[U-Boot] [PATCH 00/20] Add Intel Arria 10 SoC support
This patchset adds support to Intel Arria 10 SoC. This is initial patchset enables the basic support for Arria 10 and other features will come after this.
Tien Fong submitted the initial version previously as in [1] and Marek suggested to restructure the whole patch series. So, this series resolve comments from [1] and restructure all the patches. Since the patch series is changed, so I start this with new version number v1.
This series is working on top of “arm: socfpga: Move to using distro boot” series [2] from Dalon Westergreen.
[1]: https://www.mail-archive.com/u-boot@lists.denx.de/msg235503.html [2]: https://www.mail-archive.com/u-boot@lists.denx.de/msg239560.html
Regards Ley Foon
Ley Foon Tan (20): arm: socfpga: restructure clock manager driver arm: socfpga: restructure reset manager driver arm: socfpga: restructure misc driver arm: socfpga: restructure system manager arm: socfpga: add A10 defines arm: socfpga: add reset driver support for Arria 10 arm: socfpga: add clock driver for Arria 10 arm: socfpga: add system manager for Arria 10 arm: socfpga: add sdram header file for Arria 10 arm: socfpga: add misc support for Arria 10 arm: socfpga: add pinmux for Arria 10 fdt: add compatible strings for Arria 10 arm: dts: add dts and dtsi for Arria 10 arm: socfpga: add SPL support for Arria 10 drivers: Makefile: include fpga build in SPL drivers: fpga: add compile switch for Gen5 only registers arm: socfpga: convert Altera ddr driver to use Kconfig arm: socfpga: add config and defconfig for Arria 10 arm: socfpga: add board files for the Arria10 arm: socfpga: enable build for Arria 10
arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_arria10.dtsi | 859 +++++++++++++++ arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 30 + .../dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi | 479 +++++++++ arch/arm/mach-socfpga/Kconfig | 9 + arch/arm/mach-socfpga/Makefile | 41 +- arch/arm/mach-socfpga/clock_manager.c | 532 +--------- arch/arm/mach-socfpga/clock_manager_arria10.c | 1104 ++++++++++++++++++++ arch/arm/mach-socfpga/clock_manager_gen5.c | 521 +++++++++ arch/arm/mach-socfpga/include/mach/base_addr_a10.h | 8 +- arch/arm/mach-socfpga/include/mach/clock_manager.h | 313 +----- .../include/mach/clock_manager_arria10.h | 231 ++++ .../mach-socfpga/include/mach/clock_manager_gen5.h | 322 ++++++ arch/arm/mach-socfpga/include/mach/misc.h | 32 + arch/arm/mach-socfpga/include/mach/pinmux.h | 15 + arch/arm/mach-socfpga/include/mach/reset_manager.h | 44 +- .../include/mach/reset_manager_arria10.h | 144 +++ .../mach-socfpga/include/mach/reset_manager_gen5.h | 47 + arch/arm/mach-socfpga/include/mach/sdram_arria10.h | 380 +++++++ .../arm/mach-socfpga/include/mach/system_manager.h | 177 ++-- .../include/mach/system_manager_arria10.h | 81 ++ .../include/mach/system_manager_gen5.h | 122 +++ arch/arm/mach-socfpga/misc.c | 361 +------ arch/arm/mach-socfpga/misc_arria10.c | 262 +++++ arch/arm/mach-socfpga/misc_gen5.c | 356 +++++++ arch/arm/mach-socfpga/pinmux_arria10.c | 98 ++ arch/arm/mach-socfpga/reset_manager.c | 93 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 406 +++++++ arch/arm/mach-socfpga/reset_manager_gen5.c | 113 ++ arch/arm/mach-socfpga/spl.c | 92 +- arch/arm/mach-socfpga/system_manager.c | 85 -- arch/arm/mach-socfpga/system_manager_gen5.c | 85 ++ board/altera/arria10-socdk/Kconfig | 18 + board/altera/arria10-socdk/Makefile | 7 + board/altera/arria10-socdk/socfpga.c | 7 + configs/socfpga_arria10_defconfig | 30 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/ddr/Kconfig | 1 + drivers/ddr/altera/Kconfig | 6 + drivers/fpga/socfpga.c | 6 + include/configs/socfpga_arria10_socdk.h | 67 ++ include/configs/socfpga_common.h | 30 +- include/dt-bindings/reset/altr,rst-mgr-a10.h | 103 ++ include/fdtdec.h | 8 + lib/fdtdec.c | 8 + 46 files changed, 6244 insertions(+), 1493 deletions(-) create mode 100644 arch/arm/dts/socfpga_arria10.dtsi create mode 100644 arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts create mode 100644 arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi create mode 100644 arch/arm/mach-socfpga/clock_manager_arria10.c create mode 100644 arch/arm/mach-socfpga/clock_manager_gen5.c create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h create mode 100644 arch/arm/mach-socfpga/include/mach/misc.h create mode 100644 arch/arm/mach-socfpga/include/mach/pinmux.h create mode 100755 arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h create mode 100755 arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h create mode 100644 arch/arm/mach-socfpga/include/mach/sdram_arria10.h create mode 100755 arch/arm/mach-socfpga/include/mach/system_manager_arria10.h create mode 100755 arch/arm/mach-socfpga/include/mach/system_manager_gen5.h create mode 100644 arch/arm/mach-socfpga/misc_arria10.c create mode 100755 arch/arm/mach-socfpga/misc_gen5.c create mode 100644 arch/arm/mach-socfpga/pinmux_arria10.c create mode 100644 arch/arm/mach-socfpga/reset_manager_arria10.c create mode 100755 arch/arm/mach-socfpga/reset_manager_gen5.c delete mode 100644 arch/arm/mach-socfpga/system_manager.c create mode 100644 arch/arm/mach-socfpga/system_manager_gen5.c create mode 100644 board/altera/arria10-socdk/Kconfig create mode 100644 board/altera/arria10-socdk/Makefile create mode 100644 board/altera/arria10-socdk/socfpga.c create mode 100644 configs/socfpga_arria10_defconfig create mode 100644 drivers/ddr/Kconfig create mode 100644 drivers/ddr/altera/Kconfig create mode 100644 include/configs/socfpga_arria10_socdk.h create mode 100644 include/dt-bindings/reset/altr,rst-mgr-a10.h
Restructure clock manager driver in the preparation to support A10. Move the Gen5 specific code to _gen5 files. No functional change.
Change all uint32_t to u32 and change to use macro BIT(n) for bit shift.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 3 +- arch/arm/mach-socfpga/clock_manager.c | 496 +-------------------- arch/arm/mach-socfpga/clock_manager_gen5.c | 495 ++++++++++++++++++++ arch/arm/mach-socfpga/include/mach/clock_manager.h | 311 +------------ .../mach-socfpga/include/mach/clock_manager_gen5.h | 322 +++++++++++++ 5 files changed, 830 insertions(+), 797 deletions(-) create mode 100755 arch/arm/mach-socfpga/clock_manager_gen5.c create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 809cd47..b76de4c 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -13,7 +13,8 @@ obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
# QTS-generated config file wrappers -obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ + clock_manager_gen5.o obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index 29e18f8..d675973 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -13,10 +13,10 @@ DECLARE_GLOBAL_DATA_PTR; static const struct socfpga_clock_manager *clock_manager_base = (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS;
-static void cm_wait_for_lock(uint32_t mask) +void cm_wait_for_lock(u32 mask) { - register uint32_t inter_val; - uint32_t retry = 0; + register u32 inter_val; + u32 retry = 0; do { inter_val = readl(&clock_manager_base->inter) & mask; if (inter_val == mask) @@ -29,498 +29,12 @@ static void cm_wait_for_lock(uint32_t mask) }
/* function to poll in the fsm busy bit */ -static void cm_wait_for_fsm(void) +void cm_wait_for_fsm(void) { while (readl(&clock_manager_base->stat) & CLKMGR_STAT_BUSY) ; }
-/* - * function to write the bypass register which requires a poll of the - * busy bit - */ -static void cm_write_bypass(uint32_t val) -{ - writel(val, &clock_manager_base->bypass); - cm_wait_for_fsm(); -} - -/* function to write the ctrl register which requires a poll of the busy bit */ -static void cm_write_ctrl(uint32_t val) -{ - writel(val, &clock_manager_base->ctrl); - cm_wait_for_fsm(); -} - -/* function to write a clock register that has phase information */ -static void cm_write_with_phase(uint32_t value, - uint32_t reg_address, uint32_t mask) -{ - /* poll until phase is zero */ - while (readl(reg_address) & mask) - ; - - writel(value, reg_address); - - while (readl(reg_address) & mask) - ; -} - -/* - * Setup clocks while making no assumptions about previous state of the clocks. - * - * Start by being paranoid and gate all sw managed clocks - * Put all plls in bypass - * Put all plls VCO registers back to reset value (bandgap power down). - * Put peripheral and main pll src to reset value to avoid glitch. - * Delay 5 us. - * Deassert bandgap power down and set numerator and denominator - * Start 7 us timer. - * set internal dividers - * Wait for 7 us timer. - * Enable plls - * Set external dividers while plls are locking - * Wait for pll lock - * Assert/deassert outreset all. - * Take all pll's out of bypass - * Clear safe mode - * set