[U-Boot-Users] [PATCH 01/11] i2c: Clean drivers/i2c/ Makefile
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/i2c/Makefile | 10 +++++----- drivers/i2c/fsl_i2c.c | 2 -- drivers/i2c/mxc_i2c.c | 2 +- drivers/i2c/omap1510_i2c.c | 4 ---- drivers/i2c/omap24xx_i2c.c | 4 ---- drivers/i2c/tsi108_i2c.c | 2 -- 6 files changed, 6 insertions(+), 18 deletions(-)
diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 534c015..1f25afb 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -25,11 +25,11 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libi2c.a
-COBJS-y += fsl_i2c.o -COBJS-y += omap1510_i2c.o -COBJS-y += omap24xx_i2c.o -COBJS-y += tsi108_i2c.o -COBJS-y += mxc_i2c.o +COBJS-$(CONFIG_FSL_I2C) += fsl_i2c.o +COBJS-$(CONFIG_I2C_MXC) += mxc_i2c.o +COBJS-$(CONFIG_DRIVER_OMAP1510_I2C) += omap1510_i2c.o +COBJS-$(CONFIG_DRIVER_OMAP24XX_I2C) += omap24xx_i2c.o +COBJS-$(CONFIG_TSI108_I2C) += tsi108_i2c.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/i2c/fsl_i2c.c b/drivers/i2c/fsl_i2c.c index 9f2c1ec..688f66a 100644 --- a/drivers/i2c/fsl_i2c.c +++ b/drivers/i2c/fsl_i2c.c @@ -18,7 +18,6 @@
#include <common.h>
-#ifdef CONFIG_FSL_I2C #ifdef CONFIG_HARD_I2C
#include <command.h> @@ -387,4 +386,3 @@ unsigned int i2c_get_bus_speed(void) }
#endif /* CONFIG_HARD_I2C */ -#endif /* CONFIG_FSL_I2C */ diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index a218329..1f6ba1f 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -24,7 +24,7 @@
#include <common.h>
-#if defined(CONFIG_HARD_I2C) && defined (CONFIG_I2C_MXC) +#if defined(CONFIG_HARD_I2C)
#include <asm/arch/mx31.h> #include <asm/arch/mx31-regs.h> diff --git a/drivers/i2c/omap1510_i2c.c b/drivers/i2c/omap1510_i2c.c index 04400fb..388951d 100644 --- a/drivers/i2c/omap1510_i2c.c +++ b/drivers/i2c/omap1510_i2c.c @@ -20,8 +20,6 @@
#include <common.h>
-#ifdef CONFIG_DRIVER_OMAP1510_I2C - static void wait_for_bb (void); static u16 wait_for_pin (void);
@@ -277,5 +275,3 @@ static u16 wait_for_pin (void)
return status; } - -#endif /* CONFIG_DRIVER_OMAP1510_I2C */ diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 7dab786..d16cfb1 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -22,8 +22,6 @@
#include <common.h>
-#ifdef CONFIG_DRIVER_OMAP24XX_I2C - #include <asm/arch/i2c.h> #include <asm/io.h>
@@ -325,5 +323,3 @@ static u16 wait_for_pin (void) } return status; } - -#endif /* CONFIG_DRIVER_OMAP24XX_I2C */ diff --git a/drivers/i2c/tsi108_i2c.c b/drivers/i2c/tsi108_i2c.c index d6736b0..695e393 100644 --- a/drivers/i2c/tsi108_i2c.c +++ b/drivers/i2c/tsi108_i2c.c @@ -25,7 +25,6 @@ #include <config.h> #include <common.h>
-#ifdef CONFIG_TSI108_I2C #include <tsi108.h>
#if defined(CONFIG_CMD_I2C) @@ -280,4 +279,3 @@ int i2c_probe (uchar chip) }
#endif -#endif /* CONFIG_TSI108_I2C */
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/usb/Makefile | 12 ++++++------ drivers/usb/isp116x-hcd.c | 3 --- drivers/usb/sl811_usb.c | 3 --- drivers/usb/usb_ohci.c | 3 --- drivers/usb/usbdcore_ep0.c | 3 --- drivers/usb/usbdcore_mpc8xx.c | 4 ++-- drivers/usb/usbdcore_omap1510.c | 2 +- 7 files changed, 9 insertions(+), 21 deletions(-)
diff --git a/drivers/usb/Makefile b/drivers/usb/Makefile index 252b00e..1388186 100644 --- a/drivers/usb/Makefile +++ b/drivers/usb/Makefile @@ -25,13 +25,13 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libusb.a
-COBJS-y += isp116x-hcd.o -COBJS-y += sl811_usb.o -COBJS-y += usb_ohci.o +COBJS-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o +COBJS-$(CONFIG_USB_SL811HS) += sl811_usb.o +COBJS-$(CONFIG_USB_OHCI_NEW) += usb_ohci.o COBJS-y += usbdcore.o -COBJS-y += usbdcore_ep0.o -COBJS-y += usbdcore_mpc8xx.o -COBJS-y += usbdcore_omap1510.o +COBJS-$(CONFIG_USB_DEVICE) += usbdcore_ep0.o +COBJS-$(CONFIG_MPC885_FAMILY) += usbdcore_mpc8xx.o +COBJS-$(CONFIG_OMAP1510) += usbdcore_omap1510.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/usb/isp116x-hcd.c b/drivers/usb/isp116x-hcd.c index 6b9b23b..e9e69bb 100644 --- a/drivers/usb/isp116x-hcd.c +++ b/drivers/usb/isp116x-hcd.c @@ -57,7 +57,6 @@
#include <common.h>
-#ifdef CONFIG_USB_ISP116X_HCD #include <asm/io.h> #include <usb.h> #include <malloc.h> @@ -1441,5 +1440,3 @@ int usb_lowlevel_stop(void)
return 0; } - -#endif /* CONFIG_USB_ISP116X_HCD */ diff --git a/drivers/usb/sl811_usb.c b/drivers/usb/sl811_usb.c index 159cc25..cfdd375 100644 --- a/drivers/usb/sl811_usb.c +++ b/drivers/usb/sl811_usb.c @@ -36,7 +36,6 @@ */
#include <common.h> -#ifdef CONFIG_USB_SL811HS #include <mpc8xx.h> #include <usb.h> #include "sl811.h" @@ -733,5 +732,3 @@ static int sl811_rh_submit_urb(struct usb_device *usb_dev, unsigned long pipe,
return status == 0 ? len : status; } - -#endif /* CONFIG_USB_SL811HS */ diff --git a/drivers/usb/usb_ohci.c b/drivers/usb/usb_ohci.c index fd60edb..9e7b396 100644 --- a/drivers/usb/usb_ohci.c +++ b/drivers/usb/usb_ohci.c @@ -47,8 +47,6 @@
#include <common.h>
-#ifdef CONFIG_USB_OHCI_NEW - #include <asm/byteorder.h>
#if defined(CONFIG_PCI_OHCI) @@ -1910,4 +1908,3 @@ int usb_lowlevel_stop(void)
return 0; } -#endif /* CONFIG_USB_OHCI_NEW */ diff --git a/drivers/usb/usbdcore_ep0.c b/drivers/usb/usbdcore_ep0.c index cf3f382..2395eec 100644 --- a/drivers/usb/usbdcore_ep0.c +++ b/drivers/usb/usbdcore_ep0.c @@ -52,7 +52,6 @@
#include <common.h>
-#if defined(CONFIG_USB_DEVICE) #include "usbdcore.h"
#if 0 @@ -597,5 +596,3 @@ int ep0_recv_setup (struct urb *urb) } return -1; } - -#endif diff --git a/drivers/usb/usbdcore_mpc8xx.c b/drivers/usb/usbdcore_mpc8xx.c index 122793c..539e0f8 100644 --- a/drivers/usb/usbdcore_mpc8xx.c +++ b/drivers/usb/usbdcore_mpc8xx.c @@ -59,7 +59,7 @@ #include <common.h> #include <config.h>
-#if defined(CONFIG_MPC885_FAMILY) && defined(CONFIG_USB_DEVICE) +#if defined(CONFIG_USB_DEVICE) #include <commproc.h> #include "usbdcore.h" #include "usbdcore_mpc8xx.h" @@ -1399,4 +1399,4 @@ static u32 mpc8xx_udc_alloc (u32 data_size, u32 alignment) return retaddr; }
-#endif /* CONFIG_MPC885_FAMILY && CONFIG_USB_DEVICE) */ +#endif /* CONFIG_USB_DEVICE) */ diff --git a/drivers/usb/usbdcore_omap1510.c b/drivers/usb/usbdcore_omap1510.c index 84bb936..8d23537 100644 --- a/drivers/usb/usbdcore_omap1510.c +++ b/drivers/usb/usbdcore_omap1510.c @@ -28,7 +28,7 @@
#include <common.h>
-#if defined(CONFIG_OMAP1510) && defined(CONFIG_USB_DEVICE) +#if defined(CONFIG_USB_DEVICE)
