config_s cn; */ +}; + +static inline u64 CGXX_CMRX_CONFIG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_CONFIG(u64 a) +{ + return 0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_int + * + * CGX CMR Interrupt Register + */ +union cgxx_cmrx_int { + u64 u; + struct cgxx_cmrx_int_s { + u64 pause_drp : 1; + u64 overflw : 1; + u64 nic_nxc : 1; + u64 nix0_nxc : 1; + u64 nix1_nxc : 1; + u64 nix0_e_nxc : 1; + u64 nix1_e_nxc : 1; + u64 reserved_7_63 : 57; + } s; + /* struct cgxx_cmrx_int_s cn; */ +}; + +static inline u64 CGXX_CMRX_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_INT(u64 a) +{ + return 0x40 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_int_ena_w1c + * + * CGX CMR Interrupt Enable Clear Register This register clears interrupt + * enable bits. + */ +union cgxx_cmrx_int_ena_w1c { + u64 u; + struct cgxx_cmrx_int_ena_w1c_s { + u64 pause_drp : 1; + u64 overflw : 1; + u64 nic_nxc : 1; + u64 nix0_nxc : 1; + u64 nix1_nxc : 1; + u64 nix0_e_nxc : 1; + u64 nix1_e_nxc : 1; + u64 reserved_7_63 : 57; + } s; + /* struct cgxx_cmrx_int_ena_w1c_s cn; */ +}; + +static inline u64 CGXX_CMRX_INT_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_INT_ENA_W1C(u64 a) +{ + return 0x50 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_int_ena_w1s + * + * CGX CMR Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union cgxx_cmrx_int_ena_w1s { + u64 u; + struct cgxx_cmrx_int_ena_w1s_s { + u64 pause_drp : 1; + u64 overflw : 1; + u64 nic_nxc : 1; + u64 nix0_nxc : 1; + u64 nix1_nxc : 1; + u64 nix0_e_nxc : 1; + u64 nix1_e_nxc : 1; + u64 reserved_7_63 : 57; + } s; + /* struct cgxx_cmrx_int_ena_w1s_s cn; */ +}; + +static inline u64 CGXX_CMRX_INT_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_INT_ENA_W1S(u64 a) +{ + return 0x58 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_int_w1s + * + * CGX CMR Interrupt Set Register This register sets interrupt bits. + */ +union cgxx_cmrx_int_w1s { + u64 u; + struct cgxx_cmrx_int_w1s_s { + u64 pause_drp : 1; + u64 overflw : 1; + u64 nic_nxc : 1; + u64 nix0_nxc : 1; + u64 nix1_nxc : 1; + u64 nix0_e_nxc : 1; + u64 nix1_e_nxc : 1; + u64 reserved_7_63 : 57; + } s; + /* struct cgxx_cmrx_int_w1s_s cn; */ +}; + +static inline u64 CGXX_CMRX_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_INT_W1S(u64 a) +{ + return 0x48 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_led_timing + * + * CGX MAC LED Activity Timing Registers + */ +union cgxx_cmrx_led_timing { + u64 u; + struct cgxx_cmrx_led_timing_s { + u64 extension : 8; + u64 reserved_8_63 : 56; + } s; + /* struct cgxx_cmrx_led_timing_s cn; */ +}; + +static inline u64 CGXX_CMRX_LED_TIMING(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_LED_TIMING(u64 a) +{ + return 0x5f0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_prt_cbfc_ctl + * + * CGX CMR LMAC PFC Control Registers See CGX()_CMR()_RX_LOGL_XOFF[XOFF]. + */ +union cgxx_cmrx_prt_cbfc_ctl { + u64 u; + struct cgxx_cmrx_prt_cbfc_ctl_s { + u64 reserved_0_15 : 16; + u64 phys_bp : 16; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_cmrx_prt_cbfc_ctl_s cn; */ +}; + +static inline u64 CGXX_CMRX_PRT_CBFC_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_PRT_CBFC_CTL(u64 a) +{ + return 0x608 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_bp_drop + * + * CGX Receive Backpressure Drop Register + */ +union cgxx_cmrx_rx_bp_drop { + u64 u; + struct cgxx_cmrx_rx_bp_drop_s { + u64 mark : 7; + u64 reserved_7_63 : 57; + } s; + /* struct cgxx_cmrx_rx_bp_drop_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_BP_DROP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_BP_DROP(u64 a) +{ + return 0xd8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_bp_off + * + * CGX Receive Backpressure Off Register + */ +union cgxx_cmrx_rx_bp_off { + u64 u; + struct cgxx_cmrx_rx_bp_off_s { + u64 mark : 7; + u64 reserved_7_63 : 57; + } s; + /* struct cgxx_cmrx_rx_bp_off_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_BP_OFF(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_BP_OFF(u64 a) +{ + return 0xe8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_bp_on + * + * CGX Receive Backpressure On Register + */ +union cgxx_cmrx_rx_bp_on { + u64 u; + struct cgxx_cmrx_rx_bp_on_s { + u64 mark : 13; + u64 reserved_13_63 : 51; + } s; + /* struct cgxx_cmrx_rx_bp_on_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_BP_ON(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_BP_ON(u64 a) +{ + return 0xe0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_bp_status + * + * CGX CMR Receive Backpressure Status Registers + */ +union cgxx_cmrx_rx_bp_status { + u64 u; + struct cgxx_cmrx_rx_bp_status_s { + u64 bp : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_cmrx_rx_bp_status_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_BP_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_BP_STATUS(u64 a) +{ + return 0xf0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_dmac_ctl0 + * + * CGX CMR Receive DMAC Address-Control0 Register DMAC CAM control + * register for use by X2P/NIX bound traffic. Received packets are only + * passed to X2P/NIX when the DMAC0 filter result is ACCEPT and STEERING0 + * filter result is PASS. See also CGX()_CMR_RX_DMAC()_CAM0 and + * CGX()_CMR_RX_STEERING0(). Internal: "* ALGORITHM Here is some pseudo + * code that represents the address filter behavior. <pre> + * dmac_addr_filter(uint8 prt, uint48 dmac) { for (lmac=0, lmac<4, + * lmac++) { if (is_bcst(dmac)) // + * broadcast accept return (CGX()_CMR(lmac)_RX_DMAC_CTL0[BCST_ACCEPT] + * ? ACCEPT : REJECT); if (is_mcst(dmac) && + * CGX()_CMR(lmac)_RX_DMAC_CTL0[MCST_MODE] == 0) // multicast reject + * return REJECT; if (is_mcst(dmac) && + * CGX()_CMR(lmac)_RX_DMAC_CTL0[MCST_MODE] == 1) // multicast accept + * return ACCEPT; else // DMAC CAM filter cam_hit = 0; for + * (i=0; i<32; i++) { cam = CGX()_CMR_RX_DMAC(i)_CAM0; if + * (cam[EN] && cam[ID] == lmac && cam[ADR] == dmac) { cam_hit = 1; + * break; } } if (cam_hit) { return + * (CGX()_CMR(lmac)_RX_DMAC_CTL0[CAM_ACCEPT] ? ACCEPT : REJECT); else + * return (CGX()_CMR(lmac)_RX_DMAC_CTL0[CAM_ACCEPT] ? REJECT : ACCEPT); + * } } </pre>" + */ +union cgxx_cmrx_rx_dmac_ctl0 { + u64 u; + struct cgxx_cmrx_rx_dmac_ctl0_s { + u64 bcst_accept : 1; + u64 mcst_mode : 2; + u64 cam_accept : 1; + u64 reserved_4_63 : 60; + } s; + /* struct cgxx_cmrx_rx_dmac_ctl0_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_DMAC_CTL0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_DMAC_CTL0(u64 a) +{ + return 0x1f8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_dmac_ctl1 + * + * CGX CMR Receive DMAC Address-Control1 Register DMAC CAM control + * register for use by NCSI bound traffic. Received packets are only + * passed to NCSI when the DMAC1 filter result is ACCEPT and STEERING1 + * filter result is PASS. See also CGX()_CMR_RX_DMAC()_CAM1 and + * CGX()_CMR_RX_STEERING1(). For use with the LMAC associated with NCSI; + * see CGX()_CMR_GLOBAL_CONFIG[NCSI_LMAC_ID]. Internal: ALGORITHM: See + * CGX()_CMR()_RX_DMAC_CTL0. + */ +union cgxx_cmrx_rx_dmac_ctl1 { + u64 u; + struct cgxx_cmrx_rx_dmac_ctl1_s { + u64 bcst_accept : 1; + u64 mcst_mode : 2; + u64 cam_accept : 1; + u64 reserved_4_63 : 60; + } s; + /* struct cgxx_cmrx_rx_dmac_ctl1_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_DMAC_CTL1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_DMAC_CTL1(u64 a) +{ + return 0x3f8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_fifo_len + * + * CGX CMR Receive Fifo Length Registers + */ +union cgxx_cmrx_rx_fifo_len { + u64 u; + struct cgxx_cmrx_rx_fifo_len_s { + u64 fifo_len : 14; + u64 busy : 1; + u64 fifo_len_e : 14; + u64 busy_e : 1; + u64 reserved_30_63 : 34; + } s; + /* struct cgxx_cmrx_rx_fifo_len_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_FIFO_LEN(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_FIFO_LEN(u64 a) +{ + return 0x108 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_id_map + * + * CGX CMR Receive ID Map Register These registers set the RX LMAC ID + * mapping for X2P/NIX. + */ +union cgxx_cmrx_rx_id_map { + u64 u; + struct cgxx_cmrx_rx_id_map_s { + u64 pknd : 6; + u64 unused : 2; + u64 rid : 7; + u64 reserved_15_63 : 49; + } s; + /* struct cgxx_cmrx_rx_id_map_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_ID_MAP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_ID_MAP(u64 a) +{ + return 0x60 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_logl_xoff + * + * CGX CMR Receive Logical XOFF Registers + */ +union cgxx_cmrx_rx_logl_xoff { + u64 u; + struct cgxx_cmrx_rx_logl_xoff_s { + u64 xoff : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_cmrx_rx_logl_xoff_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_LOGL_XOFF(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_LOGL_XOFF(u64 a) +{ + return 0xf8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_logl_xon + * + * CGX CMR Receive Logical XON Registers + */ +union cgxx_cmrx_rx_logl_xon { + u64 u; + struct cgxx_cmrx_rx_logl_xon_s { + u64 xon : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_cmrx_rx_logl_xon_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_LOGL_XON(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_LOGL_XON(u64 a) +{ + return 0x100 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_merge_stat0 + * + * CGX RX Preemption Status Register 0 + */ +union cgxx_cmrx_rx_merge_stat0 { + u64 u; + struct cgxx_cmrx_rx_merge_stat0_s { + u64 fa_err_cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_merge_stat0_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_MERGE_STAT0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_MERGE_STAT0(u64 a) +{ + return 0x138 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_merge_stat1 + * + * CGX RX Preemption Status Register 1 + */ +union cgxx_cmrx_rx_merge_stat1 { + u64 u; + struct cgxx_cmrx_rx_merge_stat1_s { + u64 fs_err_cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_merge_stat1_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_MERGE_STAT1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_MERGE_STAT1(u64 a) +{ + return 0x140 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_merge_stat2 + * + * CGX RX Preemption Status Register 2 + */ +union cgxx_cmrx_rx_merge_stat2 { + u64 u; + struct cgxx_cmrx_rx_merge_stat2_s { + u64 fa_ok_cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_merge_stat2_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_MERGE_STAT2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_MERGE_STAT2(u64 a) +{ + return 0x148 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_merge_stat3 + * + * CGX RX Preemption Status Register 3 + */ +union cgxx_cmrx_rx_merge_stat3 { + u64 u; + struct cgxx_cmrx_rx_merge_stat3_s { + u64 ff_cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_merge_stat3_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_MERGE_STAT3(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_MERGE_STAT3(u64 a) +{ + return 0x150 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_merge_stat4 + * + * CGX RX Preemption Status Register 4 + */ +union cgxx_cmrx_rx_merge_stat4 { + u64 u; + struct cgxx_cmrx_rx_merge_stat4_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_merge_stat4_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_MERGE_STAT4(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_MERGE_STAT4(u64 a) +{ + return 0x158 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_pause_drop_time + * + * CGX CMR Receive Pause Drop-Time Register + */ +union cgxx_cmrx_rx_pause_drop_time { + u64 u; + struct cgxx_cmrx_rx_pause_drop_time_s { + u64 pause_time : 16; + u64 pause_time_e : 16; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_cmrx_rx_pause_drop_time_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_PAUSE_DROP_TIME(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_PAUSE_DROP_TIME(u64 a) +{ + return 0x68 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_stat0 + * + * CGX Receive Status Register 0 These registers provide a count of + * received packets that meet the following conditions: * are not + * recognized as ERROR packets(any OPCODE). * are not recognized as PAUSE + * packets. * are not dropped due FIFO full status. * are not dropped due + * DMAC0 or STEERING0 filtering. Internal: "This pseudo code represents + * the RX STAT0 through STAT8 accounting: <pre> If (errored) incr + * RX_STAT8 else if (ctrl packet, i.e. Pause/PFC) incr RX_STAT2,3 else + * if (fifo full drop) incr RX_STAT6,7 else if (DMAC0/VLAN0 filter + * drop) incr RX_STAT4,5 if not a filter+decision else incr + * RX_STAT0,1 end </pre>" + */ +union cgxx_cmrx_rx_stat0 { + u64 u; + struct cgxx_cmrx_rx_stat0_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_stat0_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_STAT0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_STAT0(u64 a) +{ + return 0x70 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_stat1 + * + * CGX Receive Status Register 1 These registers provide a count of + * octets of received packets. + */ +union cgxx_cmrx_rx_stat1 { + u64 u; + struct cgxx_cmrx_rx_stat1_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_stat1_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_STAT1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_STAT1(u64 a) +{ + return 0x78 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_stat2 + * + * CGX Receive Status Register 2 These registers provide a count of + * received packets that meet the following conditions: * are not + * recognized as ERROR packets(any OPCODE). * are recognized as PAUSE + * packets. Pause packets can be optionally dropped or forwarded based + * on + * CGX()_SMU()_RX_FRM_CTL[CTL_DRP]/CGX()_GMP_GMI_RX()_FRM_CTL[CTL_DRP]. + * This count increments regardless of whether the packet is dropped. + */ +union cgxx_cmrx_rx_stat2 { + u64 u; + struct cgxx_cmrx_rx_stat2_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_stat2_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_STAT2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_STAT2(u64 a) +{ + return 0x80 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_stat3 + * + * CGX Receive Status Register 3 These registers provide a count of + * octets of received PAUSE and control packets. + */ +union cgxx_cmrx_rx_stat3 { + u64 u; + struct cgxx_cmrx_rx_stat3_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_stat3_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_STAT3(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_STAT3(u64 a) +{ + return 0x88 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_stat4 + * + * CGX Receive Status Register 4 These registers provide a count of + * received packets that meet the following conditions: * are not + * recognized as ERROR packets(any OPCODE). * are not recognized as PAUSE + * packets. * are not dropped due FIFO full status. * are dropped due + * DMAC0 or STEERING0 filtering. 16B packets or smaller (20B in case of + * FCS strip) as the result of truncation or other means are not dropped + * by CGX (unless filter and decision is also asserted) and will never + * appear in this count. Should the MAC signal to the CMR that the packet + * be filtered upon decision before the end of packet, then STAT4 and + * STAT5 will not be updated. + */ +union cgxx_cmrx_rx_stat4 { + u64 u; + struct cgxx_cmrx_rx_stat4_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_stat4_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_STAT4(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_STAT4(u64 a) +{ + return 0x90 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_stat5 + * + * CGX Receive Status Register 5 These registers provide a count of + * octets of filtered DMAC0 or VLAN STEERING0 packets. + */ +union cgxx_cmrx_rx_stat5 { + u64 u; + struct cgxx_cmrx_rx_stat5_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_stat5_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_STAT5(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_STAT5(u64 a) +{ + return 0x98 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_stat6 + * + * CGX Receive Status Register 6 These registers provide a count of + * received packets that meet the following conditions: * are not + * recognized as ERROR packets(any OPCODE). * are not recognized as PAUSE + * packets. * are dropped due FIFO full status. They do not count any + * packet that is truncated at the point of overflow and sent on to the + * NIX. The truncated packet will be marked with error and increment + * STAT8. These registers count all entire packets dropped by the FIFO + * for a given LMAC. + */ +union cgxx_cmrx_rx_stat6 { + u64 u; + struct cgxx_cmrx_rx_stat6_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_stat6_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_STAT6(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_STAT6(u64 a) +{ + return 0xa0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_stat7 + * + * CGX Receive Status Register 7 These registers provide a count of + * octets of received packets that were dropped due to a full receive + * FIFO. + */ +union cgxx_cmrx_rx_stat7 { + u64 u; + struct cgxx_cmrx_rx_stat7_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_stat7_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_STAT7(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_STAT7(u64 a) +{ + return 0xa8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_stat8 + * + * CGX Receive Status Register 8 These registers provide a count of + * received packets that meet the following conditions: * are recognized + * as ERROR packets(any OPCODE). + */ +union cgxx_cmrx_rx_stat8 { + u64 u; + struct cgxx_cmrx_rx_stat8_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_stat8_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_STAT8(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_STAT8(u64 a) +{ + return 0xb0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_rx_stat_pri#_xoff + * + * CGX CMR RX XON to XOFF transition Registers + */ +union cgxx_cmrx_rx_stat_prix_xoff { + u64 u; + struct cgxx_cmrx_rx_stat_prix_xoff_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_rx_stat_prix_xoff_s cn; */ +}; + +static inline u64 CGXX_CMRX_RX_STAT_PRIX_XOFF(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_RX_STAT_PRIX_XOFF(u64 a, u64 b) +{ + return 0x7c0 + 0x40000 * a + 8 * b; +} + +/** + * Register (RSL) cgx#_cmr#_scratch# + * + * CGX CMR Scratch Registers + */ +union cgxx_cmrx_scratchx { + u64 u; + struct cgxx_cmrx_scratchx_s { + u64 scratch : 64; + } s; + /* struct cgxx_cmrx_scratchx_s cn; */ +}; + +static inline u64 CGXX_CMRX_SCRATCHX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_SCRATCHX(u64 a, u64 b) +{ + return 0x1050 + 0x40000 * a + 8 * b; +} + +/** + * Register (RSL) cgx#_cmr#_sw_int + * + * CGX CMR Interrupt Register + */ +union cgxx_cmrx_sw_int { + u64 u; + struct cgxx_cmrx_sw_int_s { + u64 sw_set : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_cmrx_sw_int_s cn; */ +}; + +static inline u64 CGXX_CMRX_SW_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_SW_INT(u64 a) +{ + return 0x180 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_sw_int_ena_w1c + * + * CGX CMR Interrupt Enable Clear Register This register clears interrupt + * enable bits. + */ +union cgxx_cmrx_sw_int_ena_w1c { + u64 u; + struct cgxx_cmrx_sw_int_ena_w1c_s { + u64 sw_set : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_cmrx_sw_int_ena_w1c_s cn; */ +}; + +static inline u64 CGXX_CMRX_SW_INT_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_SW_INT_ENA_W1C(u64 a) +{ + return 0x190 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_sw_int_ena_w1s + * + * CGX CMR Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union cgxx_cmrx_sw_int_ena_w1s { + u64 u; + struct cgxx_cmrx_sw_int_ena_w1s_s { + u64 sw_set : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_cmrx_sw_int_ena_w1s_s cn; */ +}; + +static inline u64 CGXX_CMRX_SW_INT_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_SW_INT_ENA_W1S(u64 a) +{ + return 0x198 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_sw_int_w1s + * + * CGX CMR Interrupt Set Register This register sets interrupt bits. + */ +union cgxx_cmrx_sw_int_w1s { + u64 u; + struct cgxx_cmrx_sw_int_w1s_s { + u64 sw_set : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_cmrx_sw_int_w1s_s cn; */ +}; + +static inline u64 CGXX_CMRX_SW_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_SW_INT_W1S(u64 a) +{ + return 0x188 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_channel + * + * CGX CMR Transmit-Channels Registers + */ +union cgxx_cmrx_tx_channel { + u64 u; + struct cgxx_cmrx_tx_channel_s { + u64 msk : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_cmrx_tx_channel_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_CHANNEL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_CHANNEL(u64 a) +{ + return 0x600 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_fifo_len + * + * CGX CMR Transmit Fifo Length Registers + */ +union cgxx_cmrx_tx_fifo_len { + u64 u; + struct cgxx_cmrx_tx_fifo_len_s { + u64 fifo_len : 14; + u64 lmac_idle : 1; + u64 fifo_e_len : 14; + u64 lmac_e_idle : 1; + u64 reserved_30_63 : 34; + } s; + /* struct cgxx_cmrx_tx_fifo_len_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_FIFO_LEN(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_FIFO_LEN(u64 a) +{ + return 0x618 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_hg2_status + * + * CGX CMR Transmit HiGig2 Status Registers + */ +union cgxx_cmrx_tx_hg2_status { + u64 u; + struct cgxx_cmrx_tx_hg2_status_s { + u64 lgtim2go : 16; + u64 xof : 16; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_cmrx_tx_hg2_status_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_HG2_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_HG2_STATUS(u64 a) +{ + return 0x610 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_merge_stat0 + * + * CGX TX Preemption Status Register 0 + */ +union cgxx_cmrx_tx_merge_stat0 { + u64 u; + struct cgxx_cmrx_tx_merge_stat0_s { + u64 ff_cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_merge_stat0_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_MERGE_STAT0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_MERGE_STAT0(u64 a) +{ + return 0x160 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_ovr_bp + * + * CGX CMR Transmit-Channels Backpressure Override Registers + */ +union cgxx_cmrx_tx_ovr_bp { + u64 u; + struct cgxx_cmrx_tx_ovr_bp_s { + u64 tx_chan_bp : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_cmrx_tx_ovr_bp_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_OVR_BP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_OVR_BP(u64 a) +{ + return 0x620 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat0 + * + * CGX CMR Transmit Statistics Registers 0 + */ +union cgxx_cmrx_tx_stat0 { + u64 u; + struct cgxx_cmrx_tx_stat0_s { + u64 xscol : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat0_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT0(u64 a) +{ + return 0x700 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat1 + * + * CGX CMR Transmit Statistics Registers 1 + */ +union cgxx_cmrx_tx_stat1 { + u64 u; + struct cgxx_cmrx_tx_stat1_s { + u64 xsdef : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat1_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT1(u64 a) +{ + return 0x708 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat10 + * + * CGX CMR Transmit Statistics Registers 10 + */ +union cgxx_cmrx_tx_stat10 { + u64 u; + struct cgxx_cmrx_tx_stat10_s { + u64 hist4 : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat10_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT10(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT10(u64 a) +{ + return 0x750 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat11 + * + * CGX CMR Transmit Statistics Registers 11 + */ +union cgxx_cmrx_tx_stat11 { + u64 u; + struct cgxx_cmrx_tx_stat11_s { + u64 hist5 : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat11_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT11(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT11(u64 a) +{ + return 0x758 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat12 + * + * CGX CMR Transmit Statistics Registers 12 + */ +union cgxx_cmrx_tx_stat12 { + u64 u; + struct cgxx_cmrx_tx_stat12_s { + u64 hist6 : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat12_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT12(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT12(u64 a) +{ + return 0x760 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat13 + * + * CGX CMR Transmit Statistics Registers 13 + */ +union cgxx_cmrx_tx_stat13 { + u64 u; + struct cgxx_cmrx_tx_stat13_s { + u64 hist7 : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat13_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT13(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT13(u64 a) +{ + return 0x768 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat14 + * + * CGX CMR Transmit Statistics Registers 14 + */ +union cgxx_cmrx_tx_stat14 { + u64 u; + struct cgxx_cmrx_tx_stat14_s { + u64 bcst : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat14_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT14(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT14(u64 a) +{ + return 0x770 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat15 + * + * CGX CMR Transmit Statistics Registers 15 + */ +union cgxx_cmrx_tx_stat15 { + u64 u; + struct cgxx_cmrx_tx_stat15_s { + u64 mcst : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat15_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT15(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT15(u64 a) +{ + return 0x778 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat16 + * + * CGX CMR Transmit Statistics Registers 16 + */ +union cgxx_cmrx_tx_stat16 { + u64 u; + struct cgxx_cmrx_tx_stat16_s { + u64 undflw : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat16_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT16(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT16(u64 a) +{ + return 0x780 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat17 + * + * CGX CMR Transmit Statistics Registers 17 + */ +union cgxx_cmrx_tx_stat17 { + u64 u; + struct cgxx_cmrx_tx_stat17_s { + u64 ctl : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat17_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT17(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT17(u64 a) +{ + return 0x788 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat2 + * + * CGX CMR Transmit Statistics Registers 2 + */ +union cgxx_cmrx_tx_stat2 { + u64 u; + struct cgxx_cmrx_tx_stat2_s { + u64 mcol : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat2_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT2(u64 a) +{ + return 0x710 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat3 + * + * CGX CMR Transmit Statistics Registers 3 + */ +union cgxx_cmrx_tx_stat3 { + u64 u; + struct cgxx_cmrx_tx_stat3_s { + u64 scol : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat3_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT3(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT3(u64 a) +{ + return 0x718 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat4 + * + * CGX CMR Transmit Statistics Registers 4 + */ +union cgxx_cmrx_tx_stat4 { + u64 u; + struct cgxx_cmrx_tx_stat4_s { + u64 octs : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat4_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT4(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT4(u64 a) +{ + return 0x720 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat5 + * + * CGX CMR Transmit Statistics Registers 5 + */ +union cgxx_cmrx_tx_stat5 { + u64 u; + struct cgxx_cmrx_tx_stat5_s { + u64 pkts : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat5_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT5(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT5(u64 a) +{ + return 0x728 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat6 + * + * CGX CMR Transmit Statistics Registers 6 + */ +union cgxx_cmrx_tx_stat6 { + u64 u; + struct cgxx_cmrx_tx_stat6_s { + u64 hist0 : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat6_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT6(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT6(u64 a) +{ + return 0x730 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat7 + * + * CGX CMR Transmit Statistics Registers 7 + */ +union cgxx_cmrx_tx_stat7 { + u64 u; + struct cgxx_cmrx_tx_stat7_s { + u64 hist1 : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat7_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT7(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT7(u64 a) +{ + return 0x738 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat8 + * + * CGX CMR Transmit Statistics Registers 8 + */ +union cgxx_cmrx_tx_stat8 { + u64 u; + struct cgxx_cmrx_tx_stat8_s { + u64 hist2 : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat8_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT8(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT8(u64 a) +{ + return 0x740 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat9 + * + * CGX CMR Transmit Statistics Registers 9 + */ +union cgxx_cmrx_tx_stat9 { + u64 u; + struct cgxx_cmrx_tx_stat9_s { + u64 hist3 : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat9_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT9(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT9(u64 a) +{ + return 0x748 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_cmr#_tx_stat_pri#_xoff + * + * CGX CMR TX XON to XOFF transition Registers + */ +union cgxx_cmrx_tx_stat_prix_xoff { + u64 u; + struct cgxx_cmrx_tx_stat_prix_xoff_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmrx_tx_stat_prix_xoff_s cn; */ +}; + +static inline u64 CGXX_CMRX_TX_STAT_PRIX_XOFF(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMRX_TX_STAT_PRIX_XOFF(u64 a, u64 b) +{ + return 0x800 + 0x40000 * a + 8 * b; +} + +/** + * Register (RSL) cgx#_cmr_bad + * + * CGX CMR Bad Registers + */ +union cgxx_cmr_bad { + u64 u; + struct cgxx_cmr_bad_s { + u64 rxb_nxl : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_cmr_bad_s cn; */ +}; + +static inline u64 CGXX_CMR_BAD(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_BAD(void) +{ + return 0x1020; +} + +/** + * Register (RSL) cgx#_cmr_chan_msk_and + * + * CGX CMR Backpressure Channel Mask AND Registers + */ +union cgxx_cmr_chan_msk_and { + u64 u; + struct cgxx_cmr_chan_msk_and_s { + u64 msk_and : 64; + } s; + /* struct cgxx_cmr_chan_msk_and_s cn; */ +}; + +static inline u64 CGXX_CMR_CHAN_MSK_AND(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_CHAN_MSK_AND(void) +{ + return 0x110; +} + +/** + * Register (RSL) cgx#_cmr_chan_msk_or + * + * CGX Backpressure Channel Mask OR Registers + */ +union cgxx_cmr_chan_msk_or { + u64 u; + struct cgxx_cmr_chan_msk_or_s { + u64 msk_or : 64; + } s; + /* struct cgxx_cmr_chan_msk_or_s cn; */ +}; + +static inline u64 CGXX_CMR_CHAN_MSK_OR(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_CHAN_MSK_OR(void) +{ + return 0x118; +} + +/** + * Register (RSL) cgx#_cmr_eco + * + * INTERNAL: CGX ECO Registers + */ +union cgxx_cmr_eco { + u64 u; + struct cgxx_cmr_eco_s { + u64 eco_rw : 32; + u64 eco_ro : 32; + } s; + /* struct cgxx_cmr_eco_s cn; */ +}; + +static inline u64 CGXX_CMR_ECO(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_ECO(void) +{ + return 0x1028; +} + +/** + * Register (RSL) cgx#_cmr_global_config + * + * CGX CMR Global Configuration Register These registers configure the + * global CMR, PCS, and MAC. + */ +union cgxx_cmr_global_config { + u64 u; + struct cgxx_cmr_global_config_s { + u64 pmux_sds_sel : 1; + u64 cgx_clk_enable : 1; + u64 cmr_x2p_reset : 3; + u64 interleave_mode : 1; + u64 fcs_strip : 1; + u64 ncsi_lmac_id : 2; + u64 cmr_ncsi_drop : 1; + u64 cmr_ncsi_reset : 1; + u64 cmr_ncsi_tag_cnt : 13; + u64 cmr_clken_ovrd : 1; + u64 reserved_25_63 : 39; + } s; + /* struct cgxx_cmr_global_config_s cn; */ +}; + +static inline u64 CGXX_CMR_GLOBAL_CONFIG(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_GLOBAL_CONFIG(void) +{ + return 8; +} + +/** + * Register (RSL) cgx#_cmr_mem_int + * + * CGX CMR Memory Interrupt Register + */ +union cgxx_cmr_mem_int { + u64 u; + struct cgxx_cmr_mem_int_s { + u64 gmp_in_overfl : 1; + u64 smu_in_overfl : 1; + u64 reserved_2_63 : 62; + } s; + /* struct cgxx_cmr_mem_int_s cn; */ +}; + +static inline u64 CGXX_CMR_MEM_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_MEM_INT(void) +{ + return 0x10; +} + +/** + * Register (RSL) cgx#_cmr_mem_int_ena_w1c + * + * CGX CMR Memory Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union cgxx_cmr_mem_int_ena_w1c { + u64 u; + struct cgxx_cmr_mem_int_ena_w1c_s { + u64 gmp_in_overfl : 1; + u64 smu_in_overfl : 1; + u64 reserved_2_63 : 62; + } s; + /* struct cgxx_cmr_mem_int_ena_w1c_s cn; */ +}; + +static inline u64 CGXX_CMR_MEM_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_MEM_INT_ENA_W1C(void) +{ + return 0x20; +} + +/** + * Register (RSL) cgx#_cmr_mem_int_ena_w1s + * + * CGX CMR Memory Interrupt Enable Set Register This register sets + * interrupt enable bits. + */ +union cgxx_cmr_mem_int_ena_w1s { + u64 u; + struct cgxx_cmr_mem_int_ena_w1s_s { + u64 gmp_in_overfl : 1; + u64 smu_in_overfl : 1; + u64 reserved_2_63 : 62; + } s; + /* struct cgxx_cmr_mem_int_ena_w1s_s cn; */ +}; + +static inline u64 CGXX_CMR_MEM_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_MEM_INT_ENA_W1S(void) +{ + return 0x28; +} + +/** + * Register (RSL) cgx#_cmr_mem_int_w1s + * + * CGX CMR Memory Interrupt Set Register This register sets interrupt + * bits. + */ +union cgxx_cmr_mem_int_w1s { + u64 u; + struct cgxx_cmr_mem_int_w1s_s { + u64 gmp_in_overfl : 1; + u64 smu_in_overfl : 1; + u64 reserved_2_63 : 62; + } s; + /* struct cgxx_cmr_mem_int_w1s_s cn; */ +}; + +static inline u64 CGXX_CMR_MEM_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_MEM_INT_W1S(void) +{ + return 0x18; +} + +/** + * Register (RSL) cgx#_cmr_nic_nxc_adr + * + * CGX CMR NIC NXC Exception Registers + */ +union cgxx_cmr_nic_nxc_adr { + u64 u; + struct cgxx_cmr_nic_nxc_adr_s { + u64 channel : 12; + u64 lmac_id : 4; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_cmr_nic_nxc_adr_s cn; */ +}; + +static inline u64 CGXX_CMR_NIC_NXC_ADR(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_NIC_NXC_ADR(void) +{ + return 0x1030; +} + +/** + * Register (RSL) cgx#_cmr_nix0_nxc_adr + * + * CGX CMR NIX0 NXC Exception Registers + */ +union cgxx_cmr_nix0_nxc_adr { + u64 u; + struct cgxx_cmr_nix0_nxc_adr_s { + u64 channel : 12; + u64 lmac_id : 4; + u64 channel_e : 12; + u64 lmac_e_id : 4; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_cmr_nix0_nxc_adr_s cn; */ +}; + +static inline u64 CGXX_CMR_NIX0_NXC_ADR(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_NIX0_NXC_ADR(void) +{ + return 0x1038; +} + +/** + * Register (RSL) cgx#_cmr_nix1_nxc_adr + * + * CGX CMR NIX1 NXC Exception Registers + */ +union cgxx_cmr_nix1_nxc_adr { + u64 u; + struct cgxx_cmr_nix1_nxc_adr_s { + u64 channel : 12; + u64 lmac_id : 4; + u64 channel_e : 12; + u64 lmac_e_id : 4; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_cmr_nix1_nxc_adr_s cn; */ +}; + +static inline u64 CGXX_CMR_NIX1_NXC_ADR(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_NIX1_NXC_ADR(void) +{ + return 0x1040; +} + +/** + * Register (RSL) cgx#_cmr_p2x#_count + * + * CGX P2X Activity Register + */ +union cgxx_cmr_p2xx_count { + u64 u; + struct cgxx_cmr_p2xx_count_s { + u64 p2x_cnt : 64; + } s; + /* struct cgxx_cmr_p2xx_count_s cn; */ +}; + +static inline u64 CGXX_CMR_P2XX_COUNT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_P2XX_COUNT(u64 a) +{ + return 0x168 + 0x1000 * a; +} + +/** + * Register (RSL) cgx#_cmr_rx_dmac#_cam0 + * + * CGX CMR Receive CAM Registers These registers provide access to the 32 + * DMAC CAM0 entries in CGX, for use by X2P/NIX bound traffic. + */ +union cgxx_cmr_rx_dmacx_cam0 { + u64 u; + struct cgxx_cmr_rx_dmacx_cam0_s { + u64 adr : 48; + u64 en : 1; + u64 id : 2; + u64 reserved_51_63 : 13; + } s; + /* struct cgxx_cmr_rx_dmacx_cam0_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_DMACX_CAM0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_DMACX_CAM0(u64 a) +{ + return 0x200 + 8 * a; +} + +/** + * Register (RSL) cgx#_cmr_rx_dmac#_cam1 + * + * CGX CMR Receive CAM Registers These registers provide access to the 32 + * DMAC CAM entries in CGX for use by NCSI bound traffic. See + * CGX()_CMR_GLOBAL_CONFIG[NCSI_LMAC_ID] and CGX()_CMR_RX_STEERING1() + * registers. + */ +union cgxx_cmr_rx_dmacx_cam1 { + u64 u; + struct cgxx_cmr_rx_dmacx_cam1_s { + u64 adr : 48; + u64 en : 1; + u64 id : 2; + u64 reserved_51_63 : 13; + } s; + /* struct cgxx_cmr_rx_dmacx_cam1_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_DMACX_CAM1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_DMACX_CAM1(u64 a) +{ + return 0x400 + 8 * a; +} + +/** + * Register (RSL) cgx#_cmr_rx_lmacs + * + * CGX CMR Receive Logical MACs Registers + */ +union cgxx_cmr_rx_lmacs { + u64 u; + struct cgxx_cmr_rx_lmacs_s { + u64 lmacs : 3; + u64 reserved_3_63 : 61; + } s; + /* struct cgxx_cmr_rx_lmacs_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_LMACS(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_LMACS(void) +{ + return 0x128; +} + +/** + * Register (RSL) cgx#_cmr_rx_ovr_bp + * + * CGX CMR Receive-Ports Backpressure Override Registers Per-LMAC + * backpressure override register. For SMU, CGX()_CMR_RX_OVR_BP[EN]<0> + * must be set to one and CGX()_CMR_RX_OVR_BP[BP]<0> must be cleared to + * zero (to forcibly disable hardware-automatic 802.3 PAUSE packet + * generation) with the HiGig2 Protocol when + * CGX()_SMU()_HG2_CONTROL[HG2TX_EN]=0. (The HiGig2 protocol is indicated + * by CGX()_SMU()_TX_CTL[HG_EN]=1 and CGX()_SMU()_RX_UDD_SKP[LEN]=16). + * Hardware can only auto-generate backpressure through HiGig2 messages + * (optionally, when CGX()_SMU()_HG2_CONTROL[HG2TX_EN]=1) with the HiGig2 + * protocol. + */ +union cgxx_cmr_rx_ovr_bp { + u64 u; + struct cgxx_cmr_rx_ovr_bp_s { + u64 ign_fifo_bp : 4; + u64 bp : 4; + u64 en : 4; + u64 reserved_12_63 : 52; + } s; + /* struct cgxx_cmr_rx_ovr_bp_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_OVR_BP(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_OVR_BP(void) +{ + return 0x130; +} + +/** + * Register (RSL) cgx#_cmr_rx_stat10 + * + * CGX Receive Status Register 10 These registers provide a count of + * octets of filtered DMAC1 or VLAN STEERING1 packets. + */ +union cgxx_cmr_rx_stat10 { + u64 u; + struct cgxx_cmr_rx_stat10_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmr_rx_stat10_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_STAT10(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_STAT10(void) +{ + return 0xc0; +} + +/** + * Register (RSL) cgx#_cmr_rx_stat11 + * + * CGX Receive Status Register 11 This registers provides a count of + * packets dropped at the NCSI interface. This includes drops due to + * CGX()_CMR_GLOBAL_CONFIG[CMR_NCSI_DROP] or NCSI FIFO full. The count of + * dropped NCSI packets is not accounted for in any other stats + * registers. + */ +union cgxx_cmr_rx_stat11 { + u64 u; + struct cgxx_cmr_rx_stat11_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmr_rx_stat11_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_STAT11(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_STAT11(void) +{ + return 0xc8; +} + +/** + * Register (RSL) cgx#_cmr_rx_stat12 + * + * CGX Receive Status Register 12 This register provide a count of octets + * of dropped at the NCSI interface. + */ +union cgxx_cmr_rx_stat12 { + u64 u; + struct cgxx_cmr_rx_stat12_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmr_rx_stat12_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_STAT12(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_STAT12(void) +{ + return 0xd0; +} + +/** + * Register (RSL) cgx#_cmr_rx_stat9 + * + * CGX Receive Status Register 9 These registers provide a count of all + * received packets that were dropped by the DMAC1 or VLAN STEERING1 + * filter. Packets that are dropped by the DMAC1 or VLAN STEERING1 + * filters are counted here regardless of whether they were ERR packets, + * but does not include those reported in CGX()_CMR()_RX_STAT6. 16B + * packets or smaller (20B in case of FCS strip) as the result of + * truncation or other means are not dropped by CGX (unless filter and + * decision is also asserted) and will never appear in this count. Should + * the MAC signal to the CMR that the packet be filtered upon decision + * before the end of packet, then STAT9 and STAT10 will not be updated. + */ +union cgxx_cmr_rx_stat9 { + u64 u; + struct cgxx_cmr_rx_stat9_s { + u64 cnt : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_cmr_rx_stat9_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_STAT9(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_STAT9(void) +{ + return 0xb8; +} + +/** + * Register (RSL) cgx#_cmr_rx_steering0# + * + * CGX CMR Receive Steering0 Registers These registers, along with + * CGX()_CMR_RX_STEERING_VETYPE0(), provide eight filters for identifying + * and steering receive traffic to X2P/NIX. Received packets are only + * passed to X2P/NIX when the DMAC0 filter result is ACCEPT and STEERING0 + * filter result is PASS. See also CGX()_CMR()_RX_DMAC_CTL0. Internal: + * "* ALGORITHM <pre> rx_steering(uint48 pkt_dmac, uint16 pkt_etype, + * uint16 pkt_vlan_id) { for (int i = 0; i < 8; i++) { steer = + * CGX()_CMR_RX_STEERING0(i); vetype = + * CGX()_CMR_RX_STEERING_VETYPE0(i); if (steer[MCST_EN] || + * steer[DMAC_EN] || vetype[VLAN_EN] || vetype[VLAN_TAG_EN]) { + * // Filter is enabled. if ( (!steer[MCST_EN] || + * is_mcst(pkt_dmac)) && (!steer[DMAC_EN] || pkt_dmac == + * steer[DMAC]) && (!vetype[VLAN_EN] || pkt_vlan_id == + * vetype[VLAN_ID]) && (!vetype[VLAN_TAG_EN] || pkt_etype == + * vetype[VLAN_ETYPE]) ) { // Filter match (all + * enabled matching criteria are met). return steer[PASS]; + * } } } return CGX()_CMR_RX_STEERING_DEFAULT0[PASS]; // No + * match } </pre>" + */ +union cgxx_cmr_rx_steering0x { + u64 u; + struct cgxx_cmr_rx_steering0x_s { + u64 dmac : 48; + u64 dmac_en : 1; + u64 mcst_en : 1; + u64 pass : 1; + u64 reserved_51_63 : 13; + } s; + /* struct cgxx_cmr_rx_steering0x_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_STEERING0X(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_STEERING0X(u64 a) +{ + return 0x300 + 8 * a; +} + +/** + * Register (RSL) cgx#_cmr_rx_steering1# + * + * CGX CMR Receive Steering1 Registers These registers, along with + * CGX()_CMR_RX_STEERING_VETYPE1(), provide eight filters for identifying + * and steering NCSI receive traffic. Received packets are only passed to + * NCSI when the DMAC1 filter result is ACCEPT and STEERING1 filter + * result is PASS. See also CGX()_CMR_RX_DMAC()_CAM1 and + * CGX()_CMR_RX_STEERING1(). For use with the LMAC associated with NCSI. + * See CGX()_CMR_GLOBAL_CONFIG[NCSI_LMAC_ID]. Internal: ALGORITHM: See + * CGX()_CMR_RX_STEERING0(). + */ +union cgxx_cmr_rx_steering1x { + u64 u; + struct cgxx_cmr_rx_steering1x_s { + u64 dmac : 48; + u64 dmac_en : 1; + u64 mcst_en : 1; + u64 pass : 1; + u64 reserved_51_63 : 13; + } s; + /* struct cgxx_cmr_rx_steering1x_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_STEERING1X(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_STEERING1X(u64 a) +{ + return 0x500 + 8 * a; +} + +/** + * Register (RSL) cgx#_cmr_rx_steering_default0 + * + * CGX CMR Receive Steering Default0 Destination Register For determining + * destination of traffic that does not meet matching algorithm described + * in registers CGX()_CMR_RX_STEERING0() and + * CGX()_CMR_RX_STEERING_VETYPE0(). All 16B packets or smaller (20B in + * case of FCS strip) as the result of truncation will steer to default + * destination + */ +union cgxx_cmr_rx_steering_default0 { + u64 u; + struct cgxx_cmr_rx_steering_default0_s { + u64 pass : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_cmr_rx_steering_default0_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_STEERING_DEFAULT0(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_STEERING_DEFAULT0(void) +{ + return 0x3f0; +} + +/** + * Register (RSL) cgx#_cmr_rx_steering_default1 + * + * CGX CMR Receive Steering Default1 Destination Register For use with + * the lmac_id associated with NCSI. See + * CGX()_CMR_GLOBAL_CONFIG[NCSI_LMAC_ID]. For determining destination of + * traffic that does not meet matching algorithm described in registers + * CGX()_CMR_RX_STEERING1() and CGX()_CMR_RX_STEERING_VETYPE1(). All 16B + * packets or smaller (20B in case of FCS strip) as the result of + * truncation will steer to default destination + */ +union cgxx_cmr_rx_steering_default1 { + u64 u; + struct cgxx_cmr_rx_steering_default1_s { + u64 pass : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_cmr_rx_steering_default1_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_STEERING_DEFAULT1(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_STEERING_DEFAULT1(void) +{ + return 0x5e0; +} + +/** + * Register (RSL) cgx#_cmr_rx_steering_vetype0# + * + * CGX CMR Receive VLAN Ethertype1 Register These registers, along with + * CGX()_CMR_RX_STEERING0(), provide eight filters for identifying and + * steering X2P/NIX receive traffic. + */ +union cgxx_cmr_rx_steering_vetype0x { + u64 u; + struct cgxx_cmr_rx_steering_vetype0x_s { + u64 vlan_etype : 16; + u64 vlan_tag_en : 1; + u64 vlan_id : 12; + u64 vlan_en : 1; + u64 reserved_30_63 : 34; + } s; + /* struct cgxx_cmr_rx_steering_vetype0x_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_STEERING_VETYPE0X(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_STEERING_VETYPE0X(u64 a) +{ + return 0x380 + 8 * a; +} + +/** + * Register (RSL) cgx#_cmr_rx_steering_vetype1# + * + * CGX CMR Receive VLAN Ethertype1 Register For use with the lmac_id + * associated with NCSI. See CGX()_CMR_GLOBAL_CONFIG[NCSI_LMAC_ID]. These + * registers, along with CGX()_CMR_RX_STEERING1(), provide eight filters + * for identifying and steering NCSI receive traffic. + */ +union cgxx_cmr_rx_steering_vetype1x { + u64 u; + struct cgxx_cmr_rx_steering_vetype1x_s { + u64 vlan_etype : 16; + u64 vlan_tag_en : 1; + u64 vlan_id : 12; + u64 vlan_en : 1; + u64 reserved_30_63 : 34; + } s; + /* struct cgxx_cmr_rx_steering_vetype1x_s cn; */ +}; + +static inline u64 CGXX_CMR_RX_STEERING_VETYPE1X(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_RX_STEERING_VETYPE1X(u64 a) +{ + return 0x580 + 8 * a; +} + +/** + * Register (RSL) cgx#_cmr_tx_lmacs + * + * CGX CMR Transmit Logical MACs Registers This register sets the number + * of LMACs allowed on the TX interface. The value is important for + * defining the partitioning of the transmit FIFO. + */ +union cgxx_cmr_tx_lmacs { + u64 u; + struct cgxx_cmr_tx_lmacs_s { + u64 lmacs : 3; + u64 reserved_3_63 : 61; + } s; + /* struct cgxx_cmr_tx_lmacs_s cn; */ +}; + +static inline u64 CGXX_CMR_TX_LMACS(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_TX_LMACS(void) +{ + return 0x1000; +} + +/** + * Register (RSL) cgx#_cmr_x2p#_count + * + * CGX X2P Activity Register + */ +union cgxx_cmr_x2px_count { + u64 u; + struct cgxx_cmr_x2px_count_s { + u64 x2p_cnt : 64; + } s; + /* struct cgxx_cmr_x2px_count_s cn; */ +}; + +static inline u64 CGXX_CMR_X2PX_COUNT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CMR_X2PX_COUNT(u64 a) +{ + return 0x170 + 0x1000 * a; +} + +/** + * Register (RSL) cgx#_const + * + * CGX CONST Registers This register contains constants for software + * discovery. + */ +union cgxx_const { + u64 u; + struct cgxx_const_s { + u64 tx_fifosz : 24; + u64 lmacs : 8; + u64 rx_fifosz : 24; + u64 reserved_56_63 : 8; + } s; + /* struct cgxx_const_s cn; */ +}; + +static inline u64 CGXX_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CONST(void) +{ + return 0x2000; +} + +/** + * Register (RSL) cgx#_const1 + * + * CGX CONST1 Registers This register contains constants for software + * discovery. + */ +union cgxx_const1 { + u64 u; + struct cgxx_const1_s { + u64 types : 11; + u64 res_types : 21; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_const1_s cn; */ +}; + +static inline u64 CGXX_CONST1(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_CONST1(void) +{ + return 0x2008; +} + +/** + * Register (RSL) cgx#_gmp_gmi#_rx_wol_ctrl0 + * + * CGX GMP GMI RX Wake-on-LAN Control 0 Registers + */ +union cgxx_gmp_gmix_rx_wol_ctrl0 { + u64 u; + struct cgxx_gmp_gmix_rx_wol_ctrl0_s { + u64 dmac : 48; + u64 pswd_len : 4; + u64 reserved_52_63 : 12; + } s; + /* struct cgxx_gmp_gmix_rx_wol_ctrl0_s cn; */ +}; + +static inline u64 CGXX_GMP_GMIX_RX_WOL_CTRL0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMIX_RX_WOL_CTRL0(u64 a) +{ + return 0x38a00 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi#_rx_wol_ctrl1 + * + * CGX GMP GMI RX Wake-on-LAN Control 1 Registers + */ +union cgxx_gmp_gmix_rx_wol_ctrl1 { + u64 u; + struct cgxx_gmp_gmix_rx_wol_ctrl1_s { + u64 pswd : 64; + } s; + /* struct cgxx_gmp_gmix_rx_wol_ctrl1_s cn; */ +}; + +static inline u64 CGXX_GMP_GMIX_RX_WOL_CTRL1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMIX_RX_WOL_CTRL1(u64 a) +{ + return 0x38a08 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi#_tx_eee + * + * INTERNAL: CGX GMP GMI TX EEE Configure Registers Reserved. Internal: + * These registers control when GMP GMI TX requests to enter or exist + * LPI. Those registers take effect only when EEE is supported and + * enabled for a given LMAC. + */ +union cgxx_gmp_gmix_tx_eee { + u64 u; + struct cgxx_gmp_gmix_tx_eee_s { + u64 idle_thresh : 28; + u64 reserved_28 : 1; + u64 force_lpi : 1; + u64 wakeup : 1; + u64 auto_lpi : 1; + u64 idle_cnt : 28; + u64 tx_lpi : 1; + u64 tx_lpi_wait : 1; + u64 sync_status_lpi_enable : 1; + u64 reserved_63 : 1; + } s; + /* struct cgxx_gmp_gmix_tx_eee_s cn; */ +}; + +static inline u64 CGXX_GMP_GMIX_TX_EEE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMIX_TX_EEE(u64 a) +{ + return 0x38800 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi#_tx_eee_cfg1 + * + * INTERNAL: CGX GMP GMI TX EEE Configure More Configuration Registers + * Reserved. Internal: Controls the GMP exiting of LPI and starting to + * send data. + */ +union cgxx_gmp_gmix_tx_eee_cfg1 { + u64 u; + struct cgxx_gmp_gmix_tx_eee_cfg1_s { + u64 wake2data_time : 24; + u64 reserved_24_35 : 12; + u64 tx_eee_enable : 1; + u64 reserved_37_39 : 3; + u64 sync2lpi_time : 21; + u64 reserved_61_63 : 3; + } s; + struct cgxx_gmp_gmix_tx_eee_cfg1_cn { + u64 wake2data_time : 24; + u64 reserved_24_31 : 8; + u64 reserved_32_35 : 4; + u64 tx_eee_enable : 1; + u64 reserved_37_39 : 3; + u64 sync2lpi_time : 21; + u64 reserved_61_63 : 3; + } cn; +}; + +static inline u64 CGXX_GMP_GMIX_TX_EEE_CFG1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMIX_TX_EEE_CFG1(u64 a) +{ + return 0x38808 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi#_wol_int + * + * CGX GMP GMI RX WOL Interrupt Registers These registers allow WOL + * interrupts to be sent to the control processor. + */ +union cgxx_gmp_gmix_wol_int { + u64 u; + struct cgxx_gmp_gmix_wol_int_s { + u64 wol_rcvd : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_gmp_gmix_wol_int_s cn; */ +}; + +static inline u64 CGXX_GMP_GMIX_WOL_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMIX_WOL_INT(u64 a) +{ + return 0x38a80 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi#_wol_int_ena_w1c + * + * CGX GMP GMI RX WOL Interrupt Enable Clear Registers This register + * clears interrupt enable bits. + */ +union cgxx_gmp_gmix_wol_int_ena_w1c { + u64 u; + struct cgxx_gmp_gmix_wol_int_ena_w1c_s { + u64 wol_rcvd : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_gmp_gmix_wol_int_ena_w1c_s cn; */ +}; + +static inline u64 CGXX_GMP_GMIX_WOL_INT_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMIX_WOL_INT_ENA_W1C(u64 a) +{ + return 0x38a90 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi#_wol_int_ena_w1s + * + * CGX GMP GMI RX WOL Interrupt Enable Set Registers This register sets + * interrupt enable bits. + */ +union cgxx_gmp_gmix_wol_int_ena_w1s { + u64 u; + struct cgxx_gmp_gmix_wol_int_ena_w1s_s { + u64 wol_rcvd : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_gmp_gmix_wol_int_ena_w1s_s cn; */ +}; + +static inline u64 CGXX_GMP_GMIX_WOL_INT_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMIX_WOL_INT_ENA_W1S(u64 a) +{ + return 0x38a98 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi#_wol_int_w1s + * + * CGX GMP GMI RX WOL Interrupt Set Registers This register sets + * interrupt bits. + */ +union cgxx_gmp_gmix_wol_int_w1s { + u64 u; + struct cgxx_gmp_gmix_wol_int_w1s_s { + u64 wol_rcvd : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_gmp_gmix_wol_int_w1s_s cn; */ +}; + +static inline u64 CGXX_GMP_GMIX_WOL_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMIX_WOL_INT_W1S(u64 a) +{ + return 0x38a88 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_prt#_cfg + * + * CGX GMP GMI LMAC Configuration Registers This register controls the + * configuration of the LMAC. + */ +union cgxx_gmp_gmi_prtx_cfg { + u64 u; + struct cgxx_gmp_gmi_prtx_cfg_s { + u64 reserved_0 : 1; + u64 speed : 1; + u64 duplex : 1; + u64 slottime : 1; + u64 reserved_4_7 : 4; + u64 speed_msb : 1; + u64 reserved_9_11 : 3; + u64 rx_idle : 1; + u64 tx_idle : 1; + u64 reserved_14_63 : 50; + } s; + /* struct cgxx_gmp_gmi_prtx_cfg_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_PRTX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_PRTX_CFG(u64 a) +{ + return 0x38020 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_rx#_decision + * + * CGX GMP Packet-Decision Registers This register specifies the byte + * count used to determine when to accept or to filter a packet. As each + * byte in a packet is received by GMI, the L2 byte count is compared + * against [CNT]. In normal operation, the L2 header begins after the + * PREAMBLE + SFD (CGX()_GMP_GMI_RX()_FRM_CTL[PRE_CHK] = 1) and any + * optional UDD skip data (CGX()_GMP_GMI_RX()_UDD_SKP[LEN]). Internal: + * Notes: As each byte in a packet is received by GMI, the L2 byte count + * is compared against the [CNT]. The L2 byte count is the number of + * bytes from the beginning of the L2 header (DMAC). In normal + * operation, the L2 header begins after the PREAMBLE+SFD + * (CGX()_GMP_GMI_RX()_FRM_CTL[PRE_CHK]=1) and any optional UDD skip data + * (CGX()_GMP_GMI_RX()_UDD_SKP[LEN]). When + * CGX()_GMP_GMI_RX()_FRM_CTL[PRE_CHK] is clear, PREAMBLE+SFD are + * prepended to the packet and would require UDD skip length to account + * for them. Full Duplex: _ L2 Size < [CNT] - Accept packet. No + * filtering is applied. _ L2 Size >= [CNT] - Apply filter. Accept + * packet based on PAUSE packet filter. Half Duplex: _ L2 Size < + * [CNT] - Drop packet. Packet is unconditionally dropped. _ L2 Size + * >= [CNT] - Accept packet. where L2_size = MAX(0, total_packet_size - + * CGX()_GMP_GMI_RX()_UDD_SKP[LEN] - + * ((CGX()_GMP_GMI_RX()_FRM_CTL[PRE_CHK]==1)*8)). + */ +union cgxx_gmp_gmi_rxx_decision { + u64 u; + struct cgxx_gmp_gmi_rxx_decision_s { + u64 cnt : 5; + u64 reserved_5_63 : 59; + } s; + /* struct cgxx_gmp_gmi_rxx_decision_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_RXX_DECISION(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_RXX_DECISION(u64 a) +{ + return 0x38040 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_rx#_frm_chk + * + * CGX GMP Frame Check Registers + */ +union cgxx_gmp_gmi_rxx_frm_chk { + u64 u; + struct cgxx_gmp_gmi_rxx_frm_chk_s { + u64 minerr : 1; + u64 carext : 1; + u64 reserved_2 : 1; + u64 jabber : 1; + u64 fcserr : 1; + u64 reserved_5_6 : 2; + u64 rcverr : 1; + u64 skperr : 1; + u64 reserved_9_63 : 55; + } s; + /* struct cgxx_gmp_gmi_rxx_frm_chk_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_RXX_FRM_CHK(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_RXX_FRM_CHK(u64 a) +{ + return 0x38030 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_rx#_frm_ctl + * + * CGX GMP Frame Control Registers This register controls the handling of + * the frames. The [CTL_BCK] and [CTL_DRP] bits control how the hardware + * handles incoming PAUSE packets. The most common modes of operation: _ + * [CTL_BCK] = 1, [CTL_DRP] = 1: hardware handles everything. _ [CTL_BCK] + * = 0, [CTL_DRP] = 0: software sees all PAUSE frames. _ [CTL_BCK] = 0, + * [CTL_DRP] = 1: all PAUSE frames are completely ignored. These control + * bits should be set to [CTL_BCK] = 0, [CTL_DRP] = 0 in half-duplex + * mode. Since PAUSE packets only apply to full duplex operation, any + * PAUSE packet would constitute an exception which should be handled by + * the processing cores. PAUSE packets should not be forwarded. + * Internal: Notes: [PRE_STRP]: When [PRE_CHK] is set (indicating that + * the PREAMBLE will be sent), [PRE_STRP] determines if the PREAMBLE+SFD + * bytes are thrown away or sent to the Octane core as part of the + * packet. In either mode, the PREAMBLE+SFD bytes are not counted toward + * the packet size when checking against the MIN and MAX bounds. + * Furthermore, the bytes are skipped when locating the start of the L2 + * header for DMAC and Control frame recognition. + */ +union cgxx_gmp_gmi_rxx_frm_ctl { + u64 u; + struct cgxx_gmp_gmi_rxx_frm_ctl_s { + u64 pre_chk : 1; + u64 pre_strp : 1; + u64 ctl_drp : 1; + u64 ctl_bck : 1; + u64 ctl_mcst : 1; + u64 ctl_smac : 1; + u64 pre_free : 1; + u64 reserved_7_8 : 2; + u64 pre_align : 1; + u64 null_dis : 1; + u64 reserved_11 : 1; + u64 ptp_mode : 1; + u64 rx_fc_type : 1; + u64 reserved_14_63 : 50; + } s; + struct cgxx_gmp_gmi_rxx_frm_ctl_cn { + u64 pre_chk : 1; + u64 pre_strp : 1; + u64 ctl_drp : 1; + u64 ctl_bck : 1; + u64 ctl_mcst : 1; + u64 ctl_smac : 1; + u64 pre_free : 1; + u64 reserved_7 : 1; + u64 reserved_8 : 1; + u64 pre_align : 1; + u64 null_dis : 1; + u64 reserved_11 : 1; + u64 ptp_mode : 1; + u64 rx_fc_type : 1; + u64 reserved_14_63 : 50; + } cn; +}; + +static inline u64 CGXX_GMP_GMI_RXX_FRM_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_RXX_FRM_CTL(u64 a) +{ + return 0x38028 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_rx#_ifg + * + * CGX GMI Minimum Interframe-Gap Cycles Registers This register + * specifies the minimum number of interframe-gap (IFG) cycles between + * packets. + */ +union cgxx_gmp_gmi_rxx_ifg { + u64 u; + struct cgxx_gmp_gmi_rxx_ifg_s { + u64 ifg : 4; + u64 reserved_4_63 : 60; + } s; + /* struct cgxx_gmp_gmi_rxx_ifg_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_RXX_IFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_RXX_IFG(u64 a) +{ + return 0x38058 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_rx#_int + * + * CGX GMP GMI RX Interrupt Registers These registers allow interrupts to + * be sent to the control processor. * Exception conditions <10:0> can + * also set the rcv/opcode in the received packet's work-queue entry. + * CGX()_GMP_GMI_RX()_FRM_CHK provides a bit mask for configuring which + * conditions set the error. In half duplex operation, the expectation is + * that collisions will appear as either MINERR or CAREXT errors. + * Internal: Notes: (1) exception conditions 10:0 can also set the + * rcv/opcode in the received packet's workQ entry. The + * CGX()_GMP_GMI_RX()_FRM_CHK register provides a bit mask for + * configuring which conditions set the error. (2) in half duplex + * operation, the expectation is that collisions will appear as either + * MINERR o r CAREXT errors. (3) JABBER An RX jabber error indicates + * that a packet was received which is longer than the maximum allowed + * packet as defined by the system. GMI will truncate the packet at the + * JABBER count. Failure to do so could lead to system instabilty. (4) + * NIBERR This error is illegal at 1000Mbs speeds + * (CGX()_GMP_GMI_PRT()_CFG[SPEED]==0) and will never assert. (5) MINERR + * total frame DA+SA+TL+DATA+PAD+FCS < 64 (6) ALNERR Indicates that the + * packet received was not an integer number of bytes. If FCS checking + * is enabled, ALNERR will only assert if the FCS is bad. If FCS + * checking is disabled, ALNERR will assert in all non-integer frame + * cases. (7) Collisions Collisions can only occur in half-duplex mode. + * A collision is assumed by the receiver when the slottime + * (CGX()_GMP_GMI_PRT()_CFG[SLOTTIME]) is not satisfied. In 10/100 mode, + * this will result in a frame < SLOTTIME. In 1000 mode, it could + * result either in frame < SLOTTIME or a carrier extend error with the + * SLOTTIME. These conditions are visible by... . transfer ended before + * slottime COLDET . carrier extend error CAREXT (A) LENERR + * Length errors occur when the received packet does not match the length + * field. LENERR is only checked for packets between 64 and 1500 bytes. + * For untagged frames, the length must exact match. For tagged frames + * the length or length+4 must match. (B) PCTERR checks that the frame + * begins with a valid PREAMBLE sequence. Does not check the number of + * PREAMBLE cycles. (C) OVRERR *DON'T PUT IN HRM* OVRERR is an + * architectural assertion check internal to GMI to make sure no + * assumption was violated. In a correctly operating system, this + * interrupt can never fire. GMI has an internal arbiter which selects + * which of four ports to buffer in the main RX FIFO. If we normally + * buffer eight bytes, then each port will typically push a tick every + * eight cycles if the packet interface is going as fast as possible. If + * there are four ports, they push every two cycles. So that's the + * assumption. That the inbound module will always be able to consume + * the tick before another is produced. If that doesn't happen that's + * when OVRERR will assert." + */ +union cgxx_gmp_gmi_rxx_int { + u64 u; + struct cgxx_gmp_gmi_rxx_int_s { + u64 minerr : 1; + u64 carext : 1; + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 ovrerr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 falerr : 1; + u64 coldet : 1; + u64 ifgerr : 1; + u64 reserved_12_63 : 52; + } s; + struct cgxx_gmp_gmi_rxx_int_cn { + u64 minerr : 1; + u64 carext : 1; + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 ovrerr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 falerr : 1; + u64 coldet : 1; + u64 ifgerr : 1; + u64 reserved_12_15 : 4; + u64 reserved_16_63 : 48; + } cn; +}; + +static inline u64 CGXX_GMP_GMI_RXX_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_RXX_INT(u64 a) +{ + return 0x38000 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_rx#_int_ena_w1c + * + * CGX GMP GMI RX Interrupt Enable Clear Registers This register clears + * interrupt enable bits. + */ +union cgxx_gmp_gmi_rxx_int_ena_w1c { + u64 u; + struct cgxx_gmp_gmi_rxx_int_ena_w1c_s { + u64 minerr : 1; + u64 carext : 1; + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 ovrerr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 falerr : 1; + u64 coldet : 1; + u64 ifgerr : 1; + u64 reserved_12_63 : 52; + } s; + struct cgxx_gmp_gmi_rxx_int_ena_w1c_cn { + u64 minerr : 1; + u64 carext : 1; + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 ovrerr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 falerr : 1; + u64 coldet : 1; + u64 ifgerr : 1; + u64 reserved_12_15 : 4; + u64 reserved_16_63 : 48; + } cn; +}; + +static inline u64 CGXX_GMP_GMI_RXX_INT_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_RXX_INT_ENA_W1C(u64 a) +{ + return 0x38010 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_rx#_int_ena_w1s + * + * CGX GMP GMI RX Interrupt Enable Set Registers This register sets + * interrupt enable bits. + */ +union cgxx_gmp_gmi_rxx_int_ena_w1s { + u64 u; + struct cgxx_gmp_gmi_rxx_int_ena_w1s_s { + u64 minerr : 1; + u64 carext : 1; + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 ovrerr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 falerr : 1; + u64 coldet : 1; + u64 ifgerr : 1; + u64 reserved_12_63 : 52; + } s; + struct cgxx_gmp_gmi_rxx_int_ena_w1s_cn { + u64 minerr : 1; + u64 carext : 1; + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 ovrerr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 falerr : 1; + u64 coldet : 1; + u64 ifgerr : 1; + u64 reserved_12_15 : 4; + u64 reserved_16_63 : 48; + } cn; +}; + +static inline u64 CGXX_GMP_GMI_RXX_INT_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_RXX_INT_ENA_W1S(u64 a) +{ + return 0x38018 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_rx#_int_w1s + * + * CGX GMP GMI RX Interrupt Set Registers This register sets interrupt + * bits. + */ +union cgxx_gmp_gmi_rxx_int_w1s { + u64 u; + struct cgxx_gmp_gmi_rxx_int_w1s_s { + u64 minerr : 1; + u64 carext : 1; + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 ovrerr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 falerr : 1; + u64 coldet : 1; + u64 ifgerr : 1; + u64 reserved_12_63 : 52; + } s; + struct cgxx_gmp_gmi_rxx_int_w1s_cn { + u64 minerr : 1; + u64 carext : 1; + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 ovrerr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 falerr : 1; + u64 coldet : 1; + u64 ifgerr : 1; + u64 reserved_12_15 : 4; + u64 reserved_16_63 : 48; + } cn; +}; + +static inline u64 CGXX_GMP_GMI_RXX_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_RXX_INT_W1S(u64 a) +{ + return 0x38008 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_rx#_jabber + * + * CGX GMP Maximum Packet-Size Registers This register specifies the + * maximum size for packets, beyond which the GMI truncates. + */ +union cgxx_gmp_gmi_rxx_jabber { + u64 u; + struct cgxx_gmp_gmi_rxx_jabber_s { + u64 cnt : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_gmi_rxx_jabber_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_RXX_JABBER(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_RXX_JABBER(u64 a) +{ + return 0x38038 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_rx#_udd_skp + * + * CGX GMP GMI User-Defined Data Skip Registers This register specifies + * the amount of user-defined data (UDD) added before the start of the + * L2C data. Internal: Notes: (1) The skip bytes are part of the packet + * and will be handled by NIX. (2) The system can determine if the UDD + * bytes are included in the FCS check by using the FCSSEL field - if the + * FCS check is enabled. (3) Assume that the preamble/sfd is always at + * the start of the frame - even before UDD bytes. In most cases, there + * will be no preamble in these cases since it will be packet interface + * in direct communication to another packet interface (MAC to MAC) + * without a PHY involved. (4) We can still do address filtering and + * control packet filtering is the user desires. (5) + * CGX()_GMP_GMI_RX()_UDD_SKP[LEN] must be 0 in half-duplex operation + * unless CGX()_GMP_GMI_RX()_FRM_CTL[PRE_CHK] is clear. If + * CGX()_GMP_GMI_RX()_FRM_CTL[PRE_CHK] is clear, then + * CGX()_GMP_GMI_RX()_UDD_SKP[LEN] will normally be 8. (6) In all cases, + * the UDD bytes will be sent down the packet interface as part of the + * packet. The UDD bytes are never stripped from the actual packet. + */ +union cgxx_gmp_gmi_rxx_udd_skp { + u64 u; + struct cgxx_gmp_gmi_rxx_udd_skp_s { + u64 len : 7; + u64 reserved_7 : 1; + u64 fcssel : 1; + u64 reserved_9_63 : 55; + } s; + /* struct cgxx_gmp_gmi_rxx_udd_skp_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_RXX_UDD_SKP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_RXX_UDD_SKP(u64 a) +{ + return 0x38048 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_smac# + * + * CGX GMI SMAC Registers + */ +union cgxx_gmp_gmi_smacx { + u64 u; + struct cgxx_gmp_gmi_smacx_s { + u64 smac : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_gmp_gmi_smacx_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_SMACX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_SMACX(u64 a) +{ + return 0x38230 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_append + * + * CGX GMI TX Append Control Registers + */ +union cgxx_gmp_gmi_txx_append { + u64 u; + struct cgxx_gmp_gmi_txx_append_s { + u64 preamble : 1; + u64 pad : 1; + u64 fcs : 1; + u64 force_fcs : 1; + u64 reserved_4_63 : 60; + } s; + /* struct cgxx_gmp_gmi_txx_append_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_APPEND(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_APPEND(u64 a) +{ + return 0x38218 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_burst + * + * CGX GMI TX Burst-Counter Registers + */ +union cgxx_gmp_gmi_txx_burst { + u64 u; + struct cgxx_gmp_gmi_txx_burst_s { + u64 burst : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_gmi_txx_burst_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_BURST(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_BURST(u64 a) +{ + return 0x38228 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_ctl + * + * CGX GMI Transmit Control Registers + */ +union cgxx_gmp_gmi_txx_ctl { + u64 u; + struct cgxx_gmp_gmi_txx_ctl_s { + u64 xscol_en : 1; + u64 xsdef_en : 1; + u64 tx_fc_type : 1; + u64 link_drain : 1; + u64 reserved_4_63 : 60; + } s; + /* struct cgxx_gmp_gmi_txx_ctl_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_CTL(u64 a) +{ + return 0x38270 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_int + * + * CGX GMI TX Interrupt Registers + */ +union cgxx_gmp_gmi_txx_int { + u64 u; + struct cgxx_gmp_gmi_txx_int_s { + u64 undflw : 1; + u64 xscol : 1; + u64 xsdef : 1; + u64 late_col : 1; + u64 ptp_lost : 1; + u64 reserved_5_63 : 59; + } s; + struct cgxx_gmp_gmi_txx_int_cn { + u64 undflw : 1; + u64 xscol : 1; + u64 xsdef : 1; + u64 late_col : 1; + u64 ptp_lost : 1; + u64 reserved_5_7 : 3; + u64 reserved_8 : 1; + u64 reserved_9_63 : 55; + } cn; +}; + +static inline u64 CGXX_GMP_GMI_TXX_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_INT(u64 a) +{ + return 0x38500 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_int_ena_w1c + * + * CGX GMI TX Interrupt Enable Clear Registers This register clears + * interrupt enable bits. + */ +union cgxx_gmp_gmi_txx_int_ena_w1c { + u64 u; + struct cgxx_gmp_gmi_txx_int_ena_w1c_s { + u64 undflw : 1; + u64 xscol : 1; + u64 xsdef : 1; + u64 late_col : 1; + u64 ptp_lost : 1; + u64 reserved_5_63 : 59; + } s; + struct cgxx_gmp_gmi_txx_int_ena_w1c_cn { + u64 undflw : 1; + u64 xscol : 1; + u64 xsdef : 1; + u64 late_col : 1; + u64 ptp_lost : 1; + u64 reserved_5_7 : 3; + u64 reserved_8 : 1; + u64 reserved_9_63 : 55; + } cn; +}; + +static inline u64 CGXX_GMP_GMI_TXX_INT_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_INT_ENA_W1C(u64 a) +{ + return 0x38510 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_int_ena_w1s + * + * CGX GMI TX Interrupt Enable Set Registers This register sets interrupt + * enable bits. + */ +union cgxx_gmp_gmi_txx_int_ena_w1s { + u64 u; + struct cgxx_gmp_gmi_txx_int_ena_w1s_s { + u64 undflw : 1; + u64 xscol : 1; + u64 xsdef : 1; + u64 late_col : 1; + u64 ptp_lost : 1; + u64 reserved_5_63 : 59; + } s; + struct cgxx_gmp_gmi_txx_int_ena_w1s_cn { + u64 undflw : 1; + u64 xscol : 1; + u64 xsdef : 1; + u64 late_col : 1; + u64 ptp_lost : 1; + u64 reserved_5_7 : 3; + u64 reserved_8 : 1; + u64 reserved_9_63 : 55; + } cn; +}; + +static inline u64 CGXX_GMP_GMI_TXX_INT_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_INT_ENA_W1S(u64 a) +{ + return 0x38518 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_int_w1s + * + * CGX GMI TX Interrupt Set Registers This register sets interrupt bits. + */ +union cgxx_gmp_gmi_txx_int_w1s { + u64 u; + struct cgxx_gmp_gmi_txx_int_w1s_s { + u64 undflw : 1; + u64 xscol : 1; + u64 xsdef : 1; + u64 late_col : 1; + u64 ptp_lost : 1; + u64 reserved_5_63 : 59; + } s; + struct cgxx_gmp_gmi_txx_int_w1s_cn { + u64 undflw : 1; + u64 xscol : 1; + u64 xsdef : 1; + u64 late_col : 1; + u64 ptp_lost : 1; + u64 reserved_5_7 : 3; + u64 reserved_8 : 1; + u64 reserved_9_63 : 55; + } cn; +}; + +static inline u64 CGXX_GMP_GMI_TXX_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_INT_W1S(u64 a) +{ + return 0x38508 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_min_pkt + * + * CGX GMI TX Minimum-Size-Packet Registers + */ +union cgxx_gmp_gmi_txx_min_pkt { + u64 u; + struct cgxx_gmp_gmi_txx_min_pkt_s { + u64 min_size : 8; + u64 reserved_8_63 : 56; + } s; + /* struct cgxx_gmp_gmi_txx_min_pkt_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_MIN_PKT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_MIN_PKT(u64 a) +{ + return 0x38240 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_pause_pkt_interval + * + * CGX GMI TX PAUSE-Packet Transmission-Interval Registers This register + * specifies how often PAUSE packets are sent. Internal: Notes: Choosing + * proper values of CGX()_GMP_GMI_TX()_PAUSE_PKT_TIME[PTIME] and + * CGX()_GMP_GMI_TX()_PAUSE_PKT_INTERVAL[INTERVAL] can be challenging to + * the system designer. It is suggested that TIME be much greater than + * INTERVAL and CGX()_GMP_GMI_TX()_PAUSE_ZERO[SEND] be set. This allows + * a periodic refresh of the PAUSE count and then when the backpressure + * condition is lifted, a PAUSE packet with TIME==0 will be sent + * indicating that Octane is ready for additional data. If the system + * chooses to not set CGX()_GMP_GMI_TX()_PAUSE_ZERO[SEND], then it is + * suggested that TIME and INTERVAL are programmed such that they + * satisify the following rule: _ INTERVAL <= TIME - (largest_pkt_size + * + IFG + pause_pkt_size) where largest_pkt_size is that largest packet + * that the system can send (normally 1518B), IFG is the interframe gap + * and pause_pkt_size is the size of the PAUSE packet (normally 64B). + */ +union cgxx_gmp_gmi_txx_pause_pkt_interval { + u64 u; + struct cgxx_gmp_gmi_txx_pause_pkt_interval_s { + u64 interval : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_gmi_txx_pause_pkt_interval_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_PAUSE_PKT_INTERVAL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_PAUSE_PKT_INTERVAL(u64 a) +{ + return 0x38248 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_pause_pkt_time + * + * CGX GMI TX PAUSE Packet PAUSE-Time Registers + */ +union cgxx_gmp_gmi_txx_pause_pkt_time { + u64 u; + struct cgxx_gmp_gmi_txx_pause_pkt_time_s { + u64 ptime : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_gmi_txx_pause_pkt_time_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_PAUSE_PKT_TIME(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_PAUSE_PKT_TIME(u64 a) +{ + return 0x38238 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_pause_togo + * + * CGX GMI TX Time-to-Backpressure Registers + */ +union cgxx_gmp_gmi_txx_pause_togo { + u64 u; + struct cgxx_gmp_gmi_txx_pause_togo_s { + u64 ptime : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_gmi_txx_pause_togo_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_PAUSE_TOGO(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_PAUSE_TOGO(u64 a) +{ + return 0x38258 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_pause_zero + * + * CGX GMI TX PAUSE-Zero-Enable Registers + */ +union cgxx_gmp_gmi_txx_pause_zero { + u64 u; + struct cgxx_gmp_gmi_txx_pause_zero_s { + u64 send : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_gmp_gmi_txx_pause_zero_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_PAUSE_ZERO(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_PAUSE_ZERO(u64 a) +{ + return 0x38260 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_sgmii_ctl + * + * CGX SGMII Control Registers + */ +union cgxx_gmp_gmi_txx_sgmii_ctl { + u64 u; + struct cgxx_gmp_gmi_txx_sgmii_ctl_s { + u64 align : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_gmp_gmi_txx_sgmii_ctl_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_SGMII_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_SGMII_CTL(u64 a) +{ + return 0x38300 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_slot + * + * CGX GMI TX Slottime Counter Registers + */ +union cgxx_gmp_gmi_txx_slot { + u64 u; + struct cgxx_gmp_gmi_txx_slot_s { + u64 slot : 10; + u64 reserved_10_63 : 54; + } s; + /* struct cgxx_gmp_gmi_txx_slot_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_SLOT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_SLOT(u64 a) +{ + return 0x38220 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_soft_pause + * + * CGX GMI TX Software PAUSE Registers + */ +union cgxx_gmp_gmi_txx_soft_pause { + u64 u; + struct cgxx_gmp_gmi_txx_soft_pause_s { + u64 ptime : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_gmi_txx_soft_pause_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_SOFT_PAUSE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_SOFT_PAUSE(u64 a) +{ + return 0x38250 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx#_thresh + * + * CGX GMI TX Threshold Registers + */ +union cgxx_gmp_gmi_txx_thresh { + u64 u; + struct cgxx_gmp_gmi_txx_thresh_s { + u64 cnt : 11; + u64 reserved_11_63 : 53; + } s; + /* struct cgxx_gmp_gmi_txx_thresh_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TXX_THRESH(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TXX_THRESH(u64 a) +{ + return 0x38210 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx_col_attempt + * + * CGX TX Collision Attempts Before Dropping Frame Registers + */ +union cgxx_gmp_gmi_tx_col_attempt { + u64 u; + struct cgxx_gmp_gmi_tx_col_attempt_s { + u64 limit : 5; + u64 reserved_5_63 : 59; + } s; + /* struct cgxx_gmp_gmi_tx_col_attempt_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TX_COL_ATTEMPT(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TX_COL_ATTEMPT(void) +{ + return 0x39010; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx_ifg + * + * CGX GMI TX Interframe-Gap Cycles Registers Consider the following when + * programming IFG1 and IFG2: * For 10/100/1000 Mb/s half-duplex systems + * that require IEEE 802.3 compatibility, IFG1 must be in the range of + * 1-8, [IFG2] must be in the range of 4-12, and the [IFG1] + [IFG2] sum + * must be 12. * For 10/100/1000 Mb/s full-duplex systems that require + * IEEE 802.3 compatibility, IFG1 must be in the range of 1-11, [IFG2] + * must be in the range of 1-11, and the [IFG1] + [IFG2] sum must be 12. + * For all other systems, IFG1 and IFG2 can be any value in the range of + * 1-15, allowing for a total possible IFG sum of 2-30. + */ +union cgxx_gmp_gmi_tx_ifg { + u64 u; + struct cgxx_gmp_gmi_tx_ifg_s { + u64 ifg1 : 4; + u64 ifg2 : 4; + u64 reserved_8_63 : 56; + } s; + /* struct cgxx_gmp_gmi_tx_ifg_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TX_IFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TX_IFG(void) +{ + return 0x39000; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx_jam + * + * CGX GMI TX JAM Pattern Registers This register provides the pattern + * used in JAM bytes. + */ +union cgxx_gmp_gmi_tx_jam { + u64 u; + struct cgxx_gmp_gmi_tx_jam_s { + u64 jam : 8; + u64 reserved_8_63 : 56; + } s; + /* struct cgxx_gmp_gmi_tx_jam_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TX_JAM(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TX_JAM(void) +{ + return 0x39008; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx_lfsr + * + * CGX GMI TX LFSR Registers This register shows the contents of the + * linear feedback shift register (LFSR), which is used to implement + * truncated binary exponential backoff. + */ +union cgxx_gmp_gmi_tx_lfsr { + u64 u; + struct cgxx_gmp_gmi_tx_lfsr_s { + u64 lfsr : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_gmi_tx_lfsr_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TX_LFSR(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TX_LFSR(void) +{ + return 0x39028; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx_pause_pkt_dmac + * + * CGX TX PAUSE-Packet DMAC-Field Registers + */ +union cgxx_gmp_gmi_tx_pause_pkt_dmac { + u64 u; + struct cgxx_gmp_gmi_tx_pause_pkt_dmac_s { + u64 dmac : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_gmp_gmi_tx_pause_pkt_dmac_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TX_PAUSE_PKT_DMAC(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TX_PAUSE_PKT_DMAC(void) +{ + return 0x39018; +} + +/** + * Register (RSL) cgx#_gmp_gmi_tx_pause_pkt_type + * + * CGX GMI TX PAUSE-Packet-PTYPE Field Registers This register provides + * the PTYPE field that is placed in outbound PAUSE packets. + */ +union cgxx_gmp_gmi_tx_pause_pkt_type { + u64 u; + struct cgxx_gmp_gmi_tx_pause_pkt_type_s { + u64 ptype : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_gmi_tx_pause_pkt_type_s cn; */ +}; + +static inline u64 CGXX_GMP_GMI_TX_PAUSE_PKT_TYPE(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_GMI_TX_PAUSE_PKT_TYPE(void) +{ + return 0x39020; +} + +/** + * Register (RSL) cgx#_gmp_misc#_cfg + * + * CGX GMP PCS Miscellaneous Control Registers This register contains + * general configuration that should not need to be changed from reset + * settings. Internal: Per lmac diagnostic and chicken bits. + */ +union cgxx_gmp_miscx_cfg { + u64 u; + struct cgxx_gmp_miscx_cfg_s { + u64 tx_eee_quiet_credit_mode : 1; + u64 tx_eee_wait_gmi_fast_idle : 1; + u64 tx_qsgmii_port0_init : 1; + u64 tx_eee_rx_sync_status_enable : 1; + u64 pcs_alt_an : 1; + u64 reserved_5_7 : 3; + u64 rx_pcs_sync_signal_detect : 1; + u64 rx_pcs_sync_timeout : 1; + u64 rx_pcs_eee_mode_enable : 1; + u64 rx_pcs_lpi_enable : 1; + u64 rx_pcs_802_rx_k : 1; + u64 rx_pcs_alt_qlb2i : 1; + u64 reserved_14_15 : 2; + u64 rx_cgp_gser_throttle : 1; + u64 rx_cgp_edet_filter : 1; + u64 rx_cgp_edet_qlm_val : 1; + u64 reserved_19_63 : 45; + } s; + /* struct cgxx_gmp_miscx_cfg_s cn; */ +}; + +static inline u64 CGXX_GMP_MISCX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_MISCX_CFG(u64 a) +{ + return 0x34000 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs#_an_expansion + * + * CGX GMP PCS AN Expansion register Register 6 AN status + */ +union cgxx_gmp_pcsx_an_expansion { + u64 u; + struct cgxx_gmp_pcsx_an_expansion_s { + u64 reserved_0 : 1; + u64 page_received : 1; + u64 next_page_able : 1; + u64 reserved_3_63 : 61; + } s; + /* struct cgxx_gmp_pcsx_an_expansion_s cn; */ +}; + +static inline u64 CGXX_GMP_PCSX_AN_EXPANSION(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCSX_AN_EXPANSION(u64 a) +{ + return 0x30a60 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs#_an_lp_abil_np + * + * CGX GMP PCS AN Link Partner Ability Next Page Register 8 This register + * contains the advertised ability of the link partners Next Page. The + * definition for this register is provided in 32.5.4.2 for changes to + * 28.2.4.1.4. + */ +union cgxx_gmp_pcsx_an_lp_abil_np { + u64 u; + struct cgxx_gmp_pcsx_an_lp_abil_np_s { + u64 m_u : 11; + u64 toggle : 1; + u64 ack2 : 1; + u64 mp : 1; + u64 ack : 1; + u64 np : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcsx_an_lp_abil_np_s cn; */ +}; + +static inline u64 CGXX_GMP_PCSX_AN_LP_ABIL_NP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCSX_AN_LP_ABIL_NP(u64 a) +{ + return 0x30a80 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs#_an_np_tx + * + * CGX GMP PCS AN Next Page Transmit Register 7 Software programs this + * register with the contents of the AN message next page or unformatted + * next page link code word to be transmitted during autonegotiation. + * Next page exchange occurs after the base link code words have been + * exchanged if either end of the link segment sets the NP bit to 1, + * indicating that it has at least one next page to send. Once initiated, + * next page exchange continues until both ends of the link segment set + * their NP bits to 0. Both sides must be NP capable to use NP exchanges. + */ +union cgxx_gmp_pcsx_an_np_tx { + u64 u; + struct cgxx_gmp_pcsx_an_np_tx_s { + u64 m_u : 11; + u64 toggle : 1; + u64 ack2 : 1; + u64 mp : 1; + u64 ack : 1; + u64 np : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcsx_an_np_tx_s cn; */ +}; + +static inline u64 CGXX_GMP_PCSX_AN_NP_TX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCSX_AN_NP_TX(u64 a) +{ + return 0x30a70 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs#_dbg_control + * + * CGX PCS Debug Control Registers + */ +union cgxx_gmp_pcsx_dbg_control { + u64 u; + struct cgxx_gmp_pcsx_dbg_control_s { + u64 us_clk_period : 7; + u64 reserved_7_63 : 57; + } s; + /* struct cgxx_gmp_pcsx_dbg_control_s cn; */ +}; + +static inline u64 CGXX_GMP_PCSX_DBG_CONTROL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCSX_DBG_CONTROL(u64 a) +{ + return 0x31000 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs#_rx_eee_wake + * + * INTERNAL: CGX GMP PCS RX EEE Wake Error Counter Registers Reserved. + * Internal: This register is used by PHY types that support EEE to count + * wake time faults where the PHY fails to complete its normal wake + * sequence within the time required for the specific PHY type. The + * definition of the fault event to be counted is defined for each PHY + * and may occur during a refresh or a wake-up as defined by the PHY. + * This 16-bit counter shall be reset to all zeros upon execution of the + * PCS reset. This counter shall be held at all ones in the case of + * overflow. + */ +union cgxx_gmp_pcsx_rx_eee_wake { + u64 u; + struct cgxx_gmp_pcsx_rx_eee_wake_s { + u64 error_counter : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcsx_rx_eee_wake_s cn; */ +}; + +static inline u64 CGXX_GMP_PCSX_RX_EEE_WAKE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCSX_RX_EEE_WAKE(u64 a) +{ + return 0x30910 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs#_rx_lpi_timing + * + * INTERNAL: CGX GMP PCS RX EEE LPI Timing Parameters Registers + * Reserved. Internal: Receiver LPI timing parameters Tqr, Twr and Twtf. + */ +union cgxx_gmp_pcsx_rx_lpi_timing { + u64 u; + struct cgxx_gmp_pcsx_rx_lpi_timing_s { + u64 twtf : 18; + u64 reserved_18_19 : 2; + u64 twr : 12; + u64 tqr : 20; + u64 reserved_52_63 : 12; + } s; + /* struct cgxx_gmp_pcsx_rx_lpi_timing_s cn; */ +}; + +static inline u64 CGXX_GMP_PCSX_RX_LPI_TIMING(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCSX_RX_LPI_TIMING(u64 a) +{ + return 0x30900 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs#_status1 + * + * CGX GMP PCS Status 1 Register PCS LPI Status, Link OK. Register 3.1 + */ +union cgxx_gmp_pcsx_status1 { + u64 u; + struct cgxx_gmp_pcsx_status1_s { + u64 reserved_0_1 : 2; + u64 receive_link_status : 1; + u64 reserved_3_7 : 5; + u64 rx_lpi_indication : 1; + u64 tx_lpi_indication : 1; + u64 rx_lpi_received : 1; + u64 tx_lpi_received : 1; + u64 reserved_12_63 : 52; + } s; + /* struct cgxx_gmp_pcsx_status1_s cn; */ +}; + +static inline u64 CGXX_GMP_PCSX_STATUS1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCSX_STATUS1(u64 a) +{ + return 0x30880 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs#_tx_lpi_timing + * + * INTERNAL: CGX GMP GMI TX EEE LPI Timing Parameters Registers + * Reserved. Internal: Transmitter LPI timing parameters Tsl, Tql and + * Tul. + */ +union cgxx_gmp_pcsx_tx_lpi_timing { + u64 u; + struct cgxx_gmp_pcsx_tx_lpi_timing_s { + u64 tql : 19; + u64 reserved_19_31 : 13; + u64 tul : 12; + u64 reserved_44_47 : 4; + u64 tsl : 12; + u64 reserved_60_63 : 4; + } s; + /* struct cgxx_gmp_pcsx_tx_lpi_timing_s cn; */ +}; + +static inline u64 CGXX_GMP_PCSX_TX_LPI_TIMING(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCSX_TX_LPI_TIMING(u64 a) +{ + return 0x30800 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_an#_adv + * + * CGX GMP PCS Autonegotiation Advertisement Registers + */ +union cgxx_gmp_pcs_anx_adv { + u64 u; + struct cgxx_gmp_pcs_anx_adv_s { + u64 reserved_0_4 : 5; + u64 fd : 1; + u64 hfd : 1; + u64 pause : 2; + u64 reserved_9_11 : 3; + u64 rem_flt : 2; + u64 reserved_14 : 1; + u64 np : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcs_anx_adv_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_ANX_ADV(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_ANX_ADV(u64 a) +{ + return 0x30010 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_an#_ext_st + * + * CGX GMO PCS Autonegotiation Extended Status Registers + */ +union cgxx_gmp_pcs_anx_ext_st { + u64 u; + struct cgxx_gmp_pcs_anx_ext_st_s { + u64 reserved_0_11 : 12; + u64 thou_thd : 1; + u64 thou_tfd : 1; + u64 thou_xhd : 1; + u64 thou_xfd : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcs_anx_ext_st_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_ANX_EXT_ST(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_ANX_EXT_ST(u64 a) +{ + return 0x30028 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_an#_lp_abil + * + * CGX GMP PCS Autonegotiation Link Partner Ability Registers This is the + * autonegotiation link partner ability register 5 as per IEEE 802.3, + * Clause 37. + */ +union cgxx_gmp_pcs_anx_lp_abil { + u64 u; + struct cgxx_gmp_pcs_anx_lp_abil_s { + u64 reserved_0_4 : 5; + u64 fd : 1; + u64 hfd : 1; + u64 pause : 2; + u64 reserved_9_11 : 3; + u64 rem_flt : 2; + u64 ack : 1; + u64 np : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcs_anx_lp_abil_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_ANX_LP_ABIL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_ANX_LP_ABIL(u64 a) +{ + return 0x30018 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_an#_results + * + * CGX GMP PCS Autonegotiation Results Registers This register is not + * valid when CGX()_GMP_PCS_MISC()_CTL[AN_OVRD] is set to 1. If + * CGX()_GMP_PCS_MISC()_CTL[AN_OVRD] is set to 0 and + * CGX()_GMP_PCS_AN()_RESULTS[AN_CPT] is set to 1, this register is + * valid. + */ +union cgxx_gmp_pcs_anx_results { + u64 u; + struct cgxx_gmp_pcs_anx_results_s { + u64 link_ok : 1; + u64 dup : 1; + u64 an_cpt : 1; + u64 spd : 2; + u64 pause : 2; + u64 reserved_7_63 : 57; + } s; + /* struct cgxx_gmp_pcs_anx_results_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_ANX_RESULTS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_ANX_RESULTS(u64 a) +{ + return 0x30020 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_int# + * + * CGX GMP PCS Interrupt Registers + */ +union cgxx_gmp_pcs_intx { + u64 u; + struct cgxx_gmp_pcs_intx_s { + u64 lnkspd : 1; + u64 xmit : 1; + u64 an_err : 1; + u64 txfifu : 1; + u64 txfifo : 1; + u64 txbad : 1; + u64 rxerr : 1; + u64 rxbad : 1; + u64 rxlock : 1; + u64 an_bad : 1; + u64 sync_bad : 1; + u64 dup : 1; + u64 dbg_sync : 1; + u64 reserved_13_15 : 3; + u64 an_page_received : 1; + u64 an_complete : 1; + u64 reserved_18_19 : 2; + u64 eee_tx_change : 1; + u64 eee_rx_change : 1; + u64 eee_rx_link_fail : 1; + u64 reserved_23_63 : 41; + } s; + /* struct cgxx_gmp_pcs_intx_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_INTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_INTX(u64 a) +{ + return 0x30080 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_int#_ena_w1c + * + * CGX GMP PCS Interrupt Enable Clear Registers This register clears + * interrupt enable bits. + */ +union cgxx_gmp_pcs_intx_ena_w1c { + u64 u; + struct cgxx_gmp_pcs_intx_ena_w1c_s { + u64 lnkspd : 1; + u64 xmit : 1; + u64 an_err : 1; + u64 txfifu : 1; + u64 txfifo : 1; + u64 txbad : 1; + u64 rxerr : 1; + u64 rxbad : 1; + u64 rxlock : 1; + u64 an_bad : 1; + u64 sync_bad : 1; + u64 dup : 1; + u64 dbg_sync : 1; + u64 reserved_13_15 : 3; + u64 an_page_received : 1; + u64 an_complete : 1; + u64 reserved_18_19 : 2; + u64 eee_tx_change : 1; + u64 eee_rx_change : 1; + u64 eee_rx_link_fail : 1; + u64 reserved_23_63 : 41; + } s; + /* struct cgxx_gmp_pcs_intx_ena_w1c_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_INTX_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_INTX_ENA_W1C(u64 a) +{ + return 0x30090 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_int#_ena_w1s + * + * CGX GMP PCS Interrupt Enable Set Registers This register sets + * interrupt enable bits. + */ +union cgxx_gmp_pcs_intx_ena_w1s { + u64 u; + struct cgxx_gmp_pcs_intx_ena_w1s_s { + u64 lnkspd : 1; + u64 xmit : 1; + u64 an_err : 1; + u64 txfifu : 1; + u64 txfifo : 1; + u64 txbad : 1; + u64 rxerr : 1; + u64 rxbad : 1; + u64 rxlock : 1; + u64 an_bad : 1; + u64 sync_bad : 1; + u64 dup : 1; + u64 dbg_sync : 1; + u64 reserved_13_15 : 3; + u64 an_page_received : 1; + u64 an_complete : 1; + u64 reserved_18_19 : 2; + u64 eee_tx_change : 1; + u64 eee_rx_change : 1; + u64 eee_rx_link_fail : 1; + u64 reserved_23_63 : 41; + } s; + /* struct cgxx_gmp_pcs_intx_ena_w1s_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_INTX_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_INTX_ENA_W1S(u64 a) +{ + return 0x30098 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_int#_w1s + * + * CGX GMP PCS Interrupt Set Registers This register sets interrupt bits. + */ +union cgxx_gmp_pcs_intx_w1s { + u64 u; + struct cgxx_gmp_pcs_intx_w1s_s { + u64 lnkspd : 1; + u64 xmit : 1; + u64 an_err : 1; + u64 txfifu : 1; + u64 txfifo : 1; + u64 txbad : 1; + u64 rxerr : 1; + u64 rxbad : 1; + u64 rxlock : 1; + u64 an_bad : 1; + u64 sync_bad : 1; + u64 dup : 1; + u64 dbg_sync : 1; + u64 reserved_13_15 : 3; + u64 an_page_received : 1; + u64 an_complete : 1; + u64 reserved_18_19 : 2; + u64 eee_tx_change : 1; + u64 eee_rx_change : 1; + u64 eee_rx_link_fail : 1; + u64 reserved_23_63 : 41; + } s; + /* struct cgxx_gmp_pcs_intx_w1s_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_INTX_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_INTX_W1S(u64 a) +{ + return 0x30088 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_link#_timer + * + * CGX GMP PCS Link Timer Registers This is the 1.6 ms nominal link timer + * register. + */ +union cgxx_gmp_pcs_linkx_timer { + u64 u; + struct cgxx_gmp_pcs_linkx_timer_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcs_linkx_timer_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_LINKX_TIMER(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_LINKX_TIMER(u64 a) +{ + return 0x30040 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_misc#_ctl + * + * CGX GMP SGMII Miscellaneous Control Registers Internal: SGMII bit [12] + * is really a misnomer, it is a decode of pi_qlm_cfg pins to indicate + * SGMII or 1000Base-X modes. Note: The SGMII AN Advertisement Register + * above will be sent during Auto Negotiation if [MAC_PHY] is set (1=PHY + * mode). If the bit is not set (0=MAC mode), the tx_Config_Reg<14> + * becomes ACK bit and tx_Config_Reg<0> is always 1. All other bits in + * tx_Config_Reg sent will be 0. The PHY dictates the Auto Negotiation + * results. + */ +union cgxx_gmp_pcs_miscx_ctl { + u64 u; + struct cgxx_gmp_pcs_miscx_ctl_s { + u64 samp_pt : 7; + u64 an_ovrd : 1; + u64 mode : 1; + u64 mac_phy : 1; + u64 loopbck2 : 1; + u64 gmxeno : 1; + u64 reserved_12 : 1; + u64 disp_en : 1; + u64 reserved_14_15 : 2; + u64 qsgmii_comma_wd : 16; + u64 qsgmii_comma_wd_en : 1; + u64 reserved_33_63 : 31; + } s; + struct cgxx_gmp_pcs_miscx_ctl_cn { + u64 samp_pt : 7; + u64 an_ovrd : 1; + u64 mode : 1; + u64 mac_phy : 1; + u64 loopbck2 : 1; + u64 gmxeno : 1; + u64 reserved_12 : 1; + u64 disp_en : 1; + u64 reserved_14_15 : 2; + u64 qsgmii_comma_wd : 16; + u64 qsgmii_comma_wd_en : 1; + u64 reserved_33_35 : 3; + u64 reserved_36_63 : 28; + } cn; +}; + +static inline u64 CGXX_GMP_PCS_MISCX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_MISCX_CTL(u64 a) +{ + return 0x30078 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_mr#_control + * + * CGX GMP PCS Control Registers + */ +union cgxx_gmp_pcs_mrx_control { + u64 u; + struct cgxx_gmp_pcs_mrx_control_s { + u64 reserved_0_4 : 5; + u64 uni : 1; + u64 spdmsb : 1; + u64 coltst : 1; + u64 dup : 1; + u64 rst_an : 1; + u64 reserved_10 : 1; + u64 pwr_dn : 1; + u64 an_en : 1; + u64 spdlsb : 1; + u64 loopbck1 : 1; + u64 reset : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcs_mrx_control_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_MRX_CONTROL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_MRX_CONTROL(u64 a) +{ + return 0x30000 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_mr#_status + * + * CGX GMP PCS Status Registers Bits <15:9> in this register indicate + * the ability to operate when CGX()_GMP_PCS_MISC()_CTL[MAC_PHY] is set + * to MAC mode. Bits <15:9> are always read as 0, indicating that the + * chip cannot operate in the corresponding modes. The field [RM_FLT] is + * a 'don't care' when the selected mode is SGMII/QSGMII. + */ +union cgxx_gmp_pcs_mrx_status { + u64 u; + struct cgxx_gmp_pcs_mrx_status_s { + u64 extnd : 1; + u64 reserved_1 : 1; + u64 lnk_st : 1; + u64 an_abil : 1; + u64 rm_flt : 1; + u64 an_cpt : 1; + u64 prb_sup : 1; + u64 reserved_7 : 1; + u64 ext_st : 1; + u64 hun_t2hd : 1; + u64 hun_t2fd : 1; + u64 ten_hd : 1; + u64 ten_fd : 1; + u64 hun_xhd : 1; + u64 hun_xfd : 1; + u64 hun_t4 : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcs_mrx_status_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_MRX_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_MRX_STATUS(u64 a) +{ + return 0x30008 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_rx#_states + * + * CGX GMP PCS RX State-Machines States Registers + */ +union cgxx_gmp_pcs_rxx_states { + u64 u; + struct cgxx_gmp_pcs_rxx_states_s { + u64 an_st : 4; + u64 an_bad : 1; + u64 sync : 4; + u64 sync_bad : 1; + u64 rx_st : 5; + u64 rx_bad : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcs_rxx_states_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_RXX_STATES(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_RXX_STATES(u64 a) +{ + return 0x30058 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_rx#_sync + * + * CGX GMP PCS Code Group Synchronization Registers + */ +union cgxx_gmp_pcs_rxx_sync { + u64 u; + struct cgxx_gmp_pcs_rxx_sync_s { + u64 bit_lock : 1; + u64 sync : 1; + u64 reserved_2_63 : 62; + } s; + /* struct cgxx_gmp_pcs_rxx_sync_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_RXX_SYNC(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_RXX_SYNC(u64 a) +{ + return 0x30050 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_sgm#_an_adv + * + * CGX GMP PCS SGMII Autonegotiation Advertisement Registers This is the + * SGMII autonegotiation advertisement register (sent out as + * tx_Config_Reg<15:0> as defined in IEEE 802.3 clause 37). This + * register is sent during autonegotiation if + * CGX()_GMP_PCS_MISC()_CTL[MAC_PHY] is set (1 = PHY mode). If the bit is + * not set (0 = MAC mode), then tx_Config_Reg<14> becomes ACK bit and + * tx_Config_Reg<0> is always 1. All other bits in tx_Config_Reg sent + * will be 0. The PHY dictates the autonegotiation results. + */ +union cgxx_gmp_pcs_sgmx_an_adv { + u64 u; + struct cgxx_gmp_pcs_sgmx_an_adv_s { + u64 one : 1; + u64 reserved_1_9 : 9; + u64 speed : 2; + u64 dup : 1; + u64 reserved_13 : 1; + u64 ack : 1; + u64 link : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_gmp_pcs_sgmx_an_adv_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_SGMX_AN_ADV(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_SGMX_AN_ADV(u64 a) +{ + return 0x30068 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_sgm#_lp_adv + * + * CGX GMP PCS SGMII Link-Partner-Advertisement Registers This is the + * SGMII link partner advertisement register (received as + * rx_Config_Reg<15:0> as defined in IEEE 802.3 clause 37). + */ +union cgxx_gmp_pcs_sgmx_lp_adv { + u64 u; + struct cgxx_gmp_pcs_sgmx_lp_adv_s { + u64 one : 1; + u64 reserved_1_9 : 9; + u64 speed : 2; + u64 dup : 1; + u64 reserved_13_14 : 2; + u64 link : 1; + u64 reserved_16_63 : 48; + } s; + struct cgxx_gmp_pcs_sgmx_lp_adv_cn { + u64 one : 1; + u64 reserved_1_9 : 9; + u64 speed : 2; + u64 dup : 1; + u64 reserved_13 : 1; + u64 reserved_14 : 1; + u64 link : 1; + u64 reserved_16_63 : 48; + } cn; +}; + +static inline u64 CGXX_GMP_PCS_SGMX_LP_ADV(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_SGMX_LP_ADV(u64 a) +{ + return 0x30070 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_tx#_states + * + * CGX GMP PCS TX State-Machines States Registers + */ +union cgxx_gmp_pcs_txx_states { + u64 u; + struct cgxx_gmp_pcs_txx_states_s { + u64 ord_st : 4; + u64 tx_bad : 1; + u64 xmit : 2; + u64 reserved_7_63 : 57; + } s; + /* struct cgxx_gmp_pcs_txx_states_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_TXX_STATES(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_TXX_STATES(u64 a) +{ + return 0x30060 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_gmp_pcs_tx_rx#_polarity + * + * CGX GMP PCS TX/RX Polarity Registers + * CGX()_GMP_PCS_TX_RX()_POLARITY[AUTORXPL] shows correct polarity needed + * on the link receive path after code group synchronization is achieved. + * When LMAC_TYPE=QSGMII, only lane 0 polarity data and settings are + * relevant and settings for lanes 1, 2 and 3 are unused. + */ +union cgxx_gmp_pcs_tx_rxx_polarity { + u64 u; + struct cgxx_gmp_pcs_tx_rxx_polarity_s { + u64 txplrt : 1; + u64 rxplrt : 1; + u64 autorxpl : 1; + u64 rxovrd : 1; + u64 reserved_4_63 : 60; + } s; + /* struct cgxx_gmp_pcs_tx_rxx_polarity_s cn; */ +}; + +static inline u64 CGXX_GMP_PCS_TX_RXX_POLARITY(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_GMP_PCS_TX_RXX_POLARITY(u64 a) +{ + return 0x30048 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_msix_pba# + * + * CGX MSI-X Pending Bit Array Registers This register is the MSI-X PBA + * table, the bit number is indexed by the CGX_INT_VEC_E enumeration. + */ +union cgxx_msix_pbax { + u64 u; + struct cgxx_msix_pbax_s { + u64 pend : 64; + } s; + /* struct cgxx_msix_pbax_s cn; */ +}; + +static inline u64 CGXX_MSIX_PBAX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_MSIX_PBAX(u64 a) +{ + return 0xf0000 + 8 * a; +} + +/** + * Register (RSL) cgx#_msix_vec#_addr + * + * CGX MSI-X Vector Table Address Registers This register is the MSI-X + * vector table, indexed by the CGX_INT_VEC_E enumeration. + */ +union cgxx_msix_vecx_addr { + u64 u; + struct cgxx_msix_vecx_addr_s { + u64 secvec : 1; + u64 reserved_1 : 1; + u64 addr : 51; + u64 reserved_53_63 : 11; + } s; + /* struct cgxx_msix_vecx_addr_s cn; */ +}; + +static inline u64 CGXX_MSIX_VECX_ADDR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_MSIX_VECX_ADDR(u64 a) +{ + return 0 + 0x10 * a; +} + +/** + * Register (RSL) cgx#_msix_vec#_ctl + * + * CGX MSI-X Vector Table Control and Data Registers This register is the + * MSI-X vector table, indexed by the CGX_INT_VEC_E enumeration. + */ +union cgxx_msix_vecx_ctl { + u64 u; + struct cgxx_msix_vecx_ctl_s { + u64 data : 32; + u64 mask : 1; + u64 reserved_33_63 : 31; + } s; + /* struct cgxx_msix_vecx_ctl_s cn; */ +}; + +static inline u64 CGXX_MSIX_VECX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_MSIX_VECX_CTL(u64 a) +{ + return 8 + 0x10 * a; +} + +/** + * Register (RSL) cgx#_smu#_bp_test + * + * INTERNAL: CGX SMU TX Backpressure Test Registers + */ +union cgxx_smux_bp_test { + u64 u; + struct cgxx_smux_bp_test_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_47 : 24; + u64 enable : 4; + u64 reserved_52_63 : 12; + } s; + /* struct cgxx_smux_bp_test_s cn; */ +}; + +static inline u64 CGXX_SMUX_BP_TEST(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_BP_TEST(u64 a) +{ + return 0x20230 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_cbfc_ctl + * + * CGX SMU PFC Control Registers Internal: INTERNAL: XOFF for a specific + * class/channel <i> is XOFF<i> = ([PHYS_EN]<i> & cmr_rx_phys_bp) | + * ([LOGL_EN]<i> & cmr_rx_logl_xoff<i>). + */ +union cgxx_smux_cbfc_ctl { + u64 u; + struct cgxx_smux_cbfc_ctl_s { + u64 rx_en : 1; + u64 tx_en : 1; + u64 drp_en : 1; + u64 bck_en : 1; + u64 reserved_4_31 : 28; + u64 logl_en : 16; + u64 phys_en : 16; + } s; + /* struct cgxx_smux_cbfc_ctl_s cn; */ +}; + +static inline u64 CGXX_SMUX_CBFC_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_CBFC_CTL(u64 a) +{ + return 0x20218 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_ctrl + * + * CGX SMU Control Registers + */ +union cgxx_smux_ctrl { + u64 u; + struct cgxx_smux_ctrl_s { + u64 rx_idle : 1; + u64 tx_idle : 1; + u64 reserved_2_63 : 62; + } s; + /* struct cgxx_smux_ctrl_s cn; */ +}; + +static inline u64 CGXX_SMUX_CTRL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_CTRL(u64 a) +{ + return 0x20200 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_ext_loopback + * + * CGX SMU External Loopback Registers In loopback mode, the IFG1+IFG2 of + * local and remote parties must match exactly; otherwise loopback FIFO + * will overrun: CGX()_SMU()_TX_INT[LB_OVRFLW]. + */ +union cgxx_smux_ext_loopback { + u64 u; + struct cgxx_smux_ext_loopback_s { + u64 thresh : 6; + u64 reserved_6_7 : 2; + u64 depth : 6; + u64 reserved_14_15 : 2; + u64 en : 1; + u64 reserved_17_63 : 47; + } s; + /* struct cgxx_smux_ext_loopback_s cn; */ +}; + +static inline u64 CGXX_SMUX_EXT_LOOPBACK(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_EXT_LOOPBACK(u64 a) +{ + return 0x20208 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_hg2_control + * + * CGX SMU HiGig2 Control Registers HiGig2 TX- and RX-enable are normally + * set together for HiGig2 messaging. Setting just the TX or RX bit + * results in only the HG2 message transmit or receive capability. + * Setting [PHYS_EN] and [LOGL_EN] to 1 allows link PAUSE or backpressure + * to NIX as per the received HiGig2 message. Setting these fields to 0 + * disables link PAUSE and backpressure to NIX in response to received + * messages. CGX()_SMU()_TX_CTL[HG_EN] must be set (to enable HiGig) + * whenever either [HG2TX_EN] or [HG2RX_EN] are set. + * CGX()_SMU()_RX_UDD_SKP[LEN] must be set to 16 (to select HiGig2) + * whenever either [HG2TX_EN] or [HG2RX_EN] are set. + * CGX()_CMR_RX_OVR_BP[EN]<0> must be set and + * CGX()_CMR_RX_OVR_BP[BP]<0> must be cleared to 0 (to forcibly disable + * hardware-automatic 802.3 PAUSE packet generation) with the HiGig2 + * Protocol when [HG2TX_EN] = 0. (The HiGig2 protocol is indicated by + * CGX()_SMU()_TX_CTL[HG_EN] = 1 and CGX()_SMU()_RX_UDD_SKP[LEN]=16.) + * Hardware can only autogenerate backpressure via HiGig2 messages + * (optionally, when [HG2TX_EN] = 1) with the HiGig2 protocol. + */ +union cgxx_smux_hg2_control { + u64 u; + struct cgxx_smux_hg2_control_s { + u64 logl_en : 16; + u64 phys_en : 1; + u64 hg2rx_en : 1; + u64 hg2tx_en : 1; + u64 reserved_19_63 : 45; + } s; + /* struct cgxx_smux_hg2_control_s cn; */ +}; + +static inline u64 CGXX_SMUX_HG2_CONTROL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_HG2_CONTROL(u64 a) +{ + return 0x20210 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_mmsi_ctl_sta + * + * CGX SMU MAC Merge Service Interface (MMSI) Control/Status Registers + * MMSI control and status registers for frame preemption mode. Refer to + * IEEE 802.3br, Clause 99. + */ +union cgxx_smux_mmsi_ctl_sta { + u64 u; + struct cgxx_smux_mmsi_ctl_sta_s { + u64 p_en : 1; + u64 dis_v : 1; + u64 afs : 2; + u64 v_sta : 3; + u64 tx_pactive : 1; + u64 reserved_8_31 : 24; + u64 v_time : 24; + u64 reserved_56_63 : 8; + } s; + /* struct cgxx_smux_mmsi_ctl_sta_s cn; */ +}; + +static inline u64 CGXX_SMUX_MMSI_CTL_STA(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_MMSI_CTL_STA(u64 a) +{ + return 0x20220 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_bad_col_ctrl + * + * CGX SMU RX Bad Column High Registers + */ +union cgxx_smux_rx_bad_col_ctrl { + u64 u; + struct cgxx_smux_rx_bad_col_ctrl_s { + u64 lane_rxc : 16; + u64 state : 3; + u64 val : 1; + u64 reserved_20_63 : 44; + } s; + /* struct cgxx_smux_rx_bad_col_ctrl_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_BAD_COL_CTRL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_BAD_COL_CTRL(u64 a) +{ + return 0x20060 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_bad_col_data_hi + * + * CGX SMU RX Bad Column Low Registers + */ +union cgxx_smux_rx_bad_col_data_hi { + u64 u; + struct cgxx_smux_rx_bad_col_data_hi_s { + u64 lane_rxd : 64; + } s; + /* struct cgxx_smux_rx_bad_col_data_hi_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_BAD_COL_DATA_HI(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_BAD_COL_DATA_HI(u64 a) +{ + return 0x20058 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_bad_col_data_lo + * + * CGX SMU RX Bad Column Low Registers + */ +union cgxx_smux_rx_bad_col_data_lo { + u64 u; + struct cgxx_smux_rx_bad_col_data_lo_s { + u64 lane_rxd : 64; + } s; + /* struct cgxx_smux_rx_bad_col_data_lo_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_BAD_COL_DATA_LO(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_BAD_COL_DATA_LO(u64 a) +{ + return 0x20050 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_ctl + * + * CGX SMU RX Control Registers + */ +union cgxx_smux_rx_ctl { + u64 u; + struct cgxx_smux_rx_ctl_s { + u64 status : 2; + u64 reserved_2_63 : 62; + } s; + /* struct cgxx_smux_rx_ctl_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_CTL(u64 a) +{ + return 0x20048 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_decision + * + * CGX SMU Packet Decision Registers This register specifies the byte + * count used to determine when to accept or to filter a packet. As each + * byte in a packet is received by CGX, the L2 byte count (i.e. the + * number of bytes from the beginning of the L2 header (DMAC)) is + * compared against CNT. In normal operation, the L2 header begins after + * the PREAMBLE + SFD (CGX()_SMU()_RX_FRM_CTL[PRE_CHK] = 1) and any + * optional UDD skip data (CGX()_SMU()_RX_UDD_SKP[LEN]). + */ +union cgxx_smux_rx_decision { + u64 u; + struct cgxx_smux_rx_decision_s { + u64 cnt : 5; + u64 reserved_5_63 : 59; + } s; + /* struct cgxx_smux_rx_decision_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_DECISION(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_DECISION(u64 a) +{ + return 0x20038 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_frm_chk + * + * CGX SMU RX Frame Check Registers The CSRs provide the enable bits for + * a subset of errors passed to CMR encoded. + */ +union cgxx_smux_rx_frm_chk { + u64 u; + struct cgxx_smux_rx_frm_chk_s { + u64 reserved_0_2 : 3; + u64 jabber : 1; + u64 fcserr_d : 1; + u64 fcserr_c : 1; + u64 reserved_6 : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 reserved_9_63 : 55; + } s; + /* struct cgxx_smux_rx_frm_chk_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_FRM_CHK(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_FRM_CHK(u64 a) +{ + return 0x20028 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_frm_ctl + * + * CGX SMU RX Frame Control Registers This register controls the handling + * of the frames. The [CTL_BCK] and [CTL_DRP] bits control how the + * hardware handles incoming PAUSE packets. The most common modes of + * operation: _ [CTL_BCK] = 1, [CTL_DRP] = 1: hardware handles everything + * _ [CTL_BCK] = 0, [CTL_DRP] = 0: software sees all PAUSE frames _ + * [CTL_BCK] = 0, [CTL_DRP] = 1: all PAUSE frames are completely ignored + * These control bits should be set to [CTL_BCK] = 0, [CTL_DRP] = 0 in + * half-duplex mode. Since PAUSE packets only apply to full duplex + * operation, any PAUSE packet would constitute an exception which should + * be handled by the processing cores. PAUSE packets should not be + * forwarded. + */ +union cgxx_smux_rx_frm_ctl { + u64 u; + struct cgxx_smux_rx_frm_ctl_s { + u64 pre_chk : 1; + u64 pre_strp : 1; + u64 ctl_drp : 1; + u64 ctl_bck : 1; + u64 ctl_mcst : 1; + u64 ctl_smac : 1; + u64 reserved_6_11 : 6; + u64 ptp_mode : 1; + u64 reserved_13_63 : 51; + } s; + /* struct cgxx_smux_rx_frm_ctl_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_FRM_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_FRM_CTL(u64 a) +{ + return 0x20020 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_int + * + * CGX SMU Receive Interrupt Registers SMU Interrupt Register. Internal: + * Exception conditions <9> and <4:0> can also set the rcv/opcode in + * the received packet's work queue entry. CGX()_SMU()_RX_FRM_CHK + * provides a bit mask for configuring which conditions set the error. + */ +union cgxx_smux_rx_int { + u64 u; + struct cgxx_smux_rx_int_s { + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 loc_fault : 1; + u64 rem_fault : 1; + u64 bad_seq : 1; + u64 bad_term : 1; + u64 hg2fld : 1; + u64 hg2cc : 1; + u64 badver : 1; + u64 badrsp : 1; + u64 reserved_14_63 : 50; + } s; + /* struct cgxx_smux_rx_int_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_INT(u64 a) +{ + return 0x20000 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_int_ena_w1c + * + * CGX SMU Receive Interrupt Enable Clear Registers This register clears + * interrupt enable bits. + */ +union cgxx_smux_rx_int_ena_w1c { + u64 u; + struct cgxx_smux_rx_int_ena_w1c_s { + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 loc_fault : 1; + u64 rem_fault : 1; + u64 bad_seq : 1; + u64 bad_term : 1; + u64 hg2fld : 1; + u64 hg2cc : 1; + u64 badver : 1; + u64 badrsp : 1; + u64 reserved_14_63 : 50; + } s; + /* struct cgxx_smux_rx_int_ena_w1c_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_INT_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_INT_ENA_W1C(u64 a) +{ + return 0x20010 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_int_ena_w1s + * + * CGX SMU Receive Interrupt Enable Set Registers This register sets + * interrupt enable bits. + */ +union cgxx_smux_rx_int_ena_w1s { + u64 u; + struct cgxx_smux_rx_int_ena_w1s_s { + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 loc_fault : 1; + u64 rem_fault : 1; + u64 bad_seq : 1; + u64 bad_term : 1; + u64 hg2fld : 1; + u64 hg2cc : 1; + u64 badver : 1; + u64 badrsp : 1; + u64 reserved_14_63 : 50; + } s; + /* struct cgxx_smux_rx_int_ena_w1s_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_INT_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_INT_ENA_W1S(u64 a) +{ + return 0x20018 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_int_w1s + * + * CGX SMU Receive Interrupt Set Registers This register sets interrupt + * bits. + */ +union cgxx_smux_rx_int_w1s { + u64 u; + struct cgxx_smux_rx_int_w1s_s { + u64 jabber : 1; + u64 fcserr : 1; + u64 rcverr : 1; + u64 skperr : 1; + u64 pcterr : 1; + u64 rsverr : 1; + u64 loc_fault : 1; + u64 rem_fault : 1; + u64 bad_seq : 1; + u64 bad_term : 1; + u64 hg2fld : 1; + u64 hg2cc : 1; + u64 badver : 1; + u64 badrsp : 1; + u64 reserved_14_63 : 50; + } s; + /* struct cgxx_smux_rx_int_w1s_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_INT_W1S(u64 a) +{ + return 0x20008 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_jabber + * + * CGX SMU Maximum Packet-Size Registers This register specifies the + * maximum size for packets, beyond which the SMU truncates. Internal: + * JABBER[CNT] is checked against the packet that arrives from SPU. The + * checking is performed before preamble is stripped or PTP is inserted. + * If present, preamble is counted as eight bytes of the incoming packet. + */ +union cgxx_smux_rx_jabber { + u64 u; + struct cgxx_smux_rx_jabber_s { + u64 cnt : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_smux_rx_jabber_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_JABBER(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_JABBER(u64 a) +{ + return 0x20030 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_udd_skp + * + * CGX SMU User-Defined Data Skip Registers Internal: (1) The skip bytes + * are part of the packet and will be sent down the NCB packet interface + * and will be handled by NIX. (2) The system can determine if the UDD + * bytes are included in the FCS check by using the FCSSEL field if the + * FCS check is enabled. (3) Assume that the preamble/sfd is always at + * the start of the frame even before UDD bytes. In most cases, there + * will be no preamble in these cases since it will be packet interface + * in direct communication to another packet interface (MAC to MAC) + * without a PHY involved. (4) We can still do address filtering and + * control packet filtering if the user desires. (5) In all cases, the + * UDD bytes will be sent down the packet interface as part of the + * packet. The UDD bytes are never stripped from the actual packet. + */ +union cgxx_smux_rx_udd_skp { + u64 u; + struct cgxx_smux_rx_udd_skp_s { + u64 len : 7; + u64 reserved_7 : 1; + u64 fcssel : 1; + u64 reserved_9_63 : 55; + } s; + /* struct cgxx_smux_rx_udd_skp_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_UDD_SKP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_UDD_SKP(u64 a) +{ + return 0x20040 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_wol_ctrl0 + * + * CGX SMU RX Wake-on-LAN Control 0 Registers + */ +union cgxx_smux_rx_wol_ctrl0 { + u64 u; + struct cgxx_smux_rx_wol_ctrl0_s { + u64 dmac : 48; + u64 pswd_len : 4; + u64 reserved_52_63 : 12; + } s; + /* struct cgxx_smux_rx_wol_ctrl0_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_WOL_CTRL0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_WOL_CTRL0(u64 a) +{ + return 0x20068 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_wol_ctrl1 + * + * CGX SMU RX Wake-on-LAN Control 1 Registers + */ +union cgxx_smux_rx_wol_ctrl1 { + u64 u; + struct cgxx_smux_rx_wol_ctrl1_s { + u64 pswd : 64; + } s; + /* struct cgxx_smux_rx_wol_ctrl1_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_WOL_CTRL1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_WOL_CTRL1(u64 a) +{ + return 0x20070 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_wol_int + * + * CGX SMU RX WOL Interrupt Registers These registers allow WOL + * interrupts to be sent to the control processor. + */ +union cgxx_smux_rx_wol_int { + u64 u; + struct cgxx_smux_rx_wol_int_s { + u64 wol_rcvd : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_smux_rx_wol_int_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_WOL_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_WOL_INT(u64 a) +{ + return 0x20078 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_wol_int_ena_w1c + * + * CGX SMU RX WOL Interrupt Enable Clear Registers This register clears + * interrupt enable bits. + */ +union cgxx_smux_rx_wol_int_ena_w1c { + u64 u; + struct cgxx_smux_rx_wol_int_ena_w1c_s { + u64 wol_rcvd : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_smux_rx_wol_int_ena_w1c_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_WOL_INT_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_WOL_INT_ENA_W1C(u64 a) +{ + return 0x20088 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_wol_int_ena_w1s + * + * CGX SMU RX WOL Interrupt Enable Set Registers This register sets + * interrupt enable bits. + */ +union cgxx_smux_rx_wol_int_ena_w1s { + u64 u; + struct cgxx_smux_rx_wol_int_ena_w1s_s { + u64 wol_rcvd : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_smux_rx_wol_int_ena_w1s_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_WOL_INT_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_WOL_INT_ENA_W1S(u64 a) +{ + return 0x20090 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_rx_wol_int_w1s + * + * CGX SMU RX WOL Interrupt Set Registers This register sets interrupt + * bits. + */ +union cgxx_smux_rx_wol_int_w1s { + u64 u; + struct cgxx_smux_rx_wol_int_w1s_s { + u64 wol_rcvd : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_smux_rx_wol_int_w1s_s cn; */ +}; + +static inline u64 CGXX_SMUX_RX_WOL_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_RX_WOL_INT_W1S(u64 a) +{ + return 0x20080 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_smac + * + * CGX SMU SMAC Registers + */ +union cgxx_smux_smac { + u64 u; + struct cgxx_smux_smac_s { + u64 smac : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_smux_smac_s cn; */ +}; + +static inline u64 CGXX_SMUX_SMAC(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_SMAC(u64 a) +{ + return 0x20108 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_append + * + * CGX SMU TX Append Control Registers For more details on the + * interactions between FCS and PAD, see also the description of + * CGX()_SMU()_TX_MIN_PKT[MIN_SIZE]. + */ +union cgxx_smux_tx_append { + u64 u; + struct cgxx_smux_tx_append_s { + u64 preamble : 1; + u64 pad : 1; + u64 fcs_d : 1; + u64 fcs_c : 1; + u64 reserved_4_63 : 60; + } s; + /* struct cgxx_smux_tx_append_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_APPEND(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_APPEND(u64 a) +{ + return 0x20100 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_ctl + * + * CGX SMU Transmit Control Registers + */ +union cgxx_smux_tx_ctl { + u64 u; + struct cgxx_smux_tx_ctl_s { + u64 dic_en : 1; + u64 uni_en : 1; + u64 x4a_dis : 1; + u64 mia_en : 1; + u64 ls : 2; + u64 ls_byp : 1; + u64 l2p_bp_conv : 1; + u64 hg_en : 1; + u64 hg_pause_hgi : 2; + u64 reserved_11_63 : 53; + } s; + /* struct cgxx_smux_tx_ctl_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_CTL(u64 a) +{ + return 0x20178 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_dack + * + * CGX SMU TX Drop Counters Registers + */ +union cgxx_smux_tx_dack { + u64 u; + struct cgxx_smux_tx_dack_s { + u64 dpi_sdrop_ack : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_smux_tx_dack_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_DACK(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_DACK(u64 a) +{ + return 0x201b0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_dcnt + * + * CGX SMU TX Drop Counters Registers + */ +union cgxx_smux_tx_dcnt { + u64 u; + struct cgxx_smux_tx_dcnt_s { + u64 dpi_sdrop_cnt : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_smux_tx_dcnt_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_DCNT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_DCNT(u64 a) +{ + return 0x201a8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_eee + * + * INTERNAL: CGX SMU TX EEE Configure Registers Resvered. Internal: + * These registers control when SMU TX requests to enter or exist LPI. + * Those registers take effect only when EEE is supported and enabled for + * a given LMAC. + */ +union cgxx_smux_tx_eee { + u64 u; + struct cgxx_smux_tx_eee_s { + u64 idle_thresh : 28; + u64 reserved_28 : 1; + u64 force_lpi : 1; + u64 wakeup : 1; + u64 auto_lpi : 1; + u64 idle_cnt : 28; + u64 reserved_60_61 : 2; + u64 tx_lpi_wake : 1; + u64 tx_lpi : 1; + } s; + /* struct cgxx_smux_tx_eee_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_EEE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_EEE(u64 a) +{ + return 0x20190 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_eee_timer_status + * + * INTERNAL: CGX SMU TX EEE TIMER STATUS Registers Reserved. Internal: + * These registers configure SMU TX EEE timing parameters. + */ +union cgxx_smux_tx_eee_timer_status { + u64 u; + struct cgxx_smux_tx_eee_timer_status_s { + u64 lpi_wake_cnt : 16; + u64 reserved_16_30 : 15; + u64 wake_timer_done : 1; + u64 link_ok_cnt : 30; + u64 reserved_62 : 1; + u64 link_timer_done : 1; + } s; + /* struct cgxx_smux_tx_eee_timer_status_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_EEE_TIMER_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_EEE_TIMER_STATUS(u64 a) +{ + return 0x201a0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_eee_timing + * + * INTERNAL: CGX SMU TX EEE TIMING Parameter Registers Reserved. + * Internal: These registers configure SMU TX EEE timing parameters. + */ +union cgxx_smux_tx_eee_timing { + u64 u; + struct cgxx_smux_tx_eee_timing_s { + u64 w_sys_tx_min : 16; + u64 reserved_16_31 : 16; + u64 link_ok_min : 30; + u64 reserved_62_63 : 2; + } s; + /* struct cgxx_smux_tx_eee_timing_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_EEE_TIMING(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_EEE_TIMING(u64 a) +{ + return 0x20198 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_ifg + * + * CGX SMU TX Interframe-Gap Cycles Registers Programming IFG1 and IFG2: + * * For XAUI/RXAUI/10G/25G/40G/50G/100G systems that require IEEE 802.3 + * compatibility, the [IFG1]+[IFG2] sum must be 12. * In loopback mode, + * the [IFG1]+[IFG2] of local and remote parties must match exactly; + * otherwise loopback FIFO will overrun: CGX()_SMU()_TX_INT[LB_OVRFLW]. * + * When CGX()_SMU()_TX_CTL[DIC_EN] is set, [IFG1]+[IFG2] sum must be at + * least 8. The behavior of smaller values is un-determined. * When + * CGX()_SMU()_TX_CTL[DIC_EN] is cleared, the minimum value of + * [IFG1]+[IFG2] is 1 for 40G/50G/100G LMAC_TYPE configurations and 5 for + * all other values. The behavior of smaller values is un-determined. + * Internal: When CGX()_SMU()_TX_CTL[DIC_EN] is set, SMU TX treats + * ([IFG1]+[IFG2]) < 8 as 8 for 40G/50G/100G MACs and ([IFG1]+[IFG2]) < + * 8 as 8 for other MACs. When CGX()_SMU()_TX_CTL[DIC_EN] is cleared, SMU + * TX can work correctly with any IFG1 and IFG2. + */ +union cgxx_smux_tx_ifg { + u64 u; + struct cgxx_smux_tx_ifg_s { + u64 ifg1 : 4; + u64 ifg2 : 4; + u64 mia_amt : 2; + u64 reserved_10_15 : 6; + u64 mia_cnt : 8; + u64 reserved_24_63 : 40; + } s; + /* struct cgxx_smux_tx_ifg_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_IFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_IFG(u64 a) +{ + return 0x20160 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_int + * + * CGX SMU TX Interrupt Registers + */ +union cgxx_smux_tx_int { + u64 u; + struct cgxx_smux_tx_int_s { + u64 undflw : 1; + u64 xchange : 1; + u64 fake_commit : 1; + u64 lb_undflw : 1; + u64 lb_ovrflw : 1; + u64 dpi_sdrop : 1; + u64 reserved_6_63 : 58; + } s; + /* struct cgxx_smux_tx_int_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_INT(u64 a) +{ + return 0x20140 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_int_ena_w1c + * + * CGX SMU TX Interrupt Enable Clear Registers This register clears + * interrupt enable bits. + */ +union cgxx_smux_tx_int_ena_w1c { + u64 u; + struct cgxx_smux_tx_int_ena_w1c_s { + u64 undflw : 1; + u64 xchange : 1; + u64 fake_commit : 1; + u64 lb_undflw : 1; + u64 lb_ovrflw : 1; + u64 dpi_sdrop : 1; + u64 reserved_6_63 : 58; + } s; + /* struct cgxx_smux_tx_int_ena_w1c_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_INT_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_INT_ENA_W1C(u64 a) +{ + return 0x20150 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_int_ena_w1s + * + * CGX SMU TX Interrupt Enable Set Registers This register sets interrupt + * enable bits. + */ +union cgxx_smux_tx_int_ena_w1s { + u64 u; + struct cgxx_smux_tx_int_ena_w1s_s { + u64 undflw : 1; + u64 xchange : 1; + u64 fake_commit : 1; + u64 lb_undflw : 1; + u64 lb_ovrflw : 1; + u64 dpi_sdrop : 1; + u64 reserved_6_63 : 58; + } s; + /* struct cgxx_smux_tx_int_ena_w1s_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_INT_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_INT_ENA_W1S(u64 a) +{ + return 0x20158 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_int_w1s + * + * CGX SMU TX Interrupt Set Registers This register sets interrupt bits. + */ +union cgxx_smux_tx_int_w1s { + u64 u; + struct cgxx_smux_tx_int_w1s_s { + u64 undflw : 1; + u64 xchange : 1; + u64 fake_commit : 1; + u64 lb_undflw : 1; + u64 lb_ovrflw : 1; + u64 dpi_sdrop : 1; + u64 reserved_6_63 : 58; + } s; + /* struct cgxx_smux_tx_int_w1s_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_INT_W1S(u64 a) +{ + return 0x20148 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_min_pkt + * + * CGX SMU TX Minimum-Size-Packet Registers Internal: [MIN_SIZE] less + * than 16 will be ignored by hardware which will use 16 instead. + */ +union cgxx_smux_tx_min_pkt { + u64 u; + struct cgxx_smux_tx_min_pkt_s { + u64 min_size : 8; + u64 reserved_8_63 : 56; + } s; + /* struct cgxx_smux_tx_min_pkt_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_MIN_PKT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_MIN_PKT(u64 a) +{ + return 0x20118 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_pause_pkt_dmac + * + * CGX SMU TX PAUSE-Packet DMAC-Field Registers This register provides + * the DMAC value that is placed in outbound PAUSE packets. + */ +union cgxx_smux_tx_pause_pkt_dmac { + u64 u; + struct cgxx_smux_tx_pause_pkt_dmac_s { + u64 dmac : 48; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_smux_tx_pause_pkt_dmac_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_PAUSE_PKT_DMAC(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_PAUSE_PKT_DMAC(u64 a) +{ + return 0x20168 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_pause_pkt_interval + * + * CGX SMU TX PAUSE-Packet Transmission-Interval Registers This register + * specifies how often PAUSE packets are sent. + */ +union cgxx_smux_tx_pause_pkt_interval { + u64 u; + struct cgxx_smux_tx_pause_pkt_interval_s { + u64 interval : 16; + u64 hg2_intra_interval : 16; + u64 hg2_intra_en : 1; + u64 reserved_33_63 : 31; + } s; + /* struct cgxx_smux_tx_pause_pkt_interval_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_PAUSE_PKT_INTERVAL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_PAUSE_PKT_INTERVAL(u64 a) +{ + return 0x20120 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_pause_pkt_time + * + * CGX SMU TX PAUSE Packet Time Registers + */ +union cgxx_smux_tx_pause_pkt_time { + u64 u; + struct cgxx_smux_tx_pause_pkt_time_s { + u64 p_time : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_smux_tx_pause_pkt_time_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_PAUSE_PKT_TIME(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_PAUSE_PKT_TIME(u64 a) +{ + return 0x20110 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_pause_pkt_type + * + * CGX SMU TX PAUSE-Packet P_TYPE-Field Registers This register provides + * the P_TYPE field that is placed in outbound PAUSE packets. + */ +union cgxx_smux_tx_pause_pkt_type { + u64 u; + struct cgxx_smux_tx_pause_pkt_type_s { + u64 p_type : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_smux_tx_pause_pkt_type_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_PAUSE_PKT_TYPE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_PAUSE_PKT_TYPE(u64 a) +{ + return 0x20170 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_pause_togo + * + * CGX SMU TX Time-to-Backpressure Registers + */ +union cgxx_smux_tx_pause_togo { + u64 u; + struct cgxx_smux_tx_pause_togo_s { + u64 p_time : 16; + u64 msg_time : 16; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_smux_tx_pause_togo_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_PAUSE_TOGO(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_PAUSE_TOGO(u64 a) +{ + return 0x20130 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_pause_zero + * + * CGX SMU TX PAUSE Zero Registers + */ +union cgxx_smux_tx_pause_zero { + u64 u; + struct cgxx_smux_tx_pause_zero_s { + u64 send : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_smux_tx_pause_zero_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_PAUSE_ZERO(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_PAUSE_ZERO(u64 a) +{ + return 0x20138 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_soft_pause + * + * CGX SMU TX Soft PAUSE Registers + */ +union cgxx_smux_tx_soft_pause { + u64 u; + struct cgxx_smux_tx_soft_pause_s { + u64 p_time : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_smux_tx_soft_pause_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_SOFT_PAUSE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_SOFT_PAUSE(u64 a) +{ + return 0x20128 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_smu#_tx_thresh + * + * CGX SMU TX Threshold Registers + */ +union cgxx_smux_tx_thresh { + u64 u; + struct cgxx_smux_tx_thresh_s { + u64 cnt : 12; + u64 reserved_12_15 : 4; + u64 dpi_thresh : 5; + u64 reserved_21_23 : 3; + u64 dpi_depth : 5; + u64 reserved_29_31 : 3; + u64 ecnt : 12; + u64 reserved_44_63 : 20; + } s; + /* struct cgxx_smux_tx_thresh_s cn; */ +}; + +static inline u64 CGXX_SMUX_TX_THRESH(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SMUX_TX_THRESH(u64 a) +{ + return 0x20180 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_an_adv + * + * CGX SPU Autonegotiation Advertisement Registers Software programs this + * register with the contents of the AN-link code word base page to be + * transmitted during autonegotiation. (See IEEE 802.3 section 73.6 for + * details.) Any write operations to this register prior to completion of + * autonegotiation, as indicated by CGX()_SPU()_AN_STATUS[AN_COMPLETE], + * should be followed by a renegotiation in order for the new values to + * take effect. Renegotiation is initiated by setting + * CGX()_SPU()_AN_CONTROL[AN_RESTART]. Once autonegotiation has + * completed, software can examine this register along with + * CGX()_SPU()_AN_LP_BASE to determine the highest common denominator + * technology. + */ +union cgxx_spux_an_adv { + u64 u; + struct cgxx_spux_an_adv_s { + u64 s : 5; + u64 e : 5; + u64 pause : 1; + u64 asm_dir : 1; + u64 xnp_able : 1; + u64 rf : 1; + u64 ack : 1; + u64 np : 1; + u64 t : 5; + u64 a1g_kx : 1; + u64 a10g_kx4 : 1; + u64 a10g_kr : 1; + u64 a40g_kr4 : 1; + u64 a40g_cr4 : 1; + u64 a100g_cr10 : 1; + u64 a100g_kp4 : 1; + u64 a100g_kr4 : 1; + u64 a100g_cr4 : 1; + u64 a25g_krs_crs : 1; + u64 a25g_kr_cr : 1; + u64 arsv : 12; + u64 a25g_rs_fec_req : 1; + u64 a25g_br_fec_req : 1; + u64 fec_able : 1; + u64 fec_req : 1; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_spux_an_adv_s cn; */ +}; + +static inline u64 CGXX_SPUX_AN_ADV(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_AN_ADV(u64 a) +{ + return 0x10198 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_an_bp_status + * + * CGX SPU Autonegotiation Backplane Ethernet & BASE-R Copper Status + * Registers The contents of this register are updated during + * autonegotiation and are valid when CGX()_SPU()_AN_STATUS[AN_COMPLETE] + * is set. At that time, one of the port type bits will be set depending + * on the AN priority resolution. The port types are listed in order of + * decreasing priority. If a BASE-R type is negotiated then [FEC] or + * [RS_FEC] will be set to indicate whether/which FEC operation has been + * negotiated and will be clear otherwise. + */ +union cgxx_spux_an_bp_status { + u64 u; + struct cgxx_spux_an_bp_status_s { + u64 bp_an_able : 1; + u64 n1g_kx : 1; + u64 n10g_kx4 : 1; + u64 n10g_kr : 1; + u64 n25g_kr1 : 1; + u64 n25g_cr1 : 1; + u64 n25g_krs_crs : 1; + u64 n25g_kr_cr : 1; + u64 n40g_kr4 : 1; + u64 n40g_cr4 : 1; + u64 n50g_kr2 : 1; + u64 n50g_cr2 : 1; + u64 n100g_cr10 : 1; + u64 n100g_kp4 : 1; + u64 n100g_kr4 : 1; + u64 n100g_cr4 : 1; + u64 fec : 1; + u64 rs_fec : 1; + u64 reserved_18_63 : 46; + } s; + /* struct cgxx_spux_an_bp_status_s cn; */ +}; + +static inline u64 CGXX_SPUX_AN_BP_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_AN_BP_STATUS(u64 a) +{ + return 0x101b8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_an_control + * + * CGX SPU Autonegotiation Control Registers + */ +union cgxx_spux_an_control { + u64 u; + struct cgxx_spux_an_control_s { + u64 reserved_0_8 : 9; + u64 an_restart : 1; + u64 reserved_10_11 : 2; + u64 an_en : 1; + u64 xnp_en : 1; + u64 reserved_14 : 1; + u64 an_reset : 1; + u64 an_arb_link_chk_en : 1; + u64 usx_an_arb_link_chk_en : 1; + u64 reserved_18_63 : 46; + } s; + /* struct cgxx_spux_an_control_s cn; */ +}; + +static inline u64 CGXX_SPUX_AN_CONTROL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_AN_CONTROL(u64 a) +{ + return 0x10188 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_an_lp_base + * + * CGX SPU Autonegotiation Link-Partner Base-Page Ability Registers This + * register captures the contents of the latest AN link code word base + * page received from the link partner during autonegotiation. (See IEEE + * 802.3 section 73.6 for details.) CGX()_SPU()_AN_STATUS[PAGE_RX] is set + * when this register is updated by hardware. + */ +union cgxx_spux_an_lp_base { + u64 u; + struct cgxx_spux_an_lp_base_s { + u64 s : 5; + u64 e : 5; + u64 pause : 1; + u64 asm_dir : 1; + u64 xnp_able : 1; + u64 rf : 1; + u64 ack : 1; + u64 np : 1; + u64 t : 5; + u64 a1g_kx : 1; + u64 a10g_kx4 : 1; + u64 a10g_kr : 1; + u64 a40g_kr4 : 1; + u64 a40g_cr4 : 1; + u64 a100g_cr10 : 1; + u64 a100g_kp4 : 1; + u64 a100g_kr4 : 1; + u64 a100g_cr4 : 1; + u64 a25g_krs_crs : 1; + u64 a25g_kr_cr : 1; + u64 arsv : 12; + u64 a25g_rs_fec_req : 1; + u64 a25g_br_fec_req : 1; + u64 fec_able : 1; + u64 fec_req : 1; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_spux_an_lp_base_s cn; */ +}; + +static inline u64 CGXX_SPUX_AN_LP_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_AN_LP_BASE(u64 a) +{ + return 0x101a0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_an_lp_xnp + * + * CGX SPU Autonegotiation Link Partner Extended Next Page Ability + * Registers This register captures the contents of the latest next page + * code word received from the link partner during autonegotiation, if + * any. See IEEE 802.3 section 73.7.7 for details. + */ +union cgxx_spux_an_lp_xnp { + u64 u; + struct cgxx_spux_an_lp_xnp_s { + u64 m_u : 11; + u64 toggle : 1; + u64 ack2 : 1; + u64 mp : 1; + u64 ack : 1; + u64 np : 1; + u64 u : 32; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_spux_an_lp_xnp_s cn; */ +}; + +static inline u64 CGXX_SPUX_AN_LP_XNP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_AN_LP_XNP(u64 a) +{ + return 0x101b0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_an_status + * + * CGX SPU Autonegotiation Status Registers + */ +union cgxx_spux_an_status { + u64 u; + struct cgxx_spux_an_status_s { + u64 lp_an_able : 1; + u64 reserved_1 : 1; + u64 link_status : 1; + u64 an_able : 1; + u64 rmt_flt : 1; + u64 an_complete : 1; + u64 page_rx : 1; + u64 xnp_stat : 1; + u64 reserved_8 : 1; + u64 prl_flt : 1; + u64 reserved_10_63 : 54; + } s; + /* struct cgxx_spux_an_status_s cn; */ +}; + +static inline u64 CGXX_SPUX_AN_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_AN_STATUS(u64 a) +{ + return 0x10190 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_an_xnp_tx + * + * CGX SPU Autonegotiation Extended Next Page Transmit Registers Software + * programs this register with the contents of the AN message next page + * or unformatted next page link code word to be transmitted during + * autonegotiation. Next page exchange occurs after the base link code + * words have been exchanged if either end of the link segment sets the + * NP bit to 1, indicating that it has at least one next page to send. + * Once initiated, next page exchange continues until both ends of the + * link segment set their NP bits to 0. See IEEE 802.3 section 73.7.7 for + * details. + */ +union cgxx_spux_an_xnp_tx { + u64 u; + struct cgxx_spux_an_xnp_tx_s { + u64 m_u : 11; + u64 toggle : 1; + u64 ack2 : 1; + u64 mp : 1; + u64 ack : 1; + u64 np : 1; + u64 u : 32; + u64 reserved_48_63 : 16; + } s; + /* struct cgxx_spux_an_xnp_tx_s cn; */ +}; + +static inline u64 CGXX_SPUX_AN_XNP_TX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_AN_XNP_TX(u64 a) +{ + return 0x101a8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_algn_status + * + * CGX SPU Multilane BASE-R PCS Alignment-Status Registers This register + * implements the IEEE 802.3 multilane BASE-R PCS alignment status 1-4 + * registers (3.50-3.53). It is valid only when the LPCS type is + * 40GBASE-R, 50GBASE-R, 100GBASE-R, (CGX()_CMR()_CONFIG[LMAC_TYPE] = + * CGX_LMAC_TYPES_E::FORTYG_R,FIFTYG_R,HUNDREDG_R), and always returns + * 0x0 for all other LPCS types. Service interfaces (lanes) 19-0 (100G) + * and 3-0 (all others) are mapped to PCS lanes 19-0 or 3-0 via + * CGX()_SPU()_BR_LANE_MAP()[LN_MAPPING]. For 100G, logical lane 0 fans + * out to service interfaces 0-4, logical lane 1 fans out to service + * interfaces 5-9, ... etc. For all other modes, logical lanes and + * service interfaces are identical. Logical interfaces (lanes) map to + * SerDes lanes via CGX()_CMR()_CONFIG[LANE_TO_SDS] (programmable). + */ +union cgxx_spux_br_algn_status { + u64 u; + struct cgxx_spux_br_algn_status_s { + u64 block_lock : 20; + u64 reserved_20_29 : 10; + u64 alignd : 1; + u64 reserved_31_40 : 10; + u64 marker_lock : 20; + u64 reserved_61_63 : 3; + } s; + /* struct cgxx_spux_br_algn_status_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_ALGN_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_ALGN_STATUS(u64 a) +{ + return 0x10050 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_lane_map# + * + * CGX SPU 40,50,100GBASE-R Lane-Mapping Registers This register + * implements the IEEE 802.3 lane 0-19 mapping registers (3.400-3.403). + * It is valid only when the LPCS type is 40GBASE-R, 50GBASE-R, + * 100GBASE-R, USXGMII (CGX()_CMR()_CONFIG[LMAC_TYPE]), and always + * returns 0x0 for all other LPCS types. The LNx_MAPPING field for each + * programmed PCS lane (called service interface in 802.3) is valid when + * that lane has achieved alignment marker lock on the receive side (i.e. + * the associated CGX()_SPU()_BR_ALGN_STATUS[MARKER_LOCK] = 1), and is + * invalid otherwise. When valid, it returns the actual detected receive + * PCS lane number based on the received alignment marker contents + * received on that service interface. In RS-FEC mode the LNx_MAPPING + * field is valid when that lane has achieved alignment marker lock on + * the receive side (i.e. the associated + * CGX()_SPU()_RSFEC_STATUS[AMPS_LOCK] = 1), and is invalid otherwise. + * When valid, it returns the actual detected receive FEC lane number + * based on the received alignment marker contents received on that + * logical lane therefore expect for RS-FEC that LNx_MAPPING = x. The + * mapping is flexible because IEEE 802.3 allows multilane BASE-R receive + * lanes to be re-ordered. Note that for the transmit side, each logical + * lane is mapped to a physical SerDes lane based on the programming of + * CGX()_CMR()_CONFIG[LANE_TO_SDS]. For the receive side, + * CGX()_CMR()_CONFIG[LANE_TO_SDS] specifies the logical lane to physical + * SerDes lane mapping, and this register specifies the service interface + * (or lane) to PCS lane mapping. + */ +union cgxx_spux_br_lane_mapx { + u64 u; + struct cgxx_spux_br_lane_mapx_s { + u64 ln_mapping : 6; + u64 reserved_6_63 : 58; + } s; + /* struct cgxx_spux_br_lane_mapx_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_LANE_MAPX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_LANE_MAPX(u64 a, u64 b) +{ + return 0x10600 + 0x40000 * a + 8 * b; +} + +/** + * Register (RSL) cgx#_spu#_br_pmd_control + * + * CGX SPU BASE-R PMD Control Registers + */ +union cgxx_spux_br_pmd_control { + u64 u; + struct cgxx_spux_br_pmd_control_s { + u64 train_restart : 1; + u64 train_en : 1; + u64 use_lane_poly : 1; + u64 max_wait_disable : 1; + u64 reserved_4_63 : 60; + } s; + struct cgxx_spux_br_pmd_control_cn96xx { + u64 train_restart : 1; + u64 train_en : 1; + u64 use_lane_poly : 1; + u64 reserved_3_63 : 61; + } cn96xx; + /* struct cgxx_spux_br_pmd_control_s cnf95xxp1; */ + /* struct cgxx_spux_br_pmd_control_cn96xx cnf95xxp2; */ +}; + +static inline u64 CGXX_SPUX_BR_PMD_CONTROL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_PMD_CONTROL(u64 a) +{ + return 0x100a8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_pmd_ld_cup + * + * INTERNAL:CGX SPU BASE-R PMD Local Device Coefficient Update Registers + * This register implements MDIO register 1.154 of 802.3-2012 Section 5 + * CL45 for 10GBASE-R and and of 802.3by-2016 CL45 for 25GBASE-R. Note + * that for 10G, 25G LN0_ only is used. It implements MDIO registers + * 1.1300-1.1303 for all other BASE-R modes (40G, 50G, 100G) per + * 802.3bj-2014 CL45. Note that for 50G LN0_ and LN1_ only are used. The + * fields in this register are read/write even though they are specified + * as read-only in 802.3. The register is automatically cleared at the + * start of training. When link training is in progress, each field + * reflects the contents of the coefficient update field in the + * associated lane's outgoing training frame. If + * CGX()_SPU_DBG_CONTROL[BR_PMD_TRAIN_SOFT_EN] is set, then this register + * must be updated by software during link training and hardware updates + * are disabled. If CGX()_SPU_DBG_CONTROL[BR_PMD_TRAIN_SOFT_EN] is clear, + * this register is automatically updated by hardware, and it should not + * be written by software. The lane fields in this register are indexed + * by logical PCS lane ID. + */ +union cgxx_spux_br_pmd_ld_cup { + u64 u; + struct cgxx_spux_br_pmd_ld_cup_s { + u64 ln0_cup : 16; + u64 ln1_cup : 16; + u64 ln2_cup : 16; + u64 ln3_cup : 16; + } s; + /* struct cgxx_spux_br_pmd_ld_cup_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_PMD_LD_CUP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_PMD_LD_CUP(u64 a) +{ + return 0x100c8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_pmd_ld_rep + * + * INTERNAL:CGX SPU BASE-R PMD Local Device Status Report Registers This + * register implements MDIO register 1.155 of 802.3-2012 Section 5 CL45 + * for 10GBASE-R and and of 802.3by-2016 CL45 for 25GBASE-R. Note that + * for 10G, 25G LN0_ only is used. It implements MDIO registers + * 1.1400-1.1403 for all other BASE-R modes (40G, 50G, 100G) per + * 802.3bj-2014 CL45. Note that for 50G LN0_ and LN1_ only are used. The + * fields in this register are read/write even though they are specified + * as read-only in 802.3. The register is automatically cleared at the + * start of training. Each field reflects the contents of the status + * report field in the associated lane's outgoing training frame. If + * CGX()_SPU_DBG_CONTROL[BR_PMD_TRAIN_SOFT_EN] is set, then this register + * must be updated by software during link training and hardware updates + * are disabled. If CGX()_SPU_DBG_CONTROL[BR_PMD_TRAIN_SOFT_EN] is clear, + * this register is automatically updated by hardware, and it should not + * be written by software. The lane fields in this register are indexed + * by logical PCS lane ID. + */ +union cgxx_spux_br_pmd_ld_rep { + u64 u; + struct cgxx_spux_br_pmd_ld_rep_s { + u64 ln0_rep : 16; + u64 ln1_rep : 16; + u64 ln2_rep : 16; + u64 ln3_rep : 16; + } s; + /* struct cgxx_spux_br_pmd_ld_rep_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_PMD_LD_REP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_PMD_LD_REP(u64 a) +{ + return 0x100d0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_pmd_lp_cup + * + * INTERNAL:CGX SPU BASE-R PMD Link Partner Coefficient Update Registers + * This register implements MDIO register 1.152 of 802.3-2012 Section 5 + * CL45 for 10GBASE-R and and of 802.3by-2016 CL45 for 25GBASE-R. Note + * that for 10G, 25G LN0_ only is used. It implements MDIO registers + * 1.1100-1.1103 for all other BASE-R modes (40G, 50G, 100G) per + * 802.3bj-2014 CL45. Note that for 50G LN0_ and LN1_ only are used. The + * register is automatically cleared at the start of training. Each field + * reflects the contents of the coefficient update field in the lane's + * most recently received training frame. This register should not be + * written when link training is enabled, i.e. when + * CGX()_SPU()_BR_PMD_CONTROL[TRAIN_EN] is set. The lane fields in this + * register are indexed by logical PCS lane ID. + */ +union cgxx_spux_br_pmd_lp_cup { + u64 u; + struct cgxx_spux_br_pmd_lp_cup_s { + u64 ln0_cup : 16; + u64 ln1_cup : 16; + u64 ln2_cup : 16; + u64 ln3_cup : 16; + } s; + /* struct cgxx_spux_br_pmd_lp_cup_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_PMD_LP_CUP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_PMD_LP_CUP(u64 a) +{ + return 0x100b8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_pmd_lp_rep + * + * INTERNAL:CGX SPU BASE-R PMD Link Partner Status Report Registers This + * register implements MDIO register 1.153 of 802.3-2012 Section 5 CL45 + * for 10GBASE-R and and of 802.3by-2016 CL45 for 25GBASE-R. Note that + * for 10G, 25G LN0_ only is used. It implements MDIO registers + * 1.1200-1.1203 for all other BASE-R modes (40G, 50G, 100G) per + * 802.3bj-2014 CL45. Note that for 50G LN0_ and LN1_ only are used. The + * register is automatically cleared at the start of training. Each field + * reflects the contents of the coefficient update field in the lane's + * most recently received training frame. This register should not be + * written when link training is enabled, i.e. when + * CGX()_SPU()_BR_PMD_CONTROL[TRAIN_EN] is set. The lane fields in this + * register are indexed by logical PCS lane ID. + */ +union cgxx_spux_br_pmd_lp_rep { + u64 u; + struct cgxx_spux_br_pmd_lp_rep_s { + u64 ln0_rep : 16; + u64 ln1_rep : 16; + u64 ln2_rep : 16; + u64 ln3_rep : 16; + } s; + /* struct cgxx_spux_br_pmd_lp_rep_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_PMD_LP_REP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_PMD_LP_REP(u64 a) +{ + return 0x100c0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_pmd_status + * + * INTERNAL:CGX SPU BASE-R PMD Status Registers The lane fields in this + * register are indexed by logical PCS lane ID. The lane 0 field (LN0_*) + * is valid for 10GBASE-R, 25GBASE-R, 40GBASE-R, 50GBASE-R and + * 100GBASE-R. The lane 1 field (LN1_*) is valid for 40GBASE-R, 50GBASE-R + * and 100GBASE-R. The remaining fields (LN2_*, LN3_*) are only valid for + * 40GBASE-R and 100GBASE-R. + */ +union cgxx_spux_br_pmd_status { + u64 u; + struct cgxx_spux_br_pmd_status_s { + u64 ln0_train_status : 4; + u64 ln1_train_status : 4; + u64 ln2_train_status : 4; + u64 ln3_train_status : 4; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_spux_br_pmd_status_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_PMD_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_PMD_STATUS(u64 a) +{ + return 0x100b0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_status1 + * + * CGX SPU BASE-R Status 1 Registers + */ +union cgxx_spux_br_status1 { + u64 u; + struct cgxx_spux_br_status1_s { + u64 blk_lock : 1; + u64 hi_ber : 1; + u64 prbs31 : 1; + u64 prbs9 : 1; + u64 reserved_4_11 : 8; + u64 rcv_lnk : 1; + u64 reserved_13_63 : 51; + } s; + /* struct cgxx_spux_br_status1_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_STATUS1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_STATUS1(u64 a) +{ + return 0x10030 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_status2 + * + * CGX SPU BASE-R Status 2 Registers This register implements a + * combination of the following IEEE 802.3 registers: * BASE-R PCS status + * 2 (MDIO address 3.33). * BASE-R BER high-order counter (MDIO address + * 3.44). * Errored-blocks high-order counter (MDIO address 3.45). Note + * that the relative locations of some fields have been moved from IEEE + * 802.3 in order to make the register layout more software friendly: the + * BER counter high-order and low-order bits from sections 3.44 and 3.33 + * have been combined into the contiguous, 22-bit [BER_CNT] field; + * likewise, the errored-blocks counter high-order and low-order bits + * from section 3.45 have been combined into the contiguous, 22-bit + * [ERR_BLKS] field. + */ +union cgxx_spux_br_status2 { + u64 u; + struct cgxx_spux_br_status2_s { + u64 reserved_0_13 : 14; + u64 latched_ber : 1; + u64 latched_lock : 1; + u64 ber_cnt : 22; + u64 reserved_38_39 : 2; + u64 err_blks : 22; + u64 reserved_62_63 : 2; + } s; + /* struct cgxx_spux_br_status2_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_STATUS2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_STATUS2(u64 a) +{ + return 0x10038 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_tp_control + * + * CGX SPU BASE-R Test-Pattern Control Registers Refer to the test + * pattern methodology described in 802.3 sections 49.2.8 and 82.2.10. + */ +union cgxx_spux_br_tp_control { + u64 u; + struct cgxx_spux_br_tp_control_s { + u64 dp_sel : 1; + u64 tp_sel : 1; + u64 rx_tp_en : 1; + u64 tx_tp_en : 1; + u64 prbs31_tx : 1; + u64 prbs31_rx : 1; + u64 prbs9_tx : 1; + u64 scramble_tp : 2; + u64 pr_tp_data_type : 1; + u64 reserved_10_63 : 54; + } s; + /* struct cgxx_spux_br_tp_control_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_TP_CONTROL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_TP_CONTROL(u64 a) +{ + return 0x10040 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_tp_err_cnt + * + * CGX SPU BASE-R Test-Pattern Error-Count Registers This register + * provides the BASE-R PCS test-pattern error counter. + */ +union cgxx_spux_br_tp_err_cnt { + u64 u; + struct cgxx_spux_br_tp_err_cnt_s { + u64 err_cnt : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_spux_br_tp_err_cnt_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_TP_ERR_CNT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_TP_ERR_CNT(u64 a) +{ + return 0x10048 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_tp_seed_a + * + * CGX SPU BASE-R Test-Pattern Seed A Registers Refer to the test pattern + * methodology described in 802.3 sections 49.2.8 and 82.2.10. + */ +union cgxx_spux_br_tp_seed_a { + u64 u; + struct cgxx_spux_br_tp_seed_a_s { + u64 tp_seed_a : 58; + u64 reserved_58_63 : 6; + } s; + /* struct cgxx_spux_br_tp_seed_a_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_TP_SEED_A(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_TP_SEED_A(u64 a) +{ + return 0x10060 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_br_tp_seed_b + * + * CGX SPU BASE-R Test-Pattern Seed B Registers Refer to the test pattern + * methodology described in 802.3 sections 49.2.8 and 82.2.10. + */ +union cgxx_spux_br_tp_seed_b { + u64 u; + struct cgxx_spux_br_tp_seed_b_s { + u64 tp_seed_b : 58; + u64 reserved_58_63 : 6; + } s; + /* struct cgxx_spux_br_tp_seed_b_s cn; */ +}; + +static inline u64 CGXX_SPUX_BR_TP_SEED_B(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BR_TP_SEED_B(u64 a) +{ + return 0x10068 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_bx_status + * + * CGX SPU BASE-X Status Registers + */ +union cgxx_spux_bx_status { + u64 u; + struct cgxx_spux_bx_status_s { + u64 lsync : 4; + u64 reserved_4_10 : 7; + u64 pattst : 1; + u64 alignd : 1; + u64 reserved_13_63 : 51; + } s; + /* struct cgxx_spux_bx_status_s cn; */ +}; + +static inline u64 CGXX_SPUX_BX_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_BX_STATUS(u64 a) +{ + return 0x10028 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_control1 + * + * CGX SPU Control 1 Registers + */ +union cgxx_spux_control1 { + u64 u; + struct cgxx_spux_control1_s { + u64 reserved_0_1 : 2; + u64 spd : 4; + u64 spdsel0 : 1; + u64 reserved_7_10 : 4; + u64 lo_pwr : 1; + u64 reserved_12 : 1; + u64 spdsel1 : 1; + u64 loopbck : 1; + u64 reset : 1; + u64 usxgmii_type : 3; + u64 usxgmii_rate : 3; + u64 disable_am : 1; + u64 reserved_23_63 : 41; + } s; + struct cgxx_spux_control1_cn96xxp1 { + u64 reserved_0_1 : 2; + u64 spd : 4; + u64 spdsel0 : 1; + u64 reserved_7_10 : 4; + u64 lo_pwr : 