source main and peripheral clocks - * Ungate clocks - */ - -void cm_basic_init(const struct cm_config * const cfg) -{ - unsigned long end; - - /* Start by being paranoid and gate all sw managed clocks */ - - /* - * We need to disable nandclk - * and then do another apb access before disabling - * gatting off the rest of the periperal clocks. - */ - writel(~CLKMGR_PERPLLGRP_EN_NANDCLK_MASK & - readl(&clock_manager_base->per_pll.en), - &clock_manager_base->per_pll.en); - - /* DO NOT GATE OFF DEBUG CLOCKS & BRIDGE CLOCKS */ - writel(CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK | - CLKMGR_MAINPLLGRP_EN_DBGTRACECLK_MASK | - CLKMGR_MAINPLLGRP_EN_DBGCLK_MASK | - CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK | - CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK | - CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK, - &clock_manager_base->main_pll.en); - - writel(0, &clock_manager_base->sdr_pll.en); - - /* now we can gate off the rest of the peripheral clocks */ - writel(0, &clock_manager_base->per_pll.en); - - /* Put all plls in bypass */ - cm_write_bypass(CLKMGR_BYPASS_PERPLL | CLKMGR_BYPASS_SDRPLL | - CLKMGR_BYPASS_MAINPLL); - - /* Put all plls VCO registers back to reset value. */ - writel(CLKMGR_MAINPLLGRP_VCO_RESET_VALUE & - ~CLKMGR_MAINPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->main_pll.vco); - writel(CLKMGR_PERPLLGRP_VCO_RESET_VALUE & - ~CLKMGR_PERPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->per_pll.vco); - writel(CLKMGR_SDRPLLGRP_VCO_RESET_VALUE & - ~CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->sdr_pll.vco); - - /* - * The clocks to the flash devices and the L4_MAIN clocks can - * glitch when coming out of safe mode if their source values - * are different from their reset value. So the trick it to - * put them back to their reset state, and change input - * after exiting safe mode but before ungating the clocks. - */ - writel(CLKMGR_PERPLLGRP_SRC_RESET_VALUE, - &clock_manager_base->per_pll.src); - writel(CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE, - &clock_manager_base->main_pll.l4src); - - /* read back for the required 5 us delay. */ - readl(&clock_manager_base->main_pll.vco); - readl(&clock_manager_base->per_pll.vco); - readl(&clock_manager_base->sdr_pll.vco); - - - /* - * We made sure bgpwr down was assert for 5 us. Now deassert BG PWR DN - * with numerator and denominator. - */ - writel(cfg->main_vco_base, &clock_manager_base->main_pll.vco); - writel(cfg->peri_vco_base, &clock_manager_base->per_pll.vco); - writel(cfg->sdram_vco_base, &clock_manager_base->sdr_pll.vco); - - /* - * Time starts here. Must wait 7 us from - * BGPWRDN_SET(0) to VCO_ENABLE_SET(1). - */ - end = timer_get_us() + 7; - - /* main mpu */ - writel(cfg->mpuclk, &clock_manager_base->main_pll.mpuclk); - - /* altera group mpuclk */ - writel(cfg->altera_grp_mpuclk, &clock_manager_base->altera.mpuclk); - - /* main main clock */ - writel(cfg->mainclk, &clock_manager_base->main_pll.mainclk); - - /* main for dbg */ - writel(cfg->dbgatclk, &clock_manager_base->main_pll.dbgatclk); - - /* main for cfgs2fuser0clk */ - writel(cfg->cfg2fuser0clk, - &clock_manager_base->main_pll.cfgs2fuser0clk); - - /* Peri emac0 50 MHz default to RMII */ - writel(cfg->emac0clk, &clock_manager_base->per_pll.emac0clk); - - /* Peri emac1 50 MHz default to RMII */ - writel(cfg->emac1clk, &clock_manager_base->per_pll.emac1clk); - - /* Peri QSPI */ - writel(cfg->mainqspiclk, &clock_manager_base->main_pll.mainqspiclk); - - writel(cfg->perqspiclk, &clock_manager_base->per_pll.perqspiclk); - - /* Peri pernandsdmmcclk */ - writel(cfg->mainnandsdmmcclk, - &clock_manager_base->main_pll.mainnandsdmmcclk); - - writel(cfg->pernandsdmmcclk, - &clock_manager_base->per_pll.pernandsdmmcclk); - - /* Peri perbaseclk */ - writel(cfg->perbaseclk, &clock_manager_base->per_pll.perbaseclk); - - /* Peri s2fuser1clk */ - writel(cfg->s2fuser1clk, &clock_manager_base->per_pll.s2fuser1clk); - - /* 7 us must have elapsed before we can enable the VCO */ - while (timer_get_us() < end) - ; - - /* Enable vco */ - /* main pll vco */ - writel(cfg->main_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->main_pll.vco); - - /* periferal pll */ - writel(cfg->peri_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->per_pll.vco); - - /* sdram pll vco */ - writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->sdr_pll.vco); - - /* L3 MP and L3 SP */ - writel(cfg->maindiv, &clock_manager_base->main_pll.maindiv); - - writel(cfg->dbgdiv, &clock_manager_base->main_pll.dbgdiv); - - writel(cfg->tracediv, &clock_manager_base->main_pll.tracediv); - - /* L4 MP, L4 SP, can0, and can1 */ - writel(cfg->perdiv, &clock_manager_base->per_pll.div); - - writel(cfg->gpiodiv, &clock_manager_base->per_pll.gpiodiv); - -#define LOCKED_MASK \ - (CLKMGR_INTER_SDRPLLLOCKED_MASK | \ - CLKMGR_INTER_PERPLLLOCKED_MASK | \ - CLKMGR_INTER_MAINPLLLOCKED_MASK) - - cm_wait_for_lock(LOCKED_MASK); - - /* write the sdram clock counters before toggling outreset all */ - writel(cfg->ddrdqsclk & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddrdqsclk); - - writel(cfg->ddr2xdqsclk & CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddr2xdqsclk); - - writel(cfg->ddrdqclk & CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddrdqclk); - - writel(cfg->s2fuser2clk & CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_MASK, - &clock_manager_base->sdr_pll.s2fuser2clk); - - /* - * after locking, but before taking out of bypass - * assert/deassert outresetall - */ - uint32_t mainvco = readl(&clock_manager_base->main_pll.vco); - - /* assert main outresetall */ - writel(mainvco | CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->main_pll.vco); - - uint32_t periphvco = readl(&clock_manager_base->per_pll.vco); - - /* assert pheriph outresetall */ - writel(periphvco | CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->per_pll.vco); - - /* assert sdram outresetall */ - writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN| - CLKMGR_SDRPLLGRP_VCO_OUTRESETALL, - &clock_manager_base->sdr_pll.vco); - - /* deassert main outresetall */ - writel(mainvco & ~CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->main_pll.vco); - - /* deassert pheriph outresetall */ - writel(periphvco & ~CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->per_pll.vco); - - /* deassert sdram outresetall */ - writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->sdr_pll.vco); - - /* - * now that we've toggled outreset all, all the clocks - * are aligned nicely; so we can change any phase. - */ - cm_write_with_phase(cfg->ddrdqsclk, - (uint32_t)&clock_manager_base->sdr_pll.ddrdqsclk, - CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK); - - /* SDRAM DDR2XDQSCLK */ - cm_write_with_phase(cfg->ddr2xdqsclk, - (uint32_t)&clock_manager_base->sdr_pll.ddr2xdqsclk, - CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK); - - cm_write_with_phase(cfg->ddrdqclk, - (uint32_t)&clock_manager_base->sdr_pll.ddrdqclk, - CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK); - - cm_write_with_phase(cfg->s2fuser2clk, - (uint32_t)&clock_manager_base->sdr_pll.s2fuser2clk, - CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK); - - /* Take all three PLLs out of bypass when safe mode is cleared. */ - cm_write_bypass(0); - - /* clear safe mode */ - cm_write_ctrl(readl(&clock_manager_base->ctrl) | CLKMGR_CTRL_SAFEMODE); - - /* - * now that safe mode is clear with clocks gated - * it safe to change the source mux for the flashes the the L4_MAIN - */ - writel(cfg->persrc, &clock_manager_base->per_pll.src); - writel(cfg->l4src, &clock_manager_base->main_pll.l4src); - - /* Now ungate non-hw-managed clocks */ - writel(~0, &clock_manager_base->main_pll.en); - writel(~0, &clock_manager_base->per_pll.en); - writel(~0, &clock_manager_base->sdr_pll.en); - - /* Clear the loss of lock bits (write 1 to clear) */ - writel(CLKMGR_INTER_SDRPLLLOST_MASK | CLKMGR_INTER_PERPLLLOST_MASK | - CLKMGR_INTER_MAINPLLLOST_MASK, - &clock_manager_base->inter); -} - -static unsigned int cm_get_main_vco_clk_hz(void) -{ - uint32_t reg, clock; - - /* get the main VCO clock */ - reg = readl(&clock_manager_base->main_pll.vco); - clock = cm_get_osc_clk_hz(1); - clock /= ((reg & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_MAINPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET) + 1; - - return clock; -} - -static unsigned int cm_get_per_vco_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify PER PLL clock source */ - reg = readl(&clock_manager_base->per_pll.vco); - reg = (reg & CLKMGR_PERPLLGRP_VCO_SSRC_MASK) >> - CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET; - if (reg == CLKMGR_VCO_SSRC_EOSC1) - clock = cm_get_osc_clk_hz(1); - else if (reg == CLKMGR_VCO_SSRC_EOSC2) - clock = cm_get_osc_clk_hz(2); - else if (reg == CLKMGR_VCO_SSRC_F2S) - clock = cm_get_f2s_per_ref_clk_hz(); - - /* get the PER VCO clock */ - reg = readl(&clock_manager_base->per_pll.vco); - clock /= ((reg & CLKMGR_PERPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_PERPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET) + 1; - - return clock; -} - -unsigned long cm_get_mpu_clk_hz(void) -{ - uint32_t reg, clock; - - clock = cm_get_main_vco_clk_hz(); - - /* get the MPU clock */ - reg = readl(&clock_manager_base->altera.mpuclk); - clock /= (reg + 1); - reg = readl(&clock_manager_base->main_pll.mpuclk); - clock /= (reg + 1); - return clock; -} - -unsigned long cm_get_sdram_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify SDRAM PLL clock source */ - reg = readl(&clock_manager_base->sdr_pll.vco); - reg = (reg & CLKMGR_SDRPLLGRP_VCO_SSRC_MASK) >> - CLKMGR_SDRPLLGRP_VCO_SSRC_OFFSET; - if (reg == CLKMGR_VCO_SSRC_EOSC1) - clock = cm_get_osc_clk_hz(1); - else if (reg == CLKMGR_VCO_SSRC_EOSC2) - clock = cm_get_osc_clk_hz(2); - else if (reg == CLKMGR_VCO_SSRC_F2S) - clock = cm_get_f2s_sdr_ref_clk_hz(); - - /* get the SDRAM VCO clock */ - reg = readl(&clock_manager_base->sdr_pll.vco); - clock /= ((reg & CLKMGR_SDRPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_SDRPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_SDRPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_SDRPLLGRP_VCO_NUMER_OFFSET) + 1; - - /* get the SDRAM (DDR_DQS) clock */ - reg = readl(&clock_manager_base->sdr_pll.ddrdqsclk); - reg = (reg & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK) >> - CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_OFFSET; - clock /= (reg + 1); - - return clock; -} - -unsigned int cm_get_l4_sp_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify the source of L4 SP clock */ - reg = readl(&clock_manager_base->main_pll.l4src); - reg = (reg & CLKMGR_MAINPLLGRP_L4SRC_L4SP) >> - CLKMGR_MAINPLLGRP_L4SRC_L4SP_OFFSET; - - if (reg == CLKMGR_L4_SP_CLK_SRC_MAINPLL) { - clock = cm_get_main_vco_clk_hz(); - - /* get the clock prior L4 SP divider (main clk) */ - reg = readl(&clock_manager_base->altera.mainclk); - clock /= (reg + 1); - reg = readl(&clock_manager_base->main_pll.mainclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_L4_SP_CLK_SRC_PERPLL) { - clock = cm_get_per_vco_clk_hz(); - - /* get the clock prior L4 SP divider (periph_base_clk) */ - reg = readl(&clock_manager_base->per_pll.perbaseclk); - clock /= (reg + 1); - } - - /* get the L4 SP clock which supplied to UART */ - reg = readl(&clock_manager_base->main_pll.maindiv); - reg = (reg & CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_MASK) >> - CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_OFFSET; - clock = clock / (1 << reg); - - return clock; -} - -unsigned int cm_get_mmc_controller_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify the source of MMC clock */ - reg = readl(&clock_manager_base->per_pll.src); - reg = (reg & CLKMGR_PERPLLGRP_SRC_SDMMC_MASK) >> - CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET; - - if (reg == CLKMGR_SDMMC_CLK_SRC_F2S) { - clock = cm_get_f2s_per_ref_clk_hz(); - } else if (reg == CLKMGR_SDMMC_CLK_SRC_MAIN) { - clock = cm_get_main_vco_clk_hz(); - - /* get the SDMMC clock */ - reg = readl(&clock_manager_base->main_pll.mainnandsdmmcclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_SDMMC_CLK_SRC_PER) { - clock = cm_get_per_vco_clk_hz(); - - /* get the SDMMC clock */ - reg = readl(&clock_manager_base->per_pll.pernandsdmmcclk); - clock /= (reg + 1); - } - - /* further divide by 4 as we have fixed divider at wrapper */ - clock /= 4; - return clock; -} - -unsigned int cm_get_qspi_controller_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify the source of QSPI clock */ - reg = readl(&clock_manager_base->per_pll.src); - reg = (reg & CLKMGR_PERPLLGRP_SRC_QSPI_MASK) >> - CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET; - - if (reg == CLKMGR_QSPI_CLK_SRC_F2S) { - clock = cm_get_f2s_per_ref_clk_hz(); - } else if (reg == CLKMGR_QSPI_CLK_SRC_MAIN) { - clock = cm_get_main_vco_clk_hz(); - - /* get the qspi clock */ - reg = readl(&clock_manager_base->main_pll.mainqspiclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_QSPI_CLK_SRC_PER) { - clock = cm_get_per_vco_clk_hz(); - - /* get the qspi clock */ - reg = readl(&clock_manager_base->per_pll.perqspiclk); - clock /= (reg + 1); - } - - return clock; -} - -unsigned int cm_get_spi_controller_clk_hz(void) -{ - uint32_t reg, clock = 0; - - clock = cm_get_per_vco_clk_hz(); - - /* get the clock prior L4 SP divider (periph_base_clk) */ - reg = readl(&clock_manager_base->per_pll.perbaseclk); - clock /= (reg + 1); - - return clock; -} - static void cm_print_clock_quick_summary(void) { printf("MPU %10ld kHz\n", cm_get_mpu_clk_hz() / 1000); diff --git a/arch/arm/mach-socfpga/clock_manager_gen5.c b/arch/arm/mach-socfpga/clock_manager_gen5.c new file mode 100755 index 0000000..1df2ed4 --- /dev/null +++ b/arch/arm/mach-socfpga/clock_manager_gen5.c @@ -0,0 +1,495 @@ +/* + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock_manager.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_clock_manager *clock_manager_base = + (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; + +/* + * function to write the bypass register which requires a poll of the + * busy bit + */ +static void cm_write_bypass(u32 val) +{ + writel(val, &clock_manager_base->bypass); + cm_wait_for_fsm(); +} + +/* function to write the ctrl register which requires a poll of the busy bit */ +static void cm_write_ctrl(u32 val) +{ + writel(val, &clock_manager_base->ctrl); + cm_wait_for_fsm(); +} + +/* function to write a clock register that has phase information */ +static void cm_write_with_phase(u32 value, + u32 reg_address, u32 mask) +{ + /* poll until phase is zero */ + while (readl(reg_address) & mask) + ; + + writel(value, reg_address); + + while (readl(reg_address) & mask) + ; +} + +/* + * Setup clocks while making no assumptions about previous state of the clocks. + * + * Start by being paranoid and gate all sw managed clocks + * Put all plls in bypass + * Put all plls VCO registers back to reset value (bandgap power down). + * Put peripheral and main pll src to reset value to avoid glitch. + * Delay 5 us. + * Deassert bandgap power down and set numerator and denominator + * Start 7 us timer. + * set internal dividers + * Wait for 7 us timer. + * Enable plls + * Set external dividers while plls are locking + * Wait for pll lock + * Assert/deassert outreset all. + * Take all pll's out of bypass + * Clear safe mode + * set source main and peripheral clocks + * Ungate clocks + */ + +void cm_basic_init(const struct cm_config * const cfg) +{ + unsigned long end; + + /* Start by being paranoid and gate all sw managed clocks */ + + /* + * We need to disable nandclk + * and then do another apb access before disabling + * gatting off the rest of the periperal clocks. + */ + writel(~CLKMGR_PERPLLGRP_EN_NANDCLK_MASK & + readl(&clock_manager_base->per_pll.en), + &clock_manager_base->per_pll.en); + + /* DO NOT GATE OFF DEBUG CLOCKS & BRIDGE CLOCKS */ + writel(CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK | + CLKMGR_MAINPLLGRP_EN_DBGTRACECLK_MASK | + CLKMGR_MAINPLLGRP_EN_DBGCLK_MASK | + CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK | + CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK | + CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK, + &clock_manager_base->main_pll.en); + + writel(0, &clock_manager_base->sdr_pll.en); + + /* now we can gate off the rest of the peripheral clocks */ + writel(0, &clock_manager_base->per_pll.en); + + /* Put all plls in bypass */ + cm_write_bypass(CLKMGR_BYPASS_PERPLL | CLKMGR_BYPASS_SDRPLL | + CLKMGR_BYPASS_MAINPLL); + + /* Put all plls VCO registers back to reset value. */ + writel(CLKMGR_MAINPLLGRP_VCO_RESET_VALUE & + ~CLKMGR_MAINPLLGRP_VCO_REGEXTSEL_MASK, + &clock_manager_base->main_pll.vco); + writel(CLKMGR_PERPLLGRP_VCO_RESET_VALUE & + ~CLKMGR_PERPLLGRP_VCO_REGEXTSEL_MASK, + &clock_manager_base->per_pll.vco); + writel(CLKMGR_SDRPLLGRP_VCO_RESET_VALUE & + ~CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK, + &clock_manager_base->sdr_pll.vco); + + /* + * The clocks to the flash devices and the L4_MAIN clocks can + * glitch when coming out of safe mode if their source values + * are different from their reset value. So the trick it to + * put them back to their reset state, and change input + * after exiting safe mode but before ungating the clocks. + */ + writel(CLKMGR_PERPLLGRP_SRC_RESET_VALUE, + &clock_manager_base->per_pll.src); + writel(CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE, + &clock_manager_base->main_pll.l4src); + + /* read back for the required 5 us delay. */ + readl(&clock_manager_base->main_pll.vco); + readl(&clock_manager_base->per_pll.vco); + readl(&clock_manager_base->sdr_pll.vco); + + + /* + * We made sure bgpwr down was assert for 5 us. Now deassert BG PWR DN + * with numerator and denominator. + */ + writel(cfg->main_vco_base, &clock_manager_base->main_pll.vco); + writel(cfg->peri_vco_base, &clock_manager_base->per_pll.vco); + writel(cfg->sdram_vco_base, &clock_manager_base->sdr_pll.vco); + + /* + * Time starts here. Must wait 7 us from + * BGPWRDN_SET(0) to VCO_ENABLE_SET(1). + */ + end = timer_get_us() + 7; + + /* main mpu */ + writel(cfg->mpuclk, &clock_manager_base->main_pll.mpuclk); + + /* altera group mpuclk */ + writel(cfg->altera_grp_mpuclk, &clock_manager_base->altera.mpuclk); + + /* main main clock */ + writel(cfg->mainclk, &clock_manager_base->main_pll.mainclk); + + /* main for dbg */ + writel(cfg->dbgatclk, &clock_manager_base->main_pll.dbgatclk); + + /* main for cfgs2fuser0clk */ + writel(cfg->cfg2fuser0clk, + &clock_manager_base->main_pll.cfgs2fuser0clk); + + /* Peri emac0 50 MHz default to RMII */ + writel(cfg->emac0clk, &clock_manager_base->per_pll.emac0clk); + + /* Peri emac1 50 MHz default to RMII */ + writel(cfg->emac1clk, &clock_manager_base->per_pll.emac1clk); + + /* Peri QSPI */ + writel(cfg->mainqspiclk, &clock_manager_base->main_pll.mainqspiclk); + + writel(cfg->perqspiclk, &clock_manager_base->per_pll.perqspiclk); + + /* Peri pernandsdmmcclk */ + writel(cfg->mainnandsdmmcclk, + &clock_manager_base->main_pll.mainnandsdmmcclk); + + writel(cfg->pernandsdmmcclk, + &clock_manager_base->per_pll.pernandsdmmcclk); + + /* Peri perbaseclk */ + writel(cfg->perbaseclk, &clock_manager_base->per_pll.perbaseclk); + + /* Peri s2fuser1clk */ + writel(cfg->s2fuser1clk, &clock_manager_base->per_pll.s2fuser1clk); + + /* 7 us must have elapsed before we can enable the VCO */ + while (timer_get_us() < end) + ; + + /* Enable vco */ + /* main pll vco */ + writel(cfg->main_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, + &clock_manager_base->main_pll.vco); + + /* periferal pll */ + writel(cfg->peri_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, + &clock_manager_base->per_pll.vco); + + /* sdram pll vco */ + writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, + &clock_manager_base->sdr_pll.vco); + + /* L3 MP and L3 SP */ + writel(cfg->maindiv, &clock_manager_base->main_pll.maindiv); + + writel(cfg->dbgdiv, &clock_manager_base->main_pll.dbgdiv); + + writel(cfg->tracediv, &clock_manager_base->main_pll.tracediv); + + /* L4 MP, L4 SP, can0, and can1 */ + writel(cfg->perdiv, &clock_manager_base->per_pll.div); + + writel(cfg->gpiodiv, &clock_manager_base->per_pll.gpiodiv); + + cm_wait_for_lock(LOCKED_MASK); + + /* write the sdram clock counters before toggling outreset all */ + writel(cfg->ddrdqsclk & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK, + &clock_manager_base->sdr_pll.ddrdqsclk); + + writel(cfg->ddr2xdqsclk & CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_MASK, + &clock_manager_base->sdr_pll.ddr2xdqsclk); + + writel(cfg->ddrdqclk & CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_MASK, + &clock_manager_base->sdr_pll.ddrdqclk); + + writel(cfg->s2fuser2clk & CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_MASK, + &clock_manager_base->sdr_pll.s2fuser2clk); + + /* + * after locking, but before taking out of bypass + * assert/deassert outresetall + */ + u32 mainvco = readl(&clock_manager_base->main_pll.vco); + + /* assert main outresetall */ + writel(mainvco | CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, + &clock_manager_base->main_pll.vco); + + u32 periphvco = readl(&clock_manager_base->per_pll.vco); + + /* assert pheriph outresetall */ + writel(periphvco | CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, + &clock_manager_base->per_pll.vco); + + /* assert sdram outresetall */ + writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN| + CLKMGR_SDRPLLGRP_VCO_OUTRESETALL, + &clock_manager_base->sdr_pll.vco); + + /* deassert main outresetall */ + writel(mainvco & ~CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, + &clock_manager_base->main_pll.vco); + + /* deassert pheriph outresetall */ + writel(periphvco & ~CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, + &clock_manager_base->per_pll.vco); + + /* deassert sdram outresetall */ + writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, + &clock_manager_base->sdr_pll.vco); + + /* + * now that we've toggled outreset all, all the clocks + * are aligned nicely; so we can change any phase. + */ + cm_write_with_phase(cfg->ddrdqsclk, + (u32)&clock_manager_base->sdr_pll.ddrdqsclk, + CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK); + + /* SDRAM DDR2XDQSCLK */ + cm_write_with_phase(cfg->ddr2xdqsclk, + (u32)&clock_manager_base->sdr_pll.ddr2xdqsclk, + CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK); + + cm_write_with_phase(cfg->ddrdqclk, + (u32)&clock_manager_base->sdr_pll.ddrdqclk, + CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK); + + cm_write_with_phase(cfg->s2fuser2clk, + (u32)&clock_manager_base->sdr_pll.s2fuser2clk, + CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK); + + /* Take all three PLLs out of bypass when safe mode is cleared. */ + cm_write_bypass(0); + + /* clear safe mode */ + cm_write_ctrl(readl(&clock_manager_base->ctrl) | CLKMGR_CTRL_SAFEMODE); + + /* + * now that safe mode is clear with clocks gated + * it safe to change the source mux for the flashes the the L4_MAIN + */ + writel(cfg->persrc, &clock_manager_base->per_pll.src); + writel(cfg->l4src, &clock_manager_base->main_pll.l4src); + + /* Now ungate non-hw-managed clocks */ + writel(~0, &clock_manager_base->main_pll.en); + writel(~0, &clock_manager_base->per_pll.en); + writel(~0, &clock_manager_base->sdr_pll.en); + + /* Clear the loss of lock bits (write 1 to clear) */ + writel(CLKMGR_INTER_SDRPLLLOST_MASK | CLKMGR_INTER_PERPLLLOST_MASK | + CLKMGR_INTER_MAINPLLLOST_MASK, + &clock_manager_base->inter); +} + +static unsigned int cm_get_main_vco_clk_hz(void) +{ + u32 reg, clock; + + /* get the main VCO clock */ + reg = readl(&clock_manager_base->main_pll.vco); + clock = cm_get_osc_clk_hz(1); + clock /= ((reg & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >> + CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET) + 1; + clock *= ((reg & CLKMGR_MAINPLLGRP_VCO_NUMER_MASK) >> + CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET) + 1; + + return clock; +} + +static unsigned int cm_get_per_vco_clk_hz(void) +{ + u32 reg, clock = 0; + + /* identify PER PLL clock source */ + reg = readl(&clock_manager_base->per_pll.vco); + reg = (reg & CLKMGR_PERPLLGRP_VCO_SSRC_MASK) >> + CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET; + if (reg == CLKMGR_VCO_SSRC_EOSC1) + clock = cm_get_osc_clk_hz(1); + else if (reg == CLKMGR_VCO_SSRC_EOSC2) + clock = cm_get_osc_clk_hz(2); + else if (reg == CLKMGR_VCO_SSRC_F2S) + clock = cm_get_f2s_per_ref_clk_hz(); + + /* get the PER VCO clock */ + reg = readl(&clock_manager_base->per_pll.vco); + clock /= ((reg & CLKMGR_PERPLLGRP_VCO_DENOM_MASK) >> + CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET) + 1; + clock *= ((reg & CLKMGR_PERPLLGRP_VCO_NUMER_MASK) >> + CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET) + 1; + + return clock; +} + +unsigned long cm_get_mpu_clk_hz(void) +{ + u32 reg, clock; + + clock = cm_get_main_vco_clk_hz(); + + /* get the MPU clock */ + reg = readl(&clock_manager_base->altera.mpuclk); + clock /= (reg + 1); + reg = readl(&clock_manager_base->main_pll.mpuclk); + clock /= (reg + 1); + return clock; +} + +unsigned long cm_get_sdram_clk_hz(void) +{ + u32 reg, clock = 0; + + /* identify SDRAM PLL clock source */ + reg = readl(&clock_manager_base->sdr_pll.vco); + reg = (reg & CLKMGR_SDRPLLGRP_VCO_SSRC_MASK) >> + CLKMGR_SDRPLLGRP_VCO_SSRC_OFFSET; + if (reg == CLKMGR_VCO_SSRC_EOSC1) + clock = cm_get_osc_clk_hz(1); + else if (reg == CLKMGR_VCO_SSRC_EOSC2) + clock = cm_get_osc_clk_hz(2); + else if (reg == CLKMGR_VCO_SSRC_F2S) + clock = cm_get_f2s_sdr_ref_clk_hz(); + + /* get the SDRAM VCO clock */ + reg = readl(&clock_manager_base->sdr_pll.vco); + clock /= ((reg & CLKMGR_SDRPLLGRP_VCO_DENOM_MASK) >> + CLKMGR_SDRPLLGRP_VCO_DENOM_OFFSET) + 1; + clock *= ((reg & CLKMGR_SDRPLLGRP_VCO_NUMER_MASK) >> + CLKMGR_SDRPLLGRP_VCO_NUMER_OFFSET) + 1; + + /* get the SDRAM (DDR_DQS) clock */ + reg = readl(&clock_manager_base->sdr_pll.ddrdqsclk); + reg = (reg & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK) >> + CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_OFFSET; + clock /= (reg + 1); + + return clock; +} + +unsigned int cm_get_l4_sp_clk_hz(void) +{ + u32 reg, clock = 0; + + /* identify the source of L4 SP clock */ + reg = readl(&clock_manager_base->main_pll.l4src); + reg = (reg & CLKMGR_MAINPLLGRP_L4SRC_L4SP) >> + CLKMGR_MAINPLLGRP_L4SRC_L4SP_OFFSET; + + if (reg == CLKMGR_L4_SP_CLK_SRC_MAINPLL) { + clock = cm_get_main_vco_clk_hz(); + + /* get the clock prior L4 SP divider (main clk) */ + reg = readl(&clock_manager_base->altera.mainclk); + clock /= (reg + 1); + reg = readl(&clock_manager_base->main_pll.mainclk); + clock /= (reg + 1); + } else if (reg == CLKMGR_L4_SP_CLK_SRC_PERPLL) { + clock = cm_get_per_vco_clk_hz(); + + /* get the clock prior L4 SP divider (periph_base_clk) */ + reg = readl(&clock_manager_base->per_pll.perbaseclk); + clock /= (reg + 1); + } + + /* get the L4 SP clock which supplied to UART */ + reg = readl(&clock_manager_base->main_pll.maindiv); + reg = (reg & CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_MASK) >> + CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_OFFSET; + clock = clock / (1 << reg); + + return clock; +} + +unsigned int cm_get_mmc_controller_clk_hz(void) +{ + u32 reg, clock = 0; + + /* identify the source of MMC clock */ + reg = readl(&clock_manager_base->per_pll.src); + reg = (reg & CLKMGR_PERPLLGRP_SRC_SDMMC_MASK) >> + CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET; + + if (reg == CLKMGR_SDMMC_CLK_SRC_F2S) { + clock = cm_get_f2s_per_ref_clk_hz(); + } else if (reg == CLKMGR_SDMMC_CLK_SRC_MAIN) { + clock = cm_get_main_vco_clk_hz(); + + /* get the SDMMC clock */ + reg = readl(&clock_manager_base->main_pll.mainnandsdmmcclk); + clock /= (reg + 1); + } else if (reg == CLKMGR_SDMMC_CLK_SRC_PER) { + clock = cm_get_per_vco_clk_hz(); + + /* get the SDMMC clock */ + reg = readl(&clock_manager_base->per_pll.pernandsdmmcclk); + clock /= (reg + 1); + } + + /* further divide by 4 as we have fixed divider at wrapper */ + clock /= 4; + return clock; +} + +unsigned int cm_get_qspi_controller_clk_hz(void) +{ + u32 reg, clock = 0; + + /* identify the source of QSPI clock */ + reg = readl(&clock_manager_base->per_pll.src); + reg = (reg & CLKMGR_PERPLLGRP_SRC_QSPI_MASK) >> + CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET; + + if (reg == CLKMGR_QSPI_CLK_SRC_F2S) { + clock = cm_get_f2s_per_ref_clk_hz(); + } else if (reg == CLKMGR_QSPI_CLK_SRC_MAIN) { + clock = cm_get_main_vco_clk_hz(); + + /* get the qspi clock */ + reg = readl(&clock_manager_base->main_pll.mainqspiclk); + clock /= (reg + 1); + } else if (reg == CLKMGR_QSPI_CLK_SRC_PER) { + clock = cm_get_per_vco_clk_hz(); + + /* get the qspi clock */ + reg = readl(&clock_manager_base->per_pll.perqspiclk); + clock /= (reg + 1); + } + + return clock; +} + +unsigned int cm_get_spi_controller_clk_hz(void) +{ + u32 reg, clock = 0; + + clock = cm_get_per_vco_clk_hz(); + + /* get the clock prior L4 SP divider (periph_base_clk) */ + reg = readl(&clock_manager_base->per_pll.perbaseclk); + clock /= (reg + 1); + + return clock; +} diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index 803c926..123f6e2 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -8,310 +8,11 @@ #define _CLOCK_MANAGER_H_
#ifndef __ASSEMBLER__ -/* Clock speed accessors */ -unsigned long cm_get_mpu_clk_hz(void); -unsigned long cm_get_sdram_clk_hz(void); -unsigned int cm_get_l4_sp_clk_hz(void); -unsigned int cm_get_mmc_controller_clk_hz(void); -unsigned int cm_get_qspi_controller_clk_hz(void); -unsigned int cm_get_spi_controller_clk_hz(void); -const unsigned int cm_get_osc_clk_hz(const int osc); -const unsigned int cm_get_f2s_per_ref_clk_hz(void); -const unsigned int cm_get_f2s_sdr_ref_clk_hz(void); - -/* Clock configuration accessors */ -const struct cm_config * const cm_get_default_config(void); +void cm_wait_for_lock(u32 mask); +void cm_wait_for_fsm(void); #endif
-struct cm_config { - /* main group */ - uint32_t main_vco_base; - uint32_t mpuclk; - uint32_t mainclk; - uint32_t dbgatclk; - uint32_t mainqspiclk; - uint32_t mainnandsdmmcclk; - uint32_t cfg2fuser0clk; - uint32_t maindiv; - uint32_t dbgdiv; - uint32_t tracediv; - uint32_t l4src; - - /* peripheral group */ - uint32_t peri_vco_base; - uint32_t emac0clk; - uint32_t emac1clk; - uint32_t perqspiclk; - uint32_t pernandsdmmcclk; - uint32_t perbaseclk; - uint32_t s2fuser1clk; - uint32_t perdiv; - uint32_t gpiodiv; - uint32_t persrc; - - /* sdram pll group */ - uint32_t sdram_vco_base; - uint32_t ddrdqsclk; - uint32_t ddr2xdqsclk; - uint32_t ddrdqclk; - uint32_t s2fuser2clk; - - /* altera group */ - uint32_t altera_grp_mpuclk; -}; - -void cm_basic_init(const struct cm_config * const cfg); - -struct socfpga_clock_manager_main_pll { - u32 vco; - u32 misc; - u32 mpuclk; - u32 mainclk; - u32 dbgatclk; - u32 mainqspiclk; - u32 mainnandsdmmcclk; - u32 cfgs2fuser0clk; - u32 en; - u32 maindiv; - u32 dbgdiv; - u32 tracediv; - u32 l4src; - u32 stat; - u32 _pad_0x38_0x40[2]; -}; - -struct socfpga_clock_manager_per_pll { - u32 vco; - u32 misc; - u32 emac0clk; - u32 emac1clk; - u32 perqspiclk; - u32 pernandsdmmcclk; - u32 perbaseclk; - u32 s2fuser1clk; - u32 en; - u32 div; - u32 gpiodiv; - u32 src; - u32 stat; - u32 _pad_0x34_0x40[3]; -}; - -struct socfpga_clock_manager_sdr_pll { - u32 vco; - u32 ctrl; - u32 ddrdqsclk; - u32 ddr2xdqsclk; - u32 ddrdqclk; - u32 s2fuser2clk; - u32 en; - u32 stat; -}; - -struct socfpga_clock_manager_altera { - u32 mpuclk; - u32 mainclk; -}; - -struct socfpga_clock_manager { - u32 ctrl; - u32 bypass; - u32 inter; - u32 intren; - u32 dbctrl; - u32 stat; - u32 _pad_0x18_0x3f[10]; - struct socfpga_clock_manager_main_pll main_pll; - struct socfpga_clock_manager_per_pll per_pll; - struct socfpga_clock_manager_sdr_pll sdr_pll; - struct socfpga_clock_manager_altera altera; - u32 _pad_0xe8_0x200[70]; -}; - -#define CLKMGR_CTRL_SAFEMODE (1 << 0) -#define CLKMGR_CTRL_SAFEMODE_OFFSET 0 - -#define CLKMGR_BYPASS_PERPLLSRC (1 << 4) -#define CLKMGR_BYPASS_PERPLLSRC_OFFSET 4 -#define CLKMGR_BYPASS_PERPLL (1 << 3) -#define CLKMGR_BYPASS_PERPLL_OFFSET 3 -#define CLKMGR_BYPASS_SDRPLLSRC (1 << 2) -#define CLKMGR_BYPASS_SDRPLLSRC_OFFSET 2 -#define CLKMGR_BYPASS_SDRPLL (1 << 1) -#define CLKMGR_BYPASS_SDRPLL_OFFSET 1 -#define CLKMGR_BYPASS_MAINPLL (1 << 0) -#define CLKMGR_BYPASS_MAINPLL_OFFSET 0 - -#define CLKMGR_INTER_SDRPLLLOCKED_MASK 0x00000100 -#define CLKMGR_INTER_PERPLLLOCKED_MASK 0x00000080 -#define CLKMGR_INTER_MAINPLLLOCKED_MASK 0x00000040 -#define CLKMGR_INTER_PERPLLLOST_MASK 0x00000010 -#define CLKMGR_INTER_SDRPLLLOST_MASK 0x00000020 -#define CLKMGR_INTER_MAINPLLLOST_MASK 0x00000008 - -#define CLKMGR_STAT_BUSY (1 << 0) - -/* Main PLL */ -#define CLKMGR_MAINPLLGRP_VCO_BGPWRDN (1 << 0) -#define CLKMGR_MAINPLLGRP_VCO_BGPWRDN_OFFSET 0 -#define CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET 16 -#define CLKMGR_MAINPLLGRP_VCO_DENOM_MASK 0x003f0000 -#define CLKMGR_MAINPLLGRP_VCO_EN (1 << 1) -#define CLKMGR_MAINPLLGRP_VCO_EN_OFFSET 1 -#define CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET 3 -#define CLKMGR_MAINPLLGRP_VCO_NUMER_MASK 0x0000fff8 -#define CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK 0x01000000 -#define CLKMGR_MAINPLLGRP_VCO_PWRDN (1 << 2) -#define CLKMGR_MAINPLLGRP_VCO_PWRDN_OFFSET 2 -#define CLKMGR_MAINPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 -#define CLKMGR_MAINPLLGRP_VCO_RESET_VALUE 0x8001000d - -#define CLKMGR_MAINPLLGRP_MPUCLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_MPUCLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_MAINCLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_MAINCLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_DBGATCLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_DBGATCLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_MAINQSPICLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_MAINQSPICLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_MAINNANDSDMMCCLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_MAINNANDSDMMCCLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_CFGS2FUSER0CLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_CFGS2FUSER0CLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK 0x00000010 -#define CLKMGR_MAINPLLGRP_EN_DBGCLK_MASK 0x00000020 -#define CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK 0x00000080 -#define CLKMGR_MAINPLLGRP_EN_DBGTRACECLK_MASK 0x00000040 -#define CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK 0x00000004 -#define CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK 0x00000200 - -#define CLKMGR_MAINPLLGRP_MAINDIV_L3MPCLK_OFFSET 0 -#define CLKMGR_MAINPLLGRP_MAINDIV_L3MPCLK_MASK 0x00000003 -#define CLKMGR_MAINPLLGRP_MAINDIV_L3SPCLK_OFFSET 2 -#define CLKMGR_MAINPLLGRP_MAINDIV_L3SPCLK_MASK 0x0000000c -#define CLKMGR_MAINPLLGRP_MAINDIV_L4MPCLK_OFFSET 4 -#define CLKMGR_MAINPLLGRP_MAINDIV_L4MPCLK_MASK 0x00000070 -#define CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_OFFSET 7 -#define CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_MASK 0x00000380 - -#define CLKMGR_MAINPLLGRP_DBGDIV_DBGATCLK_OFFSET 