#include <asm/io.h> #ifdef CONFIG_OMAP_SX1
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/rtc/Makefile | 50 ++++++++++++++++++++++---------------------- drivers/rtc/bfin_rtc.c | 2 +- drivers/rtc/ds12887.c | 2 +- drivers/rtc/ds1302.c | 2 +- drivers/rtc/ds1306.c | 2 +- drivers/rtc/ds1307.c | 3 +- drivers/rtc/ds1337.c | 2 +- drivers/rtc/ds1374.c | 2 +- drivers/rtc/ds1556.c | 3 +- drivers/rtc/ds164x.c | 2 +- drivers/rtc/ds174x.c | 2 +- drivers/rtc/ds3231.c | 2 +- drivers/rtc/m41t11.c | 2 +- drivers/rtc/m41t60.c | 3 +- drivers/rtc/m48t35ax.c | 2 +- drivers/rtc/max6900.c | 2 +- drivers/rtc/mc146818.c | 2 +- drivers/rtc/mcfrtc.c | 2 +- drivers/rtc/mk48t59.c | 3 -- drivers/rtc/mpc5xxx.c | 2 +- drivers/rtc/mpc8xx.c | 2 +- drivers/rtc/pcf8563.c | 2 +- drivers/rtc/rs5c372.c | 2 +- drivers/rtc/rx8025.c | 2 +- drivers/rtc/s3c24x0_rtc.c | 2 +- drivers/rtc/x1205.c | 2 +- 26 files changed, 49 insertions(+), 55 deletions(-)
diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index 2e0c118..2af3ee5 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -27,35 +27,35 @@ include $(TOPDIR)/config.mk
LIB = $(obj)librtc.a
-COBJS-y += bfin_rtc.o +COBJS-$(CONFIG_RTC_BFIN) += bfin_rtc.o COBJS-y += date.o -COBJS-y += ds12887.o -COBJS-y += ds1302.o -COBJS-y += ds1306.o -COBJS-y += ds1307.o -COBJS-y += ds1337.o -COBJS-y += ds1374.o -COBJS-y += ds1556.o -COBJS-y += ds164x.o -COBJS-y += ds174x.o -COBJS-y += ds3231.o +COBJS-$(CONFIG_RTC_DS12887) += ds12887.o +COBJS-$(CONFIG_RTC_DS1302) += ds1302.o +COBJS-$(CONFIG_RTC_DS1306) += ds1306.o +COBJS-$(CONFIG_RTC_DS1307 || CONFIG_RTC_DS1338) += ds1307.o +COBJS-$(CONFIG_RTC_DS1337) += ds1337.o +COBJS-$(CONFIG_RTC_DS1374) += ds1374.o +COBJS-$(CONFIG_RTC_DS1556) += ds1556.o +COBJS-$(CONFIG_RTC_DS164x) += ds164x.o +COBJS-$(CONFIG_RTC_DS174x) += ds174x.o +COBJS-$(CONFIG_RTC_DS3231) += ds3231.o COBJS-$(CONFIG_RTC_ISL1208) += isl1208.o -COBJS-y += m41t11.o -COBJS-y += m41t60.o +COBJS-$(CONFIG_RTC_M41T11) += m41t11.o +COBJS-$(CONFIG_RTC_M41T60) += m41t60.o COBJS-$(CONFIG_RTC_M41T62) += m41t62.o -COBJS-y += m48t35ax.o -COBJS-y += max6900.o +COBJS-$(CONFIG_RTC_M48T35A) += m48t35ax.o +COBJS-$(CONFIG_RTC_MAX6900) += max6900.o COBJS-$(CONFIG_RTC_MC13783) += mc13783-rtc.o -COBJS-y += mc146818.o -COBJS-y += mcfrtc.o -COBJS-y += mk48t59.o -COBJS-y += mpc5xxx.o -COBJS-y += mpc8xx.o -COBJS-y += pcf8563.o -COBJS-y += rs5c372.o -COBJS-y += rx8025.o -COBJS-y += s3c24x0_rtc.o -COBJS-y += x1205.o +COBJS-$(CONFIG_RTC_MC146818) += mc146818.o +COBJS-$(CONFIG_MCFRTC) += mcfrtc.o +COBJS-$(CONFIG_RTC_MK48T59) += mk48t59.o +COBJS-$(CONFIG_RTC_MPC5200) += mpc5xxx.o +COBJS-$(CONFIG_RTC_MPC8xx) += mpc8xx.o +COBJS-$(CONFIG_RTC_PCF8563) += pcf8563.o +COBJS-$(CONFIG_RTC_RS5C372A) += rs5c372.o +COBJS-$(CONFIG_RTC_RX8025) += rx8025.o +COBJS-$(CONFIG_RTC_S3C24X0) += s3c24x0_rtc.o +COBJS-$(CONFIG_RTC_X1205) += x1205.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/rtc/bfin_rtc.c b/drivers/rtc/bfin_rtc.c index ce4f171..ee8acd3 100644 --- a/drivers/rtc/bfin_rtc.c +++ b/drivers/rtc/bfin_rtc.c @@ -11,7 +11,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_BFIN) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
#include <asm/blackfin.h> #include <asm/mach-common/bits/rtc.h> diff --git a/drivers/rtc/ds12887.c b/drivers/rtc/ds12887.c index 990ebba..fb1825b 100644 --- a/drivers/rtc/ds12887.c +++ b/drivers/rtc/ds12887.c @@ -28,7 +28,7 @@ #include <config.h> #include <rtc.h>
-#if defined(CONFIG_RTC_DS12887) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
#define RTC_SECONDS 0x00 #define RTC_SECONDS_ALARM 0x01 diff --git a/drivers/rtc/ds1302.c b/drivers/rtc/ds1302.c index e4e9154..d28a9fd 100644 --- a/drivers/rtc/ds1302.c +++ b/drivers/rtc/ds1302.c @@ -9,7 +9,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_DS1302) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
/* GPP Pins */ #define DATA 0x200 diff --git a/drivers/rtc/ds1306.c b/drivers/rtc/ds1306.c index 29854fc..12528ed 100644 --- a/drivers/rtc/ds1306.c +++ b/drivers/rtc/ds1306.c @@ -36,7 +36,7 @@ #include <rtc.h> #include <spi.h>
-#if defined(CONFIG_RTC_DS1306) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
#define RTC_SECONDS 0x00 #define RTC_MINUTES 0x01 diff --git a/drivers/rtc/ds1307.c b/drivers/rtc/ds1307.c index b20f193..11fc14f 100644 --- a/drivers/rtc/ds1307.c +++ b/drivers/rtc/ds1307.c @@ -35,8 +35,7 @@ #include <rtc.h> #include <i2c.h>
-#if (defined(CONFIG_RTC_DS1307) || defined(CONFIG_RTC_DS1338) ) && \ - defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
/*---------------------------------------------------------------------*/ #undef DEBUG_RTC diff --git a/drivers/rtc/ds1337.c b/drivers/rtc/ds1337.c index e908749..df1132a 100644 --- a/drivers/rtc/ds1337.c +++ b/drivers/rtc/ds1337.c @@ -32,7 +32,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_DS1337) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
/*---------------------------------------------------------------------*/ #undef DEBUG_RTC diff --git a/drivers/rtc/ds1374.c b/drivers/rtc/ds1374.c index 1533b60..130588c 100644 --- a/drivers/rtc/ds1374.c +++ b/drivers/rtc/ds1374.c @@ -35,7 +35,7 @@ #include <rtc.h> #include <i2c.h>
-#if (defined(CONFIG_RTC_DS1374)) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
/*---------------------------------------------------------------------*/ #undef DEBUG_RTC diff --git a/drivers/rtc/ds1556.c b/drivers/rtc/ds1556.c index 2c496f5..f95f28e 100644 --- a/drivers/rtc/ds1556.c +++ b/drivers/rtc/ds1556.c @@ -36,8 +36,7 @@ #include <command.h> #include <rtc.h>
- -#if defined(CONFIG_RTC_DS1556) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
static uchar rtc_read( unsigned int addr ); static void rtc_write( unsigned int addr, uchar val); diff --git a/drivers/rtc/ds164x.c b/drivers/rtc/ds164x.c index 5943f87..c621a9e 100644 --- a/drivers/rtc/ds164x.c +++ b/drivers/rtc/ds164x.c @@ -37,7 +37,7 @@ #include <rtc.h>
-#if defined(CONFIG_RTC_DS164x) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
static uchar rtc_read(unsigned int addr ); static void rtc_write(unsigned int addr, uchar val); diff --git a/drivers/rtc/ds174x.c b/drivers/rtc/ds174x.c index eb3ca88..3f486b1 100644 --- a/drivers/rtc/ds174x.c +++ b/drivers/rtc/ds174x.c @@ -33,7 +33,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_DS174x) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
