[RFC][PATCH v4] Add support for SoM "VoCore2"
Foreword: Patch sent as reference only, as it *still* does not work as expected. Most likely some cache misalignment is afoot (but I didn't change anything there). Symptoms are:
* Dynamically loading a *different* version of U-Boot with: usb start; load usb 0:1 80200000 u-boot.bin; go 80200000 very often does not work. Workaround is: usb start; load usb 0:1 80200000 u-boot.bin; load usb 0:1 85000000 uImage; go 80200000
* I noticed a very strange behavior with Linux command line handling:
U-Boot 2020.01-00646-g03de3f19fa (Jan 28 2020 - 22:56:42 +0100)
CPU: MediaTek MT7628A ver:1 eco:2 Boot: DDR2, SPI-NOR 3-Byte Addr, CPU clock from XTAL Clock: CPU: 580MHz, Bus: 193MHz, XTAL: 40MHz Model: VoCore2 DRAM: 128 MiB WDT: Started with servicing (60s timeout) MMC: mmc@10130000: 0 Loading Environment from FAT... OK Model: VoCore2 => load mmc 0:5 85000000 /boot/uImage 2329562 bytes read in 141 ms (15.8 MiB/s) => printenv bootcmd=load mmc 0:2 85000000 /boot/uImage; load mmc 0:2 86000000 /boot/initrd; setenv bootargs ${default_bootargs} mtdparts=${mtdparts} rd_start=0x${fileaddr} rd_size=0x${filesize} USE=mmc; bootm 85000000 bootdelay=5 default_bootargs=earlyprintk rootwait console=ttyS2,115200 fdtcontroladdr=87e7c2e8 fileaddr=85000000 filesize=238bda mtdids=nor0=spi0.0 mtdparts=spi0.0:312k(u-boot),4k(env),4k(factory),2368k(kernel),-(filesystem) stderr=uart2@e00 stdin=uart2@e00 stdout=uart2@e00 ver=U-Boot 2020.01-00646-g03de3f19fa (Jan 28 2020 - 22:56:42 +0100)
Environment size: 716/4092 bytes => setenv bootargs ${default_bootargs} mtdparts=${mtdparts} root=/dev/mmcblk0p5 => printenv bootargs=earlyprintk rootwait console=ttyS2,115200 mtdparts=spi0.0:312k(u-boot),4k(env),4k(factory),2368k(kernel),-(filesystem) mtdparts=spi0.0:312k(u-boot),4k(env),4k(factory),2368k(kernel),-(filesystem) root=/dev/mmcblk0p5 bootcmd=load mmc 0:2 85000000 /boot/uImage; load mmc 0:2 86000000 /boot/initrd; setenv bootargs ${default_bootargs} mtdparts=${mtdparts} rd_start=0x${fileaddr} rd_size=0x${filesize} USE=mmc; bootm 85000000 bootdelay=5 default_bootargs=earlyprintk rootwait console=ttyS2,115200 mtdparts=spi0.0:312k(u-boot),4k(env),4k(factory),2368k(kernel),-(filesystem) fdtcontroladdr=87e7c2e8 fileaddr=85000000 filesize=238bda mtdids=nor0=spi0.0 mtdparts=spi0.0:312k(u-boot),4k(env),4k(factory),2368k(kernel),-(filesystem) stderr=uart2@e00 stdin=uart2@e00 stdout=uart2@e00 ver=U-Boot 2020.01-00646-g03de3f19fa (Jan 28 2020 - 22:56:42 +0100)
Environment size: 941/4092 bytes => bootm ${fileaddr} ## Booting kernel from Legacy Image at 85000000 ... Image Name: Linux-5.3.0 Image Type: MIPS Linux Kernel Image (gzip compressed) Data Size: 2329498 Bytes = 2.2 MiB Load Address: 80000000 Entry Point: 803fc050 Verifying Checksum ... OK Uncompressing Kernel Image [ 0.000000] Linux version 5.3.0 (mcon@cinderella) (gcc version 8.3.0 (Buildroot 2019.11-git-01046-g084c788231-dirty)) #4 PREEMPT Wed Jan 29 00:29:59 CET 2020 [ 0.000000] Board has DDR2 [ 0.000000] Analog PMU set to hw control [ 0.000000] Digital PMU set to hw control [ 0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2 [ 0.000000] printk: bootconsole [early0] enabled [ 0.000000] CPU0 revision is: 00019655 (MIPS 24KEc) [ 0.000000] MIPS: machine is VoCore2 [ 0.000000] Determined physical RAM map: [ 0.000000] memory: 08000000 @ 00000000 (usable) [ 0.000000] Initrd not found or empty - disabling initrd [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32480 [ 0.000000] Kernel command line: mtdparts=spi0.0:312k(u-boot),4k(env),4k(factory),2368k(kernel),-(filesystem) mtdparts=spi0.0:312k(u-boot),4k(env),4k(factory),2368k(kernel),-(filesystem) root=/dev/mmcblk0p5