0 -#define CLKMGR_MAINPLLGRP_DBGDIV_DBGATCLK_MASK 0x00000003 -#define CLKMGR_MAINPLLGRP_DBGDIV_DBGCLK_OFFSET 2 -#define CLKMGR_MAINPLLGRP_DBGDIV_DBGCLK_MASK 0x0000000c - -#define CLKMGR_MAINPLLGRP_TRACEDIV_TRACECLK_OFFSET 0 -#define CLKMGR_MAINPLLGRP_TRACEDIV_TRACECLK_MASK 0x00000007 - -#define CLKMGR_MAINPLLGRP_L4SRC_L4MP (1 << 0) -#define CLKMGR_MAINPLLGRP_L4SRC_L4MP_OFFSET 0 -#define CLKMGR_MAINPLLGRP_L4SRC_L4SP (1 << 1) -#define CLKMGR_MAINPLLGRP_L4SRC_L4SP_OFFSET 1 -#define CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE 0x00000000 -#define CLKMGR_L4_SP_CLK_SRC_MAINPLL 0x0 -#define CLKMGR_L4_SP_CLK_SRC_PERPLL 0x1 - -/* Per PLL */ -#define CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET 16 -#define CLKMGR_PERPLLGRP_VCO_DENOM_MASK 0x003f0000 -#define CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET 3 -#define CLKMGR_PERPLLGRP_VCO_NUMER_MASK 0x0000fff8 -#define CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK 0x01000000 -#define CLKMGR_PERPLLGRP_VCO_PSRC_OFFSET 22 -#define CLKMGR_PERPLLGRP_VCO_PSRC_MASK 0x00c00000 -#define CLKMGR_PERPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 -#define CLKMGR_PERPLLGRP_VCO_RESET_VALUE 0x8001000d -#define CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET 22 -#define CLKMGR_PERPLLGRP_VCO_SSRC_MASK 0x00c00000 - -#define CLKMGR_VCO_SSRC_EOSC1 0x0 -#define CLKMGR_VCO_SSRC_EOSC2 0x1 -#define CLKMGR_VCO_SSRC_F2S 0x2 - -#define CLKMGR_PERPLLGRP_EMAC0CLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_EMAC0CLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_EMAC1CLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_EMAC1CLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_PERQSPICLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_PERQSPICLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_PERNANDSDMMCCLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_PERNANDSDMMCCLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_PERBASECLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_PERBASECLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_S2FUSER1CLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_S2FUSER1CLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_EN_NANDCLK_MASK 0x00000400 -#define CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK 0x00000100 - -#define CLKMGR_PERPLLGRP_DIV_CAN0CLK_OFFSET 6 -#define CLKMGR_PERPLLGRP_DIV_CAN0CLK_MASK 0x000001c0 -#define CLKMGR_PERPLLGRP_DIV_CAN1CLK_OFFSET 9 -#define CLKMGR_PERPLLGRP_DIV_CAN1CLK_MASK 0x00000e00 -#define CLKMGR_PERPLLGRP_DIV_SPIMCLK_OFFSET 3 -#define CLKMGR_PERPLLGRP_DIV_SPIMCLK_OFFSET 3 -#define CLKMGR_PERPLLGRP_DIV_USBCLK_OFFSET 0 -#define CLKMGR_PERPLLGRP_DIV_USBCLK_MASK 0x00000007 - -#define CLKMGR_PERPLLGRP_GPIODIV_GPIODBCLK_OFFSET 0 -#define CLKMGR_PERPLLGRP_GPIODIV_GPIODBCLK_MASK 0x00ffffff - -#define CLKMGR_PERPLLGRP_SRC_NAND_OFFSET 2 -#define CLKMGR_PERPLLGRP_SRC_NAND_MASK 0x0000000c -#define CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET 4 -#define CLKMGR_PERPLLGRP_SRC_QSPI_MASK 0x00000030 -#define CLKMGR_PERPLLGRP_SRC_RESET_VALUE 0x00000015 -#define CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET 0 -#define CLKMGR_PERPLLGRP_SRC_SDMMC_MASK 0x00000003 -#define CLKMGR_SDMMC_CLK_SRC_F2S 0x0 -#define CLKMGR_SDMMC_CLK_SRC_MAIN 0x1 -#define CLKMGR_SDMMC_CLK_SRC_PER 0x2 -#define CLKMGR_QSPI_CLK_SRC_F2S 0x0 -#define CLKMGR_QSPI_CLK_SRC_MAIN 0x1 -#define CLKMGR_QSPI_CLK_SRC_PER 0x2 - -/* SDR PLL */ -#define CLKMGR_SDRPLLGRP_VCO_DENOM_OFFSET 16 -#define CLKMGR_SDRPLLGRP_VCO_DENOM_MASK 0x003f0000 -#define CLKMGR_SDRPLLGRP_VCO_NUMER_OFFSET 3 -#define CLKMGR_SDRPLLGRP_VCO_NUMER_MASK 0x0000fff8 -#define CLKMGR_SDRPLLGRP_VCO_OUTRESETALL (1 << 24) -#define CLKMGR_SDRPLLGRP_VCO_OUTRESETALL_OFFSET 24 -#define CLKMGR_SDRPLLGRP_VCO_OUTRESET_OFFSET 25 -#define CLKMGR_SDRPLLGRP_VCO_OUTRESET_MASK 0x7e000000 -#define CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 -#define CLKMGR_SDRPLLGRP_VCO_RESET_VALUE 0x8001000d -#define CLKMGR_SDRPLLGRP_VCO_SSRC_OFFSET 22 -#define CLKMGR_SDRPLLGRP_VCO_SSRC_MASK 0x00c00000 - -#define CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_OFFSET 0 -#define CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK 0x000001ff -#define CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_OFFSET 9 -#define CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK 0x00000e00 - -#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_OFFSET 0 -#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_MASK 0x000001ff -#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_OFFSET 9 -#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK 0x00000e00 - -#define CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_OFFSET 0 -#define CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_MASK 0x000001ff -#define CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_OFFSET 9 -#define CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK 0x00000e00 - -#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_OFFSET 0 -#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_MASK 0x000001ff -#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_OFFSET 9 -#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK 0x00000e00 - +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#include <asm/arch/clock_manager_gen5.h> +#endif #endif /* _CLOCK_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h new file mode 100644 index 0000000..8d62d8e --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h @@ -0,0 +1,322 @@ +/* + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _CLOCK_MANAGER_GEN5_H_ +#define _CLOCK_MANAGER_GEN5_H_ + +#ifndef __ASSEMBLER__ + +struct cm_config { + /* main group */ + u32 main_vco_base; + u32 mpuclk; + u32 mainclk; + u32 dbgatclk; + u32 mainqspiclk; + u32 mainnandsdmmcclk; + u32 cfg2fuser0clk; + u32 maindiv; + u32 dbgdiv; + u32 tracediv; + u32 l4src; + + /* peripheral group */ + u32 peri_vco_base; + u32 emac0clk; + u32 emac1clk; + u32 perqspiclk; + u32 pernandsdmmcclk; + u32 perbaseclk; + u32 s2fuser1clk; + u32 perdiv; + u32 gpiodiv; + u32 persrc; + + /* sdram pll group */ + u32 sdram_vco_base; + u32 ddrdqsclk; + u32 ddr2xdqsclk; + u32 ddrdqclk; + u32 s2fuser2clk; + + /* altera group */ + u32 altera_grp_mpuclk; +}; + +struct socfpga_clock_manager_main_pll { + u32 vco; + u32 misc; + u32 mpuclk; + u32 mainclk; + u32 dbgatclk; + u32 mainqspiclk; + u32 mainnandsdmmcclk; + u32 cfgs2fuser0clk; + u32 en; + u32 maindiv; + u32 dbgdiv; + u32 tracediv; + u32 l4src; + u32 stat; + u32 _pad_0x38_0x40[2]; +}; + +struct socfpga_clock_manager_per_pll { + u32 vco; + u32 misc; + u32 emac0clk; + u32 emac1clk; + u32 perqspiclk; + u32 pernandsdmmcclk; + u32 perbaseclk; + u32 s2fuser1clk; + u32 en; + u32 div; + u32 gpiodiv; + u32 src; + u32 stat; + u32 _pad_0x34_0x40[3]; +}; + +struct socfpga_clock_manager_sdr_pll { + u32 vco; + u32 ctrl; + u32 ddrdqsclk; + u32 ddr2xdqsclk; + u32 ddrdqclk; + u32 s2fuser2clk; + u32 en; + u32 stat; +}; + +struct socfpga_clock_manager_altera { + u32 mpuclk; + u32 mainclk; +}; + +struct socfpga_clock_manager { + u32 ctrl; + u32 bypass; + u32 inter; + u32 intren; + u32 dbctrl; + u32 stat; + u32 _pad_0x18_0x3f[10]; + struct socfpga_clock_manager_main_pll main_pll; + struct socfpga_clock_manager_per_pll per_pll; + struct socfpga_clock_manager_sdr_pll sdr_pll; + struct socfpga_clock_manager_altera altera; + u32 _pad_0xe8_0x200[70]; +}; + +/* Clock speed accessors */ +unsigned long cm_get_mpu_clk_hz(void); +unsigned long cm_get_sdram_clk_hz(void); +unsigned int cm_get_l4_sp_clk_hz(void); +unsigned int cm_get_mmc_controller_clk_hz(void); +unsigned int cm_get_qspi_controller_clk_hz(void); +unsigned int cm_get_spi_controller_clk_hz(void); +const unsigned int cm_get_osc_clk_hz(const int osc); +const unsigned int cm_get_f2s_per_ref_clk_hz(void); +const unsigned int cm_get_f2s_sdr_ref_clk_hz(void); + +/* Clock configuration accessors */ +void cm_basic_init(const struct cm_config * const cfg); +const struct cm_config * const cm_get_default_config(void); +#endif /* __ASSEMBLER__ */ + +#define LOCKED_MASK \ + (CLKMGR_INTER_SDRPLLLOCKED_MASK | \ + CLKMGR_INTER_PERPLLLOCKED_MASK | \ + CLKMGR_INTER_MAINPLLLOCKED_MASK) + +#define CLKMGR_CTRL_SAFEMODE BIT(0) +#define CLKMGR_CTRL_SAFEMODE_OFFSET 0 + +#define CLKMGR_BYPASS_PERPLLSRC BIT(4) +#define CLKMGR_BYPASS_PERPLLSRC_OFFSET 4 +#define CLKMGR_BYPASS_PERPLL BIT(3) +#define CLKMGR_BYPASS_PERPLL_OFFSET 3 +#define CLKMGR_BYPASS_SDRPLLSRC BIT(2) +#define CLKMGR_BYPASS_SDRPLLSRC_OFFSET 2 +#define CLKMGR_BYPASS_SDRPLL BIT(1) +#define CLKMGR_BYPASS_SDRPLL_OFFSET 1 +#define CLKMGR_BYPASS_MAINPLL BIT(0) +#define CLKMGR_BYPASS_MAINPLL_OFFSET 0 + +#define CLKMGR_INTER_SDRPLLLOCKED_MASK 0x00000100 +#define CLKMGR_INTER_PERPLLLOCKED_MASK 0x00000080 +#define