static uchar rtc_read( unsigned int addr ); static void rtc_write( unsigned int addr, uchar val); diff --git a/drivers/rtc/ds3231.c b/drivers/rtc/ds3231.c index 95cb186..d8cd47d 100644 --- a/drivers/rtc/ds3231.c +++ b/drivers/rtc/ds3231.c @@ -33,7 +33,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_DS3231) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
/*---------------------------------------------------------------------*/ #undef DEBUG_RTC diff --git a/drivers/rtc/m41t11.c b/drivers/rtc/m41t11.c index fce00d9..3727310 100644 --- a/drivers/rtc/m41t11.c +++ b/drivers/rtc/m41t11.c @@ -43,7 +43,7 @@ #endif */
-#if defined(CONFIG_RTC_M41T11) && defined(CFG_I2C_RTC_ADDR) && defined(CONFIG_CMD_DATE) +#if defined(CFG_I2C_RTC_ADDR) && defined(CONFIG_CMD_DATE)
static unsigned bcd2bin (uchar n) { diff --git a/drivers/rtc/m41t60.c b/drivers/rtc/m41t60.c index ef135ca..402a8c8 100644 --- a/drivers/rtc/m41t60.c +++ b/drivers/rtc/m41t60.c @@ -34,8 +34,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_M41T60) && defined(CFG_I2C_RTC_ADDR) && \ - defined(CONFIG_CMD_DATE) +#if defined(CFG_I2C_RTC_ADDR) && defined(CONFIG_CMD_DATE)
static unsigned bcd2bin(uchar n) { diff --git a/drivers/rtc/m48t35ax.c b/drivers/rtc/m48t35ax.c index be29279..353a30e 100644 --- a/drivers/rtc/m48t35ax.c +++ b/drivers/rtc/m48t35ax.c @@ -33,7 +33,7 @@ #include <rtc.h> #include <config.h>
-#if defined(CONFIG_RTC_M48T35A) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
static uchar rtc_read (uchar reg); static void rtc_write (uchar reg, uchar val); diff --git a/drivers/rtc/max6900.c b/drivers/rtc/max6900.c index e9979f2..4cfc5de 100644 --- a/drivers/rtc/max6900.c +++ b/drivers/rtc/max6900.c @@ -32,7 +32,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_MAX6900) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
#ifndef CFG_I2C_RTC_ADDR #define CFG_I2C_RTC_ADDR 0x50 diff --git a/drivers/rtc/mc146818.c b/drivers/rtc/mc146818.c index 7c4fe36..460a0e6 100644 --- a/drivers/rtc/mc146818.c +++ b/drivers/rtc/mc146818.c @@ -31,7 +31,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_MC146818) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
static uchar rtc_read (uchar reg); static void rtc_write (uchar reg, uchar val); diff --git a/drivers/rtc/mcfrtc.c b/drivers/rtc/mcfrtc.c index d235d10..30b2a81 100644 --- a/drivers/rtc/mcfrtc.c +++ b/drivers/rtc/mcfrtc.c @@ -23,7 +23,7 @@
#include <common.h>
-#if defined(CONFIG_MCFRTC) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
#include <command.h> #include <rtc.h> diff --git a/drivers/rtc/mk48t59.c b/drivers/rtc/mk48t59.c index 5981399..918c291 100644 --- a/drivers/rtc/mk48t59.c +++ b/drivers/rtc/mk48t59.c @@ -33,8 +33,6 @@ #include <rtc.h> #include <mk48t59.h>
-#if defined(CONFIG_RTC_MK48T59) - #if defined(CONFIG_BAB7xx)
static uchar rtc_read (short reg) @@ -236,4 +234,3 @@ void rtc_set_watchdog(short multi, short res) }
#endif -#endif /* CONFIG_RTC_MK48T59 */ diff --git a/drivers/rtc/mpc5xxx.c b/drivers/rtc/mpc5xxx.c index a6555f5..1450649 100644 --- a/drivers/rtc/mpc5xxx.c +++ b/drivers/rtc/mpc5xxx.c @@ -32,7 +32,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_MPC5200) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
/***************************************************************************** * this structure should be defined in mpc5200.h ... diff --git a/drivers/rtc/mpc8xx.c b/drivers/rtc/mpc8xx.c index 057547b..9435069 100644 --- a/drivers/rtc/mpc8xx.c +++ b/drivers/rtc/mpc8xx.c @@ -31,7 +31,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_MPC8xx) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
diff --git a/drivers/rtc/pcf8563.c b/drivers/rtc/pcf8563.c index c384975..1274ffa 100644 --- a/drivers/rtc/pcf8563.c +++ b/drivers/rtc/pcf8563.c @@ -32,7 +32,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_PCF8563) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
static uchar rtc_read (uchar reg); static void rtc_write (uchar reg, uchar val); diff --git a/drivers/rtc/rs5c372.c b/drivers/rtc/rs5c372.c index 1c9b752..38db199 100644 --- a/drivers/rtc/rs5c372.c +++ b/drivers/rtc/rs5c372.c @@ -34,7 +34,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_RS5C372A) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE) /* * Reads are always done starting with register 15, which requires some * jumping-through-hoops to access the data correctly. diff --git a/drivers/rtc/rx8025.c b/drivers/rtc/rx8025.c index 64eafe5..064138e 100644 --- a/drivers/rtc/rx8025.c +++ b/drivers/rtc/rx8025.c @@ -30,7 +30,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_RX8025) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
/*---------------------------------------------------------------------*/ #undef DEBUG_RTC diff --git a/drivers/rtc/s3c24x0_rtc.c b/drivers/rtc/s3c24x0_rtc.c index 358aef7..13d077b 100644 --- a/drivers/rtc/s3c24x0_rtc.c +++ b/drivers/rtc/s3c24x0_rtc.c @@ -28,7 +28,7 @@ #include <common.h> #include <command.h>
-#if defined(CONFIG_RTC_S3C24X0) && (defined(CONFIG_CMD_DATE)) +#if (defined(CONFIG_CMD_DATE))
#if defined(CONFIG_S3C2400) #include <s3c2400.h> diff --git a/drivers/rtc/x1205.c b/drivers/rtc/x1205.c index 0e18139..7025cf4 100644 --- a/drivers/rtc/x1205.c +++ b/drivers/rtc/x1205.c @@ -40,7 +40,7 @@ #include <i2c.h> #include <bcd.h>
-#if defined(CONFIG_RTC_X1205) && defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
#define CCR_SEC 0 #define CCR_MIN 1
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/serial/Makefile | 24 ++++++++++++------------ drivers/serial/atmel_usart.c | 3 --- drivers/serial/mcfuart.c | 3 --- drivers/serial/ns16550.c | 4 ---- drivers/serial/ns9750_serial.c | 4 ---- drivers/serial/s3c4510b_uart.c | 4 ---- drivers/serial/serial.c | 4 ---- drivers/serial/serial_max3100.c | 4 ---- drivers/serial/serial_pl010.c | 4 ---- drivers/serial/serial_pl011.c | 4 ---- drivers/serial/serial_sh.c | 4 ---- drivers/serial/serial_xuartlite.c | 4 ---- drivers/serial/usbtty.c | 5 ----- 13 files changed, 12 insertions(+), 59 deletions(-)
diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index c9e797e..45dfe96 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -25,18 +25,18 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libserial.a