*** here command line seems truncated (missing first part) and missing "console" and "rootwait" result in WDT reboot.
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear) [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 0.000000] Writing ErrCtl register=00065516 [ 0.000000] Readback ErrCtl register=00065516 [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 124656K/131072K available (4107K kernel code, 221K rwdata, 480K rodata, 176K init, 95K bss, 6416K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] NR_IRQS: 256 [ 0.000000] intc: using register map from devicetree [ 0.000000] random: get_random_bytes called from 0x804b4a4c with crng_init=0 [ 0.000000] CPU Clock: 580MHz [ 0.000000] timer_probe: no matching timers found [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns [ 0.000012] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns [ 0.008046] Console: colour dummy device 80x25 [ 0.012474] printk: console [tty0] enabled [ 0.016608] printk: bootconsole [early0] disabled
Here workaround is to have "setenv bootargs ${default_bootargs} mtdparts=${mtdparts} root=/dev/mmcblk0p5 ${default_bootargs}"; I.e.: insert ${default_bootargs} *twice* (simply moving it to end would result in missing "mtdparts").
* given the above environment, shouldn't autoboot be attempted?
* I also tried enabling CONFIG_CMD_CACHE, but compilation fails with: ... LD u-boot mipsel-linux-ld.bfd: cmd/built-in.o: in function `do_icache': cmd/cache.c:(.text.do_icache+0x5c): undefined reference to `icache_disable' mipsel-linux-ld.bfd: cmd/cache.c:(.text.do_icache+0x6c): undefined reference to `icache_enable' mipsel-linux-ld.bfd: cmd/cache.c:(.text.do_icache+0x8c): undefined reference to `icache_status' make: *** [Makefile:1695: u-boot] Error 1
My only guess, ATM, is I goofed somehow applying Weijie patches: I'll try rebuilding from a pristine "master". Can someone confirm patchset "[v3,xx/20]Refactor the architecture parts of mt7628" still applies cleanly?
Side issue: patman complain with:
mcon@cinderella:~/vocore/__V2__/u-boot$ ./tools/patman/patman -n -c1 -m Cleaned 1 patches 0 errors, 1 warnings, 0 checks for 0001-Add-support-for-SoM-VoCore2.patch: <unknown>:0: warning: added, moved or deleted file(s), does MAINTAINERS need updating? checkpatch.pl found 0 error(s), 1 warning(s), 0 checks(s)
What should I do?
Any hint welcome.
Regards and TiA! Mauro
================================================= Small patch series to add support for VoCore/VoCore2 board.
VoCore is open hardware and runs OpenWrt/LEDE. It has WIFI, USB, UART, 20+ GPIOs but is only one inch square. It will help you to make a smart house, study embedded system or even make the tiniest router in the world.
Details about this SoM can be found at "https://vocore.io/v2.html".