1; + u64 reserved_12 : 1; + u64 spdsel1 : 1; + u64 loopbck : 1; + u64 reset : 1; + u64 usxgmii_type : 3; + u64 usxgmii_rate : 3; + u64 reserved_22_63 : 42; + } cn96xxp1; + /* struct cgxx_spux_control1_s cn96xxp3; */ + /* struct cgxx_spux_control1_cn96xxp1 cnf95xxp1; */ + struct cgxx_spux_control1_cnf95xxp2 { + u64 reserved_0_1 : 2; + u64 spd : 4; + u64 spdsel0 : 1; + u64 reserved_7_10 : 4; + u64 lo_pwr : 1; + u64 reserved_12 : 1; + u64 spdsel1 : 1; + u64 loopbck : 1; + u64 reset : 1; + u64 usxgmii_type : 3; + u64 usxgmii_rate : 3; + u64 reserved_22 : 1; + u64 reserved_23_63 : 41; + } cnf95xxp2; +}; + +static inline u64 CGXX_SPUX_CONTROL1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_CONTROL1(u64 a) +{ + return 0x10000 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_control2 + * + * CGX SPU Control 2 Registers + */ +union cgxx_spux_control2 { + u64 u; + struct cgxx_spux_control2_s { + u64 pcs_type : 4; + u64 reserved_4_63 : 60; + } s; + /* struct cgxx_spux_control2_s cn; */ +}; + +static inline u64 CGXX_SPUX_CONTROL2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_CONTROL2(u64 a) +{ + return 0x10018 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_fec_abil + * + * CGX SPU Forward Error Correction Ability Registers + */ +union cgxx_spux_fec_abil { + u64 u; + struct cgxx_spux_fec_abil_s { + u64 fec_abil : 1; + u64 err_abil : 1; + u64 reserved_2_63 : 62; + } s; + /* struct cgxx_spux_fec_abil_s cn; */ +}; + +static inline u64 CGXX_SPUX_FEC_ABIL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_FEC_ABIL(u64 a) +{ + return 0x100d8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_fec_control + * + * CGX SPU Forward Error Correction Control Registers + */ +union cgxx_spux_fec_control { + u64 u; + struct cgxx_spux_fec_control_s { + u64 fec_en : 2; + u64 err_en : 1; + u64 fec_byp_ind_en : 1; + u64 fec_byp_cor_en : 1; + u64 reserved_5_63 : 59; + } s; + /* struct cgxx_spux_fec_control_s cn; */ +}; + +static inline u64 CGXX_SPUX_FEC_CONTROL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_FEC_CONTROL(u64 a) +{ + return 0x100e0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_fec_ln#_rsfec_err + * + * CGX SPU Reed-Solomon FEC Symbol Error Counter for FEC Lanes 0-3 + * Registers This register is valid only when Reed-Solomon FEC is + * enabled. The symbol error counters are defined in 802.3 section + * 91.6.11 (for 100G and extended to 50G) and 802.3by-2016 section + * 108.6.9 (for 25G and extended to USXGMII). The counter is reset to all + * zeros when the register is read, and held at all ones in case of + * overflow. The reset operation takes precedence over the increment + * operation; if the register is read on the same clock cycle as an + * increment operation, the counter is reset to all zeros and the + * increment operation is lost. The counters are writable for test + * purposes, rather than read-only as specified in IEEE 802.3. + */ +union cgxx_spux_fec_lnx_rsfec_err { + u64 u; + struct cgxx_spux_fec_lnx_rsfec_err_s { + u64 symb_err_cnt : 32; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_spux_fec_lnx_rsfec_err_s cn; */ +}; + +static inline u64 CGXX_SPUX_FEC_LNX_RSFEC_ERR(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_FEC_LNX_RSFEC_ERR(u64 a, u64 b) +{ + return 0x10900 + 0x40000 * a + 8 * b; +} + +/** + * Register (RSL) cgx#_spu#_int + * + * CGX SPU Interrupt Registers + */ +union cgxx_spux_int { + u64 u; + struct cgxx_spux_int_s { + u64 rx_link_up : 1; + u64 rx_link_down : 1; + u64 err_blk : 1; + u64 bitlckls : 1; + u64 synlos : 1; + u64 algnlos : 1; + u64 dbg_sync : 1; + u64 bip_err : 1; + u64 fec_corr : 1; + u64 fec_uncorr : 1; + u64 an_page_rx : 1; + u64 an_link_good : 1; + u64 an_complete : 1; + u64 training_done : 1; + u64 training_failure : 1; + u64 fec_align_status : 1; + u64 rsfec_corr : 1; + u64 rsfec_uncorr : 1; + u64 hi_ser : 1; + u64 usx_an_lnk_st : 1; + u64 usx_an_cpt : 1; + u64 reserved_21_63 : 43; + } s; + /* struct cgxx_spux_int_s cn; */ +}; + +static inline u64 CGXX_SPUX_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_INT(u64 a) +{ + return 0x10220 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_int_ena_w1c + * + * CGX SPU Interrupt Enable Clear Registers This register clears + * interrupt enable bits. + */ +union cgxx_spux_int_ena_w1c { + u64 u; + struct cgxx_spux_int_ena_w1c_s { + u64 rx_link_up : 1; + u64 rx_link_down : 1; + u64 err_blk : 1; + u64 bitlckls : 1; + u64 synlos : 1; + u64 algnlos : 1; + u64 dbg_sync : 1; + u64 bip_err : 1; + u64 fec_corr : 1; + u64 fec_uncorr : 1; + u64 an_page_rx : 1; + u64 an_link_good : 1; + u64 an_complete : 1; + u64 training_done : 1; + u64 training_failure : 1; + u64 fec_align_status : 1; + u64 rsfec_corr : 1; + u64 rsfec_uncorr : 1; + u64 hi_ser : 1; + u64 usx_an_lnk_st : 1; + u64 usx_an_cpt : 1; + u64 reserved_21_63 : 43; + } s; + /* struct cgxx_spux_int_ena_w1c_s cn; */ +}; + +static inline u64 CGXX_SPUX_INT_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_INT_ENA_W1C(u64 a) +{ + return 0x10230 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_int_ena_w1s + * + * CGX SPU Interrupt Enable Set Registers This register sets interrupt + * enable bits. + */ +union cgxx_spux_int_ena_w1s { + u64 u; + struct cgxx_spux_int_ena_w1s_s { + u64 rx_link_up : 1; + u64 rx_link_down : 1; + u64 err_blk : 1; + u64 bitlckls : 1; + u64 synlos : 1; + u64 algnlos : 1; + u64 dbg_sync : 1; + u64 bip_err : 1; + u64 fec_corr : 1; + u64 fec_uncorr : 1; + u64 an_page_rx : 1; + u64 an_link_good : 1; + u64 an_complete : 1; + u64 training_done : 1; + u64 training_failure : 1; + u64 fec_align_status : 1; + u64 rsfec_corr : 1; + u64 rsfec_uncorr : 1; + u64 hi_ser : 1; + u64 usx_an_lnk_st : 1; + u64 usx_an_cpt : 1; + u64 reserved_21_63 : 43; + } s; + /* struct cgxx_spux_int_ena_w1s_s cn; */ +}; + +static inline u64 CGXX_SPUX_INT_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_INT_ENA_W1S(u64 a) +{ + return 0x10238 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_int_w1s + * + * CGX SPU Interrupt Set Registers This register sets interrupt bits. + */ +union cgxx_spux_int_w1s { + u64 u; + struct cgxx_spux_int_w1s_s { + u64 rx_link_up : 1; + u64 rx_link_down : 1; + u64 err_blk : 1; + u64 bitlckls : 1; + u64 synlos : 1; + u64 algnlos : 1; + u64 dbg_sync : 1; + u64 bip_err : 1; + u64 fec_corr : 1; + u64 fec_uncorr : 1; + u64 an_page_rx : 1; + u64 an_link_good : 1; + u64 an_complete : 1; + u64 training_done : 1; + u64 training_failure : 1; + u64 fec_align_status : 1; + u64 rsfec_corr : 1; + u64 rsfec_uncorr : 1; + u64 hi_ser : 1; + u64 usx_an_lnk_st : 1; + u64 usx_an_cpt : 1; + u64 reserved_21_63 : 43; + } s; + /* struct cgxx_spux_int_w1s_s cn; */ +}; + +static inline u64 CGXX_SPUX_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_INT_W1S(u64 a) +{ + return 0x10228 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_ln#_br_bip_err_cnt + * + * CGX SPU 40,50,100GBASE-R BIP Error-Counter Registers This register + * implements the IEEE 802.3 BIP error-counter registers for PCS lanes + * 0-19 (3.200-3.203). It is valid only when the LPCS type is 40GBASE-R, + * 50GBASE-R, 100GBASE-R, (CGX()_CMR()_CONFIG[LMAC_TYPE]), and always + * returns 0x0 for all other LPCS types. The counters are indexed by the + * RX PCS lane number based on the alignment marker detected on each lane + * and captured in CGX()_SPU()_BR_LANE_MAP(). Each counter counts the BIP + * errors for its PCS lane, and is held at all ones in case of overflow. + * The counters are reset to all zeros when this register is read by + * software. The reset operation takes precedence over the increment + * operation; if the register is read on the same clock cycle as an + * increment operation, the counter is reset to all zeros and the + * increment operation is lost. The counters are writable for test + * purposes, rather than read-only as specified in IEEE 802.3. + */ +union cgxx_spux_lnx_br_bip_err_cnt { + u64 u; + struct cgxx_spux_lnx_br_bip_err_cnt_s { + u64 bip_err_cnt : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_spux_lnx_br_bip_err_cnt_s cn; */ +}; + +static inline u64 CGXX_SPUX_LNX_BR_BIP_ERR_CNT(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_LNX_BR_BIP_ERR_CNT(u64 a, u64 b) +{ + return 0x10500 + 0x40000 * a + 8 * b; +} + +/** + * Register (RSL) cgx#_spu#_ln#_fec_corr_blks + * + * CGX SPU FEC Corrected-Blocks Counters 0-19 Registers This register is + * valid only when the LPCS type is BASE-R + * (CGX()_CMR()_CONFIG[LMAC_TYPE]) and applies to BASE-R FEC and Reed- + * Solomon FEC (RS-FEC). When BASE-R FEC is enabled, the FEC corrected- + * block counters are defined in IEEE 802.3 section 74.8.4.1. Each + * corrected-blocks counter increments by one for a corrected FEC block, + * i.e. an FEC block that has been received with invalid parity on the + * associated PCS lane and has been corrected by the FEC decoder. The + * counter is reset to all zeros when the register is read, and held at + * all ones in case of overflow. The reset operation takes precedence + * over the increment operation; if the register is read on the same + * clock cycle as an increment operation, the counter is reset to all + * zeros and the increment operation is lost. The counters are writable + * for test purposes, rather than read-only as specified in IEEE 802.3. + */ +union cgxx_spux_lnx_fec_corr_blks { + u64 u; + struct cgxx_spux_lnx_fec_corr_blks_s { + u64 ln_corr_blks : 32; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_spux_lnx_fec_corr_blks_s cn; */ +}; + +static inline u64 CGXX_SPUX_LNX_FEC_CORR_BLKS(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_LNX_FEC_CORR_BLKS(u64 a, u64 b) +{ + return 0x10700 + 0x40000 * a + 8 * b; +} + +/** + * Register (RSL) cgx#_spu#_ln#_fec_uncorr_blks + * + * CGX SPU FEC Uncorrected-Blocks Counters 0-19 Registers This register + * is valid only when the LPCS type is BASE-R + * (CGX()_CMR()_CONFIG[LMAC_TYPE]) and applies to BASE-R FEC and Reed- + * Solomon FEC (RS-FEC). When BASE-R FEC is enabled, the FEC corrected- + * block counters are defined in IEEE 802.3 section 74.8.4.2. Each + * uncorrected-blocks counter increments by one for an uncorrected FEC + * block, i.e. an FEC block that has been received with invalid parity on + * the associated PCS lane and has not been corrected by the FEC decoder. + * The counter is reset to all zeros when the register is read, and held + * at all ones in case of overflow. The reset operation takes precedence + * over the increment operation; if the register is read on the same + * clock cycle as an increment operation, the counter is reset to all + * zeros and the increment operation is lost. The counters are writable + * for test purposes, rather than read-only as specified in IEEE 802.3. + */ +union cgxx_spux_lnx_fec_uncorr_blks { + u64 u; + struct cgxx_spux_lnx_fec_uncorr_blks_s { + u64 ln_uncorr_blks : 32; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_spux_lnx_fec_uncorr_blks_s cn; */ +}; + +static inline u64 CGXX_SPUX_LNX_FEC_UNCORR_BLKS(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_LNX_FEC_UNCORR_BLKS(u64 a, u64 b) +{ + return 0x10800 + 0x40000 * a + 8 * b; +} + +/** + * Register (RSL) cgx#_spu#_lpcs_states + * + * CGX SPU BASE-X Transmit/Receive States Registers + */ +union cgxx_spux_lpcs_states { + u64 u; + struct cgxx_spux_lpcs_states_s { + u64 deskew_sm : 3; + u64 reserved_3 : 1; + u64 deskew_am_found : 20; + u64 bx_rx_sm : 2; + u64 reserved_26_27 : 2; + u64 br_rx_sm : 3; + u64 reserved_31_63 : 33; + } s; + /* struct cgxx_spux_lpcs_states_s cn; */ +}; + +static inline u64 CGXX_SPUX_LPCS_STATES(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_LPCS_STATES(u64 a) +{ + return 0x10208 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_misc_control + * + * CGX SPU Miscellaneous Control Registers "* RX logical PCS lane + * polarity vector <3:0> = [XOR_RXPLRT]<3:0> ^ {4{[RXPLRT]}}. * TX + * logical PCS lane polarity vector <3:0> = [XOR_TXPLRT]<3:0> ^ + * {4{[TXPLRT]}}. In short, keep [RXPLRT] and [TXPLRT] cleared, and use + * [XOR_RXPLRT] and [XOR_TXPLRT] fields to define the polarity per + * logical PCS lane. Only bit 0 of vector is used for 10GBASE-R, and only + * bits 1:0 of vector are used for RXAUI." + */ +union cgxx_spux_misc_control { + u64 u; + struct cgxx_spux_misc_control_s { + u64 txplrt : 1; + u64 rxplrt : 1; + u64 xor_txplrt : 4; + u64 xor_rxplrt : 4; + u64 intlv_rdisp : 1; + u64 skip_after_term : 1; + u64 rx_packet_dis : 1; + u64 rx_edet_signal_ok : 1; + u64 reserved_14_63 : 50; + } s; + /* struct cgxx_spux_misc_control_s cn; */ +}; + +static inline u64 CGXX_SPUX_MISC_CONTROL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_MISC_CONTROL(u64 a) +{ + return 0x10218 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_rsfec_corr + * + * CGX SPU Reed-Solomon FEC Corrected Codeword Counter Register This + * register implements the IEEE 802.3 RS-FEC corrected codewords counter + * described in 802.3 section 91.6.8 (for 100G and extended to 50G) and + * 802.3by-2016 section 108.6.7 (for 25G and extended to USXGMII). + */ +union cgxx_spux_rsfec_corr { + u64 u; + struct cgxx_spux_rsfec_corr_s { + u64 cw_cnt : 32; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_spux_rsfec_corr_s cn; */ +}; + +static inline u64 CGXX_SPUX_RSFEC_CORR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_RSFEC_CORR(u64 a) +{ + return 0x10088 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_rsfec_status + * + * CGX SPU Reed-Solomon FEC Status Registers This register implements the + * IEEE 802.3 RS-FEC status and lane mapping registers as described in + * 802.3 section 91.6 (for 100G and extended to 50G) and 802.3by-2016 + * section 108-6 (for 25G and extended to USXGMII). + */ +union cgxx_spux_rsfec_status { + u64 u; + struct cgxx_spux_rsfec_status_s { + u64 fec_lane_mapping : 8; + u64 fec_align_status : 1; + u64 amps_lock : 4; + u64 hi_ser : 1; + u64 fec_byp_ind_abil : 1; + u64 fec_byp_cor_abil : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_spux_rsfec_status_s cn; */ +}; + +static inline u64 CGXX_SPUX_RSFEC_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_RSFEC_STATUS(u64 a) +{ + return 0x10080 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_rsfec_uncorr + * + * CGX SPU Reed-Solomon FEC Uncorrected Codeword Counter Register This + * register implements the IEEE 802.3 RS-FEC uncorrected codewords + * counter described in 802.3 section 91.6.9 (for 100G and extended to + * 50G) and 802.3by-2016 section 108.6.8 (for 25G and extended to + * USXGMII). + */ +union cgxx_spux_rsfec_uncorr { + u64 u; + struct cgxx_spux_rsfec_uncorr_s { + u64 cw_cnt : 32; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_spux_rsfec_uncorr_s cn; */ +}; + +static inline u64 CGXX_SPUX_RSFEC_UNCORR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_RSFEC_UNCORR(u64 a) +{ + return 0x10090 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_rx_eee_wake + * + * INTERNAL: CGX SPU RX EEE Wake Error Counter Registers Reserved. + * Internal: A counter that is incremented each time that the LPI receive + * state diagram enters the RX_WTF state indicating that a wake time + * fault has been detected. + */ +union cgxx_spux_rx_eee_wake { + u64 u; + struct cgxx_spux_rx_eee_wake_s { + u64 wtf_error_counter : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_spux_rx_eee_wake_s cn; */ +}; + +static inline u64 CGXX_SPUX_RX_EEE_WAKE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_RX_EEE_WAKE(u64 a) +{ + return 0x103e0 + 8 * a; +} + +/** + * Register (RSL) cgx#_spu#_rx_lpi_timing + * + * INTERNAL: CGX SPU RX EEE LPI Timing Parameters Registers Reserved. + * Internal: This register specifies receiver LPI timing parameters Tqr, + * Twr and Twtf. + */ +union cgxx_spux_rx_lpi_timing { + u64 u; + struct cgxx_spux_rx_lpi_timing_s { + u64 twtf : 20; + u64 twr : 20; + u64 tqr : 20; + u64 reserved_60_61 : 2; + u64 rx_lpi_fw : 1; + u64 rx_lpi_en : 1; + } s; + /* struct cgxx_spux_rx_lpi_timing_s cn; */ +}; + +static inline u64 CGXX_SPUX_RX_LPI_TIMING(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_RX_LPI_TIMING(u64 a) +{ + return 0x103c0 + 8 * a; +} + +/** + * Register (RSL) cgx#_spu#_rx_lpi_timing2 + * + * INTERNAL: CGX SPU RX EEE LPI Timing2 Parameters Registers Reserved. + * Internal: This register specifies receiver LPI timing parameters + * hold_off_timer. + */ +union cgxx_spux_rx_lpi_timing2 { + u64 u; + struct cgxx_spux_rx_lpi_timing2_s { + u64 hold_off_timer : 20; + u64 reserved_20_63 : 44; + } s; + /* struct cgxx_spux_rx_lpi_timing2_s cn; */ +}; + +static inline u64 CGXX_SPUX_RX_LPI_TIMING2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_RX_LPI_TIMING2(u64 a) +{ + return 0x10420 + 8 * a; +} + +/** + * Register (RSL) cgx#_spu#_rx_mrk_cnt + * + * CGX SPU Receiver Marker Interval Count Control Registers + */ +union cgxx_spux_rx_mrk_cnt { + u64 u; + struct cgxx_spux_rx_mrk_cnt_s { + u64 mrk_cnt : 20; + u64 reserved_20_43 : 24; + u64 by_mrk_100g : 1; + u64 reserved_45_47 : 3; + u64 ram_mrk_cnt : 8; + u64 reserved_56_63 : 8; + } s; + /* struct cgxx_spux_rx_mrk_cnt_s cn; */ +}; + +static inline u64 CGXX_SPUX_RX_MRK_CNT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_RX_MRK_CNT(u64 a) +{ + return 0x103a0 + 8 * a; +} + +/** + * Register (RSL) cgx#_spu#_spd_abil + * + * CGX SPU PCS Speed Ability Registers + */ +union cgxx_spux_spd_abil { + u64 u; + struct cgxx_spux_spd_abil_s { + u64 tengb : 1; + u64 tenpasst : 1; + u64 usxgmii : 1; + u64 twentyfivegb : 1; + u64 fortygb : 1; + u64 fiftygb : 1; + u64 hundredgb : 1; + u64 reserved_7_63 : 57; + } s; + /* struct cgxx_spux_spd_abil_s cn; */ +}; + +static inline u64 CGXX_SPUX_SPD_ABIL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_SPD_ABIL(u64 a) +{ + return 0x10010 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_status1 + * + * CGX SPU Status 1 Registers + */ +union cgxx_spux_status1 { + u64 u; + struct cgxx_spux_status1_s { + u64 reserved_0 : 1; + u64 lpable : 1; + u64 rcv_lnk : 1; + u64 reserved_3_6 : 4; + u64 flt : 1; + u64 rx_lpi_indication : 1; + u64 tx_lpi_indication : 1; + u64 rx_lpi_received : 1; + u64 tx_lpi_received : 1; + u64 reserved_12_63 : 52; + } s; + /* struct cgxx_spux_status1_s cn; */ +}; + +static inline u64 CGXX_SPUX_STATUS1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_STATUS1(u64 a) +{ + return 0x10008 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_status2 + * + * CGX SPU Status 2 Registers + */ +union cgxx_spux_status2 { + u64 u; + struct cgxx_spux_status2_s { + u64 tengb_r : 1; + u64 tengb_x : 1; + u64 tengb_w : 1; + u64 tengb_t : 1; + u64 usxgmii_r : 1; + u64 twentyfivegb_r : 1; + u64 fortygb_r : 1; + u64 fiftygb_r : 1; + u64 hundredgb_r : 1; + u64 reserved_9 : 1; + u64 rcvflt : 1; + u64 xmtflt : 1; + u64 reserved_12_13 : 2; + u64 dev : 2; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_spux_status2_s cn; */ +}; + +static inline u64 CGXX_SPUX_STATUS2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_STATUS2(u64 a) +{ + return 0x10020 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_tx_lpi_timing + * + * INTERNAL: CGX SPU TX EEE LPI Timing Parameters Registers Reserved. + * Internal: Transmit LPI timing parameters Tsl, Tql and Tul + */ +union cgxx_spux_tx_lpi_timing { + u64 u; + struct cgxx_spux_tx_lpi_timing_s { + u64 tql : 19; + u64 reserved_19_31 : 13; + u64 tul : 12; + u64 reserved_44_47 : 4; + u64 tsl : 12; + u64 reserved_60 : 1; + u64 tx_lpi_ignore_twl : 1; + u64 tx_lpi_fw : 1; + u64 tx_lpi_en : 1; + } s; + /* struct cgxx_spux_tx_lpi_timing_s cn; */ +}; + +static inline u64 CGXX_SPUX_TX_LPI_TIMING(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_TX_LPI_TIMING(u64 a) +{ + return 0x10400 + 8 * a; +} + +/** + * Register (RSL) cgx#_spu#_tx_lpi_timing2 + * + * INTERNAL: CGX SPU TX EEE LPI Timing2 Parameters Registers Reserved. + * Internal: This register specifies transmit LPI timer parameters. + */ +union cgxx_spux_tx_lpi_timing2 { + u64 u; + struct cgxx_spux_tx_lpi_timing2_s { + u64 t1u : 8; + u64 reserved_8_11 : 4; + u64 twl : 12; + u64 reserved_24_31 : 8; + u64 twl2 : 12; + u64 reserved_44_47 : 4; + u64 tbyp : 12; + u64 reserved_60_63 : 4; + } s; + /* struct cgxx_spux_tx_lpi_timing2_s cn; */ +}; + +static inline u64 CGXX_SPUX_TX_LPI_TIMING2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_TX_LPI_TIMING2(u64 a) +{ + return 0x10440 + 8 * a; +} + +/** + * Register (RSL) cgx#_spu#_tx_mrk_cnt + * + * CGX SPU Transmitter Marker Interval Count Control Registers + */ +union cgxx_spux_tx_mrk_cnt { + u64 u; + struct cgxx_spux_tx_mrk_cnt_s { + u64 mrk_cnt : 20; + u64 reserved_20_43 : 24; + u64 by_mrk_100g : 1; + u64 reserved_45_47 : 3; + u64 ram_mrk_cnt : 8; + u64 reserved_56_63 : 8; + } s; + /* struct cgxx_spux_tx_mrk_cnt_s cn; */ +}; + +static inline u64 CGXX_SPUX_TX_MRK_CNT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_TX_MRK_CNT(u64 a) +{ + return 0x10380 + 8 * a; +} + +/** + * Register (RSL) cgx#_spu#_usx_an_adv + * + * CGX SPU USXGMII Autonegotiation Advertisement Registers Software + * programs this register with the contents of the AN-link code word base + * page to be transmitted during autonegotiation. Any write operations to + * this register prior to completion of autonegotiation should be + * followed by a renegotiation in order for the new values to take + * effect. Once autonegotiation has completed, software can examine this + * register along with CGX()_SPU()_USX_AN_ADV to determine the highest + * common denominator technology. The format for this register is from + * USXGMII Multiport specification section 1.1.2 Table 2. + */ +union cgxx_spux_usx_an_adv { + u64 u; + struct cgxx_spux_usx_an_adv_s { + u64 set : 1; + u64 reserved_1_6 : 6; + u64 eee_clk_stop_abil : 1; + u64 eee_abil : 1; + u64 spd : 3; + u64 dplx : 1; + u64 reserved_13_14 : 2; + u64 lnk_st : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_spux_usx_an_adv_s cn; */ +}; + +static inline u64 CGXX_SPUX_USX_AN_ADV(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_USX_AN_ADV(u64 a) +{ + return 0x101d0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_usx_an_control + * + * CGX SPU USXGMII Autonegotiation Control Register + */ +union cgxx_spux_usx_an_control { + u64 u; + struct cgxx_spux_usx_an_control_s { + u64 reserved_0_8 : 9; + u64 rst_an : 1; + u64 reserved_10_11 : 2; + u64 an_en : 1; + u64 reserved_13_14 : 2; + u64 an_reset : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_spux_usx_an_control_s cn; */ +}; + +static inline u64 CGXX_SPUX_USX_AN_CONTROL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_USX_AN_CONTROL(u64 a) +{ + return 0x101c0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_usx_an_expansion + * + * CGX SPU USXGMII Autonegotiation Expansion Register This register is + * only used to signal page reception. + */ +union cgxx_spux_usx_an_expansion { + u64 u; + struct cgxx_spux_usx_an_expansion_s { + u64 reserved_0 : 1; + u64 an_page_received : 1; + u64 next_page_able : 1; + u64 reserved_3_63 : 61; + } s; + /* struct cgxx_spux_usx_an_expansion_s cn; */ +}; + +static inline u64 CGXX_SPUX_USX_AN_EXPANSION(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_USX_AN_EXPANSION(u64 a) +{ + return 0x101e0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_usx_an_flow_ctrl + * + * CGX SPU USXGMII Flow Control Registers This register is used by + * software to affect USXGMII AN hardware behavior. + */ +union cgxx_spux_usx_an_flow_ctrl { + u64 u; + struct cgxx_spux_usx_an_flow_ctrl_s { + u64 start_idle_detect : 1; + u64 reserved_1_63 : 63; + } s; + /* struct cgxx_spux_usx_an_flow_ctrl_s cn; */ +}; + +static inline u64 CGXX_SPUX_USX_AN_FLOW_CTRL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_USX_AN_FLOW_CTRL(u64 a) +{ + return 0x101e8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_usx_an_link_timer + * + * CGX SPU USXGMII Link Timer Registers This is the link timer register. + */ +union cgxx_spux_usx_an_link_timer { + u64 u; + struct cgxx_spux_usx_an_link_timer_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_spux_usx_an_link_timer_s cn; */ +}; + +static inline u64 CGXX_SPUX_USX_AN_LINK_TIMER(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_USX_AN_LINK_TIMER(u64 a) +{ + return 0x101f0 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_usx_an_lp_abil + * + * CGX SPU USXGMII Autonegotiation Link-Partner Advertisement Registers + * This register captures the contents of the latest AN link code word + * base page received from the link partner during autonegotiation. This + * is register 5 per IEEE 802.3, Clause 37. + * CGX()_SPU()_USX_AN_EXPANSION[AN_PAGE_RECEIVED] is set when this + * register is updated by hardware. + */ +union cgxx_spux_usx_an_lp_abil { + u64 u; + struct cgxx_spux_usx_an_lp_abil_s { + u64 set : 1; + u64 reserved_1_6 : 6; + u64 eee_clk_stop_abil : 1; + u64 eee_abil : 1; + u64 spd : 3; + u64 dplx : 1; + u64 reserved_13_14 : 2; + u64 lnk_st : 1; + u64 reserved_16_63 : 48; + } s; + /* struct cgxx_spux_usx_an_lp_abil_s cn; */ +}; + +static inline u64 CGXX_SPUX_USX_AN_LP_ABIL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_USX_AN_LP_ABIL(u64 a) +{ + return 0x101d8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu#_usx_an_status + * + * CGX SPU USXGMII Autonegotiation Status Register + */ +union cgxx_spux_usx_an_status { + u64 u; + struct cgxx_spux_usx_an_status_s { + u64 extnd : 1; + u64 reserved_1 : 1; + u64 lnk_st : 1; + u64 an_abil : 1; + u64 rmt_flt : 1; + u64 an_cpt : 1; + u64 reserved_6_63 : 58; + } s; + /* struct cgxx_spux_usx_an_status_s cn; */ +}; + +static inline u64 CGXX_SPUX_USX_AN_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPUX_USX_AN_STATUS(u64 a) +{ + return 0x101c8 + 0x40000 * a; +} + +/** + * Register (RSL) cgx#_spu_dbg_control + * + * CGX SPU Debug Control Registers + */ +union cgxx_spu_dbg_control { + u64 u; + struct cgxx_spu_dbg_control_s { + u64 marker_rxp : 15; + u64 reserved_15 : 1; + u64 scramble_dis : 1; + u64 reserved_17_18 : 2; + u64 br_pmd_train_soft_en : 1; + u64 reserved_20_27 : 8; + u64 timestamp_norm_dis : 1; + u64 an_nonce_match_dis : 1; + u64 br_ber_mon_dis : 1; + u64 rf_cw_mon_erly_restart_dis : 1; + u64 us_clk_period : 12; + u64 ms_clk_period : 12; + u64 reserved_56_63 : 8; + } s; + struct cgxx_spu_dbg_control_cn96xxp1 { + u64 marker_rxp : 15; + u64 reserved_15 : 1; + u64 scramble_dis : 1; + u64 reserved_17_18 : 2; + u64 br_pmd_train_soft_en : 1; + u64 reserved_20_27 : 8; + u64 timestamp_norm_dis : 1; + u64 an_nonce_match_dis : 1; + u64 br_ber_mon_dis : 1; + u64 reserved_31 : 1; + u64 us_clk_period : 12; + u64 ms_clk_period : 12; + u64 reserved_56_63 : 8; + } cn96xxp1; + /* struct cgxx_spu_dbg_control_s cn96xxp3; */ + /* struct cgxx_spu_dbg_control_cn96xxp1 cnf95xxp1; */ + /* struct cgxx_spu_dbg_control_s cnf95xxp2; */ +}; + +static inline u64 CGXX_SPU_DBG_CONTROL(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPU_DBG_CONTROL(void) +{ + return 0x10300; +} + +/** + * Register (RSL) cgx#_spu_sds#_skew_status + * + * CGX SPU SerDes Lane Skew Status Registers This register provides + * SerDes lane skew status. One register per physical SerDes lane. + */ +union cgxx_spu_sdsx_skew_status { + u64 u; + struct cgxx_spu_sdsx_skew_status_s { + u64 skew_status : 32; + u64 reserved_32_63 : 32; + } s; + /* struct cgxx_spu_sdsx_skew_status_s cn; */ +}; + +static inline u64 CGXX_SPU_SDSX_SKEW_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPU_SDSX_SKEW_STATUS(u64 a) +{ + return 0x10340 + 8 * a; +} + +/** + * Register (RSL) cgx#_spu_sds#_states + * + * CGX SPU SerDes States Registers This register provides SerDes lane + * states. One register per physical SerDes lane. + */ +union cgxx_spu_sdsx_states { + u64 u; + struct cgxx_spu_sdsx_states_s { + u64 bx_sync_sm : 4; + u64 br_sh_cnt : 11; + u64 br_block_lock : 1; + u64 br_sh_invld_cnt : 7; + u64 reserved_23 : 1; + u64 fec_sync_cnt : 4; + u64 fec_block_sync : 1; + u64 reserved_29 : 1; + u64 an_rx_sm : 2; + u64 an_arb_sm : 3; + u64 reserved_35 : 1; + u64 train_lock_bad_markers : 3; + u64 train_lock_found_1st_marker : 1; + u64 train_frame_lock : 1; + u64 train_code_viol : 1; + u64 train_sm : 3; + u64 reserved_45_47 : 3; + u64 am_lock_sm : 2; + u64 am_lock_invld_cnt : 2; + u64 reserved_52_63 : 12; + } s; + /* struct cgxx_spu_sdsx_states_s cn; */ +}; + +static inline u64 CGXX_SPU_SDSX_STATES(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPU_SDSX_STATES(u64 a) +{ + return 0x10360 + 8 * a; +} + +/** + * Register (RSL) cgx#_spu_usxgmii_control + * + * CGX SPU Common USXGMII Control Register This register is the common + * control register that enables USXGMII Mode. The fields in this + * register are preserved across any LMAC soft-resets. For an LMAC in + * soft- reset state in USXGMII mode, the CGX will transmit Remote Fault + * BASE-R blocks. + */ +union cgxx_spu_usxgmii_control { + u64 u; + struct cgxx_spu_usxgmii_control_s { + u64 enable : 1; + u64 usxgmii_type : 3; + u64 sds_id : 2; + u64 reserved_6_63 : 58; + } s; + /* struct cgxx_spu_usxgmii_control_s cn; */ +}; + +static inline u64 CGXX_SPU_USXGMII_CONTROL(void) + __attribute__ ((pure, always_inline)); +static inline u64 CGXX_SPU_USXGMII_CONTROL(void) +{ + return 0x10920; +} + +#endif /* __CSRS_CGX_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx2/csrs/csrs-lmt.h b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-lmt.h new file mode 100644 index 0000000000..625470b2de --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-lmt.h @@ -0,0 +1,60 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Marvell International Ltd. + * + * https://spdx.org/licenses + */ +#ifndef __CSRS_LMT_H__ +#define __CSRS_LMT_H__ + +/** + * @file + * + * Configuration and status register (CSR) address and type definitions for + * LMT. + * + * This file is auto generated. Do not edit. + * + */ + +/** + * Register (RVU_PFVF_BAR2) lmt_lf_lmtcancel + * + * RVU VF LMT Cancel Register + */ +union lmt_lf_lmtcancel { + u64 u; + struct lmt_lf_lmtcancel_s { + u64 data : 64; + } s; + /* struct lmt_lf_lmtcancel_s cn; */ +}; + +static inline u64 LMT_LF_LMTCANCEL(void) + __attribute__ ((pure, always_inline)); +static inline u64 LMT_LF_LMTCANCEL(void) +{ + return 0x400; +} + +/** + * Register (RVU_PFVF_BAR2) lmt_lf_lmtline# + * + * RVU VF LMT Line Registers + */ +union lmt_lf_lmtlinex { + u64 u; + struct lmt_lf_lmtlinex_s { + u64 data : 64; + } s; + /* struct lmt_lf_lmtlinex_s cn; */ +}; + +static inline u64 LMT_LF_LMTLINEX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 LMT_LF_LMTLINEX(u64 a) +{ + return 0 + 8 * a; +} + +#endif /* __CSRS_LMT_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx2/csrs/csrs-mio_emm.h b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-mio_emm.h new file mode 100644 index 0000000000..a5a4740833 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-mio_emm.h @@ -0,0 +1,1193 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Marvell International Ltd. + * + * https://spdx.org/licenses + */ +#ifndef __CSRS_MIO_EMM_H__ +#define __CSRS_MIO_EMM_H__ + +/** + * @file + * + * Configuration and status register (CSR) address and type definitions for + * MIO_EMM. + * + * This file is auto generated. Do not edit. + * + */ + +/** + * Enumeration mio_emm_bar_e + * + * eMMC Base Address Register Enumeration Enumerates the base address + * registers. + */ +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR0_CN8 (0x87e009000000ll) +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR0_CN8_SIZE 0x800000ull +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR0_CN9 (0x87e009000000ll) +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR0_CN9_SIZE 0x10000ull +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR4 (0x87e009f00000ll) +#define MIO_EMM_BAR_E_MIO_EMM_PF_BAR4_SIZE 0x100000ull + +/** + * Enumeration mio_emm_int_vec_e + * + * eMMC MSI-X Vector Enumeration Enumerates the MSI-X interrupt vectors. + */ +#define MIO_EMM_INT_VEC_E_DMA_INT_DONE (8) +#define MIO_EMM_INT_VEC_E_DMA_INT_FIFO (7) +#define MIO_EMM_INT_VEC_E_EMM_BUF_DONE (0) +#define MIO_EMM_INT_VEC_E_EMM_CMD_DONE (1) +#define MIO_EMM_INT_VEC_E_EMM_CMD_ERR (3) +#define MIO_EMM_INT_VEC_E_EMM_DMA_DONE (2) +#define MIO_EMM_INT_VEC_E_EMM_DMA_ERR (4) +#define MIO_EMM_INT_VEC_E_EMM_SWITCH_DONE (5) +#define MIO_EMM_INT_VEC_E_EMM_SWITCH_ERR (6) +#define MIO_EMM_INT_VEC_E_NCB_FLT (9) +#define MIO_EMM_INT_VEC_E_NCB_RAS (0xa) + +/** + * Register (RSL) mio_emm_access_wdog + * + * eMMC Access Watchdog Register + */ +union mio_emm_access_wdog { + u64 u; + struct mio_emm_access_wdog_s { + u64 clk_cnt : 32; + u64 reserved_32_63 : 32; + } s; + /* struct mio_emm_access_wdog_s cn; */ +}; + +static inline u64 MIO_EMM_ACCESS_WDOG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_ACCESS_WDOG(void) +{ + return 0x20f0; +} + +/** + * Register (RSL) mio_emm_buf_dat + * + * eMMC Data Buffer Access Register + */ +union mio_emm_buf_dat { + u64 u; + struct mio_emm_buf_dat_s { + u64 dat : 64; + } s; + /* struct mio_emm_buf_dat_s cn; */ +}; + +static inline u64 MIO_EMM_BUF_DAT(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_BUF_DAT(void) +{ + return 0x20e8; +} + +/** + * Register (RSL) mio_emm_buf_idx + * + * eMMC Data Buffer Address Register + */ +union mio_emm_buf_idx { + u64 u; + struct mio_emm_buf_idx_s { + u64 offset : 6; + u64 buf_num : 1; + u64 reserved_7_15 : 9; + u64 inc : 1; + u64 reserved_17_63 : 47; + } s; + /* struct mio_emm_buf_idx_s cn; */ +}; + +static inline u64 MIO_EMM_BUF_IDX(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_BUF_IDX(void) +{ + return 0x20e0; +} + +/** + * Register (RSL) mio_emm_calb + * + * eMMC Calbration Register This register initiates delay line + * characterization. + */ +union mio_emm_calb { + u64 u; + struct mio_emm_calb_s { + u64 start : 1; + u64 reserved_1_63 : 63; + } s; + /* struct mio_emm_calb_s cn; */ +}; + +static inline u64 MIO_EMM_CALB(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_CALB(void) +{ + return 0x20c0; +} + +/** + * Register (RSL) mio_emm_cfg + * + * eMMC Configuration Register + */ +union mio_emm_cfg { + u64 u; + struct mio_emm_cfg_s { + u64 bus_ena : 4; + u64 reserved_4_63 : 60; + } s; + /* struct mio_emm_cfg_s cn; */ +}; + +static inline u64 MIO_EMM_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_CFG(void) +{ + return 0x2000; +} + +/** + * Register (RSL) mio_emm_cmd + * + * eMMC Command Register + */ +union mio_emm_cmd { + u64 u; + struct mio_emm_cmd_s { + u64 arg : 32; + u64 cmd_idx : 6; + u64 rtype_xor : 3; + u64 ctype_xor : 2; + u64 reserved_43_48 : 6; + u64 offset : 6; + u64 dbuf : 1; + u64 reserved_56_58 : 3; + u64 cmd_val : 1; + u64 bus_id : 2; + u64 skip_busy : 1; + u64 reserved_63 : 1; + } s; + /* struct mio_emm_cmd_s cn; */ +}; + +static inline u64 MIO_EMM_CMD(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_CMD(void) +{ + return 0x2058; +} + +/** + * Register (RSL) mio_emm_comp + * + * eMMC Compensation Register + */ +union mio_emm_comp { + u64 u; + struct mio_emm_comp_s { + u64 nctl : 3; + u64 reserved_3_7 : 5; + u64 pctl : 3; + u64 reserved_11_63 : 53; + } s; + /* struct mio_emm_comp_s cn; */ +}; + +static inline u64 MIO_EMM_COMP(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_COMP(void) +{ + return 0x2040; +} + +/** + * Register (RSL) mio_emm_debug + * + * eMMC Debug Register + */ +union mio_emm_debug { + u64 u; + struct mio_emm_debug_s { + u64 clk_on : 1; + u64 reserved_1_7 : 7; + u64 cmd_sm : 4; + u64 data_sm : 4; + u64 dma_sm : 4; + u64 emmc_clk_disable : 1; + u64 rdsync_rst : 1; + u64 reserved_22_63 : 42; + } s; + struct mio_emm_debug_cn96xxp1 { + u64 clk_on : 1; + u64 reserved_1_7 : 7; + u64 cmd_sm : 4; + u64 data_sm : 4; + u64 dma_sm : 4; + u64 reserved_20_63 : 44; + } cn96xxp1; + /* struct mio_emm_debug_s cn96xxp3; */ + /* struct mio_emm_debug_cn96xxp1 cnf95xx; */ +}; + +static inline u64 MIO_EMM_DEBUG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DEBUG(void) +{ + return 0x20f8; +} + +/** + * Register (RSL) mio_emm_dma + * + * eMMC External DMA Configuration Register + */ +union mio_emm_dma { + u64 u; + struct mio_emm_dma_s { + u64 card_addr : 32; + u64 block_cnt : 16; + u64 multi : 1; + u64 rw : 1; + u64 rel_wr : 1; + u64 thres : 6; + u64 dat_null : 1; + u64 sector : 1; + u64 dma_val : 1; + u64 bus_id : 2; + u64 skip_busy : 1; + u64 extra_args : 1; + } s; + struct mio_emm_dma_cn8 { + u64 card_addr : 32; + u64 block_cnt : 16; + u64 multi : 1; + u64 rw : 1; + u64 rel_wr : 1; + u64 thres : 6; + u64 dat_null : 1; + u64 sector : 1; + u64 dma_val : 1; + u64 bus_id : 2; + u64 skip_busy : 1; + u64 reserved_63 : 1; + } cn8; + struct mio_emm_dma_cn9 { + u64 card_addr : 32; + u64 block_cnt : 16; + u64 multi : 1; + u64 rw : 1; + u64 reserved_50 : 1; + u64 thres : 6; + u64 dat_null : 1; + u64 sector : 1; + u64 dma_val : 1; + u64 bus_id : 2; + u64 skip_busy : 1; + u64 extra_args : 1; + } cn9; +}; + +static inline u64 MIO_EMM_DMA(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA(void) +{ + return 0x2050; +} + +/** + * Register (RSL) mio_emm_dma_adr + * + * eMMC DMA Address Register This register sets the address for eMMC/SD + * flash transfers to/from memory. Sixty-four-bit operations must be used + * to access this register. This register is updated by the DMA hardware + * and can be reloaded by the values placed in the MIO_EMM_DMA_FIFO_ADR. + */ +union mio_emm_dma_adr { + u64 u; + struct mio_emm_dma_adr_s { + u64 adr : 53; + u64 reserved_53_63 : 11; + } s; + struct mio_emm_dma_adr_cn8 { + u64 adr : 49; + u64 reserved_49_63 : 15; + } cn8; + /* struct mio_emm_dma_adr_s cn9; */ +}; + +static inline u64 MIO_EMM_DMA_ADR(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_ADR(void) +{ + return 0x188; +} + +/** + * Register (RSL) mio_emm_dma_arg + * + * eMMC External DMA Extra Arguments Register + */ +union mio_emm_dma_arg { + u64 u; + struct mio_emm_dma_arg_s { + u64 cmd23_args : 8; + u64 force_pgm : 1; + u64 context_id : 4; + u64 tag_req : 1; + u64 pack_cmd : 1; + u64 rel_wr : 1; + u64 alt_cmd : 6; + u64 skip_blk_cmd : 1; + u64 reserved_23_31 : 9; + u64 alt_cmd_arg : 32; + } s; + /* struct mio_emm_dma_arg_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_ARG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_ARG(void) +{ + return 0x2090; +} + +/** + * Register (RSL) mio_emm_dma_cfg + * + * eMMC DMA Configuration Register This register controls the internal + * DMA engine used with the eMMC/SD flash controller. Sixty- four-bit + * operations must be used to access this register. This register is + * updated by the hardware DMA engine and can also be reloaded by writes + * to the MIO_EMM_DMA_FIFO_CMD register. + */ +union mio_emm_dma_cfg { + u64 u; + struct mio_emm_dma_cfg_s { + u64 reserved_0_35 : 36; + u64 size : 20; + u64 endian : 1; + u64 swap8 : 1; + u64 swap16 : 1; + u64 swap32 : 1; + u64 reserved_60 : 1; + u64 clr : 1; + u64 rw : 1; + u64 en : 1; + } s; + /* struct mio_emm_dma_cfg_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_CFG(void) +{ + return 0x180; +} + +/** + * Register (RSL) mio_emm_dma_fifo_adr + * + * eMMC Internal DMA FIFO Address Register This register specifies the + * internal address that is loaded into the eMMC internal DMA FIFO. The + * FIFO is used to queue up operations for the + * MIO_EMM_DMA_CFG/MIO_EMM_DMA_ADR when the DMA completes successfully. + */ +union mio_emm_dma_fifo_adr { + u64 u; + struct mio_emm_dma_fifo_adr_s { + u64 reserved_0_2 : 3; + u64 adr : 50; + u64 reserved_53_63 : 11; + } s; + struct mio_emm_dma_fifo_adr_cn8 { + u64 reserved_0_2 : 3; + u64 adr : 46; + u64 reserved_49_63 : 15; + } cn8; + /* struct mio_emm_dma_fifo_adr_s cn9; */ +}; + +static inline u64 MIO_EMM_DMA_FIFO_ADR(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_FIFO_ADR(void) +{ + return 0x170; +} + +/** + * Register (RSL) mio_emm_dma_fifo_cfg + * + * eMMC Internal DMA FIFO Configuration Register This register controls + * DMA FIFO operations. + */ +union mio_emm_dma_fifo_cfg { + u64 u; + struct mio_emm_dma_fifo_cfg_s { + u64 count : 5; + u64 reserved_5_7 : 3; + u64 int_lvl : 5; + u64 reserved_13_15 : 3; + u64 clr : 1; + u64 reserved_17_63 : 47; + } s; + /* struct mio_emm_dma_fifo_cfg_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_FIFO_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_FIFO_CFG(void) +{ + return 0x160; +} + +/** + * Register (RSL) mio_emm_dma_fifo_cmd + * + * eMMC Internal DMA FIFO Command Register This register specifies a + * command that is loaded into the eMMC internal DMA FIFO. The FIFO is + * used to queue up operations for the MIO_EMM_DMA_CFG/MIO_EMM_DMA_ADR + * when the DMA completes successfully. Writes to this register store + * both the MIO_EMM_DMA_FIFO_CMD and the MIO_EMM_DMA_FIFO_ADR contents + * into the FIFO and increment the MIO_EMM_DMA_FIFO_CFG[COUNT] field. + * Note: This register has a similar format to MIO_EMM_DMA_CFG with the + * exception that the EN and CLR fields are absent. These are supported + * in MIO_EMM_DMA_FIFO_CFG. + */ +union mio_emm_dma_fifo_cmd { + u64 u; + struct mio_emm_dma_fifo_cmd_s { + u64 reserved_0_35 : 36; + u64 size : 20; + u64 endian : 1; + u64 swap8 : 1; + u64 swap16 : 1; + u64 swap32 : 1; + u64 intdis : 1; + u64 reserved_61 : 1; + u64 rw : 1; + u64 reserved_63 : 1; + } s; + /* struct mio_emm_dma_fifo_cmd_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_FIFO_CMD(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_FIFO_CMD(void) +{ + return 0x178; +} + +/** + * Register (RSL) mio_emm_dma_int + * + * eMMC DMA Interrupt Register Sixty-four-bit operations must be used to + * access this register. + */ +union mio_emm_dma_int { + u64 u; + struct mio_emm_dma_int_s { + u64 done : 1; + u64 fifo : 1; + u64 reserved_2_63 : 62; + } s; + /* struct mio_emm_dma_int_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_INT(void) +{ + return 0x190; +} + +/** + * Register (RSL) mio_emm_dma_int_ena_w1c + * + * eMMC DMA Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union mio_emm_dma_int_ena_w1c { + u64 u; + struct mio_emm_dma_int_ena_w1c_s { + u64 done : 1; + u64 fifo : 1; + u64 reserved_2_63 : 62; + } s; + /* struct mio_emm_dma_int_ena_w1c_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_INT_ENA_W1C(void) +{ + return 0x1a8; +} + +/** + * Register (RSL) mio_emm_dma_int_ena_w1s + * + * eMMC DMA Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union mio_emm_dma_int_ena_w1s { + u64 u; + struct mio_emm_dma_int_ena_w1s_s { + u64 done : 1; + u64 fifo : 1; + u64 reserved_2_63 : 62; + } s; + /* struct mio_emm_dma_int_ena_w1s_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_INT_ENA_W1S(void) +{ + return 0x1a0; +} + +/** + * Register (RSL) mio_emm_dma_int_w1s + * + * eMMC DMA Interrupt Set Register This register sets interrupt bits. + */ +union mio_emm_dma_int_w1s { + u64 u; + struct mio_emm_dma_int_w1s_s { + u64 done : 1; + u64 fifo : 1; + u64 reserved_2_63 : 62; + } s; + /* struct mio_emm_dma_int_w1s_s cn; */ +}; + +static inline u64 MIO_EMM_DMA_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_DMA_INT_W1S(void) +{ + return 0x198; +} + +/** + * Register (RSL) mio_emm_int + * + * eMMC Interrupt Register + */ +union mio_emm_int { + u64 u; + struct mio_emm_int_s { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 ncb_flt : 1; + u64 ncb_ras : 1; + u64 reserved_9_63 : 55; + } s; + struct mio_emm_int_cn8 { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 reserved_7_63 : 57; + } cn8; + /* struct mio_emm_int_s cn9; */ +}; + +static inline u64 MIO_EMM_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_INT(void) +{ + return 0x2078; +} + +/** + * Register (RSL) mio_emm_int_ena_w1c + * + * eMMC Interrupt Enable Clear Register This register clears interrupt + * enable bits. + */ +union mio_emm_int_ena_w1c { + u64 u; + struct mio_emm_int_ena_w1c_s { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 ncb_flt : 1; + u64 ncb_ras : 1; + u64 reserved_9_63 : 55; + } s; + struct mio_emm_int_ena_w1c_cn8 { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 reserved_7_63 : 57; + } cn8; + /* struct mio_emm_int_ena_w1c_s cn9; */ +}; + +static inline u64 MIO_EMM_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_INT_ENA_W1C(void) +{ + return 0x20b8; +} + +/** + * Register (RSL) mio_emm_int_ena_w1s + * + * eMMC Interrupt Enable Set Register This register sets interrupt enable + * bits. + */ +union mio_emm_int_ena_w1s { + u64 u; + struct mio_emm_int_ena_w1s_s { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 ncb_flt : 1; + u64 ncb_ras : 1; + u64 reserved_9_63 : 55; + } s; + struct mio_emm_int_ena_w1s_cn8 { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 reserved_7_63 : 57; + } cn8; + /* struct mio_emm_int_ena_w1s_s cn9; */ +}; + +static inline u64 MIO_EMM_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_INT_ENA_W1S(void) +{ + return 0x20b0; +} + +/** + * Register (RSL) mio_emm_int_w1s + * + * eMMC Interrupt Set Register This register sets interrupt bits. + */ +union mio_emm_int_w1s { + u64 u; + struct mio_emm_int_w1s_s { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 ncb_flt : 1; + u64 ncb_ras : 1; + u64 reserved_9_63 : 55; + } s; + struct mio_emm_int_w1s_cn8 { + u64 buf_done : 1; + u64 cmd_done : 1; + u64 dma_done : 1; + u64 cmd_err : 1; + u64 dma_err : 1; + u64 switch_done : 1; + u64 switch_err : 1; + u64 reserved_7_63 : 57; + } cn8; + /* struct mio_emm_int_w1s_s cn9; */ +}; + +static inline u64 MIO_EMM_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_INT_W1S(void) +{ + return 0x2080; +} + +/** + * Register (RSL) mio_emm_io_ctl + * + * eMMC I/O Control Register + */ +union mio_emm_io_ctl { + u64 u; + struct mio_emm_io_ctl_s { + u64 slew : 1; + u64 reserved_1 : 1; + u64 drive : 2; + u64 reserved_4_63 : 60; + } s; + /* struct mio_emm_io_ctl_s cn; */ +}; + +static inline u64 MIO_EMM_IO_CTL(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_IO_CTL(void) +{ + return 0x2040; +} + +/** + * Register (RSL) mio_emm_mode# + * + * eMMC Operating Mode Register + */ +union mio_emm_modex { + u64 u; + struct mio_emm_modex_s { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 clk_swap : 1; + u64 reserved_37_39 : 3; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 hs200_timing : 1; + u64 hs400_timing : 1; + u64 reserved_51_63 : 13; + } s; + struct mio_emm_modex_cn8 { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 reserved_36_39 : 4; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 reserved_49_63 : 15; + } cn8; + struct mio_emm_modex_cn96xxp1 { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 reserved_36_39 : 4; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 hs200_timing : 1; + u64 hs400_timing : 1; + u64 reserved_51_63 : 13; + } cn96xxp1; + /* struct mio_emm_modex_s cn96xxp3; */ + /* struct mio_emm_modex_s cnf95xx; */ +}; + +static inline u64 MIO_EMM_MODEX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_MODEX(u64 a) +{ + return 0x2008 + 8 * a; +} + +/** + * Register (RSL) mio_emm_msix_pba# + * + * eMMC MSI-X Pending Bit Array Registers This register is the MSI-X PBA + * table; the bit number is indexed by the MIO_EMM_INT_VEC_E enumeration. + */ +union mio_emm_msix_pbax { + u64 u; + struct mio_emm_msix_pbax_s { + u64 pend : 64; + } s; + /* struct mio_emm_msix_pbax_s cn; */ +}; + +static inline u64 MIO_EMM_MSIX_PBAX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_MSIX_PBAX(u64 a) +{ + return 0xf0000 + 8 * a; +} + +/** + * Register (RSL) mio_emm_msix_vec#_addr + * + * eMMC MSI-X Vector-Table Address Register This register is the MSI-X + * vector table, indexed by the MIO_EMM_INT_VEC_E enumeration. + */ +union mio_emm_msix_vecx_addr { + u64 u; + struct mio_emm_msix_vecx_addr_s { + u64 secvec : 1; + u64 reserved_1 : 1; + u64 addr : 51; + u64 reserved_53_63 : 11; + } s; + struct mio_emm_msix_vecx_addr_cn8 { + u64 secvec : 1; + u64 reserved_1 : 1; + u64 addr : 47; + u64 reserved_49_63 : 15; + } cn8; + /* struct mio_emm_msix_vecx_addr_s cn9; */ +}; + +static inline u64 MIO_EMM_MSIX_VECX_ADDR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_MSIX_VECX_ADDR(u64 a) +{ + return 0 + 0x10 * a; +} + +/** + * Register (RSL) mio_emm_msix_vec#_ctl + * + * eMMC MSI-X Vector-Table Control and Data Register This register is the + * MSI-X vector table, indexed by the MIO_EMM_INT_VEC_E enumeration. + */ +union mio_emm_msix_vecx_ctl { + u64 u; + struct mio_emm_msix_vecx_ctl_s { + u64 data : 32; + u64 mask : 1; + u64 reserved_33_63 : 31; + } s; + struct mio_emm_msix_vecx_ctl_cn8 { + u64 data : 20; + u64 reserved_20_31 : 12; + u64 mask : 1; + u64 reserved_33_63 : 31; + } cn8; + /* struct mio_emm_msix_vecx_ctl_s cn9; */ +}; + +static inline u64 MIO_EMM_MSIX_VECX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_MSIX_VECX_CTL(u64 a) +{ + return 8 + 0x10 * a; +} + +/** + * Register (RSL) mio_emm_rca + * + * eMMC Relative Card Address Register + */ +union mio_emm_rca { + u64 u; + struct mio_emm_rca_s { + u64 card_rca : 16; + u64 reserved_16_63 : 48; + } s; + /* struct mio_emm_rca_s cn; */ +}; + +static inline u64 MIO_EMM_RCA(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_RCA(void) +{ + return 0x20a0; +} + +/** + * Register (RSL) mio_emm_rsp_hi + * + * eMMC Response Data High Register + */ +union mio_emm_rsp_hi { + u64 u; + struct mio_emm_rsp_hi_s { + u64 dat : 64; + } s; + /* struct mio_emm_rsp_hi_s cn; */ +}; + +static inline u64 MIO_EMM_RSP_HI(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_RSP_HI(void) +{ + return 0x2070; +} + +/** + * Register (RSL) mio_emm_rsp_lo + * + * eMMC Response Data Low Register + */ +union mio_emm_rsp_lo { + u64 u; + struct mio_emm_rsp_lo_s { + u64 dat : 64; + } s; + /* struct mio_emm_rsp_lo_s cn; */ +}; + +static inline u64 MIO_EMM_RSP_LO(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_RSP_LO(void) +{ + return 0x2068; +} + +/** + * Register (RSL) mio_emm_rsp_sts + * + * eMMC Response Status Register + */ +union mio_emm_rsp_sts { + u64 u; + struct mio_emm_rsp_sts_s { + u64 cmd_done : 1; + u64 cmd_idx : 6; + u64 cmd_type : 2; + u64 rsp_type : 3; + u64 rsp_val : 1; + u64 rsp_bad_sts : 1; + u64 rsp_crc_err : 1; + u64 rsp_timeout : 1; + u64 stp_val : 1; + u64 stp_bad_sts : 1; + u64 stp_crc_err : 1; + u64 stp_timeout : 1; + u64 rsp_busybit : 1; + u64 blk_crc_err : 1; + u64 blk_timeout : 1; + u64 dbuf : 1; + u64 reserved_24_27 : 4; + u64 dbuf_err : 1; + u64 reserved_29_54 : 26; + u64 acc_timeout : 1; + u64 dma_pend : 1; + u64 dma_val : 1; + u64 switch_val : 1; + u64 cmd_val : 1; + u64 bus_id : 2; + u64 reserved_62_63 : 2; + } s; + /* struct mio_emm_rsp_sts_s cn; */ +}; + +static inline u64 MIO_EMM_RSP_STS(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_RSP_STS(void) +{ + return 0x2060; +} + +/** + * Register (RSL) mio_emm_sample + * + * eMMC Sampling Register + */ +union mio_emm_sample { + u64 u; + struct mio_emm_sample_s { + u64 dat_cnt : 10; + u64 reserved_10_15 : 6; + u64 cmd_cnt : 10; + u64 reserved_26_63 : 38; + } s; + /* struct mio_emm_sample_s cn; */ +}; + +static inline u64 MIO_EMM_SAMPLE(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_SAMPLE(void) +{ + return 0x2090; +} + +/** + * Register (RSL) mio_emm_sts_mask + * + * eMMC Status Mask Register + */ +union mio_emm_sts_mask { + u64 u; + struct mio_emm_sts_mask_s { + u64 sts_msk : 32; + u64 reserved_32_63 : 32; + } s; + /* struct mio_emm_sts_mask_s cn; */ +}; + +static inline u64 MIO_EMM_STS_MASK(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_STS_MASK(void) +{ + return 0x2098; +} + +/** + * Register (RSL) mio_emm_switch + * + * eMMC Operating Mode Switch Register This register allows software to + * change eMMC related parameters associated with a specific BUS_ID. The + * MIO_EMM_MODE() registers contain the current setting for each BUS. + * This register is also used to switch the [CLK_HI] and [CLK_LO] + * settings associated with the common EMMC_CLK. These settings can only + * be changed when [BUS_ID] = 0. + */ +union mio_emm_switch { + u64 u; + struct mio_emm_switch_s { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 clk_swap : 1; + u64 reserved_37_39 : 3; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 hs200_timing : 1; + u64 hs400_timing : 1; + u64 reserved_51_55 : 5; + u64 switch_err2 : 1; + u64 switch_err1 : 1; + u64 switch_err0 : 1; + u64 switch_exe : 1; + u64 bus_id : 2; + u64 reserved_62_63 : 2; + } s; + struct mio_emm_switch_cn8 { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 reserved_36_39 : 4; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 reserved_49_55 : 7; + u64 switch_err2 : 1; + u64 switch_err1 : 1; + u64 switch_err0 : 1; + u64 switch_exe : 1; + u64 bus_id : 2; + u64 reserved_62_63 : 2; + } cn8; + struct mio_emm_switch_cn96xxp1 { + u64 clk_lo : 16; + u64 clk_hi : 16; + u64 power_class : 4; + u64 reserved_36_39 : 4; + u64 bus_width : 3; + u64 reserved_43_47 : 5; + u64 hs_timing : 1; + u64 hs200_timing : 1; + u64 hs400_timing : 1; + u64 reserved_51_55 : 5; + u64 switch_err2 : 1; + u64 switch_err1 : 1; + u64 switch_err0 : 1; + u64 switch_exe : 1; + u64 bus_id : 2; + u64 reserved_62_63 : 2; + } cn96xxp1; + /* struct mio_emm_switch_s cn96xxp3; */ + /* struct mio_emm_switch_s cnf95xx; */ +}; + +static inline u64 MIO_EMM_SWITCH(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_SWITCH(void) +{ + return 0x2048; +} + +/** + * Register (RSL) mio_emm_tap + * + * eMMC TAP Delay Register This register indicates the delay line + * characteristics. + */ +union mio_emm_tap { + u64 u; + struct mio_emm_tap_s { + u64 delay : 8; + u64 reserved_8_63 : 56; + } s; + /* struct mio_emm_tap_s cn; */ +}; + +static inline u64 MIO_EMM_TAP(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_TAP(void) +{ + return 0x20c8; +} + +/** + * Register (RSL) mio_emm_timing + * + * eMMC Timing Register This register determines the number of tap delays + * the EMM_DAT, EMM_DS, and EMM_CMD lines are transmitted or received in + * relation to EMM_CLK. These values should only be changed when the eMMC + * bus is idle. + */ +union mio_emm_timing { + u64 u; + struct mio_emm_timing_s { + u64 data_out_tap : 6; + u64 reserved_6_15 : 10; + u64 data_in_tap : 6; + u64 reserved_22_31 : 10; + u64 cmd_out_tap : 6; + u64 reserved_38_47 : 10; + u64 cmd_in_tap : 6; + u64 reserved_54_63 : 10; + } s; + /* struct mio_emm_timing_s cn; */ +}; + +static inline u64 MIO_EMM_TIMING(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_TIMING(void) +{ + return 0x20d0; +} + +/** + * Register (RSL) mio_emm_wdog + * + * eMMC Watchdog Register + */ +union mio_emm_wdog { + u64 u; + struct mio_emm_wdog_s { + u64 clk_cnt : 26; + u64 reserved_26_63 : 38; + } s; + /* struct mio_emm_wdog_s cn; */ +}; + +static inline u64 MIO_EMM_WDOG(void) + __attribute__ ((pure, always_inline)); +static inline u64 MIO_EMM_WDOG(void) +{ + return 0x2088; +} + +#endif /* __CSRS_MIO_EMM_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx2/csrs/csrs-nix.h b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-nix.h new file mode 100644 index 0000000000..2908f25049 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-nix.h @@ -0,0 +1,10404 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Marvell International Ltd. + * + * https://spdx.org/licenses + */ +#ifndef __CSRS_NIX_H__ +#define __CSRS_NIX_H__ + +/** + * @file + * + * Configuration and status register (CSR) address and type definitions for + * NIX. + * + * This file is auto generated. Do not edit. + * + */ + +/** + * Enumeration nix_af_int_vec_e + * + * NIX Admin Function Interrupt Vector Enumeration Enumerates the NIX AF + * MSI-X interrupt vectors. + */ +#define NIX_AF_INT_VEC_E_AF_ERR (3) +#define NIX_AF_INT_VEC_E_AQ_DONE (2) +#define NIX_AF_INT_VEC_E_GEN (1) +#define NIX_AF_INT_VEC_E_POISON (4) +#define NIX_AF_INT_VEC_E_RVU (0) + +/** + * Enumeration nix_aq_comp_e + * + * NIX Completion Enumeration Enumerates the values of + * NIX_AQ_RES_S[COMPCODE]. + */ +#define NIX_AQ_COMP_E_CTX_FAULT (4) +#define NIX_AQ_COMP_E_CTX_POISON (3) +#define NIX_AQ_COMP_E_GOOD (1) +#define NIX_AQ_COMP_E_LOCKERR (5) +#define NIX_AQ_COMP_E_NOTDONE (0) +#define NIX_AQ_COMP_E_SQB_ALLOC_FAIL (6) +#define NIX_AQ_COMP_E_SWERR (2) + +/** + * Enumeration nix_aq_ctype_e + * + * NIX Context Type Enumeration Enumerates NIX_AQ_INST_S[CTYPE] values. + */ +#define NIX_AQ_CTYPE_E_CQ (2) +#define NIX_AQ_CTYPE_E_DYNO (5) +#define NIX_AQ_CTYPE_E_MCE (3) +#define NIX_AQ_CTYPE_E_RQ (0) +#define NIX_AQ_CTYPE_E_RSS (4) +#define NIX_AQ_CTYPE_E_SQ (1) + +/** + * Enumeration nix_aq_instop_e + * + * NIX Admin Queue Opcode Enumeration Enumerates NIX_AQ_INST_S[OP] + * values. + */ +#define NIX_AQ_INSTOP_E_INIT (1) +#define NIX_AQ_INSTOP_E_LOCK (4) +#define NIX_AQ_INSTOP_E_NOP (0) +#define NIX_AQ_INSTOP_E_READ (3) +#define NIX_AQ_INSTOP_E_UNLOCK (5) +#define NIX_AQ_INSTOP_E_WRITE (2) + +/** + * Enumeration nix_chan_e + * + * NIX Channel Number Enumeration Enumerates the receive and transmit + * channels, and values of NIX_RX_PARSE_S[CHAN], + * NIX_SQ_CTX_S[DEFAULT_CHAN]. CNXXXX implements a subset of these + * channels. Specifically, only channels for links enumerated by + * NIX_LINK_E are implemented. Internal: P2X/X2P channel enumeration for + * t9x. + */ +#define NIX_CHAN_E_CGXX_LMACX_CHX(a, b, c) \ + (0x800 + 0x100 * (a) + 0x10 * (b) + (c)) +#define NIX_CHAN_E_LBKX_CHX(a, b) (0 + 0x100 * (a) + (b)) +#define NIX_CHAN_E_RX(a) (0 + 0x100 * (a)) +#define NIX_CHAN_E_SDP_CHX(a) (0x700 + (a)) + +/** + * Enumeration nix_colorresult_e + * + * NIX Color Result Enumeration Enumerates the values of + * NIX_MEM_RESULT_S[COLOR], NIX_AF_TL1()_MD_DEBUG1[COLOR] and + * NIX_AF_TL1()_MD_DEBUG1[COLOR]. + */ +#define NIX_COLORRESULT_E_GREEN (0) +#define NIX_COLORRESULT_E_RED_DROP (3) +#define NIX_COLORRESULT_E_RED_SEND (2) +#define NIX_COLORRESULT_E_YELLOW (1) + +/** + * Enumeration nix_cqerrint_e + * + * NIX Completion Queue Interrupt Enumeration Enumerates the bit index of + * NIX_CQ_CTX_S[CQ_ERR_INT,CQ_ERR_INT_ENA]. + */ +#define NIX_CQERRINT_E_CQE_FAULT (2) +#define NIX_CQERRINT_E_DOOR_ERR (0) +#define NIX_CQERRINT_E_WR_FULL (1) + +/** + * Enumeration nix_intf_e + * + * NIX Interface Number Enumeration Enumerates the bit index of + * NIX_AF_STATUS[CALIBRATE_STATUS]. + */ +#define NIX_INTF_E_CGXX(a) (0 + (a)) +#define NIX_INTF_E_LBKX(a) (3 + (a)) +#define NIX_INTF_E_SDP (4) + +/** + * Enumeration nix_lf_int_vec_e + * + * NIX Local Function Interrupt Vector Enumeration Enumerates the NIX + * MSI-X interrupt vectors per LF. + */ +#define NIX_LF_INT_VEC_E_CINTX(a) (0x40 + (a)) +#define NIX_LF_INT_VEC_E_ERR_INT (0x81) +#define NIX_LF_INT_VEC_E_GINT (0x80) +#define NIX_LF_INT_VEC_E_POISON (0x82) +#define NIX_LF_INT_VEC_E_QINTX(a) (0 + (a)) + +/** + * Enumeration nix_link_e + * + * NIX Link Number Enumeration Enumerates the receive and transmit links, + * and LINK index of NIX_AF_RX_LINK()_CFG, NIX_AF_RX_LINK()_WRR_CFG, + * NIX_AF_TX_LINK()_NORM_CREDIT, NIX_AF_TX_LINK()_HW_XOFF and + * NIX_AF_TL3_TL2()_LINK()_CFG. + */ +#define NIX_LINK_E_CGXX_LMACX(a, b) (0 + 4 * (a) + (b)) +#define NIX_LINK_E_LBKX(a) (0xc + (a)) +#define NIX_LINK_E_MC (0xe) +#define NIX_LINK_E_SDP (0xd) + +/** + * Enumeration nix_lsoalg_e + * + * NIX Large Send Offload Algorithm Enumeration Enumerates + * NIX_AF_LSO_FORMAT()_FIELD()[ALG] values. Specifies algorithm for + * modifying the associated LSO packet field. + */ +#define NIX_LSOALG_E_ADD_OFFSET (3) +#define NIX_LSOALG_E_ADD_PAYLEN (2) +#define NIX_LSOALG_E_ADD_SEGNUM (1) +#define NIX_LSOALG_E_NOP (0) +#define NIX_LSOALG_E_TCP_FLAGS (4) + +/** + * Enumeration nix_maxsqesz_e + * + * NIX Maximum SQE Size Enumeration Enumerates the values of + * NIX_SQ_CTX_S[MAX_SQE_SIZE]. + */ +#define NIX_MAXSQESZ_E_W16 (0) +#define NIX_MAXSQESZ_E_W8 (1) + +/** + * Enumeration nix_mdtype_e + * + * NIX Meta Descriptor Type Enumeration Enumerates values of + * NIX_AF_MDQ()_MD_DEBUG[MD_TYPE]. + */ +#define NIX_MDTYPE_E_FLUSH (1) +#define NIX_MDTYPE_E_PMD (2) +#define NIX_MDTYPE_E_RSVD (0) + +/** + * Enumeration nix_mnqerr_e + * + * NIX Meta-Descriptor Enqueue Error Enumeration Enumerates + * NIX_LF_MNQ_ERR_DBG[ERRCODE] values. + */ +#define NIX_MNQERR_E_CQ_QUERY_ERR (6) +#define NIX_MNQERR_E_LSO_ERR (5) +#define NIX_MNQERR_E_MAXLEN_ERR (8) +#define NIX_MNQERR_E_MAX_SQE_SIZE_ERR (7) +#define NIX_MNQERR_E_SQB_FAULT (2) +#define NIX_MNQERR_E_SQB_POISON (3) +#define NIX_MNQERR_E_SQE_SIZEM1_ZERO (9) +#define NIX_MNQERR_E_SQ_CTX_FAULT (0) +#define NIX_MNQERR_E_SQ_CTX_POISON (1) +#define NIX_MNQERR_E_TOTAL_ERR (4) + +/** + * Enumeration nix_ndc_rx_port_e + * + * NIX Receive NDC Port Enumeration Enumerates NIX receive NDC + * (NDC_IDX_E::NIX()_RX) ports and the PORT index of + * NDC_AF_PORT()_RT()_RW()_REQ_PC and NDC_AF_PORT()_RT()_RW()_LAT_PC. + */ +#define NIX_NDC_RX_PORT_E_AQ (0) +#define NIX_NDC_RX_PORT_E_CINT (2) +#define NIX_NDC_RX_PORT_E_CQ (1) +#define NIX_NDC_RX_PORT_E_MC (3) +#define NIX_NDC_RX_PORT_E_PKT (4) +#define NIX_NDC_RX_PORT_E_RQ (5) + +/** + * Enumeration nix_ndc_tx_port_e + * + * NIX Transmit NDC Port Enumeration Enumerates NIX transmit NDC + * (NDC_IDX_E::NIX()_TX) ports and the PORT index of + * NDC_AF_PORT()_RT()_RW()_REQ_PC and NDC_AF_PORT()_RT()_RW()_LAT_PC. + */ +#define NIX_NDC_TX_PORT_E_DEQ (3) +#define NIX_NDC_TX_PORT_E_DMA (4) +#define NIX_NDC_TX_PORT_E_ENQ (1) +#define NIX_NDC_TX_PORT_E_LMT (0) +#define NIX_NDC_TX_PORT_E_MNQ (2) +#define NIX_NDC_TX_PORT_E_XQE (5) + +/** + * Enumeration nix_re_opcode_e + * + * NIX Receive Error Opcode Enumeration Enumerates + * NIX_RX_PARSE_S[ERRCODE] values when NIX_RX_PARSE_S[ERRLEV] = + * NPC_ERRLEV_E::RE. + */ +#define NIX_RE_OPCODE_E_OL2_LENMISM (0x12) +#define NIX_RE_OPCODE_E_OVERSIZE (0x11) +#define NIX_RE_OPCODE_E_RE_DMAPKT (0xf) +#define NIX_RE_OPCODE_E_RE_FCS (7) +#define NIX_RE_OPCODE_E_RE_FCS_RCV (8) +#define NIX_RE_OPCODE_E_RE_JABBER (2) +#define NIX_RE_OPCODE_E_RE_NONE (0) +#define NIX_RE_OPCODE_E_RE_PARTIAL (1) +#define NIX_RE_OPCODE_E_RE_RX_CTL (0xb) +#define NIX_RE_OPCODE_E_RE_SKIP (0xc) +#define NIX_RE_OPCODE_E_RE_TERMINATE (9) +#define NIX_RE_OPCODE_E_UNDERSIZE (0x10) + +/** + * Enumeration nix_redalg_e + * + * NIX Red Algorithm Enumeration Enumerates the different algorithms of + * NIX_SEND_EXT_S[SHP_RA]. + */ +#define NIX_REDALG_E_DISCARD (3) +#define NIX_REDALG_E_SEND (1) +#define NIX_REDALG_E_STALL (2) +#define NIX_REDALG_E_STD (0) + +/** + * Enumeration nix_rqint_e + * + * NIX Receive Queue Interrupt Enumeration Enumerates the bit index of + * NIX_RQ_CTX_S[RQ_INT,RQ_INT_ENA]. + */ +#define NIX_RQINT_E_DROP (0) +#define NIX_RQINT_E_RX(a) (0 + (a)) +#define NIX_RQINT_E_RED (1) + +/** + * Enumeration nix_rx_actionop_e + * + * NIX Receive Action Opcode Enumeration Enumerates the values of + * NIX_RX_ACTION_S[OP]. + */ +#define NIX_RX_ACTIONOP_E_DROP (0) +#define NIX_RX_ACTIONOP_E_MCAST (3) +#define NIX_RX_ACTIONOP_E_MIRROR (6) +#define NIX_RX_ACTIONOP_E_PF_FUNC_DROP (5) +#define NIX_RX_ACTIONOP_E_RSS (4) +#define NIX_RX_ACTIONOP_E_UCAST (1) +#define NIX_RX_ACTIONOP_E_UCAST_IPSEC (2) + +/** + * Enumeration nix_rx_mcop_e + * + * NIX Receive Multicast/Mirror Opcode Enumeration Enumerates the values + * of NIX_RX_MCE_S[OP]. + */ +#define NIX_RX_MCOP_E_RQ (0) +#define NIX_RX_MCOP_E_RSS (1) + +/** + * Enumeration nix_rx_perrcode_e + * + * NIX Receive Protocol Error Code Enumeration Enumerates + * NIX_RX_PARSE_S[ERRCODE] values when NIX_RX_PARSE_S[ERRLEV] = + * NPC_ERRLEV_E::NIX. + */ +#define NIX_RX_PERRCODE_E_BUFS_OFLOW (0xa) +#define NIX_RX_PERRCODE_E_DATA_FAULT (8) +#define NIX_RX_PERRCODE_E_IL3_LEN (0x20) +#define NIX_RX_PERRCODE_E_IL4_CHK (0x22) +#define NIX_RX_PERRCODE_E_IL4_LEN (0x21) +#define NIX_RX_PERRCODE_E_IL4_PORT (0x23) +#define NIX_RX_PERRCODE_E_MCAST_FAULT (4) +#define NIX_RX_PERRCODE_E_MCAST_POISON (6) +#define NIX_RX_PERRCODE_E_MEMOUT (9) +#define NIX_RX_PERRCODE_E_MIRROR_FAULT (5) +#define NIX_RX_PERRCODE_E_MIRROR_POISON (7) +#define NIX_RX_PERRCODE_E_NPC_RESULT_ERR (2) +#define NIX_RX_PERRCODE_E_OL3_LEN (0x10) +#define NIX_RX_PERRCODE_E_OL4_CHK (0x12) +#define NIX_RX_PERRCODE_E_OL4_LEN (0x11) +#define NIX_RX_PERRCODE_E_OL4_PORT (0x13) + +/** + * Enumeration nix_send_status_e + * + * NIX Send Completion Status Enumeration Enumerates values of + * NIX_SEND_COMP_S[STATUS] and NIX_LF_SEND_ERR_DBG[ERRCODE]. + */ +#define NIX_SEND_STATUS_E_DATA_FAULT (0x16) +#define NIX_SEND_STATUS_E_DATA_POISON (0x17) +#define NIX_SEND_STATUS_E_GOOD (0) +#define NIX_SEND_STATUS_E_INVALID_SUBDC (0x14) +#define NIX_SEND_STATUS_E_JUMP_FAULT (7) +#define NIX_SEND_STATUS_E_JUMP_POISON (8) +#define NIX_SEND_STATUS_E_LOCK_VIOL (0x21) +#define NIX_SEND_STATUS_E_NPC_DROP_ACTION (0x20) +#define NIX_SEND_STATUS_E_NPC_MCAST_ABORT (0x24) +#define NIX_SEND_STATUS_E_NPC_MCAST_CHAN_ERR (0x23) +#define NIX_SEND_STATUS_E_NPC_UCAST_CHAN_ERR (0x22) +#define NIX_SEND_STATUS_E_NPC_VTAG_PTR_ERR (0x25) +#define NIX_SEND_STATUS_E_NPC_VTAG_SIZE_ERR (0x26) +#define NIX_SEND_STATUS_E_SEND_CRC_ERR (0x10) +#define NIX_SEND_STATUS_E_SEND_EXT_ERR (6) +#define NIX_SEND_STATUS_E_SEND_HDR_ERR (5) +#define NIX_SEND_STATUS_E_SEND_IMM_ERR (0x11) +#define NIX_SEND_STATUS_E_SEND_MEM_ERR (0x13) +#define NIX_SEND_STATUS_E_SEND_MEM_FAULT (0x27) +#define NIX_SEND_STATUS_E_SEND_SG_ERR (0x12) +#define NIX_SEND_STATUS_E_SQB_FAULT (3) +#define NIX_SEND_STATUS_E_SQB_POISON (4) +#define NIX_SEND_STATUS_E_SQ_CTX_FAULT (1) +#define NIX_SEND_STATUS_E_SQ_CTX_POISON (2) +#define NIX_SEND_STATUS_E_SUBDC_ORDER_ERR (0x15) + +/** + * Enumeration nix_sendcrcalg_e + * + * NIX Send CRC Algorithm Enumeration Enumerates the CRC algorithm used, + * see NIX_SEND_CRC_S[ALG]. + */ +#define NIX_SENDCRCALG_E_CRC32 (0) +#define NIX_SENDCRCALG_E_CRC32C (1) +#define NIX_SENDCRCALG_E_ONES16 (2) + +/** + * Enumeration nix_sendl3type_e + * + * NIX Send Layer 3 Header Type Enumeration Enumerates values of + * NIX_SEND_HDR_S[OL3TYPE], NIX_SEND_HDR_S[IL3TYPE]. Internal: Encoding + * matches DPDK TX IP types: <pre> PKT_TX_IP_CKSUM (1ULL << 54) + * PKT_TX_IPV4 (1ULL << 55) PKT_TX_IPV6 (1ULL << + * 56) PKT_TX_OUTER_IP_CKSUM(1ULL << 58) PKT_TX_OUTER_IPV4 (1ULL + * << 59) PKT_TX_OUTER_IPV6 (1ULL << 60) </pre> + */ +#define NIX_SENDL3TYPE_E_IP4 (2) +#define NIX_SENDL3TYPE_E_IP4_CKSUM (3) +#define NIX_SENDL3TYPE_E_IP6 (4) +#define NIX_SENDL3TYPE_E_NONE (0) + +/** + * Enumeration nix_sendl4type_e + * + * NIX Send Layer 4 Header Type Enumeration Enumerates values of + * NIX_SEND_HDR_S[OL4TYPE], NIX_SEND_HDR_S[IL4TYPE]. Internal: Encoding + * matches DPDK TX L4 types. <pre> PKT_TX_L4_NO_CKSUM (0ULL << 52) + * // Disable L4 cksum of TX pkt. PKT_TX_TCP_CKSUM (1ULL << 52) // + * TCP cksum of TX pkt. computed by nic. PKT_TX_SCTP_CKSUM (2ULL << + * 52) // SCTP cksum of TX pkt. computed by nic. PKT_TX_UDP_CKSUM + * (3ULL << 52) // UDP cksum of TX pkt. computed by nic. </pre> + */ +#define NIX_SENDL4TYPE_E_NONE (0) +#define NIX_SENDL4TYPE_E_SCTP_CKSUM (2) +#define NIX_SENDL4TYPE_E_TCP_CKSUM (1) +#define NIX_SENDL4TYPE_E_UDP_CKSUM (3) + +/** + * Enumeration nix_sendldtype_e + * + * NIX Send Load Type Enumeration Enumerates the load transaction types + * for reading segment bytes specified by NIX_SEND_SG_S[LD_TYPE] and + * NIX_SEND_JUMP_S[LD_TYPE]. Internal: The hardware implementation + * treats undefined encodings as LDD load type. + */ +#define NIX_SENDLDTYPE_E_LDD (0) +#define NIX_SENDLDTYPE_E_LDT (1) +#define NIX_SENDLDTYPE_E_LDWB (2) + +/** + * Enumeration nix_sendmemalg_e + * + * NIX Memory Modify Algorithm Enumeration Enumerates the different + * algorithms for modifying memory; see NIX_SEND_MEM_S[ALG]. mbufs_freed + * is the number of gather buffers freed to NPA for the send descriptor. + * See NIX_SEND_HDR_S[DF] and NIX_SEND_SG_S[I*]. + */ +#define NIX_SENDMEMALG_E_ADD (8) +#define NIX_SENDMEMALG_E_ADDLEN (0xa) +#define NIX_SENDMEMALG_E_ADDMBUF (0xc) +#define NIX_SENDMEMALG_E_SET (0) +#define NIX_SENDMEMALG_E_SETRSLT (2) +#define NIX_SENDMEMALG_E_SETTSTMP (1) +#define NIX_SENDMEMALG_E_SUB (9) +#define NIX_SENDMEMALG_E_SUBLEN (0xb) +#define NIX_SENDMEMALG_E_SUBMBUF (0xd) + +/** + * Enumeration nix_sendmemdsz_e + * + * NIX Memory Data Size Enumeration Enumerates the datum size for + * modifying memory; see NIX_SEND_MEM_S[DSZ]. + */ +#define NIX_SENDMEMDSZ_E_B16 (2) +#define NIX_SENDMEMDSZ_E_B32 (1) +#define NIX_SENDMEMDSZ_E_B64 (0) +#define NIX_SENDMEMDSZ_E_B8 (3) + +/** + * Enumeration nix_sqint_e + * + * NIX Send Queue Interrupt Enumeration Enumerates the bit index of + * NIX_SQ_CTX_S[SQ_INT,SQ_INT_ENA]. + */ +#define NIX_SQINT_E_LMT_ERR (0) +#define NIX_SQINT_E_MNQ_ERR (1) +#define NIX_SQINT_E_SEND_ERR (2) +#define NIX_SQINT_E_SQB_ALLOC_FAIL (3) + +/** + * Enumeration nix_sqoperr_e + * + * NIX SQ Operation Error Enumeration Enumerates + * NIX_LF_SQ_OP_ERR_DBG[ERRCODE] values. + */ +#define NIX_SQOPERR_E_MAX_SQE_SIZE_ERR (4) +#define NIX_SQOPERR_E_SQB_FAULT (7) +#define NIX_SQOPERR_E_SQB_NULL (6) +#define NIX_SQOPERR_E_SQE_OFLOW (5) +#define NIX_SQOPERR_E_SQE_SIZEM1_ZERO (8) +#define NIX_SQOPERR_E_SQ_CTX_FAULT (1) +#define NIX_SQOPERR_E_SQ_CTX_POISON (2) +#define NIX_SQOPERR_E_SQ_DISABLED (3) +#define NIX_SQOPERR_E_SQ_OOR (0) + +/** + * Enumeration nix_stat_lf_rx_e + * + * NIX Local Function Receive Statistics Enumeration Enumerates the last + * index of NIX_AF_LF()_RX_STAT() and NIX_LF_RX_STAT(). + */ +#define NIX_STAT_LF_RX_E_RX_BCAST (2) +#define NIX_STAT_LF_RX_E_RX_DROP (4) +#define NIX_STAT_LF_RX_E_RX_DROP_OCTS (5) +#define NIX_STAT_LF_RX_E_RX_DRP_BCAST (8) +#define NIX_STAT_LF_RX_E_RX_DRP_L3BCAST (0xa) +#define NIX_STAT_LF_RX_E_RX_DRP_L3MCAST (0xb) +#define NIX_STAT_LF_RX_E_RX_DRP_MCAST (9) +#define NIX_STAT_LF_RX_E_RX_ERR (7) +#define NIX_STAT_LF_RX_E_RX_FCS (6) +#define NIX_STAT_LF_RX_E_RX_MCAST (3) +#define NIX_STAT_LF_RX_E_RX_OCTS (0) +#define NIX_STAT_LF_RX_E_RX_UCAST (1) + +/** + * Enumeration nix_stat_lf_tx_e + * + * NIX Local Function Transmit Statistics Enumeration Enumerates the + * index of NIX_AF_LF()_TX_STAT() and NIX_LF_TX_STAT(). These statistics + * do not account for packet replication due to NIX_TX_ACTION_S[OP] = + * NIX_TX_ACTIONOP_E::MCAST. + */ +#define NIX_STAT_LF_TX_E_TX_BCAST (1) +#define NIX_STAT_LF_TX_E_TX_DROP (3) +#define NIX_STAT_LF_TX_E_TX_MCAST (2) +#define NIX_STAT_LF_TX_E_TX_OCTS (4) +#define NIX_STAT_LF_TX_E_TX_UCAST (0) + +/** + * Enumeration nix_stype_e + * + * NIX SQB Caching Type Enumeration Enumerates the values of + * NIX_SQ_CTX_S[SQE_STYPE]. + */ +#define NIX_STYPE_E_STF (0) +#define NIX_STYPE_E_STP (2) +#define NIX_STYPE_E_STT (1) + +/** + * Enumeration nix_subdc_e + * + * NIX Subdescriptor Operation Enumeration Enumerates send and receive + * subdescriptor codes. The codes differentiate subdescriptors within a + * NIX send or receive descriptor, excluding NIX_SEND_HDR_S for send and + * NIX_CQE_HDR_S/NIX_WQE_HDR_S for receive, which are determined by their + * position as the first subdescriptor, and NIX_RX_PARSE_S, which is + * determined by its position as the second subdescriptor. + */ +#define NIX_SUBDC_E_CRC (2) +#define NIX_SUBDC_E_EXT (1) +#define NIX_SUBDC_E_IMM (3) +#define NIX_SUBDC_E_JUMP (6) +#define NIX_SUBDC_E_MEM (5) +#define NIX_SUBDC_E_NOP (0) +#define NIX_SUBDC_E_SG (4) +#define NIX_SUBDC_E_SOD (0xf) +#define NIX_SUBDC_E_WORK (7) + +/** + * Enumeration nix_tx_actionop_e + * + * NIX Transmit Action Opcode Enumeration Enumerates the values of + * NIX_TX_ACTION_S[OP]. + */ +#define NIX_TX_ACTIONOP_E_DROP (0) +#define NIX_TX_ACTIONOP_E_DROP_VIOL (5) +#define NIX_TX_ACTIONOP_E_MCAST (3) +#define NIX_TX_ACTIONOP_E_UCAST_CHAN (2) +#define NIX_TX_ACTIONOP_E_UCAST_DEFAULT (1) + +/** + * Enumeration nix_tx_vtagop_e + * + * NIX Transmit Vtag Opcode Enumeration Enumerates the values of + * NIX_TX_VTAG_ACTION_S[VTAG0_OP,VTAG1_OP]. + */ +#define NIX_TX_VTAGOP_E_INSERT (1) +#define NIX_TX_VTAGOP_E_NOP (0) +#define NIX_TX_VTAGOP_E_REPLACE (2) + +/** + * Enumeration nix_txlayer_e + * + * NIX Transmit Layer Enumeration Enumerates the values of + * NIX_AF_LSO_FORMAT()_FIELD()[LAYER]. + */ +#define NIX_TXLAYER_E_IL3 (2) +#define NIX_TXLAYER_E_IL4 (3) +#define NIX_TXLAYER_E_OL3 (0) +#define NIX_TXLAYER_E_OL4 (1) + +/** + * Enumeration nix_vtagsize_e + * + * NIX Vtag Size Enumeration Enumerates the values of + * NIX_AF_TX_VTAG_DEF()_CTL[SIZE] and NIX_AF_LF()_RX_VTAG_TYPE()[SIZE]. + */ +#define NIX_VTAGSIZE_E_T4 (0) +#define NIX_VTAGSIZE_E_T8 (1) + +/** + * Enumeration nix_xqe_type_e + * + * NIX WQE/CQE Type Enumeration Enumerates the values of + * NIX_WQE_HDR_S[WQE_TYPE], NIX_CQE_HDR_S[CQE_TYPE]. + */ +#define NIX_XQE_TYPE_E_INVALID (0) +#define NIX_XQE_TYPE_E_RX (1) +#define NIX_XQE_TYPE_E_RX_IPSECD (4) +#define NIX_XQE_TYPE_E_RX_IPSECH (3) +#define NIX_XQE_TYPE_E_RX_IPSECS (2) +#define NIX_XQE_TYPE_E_SEND (8) + +/** + * Enumeration nix_xqesz_e + * + * NIX WQE/CQE Size Enumeration Enumerates the values of + * NIX_AF_LF()_CFG[XQE_SIZE]. + */ +#define NIX_XQESZ_E_W16 (1) +#define NIX_XQESZ_E_W64 (0) + +/** + * Structure nix_aq_inst_s + * + * NIX Admin Queue Instruction Structure This structure specifies the AQ + * instruction. Instructions and associated software structures are + * stored in memory as little-endian unless NIX_AF_CFG[AF_BE] is set. + * Hardware reads of NIX_AQ_INST_S do not allocate into LLC. Hardware + * reads and writes of the context structure selected by [CTYPE], [LF] + * and [CINDEX] use the NDC and LLC caching style configured for that + * context. For example: * When [CTYPE] = NIX_AQ_CTYPE_E::RQ: use + * NIX_AF_LF()_RSS_CFG[CACHING] and NIX_AF_LF()_RSS_CFG[WAY_MASK]. * When + * [CTYPE] = NIX_AQ_CTYPE_E::MCE: use NIX_AF_RX_MCAST_CFG[CACHING] and + * NIX_AF_RX_MCAST_CFG[WAY_MASK]. + */ +union nix_aq_inst_s { + u64 u[2]; + struct nix_aq_inst_s_s { + u64 op : 4; + u64 ctype : 4; + u64 lf : 7; + u64 reserved_15_23 : 9; + u64 cindex : 20; + u64 reserved_44_62 : 19; + u64 doneint : 1; + u64 res_addr : 64; + } s; + /* struct nix_aq_inst_s_s cn; */ +}; + +/** + * Structure nix_aq_res_s + * + * NIX Admin Queue Result Structure NIX writes this structure after it + * completes the NIX_AQ_INST_S instruction. The result structure is + * exactly 16 bytes, and each instruction completion produces exactly one + * result structure. Results and associated software structures are + * stored in memory as little-endian unless NIX_AF_CFG[AF_BE] is set. + * When [OP] = NIX_AQ_INSTOP_E::INIT, WRITE or READ, this structure is + * immediately followed by context read or write data. See + * NIX_AQ_INSTOP_E. Hardware writes of NIX_AQ_RES_S and context data + * always allocate into LLC. Hardware reads of context data do not + * allocate into LLC. + */ +union nix_aq_res_s { + u64 u[2]; + struct nix_aq_res_s_s { + u64 op : 4; + u64 ctype : 4; + u64 compcode : 8; + u64 doneint : 1; + u64 reserved_17_63 : 47; + u64 reserved_64_127 : 64; + } s; + /* struct nix_aq_res_s_s cn; */ +}; + +/** + * Structure nix_cint_hw_s + * + * NIX Completion Interrupt Context Hardware Structure This structure + * contains context state maintained by hardware for each completion + * interrupt (CINT) in NDC/LLC/DRAM. Software accesses this structure + * with the NIX_LF_CINT()* registers. Hardware maintains a table of + * NIX_AF_CONST2[CINTS] contiguous NIX_CINT_HW_S structures per LF + * starting at AF IOVA NIX_AF_LF()_CINTS_BASE. Always stored in byte + * invariant little-endian format (LE8). + */ +union nix_cint_hw_s { + u64 u[2]; + struct nix_cint_hw_s_s { + u64 ecount : 32; + u64 qcount : 16; + u64 intr : 1; + u64 ena : 1; + u64 timer_idx : 8; + u64 reserved_58_63 : 6; + u64 ecount_wait : 32; + u64 qcount_wait : 16; + u64 time_wait : 8; + u64 reserved_120_127 : 8; + } s; + /* struct nix_cint_hw_s_s cn; */ +}; + +/** + * Structure nix_cq_ctx_s + * + * NIX Completion Queue Context Structure This structure contains context + * state maintained by hardware for each CQ in NDC/LLC/DRAM. Software + * uses the same structure format to read and write an CQ context with + * the NIX admin queue. + */ +union nix_cq_ctx_s { + u64 u[4]; + struct nix_cq_ctx_s_s { + u64 base : 64; + u64 reserved_64_67 : 4; + u64 bp_ena : 1; + u64 reserved_69_71 : 3; + u64 bpid : 9; + u64 reserved_81_83 : 3; + u64 qint_idx : 7; + u64 cq_err : 1; + u64 cint_idx : 7; + u64 avg_con : 9; + u64 wrptr : 20; + u64 tail : 20; + u64 head : 20; + u64 avg_level : 8; + u64 update_time : 16; + u64 bp : 8; + u64 drop : 8; + u64 drop_ena : 1; + u64 ena : 1; + u64 reserved_210_211 : 2; + u64 substream : 20; + u64 caching : 1; + u64 reserved_233_235 : 3; + u64 qsize : 4; + u64 cq_err_int : 8; + u64 cq_err_int_ena : 8; + } s; + /* struct nix_cq_ctx_s_s cn; */ +}; + +/** + * Structure nix_cqe_hdr_s + * + * NIX Completion Queue Entry Header Structure This 64-bit structure + * defines the first word of every CQE. It is immediately followed by + * NIX_RX_PARSE_S in a receive CQE, and by NIX_SEND_COMP_S in a send + * completion CQE. Stored in memory as little-endian unless + * NIX_AF_LF()_CFG[BE] is set. + */ +union nix_cqe_hdr_s { + u64 u; + struct nix_cqe_hdr_s_s { + u64 tag : 32; + u64 q : 20; + u64 reserved_52_57 : 6; + u64 node : 2; + u64 cqe_type : 4; + } s; + /* struct nix_cqe_hdr_s_s cn; */ +}; + +/** + * Structure nix_inst_hdr_s + * + * NIX Instruction Header Structure This structure defines the + * instruction header that precedes the packet header supplied to NPC for + * packets to be transmitted by NIX. + */ +union nix_inst_hdr_s { + u64 u; + struct nix_inst_hdr_s_s { + u64 pf_func : 16; + u64 sq : 20; + u64 reserved_36_63 : 28; + } s; + /* struct nix_inst_hdr_s_s cn; */ +}; + +/** + * Structure nix_iova_s + * + * NIX I/O Virtual Address Structure + */ +union nix_iova_s { + u64 u; + struct nix_iova_s_s { + u64 addr : 64; + } s; + /* struct nix_iova_s_s cn; */ +}; + +/** + * Structure nix_ipsec_dyno_s + * + * INTERNAL: NIX IPSEC Dynamic Ordering Counter Structure Internal: Not + * used; no IPSEC fast-path. + */ +union nix_ipsec_dyno_s { + u32 u; + struct nix_ipsec_dyno_s_s { + u32 count : 32; + } s; + /* struct nix_ipsec_dyno_s_s cn; */ +}; + +/** + * Structure nix_mem_result_s + * + * NIX Memory Value Structure When + * NIX_SEND_MEM_S[ALG]=NIX_SENDMEMALG_E::SETRSLT, the value written to + * memory is formed with this structure. + */ +union nix_mem_result_s { + u64 u; + struct nix_mem_result_s_s { + u64 v : 1; + u64 color : 2; + u64 reserved_3_63 : 61; + } s; + /* struct nix_mem_result_s_s cn; */ +}; + +/** + * Structure nix_op_q_wdata_s + * + * NIX Statistics Operation Write Data Structure This structure specifies + * the write data format of an atomic 64-bit load-and-add of some + * NIX_LF_RQ_OP_*, NIX_LF_SQ_OP* and NIX_LF_CQ_OP* registers. + */ +union nix_op_q_wdata_s { + u64 u; + struct nix_op_q_wdata_s_s { + u64 reserved_0_31 : 32; + u64 q : 20; + u64 reserved_52_63 : 12; + } s; + /* struct nix_op_q_wdata_s_s cn; */ +}; + +/** + * Structure nix_qint_hw_s + * + * NIX Queue Interrupt Context Hardware Structure This structure contains + * context state maintained by hardware for each queue interrupt (QINT) + * in NDC/LLC/DRAM. Software accesses this structure with the + * NIX_LF_QINT()* registers. Hardware maintains a table of + * NIX_AF_CONST2[QINTS] contiguous NIX_QINT_HW_S structures per LF + * starting at IOVA NIX_AF_LF()_QINTS_BASE. Always stored in byte + * invariant little-endian format (LE8). + */ +union nix_qint_hw_s { + u32 u; + struct nix_qint_hw_s_s { + u32 count : 22; + u32 reserved_22_30 : 9; + u32 ena : 1; + } s; + /* struct nix_qint_hw_s_s cn; */ +}; + +/** + * Structure nix_rq_ctx_hw_s + * + * NIX Receive Queue Context Structure This structure contains context + * state maintained by hardware for each RQ in NDC/LLC/DRAM. Software + * uses the equivalent NIX_RQ_CTX_S structure format to read and write an + * RQ context with the NIX admin queue. Always stored in byte invariant + * little-endian format (LE8). + */ +union nix_rq_ctx_hw_s { + u64 u[16]; + struct nix_rq_ctx_hw_s_s { + u64 ena : 1; + u64 sso_ena : 1; + u64 ipsech_ena : 1; + u64 ena_wqwd : 1; + u64 cq : 20; + u64 substream : 20; + u64 wqe_aura : 20; + u64 spb_aura : 20; + u64 lpb_aura : 20; + u64 sso_grp : 10; + u64 sso_tt : 2; + u64 pb_caching : 2; + u64 wqe_caching : 1; + u64 xqe_drop_ena : 1; + u64 spb_drop_ena : 1; + u64 lpb_drop_ena : 1; + u64 wqe_skip : 2; + u64 reserved_124_127 : 4; + u64 reserved_128_139 : 12; + u64 spb_sizem1 : 6; + u64 reserved_146_150 : 5; + u64 spb_ena : 1; + u64 lpb_sizem1 : 12; + u64 first_skip : 7; + u64 reserved_171 : 1; + u64 later_skip : 6; + u64 xqe_imm_size : 6; + u64 reserved_184_189 : 6; + u64 xqe_imm_copy : 1; + u64 xqe_hdr_split : 1; + u64 xqe_drop : 8; + u64 xqe_pass : 8; + u64 wqe_pool_drop : 8; + u64 wqe_pool_pass : 8; + u64 spb_aura_drop : 8; + u64 spb_aura_pass : 8; + u64 spb_pool_drop : 8; + u64 spb_pool_pass : 8; + u64 lpb_aura_drop : 8; + u64 lpb_aura_pass : 8; + u64 lpb_pool_drop : 8; + u64 lpb_pool_pass : 8; + u64 reserved_288_319 : 32; + u64 ltag : 24; + u64 good_utag : 8; + u64 bad_utag : 8; + u64 flow_tagw : 6; + u64 reserved_366_383 : 18; + u64 octs : 48; + u64 reserved_432_447 : 16; + u64 pkts : 48; + u64 reserved_496_511 : 16; + u64 drop_octs : 48; + u64 reserved_560_575 : 16; + u64 drop_pkts : 48; + u64 reserved_624_639 : 16; + u64 re_pkts : 48; + u64 reserved_688_702 : 15; + u64 ena_copy : 1; + u64 reserved_704_739 : 36; + u64 rq_int : 8; + u64 rq_int_ena : 8; + u64 qint_idx : 7; + u64 reserved_763_767 : 5; + u64 reserved_768_831 : 64; + u64 reserved_832_895 : 64; + u64 reserved_896_959 : 64; + u64 reserved_960_1023 : 64; + } s; + /* struct nix_rq_ctx_hw_s_s cn; */ +}; + +/** + * Structure nix_rq_ctx_s + * + * NIX Receive Queue Context Structure This structure specifies the + * format used by software to read and write an RQ context with the NIX + * admin queue. + */ +union nix_rq_ctx_s { + u64 u[16]; + struct nix_rq_ctx_s_s { + u64 ena : 1; + u64 sso_ena : 1; + u64 ipsech_ena : 1; + u64 ena_wqwd : 1; + u64 cq : 20; + u64 substream : 20; + u64 wqe_aura : 20; + u64 spb_aura : 20; + u64 lpb_aura : 20; + u64 sso_grp : 10; + u64 sso_tt : 2; + u64 pb_caching : 2; + u64 wqe_caching : 1; + u64 xqe_drop_ena : 1; + u64 spb_drop_ena : 1; + u64 lpb_drop_ena : 1; + u64 reserved_122_127 : 6; + u64 reserved_128_139 : 12; + u64 spb_sizem1 : 6; + u64 wqe_skip : 2; + u64 reserved_148_150 : 3; + u64 spb_ena : 1; + u64 lpb_sizem1 : 12; + u64 first_skip : 7; + u64 reserved_171 : 1; + u64 later_skip : 6; + u64 xqe_imm_size : 6; + u64 reserved_184_189 : 6; + u64 xqe_imm_copy : 1; + u64 xqe_hdr_split : 1; + u64 xqe_drop : 8; + u64 xqe_pass : 8; + u64 wqe_pool_drop : 8; + u64 wqe_pool_pass : 8; + u64 spb_aura_drop : 8; + u64 spb_aura_pass : 8; + u64 spb_pool_drop : 8; + u64 spb_pool_pass : 8; + u64 lpb_aura_drop : 8; + u64 lpb_aura_pass : 8; + u64 lpb_pool_drop : 8; + u64 lpb_pool_pass : 8; + u64 reserved_288_291 : 4; + u64 rq_int : 8; + u64 rq_int_ena : 8; + u64 qint_idx : 7; + u64 reserved_315_319 : 5; + u64 ltag : 24; + u64 good_utag : 8; + u64 bad_utag : 8; + u64 flow_tagw : 6; + u64 reserved_366_383 : 18; + u64 octs : 48; + u64 reserved_432_447 : 16; + u64 pkts : 48; + u64 reserved_496_511 : 16; + u64 drop_octs : 48; + u64 reserved_560_575 : 16; + u64 drop_pkts : 48; + u64 reserved_624_639 : 16; + u64 re_pkts : 48; + u64 reserved_688_703 : 16; + u64 reserved_704_767 : 64; + u64 reserved_768_831 : 64; + u64 reserved_832_895 : 64; + u64 reserved_896_959 : 64; + u64 reserved_960_1023 : 64; + } s; + /* struct nix_rq_ctx_s_s cn; */ +}; + +/** + * Structure nix_rsse_s + * + * NIX Receive Side Scaling Entry Structure This structure specifies the + * format of each hardware entry in the NIX RSS tables in NDC/LLC/DRAM. + * See NIX_AF_LF()_RSS_BASE and NIX_AF_LF()_RSS_GRP(). Software uses the + * same structure format to read and write an RSS table entry with the + * NIX admin queue. + */ +union nix_rsse_s { + u32 u; + struct nix_rsse_s_s { + u32 rq : 20; + u32 reserved_20_31 : 12; + } s; + /* struct nix_rsse_s_s cn; */ +}; + +/** + * Structure nix_rx_action_s + * + * NIX Receive Action Structure This structure defines the format of + * NPC_RESULT_S[ACTION] for a receive packet. + */ +union nix_rx_action_s { + u64 u; + struct nix_rx_action_s_s { + u64 op : 4; + u64 pf_func : 16; + u64 index : 20; + u64 match_id : 16; + u64 flow_key_alg : 5; + u64 reserved_61_63 : 3; + } s; + /* struct nix_rx_action_s_s cn; */ +}; + +/** + * Structure nix_rx_imm_s + * + * NIX Receive Immediate Subdescriptor Structure The receive immediate + * subdescriptor indicates that bytes immediately following this + * NIX_RX_IMM_S (after skipping [APAD] bytes) were saved from the + * received packet. The next subdescriptor following this NIX_RX_IMM_S + * (when one exists) will follow the immediate bytes, after rounding up + * the address to a multiple of 16 bytes. + */ +union nix_rx_imm_s { + u64 u; + struct nix_rx_imm_s_s { + u64 size : 16; + u64 apad : 3; + u64 reserved_19_59 : 41; + u64 subdc : 4; + } s; + /* struct nix_rx_imm_s_s cn; */ +}; + +/** + * Structure nix_rx_mce_s + * + * NIX Receive Multicast/Mirror Entry Structure This structure specifies + * the format of entries in the NIX receive multicast/mirror table + * maintained by hardware in NDC/LLC/DRAM. See NIX_AF_RX_MCAST_BASE and + * NIX_AF_RX_MCAST_CFG. Note the table may contain both multicast and + * mirror replication lists. Software uses the same structure format to + * read and write a multicast/mirror table entry with the NIX admin + * queue. + */ +union nix_rx_mce_s { + u64 u; + struct nix_rx_mce_s_s { + u64 op : 2; + u64 reserved_2 : 1; + u64 eol : 1; + u64 index : 20; + u64 reserved_24_31 : 8; + u64 pf_func : 16; + u64 next : 16; + } s; + /* struct nix_rx_mce_s_s cn; */ +}; + +/** + * Structure nix_rx_parse_s + * + * NIX Receive Parse Structure This structure contains the receive packet + * parse result. It immediately follows NIX_CQE_HDR_S in a receive CQE, + * or NIX_WQE_HDR_S in a receive WQE. Stored in memory as little-endian + * unless NIX_AF_LF()_CFG[BE] is set. Header layers are always 2-byte + * aligned, so all header pointers in this structure ([EOH_PTR], [LAPTR] + * through [LHPTR], [VTAG*_PTR]) are even. + */ +union nix_rx_parse_s { + u64 u[7]; + struct nix_rx_parse_s_s { + u64 chan : 12; + u64 desc_sizem1 : 5; + u64 imm_copy : 1; + u64 express : 1; + u64 wqwd : 1; + u64 errlev : 4; + u64 errcode : 8; + u64 latype : 4; + u64 lbtype : 4; + u64 lctype : 4; + u64 ldtype : 4; + u64 letype : 4; + u64 lftype : 4; + u64 lgtype : 4; + u64 lhtype : 4; + u64 pkt_lenm1 : 16; + u64 l2m : 1; + u64 l2b : 1; + u64 l3m : 1; + u64 l3b : 1; + u64 vtag0_valid : 1; + u64 vtag0_gone : 1; + u64 vtag1_valid : 1; + u64 vtag1_gone : 1; + u64 pkind : 6; + u64 reserved_94_95 : 2; + u64 vtag0_tci : 16; + u64 vtag1_tci : 16; + u64 laflags : 8; + u64 lbflags : 8; + u64 lcflags : 8; + u64 ldflags : 8; + u64 leflags : 8; + u64 lfflags : 8; + u64 lgflags : 8; + u64 lhflags : 8; + u64 eoh_ptr : 8; + u64 wqe_aura : 20; + u64 pb_aura : 20; + u64 match_id : 16; + u64 laptr : 8; + u64 lbptr : 8; + u64 lcptr : 8; + u64 ldptr : 8; + u64 leptr : 8; + u64 lfptr : 8; + u64 lgptr : 8; + u64 lhptr : 8; + u64 vtag0_ptr : 8; + u64 vtag1_ptr : 8; + u64 flow_key_alg : 5; + u64 reserved_341_383 : 43; + u64 reserved_384_447 : 64; + } s; + /* struct nix_rx_parse_s_s cn; */ +}; + +/** + * Structure nix_rx_sg_s + * + * NIX Receive Scatter/Gather Subdescriptor Structure The receive + * scatter/gather subdescriptor specifies one to three segments of packet + * data bytes. There may be multiple NIX_RX_SG_Ss in each NIX receive + * descriptor. NIX_RX_SG_S is immediately followed by one NIX_IOVA_S + * word when [SEGS] = 1, three NIX_IOVA_S words when [SEGS] >= 2. Each + * NIX_IOVA_S word specifies the LF IOVA of first packet data byte in the + * corresponding segment; first NIX_IOVA_S word for segment 1, second + * word for segment 2, third word for segment 3. Note the third word is + * present when [SEGS] >= 2 but only valid when [SEGS] = 3. + */ +union nix_rx_sg_s { + u64 u; + struct nix_rx_sg_s_s { + u64 seg1_size : 16; + u64 seg2_size : 16; + u64 seg3_size : 16; + u64 segs : 2; + u64 reserved_50_59 : 10; + u64 subdc : 4; + } s; + /* struct nix_rx_sg_s_s cn; */ +}; + +/** + * Structure nix_rx_vtag_action_s + * + * NIX Receive Vtag Action Structure This structure defines the format of + * NPC_RESULT_S[VTAG_ACTION] for a receive packet. It specifies up to two + * Vtags (e.g. C-VLAN/S-VLAN tags, 802.1BR E-TAG) for optional capture + * and/or stripping. + */ +union nix_rx_vtag_action_s { + u64 u; + struct nix_rx_vtag_action_s_s { + u64 vtag0_relptr : 8; + u64 vtag0_lid : 3; + u64 reserved_11 : 1; + u64 vtag0_type : 3; + u64 vtag0_valid : 1; + u64 reserved_16_31 : 16; + u64 vtag1_relptr : 8; + u64 vtag1_lid : 3; + u64 reserved_43 : 1; + u64 vtag1_type : 3; + u64 vtag1_valid : 1; + u64 reserved_48_63 : 16; + } s; + /* struct nix_rx_vtag_action_s_s cn; */ +}; + +/** + * Structure nix_send_comp_s + * + * NIX Send Completion Structure This structure immediately follows + * NIX_CQE_HDR_S in a send completion CQE. + */ +union nix_send_comp_s { + u64 u; + struct nix_send_comp_s_s { + u64 status : 8; + u64 sqe_id : 16; + u64 reserved_24_63 : 40; + } s; + /* struct nix_send_comp_s_s cn; */ +}; + +/** + * Structure nix_send_crc_s + * + * NIX Send CRC Subdescriptor Structure The send CRC subdescriptor + * specifies a CRC calculation be performed during transmission. Ignored + * when present in a send descriptor with NIX_SEND_EXT_S[LSO] set. There + * may be up to two NIX_SEND_CRC_Ss per send descriptor. NIX_SEND_CRC_S + * constraints: * When present, NIX_SEND_CRC_S subdescriptors must + * precede all NIX_SEND_SG_S, NIX_SEND_IMM_S and NIX_SEND_MEM_S + * subdescriptors in the send descriptor. * NIX_SEND_CRC_S subdescriptors + * must follow the same order as their checksum and insert regions in the + * packet, i.e. the checksum and insert regions of a NIX_SEND_CRC_S must + * come after the checksum and insert regions of a preceding + * NIX_SEND_CRC_S. There must be no overlap between any NIX_SEND_CRC_S + * checksum and insert regions. * If either + * NIX_SEND_HDR_S[OL4TYPE,IL4TYPE] = NIX_SENDL4TYPE_E::SCTP_CKSUM, the + * SCTP checksum region and NIX_SEND_CRC_S insert region must not + * overlap, and likewise the NIX_SEND_CRC_S checksum region and SCTP + * insert region must not overlap. * If either + * NIX_SEND_HDR_S[OL3TYPE,IL3TYPE] = NIX_SENDL3TYPE_E::IP4_CKSUM, the + * IPv4 header checksum region and NIX_SEND_CRC_S insert region must not + * overlap. * Any checksums inserted by + * NIX_SEND_HDR_S[OL3TYPE,OL4TYPE,IL3TYPE,IL4TYPE] must be outside of the + * NIX_SEND_CRC_S checksum and insert regions. Hardware adjusts [START], + * [SIZE] and [INSERT] as needed to account for any VLAN inserted by + * NIX_SEND_EXT_S[VLAN*] or Vtag inserted by NIX_TX_VTAG_ACTION_S. + */ +union nix_send_crc_s { + u64 u[2]; + struct nix_send_crc_s_s { + u64 size : 16; + u64 start : 16; + u64 insert : 16; + u64 reserved_48_57 : 10; + u64 alg : 2; + u64 subdc : 4; + u64 iv : 32; + u64 reserved_96_127 : 32; + } s; + /* struct nix_send_crc_s_s cn; */ +}; + +/** + * Structure nix_send_ext_s + * + * NIX Send Extended Header Subdescriptor Structure The send extended + * header specifies LSO, VLAN insertion, timestamp and/or scheduling + * services on the packet. If present, it must immediately follow + * NIX_SEND_HDR_S. All fields are assumed to be zero when this + * subdescriptor is not present. + */ +union nix_send_ext_s { + u64 u[2]; + struct nix_send_ext_s_s { + u64 lso_mps : 14; + u64 lso : 1; + u64 tstmp : 1; + u64 lso_sb : 8; + u64 lso_format : 5; + u64 reserved_29_31 : 3; + u64 shp_chg : 9; + u64 shp_dis : 1; + u64 shp_ra : 2; + u64 markptr : 8; + u64 markform : 7; + u64 mark_en : 1; + u64 subdc : 4; + u64 vlan0_ins_ptr : 8; + u64 vlan0_ins_tci : 16; + u64 vlan1_ins_ptr : 8; + u64 vlan1_ins_tci : 16; + u64 vlan0_ins_ena : 1; + u64 vlan1_ins_ena : 1; + u64 reserved_114_127 : 14; + } s; + /* struct nix_send_ext_s_s cn; */ +}; + +/** + * Structure nix_send_hdr_s + * + * NIX Send Header Subdescriptor Structure The send header is the first + * subdescriptor of every send descriptor. + */ +union nix_send_hdr_s { + u64 u[2]; + struct nix_send_hdr_s_s { + u64 total : 18; + u64 reserved_18 : 1; + u64 df : 1; + u64 aura : 20; + u64 sizem1 : 3; + u64 pnc : 1; + u64 sq : 20; + u64 ol3ptr : 8; + u64 ol4ptr : 8; + u64 il3ptr : 8; + u64 il4ptr : 8; + u64 ol3type : 4; + u64 ol4type : 4; + u64 il3type : 4; + u64 il4type : 4; + u64 sqe_id : 16; + } s; + /* struct nix_send_hdr_s_s cn; */ +}; + +/** + * Structure nix_send_imm_s + * + * NIX Send Immediate Subdescriptor Structure The send immediate + * subdescriptor requests that bytes immediately following this + * NIX_SEND_IMM_S (after skipping [APAD] bytes) are to be included in the + * packet data. The next subdescriptor following this NIX_SEND_IMM_S + * (when one exists) will follow the immediate bytes, after rounding up + * the address to a multiple of 16 bytes. There may be multiple + * NIX_SEND_IMM_S in one NIX send descriptor. A NIX_SEND_IMM_S is ignored + * in a NIX send descriptor if the sum of all prior + * NIX_SEND_SG_S[SEG*_SIZE]s and NIX_SEND_IMM_S[SIZE]s meets or exceeds + * NIX_SEND_HDR_S[TOTAL]. When NIX_SEND_EXT_S[LSO] is set in the + * descriptor, all NIX_SEND_IMM_S bytes must be included in the first + * NIX_SEND_EXT_S[LSO_SB] bytes of the source packet. + */ +union nix_send_imm_s { + u64 u; + struct nix_send_imm_s_s { + u64 size : 16; + u64 apad : 3; + u64 reserved_19_59 : 41; + u64 subdc : 4; + } s; + /* struct nix_send_imm_s_s cn; */ +}; + +/** + * Structure nix_send_jump_s + * + * NIX Send Jump Subdescriptor Structure The send jump subdescriptor + * selects a new address for fetching the remaining subdescriptors of a + * send descriptor. This allows software to create a send descriptor + * longer than SQE size selected by NIX_SQ_CTX_S[MAX_SQE_SIZE]. There + * can be only one NIX_SEND_JUMP_S subdescriptor in a send descriptor. If + * present, it must immediately follow NIX_SEND_HDR_S if NIX_SEND_EXT_S + * is not present, else it must immediately follow NIX_SEND_EXT_S. In + * either case, it must terminate the SQE enqueued by software. + */ +union nix_send_jump_s { + u64 u[2]; + struct nix_send_jump_s_s { + u64 sizem1 : 7; + u64 reserved_7_13 : 7; + u64 ld_type : 2; + u64 aura : 20; + u64 reserved_36_58 : 23; + u64 f : 1; + u64 subdc : 4; + u64 addr : 64; + } s; + /* struct nix_send_jump_s_s cn; */ +}; + +/** + * Structure nix_send_mem_s + * + * NIX Send Memory Subdescriptor Structure The send memory subdescriptor + * atomically sets, increments or decrements a memory location. + * NIX_SEND_MEM_S subdescriptors must follow all NIX_SEND_SG_S and + * NIX_SEND_IMM_S subdescriptors in the NIX send descriptor. NIX will not + * initiate the memory update for this subdescriptor until after it has + * completed all LLC/DRAM fetches that service all prior NIX_SEND_SG_S + * subdescriptors. The memory update is executed once, even if the packet + * is replicated due to NIX_TX_ACTION_S[OP] = NIX_TX_ACTIONOP_E::MCAST. + * Performance is best if a memory decrement by one is used rather than + * any other memory set/increment/decrement. (Less internal bus bandwidth + * is used with memory decrements by one.) When NIX_SEND_EXT_S[LSO] is + * set in the descriptor, NIX executes the memory update only while + * processing the last LSO segment, after processing prior segments. + */ +union nix_send_mem_s { + u64 u[2]; + struct nix_send_mem_s_s { + u64 offset : 16; + u64 reserved_16_52 : 37; + u64 wmem : 1; + u64 dsz : 2; + u64 alg : 4; + u64 subdc : 4; + u64 addr : 64; + } s; + /* struct nix_send_mem_s_s cn; */ +}; + +/** + * Structure nix_send_sg_s + * + * NIX Send Scatter/Gather Subdescriptor Structure The send + * scatter/gather subdescriptor requests one to three segments of packet + * data bytes to be transmitted. There may be multiple NIX_SEND_SG_Ss in + * each NIX send descriptor. NIX_SEND_SG_S is immediately followed by + * one NIX_IOVA_S word when [SEGS] = 1, three NIX_IOVA_S words when + * [SEGS] >= 2. Each NIX_IOVA_S word specifies the LF IOVA of first + * packet data byte in the corresponding segment; first NIX_IOVA_S word + * for segment 1, second word for segment 2, third word for segment 3. + * Note the third word is present when [SEGS] >= 2 but only valid when + * [SEGS] = 3. If the sum of all prior NIX_SEND_SG_S[SEG*_SIZE]s and + * NIX_SEND_IMM_S[SIZE]s meets or exceeds NIX_SEND_HDR_S[TOTAL], this + * subdescriptor will not contribute any packet data but may free buffers + * to NPA (see [I1]). + */ +union nix_send_sg_s { + u64 u; + struct nix_send_sg_s_s { + u64 seg1_size : 16; + u64 seg2_size : 16; + u64 seg3_size : 16; + u64 segs : 2; + u64 reserved_50_54 : 5; + u64 i1 : 1; + u64 i2 : 1; + u64 i3 : 1; + u64 ld_type : 2; + u64 subdc : 4; + } s; + /* struct nix_send_sg_s_s cn; */ +}; + +/** + * Structure nix_send_work_s + * + * NIX Send Work Subdescriptor Structure This subdescriptor adds work to + * the SSO. At most one NIX_SEND_WORK_S subdescriptor can exist in the + * NIX send descriptor. If a NIX_SEND_WORK_S exists in the descriptor, it + * must be the last subdescriptor. NIX will not initiate the work add for + * this subdescriptor until after (1) it has completed all LLC/DRAM + * fetches that service all prior NIX_SEND_SG_S subdescriptors, (2) it + * has fetched all subdescriptors in the descriptor, and (3) all + * NIX_SEND_MEM_S[WMEM]=1 LLC/DRAM updates have completed. Provided the + * path of descriptors from the SQ through NIX to an output FIFO is + * unmodified between the descriptors (as should normally be the case, + * but it is possible for software to change the path), NIX also (1) will + * submit the SSO add works from all descriptors in the SQ in order, and + * (2) will not submit an SSO work add until after all prior descriptors + * in the SQ have completed their NIX_SEND_SG_S processing, and (3) will + * not submit an SSO work add until after it has fetched all + * subdescriptors from prior descriptors in the SQ. When + * NIX_SEND_EXT_S[LSO] is set in the descriptor, NIX executes the + * NIX_SEND_WORK_S work add only while processing the last LSO segment, + * after processing prior segments. Hardware ignores NIX_SEND_WORK_S + * when NIX_SQ_CTX_S[SSO_ENA] is clear. + */ +union nix_send_work_s { + u64 u[2]; + struct nix_send_work_s_s { + u64 tag : 32; + u64 tt : 2; + u64 grp : 10; + u64 reserved_44_59 : 16; + u64 subdc : 4; + u64 addr : 64; + } s; + /* struct nix_send_work_s_s cn; */ +}; + +/** + * Structure nix_sq_ctx_hw_s + * + * NIX SQ Context Hardware Structure This structure contains context + * state maintained by hardware for each SQ in NDC/LLC/DRAM. Software + * uses the equivalent NIX_SQ_CTX_S structure format to read and write an + * SQ context with the NIX admin queue. Always stored in byte invariant + * little-endian format (LE8). + */ +union nix_sq_ctx_hw_s { + u64 u[16]; + struct nix_sq_ctx_hw_s_s { + u64 ena : 1; + u64 substream : 20; + u64 max_sqe_size : 2; + u64 sqe_way_mask : 16; + u64 sqb_aura : 20; + u64 gbl_rsvd1 : 5; + u64 cq_id : 20; + u64 cq_ena : 1; + u64 qint_idx : 6; + u64 gbl_rsvd2 : 1; + u64 sq_int : 8; + u64 sq_int_ena : 8; + u64 xoff : 1; + u64 sqe_stype : 2; + u64 gbl_rsvd : 17; + u64 head_sqb : 64; + u64 head_offset : 6; + u64 sqb_dequeue_count : 16; + u64 default_chan : 12; + u64 sdp_mcast : 1; + u64 sso_ena : 1; + u64 dse_rsvd1 : 28; + u64 sqb_enqueue_count : 16; + u64 tail_offset : 6; + u64 lmt_dis : 1; + u64 smq_rr_quantum : 24; + u64 dnq_rsvd1 : 17; + u64 tail_sqb : 64; + u64 next_sqb : 64; + u64 mnq_dis : 1; + u64 smq : 9; + u64 smq_pend : 1; + u64 smq_next_sq : 20; + u64 smq_next_sq_vld : 1; + u64 scm1_rsvd2 : 32; + u64 smenq_sqb : 64; + u64 smenq_offset : 6; + u64 cq_limit : 8; + u64 smq_rr_count : 25; + u64 scm_lso_rem : 18; + u64 scm_dq_rsvd0 : 7; + u64 smq_lso_segnum : 8; + u64 vfi_lso_total : 18; + u64 vfi_lso_sizem1 : 3; + u64 vfi_lso_sb : 8; + u64 vfi_lso_mps : 14; + u64 vfi_lso_vlan0_ins_ena : 1; + u64 vfi_lso_vlan1_ins_ena : 1; + u64 vfi_lso_vld : 1; + u64 smenq_next_sqb_vld : 1; + u64 scm_dq_rsvd1 : 9; + u64 smenq_next_sqb : 64; + u64 seb_rsvd1 : 64; + u64 drop_pkts : 48; + u64 drop_octs_lsw : 16; + u64 drop_octs_msw : 32; + u64 pkts_lsw : 32; + u64 pkts_msw : 16; + u64 octs : 48; + } s; + /* struct nix_sq_ctx_hw_s_s cn; */ +}; + +/** + * Structure nix_sq_ctx_s + * + * NIX Send Queue Context Structure This structure specifies the format + * used by software with the NIX admin queue to read and write a send + * queue's NIX_SQ_CTX_HW_S structure maintained by hardware in + * NDC/LLC/DRAM. The SQ statistics ([OCTS], [PKTS], [DROP_OCTS], + * [DROP_PKTS]) do not account for packet replication due to + * NIX_TX_ACTION_S[OP] = NIX_TX_ACTIONOP_E::MCAST. + */ +union nix_sq_ctx_s { + u64 u[16]; + struct nix_sq_ctx_s_s { + u64 ena : 1; + u64 qint_idx : 6; + u64 substream : 20; + u64 sdp_mcast : 1; + u64 cq : 20; + u64 sqe_way_mask : 16; + u64 smq : 9; + u64 cq_ena : 1; + u64 xoff : 1; + u64 sso_ena : 1; + u64 smq_rr_quantum : 24; + u64 default_chan : 12; + u64 sqb_count : 16; + u64 smq_rr_count : 25; + u64 sqb_aura : 20; + u64 sq_int : 8; + u64 sq_int_ena : 8; + u64 sqe_stype : 2; + u64 reserved_191 : 1; + u64 max_sqe_size : 2; + u64 cq_limit : 8; + u64 lmt_dis : 1; + u64 mnq_dis : 1; + u64 smq_next_sq : 20; + u64 smq_lso_segnum : 8; + u64 tail_offset : 6; + u64 smenq_offset : 6; + u64 head_offset : 6; + u64 smenq_next_sqb_vld : 1; + u64 smq_pend : 1; + u64 smq_next_sq_vld : 1; + u64 reserved_253_255 : 3; + u64 next_sqb : 64; + u64 tail_sqb : 64; + u64 smenq_sqb : 64; + u64 smenq_next_sqb : 64; + u64 head_sqb : 64; + u64 reserved_576_583 : 8; + u64 vfi_lso_total : 18; + u64 vfi_lso_sizem1 : 3; + u64 vfi_lso_sb : 8; + u64 vfi_lso_mps : 14; + u64 vfi_lso_vlan0_ins_ena : 1; + u64 vfi_lso_vlan1_ins_ena : 1; + u64 vfi_lso_vld : 1; + u64 reserved_630_639 : 10; + u64 scm_lso_rem : 18; + u64 reserved_658_703 : 46; + u64 octs : 48; + u64 reserved_752_767 : 16; + u64 pkts : 48; + u64 reserved_816_831 : 16; + u64 reserved_832_895 : 64; + u64 drop_octs : 48; + u64 reserved_944_959 : 16; + u64 drop_pkts : 48; + u64 reserved_1008_1023 : 16; + } s; + /* struct nix_sq_ctx_s_s cn; */ +}; + +/** + * Structure nix_tx_action_s + * + * NIX Transmit Action Structure This structure defines the format of + * NPC_RESULT_S[ACTION] for a transmit packet. + */ +union nix_tx_action_s { + u64 u; + struct nix_tx_action_s_s { + u64 op : 4; + u64 reserved_4_11 : 8; + u64 index : 20; + u64 match_id : 16; + u64 reserved_48_63 : 16; + } s; + /* struct nix_tx_action_s_s cn; */ +}; + +/** + * Structure nix_tx_vtag_action_s + * + * NIX Transmit Vtag Action Structure This structure defines the format + * of NPC_RESULT_S[VTAG_ACTION] for a transmit packet. It specifies the + * optional insertion or replacement of up to two Vtags (e.g. + * C-VLAN/S-VLAN tags, 802.1BR E-TAG). If two Vtags are specified: * The + * Vtag 0 byte offset from packet start (see [VTAG0_RELPTR]) must be less + * than or equal to the Vtag 1 byte offset. * Hardware executes the Vtag + * 0 action first, Vtag 1 action second. * If Vtag 0 is inserted, + * hardware adjusts the Vtag 1 byte offset accordingly. Thus, if the two + * offsets are equal in the structure, hardware inserts Vtag 1 + * immediately after Vtag 0 in the packet. A Vtag must not be inserted + * or replaced within an outer or inner L3/L4 header, but may be inserted + * or replaced within an outer L4 payload. + */ +union nix_tx_vtag_action_s { + u64 u; + struct nix_tx_vtag_action_s_s { + u64 vtag0_relptr : 8; + u64 vtag0_lid : 3; + u64 reserved_11 : 1; + u64 vtag0_op : 2; + u64 reserved_14_15 : 2; + u64 vtag0_def : 10; + u64 reserved_26_31 : 6; + u64 vtag1_relptr : 8; + u64 vtag1_lid : 3; + u64 reserved_43 : 1; + u64 vtag1_op : 2; + u64 reserved_46_47 : 2; + u64 vtag1_def : 10; + u64 reserved_58_63 : 6; + } s; + /* struct nix_tx_vtag_action_s_s cn; */ +}; + +/** + * Structure nix_wqe_hdr_s + * + * NIX Work Queue Entry Header Structure This 64-bit structure defines + * the first word of every receive WQE generated by NIX. It is + * immediately followed by NIX_RX_PARSE_S. Stored in memory as little- + * endian unless NIX_AF_LF()_CFG[BE] is set. + */ +union nix_wqe_hdr_s { + u64 u; + struct nix_wqe_hdr_s_s { + u64 tag : 32; + u64 tt : 2; + u64 grp : 10; + u64 node : 2; + u64 q : 14; + u64 wqe_type : 4; + } s; + /* struct nix_wqe_hdr_s_s cn; */ +}; + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_base + * + * NIX AF Admin Queue Base Address Register + */ +union nixx_af_aq_base { + u64 u; + struct nixx_af_aq_base_s { + u64 reserved_0_6 : 7; + u64 base_addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_aq_base_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_BASE(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_BASE(void) +{ + return 0x410; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_cfg + * + * NIX AF Admin Queue Configuration Register + */ +union nixx_af_aq_cfg { + u64 u; + struct nixx_af_aq_cfg_s { + u64 qsize : 4; + u64 reserved_4_63 : 60; + } s; + /* struct nixx_af_aq_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_CFG(void) +{ + return 0x400; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_done + * + * NIX AF Admin Queue Done Count Register + */ +union nixx_af_aq_done { + u64 u; + struct nixx_af_aq_done_s { + u64 done : 20; + u64 reserved_20_63 : 44; + } s; + /* struct nixx_af_aq_done_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_DONE(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_DONE(void) +{ + return 0x450; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_done_ack + * + * NIX AF Admin Queue Done Count Ack Register This register is written by + * software to acknowledge interrupts. + */ +union nixx_af_aq_done_ack { + u64 u; + struct nixx_af_aq_done_ack_s { + u64 done_ack : 20; + u64 reserved_20_63 : 44; + } s; + /* struct nixx_af_aq_done_ack_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_DONE_ACK(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_DONE_ACK(void) +{ + return 0x460; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_done_ena_w1c + * + * NIX AF Admin Queue Done Interrupt Enable Clear Register + */ +union nixx_af_aq_done_ena_w1c { + u64 u; + struct nixx_af_aq_done_ena_w1c_s { + u64 done : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_aq_done_ena_w1c_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_DONE_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_DONE_ENA_W1C(void) +{ + return 0x498; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_done_ena_w1s + * + * NIX AF Admin Queue Done Interrupt Enable Set Register + */ +union nixx_af_aq_done_ena_w1s { + u64 u; + struct nixx_af_aq_done_ena_w1s_s { + u64 done : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_aq_done_ena_w1s_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_DONE_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_DONE_ENA_W1S(void) +{ + return 0x490; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_done_int + * + * INTERNAL: NIX AF Admin Queue Done Interrupt Register + */ +union nixx_af_aq_done_int { + u64 u; + struct nixx_af_aq_done_int_s { + u64 done : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_aq_done_int_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_DONE_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_DONE_INT(void) +{ + return 0x480; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_done_int_w1s + * + * INTERNAL: NIX AF Admin Queue Done Interrupt Set Register + */ +union nixx_af_aq_done_int_w1s { + u64 u; + struct nixx_af_aq_done_int_w1s_s { + u64 done : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_aq_done_int_w1s_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_DONE_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_DONE_INT_W1S(void) +{ + return 0x488; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_done_timer + * + * NIX AF Admin Queue Done Interrupt Timer Register + */ +union nixx_af_aq_done_timer { + u64 u; + struct nixx_af_aq_done_timer_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct nixx_af_aq_done_timer_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_DONE_TIMER(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_DONE_TIMER(void) +{ + return 0x470; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_done_wait + * + * NIX AF Admin Queue Done Interrupt Coalescing Wait Register Specifies + * the queue interrupt coalescing settings. + */ +union nixx_af_aq_done_wait { + u64 u; + struct nixx_af_aq_done_wait_s { + u64 num_wait : 20; + u64 reserved_20_31 : 12; + u64 time_wait : 16; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_aq_done_wait_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_DONE_WAIT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_DONE_WAIT(void) +{ + return 0x440; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_door + * + * NIX AF Admin Queue Doorbell Register Software writes to this register + * to enqueue entries to AQ. + */ +union nixx_af_aq_door { + u64 u; + struct nixx_af_aq_door_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct nixx_af_aq_door_s cn; */ +}; + +static inline u64 NIXX_AF_AQ_DOOR(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_DOOR(void) +{ + return 0x430; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_aq_status + * + * NIX AF Admin Queue Status Register + */ +union nixx_af_aq_status { + u64 u; + struct nixx_af_aq_status_s { + u64 reserved_0_3 : 4; + u64 head_ptr : 20; + u64 reserved_24_35 : 12; + u64 tail_ptr : 20; + u64 reserved_56_61 : 6; + u64 aq_busy : 1; + u64 aq_err : 1; + } s; + struct nixx_af_aq_status_cn { + u64 reserved_0_3 : 4; + u64 head_ptr : 20; + u64 reserved_24_31 : 8; + u64 reserved_32_35 : 4; + u64 tail_ptr : 20; + u64 reserved_56_61 : 6; + u64 aq_busy : 1; + u64 aq_err : 1; + } cn; +}; + +static inline u64 NIXX_AF_AQ_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AQ_STATUS(void) +{ + return 0x420; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_avg_delay + * + * NIX AF Queue Average Delay Register + */ +union nixx_af_avg_delay { + u64 u; + struct nixx_af_avg_delay_s { + u64 avg_dly : 19; + u64 reserved_19_23 : 5; + u64 avg_timer : 16; + u64 reserved_40_63 : 24; + } s; + /* struct nixx_af_avg_delay_s cn; */ +}; + +static inline u64 NIXX_AF_AVG_DELAY(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_AVG_DELAY(void) +{ + return 0xe0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_bar2_alias# + * + * NIX Admin Function BAR2 Alias Registers These registers alias to the + * NIX BAR2 registers for the PF and function selected by + * NIX_AF_BAR2_SEL[PF_FUNC]. Internal: Not implemented. Placeholder for + * bug33464. + */ +union nixx_af_bar2_aliasx { + u64 u; + struct nixx_af_bar2_aliasx_s { + u64 data : 64; + } s; + /* struct nixx_af_bar2_aliasx_s cn; */ +}; + +static inline u64 NIXX_AF_BAR2_ALIASX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_BAR2_ALIASX(u64 a) +{ + return 0x9100000 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_bar2_sel + * + * NIX Admin Function BAR2 Select Register This register configures BAR2 + * accesses from the NIX_AF_BAR2_ALIAS() registers in BAR0. Internal: Not + * implemented. Placeholder for bug33464. + */ +union nixx_af_bar2_sel { + u64 u; + struct nixx_af_bar2_sel_s { + u64 alias_pf_func : 16; + u64 alias_ena : 1; + u64 reserved_17_63 : 47; + } s; + /* struct nixx_af_bar2_sel_s cn; */ +}; + +static inline u64 NIXX_AF_BAR2_SEL(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_BAR2_SEL(void) +{ + return 0x9000000; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_blk_rst + * + * NIX AF Block Reset Register + */ +union nixx_af_blk_rst { + u64 u; + struct nixx_af_blk_rst_s { + u64 rst : 1; + u64 reserved_1_62 : 62; + u64 busy : 1; + } s; + /* struct nixx_af_blk_rst_s cn; */ +}; + +static inline u64 NIXX_AF_BLK_RST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_BLK_RST(void) +{ + return 0xb0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_cfg + * + * NIX AF General Configuration Register + */ +union nixx_af_cfg { + u64 u; + struct nixx_af_cfg_s { + u64 force_cond_clk_en : 1; + u64 force_rx_gbl_clk_en : 1; + u64 force_rx_strm_clk_en : 1; + u64 force_cqm_clk_en : 1; + u64 force_seb_clk_en : 1; + u64 force_sqm_clk_en : 1; + u64 force_pse_clk_en : 1; + u64 reserved_7 : 1; + u64 af_be : 1; + u64 calibrate_x2p : 1; + u64 force_intf_clk_en : 1; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CFG(void) +{ + return 0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_cint_delay + * + * NIX AF Completion Interrupt Delay Register + */ +union nixx_af_cint_delay { + u64 u; + struct nixx_af_cint_delay_s { + u64 cint_dly : 10; + u64 reserved_10_15 : 6; + u64 cint_timer : 16; + u64 reserved_32_63 : 32; + } s; + /* struct nixx_af_cint_delay_s cn; */ +}; + +static inline u64 NIXX_AF_CINT_DELAY(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CINT_DELAY(void) +{ + return 0xf0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_cint_timer# + * + * NIX AF Completion Interrupt Timer Registers + */ +union nixx_af_cint_timerx { + u64 u; + struct nixx_af_cint_timerx_s { + u64 expir_time : 16; + u64 cint : 7; + u64 reserved_23 : 1; + u64 lf : 8; + u64 active : 1; + u64 reserved_33_63 : 31; + } s; + /* struct nixx_af_cint_timerx_s cn; */ +}; + +static inline u64 NIXX_AF_CINT_TIMERX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CINT_TIMERX(u64 a) +{ + return 0x1a40 + 0x40000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_const + * + * NIX AF Constants Register This register contains constants for + * software discovery. + */ +union nixx_af_const { + u64 u; + struct nixx_af_const_s { + u64 cgx_lmac_channels : 8; + u64 cgx_lmacs : 4; + u64 num_cgx : 4; + u64 lbk_channels : 8; + u64 num_lbk : 4; + u64 num_sdp : 4; + u64 reserved_32_47 : 16; + u64 links : 8; + u64 intfs : 4; + u64 reserved_60_63 : 4; + } s; + /* struct nixx_af_const_s cn; */ +}; + +static inline u64 NIXX_AF_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CONST(void) +{ + return 0x20; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_const1 + * + * NIX AF Constants 1 Register This register contains constants for + * software discovery. + */ +union nixx_af_const1 { + u64 u; + struct nixx_af_const1_s { + u64 sdp_channels : 12; + u64 rx_bpids : 12; + u64 lf_tx_stats : 8; + u64 lf_rx_stats : 8; + u64 lso_format_fields : 8; + u64 lso_formats : 8; + u64 reserved_56_63 : 8; + } s; + /* struct nixx_af_const1_s cn; */ +}; + +static inline u64 NIXX_AF_CONST1(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CONST1(void) +{ + return 0x28; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_const2 + * + * NIX AF Constants 2 Register This register contains constants for + * software discovery. + */ +union nixx_af_const2 { + u64 u; + struct nixx_af_const2_s { + u64 lfs : 12; + u64 qints : 12; + u64 cints : 12; + u64 reserved_36_63 : 28; + } s; + /* struct nixx_af_const2_s cn; */ +}; + +static inline u64 NIXX_AF_CONST2(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CONST2(void) +{ + return 0x30; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_const3 + * + * NIX AF Constants 2 Register This register contains constants for + * software discovery. + */ +union nixx_af_const3 { + u64 u; + struct nixx_af_const3_s { + u64 sq_ctx_log2bytes : 4; + u64 rq_ctx_log2bytes : 4; + u64 cq_ctx_log2bytes : 4; + u64 rsse_log2bytes : 4; + u64 mce_log2bytes : 4; + u64 qint_log2bytes : 4; + u64 cint_log2bytes : 4; + u64 dyno_log2bytes : 4; + u64 reserved_32_63 : 32; + } s; + /* struct nixx_af_const3_s cn; */ +}; + +static inline u64 NIXX_AF_CONST3(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CONST3(void) +{ + return 0x38; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_cq_const + * + * NIX AF CQ Constants Register This register contains constants for + * software discovery. + */ +union nixx_af_cq_const { + u64 u; + struct nixx_af_cq_const_s { + u64 queues_per_lf : 24; + u64 reserved_24_63 : 40; + } s; + /* struct nixx_af_cq_const_s cn; */ +}; + +static inline u64 NIXX_AF_CQ_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CQ_CONST(void) +{ + return 0x48; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_cqm_bp_test + * + * INTERNAL: NIX AF CQM Backpressure Test Registers + */ +union nixx_af_cqm_bp_test { + u64 u; + struct nixx_af_cqm_bp_test_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 24; + u64 enable : 12; + u64 reserved_52_63 : 12; + } s; + /* struct nixx_af_cqm_bp_test_s cn; */ +}; + +static inline u64 NIXX_AF_CQM_BP_TEST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CQM_BP_TEST(void) +{ + return 0x48c0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_cqm_eco + * + * INTERNAL: AF CQM ECO Register + */ +union nixx_af_cqm_eco { + u64 u; + struct nixx_af_cqm_eco_s { + u64 eco_rw : 64; + } s; + /* struct nixx_af_cqm_eco_s cn; */ +}; + +static inline u64 NIXX_AF_CQM_ECO(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CQM_ECO(void) +{ + return 0x590; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_csi_eco + * + * INTERNAL: AF CSI ECO Register + */ +union nixx_af_csi_eco { + u64 u; + struct nixx_af_csi_eco_s { + u64 eco_rw : 64; + } s; + /* struct nixx_af_csi_eco_s cn; */ +}; + +static inline u64 NIXX_AF_CSI_ECO(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_CSI_ECO(void) +{ + return 0x580; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_err_int + * + * NIX Admin Function Error Interrupt Register + */ +union nixx_af_err_int { + u64 u; + struct nixx_af_err_int_s { + u64 rx_mcast_data_fault : 1; + u64 rx_mirror_data_fault : 1; + u64 rx_mcast_wqe_fault : 1; + u64 rx_mirror_wqe_fault : 1; + u64 rx_mce_fault : 1; + u64 rx_mce_list_err : 1; + u64 rx_unmapped_pf_func : 1; + u64 reserved_7_11 : 5; + u64 aq_door_err : 1; + u64 aq_res_fault : 1; + u64 aq_inst_fault : 1; + u64 reserved_15_63 : 49; + } s; + /* struct nixx_af_err_int_s cn; */ +}; + +static inline u64 NIXX_AF_ERR_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_ERR_INT(void) +{ + return 0x180; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_err_int_ena_w1c + * + * NIX Admin Function Error Interrupt Enable Clear Register This register + * clears interrupt enable bits. + */ +union nixx_af_err_int_ena_w1c { + u64 u; + struct nixx_af_err_int_ena_w1c_s { + u64 rx_mcast_data_fault : 1; + u64 rx_mirror_data_fault : 1; + u64 rx_mcast_wqe_fault : 1; + u64 rx_mirror_wqe_fault : 1; + u64 rx_mce_fault : 1; + u64 rx_mce_list_err : 1; + u64 rx_unmapped_pf_func : 1; + u64 reserved_7_11 : 5; + u64 aq_door_err : 1; + u64 aq_res_fault : 1; + u64 aq_inst_fault : 1; + u64 reserved_15_63 : 49; + } s; + /* struct nixx_af_err_int_ena_w1c_s cn; */ +}; + +static inline u64 NIXX_AF_ERR_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_ERR_INT_ENA_W1C(void) +{ + return 0x198; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_err_int_ena_w1s + * + * NIX Admin Function Error Interrupt Enable Set Register This register + * sets interrupt enable bits. + */ +union nixx_af_err_int_ena_w1s { + u64 u; + struct nixx_af_err_int_ena_w1s_s { + u64 rx_mcast_data_fault : 1; + u64 rx_mirror_data_fault : 1; + u64 rx_mcast_wqe_fault : 1; + u64 rx_mirror_wqe_fault : 1; + u64 rx_mce_fault : 1; + u64 rx_mce_list_err : 1; + u64 rx_unmapped_pf_func : 1; + u64 reserved_7_11 : 5; + u64 aq_door_err : 1; + u64 aq_res_fault : 1; + u64 aq_inst_fault : 1; + u64 reserved_15_63 : 49; + } s; + /* struct nixx_af_err_int_ena_w1s_s cn; */ +}; + +static inline u64 NIXX_AF_ERR_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_ERR_INT_ENA_W1S(void) +{ + return 0x190; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_err_int_w1s + * + * NIX Admin Function Error Interrupt Set Register This register sets + * interrupt bits. + */ +union nixx_af_err_int_w1s { + u64 u; + struct nixx_af_err_int_w1s_s { + u64 rx_mcast_data_fault : 1; + u64 rx_mirror_data_fault : 1; + u64 rx_mcast_wqe_fault : 1; + u64 rx_mirror_wqe_fault : 1; + u64 rx_mce_fault : 1; + u64 rx_mce_list_err : 1; + u64 rx_unmapped_pf_func : 1; + u64 reserved_7_11 : 5; + u64 aq_door_err : 1; + u64 aq_res_fault : 1; + u64 aq_inst_fault : 1; + u64 reserved_15_63 : 49; + } s; + /* struct nixx_af_err_int_w1s_s cn; */ +}; + +static inline u64 NIXX_AF_ERR_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_ERR_INT_W1S(void) +{ + return 0x188; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_expr_tx_fifo_status + * + * INTERNAL: NIX AF Express Transmit FIFO Status Register Internal: + * 802.3br frame preemption/express path is defeatured. Old definition: + * Status of FIFO which transmits express packets to CGX and LBK. + */ +union nixx_af_expr_tx_fifo_status { + u64 u; + struct nixx_af_expr_tx_fifo_status_s { + u64 count : 12; + u64 reserved_12_63 : 52; + } s; + /* struct nixx_af_expr_tx_fifo_status_s cn; */ +}; + +static inline u64 NIXX_AF_EXPR_TX_FIFO_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_EXPR_TX_FIFO_STATUS(void) +{ + return 0x640; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_gen_int + * + * NIX AF General Interrupt Register + */ +union nixx_af_gen_int { + u64 u; + struct nixx_af_gen_int_s { + u64 rx_mcast_drop : 1; + u64 rx_mirror_drop : 1; + u64 reserved_2 : 1; + u64 tl1_drain : 1; + u64 smq_flush_done : 1; + u64 reserved_5_63 : 59; + } s; + /* struct nixx_af_gen_int_s cn; */ +}; + +static inline u64 NIXX_AF_GEN_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_GEN_INT(void) +{ + return 0x160; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_gen_int_ena_w1c + * + * NIX AF General Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union nixx_af_gen_int_ena_w1c { + u64 u; + struct nixx_af_gen_int_ena_w1c_s { + u64 rx_mcast_drop : 1; + u64 rx_mirror_drop : 1; + u64 reserved_2 : 1; + u64 tl1_drain : 1; + u64 smq_flush_done : 1; + u64 reserved_5_63 : 59; + } s; + /* struct nixx_af_gen_int_ena_w1c_s cn; */ +}; + +static inline u64 NIXX_AF_GEN_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_GEN_INT_ENA_W1C(void) +{ + return 0x178; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_gen_int_ena_w1s + * + * NIX AF General Interrupt Enable Set Register This register sets + * interrupt enable bits. + */ +union nixx_af_gen_int_ena_w1s { + u64 u; + struct nixx_af_gen_int_ena_w1s_s { + u64 rx_mcast_drop : 1; + u64 rx_mirror_drop : 1; + u64 reserved_2 : 1; + u64 tl1_drain : 1; + u64 smq_flush_done : 1; + u64 reserved_5_63 : 59; + } s; + /* struct nixx_af_gen_int_ena_w1s_s cn; */ +}; + +static inline u64 NIXX_AF_GEN_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_GEN_INT_ENA_W1S(void) +{ + return 0x170; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_gen_int_w1s + * + * NIX AF General Interrupt Set Register This register sets interrupt + * bits. + */ +union nixx_af_gen_int_w1s { + u64 u; + struct nixx_af_gen_int_w1s_s { + u64 rx_mcast_drop : 1; + u64 rx_mirror_drop : 1; + u64 reserved_2 : 1; + u64 tl1_drain : 1; + u64 smq_flush_done : 1; + u64 reserved_5_63 : 59; + } s; + /* struct nixx_af_gen_int_w1s_s cn; */ +}; + +static inline u64 NIXX_AF_GEN_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_GEN_INT_W1S(void) +{ + return 0x168; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_cfg + * + * NIX AF Local Function Configuration Registers + */ +union nixx_af_lfx_cfg { + u64 u; + struct nixx_af_lfx_cfg_s { + u64 npa_pf_func : 16; + u64 sso_pf_func : 16; + u64 be : 1; + u64 xqe_size : 2; + u64 reserved_35_63 : 29; + } s; + /* struct nixx_af_lfx_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_CFG(u64 a) +{ + return 0x4000 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_cints_base + * + * NIX AF Local Function Completion Interrupts Base Address Registers + * This register specifies the base AF IOVA of LF's completion interrupt + * context table in NDC/LLC/DRAM. The table consists of + * NIX_AF_CONST2[CINTS] contiguous NIX_CINT_HW_S structures. After + * writing to this register, software should read it back to ensure that + * the write has completed before accessing any NIX_LF_CINT()_* + * registers. + */ +union nixx_af_lfx_cints_base { + u64 u; + struct nixx_af_lfx_cints_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_lfx_cints_base_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_CINTS_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_CINTS_BASE(u64 a) +{ + return 0x4130 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_cints_cfg + * + * NIX AF Local Function Completion Interrupts Configuration Registers + * This register controls access to the LF's completion interrupt context + * table in NDC/LLC/DRAM. The table consists of NIX_AF_CONST2[CINTS] + * contiguous NIX_CINT_HW_S structures. The size of each structure is 1 + * << NIX_AF_CONST3[CINT_LOG2BYTES]. After writing to this register, + * software should read it back to ensure that the write has completed + * before accessing any NIX_LF_CINT()_* registers. + */ +union nixx_af_lfx_cints_cfg { + u64 u; + struct nixx_af_lfx_cints_cfg_s { + u64 reserved_0_19 : 20; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_37_63 : 27; + } s; + /* struct nixx_af_lfx_cints_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_CINTS_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_CINTS_CFG(u64 a) +{ + return 0x4120 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_cqs_base + * + * NIX AF Local Function Completion Queues Base Address Register This + * register specifies the base AF IOVA of the LF's CQ context table. The + * table consists of NIX_AF_LF()_CQS_CFG[MAX_QUEUESM1]+1 contiguous + * NIX_CQ_CTX_S structures. + */ +union nixx_af_lfx_cqs_base { + u64 u; + struct nixx_af_lfx_cqs_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_lfx_cqs_base_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_CQS_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_CQS_BASE(u64 a) +{ + return 0x4070 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_cqs_cfg + * + * NIX AF Local Function Completion Queues Configuration Register This + * register configures completion queues in the LF. + */ +union nixx_af_lfx_cqs_cfg { + u64 u; + struct nixx_af_lfx_cqs_cfg_s { + u64 max_queuesm1 : 20; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_37_63 : 27; + } s; + /* struct nixx_af_lfx_cqs_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_CQS_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_CQS_CFG(u64 a) +{ + return 0x4060 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_lock# + * + * NIX AF Local Function Lockdown Registers Internal: The NIX lockdown + * depth of 32 bytes is shallow compared to 96 bytes for NIC and meant + * for outer MAC and/or VLAN (optionally preceded by a small number of + * skip bytes). NPC's MCAM can be used for deeper protocol-aware + * lockdown. + */ +union nixx_af_lfx_lockx { + u64 u; + struct nixx_af_lfx_lockx_s { + u64 data : 32; + u64 bit_ena : 32; + } s; + /* struct nixx_af_lfx_lockx_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_LOCKX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_LOCKX(u64 a, u64 b) +{ + return 0x4300 + 0x20000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_qints_base + * + * NIX AF Local Function Queue Interrupts Base Address Registers This + * register specifies the base AF IOVA of LF's queue interrupt context + * table in NDC/LLC/DRAM. The table consists of NIX_AF_CONST2[QINTS] + * contiguous NIX_QINT_HW_S structures. After writing to this register, + * software should read it back to ensure that the write has completed + * before accessing any NIX_LF_QINT()_* registers. + */ +union nixx_af_lfx_qints_base { + u64 u; + struct nixx_af_lfx_qints_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_lfx_qints_base_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_QINTS_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_QINTS_BASE(u64 a) +{ + return 0x4110 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_qints_cfg + * + * NIX AF Local Function Queue Interrupts Configuration Registers This + * register controls access to the LF's queue interrupt context table in + * NDC/LLC/DRAM. The table consists of NIX_AF_CONST2[QINTS] contiguous + * NIX_QINT_HW_S structures. The size of each structure is 1 << + * NIX_AF_CONST3[QINT_LOG2BYTES]. After writing to this register, + * software should read it back to ensure that the write has completed + * before accessing any NIX_LF_QINT()_* registers. + */ +union nixx_af_lfx_qints_cfg { + u64 u; + struct nixx_af_lfx_qints_cfg_s { + u64 reserved_0_19 : 20; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_37_63 : 27; + } s; + /* struct nixx_af_lfx_qints_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_QINTS_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_QINTS_CFG(u64 a) +{ + return 0x4100 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rqs_base + * + * NIX AF Local Function Receive Queues Base Address Register This + * register specifies the base AF IOVA of the LF's RQ context table. The + * table consists of NIX_AF_LF()_RQS_CFG[MAX_QUEUESM1]+1 contiguous + * NIX_RQ_CTX_S structures. + */ +union nixx_af_lfx_rqs_base { + u64 u; + struct nixx_af_lfx_rqs_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_lfx_rqs_base_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RQS_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RQS_BASE(u64 a) +{ + return 0x4050 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rqs_cfg + * + * NIX AF Local Function Receive Queues Configuration Register This + * register configures receive queues in the LF. + */ +union nixx_af_lfx_rqs_cfg { + u64 u; + struct nixx_af_lfx_rqs_cfg_s { + u64 max_queuesm1 : 20; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_37_63 : 27; + } s; + /* struct nixx_af_lfx_rqs_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RQS_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RQS_CFG(u64 a) +{ + return 0x4040 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rss_base + * + * NIX AF Local Function Receive Size Scaling Table Base Address Register + * This register specifies the base AF IOVA of the RSS table per LF. The + * table is present when NIX_AF_LF()_RSS_CFG[ENA] is set and consists of + * 1 << (NIX_AF_LF()_RSS_CFG[SIZE] + 8) contiguous NIX_RSSE_S + * structures, where the size of each structure is 1 << + * NIX_AF_CONST3[RSSE_LOG2BYTES]. See NIX_AF_LF()_RSS_GRP(). + */ +union nixx_af_lfx_rss_base { + u64 u; + struct nixx_af_lfx_rss_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_lfx_rss_base_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RSS_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RSS_BASE(u64 a) +{ + return 0x40d0 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rss_cfg + * + * NIX AF Local Function Receive Size Scaling Table Configuration + * Register See NIX_AF_LF()_RSS_BASE and NIX_AF_LF()_RSS_GRP(). + */ +union nixx_af_lfx_rss_cfg { + u64 u; + struct nixx_af_lfx_rss_cfg_s { + u64 size : 4; + u64 ena : 1; + u64 adder_is_tag_lsb : 1; + u64 reserved_6_19 : 14; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_37_63 : 27; + } s; + struct nixx_af_lfx_rss_cfg_cn96xxp1 { + u64 size : 4; + u64 ena : 1; + u64 reserved_5_19 : 15; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_37_63 : 27; + } cn96xxp1; + /* struct nixx_af_lfx_rss_cfg_s cn96xxp3; */ + /* struct nixx_af_lfx_rss_cfg_cn96xxp1 cnf95xx; */ +}; + +static inline u64 NIXX_AF_LFX_RSS_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RSS_CFG(u64 a) +{ + return 0x40c0 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rss_grp# + * + * NIX AF Local Function Receive Side Scaling Group Registers A receive + * packet targets a LF's RSS group when its NIX_RX_ACTION_S[OP] = + * NIX_RX_ACTIONOP_E::RSS, or its target multicast list has an entry with + * NIX_RX_MCE_S[OP] = NIX_RX_MCOP_E::RSS. The RSS group index (this + * register's last index) is NIX_RX_ACTION_S[INDEX] or + * NIX_RX_MCE_S[INDEX]. The RSS computation is as follows: * The + * packet's flow_tag (see NIX_LF_RX_SECRET()) and RSS group are used to + * select a NIX_RSSE_S entry in the LF's RSS table (see [SIZEM1]). * + * NIX_RSSE_S selects the packet's destination RQ. + */ +union nixx_af_lfx_rss_grpx { + u64 u; + struct nixx_af_lfx_rss_grpx_s { + u64 offset : 11; + u64 reserved_11_15 : 5; + u64 sizem1 : 3; + u64 reserved_19_63 : 45; + } s; + /* struct nixx_af_lfx_rss_grpx_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RSS_GRPX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RSS_GRPX(u64 a, u64 b) +{ + return 0x4600 + 0x20000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rx_cfg + * + * NIX AF Local Function Receive Configuration Register + */ +union nixx_af_lfx_rx_cfg { + u64 u; + struct nixx_af_lfx_rx_cfg_s { + u64 reserved_0_31 : 32; + u64 drop_re : 1; + u64 lenerr_en : 1; + u64 ip6_udp_opt : 1; + u64 dis_apad : 1; + u64 csum_il4 : 1; + u64 csum_ol4 : 1; + u64 len_il4 : 1; + u64 len_il3 : 1; + u64 len_ol4 : 1; + u64 len_ol3 : 1; + u64 reserved_42_63 : 22; + } s; + struct nixx_af_lfx_rx_cfg_cn96xxp1 { + u64 reserved_0_31 : 32; + u64 reserved_32 : 1; + u64 lenerr_en : 1; + u64 ip6_udp_opt : 1; + u64 dis_apad : 1; + u64 csum_il4 : 1; + u64 csum_ol4 : 1; + u64 len_il4 : 1; + u64 len_il3 : 1; + u64 len_ol4 : 1; + u64 len_ol3 : 1; + u64 reserved_42_63 : 22; + } cn96xxp1; + /* struct nixx_af_lfx_rx_cfg_s cn96xxp3; */ + /* struct nixx_af_lfx_rx_cfg_s cnf95xx; */ +}; + +static inline u64 NIXX_AF_LFX_RX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RX_CFG(u64 a) +{ + return 0x40a0 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rx_ipsec_cfg0 + * + * INTERNAL: NIX AF LF Receive IPSEC Configuration Registers Internal: + * Not used; no IPSEC fast-path. + */ +union nixx_af_lfx_rx_ipsec_cfg0 { + u64 u; + struct nixx_af_lfx_rx_ipsec_cfg0_s { + u64 lenm1_max : 14; + u64 reserved_14_15 : 2; + u64 sa_pow2_size : 4; + u64 tag_const : 24; + u64 tt : 2; + u64 defcpt : 1; + u64 hshcpt : 1; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_lfx_rx_ipsec_cfg0_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RX_IPSEC_CFG0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RX_IPSEC_CFG0(u64 a) +{ + return 0x4140 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rx_ipsec_cfg1 + * + * INTERNAL: NIX AF LF Receive IPSEC Security Association Configuration + * Register Internal: Not used; no IPSEC fast-path. + */ +union nixx_af_lfx_rx_ipsec_cfg1 { + u64 u; + struct nixx_af_lfx_rx_ipsec_cfg1_s { + u64 sa_idx_max : 32; + u64 sa_idx_w : 5; + u64 reserved_37_63 : 27; + } s; + /* struct nixx_af_lfx_rx_ipsec_cfg1_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RX_IPSEC_CFG1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RX_IPSEC_CFG1(u64 a) +{ + return 0x4148 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rx_ipsec_dyno_base + * + * INTERNAL: NIX AF LF Receive IPSEC Dynamic Ordering Base Address + * Registers Internal: Not used; no IPSEC fast-path. + */ +union nixx_af_lfx_rx_ipsec_dyno_base { + u64 u; + struct nixx_af_lfx_rx_ipsec_dyno_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_lfx_rx_ipsec_dyno_base_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RX_IPSEC_DYNO_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RX_IPSEC_DYNO_BASE(u64 a) +{ + return 0x4158 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rx_ipsec_dyno_cfg + * + * INTERNAL: NIX AF LF Receive IPSEC Dynamic Ordering Base Address + * Registers Internal: Not used; no IPSEC fast-path. + */ +union nixx_af_lfx_rx_ipsec_dyno_cfg { + u64 u; + struct nixx_af_lfx_rx_ipsec_dyno_cfg_s { + u64 dyno_idx_w : 4; + u64 dyno_ena : 1; + u64 reserved_5_19 : 15; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_37_63 : 27; + } s; + /* struct nixx_af_lfx_rx_ipsec_dyno_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RX_IPSEC_DYNO_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RX_IPSEC_DYNO_CFG(u64 a) +{ + return 0x4150 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rx_ipsec_sa_base + * + * INTERNAL: NIX AF LF Receive IPSEC Security Association Base Address + * Register Internal: Not used; no IPSEC fast-path. + */ +union nixx_af_lfx_rx_ipsec_sa_base { + u64 u; + struct nixx_af_lfx_rx_ipsec_sa_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_lfx_rx_ipsec_sa_base_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RX_IPSEC_SA_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RX_IPSEC_SA_BASE(u64 a) +{ + return 0x4170 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rx_stat# + * + * NIX AF Local Function Receive Statistics Registers The last dimension + * indicates which statistic, and is enumerated by NIX_STAT_LF_RX_E. + */ +union nixx_af_lfx_rx_statx { + u64 u; + struct nixx_af_lfx_rx_statx_s { + u64 stat : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_lfx_rx_statx_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RX_STATX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RX_STATX(u64 a, u64 b) +{ + return 0x4500 + 0x20000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_rx_vtag_type# + * + * NIX AF Local Function Receive Vtag Type Registers These registers + * specify optional Vtag (e.g. VLAN, E-TAG) actions for received packets. + * Indexed by NIX_RX_VTAG_ACTION_S[VTAG*_TYPE]. + */ +union nixx_af_lfx_rx_vtag_typex { + u64 u; + struct nixx_af_lfx_rx_vtag_typex_s { + u64 size : 1; + u64 reserved_1_3 : 3; + u64 strip : 1; + u64 capture : 1; + u64 reserved_6_63 : 58; + } s; + /* struct nixx_af_lfx_rx_vtag_typex_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_RX_VTAG_TYPEX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_RX_VTAG_TYPEX(u64 a, u64 b) +{ + return 0x4200 + 0x20000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_sqs_base + * + * NIX AF Local Function Send Queues Base Address Register This register + * specifies the base AF IOVA of the LF's SQ context table. The table + * consists of NIX_AF_LF()_SQS_CFG[MAX_QUEUESM1]+1 contiguous + * NIX_SQ_CTX_HW_S structures. + */ +union nixx_af_lfx_sqs_base { + u64 u; + struct nixx_af_lfx_sqs_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_lfx_sqs_base_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_SQS_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_SQS_BASE(u64 a) +{ + return 0x4030 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_sqs_cfg + * + * NIX AF Local Function Send Queues Configuration Register This register + * configures send queues in the LF. + */ +union nixx_af_lfx_sqs_cfg { + u64 u; + struct nixx_af_lfx_sqs_cfg_s { + u64 max_queuesm1 : 20; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_37_63 : 27; + } s; + /* struct nixx_af_lfx_sqs_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_SQS_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_SQS_CFG(u64 a) +{ + return 0x4020 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_tx_cfg + * + * NIX AF Local Function Transmit Configuration Register + */ +union nixx_af_lfx_tx_cfg { + u64 u; + struct nixx_af_lfx_tx_cfg_s { + u64 vlan0_ins_etype : 16; + u64 vlan1_ins_etype : 16; + u64 send_tstmp_ena : 1; + u64 lock_viol_cqe_ena : 1; + u64 lock_ena : 1; + u64 reserved_35_63 : 29; + } s; + /* struct nixx_af_lfx_tx_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_TX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_TX_CFG(u64 a) +{ + return 0x4080 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_tx_cfg2 + * + * NIX AF Local Function Transmit Configuration Register + */ +union nixx_af_lfx_tx_cfg2 { + u64 u; + struct nixx_af_lfx_tx_cfg2_s { + u64 lmt_ena : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_lfx_tx_cfg2_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_TX_CFG2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_TX_CFG2(u64 a) +{ + return 0x4028 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_tx_parse_cfg + * + * NIX AF Local Function Transmit Parse Configuration Register + */ +union nixx_af_lfx_tx_parse_cfg { + u64 u; + struct nixx_af_lfx_tx_parse_cfg_s { + u64 pkind : 6; + u64 reserved_6_63 : 58; + } s; + /* struct nixx_af_lfx_tx_parse_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_TX_PARSE_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_TX_PARSE_CFG(u64 a) +{ + return 0x4090 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_tx_stat# + * + * NIX AF Local Function Transmit Statistics Registers The last dimension + * indicates which statistic, and is enumerated by NIX_STAT_LF_TX_E. + */ +union nixx_af_lfx_tx_statx { + u64 u; + struct nixx_af_lfx_tx_statx_s { + u64 stat : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_lfx_tx_statx_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_TX_STATX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_TX_STATX(u64 a, u64 b) +{ + return 0x4400 + 0x20000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf#_tx_status + * + * NIX AF LF Transmit Status Register + */ +union nixx_af_lfx_tx_status { + u64 u; + struct nixx_af_lfx_tx_status_s { + u64 sq_ctx_err : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_lfx_tx_status_s cn; */ +}; + +static inline u64 NIXX_AF_LFX_TX_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LFX_TX_STATUS(u64 a) +{ + return 0x4180 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lf_rst + * + * NIX Admin Function LF Reset Register + */ +union nixx_af_lf_rst { + u64 u; + struct nixx_af_lf_rst_s { + u64 lf : 8; + u64 reserved_8_11 : 4; + u64 exec : 1; + u64 reserved_13_63 : 51; + } s; + /* struct nixx_af_lf_rst_s cn; */ +}; + +static inline u64 NIXX_AF_LF_RST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LF_RST(void) +{ + return 0x150; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lso_cfg + * + * NIX AF Large Send Offload Configuration Register + */ +union nixx_af_lso_cfg { + u64 u; + struct nixx_af_lso_cfg_s { + u64 tcp_lsf : 16; + u64 tcp_msf : 16; + u64 tcp_fsf : 16; + u64 reserved_48_62 : 15; + u64 enable : 1; + } s; + /* struct nixx_af_lso_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_LSO_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LSO_CFG(void) +{ + return 0xa8; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_lso_format#_field# + * + * NIX AF Large Send Offload Format Field Registers These registers + * specify LSO packet modification formats. Each format may modify up to + * eight packet fields with the following constraints: * If fewer than + * eight fields are modified, [ALG] must be NIX_LSOALG_E::NOP in the + * unused field registers. * Modified fields must be specified in + * contiguous field registers starting with NIX_AF_LSO_FORMAT()_FIELD(0). + * * Modified fields cannot overlap. * Multiple fields with the same + * [LAYER] value must be specified in ascending [OFFSET] order. * Fields + * in different layers must be specified in ascending [LAYER] order. + */ +union nixx_af_lso_formatx_fieldx { + u64 u; + struct nixx_af_lso_formatx_fieldx_s { + u64 offset : 8; + u64 layer : 2; + u64 reserved_10_11 : 2; + u64 sizem1 : 2; + u64 reserved_14_15 : 2; + u64 alg : 3; + u64 reserved_19_63 : 45; + } s; + /* struct nixx_af_lso_formatx_fieldx_s cn; */ +}; + +static inline u64 NIXX_AF_LSO_FORMATX_FIELDX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_LSO_FORMATX_FIELDX(u64 a, u64 b) +{ + return 0x1b00 + 0x10000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mark_format#_ctl + * + * NIX AF Packet Marking Format Registers Describes packet marking + * calculations for YELLOW and for NIX_COLORRESULT_E::RED_SEND packets. + * NIX_SEND_EXT_S[MARKFORM] selects the CSR used for the packet + * descriptor. All the packet marking offset calculations assume big- + * endian bits within a byte. For example, if NIX_SEND_EXT_S[MARKPTR] is + * 3 and [OFFSET] is 5 and the packet is YELLOW, the NIX marking hardware + * would do this: _ byte[3]<2:0> |= [Y_VAL]<3:1> _ + * byte[3]<2:0> &= ~[Y_MASK]<3:1> _ byte[4]<7> |= [Y_VAL]<0> + * _ byte[4]<7> &= ~[Y_MASK]<0> where byte[3] is the third byte + * in the packet, and byte[4] the fourth. For another example, if + * NIX_SEND_EXT_S[MARKPTR] is 3 and [OFFSET] is 0 and the packet is + * NIX_COLORRESULT_E::RED_SEND, _ byte[3]<7:4> |= [R_VAL]<3:0> _ + * byte[3]<7:4> &= ~[R_MASK]<3:0> + */ +union nixx_af_mark_formatx_ctl { + u64 u; + struct nixx_af_mark_formatx_ctl_s { + u64 r_val : 4; + u64 r_mask : 4; + u64 y_val : 4; + u64 y_mask : 4; + u64 offset : 3; + u64 reserved_19_63 : 45; + } s; + /* struct nixx_af_mark_formatx_ctl_s cn; */ +}; + +static inline u64 NIXX_AF_MARK_FORMATX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MARK_FORMATX_CTL(u64 a) +{ + return 0x900 + 0x40000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mc_mirror_const + * + * NIX AF Multicast/Mirror Constants Register This register contains + * constants for software discovery. + */ +union nixx_af_mc_mirror_const { + u64 u; + struct nixx_af_mc_mirror_const_s { + u64 buf_size : 16; + u64 reserved_16_63 : 48; + } s; + /* struct nixx_af_mc_mirror_const_s cn; */ +}; + +static inline u64 NIXX_AF_MC_MIRROR_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MC_MIRROR_CONST(void) +{ + return 0x98; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_cir + * + * NIX AF Meta Descriptor Queue Committed Information Rate Registers This + * register has the same bit fields as NIX_AF_TL1()_CIR. + */ +union nixx_af_mdqx_cir { + u64 u; + struct nixx_af_mdqx_cir_s { + u64 enable : 1; + u64 rate_mantissa : 8; + u64 rate_exponent : 4; + u64 rate_divider_exponent : 4; + u64 reserved_17_28 : 12; + u64 burst_mantissa : 8; + u64 burst_exponent : 4; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_mdqx_cir_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_CIR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_CIR(u64 a) +{ + return 0x1420 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_md_debug + * + * NIX AF Meta Descriptor Queue Meta Descriptor State Debug Registers + * This register provides access to the meta descriptor at the front of + * the MDQ. An MDQ can hold up to 8 packet meta descriptors (PMD) and one + * flush meta descriptor (FMD). + */ +union nixx_af_mdqx_md_debug { + u64 u; + struct nixx_af_mdqx_md_debug_s { + u64 pkt_len : 16; + u64 red_algo_override : 2; + u64 shp_dis : 1; + u64 reserved_19 : 1; + u64 shp_chg : 9; + u64 reserved_29_31 : 3; + u64 sqm_pkt_id : 13; + u64 reserved_45_60 : 16; + u64 md_type : 2; + u64 reserved_63 : 1; + } s; + /* struct nixx_af_mdqx_md_debug_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_MD_DEBUG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_MD_DEBUG(u64 a) +{ + return 0x14c0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_parent + * + * NIX AF Meta Descriptor Queue Topology Registers + */ +union nixx_af_mdqx_parent { + u64 u; + struct nixx_af_mdqx_parent_s { + u64 reserved_0_15 : 16; + u64 parent : 9; + u64 reserved_25_63 : 39; + } s; + /* struct nixx_af_mdqx_parent_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_PARENT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_PARENT(u64 a) +{ + return 0x1480 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_pir + * + * NIX AF Meta Descriptor Queue Peak Information Rate Registers This + * register has the same bit fields as NIX_AF_TL1()_CIR. + */ +union nixx_af_mdqx_pir { + u64 u; + struct nixx_af_mdqx_pir_s { + u64 enable : 1; + u64 rate_mantissa : 8; + u64 rate_exponent : 4; + u64 rate_divider_exponent : 4; + u64 reserved_17_28 : 12; + u64 burst_mantissa : 8; + u64 burst_exponent : 4; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_mdqx_pir_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_PIR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_PIR(u64 a) +{ + return 0x1430 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_pointers + * + * INTERNAL: NIX AF Meta Descriptor 4 Linked List Pointers Debug Register + * This register has the same bit fields as NIX_AF_TL4()_POINTERS. + */ +union nixx_af_mdqx_pointers { + u64 u; + struct nixx_af_mdqx_pointers_s { + u64 next : 9; + u64 reserved_9_15 : 7; + u64 prev : 9; + u64 reserved_25_63 : 39; + } s; + /* struct nixx_af_mdqx_pointers_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_POINTERS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_POINTERS(u64 a) +{ + return 0x1460 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_ptr_fifo + * + * INTERNAL: NIX Meta Descriptor Queue Pointer FIFO State Debug Registers + */ +union nixx_af_mdqx_ptr_fifo { + u64 u; + struct nixx_af_mdqx_ptr_fifo_s { + u64 tail : 4; + u64 head : 4; + u64 p_con : 1; + u64 reserved_9_63 : 55; + } s; + /* struct nixx_af_mdqx_ptr_fifo_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_PTR_FIFO(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_PTR_FIFO(u64 a) +{ + return 0x14d0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_sched_state + * + * NIX AF Meta Descriptor Queue Scheduling Control State Registers This + * register has the same bit fields as NIX_AF_TL2()_SCHED_STATE. + */ +union nixx_af_mdqx_sched_state { + u64 u; + struct nixx_af_mdqx_sched_state_s { + u64 rr_count : 25; + u64 reserved_25_63 : 39; + } s; + /* struct nixx_af_mdqx_sched_state_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_SCHED_STATE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_SCHED_STATE(u64 a) +{ + return 0x1440 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_schedule + * + * NIX AF Meta Descriptor Queue Scheduling Control Registers This + * register has the same bit fields as NIX_AF_TL2()_SCHEDULE. + */ +union nixx_af_mdqx_schedule { + u64 u; + struct nixx_af_mdqx_schedule_s { + u64 rr_quantum : 24; + u64 prio : 4; + u64 reserved_28_63 : 36; + } s; + /* struct nixx_af_mdqx_schedule_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_SCHEDULE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_SCHEDULE(u64 a) +{ + return 0x1400 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_shape + * + * NIX AF Meta Descriptor Queue Shaping Control Registers This register + * has the same bit fields as NIX_AF_TL3()_SHAPE. + */ +union nixx_af_mdqx_shape { + u64 u; + struct nixx_af_mdqx_shape_s { + u64 adjust : 9; + u64 red_algo : 2; + u64 red_disable : 1; + u64 yellow_disable : 1; + u64 reserved_13_23 : 11; + u64 length_disable : 1; + u64 schedule_list : 2; + u64 reserved_27_63 : 37; + } s; + /* struct nixx_af_mdqx_shape_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_SHAPE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_SHAPE(u64 a) +{ + return 0x1410 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_shape_state + * + * NIX AF Meta Descriptor Queue Shaping State Registers This register has + * the same bit fields as NIX_AF_TL2()_SHAPE_STATE. This register must + * not be written during normal operation. + */ +union nixx_af_mdqx_shape_state { + u64 u; + struct nixx_af_mdqx_shape_state_s { + u64 cir_accum : 26; + u64 pir_accum : 26; + u64 color : 2; + u64 reserved_54_63 : 10; + } s; + /* struct nixx_af_mdqx_shape_state_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_SHAPE_STATE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_SHAPE_STATE(u64 a) +{ + return 0x1450 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq#_sw_xoff + * + * NIX AF Meta Descriptor Controlled XOFF Registers This register has the + * same bit fields as NIX_AF_TL1()_SW_XOFF + */ +union nixx_af_mdqx_sw_xoff { + u64 u; + struct nixx_af_mdqx_sw_xoff_s { + u64 xoff : 1; + u64 drain : 1; + u64 reserved_2 : 1; + u64 drain_irq : 1; + u64 reserved_4_63 : 60; + } s; + /* struct nixx_af_mdqx_sw_xoff_s cn; */ +}; + +static inline u64 NIXX_AF_MDQX_SW_XOFF(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQX_SW_XOFF(u64 a) +{ + return 0x1470 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_mdq_const + * + * NIX AF Meta Descriptor Queue Constants Register This register contains + * constants for software discovery. + */ +union nixx_af_mdq_const { + u64 u; + struct nixx_af_mdq_const_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct nixx_af_mdq_const_s cn; */ +}; + +static inline u64 NIXX_AF_MDQ_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_MDQ_CONST(void) +{ + return 0x90; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_ndc_cfg + * + * NIX AF General Configuration Register + */ +union nixx_af_ndc_cfg { + u64 u; + struct nixx_af_ndc_cfg_s { + u64 ndc_ign_pois : 1; + u64 byp_sq : 1; + u64 byp_sqb : 1; + u64 byp_cqs : 1; + u64 byp_cints : 1; + u64 byp_dyno : 1; + u64 byp_mce : 1; + u64 byp_rqc : 1; + u64 byp_rsse : 1; + u64 byp_mc_data : 1; + u64 byp_mc_wqe : 1; + u64 byp_mr_data : 1; + u64 byp_mr_wqe : 1; + u64 byp_qints : 1; + u64 reserved_14_63 : 50; + } s; + /* struct nixx_af_ndc_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_NDC_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_NDC_CFG(void) +{ + return 0x18; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_ndc_rx_sync + * + * NIX AF Receive NDC Sync Register Used to synchronize the NIX receive + * NDC (NDC_IDX_E::NIX()_RX). + */ +union nixx_af_ndc_rx_sync { + u64 u; + struct nixx_af_ndc_rx_sync_s { + u64 lf : 8; + u64 reserved_8_11 : 4; + u64 exec : 1; + u64 reserved_13_63 : 51; + } s; + /* struct nixx_af_ndc_rx_sync_s cn; */ +}; + +static inline u64 NIXX_AF_NDC_RX_SYNC(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_NDC_RX_SYNC(void) +{ + return 0x3e0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_ndc_tx_sync + * + * NIX AF NDC_TX Sync Register Used to synchronize the NIX transmit NDC + * (NDC_IDX_E::NIX()_TX). + */ +union nixx_af_ndc_tx_sync { + u64 u; + struct nixx_af_ndc_tx_sync_s { + u64 lf : 8; + u64 reserved_8_11 : 4; + u64 exec : 1; + u64 reserved_13_63 : 51; + } s; + /* struct nixx_af_ndc_tx_sync_s cn; */ +}; + +static inline u64 NIXX_AF_NDC_TX_SYNC(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_NDC_TX_SYNC(void) +{ + return 0x3f0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_norm_tx_fifo_status + * + * NIX AF Normal Transmit FIFO Status Register Status of FIFO which + * transmits normal packets to CGX and LBK. + */ +union nixx_af_norm_tx_fifo_status { + u64 u; + struct nixx_af_norm_tx_fifo_status_s { + u64 count : 12; + u64 reserved_12_63 : 52; + } s; + /* struct nixx_af_norm_tx_fifo_status_s cn; */ +}; + +static inline u64 NIXX_AF_NORM_TX_FIFO_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_NORM_TX_FIFO_STATUS(void) +{ + return 0x648; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pq#_dbg_arb_link_exp + * + * INTERNAL: NIX AF PQ Arb Link EXPRESS Debug Register + */ +union nixx_af_pqx_dbg_arb_link_exp { + u64 u; + struct nixx_af_pqx_dbg_arb_link_exp_s { + u64 req : 1; + u64 act_c_con : 1; + u64 cnt : 2; + u64 