-COBJS-y += atmel_usart.o -COBJS-y += mcfuart.o -COBJS-y += ns9750_serial.o -COBJS-y += ns16550.o -COBJS-y += s3c4510b_uart.o -COBJS-y += serial.o -COBJS-y += serial_max3100.o -COBJS-y += serial_pl010.o -COBJS-y += serial_pl011.o -COBJS-y += serial_xuartlite.o -COBJS-y += serial_sh.o -COBJS-y += usbtty.o +COBJS-$(CONFIG_ATMEL_USART) += atmel_usart.o +COBJS-$(CONFIG_MCFUART) += mcfuart.o +COBJS-$(CFG_NS9750_UART) += ns9750_serial.o +COBJS-$(CFG_NS16550) += ns16550.o +COBJS-$(CONFIG_DRIVER_S3C4510_UART) += s3c4510b_uart.o +COBJS-$(CFG_NS16550_SERIAL) += serial.o +COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o +COBJS-$(CFG_PL010_SERIAL) += serial_pl010.o +COBJS-$(CFG_PL011_SERIAL) += serial_pl011.o +COBJS-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o +COBJS-$(CFG_SCIF_CONSOLE) += serial_sh.o +COBJS-$(CONFIG_USB_TTY) += usbtty.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index f35b997..f3b146c 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -17,7 +17,6 @@ */ #include <common.h>
-#ifdef CONFIG_ATMEL_USART #include <asm/io.h> #include <asm/arch/clk.h> #include <asm/arch/memory-map.h> @@ -96,5 +95,3 @@ int serial_tstc(void) { return (usart3_readl(CSR) & USART3_BIT(RXRDY)) != 0; } - -#endif /* CONFIG_ATMEL_USART */ diff --git a/drivers/serial/mcfuart.c b/drivers/serial/mcfuart.c index 5eb4f45..a1fcd05 100644 --- a/drivers/serial/mcfuart.c +++ b/drivers/serial/mcfuart.c @@ -29,8 +29,6 @@
#include <common.h>
-#ifdef CONFIG_MCFUART - #include <asm/immap.h> #include <asm/uart.h>
@@ -130,4 +128,3 @@ void serial_setbrg(void)
uart->ucr = UART_UCR_RX_ENABLED | UART_UCR_TX_ENABLED; } -#endif /* CONFIG_MCFUART */ diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 6b3f60e..af717e0 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -6,8 +6,6 @@
#include <config.h>
-#ifdef CFG_NS16550 - #include <ns16550.h>
#define LCRVAL LCR_8N1 /* 8 data, 1 stop, no parity */ @@ -75,5 +73,3 @@ int NS16550_tstc (NS16550_t com_port) { return ((com_port->lsr & LSR_DR) != 0); } - -#endif diff --git a/drivers/serial/ns9750_serial.c b/drivers/serial/ns9750_serial.c index 02c0d39..e9645a0 100644 --- a/drivers/serial/ns9750_serial.c +++ b/drivers/serial/ns9750_serial.c @@ -28,8 +28,6 @@
#include <common.h>
-#ifdef CFG_NS9750_UART - #include "ns9750_bbus.h" /* for GPIOs */ #include "ns9750_ser.h" /* for serial configuration */
@@ -210,5 +208,3 @@ static unsigned int calcRxCharGapRegister( void ) { return NS9750_SER_RX_CHAR_TIMER_TRUN; } - -#endif /* CFG_NS9750_UART */ diff --git a/drivers/serial/s3c4510b_uart.c b/drivers/serial/s3c4510b_uart.c index ddcd591..aa378e1 100644 --- a/drivers/serial/s3c4510b_uart.c +++ b/drivers/serial/s3c4510b_uart.c @@ -45,8 +45,6 @@
#include <common.h>
-#ifdef CONFIG_DRIVER_S3C4510_UART - #include <asm/hardware.h> #include "s3c4510b_uart.h"
@@ -212,5 +210,3 @@ void serial_puts (const char *s) uart->m_ctrl.bf.sendBreak = 0;
} - -#endif diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index 4ccaee2..77a0ba5 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -23,8 +23,6 @@
#include <common.h>
-#ifdef CFG_NS16550_SERIAL - #include <ns16550.h> #ifdef CFG_NS87308 #include <ns87308.h> @@ -334,5 +332,3 @@ DECLARE_ESERIAL_FUNCTIONS(4); struct serial_device eserial4_device = INIT_ESERIAL_STRUCTURE(4,"eserial3","EUART4"); #endif /* CONFIG_SERIAL_MULTI */ - -#endif diff --git a/drivers/serial/serial_max3100.c b/drivers/serial/serial_max3100.c index 0611fc1..4abc271 100644 --- a/drivers/serial/serial_max3100.c +++ b/drivers/serial/serial_max3100.c @@ -26,8 +26,6 @@ #include <common.h> #include <watchdog.h>
-#ifdef CONFIG_MAX3100_SERIAL - DECLARE_GLOBAL_DATA_PTR;
/**************************************************************/ @@ -298,5 +296,3 @@ int serial_tstc(void) void serial_setbrg(void) { } - -#endif diff --git a/drivers/serial/serial_pl010.c b/drivers/serial/serial_pl010.c index 134ed09..436d6e0 100644 --- a/drivers/serial/serial_pl010.c +++ b/drivers/serial/serial_pl010.c @@ -31,8 +31,6 @@ #include <common.h> #include <watchdog.h>
-#ifdef CFG_PL010_SERIAL - #include "serial_pl011.h"
#define IO_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (val)) @@ -171,5 +169,3 @@ static int pl010_tstc (int portnum) return !(IO_READ (port[portnum] + UART_PL01x_FR) & UART_PL01x_FR_RXFE); } - -#endif diff --git a/drivers/serial/serial_pl011.c b/drivers/serial/serial_pl011.c index 4d35fe5..b8d394c 100644 --- a/drivers/serial/serial_pl011.c +++ b/drivers/serial/serial_pl011.c @@ -30,8 +30,6 @@
#include <common.h>
-#ifdef CFG_PL011_SERIAL - #include "serial_pl011.h"
#define IO_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (val)) @@ -157,5 +155,3 @@ static int pl011_tstc (int portnum) return !(IO_READ (port[portnum] + UART_PL01x_FR) & UART_PL01x_FR_RXFE); } - -#endif diff --git a/drivers/serial/serial_sh.c b/drivers/serial/serial_sh.c index 0801ac4..2b9eeed 100644 --- a/drivers/serial/serial_sh.c +++ b/drivers/serial/serial_sh.c @@ -20,8 +20,6 @@ #include <common.h> #include <asm/processor.h>
-#ifdef CFG_SCIF_CONSOLE - #if defined (CONFIG_CONS_SCIF0) #define SCIF_BASE SCIF0_BASE #elif defined (CONFIG_CONS_SCIF1) @@ -215,5 +213,3 @@ int serial_getc(void)
return ch; } - -#endif /* CFG_SCIF_CONSOLE */ diff --git a/drivers/serial/serial_xuartlite.c b/drivers/serial/serial_xuartlite.c index 5c41a1c..7e84aa1 100644 --- a/drivers/serial/serial_xuartlite.c +++ b/drivers/serial/serial_xuartlite.c @@ -27,8 +27,6 @@ #include <config.h> #include <asm/io.h>
-#ifdef CONFIG_XILINX_UARTLITE - #define RX_FIFO_OFFSET 0 /* receive FIFO, read only */ #define TX_FIFO_OFFSET 4 /* transmit FIFO, write only */ #define STATUS_REG_OFFSET 8 /* status register, read only */ @@ -77,5 +75,3 @@ int serial_tstc(void) { return (in_be32(UARTLITE_STATUS) & SR_RX_FIFO_VALID_DATA); } - -#endif /* CONFIG_MICROBLZE */ diff --git a/drivers/serial/usbtty.c b/drivers/serial/usbtty.c index cc2bdac..846d12e 100644 --- a/drivers/serial/usbtty.c +++ b/drivers/serial/usbtty.c @@ -23,8 +23,6 @@
#include <common.h>
-#ifdef CONFIG_USB_TTY - #include <circbuf.h> #include <devices.h> #include "usbtty.h" @@ -1007,6 +1005,3 @@ void usbtty_poll (void) udc_irq();
} - - -#endif