Signed-off-by: Mauro Condarelli mc5686@mclink.it ---
Changes in v4: - Reverted some overzealous DTS cleaning. - Added support for bootcount
Changes in v3: - based on top of Weijie Gao patchset: "[v3,xx/20]Refactor the architecture parts of mt7628"
Changes in v2: - Removed some dead code - Changed Author to my full name (no nick) - Removed unwanted fixup to .dts generation (not my call). - Fixed commit message - Fixed various variables/filenames to include Vendor name - Changed Vendor name (Vonger -> Vocore)
arch/mips/dts/Makefile | 1 + arch/mips/dts/mt7628a.dtsi | 5 ++ arch/mips/dts/vocore_vocore2.dts | 76 ++++++++++++++++++++++ arch/mips/mach-mtmips/Kconfig | 8 +++ board/vocore/vocore2/Kconfig | 12 ++++ board/vocore/vocore2/Makefile | 3 + board/vocore/vocore2/board.c | 33 ++++++++++ configs/vocore2_defconfig | 105 +++++++++++++++++++++++++++++++ include/configs/vocore2.h | 61 ++++++++++++++++++ 9 files changed, 304 insertions(+) create mode 100644 arch/mips/dts/vocore_vocore2.dts create mode 100644 board/vocore/vocore2/Kconfig create mode 100644 board/vocore/vocore2/Makefile create mode 100644 board/vocore/vocore2/board.c create mode 100644 configs/vocore2_defconfig create mode 100644 include/configs/vocore2.h
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index cbd0c8bc8b..f711e9fb59 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -23,6 +23,7 @@ dtb-$(CONFIG_BOARD_NETGEAR_DGND3700V2) += netgear,dgnd3700v2.dtb dtb-$(CONFIG_BOARD_SAGEM_FAST1704) += sagem,f@st1704.dtb dtb-$(CONFIG_BOARD_SFR_NB4_SER) += sfr,nb4-ser.dtb dtb-$(CONFIG_BOARD_TPLINK_WDR4300) += tplink_wdr4300.dtb +dtb-$(CONFIG_BOARD_VOCORE2) += vocore_vocore2.dtb dtb-$(CONFIG_TARGET_JZ4780_CI20) += ci20.dtb dtb-$(CONFIG_SOC_LUTON) += luton_pcb090.dtb luton_pcb091.dtb dtb-$(CONFIG_SOC_OCELOT) += ocelot_pcb120.dtb ocelot_pcb123.dtb diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 6baa63add3..192599c37f 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -402,6 +402,11 @@ builtin-cd = <1>; r_smpl = <1>; + bus-width = <4>; + max-frequency = <48000000>; + cap-sd-highspeed; + cap-mmc-highspeed; + clocks = <&clk48m>, <&clkctrl CLK_SDXC>; clock-names = "source", "hclk"; diff --git a/arch/mips/dts/vocore_vocore2.dts b/arch/mips/dts/vocore_vocore2.dts new file mode 100644 index 0000000000..b8fd87a3e9 --- /dev/null +++ b/arch/mips/dts/vocore_vocore2.dts @@ -0,0 +1,76 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Mauro Condarelli mc5686@mclink.it + */ + +/dts-v1/; + +#include "mt7628a.dtsi" +#include <dt-bindings/gpio/gpio.h> + +/ { + compatible = "vocore,vocore2", "ralink,mt7628a-soc"; + model = "VoCore2"; + + aliases { + serial0 = &uart2; + spi0 = &spi0; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x08000000>; + }; + leds { + compatible = "gpio-leds"; + + power { + label = "vocore:power"; + gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + }; + + chosen { + bootargs = "console=ttyS2,115200"; + stdout-path = &uart2; + }; +}; + +&pinctrl { + state_default: pin_state { + p0led { + groups = "p0led_a"; + function = "led"; + }; + }; +}; + +&uart2 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + nor0: spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; + +ð { + pinctrl-names = "default"; + pinctrl-0 = <&ephy_iot_mode>; + mediatek,poll-link-phy = <0>; +}; + +&mmc { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&sd_iot_mode>; + pinctrl-1 = <&sd_iot_mode>; +}; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index bcd635f438..489e466daf 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -83,6 +83,13 @@ config BOARD_MT7628_RFB SPI-NOR flash, 1 built-in switch with 5 ports, 1 UART, 1 USB host, 1 SDXC, 1 PCIe socket and JTAG pins. +config BOARD_VOCORE2 + bool "VoCore2" + depends on SOC_MT7628 + help + VoCore VoCore2 board has a MT7628 SoC with 128 MiB of RAM + and 16 MiB of flash (SPI). + endchoice config SPL_UART2_SPIS_PINMUX @@ -96,5 +103,6 @@ config SPL_UART2_SPIS_PINMUX source "board/gardena/smart-gateway-mt7688/Kconfig" source "board/mediatek/mt7628/Kconfig" source "board/seeed/linkit-smart-7688/Kconfig" +source "board/vocore/vocore2/Kconfig" endmenu diff --git a/board/vocore/vocore2/Kconfig b/board/vocore/vocore2/Kconfig new file mode 100644 index 0000000000..baeff31b69 --- /dev/null +++ b/board/vocore/vocore2/Kconfig @@ -0,0 +1,12 @@ +if BOARD_VOCORE2 + +config SYS_BOARD + default "vocore2" + +config SYS_VENDOR + default "vocore" + +config SYS_CONFIG_NAME + default "vocore2" + +endif diff --git