reserved_4_5 : 2; + u64 rr_mask : 1; + u64 reserved_7_63 : 57; + } s; + /* struct nixx_af_pqx_dbg_arb_link_exp_s cn; */ +}; + +static inline u64 NIXX_AF_PQX_DBG_ARB_LINK_EXP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PQX_DBG_ARB_LINK_EXP(u64 a) +{ + return 0xce8 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pq#_dbg_arb_link_nrm + * + * INTERNAL: NIX AF PQ Arb Link NORMAL Debug Register + */ +union nixx_af_pqx_dbg_arb_link_nrm { + u64 u; + struct nixx_af_pqx_dbg_arb_link_nrm_s { + u64 req : 1; + u64 act_c_con : 1; + u64 cnt : 2; + u64 reserved_4_5 : 2; + u64 rr_mask : 1; + u64 reserved_7_63 : 57; + } s; + /* struct nixx_af_pqx_dbg_arb_link_nrm_s cn; */ +}; + +static inline u64 NIXX_AF_PQX_DBG_ARB_LINK_NRM(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PQX_DBG_ARB_LINK_NRM(u64 a) +{ + return 0xce0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pq#_dbg_arb_link_sdp + * + * INTERNAL: NIX AF PQ Arb Link SDP Debug Register + */ +union nixx_af_pqx_dbg_arb_link_sdp { + u64 u; + struct nixx_af_pqx_dbg_arb_link_sdp_s { + u64 req : 1; + u64 act_c_con : 1; + u64 cnt : 2; + u64 reserved_4_5 : 2; + u64 rr_mask : 1; + u64 reserved_7_63 : 57; + } s; + /* struct nixx_af_pqx_dbg_arb_link_sdp_s cn; */ +}; + +static inline u64 NIXX_AF_PQX_DBG_ARB_LINK_SDP(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PQX_DBG_ARB_LINK_SDP(u64 a) +{ + return 0xcf0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pq_arb_crd_rdy_debug + * + * INTERNAL: NIX AF PQ_ARB Node Credit Ready Registers NIX AF PQ ARB + * Credit ready register + */ +union nixx_af_pq_arb_crd_rdy_debug { + u64 u; + struct nixx_af_pq_arb_crd_rdy_debug_s { + u64 node_crd_rdy : 28; + u64 reserved_28_63 : 36; + } s; + /* struct nixx_af_pq_arb_crd_rdy_debug_s cn; */ +}; + +static inline u64 NIXX_AF_PQ_ARB_CRD_RDY_DEBUG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PQ_ARB_CRD_RDY_DEBUG(void) +{ + return 0xf10; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pq_arb_dwrr_msk_debug + * + * INTERNAL: NIX AF PQ_ARB DWRR mask set read only debug Registers + */ +union nixx_af_pq_arb_dwrr_msk_debug { + u64 u; + struct nixx_af_pq_arb_dwrr_msk_debug_s { + u64 node_dwrr_mask_set : 28; + u64 reserved_28_63 : 36; + } s; + /* struct nixx_af_pq_arb_dwrr_msk_debug_s cn; */ +}; + +static inline u64 NIXX_AF_PQ_ARB_DWRR_MSK_DEBUG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PQ_ARB_DWRR_MSK_DEBUG(void) +{ + return 0xf30; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pq_arb_node_gnt_debug + * + * INTERNAL: NIX AF PQ_ARB Node Grant vector Registers + */ +union nixx_af_pq_arb_node_gnt_debug { + u64 u; + struct nixx_af_pq_arb_node_gnt_debug_s { + u64 node_grant_vec : 28; + u64 reserved_28_63 : 36; + } s; + /* struct nixx_af_pq_arb_node_gnt_debug_s cn; */ +}; + +static inline u64 NIXX_AF_PQ_ARB_NODE_GNT_DEBUG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PQ_ARB_NODE_GNT_DEBUG(void) +{ + return 0xf20; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pq_arb_node_req_debug + * + * INTERNAL: NIX AF PQ_ARB Node Request Debug Registers NIX AF PQ ARB + * Node Request Debug register + */ +union nixx_af_pq_arb_node_req_debug { + u64 u; + struct nixx_af_pq_arb_node_req_debug_s { + u64 node_req : 28; + u64 reserved_28_63 : 36; + } s; + /* struct nixx_af_pq_arb_node_req_debug_s cn; */ +}; + +static inline u64 NIXX_AF_PQ_ARB_NODE_REQ_DEBUG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PQ_ARB_NODE_REQ_DEBUG(void) +{ + return 0xf00; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pq_arb_shape_vld_dbg + * + * INTERNAL: NIX AF PQ_ARB shape valid set Register + */ +union nixx_af_pq_arb_shape_vld_dbg { + u64 u; + struct nixx_af_pq_arb_shape_vld_dbg_s { + u64 node_shape_vld_set : 28; + u64 reserved_28_63 : 36; + } s; + /* struct nixx_af_pq_arb_shape_vld_dbg_s cn; */ +}; + +static inline u64 NIXX_AF_PQ_ARB_SHAPE_VLD_DBG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PQ_ARB_SHAPE_VLD_DBG(void) +{ + return 0xf40; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pq_dbg_arb_0 + * + * INTERNAL: NIX AF PQ Arb Debug 0 Register + */ +union nixx_af_pq_dbg_arb_0 { + u64 u; + struct nixx_af_pq_dbg_arb_0_s { + u64 rr_mask_clr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_pq_dbg_arb_0_s cn; */ +}; + +static inline u64 NIXX_AF_PQ_DBG_ARB_0(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PQ_DBG_ARB_0(void) +{ + return 0xcf8; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pq_lnk_#_dwrr_msk_dbg + * + * INTERNAL: NIX AF PQ_ARB Physical Link DWRR MASK Registers + */ +union nixx_af_pq_lnk_x_dwrr_msk_dbg { + u64 u; + struct nixx_af_pq_lnk_x_dwrr_msk_dbg_s { + u64 link_dwrr_mask_set : 28; + u64 reserved_28_63 : 36; + } s; + /* struct nixx_af_pq_lnk_x_dwrr_msk_dbg_s cn; */ +}; + +static inline u64 NIXX_AF_PQ_LNK_X_DWRR_MSK_DBG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PQ_LNK_X_DWRR_MSK_DBG(u64 a) +{ + return 0x1100 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_400_rate_divider + * + * INTERNAL: NIX AF PSE 400 Rate Divider Register + */ +union nixx_af_pse_400_rate_divider { + u64 u; + struct nixx_af_pse_400_rate_divider_s { + u64 rate_div_cfg : 9; + u64 reserved_9_63 : 55; + } s; + /* struct nixx_af_pse_400_rate_divider_s cn; */ +}; + +static inline u64 NIXX_AF_PSE_400_RATE_DIVIDER(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_400_RATE_DIVIDER(void) +{ + return 0x830; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_active_cycles_pc + * + * NIX AF Active Cycles Register These registers are indexed by the + * conditional clock domain number. + */ +union nixx_af_pse_active_cycles_pc { + u64 u; + struct nixx_af_pse_active_cycles_pc_s { + u64 act_cyc : 64; + } s; + /* struct nixx_af_pse_active_cycles_pc_s cn; */ +}; + +static inline u64 NIXX_AF_PSE_ACTIVE_CYCLES_PC(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_ACTIVE_CYCLES_PC(void) +{ + return 0x8c0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_bp_test0 + * + * INTERNAL: NIX AF PSE Backpressure Test 0 Register + */ +union nixx_af_pse_bp_test0 { + u64 u; + struct nixx_af_pse_bp_test0_s { + u64 lfsr_freq : 12; + u64 reserved_12_63 : 52; + } s; + struct nixx_af_pse_bp_test0_cn96xxp1 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_59 : 36; + u64 enable : 4; + } cn96xxp1; + struct nixx_af_pse_bp_test0_cn96xxp3 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 reserved_16_19 : 4; + u64 bp_cfg : 12; + u64 reserved_32_55 : 24; + u64 reserved_56_57 : 2; + u64 enable : 6; + } cn96xxp3; + /* struct nixx_af_pse_bp_test0_cn96xxp1 cnf95xxp1; */ + struct nixx_af_pse_bp_test0_cnf95xxp2 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_31 : 8; + u64 reserved_32_55 : 24; + u64 reserved_56_59 : 4; + u64 enable : 4; + } cnf95xxp2; +}; + +static inline u64 NIXX_AF_PSE_BP_TEST0(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_BP_TEST0(void) +{ + return 0x840; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_bp_test1 + * + * INTERNAL: NIX AF PSE Backpressure Test 1 Register + */ +union nixx_af_pse_bp_test1 { + u64 u; + struct nixx_af_pse_bp_test1_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 10; + u64 reserved_26_63 : 38; + } s; + struct nixx_af_pse_bp_test1_cn96xxp1 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_59 : 36; + u64 enable : 4; + } cn96xxp1; + struct nixx_af_pse_bp_test1_cn96xxp3 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 10; + u64 reserved_26_31 : 6; + u64 reserved_32_55 : 24; + u64 reserved_56_58 : 3; + u64 enable : 5; + } cn96xxp3; + /* struct nixx_af_pse_bp_test1_cn96xxp1 cnf95xxp1; */ + struct nixx_af_pse_bp_test1_cnf95xxp2 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_31 : 8; + u64 reserved_32_55 : 24; + u64 reserved_56_59 : 4; + u64 enable : 4; + } cnf95xxp2; +}; + +static inline u64 NIXX_AF_PSE_BP_TEST1(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_BP_TEST1(void) +{ + return 0x850; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_bp_test2 + * + * INTERNAL: NIX AF PSE Backpressure Test 2 Register + */ +union nixx_af_pse_bp_test2 { + u64 u; + struct nixx_af_pse_bp_test2_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 10; + u64 reserved_26_63 : 38; + } s; + struct nixx_af_pse_bp_test2_cn96xxp1 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_59 : 36; + u64 enable : 4; + } cn96xxp1; + struct nixx_af_pse_bp_test2_cn96xxp3 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 10; + u64 reserved_26_31 : 6; + u64 reserved_32_55 : 24; + u64 reserved_56_58 : 3; + u64 enable : 5; + } cn96xxp3; + /* struct nixx_af_pse_bp_test2_cn96xxp1 cnf95xxp1; */ + struct nixx_af_pse_bp_test2_cnf95xxp2 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_31 : 8; + u64 reserved_32_55 : 24; + u64 reserved_56_59 : 4; + u64 enable : 4; + } cnf95xxp2; +}; + +static inline u64 NIXX_AF_PSE_BP_TEST2(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_BP_TEST2(void) +{ + return 0x860; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_bp_test3 + * + * INTERNAL: NIX AF PSE Backpressure Test 3 Register + */ +union nixx_af_pse_bp_test3 { + u64 u; + struct nixx_af_pse_bp_test3_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 10; + u64 reserved_26_63 : 38; + } s; + struct nixx_af_pse_bp_test3_cn96xxp1 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_59 : 36; + u64 enable : 4; + } cn96xxp1; + struct nixx_af_pse_bp_test3_cn96xxp3 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 10; + u64 reserved_26_31 : 6; + u64 reserved_32_55 : 24; + u64 reserved_56_58 : 3; + u64 enable : 5; + } cn96xxp3; + /* struct nixx_af_pse_bp_test3_cn96xxp1 cnf95xxp1; */ + struct nixx_af_pse_bp_test3_cnf95xxp2 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_31 : 8; + u64 reserved_32_55 : 24; + u64 reserved_56_59 : 4; + u64 enable : 4; + } cnf95xxp2; +}; + +static inline u64 NIXX_AF_PSE_BP_TEST3(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_BP_TEST3(void) +{ + return 0x870; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_channel_level + * + * NIX AF PSE Channel Level Register + */ +union nixx_af_pse_channel_level { + u64 u; + struct nixx_af_pse_channel_level_s { + u64 bp_level : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_pse_channel_level_s cn; */ +}; + +static inline u64 NIXX_AF_PSE_CHANNEL_LEVEL(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_CHANNEL_LEVEL(void) +{ + return 0x800; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_const + * + * NIX AF PSE Constants Register This register contains constants for + * software discovery. + */ +union nixx_af_pse_const { + u64 u; + struct nixx_af_pse_const_s { + u64 levels : 4; + u64 reserved_4_7 : 4; + u64 mark_formats : 8; + u64 reserved_16_63 : 48; + } s; + /* struct nixx_af_pse_const_s cn; */ +}; + +static inline u64 NIXX_AF_PSE_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_CONST(void) +{ + return 0x60; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_eco + * + * INTERNAL: AF PSE ECO Register + */ +union nixx_af_pse_eco { + u64 u; + struct nixx_af_pse_eco_s { + u64 eco_rw : 64; + } s; + /* struct nixx_af_pse_eco_s cn; */ +}; + +static inline u64 NIXX_AF_PSE_ECO(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_ECO(void) +{ + return 0x5d0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_expr_bp_test + * + * INTERNAL: NIX AF PSE Express Backpressure Test Register Internal: + * 802.3br frame preemption/express path is defeatured. + */ +union nixx_af_pse_expr_bp_test { + u64 u; + struct nixx_af_pse_expr_bp_test_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 32; + u64 enable : 16; + } s; + /* struct nixx_af_pse_expr_bp_test_s cn; */ +}; + +static inline u64 NIXX_AF_PSE_EXPR_BP_TEST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_EXPR_BP_TEST(void) +{ + return 0x890; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_norm_bp_test + * + * INTERNAL: NIX AF PSE Normal Backpressure Test Register + */ +union nixx_af_pse_norm_bp_test { + u64 u; + struct nixx_af_pse_norm_bp_test_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 32; + u64 reserved_48_63 : 16; + } s; + struct nixx_af_pse_norm_bp_test_cn96xxp1 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 32; + u64 enable : 16; + } cn96xxp1; + struct nixx_af_pse_norm_bp_test_cn96xxp3 { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 12; + u64 reserved_28_57 : 30; + u64 enable : 6; + } cn96xxp3; + /* struct nixx_af_pse_norm_bp_test_cn96xxp1 cnf95xx; */ +}; + +static inline u64 NIXX_AF_PSE_NORM_BP_TEST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_NORM_BP_TEST(void) +{ + return 0x880; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_pse_shaper_cfg + * + * NIX AF PSE Shaper Configuration Register + */ +union nixx_af_pse_shaper_cfg { + u64 u; + struct nixx_af_pse_shaper_cfg_s { + u64 red_send_as_yellow : 1; + u64 color_aware : 1; + u64 reserved_2_63 : 62; + } s; + /* struct nixx_af_pse_shaper_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_PSE_SHAPER_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_PSE_SHAPER_CFG(void) +{ + return 0x810; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_ras + * + * NIX AF RAS Interrupt Register This register is intended for delivery + * of RAS events to the SCP, so should be ignored by OS drivers. + */ +union nixx_af_ras { + u64 u; + struct nixx_af_ras_s { + u64 rx_mce_poison : 1; + u64 rx_mcast_wqe_poison : 1; + u64 rx_mirror_wqe_poison : 1; + u64 rx_mcast_data_poison : 1; + u64 rx_mirror_data_poison : 1; + u64 reserved_5_31 : 27; + u64 aq_ctx_poison : 1; + u64 aq_res_poison : 1; + u64 aq_inst_poison : 1; + u64 reserved_35_63 : 29; + } s; + /* struct nixx_af_ras_s cn; */ +}; + +static inline u64 NIXX_AF_RAS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RAS(void) +{ + return 0x1a0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_ras_ena_w1c + * + * NIX AF RAS Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union nixx_af_ras_ena_w1c { + u64 u; + struct nixx_af_ras_ena_w1c_s { + u64 rx_mce_poison : 1; + u64 rx_mcast_wqe_poison : 1; + u64 rx_mirror_wqe_poison : 1; + u64 rx_mcast_data_poison : 1; + u64 rx_mirror_data_poison : 1; + u64 reserved_5_31 : 27; + u64 aq_ctx_poison : 1; + u64 aq_res_poison : 1; + u64 aq_inst_poison : 1; + u64 reserved_35_63 : 29; + } s; + /* struct nixx_af_ras_ena_w1c_s cn; */ +}; + +static inline u64 NIXX_AF_RAS_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RAS_ENA_W1C(void) +{ + return 0x1b8; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_ras_ena_w1s + * + * NIX AF RAS Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union nixx_af_ras_ena_w1s { + u64 u; + struct nixx_af_ras_ena_w1s_s { + u64 rx_mce_poison : 1; + u64 rx_mcast_wqe_poison : 1; + u64 rx_mirror_wqe_poison : 1; + u64 rx_mcast_data_poison : 1; + u64 rx_mirror_data_poison : 1; + u64 reserved_5_31 : 27; + u64 aq_ctx_poison : 1; + u64 aq_res_poison : 1; + u64 aq_inst_poison : 1; + u64 reserved_35_63 : 29; + } s; + /* struct nixx_af_ras_ena_w1s_s cn; */ +}; + +static inline u64 NIXX_AF_RAS_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RAS_ENA_W1S(void) +{ + return 0x1b0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_ras_w1s + * + * NIX AF RAS Interrupt Set Register This register sets interrupt bits. + */ +union nixx_af_ras_w1s { + u64 u; + struct nixx_af_ras_w1s_s { + u64 rx_mce_poison : 1; + u64 rx_mcast_wqe_poison : 1; + u64 rx_mirror_wqe_poison : 1; + u64 rx_mcast_data_poison : 1; + u64 rx_mirror_data_poison : 1; + u64 reserved_5_31 : 27; + u64 aq_ctx_poison : 1; + u64 aq_res_poison : 1; + u64 aq_inst_poison : 1; + u64 reserved_35_63 : 29; + } s; + /* struct nixx_af_ras_w1s_s cn; */ +}; + +static inline u64 NIXX_AF_RAS_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RAS_W1S(void) +{ + return 0x1a8; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_reb_bp_test# + * + * INTERNAL: NIX AF REB Backpressure Test Registers + */ +union nixx_af_reb_bp_testx { + u64 u; + struct nixx_af_reb_bp_testx_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_47 : 24; + u64 enable : 4; + u64 reserved_52_63 : 12; + } s; + /* struct nixx_af_reb_bp_testx_s cn; */ +}; + +static inline u64 NIXX_AF_REB_BP_TESTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_REB_BP_TESTX(u64 a) +{ + return 0x4840 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rq_const + * + * NIX AF RQ Constants Register This register contains constants for + * software discovery. + */ +union nixx_af_rq_const { + u64 u; + struct nixx_af_rq_const_s { + u64 queues_per_lf : 24; + u64 reserved_24_63 : 40; + } s; + /* struct nixx_af_rq_const_s cn; */ +}; + +static inline u64 NIXX_AF_RQ_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RQ_CONST(void) +{ + return 0x50; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rqm_bp_test + * + * INTERNAL: NIX AF REB Backpressure Test Registers + */ +union nixx_af_rqm_bp_test { + u64 u; + struct nixx_af_rqm_bp_test_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 16; + u64 reserved_32_47 : 16; + u64 enable : 8; + u64 reserved_56_63 : 8; + } s; + /* struct nixx_af_rqm_bp_test_s cn; */ +}; + +static inline u64 NIXX_AF_RQM_BP_TEST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RQM_BP_TEST(void) +{ + return 0x4880; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rqm_eco + * + * INTERNAL: AF RQM ECO Register + */ +union nixx_af_rqm_eco { + u64 u; + struct nixx_af_rqm_eco_s { + u64 eco_rw : 64; + } s; + /* struct nixx_af_rqm_eco_s cn; */ +}; + +static inline u64 NIXX_AF_RQM_ECO(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RQM_ECO(void) +{ + return 0x5a0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rvu_int + * + * NIX AF RVU Interrupt Register This register contains RVU error + * interrupt summary bits. + */ +union nixx_af_rvu_int { + u64 u; + struct nixx_af_rvu_int_s { + u64 unmapped_slot : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_rvu_int_s cn; */ +}; + +static inline u64 NIXX_AF_RVU_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RVU_INT(void) +{ + return 0x1c0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rvu_int_ena_w1c + * + * NIX AF RVU Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union nixx_af_rvu_int_ena_w1c { + u64 u; + struct nixx_af_rvu_int_ena_w1c_s { + u64 unmapped_slot : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_rvu_int_ena_w1c_s cn; */ +}; + +static inline u64 NIXX_AF_RVU_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RVU_INT_ENA_W1C(void) +{ + return 0x1d8; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rvu_int_ena_w1s + * + * NIX AF RVU Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union nixx_af_rvu_int_ena_w1s { + u64 u; + struct nixx_af_rvu_int_ena_w1s_s { + u64 unmapped_slot : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_rvu_int_ena_w1s_s cn; */ +}; + +static inline u64 NIXX_AF_RVU_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RVU_INT_ENA_W1S(void) +{ + return 0x1d0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rvu_int_w1s + * + * NIX AF RVU Interrupt Set Register This register sets interrupt bits. + */ +union nixx_af_rvu_int_w1s { + u64 u; + struct nixx_af_rvu_int_w1s_s { + u64 unmapped_slot : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_rvu_int_w1s_s cn; */ +}; + +static inline u64 NIXX_AF_RVU_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RVU_INT_W1S(void) +{ + return 0x1c8; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rvu_lf_cfg_debug + * + * NIX Privileged LF Configuration Debug Register This debug register + * allows software to lookup the reverse mapping from VF/PF slot to LF. + * The forward mapping is programmed with NIX_PRIV_LF()_CFG. + */ +union nixx_af_rvu_lf_cfg_debug { + u64 u; + struct nixx_af_rvu_lf_cfg_debug_s { + u64 lf : 12; + u64 lf_valid : 1; + u64 exec : 1; + u64 reserved_14_15 : 2; + u64 slot : 8; + u64 pf_func : 16; + u64 reserved_40_63 : 24; + } s; + /* struct nixx_af_rvu_lf_cfg_debug_s cn; */ +}; + +static inline u64 NIXX_AF_RVU_LF_CFG_DEBUG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RVU_LF_CFG_DEBUG(void) +{ + return 0x8000030; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_active_cycles_pc# + * + * NIX AF Active Cycles Register These registers are indexed by the + * conditional clock domain number. + */ +union nixx_af_rx_active_cycles_pcx { + u64 u; + struct nixx_af_rx_active_cycles_pcx_s { + u64 act_cyc : 64; + } s; + /* struct nixx_af_rx_active_cycles_pcx_s cn; */ +}; + +static inline u64 NIXX_AF_RX_ACTIVE_CYCLES_PCX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_ACTIVE_CYCLES_PCX(u64 a) +{ + return 0x4800 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_bpid#_status + * + * NIX AF Receive Backpressure ID Status Registers + */ +union nixx_af_rx_bpidx_status { + u64 u; + struct nixx_af_rx_bpidx_status_s { + u64 aura_cnt : 32; + u64 cq_cnt : 32; + } s; + /* struct nixx_af_rx_bpidx_status_s cn; */ +}; + +static inline u64 NIXX_AF_RX_BPIDX_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_BPIDX_STATUS(u64 a) +{ + return 0x1a20 + 0x20000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_cfg + * + * NIX AF Receive Configuration Register + */ +union nixx_af_rx_cfg { + u64 u; + struct nixx_af_rx_cfg_s { + u64 cbp_ena : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_rx_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_RX_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_CFG(void) +{ + return 0xd0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_chan#_cfg + * + * NIX AF Receive Channel Configuration Registers + */ +union nixx_af_rx_chanx_cfg { + u64 u; + struct nixx_af_rx_chanx_cfg_s { + u64 bpid : 9; + u64 reserved_9_15 : 7; + u64 bp_ena : 1; + u64 sw_xoff : 1; + u64 imp : 1; + u64 reserved_19_63 : 45; + } s; + /* struct nixx_af_rx_chanx_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_RX_CHANX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_CHANX_CFG(u64 a) +{ + return 0x1a30 + 0x8000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_cpt#_credit + * + * INTERNAL: NIX AF Receive CPT Credit Register Internal: Not used; no + * IPSEC fast-path. + */ +union nixx_af_rx_cptx_credit { + u64 u; + struct nixx_af_rx_cptx_credit_s { + u64 inst_cred_cnt : 22; + u64 reserved_22_63 : 42; + } s; + /* struct nixx_af_rx_cptx_credit_s cn; */ +}; + +static inline u64 NIXX_AF_RX_CPTX_CREDIT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_CPTX_CREDIT(u64 a) +{ + return 0x360 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_cpt#_inst_qsel + * + * INTERNAL: NIX AF Receive CPT Instruction Queue Select Register + * Internal: Not used; no IPSEC fast-path. + */ +union nixx_af_rx_cptx_inst_qsel { + u64 u; + struct nixx_af_rx_cptx_inst_qsel_s { + u64 slot : 8; + u64 pf_func : 16; + u64 reserved_24_63 : 40; + } s; + /* struct nixx_af_rx_cptx_inst_qsel_s cn; */ +}; + +static inline u64 NIXX_AF_RX_CPTX_INST_QSEL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_CPTX_INST_QSEL(u64 a) +{ + return 0x320 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_iip4 + * + * NIX AF Receive Inner IPv4 Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an inner IPv4 header. + * Typically the same as NPC_AF_PCK_DEF_IIP4. + */ +union nixx_af_rx_def_iip4 { + u64 u; + struct nixx_af_rx_def_iip4_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_iip4_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_IIP4(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_IIP4(void) +{ + return 0x220; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_iip6 + * + * NIX AF Receive Inner IPv6 Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an inner IPv6 header. + */ +union nixx_af_rx_def_iip6 { + u64 u; + struct nixx_af_rx_def_iip6_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_iip6_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_IIP6(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_IIP6(void) +{ + return 0x240; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_ipsec# + * + * INTERNAL: NIX AF Receive IPSEC Header Definition Registers Internal: + * Not used; no IPSEC fast-path. + */ +union nixx_af_rx_def_ipsecx { + u64 u; + struct nixx_af_rx_def_ipsecx_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11 : 1; + u64 spi_offset : 4; + u64 spi_nz : 1; + u64 reserved_17_63 : 47; + } s; + /* struct nixx_af_rx_def_ipsecx_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_IPSECX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_IPSECX(u64 a) +{ + return 0x2b0 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_isctp + * + * NIX AF Receive Inner SCTP Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an inner SCTP header. + */ +union nixx_af_rx_def_isctp { + u64 u; + struct nixx_af_rx_def_isctp_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_isctp_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_ISCTP(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_ISCTP(void) +{ + return 0x2a0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_itcp + * + * NIX AF Receive Inner TCP Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an inner TCP header. + */ +union nixx_af_rx_def_itcp { + u64 u; + struct nixx_af_rx_def_itcp_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_itcp_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_ITCP(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_ITCP(void) +{ + return 0x260; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_iudp + * + * NIX AF Receive Inner UDP Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an inner UDP header. + */ +union nixx_af_rx_def_iudp { + u64 u; + struct nixx_af_rx_def_iudp_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_iudp_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_IUDP(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_IUDP(void) +{ + return 0x280; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_oip4 + * + * NIX AF Receive Outer IPv4 Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an outer IPv4 L3 header. + * Typically the same as NPC_AF_PCK_DEF_OIP4. + */ +union nixx_af_rx_def_oip4 { + u64 u; + struct nixx_af_rx_def_oip4_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_oip4_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_OIP4(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_OIP4(void) +{ + return 0x210; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_oip6 + * + * NIX AF Receive Outer IPv6 Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an outer IPv6 header. + * Typically the same as NPC_AF_PCK_DEF_OIP6. + */ +union nixx_af_rx_def_oip6 { + u64 u; + struct nixx_af_rx_def_oip6_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_oip6_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_OIP6(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_OIP6(void) +{ + return 0x230; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_ol2 + * + * NIX AF Receive Outer L2 Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an outer L2/Ethernet header. + * Typically the same as NPC_AF_PCK_DEF_OL2. + */ +union nixx_af_rx_def_ol2 { + u64 u; + struct nixx_af_rx_def_ol2_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_ol2_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_OL2(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_OL2(void) +{ + return 0x200; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_osctp + * + * NIX AF Receive Outer SCTP Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an outer SCTP header. + */ +union nixx_af_rx_def_osctp { + u64 u; + struct nixx_af_rx_def_osctp_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_osctp_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_OSCTP(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_OSCTP(void) +{ + return 0x290; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_otcp + * + * NIX AF Receive Outer TCP Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an outer TCP header. + */ +union nixx_af_rx_def_otcp { + u64 u; + struct nixx_af_rx_def_otcp_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_otcp_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_OTCP(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_OTCP(void) +{ + return 0x250; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_def_oudp + * + * NIX AF Receive Outer UDP Header Definition Register Defines layer + * information in NPC_RESULT_S to identify an outer UDP header. + */ +union nixx_af_rx_def_oudp { + u64 u; + struct nixx_af_rx_def_oudp_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_af_rx_def_oudp_s cn; */ +}; + +static inline u64 NIXX_AF_RX_DEF_OUDP(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_DEF_OUDP(void) +{ + return 0x270; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_flow_key_alg#_field# + * + * NIX AF Receive Flow Key Algorithm Field Registers A flow key algorithm + * defines how the 40-byte FLOW_KEY is formed from the received packet + * header. FLOW_KEY is formed using up to five header fields (this + * register's last index) with up to 16 bytes per field. Header fields + * must not overlap in FLOW_KEY. The algorithm (index {a} (ALG) of these + * registers) is selected by NIX_RX_ACTION_S[FLOW_KEY_ALG] from the + * packet's NPC_RESULT_S[ACTION]. Internal: 40-byte FLOW_KEY is wide + * enough to support an IPv6 5-tuple that includes a VXLAN/GENEVE/NVGRE + * tunnel ID, e.g: _ Source IP: 16B. _ Dest IP: 16B. _ Source port: 2B. _ + * Dest port: 2B. _ Tunnel VNI/VSI: 3B. _ Total: 39B. + */ +union nixx_af_rx_flow_key_algx_fieldx { + u64 u; + struct nixx_af_rx_flow_key_algx_fieldx_s { + u64 key_offset : 6; + u64 ln_mask : 1; + u64 fn_mask : 1; + u64 hdr_offset : 8; + u64 bytesm1 : 5; + u64 lid : 3; + u64 reserved_24 : 1; + u64 ena : 1; + u64 sel_chan : 1; + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 reserved_35_63 : 29; + } s; + /* struct nixx_af_rx_flow_key_algx_fieldx_s cn; */ +}; + +static inline u64 NIXX_AF_RX_FLOW_KEY_ALGX_FIELDX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_FLOW_KEY_ALGX_FIELDX(u64 a, u64 b) +{ + return 0x1800 + 0x40000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_ipsec_gen_cfg + * + * INTERNAL: NIX AF Receive IPSEC General Configuration Register + * Internal: Not used; no IPSEC fast-path. + */ +union nixx_af_rx_ipsec_gen_cfg { + u64 u; + struct nixx_af_rx_ipsec_gen_cfg_s { + u64 param2 : 16; + u64 param1 : 16; + u64 opcode : 16; + u64 egrp : 3; + u64 reserved_51_63 : 13; + } s; + /* struct nixx_af_rx_ipsec_gen_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_RX_IPSEC_GEN_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_IPSEC_GEN_CFG(void) +{ + return 0x300; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_link#_cfg + * + * NIX AF Receive Link Configuration Registers Index enumerated by + * NIX_LINK_E. + */ +union nixx_af_rx_linkx_cfg { + u64 u; + struct nixx_af_rx_linkx_cfg_s { + u64 minlen : 16; + u64 maxlen : 16; + u64 reserved_32_63 : 32; + } s; + /* struct nixx_af_rx_linkx_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_RX_LINKX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_LINKX_CFG(u64 a) +{ + return 0x540 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_link#_sl#_spkt_cnt + * + * INTERNAL: NIX Receive Software Sync Link Packet Count Registers For + * diagnostic use only for debug of NIX_AF_RX_SW_SYNC[ENA] function. LINK + * index is enumerated by NIX_LINK_E. For the internal multicast/mirror + * link (NIX_LINK_E::MC), SL index is zero for multicast replay, one for + * mirror replay. SL index one is reserved for all other links. + * Internal: 802.3br frame preemption/express path is defeatured. Old + * definition of SL index: SL index is zero for non-express packets, one + * for express packets. For the internal NIX_LINK_E::MC, SL index is zero + * for multicast replay, one for mirror replay. + */ +union nixx_af_rx_linkx_slx_spkt_cnt { + u64 u; + struct nixx_af_rx_linkx_slx_spkt_cnt_s { + u64 in_cnt : 20; + u64 reserved_20_31 : 12; + u64 out_cnt : 20; + u64 reserved_52_63 : 12; + } s; + /* struct nixx_af_rx_linkx_slx_spkt_cnt_s cn; */ +}; + +static inline u64 NIXX_AF_RX_LINKX_SLX_SPKT_CNT(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_LINKX_SLX_SPKT_CNT(u64 a, u64 b) +{ + return 0x500 + 0x10000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_link#_wrr_cfg + * + * NIX AF Receive Link Weighted Round Robin Configuration Registers Index + * enumerated by NIX_LINK_E. + */ +union nixx_af_rx_linkx_wrr_cfg { + u64 u; + struct nixx_af_rx_linkx_wrr_cfg_s { + u64 weight : 8; + u64 reserved_8_63 : 56; + } s; + /* struct nixx_af_rx_linkx_wrr_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_RX_LINKX_WRR_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_LINKX_WRR_CFG(u64 a) +{ + return 0x560 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_mcast_base + * + * NIX AF Receive Multicast/Mirror Table Base Address Register This + * register specifies the base AF IOVA of the receive multicast/mirror + * table in NDC/LLC/DRAM. The table consists of 1 << + * (NIX_AF_RX_MCAST_CFG[SIZE] + 8) contiguous NIX_RX_MCE_S structures. + * The size of each structure is 1 << NIX_AF_CONST3[MCE_LOG2BYTES]. + * The table contains multicast/mirror replication lists. Each list + * consists of linked entries with NIX_RX_MCE_S[EOL] = 1 in the last + * entry. All lists must reside within the table size specified by + * NIX_AF_RX_MCAST_CFG[SIZE]. A mirror replication list will typically + * consist of two entries, but that is not checked or enforced by + * hardware. A receive packet is multicast when the action returned by + * NPC has NIX_RX_ACTION_S[OP] = NIX_RX_ACTIONOP_E::MCAST. A receive + * packet is mirrored when the action returned by NPC has + * NIX_RX_ACTION_S[OP] = NIX_RX_ACTIONOP_E::MIRROR. In both cases, + * NIX_RX_ACTION_S[INDEX] specifies the index of the replication list's + * first NIX_RX_MCE_S in the table, and a linked entry with + * NIX_RX_MCE_S[EOL] = 1 indicates the end of list. If a mirrored flow + * is part of a multicast replication list, software should include the + * two mirror entries in that list. Internal: A multicast list may have + * multiple entries for the same LF (e.g. for future RoCE/IB multicast). + */ +union nixx_af_rx_mcast_base { + u64 u; + struct nixx_af_rx_mcast_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_rx_mcast_base_s cn; */ +}; + +static inline u64 NIXX_AF_RX_MCAST_BASE(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_MCAST_BASE(void) +{ + return 0x100; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_mcast_buf_base + * + * NIX AF Receive Multicast Buffer Base Address Register This register + * specifies the base AF IOVA of the receive multicast buffers in + * NDC/LLC/DRAM. These buffers are used to temporarily store packets + * whose action returned by NPC has NIX_RX_ACTION_S[OP] = + * NIX_RX_ACTIONOP_E::MCAST. The number of buffers is configured by + * NIX_AF_RX_MCAST_BUF_CFG[SIZE]. If the number of free buffers is + * insufficient for a received multicast packet, hardware tail drops the + * packet and sets NIX_AF_GEN_INT[RX_MCAST_DROP]. Hardware prioritizes + * the processing of RX mirror packets over RX multicast packets. + */ +union nixx_af_rx_mcast_buf_base { + u64 u; + struct nixx_af_rx_mcast_buf_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_rx_mcast_buf_base_s cn; */ +}; + +static inline u64 NIXX_AF_RX_MCAST_BUF_BASE(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_MCAST_BUF_BASE(void) +{ + return 0x120; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_mcast_buf_cfg + * + * NIX AF Receive Multicast Buffer Configuration Register See + * NIX_AF_RX_MCAST_BUF_BASE. + */ +union nixx_af_rx_mcast_buf_cfg { + u64 u; + struct nixx_af_rx_mcast_buf_cfg_s { + u64 size : 4; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_21_23 : 3; + u64 npc_replay_pkind : 6; + u64 reserved_30_31 : 2; + u64 free_buf_level : 11; + u64 reserved_43_61 : 19; + u64 busy : 1; + u64 ena : 1; + } s; + struct nixx_af_rx_mcast_buf_cfg_cn96xxp1 { + u64 size : 4; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_21_23 : 3; + u64 npc_replay_pkind : 6; + u64 reserved_30_31 : 2; + u64 free_buf_level : 11; + u64 reserved_43_61 : 19; + u64 reserved_62 : 1; + u64 ena : 1; + } cn96xxp1; + /* struct nixx_af_rx_mcast_buf_cfg_s cn96xxp3; */ + struct nixx_af_rx_mcast_buf_cfg_cnf95xxp1 { + u64 size : 4; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_21_23 : 3; + u64 npc_replay_pkind : 6; + u64 reserved_30_31 : 2; + u64 free_buf_level : 11; + u64 reserved_43_62 : 20; + u64 ena : 1; + } cnf95xxp1; + /* struct nixx_af_rx_mcast_buf_cfg_s cnf95xxp2; */ +}; + +static inline u64 NIXX_AF_RX_MCAST_BUF_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_MCAST_BUF_CFG(void) +{ + return 0x130; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_mcast_cfg + * + * NIX AF Receive Multicast/Mirror Table Configuration Register See + * NIX_AF_RX_MCAST_BASE. + */ +union nixx_af_rx_mcast_cfg { + u64 u; + struct nixx_af_rx_mcast_cfg_s { + u64 size : 4; + u64 max_list_lenm1 : 8; + u64 reserved_12_19 : 8; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_37_63 : 27; + } s; + /* struct nixx_af_rx_mcast_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_RX_MCAST_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_MCAST_CFG(void) +{ + return 0x110; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_mirror_buf_base + * + * NIX AF Receive Mirror Buffer Base Address Register This register + * specifies the base AF IOVA of the receive mirror buffers in + * NDC/LLC/DRAM. These buffers are used to temporarily store packets + * whose action returned by NPC has NIX_RX_ACTION_S[OP] = + * NIX_RX_ACTIONOP_E::MIRROR. The number of buffers is configured by + * NIX_AF_RX_MIRROR_BUF_CFG[SIZE]. If the number of free buffers is + * insufficient for a received multicast packet, hardware tail drops the + * packet and sets NIX_AF_GEN_INT[RX_MIRROR_DROP]. Hardware prioritizes + * the processing of RX mirror packets over RX multicast packets. + */ +union nixx_af_rx_mirror_buf_base { + u64 u; + struct nixx_af_rx_mirror_buf_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_rx_mirror_buf_base_s cn; */ +}; + +static inline u64 NIXX_AF_RX_MIRROR_BUF_BASE(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_MIRROR_BUF_BASE(void) +{ + return 0x140; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_mirror_buf_cfg + * + * NIX AF Receive Mirror Buffer Configuration Register See + * NIX_AF_RX_MIRROR_BUF_BASE. + */ +union nixx_af_rx_mirror_buf_cfg { + u64 u; + struct nixx_af_rx_mirror_buf_cfg_s { + u64 size : 4; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_21_23 : 3; + u64 npc_replay_pkind : 6; + u64 reserved_30_31 : 2; + u64 free_buf_level : 11; + u64 reserved_43_61 : 19; + u64 busy : 1; + u64 ena : 1; + } s; + struct nixx_af_rx_mirror_buf_cfg_cn96xxp1 { + u64 size : 4; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_21_23 : 3; + u64 npc_replay_pkind : 6; + u64 reserved_30_31 : 2; + u64 free_buf_level : 11; + u64 reserved_43_61 : 19; + u64 reserved_62 : 1; + u64 ena : 1; + } cn96xxp1; + /* struct nixx_af_rx_mirror_buf_cfg_s cn96xxp3; */ + struct nixx_af_rx_mirror_buf_cfg_cnf95xxp1 { + u64 size : 4; + u64 way_mask : 16; + u64 caching : 1; + u64 reserved_21_23 : 3; + u64 npc_replay_pkind : 6; + u64 reserved_30_31 : 2; + u64 free_buf_level : 11; + u64 reserved_43_62 : 20; + u64 ena : 1; + } cnf95xxp1; + /* struct nixx_af_rx_mirror_buf_cfg_s cnf95xxp2; */ +}; + +static inline u64 NIXX_AF_RX_MIRROR_BUF_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_MIRROR_BUF_CFG(void) +{ + return 0x148; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_npc_mc_drop + * + * NIX AF Multicast Drop Statistics Register The counter increments for + * every dropped MC packet marked by the NPC. + */ +union nixx_af_rx_npc_mc_drop { + u64 u; + struct nixx_af_rx_npc_mc_drop_s { + u64 stat : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_rx_npc_mc_drop_s cn; */ +}; + +static inline u64 NIXX_AF_RX_NPC_MC_DROP(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_NPC_MC_DROP(void) +{ + return 0x4710; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_npc_mc_rcv + * + * NIX AF Multicast Receive Statistics Register The counter increments + * for every received MC packet marked by the NPC. + */ +union nixx_af_rx_npc_mc_rcv { + u64 u; + struct nixx_af_rx_npc_mc_rcv_s { + u64 stat : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_rx_npc_mc_rcv_s cn; */ +}; + +static inline u64 NIXX_AF_RX_NPC_MC_RCV(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_NPC_MC_RCV(void) +{ + return 0x4700; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_npc_mirror_drop + * + * NIX AF Mirror Drop Statistics Register The counter increments for + * every dropped MIRROR packet marked by the NPC. + */ +union nixx_af_rx_npc_mirror_drop { + u64 u; + struct nixx_af_rx_npc_mirror_drop_s { + u64 stat : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_rx_npc_mirror_drop_s cn; */ +}; + +static inline u64 NIXX_AF_RX_NPC_MIRROR_DROP(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_NPC_MIRROR_DROP(void) +{ + return 0x4730; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_npc_mirror_rcv + * + * NIX AF Mirror Receive Statistics Register The counter increments for + * every received MIRROR packet marked by the NPC. + */ +union nixx_af_rx_npc_mirror_rcv { + u64 u; + struct nixx_af_rx_npc_mirror_rcv_s { + u64 stat : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_rx_npc_mirror_rcv_s cn; */ +}; + +static inline u64 NIXX_AF_RX_NPC_MIRROR_RCV(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_NPC_MIRROR_RCV(void) +{ + return 0x4720; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_rx_sw_sync + * + * NIX AF Receive Software Sync Register + */ +union nixx_af_rx_sw_sync { + u64 u; + struct nixx_af_rx_sw_sync_s { + u64 ena : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_rx_sw_sync_s cn; */ +}; + +static inline u64 NIXX_AF_RX_SW_SYNC(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_RX_SW_SYNC(void) +{ + return 0x550; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_sdp_hw_xoff# + * + * NIX AF SDP Transmit Link Hardware Controlled XOFF Registers . + */ +union nixx_af_sdp_hw_xoffx { + u64 u; + struct nixx_af_sdp_hw_xoffx_s { + u64 chan_xoff : 64; + } s; + /* struct nixx_af_sdp_hw_xoffx_s cn; */ +}; + +static inline u64 NIXX_AF_SDP_HW_XOFFX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SDP_HW_XOFFX(u64 a) +{ + return 0xac0 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_sdp_link_credit + * + * NIX AF Transmit Link SDP Credit Register This register tracks SDP link + * credits. + */ +union nixx_af_sdp_link_credit { + u64 u; + struct nixx_af_sdp_link_credit_s { + u64 reserved_0 : 1; + u64 cc_enable : 1; + u64 cc_packet_cnt : 10; + u64 cc_unit_cnt : 20; + u64 reserved_32_62 : 31; + u64 pse_pkt_id_lmt : 1; + } s; + struct nixx_af_sdp_link_credit_cn96xx { + u64 reserved_0 : 1; + u64 cc_enable : 1; + u64 cc_packet_cnt : 10; + u64 cc_unit_cnt : 20; + u64 reserved_32_62 : 31; + u64 reserved_63 : 1; + } cn96xx; + /* struct nixx_af_sdp_link_credit_s cnf95xx; */ +}; + +static inline u64 NIXX_AF_SDP_LINK_CREDIT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SDP_LINK_CREDIT(void) +{ + return 0xa40; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_sdp_sw_xoff# + * + * INTERNAL: NIX AF SDP Transmit Link Software Controlled XOFF Registers + * Internal: Defeatured registers. Software should use + * NIX_AF_TL4()_SW_XOFF registers instead. + */ +union nixx_af_sdp_sw_xoffx { + u64 u; + struct nixx_af_sdp_sw_xoffx_s { + u64 chan_xoff : 64; + } s; + /* struct nixx_af_sdp_sw_xoffx_s cn; */ +}; + +static inline u64 NIXX_AF_SDP_SW_XOFFX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SDP_SW_XOFFX(u64 a) +{ + return 0xa60 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_sdp_tx_fifo_status + * + * NIX AF SDP Transmit FIFO Status Register Status of FIFO which + * transmits packets to SDP. + */ +union nixx_af_sdp_tx_fifo_status { + u64 u; + struct nixx_af_sdp_tx_fifo_status_s { + u64 count : 12; + u64 reserved_12_63 : 52; + } s; + /* struct nixx_af_sdp_tx_fifo_status_s cn; */ +}; + +static inline u64 NIXX_AF_SDP_TX_FIFO_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SDP_TX_FIFO_STATUS(void) +{ + return 0x650; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_seb_active_cycles_pc# + * + * NIX AF Active Cycles Register These registers are indexed by the + * conditional clock domain number. + */ +union nixx_af_seb_active_cycles_pcx { + u64 u; + struct nixx_af_seb_active_cycles_pcx_s { + u64 act_cyc : 64; + } s; + /* struct nixx_af_seb_active_cycles_pcx_s cn; */ +}; + +static inline u64 NIXX_AF_SEB_ACTIVE_CYCLES_PCX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SEB_ACTIVE_CYCLES_PCX(u64 a) +{ + return 0x6c0 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_seb_bp_test + * + * INTERNAL: NIX AF SEB Backpressure Test Register + */ +union nixx_af_seb_bp_test { + u64 u; + struct nixx_af_seb_bp_test_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 14; + u64 reserved_30_47 : 18; + u64 enable : 7; + u64 reserved_55_63 : 9; + } s; + /* struct nixx_af_seb_bp_test_s cn; */ +}; + +static inline u64 NIXX_AF_SEB_BP_TEST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SEB_BP_TEST(void) +{ + return 0x630; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_seb_cfg + * + * NIX SEB Configuration Register + */ +union nixx_af_seb_cfg { + u64 u; + struct nixx_af_seb_cfg_s { + u64 sg_ndc_sel : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_seb_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_SEB_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SEB_CFG(void) +{ + return 0x5f0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_seb_eco + * + * INTERNAL: AF SEB ECO Register + */ +union nixx_af_seb_eco { + u64 u; + struct nixx_af_seb_eco_s { + u64 eco_rw : 64; + } s; + /* struct nixx_af_seb_eco_s cn; */ +}; + +static inline u64 NIXX_AF_SEB_ECO(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SEB_ECO(void) +{ + return 0x5c0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_seb_pipe_bp_test# + * + * INTERNAL: NIX AF SEB Pipe Backpressure Test Registers + */ +union nixx_af_seb_pipe_bp_testx { + u64 u; + struct nixx_af_seb_pipe_bp_testx_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 24; + u64 reserved_40_47 : 8; + u64 enable : 12; + u64 reserved_60_63 : 4; + } s; + /* struct nixx_af_seb_pipe_bp_testx_s cn; */ +}; + +static inline u64 NIXX_AF_SEB_PIPE_BP_TESTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SEB_PIPE_BP_TESTX(u64 a) +{ + return 0x600 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_seb_pipeb_bp_test# + * + * INTERNAL: NIX AF SEB Pipe Backpressure Test Registers + */ +union nixx_af_seb_pipeb_bp_testx { + u64 u; + struct nixx_af_seb_pipeb_bp_testx_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 18; + u64 reserved_34_47 : 14; + u64 enable : 9; + u64 reserved_57_63 : 7; + } s; + /* struct nixx_af_seb_pipeb_bp_testx_s cn; */ +}; + +static inline u64 NIXX_AF_SEB_PIPEB_BP_TESTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SEB_PIPEB_BP_TESTX(u64 a) +{ + return 0x608 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_seb_wd_tick_divider + * + * INTERNAL: NIX AF SEB TSTMP Watchdog Tick Divider Register + */ +union nixx_af_seb_wd_tick_divider { + u64 u; + struct nixx_af_seb_wd_tick_divider_s { + u64 tick_div_cfg : 7; + u64 reserved_7_63 : 57; + } s; + /* struct nixx_af_seb_wd_tick_divider_s cn; */ +}; + +static inline u64 NIXX_AF_SEB_WD_TICK_DIVIDER(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SEB_WD_TICK_DIVIDER(void) +{ + return 0x6f0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_smq#_cfg + * + * NIX AF SQM PSE Queue Configuration Registers + */ +union nixx_af_smqx_cfg { + u64 u; + struct nixx_af_smqx_cfg_s { + u64 minlen : 7; + u64 desc_shp_ctl_dis : 1; + u64 maxlen : 16; + u64 lf : 7; + u64 reserved_31_35 : 5; + u64 max_vtag_ins : 3; + u64 rr_minlen : 9; + u64 express : 1; + u64 flush : 1; + u64 enq_xoff : 1; + u64 pri_thr : 6; + u64 reserved_57_63 : 7; + } s; + /* struct nixx_af_smqx_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_SMQX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SMQX_CFG(u64 a) +{ + return 0x700 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_smq#_head + * + * NIX AF SQM SMQ Head Register These registers track the head of the SMQ + * linked list. + */ +union nixx_af_smqx_head { + u64 u; + struct nixx_af_smqx_head_s { + u64 sq_idx : 20; + u64 valid : 1; + u64 reserved_21_63 : 43; + } s; + /* struct nixx_af_smqx_head_s cn; */ +}; + +static inline u64 NIXX_AF_SMQX_HEAD(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SMQX_HEAD(u64 a) +{ + return 0x710 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_smq#_nxt_head + * + * NIX AF SQM SMQ Next Head Register These registers track the next head + * of the SMQ linked list. + */ +union nixx_af_smqx_nxt_head { + u64 u; + struct nixx_af_smqx_nxt_head_s { + u64 sq_idx : 20; + u64 valid : 1; + u64 reserved_21_63 : 43; + } s; + /* struct nixx_af_smqx_nxt_head_s cn; */ +}; + +static inline u64 NIXX_AF_SMQX_NXT_HEAD(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SMQX_NXT_HEAD(u64 a) +{ + return 0x740 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_smq#_status + * + * NIX AF SQM SMQ Status Register These registers track the status of the + * SMQ FIFO. + */ +union nixx_af_smqx_status { + u64 u; + struct nixx_af_smqx_status_s { + u64 level : 7; + u64 reserved_7_63 : 57; + } s; + /* struct nixx_af_smqx_status_s cn; */ +}; + +static inline u64 NIXX_AF_SMQX_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SMQX_STATUS(u64 a) +{ + return 0x730 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_smq#_tail + * + * NIX AF SQM SMQ Head Register These registers track the tail of SMQ + * linked list. + */ +union nixx_af_smqx_tail { + u64 u; + struct nixx_af_smqx_tail_s { + u64 sq_idx : 20; + u64 valid : 1; + u64 reserved_21_63 : 43; + } s; + /* struct nixx_af_smqx_tail_s cn; */ +}; + +static inline u64 NIXX_AF_SMQX_TAIL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SMQX_TAIL(u64 a) +{ + return 0x720 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_sq_const + * + * NIX AF SQ Constants Register This register contains constants for + * software discovery. + */ +union nixx_af_sq_const { + u64 u; + struct nixx_af_sq_const_s { + u64 queues_per_lf : 24; + u64 smq_depth : 10; + u64 sqb_size : 16; + u64 reserved_50_63 : 14; + } s; + /* struct nixx_af_sq_const_s cn; */ +}; + +static inline u64 NIXX_AF_SQ_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SQ_CONST(void) +{ + return 0x40; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_sqm_active_cycles_pc + * + * NIX AF SQM Active Cycles Register These registers are indexed by the + * conditional clock domain number. + */ +union nixx_af_sqm_active_cycles_pc { + u64 u; + struct nixx_af_sqm_active_cycles_pc_s { + u64 act_cyc : 64; + } s; + /* struct nixx_af_sqm_active_cycles_pc_s cn; */ +}; + +static inline u64 NIXX_AF_SQM_ACTIVE_CYCLES_PC(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SQM_ACTIVE_CYCLES_PC(void) +{ + return 0x770; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_sqm_bp_test# + * + * INTERNAL: NIX AF SQM Backpressure Test Register + */ +union nixx_af_sqm_bp_testx { + u64 u; + struct nixx_af_sqm_bp_testx_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 8; + u64 reserved_24_59 : 36; + u64 enable : 4; + } s; + /* struct nixx_af_sqm_bp_testx_s cn; */ +}; + +static inline u64 NIXX_AF_SQM_BP_TESTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SQM_BP_TESTX(u64 a) +{ + return 0x760 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_sqm_dbg_ctl_status + * + * NIX AF SQM Debug Register This register is for SQM diagnostic use + * only. + */ +union nixx_af_sqm_dbg_ctl_status { + u64 u; + struct nixx_af_sqm_dbg_ctl_status_s { + u64 tm1 : 8; + u64 tm2 : 1; + u64 tm3 : 4; + u64 tm4 : 1; + u64 tm5 : 1; + u64 tm6 : 1; + u64 tm7 : 4; + u64 tm8 : 1; + u64 tm9 : 1; + u64 tm10 : 1; + u64 tm11 : 1; + u64 tm12 : 1; + u64 tm13 : 1; + u64 reserved_26_63 : 38; + } s; + struct nixx_af_sqm_dbg_ctl_status_cn96xxp1 { + u64 tm1 : 8; + u64 tm2 : 1; + u64 tm3 : 4; + u64 tm4 : 1; + u64 tm5 : 1; + u64 tm6 : 1; + u64 tm7 : 4; + u64 tm8 : 1; + u64 tm9 : 1; + u64 reserved_22_63 : 42; + } cn96xxp1; + /* struct nixx_af_sqm_dbg_ctl_status_s cn96xxp3; */ + /* struct nixx_af_sqm_dbg_ctl_status_cn96xxp1 cnf95xxp1; */ + struct nixx_af_sqm_dbg_ctl_status_cnf95xxp2 { + u64 tm1 : 8; + u64 tm2 : 1; + u64 tm3 : 4; + u64 tm4 : 1; + u64 tm5 : 1; + u64 tm6 : 1; + u64 tm7 : 4; + u64 tm8 : 1; + u64 tm9 : 1; + u64 reserved_22 : 1; + u64 reserved_23 : 1; + u64 reserved_24 : 1; + u64 reserved_25 : 1; + u64 reserved_26_63 : 38; + } cnf95xxp2; +}; + +static inline u64 NIXX_AF_SQM_DBG_CTL_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SQM_DBG_CTL_STATUS(void) +{ + return 0x750; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_sqm_eco + * + * INTERNAL: AF SQM ECO Register + */ +union nixx_af_sqm_eco { + u64 u; + struct nixx_af_sqm_eco_s { + u64 eco_rw : 64; + } s; + /* struct nixx_af_sqm_eco_s cn; */ +}; + +static inline u64 NIXX_AF_SQM_ECO(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_SQM_ECO(void) +{ + return 0x5b0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_status + * + * NIX AF General Status Register + */ +union nixx_af_status { + u64 u; + struct nixx_af_status_s { + u64 blk_busy : 10; + u64 calibrate_done : 1; + u64 reserved_11_15 : 5; + u64 calibrate_status : 15; + u64 reserved_31_63 : 33; + } s; + /* struct nixx_af_status_s cn; */ +}; + +static inline u64 NIXX_AF_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_STATUS(void) +{ + return 0x10; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tcp_timer + * + * NIX TCP Timer Register + */ +union nixx_af_tcp_timer { + u64 u; + struct nixx_af_tcp_timer_s { + u64 dur_counter : 16; + u64 lf_counter : 8; + u64 reserved_24_31 : 8; + u64 duration : 16; + u64 reserved_48_62 : 15; + u64 ena : 1; + } s; + /* struct nixx_af_tcp_timer_s cn; */ +}; + +static inline u64 NIXX_AF_TCP_TIMER(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TCP_TIMER(void) +{ + return 0x1e0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_cir + * + * NIX AF Transmit Level 1 Committed Information Rate Register + */ +union nixx_af_tl1x_cir { + u64 u; + struct nixx_af_tl1x_cir_s { + u64 enable : 1; + u64 rate_mantissa : 8; + u64 rate_exponent : 4; + u64 rate_divider_exponent : 4; + u64 reserved_17_28 : 12; + u64 burst_mantissa : 8; + u64 burst_exponent : 4; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl1x_cir_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_CIR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_CIR(u64 a) +{ + return 0xc20 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_dropped_bytes + * + * NIX AF Transmit Level 1 Dropped Bytes Registers This register has the + * same bit fields as NIX_AF_TL1()_GREEN_BYTES. + */ +union nixx_af_tl1x_dropped_bytes { + u64 u; + struct nixx_af_tl1x_dropped_bytes_s { + u64 count : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_tl1x_dropped_bytes_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_DROPPED_BYTES(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_DROPPED_BYTES(u64 a) +{ + return 0xd30 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_dropped_packets + * + * NIX AF Transmit Level 1 Dropped Packets Registers This register has + * the same bit fields as NIX_AF_TL1()_GREEN_PACKETS. + */ +union nixx_af_tl1x_dropped_packets { + u64 u; + struct nixx_af_tl1x_dropped_packets_s { + u64 count : 40; + u64 reserved_40_63 : 24; + } s; + /* struct nixx_af_tl1x_dropped_packets_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_DROPPED_PACKETS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_DROPPED_PACKETS(u64 a) +{ + return 0xd20 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_green + * + * INTERNAL: NIX Transmit Level 1 Green State Debug Register + */ +union nixx_af_tl1x_green { + u64 u; + struct nixx_af_tl1x_green_s { + u64 tail : 8; + u64 reserved_8_9 : 2; + u64 head : 8; + u64 reserved_18_19 : 2; + u64 active_vec : 20; + u64 rr_active : 1; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl1x_green_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_GREEN(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_GREEN(u64 a) +{ + return 0xc90 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_green_bytes + * + * NIX AF Transmit Level 1 Green Sent Bytes Registers + */ +union nixx_af_tl1x_green_bytes { + u64 u; + struct nixx_af_tl1x_green_bytes_s { + u64 count : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_tl1x_green_bytes_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_GREEN_BYTES(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_GREEN_BYTES(u64 a) +{ + return 0xd90 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_green_packets + * + * NIX AF Transmit Level 1 Green Sent Packets Registers + */ +union nixx_af_tl1x_green_packets { + u64 u; + struct nixx_af_tl1x_green_packets_s { + u64 count : 40; + u64 reserved_40_63 : 24; + } s; + /* struct nixx_af_tl1x_green_packets_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_GREEN_PACKETS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_GREEN_PACKETS(u64 a) +{ + return 0xd80 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_md_debug0 + * + * NIX AF Transmit Level 1 Meta Descriptor Debug 0 Registers + * NIX_AF_TL1()_MD_DEBUG0, NIX_AF_TL1()_MD_DEBUG1, NIX_AF_TL1()_MD_DEBUG2 + * and NIX_AF_TL1()_MD_DEBUG3 provide access to the TLn queue meta + * descriptor. A TLn queue can hold up to two packet meta descriptors + * (PMD) and one flush meta descriptor (FMD): * PMD0 state is accessed + * with [PMD0_VLD], [PMD0_LENGTH] and NIX_AF_TL1()_MD_DEBUG1. * PMD1 is + * accessed with [PMD1_VLD], [PMD1_LENGTH] and NIX_AF_TL1()_MD_DEBUG2. * + * FMD is accessed with NIX_AF_TL1()_MD_DEBUG3. + */ +union nixx_af_tl1x_md_debug0 { + u64 u; + struct nixx_af_tl1x_md_debug0_s { + u64 pmd0_length : 16; + u64 pmd1_length : 16; + u64 pmd0_vld : 1; + u64 pmd1_vld : 1; + u64 reserved_34_45 : 12; + u64 drain_pri : 1; + u64 drain : 1; + u64 c_con : 1; + u64 p_con : 1; + u64 reserved_50_51 : 2; + u64 child : 10; + u64 reserved_62 : 1; + u64 pmd_count : 1; + } s; + /* struct nixx_af_tl1x_md_debug0_s cn96xxp1; */ + struct nixx_af_tl1x_md_debug0_cn96xxp3 { + u64 pmd0_length : 16; + u64 reserved_16_31 : 16; + u64 pmd0_vld : 1; + u64 reserved_33 : 1; + u64 reserved_34_45 : 12; + u64 reserved_46 : 1; + u64 reserved_47 : 1; + u64 c_con : 1; + u64 p_con : 1; + u64 reserved_50_51 : 2; + u64 child : 10; + u64 reserved_62 : 1; + u64 reserved_63 : 1; + } cn96xxp3; + /* struct nixx_af_tl1x_md_debug0_s cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL1X_MD_DEBUG0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_MD_DEBUG0(u64 a) +{ + return 0xcc0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_md_debug1 + * + * NIX AF Transmit Level 1 Meta Descriptor Debug 1 Registers Packet meta + * descriptor 0 debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl1x_md_debug1 { + u64 u; + struct nixx_af_tl1x_md_debug1_s { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 reserved_23 : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + struct nixx_af_tl1x_md_debug1_cn96xxp1 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 drain : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp1; + struct nixx_af_tl1x_md_debug1_cn96xxp3 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 reserved_19_22 : 4; + u64 flush : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp3; + /* struct nixx_af_tl1x_md_debug1_cn96xxp1 cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL1X_MD_DEBUG1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_MD_DEBUG1(u64 a) +{ + return 0xcc8 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_md_debug2 + * + * NIX AF Transmit Level 1 Meta Descriptor Debug 2 Registers Packet meta + * descriptor 1 debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl1x_md_debug2 { + u64 u; + struct nixx_af_tl1x_md_debug2_s { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 reserved_23 : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + struct nixx_af_tl1x_md_debug2_cn96xxp1 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 drain : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp1; + struct nixx_af_tl1x_md_debug2_cn96xxp3 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 reserved_19_22 : 4; + u64 flush : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp3; + /* struct nixx_af_tl1x_md_debug2_cn96xxp1 cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL1X_MD_DEBUG2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_MD_DEBUG2(u64 a) +{ + return 0xcd0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_md_debug3 + * + * NIX AF Transmit Level 1 Meta Descriptor Debug 3 Registers Flush meta + * descriptor debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl1x_md_debug3 { + u64 u; + struct nixx_af_tl1x_md_debug3_s { + u64 reserved_0_36 : 37; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + /* struct nixx_af_tl1x_md_debug3_s cn96xxp1; */ + struct nixx_af_tl1x_md_debug3_cn96xxp3 { + u64 reserved_0_36 : 37; + u64 reserved_37_38 : 2; + u64 reserved_39_51 : 13; + u64 reserved_52_61 : 10; + u64 reserved_62 : 1; + u64 reserved_63 : 1; + } cn96xxp3; + /* struct nixx_af_tl1x_md_debug3_s cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL1X_MD_DEBUG3(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_MD_DEBUG3(u64 a) +{ + return 0xcd8 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_red + * + * INTERNAL: NIX Transmit Level 1 Red State Debug Register This register + * has the same bit fields as NIX_AF_TL1()_YELLOW. + */ +union nixx_af_tl1x_red { + u64 u; + struct nixx_af_tl1x_red_s { + u64 tail : 8; + u64 reserved_8_9 : 2; + u64 head : 8; + u64 reserved_18_63 : 46; + } s; + /* struct nixx_af_tl1x_red_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_RED(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_RED(u64 a) +{ + return 0xcb0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_red_bytes + * + * NIX AF Transmit Level 1 Red Sent Bytes Registers This register has the + * same bit fields as NIX_AF_TL1()_GREEN_BYTES. + */ +union nixx_af_tl1x_red_bytes { + u64 u; + struct nixx_af_tl1x_red_bytes_s { + u64 count : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_tl1x_red_bytes_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_RED_BYTES(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_RED_BYTES(u64 a) +{ + return 0xd50 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_red_packets + * + * NIX AF Transmit Level 1 Red Sent Packets Registers This register has + * the same bit fields as NIX_AF_TL1()_GREEN_PACKETS. + */ +union nixx_af_tl1x_red_packets { + u64 u; + struct nixx_af_tl1x_red_packets_s { + u64 count : 40; + u64 reserved_40_63 : 24; + } s; + /* struct nixx_af_tl1x_red_packets_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_RED_PACKETS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_RED_PACKETS(u64 a) +{ + return 0xd40 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_schedule + * + * NIX AF Transmit Level 1 Scheduling Control Register + */ +union nixx_af_tl1x_schedule { + u64 u; + struct nixx_af_tl1x_schedule_s { + u64 rr_quantum : 24; + u64 reserved_24_63 : 40; + } s; + /* struct nixx_af_tl1x_schedule_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_SCHEDULE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_SCHEDULE(u64 a) +{ + return 0xc00 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_shape + * + * NIX AF Transmit Level 1 Shaping Control Register + */ +union nixx_af_tl1x_shape { + u64 u; + struct nixx_af_tl1x_shape_s { + u64 adjust : 9; + u64 reserved_9_23 : 15; + u64 length_disable : 1; + u64 reserved_25_63 : 39; + } s; + struct nixx_af_tl1x_shape_cn { + u64 adjust : 9; + u64 reserved_9_17 : 9; + u64 reserved_18_23 : 6; + u64 length_disable : 1; + u64 reserved_25_63 : 39; + } cn; +}; + +static inline u64 NIXX_AF_TL1X_SHAPE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_SHAPE(u64 a) +{ + return 0xc10 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_shape_state + * + * NIX AF Transmit Level 1 Shape State Register This register must not be + * written during normal operation. + */ +union nixx_af_tl1x_shape_state { + u64 u; + struct nixx_af_tl1x_shape_state_s { + u64 cir_accum : 26; + u64 reserved_26_51 : 26; + u64 color : 1; + u64 reserved_53_63 : 11; + } s; + /* struct nixx_af_tl1x_shape_state_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_SHAPE_STATE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_SHAPE_STATE(u64 a) +{ + return 0xc50 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_sw_xoff + * + * NIX AF Transmit Level 1 Software Controlled XOFF Registers + */ +union nixx_af_tl1x_sw_xoff { + u64 u; + struct nixx_af_tl1x_sw_xoff_s { + u64 xoff : 1; + u64 drain : 1; + u64 reserved_2 : 1; + u64 drain_irq : 1; + u64 reserved_4_63 : 60; + } s; + /* struct nixx_af_tl1x_sw_xoff_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_SW_XOFF(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_SW_XOFF(u64 a) +{ + return 0xc70 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_topology + * + * NIX AF Transmit Level 1 Topology Registers + */ +union nixx_af_tl1x_topology { + u64 u; + struct nixx_af_tl1x_topology_s { + u64 reserved_0 : 1; + u64 rr_prio : 4; + u64 reserved_5_31 : 27; + u64 prio_anchor : 8; + u64 reserved_40_63 : 24; + } s; + /* struct nixx_af_tl1x_topology_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_TOPOLOGY(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_TOPOLOGY(u64 a) +{ + return 0xc80 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_yellow + * + * INTERNAL: NIX Transmit Level 1 Yellow State Debug Register + */ +union nixx_af_tl1x_yellow { + u64 u; + struct nixx_af_tl1x_yellow_s { + u64 tail : 8; + u64 reserved_8_9 : 2; + u64 head : 8; + u64 reserved_18_63 : 46; + } s; + /* struct nixx_af_tl1x_yellow_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_YELLOW(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_YELLOW(u64 a) +{ + return 0xca0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_yellow_bytes + * + * NIX AF Transmit Level 1 Yellow Sent Bytes Registers This register has + * the same bit fields as NIX_AF_TL1()_GREEN_BYTES. + */ +union nixx_af_tl1x_yellow_bytes { + u64 u; + struct nixx_af_tl1x_yellow_bytes_s { + u64 count : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_af_tl1x_yellow_bytes_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_YELLOW_BYTES(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_YELLOW_BYTES(u64 a) +{ + return 0xd70 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1#_yellow_packets + * + * NIX AF Transmit Level 1 Yellow Sent Packets Registers This register + * has the same bit fields as NIX_AF_TL1()_GREEN_PACKETS. + */ +union nixx_af_tl1x_yellow_packets { + u64 u; + struct nixx_af_tl1x_yellow_packets_s { + u64 count : 40; + u64 reserved_40_63 : 24; + } s; + /* struct nixx_af_tl1x_yellow_packets_s cn; */ +}; + +static inline u64 NIXX_AF_TL1X_YELLOW_PACKETS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1X_YELLOW_PACKETS(u64 a) +{ + return 0xd60 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl1_const + * + * NIX AF Transmit Level 1 Constants Register This register contains + * constants for software discovery. + */ +union nixx_af_tl1_const { + u64 u; + struct nixx_af_tl1_const_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct nixx_af_tl1_const_s cn; */ +}; + +static inline u64 NIXX_AF_TL1_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL1_CONST(void) +{ + return 0x70; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_cir + * + * NIX AF Transmit Level 2 Committed Information Rate Registers This + * register has the same bit fields as NIX_AF_TL1()_CIR. + */ +union nixx_af_tl2x_cir { + u64 u; + struct nixx_af_tl2x_cir_s { + u64 enable : 1; + u64 rate_mantissa : 8; + u64 rate_exponent : 4; + u64 rate_divider_exponent : 4; + u64 reserved_17_28 : 12; + u64 burst_mantissa : 8; + u64 burst_exponent : 4; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl2x_cir_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_CIR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_CIR(u64 a) +{ + return 0xe20 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_green + * + * INTERNAL: NIX Transmit Level 2 Green State Debug Register This + * register has the same bit fields as NIX_AF_TL1()_GREEN. + */ +union nixx_af_tl2x_green { + u64 u; + struct nixx_af_tl2x_green_s { + u64 tail : 8; + u64 reserved_8_9 : 2; + u64 head : 8; + u64 reserved_18_19 : 2; + u64 active_vec : 20; + u64 rr_active : 1; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl2x_green_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_GREEN(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_GREEN(u64 a) +{ + return 0xe90 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_md_debug0 + * + * NIX AF Transmit Level 2 Meta Descriptor Debug 0 Registers See + * NIX_AF_TL1()_MD_DEBUG0 + */ +union nixx_af_tl2x_md_debug0 { + u64 u; + struct nixx_af_tl2x_md_debug0_s { + u64 pmd0_length : 16; + u64 pmd1_length : 16; + u64 pmd0_vld : 1; + u64 pmd1_vld : 1; + u64 reserved_34_45 : 12; + u64 drain_pri : 1; + u64 drain : 1; + u64 c_con : 1; + u64 p_con : 1; + u64 reserved_50_51 : 2; + u64 child : 10; + u64 reserved_62 : 1; + u64 pmd_count : 1; + } s; + /* struct nixx_af_tl2x_md_debug0_s cn96xxp1; */ + struct nixx_af_tl2x_md_debug0_cn96xxp3 { + u64 pmd0_length : 16; + u64 reserved_16_31 : 16; + u64 pmd0_vld : 1; + u64 reserved_33 : 1; + u64 reserved_34_45 : 12; + u64 reserved_46 : 1; + u64 reserved_47 : 1; + u64 c_con : 1; + u64 p_con : 1; + u64 reserved_50_51 : 2; + u64 child : 10; + u64 reserved_62 : 1; + u64 reserved_63 : 1; + } cn96xxp3; + /* struct nixx_af_tl2x_md_debug0_s cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL2X_MD_DEBUG0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_MD_DEBUG0(u64 a) +{ + return 0xec0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_md_debug1 + * + * NIX AF Transmit Level 2 Meta Descriptor Debug 1 Registers Packet meta + * descriptor 0 debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl2x_md_debug1 { + u64 u; + struct nixx_af_tl2x_md_debug1_s { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 reserved_23 : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + struct nixx_af_tl2x_md_debug1_cn96xxp1 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 drain : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp1; + struct nixx_af_tl2x_md_debug1_cn96xxp3 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 reserved_19_22 : 4; + u64 flush : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp3; + /* struct nixx_af_tl2x_md_debug1_cn96xxp1 cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL2X_MD_DEBUG1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_MD_DEBUG1(u64 a) +{ + return 0xec8 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_md_debug2 + * + * NIX AF Transmit Level 2 Meta Descriptor Debug 2 Registers Packet meta + * descriptor 1 debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl2x_md_debug2 { + u64 u; + struct nixx_af_tl2x_md_debug2_s { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 reserved_23 : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + struct nixx_af_tl2x_md_debug2_cn96xxp1 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 drain : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp1; + struct nixx_af_tl2x_md_debug2_cn96xxp3 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 reserved_19_22 : 4; + u64 flush : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp3; + /* struct nixx_af_tl2x_md_debug2_cn96xxp1 cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL2X_MD_DEBUG2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_MD_DEBUG2(u64 a) +{ + return 0xed0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_md_debug3 + * + * NIX AF Transmit Level 2 Meta Descriptor Debug 3 Registers Flush meta + * descriptor debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl2x_md_debug3 { + u64 u; + struct nixx_af_tl2x_md_debug3_s { + u64 reserved_0_36 : 37; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + /* struct nixx_af_tl2x_md_debug3_s cn96xxp1; */ + struct nixx_af_tl2x_md_debug3_cn96xxp3 { + u64 reserved_0_36 : 37; + u64 reserved_37_38 : 2; + u64 reserved_39_51 : 13; + u64 reserved_52_61 : 10; + u64 reserved_62 : 1; + u64 reserved_63 : 1; + } cn96xxp3; + /* struct nixx_af_tl2x_md_debug3_s cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL2X_MD_DEBUG3(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_MD_DEBUG3(u64 a) +{ + return 0xed8 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_parent + * + * NIX AF Transmit Level 2 Parent Registers + */ +union nixx_af_tl2x_parent { + u64 u; + struct nixx_af_tl2x_parent_s { + u64 reserved_0_15 : 16; + u64 parent : 5; + u64 reserved_21_63 : 43; + } s; + /* struct nixx_af_tl2x_parent_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_PARENT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_PARENT(u64 a) +{ + return 0xe88 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_pir + * + * NIX AF Transmit Level 2 Peak Information Rate Registers This register + * has the same bit fields as NIX_AF_TL1()_CIR. + */ +union nixx_af_tl2x_pir { + u64 u; + struct nixx_af_tl2x_pir_s { + u64 enable : 1; + u64 rate_mantissa : 8; + u64 rate_exponent : 4; + u64 rate_divider_exponent : 4; + u64 reserved_17_28 : 12; + u64 burst_mantissa : 8; + u64 burst_exponent : 4; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl2x_pir_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_PIR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_PIR(u64 a) +{ + return 0xe30 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_pointers + * + * INTERNAL: NIX Transmit Level 2 Linked List Pointers Debug Register + */ +union nixx_af_tl2x_pointers { + u64 u; + struct nixx_af_tl2x_pointers_s { + u64 next : 8; + u64 reserved_8_15 : 8; + u64 prev : 8; + u64 reserved_24_63 : 40; + } s; + /* struct nixx_af_tl2x_pointers_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_POINTERS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_POINTERS(u64 a) +{ + return 0xe60 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_red + * + * INTERNAL: NIX Transmit Level 2 Red State Debug Register This register + * has the same bit fields as NIX_AF_TL1()_RED. + */ +union nixx_af_tl2x_red { + u64 u; + struct nixx_af_tl2x_red_s { + u64 tail : 8; + u64 reserved_8_9 : 2; + u64 head : 8; + u64 reserved_18_63 : 46; + } s; + /* struct nixx_af_tl2x_red_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_RED(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_RED(u64 a) +{ + return 0xeb0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_sched_state + * + * NIX AF Transmit Level 2 Scheduling Control State Registers + */ +union nixx_af_tl2x_sched_state { + u64 u; + struct nixx_af_tl2x_sched_state_s { + u64 rr_count : 25; + u64 reserved_25_63 : 39; + } s; + /* struct nixx_af_tl2x_sched_state_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_SCHED_STATE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_SCHED_STATE(u64 a) +{ + return 0xe40 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_schedule + * + * NIX AF Transmit Level 2 Scheduling Control Registers + */ +union nixx_af_tl2x_schedule { + u64 u; + struct nixx_af_tl2x_schedule_s { + u64 rr_quantum : 24; + u64 prio : 4; + u64 reserved_28_63 : 36; + } s; + /* struct nixx_af_tl2x_schedule_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_SCHEDULE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_SCHEDULE(u64 a) +{ + return 0xe00 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_shape + * + * NIX AF Transmit Level 2 Shaping Control Registers + */ +union nixx_af_tl2x_shape { + u64 u; + struct nixx_af_tl2x_shape_s { + u64 adjust : 9; + u64 red_algo : 2; + u64 red_disable : 1; + u64 yellow_disable : 1; + u64 reserved_13_23 : 11; + u64 length_disable : 1; + u64 schedule_list : 2; + u64 reserved_27_63 : 37; + } s; + /* struct nixx_af_tl2x_shape_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_SHAPE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_SHAPE(u64 a) +{ + return 0xe10 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_shape_state + * + * NIX AF Transmit Level 2 Shape State Registers This register must not + * be written during normal operation. + */ +union nixx_af_tl2x_shape_state { + u64 u; + struct nixx_af_tl2x_shape_state_s { + u64 cir_accum : 26; + u64 pir_accum : 26; + u64 color : 2; + u64 reserved_54_63 : 10; + } s; + /* struct nixx_af_tl2x_shape_state_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_SHAPE_STATE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_SHAPE_STATE(u64 a) +{ + return 0xe50 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_sw_xoff + * + * NIX AF Transmit Level 2 Software Controlled XOFF Registers This + * register has the same bit fields as NIX_AF_TL1()_SW_XOFF. + */ +union nixx_af_tl2x_sw_xoff { + u64 u; + struct nixx_af_tl2x_sw_xoff_s { + u64 xoff : 1; + u64 drain : 1; + u64 reserved_2 : 1; + u64 drain_irq : 1; + u64 reserved_4_63 : 60; + } s; + /* struct nixx_af_tl2x_sw_xoff_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_SW_XOFF(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_SW_XOFF(u64 a) +{ + return 0xe70 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_topology + * + * NIX AF Transmit Level 2 Topology Registers + */ +union nixx_af_tl2x_topology { + u64 u; + struct nixx_af_tl2x_topology_s { + u64 reserved_0 : 1; + u64 rr_prio : 4; + u64 reserved_5_31 : 27; + u64 prio_anchor : 8; + u64 reserved_40_63 : 24; + } s; + /* struct nixx_af_tl2x_topology_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_TOPOLOGY(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_TOPOLOGY(u64 a) +{ + return 0xe80 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2#_yellow + * + * INTERNAL: NIX Transmit Level 2 Yellow State Debug Register This + * register has the same bit fields as NIX_AF_TL1()_YELLOW. + */ +union nixx_af_tl2x_yellow { + u64 u; + struct nixx_af_tl2x_yellow_s { + u64 tail : 8; + u64 reserved_8_9 : 2; + u64 head : 8; + u64 reserved_18_63 : 46; + } s; + /* struct nixx_af_tl2x_yellow_s cn; */ +}; + +static inline u64 NIXX_AF_TL2X_YELLOW(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2X_YELLOW(u64 a) +{ + return 0xea0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl2_const + * + * NIX AF Transmit Level 2 Constants Register This register contains + * constants for software discovery. + */ +union nixx_af_tl2_const { + u64 u; + struct nixx_af_tl2_const_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct nixx_af_tl2_const_s cn; */ +}; + +static inline u64 NIXX_AF_TL2_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL2_CONST(void) +{ + return 0x78; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_cir + * + * NIX AF Transmit Level 3 Committed Information Rate Registers This + * register has the same bit fields as NIX_AF_TL1()_CIR. + */ +union nixx_af_tl3x_cir { + u64 u; + struct nixx_af_tl3x_cir_s { + u64 enable : 1; + u64 rate_mantissa : 8; + u64 rate_exponent : 4; + u64 rate_divider_exponent : 4; + u64 reserved_17_28 : 12; + u64 burst_mantissa : 8; + u64 burst_exponent : 4; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl3x_cir_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_CIR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_CIR(u64 a) +{ + return 0x1020 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_green + * + * INTERNAL: NIX Transmit Level 3 Green State Debug Register + */ +union nixx_af_tl3x_green { + u64 u; + struct nixx_af_tl3x_green_s { + u64 tail : 9; + u64 reserved_9 : 1; + u64 head : 9; + u64 reserved_19 : 1; + u64 active_vec : 20; + u64 rr_active : 1; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl3x_green_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_GREEN(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_GREEN(u64 a) +{ + return 0x1090 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_md_debug0 + * + * NIX AF Transmit Level 3 Meta Descriptor Debug 0 Registers See + * NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl3x_md_debug0 { + u64 u; + struct nixx_af_tl3x_md_debug0_s { + u64 pmd0_length : 16; + u64 pmd1_length : 16; + u64 pmd0_vld : 1; + u64 pmd1_vld : 1; + u64 reserved_34_45 : 12; + u64 drain_pri : 1; + u64 drain : 1; + u64 c_con : 1; + u64 p_con : 1; + u64 reserved_50_51 : 2; + u64 child : 10; + u64 reserved_62 : 1; + u64 pmd_count : 1; + } s; + /* struct nixx_af_tl3x_md_debug0_s cn96xxp1; */ + struct nixx_af_tl3x_md_debug0_cn96xxp3 { + u64 pmd0_length : 16; + u64 reserved_16_31 : 16; + u64 pmd0_vld : 1; + u64 reserved_33 : 1; + u64 reserved_34_45 : 12; + u64 reserved_46 : 1; + u64 reserved_47 : 1; + u64 c_con : 1; + u64 p_con : 1; + u64 reserved_50_51 : 2; + u64 child : 10; + u64 reserved_62 : 1; + u64 reserved_63 : 1; + } cn96xxp3; + /* struct nixx_af_tl3x_md_debug0_s cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL3X_MD_DEBUG0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_MD_DEBUG0(u64 a) +{ + return 0x10c0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_md_debug1 + * + * NIX AF Transmit Level 3 Meta Descriptor Debug 1 Registers Packet meta + * descriptor 0 debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl3x_md_debug1 { + u64 u; + struct nixx_af_tl3x_md_debug1_s { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 reserved_23 : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + struct nixx_af_tl3x_md_debug1_cn96xxp1 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 drain : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp1; + struct nixx_af_tl3x_md_debug1_cn96xxp3 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 reserved_19_22 : 4; + u64 flush : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp3; + /* struct nixx_af_tl3x_md_debug1_cn96xxp1 cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL3X_MD_DEBUG1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_MD_DEBUG1(u64 a) +{ + return 0x10c8 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_md_debug2 + * + * NIX AF Transmit Level 3 Meta Descriptor Debug 2 Registers Packet meta + * descriptor 1 debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl3x_md_debug2 { + u64 u; + struct nixx_af_tl3x_md_debug2_s { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 reserved_23 : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + struct nixx_af_tl3x_md_debug2_cn96xxp1 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 drain : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp1; + struct nixx_af_tl3x_md_debug2_cn96xxp3 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 reserved_19_22 : 4; + u64 flush : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp3; + /* struct nixx_af_tl3x_md_debug2_cn96xxp1 cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL3X_MD_DEBUG2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_MD_DEBUG2(u64 a) +{ + return 0x10d0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_md_debug3 + * + * NIX AF Transmit Level 3 Meta Descriptor Debug 3 Registers Flush meta + * descriptor debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl3x_md_debug3 { + u64 u; + struct nixx_af_tl3x_md_debug3_s { + u64 reserved_0_36 : 37; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + /* struct nixx_af_tl3x_md_debug3_s cn96xxp1; */ + struct nixx_af_tl3x_md_debug3_cn96xxp3 { + u64 reserved_0_36 : 37; + u64 reserved_37_38 : 2; + u64 reserved_39_51 : 13; + u64 reserved_52_61 : 10; + u64 reserved_62 : 1; + u64 reserved_63 : 1; + } cn96xxp3; + /* struct nixx_af_tl3x_md_debug3_s cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL3X_MD_DEBUG3(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_MD_DEBUG3(u64 a) +{ + return 0x10d8 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_parent + * + * NIX AF Transmit Level 3 Parent Registers + */ +union nixx_af_tl3x_parent { + u64 u; + struct nixx_af_tl3x_parent_s { + u64 reserved_0_15 : 16; + u64 parent : 8; + u64 reserved_24_63 : 40; + } s; + /* struct nixx_af_tl3x_parent_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_PARENT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_PARENT(u64 a) +{ + return 0x1088 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_pir + * + * NIX AF Transmit Level 3 Peak Information Rate Registers This register + * has the same bit fields as NIX_AF_TL1()_CIR. + */ +union nixx_af_tl3x_pir { + u64 u; + struct nixx_af_tl3x_pir_s { + u64 enable : 1; + u64 rate_mantissa : 8; + u64 rate_exponent : 4; + u64 rate_divider_exponent : 4; + u64 reserved_17_28 : 12; + u64 burst_mantissa : 8; + u64 burst_exponent : 4; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl3x_pir_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_PIR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_PIR(u64 a) +{ + return 0x1030 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_pointers + * + * INTERNAL: NIX Transmit Level 3 Linked List Pointers Debug Register + * This register has the same bit fields as NIX_AF_TL2()_POINTERS. + */ +union nixx_af_tl3x_pointers { + u64 u; + struct nixx_af_tl3x_pointers_s { + u64 next : 8; + u64 reserved_8_15 : 8; + u64 prev : 8; + u64 reserved_24_63 : 40; + } s; + /* struct nixx_af_tl3x_pointers_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_POINTERS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_POINTERS(u64 a) +{ + return 0x1060 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_red + * + * INTERNAL: NIX Transmit Level 3 Red State Debug Register This register + * has the same bit fields as NIX_AF_TL3()_YELLOW. + */ +union nixx_af_tl3x_red { + u64 u; + struct nixx_af_tl3x_red_s { + u64 tail : 9; + u64 reserved_9 : 1; + u64 head : 9; + u64 reserved_19_63 : 45; + } s; + /* struct nixx_af_tl3x_red_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_RED(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_RED(u64 a) +{ + return 0x10b0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_sched_state + * + * NIX AF Transmit Level 3 Scheduling Control State Registers This + * register has the same bit fields as NIX_AF_TL2()_SCHED_STATE. + */ +union nixx_af_tl3x_sched_state { + u64 u; + struct nixx_af_tl3x_sched_state_s { + u64 rr_count : 25; + u64 reserved_25_63 : 39; + } s; + /* struct nixx_af_tl3x_sched_state_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_SCHED_STATE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_SCHED_STATE(u64 a) +{ + return 0x1040 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_schedule + * + * NIX AF Transmit Level 3 Scheduling Control Registers This register has + * the same bit fields as NIX_AF_TL2()_SCHEDULE. + */ +union nixx_af_tl3x_schedule { + u64 u; + struct nixx_af_tl3x_schedule_s { + u64 rr_quantum : 24; + u64 prio : 4; + u64 reserved_28_63 : 36; + } s; + /* struct nixx_af_tl3x_schedule_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_SCHEDULE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_SCHEDULE(u64 a) +{ + return 0x1000 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_shape + * + * NIX AF Transmit Level 3 Shaping Control Registers + */ +union nixx_af_tl3x_shape { + u64 u; + struct nixx_af_tl3x_shape_s { + u64 adjust : 9; + u64 red_algo : 2; + u64 red_disable : 1; + u64 yellow_disable : 1; + u64 reserved_13_23 : 11; + u64 length_disable : 1; + u64 schedule_list : 2; + u64 reserved_27_63 : 37; + } s; + /* struct nixx_af_tl3x_shape_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_SHAPE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_SHAPE(u64 a) +{ + return 0x1010 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_shape_state + * + * NIX AF Transmit Level 3 Shaping State Registers This register has the + * same bit fields as NIX_AF_TL2()_SHAPE_STATE. This register must not be + * written during normal operation. + */ +union nixx_af_tl3x_shape_state { + u64 u; + struct nixx_af_tl3x_shape_state_s { + u64 cir_accum : 26; + u64 pir_accum : 26; + u64 color : 2; + u64 reserved_54_63 : 10; + } s; + /* struct nixx_af_tl3x_shape_state_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_SHAPE_STATE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_SHAPE_STATE(u64 a) +{ + return 0x1050 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_sw_xoff + * + * NIX AF Transmit Level 3 Software Controlled XOFF Registers This + * register has the same bit fields as NIX_AF_TL1()_SW_XOFF + */ +union nixx_af_tl3x_sw_xoff { + u64 u; + struct nixx_af_tl3x_sw_xoff_s { + u64 xoff : 1; + u64 drain : 1; + u64 reserved_2 : 1; + u64 drain_irq : 1; + u64 reserved_4_63 : 60; + } s; + /* struct nixx_af_tl3x_sw_xoff_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_SW_XOFF(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_SW_XOFF(u64 a) +{ + return 0x1070 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_topology + * + * NIX AF Transmit Level 3 Topology Registers + */ +union nixx_af_tl3x_topology { + u64 u; + struct nixx_af_tl3x_topology_s { + u64 reserved_0 : 1; + u64 rr_prio : 4; + u64 reserved_5_31 : 27; + u64 prio_anchor : 9; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl3x_topology_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_TOPOLOGY(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_TOPOLOGY(u64 a) +{ + return 0x1080 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3#_yellow + * + * INTERNAL: NIX Transmit Level 3 Yellow State Debug Register + */ +union nixx_af_tl3x_yellow { + u64 u; + struct nixx_af_tl3x_yellow_s { + u64 tail : 9; + u64 reserved_9 : 1; + u64 head : 9; + u64 reserved_19_63 : 45; + } s; + /* struct nixx_af_tl3x_yellow_s cn; */ +}; + +static inline u64 NIXX_AF_TL3X_YELLOW(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3X_YELLOW(u64 a) +{ + return 0x10a0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3_const + * + * NIX AF Transmit Level 3 Constants Register This register contains + * constants for software discovery. + */ +union nixx_af_tl3_const { + u64 u; + struct nixx_af_tl3_const_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct nixx_af_tl3_const_s cn; */ +}; + +static inline u64 NIXX_AF_TL3_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3_CONST(void) +{ + return 0x80; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3_tl2#_bp_status + * + * NIX AF Transmit Level 3/2 Backpressure Status Registers + */ +union nixx_af_tl3_tl2x_bp_status { + u64 u; + struct nixx_af_tl3_tl2x_bp_status_s { + u64 hw_xoff : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_tl3_tl2x_bp_status_s cn; */ +}; + +static inline u64 NIXX_AF_TL3_TL2X_BP_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3_TL2X_BP_STATUS(u64 a) +{ + return 0x1610 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3_tl2#_cfg + * + * NIX AF Transmit Level 3/2 Configuration Registers + */ +union nixx_af_tl3_tl2x_cfg { + u64 u; + struct nixx_af_tl3_tl2x_cfg_s { + u64 express : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_tl3_tl2x_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_TL3_TL2X_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3_TL2X_CFG(u64 a) +{ + return 0x1600 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl3_tl2#_link#_cfg + * + * NIX AF Transmit Level 3/2 Link Configuration Registers These registers + * specify the links and associated channels that a given TL3 or TL2 + * queue (depending on NIX_AF_PSE_CHANNEL_LEVEL[BP_LEVEL]) can transmit + * on. Each TL3/TL2 queue can be enabled to transmit on and be + * backpressured by one or more links and associated channels. The last + * index (LINK) is enumerated by NIX_LINK_E. + */ +union nixx_af_tl3_tl2x_linkx_cfg { + u64 u; + struct nixx_af_tl3_tl2x_linkx_cfg_s { + u64 relchan : 8; + u64 reserved_8_11 : 4; + u64 ena : 1; + u64 bp_ena : 1; + u64 reserved_14_63 : 50; + } s; + /* struct nixx_af_tl3_tl2x_linkx_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_TL3_TL2X_LINKX_CFG(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL3_TL2X_LINKX_CFG(u64 a, u64 b) +{ + return 0x1700 + 0x10000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_bp_status + * + * NIX AF Transmit Level 4 Backpressure Status Registers + */ +union nixx_af_tl4x_bp_status { + u64 u; + struct nixx_af_tl4x_bp_status_s { + u64 hw_xoff : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_tl4x_bp_status_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_BP_STATUS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_BP_STATUS(u64 a) +{ + return 0xb00 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_cir + * + * NIX AF Transmit Level 4 Committed Information Rate Registers This + * register has the same bit fields as NIX_AF_TL1()_CIR. + */ +union nixx_af_tl4x_cir { + u64 u; + struct nixx_af_tl4x_cir_s { + u64 enable : 1; + u64 rate_mantissa : 8; + u64 rate_exponent : 4; + u64 rate_divider_exponent : 4; + u64 reserved_17_28 : 12; + u64 burst_mantissa : 8; + u64 burst_exponent : 4; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl4x_cir_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_CIR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_CIR(u64 a) +{ + return 0x1220 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_green + * + * INTERNAL: NIX Transmit Level 4 Green State Debug Register This + * register has the same bit fields as NIX_AF_TL3()_GREEN. + */ +union nixx_af_tl4x_green { + u64 u; + struct nixx_af_tl4x_green_s { + u64 tail : 9; + u64 reserved_9 : 1; + u64 head : 9; + u64 reserved_19 : 1; + u64 active_vec : 20; + u64 rr_active : 1; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl4x_green_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_GREEN(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_GREEN(u64 a) +{ + return 0x1290 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_md_debug0 + * + * NIX AF Transmit Level 4 Meta Descriptor Debug 0 Registers See + * NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl4x_md_debug0 { + u64 u; + struct nixx_af_tl4x_md_debug0_s { + u64 pmd0_length : 16; + u64 pmd1_length : 16; + u64 pmd0_vld : 1; + u64 pmd1_vld : 1; + u64 reserved_34_45 : 12; + u64 drain_pri : 1; + u64 drain : 1; + u64 c_con : 1; + u64 p_con : 1; + u64 reserved_50_51 : 2; + u64 child : 10; + u64 reserved_62 : 1; + u64 pmd_count : 1; + } s; + /* struct nixx_af_tl4x_md_debug0_s cn96xxp1; */ + struct nixx_af_tl4x_md_debug0_cn96xxp3 { + u64 pmd0_length : 16; + u64 reserved_16_31 : 16; + u64 pmd0_vld : 1; + u64 reserved_33 : 1; + u64 reserved_34_45 : 12; + u64 reserved_46 : 1; + u64 reserved_47 : 1; + u64 c_con : 1; + u64 p_con : 1; + u64 reserved_50_51 : 2; + u64 child : 10; + u64 reserved_62 : 1; + u64 reserved_63 : 1; + } cn96xxp3; + /* struct nixx_af_tl4x_md_debug0_s cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL4X_MD_DEBUG0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_MD_DEBUG0(u64 a) +{ + return 0x12c0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_md_debug1 + * + * NIX AF Transmit Level 4 Meta Descriptor Debug 1 Registers Packet meta + * descriptor 0 debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl4x_md_debug1 { + u64 u; + struct nixx_af_tl4x_md_debug1_s { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 reserved_23 : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + struct nixx_af_tl4x_md_debug1_cn96xxp1 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 drain : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp1; + struct nixx_af_tl4x_md_debug1_cn96xxp3 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 reserved_19_22 : 4; + u64 flush : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp3; + /* struct nixx_af_tl4x_md_debug1_cn96xxp1 cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL4X_MD_DEBUG1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_MD_DEBUG1(u64 a) +{ + return 0x12c8 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_md_debug2 + * + * NIX AF Transmit Level 4 Meta Descriptor Debug 2 Registers Packet meta + * descriptor 1 debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl4x_md_debug2 { + u64 u; + struct nixx_af_tl4x_md_debug2_s { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 reserved_23 : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + struct nixx_af_tl4x_md_debug2_cn96xxp1 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 uid : 4; + u64 drain : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp1; + struct nixx_af_tl4x_md_debug2_cn96xxp3 { + u64 reserved_0_5 : 6; + u64 red_algo_override : 2; + u64 cir_dis : 1; + u64 pir_dis : 1; + u64 adjust : 9; + u64 reserved_19_22 : 4; + u64 flush : 1; + u64 bubble : 1; + u64 color : 2; + u64 pse_pkt_id : 9; + u64 reserved_36 : 1; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } cn96xxp3; + /* struct nixx_af_tl4x_md_debug2_cn96xxp1 cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL4X_MD_DEBUG2(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_MD_DEBUG2(u64 a) +{ + return 0x12d0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_md_debug3 + * + * NIX AF Transmit Level 4 Meta Descriptor Debug 3 Registers Flush meta + * descriptor debug. See NIX_AF_TL1()_MD_DEBUG0. + */ +union nixx_af_tl4x_md_debug3 { + u64 u; + struct nixx_af_tl4x_md_debug3_s { + u64 reserved_0_36 : 37; + u64 tx_pkt_p2x : 2; + u64 sqm_pkt_id : 13; + u64 mdq_idx : 10; + u64 reserved_62 : 1; + u64 vld : 1; + } s; + /* struct nixx_af_tl4x_md_debug3_s cn96xxp1; */ + struct nixx_af_tl4x_md_debug3_cn96xxp3 { + u64 reserved_0_36 : 37; + u64 reserved_37_38 : 2; + u64 reserved_39_51 : 13; + u64 reserved_52_61 : 10; + u64 reserved_62 : 1; + u64 reserved_63 : 1; + } cn96xxp3; + /* struct nixx_af_tl4x_md_debug3_s cnf95xx; */ +}; + +static inline u64 NIXX_AF_TL4X_MD_DEBUG3(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_MD_DEBUG3(u64 a) +{ + return 0x12d8 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_parent + * + * NIX AF Transmit Level 4 Parent Registers + */ +union nixx_af_tl4x_parent { + u64 u; + struct nixx_af_tl4x_parent_s { + u64 reserved_0_15 : 16; + u64 parent : 8; + u64 reserved_24_63 : 40; + } s; + /* struct nixx_af_tl4x_parent_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_PARENT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_PARENT(u64 a) +{ + return 0x1288 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_pir + * + * NIX AF Transmit Level 4 Peak Information Rate Registers This register + * has the same bit fields as NIX_AF_TL1()_CIR. + */ +union nixx_af_tl4x_pir { + u64 u; + struct nixx_af_tl4x_pir_s { + u64 enable : 1; + u64 rate_mantissa : 8; + u64 rate_exponent : 4; + u64 rate_divider_exponent : 4; + u64 reserved_17_28 : 12; + u64 burst_mantissa : 8; + u64 burst_exponent : 4; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl4x_pir_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_PIR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_PIR(u64 a) +{ + return 0x1230 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_pointers + * + * INTERNAL: NIX Transmit Level 4 Linked List Pointers Debug Register + * This register has the same bit fields as NIX_AF_TL2()_POINTERS. + */ +union nixx_af_tl4x_pointers { + u64 u; + struct nixx_af_tl4x_pointers_s { + u64 next : 9; + u64 reserved_9_15 : 7; + u64 prev : 9; + u64 reserved_25_63 : 39; + } s; + /* struct nixx_af_tl4x_pointers_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_POINTERS(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_POINTERS(u64 a) +{ + return 0x1260 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_red + * + * INTERNAL: NIX Transmit Level 4 Red State Debug Register This register + * has the same bit fields as NIX_AF_TL3()_YELLOW. + */ +union nixx_af_tl4x_red { + u64 u; + struct nixx_af_tl4x_red_s { + u64 tail : 9; + u64 reserved_9 : 1; + u64 head : 9; + u64 reserved_19_63 : 45; + } s; + /* struct nixx_af_tl4x_red_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_RED(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_RED(u64 a) +{ + return 0x12b0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_sched_state + * + * NIX AF Transmit Level 4 Scheduling Control State Registers This + * register has the same bit fields as NIX_AF_TL2()_SCHED_STATE. + */ +union nixx_af_tl4x_sched_state { + u64 u; + struct nixx_af_tl4x_sched_state_s { + u64 rr_count : 25; + u64 reserved_25_63 : 39; + } s; + /* struct nixx_af_tl4x_sched_state_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_SCHED_STATE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_SCHED_STATE(u64 a) +{ + return 0x1240 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_schedule + * + * NIX AF Transmit Level 4 Scheduling Control Registers This register has + * the same bit fields as NIX_AF_TL2()_SCHEDULE. + */ +union nixx_af_tl4x_schedule { + u64 u; + struct nixx_af_tl4x_schedule_s { + u64 rr_quantum : 24; + u64 prio : 4; + u64 reserved_28_63 : 36; + } s; + /* struct nixx_af_tl4x_schedule_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_SCHEDULE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_SCHEDULE(u64 a) +{ + return 0x1200 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_sdp_link_cfg + * + * NIX AF Transmit Level 4 Link Configuration Registers These registers + * specify which TL4 queues transmit to and are optionally backpressured + * by SDP. + */ +union nixx_af_tl4x_sdp_link_cfg { + u64 u; + struct nixx_af_tl4x_sdp_link_cfg_s { + u64 relchan : 8; + u64 reserved_8_11 : 4; + u64 ena : 1; + u64 bp_ena : 1; + u64 reserved_14_63 : 50; + } s; + /* struct nixx_af_tl4x_sdp_link_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_SDP_LINK_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_SDP_LINK_CFG(u64 a) +{ + return 0xb10 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_shape + * + * NIX AF Transmit Level 4 Shaping Control Registers This register has + * the same bit fields as NIX_AF_TL2()_SHAPE. + */ +union nixx_af_tl4x_shape { + u64 u; + struct nixx_af_tl4x_shape_s { + u64 adjust : 9; + u64 red_algo : 2; + u64 red_disable : 1; + u64 yellow_disable : 1; + u64 reserved_13_23 : 11; + u64 length_disable : 1; + u64 schedule_list : 2; + u64 reserved_27_63 : 37; + } s; + /* struct nixx_af_tl4x_shape_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_SHAPE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_SHAPE(u64 a) +{ + return 0x1210 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_shape_state + * + * NIX AF Transmit Level 4 Shaping State Registers This register has the + * same bit fields as NIX_AF_TL2()_SHAPE_STATE. This register must not be + * written during normal operation. + */ +union nixx_af_tl4x_shape_state { + u64 u; + struct nixx_af_tl4x_shape_state_s { + u64 cir_accum : 26; + u64 pir_accum : 26; + u64 color : 2; + u64 reserved_54_63 : 10; + } s; + /* struct nixx_af_tl4x_shape_state_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_SHAPE_STATE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_SHAPE_STATE(u64 a) +{ + return 0x1250 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_sw_xoff + * + * NIX AF Transmit Level 4 Software Controlled XOFF Registers This + * register has the same bit fields as NIX_AF_TL1()_SW_XOFF + */ +union nixx_af_tl4x_sw_xoff { + u64 u; + struct nixx_af_tl4x_sw_xoff_s { + u64 xoff : 1; + u64 drain : 1; + u64 reserved_2 : 1; + u64 drain_irq : 1; + u64 reserved_4_63 : 60; + } s; + /* struct nixx_af_tl4x_sw_xoff_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_SW_XOFF(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_SW_XOFF(u64 a) +{ + return 0x1270 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_topology + * + * NIX AF Transmit Level 4 Topology Registers + */ +union nixx_af_tl4x_topology { + u64 u; + struct nixx_af_tl4x_topology_s { + u64 reserved_0 : 1; + u64 rr_prio : 4; + u64 reserved_5_31 : 27; + u64 prio_anchor : 9; + u64 reserved_41_63 : 23; + } s; + /* struct nixx_af_tl4x_topology_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_TOPOLOGY(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_TOPOLOGY(u64 a) +{ + return 0x1280 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4#_yellow + * + * INTERNAL: NIX Transmit Level 4 Yellow State Debug Register This + * register has the same bit fields as NIX_AF_TL3()_YELLOW + */ +union nixx_af_tl4x_yellow { + u64 u; + struct nixx_af_tl4x_yellow_s { + u64 tail : 9; + u64 reserved_9 : 1; + u64 head : 9; + u64 reserved_19_63 : 45; + } s; + /* struct nixx_af_tl4x_yellow_s cn; */ +}; + +static inline u64 NIXX_AF_TL4X_YELLOW(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4X_YELLOW(u64 a) +{ + return 0x12a0 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tl4_const + * + * NIX AF Transmit Level 4 Constants Register This register contains + * constants for software discovery. + */ +union nixx_af_tl4_const { + u64 u; + struct nixx_af_tl4_const_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct nixx_af_tl4_const_s cn; */ +}; + +static inline u64 NIXX_AF_TL4_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TL4_CONST(void) +{ + return 0x88; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_link#_expr_credit + * + * INTERNAL: NIX AF Transmit Link Express Credit Registers Internal: + * 802.3br frame preemption/express path is defeatured. Old definition: + * These registers track credits per link for express packets that may + * potentially preempt normal packets. Link index enumerated by + * NIX_LINK_E. + */ +union nixx_af_tx_linkx_expr_credit { + u64 u; + struct nixx_af_tx_linkx_expr_credit_s { + u64 reserved_0 : 1; + u64 cc_enable : 1; + u64 cc_packet_cnt : 10; + u64 cc_unit_cnt : 20; + u64 reserved_32_63 : 32; + } s; + /* struct nixx_af_tx_linkx_expr_credit_s cn; */ +}; + +static inline u64 NIXX_AF_TX_LINKX_EXPR_CREDIT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_LINKX_EXPR_CREDIT(u64 a) +{ + return 0xa10 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_link#_hw_xoff + * + * NIX AF Transmit Link Hardware Controlled XOFF Registers Link index + * enumerated by NIX_LINK_E. + */ +union nixx_af_tx_linkx_hw_xoff { + u64 u; + struct nixx_af_tx_linkx_hw_xoff_s { + u64 chan_xoff : 64; + } s; + /* struct nixx_af_tx_linkx_hw_xoff_s cn; */ +}; + +static inline u64 NIXX_AF_TX_LINKX_HW_XOFF(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_LINKX_HW_XOFF(u64 a) +{ + return 0xa30 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_link#_norm_credit + * + * NIX AF Transmit Link Normal Credit Registers These registers track + * credits per link for normal packets sent to CGX and LBK. Link index + * enumerated by NIX_LINK_E. + */ +union nixx_af_tx_linkx_norm_credit { + u64 u; + struct nixx_af_tx_linkx_norm_credit_s { + u64 reserved_0 : 1; + u64 cc_enable : 1; + u64 cc_packet_cnt : 10; + u64 cc_unit_cnt : 20; + u64 reserved_32_63 : 32; + } s; + /* struct nixx_af_tx_linkx_norm_credit_s cn; */ +}; + +static inline u64 NIXX_AF_TX_LINKX_NORM_CREDIT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_LINKX_NORM_CREDIT(u64 a) +{ + return 0xa00 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_link#_sw_xoff + * + * INTERNAL: NIX AF Transmit Link Software Controlled XOFF Registers + * Link index enumerated by NIX_LINK_E. Internal: Defeatured registers. + * Software should instead use NIX_AF_TL3()_SW_XOFF registers when + * NIX_AF_PSE_CHANNEL_LEVEL[BP_LEVEL] is set and NIX_AF_TL2()_SW_XOFF + * registers when NIX_AF_PSE_CHANNEL_LEVEL[BP_LEVEL] is clear. + */ +union nixx_af_tx_linkx_sw_xoff { + u64 u; + struct nixx_af_tx_linkx_sw_xoff_s { + u64 chan_xoff : 64; + } s; + /* struct nixx_af_tx_linkx_sw_xoff_s cn; */ +}; + +static inline u64 NIXX_AF_TX_LINKX_SW_XOFF(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_LINKX_SW_XOFF(u64 a) +{ + return 0xa20 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_mcast# + * + * NIX AF Transmit Multicast Registers These registers access transmit + * multicast table entries used to specify multicast replication lists. + * Each list consists of linked entries with [EOL] = 1 in the last entry. + * A transmit packet is multicast when the action returned by NPC has + * NIX_TX_ACTION_S[OP] = NIX_TX_ACTIONOP_E::MCAST. NIX_TX_ACTION_S[INDEX] + * points to the start of the multicast replication list, and [EOL] = 1 + * indicates the end of list. + */ +union nixx_af_tx_mcastx { + u64 u; + struct nixx_af_tx_mcastx_s { + u64 channel : 12; + u64 eol : 1; + u64 reserved_13_15 : 3; + u64 next : 16; + u64 reserved_32_63 : 32; + } s; + /* struct nixx_af_tx_mcastx_s cn; */ +}; + +static inline u64 NIXX_AF_TX_MCASTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_MCASTX(u64 a) +{ + return 0x1900 + 0x8000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_npc_capture_config + * + * NIX AF Transmit NPC Response Capture Configuration Register Configures + * the NPC response capture logic for transmit packets. When enabled, + * allows NPC responses for selected packets to be captured in + * NIX_AF_TX_NPC_CAPTURE_INFO and NIX_AF_TX_NPC_CAPTURE_RESP(). + */ +union nixx_af_tx_npc_capture_config { + u64 u; + struct nixx_af_tx_npc_capture_config_s { + u64 en : 1; + u64 continuous : 1; + u64 lso_segnum_en : 1; + u64 sqe_id_en : 1; + u64 sq_id_en : 1; + u64 lf_id_en : 1; + u64 reserved_6_11 : 6; + u64 lso_segnum : 8; + u64 sqe_id : 16; + u64 sq_id : 20; + u64 lf_id : 8; + } s; + /* struct nixx_af_tx_npc_capture_config_s cn; */ +}; + +static inline u64 NIXX_AF_TX_NPC_CAPTURE_CONFIG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_NPC_CAPTURE_CONFIG(void) +{ + return 0x660; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_npc_capture_info + * + * NIX AF Transmit NPC Response Capture Information Register This + * register contains captured NPC response information for a transmit + * packet. See NIX_AF_TX_NPC_CAPTURE_CONFIG. + */ +union nixx_af_tx_npc_capture_info { + u64 u; + struct nixx_af_tx_npc_capture_info_s { + u64 vld : 1; + u64 reserved_1_11 : 11; + u64 lso_segnum : 8; + u64 sqe_id : 16; + u64 sq_id : 20; + u64 lf_id : 8; + } s; + /* struct nixx_af_tx_npc_capture_info_s cn; */ +}; + +static inline u64 NIXX_AF_TX_NPC_CAPTURE_INFO(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_NPC_CAPTURE_INFO(void) +{ + return 0x668; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_npc_capture_resp# + * + * NIX AF Transmit NPC Capture Response Registers These registers contain + * the captured NPC response for a transmit packet when + * NIX_AF_TX_NPC_CAPTURE_INFO[VLD] is set. See also + * NIX_AF_TX_NPC_CAPTURE_CONFIG. + */ +union nixx_af_tx_npc_capture_respx { + u64 u; + struct nixx_af_tx_npc_capture_respx_s { + u64 data : 64; + } s; + /* struct nixx_af_tx_npc_capture_respx_s cn; */ +}; + +static inline u64 NIXX_AF_TX_NPC_CAPTURE_RESPX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_NPC_CAPTURE_RESPX(u64 a) +{ + return 0x680 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_tstmp_cfg + * + * NIX AF Transmit Timestamp Configuration Register + */ +union nixx_af_tx_tstmp_cfg { + u64 u; + struct nixx_af_tx_tstmp_cfg_s { + u64 tstmp_wd_period : 4; + u64 reserved_4_7 : 4; + u64 express : 16; + u64 reserved_24_63 : 40; + } s; + /* struct nixx_af_tx_tstmp_cfg_s cn; */ +}; + +static inline u64 NIXX_AF_TX_TSTMP_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_TSTMP_CFG(void) +{ + return 0xc0; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_vtag_def#_ctl + * + * NIX AF Transmit Vtag Definition Control Registers The transmit Vtag + * definition table specifies Vtag layers (e.g. VLAN, E-TAG) to + * optionally insert or replace in the TX packet header. Indexed by + * NIX_TX_VTAG_ACTION_S[VTAG*_DEF]. + */ +union nixx_af_tx_vtag_defx_ctl { + u64 u; + struct nixx_af_tx_vtag_defx_ctl_s { + u64 size : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_af_tx_vtag_defx_ctl_s cn; */ +}; + +static inline u64 NIXX_AF_TX_VTAG_DEFX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_VTAG_DEFX_CTL(u64 a) +{ + return 0x1a00 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_af_tx_vtag_def#_data + * + * NIX AF Transmit Vtag Definition Data Registers See + * NIX_AF_TX_VTAG_DEF()_CTL. + */ +union nixx_af_tx_vtag_defx_data { + u64 u; + struct nixx_af_tx_vtag_defx_data_s { + u64 data : 64; + } s; + /* struct nixx_af_tx_vtag_defx_data_s cn; */ +}; + +static inline u64 NIXX_AF_TX_VTAG_DEFX_DATA(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_AF_TX_VTAG_DEFX_DATA(u64 a) +{ + return 0x1a10 + 0x10000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_cfg + * + * NIX LF Configuration Register + */ +union nixx_lf_cfg { + u64 u; + struct nixx_lf_cfg_s { + u64 tcp_timer_int_ena : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_lf_cfg_s cn; */ +}; + +static inline u64 NIXX_LF_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_CFG(void) +{ + return 0x100; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_cint#_cnt + * + * NIX LF Completion Interrupt Count Registers + */ +union nixx_lf_cintx_cnt { + u64 u; + struct nixx_lf_cintx_cnt_s { + u64 ecount : 32; + u64 qcount : 16; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_lf_cintx_cnt_s cn; */ +}; + +static inline u64 NIXX_LF_CINTX_CNT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_CINTX_CNT(u64 a) +{ + return 0xd00 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_cint#_ena_w1c + * + * NIX LF Completion Interrupt Enable Clear Registers This register + * clears interrupt enable bits. + */ +union nixx_lf_cintx_ena_w1c { + u64 u; + struct nixx_lf_cintx_ena_w1c_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_lf_cintx_ena_w1c_s cn; */ +}; + +static inline u64 NIXX_LF_CINTX_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_CINTX_ENA_W1C(u64 a) +{ + return 0xd50 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_cint#_ena_w1s + * + * NIX LF Completion Interrupt Enable Set Registers This register sets + * interrupt enable bits. + */ +union nixx_lf_cintx_ena_w1s { + u64 u; + struct nixx_lf_cintx_ena_w1s_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_lf_cintx_ena_w1s_s cn; */ +}; + +static inline u64 NIXX_LF_CINTX_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_CINTX_ENA_W1S(u64 a) +{ + return 0xd40 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_cint#_int + * + * NIX LF Completion Interrupt Registers + */ +union nixx_lf_cintx_int { + u64 u; + struct nixx_lf_cintx_int_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_lf_cintx_int_s cn; */ +}; + +static inline u64 NIXX_LF_CINTX_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_CINTX_INT(u64 a) +{ + return 0xd20 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_cint#_int_w1s + * + * NIX LF Completion Interrupt Set Registers This register sets interrupt + * bits. + */ +union nixx_lf_cintx_int_w1s { + u64 u; + struct nixx_lf_cintx_int_w1s_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_lf_cintx_int_w1s_s cn; */ +}; + +static inline u64 NIXX_LF_CINTX_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_CINTX_INT_W1S(u64 a) +{ + return 0xd30 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_cint#_wait + * + * NIX LF Completion Interrupt Count Registers + */ +union nixx_lf_cintx_wait { + u64 u; + struct nixx_lf_cintx_wait_s { + u64 ecount_wait : 32; + u64 qcount_wait : 16; + u64 time_wait : 8; + u64 reserved_56_63 : 8; + } s; + /* struct nixx_lf_cintx_wait_s cn; */ +}; + +static inline u64 NIXX_LF_CINTX_WAIT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_CINTX_WAIT(u64 a) +{ + return 0xd10 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_cq_op_door + * + * NIX LF CQ Doorbell Operation Register A write to this register + * dequeues CQEs from a CQ ring within the LF. A read is RAZ. RSL + * accesses to this register are RAZ/WI. + */ +union nixx_lf_cq_op_door { + u64 u; + struct nixx_lf_cq_op_door_s { + u64 count : 16; + u64 reserved_16_31 : 16; + u64 cq : 20; + u64 reserved_52_63 : 12; + } s; + /* struct nixx_lf_cq_op_door_s cn; */ +}; + +static inline u64 NIXX_LF_CQ_OP_DOOR(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_CQ_OP_DOOR(void) +{ + return 0xb30; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_cq_op_int + * + * NIX LF Completion Queue Interrupt Operation Register A 64-bit atomic + * load-and-add to this register reads CQ interrupts and interrupt + * enables. A write optionally sets or clears interrupts and interrupt + * enables. A read is RAZ. RSL accesses to this register are RAZ/WI. + */ +union nixx_lf_cq_op_int { + u64 u; + struct nixx_lf_cq_op_int_s { + u64 cq_err_int : 8; + u64 cq_err_int_ena : 8; + u64 reserved_16_41 : 26; + u64 op_err : 1; + u64 setop : 1; + u64 cq : 20; + } s; + /* struct nixx_lf_cq_op_int_s cn; */ +}; + +static inline u64 NIXX_LF_CQ_OP_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_CQ_OP_INT(void) +{ + return 0xb00; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_cq_op_status + * + * NIX LF Completion Queue Status Operation Register A 64-bit atomic + * load-and-add to this register reads NIX_CQ_CTX_S[HEAD,TAIL]. The + * atomic write data has format NIX_OP_Q_WDATA_S and selects the CQ + * within LF. All other accesses to this register (e.g. reads and + * writes) are RAZ/WI. RSL accesses to this register are RAZ/WI. + */ +union nixx_lf_cq_op_status { + u64 u; + struct nixx_lf_cq_op_status_s { + u64 tail : 20; + u64 head : 20; + u64 reserved_40_45 : 6; + u64 cq_err : 1; + u64 reserved_47_62 : 16; + u64 op_err : 1; + } s; + /* struct nixx_lf_cq_op_status_s cn; */ +}; + +static inline u64 NIXX_LF_CQ_OP_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_CQ_OP_STATUS(void) +{ + return 0xb40; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_err_int + * + * NIX LF Error Interrupt Register + */ +union nixx_lf_err_int { + u64 u; + struct nixx_lf_err_int_s { + u64 sqb_fault : 1; + u64 sq_ctx_fault : 1; + u64 rq_ctx_fault : 1; + u64 cq_ctx_fault : 1; + u64 reserved_4 : 1; + u64 rsse_fault : 1; + u64 ipsec_dyno_fault : 1; + u64 sq_disabled : 1; + u64 sq_oor : 1; + u64 send_jump_fault : 1; + u64 send_sg_fault : 1; + u64 rq_disabled : 1; + u64 rq_oor : 1; + u64 rx_wqe_fault : 1; + u64 rss_err : 1; + u64 reserved_15_19 : 5; + u64 dyno_err : 1; + u64 reserved_21_23 : 3; + u64 cq_disabled : 1; + u64 cq_oor : 1; + u64 reserved_26_27 : 2; + u64 qint_fault : 1; + u64 cint_fault : 1; + u64 reserved_30_63 : 34; + } s; + /* struct nixx_lf_err_int_s cn; */ +}; + +static inline u64 NIXX_LF_ERR_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_ERR_INT(void) +{ + return 0x220; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_err_int_ena_w1c + * + * NIX LF Error Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union nixx_lf_err_int_ena_w1c { + u64 u; + struct nixx_lf_err_int_ena_w1c_s { + u64 sqb_fault : 1; + u64 sq_ctx_fault : 1; + u64 rq_ctx_fault : 1; + u64 cq_ctx_fault : 1; + u64 reserved_4 : 1; + u64 rsse_fault : 1; + u64 ipsec_dyno_fault : 1; + u64 sq_disabled : 1; + u64 sq_oor : 1; + u64 send_jump_fault : 1; + u64 send_sg_fault : 1; + u64 rq_disabled : 1; + u64 rq_oor : 1; + u64 rx_wqe_fault : 1; + u64 rss_err : 1; + u64 reserved_15_19 : 5; + u64 dyno_err : 1; + u64 reserved_21_23 : 3; + u64 cq_disabled : 1; + u64 cq_oor : 1; + u64 reserved_26_27 : 2; + u64 qint_fault : 1; + u64 cint_fault : 1; + u64 reserved_30_63 : 34; + } s; + /* struct nixx_lf_err_int_ena_w1c_s cn; */ +}; + +static inline u64 NIXX_LF_ERR_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_ERR_INT_ENA_W1C(void) +{ + return 0x230; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_err_int_ena_w1s + * + * NIX LF Error Interrupt Enable Set Register This register sets + * interrupt enable bits. + */ +union nixx_lf_err_int_ena_w1s { + u64 u; + struct nixx_lf_err_int_ena_w1s_s { + u64 sqb_fault : 1; + u64 sq_ctx_fault : 1; + u64 rq_ctx_fault : 1; + u64 cq_ctx_fault : 1; + u64 reserved_4 : 1; + u64 rsse_fault : 1; + u64 ipsec_dyno_fault : 1; + u64 sq_disabled : 1; + u64 sq_oor : 1; + u64 send_jump_fault : 1; + u64 send_sg_fault : 1; + u64 rq_disabled : 1; + u64 rq_oor : 1; + u64 rx_wqe_fault : 1; + u64 rss_err : 1; + u64 reserved_15_19 : 5; + u64 dyno_err : 1; + u64 reserved_21_23 : 3; + u64 cq_disabled : 1; + u64 cq_oor : 1; + u64 reserved_26_27 : 2; + u64 qint_fault : 1; + u64 cint_fault : 1; + u64 reserved_30_63 : 34; + } s; + /* struct nixx_lf_err_int_ena_w1s_s cn; */ +}; + +static inline u64 NIXX_LF_ERR_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_ERR_INT_ENA_W1S(void) +{ + return 0x238; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_err_int_w1s + * + * NIX LF Error Interrupt Set Register This register sets interrupt bits. + */ +union nixx_lf_err_int_w1s { + u64 u; + struct nixx_lf_err_int_w1s_s { + u64 sqb_fault : 1; + u64 sq_ctx_fault : 1; + u64 rq_ctx_fault : 1; + u64 cq_ctx_fault : 1; + u64 reserved_4 : 1; + u64 rsse_fault : 1; + u64 ipsec_dyno_fault : 1; + u64 sq_disabled : 1; + u64 sq_oor : 1; + u64 send_jump_fault : 1; + u64 send_sg_fault : 1; + u64 rq_disabled : 1; + u64 rq_oor : 1; + u64 rx_wqe_fault : 1; + u64 rss_err : 1; + u64 reserved_15_19 : 5; + u64 dyno_err : 1; + u64 reserved_21_23 : 3; + u64 cq_disabled : 1; + u64 cq_oor : 1; + u64 reserved_26_27 : 2; + u64 qint_fault : 1; + u64 cint_fault : 1; + u64 reserved_30_63 : 34; + } s; + /* struct nixx_lf_err_int_w1s_s cn; */ +}; + +static inline u64 NIXX_LF_ERR_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_ERR_INT_W1S(void) +{ + return 0x228; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_gint + * + * NIX LF General Interrupt Register + */ +union nixx_lf_gint { + u64 u; + struct nixx_lf_gint_s { + u64 drop : 1; + u64 tcp_timer : 1; + u64 reserved_2_63 : 62; + } s; + /* struct nixx_lf_gint_s cn; */ +}; + +static inline u64 NIXX_LF_GINT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_GINT(void) +{ + return 0x200; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_gint_ena_w1c + * + * NIX LF General Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union nixx_lf_gint_ena_w1c { + u64 u; + struct nixx_lf_gint_ena_w1c_s { + u64 drop : 1; + u64 tcp_timer : 1; + u64 reserved_2_63 : 62; + } s; + /* struct nixx_lf_gint_ena_w1c_s cn; */ +}; + +static inline u64 NIXX_LF_GINT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_GINT_ENA_W1C(void) +{ + return 0x210; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_gint_ena_w1s + * + * NIX LF General Interrupt Enable Set Register This register sets + * interrupt enable bits. + */ +union nixx_lf_gint_ena_w1s { + u64 u; + struct nixx_lf_gint_ena_w1s_s { + u64 drop : 1; + u64 tcp_timer : 1; + u64 reserved_2_63 : 62; + } s; + /* struct nixx_lf_gint_ena_w1s_s cn; */ +}; + +static inline u64 NIXX_LF_GINT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_GINT_ENA_W1S(void) +{ + return 0x218; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_gint_w1s + * + * NIX LF General Interrupt Set Register This register sets interrupt + * bits. + */ +union nixx_lf_gint_w1s { + u64 u; + struct nixx_lf_gint_w1s_s { + u64 drop : 1; + u64 tcp_timer : 1; + u64 reserved_2_63 : 62; + } s; + /* struct nixx_lf_gint_w1s_s cn; */ +}; + +static inline u64 NIXX_LF_GINT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_GINT_W1S(void) +{ + return 0x208; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_mnq_err_dbg + * + * NIX LF Meta-descriptor Enqueue Error Debug Register This register + * captures debug info for an error detected during send meta-descriptor + * enqueue from an SQ to an SMQ. Hardware sets [VALID] when the debug + * info is captured, and subsequent errors are not captured until + * software clears [VALID] by writing a one to it. + */ +union nixx_lf_mnq_err_dbg { + u64 u; + struct nixx_lf_mnq_err_dbg_s { + u64 errcode : 8; + u64 sq : 20; + u64 sqe_id : 16; + u64 valid : 1; + u64 reserved_45_63 : 19; + } s; + /* struct nixx_lf_mnq_err_dbg_s cn; */ +}; + +static inline u64 NIXX_LF_MNQ_ERR_DBG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_MNQ_ERR_DBG(void) +{ + return 0x270; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_op_ipsec_dyno_cnt + * + * INTERNAL: NIX LF IPSEC Dynamic Ordering Counter Operation Register + * Internal: Not used; no IPSEC fast-path. All accesses are RAZ/WI. + */ +union nixx_lf_op_ipsec_dyno_cnt { + u64 u; + struct nixx_lf_op_ipsec_dyno_cnt_s { + u64 count : 32; + u64 reserved_32_46 : 15; + u64 storeop : 1; + u64 dyno_sel : 15; + u64 op_err : 1; + } s; + /* struct nixx_lf_op_ipsec_dyno_cnt_s cn; */ +}; + +static inline u64 NIXX_LF_OP_IPSEC_DYNO_CNT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_OP_IPSEC_DYNO_CNT(void) +{ + return 0x980; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_op_send# + * + * NIX LF Send Operation Registers An LMTST (or large store from CPT) to + * this address enqueues one or more SQEs to a send queue. + * NIX_SEND_HDR_S[SQ] in the first SQE selects the send queue.The maximum + * size of each SQE is specified by NIX_SQ_CTX_S[MAX_SQE_SIZE]. A read + * to this address is RAZ. An RSL access to this address will fault. + * The endianness of the instruction write data is controlled by + * NIX_AF_LF()_CFG[BE]. When a NIX_SEND_JUMP_S is not present in the + * SQE, the SQE consists of the entire send descriptor. When a + * NIX_SEND_JUMP_S is present in the SQE, the SQE must contain exactly + * the portion of the send descriptor up to and including the + * NIX_SEND_JUMP_S, and the remainder of the send descriptor must be at + * LF IOVA NIX_SEND_JUMP_S[ADDR] in LLC/DRAM. Software must ensure that + * all LLC/DRAM locations that will be referenced by NIX while processing + * this descriptor, including all packet data and post-jump + * subdescriptors contain the latest updates before issuing the LMTST. A + * DMB instruction may be required prior to the LMTST to ensure this. A + * DMB following the LMTST may be useful if SQ descriptor ordering + * matters and more than one CPU core is simultaneously enqueueing to the + * same SQ. + */ +union nixx_lf_op_sendx { + u64 u; + struct nixx_lf_op_sendx_s { + u64 data : 64; + } s; + /* struct nixx_lf_op_sendx_s cn; */ +}; + +static inline u64 NIXX_LF_OP_SENDX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_OP_SENDX(u64 a) +{ + return 0x800 + 8 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_qint#_cnt + * + * NIX LF Queue Interrupt Count Registers + */ +union nixx_lf_qintx_cnt { + u64 u; + struct nixx_lf_qintx_cnt_s { + u64 count : 22; + u64 reserved_22_63 : 42; + } s; + /* struct nixx_lf_qintx_cnt_s cn; */ +}; + +static inline u64 NIXX_LF_QINTX_CNT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_QINTX_CNT(u64 a) +{ + return 0xc00 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_qint#_ena_w1c + * + * NIX LF Queue Interrupt Enable Clear Registers This register clears + * interrupt enable bits. + */ +union nixx_lf_qintx_ena_w1c { + u64 u; + struct nixx_lf_qintx_ena_w1c_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_lf_qintx_ena_w1c_s cn; */ +}; + +static inline u64 NIXX_LF_QINTX_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_QINTX_ENA_W1C(u64 a) +{ + return 0xc30 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_qint#_ena_w1s + * + * NIX LF Queue Interrupt Enable Set Registers This register sets + * interrupt enable bits. + */ +union nixx_lf_qintx_ena_w1s { + u64 u; + struct nixx_lf_qintx_ena_w1s_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_lf_qintx_ena_w1s_s cn; */ +}; + +static inline u64 NIXX_LF_QINTX_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_QINTX_ENA_W1S(u64 a) +{ + return 0xc20 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_qint#_int + * + * NIX LF Queue Interrupt Registers + */ +union nixx_lf_qintx_int { + u64 u; + struct nixx_lf_qintx_int_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_lf_qintx_int_s cn; */ +}; + +static inline u64 NIXX_LF_QINTX_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_QINTX_INT(u64 a) +{ + return 0xc10 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_qint#_int_w1s + * + * INTERNAL: NIX LF Queue Interrupt Set Registers + */ +union nixx_lf_qintx_int_w1s { + u64 u; + struct nixx_lf_qintx_int_w1s_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct nixx_lf_qintx_int_w1s_s cn; */ +}; + +static inline u64 NIXX_LF_QINTX_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_QINTX_INT_W1S(u64 a) +{ + return 0xc18 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_ras + * + * NIX LF RAS Interrupt Register + */ +union nixx_lf_ras { + u64 u; + struct nixx_lf_ras_s { + u64 sqb_poison : 1; + u64 sq_ctx_poison : 1; + u64 rq_ctx_poison : 1; + u64 cq_ctx_poison : 1; + u64 reserved_4 : 1; + u64 rsse_poison : 1; + u64 ipsec_dyno_poison : 1; + u64 send_jump_poison : 1; + u64 send_sg_poison : 1; + u64 qint_poison : 1; + u64 cint_poison : 1; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_lf_ras_s cn; */ +}; + +static inline u64 NIXX_LF_RAS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RAS(void) +{ + return 0x240; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_ras_ena_w1c + * + * NIX LF RAS Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union nixx_lf_ras_ena_w1c { + u64 u; + struct nixx_lf_ras_ena_w1c_s { + u64 sqb_poison : 1; + u64 sq_ctx_poison : 1; + u64 rq_ctx_poison : 1; + u64 cq_ctx_poison : 1; + u64 reserved_4 : 1; + u64 rsse_poison : 1; + u64 ipsec_dyno_poison : 1; + u64 send_jump_poison : 1; + u64 send_sg_poison : 1; + u64 qint_poison : 1; + u64 cint_poison : 1; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_lf_ras_ena_w1c_s cn; */ +}; + +static inline u64 NIXX_LF_RAS_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RAS_ENA_W1C(void) +{ + return 0x250; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_ras_ena_w1s + * + * NIX LF RAS Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union nixx_lf_ras_ena_w1s { + u64 u; + struct nixx_lf_ras_ena_w1s_s { + u64 sqb_poison : 1; + u64 sq_ctx_poison : 1; + u64 rq_ctx_poison : 1; + u64 cq_ctx_poison : 1; + u64 reserved_4 : 1; + u64 rsse_poison : 1; + u64 ipsec_dyno_poison : 1; + u64 send_jump_poison : 1; + u64 send_sg_poison : 1; + u64 qint_poison : 1; + u64 cint_poison : 1; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_lf_ras_ena_w1s_s cn; */ +}; + +static inline u64 NIXX_LF_RAS_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RAS_ENA_W1S(void) +{ + return 0x258; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_ras_w1s + * + * NIX LF RAS Interrupt Set Register This register sets interrupt bits. + */ +union nixx_lf_ras_w1s { + u64 u; + struct nixx_lf_ras_w1s_s { + u64 sqb_poison : 1; + u64 sq_ctx_poison : 1; + u64 rq_ctx_poison : 1; + u64 cq_ctx_poison : 1; + u64 reserved_4 : 1; + u64 rsse_poison : 1; + u64 ipsec_dyno_poison : 1; + u64 send_jump_poison : 1; + u64 send_sg_poison : 1; + u64 qint_poison : 1; + u64 cint_poison : 1; + u64 reserved_11_63 : 53; + } s; + /* struct nixx_lf_ras_w1s_s cn; */ +}; + +static inline u64 NIXX_LF_RAS_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RAS_W1S(void) +{ + return 0x248; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_rq_op_drop_octs + * + * NIX LF Receive Queue Dropped Octets Operation Register A 64-bit atomic + * load-and-add to this register reads NIX_RQ_CTX_S[DROP_OCTS]. The + * atomic write data has format NIX_OP_Q_WDATA_S and selects the RQ + * within LF. All other accesses to this register (e.g. reads and + * writes) are RAZ/WI. RSL accesses to this register are RAZ/WI. + */ +union nixx_lf_rq_op_drop_octs { + u64 u; + struct nixx_lf_rq_op_drop_octs_s { + u64 cnt : 48; + u64 reserved_48_62 : 15; + u64 op_err : 1; + } s; + /* struct nixx_lf_rq_op_drop_octs_s cn; */ +}; + +static inline u64 NIXX_LF_RQ_OP_DROP_OCTS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RQ_OP_DROP_OCTS(void) +{ + return 0x930; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_rq_op_drop_pkts + * + * NIX LF Receive Queue Dropped Packets Operation Register A 64-bit + * atomic load-and-add to this register reads NIX_RQ_CTX_S[DROP_PKTS]. + * The atomic write data has format NIX_OP_Q_WDATA_S and selects the RQ + * within LF. All other accesses to this register (e.g. reads and + * writes) are RAZ/WI. RSL accesses to this register are RAZ/WI. + */ +union nixx_lf_rq_op_drop_pkts { + u64 u; + struct nixx_lf_rq_op_drop_pkts_s { + u64 cnt : 48; + u64 reserved_48_62 : 15; + u64 op_err : 1; + } s; + /* struct nixx_lf_rq_op_drop_pkts_s cn; */ +}; + +static inline u64 NIXX_LF_RQ_OP_DROP_PKTS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RQ_OP_DROP_PKTS(void) +{ + return 0x940; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_rq_op_int + * + * NIX LF Receive Queue Interrupt Operation Register A 64-bit atomic + * load-and-add to this register reads RQ interrupts and interrupt + * enables. A 64-bit write optionally sets or clears interrupts and + * interrupt enables. All other accesses to this register (e.g. reads, + * 128-bit accesses) are RAZ/WI. RSL accesses to this register are + * RAZ/WI. + */ +union nixx_lf_rq_op_int { + u64 u; + struct nixx_lf_rq_op_int_s { + u64 rq_int : 8; + u64 rq_int_ena : 8; + u64 reserved_16_41 : 26; + u64 op_err : 1; + u64 setop : 1; + u64 rq : 20; + } s; + /* struct nixx_lf_rq_op_int_s cn; */ +}; + +static inline u64 NIXX_LF_RQ_OP_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RQ_OP_INT(void) +{ + return 0x900; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_rq_op_octs + * + * NIX LF Receive Queue Octets Operation Register A 64-bit atomic load- + * and-add to this register reads NIX_RQ_CTX_S[OCTS]. The atomic write + * data has format NIX_OP_Q_WDATA_S and selects the RQ within LF. All + * other accesses to this register (e.g. reads and writes) are RAZ/WI. + * RSL accesses to this register are RAZ/WI. + */ +union nixx_lf_rq_op_octs { + u64 u; + struct nixx_lf_rq_op_octs_s { + u64 cnt : 48; + u64 reserved_48_62 : 15; + u64 op_err : 1; + } s; + /* struct nixx_lf_rq_op_octs_s cn; */ +}; + +static inline u64 NIXX_LF_RQ_OP_OCTS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RQ_OP_OCTS(void) +{ + return 0x910; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_rq_op_pkts + * + * NIX LF Receive Queue Packets Operation Register A 64-bit atomic load- + * and-add to this register reads NIX_RQ_CTX_S[PKTS]. The atomic write + * data has format NIX_OP_Q_WDATA_S and selects the RQ within LF. All + * other accesses to this register (e.g. reads and writes) are RAZ/WI. + * RSL accesses to this register are RAZ/WI. + */ +union nixx_lf_rq_op_pkts { + u64 u; + struct nixx_lf_rq_op_pkts_s { + u64 cnt : 48; + u64 reserved_48_62 : 15; + u64 op_err : 1; + } s; + /* struct nixx_lf_rq_op_pkts_s cn; */ +}; + +static inline u64 NIXX_LF_RQ_OP_PKTS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RQ_OP_PKTS(void) +{ + return 0x920; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_rq_op_re_pkts + * + * NIX LF Receive Queue Errored Packets Operation Register A 64-bit + * atomic load-and-add to this register reads NIX_RQ_CTX_S[RE_PKTS]. The + * atomic write data has format NIX_OP_Q_WDATA_S and selects the RQ + * within LF. All other accesses to this register (e.g. reads and + * writes) are RAZ/WI. RSL accesses to this register are RAZ/WI. + */ +union nixx_lf_rq_op_re_pkts { + u64 u; + struct nixx_lf_rq_op_re_pkts_s { + u64 cnt : 48; + u64 reserved_48_62 : 15; + u64 op_err : 1; + } s; + /* struct nixx_lf_rq_op_re_pkts_s cn; */ +}; + +static inline u64 NIXX_LF_RQ_OP_RE_PKTS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RQ_OP_RE_PKTS(void) +{ + return 0x950; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_rx_secret# + * + * NIX LF Receive Secret Key Registers + */ +union nixx_lf_rx_secretx { + u64 u; + struct nixx_lf_rx_secretx_s { + u64 key : 64; + } s; + /* struct nixx_lf_rx_secretx_s cn; */ +}; + +static inline u64 NIXX_LF_RX_SECRETX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RX_SECRETX(u64 a) +{ + return 0 + 8 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_rx_stat# + * + * NIX LF Receive Statistics Registers The last dimension indicates which + * statistic, and is enumerated by NIX_STAT_LF_RX_E. + */ +union nixx_lf_rx_statx { + u64 u; + struct nixx_lf_rx_statx_s { + u64 stat : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_lf_rx_statx_s cn; */ +}; + +static inline u64 NIXX_LF_RX_STATX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_RX_STATX(u64 a) +{ + return 0x400 + 8 * a; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_send_err_dbg + * + * NIX LF Send Error Debug Register This register captures debug info an + * error detected on packet send after a meta-descriptor is granted by + * PSE. Hardware sets [VALID] when the debug info is captured, and + * subsequent errors are not captured until software clears [VALID] by + * writing a one to it. + */ +union nixx_lf_send_err_dbg { + u64 u; + struct nixx_lf_send_err_dbg_s { + u64 errcode : 8; + u64 sq : 20; + u64 sqe_id : 16; + u64 valid : 1; + u64 reserved_45_63 : 19; + } s; + /* struct nixx_lf_send_err_dbg_s cn; */ +}; + +static inline u64 NIXX_LF_SEND_ERR_DBG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_SEND_ERR_DBG(void) +{ + return 0x280; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_sq_op_drop_octs + * + * NIX LF Send Queue Dropped Octets Operation Register A 64-bit atomic + * load-and-add to this register reads NIX_SQ_CTX_S[DROP_OCTS]. The + * atomic write data has format NIX_OP_Q_WDATA_S and selects the SQ + * within LF. All other accesses to this register (e.g. reads and + * writes) are RAZ/WI. RSL accesses to this register are RAZ/WI. + */ +union nixx_lf_sq_op_drop_octs { + u64 u; + struct nixx_lf_sq_op_drop_octs_s { + u64 cnt : 48; + u64 reserved_48_62 : 15; + u64 op_err : 1; + } s; + /* struct nixx_lf_sq_op_drop_octs_s cn; */ +}; + +static inline u64 NIXX_LF_SQ_OP_DROP_OCTS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_SQ_OP_DROP_OCTS(void) +{ + return 0xa40; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_sq_op_drop_pkts + * + * NIX LF Send Queue Dropped Packets Operation Register A 64-bit atomic + * load-and-add to this register reads NIX_SQ_CTX_S[DROP_PKTS]. The + * atomic write data has format NIX_OP_Q_WDATA_S and selects the SQ + * within LF. All other accesses to this register (e.g. reads and + * writes) are RAZ/WI. RSL accesses to this register are RAZ/WI. + */ +union nixx_lf_sq_op_drop_pkts { + u64 u; + struct nixx_lf_sq_op_drop_pkts_s { + u64 cnt : 48; + u64 reserved_48_62 : 15; + u64 op_err : 1; + } s; + /* struct nixx_lf_sq_op_drop_pkts_s cn; */ +}; + +static inline u64 NIXX_LF_SQ_OP_DROP_PKTS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_SQ_OP_DROP_PKTS(void) +{ + return 0xa50; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_sq_op_err_dbg + * + * NIX LF SQ Operation Error Debug Register This register captures debug + * info for an error detected on LMT store to NIX_LF_OP_SEND() or when a + * NIX_LF_SQ_OP_* register is accessed. Hardware sets [VALID] when the + * debug info is captured, and subsequent errors are not captured until + * software clears [VALID] by writing a one to it. + */ +union nixx_lf_sq_op_err_dbg { + u64 u; + struct nixx_lf_sq_op_err_dbg_s { + u64 errcode : 8; + u64 sq : 20; + u64 sqe_id : 16; + u64 valid : 1; + u64 reserved_45_63 : 19; + } s; + /* struct nixx_lf_sq_op_err_dbg_s cn; */ +}; + +static inline u64 NIXX_LF_SQ_OP_ERR_DBG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_SQ_OP_ERR_DBG(void) +{ + return 0x260; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_sq_op_int + * + * NIX LF Send Queue Interrupt Operation Register A 64-bit atomic load- + * and-add to this register reads SQ interrupts, interrupt enables and + * XOFF status. A write optionally sets or clears interrupts, interrupt + * enables and XOFF status. A read is RAZ. RSL accesses to this register + * are RAZ/WI. + */ +union nixx_lf_sq_op_int { + u64 u; + struct nixx_lf_sq_op_int_s { + u64 sq_int : 8; + u64 sq_int_ena : 8; + u64 xoff : 1; + u64 reserved_17_41 : 25; + u64 op_err : 1; + u64 setop : 1; + u64 sq : 20; + } s; + /* struct nixx_lf_sq_op_int_s cn; */ +}; + +static inline u64 NIXX_LF_SQ_OP_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_SQ_OP_INT(void) +{ + return 0xa00; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_sq_op_octs + * + * NIX LF Send Queue Octets Operation Register A 64-bit atomic load-and- + * add to this register reads NIX_SQ_CTX_S[OCTS]. The atomic write data + * has format NIX_OP_Q_WDATA_S and selects the SQ within LF. All other + * accesses to this register (e.g. reads and writes) are RAZ/WI. RSL + * accesses to this register are RAZ/WI. + */ +union nixx_lf_sq_op_octs { + u64 u; + struct nixx_lf_sq_op_octs_s { + u64 cnt : 48; + u64 reserved_48_62 : 15; + u64 op_err : 1; + } s; + /* struct nixx_lf_sq_op_octs_s cn; */ +}; + +static inline u64 NIXX_LF_SQ_OP_OCTS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_SQ_OP_OCTS(void) +{ + return 0xa10; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_sq_op_pkts + * + * NIX LF Send Queue Packets Operation Register A 64-bit atomic load-and- + * add to this register reads NIX_SQ_CTX_S[PKTS]. The atomic write data + * has format NIX_OP_Q_WDATA_S and selects the SQ within LF. All other + * accesses to this register (e.g. reads and writes) are RAZ/WI. RSL + * accesses to this register are RAZ/WI. + */ +union nixx_lf_sq_op_pkts { + u64 u; + struct nixx_lf_sq_op_pkts_s { + u64 cnt : 48; + u64 reserved_48_62 : 15; + u64 op_err : 1; + } s; + /* struct nixx_lf_sq_op_pkts_s cn; */ +}; + +static inline u64 NIXX_LF_SQ_OP_PKTS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_SQ_OP_PKTS(void) +{ + return 0xa20; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_sq_op_status + * + * NIX LF Send Queue Status Operation Register A 64-bit atomic load-and- + * add to this register reads status fields in NIX_SQ_CTX_S. The atomic + * write data has format NIX_OP_Q_WDATA_S and selects the SQ within LF. + * Completion of the load-and-add operation also ensures that all + * previously issued LMT stores to NIX_LF_OP_SEND() have completed. All + * other accesses to this register (e.g. reads and writes) are RAZ/WI. + * RSL accesses to this register are RAZ/WI. + */ +union nixx_lf_sq_op_status { + u64 u; + struct nixx_lf_sq_op_status_s { + u64 sqb_count : 16; + u64 reserved_16_19 : 4; + u64 head_offset : 6; + u64 reserved_26_27 : 2; + u64 tail_offset : 6; + u64 reserved_34_62 : 29; + u64 op_err : 1; + } s; + struct nixx_lf_sq_op_status_cn { + u64 sqb_count : 16; + u64 reserved_16_19 : 4; + u64 head_offset : 6; + u64 reserved_26_27 : 2; + u64 tail_offset : 6; + u64 reserved_34_35 : 2; + u64 reserved_36_62 : 27; + u64 op_err : 1; + } cn; +}; + +static inline u64 NIXX_LF_SQ_OP_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_SQ_OP_STATUS(void) +{ + return 0xa30; +} + +/** + * Register (RVU_PFVF_BAR2) nix#_lf_tx_stat# + * + * NIX LF Transmit Statistics Registers The last dimension indicates + * which statistic, and is enumerated by NIX_STAT_LF_TX_E. + */ +union nixx_lf_tx_statx { + u64 u; + struct nixx_lf_tx_statx_s { + u64 stat : 48; + u64 reserved_48_63 : 16; + } s; + /* struct nixx_lf_tx_statx_s cn; */ +}; + +static inline u64 NIXX_LF_TX_STATX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_LF_TX_STATX(u64 a) +{ + return 0x300 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_priv_af_int_cfg + * + * NIX Privileged Admin Function Interrupt Configuration Register + */ +union nixx_priv_af_int_cfg { + u64 u; + struct nixx_priv_af_int_cfg_s { + u64 msix_offset : 11; + u64 reserved_11 : 1; + u64 msix_size : 8; + u64 reserved_20_63 : 44; + } s; + /* struct nixx_priv_af_int_cfg_s cn; */ +}; + +static inline u64 NIXX_PRIV_AF_INT_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_PRIV_AF_INT_CFG(void) +{ + return 0x8000000; +} + +/** + * Register (RVU_PF_BAR0) nix#_priv_lf#_cfg + * + * NIX Privileged Local Function Configuration Registers These registers + * allow each NIX local function (LF) to be provisioned to a VF/PF for + * RVU. See also NIX_AF_RVU_LF_CFG_DEBUG. Software should read this + * register after write to ensure that the LF is mapped to [PF_FUNC] + * before issuing transactions to the mapped PF and function. [SLOT] + * must be zero. Internal: Hardware ignores [SLOT] and always assumes + * 0x0. + */ +union nixx_priv_lfx_cfg { + u64 u; + struct nixx_priv_lfx_cfg_s { + u64 slot : 8; + u64 pf_func : 16; + u64 reserved_24_62 : 39; + u64 ena : 1; + } s; + /* struct nixx_priv_lfx_cfg_s cn; */ +}; + +static inline u64 NIXX_PRIV_LFX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_PRIV_LFX_CFG(u64 a) +{ + return 0x8000010 + 0x100 * a; +} + +/** + * Register (RVU_PF_BAR0) nix#_priv_lf#_int_cfg + * + * NIX Privileged LF Interrupt Configuration Registers + */ +union nixx_priv_lfx_int_cfg { + u64 u; + struct nixx_priv_lfx_int_cfg_s { + u64 msix_offset : 11; + u64 reserved_11 : 1; + u64 msix_size : 8; + u64 reserved_20_63 : 44; + } s; + /* struct nixx_priv_lfx_int_cfg_s cn; */ +}; + +static inline u64 NIXX_PRIV_LFX_INT_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NIXX_PRIV_LFX_INT_CFG(u64 a) +{ + return 0x8000020 + 0x100 * a; +} + +#endif /* __CSRS_NIX_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx2/csrs/csrs-npa.h b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-npa.h new file mode 100644 index 0000000000..b70c91bf0d --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-npa.h @@ -0,0 +1,2294 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Marvell International Ltd. + * + * https://spdx.org/licenses + */ +#ifndef __CSRS_NPA_H__ +#define __CSRS_NPA_H__ + +/** + * @file + * + * Configuration and status register (CSR) address and type definitions for + * NPA. + * + * This file is auto generated. Do not edit. + * + */ + +/** + * Enumeration npa_af_int_vec_e + * + * NPA Admin Function Interrupt Vector Enumeration Enumerates the NPA AF + * MSI-X interrupt vectors. + */ +#define NPA_AF_INT_VEC_E_AF_ERR (3) +#define NPA_AF_INT_VEC_E_AQ_DONE (2) +#define NPA_AF_INT_VEC_E_GEN (1) +#define NPA_AF_INT_VEC_E_POISON (4) +#define NPA_AF_INT_VEC_E_RVU (0) + +/** + * Enumeration npa_aq_comp_e + * + * NPA Admin Queue Completion Enumeration Enumerates the values of + * NPA_AQ_RES_S[COMPCODE]. + */ +#define NPA_AQ_COMP_E_CTX_FAULT (4) +#define NPA_AQ_COMP_E_CTX_POISON (3) +#define NPA_AQ_COMP_E_GOOD (1) +#define NPA_AQ_COMP_E_LOCKERR (5) +#define NPA_AQ_COMP_E_NOTDONE (0) +#define NPA_AQ_COMP_E_SWERR (2) + +/** + * Enumeration npa_aq_ctype_e + * + * NPA Admin Queue Context Type Enumeration Enumerates + * NPA_AQ_INST_S[CTYPE] values. + */ +#define NPA_AQ_CTYPE_E_AURA (0) +#define NPA_AQ_CTYPE_E_POOL (1) + +/** + * Enumeration npa_aq_instop_e + * + * NPA Admin Queue Opcode Enumeration Enumerates NPA_AQ_INST_S[OP] + * values. + */ +#define NPA_AQ_INSTOP_E_INIT (1) +#define NPA_AQ_INSTOP_E_LOCK (4) +#define NPA_AQ_INSTOP_E_NOP (0) +#define NPA_AQ_INSTOP_E_READ (3) +#define NPA_AQ_INSTOP_E_UNLOCK (5) +#define NPA_AQ_INSTOP_E_WRITE (2) + +/** + * Enumeration npa_aura_err_int_e + * + * NPA Aura Error Interrupt Enumeration Enumerates the bit index of + * NPA_AURA_S[ERR_INT], and NPA_AURA_S[ERR_INT_ENA]. + */ +#define NPA_AURA_ERR_INT_E_AURA_ADD_OVER (1) +#define NPA_AURA_ERR_INT_E_AURA_ADD_UNDER (2) +#define NPA_AURA_ERR_INT_E_AURA_FREE_UNDER (0) +#define NPA_AURA_ERR_INT_E_POOL_DIS (3) +#define NPA_AURA_ERR_INT_E_RX(a) (0 + (a)) + +/** + * Enumeration npa_bpintf_e + * + * NPA Backpressure Interface Enumeration Enumerates index of + * NPA_AURA_S[BP_ENA]. + */ +#define NPA_BPINTF_E_NIXX_RX(a) (0 + (a)) + +/** + * Enumeration npa_inpq_e + * + * NPA Input Queue Enumeration Enumerates ALLOC/FREE input queues from + * coprocessors. + */ +#define NPA_INPQ_E_AURA_OP (0xe) +#define NPA_INPQ_E_BPHY (7) +#define NPA_INPQ_E_DPI (6) +#define NPA_INPQ_E_INTERNAL_RSV (0xf) +#define NPA_INPQ_E_NIXX_RX(a) (0 + 2 * (a)) +#define NPA_INPQ_E_NIXX_TX(a) (1 + 2 * (a)) +#define NPA_INPQ_E_RX(a) (0 + (a)) +#define NPA_INPQ_E_SSO (4) +#define NPA_INPQ_E_TIM (5) + +/** + * Enumeration npa_lf_int_vec_e + * + * NPA Local Function Interrupt Vector Enumeration Enumerates the NPA + * MSI-X interrupt vectors per LF. + */ +#define NPA_LF_INT_VEC_E_ERR_INT (0x40) +#define NPA_LF_INT_VEC_E_POISON (0x41) +#define NPA_LF_INT_VEC_E_QINTX(a) (0 + (a)) + +/** + * Enumeration npa_ndc0_port_e + * + * NPA NDC0 Port Enumeration Enumerates NPA NDC0 (NDC_IDX_E::NPA_U(0)) + * ports and the PORT index of NDC_AF_PORT()_RT()_RW()_REQ_PC and + * NDC_AF_PORT()_RT()_RW()_LAT_PC. + */ +#define NPA_NDC0_PORT_E_AURA0 (0) +#define NPA_NDC0_PORT_E_AURA1 (1) +#define NPA_NDC0_PORT_E_POOL0 (2) +#define NPA_NDC0_PORT_E_POOL1 (3) +#define NPA_NDC0_PORT_E_STACK0 (4) +#define NPA_NDC0_PORT_E_STACK1 (5) + +/** + * Enumeration npa_pool_err_int_e + * + * NPA Pool Error Interrupt Enumeration Enumerates the bit index of + * NPA_POOL_S[ERR_INT] and NPA_POOL_S[ERR_INT_ENA]. + */ +#define NPA_POOL_ERR_INT_E_OVFLS (0) +#define NPA_POOL_ERR_INT_E_PERR (2) +#define NPA_POOL_ERR_INT_E_RX(a) (0 + (a)) +#define NPA_POOL_ERR_INT_E_RANGE (1) + +/** + * Structure npa_aq_inst_s + * + * NPA Admin Queue Instruction Structure This structure specifies the AQ + * instruction. Instructions and associated software structures are + * stored in memory as little-endian unless NPA_AF_GEN_CFG[AF_BE] is set. + * Hardware reads of NPA_AQ_INST_S do not allocate into LLC. Hardware + * reads and writes of the context structure selected by [CTYPE], [LF] + * and [CINDEX] use the NDC and LLC caching style configured for that + * context, i.e.: * NPA_AURA_HW_S reads and writes use + * NPA_AF_LF()_AURAS_CFG[CACHING] and NPA_AF_LF()_AURAS_CFG[WAY_MASK]. * + * NPA_POOL_HW_S reads and writes use NPA_AURA_HW_S[POOL_CACHING] and + * NPA_AURA_HW_S[POOL_WAY_MASK]. + */ +union npa_aq_inst_s { + u64 u[2]; + struct npa_aq_inst_s_s { + u64 op : 4; + u64 ctype : 4; + u64 lf : 9; + u64 reserved_17_23 : 7; + u64 cindex : 20; + u64 reserved_44_62 : 19; + u64 doneint : 1; + u64 res_addr : 64; + } s; + /* struct npa_aq_inst_s_s cn; */ +}; + +/** + * Structure npa_aq_res_s + * + * NPA Admin Queue Result Structure NPA writes this structure after it + * completes the NPA_AQ_INST_S instruction. The result structure is + * exactly 16 bytes, and each instruction completion produces exactly one + * result structure. Results and associated software structures are + * stored in memory as little-endian unless NPA_AF_GEN_CFG[AF_BE] is set. + * When [OP] = NPA_AQ_INSTOP_E::INIT, WRITE or READ, this structure is + * immediately followed by context read or write data. See + * NPA_AQ_INSTOP_E. Hardware writes of NPA_AQ_RES_S and context data + * always allocate into LLC. Hardware reads of context data do not + * allocate into LLC. + */ +union npa_aq_res_s { + u64 u[2]; + struct npa_aq_res_s_s { + u64 op : 4; + u64 ctype : 4; + u64 compcode : 8; + u64 doneint : 1; + u64 reserved_17_63 : 47; + u64 reserved_64_127 : 64; + } s; + /* struct npa_aq_res_s_s cn; */ +}; + +/** + * Structure npa_aura_op_wdata_s + * + * NPA Aura Operation Write Data Structure This structure specifies the + * write data format of a 64-bit atomic load-and-add to + * NPA_LF_AURA_OP_ALLOC() and NPA_LF_POOL_OP_PC, and a 128-bit atomic + * CASP operation to NPA_LF_AURA_OP_ALLOC(). + */ +union npa_aura_op_wdata_s { + u64 u; + struct npa_aura_op_wdata_s_s { + u64 aura : 20; + u64 reserved_20_62 : 43; + u64 drop : 1; + } s; + /* struct npa_aura_op_wdata_s_s cn; */ +}; + +/** + * Structure npa_aura_s + * + * NPA Aura Context Structure This structure specifies the format used by + * software with the NPA admin queue to read and write an aura's + * NPA_AURA_HW_S structure maintained by hardware in LLC/DRAM. + */ +union npa_aura_s { + u64 u[8]; + struct npa_aura_s_s { + u64 pool_addr : 64; + u64 ena : 1; + u64 reserved_65_66 : 2; + u64 pool_caching : 1; + u64 pool_way_mask : 16; + u64 avg_con : 9; + u64 reserved_93 : 1; + u64 pool_drop_ena : 1; + u64 aura_drop_ena : 1; + u64 bp_ena : 2; + u64 reserved_98_103 : 6; + u64 aura_drop : 8; + u64 shift : 6; + u64 reserved_118_119 : 2; + u64 avg_level : 8; + u64 count : 36; + u64 reserved_164_167 : 4; + u64 nix0_bpid : 9; + u64 reserved_177_179 : 3; + u64 nix1_bpid : 9; + u64 reserved_189_191 : 3; + u64 limit : 36; + u64 reserved_228_231 : 4; + u64 bp : 8; + u64 reserved_240_243 : 4; + u64 fc_ena : 1; + u64 fc_up_crossing : 1; + u64 fc_stype : 2; + u64 fc_hyst_bits : 4; + u64 reserved_252_255 : 4; + u64 fc_addr : 64; + u64 pool_drop : 8; + u64 update_time : 16; + u64 err_int : 8; + u64 err_int_ena : 8; + u64 thresh_int : 1; + u64 thresh_int_ena : 1; + u64 thresh_up : 1; + u64 reserved_363 : 1; + u64 thresh_qint_idx : 7; + u64 reserved_371 : 1; + u64 err_qint_idx : 7; + u64 reserved_379_383 : 5; + u64 thresh : 36; + u64 reserved_420_447 : 28; + u64 reserved_448_511 : 64; + } s; + /* struct npa_aura_s_s cn; */ +}; + +/** + * Structure npa_pool_s + * + * NPA Pool Context Structure This structure specifies the format used by + * software with the NPA admin queue to read and write a pool's + * NPA_POOL_HW_S structure maintained by hardware in LLC/DRAM. + */ +union npa_pool_s { + u64 u[16]; + struct npa_pool_s_s { + u64 stack_base : 64; + u64 ena : 1; + u64 nat_align : 1; + u64 reserved_66_67 : 2; + u64 stack_caching : 1; + u64 reserved_69_71 : 3; + u64 stack_way_mask : 16; + u64 buf_offset : 12; + u64 reserved_100_103 : 4; + u64 buf_size : 11; + u64 reserved_115_127 : 13; + u64 stack_max_pages : 32; + u64 stack_pages : 32; + u64 op_pc : 48; + u64 reserved_240_255 : 16; + u64 stack_offset : 4; + u64 reserved_260_263 : 4; + u64 shift : 6; + u64 reserved_270_271 : 2; + u64 avg_level : 8; + u64 avg_con : 9; + u64 fc_ena : 1; + u64 fc_stype : 2; + u64 fc_hyst_bits : 4; + u64 fc_up_crossing : 1; + u64 reserved_297_299 : 3; + u64 update_time : 16; + u64 reserved_316_319 : 4; + u64 fc_addr : 64; + u64 ptr_start : 64; + u64 ptr_end : 64; + u64 reserved_512_535 : 24; + u64 err_int : 8; + u64 err_int_ena : 8; + u64 thresh_int : 1; + u64 thresh_int_ena : 1; + u64 thresh_up : 1; + u64 reserved_555 : 1; + u64 thresh_qint_idx : 7; + u64 reserved_563 : 1; + u64 err_qint_idx : 7; + u64 reserved_571_575 : 5; + u64 thresh : 36; + u64 reserved_612_639 : 28; + u64 reserved_640_703 : 64; + u64 reserved_704_767 : 64; + u64 reserved_768_831 : 64; + u64 reserved_832_895 : 64; + u64 reserved_896_959 : 64; + u64 reserved_960_1023 : 64; + } s; + /* struct npa_pool_s_s cn; */ +}; + +/** + * Structure npa_qint_hw_s + * + * NPA Queue Interrupt Context Hardware Structure This structure contains + * context state maintained by hardware