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/mtd/Makefile | 6 +++--- drivers/mtd/at45.c | 2 -- drivers/mtd/cfi_flash.c | 3 --- drivers/mtd/mw_eeprom.c | 5 ----- 4 files changed, 3 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index ff932a1..e1bf095 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -25,10 +25,10 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libmtd.a
-COBJS-y += at45.o -COBJS-y += cfi_flash.o +COBJS-$(CONFIG_HAS_DATAFLASH) += at45.o +COBJS-$(CFG_FLASH_CFI_DRIVER) += cfi_flash.o COBJS-$(CONFIG_HAS_DATAFLASH) += dataflash.o -COBJS-y += mw_eeprom.o +COBJS-$(CONFIG_MW_EEPROM) += mw_eeprom.o COBJS-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o
COBJS := $(COBJS-y) diff --git a/drivers/mtd/at45.c b/drivers/mtd/at45.c index a9d13ff..4739e04 100644 --- a/drivers/mtd/at45.c +++ b/drivers/mtd/at45.c @@ -21,7 +21,6 @@ #include <config.h> #include <common.h>
-#ifdef CONFIG_HAS_DATAFLASH #include <dataflash.h>
/* @@ -559,4 +558,3 @@ int AT91F_DataflashProbe(int cs, AT91PS_DataflashDesc pDesc) AT91F_DataFlashGetStatus(pDesc); return ((pDesc->command[1] == 0xFF) ? 0 : pDesc->command[1] & 0x3C); } -#endif diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index c0ea97b..5bed30d 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -39,7 +39,6 @@ #include <asm/io.h> #include <asm/byteorder.h> #include <environment.h> -#ifdef CFG_FLASH_CFI_DRIVER
/* * This file implements a Common Flash Interface (CFI) driver for @@ -2010,5 +2009,3 @@ unsigned long flash_init (void) #endif return (size); } - -#endif /* CFG_FLASH_CFI */ diff --git a/drivers/mtd/mw_eeprom.c b/drivers/mtd/mw_eeprom.c index 2b33488..f32ced4 100644 --- a/drivers/mtd/mw_eeprom.c +++ b/drivers/mtd/mw_eeprom.c @@ -1,9 +1,6 @@ /* Three-wire (MicroWire) serial eeprom driver (for 93C46 and compatibles) */
#include <common.h> - -#ifdef CONFIG_MW_EEPROM - #include <ssi.h>
/* @@ -237,5 +234,3 @@ int mw_eeprom_probe(int dev) } return 0; } - -#endif
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/misc/Makefile | 6 +++--- drivers/misc/ali512x.c | 5 ----- drivers/misc/ns87308.c | 4 ---- drivers/misc/status_led.c | 4 ---- 4 files changed, 3 insertions(+), 16 deletions(-)
diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index fe8d3d8..2e5884b 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -25,9 +25,9 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libmisc.a
-COBJS-y += ali512x.o -COBJS-y += ns87308.o -COBJS-y += status_led.o +COBJS-$(CONFIG_ALI152X) += ali512x.o +COBJS-$(CFG_NS87308) += ns87308.o +COBJS-$(CONFIG_STATUS_LED) += status_led.o COBJS-$(CONFIG_FSL_LAW) += fsl_law.o
COBJS := $(COBJS-y) diff --git a/drivers/misc/ali512x.c b/drivers/misc/ali512x.c index 90b45d9..d6a2c1f 100644 --- a/drivers/misc/ali512x.c +++ b/drivers/misc/ali512x.c @@ -32,8 +32,6 @@
#include <config.h>
-#ifdef CONFIG_ALI152X - #include <common.h> #include <asm/io.h> #include <asm/ic/ali512x.h> @@ -418,6 +416,3 @@ int ali512x_cio_in(int pin)
return data & bit; } - - -#endif diff --git a/drivers/misc/ns87308.c b/drivers/misc/ns87308.c index cf4d359..6642c2e 100644 --- a/drivers/misc/ns87308.c +++ b/drivers/misc/ns87308.c @@ -23,8 +23,6 @@
#include <config.h>
-#ifdef CFG_NS87308 - #include <ns87308.h>
void initialise_ns87308 (void) @@ -117,5 +115,3 @@ void initialise_ns87308 (void) PNP_PGCS_CSLINE_CONF(2, CFG_NS87308_CS2_CONF); #endif } - -#endif diff --git a/drivers/misc/status_led.c b/drivers/misc/status_led.c index ddb6c22..4ba3e18 100644 --- a/drivers/misc/status_led.c +++ b/drivers/misc/status_led.c @@ -35,8 +35,6 @@
-#ifdef CONFIG_STATUS_LED - typedef struct { led_id_t mask; int state; @@ -127,5 +125,3 @@ void status_led_set (int led, int state) } __led_set (ld->mask, state); } - -#endif /* CONFIG_STATUS_LED */
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/block/Makefile | 10 +++++----- drivers/block/ahci.c | 3 --- drivers/block/ata_piix.c | 4 ---- drivers/block/sil680.c | 4 +--- drivers/block/sym53c8xx.c | 5 ----- drivers/block/systemace.c | 3 --- 6 files changed, 6 insertions(+), 23 deletions(-)
diff --git a/drivers/block/Makefile b/drivers/block/Makefile index a09cd2a..95db69c 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -25,14 +25,14 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libblock.a
-COBJS-y += ahci.o -COBJS-y += ata_piix.o +COBJS-$(CONFIG_SCSI_AHCI) += ahci.o +COBJS-$(CFG_ATA_PIIX) += ata_piix.o COBJS-$(CONFIG_FSL_SATA) += fsl_sata.o COBJS-$(CONFIG_LIBATA) += libata.o COBJS-$(CONFIG_SATA_SIL3114) += sata_sil3114.o -COBJS-y += sil680.o -COBJS-y += sym53c8xx.o -COBJS-y += systemace.o +COBJS-$(CFG_IDE_SIL680) += sil680.o +COBJS-$(CONFIG_SCSI_SYM53C8XX) += sym53c8xx.o +COBJS-$(CONFIG_SYSTEMACE) += systemace.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 3d82c62..52fd108 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -26,8 +26,6 @@ */ #include <common.h>
-#ifdef CONFIG_SCSI_AHCI - #include <command.h> #include <pci.h> #include <asm/processor.h> @@ -700,4 +698,3 @@ void scsi_print_error(ccb * pccb) { /*The ahci error info can be read in the ahci driver*/ } -#endif diff --git a/drivers/block/ata_piix.c b/drivers/block/ata_piix.c index 441a4dc..4c26b36 100644 --- a/drivers/block/ata_piix.c +++ b/drivers/block/ata_piix.c @@ -35,8 +35,6 @@ #include <ide.h> #include <ata.h>
-#ifdef CFG_ATA_PIIX /*ata_piix driver */ - extern block_dev_desc_t sata_dev_desc[CFG_SATA_MAX_DEVICE]; extern int curr_device;
@@ -756,5 +754,3 @@ int scan_sata(int dev) { return 0; } - -#endif diff --git a/drivers/block/sil680.c b/drivers/block/sil680.c index a6143df..3535f20 100644 --- a/drivers/block/sil680.c +++ b/drivers/block/sil680.c @@ -54,7 +54,7 @@ */
#include <common.h> -#if defined(CFG_IDE_SIL680) + #include <ata.h> #include <ide.h> #include <pci.h> @@ -106,5 +106,3 @@ int ide_preinit (void) void ide_set_reset (int flag) { return; } - -#endif /* CFG_IDE_SIL680 */ diff --git a/drivers/block/sym53c8xx.c b/drivers/block/sym53c8xx.c index 87b63b7..9291b60 100644 --- a/drivers/block/sym53c8xx.c +++ b/drivers/block/sym53c8xx.c @@ -35,8 +35,6 @@
#include <common.h>
-#ifdef CONFIG_SCSI_SYM53C8XX - #include <command.h> #include <pci.h> #include <asm/processor.h> @@ -870,6 +868,3 @@ void scsi_chip_init(void) #endif } #endif - - -#endif /* CONFIG_SCSI_SYM53C8XX */ diff --git a/drivers/block/systemace.c b/drivers/block/systemace.c index 7d82c27..dfaab52 100644 --- a/drivers/block/systemace.c +++ b/drivers/block/systemace.c @@ -44,8 +44,6 @@ #include <part.h> #include <asm/io.h>
