[U-Boot] [PATCH] sunxi: enable SATA on Banana Pi M2 Berry
Banana Pi M2 Ultra and M2 Berry are very similar boards. SATA can be enabled exactly the same as for M2 Ultra introduced in commit daa8b75a5527 ("sunxi: enable SATA on Banana Pi M2 Ultra").
Signed-off-by: Simon Baatz gmbnomis@gmail.com ---
configs/bananapi_m2_berry_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/bananapi_m2_berry_defconfig b/configs/bananapi_m2_berry_defconfig index 9d75108d04..313e09a764 100644 --- a/configs/bananapi_m2_berry_defconfig +++ b/configs/bananapi_m2_berry_defconfig @@ -7,8 +7,11 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="PH13" CONFIG_DEFAULT_DEVICE_TREE="sun8i-v40-bananapi-m2-berry" +CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set +CONFIG_SCSI_AHCI=y CONFIG_AXP_DLDO4_VOLT=2500 CONFIG_AXP_ELDO3_VOLT=1200 +CONFIG_SCSI=y
Acked-by: Maxime Ripard maxime.ripard@bootlin.com
Thanks! Maxime
Maxime Ripard
Simon Baatz