CLKMGR_INTER_MAINPLLLOCKED_MASK 0x00000040 +#define CLKMGR_INTER_PERPLLLOST_MASK 0x00000010 +#define CLKMGR_INTER_SDRPLLLOST_MASK 0x00000020 +#define CLKMGR_INTER_MAINPLLLOST_MASK 0x00000008 + +#define CLKMGR_STAT_BUSY BIT(0) + +/* Main PLL */ +#define CLKMGR_MAINPLLGRP_VCO_BGPWRDN BIT(0) +#define CLKMGR_MAINPLLGRP_VCO_BGPWRDN_OFFSET 0 +#define CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET 16 +#define CLKMGR_MAINPLLGRP_VCO_DENOM_MASK 0x003f0000 +#define CLKMGR_MAINPLLGRP_VCO_EN BIT(1) +#define CLKMGR_MAINPLLGRP_VCO_EN_OFFSET 1 +#define CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET 3 +#define CLKMGR_MAINPLLGRP_VCO_NUMER_MASK 0x0000fff8 +#define CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK 0x01000000 +#define CLKMGR_MAINPLLGRP_VCO_PWRDN BIT(2) +#define CLKMGR_MAINPLLGRP_VCO_PWRDN_OFFSET 2 +#define CLKMGR_MAINPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 +#define CLKMGR_MAINPLLGRP_VCO_RESET_VALUE 0x8001000d + +#define CLKMGR_MAINPLLGRP_MPUCLK_CNT_OFFSET 0 +#define CLKMGR_MAINPLLGRP_MPUCLK_CNT_MASK 0x000001ff + +#define CLKMGR_MAINPLLGRP_MAINCLK_CNT_OFFSET 0 +#define CLKMGR_MAINPLLGRP_MAINCLK_CNT_MASK 0x000001ff + +#define CLKMGR_MAINPLLGRP_DBGATCLK_CNT_OFFSET 0 +#define CLKMGR_MAINPLLGRP_DBGATCLK_CNT_MASK 0x000001ff + +#define CLKMGR_MAINPLLGRP_MAINQSPICLK_CNT_OFFSET 0 +#define CLKMGR_MAINPLLGRP_MAINQSPICLK_CNT_MASK 0x000001ff + +#define CLKMGR_MAINPLLGRP_MAINNANDSDMMCCLK_CNT_OFFSET 0 +#define CLKMGR_MAINPLLGRP_MAINNANDSDMMCCLK_CNT_MASK 0x000001ff + +#define CLKMGR_MAINPLLGRP_CFGS2FUSER0CLK_CNT_OFFSET 0 +#define CLKMGR_MAINPLLGRP_CFGS2FUSER0CLK_CNT_MASK 0x000001ff + +#define CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK 0x00000010 +#define CLKMGR_MAINPLLGRP_EN_DBGCLK_MASK 0x00000020 +#define CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK 0x00000080 +#define CLKMGR_MAINPLLGRP_EN_DBGTRACECLK_MASK 0x00000040 +#define CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK 0x00000004 +#define CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK 0x00000200 + +#define CLKMGR_MAINPLLGRP_MAINDIV_L3MPCLK_OFFSET 0 +#define CLKMGR_MAINPLLGRP_MAINDIV_L3MPCLK_MASK 0x00000003 +#define CLKMGR_MAINPLLGRP_MAINDIV_L3SPCLK_OFFSET 2 +#define CLKMGR_MAINPLLGRP_MAINDIV_L3SPCLK_MASK 0x0000000c +#define CLKMGR_MAINPLLGRP_MAINDIV_L4MPCLK_OFFSET 4 +#define CLKMGR_MAINPLLGRP_MAINDIV_L4MPCLK_MASK 0x00000070 +#define CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_OFFSET 7 +#define CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_MASK 0x00000380 + +#define CLKMGR_MAINPLLGRP_DBGDIV_DBGATCLK_OFFSET 0 +#define CLKMGR_MAINPLLGRP_DBGDIV_DBGATCLK_MASK 0x00000003 +#define CLKMGR_MAINPLLGRP_DBGDIV_DBGCLK_OFFSET 2 +#define CLKMGR_MAINPLLGRP_DBGDIV_DBGCLK_MASK 0x0000000c + +#define CLKMGR_MAINPLLGRP_TRACEDIV_TRACECLK_OFFSET 0 +#define CLKMGR_MAINPLLGRP_TRACEDIV_TRACECLK_MASK 0x00000007 + +#define CLKMGR_MAINPLLGRP_L4SRC_L4MP BIT(0) +#define CLKMGR_MAINPLLGRP_L4SRC_L4MP_OFFSET 0 +#define CLKMGR_MAINPLLGRP_L4SRC_L4SP BIT(1) +#define CLKMGR_MAINPLLGRP_L4SRC_L4SP_OFFSET 1 +#define CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE 0x00000000 +#define CLKMGR_L4_SP_CLK_SRC_MAINPLL 0x0 +#define CLKMGR_L4_SP_CLK_SRC_PERPLL 0x1 + +/* Per PLL */ +#define CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET 16 +#define CLKMGR_PERPLLGRP_VCO_DENOM_MASK 0x003f0000 +#define CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET 3 +#define CLKMGR_PERPLLGRP_VCO_NUMER_MASK 0x0000fff8 +#define CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK 0x01000000 +#define CLKMGR_PERPLLGRP_VCO_PSRC_OFFSET 22 +#define CLKMGR_PERPLLGRP_VCO_PSRC_MASK 0x00c00000 +#define CLKMGR_PERPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 +#define CLKMGR_PERPLLGRP_VCO_RESET_VALUE 0x8001000d +#define CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET 22 +#define CLKMGR_PERPLLGRP_VCO_SSRC_MASK 0x00c00000 + +#define CLKMGR_VCO_SSRC_EOSC1 0x0 +#define CLKMGR_VCO_SSRC_EOSC2 0x1 +#define CLKMGR_VCO_SSRC_F2S 0x2 + +#define CLKMGR_PERPLLGRP_EMAC0CLK_CNT_OFFSET 0 +#define CLKMGR_PERPLLGRP_EMAC0CLK_CNT_MASK 0x000001ff + +#define CLKMGR_PERPLLGRP_EMAC1CLK_CNT_OFFSET 0 +#define CLKMGR_PERPLLGRP_EMAC1CLK_CNT_MASK 0x000001ff + +#define CLKMGR_PERPLLGRP_PERQSPICLK_CNT_OFFSET 0 +#define CLKMGR_PERPLLGRP_PERQSPICLK_CNT_MASK 0x000001ff + +#define CLKMGR_PERPLLGRP_PERNANDSDMMCCLK_CNT_OFFSET 0 +#define CLKMGR_PERPLLGRP_PERNANDSDMMCCLK_CNT_MASK 0x000001ff + +#define CLKMGR_PERPLLGRP_PERBASECLK_CNT_OFFSET 0 +#define CLKMGR_PERPLLGRP_PERBASECLK_CNT_MASK 0x000001ff + +#define CLKMGR_PERPLLGRP_S2FUSER1CLK_CNT_OFFSET 0 +#define CLKMGR_PERPLLGRP_S2FUSER1CLK_CNT_MASK 0x000001ff + +#define CLKMGR_PERPLLGRP_EN_NANDCLK_MASK 0x00000400 +#define CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK 0x00000100 + +#define CLKMGR_PERPLLGRP_DIV_CAN0CLK_OFFSET 6 +#define CLKMGR_PERPLLGRP_DIV_CAN0CLK_MASK 0x000001c0 +#define CLKMGR_PERPLLGRP_DIV_CAN1CLK_OFFSET 9 +#define CLKMGR_PERPLLGRP_DIV_CAN1CLK_MASK 0x00000e00 +#define CLKMGR_PERPLLGRP_DIV_SPIMCLK_OFFSET 3 +#define CLKMGR_PERPLLGRP_DIV_SPIMCLK_OFFSET 3 +#define CLKMGR_PERPLLGRP_DIV_USBCLK_OFFSET 0 +#define CLKMGR_PERPLLGRP_DIV_USBCLK_MASK 0x00000007 + +#define CLKMGR_PERPLLGRP_GPIODIV_GPIODBCLK_OFFSET 0 +#define CLKMGR_PERPLLGRP_GPIODIV_GPIODBCLK_MASK 0x00ffffff + +#define CLKMGR_PERPLLGRP_SRC_NAND_OFFSET 2 +#define CLKMGR_PERPLLGRP_SRC_NAND_MASK 0x0000000c +#define CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET 4 +#define CLKMGR_PERPLLGRP_SRC_QSPI_MASK 0x00000030 +#define CLKMGR_PERPLLGRP_SRC_RESET_VALUE 0x00000015 +#define CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET 0 +#define CLKMGR_PERPLLGRP_SRC_SDMMC_MASK 0x00000003 +#define CLKMGR_SDMMC_CLK_SRC_F2S 0x0 +#define CLKMGR_SDMMC_CLK_SRC_MAIN 0x1 +#define CLKMGR_SDMMC_CLK_SRC_PER 0x2 +#define CLKMGR_QSPI_CLK_SRC_F2S 0x0 +#define CLKMGR_QSPI_CLK_SRC_MAIN 0x1 +#define CLKMGR_QSPI_CLK_SRC_PER 0x2 + +/* SDR PLL */ +#define CLKMGR_SDRPLLGRP_VCO_DENOM_OFFSET 16 +#define CLKMGR_SDRPLLGRP_VCO_DENOM_MASK 0x003f0000 +#define CLKMGR_SDRPLLGRP_VCO_NUMER_OFFSET 3 +#define CLKMGR_SDRPLLGRP_VCO_NUMER_MASK 0x0000fff8 +#define CLKMGR_SDRPLLGRP_VCO_OUTRESETALL BIT(24) +#define CLKMGR_SDRPLLGRP_VCO_OUTRESETALL_OFFSET 24 +#define CLKMGR_SDRPLLGRP_VCO_OUTRESET_OFFSET 25 +#define CLKMGR_SDRPLLGRP_VCO_OUTRESET_MASK 0x7e000000 +#define CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 +#define CLKMGR_SDRPLLGRP_VCO_RESET_VALUE 0x8001000d +#define CLKMGR_SDRPLLGRP_VCO_SSRC_OFFSET 22 +#define CLKMGR_SDRPLLGRP_VCO_SSRC_MASK 0x00c00000 + +#define CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_OFFSET 0 +#define CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK 0x000001ff +#define CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_OFFSET 9 +#define CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK 0x00000e00 + +#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_OFFSET 0 +#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_MASK 0x000001ff +#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_OFFSET 9 +#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK 0x00000e00 + +#define CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_OFFSET 0 +#define CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_MASK 0x000001ff +#define CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_OFFSET 9 +#define CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK 0x00000e00 + +#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_OFFSET 0 +#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_MASK 0x000001ff +#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_OFFSET 9 +#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK 0x00000e00 + +#endif /* _CLOCK_MANAGER_GEN5_H_ */
- Copyright (C) 2013 Altera Corporation <www.altera.com>
- Copyright (C) 2013-2017 Altera Corporation <www.altera.com>
We should probably drop this "register" altogether.
- register u32 inter_val;
- u32 retry = 0; do { inter_val = readl(&clock_manager_base->inter) & mask; if (inter_val == mask)
- (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS;
- function to write the bypass register which requires a poll of the
- busy bit
This polling should be bounded, in fact, wait_for_bit() might be what you want .
DTTO
- Setup clocks while making no assumptions about previous state of the clocks.
- * Copyright (C) 2013-2017 Altera Corporation <www.altera.com>
* * SPDX-License-Identifier: GPL-2.0+ */ @@ -13,10 +13,10 @@ DECLARE_GLOBAL_DATA_PTR; static const struct socfpga_clock_manager *clock_manager_base = (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; -static void cm_wait_for_lock(uint32_t mask) +void cm_wait_for_lock(u32 mask) {
Okay.
- u32 retry = 0;
the
- busy bit
Okay, will change to wait_for_bit() here.
DTTO
Same here.