-#ifdef CONFIG_SYSTEMACE - /* * The ace_readw and writew functions read/write 16bit words, but the * offset value is the BYTE offset as most used in the Xilinx @@ -255,4 +253,3 @@ static unsigned long systemace_read(int dev, unsigned long start,
return blkcnt; } -#endif /* CONFIG_SYSTEMACE */
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/dma/MCD_dmaApi.c | 3 --- drivers/dma/MCD_tasks.c | 4 ---- drivers/dma/MCD_tasksInit.c | 4 ---- drivers/dma/Makefile | 2 +- 4 files changed, 1 insertions(+), 12 deletions(-)
diff --git a/drivers/dma/MCD_dmaApi.c b/drivers/dma/MCD_dmaApi.c index b0062b7..5c95651 100644 --- a/drivers/dma/MCD_dmaApi.c +++ b/drivers/dma/MCD_dmaApi.c @@ -24,8 +24,6 @@
#include <common.h>
-#ifdef CONFIG_FSLDMAFEC - #include <MCD_dma.h> #include <MCD_tasksInit.h> #include <MCD_progCheck.h> @@ -1023,4 +1021,3 @@ static void MCD_memcpy(int *dest, int *src, u32 size) for (i = 0; i < size; i += sizeof(int), dest++, src++) *dest = *src; } -#endif /* CONFIG_FSLDMAFEC */ diff --git a/drivers/dma/MCD_tasks.c b/drivers/dma/MCD_tasks.c index 06a2d53..4f6e346 100644 --- a/drivers/dma/MCD_tasks.c +++ b/drivers/dma/MCD_tasks.c @@ -24,8 +24,6 @@
#include <common.h>
u32 MCD_varTab0[]; @@ -2430,5 +2428,3 @@ u32 MCD_ENetXmit_TDT[] = { #ifdef MCD_INCLUDE_EU MCD_bufDesc MCD_singleBufDescs[NCHANNELS]; #endif - -#endif /* CONFIG_FSLDMAFEC */ diff --git a/drivers/dma/MCD_tasksInit.c b/drivers/dma/MCD_tasksInit.c index cf567db..2f19875 100644 --- a/drivers/dma/MCD_tasksInit.c +++ b/drivers/dma/MCD_tasksInit.c @@ -28,8 +28,6 @@ * Do not edit! */
extern dmaRegs *MCD_dmaBar; @@ -242,5 +240,3 @@ void MCD_startDmaENetXmit(char *bDBase, char *currBD, char *xmitFifoPtr, /* Set the task's Enable bit in its Task Control Register */ MCD_dmaBar->taskControl[channel] |= (u16) 0x8000; } - -#endif /* CONFIG_FSLDMAFEC */ diff --git a/drivers/dma/Makefile b/drivers/dma/Makefile index 7e17360..cf29efa 100644 --- a/drivers/dma/Makefile +++ b/drivers/dma/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libdma.a
-COBJS-y += MCD_tasksInit.o MCD_dmaApi.o MCD_tasks.o +COBJS-$(CONFIG_FSLDMAFEC) += MCD_tasksInit.o MCD_dmaApi.o MCD_tasks.o
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/pci/Makefile | 10 ++++------ drivers/pci/fsl_pci_init.c | 4 ---- drivers/pci/pci.c | 4 ---- drivers/pci/pci_auto.c | 5 ----- drivers/pci/pci_indirect.c | 2 -- drivers/pci/tsi108_pci.c | 4 ---- drivers/pci/w83c553f.c | 4 ---- 7 files changed, 4 insertions(+), 29 deletions(-)
diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index dec93b9..87a3a96 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -25,12 +25,10 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libpci.a
-COBJS-y += fsl_pci_init.o -COBJS-y += pci.o -COBJS-y += pci_auto.o -COBJS-y += pci_indirect.o -COBJS-y += tsi108_pci.o -COBJS-y += w83c553f.o +COBJS-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o +COBJS-$(CONFIG_PCI) += pci.o pci_auto.o pci_indirect.o +COBJS-$(CONFIG_TSI108_PCI) += tsi108_pci.o +COBJS-$(CFG_WINBOND_83C553) += w83c553f.o COBJS-$(CONFIG_SH4_PCI) += pci_sh4.o COBJS-$(CONFIG_SH7751_PCI) +=pci_sh7751.o COBJS-$(CONFIG_SH7780_PCI) +=pci_sh7780.o diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 7dc33be..2fdb8d0 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -18,8 +18,6 @@
#include <common.h>
-#ifdef CONFIG_FSL_PCI_INIT - /* * PCI/PCIE Controller initialization for mpc85xx/mpc86xx soc's * @@ -197,5 +195,3 @@ fsl_pci_init(struct pci_controller *hose) pci_hose_write_config_word(hose, dev, PCI_SEC_STATUS, 0xffff); } } - -#endif /* CONFIG_FSL_PCI */ diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 16180cb..b5eea89 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -30,8 +30,6 @@
#include <common.h>
-#ifdef CONFIG_PCI - #include <command.h> #include <asm/processor.h> #include <asm/io.h> @@ -544,5 +542,3 @@ void pci_init(void) /* now call board specific pci_init()... */ pci_init_board(); } - -#endif /* CONFIG_PCI */ diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index eb69593..944ebc7 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -14,9 +14,6 @@ */
#include <common.h> - -#ifdef CONFIG_PCI - #include <pci.h>
#undef DEBUG @@ -408,5 +405,3 @@ int pciauto_config_device(struct pci_controller *hose, pci_dev_t dev)
return sub_bus; } - -#endif /* CONFIG_PCI */ diff --git a/drivers/pci/pci_indirect.c b/drivers/pci/pci_indirect.c index 55517a8..ab51f8d 100644 --- a/drivers/pci/pci_indirect.c +++ b/drivers/pci/pci_indirect.c @@ -11,7 +11,6 @@
#include <common.h>
-#ifdef CONFIG_PCI #if (!defined(__I386__) && !defined(CONFIG_IXDP425))
#include <asm/processor.h> @@ -135,4 +134,3 @@ void pci_setup_indirect(struct pci_controller* hose, u32 cfg_addr, u32 cfg_data) }
#endif /* !__I386__ && !CONFIG_IXDP425 */ -#endif /* CONFIG_PCI */ diff --git a/drivers/pci/tsi108_pci.c b/drivers/pci/tsi108_pci.c index 4f02cb8..edd614f 100644 --- a/drivers/pci/tsi108_pci.c +++ b/drivers/pci/tsi108_pci.c @@ -27,8 +27,6 @@
#include <config.h>
-#ifdef CONFIG_TSI108_PCI - #include <common.h> #include <pci.h> #include <asm/io.h> @@ -182,5 +180,3 @@ void ft_pci_setup(void *blob, bd_t *bd) } } #endif /* CONFIG_OF_LIBFDT */ - -#endif /* CONFIG_TSI108_PCI */ diff --git a/drivers/pci/w83c553f.c b/drivers/pci/w83c553f.c index 9ea08a2..d7355a4 100644 --- a/drivers/pci/w83c553f.c +++ b/drivers/pci/w83c553f.c @@ -30,8 +30,6 @@ #include <common.h> #include <config.h>
-#ifdef CFG_WINBOND_83C553 - #include <asm/io.h> #include <pci.h>
@@ -222,5 +220,3 @@ void initialise_dma(void) out8(W83C553F_DMA1 + W83C553F_DMA1_CS, 0x00); out16(W83C553F_DMA2 + W83C553F_DMA2_CS, 0x0000); } - -#endif /* CFG_WINBOND_83C553 */
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/input/Makefile | 7 ++++--- drivers/input/i8042.c | 4 ---- drivers/input/keyboard.c | 4 ---- drivers/input/pc_keyb.c | 4 ---- 4 files changed, 4 insertions(+), 15 deletions(-)
diff --git a/drivers/input/Makefile b/drivers/input/Makefile index 2933cb6..d34c5e7 100644 --- a/drivers/input/Makefile +++ b/drivers/input/Makefile @@ -25,9 +25,10 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libinput.a