for each queue interrupt (QINT) + * in NDC/LLC/DRAM. Software accesses this structure with the + * NPA_LF_QINT()_* registers. Hardware maintains a table of + * NPA_AF_CONST[QINTS] contiguous NPA_QINT_HW_S structures per LF + * starting at IOVA NPA_AF_LF()_QINTS_BASE. Always stored in byte + * invariant little-endian format (LE8). + */ +union npa_qint_hw_s { + u32 u; + struct npa_qint_hw_s_s { + u32 count : 22; + u32 reserved_22_30 : 9; + u32 ena : 1; + } s; + /* struct npa_qint_hw_s_s cn; */ +}; + +/** + * Register (RVU_PF_BAR0) npa_af_active_cycles_pc + * + * NPA AF Active Cycles Register + */ +union npa_af_active_cycles_pc { + u64 u; + struct npa_af_active_cycles_pc_s { + u64 act_cyc : 64; + } s; + /* struct npa_af_active_cycles_pc_s cn; */ +}; + +static inline u64 NPA_AF_ACTIVE_CYCLES_PC(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_ACTIVE_CYCLES_PC(void) +{ + return 0xf0; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_base + * + * NPA AF Admin Queue Base Address Register + */ +union npa_af_aq_base { + u64 u; + struct npa_af_aq_base_s { + u64 reserved_0_6 : 7; + u64 base_addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct npa_af_aq_base_s cn; */ +}; + +static inline u64 NPA_AF_AQ_BASE(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_BASE(void) +{ + return 0x610; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_cfg + * + * NPA AF Admin Queue Configuration Register + */ +union npa_af_aq_cfg { + u64 u; + struct npa_af_aq_cfg_s { + u64 qsize : 4; + u64 reserved_4_63 : 60; + } s; + /* struct npa_af_aq_cfg_s cn; */ +}; + +static inline u64 NPA_AF_AQ_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_CFG(void) +{ + return 0x600; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_done + * + * NPA AF AQ Done Count Register + */ +union npa_af_aq_done { + u64 u; + struct npa_af_aq_done_s { + u64 done : 20; + u64 reserved_20_63 : 44; + } s; + /* struct npa_af_aq_done_s cn; */ +}; + +static inline u64 NPA_AF_AQ_DONE(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_DONE(void) +{ + return 0x650; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_done_ack + * + * NPA AF AQ Done Count Ack Register This register is written by software + * to acknowledge interrupts. + */ +union npa_af_aq_done_ack { + u64 u; + struct npa_af_aq_done_ack_s { + u64 done_ack : 20; + u64 reserved_20_63 : 44; + } s; + /* struct npa_af_aq_done_ack_s cn; */ +}; + +static inline u64 NPA_AF_AQ_DONE_ACK(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_DONE_ACK(void) +{ + return 0x660; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_done_ena_w1c + * + * NPA AF AQ Done Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union npa_af_aq_done_ena_w1c { + u64 u; + struct npa_af_aq_done_ena_w1c_s { + u64 done : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_af_aq_done_ena_w1c_s cn; */ +}; + +static inline u64 NPA_AF_AQ_DONE_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_DONE_ENA_W1C(void) +{ + return 0x698; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_done_ena_w1s + * + * NPA AF AQ Done Interrupt Enable Set Register This register sets + * interrupt enable bits. + */ +union npa_af_aq_done_ena_w1s { + u64 u; + struct npa_af_aq_done_ena_w1s_s { + u64 done : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_af_aq_done_ena_w1s_s cn; */ +}; + +static inline u64 NPA_AF_AQ_DONE_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_DONE_ENA_W1S(void) +{ + return 0x690; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_done_int + * + * NPA AF AQ Done Interrupt Register + */ +union npa_af_aq_done_int { + u64 u; + struct npa_af_aq_done_int_s { + u64 done : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_af_aq_done_int_s cn; */ +}; + +static inline u64 NPA_AF_AQ_DONE_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_DONE_INT(void) +{ + return 0x680; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_done_int_w1s + * + * INTERNAL: NPA AF AQ Done Interrupt Set Register + */ +union npa_af_aq_done_int_w1s { + u64 u; + struct npa_af_aq_done_int_w1s_s { + u64 done : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_af_aq_done_int_w1s_s cn; */ +}; + +static inline u64 NPA_AF_AQ_DONE_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_DONE_INT_W1S(void) +{ + return 0x688; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_done_timer + * + * NPA AF Admin Queue Done Interrupt Timer Register Used to debug the + * queue interrupt coalescing timer. + */ +union npa_af_aq_done_timer { + u64 u; + struct npa_af_aq_done_timer_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct npa_af_aq_done_timer_s cn; */ +}; + +static inline u64 NPA_AF_AQ_DONE_TIMER(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_DONE_TIMER(void) +{ + return 0x670; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_done_wait + * + * NPA AF AQ Done Interrupt Coalescing Wait Register Specifies the queue + * interrupt coalescing settings. + */ +union npa_af_aq_done_wait { + u64 u; + struct npa_af_aq_done_wait_s { + u64 num_wait : 20; + u64 reserved_20_31 : 12; + u64 time_wait : 16; + u64 reserved_48_63 : 16; + } s; + /* struct npa_af_aq_done_wait_s cn; */ +}; + +static inline u64 NPA_AF_AQ_DONE_WAIT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_DONE_WAIT(void) +{ + return 0x640; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_door + * + * NPA AF Admin Queue Doorbell Register Software writes to this register + * to enqueue one or more entries to AQ. + */ +union npa_af_aq_door { + u64 u; + struct npa_af_aq_door_s { + u64 count : 16; + u64 reserved_16_63 : 48; + } s; + /* struct npa_af_aq_door_s cn; */ +}; + +static inline u64 NPA_AF_AQ_DOOR(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_DOOR(void) +{ + return 0x630; +} + +/** + * Register (RVU_PF_BAR0) npa_af_aq_status + * + * NPA AF Admin Queue Status Register + */ +union npa_af_aq_status { + u64 u; + struct npa_af_aq_status_s { + u64 reserved_0_3 : 4; + u64 head_ptr : 20; + u64 reserved_24_35 : 12; + u64 tail_ptr : 20; + u64 reserved_56_61 : 6; + u64 aq_busy : 1; + u64 aq_err : 1; + } s; + struct npa_af_aq_status_cn { + u64 reserved_0_3 : 4; + u64 head_ptr : 20; + u64 reserved_24_31 : 8; + u64 reserved_32_35 : 4; + u64 tail_ptr : 20; + u64 reserved_56_61 : 6; + u64 aq_busy : 1; + u64 aq_err : 1; + } cn; +}; + +static inline u64 NPA_AF_AQ_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AQ_STATUS(void) +{ + return 0x620; +} + +/** + * Register (RVU_PF_BAR0) npa_af_avg_delay + * + * NPA AF Queue Average Delay Register + */ +union npa_af_avg_delay { + u64 u; + struct npa_af_avg_delay_s { + u64 avg_dly : 19; + u64 reserved_19_23 : 5; + u64 avg_timer : 16; + u64 reserved_40_62 : 23; + u64 avg_timer_dis : 1; + } s; + /* struct npa_af_avg_delay_s cn; */ +}; + +static inline u64 NPA_AF_AVG_DELAY(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_AVG_DELAY(void) +{ + return 0x100; +} + +/** + * Register (RVU_PF_BAR0) npa_af_bar2_alias# + * + * INTERNAL: NPA Admin Function BAR2 Alias Registers These registers + * alias to the NPA BAR2 registers for the PF and function selected by + * NPA_AF_BAR2_SEL[PF_FUNC]. Internal: Not implemented. Placeholder for + * bug33464. + */ +union npa_af_bar2_aliasx { + u64 u; + struct npa_af_bar2_aliasx_s { + u64 data : 64; + } s; + /* struct npa_af_bar2_aliasx_s cn; */ +}; + +static inline u64 NPA_AF_BAR2_ALIASX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_BAR2_ALIASX(u64 a) +{ + return 0x9100000 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) npa_af_bar2_sel + * + * INTERNAL: NPA Admin Function BAR2 Select Register This register + * configures BAR2 accesses from the NPA_AF_BAR2_ALIAS() registers in + * BAR0. Internal: Not implemented. Placeholder for bug33464. + */ +union npa_af_bar2_sel { + u64 u; + struct npa_af_bar2_sel_s { + u64 alias_pf_func : 16; + u64 alias_ena : 1; + u64 reserved_17_63 : 47; + } s; + /* struct npa_af_bar2_sel_s cn; */ +}; + +static inline u64 NPA_AF_BAR2_SEL(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_BAR2_SEL(void) +{ + return 0x9000000; +} + +/** + * Register (RVU_PF_BAR0) npa_af_blk_rst + * + * NPA AF Block Reset Register + */ +union npa_af_blk_rst { + u64 u; + struct npa_af_blk_rst_s { + u64 rst : 1; + u64 reserved_1_62 : 62; + u64 busy : 1; + } s; + /* struct npa_af_blk_rst_s cn; */ +}; + +static inline u64 NPA_AF_BLK_RST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_BLK_RST(void) +{ + return 0; +} + +/** + * Register (RVU_PF_BAR0) npa_af_bp_test + * + * INTERNAL: NPA AF Backpressure Test Register + */ +union npa_af_bp_test { + u64 u; + struct npa_af_bp_test_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 32; + u64 enable : 16; + } s; + /* struct npa_af_bp_test_s cn; */ +}; + +static inline u64 NPA_AF_BP_TEST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_BP_TEST(void) +{ + return 0x200; +} + +/** + * Register (RVU_PF_BAR0) npa_af_const + * + * NPA AF Constants Register This register contains constants for + * software discovery. + */ +union npa_af_const { + u64 u; + struct npa_af_const_s { + u64 stack_page_bytes : 8; + u64 stack_page_ptrs : 8; + u64 lfs : 12; + u64 qints : 12; + u64 num_ndc : 3; + u64 reserved_43_63 : 21; + } s; + /* struct npa_af_const_s cn; */ +}; + +static inline u64 NPA_AF_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_CONST(void) +{ + return 0x10; +} + +/** + * Register (RVU_PF_BAR0) npa_af_const1 + * + * NPA AF Constants Register 1 This register contains constants for + * software discovery. + */ +union npa_af_const1 { + u64 u; + struct npa_af_const1_s { + u64 aura_log2bytes : 4; + u64 pool_log2bytes : 4; + u64 qint_log2bytes : 4; + u64 reserved_12_63 : 52; + } s; + /* struct npa_af_const1_s cn; */ +}; + +static inline u64 NPA_AF_CONST1(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_CONST1(void) +{ + return 0x18; +} + +/** + * Register (RVU_PF_BAR0) npa_af_dtx_filter_ctl + * + * NPA AF DTX LF Filter Control Register + */ +union npa_af_dtx_filter_ctl { + u64 u; + struct npa_af_dtx_filter_ctl_s { + u64 ena : 1; + u64 reserved_1_3 : 3; + u64 lf : 7; + u64 reserved_11_63 : 53; + } s; + /* struct npa_af_dtx_filter_ctl_s cn; */ +}; + +static inline u64 NPA_AF_DTX_FILTER_CTL(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_DTX_FILTER_CTL(void) +{ + return 0x10040; +} + +/** + * Register (RVU_PF_BAR0) npa_af_eco + * + * INTERNAL: NPA AF ECO Register + */ +union npa_af_eco { + u64 u; + struct npa_af_eco_s { + u64 eco_rw : 32; + u64 reserved_32_63 : 32; + } s; + /* struct npa_af_eco_s cn; */ +}; + +static inline u64 NPA_AF_ECO(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_ECO(void) +{ + return 0x300; +} + +/** + * Register (RVU_PF_BAR0) npa_af_err_int + * + * NPA Admin Function Error Interrupt Register + */ +union npa_af_err_int { + u64 u; + struct npa_af_err_int_s { + u64 reserved_0_11 : 12; + u64 aq_door_err : 1; + u64 aq_res_fault : 1; + u64 aq_inst_fault : 1; + u64 reserved_15_63 : 49; + } s; + /* struct npa_af_err_int_s cn; */ +}; + +static inline u64 NPA_AF_ERR_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_ERR_INT(void) +{ + return 0x180; +} + +/** + * Register (RVU_PF_BAR0) npa_af_err_int_ena_w1c + * + * NPA Admin Function Error Interrupt Enable Clear Register This register + * clears interrupt enable bits. + */ +union npa_af_err_int_ena_w1c { + u64 u; + struct npa_af_err_int_ena_w1c_s { + u64 reserved_0_11 : 12; + u64 aq_door_err : 1; + u64 aq_res_fault : 1; + u64 aq_inst_fault : 1; + u64 reserved_15_63 : 49; + } s; + /* struct npa_af_err_int_ena_w1c_s cn; */ +}; + +static inline u64 NPA_AF_ERR_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_ERR_INT_ENA_W1C(void) +{ + return 0x198; +} + +/** + * Register (RVU_PF_BAR0) npa_af_err_int_ena_w1s + * + * NPA Admin Function Error Interrupt Enable Set Register This register + * sets interrupt enable bits. + */ +union npa_af_err_int_ena_w1s { + u64 u; + struct npa_af_err_int_ena_w1s_s { + u64 reserved_0_11 : 12; + u64 aq_door_err : 1; + u64 aq_res_fault : 1; + u64 aq_inst_fault : 1; + u64 reserved_15_63 : 49; + } s; + /* struct npa_af_err_int_ena_w1s_s cn; */ +}; + +static inline u64 NPA_AF_ERR_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_ERR_INT_ENA_W1S(void) +{ + return 0x190; +} + +/** + * Register (RVU_PF_BAR0) npa_af_err_int_w1s + * + * NPA Admin Function Error Interrupt Set Register This register sets + * interrupt bits. + */ +union npa_af_err_int_w1s { + u64 u; + struct npa_af_err_int_w1s_s { + u64 reserved_0_11 : 12; + u64 aq_door_err : 1; + u64 aq_res_fault : 1; + u64 aq_inst_fault : 1; + u64 reserved_15_63 : 49; + } s; + /* struct npa_af_err_int_w1s_s cn; */ +}; + +static inline u64 NPA_AF_ERR_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_ERR_INT_W1S(void) +{ + return 0x188; +} + +/** + * Register (RVU_PF_BAR0) npa_af_gen_cfg + * + * NPA AF General Configuration Register This register provides NPA + * control and status information. + */ +union npa_af_gen_cfg { + u64 u; + struct npa_af_gen_cfg_s { + u64 reserved_0 : 1; + u64 af_be : 1; + u64 reserved_2 : 1; + u64 force_cond_clk_en : 1; + u64 force_intf_clk_en : 1; + u64 reserved_5_9 : 5; + u64 ocla_bp : 1; + u64 reserved_11 : 1; + u64 ratem1 : 4; + u64 reserved_16_63 : 48; + } s; + /* struct npa_af_gen_cfg_s cn; */ +}; + +static inline u64 NPA_AF_GEN_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_GEN_CFG(void) +{ + return 0x30; +} + +/** + * Register (RVU_PF_BAR0) npa_af_gen_int + * + * NPA AF General Interrupt Register This register contains general error + * interrupt summary bits. + */ +union npa_af_gen_int { + u64 u; + struct npa_af_gen_int_s { + u64 free_dis : 16; + u64 alloc_dis : 16; + u64 unmapped_pf_func : 1; + u64 reserved_33_63 : 31; + } s; + /* struct npa_af_gen_int_s cn; */ +}; + +static inline u64 NPA_AF_GEN_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_GEN_INT(void) +{ + return 0x140; +} + +/** + * Register (RVU_PF_BAR0) npa_af_gen_int_ena_w1c + * + * NPA AF General Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union npa_af_gen_int_ena_w1c { + u64 u; + struct npa_af_gen_int_ena_w1c_s { + u64 free_dis : 16; + u64 alloc_dis : 16; + u64 unmapped_pf_func : 1; + u64 reserved_33_63 : 31; + } s; + /* struct npa_af_gen_int_ena_w1c_s cn; */ +}; + +static inline u64 NPA_AF_GEN_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_GEN_INT_ENA_W1C(void) +{ + return 0x158; +} + +/** + * Register (RVU_PF_BAR0) npa_af_gen_int_ena_w1s + * + * NPA AF General Interrupt Enable Set Register This register sets + * interrupt enable bits. + */ +union npa_af_gen_int_ena_w1s { + u64 u; + struct npa_af_gen_int_ena_w1s_s { + u64 free_dis : 16; + u64 alloc_dis : 16; + u64 unmapped_pf_func : 1; + u64 reserved_33_63 : 31; + } s; + /* struct npa_af_gen_int_ena_w1s_s cn; */ +}; + +static inline u64 NPA_AF_GEN_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_GEN_INT_ENA_W1S(void) +{ + return 0x150; +} + +/** + * Register (RVU_PF_BAR0) npa_af_gen_int_w1s + * + * NPA AF General Interrupt Set Register This register sets interrupt + * bits. + */ +union npa_af_gen_int_w1s { + u64 u; + struct npa_af_gen_int_w1s_s { + u64 free_dis : 16; + u64 alloc_dis : 16; + u64 unmapped_pf_func : 1; + u64 reserved_33_63 : 31; + } s; + /* struct npa_af_gen_int_w1s_s cn; */ +}; + +static inline u64 NPA_AF_GEN_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_GEN_INT_W1S(void) +{ + return 0x148; +} + +/** + * Register (RVU_PF_BAR0) npa_af_inp_ctl + * + * NPA AF Input Control Register + */ +union npa_af_inp_ctl { + u64 u; + struct npa_af_inp_ctl_s { + u64 free_dis : 16; + u64 alloc_dis : 16; + u64 reserved_32_63 : 32; + } s; + /* struct npa_af_inp_ctl_s cn; */ +}; + +static inline u64 NPA_AF_INP_CTL(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_INP_CTL(void) +{ + return 0xd0; +} + +/** + * Register (RVU_PF_BAR0) npa_af_lf#_auras_cfg + * + * NPA AF Local Function Auras Configuration Registers + */ +union npa_af_lfx_auras_cfg { + u64 u; + struct npa_af_lfx_auras_cfg_s { + u64 way_mask : 16; + u64 loc_aura_size : 4; + u64 loc_aura_offset : 14; + u64 caching : 1; + u64 be : 1; + u64 rmt_aura_size : 4; + u64 rmt_aura_offset : 14; + u64 rmt_lf : 7; + u64 reserved_61_63 : 3; + } s; + struct npa_af_lfx_auras_cfg_cn96xxp1 { + u64 way_mask : 16; + u64 loc_aura_size : 4; + u64 loc_aura_offset : 14; + u64 caching : 1; + u64 reserved_35 : 1; + u64 rmt_aura_size : 4; + u64 rmt_aura_offset : 14; + u64 rmt_lf : 7; + u64 reserved_61_63 : 3; + } cn96xxp1; + /* struct npa_af_lfx_auras_cfg_s cn96xxp3; */ + /* struct npa_af_lfx_auras_cfg_s cnf95xx; */ +}; + +static inline u64 NPA_AF_LFX_AURAS_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_LFX_AURAS_CFG(u64 a) +{ + return 0x4000 + 0x40000 * a; +} + +/** + * Register (RVU_PF_BAR0) npa_af_lf#_loc_auras_base + * + * NPA AF Local Function Auras Base Registers + */ +union npa_af_lfx_loc_auras_base { + u64 u; + struct npa_af_lfx_loc_auras_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct npa_af_lfx_loc_auras_base_s cn; */ +}; + +static inline u64 NPA_AF_LFX_LOC_AURAS_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_LFX_LOC_AURAS_BASE(u64 a) +{ + return 0x4010 + 0x40000 * a; +} + +/** + * Register (RVU_PF_BAR0) npa_af_lf#_qints_base + * + * NPA AF Local Function Queue Interrupts Base Registers + */ +union npa_af_lfx_qints_base { + u64 u; + struct npa_af_lfx_qints_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct npa_af_lfx_qints_base_s cn; */ +}; + +static inline u64 NPA_AF_LFX_QINTS_BASE(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_LFX_QINTS_BASE(u64 a) +{ + return 0x4110 + 0x40000 * a; +} + +/** + * Register (RVU_PF_BAR0) npa_af_lf#_qints_cfg + * + * NPA AF Local Function Queue Interrupts Configuration Registers This + * register controls access to the LF's queue interrupt context table in + * LLC/DRAM. The table consists of NPA_AF_CONST[QINTS] contiguous + * NPA_QINT_HW_S structures. The size of each structure is 1 << + * NPA_AF_CONST1[QINT_LOG2BYTES] bytes. + */ +union npa_af_lfx_qints_cfg { + u64 u; + struct npa_af_lfx_qints_cfg_s { + u64 reserved_0_19 : 20; + u64 way_mask : 16; + u64 caching : 2; + u64 reserved_38_63 : 26; + } s; + /* struct npa_af_lfx_qints_cfg_s cn; */ +}; + +static inline u64 NPA_AF_LFX_QINTS_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_LFX_QINTS_CFG(u64 a) +{ + return 0x4100 + 0x40000 * a; +} + +/** + * Register (RVU_PF_BAR0) npa_af_lf_rst + * + * NPA Admin Function LF Reset Register + */ +union npa_af_lf_rst { + u64 u; + struct npa_af_lf_rst_s { + u64 lf : 8; + u64 reserved_8_11 : 4; + u64 exec : 1; + u64 reserved_13_63 : 51; + } s; + /* struct npa_af_lf_rst_s cn; */ +}; + +static inline u64 NPA_AF_LF_RST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_LF_RST(void) +{ + return 0x20; +} + +/** + * Register (RVU_PF_BAR0) npa_af_ndc_cfg + * + * NDC AF General Configuration Register This register provides NDC + * control. + */ +union npa_af_ndc_cfg { + u64 u; + struct npa_af_ndc_cfg_s { + u64 ndc_bypass : 1; + u64 ndc_ign_pois : 1; + u64 byp_aura : 1; + u64 byp_pool : 1; + u64 byp_stack : 1; + u64 byp_qint : 1; + u64 reserved_6_63 : 58; + } s; + /* struct npa_af_ndc_cfg_s cn; */ +}; + +static inline u64 NPA_AF_NDC_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_NDC_CFG(void) +{ + return 0x40; +} + +/** + * Register (RVU_PF_BAR0) npa_af_ndc_sync + * + * NPA AF NDC Sync Register Used to synchronize the NPA NDC. + */ +union npa_af_ndc_sync { + u64 u; + struct npa_af_ndc_sync_s { + u64 lf : 8; + u64 reserved_8_11 : 4; + u64 exec : 1; + u64 reserved_13_63 : 51; + } s; + /* struct npa_af_ndc_sync_s cn; */ +}; + +static inline u64 NPA_AF_NDC_SYNC(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_NDC_SYNC(void) +{ + return 0x50; +} + +/** + * Register (RVU_PF_BAR0) npa_af_ras + * + * NPA AF RAS Interrupt Register This register is intended for delivery + * of RAS events to the SCP, so should be ignored by OS drivers. + */ +union npa_af_ras { + u64 u; + struct npa_af_ras_s { + u64 reserved_0_31 : 32; + u64 aq_ctx_poison : 1; + u64 aq_res_poison : 1; + u64 aq_inst_poison : 1; + u64 reserved_35_63 : 29; + } s; + /* struct npa_af_ras_s cn; */ +}; + +static inline u64 NPA_AF_RAS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_RAS(void) +{ + return 0x1a0; +} + +/** + * Register (RVU_PF_BAR0) npa_af_ras_ena_w1c + * + * NPA AF RAS Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union npa_af_ras_ena_w1c { + u64 u; + struct npa_af_ras_ena_w1c_s { + u64 reserved_0_31 : 32; + u64 aq_ctx_poison : 1; + u64 aq_res_poison : 1; + u64 aq_inst_poison : 1; + u64 reserved_35_63 : 29; + } s; + /* struct npa_af_ras_ena_w1c_s cn; */ +}; + +static inline u64 NPA_AF_RAS_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_RAS_ENA_W1C(void) +{ + return 0x1b8; +} + +/** + * Register (RVU_PF_BAR0) npa_af_ras_ena_w1s + * + * NPA AF RAS Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union npa_af_ras_ena_w1s { + u64 u; + struct npa_af_ras_ena_w1s_s { + u64 reserved_0_31 : 32; + u64 aq_ctx_poison : 1; + u64 aq_res_poison : 1; + u64 aq_inst_poison : 1; + u64 reserved_35_63 : 29; + } s; + /* struct npa_af_ras_ena_w1s_s cn; */ +}; + +static inline u64 NPA_AF_RAS_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_RAS_ENA_W1S(void) +{ + return 0x1b0; +} + +/** + * Register (RVU_PF_BAR0) npa_af_ras_w1s + * + * NPA AF RAS Interrupt Set Register This register sets interrupt bits. + */ +union npa_af_ras_w1s { + u64 u; + struct npa_af_ras_w1s_s { + u64 reserved_0_31 : 32; + u64 aq_ctx_poison : 1; + u64 aq_res_poison : 1; + u64 aq_inst_poison : 1; + u64 reserved_35_63 : 29; + } s; + /* struct npa_af_ras_w1s_s cn; */ +}; + +static inline u64 NPA_AF_RAS_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_RAS_W1S(void) +{ + return 0x1a8; +} + +/** + * Register (RVU_PF_BAR0) npa_af_rvu_int + * + * NPA AF RVU Interrupt Register This register contains RVU error + * interrupt summary bits. + */ +union npa_af_rvu_int { + u64 u; + struct npa_af_rvu_int_s { + u64 unmapped_slot : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_af_rvu_int_s cn; */ +}; + +static inline u64 NPA_AF_RVU_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_RVU_INT(void) +{ + return 0x160; +} + +/** + * Register (RVU_PF_BAR0) npa_af_rvu_int_ena_w1c + * + * NPA AF RVU Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union npa_af_rvu_int_ena_w1c { + u64 u; + struct npa_af_rvu_int_ena_w1c_s { + u64 unmapped_slot : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_af_rvu_int_ena_w1c_s cn; */ +}; + +static inline u64 NPA_AF_RVU_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_RVU_INT_ENA_W1C(void) +{ + return 0x178; +} + +/** + * Register (RVU_PF_BAR0) npa_af_rvu_int_ena_w1s + * + * NPA AF RVU Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union npa_af_rvu_int_ena_w1s { + u64 u; + struct npa_af_rvu_int_ena_w1s_s { + u64 unmapped_slot : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_af_rvu_int_ena_w1s_s cn; */ +}; + +static inline u64 NPA_AF_RVU_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_RVU_INT_ENA_W1S(void) +{ + return 0x170; +} + +/** + * Register (RVU_PF_BAR0) npa_af_rvu_int_w1s + * + * NPA AF RVU Interrupt Set Register This register sets interrupt bits. + */ +union npa_af_rvu_int_w1s { + u64 u; + struct npa_af_rvu_int_w1s_s { + u64 unmapped_slot : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_af_rvu_int_w1s_s cn; */ +}; + +static inline u64 NPA_AF_RVU_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_RVU_INT_W1S(void) +{ + return 0x168; +} + +/** + * Register (RVU_PF_BAR0) npa_af_rvu_lf_cfg_debug + * + * NPA Privileged LF Configuration Debug Register This debug register + * allows software to lookup the reverse mapping from VF/PF slot to LF. + * The forward mapping is programmed with NPA_PRIV_LF()_CFG. + */ +union npa_af_rvu_lf_cfg_debug { + u64 u; + struct npa_af_rvu_lf_cfg_debug_s { + u64 lf : 12; + u64 lf_valid : 1; + u64 exec : 1; + u64 reserved_14_15 : 2; + u64 slot : 8; + u64 pf_func : 16; + u64 reserved_40_63 : 24; + } s; + /* struct npa_af_rvu_lf_cfg_debug_s cn; */ +}; + +static inline u64 NPA_AF_RVU_LF_CFG_DEBUG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_AF_RVU_LF_CFG_DEBUG(void) +{ + return 0x10030; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_aura_op_alloc# + * + * NPA Aura Allocate Operation Registers These registers are used to + * allocate one or two pointers from a given aura's pool. A 64-bit atomic + * load-and-add to NPA_LF_AURA_OP_ALLOC(0) allocates a single pointer. A + * 128-bit atomic CASP operation to NPA_LF_AURA_OP_ALLOC(0..1) allocates + * two pointers. The atomic write data format is NPA_AURA_OP_WDATA_S. For + * CASP, the first SWAP word in the write data contains + * NPA_AURA_OP_WDATA_S and the remaining write data words are ignored. + * All other accesses to this register (e.g. reads and writes) are + * RAZ/WI. RSL accesses to this register are RAZ/WI. + */ +union npa_lf_aura_op_allocx { + u64 u; + struct npa_lf_aura_op_allocx_s { + u64 addr : 64; + } s; + /* struct npa_lf_aura_op_allocx_s cn; */ +}; + +static inline u64 NPA_LF_AURA_OP_ALLOCX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_AURA_OP_ALLOCX(u64 a) +{ + return 0x10 + 8 * a; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_aura_op_cnt + * + * NPA LF Aura Count Register A 64-bit atomic load-and-add to this + * register returns a given aura's count. A write sets or adds the aura's + * count. A read is RAZ. RSL accesses to this register are RAZ/WI. + */ +union npa_lf_aura_op_cnt { + u64 u; + struct npa_lf_aura_op_cnt_s { + u64 count : 36; + u64 reserved_36_41 : 6; + u64 op_err : 1; + u64 cnt_add : 1; + u64 aura : 20; + } s; + /* struct npa_lf_aura_op_cnt_s cn; */ +}; + +static inline u64 NPA_LF_AURA_OP_CNT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_AURA_OP_CNT(void) +{ + return 0x30; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_aura_op_free0 + * + * NPA LF Aura Free Operation Register 0 A 128-bit write (STP) to + * NPA_LF_AURA_OP_FREE0 and NPA_LF_AURA_OP_FREE1 frees a pointer into a + * given aura's pool. All other accesses to these registers (e.g. reads + * and 64-bit writes) are RAZ/WI. RSL accesses to this register are + * RAZ/WI. + */ +union npa_lf_aura_op_free0 { + u64 u; + struct npa_lf_aura_op_free0_s { + u64 addr : 64; + } s; + /* struct npa_lf_aura_op_free0_s cn; */ +}; + +static inline u64 NPA_LF_AURA_OP_FREE0(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_AURA_OP_FREE0(void) +{ + return 0x20; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_aura_op_free1 + * + * NPA LF Aura Free Operation Register 1 See NPA_LF_AURA_OP_FREE0. RSL + * accesses to this register are RAZ/WI. + */ +union npa_lf_aura_op_free1 { + u64 u; + struct npa_lf_aura_op_free1_s { + u64 aura : 20; + u64 reserved_20_62 : 43; + u64 fabs : 1; + } s; + /* struct npa_lf_aura_op_free1_s cn; */ +}; + +static inline u64 NPA_LF_AURA_OP_FREE1(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_AURA_OP_FREE1(void) +{ + return 0x28; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_aura_op_int + * + * NPA LF Aura Interrupt Operation Register A 64-bit atomic load-and-add + * to this register reads + * NPA_AURA_HW_S[ERR_INT,ERR_INT_ENA,THRESH_INT,THRESH_INT_ENA]. A write + * optionally sets or clears these fields. A read is RAZ. RSL accesses + * to this register are RAZ/WI. + */ +union npa_lf_aura_op_int { + u64 u; + struct npa_lf_aura_op_int_s { + u64 err_int : 8; + u64 err_int_ena : 8; + u64 thresh_int : 1; + u64 thresh_int_ena : 1; + u64 reserved_18_41 : 24; + u64 op_err : 1; + u64 setop : 1; + u64 aura : 20; + } s; + /* struct npa_lf_aura_op_int_s cn; */ +}; + +static inline u64 NPA_LF_AURA_OP_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_AURA_OP_INT(void) +{ + return 0x60; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_aura_op_limit + * + * NPA LF Aura Allocation Limit Register A 64-bit atomic load-and-add to + * this register returns a given aura's limit. A write sets the aura's + * limit. A read is RAZ. RSL accesses to this register are RAZ/WI. + */ +union npa_lf_aura_op_limit { + u64 u; + struct npa_lf_aura_op_limit_s { + u64 limit : 36; + u64 reserved_36_41 : 6; + u64 op_err : 1; + u64 reserved_43 : 1; + u64 aura : 20; + } s; + /* struct npa_lf_aura_op_limit_s cn; */ +}; + +static inline u64 NPA_LF_AURA_OP_LIMIT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_AURA_OP_LIMIT(void) +{ + return 0x50; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_aura_op_thresh + * + * NPA LF Aura Threshold Operation Register A 64-bit atomic load-and-add + * to this register reads NPA_AURA_HW_S[THRESH_UP,THRESH]. A write to the + * register writes NPA_AURA_HW_S[THRESH_UP,THRESH] and recomputes + * NPA_AURA_HW_S[THRESH_INT]. A read is RAZ. RSL accesses to this + * register are RAZ/WI. + */ +union npa_lf_aura_op_thresh { + u64 u; + struct npa_lf_aura_op_thresh_s { + u64 thresh : 36; + u64 reserved_36_41 : 6; + u64 op_err : 1; + u64 thresh_up : 1; + u64 aura : 20; + } s; + /* struct npa_lf_aura_op_thresh_s cn; */ +}; + +static inline u64 NPA_LF_AURA_OP_THRESH(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_AURA_OP_THRESH(void) +{ + return 0x70; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_err_int + * + * NPA LF Error Interrupt Register + */ +union npa_lf_err_int { + u64 u; + struct npa_lf_err_int_s { + u64 aura_dis : 1; + u64 aura_oor : 1; + u64 reserved_2 : 1; + u64 rmt_req_oor : 1; + u64 reserved_4_11 : 8; + u64 aura_fault : 1; + u64 pool_fault : 1; + u64 stack_fault : 1; + u64 qint_fault : 1; + u64 reserved_16_63 : 48; + } s; + /* struct npa_lf_err_int_s cn; */ +}; + +static inline u64 NPA_LF_ERR_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_ERR_INT(void) +{ + return 0x200; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_err_int_ena_w1c + * + * NPA LF Error Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union npa_lf_err_int_ena_w1c { + u64 u; + struct npa_lf_err_int_ena_w1c_s { + u64 aura_dis : 1; + u64 aura_oor : 1; + u64 reserved_2 : 1; + u64 rmt_req_oor : 1; + u64 reserved_4_11 : 8; + u64 aura_fault : 1; + u64 pool_fault : 1; + u64 stack_fault : 1; + u64 qint_fault : 1; + u64 reserved_16_63 : 48; + } s; + /* struct npa_lf_err_int_ena_w1c_s cn; */ +}; + +static inline u64 NPA_LF_ERR_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_ERR_INT_ENA_W1C(void) +{ + return 0x210; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_err_int_ena_w1s + * + * NPA LF Error Interrupt Enable Set Register This register sets + * interrupt enable bits. + */ +union npa_lf_err_int_ena_w1s { + u64 u; + struct npa_lf_err_int_ena_w1s_s { + u64 aura_dis : 1; + u64 aura_oor : 1; + u64 reserved_2 : 1; + u64 rmt_req_oor : 1; + u64 reserved_4_11 : 8; + u64 aura_fault : 1; + u64 pool_fault : 1; + u64 stack_fault : 1; + u64 qint_fault : 1; + u64 reserved_16_63 : 48; + } s; + /* struct npa_lf_err_int_ena_w1s_s cn; */ +}; + +static inline u64 NPA_LF_ERR_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_ERR_INT_ENA_W1S(void) +{ + return 0x218; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_err_int_w1s + * + * NPA LF Error Interrupt Set Register This register sets interrupt bits. + */ +union npa_lf_err_int_w1s { + u64 u; + struct npa_lf_err_int_w1s_s { + u64 aura_dis : 1; + u64 aura_oor : 1; + u64 reserved_2 : 1; + u64 rmt_req_oor : 1; + u64 reserved_4_11 : 8; + u64 aura_fault : 1; + u64 pool_fault : 1; + u64 stack_fault : 1; + u64 qint_fault : 1; + u64 reserved_16_63 : 48; + } s; + /* struct npa_lf_err_int_w1s_s cn; */ +}; + +static inline u64 NPA_LF_ERR_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_ERR_INT_W1S(void) +{ + return 0x208; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_pool_op_available + * + * NPA LF Pool Available Count Operation Register A 64-bit atomic load- + * and-add to this register returns a given pool's free pointer count. + * Reads and writes are RAZ/WI. RSL accesses to this register are + * RAZ/WI. + */ +union npa_lf_pool_op_available { + u64 u; + struct npa_lf_pool_op_available_s { + u64 count : 36; + u64 reserved_36_41 : 6; + u64 op_err : 1; + u64 reserved_43 : 1; + u64 aura : 20; + } s; + /* struct npa_lf_pool_op_available_s cn; */ +}; + +static inline u64 NPA_LF_POOL_OP_AVAILABLE(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_POOL_OP_AVAILABLE(void) +{ + return 0x110; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_pool_op_int + * + * NPA LF Pool Interrupt Operation Register A 64-bit atomic load-and-add + * to this register reads + * NPA_POOL_S[ERR_INT,ERR_INT_ENA,THRESH_INT,THRESH_INT_ENA]. A write + * optionally sets or clears these fields. A read is RAZ. RSL accesses + * to this register are RAZ/WI. + */ +union npa_lf_pool_op_int { + u64 u; + struct npa_lf_pool_op_int_s { + u64 err_int : 8; + u64 err_int_ena : 8; + u64 thresh_int : 1; + u64 thresh_int_ena : 1; + u64 reserved_18_41 : 24; + u64 op_err : 1; + u64 setop : 1; + u64 aura : 20; + } s; + /* struct npa_lf_pool_op_int_s cn; */ +}; + +static inline u64 NPA_LF_POOL_OP_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_POOL_OP_INT(void) +{ + return 0x160; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_pool_op_pc + * + * NPA LF Pool Performance Count Register A 64-bit atomic load-and-add to + * this register reads NPA_POOL_S[OP_PC] from a given aura's pool. The + * aura is selected by the atomic write data, whose format is + * NPA_AURA_OP_WDATA_S. Reads and writes are RAZ/WI. RSL accesses to + * this register are RAZ/WI. + */ +union npa_lf_pool_op_pc { + u64 u; + struct npa_lf_pool_op_pc_s { + u64 op_pc : 48; + u64 op_err : 1; + u64 reserved_49_63 : 15; + } s; + /* struct npa_lf_pool_op_pc_s cn; */ +}; + +static inline u64 NPA_LF_POOL_OP_PC(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_POOL_OP_PC(void) +{ + return 0x100; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_pool_op_ptr_end0 + * + * NPA LF Pool Pointer End Operation Register 0 A 128-bit write (STP) to + * the NPA_LF_POOL_OP_PTR_END0 and NPA_LF_POOL_OP_PTR_END1 registers + * writes to a given pool's pointer end value. All other accesses to + * these registers (e.g. reads and 64-bit writes) are RAZ/WI. RSL + * accesses to this register are RAZ/WI. + */ +union npa_lf_pool_op_ptr_end0 { + u64 u; + struct npa_lf_pool_op_ptr_end0_s { + u64 ptr_end : 64; + } s; + /* struct npa_lf_pool_op_ptr_end0_s cn; */ +}; + +static inline u64 NPA_LF_POOL_OP_PTR_END0(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_POOL_OP_PTR_END0(void) +{ + return 0x130; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_pool_op_ptr_end1 + * + * NPA LF Pool Pointer End Operation Register 1 See + * NPA_LF_POOL_OP_PTR_END0. RSL accesses to this register are RAZ/WI. + */ +union npa_lf_pool_op_ptr_end1 { + u64 u; + struct npa_lf_pool_op_ptr_end1_s { + u64 aura : 20; + u64 reserved_20_63 : 44; + } s; + /* struct npa_lf_pool_op_ptr_end1_s cn; */ +}; + +static inline u64 NPA_LF_POOL_OP_PTR_END1(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_POOL_OP_PTR_END1(void) +{ + return 0x138; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_pool_op_ptr_start0 + * + * NPA LF Pool Pointer Start Operation Register 0 A 128-bit write (STP) + * to the NPA_LF_POOL_OP_PTR_START0 and NPA_LF_POOL_OP_PTR_START1 + * registers writes to a given pool's pointer start value. All other + * accesses to these registers (e.g. reads and 64-bit writes) are RAZ/WI. + * RSL accesses to this register are RAZ/WI. + */ +union npa_lf_pool_op_ptr_start0 { + u64 u; + struct npa_lf_pool_op_ptr_start0_s { + u64 ptr_start : 64; + } s; + /* struct npa_lf_pool_op_ptr_start0_s cn; */ +}; + +static inline u64 NPA_LF_POOL_OP_PTR_START0(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_POOL_OP_PTR_START0(void) +{ + return 0x120; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_pool_op_ptr_start1 + * + * NPA LF Pool Pointer Start Operation Register 1 See + * NPA_LF_POOL_OP_PTR_START0. RSL accesses to this register are RAZ/WI. + */ +union npa_lf_pool_op_ptr_start1 { + u64 u; + struct npa_lf_pool_op_ptr_start1_s { + u64 aura : 20; + u64 reserved_20_63 : 44; + } s; + /* struct npa_lf_pool_op_ptr_start1_s cn; */ +}; + +static inline u64 NPA_LF_POOL_OP_PTR_START1(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_POOL_OP_PTR_START1(void) +{ + return 0x128; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_pool_op_thresh + * + * NPA LF Pool Threshold Operation Register A 64-bit atomic load-and-add + * to this register reads NPA_POOL_S[THRESH_UP,THRESH]. A write to the + * register writes NPA_POOL_S[THRESH_UP,THRESH]. A read is RAZ. RSL + * accesses to this register are RAZ/WI. + */ +union npa_lf_pool_op_thresh { + u64 u; + struct npa_lf_pool_op_thresh_s { + u64 thresh : 36; + u64 reserved_36_41 : 6; + u64 op_err : 1; + u64 thresh_up : 1; + u64 aura : 20; + } s; + /* struct npa_lf_pool_op_thresh_s cn; */ +}; + +static inline u64 NPA_LF_POOL_OP_THRESH(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_POOL_OP_THRESH(void) +{ + return 0x170; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_qint#_cnt + * + * NPA LF Queue Interrupt Count Registers + */ +union npa_lf_qintx_cnt { + u64 u; + struct npa_lf_qintx_cnt_s { + u64 count : 22; + u64 reserved_22_63 : 42; + } s; + /* struct npa_lf_qintx_cnt_s cn; */ +}; + +static inline u64 NPA_LF_QINTX_CNT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_QINTX_CNT(u64 a) +{ + return 0x300 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_qint#_ena_w1c + * + * NPA LF Queue Interrupt Enable Clear Registers This register clears + * interrupt enable bits. + */ +union npa_lf_qintx_ena_w1c { + u64 u; + struct npa_lf_qintx_ena_w1c_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_lf_qintx_ena_w1c_s cn; */ +}; + +static inline u64 NPA_LF_QINTX_ENA_W1C(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_QINTX_ENA_W1C(u64 a) +{ + return 0x330 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_qint#_ena_w1s + * + * NPA LF Queue Interrupt Enable Set Registers This register sets + * interrupt enable bits. + */ +union npa_lf_qintx_ena_w1s { + u64 u; + struct npa_lf_qintx_ena_w1s_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_lf_qintx_ena_w1s_s cn; */ +}; + +static inline u64 NPA_LF_QINTX_ENA_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_QINTX_ENA_W1S(u64 a) +{ + return 0x320 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_qint#_int + * + * NPA LF Queue Interrupt Registers + */ +union npa_lf_qintx_int { + u64 u; + struct npa_lf_qintx_int_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_lf_qintx_int_s cn; */ +}; + +static inline u64 NPA_LF_QINTX_INT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_QINTX_INT(u64 a) +{ + return 0x310 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_qint#_int_w1s + * + * INTERNAL: NPA LF Queue Interrupt Set Registers + */ +union npa_lf_qintx_int_w1s { + u64 u; + struct npa_lf_qintx_int_w1s_s { + u64 intr : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npa_lf_qintx_int_w1s_s cn; */ +}; + +static inline u64 NPA_LF_QINTX_INT_W1S(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_QINTX_INT_W1S(u64 a) +{ + return 0x318 + 0x1000 * a; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_ras + * + * NPA LF RAS Interrupt Register + */ +union npa_lf_ras { + u64 u; + struct npa_lf_ras_s { + u64 aura_poison : 1; + u64 pool_poison : 1; + u64 stack_poison : 1; + u64 qint_poison : 1; + u64 reserved_4_63 : 60; + } s; + /* struct npa_lf_ras_s cn; */ +}; + +static inline u64 NPA_LF_RAS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_RAS(void) +{ + return 0x220; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_ras_ena_w1c + * + * NPA LF RAS Interrupt Enable Clear Register This register clears + * interrupt enable bits. + */ +union npa_lf_ras_ena_w1c { + u64 u; + struct npa_lf_ras_ena_w1c_s { + u64 aura_poison : 1; + u64 pool_poison : 1; + u64 stack_poison : 1; + u64 qint_poison : 1; + u64 reserved_4_63 : 60; + } s; + /* struct npa_lf_ras_ena_w1c_s cn; */ +}; + +static inline u64 NPA_LF_RAS_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_RAS_ENA_W1C(void) +{ + return 0x230; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_ras_ena_w1s + * + * NPA LF RAS Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union npa_lf_ras_ena_w1s { + u64 u; + struct npa_lf_ras_ena_w1s_s { + u64 aura_poison : 1; + u64 pool_poison : 1; + u64 stack_poison : 1; + u64 qint_poison : 1; + u64 reserved_4_63 : 60; + } s; + /* struct npa_lf_ras_ena_w1s_s cn; */ +}; + +static inline u64 NPA_LF_RAS_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_RAS_ENA_W1S(void) +{ + return 0x238; +} + +/** + * Register (RVU_PFVF_BAR2) npa_lf_ras_w1s + * + * NPA LF RAS Interrupt Set Register This register sets interrupt bits. + */ +union npa_lf_ras_w1s { + u64 u; + struct npa_lf_ras_w1s_s { + u64 aura_poison : 1; + u64 pool_poison : 1; + u64 stack_poison : 1; + u64 qint_poison : 1; + u64 reserved_4_63 : 60; + } s; + /* struct npa_lf_ras_w1s_s cn; */ +}; + +static inline u64 NPA_LF_RAS_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_LF_RAS_W1S(void) +{ + return 0x228; +} + +/** + * Register (RVU_PF_BAR0) npa_priv_af_int_cfg + * + * NPA Privileged AF Interrupt Configuration Register + */ +union npa_priv_af_int_cfg { + u64 u; + struct npa_priv_af_int_cfg_s { + u64 msix_offset : 11; + u64 reserved_11 : 1; + u64 msix_size : 8; + u64 reserved_20_63 : 44; + } s; + /* struct npa_priv_af_int_cfg_s cn; */ +}; + +static inline u64 NPA_PRIV_AF_INT_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_PRIV_AF_INT_CFG(void) +{ + return 0x10000; +} + +/** + * Register (RVU_PF_BAR0) npa_priv_lf#_cfg + * + * NPA Privileged Local Function Configuration Registers These registers + * allow each NPA local function (LF) to be provisioned to a VF/PF slot + * for RVU. See also NPA_AF_RVU_LF_CFG_DEBUG. Software should read this + * register after write to ensure that the LF is mapped to [PF_FUNC] + * before issuing transactions to the mapped PF and function. [SLOT] + * must be zero. Internal: Hardware ignores [SLOT] and always assumes + * 0x0. + */ +union npa_priv_lfx_cfg { + u64 u; + struct npa_priv_lfx_cfg_s { + u64 slot : 8; + u64 pf_func : 16; + u64 reserved_24_62 : 39; + u64 ena : 1; + } s; + /* struct npa_priv_lfx_cfg_s cn; */ +}; + +static inline u64 NPA_PRIV_LFX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_PRIV_LFX_CFG(u64 a) +{ + return 0x10010 + 0x100 * a; +} + +/** + * Register (RVU_PF_BAR0) npa_priv_lf#_int_cfg + * + * NPA Privileged LF Interrupt Configuration Registers + */ +union npa_priv_lfx_int_cfg { + u64 u; + struct npa_priv_lfx_int_cfg_s { + u64 msix_offset : 11; + u64 reserved_11 : 1; + u64 msix_size : 8; + u64 reserved_20_63 : 44; + } s; + /* struct npa_priv_lfx_int_cfg_s cn; */ +}; + +static inline u64 NPA_PRIV_LFX_INT_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPA_PRIV_LFX_INT_CFG(u64 a) +{ + return 0x10020 + 0x100 * a; +} + +#endif /* __CSRS_NPA_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx2/csrs/csrs-npc.h b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-npc.h new file mode 100644 index 0000000000..c1c4baabe7 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-npc.h @@ -0,0 +1,1629 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Marvell International Ltd. + * + * https://spdx.org/licenses + */ +#ifndef __CSRS_NPC_H__ +#define __CSRS_NPC_H__ + +/** + * @file + * + * Configuration and status register (CSR) address and type definitions for + * NPC. + * + * This file is auto generated. Do not edit. + * + */ + +/** + * Enumeration npc_errlev_e + * + * NPC Error Level Enumeration Enumerates the lowest protocol layer + * containing an error. + */ +#define NPC_ERRLEV_E_LA (1) +#define NPC_ERRLEV_E_LB (2) +#define NPC_ERRLEV_E_LC (3) +#define NPC_ERRLEV_E_LD (4) +#define NPC_ERRLEV_E_LE (5) +#define NPC_ERRLEV_E_LF (6) +#define NPC_ERRLEV_E_LG (7) +#define NPC_ERRLEV_E_LH (8) +#define NPC_ERRLEV_E_NIX (0xf) +#define NPC_ERRLEV_E_RX(a) (0 + (a)) +#define NPC_ERRLEV_E_RE (0) + +/** + * Enumeration npc_intf_e + * + * NPC Interface Enumeration Enumerates the NPC interfaces. + */ +#define NPC_INTF_E_NIXX_RX(a) (0 + 2 * (a)) +#define NPC_INTF_E_NIXX_TX(a) (1 + 2 * (a)) + +/** + * Enumeration npc_lid_e + * + * NPC Layer ID Enumeration Enumerates layers parsed by NPC. + */ +#define NPC_LID_E_LA (0) +#define NPC_LID_E_LB (1) +#define NPC_LID_E_LC (2) +#define NPC_LID_E_LD (3) +#define NPC_LID_E_LE (4) +#define NPC_LID_E_LF (5) +#define NPC_LID_E_LG (6) +#define NPC_LID_E_LH (7) + +/** + * Enumeration npc_lkupop_e + * + * NPC Lookup Operation Enumeration Enumerates the lookup operation for + * NPC_AF_LKUP_CTL[OP]. + */ +#define NPC_LKUPOP_E_KEY (1) +#define NPC_LKUPOP_E_PKT (0) + +/** + * Enumeration npc_mcamkeyw_e + * + * NPC MCAM Search Key Width Enumeration + */ +#define NPC_MCAMKEYW_E_X1 (0) +#define NPC_MCAMKEYW_E_X2 (1) +#define NPC_MCAMKEYW_E_X4 (2) + +/** + * Structure npc_layer_info_s + * + * NPC Layer Parse Information Structure This structure specifies the + * format of NPC_RESULT_S[LA,LB,...,LH]. + */ +union npc_layer_info_s { + u32 u; + struct npc_layer_info_s_s { + u32 lptr : 8; + u32 flags : 8; + u32 ltype : 4; + u32 reserved_20_31 : 12; + } s; + /* struct npc_layer_info_s_s cn; */ +}; + +/** + * Structure npc_layer_kex_s + * + * NPC Layer MCAM Search Key Extract Structure This structure specifies + * the format of each of the NPC_PARSE_KEX_S[LA,LB,...,LH] fields. It + * contains the subset of NPC_LAYER_INFO_S fields that can be included in + * the MCAM search key. See NPC_PARSE_KEX_S and NPC_AF_INTF()_KEX_CFG. + */ +union npc_layer_kex_s { + u32 u; + struct npc_layer_kex_s_s { + u32 flags : 8; + u32 ltype : 4; + u32 reserved_12_31 : 20; + } s; + /* struct npc_layer_kex_s_s cn; */ +}; + +/** + * Structure npc_mcam_key_x1_s + * + * NPC MCAM Search Key X1 Structure This structure specifies the MCAM + * search key format used by an interface when + * NPC_AF_INTF()_KEX_CFG[KEYW] = NPC_MCAMKEYW_E::X1. + */ +union npc_mcam_key_x1_s { + u64 u[3]; + struct npc_mcam_key_x1_s_s { + u64 intf : 2; + u64 reserved_2_63 : 62; + u64 kw0 : 64; + u64 kw1 : 48; + u64 reserved_176_191 : 16; + } s; + /* struct npc_mcam_key_x1_s_s cn; */ +}; + +/** + * Structure npc_mcam_key_x2_s + * + * NPC MCAM Search Key X2 Structure This structure specifies the MCAM + * search key format used by an interface when + * NPC_AF_INTF()_KEX_CFG[KEYW] = NPC_MCAMKEYW_E::X2. + */ +union npc_mcam_key_x2_s { + u64 u[5]; + struct npc_mcam_key_x2_s_s { + u64 intf : 2; + u64 reserved_2_63 : 62; + u64 kw0 : 64; + u64 kw1 : 64; + u64 kw2 : 64; + u64 kw3 : 32; + u64 reserved_288_319 : 32; + } s; + /* struct npc_mcam_key_x2_s_s cn; */ +}; + +/** + * Structure npc_mcam_key_x4_s + * + * NPC MCAM Search Key X4 Structure This structure specifies the MCAM + * search key format used by an interface when + * NPC_AF_INTF()_KEX_CFG[KEYW] = NPC_MCAMKEYW_E::X4. + */ +union npc_mcam_key_x4_s { + u64 u[8]; + struct npc_mcam_key_x4_s_s { + u64 intf : 2; + u64 reserved_2_63 : 62; + u64 kw0 : 64; + u64 kw1 : 64; + u64 kw2 : 64; + u64 kw3 : 64; + u64 kw4 : 64; + u64 kw5 : 64; + u64 kw6 : 64; + } s; + /* struct npc_mcam_key_x4_s_s cn; */ +}; + +/** + * Structure npc_parse_kex_s + * + * NPC Parse Key Extract Structure This structure contains the subset of + * NPC_RESULT_S fields that can be included in the MCAM search key. See + * NPC_AF_INTF()_KEX_CFG. + */ +union npc_parse_kex_s { + u64 u[2]; + struct npc_parse_kex_s_s { + u64 chan : 12; + u64 errlev : 4; + u64 errcode : 8; + u64 l2m : 1; + u64 l2b : 1; + u64 l3m : 1; + u64 l3b : 1; + u64 la : 12; + u64 lb : 12; + u64 lc : 12; + u64 ld : 12; + u64 le : 12; + u64 lf : 12; + u64 lg : 12; + u64 lh : 12; + u64 reserved_124_127 : 4; + } s; + /* struct npc_parse_kex_s_s cn; */ +}; + +/** + * Structure npc_result_s + * + * NPC Result Structure This structure contains a packet's parse and flow + * identification information. + */ +union npc_result_s { + u64 u[6]; + struct npc_result_s_s { + u64 intf : 2; + u64 pkind : 6; + u64 chan : 12; + u64 errlev : 4; + u64 errcode : 8; + u64 l2m : 1; + u64 l2b : 1; + u64 l3m : 1; + u64 l3b : 1; + u64 eoh_ptr : 8; + u64 reserved_44_63 : 20; + u64 action : 64; + u64 vtag_action : 64; + u64 la : 20; + u64 lb : 20; + u64 lc : 20; + u64 reserved_252_255 : 4; + u64 ld : 20; + u64 le : 20; + u64 lf : 20; + u64 reserved_316_319 : 4; + u64 lg : 20; + u64 lh : 20; + u64 reserved_360_383 : 24; + } s; + /* struct npc_result_s_s cn; */ +}; + +/** + * Register (RVU_PF_BAR0) npc_af_active_pc + * + * NPC Interrupt-Timer Configuration Register + */ +union npc_af_active_pc { + u64 u; + struct npc_af_active_pc_s { + u64 active_pc : 64; + } s; + /* struct npc_af_active_pc_s cn; */ +}; + +static inline u64 NPC_AF_ACTIVE_PC(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_ACTIVE_PC(void) +{ + return 0x10; +} + +/** + * Register (RVU_PF_BAR0) npc_af_blk_rst + * + * NPC AF Block Reset Register + */ +union npc_af_blk_rst { + u64 u; + struct npc_af_blk_rst_s { + u64 rst : 1; + u64 reserved_1_62 : 62; + u64 busy : 1; + } s; + /* struct npc_af_blk_rst_s cn; */ +}; + +static inline u64 NPC_AF_BLK_RST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_BLK_RST(void) +{ + return 0x40; +} + +/** + * Register (RVU_PF_BAR0) npc_af_cfg + * + * NPC AF General Configuration Register + */ +union npc_af_cfg { + u64 u; + struct npc_af_cfg_s { + u64 reserved_0_1 : 2; + u64 cclk_force : 1; + u64 force_intf_clk_en : 1; + u64 reserved_4_63 : 60; + } s; + /* struct npc_af_cfg_s cn; */ +}; + +static inline u64 NPC_AF_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_CFG(void) +{ + return 0; +} + +/** + * Register (RVU_PF_BAR0) npc_af_const + * + * NPC AF Constants Register This register contains constants for + * software discovery. + */ +union npc_af_const { + u64 u; + struct npc_af_const_s { + u64 intfs : 4; + u64 lids : 4; + u64 kpus : 5; + u64 reserved_13_15 : 3; + u64 mcam_bank_width : 10; + u64 reserved_26_27 : 2; + u64 mcam_bank_depth : 16; + u64 mcam_banks : 4; + u64 match_stats : 16; + } s; + /* struct npc_af_const_s cn; */ +}; + +static inline u64 NPC_AF_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_CONST(void) +{ + return 0x20; +} + +/** + * Register (RVU_PF_BAR0) npc_af_const1 + * + * NPC AF Constants 1 Register This register contains constants for + * software discovery. + */ +union npc_af_const1 { + u64 u; + struct npc_af_const1_s { + u64 kpu_entries : 12; + u64 pkinds : 8; + u64 cpi_size : 16; + u64 reserved_36_63 : 28; + } s; + /* struct npc_af_const1_s cn; */ +}; + +static inline u64 NPC_AF_CONST1(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_CONST1(void) +{ + return 0x30; +} + +/** + * Register (RVU_PF_BAR0) npc_af_cpi#_cfg + * + * NPC AF Channel Parse Index Table Registers + */ +union npc_af_cpix_cfg { + u64 u; + struct npc_af_cpix_cfg_s { + u64 padd : 4; + u64 reserved_4_63 : 60; + } s; + /* struct npc_af_cpix_cfg_s cn; */ +}; + +static inline u64 NPC_AF_CPIX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_CPIX_CFG(u64 a) +{ + return 0x200000 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_dbg_ctl + * + * NPC AF Debug Control Register This register controls the capture of + * debug information in NPC_AF_KPU()_DBG, NPC_AF_MCAM_DBG, + * NPC_AF_DBG_DATA() and NPC_AF_DBG_RESULT(). + */ +union npc_af_dbg_ctl { + u64 u; + struct npc_af_dbg_ctl_s { + u64 continuous : 1; + u64 lkup_dbg : 1; + u64 intf_dbg : 4; + u64 reserved_6_63 : 58; + } s; + /* struct npc_af_dbg_ctl_s cn; */ +}; + +static inline u64 NPC_AF_DBG_CTL(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_DBG_CTL(void) +{ + return 0x3000000; +} + +/** + * Register (RVU_PF_BAR0) npc_af_dbg_data# + * + * NPC AF Debug Data Registers These registers contain the packet header + * data of the last packet/lookup whose debug information is captured by + * NPC_AF_DBG_CTL[INTF_DBG,LKUP_DBG]. + */ +union npc_af_dbg_datax { + u64 u; + struct npc_af_dbg_datax_s { + u64 data : 64; + } s; + /* struct npc_af_dbg_datax_s cn; */ +}; + +static inline u64 NPC_AF_DBG_DATAX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_DBG_DATAX(u64 a) +{ + return 0x3001400 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_dbg_result# + * + * NPC AF Debug Result Registers These registers contain the result data + * of the last packet/lookup whose debug information is captured by + * NPC_AF_DBG_CTL[INTF_DBG,LKUP_DBG]. Internal: FIXME - add note about + * coherency of data in continuous packet capture mode. + */ +union npc_af_dbg_resultx { + u64 u; + struct npc_af_dbg_resultx_s { + u64 data : 64; + } s; + /* struct npc_af_dbg_resultx_s cn; */ +}; + +static inline u64 NPC_AF_DBG_RESULTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_DBG_RESULTX(u64 a) +{ + return 0x3001800 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_dbg_status + * + * NPC AF Debug Status Register + */ +union npc_af_dbg_status { + u64 u; + struct npc_af_dbg_status_s { + u64 done : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npc_af_dbg_status_s cn; */ +}; + +static inline u64 NPC_AF_DBG_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_DBG_STATUS(void) +{ + return 0x3000010; +} + +/** + * Register (RVU_PF_BAR0) npc_af_dv_fc_scratch + * + * INTERNAL: NPC AF Scratch Register Internal: This register is for + * internal DV purpose. + */ +union npc_af_dv_fc_scratch { + u64 u; + struct npc_af_dv_fc_scratch_s { + u64 it : 64; + } s; + /* struct npc_af_dv_fc_scratch_s cn; */ +}; + +static inline u64 NPC_AF_DV_FC_SCRATCH(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_DV_FC_SCRATCH(void) +{ + return 0x60; +} + +/** + * Register (RVU_PF_BAR0) npc_af_eco0 + * + * INTERNAL: ECO 0 Register + */ +union npc_af_eco0 { + u64 u; + struct npc_af_eco0_s { + u64 eco_rw : 32; + u64 reserved_32_63 : 32; + } s; + /* struct npc_af_eco0_s cn; */ +}; + +static inline u64 NPC_AF_ECO0(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_ECO0(void) +{ + return 0x200; +} + +/** + * Register (RVU_PF_BAR0) npc_af_ikpu_err_ctl + * + * NPC AF Initial KPU Error Control Registers Similar to + * NPC_AF_KPU()_ERR_CTL, but specifies values captured in + * NPC_RESULT_S[ERRLEV,ERRCODE] for errors detected by the PKIND-based + * initial actions from NPC_AF_PKIND()_ACTION0 and + * NPC_AF_PKIND()_ACTION1. [DP_OFFSET_ERRCODE] from this register is + * never used. + */ +union npc_af_ikpu_err_ctl { + u64 u; + struct npc_af_ikpu_err_ctl_s { + u64 errlev : 4; + u64 dp_offset_errcode : 8; + u64 ptr_advance_errcode : 8; + u64 var_len_offset_errcode : 8; + u64 reserved_28_63 : 36; + } s; + /* struct npc_af_ikpu_err_ctl_s cn; */ +}; + +static inline u64 NPC_AF_IKPU_ERR_CTL(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_IKPU_ERR_CTL(void) +{ + return 0x3000080; +} + +/** + * Register (RVU_PF_BAR0) npc_af_intf#_kex_cfg + * + * NPC AF Interface Key Extract Configuration Registers + */ +union npc_af_intfx_kex_cfg { + u64 u; + struct npc_af_intfx_kex_cfg_s { + u64 parse_nibble_ena : 31; + u64 reserved_31 : 1; + u64 keyw : 3; + u64 reserved_35_63 : 29; + } s; + /* struct npc_af_intfx_kex_cfg_s cn; */ +}; + +static inline u64 NPC_AF_INTFX_KEX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_INTFX_KEX_CFG(u64 a) +{ + return 0x1010 + 0x100 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_intf#_ldata#_flags#_cfg + * + * NPC AF Interface Layer Data Flags Configuration Registers These + * registers control the extraction of layer data (LDATA) into the MCAM + * search key for each interface based on the FLAGS<3:0> bits of two + * layers selected by NPC_AF_KEX_LDATA()_FLAGS_CFG. + */ +union npc_af_intfx_ldatax_flagsx_cfg { + u64 u; + struct npc_af_intfx_ldatax_flagsx_cfg_s { + u64 key_offset : 6; + u64 reserved_6 : 1; + u64 ena : 1; + u64 hdr_offset : 8; + u64 bytesm1 : 4; + u64 reserved_20_63 : 44; + } s; + /* struct npc_af_intfx_ldatax_flagsx_cfg_s cn; */ +}; + +static inline u64 NPC_AF_INTFX_LDATAX_FLAGSX_CFG(u64 a, u64 b, u64 c) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_INTFX_LDATAX_FLAGSX_CFG(u64 a, u64 b, u64 c) +{ + return 0x980000 + 0x10000 * a + 0x1000 * b + 8 * c; +} + +/** + * Register (RVU_PF_BAR0) npc_af_intf#_lid#_lt#_ld#_cfg + * + * NPC AF Interface Layer Data Extract Configuration Registers These + * registers control the extraction of layer data (LDATA) into the MCAM + * search key for each interface. Up to two LDATA fields can be extracted + * per layer (LID(0..7) indexed by NPC_LID_E), with up to 16 bytes per + * LDATA field. For each layer, the corresponding NPC_LAYER_INFO_S[LTYPE] + * value in NPC_RESULT_S is used as the LTYPE(0..15) index and select the + * associated LDATA(0..1) registers. NPC_LAYER_INFO_S[LTYPE]=0x0 means + * the corresponding layer not parsed (invalid), so software should keep + * NPC_AF_INTF()_LID()_LT(0)_LD()_CFG[ENA] clear to disable extraction + * when LTYPE is zero. + */ +union npc_af_intfx_lidx_ltx_ldx_cfg { + u64 u; + struct npc_af_intfx_lidx_ltx_ldx_cfg_s { + u64 key_offset : 6; + u64 flags_ena : 1; + u64 ena : 1; + u64 hdr_offset : 8; + u64 bytesm1 : 4; + u64 reserved_20_63 : 44; + } s; + /* struct npc_af_intfx_lidx_ltx_ldx_cfg_s cn; */ +}; + +static inline u64 NPC_AF_INTFX_LIDX_LTX_LDX_CFG(u64 a, u64 b, u64 c, u64 d) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_INTFX_LIDX_LTX_LDX_CFG(u64 a, u64 b, u64 c, u64 d) +{ + return 0x900000 + 0x10000 * a + 0x1000 * b + 0x20 * c + 8 * d; +} + +/** + * Register (RVU_PF_BAR0) npc_af_intf#_miss_act + * + * NPC AF Interface MCAM Miss Action Data Registers When a combination of + * NPC_AF_MCAME()_BANK()_CAM()_* and NPC_AF_MCAME()_BANK()_CFG[ENA] + * yields an MCAM miss for a packet, this register specifies the packet's + * match action captured in NPC_RESULT_S[ACTION]. + */ +union npc_af_intfx_miss_act { + u64 u; + struct npc_af_intfx_miss_act_s { + u64 action : 64; + } s; + /* struct npc_af_intfx_miss_act_s cn; */ +}; + +static inline u64 NPC_AF_INTFX_MISS_ACT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_INTFX_MISS_ACT(u64 a) +{ + return 0x1a00000 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_intf#_miss_stat_act + * + * NPC AF Interface MCAM Miss Stat Action Data Registers Used to + * optionally increment a NPC_AF_MATCH_STAT() counter when a packet + * misses an MCAM entry. + */ +union npc_af_intfx_miss_stat_act { + u64 u; + struct npc_af_intfx_miss_stat_act_s { + u64 stat_sel : 9; + u64 ena : 1; + u64 reserved_10_63 : 54; + } s; + /* struct npc_af_intfx_miss_stat_act_s cn; */ +}; + +static inline u64 NPC_AF_INTFX_MISS_STAT_ACT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_INTFX_MISS_STAT_ACT(u64 a) +{ + return 0x1880040 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_intf#_miss_tag_act + * + * NPC AF Interface MCAM Miss VTag Action Data Registers When a + * combination of NPC_AF_MCAME()_BANK()_CAM()_* and + * NPC_AF_MCAME()_BANK()_CFG[ENA] yields an MCAM miss for a packet, this + * register specifies the packet's match Vtag action captured in + * NPC_RESULT_S[VTAG_ACTION]. + */ +union npc_af_intfx_miss_tag_act { + u64 u; + struct npc_af_intfx_miss_tag_act_s { + u64 vtag_action : 64; + } s; + /* struct npc_af_intfx_miss_tag_act_s cn; */ +}; + +static inline u64 NPC_AF_INTFX_MISS_TAG_ACT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_INTFX_MISS_TAG_ACT(u64 a) +{ + return 0x1b00008 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_intf#_stat + * + * NPC AF Interface Statistics Registers Statistics per interface. Index + * enumerated by NPC_INTF_E. + */ +union npc_af_intfx_stat { + u64 u; + struct npc_af_intfx_stat_s { + u64 count : 48; + u64 reserved_48_63 : 16; + } s; + /* struct npc_af_intfx_stat_s cn; */ +}; + +static inline u64 NPC_AF_INTFX_STAT(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_INTFX_STAT(u64 a) +{ + return 0x2000800 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_kcam_scrub_ctl + * + * NPC AF KCAM Scrub Control Register + */ +union npc_af_kcam_scrub_ctl { + u64 u; + struct npc_af_kcam_scrub_ctl_s { + u64 ena : 1; + u64 reserved_1_7 : 7; + u64 lp_dis : 1; + u64 reserved_9_15 : 7; + u64 toth : 4; + u64 reserved_20_63 : 44; + } s; + /* struct npc_af_kcam_scrub_ctl_s cn; */ +}; + +static inline u64 NPC_AF_KCAM_SCRUB_CTL(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_KCAM_SCRUB_CTL(void) +{ + return 0xb0; +} + +/** + * Register (RVU_PF_BAR0) npc_af_kex_ldata#_flags_cfg + * + * NPC AF Key Extract Layer Data Flags Configuration Register + */ +union npc_af_kex_ldatax_flags_cfg { + u64 u; + struct npc_af_kex_ldatax_flags_cfg_s { + u64 lid : 3; + u64 reserved_3_63 : 61; + } s; + /* struct npc_af_kex_ldatax_flags_cfg_s cn; */ +}; + +static inline u64 NPC_AF_KEX_LDATAX_FLAGS_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_KEX_LDATAX_FLAGS_CFG(u64 a) +{ + return 0x800 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_kpu#_cfg + * + * NPC AF KPU Configuration Registers + */ +union npc_af_kpux_cfg { + u64 u; + struct npc_af_kpux_cfg_s { + u64 ena : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npc_af_kpux_cfg_s cn; */ +}; + +static inline u64 NPC_AF_KPUX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_KPUX_CFG(u64 a) +{ + return 0x500 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_kpu#_dbg + * + * NPC AF KPU Debug Registers This register contains information for the + * last packet/lookup for which debug is enabled by + * NPC_AF_DBG_CTL[INTF_DBG,LKUP_DBG]. The register contents are undefined + * when debug information is captured for a software key lookup + * (NPC_AF_LKUP_CTL[OP] = NPC_LKUPOP_E::KEY). + */ +union npc_af_kpux_dbg { + u64 u; + struct npc_af_kpux_dbg_s { + u64 hit_entry : 8; + u64 byp : 1; + u64 reserved_9_63 : 55; + } s; + /* struct npc_af_kpux_dbg_s cn; */ +}; + +static inline u64 NPC_AF_KPUX_DBG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_KPUX_DBG(u64 a) +{ + return 0x3000020 + 0x100 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_kpu#_entry#_action0 + * + * NPC AF KPU Entry Action Data 0 Registers When a KPU's search data + * matches a KPU CAM entry in NPC_AF_KPU()_ENTRY()_CAM(), the + * corresponding entry action in NPC_AF_KPU()_ENTRY()_ACTION0 and + * NPC_AF_KPU()_ENTRY()_ACTION1 specifies the next state and operations + * to perform before exiting the KPU. + */ +union npc_af_kpux_entryx_action0 { + u64 u; + struct npc_af_kpux_entryx_action0_s { + u64 var_len_shift : 3; + u64 var_len_right : 1; + u64 var_len_mask : 8; + u64 var_len_offset : 8; + u64 ptr_advance : 8; + u64 capture_flags : 8; + u64 capture_ltype : 4; + u64 capture_lid : 3; + u64 reserved_43 : 1; + u64 next_state : 8; + u64 parse_done : 1; + u64 capture_ena : 1; + u64 byp_count : 3; + u64 reserved_57_63 : 7; + } s; + /* struct npc_af_kpux_entryx_action0_s cn; */ +}; + +static inline u64 NPC_AF_KPUX_ENTRYX_ACTION0(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_KPUX_ENTRYX_ACTION0(u64 a, u64 b) +{ + return 0x100020 + 0x4000 * a + 0x40 * b; +} + +/** + * Register (RVU_PF_BAR0) npc_af_kpu#_entry#_action1 + * + * NPC AF KPU Entry Action Data 0 Registers See + * NPC_AF_KPU()_ENTRY()_ACTION0. + */ +union npc_af_kpux_entryx_action1 { + u64 u; + struct npc_af_kpux_entryx_action1_s { + u64 dp0_offset : 8; + u64 dp1_offset : 8; + u64 dp2_offset : 8; + u64 errcode : 8; + u64 errlev : 4; + u64 reserved_36_63 : 28; + } s; + /* struct npc_af_kpux_entryx_action1_s cn; */ +}; + +static inline u64 NPC_AF_KPUX_ENTRYX_ACTION1(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_KPUX_ENTRYX_ACTION1(u64 a, u64 b) +{ + return 0x100028 + 0x4000 * a + 0x40 * b; +} + +/** + * Register (RVU_PF_BAR0) npc_af_kpu#_entry#_cam# + * + * NPC AF KPU Entry CAM Registers KPU comparison ternary data. The field + * values in NPC_AF_KPU()_ENTRY()_CAM() are ternary, where each data bit + * of the search key matches as follows: _ [CAM(1)]<n>=0, + * [CAM(0)]<n>=0: Always match; search key data<n> don't care. _ + * [CAM(1)]<n>=0, [CAM(0)]<n>=1: Match when search key data<n> == + * 0. _ [CAM(1)]<n>=1, [CAM(0)]<n>=0: Match when search key data<n> + * == 1. _ [CAM(1)]<n>=1, [CAM(0)]<n>=1: Reserved. The reserved + * combination is not allowed. Hardware suppresses any write to CAM(0) or + * CAM(1) that would result in the reserved combination for any CAM bit. + * The reset value for all non-reserved fields is all zeros for CAM(1) + * and all ones for CAM(0), matching a search key of all zeros. Software + * must program a default entry for each KPU, e.g. by programming each + * KPU's last entry {b} (NPC_AF_KPU()_ENTRY({b})_CAM()) to always match + * all bits. + */ +union npc_af_kpux_entryx_camx { + u64 u; + struct npc_af_kpux_entryx_camx_s { + u64 dp0_data : 16; + u64 dp1_data : 16; + u64 dp2_data : 16; + u64 state : 8; + u64 reserved_56_63 : 8; + } s; + /* struct npc_af_kpux_entryx_camx_s cn; */ +}; + +static inline u64 NPC_AF_KPUX_ENTRYX_CAMX(u64 a, u64 b, u64 c) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_KPUX_ENTRYX_CAMX(u64 a, u64 b, u64 c) +{ + return 0x100000 + 0x4000 * a + 0x40 * b + 8 * c; +} + +/** + * Register (RVU_PF_BAR0) npc_af_kpu#_entry_dis# + * + * NPC AF KPU Entry Disable Registers See NPC_AF_KPU()_ENTRY()_ACTION0. + */ +union npc_af_kpux_entry_disx { + u64 u; + struct npc_af_kpux_entry_disx_s { + u64 dis : 64; + } s; + /* struct npc_af_kpux_entry_disx_s cn; */ +}; + +static inline u64 NPC_AF_KPUX_ENTRY_DISX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_KPUX_ENTRY_DISX(u64 a, u64 b) +{ + return 0x180000 + 0x40 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) npc_af_kpu#_err_ctl + * + * NPC AF KPU Error Control Registers This register specifies values + * captured in NPC_RESULT_S[ERRLEV,ERRCODE] when errors are detected by a + * KPU. + */ +union npc_af_kpux_err_ctl { + u64 u; + struct npc_af_kpux_err_ctl_s { + u64 errlev : 4; + u64 dp_offset_errcode : 8; + u64 ptr_advance_errcode : 8; + u64 var_len_offset_errcode : 8; + u64 reserved_28_63 : 36; + } s; + /* struct npc_af_kpux_err_ctl_s cn; */ +}; + +static inline u64 NPC_AF_KPUX_ERR_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_KPUX_ERR_CTL(u64 a) +{ + return 0x30000a0 + 0x100 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_kpu_diag + * + * INTERNAL : NPC AF Debug Result Registers + */ +union npc_af_kpu_diag { + u64 u; + struct npc_af_kpu_diag_s { + u64 skip_dis : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npc_af_kpu_diag_s cn; */ +}; + +static inline u64 NPC_AF_KPU_DIAG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_KPU_DIAG(void) +{ + return 0x3002000; +} + +/** + * Register (RVU_PF_BAR0) npc_af_lkup_ctl + * + * NPC AF Software Lookup Control Registers + */ +union npc_af_lkup_ctl { + u64 u; + struct npc_af_lkup_ctl_s { + u64 intf : 2; + u64 pkind : 6; + u64 chan : 12; + u64 hdr_sizem1 : 8; + u64 op : 3; + u64 exec : 1; + u64 reserved_32_63 : 32; + } s; + /* struct npc_af_lkup_ctl_s cn; */ +}; + +static inline u64 NPC_AF_LKUP_CTL(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_LKUP_CTL(void) +{ + return 0x2000000; +} + +/** + * Register (RVU_PF_BAR0) npc_af_lkup_data# + * + * NPC AF Software Lookup Data Registers + */ +union npc_af_lkup_datax { + u64 u; + struct npc_af_lkup_datax_s { + u64 data : 64; + } s; + /* struct npc_af_lkup_datax_s cn; */ +}; + +static inline u64 NPC_AF_LKUP_DATAX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_LKUP_DATAX(u64 a) +{ + return 0x2000200 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_lkup_result# + * + * NPC AF Software Lookup Result Registers + */ +union npc_af_lkup_resultx { + u64 u; + struct npc_af_lkup_resultx_s { + u64 data : 64; + } s; + /* struct npc_af_lkup_resultx_s cn; */ +}; + +static inline u64 NPC_AF_LKUP_RESULTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_LKUP_RESULTX(u64 a) +{ + return 0x2000400 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_match_stat# + * + * NPC AF Match Statistics Registers + */ +union npc_af_match_statx { + u64 u; + struct npc_af_match_statx_s { + u64 count : 48; + u64 reserved_48_63 : 16; + } s; + /* struct npc_af_match_statx_s cn; */ +}; + +static inline u64 NPC_AF_MATCH_STATX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MATCH_STATX(u64 a) +{ + return 0x1880008 + 0x100 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_mcam_bank#_hit# + * + * NPC AF MCAM Bank Hit Registers + */ +union npc_af_mcam_bankx_hitx { + u64 u; + struct npc_af_mcam_bankx_hitx_s { + u64 hit : 64; + } s; + /* struct npc_af_mcam_bankx_hitx_s cn; */ +}; + +static inline u64 NPC_AF_MCAM_BANKX_HITX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MCAM_BANKX_HITX(u64 a, u64 b) +{ + return 0x1c80000 + 0x100 * a + 0x10 * b; +} + +/** + * Register (RVU_PF_BAR0) npc_af_mcam_dbg + * + * NPC AF MCAM Debug Register This register contains information for the + * last packet/lookup for which debug is enabled by + * NPC_AF_DBG_CTL[INTF_DBG,LKUP_DBG]. + */ +union npc_af_mcam_dbg { + u64 u; + struct npc_af_mcam_dbg_s { + u64 hit_entry : 10; + u64 reserved_10_11 : 2; + u64 hit_bank : 2; + u64 reserved_14_15 : 2; + u64 miss : 1; + u64 reserved_17_63 : 47; + } s; + /* struct npc_af_mcam_dbg_s cn; */ +}; + +static inline u64 NPC_AF_MCAM_DBG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MCAM_DBG(void) +{ + return 0x3001000; +} + +/** + * Register (RVU_PF_BAR0) npc_af_mcam_scrub_ctl + * + * NPC AF MCAM Scrub Control Register + */ +union npc_af_mcam_scrub_ctl { + u64 u; + struct npc_af_mcam_scrub_ctl_s { + u64 ena : 1; + u64 reserved_1_7 : 7; + u64 lp_dis : 1; + u64 reserved_9_15 : 7; + u64 toth : 4; + u64 reserved_20_63 : 44; + } s; + /* struct npc_af_mcam_scrub_ctl_s cn; */ +}; + +static inline u64 NPC_AF_MCAM_SCRUB_CTL(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MCAM_SCRUB_CTL(void) +{ + return 0xa0; +} + +/** + * Register (RVU_PF_BAR0) npc_af_mcame#_bank#_action + * + * NPC AF MCAM Entry Bank Action Data Registers Specifies a packet's + * match action captured in NPC_RESULT_S[ACTION]. When an interface is + * configured to use the NPC_MCAM_KEY_X2_S search key format + * (NPC_AF_INTF()_KEX_CFG[KEYW] = NPC_MCAMKEYW_E::X2), * + * NPC_AF_MCAME()_BANK(0)_ACTION/_TAG_ACT/_STAT_ACT are used if the + * search key matches NPC_AF_MCAME()_BANK(0..1)_CAM()_W*. * + * NPC_AF_MCAME()_BANK(2)_ACTION/_TAG_ACT/_STAT_ACT are used if the + * search key matches NPC_AF_MCAME()_BANK(2..3)_CAM()_W*. * + * NPC_AF_MCAME()_BANK(1,3)_ACTION/_TAG_ACT/_STAT_ACT are not used. When + * an interface is configured to use the NPC_MCAM_KEY_X4_S search key + * format (NPC_AF_INTF()_KEX_CFG[KEYW] = NPC_MCAMKEYW_E::X4): * + * NPC_AF_MCAME()_BANK(0)_ACTION/_TAG_ACT/_STAT_ACT are used if the + * search key matches NPC_AF_MCAME()_BANK(0..3)_CAM()_W*. * + * NPC_AF_MCAME()_BANK(1..3)_ACTION/_TAG_ACT/_STAT_ACT are not used. + */ +union npc_af_mcamex_bankx_action { + u64 u; + struct npc_af_mcamex_bankx_action_s { + u64 action : 64; + } s; + /* struct npc_af_mcamex_bankx_action_s cn; */ +}; + +static inline u64 NPC_AF_MCAMEX_BANKX_ACTION(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MCAMEX_BANKX_ACTION(u64 a, u64 b) +{ + return 0x1900000 + 0x100 * a + 0x10 * b; +} + +/** + * Register (RVU_PF_BAR0) npc_af_mcame#_bank#_cam#_intf + * + * NPC AF MCAM Entry Bank CAM Data Interface Registers MCAM comparison + * ternary data interface word. The field values in + * NPC_AF_MCAME()_BANK()_CAM()_INTF, NPC_AF_MCAME()_BANK()_CAM()_W0 and + * NPC_AF_MCAME()_BANK()_CAM()_W1 are ternary, where each data bit of + * the search key matches as follows: _ [CAM(1)]<n>=0, [CAM(0)]<n>=0: + * Always match; search key data<n> don't care. _ [CAM(1)]<n>=0, + * [CAM(0)]<n>=1: Match when search key data<n> == 0. _ + * [CAM(1)]<n>=1, [CAM(0)]<n>=0: Match when search key data<n> == + * 1. _ [CAM(1)]<n>=1, [CAM(0)]<n>=1: Reserved. The reserved + * combination is not allowed. Hardware suppresses any write to CAM(0) or + * CAM(1) that would result in the reserved combination for any CAM bit. + * The reset value for all non-reserved fields in + * NPC_AF_MCAME()_BANK()_CAM()_INTF, NPC_AF_MCAME()_BANK()_CAM()_W0 and + * NPC_AF_MCAME()_BANK()_CAM()_W1 is all zeros for CAM(1) and all ones + * for CAM(0), matching a search key of all zeros. When an interface is + * configured to use the NPC_MCAM_KEY_X1_S search key format + * (NPC_AF_INTF()_KEX_CFG[KEYW] = NPC_MCAMKEYW_E::X1), the four banks of + * every MCAM entry are used as individual entries, each of which is + * independently compared with the search key as follows: _ + * NPC_AF_MCAME()_BANK()_CAM()_INTF[INTF] corresponds to + * NPC_MCAM_KEY_X1_S[INTF]. _ NPC_AF_MCAME()_BANK()_CAM()_W0[MD] + * corresponds to NPC_MCAM_KEY_X1_S[KW0]. _ + * NPC_AF_MCAME()_BANK()_CAM()_W1[MD] corresponds to + * NPC_MCAM_KEY_X1_S[KW1]. When an interface is configured to use the + * NPC_MCAM_KEY_X2_S search key format (NPC_AF_INTF()_KEX_CFG[KEYW] = + * NPC_MCAMKEYW_E::X2), banks 0-1 of every MCAM entry are used as one + * double-wide entry, banks 2-3 as a second double-wide entry, and each + * double-wide entry is independently compared with the search key as + * follows: _ NPC_AF_MCAME()_BANK(0,2)_CAM()_INTF[INTF] corresponds to + * NPC_MCAM_KEY_X2_S[INTF]. _ NPC_AF_MCAME()_BANK(0,2)_CAM()_W0[MD] + * corresponds to NPC_MCAM_KEY_X2_S[KW0]. _ + * NPC_AF_MCAME()_BANK(0,2)_CAM()_W1[MD] corresponds to + * NPC_MCAM_KEY_X2_S[KW1]<47:0>. _ + * NPC_AF_MCAME()_BANK(1,3)_CAM()_INTF[INTF] corresponds to + * NPC_MCAM_KEY_X2_S[INTF]. _ + * NPC_AF_MCAME()_BANK(1,3)_CAM()_W0[MD]<15:0> corresponds to + * NPC_MCAM_KEY_X2_S[KW1]<63:48>. _ + * NPC_AF_MCAME()_BANK(1,3)_CAM()_W0[MD]<63:16> corresponds to + * NPC_MCAM_KEY_X2_S[KW2]<47:0>. _ + * NPC_AF_MCAME()_BANK(1,3)_CAM()_W1[MD]<15:0> corresponds to + * NPC_MCAM_KEY_X2_S[KW2]<63:48>. _ + * NPC_AF_MCAME()_BANK(1,3)_CAM()_W1[MD]<47:16> corresponds to + * NPC_MCAM_KEY_X2_S[KW3]<31:0>. When an interface is configured to + * use the NPC_MCAM_KEY_X4_S search key format + * (NPC_AF_INTF()_KEX_CFG[KEYW] = NPC_MCAMKEYW_E::X4), the four banks of + * every MCAM entry are used as a single quad-wide entry that is compared + * with the search key as follows: _ + * NPC_AF_MCAME()_BANK(0)_CAM()_INTF[INTF] corresponds to + * NPC_MCAM_KEY_X4_S[INTF]. _ NPC_AF_MCAME()_BANK(0)_CAM()_W0[MD] + * corresponds to NPC_MCAM_KEY_X4_S[KW0]. _ + * NPC_AF_MCAME()_BANK(0)_CAM()_W1[MD] corresponds to + * NPC_MCAM_KEY_X4_S[KW1]<47:0>. _ + * NPC_AF_MCAME()_BANK(1)_CAM()_INTF[INTF] corresponds to + * NPC_MCAM_KEY_X4_S[INTF]. _ NPC_AF_MCAME()_BANK(1)_CAM()_W0[MD]<15:0> + * corresponds to NPC_MCAM_KEY_X4_S[KW1]<63:48>. _ + * NPC_AF_MCAME()_BANK(1)_CAM()_W0[MD]<63:16> corresponds to + * NPC_MCAM_KEY_X4_S[KW2]<47:0>. _ + * NPC_AF_MCAME()_BANK(1)_CAM()_W1[MD]<15:0> corresponds to + * NPC_MCAM_KEY_X4_S[KW2]<63:48>. _ + * NPC_AF_MCAME()_BANK(1)_CAM()_W1[MD]<47:16> corresponds to + * NPC_MCAM_KEY_X4_S[KW3]<31:0>. _ + * NPC_AF_MCAME()_BANK(2)_CAM()_INTF[INTF] corresponds to + * NPC_MCAM_KEY_X4_S[INTF]. _ NPC_AF_MCAME()_BANK(2)_CAM()_W0[MD]<31:0> + * corresponds to NPC_MCAM_KEY_X4_S[KW3]<63:32>. _ + * NPC_AF_MCAME()_BANK(2)_CAM()_W0[MD]<63:32> corresponds to + * NPC_MCAM_KEY_X4_S[KW4]<31:0>. _ + * NPC_AF_MCAME()_BANK(2)_CAM()_W1[MD]<31:0> corresponds to + * NPC_MCAM_KEY_X4_S[KW4]<63:32>. _ + * NPC_AF_MCAME()_BANK(2)_CAM()_W1[MD]<47:32> corresponds to + * NPC_MCAM_KEY_X4_S[KW5]<15:0>. _ + * NPC_AF_MCAME()_BANK(3)_CAM()_INTF[INTF] corresponds to + * NPC_MCAM_KEY_X4_S[INTF]. _ NPC_AF_MCAME()_BANK(3)_CAM()_W0[MD]<47:0> + * corresponds to NPC_MCAM_KEY_X4_S[KW5]<63:16>. _ + * NPC_AF_MCAME()_BANK(3)_CAM()_W0[MD]<63:48> corresponds to + * NPC_MCAM_KEY_X4_S[KW6]<15:0>. _ NPC_AF_MCAME()_BANK(3)_CAM()_W1[MD] + * corresponds to NPC_MCAM_KEY_X4_S[KW6]<63:16>. Note that for the X2 + * and X4 formats, a wide entry will not match unless the INTF fields + * from the associated two or four banks match the INTF value from the + * search key. For the X1 and X2 formats, a match in a lower-numbered + * bank takes priority over a match in any higher numbered banks. Within + * each bank, the lowest numbered matching entry takes priority over any + * higher numbered entry. + */ +union npc_af_mcamex_bankx_camx_intf { + u64 u; + struct npc_af_mcamex_bankx_camx_intf_s { + u64 intf : 2; + u64 reserved_2_63 : 62; + } s; + /* struct npc_af_mcamex_bankx_camx_intf_s cn; */ +}; + +static inline u64 NPC_AF_MCAMEX_BANKX_CAMX_INTF(u64 a, u64 b, u64 c) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MCAMEX_BANKX_CAMX_INTF(u64 a, u64 b, u64 c) +{ + return 0x1000000 + 0x400 * a + 0x40 * b + 8 * c; +} + +/** + * Register (RVU_PF_BAR0) npc_af_mcame#_bank#_cam#_w0 + * + * NPC AF MCAM Entry Bank CAM Data Word 0 Registers MCAM comparison + * ternary data word 0. See NPC_AF_MCAME()_BANK()_CAM()_INTF. + */ +union npc_af_mcamex_bankx_camx_w0 { + u64 u; + struct npc_af_mcamex_bankx_camx_w0_s { + u64 md : 64; + } s; + /* struct npc_af_mcamex_bankx_camx_w0_s cn; */ +}; + +static inline u64 NPC_AF_MCAMEX_BANKX_CAMX_W0(u64 a, u64 b, u64 c) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MCAMEX_BANKX_CAMX_W0(u64 a, u64 b, u64 c) +{ + return 0x1000010 + 0x400 * a + 0x40 * b + 8 * c; +} + +/** + * Register (RVU_PF_BAR0) npc_af_mcame#_bank#_cam#_w1 + * + * NPC AF MCAM Entry Bank Data Word 1 Registers MCAM comparison ternary + * data word 1. See NPC_AF_MCAME()_BANK()_CAM()_INTF. + */ +union npc_af_mcamex_bankx_camx_w1 { + u64 u; + struct npc_af_mcamex_bankx_camx_w1_s { + u64 md : 48; + u64 reserved_48_63 : 16; + } s; + /* struct npc_af_mcamex_bankx_camx_w1_s cn; */ +}; + +static inline u64 NPC_AF_MCAMEX_BANKX_CAMX_W1(u64 a, u64 b, u64 c) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MCAMEX_BANKX_CAMX_W1(u64 a, u64 b, u64 c) +{ + return 0x1000020 + 0x400 * a + 0x40 * b + 8 * c; +} + +/** + * Register (RVU_PF_BAR0) npc_af_mcame#_bank#_cfg + * + * NPC AF MCAM Entry Bank Configuration Registers + */ +union npc_af_mcamex_bankx_cfg { + u64 u; + struct npc_af_mcamex_bankx_cfg_s { + u64 ena : 1; + u64 reserved_1_63 : 63; + } s; + /* struct npc_af_mcamex_bankx_cfg_s cn; */ +}; + +static inline u64 NPC_AF_MCAMEX_BANKX_CFG(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MCAMEX_BANKX_CFG(u64 a, u64 b) +{ + return 0x1800000 + 0x100 * a + 0x10 * b; +} + +/** + * Register (RVU_PF_BAR0) npc_af_mcame#_bank#_stat_act + * + * NPC AF MCAM Entry Bank Statistics Action Registers Used to optionally + * increment a NPC_AF_MATCH_STAT() counter when a packet matches an MCAM + * entry. See also NPC_AF_MCAME()_BANK()_ACTION. + */ +union npc_af_mcamex_bankx_stat_act { + u64 u; + struct npc_af_mcamex_bankx_stat_act_s { + u64 stat_sel : 9; + u64 ena : 1; + u64 reserved_10_63 : 54; + } s; + /* struct npc_af_mcamex_bankx_stat_act_s cn; */ +}; + +static inline u64 NPC_AF_MCAMEX_BANKX_STAT_ACT(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MCAMEX_BANKX_STAT_ACT(u64 a, u64 b) +{ + return 0x1880000 + 0x100 * a + 0x10 * b; +} + +/** + * Register (RVU_PF_BAR0) npc_af_mcame#_bank#_tag_act + * + * NPC AF MCAM Entry Bank VTag Action Data Registers Specifies a packet's + * match Vtag action captured in NPC_RESULT_S[VTAG_ACTION]. See also + * NPC_AF_MCAME()_BANK()_ACTION. + */ +union npc_af_mcamex_bankx_tag_act { + u64 u; + struct npc_af_mcamex_bankx_tag_act_s { + u64 vtag_action : 64; + } s; + /* struct npc_af_mcamex_bankx_tag_act_s cn; */ +}; + +static inline u64 NPC_AF_MCAMEX_BANKX_TAG_ACT(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_MCAMEX_BANKX_TAG_ACT(u64 a, u64 b) +{ + return 0x1900008 + 0x100 * a + 0x10 * b; +} + +/** + * Register (RVU_PF_BAR0) npc_af_pck_cfg + * + * NPC AF Protocol Check Configuration Register + */ +union npc_af_pck_cfg { + u64 u; + struct npc_af_pck_cfg_s { + u64 reserved_0 : 1; + u64 iip4_cksum : 1; + u64 oip4_cksum : 1; + u64 reserved_3 : 1; + u64 l3b : 1; + u64 l3m : 1; + u64 l2b : 1; + u64 l2m : 1; + u64 reserved_8_23 : 16; + u64 iip4_cksum_errcode : 8; + u64 oip4_cksum_errcode : 8; + u64 reserved_40_63 : 24; + } s; + /* struct npc_af_pck_cfg_s cn; */ +}; + +static inline u64 NPC_AF_PCK_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_PCK_CFG(void) +{ + return 0x600; +} + +/** + * Register (RVU_PF_BAR0) npc_af_pck_def_iip4 + * + * NPC AF Protocol Check Inner IPv4 Definition Register Provides layer + * information used by the protocol checker to identify an inner IPv4 + * header. + */ +union npc_af_pck_def_iip4 { + u64 u; + struct npc_af_pck_def_iip4_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct npc_af_pck_def_iip4_s cn; */ +}; + +static inline u64 NPC_AF_PCK_DEF_IIP4(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_PCK_DEF_IIP4(void) +{ + return 0x640; +} + +/** + * Register (RVU_PF_BAR0) npc_af_pck_def_oip4 + * + * NPC AF Protocol Check Outer IPv4 Definition Register Provides layer + * information used by the protocol checker to identify an outer IPv4 + * header. + */ +union npc_af_pck_def_oip4 { + u64 u; + struct npc_af_pck_def_oip4_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct npc_af_pck_def_oip4_s cn; */ +}; + +static inline u64 NPC_AF_PCK_DEF_OIP4(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_PCK_DEF_OIP4(void) +{ + return 0x620; +} + +/** + * Register (RVU_PF_BAR0) npc_af_pck_def_oip6 + * + * NPC AF Protocol Check Outer IPv6 Definition Register Provides layer + * information used by the protocol checker to identify an outer IPv6 + * header. [LID] must have the same value as NPC_AF_PCK_DEF_OIP4[LID]. + */ +union npc_af_pck_def_oip6 { + u64 u; + struct npc_af_pck_def_oip6_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct npc_af_pck_def_oip6_s cn; */ +}; + +static inline u64 NPC_AF_PCK_DEF_OIP6(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_PCK_DEF_OIP6(void) +{ + return 0x630; +} + +/** + * Register (RVU_PF_BAR0) npc_af_pck_def_ol2 + * + * NPC AF Protocol Check Outer L2 Definition Register Provides layer + * information used by the protocol checker to identify an outer L2 + * header. + */ +union npc_af_pck_def_ol2 { + u64 u; + struct npc_af_pck_def_ol2_s { + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_11_63 : 53; + } s; + /* struct npc_af_pck_def_ol2_s cn; */ +}; + +static inline u64 NPC_AF_PCK_DEF_OL2(void) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_PCK_DEF_OL2(void) +{ + return 0x610; +} + +/** + * Register (RVU_PF_BAR0) npc_af_pkind#_action0 + * + * NPC AF Port Kind Action Data 0 Registers NPC_AF_PKIND()_ACTION0 and + * NPC_AF_PKIND()_ACTION1 specify the initial parse state and operations + * to perform before entering KPU 0. + */ +union npc_af_pkindx_action0 { + u64 u; + struct npc_af_pkindx_action0_s { + u64 var_len_shift : 3; + u64 var_len_right : 1; + u64 var_len_mask : 8; + u64 var_len_offset : 8; + u64 ptr_advance : 8; + u64 capture_flags : 8; + u64 capture_ltype : 4; + u64 capture_lid : 3; + u64 reserved_43 : 1; + u64 next_state : 8; + u64 parse_done : 1; + u64 capture_ena : 1; + u64 byp_count : 3; + u64 reserved_57_63 : 7; + } s; + /* struct npc_af_pkindx_action0_s cn; */ +}; + +static inline u64 NPC_AF_PKINDX_ACTION0(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_PKINDX_ACTION0(u64 a) +{ + return 0x80000 + 0x40 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_pkind#_action1 + * + * NPC AF Port Kind Action Data 1 Registers NPC_AF_PKIND()_ACTION0 and + * NPC_AF_PKIND()_ACTION1 specify the initial parse state and operations + * to perform before entering KPU 0. + */ +union npc_af_pkindx_action1 { + u64 u; + struct npc_af_pkindx_action1_s { + u64 dp0_offset : 8; + u64 dp1_offset : 8; + u64 dp2_offset : 8; + u64 errcode : 8; + u64 errlev : 4; + u64 reserved_36_63 : 28; + } s; + /* struct npc_af_pkindx_action1_s cn; */ +}; + +static inline u64 NPC_AF_PKINDX_ACTION1(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_PKINDX_ACTION1(u64 a) +{ + return 0x80008 + 0x40 * a; +} + +/** + * Register (RVU_PF_BAR0) npc_af_pkind#_cpi_def# + * + * NPC AF Port Kind Channel Parse Index Definition Registers These + * registers specify the layer information and algorithm to compute a + * packet's channel parse index (CPI), which provides a port to channel + * adder for calculating NPC_RESULT_S[CHAN]. There are two CPI + * definitions per port kind, allowing the CPI computation to use two + * possible layer definitions in the parsed packet, e.g. DiffServ DSCP + * from either IPv4 or IPv6 header. CPI pseudocode: <pre> for (i = 0; + * i < 2; i++) { cpi_def = NPC_AF_PKIND()_CPI_DEF(i); LX = LA, LB, + * ..., or LH as selected by cpi_def[LID]; if (cpi_def[ENA] && + * ((cpi_def[LTYPE_MATCH] & cpi_def[LTYPE_MASK]) == + * (NPC_RESULT_S[LX[LTYPE]] & cpi_def[LTYPE_MASK])) && + * ((cpi_def[FLAGS_MATCH] & cpi_def[FLAGS_MASK]) == + * (NPC_RESULT_S[LX[FLAGS]] & cpi_def[FLAGS_MASK]))) { // Found + * matching layer nibble_offset = (2*NPC_RESULT_S[LX[LPTR]]) + + * cpi_def[ADD_OFFSET]; add_byte = byte at nibble_offset from start + * of packet; cpi_add = (add_byte & cpi_def[ADD_MASK]) >> + * cpi_def[ADD_SHIFT]; cpi = cpi_def[CPI_BASE] + cpi_add; + * NPC_RESULT_S[CHAN] += NPC_AF_CPI(cpi)_CFG[PADD]; break; } } + * </pre> + */ +union npc_af_pkindx_cpi_defx { + u64 u; + struct npc_af_pkindx_cpi_defx_s { + u64 cpi_base : 10; + u64 reserved_10_11 : 2; + u64 add_shift : 3; + u64 reserved_15 : 1; + u64 add_mask : 8; + u64 add_offset : 8; + u64 flags_mask : 8; + u64 flags_match : 8; + u64 ltype_mask : 4; + u64 ltype_match : 4; + u64 lid : 3; + u64 reserved_59_62 : 4; + u64 ena : 1; + } s; + /* struct npc_af_pkindx_cpi_defx_s cn; */ +}; + +static inline u64 NPC_AF_PKINDX_CPI_DEFX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 NPC_AF_PKINDX_CPI_DEFX(u64 a, u64 b) +{ + return 0x80020 + 0x40 * a + 8 * b; +} + +#endif /* __CSRS_NPC_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx2/csrs/csrs-rvu.h b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-rvu.h new file mode 100644 index 0000000000..f4e0de6025 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/csrs/csrs-rvu.h @@ -0,0 +1,2276 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Marvell International Ltd. + * + * https://spdx.org/licenses + */ +#ifndef __CSRS_RVU_H__ +#define __CSRS_RVU_H__ + +/** + * @file + * + * Configuration and status register (CSR) address and type definitions for + * RVU. + * + * This file is auto generated. Do not edit. + * + */ + +/** + * Enumeration rvu_af_int_vec_e + * + * RVU Admin Function Interrupt Vector Enumeration Enumerates the MSI-X + * interrupt vectors. Internal: RVU maintains the state of these vectors + * internally, and generates GIB messages for it without accessing the + * MSI-X table region in LLC/DRAM. + */ +#define RVU_AF_INT_VEC_E_GEN (3) +#define RVU_AF_INT_VEC_E_MBOX (4) +#define RVU_AF_INT_VEC_E_PFFLR (1) +#define RVU_AF_INT_VEC_E_PFME (2) +#define RVU_AF_INT_VEC_E_POISON (0) + +/** + * Enumeration rvu_bar_e + * + * RVU Base Address Register Enumeration Enumerates the base address + * registers. Internal: For documentation only. + */ +#define RVU_BAR_E_RVU_PFX_BAR0(a) (0x840000000000ll + 0x1000000000ll * (a)) +#define RVU_BAR_E_RVU_PFX_BAR0_SIZE 0x10000000ull +#define RVU_BAR_E_RVU_PFX_FUNCX_BAR2(a, b) \ + (0x840200000000ll + 0x1000000000ll * (a) + 0x2000000ll * (b)) +#define RVU_BAR_E_RVU_PFX_FUNCX_BAR2_SIZE 0x100000ull +#define RVU_BAR_E_RVU_PFX_FUNCX_BAR4(a, b) \ + (0x840400000000ll + 0x1000000000ll * (a) + 0x2000000ll * (b)) +#define RVU_BAR_E_RVU_PFX_FUNCX_BAR4_SIZE 0x10000ull + +/** + * Enumeration rvu_block_addr_e + * + * RVU Block Address Enumeration Enumerates addressing of RVU resource + * blocks within each RVU BAR, i.e. values of RVU_FUNC_ADDR_S[BLOCK] and + * RVU_AF_ADDR_S[BLOCK]. CNXXXX may not implement all enumerated blocks. + * Software can read RVU_PF/RVU_VF_BLOCK_ADDR()_DISC[IMP] to discover + * which blocks are implemented and enabled. + */ +#define RVU_BLOCK_ADDR_E_CPTX(a) (0xa + (a)) +#define RVU_BLOCK_ADDR_E_LMT (1) +#define RVU_BLOCK_ADDR_E_NDCX(a) (0xc + (a)) +#define RVU_BLOCK_ADDR_E_NIXX(a) (4 + (a)) +#define RVU_BLOCK_ADDR_E_NPA (3) +#define RVU_BLOCK_ADDR_E_NPC (6) +#define RVU_BLOCK_ADDR_E_RX(a) (0 + (a)) +#define RVU_BLOCK_ADDR_E_REEX(a) (0x14 + (a)) +#define RVU_BLOCK_ADDR_E_RVUM (0) +#define RVU_BLOCK_ADDR_E_SSO (7) +#define RVU_BLOCK_ADDR_E_SSOW (8) +#define RVU_BLOCK_ADDR_E_TIM (9) + +/** + * Enumeration rvu_block_type_e + * + * RVU Block Type Enumeration Enumerates values of + * RVU_PF/RVU_VF_BLOCK_ADDR()_DISC[BTYPE]. + */ +#define RVU_BLOCK_TYPE_E_CPT (9) +#define RVU_BLOCK_TYPE_E_DDF (0xb) +#define RVU_BLOCK_TYPE_E_LMT (2) +#define RVU_BLOCK_TYPE_E_NDC (0xa) +#define RVU_BLOCK_TYPE_E_NIX (3) +#define RVU_BLOCK_TYPE_E_NPA (4) +#define RVU_BLOCK_TYPE_E_NPC (5) +#define RVU_BLOCK_TYPE_E_RAD (0xd) +#define RVU_BLOCK_TYPE_E_REE (0xe) +#define RVU_BLOCK_TYPE_E_RVUM (0) +#define RVU_BLOCK_TYPE_E_SSO (6) +#define RVU_BLOCK_TYPE_E_SSOW (7) +#define RVU_BLOCK_TYPE_E_TIM (8) +#define RVU_BLOCK_TYPE_E_ZIP (0xc) + +/** + * Enumeration rvu_bus_lf_e + * + * INTERNAL: RVU Bus LF Range Enumeration Enumerates the LF range for + * the RVU bus. Internal: This is an enum used in csr3 virtual equations. + */ +#define RVU_BUS_LF_E_RVU_BUS_LFX(a) (0 + 0x2000000 * (a)) + +/** + * Enumeration rvu_bus_lf_slot_e + * + * INTERNAL: RVU Bus LF Slot Range Enumeration Enumerates the LF and + * Slot range for the RVU bus. Internal: This is an enum used in csr3 + * virtual equations. + */ +#define RVU_BUS_LF_SLOT_E_RVU_BUS_LFX_SLOTX(a, b) \ + (0 + 0x2000000 * (a) + 0x1000 * (b)) + +/** + * Enumeration rvu_bus_pf_e + * + * INTERNAL: RVU Bus PF Range Enumeration Enumerates the PF range for + * the RVU bus. Internal: This is an enum used in csr3 virtual equations. + */ +#define RVU_BUS_PF_E_RVU_BUS_PFX(a) (0ll + 0x1000000000ll * (a)) + +/** + * Enumeration rvu_bus_pfvf_e + * + * INTERNAL: RVU Bus PFVF Range Enumeration Enumerates the PF and VF + * ranges for the RVU bus. Internal: This is an enum used in csr3 virtual + * equations. + */ +#define RVU_BUS_PFVF_E_RVU_BUS_PFX(a) (0 + 0x2000000 * (a)) +#define RVU_BUS_PFVF_E_RVU_BUS_VFX(a) (0 + 0x2000000 * (a)) + +/** + * Enumeration rvu_busbar_e + * + * INTERNAL: RVU Bus Base Address Region Enumeration Enumerates the base + * address region for the RVU bus. Internal: This is an enum used in csr3 + * virtual equations. + */ +#define RVU_BUSBAR_E_RVU_BUSBAR0 (0) +#define RVU_BUSBAR_E_RVU_BUSBAR2 (0x200000000ll) + +/** + * Enumeration rvu_busdid_e + * + * INTERNAL: RVU Bus DID Enumeration Enumerates the DID offset for the + * RVU bus. Internal: This is an enum used in csr3 virtual equations. + */ +#define RVU_BUSDID_E_RVU_BUSDID (0x840000000000ll) + +/** + * Enumeration rvu_pf_int_vec_e + * + * RVU PF Interrupt Vector Enumeration Enumerates the MSI-X interrupt + * vectors. + */ +#define RVU_PF_INT_VEC_E_AFPF_MBOX (6) +#define RVU_PF_INT_VEC_E_VFFLRX(a) (0 + (a)) +#define RVU_PF_INT_VEC_E_VFMEX(a) (2 + (a)) +#define RVU_PF_INT_VEC_E_VFPF_MBOXX(a) (4 + (a)) + +/** + * Enumeration rvu_vf_int_vec_e + * + * RVU VF Interrupt Vector Enumeration Enumerates the MSI-X interrupt + * vectors. + */ +#define RVU_VF_INT_VEC_E_MBOX (0) + +/** + * Structure rvu_af_addr_s + * + * RVU Admin Function Register Address Structure Address format for + * accessing shared Admin Function (AF) registers in RVU PF BAR0. These + * registers may be accessed by all RVU PFs whose + * RVU_PRIV_PF()_CFG[AF_ENA] bit is set. + */ +union rvu_af_addr_s { + u64 u; + struct rvu_af_addr_s_s { + u64 addr : 28; + u64 block : 5; + u64 reserved_33_63 : 31; + } s; + /* struct rvu_af_addr_s_s cn; */ +}; + +/** + * Structure rvu_func_addr_s + * + * RVU Function-unique Address Structure Address format for accessing + * function-unique registers in RVU PF/FUNC BAR2. + */ +union rvu_func_addr_s { + u32 u; + struct rvu_func_addr_s_s { + u32 addr : 12; + u32 lf_slot : 8; + u32 block : 5; + u32 reserved_25_31 : 7; + } s; + /* struct rvu_func_addr_s_s cn; */ +}; + +/** + * Structure rvu_msix_vec_s + * + * RVU MSI-X Vector Structure Format of entries in the RVU MSI-X table + * region in LLC/DRAM. See RVU_PRIV_PF()_MSIX_CFG. + */ +union rvu_msix_vec_s { + u64 u[2]; + struct rvu_msix_vec_s_s { + u64 addr : 64; + u64 data : 32; + u64 mask : 1; + u64 pend : 1; + u64 reserved_98_127 : 30; + } s; + /* struct rvu_msix_vec_s_s cn; */ +}; + +/** + * Structure rvu_pf_func_s + * + * RVU PF Function Identification Structure Identifies an RVU PF/VF, and + * format of *_PRIV_LF()_CFG[PF_FUNC] in RVU resource blocks, e.g. + * NPA_PRIV_LF()_CFG[PF_FUNC]. Internal: Also used for PF/VF + * identification on inter-coprocessor hardware interfaces (NPA, SSO, + * CPT, ...). + */ +union rvu_pf_func_s { + u32 u; + struct rvu_pf_func_s_s { + u32 func : 10; + u32 pf : 6; + u32 reserved_16_31 : 16; + } s; + /* struct rvu_pf_func_s_s cn; */ +}; + +/** + * Register (RVU_PF_BAR0) rvu_af_afpf#_mbox# + * + * RVU Admin Function AF/PF Mailbox Registers + */ +union rvu_af_afpfx_mboxx { + u64 u; + struct rvu_af_afpfx_mboxx_s { + u64 data : 64; + } s; + /* struct rvu_af_afpfx_mboxx_s cn; */ +}; + +static inline u64 RVU_AF_AFPFX_MBOXX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_AFPFX_MBOXX(u64 a, u64 b) +{ + return 0x2000 + 0x10 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_bar2_alias# + * + * INTERNAL: RVU Admin Function BAR2 Alias Registers These registers + * alias to the RVU BAR2 registers for the PF and function selected by + * RVU_AF_BAR2_SEL[PF_FUNC]. Internal: Not implemented. Placeholder for + * bug33464. + */ +union rvu_af_bar2_aliasx { + u64 u; + struct rvu_af_bar2_aliasx_s { + u64 data : 64; + } s; + /* struct rvu_af_bar2_aliasx_s cn; */ +}; + +static inline u64 RVU_AF_BAR2_ALIASX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_BAR2_ALIASX(u64 a) +{ + return 0x9100000 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_bar2_sel + * + * INTERNAL: RVU Admin Function BAR2 Select Register This register + * configures BAR2 accesses from the RVU_AF_BAR2_ALIAS() registers in + * BAR0. Internal: Not implemented. Placeholder for bug33464. + */ +union rvu_af_bar2_sel { + u64 u; + struct rvu_af_bar2_sel_s { + u64 alias_pf_func : 16; + u64 alias_ena : 1; + u64 reserved_17_63 : 47; + } s; + /* struct rvu_af_bar2_sel_s cn; */ +}; + +static inline u64 RVU_AF_BAR2_SEL(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_BAR2_SEL(void) +{ + return 0x9000000; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_blk_rst + * + * RVU Master Admin Function Block Reset Register + */ +union rvu_af_blk_rst { + u64 u; + struct rvu_af_blk_rst_s { + u64 rst : 1; + u64 reserved_1_62 : 62; + u64 busy : 1; + } s; + /* struct rvu_af_blk_rst_s cn; */ +}; + +static inline u64 RVU_AF_BLK_RST(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_BLK_RST(void) +{ + return 0x30; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_bp_test + * + * INTERNAL: RVUM Backpressure Test Registers + */ +union rvu_af_bp_test { + u64 u; + struct rvu_af_bp_test_s { + u64 lfsr_freq : 12; + u64 reserved_12_15 : 4; + u64 bp_cfg : 16; + u64 enable : 8; + u64 reserved_40_63 : 24; + } s; + /* struct rvu_af_bp_test_s cn; */ +}; + +static inline u64 RVU_AF_BP_TEST(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_BP_TEST(void) +{ + return 0x4000; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_eco + * + * INTERNAL: RVU Admin Function ECO Register + */ +union rvu_af_eco { + u64 u; + struct rvu_af_eco_s { + u64 eco_rw : 32; + u64 reserved_32_63 : 32; + } s; + /* struct rvu_af_eco_s cn; */ +}; + +static inline u64 RVU_AF_ECO(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_ECO(void) +{ + return 0x20; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_gen_int + * + * RVU Admin Function General Interrupt Register This register contains + * General interrupt summary bits. + */ +union rvu_af_gen_int { + u64 u; + struct rvu_af_gen_int_s { + u64 unmapped : 1; + u64 msix_fault : 1; + u64 reserved_2_63 : 62; + } s; + /* struct rvu_af_gen_int_s cn; */ +}; + +static inline u64 RVU_AF_GEN_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_GEN_INT(void) +{ + return 0x120; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_gen_int_ena_w1c + * + * RVU Admin Function General Interrupt Enable Clear Register This + * register clears interrupt enable bits. + */ +union rvu_af_gen_int_ena_w1c { + u64 u; + struct rvu_af_gen_int_ena_w1c_s { + u64 unmapped : 1; + u64 msix_fault : 1; + u64 reserved_2_63 : 62; + } s; + /* struct rvu_af_gen_int_ena_w1c_s cn; */ +}; + +static inline u64 RVU_AF_GEN_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_GEN_INT_ENA_W1C(void) +{ + return 0x138; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_gen_int_ena_w1s + * + * RVU Admin Function General Interrupt Enable Set Register This register + * sets interrupt enable bits. + */ +union rvu_af_gen_int_ena_w1s { + u64 u; + struct rvu_af_gen_int_ena_w1s_s { + u64 unmapped : 1; + u64 msix_fault : 1; + u64 reserved_2_63 : 62; + } s; + /* struct rvu_af_gen_int_ena_w1s_s cn; */ +}; + +static inline u64 RVU_AF_GEN_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_GEN_INT_ENA_W1S(void) +{ + return 0x130; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_gen_int_w1s + * + * RVU Admin Function General Interrupt Set Register This register sets + * interrupt bits. + */ +union rvu_af_gen_int_w1s { + u64 u; + struct rvu_af_gen_int_w1s_s { + u64 unmapped : 1; + u64 msix_fault : 1; + u64 reserved_2_63 : 62; + } s; + /* struct rvu_af_gen_int_w1s_s cn; */ +}; + +static inline u64 RVU_AF_GEN_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_GEN_INT_W1S(void) +{ + return 0x128; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_hwvf_rst + * + * RVU Admin Function Hardware VF Reset Register + */ +union rvu_af_hwvf_rst { + u64 u; + struct rvu_af_hwvf_rst_s { + u64 hwvf : 8; + u64 reserved_8_11 : 4; + u64 exec : 1; + u64 reserved_13_63 : 51; + } s; + /* struct rvu_af_hwvf_rst_s cn; */ +}; + +static inline u64 RVU_AF_HWVF_RST(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_HWVF_RST(void) +{ + return 0x2850; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_msixtr_base + * + * RVU Admin Function MSI-X Table Region Base-Address Register + */ +union rvu_af_msixtr_base { + u64 u; + struct rvu_af_msixtr_base_s { + u64 reserved_0_6 : 7; + u64 addr : 46; + u64 reserved_53_63 : 11; + } s; + /* struct rvu_af_msixtr_base_s cn; */ +}; + +static inline u64 RVU_AF_MSIXTR_BASE(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_MSIXTR_BASE(void) +{ + return 0x10; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pf#_vf_bar4_addr + * + * RVU Admin Function PF/VF BAR4 Address Registers + */ +union rvu_af_pfx_vf_bar4_addr { + u64 u; + struct rvu_af_pfx_vf_bar4_addr_s { + u64 reserved_0_15 : 16; + u64 addr : 48; + } s; + /* struct rvu_af_pfx_vf_bar4_addr_s cn; */ +}; + +static inline u64 RVU_AF_PFX_VF_BAR4_ADDR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFX_VF_BAR4_ADDR(u64 a) +{ + return 0x1000 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pf_bar4_addr + * + * RVU Admin Function PF BAR4 Address Registers + */ +union rvu_af_pf_bar4_addr { + u64 u; + struct rvu_af_pf_bar4_addr_s { + u64 reserved_0_15 : 16; + u64 addr : 48; + } s; + /* struct rvu_af_pf_bar4_addr_s cn; */ +}; + +static inline u64 RVU_AF_PF_BAR4_ADDR(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PF_BAR4_ADDR(void) +{ + return 0x40; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pf_rst + * + * RVU Admin Function PF Reset Register + */ +union rvu_af_pf_rst { + u64 u; + struct rvu_af_pf_rst_s { + u64 pf : 4; + u64 reserved_4_11 : 8; + u64 exec : 1; + u64 reserved_13_63 : 51; + } s; + /* struct rvu_af_pf_rst_s cn; */ +}; + +static inline u64 RVU_AF_PF_RST(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PF_RST(void) +{ + return 0x2840; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfaf_mbox_int + * + * RVU Admin Function PF to AF Mailbox Interrupt Registers + */ +union rvu_af_pfaf_mbox_int { + u64 u; + struct rvu_af_pfaf_mbox_int_s { + u64 mbox : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfaf_mbox_int_s cn; */ +}; + +static inline u64 RVU_AF_PFAF_MBOX_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFAF_MBOX_INT(void) +{ + return 0x2880; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfaf_mbox_int_ena_w1c + * + * RVU Admin Function PF to AF Mailbox Interrupt Enable Clear Registers + * This register clears interrupt enable bits. + */ +union rvu_af_pfaf_mbox_int_ena_w1c { + u64 u; + struct rvu_af_pfaf_mbox_int_ena_w1c_s { + u64 mbox : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfaf_mbox_int_ena_w1c_s cn; */ +}; + +static inline u64 RVU_AF_PFAF_MBOX_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFAF_MBOX_INT_ENA_W1C(void) +{ + return 0x2898; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfaf_mbox_int_ena_w1s + * + * RVU Admin Function PF to AF Mailbox Interrupt Enable Set Registers + * This register sets interrupt enable bits. + */ +union rvu_af_pfaf_mbox_int_ena_w1s { + u64 u; + struct rvu_af_pfaf_mbox_int_ena_w1s_s { + u64 mbox : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfaf_mbox_int_ena_w1s_s cn; */ +}; + +static inline u64 RVU_AF_PFAF_MBOX_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFAF_MBOX_INT_ENA_W1S(void) +{ + return 0x2890; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfaf_mbox_int_w1s + * + * RVU Admin Function PF to AF Mailbox Interrupt Set Registers This + * register sets interrupt bits. + */ +union rvu_af_pfaf_mbox_int_w1s { + u64 u; + struct rvu_af_pfaf_mbox_int_w1s_s { + u64 mbox : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfaf_mbox_int_w1s_s cn; */ +}; + +static inline u64 RVU_AF_PFAF_MBOX_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFAF_MBOX_INT_W1S(void) +{ + return 0x2888; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfflr_int + * + * RVU Admin Function PF Function Level Reset Interrupt Registers + */ +union rvu_af_pfflr_int { + u64 u; + struct rvu_af_pfflr_int_s { + u64 flr : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfflr_int_s cn; */ +}; + +static inline u64 RVU_AF_PFFLR_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFFLR_INT(void) +{ + return 0x28a0; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfflr_int_ena_w1c + * + * RVU Admin Function PF Function Level Reset Interrupt Enable Clear + * Registers This register clears interrupt enable bits. + */ +union rvu_af_pfflr_int_ena_w1c { + u64 u; + struct rvu_af_pfflr_int_ena_w1c_s { + u64 flr : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfflr_int_ena_w1c_s cn; */ +}; + +static inline u64 RVU_AF_PFFLR_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFFLR_INT_ENA_W1C(void) +{ + return 0x28b8; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfflr_int_ena_w1s + * + * RVU Admin Function PF Function Level Reset Interrupt Enable Set + * Registers This register sets interrupt enable bits. + */ +union rvu_af_pfflr_int_ena_w1s { + u64 u; + struct rvu_af_pfflr_int_ena_w1s_s { + u64 flr : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfflr_int_ena_w1s_s cn; */ +}; + +static inline u64 RVU_AF_PFFLR_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFFLR_INT_ENA_W1S(void) +{ + return 0x28b0; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfflr_int_w1s + * + * RVU Admin Function PF Function Level Reset Interrupt Set Registers + * This register sets interrupt bits. + */ +union rvu_af_pfflr_int_w1s { + u64 u; + struct rvu_af_pfflr_int_w1s_s { + u64 flr : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfflr_int_w1s_s cn; */ +}; + +static inline u64 RVU_AF_PFFLR_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFFLR_INT_W1S(void) +{ + return 0x28a8; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfme_int + * + * RVU Admin Function PF Bus Master Enable Interrupt Registers + */ +union rvu_af_pfme_int { + u64 u; + struct rvu_af_pfme_int_s { + u64 me : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfme_int_s cn; */ +}; + +static inline u64 RVU_AF_PFME_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFME_INT(void) +{ + return 0x28c0; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfme_int_ena_w1c + * + * RVU Admin Function PF Bus Master Enable Interrupt Enable Clear + * Registers This register clears interrupt enable bits. + */ +union rvu_af_pfme_int_ena_w1c { + u64 u; + struct rvu_af_pfme_int_ena_w1c_s { + u64 me : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfme_int_ena_w1c_s cn; */ +}; + +static inline u64 RVU_AF_PFME_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFME_INT_ENA_W1C(void) +{ + return 0x28d8; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfme_int_ena_w1s + * + * RVU Admin Function PF Bus Master Enable Interrupt Enable Set Registers + * This register sets interrupt enable bits. + */ +union rvu_af_pfme_int_ena_w1s { + u64 u; + struct rvu_af_pfme_int_ena_w1s_s { + u64 me : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfme_int_ena_w1s_s cn; */ +}; + +static inline u64 RVU_AF_PFME_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFME_INT_ENA_W1S(void) +{ + return 0x28d0; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfme_int_w1s + * + * RVU Admin Function PF Bus Master Enable Interrupt Set Registers This + * register sets interrupt bits. + */ +union rvu_af_pfme_int_w1s { + u64 u; + struct rvu_af_pfme_int_w1s_s { + u64 me : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfme_int_w1s_s cn; */ +}; + +static inline u64 RVU_AF_PFME_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFME_INT_W1S(void) +{ + return 0x28c8; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pfme_status + * + * RVU Admin Function PF Bus Master Enable Status Registers + */ +union rvu_af_pfme_status { + u64 u; + struct rvu_af_pfme_status_s { + u64 me : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pfme_status_s cn; */ +}; + +static inline u64 RVU_AF_PFME_STATUS(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFME_STATUS(void) +{ + return 0x2800; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pftrpend + * + * RVU Admin Function PF Transaction Pending Registers + */ +union rvu_af_pftrpend { + u64 u; + struct rvu_af_pftrpend_s { + u64 trpend : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pftrpend_s cn; */ +}; + +static inline u64 RVU_AF_PFTRPEND(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFTRPEND(void) +{ + return 0x2810; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_pftrpend_w1s + * + * RVU Admin Function PF Transaction Pending Set Registers This register + * reads or sets bits. + */ +union rvu_af_pftrpend_w1s { + u64 u; + struct rvu_af_pftrpend_w1s_s { + u64 trpend : 16; + u64 reserved_16_63 : 48; + } s; + /* struct rvu_af_pftrpend_w1s_s cn; */ +}; + +static inline u64 RVU_AF_PFTRPEND_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_PFTRPEND_W1S(void) +{ + return 0x2820; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_ras + * + * RVU Admin Function RAS Interrupt Register This register is intended + * for delivery of RAS events to the SCP, so should be ignored by OS + * drivers. + */ +union rvu_af_ras { + u64 u; + struct rvu_af_ras_s { + u64 msix_poison : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_af_ras_s cn; */ +}; + +static inline u64 RVU_AF_RAS(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_RAS(void) +{ + return 0x100; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_ras_ena_w1c + * + * RVU Admin Function RAS Interrupt Enable Clear Register This register + * clears interrupt enable bits. + */ +union rvu_af_ras_ena_w1c { + u64 u; + struct rvu_af_ras_ena_w1c_s { + u64 msix_poison : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_af_ras_ena_w1c_s cn; */ +}; + +static inline u64 RVU_AF_RAS_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_RAS_ENA_W1C(void) +{ + return 0x118; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_ras_ena_w1s + * + * RVU Admin Function RAS Interrupt Enable Set Register This register + * sets interrupt enable bits. + */ +union rvu_af_ras_ena_w1s { + u64 u; + struct rvu_af_ras_ena_w1s_s { + u64 msix_poison : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_af_ras_ena_w1s_s cn; */ +}; + +static inline u64 RVU_AF_RAS_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_RAS_ENA_W1S(void) +{ + return 0x110; +} + +/** + * Register (RVU_PF_BAR0) rvu_af_ras_w1s + * + * RVU Admin Function RAS Interrupt Set Register This register sets + * interrupt bits. + */ +union rvu_af_ras_w1s { + u64 u; + struct rvu_af_ras_w1s_s { + u64 msix_poison : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_af_ras_w1s_s cn; */ +}; + +static inline u64 RVU_AF_RAS_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_AF_RAS_W1S(void) +{ + return 0x108; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_block_addr#_disc + * + * RVU PF Block Address Discovery Registers These registers allow each PF + * driver to discover block resources that are provisioned to its PF. The + * register's BLOCK_ADDR index is enumerated by RVU_BLOCK_ADDR_E. + */ +union rvu_pf_block_addrx_disc { + u64 u; + struct rvu_pf_block_addrx_disc_s { + u64 num_lfs : 9; + u64 reserved_9_10 : 2; + u64 imp : 1; + u64 rid : 8; + u64 btype : 8; + u64 reserved_28_63 : 36; + } s; + /* struct rvu_pf_block_addrx_disc_s cn; */ +}; + +static inline u64 RVU_PF_BLOCK_ADDRX_DISC(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_BLOCK_ADDRX_DISC(u64 a) +{ + return 0x200 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_int + * + * RVU PF Interrupt Registers + */ +union rvu_pf_int { + u64 u; + struct rvu_pf_int_s { + u64 mbox : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_pf_int_s cn; */ +}; + +static inline u64 RVU_PF_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_INT(void) +{ + return 0xc20; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_int_ena_w1c + * + * RVU PF Interrupt Enable Clear Register This register clears interrupt + * enable bits. + */ +union rvu_pf_int_ena_w1c { + u64 u; + struct rvu_pf_int_ena_w1c_s { + u64 mbox : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_pf_int_ena_w1c_s cn; */ +}; + +static inline u64 RVU_PF_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_INT_ENA_W1C(void) +{ + return 0xc38; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_int_ena_w1s + * + * RVU PF Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union rvu_pf_int_ena_w1s { + u64 u; + struct rvu_pf_int_ena_w1s_s { + u64 mbox : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_pf_int_ena_w1s_s cn; */ +}; + +static inline u64 RVU_PF_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_INT_ENA_W1S(void) +{ + return 0xc30; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_int_w1s + * + * RVU PF Interrupt Set Register This register sets interrupt bits. + */ +union rvu_pf_int_w1s { + u64 u; + struct rvu_pf_int_w1s_s { + u64 mbox : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_pf_int_w1s_s cn; */ +}; + +static inline u64 RVU_PF_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_INT_W1S(void) +{ + return 0xc28; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_msix_pba# + * + * RVU PF MSI-X Pending-Bit-Array Registers This register is the MSI-X PF + * PBA table. + */ +union rvu_pf_msix_pbax { + u64 u; + struct rvu_pf_msix_pbax_s { + u64 pend : 64; + } s; + /* struct rvu_pf_msix_pbax_s cn; */ +}; + +static inline u64 RVU_PF_MSIX_PBAX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_MSIX_PBAX(u64 a) +{ + return 0xf0000 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_msix_vec#_addr + * + * RVU PF MSI-X Vector-Table Address Registers These registers and + * RVU_PF_MSIX_VEC()_CTL form the PF MSI-X vector table. The number of + * MSI-X vectors for a given PF is specified by + * RVU_PRIV_PF()_MSIX_CFG[PF_MSIXT_SIZEM1] (plus 1). Software must do a + * read after any writes to the MSI-X vector table to ensure that the + * writes have completed before interrupts are generated to the modified + * vectors. + */ +union rvu_pf_msix_vecx_addr { + u64 u; + struct rvu_pf_msix_vecx_addr_s { + u64 secvec : 1; + u64 reserved_1 : 1; + u64 addr : 51; + u64 reserved_53_63 : 11; + } s; + /* struct rvu_pf_msix_vecx_addr_s cn; */ +}; + +static inline u64 RVU_PF_MSIX_VECX_ADDR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_MSIX_VECX_ADDR(u64 a) +{ + return 0x80000 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_msix_vec#_ctl + * + * RVU PF MSI-X Vector-Table Control and Data Registers These registers + * and RVU_PF_MSIX_VEC()_ADDR form the PF MSI-X vector table. + */ +union rvu_pf_msix_vecx_ctl { + u64 u; + struct rvu_pf_msix_vecx_ctl_s { + u64 data : 32; + u64 mask : 1; + u64 reserved_33_63 : 31; + } s; + /* struct rvu_pf_msix_vecx_ctl_s cn; */ +}; + +static inline u64 RVU_PF_MSIX_VECX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_MSIX_VECX_CTL(u64 a) +{ + return 0x80008 + 0x10 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_pfaf_mbox# + * + * RVU PF/AF Mailbox Registers + */ +union rvu_pf_pfaf_mboxx { + u64 u; + struct rvu_pf_pfaf_mboxx_s { + u64 data : 64; + } s; + /* struct rvu_pf_pfaf_mboxx_s cn; */ +}; + +static inline u64 RVU_PF_PFAF_MBOXX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_PFAF_MBOXX(u64 a) +{ + return 0xc00 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vf#_pfvf_mbox# + * + * RVU PF/VF Mailbox Registers + */ +union rvu_pf_vfx_pfvf_mboxx { + u64 u; + struct rvu_pf_vfx_pfvf_mboxx_s { + u64 data : 64; + } s; + /* struct rvu_pf_vfx_pfvf_mboxx_s cn; */ +}; + +static inline u64 RVU_PF_VFX_PFVF_MBOXX(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFX_PFVF_MBOXX(u64 a, u64 b) +{ + return 0 + 0x1000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vf_bar4_addr + * + * RVU PF VF BAR4 Address Registers + */ +union rvu_pf_vf_bar4_addr { + u64 u; + struct rvu_pf_vf_bar4_addr_s { + u64 reserved_0_15 : 16; + u64 addr : 48; + } s; + /* struct rvu_pf_vf_bar4_addr_s cn; */ +}; + +static inline u64 RVU_PF_VF_BAR4_ADDR(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VF_BAR4_ADDR(void) +{ + return 0x10; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfflr_int# + * + * RVU PF VF Function Level Reset Interrupt Registers + */ +union rvu_pf_vfflr_intx { + u64 u; + struct rvu_pf_vfflr_intx_s { + u64 flr : 64; + } s; + /* struct rvu_pf_vfflr_intx_s cn; */ +}; + +static inline u64 RVU_PF_VFFLR_INTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFFLR_INTX(u64 a) +{ + return 0x900 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfflr_int_ena_w1c# + * + * RVU PF VF Function Level Reset Interrupt Enable Clear Registers This + * register clears interrupt enable bits. + */ +union rvu_pf_vfflr_int_ena_w1cx { + u64 u; + struct rvu_pf_vfflr_int_ena_w1cx_s { + u64 flr : 64; + } s; + /* struct rvu_pf_vfflr_int_ena_w1cx_s cn; */ +}; + +static inline u64 RVU_PF_VFFLR_INT_ENA_W1CX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFFLR_INT_ENA_W1CX(u64 a) +{ + return 0x960 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfflr_int_ena_w1s# + * + * RVU PF VF Function Level Reset Interrupt Enable Set Registers This + * register sets interrupt enable bits. + */ +union rvu_pf_vfflr_int_ena_w1sx { + u64 u; + struct rvu_pf_vfflr_int_ena_w1sx_s { + u64 flr : 64; + } s; + /* struct rvu_pf_vfflr_int_ena_w1sx_s cn; */ +}; + +static inline u64 RVU_PF_VFFLR_INT_ENA_W1SX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFFLR_INT_ENA_W1SX(u64 a) +{ + return 0x940 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfflr_int_w1s# + * + * RVU PF VF Function Level Reset Interrupt Set Registers This register + * sets interrupt bits. + */ +union rvu_pf_vfflr_int_w1sx { + u64 u; + struct rvu_pf_vfflr_int_w1sx_s { + u64 flr : 64; + } s; + /* struct rvu_pf_vfflr_int_w1sx_s cn; */ +}; + +static inline u64 RVU_PF_VFFLR_INT_W1SX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFFLR_INT_W1SX(u64 a) +{ + return 0x920 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfme_int# + * + * RVU PF VF Bus Master Enable Interrupt Registers + */ +union rvu_pf_vfme_intx { + u64 u; + struct rvu_pf_vfme_intx_s { + u64 me : 64; + } s; + /* struct rvu_pf_vfme_intx_s cn; */ +}; + +static inline u64 RVU_PF_VFME_INTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFME_INTX(u64 a) +{ + return 0x980 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfme_int_ena_w1c# + * + * RVU PF VF Bus Master Enable Interrupt Enable Clear Registers This + * register clears interrupt enable bits. + */ +union rvu_pf_vfme_int_ena_w1cx { + u64 u; + struct rvu_pf_vfme_int_ena_w1cx_s { + u64 me : 64; + } s; + /* struct rvu_pf_vfme_int_ena_w1cx_s cn; */ +}; + +static inline u64 RVU_PF_VFME_INT_ENA_W1CX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFME_INT_ENA_W1CX(u64 a) +{ + return 0x9e0 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfme_int_ena_w1s# + * + * RVU PF VF Bus Master Enable Interrupt Enable Set Registers This + * register sets interrupt enable bits. + */ +union rvu_pf_vfme_int_ena_w1sx { + u64 u; + struct rvu_pf_vfme_int_ena_w1sx_s { + u64 me : 64; + } s; + /* struct rvu_pf_vfme_int_ena_w1sx_s cn; */ +}; + +static inline u64 RVU_PF_VFME_INT_ENA_W1SX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFME_INT_ENA_W1SX(u64 a) +{ + return 0x9c0 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfme_int_w1s# + * + * RVU PF VF Bus Master Enable Interrupt Set Registers This register sets + * interrupt bits. + */ +union rvu_pf_vfme_int_w1sx { + u64 u; + struct rvu_pf_vfme_int_w1sx_s { + u64 me : 64; + } s; + /* struct rvu_pf_vfme_int_w1sx_s cn; */ +}; + +static inline u64 RVU_PF_VFME_INT_W1SX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFME_INT_W1SX(u64 a) +{ + return 0x9a0 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfme_status# + * + * RVU PF VF Bus Master Enable Status Registers + */ +union rvu_pf_vfme_statusx { + u64 u; + struct rvu_pf_vfme_statusx_s { + u64 me : 64; + } s; + /* struct rvu_pf_vfme_statusx_s cn; */ +}; + +static inline u64 RVU_PF_VFME_STATUSX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFME_STATUSX(u64 a) +{ + return 0x800 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfpf_mbox_int# + * + * RVU VF to PF Mailbox Interrupt Registers + */ +union rvu_pf_vfpf_mbox_intx { + u64 u; + struct rvu_pf_vfpf_mbox_intx_s { + u64 mbox : 64; + } s; + /* struct rvu_pf_vfpf_mbox_intx_s cn; */ +}; + +static inline u64 RVU_PF_VFPF_MBOX_INTX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFPF_MBOX_INTX(u64 a) +{ + return 0x880 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfpf_mbox_int_ena_w1c# + * + * RVU VF to PF Mailbox Interrupt Enable Clear Registers This register + * clears interrupt enable bits. + */ +union rvu_pf_vfpf_mbox_int_ena_w1cx { + u64 u; + struct rvu_pf_vfpf_mbox_int_ena_w1cx_s { + u64 mbox : 64; + } s; + /* struct rvu_pf_vfpf_mbox_int_ena_w1cx_s cn; */ +}; + +static inline u64 RVU_PF_VFPF_MBOX_INT_ENA_W1CX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFPF_MBOX_INT_ENA_W1CX(u64 a) +{ + return 0x8e0 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfpf_mbox_int_ena_w1s# + * + * RVU VF to PF Mailbox Interrupt Enable Set Registers This register sets + * interrupt enable bits. + */ +union rvu_pf_vfpf_mbox_int_ena_w1sx { + u64 u; + struct rvu_pf_vfpf_mbox_int_ena_w1sx_s { + u64 mbox : 64; + } s; + /* struct rvu_pf_vfpf_mbox_int_ena_w1sx_s cn; */ +}; + +static inline u64 RVU_PF_VFPF_MBOX_INT_ENA_W1SX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFPF_MBOX_INT_ENA_W1SX(u64 a) +{ + return 0x8c0 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vfpf_mbox_int_w1s# + * + * RVU VF to PF Mailbox Interrupt Set Registers This register sets + * interrupt bits. + */ +union rvu_pf_vfpf_mbox_int_w1sx { + u64 u; + struct rvu_pf_vfpf_mbox_int_w1sx_s { + u64 mbox : 64; + } s; + /* struct rvu_pf_vfpf_mbox_int_w1sx_s cn; */ +}; + +static inline u64 RVU_PF_VFPF_MBOX_INT_W1SX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFPF_MBOX_INT_W1SX(u64 a) +{ + return 0x8a0 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vftrpend# + * + * RVU PF VF Transaction Pending Registers + */ +union rvu_pf_vftrpendx { + u64 u; + struct rvu_pf_vftrpendx_s { + u64 trpend : 64; + } s; + /* struct rvu_pf_vftrpendx_s cn; */ +}; + +static inline u64 RVU_PF_VFTRPENDX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFTRPENDX(u64 a) +{ + return 0x820 + 8 * a; +} + +/** + * Register (RVU_PF_BAR2) rvu_pf_vftrpend_w1s# + * + * RVU PF VF Transaction Pending Set Registers This register reads or + * sets bits. + */ +union rvu_pf_vftrpend_w1sx { + u64 u; + struct rvu_pf_vftrpend_w1sx_s { + u64 trpend : 64; + } s; + /* struct rvu_pf_vftrpend_w1sx_s cn; */ +}; + +static inline u64 RVU_PF_VFTRPEND_W1SX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PF_VFTRPEND_W1SX(u64 a) +{ + return 0x840 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_active_pc + * + * RVU Active Program Counter Register + */ +union rvu_priv_active_pc { + u64 u; + struct rvu_priv_active_pc_s { + u64 active_pc : 64; + } s; + /* struct rvu_priv_active_pc_s cn; */ +}; + +static inline u64 RVU_PRIV_ACTIVE_PC(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_ACTIVE_PC(void) +{ + return 0x8000030; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_block_type#_rev + * + * RVU Privileged Block Type Revision Registers These registers are used + * by configuration software to specify the revision ID of each block + * type enumerated by RVU_BLOCK_TYPE_E, to assist VF/PF software + * discovery. + */ +union rvu_priv_block_typex_rev { + u64 u; + struct rvu_priv_block_typex_rev_s { + u64 rid : 8; + u64 reserved_8_63 : 56; + } s; + /* struct rvu_priv_block_typex_rev_s cn; */ +}; + +static inline u64 RVU_PRIV_BLOCK_TYPEX_REV(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_BLOCK_TYPEX_REV(u64 a) +{ + return 0x8000400 + 8 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_clk_cfg + * + * RVU Privileged General Configuration Register + */ +union rvu_priv_clk_cfg { + u64 u; + struct rvu_priv_clk_cfg_s { + u64 blk_clken : 1; + u64 ncbi_clken : 1; + u64 reserved_2_63 : 62; + } s; + /* struct rvu_priv_clk_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_CLK_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_CLK_CFG(void) +{ + return 0x8000020; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_const + * + * RVU Privileged Constants Register This register contains constants for + * software discovery. + */ +union rvu_priv_const { + u64 u; + struct rvu_priv_const_s { + u64 max_msix : 20; + u64 hwvfs : 12; + u64 pfs : 8; + u64 max_vfs_per_pf : 8; + u64 reserved_48_63 : 16; + } s; + /* struct rvu_priv_const_s cn; */ +}; + +static inline u64 RVU_PRIV_CONST(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_CONST(void) +{ + return 0x8000000; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_gen_cfg + * + * RVU Privileged General Configuration Register + */ +union rvu_priv_gen_cfg { + u64 u; + struct rvu_priv_gen_cfg_s { + u64 lock : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_priv_gen_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_GEN_CFG(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_GEN_CFG(void) +{ + return 0x8000010; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_hwvf#_cpt#_cfg + * + * RVU Privileged Hardware VF CPT Configuration Registers Similar to + * RVU_PRIV_HWVF()_NIX()_CFG, but for CPT({a}) block. + */ +union rvu_priv_hwvfx_cptx_cfg { + u64 u; + struct rvu_priv_hwvfx_cptx_cfg_s { + u64 num_lfs : 9; + u64 reserved_9_63 : 55; + } s; + /* struct rvu_priv_hwvfx_cptx_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_HWVFX_CPTX_CFG(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_HWVFX_CPTX_CFG(u64 a, u64 b) +{ + return 0x8001350 + 0x10000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_hwvf#_int_cfg + * + * RVU Privileged Hardware VF Interrupt Configuration Registers + */ +union rvu_priv_hwvfx_int_cfg { + u64 u; + struct rvu_priv_hwvfx_int_cfg_s { + u64 msix_offset : 11; + u64 reserved_11 : 1; + u64 msix_size : 8; + u64 reserved_20_63 : 44; + } s; + /* struct rvu_priv_hwvfx_int_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_HWVFX_INT_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_HWVFX_INT_CFG(u64 a) +{ + return 0x8001280 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_hwvf#_nix#_cfg + * + * RVU Privileged Hardware VF NIX Configuration Registers These registers + * are used to assist VF software discovery. For each HWVF, if the HWVF + * is mapped to a VF by RVU_PRIV_PF()_CFG[FIRST_HWVF,NVF], software + * writes NIX block's resource configuration for the VF in this register. + * The VF driver can read RVU_VF_BLOCK_ADDR()_DISC to discover the + * configuration. + */ +union rvu_priv_hwvfx_nixx_cfg { + u64 u; + struct rvu_priv_hwvfx_nixx_cfg_s { + u64 has_lf : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_priv_hwvfx_nixx_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_HWVFX_NIXX_CFG(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_HWVFX_NIXX_CFG(u64 a, u64 b) +{ + return 0x8001300 + 0x10000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_hwvf#_npa_cfg + * + * RVU Privileged Hardware VF NPA Configuration Registers Similar to + * RVU_PRIV_HWVF()_NIX()_CFG, but for NPA block. + */ +union rvu_priv_hwvfx_npa_cfg { + u64 u; + struct rvu_priv_hwvfx_npa_cfg_s { + u64 has_lf : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_priv_hwvfx_npa_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_HWVFX_NPA_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_HWVFX_NPA_CFG(u64 a) +{ + return 0x8001310 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_hwvf#_sso_cfg + * + * RVU Privileged Hardware VF SSO Configuration Registers Similar to + * RVU_PRIV_HWVF()_NIX()_CFG, but for SSO block. + */ +union rvu_priv_hwvfx_sso_cfg { + u64 u; + struct rvu_priv_hwvfx_sso_cfg_s { + u64 num_lfs : 9; + u64 reserved_9_63 : 55; + } s; + /* struct rvu_priv_hwvfx_sso_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_HWVFX_SSO_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_HWVFX_SSO_CFG(u64 a) +{ + return 0x8001320 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_hwvf#_ssow_cfg + * + * RVU Privileged Hardware VF SSO Work Slot Configuration Registers + * Similar to RVU_PRIV_HWVF()_NIX()_CFG, but for SSOW block. + */ +union rvu_priv_hwvfx_ssow_cfg { + u64 u; + struct rvu_priv_hwvfx_ssow_cfg_s { + u64 num_lfs : 9; + u64 reserved_9_63 : 55; + } s; + /* struct rvu_priv_hwvfx_ssow_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_HWVFX_SSOW_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_HWVFX_SSOW_CFG(u64 a) +{ + return 0x8001330 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_hwvf#_tim_cfg + * + * RVU Privileged Hardware VF SSO Work Slot Configuration Registers + * Similar to RVU_PRIV_HWVF()_NIX()_CFG, but for TIM block. + */ +union rvu_priv_hwvfx_tim_cfg { + u64 u; + struct rvu_priv_hwvfx_tim_cfg_s { + u64 num_lfs : 9; + u64 reserved_9_63 : 55; + } s; + /* struct rvu_priv_hwvfx_tim_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_HWVFX_TIM_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_HWVFX_TIM_CFG(u64 a) +{ + return 0x8001340 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_pf#_cfg + * + * RVU Privileged PF Configuration Registers + */ +union rvu_priv_pfx_cfg { + u64 u; + struct rvu_priv_pfx_cfg_s { + u64 first_hwvf : 12; + u64 nvf : 8; + u64 ena : 1; + u64 af_ena : 1; + u64 me_flr_ena : 1; + u64 pf_vf_io_bar4 : 1; + u64 reserved_24_63 : 40; + } s; + struct rvu_priv_pfx_cfg_cn96xxp1 { + u64 first_hwvf : 12; + u64 nvf : 8; + u64 ena : 1; + u64 af_ena : 1; + u64 me_flr_ena : 1; + u64 reserved_23_63 : 41; + } cn96xxp1; + /* struct rvu_priv_pfx_cfg_s cn96xxp3; */ + /* struct rvu_priv_pfx_cfg_cn96xxp1 cnf95xx; */ +}; + +static inline u64 RVU_PRIV_PFX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_PFX_CFG(u64 a) +{ + return 0x8000100 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_pf#_cpt#_cfg + * + * RVU Privileged PF CPT Configuration Registers Similar to + * RVU_PRIV_PF()_NIX()_CFG, but for CPT({a}) block. + */ +union rvu_priv_pfx_cptx_cfg { + u64 u; + struct rvu_priv_pfx_cptx_cfg_s { + u64 num_lfs : 9; + u64 reserved_9_63 : 55; + } s; + /* struct rvu_priv_pfx_cptx_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_PFX_CPTX_CFG(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_PFX_CPTX_CFG(u64 a, u64 b) +{ + return 0x8000350 + 0x10000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_pf#_id_cfg + * + * RVU Privileged PF ID Configuration Registers + */ +union rvu_priv_pfx_id_cfg { + u64 u; + struct rvu_priv_pfx_id_cfg_s { + u64 pf_devid : 8; + u64 vf_devid : 8; + u64 class_code : 24; + u64 reserved_40_63 : 24; + } s; + /* struct rvu_priv_pfx_id_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_PFX_ID_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_PFX_ID_CFG(u64 a) +{ + return 0x8000120 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_pf#_int_cfg + * + * RVU Privileged PF Interrupt Configuration Registers + */ +union rvu_priv_pfx_int_cfg { + u64 u; + struct rvu_priv_pfx_int_cfg_s { + u64 msix_offset : 11; + u64 reserved_11 : 1; + u64 msix_size : 8; + u64 reserved_20_63 : 44; + } s; + /* struct rvu_priv_pfx_int_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_PFX_INT_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_PFX_INT_CFG(u64 a) +{ + return 0x8000200 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_pf#_msix_cfg + * + * RVU Privileged PF MSI-X Configuration Registers These registers + * specify MSI-X table sizes and locations for RVU PFs and associated + * VFs. Hardware maintains all RVU MSI-X tables in a contiguous memory + * region in LLC/DRAM called the MSI-X table region. The table region's + * base AF IOVA is specified by RVU_AF_MSIXTR_BASE, and its size as a + * multiple of 16-byte RVU_MSIX_VEC_S structures must be less than or + * equal to RVU_PRIV_CONST[MAX_MSIX]. A PF's MSI-X table consists of the + * following range of RVU_MSIX_VEC_S structures in the table region: * + * First index: [PF_MSIXT_OFFSET]. * Last index: [PF_MSIXT_OFFSET] + + * [PF_MSIXT_SIZEM1]. If a PF has enabled VFs (associated + * RVU_PRIV_PF()_CFG[NVF] is nonzero), then each VF's MSI-X table + * consumes the following range of RVU_MSIX_VEC_S structures: * First + * index: [VF_MSIXT_OFFSET] + N*([VF_MSIXT_SIZEM1] + 1). * Last index: + * [VF_MSIXT_OFFSET] + N*([VF_MSIXT_SIZEM1] + 1) + [VF_MSIXT_SIZEM1]. + * N=0 for the first VF, N=1 for the second VF, etc. Different PFs and + * VFs must have non-overlapping vector ranges, and the last index of any + * range must be less than RVU_PRIV_CONST[MAX_MSIX]. + */ +union rvu_priv_pfx_msix_cfg { + u64 u; + struct rvu_priv_pfx_msix_cfg_s { + u64 vf_msixt_sizem1 : 12; + u64 vf_msixt_offset : 20; + u64 pf_msixt_sizem1 : 12; + u64 pf_msixt_offset : 20; + } s; + /* struct rvu_priv_pfx_msix_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_PFX_MSIX_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_PFX_MSIX_CFG(u64 a) +{ + return 0x8000110 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_pf#_nix#_cfg + * + * RVU Privileged PF NIX Configuration Registers These registers are used + * to assist PF software discovery. For each enabled RVU PF, software + * writes the block's resource configuration for the PF in this register. + * The PF driver can read RVU_PF_BLOCK_ADDR()_DISC to discover the + * configuration. + */ +union rvu_priv_pfx_nixx_cfg { + u64 u; + struct rvu_priv_pfx_nixx_cfg_s { + u64 has_lf : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_priv_pfx_nixx_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_PFX_NIXX_CFG(u64 a, u64 b) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_PFX_NIXX_CFG(u64 a, u64 b) +{ + return 0x8000300 + 0x10000 * a + 8 * b; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_pf#_npa_cfg + * + * RVU Privileged PF NPA Configuration Registers Similar to + * RVU_PRIV_PF()_NIX()_CFG, but for NPA block. + */ +union rvu_priv_pfx_npa_cfg { + u64 u; + struct rvu_priv_pfx_npa_cfg_s { + u64 has_lf : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_priv_pfx_npa_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_PFX_NPA_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_PFX_NPA_CFG(u64 a) +{ + return 0x8000310 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_pf#_sso_cfg + * + * RVU Privileged PF SSO Configuration Registers Similar to + * RVU_PRIV_PF()_NIX()_CFG, but for SSO block. + */ +union rvu_priv_pfx_sso_cfg { + u64 u; + struct rvu_priv_pfx_sso_cfg_s { + u64 num_lfs : 9; + u64 reserved_9_63 : 55; + } s; + /* struct rvu_priv_pfx_sso_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_PFX_SSO_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_PFX_SSO_CFG(u64 a) +{ + return 0x8000320 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_pf#_ssow_cfg + * + * RVU Privileged PF SSO Work Slot Configuration Registers Similar to + * RVU_PRIV_PF()_NIX()_CFG, but for SSOW block. + */ +union rvu_priv_pfx_ssow_cfg { + u64 u; + struct rvu_priv_pfx_ssow_cfg_s { + u64 num_lfs : 9; + u64 reserved_9_63 : 55; + } s; + /* struct rvu_priv_pfx_ssow_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_PFX_SSOW_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_PFX_SSOW_CFG(u64 a) +{ + return 0x8000330 + 0x10000 * a; +} + +/** + * Register (RVU_PF_BAR0) rvu_priv_pf#_tim_cfg + * + * RVU Privileged PF SSO Work Slot Configuration Registers Similar to + * RVU_PRIV_PF()_NIX()_CFG, but for TIM block. + */ +union rvu_priv_pfx_tim_cfg { + u64 u; + struct rvu_priv_pfx_tim_cfg_s { + u64 num_lfs : 9; + u64 reserved_9_63 : 55; + } s; + /* struct rvu_priv_pfx_tim_cfg_s cn; */ +}; + +static inline u64 RVU_PRIV_PFX_TIM_CFG(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_PRIV_PFX_TIM_CFG(u64 a) +{ + return 0x8000340 + 0x10000 * a; +} + +/** + * Register (RVU_VF_BAR2) rvu_vf_block_addr#_disc + * + * RVU VF Block Address Discovery Registers These registers allow each VF + * driver to discover block resources that are provisioned to its VF. The + * register's BLOCK_ADDR index is enumerated by RVU_BLOCK_ADDR_E. + */ +union rvu_vf_block_addrx_disc { + u64 u; + struct rvu_vf_block_addrx_disc_s { + u64 num_lfs : 9; + u64 reserved_9_10 : 2; + u64 imp : 1; + u64 rid : 8; + u64 btype : 8; + u64 reserved_28_63 : 36; + } s; + /* struct rvu_vf_block_addrx_disc_s cn; */ +}; + +static inline u64 RVU_VF_BLOCK_ADDRX_DISC(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_VF_BLOCK_ADDRX_DISC(u64 a) +{ + return 0x200 + 8 * a; +} + +/** + * Register (RVU_VF_BAR2) rvu_vf_int + * + * RVU VF Interrupt Registers + */ +union rvu_vf_int { + u64 u; + struct rvu_vf_int_s { + u64 mbox : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_vf_int_s cn; */ +}; + +static inline u64 RVU_VF_INT(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_VF_INT(void) +{ + return 0x20; +} + +/** + * Register (RVU_VF_BAR2) rvu_vf_int_ena_w1c + * + * RVU VF Interrupt Enable Clear Register This register clears interrupt + * enable bits. + */ +union rvu_vf_int_ena_w1c { + u64 u; + struct rvu_vf_int_ena_w1c_s { + u64 mbox : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_vf_int_ena_w1c_s cn; */ +}; + +static inline u64 RVU_VF_INT_ENA_W1C(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_VF_INT_ENA_W1C(void) +{ + return 0x38; +} + +/** + * Register (RVU_VF_BAR2) rvu_vf_int_ena_w1s + * + * RVU VF Interrupt Enable Set Register This register sets interrupt + * enable bits. + */ +union rvu_vf_int_ena_w1s { + u64 u; + struct rvu_vf_int_ena_w1s_s { + u64 mbox : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_vf_int_ena_w1s_s cn; */ +}; + +static inline u64 RVU_VF_INT_ENA_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_VF_INT_ENA_W1S(void) +{ + return 0x30; +} + +/** + * Register (RVU_VF_BAR2) rvu_vf_int_w1s + * + * RVU VF Interrupt Set Register This register sets interrupt bits. + */ +union rvu_vf_int_w1s { + u64 u; + struct rvu_vf_int_w1s_s { + u64 mbox : 1; + u64 reserved_1_63 : 63; + } s; + /* struct rvu_vf_int_w1s_s cn; */ +}; + +static inline u64 RVU_VF_INT_W1S(void) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_VF_INT_W1S(void) +{ + return 0x28; +} + +/** + * Register (RVU_VF_BAR2) rvu_vf_msix_pba# + * + * RVU VF MSI-X Pending-Bit-Array Registers This register is the MSI-X VF + * PBA table. + */ +union rvu_vf_msix_pbax { + u64 u; + struct rvu_vf_msix_pbax_s { + u64 pend : 64; + } s; + /* struct rvu_vf_msix_pbax_s cn; */ +}; + +static inline u64 RVU_VF_MSIX_PBAX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_VF_MSIX_PBAX(u64 a) +{ + return 0xf0000 + 8 * a; +} + +/** + * Register (RVU_VF_BAR2) rvu_vf_msix_vec#_addr + * + * RVU VF MSI-X Vector-Table Address Registers These registers and + * RVU_VF_MSIX_VEC()_CTL form the VF MSI-X vector table. The number of + * MSI-X vectors for a given VF is specified by + * RVU_PRIV_PF()_MSIX_CFG[VF_MSIXT_SIZEM1] (plus 1). Software must do a + * read after any writes to the MSI-X vector table to ensure that the + * writes have completed before interrupts are generated to the modified + * vectors. + */ +union rvu_vf_msix_vecx_addr { + u64 u; + struct rvu_vf_msix_vecx_addr_s { + u64 secvec : 1; + u64 reserved_1 : 1; + u64 addr : 51; + u64 reserved_53_63 : 11; + } s; + /* struct rvu_vf_msix_vecx_addr_s cn; */ +}; + +static inline u64 RVU_VF_MSIX_VECX_ADDR(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_VF_MSIX_VECX_ADDR(u64 a) +{ + return 0x80000 + 0x10 * a; +} + +/** + * Register (RVU_VF_BAR2) rvu_vf_msix_vec#_ctl + * + * RVU VF MSI-X Vector-Table Control and Data Registers These registers + * and RVU_VF_MSIX_VEC()_ADDR form the VF MSI-X vector table. + */ +union rvu_vf_msix_vecx_ctl { + u64 u; + struct rvu_vf_msix_vecx_ctl_s { + u64 data : 32; + u64 mask : 1; + u64 reserved_33_63 : 31; + } s; + /* struct rvu_vf_msix_vecx_ctl_s cn; */ +}; + +static inline u64 RVU_VF_MSIX_VECX_CTL(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_VF_MSIX_VECX_CTL(u64 a) +{ + return 0x80008 + 0x10 * a; +} + +/** + * Register (RVU_VF_BAR2) rvu_vf_vfpf_mbox# + * + * RVU VF/PF Mailbox Registers + */ +union rvu_vf_vfpf_mboxx { + u64 u; + struct rvu_vf_vfpf_mboxx_s { + u64 data : 64; + } s; + /* struct rvu_vf_vfpf_mboxx_s cn; */ +}; + +static inline u64 RVU_VF_VFPF_MBOXX(u64 a) + __attribute__ ((pure, always_inline)); +static inline u64 RVU_VF_VFPF_MBOXX(u64 a) +{ + return 0 + 8 * a; +} + +#endif /* __CSRS_RVU_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx2/gpio.h b/arch/arm/include/asm/arch-octeontx2/gpio.h new file mode 100644 index 0000000000..3943ffd952 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/gpio.h @@ -0,0 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ diff --git a/arch/arm/include/asm/arch-octeontx2/smc-id.h b/arch/arm/include/asm/arch-octeontx2/smc-id.h new file mode 100644 index 0000000000..93a81b2954 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/smc-id.h @@ -0,0 +1,32 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __SMC_ID_H__ +#define __SMC_ID_H__ + +/* SMC function IDs for general purpose queries */ + +#define OCTEONTX2_SVC_CALL_COUNT 0xc200ff00 +#define OCTEONTX2_SVC_UID 0xc200ff01 + +#define OCTEONTX2_SVC_VERSION 0xc200ff03 + +/* OcteonTX Service Calls version numbers */ +#define OCTEONTX2_VERSION_MAJOR 0x1 +#define OCTEONTX2_VERSION_MINOR 0x0 + +/* x1 - node number */ +#define OCTEONTX2_DRAM_SIZE 0xc2000301 +#define OCTEONTX2_NODE_COUNT 0xc2000601 +#define OCTEONTX2_DISABLE_RVU_LFS 0xc2000b01 + +#define OCTEONTX2_CONFIG_OOO 0xc2000b04 + +/* fail safe */ +#define OCTEONTX2_FSAFE_PR_BOOT_SUCCESS 0xc2000b02 + +#endif /* __SMC_ID_H__ */ diff --git a/arch/arm/include/asm/arch-octeontx2/smc.h b/arch/arm/include/asm/arch-octeontx2/smc.h new file mode 100644 index 0000000000..8e719a2aad --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/smc.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __SMC_H__ +#define __SMC_H__ + +#include <asm/arch/smc-id.h> + +ssize_t smc_configure_ooo(unsigned int val); +ssize_t smc_dram_size(unsigned int node); +ssize_t smc_disable_rvu_lfs(unsigned int node); +ssize_t smc_flsf_fw_booted(void); + +#endif diff --git a/arch/arm/include/asm/arch-octeontx2/soc.h b/arch/arm/include/asm/arch-octeontx2/soc.h new file mode 100644 index 0000000000..9cf6628da4 --- /dev/null +++ b/arch/arm/include/asm/arch-octeontx2/soc.h @@ -0,0 +1,33 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2019 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __SOC_H__ +#define __SOC_H__ + +/* Product PARTNUM */ +#define CN81XX 0xA2 +#define CN83XX 0xA3 +#define CN96XX 0xB2 +#define CN95XX 0xB3 + +/* Register defines */ + +#define otx_is_soc(soc) (read_partnum() == (soc)) +#define otx_is_board(model) (!strcmp(read_board_name(), model)) +#define otx_is_platform(platform) (read_platform() == (platform)) + +enum platform_t { + PLATFORM_HW = 0, + PLATFORM_EMULATOR = 1, + PLATFORM_ASIM = 3, +}; + +int read_platform(void); +u8 read_partnum(void); +const char *read_board_name(void); + +#endif /* __SOC_H */
For SATA controller found on OcteonTX SoC's, use non-standard PCI BAR0 instead of BAR5.
Signed-off-by: Suneel Garapati sgarapati@marvell.com Reviewed-by: Simon Glass sjg@chromium.org
Signed-off-by: Stefan Roese sr@denx.de ---
Changes in v2: - Add Reviewed-by tag from Simon - Add note about adding a Kconfig option for AHCI quirks, once there are multiple quirks
Changes in v1: - Change patch subject - Use constants from pci_ids.h instead of hardcoded values
drivers/ata/ahci.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/ata/ahci.c b/drivers/ata/ahci.c index 47cdea1f58..22bc0d3b10 100644 --- a/drivers/ata/ahci.c +++ b/drivers/ata/ahci.c @@ -1198,10 +1198,25 @@ int ahci_probe_scsi(struct udevice *ahci_dev, ulong base) int ahci_probe_scsi_pci(struct udevice *ahci_dev) { ulong base; + u16 vendor, device;
base = (ulong)dm_pci_map_bar(ahci_dev, PCI_BASE_ADDRESS_5, PCI_REGION_MEM);
+ /* + * Note: + * Right now, we have only one quirk here, which is not enough to + * introduce a new Kconfig option to select this. Once we have more + * quirks in this AHCI code, we should add a Kconfig option for + * this though. + */ + dm_pci_read_config16(ahci_dev, PCI_VENDOR_ID, &vendor); + dm_pci_read_config16(ahci_dev, PCI_DEVICE_ID, &device); + + if (vendor == PCI_VENDOR_ID_CAVIUM && + device == PCI_DEVICE_ID_CAVIUM_SATA) + base = (uintptr_t)dm_pci_map_bar(ahci_dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); return ahci_probe_scsi(ahci_dev, base); } #endif
Adds support for PCI ECAM/PEM controllers found on OcteonTX or OcteonTX2 SoC platforms.
Signed-off-by: Suneel Garapati sgarapati@marvell.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com
Changes in v2: - Add Reviewed-by tag from Simon - Add comments to enum declaration and "type" declaration - Return -EINVAL in default case statement for unsupported length - Add helper function octeontx_bdf_invalid() and return -EPERM in case of an errror - Use livetree API
Changes in v1: - Change patch subject - Remove inclusion of common.h - Remove #ifdef's and use driver specific data instead - Add comments to struct - Add some helper functions to reduce code size - Misc coding style changes (blank lines etc) - Use debug() instead of printf() in some cases
drivers/pci/Kconfig | 8 + drivers/pci/Makefile | 1 + drivers/pci/pci_octeontx.c | 364 +++++++++++++++++++++++++++++++++++++ 3 files changed, 373 insertions(+) create mode 100644 drivers/pci/pci_octeontx.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 377806f3b0..06d39df1d3 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -149,6 +149,14 @@ config PCI_TEGRA with a total of 5 lanes. Some boards require this for Ethernet support to work (e.g. beaver, jetson-tk1).
+config PCI_OCTEONTX + bool "OcteonTX PCI support" + depends on (ARCH_OCTEONTX || ARCH_OCTEONTX2) + help + Enable support for the OcteonTX/TX2 SoC family ECAM/PEM controllers. + These controllers provide PCI configuration access to all on-board + peripherals so it should only be disabled for testing purposes + config PCI_XILINX bool "Xilinx AXI Bridge for PCI Express" depends on DM_PCI diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 9db90fb53c..8b4d49a590 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -49,3 +49,4 @@ obj-$(CONFIG_PCI_KEYSTONE) += pcie_dw_ti.o obj-$(CONFIG_PCIE_MEDIATEK) += pcie_mediatek.o obj-$(CONFIG_PCIE_ROCKCHIP) += pcie_rockchip.o obj-$(CONFIG_PCI_BRCMSTB) += pcie_brcmstb.o +obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o diff --git a/drivers/pci/pci_octeontx.c b/drivers/pci/pci_octeontx.c new file mode 100644 index 0000000000..30537543a0 --- /dev/null +++ b/drivers/pci/pci_octeontx.c @@ -0,0 +1,364 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <log.h> +#include <malloc.h> +#include <pci.h> + +#include <asm/io.h> + +#include <linux/ioport.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * This driver supports multiple types of operations / host bridges / busses: + * + * OTX_ECAM: Octeon TX & TX2 ECAM (Enhanced Configuration Access Mechanism) + * Used to access the internal on-chip devices which are connected + * to internal buses + * OTX_PEM: Octeon TX PEM (PCI Express MAC) + * Used to access the external (off-chip) PCI devices + * OTX2_PEM: Octeon TX2 PEM (PCI Express MAC) + * Used to access the external (off-chip) PCI devices + */ +enum { + OTX_ECAM, + OTX_PEM, + OTX2_PEM, +}; + +/** + * struct octeontx_pci - Driver private data + * @type: Device type matched via compatible (e.g. OTX_ECAM etc) + * @cfg: Config resource + * @bus: Bus resource + */ +struct octeontx_pci { + unsigned int type; + + struct resource cfg; + struct resource bus; +}; + +static uintptr_t octeontx_cfg_addr(struct octeontx_pci *pcie, + int bus_offs, int shift_offs, + pci_dev_t bdf, uint offset) +{ + u32 bus, dev, func; + uintptr_t address; + + bus = PCI_BUS(bdf) + bus_offs; + dev = PCI_DEV(bdf); + func = PCI_FUNC(bdf); + + address = (bus << (20 + shift_offs)) | + (dev << (15 + shift_offs)) | + (func << (12 + shift_offs)) | offset; + address += pcie->cfg.start; + + return address; +} + +static ulong readl_size(uintptr_t addr, enum pci_size_t size) +{ + ulong val; + + switch (size) { + case PCI_SIZE_8: + val = readb(addr); + break; + case PCI_SIZE_16: + val = readw(addr); + break; + case PCI_SIZE_32: + val = readl(addr); + break; + default: + printf("Invalid size\n"); + return -EINVAL; + }; + + return val; +} + +static void writel_size(uintptr_t addr, enum pci_size_t size, ulong valuep) +{ + switch (size) { + case PCI_SIZE_8: + writeb(valuep, addr); + break; + case PCI_SIZE_16: + writew(valuep, addr); + break; + case PCI_SIZE_32: + writel(valuep, addr); + break; + default: + printf("Invalid size\n"); + }; +} + +static bool octeontx_bdf_invalid(pci_dev_t bdf) +{ + if (PCI_BUS(bdf) == 1 && PCI_DEV(bdf) > 0) + return true; + + return false; +} + +static int octeontx_ecam_read_config(const struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + struct octeontx_pci *pcie = (struct octeontx_pci *)dev_get_priv(bus); + struct pci_controller *hose = dev_get_uclass_priv(bus); + uintptr_t address; + + address = octeontx_cfg_addr(pcie, pcie->bus.start - hose->first_busno, + 0, bdf, offset); + *valuep = readl_size(address, size); + + debug("%02x.%02x.%02x: u%d %x -> %lx\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), size, offset, *valuep); + + return 0; +} + +static int octeontx_ecam_write_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + struct octeontx_pci *pcie = (struct octeontx_pci *)dev_get_priv(bus); + struct pci_controller *hose = dev_get_uclass_priv(bus); + uintptr_t address; + + address = octeontx_cfg_addr(pcie, pcie->bus.start - hose->first_busno, + 0, bdf, offset); + writel_size(address, size, value); + + debug("%02x.%02x.%02x: u%d %x <- %lx\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), size, offset, value); + + return 0; +} + +static int octeontx_pem_read_config(const struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + struct octeontx_pci *pcie = (struct octeontx_pci *)dev_get_priv(bus); + struct pci_controller *hose = dev_get_uclass_priv(bus); + uintptr_t address; + u8 hdrtype; + u8 pri_bus = pcie->bus.start + 1 - hose->first_busno; + u32 bus_offs = (pri_bus << 16) | (pri_bus << 8) | (pri_bus << 0); + + address = octeontx_cfg_addr(pcie, 1 - hose->first_busno, 4, + bdf, 0); + + *valuep = pci_conv_32_to_size(~0UL, offset, size); + + if (octeontx_bdf_invalid(bdf)) + return -EPERM; + + *valuep = readl_size(address + offset, size); + + hdrtype = readb(address + PCI_HEADER_TYPE); + if (hdrtype == PCI_HEADER_TYPE_BRIDGE && + offset >= PCI_PRIMARY_BUS && + offset <= PCI_SUBORDINATE_BUS && + *valuep != pci_conv_32_to_size(~0UL, offset, size)) + *valuep -= pci_conv_32_to_size(bus_offs, offset, size); + + return 0; +} + +static int octeontx_pem_write_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + struct octeontx_pci *pcie = (struct octeontx_pci *)dev_get_priv(bus); + struct pci_controller *hose = dev_get_uclass_priv(bus); + uintptr_t address; + u8 hdrtype; + u8 pri_bus = pcie->bus.start + 1 - hose->first_busno; + u32 bus_offs = (pri_bus << 16) | (pri_bus << 8) | (pri_bus << 0); + + address = octeontx_cfg_addr(pcie, 1 - hose->first_busno, 4, bdf, 0); + + hdrtype = readb(address + PCI_HEADER_TYPE); + if (hdrtype == PCI_HEADER_TYPE_BRIDGE && + offset >= PCI_PRIMARY_BUS && + offset <= PCI_SUBORDINATE_BUS && + value != pci_conv_32_to_size(~0UL, offset, size)) + value += pci_conv_32_to_size(bus_offs, offset, size); + + if (octeontx_bdf_invalid(bdf)) + return -EPERM; + + writel_size(address + offset, size, value); + + debug("%02x.%02x.%02x: u%d %x (%lx) <- %lx\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), size, offset, + address, value); + + return 0; +} + +static int octeontx2_pem_read_config(const struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + struct octeontx_pci *pcie = (struct octeontx_pci *)dev_get_priv(bus); + struct pci_controller *hose = dev_get_uclass_priv(bus); + uintptr_t address; + + address = octeontx_cfg_addr(pcie, 1 - hose->first_busno, 0, + bdf, 0); + + *valuep = pci_conv_32_to_size(~0UL, offset, size); + + if (octeontx_bdf_invalid(bdf)) + return -EPERM; + + *valuep = readl_size(address + offset, size); + + debug("%02x.%02x.%02x: u%d %x (%lx) -> %lx\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), size, offset, + address, *valuep); + + return 0; +} + +static int octeontx2_pem_write_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + struct octeontx_pci *pcie = (struct octeontx_pci *)dev_get_priv(bus); + struct pci_controller *hose = dev_get_uclass_priv(bus); + uintptr_t address; + + address = octeontx_cfg_addr(pcie, 1 - hose->first_busno, 0, + bdf, 0); + + if (octeontx_bdf_invalid(bdf)) + return -EPERM; + + writel_size(address + offset, size, value); + + debug("%02x.%02x.%02x: u%d %x (%lx) <- %lx\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), size, offset, + address, value); + + return 0; +} + +int pci_octeontx_read_config(const struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + struct octeontx_pci *pcie = (struct octeontx_pci *)dev_get_priv(bus); + int ret = -EIO; + + switch (pcie->type) { + case OTX_ECAM: + ret = octeontx_ecam_read_config(bus, bdf, offset, valuep, + size); + break; + case OTX_PEM: + ret = octeontx_pem_read_config(bus, bdf, offset, valuep, + size); + break; + case OTX2_PEM: + ret = octeontx2_pem_read_config(bus, bdf, offset, valuep, + size); + break; + } + + return ret; +} + +int pci_octeontx_write_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + struct octeontx_pci *pcie = (struct octeontx_pci *)dev_get_priv(bus); + int ret = -EIO; + + switch (pcie->type) { + case OTX_ECAM: + ret = octeontx_ecam_write_config(bus, bdf, offset, value, + size); + break; + case OTX_PEM: + ret = octeontx_pem_write_config(bus, bdf, offset, value, + size); + break; + case OTX2_PEM: + ret = octeontx2_pem_write_config(bus, bdf, offset, value, + size); + break; + } + + return ret; +} + +static int pci_octeontx_ofdata_to_platdata(struct udevice *dev) +{ + return 0; +} + +static int pci_octeontx_probe(struct udevice *dev) +{ + struct octeontx_pci *pcie = (struct octeontx_pci *)dev_get_priv(dev); + int err; + + pcie->type = dev_get_driver_data(dev); + + err = dev_read_resource(dev, 0, &pcie->cfg); + if (err) { + debug("Error reading resource: %s\n", fdt_strerror(err)); + return err; + } + + err = dev_read_pci_bus_range(dev, &pcie->bus); + if (err) { + debug("Error reading resource: %s\n", fdt_strerror(err)); + return err; + } + + return 0; +} + +static const struct dm_pci_ops pci_octeontx_ops = { + .read_config = pci_octeontx_read_config, + .write_config = pci_octeontx_write_config, +}; + +static const struct udevice_id pci_octeontx_ids[] = { + { .compatible = "cavium,pci-host-thunder-ecam", .data = OTX_ECAM }, + { .compatible = "cavium,pci-host-octeontx-ecam", .data = OTX_ECAM }, + { .compatible = "pci-host-ecam-generic", .data = OTX_ECAM }, + { .compatible = "cavium,pci-host-thunder-pem", .data = OTX_PEM }, + { .compatible = "marvell,pci-host-octeontx2-pem", .data = OTX2_PEM }, + { } +}; + +U_BOOT_DRIVER(pci_octeontx) = { + .name = "pci_octeontx", + .id = UCLASS_PCI, + .of_match = pci_octeontx_ids, + .ops = &pci_octeontx_ops, + .ofdata_to_platdata = pci_octeontx_ofdata_to_platdata, + .probe = pci_octeontx_probe, + .priv_auto_alloc_size = sizeof(struct octeontx_pci), + .flags = DM_FLAG_PRE_RELOC, +};
Adds support for MMC controllers found on OcteonTX or OcteonTX2 SoC platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Suneel Garapati sgarapati@marvell.com Cc: Peng Fan peng.fan@nxp.com
Changes in v2: - Remove local mmc_power_init() call
Changes in v1: - Change patch subject - Rebased on latest TOT - Removed inclusion of common.h - Fix most checkpatch errors / warnings (use IS_ENABLED etc)
drivers/mmc/Kconfig | 9 + drivers/mmc/Makefile | 1 + drivers/mmc/octeontx_hsmmc.c | 3897 ++++++++++++++++++++++++++++++++++ drivers/mmc/octeontx_hsmmc.h | 207 ++ 4 files changed, 4114 insertions(+) create mode 100644 drivers/mmc/octeontx_hsmmc.c create mode 100644 drivers/mmc/octeontx_hsmmc.h
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 556b3ac489..669e40d7b2 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -305,6 +305,15 @@ config MMC_PCI This selects PCI-based MMC controllers. If you have an MMC controller on a PCI bus, say Y here.
+config MMC_OCTEONTX + bool "Marvell OcteonTX Multimedia Card Interface support" + depends on (ARCH_OCTEONTX || ARCH_OCTEONTX2) + depends on DM_MMC + help + This selects the OcteonTX Multimedia card Interface. + If you have an OcteonTX/TX2 board with a Multimedia Card slot, + say Y here. + If unsure, say N.