a/board/vocore/vocore2/Makefile b/board/vocore/vocore2/Makefile new file mode 100644 index 0000000000..70cd7a8e56 --- /dev/null +++ b/board/vocore/vocore2/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += board.o diff --git a/board/vocore/vocore2/board.c b/board/vocore/vocore2/board.c new file mode 100644 index 0000000000..d387715d14 --- /dev/null +++ b/board/vocore/vocore2/board.c @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Mauro Condarelli mc5686@mclink.it + * + * Note: this is largely copied from: + * board/seeed/linkit_smart_7688/board.c + * Copyright (C) 2018 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <asm/io.h> + +#define MT76XX_GPIO1_MODE 0x10000060 + +void board_debug_uart_init(void) +{ + void __iomem *gpio_mode; + + /* Select UART2 mode instead of GPIO mode (default) */ + gpio_mode = ioremap_nocache(MT76XX_GPIO1_MODE, 0x100); + clrbits_le32(gpio_mode, GENMASK(27, 26)); +} + +int board_early_init_f(void) +{ + /* + * The pin muxing of UART2 also needs to be done, if debug uart + * is not enabled. So we need to call this function here as well. + */ + board_debug_uart_init(); + + return 0; +} diff --git a/configs/vocore2_defconfig b/configs/vocore2_defconfig new file mode 100644 index 0000000000..b0c15c02f6 --- /dev/null +++ b/configs/vocore2_defconfig @@ -0,0 +1,105 @@ +CONFIG_MIPS=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y +CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c +CONFIG_ARCH_MTMIPS=y +CONFIG_BOARD_VOCORE2=y +CONFIG_SPL_UART2_SPIS_PINMUX=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_SYS_BOOT_GET_CMDLINE=y +CONFIG_SYS_BOOT_GET_KBD=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_USE_BOOTARGS=y +CONFIG_LOGLEVEL=8 +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_VERSION_VARIABLE=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y +CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set +CONFIG_CMD_LICENSE=y +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PART=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_BOOTCOUNT=y +# CONFIG_CMD_BLOCK_CACHE is not set +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" +CONFIG_MTDPARTS_DEFAULT="spi0.0:312k(u-boot),4k(env),4k(factory),2368k(kernel),-(filesystem)" +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="vocore_vocore2" +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +# CONFIG_NET is not set +CONFIG_SPL_DM=y +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y +CONFIG_MMC=y +CONFIG_DM_MMC=y +# CONFIG_MMC_HW_PARTITIONING is not set +CONFIG_MMC_MTK=y +CONFIG_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +# CONFIG_DM_ETH is not set +# CONFIG_RAM_ROCKCHIP_DEBUG is not set +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_CONS_INDEX=3 +CONFIG_SPI=y +CONFIG_MT7621_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_WDT=y +CONFIG_WDT_MT7621=y +CONFIG_FS_EXT4=y +CONFIG_LZMA=y +CONFIG_LZO=y +CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/include/configs/vocore2.h b/include/configs/vocore2.h new file mode 100644 index 0000000000..6b43aa766e --- /dev/null +++ b/include/configs/vocore2.h @@ -0,0 +1,61 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Mauro Condarelli mc5686@mclink.it + */ + +#ifndef __VOCORE2_CONFIG_H__ +#define __VOCORE2_CONFIG_H__ + +/* CPU */ +#define CONFIG_SYS_MIPS_TIMER_FREQ 290000000 + +/* RAM */ +#define CONFIG_SYS_SDRAM_BASE 0x80000000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000 + +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 + +/* SPL */ +#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SPL_BSS_START_ADDR 0x80010000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x10000 +#define CONFIG_SPL_MAX_SIZE 0x10000 + +/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 + +/* Serial SPL */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL_SUPPORT) +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_CLK 40000000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM3 0xb0000e00 +#define CONFIG_CONS_INDEX 3 + +#endif + +/* UART */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ + 230400, 460800, 921600 } + +/* RAM */ +#define CONFIG_SYS_MEMTEST_START 0x80100000 +#define CONFIG_SYS_MEMTEST_END 0x80400000 + +/* Memory usage */ +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) +#define CONFIG_SYS_BOOTPARAMS_LEN (128 * 1024) +#define CONFIG_SYS_CBSIZE 512 + +/* U-Boot */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +/* Environment settings */ + +#endif //__VOCORE2_CONFIG_H__
Mauro Condarelli