-COBJS-y += i8042.o -COBJS-y += keyboard.o -COBJS-y += pc_keyb.o ps2ser.o ps2mult.o +COBJS-$(CONFIG_I8042_KBD) += i8042.o +COBJS-$(CONFIG_PS2KBD) += keyboard.o pc_keyb.o +COBJS-$(CONFIG_PS2SERIAL) += ps2ser.o +COBJS-$(CONFIG_PS2MULT) += ps2mult.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/input/i8042.c b/drivers/input/i8042.c index 22c2a4e..d152768 100644 --- a/drivers/input/i8042.c +++ b/drivers/input/i8042.c @@ -27,8 +27,6 @@
#include <common.h>
-#ifdef CONFIG_I8042_KBD - #ifdef CONFIG_USE_CPCIDVI extern u8 gt_cpcidvi_in8(u32 offset); extern void gt_cpcidvi_out8(u32 offset, u8 data); @@ -670,5 +668,3 @@ static int kbd_reset (void)
return 0; } - -#endif /* CONFIG_I8042_KBD */ diff --git a/drivers/input/keyboard.c b/drivers/input/keyboard.c index 54182a7..a634d76 100644 --- a/drivers/input/keyboard.c +++ b/drivers/input/keyboard.c @@ -11,8 +11,6 @@
#include <common.h>
-#ifdef CONFIG_PS2KBD - #include <devices.h> #include <keyboard.h>
@@ -301,5 +299,3 @@ int kbd_init (void) } return error; } - -#endif /* CONFIG_PS2KBD */ diff --git a/drivers/input/pc_keyb.c b/drivers/input/pc_keyb.c index 81d3e98..4649580 100644 --- a/drivers/input/pc_keyb.c +++ b/drivers/input/pc_keyb.c @@ -13,8 +13,6 @@
#include <common.h>
-#ifdef CONFIG_PS2KBD - #include <keyboard.h> #include <pc_keyb.h>
@@ -252,5 +250,3 @@ void pckbd_leds(unsigned char leds) kbd_send_data(KBD_CMD_SET_LEDS); kbd_send_data(leds); } - -#endif /* CONFIG_PS2KBD */
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/video/Makefile | 16 ++++++++-------- drivers/video/ati_radeon_fb.c | 3 --- drivers/video/cfb_console.c | 3 --- drivers/video/ct69000.c | 5 ----- drivers/video/mb862xx.c | 3 --- drivers/video/sed13806.c | 3 --- drivers/video/sed156x.c | 4 ---- drivers/video/sm501.c | 4 ---- drivers/video/smiLynxEM.c | 4 ---- 9 files changed, 8 insertions(+), 37 deletions(-)
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 20a54c5..7fba29f 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -25,15 +25,15 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libvideo.a
-COBJS-y += ati_radeon_fb.o +COBJS-$(CONFIG_ATI_RADEON_FB) += ati_radeon_fb.o COBJS-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o -COBJS-y += cfb_console.o -COBJS-y += ct69000.o -COBJS-y += mb862xx.o -COBJS-y += sed13806.o -COBJS-y += sed156x.o -COBJS-y += sm501.o -COBJS-y += smiLynxEM.o +COBJS-$(CONFIG_CFB_CONSOLE) += cfb_console.o +COBJS-$(CONFIG_VIDEO_CT69000) += ct69000.o +COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o +COBJS-$(CONFIG_VIDEO_SED13806) += sed13806.o +COBJS-$(CONFIG_SED156X) += sed156x.o +COBJS-$(CONFIG_VIDEO_SM501) += sm501.o +COBJS-$(CONFIG_VIDEO_SMI_LYNXEM) += smiLynxEM.o COBJS-y += videomodes.o
COBJS := $(COBJS-y) diff --git a/drivers/video/ati_radeon_fb.c b/drivers/video/ati_radeon_fb.c index a1e7bae..650380b 100644 --- a/drivers/video/ati_radeon_fb.c +++ b/drivers/video/ati_radeon_fb.c @@ -35,8 +35,6 @@
#include <common.h>
-#ifdef CONFIG_ATI_RADEON_FB - #include <command.h> #include <pci.h> #include <asm/processor.h> @@ -777,4 +775,3 @@ void video_set_lut (unsigned int index, /* color number */ OUTREG(PALETTE_INDEX, index); OUTREG(PALETTE_DATA, (r << 16) | (g << 8) | b); } -#endif diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 68b9861..dce2a24 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -92,8 +92,6 @@ CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability of the
#include <common.h>
-#ifdef CONFIG_CFB_CONSOLE - #include <malloc.h>
/*****************************************************************************/ @@ -1337,4 +1335,3 @@ int drv_video_init (void) /* No console dev available */ return 0; } -#endif /* CONFIG_CFB_CONSOLE */ diff --git a/drivers/video/ct69000.c b/drivers/video/ct69000.c index 29d82e4..cae662e 100644 --- a/drivers/video/ct69000.c +++ b/drivers/video/ct69000.c @@ -31,8 +31,6 @@ #include <video_fb.h> #include "videomodes.h"
-#ifdef CONFIG_VIDEO_CT69000 - /* debug */ #undef VGA_DEBUG #undef VGA_DUMP_REG @@ -1280,7 +1278,4 @@ video_hw_bitblt (unsigned int bpp, /* bytes per pixel */ out32r (pGD->pciBase + BR08_o, (dim_y << 16) + dim_x); /* start the BITBlt */ video_wait_bitblt (pGD->pciBase + BR04_o); } - -#endif /* CONFIG_CT69000 */ - #endif /* CONFIG_VIDEO */ diff --git a/drivers/video/mb862xx.c b/drivers/video/mb862xx.c index 733d9a2..6c14b0d 100644 --- a/drivers/video/mb862xx.c +++ b/drivers/video/mb862xx.c @@ -28,8 +28,6 @@
#include <common.h>
-#if defined(CONFIG_VIDEO_MB862xx) - #include <asm/io.h> #include <pci.h> #include <video_fb.h> @@ -416,4 +414,3 @@ void video_hw_bitblt (unsigned int bpp, unsigned int src_x, unsigned int src_y, DE_WR_FIFO ((height << 16) | width); de_wait (); /* sync */ } -#endif /* CONFIG_VIDEO_MB862xx */ diff --git a/drivers/video/sed13806.c b/drivers/video/sed13806.c index 6996ca8..9cd19b5 100644 --- a/drivers/video/sed13806.c +++ b/drivers/video/sed13806.c @@ -25,8 +25,6 @@
#include <common.h>
-#ifdef CONFIG_VIDEO_SED13806 - #include <video_fb.h> #include <sed13806.h>
@@ -307,4 +305,3 @@ void video_init_hw_cursor (int font_width, int font_height) writeByte (LCD_CURSOR_CNTL, 1); } #endif -#endif diff --git a/drivers/video/sed156x.c b/drivers/video/sed156x.c index e9d5ed4..707250d 100644 --- a/drivers/video/sed156x.c +++ b/drivers/video/sed156x.c @@ -28,8 +28,6 @@
#include <sed156x.h>
-#ifdef CONFIG_SED156X - /* configure according to the selected display */ #if defined(CONFIG_SED156X_PG12864Q) #define LCD_WIDTH 128 @@ -562,5 +560,3 @@ void sed156x_init(void) sed156x_sync(); sed156x_cmd_transfer(LCD_ON); /* Turn display ON */ } - -#endif /* CONFIG_SED156X */ diff --git a/drivers/video/sm501.c b/drivers/video/sm501.c index 23db02c..283d2d9 100644 --- a/drivers/video/sm501.c +++ b/drivers/video/sm501.c @@ -31,8 +31,6 @@
#include <common.h>
-#ifdef CONFIG_VIDEO_SM501 - #include <video_fb.h> #include <sm501.h>
@@ -146,5 +144,3 @@ void video_set_lut ( ) { } - -#endif /* CONFIG_VIDEO_SM501 */ diff --git a/drivers/video/smiLynxEM.c b/drivers/video/smiLynxEM.c index 20f9beb..390dd56 100644 --- a/drivers/video/smiLynxEM.c +++ b/drivers/video/smiLynxEM.c @@ -40,8 +40,6 @@
#include <common.h>
-#if defined(CONFIG_VIDEO_SMI_LYNXEM) - #include <pci.h> #include <video_fb.h> #include "videomodes.h" @@ -854,5 +852,3 @@ void video_set_lut ( out8 (SMI_LUT_RGB, b>>2); /* blue */ udelay (10); } - -#endif /* CONFIG_VIDEO_SMI_LYNXEM */
Dear monstr@seznam.cz,
Applied, thanks.