config PXA_MMC_GENERIC diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index d375669a7b..22266ec8ec 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -36,6 +36,7 @@ obj-$(CONFIG_MVEBU_MMC) += mvebu_mmc.o obj-$(CONFIG_MMC_OMAP_HS) += omap_hsmmc.o obj-$(CONFIG_MMC_MXC) += mxcmmc.o obj-$(CONFIG_MMC_MXS) += mxsmmc.o +obj-$(CONFIG_MMC_OCTEONTX) += octeontx_hsmmc.o obj-$(CONFIG_MMC_PCI) += pci_mmc.o obj-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o obj-$(CONFIG_$(SPL_TPL_)SUPPORT_EMMC_RPMB) += rpmb.o diff --git a/drivers/mmc/octeontx_hsmmc.c b/drivers/mmc/octeontx_hsmmc.c new file mode 100644 index 0000000000..ddc36694e1 --- /dev/null +++ b/drivers/mmc/octeontx_hsmmc.c @@ -0,0 +1,3897 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +//#define DEBUG +#include <cpu_func.h> +#include <dm.h> +#include <dm/lists.h> +#include <env.h> +#include <errno.h> +#include <fdtdec.h> +#include <log.h> +#include <malloc.h> +#include <memalign.h> +#include <mmc.h> +#include <part.h> +#include <pci.h> +#include <pci_ids.h> +#include <time.h> +#include <watchdog.h> + +#include <linux/delay.h> +#include <linux/kernel.h> +#include <linux/libfdt.h> + +#include <asm/arch/board.h> +#include <asm/arch/clock.h> +#include <asm/arch/csrs/csrs-mio_emm.h> +#include <asm/io.h> + +#include <power/regulator.h> + +#include "octeontx_hsmmc.h" + +#define MMC_TIMEOUT_SHORT 20 /* in ms */ +#define MMC_TIMEOUT_LONG 1000 +#define MMC_TIMEOUT_ERASE 10000 + +#define MMC_DEFAULT_DATA_IN_TAP 10 +#define MMC_DEFAULT_CMD_IN_TAP 10 +#define MMC_DEFAULT_CMD_OUT_TAP 39 +#define MMC_DEFAULT_DATA_OUT_TAP 39 +#define MMC_DEFAULT_HS200_CMD_IN_TAP 24 +#define MMC_DEFAULT_HS200_DATA_IN_TAP 24 +#define MMC_DEFAULT_HS200_CMD_OUT_TAP (otx_is_soc(CN95XX) ? 10 : 5) +#define MMC_DEFAULT_HS200_DATA_OUT_TAP (otx_is_soc(CN95XX) ? 10 : 5) +#define MMC_DEFAULT_HS400_CMD_OUT_TAP (otx_is_soc(CN95XX) ? 10 : 5) +#define MMC_DEFAULT_HS400_DATA_OUT_TAP (otx_is_soc(CN95XX) ? 5 : 3) +#define MMC_DEFAULT_HS200_CMD_OUT_DLY 800 /* Delay in ps */ +#define MMC_DEFAULT_HS200_DATA_OUT_DLY 800 /* Delay in ps */ +#define MMC_DEFAULT_HS400_CMD_OUT_DLY 800 /* Delay in ps */ +#define MMC_DEFAULT_HS400_DATA_OUT_DLY 400 /* Delay in ps */ +#define MMC_DEFAULT_SD_UHS_SDR104_CMD_OUT_TAP MMC_DEFAULT_HS200_CMD_OUT_TAP +#define MMC_DEFAULT_SD_UHS_SDR104_DATA_OUT_TAP MMC_DEFAULT_HS200_DATA_OUT_TAP +#define MMC_LEGACY_DEFAULT_CMD_OUT_TAP 39 +#define MMC_LEGACY_DEFAULT_DATA_OUT_TAP 39 +#define MMC_SD_LEGACY_DEFAULT_CMD_OUT_TAP 63 +#define MMC_SD_LEGACY_DEFAULT_DATA_OUT_TAP 63 +#define MMC_HS_CMD_OUT_TAP 32 +#define MMC_HS_DATA_OUT_TAP 32 +#define MMC_SD_HS_CMD_OUT_TAP 26 +#define MMC_SD_HS_DATA_OUT_TAP 26 +#define MMC_SD_UHS_SDR25_CMD_OUT_TAP 26 +#define MMC_SD_UHS_SDR25_DATA_OUT_TAP 26 +#define MMC_SD_UHS_SDR50_CMD_OUT_TAP 26 +#define MMC_SD_UHS_SDR50_DATA_OUT_TAP 26 +#define MMC_DEFAULT_TAP_DELAY 4 +#define TOTAL_NO_OF_TAPS 512 +static void octeontx_mmc_switch_to(struct mmc *mmc); +static int octeontx_mmc_configure_delay(struct mmc *mmc); +static void octeontx_mmc_set_timing(struct mmc *mmc); +static void set_wdog(struct mmc *mmc, u64 us); +static void do_switch(struct mmc *mmc, union mio_emm_switch emm_switch); +static int octeontx_mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data); +static int octeontx2_mmc_calc_delay(struct mmc *mmc, int delay); +static int octeontx_mmc_calibrate_delay(struct mmc *mmc); +static int octeontx_mmc_set_input_bus_timing(struct mmc *mmc); +static int octeontx_mmc_set_output_bus_timing(struct mmc *mmc); + +static bool host_probed; + +/** + * Get the slot data structure from a MMC data structure + */ +static inline struct octeontx_mmc_slot *mmc_to_slot(struct mmc *mmc) +{ + return container_of(mmc, struct octeontx_mmc_slot, mmc); +} + +static inline struct octeontx_mmc_host *mmc_to_host(struct mmc *mmc) +{ + return mmc_to_slot(mmc)->host; +} + +static inline struct octeontx_mmc_slot *dev_to_mmc_slot(struct udevice *dev) +{ + return dev_get_priv(dev); +} + +static inline struct mmc *dev_to_mmc(struct udevice *dev) +{ + return &((struct octeontx_mmc_slot *)dev_get_priv(dev))->mmc; +} + +#ifdef DEBUG +const char *mmc_reg_str(u64 reg) +{ + if (reg == MIO_EMM_DMA_CFG()) + return "MIO_EMM_DMA_CFG"; + if (reg == MIO_EMM_DMA_ADR()) + return "MIO_EMM_DMA_ADR"; + if (reg == MIO_EMM_DMA_INT()) + return "MIO_EMM_DMA_INT"; + if (reg == MIO_EMM_CFG()) + return "MIO_EMM_CFG"; + if (reg == MIO_EMM_MODEX(0)) + return "MIO_EMM_MODE0"; + if (reg == MIO_EMM_MODEX(1)) + return "MIO_EMM_MODE1"; + if (reg == MIO_EMM_MODEX(2)) + return "MIO_EMM_MODE2"; + if (reg == MIO_EMM_MODEX(3)) + return "MIO_EMM_MODE3"; + if (reg == MIO_EMM_IO_CTL()) + return "MIO_EMM_IO_CTL"; + if (reg == MIO_EMM_SWITCH()) + return "MIO_EMM_SWITCH"; + if (reg == MIO_EMM_DMA()) + return "MIO_EMM_DMA"; + if (reg == MIO_EMM_CMD()) + return "MIO_EMM_CMD"; + if (reg == MIO_EMM_RSP_STS()) + return "MIO_EMM_RSP_STS"; + if (reg == MIO_EMM_RSP_LO()) + return "MIO_EMM_RSP_LO"; + if (reg == MIO_EMM_RSP_HI()) + return "MIO_EMM_RSP_HI"; + if (reg == MIO_EMM_INT()) + return "MIO_EMM_INT"; + if (reg == MIO_EMM_WDOG()) + return "MIO_EMM_WDOG"; + if (reg == MIO_EMM_DMA_ARG()) + return "MIO_EMM_DMA_ARG"; + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { + if (reg == MIO_EMM_SAMPLE()) + return "MIO_EMM_SAMPLE"; + } + if (reg == MIO_EMM_STS_MASK()) + return "MIO_EMM_STS_MASK"; + if (reg == MIO_EMM_RCA()) + return "MIO_EMM_RCA"; + if (reg == MIO_EMM_BUF_IDX()) + return "MIO_EMM_BUF_IDX"; + if (reg == MIO_EMM_BUF_DAT()) + return "MIO_EMM_BUF_DAT"; + if (!IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { + if (reg == MIO_EMM_CALB()) + return "MIO_EMM_CALB"; + if (reg == MIO_EMM_TAP()) + return "MIO_EMM_TAP"; + if (reg == MIO_EMM_TIMING()) + return "MIO_EMM_TIMING"; + if (reg == MIO_EMM_DEBUG()) + return "MIO_EMM_DEBUG"; + } + + return "UNKNOWN"; +} +#endif + +static void octeontx_print_rsp_sts(struct mmc *mmc) +{ +#ifdef DEBUG + union mio_emm_rsp_sts emm_rsp_sts; + const struct octeontx_mmc_host *host = mmc_to_host(mmc); + static const char * const ctype_xor_str[] = { + "No data", + "Read data into Dbuf", + "Write data from Dbuf", + "Reserved" + }; + + static const char * const rtype_xor_str[] = { + "No response", + "R1, 48 bits", + "R2, 136 bits", + "R3, 48 bits", + "R4, 48 bits", + "R5, 48 bits", + "Reserved 6", + "Reserved 7" + }; + + emm_rsp_sts.u = readq(host->base_addr + MIO_EMM_RSP_STS()); + printf("\nMIO_EMM_RSP_STS: 0x%016llx\n", emm_rsp_sts.u); + printf(" 60-61: bus_id: %u\n", emm_rsp_sts.s.bus_id); + printf(" 59: cmd_val: %s\n", + emm_rsp_sts.s.cmd_val ? "yes" : "no"); + printf(" 58: switch_val: %s\n", + emm_rsp_sts.s.switch_val ? "yes" : "no"); + printf(" 57: dma_val: %s\n", + emm_rsp_sts.s.dma_val ? "yes" : "no"); + printf(" 56: dma_pend: %s\n", + emm_rsp_sts.s.dma_pend ? "yes" : "no"); + printf(" 28: dbuf_err: %s\n", + emm_rsp_sts.s.dbuf_err ? "yes" : "no"); + printf(" 23: dbuf: %u\n", emm_rsp_sts.s.dbuf); + printf(" 22: blk_timeout: %s\n", + emm_rsp_sts.s.blk_timeout ? "yes" : "no"); + printf(" 21: blk_crc_err: %s\n", + emm_rsp_sts.s.blk_crc_err ? "yes" : "no"); + printf(" 20: rsp_busybit: %s\n", + emm_rsp_sts.s.rsp_busybit ? "yes" : "no"); + printf(" 19: stp_timeout: %s\n", + emm_rsp_sts.s.stp_timeout ? "yes" : "no"); + printf(" 18: stp_crc_err: %s\n", + emm_rsp_sts.s.stp_crc_err ? "yes" : "no"); + printf(" 17: stp_bad_sts: %s\n", + emm_rsp_sts.s.stp_bad_sts ? "yes" : "no"); + printf(" 16: stp_val: %s\n", + emm_rsp_sts.s.stp_val ? "yes" : "no"); + printf(" 15: rsp_timeout: %s\n", + emm_rsp_sts.s.rsp_timeout ? "yes" : "no"); + printf(" 14: rsp_crc_err: %s\n", + emm_rsp_sts.s.rsp_crc_err ? "yes" : "no"); + printf(" 13: rsp_bad_sts: %s\n", + emm_rsp_sts.s.rsp_bad_sts ? "yes" : "no"); + printf(" 12: rsp_val: %s\n", + emm_rsp_sts.s.rsp_val ? "yes" : "no"); + printf(" 9-11: rsp_type: %s\n", + rtype_xor_str[emm_rsp_sts.s.rsp_type]); + printf(" 7-8: cmd_type: %s\n", + ctype_xor_str[emm_rsp_sts.s.cmd_type]); + printf(" 1-6: cmd_idx: %u\n", + emm_rsp_sts.s.cmd_idx); + printf(" 0: cmd_done: %s\n", + emm_rsp_sts.s.cmd_done ? "yes" : "no"); +#endif +} + +static inline u64 read_csr(struct mmc *mmc, u64 reg) +{ + const struct octeontx_mmc_host *host = mmc_to_host(mmc); + u64 value = readq(host->base_addr + reg); +#ifdef DEBUG_CSR + printf(" %s: %s(0x%p) => 0x%llx\n", __func__, + mmc_reg_str(reg), host->base_addr + reg, + value); +#endif + return value; +} + +/** + * Writes to a CSR register + * + * @param[in] mmc pointer to mmc data structure + * @param reg register offset + * @param value value to write to register + */ +static inline void write_csr(struct mmc *mmc, u64 reg, u64 value) +{ + const struct octeontx_mmc_host *host = mmc_to_host(mmc); + void *addr = host->base_addr + reg; + +#ifdef DEBUG_CSR + printf(" %s: %s(0x%p) <= 0x%llx\n", __func__, mmc_reg_str(reg), + addr, value); +#endif + writeq(value, addr); +} + +#ifdef DEBUG +static void mmc_print_status(u32 status) +{ +#ifdef DEBUG_STATUS + static const char * const state[] = { + "Idle", /* 0 */ + "Ready", /* 1 */ + "Ident", /* 2 */ + "Standby", /* 3 */ + "Tran", /* 4 */ + "Data", /* 5 */ + "Receive", /* 6 */ + "Program", /* 7 */ + "Dis", /* 8 */ + "Btst", /* 9 */ + "Sleep", /* 10 */ + "reserved", /* 11 */ + "reserved", /* 12 */ + "reserved", /* 13 */ + "reserved", /* 14 */ + "reserved" /* 15 */ }; + if (status & R1_APP_CMD) + puts("MMC ACMD\n"); + if (status & R1_SWITCH_ERROR) + puts("MMC switch error\n"); + if (status & R1_READY_FOR_DATA) + puts("MMC ready for data\n"); + printf("MMC %s state\n", state[R1_CURRENT_STATE(status)]); + if (status & R1_ERASE_RESET) + puts("MMC erase reset\n"); + if (status & R1_WP_ERASE_SKIP) + puts("MMC partial erase due to write protected blocks\n"); + if (status & R1_CID_CSD_OVERWRITE) + puts("MMC CID/CSD overwrite error\n"); + if (status & R1_ERROR) + puts("MMC undefined device error\n"); + if (status & R1_CC_ERROR) + puts("MMC device error\n"); + if (status & R1_CARD_ECC_FAILED) + puts("MMC internal ECC failed to correct data\n"); + if (status & R1_ILLEGAL_COMMAND) + puts("MMC illegal command\n"); + if (status & R1_COM_CRC_ERROR) + puts("MMC CRC of previous command failed\n"); + if (status & R1_LOCK_UNLOCK_FAILED) + puts("MMC sequence or password error in lock/unlock device command\n"); + if (status & R1_CARD_IS_LOCKED) + puts("MMC device locked by host\n"); + if (status & R1_WP_VIOLATION) + puts("MMC attempt to program write protected block\n"); + if (status & R1_ERASE_PARAM) + puts("MMC invalid selection of erase groups for erase\n"); + if (status & R1_ERASE_SEQ_ERROR) + puts("MMC error in sequence of erase commands\n"); + if (status & R1_BLOCK_LEN_ERROR) + puts("MMC block length error\n"); + if (status & R1_ADDRESS_ERROR) + puts("MMC address misalign error\n"); + if (status & R1_OUT_OF_RANGE) + puts("MMC address out of range\n"); +#endif +} +#endif + +/** + * Print out all of the register values where mmc is optional + * + * @param mmc MMC device (can be NULL) + * @param host Pointer to host data structure (can be NULL if mmc is !NULL) + */ +static void octeontx_mmc_print_registers2(struct mmc *mmc, + struct octeontx_mmc_host *host) +{ + struct octeontx_mmc_slot *slot = mmc ? mmc->priv : NULL; + union mio_emm_dma_cfg emm_dma_cfg; + union mio_emm_dma_adr emm_dma_adr; + union mio_emm_dma_int emm_dma_int; + union mio_emm_cfg emm_cfg; + union mio_emm_modex emm_mode; + union mio_emm_switch emm_switch; + union mio_emm_dma emm_dma; + union mio_emm_cmd emm_cmd; + union mio_emm_rsp_sts emm_rsp_sts; + union mio_emm_rsp_lo emm_rsp_lo; + union mio_emm_rsp_hi emm_rsp_hi; + union mio_emm_int emm_int; + union mio_emm_wdog emm_wdog; + union mio_emm_sample emm_sample; + union mio_emm_calb emm_calb; + union mio_emm_tap emm_tap; + union mio_emm_timing emm_timing; + union mio_emm_io_ctl io_ctl; + union mio_emm_debug emm_debug; + union mio_emm_sts_mask emm_sts_mask; + union mio_emm_rca emm_rca; + int bus; + + static const char * const bus_width_str[] = { + "1-bit data bus (power on)", + "4-bit data bus", + "8-bit data bus", + "reserved (3)", + "reserved (4)", + "4-bit data bus (dual data rate)", + "8-bit data bus (dual data rate)", + "reserved (7)", + "reserved (8)", + "invalid (9)", + "invalid (10)", + "invalid (11)", + "invalid (12)", + "invalid (13)", + "invalid (14)", + "invalid (15)", + }; + static const char * const ctype_xor_str[] = { + "No data", + "Read data into Dbuf", + "Write data from Dbuf", + "Reserved" + }; + + static const char * const rtype_xor_str[] = { + "No response", + "R1, 48 bits", + "R2, 136 bits", + "R3, 48 bits", + "R4, 48 bits", + "R5, 48 bits", + "Reserved 6", + "Reserved 7" + }; + + if (!host && mmc) + host = mmc_to_host(mmc); + + if (mmc) + printf("%s: bus id: %u\n", __func__, slot->bus_id); + emm_dma_cfg.u = readq(host->base_addr + MIO_EMM_DMA_CFG()); + printf("MIO_EMM_DMA_CFG: 0x%016llx\n", + emm_dma_cfg.u); + printf(" 63: en: %s\n", + emm_dma_cfg.s.en ? "enabled" : "disabled"); + printf(" 62: rw: %s\n", + emm_dma_cfg.s.rw ? "write" : "read"); + printf(" 61: clr: %s\n", + emm_dma_cfg.s.clr ? "clear" : "not clear"); + printf(" 59: swap32: %s\n", + emm_dma_cfg.s.swap32 ? "yes" : "no"); + printf(" 58: swap16: %s\n", + emm_dma_cfg.s.swap16 ? "yes" : "no"); + printf(" 57: swap8: %s\n", + emm_dma_cfg.s.swap8 ? "yes" : "no"); + printf(" 56: endian: %s\n", + emm_dma_cfg.s.endian ? "little" : "big"); + printf(" 36-55: size: %u\n", + emm_dma_cfg.s.size); + + emm_dma_adr.u = readq(host->base_addr + MIO_EMM_DMA_ADR()); + printf("MIO_EMM_DMA_ADR: 0x%016llx\n", emm_dma_adr.u); + printf(" 0-49: adr: 0x%llx\n", + (u64)emm_dma_adr.s.adr); + + emm_dma_int.u = readq(host->base_addr + MIO_EMM_DMA_INT()); + printf("\nMIO_EMM_DMA_INT: 0x%016llx\n", + emm_dma_int.u); + printf(" 1: FIFO: %s\n", + emm_dma_int.s.fifo ? "yes" : "no"); + printf(" 0: Done: %s\n", + emm_dma_int.s.done ? "yes" : "no"); + emm_cfg.u = readq(host->base_addr + MIO_EMM_CFG()); + + printf("\nMIO_EMM_CFG: 0x%016llx\n", + emm_cfg.u); + printf(" 3: bus_ena3: %s\n", + emm_cfg.s.bus_ena & 0x08 ? "yes" : "no"); + printf(" 2: bus_ena2: %s\n", + emm_cfg.s.bus_ena & 0x04 ? "yes" : "no"); + printf(" 1: bus_ena1: %s\n", + emm_cfg.s.bus_ena & 0x02 ? "yes" : "no"); + printf(" 0: bus_ena0: %s\n", + emm_cfg.s.bus_ena & 0x01 ? "yes" : "no"); + for (bus = 0; bus < 4; bus++) { + emm_mode.u = readq(host->base_addr + MIO_EMM_MODEX(bus)); + printf("\nMIO_EMM_MODE%u: 0x%016llx\n", + bus, emm_mode.u); + if (!IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { + printf(" 50: hs400_timing: %s\n", + emm_mode.s.hs400_timing ? "yes" : "no"); + printf(" 49: hs200_timing: %s\n", + emm_mode.s.hs200_timing ? "yes" : "no"); + } + printf(" 48: hs_timing: %s\n", + emm_mode.s.hs_timing ? "yes" : "no"); + printf(" 40-42: bus_width: %s\n", + bus_width_str[emm_mode.s.bus_width]); + printf(" 32-35: power_class %u\n", + emm_mode.s.power_class); + printf(" 16-31: clk_hi: %u\n", + emm_mode.s.clk_hi); + printf(" 0-15: clk_lo: %u\n", + emm_mode.s.clk_lo); + } + + emm_switch.u = readq(host->base_addr + MIO_EMM_SWITCH()); + printf("\nMIO_EMM_SWITCH: 0x%016llx\n", emm_switch.u); + printf(" 60-61: bus_id: %u\n", emm_switch.s.bus_id); + printf(" 59: switch_exe: %s\n", + emm_switch.s.switch_exe ? "yes" : "no"); + printf(" 58: switch_err0: %s\n", + emm_switch.s.switch_err0 ? "yes" : "no"); + printf(" 57: switch_err1: %s\n", + emm_switch.s.switch_err1 ? "yes" : "no"); + printf(" 56: switch_err2: %s\n", + emm_switch.s.switch_err2 ? "yes" : "no"); + printf(" 48: hs_timing: %s\n", + emm_switch.s.hs_timing ? "yes" : "no"); + printf(" 42-40: bus_width: %s\n", + bus_width_str[emm_switch.s.bus_width]); + printf(" 32-35: power_class: %u\n", + emm_switch.s.power_class); + printf(" 16-31: clk_hi: %u\n", + emm_switch.s.clk_hi); + printf(" 0-15: clk_lo: %u\n", emm_switch.s.clk_lo); + + emm_dma.u = readq(host->base_addr + MIO_EMM_DMA()); + printf("\nMIO_EMM_DMA: 0x%016llx\n", emm_dma.u); + printf(" 60-61: bus_id: %u\n", emm_dma.s.bus_id); + printf(" 59: dma_val: %s\n", + emm_dma.s.dma_val ? "yes" : "no"); + printf(" 58: sector: %s mode\n", + emm_dma.s.sector ? "sector" : "byte"); + printf(" 57: dat_null: %s\n", + emm_dma.s.dat_null ? "yes" : "no"); + printf(" 51-56: thres: %u\n", emm_dma.s.thres); + printf(" 50: rel_wr: %s\n", + emm_dma.s.rel_wr ? "yes" : "no"); + printf(" 49: rw: %s\n", + emm_dma.s.rw ? "write" : "read"); + printf(" 48: multi: %s\n", + emm_dma.s.multi ? "yes" : "no"); + printf(" 32-47: block_cnt: %u\n", + emm_dma.s.block_cnt); + printf(" 0-31: card_addr: 0x%x\n", + emm_dma.s.card_addr); + + emm_cmd.u = readq(host->base_addr + MIO_EMM_CMD()); + printf("\nMIO_EMM_CMD: 0x%016llx\n", emm_cmd.u); + printf("\n 62: skip_busy: %s\n", + emm_cmd.s.skip_busy ? "yes" : "no"); + printf(" 60-61: bus_id: %u\n", emm_cmd.s.bus_id); + printf(" 59: cmd_val: %s\n", + emm_cmd.s.cmd_val ? "yes" : "no"); + printf(" 55: dbuf: %u\n", emm_cmd.s.dbuf); + printf(" 49-54: offset: %u\n", emm_cmd.s.offset); + printf(" 41-42: ctype_xor: %s\n", + ctype_xor_str[emm_cmd.s.ctype_xor]); + printf(" 38-40: rtype_xor: %s\n", + rtype_xor_str[emm_cmd.s.rtype_xor]); + printf(" 32-37: cmd_idx: %u\n", emm_cmd.s.cmd_idx); + printf(" 0-31: arg: 0x%x\n", emm_cmd.s.arg); + + emm_rsp_sts.u = readq(host->base_addr + MIO_EMM_RSP_STS()); + printf("\nMIO_EMM_RSP_STS: 0x%016llx\n", emm_rsp_sts.u); + printf(" 60-61: bus_id: %u\n", emm_rsp_sts.s.bus_id); + printf(" 59: cmd_val: %s\n", + emm_rsp_sts.s.cmd_val ? "yes" : "no"); + printf(" 58: switch_val: %s\n", + emm_rsp_sts.s.switch_val ? "yes" : "no"); + printf(" 57: dma_val: %s\n", + emm_rsp_sts.s.dma_val ? "yes" : "no"); + printf(" 56: dma_pend: %s\n", + emm_rsp_sts.s.dma_pend ? "yes" : "no"); + printf(" 28: dbuf_err: %s\n", + emm_rsp_sts.s.dbuf_err ? "yes" : "no"); + printf(" 23: dbuf: %u\n", emm_rsp_sts.s.dbuf); + printf(" 22: blk_timeout: %s\n", + emm_rsp_sts.s.blk_timeout ? "yes" : "no"); + printf(" 21: blk_crc_err: %s\n", + emm_rsp_sts.s.blk_crc_err ? "yes" : "no"); + printf(" 20: rsp_busybit: %s\n", + emm_rsp_sts.s.rsp_busybit ? "yes" : "no"); + printf(" 19: stp_timeout: %s\n", + emm_rsp_sts.s.stp_timeout ? "yes" : "no"); + printf(" 18: stp_crc_err: %s\n", + emm_rsp_sts.s.stp_crc_err ? "yes" : "no"); + printf(" 17: stp_bad_sts: %s\n", + emm_rsp_sts.s.stp_bad_sts ? "yes" : "no"); + printf(" 16: stp_val: %s\n", + emm_rsp_sts.s.stp_val ? "yes" : "no"); + printf(" 15: rsp_timeout: %s\n", + emm_rsp_sts.s.rsp_timeout ? "yes" : "no"); + printf(" 14: rsp_crc_err: %s\n", + emm_rsp_sts.s.rsp_crc_err ? "yes" : "no"); + printf(" 13: rsp_bad_sts: %s\n", + emm_rsp_sts.s.rsp_bad_sts ? "yes" : "no"); + printf(" 12: rsp_val: %s\n", + emm_rsp_sts.s.rsp_val ? "yes" : "no"); + printf(" 9-11: rsp_type: %s\n", + rtype_xor_str[emm_rsp_sts.s.rsp_type]); + printf(" 7-8: cmd_type: %s\n", + ctype_xor_str[emm_rsp_sts.s.cmd_type]); + printf(" 1-6: cmd_idx: %u\n", + emm_rsp_sts.s.cmd_idx); + printf(" 0: cmd_done: %s\n", + emm_rsp_sts.s.cmd_done ? "yes" : "no"); + + emm_rsp_lo.u = readq(host->base_addr + MIO_EMM_RSP_LO()); + printf("\nMIO_EMM_RSP_STS_LO: 0x%016llx\n", emm_rsp_lo.u); + + emm_rsp_hi.u = readq(host->base_addr + MIO_EMM_RSP_HI()); + printf("\nMIO_EMM_RSP_STS_HI: 0x%016llx\n", emm_rsp_hi.u); + + emm_int.u = readq(host->base_addr + MIO_EMM_INT()); + printf("\nMIO_EMM_INT: 0x%016llx\n", emm_int.u); + printf(" 6: switch_err: %s\n", + emm_int.s.switch_err ? "yes" : "no"); + printf(" 5: switch_done: %s\n", + emm_int.s.switch_done ? "yes" : "no"); + printf(" 4: dma_err: %s\n", + emm_int.s.dma_err ? "yes" : "no"); + printf(" 3: cmd_err: %s\n", + emm_int.s.cmd_err ? "yes" : "no"); + printf(" 2: dma_done: %s\n", + emm_int.s.dma_done ? "yes" : "no"); + printf(" 1: cmd_done: %s\n", + emm_int.s.cmd_done ? "yes" : "no"); + printf(" 0: buf_done: %s\n", + emm_int.s.buf_done ? "yes" : "no"); + + emm_wdog.u = readq(host->base_addr + MIO_EMM_WDOG()); + printf("\nMIO_EMM_WDOG: 0x%016llx (%u)\n", + emm_wdog.u, emm_wdog.s.clk_cnt); + + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { + emm_sample.u = readq(host->base_addr + MIO_EMM_SAMPLE()); + printf("\nMIO_EMM_SAMPLE: 0x%016llx\n", + emm_sample.u); + printf(" 16-25: cmd_cnt: %u\n", + emm_sample.s.cmd_cnt); + printf(" 0-9: dat_cnt: %u\n", + emm_sample.s.dat_cnt); + } + + emm_sts_mask.u = readq(host->base_addr + MIO_EMM_STS_MASK()); + printf("\nMIO_EMM_STS_MASK: 0x%016llx\n", emm_sts_mask.u); + + emm_rca.u = readq(host->base_addr + MIO_EMM_RCA()); + printf("\nMIO_EMM_RCA: 0x%016llx\n", emm_rca.u); + printf(" 0-15: card_rca: 0x%04x\n", + emm_rca.s.card_rca); + if (!IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { + emm_calb.u = readq(host->base_addr + MIO_EMM_CALB()); + printf("\nMIO_EMM_CALB: 0x%016llx\n", + emm_calb.u); + printf(" 0: start: %u\n", + emm_calb.s.start); + emm_tap.u = readq(host->base_addr + MIO_EMM_TAP()); + printf("\nMIO_EMM_TAP: 0x%016llx\n", + emm_tap.u); + printf(" 7-0: delay: %u\n", emm_tap.s.delay); + emm_timing.u = readq(host->base_addr + MIO_EMM_TIMING()); + printf("\nMIO_EMM_TIMING: 0x%016llx\n", + emm_timing.u); + printf(" 53-48: cmd_in_tap: %u\n", + emm_timing.s.cmd_in_tap); + printf(" 37-32: cmd_out_tap: %u\n", + emm_timing.s.cmd_out_tap); + printf(" 21-16: data_in_tap: %u\n", + emm_timing.s.data_in_tap); + printf(" 5-0: data_out_tap: %u\n", + emm_timing.s.data_out_tap); + io_ctl.u = readq(host->base_addr + MIO_EMM_IO_CTL()); + printf("\nMIO_IO_CTL: 0x%016llx\n", io_ctl.u); + printf(" 3-2: drive: %u (%u mA)\n", + io_ctl.s.drive, 2 << io_ctl.s.drive); + printf(" 0: slew: %u %s\n", io_ctl.s.slew, + io_ctl.s.slew ? "high" : "low"); + emm_debug.u = readq(host->base_addr + MIO_EMM_DEBUG()); + printf("\nMIO_EMM_DEBUG: 0x%016llx\n", + emm_debug.u); + printf(" 21: rdsync_rst 0x%x\n", + emm_debug.s.rdsync_rst); + printf(" 20: emmc_clk_disable 0x%x\n", + emm_debug.s.emmc_clk_disable); + printf(" 19-16: dma_sm: 0x%x\n", + emm_debug.s.dma_sm); + printf(" 15-12: data_sm: 0x%x\n", + emm_debug.s.data_sm); + printf(" 11-8: cmd_sm: 0x%x\n", + emm_debug.s.cmd_sm); + printf(" 0: clk_on: 0x%x\n", + emm_debug.s.clk_on); + } + + puts("\n"); +} + +/** + * Print out all of the register values + * + * @param mmc MMC device + */ +static void octeontx_mmc_print_registers(struct mmc *mmc) +{ +#ifdef DEBUG_REGISTERS + const int print = 1; +#else + const int print = 0; +#endif + if (print) + octeontx_mmc_print_registers2(mmc, mmc_to_host(mmc)); +} + +static const struct octeontx_sd_mods octeontx_cr_types[] = { +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD0 */ +{ {0, 3}, {0, 3}, {0, 0} }, /* CMD1 */ +{ {0, 2}, {0, 2}, {0, 0} }, /* CMD2 */ +{ {0, 1}, {0, 3}, {0, 0} }, /* CMD3 SD_CMD_SEND_RELATIVE_ADDR 0, 2 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD4 */ +{ {0, 1}, {0, 1}, {0, 0} }, /* CMD5 */ +{ {0, 1}, {1, 1}, {0, 1} }, /* + * CMD6 SD_CMD_SWITCH_FUNC 1,0 + * (ACMD) SD_APP_SET_BUS_WIDTH + */ +{ {0, 1}, {0, 1}, {0, 0} }, /* CMD7 */ +{ {1, 1}, {0, 3}, {0, 0} }, /* CMD8 SD_CMD_SEND_IF_COND 1,2 */ +{ {0, 2}, {0, 2}, {0, 0} }, /* CMD9 */ +{ {0, 2}, {0, 2}, {0, 0} }, /* CMD10 */ +{ {1, 1}, {0, 1}, {1, 1} }, /* CMD11 SD_CMD_SWITCH_UHS18V 1,0 */ +{ {0, 1}, {0, 1}, {0, 0} }, /* CMD12 */ +{ {0, 1}, {0, 1}, {1, 3} }, /* CMD13 (ACMD)) SD_CMD_APP_SD_STATUS 1,2 */ +{ {1, 1}, {1, 1}, {0, 0} }, /* CMD14 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD15 */ +{ {0, 1}, {0, 1}, {0, 0} }, /* CMD16 */ +{ {1, 1}, {1, 1}, {0, 0} }, /* CMD17 */ +{ {1, 1}, {1, 1}, {0, 0} }, /* CMD18 */ +{ {3, 1}, {3, 1}, {0, 0} }, /* CMD19 */ +{ {2, 1}, {0, 0}, {0, 0} }, /* CMD20 */ /* SD 2,0 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD21 */ +{ {0, 0}, {0, 0}, {1, 1} }, /* CMD22 (ACMD) SD_APP_SEND_NUM_WR_BLKS 1,0 */ +{ {0, 1}, {0, 1}, {0, 1} }, /* CMD23 */ /* SD ACMD 1,0 */ +{ {2, 1}, {2, 1}, {2, 1} }, /* CMD24 */ +{ {2, 1}, {2, 1}, {2, 1} }, /* CMD25 */ +{ {2, 1}, {2, 1}, {2, 1} }, /* CMD26 */ +{ {2, 1}, {2, 1}, {2, 1} }, /* CMD27 */ +{ {0, 1}, {0, 1}, {0, 1} }, /* CMD28 */ +{ {0, 1}, {0, 1}, {0, 1} }, /* CMD29 */ +{ {1, 1}, {1, 1}, {1, 1} }, /* CMD30 */ +{ {1, 1}, {1, 1}, {1, 1} }, /* CMD31 */ +{ {0, 0}, {0, 1}, {0, 0} }, /* CMD32 SD_CMD_ERASE_WR_BLK_START 0,1 */ +{ {0, 0}, {0, 1}, {0, 0} }, /* CMD33 SD_CMD_ERASE_WR_BLK_END 0,1 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD34 */ +{ {0, 1}, {0, 1}, {0, 1} }, /* CMD35 */ +{ {0, 1}, {0, 1}, {0, 1} }, /* CMD36 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD37 */ +{ {0, 1}, {0, 1}, {0, 1} }, /* CMD38 */ +{ {0, 4}, {0, 4}, {0, 4} }, /* CMD39 */ +{ {0, 5}, {0, 5}, {0, 5} }, /* CMD40 */ +{ {0, 0}, {0, 0}, {0, 3} }, /* CMD41 (ACMD) SD_CMD_APP_SEND_OP_COND 0,3 */ +{ {2, 1}, {2, 1}, {2, 1} }, /* CMD42 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD43 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD44 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD45 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD46 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD47 */ +{ {0, 0}, {1, 0}, {0, 0} }, /* CMD48 SD_CMD_READ_EXTR_SINGLE */ +{ {0, 0}, {2, 0}, {0, 0} }, /* CMD49 SD_CMD_WRITE_EXTR_SINGLE */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD50 */ +{ {0, 0}, {0, 0}, {1, 1} }, /* CMD51 (ACMD) SD_CMD_APP_SEND_SCR 1,1 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD52 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD53 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD54 */ +{ {0, 1}, {0, 1}, {0, 1} }, /* CMD55 */ +{ {0xff, 0xff}, {0xff, 0xff}, {0xff, 0xff} }, /* CMD56 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD57 */ +{ {0, 0}, {0, 3}, {0, 3} }, /* CMD58 SD_CMD_SPI_READ_OCR 0,3 */ +{ {0, 0}, {0, 1}, {0, 0} }, /* CMD59 SD_CMD_SPI_CRC_ON_OFF 0,1 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD60 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD61 */ +{ {0, 0}, {0, 0}, {0, 0} }, /* CMD62 */ +{ {0, 0}, {0, 0}, {0, 0} } /* CMD63 */ +}; + +/** + * Returns XOR values needed for SD commands and other quirks + * + * @param mmc mmc device + * @param cmd command information + * + * @return octeontx_mmc_cr_mods data structure with various quirks and flags + */ +static struct octeontx_mmc_cr_mods +octeontx_mmc_get_cr_mods(struct mmc *mmc, const struct mmc_cmd *cmd, + const struct mmc_data *data) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + struct octeontx_mmc_cr_mods cr = {0, 0}; + const struct octeontx_sd_mods *sdm = + &octeontx_cr_types[cmd->cmdidx & 0x3f]; + u8 c = sdm->mmc.c, r = sdm->mmc.r; + u8 desired_ctype = 0; + + if (IS_MMC(mmc)) { +#ifdef MMC_SUPPORTS_TUNING + if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200) { + if (cmd->resp_type == MMC_RSP_R1) + cr.rtype_xor = 1; + if (data && data->flags & MMC_DATA_READ) + cr.ctype_xor = 1; + } +#endif + return cr; + } + + if (cmd->cmdidx == 56) + c = (cmd->cmdarg & 1) ? 1 : 2; + + if (data) { + if (data->flags & MMC_DATA_READ) + desired_ctype = 1; + else if (data->flags & MMC_DATA_WRITE) + desired_ctype = 2; + } + + cr.ctype_xor = c ^ desired_ctype; + if (slot->is_acmd) + cr.rtype_xor = r ^ sdm->sdacmd.r; + else + cr.rtype_xor = r ^ sdm->sd.r; + + debug("%s(%s): mmc c: %d, mmc r: %d, desired c: %d, xor c: %d, xor r: %d\n", + __func__, mmc->dev->name, c, r, desired_ctype, + cr.ctype_xor, cr.rtype_xor); + return cr; +} + +/** + * Keep track of switch commands internally + */ +static void octeontx_mmc_track_switch(struct mmc *mmc, u32 cmd_arg) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + u8 how = (cmd_arg >> 24) & 3; + u8 where = (u8)(cmd_arg >> 16); + u8 val = (u8)(cmd_arg >> 8); + + slot->want_switch = slot->cached_switch; + + if (slot->is_acmd) + return; + + if (how != 3) + return; + + switch (where) { + case EXT_CSD_BUS_WIDTH: + slot->want_switch.s.bus_width = val; + break; + case EXT_CSD_POWER_CLASS: + slot->want_switch.s.power_class = val; + break; + case EXT_CSD_HS_TIMING: + slot->want_switch.s.hs_timing = 0; + slot->want_switch.s.hs200_timing = 0; + slot->want_switch.s.hs400_timing = 0; + switch (val & 0xf) { + case 0: + break; + case 1: + slot->want_switch.s.hs_timing = 1; + break; + case 2: + if (!slot->is_asim && !slot->is_emul) + slot->want_switch.s.hs200_timing = 1; + break; + case 3: + if (!slot->is_asim && !slot->is_emul) + slot->want_switch.s.hs400_timing = 1; + break; + default: + pr_err("%s(%s): Unsupported timing mode 0x%x\n", + __func__, mmc->dev->name, val & 0xf); + break; + } + break; + default: + break; + } +} + +static int octeontx_mmc_print_rsp_errors(struct mmc *mmc, + union mio_emm_rsp_sts rsp_sts) +{ + bool err = false; + const char *name = mmc->dev->name; + + if (rsp_sts.s.acc_timeout) { + pr_warn("%s(%s): acc_timeout\n", __func__, name); + err = true; + } + if (rsp_sts.s.dbuf_err) { + pr_warn("%s(%s): dbuf_err\n", __func__, name); + err = true; + } + if (rsp_sts.s.blk_timeout) { + pr_warn("%s(%s): blk_timeout\n", __func__, name); + err = true; + } + if (rsp_sts.s.blk_crc_err) { + pr_warn("%s(%s): blk_crc_err\n", __func__, name); + err = true; + } + if (rsp_sts.s.stp_timeout) { + pr_warn("%s(%s): stp_timeout\n", __func__, name); + err = true; + } + if (rsp_sts.s.stp_crc_err) { + pr_warn("%s(%s): stp_crc_err\n", __func__, name); + err = true; + } + if (rsp_sts.s.stp_bad_sts) { + pr_warn("%s(%s): stp_bad_sts\n", __func__, name); + err = true; + } + if (err) + pr_warn(" rsp_sts: 0x%llx\n", rsp_sts.u); + + return err ? -1 : 0; +} + +/** + * Starts a DMA operation for block read/write + * + * @param mmc mmc device + * @param write true if write operation + * @param clear true to clear DMA operation + * @param adr source or destination DMA address + * @param size size in blocks + * @param timeout timeout in ms + */ +static void octeontx_mmc_start_dma(struct mmc *mmc, bool write, + bool clear, u32 block, dma_addr_t adr, + u32 size, int timeout) +{ + const struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + union mio_emm_dma_cfg emm_dma_cfg; + union mio_emm_dma_adr emm_dma_adr; + union mio_emm_dma emm_dma; + + /* Clear any interrupts */ + write_csr(mmc, MIO_EMM_DMA_INT(), + read_csr(mmc, MIO_EMM_DMA_INT())); + + emm_dma_cfg.u = 0; + emm_dma_cfg.s.en = 1; + emm_dma_cfg.s.rw = !!write; + emm_dma_cfg.s.clr = !!clear; + emm_dma_cfg.s.size = ((u64)(size * mmc->read_bl_len) / 8) - 1; +#if __BYTE_ORDER != __BIG_ENDIAN + emm_dma_cfg.s.endian = 1; +#endif + emm_dma_adr.u = 0; + emm_dma_adr.s.adr = adr; + write_csr(mmc, MIO_EMM_DMA_ADR(), emm_dma_adr.u); + write_csr(mmc, MIO_EMM_DMA_CFG(), emm_dma_cfg.u); + + emm_dma.u = 0; + emm_dma.s.bus_id = slot->bus_id; + emm_dma.s.dma_val = 1; + emm_dma.s.rw = !!write; + emm_dma.s.sector = mmc->high_capacity ? 1 : 0; + + if (size > 1 && ((IS_SD(mmc) && (mmc->scr[0] & 2)) || !IS_SD(mmc))) + emm_dma.s.multi = 1; + else + emm_dma.s.multi = 0; + + emm_dma.s.block_cnt = size; + if (!mmc->high_capacity) + block *= mmc->read_bl_len; + emm_dma.s.card_addr = block; + debug("%s(%s): card address: 0x%x, size: %d, multi: %d\n", + __func__, mmc->dev->name, block, size, emm_dma.s.multi); + + if (timeout > 0) + timeout = (timeout * 1000) - 1000; + set_wdog(mmc, timeout); + + debug(" Writing 0x%llx to mio_emm_dma\n", emm_dma.u); + write_csr(mmc, MIO_EMM_DMA(), emm_dma.u); +} + +/** + * Waits for a DMA operation to complete + * + * @param mmc mmc device + * @param timeout timeout in ms + * + * @return 0 for success (could be DMA errors), -ETIMEDOUT on timeout + */ + +/** + * Cleanup DMA engine after a failure + * + * @param mmc mmc device + * @param rsp_sts rsp status + */ +static void octeontx_mmc_cleanup_dma(struct mmc *mmc, + union mio_emm_rsp_sts rsp_sts) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + union mio_emm_dma emm_dma; + ulong start; + int retries = 3; + + do { + debug("%s(%s): rsp_sts: 0x%llx, rsp_lo: 0x%llx, dma_int: 0x%llx\n", + __func__, mmc->dev->name, rsp_sts.u, + read_csr(mmc, MIO_EMM_RSP_LO()), + read_csr(mmc, MIO_EMM_DMA_INT())); + emm_dma.u = read_csr(mmc, MIO_EMM_DMA()); + emm_dma.s.dma_val = 1; + emm_dma.s.dat_null = 1; + emm_dma.s.bus_id = slot->bus_id; + write_csr(mmc, MIO_EMM_DMA(), emm_dma.u); + start = get_timer(0); + do { + rsp_sts.u = read_csr(mmc, MIO_EMM_RSP_STS()); + WATCHDOG_RESET(); + } while (get_timer(start) < 100 && + (rsp_sts.s.dma_val || rsp_sts.s.dma_pend)); + } while (retries-- >= 0 && rsp_sts.s.dma_pend); + if (rsp_sts.s.dma_val) + pr_err("%s(%s): Error: could not clean up DMA. RSP_STS: 0x%llx, RSP_LO: 0x%llx\n", + __func__, mmc->dev->name, rsp_sts.u, + read_csr(mmc, MIO_EMM_RSP_LO())); + debug(" rsp_sts after clearing up DMA: 0x%llx\n", + read_csr(mmc, MIO_EMM_RSP_STS())); +} + +/** + * Waits for a DMA operation to complete + * + * @param mmc mmc device + * @param timeout timeout in ms + * @param verbose true to print out error information + * + * @return 0 for success (could be DMA errors), -ETIMEDOUT on timeout + * or -EIO if IO error. + */ +static int octeontx_mmc_wait_dma(struct mmc *mmc, bool write, ulong timeout, + bool verbose) +{ + struct octeontx_mmc_host *host = mmc_to_host(mmc); + ulong start_time = get_timer(0); + union mio_emm_dma_int emm_dma_int; + union mio_emm_rsp_sts rsp_sts; + union mio_emm_dma emm_dma; + bool timed_out = false; + bool err = false; + + debug("%s(%s, %lu, %d), delay: %uus\n", __func__, mmc->dev->name, + timeout, verbose, host->dma_wait_delay); + + udelay(host->dma_wait_delay); + do { + emm_dma_int.u = read_csr(mmc, MIO_EMM_DMA_INT()); + rsp_sts.u = read_csr(mmc, MIO_EMM_RSP_STS()); + if (write) { + if ((rsp_sts.s.dma_pend && !rsp_sts.s.dma_val) || + rsp_sts.s.blk_timeout || + rsp_sts.s.stp_timeout || + rsp_sts.s.rsp_timeout) { + err = true; +#ifdef DEBUG + debug("%s: f1\n", __func__); + octeontx_mmc_print_rsp_errors(mmc, rsp_sts); +#endif + break; + } + } else { + if (rsp_sts.s.blk_crc_err || + (rsp_sts.s.dma_pend && !rsp_sts.s.dma_val)) { + err = true; +#if defined(DEBUG) + octeontx_mmc_print_rsp_errors(mmc, rsp_sts); +#endif + break; + } + } + if (rsp_sts.s.dma_pend) { + /* + * If this is set then an error has occurred. + * Try and restart the DMA operation. + */ + emm_dma.u = read_csr(mmc, MIO_EMM_DMA()); + if (verbose) { + pr_err("%s(%s): DMA pending error: rsp_sts: 0x%llx, dma_int: 0x%llx, emm_dma: 0x%llx\n", + __func__, mmc->dev->name, rsp_sts.u, + emm_dma_int.u, emm_dma.u); + octeontx_print_rsp_sts(mmc); + debug(" MIO_EMM_DEBUG: 0x%llx\n", + read_csr(mmc, MIO_EMM_DEBUG())); + pr_err("%s: Trying DMA resume...\n", __func__); + } + emm_dma.s.dma_val = 1; + emm_dma.s.dat_null = 1; + write_csr(mmc, MIO_EMM_DMA(), emm_dma.u); + udelay(10); + } else if (!rsp_sts.s.dma_val && emm_dma_int.s.done) { + break; + } + WATCHDOG_RESET(); + timed_out = (get_timer(start_time) > timeout); + } while (!timed_out); + + if (timed_out || err) { + if (verbose) { + pr_err("%s(%s): MMC DMA %s after %lu ms, rsp_sts: 0x%llx, dma_int: 0x%llx, rsp_sts_lo: 0x%llx, emm_dma: 0x%llx\n", + __func__, mmc->dev->name, + timed_out ? "timed out" : "error", + get_timer(start_time), rsp_sts.u, + emm_dma_int.u, + read_csr(mmc, MIO_EMM_RSP_LO()), + read_csr(mmc, MIO_EMM_DMA())); + octeontx_print_rsp_sts(mmc); + } + if (rsp_sts.s.dma_pend) + octeontx_mmc_cleanup_dma(mmc, rsp_sts); + } else { + write_csr(mmc, MIO_EMM_DMA_INT(), + read_csr(mmc, MIO_EMM_DMA_INT())); + } + + return timed_out ? -ETIMEDOUT : (err ? -EIO : 0); +} + +/** + * Read blocks from the MMC/SD device + * + * @param mmc mmc device + * @param cmd command + * @param data data for read + * @param verbose true to print out error information + * + * @return number of blocks read or 0 if error + */ +static int octeontx_mmc_read_blocks(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data, bool verbose) +{ + struct octeontx_mmc_host *host = mmc_to_host(mmc); + union mio_emm_rsp_sts rsp_sts; + dma_addr_t dma_addr = (dma_addr_t)dm_pci_virt_to_mem(host->dev, + data->dest); + ulong count; + ulong blkcnt = data->blocks; + ulong start = cmd->cmdarg; + int timeout = 1000 + blkcnt * 20; + bool timed_out = false; + bool multi_xfer = cmd->cmdidx == MMC_CMD_READ_MULTIPLE_BLOCK; + + debug("%s(%s): dest: %p, dma address: 0x%llx, blkcnt: %lu, start: %lu\n", + __func__, mmc->dev->name, data->dest, dma_addr, blkcnt, start); + debug("%s: rsp_sts: 0x%llx\n", __func__, + read_csr(mmc, MIO_EMM_RSP_STS())); + /* use max timeout for multi-block transfers */ + /* timeout = 0; */ + + /* + * If we have a valid SD card in the slot, we set the response bit + * mask to check for CRC errors and timeouts only. + * Otherwise, use the default power on reset value. + */ + write_csr(mmc, MIO_EMM_STS_MASK(), + IS_SD(mmc) ? 0x00b00000ull : 0xe4390080ull); + invalidate_dcache_range((u64)data->dest, + (u64)data->dest + blkcnt * data->blocksize); + + if (multi_xfer) { + octeontx_mmc_start_dma(mmc, false, false, start, dma_addr, + blkcnt, timeout); + timed_out = !!octeontx_mmc_wait_dma(mmc, false, timeout, + verbose); + rsp_sts.u = read_csr(mmc, MIO_EMM_RSP_STS()); + if (timed_out || rsp_sts.s.dma_val || rsp_sts.s.dma_pend) { + if (!verbose) + return 0; + + pr_err("%s(%s): Error: DMA timed out. rsp_sts: 0x%llx, emm_int: 0x%llx, dma_int: 0x%llx, rsp_lo: 0x%llx\n", + __func__, mmc->dev->name, rsp_sts.u, + read_csr(mmc, MIO_EMM_INT()), + read_csr(mmc, MIO_EMM_DMA_INT()), + read_csr(mmc, MIO_EMM_RSP_LO())); + pr_err("%s: block count: %lu, start: 0x%lx\n", + __func__, blkcnt, start); + octeontx_mmc_print_registers(mmc); + return 0; + } + } else { + count = blkcnt; + timeout = 1000; + do { + octeontx_mmc_start_dma(mmc, false, false, start, + dma_addr, 1, timeout); + dma_addr += mmc->read_bl_len; + start++; + + timed_out = !!octeontx_mmc_wait_dma(mmc, false, + timeout, verbose); + rsp_sts.u = read_csr(mmc, MIO_EMM_RSP_STS()); + if (timed_out || rsp_sts.s.dma_val || + rsp_sts.s.dma_pend) { + if (verbose) { + pr_err("%s: Error: DMA timed out. rsp_sts: 0x%llx, emm_int: 0x%llx, dma_int: 0x%llx, rsp_lo: 0x%llx\n", + __func__, rsp_sts.u, + read_csr(mmc, MIO_EMM_INT()), + read_csr(mmc, MIO_EMM_DMA_INT()), + read_csr(mmc, MIO_EMM_RSP_LO())); + pr_err("%s: block count: 1, start: 0x%lx\n", + __func__, start); + octeontx_mmc_print_registers(mmc); + } + return blkcnt - count; + } + WATCHDOG_RESET(); + } while (--count); + } +#ifdef DEBUG + debug("%s(%s): Read %lu (0x%lx) blocks starting at block %u (0x%x) to address %p (dma address 0x%llx)\n", + __func__, mmc->dev->name, blkcnt, blkcnt, + cmd->cmdarg, cmd->cmdarg, data->dest, + dm_pci_virt_to_mem(host->dev, data->dest)); + print_buffer(0, data->dest, 1, 0x200, 0); +#endif + return blkcnt; +} + +static int octeontx_mmc_poll_ready(struct mmc *mmc, ulong timeout) +{ + ulong start; + struct mmc_cmd cmd; + int err; + bool not_ready = false; + + memset(&cmd, 0, sizeof(cmd)); + cmd.cmdidx = MMC_CMD_SEND_STATUS; + cmd.cmdarg = mmc->rca << 16; + cmd.resp_type = MMC_RSP_R1; + start = get_timer(0); + do { + err = octeontx_mmc_send_cmd(mmc, &cmd, NULL); + if (err) { + pr_err("%s(%s): MMC command error: %d; Retry...\n", + __func__, mmc->dev->name, err); + not_ready = true; + } else if (cmd.response[0] & R1_READY_FOR_DATA) { + return 0; + } + WATCHDOG_RESET(); + } while (get_timer(start) < timeout); + + if (not_ready) + pr_err("%s(%s): MMC command error; Retry timeout\n", + __func__, mmc->dev->name); + return -ETIMEDOUT; +} + +static ulong octeontx_mmc_write_blocks(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct octeontx_mmc_host *host = mmc_to_host(mmc); + ulong start = cmd->cmdarg; + ulong blkcnt = data->blocks; + dma_addr_t dma_addr; + union mio_emm_rsp_sts rsp_sts; + union mio_emm_sts_mask emm_sts_mask; + ulong timeout; + int count; + bool timed_out = false; + bool multi_xfer = (blkcnt > 1) && + ((IS_SD(mmc) && mmc->scr[0] & 2) || !IS_SD(mmc)); + + octeontx_mmc_switch_to(mmc); + emm_sts_mask.u = 0; + emm_sts_mask.s.sts_msk = R1_BLOCK_WRITE_MASK; + write_csr(mmc, MIO_EMM_STS_MASK(), emm_sts_mask.u); + + if (octeontx_mmc_poll_ready(mmc, 10000)) { + pr_err("%s(%s): Ready timed out\n", __func__, mmc->dev->name); + return 0; + } + flush_dcache_range((u64)data->src, + (u64)data->src + blkcnt * mmc->write_bl_len); + dma_addr = (u64)dm_pci_virt_to_mem(host->dev, (void *)data->src); + if (multi_xfer) { + timeout = 5000 + 100 * blkcnt; + octeontx_mmc_start_dma(mmc, true, false, start, dma_addr, + blkcnt, timeout); + timed_out = !!octeontx_mmc_wait_dma(mmc, true, timeout, true); + rsp_sts.u = read_csr(mmc, MIO_EMM_RSP_STS()); + if (timed_out || rsp_sts.s.dma_val || rsp_sts.s.dma_pend) { + pr_err("%s(%s): Error: multi-DMA timed out after %lums. rsp_sts: 0x%llx, emm_int: 0x%llx, emm_dma_int: 0x%llx, rsp_sts_lo: 0x%llx, emm_dma: 0x%llx\n", + __func__, mmc->dev->name, timeout, + rsp_sts.u, + read_csr(mmc, MIO_EMM_INT()), + read_csr(mmc, MIO_EMM_DMA_INT()), + read_csr(mmc, MIO_EMM_RSP_LO()), + read_csr(mmc, MIO_EMM_DMA())); + return 0; + } + } else { + timeout = 5000; + count = blkcnt; + do { + octeontx_mmc_start_dma(mmc, true, false, start, + dma_addr, 1, timeout); + dma_addr += mmc->read_bl_len; + start++; + + timed_out = !!octeontx_mmc_wait_dma(mmc, true, timeout, + true); + rsp_sts.u = read_csr(mmc, MIO_EMM_RSP_STS()); + if (timed_out || rsp_sts.s.dma_val || + rsp_sts.s.dma_pend) { + pr_err("%s(%s): Error: single-DMA timed out after %lums. rsp_sts: 0x%llx, emm_int: 0x%llx, emm_dma_int: 0x%llx, rsp_sts_lo: 0x%llx, emm_dma: 0x%llx\n", + __func__, mmc->dev->name, timeout, + rsp_sts.u, + read_csr(mmc, MIO_EMM_RSP_STS()), + read_csr(mmc, MIO_EMM_DMA_INT()), + read_csr(mmc, MIO_EMM_RSP_LO()), + read_csr(mmc, MIO_EMM_DMA())); + return blkcnt - count; + } + WATCHDOG_RESET(); + } while (--count); + } + + return blkcnt; +} + +/** + * Send a command to the eMMC/SD device + * + * @param mmc mmc device + * @param cmd cmd to send and response + * @param data additional data + * @param flags + * @return 0 for success, otherwise error + */ +static int octeontx_mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + const char *name = slot->dev->name; + struct octeontx_mmc_cr_mods mods = {0, 0}; + union mio_emm_rsp_sts rsp_sts; + union mio_emm_cmd emm_cmd; + union mio_emm_rsp_lo rsp_lo; + union mio_emm_buf_idx emm_buf_idx; + union mio_emm_buf_dat emm_buf_dat; + ulong start; + int i; + ulong blkcnt; + + /** + * This constant has a 1 bit for each command which should have a short + * timeout and a 0 for each bit with a long timeout. Currently the + * following commands have a long timeout: + * CMD6, CMD17, CMD18, CMD24, CMD25, CMD32, CMD33, CMD35, CMD36 and + * CMD38. + */ + static const u64 timeout_short = 0xFFFFFFA4FCF9FFDFull; + uint timeout; + + if (cmd->cmdidx == MMC_CMD_SEND_EXT_CSD) { + union mio_emm_rca emm_rca; + + emm_rca.u = 0; + emm_rca.s.card_rca = mmc->rca; + write_csr(mmc, MIO_EMM_RCA(), emm_rca.u); + } + + if (timeout_short & (1ull << cmd->cmdidx)) + timeout = MMC_TIMEOUT_SHORT; + else if (cmd->cmdidx == MMC_CMD_SWITCH && IS_SD(mmc)) + timeout = 2560; + else if (cmd->cmdidx == MMC_CMD_ERASE) + timeout = MMC_TIMEOUT_ERASE; + else + timeout = MMC_TIMEOUT_LONG; + + debug("%s(%s): cmd idx: %u, arg: 0x%x, resp type: 0x%x, timeout: %u\n", + __func__, name, cmd->cmdidx, cmd->cmdarg, cmd->resp_type, + timeout); + if (data) + debug(" data: addr: %p, flags: 0x%x, blocks: %u, blocksize: %u\n", + data->dest, data->flags, data->blocks, data->blocksize); + + octeontx_mmc_switch_to(mmc); + + /* Clear any interrupts */ + write_csr(mmc, MIO_EMM_INT(), read_csr(mmc, MIO_EMM_INT())); + + /* + * We need to override the default command types and response types + * when dealing with SD cards. + */ + mods = octeontx_mmc_get_cr_mods(mmc, cmd, data); + + /* Handle block read/write/stop operations */ + switch (cmd->cmdidx) { + case MMC_CMD_GO_IDLE_STATE: + slot->tuned = false; + slot->hs200_tuned = false; + slot->hs400_tuned = false; + break; + case MMC_CMD_STOP_TRANSMISSION: + return 0; + case MMC_CMD_READ_MULTIPLE_BLOCK: + case MMC_CMD_READ_SINGLE_BLOCK: + pr_debug("%s(%s): Reading blocks\n", __func__, name); + blkcnt = octeontx_mmc_read_blocks(mmc, cmd, data, true); + return (blkcnt > 0) ? 0 : -1; + case MMC_CMD_WRITE_MULTIPLE_BLOCK: + case MMC_CMD_WRITE_SINGLE_BLOCK: + blkcnt = octeontx_mmc_write_blocks(mmc, cmd, data); + return (blkcnt > 0) ? 0 : -1; + case MMC_CMD_SELECT_CARD: + /* Set the RCA register (is it set automatically?) */ + if (IS_SD(mmc)) { + union mio_emm_rca emm_rca; + + emm_rca.u = 0; + emm_rca.s.card_rca = (cmd->cmdarg >> 16); + write_csr(mmc, MIO_EMM_RCA(), emm_rca.u); + debug("%s: Set SD relative address (RCA) to 0x%x\n", + __func__, emm_rca.s.card_rca); + } + break; + + case MMC_CMD_SWITCH: + if (!data && !slot->is_acmd) + octeontx_mmc_track_switch(mmc, cmd->cmdarg); + break; + } + + emm_cmd.u = 0; + emm_cmd.s.cmd_val = 1; + emm_cmd.s.bus_id = slot->bus_id; + emm_cmd.s.cmd_idx = cmd->cmdidx; + emm_cmd.s.arg = cmd->cmdarg; + emm_cmd.s.ctype_xor = mods.ctype_xor; + emm_cmd.s.rtype_xor = mods.rtype_xor; + if (data && data->blocks == 1 && data->blocksize != 512) { + emm_cmd.s.offset = + 64 - ((data->blocks * data->blocksize) / 8); + debug("%s: offset set to %u\n", __func__, emm_cmd.s.offset); + } + + if (data && data->flags & MMC_DATA_WRITE) { + u8 *src = (u8 *)data->src; + + if (!src) { + pr_err("%s(%s): Error: data source for cmd 0x%x is NULL!\n", + __func__, name, cmd->cmdidx); + return -1; + } + if (data->blocksize > 512) { + pr_err("%s(%s): Error: data for cmd 0x%x exceeds 512 bytes\n", + __func__, name, cmd->cmdidx); + return -1; + } +#ifdef DEBUG + debug("%s: Sending %d bytes data\n", __func__, data->blocksize); + print_buffer(0, src, 1, data->blocksize, 0); +#endif + emm_buf_idx.u = 0; + emm_buf_idx.s.inc = 1; + write_csr(mmc, MIO_EMM_BUF_IDX(), emm_buf_idx.u); + for (i = 0; i < (data->blocksize + 7) / 8; i++) { + memcpy(&emm_buf_dat.u, src, sizeof(emm_buf_dat.u)); + write_csr(mmc, MIO_EMM_BUF_DAT(), + cpu_to_be64(emm_buf_dat.u)); + src += sizeof(emm_buf_dat.u); + } + write_csr(mmc, MIO_EMM_BUF_IDX(), 0); + } + debug("%s(%s): Sending command %u (emm_cmd: 0x%llx)\n", __func__, + name, cmd->cmdidx, emm_cmd.u); + set_wdog(mmc, timeout * 1000); + write_csr(mmc, MIO_EMM_CMD(), emm_cmd.u); + + /* Wait for command to finish or time out */ + start = get_timer(0); + do { + rsp_sts.u = read_csr(mmc, MIO_EMM_RSP_STS()); + WATCHDOG_RESET(); + } while (!rsp_sts.s.cmd_done && !rsp_sts.s.rsp_timeout && + (get_timer(start) < timeout + 10)); + octeontx_mmc_print_rsp_errors(mmc, rsp_sts); + if (rsp_sts.s.rsp_timeout || !rsp_sts.s.cmd_done) { + debug("%s(%s): Error: command %u(0x%x) timed out. rsp_sts: 0x%llx\n", + __func__, name, cmd->cmdidx, cmd->cmdarg, rsp_sts.u); + octeontx_mmc_print_registers(mmc); + return -ETIMEDOUT; + } + if (rsp_sts.s.rsp_crc_err) { + debug("%s(%s): RSP CRC error, rsp_sts: 0x%llx, cmdidx: %u, arg: 0x%08x\n", + __func__, name, rsp_sts.u, cmd->cmdidx, cmd->cmdarg); + octeontx_mmc_print_registers(mmc); + return -1; + } + if (slot->bus_id != rsp_sts.s.bus_id) { + pr_warn("%s(%s): bus id mismatch, got %d, expected %d for command 0x%x(0x%x)\n", + __func__, name, + rsp_sts.s.bus_id, slot->bus_id, + cmd->cmdidx, cmd->cmdarg); + goto error; + } + if (rsp_sts.s.rsp_bad_sts) { + rsp_lo.u = read_csr(mmc, MIO_EMM_RSP_LO()); + debug("%s: Bad response for bus id %d, cmd id %d:\n" + " rsp_timeout: %d\n" + " rsp_bad_sts: %d\n" + " rsp_crc_err: %d\n", + __func__, slot->bus_id, cmd->cmdidx, + rsp_sts.s.rsp_timeout, + rsp_sts.s.rsp_bad_sts, + rsp_sts.s.rsp_crc_err); + if (rsp_sts.s.rsp_type == 1 && rsp_sts.s.rsp_bad_sts) { + debug(" Response status: 0x%llx\n", + (rsp_lo.u >> 8) & 0xffffffff); +#ifdef DEBUG + mmc_print_status((rsp_lo.u >> 8) & 0xffffffff); +#endif + } + goto error; + } + if (rsp_sts.s.cmd_idx != cmd->cmdidx) { + debug("%s(%s): Command response index %d does not match command index %d\n", + __func__, name, rsp_sts.s.cmd_idx, cmd->cmdidx); + octeontx_print_rsp_sts(mmc); + debug("%s: rsp_lo: 0x%llx\n", __func__, + read_csr(mmc, MIO_EMM_RSP_LO())); + + goto error; + } + + slot->is_acmd = (cmd->cmdidx == MMC_CMD_APP_CMD); + + if (!cmd->resp_type & MMC_RSP_PRESENT) + debug(" Response type: 0x%x, no response expected\n", + cmd->resp_type); + /* Get the response if present */ + if (rsp_sts.s.rsp_val && (cmd->resp_type & MMC_RSP_PRESENT)) { + union mio_emm_rsp_hi rsp_hi; + + rsp_lo.u = read_csr(mmc, MIO_EMM_RSP_LO()); + + switch (rsp_sts.s.rsp_type) { + case 1: + case 3: + case 4: + case 5: + cmd->response[0] = (rsp_lo.u >> 8) & 0xffffffffull; + debug(" response: 0x%08x\n", + cmd->response[0]); + cmd->response[1] = 0; + cmd->response[2] = 0; + cmd->response[3] = 0; + break; + case 2: + cmd->response[3] = rsp_lo.u & 0xffffffff; + cmd->response[2] = (rsp_lo.u >> 32) & 0xffffffff; + rsp_hi.u = read_csr(mmc, MIO_EMM_RSP_HI()); + cmd->response[1] = rsp_hi.u & 0xffffffff; + cmd->response[0] = (rsp_hi.u >> 32) & 0xffffffff; + debug(" response: 0x%08x 0x%08x 0x%08x 0x%08x\n", + cmd->response[0], cmd->response[1], + cmd->response[2], cmd->response[3]); + break; + default: + pr_err("%s(%s): Unknown response type 0x%x for command %d, arg: 0x%x, rsp_sts: 0x%llx\n", + __func__, name, rsp_sts.s.rsp_type, cmd->cmdidx, + cmd->cmdarg, rsp_sts.u); + return -1; + } + } else { + debug(" Response not expected\n"); + } + + if (data && data->flags & MMC_DATA_READ) { + u8 *dest = (u8 *)data->dest; + + if (!dest) { + pr_err("%s(%s): Error, destination buffer NULL!\n", + __func__, mmc->dev->name); + goto error; + } + if (data->blocksize > 512) { + printf("%s(%s): Error: data size %u exceeds 512\n", + __func__, mmc->dev->name, + data->blocksize); + goto error; + } + emm_buf_idx.u = 0; + emm_buf_idx.s.inc = 1; + write_csr(mmc, MIO_EMM_BUF_IDX(), emm_buf_idx.u); + for (i = 0; i < (data->blocksize + 7) / 8; i++) { + emm_buf_dat.u = read_csr(mmc, MIO_EMM_BUF_DAT()); + emm_buf_dat.u = be64_to_cpu(emm_buf_dat.u); + memcpy(dest, &emm_buf_dat.u, sizeof(emm_buf_dat.u)); + dest += sizeof(emm_buf_dat.u); + } + write_csr(mmc, MIO_EMM_BUF_IDX(), 0); +#ifdef DEBUG + debug("%s: Received %d bytes data\n", __func__, + data->blocksize); + print_buffer(0, data->dest, 1, data->blocksize, 0); +#endif + } + + return 0; +error: +#ifdef DEBUG + octeontx_mmc_print_registers(mmc); +#endif + return -1; +} + +static int octeontx_mmc_dev_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + return octeontx_mmc_send_cmd(dev_to_mmc(dev), cmd, data); +} + +#ifdef MMC_SUPPORTS_TUNING +static int octeontx_mmc_test_cmd(struct mmc *mmc, u32 opcode, int *statp) +{ + struct mmc_cmd cmd; + int err; + + memset(&cmd, 0, sizeof(cmd)); + + debug("%s(%s, %u, %p)\n", __func__, mmc->dev->name, opcode, statp); + cmd.cmdidx = opcode; + cmd.resp_type = MMC_RSP_R1; + cmd.cmdarg = mmc->rca << 16; + + err = octeontx_mmc_send_cmd(mmc, &cmd, NULL); + if (err) + debug("%s(%s, %u) returned %d\n", __func__, + mmc->dev->name, opcode, err); + if (statp) + *statp = cmd.response[0]; + return err; +} + +static int octeontx_mmc_test_get_ext_csd(struct mmc *mmc, u32 opcode, + int *statp) +{ + struct mmc_cmd cmd; + struct mmc_data data; + int err; + u8 ext_csd[MMC_MAX_BLOCK_LEN]; + + debug("%s(%s, %u, %p)\n", __func__, mmc->dev->name, opcode, statp); + memset(&cmd, 0, sizeof(cmd)); + + cmd.cmdidx = MMC_CMD_SEND_EXT_CSD; + cmd.resp_type = MMC_RSP_R1; + cmd.cmdarg = 0; + + data.dest = (char *)ext_csd; + data.blocks = 1; + data.blocksize = MMC_MAX_BLOCK_LEN; + data.flags = MMC_DATA_READ; + + err = octeontx_mmc_send_cmd(mmc, &cmd, &data); + if (statp) + *statp = cmd.response[0]; + + return err; +} + +/** + * Wrapper to set the MIO_EMM_TIMING register + * + * @param mmc pointer to mmc data structure + * @param emm_timing New emm_timing register value + * + * On some devices it is possible that changing the data out value can + * cause a glitch on an internal fifo. This works around this problem + * by performing a soft-reset immediately before setting the timing register. + * + * Note: this function should not be called from any function that + * performs DMA or block operations since not all registers are + * preserved. + */ +static void octeontx_mmc_set_emm_timing(struct mmc *mmc, + union mio_emm_timing emm_timing) +{ + union mio_emm_cfg emm_cfg; + struct octeontx_mmc_slot *slot = mmc->priv; + union mio_emm_debug emm_debug; + + debug("%s(%s, 0x%llx) din: %u\n", __func__, mmc->dev->name, + emm_timing.u, emm_timing.s.data_in_tap); + + udelay(1); + if (slot->host->tap_requires_noclk) { + /* Turn off the clock */ + emm_debug.u = read_csr(mmc, MIO_EMM_DEBUG()); + emm_debug.s.emmc_clk_disable = 1; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + udelay(1); + emm_debug.s.rdsync_rst = 1; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + } + emm_cfg.u = read_csr(mmc, MIO_EMM_CFG()); + emm_cfg.s.bus_ena = 1 << 3; + write_csr(mmc, MIO_EMM_CFG(), emm_cfg.u); + + udelay(1); + write_csr(mmc, MIO_EMM_TIMING(), emm_timing.u); + udelay(1); + + if (slot->host->tap_requires_noclk) { + /* Turn on the clock */ + emm_debug.s.rdsync_rst = 0; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + udelay(1); + emm_debug.s.emmc_clk_disable = 0; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + udelay(1); + } + emm_cfg.s.bus_ena = 1 << mmc_to_slot(mmc)->bus_id; + write_csr(mmc, MIO_EMM_CFG(), emm_cfg.u); +} + +static const u8 octeontx_hs400_tuning_block[512] = { + 0xff, 0xff, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, + 0xff, 0xff, 0xcc, 0xcc, 0xcc, 0x33, 0xcc, 0xcc, + 0xcc, 0x33, 0x33, 0xcc, 0xcc, 0xcc, 0xff, 0xff, + 0xff, 0xee, 0xff, 0xff, 0xff, 0xee, 0xee, 0xff, + 0xff, 0xff, 0xdd, 0xff, 0xff, 0xff, 0xdd, 0xdd, + 0xff, 0xff, 0xff, 0xbb, 0xff, 0xff, 0xff, 0xbb, + 0xbb, 0xff, 0xff, 0xff, 0x77, 0xff, 0xff, 0xff, + 0x77, 0x77, 0xff, 0x77, 0xbb, 0xdd, 0xee, 0xff, + 0xff, 0xff, 0xff, 0x00, 0xff, 0xff, 0xff, 0x00, + 0x00, 0xff, 0xff, 0xcc, 0xcc, 0xcc, 0x33, 0xcc, + 0xcc, 0xcc, 0x33, 0x33, 0xcc, 0xcc, 0xcc, 0xff, + 0xff, 0xff, 0xee, 0xff, 0xff, 0xff, 0xee, 0xee, + 0xff, 0xff, 0xff, 0xdd, 0xff, 0xff, 0xff, 0xdd, + 0xdd, 0xff, 0xff, 0xff, 0xbb, 0xff, 0xff, 0xff, + 0xbb, 0xbb, 0xff, 0xff, 0xff, 0x77, 0xff, 0xff, + 0xff, 0x77, 0x77, 0xff, 0x77, 0xbb, 0xdd, 0xee, + 0xff, 0xff, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, + 0xff, 0xff, 0xcc, 0xcc, 0xcc, 0x33, 0xcc, 0xcc, + 0xcc, 0x33, 0x33, 0xcc, 0xcc, 0xcc, 0xff, 0xff, + 0xff, 0xee, 0xff, 0xff, 0xff, 0xee, 0xee, 0xff, + 0xff, 0xff, 0xdd, 0xff, 0xff, 0xff, 0xdd, 0xdd, + 0xff, 0xff, 0xff, 0xbb, 0xff, 0xff, 0xff, 0xbb, + 0xbb, 0xff, 0xff, 0xff, 0x77, 0xff, 0xff, 0xff, + 0x77, 0x77, 0xff, 0x77, 0xbb, 0xdd, 0xee, 0xff, + 0xff, 0xff, 0xff, 0x00, 0xff, 0xff, 0xff, 0x00, + 0x00, 0xff, 0xff, 0xcc, 0xcc, 0xcc, 0x33, 0xcc, + 0xcc, 0xcc, 0x33, 0x33, 0xcc, 0xcc, 0xcc, 0xff, + 0xff, 0xff, 0xee, 0xff, 0xff, 0xff, 0xee, 0xee, + 0xff, 0xff, 0xff, 0xdd, 0xff, 0xff, 0xff, 0xdd, + 0xdd, 0xff, 0xff, 0xff, 0xbb, 0xff, 0xff, 0xff, + 0xbb, 0xbb, 0xff, 0xff, 0xff, 0x77, 0xff, 0xff, + 0xff, 0x77, 0x77, 0xff, 0x77, 0xbb, 0xdd, 0xee, + 0xff, 0xff, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, + 0xff, 0xff, 0xcc, 0xcc, 0xcc, 0x33, 0xcc, 0xcc, + 0xcc, 0x33, 0x33, 0xcc, 0xcc, 0xcc, 0xff, 0xff, + 0xff, 0xee, 0xff, 0xff, 0xff, 0xee, 0xee, 0xff, + 0xff, 0xff, 0xdd, 0xff, 0xff, 0xff, 0xdd, 0xdd, + 0xff, 0xff, 0xff, 0xbb, 0xff, 0xff, 0xff, 0xbb, + 0xbb, 0xff, 0xff, 0xff, 0x77, 0xff, 0xff, 0xff, + 0x77, 0x77, 0xff, 0x77, 0xbb, 0xdd, 0xee, 0xff, + 0xff, 0xff, 0xff, 0x00, 0xff, 0xff, 0xff, 0x00, + 0x00, 0xff, 0xff, 0xcc, 0xcc, 0xcc, 0x33, 0xcc, + 0xcc, 0xcc, 0x33, 0x33, 0xcc, 0xcc, 0xcc, 0xff, + 0xff, 0xff, 0xee, 0xff, 0xff, 0xff, 0xee, 0xee, + 0xff, 0xff, 0xff, 0xdd, 0xff, 0xff, 0xff, 0xdd, + 0xdd, 0xff, 0xff, 0xff, 0xbb, 0xff, 0xff, 0xff, + 0xbb, 0xbb, 0xff, 0xff, 0xff, 0x77, 0xff, 0xff, + 0xff, 0x77, 0x77, 0xff, 0x77, 0xbb, 0xdd, 0xee, + 0xff, 0x00, 0x00, 0xff, 0xff, 0x00, 0xff, 0x00, + 0x00, 0xff, 0x00, 0xff, 0x55, 0xaa, 0x55, 0xaa, + 0xcc, 0x33, 0x33, 0xcc, 0xcc, 0xcc, 0xff, 0xff, + 0xff, 0xee, 0xff, 0xff, 0xff, 0xee, 0xee, 0xff, + 0xff, 0xff, 0xdd, 0xff, 0xff, 0xff, 0xdd, 0xdd, + 0xff, 0xff, 0xff, 0xbb, 0xff, 0xff, 0xff, 0xbb, + 0xbb, 0xff, 0xff, 0xff, 0x77, 0xff, 0xff, 0xff, + 0x77, 0x77, 0xff, 0x77, 0xbb, 0xdd, 0xee, 0xff, + 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, + 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, + 0x01, 0xfe, 0x01, 0xfe, 0xcc, 0xcc, 0xcc, 0xff, + 0xff, 0xff, 0xee, 0xff, 0xff, 0xff, 0xee, 0xee, + 0xff, 0xff, 0xff, 0xdd, 0xff, 0xff, 0xff, 0xdd, + 0xdd, 0xff, 0xff, 0xff, 0xbb, 0xff, 0xff, 0xff, + 0xbb, 0xbb, 0xff, 0xff, 0xff, 0x77, 0xff, 0xff, + 0xff, 0x77, 0x77, 0xff, 0x77, 0xbb, 0xdd, 0xee, + +}; + +/** + * Perform tuning in HS400 mode + * + * @param[in] mmc mmc data structure + * + * @ret 0 for success, otherwise error + */ +static int octeontx_tune_hs400(struct mmc *mmc) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + struct mmc_cmd cmd; + struct mmc_data data; + union mio_emm_timing emm_timing; + u8 buffer[mmc->read_bl_len]; + int tap_adj; + int err = -1; + int tap; + int run = 0; + int start_run = -1; + int best_run = 0; + int best_start = -1; + bool prev_ok = false; + char env_name[64]; + char how[MAX_NO_OF_TAPS + 1] = ""; + + if (slot->hs400_tuning_block == -1) + return 0; + + /* The eMMC standard disables all tuning support when operating in + * DDR modes like HS400. The problem with this is that there are + * many cases where the HS200 tuning does not work for HS400 mode. + * In order to perform this tuning, while in HS200 a block is written + * to a block specified in the device tree (marvell,hs400-tuning-block) + * which is used for tuning in this function by repeatedly reading + * this block and comparing the data and return code. This function + * chooses the data input tap in the middle of the longest run of + * successful read operations. + */ + + emm_timing = slot->hs200_taps; + debug("%s(%s): Start ci: %d, co: %d, di: %d, do: %d\n", + __func__, mmc->dev->name, emm_timing.s.cmd_in_tap, + emm_timing.s.cmd_out_tap, emm_timing.s.data_in_tap, + emm_timing.s.data_out_tap); + memset(buffer, 0xdb, sizeof(buffer)); + + snprintf(env_name, sizeof(env_name), "emmc%d_data_in_tap_hs400", + slot->bus_id); + tap = env_get_ulong(env_name, 10, -1L); + if (tap >= 0 && tap < MAX_NO_OF_TAPS) { + printf("Overriding data input tap for HS400 mode to %d\n", tap); + emm_timing.s.data_in_tap = tap; + octeontx_mmc_set_emm_timing(mmc, emm_timing); + return 0; + } + + for (tap = 0; tap <= MAX_NO_OF_TAPS; tap++, prev_ok = !err) { + if (tap < MAX_NO_OF_TAPS) { + debug("%s: Testing data in tap %d\n", __func__, tap); + emm_timing.s.data_in_tap = tap; + octeontx_mmc_set_emm_timing(mmc, emm_timing); + + cmd.cmdidx = MMC_CMD_READ_SINGLE_BLOCK; + cmd.cmdarg = slot->hs400_tuning_block; + cmd.resp_type = MMC_RSP_R1; + data.dest = (void *)buffer; + data.blocks = 1; + data.blocksize = mmc->read_bl_len; + data.flags = MMC_DATA_READ; + err = !octeontx_mmc_read_blocks(mmc, &cmd, &data, + false); + if (err || memcmp(buffer, octeontx_hs400_tuning_block, + sizeof(buffer))) { +#ifdef DEBUG + if (!err) { + debug("%s: data mismatch. Read:\n", + __func__); + print_buffer(0, buffer, 1, + sizeof(buffer), 0); + debug("\nExpected:\n"); + print_buffer(0, + octeontx_hs400_tuning_block, 1, + sizeof(octeontx_hs400_tuning_block), + 0); + } else { + debug("%s: Error %d reading block\n", + __func__, err); + } +#endif + err = -EINVAL; + } else { + debug("%s: tap %d good\n", __func__, tap); + } + how[tap] = "-+"[!err]; + } else { + err = -EINVAL; + } + + if (!err) { + if (!prev_ok) + start_run = tap; + } else if (prev_ok) { + run = tap - 1 - start_run; + if (start_run >= 0 && run > best_run) { + best_start = start_run; + best_run = run; + } + } + } + + how[tap - 1] = '\0'; + if (best_start < 0) { + printf("%s(%s): %lldMHz tuning failed for HS400\n", + __func__, mmc->dev->name, slot->clock / 1000000); + return -EINVAL; + } + tap = best_start + best_run / 2; + + snprintf(env_name, sizeof(env_name), "emmc%d_data_in_tap_adj_hs400", + slot->bus_id); + tap_adj = env_get_ulong(env_name, 10, slot->hs400_tap_adj); + /* + * Keep it in range and if out of range force it back in with a small + * buffer. + */ + if (best_run > 3) { + tap = tap + tap_adj; + if (tap >= best_start + best_run) + tap = best_start + best_run - 2; + if (tap <= best_start) + tap = best_start + 2; + } + how[tap] = '@'; + debug("Tuning: %s\n", how); + debug("%s(%s): HS400 tap: best run start: %d, length: %d, tap: %d\n", + __func__, mmc->dev->name, best_start, best_run, tap); + slot->hs400_taps = slot->hs200_taps; + slot->hs400_taps.s.data_in_tap = tap; + slot->hs400_tuned = true; + if (env_get_yesno("emmc_export_hs400_taps") > 0) { + debug("%s(%s): Exporting HS400 taps\n", + __func__, mmc->dev->name); + env_set_ulong("emmc_timing_tap", slot->host->timing_taps); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs400_data_in_tap_debug", + slot->bus_id); + env_set(env_name, how); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs400_data_in_tap_val", + slot->bus_id); + env_set_ulong(env_name, tap); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs400_data_in_tap_start", + slot->bus_id); + env_set_ulong(env_name, best_start); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs400_data_in_tap_end", + slot->bus_id); + env_set_ulong(env_name, best_start + best_run); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs400_cmd_in_tap", + slot->bus_id); + env_set_ulong(env_name, slot->hs400_taps.s.cmd_in_tap); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs400_cmd_out_tap", + slot->bus_id); + env_set_ulong(env_name, slot->hs400_taps.s.cmd_out_tap); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs400_cmd_out_delay", + slot->bus_id); + env_set_ulong(env_name, slot->cmd_out_hs400_delay); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs400_data_out_tap", + slot->bus_id); + env_set_ulong(env_name, slot->hs400_taps.s.data_out_tap); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs400_data_out_delay", + slot->bus_id); + env_set_ulong(env_name, slot->data_out_hs400_delay); + } else { + debug("%s(%s): HS400 environment export disabled\n", + __func__, mmc->dev->name); + } + octeontx_mmc_set_timing(mmc); + + return 0; +} + +struct adj { + const char *name; + u8 mask_shift; + int (*test)(struct mmc *mmc, u32 opcode, int *error); + u32 opcode; + bool ddr_only; + bool hs200_only; + bool not_hs200_only; + u8 num_runs; +}; + +struct adj adj[] = { + { "CMD_IN", 48, octeontx_mmc_test_cmd, MMC_CMD_SEND_STATUS, + false, false, false, 2, }, +/* { "CMD_OUT", 32, octeontx_mmc_test_cmd, MMC_CMD_SEND_STATUS, },*/ + { "DATA_IN(HS200)", 16, mmc_send_tuning, + MMC_CMD_SEND_TUNING_BLOCK_HS200, false, true, false, 2, }, + { "DATA_IN", 16, octeontx_mmc_test_get_ext_csd, 0, false, false, + true, 2, }, +/* { "DATA_OUT", 0, octeontx_mmc_test_cmd, 0, true, false},*/ + { NULL, }, +}; + +/** + * Perform tuning tests to find optimal timing + * + * @param mmc mmc device + * @param adj parameter to tune + * @param opcode command opcode to use + * + * @return 0 for success, -1 if tuning failed + */ +static int octeontx_mmc_adjust_tuning(struct mmc *mmc, struct adj *adj, + u32 opcode) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + union mio_emm_timing timing; + union mio_emm_debug emm_debug; + int tap; + int err = -1; + int run = 0; + int count; + int start_run = -1; + int best_run = 0; + int best_start = -1; + bool prev_ok = false; + u64 tap_status = 0; + const int tap_adj = slot->hs200_tap_adj; + char how[MAX_NO_OF_TAPS + 1] = ""; + bool is_hs200 = mmc->selected_mode == MMC_HS_200; + + debug("%s(%s, %s, %d), hs200: %d\n", __func__, mmc->dev->name, + adj->name, opcode, is_hs200); + octeontx_mmc_set_emm_timing(mmc, + is_hs200 ? slot->hs200_taps : slot->taps); + +#ifdef DEBUG + if (opcode == MMC_CMD_SEND_TUNING_BLOCK_HS200) { + printf("%s(%s): Before tuning %s, opcode: %d\n", + __func__, mmc->dev->name, adj->name, opcode); + octeontx_mmc_print_registers2(mmc, NULL); + } +#endif + + /* + * The algorithm to find the optimal timing is to start + * at the end and work backwards and select the second + * value that passes. Each test is repeated twice. + */ + for (tap = 0; tap <= MAX_NO_OF_TAPS; tap++, prev_ok = !err) { + if (tap < MAX_NO_OF_TAPS) { + if (slot->host->tap_requires_noclk) { + /* Turn off the clock */ + emm_debug.u = read_csr(mmc, MIO_EMM_DEBUG()); + emm_debug.s.emmc_clk_disable = 1; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + udelay(1); + emm_debug.s.rdsync_rst = 1; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + udelay(1); + } + + timing.u = read_csr(mmc, MIO_EMM_TIMING()); + timing.u &= ~(0x3full << adj->mask_shift); + timing.u |= (u64)tap << adj->mask_shift; + write_csr(mmc, MIO_EMM_TIMING(), timing.u); + debug("%s(%s): Testing ci: %d, co: %d, di: %d, do: %d\n", + __func__, mmc->dev->name, timing.s.cmd_in_tap, + timing.s.cmd_out_tap, timing.s.data_in_tap, + timing.s.data_out_tap); + + if (slot->host->tap_requires_noclk) { + /* Turn off the clock */ + emm_debug.s.rdsync_rst = 0; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + udelay(1); + emm_debug.u = read_csr(mmc, MIO_EMM_DEBUG()); + emm_debug.s.emmc_clk_disable = 0; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + udelay(1); + } + for (count = 0; count < 2; count++) { + err = adj->test(mmc, opcode, NULL); + if (err) { + debug("%s(%s, %s): tap %d failed, count: %d, rsp_sts: 0x%llx, rsp_lo: 0x%llx\n", + __func__, mmc->dev->name, + adj->name, tap, count, + read_csr(mmc, + MIO_EMM_RSP_STS()), + read_csr(mmc, + MIO_EMM_RSP_LO())); + debug("%s(%s, %s): tap: %d, do: %d, di: %d, co: %d, ci: %d\n", + __func__, mmc->dev->name, + adj->name, tap, + timing.s.data_out_tap, + timing.s.data_in_tap, + timing.s.cmd_out_tap, + timing.s.cmd_in_tap); + break; + } + debug("%s(%s, %s): tap %d passed, count: %d, rsp_sts: 0x%llx, rsp_lo: 0x%llx\n", + __func__, mmc->dev->name, adj->name, tap, + count, + read_csr(mmc, MIO_EMM_RSP_STS()), + read_csr(mmc, MIO_EMM_RSP_LO())); + } + tap_status |= (u64)(!err) << tap; + how[tap] = "-+"[!err]; + } else { + /* + * Putting the end+1 case in the loop simplifies + * logic, allowing 'prev_ok' to process a sweet + * spot in tuning which extends to the wall. + */ + err = -EINVAL; + } + if (!err) { + /* + * If no CRC/etc errors in the response, but previous + * failed, note the start of a new run. + */ + debug(" prev_ok: %d\n", prev_ok); + if (!prev_ok) + start_run = tap; + } else if (prev_ok) { + run = tap - 1 - start_run; + /* did we just exit a wider sweet spot? */ + if (start_run >= 0 && run > best_run) { + best_start = start_run; + best_run = run; + } + } + } + how[tap - 1] = '\0'; + if (best_start < 0) { + printf("%s(%s, %s): %lldMHz tuning %s failed\n", __func__, + mmc->dev->name, adj->name, slot->clock / 1000000, + adj->name); + return -EINVAL; + } + + tap = best_start + best_run / 2; + debug(" tap %d is center, start: %d, run: %d\n", tap, + best_start, best_run); + if (is_hs200) { + slot->hs200_taps.u &= ~(0x3full << adj->mask_shift); + slot->hs200_taps.u |= (u64)tap << adj->mask_shift; + } else { + slot->taps.u &= ~(0x3full << adj->mask_shift); + slot->taps.u |= (u64)tap << adj->mask_shift; + } + if (best_start < 0) { + printf("%s(%s, %s): %lldMHz tuning %s failed\n", __func__, + mmc->dev->name, adj->name, slot->clock / 1000000, + adj->name); + return -EINVAL; + } + + tap = best_start + best_run / 2; + if (is_hs200 && (tap + tap_adj >= 0) && (tap + tap_adj < 64) && + tap_status & (1ULL << (tap + tap_adj))) { + debug("Adjusting tap from %d by %d to %d\n", + tap, tap_adj, tap + tap_adj); + tap += tap_adj; + } + how[tap] = '@'; + debug("%s/%s %d/%d/%d %s\n", mmc->dev->name, + adj->name, best_start, tap, best_start + best_run, how); + + if (is_hs200) { + slot->hs200_taps.u &= ~(0x3full << adj->mask_shift); + slot->hs200_taps.u |= (u64)tap << adj->mask_shift; + } else { + slot->taps.u &= ~(0x3full << adj->mask_shift); + slot->taps.u |= (u64)tap << adj->mask_shift; + } + +#ifdef DEBUG + if (opcode == MMC_CMD_SEND_TUNING_BLOCK_HS200) { + debug("%s(%s, %s): After successful tuning\n", + __func__, mmc->dev->name, adj->name); + debug("%s(%s, %s): tap: %d, new do: %d, di: %d, co: %d, ci: %d\n", + __func__, mmc->dev->name, adj->name, tap, + slot->taps.s.data_out_tap, + slot->taps.s.data_in_tap, + slot->taps.s.cmd_out_tap, + slot->taps.s.cmd_in_tap); + debug("%s(%s, %s): tap: %d, new do HS200: %d, di: %d, co: %d, ci: %d\n", + __func__, mmc->dev->name, adj->name, tap, + slot->hs200_taps.s.data_out_tap, + slot->hs200_taps.s.data_in_tap, + slot->hs200_taps.s.cmd_out_tap, + slot->hs200_taps.s.cmd_in_tap); + } +#endif + octeontx_mmc_set_timing(mmc); + + if (is_hs200 && env_get_yesno("emmc_export_hs200_taps")) { + char env_name[64]; + + env_set_ulong("emmc_timing_tap", slot->host->timing_taps); + switch (opcode) { + case MMC_CMD_SEND_TUNING_BLOCK: + snprintf(env_name, sizeof(env_name), + "emmc%d_hs200_data_in_tap_debug", + slot->bus_id); + env_set(env_name, how); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs200_data_in_tap_val", slot->bus_id); + env_set_ulong(env_name, tap); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs200_data_in_tap_start", + slot->bus_id); + env_set_ulong(env_name, best_start); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs200_data_in_tap_end", + slot->bus_id); + env_set_ulong(env_name, best_start + best_run); + break; + case MMC_CMD_SEND_STATUS: + snprintf(env_name, sizeof(env_name), + "emmc%d_hs200_cmd_in_tap_debug", + slot->bus_id); + env_set(env_name, how); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs200_cmd_in_tap_val", slot->bus_id); + env_set_ulong(env_name, tap); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs200_cmd_in_tap_start", + slot->bus_id); + env_set_ulong(env_name, best_start); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs200_cmd_in_tap_end", + slot->bus_id); + env_set_ulong(env_name, best_start + best_run); + break; + default: + snprintf(env_name, sizeof(env_name), + "emmc%d_hs200_data_out_tap", slot->bus_id); + env_set_ulong(env_name, slot->data_out_hs200_delay); + snprintf(env_name, sizeof(env_name), + "emmc%d_hs200_cmd_out_tap", slot->bus_id); + env_set_ulong(env_name, slot->cmd_out_hs200_delay); + break; + } + } + + return 0; +} + +static int octeontx_mmc_execute_tuning(struct udevice *dev, u32 opcode) +{ + struct mmc *mmc = dev_to_mmc(dev); + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + union mio_emm_timing emm_timing; + int err; + struct adj *a; + bool is_hs200; + char env_name[64]; + + pr_info("%s re-tuning, opcode 0x%x\n", dev->name, opcode); + + if (slot->is_asim || slot->is_emul) + return 0; + + is_hs200 = (mmc->selected_mode == MMC_HS_200); + if (is_hs200) { + slot->hs200_tuned = false; + slot->hs400_tuned = false; + } else { + slot->tuned = false; + } + octeontx_mmc_set_output_bus_timing(mmc); + octeontx_mmc_set_input_bus_timing(mmc); + emm_timing.u = read_csr(mmc, MIO_EMM_TIMING()); + if (mmc->selected_mode == MMC_HS_200) { + slot->hs200_taps.s.cmd_out_tap = emm_timing.s.cmd_out_tap; + slot->hs200_taps.s.data_out_tap = emm_timing.s.data_out_tap; + } else { + slot->taps.s.cmd_out_tap = emm_timing.s.cmd_out_tap; + slot->taps.s.data_out_tap = emm_timing.s.data_out_tap; + } + octeontx_mmc_set_input_bus_timing(mmc); + octeontx_mmc_set_output_bus_timing(mmc); + + for (a = adj; a->name; a++) { + ulong in_tap; + + if (!strcmp(a->name, "CMD_IN")) { + snprintf(env_name, sizeof(env_name), + "emmc%d_cmd_in_tap", slot->bus_id); + in_tap = env_get_ulong(env_name, 10, (ulong)-1); + if (in_tap != (ulong)-1) { + if (mmc->selected_mode == MMC_HS_200 || + a->hs200_only) { + slot->hs200_taps.s.cmd_in_tap = in_tap; + slot->hs400_taps.s.cmd_in_tap = in_tap; + } else { + slot->taps.s.cmd_in_tap = in_tap; + } + continue; + } + } else if (a->hs200_only && + !strcmp(a->name, "DATA_IN(HS200)")) { + snprintf(env_name, sizeof(env_name), + "emmc%d_data_in_tap_hs200", slot->bus_id); + in_tap = env_get_ulong(env_name, 10, (ulong)-1); + if (in_tap != (ulong)-1) { + debug("%s(%s): Overriding HS200 data in tap to %d\n", + __func__, dev->name, (int)in_tap); + slot->hs200_taps.s.data_in_tap = in_tap; + continue; + } + } else if (!a->hs200_only && !strcmp(a->name, "DATA_IN")) { + snprintf(env_name, sizeof(env_name), + "emmc%d_data_in_tap", slot->bus_id); + in_tap = env_get_ulong(env_name, 10, (ulong)-1); + if (in_tap != (ulong)-1) { + debug("%s(%s): Overriding non-HS200 data in tap to %d\n", + __func__, dev->name, (int)in_tap); + slot->taps.s.data_in_tap = in_tap; + continue; + } + } + + debug("%s(%s): Testing: %s, mode: %s, opcode: %u\n", __func__, + dev->name, a->name, mmc_mode_name(mmc->selected_mode), + opcode); + + /* Skip DDR only test when not in DDR mode */ + if (a->ddr_only && !mmc->ddr_mode) { + debug("%s(%s): Skipping %s due to non-DDR mode\n", + __func__, dev->name, a->name); + continue; + } + /* Skip hs200 tests in non-hs200 mode and + * non-hs200 tests in hs200 mode + */ + if (is_hs200) { + if (a->not_hs200_only) { + debug("%s(%s): Skipping %s\n", __func__, + dev->name, a->name); + continue; + } + } else { + if (a->hs200_only) { + debug("%s(%s): Skipping %s\n", __func__, + dev->name, a->name); + continue; + } + } + + err = octeontx_mmc_adjust_tuning(mmc, a, a->opcode ? + a->opcode : opcode); + if (err) { + pr_err("%s(%s, %u): tuning %s failed\n", __func__, + dev->name, opcode, a->name); + return err; + } + } + + octeontx_mmc_set_timing(mmc); + if (is_hs200) + slot->hs200_tuned = true; + else + slot->tuned = true; + + if (slot->hs400_tuning_block != -1) { + struct mmc_cmd cmd; + struct mmc_data data; + u8 buffer[mmc->read_bl_len]; + + cmd.cmdidx = MMC_CMD_READ_SINGLE_BLOCK; + cmd.cmdarg = slot->hs400_tuning_block; + cmd.resp_type = MMC_RSP_R1; + data.dest = (void *)buffer; + data.blocks = 1; + data.blocksize = mmc->read_bl_len; + data.flags = MMC_DATA_READ; + err = octeontx_mmc_read_blocks(mmc, &cmd, &data, true) != 1; + + if (err) { + printf("%s: Cannot read HS400 tuning block %u\n", + dev->name, slot->hs400_tuning_block); + return err; + } + if (memcmp(buffer, octeontx_hs400_tuning_block, + sizeof(buffer))) { + debug("%s(%s): Writing new HS400 tuning block to block %d\n", + __func__, dev->name, slot->hs400_tuning_block); + cmd.cmdidx = MMC_CMD_WRITE_SINGLE_BLOCK; + data.src = (void *)octeontx_hs400_tuning_block; + data.flags = MMC_DATA_WRITE; + err = !octeontx_mmc_write_blocks(mmc, &cmd, &data); + if (err) { + printf("%s: Cannot write HS400 tuning block %u\n", + dev->name, slot->hs400_tuning_block); + return -EINVAL; + } + } + } + + return 0; +} +#else /* MMC_SUPPORTS_TUNING */ +static void octeontx_mmc_set_emm_timing(struct mmc *mmc, + union mio_emm_timing emm_timing) +{ +} +#endif /* MMC_SUPPORTS_TUNING */ + +/** + * Calculate the clock period with rounding up + * + * @param mmc mmc device + * @return clock period in system clocks for clk_lo + clk_hi + */ +static u32 octeontx_mmc_calc_clk_period(struct mmc *mmc) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + struct octeontx_mmc_host *host = slot->host; + + return DIV_ROUND_UP(host->sys_freq, mmc->clock); +} + +static int octeontx_mmc_set_ios(struct udevice *dev) +{ + struct octeontx_mmc_slot *slot = dev_to_mmc_slot(dev); + struct mmc *mmc = &slot->mmc; + struct octeontx_mmc_host *host = slot->host; + union mio_emm_switch emm_switch; + union mio_emm_modex mode; + uint clock; + int bus_width = 0; + int clk_period = 0; + int power_class = 10; + int err = 0; + bool is_hs200 = false; + bool is_hs400 = false; + + debug("%s(%s): Entry\n", __func__, dev->name); + debug(" clock: %u, bus width: %u, mode: %u\n", mmc->clock, + mmc->bus_width, mmc->selected_mode); + debug(" host caps: 0x%x, card caps: 0x%x\n", mmc->host_caps, + mmc->card_caps); + octeontx_mmc_switch_to(mmc); + + clock = mmc->clock; + if (!clock) + clock = mmc->cfg->f_min; + + switch (mmc->bus_width) { + case 8: + bus_width = 2; + break; + case 4: + bus_width = 1; + break; + case 1: + bus_width = 0; + break; + default: + pr_warn("%s(%s): Invalid bus width %d, defaulting to 1\n", + __func__, dev->name, mmc->bus_width); + bus_width = 0; + } + + /* DDR is available for 4/8 bit bus width */ + if (mmc->ddr_mode && bus_width) + bus_width |= 4; + + debug("%s: sys_freq: %llu\n", __func__, host->sys_freq); + clk_period = octeontx_mmc_calc_clk_period(mmc); + + emm_switch.u = 0; + emm_switch.s.bus_width = bus_width; + emm_switch.s.power_class = power_class; + emm_switch.s.clk_hi = clk_period / 2; + emm_switch.s.clk_lo = clk_period / 2; + + debug("%s: last mode: %d, mode: %d, last clock: %u, clock: %u, ddr: %d\n", + __func__, slot->last_mode, mmc->selected_mode, + slot->last_clock, mmc->clock, mmc->ddr_mode); + switch (mmc->selected_mode) { + case MMC_LEGACY: + break; + case MMC_HS: + case SD_HS: + case MMC_HS_52: + emm_switch.s.hs_timing = 1; + break; + case MMC_HS_200: + is_hs200 = true; + fallthrough; + case UHS_SDR12: + case UHS_SDR25: + case UHS_SDR50: + case UHS_SDR104: + emm_switch.s.hs200_timing = 1; + break; + case MMC_HS_400: + is_hs400 = true; + fallthrough; + case UHS_DDR50: + case MMC_DDR_52: + emm_switch.s.hs400_timing = 1; + break; + default: + pr_err("%s(%s): Unsupported mode 0x%x\n", __func__, dev->name, + mmc->selected_mode); + return -1; + } + emm_switch.s.bus_id = slot->bus_id; + + if (!is_hs200 && !is_hs400 && + (mmc->selected_mode != slot->last_mode || + mmc->clock != slot->last_clock) && + !mmc->ddr_mode) { + slot->tuned = false; + slot->last_mode = mmc->selected_mode; + slot->last_clock = mmc->clock; + } + + if (CONFIG_IS_ENABLED(MMC_VERBOSE)) { + debug("%s(%s): Setting bus mode to %s\n", __func__, dev->name, + mmc_mode_name(mmc->selected_mode)); + } else { + debug("%s(%s): Setting bus mode to 0x%x\n", __func__, dev->name, + mmc->selected_mode); + } + + debug(" Trying switch 0x%llx w%d hs:%d hs200:%d hs400:%d\n", + emm_switch.u, emm_switch.s.bus_width, emm_switch.s.hs_timing, + emm_switch.s.hs200_timing, emm_switch.s.hs400_timing); + + set_wdog(mmc, 1000); + do_switch(mmc, emm_switch); + mdelay(100); + mode.u = read_csr(mmc, MIO_EMM_MODEX(slot->bus_id)); + debug("%s(%s): mode: 0x%llx w:%d, hs:%d, hs200:%d, hs400:%d\n", + __func__, dev->name, mode.u, mode.s.bus_width, + mode.s.hs_timing, mode.s.hs200_timing, mode.s.hs400_timing); + + err = octeontx_mmc_configure_delay(mmc); + +#ifdef MMC_SUPPORTS_TUNING + if (!err && mmc->selected_mode == MMC_HS_400 && !slot->hs400_tuned) { + debug("%s: Tuning HS400 mode\n", __func__); + err = octeontx_tune_hs400(mmc); + } +#endif + + return err; +} + +/** + * Gets the status of the card detect pin + */ +static int octeontx_mmc_get_cd(struct udevice *dev) +{ + struct octeontx_mmc_slot *slot = dev_to_mmc_slot(dev); + int val = 1; + + if (dm_gpio_is_valid(&slot->cd_gpio)) { + val = dm_gpio_get_value(&slot->cd_gpio); + val ^= slot->cd_inverted; + } + debug("%s(%s): cd: %d\n", __func__, dev->name, val); + return val; +} + +/** + * Gets the status of the write protect pin + */ +static int octeontx_mmc_get_wp(struct udevice *dev) +{ + struct octeontx_mmc_slot *slot = dev_to_mmc_slot(dev); + int val = 0; + + if (dm_gpio_is_valid(&slot->wp_gpio)) { + val = dm_gpio_get_value(&slot->wp_gpio); + val ^= slot->wp_inverted; + } + debug("%s(%s): wp: %d\n", __func__, dev->name, val); + return val; +} + +static void octeontx_mmc_set_timing(struct mmc *mmc) +{ + union mio_emm_timing timing; + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + + switch (mmc->selected_mode) { + case MMC_HS_200: + timing = slot->hs200_taps; + break; + case MMC_HS_400: + timing = slot->hs400_tuned ? + slot->hs400_taps : slot->hs200_taps; + break; + default: + timing = slot->taps; + break; + } + + debug("%s(%s):\n cmd_in_tap: %u\n cmd_out_tap: %u\n data_in_tap: %u\n data_out_tap: %u\n", + __func__, mmc->dev->name, timing.s.cmd_in_tap, + timing.s.cmd_out_tap, timing.s.data_in_tap, + timing.s.data_out_tap); + + octeontx_mmc_set_emm_timing(mmc, timing); +} + +static int octeontx_mmc_configure_delay(struct mmc *mmc) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + struct octeontx_mmc_host *host __maybe_unused = slot->host; + bool __maybe_unused is_hs200; + bool __maybe_unused is_hs400; + + debug("%s(%s)\n", __func__, mmc->dev->name); + + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { + union mio_emm_sample emm_sample; + + emm_sample.u = 0; + emm_sample.s.cmd_cnt = slot->cmd_cnt; + emm_sample.s.dat_cnt = slot->dat_cnt; + write_csr(mmc, MIO_EMM_SAMPLE(), emm_sample.u); + } else { + is_hs200 = (mmc->selected_mode == MMC_HS_200); + is_hs400 = (mmc->selected_mode == MMC_HS_400); + + if ((is_hs200 && slot->hs200_tuned) || + (is_hs400 && slot->hs400_tuned) || + (!is_hs200 && !is_hs400 && slot->tuned)) { + octeontx_mmc_set_output_bus_timing(mmc); + } else { + int half = MAX_NO_OF_TAPS / 2; + int dout, cout; + + switch (mmc->selected_mode) { + case MMC_LEGACY: + if (IS_SD(mmc)) { + cout = MMC_SD_LEGACY_DEFAULT_CMD_OUT_TAP; + dout = MMC_SD_LEGACY_DEFAULT_DATA_OUT_TAP; + } else { + cout = MMC_LEGACY_DEFAULT_CMD_OUT_TAP; + dout = MMC_LEGACY_DEFAULT_DATA_OUT_TAP; + } + break; + case MMC_HS: + cout = MMC_HS_CMD_OUT_TAP; + dout = MMC_HS_DATA_OUT_TAP; + break; + case SD_HS: + case UHS_SDR12: + case UHS_SDR25: + case UHS_SDR50: + cout = MMC_SD_HS_CMD_OUT_TAP; + dout = MMC_SD_HS_DATA_OUT_TAP; + break; + case UHS_SDR104: + case UHS_DDR50: + case MMC_HS_52: + case MMC_DDR_52: + cout = MMC_DEFAULT_CMD_OUT_TAP; + dout = MMC_DEFAULT_DATA_OUT_TAP; + break; + case MMC_HS_200: + cout = -1; + dout = -1; + if (host->timing_calibrated) { + cout = octeontx2_mmc_calc_delay( + mmc, slot->cmd_out_hs200_delay); + dout = octeontx2_mmc_calc_delay( + mmc, + slot->data_out_hs200_delay); + debug("%s(%s): Calibrated HS200/HS400 cmd out delay: %dps tap: %d, data out delay: %d, tap: %d\n", + __func__, mmc->dev->name, + slot->cmd_out_hs200_delay, cout, + slot->data_out_hs200_delay, dout); + } else { + cout = MMC_DEFAULT_HS200_CMD_OUT_TAP; + dout = MMC_DEFAULT_HS200_DATA_OUT_TAP; + } + is_hs200 = true; + break; + case MMC_HS_400: + cout = -1; + dout = -1; + if (host->timing_calibrated) { + if (slot->cmd_out_hs400_delay) + cout = octeontx2_mmc_calc_delay( + mmc, + slot->cmd_out_hs400_delay); + if (slot->data_out_hs400_delay) + dout = octeontx2_mmc_calc_delay( + mmc, + slot->data_out_hs400_delay); + debug("%s(%s): Calibrated HS200/HS400 cmd out delay: %dps tap: %d, data out delay: %d, tap: %d\n", + __func__, mmc->dev->name, + slot->cmd_out_hs400_delay, cout, + slot->data_out_hs400_delay, dout); + } else { + cout = MMC_DEFAULT_HS400_CMD_OUT_TAP; + dout = MMC_DEFAULT_HS400_DATA_OUT_TAP; + } + is_hs400 = true; + break; + default: + pr_err("%s(%s): Invalid mode %d\n", __func__, + mmc->dev->name, mmc->selected_mode); + return -1; + } + debug("%s(%s): Not tuned, hs200: %d, hs200 tuned: %d, hs400: %d, hs400 tuned: %d, tuned: %d\n", + __func__, mmc->dev->name, is_hs200, + slot->hs200_tuned, + is_hs400, slot->hs400_tuned, slot->tuned); + /* Set some defaults */ + if (is_hs200) { + slot->hs200_taps.u = 0; + slot->hs200_taps.s.cmd_out_tap = cout; + slot->hs200_taps.s.data_out_tap = dout; + slot->hs200_taps.s.cmd_in_tap = half; + slot->hs200_taps.s.data_in_tap = half; + } else if (is_hs400) { + slot->hs400_taps.u = 0; + slot->hs400_taps.s.cmd_out_tap = cout; + slot->hs400_taps.s.data_out_tap = dout; + slot->hs400_taps.s.cmd_in_tap = half; + slot->hs400_taps.s.data_in_tap = half; + } else { + slot->taps.u = 0; + slot->taps.s.cmd_out_tap = cout; + slot->taps.s.data_out_tap = dout; + slot->taps.s.cmd_in_tap = half; + slot->taps.s.data_in_tap = half; + } + } + + if (is_hs200) + debug("%s(%s): hs200 taps: ci: %u, co: %u, di: %u, do: %u\n", + __func__, mmc->dev->name, + slot->hs200_taps.s.cmd_in_tap, + slot->hs200_taps.s.cmd_out_tap, + slot->hs200_taps.s.data_in_tap, + slot->hs200_taps.s.data_out_tap); + else if (is_hs400) + debug("%s(%s): hs400 taps: ci: %u, co: %u, di: %u, do: %u\n", + __func__, mmc->dev->name, + slot->hs400_taps.s.cmd_in_tap, + slot->hs400_taps.s.cmd_out_tap, + slot->hs400_taps.s.data_in_tap, + slot->hs400_taps.s.data_out_tap); + else + debug("%s(%s): taps: ci: %u, co: %u, di: %u, do: %u\n", + __func__, mmc->dev->name, slot->taps.s.cmd_in_tap, + slot->taps.s.cmd_out_tap, + slot->taps.s.data_in_tap, + slot->taps.s.data_out_tap); + octeontx_mmc_set_timing(mmc); + debug("%s: Done\n", __func__); + } + + return 0; +} + +/** + * Sets the MMC watchdog timer in microseconds + * + * @param mmc mmc device + * @param us timeout in microseconds, 0 for maximum timeout + */ +static void set_wdog(struct mmc *mmc, u64 us) +{ + union mio_emm_wdog wdog; + u64 val; + + val = (us * mmc->clock) / 1000000; + if (val >= (1 << 26) || !us) { + if (us) + pr_debug("%s: warning: timeout %llu exceeds max value %llu, truncating\n", + __func__, us, + (u64)(((1ULL << 26) - 1) * 1000000ULL) / + mmc->clock); + val = (1 << 26) - 1; + } + wdog.u = 0; + wdog.s.clk_cnt = val; + write_csr(mmc, MIO_EMM_WDOG(), wdog.u); +} + +/** + * Set the IO drive strength and slew + * + * @param mmc mmc device + */ +static void octeontx_mmc_io_drive_setup(struct mmc *mmc) +{ + if (!IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + union mio_emm_io_ctl io_ctl; + + if (slot->drive < 0 || slot->slew < 0) + return; + + io_ctl.u = 0; + io_ctl.s.drive = slot->drive; + io_ctl.s.slew = slot->slew; + write_csr(mmc, MIO_EMM_IO_CTL(), io_ctl.u); + } +} + +/** + * Print switch errors + * + * @param mmc mmc device + */ +static void check_switch_errors(struct mmc *mmc) +{ + union mio_emm_switch emm_switch; + + emm_switch.u = read_csr(mmc, MIO_EMM_SWITCH()); + if (emm_switch.s.switch_err0) + pr_err("%s: Switch power class error\n", mmc->cfg->name); + if (emm_switch.s.switch_err1) + pr_err("%s: Switch HS timing error\n", mmc->cfg->name); + if (emm_switch.s.switch_err2) + pr_err("%s: Switch bus width error\n", mmc->cfg->name); +} + +static void do_switch(struct mmc *mmc, union mio_emm_switch emm_switch) +{ + union mio_emm_rsp_sts rsp_sts; + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + int bus_id = emm_switch.s.bus_id; + ulong start; + + if (emm_switch.s.bus_id != 0) { + emm_switch.s.bus_id = 0; + write_csr(mmc, MIO_EMM_SWITCH(), emm_switch.u); + udelay(100); + emm_switch.s.bus_id = bus_id; + } + debug("%s(%s, 0x%llx)\n", __func__, mmc->dev->name, emm_switch.u); + write_csr(mmc, MIO_EMM_SWITCH(), emm_switch.u); + + start = get_timer(0); + do { + rsp_sts.u = read_csr(mmc, MIO_EMM_RSP_STS()); + if (!rsp_sts.s.switch_val) + break; + udelay(100); + } while (get_timer(start) < 10); + if (rsp_sts.s.switch_val) { + pr_warn("%s(%s): Warning: writing 0x%llx to emm_switch timed out, status: 0x%llx\n", + __func__, mmc->dev->name, emm_switch.u, rsp_sts.u); + } + slot->cached_switch = emm_switch; + check_switch_errors(mmc); + slot->cached_switch.u = emm_switch.u; + debug("%s: emm_switch: 0x%llx, rsp_lo: 0x%llx\n", + __func__, read_csr(mmc, MIO_EMM_SWITCH()), + read_csr(mmc, MIO_EMM_RSP_LO())); +} + +/** + * Given a delay in ps, return the tap delay count + * + * @param mmc mmc data structure + * @param delay delay in picoseconds + * + * @return Number of tap cycles or error if -1 + */ +static int octeontx2_mmc_calc_delay(struct mmc *mmc, int delay) +{ + struct octeontx_mmc_host *host = mmc_to_host(mmc); + + if (host->is_asim || host->is_emul) + return 63; + + if (!host->timing_taps) { + pr_err("%s(%s): Error: host timing not calibrated\n", + __func__, mmc->dev->name); + return -1; + } + debug("%s(%s, %d) timing taps: %llu\n", __func__, mmc->dev->name, + delay, host->timing_taps); + return min_t(int, DIV_ROUND_UP(delay, host->timing_taps), 63); +} + +/** + * Calibrates the delay based on the internal clock + * + * @param mmc Pointer to mmc data structure + * + * @return 0 for success or -ETIMEDOUT on error + * + * NOTE: On error a default value will be calculated. + */ +static int octeontx_mmc_calibrate_delay(struct mmc *mmc) +{ + union mio_emm_calb emm_calb; + union mio_emm_tap emm_tap; + union mio_emm_cfg emm_cfg; + union mio_emm_io_ctl emm_io_ctl; + union mio_emm_switch emm_switch; + union mio_emm_wdog emm_wdog; + union mio_emm_sts_mask emm_sts_mask; + union mio_emm_debug emm_debug; + union mio_emm_timing emm_timing; + struct octeontx_mmc_host *host = mmc_to_host(mmc); + ulong start; + u8 bus_id, bus_ena; + + debug("%s: Calibrating delay\n", __func__); + if (host->is_asim || host->is_emul) { + debug(" No calibration for ASIM\n"); + return 0; + } + emm_tap.u = 0; + if (host->calibrate_glitch) { + emm_tap.s.delay = MMC_DEFAULT_TAP_DELAY; + } else { + /* Save registers */ + emm_cfg.u = read_csr(mmc, MIO_EMM_CFG()); + emm_io_ctl.u = read_csr(mmc, MIO_EMM_IO_CTL()); + emm_switch.u = read_csr(mmc, MIO_EMM_SWITCH()); + emm_wdog.u = read_csr(mmc, MIO_EMM_WDOG()); + emm_sts_mask.u = read_csr(mmc, MIO_EMM_STS_MASK()); + emm_debug.u = read_csr(mmc, MIO_EMM_DEBUG()); + emm_timing.u = read_csr(mmc, MIO_EMM_TIMING()); + bus_ena = emm_cfg.s.bus_ena; + bus_id = emm_switch.s.bus_id; + emm_cfg.s.bus_ena = 0; + write_csr(mmc, MIO_EMM_CFG(), emm_cfg.u); + udelay(1); + emm_cfg.s.bus_ena = 1ULL << 3; + write_csr(mmc, MIO_EMM_CFG(), emm_cfg.u); + mdelay(1); + emm_calb.u = 0; + write_csr(mmc, MIO_EMM_CALB(), emm_calb.u); + emm_calb.s.start = 1; + write_csr(mmc, MIO_EMM_CALB(), emm_calb.u); + start = get_timer(0); + /* This should only take 3 microseconds */ + do { + udelay(5); + emm_tap.u = read_csr(mmc, MIO_EMM_TAP()); + } while (!emm_tap.s.delay && get_timer(start) < 10); + + emm_calb.s.start = 0; + write_csr(mmc, MIO_EMM_CALB(), emm_calb.u); + + emm_cfg.s.bus_ena = 0; + write_csr(mmc, MIO_EMM_CFG(), emm_cfg.u); + udelay(1); + /* Restore registers */ + emm_cfg.s.bus_ena = bus_ena; + write_csr(mmc, MIO_EMM_CFG(), emm_cfg.u); + if (host->tap_requires_noclk) { + /* Turn off the clock */ + emm_debug.u = read_csr(mmc, MIO_EMM_DEBUG()); + emm_debug.s.emmc_clk_disable = 1; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + udelay(1); + emm_debug.s.rdsync_rst = 1; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + udelay(1); + } + + write_csr(mmc, MIO_EMM_TIMING(), emm_timing.u); + if (host->tap_requires_noclk) { + /* Turn the clock back on */ + udelay(1); + emm_debug.s.rdsync_rst = 0; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + udelay(1); + emm_debug.s.emmc_clk_disable = 0; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + } + udelay(1); + write_csr(mmc, MIO_EMM_IO_CTL(), emm_io_ctl.u); + bus_id = emm_switch.s.bus_id; + emm_switch.s.bus_id = 0; + write_csr(mmc, MIO_EMM_SWITCH(), emm_switch.u); + emm_switch.s.bus_id = bus_id; + write_csr(mmc, MIO_EMM_SWITCH(), emm_switch.u); + write_csr(mmc, MIO_EMM_WDOG(), emm_wdog.u); + write_csr(mmc, MIO_EMM_STS_MASK(), emm_sts_mask.u); + write_csr(mmc, MIO_EMM_RCA(), mmc->rca); + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + + if (!emm_tap.s.delay) { + pr_err("%s: Error: delay calibration failed, timed out.\n", + __func__); + /* Set to default value if timed out */ + emm_tap.s.delay = MMC_DEFAULT_TAP_DELAY; + return -ETIMEDOUT; + } + } + /* Round up */ + host->timing_taps = (10 * 1000 * emm_tap.s.delay) / TOTAL_NO_OF_TAPS; + debug("%s(%s): timing taps: %llu, delay: %u\n", + __func__, mmc->dev->name, host->timing_taps, emm_tap.s.delay); + host->timing_calibrated = true; + return 0; +} + +static int octeontx_mmc_set_input_bus_timing(struct mmc *mmc) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { + union mio_emm_sample sample; + + sample.u = 0; + sample.s.cmd_cnt = slot->cmd_clk_skew; + sample.s.dat_cnt = slot->dat_clk_skew; + write_csr(mmc, MIO_EMM_SAMPLE(), sample.u); + } else { + union mio_emm_timing timing; + + timing.u = read_csr(mmc, MIO_EMM_TIMING()); + if (mmc->selected_mode == MMC_HS_200) { + if (slot->hs200_tuned) { + timing.s.cmd_in_tap = + slot->hs200_taps.s.cmd_in_tap; + timing.s.data_in_tap = + slot->hs200_taps.s.data_in_tap; + } else { + pr_warn("%s(%s): Warning: hs200 timing not tuned\n", + __func__, mmc->dev->name); + timing.s.cmd_in_tap = + MMC_DEFAULT_HS200_CMD_IN_TAP; + timing.s.data_in_tap = + MMC_DEFAULT_HS200_DATA_IN_TAP; + } + } else if (mmc->selected_mode == MMC_HS_400) { + if (slot->hs400_tuned) { + timing.s.cmd_in_tap = + slot->hs400_taps.s.cmd_in_tap; + timing.s.data_in_tap = + slot->hs400_taps.s.data_in_tap; + } else if (slot->hs200_tuned) { + timing.s.cmd_in_tap = + slot->hs200_taps.s.cmd_in_tap; + timing.s.data_in_tap = + slot->hs200_taps.s.data_in_tap; + } else { + pr_warn("%s(%s): Warning: hs400 timing not tuned\n", + __func__, mmc->dev->name); + timing.s.cmd_in_tap = + MMC_DEFAULT_HS200_CMD_IN_TAP; + timing.s.data_in_tap = + MMC_DEFAULT_HS200_DATA_IN_TAP; + } + } else if (slot->tuned) { + timing.s.cmd_in_tap = slot->taps.s.cmd_in_tap; + timing.s.data_in_tap = slot->taps.s.data_in_tap; + } else { + timing.s.cmd_in_tap = MMC_DEFAULT_CMD_IN_TAP; + timing.s.data_in_tap = MMC_DEFAULT_DATA_IN_TAP; + } + octeontx_mmc_set_emm_timing(mmc, timing); + } + + return 0; +} + +/** + * Sets the default bus timing for the current mode. + * + * @param mmc mmc data structure + * + * @return 0 for success, error otherwise + */ +static int octeontx_mmc_set_output_bus_timing(struct mmc *mmc) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + union mio_emm_timing timing; + int cout_bdelay, dout_bdelay; + unsigned int cout_delay, dout_delay; + char env_name[32]; + + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX)) + return 0; + + debug("%s(%s)\n", __func__, mmc->dev->name); + if (slot->is_asim || slot->is_emul) + return 0; + + octeontx_mmc_calibrate_delay(mmc); + + if (mmc->clock < 26000000) { + cout_delay = 5000; + dout_delay = 5000; + } else if (mmc->clock <= 52000000) { + cout_delay = 2500; + dout_delay = 2500; + } else if (!mmc_is_mode_ddr(mmc->selected_mode)) { + cout_delay = slot->cmd_out_hs200_delay; + dout_delay = slot->data_out_hs200_delay; + } else { + cout_delay = slot->cmd_out_hs400_delay; + dout_delay = slot->data_out_hs400_delay; + } + + snprintf(env_name, sizeof(env_name), "mmc%d_hs200_dout_delay_ps", + slot->bus_id); + dout_delay = env_get_ulong(env_name, 10, dout_delay); + debug("%s: dout_delay: %u\n", __func__, dout_delay); + + cout_bdelay = octeontx2_mmc_calc_delay(mmc, cout_delay); + dout_bdelay = octeontx2_mmc_calc_delay(mmc, dout_delay); + + debug("%s: cmd output delay: %u, data output delay: %u, cmd bdelay: %d, data bdelay: %d, clock: %d\n", + __func__, cout_delay, dout_delay, cout_bdelay, dout_bdelay, + mmc->clock); + if (cout_bdelay < 0 || dout_bdelay < 0) { + pr_err("%s: Error: could not calculate command and/or data clock skew\n", + __func__); + return -1; + } + timing.u = read_csr(mmc, MIO_EMM_TIMING()); + timing.s.cmd_out_tap = cout_bdelay; + timing.s.data_out_tap = dout_bdelay; + if (mmc->selected_mode == MMC_HS_200) { + slot->hs200_taps.s.cmd_out_tap = cout_bdelay; + slot->hs200_taps.s.data_out_tap = dout_bdelay; + } else if (mmc->selected_mode == MMC_HS_400) { + slot->hs400_taps.s.cmd_out_tap = cout_bdelay; + slot->hs400_taps.s.data_out_tap = dout_bdelay; + } else { + slot->taps.s.cmd_out_tap = cout_bdelay; + slot->taps.s.data_out_tap = dout_bdelay; + } + octeontx_mmc_set_emm_timing(mmc, timing); + debug("%s(%s): bdelay: %d/%d, clock: %d, ddr: %s, timing taps: %llu, do: %d, di: %d, co: %d, ci: %d\n", + __func__, mmc->dev->name, cout_bdelay, dout_bdelay, mmc->clock, + mmc->ddr_mode ? "yes" : "no", + mmc_to_host(mmc)->timing_taps, + timing.s.data_out_tap, + timing.s.data_in_tap, + timing.s.cmd_out_tap, + timing.s.cmd_in_tap); + + return 0; +} + +static void octeontx_mmc_set_clock(struct mmc *mmc) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + uint clock; + + clock = min(mmc->cfg->f_max, (uint)slot->clock); + clock = max(mmc->cfg->f_min, clock); + debug("%s(%s): f_min: %u, f_max: %u, clock: %u\n", __func__, + mmc->dev->name, mmc->cfg->f_min, mmc->cfg->f_max, clock); + slot->clock = clock; + mmc->clock = clock; +} + +/** + * This switches I/O power as needed when switching between slots. + * + * @param mmc mmc data structure + */ +static void octeontx_mmc_switch_io(struct mmc *mmc) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + struct octeontx_mmc_host *host = slot->host; + struct mmc *last_mmc = host->last_mmc; + static struct udevice *last_reg; + union mio_emm_cfg emm_cfg; + int bus; + static bool initialized; + + /* First time? */ + if (!initialized || mmc != host->last_mmc) { + struct mmc *ommc; + + /* Switch to bus 3 which is unused */ + emm_cfg.u = read_csr(mmc, MIO_EMM_CFG()); + emm_cfg.s.bus_ena = 1 << 3; + write_csr(mmc, MIO_EMM_CFG(), emm_cfg.u); + + /* Turn off all other I/O interfaces with first initialization + * if at least one supply was found. + */ + for (bus = 0; bus <= OCTEONTX_MAX_MMC_SLOT; bus++) { + ommc = &host->slots[bus].mmc; + + /* Handle self case later */ + if (ommc == mmc || !ommc->vqmmc_supply) + continue; + + /* Skip if we're not switching regulators */ + if (last_reg == mmc->vqmmc_supply) + continue; + + /* Turn off other regulators */ + if (ommc->vqmmc_supply != mmc->vqmmc_supply) + regulator_set_enable(ommc->vqmmc_supply, false); + } + /* Turn ourself on */ + if (mmc->vqmmc_supply && last_reg != mmc->vqmmc_supply) + regulator_set_enable(mmc->vqmmc_supply, true); + mdelay(1); /* Settle time */ + /* Switch to new bus */ + emm_cfg.s.bus_ena = 1 << slot->bus_id; + write_csr(mmc, MIO_EMM_CFG(), emm_cfg.u); + last_reg = mmc->vqmmc_supply; + initialized = true; + return; + } + + /* No change in device */ + if (last_mmc == mmc) + return; + + if (!last_mmc) { + pr_warn("%s(%s): No previous slot detected in IO slot switch!\n", + __func__, mmc->dev->name); + return; + } + + debug("%s(%s): last: %s, supply: %p\n", __func__, mmc->dev->name, + last_mmc->dev->name, mmc->vqmmc_supply); + + /* The supply is the same so we do nothing */ + if (last_mmc->vqmmc_supply == mmc->vqmmc_supply) + return; + + /* Turn off the old slot I/O supply */ + if (last_mmc->vqmmc_supply) { + debug("%s(%s): Turning off IO to %s, supply: %s\n", + __func__, mmc->dev->name, last_mmc->dev->name, + last_mmc->vqmmc_supply->name); + regulator_set_enable(last_mmc->vqmmc_supply, false); + } + /* Turn on the new slot I/O supply */ + if (mmc->vqmmc_supply) { + debug("%s(%s): Turning on IO to slot %d, supply: %s\n", + __func__, mmc->dev->name, slot->bus_id, + mmc->vqmmc_supply->name); + regulator_set_enable(mmc->vqmmc_supply, true); + } + /* Allow power to settle */ + mdelay(1); +} + +/** + * Called to switch between mmc devices + * + * @param mmc new mmc device + */ +static void octeontx_mmc_switch_to(struct mmc *mmc) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + struct octeontx_mmc_slot *old_slot; + struct octeontx_mmc_host *host = slot->host; + union mio_emm_switch emm_switch; + union mio_emm_sts_mask emm_sts_mask; + union mio_emm_rca emm_rca; + + if (slot->bus_id == host->last_slotid) + return; + + debug("%s(%s) switching from slot %d to slot %d\n", __func__, + mmc->dev->name, host->last_slotid, slot->bus_id); + octeontx_mmc_switch_io(mmc); + + if (host->last_slotid >= 0 && slot->valid) { + old_slot = &host->slots[host->last_slotid]; + old_slot->cached_switch.u = read_csr(mmc, MIO_EMM_SWITCH()); + old_slot->cached_rca.u = read_csr(mmc, MIO_EMM_RCA()); + } + if (mmc->rca) + write_csr(mmc, MIO_EMM_RCA(), mmc->rca); + emm_switch = slot->cached_switch; + do_switch(mmc, emm_switch); + emm_rca.u = 0; + emm_rca.s.card_rca = mmc->rca; + write_csr(mmc, MIO_EMM_RCA(), emm_rca.u); + mdelay(100); + + set_wdog(mmc, 100000); + if (octeontx_mmc_set_output_bus_timing(mmc) || + octeontx_mmc_set_input_bus_timing(mmc)) + pr_err("%s(%s): Error setting bus timing\n", __func__, + mmc->dev->name); + octeontx_mmc_io_drive_setup(mmc); + + emm_sts_mask.u = 0; + emm_sts_mask.s.sts_msk = 1 << 7 | 1 << 22 | 1 << 23 | 1 << 19; + write_csr(mmc, MIO_EMM_STS_MASK(), emm_sts_mask.u); + host->last_slotid = slot->bus_id; + host->last_mmc = mmc; + mdelay(10); +} + +/** + * Perform initial timing configuration + * + * @param mmc mmc device + * + * @return 0 for success + * + * NOTE: This will need to be updated when new silicon comes out + */ +static int octeontx_mmc_init_timing(struct mmc *mmc) +{ + union mio_emm_timing timing; + + if (mmc_to_slot(mmc)->is_asim || mmc_to_slot(mmc)->is_emul) + return 0; + + debug("%s(%s)\n", __func__, mmc->dev->name); + timing.u = 0; + timing.s.cmd_out_tap = MMC_DEFAULT_CMD_OUT_TAP; + timing.s.data_out_tap = MMC_DEFAULT_DATA_OUT_TAP; + timing.s.cmd_in_tap = MMC_DEFAULT_CMD_IN_TAP; + timing.s.data_in_tap = MMC_DEFAULT_DATA_IN_TAP; + octeontx_mmc_set_emm_timing(mmc, timing); + return 0; +} + +/** + * Perform low-level initialization + * + * @param mmc mmc device + * + * @return 0 for success, error otherwise + */ +static int octeontx_mmc_init_lowlevel(struct mmc *mmc) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + struct octeontx_mmc_host *host = slot->host; + union mio_emm_switch emm_switch; + u32 clk_period; + + debug("%s(%s): lowlevel init for slot %d\n", __func__, + mmc->dev->name, slot->bus_id); + host->emm_cfg.s.bus_ena &= ~(1 << slot->bus_id); + write_csr(mmc, MIO_EMM_CFG(), host->emm_cfg.u); + udelay(100); + host->emm_cfg.s.bus_ena |= 1 << slot->bus_id; + write_csr(mmc, MIO_EMM_CFG(), host->emm_cfg.u); + udelay(10); + slot->clock = mmc->cfg->f_min; + octeontx_mmc_set_clock(&slot->mmc); + + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX2)) { + if (host->cond_clock_glitch) { + union mio_emm_debug emm_debug; + + emm_debug.u = read_csr(mmc, MIO_EMM_DEBUG()); + emm_debug.s.clk_on = 1; + write_csr(mmc, MIO_EMM_DEBUG(), emm_debug.u); + } + octeontx_mmc_calibrate_delay(&slot->mmc); + } + + clk_period = octeontx_mmc_calc_clk_period(mmc); + emm_switch.u = 0; + emm_switch.s.power_class = 10; + emm_switch.s.clk_lo = clk_period / 2; + emm_switch.s.clk_hi = clk_period / 2; + + emm_switch.s.bus_id = slot->bus_id; + debug("%s: Performing switch\n", __func__); + do_switch(mmc, emm_switch); + slot->cached_switch.u = emm_switch.u; + + if (!IS_ENABLED(CONFIG_ARCH_OCTEONTX)) + octeontx_mmc_init_timing(mmc); + + set_wdog(mmc, 1000000); /* Set to 1 second */ + write_csr(mmc, MIO_EMM_STS_MASK(), 0xe4390080ull); + write_csr(mmc, MIO_EMM_RCA(), 1); + mdelay(10); + debug("%s: done\n", __func__); + return 0; +} + +/** + * Translates a voltage number to bits in MMC register + * + * @param voltage voltage in microvolts + * + * @return MMC register value for voltage + */ +static u32 xlate_voltage(u32 voltage) +{ + u32 volt = 0; + + /* Convert to millivolts */ + voltage /= 1000; + if (voltage >= 1650 && voltage <= 1950) + volt |= MMC_VDD_165_195; + if (voltage >= 2000 && voltage <= 2100) + volt |= MMC_VDD_20_21; + if (voltage >= 2100 && voltage <= 2200) + volt |= MMC_VDD_21_22; + if (voltage >= 2200 && voltage <= 2300) + volt |= MMC_VDD_22_23; + if (voltage >= 2300 && voltage <= 2400) + volt |= MMC_VDD_23_24; + if (voltage >= 2400 && voltage <= 2500) + volt |= MMC_VDD_24_25; + if (voltage >= 2500 && voltage <= 2600) + volt |= MMC_VDD_25_26; + if (voltage >= 2600 && voltage <= 2700) + volt |= MMC_VDD_26_27; + if (voltage >= 2700 && voltage <= 2800) + volt |= MMC_VDD_27_28; + if (voltage >= 2800 && voltage <= 2900) + volt |= MMC_VDD_28_29; + if (voltage >= 2900 && voltage <= 3000) + volt |= MMC_VDD_29_30; + if (voltage >= 3000 && voltage <= 3100) + volt |= MMC_VDD_30_31; + if (voltage >= 3100 && voltage <= 3200) + volt |= MMC_VDD_31_32; + if (voltage >= 3200 && voltage <= 3300) + volt |= MMC_VDD_32_33; + if (voltage >= 3300 && voltage <= 3400) + volt |= MMC_VDD_33_34; + if (voltage >= 3400 && voltage <= 3500) + volt |= MMC_VDD_34_35; + if (voltage >= 3500 && voltage <= 3600) + volt |= MMC_VDD_35_36; + + return volt; +} + +/** + * Check if a slot is valid in the device tree + * + * @param dev slot device to check + * + * @return true if status reports "ok" or "okay" or if no status, + * false otherwise. + */ +static bool octeontx_mmc_get_valid(struct udevice *dev) +{ + const char *stat = ofnode_read_string(dev->node, "status"); + + if (!stat || !strncmp(stat, "ok", 2)) + return true; + else + return false; +} + +/** + * Reads slot configuration from the device tree + * + * @param dev slot device + * + * @return 0 on success, otherwise error + */ +static int octeontx_mmc_get_config(struct udevice *dev) +{ + struct octeontx_mmc_slot *slot = dev_to_mmc_slot(dev); + uint voltages[2]; + uint low, high; + char env_name[32]; + int err; + ofnode node = dev->node; + int bus_width = 1; + ulong new_max_freq; + + debug("%s(%s)", __func__, dev->name); + slot->cfg.name = dev->name; + + slot->cfg.f_max = ofnode_read_s32_default(dev->node, "max-frequency", + 26000000); + snprintf(env_name, sizeof(env_name), "mmc_max_frequency%d", + slot->bus_id); + + new_max_freq = env_get_ulong(env_name, 10, slot->cfg.f_max); + debug("Reading %s, got %lu\n", env_name, new_max_freq); + + if (new_max_freq != slot->cfg.f_max) { + printf("Overriding device tree MMC maximum frequency %u to %lu\n", + slot->cfg.f_max, new_max_freq); + slot->cfg.f_max = new_max_freq; + } + slot->cfg.f_min = 400000; + slot->cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT; + + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX2)) { + slot->hs400_tuning_block = + ofnode_read_s32_default(dev->node, + "marvell,hs400-tuning-block", + -1); + debug("%s(%s): mmc HS400 tuning block: %d\n", __func__, + dev->name, slot->hs400_tuning_block); + + slot->hs200_tap_adj = + ofnode_read_s32_default(dev->node, + "marvell,hs200-tap-adjust", 0); + debug("%s(%s): hs200-tap-adjust: %d\n", __func__, dev->name, + slot->hs200_tap_adj); + slot->hs400_tap_adj = + ofnode_read_s32_default(dev->node, + "marvell,hs400-tap-adjust", 0); + debug("%s(%s): hs400-tap-adjust: %d\n", __func__, dev->name, + slot->hs400_tap_adj); + } + + err = ofnode_read_u32_array(dev->node, "voltage-ranges", voltages, 2); + if (err) { + slot->cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34; + } else { + low = xlate_voltage(voltages[0]); + high = xlate_voltage(voltages[1]); + debug(" low voltage: 0x%x (%u), high: 0x%x (%u)\n", + low, voltages[0], high, voltages[1]); + if (low > high || !low || !high) { + pr_err("Invalid MMC voltage range [%u-%u] specified for %s\n", + low, high, dev->name); + return -1; + } + slot->cfg.voltages = 0; + do { + slot->cfg.voltages |= low; + low <<= 1; + } while (low <= high); + } + debug("%s: config voltages: 0x%x\n", __func__, slot->cfg.voltages); + slot->slew = ofnode_read_s32_default(node, "cavium,clk-slew", -1); + slot->drive = ofnode_read_s32_default(node, "cavium,drv-strength", -1); + gpio_request_by_name(dev, "cd-gpios", 0, &slot->cd_gpio, GPIOD_IS_IN); + slot->cd_inverted = ofnode_read_bool(node, "cd-inverted"); + gpio_request_by_name(dev, "wp-gpios", 0, &slot->wp_gpio, GPIOD_IS_IN); + slot->wp_inverted = ofnode_read_bool(node, "wp-inverted"); + if (slot->cfg.voltages & MMC_VDD_165_195) { + slot->is_1_8v = true; + slot->is_3_3v = false; + } else if (slot->cfg.voltages & (MMC_VDD_30_31 | MMC_VDD_31_32 | + MMC_VDD_33_34 | MMC_VDD_34_35 | + MMC_VDD_35_36)) { + slot->is_1_8v = false; + slot->is_3_3v = true; + } + + bus_width = ofnode_read_u32_default(node, "bus-width", 1); + /* Note fall-through */ + switch (bus_width) { + case 8: + slot->cfg.host_caps |= MMC_MODE_8BIT; + case 4: + slot->cfg.host_caps |= MMC_MODE_4BIT; + case 1: + slot->cfg.host_caps |= MMC_MODE_1BIT; + break; + } + if (ofnode_read_bool(node, "no-1-8-v")) { + slot->is_3_3v = true; + slot->is_1_8v = false; + if (!(slot->cfg.voltages & (MMC_VDD_32_33 | MMC_VDD_33_34))) + pr_warn("%s(%s): voltages indicate 3.3v but 3.3v not supported\n", + __func__, dev->name); + } + if (ofnode_read_bool(node, "mmc-ddr-3-3v")) { + slot->is_3_3v = true; + slot->is_1_8v = false; + if (!(slot->cfg.voltages & (MMC_VDD_32_33 | MMC_VDD_33_34))) + pr_warn("%s(%s): voltages indicate 3.3v but 3.3v not supported\n", + __func__, dev->name); + } + if (ofnode_read_bool(node, "cap-sd-highspeed") || + ofnode_read_bool(node, "cap-mmc-highspeed") || + ofnode_read_bool(node, "sd-uhs-sdr25")) + slot->cfg.host_caps |= MMC_MODE_HS; + if (slot->cfg.f_max >= 50000000 && + slot->cfg.host_caps & MMC_MODE_HS) + slot->cfg.host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS; + if (ofnode_read_bool(node, "sd-uhs-sdr50")) + slot->cfg.host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS; + if (ofnode_read_bool(node, "sd-uhs-ddr50")) + slot->cfg.host_caps |= MMC_MODE_HS | MMC_MODE_HS_52MHz | + MMC_MODE_DDR_52MHz; + + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX2)) { + if (!slot->is_asim && !slot->is_emul) { + if (ofnode_read_bool(node, "mmc-hs200-1_8v")) + slot->cfg.host_caps |= MMC_MODE_HS200 | + MMC_MODE_HS_52MHz; + if (ofnode_read_bool(node, "mmc-hs400-1_8v")) + slot->cfg.host_caps |= MMC_MODE_HS400 | + MMC_MODE_HS_52MHz | + MMC_MODE_HS200 | + MMC_MODE_DDR_52MHz; + slot->cmd_out_hs200_delay = + ofnode_read_u32_default(node, + "marvell,cmd-out-hs200-dly", + MMC_DEFAULT_HS200_CMD_OUT_DLY); + debug("%s(%s): HS200 cmd out delay: %d\n", + __func__, dev->name, slot->cmd_out_hs200_delay); + slot->data_out_hs200_delay = + ofnode_read_u32_default(node, + "marvell,data-out-hs200-dly", + MMC_DEFAULT_HS200_DATA_OUT_DLY); + debug("%s(%s): HS200 data out delay: %d\n", + __func__, dev->name, slot->data_out_hs200_delay); + slot->cmd_out_hs400_delay = + ofnode_read_u32_default(node, + "marvell,cmd-out-hs400-dly", + MMC_DEFAULT_HS400_CMD_OUT_DLY); + debug("%s(%s): HS400 cmd out delay: %d\n", + __func__, dev->name, slot->cmd_out_hs400_delay); + slot->data_out_hs400_delay = + ofnode_read_u32_default(node, + "marvell,data-out-hs400-dly", + MMC_DEFAULT_HS400_DATA_OUT_DLY); + debug("%s(%s): HS400 data out delay: %d\n", + __func__, dev->name, slot->data_out_hs400_delay); + } + } + + slot->disable_ddr = ofnode_read_bool(node, "marvell,disable-ddr"); + slot->non_removable = ofnode_read_bool(node, "non-removable"); + slot->cmd_clk_skew = ofnode_read_u32_default(node, + "cavium,cmd-clk-skew", 0); + slot->dat_clk_skew = ofnode_read_u32_default(node, + "cavium,dat-clk-skew", 0); + debug("%s(%s): host caps: 0x%x\n", __func__, + dev->name, slot->cfg.host_caps); + return 0; +} + +/** + * Probes a MMC slot + * + * @param dev mmc device + * + * @return 0 for success, error otherwise + */ +static int octeontx_mmc_slot_probe(struct udevice *dev) +{ + struct octeontx_mmc_slot *slot; + struct mmc *mmc; + int err; + + printk("%s (%d)\n", __func__, __LINE__); // test-only + debug("%s(%s)\n", __func__, dev->name); + if (!host_probed) { + pr_err("%s(%s): Error: host not probed yet\n", + __func__, dev->name); + } + slot = dev_to_mmc_slot(dev); + mmc = &slot->mmc; + mmc->dev = dev; + + slot->valid = false; + if (!octeontx_mmc_get_valid(dev)) { + debug("%s(%s): slot is invalid\n", __func__, dev->name); + return -ENODEV; + } + + debug("%s(%s): Getting config\n", __func__, dev->name); + err = octeontx_mmc_get_config(dev); + if (err) { + pr_err("probe(%s): Error getting config\n", dev->name); + return err; + } + + debug("%s(%s): mmc bind, mmc: %p\n", __func__, dev->name, &slot->mmc); + err = mmc_bind(dev, &slot->mmc, &slot->cfg); + if (err) { + pr_err("%s(%s): Error binding mmc\n", __func__, dev->name); + return -1; + } + + /* For some reason, mmc_bind always assigns priv to the device */ + slot->mmc.priv = slot; + + debug("%s(%s): lowlevel init\n", __func__, dev->name); + err = octeontx_mmc_init_lowlevel(mmc); + if (err) { + pr_err("probe(%s): Low-level init failed\n", dev->name); + return err; + } + + slot->valid = true; + + debug("%s(%s):\n" + " base address : %p\n" + " bus id : %d\n", __func__, dev->name, + slot->base_addr, slot->bus_id); + + return err; +} + +/** + * MMC slot driver operations + */ +static const struct dm_mmc_ops octeontx_hsmmc_ops = { + .send_cmd = octeontx_mmc_dev_send_cmd, + .set_ios = octeontx_mmc_set_ios, + .get_cd = octeontx_mmc_get_cd, + .get_wp = octeontx_mmc_get_wp, +#ifdef MMC_SUPPORTS_TUNING + .execute_tuning = octeontx_mmc_execute_tuning, +#endif +}; + +static const struct udevice_id octeontx_hsmmc_ids[] = { + { .compatible = "mmc-slot" }, + { } +}; + +U_BOOT_DRIVER(octeontx_hsmmc_slot) = { + .name = "octeontx_hsmmc_slot", + .id = UCLASS_MMC, + .of_match = of_match_ptr(octeontx_hsmmc_ids), + .probe = octeontx_mmc_slot_probe, + .ops = &octeontx_hsmmc_ops, +}; + +/***************************************************************** + * PCI host driver + * + * The PCI host driver contains the resources used by all of the + * slot drivers. + * + * The slot drivers are pseudo drivers. + */ + +/** + * Probe the MMC host controller + * + * @param dev mmc host controller device + * + * @return 0 for success, -1 on error + */ +static int octeontx_mmc_host_probe(struct udevice *dev) +{ + pci_dev_t bdf = dm_pci_get_bdf(dev); + struct octeontx_mmc_host *host = dev_get_priv(dev); + union mio_emm_int emm_int; + u8 rev; + + debug("%s(%s): Entry host: %p\n", __func__, dev->name, host); + + if (!octeontx_mmc_get_valid(dev)) { + debug("%s(%s): mmc host not valid\n", __func__, dev->name); + return -ENODEV; + } + memset(host, 0, sizeof(*host)); + host->base_addr = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + if (!host->base_addr) { + pr_err("%s: Error: MMC base address not found\n", __func__); + return -1; + } + host->dev = dev; + debug("%s(%s): Base address: %p\n", __func__, dev->name, + host->base_addr); + if (!dev_has_of_node(dev)) { + pr_err("%s: No device tree information found\n", __func__); + return -1; + } + host->node = dev->node; + dev->req_seq = PCI_FUNC(bdf); + host->last_slotid = -1; + if (otx_is_platform(PLATFORM_ASIM)) + host->is_asim = true; + if (otx_is_platform(PLATFORM_EMULATOR)) + host->is_emul = true; + host->dma_wait_delay = + ofnode_read_u32_default(dev->node, "marvell,dma-wait-delay", 1); + /* Force reset of eMMC */ + writeq(0, host->base_addr + MIO_EMM_CFG()); + debug("%s: Clearing MIO_EMM_CFG\n", __func__); + udelay(100); + emm_int.u = readq(host->base_addr + MIO_EMM_INT()); + debug("%s: Writing 0x%llx to MIO_EMM_INT\n", __func__, emm_int.u); + writeq(emm_int.u, host->base_addr + MIO_EMM_INT()); + + debug("%s(%s): Getting I/O clock\n", __func__, dev->name); + host->sys_freq = octeontx_get_io_clock(); + debug("%s(%s): I/O clock %llu\n", __func__, dev->name, host->sys_freq); + + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX2)) { + /* Flags for issues to work around */ + dm_pci_read_config8(dev, PCI_REVISION_ID, &rev); + if (otx_is_soc(CN96XX)) { + debug("%s: CN96XX revision %d\n", __func__, rev); + switch (rev) { + case 0: + host->calibrate_glitch = true; + host->cond_clock_glitch = true; + break; + case 1: + break; + case 2: + break; + case 0x10: /* C0 */ + host->hs400_skew_needed = true; + debug("HS400 skew support enabled\n"); + fallthrough; + default: + debug("CN96XX rev C0+ detected\n"); + host->tap_requires_noclk = true; + break; + } + } else if (otx_is_soc(CN95XX)) { + if (!rev) + host->cond_clock_glitch = true; + } + } + + host_probed = true; + + return 0; +} + +/** + * This performs some initial setup before a probe occurs. + * + * @param dev: MMC slot device + * + * @return 0 for success, -1 on failure + * + * Do some pre-initialization before probing a slot. + */ +static int octeontx_mmc_host_child_pre_probe(struct udevice *dev) +{ + struct octeontx_mmc_host *host = dev_get_priv(dev_get_parent(dev)); + struct octeontx_mmc_slot *slot; + struct mmc_uclass_priv *upriv; + ofnode node = dev->node; + u32 bus_id; + char name[16]; + int err; + + debug("%s(%s) Pre-Probe\n", __func__, dev->name); + if (ofnode_read_u32(node, "reg", &bus_id)) { + pr_err("%s(%s): Error: "reg" not found in device tree\n", + __func__, dev->name); + return -1; + } + if (bus_id > OCTEONTX_MAX_MMC_SLOT) { + pr_err("%s(%s): Error: "reg" out of range of 0..%d\n", + __func__, dev->name, OCTEONTX_MAX_MMC_SLOT); + return -1; + } + + slot = &host->slots[bus_id]; + dev->priv = slot; + slot->host = host; + slot->bus_id = bus_id; + slot->dev = dev; + slot->base_addr = host->base_addr; + slot->is_asim = host->is_asim; + slot->is_emul = host->is_emul; + + snprintf(name, sizeof(name), "octeontx-mmc%d", bus_id); + err = device_set_name(dev, name); + + if (!dev->uclass_priv) { + debug("%s(%s): Allocating uclass priv\n", __func__, + dev->name); + upriv = calloc(1, sizeof(struct mmc_uclass_priv)); + if (!upriv) + return -ENOMEM; + dev->uclass_priv = upriv; + dev->uclass->priv = upriv; + } else { + upriv = dev->uclass_priv; + } + + upriv->mmc = &slot->mmc; + debug("%s: uclass priv: %p, mmc: %p\n", dev->name, upriv, upriv->mmc); + + debug("%s: ret: %d\n", __func__, err); + return err; +} + +static const struct udevice_id octeontx_hsmmc_host_ids[] = { + { .compatible = "cavium,thunder-8890-mmc" }, + { } +}; + +U_BOOT_DRIVER(octeontx_hsmmc_host) = { + .name = "octeontx_hsmmc_host", + .id = UCLASS_MISC, + .of_match = of_match_ptr(octeontx_hsmmc_host_ids), + .probe = octeontx_mmc_host_probe, + .priv_auto_alloc_size = sizeof(struct octeontx_mmc_host), + .child_pre_probe = octeontx_mmc_host_child_pre_probe, + .flags = DM_FLAG_PRE_RELOC, +}; + +static struct pci_device_id octeontx_mmc_supported[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_EMMC) }, + { }, +}; + +U_BOOT_PCI_DEVICE(octeontx_hsmmc_host, octeontx_mmc_supported); diff --git a/drivers/mmc/octeontx_hsmmc.h b/drivers/mmc/octeontx_hsmmc.h new file mode 100644 index 0000000000..70844b1cba --- /dev/null +++ b/drivers/mmc/octeontx_hsmmc.h @@ -0,0 +1,207 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2019 Marvell International Ltd. + * + * https://spdx.org/licenses + */ +#ifndef __OCTEONTX_HSMMC_H__ +#define __OCTEONTX_HSMMC_H__ +#include <asm/gpio.h> + +/** Name of our driver */ +#define OCTEONTX_MMC_DRIVER_NAME "octeontx-hsmmc" + +/** Maximum supported MMC slots */ +#define OCTEONTX_MAX_MMC_SLOT 3 + +#define POWER_ON_TIME 40 /** See SD 4.1 spec figure 6-5 */ + +/** + * Timeout used when waiting for commands to complete. We need to keep this + * above the hardware watchdog timeout which is usually limited to 1000ms + */ +#define WATCHDOG_COUNT (1100) /* in msecs */ + +/** + * Long timeout for commands which might take a while to complete. + */ +#define MMC_TIMEOUT_LONG 1000 + +/** + * Short timeout used for most commands in msecs + */ +#define MMC_TIMEOUT_SHORT 20 + +#define NSEC_PER_SEC 1000000000L + +#define MAX_NO_OF_TAPS 64 + +#define EXT_CSD_POWER_CLASS 187 /* R/W */ + +/* default HS400 tuning block number */ +#define DEFAULT_HS400_TUNING_BLOCK 1 + +struct octeontx_mmc_host; + +/** MMC/SD slot data structure */ +struct octeontx_mmc_slot { + struct mmc mmc; + struct mmc_config cfg; + struct octeontx_mmc_host *host; + struct udevice *dev; + void *base_addr; /** Same as host base_addr */ + u64 clock; + int bus_id; /** slot number */ + uint bus_width; + uint max_width; + int hs200_tap_adj; + int hs400_tap_adj; + int hs400_tuning_block; + struct gpio_desc cd_gpio; + struct gpio_desc wp_gpio; + struct gpio_desc power_gpio; + enum bus_mode mode; + union mio_emm_switch cached_switch; + union mio_emm_switch want_switch; + union mio_emm_rca cached_rca; + union mio_emm_timing taps; /* otx2: MIO_EMM_TIMING */ + union mio_emm_timing hs200_taps; + union mio_emm_timing hs400_taps; + /* These are used to see if our tuning is still valid or not */ + enum bus_mode last_mode; + u32 last_clock; + u32 block_len; + u32 block_count; + int cmd_clk_skew; + int dat_clk_skew; + uint cmd_cnt; /* otx: sample cmd in delay */ + uint dat_cnt; /* otx: sample data in delay */ + uint drive; /* Current drive */ + uint slew; /* clock skew */ + uint cmd_out_hs200_delay; + uint data_out_hs200_delay; + uint cmd_out_hs400_delay; + uint data_out_hs400_delay; + uint clk_period; + bool valid:1; + bool is_acmd:1; + bool tuned:1; + bool hs200_tuned:1; + bool hs400_tuned:1; + bool is_1_8v:1; + bool is_3_3v:1; + bool is_ddr:1; + bool is_asim:1; + bool is_emul:1; + bool cd_inverted:1; + bool wp_inverted:1; + bool disable_ddr:1; + bool non_removable:1; +}; + +struct octeontx_mmc_cr_mods { + u8 ctype_xor; + u8 rtype_xor; +}; + +struct octeontx_mmc_cr { + u8 c; + u8 r; +}; + +struct octeontx_sd_mods { + struct octeontx_mmc_cr mmc; + struct octeontx_mmc_cr sd; + struct octeontx_mmc_cr sdacmd; +}; + +/** Host controller data structure */ +struct octeontx_mmc_host { + struct udevice *dev; + void *base_addr; + struct octeontx_mmc_slot slots[OCTEONTX_MAX_MMC_SLOT + 1]; + pci_dev_t pdev; + u64 sys_freq; + union mio_emm_cfg emm_cfg; + u64 timing_taps; + struct mmc *last_mmc; /** Last mmc used */ + ofnode node; + int cur_slotid; + int last_slotid; + int max_width; + uint per_tap_delay; + uint num_slots; + uint dma_wait_delay; /* Delay before polling DMA in usecs */ + bool initialized:1; + bool timing_calibrated:1; + bool is_asim:1; + bool is_emul:1; + bool calibrate_glitch:1; + bool cond_clock_glitch:1; + bool tap_requires_noclk:1; + bool hs400_skew_needed:1; +}; + +/* + * NOTE: This was copied from the Linux kernel. + * + * MMC status in R1, for native mode (SPI bits are different) + * Type + * e:error bit + * s:status bit + * r:detected and set for the actual command response + * x:detected and set during command execution. the host must poll + * the card by sending status command in order to read these bits. + * Clear condition + * a:according to the card state + * b:always related to the previous command. Reception of + * a valid command will clear it (with a delay of one command) + * c:clear by read + */ +#define R1_OUT_OF_RANGE BIT(31) /* er, c */ +#define R1_ADDRESS_ERROR BIT(30) /* erx, c */ +#define R1_BLOCK_LEN_ERROR BIT(29) /* er, c */ +#define R1_ERASE_SEQ_ERROR BIT(28) /* er, c */ +#define R1_ERASE_PARAM BIT(27) /* ex, c */ +#define R1_WP_VIOLATION BIT(26) /* erx, c */ +#define R1_CARD_IS_LOCKED BIT(25) /* sx, a */ +#define R1_LOCK_UNLOCK_FAILED BIT(24) /* erx, c */ +#define R1_COM_CRC_ERROR BIT(23) /* er, b */ +/*#define R1_ILLEGAL_COMMAND BIT(22)*/ /* er, b */ +#define R1_CARD_ECC_FAILED BIT(21) /* ex, c */ +#define R1_CC_ERROR BIT(20) /* erx, c */ +#define R1_ERROR BIT(19) /* erx, c */ +#define R1_UNDERRUN BIT(18) /* ex, c */ +#define R1_OVERRUN BIT(17) /* ex, c */ +#define R1_CID_CSD_OVERWRITE BIT(16) /* erx, c, CID/CSD overwrite */ +#define R1_WP_ERASE_SKIP BIT(15) /* sx, c */ +#define R1_CARD_ECC_DISABLED BIT(14) /* sx, a */ +#define R1_ERASE_RESET BIT(13) /* sr, c */ +#define R1_STATUS(x) ((x) & 0xFFFFE000) +#define R1_CURRENT_STATE(x) (((x) & 0x00001E00) >> 9) /* sx, b (4 bits) */ +#define R1_READY_FOR_DATA BIT(8) /* sx, a */ +#define R1_SWITCH_ERROR BIT(7) /* sx, c */ + +#define R1_BLOCK_READ_MASK R1_OUT_OF_RANGE | \ + R1_ADDRESS_ERROR | \ + R1_BLOCK_LEN_ERROR | \ + R1_CARD_IS_LOCKED | \ + R1_COM_CRC_ERROR | \ + R1_ILLEGAL_COMMAND | \ + R1_CARD_ECC_FAILED | \ + R1_CC_ERROR | \ + R1_ERROR +#define R1_BLOCK_WRITE_MASK R1_OUT_OF_RANGE | \ + R1_ADDRESS_ERROR | \ + R1_BLOCK_LEN_ERROR | \ + R1_WP_VIOLATION | \ + R1_CARD_IS_LOCKED | \ + R1_COM_CRC_ERROR | \ + R1_ILLEGAL_COMMAND | \ + R1_CARD_ECC_FAILED | \ + R1_CC_ERROR | \ + R1_ERROR | \ + R1_UNDERRUN | \ + R1_OVERRUN + +#endif /* __OCTEONTX_HSMMC_H__ */
Adds support for NAND controllers found on OcteonTX or OcteonTX2 SoC platforms. Also includes driver to support Hardware ECC using BCH HW engine found on these platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Suneel Garapati sgarapati@marvell.com
Signed-off-by: Stefan Roese sr@denx.de ---
(no changes since v1)
Changes in v1: - Change patch subject
drivers/mtd/nand/raw/Kconfig | 16 + drivers/mtd/nand/raw/Makefile | 2 + drivers/mtd/nand/raw/octeontx_bch.c | 425 ++++ drivers/mtd/nand/raw/octeontx_bch.h | 133 ++ drivers/mtd/nand/raw/octeontx_bch_regs.h | 169 ++ drivers/mtd/nand/raw/octeontx_nand.c | 2263 ++++++++++++++++++++++ 6 files changed, 3008 insertions(+) create mode 100644 drivers/mtd/nand/raw/octeontx_bch.c create mode 100644 drivers/mtd/nand/raw/octeontx_bch.h create mode 100644 drivers/mtd/nand/raw/octeontx_bch_regs.h create mode 100644 drivers/mtd/nand/raw/octeontx_nand.c
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 06b2ff972c..5d86fe470d 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -291,6 +291,22 @@ config NAND_ZYNQ_USE_BOOTLOADER1_TIMINGS This flag prevent U-boot reconfigure NAND flash controller and reuse the NAND timing from 1st stage bootloader.
