[PATCH] expo: allocate correct ammount of memory
This should be allocating the memory for "item" instead of "menu". The item struct is 48 bytes instead of 96 (assuming a 64bit system) so this saves a little memory.
Signed-off-by: Dan Carpenter dan.carpenter@linaro.org --- boot/scene_menu.c | 2 +- 1 file changed, 1 insertions(+), 1 deletions(-)
diff --git a/boot/scene_menu.c b/boot/scene_menu.c index 8a355f838cc8..57ffb523ff3f 100644 --- a/boot/scene_menu.c +++ b/boot/scene_menu.c @@ -416,7 +416,7 @@ int scene_menuitem(struct scene *scn, uint menu_id, const char *name, uint id, if (!scene_obj_find(scn, label_id, SCENEOBJT_TEXT)) return log_msg_ret("txt", -EINVAL);
- item = calloc(1, sizeof(struct scene_obj_menu)); + item = calloc(1, sizeof(struct scene_menitem)); if (!item) return log_msg_ret("item", -ENOMEM); item->name = strdup(name);
typo in commit subject
-- 2.39.2
Signed-off-by: Dan Carpenter dan.carpenter@linaro.org Reviewed-by: Simon Glass sjg@chromium.org
Dan Carpenter