Applying input: Clean drivers/input/Makefile error: patch failed: drivers/input/Makefile:25 error: drivers/input/Makefile: patch does not apply error: patch failed: drivers/input/i8042.c:27 error: drivers/input/i8042.c: patch does not apply error: patch failed: drivers/input/keyboard.c:11 error: drivers/input/keyboard.c: patch does not apply error: patch failed: drivers/input/pc_keyb.c:13 error: drivers/input/pc_keyb.c: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merged drivers/input/Makefile CONFLICT (content): Merge conflict in drivers/input/Makefile Auto-merged drivers/input/pc_keyb.c Failed to merge in the changes. Patch failed at 0010.
Please rebase and resubmit.
Applying pci: Clean drivers/pci/Makefile error: patch failed: drivers/pci/Makefile:25 error: drivers/pci/Makefile: patch does not apply error: patch failed: drivers/pci/fsl_pci_init.c:18 error: drivers/pci/fsl_pci_init.c: patch does not apply error: patch failed: drivers/pci/pci.c:30 error: drivers/pci/pci.c: patch does not apply error: patch failed: drivers/pci/pci_auto.c:14 error: drivers/pci/pci_auto.c: patch does not apply error: patch failed: drivers/pci/pci_indirect.c:11 error: drivers/pci/pci_indirect.c: patch does not apply error: patch failed: drivers/pci/tsi108_pci.c:27 error: drivers/pci/tsi108_pci.c: patch does not apply error: patch failed: drivers/pci/w83c553f.c:30 error: drivers/pci/w83c553f.c: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merged drivers/pci/Makefile CONFLICT (content): Merge conflict in drivers/pci/Makefile Auto-merged drivers/pci/fsl_pci_init.c Auto-merged drivers/pci/pci_auto.c CONFLICT (content): Merge conflict in drivers/pci/pci_auto.c Failed to merge in the changes. Patch failed at 0009.
*this one* was already applied, it seems.
Patch was already applied ?
Oops, wrong message sent.
Applying block: Clean drivers/block/Makefile error: patch failed: drivers/block/Makefile:25 error: drivers/block/Makefile: patch does not apply error: patch failed: drivers/block/ahci.c:26 error: drivers/block/ahci.c: patch does not apply error: patch failed: drivers/block/ata_piix.c:35 error: drivers/block/ata_piix.c: patch does not apply error: patch failed: drivers/block/sil680.c:54 error: drivers/block/sil680.c: patch does not apply error: patch failed: drivers/block/sym53c8xx.c:35 error: drivers/block/sym53c8xx.c: patch does not apply error: patch failed: drivers/block/systemace.c:44 error: drivers/block/systemace.c: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merged drivers/block/Makefile CONFLICT (content): Merge conflict in drivers/block/Makefile Auto-merged drivers/block/sil680.c CONFLICT (content): Merge conflict in drivers/block/sil680.c Auto-merged drivers/block/sym53c8xx.c Failed to merge in the changes. Patch failed at 0007.
Applying misc: Clean drivers/misc/Makefile error: patch failed: drivers/misc/Makefile:25 error: drivers/misc/Makefile: patch does not apply error: patch failed: drivers/misc/ali512x.c:32 error: drivers/misc/ali512x.c: patch does not apply error: patch failed: drivers/misc/ns87308.c:23 error: drivers/misc/ns87308.c: patch does not apply error: patch failed: drivers/misc/status_led.c:35 error: drivers/misc/status_led.c: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merged drivers/misc/Makefile CONFLICT (content): Merge conflict in drivers/misc/Makefile Failed to merge in the changes. Patch failed at 0006.
error: patch failed: drivers/mtd/Makefile:25 error: drivers/mtd/Makefile: patch does not apply error: patch failed: drivers/mtd/at45.c:21 error: drivers/mtd/at45.c: patch does not apply error: patch failed: drivers/mtd/cfi_flash.c:39 error: drivers/mtd/cfi_flash.c: patch does not apply error: patch failed: drivers/mtd/mw_eeprom.c:1 error: drivers/mtd/mw_eeprom.c: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merged drivers/mtd/Makefile CONFLICT (content): Merge conflict in drivers/mtd/Makefile Auto-merged drivers/mtd/at45.c CONFLICT (content): Merge conflict in drivers/mtd/at45.c Auto-merged drivers/mtd/cfi_flash.c Failed to merge in the changes. Patch failed at 0005.
This patch does not apply any more:
error: patch failed: drivers/serial/Makefile:25 error: drivers/serial/Makefile: patch does not apply error: patch failed: drivers/serial/atmel_usart.c:17 error: drivers/serial/atmel_usart.c: patch does not apply error: patch failed: drivers/serial/mcfuart.c:29 error: drivers/serial/mcfuart.c: patch does not apply error: patch failed: drivers/serial/ns9750_serial.c:28 error: drivers/serial/ns9750_serial.c: patch does not apply error: patch failed: drivers/serial/s3c4510b_uart.c:45 error: drivers/serial/s3c4510b_uart.c: patch does not apply error: patch failed: drivers/serial/serial.c:23 error: drivers/serial/serial.c: patch does not apply error: patch failed: drivers/serial/serial_max3100.c:26 error: drivers/serial/serial_max3100.c: patch does not apply error: patch failed: drivers/serial/serial_sh.c:20 error: drivers/serial/serial_sh.c: patch does not apply error: patch failed: drivers/serial/serial_xuartlite.c:27 error: drivers/serial/serial_xuartlite.c: patch does not apply error: patch failed: drivers/serial/usbtty.c:23 error: drivers/serial/usbtty.c: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merged drivers/serial/Makefile CONFLICT (content): Merge conflict in drivers/serial/Makefile Auto-merged drivers/serial/serial.c Auto-merged drivers/serial/serial_xuartlite.c Auto-merged drivers/serial/usbtty.c Failed to merge in the changes. Patch failed at 0004.
Applied, thanks.
This patch doesn't apply any more:
error: patch failed: drivers/usb/Makefile:25 error: drivers/usb/Makefile: patch does not apply error: patch failed: drivers/usb/usbdcore_omap1510.c:28 error: drivers/usb/usbdcore_omap1510.c: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merged drivers/usb/Makefile CONFLICT (content): Merge conflict in drivers/usb/Makefile Auto-merged drivers/usb/usbdcore_omap1510.c CONFLICT (content): Merge conflict in drivers/usb/usbdcore_omap1510.c Failed to merge in the changes. Patch failed at 0002.
Applied, thanks.
Hi Wolfgang,
the patches are older and progress in U-BOOT is too big. That's why some patches contains faults. And you applied some patches from Jean-Christophe before these which fixed the same issue.
In driver folder only pcmcia and usb need some fix in Makefile.
Regards, Michal
Applied, thanks.
Dear Michal Simek,
In message 48AA650D.7040002@seznam.cz you wrote:
Hi Wolfgang,
Yes, please - post patches.
Michal Simek
monstr@seznam.cz