+config NAND_OCTEONTX + bool "Support for OcteonTX NAND controller" + select SYS_NAND_SELF_INIT + imply CMD_NAND + help + This enables Nand flash controller hardware found on the OcteonTX + processors. + +config NAND_OCTEONTX_HW_ECC + bool "Support Hardware ECC for OcteonTX NAND controller" + depends on NAND_OCTEONTX + default y + help + This enables Hardware BCH engine found on the OcteonTX processors to + support ECC for NAND flash controller. + config NAND_STM32_FMC2 bool "Support for NAND controller on STM32MP SoCs" depends on ARCH_STM32MP diff --git a/drivers/mtd/nand/raw/Makefile b/drivers/mtd/nand/raw/Makefile index 9337f6482e..24c51b6924 100644 --- a/drivers/mtd/nand/raw/Makefile +++ b/drivers/mtd/nand/raw/Makefile @@ -58,6 +58,8 @@ obj-$(CONFIG_NAND_VF610_NFC) += vf610_nfc.o obj-$(CONFIG_NAND_MXC) += mxc_nand.o obj-$(CONFIG_NAND_MXS) += mxs_nand.o obj-$(CONFIG_NAND_MXS_DT) += mxs_nand_dt.o +obj-$(CONFIG_NAND_OCTEONTX) += octeontx_nand.o +obj-$(CONFIG_NAND_OCTEONTX_HW_ECC) += octeontx_bch.o obj-$(CONFIG_NAND_PXA3XX) += pxa3xx_nand.o obj-$(CONFIG_NAND_SPEAR) += spr_nand.o obj-$(CONFIG_TEGRA_NAND) += tegra_nand.o diff --git a/drivers/mtd/nand/raw/octeontx_bch.c b/drivers/mtd/nand/raw/octeontx_bch.c new file mode 100644 index 0000000000..c38cbb9526 --- /dev/null +++ b/drivers/mtd/nand/raw/octeontx_bch.c @@ -0,0 +1,425 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <common.h> +#include <malloc.h> +#include <memalign.h> +#include <pci.h> +#include <pci_ids.h> +#include <nand.h> +#include <dm.h> +#include <dm/of_access.h> +#include <linux/bitfield.h> +#include <linux/ctype.h> +#include <linux/errno.h> +#include <linux/err.h> +#include <linux/ioport.h> +#include <linux/libfdt.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/nand_bch.h> +#include <linux/mtd/nand_ecc.h> +#include <asm/io.h> +#include <asm/types.h> +#include <asm/dma-mapping.h> +#include <asm/arch/clock.h> +#include "octeontx_bch.h" + +#ifdef DEBUG +# undef CONFIG_LOGLEVEL +# define CONFIG_LOGLEVEL 8 +#endif + +LIST_HEAD(octeontx_bch_devices); +static unsigned int num_vfs = BCH_NR_VF; +static void *bch_pf; +static void *bch_vf; +static void *token; +static bool bch_pf_initialized; +static bool bch_vf_initialized; + +static int pci_enable_sriov(struct udevice *dev, int nr_virtfn) +{ + int ret; + + ret = pci_sriov_init(dev, nr_virtfn); + if (ret) + printf("%s(%s): pci_sriov_init returned %d\n", __func__, + dev->name, ret); + return ret; +} + +void *octeontx_bch_getv(void) +{ + if (!bch_vf) + return NULL; + if (bch_vf_initialized && bch_pf_initialized) + return bch_vf; + else + return NULL; +} + +void octeontx_bch_putv(void *token) +{ + bch_vf_initialized = !!token; + bch_vf = token; +} + +void *octeontx_bch_getp(void) +{ + return token; +} + +void octeontx_bch_putp(void *token) +{ + bch_pf = token; + bch_pf_initialized = !!token; +} + +static int do_bch_init(struct bch_device *bch) +{ + return 0; +} + +static void bch_reset(struct bch_device *bch) +{ + writeq(1, bch->reg_base + BCH_CTL); + mdelay(2); +} + +static void bch_disable(struct bch_device *bch) +{ + writeq(~0ull, bch->reg_base + BCH_ERR_INT_ENA_W1C); + writeq(~0ull, bch->reg_base + BCH_ERR_INT); + bch_reset(bch); +} + +static u32 bch_check_bist_status(struct bch_device *bch) +{ + return readq(bch->reg_base + BCH_BIST_RESULT); +} + +static int bch_device_init(struct bch_device *bch) +{ + u64 bist; + int rc; + + debug("%s: Resetting...\n", __func__); + /* Reset the PF when probed first */ + bch_reset(bch); + + debug("%s: Checking BIST...\n", __func__); + /* Check BIST status */ + bist = (u64)bch_check_bist_status(bch); + if (bist) { + dev_err(dev, "BCH BIST failed with code 0x%llx\n", bist); + return -ENODEV; + } + + /* Get max VQs/VFs supported by the device */ + + bch->max_vfs = pci_sriov_get_totalvfs(bch->dev); + debug("%s: %d vfs\n", __func__, bch->max_vfs); + if (num_vfs > bch->max_vfs) { + dev_warn(dev, "Num of VFs to enable %d is greater than max available. Enabling %d VFs.\n", + num_vfs, bch->max_vfs); + num_vfs = bch->max_vfs; + } + bch->vfs_enabled = bch->max_vfs; + /* Get number of VQs/VFs to be enabled */ + /* TODO: Get CLK frequency */ + /* Reset device parameters */ + + debug("%s: Doing initialization\n", __func__); + rc = do_bch_init(bch); + + return rc; +} + +static int bch_sriov_configure(struct udevice *dev, int numvfs) +{ + struct bch_device *bch = dev_get_priv(dev); + int ret = -EBUSY; + + debug("%s(%s, %d), bch: %p, vfs_in_use: %d, enabled: %d\n", __func__, + dev->name, numvfs, bch, bch->vfs_in_use, bch->vfs_enabled); + if (bch->vfs_in_use) + goto exit; + + ret = 0; + + if (numvfs > 0) { + debug("%s: Enabling sriov\n", __func__); + ret = pci_enable_sriov(dev, numvfs); + if (ret == 0) { + bch->flags |= BCH_FLAG_SRIOV_ENABLED; + ret = numvfs; + bch->vfs_enabled = numvfs; + } + } + + debug("VFs enabled: %d\n", ret); +exit: + debug("%s: Returning %d\n", __func__, ret); + return ret; +} + +static int octeontx_pci_bchpf_probe(struct udevice *dev) +{ + struct bch_device *bch; + int ret; + + debug("%s(%s)\n", __func__, dev->name); + bch = dev_get_priv(dev); + if (!bch) + return -ENOMEM; + + bch->reg_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM); + bch->dev = dev; + + debug("%s: base address: %p\n", __func__, bch->reg_base); + ret = bch_device_init(bch); + if (ret) { + printf("%s(%s): init returned %d\n", __func__, dev->name, ret); + return ret; + } + INIT_LIST_HEAD(&bch->list); + list_add(&bch->list, &octeontx_bch_devices); + token = (void *)dev; + + debug("%s: Configuring SRIOV\n", __func__); + bch_sriov_configure(dev, num_vfs); + debug("%s: Done.\n", __func__); + octeontx_bch_putp(bch); + + return 0; +} + +static const struct pci_device_id octeontx_bchpf_pci_id_table[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_BCH) }, + {}, +}; + +static const struct pci_device_id octeontx_bchvf_pci_id_table[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_BCHVF)}, + {}, +}; + +/** + * Given a data block calculate the ecc data and fill in the response + * + * @param[in] block 8-byte aligned pointer to data block to calculate ECC + * @param block_size Size of block in bytes, must be a multiple of two. + * @param bch_level Number of errors that must be corrected. The number of + * parity bytes is equal to ((15 * bch_level) + 7) / 8. + * Must be 4, 8, 16, 24, 32, 40, 48, 56, 60 or 64. + * @param[out] ecc 8-byte aligned pointer to where ecc data should go + * @param[in] resp pointer to where responses will be written. + * + * @return Zero on success, negative on failure. + */ +int octeontx_bch_encode(struct bch_vf *vf, dma_addr_t block, u16 block_size, + u8 bch_level, dma_addr_t ecc, dma_addr_t resp) +{ + union bch_cmd cmd; + int rc; + + memset(&cmd, 0, sizeof(cmd)); + cmd.s.cword.ecc_gen = eg_gen; + cmd.s.cword.ecc_level = bch_level; + cmd.s.cword.size = block_size; + + cmd.s.oword.ptr = ecc; + cmd.s.iword.ptr = block; + cmd.s.rword.ptr = resp; + rc = octeontx_cmd_queue_write(QID_BCH, 1, + sizeof(cmd) / sizeof(uint64_t), cmd.u); + if (rc) + return -1; + + octeontx_bch_write_doorbell(1, vf); + + return 0; +} + +/** + * Given a data block and ecc data correct the data block + * + * @param[in] block_ecc_in 8-byte aligned pointer to data block with ECC + * data concatenated to the end to correct + * @param block_size Size of block in bytes, must be a multiple of + * two. + * @param bch_level Number of errors that must be corrected. The + * number of parity bytes is equal to + * ((15 * bch_level) + 7) / 8. + * Must be 4, 8, 16, 24, 32, 40, 48, 56, 60 or 64. + * @param[out] block_out 8-byte aligned pointer to corrected data buffer. + * This should not be the same as block_ecc_in. + * @param[in] resp pointer to where responses will be written. + * + * @return Zero on success, negative on failure. + */ + +int octeontx_bch_decode(struct bch_vf *vf, dma_addr_t block_ecc_in, + u16 block_size, u8 bch_level, + dma_addr_t block_out, dma_addr_t resp) +{ + union bch_cmd cmd; + int rc; + + memset(&cmd, 0, sizeof(cmd)); + cmd.s.cword.ecc_gen = eg_correct; + cmd.s.cword.ecc_level = bch_level; + cmd.s.cword.size = block_size; + + cmd.s.oword.ptr = block_out; + cmd.s.iword.ptr = block_ecc_in; + cmd.s.rword.ptr = resp; + rc = octeontx_cmd_queue_write(QID_BCH, 1, + sizeof(cmd) / sizeof(uint64_t), cmd.u); + if (rc) + return -1; + + octeontx_bch_write_doorbell(1, vf); + return 0; +} +EXPORT_SYMBOL(octeontx_bch_decode); + +int octeontx_bch_wait(struct bch_vf *vf, union bch_resp *resp, + dma_addr_t handle) +{ + ulong start = get_timer(0); + + __iormb(); /* HW is updating *resp */ + while (!resp->s.done && get_timer(start) < 10) + __iormb(); /* HW is updating *resp */ + + if (resp->s.done) + return 0; + + return -ETIMEDOUT; +} + +struct bch_q octeontx_bch_q[QID_MAX]; + +static int octeontx_cmd_queue_initialize(struct udevice *dev, int queue_id, + int max_depth, int fpa_pool, + int pool_size) +{ + /* some params are for later merge with CPT or cn83xx */ + struct bch_q *q = &octeontx_bch_q[queue_id]; + unsigned long paddr; + union bch_cmd *qb; + int chunk = max_depth + 1; + int i, size; + + if ((unsigned int)queue_id >= QID_MAX) + return -EINVAL; + if (max_depth & chunk) /* must be 2^N - 1 */ + return -EINVAL; + + size = NQS * chunk * sizeof(u64); + qb = dma_alloc_coherent(size, &paddr); + if (!qb) + return -ENOMEM; + q->base_paddr = paddr; + q->dev = dev; + q->index = 0; + q->max_depth = max_depth; + q->pool_size_m1 = pool_size; + q->base_vaddr = (u64 *)qb; + + for (i = 0; i < NQS; i++) { + u64 *ixp; + int inext = (i + 1) * chunk - 1; + int j = (i + 1) % NQS; + int jnext = j * chunk; + dma_addr_t jbase = q->base_paddr + jnext * sizeof(u64); + + ixp = &qb->u[inext]; + *ixp = jbase; + } + + return 0; +} + +static int octeontx_pci_bchvf_probe(struct udevice *dev) +{ + struct bch_vf *vf; + union bch_vqx_ctl ctl; + union bch_vqx_cmd_buf cbuf; + int err; + + debug("%s(%s)\n", __func__, dev->name); + vf = dev_get_priv(dev); + if (!vf) + return -ENOMEM; + + vf->dev = dev; + + /* Map PF's configuration registers */ + vf->reg_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM); + debug("%s: reg base: %p\n", __func__, vf->reg_base); + + err = octeontx_cmd_queue_initialize(dev, QID_BCH, QDEPTH - 1, 0, + sizeof(union bch_cmd) * QDEPTH); + if (err) { + dev_err(dev, "octeontx_cmd_queue_initialize() failed\n"); + goto release; + } + + ctl.u = readq(vf->reg_base + BCH_VQX_CTL(0)); + + cbuf.u = 0; + cbuf.s.ldwb = 1; + cbuf.s.dfb = 1; + cbuf.s.size = QDEPTH; + writeq(cbuf.u, vf->reg_base + BCH_VQX_CMD_BUF(0)); + + writeq(ctl.u, vf->reg_base + BCH_VQX_CTL(0)); + + writeq(octeontx_bch_q[QID_BCH].base_paddr, + vf->reg_base + BCH_VQX_CMD_PTR(0)); + + octeontx_bch_putv(vf); + + debug("%s: bch vf initialization complete\n", __func__); + + if (octeontx_bch_getv()) + return octeontx_pci_nand_deferred_probe(); + + return -1; + +release: + return err; +} + +static int octeontx_pci_bchpf_remove(struct udevice *dev) +{ + struct bch_device *bch = dev_get_priv(dev); + + bch_disable(bch); + return 0; +} + +U_BOOT_DRIVER(octeontx_pci_bchpf) = { + .name = BCHPF_DRIVER_NAME, + .id = UCLASS_MISC, + .probe = octeontx_pci_bchpf_probe, + .remove = octeontx_pci_bchpf_remove, + .priv_auto_alloc_size = sizeof(struct bch_device), + .flags = DM_FLAG_OS_PREPARE, +}; + +U_BOOT_DRIVER(octeontx_pci_bchvf) = { + .name = BCHVF_DRIVER_NAME, + .id = UCLASS_MISC, + .probe = octeontx_pci_bchvf_probe, + .priv_auto_alloc_size = sizeof(struct bch_vf), +}; + +U_BOOT_PCI_DEVICE(octeontx_pci_bchpf, octeontx_bchpf_pci_id_table); +U_BOOT_PCI_DEVICE(octeontx_pci_bchvf, octeontx_bchvf_pci_id_table); diff --git a/drivers/mtd/nand/raw/octeontx_bch.h b/drivers/mtd/nand/raw/octeontx_bch.h new file mode 100644 index 0000000000..b34cc8363d --- /dev/null +++ b/drivers/mtd/nand/raw/octeontx_bch.h @@ -0,0 +1,133 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __OCTEONTX_BCH_H__ +#define __OCTEONTX_BCH_H__ + +#include "octeontx_bch_regs.h" + +/* flags to indicate the features supported */ +#define BCH_FLAG_SRIOV_ENABLED BIT(1) + +/* + * BCH Registers map for 81xx + */ + +/* PF registers */ +#define BCH_CTL 0x0ull +#define BCH_ERR_CFG 0x10ull +#define BCH_BIST_RESULT 0x80ull +#define BCH_ERR_INT 0x88ull +#define BCH_ERR_INT_W1S 0x90ull +#define BCH_ERR_INT_ENA_W1C 0xA0ull +#define BCH_ERR_INT_ENA_W1S 0xA8ull + +/* VF registers */ +#define BCH_VQX_CTL(z) 0x0ull +#define BCH_VQX_CMD_BUF(z) 0x8ull +#define BCH_VQX_CMD_PTR(z) 0x20ull +#define BCH_VQX_DOORBELL(z) 0x800ull + +#define BCHPF_DRIVER_NAME "octeontx-bchpf" +#define BCHVF_DRIVER_NAME "octeontx-bchvf" + +struct bch_device { + struct list_head list; + u8 max_vfs; + u8 vfs_enabled; + u8 vfs_in_use; + u32 flags; + void __iomem *reg_base; + struct udevice *dev; +}; + +struct bch_vf { + u16 flags; + u8 vfid; + u8 node; + u8 priority; + struct udevice *dev; + void __iomem *reg_base; +}; + +struct buf_ptr { + u8 *vptr; + dma_addr_t dma_addr; + u16 size; +}; + +void *octeontx_bch_getv(void); +void octeontx_bch_putv(void *token); +void *octeontx_bch_getp(void); +void octeontx_bch_putp(void *token); +int octeontx_bch_wait(struct bch_vf *vf, union bch_resp *resp, + dma_addr_t handle); +/** + * Given a data block calculate the ecc data and fill in the response + * + * @param[in] block 8-byte aligned pointer to data block to calculate ECC + * @param block_size Size of block in bytes, must be a multiple of two. + * @param bch_level Number of errors that must be corrected. The number of + * parity bytes is equal to ((15 * bch_level) + 7) / 8. + * Must be 4, 8, 16, 24, 32, 40, 48, 56, 60 or 64. + * @param[out] ecc 8-byte aligned pointer to where ecc data should go + * @param[in] resp pointer to where responses will be written. + * + * @return Zero on success, negative on failure. + */ +int octeontx_bch_encode(struct bch_vf *vf, dma_addr_t block, u16 block_size, + u8 bch_level, dma_addr_t ecc, dma_addr_t resp); + +/** + * Given a data block and ecc data correct the data block + * + * @param[in] block_ecc_in 8-byte aligned pointer to data block with ECC + * data concatenated to the end to correct + * @param block_size Size of block in bytes, must be a multiple of + * two. + * @param bch_level Number of errors that must be corrected. The + * number of parity bytes is equal to + * ((15 * bch_level) + 7) / 8. + * Must be 4, 8, 16, 24, 32, 40, 48, 56, 60 or 64. + * @param[out] block_out 8-byte aligned pointer to corrected data buffer. + * This should not be the same as block_ecc_in. + * @param[in] resp pointer to where responses will be written. + * + * @return Zero on success, negative on failure. + */ + +int octeontx_bch_decode(struct bch_vf *vf, dma_addr_t block_ecc_in, + u16 block_size, u8 bch_level, + dma_addr_t block_out, dma_addr_t resp); + +/** + * Ring the BCH doorbell telling it that new commands are + * available. + * + * @param num_commands Number of new commands + * @param vf virtual function handle + */ +static inline void octeontx_bch_write_doorbell(u64 num_commands, + struct bch_vf *vf) +{ + u64 num_words = num_commands * sizeof(union bch_cmd) / sizeof(uint64_t); + + writeq(num_words, vf->reg_base + BCH_VQX_DOORBELL(0)); +} + +/** + * Since it's possible (and even likely) that the NAND device will be probed + * before the BCH device has been probed, we may need to defer the probing. + * + * In this case, the initial probe returns success but the actual probing + * is deferred until the BCH VF has been probed. + * + * @return 0 for success, otherwise error + */ +int octeontx_pci_nand_deferred_probe(void); + +#endif /* __OCTEONTX_BCH_H__ */ diff --git a/drivers/mtd/nand/raw/octeontx_bch_regs.h b/drivers/mtd/nand/raw/octeontx_bch_regs.h new file mode 100644 index 0000000000..d8f8432690 --- /dev/null +++ b/drivers/mtd/nand/raw/octeontx_bch_regs.h @@ -0,0 +1,169 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __OCTEONTX_BCH_REGS_H__ +#define __OCTEONTX_BCH_REGS_H__ + +#define BCH_NR_VF 1 + +union bch_cmd { + u64 u[4]; + struct fields { + struct { + u64 size:12; + u64 reserved_12_31:20; + u64 ecc_level:4; + u64 reserved_36_61:26; + u64 ecc_gen:2; + } cword; + struct { + u64 ptr:49; + u64 reserved_49_55:7; + u64 nc:1; + u64 fw:1; + u64 reserved_58_63:6; + } oword; + struct { + u64 ptr:49; + u64 reserved_49_55:7; + u64 nc:1; + u64 reserved_57_63:7; + } iword; + struct { + u64 ptr:49; + u64 reserved_49_63:15; + } rword; + } s; +}; + +enum ecc_gen { + eg_correct, + eg_copy, + eg_gen, + eg_copy3, +}; + +/** Response from BCH instruction */ +union bch_resp { + u16 u16; + struct { + u16 num_errors:7; /** Number of errors in block */ + u16 zero:6; /** Always zero, ignore */ + u16 erased:1; /** Block is erased */ + u16 uncorrectable:1;/** too many bits flipped */ + u16 done:1; /** Block is done */ + } s; +}; + +union bch_vqx_ctl { + u64 u; + struct { + u64 reserved_0:1; + u64 cmd_be:1; + u64 max_read:4; + u64 reserved_6_15:10; + u64 erase_disable:1; + u64 one_cmd:1; + u64 early_term:4; + u64 reserved_22_63:42; + } s; +}; + +union bch_vqx_cmd_buf { + u64 u; + struct { + u64 reserved_0_32:33; + u64 size:13; + u64 dfb:1; + u64 ldwb:1; + u64 reserved_48_63:16; + } s; +}; + +/* keep queue state indexed, even though just one supported here, + * for later generalization to similarly-shaped queues on other Cavium devices + */ +enum { + QID_BCH, + QID_MAX +}; + +struct bch_q { + struct udevice *dev; + int index; + u16 max_depth; + u16 pool_size_m1; + u64 *base_vaddr; + dma_addr_t base_paddr; +}; + +extern struct bch_q octeontx_bch_q[QID_MAX]; + +/* with one dma-mapped area, virt<->phys conversions by +/- (vaddr-paddr) */ +static inline dma_addr_t qphys(int qid, void *v) +{ + struct bch_q *q = &octeontx_bch_q[qid]; + int off = (u8 *)v - (u8 *)q->base_vaddr; + + return q->base_paddr + off; +} + +#define octeontx_ptr_to_phys(v) qphys(QID_BCH, (v)) + +static inline void *qvirt(int qid, dma_addr_t p) +{ + struct bch_q *q = &octeontx_bch_q[qid]; + int off = p - q->base_paddr; + + return q->base_vaddr + off; +} + +#define octeontx_phys_to_ptr(p) qvirt(QID_BCH, (p)) + +/* plenty for interleaved r/w on two planes with 16k page, ecc_size 1k */ +/* QDEPTH >= 16, as successive chunks must align on 128-byte boundaries */ +#define QDEPTH 256 /* u64s in a command queue chunk, incl next-pointer */ +#define NQS 1 /* linked chunks in the chain */ + +/** + * Write an arbitrary number of command words to a command queue. + * This is a generic function; the fixed number of command word + * functions yield higher performance. + * + * Could merge with crypto version for FPA use on cn83xx + */ +static inline int octeontx_cmd_queue_write(int queue_id, bool use_locking, + int cmd_count, const u64 *cmds) +{ + int ret = 0; + u64 *cmd_ptr; + struct bch_q *qptr = &octeontx_bch_q[queue_id]; + + if (unlikely(cmd_count < 1 || cmd_count > 32)) + return -EINVAL; + if (unlikely(!cmds)) + return -EINVAL; + + cmd_ptr = qptr->base_vaddr; + + while (cmd_count > 0) { + int slot = qptr->index % (QDEPTH * NQS); + + if (slot % QDEPTH != QDEPTH - 1) { + cmd_ptr[slot] = *cmds++; + cmd_count--; + } + + qptr->index++; + } + + __iowmb(); /* flush commands before ringing bell */ + + return ret; +} + +#endif /* __OCTEONTX_BCH_REGS_H__ */ diff --git a/drivers/mtd/nand/raw/octeontx_nand.c b/drivers/mtd/nand/raw/octeontx_nand.c new file mode 100644 index 0000000000..847e9f9c58 --- /dev/null +++ b/drivers/mtd/nand/raw/octeontx_nand.c @@ -0,0 +1,2263 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <common.h> +#include <malloc.h> +#include <memalign.h> +#include <pci.h> +#include <nand.h> +#include <dm.h> +#include <dm/of_access.h> +#include <dm/devres.h> +#include <dm/device-internal.h> +#include <linux/bitfield.h> +#include <linux/ctype.h> +#include <linux/dma-mapping.h> +#include <linux/errno.h> +#include <linux/err.h> +#include <linux/ioport.h> +#include <linux/libfdt.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/nand_bch.h> +#include <linux/mtd/nand_ecc.h> +#include <asm/io.h> +#include <asm/types.h> +#include <asm/dma-mapping.h> +#include <asm/arch/clock.h> +#include "octeontx_bch.h" + +#ifdef DEBUG +# undef CONFIG_LOGLEVEL +# define CONFIG_LOGLEVEL 8 +#endif + +/* + * The NDF_CMD queue takes commands between 16 - 128 bit. + * All commands must be 16 bit aligned and are little endian. + * WAIT_STATUS commands must be 64 bit aligned. + * Commands are selected by the 4 bit opcode. + * + * Available Commands: + * + * 16 Bit: + * NOP + * WAIT + * BUS_ACQ, BUS_REL + * CHIP_EN, CHIP_DIS + * + * 32 Bit: + * CLE_CMD + * RD_CMD, RD_EDO_CMD + * WR_CMD + * + * 64 Bit: + * SET_TM_PAR + * + * 96 Bit: + * ALE_CMD + * + * 128 Bit: + * WAIT_STATUS, WAIT_STATUS_ALE + */ + +/* NDF Register offsets */ +#define NDF_CMD 0x0 +#define NDF_MISC 0x8 +#define NDF_ECC_CNT 0x10 +#define NDF_DRBELL 0x30 +#define NDF_ST_REG 0x38 /* status */ +#define NDF_INT 0x40 +#define NDF_INT_W1S 0x48 +#define NDF_DMA_CFG 0x50 +#define NDF_DMA_ADR 0x58 +#define NDF_INT_ENA_W1C 0x60 +#define NDF_INT_ENA_W1S 0x68 + +/* NDF command opcodes */ +#define NDF_OP_NOP 0x0 +#define NDF_OP_SET_TM_PAR 0x1 +#define NDF_OP_WAIT 0x2 +#define NDF_OP_CHIP_EN_DIS 0x3 +#define NDF_OP_CLE_CMD 0x4 +#define NDF_OP_ALE_CMD 0x5 +#define NDF_OP_WR_CMD 0x8 +#define NDF_OP_RD_CMD 0x9 +#define NDF_OP_RD_EDO_CMD 0xa +#define NDF_OP_WAIT_STATUS 0xb /* same opcode for WAIT_STATUS_ALE */ +#define NDF_OP_BUS_ACQ_REL 0xf + +#define NDF_BUS_ACQUIRE 1 +#define NDF_BUS_RELEASE 0 + +#define DBGX_EDSCR(X) (0x87A008000088 + (X) * 0x80000) + +struct ndf_nop_cmd { + u16 opcode: 4; + u16 nop: 12; +}; + +struct ndf_wait_cmd { + u16 opcode:4; + u16 r_b:1; /* wait for one cycle or PBUS_WAIT deassert */ + u16:3; + u16 wlen:3; /* timing parameter select */ + u16:5; +}; + +struct ndf_bus_cmd { + u16 opcode:4; + u16 direction:4; /* 1 = acquire, 0 = release */ + u16:8; +}; + +struct ndf_chip_cmd { + u16 opcode:4; + u16 chip:3; /* select chip, 0 = disable */ + u16 enable:1; /* 1 = enable, 0 = disable */ + u16 bus_width:2; /* 10 = 16 bit, 01 = 8 bit */ + u16:6; +}; + +struct ndf_cle_cmd { + u32 opcode:4; + u32:4; + u32 cmd_data:8; /* command sent to the PBUS AD pins */ + u32 clen1:3; /* time between PBUS CLE and WE asserts */ + u32 clen2:3; /* time WE remains asserted */ + u32 clen3:3; /* time between WE deassert and CLE */ + u32:7; +}; + +/* RD_EDO_CMD uses the same layout as RD_CMD */ +struct ndf_rd_cmd { + u32 opcode:4; + u32 data:16; /* data bytes */ + u32 rlen1:3; + u32 rlen2:3; + u32 rlen3:3; + u32 rlen4:3; +}; + +struct ndf_wr_cmd { + u32 opcode:4; + u32 data:16; /* data bytes */ + u32:4; + u32 wlen1:3; + u32 wlen2:3; + u32:3; +}; + +struct ndf_set_tm_par_cmd { + u64 opcode:4; + u64 tim_mult:4; /* multiplier for the seven parameters */ + u64 tm_par1:8; /* --> Following are the 7 timing parameters that */ + u64 tm_par2:8; /* specify the number of coprocessor cycles. */ + u64 tm_par3:8; /* A value of zero means one cycle. */ + u64 tm_par4:8; /* All values are scaled by tim_mult */ + u64 tm_par5:8; /* using tim_par * (2 ^ tim_mult). */ + u64 tm_par6:8; + u64 tm_par7:8; +}; + +struct ndf_ale_cmd { + u32 opcode:4; + u32:4; + u32 adr_byte_num:4; /* number of address bytes to be sent */ + u32:4; + u32 alen1:3; + u32 alen2:3; + u32 alen3:3; + u32 alen4:3; + u32:4; + u8 adr_byt1; + u8 adr_byt2; + u8 adr_byt3; + u8 adr_byt4; + u8 adr_byt5; + u8 adr_byt6; + u8 adr_byt7; + u8 adr_byt8; +}; + +struct ndf_wait_status_cmd { + u32 opcode:4; + u32:4; + u32 data:8; /** data */ + u32 clen1:3; + u32 clen2:3; + u32 clen3:3; + u32:8; + /** set to 5 to select WAIT_STATUS_ALE command */ + u32 ale_ind:8; + /** ALE only: number of address bytes to be sent */ + u32 adr_byte_num:4; + u32:4; + u32 alen1:3; /* ALE only */ + u32 alen2:3; /* ALE only */ + u32 alen3:3; /* ALE only */ + u32 alen4:3; /* ALE only */ + u32:4; + u8 adr_byt[4]; /* ALE only */ + u32 nine:4; /* set to 9 */ + u32 and_mask:8; + u32 comp_byte:8; + u32 rlen1:3; + u32 rlen2:3; + u32 rlen3:3; + u32 rlen4:3; +}; + +union ndf_cmd { + u64 val[2]; + union { + struct ndf_nop_cmd nop; + struct ndf_wait_cmd wait; + struct ndf_bus_cmd bus_acq_rel; + struct ndf_chip_cmd chip_en_dis; + struct ndf_cle_cmd cle_cmd; + struct ndf_rd_cmd rd_cmd; + struct ndf_wr_cmd wr_cmd; + struct ndf_set_tm_par_cmd set_tm_par; + struct ndf_ale_cmd ale_cmd; + struct ndf_wait_status_cmd wait_status; + } u; +}; + +/** Disable multi-bit error hangs */ +#define NDF_MISC_MB_DIS BIT_ULL(27) +/** High watermark for NBR FIFO or load/store operations */ +#define NDF_MISC_NBR_HWM GENMASK_ULL(26, 24) +/** Wait input filter count */ +#define NDF_MISC_WAIT_CNT GENMASK_ULL(23, 18) +/** Unfilled NFD_CMD queue bytes */ +#define NDF_MISC_FR_BYTE GENMASK_ULL(17, 7) +/** Set by HW when it reads the last 8 bytes of NDF_CMD */ +#define NDF_MISC_RD_DONE BIT_ULL(6) +/** Set by HW when it reads. SW read of NDF_CMD clears it */ +#define NDF_MISC_RD_VAL BIT_ULL(5) +/** Let HW read NDF_CMD queue. Cleared on SW NDF_CMD write */ +#define NDF_MISC_RD_CMD BIT_ULL(4) +/** Boot disable */ +#define NDF_MISC_BT_DIS BIT_ULL(2) +/** Stop command execution after completing command queue */ +#define NDF_MISC_EX_DIS BIT_ULL(1) +/** Reset fifo */ +#define NDF_MISC_RST_FF BIT_ULL(0) + +/** DMA engine enable */ +#define NDF_DMA_CFG_EN BIT_ULL(63) +/** Read or write */ +#define NDF_DMA_CFG_RW BIT_ULL(62) +/** Terminates DMA and clears enable bit */ +#define NDF_DMA_CFG_CLR BIT_ULL(61) +/** 32-bit swap enable */ +#define NDF_DMA_CFG_SWAP32 BIT_ULL(59) +/** 16-bit swap enable */ +#define NDF_DMA_CFG_SWAP16 BIT_ULL(58) +/** 8-bit swap enable */ +#define NDF_DMA_CFG_SWAP8 BIT_ULL(57) +/** Endian mode */ +#define NDF_DMA_CFG_CMD_BE BIT_ULL(56) +/** Number of 64 bit transfers */ +#define NDF_DMA_CFG_SIZE GENMASK_ULL(55, 36) + +/** Command execution status idle */ +#define NDF_ST_REG_EXE_IDLE BIT_ULL(15) +/** Command execution SM states */ +#define NDF_ST_REG_EXE_SM GENMASK_ULL(14, 11) +/** DMA and load SM states */ +#define NDF_ST_REG_BT_SM GENMASK_ULL(10, 7) +/** Queue read-back SM bad state */ +#define NDF_ST_REG_RD_FF_BAD BIT_ULL(6) +/** Queue read-back SM states */ +#define NDF_ST_REG_RD_FF GENMASK_ULL(5, 4) +/** Main SM is in a bad state */ +#define NDF_ST_REG_MAIN_BAD BIT_ULL(3) +/** Main SM states */ +#define NDF_ST_REG_MAIN_SM GENMASK_ULL(2, 0) + +#define MAX_NAND_NAME_LEN 64 +#if (defined(NAND_MAX_PAGESIZE) && (NAND_MAX_PAGESIZE > 4096)) || \ + !defined(NAND_MAX_PAGESIZE) +# undef NAND_MAX_PAGESIZE +# define NAND_MAX_PAGESIZE 4096 +#endif +#if (defined(NAND_MAX_OOBSIZE) && (NAND_MAX_OOBSIZE > 256)) || \ + !defined(NAND_MAX_OOBSIZE) +# undef NAND_MAX_OOBSIZE +# define NAND_MAX_OOBSIZE 256 +#endif + +#define OCTEONTX_NAND_DRIVER_NAME "octeontx_nand" + +#define NDF_TIMEOUT 1000 /** Timeout in ms */ +#define USEC_PER_SEC 1000000 /** Linux compatibility */ +#ifndef NAND_MAX_CHIPS +# define NAND_MAX_CHIPS 8 /** Linux compatibility */ +#endif + +struct octeontx_nand_chip { + struct list_head node; + struct nand_chip nand; + struct ndf_set_tm_par_cmd timings; + int cs; + int selected_page; + int iface_mode; + int row_bytes; + int col_bytes; + bool oob_only; + bool iface_set; +}; + +struct octeontx_nand_buf { + u8 *dmabuf; + dma_addr_t dmaaddr; + int dmabuflen; + int data_len; + int data_index; +}; + +/** NAND flash controller (NDF) related information */ +struct octeontx_nfc { + struct nand_hw_control controller; + struct udevice *dev; + void __iomem *base; + struct list_head chips; + int selected_chip; /* Currently selected NAND chip number */ + + /* + * Status is separate from octeontx_nand_buf because + * it can be used in parallel and during init. + */ + u8 *stat; + dma_addr_t stat_addr; + bool use_status; + + struct octeontx_nand_buf buf; + union bch_resp *bch_resp; + dma_addr_t bch_rhandle; + + /* BCH of all-0xff, so erased pages read as error-free */ + unsigned char *eccmask; +}; + +/* settable timings - 0..7 select timing of alen1..4/clen1..3/etc */ +enum tm_idx { + t0, /* fixed at 4<<mult cycles */ + t1, t2, t3, t4, t5, t6, t7, /* settable per ONFI-timing mode */ +}; + +#ifdef CONFIG_NAND_OCTEONTX_HW_ECC +struct octeontx_probe_device { + struct list_head list; + struct udevice *dev; +}; + +static struct bch_vf *bch_vf; +/** Deferred devices due to BCH not being ready */ +LIST_HEAD(octeontx_pci_nand_deferred_devices); +#endif + +/** default parameters used for probing chips */ +#define MAX_ONFI_MODE 5 + +static int default_onfi_timing; +static int slew_ns = 2; /* default timing padding */ +static int def_ecc_size = 512; /* 1024 best for sw_bch, <= 4095 for hw_bch */ +static int default_width = 1; /* 8 bit */ +static int default_page_size = 2048; +static struct ndf_set_tm_par_cmd default_timing_parms; + +/** Port from Linux */ +#define readq_poll_timeout(addr, val, cond, delay_us, timeout_us) \ +({ \ + ulong __start = get_timer(0); \ + void *__addr = (addr); \ + const ulong __timeout_ms = timeout_us / 1000; \ + do { \ + (val) = readq(__addr); \ + if (cond) \ + break; \ + if (timeout_us && get_timer(__start) > __timeout_ms) { \ + (val) = readq(__addr); \ + break; \ + } \ + if (delay_us) \ + udelay(delay_us); \ + } while (1); \ + (cond) ? 0 : -ETIMEDOUT; \ +}) + +/** Ported from Linux 4.9.0 include/linux/of.h for compatibility */ +static inline int of_get_child_count(const ofnode node) +{ + return fdtdec_get_child_count(gd->fdt_blob, ofnode_to_offset(node)); +} + +/** + * Linux compatibility from Linux 4.9.0 drivers/mtd/nand/nand_base.c + */ +static int nand_ooblayout_ecc_lp(struct mtd_info *mtd, int section, + struct mtd_oob_region *oobregion) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_ecc_ctrl *ecc = &chip->ecc; + + if (section || !ecc->total) + return -ERANGE; + + oobregion->length = ecc->total; + oobregion->offset = mtd->oobsize - oobregion->length; + + return 0; +} + +/** + * Linux compatibility from Linux 4.9.0 drivers/mtd/nand/nand_base.c + */ +static int nand_ooblayout_free_lp(struct mtd_info *mtd, int section, + struct mtd_oob_region *oobregion) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_ecc_ctrl *ecc = &chip->ecc; + + if (section) + return -ERANGE; + + oobregion->length = mtd->oobsize - ecc->total - 2; + oobregion->offset = 2; + + return 0; +} + +static const struct mtd_ooblayout_ops nand_ooblayout_lp_ops = { + .ecc = nand_ooblayout_ecc_lp, + .rfree = nand_ooblayout_free_lp, +}; + +static inline struct octeontx_nand_chip *to_otx_nand(struct nand_chip *nand) +{ + return container_of(nand, struct octeontx_nand_chip, nand); +} + +static inline struct octeontx_nfc *to_otx_nfc(struct nand_hw_control *ctrl) +{ + return container_of(ctrl, struct octeontx_nfc, controller); +} + +#if defined(CONFIG_NAND_OCTEONTX_HW_ECC) +static int octeontx_nand_calc_ecc_layout(struct nand_chip *nand) +{ + struct nand_ecclayout *layout = nand->ecc.layout; + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + struct mtd_info *mtd = &nand->mtd; + int oobsize = mtd->oobsize; + int i; + bool layout_alloc = false; + + if (!layout) { + layout = devm_kzalloc(tn->dev, sizeof(*layout), GFP_KERNEL); + if (!layout) + return -ENOMEM; + nand->ecc.layout = layout; + layout_alloc = true; + } + layout->eccbytes = nand->ecc.steps * nand->ecc.bytes; + /* Reserve 2 bytes for bad block marker */ + if (layout->eccbytes + 2 > oobsize) { + pr_err("No suitable oob scheme available for oobsize %d eccbytes %u\n", + oobsize, layout->eccbytes); + goto fail; + } + /* put ecc bytes at oob tail */ + for (i = 0; i < layout->eccbytes; i++) + layout->eccpos[i] = oobsize - layout->eccbytes + i; + layout->oobfree[0].offset = 2; + layout->oobfree[0].length = oobsize - 2 - layout->eccbytes; + nand->ecc.layout = layout; + return 0; + +fail: + if (layout_alloc) + kfree(layout); + return -1; +} +#endif + +/* + * Read a single byte from the temporary buffer. Used after READID + * to get the NAND information and for STATUS. + */ +static u8 octeontx_nand_read_byte(struct mtd_info *mtd) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + + if (tn->use_status) { + tn->use_status = false; + return *tn->stat; + } + + if (tn->buf.data_index < tn->buf.data_len) + return tn->buf.dmabuf[tn->buf.data_index++]; + + dev_err(tn->dev, "No data to read, idx: 0x%x, len: 0x%x\n", + tn->buf.data_index, tn->buf.data_len); + + return 0xff; +} + +/* + * Read a number of pending bytes from the temporary buffer. Used + * to get page and OOB data. + */ +static void octeontx_nand_read_buf(struct mtd_info *mtd, u8 *buf, int len) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + + if (len > tn->buf.data_len - tn->buf.data_index) { + dev_err(tn->dev, "Not enough data for read of %d bytes\n", len); + return; + } + + memcpy(buf, tn->buf.dmabuf + tn->buf.data_index, len); + tn->buf.data_index += len; +} + +static void octeontx_nand_write_buf(struct mtd_info *mtd, + const u8 *buf, int len) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + + memcpy(tn->buf.dmabuf + tn->buf.data_len, buf, len); + tn->buf.data_len += len; +} + +/* Overwrite default function to avoid sync abort on chip = -1. */ +static void octeontx_nand_select_chip(struct mtd_info *mtd, int chip) +{ +} + +static inline int timing_to_cycle(u32 psec, unsigned long clock) +{ + unsigned int ns; + int ticks; + + ns = DIV_ROUND_UP(psec, 1000); + ns += slew_ns; + + /* no rounding needed since clock is multiple of 1MHz */ + clock /= 1000000; + ns *= clock; + + ticks = DIV_ROUND_UP(ns, 1000); + + /* actual delay is (tm_parX+1)<<tim_mult */ + if (ticks) + ticks--; + + return ticks; +} + +static void set_timings(struct octeontx_nand_chip *chip, + struct ndf_set_tm_par_cmd *tp, + const struct nand_sdr_timings *timings, + unsigned long sclk) +{ + /* scaled coprocessor-cycle values */ + u32 sWH, sCLS, sCLH, sRP, sWB, sWC; + + tp->tim_mult = 0; + sWH = timing_to_cycle(timings->tWH_min, sclk); + sCLS = timing_to_cycle(timings->tCLS_min, sclk); + sCLH = timing_to_cycle(timings->tCLH_min, sclk); + sRP = timing_to_cycle(timings->tRP_min, sclk); + sWB = timing_to_cycle(timings->tWB_max, sclk); + sWC = timing_to_cycle(timings->tWC_min, sclk); + + tp->tm_par1 = sWH; + tp->tm_par2 = sCLH; + tp->tm_par3 = sRP + 1; + tp->tm_par4 = sCLS - sWH; + tp->tm_par5 = sWC - sWH + 1; + tp->tm_par6 = sWB; + tp->tm_par7 = 0; + tp->tim_mult++; /* overcompensate for bad math */ + + /* TODO: comment parameter re-use */ + + pr_debug("%s: tim_par: mult: %d p1: %d p2: %d p3: %d\n", + __func__, tp->tim_mult, tp->tm_par1, tp->tm_par2, tp->tm_par3); + pr_debug(" p4: %d p5: %d p6: %d p7: %d\n", + tp->tm_par4, tp->tm_par5, tp->tm_par6, tp->tm_par7); +} + +static int set_default_timings(struct octeontx_nfc *tn, + const struct nand_sdr_timings *timings) +{ + unsigned long sclk = octeontx_get_io_clock(); + + set_timings(NULL, &default_timing_parms, timings, sclk); + return 0; +} + +static int octeontx_nfc_chip_set_timings(struct octeontx_nand_chip *chip, + const struct nand_sdr_timings *timings) +{ + /*struct octeontx_nfc *tn = to_otx_nfc(chip->nand.controller);*/ + unsigned long sclk = octeontx_get_io_clock(); + + set_timings(chip, &chip->timings, timings, sclk); + return 0; +} + +/* How many bytes are free in the NFD_CMD queue? */ +static int ndf_cmd_queue_free(struct octeontx_nfc *tn) +{ + u64 ndf_misc; + + ndf_misc = readq(tn->base + NDF_MISC); + return FIELD_GET(NDF_MISC_FR_BYTE, ndf_misc); +} + +/* Submit a command to the NAND command queue. */ +static int ndf_submit(struct octeontx_nfc *tn, union ndf_cmd *cmd) +{ + int opcode = cmd->val[0] & 0xf; + + switch (opcode) { + /* All these commands fit in one 64bit word */ + case NDF_OP_NOP: + case NDF_OP_SET_TM_PAR: + case NDF_OP_WAIT: + case NDF_OP_CHIP_EN_DIS: + case NDF_OP_CLE_CMD: + case NDF_OP_WR_CMD: + case NDF_OP_RD_CMD: + case NDF_OP_RD_EDO_CMD: + case NDF_OP_BUS_ACQ_REL: + if (ndf_cmd_queue_free(tn) < 8) + goto full; + writeq(cmd->val[0], tn->base + NDF_CMD); + break; + case NDF_OP_ALE_CMD: + /* ALE commands take either one or two 64bit words */ + if (cmd->u.ale_cmd.adr_byte_num < 5) { + if (ndf_cmd_queue_free(tn) < 8) + goto full; + writeq(cmd->val[0], tn->base + NDF_CMD); + } else { + if (ndf_cmd_queue_free(tn) < 16) + goto full; + writeq(cmd->val[0], tn->base + NDF_CMD); + writeq(cmd->val[1], tn->base + NDF_CMD); + } + break; + case NDF_OP_WAIT_STATUS: /* Wait status commands take two 64bit words */ + if (ndf_cmd_queue_free(tn) < 16) + goto full; + writeq(cmd->val[0], tn->base + NDF_CMD); + writeq(cmd->val[1], tn->base + NDF_CMD); + break; + default: + dev_err(tn->dev, "%s: unknown command: %u\n", __func__, opcode); + return -EINVAL; + } + return 0; + +full: + dev_err(tn->dev, "%s: no space left in command queue\n", __func__); + return -ENOMEM; +} + +/** + * Wait for the ready/busy signal. First wait for busy to be valid, + * then wait for busy to de-assert. + */ +static int ndf_build_wait_busy(struct octeontx_nfc *tn) +{ + union ndf_cmd cmd; + + memset(&cmd, 0, sizeof(cmd)); + cmd.u.wait.opcode = NDF_OP_WAIT; + cmd.u.wait.r_b = 1; + cmd.u.wait.wlen = t6; + + if (ndf_submit(tn, &cmd)) + return -ENOMEM; + return 0; +} + +static bool ndf_dma_done(struct octeontx_nfc *tn) +{ + u64 dma_cfg; + + /* Enable bit should be clear after a transfer */ + dma_cfg = readq(tn->base + NDF_DMA_CFG); + if (!(dma_cfg & NDF_DMA_CFG_EN)) + return true; + + return false; +} + +static int ndf_wait(struct octeontx_nfc *tn) +{ + ulong start = get_timer(0); + bool done; + + while (!(done = ndf_dma_done(tn)) && get_timer(start) < NDF_TIMEOUT) + ; + + if (!done) { + dev_err(tn->dev, "%s: timeout error\n", __func__); + return -ETIMEDOUT; + } + return 0; +} + +static int ndf_wait_idle(struct octeontx_nfc *tn) +{ + u64 val; + u64 dval = 0; + int rc; + int pause = 100; + u64 tot_us = USEC_PER_SEC / 10; + + rc = readq_poll_timeout(tn->base + NDF_ST_REG, + val, val & NDF_ST_REG_EXE_IDLE, pause, tot_us); + if (!rc) + rc = readq_poll_timeout(tn->base + NDF_DMA_CFG, + dval, !(dval & NDF_DMA_CFG_EN), + pause, tot_us); + + return rc; +} + +/** Issue set timing parameters */ +static int ndf_queue_cmd_timing(struct octeontx_nfc *tn, + struct ndf_set_tm_par_cmd *timings) +{ + union ndf_cmd cmd; + + memset(&cmd, 0, sizeof(cmd)); + cmd.u.set_tm_par.opcode = NDF_OP_SET_TM_PAR; + cmd.u.set_tm_par.tim_mult = timings->tim_mult; + cmd.u.set_tm_par.tm_par1 = timings->tm_par1; + cmd.u.set_tm_par.tm_par2 = timings->tm_par2; + cmd.u.set_tm_par.tm_par3 = timings->tm_par3; + cmd.u.set_tm_par.tm_par4 = timings->tm_par4; + cmd.u.set_tm_par.tm_par5 = timings->tm_par5; + cmd.u.set_tm_par.tm_par6 = timings->tm_par6; + cmd.u.set_tm_par.tm_par7 = timings->tm_par7; + return ndf_submit(tn, &cmd); +} + +/** Issue bus acquire or release */ +static int ndf_queue_cmd_bus(struct octeontx_nfc *tn, int direction) +{ + union ndf_cmd cmd; + + memset(&cmd, 0, sizeof(cmd)); + cmd.u.bus_acq_rel.opcode = NDF_OP_BUS_ACQ_REL; + cmd.u.bus_acq_rel.direction = direction; + return ndf_submit(tn, &cmd); +} + +/* Issue chip select or deselect */ +static int ndf_queue_cmd_chip(struct octeontx_nfc *tn, int enable, int chip, + int width) +{ + union ndf_cmd cmd; + + memset(&cmd, 0, sizeof(cmd)); + cmd.u.chip_en_dis.opcode = NDF_OP_CHIP_EN_DIS; + cmd.u.chip_en_dis.chip = chip; + cmd.u.chip_en_dis.enable = enable; + cmd.u.chip_en_dis.bus_width = width; + return ndf_submit(tn, &cmd); +} + +static int ndf_queue_cmd_wait(struct octeontx_nfc *tn, int t_delay) +{ + union ndf_cmd cmd; + + memset(&cmd, 0, sizeof(cmd)); + cmd.u.wait.opcode = NDF_OP_WAIT; + cmd.u.wait.wlen = t_delay; + return ndf_submit(tn, &cmd); +} + +static int ndf_queue_cmd_cle(struct octeontx_nfc *tn, int command) +{ + union ndf_cmd cmd; + + memset(&cmd, 0, sizeof(cmd)); + cmd.u.cle_cmd.opcode = NDF_OP_CLE_CMD; + cmd.u.cle_cmd.cmd_data = command; + cmd.u.cle_cmd.clen1 = t4; + cmd.u.cle_cmd.clen2 = t1; + cmd.u.cle_cmd.clen3 = t2; + return ndf_submit(tn, &cmd); +} + +static int ndf_queue_cmd_ale(struct octeontx_nfc *tn, int addr_bytes, + struct nand_chip *nand, u64 page, + u32 col, int page_size) +{ + struct octeontx_nand_chip *octeontx_nand = (nand) ? + to_otx_nand(nand) : NULL; + union ndf_cmd cmd; + + memset(&cmd, 0, sizeof(cmd)); + cmd.u.ale_cmd.opcode = NDF_OP_ALE_CMD; + cmd.u.ale_cmd.adr_byte_num = addr_bytes; + + /* set column bit for OOB area, assume OOB follows page */ + if (octeontx_nand && octeontx_nand->oob_only) + col += page_size; + + /* page is u64 for this generality, even if cmdfunc() passes int */ + switch (addr_bytes) { + /* 4-8 bytes: page, then 2-byte col */ + case 8: + cmd.u.ale_cmd.adr_byt8 = (page >> 40) & 0xff; + /* fall thru */ + case 7: + cmd.u.ale_cmd.adr_byt7 = (page >> 32) & 0xff; + /* fall thru */ + case 6: + cmd.u.ale_cmd.adr_byt6 = (page >> 24) & 0xff; + /* fall thru */ + case 5: + cmd.u.ale_cmd.adr_byt5 = (page >> 16) & 0xff; + /* fall thru */ + case 4: + cmd.u.ale_cmd.adr_byt4 = (page >> 8) & 0xff; + cmd.u.ale_cmd.adr_byt3 = page & 0xff; + cmd.u.ale_cmd.adr_byt2 = (col >> 8) & 0xff; + cmd.u.ale_cmd.adr_byt1 = col & 0xff; + break; + /* 1-3 bytes: just the page address */ + case 3: + cmd.u.ale_cmd.adr_byt3 = (page >> 16) & 0xff; + /* fall thru */ + case 2: + cmd.u.ale_cmd.adr_byt2 = (page >> 8) & 0xff; + /* fall thru */ + case 1: + cmd.u.ale_cmd.adr_byt1 = page & 0xff; + break; + default: + break; + } + + cmd.u.ale_cmd.alen1 = t3; + cmd.u.ale_cmd.alen2 = t1; + cmd.u.ale_cmd.alen3 = t5; + cmd.u.ale_cmd.alen4 = t2; + return ndf_submit(tn, &cmd); +} + +static int ndf_queue_cmd_write(struct octeontx_nfc *tn, int len) +{ + union ndf_cmd cmd; + + memset(&cmd, 0, sizeof(cmd)); + cmd.u.wr_cmd.opcode = NDF_OP_WR_CMD; + cmd.u.wr_cmd.data = len; + cmd.u.wr_cmd.wlen1 = t3; + cmd.u.wr_cmd.wlen2 = t1; + return ndf_submit(tn, &cmd); +} + +static int ndf_build_pre_cmd(struct octeontx_nfc *tn, int cmd1, + int addr_bytes, u64 page, u32 col, int cmd2) +{ + struct nand_chip *nand = tn->controller.active; + struct octeontx_nand_chip *octeontx_nand; + struct ndf_set_tm_par_cmd *timings; + int width, page_size, rc; + + /* Also called before chip probing is finished */ + if (!nand) { + timings = &default_timing_parms; + page_size = default_page_size; + width = default_width; + } else { + octeontx_nand = to_otx_nand(nand); + timings = &octeontx_nand->timings; + page_size = nand->mtd.writesize; + if (nand->options & NAND_BUSWIDTH_16) + width = 2; + else + width = 1; + } + rc = ndf_queue_cmd_timing(tn, timings); + if (rc) + return rc; + + rc = ndf_queue_cmd_bus(tn, NDF_BUS_ACQUIRE); + if (rc) + return rc; + + rc = ndf_queue_cmd_chip(tn, 1, tn->selected_chip, width); + if (rc) + return rc; + + rc = ndf_queue_cmd_wait(tn, t1); + if (rc) + return rc; + + rc = ndf_queue_cmd_cle(tn, cmd1); + if (rc) + return rc; + + if (addr_bytes) { + rc = ndf_build_wait_busy(tn); + if (rc) + return rc; + + rc = ndf_queue_cmd_ale(tn, addr_bytes, nand, + page, col, page_size); + if (rc) + return rc; + } + + /* CLE 2 */ + if (cmd2) { + rc = ndf_build_wait_busy(tn); + if (rc) + return rc; + + rc = ndf_queue_cmd_cle(tn, cmd2); + if (rc) + return rc; + } + return 0; +} + +static int ndf_build_post_cmd(struct octeontx_nfc *tn, int hold_time) +{ + int rc; + + /* Deselect chip */ + rc = ndf_queue_cmd_chip(tn, 0, 0, 0); + if (rc) + return rc; + + rc = ndf_queue_cmd_wait(tn, t2); + if (rc) + return rc; + + /* Release bus */ + rc = ndf_queue_cmd_bus(tn, 0); + if (rc) + return rc; + + rc = ndf_queue_cmd_wait(tn, hold_time); + if (rc) + return rc; + + /* + * Last action is ringing the doorbell with number of bus + * acquire-releases cycles (currently 1). + */ + writeq(1, tn->base + NDF_DRBELL); + return 0; +} + +/* Setup the NAND DMA engine for a transfer. */ +static void ndf_setup_dma(struct octeontx_nfc *tn, int is_write, + dma_addr_t bus_addr, int len) +{ + u64 dma_cfg; + + dma_cfg = FIELD_PREP(NDF_DMA_CFG_RW, is_write) | + FIELD_PREP(NDF_DMA_CFG_SIZE, (len >> 3) - 1); + dma_cfg |= NDF_DMA_CFG_EN; + writeq(bus_addr, tn->base + NDF_DMA_ADR); + writeq(dma_cfg, tn->base + NDF_DMA_CFG); +} + +static int octeontx_nand_reset(struct octeontx_nfc *tn) +{ + int rc; + + rc = ndf_build_pre_cmd(tn, NAND_CMD_RESET, 0, 0, 0, 0); + if (rc) + return rc; + + rc = ndf_build_wait_busy(tn); + if (rc) + return rc; + + rc = ndf_build_post_cmd(tn, t2); + if (rc) + return rc; + + return 0; +} + +static int ndf_read(struct octeontx_nfc *tn, int cmd1, int addr_bytes, + u64 page, u32 col, int cmd2, int len) +{ + dma_addr_t bus_addr = tn->use_status ? tn->stat_addr : tn->buf.dmaaddr; + struct nand_chip *nand = tn->controller.active; + int timing_mode, bytes, rc; + union ndf_cmd cmd; + u64 start, end; + + pr_debug("%s(%p, 0x%x, 0x%x, 0x%llx, 0x%x, 0x%x, 0x%x)\n", __func__, + tn, cmd1, addr_bytes, page, col, cmd2, len); + if (!nand) + timing_mode = default_onfi_timing; + else + timing_mode = nand->onfi_timing_mode_default; + + /* Build the command and address cycles */ + rc = ndf_build_pre_cmd(tn, cmd1, addr_bytes, page, col, cmd2); + if (rc) { + dev_err(tn->dev, "Build pre command failed\n"); + return rc; + } + + /* This waits for some time, then waits for busy to be de-asserted. */ + rc = ndf_build_wait_busy(tn); + if (rc) { + dev_err(tn->dev, "Wait timeout\n"); + return rc; + } + + memset(&cmd, 0, sizeof(cmd)); + + if (timing_mode < 4) + cmd.u.rd_cmd.opcode = NDF_OP_RD_CMD; + else + cmd.u.rd_cmd.opcode = NDF_OP_RD_EDO_CMD; + + cmd.u.rd_cmd.data = len; + cmd.u.rd_cmd.rlen1 = t7; + cmd.u.rd_cmd.rlen2 = t3; + cmd.u.rd_cmd.rlen3 = t1; + cmd.u.rd_cmd.rlen4 = t7; + rc = ndf_submit(tn, &cmd); + if (rc) { + dev_err(tn->dev, "Error submitting command\n"); + return rc; + } + + start = (u64)bus_addr; + ndf_setup_dma(tn, 0, bus_addr, len); + + rc = ndf_build_post_cmd(tn, t2); + if (rc) { + dev_err(tn->dev, "Build post command failed\n"); + return rc; + } + + /* Wait for the DMA to complete */ + rc = ndf_wait(tn); + if (rc) { + dev_err(tn->dev, "DMA timed out\n"); + return rc; + } + + end = readq(tn->base + NDF_DMA_ADR); + bytes = end - start; + + /* Make sure NDF is really done */ + rc = ndf_wait_idle(tn); + if (rc) { + dev_err(tn->dev, "poll idle failed\n"); + return rc; + } + + pr_debug("%s: Read %d bytes\n", __func__, bytes); + return bytes; +} + +static int octeontx_nand_get_features(struct mtd_info *mtd, + struct nand_chip *chip, int feature_addr, + u8 *subfeature_para) +{ + struct nand_chip *nand = chip; + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + int len = 8; + int rc; + + pr_debug("%s: feature addr: 0x%x\n", __func__, feature_addr); + memset(tn->buf.dmabuf, 0xff, len); + tn->buf.data_index = 0; + tn->buf.data_len = 0; + rc = ndf_read(tn, NAND_CMD_GET_FEATURES, 1, feature_addr, 0, 0, len); + if (rc) + return rc; + + memcpy(subfeature_para, tn->buf.dmabuf, ONFI_SUBFEATURE_PARAM_LEN); + + return 0; +} + +static int octeontx_nand_set_features(struct mtd_info *mtd, + struct nand_chip *chip, int feature_addr, + u8 *subfeature_para) +{ + struct nand_chip *nand = chip; + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + const int len = ONFI_SUBFEATURE_PARAM_LEN; + int rc; + + rc = ndf_build_pre_cmd(tn, NAND_CMD_SET_FEATURES, + 1, feature_addr, 0, 0); + if (rc) + return rc; + + memcpy(tn->buf.dmabuf, subfeature_para, len); + memset(tn->buf.dmabuf + len, 0, 8 - len); + + ndf_setup_dma(tn, 1, tn->buf.dmaaddr, 8); + + rc = ndf_queue_cmd_write(tn, 8); + if (rc) + return rc; + + rc = ndf_build_wait_busy(tn); + if (rc) + return rc; + + rc = ndf_build_post_cmd(tn, t2); + if (rc) + return rc; + + return 0; +} + +/* + * Read a page from NAND. If the buffer has room, the out of band + * data will be included. + */ +static int ndf_page_read(struct octeontx_nfc *tn, u64 page, int col, int len) +{ + debug("%s(%p, 0x%llx, 0x%x, 0x%x) active: %p\n", __func__, + tn, page, col, len, tn->controller.active); + struct nand_chip *nand = tn->controller.active; + struct octeontx_nand_chip *chip = to_otx_nand(nand); + int addr_bytes = chip->row_bytes + chip->col_bytes; + + memset(tn->buf.dmabuf, 0xff, len); + return ndf_read(tn, NAND_CMD_READ0, addr_bytes, + page, col, NAND_CMD_READSTART, len); +} + +/* Erase a NAND block */ +static int ndf_block_erase(struct octeontx_nfc *tn, u64 page_addr) +{ + struct nand_chip *nand = tn->controller.active; + struct octeontx_nand_chip *chip = to_otx_nand(nand); + int addr_bytes = chip->row_bytes; + int rc; + + rc = ndf_build_pre_cmd(tn, NAND_CMD_ERASE1, addr_bytes, + page_addr, 0, NAND_CMD_ERASE2); + if (rc) + return rc; + + /* Wait for R_B to signal erase is complete */ + rc = ndf_build_wait_busy(tn); + if (rc) + return rc; + + rc = ndf_build_post_cmd(tn, t2); + if (rc) + return rc; + + /* Wait until the command queue is idle */ + return ndf_wait_idle(tn); +} + +/* + * Write a page (or less) to NAND. + */ +static int ndf_page_write(struct octeontx_nfc *tn, int page) +{ + int len, rc; + struct nand_chip *nand = tn->controller.active; + struct octeontx_nand_chip *chip = to_otx_nand(nand); + int addr_bytes = chip->row_bytes + chip->col_bytes; + + len = tn->buf.data_len - tn->buf.data_index; + chip->oob_only = (tn->buf.data_index >= nand->mtd.writesize); + WARN_ON_ONCE(len & 0x7); + + ndf_setup_dma(tn, 1, tn->buf.dmaaddr + tn->buf.data_index, len); + rc = ndf_build_pre_cmd(tn, NAND_CMD_SEQIN, addr_bytes, page, 0, 0); + if (rc) + return rc; + + rc = ndf_queue_cmd_write(tn, len); + if (rc) + return rc; + + rc = ndf_queue_cmd_cle(tn, NAND_CMD_PAGEPROG); + if (rc) + return rc; + + /* Wait for R_B to signal program is complete */ + rc = ndf_build_wait_busy(tn); + if (rc) + return rc; + + rc = ndf_build_post_cmd(tn, t2); + if (rc) + return rc; + + /* Wait for the DMA to complete */ + rc = ndf_wait(tn); + if (rc) + return rc; + + /* Data transfer is done but NDF is not, it is waiting for R/B# */ + return ndf_wait_idle(tn); +} + +static void octeontx_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, + int column, int page_addr) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + struct octeontx_nand_chip *octeontx_nand = to_otx_nand(nand); + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + int rc; + + tn->selected_chip = octeontx_nand->cs; + if (tn->selected_chip < 0 || tn->selected_chip >= NAND_MAX_CHIPS) { + dev_err(tn->dev, "invalid chip select\n"); + return; + } + + tn->use_status = false; + + pr_debug("%s(%p, 0x%x, 0x%x, 0x%x) cs: %d\n", __func__, mtd, command, + column, page_addr, tn->selected_chip); + switch (command) { + case NAND_CMD_READID: + tn->buf.data_index = 0; + octeontx_nand->oob_only = false; + rc = ndf_read(tn, command, 1, column, 0, 0, 8); + if (rc < 0) + dev_err(tn->dev, "READID failed with %d\n", rc); + else + tn->buf.data_len = rc; + break; + + case NAND_CMD_READOOB: + octeontx_nand->oob_only = true; + tn->buf.data_index = 0; + tn->buf.data_len = 0; + rc = ndf_page_read(tn, page_addr, column, mtd->oobsize); + if (rc < mtd->oobsize) + dev_err(tn->dev, "READOOB failed with %d\n", + tn->buf.data_len); + else + tn->buf.data_len = rc; + break; + + case NAND_CMD_READ0: + octeontx_nand->oob_only = false; + tn->buf.data_index = 0; + tn->buf.data_len = 0; + rc = ndf_page_read(tn, page_addr, column, + mtd->writesize + mtd->oobsize); + + if (rc < mtd->writesize + mtd->oobsize) + dev_err(tn->dev, "READ0 failed with %d\n", rc); + else + tn->buf.data_len = rc; + break; + + case NAND_CMD_STATUS: + /* used in oob/not states */ + tn->use_status = true; + rc = ndf_read(tn, command, 0, 0, 0, 0, 8); + if (rc < 0) + dev_err(tn->dev, "STATUS failed with %d\n", rc); + break; + + case NAND_CMD_RESET: + /* used in oob/not states */ + rc = octeontx_nand_reset(tn); + if (rc < 0) + dev_err(tn->dev, "RESET failed with %d\n", rc); + break; + + case NAND_CMD_PARAM: + octeontx_nand->oob_only = false; + tn->buf.data_index = 0; + rc = ndf_read(tn, command, 1, 0, 0, 0, + min(tn->buf.dmabuflen, 3 * 512)); + if (rc < 0) + dev_err(tn->dev, "PARAM failed with %d\n", rc); + else + tn->buf.data_len = rc; + break; + + case NAND_CMD_RNDOUT: + tn->buf.data_index = column; + break; + + case NAND_CMD_ERASE1: + if (ndf_block_erase(tn, page_addr)) + dev_err(tn->dev, "ERASE1 failed\n"); + break; + + case NAND_CMD_ERASE2: + /* We do all erase processing in the first command, so ignore + * this one. + */ + break; + + case NAND_CMD_SEQIN: + octeontx_nand->oob_only = (column >= mtd->writesize); + tn->buf.data_index = column; + tn->buf.data_len = column; + + octeontx_nand->selected_page = page_addr; + break; + + case NAND_CMD_PAGEPROG: + rc = ndf_page_write(tn, octeontx_nand->selected_page); + if (rc) + dev_err(tn->dev, "PAGEPROG failed with %d\n", rc); + break; + + case NAND_CMD_SET_FEATURES: + octeontx_nand->oob_only = false; + /* assume tn->buf.data_len == 4 of data has been set there */ + rc = octeontx_nand_set_features(mtd, nand, + page_addr, tn->buf.dmabuf); + if (rc) + dev_err(tn->dev, "SET_FEATURES failed with %d\n", rc); + break; + + case NAND_CMD_GET_FEATURES: + octeontx_nand->oob_only = false; + rc = octeontx_nand_get_features(mtd, nand, + page_addr, tn->buf.dmabuf); + if (!rc) { + tn->buf.data_index = 0; + tn->buf.data_len = 4; + } else { + dev_err(tn->dev, "GET_FEATURES failed with %d\n", rc); + } + break; + + default: + WARN_ON_ONCE(1); + dev_err(tn->dev, "unhandled nand cmd: %x\n", command); + } +} + +static int octeontx_nand_waitfunc(struct mtd_info *mtd, struct nand_chip *chip) +{ + struct octeontx_nfc *tn = to_otx_nfc(chip->controller); + int ret; + + ret = ndf_wait_idle(tn); + return (ret < 0) ? -EIO : 0; +} + +/* check compatibility with ONFI timing mode#N, and optionally apply */ +/* TODO: Implement chipnr support? */ +static int octeontx_nand_setup_dat_intf(struct mtd_info *mtd, int chipnr, + const struct nand_data_interface *conf) +{ + static const bool check_only; + struct nand_chip *nand = mtd_to_nand(mtd); + struct octeontx_nand_chip *chip = to_otx_nand(nand); + int rc; + static u64 tWC_N[MAX_ONFI_MODE + 2]; /* cache a mode signature */ + int mode; /* deduced mode number, for reporting and restricting */ + + /* + * Cache timing modes for reporting, and reducing needless change. + * + * Challenge: caller does not pass ONFI mode#, but reporting the mode + * and restricting to a maximum, or a list, are useful for diagnosing + * new hardware. So use tWC_min, distinct and monotonic across modes, + * to discover the requested/accepted mode number + */ + for (mode = MAX_ONFI_MODE; mode >= 0 && !tWC_N[0]; mode--) { + const struct nand_sdr_timings *t; + + t = onfi_async_timing_mode_to_sdr_timings(mode); + if (!t) + continue; + tWC_N[mode] = t->tWC_min; + } + + if (!conf) { + rc = -EINVAL; + } else if (check_only) { + rc = 0; + } else if (nand->data_interface && + chip->iface_set && chip->iface_mode == mode) { + /* + * Cases: + * - called from nand_reset, which clears DDR timing + * mode back to SDR. BUT if we're already in SDR, + * timing mode persists over resets. + * While mtd/nand layer only supports SDR, + * this is always safe. And this driver only supports SDR. + * + * - called from post-power-event nand_reset (maybe + * NFC+flash power down, or system hibernate. + * Address this when CONFIG_PM support added + */ + rc = 0; + } else { + rc = octeontx_nfc_chip_set_timings(chip, &conf->timings.sdr); + if (!rc) { + chip->iface_mode = mode; + chip->iface_set = true; + } + } + return rc; +} + +#if defined(CONFIG_NAND_OCTEONTX_HW_ECC) + +static void octeontx_bch_reset(void) +{ +} + +/* + * Given a page, calculate the ECC code + * + * chip: Pointer to NAND chip data structure + * buf: Buffer to calculate ECC on + * code: Buffer to hold ECC data + * + * Return 0 on success or -1 on failure + */ +static int octeontx_nand_bch_calculate_ecc_internal(struct mtd_info *mtd, + dma_addr_t ihandle, + u8 *code) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + int rc; + int i; + static u8 *ecc_buffer; + static int ecc_size; + static unsigned long ecc_handle; + union bch_resp *r = tn->bch_resp; + + if (!ecc_buffer || ecc_size < nand->ecc.size) { + ecc_size = nand->ecc.size; + ecc_buffer = dma_alloc_coherent(ecc_size, + (unsigned long *)&ecc_handle); + } + + memset(ecc_buffer, 0, nand->ecc.bytes); + + r->u16 = 0; + __iowmb(); /* flush done=0 before making request */ + + rc = octeontx_bch_encode(bch_vf, ihandle, nand->ecc.size, + nand->ecc.strength, + (dma_addr_t)ecc_handle, tn->bch_rhandle); + + if (!rc) { + octeontx_bch_wait(bch_vf, r, tn->bch_rhandle); + } else { + dev_err(tn->dev, "octeontx_bch_encode failed\n"); + return -1; + } + + if (!r->s.done || r->s.uncorrectable) { + dev_err(tn->dev, + "%s timeout, done:%d uncorr:%d corr:%d erased:%d\n", + __func__, r->s.done, r->s.uncorrectable, + r->s.num_errors, r->s.erased); + octeontx_bch_reset(); + return -1; + } + + memcpy(code, ecc_buffer, nand->ecc.bytes); + + for (i = 0; i < nand->ecc.bytes; i++) + code[i] ^= tn->eccmask[i]; + + return tn->bch_resp->s.num_errors; +} + +/* + * Given a page, calculate the ECC code + * + * mtd: MTD block structure + * dat: raw data (unused) + * ecc_code: buffer for ECC + */ +static int octeontx_nand_bch_calculate(struct mtd_info *mtd, + const u8 *dat, u8 *ecc_code) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + dma_addr_t handle = dma_map_single((u8 *)dat, + nand->ecc.size, DMA_TO_DEVICE); + int ret; + + ret = octeontx_nand_bch_calculate_ecc_internal(mtd, handle, + (void *)ecc_code); + + return ret; +} + +/* + * Detect and correct multi-bit ECC for a page + * + * mtd: MTD block structure + * dat: raw data read from the chip + * read_ecc: ECC from the chip (unused) + * isnull: unused + * + * Returns number of bits corrected or -1 if unrecoverable + */ +static int octeontx_nand_bch_correct(struct mtd_info *mtd, u_char *dat, + u_char *read_ecc, u_char *isnull) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + int i = nand->ecc.size + nand->ecc.bytes; + static u8 *data_buffer; + static dma_addr_t ihandle; + static int buffer_size; + dma_addr_t ohandle; + union bch_resp *r = tn->bch_resp; + int rc; + + if (i > buffer_size) { + if (buffer_size) + free(data_buffer); + data_buffer = dma_alloc_coherent(i, + (unsigned long *)&ihandle); + if (!data_buffer) { + dev_err(tn->dev, + "%s: Could not allocate %d bytes for buffer\n", + __func__, i); + goto error; + } + buffer_size = i; + } + + memcpy(data_buffer, dat, nand->ecc.size); + memcpy(data_buffer + nand->ecc.size, read_ecc, nand->ecc.bytes); + + for (i = 0; i < nand->ecc.bytes; i++) + data_buffer[nand->ecc.size + i] ^= tn->eccmask[i]; + + r->u16 = 0; + __iowmb(); /* flush done=0 before making request */ + + ohandle = dma_map_single(dat, nand->ecc.size, DMA_FROM_DEVICE); + rc = octeontx_bch_decode(bch_vf, ihandle, nand->ecc.size, + nand->ecc.strength, ohandle, tn->bch_rhandle); + + if (!rc) + octeontx_bch_wait(bch_vf, r, tn->bch_rhandle); + + if (rc) { + dev_err(tn->dev, "octeontx_bch_decode failed\n"); + goto error; + } + + if (!r->s.done) { + dev_err(tn->dev, "Error: BCH engine timeout\n"); + octeontx_bch_reset(); + goto error; + } + + if (r->s.erased) { + debug("Info: BCH block is erased\n"); + return 0; + } + + if (r->s.uncorrectable) { + debug("Cannot correct NAND block, response: 0x%x\n", + r->u16); + goto error; + } + + return r->s.num_errors; + +error: + debug("Error performing bch correction\n"); + return -1; +} + +void octeontx_nand_bch_hwctl(struct mtd_info *mtd, int mode) +{ + /* Do nothing. */ +} + +static int octeontx_nand_hw_bch_read_page(struct mtd_info *mtd, + struct nand_chip *chip, u8 *buf, + int oob_required, int page) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + int i, eccsize = chip->ecc.size, ret; + int eccbytes = chip->ecc.bytes; + int eccsteps = chip->ecc.steps; + u8 *p; + u8 *ecc_code = chip->buffers->ecccode; + unsigned int max_bitflips = 0; + + /* chip->read_buf() insists on sequential order, we do OOB first */ + memcpy(chip->oob_poi, tn->buf.dmabuf + mtd->writesize, mtd->oobsize); + + /* Use private buffer as input for ECC correction */ + p = tn->buf.dmabuf; + + ret = mtd_ooblayout_get_eccbytes(mtd, ecc_code, chip->oob_poi, 0, + chip->ecc.total); + if (ret) + return ret; + + for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize) { + int stat; + + debug("Correcting block offset %lx, ecc offset %x\n", + p - buf, i); + stat = chip->ecc.correct(mtd, p, &ecc_code[i], NULL); + + if (stat < 0) { + mtd->ecc_stats.failed++; + debug("Cannot correct NAND page %d\n", page); + } else { + mtd->ecc_stats.corrected += stat; + max_bitflips = max_t(unsigned int, max_bitflips, stat); + } + } + + /* Copy corrected data to caller's buffer now */ + memcpy(buf, tn->buf.dmabuf, mtd->writesize); + + return max_bitflips; +} + +static int octeontx_nand_hw_bch_write_page(struct mtd_info *mtd, + struct nand_chip *chip, + const u8 *buf, int oob_required, + int page) +{ + struct octeontx_nfc *tn = to_otx_nfc(chip->controller); + int i, eccsize = chip->ecc.size, ret; + int eccbytes = chip->ecc.bytes; + int eccsteps = chip->ecc.steps; + const u8 *p; + u8 *ecc_calc = chip->buffers->ecccalc; + + debug("%s(buf?%p, oob%d p%x)\n", + __func__, buf, oob_required, page); + for (i = 0; i < chip->ecc.total; i++) + ecc_calc[i] = 0xFF; + + /* Copy the page data from caller's buffers to private buffer */ + chip->write_buf(mtd, buf, mtd->writesize); + /* Use private date as source for ECC calculation */ + p = tn->buf.dmabuf; + + /* Hardware ECC calculation */ + for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize) { + int ret; + + ret = chip->ecc.calculate(mtd, p, &ecc_calc[i]); + + if (ret < 0) + debug("calculate(mtd, p?%p, &ecc_calc[%d]?%p) returned %d\n", + p, i, &ecc_calc[i], ret); + + debug("block offset %lx, ecc offset %x\n", p - buf, i); + } + + ret = mtd_ooblayout_set_eccbytes(mtd, ecc_calc, chip->oob_poi, 0, + chip->ecc.total); + if (ret) + return ret; + + /* Store resulting OOB into private buffer, will be sent to HW */ + chip->write_buf(mtd, chip->oob_poi, mtd->oobsize); + + return 0; +} + +/** + * nand_write_page_raw - [INTERN] raw page write function + * @mtd: mtd info structure + * @chip: nand chip info structure + * @buf: data buffer + * @oob_required: must write chip->oob_poi to OOB + * @page: page number to write + * + * Not for syndrome calculating ECC controllers, which use a special oob layout. + */ +static int octeontx_nand_write_page_raw(struct mtd_info *mtd, + struct nand_chip *chip, + const u8 *buf, int oob_required, + int page) +{ + chip->write_buf(mtd, buf, mtd->writesize); + if (oob_required) + chip->write_buf(mtd, chip->oob_poi, mtd->oobsize); + + return 0; +} + +/** + * octeontx_nand_write_oob_std - [REPLACEABLE] the most common OOB data write + * function + * @mtd: mtd info structure + * @chip: nand chip info structure + * @page: page number to write + */ +static int octeontx_nand_write_oob_std(struct mtd_info *mtd, + struct nand_chip *chip, + int page) +{ + int status = 0; + const u8 *buf = chip->oob_poi; + int length = mtd->oobsize; + + chip->cmdfunc(mtd, NAND_CMD_SEQIN, mtd->writesize, page); + chip->write_buf(mtd, buf, length); + /* Send command to program the OOB data */ + chip->cmdfunc(mtd, NAND_CMD_PAGEPROG, -1, -1); + + status = chip->waitfunc(mtd, chip); + + return status & NAND_STATUS_FAIL ? -EIO : 0; +} + +/** + * octeontx_nand_read_page_raw - [INTERN] read raw page data without ecc + * @mtd: mtd info structure + * @chip: nand chip info structure + * @buf: buffer to store read data + * @oob_required: caller requires OOB data read to chip->oob_poi + * @page: page number to read + * + * Not for syndrome calculating ECC controllers, which use a special oob layout. + */ +static int octeontx_nand_read_page_raw(struct mtd_info *mtd, + struct nand_chip *chip, + u8 *buf, int oob_required, int page) +{ + chip->read_buf(mtd, buf, mtd->writesize); + if (oob_required) + chip->read_buf(mtd, chip->oob_poi, mtd->oobsize); + return 0; +} + +static int octeontx_nand_read_oob_std(struct mtd_info *mtd, + struct nand_chip *chip, + int page) + +{ + chip->cmdfunc(mtd, NAND_CMD_READOOB, 0, page); + chip->read_buf(mtd, chip->oob_poi, mtd->oobsize); + return 0; +} + +static int octeontx_nand_calc_bch_ecc_strength(struct nand_chip *nand) +{ + struct mtd_info *mtd = nand_to_mtd(nand); + struct nand_ecc_ctrl *ecc = &nand->ecc; + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + int nsteps = mtd->writesize / ecc->size; + int oobchunk = mtd->oobsize / nsteps; + + /* ecc->strength determines ecc_level and OOB's ecc_bytes. */ + const u8 strengths[] = {4, 8, 16, 24, 32, 40, 48, 56, 60, 64}; + /* first set the desired ecc_level to match strengths[] */ + int index = ARRAY_SIZE(strengths) - 1; + int need; + + while (index > 0 && !(ecc->options & NAND_ECC_MAXIMIZE) && + strengths[index - 1] >= ecc->strength) + index--; + + do { + need = DIV_ROUND_UP(15 * strengths[index], 8); + if (need <= oobchunk - 2) + break; + } while (index > 0); + + debug("%s: steps ds: %d, strength ds: %d\n", __func__, + nand->ecc_step_ds, nand->ecc_strength_ds); + ecc->strength = strengths[index]; + ecc->bytes = need; + debug("%s: strength: %d, bytes: %d\n", __func__, ecc->strength, + ecc->bytes); + + if (!tn->eccmask) + tn->eccmask = devm_kzalloc(tn->dev, ecc->bytes, GFP_KERNEL); + if (!tn->eccmask) + return -ENOMEM; + + return 0; +} + +/* sample the BCH signature of an erased (all 0xff) page, + * to XOR into all page traffic, so erased pages have no ECC errors + */ +static int octeontx_bch_save_empty_eccmask(struct nand_chip *nand) +{ + struct mtd_info *mtd = nand_to_mtd(nand); + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + unsigned int eccsize = nand->ecc.size; + unsigned int eccbytes = nand->ecc.bytes; + u8 erased_ecc[eccbytes]; + unsigned long erased_handle; + unsigned char *erased_page = dma_alloc_coherent(eccsize, + &erased_handle); + int i; + int rc = 0; + + if (!erased_page) + return -ENOMEM; + + memset(erased_page, 0xff, eccsize); + memset(erased_ecc, 0, eccbytes); + + rc = octeontx_nand_bch_calculate_ecc_internal(mtd, + (dma_addr_t)erased_handle, + erased_ecc); + + free(erased_page); + + for (i = 0; i < eccbytes; i++) + tn->eccmask[i] = erased_ecc[i] ^ 0xff; + + return rc; +} +#endif /*CONFIG_NAND_OCTEONTX_HW_ECC*/ + +static void octeontx_nfc_chip_sizing(struct nand_chip *nand) +{ + struct octeontx_nand_chip *chip = to_otx_nand(nand); + struct mtd_info *mtd = nand_to_mtd(nand); + struct nand_ecc_ctrl *ecc = &nand->ecc; + + chip->row_bytes = nand->onfi_params.addr_cycles & 0xf; + chip->col_bytes = nand->onfi_params.addr_cycles >> 4; + debug("%s(%p) row bytes: %d, col bytes: %d, ecc mode: %d\n", + __func__, nand, chip->row_bytes, chip->col_bytes, ecc->mode); + + /* + * HW_BCH using OcteonTX BCH engine, or SOFT_BCH laid out in + * HW_BCH-compatible fashion, depending on devtree advice + * and kernel config. + * BCH/NFC hardware capable of subpage ops, not implemented. + */ + mtd_set_ooblayout(mtd, &nand_ooblayout_lp_ops); + nand->options |= NAND_NO_SUBPAGE_WRITE; + debug("%s: start steps: %d, size: %d, bytes: %d\n", + __func__, ecc->steps, ecc->size, ecc->bytes); + debug("%s: step ds: %d, strength ds: %d\n", __func__, + nand->ecc_step_ds, nand->ecc_strength_ds); + + if (ecc->mode != NAND_ECC_NONE) { + int nsteps = ecc->steps ? ecc->steps : 1; + + if (ecc->size && ecc->size != mtd->writesize) + nsteps = mtd->writesize / ecc->size; + else if (mtd->writesize > def_ecc_size && + !(mtd->writesize & (def_ecc_size - 1))) + nsteps = mtd->writesize / def_ecc_size; + ecc->steps = nsteps; + ecc->size = mtd->writesize / nsteps; + ecc->bytes = mtd->oobsize / nsteps; + + if (nand->ecc_strength_ds) + ecc->strength = nand->ecc_strength_ds; + if (nand->ecc_step_ds) + ecc->size = nand->ecc_step_ds; + /* + * no subpage ops, but set subpage-shift to match ecc->steps + * so mtd_nandbiterrs tests appropriate boundaries + */ + if (!mtd->subpage_sft && !(ecc->steps & (ecc->steps - 1))) + mtd->subpage_sft = fls(ecc->steps) - 1; + +#if defined(CONFIG_NAND_OCTEONTX_HW_ECC) + debug("%s: ecc mode: %d\n", __func__, ecc->mode); + if (ecc->mode != NAND_ECC_SOFT && + !octeontx_nand_calc_bch_ecc_strength(nand)) { + struct octeontx_nfc *tn = to_otx_nfc(nand->controller); + + debug("Using hardware BCH engine support\n"); + ecc->mode = NAND_ECC_HW_SYNDROME; + ecc->read_page = octeontx_nand_hw_bch_read_page; + ecc->write_page = octeontx_nand_hw_bch_write_page; + ecc->read_page_raw = octeontx_nand_read_page_raw; + ecc->write_page_raw = octeontx_nand_write_page_raw; + ecc->read_oob = octeontx_nand_read_oob_std; + ecc->write_oob = octeontx_nand_write_oob_std; + + ecc->calculate = octeontx_nand_bch_calculate; + ecc->correct = octeontx_nand_bch_correct; + ecc->hwctl = octeontx_nand_bch_hwctl; + + debug("NAND chip %d using hw_bch\n", + tn->selected_chip); + debug(" %d bytes ECC per %d byte block\n", + ecc->bytes, ecc->size); + debug(" for %d bits of correction per block.", + ecc->strength); + octeontx_nand_calc_ecc_layout(nand); + octeontx_bch_save_empty_eccmask(nand); + } +#endif /*CONFIG_NAND_OCTEONTX_HW_ECC*/ + } +} + +static int octeontx_nfc_chip_init(struct octeontx_nfc *tn, struct udevice *dev, + ofnode node) +{ + struct octeontx_nand_chip *chip; + struct nand_chip *nand; + struct mtd_info *mtd; + int ret; + + chip = devm_kzalloc(dev, sizeof(*chip), GFP_KERNEL); + if (!chip) + return -ENOMEM; + + debug("%s: Getting chip select\n", __func__); + ret = ofnode_read_s32(node, "reg", &chip->cs); + if (ret) { + dev_err(dev, "could not retrieve reg property: %d\n", ret); + return ret; + } + + if (chip->cs >= NAND_MAX_CHIPS) { + dev_err(dev, "invalid reg value: %u (max CS = 7)\n", chip->cs); + return -EINVAL; + } + debug("%s: chip select: %d\n", __func__, chip->cs); + nand = &chip->nand; + nand->controller = &tn->controller; + if (!tn->controller.active) + tn->controller.active = nand; + + debug("%s: Setting flash node\n", __func__); + nand_set_flash_node(nand, node); + + nand->options = 0; + nand->select_chip = octeontx_nand_select_chip; + nand->cmdfunc = octeontx_nand_cmdfunc; + nand->waitfunc = octeontx_nand_waitfunc; + nand->read_byte = octeontx_nand_read_byte; + nand->read_buf = octeontx_nand_read_buf; + nand->write_buf = octeontx_nand_write_buf; + nand->onfi_set_features = octeontx_nand_set_features; + nand->onfi_get_features = octeontx_nand_get_features; + nand->setup_data_interface = octeontx_nand_setup_dat_intf; + + mtd = nand_to_mtd(nand); + debug("%s: mtd: %p\n", __func__, mtd); + mtd->dev->parent = dev; + + debug("%s: NDF_MISC: 0x%llx\n", __func__, + readq(tn->base + NDF_MISC)); + + /* TODO: support more then 1 chip */ + debug("%s: Scanning identification\n", __func__); + ret = nand_scan_ident(mtd, 1, NULL); + if (ret) + return ret; + + debug("%s: Sizing chip\n", __func__); + octeontx_nfc_chip_sizing(nand); + + debug("%s: Scanning tail\n", __func__); + ret = nand_scan_tail(mtd); + if (ret) { + dev_err(dev, "nand_scan_tail failed: %d\n", ret); + return ret; + } + + debug("%s: Registering mtd\n", __func__); + ret = nand_register(0, mtd); + + debug("%s: Adding tail\n", __func__); + list_add_tail(&chip->node, &tn->chips); + return 0; +} + +static int octeontx_nfc_chips_init(struct octeontx_nfc *tn) +{ + struct udevice *dev = tn->dev; + ofnode node = dev->node; + ofnode nand_node; + int nr_chips = of_get_child_count(node); + int ret; + + debug("%s: node: %s\n", __func__, ofnode_get_name(node)); + debug("%s: %d chips\n", __func__, nr_chips); + if (nr_chips > NAND_MAX_CHIPS) { + dev_err(dev, "too many NAND chips: %d\n", nr_chips); + return -EINVAL; + } + + if (!nr_chips) { + debug("no DT NAND chips found\n"); + return -ENODEV; + } + + pr_info("%s: scanning %d chips DTs\n", __func__, nr_chips); + + ofnode_for_each_subnode(nand_node, node) { + debug("%s: Calling octeontx_nfc_chip_init(%p, %s, %ld)\n", + __func__, tn, dev->name, nand_node.of_offset); + ret = octeontx_nfc_chip_init(tn, dev, nand_node); + if (ret) + return ret; + } + return 0; +} + +/* Reset NFC and initialize registers. */ +static int octeontx_nfc_init(struct octeontx_nfc *tn) +{ + const struct nand_sdr_timings *timings; + u64 ndf_misc; + int rc; + + /* Initialize values and reset the fifo */ + ndf_misc = readq(tn->base + NDF_MISC); + + ndf_misc &= ~NDF_MISC_EX_DIS; + ndf_misc |= (NDF_MISC_BT_DIS | NDF_MISC_RST_FF); + writeq(ndf_misc, tn->base + NDF_MISC); + debug("%s: NDF_MISC: 0x%llx\n", __func__, readq(tn->base + NDF_MISC)); + + /* Bring the fifo out of reset */ + ndf_misc &= ~(NDF_MISC_RST_FF); + + /* Maximum of co-processor cycles for glitch filtering */ + ndf_misc |= FIELD_PREP(NDF_MISC_WAIT_CNT, 0x3f); + + writeq(ndf_misc, tn->base + NDF_MISC); + + /* Set timing parameters to onfi mode 0 for probing */ + timings = onfi_async_timing_mode_to_sdr_timings(0); + if (IS_ERR(timings)) + return PTR_ERR(timings); + rc = set_default_timings(tn, timings); + if (rc) + return rc; + + return 0; +} + +static int octeontx_pci_nand_probe(struct udevice *dev) +{ + struct octeontx_nfc *tn = dev_get_priv(dev); + int ret; + static bool probe_done; + + debug("%s(%s) tn: %p\n", __func__, dev->name, tn); + if (probe_done) + return 0; + +#ifdef CONFIG_NAND_OCTEONTX_HW_ECC + bch_vf = octeontx_bch_getv(); + if (!bch_vf) { + struct octeontx_probe_device *probe_dev; + + debug("%s: bch not yet initialized\n", __func__); + probe_dev = calloc(sizeof(*probe_dev), 1); + if (!probe_dev) { + printf("%s: Out of memory\n", __func__); + return -ENOMEM; + } + probe_dev->dev = dev; + INIT_LIST_HEAD(&probe_dev->list); + list_add_tail(&probe_dev->list, + &octeontx_pci_nand_deferred_devices); + debug("%s: Defering probe until after BCH initialization\n", + __func__); + return 0; + } +#endif + + tn->dev = dev; + INIT_LIST_HEAD(&tn->chips); + + tn->base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM); + if (!tn->base) { + ret = -EINVAL; + goto release; + } + debug("%s: bar at %p\n", __func__, tn->base); + tn->buf.dmabuflen = NAND_MAX_PAGESIZE + NAND_MAX_OOBSIZE; + tn->buf.dmabuf = dma_alloc_coherent(tn->buf.dmabuflen, + (unsigned long *)&tn->buf.dmaaddr); + if (!tn->buf.dmabuf) { + ret = -ENOMEM; + debug("%s: Could not allocate DMA buffer\n", __func__); + goto unclk; + } + + /* one hw-bch response, for one outstanding transaction */ + tn->bch_resp = dma_alloc_coherent(sizeof(*tn->bch_resp), + (unsigned long *)&tn->bch_rhandle); + + tn->stat = dma_alloc_coherent(8, (unsigned long *)&tn->stat_addr); + if (!tn->stat || !tn->bch_resp) { + debug("%s: Could not allocate bch status or response\n", + __func__); + ret = -ENOMEM; + goto unclk; + } + + debug("%s: Calling octeontx_nfc_init()\n", __func__); + octeontx_nfc_init(tn); + debug("%s: Initializing chips\n", __func__); + ret = octeontx_nfc_chips_init(tn); + debug("%s: init chips ret: %d\n", __func__, ret); + if (ret) { + if (ret != -ENODEV) + dev_err(dev, "failed to init nand chips\n"); + goto unclk; + } + dev_info(dev, "probed\n"); + return 0; + +unclk: +release: + return ret; +} + +int octeontx_pci_nand_disable(struct udevice *dev) +{ + struct octeontx_nfc *tn = dev_get_priv(dev); + u64 dma_cfg; + u64 ndf_misc; + + debug("%s: Disabling NAND device %s\n", __func__, dev->name); + dma_cfg = readq(tn->base + NDF_DMA_CFG); + dma_cfg &= ~NDF_DMA_CFG_EN; + dma_cfg |= NDF_DMA_CFG_CLR; + writeq(dma_cfg, tn->base + NDF_DMA_CFG); + + /* Disable execution and put FIFO in reset mode */ + ndf_misc = readq(tn->base + NDF_MISC); + ndf_misc |= NDF_MISC_EX_DIS | NDF_MISC_RST_FF; + writeq(ndf_misc, tn->base + NDF_MISC); + ndf_misc &= ~NDF_MISC_RST_FF; + writeq(ndf_misc, tn->base + NDF_MISC); +#ifdef DEBUG + printf("%s: NDF_MISC: 0x%llx\n", __func__, readq(tn->base + NDF_MISC)); +#endif + /* Clear any interrupts and enable bits */ + writeq(~0ull, tn->base + NDF_INT_ENA_W1C); + writeq(~0ull, tn->base + NDF_INT); + debug("%s: NDF_ST_REG: 0x%llx\n", __func__, + readq(tn->base + NDF_ST_REG)); + return 0; +} + +#ifdef CONFIG_NAND_OCTEONTX_HW_ECC +/** + * Since it's possible (and even likely) that the NAND device will be probed + * before the BCH device has been probed, we may need to defer the probing. + * + * In this case, the initial probe returns success but the actual probing + * is deferred until the BCH VF has been probed. + * + * @return 0 for success, otherwise error + */ +int octeontx_pci_nand_deferred_probe(void) +{ + int rc = 0; + struct octeontx_probe_device *pdev; + + debug("%s: Performing deferred probing\n", __func__); + list_for_each_entry(pdev, &octeontx_pci_nand_deferred_devices, list) { + debug("%s: Probing %s\n", __func__, pdev->dev->name); + pdev->dev->flags &= ~DM_FLAG_ACTIVATED; + rc = device_probe(pdev->dev); + if (rc && rc != -ENODEV) { + printf("%s: Error %d with deferred probe of %s\n", + __func__, rc, pdev->dev->name); + break; + } + } + return rc; +} +#endif + +static const struct pci_device_id octeontx_nfc_pci_id_table[] = { + { PCI_VDEVICE(CAVIUM, 0xA04F) }, + {} +}; + +static int octeontx_nand_ofdata_to_platdata(struct udevice *dev) +{ + return 0; +} + +static const struct udevice_id octeontx_nand_ids[] = { + { .compatible = "cavium,cn8130-nand" }, + { }, +}; + +U_BOOT_DRIVER(octeontx_pci_nand) = { + .name = OCTEONTX_NAND_DRIVER_NAME, + .id = UCLASS_MTD, + .of_match = of_match_ptr(octeontx_nand_ids), + .ofdata_to_platdata = octeontx_nand_ofdata_to_platdata, + .probe = octeontx_pci_nand_probe, + .priv_auto_alloc_size = sizeof(struct octeontx_nfc), + .remove = octeontx_pci_nand_disable, + .flags = DM_FLAG_OS_PREPARE, +}; + +U_BOOT_PCI_DEVICE(octeontx_pci_nand, octeontx_nfc_pci_id_table); + +void board_nand_init(void) +{ + struct udevice *dev; + int ret; + +#ifdef CONFIG_NAND_OCTEONTX_HW_ECC + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(octeontx_pci_bchpf), + &dev); + if (ret && ret != -ENODEV) { + pr_err("Failed to initialize OcteonTX BCH PF controller. (error %d)\n", + ret); + } + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(octeontx_pci_bchvf), + &dev); + if (ret && ret != -ENODEV) { + pr_err("Failed to initialize OcteonTX BCH VF controller. (error %d)\n", + ret); + } +#endif + + ret = uclass_get_device_by_driver(UCLASS_MTD, + DM_GET_DRIVER(octeontx_pci_nand), + &dev); + if (ret && ret != -ENODEV) + pr_err("Failed to initialize OcteonTX NAND controller. (error %d)\n", + ret); +}
Adds support for Network Interface controllers found on OcteonTX SoC platforms.
Signed-off-by: Suneel Garapati sgarapati@marvell.com Cc: Joe Hershberger joe.hershberger@ni.com
Signed-off-by: Stefan Roese sr@denx.de ---
(no changes since v1)
Changes in v1: - Change patch subject - Rebased on latest TOT - Removed inclusion of common.h
drivers/net/Kconfig | 14 + drivers/net/Makefile | 2 + drivers/net/octeontx/Makefile | 9 + drivers/net/octeontx/bgx.c | 1572 +++++++++++++++++++++++++++ drivers/net/octeontx/bgx.h | 259 +++++ drivers/net/octeontx/nic.h | 510 +++++++++ drivers/net/octeontx/nic_main.c | 780 +++++++++++++ drivers/net/octeontx/nic_reg.h | 252 +++++ drivers/net/octeontx/nicvf_main.c | 583 ++++++++++ drivers/net/octeontx/nicvf_queues.c | 1142 +++++++++++++++++++ drivers/net/octeontx/nicvf_queues.h | 355 ++++++ drivers/net/octeontx/q_struct.h | 697 ++++++++++++ drivers/net/octeontx/smi.c | 383 +++++++ drivers/net/octeontx/xcv.c | 129 +++ 14 files changed, 6687 insertions(+) create mode 100644 drivers/net/octeontx/Makefile create mode 100644 drivers/net/octeontx/bgx.c create mode 100644 drivers/net/octeontx/bgx.h create mode 100644 drivers/net/octeontx/nic.h create mode 100644 drivers/net/octeontx/nic_main.c create mode 100644 drivers/net/octeontx/nic_reg.h create mode 100644 drivers/net/octeontx/nicvf_main.c create mode 100644 drivers/net/octeontx/nicvf_queues.c create mode 100644 drivers/net/octeontx/nicvf_queues.h create mode 100644 drivers/net/octeontx/q_struct.h create mode 100644 drivers/net/octeontx/smi.c create mode 100644 drivers/net/octeontx/xcv.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index ecd779d979..6f077bad58 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -407,6 +407,20 @@ config MT7628_ETH The MediaTek MT7628 ethernet interface is used on MT7628 and MT7688 based boards.
+config NET_OCTEONTX + bool "OcteonTX Ethernet support" + depends on ARCH_OCTEONTX + depends on PCI_SRIOV + help + You must select Y to enable network device support for + OcteonTX SoCs. If unsure, say n +config OCTEONTX_SMI + bool "OcteonTX SMI Device support" + depends on ARCH_OCTEONTX || ARCH_OCTEONTX2 + help + You must select Y to enable SMI controller support for + OcteonTX or OcteonTX2 SoCs. If unsure, say n + config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver" depends on DM_ETH && DM_PCI diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 1ecdc40b8f..bee9680f76 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -65,6 +65,8 @@ obj-$(CONFIG_RENESAS_RAVB) += ravb.o obj-$(CONFIG_SMC91111) += smc91111.o obj-$(CONFIG_SMC911X) += smc911x.o obj-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o +obj-$(CONFIG_NET_OCTEONTX) += octeontx/ +obj-$(CONFIG_OCTEONTX_SMI) += octeontx/smi.o obj-$(CONFIG_FMAN_ENET) += fsl_mdio.o obj-$(CONFIG_ULI526X) += uli526x.o obj-$(CONFIG_VSC7385_ENET) += vsc7385.o diff --git a/drivers/net/octeontx/Makefile b/drivers/net/octeontx/Makefile new file mode 100644 index 0000000000..170f1f41cd --- /dev/null +++ b/drivers/net/octeontx/Makefile @@ -0,0 +1,9 @@ +#/* SPDX-License-Identifier: GPL-2.0 +# * +# * Copyright (C) 2018 Marvell International Ltd. +# * +# * https://spdx.org/licenses +# */ + +obj-$(CONFIG_NET_OCTEONTX) += bgx.o nic_main.o nicvf_queues.o nicvf_main.o \ + xcv.o diff --git a/drivers/net/octeontx/bgx.c b/drivers/net/octeontx/bgx.c new file mode 100644 index 0000000000..e08ca71058 --- /dev/null +++ b/drivers/net/octeontx/bgx.c @@ -0,0 +1,1572 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <config.h> +#include <common.h> +#include <errno.h> +#include <net.h> +#include <dm.h> +#include <pci.h> +#include <pci_ids.h> +#include <misc.h> +#include <netdev.h> +#include <malloc.h> +#include <miiphy.h> +#include <asm/io.h> +#include <asm/arch/board.h> + +#ifdef CONFIG_OF_LIBFDT + #include <linux/libfdt.h> + #include <fdt_support.h> +#endif + +#include "nic_reg.h" +#include "nic.h" +#include "bgx.h" + +static const phy_interface_t if_mode[] = { + [QLM_MODE_SGMII] = PHY_INTERFACE_MODE_SGMII, + [QLM_MODE_RGMII] = PHY_INTERFACE_MODE_RGMII, + [QLM_MODE_QSGMII] = PHY_INTERFACE_MODE_QSGMII, + [QLM_MODE_XAUI] = PHY_INTERFACE_MODE_XAUI, + [QLM_MODE_RXAUI] = PHY_INTERFACE_MODE_RXAUI, +}; + +struct lmac { + struct bgx *bgx; + int dmac; + u8 mac[6]; + bool link_up; + bool init_pend; + int lmacid; /* ID within BGX */ + int phy_addr; /* ID on board */ + struct udevice *dev; + struct mii_dev *mii_bus; + struct phy_device *phydev; + unsigned int last_duplex; + unsigned int last_link; + unsigned int last_speed; + int lane_to_sds; + int use_training; + int lmac_type; + u8 qlm_mode; + int qlm; + bool is_1gx; +}; + +struct bgx { + u8 bgx_id; + int node; + struct lmac lmac[MAX_LMAC_PER_BGX]; + int lmac_count; + u8 max_lmac; + void __iomem *reg_base; + struct pci_dev *pdev; + bool is_rgx; +}; + +struct bgx_board_info bgx_board_info[MAX_BGX_PER_NODE]; + +struct bgx *bgx_vnic[MAX_BGX_PER_NODE]; +extern int rxaui_phy_xs_init(struct mii_dev *bus, int phy_addr); + +/* APIs to read/write BGXX CSRs */ +static u64 bgx_reg_read(struct bgx *bgx, uint8_t lmac, u64 offset) +{ + u64 addr = (uintptr_t)bgx->reg_base + + ((uint32_t)lmac << 20) + offset; + + return readq((void *)addr); +} + +static void bgx_reg_write(struct bgx *bgx, uint8_t lmac, + u64 offset, u64 val) +{ + u64 addr = (uintptr_t)bgx->reg_base + + ((uint32_t)lmac << 20) + offset; + + writeq(val, (void *)addr); +} + +static void bgx_reg_modify(struct bgx *bgx, uint8_t lmac, + u64 offset, u64 val) +{ + u64 addr = (uintptr_t)bgx->reg_base + + ((uint32_t)lmac << 20) + offset; + + writeq(val | bgx_reg_read(bgx, lmac, offset), (void *)addr); +} + +static int bgx_poll_reg(struct bgx *bgx, uint8_t lmac, + u64 reg, u64 mask, bool zero) +{ + int timeout = 200; + u64 reg_val; + + while (timeout) { + reg_val = bgx_reg_read(bgx, lmac, reg); + if (zero && !(reg_val & mask)) + return 0; + if (!zero && (reg_val & mask)) + return 0; + mdelay(1); + timeout--; + } + return 1; +} + +static int gser_poll_reg(u64 reg, int bit, u64 mask, u64 expected_val, + int timeout) +{ + u64 reg_val; + + debug("%s reg = %#llx, mask = %#llx,", __func__, reg, mask); + debug(" expected_val = %#llx, bit = %d\n", expected_val, bit); + while (timeout) { + reg_val = readq(reg) >> bit; + if ((reg_val & mask) == (expected_val)) + return 0; + mdelay(1); + timeout--; + } + return 1; +} + +static bool is_bgx_port_valid(int bgx, int lmac) +{ + debug("%s bgx %d lmac %d valid %d\n", __func__, bgx, lmac, + bgx_board_info[bgx].lmac_reg[lmac]); + + if (bgx_board_info[bgx].lmac_reg[lmac]) + return 1; + else + return 0; +} + +struct lmac *bgx_get_lmac(int node, int bgx_idx, int lmacid) +{ + struct bgx *bgx = bgx_vnic[(node * MAX_BGX_PER_NODE) + bgx_idx]; + + if (bgx) + return &bgx->lmac[lmacid]; + + return NULL; +} + +const u8 *bgx_get_lmac_mac(int node, int bgx_idx, int lmacid) +{ + struct bgx *bgx = bgx_vnic[(node * MAX_BGX_PER_NODE) + bgx_idx]; + + if (bgx) + return bgx->lmac[lmacid].mac; + + return NULL; +} + +void bgx_set_lmac_mac(int node, int bgx_idx, int lmacid, const u8 *mac) +{ + struct bgx *bgx = bgx_vnic[(node * MAX_BGX_PER_NODE) + bgx_idx]; + + if (!bgx) + return; + + memcpy(bgx->lmac[lmacid].mac, mac, 6); +} + +/* Return number of BGX present in HW */ +void bgx_get_count(int node, int *bgx_count) +{ + int i; + struct bgx *bgx; + + *bgx_count = 0; + for (i = 0; i < MAX_BGX_PER_NODE; i++) { + bgx = bgx_vnic[node * MAX_BGX_PER_NODE + i]; + debug("bgx_vnic[%u]: %p\n", node * MAX_BGX_PER_NODE + i, + bgx); + if (bgx) + *bgx_count |= (1 << i); + } +} + +/* Return number of LMAC configured for this BGX */ +int bgx_get_lmac_count(int node, int bgx_idx) +{ + struct bgx *bgx; + + bgx = bgx_vnic[(node * MAX_BGX_PER_NODE) + bgx_idx]; + if (bgx) + return bgx->lmac_count; + + return 0; +} + +void bgx_lmac_rx_tx_enable(int node, int bgx_idx, int lmacid, bool enable) +{ + struct bgx *bgx = bgx_vnic[(node * MAX_BGX_PER_NODE) + bgx_idx]; + u64 cfg; + + if (!bgx) + return; + + cfg = bgx_reg_read(bgx, lmacid, BGX_CMRX_CFG); + if (enable) + cfg |= CMR_PKT_RX_EN | CMR_PKT_TX_EN; + else + cfg &= ~(CMR_PKT_RX_EN | CMR_PKT_TX_EN); + bgx_reg_write(bgx, lmacid, BGX_CMRX_CFG, cfg); +} + +static void bgx_flush_dmac_addrs(struct bgx *bgx, u64 lmac) +{ + u64 dmac = 0x00; + u64 offset, addr; + + while (bgx->lmac[lmac].dmac > 0) { + offset = ((bgx->lmac[lmac].dmac - 1) * sizeof(dmac)) + + (lmac * MAX_DMAC_PER_LMAC * sizeof(dmac)); + addr = (uintptr_t)bgx->reg_base + + BGX_CMR_RX_DMACX_CAM + offset; + writeq(dmac, (void *)addr); + bgx->lmac[lmac].dmac--; + } +} + +/* Configure BGX LMAC in internal loopback mode */ +void bgx_lmac_internal_loopback(int node, int bgx_idx, + int lmac_idx, bool enable) +{ + struct bgx *bgx; + struct lmac *lmac; + u64 cfg; + + bgx = bgx_vnic[(node * MAX_BGX_PER_NODE) + bgx_idx]; + if (!bgx) + return; + + lmac = &bgx->lmac[lmac_idx]; + if (lmac->qlm_mode == QLM_MODE_SGMII) { + cfg = bgx_reg_read(bgx, lmac_idx, BGX_GMP_PCS_MRX_CTL); + if (enable) + cfg |= PCS_MRX_CTL_LOOPBACK1; + else + cfg &= ~PCS_MRX_CTL_LOOPBACK1; + bgx_reg_write(bgx, lmac_idx, BGX_GMP_PCS_MRX_CTL, cfg); + } else { + cfg = bgx_reg_read(bgx, lmac_idx, BGX_SPUX_CONTROL1); + if (enable) + cfg |= SPU_CTL_LOOPBACK; + else + cfg &= ~SPU_CTL_LOOPBACK; + bgx_reg_write(bgx, lmac_idx, BGX_SPUX_CONTROL1, cfg); + } +} + +/* Return the DLM used for the BGX */ +static int get_qlm_for_bgx(int node, int bgx_id, int index) +{ + int qlm = 0; + u64 cfg; + + if (otx_is_soc(CN81XX)) { + qlm = (bgx_id) ? 2 : 0; + qlm += (index >= 2) ? 1 : 0; + } else if (otx_is_soc(CN83XX)) { + switch (bgx_id) { + case 0: + qlm = 2; + break; + case 1: + qlm = 3; + break; + case 2: + if (index >= 2) + qlm = 6; + else + qlm = 5; + break; + case 3: + qlm = 4; + break; + } + } + + cfg = readq(GSERX_CFG(qlm)) & GSERX_CFG_BGX; + debug("%s:qlm%d: cfg = %lld\n", __func__, qlm, cfg); + + /* Check if DLM is configured as BGX# */ + if (cfg) { + if (readq(GSERX_PHY_CTL(qlm))) + return -1; + return qlm; + } + return -1; +} + +static int bgx_lmac_sgmii_init(struct bgx *bgx, int lmacid) +{ + u64 cfg; + struct lmac *lmac; + + lmac = &bgx->lmac[lmacid]; + + debug("%s:bgx_id = %d, lmacid = %d\n", __func__, bgx->bgx_id, lmacid); + + bgx_reg_modify(bgx, lmacid, BGX_GMP_GMI_TXX_THRESH, 0x30); + /* max packet size */ + bgx_reg_modify(bgx, lmacid, BGX_GMP_GMI_RXX_JABBER, MAX_FRAME_SIZE); + + /* Disable frame alignment if using preamble */ + cfg = bgx_reg_read(bgx, lmacid, BGX_GMP_GMI_TXX_APPEND); + if (cfg & 1) + bgx_reg_write(bgx, lmacid, BGX_GMP_GMI_TXX_SGMII_CTL, 0); + + /* Enable lmac */ + bgx_reg_modify(bgx, lmacid, BGX_CMRX_CFG, CMR_EN); + + /* PCS reset */ + bgx_reg_modify(bgx, lmacid, BGX_GMP_PCS_MRX_CTL, PCS_MRX_CTL_RESET); + if (bgx_poll_reg(bgx, lmacid, BGX_GMP_PCS_MRX_CTL, + PCS_MRX_CTL_RESET, true)) { + printf("BGX PCS reset not completed\n"); + return -1; + } + + /* power down, reset autoneg, autoneg enable */ + cfg = bgx_reg_read(bgx, lmacid, BGX_GMP_PCS_MRX_CTL); + cfg &= ~PCS_MRX_CTL_PWR_DN; + + if (bgx_board_info[bgx->bgx_id].phy_info[lmacid].autoneg_dis) + cfg |= (PCS_MRX_CTL_RST_AN); + else + cfg |= (PCS_MRX_CTL_RST_AN | PCS_MRX_CTL_AN_EN); + bgx_reg_write(bgx, lmacid, BGX_GMP_PCS_MRX_CTL, cfg); + + /* Disable disparity for QSGMII mode, to prevent propogation across + * ports. + */ + + if (lmac->qlm_mode == QLM_MODE_QSGMII) { + cfg = bgx_reg_read(bgx, lmacid, BGX_GMP_PCS_MISCX_CTL); + cfg &= ~PCS_MISCX_CTL_DISP_EN; + bgx_reg_write(bgx, lmacid, BGX_GMP_PCS_MISCX_CTL, cfg); + return 0; /* Skip checking AN_CPT */ + } + + if (lmac->is_1gx) { + cfg = bgx_reg_read(bgx, lmacid, BGX_GMP_PCS_MISCX_CTL); + cfg |= PCS_MISC_CTL_MODE; + bgx_reg_write(bgx, lmacid, BGX_GMP_PCS_MISCX_CTL, cfg); + } + + if (lmac->qlm_mode == QLM_MODE_SGMII) { + if (bgx_poll_reg(bgx, lmacid, BGX_GMP_PCS_MRX_STATUS, + PCS_MRX_STATUS_AN_CPT, false)) { + printf("BGX AN_CPT not completed\n"); + return -1; + } + } + + return 0; +} + +static int bgx_lmac_sgmii_set_link_speed(struct lmac *lmac) +{ + u64 prtx_cfg; + u64 pcs_miscx_ctl; + u64 cfg; + struct bgx *bgx = lmac->bgx; + unsigned int lmacid = lmac->lmacid; + + debug("%s: lmacid %d\n", __func__, lmac->lmacid); + + /* Disable LMAC before setting up speed */ + cfg = bgx_reg_read(bgx, lmacid, BGX_CMRX_CFG); + cfg &= ~CMR_EN; + bgx_reg_write(bgx, lmacid, BGX_CMRX_CFG, cfg); + + /* Read GMX CFG */ + prtx_cfg = bgx_reg_read(bgx, lmacid, + BGX_GMP_GMI_PRTX_CFG); + /* Read PCS MISCS CTL */ + pcs_miscx_ctl = bgx_reg_read(bgx, lmacid, + BGX_GMP_PCS_MISCX_CTL); + + /* Use GMXENO to force the link down*/ + if (lmac->link_up) { + pcs_miscx_ctl &= ~PCS_MISC_CTL_GMX_ENO; + /* change the duplex setting if the link is up */ + prtx_cfg |= GMI_PORT_CFG_DUPLEX; + } else { + pcs_miscx_ctl |= PCS_MISC_CTL_GMX_ENO; + } + + /* speed based setting for GMX */ + switch (lmac->last_speed) { + case 10: + prtx_cfg &= ~GMI_PORT_CFG_SPEED; + prtx_cfg |= GMI_PORT_CFG_SPEED_MSB; + prtx_cfg &= ~GMI_PORT_CFG_SLOT_TIME; + pcs_miscx_ctl |= 50; /* sampling point */ + bgx_reg_write(bgx, lmacid, BGX_GMP_GMI_TXX_SLOT, 0x40); + bgx_reg_write(bgx, lmacid, BGX_GMP_GMI_TXX_BURST, 0); + break; + case 100: + prtx_cfg &= ~GMI_PORT_CFG_SPEED; + prtx_cfg &= ~GMI_PORT_CFG_SPEED_MSB; + prtx_cfg &= ~GMI_PORT_CFG_SLOT_TIME; + pcs_miscx_ctl |= 0x5; /* sampling point */ + bgx_reg_write(bgx, lmacid, BGX_GMP_GMI_TXX_SLOT, 0x40); + bgx_reg_write(bgx, lmacid, BGX_GMP_GMI_TXX_BURST, 0); + break; + case 1000: + prtx_cfg |= GMI_PORT_CFG_SPEED; + prtx_cfg &= ~GMI_PORT_CFG_SPEED_MSB; + prtx_cfg |= GMI_PORT_CFG_SLOT_TIME; + pcs_miscx_ctl |= 0x1; /* sampling point */ + bgx_reg_write(bgx, lmacid, BGX_GMP_GMI_TXX_SLOT, 0x200); + if (lmac->last_duplex) + bgx_reg_write(bgx, lmacid, BGX_GMP_GMI_TXX_BURST, 0); + else /* half duplex */ + bgx_reg_write(bgx, lmacid, BGX_GMP_GMI_TXX_BURST, + 0x2000); + break; + default: + break; + } + + /* write back the new PCS misc and GMX settings */ + bgx_reg_write(bgx, lmacid, BGX_GMP_PCS_MISCX_CTL, pcs_miscx_ctl); + bgx_reg_write(bgx, lmacid, BGX_GMP_GMI_PRTX_CFG, prtx_cfg); + + /* read back GMX CFG again to check config completion */ + bgx_reg_read(bgx, lmacid, BGX_GMP_GMI_PRTX_CFG); + + /* enable BGX back */ + cfg = bgx_reg_read(bgx, lmacid, BGX_CMRX_CFG); + cfg |= CMR_EN; + bgx_reg_write(bgx, lmacid, BGX_CMRX_CFG, cfg); + + return 0; +} + +static int bgx_lmac_xaui_init(struct bgx *bgx, int lmacid, int lmac_type) +{ + u64 cfg; + struct lmac *lmac; + + lmac = &bgx->lmac[lmacid]; + + /* Reset SPU */ + bgx_reg_modify(bgx, lmacid, BGX_SPUX_CONTROL1, SPU_CTL_RESET); + if (bgx_poll_reg(bgx, lmacid, BGX_SPUX_CONTROL1, SPU_CTL_RESET, true)) { + printf("BGX SPU reset not completed\n"); + return -1; + } + + /* Disable LMAC */ + cfg = bgx_reg_read(bgx, lmacid, BGX_CMRX_CFG); + cfg &= ~CMR_EN; + bgx_reg_write(bgx, lmacid, BGX_CMRX_CFG, cfg); + + bgx_reg_modify(bgx, lmacid, BGX_SPUX_CONTROL1, SPU_CTL_LOW_POWER); + /* Set interleaved running disparity for RXAUI */ + if (lmac->qlm_mode != QLM_MODE_RXAUI) + bgx_reg_modify(bgx, lmacid, + BGX_SPUX_MISC_CONTROL, SPU_MISC_CTL_RX_DIS); + else + bgx_reg_modify(bgx, lmacid, BGX_SPUX_MISC_CONTROL, + SPU_MISC_CTL_RX_DIS | SPU_MISC_CTL_INTLV_RDISP); + + /* clear all interrupts */ + cfg = bgx_reg_read(bgx, lmacid, BGX_SMUX_RX_INT); + bgx_reg_write(bgx, lmacid, BGX_SMUX_RX_INT, cfg); + cfg = bgx_reg_read(bgx, lmacid, BGX_SMUX_TX_INT); + bgx_reg_write(bgx, lmacid, BGX_SMUX_TX_INT, cfg); + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_INT); + bgx_reg_write(bgx, lmacid, BGX_SPUX_INT, cfg); + + if (lmac->use_training) { + bgx_reg_write(bgx, lmacid, BGX_SPUX_BR_PMD_LP_CUP, 0x00); + bgx_reg_write(bgx, lmacid, BGX_SPUX_BR_PMD_LD_CUP, 0x00); + bgx_reg_write(bgx, lmacid, BGX_SPUX_BR_PMD_LD_REP, 0x00); + /* training enable */ + bgx_reg_modify(bgx, lmacid, + BGX_SPUX_BR_PMD_CRTL, SPU_PMD_CRTL_TRAIN_EN); + } + + /* Append FCS to each packet */ + bgx_reg_modify(bgx, lmacid, BGX_SMUX_TX_APPEND, SMU_TX_APPEND_FCS_D); + + /* Disable forward error correction */ + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_FEC_CONTROL); + cfg &= ~SPU_FEC_CTL_FEC_EN; + bgx_reg_write(bgx, lmacid, BGX_SPUX_FEC_CONTROL, cfg); + + /* Disable autoneg */ + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_AN_CONTROL); + cfg = cfg & ~(SPU_AN_CTL_XNP_EN); + if (lmac->use_training) + cfg = cfg | (SPU_AN_CTL_AN_EN); + else + cfg = cfg & ~(SPU_AN_CTL_AN_EN); + bgx_reg_write(bgx, lmacid, BGX_SPUX_AN_CONTROL, cfg); + + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_AN_ADV); + /* Clear all KR bits, configure according to the mode */ + cfg &= ~((0xfULL << 22) | (1ULL << 12)); + if (lmac->qlm_mode == QLM_MODE_10G_KR) + cfg |= (1 << 23); + else if (lmac->qlm_mode == QLM_MODE_40G_KR4) + cfg |= (1 << 24); + bgx_reg_write(bgx, lmacid, BGX_SPUX_AN_ADV, cfg); + + cfg = bgx_reg_read(bgx, 0, BGX_SPU_DBG_CONTROL); + if (lmac->use_training) + cfg |= SPU_DBG_CTL_AN_ARB_LINK_CHK_EN; + else + cfg &= ~SPU_DBG_CTL_AN_ARB_LINK_CHK_EN; + bgx_reg_write(bgx, 0, BGX_SPU_DBG_CONTROL, cfg); + + /* Enable lmac */ + bgx_reg_modify(bgx, lmacid, BGX_CMRX_CFG, CMR_EN); + + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_CONTROL1); + cfg &= ~SPU_CTL_LOW_POWER; + bgx_reg_write(bgx, lmacid, BGX_SPUX_CONTROL1, cfg); + + cfg = bgx_reg_read(bgx, lmacid, BGX_SMUX_TX_CTL); + cfg &= ~SMU_TX_CTL_UNI_EN; + cfg |= SMU_TX_CTL_DIC_EN; + bgx_reg_write(bgx, lmacid, BGX_SMUX_TX_CTL, cfg); + + /* take lmac_count into account */ + bgx_reg_modify(bgx, lmacid, BGX_SMUX_TX_THRESH, (0x100 - 1)); + /* max packet size */ + bgx_reg_modify(bgx, lmacid, BGX_SMUX_RX_JABBER, MAX_FRAME_SIZE); + + debug("xaui_init: lmacid = %d, qlm = %d, qlm_mode = %d\n", + lmacid, lmac->qlm, lmac->qlm_mode); + /* RXAUI with Marvell PHY requires some tweaking */ + if (lmac->qlm_mode == QLM_MODE_RXAUI) { + char mii_name[20]; + struct phy_info *phy; + + phy = &bgx_board_info[bgx->bgx_id].phy_info[lmacid]; + snprintf(mii_name, sizeof(mii_name), "smi%d", phy->mdio_bus); + + debug("mii_name: %s\n", mii_name); + lmac->mii_bus = miiphy_get_dev_by_name(mii_name); + lmac->phy_addr = phy->phy_addr; + rxaui_phy_xs_init(lmac->mii_bus, lmac->phy_addr); + } + + return 0; +} + +/* Get max number of lanes present in a given QLM/DLM */ +static int get_qlm_lanes(int qlm) +{ + if (otx_is_soc(CN81XX)) + return 2; + else if (otx_is_soc(CN83XX)) + return (qlm >= 5) ? 2 : 4; + else + return -1; +} + +int __rx_equalization(int qlm, int lane) +{ + int max_lanes = get_qlm_lanes(qlm); + int l; + int fail = 0; + + /* Before completing Rx equalization wait for + * GSERx_RX_EIE_DETSTS[CDRLOCK] to be set + * This ensures the rx data is valid + */ + if (lane == -1) { + if (gser_poll_reg(GSER_RX_EIE_DETSTS(qlm), GSER_CDRLOCK, 0xf, + (1 << max_lanes) - 1, 100)) { + debug("ERROR: CDR Lock not detected"); + debug(" on DLM%d for 2 lanes\n", qlm); + return -1; + } + } else { + if (gser_poll_reg(GSER_RX_EIE_DETSTS(qlm), GSER_CDRLOCK, + (0xf & (1 << lane)), (1 << lane), 100)) { + debug("ERROR: DLM%d: CDR Lock not detected", qlm); + debug(" on %d lane\n", lane); + return -1; + } + } + + for (l = 0; l < max_lanes; l++) { + u64 rctl, reer; + + if (lane != -1 && lane != l) + continue; + + /* Enable software control */ + rctl = readq(GSER_BR_RXX_CTL(qlm, l)); + rctl |= GSER_BR_RXX_CTL_RXT_SWM; + writeq(rctl, GSER_BR_RXX_CTL(qlm, l)); + + /* Clear the completion flag and initiate a new request */ + reer = readq(GSER_BR_RXX_EER(qlm, l)); + reer &= ~GSER_BR_RXX_EER_RXT_ESV; + reer |= GSER_BR_RXX_EER_RXT_EER; + writeq(reer, GSER_BR_RXX_EER(qlm, l)); + } + + /* Wait for RX equalization to complete */ + for (l = 0; l < max_lanes; l++) { + u64 rctl, reer; + + if (lane != -1 && lane != l) + continue; + + gser_poll_reg(GSER_BR_RXX_EER(qlm, l), EER_RXT_ESV, 1, 1, 200); + reer = readq(GSER_BR_RXX_EER(qlm, l)); + + /* Switch back to hardware control */ + rctl = readq(GSER_BR_RXX_CTL(qlm, l)); + rctl &= ~GSER_BR_RXX_CTL_RXT_SWM; + writeq(rctl, GSER_BR_RXX_CTL(qlm, l)); + + if (reer & GSER_BR_RXX_EER_RXT_ESV) { + debug("Rx equalization completed on DLM%d", qlm); + debug(" QLM%d rxt_esm = 0x%llx\n", l, (reer & 0x3fff)); + } else { + debug("Rx equalization timedout on DLM%d", qlm); + debug(" lane %d\n", l); + fail = 1; + } + } + + return (fail) ? -1 : 0; +} + +static int bgx_xaui_check_link(struct lmac *lmac) +{ + struct bgx *bgx = lmac->bgx; + int lmacid = lmac->lmacid; + int lmac_type = lmac->lmac_type; + u64 cfg; + + bgx_reg_modify(bgx, lmacid, BGX_SPUX_MISC_CONTROL, SPU_MISC_CTL_RX_DIS); + + /* check if auto negotiation is complete */ + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_AN_CONTROL); + if (cfg & SPU_AN_CTL_AN_EN) { + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_AN_STATUS); + if (!(cfg & SPU_AN_STS_AN_COMPLETE)) { + /* Restart autonegotiation */ + debug("restarting auto-neg\n"); + bgx_reg_modify(bgx, lmacid, BGX_SPUX_AN_CONTROL, + SPU_AN_CTL_AN_RESTART); + return -1; + } + } + + debug("%s link use_training %d\n", __func__, lmac->use_training); + if (lmac->use_training) { + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_INT); + if (!(cfg & (1ull << 13))) { + debug("waiting for link training\n"); + /* Clear the training interrupts (W1C) */ + cfg = (1ull << 13) | (1ull << 14); + bgx_reg_write(bgx, lmacid, BGX_SPUX_INT, cfg); + + udelay(2000); + /* Restart training */ + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_BR_PMD_CRTL); + cfg |= (1ull << 0); + bgx_reg_write(bgx, lmacid, BGX_SPUX_BR_PMD_CRTL, cfg); + return -1; + } + } + + /* Perform RX Equalization. Applies to non-KR interfaces for speeds + * >= 6.25Gbps. + */ + if (!lmac->use_training) { + int qlm; + bool use_dlm = 0; + + if (otx_is_soc(CN81XX) || (otx_is_soc(CN83XX) && + bgx->bgx_id == 2)) + use_dlm = 1; + switch (lmac->lmac_type) { + default: + case BGX_MODE_SGMII: + case BGX_MODE_RGMII: + case BGX_MODE_XAUI: + /* Nothing to do */ + break; + case BGX_MODE_XLAUI: + if (use_dlm) { + if (__rx_equalization(lmac->qlm, -1) || + __rx_equalization(lmac->qlm + 1, -1)) { + printf("BGX%d:%d", bgx->bgx_id, lmacid); + printf(" Waiting for RX Equalization"); + printf(" on DLM%d/DLM%d\n", + lmac->qlm, lmac->qlm + 1); + return -1; + } + } else { + if (__rx_equalization(lmac->qlm, -1)) { + printf("BGX%d:%d", bgx->bgx_id, lmacid); + printf(" Waiting for RX Equalization"); + printf(" on QLM%d\n", lmac->qlm); + return -1; + } + } + break; + case BGX_MODE_RXAUI: + /* RXAUI0 uses LMAC0:QLM0/QLM2 and RXAUI1 uses + * LMAC1:QLM1/QLM3 RXAUI requires 2 lanes + * for each interface + */ + qlm = lmac->qlm; + if (__rx_equalization(qlm, 0)) { + printf("BGX%d:%d", bgx->bgx_id, lmacid); + printf(" Waiting for RX Equalization"); + printf(" on QLM%d, Lane0\n", qlm); + return -1; + } + if (__rx_equalization(qlm, 1)) { + printf("BGX%d:%d", bgx->bgx_id, lmacid); + printf(" Waiting for RX Equalization"); + printf(" on QLM%d, Lane1\n", qlm); + return -1; + } + break; + case BGX_MODE_XFI: + { + int lid; + bool altpkg = otx_is_altpkg(); + + if (bgx->bgx_id == 0 && altpkg && lmacid) + lid = 0; + else if ((lmacid >= 2) && use_dlm) + lid = lmacid - 2; + else + lid = lmacid; + + if (__rx_equalization(lmac->qlm, lid)) { + printf("BGX%d:%d", bgx->bgx_id, lid); + printf(" Waiting for RX Equalization"); + printf(" on QLM%d\n", lmac->qlm); + } + } + break; + } + } + + /* wait for PCS to come out of reset */ + if (bgx_poll_reg(bgx, lmacid, BGX_SPUX_CONTROL1, SPU_CTL_RESET, true)) { + printf("BGX SPU reset not completed\n"); + return -1; + } + + if (lmac_type == 3 || lmac_type == 4) { + if (bgx_poll_reg(bgx, lmacid, BGX_SPUX_BR_STATUS1, + SPU_BR_STATUS_BLK_LOCK, false)) { + printf("SPU_BR_STATUS_BLK_LOCK not completed\n"); + return -1; + } + } else { + if (bgx_poll_reg(bgx, lmacid, BGX_SPUX_BX_STATUS, + SPU_BX_STATUS_RX_ALIGN, false)) { + printf("SPU_BX_STATUS_RX_ALIGN not completed\n"); + return -1; + } + } + + /* Clear rcvflt bit (latching high) and read it back */ + bgx_reg_modify(bgx, lmacid, BGX_SPUX_STATUS2, SPU_STATUS2_RCVFLT); + if (bgx_reg_read(bgx, lmacid, BGX_SPUX_STATUS2) & SPU_STATUS2_RCVFLT) { + printf("Receive fault, retry training\n"); + if (lmac->use_training) { + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_INT); + if (!(cfg & (1ull << 13))) { + cfg = (1ull << 13) | (1ull << 14); + bgx_reg_write(bgx, lmacid, BGX_SPUX_INT, cfg); + cfg = bgx_reg_read(bgx, lmacid, + BGX_SPUX_BR_PMD_CRTL); + cfg |= (1ull << 0); + bgx_reg_write(bgx, lmacid, + BGX_SPUX_BR_PMD_CRTL, cfg); + return -1; + } + } + return -1; + } + + /* Wait for MAC RX to be ready */ + if (bgx_poll_reg(bgx, lmacid, BGX_SMUX_RX_CTL, + SMU_RX_CTL_STATUS, true)) { + printf("SMU RX link not okay\n"); + return -1; + } + + /* Wait for BGX RX to be idle */ + if (bgx_poll_reg(bgx, lmacid, BGX_SMUX_CTL, SMU_CTL_RX_IDLE, false)) { + printf("SMU RX not idle\n"); + return -1; + } + + /* Wait for BGX TX to be idle */ + if (bgx_poll_reg(bgx, lmacid, BGX_SMUX_CTL, SMU_CTL_TX_IDLE, false)) { + printf("SMU TX not idle\n"); + return -1; + } + + if (bgx_reg_read(bgx, lmacid, BGX_SPUX_STATUS2) & SPU_STATUS2_RCVFLT) { + printf("Receive fault\n"); + return -1; + } + + /* Receive link is latching low. Force it high and verify it */ + if (!(bgx_reg_read(bgx, lmacid, BGX_SPUX_STATUS1) & + SPU_STATUS1_RCV_LNK)) + bgx_reg_modify(bgx, lmacid, BGX_SPUX_STATUS1, + SPU_STATUS1_RCV_LNK); + if (bgx_poll_reg(bgx, lmacid, BGX_SPUX_STATUS1, + SPU_STATUS1_RCV_LNK, false)) { + printf("SPU receive link down\n"); + return -1; + } + + cfg = bgx_reg_read(bgx, lmacid, BGX_SPUX_MISC_CONTROL); + cfg &= ~SPU_MISC_CTL_RX_DIS; + bgx_reg_write(bgx, lmacid, BGX_SPUX_MISC_CONTROL, cfg); + return 0; +} + +static int bgx_lmac_enable(struct bgx *bgx, int8_t lmacid) +{ + struct lmac *lmac; + u64 cfg; + + lmac = &bgx->lmac[lmacid]; + + debug("%s: lmac: %p, lmacid = %d\n", __func__, lmac, lmacid); + + if (lmac->qlm_mode == QLM_MODE_SGMII || + lmac->qlm_mode == QLM_MODE_RGMII || + lmac->qlm_mode == QLM_MODE_QSGMII) { + if (bgx_lmac_sgmii_init(bgx, lmacid)) { + debug("bgx_lmac_sgmii_init failed\n"); + return -1; + } + cfg = bgx_reg_read(bgx, lmacid, BGX_GMP_GMI_TXX_APPEND); + cfg |= ((1ull << 2) | (1ull << 1)); /* FCS and PAD */ + bgx_reg_modify(bgx, lmacid, BGX_GMP_GMI_TXX_APPEND, cfg); + bgx_reg_write(bgx, lmacid, BGX_GMP_GMI_TXX_MIN_PKT, 60 - 1); + } else { + if (bgx_lmac_xaui_init(bgx, lmacid, lmac->lmac_type)) + return -1; + cfg = bgx_reg_read(bgx, lmacid, BGX_SMUX_TX_APPEND); + cfg |= ((1ull << 2) | (1ull << 1)); /* FCS and PAD */ + bgx_reg_modify(bgx, lmacid, BGX_SMUX_TX_APPEND, cfg); + bgx_reg_write(bgx, lmacid, BGX_SMUX_TX_MIN_PKT, 60 + 4); + } + + /* Enable lmac */ + bgx_reg_modify(bgx, lmacid, BGX_CMRX_CFG, + CMR_EN | CMR_PKT_RX_EN | CMR_PKT_TX_EN); + + return 0; +} + +int bgx_poll_for_link(int node, int bgx_idx, int lmacid) +{ + int ret; + struct lmac *lmac = bgx_get_lmac(node, bgx_idx, lmacid); + char mii_name[10]; + struct phy_info *phy; + + if (!lmac) { + printf("LMAC %d/%d/%d is disabled or doesn't exist\n", + node, bgx_idx, lmacid); + return 0; + } + + debug("%s: %d, lmac: %d/%d/%d %p\n", + __FILE__, __LINE__, + node, bgx_idx, lmacid, lmac); + if (lmac->init_pend) { + ret = bgx_lmac_enable(lmac->bgx, lmacid); + if (ret < 0) { + printf("BGX%d LMAC%d lmac_enable failed\n", bgx_idx, + lmacid); + return ret; + } + lmac->init_pend = 0; + mdelay(100); + } + if (lmac->qlm_mode == QLM_MODE_SGMII || + lmac->qlm_mode == QLM_MODE_RGMII || + lmac->qlm_mode == QLM_MODE_QSGMII) { + if (bgx_board_info[bgx_idx].phy_info[lmacid].phy_addr == -1) { + lmac->link_up = 1; + lmac->last_speed = 1000; + lmac->last_duplex = 1; + printf("BGX%d:LMAC %u link up\n", bgx_idx, lmacid); + return lmac->link_up; + } + snprintf(mii_name, sizeof(mii_name), "smi%d", + bgx_board_info[bgx_idx].phy_info[lmacid].mdio_bus); + + debug("mii_name: %s\n", mii_name); + + lmac->mii_bus = miiphy_get_dev_by_name(mii_name); + phy = &bgx_board_info[bgx_idx].phy_info[lmacid]; + lmac->phy_addr = phy->phy_addr; + + debug("lmac->mii_bus: %p\n", lmac->mii_bus); + if (!lmac->mii_bus) { + printf("MDIO device %s not found\n", mii_name); + ret = -ENODEV; + return ret; + } + + lmac->phydev = phy_connect(lmac->mii_bus, lmac->phy_addr, + lmac->dev, + if_mode[lmac->qlm_mode]); + + if (!lmac->phydev) { + printf("%s: No PHY device\n", __func__); + return -1; + } + + ret = phy_config(lmac->phydev); + if (ret) { + printf("%s: Could not initialize PHY %s\n", + __func__, lmac->phydev->dev->name); + return ret; + } + + ret = phy_startup(lmac->phydev); + debug("%s: %d\n", __FILE__, __LINE__); + if (ret) { + printf("%s: Could not initialize PHY %s\n", + __func__, lmac->phydev->dev->name); + } + +#ifdef OCTEONTX_XCV + if (lmac->qlm_mode == QLM_MODE_RGMII) + xcv_setup_link(lmac->phydev->link, lmac->phydev->speed); +#endif + + lmac->link_up = lmac->phydev->link; + lmac->last_speed = lmac->phydev->speed; + lmac->last_duplex = lmac->phydev->duplex; + + debug("%s qlm_mode %d phy link status 0x%x,last speed 0x%x,", + __func__, lmac->qlm_mode, lmac->link_up, + lmac->last_speed); + debug(" duplex 0x%x\n", lmac->last_duplex); + + if (lmac->qlm_mode != QLM_MODE_RGMII) + bgx_lmac_sgmii_set_link_speed(lmac); + + } else { + u64 status1; + u64 tx_ctl; + u64 rx_ctl; + + status1 = bgx_reg_read(lmac->bgx, lmac->lmacid, + BGX_SPUX_STATUS1); + tx_ctl = bgx_reg_read(lmac->bgx, lmac->lmacid, BGX_SMUX_TX_CTL); + rx_ctl = bgx_reg_read(lmac->bgx, lmac->lmacid, BGX_SMUX_RX_CTL); + + debug("BGX%d LMAC%d BGX_SPUX_STATUS2: %lx\n", bgx_idx, lmacid, + (unsigned long)bgx_reg_read(lmac->bgx, lmac->lmacid, + BGX_SPUX_STATUS2)); + debug("BGX%d LMAC%d BGX_SPUX_STATUS1: %lx\n", bgx_idx, lmacid, + (unsigned long)bgx_reg_read(lmac->bgx, lmac->lmacid, + BGX_SPUX_STATUS1)); + debug("BGX%d LMAC%d BGX_SMUX_RX_CTL: %lx\n", bgx_idx, lmacid, + (unsigned long)bgx_reg_read(lmac->bgx, lmac->lmacid, + BGX_SMUX_RX_CTL)); + debug("BGX%d LMAC%d BGX_SMUX_TX_CTL: %lx\n", bgx_idx, lmacid, + (unsigned long)bgx_reg_read(lmac->bgx, lmac->lmacid, + BGX_SMUX_TX_CTL)); + + if ((status1 & SPU_STATUS1_RCV_LNK) && + ((tx_ctl & SMU_TX_CTL_LNK_STATUS) == 0) && + ((rx_ctl & SMU_RX_CTL_STATUS) == 0)) { + lmac->link_up = 1; + if (lmac->lmac_type == 4) + lmac->last_speed = 40000; + else + lmac->last_speed = 10000; + lmac->last_duplex = 1; + } else { + lmac->link_up = 0; + lmac->last_speed = 0; + lmac->last_duplex = 0; + return bgx_xaui_check_link(lmac); + } + + lmac->last_link = lmac->link_up; + } + + printf("BGX%d:LMAC %u link %s\n", bgx_idx, lmacid, + (lmac->link_up) ? "up" : "down"); + + return lmac->link_up; +} + +void bgx_lmac_disable(struct bgx *bgx, uint8_t lmacid) +{ + struct lmac *lmac; + u64 cmrx_cfg; + + lmac = &bgx->lmac[lmacid]; + + cmrx_cfg = bgx_reg_read(bgx, lmacid, BGX_CMRX_CFG); + cmrx_cfg &= ~(1 << 15); + bgx_reg_write(bgx, lmacid, BGX_CMRX_CFG, cmrx_cfg); + bgx_flush_dmac_addrs(bgx, lmacid); + + if (lmac->phydev) + phy_shutdown(lmac->phydev); + + lmac->phydev = NULL; +} + +/* Program BGXX_CMRX_CONFIG.{lmac_type,lane_to_sds} for each interface. + * And the number of LMACs used by this interface. Each lmac can be in + * programmed in a different mode, so parse each lmac one at a time. + */ +static void bgx_init_hw(struct bgx *bgx) +{ + struct lmac *lmac; + int i, lmacid, count = 0, inc = 0; + char buf[40]; + static int qsgmii_configured; + + for (lmacid = 0; lmacid < MAX_LMAC_PER_BGX; lmacid++) { + struct lmac *tlmac; + + lmac = &bgx->lmac[lmacid]; + debug("%s: lmacid = %d, qlm = %d, mode = %d\n", + __func__, lmacid, lmac->qlm, lmac->qlm_mode); + /* If QLM is not programmed, skip */ + if (lmac->qlm == -1) + continue; + + switch (lmac->qlm_mode) { + case QLM_MODE_SGMII: + { + /* EBB8000 (alternative pkg) has only lane0 present on + * DLM0 and DLM1, skip configuring other lanes + */ + if (bgx->bgx_id == 0 && otx_is_altpkg()) { + if (lmacid % 2) + continue; + } + lmac->lane_to_sds = lmacid; + lmac->lmac_type = 0; + snprintf(buf, sizeof(buf), + "BGX%d QLM%d LMAC%d mode: %s\n", + bgx->bgx_id, lmac->qlm, lmacid, + lmac->is_1gx ? "1000Base-X" : "SGMII"); + break; + } + case QLM_MODE_XAUI: + if (lmacid != 0) + continue; + lmac->lmac_type = 1; + lmac->lane_to_sds = 0xE4; + snprintf(buf, sizeof(buf), + "BGX%d QLM%d LMAC%d mode: XAUI\n", + bgx->bgx_id, lmac->qlm, lmacid); + break; + case QLM_MODE_RXAUI: + if (lmacid == 0) { + lmac->lmac_type = 2; + lmac->lane_to_sds = 0x4; + } else if (lmacid == 1) { + struct lmac *tlmac; + + tlmac = &bgx->lmac[2]; + if (tlmac->qlm_mode == QLM_MODE_RXAUI) { + lmac->lmac_type = 2; + lmac->lane_to_sds = 0xe; + lmac->qlm = tlmac->qlm; + } + } else { + continue; + } + snprintf(buf, sizeof(buf), + "BGX%d QLM%d LMAC%d mode: RXAUI\n", + bgx->bgx_id, lmac->qlm, lmacid); + break; + case QLM_MODE_XFI: + /* EBB8000 (alternative pkg) has only lane0 present on + * DLM0 and DLM1, skip configuring other lanes + */ + if (bgx->bgx_id == 0 && otx_is_altpkg()) { + if (lmacid % 2) + continue; + } + lmac->lane_to_sds = lmacid; + lmac->lmac_type = 3; + snprintf(buf, sizeof(buf), + "BGX%d QLM%d LMAC%d mode: XFI\n", + bgx->bgx_id, lmac->qlm, lmacid); + break; + case QLM_MODE_XLAUI: + if (lmacid != 0) + continue; + lmac->lmac_type = 4; + lmac->lane_to_sds = 0xE4; + snprintf(buf, sizeof(buf), + "BGX%d QLM%d LMAC%d mode: XLAUI\n", + bgx->bgx_id, lmac->qlm, lmacid); + break; + case QLM_MODE_10G_KR: + /* EBB8000 (alternative pkg) has only lane0 present on + * DLM0 and DLM1, skip configuring other lanes + */ + if (bgx->bgx_id == 0 && otx_is_altpkg()) { + if (lmacid % 2) + continue; + } + lmac->lane_to_sds = lmacid; + lmac->lmac_type = 3; + lmac->use_training = 1; + snprintf(buf, sizeof(buf), + "BGX%d QLM%d LMAC%d mode: 10G-KR\n", + bgx->bgx_id, lmac->qlm, lmacid); + break; + case QLM_MODE_40G_KR4: + if (lmacid != 0) + continue; + lmac->lmac_type = 4; + lmac->lane_to_sds = 0xE4; + lmac->use_training = 1; + snprintf(buf, sizeof(buf), + "BGX%d QLM%d LMAC%d mode: 40G-KR4\n", + bgx->bgx_id, lmac->qlm, lmacid); + break; + case QLM_MODE_RGMII: + if (lmacid != 0) + continue; + lmac->lmac_type = 5; + lmac->lane_to_sds = 0xE4; + snprintf(buf, sizeof(buf), + "BGX%d LMAC%d mode: RGMII\n", + bgx->bgx_id, lmacid); + break; + case QLM_MODE_QSGMII: + if (qsgmii_configured) + continue; + if (lmacid == 0 || lmacid == 2) { + count = 4; + printf("BGX%d QLM%d LMAC%d mode: QSGMII\n", + bgx->bgx_id, lmac->qlm, lmacid); + for (i = 0; i < count; i++) { + struct lmac *l; + int type; + + l = &bgx->lmac[i]; + l->lmac_type = 6; + type = l->lmac_type; + l->qlm_mode = QLM_MODE_QSGMII; + l->lane_to_sds = lmacid + i; + if (is_bgx_port_valid(bgx->bgx_id, i)) + bgx_reg_write(bgx, i, + BGX_CMRX_CFG, + (type << 8) | + l->lane_to_sds); + } + qsgmii_configured = 1; + } + continue; + default: + continue; + } + + /* Reset lmac to the unused slot */ + if (is_bgx_port_valid(bgx->bgx_id, count) && + lmac->qlm_mode != QLM_MODE_QSGMII) { + int lmac_en = 0; + int tmp, idx; + + tlmac = &bgx->lmac[count]; + tlmac->lmac_type = lmac->lmac_type; + idx = bgx->bgx_id; + tmp = count + inc; + /* Adjust lane_to_sds based on BGX-ENABLE */ + for (; tmp < MAX_LMAC_PER_BGX; inc++) { + lmac_en = bgx_board_info[idx].lmac_enable[tmp]; + if (lmac_en) + break; + tmp = count + inc; + } + + if (inc != 0 && inc < MAX_LMAC_PER_BGX && + lmac_en && inc != count) + tlmac->lane_to_sds = + lmac->lane_to_sds + abs(inc - count); + else + tlmac->lane_to_sds = lmac->lane_to_sds; + tlmac->qlm = lmac->qlm; + tlmac->qlm_mode = lmac->qlm_mode; + + printf("%s", buf); + /* Initialize lmac_type and lane_to_sds */ + bgx_reg_write(bgx, count, BGX_CMRX_CFG, + (tlmac->lmac_type << 8) | + tlmac->lane_to_sds); + + if (tlmac->lmac_type == BGX_MODE_SGMII) { + if (tlmac->is_1gx) { + /* This is actually 1000BASE-X, so + * mark the LMAC as such. + */ + bgx_reg_modify(bgx, count, + BGX_GMP_PCS_MISCX_CTL, + PCS_MISC_CTL_MODE); + } + + if (!bgx_board_info[bgx->bgx_id]. + phy_info[lmacid].autoneg_dis) { + /* The Linux DTS does not disable + * autoneg for this LMAC (in SGMII or + * 1000BASE-X mode), so that means + * enable autoneg. + */ + bgx_reg_modify(bgx, count, + BGX_GMP_PCS_MRX_CTL, + PCS_MRX_CTL_AN_EN); + } + } + + count += 1; + } + } + + /* Done probing all 4 lmacs, now clear qsgmii_configured */ + qsgmii_configured = 0; + + printf("BGX%d LMACs: %d\n", bgx->bgx_id, count); + bgx->lmac_count = count; + bgx_reg_write(bgx, 0, BGX_CMR_RX_LMACS, count); + bgx_reg_write(bgx, 0, BGX_CMR_TX_LMACS, count); + + bgx_reg_modify(bgx, 0, BGX_CMR_GLOBAL_CFG, CMR_GLOBAL_CFG_FCS_STRIP); + if (bgx_reg_read(bgx, 0, BGX_CMR_BIST_STATUS)) + printf("BGX%d BIST failed\n", bgx->bgx_id); + + /* Set the backpressure AND mask */ + for (i = 0; i < bgx->lmac_count; i++) + bgx_reg_modify(bgx, 0, BGX_CMR_CHAN_MSK_AND, + ((1ULL << MAX_BGX_CHANS_PER_LMAC) - 1) << + (i * MAX_BGX_CHANS_PER_LMAC)); + + /* Disable all MAC filtering */ + for (i = 0; i < RX_DMAC_COUNT; i++) + bgx_reg_write(bgx, 0, BGX_CMR_RX_DMACX_CAM + (i * 8), 0x00); + + /* Disable MAC steering (NCSI traffic) */ + for (i = 0; i < RX_TRAFFIC_STEER_RULE_COUNT; i++) + bgx_reg_write(bgx, 0, BGX_CMR_RX_STREERING + (i * 8), 0x00); +} + +static void bgx_get_qlm_mode(struct bgx *bgx) +{ + struct lmac *lmac; + int lmacid; + + /* Read LMACx type to figure out QLM mode + * This is configured by low level firmware + */ + for (lmacid = 0; lmacid < MAX_LMAC_PER_BGX; lmacid++) { + int lmac_type; + int train_en; + int index = 0; + + if (otx_is_soc(CN81XX) || (otx_is_soc(CN83XX) && + bgx->bgx_id == 2)) + index = (lmacid < 2) ? 0 : 2; + + lmac = &bgx->lmac[lmacid]; + + /* check if QLM is programmed, if not, skip */ + if (lmac->qlm == -1) + continue; + + lmac_type = bgx_reg_read(bgx, index, BGX_CMRX_CFG); + lmac->lmac_type = (lmac_type >> 8) & 0x07; + debug("%s:%d:%d: lmac_type = %d, altpkg = %d\n", __func__, + bgx->bgx_id, lmacid, lmac->lmac_type, otx_is_altpkg()); + + train_en = (readq(GSERX_SCRATCH(lmac->qlm))) & 0xf; + lmac->is_1gx = bgx_reg_read(bgx, index, BGX_GMP_PCS_MISCX_CTL) + & (PCS_MISC_CTL_MODE) ? true : false; + + switch (lmac->lmac_type) { + case BGX_MODE_SGMII: + if (bgx->is_rgx) { + if (lmacid == 0) { + lmac->qlm_mode = QLM_MODE_RGMII; + debug("BGX%d LMAC%d mode: RGMII\n", + bgx->bgx_id, lmacid); + } + continue; + } else { + if (bgx->bgx_id == 0 && otx_is_altpkg()) { + if (lmacid % 2) + continue; + } + lmac->qlm_mode = QLM_MODE_SGMII; + debug("BGX%d QLM%d LMAC%d mode: %s\n", + bgx->bgx_id, lmac->qlm, lmacid, + lmac->is_1gx ? "1000Base-X" : "SGMII"); + } + break; + case BGX_MODE_XAUI: + if (bgx->bgx_id == 0 && otx_is_altpkg()) + continue; + lmac->qlm_mode = QLM_MODE_XAUI; + if (lmacid != 0) + continue; + debug("BGX%d QLM%d LMAC%d mode: XAUI\n", + bgx->bgx_id, lmac->qlm, lmacid); + break; + case BGX_MODE_RXAUI: + if (bgx->bgx_id == 0 && otx_is_altpkg()) + continue; + lmac->qlm_mode = QLM_MODE_RXAUI; + if (index == lmacid) { + debug("BGX%d QLM%d LMAC%d mode: RXAUI\n", + bgx->bgx_id, lmac->qlm, (index ? 1 : 0)); + } + break; + case BGX_MODE_XFI: + if (bgx->bgx_id == 0 && otx_is_altpkg()) { + if (lmacid % 2) + continue; + } + if ((lmacid < 2 && (train_en & (1 << lmacid))) || + (train_en & (1 << (lmacid - 2)))) { + lmac->qlm_mode = QLM_MODE_10G_KR; + debug("BGX%d QLM%d LMAC%d mode: 10G_KR\n", + bgx->bgx_id, lmac->qlm, lmacid); + } else { + lmac->qlm_mode = QLM_MODE_XFI; + debug("BGX%d QLM%d LMAC%d mode: XFI\n", + bgx->bgx_id, lmac->qlm, lmacid); + } + break; + case BGX_MODE_XLAUI: + if (bgx->bgx_id == 0 && otx_is_altpkg()) + continue; + if (train_en) { + lmac->qlm_mode = QLM_MODE_40G_KR4; + if (lmacid != 0) + break; + debug("BGX%d QLM%d LMAC%d mode: 40G_KR4\n", + bgx->bgx_id, lmac->qlm, lmacid); + } else { + lmac->qlm_mode = QLM_MODE_XLAUI; + if (lmacid != 0) + break; + debug("BGX%d QLM%d LMAC%d mode: XLAUI\n", + bgx->bgx_id, lmac->qlm, lmacid); + } + break; + case BGX_MODE_QSGMII: + /* If QLM is configured as QSGMII, use lmac0 */ + if (otx_is_soc(CN83XX) && lmacid == 2 && + bgx->bgx_id != 2) { + //lmac->qlm_mode = QLM_MODE_DISABLED; + continue; + } + + if (lmacid == 0 || lmacid == 2) { + lmac->qlm_mode = QLM_MODE_QSGMII; + debug("BGX%d QLM%d LMAC%d mode: QSGMII\n", + bgx->bgx_id, lmac->qlm, lmacid); + } + break; + default: + break; + } + } +} + +void bgx_set_board_info(int bgx_id, int *mdio_bus, + int *phy_addr, bool *autoneg_dis, bool *lmac_reg, + bool *lmac_enable) +{ + unsigned int i; + + for (i = 0; i < MAX_LMAC_PER_BGX; i++) { + bgx_board_info[bgx_id].phy_info[i].phy_addr = phy_addr[i]; + bgx_board_info[bgx_id].phy_info[i].mdio_bus = mdio_bus[i]; + bgx_board_info[bgx_id].phy_info[i].autoneg_dis = autoneg_dis[i]; + bgx_board_info[bgx_id].lmac_reg[i] = lmac_reg[i]; + bgx_board_info[bgx_id].lmac_enable[i] = lmac_enable[i]; + debug("%s bgx_id %d lmac %d\n", __func__, bgx_id, i); + debug("phy addr %x mdio bus %d autoneg_dis %d lmac_reg %d\n", + bgx_board_info[bgx_id].phy_info[i].phy_addr, + bgx_board_info[bgx_id].phy_info[i].mdio_bus, + bgx_board_info[bgx_id].phy_info[i].autoneg_dis, + bgx_board_info[bgx_id].lmac_reg[i]); + debug("lmac_enable = %x\n", + bgx_board_info[bgx_id].lmac_enable[i]); + } +} + +int octeontx_bgx_remove(struct udevice *dev) +{ + int lmacid; + u64 cfg; + int count = MAX_LMAC_PER_BGX; + struct bgx *bgx = dev_get_priv(dev); + + if (!bgx->reg_base) + return 0; + + if (bgx->is_rgx) + count = 1; + + for (lmacid = 0; lmacid < count; lmacid++) { + struct lmac *lmac; + + lmac = &bgx->lmac[lmacid]; + cfg = bgx_reg_read(bgx, lmacid, BGX_CMRX_CFG); + cfg &= ~(CMR_PKT_RX_EN | CMR_PKT_TX_EN); + bgx_reg_write(bgx, lmacid, BGX_CMRX_CFG, cfg); + + /* Disable PCS for 1G interface */ + if (lmac->lmac_type == BGX_MODE_SGMII || + lmac->lmac_type == BGX_MODE_QSGMII) { + cfg = bgx_reg_read(bgx, lmacid, BGX_GMP_PCS_MRX_CTL); + cfg |= PCS_MRX_CTL_PWR_DN; + bgx_reg_write(bgx, lmacid, BGX_GMP_PCS_MRX_CTL, cfg); + } + + debug("%s disabling bgx%d lmacid%d\n", __func__, bgx->bgx_id, + lmacid); + bgx_lmac_disable(bgx, lmacid); + } + return 0; +} + +int octeontx_bgx_probe(struct udevice *dev) +{ + struct bgx *bgx = dev_get_priv(dev); + u8 lmac = 0; + int qlm[4] = {-1, -1, -1, -1}; + int bgx_idx, node; + int inc = 1; + + bgx->reg_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + if (!bgx->reg_base) { + debug("No PCI region found\n"); + return 0; + } + +#ifdef OCTEONTX_XCV + /* Use FAKE BGX2 for RGX interface */ + if ((((uintptr_t)bgx->reg_base >> 24) & 0xf) == 0x8) { + bgx->bgx_id = 2; + bgx->is_rgx = true; + for (lmac = 0; lmac < MAX_LMAC_PER_BGX; lmac++) { + if (lmac == 0) { + bgx->lmac[lmac].lmacid = 0; + bgx->lmac[lmac].qlm = 0; + } else { + bgx->lmac[lmac].qlm = -1; + } + } + xcv_init_hw(); + goto skip_qlm_config; + } +#endif + + node = node_id(bgx->reg_base); + bgx_idx = ((uintptr_t)bgx->reg_base >> 24) & 3; + bgx->bgx_id = (node * MAX_BGX_PER_NODE) + bgx_idx; + if (otx_is_soc(CN81XX)) + inc = 2; + else if (otx_is_soc(CN83XX) && (bgx_idx == 2)) + inc = 2; + + for (lmac = 0; lmac < MAX_LMAC_PER_BGX; lmac += inc) { + /* BGX3 (DLM4), has only 2 lanes */ + if (otx_is_soc(CN83XX) && bgx_idx == 3 && lmac >= 2) + continue; + qlm[lmac + 0] = get_qlm_for_bgx(node, bgx_idx, lmac); + /* Each DLM has 2 lanes, configure both lanes with + * same qlm configuration + */ + if (inc == 2) + qlm[lmac + 1] = qlm[lmac]; + debug("qlm[%d] = %d\n", lmac, qlm[lmac]); + } + + /* A BGX can take 1 or 2 DLMs, if both the DLMs are not configured + * as BGX, then return, nothing to initialize + */ + if (otx_is_soc(CN81XX)) + if ((qlm[0] == -1) && (qlm[2] == -1)) + return -ENODEV; + + /* MAP configuration registers */ + for (lmac = 0; lmac < MAX_LMAC_PER_BGX; lmac++) { + bgx->lmac[lmac].qlm = qlm[lmac]; + bgx->lmac[lmac].lmacid = lmac; + } + +#ifdef OCTEONTX_XCV +skip_qlm_config: +#endif + bgx_vnic[bgx->bgx_id] = bgx; + bgx_get_qlm_mode(bgx); + debug("bgx_vnic[%u]: %p\n", bgx->bgx_id, bgx); + + bgx_init_hw(bgx); + + /* Init LMACs */ + for (lmac = 0; lmac < bgx->lmac_count; lmac++) { + struct lmac *tlmac = &bgx->lmac[lmac]; + + tlmac->dev = dev; + tlmac->init_pend = 1; + tlmac->bgx = bgx; + } + + return 0; +} + +U_BOOT_DRIVER(octeontx_bgx) = { + .name = "octeontx_bgx", + .id = UCLASS_MISC, + .probe = octeontx_bgx_probe, + .remove = octeontx_bgx_remove, + .priv_auto_alloc_size = sizeof(struct bgx), + .flags = DM_FLAG_OS_PREPARE, +}; + +static struct pci_device_id octeontx_bgx_supported[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_BGX) }, + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_RGX) }, + {} +}; + +U_BOOT_PCI_DEVICE(octeontx_bgx, octeontx_bgx_supported); diff --git a/drivers/net/octeontx/bgx.h b/drivers/net/octeontx/bgx.h new file mode 100644 index 0000000000..1ad582a91a --- /dev/null +++ b/drivers/net/octeontx/bgx.h @@ -0,0 +1,259 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef BGX_H +#define BGX_H + +#include <asm/arch/board.h> + +/* PCI device IDs */ +#define PCI_DEVICE_ID_OCTEONTX_BGX 0xA026 +#define PCI_DEVICE_ID_OCTEONTX_RGX 0xA054 + +#define MAX_LMAC_PER_BGX 4 +#define MAX_BGX_CHANS_PER_LMAC 16 +#define MAX_DMAC_PER_LMAC 8 +#define MAX_FRAME_SIZE 9216 + +#define MAX_DMAC_PER_LMAC_TNS_BYPASS_MODE 2 + +#define MAX_LMAC (MAX_BGX_PER_NODE * MAX_LMAC_PER_BGX) + +#define NODE_ID_MASK 0x300000000000 +#define NODE_ID(x) (((x) & NODE_ID_MASK) >> 44) + +/* Registers */ +#define GSERX_CFG(x) (0x87E090000080ull + (x) * 0x1000000ull) +#define GSERX_SCRATCH(x) (0x87E090000020ull + (x) * 0x1000000ull) +#define GSERX_PHY_CTL(x) (0x87E090000000ull + (x) * 0x1000000ull) +#define GSERX_CFG_BGX BIT(2) +#define GSER_RX_EIE_DETSTS(x) (0x87E090000150ull + (x) * 0x1000000ull) +#define GSER_CDRLOCK (8) +#define GSER_BR_RXX_CTL(x, y) (0x87E090000400ull + (x) * 0x1000000ull + \ + (y) * 0x80) +#define GSER_BR_RXX_CTL_RXT_SWM BIT(2) +#define GSER_BR_RXX_EER(x, y) (0x87E090000418ull + (x) * 0x1000000ull + \ + (y) * 0x80) +#define GSER_BR_RXX_EER_RXT_ESV BIT(14) +#define GSER_BR_RXX_EER_RXT_EER BIT(15) +#define EER_RXT_ESV (14) + +#define BGX_CMRX_CFG 0x00 +#define CMR_PKT_TX_EN BIT_ULL(13) +#define CMR_PKT_RX_EN BIT_ULL(14) +#define CMR_EN BIT_ULL(15) +#define BGX_CMR_GLOBAL_CFG 0x08 +#define CMR_GLOBAL_CFG_FCS_STRIP BIT_ULL(6) +#define BGX_CMRX_RX_ID_MAP 0x60 +#define BGX_CMRX_RX_STAT0 0x70 +#define BGX_CMRX_RX_STAT1 0x78 +#define BGX_CMRX_RX_STAT2 0x80 +#define BGX_CMRX_RX_STAT3 0x88 +#define BGX_CMRX_RX_STAT4 0x90 +#define BGX_CMRX_RX_STAT5 0x98 +#define BGX_CMRX_RX_STAT6 0xA0 +#define BGX_CMRX_RX_STAT7 0xA8 +#define BGX_CMRX_RX_STAT8 0xB0 +#define BGX_CMRX_RX_STAT9 0xB8 +#define BGX_CMRX_RX_STAT10 0xC0 +#define BGX_CMRX_RX_BP_DROP 0xC8 +#define BGX_CMRX_RX_DMAC_CTL 0x0E8 +#define BGX_CMR_RX_DMACX_CAM 0x200 +#define RX_DMACX_CAM_EN BIT_ULL(48) +#define RX_DMACX_CAM_LMACID(x) ((x) << 49) +#define RX_DMAC_COUNT 32 +#define BGX_CMR_RX_STREERING 0x300 +#define RX_TRAFFIC_STEER_RULE_COUNT 8 +#define BGX_CMR_CHAN_MSK_AND 0x450 +#define BGX_CMR_BIST_STATUS 0x460 +#define BGX_CMR_RX_LMACS 0x468 +#define BGX_CMRX_TX_STAT0 0x600 +#define BGX_CMRX_TX_STAT1 0x608 +#define BGX_CMRX_TX_STAT2 0x610 +#define BGX_CMRX_TX_STAT3 0x618 +#define BGX_CMRX_TX_STAT4 0x620 +#define BGX_CMRX_TX_STAT5 0x628 +#define BGX_CMRX_TX_STAT6 0x630 +#define BGX_CMRX_TX_STAT7 0x638 +#define BGX_CMRX_TX_STAT8 0x640 +#define BGX_CMRX_TX_STAT9 0x648 +#define BGX_CMRX_TX_STAT10 0x650 +#define BGX_CMRX_TX_STAT11 0x658 +#define BGX_CMRX_TX_STAT12 0x660 +#define BGX_CMRX_TX_STAT13 0x668 +#define BGX_CMRX_TX_STAT14 0x670 +#define BGX_CMRX_TX_STAT15 0x678 +#define BGX_CMRX_TX_STAT16 0x680 +#define BGX_CMRX_TX_STAT17 0x688 +#define BGX_CMR_TX_LMACS 0x1000 + +#define BGX_SPUX_CONTROL1 0x10000 +#define SPU_CTL_LOW_POWER BIT_ULL(11) +#define SPU_CTL_LOOPBACK BIT_ULL(14) +#define SPU_CTL_RESET BIT_ULL(15) +#define BGX_SPUX_STATUS1 0x10008 +#define SPU_STATUS1_RCV_LNK BIT_ULL(2) +#define BGX_SPUX_STATUS2 0x10020 +#define SPU_STATUS2_RCVFLT BIT_ULL(10) +#define BGX_SPUX_BX_STATUS 0x10028 +#define SPU_BX_STATUS_RX_ALIGN BIT_ULL(12) +#define BGX_SPUX_BR_STATUS1 0x10030 +#define SPU_BR_STATUS_BLK_LOCK BIT_ULL(0) +#define SPU_BR_STATUS_RCV_LNK BIT_ULL(12) +#define BGX_SPUX_BR_PMD_CRTL 0x10068 +#define SPU_PMD_CRTL_TRAIN_EN BIT_ULL(1) +#define BGX_SPUX_BR_PMD_LP_CUP 0x10078 +#define BGX_SPUX_BR_PMD_LD_CUP 0x10088 +#define BGX_SPUX_BR_PMD_LD_REP 0x10090 +#define BGX_SPUX_FEC_CONTROL 0x100A0 +#define SPU_FEC_CTL_FEC_EN BIT_ULL(0) +#define SPU_FEC_CTL_ERR_EN BIT_ULL(1) +#define BGX_SPUX_AN_CONTROL 0x100C8 +#define SPU_AN_CTL_AN_EN BIT_ULL(12) +#define SPU_AN_CTL_XNP_EN BIT_ULL(13) +#define SPU_AN_CTL_AN_RESTART BIT_ULL(15) +#define BGX_SPUX_AN_STATUS 0x100D0 +#define SPU_AN_STS_AN_COMPLETE BIT_ULL(5) +#define BGX_SPUX_AN_ADV 0x100D8 +#define BGX_SPUX_MISC_CONTROL 0x10218 +#define SPU_MISC_CTL_INTLV_RDISP BIT_ULL(10) +#define SPU_MISC_CTL_RX_DIS BIT_ULL(12) +#define BGX_SPUX_INT 0x10220 /* +(0..3) << 20 */ +#define BGX_SPUX_INT_W1S 0x10228 +#define BGX_SPUX_INT_ENA_W1C 0x10230 +#define BGX_SPUX_INT_ENA_W1S 0x10238 +#define BGX_SPU_DBG_CONTROL 0x10300 +#define SPU_DBG_CTL_AN_ARB_LINK_CHK_EN BIT_ULL(18) +#define SPU_DBG_CTL_AN_NONCE_MCT_DIS BIT_ULL(29) + +#define BGX_SMUX_RX_INT 0x20000 +#define BGX_SMUX_RX_JABBER 0x20030 +#define BGX_SMUX_RX_CTL 0x20048 +#define SMU_RX_CTL_STATUS (3ull << 0) +#define BGX_SMUX_TX_APPEND 0x20100 +#define SMU_TX_APPEND_FCS_D BIT_ULL(2) +#define BGX_SMUX_TX_MIN_PKT 0x20118 +#define BGX_SMUX_TX_INT 0x20140 +#define BGX_SMUX_TX_CTL 0x20178 +#define SMU_TX_CTL_DIC_EN BIT_ULL(0) +#define SMU_TX_CTL_UNI_EN BIT_ULL(1) +#define SMU_TX_CTL_LNK_STATUS (3ull << 4) +#define BGX_SMUX_TX_THRESH 0x20180 +#define BGX_SMUX_CTL 0x20200 +#define SMU_CTL_RX_IDLE BIT_ULL(0) +#define SMU_CTL_TX_IDLE BIT_ULL(1) + +#define BGX_GMP_PCS_MRX_CTL 0x30000 +#define PCS_MRX_CTL_RST_AN BIT_ULL(9) +#define PCS_MRX_CTL_PWR_DN BIT_ULL(11) +#define PCS_MRX_CTL_AN_EN BIT_ULL(12) +#define PCS_MRX_CTL_LOOPBACK1 BIT_ULL(14) +#define PCS_MRX_CTL_RESET BIT_ULL(15) +#define BGX_GMP_PCS_MRX_STATUS 0x30008 +#define PCS_MRX_STATUS_AN_CPT BIT_ULL(5) +#define BGX_GMP_PCS_ANX_AN_RESULTS 0x30020 +#define BGX_GMP_PCS_SGM_AN_ADV 0x30068 +#define BGX_GMP_PCS_MISCX_CTL 0x30078 +#define PCS_MISCX_CTL_DISP_EN BIT_ULL(13) +#define PCS_MISC_CTL_GMX_ENO BIT_ULL(11) +#define PCS_MISC_CTL_SAMP_PT_MASK 0x7Full +#define PCS_MISC_CTL_MODE BIT_ULL(8) +#define BGX_GMP_GMI_PRTX_CFG 0x38020 +#define GMI_PORT_CFG_SPEED BIT_ULL(1) +#define GMI_PORT_CFG_DUPLEX BIT_ULL(2) +#define GMI_PORT_CFG_SLOT_TIME BIT_ULL(3) +#define GMI_PORT_CFG_SPEED_MSB BIT_ULL(8) +#define BGX_GMP_GMI_RXX_JABBER 0x38038 +#define BGX_GMP_GMI_TXX_THRESH 0x38210 +#define BGX_GMP_GMI_TXX_APPEND 0x38218 +#define BGX_GMP_GMI_TXX_SLOT 0x38220 +#define BGX_GMP_GMI_TXX_BURST 0x38228 +#define BGX_GMP_GMI_TXX_MIN_PKT 0x38240 +#define BGX_GMP_GMI_TXX_SGMII_CTL 0x38300 + +#define BGX_MSIX_VEC_0_29_ADDR 0x400000 /* +(0..29) << 4 */ +#define BGX_MSIX_VEC_0_29_CTL 0x400008 +#define BGX_MSIX_PBA_0 0x4F0000 + +/* MSI-X interrupts */ +#define BGX_MSIX_VECTORS 30 +#define BGX_LMAC_VEC_OFFSET 7 +#define BGX_MSIX_VEC_SHIFT 4 + +#define CMRX_INT 0 +#define SPUX_INT 1 +#define SMUX_RX_INT 2 +#define SMUX_TX_INT 3 +#define GMPX_PCS_INT 4 +#define GMPX_GMI_RX_INT 5 +#define GMPX_GMI_TX_INT 6 +#define CMR_MEM_INT 28 +#define SPU_MEM_INT 29 + +#define LMAC_INTR_LINK_UP BIT(0) +#define LMAC_INTR_LINK_DOWN BIT(1) + +/* RX_DMAC_CTL configuration*/ +enum MCAST_MODE { + MCAST_MODE_REJECT, + MCAST_MODE_ACCEPT, + MCAST_MODE_CAM_FILTER, + RSVD +}; + +#define BCAST_ACCEPT 1 +#define CAM_ACCEPT 1 + +int octeontx_bgx_initialize(unsigned int bgx_idx, unsigned int node); +void bgx_add_dmac_addr(u64 dmac, int node, int bgx_idx, int lmac); +void bgx_get_count(int node, int *bgx_count); +int bgx_get_lmac_count(int node, int bgx); +void bgx_print_stats(int bgx_idx, int lmac); +void xcv_init_hw(void); +void xcv_setup_link(bool link_up, int link_speed); + +#undef LINK_INTR_ENABLE + +enum qlm_mode { + QLM_MODE_SGMII, /* SGMII, each lane independent */ + QLM_MODE_XAUI, /* 1 XAUI or DXAUI, 4 lanes */ + QLM_MODE_RXAUI, /* 2 RXAUI, 2 lanes each */ + QLM_MODE_XFI, /* 4 XFI, 1 lane each */ + QLM_MODE_XLAUI, /* 1 XLAUI, 4 lanes each */ + QLM_MODE_10G_KR, /* 4 10GBASE-KR, 1 lane each */ + QLM_MODE_40G_KR4, /* 1 40GBASE-KR4, 4 lanes each */ + QLM_MODE_QSGMII, /* 4 QSGMII, each lane independent */ + QLM_MODE_RGMII, /* 1 RGX */ +}; + +struct phy_info { + int mdio_bus; + int phy_addr; + bool autoneg_dis; +}; + +struct bgx_board_info { + struct phy_info phy_info[MAX_LMAC_PER_BGX]; + bool lmac_reg[MAX_LMAC_PER_BGX]; + bool lmac_enable[MAX_LMAC_PER_BGX]; +}; + +enum LMAC_TYPE { + BGX_MODE_SGMII = 0, /* 1 lane, 1.250 Gbaud */ + BGX_MODE_XAUI = 1, /* 4 lanes, 3.125 Gbaud */ + BGX_MODE_DXAUI = 1, /* 4 lanes, 6.250 Gbaud */ + BGX_MODE_RXAUI = 2, /* 2 lanes, 6.250 Gbaud */ + BGX_MODE_XFI = 3, /* 1 lane, 10.3125 Gbaud */ + BGX_MODE_XLAUI = 4, /* 4 lanes, 10.3125 Gbaud */ + BGX_MODE_10G_KR = 3,/* 1 lane, 10.3125 Gbaud */ + BGX_MODE_40G_KR = 4,/* 4 lanes, 10.3125 Gbaud */ + BGX_MODE_RGMII = 5, + BGX_MODE_QSGMII = 6, + BGX_MODE_INVALID = 7, +}; + +#endif /* BGX_H */ diff --git a/drivers/net/octeontx/nic.h b/drivers/net/octeontx/nic.h new file mode 100644 index 0000000000..beabe1e6b5 --- /dev/null +++ b/drivers/net/octeontx/nic.h @@ -0,0 +1,510 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef NIC_H +#define NIC_H + +#include <linux/netdevice.h> +#include "bgx.h" + +#define PCI_DEVICE_ID_CAVIUM_NICVF_1 0x0011 + +/* Subsystem device IDs */ +#define PCI_SUBSYS_DEVID_88XX_NIC_PF 0xA11E +#define PCI_SUBSYS_DEVID_81XX_NIC_PF 0xA21E +#define PCI_SUBSYS_DEVID_83XX_NIC_PF 0xA31E + +#define PCI_SUBSYS_DEVID_88XX_PASS1_NIC_VF 0xA11E +#define PCI_SUBSYS_DEVID_88XX_NIC_VF 0xA134 +#define PCI_SUBSYS_DEVID_81XX_NIC_VF 0xA234 +#define PCI_SUBSYS_DEVID_83XX_NIC_VF 0xA334 + +#define NIC_INTF_COUNT 2 /* Interfaces btw VNIC and TNS/BGX */ +#define NIC_CHANS_PER_INF 128 +#define NIC_MAX_CHANS (NIC_INTF_COUNT * NIC_CHANS_PER_INF) + +/* PCI BAR nos */ +#define PCI_CFG_REG_BAR_NUM 0 +#define PCI_MSIX_REG_BAR_NUM 4 + +/* NIC SRIOV VF count */ +#define MAX_NUM_VFS_SUPPORTED 128 +#define DEFAULT_NUM_VF_ENABLED 8 + +#define NIC_TNS_BYPASS_MODE 0 +#define NIC_TNS_MODE 1 + +/* NIC priv flags */ +#define NIC_SRIOV_ENABLED BIT(0) +#define NIC_TNS_ENABLED BIT(1) + +/* VNIC HW optimiation features */ +#define VNIC_RX_CSUM_OFFLOAD_SUPPORT +#undef VNIC_TX_CSUM_OFFLOAD_SUPPORT +#undef VNIC_SG_SUPPORT +#undef VNIC_TSO_SUPPORT +#undef VNIC_LRO_SUPPORT +#undef VNIC_RSS_SUPPORT + +/* TSO not supported in Thunder pass1 */ +#ifdef VNIC_TSO_SUPPORT +#define VNIC_SW_TSO_SUPPORT +#undef VNIC_HW_TSO_SUPPORT +#endif + +/* ETHTOOL enable or disable, undef this to disable */ +#define NICVF_ETHTOOL_ENABLE + +/* Min/Max packet size */ +#define NIC_HW_MIN_FRS 64 +#define NIC_HW_MAX_FRS 9200 /* 9216 max packet including FCS */ + +/* Max pkinds */ +#define NIC_MAX_PKIND 16 + +/* Max when CPI_ALG is IP diffserv */ +#define NIC_MAX_CPI_PER_LMAC 64 + +/* NIC VF Interrupts */ +#define NICVF_INTR_CQ 0 +#define NICVF_INTR_SQ 1 +#define NICVF_INTR_RBDR 2 +#define NICVF_INTR_PKT_DROP 3 +#define NICVF_INTR_TCP_TIMER 4 +#define NICVF_INTR_MBOX 5 +#define NICVF_INTR_QS_ERR 6 + +#define NICVF_INTR_CQ_SHIFT 0 +#define NICVF_INTR_SQ_SHIFT 8 +#define NICVF_INTR_RBDR_SHIFT 16 +#define NICVF_INTR_PKT_DROP_SHIFT 20 +#define NICVF_INTR_TCP_TIMER_SHIFT 21 +#define NICVF_INTR_MBOX_SHIFT 22 +#define NICVF_INTR_QS_ERR_SHIFT 23 + +#define NICVF_INTR_CQ_MASK (0xFF << NICVF_INTR_CQ_SHIFT) +#define NICVF_INTR_SQ_MASK (0xFF << NICVF_INTR_SQ_SHIFT) +#define NICVF_INTR_RBDR_MASK (0x03 << NICVF_INTR_RBDR_SHIFT) +#define NICVF_INTR_PKT_DROP_MASK BIT(NICVF_INTR_PKT_DROP_SHIFT) +#define NICVF_INTR_TCP_TIMER_MASK BIT(NICVF_INTR_TCP_TIMER_SHIFT) +#define NICVF_INTR_MBOX_MASK BIT(NICVF_INTR_MBOX_SHIFT) +#define NICVF_INTR_QS_ERR_MASK BIT(NICVF_INTR_QS_ERR_SHIFT) + +/* MSI-X interrupts */ +#define NIC_PF_MSIX_VECTORS 10 +#define NIC_VF_MSIX_VECTORS 20 + +#define NIC_PF_INTR_ID_ECC0_SBE 0 +#define NIC_PF_INTR_ID_ECC0_DBE 1 +#define NIC_PF_INTR_ID_ECC1_SBE 2 +#define NIC_PF_INTR_ID_ECC1_DBE 3 +#define NIC_PF_INTR_ID_ECC2_SBE 4 +#define NIC_PF_INTR_ID_ECC2_DBE 5 +#define NIC_PF_INTR_ID_ECC3_SBE 6 +#define NIC_PF_INTR_ID_ECC3_DBE 7 +#define NIC_PF_INTR_ID_MBOX0 8 +#define NIC_PF_INTR_ID_MBOX1 9 + +/* Global timer for CQ timer thresh interrupts + * Calculated for SCLK of 700Mhz + * value written should be a 1/16thof what is expected + * + * 1 tick per ms + */ +#define NICPF_CLK_PER_INT_TICK 43750 + +struct nicvf_cq_poll { + u8 cq_idx; /* Completion queue index */ +}; + +#define NIC_MAX_RSS_HASH_BITS 8 +#define NIC_MAX_RSS_IDR_TBL_SIZE BIT(NIC_MAX_RSS_HASH_BITS) +#define RSS_HASH_KEY_SIZE 5 /* 320 bit key */ + +#ifdef VNIC_RSS_SUPPORT +struct nicvf_rss_info { + bool enable; +#define RSS_L2_EXTENDED_HASH_ENA BIT(0) +#define RSS_IP_HASH_ENA BIT(1) +#define RSS_TCP_HASH_ENA BIT(2) +#define RSS_TCP_SYN_DIS BIT(3) +#define RSS_UDP_HASH_ENA BIT(4) +#define RSS_L4_EXTENDED_HASH_ENA BIT(5) +#define RSS_ROCE_ENA BIT(6) +#define RSS_L3_BI_DIRECTION_ENA BIT(7) +#define RSS_L4_BI_DIRECTION_ENA BIT(8) + u64 cfg; + u8 hash_bits; + u16 rss_size; + u8 ind_tbl[NIC_MAX_RSS_IDR_TBL_SIZE]; + u64 key[RSS_HASH_KEY_SIZE]; +}; +#endif + +enum rx_stats_reg_offset { + RX_OCTS = 0x0, + RX_UCAST = 0x1, + RX_BCAST = 0x2, + RX_MCAST = 0x3, + RX_RED = 0x4, + RX_RED_OCTS = 0x5, + RX_ORUN = 0x6, + RX_ORUN_OCTS = 0x7, + RX_FCS = 0x8, + RX_L2ERR = 0x9, + RX_DRP_BCAST = 0xa, + RX_DRP_MCAST = 0xb, + RX_DRP_L3BCAST = 0xc, + RX_DRP_L3MCAST = 0xd, + RX_STATS_ENUM_LAST, +}; + +enum tx_stats_reg_offset { + TX_OCTS = 0x0, + TX_UCAST = 0x1, + TX_BCAST = 0x2, + TX_MCAST = 0x3, + TX_DROP = 0x4, + TX_STATS_ENUM_LAST, +}; + +struct nicvf_hw_stats { + u64 rx_bytes_ok; + u64 rx_ucast_frames_ok; + u64 rx_bcast_frames_ok; + u64 rx_mcast_frames_ok; + u64 rx_fcs_errors; + u64 rx_l2_errors; + u64 rx_drop_red; + u64 rx_drop_red_bytes; + u64 rx_drop_overrun; + u64 rx_drop_overrun_bytes; + u64 rx_drop_bcast; + u64 rx_drop_mcast; + u64 rx_drop_l3_bcast; + u64 rx_drop_l3_mcast; + u64 tx_bytes_ok; + u64 tx_ucast_frames_ok; + u64 tx_bcast_frames_ok; + u64 tx_mcast_frames_ok; + u64 tx_drops; +}; + +struct nicvf_drv_stats { + /* Rx */ + u64 rx_frames_ok; + u64 rx_frames_64; + u64 rx_frames_127; + u64 rx_frames_255; + u64 rx_frames_511; + u64 rx_frames_1023; + u64 rx_frames_1518; + u64 rx_frames_jumbo; + u64 rx_drops; + /* Tx */ + u64 tx_frames_ok; + u64 tx_drops; + u64 tx_busy; + u64 tx_tso; +}; + +struct hw_info { + u8 bgx_cnt; + u8 chans_per_lmac; + u8 chans_per_bgx; /* Rx/Tx chans */ + u8 chans_per_rgx; + u8 chans_per_lbk; + u16 cpi_cnt; + u16 rssi_cnt; + u16 rss_ind_tbl_size; + u16 tl4_cnt; + u16 tl3_cnt; + u8 tl2_cnt; + u8 tl1_cnt; + bool tl1_per_bgx; /* TL1 per BGX or per LMAC */ + u8 model_id; +}; + +struct nicvf { + struct udevice *dev; + u8 vf_id; + bool sqs_mode:1; + bool loopback_supported:1; + u8 tns_mode; + u8 node; + u16 mtu; + struct queue_set *qs; +#define MAX_SQS_PER_VF_SINGLE_NODE 5 +#define MAX_SQS_PER_VF 11 + u8 num_qs; + void *addnl_qs; + u16 vf_mtu; + void __iomem *reg_base; +#define MAX_QUEUES_PER_QSET 8 + struct nicvf_cq_poll *napi[8]; + + u8 cpi_alg; + + struct nicvf_hw_stats stats; + struct nicvf_drv_stats drv_stats; + + struct nicpf *nicpf; + + /* VF <-> PF mailbox communication */ + bool pf_acked; + bool pf_nacked; + bool set_mac_pending; + + bool link_up; + u8 duplex; + u32 speed; + u8 rev_id; + u8 rx_queues; + u8 tx_queues; + + bool open; + bool rb_alloc_fail; + void *rcv_buf; + bool hw_tso; +}; + +static inline int node_id(void *addr) +{ + return ((uintptr_t)addr >> 44) & 0x3; +} + +struct nicpf { + struct udevice *udev; + struct hw_info *hw; + u8 node; + unsigned int flags; + u16 total_vf_cnt; /* Total num of VF supported */ + u16 num_vf_en; /* No of VF enabled */ + void __iomem *reg_base; /* Register start address */ + u16 rss_ind_tbl_size; + u8 num_sqs_en; /* Secondary qsets enabled */ + u64 nicvf[MAX_NUM_VFS_SUPPORTED]; + u8 vf_sqs[MAX_NUM_VFS_SUPPORTED][MAX_SQS_PER_VF]; + u8 pqs_vf[MAX_NUM_VFS_SUPPORTED]; + bool sqs_used[MAX_NUM_VFS_SUPPORTED]; + struct pkind_cfg pkind; + u8 bgx_cnt; + u8 rev_id; +#define NIC_SET_VF_LMAC_MAP(bgx, lmac) ((((bgx) & 0xF) << 4) | ((lmac) & 0xF)) +#define NIC_GET_BGX_FROM_VF_LMAC_MAP(map) (((map) >> 4) & 0xF) +#define NIC_GET_LMAC_FROM_VF_LMAC_MAP(map) ((map) & 0xF) + u8 vf_lmac_map[MAX_LMAC]; + u16 cpi_base[MAX_NUM_VFS_SUPPORTED]; + u64 mac[MAX_NUM_VFS_SUPPORTED]; + bool mbx_lock[MAX_NUM_VFS_SUPPORTED]; + u8 link[MAX_LMAC]; + u8 duplex[MAX_LMAC]; + u32 speed[MAX_LMAC]; + bool vf_enabled[MAX_NUM_VFS_SUPPORTED]; + u16 rssi_base[MAX_NUM_VFS_SUPPORTED]; + u8 lmac_cnt; +}; + +/* PF <--> VF Mailbox communication + * Eight 64bit registers are shared between PF and VF. + * Separate set for each VF. + * Writing '1' into last register mbx7 means end of message. + */ + +/* PF <--> VF mailbox communication */ +#define NIC_PF_VF_MAILBOX_SIZE 2 +#define NIC_PF_VF_MBX_TIMEOUT 2000 /* ms */ + +/* Mailbox message types */ +#define NIC_MBOX_MSG_READY 0x01 /* Is PF ready to rcv msgs */ +#define NIC_MBOX_MSG_ACK 0x02 /* ACK the message received */ +#define NIC_MBOX_MSG_NACK 0x03 /* NACK the message received */ +#define NIC_MBOX_MSG_QS_CFG 0x04 /* Configure Qset */ +#define NIC_MBOX_MSG_RQ_CFG 0x05 /* Configure receive queue */ +#define NIC_MBOX_MSG_SQ_CFG 0x06 /* Configure Send queue */ +#define NIC_MBOX_MSG_RQ_DROP_CFG 0x07 /* Configure receive queue */ +#define NIC_MBOX_MSG_SET_MAC 0x08 /* Add MAC ID to DMAC filter */ +#define NIC_MBOX_MSG_SET_MAX_FRS 0x09 /* Set max frame size */ +#define NIC_MBOX_MSG_CPI_CFG 0x0A /* Config CPI, RSSI */ +#define NIC_MBOX_MSG_RSS_SIZE 0x0B /* Get RSS indir_tbl size */ +#define NIC_MBOX_MSG_RSS_CFG 0x0C /* Config RSS table */ +#define NIC_MBOX_MSG_RSS_CFG_CONT 0x0D /* RSS config continuation */ +#define NIC_MBOX_MSG_RQ_BP_CFG 0x0E /* RQ backpressure config */ +#define NIC_MBOX_MSG_RQ_SW_SYNC 0x0F /* Flush inflight pkts to RQ */ +#define NIC_MBOX_MSG_BGX_STATS 0x10 /* Get stats from BGX */ +#define NIC_MBOX_MSG_BGX_LINK_CHANGE 0x11 /* BGX:LMAC link status */ +#define NIC_MBOX_MSG_ALLOC_SQS 0x12 /* Allocate secondary Qset */ +#define NIC_MBOX_MSG_NICVF_PTR 0x13 /* Send nicvf ptr to PF */ +#define NIC_MBOX_MSG_PNICVF_PTR 0x14 /* Get primary qset nicvf ptr */ +#define NIC_MBOX_MSG_SNICVF_PTR 0x15 /* Send sqet nicvf ptr to PVF */ +#define NIC_MBOX_MSG_LOOPBACK 0x16 /* Set interface in loopback */ +#define NIC_MBOX_MSG_CFG_DONE 0xF0 /* VF configuration done */ +#define NIC_MBOX_MSG_SHUTDOWN 0xF1 /* VF is being shutdown */ + +struct nic_cfg_msg { + u8 msg; + u8 vf_id; + u8 node_id; + bool tns_mode:1; + bool sqs_mode:1; + bool loopback_supported:1; + u8 mac_addr[6]; +}; + +/* Qset configuration */ +struct qs_cfg_msg { + u8 msg; + u8 num; + u8 sqs_count; + u64 cfg; +}; + +/* Receive queue configuration */ +struct rq_cfg_msg { + u8 msg; + u8 qs_num; + u8 rq_num; + u64 cfg; +}; + +/* Send queue configuration */ +struct sq_cfg_msg { + u8 msg; + u8 qs_num; + u8 sq_num; + bool sqs_mode; + u64 cfg; +}; + +/* Set VF's MAC address */ +struct set_mac_msg { + u8 msg; + u8 vf_id; + u8 mac_addr[6]; +}; + +/* Set Maximum frame size */ +struct set_frs_msg { + u8 msg; + u8 vf_id; + u16 max_frs; +}; + +/* Set CPI algorithm type */ +struct cpi_cfg_msg { + u8 msg; + u8 vf_id; + u8 rq_cnt; + u8 cpi_alg; +}; + +/* Get RSS table size */ +struct rss_sz_msg { + u8 msg; + u8 vf_id; + u16 ind_tbl_size; +}; + +/* Set RSS configuration */ +struct rss_cfg_msg { + u8 msg; + u8 vf_id; + u8 hash_bits; + u8 tbl_len; + u8 tbl_offset; +#define RSS_IND_TBL_LEN_PER_MBX_MSG 8 + u8 ind_tbl[RSS_IND_TBL_LEN_PER_MBX_MSG]; +}; + +struct bgx_stats_msg { + u8 msg; + u8 vf_id; + u8 rx; + u8 idx; + u64 stats; +}; + +/* Physical interface link status */ +struct bgx_link_status { + u8 msg; + u8 link_up; + u8 duplex; + u32 speed; +}; + +#ifdef VNIC_MULTI_QSET_SUPPORT +/* Get Extra Qset IDs */ +struct sqs_alloc { + u8 msg; + u8 vf_id; + u8 qs_count; +}; + +struct nicvf_ptr { + u8 msg; + u8 vf_id; + bool sqs_mode; + u8 sqs_id; + u64 nicvf; +}; +#endif + +/* Set interface in loopback mode */ +struct set_loopback { + u8 msg; + u8 vf_id; + bool enable; +}; + +/* 128 bit shared memory between PF and each VF */ +union nic_mbx { + struct { u8 msg; } msg; + struct nic_cfg_msg nic_cfg; + struct qs_cfg_msg qs; + struct rq_cfg_msg rq; + struct sq_cfg_msg sq; + struct set_mac_msg mac; + struct set_frs_msg frs; + struct cpi_cfg_msg cpi_cfg; + struct rss_sz_msg rss_size; + struct rss_cfg_msg rss_cfg; + struct bgx_stats_msg bgx_stats; + struct bgx_link_status link_status; +#ifdef VNIC_MULTI_QSET_SUPPORT + struct sqs_alloc sqs_alloc; + struct nicvf_ptr nicvf; +#endif + struct set_loopback lbk; +}; + +int nicvf_set_real_num_queues(struct udevice *dev, + int tx_queues, int rx_queues); +int nicvf_open(struct udevice *dev); +void nicvf_stop(struct udevice *dev); +int nicvf_send_msg_to_pf(struct nicvf *vf, union nic_mbx *mbx); +void nicvf_update_stats(struct nicvf *nic); + +void nic_handle_mbx_intr(struct nicpf *nic, int vf); + +int bgx_poll_for_link(int node, int bgx_idx, int lmacid); +const u8 *bgx_get_lmac_mac(int node, int bgx_idx, int lmacid); +void bgx_set_lmac_mac(int node, int bgx_idx, int lmacid, const u8 *mac); +void bgx_lmac_rx_tx_enable(int node, int bgx_idx, int lmacid, bool enable); +void bgx_lmac_internal_loopback(int node, int bgx_idx, + int lmac_idx, bool enable); + +static inline bool pass1_silicon(unsigned int revision, int model_id) +{ + return ((revision < 8) && (model_id == 0x88)); +} + +static inline bool pass2_silicon(unsigned int revision, int model_id) +{ + return ((revision >= 8) && (model_id == 0x88)); +} + +#endif /* NIC_H */ diff --git a/drivers/net/octeontx/nic_main.c b/drivers/net/octeontx/nic_main.c new file mode 100644 index 0000000000..799b4d70e2 --- /dev/null +++ b/drivers/net/octeontx/nic_main.c @@ -0,0 +1,780 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <config.h> +#include <common.h> +#include <net.h> +#include <netdev.h> +#include <malloc.h> +#include <miiphy.h> +#include <dm.h> +#include <misc.h> +#include <pci.h> +#include <pci_ids.h> +#include <asm/io.h> + +#include "nic_reg.h" +#include "nic.h" +#include "q_struct.h" + +unsigned long rounddown_pow_of_two(unsigned long n) +{ + n |= n >> 1; + n |= n >> 2; + n |= n >> 4; + n |= n >> 8; + n |= n >> 16; + n |= n >> 32; + + return(n + 1); +} + +static void nic_config_cpi(struct nicpf *nic, struct cpi_cfg_msg *cfg); +static void nic_tx_channel_cfg(struct nicpf *nic, u8 vnic, + struct sq_cfg_msg *sq); +static int nic_update_hw_frs(struct nicpf *nic, int new_frs, int vf); +static int nic_rcv_queue_sw_sync(struct nicpf *nic); + +/* Register read/write APIs */ +static void nic_reg_write(struct nicpf *nic, u64 offset, u64 val) +{ + writeq(val, nic->reg_base + offset); +} + +static u64 nic_reg_read(struct nicpf *nic, u64 offset) +{ + return readq(nic->reg_base + offset); +} + +static u64 nic_get_mbx_addr(int vf) +{ + return NIC_PF_VF_0_127_MAILBOX_0_1 + (vf << NIC_VF_NUM_SHIFT); +} + +static void nic_send_msg_to_vf(struct nicpf *nic, int vf, union nic_mbx *mbx) +{ + void __iomem *mbx_addr = (void *)(nic->reg_base + nic_get_mbx_addr(vf)); + u64 *msg = (u64 *)mbx; + + /* In first revision HW, mbox interrupt is triggerred + * when PF writes to MBOX(1), in next revisions when + * PF writes to MBOX(0) + */ + if (pass1_silicon(nic->rev_id, nic->hw->model_id)) { + /* see the comment for nic_reg_write()/nic_reg_read() + * functions above + */ + writeq(msg[0], mbx_addr); + writeq(msg[1], mbx_addr + 8); + } else { + writeq(msg[1], mbx_addr + 8); + writeq(msg[0], mbx_addr); + } +} + +static void nic_mbx_send_ready(struct nicpf *nic, int vf) +{ + union nic_mbx mbx = {}; + int bgx_idx, lmac, timeout = 5, link = -1; + const u8 *mac; + + mbx.nic_cfg.msg = NIC_MBOX_MSG_READY; + mbx.nic_cfg.vf_id = vf; + + if (nic->flags & NIC_TNS_ENABLED) + mbx.nic_cfg.tns_mode = NIC_TNS_MODE; + else + mbx.nic_cfg.tns_mode = NIC_TNS_BYPASS_MODE; + + if (vf < nic->num_vf_en) { + bgx_idx = NIC_GET_BGX_FROM_VF_LMAC_MAP(nic->vf_lmac_map[vf]); + lmac = NIC_GET_LMAC_FROM_VF_LMAC_MAP(nic->vf_lmac_map[vf]); + + mac = bgx_get_lmac_mac(nic->node, bgx_idx, lmac); + if (mac) + memcpy((u8 *)&mbx.nic_cfg.mac_addr, mac, 6); + + while (timeout-- && (link <= 0)) { + link = bgx_poll_for_link(nic->node, bgx_idx, lmac); + debug("Link status: %d\n", link); + if (link <= 0) + mdelay(2000); + } + } +#ifdef VNIC_MULTI_QSET_SUPPORT + mbx.nic_cfg.sqs_mode = (vf >= nic->num_vf_en) ? true : false; +#endif + mbx.nic_cfg.node_id = nic->node; + + mbx.nic_cfg.loopback_supported = vf < nic->num_vf_en; + + nic_send_msg_to_vf(nic, vf, &mbx); +} + +/* ACKs VF's mailbox message + * @vf: VF to which ACK to be sent + */ +static void nic_mbx_send_ack(struct nicpf *nic, int vf) +{ + union nic_mbx mbx = {}; + + mbx.msg.msg = NIC_MBOX_MSG_ACK; + nic_send_msg_to_vf(nic, vf, &mbx); +} + +/* NACKs VF's mailbox message that PF is not able to + * complete the action + * @vf: VF to which ACK to be sent + */ +static void nic_mbx_send_nack(struct nicpf *nic, int vf) +{ + union nic_mbx mbx = {}; + + mbx.msg.msg = NIC_MBOX_MSG_NACK; + nic_send_msg_to_vf(nic, vf, &mbx); +} + +static int nic_config_loopback(struct nicpf *nic, struct set_loopback *lbk) +{ + int bgx_idx, lmac_idx; + + if (lbk->vf_id > nic->num_vf_en) + return -1; + + bgx_idx = NIC_GET_BGX_FROM_VF_LMAC_MAP(nic->vf_lmac_map[lbk->vf_id]); + lmac_idx = NIC_GET_LMAC_FROM_VF_LMAC_MAP(nic->vf_lmac_map[lbk->vf_id]); + + bgx_lmac_internal_loopback(nic->node, bgx_idx, lmac_idx, lbk->enable); + + return 0; +} + +/* Interrupt handler to handle mailbox messages from VFs */ +void nic_handle_mbx_intr(struct nicpf *nic, int vf) +{ + union nic_mbx mbx = {}; + u64 *mbx_data; + u64 mbx_addr; + u64 reg_addr; + u64 cfg; + int bgx, lmac; + int i; + int ret = 0; + + nic->mbx_lock[vf] = true; + + mbx_addr = nic_get_mbx_addr(vf); + mbx_data = (u64 *)&mbx; + + for (i = 0; i < NIC_PF_VF_MAILBOX_SIZE; i++) { + *mbx_data = nic_reg_read(nic, mbx_addr); + mbx_data++; + mbx_addr += sizeof(u64); + } + + debug("%s: Mailbox msg %d from VF%d\n", __func__, mbx.msg.msg, vf); + switch (mbx.msg.msg) { + case NIC_MBOX_MSG_READY: + nic_mbx_send_ready(nic, vf); + if (vf < nic->num_vf_en) { + nic->link[vf] = 0; + nic->duplex[vf] = 0; + nic->speed[vf] = 0; + } + ret = 1; + break; + case NIC_MBOX_MSG_QS_CFG: + reg_addr = NIC_PF_QSET_0_127_CFG | + (mbx.qs.num << NIC_QS_ID_SHIFT); + cfg = mbx.qs.cfg; +#ifdef VNIC_MULTI_QSET_SUPPORT + /* Check if its a secondary Qset */ + if (vf >= nic->num_vf_en) { + cfg = cfg & (~0x7FULL); + /* Assign this Qset to primary Qset's VF */ + cfg |= nic->pqs_vf[vf]; + } +#endif + nic_reg_write(nic, reg_addr, cfg); + break; + case NIC_MBOX_MSG_RQ_CFG: + reg_addr = NIC_PF_QSET_0_127_RQ_0_7_CFG | + (mbx.rq.qs_num << NIC_QS_ID_SHIFT) | + (mbx.rq.rq_num << NIC_Q_NUM_SHIFT); + nic_reg_write(nic, reg_addr, mbx.rq.cfg); + /* Enable CQE_RX2_S extension in CQE_RX descriptor. + * This gets appended by default on 81xx/83xx chips, + * for consistency enabling the same on 88xx pass2 + * where this is introduced. + */ + if (pass2_silicon(nic->rev_id, nic->hw->model_id)) + nic_reg_write(nic, NIC_PF_RX_CFG, 0x01); + break; + case NIC_MBOX_MSG_RQ_BP_CFG: + reg_addr = NIC_PF_QSET_0_127_RQ_0_7_BP_CFG | + (mbx.rq.qs_num << NIC_QS_ID_SHIFT) | + (mbx.rq.rq_num << NIC_Q_NUM_SHIFT); + nic_reg_write(nic, reg_addr, mbx.rq.cfg); + break; + case NIC_MBOX_MSG_RQ_SW_SYNC: + ret = nic_rcv_queue_sw_sync(nic); + break; + case NIC_MBOX_MSG_RQ_DROP_CFG: + reg_addr = NIC_PF_QSET_0_127_RQ_0_7_DROP_CFG | + (mbx.rq.qs_num << NIC_QS_ID_SHIFT) | + (mbx.rq.rq_num << NIC_Q_NUM_SHIFT); + nic_reg_write(nic, reg_addr, mbx.rq.cfg); + break; + case NIC_MBOX_MSG_SQ_CFG: + reg_addr = NIC_PF_QSET_0_127_SQ_0_7_CFG | + (mbx.sq.qs_num << NIC_QS_ID_SHIFT) | + (mbx.sq.sq_num << NIC_Q_NUM_SHIFT); + nic_reg_write(nic, reg_addr, mbx.sq.cfg); + nic_tx_channel_cfg(nic, mbx.qs.num, + (struct sq_cfg_msg *)&mbx.sq); + break; + case NIC_MBOX_MSG_SET_MAC: +#ifdef VNIC_MULTI_QSET_SUPPORT + if (vf >= nic->num_vf_en) + break; +#endif + lmac = mbx.mac.vf_id; + bgx = NIC_GET_BGX_FROM_VF_LMAC_MAP(nic->vf_lmac_map[lmac]); + lmac = NIC_GET_LMAC_FROM_VF_LMAC_MAP(nic->vf_lmac_map[lmac]); + bgx_set_lmac_mac(nic->node, bgx, lmac, mbx.mac.mac_addr); + break; + case NIC_MBOX_MSG_SET_MAX_FRS: + ret = nic_update_hw_frs(nic, mbx.frs.max_frs, + mbx.frs.vf_id); + break; + case NIC_MBOX_MSG_CPI_CFG: + nic_config_cpi(nic, &mbx.cpi_cfg); + break; +#ifdef VNIC_RSS_SUPPORT + case NIC_MBOX_MSG_RSS_SIZE: + nic_send_rss_size(nic, vf); + goto unlock; + case NIC_MBOX_MSG_RSS_CFG: + case NIC_MBOX_MSG_RSS_CFG_CONT: + nic_config_rss(nic, &mbx.rss_cfg); + break; +#endif + case NIC_MBOX_MSG_CFG_DONE: + /* Last message of VF config msg sequence */ + nic->vf_enabled[vf] = true; + if (vf >= nic->lmac_cnt) + goto unlock; + + bgx = NIC_GET_BGX_FROM_VF_LMAC_MAP(nic->vf_lmac_map[vf]); + lmac = NIC_GET_LMAC_FROM_VF_LMAC_MAP(nic->vf_lmac_map[vf]); + + bgx_lmac_rx_tx_enable(nic->node, bgx, lmac, true); + goto unlock; + case NIC_MBOX_MSG_SHUTDOWN: + /* First msg in VF teardown sequence */ + nic->vf_enabled[vf] = false; +#ifdef VNIC_MULTI_QSET_SUPPORT + if (vf >= nic->num_vf_en) + nic->sqs_used[vf - nic->num_vf_en] = false; + nic->pqs_vf[vf] = 0; +#endif + if (vf >= nic->lmac_cnt) + break; + + bgx = NIC_GET_BGX_FROM_VF_LMAC_MAP(nic->vf_lmac_map[vf]); + lmac = NIC_GET_LMAC_FROM_VF_LMAC_MAP(nic->vf_lmac_map[vf]); + + bgx_lmac_rx_tx_enable(nic->node, bgx, lmac, false); + break; +#ifdef VNIC_MULTI_QSET_SUPPORT + case NIC_MBOX_MSG_ALLOC_SQS: + nic_alloc_sqs(nic, &mbx.sqs_alloc); + goto unlock; + case NIC_MBOX_MSG_NICVF_PTR: + nic->nicvf[vf] = mbx.nicvf.nicvf; + break; + case NIC_MBOX_MSG_PNICVF_PTR: + nic_send_pnicvf(nic, vf); + goto unlock; + case NIC_MBOX_MSG_SNICVF_PTR: + nic_send_snicvf(nic, &mbx.nicvf); + goto unlock; +#endif + case NIC_MBOX_MSG_LOOPBACK: + ret = nic_config_loopback(nic, &mbx.lbk); + break; + default: + printf("Invalid msg from VF%d, msg 0x%x\n", vf, mbx.msg.msg); + break; + } + + if (!ret) + nic_mbx_send_ack(nic, vf); + else if (mbx.msg.msg != NIC_MBOX_MSG_READY) + nic_mbx_send_nack(nic, vf); +unlock: + nic->mbx_lock[vf] = false; +} + +static int nic_rcv_queue_sw_sync(struct nicpf *nic) +{ + int timeout = 20; + + nic_reg_write(nic, NIC_PF_SW_SYNC_RX, 0x01); + while (timeout) { + if (nic_reg_read(nic, NIC_PF_SW_SYNC_RX_DONE) & 0x1) + break; + udelay(2000); + timeout--; + } + nic_reg_write(nic, NIC_PF_SW_SYNC_RX, 0x00); + if (!timeout) { + printf("Recevie queue software sync failed"); + return 1; + } + return 0; +} + +static int nic_update_hw_frs(struct nicpf *nic, int new_frs, int vf) +{ + u64 *pkind = (u64 *)&nic->pkind; + + if (new_frs > NIC_HW_MAX_FRS || new_frs < NIC_HW_MIN_FRS) { + printf("Invalid MTU setting from VF%d rejected,", vf); + printf(" should be between %d and %d\n", NIC_HW_MIN_FRS, + NIC_HW_MAX_FRS); + return 1; + } + new_frs += ETH_HLEN; + if (new_frs <= nic->pkind.maxlen) + return 0; + + nic->pkind.maxlen = new_frs; + + nic_reg_write(nic, NIC_PF_PKIND_0_15_CFG, *pkind); + return 0; +} + +/* Set minimum transmit packet size */ +static void nic_set_tx_pkt_pad(struct nicpf *nic, int size) +{ + int lmac; + u64 lmac_cfg; + struct hw_info *hw = nic->hw; + int max_lmac = nic->hw->bgx_cnt * MAX_LMAC_PER_BGX; + + /* Max value that can be set is 60 */ + if (size > 52) + size = 52; + + /* CN81XX has RGX configured as FAKE BGX, adjust mac_lmac accordingly */ + if (hw->chans_per_rgx) + max_lmac = ((nic->hw->bgx_cnt - 1) * MAX_LMAC_PER_BGX) + 1; + + for (lmac = 0; lmac < max_lmac; lmac++) { + lmac_cfg = nic_reg_read(nic, NIC_PF_LMAC_0_7_CFG | (lmac << 3)); + lmac_cfg &= ~(0xF << 2); + lmac_cfg |= ((size / 4) << 2); + nic_reg_write(nic, NIC_PF_LMAC_0_7_CFG | (lmac << 3), lmac_cfg); + } +} + +/* Function to check number of LMACs present and set VF to LMAC mapping. + * Mapping will be used while initializing channels. + */ +static void nic_set_lmac_vf_mapping(struct nicpf *nic) +{ + int bgx, bgx_count, next_bgx_lmac = 0; + int lmac, lmac_cnt = 0; + u64 lmac_credit; + + nic->num_vf_en = 0; + if (nic->flags & NIC_TNS_ENABLED) { + nic->num_vf_en = DEFAULT_NUM_VF_ENABLED; + return; + } + + bgx_get_count(nic->node, &bgx_count); + debug("bgx_count: %d\n", bgx_count); + + for (bgx = 0; bgx < nic->hw->bgx_cnt; bgx++) { + if (!(bgx_count & (1 << bgx))) + continue; + nic->bgx_cnt++; + lmac_cnt = bgx_get_lmac_count(nic->node, bgx); + debug("lmac_cnt: %d for BGX%d\n", lmac_cnt, bgx); + for (lmac = 0; lmac < lmac_cnt; lmac++) + nic->vf_lmac_map[next_bgx_lmac++] = + NIC_SET_VF_LMAC_MAP(bgx, lmac); + nic->num_vf_en += lmac_cnt; + + /* Program LMAC credits */ + lmac_credit = (1ull << 1); /* chennel credit enable */ + lmac_credit |= (0x1ff << 2); + lmac_credit |= (((((48 * 1024) / lmac_cnt) - + NIC_HW_MAX_FRS) / 16) << 12); + lmac = bgx * MAX_LMAC_PER_BGX; + for (; lmac < lmac_cnt + (bgx * MAX_LMAC_PER_BGX); lmac++) + nic_reg_write(nic, NIC_PF_LMAC_0_7_CREDIT + (lmac * 8), + lmac_credit); + } +} + +static void nic_get_hw_info(struct nicpf *nic) +{ + u16 sdevid; + struct hw_info *hw = nic->hw; + + dm_pci_read_config16(nic->udev, PCI_SUBSYSTEM_ID, &sdevid); + + switch (sdevid) { + case PCI_SUBSYS_DEVID_88XX_NIC_PF: + hw->bgx_cnt = MAX_BGX_PER_NODE; + hw->chans_per_lmac = 16; + hw->chans_per_bgx = 128; + hw->cpi_cnt = 2048; + hw->rssi_cnt = 4096; + hw->rss_ind_tbl_size = NIC_MAX_RSS_IDR_TBL_SIZE; + hw->tl3_cnt = 256; + hw->tl2_cnt = 64; + hw->tl1_cnt = 2; + hw->tl1_per_bgx = true; + hw->model_id = 0x88; + break; + case PCI_SUBSYS_DEVID_81XX_NIC_PF: + hw->bgx_cnt = MAX_BGX_PER_NODE; + hw->chans_per_lmac = 8; + hw->chans_per_bgx = 32; + hw->chans_per_rgx = 8; + hw->chans_per_lbk = 24; + hw->cpi_cnt = 512; + hw->rssi_cnt = 256; + hw->rss_ind_tbl_size = 32; /* Max RSSI / Max interfaces */ + hw->tl3_cnt = 64; + hw->tl2_cnt = 16; + hw->tl1_cnt = 10; + hw->tl1_per_bgx = false; + hw->model_id = 0x81; + break; + case PCI_SUBSYS_DEVID_83XX_NIC_PF: + hw->bgx_cnt = MAX_BGX_PER_NODE; + hw->chans_per_lmac = 8; + hw->chans_per_bgx = 32; + hw->chans_per_lbk = 64; + hw->cpi_cnt = 2048; + hw->rssi_cnt = 1024; + hw->rss_ind_tbl_size = 64; /* Max RSSI / Max interfaces */ + hw->tl3_cnt = 256; + hw->tl2_cnt = 64; + hw->tl1_cnt = 18; + hw->tl1_per_bgx = false; + hw->model_id = 0x83; + break; + } + + hw->tl4_cnt = MAX_QUEUES_PER_QSET * pci_sriov_get_totalvfs(nic->udev); +} + +static void nic_init_hw(struct nicpf *nic) +{ + int i; + u64 reg; + u64 *pkind = (u64 *)&nic->pkind; + + /* Get HW capability info */ + nic_get_hw_info(nic); + + /* Enable NIC HW block */ + nic_reg_write(nic, NIC_PF_CFG, 0x3); + + /* Enable backpressure */ + nic_reg_write(nic, NIC_PF_BP_CFG, (1ULL << 6) | 0x03); + nic_reg_write(nic, NIC_PF_INTF_0_1_BP_CFG, (1ULL << 63) | 0x08); + nic_reg_write(nic, NIC_PF_INTF_0_1_BP_CFG + (1 << 8), + (1ULL << 63) | 0x09); + + for (i = 0; i < NIC_MAX_CHANS; i++) + nic_reg_write(nic, NIC_PF_CHAN_0_255_TX_CFG | (i << 3), 1); + + if (nic->flags & NIC_TNS_ENABLED) { + reg = NIC_TNS_MODE << 7; + reg |= 0x06; + nic_reg_write(nic, NIC_PF_INTF_0_1_SEND_CFG, reg); + reg &= ~0xFull; + reg |= 0x07; + nic_reg_write(nic, NIC_PF_INTF_0_1_SEND_CFG | (1 << 8), reg); + } else { + /* Disable TNS mode on both interfaces */ + reg = NIC_TNS_BYPASS_MODE << 7; + reg |= 0x08; /* Block identifier */ + nic_reg_write(nic, NIC_PF_INTF_0_1_SEND_CFG, reg); + reg &= ~0xFull; + reg |= 0x09; + nic_reg_write(nic, NIC_PF_INTF_0_1_SEND_CFG | (1 << 8), reg); + } + + /* PKIND configuration */ + nic->pkind.minlen = 0; + nic->pkind.maxlen = NIC_HW_MAX_FRS + ETH_HLEN; + nic->pkind.lenerr_en = 1; + nic->pkind.rx_hdr = 0; + nic->pkind.hdr_sl = 0; + + for (i = 0; i < NIC_MAX_PKIND; i++) + nic_reg_write(nic, NIC_PF_PKIND_0_15_CFG | (i << 3), *pkind); + + nic_set_tx_pkt_pad(nic, NIC_HW_MIN_FRS); + + /* Timer config */ + nic_reg_write(nic, NIC_PF_INTR_TIMER_CFG, NICPF_CLK_PER_INT_TICK); +} + +/* Channel parse index configuration */ +static void nic_config_cpi(struct nicpf *nic, struct cpi_cfg_msg *cfg) +{ + struct hw_info *hw = nic->hw; + u32 vnic, bgx, lmac, chan; + u32 padd, cpi_count = 0; + u64 cpi_base, cpi, rssi_base, rssi; + u8 qset, rq_idx = 0; + + vnic = cfg->vf_id; + bgx = NIC_GET_BGX_FROM_VF_LMAC_MAP(nic->vf_lmac_map[vnic]); + lmac = NIC_GET_LMAC_FROM_VF_LMAC_MAP(nic->vf_lmac_map[vnic]); + + chan = (lmac * hw->chans_per_lmac) + (bgx * hw->chans_per_bgx); + cpi_base = vnic * NIC_MAX_CPI_PER_LMAC; + rssi_base = vnic * hw->rss_ind_tbl_size; + + /* Rx channel configuration */ + nic_reg_write(nic, NIC_PF_CHAN_0_255_RX_BP_CFG | (chan << 3), + (1ull << 63) | (vnic << 0)); + nic_reg_write(nic, NIC_PF_CHAN_0_255_RX_CFG | (chan << 3), + ((u64)cfg->cpi_alg << 62) | (cpi_base << 48)); + + if (cfg->cpi_alg == CPI_ALG_NONE) + cpi_count = 1; + else if (cfg->cpi_alg == CPI_ALG_VLAN) /* 3 bits of PCP */ + cpi_count = 8; + else if (cfg->cpi_alg == CPI_ALG_VLAN16) /* 3 bits PCP + DEI */ + cpi_count = 16; + else if (cfg->cpi_alg == CPI_ALG_DIFF) /* 6bits DSCP */ + cpi_count = NIC_MAX_CPI_PER_LMAC; + + /* RSS Qset, Qidx mapping */ + qset = cfg->vf_id; + rssi = rssi_base; + for (; rssi < (rssi_base + cfg->rq_cnt); rssi++) { + nic_reg_write(nic, NIC_PF_RSSI_0_4097_RQ | (rssi << 3), + (qset << 3) | rq_idx); + rq_idx++; + } + + rssi = 0; + cpi = cpi_base; + for (; cpi < (cpi_base + cpi_count); cpi++) { + /* Determine port to channel adder */ + if (cfg->cpi_alg != CPI_ALG_DIFF) + padd = cpi % cpi_count; + else + padd = cpi % 8; /* 3 bits CS out of 6bits DSCP */ + + /* Leave RSS_SIZE as '0' to disable RSS */ + if (pass1_silicon(nic->rev_id, nic->hw->model_id)) { + nic_reg_write(nic, NIC_PF_CPI_0_2047_CFG | (cpi << 3), + (vnic << 24) | (padd << 16) | + (rssi_base + rssi)); + } else { + /* Set MPI_ALG to '0' to disable MCAM parsing */ + nic_reg_write(nic, NIC_PF_CPI_0_2047_CFG | (cpi << 3), + (padd << 16)); + /* MPI index is same as CPI if MPI_ALG is not enabled */ + nic_reg_write(nic, NIC_PF_MPI_0_2047_CFG | (cpi << 3), + (vnic << 24) | (rssi_base + rssi)); + } + + if ((rssi + 1) >= cfg->rq_cnt) + continue; + + if (cfg->cpi_alg == CPI_ALG_VLAN) + rssi++; + else if (cfg->cpi_alg == CPI_ALG_VLAN16) + rssi = ((cpi - cpi_base) & 0xe) >> 1; + else if (cfg->cpi_alg == CPI_ALG_DIFF) + rssi = ((cpi - cpi_base) & 0x38) >> 3; + } + nic->cpi_base[cfg->vf_id] = cpi_base; + nic->rssi_base[cfg->vf_id] = rssi_base; +} + +/* Transmit channel configuration (TL4 -> TL3 -> Chan) + * VNIC0-SQ0 -> TL4(0) -> TL4A(0) -> TL3[0] -> BGX0/LMAC0/Chan0 + * VNIC1-SQ0 -> TL4(8) -> TL4A(2) -> TL3[2] -> BGX0/LMAC1/Chan0 + * VNIC2-SQ0 -> TL4(16) -> TL4A(4) -> TL3[4] -> BGX0/LMAC2/Chan0 + * VNIC3-SQ0 -> TL4(32) -> TL4A(6) -> TL3[6] -> BGX0/LMAC3/Chan0 + * VNIC4-SQ0 -> TL4(512) -> TL4A(128) -> TL3[128] -> BGX1/LMAC0/Chan0 + * VNIC5-SQ0 -> TL4(520) -> TL4A(130) -> TL3[130] -> BGX1/LMAC1/Chan0 + * VNIC6-SQ0 -> TL4(528) -> TL4A(132) -> TL3[132] -> BGX1/LMAC2/Chan0 + * VNIC7-SQ0 -> TL4(536) -> TL4A(134) -> TL3[134] -> BGX1/LMAC3/Chan0 + */ +static void nic_tx_channel_cfg(struct nicpf *nic, u8 vnic, + struct sq_cfg_msg *sq) +{ + struct hw_info *hw = nic->hw; + u32 bgx, lmac, chan; + u32 tl2, tl3, tl4; + u32 rr_quantum; + u8 sq_idx = sq->sq_num; + u8 pqs_vnic = vnic; + int svf; + u16 sdevid; + + dm_pci_read_config16(nic->udev, PCI_SUBSYSTEM_ID, &sdevid); + + bgx = NIC_GET_BGX_FROM_VF_LMAC_MAP(nic->vf_lmac_map[pqs_vnic]); + lmac = NIC_GET_LMAC_FROM_VF_LMAC_MAP(nic->vf_lmac_map[pqs_vnic]); + + /* 24 bytes for FCS, IPG and preamble */ + rr_quantum = ((NIC_HW_MAX_FRS + 24) / 4); + + /* For 88xx 0-511 TL4 transmits via BGX0 and + * 512-1023 TL4s transmit via BGX1. + */ + if (hw->tl1_per_bgx) { + tl4 = bgx * (hw->tl4_cnt / hw->bgx_cnt); + if (!sq->sqs_mode) { + tl4 += (lmac * MAX_QUEUES_PER_QSET); + } else { + for (svf = 0; svf < MAX_SQS_PER_VF_SINGLE_NODE; svf++) { + if (nic->vf_sqs[pqs_vnic][svf] == vnic) + break; + } + tl4 += (MAX_LMAC_PER_BGX * MAX_QUEUES_PER_QSET); + tl4 += (lmac * MAX_QUEUES_PER_QSET * + MAX_SQS_PER_VF_SINGLE_NODE); + tl4 += (svf * MAX_QUEUES_PER_QSET); + } + } else { + tl4 = (vnic * MAX_QUEUES_PER_QSET); + } + + tl4 += sq_idx; + + tl3 = tl4 / (hw->tl4_cnt / hw->tl3_cnt); + nic_reg_write(nic, NIC_PF_QSET_0_127_SQ_0_7_CFG2 | + ((u64)vnic << NIC_QS_ID_SHIFT) | + ((u32)sq_idx << NIC_Q_NUM_SHIFT), tl4); + nic_reg_write(nic, NIC_PF_TL4_0_1023_CFG | (tl4 << 3), + ((u64)vnic << 27) | ((u32)sq_idx << 24) | rr_quantum); + + nic_reg_write(nic, NIC_PF_TL3_0_255_CFG | (tl3 << 3), rr_quantum); + + /* On 88xx 0-127 channels are for BGX0 and + * 127-255 channels for BGX1. + * + * On 81xx/83xx TL3_CHAN reg should be configured with channel + * within LMAC i.e 0-7 and not the actual channel number like on 88xx + */ + chan = (lmac * hw->chans_per_lmac) + (bgx * hw->chans_per_bgx); + if (hw->tl1_per_bgx) + nic_reg_write(nic, NIC_PF_TL3_0_255_CHAN | (tl3 << 3), chan); + else + nic_reg_write(nic, NIC_PF_TL3_0_255_CHAN | (tl3 << 3), 0); + + /* Enable backpressure on the channel */ + nic_reg_write(nic, NIC_PF_CHAN_0_255_TX_CFG | (chan << 3), 1); + + tl2 = tl3 >> 2; + nic_reg_write(nic, NIC_PF_TL3A_0_63_CFG | (tl2 << 3), tl2); + nic_reg_write(nic, NIC_PF_TL2_0_63_CFG | (tl2 << 3), rr_quantum); + /* No priorities as of now */ + nic_reg_write(nic, NIC_PF_TL2_0_63_PRI | (tl2 << 3), 0x00); + + /* Unlike 88xx where TL2s 0-31 transmits to TL1 '0' and rest to TL1 '1' + * on 81xx/83xx TL2 needs to be configured to transmit to one of the + * possible LMACs. + * + * This register doesn't exist on 88xx. + */ + if (!hw->tl1_per_bgx) + nic_reg_write(nic, NIC_PF_TL2_LMAC | (tl2 << 3), + lmac + (bgx * MAX_LMAC_PER_BGX)); +} + +int nic_initialize(struct udevice *dev) +{ + struct nicpf *nic = dev_get_priv(dev); + + nic->udev = dev; + nic->hw = calloc(1, sizeof(struct hw_info)); + if (!nic->hw) + return -ENOMEM; + + /* MAP PF's configuration registers */ + nic->reg_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + if (!nic->reg_base) { + printf("Cannot map config register space, aborting\n"); + goto exit; + } + + nic->node = node_id(nic->reg_base); + dm_pci_read_config8(dev, PCI_REVISION_ID, &nic->rev_id); + + /* By default set NIC in TNS bypass mode */ + nic->flags &= ~NIC_TNS_ENABLED; + + /* Initialize hardware */ + nic_init_hw(nic); + + nic_set_lmac_vf_mapping(nic); + + /* Set RSS TBL size for each VF */ + nic->rss_ind_tbl_size = NIC_MAX_RSS_IDR_TBL_SIZE; + + nic->rss_ind_tbl_size = rounddown_pow_of_two(nic->rss_ind_tbl_size); + + return 0; +exit: + free(nic->hw); + return -ENODEV; +} + +int octeontx_nic_probe(struct udevice *dev) +{ + int ret = 0; + struct nicpf *nicpf = dev_get_priv(dev); + + nicpf->udev = dev; + ret = nic_initialize(dev); + if (ret < 0) { + printf("couldn't initialize NIC PF\n"); + return ret; + } +#if defined(CONFIG_PCI_SRIOV) + ret = pci_sriov_init(dev, nicpf->num_vf_en); + if (ret < 0) + printf("enabling SRIOV failed for num VFs %d\n", + nicpf->num_vf_en); +#endif + return ret; +} + +U_BOOT_DRIVER(octeontx_nic) = { + .name = "octeontx_nic", + .id = UCLASS_MISC, + .probe = octeontx_nic_probe, + .priv_auto_alloc_size = sizeof(struct nicpf), +}; + +static struct pci_device_id octeontx_nic_supported[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_NIC) }, + {} +}; + +U_BOOT_PCI_DEVICE(octeontx_nic, octeontx_nic_supported); + diff --git a/drivers/net/octeontx/nic_reg.h b/drivers/net/octeontx/nic_reg.h new file mode 100644 index 0000000000..d8a4a7bd39 --- /dev/null +++ b/drivers/net/octeontx/nic_reg.h @@ -0,0 +1,252 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef NIC_REG_H +#define NIC_REG_H + +#define NIC_PF_REG_COUNT 29573 +#define NIC_VF_REG_COUNT 249 + +/* Physical function register offsets */ +#define NIC_PF_CFG (0x0000) +#define NIC_PF_STATUS (0x0010) + +#define NIC_PF_INTR_TIMER_CFG (0x0030) +#define NIC_PF_BIST_STATUS (0x0040) +#define NIC_PF_SOFT_RESET (0x0050) + +#define NIC_PF_TCP_TIMER (0x0060) +#define NIC_PF_BP_CFG (0x0080) +#define NIC_PF_RRM_CFG (0x0088) +#define NIC_PF_CQM_CF (0x00A0) +#define NIC_PF_CNM_CF (0x00A8) +#define NIC_PF_CNM_STATUS (0x00B0) +#define NIC_PF_CQ_AVG_CFG (0x00C0) +#define NIC_PF_RRM_AVG_CFG (0x00C8) + +#define NIC_PF_INTF_0_1_SEND_CFG (0x0200) +#define NIC_PF_INTF_0_1_BP_CFG (0x0208) +#define NIC_PF_INTF_0_1_BP_DIS_0_1 (0x0210) +#define NIC_PF_INTF_0_1_BP_SW_0_1 (0x0220) +#define NIC_PF_RBDR_BP_STATE_0_3 (0x0240) + +#define NIC_PF_MAILBOX_INT (0x0410) +#define NIC_PF_MAILBOX_INT_W1S (0x0430) +#define NIC_PF_MAILBOX_ENA_W1C (0x0450) +#define NIC_PF_MAILBOX_ENA_W1S (0x0470) + +#define NIC_PF_RX_ETYPE_0_7 (0x0500) +#define NIC_PF_RX_CFG (0x05D0) +#define NIC_PF_PKIND_0_15_CFG (0x0600) + +#define NIC_PF_ECC0_FLIP0 (0x1000) +#define NIC_PF_ECC1_FLIP0 (0x1008) +#define NIC_PF_ECC2_FLIP0 (0x1010) +#define NIC_PF_ECC3_FLIP0 (0x1018) +#define NIC_PF_ECC0_FLIP1 (0x1080) +#define NIC_PF_ECC1_FLIP1 (0x1088) +#define NIC_PF_ECC2_FLIP1 (0x1090) +#define NIC_PF_ECC3_FLIP1 (0x1098) +#define NIC_PF_ECC0_CDIS (0x1100) +#define NIC_PF_ECC1_CDIS (0x1108) +#define NIC_PF_ECC2_CDIS (0x1110) +#define NIC_PF_ECC3_CDIS (0x1118) +#define NIC_PF_BIST0_STATUS (0x1280) +#define NIC_PF_BIST1_STATUS (0x1288) +#define NIC_PF_BIST2_STATUS (0x1290) +#define NIC_PF_BIST3_STATUS (0x1298) + +#define NIC_PF_ECC0_SBE_INT (0x2000) +#define NIC_PF_ECC0_SBE_INT_W1S (0x2008) +#define NIC_PF_ECC0_SBE_ENA_W1C (0x2010) +#define NIC_PF_ECC0_SBE_ENA_W1S (0x2018) +#define NIC_PF_ECC0_DBE_INT (0x2100) +#define NIC_PF_ECC0_DBE_INT_W1S (0x2108) +#define NIC_PF_ECC0_DBE_ENA_W1C (0x2110) +#define NIC_PF_ECC0_DBE_ENA_W1S (0x2118) + +#define NIC_PF_ECC1_SBE_INT (0x2200) +#define NIC_PF_ECC1_SBE_INT_W1S (0x2208) +#define NIC_PF_ECC1_SBE_ENA_W1C (0x2210) +#define NIC_PF_ECC1_SBE_ENA_W1S (0x2218) +#define NIC_PF_ECC1_DBE_INT (0x2300) +#define NIC_PF_ECC1_DBE_INT_W1S (0x2308) +#define NIC_PF_ECC1_DBE_ENA_W1C (0x2310) +#define NIC_PF_ECC1_DBE_ENA_W1S (0x2318) + +#define NIC_PF_ECC2_SBE_INT (0x2400) +#define NIC_PF_ECC2_SBE_INT_W1S (0x2408) +#define NIC_PF_ECC2_SBE_ENA_W1C (0x2410) +#define NIC_PF_ECC2_SBE_ENA_W1S (0x2418) +#define NIC_PF_ECC2_DBE_INT (0x2500) +#define NIC_PF_ECC2_DBE_INT_W1S (0x2508) +#define NIC_PF_ECC2_DBE_ENA_W1C (0x2510) +#define NIC_PF_ECC2_DBE_ENA_W1S (0x2518) + +#define NIC_PF_ECC3_SBE_INT (0x2600) +#define NIC_PF_ECC3_SBE_INT_W1S (0x2608) +#define NIC_PF_ECC3_SBE_ENA_W1C (0x2610) +#define NIC_PF_ECC3_SBE_ENA_W1S (0x2618) +#define NIC_PF_ECC3_DBE_INT (0x2700) +#define NIC_PF_ECC3_DBE_INT_W1S (0x2708) +#define NIC_PF_ECC3_DBE_ENA_W1C (0x2710) +#define NIC_PF_ECC3_DBE_ENA_W1S (0x2718) + +#define NIC_PF_CPI_0_2047_CFG (0x200000) +#define NIC_PF_MPI_0_2047_CFG (0x210000) +#define NIC_PF_RSSI_0_4097_RQ (0x220000) +#define NIC_PF_LMAC_0_7_CFG (0x240000) +#define NIC_PF_LMAC_0_7_SW_XOFF (0x242000) +#define NIC_PF_LMAC_0_7_CREDIT (0x244000) +#define NIC_PF_CHAN_0_255_TX_CFG (0x400000) +#define NIC_PF_CHAN_0_255_RX_CFG (0x420000) +#define NIC_PF_CHAN_0_255_SW_XOFF (0x440000) +#define NIC_PF_CHAN_0_255_CREDIT (0x460000) +#define NIC_PF_CHAN_0_255_RX_BP_CFG (0x480000) + +#define NIC_PF_SW_SYNC_RX (0x490000) + +#define NIC_PF_SW_SYNC_RX_DONE (0x490008) +#define NIC_PF_TL2_0_63_CFG (0x500000) +#define NIC_PF_TL2_0_63_PRI (0x520000) +#define NIC_PF_TL2_LMAC (0x540000) +#define NIC_PF_TL2_0_63_SH_STATUS (0x580000) +#define NIC_PF_TL3A_0_63_CFG (0x5F0000) +#define NIC_PF_TL3_0_255_CFG (0x600000) +#define NIC_PF_TL3_0_255_CHAN (0x620000) +#define NIC_PF_TL3_0_255_PIR (0x640000) +#define NIC_PF_TL3_0_255_SW_XOFF (0x660000) +#define NIC_PF_TL3_0_255_CNM_RATE (0x680000) +#define NIC_PF_TL3_0_255_SH_STATUS (0x6A0000) +#define NIC_PF_TL4A_0_255_CFG (0x6F0000) +#define NIC_PF_TL4_0_1023_CFG (0x800000) +#define NIC_PF_TL4_0_1023_SW_XOFF (0x820000) +#define NIC_PF_TL4_0_1023_SH_STATUS (0x840000) +#define NIC_PF_TL4A_0_1023_CNM_RATE (0x880000) +#define NIC_PF_TL4A_0_1023_CNM_STATUS (0x8A0000) + +#define NIC_PF_VF_0_127_MAILBOX_0_1 (0x20002030) +#define NIC_PF_VNIC_0_127_TX_STAT_0_4 (0x20004000) +#define NIC_PF_VNIC_0_127_RX_STAT_0_13 (0x20004100) +#define NIC_PF_QSET_0_127_LOCK_0_15 (0x20006000) +#define NIC_PF_QSET_0_127_CFG (0x20010000) +#define NIC_PF_QSET_0_127_RQ_0_7_CFG (0x20010400) +#define NIC_PF_QSET_0_127_RQ_0_7_DROP_CFG (0x20010420) +#define NIC_PF_QSET_0_127_RQ_0_7_BP_CFG (0x20010500) +#define NIC_PF_QSET_0_127_RQ_0_7_STAT_0_1 (0x20010600) +#define NIC_PF_QSET_0_127_SQ_0_7_CFG (0x20010C00) +#define NIC_PF_QSET_0_127_SQ_0_7_CFG2 (0x20010C08) +#define NIC_PF_QSET_0_127_SQ_0_7_STAT_0_1 (0x20010D00) + +#define NIC_PF_MSIX_VEC_0_18_ADDR (0x000000) +#define NIC_PF_MSIX_VEC_0_CTL (0x000008) +#define NIC_PF_MSIX_PBA_0 (0x0F0000) + +/* Virtual function register offsets */ +#define NIC_VNIC_CFG (0x000020) +#define NIC_VF_PF_MAILBOX_0_1 (0x000130) +#define NIC_VF_INT (0x000200) +#define NIC_VF_INT_W1S (0x000220) +#define NIC_VF_ENA_W1C (0x000240) +#define NIC_VF_ENA_W1S (0x000260) + +#define NIC_VNIC_RSS_CFG (0x0020E0) +#define NIC_VNIC_RSS_KEY_0_4 (0x002200) +#define NIC_VNIC_TX_STAT_0_4 (0x004000) +#define NIC_VNIC_RX_STAT_0_13 (0x004100) +#define NIC_QSET_RQ_GEN_CFG (0x010010) + +#define NIC_QSET_CQ_0_7_CFG (0x010400) +#define NIC_QSET_CQ_0_7_CFG2 (0x010408) +#define NIC_QSET_CQ_0_7_THRESH (0x010410) +#define NIC_QSET_CQ_0_7_BASE (0x010420) +#define NIC_QSET_CQ_0_7_HEAD (0x010428) +#define NIC_QSET_CQ_0_7_TAIL (0x010430) +#define NIC_QSET_CQ_0_7_DOOR (0x010438) +#define NIC_QSET_CQ_0_7_STATUS (0x010440) +#define NIC_QSET_CQ_0_7_STATUS2 (0x010448) +#define NIC_QSET_CQ_0_7_DEBUG (0x010450) + +#define NIC_QSET_RQ_0_7_CFG (0x010600) +#define NIC_QSET_RQ_0_7_STAT_0_1 (0x010700) + +#define NIC_QSET_SQ_0_7_CFG (0x010800) +#define NIC_QSET_SQ_0_7_THRESH (0x010810) +#define NIC_QSET_SQ_0_7_BASE (0x010820) +#define NIC_QSET_SQ_0_7_HEAD (0x010828) +#define NIC_QSET_SQ_0_7_TAIL (0x010830) +#define NIC_QSET_SQ_0_7_DOOR (0x010838) +#define NIC_QSET_SQ_0_7_STATUS (0x010840) +#define NIC_QSET_SQ_0_7_DEBUG (0x010848) +#define NIC_QSET_SQ_0_7_CNM_CHG (0x010860) +#define NIC_QSET_SQ_0_7_STAT_0_1 (0x010900) + +#define NIC_QSET_RBDR_0_1_CFG (0x010C00) +#define NIC_QSET_RBDR_0_1_THRESH (0x010C10) +#define NIC_QSET_RBDR_0_1_BASE (0x010C20) +#define NIC_QSET_RBDR_0_1_HEAD (0x010C28) +#define NIC_QSET_RBDR_0_1_TAIL (0x010C30) +#define NIC_QSET_RBDR_0_1_DOOR (0x010C38) +#define NIC_QSET_RBDR_0_1_STATUS0 (0x010C40) +#define NIC_QSET_RBDR_0_1_STATUS1 (0x010C48) +#define NIC_QSET_RBDR_0_1_PREFETCH_STATUS (0x010C50) + +#define NIC_VF_MSIX_VECTOR_0_19_ADDR (0x000000) +#define NIC_VF_MSIX_VECTOR_0_19_CTL (0x000008) +#define NIC_VF_MSIX_PBA (0x0F0000) + +/* Offsets within registers */ +#define NIC_MSIX_VEC_SHIFT 4 +#define NIC_Q_NUM_SHIFT 18 +#define NIC_QS_ID_SHIFT 21 +#define NIC_VF_NUM_SHIFT 21 + +/* Port kind configuration register */ +struct pkind_cfg { +#if defined(__BIG_ENDIAN_BITFIELD) + uint64_t reserved_42_63:22; + uint64_t hdr_sl:5; /* Header skip length */ + uint64_t rx_hdr:3; /* TNS Receive header present */ + uint64_t lenerr_en:1; /* L2 length error check enable */ + uint64_t reserved_32_32:1; + uint64_t maxlen:16; /* Max frame size */ + uint64_t minlen:16; /* Min frame size */ +#elif defined(__LITTLE_ENDIAN_BITFIELD) + uint64_t minlen:16; + uint64_t maxlen:16; + uint64_t reserved_32_32:1; + uint64_t lenerr_en:1; + uint64_t rx_hdr:3; + uint64_t hdr_sl:5; + uint64_t reserved_42_63:22; +#endif +}; + +static inline uint64_t BGXX_PF_BAR0(unsigned long param1) + __attribute__ ((pure, always_inline)); +static inline uint64_t BGXX_PF_BAR0(unsigned long param1) +{ + assert(param1 <= 1); + return 0x87E0E0000000 + (param1 << 24); +} + +#define BGXX_PF_BAR0_SIZE 0x400000 +#define NIC_PF_BAR0 0x843000000000 +#define NIC_PF_BAR0_SIZE 0x40000000 + +static inline uint64_t NIC_VFX_BAR0(unsigned long param1) + __attribute__ ((pure, always_inline)); +static inline uint64_t NIC_VFX_BAR0(unsigned long param1) +{ + assert(param1 <= 127); + + return 0x8430A0000000 + (param1 << 21); +} + +#define NIC_VFX_BAR0_SIZE 0x200000 + +#endif /* NIC_REG_H */ diff --git a/drivers/net/octeontx/nicvf_main.c b/drivers/net/octeontx/nicvf_main.c new file mode 100644 index 0000000000..3d90ecc735 --- /dev/null +++ b/drivers/net/octeontx/nicvf_main.c @@ -0,0 +1,583 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <config.h> +#include <common.h> +#include <dm.h> +#include <pci.h> +#include <pci_ids.h> +#include <net.h> +#include <misc.h> +#include <malloc.h> +#include <asm/io.h> + +#include "nic_reg.h" +#include "nic.h" +#include "nicvf_queues.h" + +/* Register read/write APIs */ +void nicvf_reg_write(struct nicvf *nic, u64 offset, u64 val) +{ + writeq(val, nic->reg_base + offset); +} + +u64 nicvf_reg_read(struct nicvf *nic, u64 offset) +{ + return readq(nic->reg_base + offset); +} + +void nicvf_queue_reg_write(struct nicvf *nic, u64 offset, + u64 qidx, u64 val) +{ + void *addr = nic->reg_base + offset; + + writeq(val, (void *)(addr + (qidx << NIC_Q_NUM_SHIFT))); +} + +u64 nicvf_queue_reg_read(struct nicvf *nic, u64 offset, u64 qidx) +{ + void *addr = nic->reg_base + offset; + + return readq((void *)(addr + (qidx << NIC_Q_NUM_SHIFT))); +} + +static void nicvf_handle_mbx_intr(struct nicvf *nic); + +/* VF -> PF mailbox communication */ +static void nicvf_write_to_mbx(struct nicvf *nic, union nic_mbx *mbx) +{ + u64 *msg = (u64 *)mbx; + + nicvf_reg_write(nic, NIC_VF_PF_MAILBOX_0_1 + 0, msg[0]); + nicvf_reg_write(nic, NIC_VF_PF_MAILBOX_0_1 + 8, msg[1]); +} + +int nicvf_send_msg_to_pf(struct nicvf *nic, union nic_mbx *mbx) +{ + int timeout = NIC_PF_VF_MBX_TIMEOUT; + int sleep = 10; + + nic->pf_acked = false; + nic->pf_nacked = false; + + nicvf_write_to_mbx(nic, mbx); + + nic_handle_mbx_intr(nic->nicpf, nic->vf_id); + + /* Wait for previous message to be acked, timeout 2sec */ + while (!nic->pf_acked) { + if (nic->pf_nacked) + return -1; + mdelay(sleep); + nicvf_handle_mbx_intr(nic); + + if (nic->pf_acked) + break; + timeout -= sleep; + if (!timeout) { + printf("PF didn't ack to mbox msg %d from VF%d\n", + (mbx->msg.msg & 0xFF), nic->vf_id); + return -1; + } + } + + return 0; +} + +/* Checks if VF is able to comminicate with PF + * and also gets the VNIC number this VF is associated to. + */ +static int nicvf_check_pf_ready(struct nicvf *nic) +{ + union nic_mbx mbx = {}; + + mbx.msg.msg = NIC_MBOX_MSG_READY; + if (nicvf_send_msg_to_pf(nic, &mbx)) { + printf("PF didn't respond to READY msg\n"); + return 0; + } + + return 1; +} + +static void nicvf_handle_mbx_intr(struct nicvf *nic) +{ + union nic_mbx mbx = {}; + struct eth_pdata *pdata = dev_get_platdata(nic->dev); + u64 *mbx_data; + u64 mbx_addr; + int i; + + mbx_addr = NIC_VF_PF_MAILBOX_0_1; + mbx_data = (u64 *)&mbx; + + for (i = 0; i < NIC_PF_VF_MAILBOX_SIZE; i++) { + *mbx_data = nicvf_reg_read(nic, mbx_addr); + mbx_data++; + mbx_addr += sizeof(u64); + } + + debug("Mbox message: msg: 0x%x\n", mbx.msg.msg); + switch (mbx.msg.msg) { + case NIC_MBOX_MSG_READY: + nic->pf_acked = true; + nic->vf_id = mbx.nic_cfg.vf_id & 0x7F; + nic->tns_mode = mbx.nic_cfg.tns_mode & 0x7F; + nic->node = mbx.nic_cfg.node_id; + if (!nic->set_mac_pending) + memcpy(pdata->enetaddr, + mbx.nic_cfg.mac_addr, 6); + nic->loopback_supported = mbx.nic_cfg.loopback_supported; + nic->link_up = false; + nic->duplex = 0; + nic->speed = 0; + break; + case NIC_MBOX_MSG_ACK: + nic->pf_acked = true; + break; + case NIC_MBOX_MSG_NACK: + nic->pf_nacked = true; + break; + case NIC_MBOX_MSG_BGX_LINK_CHANGE: + nic->pf_acked = true; + nic->link_up = mbx.link_status.link_up; + nic->duplex = mbx.link_status.duplex; + nic->speed = mbx.link_status.speed; + if (nic->link_up) { + printf("%s: Link is Up %d Mbps %s\n", + nic->dev->name, nic->speed, + nic->duplex == 1 ? + "Full duplex" : "Half duplex"); + } else { + printf("%s: Link is Down\n", nic->dev->name); + } + break; + default: + printf("Invalid message from PF, msg 0x%x\n", mbx.msg.msg); + break; + } + + nicvf_clear_intr(nic, NICVF_INTR_MBOX, 0); +} + +static int nicvf_hw_set_mac_addr(struct nicvf *nic, struct udevice *dev) +{ + union nic_mbx mbx = {}; + struct eth_pdata *pdata = dev_get_platdata(dev); + + mbx.mac.msg = NIC_MBOX_MSG_SET_MAC; + mbx.mac.vf_id = nic->vf_id; + memcpy(mbx.mac.mac_addr, pdata->enetaddr, 6); + + return nicvf_send_msg_to_pf(nic, &mbx); +} + +static void nicvf_config_cpi(struct nicvf *nic) +{ + union nic_mbx mbx = {}; + + mbx.cpi_cfg.msg = NIC_MBOX_MSG_CPI_CFG; + mbx.cpi_cfg.vf_id = nic->vf_id; + mbx.cpi_cfg.cpi_alg = nic->cpi_alg; + mbx.cpi_cfg.rq_cnt = nic->qs->rq_cnt; + + nicvf_send_msg_to_pf(nic, &mbx); +} + +static int nicvf_init_resources(struct nicvf *nic) +{ + int err; + + nic->num_qs = 1; + + /* Enable Qset */ + nicvf_qset_config(nic, true); + + /* Initialize queues and HW for data transfer */ + err = nicvf_config_data_transfer(nic, true); + + if (err) { + printf("Failed to alloc/config VF's QSet resources\n"); + return err; + } + return 0; +} + +static void nicvf_snd_pkt_handler(struct nicvf *nic, + struct cmp_queue *cq, + void *cq_desc, int cqe_type) +{ + struct cqe_send_t *cqe_tx; + struct snd_queue *sq; + struct sq_hdr_subdesc *hdr; + + cqe_tx = (struct cqe_send_t *)cq_desc; + sq = &nic->qs->sq[cqe_tx->sq_idx]; + + hdr = (struct sq_hdr_subdesc *)GET_SQ_DESC(sq, cqe_tx->sqe_ptr); + if (hdr->subdesc_type != SQ_DESC_TYPE_HEADER) + return; + + nicvf_check_cqe_tx_errs(nic, cq, cq_desc); + nicvf_put_sq_desc(sq, hdr->subdesc_cnt + 1); +} + +static int nicvf_rcv_pkt_handler(struct nicvf *nic, + struct cmp_queue *cq, void *cq_desc, + void **ppkt, int cqe_type) +{ + void *pkt; + + size_t pkt_len; + struct cqe_rx_t *cqe_rx = (struct cqe_rx_t *)cq_desc; + int err = 0; + + /* Check for errors */ + err = nicvf_check_cqe_rx_errs(nic, cq, cq_desc); + if (err && !cqe_rx->rb_cnt) + return -1; + + pkt = nicvf_get_rcv_pkt(nic, cq_desc, &pkt_len); + if (!pkt) { + debug("Packet not received\n"); + return -1; + } + + if (pkt) + *ppkt = pkt; + + return pkt_len; +} + +int nicvf_cq_handler(struct nicvf *nic, void **ppkt, int *pkt_len) +{ + int cq_qnum = 0; + int processed_sq_cqe = 0; + int processed_rq_cqe = 0; + int processed_cqe = 0; + + unsigned long cqe_count, cqe_head; + struct queue_set *qs = nic->qs; + struct cmp_queue *cq = &qs->cq[cq_qnum]; + struct cqe_rx_t *cq_desc; + + /* Get num of valid CQ entries expect next one to be SQ completion */ + cqe_count = nicvf_queue_reg_read(nic, NIC_QSET_CQ_0_7_STATUS, cq_qnum); + cqe_count &= 0xFFFF; + if (!cqe_count) + return 0; + + /* Get head of the valid CQ entries */ + cqe_head = nicvf_queue_reg_read(nic, NIC_QSET_CQ_0_7_HEAD, cq_qnum); + cqe_head >>= 9; + cqe_head &= 0xFFFF; + + if (cqe_count) { + /* Get the CQ descriptor */ + cq_desc = (struct cqe_rx_t *)GET_CQ_DESC(cq, cqe_head); + cqe_head++; + cqe_head &= (cq->dmem.q_len - 1); + /* Initiate prefetch for next descriptor */ + prefetch((struct cqe_rx_t *)GET_CQ_DESC(cq, cqe_head)); + + switch (cq_desc->cqe_type) { + case CQE_TYPE_RX: + debug("%s: Got Rx CQE\n", nic->dev->name); + *pkt_len = nicvf_rcv_pkt_handler(nic, cq, cq_desc, + ppkt, CQE_TYPE_RX); + processed_rq_cqe++; + break; + case CQE_TYPE_SEND: + debug("%s: Got Tx CQE\n", nic->dev->name); + nicvf_snd_pkt_handler(nic, cq, cq_desc, CQE_TYPE_SEND); + processed_sq_cqe++; + break; + default: + debug("%s: Got CQ type %u\n", nic->dev->name, + cq_desc->cqe_type); + break; + } + processed_cqe++; + } + + /* Dequeue CQE */ + nicvf_queue_reg_write(nic, NIC_QSET_CQ_0_7_DOOR, + cq_qnum, processed_cqe); + + asm volatile ("dsb sy"); + + return (processed_sq_cqe | processed_rq_cqe); +} + +/* Qset error interrupt handler + * + * As of now only CQ errors are handled + */ +void nicvf_handle_qs_err(struct nicvf *nic) +{ + struct queue_set *qs = nic->qs; + int qidx; + u64 status; + + /* Check if it is CQ err */ + for (qidx = 0; qidx < qs->cq_cnt; qidx++) { + status = nicvf_queue_reg_read(nic, NIC_QSET_CQ_0_7_STATUS, + qidx); + if (!(status & CQ_ERR_MASK)) + continue; + /* Process already queued CQEs and reconfig CQ */ + nicvf_sq_disable(nic, qidx); + nicvf_cmp_queue_config(nic, qs, qidx, true); + nicvf_sq_free_used_descs(nic->dev, &qs->sq[qidx], qidx); + nicvf_sq_enable(nic, &qs->sq[qidx], qidx); + } +} + +static int nicvf_free_pkt(struct udevice *dev, uchar *pkt, int pkt_len) +{ + struct nicvf *nic = dev_get_priv(dev); + + if (pkt && pkt_len) + free(pkt); + nicvf_refill_rbdr(nic); + return 0; +} + +static int nicvf_xmit(struct udevice *dev, void *pkt, int pkt_len) +{ + struct nicvf *nic = dev_get_priv(dev); + int ret = 0; + int rcv_len = 0; + unsigned int timeout = 5000; + void *rpkt = NULL; + + if (!nicvf_sq_append_pkt(nic, pkt, pkt_len)) { + printf("VF%d: TX ring full\n", nic->vf_id); + return -1; + } + + /* check and update CQ for pkt sent */ + while (!ret && timeout--) { + ret = nicvf_cq_handler(nic, &rpkt, &rcv_len); + if (!ret) { + debug("%s: %d, Not sent\n", __func__, __LINE__); + udelay(10); + } + } + + return 0; +} + +static int nicvf_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct nicvf *nic = dev_get_priv(dev); + void *pkt; + int pkt_len = 0; +#ifdef DEBUG + u8 *dpkt; + int i, j; +#endif + + nicvf_cq_handler(nic, &pkt, &pkt_len); + + if (pkt_len) { +#ifdef DEBUG + dpkt = pkt; + printf("RX packet contents:\n"); + for (i = 0; i < 8; i++) { + puts("\t"); + for (j = 0; j < 10; j++) + printf("%02x ", dpkt[i * 10 + j]); + puts("\n"); + } +#endif + *packetp = pkt; + } + + return pkt_len; +} + +void nicvf_stop(struct udevice *dev) +{ + struct nicvf *nic = dev_get_priv(dev); + + if (!nic->open) + return; + + /* Free resources */ + nicvf_config_data_transfer(nic, false); + + /* Disable HW Qset */ + nicvf_qset_config(nic, false); + + nic->open = false; +} + +int nicvf_open(struct udevice *dev) +{ + int err; + struct nicvf *nic = dev_get_priv(dev); + + nicvf_hw_set_mac_addr(nic, dev); + + /* Configure CPI alorithm */ + nic->cpi_alg = CPI_ALG_NONE; + nicvf_config_cpi(nic); + + /* Initialize the queues */ + err = nicvf_init_resources(nic); + if (err) + return -1; + + if (!nicvf_check_pf_ready(nic)) + return -1; + + nic->open = true; + + /* Make sure queue initialization is written */ + asm volatile("dsb sy"); + + return 0; +} + +int nicvf_write_hwaddr(struct udevice *dev) +{ + unsigned char ethaddr[ARP_HLEN]; + struct eth_pdata *pdata = dev_get_platdata(dev); + struct nicvf *nic = dev_get_priv(dev); + + /* If lower level firmware fails to set proper MAC + * u-boot framework updates MAC to random address. + * Use this hook to update mac address in environment. + */ + if (!eth_env_get_enetaddr_by_index("eth", dev->seq, ethaddr)) { + eth_env_set_enetaddr_by_index("eth", dev->seq, pdata->enetaddr); + debug("%s: pMAC %pM\n", __func__, pdata->enetaddr); + } + eth_env_get_enetaddr_by_index("eth", dev->seq, ethaddr); + if (memcmp(ethaddr, pdata->enetaddr, ARP_HLEN)) { + debug("%s: pMAC %pM\n", __func__, pdata->enetaddr); + nicvf_hw_set_mac_addr(nic, dev); + } + return 0; +} + +static void nicvf_probe_mdio_devices(void) +{ + struct udevice *pdev; + int err; + static int probed; + + if (probed) + return; + + err = dm_pci_find_device(PCI_VENDOR_ID_CAVIUM, + PCI_DEVICE_ID_CAVIUM_SMI, 0, + &pdev); + if (err) + debug("%s couldn't find SMI device\n", __func__); + probed = 1; +} + +int nicvf_initialize(struct udevice *dev) +{ + struct nicvf *nicvf = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + int ret = 0, bgx, lmac; + char name[16]; + unsigned char ethaddr[ARP_HLEN]; + struct udevice *pfdev; + struct nicpf *pf; + static int vfid; + + if (dm_pci_find_device(PCI_VENDOR_ID_CAVIUM, + PCI_DEVICE_ID_CAVIUM_NIC, 0, &pfdev)) { + printf("%s NIC PF device not found..VF probe failed\n", + __func__); + return -1; + } + pf = dev_get_priv(pfdev); + nicvf->vf_id = vfid++; + nicvf->dev = dev; + nicvf->nicpf = pf; + + nicvf_probe_mdio_devices(); + + /* Enable TSO support */ + nicvf->hw_tso = true; + + nicvf->reg_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + + debug("nicvf->reg_base: %p\n", nicvf->reg_base); + + if (!nicvf->reg_base) { + printf("Cannot map config register space, aborting\n"); + ret = -1; + goto fail; + } + + ret = nicvf_set_qset_resources(nicvf); + if (ret) + return -1; + + sprintf(name, "vnic%u", nicvf->vf_id); + debug("%s name %s\n", __func__, name); + device_set_name(dev, name); + + bgx = NIC_GET_BGX_FROM_VF_LMAC_MAP(pf->vf_lmac_map[nicvf->vf_id]); + lmac = NIC_GET_LMAC_FROM_VF_LMAC_MAP(pf->vf_lmac_map[nicvf->vf_id]); + debug("%s VF %d BGX %d LMAC %d\n", __func__, nicvf->vf_id, bgx, lmac); + debug("%s PF %p pfdev %p VF %p vfdev %p vf->pdata %p\n", + __func__, nicvf->nicpf, nicvf->nicpf->udev, nicvf, nicvf->dev, + pdata); + + fdt_board_get_ethaddr(bgx, lmac, ethaddr); + + debug("%s bgx %d lmac %d ethaddr %pM\n", __func__, bgx, lmac, ethaddr); + + if (is_valid_ethaddr(ethaddr)) { + memcpy(pdata->enetaddr, ethaddr, ARP_HLEN); + eth_env_set_enetaddr_by_index("eth", dev->seq, ethaddr); + } + debug("%s enetaddr %pM ethaddr %pM\n", __func__, + pdata->enetaddr, ethaddr); + +fail: + return ret; +} + +int octeontx_vnic_probe(struct udevice *dev) +{ + return nicvf_initialize(dev); +} + +static const struct eth_ops octeontx_vnic_ops = { + .start = nicvf_open, + .stop = nicvf_stop, + .send = nicvf_xmit, + .recv = nicvf_recv, + .free_pkt = nicvf_free_pkt, + .write_hwaddr = nicvf_write_hwaddr, +}; + +U_BOOT_DRIVER(octeontx_vnic) = { + .name = "vnic", + .id = UCLASS_ETH, + .probe = octeontx_vnic_probe, + .ops = &octeontx_vnic_ops, + .priv_auto_alloc_size = sizeof(struct nicvf), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; + +static struct pci_device_id octeontx_vnic_supported[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_NICVF) }, + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_NICVF_1) }, + {} +}; + +U_BOOT_PCI_DEVICE(octeontx_vnic, octeontx_vnic_supported); diff --git a/drivers/net/octeontx/nicvf_queues.c b/drivers/net/octeontx/nicvf_queues.c new file mode 100644 index 0000000000..96d9b90d4c --- /dev/null +++ b/drivers/net/octeontx/nicvf_queues.c @@ -0,0 +1,1142 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <config.h> +#include <common.h> +#include <cpu_func.h> +#include <net.h> +#include <dm/device.h> +#include <malloc.h> + +#include "nic_reg.h" +#include "nic.h" +#include "q_struct.h" +#include "nicvf_queues.h" + +static int nicvf_poll_reg(struct nicvf *nic, int qidx, + u64 reg, int bit_pos, int bits, int val) +{ + u64 bit_mask; + u64 reg_val; + int timeout = 10; + + bit_mask = (1ULL << bits) - 1; + bit_mask = (bit_mask << bit_pos); + + while (timeout) { + reg_val = nicvf_queue_reg_read(nic, reg, qidx); + if (((reg_val & bit_mask) >> bit_pos) == val) + return 0; + udelay(2000); + timeout--; + } + printf("Poll on reg 0x%llx failed\n", reg); + return 1; +} + +static int nicvf_alloc_q_desc_mem(struct nicvf *nic, struct q_desc_mem *dmem, + int q_len, int desc_size, int align_bytes) +{ + dmem->q_len = q_len; + dmem->size = (desc_size * q_len) + align_bytes; + /* Save address, need it while freeing */ + dmem->unalign_base = calloc(1, dmem->size); + dmem->dma = (uintptr_t)dmem->unalign_base; + + if (!dmem->unalign_base) + return -1; + + /* Align memory address for 'align_bytes' */ + dmem->phys_base = NICVF_ALIGNED_ADDR((u64)dmem->dma, align_bytes); + dmem->base = dmem->unalign_base + (dmem->phys_base - dmem->dma); + + return 0; +} + +static void nicvf_free_q_desc_mem(struct nicvf *nic, struct q_desc_mem *dmem) +{ + if (!dmem) + return; + + free(dmem->unalign_base); + + dmem->unalign_base = NULL; + dmem->base = NULL; +} + +static void *nicvf_rb_ptr_to_pkt(struct nicvf *nic, uintptr_t rb_ptr) +{ + return (void *)rb_ptr; +} + +static int nicvf_init_rbdr(struct nicvf *nic, struct rbdr *rbdr, + int ring_len, int buf_size) +{ + int idx; + uintptr_t rbuf; + struct rbdr_entry_t *desc; + + if (nicvf_alloc_q_desc_mem(nic, &rbdr->dmem, ring_len, + sizeof(struct rbdr_entry_t), + NICVF_RCV_BUF_ALIGN_BYTES)) { + printf("Unable to allocate memory for rcv buffer ring\n"); + return -1; + } + + rbdr->desc = rbdr->dmem.base; + /* Buffer size has to be in multiples of 128 bytes */ + rbdr->dma_size = buf_size; + rbdr->enable = true; + rbdr->thresh = RBDR_THRESH; + + debug("%s: %d: allocating %lld bytes for rcv buffers\n", + __func__, __LINE__, + ring_len * buf_size + NICVF_RCV_BUF_ALIGN_BYTES); + rbdr->buf_mem = (uintptr_t)calloc(1, ring_len * buf_size + + NICVF_RCV_BUF_ALIGN_BYTES); + + if (!rbdr->buf_mem) { + printf("Unable to allocate memory for rcv buffers\n"); + return -1; + } + + rbdr->buffers = NICVF_ALIGNED_ADDR(rbdr->buf_mem, + NICVF_RCV_BUF_ALIGN_BYTES); + + debug("%s: %d: rbdr->buf_mem: %lx, rbdr->buffers: %lx\n", + __func__, __LINE__, rbdr->buf_mem, rbdr->buffers); + + for (idx = 0; idx < ring_len; idx++) { + rbuf = rbdr->buffers + DMA_BUFFER_LEN * idx; + desc = GET_RBDR_DESC(rbdr, idx); + desc->buf_addr = rbuf >> NICVF_RCV_BUF_ALIGN; + flush_dcache_range((uintptr_t)desc, + (uintptr_t)desc + sizeof(desc)); + } + return 0; +} + +static void nicvf_free_rbdr(struct nicvf *nic, struct rbdr *rbdr) +{ + if (!rbdr) + return; + + rbdr->enable = false; + if (!rbdr->dmem.base) + return; + + debug("%s: %d: rbdr->buf_mem: %p\n", __func__, + __LINE__, (void *)rbdr->buf_mem); + free((void *)rbdr->buf_mem); + + /* Free RBDR ring */ + nicvf_free_q_desc_mem(nic, &rbdr->dmem); +} + +/* Refill receive buffer descriptors with new buffers. + * This runs in softirq context . + */ +void nicvf_refill_rbdr(struct nicvf *nic) +{ + struct queue_set *qs = nic->qs; + int rbdr_idx = qs->rbdr_cnt; + unsigned long qcount, head, tail, rb_cnt; + struct rbdr *rbdr; + + if (!rbdr_idx) + return; + rbdr_idx--; + rbdr = &qs->rbdr[rbdr_idx]; + /* Check if it's enabled */ + if (!rbdr->enable) { + printf("Receive queue %d is disabled\n", rbdr_idx); + return; + } + + /* check if valid descs reached or crossed threshold level */ + qcount = nicvf_queue_reg_read(nic, NIC_QSET_RBDR_0_1_STATUS0, rbdr_idx); + head = nicvf_queue_reg_read(nic, NIC_QSET_RBDR_0_1_HEAD, rbdr_idx); + tail = nicvf_queue_reg_read(nic, NIC_QSET_RBDR_0_1_TAIL, rbdr_idx); + + qcount &= 0x7FFFF; + + rb_cnt = qs->rbdr_len - qcount - 1; + + debug("%s: %d: qcount: %lu, head: %lx, tail: %lx, rb_cnt: %lu\n", + __func__, __LINE__, qcount, head, tail, rb_cnt); + + /* Notify HW */ + nicvf_queue_reg_write(nic, NIC_QSET_RBDR_0_1_DOOR, rbdr_idx, rb_cnt); + + asm volatile ("dsb sy"); +} + +/* TBD: how to handle full packets received in CQ + * i.e conversion of buffers into SKBs + */ +static int nicvf_init_cmp_queue(struct nicvf *nic, + struct cmp_queue *cq, int q_len) +{ + if (nicvf_alloc_q_desc_mem(nic, &cq->dmem, q_len, + CMP_QUEUE_DESC_SIZE, + NICVF_CQ_BASE_ALIGN_BYTES)) { + printf("Unable to allocate memory for completion queue\n"); + return -1; + } + cq->desc = cq->dmem.base; + if (!pass1_silicon(nic->rev_id, nic->nicpf->hw->model_id)) + cq->thresh = CMP_QUEUE_CQE_THRESH; + else + cq->thresh = 0; + cq->intr_timer_thresh = CMP_QUEUE_TIMER_THRESH; + + return 0; +} + +static void nicvf_free_cmp_queue(struct nicvf *nic, struct cmp_queue *cq) +{ + if (!cq) + return; + if (!cq->dmem.base) + return; + + nicvf_free_q_desc_mem(nic, &cq->dmem); +} + +static int nicvf_init_snd_queue(struct nicvf *nic, + struct snd_queue *sq, int q_len) +{ + if (nicvf_alloc_q_desc_mem(nic, &sq->dmem, q_len, + SND_QUEUE_DESC_SIZE, + NICVF_SQ_BASE_ALIGN_BYTES)) { + printf("Unable to allocate memory for send queue\n"); + return -1; + } + + sq->desc = sq->dmem.base; + sq->skbuff = calloc(q_len, sizeof(u64)); + sq->head = 0; + sq->tail = 0; + sq->free_cnt = q_len - 1; + sq->thresh = SND_QUEUE_THRESH; + + return 0; +} + +static void nicvf_free_snd_queue(struct nicvf *nic, struct snd_queue *sq) +{ + if (!sq) + return; + if (!sq->dmem.base) + return; + + debug("%s: %d\n", __func__, __LINE__); + free(sq->skbuff); + + nicvf_free_q_desc_mem(nic, &sq->dmem); +} + +static void nicvf_reclaim_snd_queue(struct nicvf *nic, + struct queue_set *qs, int qidx) +{ + /* Disable send queue */ + nicvf_queue_reg_write(nic, NIC_QSET_SQ_0_7_CFG, qidx, 0); + /* Check if SQ is stopped */ + if (nicvf_poll_reg(nic, qidx, NIC_QSET_SQ_0_7_STATUS, 21, 1, 0x01)) + return; + /* Reset send queue */ + nicvf_queue_reg_write(nic, NIC_QSET_SQ_0_7_CFG, qidx, NICVF_SQ_RESET); +} + +static void nicvf_reclaim_rcv_queue(struct nicvf *nic, + struct queue_set *qs, int qidx) +{ + union nic_mbx mbx = {}; + + /* Make sure all packets in the pipeline are written back into mem */ + mbx.msg.msg = NIC_MBOX_MSG_RQ_SW_SYNC; + nicvf_send_msg_to_pf(nic, &mbx); +} + +static void nicvf_reclaim_cmp_queue(struct nicvf *nic, + struct queue_set *qs, int qidx) +{ + /* Disable timer threshold (doesn't get reset upon CQ reset */ + nicvf_queue_reg_write(nic, NIC_QSET_CQ_0_7_CFG2, qidx, 0); + /* Disable completion queue */ + nicvf_queue_reg_write(nic, NIC_QSET_CQ_0_7_CFG, qidx, 0); + /* Reset completion queue */ + nicvf_queue_reg_write(nic, NIC_QSET_CQ_0_7_CFG, qidx, NICVF_CQ_RESET); +} + +static void nicvf_reclaim_rbdr(struct nicvf *nic, + struct rbdr *rbdr, int qidx) +{ + u64 tmp, fifo_state; + int timeout = 10; + + /* Save head and tail pointers for feeing up buffers */ + rbdr->head = nicvf_queue_reg_read(nic, + NIC_QSET_RBDR_0_1_HEAD, + qidx) >> 3; + rbdr->tail = nicvf_queue_reg_read(nic, + NIC_QSET_RBDR_0_1_TAIL, + qidx) >> 3; + + /* If RBDR FIFO is in 'FAIL' state then do a reset first + * before relaiming. + */ + fifo_state = nicvf_queue_reg_read(nic, NIC_QSET_RBDR_0_1_STATUS0, qidx); + if (((fifo_state >> 62) & 0x03) == 0x3) + nicvf_queue_reg_write(nic, NIC_QSET_RBDR_0_1_CFG, + qidx, NICVF_RBDR_RESET); + + /* Disable RBDR */ + nicvf_queue_reg_write(nic, NIC_QSET_RBDR_0_1_CFG, qidx, 0); + if (nicvf_poll_reg(nic, qidx, NIC_QSET_RBDR_0_1_STATUS0, 62, 2, 0x00)) + return; + while (1) { + tmp = nicvf_queue_reg_read(nic, + NIC_QSET_RBDR_0_1_PREFETCH_STATUS, + qidx); + if ((tmp & 0xFFFFFFFF) == ((tmp >> 32) & 0xFFFFFFFF)) + break; + mdelay(2000); + timeout--; + if (!timeout) { + printf("Failed polling on prefetch status\n"); + return; + } + } + nicvf_queue_reg_write(nic, NIC_QSET_RBDR_0_1_CFG, + qidx, NICVF_RBDR_RESET); + + if (nicvf_poll_reg(nic, qidx, NIC_QSET_RBDR_0_1_STATUS0, 62, 2, 0x02)) + return; + nicvf_queue_reg_write(nic, NIC_QSET_RBDR_0_1_CFG, qidx, 0x00); + if (nicvf_poll_reg(nic, qidx, NIC_QSET_RBDR_0_1_STATUS0, 62, 2, 0x00)) + return; +} + +/* Configures receive queue */ +static void nicvf_rcv_queue_config(struct nicvf *nic, struct queue_set *qs, + int qidx, bool enable) +{ + union nic_mbx mbx = {}; + struct rcv_queue *rq; + union { + struct rq_cfg s; + u64 u; + } rq_cfg; + + rq = &qs->rq[qidx]; + rq->enable = enable; + + /* Disable receive queue */ + nicvf_queue_reg_write(nic, NIC_QSET_RQ_0_7_CFG, qidx, 0); + + if (!rq->enable) { + nicvf_reclaim_rcv_queue(nic, qs, qidx); + return; + } + + rq->cq_qs = qs->vnic_id; + rq->cq_idx = qidx; + rq->start_rbdr_qs = qs->vnic_id; + rq->start_qs_rbdr_idx = qs->rbdr_cnt - 1; + rq->cont_rbdr_qs = qs->vnic_id; + rq->cont_qs_rbdr_idx = qs->rbdr_cnt - 1; + /* all writes of RBDR data to be loaded into L2 Cache as well*/ + rq->caching = 1; + + /* Send a mailbox msg to PF to config RQ */ + mbx.rq.msg = NIC_MBOX_MSG_RQ_CFG; + mbx.rq.qs_num = qs->vnic_id; + mbx.rq.rq_num = qidx; + mbx.rq.cfg = (rq->caching << 26) | (rq->cq_qs << 19) | + (rq->cq_idx << 16) | (rq->cont_rbdr_qs << 9) | + (rq->cont_qs_rbdr_idx << 8) | + (rq->start_rbdr_qs << 1) | (rq->start_qs_rbdr_idx); + nicvf_send_msg_to_pf(nic, &mbx); + + mbx.rq.msg = NIC_MBOX_MSG_RQ_BP_CFG; + mbx.rq.cfg = (1ULL << 63) | (1ULL << 62) | (qs->vnic_id << 0); + nicvf_send_msg_to_pf(nic, &mbx); + + /* RQ drop config + * Enable CQ drop to reserve sufficient CQEs for all tx packets + */ + mbx.rq.msg = NIC_MBOX_MSG_RQ_DROP_CFG; + mbx.rq.cfg = (1ULL << 62) | (RQ_CQ_DROP << 8); + nicvf_send_msg_to_pf(nic, &mbx); + nicvf_queue_reg_write(nic, NIC_QSET_RQ_GEN_CFG, 0, 0x00); + + /* Enable Receive queue */ + rq_cfg.s.ena = 1; + rq_cfg.s.tcp_ena = 0; + nicvf_queue_reg_write(nic, NIC_QSET_RQ_0_7_CFG, qidx, rq_cfg.u); +} + +void nicvf_cmp_queue_config(struct nicvf *nic, struct queue_set *qs, + int qidx, bool enable) +{ + struct cmp_queue *cq; + union { + u64 u; + struct cq_cfg s; + } cq_cfg; + + cq = &qs->cq[qidx]; + cq->enable = enable; + + if (!cq->enable) { + nicvf_reclaim_cmp_queue(nic, qs, qidx); + return; + } + + /* Reset completion queue */ + nicvf_queue_reg_write(nic, NIC_QSET_CQ_0_7_CFG, qidx, NICVF_CQ_RESET); + + if (!cq->enable) + return; + + /* Set completion queue base address */ + nicvf_queue_reg_write(nic, NIC_QSET_CQ_0_7_BASE, + qidx, (u64)(cq->dmem.phys_base)); + + /* Enable Completion queue */ + cq_cfg.s.ena = 1; + cq_cfg.s.reset = 0; + cq_cfg.s.caching = 0; + cq_cfg.s.qsize = CMP_QSIZE; + cq_cfg.s.avg_con = 0; + nicvf_queue_reg_write(nic, NIC_QSET_CQ_0_7_CFG, qidx, cq_cfg.u); + + /* Set threshold value for interrupt generation */ + nicvf_queue_reg_write(nic, NIC_QSET_CQ_0_7_THRESH, qidx, cq->thresh); + nicvf_queue_reg_write(nic, NIC_QSET_CQ_0_7_CFG2, qidx, + cq->intr_timer_thresh); +} + +/* Configures transmit queue */ +static void nicvf_snd_queue_config(struct nicvf *nic, struct queue_set *qs, + int qidx, bool enable) +{ + union nic_mbx mbx = {}; + struct snd_queue *sq; + + union { + struct sq_cfg s; + u64 u; + } sq_cfg; + + sq = &qs->sq[qidx]; + sq->enable = enable; + + if (!sq->enable) { + nicvf_reclaim_snd_queue(nic, qs, qidx); + return; + } + + /* Reset send queue */ + nicvf_queue_reg_write(nic, NIC_QSET_SQ_0_7_CFG, qidx, NICVF_SQ_RESET); + + sq->cq_qs = qs->vnic_id; + sq->cq_idx = qidx; + + /* Send a mailbox msg to PF to config SQ */ + mbx.sq.msg = NIC_MBOX_MSG_SQ_CFG; + mbx.sq.qs_num = qs->vnic_id; + mbx.sq.sq_num = qidx; + mbx.sq.sqs_mode = nic->sqs_mode; + mbx.sq.cfg = (sq->cq_qs << 3) | sq->cq_idx; + nicvf_send_msg_to_pf(nic, &mbx); + + /* Set queue base address */ + nicvf_queue_reg_write(nic, NIC_QSET_SQ_0_7_BASE, + qidx, (u64)(sq->dmem.phys_base)); + + /* Enable send queue & set queue size */ + sq_cfg.s.ena = 1; + sq_cfg.s.reset = 0; + sq_cfg.s.ldwb = 0; + sq_cfg.s.qsize = SND_QSIZE; + sq_cfg.s.tstmp_bgx_intf = 0; + nicvf_queue_reg_write(nic, NIC_QSET_SQ_0_7_CFG, qidx, sq_cfg.u); + + /* Set threshold value for interrupt generation */ + nicvf_queue_reg_write(nic, NIC_QSET_SQ_0_7_THRESH, qidx, sq->thresh); +} + +/* Configures receive buffer descriptor ring */ +static void nicvf_rbdr_config(struct nicvf *nic, struct queue_set *qs, + int qidx, bool enable) +{ + struct rbdr *rbdr; + union { + struct rbdr_cfg s; + u64 u; + } rbdr_cfg; + + rbdr = &qs->rbdr[qidx]; + nicvf_reclaim_rbdr(nic, rbdr, qidx); + if (!enable) + return; + + /* Set descriptor base address */ + nicvf_queue_reg_write(nic, NIC_QSET_RBDR_0_1_BASE, + qidx, (u64)(rbdr->dmem.phys_base)); + + /* Enable RBDR & set queue size */ + /* Buffer size should be in multiples of 128 bytes */ + rbdr_cfg.s.ena = 1; + rbdr_cfg.s.reset = 0; + rbdr_cfg.s.ldwb = 0; + rbdr_cfg.s.qsize = RBDR_SIZE; + rbdr_cfg.s.avg_con = 0; + rbdr_cfg.s.lines = rbdr->dma_size / 128; + nicvf_queue_reg_write(nic, NIC_QSET_RBDR_0_1_CFG, + qidx, rbdr_cfg.u); + + /* Notify HW */ + nicvf_queue_reg_write(nic, NIC_QSET_RBDR_0_1_DOOR, + qidx, qs->rbdr_len - 1); + + /* Set threshold value for interrupt generation */ + nicvf_queue_reg_write(nic, NIC_QSET_RBDR_0_1_THRESH, + qidx, rbdr->thresh - 1); +} + +/* Requests PF to assign and enable Qset */ +void nicvf_qset_config(struct nicvf *nic, bool enable) +{ + union nic_mbx mbx = {}; + struct queue_set *qs = nic->qs; + struct qs_cfg *qs_cfg; + + if (!qs) { + printf("Qset is still not allocated, don't init queues\n"); + return; + } + + qs->enable = enable; + qs->vnic_id = nic->vf_id; + + /* Send a mailbox msg to PF to config Qset */ + mbx.qs.msg = NIC_MBOX_MSG_QS_CFG; + mbx.qs.num = qs->vnic_id; +#ifdef VNIC_MULTI_QSET_SUPPORT + mbx.qs.sqs_count = nic->sqs_count; +#endif + + mbx.qs.cfg = 0; + qs_cfg = (struct qs_cfg *)&mbx.qs.cfg; + if (qs->enable) { + qs_cfg->ena = 1; +#ifdef __BIG_ENDIAN + qs_cfg->be = 1; +#endif + qs_cfg->vnic = qs->vnic_id; + } + nicvf_send_msg_to_pf(nic, &mbx); +} + +static void nicvf_free_resources(struct nicvf *nic) +{ + int qidx; + struct queue_set *qs = nic->qs; + + /* Free receive buffer descriptor ring */ + for (qidx = 0; qidx < qs->rbdr_cnt; qidx++) + nicvf_free_rbdr(nic, &qs->rbdr[qidx]); + + /* Free completion queue */ + for (qidx = 0; qidx < qs->cq_cnt; qidx++) + nicvf_free_cmp_queue(nic, &qs->cq[qidx]); + + /* Free send queue */ + for (qidx = 0; qidx < qs->sq_cnt; qidx++) + nicvf_free_snd_queue(nic, &qs->sq[qidx]); +} + +static int nicvf_alloc_resources(struct nicvf *nic) +{ + int qidx; + struct queue_set *qs = nic->qs; + + /* Alloc receive buffer descriptor ring */ + for (qidx = 0; qidx < qs->rbdr_cnt; qidx++) { + if (nicvf_init_rbdr(nic, &qs->rbdr[qidx], qs->rbdr_len, + DMA_BUFFER_LEN)) + goto alloc_fail; + } + + /* Alloc send queue */ + for (qidx = 0; qidx < qs->sq_cnt; qidx++) { + if (nicvf_init_snd_queue(nic, &qs->sq[qidx], qs->sq_len)) + goto alloc_fail; + } + + /* Alloc completion queue */ + for (qidx = 0; qidx < qs->cq_cnt; qidx++) { + if (nicvf_init_cmp_queue(nic, &qs->cq[qidx], qs->cq_len)) + goto alloc_fail; + } + + return 0; +alloc_fail: + nicvf_free_resources(nic); + return -1; +} + +int nicvf_set_qset_resources(struct nicvf *nic) +{ + struct queue_set *qs; + + qs = calloc(1, sizeof(struct queue_set)); + if (!qs) + return -1; + nic->qs = qs; + + /* Set count of each queue */ + qs->rbdr_cnt = RBDR_CNT; + qs->rq_cnt = 1; + qs->sq_cnt = SND_QUEUE_CNT; + qs->cq_cnt = CMP_QUEUE_CNT; + + /* Set queue lengths */ + qs->rbdr_len = RCV_BUF_COUNT; + qs->sq_len = SND_QUEUE_LEN; + qs->cq_len = CMP_QUEUE_LEN; + + nic->rx_queues = qs->rq_cnt; + nic->tx_queues = qs->sq_cnt; + + return 0; +} + +int nicvf_config_data_transfer(struct nicvf *nic, bool enable) +{ + bool disable = false; + struct queue_set *qs = nic->qs; + int qidx; + + if (!qs) + return 0; + + if (enable) { + if (nicvf_alloc_resources(nic)) + return -1; + + for (qidx = 0; qidx < qs->sq_cnt; qidx++) + nicvf_snd_queue_config(nic, qs, qidx, enable); + for (qidx = 0; qidx < qs->cq_cnt; qidx++) + nicvf_cmp_queue_config(nic, qs, qidx, enable); + for (qidx = 0; qidx < qs->rbdr_cnt; qidx++) + nicvf_rbdr_config(nic, qs, qidx, enable); + for (qidx = 0; qidx < qs->rq_cnt; qidx++) + nicvf_rcv_queue_config(nic, qs, qidx, enable); + } else { + for (qidx = 0; qidx < qs->rq_cnt; qidx++) + nicvf_rcv_queue_config(nic, qs, qidx, disable); + for (qidx = 0; qidx < qs->rbdr_cnt; qidx++) + nicvf_rbdr_config(nic, qs, qidx, disable); + for (qidx = 0; qidx < qs->sq_cnt; qidx++) + nicvf_snd_queue_config(nic, qs, qidx, disable); + for (qidx = 0; qidx < qs->cq_cnt; qidx++) + nicvf_cmp_queue_config(nic, qs, qidx, disable); + + nicvf_free_resources(nic); + } + + return 0; +} + +/* Get a free desc from SQ + * returns descriptor ponter & descriptor number + */ +static int nicvf_get_sq_desc(struct snd_queue *sq, int desc_cnt) +{ + int qentry; + + qentry = sq->tail; + sq->free_cnt -= desc_cnt; + sq->tail += desc_cnt; + sq->tail &= (sq->dmem.q_len - 1); + + return qentry; +} + +/* Free descriptor back to SQ for future use */ +void nicvf_put_sq_desc(struct snd_queue *sq, int desc_cnt) +{ + sq->free_cnt += desc_cnt; + sq->head += desc_cnt; + sq->head &= (sq->dmem.q_len - 1); +} + +static int nicvf_get_nxt_sqentry(struct snd_queue *sq, int qentry) +{ + qentry++; + qentry &= (sq->dmem.q_len - 1); + return qentry; +} + +void nicvf_sq_enable(struct nicvf *nic, struct snd_queue *sq, int qidx) +{ + u64 sq_cfg; + + sq_cfg = nicvf_queue_reg_read(nic, NIC_QSET_SQ_0_7_CFG, qidx); + sq_cfg |= NICVF_SQ_EN; + nicvf_queue_reg_write(nic, NIC_QSET_SQ_0_7_CFG, qidx, sq_cfg); + /* Ring doorbell so that H/W restarts processing SQEs */ + nicvf_queue_reg_write(nic, NIC_QSET_SQ_0_7_DOOR, qidx, 0); +} + +void nicvf_sq_disable(struct nicvf *nic, int qidx) +{ + u64 sq_cfg; + + sq_cfg = nicvf_queue_reg_read(nic, NIC_QSET_SQ_0_7_CFG, qidx); + sq_cfg &= ~NICVF_SQ_EN; + nicvf_queue_reg_write(nic, NIC_QSET_SQ_0_7_CFG, qidx, sq_cfg); +} + +void nicvf_sq_free_used_descs(struct udevice *dev, struct snd_queue *sq, + int qidx) +{ + u64 head; + struct nicvf *nic = dev_get_priv(dev); + struct sq_hdr_subdesc *hdr; + + head = nicvf_queue_reg_read(nic, NIC_QSET_SQ_0_7_HEAD, qidx) >> 4; + + while (sq->head != head) { + hdr = (struct sq_hdr_subdesc *)GET_SQ_DESC(sq, sq->head); + if (hdr->subdesc_type != SQ_DESC_TYPE_HEADER) { + nicvf_put_sq_desc(sq, 1); + continue; + } + nicvf_put_sq_desc(sq, hdr->subdesc_cnt + 1); + } +} + +/* Get the number of SQ descriptors needed to xmit this skb */ +static int nicvf_sq_subdesc_required(struct nicvf *nic) +{ + int subdesc_cnt = MIN_SQ_DESC_PER_PKT_XMIT; + + return subdesc_cnt; +} + +/* Add SQ HEADER subdescriptor. + * First subdescriptor for every send descriptor. + */ +static inline void +nicvf_sq_add_hdr_subdesc(struct nicvf *nic, struct snd_queue *sq, int qentry, + int subdesc_cnt, void *pkt, size_t pkt_len) +{ + struct sq_hdr_subdesc *hdr; + + hdr = (struct sq_hdr_subdesc *)GET_SQ_DESC(sq, qentry); + sq->skbuff[qentry] = (uintptr_t)pkt; + + memset(hdr, 0, SND_QUEUE_DESC_SIZE); + hdr->subdesc_type = SQ_DESC_TYPE_HEADER; + /* Enable notification via CQE after processing SQE */ + hdr->post_cqe = 1; + /* No of subdescriptors following this */ + hdr->subdesc_cnt = subdesc_cnt; + hdr->tot_len = pkt_len; + + flush_dcache_range((uintptr_t)hdr, + (uintptr_t)hdr + sizeof(struct sq_hdr_subdesc)); +} + +/* SQ GATHER subdescriptor + * Must follow HDR descriptor + */ +static inline void nicvf_sq_add_gather_subdesc(struct snd_queue *sq, int qentry, + size_t size, uintptr_t data) +{ + struct sq_gather_subdesc *gather; + + qentry &= (sq->dmem.q_len - 1); + gather = (struct sq_gather_subdesc *)GET_SQ_DESC(sq, qentry); + + memset(gather, 0, SND_QUEUE_DESC_SIZE); + gather->subdesc_type = SQ_DESC_TYPE_GATHER; + gather->ld_type = NIC_SEND_LD_TYPE_E_LDD; + gather->size = size; + gather->addr = data; + + flush_dcache_range((uintptr_t)gather, + (uintptr_t)gather + sizeof(struct sq_hdr_subdesc)); +} + +/* Append an skb to a SQ for packet transfer. */ +int nicvf_sq_append_pkt(struct nicvf *nic, void *pkt, size_t pkt_size) +{ + int subdesc_cnt; + int sq_num = 0, qentry; + struct queue_set *qs; + struct snd_queue *sq; + + qs = nic->qs; + sq = &qs->sq[sq_num]; + + subdesc_cnt = nicvf_sq_subdesc_required(nic); + if (subdesc_cnt > sq->free_cnt) + goto append_fail; + + qentry = nicvf_get_sq_desc(sq, subdesc_cnt); + + /* Add SQ header subdesc */ + nicvf_sq_add_hdr_subdesc(nic, sq, qentry, subdesc_cnt - 1, + pkt, pkt_size); + + /* Add SQ gather subdescs */ + qentry = nicvf_get_nxt_sqentry(sq, qentry); + nicvf_sq_add_gather_subdesc(sq, qentry, pkt_size, (uintptr_t)(pkt)); + + flush_dcache_range((uintptr_t)pkt, + (uintptr_t)pkt + pkt_size); + + /* make sure all memory stores are done before ringing doorbell */ + asm volatile ("dsb sy"); + + /* Inform HW to xmit new packet */ + nicvf_queue_reg_write(nic, NIC_QSET_SQ_0_7_DOOR, + sq_num, subdesc_cnt); + return 1; + +append_fail: + printf("Not enough SQ descriptors to xmit pkt\n"); + return 0; +} + +static unsigned int frag_num(unsigned int i) +{ +#ifdef __BIG_ENDIAN + return (i & ~3) + 3 - (i & 3); +#else + return i; +#endif +} + +void *nicvf_get_rcv_pkt(struct nicvf *nic, void *cq_desc, size_t *pkt_len) +{ + int frag; + int payload_len = 0, tot_len; + void *pkt = NULL, *pkt_buf = NULL, *buffer; + struct cqe_rx_t *cqe_rx; + struct rbdr *rbdr; + struct rcv_queue *rq; + struct queue_set *qs = nic->qs; + u16 *rb_lens = NULL; + u64 *rb_ptrs = NULL; + + cqe_rx = (struct cqe_rx_t *)cq_desc; + + rq = &qs->rq[cqe_rx->rq_idx]; + rbdr = &qs->rbdr[rq->start_qs_rbdr_idx]; + rb_lens = cq_desc + (3 * sizeof(u64)); /* Use offsetof */ + /* Except 88xx pass1 on all other chips CQE_RX2_S is added to + * CQE_RX at word6, hence buffer pointers move by word + * + * Use existing 'hw_tso' flag which will be set for all chips + * except 88xx pass1 instead of a additional cache line + * access (or miss) by using pci dev's revision. + */ + if (!nic->hw_tso) + rb_ptrs = (void *)cqe_rx + (6 * sizeof(u64)); + else + rb_ptrs = (void *)cqe_rx + (7 * sizeof(u64)); + + /* + * Figure out packet length to create packet buffer + */ + for (frag = 0; frag < cqe_rx->rb_cnt; frag++) + payload_len += rb_lens[frag_num(frag)]; + *pkt_len = payload_len; + /* round up size to 8 byte multiple */ + tot_len = (payload_len & (~0x7)) + 8; + buffer = calloc(1, tot_len); + if (!buffer) { + printf("%s - Failed to allocate packet buffer\n", __func__); + return NULL; + } + pkt_buf = buffer; + debug("total pkt buf %p len %ld tot_len %d\n", pkt_buf, *pkt_len, + tot_len); + for (frag = 0; frag < cqe_rx->rb_cnt; frag++) { + payload_len = rb_lens[frag_num(frag)]; + + invalidate_dcache_range((uintptr_t)(*rb_ptrs), + (uintptr_t)(*rb_ptrs) + rbdr->dma_size); + + /* First fragment */ + *rb_ptrs = *rb_ptrs - cqe_rx->align_pad; + + pkt = nicvf_rb_ptr_to_pkt(nic, *rb_ptrs); + + invalidate_dcache_range((uintptr_t)pkt, + (uintptr_t)pkt + payload_len); + + if (cqe_rx->align_pad) + pkt += cqe_rx->align_pad; + debug("pkt_buf %p, pkt %p payload_len %d\n", pkt_buf, pkt, + payload_len); + memcpy(buffer, pkt, payload_len); + buffer += payload_len; + /* Next buffer pointer */ + rb_ptrs++; + } + return pkt_buf; +} + +/* Clear interrupt */ +void nicvf_clear_intr(struct nicvf *nic, int int_type, int q_idx) +{ + u64 reg_val = 0; + + switch (int_type) { + case NICVF_INTR_CQ: + reg_val = ((1ULL << q_idx) << NICVF_INTR_CQ_SHIFT); + break; + case NICVF_INTR_SQ: + reg_val = ((1ULL << q_idx) << NICVF_INTR_SQ_SHIFT); + break; + case NICVF_INTR_RBDR: + reg_val = ((1ULL << q_idx) << NICVF_INTR_RBDR_SHIFT); + break; + case NICVF_INTR_PKT_DROP: + reg_val = (1ULL << NICVF_INTR_PKT_DROP_SHIFT); + break; + case NICVF_INTR_TCP_TIMER: + reg_val = (1ULL << NICVF_INTR_TCP_TIMER_SHIFT); + break; + case NICVF_INTR_MBOX: + reg_val = (1ULL << NICVF_INTR_MBOX_SHIFT); + break; + case NICVF_INTR_QS_ERR: + reg_val |= (1ULL << NICVF_INTR_QS_ERR_SHIFT); + break; + default: + printf("Failed to clear interrupt: unknown type\n"); + break; + } + + nicvf_reg_write(nic, NIC_VF_INT, reg_val); +} + +void nicvf_update_rq_stats(struct nicvf *nic, int rq_idx) +{ + struct rcv_queue *rq; + +#define GET_RQ_STATS(reg) \ + nicvf_reg_read(nic, NIC_QSET_RQ_0_7_STAT_0_1 |\ + (rq_idx << NIC_Q_NUM_SHIFT) | ((reg) << 3)) + + rq = &nic->qs->rq[rq_idx]; + rq->stats.bytes = GET_RQ_STATS(RQ_SQ_STATS_OCTS); + rq->stats.pkts = GET_RQ_STATS(RQ_SQ_STATS_PKTS); +} + +void nicvf_update_sq_stats(struct nicvf *nic, int sq_idx) +{ + struct snd_queue *sq; + +#define GET_SQ_STATS(reg) \ + nicvf_reg_read(nic, NIC_QSET_SQ_0_7_STAT_0_1 |\ + (sq_idx << NIC_Q_NUM_SHIFT) | ((reg) << 3)) + + sq = &nic->qs->sq[sq_idx]; + sq->stats.bytes = GET_SQ_STATS(RQ_SQ_STATS_OCTS); + sq->stats.pkts = GET_SQ_STATS(RQ_SQ_STATS_PKTS); +} + +/* Check for errors in the receive cmp.queue entry */ +int nicvf_check_cqe_rx_errs(struct nicvf *nic, + struct cmp_queue *cq, void *cq_desc) +{ + struct cqe_rx_t *cqe_rx; + struct cmp_queue_stats *stats = &cq->stats; + + cqe_rx = (struct cqe_rx_t *)cq_desc; + if (!cqe_rx->err_level && !cqe_rx->err_opcode) { + stats->rx.errop.good++; + return 0; + } + + switch (cqe_rx->err_level) { + case CQ_ERRLVL_MAC: + stats->rx.errlvl.mac_errs++; + break; + case CQ_ERRLVL_L2: + stats->rx.errlvl.l2_errs++; + break; + case CQ_ERRLVL_L3: + stats->rx.errlvl.l3_errs++; + break; + case CQ_ERRLVL_L4: + stats->rx.errlvl.l4_errs++; + break; + } + + switch (cqe_rx->err_opcode) { + case CQ_RX_ERROP_RE_PARTIAL: + stats->rx.errop.partial_pkts++; + break; + case CQ_RX_ERROP_RE_JABBER: + stats->rx.errop.jabber_errs++; + break; + case CQ_RX_ERROP_RE_FCS: + stats->rx.errop.fcs_errs++; + break; + case CQ_RX_ERROP_RE_TERMINATE: + stats->rx.errop.terminate_errs++; + break; + case CQ_RX_ERROP_RE_RX_CTL: + stats->rx.errop.bgx_rx_errs++; + break; + case CQ_RX_ERROP_PREL2_ERR: + stats->rx.errop.prel2_errs++; + break; + case CQ_RX_ERROP_L2_FRAGMENT: + stats->rx.errop.l2_frags++; + break; + case CQ_RX_ERROP_L2_OVERRUN: + stats->rx.errop.l2_overruns++; + break; + case CQ_RX_ERROP_L2_PFCS: + stats->rx.errop.l2_pfcs++; + break; + case CQ_RX_ERROP_L2_PUNY: + stats->rx.errop.l2_puny++; + break; + case CQ_RX_ERROP_L2_MAL: + stats->rx.errop.l2_hdr_malformed++; + break; + case CQ_RX_ERROP_L2_OVERSIZE: + stats->rx.errop.l2_oversize++; + break; + case CQ_RX_ERROP_L2_UNDERSIZE: + stats->rx.errop.l2_undersize++; + break; + case CQ_RX_ERROP_L2_LENMISM: + stats->rx.errop.l2_len_mismatch++; + break; + case CQ_RX_ERROP_L2_PCLP: + stats->rx.errop.l2_pclp++; + break; + case CQ_RX_ERROP_IP_NOT: + stats->rx.errop.non_ip++; + break; + case CQ_RX_ERROP_IP_CSUM_ERR: + stats->rx.errop.ip_csum_err++; + break; + case CQ_RX_ERROP_IP_MAL: + stats->rx.errop.ip_hdr_malformed++; + break; + case CQ_RX_ERROP_IP_MALD: + stats->rx.errop.ip_payload_malformed++; + break; + case CQ_RX_ERROP_IP_HOP: + stats->rx.errop.ip_hop_errs++; + break; + case CQ_RX_ERROP_L3_ICRC: + stats->rx.errop.l3_icrc_errs++; + break; + case CQ_RX_ERROP_L3_PCLP: + stats->rx.errop.l3_pclp++; + break; + case CQ_RX_ERROP_L4_MAL: + stats->rx.errop.l4_malformed++; + break; + case CQ_RX_ERROP_L4_CHK: + stats->rx.errop.l4_csum_errs++; + break; + case CQ_RX_ERROP_UDP_LEN: + stats->rx.errop.udp_len_err++; + break; + case CQ_RX_ERROP_L4_PORT: + stats->rx.errop.bad_l4_port++; + break; + case CQ_RX_ERROP_TCP_FLAG: + stats->rx.errop.bad_tcp_flag++; + break; + case CQ_RX_ERROP_TCP_OFFSET: + stats->rx.errop.tcp_offset_errs++; + break; + case CQ_RX_ERROP_L4_PCLP: + stats->rx.errop.l4_pclp++; + break; + case CQ_RX_ERROP_RBDR_TRUNC: + stats->rx.errop.pkt_truncated++; + break; + } + + return 1; +} + +/* Check for errors in the send cmp.queue entry */ +int nicvf_check_cqe_tx_errs(struct nicvf *nic, + struct cmp_queue *cq, void *cq_desc) +{ + struct cqe_send_t *cqe_tx; + struct cmp_queue_stats *stats = &cq->stats; + + cqe_tx = (struct cqe_send_t *)cq_desc; + switch (cqe_tx->send_status) { + case CQ_TX_ERROP_GOOD: + stats->tx.good++; + return 0; + break; + case CQ_TX_ERROP_DESC_FAULT: + stats->tx.desc_fault++; + break; + case CQ_TX_ERROP_HDR_CONS_ERR: + stats->tx.hdr_cons_err++; + break; + case CQ_TX_ERROP_SUBDC_ERR: + stats->tx.subdesc_err++; + break; + case CQ_TX_ERROP_IMM_SIZE_OFLOW: + stats->tx.imm_size_oflow++; + break; + case CQ_TX_ERROP_DATA_SEQUENCE_ERR: + stats->tx.data_seq_err++; + break; + case CQ_TX_ERROP_MEM_SEQUENCE_ERR: + stats->tx.mem_seq_err++; + break; + case CQ_TX_ERROP_LOCK_VIOL: + stats->tx.lock_viol++; + break; + case CQ_TX_ERROP_DATA_FAULT: + stats->tx.data_fault++; + break; + case CQ_TX_ERROP_TSTMP_CONFLICT: + stats->tx.tstmp_conflict++; + break; + case CQ_TX_ERROP_TSTMP_TIMEOUT: + stats->tx.tstmp_timeout++; + break; + case CQ_TX_ERROP_MEM_FAULT: + stats->tx.mem_fault++; + break; + case CQ_TX_ERROP_CK_OVERLAP: + stats->tx.csum_overlap++; + break; + case CQ_TX_ERROP_CK_OFLOW: + stats->tx.csum_overflow++; + break; + } + + return 1; +} diff --git a/drivers/net/octeontx/nicvf_queues.h b/drivers/net/octeontx/nicvf_queues.h new file mode 100644 index 0000000000..390eaa793b --- /dev/null +++ b/drivers/net/octeontx/nicvf_queues.h @@ -0,0 +1,355 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef NICVF_QUEUES_H +#define NICVF_QUEUES_H + +#include "q_struct.h" + +#define MAX_QUEUE_SET 128 +#define MAX_RCV_QUEUES_PER_QS 8 +#define MAX_RCV_BUF_DESC_RINGS_PER_QS 2 +#define MAX_SND_QUEUES_PER_QS 8 +#define MAX_CMP_QUEUES_PER_QS 8 + +/* VF's queue interrupt ranges */ +#define NICVF_INTR_ID_CQ 0 +#define NICVF_INTR_ID_SQ 8 +#define NICVF_INTR_ID_RBDR 16 +#define NICVF_INTR_ID_MISC 18 +#define NICVF_INTR_ID_QS_ERR 19 + +#define RBDR_SIZE0 0ULL /* 8K entries */ +#define RBDR_SIZE1 1ULL /* 16K entries */ +#define RBDR_SIZE2 2ULL /* 32K entries */ +#define RBDR_SIZE3 3ULL /* 64K entries */ +#define RBDR_SIZE4 4ULL /* 126K entries */ +#define RBDR_SIZE5 5ULL /* 256K entries */ +#define RBDR_SIZE6 6ULL /* 512K entries */ + +#define SND_QUEUE_SIZE0 0ULL /* 1K entries */ +#define SND_QUEUE_SIZE1 1ULL /* 2K entries */ +#define SND_QUEUE_SIZE2 2ULL /* 4K entries */ +#define SND_QUEUE_SIZE3 3ULL /* 8K entries */ +#define SND_QUEUE_SIZE4 4ULL /* 16K entries */ +#define SND_QUEUE_SIZE5 5ULL /* 32K entries */ +#define SND_QUEUE_SIZE6 6ULL /* 64K entries */ + +#define CMP_QUEUE_SIZE0 0ULL /* 1K entries */ +#define CMP_QUEUE_SIZE1 1ULL /* 2K entries */ +#define CMP_QUEUE_SIZE2 2ULL /* 4K entries */ +#define CMP_QUEUE_SIZE3 3ULL /* 8K entries */ +#define CMP_QUEUE_SIZE4 4ULL /* 16K entries */ +#define CMP_QUEUE_SIZE5 5ULL /* 32K entries */ +#define CMP_QUEUE_SIZE6 6ULL /* 64K entries */ + +/* Default queue count per QS, its lengths and threshold values */ +#define RBDR_CNT 1 +#define RCV_QUEUE_CNT 1 +#define SND_QUEUE_CNT 1 +#define CMP_QUEUE_CNT 1 /* Max of RCV and SND qcount */ + +#define SND_QSIZE SND_QUEUE_SIZE0 +#define SND_QUEUE_LEN BIT_ULL((SND_QSIZE + 10)) +#define SND_QUEUE_THRESH 2ULL +#define MIN_SQ_DESC_PER_PKT_XMIT 2 +#define MAX_CQE_PER_PKT_XMIT 2 + +#define CMP_QSIZE CMP_QUEUE_SIZE0 +#define CMP_QUEUE_LEN BIT_ULL((CMP_QSIZE + 10)) +#define CMP_QUEUE_CQE_THRESH 0 +#define CMP_QUEUE_TIMER_THRESH 1 /* 1 ms */ + +#define RBDR_SIZE RBDR_SIZE0 +#define RCV_BUF_COUNT BIT_ULL((RBDR_SIZE + 13)) +#define RBDR_THRESH (RCV_BUF_COUNT / 2) +#define DMA_BUFFER_LEN 2048 /* In multiples of 128bytes */ +#define RCV_FRAG_LEN DMA_BUFFER_LEN + +#define MAX_CQES_FOR_TX ((SND_QUEUE_LEN / MIN_SQ_DESC_PER_PKT_XMIT) *\ + MAX_CQE_PER_PKT_XMIT) +#define RQ_CQ_DROP ((CMP_QUEUE_LEN - MAX_CQES_FOR_TX) / 256) + +/* Descriptor size */ +#define SND_QUEUE_DESC_SIZE 16 /* 128 bits */ +#define CMP_QUEUE_DESC_SIZE 512 + +/* Buffer / descriptor alignments */ +#define NICVF_RCV_BUF_ALIGN 7 +#define NICVF_RCV_BUF_ALIGN_BYTES BIT_ULL(NICVF_RCV_BUF_ALIGN) +#define NICVF_CQ_BASE_ALIGN_BYTES 512 /* 9 bits */ +#define NICVF_SQ_BASE_ALIGN_BYTES 128 /* 7 bits */ + +#define NICVF_ALIGNED_ADDR(ADDR, ALIGN_BYTES) ALIGN(ADDR, ALIGN_BYTES) + +/* Queue enable/disable */ +#define NICVF_SQ_EN BIT_ULL(19) + +/* Queue reset */ +#define NICVF_CQ_RESET BIT_ULL(41) +#define NICVF_SQ_RESET BIT_ULL(17) +#define NICVF_RBDR_RESET BIT_ULL(43) + +enum CQ_RX_ERRLVL_E { + CQ_ERRLVL_MAC, + CQ_ERRLVL_L2, + CQ_ERRLVL_L3, + CQ_ERRLVL_L4, +}; + +enum CQ_RX_ERROP_E { + CQ_RX_ERROP_RE_NONE = 0x0, + CQ_RX_ERROP_RE_PARTIAL = 0x1, + CQ_RX_ERROP_RE_JABBER = 0x2, + CQ_RX_ERROP_RE_FCS = 0x7, + CQ_RX_ERROP_RE_TERMINATE = 0x9, + CQ_RX_ERROP_RE_RX_CTL = 0xb, + CQ_RX_ERROP_PREL2_ERR = 0x1f, + CQ_RX_ERROP_L2_FRAGMENT = 0x20, + CQ_RX_ERROP_L2_OVERRUN = 0x21, + CQ_RX_ERROP_L2_PFCS = 0x22, + CQ_RX_ERROP_L2_PUNY = 0x23, + CQ_RX_ERROP_L2_MAL = 0x24, + CQ_RX_ERROP_L2_OVERSIZE = 0x25, + CQ_RX_ERROP_L2_UNDERSIZE = 0x26, + CQ_RX_ERROP_L2_LENMISM = 0x27, + CQ_RX_ERROP_L2_PCLP = 0x28, + CQ_RX_ERROP_IP_NOT = 0x41, + CQ_RX_ERROP_IP_CSUM_ERR = 0x42, + CQ_RX_ERROP_IP_MAL = 0x43, + CQ_RX_ERROP_IP_MALD = 0x44, + CQ_RX_ERROP_IP_HOP = 0x45, + CQ_RX_ERROP_L3_ICRC = 0x46, + CQ_RX_ERROP_L3_PCLP = 0x47, + CQ_RX_ERROP_L4_MAL = 0x61, + CQ_RX_ERROP_L4_CHK = 0x62, + CQ_RX_ERROP_UDP_LEN = 0x63, + CQ_RX_ERROP_L4_PORT = 0x64, + CQ_RX_ERROP_TCP_FLAG = 0x65, + CQ_RX_ERROP_TCP_OFFSET = 0x66, + CQ_RX_ERROP_L4_PCLP = 0x67, + CQ_RX_ERROP_RBDR_TRUNC = 0x70, +}; + +enum CQ_TX_ERROP_E { + CQ_TX_ERROP_GOOD = 0x0, + CQ_TX_ERROP_DESC_FAULT = 0x10, + CQ_TX_ERROP_HDR_CONS_ERR = 0x11, + CQ_TX_ERROP_SUBDC_ERR = 0x12, + CQ_TX_ERROP_IMM_SIZE_OFLOW = 0x80, + CQ_TX_ERROP_DATA_SEQUENCE_ERR = 0x81, + CQ_TX_ERROP_MEM_SEQUENCE_ERR = 0x82, + CQ_TX_ERROP_LOCK_VIOL = 0x83, + CQ_TX_ERROP_DATA_FAULT = 0x84, + CQ_TX_ERROP_TSTMP_CONFLICT = 0x85, + CQ_TX_ERROP_TSTMP_TIMEOUT = 0x86, + CQ_TX_ERROP_MEM_FAULT = 0x87, + CQ_TX_ERROP_CK_OVERLAP = 0x88, + CQ_TX_ERROP_CK_OFLOW = 0x89, + CQ_TX_ERROP_ENUM_LAST = 0x8a, +}; + +struct cmp_queue_stats { + struct rx_stats { + struct { + u64 mac_errs; + u64 l2_errs; + u64 l3_errs; + u64 l4_errs; + } errlvl; + struct { + u64 good; + u64 partial_pkts; + u64 jabber_errs; + u64 fcs_errs; + u64 terminate_errs; + u64 bgx_rx_errs; + u64 prel2_errs; + u64 l2_frags; + u64 l2_overruns; + u64 l2_pfcs; + u64 l2_puny; + u64 l2_hdr_malformed; + u64 l2_oversize; + u64 l2_undersize; + u64 l2_len_mismatch; + u64 l2_pclp; + u64 non_ip; + u64 ip_csum_err; + u64 ip_hdr_malformed; + u64 ip_payload_malformed; + u64 ip_hop_errs; + u64 l3_icrc_errs; + u64 l3_pclp; + u64 l4_malformed; + u64 l4_csum_errs; + u64 udp_len_err; + u64 bad_l4_port; + u64 bad_tcp_flag; + u64 tcp_offset_errs; + u64 l4_pclp; + u64 pkt_truncated; + } errop; + } rx; + struct tx_stats { + u64 good; + u64 desc_fault; + u64 hdr_cons_err; + u64 subdesc_err; + u64 imm_size_oflow; + u64 data_seq_err; + u64 mem_seq_err; + u64 lock_viol; + u64 data_fault; + u64 tstmp_conflict; + u64 tstmp_timeout; + u64 mem_fault; + u64 csum_overlap; + u64 csum_overflow; + } tx; +}; + +enum RQ_SQ_STATS { + RQ_SQ_STATS_OCTS, + RQ_SQ_STATS_PKTS, +}; + +struct rx_tx_queue_stats { + u64 bytes; + u64 pkts; +}; + +struct q_desc_mem { + uintptr_t dma; + u64 size; + u16 q_len; + uintptr_t phys_base; + void *base; + void *unalign_base; + bool allocated; +}; + +struct rbdr { + bool enable; + u32 dma_size; + u32 thresh; /* Threshold level for interrupt */ + void *desc; + u32 head; + u32 tail; + struct q_desc_mem dmem; + uintptr_t buf_mem; + uintptr_t buffers; +}; + +struct rcv_queue { + bool enable; + struct rbdr *rbdr_start; + struct rbdr *rbdr_cont; + bool en_tcp_reassembly; + u8 cq_qs; /* CQ's QS to which this RQ is assigned */ + u8 cq_idx; /* CQ index (0 to 7) in the QS */ + u8 cont_rbdr_qs; /* Continue buffer ptrs - QS num */ + u8 cont_qs_rbdr_idx; /* RBDR idx in the cont QS */ + u8 start_rbdr_qs; /* First buffer ptrs - QS num */ + u8 start_qs_rbdr_idx; /* RBDR idx in the above QS */ + u8 caching; + struct rx_tx_queue_stats stats; +}; + +struct cmp_queue { + bool enable; + u16 intr_timer_thresh; + u16 thresh; + void *desc; + struct q_desc_mem dmem; + struct cmp_queue_stats stats; +}; + +struct snd_queue { + bool enable; + u8 cq_qs; /* CQ's QS to which this SQ is pointing */ + u8 cq_idx; /* CQ index (0 to 7) in the above QS */ + u16 thresh; + u32 free_cnt; + u32 head; + u32 tail; + u64 *skbuff; + void *desc; + struct q_desc_mem dmem; + struct rx_tx_queue_stats stats; +}; + +struct queue_set { + bool enable; + bool be_en; + u8 vnic_id; + u8 rq_cnt; + u8 cq_cnt; + u64 cq_len; + u8 sq_cnt; + u64 sq_len; + u8 rbdr_cnt; + u64 rbdr_len; + struct rcv_queue rq[MAX_RCV_QUEUES_PER_QS]; + struct cmp_queue cq[MAX_CMP_QUEUES_PER_QS]; + struct snd_queue sq[MAX_SND_QUEUES_PER_QS]; + struct rbdr rbdr[MAX_RCV_BUF_DESC_RINGS_PER_QS]; +}; + +#define GET_RBDR_DESC(RING, idx)\ + (&(((struct rbdr_entry_t *)((RING)->desc))[idx])) +#define GET_SQ_DESC(RING, idx)\ + (&(((struct sq_hdr_subdesc *)((RING)->desc))[idx])) +#define GET_CQ_DESC(RING, idx)\ + (&(((union cq_desc_t *)((RING)->desc))[idx])) + +/* CQ status bits */ +#define CQ_WR_FULL BIT(26) +#define CQ_WR_DISABLE BIT(25) +#define CQ_WR_FAULT BIT(24) +#define CQ_CQE_COUNT (0xFFFF << 0) + +#define CQ_ERR_MASK (CQ_WR_FULL | CQ_WR_DISABLE | CQ_WR_FAULT) + +int nicvf_set_qset_resources(struct nicvf *nic); +int nicvf_config_data_transfer(struct nicvf *nic, bool enable); +void nicvf_qset_config(struct nicvf *nic, bool enable); +void nicvf_cmp_queue_config(struct nicvf *nic, struct queue_set *qs, + int qidx, bool enable); + +void nicvf_sq_enable(struct nicvf *nic, struct snd_queue *sq, int qidx); +void nicvf_sq_disable(struct nicvf *nic, int qidx); +void nicvf_put_sq_desc(struct snd_queue *sq, int desc_cnt); +void nicvf_sq_free_used_descs(struct udevice *dev, + struct snd_queue *sq, int qidx); +int nicvf_sq_append_pkt(struct nicvf *nic, void *pkt, size_t pkt_len); + +void *nicvf_get_rcv_pkt(struct nicvf *nic, void *cq_desc, size_t *pkt_len); +void nicvf_refill_rbdr(struct nicvf *nic); + +void nicvf_enable_intr(struct nicvf *nic, int int_type, int q_idx); +void nicvf_disable_intr(struct nicvf *nic, int int_type, int q_idx); +void nicvf_clear_intr(struct nicvf *nic, int int_type, int q_idx); +int nicvf_is_intr_enabled(struct nicvf *nic, int int_type, int q_idx); + +/* Register access APIs */ +void nicvf_reg_write(struct nicvf *nic, u64 offset, u64 val); +u64 nicvf_reg_read(struct nicvf *nic, u64 offset); +void nicvf_qset_reg_write(struct nicvf *nic, u64 offset, u64 val); +u64 nicvf_qset_reg_read(struct nicvf *nic, u64 offset); +void nicvf_queue_reg_write(struct nicvf *nic, u64 offset, + u64 qidx, u64 val); +u64 nicvf_queue_reg_read(struct nicvf *nic, u64 offset, u64 qidx); + +/* Stats */ +void nicvf_update_rq_stats(struct nicvf *nic, int rq_idx); +void nicvf_update_sq_stats(struct nicvf *nic, int sq_idx); +int nicvf_check_cqe_rx_errs(struct nicvf *nic, + struct cmp_queue *cq, void *cq_desc); +int nicvf_check_cqe_tx_errs(struct nicvf *nic, + struct cmp_queue *cq, void *cq_desc); +#endif /* NICVF_QUEUES_H */ diff --git a/drivers/net/octeontx/q_struct.h b/drivers/net/octeontx/q_struct.h new file mode 100644 index 0000000000..b08b271818 --- /dev/null +++ b/drivers/net/octeontx/q_struct.h @@ -0,0 +1,697 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef Q_STRUCT_H +#define Q_STRUCT_H + +/* Load transaction types for reading segment bytes specified by + * NIC_SEND_GATHER_S[LD_TYPE]. + */ +enum nic_send_ld_type_e { + NIC_SEND_LD_TYPE_E_LDD = 0x0, + NIC_SEND_LD_TYPE_E_LDT = 0x1, + NIC_SEND_LD_TYPE_E_LDWB = 0x2, + NIC_SEND_LD_TYPE_E_ENUM_LAST = 0x3, +}; + +enum ether_type_algorithm { + ETYPE_ALG_NONE = 0x0, + ETYPE_ALG_SKIP = 0x1, + ETYPE_ALG_ENDPARSE = 0x2, + ETYPE_ALG_VLAN = 0x3, + ETYPE_ALG_VLAN_STRIP = 0x4, +}; + +enum layer3_type { + L3TYPE_NONE = 0x00, + L3TYPE_GRH = 0x01, + L3TYPE_IPV4 = 0x04, + L3TYPE_IPV4_OPTIONS = 0x05, + L3TYPE_IPV6 = 0x06, + L3TYPE_IPV6_OPTIONS = 0x07, + L3TYPE_ET_STOP = 0x0D, + L3TYPE_OTHER = 0x0E, +}; + +enum layer4_type { + L4TYPE_NONE = 0x00, + L4TYPE_IPSEC_ESP = 0x01, + L4TYPE_IPFRAG = 0x02, + L4TYPE_IPCOMP = 0x03, + L4TYPE_TCP = 0x04, + L4TYPE_UDP = 0x05, + L4TYPE_SCTP = 0x06, + L4TYPE_GRE = 0x07, + L4TYPE_ROCE_BTH = 0x08, + L4TYPE_OTHER = 0x0E, +}; + +/* CPI and RSSI configuration */ +enum cpi_algorithm_type { + CPI_ALG_NONE = 0x0, + CPI_ALG_VLAN = 0x1, + CPI_ALG_VLAN16 = 0x2, + CPI_ALG_DIFF = 0x3, +}; + +enum rss_algorithm_type { + RSS_ALG_NONE = 0x00, + RSS_ALG_PORT = 0x01, + RSS_ALG_IP = 0x02, + RSS_ALG_TCP_IP = 0x03, + RSS_ALG_UDP_IP = 0x04, + RSS_ALG_SCTP_IP = 0x05, + RSS_ALG_GRE_IP = 0x06, + RSS_ALG_ROCE = 0x07, +}; + +enum rss_hash_cfg { + RSS_HASH_L2ETC = 0x00, + RSS_HASH_IP = 0x01, + RSS_HASH_TCP = 0x02, + RSS_TCP_SYN_DIS = 0x03, + RSS_HASH_UDP = 0x04, + RSS_HASH_L4ETC = 0x05, + RSS_HASH_ROCE = 0x06, + RSS_L3_BIDI = 0x07, + RSS_L4_BIDI = 0x08, +}; + +/* Completion queue entry types */ +enum cqe_type { + CQE_TYPE_INVALID = 0x0, + CQE_TYPE_RX = 0x2, + CQE_TYPE_RX_SPLIT = 0x3, + CQE_TYPE_RX_TCP = 0x4, + CQE_TYPE_SEND = 0x8, + CQE_TYPE_SEND_PTP = 0x9, +}; + +enum cqe_rx_tcp_status { + CQE_RX_STATUS_VALID_TCP_CNXT = 0x00, + CQE_RX_STATUS_INVALID_TCP_CNXT = 0x0F, +}; + +enum cqe_send_status { + CQE_SEND_STATUS_GOOD = 0x00, + CQE_SEND_STATUS_DESC_FAULT = 0x01, + CQE_SEND_STATUS_HDR_CONS_ERR = 0x11, + CQE_SEND_STATUS_SUBDESC_ERR = 0x12, + CQE_SEND_STATUS_IMM_SIZE_OFLOW = 0x80, + CQE_SEND_STATUS_CRC_SEQ_ERR = 0x81, + CQE_SEND_STATUS_DATA_SEQ_ERR = 0x82, + CQE_SEND_STATUS_MEM_SEQ_ERR = 0x83, + CQE_SEND_STATUS_LOCK_VIOL = 0x84, + CQE_SEND_STATUS_LOCK_UFLOW = 0x85, + CQE_SEND_STATUS_DATA_FAULT = 0x86, + CQE_SEND_STATUS_TSTMP_CONFLICT = 0x87, + CQE_SEND_STATUS_TSTMP_TIMEOUT = 0x88, + CQE_SEND_STATUS_MEM_FAULT = 0x89, + CQE_SEND_STATUS_CSUM_OVERLAP = 0x8A, + CQE_SEND_STATUS_CSUM_OVERFLOW = 0x8B, +}; + +enum cqe_rx_tcp_end_reason { + CQE_RX_TCP_END_FIN_FLAG_DET = 0, + CQE_RX_TCP_END_INVALID_FLAG = 1, + CQE_RX_TCP_END_TIMEOUT = 2, + CQE_RX_TCP_END_OUT_OF_SEQ = 3, + CQE_RX_TCP_END_PKT_ERR = 4, + CQE_RX_TCP_END_QS_DISABLED = 0x0F, +}; + +/* Packet protocol level error enumeration */ +enum cqe_rx_err_level { + CQE_RX_ERRLVL_RE = 0x0, + CQE_RX_ERRLVL_L2 = 0x1, + CQE_RX_ERRLVL_L3 = 0x2, + CQE_RX_ERRLVL_L4 = 0x3, +}; + +/* Packet protocol level error type enumeration */ +enum cqe_rx_err_opcode { + CQE_RX_ERR_RE_NONE = 0x0, + CQE_RX_ERR_RE_PARTIAL = 0x1, + CQE_RX_ERR_RE_JABBER = 0x2, + CQE_RX_ERR_RE_FCS = 0x7, + CQE_RX_ERR_RE_TERMINATE = 0x9, + CQE_RX_ERR_RE_RX_CTL = 0xb, + CQE_RX_ERR_PREL2_ERR = 0x1f, + CQE_RX_ERR_L2_FRAGMENT = 0x20, + CQE_RX_ERR_L2_OVERRUN = 0x21, + CQE_RX_ERR_L2_PFCS = 0x22, + CQE_RX_ERR_L2_PUNY = 0x23, + CQE_RX_ERR_L2_MAL = 0x24, + CQE_RX_ERR_L2_OVERSIZE = 0x25, + CQE_RX_ERR_L2_UNDERSIZE = 0x26, + CQE_RX_ERR_L2_LENMISM = 0x27, + CQE_RX_ERR_L2_PCLP = 0x28, + CQE_RX_ERR_IP_NOT = 0x41, + CQE_RX_ERR_IP_CHK = 0x42, + CQE_RX_ERR_IP_MAL = 0x43, + CQE_RX_ERR_IP_MALD = 0x44, + CQE_RX_ERR_IP_HOP = 0x45, + CQE_RX_ERR_L3_ICRC = 0x46, + CQE_RX_ERR_L3_PCLP = 0x47, + CQE_RX_ERR_L4_MAL = 0x61, + CQE_RX_ERR_L4_CHK = 0x62, + CQE_RX_ERR_UDP_LEN = 0x63, + CQE_RX_ERR_L4_PORT = 0x64, + CQE_RX_ERR_TCP_FLAG = 0x65, + CQE_RX_ERR_TCP_OFFSET = 0x66, + CQE_RX_ERR_L4_PCLP = 0x67, + CQE_RX_ERR_RBDR_TRUNC = 0x70, +}; + +struct cqe_rx_t { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 cqe_type:4; /* W0 */ + u64 stdn_fault:1; + u64 rsvd0:1; + u64 rq_qs:7; + u64 rq_idx:3; + u64 rsvd1:12; + u64 rss_alg:4; + u64 rsvd2:4; + u64 rb_cnt:4; + u64 vlan_found:1; + u64 vlan_stripped:1; + u64 vlan2_found:1; + u64 vlan2_stripped:1; + u64 l4_type:4; + u64 l3_type:4; + u64 l2_present:1; + u64 err_level:3; + u64 err_opcode:8; + + u64 pkt_len:16; /* W1 */ + u64 l2_ptr:8; + u64 l3_ptr:8; + u64 l4_ptr:8; + u64 cq_pkt_len:8; + u64 align_pad:3; + u64 rsvd3:1; + u64 chan:12; + + u64 rss_tag:32; /* W2 */ + u64 vlan_tci:16; + u64 vlan_ptr:8; + u64 vlan2_ptr:8; + + u64 rb3_sz:16; /* W3 */ + u64 rb2_sz:16; + u64 rb1_sz:16; + u64 rb0_sz:16; + + u64 rb7_sz:16; /* W4 */ + u64 rb6_sz:16; + u64 rb5_sz:16; + u64 rb4_sz:16; + + u64 rb11_sz:16; /* W5 */ + u64 rb10_sz:16; + u64 rb9_sz:16; + u64 rb8_sz:16; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 err_opcode:8; + u64 err_level:3; + u64 l2_present:1; + u64 l3_type:4; + u64 l4_type:4; + u64 vlan2_stripped:1; + u64 vlan2_found:1; + u64 vlan_stripped:1; + u64 vlan_found:1; + u64 rb_cnt:4; + u64 rsvd2:4; + u64 rss_alg:4; + u64 rsvd1:12; + u64 rq_idx:3; + u64 rq_qs:7; + u64 rsvd0:1; + u64 stdn_fault:1; + u64 cqe_type:4; /* W0 */ + u64 chan:12; + u64 rsvd3:1; + u64 align_pad:3; + u64 cq_pkt_len:8; + u64 l4_ptr:8; + u64 l3_ptr:8; + u64 l2_ptr:8; + u64 pkt_len:16; /* W1 */ + u64 vlan2_ptr:8; + u64 vlan_ptr:8; + u64 vlan_tci:16; + u64 rss_tag:32; /* W2 */ + u64 rb0_sz:16; + u64 rb1_sz:16; + u64 rb2_sz:16; + u64 rb3_sz:16; /* W3 */ + u64 rb4_sz:16; + u64 rb5_sz:16; + u64 rb6_sz:16; + u64 rb7_sz:16; /* W4 */ + u64 rb8_sz:16; + u64 rb9_sz:16; + u64 rb10_sz:16; + u64 rb11_sz:16; /* W5 */ +#endif + u64 rb0_ptr:64; + u64 rb1_ptr:64; + u64 rb2_ptr:64; + u64 rb3_ptr:64; + u64 rb4_ptr:64; + u64 rb5_ptr:64; + u64 rb6_ptr:64; + u64 rb7_ptr:64; + u64 rb8_ptr:64; + u64 rb9_ptr:64; + u64 rb10_ptr:64; + u64 rb11_ptr:64; +}; + +struct cqe_rx_tcp_err_t { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 cqe_type:4; /* W0 */ + u64 rsvd0:60; + + u64 rsvd1:4; /* W1 */ + u64 partial_first:1; + u64 rsvd2:27; + u64 rbdr_bytes:8; + u64 rsvd3:24; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 rsvd0:60; + u64 cqe_type:4; + + u64 rsvd3:24; + u64 rbdr_bytes:8; + u64 rsvd2:27; + u64 partial_first:1; + u64 rsvd1:4; +#endif +}; + +struct cqe_rx_tcp_t { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 cqe_type:4; /* W0 */ + u64 rsvd0:52; + u64 cq_tcp_status:8; + + u64 rsvd1:32; /* W1 */ + u64 tcp_cntx_bytes:8; + u64 rsvd2:8; + u64 tcp_err_bytes:16; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 cq_tcp_status:8; + u64 rsvd0:52; + u64 cqe_type:4; /* W0 */ + + u64 tcp_err_bytes:16; + u64 rsvd2:8; + u64 tcp_cntx_bytes:8; + u64 rsvd1:32; /* W1 */ +#endif +}; + +struct cqe_send_t { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 cqe_type:4; /* W0 */ + u64 rsvd0:4; + u64 sqe_ptr:16; + u64 rsvd1:4; + u64 rsvd2:10; + u64 sq_qs:7; + u64 sq_idx:3; + u64 rsvd3:8; + u64 send_status:8; + + u64 ptp_timestamp:64; /* W1 */ +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 send_status:8; + u64 rsvd3:8; + u64 sq_idx:3; + u64 sq_qs:7; + u64 rsvd2:10; + u64 rsvd1:4; + u64 sqe_ptr:16; + u64 rsvd0:4; + u64 cqe_type:4; /* W0 */ + + u64 ptp_timestamp:64; /* W1 */ +#endif +}; + +union cq_desc_t { + u64 u[64]; + struct cqe_send_t snd_hdr; + struct cqe_rx_t rx_hdr; + struct cqe_rx_tcp_t rx_tcp_hdr; + struct cqe_rx_tcp_err_t rx_tcp_err_hdr; +}; + +struct rbdr_entry_t { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 rsvd0:15; + u64 buf_addr:42; + u64 cache_align:7; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 cache_align:7; + u64 buf_addr:42; + u64 rsvd0:15; +#endif +}; + +/* TCP reassembly context */ +struct rbe_tcp_cnxt_t { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 tcp_pkt_cnt:12; + u64 rsvd1:4; + u64 align_hdr_bytes:4; + u64 align_ptr_bytes:4; + u64 ptr_bytes:16; + u64 rsvd2:24; + u64 cqe_type:4; + u64 rsvd0:54; + u64 tcp_end_reason:2; + u64 tcp_status:4; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 tcp_status:4; + u64 tcp_end_reason:2; + u64 rsvd0:54; + u64 cqe_type:4; + u64 rsvd2:24; + u64 ptr_bytes:16; + u64 align_ptr_bytes:4; + u64 align_hdr_bytes:4; + u64 rsvd1:4; + u64 tcp_pkt_cnt:12; +#endif +}; + +/* Always Big endian */ +struct rx_hdr_t { + u64 opaque:32; + u64 rss_flow:8; + u64 skip_length:6; + u64 disable_rss:1; + u64 disable_tcp_reassembly:1; + u64 nodrop:1; + u64 dest_alg:2; + u64 rsvd0:2; + u64 dest_rq:11; +}; + +enum send_l4_csum_type { + SEND_L4_CSUM_DISABLE = 0x00, + SEND_L4_CSUM_UDP = 0x01, + SEND_L4_CSUM_TCP = 0x02, + SEND_L4_CSUM_SCTP = 0x03, +}; + +enum send_crc_alg { + SEND_CRCALG_CRC32 = 0x00, + SEND_CRCALG_CRC32C = 0x01, + SEND_CRCALG_ICRC = 0x02, +}; + +enum send_load_type { + SEND_LD_TYPE_LDD = 0x00, + SEND_LD_TYPE_LDT = 0x01, + SEND_LD_TYPE_LDWB = 0x02, +}; + +enum send_mem_alg_type { + SEND_MEMALG_SET = 0x00, + SEND_MEMALG_ADD = 0x08, + SEND_MEMALG_SUB = 0x09, + SEND_MEMALG_ADDLEN = 0x0A, + SEND_MEMALG_SUBLEN = 0x0B, +}; + +enum send_mem_dsz_type { + SEND_MEMDSZ_B64 = 0x00, + SEND_MEMDSZ_B32 = 0x01, + SEND_MEMDSZ_B8 = 0x03, +}; + +enum sq_subdesc_type { + SQ_DESC_TYPE_INVALID = 0x00, + SQ_DESC_TYPE_HEADER = 0x01, + SQ_DESC_TYPE_CRC = 0x02, + SQ_DESC_TYPE_IMMEDIATE = 0x03, + SQ_DESC_TYPE_GATHER = 0x04, + SQ_DESC_TYPE_MEMORY = 0x05, +}; + +struct sq_crc_subdesc { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 rsvd1:32; + u64 crc_ival:32; + u64 subdesc_type:4; + u64 crc_alg:2; + u64 rsvd0:10; + u64 crc_insert_pos:16; + u64 hdr_start:16; + u64 crc_len:16; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 crc_len:16; + u64 hdr_start:16; + u64 crc_insert_pos:16; + u64 rsvd0:10; + u64 crc_alg:2; + u64 subdesc_type:4; + u64 crc_ival:32; + u64 rsvd1:32; +#endif +}; + +struct sq_gather_subdesc { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 subdesc_type:4; /* W0 */ + u64 ld_type:2; + u64 rsvd0:42; + u64 size:16; + + u64 rsvd1:15; /* W1 */ + u64 addr:49; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 size:16; + u64 rsvd0:42; + u64 ld_type:2; + u64 subdesc_type:4; /* W0 */ + + u64 addr:49; + u64 rsvd1:15; /* W1 */ +#endif +}; + +/* SQ immediate subdescriptor */ +struct sq_imm_subdesc { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 subdesc_type:4; /* W0 */ + u64 rsvd0:46; + u64 len:14; + + u64 data:64; /* W1 */ +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 len:14; + u64 rsvd0:46; + u64 subdesc_type:4; /* W0 */ + + u64 data:64; /* W1 */ +#endif +}; + +struct sq_mem_subdesc { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 subdesc_type:4; /* W0 */ + u64 mem_alg:4; + u64 mem_dsz:2; + u64 wmem:1; + u64 rsvd0:21; + u64 offset:32; + + u64 rsvd1:15; /* W1 */ + u64 addr:49; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 offset:32; + u64 rsvd0:21; + u64 wmem:1; + u64 mem_dsz:2; + u64 mem_alg:4; + u64 subdesc_type:4; /* W0 */ + + u64 addr:49; + u64 rsvd1:15; /* W1 */ +#endif +}; + +struct sq_hdr_subdesc { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 subdesc_type:4; + u64 tso:1; + u64 post_cqe:1; /* Post CQE on no error also */ + u64 dont_send:1; + u64 tstmp:1; + u64 subdesc_cnt:8; + u64 csum_l4:2; + u64 csum_l3:1; + u64 rsvd0:5; + u64 l4_offset:8; + u64 l3_offset:8; + u64 rsvd1:4; + u64 tot_len:20; /* W0 */ + + u64 tso_sdc_cont:8; + u64 tso_sdc_first:8; + u64 tso_l4_offset:8; + u64 tso_flags_last:12; + u64 tso_flags_first:12; + u64 rsvd2:2; + u64 tso_max_paysize:14; /* W1 */ +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 tot_len:20; + u64 rsvd1:4; + u64 l3_offset:8; + u64 l4_offset:8; + u64 rsvd0:5; + u64 csum_l3:1; + u64 csum_l4:2; + u64 subdesc_cnt:8; + u64 tstmp:1; + u64 dont_send:1; + u64 post_cqe:1; /* Post CQE on no error also */ + u64 tso:1; + u64 subdesc_type:4; /* W0 */ + + u64 tso_max_paysize:14; + u64 rsvd2:2; + u64 tso_flags_first:12; + u64 tso_flags_last:12; + u64 tso_l4_offset:8; + u64 tso_sdc_first:8; + u64 tso_sdc_cont:8; /* W1 */ +#endif +}; + +/* Queue config register formats */ +struct rq_cfg { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 reserved_2_63:62; + u64 ena:1; + u64 tcp_ena:1; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 tcp_ena:1; + u64 ena:1; + u64 reserved_2_63:62; +#endif +}; + +struct cq_cfg { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 reserved_43_63:21; + u64 ena:1; + u64 reset:1; + u64 caching:1; + u64 reserved_35_39:5; + u64 qsize:3; + u64 reserved_25_31:7; + u64 avg_con:9; + u64 reserved_0_15:16; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 reserved_0_15:16; + u64 avg_con:9; + u64 reserved_25_31:7; + u64 qsize:3; + u64 reserved_35_39:5; + u64 caching:1; + u64 reset:1; + u64 ena:1; + u64 reserved_43_63:21; +#endif +}; + +struct sq_cfg { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 reserved_20_63:44; + u64 ena:1; + u64 reserved_18_18:1; + u64 reset:1; + u64 ldwb:1; + u64 reserved_11_15:5; + u64 qsize:3; + u64 reserved_3_7:5; + u64 tstmp_bgx_intf:3; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 tstmp_bgx_intf:3; + u64 reserved_3_7:5; + u64 qsize:3; + u64 reserved_11_15:5; + u64 ldwb:1; + u64 reset:1; + u64 reserved_18_18:1; + u64 ena:1; + u64 reserved_20_63:44; +#endif +}; + +struct rbdr_cfg { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 reserved_45_63:19; + u64 ena:1; + u64 reset:1; + u64 ldwb:1; + u64 reserved_36_41:6; + u64 qsize:4; + u64 reserved_25_31:7; + u64 avg_con:9; + u64 reserved_12_15:4; + u64 lines:12; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 lines:12; + u64 reserved_12_15:4; + u64 avg_con:9; + u64 reserved_25_31:7; + u64 qsize:4; + u64 reserved_36_41:6; + u64 ldwb:1; + u64 reset:1; + u64 ena: 1; + u64 reserved_45_63:19; +#endif +}; + +struct qs_cfg { +#if defined(__BIG_ENDIAN_BITFIELD) + u64 reserved_32_63:32; + u64 ena:1; + u64 reserved_27_30:4; + u64 sq_ins_ena:1; + u64 sq_ins_pos:6; + u64 lock_ena:1; + u64 lock_viol_cqe_ena:1; + u64 send_tstmp_ena:1; + u64 be:1; + u64 reserved_7_15:9; + u64 vnic:7; +#elif defined(__LITTLE_ENDIAN_BITFIELD) + u64 vnic:7; + u64 reserved_7_15:9; + u64 be:1; + u64 send_tstmp_ena:1; + u64 lock_viol_cqe_ena:1; + u64 lock_ena:1; + u64 sq_ins_pos:6; + u64 sq_ins_ena:1; + u64 reserved_27_30:4; + u64 ena:1; + u64 reserved_32_63:32; +#endif +}; + +#endif /* Q_STRUCT_H */ diff --git a/drivers/net/octeontx/smi.c b/drivers/net/octeontx/smi.c new file mode 100644 index 0000000000..bf99aca341 --- /dev/null +++ b/drivers/net/octeontx/smi.c @@ -0,0 +1,383 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <common.h> +#include <dm.h> +#include <pci.h> +#include <pci_ids.h> +#include <phy.h> +#include <miiphy.h> +#include <misc.h> +#include <malloc.h> +#include <asm/io.h> +#include <env.h> +#include <linux/ctype.h> + +#define PCI_DEVICE_ID_OCTEONTX_SMI 0xA02B + +DECLARE_GLOBAL_DATA_PTR; + +enum octeontx_smi_mode { + CLAUSE22 = 0, + CLAUSE45 = 1, +}; + +enum { + SMI_OP_C22_WRITE = 0, + SMI_OP_C22_READ = 1, + + SMI_OP_C45_ADDR = 0, + SMI_OP_C45_WRITE = 1, + SMI_OP_C45_PRIA = 2, + SMI_OP_C45_READ = 3, +}; + +union smi_x_clk { + u64 u; + struct smi_x_clk_s { + int phase:8; + int sample:4; + int preamble:1; + int clk_idle:1; + int reserved_14_14:1; + int sample_mode:1; + int sample_hi:5; + int reserved_21_23:3; + int mode:1; + } s; +}; + +union smi_x_cmd { + u64 u; + struct smi_x_cmd_s { + int reg_adr:5; + int reserved_5_7:3; + int phy_adr:5; + int reserved_13_15:3; + int phy_op:2; + } s; +}; + +union smi_x_wr_dat { + u64 u; + struct smi_x_wr_dat_s { + unsigned int dat:16; + int val:1; + int pending:1; + } s; +}; + +union smi_x_rd_dat { + u64 u; + struct smi_x_rd_dat_s { + unsigned int dat:16; + int val:1; + int pending:1; + } s; +}; + +union smi_x_en { + u64 u; + struct smi_x_en_s { + int en:1; + } s; +}; + +#define SMI_X_RD_DAT 0x10ull +#define SMI_X_WR_DAT 0x08ull +#define SMI_X_CMD 0x00ull +#define SMI_X_CLK 0x18ull +#define SMI_X_EN 0x20ull + +struct octeontx_smi_priv { + void __iomem *baseaddr; + enum octeontx_smi_mode mode; +}; + +#define MDIO_TIMEOUT 10000 + +void octeontx_smi_setmode(struct mii_dev *bus, enum octeontx_smi_mode mode) +{ + struct octeontx_smi_priv *priv = bus->priv; + union smi_x_clk smix_clk; + + smix_clk.u = readq(priv->baseaddr + SMI_X_CLK); + smix_clk.s.mode = mode; + smix_clk.s.preamble = mode == CLAUSE45; + writeq(smix_clk.u, priv->baseaddr + SMI_X_CLK); + + priv->mode = mode; +} + +int octeontx_c45_addr(struct mii_dev *bus, int addr, int devad, int regnum) +{ + struct octeontx_smi_priv *priv = bus->priv; + + union smi_x_cmd smix_cmd; + union smi_x_wr_dat smix_wr_dat; + unsigned long timeout = MDIO_TIMEOUT; + + smix_wr_dat.u = 0; + smix_wr_dat.s.dat = regnum; + + writeq(smix_wr_dat.u, priv->baseaddr + SMI_X_WR_DAT); + + smix_cmd.u = 0; + smix_cmd.s.phy_op = SMI_OP_C45_ADDR; + smix_cmd.s.phy_adr = addr; + smix_cmd.s.reg_adr = devad; + + writeq(smix_cmd.u, priv->baseaddr + SMI_X_CMD); + + do { + smix_wr_dat.u = readq(priv->baseaddr + SMI_X_WR_DAT); + udelay(100); + timeout--; + } while (smix_wr_dat.s.pending && timeout); + + return timeout == 0; +} + +int octeontx_phy_read(struct mii_dev *bus, int addr, int devad, int regnum) +{ + struct octeontx_smi_priv *priv = bus->priv; + union smi_x_cmd smix_cmd; + union smi_x_rd_dat smix_rd_dat; + unsigned long timeout = MDIO_TIMEOUT; + int ret; + + enum octeontx_smi_mode mode = (devad < 0) ? CLAUSE22 : CLAUSE45; + + debug("RD: Mode: %u, baseaddr: %p, addr: %d, devad: %d, reg: %d\n", + mode, priv->baseaddr, addr, devad, regnum); + + octeontx_smi_setmode(bus, mode); + + if (mode == CLAUSE45) { + ret = octeontx_c45_addr(bus, addr, devad, regnum); + + debug("RD: ret: %u\n", ret); + + if (ret) + return 0; + } + + smix_cmd.u = 0; + smix_cmd.s.phy_adr = addr; + + if (mode == CLAUSE45) { + smix_cmd.s.reg_adr = devad; + smix_cmd.s.phy_op = SMI_OP_C45_READ; + } else { + smix_cmd.s.reg_adr = regnum; + smix_cmd.s.phy_op = SMI_OP_C22_READ; + } + + writeq(smix_cmd.u, priv->baseaddr + SMI_X_CMD); + + do { + smix_rd_dat.u = readq(priv->baseaddr + SMI_X_RD_DAT); + udelay(10); + timeout--; + } while (smix_rd_dat.s.pending && timeout); + + debug("SMIX_RD_DAT: %lx\n", (unsigned long)smix_rd_dat.u); + + return smix_rd_dat.s.dat; +} + +int octeontx_phy_write(struct mii_dev *bus, int addr, int devad, int regnum, + u16 value) +{ + struct octeontx_smi_priv *priv = bus->priv; + union smi_x_cmd smix_cmd; + union smi_x_wr_dat smix_wr_dat; + unsigned long timeout = MDIO_TIMEOUT; + int ret; + + enum octeontx_smi_mode mode = (devad < 0) ? CLAUSE22 : CLAUSE45; + + debug("WR: Mode: %u, baseaddr: %p, addr: %d, devad: %d, reg: %d\n", + mode, priv->baseaddr, addr, devad, regnum); + + if (mode == CLAUSE45) { + ret = octeontx_c45_addr(bus, addr, devad, regnum); + + debug("WR: ret: %u\n", ret); + + if (ret) + return ret; + } + + smix_wr_dat.u = 0; + smix_wr_dat.s.dat = value; + + writeq(smix_wr_dat.u, priv->baseaddr + SMI_X_WR_DAT); + + smix_cmd.u = 0; + smix_cmd.s.phy_adr = addr; + + if (mode == CLAUSE45) { + smix_cmd.s.reg_adr = devad; + smix_cmd.s.phy_op = SMI_OP_C45_WRITE; + } else { + smix_cmd.s.reg_adr = regnum; + smix_cmd.s.phy_op = SMI_OP_C22_WRITE; + } + + writeq(smix_cmd.u, priv->baseaddr + SMI_X_CMD); + + do { + smix_wr_dat.u = readq(priv->baseaddr + SMI_X_WR_DAT); + udelay(10); + timeout--; + } while (smix_wr_dat.s.pending && timeout); + + debug("SMIX_WR_DAT: %lx\n", (unsigned long)smix_wr_dat.u); + + return timeout == 0; +} + +int octeontx_smi_reset(struct mii_dev *bus) +{ + struct octeontx_smi_priv *priv = bus->priv; + + union smi_x_en smi_en; + + smi_en.s.en = 0; + writeq(smi_en.u, priv->baseaddr + SMI_X_EN); + + smi_en.s.en = 1; + writeq(smi_en.u, priv->baseaddr + SMI_X_EN); + + octeontx_smi_setmode(bus, CLAUSE22); + + return 0; +} + +/* PHY XS initialization, primarily for RXAUI + * + */ +int rxaui_phy_xs_init(struct mii_dev *bus, int phy_addr) +{ + int reg; + ulong start_time; + int phy_id1, phy_id2; + int oui, model_number; + + phy_id1 = octeontx_phy_read(bus, phy_addr, 1, 0x2); + phy_id2 = octeontx_phy_read(bus, phy_addr, 1, 0x3); + model_number = (phy_id2 >> 4) & 0x3F; + debug("%s model %x\n", __func__, model_number); + oui = phy_id1; + oui <<= 6; + oui |= (phy_id2 >> 10) & 0x3F; + debug("%s oui %x\n", __func__, oui); + switch (oui) { + case 0x5016: + if (model_number == 9) { + debug("%s +\n", __func__); + /* Perform hardware reset in XGXS control */ + reg = octeontx_phy_read(bus, phy_addr, 4, 0x0); + if ((reg & 0xffff) < 0) + goto read_error; + reg |= 0x8000; + octeontx_phy_write(bus, phy_addr, 4, 0x0, reg); + + start_time = get_timer(0); + do { + reg = octeontx_phy_read(bus, phy_addr, 4, 0x0); + if ((reg & 0xffff) < 0) + goto read_error; + } while ((reg & 0x8000) && get_timer(start_time) < 500); + if (reg & 0x8000) { + printf("HW reset for M88X3120 PHY failed"); + printf("MII_BMCR: 0x%x\n", reg); + return -1; + } + /* program 4.49155 with 0x5 */ + octeontx_phy_write(bus, phy_addr, 4, 0xc003, 0x5); + } + break; + default: + break; + } + + return 0; + +read_error: + debug("M88X3120 PHY config read failed\n"); + return -1; +} + +int octeontx_smi_probe(struct udevice *dev) +{ + int ret, subnode, cnt = 0, node = dev->node.of_offset; + struct mii_dev *bus; + struct octeontx_smi_priv *priv; + pci_dev_t bdf = dm_pci_get_bdf(dev); + + debug("SMI PCI device: %x\n", bdf); + dev->req_seq = PCI_FUNC(bdf); + if (!dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM)) { + printf("Failed to map PCI region for bdf %x\n", bdf); + return -1; + } + + fdt_for_each_subnode(subnode, gd->fdt_blob, node) { + ret = fdt_node_check_compatible(gd->fdt_blob, subnode, + "cavium,thunder-8890-mdio"); + if (ret) + continue; + + bus = mdio_alloc(); + priv = malloc(sizeof(*priv)); + if (!bus || !priv) { + printf("Failed to allocate OcteonTX MDIO bus # %u\n", + dev->seq); + return -1; + } + + bus->read = octeontx_phy_read; + bus->write = octeontx_phy_write; + bus->reset = octeontx_smi_reset; + bus->priv = priv; + + priv->mode = CLAUSE22; + priv->baseaddr = (void __iomem *)fdtdec_get_addr(gd->fdt_blob, + subnode, + "reg"); + debug("mdio base addr %p\n", priv->baseaddr); + + /* use given name or generate its own unique name */ + snprintf(bus->name, MDIO_NAME_LEN, "smi%d", cnt++); + + ret = mdio_register(bus); + if (ret) + return ret; + } + return 0; +} + +static const struct udevice_id octeontx_smi_ids[] = { + { .compatible = "cavium,thunder-8890-mdio-nexus" }, + {} +}; + +U_BOOT_DRIVER(octeontx_smi) = { + .name = "octeontx_smi", + .id = UCLASS_MISC, + .probe = octeontx_smi_probe, + .of_match = octeontx_smi_ids, +}; + +static struct pci_device_id octeontx_smi_supported[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_SMI) }, + {} +}; + +U_BOOT_PCI_DEVICE(octeontx_smi, octeontx_smi_supported); diff --git a/drivers/net/octeontx/xcv.c b/drivers/net/octeontx/xcv.c new file mode 100644 index 0000000000..1186157485 --- /dev/null +++ b/drivers/net/octeontx/xcv.c @@ -0,0 +1,129 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <config.h> +#include <common.h> +#include <errno.h> +#include <net.h> +#include <dm.h> +#include <pci.h> +#include <misc.h> +#include <netdev.h> +#include <malloc.h> +#include <miiphy.h> +#include <asm/io.h> + +#ifdef CONFIG_OF_LIBFDT + #include <linux/libfdt.h> + #include <fdt_support.h> +#endif + +#include <asm/arch/csrs/csrs-xcv.h> + +#define XCVX_BASE 0x87E0DB000000ULL + +/* Initialize XCV block */ +void xcv_init_hw(void) +{ + union xcvx_reset reset; + union xcvx_dll_ctl xcv_dll_ctl; + + /* Take the DLL out of reset */ + reset.u = readq(XCVX_BASE + XCVX_RESET(0)); + reset.s.dllrst = 0; + writeq(reset.u, XCVX_BASE + XCVX_RESET(0)); + + /* Take the clock tree out of reset */ + reset.u = readq(XCVX_BASE + XCVX_RESET(0)); + reset.s.clkrst = 0; + writeq(reset.u, XCVX_BASE + XCVX_RESET(0)); + + /* Once the 125MHz ref clock is stable, wait 10us for DLL to lock */ + udelay(10); + + /* Optionally, bypass the DLL setting */ + xcv_dll_ctl.u = readq(XCVX_BASE + XCVX_DLL_CTL(0)); + xcv_dll_ctl.s.clkrx_set = 0; + xcv_dll_ctl.s.clkrx_byp = 1; + xcv_dll_ctl.s.clktx_byp = 0; + writeq(xcv_dll_ctl.u, XCVX_BASE + XCVX_DLL_CTL(0)); + + /* Enable the compensation controller */ + reset.u = readq(XCVX_BASE + XCVX_RESET(0)); + reset.s.comp = 1; + writeq(reset.u, XCVX_BASE + XCVX_RESET(0)); + reset.u = readq(XCVX_BASE + XCVX_RESET(0)); + + /* Wait for 1040 reference clock cycles for the compensation state + * machine lock. + */ + udelay(100); + + /* Enable the XCV block */ + reset.u = readq(XCVX_BASE + XCVX_RESET(0)); + reset.s.enable = 1; + writeq(reset.u, XCVX_BASE + XCVX_RESET(0)); + + /* set XCV(0)_RESET[CLKRST] to 1 */ + reset.u = readq(XCVX_BASE + XCVX_RESET(0)); + reset.s.clkrst = 1; + writeq(reset.u, XCVX_BASE + XCVX_RESET(0)); +} + +/* + * Configure XCV link based on the speed + * link_up : Set to 1 when link is up otherwise 0 + * link_speed: The speed of the link. + */ +void xcv_setup_link(bool link_up, int link_speed) +{ + union xcvx_ctl xcv_ctl; + union xcvx_reset reset; + union xcvx_batch_crd_ret xcv_crd_ret; + int speed = 2; + + /* Check RGMII link */ + if (link_speed == 100) + speed = 1; + else if (link_speed == 10) + speed = 0; + + if (link_up) { + /* Set operating speed */ + xcv_ctl.u = readq(XCVX_BASE + XCVX_CTL(0)); + xcv_ctl.s.speed = speed; + writeq(xcv_ctl.u, XCVX_BASE + XCVX_CTL(0)); + + /* Datapaths come out of reset + * - The datapath resets will disengage BGX from the + * RGMII interface + * - XCV will continue to return TX credits for each tick + * that is sent on the TX data path + */ + reset.u = readq(XCVX_BASE + XCVX_RESET(0)); + reset.s.tx_dat_rst_n = 1; + reset.s.rx_dat_rst_n = 1; + writeq(reset.u, XCVX_BASE + XCVX_RESET(0)); + + /* Enable packet flow */ + reset.u = readq(XCVX_BASE + XCVX_RESET(0)); + reset.s.tx_pkt_rst_n = 1; + reset.s.rx_pkt_rst_n = 1; + writeq(reset.u, XCVX_BASE + XCVX_RESET(0)); + + xcv_crd_ret.u = readq(XCVX_BASE + XCVX_BATCH_CRD_RET(0)); + xcv_crd_ret.s.crd_ret = 1; + writeq(xcv_crd_ret.u, XCVX_BASE + XCVX_BATCH_CRD_RET(0)); + } else { + /* Enable packet flow */ + reset.u = readq(XCVX_BASE + XCVX_RESET(0)); + reset.s.tx_pkt_rst_n = 0; + reset.s.rx_pkt_rst_n = 0; + writeq(reset.u, XCVX_BASE + XCVX_RESET(0)); + reset.u = readq(XCVX_BASE + XCVX_RESET(0)); + } +}
Adds support for Network Interface controllers found on OcteonTX2 SoC platforms.
Signed-off-by: Suneel Garapati sgarapati@marvell.com Cc: Joe Hershberger joe.hershberger@ni.com
Signed-off-by: Stefan Roese sr@denx.de ---
(no changes since v1)
Changes in v1: - Change patch subject - Rebased on latest TOT - Removed inclusion of common.h
drivers/net/Kconfig | 17 + drivers/net/Makefile | 2 + drivers/net/octeontx2/Makefile | 11 + drivers/net/octeontx2/cgx.c | 298 ++++++++ drivers/net/octeontx2/cgx.h | 107 +++ drivers/net/octeontx2/cgx_intf.c | 717 ++++++++++++++++++ drivers/net/octeontx2/cgx_intf.h | 450 ++++++++++++ drivers/net/octeontx2/lmt.h | 51 ++ drivers/net/octeontx2/nix.c | 833 +++++++++++++++++++++ drivers/net/octeontx2/nix.h | 355 +++++++++ drivers/net/octeontx2/nix_af.c | 1104 ++++++++++++++++++++++++++++ drivers/net/octeontx2/npc.h | 92 +++ drivers/net/octeontx2/rvu.h | 121 +++ drivers/net/octeontx2/rvu_af.c | 173 +++++ drivers/net/octeontx2/rvu_common.c | 73 ++ drivers/net/octeontx2/rvu_pf.c | 118 +++ 16 files changed, 4522 insertions(+) create mode 100644 drivers/net/octeontx2/Makefile create mode 100644 drivers/net/octeontx2/cgx.c create mode 100644 drivers/net/octeontx2/cgx.h create mode 100644 drivers/net/octeontx2/cgx_intf.c create mode 100644 drivers/net/octeontx2/cgx_intf.h create mode 100644 drivers/net/octeontx2/lmt.h create mode 100644 drivers/net/octeontx2/nix.c create mode 100644 drivers/net/octeontx2/nix.h create mode 100644 drivers/net/octeontx2/nix_af.c create mode 100644 drivers/net/octeontx2/npc.h create mode 100644 drivers/net/octeontx2/rvu.h create mode 100644 drivers/net/octeontx2/rvu_af.c create mode 100644 drivers/net/octeontx2/rvu_common.c create mode 100644 drivers/net/octeontx2/rvu_pf.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6f077bad58..84b0910f9b 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -414,6 +414,15 @@ config NET_OCTEONTX help You must select Y to enable network device support for OcteonTX SoCs. If unsure, say n + +config NET_OCTEONTX2 + bool "OcteonTX2 Ethernet support" + depends on ARCH_OCTEONTX2 + select OCTEONTX2_CGX_INTF + help + You must select Y to enable network device support for + OcteonTX2 SoCs. If unsure, say n + config OCTEONTX_SMI bool "OcteonTX SMI Device support" depends on ARCH_OCTEONTX || ARCH_OCTEONTX2 @@ -421,6 +430,14 @@ config OCTEONTX_SMI You must select Y to enable SMI controller support for OcteonTX or OcteonTX2 SoCs. If unsure, say n
+config OCTEONTX2_CGX_INTF + bool "OcteonTX2 CGX ATF interface support" + depends on ARCH_OCTEONTX2 + default y if ARCH_OCTEONTX2 + help + You must select Y to enable CGX ATF interface support for + OcteonTX2 SoCs. If unsure, say n + config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver" depends on DM_ETH && DM_PCI diff --git a/drivers/net/Makefile b/drivers/net/Makefile index bee9680f76..c07b5ad698 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -66,7 +66,9 @@ obj-$(CONFIG_SMC91111) += smc91111.o obj-$(CONFIG_SMC911X) += smc911x.o obj-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o obj-$(CONFIG_NET_OCTEONTX) += octeontx/ +obj-$(CONFIG_NET_OCTEONTX2) += octeontx2/ obj-$(CONFIG_OCTEONTX_SMI) += octeontx/smi.o +obj-$(CONFIG_OCTEONTX2_CGX_INTF) += octeontx2/cgx_intf.o obj-$(CONFIG_FMAN_ENET) += fsl_mdio.o obj-$(CONFIG_ULI526X) += uli526x.o obj-$(CONFIG_VSC7385_ENET) += vsc7385.o diff --git a/drivers/net/octeontx2/Makefile b/drivers/net/octeontx2/Makefile new file mode 100644 index 0000000000..92183ffc3e --- /dev/null +++ b/drivers/net/octeontx2/Makefile @@ -0,0 +1,11 @@ +#/* +# * Copyright (C) 2018 Marvell International Ltd. +# * +# * SPDX-License-Identifier: GPL-2.0 +# * https://spdx.org/licenses +# */ + + +obj-$(CONFIG_NET_OCTEONTX2) += cgx.o nix_af.o nix.o rvu_pf.o \ + rvu_af.o rvu_common.o + diff --git a/drivers/net/octeontx2/cgx.c b/drivers/net/octeontx2/cgx.c new file mode 100644 index 0000000000..378b11503e --- /dev/null +++ b/drivers/net/octeontx2/cgx.c @@ -0,0 +1,298 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <pci_ids.h> +#include <linux/list.h> +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-cgx.h> +#include <asm/io.h> + +#include "cgx.h" + +char lmac_type_to_str[][8] = { + "SGMII", + "XAUI", + "RXAUI", + "10G_R", + "40G_R", + "RGMII", + "QSGMII", + "25G_R", + "50G_R", + "100G_R", + "USXGMII", +}; + +char lmac_speed_to_str[][8] = { + "0", + "10M", + "100M", + "1G", + "2.5G", + "5G", + "10G", + "20G", + "25G", + "40G", + "50G", + "80G", + "100G", +}; + +/** + * Given an LMAC/PF instance number, return the lmac + * Per design, each PF has only one LMAC mapped. + * + * @param instance instance to find + * + * @return pointer to lmac data structure or NULL if not found + */ +struct lmac *nix_get_cgx_lmac(int lmac_instance) +{ + struct cgx *cgx; + struct udevice *dev; + int i, idx, err; + + for (i = 0; i < CGX_PER_NODE; i++) { + err = dm_pci_find_device(PCI_VENDOR_ID_CAVIUM, + PCI_DEVICE_ID_OCTEONTX2_CGX, i, + &dev); + if (err) + continue; + + cgx = dev_get_priv(dev); + debug("%s udev %p cgx %p instance %d\n", __func__, dev, cgx, + lmac_instance); + for (idx = 0; idx < cgx->lmac_count; idx++) { + if (cgx->lmac[idx]->instance == lmac_instance) + return cgx->lmac[idx]; + } + } + return NULL; +} + +void cgx_lmac_mac_filter_clear(struct lmac *lmac) +{ + union cgxx_cmrx_rx_dmac_ctl0 dmac_ctl0; + union cgxx_cmr_rx_dmacx_cam0 dmac_cam0; + void *reg_addr; + + dmac_cam0.u = 0x0; + reg_addr = lmac->cgx->reg_base + + CGXX_CMR_RX_DMACX_CAM0(lmac->lmac_id * 8); + writeq(dmac_cam0.u, reg_addr); + debug("%s: reg %p dmac_cam0 %llx\n", __func__, reg_addr, dmac_cam0.u); + + dmac_ctl0.u = 0x0; + dmac_ctl0.s.bcst_accept = 1; + dmac_ctl0.s.mcst_mode = 1; + dmac_ctl0.s.cam_accept = 0; + reg_addr = lmac->cgx->reg_base + + CGXX_CMRX_RX_DMAC_CTL0(lmac->lmac_id); + writeq(dmac_ctl0.u, reg_addr); + debug("%s: reg %p dmac_ctl0 %llx\n", __func__, reg_addr, dmac_ctl0.u); +} + +void cgx_lmac_mac_filter_setup(struct lmac *lmac) +{ + union cgxx_cmrx_rx_dmac_ctl0 dmac_ctl0; + union cgxx_cmr_rx_dmacx_cam0 dmac_cam0; + u64 mac, tmp; + void *reg_addr; + + memcpy((void *)&tmp, lmac->mac_addr, 6); + debug("%s: tmp %llx\n", __func__, tmp); + debug("%s: swab tmp %llx\n", __func__, swab64(tmp)); + mac = swab64(tmp) >> 16; + debug("%s: mac %llx\n", __func__, mac); + dmac_cam0.u = 0x0; + dmac_cam0.s.id = lmac->lmac_id; + dmac_cam0.s.adr = mac; + dmac_cam0.s.en = 1; + reg_addr = lmac->cgx->reg_base + + CGXX_CMR_RX_DMACX_CAM0(lmac->lmac_id * 8); + writeq(dmac_cam0.u, reg_addr); + debug("%s: reg %p dmac_cam0 %llx\n", __func__, reg_addr, dmac_cam0.u); + dmac_ctl0.u = 0x0; + dmac_ctl0.s.bcst_accept = 1; + dmac_ctl0.s.mcst_mode = 0; + dmac_ctl0.s.cam_accept = 1; + reg_addr = lmac->cgx->reg_base + + CGXX_CMRX_RX_DMAC_CTL0(lmac->lmac_id); + writeq(dmac_ctl0.u, reg_addr); + debug("%s: reg %p dmac_ctl0 %llx\n", __func__, reg_addr, dmac_ctl0.u); +} + +int cgx_lmac_set_pkind(struct lmac *lmac, u8 lmac_id, int pkind) +{ + cgx_write(lmac->cgx, lmac_id, CGXX_CMRX_RX_ID_MAP(0), + (pkind & 0x3f)); + return 0; +} + +int cgx_lmac_link_status(struct lmac *lmac, int lmac_id, u64 *status) +{ + int ret = 0; + + ret = cgx_intf_get_link_sts(lmac->cgx->cgx_id, lmac_id, status); + if (ret) { + debug("%s request failed for cgx%d lmac%d\n", + __func__, lmac->cgx->cgx_id, lmac->lmac_id); + ret = -1; + } + return ret; +} + +int cgx_lmac_rx_tx_enable(struct lmac *lmac, int lmac_id, bool enable) +{ + struct cgx *cgx = lmac->cgx; + union cgxx_cmrx_config cmrx_config; + + if (!cgx || lmac_id >= cgx->lmac_count) + return -ENODEV; + + cmrx_config.u = cgx_read(cgx, lmac_id, CGXX_CMRX_CONFIG(0)); + cmrx_config.s.data_pkt_rx_en = + cmrx_config.s.data_pkt_tx_en = enable ? 1 : 0; + cgx_write(cgx, lmac_id, CGXX_CMRX_CONFIG(0), cmrx_config.u); + return 0; +} + +int cgx_lmac_link_enable(struct lmac *lmac, int lmac_id, bool enable, + u64 *status) +{ + int ret = 0; + + ret = cgx_intf_link_up_dwn(lmac->cgx->cgx_id, lmac_id, enable, + status); + if (ret) { + debug("%s request failed for cgx%d lmac%d\n", + __func__, lmac->cgx->cgx_id, lmac->lmac_id); + ret = -1; + } + return ret; +} + +int cgx_lmac_internal_loopback(struct lmac *lmac, int lmac_id, bool enable) +{ + struct cgx *cgx = lmac->cgx; + union cgxx_cmrx_config cmrx_cfg; + union cgxx_gmp_pcs_mrx_control mrx_control; + union cgxx_spux_control1 spux_control1; + enum lmac_type lmac_type; + + if (!cgx || lmac_id >= cgx->lmac_count) + return -ENODEV; + + cmrx_cfg.u = cgx_read(cgx, lmac_id, CGXX_CMRX_CONFIG(0)); + lmac_type = cmrx_cfg.s.lmac_type; + if (lmac_type == LMAC_MODE_SGMII || lmac_type == LMAC_MODE_QSGMII) { + mrx_control.u = cgx_read(cgx, lmac_id, + CGXX_GMP_PCS_MRX_CONTROL(0)); + mrx_control.s.loopbck1 = enable ? 1 : 0; + cgx_write(cgx, lmac_id, CGXX_GMP_PCS_MRX_CONTROL(0), + mrx_control.u); + } else { + spux_control1.u = cgx_read(cgx, lmac_id, + CGXX_SPUX_CONTROL1(0)); + spux_control1.s.loopbck = enable ? 1 : 0; + cgx_write(cgx, lmac_id, CGXX_SPUX_CONTROL1(0), + spux_control1.u); + } + return 0; +} + +static int cgx_lmac_init(struct cgx *cgx) +{ + struct lmac *lmac; + union cgxx_cmrx_config cmrx_cfg; + static int instance = 1; + int i; + + cgx->lmac_count = cgx_read(cgx, 0, CGXX_CMR_RX_LMACS()); + debug("%s: Found %d lmacs for cgx %d@%p\n", __func__, cgx->lmac_count, + cgx->cgx_id, cgx->reg_base); + + for (i = 0; i < cgx->lmac_count; i++) { + lmac = calloc(1, sizeof(*lmac)); + if (!lmac) + return -ENOMEM; + lmac->instance = instance++; + snprintf(lmac->name, sizeof(lmac->name), "cgx_fwi_%d_%d", + cgx->cgx_id, i); + /* Get LMAC type */ + cmrx_cfg.u = cgx_read(cgx, i, CGXX_CMRX_CONFIG(0)); + lmac->lmac_type = cmrx_cfg.s.lmac_type; + + lmac->lmac_id = i; + lmac->cgx = cgx; + cgx->lmac[i] = lmac; + debug("%s: map id %d to lmac %p (%s), type:%d instance %d\n", + __func__, i, lmac, lmac->name, lmac->lmac_type, + lmac->instance); + lmac->init_pend = 1; + printf("CGX%d LMAC%d [%s]\n", lmac->cgx->cgx_id, + lmac->lmac_id, lmac_type_to_str[lmac->lmac_type]); + octeontx2_board_get_mac_addr((lmac->instance - 1), + lmac->mac_addr); + debug("%s: MAC %pM\n", __func__, lmac->mac_addr); + cgx_lmac_mac_filter_setup(lmac); + } + return 0; +} + +int cgx_probe(struct udevice *dev) +{ + struct cgx *cgx = dev_get_priv(dev); + int err; + + cgx->reg_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + cgx->dev = dev; + cgx->cgx_id = ((u64)(cgx->reg_base) >> 24) & 0x7; + + debug("%s CGX BAR %p, id: %d\n", __func__, cgx->reg_base, + cgx->cgx_id); + debug("%s CGX %p, udev: %p\n", __func__, cgx, dev); + + err = cgx_lmac_init(cgx); + + return err; +} + +int cgx_remove(struct udevice *dev) +{ + struct cgx *cgx = dev_get_priv(dev); + int i; + + debug("%s: cgx remove reg_base %p cgx_id %d", + __func__, cgx->reg_base, cgx->cgx_id); + for (i = 0; i < cgx->lmac_count; i++) + cgx_lmac_mac_filter_clear(cgx->lmac[i]); + + return 0; +} + +U_BOOT_DRIVER(cgx) = { + .name = "cgx", + .id = UCLASS_MISC, + .probe = cgx_probe, + .remove = cgx_remove, + .priv_auto_alloc_size = sizeof(struct cgx), +}; + +static struct pci_device_id cgx_supported[] = { + {PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_CGX) }, + {} +}; + +U_BOOT_PCI_DEVICE(cgx, cgx_supported); diff --git a/drivers/net/octeontx2/cgx.h b/drivers/net/octeontx2/cgx.h new file mode 100644 index 0000000000..d2ce7e04a4 --- /dev/null +++ b/drivers/net/octeontx2/cgx.h @@ -0,0 +1,107 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __CGX_H__ +#define __CGX_H__ + +#include "cgx_intf.h" + +#define PCI_DEVICE_ID_OCTEONTX2_CGX 0xA059 + +#define MAX_LMAC_PER_CGX 4 +#define CGX_PER_NODE 3 + +enum lmac_type { + LMAC_MODE_SGMII = 0, + LMAC_MODE_XAUI = 1, + LMAC_MODE_RXAUI = 2, + LMAC_MODE_10G_R = 3, + LMAC_MODE_40G_R = 4, + LMAC_MODE_QSGMII = 6, + LMAC_MODE_25G_R = 7, + LMAC_MODE_50G_R = 8, + LMAC_MODE_100G_R = 9, + LMAC_MODE_USXGMII = 10, +}; + +extern char lmac_type_to_str[][8]; + +extern char lmac_speed_to_str[][8]; + +struct lmac_priv { + u8 enable:1; + u8 full_duplex:1; + u8 speed:4; + u8 mode:1; + u8 rsvd:1; + u8 mac_addr[6]; +}; + +struct cgx; +struct nix; +struct nix_af; + +struct lmac { + struct cgx *cgx; + struct nix *nix; + char name[16]; + enum lmac_type lmac_type; + bool init_pend; + u8 instance; + u8 lmac_id; + u8 pknd; + u8 link_num; + u32 chan_num; + u8 mac_addr[6]; +}; + +struct cgx { + struct nix_af *nix_af; + void __iomem *reg_base; + struct udevice *dev; + struct lmac *lmac[MAX_LMAC_PER_CGX]; + u8 cgx_id; + u8 lmac_count; +}; + +static inline void cgx_write(struct cgx *cgx, u8 lmac, u64 offset, u64 val) +{ + writeq(val, cgx->reg_base + CMR_SHIFT(lmac) + offset); +} + +static inline u64 cgx_read(struct cgx *cgx, u8 lmac, u64 offset) +{ + return readq(cgx->reg_base + CMR_SHIFT(lmac) + offset); +} + +/** + * Given an LMAC/PF instance number, return the lmac + * Per design, each PF has only one LMAC mapped. + * + * @param instance instance to find + * + * @return pointer to lmac data structure or NULL if not found + */ +struct lmac *nix_get_cgx_lmac(int lmac_instance); + +int cgx_lmac_set_pkind(struct lmac *lmac, u8 lmac_id, int pkind); +int cgx_lmac_internal_loopback(struct lmac *lmac, int lmac_id, bool enable); +int cgx_lmac_rx_tx_enable(struct lmac *lmac, int lmac_id, bool enable); +int cgx_lmac_link_enable(struct lmac *lmac, int lmac_id, bool enable, + u64 *status); +int cgx_lmac_link_status(struct lmac *lmac, int lmac_id, u64 *status); +void cgx_lmac_mac_filter_setup(struct lmac *lmac); + +int cgx_intf_get_link_sts(u8 cgx, u8 lmac, u64 *lnk_sts); +int cgx_intf_link_up_dwn(u8 cgx, u8 lmac, u8 up_dwn, u64 *lnk_sts); +int cgx_intf_get_mac_addr(u8 cgx, u8 lmac, u8 *mac); +int cgx_intf_set_macaddr(struct udevice *dev); +int cgx_intf_prbs(u8 qlm, u8 mode, u32 time, u8 lane); +int cgx_intf_display_eye(u8 qlm, u8 lane); +int cgx_intf_display_serdes(u8 qlm, u8 lane); + +#endif /* __CGX_H__ */ diff --git a/drivers/net/octeontx2/cgx_intf.c b/drivers/net/octeontx2/cgx_intf.c new file mode 100644 index 0000000000..02c84b72a9 --- /dev/null +++ b/drivers/net/octeontx2/cgx_intf.c @@ -0,0 +1,717 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> + +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/list.h> + +#include <asm/arch/board.h> +#include <asm/io.h> + +#include "cgx_intf.h" +#include "cgx.h" +#include "nix.h" + +static u64 cgx_rd_scrx(u8 cgx, u8 lmac, u8 index) +{ + u64 addr; + + addr = (index == 1) ? CGX_CMR_SCRATCH1 : CGX_CMR_SCRATCH0; + addr += CGX_SHIFT(cgx) + CMR_SHIFT(lmac); + return readq(addr); +} + +static void cgx_wr_scrx(u8 cgx, u8 lmac, u8 index, u64 val) +{ + u64 addr; + + addr = (index == 1) ? CGX_CMR_SCRATCH1 : CGX_CMR_SCRATCH0; + addr += CGX_SHIFT(cgx) + CMR_SHIFT(lmac); + writeq(val, addr); +} + +static u64 cgx_rd_scr0(u8 cgx, u8 lmac) +{ + return cgx_rd_scrx(cgx, lmac, 0); +} + +static u64 cgx_rd_scr1(u8 cgx, u8 lmac) +{ + return cgx_rd_scrx(cgx, lmac, 1); +} + +static void cgx_wr_scr0(u8 cgx, u8 lmac, u64 val) +{ + return cgx_wr_scrx(cgx, lmac, 0, val); +} + +static void cgx_wr_scr1(u8 cgx, u8 lmac, u64 val) +{ + return cgx_wr_scrx(cgx, lmac, 1, val); +} + +static inline void set_ownership(u8 cgx, u8 lmac, u8 val) +{ + union cgx_scratchx1 scr1; + + scr1.u = cgx_rd_scr1(cgx, lmac); + scr1.s.own_status = val; + cgx_wr_scr1(cgx, lmac, scr1.u); +} + +static int wait_for_ownership(u8 cgx, u8 lmac) +{ + union cgx_scratchx1 scr1; + union cgx_scratchx0 scr0; + u64 cmrx_int; + int timeout = 5000; + + do { + scr1.u = cgx_rd_scr1(cgx, lmac); + scr0.u = cgx_rd_scr0(cgx, lmac); + /* clear async events if any */ + if (scr0.s.evt_sts.evt_type == CGX_EVT_ASYNC && + scr0.s.evt_sts.ack) { + /* clear interrupt */ + cmrx_int = readq(CGX_CMR_INT + + CGX_SHIFT(cgx) + CMR_SHIFT(lmac)); + cmrx_int |= 0x2; // Overflw bit + writeq(cmrx_int, CGX_CMR_INT + + CGX_SHIFT(cgx) + CMR_SHIFT(lmac)); + + /* clear ack */ + scr0.s.evt_sts.ack = 0; + cgx_wr_scr0(cgx, lmac, scr0.u); + } + + if (timeout-- < 0) { + debug("timeout waiting for ownership\n"); + return -ETIMEDOUT; + } + mdelay(1); + } while ((scr1.s.own_status == CGX_OWN_FIRMWARE) && + scr0.s.evt_sts.ack); + + return 0; +} + +int cgx_intf_req(u8 cgx, u8 lmac, union cgx_cmd_s cmd_args, u64 *rsp, + int use_cmd_id_only) +{ + union cgx_scratchx1 scr1; + union cgx_scratchx0 scr0; + u64 cmrx_int; + int timeout = 500; + int err = 0; + u8 cmd = cmd_args.cmd.id; + + if (wait_for_ownership(cgx, lmac)) { + err = -ETIMEDOUT; + goto error; + } + + /* send command */ + scr1.u = cgx_rd_scr1(cgx, lmac); + + if (use_cmd_id_only) { + scr1.s.cmd.id = cmd; + } else { + cmd_args.own_status = scr1.s.own_status; + scr1.s = cmd_args; + } + cgx_wr_scr1(cgx, lmac, scr1.u); + + set_ownership(cgx, lmac, CGX_OWN_FIRMWARE); + + /* wait for response and ownership */ + do { + scr0.u = cgx_rd_scr0(cgx, lmac); + scr1.u = cgx_rd_scr1(cgx, lmac); + mdelay(10); + } while (timeout-- && (!scr0.s.evt_sts.ack) && + (scr1.s.own_status == CGX_OWN_FIRMWARE)); + if (timeout < 0) { + debug("%s timeout waiting for ack\n", __func__); + err = -ETIMEDOUT; + goto error; + } + + if (cmd == CGX_CMD_INTF_SHUTDOWN) + goto error; + + if (scr0.s.evt_sts.evt_type != CGX_EVT_CMD_RESP) { + debug("%s received async event instead of cmd resp event\n", + __func__); + err = -1; + goto error; + } + if (scr0.s.evt_sts.id != cmd) { + debug("%s received resp for cmd %d expected cmd %d\n", + __func__, scr0.s.evt_sts.id, cmd); + err = -1; + goto error; + } + if (scr0.s.evt_sts.stat != CGX_STAT_SUCCESS) { + debug("%s cmd%d failed on cgx%u lmac%u with errcode %d\n", + __func__, cmd, cgx, lmac, scr0.s.link_sts.err_type); + err = -1; + } + +error: + /* clear interrupt */ + cmrx_int = readq(CGX_CMR_INT + CGX_SHIFT(cgx) + CMR_SHIFT(lmac)); + cmrx_int |= 0x2; // Overflw bit + writeq(cmrx_int, CGX_CMR_INT + CGX_SHIFT(cgx) + CMR_SHIFT(lmac)); + + /* clear ownership and ack */ + scr0.s.evt_sts.ack = 0; + cgx_wr_scr0(cgx, lmac, scr0.u); + + *rsp = err ? 0 : scr0.u; + + return err; +} + +int cgx_intf_get_mac_addr(u8 cgx, u8 lmac, u8 *mac) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_MAC_ADDR; + + ret = cgx_intf_req(cgx, lmac, cmd, &scr0.u, 1); + if (ret) + return -1; + + scr0.u >>= 9; + memcpy(mac, &scr0.u, 6); + + return 0; +} + +int cgx_intf_get_ver(u8 cgx, u8 lmac, u8 *ver) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_FW_VER; + + ret = cgx_intf_req(cgx, lmac, cmd, &scr0.u, 1); + if (ret) + return -1; + + scr0.u >>= 9; + *ver = scr0.u & 0xFFFF; + + return 0; +} + +int cgx_intf_get_link_sts(u8 cgx, u8 lmac, u64 *lnk_sts) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_LINK_STS; + + ret = cgx_intf_req(cgx, lmac, cmd, &scr0.u, 1); + if (ret) + return -1; + + scr0.u >>= 9; + /* pass the same format as cgx_lnk_sts_s + * err_type:10, speed:4, full_duplex:1, link_up:1 + */ + *lnk_sts = scr0.u & 0xFFFF; + return 0; +} + +int cgx_intf_link_up_dwn(u8 cgx, u8 lmac, u8 up_dwn, u64 *lnk_sts) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = up_dwn ? CGX_CMD_LINK_BRING_UP : CGX_CMD_LINK_BRING_DOWN; + + ret = cgx_intf_req(cgx, lmac, cmd, &scr0.u, 1); + if (ret) + return -1; + + scr0.u >>= 9; + /* pass the same format as cgx_lnk_sts_s + * err_type:10, speed:4, full_duplex:1, link_up:1 + */ + *lnk_sts = scr0.u & 0xFFFF; + return 0; +} + +void cgx_intf_shutdown(void) +{ + union cgx_scratchx0 scr0; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_INTF_SHUTDOWN; + + cgx_intf_req(0, 0, cmd, &scr0.u, 1); +} + +int cgx_intf_prbs(u8 qlm, u8 mode, u32 time, u8 lane) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_PRBS; + + cmd.prbs_args.qlm = qlm; + cmd.prbs_args.mode = mode; + cmd.prbs_args.time = time; + cmd.prbs_args.lane = lane; + + ret = cgx_intf_req(0, 0, cmd, &scr0.u, 0); + if (ret) + return -1; + + return 0; +} + +enum cgx_mode { + MODE_10G_C2C, + MODE_10G_C2M, + MODE_10G_KR, + MODE_25G_C2C, + MODE_25G_2_C2C, + MODE_50G_C2C, + MODE_50G_4_C2C +}; + +static char intf_speed_to_str[][8] = { + "10M", + "100M", + "1G", + "2.5G", + "5G", + "10G", + "20G", + "25G", + "40G", + "50G", + "80G", + "100G", +}; + +static void mode_to_args(int mode, struct cgx_mode_change_args *args) +{ + args->an = 0; + args->duplex = 0; + args->port = 0; + + switch (mode) { + case MODE_10G_C2C: + args->speed = CGX_LINK_10G; + args->mode = BIT_ULL(CGX_MODE_10G_C2C_BIT); + break; + case MODE_10G_C2M: + args->speed = CGX_LINK_10G; + args->mode = BIT_ULL(CGX_MODE_10G_C2M_BIT); + break; + case MODE_10G_KR: + args->speed = CGX_LINK_10G; + args->mode = BIT_ULL(CGX_MODE_10G_KR_BIT); + args->an = 1; + break; + case MODE_25G_C2C: + args->speed = CGX_LINK_25G; + args->mode = BIT_ULL(CGX_MODE_25G_C2C_BIT); + break; + case MODE_25G_2_C2C: + args->speed = CGX_LINK_25G; + args->mode = BIT_ULL(CGX_MODE_25G_2_C2C_BIT); + break; + case MODE_50G_C2C: + args->speed = CGX_LINK_50G; + args->mode = BIT_ULL(CGX_MODE_50G_C2C_BIT); + break; + case MODE_50G_4_C2C: + args->speed = CGX_LINK_50G; + args->mode = BIT_ULL(CGX_MODE_50G_4_C2C_BIT); + } +} + +int cgx_intf_set_mode(struct udevice *ethdev, int mode) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_MODE_CHANGE; + + mode_to_args(mode, &cmd.mode_change_args); + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 0); + if (ret) { + printf("Mode change command failed for %s\n", ethdev->name); + return -1; + } + + cmd.cmd.id = CGX_CMD_GET_LINK_STS; + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 1); + if (ret) { + printf("Get Link Status failed for %s\n", ethdev->name); + return -1; + } + + printf("Current Link Status: "); + if (scr0.s.link_sts.speed) { + printf("%s\n", intf_speed_to_str[scr0.s.link_sts.speed]); + switch (scr0.s.link_sts.fec) { + case 0: + printf("FEC_NONE\n"); + break; + case 1: + printf("FEC_BASE_R\n"); + break; + case 2: + printf("FEC_RS\n"); + break; + } + printf("Auto Negotiation %sabled\n", + scr0.s.link_sts.an ? "En" : "Dis"); + printf("%s Duplex\n", + scr0.s.link_sts.full_duplex ? "Full" : "Half"); + } else { + printf("Down\n"); + } + return 0; +} + +int cgx_intf_get_mode(struct udevice *ethdev) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_LINK_STS; + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 1); + if (ret) { + printf("Get link status failed for %s\n", ethdev->name); + return -1; + } + printf("Current Interface Mode: "); + switch (scr0.s.link_sts.mode) { + case CGX_MODE_10G_C2C_BIT: + printf("10G_C2C\n"); + break; + case CGX_MODE_10G_C2M_BIT: + printf("10G_C2M\n"); + break; + case CGX_MODE_10G_KR_BIT: + printf("10G_KR\n"); + break; + case CGX_MODE_25G_C2C_BIT: + printf("25G_C2C\n"); + break; + case CGX_MODE_25G_2_C2C_BIT: + printf("25G_2_C2C\n"); + break; + case CGX_MODE_50G_C2C_BIT: + printf("50G_C2C\n"); + break; + case CGX_MODE_50G_4_C2C_BIT: + printf("50G_4_C2C\n"); + break; + default: + printf("Unknown\n"); + break; + } + return 0; +} + +int cgx_intf_get_fec(struct udevice *ethdev) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_SUPPORTED_FEC; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 1); + if (ret) { + printf("Get supported FEC failed for %s\n", ethdev->name); + return -1; + } + + printf("Supported FEC type: "); + switch (scr0.s.supported_fec.fec) { + case 0: + printf("FEC_NONE\n"); + break; + case 1: + printf("FEC_BASE_R\n"); + break; + case 2: + printf("FEC_RS\n"); + break; + case 3: + printf("FEC_BASE_R FEC_RS\n"); + break; + } + + cmd.cmd.id = CGX_CMD_GET_LINK_STS; + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 1); + if (ret) { + printf("Get active fec failed for %s\n", ethdev->name); + return -1; + } + printf("Active FEC type: "); + switch (scr0.s.link_sts.fec) { + case 0: + printf("FEC_NONE\n"); + break; + case 1: + printf("FEC_BASE_R\n"); + break; + case 2: + printf("FEC_RS\n"); + break; + } + return 0; +} + +int cgx_intf_set_fec(struct udevice *ethdev, int type) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_SET_FEC; + cmd.fec_args.fec = type; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 0); + if (ret) { + printf("Set FEC type %d failed for %s\n", type, ethdev->name); + return -1; + } + return 0; +} + +int cgx_intf_get_phy_mod_type(struct udevice *ethdev) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_PHY_MOD_TYPE; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 1); + if (ret) { + printf("Get PHYMOD type failed for %s\n", ethdev->name); + return -1; + } + printf("Current phy mod type %s\n", + scr0.s.phy_mod_type.mod ? "PAM4" : "NRZ"); + return 0; +} + +int cgx_intf_set_phy_mod_type(struct udevice *ethdev, int type) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_SET_PHY_MOD_TYPE; + cmd.phy_mod_args.mod = type; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 0); + if (ret) { + printf("Set PHYMOD type %d failed for %s\n", type, + ethdev->name); + return -1; + } + + return 0; +} + +int cgx_intf_set_an_lbk(struct udevice *ethdev, int enable) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_AN_LOOPBACK; + cmd.cmd_args.enable = enable; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 0); + if (ret) { + printf("Set AN loopback command failed on %s\n", ethdev->name); + return -1; + } + printf("AN loopback %s for %s\n", enable ? "set" : "clear", + ethdev->name); + + return 0; +} + +int cgx_intf_get_ignore(struct udevice *ethdev, int cgx, int lmac) +{ + struct rvu_pf *rvu; + struct nix *nix; + union cgx_scratchx0 scr0; + int ret, cgx_id = cgx, lmac_id = lmac; + union cgx_cmd_s cmd; + + if (ethdev) { + rvu = dev_get_priv(ethdev); + nix = rvu->nix; + cgx_id = nix->lmac->cgx->cgx_id; + lmac_id = nix->lmac->lmac_id; + } + cmd.cmd.id = CGX_CMD_GET_PERSIST_IGNORE; + + ret = cgx_intf_req(cgx_id, lmac_id, cmd, &scr0.u, 1); + if (ret) { + if (ethdev) + printf("Get ignore command failed for %s\n", + ethdev->name); + else + printf("Get ignore command failed for CGX%d LMAC%d\n", + cgx_id, lmac_id); + return -1; + } + if (ethdev) + printf("Persist settings %signored for %s\n", + scr0.s.persist.ignore ? "" : "not ", ethdev->name); + else + printf("Persist settings %signored for CGX%d LMAC%d\n", + scr0.s.persist.ignore ? "" : "not ", cgx_id, lmac_id); + + return 0; +} + +int cgx_intf_set_ignore(struct udevice *ethdev, int cgx, int lmac, int ignore) +{ + struct rvu_pf *rvu; + struct nix *nix; + union cgx_scratchx0 scr0; + int ret, cgx_id = cgx, lmac_id = lmac; + union cgx_cmd_s cmd; + + if (ethdev) { + rvu = dev_get_priv(ethdev); + nix = rvu->nix; + cgx_id = nix->lmac->cgx->cgx_id; + lmac_id = nix->lmac->lmac_id; + } + cmd.cmd.id = CGX_CMD_SET_PERSIST_IGNORE; + cmd.persist_args.ignore = ignore; + + ret = cgx_intf_req(cgx_id, lmac_id, cmd, &scr0.u, 0); + if (ret) { + if (ethdev) + printf("Set ignore command failed for %s\n", + ethdev->name); + else + printf("Set ignore command failed for CGX%d LMAC%d\n", + cgx_id, lmac_id); + return -1; + } + + return 0; +} + +int cgx_intf_set_macaddr(struct udevice *ethdev) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + u64 mac, tmp; + + memcpy((void *)&tmp, nix->lmac->mac_addr, 6); + mac = swab64(tmp) >> 16; + cmd.cmd.id = CGX_CMD_SET_MAC_ADDR; + cmd.mac_args.addr = mac; + cmd.mac_args.pf_id = rvu->pfid; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 0); + if (ret) { + printf("Set user mac addr failed for %s\n", ethdev->name); + return -1; + } + + return 0; +} + +int cgx_intf_display_eye(u8 qlm, u8 lane) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_DISPLAY_EYE; + + cmd.dsp_eye_args.qlm = qlm; + cmd.dsp_eye_args.lane = lane; + + ret = cgx_intf_req(0, 0, cmd, &scr0.u, 0); + if (ret) + return -1; + + return 0; +} + +int cgx_intf_display_serdes(u8 qlm, u8 lane) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_DISPLAY_SERDES; + + cmd.dsp_eye_args.qlm = qlm; + cmd.dsp_eye_args.lane = lane; + + ret = cgx_intf_req(0, 0, cmd, &scr0.u, 0); + if (ret) + return -1; + + return 0; +} diff --git a/drivers/net/octeontx2/cgx_intf.h b/drivers/net/octeontx2/cgx_intf.h new file mode 100644 index 0000000000..0b2bf696fe --- /dev/null +++ b/drivers/net/octeontx2/cgx_intf.h @@ -0,0 +1,450 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __CGX_INTF_H__ +#define __CGX_INTF_H__ + +#define CGX_FIRMWARE_MAJOR_VER 1 +#define CGX_FIRMWARE_MINOR_VER 0 + +/* Register offsets */ +#define CGX_CMR_INT 0x87e0e0000040 +#define CGX_CMR_SCRATCH0 0x87e0e0001050 +#define CGX_CMR_SCRATCH1 0x87e0e0001058 + +#define CGX_SHIFT(x) (0x1000000 * ((x) & 0x3)) +#define CMR_SHIFT(x) (0x40000 * ((x) & 0x3)) + +/* CGX error types. set for cmd response status as CGX_STAT_FAIL */ +enum cgx_error_type { + CGX_ERR_NONE, + CGX_ERR_LMAC_NOT_ENABLED, + CGX_ERR_LMAC_MODE_INVALID, + CGX_ERR_REQUEST_ID_INVALID, + CGX_ERR_PREV_ACK_NOT_CLEAR, + CGX_ERR_PHY_LINK_DOWN, + CGX_ERR_PCS_RESET_FAIL, + CGX_ERR_AN_CPT_FAIL, + CGX_ERR_TX_NOT_IDLE, + CGX_ERR_RX_NOT_IDLE, + CGX_ERR_SPUX_BR_BLKLOCK_FAIL, + CGX_ERR_SPUX_RX_ALIGN_FAIL, + CGX_ERR_SPUX_TX_FAULT, + CGX_ERR_SPUX_RX_FAULT, + CGX_ERR_SPUX_RESET_FAIL, + CGX_ERR_SPUX_AN_RESET_FAIL, + CGX_ERR_SPUX_USX_AN_RESET_FAIL, + CGX_ERR_SMUX_RX_LINK_NOT_OK, + CGX_ERR_PCS_LINK_FAIL, + CGX_ERR_TRAINING_FAIL, + CGX_ERR_RX_EQU_FAIL, + CGX_ERR_SPUX_BER_FAIL, + CGX_ERR_SPUX_RSFEC_ALGN_FAIL, + CGX_ERR_SPUX_MARKER_LOCK_FAIL, + CGX_ERR_SET_FEC_INVALID, + CGX_ERR_SET_FEC_FAIL, + CGX_ERR_MODULE_INVALID, + CGX_ERR_MODULE_NOT_PRESENT, + CGX_ERR_SPEED_CHANGE_INVALID, /* = 28 */ + /* FIXME : add more error types when adding support for new modes */ +}; + +/* LINK speed types */ +enum cgx_link_speed { + CGX_LINK_NONE, + CGX_LINK_10M, + CGX_LINK_100M, + CGX_LINK_1G, + CGX_LINK_2HG, /* 2.5 Gbps */ + CGX_LINK_5G, + CGX_LINK_10G, + CGX_LINK_20G, + CGX_LINK_25G, + CGX_LINK_40G, + CGX_LINK_50G, + CGX_LINK_80G, + CGX_LINK_100G, + CGX_LINK_MAX, +}; + +/* REQUEST ID types. Input to firmware */ +enum cgx_cmd_id { + CGX_CMD_NONE = 0, + CGX_CMD_GET_FW_VER, + CGX_CMD_GET_MAC_ADDR, + CGX_CMD_SET_MTU, + CGX_CMD_GET_LINK_STS, /* optional to user */ + CGX_CMD_LINK_BRING_UP, /* = 5 */ + CGX_CMD_LINK_BRING_DOWN, + CGX_CMD_INTERNAL_LBK, + CGX_CMD_EXTERNAL_LBK, + CGX_CMD_HIGIG, + CGX_CMD_LINK_STAT_CHANGE, /* = 10 */ + CGX_CMD_MODE_CHANGE, /* hot plug support */ + CGX_CMD_INTF_SHUTDOWN, + CGX_CMD_GET_MKEX_SIZE, + CGX_CMD_GET_MKEX_PROFILE, + CGX_CMD_GET_FWD_BASE, /* get base address of shared FW data */ + CGX_CMD_GET_LINK_MODES, /* Supported Link Modes */ + CGX_CMD_SET_LINK_MODE, + CGX_CMD_GET_SUPPORTED_FEC, + CGX_CMD_SET_FEC, + CGX_CMD_GET_AN, /* = 20 */ + CGX_CMD_SET_AN, + CGX_CMD_GET_ADV_LINK_MODES, + CGX_CMD_GET_ADV_FEC, + CGX_CMD_GET_PHY_MOD_TYPE, /* line-side modulation type: NRZ or PAM4 */ + CGX_CMD_SET_PHY_MOD_TYPE, /* = 25 */ + CGX_CMD_PRBS, + CGX_CMD_DISPLAY_EYE, + CGX_CMD_GET_PHY_FEC_STATS, + CGX_CMD_DISPLAY_SERDES, + CGX_CMD_AN_LOOPBACK, /* = 30 */ + CGX_CMD_GET_PERSIST_IGNORE, + CGX_CMD_SET_PERSIST_IGNORE, + CGX_CMD_SET_MAC_ADDR, +}; + +/* async event ids */ +enum cgx_evt_id { + CGX_EVT_NONE, + CGX_EVT_LINK_CHANGE, +}; + +/* event types - cause of interrupt */ +enum cgx_evt_type { + CGX_EVT_ASYNC, + CGX_EVT_CMD_RESP +}; + +enum cgx_stat { + CGX_STAT_SUCCESS, + CGX_STAT_FAIL +}; + +enum cgx_cmd_own { + /* default ownership with kernel/uefi/u-boot */ + CGX_OWN_NON_SECURE_SW, + /* set by kernel/uefi/u-boot after posting a new request to ATF */ + CGX_OWN_FIRMWARE, +}; + +/* Supported LINK MODE enums + * Each link mode is a bit mask of these + * enums which are represented as bits + */ +typedef enum { + CGX_MODE_SGMII_BIT = 0, + CGX_MODE_1000_BASEX_BIT, + CGX_MODE_QSGMII_BIT, + CGX_MODE_10G_C2C_BIT, + CGX_MODE_10G_C2M_BIT, + CGX_MODE_10G_KR_BIT, + CGX_MODE_20G_C2C_BIT, + CGX_MODE_25G_C2C_BIT, + CGX_MODE_25G_C2M_BIT, + CGX_MODE_25G_2_C2C_BIT, + CGX_MODE_25G_CR_BIT, + CGX_MODE_25G_KR_BIT, + CGX_MODE_40G_C2C_BIT, + CGX_MODE_40G_C2M_BIT, + CGX_MODE_40G_CR4_BIT, + CGX_MODE_40G_KR4_BIT, + CGX_MODE_40GAUI_C2C_BIT, + CGX_MODE_50G_C2C_BIT, + CGX_MODE_50G_C2M_BIT, + CGX_MODE_50G_4_C2C_BIT, + CGX_MODE_50G_CR_BIT, + CGX_MODE_50G_KR_BIT, + CGX_MODE_80GAUI_C2C_BIT, + CGX_MODE_100G_C2C_BIT, + CGX_MODE_100G_C2M_BIT, + CGX_MODE_100G_CR4_BIT, + CGX_MODE_100G_KR4_BIT, + CGX_MODE_MAX_BIT /* = 29 */ +} cgx_mode_t; + +/* scratchx(0) CSR used for ATF->non-secure SW communication. + * This acts as the status register + * Provides details on command ack/status, link status, error details + */ + +/* CAUTION : below structures are placed in order based on the bit positions + * For any updates/new bitfields, corresponding structures needs to be updated + */ +struct cgx_evt_sts_s { /* start from bit 0 */ + u64 ack:1; + u64 evt_type:1; /* cgx_evt_type */ + u64 stat:1; /* cgx_stat */ + u64 id:6; /* cgx_evt_id/cgx_cmd_id */ + u64 reserved:55; +}; + +/* all the below structures are in the same memory location of SCRATCHX(0) + * value can be read/written based on command ID + */ + +/* Resp to command IDs with command status as CGX_STAT_FAIL + * Not applicable for commands : + * CGX_CMD_LINK_BRING_UP/DOWN/CGX_EVT_LINK_CHANGE + * check struct cgx_lnk_sts_s comments + */ +struct cgx_err_sts_s { /* start from bit 9 */ + u64 reserved1:9; + u64 type:10; /* cgx_error_type */ + u64 reserved2:35; +}; + +/* Resp to cmd ID as CGX_CMD_GET_FW_VER with cmd status as CGX_STAT_SUCCESS */ +struct cgx_ver_s { /* start from bit 9 */ + u64 reserved1:9; + u64 major_ver:4; + u64 minor_ver:4; + u64 reserved2:47; +}; + +/* Resp to cmd ID as CGX_CMD_GET_MAC_ADDR with cmd status as CGX_STAT_SUCCESS + * Returns each byte of MAC address in a separate bit field + */ +struct cgx_mac_addr_s { /* start from bit 9 */ + u64 reserved1:9; + u64 addr_0:8; + u64 addr_1:8; + u64 addr_2:8; + u64 addr_3:8; + u64 addr_4:8; + u64 addr_5:8; + u64 reserved2:7; +}; + +/* Resp to cmd ID - CGX_CMD_LINK_BRING_UP/DOWN, event ID CGX_EVT_LINK_CHANGE + * status can be either CGX_STAT_FAIL or CGX_STAT_SUCCESS + * In case of CGX_STAT_FAIL, it indicates CGX configuration failed when + * processing link up/down/change command. Both err_type and current link status + * will be updated + * In case of CGX_STAT_SUCCESS, err_type will be CGX_ERR_NONE and current + * link status will be updated + */ +struct cgx_lnk_sts_s { + u64 reserved1:9; + u64 link_up:1; + u64 full_duplex:1; + u64 speed:4; /* cgx_link_speed */ + u64 err_type:10; + u64 an:1; /* Current AN state : enabled/disabled */ + u64 fec:2; /* Current FEC type if enabled, if not 0 */ + u64 port:8; /* Share the current port info if required */ + u64 mode:8; /* cgx_mode_t enum integer value */ + u64 reserved2:20; +}; + +struct sh_fwd_base_s { + u64 reserved1:9; + u64 addr:55; +}; + +struct cgx_link_modes_s { + u64 reserved1:9; + u64 modes:55; +}; + +/* Resp to cmd ID - CGX_CMD_GET_ADV_FEC/CGX_CMD_GET_SUPPORTED_FEC + * fec : 2 bits + * typedef enum cgx_fec_type { + * CGX_FEC_NONE, + * CGX_FEC_BASE_R, + * CGX_FEC_RS + * } fec_type_t; + */ +struct cgx_fec_types_s { + u64 reserved1:9; + u64 fec:2; + u64 reserved2:53; +}; + +/* Resp to cmd ID - CGX_CMD_GET_AN */ +struct cgx_get_an_s { + u64 reserved1:9; + u64 an:1; + u64 reserved2:54; +}; + +/* Resp to cmd ID - CGX_CMD_GET_PHY_MOD_TYPE */ +struct cgx_get_phy_mod_type_s { + u64 reserved1:9; + u64 mod:1; /* 0=NRZ, 1=PAM4 */ + u64 reserved2:54; +}; + +/* Resp to cmd ID - CGX_CMD_GET_PERSIST_IGNORE */ +struct cgx_get_flash_ignore_s { + uint64_t reserved1:9; + uint64_t ignore:1; + uint64_t reserved2:54; +}; + +union cgx_rsp_sts { + /* Fixed, applicable for all commands/events */ + struct cgx_evt_sts_s evt_sts; + /* response to CGX_CMD_LINK_BRINGUP/DOWN/LINK_CHANGE */ + struct cgx_lnk_sts_s link_sts; + /* response to CGX_CMD_GET_FW_VER */ + struct cgx_ver_s ver; + /* response to CGX_CMD_GET_MAC_ADDR */ + struct cgx_mac_addr_s mac_s; + /* response to CGX_CMD_GET_FWD_BASE */ + struct sh_fwd_base_s fwd_base_s; + /* response if evt_status = CMD_FAIL */ + struct cgx_err_sts_s err; + /* response to CGX_CMD_GET_SUPPORTED_FEC */ + struct cgx_fec_types_s supported_fec; + /* response to CGX_CMD_GET_LINK_MODES */ + struct cgx_link_modes_s supported_modes; + /* response to CGX_CMD_GET_ADV_LINK_MODES */ + struct cgx_link_modes_s adv_modes; + /* response to CGX_CMD_GET_ADV_FEC */ + struct cgx_fec_types_s adv_fec; + /* response to CGX_CMD_GET_AN */ + struct cgx_get_an_s an; + /* response to CGX_CMD_GET_PHY_MOD_TYPE */ + struct cgx_get_phy_mod_type_s phy_mod_type; + /* response to CGX_CMD_GET_PERSIST_IGNORE */ + struct cgx_get_flash_ignore_s persist; +#ifdef NT_FW_CONFIG + /* response to CGX_CMD_GET_MKEX_SIZE */ + struct cgx_mcam_profile_sz_s prfl_sz; + /* response to CGX_CMD_GET_MKEX_PROFILE */ + struct cgx_mcam_profile_addr_s prfl_addr; +#endif +}; + +union cgx_scratchx0 { + u64 u; + union cgx_rsp_sts s; +}; + +/* scratchx(1) CSR used for non-secure SW->ATF communication + * This CSR acts as a command register + */ +struct cgx_cmd { /* start from bit 2 */ + u64 reserved1:2; + u64 id:6; /* cgx_request_id */ + u64 reserved2:56; +}; + +/* all the below structures are in the same memory location of SCRATCHX(1) + * corresponding arguments for command Id needs to be updated + */ + +/* Any command using enable/disable as an argument need + * to pass the option via this structure. + * Ex: Loopback, HiGig... + */ +struct cgx_ctl_args { /* start from bit 8 */ + u64 reserved1:8; + u64 enable:1; + u64 reserved2:55; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_MTU */ +struct cgx_mtu_args { + u64 reserved1:8; + u64 size:16; + u64 reserved2:40; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_MODE_CHANGE */ +struct cgx_mode_change_args { + uint64_t reserved1:8; + uint64_t speed:4; /* cgx_link_speed enum */ + uint64_t duplex:1; /* 0 - full duplex, 1 - half duplex */ + uint64_t an:1; /* 0 - disable AN, 1 - enable AN */ + uint64_t port:8; /* device port */ + uint64_t mode:42; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_LINK_CHANGE */ +struct cgx_link_change_args { /* start from bit 8 */ + u64 reserved1:8; + u64 link_up:1; + u64 full_duplex:1; + u64 speed:4; /* cgx_link_speed */ + u64 reserved2:50; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_LINK_MODE */ +struct cgx_set_mode_args { + u64 reserved1:8; + u64 mode:56; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_FEC */ +struct cgx_set_fec_args { + u64 reserved1:8; + u64 fec:2; + u64 reserved2:54; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_PHY_MOD_TYPE */ +struct cgx_set_phy_mod_args { + u64 reserved1:8; + u64 mod:1; /* 0=NRZ, 1=PAM4 */ + u64 reserved2:55; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_PERSIST_IGNORE */ +struct cgx_set_flash_ignore_args { + uint64_t reserved1:8; + uint64_t ignore:1; + uint64_t reserved2:55; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_MAC_ADDR */ +struct cgx_mac_addr_args { + uint64_t reserved1:8; + uint64_t addr:48; + uint64_t pf_id:8; +}; + +struct cgx_prbs_args { + u64 reserved1:8; /* start from bit 8 */ + u64 lane:8; + u64 qlm:8; + u64 stop_on_error:1; + u64 mode:8; + u64 time:31; +}; + +struct cgx_display_eye_args { + u64 reserved1:8; /* start from bit 8 */ + u64 qlm:8; + u64 lane:47; +}; + +union cgx_cmd_s { + u64 own_status:2; /* cgx_cmd_own */ + struct cgx_cmd cmd; + struct cgx_ctl_args cmd_args; + struct cgx_mtu_args mtu_size; + struct cgx_link_change_args lnk_args; /* Input to CGX_CMD_LINK_CHANGE */ + struct cgx_set_mode_args mode_args; + struct cgx_mode_change_args mode_change_args; + struct cgx_set_fec_args fec_args; + struct cgx_set_phy_mod_args phy_mod_args; + struct cgx_set_flash_ignore_args persist_args; + struct cgx_mac_addr_args mac_args; + /* any other arg for command id * like : mtu, dmac filtering control */ + struct cgx_prbs_args prbs_args; + struct cgx_display_eye_args dsp_eye_args; +}; + +union cgx_scratchx1 { + u64 u; + union cgx_cmd_s s; +}; + +#endif /* __CGX_INTF_H__ */ diff --git a/drivers/net/octeontx2/lmt.h b/drivers/net/octeontx2/lmt.h new file mode 100644 index 0000000000..97777eab00 --- /dev/null +++ b/drivers/net/octeontx2/lmt.h @@ -0,0 +1,51 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +/** + * Atomically adds a signed value to a 64 bit (aligned) memory location, + * and returns previous value. + * + * This version does not perform 'sync' operations to enforce memory + * operations. This should only be used when there are no memory operation + * ordering constraints. (This should NOT be used for reference counting - + * use the standard version instead.) + * + * @param ptr address in memory to add incr to + * @param incr amount to increment memory location by (signed) + * + * @return Value of memory location before increment + */ +static inline s64 atomic_fetch_and_add64_nosync(s64 *ptr, s64 incr) +{ + s64 result; + /* Atomic add with no ordering */ + asm volatile("ldadd %x[i], %x[r], [%[b]]" + : [r] "=r" (result), "+m" (*ptr) + : [i] "r" (incr), [b] "r" (ptr) + : "memory"); + return result; +} + +static inline void lmt_cancel(const struct nix *nix) +{ + writeq(0, nix->lmt_base + LMT_LF_LMTCANCEL()); +} + +static inline u64 *lmt_store_ptr(struct nix *nix) +{ + return (u64 *)((u8 *)(nix->lmt_base) + + LMT_LF_LMTLINEX(0)); +} + +static inline s64 lmt_submit(u64 io_address) +{ + s64 result = 0; + + asm volatile("ldeor xzr, %x[rf],[%[rs]]" + : [rf] "=r"(result) : [rs] "r"(io_address)); + return result; +} diff --git a/drivers/net/octeontx2/nix.c b/drivers/net/octeontx2/nix.c new file mode 100644 index 0000000000..d9c80eaf37 --- /dev/null +++ b/drivers/net/octeontx2/nix.c @@ -0,0 +1,833 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <dm.h> +#include <errno.h> +#include <log.h> +#include <malloc.h> +#include <memalign.h> +#include <misc.h> +#include <net.h> +#include <pci.h> +#include <watchdog.h> + +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-lmt.h> +#include <asm/io.h> +#include <asm/types.h> + +#include <linux/delay.h> +#include <linux/log2.h> +#include <linux/types.h> + +#include "nix.h" +#include "lmt.h" +#include "cgx.h" + +/** + * NIX needs a lot of memory areas. Rather than handle all the failure cases, + * we'll use a wrapper around alloc that prints an error if a memory + * allocation fails. + * + * @param num_elements + * Number of elements to allocate + * @param elem_size Size of each element + * @param msg Text string to show when allocation fails + * + * @return A valid memory location or NULL on failure + */ +static void *nix_memalloc(int num_elements, size_t elem_size, const char *msg) +{ + size_t alloc_size = num_elements * elem_size; + void *base = memalign(CONFIG_SYS_CACHELINE_SIZE, alloc_size); + + if (!base) + printf("NIX: Mem alloc failed for %s (%d * %zu = %zu bytes)\n", + msg ? msg : __func__, num_elements, elem_size, + alloc_size); + else + memset(base, 0, alloc_size); + + debug("NIX: Memory alloc for %s (%d * %zu = %zu bytes) at %p\n", + msg ? msg : __func__, num_elements, elem_size, alloc_size, base); + return base; +} + +int npc_lf_setup(struct nix *nix) +{ + int err; + + err = npc_lf_admin_setup(nix); + if (err) { + printf("%s: Error setting up npc lf admin\n", __func__); + return err; + } + + return 0; +} + +static int npa_setup_pool(struct npa *npa, u32 pool_id, + size_t buffer_size, u32 queue_length, void *buffers[]) +{ + struct { + union npa_lf_aura_op_free0 f0; + union npa_lf_aura_op_free1 f1; + } aura_descr; + int index; + + for (index = 0; index < queue_length; index++) { + buffers[index] = memalign(CONFIG_SYS_CACHELINE_SIZE, + buffer_size); + if (!buffers[index]) { + printf("%s: Out of memory %d, size: %zu\n", + __func__, index, buffer_size); + return -ENOMEM; + } + debug("%s: allocating buffer %d, addr %p size: %zu\n", + __func__, index, buffers[index], buffer_size); + + /* Add the newly obtained pointer to the pool. 128 bit + * writes only. + */ + aura_descr.f0.s.addr = (u64)buffers[index]; + aura_descr.f1.u = 0; + aura_descr.f1.s.aura = pool_id; + st128(npa->npa_base + NPA_LF_AURA_OP_FREE0(), + aura_descr.f0.u, aura_descr.f1.u); + } + + return 0; +} + +int npa_lf_setup(struct nix *nix) +{ + struct rvu_pf *rvu = dev_get_priv(nix->dev); + struct nix_af *nix_af = nix->nix_af; + struct npa *npa; + union npa_af_const npa_af_const; + union npa_aura_s *aura; + union npa_pool_s *pool; + union rvu_func_addr_s block_addr; + int idx; + int stack_page_pointers; + int stack_page_bytes; + int err; + + npa = (struct npa *)calloc(1, sizeof(struct npa)); + if (!npa) { + printf("%s: out of memory for npa instance\n", __func__); + return -ENOMEM; + } + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NPA; + npa->npa_base = rvu->pf_base + block_addr.u; + npa->npa_af = nix_af->npa_af; + nix->npa = npa; + + npa_af_const.u = npa_af_reg_read(npa->npa_af, NPA_AF_CONST()); + stack_page_pointers = npa_af_const.s.stack_page_ptrs; + stack_page_bytes = npa_af_const.s.stack_page_bytes; + + npa->stack_pages[NPA_POOL_RX] = (RQ_QLEN + stack_page_pointers - 1) / + stack_page_pointers; + npa->stack_pages[NPA_POOL_TX] = (SQ_QLEN + stack_page_pointers - 1) / + stack_page_pointers; + npa->stack_pages[NPA_POOL_SQB] = (SQB_QLEN + stack_page_pointers - 1) / + stack_page_pointers; + npa->pool_stack_pointers = stack_page_pointers; + + npa->q_len[NPA_POOL_RX] = RQ_QLEN; + npa->q_len[NPA_POOL_TX] = SQ_QLEN; + npa->q_len[NPA_POOL_SQB] = SQB_QLEN; + + npa->buf_size[NPA_POOL_RX] = MAX_MTU + CONFIG_SYS_CACHELINE_SIZE; + npa->buf_size[NPA_POOL_TX] = MAX_MTU + CONFIG_SYS_CACHELINE_SIZE; + npa->buf_size[NPA_POOL_SQB] = nix_af->sqb_size; + + npa->aura_ctx = nix_memalloc(NPA_POOL_COUNT, + sizeof(union npa_aura_s), + "aura context"); + if (!npa->aura_ctx) { + printf("%s: Out of memory for aura context\n", __func__); + return -ENOMEM; + } + + for (idx = 0; idx < NPA_POOL_COUNT; idx++) { + npa->pool_ctx[idx] = nix_memalloc(1, + sizeof(union npa_pool_s), + "pool context"); + if (!npa->pool_ctx[idx]) { + printf("%s: Out of memory for pool context\n", + __func__); + return -ENOMEM; + } + npa->pool_stack[idx] = nix_memalloc(npa->stack_pages[idx], + stack_page_bytes, + "pool stack"); + if (!npa->pool_stack[idx]) { + printf("%s: Out of memory for pool stack\n", __func__); + return -ENOMEM; + } + } + + err = npa_lf_admin_setup(npa, nix->lf, (dma_addr_t)npa->aura_ctx); + if (err) { + printf("%s: Error setting up NPA LF admin for lf %d\n", + __func__, nix->lf); + return err; + } + + /* Set up the auras */ + for (idx = 0; idx < NPA_POOL_COUNT; idx++) { + aura = npa->aura_ctx + (idx * sizeof(union npa_aura_s)); + pool = npa->pool_ctx[idx]; + debug("%s aura %p pool %p\n", __func__, aura, pool); + memset(aura, 0, sizeof(union npa_aura_s)); + aura->s.fc_ena = 0; + aura->s.pool_addr = (u64)npa->pool_ctx[idx]; + debug("%s aura.s.pool_addr %llx pool_addr %p\n", __func__, + aura->s.pool_addr, npa->pool_ctx[idx]); + aura->s.shift = 64 - __builtin_clzll(npa->q_len[idx]) - 8; + aura->s.count = npa->q_len[idx]; + aura->s.limit = npa->q_len[idx]; + aura->s.ena = 1; + err = npa_attach_aura(nix_af, nix->lf, aura, idx); + if (err) + return err; + + memset(pool, 0, sizeof(*pool)); + pool->s.fc_ena = 0; + pool->s.nat_align = 1; + pool->s.stack_base = (u64)(npa->pool_stack[idx]); + debug("%s pool.s.stack_base %llx stack_base %p\n", __func__, + pool->s.stack_base, npa->pool_stack[idx]); + pool->s.buf_size = + npa->buf_size[idx] / CONFIG_SYS_CACHELINE_SIZE; + pool->s.stack_max_pages = npa->stack_pages[idx]; + pool->s.shift = + 64 - __builtin_clzll(npa->pool_stack_pointers) - 8; + pool->s.ptr_start = 0; + pool->s.ptr_end = (1ULL << 40) - 1; + pool->s.ena = 1; + err = npa_attach_pool(nix_af, nix->lf, pool, idx); + if (err) + return err; + } + + for (idx = 0; idx < NPA_POOL_COUNT; idx++) { + npa->buffers[idx] = nix_memalloc(npa->q_len[idx], + sizeof(void *), + "buffers"); + if (!npa->buffers[idx]) { + printf("%s: Out of memory\n", __func__); + return -ENOMEM; + } + } + + for (idx = 0; idx < NPA_POOL_COUNT; idx++) { + err = npa_setup_pool(npa, idx, npa->buf_size[idx], + npa->q_len[idx], npa->buffers[idx]); + if (err) { + printf("%s: Error setting up pool %d\n", + __func__, idx); + return err; + } + } + return 0; +} + +int npa_lf_shutdown(struct nix *nix) +{ + struct npa *npa = nix->npa; + int err; + int pool; + + err = npa_lf_admin_shutdown(nix->nix_af, nix->lf, NPA_POOL_COUNT); + if (err) { + printf("%s: Error %d shutting down NPA LF admin\n", + __func__, err); + return err; + } + free(npa->aura_ctx); + npa->aura_ctx = NULL; + + for (pool = 0; pool < NPA_POOL_COUNT; pool++) { + free(npa->pool_ctx[pool]); + npa->pool_ctx[pool] = NULL; + free(npa->pool_stack[pool]); + npa->pool_stack[pool] = NULL; + free(npa->buffers[pool]); + npa->buffers[pool] = NULL; + } + + return 0; +} + +int nix_lf_setup(struct nix *nix) +{ + struct nix_af *nix_af = nix->nix_af; + int idx; + int err = -1; + + /* Alloc NIX RQ HW context memory */ + nix->rq_ctx_base = nix_memalloc(nix->rq_cnt, nix_af->rq_ctx_sz, + "RQ CTX"); + if (!nix->rq_ctx_base) + goto error; + memset(nix->rq_ctx_base, 0, nix_af->rq_ctx_sz); + + /* Alloc NIX SQ HW context memory */ + nix->sq_ctx_base = nix_memalloc(nix->sq_cnt, nix_af->sq_ctx_sz, + "SQ CTX"); + if (!nix->sq_ctx_base) + goto error; + memset(nix->sq_ctx_base, 0, nix_af->sq_ctx_sz); + + /* Alloc NIX CQ HW context memory */ + nix->cq_ctx_base = nix_memalloc(nix->cq_cnt, nix_af->cq_ctx_sz, + "CQ CTX"); + if (!nix->cq_ctx_base) + goto error; + memset(nix->cq_ctx_base, 0, nix_af->cq_ctx_sz * NIX_CQ_COUNT); + /* Alloc NIX CQ Ring memory */ + for (idx = 0; idx < NIX_CQ_COUNT; idx++) { + err = qmem_alloc(&nix->cq[idx], CQ_ENTRIES, CQ_ENTRY_SIZE); + if (err) + goto error; + } + + /* Alloc memory for Qints HW contexts */ + nix->qint_base = nix_memalloc(nix_af->qints, nix_af->qint_ctx_sz, + "Qint CTX"); + if (!nix->qint_base) + goto error; + /* Alloc memory for CQints HW contexts */ + nix->cint_base = nix_memalloc(nix_af->cints, nix_af->cint_ctx_sz, + "Cint CTX"); + if (!nix->cint_base) + goto error; + /* Alloc NIX RSS HW context memory and config the base */ + nix->rss_base = nix_memalloc(nix->rss_grps, nix_af->rsse_ctx_sz, + "RSS CTX"); + if (!nix->rss_base) + goto error; + + err = nix_lf_admin_setup(nix); + if (err) { + printf("%s: Error setting up LF\n", __func__); + goto error; + } + + return 0; + +error: + if (nix->rq_ctx_base) + free(nix->rq_ctx_base); + nix->rq_ctx_base = NULL; + if (nix->rq_ctx_base) + free(nix->rq_ctx_base); + nix->rq_ctx_base = NULL; + if (nix->sq_ctx_base) + free(nix->sq_ctx_base); + nix->sq_ctx_base = NULL; + if (nix->cq_ctx_base) + free(nix->cq_ctx_base); + nix->cq_ctx_base = NULL; + + for (idx = 0; idx < NIX_CQ_COUNT; idx++) + qmem_free(&nix->cq[idx]); + + return err; +} + +int nix_lf_shutdown(struct nix *nix) +{ + struct nix_af *nix_af = nix->nix_af; + int index; + int err; + + err = nix_lf_admin_shutdown(nix_af, nix->lf, nix->cq_cnt, + nix->rq_cnt, nix->sq_cnt); + if (err) { + printf("%s: Error shutting down LF admin\n", __func__); + return err; + } + + if (nix->rq_ctx_base) + free(nix->rq_ctx_base); + nix->rq_ctx_base = NULL; + if (nix->rq_ctx_base) + free(nix->rq_ctx_base); + nix->rq_ctx_base = NULL; + if (nix->sq_ctx_base) + free(nix->sq_ctx_base); + nix->sq_ctx_base = NULL; + if (nix->cq_ctx_base) + free(nix->cq_ctx_base); + nix->cq_ctx_base = NULL; + + for (index = 0; index < NIX_CQ_COUNT; index++) + qmem_free(&nix->cq[index]); + + debug("%s: nix lf %d reset --\n", __func__, nix->lf); + return 0; +} + +struct nix *nix_lf_alloc(struct udevice *dev) +{ + union rvu_func_addr_s block_addr; + struct nix *nix; + struct rvu_pf *rvu = dev_get_priv(dev); + struct rvu_af *rvu_af = dev_get_priv(rvu->afdev); + union rvu_pf_func_s pf_func; + int err; + + debug("%s(%s )\n", __func__, dev->name); + + nix = (struct nix *)calloc(1, sizeof(*nix)); + if (!nix) { + printf("%s: Out of memory for nix instance\n", __func__); + return NULL; + } + nix->nix_af = rvu_af->nix_af; + + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NIXX(0); + nix->nix_base = rvu->pf_base + block_addr.u; + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NPC; + nix->npc_base = rvu->pf_base + block_addr.u; + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_LMT; + nix->lmt_base = rvu->pf_base + block_addr.u; + + pf_func.u = 0; + pf_func.s.pf = rvu->pfid; + nix->pf_func = pf_func.u; + nix->lf = rvu->nix_lfid; + nix->pf = rvu->pfid; + nix->dev = dev; + nix->sq_cnt = 1; + nix->rq_cnt = 1; + nix->rss_grps = 1; + nix->cq_cnt = 2; + nix->xqe_sz = NIX_CQE_SIZE_W16; + + nix->lmac = nix_get_cgx_lmac(nix->pf); + if (!nix->lmac) { + printf("%s: Error: could not find lmac for pf %d\n", + __func__, nix->pf); + free(nix); + return NULL; + } + nix->lmac->link_num = + NIX_LINK_E_CGXX_LMACX(nix->lmac->cgx->cgx_id, + nix->lmac->lmac_id); + nix->lmac->chan_num = + NIX_CHAN_E_CGXX_LMACX_CHX(nix->lmac->cgx->cgx_id, + nix->lmac->lmac_id, 0); + /* This is rx pkind in 1:1 mapping to NIX_LINK_E */ + nix->lmac->pknd = nix->lmac->link_num; + + cgx_lmac_set_pkind(nix->lmac, nix->lmac->lmac_id, nix->lmac->pknd); + debug("%s(%s CGX%x LMAC%x)\n", __func__, dev->name, + nix->lmac->cgx->cgx_id, nix->lmac->lmac_id); + debug("%s(%s Link %x Chan %x Pknd %x)\n", __func__, dev->name, + nix->lmac->link_num, nix->lmac->chan_num, nix->lmac->pknd); + + err = npa_lf_setup(nix); + if (err) + return NULL; + + err = npc_lf_setup(nix); + if (err) + return NULL; + + err = nix_lf_setup(nix); + if (err) + return NULL; + + return nix; +} + +u64 npa_aura_op_alloc(struct npa *npa, u64 aura_id) +{ + union npa_lf_aura_op_allocx op_allocx; + + op_allocx.u = atomic_fetch_and_add64_nosync(npa->npa_base + + NPA_LF_AURA_OP_ALLOCX(0), aura_id); + return op_allocx.s.addr; +} + +u64 nix_cq_op_status(struct nix *nix, u64 cq_id) +{ + union nixx_lf_cq_op_status op_status; + s64 *reg = nix->nix_base + NIXX_LF_CQ_OP_STATUS(); + + op_status.u = atomic_fetch_and_add64_nosync(reg, cq_id << 32); + return op_status.u; +} + +/* TX */ +static inline void nix_write_lmt(struct nix *nix, void *buffer, + int num_words) +{ + int i; + + u64 *lmt_ptr = lmt_store_ptr(nix); + u64 *ptr = buffer; + + debug("%s lmt_ptr %p %p\n", __func__, nix->lmt_base, lmt_ptr); + for (i = 0; i < num_words; i++) { + debug("%s data %llx lmt_ptr %p\n", __func__, ptr[i], + lmt_ptr + i); + lmt_ptr[i] = ptr[i]; + } +} + +void nix_cqe_tx_pkt_handler(struct nix *nix, void *cqe) +{ + union nix_cqe_hdr_s *txcqe = (union nix_cqe_hdr_s *)cqe; + + debug("%s: txcqe: %p\n", __func__, txcqe); + + if (txcqe->s.cqe_type != NIX_XQE_TYPE_E_SEND) { + printf("%s: Error: Unsupported CQ header type %d\n", + __func__, txcqe->s.cqe_type); + return; + } + nix_pf_reg_write(nix, NIXX_LF_CQ_OP_DOOR(), + (NIX_CQ_TX << 32) | 1); +} + +void nix_lf_flush_tx(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + union nixx_lf_cq_op_status op_status; + u32 head, tail; + void *cq_tx_base = nix->cq[NIX_CQ_TX].base; + union nix_cqe_hdr_s *cqe; + + /* ack tx cqe entries */ + op_status.u = nix_cq_op_status(nix, NIX_CQ_TX); + head = op_status.s.head; + tail = op_status.s.tail; + head &= (nix->cq[NIX_CQ_TX].qsize - 1); + tail &= (nix->cq[NIX_CQ_TX].qsize - 1); + + debug("%s cq tx head %d tail %d\n", __func__, head, tail); + while (head != tail) { + cqe = cq_tx_base + head * nix->cq[NIX_CQ_TX].entry_sz; + nix_cqe_tx_pkt_handler(nix, cqe); + op_status.u = nix_cq_op_status(nix, NIX_CQ_TX); + head = op_status.s.head; + tail = op_status.s.tail; + head &= (nix->cq[NIX_CQ_TX].qsize - 1); + tail &= (nix->cq[NIX_CQ_TX].qsize - 1); + debug("%s cq tx head %d tail %d\n", __func__, head, tail); + } +} + +int nix_lf_xmit(struct udevice *dev, void *pkt, int pkt_len) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + struct nix_tx_dr tx_dr; + int dr_sz = (sizeof(struct nix_tx_dr) + 15) / 16 - 1; + s64 result; + void *packet; + + nix_lf_flush_tx(dev); + memset((void *)&tx_dr, 0, sizeof(struct nix_tx_dr)); + /* Dump TX packet in to NPA buffer */ + packet = (void *)npa_aura_op_alloc(nix->npa, NPA_POOL_TX); + if (!packet) { + printf("%s TX buffers unavailable\n", __func__); + return -1; + } + memcpy(packet, pkt, pkt_len); + debug("%s TX buffer %p\n", __func__, packet); + + tx_dr.hdr.s.aura = NPA_POOL_TX; + tx_dr.hdr.s.df = 0; + tx_dr.hdr.s.pnc = 1; + tx_dr.hdr.s.sq = 0; + tx_dr.hdr.s.total = pkt_len; + tx_dr.hdr.s.sizem1 = dr_sz - 2; /* FIXME - for now hdr+sg+sg1addr */ + debug("%s dr_sz %d\n", __func__, dr_sz); + + tx_dr.tx_sg.s.segs = 1; + tx_dr.tx_sg.s.subdc = NIX_SUBDC_E_SG; + tx_dr.tx_sg.s.seg1_size = pkt_len; + tx_dr.tx_sg.s.ld_type = NIX_SENDLDTYPE_E_LDT; + tx_dr.sg1_addr = (dma_addr_t)packet; + +#define DEBUG_PKT +#ifdef DEBUG_PKT + debug("TX PKT Data\n"); + for (int i = 0; i < pkt_len; i++) { + if (i && (i % 8 == 0)) + debug("\n"); + debug("%02x ", *((u8 *)pkt + i)); + } + debug("\n"); +#endif + do { + nix_write_lmt(nix, &tx_dr, (dr_sz - 1) * 2); + __iowmb(); + result = lmt_submit((u64)(nix->nix_base + + NIXX_LF_OP_SENDX(0))); + WATCHDOG_RESET(); + } while (result == 0); + + return 0; +} + +/* RX */ +void nix_lf_flush_rx(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + union nixx_lf_cq_op_status op_status; + void *cq_rx_base = nix->cq[NIX_CQ_RX].base; + struct nix_rx_dr *rx_dr; + union nix_rx_parse_s *rxparse; + u32 head, tail; + u32 rx_cqe_sz = nix->cq[NIX_CQ_RX].entry_sz; + u64 *seg; + + /* flush rx cqe entries */ + op_status.u = nix_cq_op_status(nix, NIX_CQ_RX); + head = op_status.s.head; + tail = op_status.s.tail; + head &= (nix->cq[NIX_CQ_RX].qsize - 1); + tail &= (nix->cq[NIX_CQ_RX].qsize - 1); + + debug("%s cq rx head %d tail %d\n", __func__, head, tail); + while (head != tail) { + rx_dr = (struct nix_rx_dr *)cq_rx_base + head * rx_cqe_sz; + rxparse = &rx_dr->rx_parse; + + debug("%s: rx parse: %p\n", __func__, rxparse); + debug("%s: rx parse: desc_sizem1 %x pkt_lenm1 %x\n", + __func__, rxparse->s.desc_sizem1, rxparse->s.pkt_lenm1); + + seg = (dma_addr_t *)(&rx_dr->rx_sg + 1); + + st128(nix->npa->npa_base + NPA_LF_AURA_OP_FREE0(), + seg[0], (1ULL << 63) | NPA_POOL_RX); + + debug("%s return %llx to NPA\n", __func__, seg[0]); + nix_pf_reg_write(nix, NIXX_LF_CQ_OP_DOOR(), + (NIX_CQ_RX << 32) | 1); + + op_status.u = nix_cq_op_status(nix, NIX_CQ_RX); + head = op_status.s.head; + tail = op_status.s.tail; + head &= (nix->cq[NIX_CQ_RX].qsize - 1); + tail &= (nix->cq[NIX_CQ_RX].qsize - 1); + debug("%s cq rx head %d tail %d\n", __func__, head, tail); + } +} + +int nix_lf_free_pkt(struct udevice *dev, uchar *pkt, int pkt_len) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + + /* Return rx packet to NPA */ + debug("%s return %p to NPA\n", __func__, pkt); + st128(nix->npa->npa_base + NPA_LF_AURA_OP_FREE0(), (u64)pkt, + (1ULL << 63) | NPA_POOL_RX); + nix_pf_reg_write(nix, NIXX_LF_CQ_OP_DOOR(), + (NIX_CQ_RX << 32) | 1); + + nix_lf_flush_tx(dev); + return 0; +} + +int nix_lf_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + union nixx_lf_cq_op_status op_status; + void *cq_rx_base = nix->cq[NIX_CQ_RX].base; + struct nix_rx_dr *rx_dr; + union nix_rx_parse_s *rxparse; + void *pkt, *cqe; + int pkt_len = 0; + u64 *addr; + u32 head, tail; + + /* fetch rx cqe entries */ + op_status.u = nix_cq_op_status(nix, NIX_CQ_RX); + head = op_status.s.head; + tail = op_status.s.tail; + head &= (nix->cq[NIX_CQ_RX].qsize - 1); + tail &= (nix->cq[NIX_CQ_RX].qsize - 1); + debug("%s cq rx head %d tail %d\n", __func__, head, tail); + if (head == tail) + return -EAGAIN; + + debug("%s: rx_base %p head %d sz %d\n", __func__, cq_rx_base, head, + nix->cq[NIX_CQ_RX].entry_sz); + cqe = cq_rx_base + head * nix->cq[NIX_CQ_RX].entry_sz; + rx_dr = (struct nix_rx_dr *)cqe; + rxparse = &rx_dr->rx_parse; + + debug("%s: rx completion: %p\n", __func__, cqe); + debug("%s: rx dr: %p\n", __func__, rx_dr); + debug("%s: rx parse: %p\n", __func__, rxparse); + debug("%s: rx parse: desc_sizem1 %x pkt_lenm1 %x\n", + __func__, rxparse->s.desc_sizem1, rxparse->s.pkt_lenm1); + debug("%s: rx parse: pkind %x chan %x\n", + __func__, rxparse->s.pkind, rxparse->s.chan); + + if (rx_dr->hdr.s.cqe_type != NIX_XQE_TYPE_E_RX) { + printf("%s: Error: Unsupported CQ header type in Rx %d\n", + __func__, rx_dr->hdr.s.cqe_type); + return -1; + } + + pkt_len = rxparse->s.pkt_lenm1 + 1; + addr = (dma_addr_t *)(&rx_dr->rx_sg + 1); + pkt = (void *)addr[0]; + + debug("%s: segs: %d (%d@0x%llx, %d@0x%llx, %d@0x%llx)\n", __func__, + rx_dr->rx_sg.s.segs, rx_dr->rx_sg.s.seg1_size, addr[0], + rx_dr->rx_sg.s.seg2_size, addr[1], + rx_dr->rx_sg.s.seg3_size, addr[2]); + if (pkt_len < rx_dr->rx_sg.s.seg1_size + rx_dr->rx_sg.s.seg2_size + + rx_dr->rx_sg.s.seg3_size) { + debug("%s: Error: rx buffer size too small\n", __func__); + return -1; + } + + __iowmb(); +#define DEBUG_PKT +#ifdef DEBUG_PKT + debug("RX PKT Data\n"); + for (int i = 0; i < pkt_len; i++) { + if (i && (i % 8 == 0)) + debug("\n"); + debug("%02x ", *((u8 *)pkt + i)); + } + debug("\n"); +#endif + + *packetp = (uchar *)pkt; + + return pkt_len; +} + +int nix_lf_setup_mac(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + struct eth_pdata *pdata = dev_get_platdata(dev); + + /* If lower level firmware fails to set proper MAC + * u-boot framework updates MAC to random address. + * Use this hook to update mac address in cgx lmac + * and call mac filter setup to update new address. + */ + if (memcmp(nix->lmac->mac_addr, pdata->enetaddr, ARP_HLEN)) { + memcpy(nix->lmac->mac_addr, pdata->enetaddr, 6); + eth_env_set_enetaddr_by_index("eth", rvu->dev->seq, + pdata->enetaddr); + cgx_lmac_mac_filter_setup(nix->lmac); + /* Update user given MAC address to ATF for update + * in sh_fwdata to use in Linux. + */ + cgx_intf_set_macaddr(dev); + debug("%s: lMAC %pM\n", __func__, nix->lmac->mac_addr); + debug("%s: pMAC %pM\n", __func__, pdata->enetaddr); + } + debug("%s: setupMAC %pM\n", __func__, pdata->enetaddr); + return 0; +} + +void nix_lf_halt(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + + cgx_lmac_rx_tx_enable(nix->lmac, nix->lmac->lmac_id, false); + + mdelay(1); + + /* Flush tx and rx descriptors */ + nix_lf_flush_rx(dev); + nix_lf_flush_tx(dev); +} + +int nix_lf_init(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + struct lmac *lmac = nix->lmac; + int ret; + u64 link_sts; + u8 link, speed; + u16 errcode; + + printf("Waiting for CGX%d LMAC%d [%s] link status...", + lmac->cgx->cgx_id, lmac->lmac_id, + lmac_type_to_str[lmac->lmac_type]); + + if (lmac->init_pend) { + /* Bring up LMAC */ + ret = cgx_lmac_link_enable(lmac, lmac->lmac_id, + true, &link_sts); + lmac->init_pend = 0; + } else { + ret = cgx_lmac_link_status(lmac, lmac->lmac_id, &link_sts); + } + + if (ret) { + printf(" [Down]\n"); + return -1; + } + + link = link_sts & 0x1; + speed = (link_sts >> 2) & 0xf; + errcode = (link_sts >> 6) & 0x2ff; + debug("%s: link %x speed %x errcode %x\n", + __func__, link, speed, errcode); + + /* Print link status */ + printf(" [%s]\n", link ? lmac_speed_to_str[speed] : "Down"); + if (!link) + return -1; + + if (!lmac->init_pend) + cgx_lmac_rx_tx_enable(lmac, lmac->lmac_id, true); + + return 0; +} + +void nix_get_cgx_lmac_id(struct udevice *dev, int *cgxid, int *lmacid) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + struct lmac *lmac = nix->lmac; + + *cgxid = lmac->cgx->cgx_id; + *lmacid = lmac->lmac_id; +} + +void nix_print_mac_info(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + struct lmac *lmac = nix->lmac; + + printf(" CGX%d LMAC%d [%s]", lmac->cgx->cgx_id, lmac->lmac_id, + lmac_type_to_str[lmac->lmac_type]); +} + diff --git a/drivers/net/octeontx2/nix.h b/drivers/net/octeontx2/nix.h new file mode 100644 index 0000000000..e26ac2789b --- /dev/null +++ b/drivers/net/octeontx2/nix.h @@ -0,0 +1,355 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __NIX_H__ +#define __NIX_H__ + +#include <asm/arch/csrs/csrs-npa.h> +#include <asm/arch/csrs/csrs-nix.h> +#include "rvu.h" + +/** Maximum number of LMACs supported */ +#define MAX_LMAC 12 + +/* NIX RX action operation*/ +#define NIX_RX_ACTIONOP_DROP (0x0ull) +#define NIX_RX_ACTIONOP_UCAST (0x1ull) +#define NIX_RX_ACTIONOP_UCAST_IPSEC (0x2ull) +#define NIX_RX_ACTIONOP_MCAST (0x3ull) +#define NIX_RX_ACTIONOP_RSS (0x4ull) + +/* NIX TX action operation*/ +#define NIX_TX_ACTIONOP_DROP (0x0ull) +#define NIX_TX_ACTIONOP_UCAST_DEFAULT (0x1ull) +#define NIX_TX_ACTIONOP_UCAST_CHAN (0x2ull) +#define NIX_TX_ACTIONOP_MCAST (0x3ull) +#define NIX_TX_ACTIONOP_DROP_VIOL (0x5ull) + +#define NIX_INTF_RX 0 +#define NIX_INTF_TX 1 + +#define NIX_INTF_TYPE_CGX 0 +#define NIX_INTF_TYPE_LBK 1 +#define NIX_MAX_HW_MTU 9212 +#define NIX_MIN_HW_MTU 40 +#define MAX_MTU 1536 + +#define NPA_POOL_COUNT 3 +#define NPA_AURA_COUNT(x) (1ULL << ((x) + 6)) +#define NPA_POOL_RX 0ULL +#define NPA_POOL_TX 1ULL +#define NPA_POOL_SQB 2ULL +#define RQ_QLEN Q_COUNT(Q_SIZE_1K) +#define SQ_QLEN Q_COUNT(Q_SIZE_1K) +#define SQB_QLEN Q_COUNT(Q_SIZE_16) + +#define NIX_CQ_RX 0ULL +#define NIX_CQ_TX 1ULL +#define NIX_CQ_COUNT 2ULL +#define NIX_CQE_SIZE_W16 (16 * sizeof(u64)) +#define NIX_CQE_SIZE_W64 (64 * sizeof(u64)) + +/** Size of aura hardware context */ +#define NPA_AURA_HW_CTX_SIZE 48 +/** Size of pool hardware context */ +#define NPA_POOL_HW_CTX_SIZE 64 + +#define NPA_DEFAULT_PF_FUNC 0xffff + +#define NIX_CHAN_CGX_LMAC_CHX(a, b, c) (0x800 + 0x100 * (a) + 0x10 * (b) + (c)) +#define NIX_LINK_CGX_LMAC(a, b) (0 + 4 * (a) + (b)) +#define NIX_LINK_LBK(a) (12 + (a)) +#define NIX_CHAN_LBK_CHX(a, b) (0 + 0x100 * (a) + (b)) +#define MAX_LMAC_PKIND 12 + +/** Number of Admin queue entries */ +#define AQ_RING_SIZE Q_COUNT(Q_SIZE_16) + +/** Each completion queue contains 256 entries, see NIC_CQ_CTX_S[qsize] */ +#define CQS_QSIZE Q_SIZE_256 +#define CQ_ENTRIES Q_COUNT(CQS_QSIZE) +/** + * Each completion queue entry contains 128 bytes, see + * NIXX_AF_LFX_CFG[xqe_size] + */ +#define CQ_ENTRY_SIZE NIX_CQE_SIZE_W16 + +enum npa_aura_size { + NPA_AURA_SZ_0, + NPA_AURA_SZ_128, + NPA_AURA_SZ_256, + NPA_AURA_SZ_512, + NPA_AURA_SZ_1K, + NPA_AURA_SZ_2K, + NPA_AURA_SZ_4K, + NPA_AURA_SZ_8K, + NPA_AURA_SZ_16K, + NPA_AURA_SZ_32K, + NPA_AURA_SZ_64K, + NPA_AURA_SZ_128K, + NPA_AURA_SZ_256K, + NPA_AURA_SZ_512K, + NPA_AURA_SZ_1M, + NPA_AURA_SZ_MAX, +}; + +#define NPA_AURA_SIZE_DEFAULT NPA_AURA_SZ_128 + +/* NIX Transmit schedulers */ +enum nix_scheduler { + NIX_TXSCH_LVL_SMQ = 0x0, + NIX_TXSCH_LVL_MDQ = 0x0, + NIX_TXSCH_LVL_TL4 = 0x1, + NIX_TXSCH_LVL_TL3 = 0x2, + NIX_TXSCH_LVL_TL2 = 0x3, + NIX_TXSCH_LVL_TL1 = 0x4, + NIX_TXSCH_LVL_CNT = 0x5, +}; + +struct cgx; + +struct nix_stats { + u64 num_packets; + u64 num_bytes; +}; + +struct nix; +struct lmac; + +struct npa_af { + void __iomem *npa_af_base; + struct admin_queue aq; + u32 aura; +}; + +struct npa { + struct npa_af *npa_af; + void __iomem *npa_base; + void __iomem *npc_base; + void __iomem *lmt_base; + /** Hardware aura context */ + void *aura_ctx; + /** Hardware pool context */ + void *pool_ctx[NPA_POOL_COUNT]; + void *pool_stack[NPA_POOL_COUNT]; + void **buffers[NPA_POOL_COUNT]; + u32 pool_stack_pages[NPA_POOL_COUNT]; + u32 pool_stack_pointers; + u32 q_len[NPA_POOL_COUNT]; + u32 buf_size[NPA_POOL_COUNT]; + u32 stack_pages[NPA_POOL_COUNT]; +}; + +struct nix_af { + struct udevice *dev; + struct nix *lmacs[MAX_LMAC]; + struct npa_af *npa_af; + void __iomem *nix_af_base; + void __iomem *npc_af_base; + struct admin_queue aq; + u8 num_lmacs; + s8 index; + u8 xqe_size; + u32 sqb_size; + u32 qints; + u32 cints; + u32 sq_ctx_sz; + u32 rq_ctx_sz; + u32 cq_ctx_sz; + u32 rsse_ctx_sz; + u32 cint_ctx_sz; + u32 qint_ctx_sz; +}; + +struct nix_tx_dr { + union nix_send_hdr_s hdr; + union nix_send_sg_s tx_sg; + dma_addr_t sg1_addr; + dma_addr_t sg2_addr; + dma_addr_t sg3_addr; + u64 in_use; +}; + +struct nix_rx_dr { + union nix_cqe_hdr_s hdr; + union nix_rx_parse_s rx_parse; + union nix_rx_sg_s rx_sg; +}; + +struct nix { + struct udevice *dev; + struct eth_device *netdev; + struct nix_af *nix_af; + struct npa *npa; + struct lmac *lmac; + union nix_cint_hw_s *cint_base; + union nix_cq_ctx_s *cq_ctx_base; + union nix_qint_hw_s *qint_base; + union nix_rq_ctx_s *rq_ctx_base; + union nix_rsse_s *rss_base; + union nix_sq_ctx_s *sq_ctx_base; + void *cqe_base; + struct qmem sq; + struct qmem cq[NIX_CQ_COUNT]; + struct qmem rq; + struct qmem rss; + struct qmem cq_ints; + struct qmem qints; + char name[16]; + void __iomem *nix_base; /** PF reg base */ + void __iomem *npc_base; + void __iomem *lmt_base; + struct nix_stats tx_stats; + struct nix_stats rx_stats; + u32 aura; + int pknd; + int lf; + int pf; + u16 pf_func; + u32 rq_cnt; /** receive queues count */ + u32 sq_cnt; /** send queues count */ + u32 cq_cnt; /** completion queues count */ + u16 rss_sz; + u16 sqb_size; + u8 rss_grps; + u8 xqe_sz; +}; + +struct nix_aq_cq_dis { + union nix_aq_res_s resp ALIGNED; + union nix_cq_ctx_s cq ALIGNED; + union nix_cq_ctx_s mcq ALIGNED; +}; + +struct nix_aq_rq_dis { + union nix_aq_res_s resp ALIGNED; + union nix_rq_ctx_s rq ALIGNED; + union nix_rq_ctx_s mrq ALIGNED; +}; + +struct nix_aq_sq_dis { + union nix_aq_res_s resp ALIGNED; + union nix_sq_ctx_s sq ALIGNED; + union nix_sq_ctx_s msq ALIGNED; +}; + +struct nix_aq_cq_request { + union nix_aq_res_s resp ALIGNED; + union nix_cq_ctx_s cq ALIGNED; +}; + +struct nix_aq_rq_request { + union nix_aq_res_s resp ALIGNED; + union nix_rq_ctx_s rq ALIGNED; +}; + +struct nix_aq_sq_request { + union nix_aq_res_s resp ALIGNED; + union nix_sq_ctx_s sq ALIGNED; +}; + +static inline u64 nix_af_reg_read(struct nix_af *nix_af, u64 offset) +{ + u64 val = readq(nix_af->nix_af_base + offset); + + debug("%s reg %p val %llx\n", __func__, nix_af->nix_af_base + offset, + val); + return val; +} + +static inline void nix_af_reg_write(struct nix_af *nix_af, u64 offset, + u64 val) +{ + debug("%s reg %p val %llx\n", __func__, nix_af->nix_af_base + offset, + val); + writeq(val, nix_af->nix_af_base + offset); +} + +static inline u64 nix_pf_reg_read(struct nix *nix, u64 offset) +{ + u64 val = readq(nix->nix_base + offset); + + debug("%s reg %p val %llx\n", __func__, nix->nix_base + offset, + val); + return val; +} + +static inline void nix_pf_reg_write(struct nix *nix, u64 offset, + u64 val) +{ + debug("%s reg %p val %llx\n", __func__, nix->nix_base + offset, + val); + writeq(val, nix->nix_base + offset); +} + +static inline u64 npa_af_reg_read(struct npa_af *npa_af, u64 offset) +{ + u64 val = readq(npa_af->npa_af_base + offset); + + debug("%s reg %p val %llx\n", __func__, npa_af->npa_af_base + offset, + val); + return val; +} + +static inline void npa_af_reg_write(struct npa_af *npa_af, u64 offset, + u64 val) +{ + debug("%s reg %p val %llx\n", __func__, npa_af->npa_af_base + offset, + val); + writeq(val, npa_af->npa_af_base + offset); +} + +static inline u64 npc_af_reg_read(struct nix_af *nix_af, u64 offset) +{ + u64 val = readq(nix_af->npc_af_base + offset); + + debug("%s reg %p val %llx\n", __func__, nix_af->npc_af_base + offset, + val); + return val; +} + +static inline void npc_af_reg_write(struct nix_af *nix_af, u64 offset, + u64 val) +{ + debug("%s reg %p val %llx\n", __func__, nix_af->npc_af_base + offset, + val); + writeq(val, nix_af->npc_af_base + offset); +} + +int npa_attach_aura(struct nix_af *nix_af, int lf, + const union npa_aura_s *desc, u32 aura_id); +int npa_attach_pool(struct nix_af *nix_af, int lf, + const union npa_pool_s *desc, u32 pool_id); +int npa_af_setup(struct npa_af *npa_af); +int npa_af_shutdown(struct npa_af *npa_af); +int npa_lf_setup(struct nix *nix); +int npa_lf_shutdown(struct nix *nix); +int npa_lf_admin_setup(struct npa *npa, int lf, dma_addr_t aura_base); +int npa_lf_admin_shutdown(struct nix_af *nix_af, int lf, u32 pool_count); + +int npc_lf_admin_setup(struct nix *nix); +int npc_af_shutdown(struct nix_af *nix_af); + +int nix_af_setup(struct nix_af *nix_af); +int nix_af_shutdown(struct nix_af *nix_af); +int nix_lf_setup(struct nix *nix); +int nix_lf_shutdown(struct nix *nix); +struct nix *nix_lf_alloc(struct udevice *dev); +int nix_lf_admin_setup(struct nix *nix); +int nix_lf_admin_shutdown(struct nix_af *nix_af, int lf, + u32 cq_count, u32 rq_count, u32 sq_count); +struct rvu_af *get_af(void); + +int nix_lf_setup_mac(struct udevice *dev); +int nix_lf_read_rom_mac(struct udevice *dev); +void nix_lf_halt(struct udevice *dev); +int nix_lf_free_pkt(struct udevice *dev, uchar *pkt, int pkt_len); +int nix_lf_recv(struct udevice *dev, int flags, uchar **packetp); +int nix_lf_init(struct udevice *dev); +int nix_lf_xmit(struct udevice *dev, void *pkt, int pkt_len); + +#endif /* __NIX_H__ */ diff --git a/drivers/net/octeontx2/nix_af.c b/drivers/net/octeontx2/nix_af.c new file mode 100644 index 0000000000..6b79bf57b9 --- /dev/null +++ b/drivers/net/octeontx2/nix_af.c @@ -0,0 +1,1104 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <pci.h> +#include <memalign.h> +#include <watchdog.h> +#include <linux/types.h> +#include <linux/list.h> +#include <linux/log2.h> +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-npc.h> +#include <asm/arch/csrs/csrs-lmt.h> +#include <asm/io.h> + +#include "nix.h" +#include "lmt.h" +#include "cgx.h" + +static struct nix_aq_cq_dis cq_dis ALIGNED; +static struct nix_aq_rq_dis rq_dis ALIGNED; +static struct nix_aq_sq_dis sq_dis ALIGNED; + +/*************** + * NPA API + ***************/ +int npa_attach_aura(struct nix_af *nix_af, int lf, + const union npa_aura_s *desc, u32 aura_id) +{ + struct npa_af *npa = nix_af->npa_af; + union npa_aq_inst_s *inst; + union npa_aq_res_s *res; + union npa_af_aq_status aq_stat; + union npa_aura_s *context; + u64 head; + ulong start; + + debug("%s(%p, %d, %p, %u)\n", __func__, nix_af, lf, desc, aura_id); + aq_stat.u = npa_af_reg_read(npa, NPA_AF_AQ_STATUS()); + head = aq_stat.s.head_ptr; + inst = (union npa_aq_inst_s *)(npa->aq.inst.base) + head; + res = (union npa_aq_res_s *)(npa->aq.res.base); + + memset(inst, 0, sizeof(*inst)); + inst->s.lf = lf; + inst->s.doneint = 0; + inst->s.ctype = NPA_AQ_CTYPE_E_AURA; + inst->s.op = NPA_AQ_INSTOP_E_INIT; + inst->s.res_addr = npa->aq.res.iova; + inst->s.cindex = aura_id; + + context = (union npa_aura_s *)(npa->aq.res.base + + CONFIG_SYS_CACHELINE_SIZE); + memset(npa->aq.res.base, 0, npa->aq.res.entry_sz); + memcpy(context, desc, sizeof(union npa_aura_s)); + __iowmb(); + npa_af_reg_write(npa, NPA_AF_AQ_DOOR(), 1); + + start = get_timer(0); + while ((res->s.compcode == NPA_AQ_COMP_E_NOTDONE) && + (get_timer(start) < 1000)) + WATCHDOG_RESET(); + if (res->s.compcode != NPA_AQ_COMP_E_GOOD) { + printf("%s: Error: result 0x%x not good\n", + __func__, res->s.compcode); + return -1; + } + + return 0; +} + +int npa_attach_pool(struct nix_af *nix_af, int lf, + const union npa_pool_s *desc, u32 pool_id) +{ + union npa_aq_inst_s *inst; + union npa_aq_res_s *res; + union npa_af_aq_status aq_stat; + struct npa_af *npa = nix_af->npa_af; + union npa_aura_s *context; + u64 head; + ulong start; + + debug("%s(%p, %d, %p, %u)\n", __func__, nix_af, lf, desc, pool_id); + aq_stat.u = npa_af_reg_read(npa, NPA_AF_AQ_STATUS()); + head = aq_stat.s.head_ptr; + + inst = (union npa_aq_inst_s *)(npa->aq.inst.base) + head; + res = (union npa_aq_res_s *)(npa->aq.res.base); + + memset(inst, 0, sizeof(*inst)); + inst->s.cindex = pool_id; + inst->s.lf = lf; + inst->s.doneint = 0; + inst->s.ctype = NPA_AQ_CTYPE_E_POOL; + inst->s.op = NPA_AQ_INSTOP_E_INIT; + inst->s.res_addr = npa->aq.res.iova; + + context = (union npa_aura_s *)(npa->aq.res.base + + CONFIG_SYS_CACHELINE_SIZE); + memset(npa->aq.res.base, 0, npa->aq.res.entry_sz); + memcpy(context, desc, sizeof(union npa_aura_s)); + __iowmb(); + npa_af_reg_write(npa, NPA_AF_AQ_DOOR(), 1); + + start = get_timer(0); + while ((res->s.compcode == NPA_AQ_COMP_E_NOTDONE) && + (get_timer(start) < 1000)) + WATCHDOG_RESET(); + + if (res->s.compcode != NPA_AQ_COMP_E_GOOD) { + printf("%s: Error: result 0x%x not good\n", + __func__, res->s.compcode); + return -1; + } + + return 0; +} + +int npa_lf_admin_setup(struct npa *npa, int lf, dma_addr_t aura_base) +{ + union npa_af_lf_rst lf_rst; + union npa_af_lfx_auras_cfg auras_cfg; + struct npa_af *npa_af = npa->npa_af; + + debug("%s(%p, %d, 0x%llx)\n", __func__, npa_af, lf, aura_base); + lf_rst.u = 0; + lf_rst.s.exec = 1; + lf_rst.s.lf = lf; + npa_af_reg_write(npa_af, NPA_AF_LF_RST(), lf_rst.u); + + do { + lf_rst.u = npa_af_reg_read(npa_af, NPA_AF_LF_RST()); + WATCHDOG_RESET(); + } while (lf_rst.s.exec); + + /* Set Aura size and enable caching of contexts */ + auras_cfg.u = npa_af_reg_read(npa_af, NPA_AF_LFX_AURAS_CFG(lf)); + auras_cfg.s.loc_aura_size = NPA_AURA_SIZE_DEFAULT; //FIXME aura_size; + auras_cfg.s.caching = 1; + auras_cfg.s.rmt_aura_size = 0; + auras_cfg.s.rmt_aura_offset = 0; + auras_cfg.s.rmt_lf = 0; + npa_af_reg_write(npa_af, NPA_AF_LFX_AURAS_CFG(lf), auras_cfg.u); + /* Configure aura HW context base */ + npa_af_reg_write(npa_af, NPA_AF_LFX_LOC_AURAS_BASE(lf), + aura_base); + + return 0; +} + +int npa_lf_admin_shutdown(struct nix_af *nix_af, int lf, u32 pool_count) +{ + int pool_id; + u32 head; + union npa_aq_inst_s *inst; + union npa_aq_res_s *res; + struct npa_aq_pool_request { + union npa_aq_res_s resp ALIGNED; + union npa_pool_s p0 ALIGNED; + union npa_pool_s p1 ALIGNED; + } pool_req ALIGNED; + struct npa_aq_aura_request { + union npa_aq_res_s resp ALIGNED; + union npa_aura_s a0 ALIGNED; + union npa_aura_s a1 ALIGNED; + } aura_req ALIGNED; + union npa_af_aq_status aq_stat; + union npa_af_lf_rst lf_rst; + struct npa_af *npa = nix_af->npa_af; + ulong start; + + for (pool_id = 0; pool_id < pool_count; pool_id++) { + aq_stat.u = npa_af_reg_read(npa, NPA_AF_AQ_STATUS()); + head = aq_stat.s.head_ptr; + inst = (union npa_aq_inst_s *)(npa->aq.inst.base) + head; + res = &pool_req.resp; + + memset(inst, 0, sizeof(*inst)); + inst->s.cindex = pool_id; + inst->s.lf = lf; + inst->s.doneint = 0; + inst->s.ctype = NPA_AQ_CTYPE_E_POOL; + inst->s.op = NPA_AQ_INSTOP_E_WRITE; + inst->s.res_addr = (u64)&pool_req.resp; + + memset((void *)&pool_req, 0, sizeof(pool_req)); + pool_req.p0.s.ena = 0; + pool_req.p1.s.ena = 1; /* Write mask */ + __iowmb(); + + npa_af_reg_write(npa, NPA_AF_AQ_DOOR(), 1); + + start = get_timer(0); + while ((res->s.compcode == NPA_AQ_COMP_E_NOTDONE) && + (get_timer(start) < 1000)) + WATCHDOG_RESET(); + + if (res->s.compcode != NPA_AQ_COMP_E_GOOD) { + printf("%s: Error: result 0x%x not good for lf %d\n" + " aura id %d", __func__, res->s.compcode, lf, + pool_id); + return -1; + } + debug("%s(LF %d, pool id %d) disabled\n", __func__, lf, + pool_id); + } + + for (pool_id = 0; pool_id < pool_count; pool_id++) { + aq_stat.u = npa_af_reg_read(npa, NPA_AF_AQ_STATUS()); + head = aq_stat.s.head_ptr; + inst = (union npa_aq_inst_s *)(npa->aq.inst.base) + head; + res = &aura_req.resp; + + memset(inst, 0, sizeof(*inst)); + inst->s.cindex = pool_id; + inst->s.lf = lf; + inst->s.doneint = 0; + inst->s.ctype = NPA_AQ_CTYPE_E_AURA; + inst->s.op = NPA_AQ_INSTOP_E_WRITE; + inst->s.res_addr = (u64)&aura_req.resp; + + memset((void *)&aura_req, 0, sizeof(aura_req)); + aura_req.a0.s.ena = 0; + aura_req.a1.s.ena = 1; /* Write mask */ + __iowmb(); + + npa_af_reg_write(npa, NPA_AF_AQ_DOOR(), 1); + + start = get_timer(0); + while ((res->s.compcode == NPA_AQ_COMP_E_NOTDONE) && + (get_timer(start) < 1000)) + WATCHDOG_RESET(); + + if (res->s.compcode != NPA_AQ_COMP_E_GOOD) { + printf("%s: Error: result 0x%x not good for lf %d\n" + " aura id %d", __func__, res->s.compcode, lf, + pool_id); + return -1; + } + debug("%s(LF %d, aura id %d) disabled\n", __func__, lf, + pool_id); + } + + /* Reset the LF */ + lf_rst.u = 0; + lf_rst.s.exec = 1; + lf_rst.s.lf = lf; + npa_af_reg_write(npa, NPA_AF_LF_RST(), lf_rst.u); + + do { + lf_rst.u = npa_af_reg_read(npa, NPA_AF_LF_RST()); + WATCHDOG_RESET(); + } while (lf_rst.s.exec); + + return 0; +} + +int npa_af_setup(struct npa_af *npa_af) +{ + int err; + union npa_af_gen_cfg npa_cfg; + union npa_af_ndc_cfg ndc_cfg; + union npa_af_aq_cfg aq_cfg; + union npa_af_blk_rst blk_rst; + + err = rvu_aq_alloc(&npa_af->aq, Q_COUNT(AQ_SIZE), + sizeof(union npa_aq_inst_s), + sizeof(union npa_aq_res_s)); + if (err) { + printf("%s: Error %d allocating admin queue\n", __func__, err); + return err; + } + debug("%s: NPA admin queue allocated at %p %llx\n", __func__, + npa_af->aq.inst.base, npa_af->aq.inst.iova); + + blk_rst.u = 0; + blk_rst.s.rst = 1; + npa_af_reg_write(npa_af, NPA_AF_BLK_RST(), blk_rst.u); + + /* Wait for reset to complete */ + do { + blk_rst.u = npa_af_reg_read(npa_af, NPA_AF_BLK_RST()); + WATCHDOG_RESET(); + } while (blk_rst.s.busy); + + /* Set little Endian */ + npa_cfg.u = npa_af_reg_read(npa_af, NPA_AF_GEN_CFG()); + npa_cfg.s.af_be = 0; + npa_af_reg_write(npa_af, NPA_AF_GEN_CFG(), npa_cfg.u); + /* Enable NDC cache */ + ndc_cfg.u = npa_af_reg_read(npa_af, NPA_AF_NDC_CFG()); + ndc_cfg.s.ndc_bypass = 0; + npa_af_reg_write(npa_af, NPA_AF_NDC_CFG(), ndc_cfg.u); + /* Set up queue size */ + aq_cfg.u = npa_af_reg_read(npa_af, NPA_AF_AQ_CFG()); + aq_cfg.s.qsize = AQ_SIZE; + npa_af_reg_write(npa_af, NPA_AF_AQ_CFG(), aq_cfg.u); + /* Set up queue base address */ + npa_af_reg_write(npa_af, NPA_AF_AQ_BASE(), npa_af->aq.inst.iova); + + return 0; +} + +int npa_af_shutdown(struct npa_af *npa_af) +{ + union npa_af_blk_rst blk_rst; + + blk_rst.u = 0; + blk_rst.s.rst = 1; + npa_af_reg_write(npa_af, NPA_AF_BLK_RST(), blk_rst.u); + + /* Wait for reset to complete */ + do { + blk_rst.u = npa_af_reg_read(npa_af, NPA_AF_BLK_RST()); + WATCHDOG_RESET(); + } while (blk_rst.s.busy); + + rvu_aq_free(&npa_af->aq); + + debug("%s: npa af reset --\n", __func__); + + return 0; +} + +/*************** + * NIX API + ***************/ +/** + * Setup SMQ -> TL4 -> TL3 -> TL2 -> TL1 -> MAC mapping + * + * @param nix Handle to setup + * + * @return 0, or negative on failure + */ +static int nix_af_setup_sq(struct nix *nix) +{ + union nixx_af_tl1x_schedule tl1_sched; + union nixx_af_tl2x_parent tl2_parent; + union nixx_af_tl3x_parent tl3_parent; + union nixx_af_tl3_tl2x_cfg tl3_tl2_cfg; + union nixx_af_tl3_tl2x_linkx_cfg tl3_tl2_link_cfg; + union nixx_af_tl4x_parent tl4_parent; + union nixx_af_tl4x_sdp_link_cfg tl4_sdp_link_cfg; + union nixx_af_smqx_cfg smq_cfg; + union nixx_af_mdqx_schedule mdq_sched; + union nixx_af_mdqx_parent mdq_parent; + union nixx_af_rx_linkx_cfg link_cfg; + int tl1_index = nix->lmac->link_num; /* NIX_LINK_E enum */ + int tl2_index = tl1_index; + int tl3_index = tl2_index; + int tl4_index = tl3_index; + int smq_index = tl4_index; + struct nix_af *nix_af = nix->nix_af; + u64 offset = 0; + + tl1_sched.u = nix_af_reg_read(nix_af, + NIXX_AF_TL1X_SCHEDULE(tl1_index)); + tl1_sched.s.rr_quantum = MAX_MTU; + nix_af_reg_write(nix_af, NIXX_AF_TL1X_SCHEDULE(tl1_index), + tl1_sched.u); + + tl2_parent.u = nix_af_reg_read(nix_af, + NIXX_AF_TL2X_PARENT(tl2_index)); + tl2_parent.s.parent = tl1_index; + nix_af_reg_write(nix_af, NIXX_AF_TL2X_PARENT(tl2_index), + tl2_parent.u); + + tl3_parent.u = nix_af_reg_read(nix_af, + NIXX_AF_TL3X_PARENT(tl3_index)); + tl3_parent.s.parent = tl2_index; + nix_af_reg_write(nix_af, NIXX_AF_TL3X_PARENT(tl3_index), + tl3_parent.u); + tl3_tl2_cfg.u = nix_af_reg_read(nix_af, + NIXX_AF_TL3_TL2X_CFG(tl3_index)); + tl3_tl2_cfg.s.express = 0; + nix_af_reg_write(nix_af, NIXX_AF_TL3_TL2X_CFG(tl3_index), + tl3_tl2_cfg.u); + + offset = NIXX_AF_TL3_TL2X_LINKX_CFG(tl3_index, + nix->lmac->link_num); + tl3_tl2_link_cfg.u = nix_af_reg_read(nix_af, offset); + tl3_tl2_link_cfg.s.bp_ena = 1; + tl3_tl2_link_cfg.s.ena = 1; + tl3_tl2_link_cfg.s.relchan = 0; + offset = NIXX_AF_TL3_TL2X_LINKX_CFG(tl3_index, + nix->lmac->link_num); + nix_af_reg_write(nix_af, offset, tl3_tl2_link_cfg.u); + + tl4_parent.u = nix_af_reg_read(nix_af, + NIXX_AF_TL4X_PARENT(tl4_index)); + tl4_parent.s.parent = tl3_index; + nix_af_reg_write(nix_af, NIXX_AF_TL4X_PARENT(tl4_index), + tl4_parent.u); + + offset = NIXX_AF_TL4X_SDP_LINK_CFG(tl4_index); + tl4_sdp_link_cfg.u = nix_af_reg_read(nix_af, offset); + tl4_sdp_link_cfg.s.bp_ena = 0; + tl4_sdp_link_cfg.s.ena = 0; + tl4_sdp_link_cfg.s.relchan = 0; + offset = NIXX_AF_TL4X_SDP_LINK_CFG(tl4_index); + nix_af_reg_write(nix_af, offset, tl4_sdp_link_cfg.u); + + smq_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_SMQX_CFG(smq_index)); + smq_cfg.s.express = 0; + smq_cfg.s.lf = nix->lf; + smq_cfg.s.desc_shp_ctl_dis = 1; + smq_cfg.s.maxlen = MAX_MTU; + smq_cfg.s.minlen = NIX_MIN_HW_MTU; + nix_af_reg_write(nix_af, NIXX_AF_SMQX_CFG(smq_index), smq_cfg.u); + + mdq_sched.u = nix_af_reg_read(nix_af, + NIXX_AF_MDQX_SCHEDULE(smq_index)); + mdq_sched.s.rr_quantum = MAX_MTU; + offset = NIXX_AF_MDQX_SCHEDULE(smq_index); + nix_af_reg_write(nix_af, offset, mdq_sched.u); + mdq_parent.u = nix_af_reg_read(nix_af, + NIXX_AF_MDQX_PARENT(smq_index)); + mdq_parent.s.parent = tl4_index; + nix_af_reg_write(nix_af, NIXX_AF_MDQX_PARENT(smq_index), + mdq_parent.u); + + link_cfg.u = 0; + link_cfg.s.maxlen = NIX_MAX_HW_MTU; + link_cfg.s.minlen = NIX_MIN_HW_MTU; + nix_af_reg_write(nix->nix_af, + NIXX_AF_RX_LINKX_CFG(nix->lmac->link_num), + link_cfg.u); + + return 0; +} + +/** + * Issue a command to the NIX AF Admin Queue + * + * @param nix nix handle + * @param lf Logical function number for command + * @param op Operation + * @param ctype Context type + * @param cindex Context index + * @param resp Result pointer + * + * @return 0 for success, -EBUSY on failure + */ +static int nix_aq_issue_command(struct nix_af *nix_af, + int lf, + int op, + int ctype, + int cindex, union nix_aq_res_s *resp) +{ + union nixx_af_aq_status aq_status; + union nix_aq_inst_s *aq_inst; + union nix_aq_res_s *result = resp; + ulong start; + + debug("%s(%p, 0x%x, 0x%x, 0x%x, 0x%x, %p)\n", __func__, nix_af, lf, + op, ctype, cindex, resp); + aq_status.u = nix_af_reg_read(nix_af, NIXX_AF_AQ_STATUS()); + aq_inst = (union nix_aq_inst_s *)(nix_af->aq.inst.base) + + aq_status.s.head_ptr; + aq_inst->u[0] = 0; + aq_inst->u[1] = 0; + aq_inst->s.op = op; + aq_inst->s.ctype = ctype; + aq_inst->s.lf = lf; + aq_inst->s.cindex = cindex; + aq_inst->s.doneint = 0; + aq_inst->s.res_addr = (u64)resp; + debug("%s: inst@%p: 0x%llx 0x%llx\n", __func__, aq_inst, + aq_inst->u[0], aq_inst->u[1]); + __iowmb(); + + /* Ring doorbell and wait for result */ + nix_af_reg_write(nix_af, NIXX_AF_AQ_DOOR(), 1); + + start = get_timer(0); + /* Wait for completion */ + do { + WATCHDOG_RESET(); + dsb(); + } while (result->s.compcode == 0 && get_timer(start) < 2); + + if (result->s.compcode != NIX_AQ_COMP_E_GOOD) { + printf("NIX:AQ fail or time out with code %d after %ld ms\n", + result->s.compcode, get_timer(start)); + return -EBUSY; + } + return 0; +} + +static int nix_attach_receive_queue(struct nix_af *nix_af, int lf) +{ + struct nix_aq_rq_request rq_req ALIGNED; + int err; + + debug("%s(%p, %d)\n", __func__, nix_af, lf); + + memset(&rq_req, 0, sizeof(struct nix_aq_rq_request)); + + rq_req.rq.s.ena = 1; + rq_req.rq.s.spb_ena = 1; + rq_req.rq.s.ipsech_ena = 0; + rq_req.rq.s.ena_wqwd = 0; + rq_req.rq.s.cq = NIX_CQ_RX; + rq_req.rq.s.substream = 0; /* FIXME: Substream IDs? */ + rq_req.rq.s.wqe_aura = -1; /* No WQE aura */ + rq_req.rq.s.spb_aura = NPA_POOL_RX; + rq_req.rq.s.lpb_aura = NPA_POOL_RX; + /* U-Boot doesn't use WQE group for anything */ + rq_req.rq.s.pb_caching = 1; + rq_req.rq.s.xqe_drop_ena = 0; /* Disable RED dropping */ + rq_req.rq.s.spb_drop_ena = 0; + rq_req.rq.s.lpb_drop_ena = 0; + rq_req.rq.s.spb_sizem1 = (MAX_MTU / (3 * 8)) - 1; /* 512 bytes */ + rq_req.rq.s.lpb_sizem1 = (MAX_MTU / 8) - 1; + rq_req.rq.s.first_skip = 0; + rq_req.rq.s.later_skip = 0; + rq_req.rq.s.xqe_imm_copy = 0; + rq_req.rq.s.xqe_hdr_split = 0; + rq_req.rq.s.xqe_drop = 0; + rq_req.rq.s.xqe_pass = 0; + rq_req.rq.s.wqe_pool_drop = 0; /* No WQE pool */ + rq_req.rq.s.wqe_pool_pass = 0; /* No WQE pool */ + rq_req.rq.s.spb_aura_drop = 255; + rq_req.rq.s.spb_aura_pass = 255; + rq_req.rq.s.spb_pool_drop = 0; + rq_req.rq.s.spb_pool_pass = 0; + rq_req.rq.s.lpb_aura_drop = 255; + rq_req.rq.s.lpb_aura_pass = 255; + rq_req.rq.s.lpb_pool_drop = 0; + rq_req.rq.s.lpb_pool_pass = 0; + rq_req.rq.s.qint_idx = 0; + + err = nix_aq_issue_command(nix_af, lf, + NIX_AQ_INSTOP_E_INIT, + NIX_AQ_CTYPE_E_RQ, + 0, &rq_req.resp); + if (err) { + printf("%s: Error requesting send queue\n", __func__); + return err; + } + + return 0; +} + +static int nix_attach_send_queue(struct nix *nix) +{ + struct nix_af *nix_af = nix->nix_af; + struct nix_aq_sq_request sq_req ALIGNED; + int err; + + debug("%s(%p)\n", __func__, nix_af); + err = nix_af_setup_sq(nix); + + memset(&sq_req, 0, sizeof(sq_req)); + + sq_req.sq.s.ena = 1; + sq_req.sq.s.cq_ena = 1; + sq_req.sq.s.max_sqe_size = NIX_MAXSQESZ_E_W16; + sq_req.sq.s.substream = 0; // FIXME: Substream IDs? + sq_req.sq.s.sdp_mcast = 0; + sq_req.sq.s.cq = NIX_CQ_TX; + sq_req.sq.s.cq_limit = 0; + sq_req.sq.s.smq = nix->lmac->link_num; // scheduling index + sq_req.sq.s.sso_ena = 0; + sq_req.sq.s.smq_rr_quantum = MAX_MTU / 4; + sq_req.sq.s.default_chan = nix->lmac->chan_num; + sq_req.sq.s.sqe_stype = NIX_STYPE_E_STP; + sq_req.sq.s.qint_idx = 0; + sq_req.sq.s.sqb_aura = NPA_POOL_SQB; + + err = nix_aq_issue_command(nix_af, nix->lf, + NIX_AQ_INSTOP_E_INIT, + NIX_AQ_CTYPE_E_SQ, + 0, &sq_req.resp); + if (err) { + printf("%s: Error requesting send queue\n", __func__); + return err; + } + + return 0; +} + +static int nix_attach_completion_queue(struct nix *nix, int cq_idx) +{ + struct nix_af *nix_af = nix->nix_af; + struct nix_aq_cq_request cq_req ALIGNED; + int err; + + debug("%s(%p)\n", __func__, nix_af); + memset(&cq_req, 0, sizeof(cq_req)); + cq_req.cq.s.ena = 1; + cq_req.cq.s.bpid = nix->lmac->pknd; + cq_req.cq.s.substream = 0; /* FIXME: Substream IDs? */ + cq_req.cq.s.drop_ena = 0; + cq_req.cq.s.caching = 1; + cq_req.cq.s.qsize = CQS_QSIZE; + cq_req.cq.s.drop = 255 * 7 / 8; + cq_req.cq.s.qint_idx = 0; + cq_req.cq.s.cint_idx = 0; + cq_req.cq.s.base = nix->cq[cq_idx].iova; + debug("%s: CQ(%d) base %p\n", __func__, cq_idx, + nix->cq[cq_idx].base); + + err = nix_aq_issue_command(nix_af, nix->lf, + NIX_AQ_INSTOP_E_INIT, + NIX_AQ_CTYPE_E_CQ, + cq_idx, &cq_req.resp); + if (err) { + printf("%s: Error requesting completion queue\n", __func__); + return err; + } + debug("%s: CQ(%d) allocated, base %p\n", __func__, cq_idx, + nix->cq[cq_idx].base); + + return 0; +} + +int nix_lf_admin_setup(struct nix *nix) +{ + union nixx_af_lfx_rqs_cfg rqs_cfg; + union nixx_af_lfx_sqs_cfg sqs_cfg; + union nixx_af_lfx_cqs_cfg cqs_cfg; + union nixx_af_lfx_rss_cfg rss_cfg; + union nixx_af_lfx_cints_cfg cints_cfg; + union nixx_af_lfx_qints_cfg qints_cfg; + union nixx_af_lfx_rss_grpx rss_grp; + union nixx_af_lfx_tx_cfg2 tx_cfg2; + union nixx_af_lfx_cfg lfx_cfg; + union nixx_af_lf_rst lf_rst; + u32 index; + struct nix_af *nix_af = nix->nix_af; + int err; + + /* Reset the LF */ + lf_rst.u = 0; + lf_rst.s.lf = nix->lf; + lf_rst.s.exec = 1; + nix_af_reg_write(nix_af, NIXX_AF_LF_RST(), lf_rst.u); + + do { + lf_rst.u = nix_af_reg_read(nix_af, NIXX_AF_LF_RST()); + WATCHDOG_RESET(); + } while (lf_rst.s.exec); + + /* Config NIX RQ HW context and base*/ + nix_af_reg_write(nix_af, NIXX_AF_LFX_RQS_BASE(nix->lf), + (u64)nix->rq_ctx_base); + /* Set caching and queue count in HW */ + rqs_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_RQS_CFG(nix->lf)); + rqs_cfg.s.caching = 1; + rqs_cfg.s.max_queuesm1 = nix->rq_cnt - 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_RQS_CFG(nix->lf), rqs_cfg.u); + + /* Config NIX SQ HW context and base*/ + nix_af_reg_write(nix_af, NIXX_AF_LFX_SQS_BASE(nix->lf), + (u64)nix->sq_ctx_base); + sqs_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_SQS_CFG(nix->lf)); + sqs_cfg.s.caching = 1; + sqs_cfg.s.max_queuesm1 = nix->sq_cnt - 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_SQS_CFG(nix->lf), sqs_cfg.u); + + /* Config NIX CQ HW context and base*/ + nix_af_reg_write(nix_af, NIXX_AF_LFX_CQS_BASE(nix->lf), + (u64)nix->cq_ctx_base); + cqs_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_CQS_CFG(nix->lf)); + cqs_cfg.s.caching = 1; + cqs_cfg.s.max_queuesm1 = nix->cq_cnt - 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_CQS_CFG(nix->lf), cqs_cfg.u); + + /* Config NIX RSS HW context and base */ + nix_af_reg_write(nix_af, NIXX_AF_LFX_RSS_BASE(nix->lf), + (u64)nix->rss_base); + rss_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_RSS_CFG(nix->lf)); + rss_cfg.s.ena = 1; + rss_cfg.s.size = ilog2(nix->rss_sz) / 256; + nix_af_reg_write(nix_af, NIXX_AF_LFX_RSS_CFG(nix->lf), rss_cfg.u); + + for (index = 0; index < nix->rss_grps; index++) { + rss_grp.u = 0; + rss_grp.s.sizem1 = 0x7; + rss_grp.s.offset = nix->rss_sz * index; + nix_af_reg_write(nix_af, + NIXX_AF_LFX_RSS_GRPX(nix->lf, index), + rss_grp.u); + } + + /* Config CQints HW contexts and base */ + nix_af_reg_write(nix_af, NIXX_AF_LFX_CINTS_BASE(nix->lf), + (u64)nix->cint_base); + cints_cfg.u = nix_af_reg_read(nix_af, + NIXX_AF_LFX_CINTS_CFG(nix->lf)); + cints_cfg.s.caching = 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_CINTS_CFG(nix->lf), + cints_cfg.u); + + /* Config Qints HW context and base */ + nix_af_reg_write(nix_af, NIXX_AF_LFX_QINTS_BASE(nix->lf), + (u64)nix->qint_base); + qints_cfg.u = nix_af_reg_read(nix_af, + NIXX_AF_LFX_QINTS_CFG(nix->lf)); + qints_cfg.s.caching = 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_QINTS_CFG(nix->lf), + qints_cfg.u); + + debug("%s(%p, %d, %d)\n", __func__, nix_af, nix->lf, nix->pf); + + /* Enable LMTST for this NIX LF */ + tx_cfg2.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_TX_CFG2(nix->lf)); + tx_cfg2.s.lmt_ena = 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_TX_CFG2(nix->lf), tx_cfg2.u); + + /* Use 16-word XQEs, write the npa pf_func number only */ + lfx_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_CFG(nix->lf)); + lfx_cfg.s.xqe_size = NIX_XQESZ_E_W16; + lfx_cfg.s.npa_pf_func = nix->pf_func; + nix_af_reg_write(nix_af, NIXX_AF_LFX_CFG(nix->lf), lfx_cfg.u); + + nix_af_reg_write(nix_af, NIXX_AF_LFX_RX_CFG(nix->lf), 0); + + for (index = 0; index < nix->cq_cnt; index++) { + err = nix_attach_completion_queue(nix, index); + if (err) { + printf("%s: Error attaching completion queue %d\n", + __func__, index); + return err; + } + } + + for (index = 0; index < nix->rq_cnt; index++) { + err = nix_attach_receive_queue(nix_af, nix->lf); + if (err) { + printf("%s: Error attaching receive queue %d\n", + __func__, index); + return err; + } + } + + for (index = 0; index < nix->sq_cnt; index++) { + err = nix_attach_send_queue(nix); + if (err) { + printf("%s: Error attaching send queue %d\n", + __func__, index); + return err; + } + } + + return 0; +} + +int nix_lf_admin_shutdown(struct nix_af *nix_af, int lf, + u32 cq_count, u32 rq_count, u32 sq_count) +{ + union nixx_af_rx_sw_sync sw_sync; + union nixx_af_lf_rst lf_rst; + int index, err; + + /* Flush all tx packets */ + sw_sync.u = 0; + sw_sync.s.ena = 1; + nix_af_reg_write(nix_af, NIXX_AF_RX_SW_SYNC(), sw_sync.u); + + do { + sw_sync.u = nix_af_reg_read(nix_af, NIXX_AF_RX_SW_SYNC()); + WATCHDOG_RESET(); + } while (sw_sync.s.ena); + + for (index = 0; index < rq_count; index++) { + memset((void *)&rq_dis, 0, sizeof(rq_dis)); + rq_dis.rq.s.ena = 0; /* Context */ + rq_dis.mrq.s.ena = 1; /* Mask */ + __iowmb(); + + err = nix_aq_issue_command(nix_af, lf, + NIX_AQ_INSTOP_E_WRITE, + NIX_AQ_CTYPE_E_RQ, + index, &rq_dis.resp); + if (err) { + printf("%s: Error disabling LF %d RQ(%d)\n", + __func__, lf, index); + return err; + } + debug("%s: LF %d RQ(%d) disabled\n", __func__, lf, index); + } + + for (index = 0; index < sq_count; index++) { + memset((void *)&sq_dis, 0, sizeof(sq_dis)); + sq_dis.sq.s.ena = 0; /* Context */ + sq_dis.msq.s.ena = 1; /* Mask */ + __iowmb(); + + err = nix_aq_issue_command(nix_af, lf, + NIX_AQ_INSTOP_E_WRITE, + NIX_AQ_CTYPE_E_SQ, + index, &sq_dis.resp); + if (err) { + printf("%s: Error disabling LF %d SQ(%d)\n", + __func__, lf, index); + return err; + } + debug("%s: LF %d SQ(%d) disabled\n", __func__, lf, index); + } + + for (index = 0; index < cq_count; index++) { + memset((void *)&cq_dis, 0, sizeof(cq_dis)); + cq_dis.cq.s.ena = 0; /* Context */ + cq_dis.mcq.s.ena = 1; /* Mask */ + __iowmb(); + + err = nix_aq_issue_command(nix_af, lf, + NIX_AQ_INSTOP_E_WRITE, + NIX_AQ_CTYPE_E_CQ, + index, &cq_dis.resp); + if (err) { + printf("%s: Error disabling LF %d CQ(%d)\n", + __func__, lf, index); + return err; + } + debug("%s: LF %d CQ(%d) disabled\n", __func__, lf, index); + } + + /* Reset the LF */ + lf_rst.u = 0; + lf_rst.s.lf = lf; + lf_rst.s.exec = 1; + nix_af_reg_write(nix_af, NIXX_AF_LF_RST(), lf_rst.u); + + do { + lf_rst.u = nix_af_reg_read(nix_af, NIXX_AF_LF_RST()); + WATCHDOG_RESET(); + } while (lf_rst.s.exec); + + return 0; +} + +int npc_lf_admin_setup(struct nix *nix) +{ + union npc_af_const af_const; + union npc_af_pkindx_action0 action0; + union npc_af_pkindx_action1 action1; + union npc_af_intfx_kex_cfg kex_cfg; + union npc_af_intfx_miss_stat_act intfx_stat_act; + union npc_af_mcamex_bankx_camx_intf camx_intf; + union npc_af_mcamex_bankx_camx_w0 camx_w0; + union npc_af_mcamex_bankx_cfg bankx_cfg; + union npc_af_mcamex_bankx_stat_act mcamex_stat_act; + + union nix_rx_action_s rx_action; + union nix_tx_action_s tx_action; + + struct nix_af *nix_af = nix->nix_af; + u32 kpus; + int pkind = nix->lmac->link_num; + int index; + u64 offset; + + debug("%s(%p, pkind 0x%x)\n", __func__, nix_af, pkind); + af_const.u = npc_af_reg_read(nix_af, NPC_AF_CONST()); + kpus = af_const.s.kpus; + + action0.u = 0; + action0.s.parse_done = 1; + npc_af_reg_write(nix_af, NPC_AF_PKINDX_ACTION0(pkind), action0.u); + + action1.u = 0; + npc_af_reg_write(nix_af, NPC_AF_PKINDX_ACTION1(pkind), action1.u); + + kex_cfg.u = 0; + kex_cfg.s.keyw = NPC_MCAMKEYW_E_X1; + kex_cfg.s.parse_nibble_ena = 0x7; + npc_af_reg_write(nix_af, + NPC_AF_INTFX_KEX_CFG(NPC_INTF_E_NIXX_RX(0)), + kex_cfg.u); + + /* HW Issue */ + kex_cfg.u = 0; + kex_cfg.s.parse_nibble_ena = 0x7; + npc_af_reg_write(nix_af, + NPC_AF_INTFX_KEX_CFG(NPC_INTF_E_NIXX_TX(0)), + kex_cfg.u); + + camx_intf.u = 0; + camx_intf.s.intf = ~NPC_INTF_E_NIXX_RX(0); + npc_af_reg_write(nix_af, + NPC_AF_MCAMEX_BANKX_CAMX_INTF(pkind, 0, 0), + camx_intf.u); + + camx_intf.u = 0; + camx_intf.s.intf = NPC_INTF_E_NIXX_RX(0); + npc_af_reg_write(nix_af, + NPC_AF_MCAMEX_BANKX_CAMX_INTF(pkind, 0, 1), + camx_intf.u); + + camx_w0.u = 0; + camx_w0.s.md = ~(nix->lmac->chan_num) & (~((~0x0ull) << 12)); + debug("NPC LF ADMIN camx_w0.u %llx\n", camx_w0.u); + npc_af_reg_write(nix_af, + NPC_AF_MCAMEX_BANKX_CAMX_W0(pkind, 0, 0), + camx_w0.u); + + camx_w0.u = 0; + camx_w0.s.md = nix->lmac->chan_num; + npc_af_reg_write(nix_af, + NPC_AF_MCAMEX_BANKX_CAMX_W0(pkind, 0, 1), + camx_w0.u); + + npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_CAMX_W1(pkind, 0, 0), + 0); + + npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_CAMX_W1(pkind, 0, 1), + 0); + + /* Enable stats for NPC INTF RX */ + mcamex_stat_act.u = 0; + mcamex_stat_act.s.ena = 1; + mcamex_stat_act.s.stat_sel = pkind; + npc_af_reg_write(nix_af, + NPC_AF_MCAMEX_BANKX_STAT_ACT(pkind, 0), + mcamex_stat_act.u); + intfx_stat_act.u = 0; + intfx_stat_act.s.ena = 1; + intfx_stat_act.s.stat_sel = 16; + offset = NPC_AF_INTFX_MISS_STAT_ACT(NPC_INTF_E_NIXX_RX(0)); + npc_af_reg_write(nix_af, offset, intfx_stat_act.u); + rx_action.u = 0; + rx_action.s.pf_func = nix->pf_func; + rx_action.s.op = NIX_RX_ACTIONOP_E_UCAST; + npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_ACTION(pkind, 0), + rx_action.u); + + for (index = 0; index < kpus; index++) + npc_af_reg_write(nix_af, NPC_AF_KPUX_CFG(index), 0); + + rx_action.u = 0; + rx_action.s.pf_func = nix->pf_func; + rx_action.s.op = NIX_RX_ACTIONOP_E_DROP; + npc_af_reg_write(nix_af, + NPC_AF_INTFX_MISS_ACT(NPC_INTF_E_NIXX_RX(0)), + rx_action.u); + bankx_cfg.u = 0; + bankx_cfg.s.ena = 1; + npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_CFG(pkind, 0), + bankx_cfg.u); + + tx_action.u = 0; + tx_action.s.op = NIX_TX_ACTIONOP_E_UCAST_DEFAULT; + npc_af_reg_write(nix_af, + NPC_AF_INTFX_MISS_ACT(NPC_INTF_E_NIXX_TX(0)), + tx_action.u); + +#ifdef DEBUG + /* Enable debug capture on RX intf */ + npc_af_reg_write(nix_af, NPC_AF_DBG_CTL(), 0x4); +#endif + + return 0; +} + +int npc_af_shutdown(struct nix_af *nix_af) +{ + union npc_af_blk_rst blk_rst; + + blk_rst.u = 0; + blk_rst.s.rst = 1; + npc_af_reg_write(nix_af, NPC_AF_BLK_RST(), blk_rst.u); + + /* Wait for reset to complete */ + do { + blk_rst.u = npc_af_reg_read(nix_af, NPC_AF_BLK_RST()); + WATCHDOG_RESET(); + } while (blk_rst.s.busy); + + debug("%s: npc af reset --\n", __func__); + + return 0; +} + +int nix_af_setup(struct nix_af *nix_af) +{ + int err; + union nixx_af_const2 af_const2; + union nixx_af_const3 af_const3; + union nixx_af_sq_const sq_const; + union nixx_af_cfg af_cfg; + union nixx_af_status af_status; + union nixx_af_ndc_cfg ndc_cfg; + union nixx_af_aq_cfg aq_cfg; + union nixx_af_blk_rst blk_rst; + + debug("%s(%p)\n", __func__, nix_af); + err = rvu_aq_alloc(&nix_af->aq, Q_COUNT(AQ_SIZE), + sizeof(union nix_aq_inst_s), + sizeof(union nix_aq_res_s)); + if (err) { + printf("%s: Error allocating nix admin queue\n", __func__); + return err; + } + + blk_rst.u = 0; + blk_rst.s.rst = 1; + nix_af_reg_write(nix_af, NIXX_AF_BLK_RST(), blk_rst.u); + + /* Wait for reset to complete */ + do { + blk_rst.u = nix_af_reg_read(nix_af, NIXX_AF_BLK_RST()); + WATCHDOG_RESET(); + } while (blk_rst.s.busy); + + /* Put in LE mode */ + af_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_CFG()); + if (af_cfg.s.force_cond_clk_en || af_cfg.s.calibrate_x2p || + af_cfg.s.force_intf_clk_en) { + printf("%s: Error: Invalid NIX_AF_CFG value 0x%llx\n", + __func__, af_cfg.u); + return -1; + } + af_cfg.s.af_be = 0; + af_cfg.u |= 0x5E; /* HW Issue */ + nix_af_reg_write(nix_af, NIXX_AF_CFG(), af_cfg.u); + + /* Perform Calibration */ + af_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_CFG()); + af_cfg.s.calibrate_x2p = 1; + nix_af_reg_write(nix_af, NIXX_AF_CFG(), af_cfg.u); + + /* Wait for calibration to complete */ + do { + af_status.u = nix_af_reg_read(nix_af, NIXX_AF_STATUS()); + WATCHDOG_RESET(); + } while (af_status.s.calibrate_done == 0); + + af_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_CFG()); + af_cfg.s.calibrate_x2p = 0; + nix_af_reg_write(nix_af, NIXX_AF_CFG(), af_cfg.u); + + /* Enable NDC cache */ + ndc_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_NDC_CFG()); + ndc_cfg.s.ndc_ign_pois = 0; + ndc_cfg.s.byp_sq = 0; + ndc_cfg.s.byp_sqb = 0; + ndc_cfg.s.byp_cqs = 0; + ndc_cfg.s.byp_cints = 0; + ndc_cfg.s.byp_dyno = 0; + ndc_cfg.s.byp_mce = 0; + ndc_cfg.s.byp_rqc = 0; + ndc_cfg.s.byp_rsse = 0; + ndc_cfg.s.byp_mc_data = 0; + ndc_cfg.s.byp_mc_wqe = 0; + ndc_cfg.s.byp_mr_data = 0; + ndc_cfg.s.byp_mr_wqe = 0; + ndc_cfg.s.byp_qints = 0; + nix_af_reg_write(nix_af, NIXX_AF_NDC_CFG(), ndc_cfg.u); + + /* Set up queue size */ + aq_cfg.u = 0; + aq_cfg.s.qsize = AQ_SIZE; + nix_af_reg_write(nix_af, NIXX_AF_AQ_CFG(), aq_cfg.u); + + /* Set up queue base address */ + nix_af_reg_write(nix_af, NIXX_AF_AQ_BASE(), nix_af->aq.inst.iova); + + af_const3.u = nix_af_reg_read(nix_af, NIXX_AF_CONST3()); + af_const2.u = nix_af_reg_read(nix_af, NIXX_AF_CONST2()); + sq_const.u = nix_af_reg_read(nix_af, NIXX_AF_SQ_CONST()); + nix_af->rq_ctx_sz = 1ULL << af_const3.s.rq_ctx_log2bytes; + nix_af->sq_ctx_sz = 1ULL << af_const3.s.sq_ctx_log2bytes; + nix_af->cq_ctx_sz = 1ULL << af_const3.s.cq_ctx_log2bytes; + nix_af->rsse_ctx_sz = 1ULL << af_const3.s.rsse_log2bytes; + nix_af->qints = af_const2.s.qints; + nix_af->cints = af_const2.s.cints; + nix_af->cint_ctx_sz = 1ULL << af_const3.s.cint_log2bytes; + nix_af->qint_ctx_sz = 1ULL << af_const3.s.qint_log2bytes; + nix_af->sqb_size = sq_const.s.sqb_size; + + return 0; +} + +int nix_af_shutdown(struct nix_af *nix_af) +{ + union nixx_af_blk_rst blk_rst; + + blk_rst.u = 0; + blk_rst.s.rst = 1; + nix_af_reg_write(nix_af, NIXX_AF_BLK_RST(), blk_rst.u); + + /* Wait for reset to complete */ + do { + blk_rst.u = nix_af_reg_read(nix_af, NIXX_AF_BLK_RST()); + WATCHDOG_RESET(); + } while (blk_rst.s.busy); + + rvu_aq_free(&nix_af->aq); + + debug("%s: nix af reset --\n", __func__); + + return 0; +} diff --git a/drivers/net/octeontx2/npc.h b/drivers/net/octeontx2/npc.h new file mode 100644 index 0000000000..30dca18b1f --- /dev/null +++ b/drivers/net/octeontx2/npc.h @@ -0,0 +1,92 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __NPC_H__ +#define __NPC_H__ + +#define RSVD_MCAM_ENTRIES_PER_PF 2 /** Ucast and Bcast */ +#define RSVD_MCAM_ENTRIES_PER_NIXLF 1 /** Ucast for VFs */ + +struct npc_kpu_profile_cam { + u8 state; + u8 state_mask; + u16 dp0; + u16 dp0_mask; + u16 dp1; + u16 dp1_mask; + u16 dp2; + u16 dp2_mask; +}; + +struct npc_kpu_profile_action { + u8 errlev; + u8 errcode; + u8 dp0_offset; + u8 dp1_offset; + u8 dp2_offset; + u8 bypass_count; + u8 parse_done; + u8 next_state; + u8 ptr_advance; + u8 cap_ena; + u8 lid; + u8 ltype; + u8 flags; + u8 offset; + u8 mask; + u8 right; + u8 shift; +}; + +struct npc_kpu_profile { + int cam_entries; + int action_entries; + struct npc_kpu_profile_cam *cam; + struct npc_kpu_profile_action *action; +}; + +struct npc_pkind { + struct rsrc_bmap rsrc; + u32 *pfchan_map; +}; + +struct npc_mcam { + struct rsrc_bmap rsrc; + u16 *pfvf_map; + u16 total_entries; /* Total number of MCAM entries */ + u16 entries; /* Total - reserved for NIX LFs */ + u8 banks_per_entry; /* Number of keywords in key */ + u8 keysize; + u8 banks; /* Number of MCAM banks */ + u16 banksize; /* Number of MCAM entries in each bank */ + u16 counters; /* Number of match counters */ + u16 nixlf_offset; + u16 pf_offset; +}; + +struct nix_af_handle; +struct nix_handle; +struct rvu_hwinfo; + +struct npc_af { + struct nix_af_handle *nix_af; + struct npc_pkind pkind; + void __iomem *npc_af_base; + u8 npc_kpus; /** Number of parser units */ + struct npc_mcam mcam; + struct rvu_block block; + struct rvu_hwinfo *hw; +}; + +struct npc { + struct npc_af *npc_af; + void __iomem *npc_base; + struct nix_handle *nix; +} + +#endif /* __NPC_H__ */ + diff --git a/drivers/net/octeontx2/rvu.h b/drivers/net/octeontx2/rvu.h new file mode 100644 index 0000000000..71e6607c19 --- /dev/null +++ b/drivers/net/octeontx2/rvu.h @@ -0,0 +1,121 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __RVU_H__ +#define __RVU_H__ + +#include <asm/arch/csrs/csrs-rvu.h> + +#define ALIGNED __aligned(CONFIG_SYS_CACHELINE_SIZE) + +#define Q_SIZE_16 0ULL /* 16 entries */ +#define Q_SIZE_64 1ULL /* 64 entries */ +#define Q_SIZE_256 2ULL +#define Q_SIZE_1K 3ULL +#define Q_SIZE_4K 4ULL +#define Q_SIZE_16K 5ULL +#define Q_SIZE_64K 6ULL +#define Q_SIZE_256K 7ULL +#define Q_SIZE_1M 8ULL /* Million entries */ +#define Q_SIZE_MIN Q_SIZE_16 +#define Q_SIZE_MAX Q_SIZE_1M + +#define Q_COUNT(x) (16ULL << (2 * (x))) +#define Q_SIZE(x, n) ((ilog2(x) - (n)) / 2) + +/* Admin queue info */ + +/* Since we intend to add only one instruction at a time, + * keep queue size to it's minimum. + */ +#define AQ_SIZE Q_SIZE_16 +/* HW head & tail pointer mask */ +#define AQ_PTR_MASK 0xFFFFF + +struct qmem { + void *base; + dma_addr_t iova; + size_t alloc_sz; + u32 qsize; + u8 entry_sz; +}; + +struct admin_queue { + struct qmem inst; + struct qmem res; +}; + +struct rvu_af { + struct udevice *dev; + void __iomem *af_base; + struct nix_af *nix_af; +}; + +struct rvu_pf { + struct udevice *dev; + struct udevice *afdev; + void __iomem *pf_base; + struct nix *nix; + u8 pfid; + int nix_lfid; + int npa_lfid; +}; + +/** + * Store 128 bit value + * + * @param[out] dest pointer to destination address + * @param val0 first 64 bits to write + * @param val1 second 64 bits to write + */ +static inline void st128(void *dest, u64 val0, u64 val1) +{ + __asm__ __volatile__("stp %x[x0], %x[x1], [%[pm]]" : + : [x0]"r"(val0), [x1]"r"(val1), [pm]"r"(dest) + : "memory"); +} + +/** + * Load 128 bit value + * + * @param[in] source pointer to 128 bits of data to load + * @param[out] val0 first 64 bits of data + * @param[out] val1 second 64 bits of data + */ +static inline void ld128(const u64 *src, u64 *val0, u64 *val1) +{ + __asm__ __volatile__ ("ldp %x[x0], %x[x1], [%[pm]]" : + : [x0]"r"(*val0), [x1]"r"(*val1), [pm]"r"(src)); +} + +void qmem_free(struct qmem *q); +int qmem_alloc(struct qmem *q, u32 qsize, size_t entry_sz); + +/** + * Allocates an admin queue for instructions and results + * + * @param aq admin queue to allocate for + * @param qsize Number of entries in the queue + * @param inst_size Size of each instruction + * @param res_size Size of each result + * + * @return -ENOMEM on error, 0 on success + */ +int rvu_aq_alloc(struct admin_queue *aq, unsigned int qsize, + size_t inst_size, size_t res_size); + +/** + * Frees an admin queue + * + * @param aq Admin queue to free + */ +void rvu_aq_free(struct admin_queue *aq); + +void rvu_get_lfid_for_pf(int pf, int *nixid, int *npaid); + +#endif /* __RVU_H__ */ + diff --git a/drivers/net/octeontx2/rvu_af.c b/drivers/net/octeontx2/rvu_af.c new file mode 100644 index 0000000000..675f0a2519 --- /dev/null +++ b/drivers/net/octeontx2/rvu_af.c @@ -0,0 +1,173 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <common.h> +#include <net.h> +#include <malloc.h> +#include <dm.h> +#include <misc.h> +#include <pci_ids.h> +#include <errno.h> +#include <linux/list.h> +#include <asm/io.h> +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-npa.h> +#include "nix.h" + +struct udevice *rvu_af_dev; + +inline struct rvu_af *get_af(void) +{ + return rvu_af_dev ? dev_get_priv(rvu_af_dev) : NULL; +} + +void rvu_get_lfid_for_pf(int pf, int *nixid, int *npaid) +{ + union nixx_af_rvu_lf_cfg_debug nix_lf_dbg; + union npa_af_rvu_lf_cfg_debug npa_lf_dbg; + union rvu_pf_func_s pf_func; + struct rvu_af *af = dev_get_priv(rvu_af_dev); + struct nix_af *nix_af = af->nix_af; + + pf_func.u = 0; + pf_func.s.pf = pf; + + nix_lf_dbg.u = 0; + nix_lf_dbg.s.pf_func = pf_func.u & 0xFFFF; + nix_lf_dbg.s.exec = 1; + nix_af_reg_write(nix_af, NIXX_AF_RVU_LF_CFG_DEBUG(), + nix_lf_dbg.u); + do { + nix_lf_dbg.u = nix_af_reg_read(nix_af, + NIXX_AF_RVU_LF_CFG_DEBUG()); + } while (nix_lf_dbg.s.exec); + + if (nix_lf_dbg.s.lf_valid) + *nixid = nix_lf_dbg.s.lf; + + debug("%s: nix lf_valid %d lf %d nixid %d\n", __func__, + nix_lf_dbg.s.lf_valid, nix_lf_dbg.s.lf, *nixid); + + npa_lf_dbg.u = 0; + npa_lf_dbg.s.pf_func = pf_func.u & 0xFFFF; + npa_lf_dbg.s.exec = 1; + npa_af_reg_write(nix_af->npa_af, NPA_AF_RVU_LF_CFG_DEBUG(), + npa_lf_dbg.u); + do { + npa_lf_dbg.u = npa_af_reg_read(nix_af->npa_af, + NPA_AF_RVU_LF_CFG_DEBUG()); + } while (npa_lf_dbg.s.exec); + + if (npa_lf_dbg.s.lf_valid) + *npaid = npa_lf_dbg.s.lf; + debug("%s: npa lf_valid %d lf %d npaid %d\n", __func__, + npa_lf_dbg.s.lf_valid, npa_lf_dbg.s.lf, *npaid); +} + +struct nix_af *rvu_af_init(struct rvu_af *rvu_af) +{ + struct nix_af *nix_af; + union rvu_af_addr_s block_addr; + int err; + + nix_af = (struct nix_af *)calloc(1, sizeof(struct nix_af)); + if (!nix_af) { + printf("%s: out of memory\n", __func__); + goto error; + } + + nix_af->dev = rvu_af->dev; + + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NIXX(0); + nix_af->nix_af_base = rvu_af->af_base + block_addr.u; + + nix_af->npa_af = (struct npa_af *)calloc(1, sizeof(struct npa_af)); + if (!nix_af->npa_af) { + printf("%s: out of memory\n", __func__); + goto error; + } + + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NPA; + nix_af->npa_af->npa_af_base = rvu_af->af_base + block_addr.u; + + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NPC; + nix_af->npc_af_base = rvu_af->af_base + block_addr.u; + + debug("%s: Setting up npa admin\n", __func__); + err = npa_af_setup(nix_af->npa_af); + if (err) { + printf("%s: Error %d setting up NPA admin\n", __func__, err); + goto error; + } + debug("%s: Setting up nix af\n", __func__); + err = nix_af_setup(nix_af); + if (err) { + printf("%s: Error %d setting up NIX admin\n", __func__, err); + goto error; + } + debug("%s: nix_af: %p\n", __func__, nix_af); + return nix_af; + +error: + if (nix_af->npa_af) { + free(nix_af->npa_af); + memset(nix_af, 0, sizeof(*nix_af)); + } + if (nix_af) + free(nix_af); + return NULL; +} + +int rvu_af_probe(struct udevice *dev) +{ + struct rvu_af *af_ptr = dev_get_priv(dev); + + af_ptr->af_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + debug("%s RVU AF BAR %p\n", __func__, af_ptr->af_base); + af_ptr->dev = dev; + rvu_af_dev = dev; + + af_ptr->nix_af = rvu_af_init(af_ptr); + if (!af_ptr->nix_af) { + printf("%s: Error: could not initialize NIX AF\n", __func__); + return -1; + } + debug("%s: Done\n", __func__); + + return 0; +} + +int rvu_af_remove(struct udevice *dev) +{ + struct rvu_af *rvu_af = dev_get_priv(dev); + + nix_af_shutdown(rvu_af->nix_af); + npa_af_shutdown(rvu_af->nix_af->npa_af); + npc_af_shutdown(rvu_af->nix_af); + + debug("%s: rvu af down --\n", __func__); + return 0; +} + +U_BOOT_DRIVER(rvu_af) = { + .name = "rvu_af", + .id = UCLASS_MISC, + .probe = rvu_af_probe, + .remove = rvu_af_remove, + .priv_auto_alloc_size = sizeof(struct rvu_af), +}; + +static struct pci_device_id rvu_af_supported[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_RVU_AF) }, + {} +}; + +U_BOOT_PCI_DEVICE(rvu_af, rvu_af_supported); diff --git a/drivers/net/octeontx2/rvu_common.c b/drivers/net/octeontx2/rvu_common.c new file mode 100644 index 0000000000..6ec28c2a8c --- /dev/null +++ b/drivers/net/octeontx2/rvu_common.c @@ -0,0 +1,73 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <asm/io.h> + +#include "rvu.h" + +int qmem_alloc(struct qmem *q, u32 qsize, size_t entry_sz) +{ + q->base = memalign(CONFIG_SYS_CACHELINE_SIZE, qsize * entry_sz); + if (!q->base) + return -ENOMEM; + q->entry_sz = entry_sz; + q->qsize = qsize; + q->alloc_sz = (size_t)qsize * entry_sz; + q->iova = (dma_addr_t)(q->base); + debug("NIX: qmem alloc for (%d * %d = %ld bytes) at %p\n", + q->qsize, q->entry_sz, q->alloc_sz, q->base); + return 0; +} + +void qmem_free(struct qmem *q) +{ + if (q->base) + free(q->base); + memset(q, 0, sizeof(*q)); +} + +/** + * Allocates an admin queue for instructions and results + * + * @param aq admin queue to allocate for + * @param qsize Number of entries in the queue + * @param inst_size Size of each instruction + * @param res_size Size of each result + * + * @return -ENOMEM on error, 0 on success + */ +int rvu_aq_alloc(struct admin_queue *aq, unsigned int qsize, + size_t inst_size, size_t res_size) +{ + int err; + + err = qmem_alloc(&aq->inst, qsize, inst_size); + if (err) + return err; + err = qmem_alloc(&aq->res, qsize, res_size); + if (err) + qmem_free(&aq->inst); + + return err; +} + +/** + * Frees an admin queue + * + * @param aq Admin queue to free + */ +void rvu_aq_free(struct admin_queue *aq) +{ + qmem_free(&aq->inst); + qmem_free(&aq->res); + memset(aq, 0, sizeof(*aq)); +} diff --git a/drivers/net/octeontx2/rvu_pf.c b/drivers/net/octeontx2/rvu_pf.c new file mode 100644 index 0000000000..0ac3071709 --- /dev/null +++ b/drivers/net/octeontx2/rvu_pf.c @@ -0,0 +1,118 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <pci_ids.h> +#include <asm/io.h> +#include <asm/types.h> +#include <asm/arch/board.h> +#include "cgx.h" +#include "nix.h" + +extern struct udevice *rvu_af_dev; + +int rvu_pf_init(struct rvu_pf *rvu) +{ + struct nix *nix; + struct eth_pdata *pdata = dev_get_platdata(rvu->dev); + + debug("%s: Allocating nix lf\n", __func__); + nix = nix_lf_alloc(rvu->dev); + if (!nix) { + printf("%s: Error allocating lf for pf %d\n", + __func__, rvu->pfid); + return -1; + } + rvu->nix = nix; + + /* to make post_probe happy */ + if (is_valid_ethaddr(nix->lmac->mac_addr)) { + memcpy(pdata->enetaddr, nix->lmac->mac_addr, 6); + eth_env_set_enetaddr_by_index("eth", rvu->dev->seq, + pdata->enetaddr); + } + + return 0; +} + +static const struct eth_ops nix_eth_ops = { + .start = nix_lf_init, + .send = nix_lf_xmit, + .recv = nix_lf_recv, + .free_pkt = nix_lf_free_pkt, + .stop = nix_lf_halt, + .write_hwaddr = nix_lf_setup_mac, +}; + +int rvu_pf_probe(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + int err; + char name[16]; + + debug("%s: name: %s\n", __func__, dev->name); + + rvu->pf_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_2, PCI_REGION_MEM); + rvu->pfid = dev->seq + 1; // RVU PF's start from 1; + rvu->dev = dev; + if (!rvu_af_dev) { + printf("%s: Error: Could not find RVU AF device\n", + __func__); + return -1; + } + rvu->afdev = rvu_af_dev; + + debug("RVU PF %u BAR2 %p\n", rvu->pfid, rvu->pf_base); + + rvu_get_lfid_for_pf(rvu->pfid, &rvu->nix_lfid, &rvu->npa_lfid); + + err = rvu_pf_init(rvu); + if (err) + printf("%s: Error %d adding nix\n", __func__, err); + + /* + * modify device name to include index/sequence number, + * for better readability, this is 1:1 mapping with eth0/1/2.. names. + */ + sprintf(name, "rvu_pf#%d", dev->seq); + device_set_name(dev, name); + debug("%s: name: %s\n", __func__, dev->name); + return err; +} + +int rvu_pf_remove(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + + nix_lf_shutdown(rvu->nix); + npa_lf_shutdown(rvu->nix); + + debug("%s: rvu pf%d down --\n", __func__, rvu->pfid); + + return 0; +} + +U_BOOT_DRIVER(rvu_pf) = { + .name = "rvu_pf", + .id = UCLASS_ETH, + .probe = rvu_pf_probe, + .remove = rvu_pf_remove, + .ops = &nix_eth_ops, + .priv_auto_alloc_size = sizeof(struct rvu_pf), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; + +static struct pci_device_id rvu_pf_supported[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_RVU_PF) }, + {} +}; + +U_BOOT_PCI_DEVICE(rvu_pf, rvu_pf_supported);
Adds support for Core 0 watchdog poke on OcteonTX and OcteonTX2 platforms.
Signed-off-by: Suneel Garapati sgarapati@marvell.com Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Simon Glass sjg@chromium.org
Changes in v2: - Add Reviewed-by tag from Simon - Add CORE0_POKE_OFFSET_MASK and calculate poke register address in _probe() instead of repeatedly in _reset() - Slightly change the Kconfig entry: use "default y", it already depends on "WDT && (ARCH_OCTEONTX || ARCH_OCTEONTX2)"
Changes in v1: - Change patch subject - Remove inclusion of common.h - Remove global wdt_dev as its unused - Remove #ifdef's - Remove optional fixed register access - only use address passed via DT while probing - Use dev_remap_addr() instead of dev_read_addr_index()
drivers/watchdog/Kconfig | 10 +++++ drivers/watchdog/Makefile | 1 + drivers/watchdog/octeontx_wdt.c | 66 +++++++++++++++++++++++++++++++++ 3 files changed, 77 insertions(+) create mode 100644 drivers/watchdog/octeontx_wdt.c
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 0ebf116b12..210d9f8093 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -139,6 +139,16 @@ config WDT_MTK The watchdog timer is stopped when initialized. It performs full SoC reset.
+config WDT_OCTEONTX + bool "OcteonTX core watchdog support" + depends on WDT && (ARCH_OCTEONTX || ARCH_OCTEONTX2) + default y + imply WATCHDOG + help + This enables OcteonTX watchdog driver, which can be + found on OcteonTX/TX2 chipsets and inline with driver model. + Only supports watchdog reset. + config WDT_OMAP3 bool "TI OMAP watchdog timer support" depends on WDT && ARCH_OMAP2PLUS diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 111e258195..01b8231f2b 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -26,6 +26,7 @@ obj-$(CONFIG_WDT_CDNS) += cdns_wdt.o obj-$(CONFIG_WDT_MPC8xx) += mpc8xx_wdt.o obj-$(CONFIG_WDT_MT7621) += mt7621_wdt.o obj-$(CONFIG_WDT_MTK) += mtk_wdt.o +obj-$(CONFIG_WDT_OCTEONTX) += octeontx_wdt.o obj-$(CONFIG_WDT_OMAP3) += omap_wdt.o obj-$(CONFIG_WDT_SBSA) += sbsa_gwdt.o obj-$(CONFIG_WDT_K3_RTI) += rti_wdt.o diff --git a/drivers/watchdog/octeontx_wdt.c b/drivers/watchdog/octeontx_wdt.c new file mode 100644 index 0000000000..1e0670e0c5 --- /dev/null +++ b/drivers/watchdog/octeontx_wdt.c @@ -0,0 +1,66 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <dm.h> +#include <errno.h> +#include <wdt.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define CORE0_POKE_OFFSET 0x50000 +#define CORE0_POKE_OFFSET_MASK 0xfffffULL + +struct octeontx_wdt { + void __iomem *reg; +}; + +static int octeontx_wdt_reset(struct udevice *dev) +{ + struct octeontx_wdt *priv = dev_get_priv(dev); + + writeq(~0ULL, priv->reg); + + return 0; +} + +static int octeontx_wdt_probe(struct udevice *dev) +{ + struct octeontx_wdt *priv = dev_get_priv(dev); + + priv->reg = dev_remap_addr(dev); + if (!priv->reg) + return -EINVAL; + + /* + * Save core poke register address in reg (its not 0xa0000 as + * extracted from the DT but 0x50000 instead) + */ + priv->reg = (void __iomem *)(((u64)priv->reg & + ~CORE0_POKE_OFFSET_MASK) | + CORE0_POKE_OFFSET); + + return 0; +} + +static const struct wdt_ops octeontx_wdt_ops = { + .reset = octeontx_wdt_reset, +}; + +static const struct udevice_id octeontx_wdt_ids[] = { + { .compatible = "arm,sbsa-gwdt" }, + {} +}; + +U_BOOT_DRIVER(wdt_octeontx) = { + .name = "wdt_octeontx", + .id = UCLASS_WDT, + .of_match = octeontx_wdt_ids, + .ops = &octeontx_wdt_ops, + .priv_auto_alloc_size = sizeof(struct octeontx_wdt), + .probe = octeontx_wdt_probe, +};
This patch adds support for all OcteonTX 81xx/83xx boards from Marvell. For 81xx boards, use octeontx_81xx_defconfig and for 83xx boards, use octeontx_83xx_defconfig.
Signed-off-by: Stefan Roese sr@denx.de ---
Changes in v2: - Select CONFIG_OF_LIVE
Changes in v1: - Changed patch subject - Rebased on latest TOT - Removed inclusion of common.h - Moved MEMTEST defines to Kconfig - *.c files checkpatch cleanup
arch/arm/Kconfig | 10 + arch/arm/Makefile | 1 + arch/arm/mach-octeontx/Kconfig | 23 ++ arch/arm/mach-octeontx/Makefile | 9 + arch/arm/mach-octeontx/clock.c | 35 +++ arch/arm/mach-octeontx/cpu.c | 76 ++++++ arch/arm/mach-octeontx/lowlevel_init.S | 33 +++ board/Marvell/octeontx/Kconfig | 14 ++ board/Marvell/octeontx/MAINTAINERS | 8 + board/Marvell/octeontx/Makefile | 9 + board/Marvell/octeontx/board-fdt.c | 311 +++++++++++++++++++++++++ board/Marvell/octeontx/board.c | 152 ++++++++++++ board/Marvell/octeontx/smc.c | 25 ++ board/Marvell/octeontx/soc-utils.c | 50 ++++ configs/octeontx_81xx_defconfig | 134 +++++++++++ configs/octeontx_83xx_defconfig | 129 ++++++++++ drivers/mtd/nand/raw/octeontx_bch.c | 7 +- drivers/mtd/nand/raw/octeontx_nand.c | 11 +- drivers/net/octeontx/bgx.c | 2 +- drivers/net/octeontx/nic_main.c | 2 +- drivers/net/octeontx/nicvf_main.c | 2 +- drivers/net/octeontx/nicvf_queues.c | 2 +- drivers/net/octeontx/smi.c | 2 +- drivers/net/octeontx/xcv.c | 2 +- include/configs/octeontx_common.h | 89 +++++++ 25 files changed, 1124 insertions(+), 14 deletions(-) create mode 100644 arch/arm/mach-octeontx/Kconfig create mode 100644 arch/arm/mach-octeontx/Makefile create mode 100644 arch/arm/mach-octeontx/clock.c create mode 100644 arch/arm/mach-octeontx/cpu.c create mode 100644 arch/arm/mach-octeontx/lowlevel_init.S create mode 100644 board/Marvell/octeontx/Kconfig create mode 100644 board/Marvell/octeontx/MAINTAINERS create mode 100644 board/Marvell/octeontx/Makefile create mode 100644 board/Marvell/octeontx/board-fdt.c create mode 100644 board/Marvell/octeontx/board.c create mode 100644 board/Marvell/octeontx/smc.c create mode 100644 board/Marvell/octeontx/soc-utils.c create mode 100644 configs/octeontx_81xx_defconfig create mode 100644 configs/octeontx_83xx_defconfig create mode 100644 include/configs/octeontx_common.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 8401851666..869d255347 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1725,6 +1725,14 @@ config ARCH_ROCKCHIP imply TPL_SYSRESET imply USB_FUNCTION_FASTBOOT
+config ARCH_OCTEONTX + bool "Support OcteonTX SoCs" + select DM + select ARM64 + select OF_CONTROL + select OF_LIVE + select BOARD_LATE_INIT + select SYS_CACHE_SHIFT_7 config TARGET_THUNDERX_88XX bool "Support ThunderX 88xx" select ARM64 @@ -1823,6 +1831,7 @@ source "arch/arm/mach-lpc32xx/Kconfig"
source "arch/arm/mach-mvebu/Kconfig"
+source "arch/arm/mach-octeontx/Kconfig" source "arch/arm/cpu/armv7/ls102xa/Kconfig"
source "arch/arm/mach-imx/mx2/Kconfig" @@ -1906,6 +1915,7 @@ source "board/bosch/guardian/Kconfig" source "board/CarMediaLab/flea3/Kconfig" source "board/Marvell/aspenite/Kconfig" source "board/Marvell/gplugd/Kconfig" +source "board/Marvell/octeontx/Kconfig" source "board/armadeus/apf27/Kconfig" source "board/armltd/vexpress/Kconfig" source "board/armltd/vexpress64/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index bf3890e99b..87b4198312 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -80,6 +80,7 @@ machine-$(CONFIG_ARCH_STM32MP) += stm32mp machine-$(CONFIG_ARCH_SUNXI) += sunxi machine-$(CONFIG_ARCH_TEGRA) += tegra machine-$(CONFIG_ARCH_U8500) += u8500 +machine-$(CONFIG_ARCH_OCTEONTX) += octeontx machine-$(CONFIG_ARCH_UNIPHIER) += uniphier machine-$(CONFIG_ARCH_VERSAL) += versal machine-$(CONFIG_ARCH_ZYNQ) += zynq diff --git a/arch/arm/mach-octeontx/Kconfig b/arch/arm/mach-octeontx/Kconfig new file mode 100644 index 0000000000..28ecf9821f --- /dev/null +++ b/arch/arm/mach-octeontx/Kconfig @@ -0,0 +1,23 @@ +if ARCH_OCTEONTX + +choice + prompt "OcteonTX board select" + optional + +config TARGET_OCTEONTX_81XX + bool "Marvell OcteonTX CN81XX" + +config TARGET_OCTEONTX_83XX + bool "Marvell OcteonTX CN83XX" + +endchoice + +config SYS_SOC + string + default "octeontx" + +config SYS_PCI_64BIT + bool + default y + +endif diff --git a/arch/arm/mach-octeontx/Makefile b/arch/arm/mach-octeontx/Makefile new file mode 100644 index 0000000000..20cb48ad92 --- /dev/null +++ b/arch/arm/mach-octeontx/Makefile @@ -0,0 +1,9 @@ +#/* SPDX-License-Identifier: GPL-2.0 +# * +# * Copyright (C) 2018 Marvell International Ltd. +# * +# * https://spdx.org/licenses +# */ + +obj-y += lowlevel_init.o clock.o cpu.o + diff --git a/arch/arm/mach-octeontx/clock.c b/arch/arm/mach-octeontx/clock.c new file mode 100644 index 0000000000..9da21077ec --- /dev/null +++ b/arch/arm/mach-octeontx/clock.c @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/board.h> +#include <asm/arch/clock.h> + +/** + * Returns the I/O clock speed in Hz + */ +u64 octeontx_get_io_clock(void) +{ + union rst_boot rst_boot; + + rst_boot.u = readq(RST_BOOT); + + return rst_boot.s.pnr_mul * PLL_REF_CLK; +} + +/** + * Returns the core clock speed in Hz + */ +u64 octeontx_get_core_clock(void) +{ + union rst_boot rst_boot; + + rst_boot.u = readq(RST_BOOT); + + return rst_boot.s.c_mul * PLL_REF_CLK; +} diff --git a/arch/arm/mach-octeontx/cpu.c b/arch/arm/mach-octeontx/cpu.c new file mode 100644 index 0000000000..9c29c31393 --- /dev/null +++ b/arch/arm/mach-octeontx/cpu.c @@ -0,0 +1,76 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <common.h> +#include <asm/armv8/mmu.h> +#include <asm/io.h> +#include <asm/arch/board.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define OTX_MEM_MAP_USED 3 + +/* 1 for 83xx, +1 is end of list which needs to be empty */ +#define OTX_MEM_MAP_MAX (OTX_MEM_MAP_USED + 1 + CONFIG_NR_DRAM_BANKS + 1) + +static struct mm_region otx_mem_map[OTX_MEM_MAP_MAX] = { + { + .virt = 0x800000000000UL, + .phys = 0x800000000000UL, + .size = 0x40000000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE + }, { + .virt = 0x840000000000UL, + .phys = 0x840000000000UL, + .size = 0x40000000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE + }, { + .virt = 0x880000000000UL, + .phys = 0x880000000000UL, + .size = 0x40000000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE + } + +}; + +struct mm_region *mem_map = otx_mem_map; + +void mem_map_fill(void) +{ + int banks = OTX_MEM_MAP_USED; + u32 dram_start = CONFIG_SYS_TEXT_BASE; + + if (otx_is_soc(CN83XX)) { + otx_mem_map[banks].virt = 0x8c0000000000UL; + otx_mem_map[banks].phys = 0x8c0000000000UL; + otx_mem_map[banks].size = 0x40000000000UL; + otx_mem_map[banks].attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE; + banks = banks + 1; + } + + for (int i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + otx_mem_map[banks].virt = dram_start; + otx_mem_map[banks].phys = dram_start; + otx_mem_map[banks].size = gd->ram_size; + otx_mem_map[banks].attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_NON_SHARE; + banks = banks + 1; + } +} + +u64 get_page_table_size(void) +{ + return 0x80000; +} + +void reset_cpu(ulong addr) +{ +} diff --git a/arch/arm/mach-octeontx/lowlevel_init.S b/arch/arm/mach-octeontx/lowlevel_init.S new file mode 100644 index 0000000000..41a9f08aed --- /dev/null +++ b/arch/arm/mach-octeontx/lowlevel_init.S @@ -0,0 +1,33 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/macro.h> + +.align 8 +.global fdt_base_addr +fdt_base_addr: + .dword 0x0 + +.global save_boot_params +save_boot_params: + /* Read FDT base from x1 register passed by ATF */ + adr x21, fdt_base_addr + str x1, [x21] + + /* Returns */ + b save_boot_params_ret + +ENTRY(lowlevel_init) + mov x29, lr /* Save LR */ + + /* any lowlevel init should go here */ + + mov lr, x29 /* Restore LR */ + ret +ENDPROC(lowlevel_init) diff --git a/board/Marvell/octeontx/Kconfig b/board/Marvell/octeontx/Kconfig new file mode 100644 index 0000000000..45d115916c --- /dev/null +++ b/board/Marvell/octeontx/Kconfig @@ -0,0 +1,14 @@ +if TARGET_OCTEONTX_81XX || TARGET_OCTEONTX_83XX + +config SYS_VENDOR + string + default "Marvell" + +config SYS_BOARD + string + default "octeontx" + +config SYS_CONFIG_NAME + default "octeontx_common" + +endif diff --git a/board/Marvell/octeontx/MAINTAINERS b/board/Marvell/octeontx/MAINTAINERS new file mode 100644 index 0000000000..1f3b12b1ab --- /dev/null +++ b/board/Marvell/octeontx/MAINTAINERS @@ -0,0 +1,8 @@ +OCTEONTX BOARD +M: Aaron Williams awilliams@marvell.com +S: Maintained +F: board/Marvell/octeontx/ +F: include/configs/octeontx_81xx.h +F: include/configs/octeontx_83xx.h +F: configs/octeontx_81xx_defconfig +F: configs/octeontx_83xx_defconfig diff --git a/board/Marvell/octeontx/Makefile b/board/Marvell/octeontx/Makefile new file mode 100644 index 0000000000..fbe32ae003 --- /dev/null +++ b/board/Marvell/octeontx/Makefile @@ -0,0 +1,9 @@ +#/* +# * Copyright (C) 2018 Marvell International Ltd. +# * +# * SPDX-License-Identifier: GPL-2.0 +# * https://spdx.org/licenses +# */ + +obj-y := board.o smc.o soc-utils.o +obj-$(CONFIG_OF_LIBFDT) += board-fdt.o diff --git a/board/Marvell/octeontx/board-fdt.c b/board/Marvell/octeontx/board-fdt.c new file mode 100644 index 0000000000..0b05ef11e9 --- /dev/null +++ b/board/Marvell/octeontx/board-fdt.c @@ -0,0 +1,311 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <errno.h> +#include <env.h> +#include <log.h> +#include <net.h> +#include <asm/io.h> +#include <linux/compiler.h> +#include <linux/libfdt.h> +#include <fdtdec.h> +#include <fdt_support.h> +#include <asm/arch/board.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +static int fdt_get_mdio_bus(const void *fdt, int phy_offset) +{ + int node, bus = -1; + const u64 *reg; + u64 addr; + + if (phy_offset < 0) + return -1; + /* obtain mdio node and get the reg prop */ + node = fdt_parent_offset(fdt, phy_offset); + if (node < 0) + return -1; + + reg = fdt_getprop(fdt, node, "reg", NULL); + addr = fdt64_to_cpu(*reg); + bus = (addr & (1 << 7)) ? 1 : 0; + return bus; +} + +static int fdt_get_phy_addr(const void *fdt, int phy_offset) +{ + const u32 *reg; + int addr = -1; + + if (phy_offset < 0) + return -1; + reg = fdt_getprop(fdt, phy_offset, "reg", NULL); + addr = fdt32_to_cpu(*reg); + return addr; +} + +void fdt_parse_phy_info(void) +{ + const void *fdt = gd->fdt_blob; + int offset = 0, node, bgx_id = 0, lmacid = 0; + const u32 *val; + char bgxname[24]; + int len, rgx_id = 0, eth_id = 0; + int phandle, phy_offset; + int subnode, i; + int bdknode; + + bdknode = fdt_path_offset(fdt, "/cavium,bdk"); + if (bdknode < 0) { + printf("%s: bdk node is missing from device tree: %s\n", + __func__, fdt_strerror(bdknode)); + } + + offset = fdt_node_offset_by_compatible(fdt, -1, "pci-bridge"); + if (offset < 1) + return; + + for (bgx_id = 0; bgx_id < MAX_BGX_PER_NODE; bgx_id++) { + int phy_addr[LMAC_CNT] = {[0 ... LMAC_CNT - 1] = -1}; + bool autoneg_dis[LMAC_CNT] = {[0 ... LMAC_CNT - 1] = 0}; + int mdio_bus[LMAC_CNT] = {[0 ... LMAC_CNT - 1] = -1}; + bool lmac_reg[LMAC_CNT] = {[0 ... LMAC_CNT - 1] = 0}; + bool lmac_enable[LMAC_CNT] = {[0 ... LMAC_CNT - 1] = 0}; + + snprintf(bgxname, sizeof(bgxname), "bgx%d", bgx_id); + node = fdt_subnode_offset(fdt, offset, bgxname); + if (node < 0) { + /* check if it is rgx node */ + snprintf(bgxname, sizeof(bgxname), "rgx%d", rgx_id); + node = fdt_subnode_offset(fdt, offset, bgxname); + if (node < 0) { + debug("bgx%d/rgx0 node not found\n", bgx_id); + return; + } + } + debug("bgx%d node found\n", bgx_id); + + /* + * loop through each of the bgx/rgx nodes + * to find PHY nodes + */ + fdt_for_each_subnode(subnode, fdt, node) { + /* Check for reg property */ + val = fdt_getprop(fdt, subnode, "reg", &len); + if (val) { + debug("lmacid = %d\n", lmacid); + lmac_reg[lmacid] = 1; + } + /* check for phy-handle property */ + val = fdt_getprop(fdt, subnode, "phy-handle", &len); + if (val) { + phandle = fdt32_to_cpu(*val); + if (!phandle) { + debug("phandle not valid %d\n", lmacid); + } else { + phy_offset = fdt_node_offset_by_phandle + (fdt, phandle); + phy_addr[lmacid] = fdt_get_phy_addr + (fdt, phy_offset); + mdio_bus[lmacid] = fdt_get_mdio_bus + (fdt, phy_offset); + } + } else { + debug("phy-handle prop not found %d\n", + lmacid); + } + /* check for autonegotiation property */ + val = fdt_getprop(fdt, subnode, + "cavium,disable-autonegotiation", + &len); + if (val) + autoneg_dis[lmacid] = 1; + + eth_id++; + lmacid++; + } + + for (i = 0; i < MAX_LMAC_PER_BGX; i++) { + const char *str; + + snprintf(bgxname, sizeof(bgxname), + "BGX-ENABLE.N0.BGX%d.P%d", bgx_id, i); + if (bdknode >= 0) { + str = fdt_getprop(fdt, bdknode, + bgxname, &len); + if (str) + lmac_enable[i] = + simple_strtol(str, NULL, + 10); + } + } + + lmacid = 0; + bgx_set_board_info(bgx_id, mdio_bus, phy_addr, + autoneg_dis, lmac_reg, lmac_enable); + } +} + +static int fdt_get_bdk_node(void) +{ + int node, ret; + const void *fdt = gd->fdt_blob; + + if (!fdt) { + printf("ERROR: %s: no valid device tree found\n", __func__); + return 0; + } + + ret = fdt_check_header(fdt); + if (ret < 0) { + printf("fdt: %s\n", fdt_strerror(ret)); + return 0; + } + + node = fdt_path_offset(fdt, "/cavium,bdk"); + if (node < 0) { + printf("%s: /cavium,bdk is missing from device tree: %s\n", + __func__, fdt_strerror(node)); + return 0; + } + return node; +} + +const char *fdt_get_board_serial(void) +{ + const void *fdt = gd->fdt_blob; + int node, len = 64; + const char *str = NULL; + + node = fdt_get_bdk_node(); + if (!node) + return NULL; + + str = fdt_getprop(fdt, node, "BOARD-SERIAL", &len); + if (!str) + printf("Error: cannot retrieve board serial from fdt\n"); + return str; +} + +const char *fdt_get_board_revision(void) +{ + const void *fdt = gd->fdt_blob; + int node, len = 64; + const char *str = NULL; + + node = fdt_get_bdk_node(); + if (!node) + return NULL; + + str = fdt_getprop(fdt, node, "BOARD-REVISION", &len); + if (!str) + printf("Error: cannot retrieve board revision from fdt\n"); + return str; +} + +const char *fdt_get_board_model(void) +{ + const void *fdt = gd->fdt_blob; + int node, len = 16; + const char *str = NULL; + + node = fdt_get_bdk_node(); + if (!node) + return NULL; + + str = fdt_getprop(fdt, node, "BOARD-MODEL", &len); + if (!str) + printf("Error: cannot retrieve board model from fdt\n"); + return str; +} + +void fdt_board_get_ethaddr(int bgx, int lmac, unsigned char *eth) +{ + const void *fdt = gd->fdt_blob; + const char *mac = NULL; + int offset = 0, node, len; + int subnode, i = 0; + char bgxname[24]; + + offset = fdt_node_offset_by_compatible(fdt, -1, "pci-bridge"); + if (offset < 0) { + printf("%s couldn't find mrml bridge node in fdt\n", + __func__); + return; + } + if (bgx == 2 && otx_is_soc(CN81XX)) { + snprintf(bgxname, sizeof(bgxname), "rgx%d", 0); + lmac = 0; + } else { + snprintf(bgxname, sizeof(bgxname), "bgx%d", bgx); + } + + node = fdt_subnode_offset(fdt, offset, bgxname); + + fdt_for_each_subnode(subnode, fdt, node) { + if (i++ != lmac) + continue; + /* check for local-mac-address */ + mac = fdt_getprop(fdt, subnode, "local-mac-address", &len); + if (mac) { + debug("%s mac %pM\n", __func__, mac); + memcpy(eth, mac, ARP_HLEN); + } else { + memset(eth, 0, ARP_HLEN); + } + debug("%s eth %pM\n", __func__, eth); + return; + } +} + +int arch_fixup_memory_node(void *blob) +{ + return 0; +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + /* remove "cavium, bdk" node from DT */ + int ret = 0, offset; + + ret = fdt_check_header(blob); + if (ret < 0) { + printf("ERROR: %s\n", fdt_strerror(ret)); + return ret; + } + + if (blob) { + offset = fdt_path_offset(blob, "/cavium,bdk"); + if (offset < 0) { + printf("ERROR: FDT BDK node not found\n"); + return offset; + } + + /* delete node */ + ret = fdt_del_node(blob, offset); + if (ret < 0) { + printf("WARNING : could not remove bdk node\n"); + return ret; + } + + debug("%s deleted bdk node\n", __func__); + } + + return 0; +} + +/** + * Return the FDT base address that was passed by ATF + * + * @return FDT base address received from ATF in x1 register + */ +void *board_fdt_blob_setup(void) +{ + return (void *)fdt_base_addr; +} diff --git a/board/Marvell/octeontx/board.c b/board/Marvell/octeontx/board.c new file mode 100644 index 0000000000..940faacbe3 --- /dev/null +++ b/board/Marvell/octeontx/board.c @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <dm.h> +#include <malloc.h> +#include <errno.h> +#include <env.h> +#include <init.h> +#include <log.h> +#include <netdev.h> +#include <pci_ids.h> +#include <asm/io.h> +#include <linux/compiler.h> +#include <linux/libfdt.h> +#include <fdt_support.h> +#include <asm/arch/smc.h> +#include <asm/arch/soc.h> +#include <asm/arch/board.h> +#include <dm/util.h> + +DECLARE_GLOBAL_DATA_PTR; + +void octeontx_cleanup_ethaddr(void) +{ + char ename[32]; + + for (int i = 0; i < 20; i++) { + sprintf(ename, i ? "eth%daddr" : "ethaddr", i); + if (env_get(ename)) + env_set(ename, NULL); + } +} + +int octeontx_board_has_pmp(void) +{ + return (otx_is_board("sff8104") || otx_is_board("nas8104")); +} + +int board_early_init_r(void) +{ + pci_init(); + return 0; +} + +int board_init(void) +{ + if (IS_ENABLED(CONFIG_NET_OCTEONTX)) + fdt_parse_phy_info(); + + return 0; +} + +int timer_init(void) +{ + return 0; +} + +int dram_init(void) +{ + gd->ram_size = smc_dram_size(0); + gd->ram_size -= CONFIG_SYS_SDRAM_BASE; + mem_map_fill(); + + return 0; +} + +void board_late_probe_devices(void) +{ + struct udevice *dev; + int err, bgx_cnt, i; + + /* Probe MAC(BGX) and NIC PF devices before Network stack init */ + bgx_cnt = otx_is_soc(CN81XX) ? 2 : 4; + for (i = 0; i < bgx_cnt; i++) { + err = dm_pci_find_device(PCI_VENDOR_ID_CAVIUM, + PCI_DEVICE_ID_CAVIUM_BGX, i, &dev); + if (err) + debug("%s BGX%d device not found\n", __func__, i); + } + if (otx_is_soc(CN81XX)) { + err = dm_pci_find_device(PCI_VENDOR_ID_CAVIUM, + PCI_DEVICE_ID_CAVIUM_RGX, 0, &dev); + if (err) + debug("%s RGX device not found\n", __func__); + } + err = dm_pci_find_device(PCI_VENDOR_ID_CAVIUM, + PCI_DEVICE_ID_CAVIUM_NIC, 0, &dev); + if (err) + debug("NIC PF device not found\n"); +} + +/** + * Board late initialization routine. + */ +int board_late_init(void) +{ + char boardname[32]; + char boardserial[150], boardrev[150]; + bool save_env = false; + const char *str; + + /* + * Try to cleanup ethaddr env variables, this is needed + * as with each boot, configuration of network interfaces can change. + */ + octeontx_cleanup_ethaddr(); + + snprintf(boardname, sizeof(boardname), "%s> ", fdt_get_board_model()); + env_set("prompt", boardname); + + set_working_fdt_addr(env_get_hex("fdtcontroladdr", fdt_base_addr)); + + str = fdt_get_board_revision(); + if (str) { + snprintf(boardrev, sizeof(boardrev), "%s", str); + if (env_get("boardrev") && + strcmp(boardrev, env_get("boardrev"))) + save_env = true; + env_set("boardrev", boardrev); + } + + str = fdt_get_board_serial(); + if (str) { + snprintf(boardserial, sizeof(boardserial), "%s", str); + if (env_get("serial#") && + strcmp(boardserial, env_get("serial#"))) + save_env = true; + env_set("serial#", boardserial); + } + + if (IS_ENABLED(CONFIG_NET_OCTEONTX)) + board_late_probe_devices(); + + if (save_env) + env_save(); + + return 0; +} + +/* + * Invoked before relocation, so limit to stack variables. + */ +int checkboard(void) +{ + printf("Board: %s\n", fdt_get_board_model()); + + return 0; +} diff --git a/board/Marvell/octeontx/smc.c b/board/Marvell/octeontx/smc.c new file mode 100644 index 0000000000..5eeba2358b --- /dev/null +++ b/board/Marvell/octeontx/smc.c @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <asm/global_data.h> +#include <asm/ptrace.h> +#include <asm/system.h> +#include <asm/arch/smc.h> + +DECLARE_GLOBAL_DATA_PTR; + +ssize_t smc_dram_size(unsigned int node) +{ + struct pt_regs regs; + + regs.regs[0] = OCTEONTX_DRAM_SIZE; + regs.regs[1] = node; + smc_call(®s); + + return regs.regs[0]; +} + diff --git a/board/Marvell/octeontx/soc-utils.c b/board/Marvell/octeontx/soc-utils.c new file mode 100644 index 0000000000..5fd5afd48d --- /dev/null +++ b/board/Marvell/octeontx/soc-utils.c @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <dm.h> +#include <dm/util.h> +#include <errno.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/arch/soc.h> +#include <asm/arch/board.h> + +int read_platform(void) +{ + int plat = PLATFORM_HW; + + const char *model = fdt_get_board_model(); + + if (model && !strncmp(model, "ASIM-", 5)) + plat = PLATFORM_ASIM; + if (model && !strncmp(model, "EMUL-", 5)) + plat = PLATFORM_EMULATOR; + return plat; +} + +static inline u64 read_midr(void) +{ + u64 result; + + asm ("mrs %[rd],MIDR_EL1" : [rd] "=r" (result)); + return result; +} + +u8 read_partnum(void) +{ + return ((read_midr() >> 4) & 0xFF); +} + +const char *read_board_name(void) +{ + return fdt_get_board_model(); +} + +bool read_alt_pkg(void) +{ + return false; +} diff --git a/configs/octeontx_81xx_defconfig b/configs/octeontx_81xx_defconfig new file mode 100644 index 0000000000..daf15cc0fb --- /dev/null +++ b/configs/octeontx_81xx_defconfig @@ -0,0 +1,134 @@ +CONFIG_ARM=y +# CONFIG_ARM64_SUPPORT_AARCH32 is not set +CONFIG_ARCH_OCTEONTX=y +CONFIG_SYS_TEXT_BASE=0x2800000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_OFFSET=0xF00000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_TARGET_OCTEONTX_81XX=y +CONFIG_DM_GPIO=y +CONFIG_DEBUG_UART_BASE=0x87e028000000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200n8 earlycon=pl011,0x87e028000000 maxcpus=4 rootwait rw root=/dev/sda2 coherent_pool=16M" +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="Marvell> " +# CONFIG_CMD_BOOTEFI_HELLO_COMPILE is not set +CONFIG_CMD_MD5SUM=y +CONFIG_MD5SUM_VERIFY=y +CONFIG_CMD_MX_CYCLIC=y +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_MEMTEST_START=0x2800000 +CONFIG_SYS_MEMTEST_END=0x28f0000 +CONFIG_CMD_SHA1SUM=y +CONFIG_SHA1SUM_VERIFY=y +CONFIG_CMD_DM=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TFTPSRV=y +CONFIG_CMD_RARP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CDP=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_PXE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_OF_BOARD=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=0 +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=0 +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=16000000 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0x0 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_OCTEONTX=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OCTEONTX=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0x0 +CONFIG_SF_DEFAULT_SPEED=16000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_BROADCOM=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_E1000=y +CONFIG_E1000_SPI=y +CONFIG_CMD_E1000=y +CONFIG_NET_OCTEONTX=y +CONFIG_OCTEONTX_SMI=y +CONFIG_NVME=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_REGION_MULTI_ENTRY=y +CONFIG_PCI_SRIOV=y +CONFIG_PCI_ARID=y +CONFIG_PCI_OCTEONTX=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_PL01X_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_PCI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_WDT=y +CONFIG_ERRNO_STR=y diff --git a/configs/octeontx_83xx_defconfig b/configs/octeontx_83xx_defconfig new file mode 100644 index 0000000000..e8cacb859f --- /dev/null +++ b/configs/octeontx_83xx_defconfig @@ -0,0 +1,129 @@ +CONFIG_ARM=y +# CONFIG_ARM64_SUPPORT_AARCH32 is not set +CONFIG_ARCH_OCTEONTX=y +CONFIG_SYS_TEXT_BASE=0x2800000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_OFFSET=0xF00000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_TARGET_OCTEONTX_83XX=y +CONFIG_DM_GPIO=y +CONFIG_DEBUG_UART_BASE=0x87e028000000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200n8 earlycon=pl011,0x87e028000000 maxcpus=24 rootwait rw root=/dev/sda2 coherent_pool=16M" +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="Marvell> " +# CONFIG_CMD_BOOTEFI_HELLO_COMPILE is not set +CONFIG_CMD_MD5SUM=y +CONFIG_MD5SUM_VERIFY=y +CONFIG_CMD_MX_CYCLIC=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SHA1SUM=y +CONFIG_SHA1SUM_VERIFY=y +CONFIG_CMD_DM=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TFTPSRV=y +CONFIG_CMD_RARP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CDP=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_PXE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_OF_BOARD=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=0 +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=0 +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=16000000 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0x0 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_OCTEONTX=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0x0 +CONFIG_SF_DEFAULT_SPEED=16000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_BROADCOM=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_E1000=y +CONFIG_E1000_SPI=y +CONFIG_CMD_E1000=y +CONFIG_NET_OCTEONTX=y +CONFIG_OCTEONTX_SMI=y +CONFIG_NVME=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_REGION_MULTI_ENTRY=y +CONFIG_PCI_SRIOV=y +CONFIG_PCI_ARID=y +CONFIG_PCI_OCTEONTX=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_PL01X_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_PCI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_WDT=y +CONFIG_ERRNO_STR=y diff --git a/drivers/mtd/nand/raw/octeontx_bch.c b/drivers/mtd/nand/raw/octeontx_bch.c index c38cbb9526..0ac432a029 100644 --- a/drivers/mtd/nand/raw/octeontx_bch.c +++ b/drivers/mtd/nand/raw/octeontx_bch.c @@ -5,16 +5,17 @@ * https://spdx.org/licenses */
-#include <common.h> +#include <dm.h> +#include <dm/of_access.h> #include <malloc.h> #include <memalign.h> #include <pci.h> #include <pci_ids.h> #include <nand.h> -#include <dm.h> -#include <dm/of_access.h> +#include <time.h> #include <linux/bitfield.h> #include <linux/ctype.h> +#include <linux/delay.h> #include <linux/errno.h> #include <linux/err.h> #include <linux/ioport.h> diff --git a/drivers/mtd/nand/raw/octeontx_nand.c b/drivers/mtd/nand/raw/octeontx_nand.c index 847e9f9c58..b2f55f1143 100644 --- a/drivers/mtd/nand/raw/octeontx_nand.c +++ b/drivers/mtd/nand/raw/octeontx_nand.c @@ -5,18 +5,19 @@ * https://spdx.org/licenses */
-#include <common.h> -#include <malloc.h> -#include <memalign.h> -#include <pci.h> -#include <nand.h> #include <dm.h> #include <dm/of_access.h> #include <dm/devres.h> #include <dm/device-internal.h> +#include <malloc.h> +#include <memalign.h> +#include <pci.h> +#include <nand.h> +#include <time.h> #include <linux/bitfield.h> #include <linux/ctype.h> #include <linux/dma-mapping.h> +#include <linux/delay.h> #include <linux/errno.h> #include <linux/err.h> #include <linux/ioport.h> diff --git a/drivers/net/octeontx/bgx.c b/drivers/net/octeontx/bgx.c index e08ca71058..0fdf9723c2 100644 --- a/drivers/net/octeontx/bgx.c +++ b/drivers/net/octeontx/bgx.c @@ -6,7 +6,6 @@ */
#include <config.h> -#include <common.h> #include <errno.h> #include <net.h> #include <dm.h> @@ -18,6 +17,7 @@ #include <miiphy.h> #include <asm/io.h> #include <asm/arch/board.h> +#include <linux/delay.h>
#ifdef CONFIG_OF_LIBFDT #include <linux/libfdt.h> diff --git a/drivers/net/octeontx/nic_main.c b/drivers/net/octeontx/nic_main.c index 799b4d70e2..faf13126d5 100644 --- a/drivers/net/octeontx/nic_main.c +++ b/drivers/net/octeontx/nic_main.c @@ -6,7 +6,6 @@ */
#include <config.h> -#include <common.h> #include <net.h> #include <netdev.h> #include <malloc.h> @@ -16,6 +15,7 @@ #include <pci.h> #include <pci_ids.h> #include <asm/io.h> +#include <linux/delay.h>
#include "nic_reg.h" #include "nic.h" diff --git a/drivers/net/octeontx/nicvf_main.c b/drivers/net/octeontx/nicvf_main.c index 3d90ecc735..e4af9f90ed 100644 --- a/drivers/net/octeontx/nicvf_main.c +++ b/drivers/net/octeontx/nicvf_main.c @@ -6,7 +6,6 @@ */
#include <config.h> -#include <common.h> #include <dm.h> #include <pci.h> #include <pci_ids.h> @@ -14,6 +13,7 @@ #include <misc.h> #include <malloc.h> #include <asm/io.h> +#include <linux/delay.h>
#include "nic_reg.h" #include "nic.h" diff --git a/drivers/net/octeontx/nicvf_queues.c b/drivers/net/octeontx/nicvf_queues.c index 96d9b90d4c..80a94937e7 100644 --- a/drivers/net/octeontx/nicvf_queues.c +++ b/drivers/net/octeontx/nicvf_queues.c @@ -6,11 +6,11 @@ */
#include <config.h> -#include <common.h> #include <cpu_func.h> #include <net.h> #include <dm/device.h> #include <malloc.h> +#include <linux/delay.h>
#include "nic_reg.h" #include "nic.h" diff --git a/drivers/net/octeontx/smi.c b/drivers/net/octeontx/smi.c index bf99aca341..59294e25c7 100644 --- a/drivers/net/octeontx/smi.c +++ b/drivers/net/octeontx/smi.c @@ -5,7 +5,6 @@ * https://spdx.org/licenses */
-#include <common.h> #include <dm.h> #include <pci.h> #include <pci_ids.h> @@ -16,6 +15,7 @@ #include <asm/io.h> #include <env.h> #include <linux/ctype.h> +#include <linux/delay.h>
#define PCI_DEVICE_ID_OCTEONTX_SMI 0xA02B
diff --git a/drivers/net/octeontx/xcv.c b/drivers/net/octeontx/xcv.c index 1186157485..5c7974f8fd 100644 --- a/drivers/net/octeontx/xcv.c +++ b/drivers/net/octeontx/xcv.c @@ -6,7 +6,6 @@ */
#include <config.h> -#include <common.h> #include <errno.h> #include <net.h> #include <dm.h> @@ -16,6 +15,7 @@ #include <malloc.h> #include <miiphy.h> #include <asm/io.h> +#include <linux/delay.h>
#ifdef CONFIG_OF_LIBFDT #include <linux/libfdt.h> diff --git a/include/configs/octeontx_common.h b/include/configs/octeontx_common.h new file mode 100644 index 0000000000..b66aa8b54e --- /dev/null +++ b/include/configs/octeontx_common.h @@ -0,0 +1,89 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __OCTEONTX_COMMON_H__ +#define __OCTEONTX_COMMON_H__ + +#define CONFIG_SUPPORT_RAW_INITRD + +/** Maximum size of image supported for bootm (and bootable FIT images) */ +#define CONFIG_SYS_BOOTM_LEN (256 << 20) + +/** Memory base address */ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_TEXT_BASE + +/** Stack starting address */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0xffff0) + +/** Heap size for U-Boot */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 64 * 1024 * 1024) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + +/* Allow environment variable to be overwritten */ +#define CONFIG_ENV_OVERWRITE + +/** Reduce hashes printed out */ +#define CONFIG_TFTP_TSIZE + +/* Autoboot options */ +#define CONFIG_RESET_TO_RETRY +#define CONFIG_BOOT_RETRY_TIME -1 +#define CONFIG_BOOT_RETRY_MIN 30 + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE + +/* AHCI support Definitions */ +#ifdef CONFIG_DM_SCSI +/** Enable 48-bit SATA addressing */ +# define CONFIG_LBA48 +/** Enable 64-bit addressing */ +# define CONFIG_SYS_64BIT_LBA +#endif + +/***** SPI Defines *********/ +#ifdef CONFIG_DM_SPI_FLASH +# define CONFIG_SF_DEFAULT_BUS 0 +# define CONFIG_SF_DEFAULT_CS 0 +#endif + +/** Extra environment settings */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=20080000\0" \ + "autoload=0\0" + +/** Environment defines */ +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#endif + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /** Console I/O Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MAXARGS 64 /** max command args */ + +#define CONFIG_SYS_MMC_MAX_BLK_COUNT 8192 + +#undef CONFIG_SYS_PROMPT +#define CONFIG_SYS_PROMPT env_get("prompt") + +/** EMMC specific defines */ +#if defined(CONFIG_MMC_OCTEONTX) +#define CONFIG_SUPPORT_EMMC_BOOT +#define CONFIG_SUPPORT_EMMC_RPMB +#define CONFIG_CMD_BKOPS_ENABLE +#endif + +#if defined(CONFIG_NAND_OCTEONTX) +/*#define CONFIG_MTD_CONCAT */ +#define CONFIG_SYS_MAX_NAND_DEVICE 8 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#endif + +#endif /* __OCTEONTX_COMMON_H__ */
This patch adds support for all OcteonTX2 96xx/95xx boards from Marvell. For 96xx boards, use octeontx_96xx_defconfig and for 95xx boards, use octeontx_95xx_defconfig.
Changes in v1: - Changed patch subject - Rebased on latest TOT - Removed inclusion of common.h - Moved MEMTEST defines to Kconfig - *.c files checkpatch cleanup - Add go_uboot cmd for U-Boot starting from RAM
arch/arm/Kconfig | 14 ++ arch/arm/Makefile | 1 + arch/arm/mach-octeontx2/Kconfig | 23 +++ arch/arm/mach-octeontx2/Makefile | 9 + arch/arm/mach-octeontx2/clock.c | 35 ++++ arch/arm/mach-octeontx2/config.mk | 4 + arch/arm/mach-octeontx2/cpu.c | 72 +++++++ arch/arm/mach-octeontx2/lowlevel_init.S | 33 ++++ board/Marvell/octeontx2/Kconfig | 14 ++ board/Marvell/octeontx2/MAINTAINERS | 8 + board/Marvell/octeontx2/Makefile | 9 + board/Marvell/octeontx2/board-fdt.c | 221 +++++++++++++++++++++ board/Marvell/octeontx2/board.c | 247 ++++++++++++++++++++++++ board/Marvell/octeontx2/smc.c | 58 ++++++ board/Marvell/octeontx2/soc-utils.c | 49 +++++ configs/octeontx2_95xx_defconfig | 105 ++++++++++ configs/octeontx2_96xx_defconfig | 131 +++++++++++++ include/configs/octeontx2_common.h | 72 +++++++ 18 files changed, 1105 insertions(+) create mode 100644 arch/arm/mach-octeontx2/Kconfig create mode 100644 arch/arm/mach-octeontx2/Makefile create mode 100644 arch/arm/mach-octeontx2/clock.c create mode 100644 arch/arm/mach-octeontx2/config.mk create mode 100644 arch/arm/mach-octeontx2/cpu.c create mode 100644 arch/arm/mach-octeontx2/lowlevel_init.S create mode 100644 board/Marvell/octeontx2/Kconfig create mode 100644 board/Marvell/octeontx2/MAINTAINERS create mode 100644 board/Marvell/octeontx2/Makefile create mode 100644 board/Marvell/octeontx2/board-fdt.c create mode 100644 board/Marvell/octeontx2/board.c create mode 100644 board/Marvell/octeontx2/smc.c create mode 100644 board/Marvell/octeontx2/soc-utils.c create mode 100644 configs/octeontx2_95xx_defconfig create mode 100644 configs/octeontx2_96xx_defconfig create mode 100644 include/configs/octeontx2_common.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 869d255347..bb219a8058 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1733,6 +1733,16 @@ config ARCH_OCTEONTX select OF_LIVE select BOARD_LATE_INIT select SYS_CACHE_SHIFT_7 + +config ARCH_OCTEONTX2 + bool "Support OcteonTX2 SoCs" + select DM + select ARM64 + select OF_CONTROL + select OF_LIVE + select BOARD_LATE_INIT + select SYS_CACHE_SHIFT_7 + config TARGET_THUNDERX_88XX bool "Support ThunderX 88xx" select ARM64 @@ -1832,6 +1842,9 @@ source "arch/arm/mach-lpc32xx/Kconfig" source "arch/arm/mach-mvebu/Kconfig"
source "arch/arm/mach-octeontx/Kconfig" + +source "arch/arm/mach-octeontx2/Kconfig" + source "arch/arm/cpu/armv7/ls102xa/Kconfig"
source "arch/arm/mach-imx/mx2/Kconfig" @@ -1916,6 +1929,7 @@ source "board/CarMediaLab/flea3/Kconfig" source "board/Marvell/aspenite/Kconfig" source "board/Marvell/gplugd/Kconfig" source "board/Marvell/octeontx/Kconfig" +source "board/Marvell/octeontx2/Kconfig" source "board/armadeus/apf27/Kconfig" source "board/armltd/vexpress/Kconfig" source "board/armltd/vexpress64/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 87b4198312..28b523b37c 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -81,6 +81,7 @@ machine-$(CONFIG_ARCH_SUNXI) += sunxi machine-$(CONFIG_ARCH_TEGRA) += tegra machine-$(CONFIG_ARCH_U8500) += u8500 machine-$(CONFIG_ARCH_OCTEONTX) += octeontx +machine-$(CONFIG_ARCH_OCTEONTX2) += octeontx2 machine-$(CONFIG_ARCH_UNIPHIER) += uniphier machine-$(CONFIG_ARCH_VERSAL) += versal machine-$(CONFIG_ARCH_ZYNQ) += zynq diff --git a/arch/arm/mach-octeontx2/Kconfig b/arch/arm/mach-octeontx2/Kconfig new file mode 100644 index 0000000000..8e5cb0f638 --- /dev/null +++ b/arch/arm/mach-octeontx2/Kconfig @@ -0,0 +1,23 @@ +if ARCH_OCTEONTX2 + +choice + prompt "OcteonTX2 board select" + optional + +config TARGET_OCTEONTX2_95XX + bool "Marvell OcteonTX2 CN95XX" + +config TARGET_OCTEONTX2_96XX + bool "Marvell OcteonTX2 CN96XX" + +endchoice + +config SYS_SOC + string + default "octeontx2" + +config SYS_PCI_64BIT + bool + default y + +endif diff --git a/arch/arm/mach-octeontx2/Makefile b/arch/arm/mach-octeontx2/Makefile new file mode 100644 index 0000000000..c3192343dd --- /dev/null +++ b/arch/arm/mach-octeontx2/Makefile @@ -0,0 +1,9 @@ +#/* +# * Copyright (C) 2018 Marvell International Ltd. +# * +# * SPDX-License-Identifier: GPL-2.0 +# * https://spdx.org/licenses +# */ + +obj-y += lowlevel_init.o clock.o cpu.o + diff --git a/arch/arm/mach-octeontx2/clock.c b/arch/arm/mach-octeontx2/clock.c new file mode 100644 index 0000000000..9da21077ec --- /dev/null +++ b/arch/arm/mach-octeontx2/clock.c @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/board.h> +#include <asm/arch/clock.h> + +/** + * Returns the I/O clock speed in Hz + */ +u64 octeontx_get_io_clock(void) +{ + union rst_boot rst_boot; + + rst_boot.u = readq(RST_BOOT); + + return rst_boot.s.pnr_mul * PLL_REF_CLK; +} + +/** + * Returns the core clock speed in Hz + */ +u64 octeontx_get_core_clock(void) +{ + union rst_boot rst_boot; + + rst_boot.u = readq(RST_BOOT); + + return rst_boot.s.c_mul * PLL_REF_CLK; +} diff --git a/arch/arm/mach-octeontx2/config.mk b/arch/arm/mach-octeontx2/config.mk new file mode 100644 index 0000000000..9214f6b742 --- /dev/null +++ b/arch/arm/mach-octeontx2/config.mk @@ -0,0 +1,4 @@ +ifeq ($(CONFIG_ARCH_OCTEONTX2),y) +PLATFORM_CPPFLAGS += $(call cc-option,-march=armv8.2-a,) +PLATFORM_CPPFLAGS += $(call cc-option,-mtune=octeontx2,) +endif diff --git a/arch/arm/mach-octeontx2/cpu.c b/arch/arm/mach-octeontx2/cpu.c new file mode 100644 index 0000000000..2a6d5e8661 --- /dev/null +++ b/arch/arm/mach-octeontx2/cpu.c @@ -0,0 +1,72 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <common.h> +#include <asm/armv8/mmu.h> +#include <asm/io.h> +#include <asm/arch/board.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define OTX2_MEM_MAP_USED 4 + +/* +1 is end of list which needs to be empty */ +#define OTX2_MEM_MAP_MAX (OTX2_MEM_MAP_USED + CONFIG_NR_DRAM_BANKS + 1) + +static struct mm_region otx2_mem_map[OTX2_MEM_MAP_MAX] = { + { + .virt = 0x800000000000UL, + .phys = 0x800000000000UL, + .size = 0x40000000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE + }, { + .virt = 0x840000000000UL, + .phys = 0x840000000000UL, + .size = 0x40000000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE + }, { + .virt = 0x880000000000UL, + .phys = 0x880000000000UL, + .size = 0x40000000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE + }, { + .virt = 0x8c0000000000UL, + .phys = 0x8c0000000000UL, + .size = 0x40000000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE + } +}; + +struct mm_region *mem_map = otx2_mem_map; + +void mem_map_fill(void) +{ + int banks = OTX2_MEM_MAP_USED; + u32 dram_start = CONFIG_SYS_TEXT_BASE; + + for (int i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + otx2_mem_map[banks].virt = dram_start; + otx2_mem_map[banks].phys = dram_start; + otx2_mem_map[banks].size = gd->ram_size; + otx2_mem_map[banks].attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_NON_SHARE; + banks = banks + 1; + } +} + +u64 get_page_table_size(void) +{ + return 0x80000; +} + +void reset_cpu(ulong addr) +{ +} diff --git a/arch/arm/mach-octeontx2/lowlevel_init.S b/arch/arm/mach-octeontx2/lowlevel_init.S new file mode 100644 index 0000000000..41a9f08aed --- /dev/null +++ b/arch/arm/mach-octeontx2/lowlevel_init.S @@ -0,0 +1,33 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/macro.h> + +.align 8 +.global fdt_base_addr +fdt_base_addr: + .dword 0x0 + +.global save_boot_params +save_boot_params: + /* Read FDT base from x1 register passed by ATF */ + adr x21, fdt_base_addr + str x1, [x21] + + /* Returns */ + b save_boot_params_ret + +ENTRY(lowlevel_init) + mov x29, lr /* Save LR */ + + /* any lowlevel init should go here */ + + mov lr, x29 /* Restore LR */ + ret +ENDPROC(lowlevel_init) diff --git a/board/Marvell/octeontx2/Kconfig b/board/Marvell/octeontx2/Kconfig new file mode 100644 index 0000000000..99291d795b --- /dev/null +++ b/board/Marvell/octeontx2/Kconfig @@ -0,0 +1,14 @@ +if TARGET_OCTEONTX2_95XX || TARGET_OCTEONTX2_96XX + +config SYS_VENDOR + string + default "Marvell" + +config SYS_BOARD + string + default "octeontx2" + +config SYS_CONFIG_NAME + default "octeontx2_common" + +endif diff --git a/board/Marvell/octeontx2/MAINTAINERS b/board/Marvell/octeontx2/MAINTAINERS new file mode 100644 index 0000000000..eec1d77dd1 --- /dev/null +++ b/board/Marvell/octeontx2/MAINTAINERS @@ -0,0 +1,8 @@ +OCTEONTX2 BOARD +M: Aaron Williams awilliams@marvell.com +S: Maintained +F: board/Marvell/octeontx2/ +F: include/configs/octeontx2_96xx.h +F: include/configs/octeontx2_95xx.h +F: configs/octeontx2_96xx_defconfig +F: configs/octeontx2_95xx_defconfig diff --git a/board/Marvell/octeontx2/Makefile b/board/Marvell/octeontx2/Makefile new file mode 100644 index 0000000000..1f763b197b --- /dev/null +++ b/board/Marvell/octeontx2/Makefile @@ -0,0 +1,9 @@ +#/* SPDX-License-Identifier: GPL-2.0 +# * +# * Copyright (C) 2018 Marvell International Ltd. +# * +# * https://spdx.org/licenses +# */ + +obj-y := board.o smc.o soc-utils.o +obj-$(CONFIG_OF_LIBFDT) += board-fdt.o diff --git a/board/Marvell/octeontx2/board-fdt.c b/board/Marvell/octeontx2/board-fdt.c new file mode 100644 index 0000000000..a4771af4c1 --- /dev/null +++ b/board/Marvell/octeontx2/board-fdt.c @@ -0,0 +1,221 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <errno.h> +#include <fdtdec.h> +#include <fdt_support.h> +#include <log.h> + +#include <linux/compiler.h> +#include <linux/libfdt.h> + +#include <asm/arch/board.h> +#include <asm/arch/smc.h> +#include <asm/global_data.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +static int fdt_get_bdk_node(void) +{ + int node, ret; + const void *fdt = gd->fdt_blob; + + if (!fdt) { + printf("ERROR: %s: no valid device tree found\n", __func__); + return 0; + } + + ret = fdt_check_header(fdt); + if (ret < 0) { + printf("fdt: %s\n", fdt_strerror(ret)); + return 0; + } + + node = fdt_path_offset(fdt, "/cavium,bdk"); + if (node < 0) { + printf("%s: /cavium,bdk is missing from device tree: %s\n", + __func__, fdt_strerror(node)); + return 0; + } + return node; +} + +u64 fdt_get_board_mac_addr(void) +{ + int node, len = 16; + const char *str = NULL; + const void *fdt = gd->fdt_blob; + u64 mac_addr = 0; + + node = fdt_get_bdk_node(); + if (!node) + return mac_addr; + str = fdt_getprop(fdt, node, "BOARD-MAC-ADDRESS", &len); + if (str) + mac_addr = simple_strtol(str, NULL, 16); + return mac_addr; +} + +int fdt_get_board_mac_cnt(void) +{ + int node, len = 16; + const char *str = NULL; + const void *fdt = gd->fdt_blob; + int mac_count = 0; + + node = fdt_get_bdk_node(); + if (!node) + return mac_count; + str = fdt_getprop(fdt, node, "BOARD-MAC-ADDRESS-NUM", &len); + if (str) { + mac_count = simple_strtol(str, NULL, 10); + if (!mac_count) + mac_count = simple_strtol(str, NULL, 16); + debug("fdt: MAC_NUM %d\n", mac_count); + } else { + printf("Error: cannot retrieve mac count prop from fdt\n"); + } + str = fdt_getprop(gd->fdt_blob, node, "BOARD-MAC-ADDRESS-NUM-OVERRIDE", + &len); + if (str) { + if (simple_strtol(str, NULL, 10) >= 0) + mac_count = simple_strtol(str, NULL, 10); + debug("fdt: MAC_NUM %d\n", mac_count); + } else { + printf("Error: cannot retrieve mac num override prop\n"); + } + return mac_count; +} + +const char *fdt_get_board_serial(void) +{ + const void *fdt = gd->fdt_blob; + int node, len = 64; + const char *str = NULL; + + node = fdt_get_bdk_node(); + if (!node) + return NULL; + + str = fdt_getprop(fdt, node, "BOARD-SERIAL", &len); + if (!str) + printf("Error: cannot retrieve board serial from fdt\n"); + return str; +} + +const char *fdt_get_board_revision(void) +{ + const void *fdt = gd->fdt_blob; + int node, len = 64; + const char *str = NULL; + + node = fdt_get_bdk_node(); + if (!node) + return NULL; + + str = fdt_getprop(fdt, node, "BOARD-REVISION", &len); + if (!str) + printf("Error: cannot retrieve board revision from fdt\n"); + return str; +} + +const char *fdt_get_board_model(void) +{ + int node, len = 16; + const char *str = NULL; + const void *fdt = gd->fdt_blob; + + node = fdt_get_bdk_node(); + if (!node) + return NULL; + str = fdt_getprop(fdt, node, "BOARD-MODEL", &len); + if (!str) + printf("Error: cannot retrieve board model from fdt\n"); + return str; +} + +int arch_fixup_memory_node(void *blob) +{ + return 0; +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + int nodeoff, node, ret, i; + const char *temp; + + static const char * const + octeontx_brd_nodes[] = {"BOARD-MODEL", + "BOARD-SERIAL", + "BOARD-MAC-ADDRESS", + "BOARD-REVISION", + "BOARD-MAC-ADDRESS-NUM" + }; + char nodes[ARRAY_SIZE(octeontx_brd_nodes)][32]; + + ret = fdt_check_header(blob); + if (ret < 0) { + printf("ERROR: %s\n", fdt_strerror(ret)); + return ret; + } + + if (blob) { + nodeoff = fdt_path_offset(blob, "/cavium,bdk"); + if (nodeoff < 0) { + printf("ERROR: FDT BDK node not found\n"); + return nodeoff; + } + + /* Read properties in temporary variables */ + for (i = 0; i < ARRAY_SIZE(octeontx_brd_nodes); i++) { + temp = fdt_getprop(blob, nodeoff, + octeontx_brd_nodes[i], NULL); + strncpy(nodes[i], temp, sizeof(nodes[i])); + } + + /* Delete cavium,bdk node */ + ret = fdt_del_node(blob, nodeoff); + if (ret < 0) { + printf("WARNING : could not remove cavium, bdk node\n"); + return ret; + } + debug("%s deleted 'cavium,bdk' node\n", __func__); + /* + * Add a new node at root level which would have + * necessary info + */ + node = fdt_add_subnode(blob, 0, "octeontx_brd"); + if (node < 0) { + printf("Cannot create node octeontx_brd: %s\n", + fdt_strerror(node)); + return -EIO; + } + + /* Populate properties in node */ + for (i = 0; i < ARRAY_SIZE(octeontx_brd_nodes); i++) { + if (fdt_setprop_string(blob, node, + octeontx_brd_nodes[i], + nodes[i])) { + printf("Can't set %s\n", nodes[i]); + return -EIO; + } + } + } + + return 0; +} + +/** + * Return the FDT base address that was passed by ATF + * + * @return FDT base address received from ATF in x1 register + */ +void *board_fdt_blob_setup(void) +{ + return (void *)fdt_base_addr; +} diff --git a/board/Marvell/octeontx2/board.c b/board/Marvell/octeontx2/board.c new file mode 100644 index 0000000000..50e903d9aa --- /dev/null +++ b/board/Marvell/octeontx2/board.c @@ -0,0 +1,247 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <command.h> +#include <console.h> +#include <cpu_func.h> +#include <dm.h> +#include <dm/uclass-internal.h> +#include <env.h> +#include <init.h> +#include <malloc.h> +#include <net.h> +#include <pci_ids.h> +#include <errno.h> +#include <asm/io.h> +#include <linux/compiler.h> +#include <linux/delay.h> +#include <linux/libfdt.h> +#include <fdt_support.h> +#include <asm/arch/smc.h> +#include <asm/arch/soc.h> +#include <asm/arch/board.h> +#include <dm/util.h> + +DECLARE_GLOBAL_DATA_PTR; + +void cleanup_env_ethaddr(void) +{ + char ename[32]; + + for (int i = 0; i < 20; i++) { + sprintf(ename, i ? "eth%daddr" : "ethaddr", i); + if (env_get(ename)) + env_set(ename, NULL); + } +} + +void octeontx2_board_get_mac_addr(u8 index, u8 *mac_addr) +{ + u64 tmp_mac, board_mac_addr = fdt_get_board_mac_addr(); + static int board_mac_num; + + board_mac_num = fdt_get_board_mac_cnt(); + if ((!is_zero_ethaddr((u8 *)&board_mac_addr)) && board_mac_num) { + tmp_mac = board_mac_addr; + tmp_mac += index; + tmp_mac = swab64(tmp_mac) >> 16; + memcpy(mac_addr, (u8 *)&tmp_mac, ARP_HLEN); + board_mac_num--; + } else { + memset(mac_addr, 0, ARP_HLEN); + } + debug("%s mac %pM\n", __func__, mac_addr); +} + +void board_quiesce_devices(void) +{ + struct uclass *uc_dev; + int ret; + + /* Removes all RVU PF devices */ + ret = uclass_get(UCLASS_ETH, &uc_dev); + if (uc_dev) + ret = uclass_destroy(uc_dev); + if (ret) + printf("couldn't remove rvu pf devices\n"); + + if (IS_ENABLED(CONFIG_OCTEONTX2_CGX_INTF)) { + /* Bring down all cgx lmac links */ + cgx_intf_shutdown(); + } + + /* Removes all CGX and RVU AF devices */ + ret = uclass_get(UCLASS_MISC, &uc_dev); + if (uc_dev) + ret = uclass_destroy(uc_dev); + if (ret) + printf("couldn't remove misc (cgx/rvu_af) devices\n"); + + /* SMC call - removes all LF<->PF mappings */ + smc_disable_rvu_lfs(0); +} + +int board_early_init_r(void) +{ + pci_init(); + return 0; +} + +int board_init(void) +{ + return 0; +} + +int timer_init(void) +{ + return 0; +} + +int dram_init(void) +{ + gd->ram_size = smc_dram_size(0); + gd->ram_size -= CONFIG_SYS_SDRAM_BASE; + + mem_map_fill(); + + return 0; +} + +void board_late_probe_devices(void) +{ + struct udevice *dev; + int err, cgx_cnt = 3, i; + + /* Probe MAC(CGX) and NIC AF devices before Network stack init */ + for (i = 0; i < cgx_cnt; i++) { + err = dm_pci_find_device(PCI_VENDOR_ID_CAVIUM, + PCI_DEVICE_ID_CAVIUM_CGX, i, &dev); + if (err) + debug("%s CGX%d device not found\n", __func__, i); + } + err = dm_pci_find_device(PCI_VENDOR_ID_CAVIUM, + PCI_DEVICE_ID_CAVIUM_RVU_AF, 0, &dev); + if (err) + debug("NIC AF device not found\n"); +} + +/** + * Board late initialization routine. + */ +int board_late_init(void) +{ + char boardname[32]; + char boardserial[150], boardrev[150]; + long val; + bool save_env = false; + const char *str; + + debug("%s()\n", __func__); + + /* + * Now that pci_init initializes env device. + * Try to cleanup ethaddr env variables, this is needed + * as with each boot, configuration of QLM can change. + */ + cleanup_env_ethaddr(); + + snprintf(boardname, sizeof(boardname), "%s> ", fdt_get_board_model()); + env_set("prompt", boardname); + set_working_fdt_addr(env_get_hex("fdtcontroladdr", fdt_base_addr)); + + str = fdt_get_board_revision(); + if (str) { + snprintf(boardrev, sizeof(boardrev), "%s", str); + if (env_get("boardrev") && + strcmp(boardrev, env_get("boardrev"))) + save_env = true; + env_set("boardrev", boardrev); + } + + str = fdt_get_board_serial(); + if (str) { + snprintf(boardserial, sizeof(boardserial), "%s", str); + if (env_get("serial#") && + strcmp(boardserial, env_get("serial#"))) + save_env = true; + env_set("serial#", boardserial); + } + + val = env_get_hex("disable_ooo", 0); + smc_configure_ooo(val); + + if (IS_ENABLED(CONFIG_NET_OCTEONTX2)) + board_late_probe_devices(); + + if (save_env) + env_save(); + + return 0; +} + +/* + * Invoked before relocation, so limit to stack variables. + */ +int checkboard(void) +{ + printf("Board: %s\n", fdt_get_board_model()); + + return 0; +} + +void board_acquire_flash_arb(bool acquire) +{ + union cpc_boot_ownerx ownerx; + + if (!acquire) { + ownerx.u = readl(CPC_BOOT_OWNERX(3)); + ownerx.s.boot_req = 0; + writel(ownerx.u, CPC_BOOT_OWNERX(3)); + } else { + ownerx.u = 0; + ownerx.s.boot_req = 1; + writel(ownerx.u, CPC_BOOT_OWNERX(3)); + udelay(1); + do { + ownerx.u = readl(CPC_BOOT_OWNERX(3)); + } while (ownerx.s.boot_wait); + } +} + +int last_stage_init(void) +{ + (void)smc_flsf_fw_booted(); + return 0; +} + +static int do_go_uboot(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + typedef void __noreturn (*uboot_entry_t)(ulong, void *); + uboot_entry_t entry; + ulong addr; + void *fdt; + + if (argc < 2) + return CMD_RET_USAGE; + + addr = simple_strtoul(argv[1], NULL, 16); + fdt = board_fdt_blob_setup(); + entry = (uboot_entry_t)addr; + flush_cache((ulong)addr, 1 << 20); /* 1MiB should be enough */ + dcache_disable(); + + printf("## Starting U-Boot at %p (FDT at %p)...\n", entry, fdt); + + entry(0, fdt); + + return 0; +} + +U_BOOT_CMD(go_uboot, 2, 0, do_go_uboot, + "Start U-Boot from RAM (pass FDT via x1 register)", + ""); diff --git a/board/Marvell/octeontx2/smc.c b/board/Marvell/octeontx2/smc.c new file mode 100644 index 0000000000..9e3169576c --- /dev/null +++ b/board/Marvell/octeontx2/smc.c @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/psci.h> +#include <asm/ptrace.h> +#include <asm/system.h> +#include <asm/arch/smc.h> + +DECLARE_GLOBAL_DATA_PTR; + +ssize_t smc_dram_size(unsigned int node) +{ + struct pt_regs regs; + + regs.regs[0] = OCTEONTX2_DRAM_SIZE; + regs.regs[1] = node; + smc_call(®s); + + return regs.regs[0]; +} + +ssize_t smc_disable_rvu_lfs(unsigned int node) +{ + struct pt_regs regs; + + regs.regs[0] = OCTEONTX2_DISABLE_RVU_LFS; + regs.regs[1] = node; + smc_call(®s); + + return regs.regs[0]; +} + +ssize_t smc_configure_ooo(unsigned int val) +{ + struct pt_regs regs; + + regs.regs[0] = OCTEONTX2_CONFIG_OOO; + regs.regs[1] = val; + smc_call(®s); + + return regs.regs[0]; +} + +ssize_t smc_flsf_fw_booted(void) +{ + struct pt_regs regs; + + regs.regs[0] = OCTEONTX2_FSAFE_PR_BOOT_SUCCESS; + smc_call(®s); + + return regs.regs[0]; +} diff --git a/board/Marvell/octeontx2/soc-utils.c b/board/Marvell/octeontx2/soc-utils.c new file mode 100644 index 0000000000..1cba7fb596 --- /dev/null +++ b/board/Marvell/octeontx2/soc-utils.c @@ -0,0 +1,49 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <common.h> +#include <dm.h> +#include <malloc.h> +#include <errno.h> +#include <asm/io.h> +#include <linux/compiler.h> +#include <asm/arch/soc.h> +#include <asm/arch/board.h> +#include <dm/util.h> + +int read_platform(void) +{ + int plat = PLATFORM_HW; + + const char *model = fdt_get_board_model(); + + if (model && !strncmp(model, "ASIM-", 5)) + plat = PLATFORM_ASIM; + if (model && !strncmp(model, "EMUL-", 5)) + plat = PLATFORM_EMULATOR; + + return plat; +} + +static inline u64 read_midr(void) +{ + u64 result; + + asm ("mrs %[rd],MIDR_EL1" : [rd] "=r" (result)); + return result; +} + +u8 read_partnum(void) +{ + return ((read_midr() >> 4) & 0xFF); +} + +const char *read_board_name(void) +{ + return fdt_get_board_model(); +} + diff --git a/configs/octeontx2_95xx_defconfig b/configs/octeontx2_95xx_defconfig new file mode 100644 index 0000000000..6aeb12c3f9 --- /dev/null +++ b/configs/octeontx2_95xx_defconfig @@ -0,0 +1,105 @@ +CONFIG_ARM=y +# CONFIG_ARM64_SUPPORT_AARCH32 is not set +CONFIG_ARCH_OCTEONTX2=y +CONFIG_SYS_TEXT_BASE=0x04000000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_OFFSET=0xF00000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_TARGET_OCTEONTX2_95XX=y +CONFIG_DM_GPIO=y +CONFIG_DEBUG_UART_BASE=0x87e028000000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200n8 earlycon=pl011,0x87e028000000 maxcpus=6 rootwait rw root=/dev/mmcblk0p2 coherent_pool=16M" +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="Marvell> " +# CONFIG_CMD_BOOTEFI_HELLO_COMPILE is not set +CONFIG_CMD_MD5SUM=y +CONFIG_MD5SUM_VERIFY=y +CONFIG_CMD_MX_CYCLIC=y +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_MEMTEST_START=0x04000000 +CONFIG_SYS_MEMTEST_END=0x040f0000 +CONFIG_CMD_SHA1SUM=y +CONFIG_SHA1SUM_VERIFY=y +CONFIG_CMD_DM=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TFTPSRV=y +CONFIG_CMD_RARP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CDP=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_PXE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_OF_BOARD=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=0 +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=0 +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=125000000 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0x0 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_OCTEONTX=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0x0 +CONFIG_SF_DEFAULT_SPEED=125000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_DM_ETH=y +CONFIG_NET_OCTEONTX2=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_REGION_MULTI_ENTRY=y +CONFIG_PCI_SRIOV=y +CONFIG_PCI_ARID=y +CONFIG_PCI_OCTEONTX=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_PL01X_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_WDT=y +CONFIG_ERRNO_STR=y diff --git a/configs/octeontx2_96xx_defconfig b/configs/octeontx2_96xx_defconfig new file mode 100644 index 0000000000..05cc1332d6 --- /dev/null +++ b/configs/octeontx2_96xx_defconfig @@ -0,0 +1,131 @@ +CONFIG_ARM=y +# CONFIG_ARM64_SUPPORT_AARCH32 is not set +CONFIG_ARCH_OCTEONTX2=y +CONFIG_SYS_TEXT_BASE=0x04000000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_OFFSET=0xF00000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_TARGET_OCTEONTX2_96XX=y +CONFIG_DM_GPIO=y +CONFIG_DEBUG_UART_BASE=0x87e028000000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200n8 earlycon=pl011,0x87e028000000 maxcpus=24 rootwait rw root=/dev/mmcblk0p2 coherent_pool=16M" +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="Marvell> " +# CONFIG_CMD_BOOTEFI_HELLO_COMPILE is not set +CONFIG_CMD_MD5SUM=y +CONFIG_MD5SUM_VERIFY=y +CONFIG_CMD_MX_CYCLIC=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SHA1SUM=y +CONFIG_SHA1SUM_VERIFY=y +CONFIG_CMD_DM=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TFTPSRV=y +CONFIG_CMD_RARP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CDP=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_PXE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_OF_BOARD=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=0 +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=0 +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=125000000 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0x0 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_OCTEONTX=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0x0 +CONFIG_SF_DEFAULT_SPEED=125000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_PHYLIB=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_E1000=y +CONFIG_E1000_SPI=y +CONFIG_CMD_E1000=y +CONFIG_NET_OCTEONTX2=y +CONFIG_NVME=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_REGION_MULTI_ENTRY=y +CONFIG_PCI_SRIOV=y +CONFIG_PCI_ARID=y +CONFIG_PCI_OCTEONTX=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_PL01X_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_OCTEON_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_PCI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_WDT=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/octeontx2_common.h b/include/configs/octeontx2_common.h new file mode 100644 index 0000000000..87dcf5fb37 --- /dev/null +++ b/include/configs/octeontx2_common.h @@ -0,0 +1,72 @@ +/* SPDX-License-Identifier: GPL-2.0 + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#ifndef __OCTEONTX2_COMMON_H__ +#define __OCTEONTX2_COMMON_H__ + +#define CONFIG_SUPPORT_RAW_INITRD + +/** Maximum size of image supported for bootm (and bootable FIT images) */ +#define CONFIG_SYS_BOOTM_LEN (256 << 20) + +/** Memory base address */ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_TEXT_BASE + +/** Stack starting address */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0xffff0) + +/** Heap size for U-Boot */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 64 * 1024 * 1024) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + +#define CONFIG_LAST_STAGE_INIT + +/* Allow environment variable to be overwritten */ +#define CONFIG_ENV_OVERWRITE + +/** Reduce hashes printed out */ +#define CONFIG_TFTP_TSIZE + +/* Autoboot options */ +#define CONFIG_RESET_TO_RETRY +#define CONFIG_BOOT_RETRY_TIME -1 +#define CONFIG_BOOT_RETRY_MIN 30 + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE + +/** Extra environment settings */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=20080000\0" \ + "ethrotate=yes\0" \ + "autoload=0\0" + +/** Environment defines */ +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#endif + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /** Console I/O Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MAXARGS 64 /** max command args */ + +#define CONFIG_SYS_MMC_MAX_BLK_COUNT 8192 + +#undef CONFIG_SYS_PROMPT +#define CONFIG_SYS_PROMPT env_get("prompt") + +#if defined(CONFIG_MMC_OCTEONTX) +#define MMC_SUPPORTS_TUNING +/** EMMC specific defines */ +#define CONFIG_SUPPORT_EMMC_BOOT +#define CONFIG_SUPPORT_EMMC_RPMB +#define CONFIG_CMD_BKOPS_ENABLE +#endif + +#endif /* __OCTEONTX2_COMMON_H__ */
Stefan Roese