Regards Ley Foon
Restructure reset manager driver in the preparation to support A10. Move the Gen5 specific code to _gen5 files. Minor update in socfpga_per_reset(). No functional change.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 2 +- arch/arm/mach-socfpga/include/mach/reset_manager.h | 42 +------- .../mach-socfpga/include/mach/reset_manager_gen5.h | 47 +++++++++ arch/arm/mach-socfpga/reset_manager.c | 93 +---------------- arch/arm/mach-socfpga/reset_manager_gen5.c | 113 +++++++++++++++++++++ 5 files changed, 168 insertions(+), 129 deletions(-) create mode 100755 arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h create mode 100755 arch/arm/mach-socfpga/reset_manager_gen5.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index b76de4c..97819ac 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -14,7 +14,7 @@ obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
# QTS-generated config file wrappers obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ - clock_manager_gen5.o + clock_manager_gen5.o reset_manager_gen5.o obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 2f070f2..9e253bf 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -8,27 +8,12 @@ #define _RESET_MANAGER_H_
void reset_cpu(ulong addr); -void reset_deassert_peripherals_handoff(void);
void socfpga_bridges_reset(int enable);
void socfpga_per_reset(u32 reset, int set); void socfpga_per_reset_all(void);
-struct socfpga_reset_manager { - u32 status; - u32 ctrl; - u32 counts; - u32 padding1; - u32 mpu_mod_reset; - u32 per_mod_reset; - u32 per2_mod_reset; - u32 brg_mod_reset; - u32 misc_mod_reset; - u32 padding2[12]; - u32 tstscratch; -}; - #if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) #define RSTMGR_CTRL_SWWARMRSTREQ_LSB 2 #else @@ -55,28 +40,11 @@ struct socfpga_reset_manager { #define RSTMGR_BANK(_reset) \ (((_reset) >> RSTMGR_BANK_OFFSET) & RSTMGR_BANK_MASK)
-/* - * SocFPGA Cyclone V/Arria V reset IDs, bank mapping is as follows: - * 0 ... mpumodrst - * 1 ... permodrst - * 2 ... per2modrst - * 3 ... brgmodrst - * 4 ... miscmodrst - */ -#define RSTMGR_EMAC0 RSTMGR_DEFINE(1, 0) -#define RSTMGR_EMAC1 RSTMGR_DEFINE(1, 1) -#define RSTMGR_NAND RSTMGR_DEFINE(1, 4) -#define RSTMGR_QSPI RSTMGR_DEFINE(1, 5) -#define RSTMGR_L4WD0 RSTMGR_DEFINE(1, 6) -#define RSTMGR_OSC1TIMER0 RSTMGR_DEFINE(1, 8) -#define RSTMGR_UART0 RSTMGR_DEFINE(1, 16) -#define RSTMGR_SPIM0 RSTMGR_DEFINE(1, 18) -#define RSTMGR_SPIM1 RSTMGR_DEFINE(1, 19) -#define RSTMGR_SDMMC RSTMGR_DEFINE(1, 22) -#define RSTMGR_DMA RSTMGR_DEFINE(1, 28) -#define RSTMGR_SDR RSTMGR_DEFINE(1, 29) - /* Create a human-readable reference to SoCFPGA reset. */ #define SOCFPGA_RESET(_name) RSTMGR_##_name
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#include <asm/arch/reset_manager_gen5.h> +#endif + #endif /* _RESET_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h new file mode 100755 index 0000000..028974a --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h @@ -0,0 +1,47 @@ +/* + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _RESET_MANAGER_GEN5_H_ +#define _RESET_MANAGER_GEN5_H_ + +void reset_deassert_peripherals_handoff(void); + +struct socfpga_reset_manager { + u32 status; + u32 ctrl; + u32 counts; + u32 padding1; + u32 mpu_mod_reset; + u32 per_mod_reset; + u32 per2_mod_reset; + u32 brg_mod_reset; + u32 misc_mod_reset; + u32 padding2[12]; + u32 tstscratch; +}; + +/* + * SocFPGA Cyclone V/Arria V reset IDs, bank mapping is as follows: + * 0 ... mpumodrst + * 1 ... permodrst + * 2 ... per2modrst + * 3 ... brgmodrst + * 4 ... miscmodrst + */ +#define RSTMGR_EMAC0 RSTMGR_DEFINE(1, 0) +#define RSTMGR_EMAC1 RSTMGR_DEFINE(1, 1) +#define RSTMGR_NAND RSTMGR_DEFINE(1, 4) +#define RSTMGR_QSPI RSTMGR_DEFINE(1, 5) +#define RSTMGR_L4WD0 RSTMGR_DEFINE(1, 6) +#define RSTMGR_OSC1TIMER0 RSTMGR_DEFINE(1, 8) +#define RSTMGR_UART0 RSTMGR_DEFINE(1, 16) +#define RSTMGR_SPIM0 RSTMGR_DEFINE(1, 18) +#define RSTMGR_SPIM1 RSTMGR_DEFINE(1, 19) +#define RSTMGR_SDMMC RSTMGR_DEFINE(1, 22) +#define RSTMGR_DMA RSTMGR_DEFINE(1, 28) +#define RSTMGR_SDR RSTMGR_DEFINE(1, 29) + +#endif /* _RESET_MANAGER_GEN5_H_ */ diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager.c index b6beaa2..29438ed 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager.c @@ -7,53 +7,12 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/fpga_manager.h> #include <asm/arch/reset_manager.h> -#include <asm/arch/system_manager.h>
static const struct socfpga_reset_manager *reset_manager_base = (void *)SOCFPGA_RSTMGR_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - -/* Assert or de-assert SoCFPGA reset manager reset. */ -void socfpga_per_reset(u32 reset, int set) -{ - const void *reg; - - if (RSTMGR_BANK(reset) == 0) - reg = &reset_manager_base->mpu_mod_reset; - else if (RSTMGR_BANK(reset) == 1) - reg = &reset_manager_base->per_mod_reset; - else if (RSTMGR_BANK(reset) == 2) - reg = &reset_manager_base->per2_mod_reset; - else if (RSTMGR_BANK(reset) == 3) - reg = &reset_manager_base->brg_mod_reset; - else if (RSTMGR_BANK(reset) == 4) - reg = &reset_manager_base->misc_mod_reset; - else /* Invalid reset register, do nothing */ - return; - - if (set) - setbits_le32(reg, 1 << RSTMGR_RESET(reset)); - else - clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); -} - -/* - * Assert reset on every peripheral but L4WD0. - * Watchdog must be kept intact to prevent glitches - * and/or hangs. - */ -void socfpga_per_reset_all(void) -{ - const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)); - - writel(~l4wd0, &reset_manager_base->per_mod_reset); - writel(0xffffffff, &reset_manager_base->per2_mod_reset); -}
/* * Write the reset manager register to cause reset @@ -61,8 +20,8 @@ void socfpga_per_reset_all(void) void reset_cpu(ulong addr) { /* request a warm reset */ - writel((1 << RSTMGR_CTRL_SWWARMRSTREQ_LSB), - &reset_manager_base->ctrl); + writel(1 << RSTMGR_CTRL_SWWARMRSTREQ_LSB, + &reset_manager_base->ctrl); /* * infinite loop here as watchdog will trigger and reset * the processor @@ -70,51 +29,3 @@ void reset_cpu(ulong addr) while (1) ; } - -/* - * Release peripherals from reset based on handoff - */ -void reset_deassert_peripherals_handoff(void) -{ - writel(0, &reset_manager_base->per_mod_reset); -} - -#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) -void socfpga_bridges_reset(int enable) -{ - /* For SoCFPGA-VT, this is NOP. */ -} -#else - -#define L3REGS_REMAP_LWHPS2FPGA_MASK 0x10 -#define L3REGS_REMAP_HPS2FPGA_MASK 0x08 -#define L3REGS_REMAP_OCRAM_MASK 0x01 - -void socfpga_bridges_reset(int enable) -{ - const uint32_t l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | - L3REGS_REMAP_HPS2FPGA_MASK | - L3REGS_REMAP_OCRAM_MASK; - - if (enable) { - /* brdmodrst */ - writel(0xffffffff, &reset_manager_base->brg_mod_reset); - } else { - writel(0, &sysmgr_regs->iswgrp_handoff[0]); - writel(l3mask, &sysmgr_regs->iswgrp_handoff[1]); - - /* Check signal from FPGA. */ - if (!fpgamgr_test_fpga_ready()) { - /* FPGA not ready, do nothing. */ - printf("%s: FPGA not ready, aborting.\n", __func__); - return; - } - - /* brdmodrst */ - writel(0, &reset_manager_base->brg_mod_reset); - - /* Remap the bridges into memory map */ - writel(l3mask, SOCFPGA_L3REGS_ADDRESS); - } -} -#endif diff --git a/arch/arm/mach-socfpga/reset_manager_gen5.c b/arch/arm/mach-socfpga/reset_manager_gen5.c new file mode 100755 index 0000000..a170865 --- /dev/null +++ b/arch/arm/mach-socfpga/reset_manager_gen5.c @@ -0,0 +1,113 @@ +/* + * Copyright (C) 2013 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/fpga_manager.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_reset_manager *reset_manager_base = + (void *)SOCFPGA_RSTMGR_ADDRESS; +static const struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +/* Assert or de-assert SoCFPGA reset manager reset. */ +void socfpga_per_reset(u32 reset, int set) +{ + const volatile u32 *reg; + u32 rstmgr_bank = RSTMGR_BANK(reset); + + switch (rstmgr_bank) { + case 0: + reg = &reset_manager_base->mpu_mod_reset; + break; + case 1: + reg = &reset_manager_base->per_mod_reset; + break; + case 2: + reg = &reset_manager_base->per2_mod_reset; + break; + case 3: + reg = &reset_manager_base->brg_mod_reset; + break; + case 4: + reg = &reset_manager_base->misc_mod_reset; + break; + + default: + return; + } + + if (set) + setbits_le32(reg, 1 << RSTMGR_RESET(reset)); + else + clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); +} + +/* + * Assert reset on every peripheral but L4WD0. + * Watchdog must be kept intact to prevent glitches + * and/or hangs. + */ +void socfpga_per_reset_all(void) +{ + const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)); + + writel(~l4wd0, &reset_manager_base->per_mod_reset); + writel(0xffffffff, &reset_manager_base->per2_mod_reset); +} + +/* + * Release peripherals from reset based on handoff + */ +void reset_deassert_peripherals_handoff(void) +{ + writel(0, &reset_manager_base->per_mod_reset); +} + +#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) +void socfpga_bridges_reset(int enable) +{ + /* For SoCFPGA-VT, this is NOP. */ +} +#else + +#define L3REGS_REMAP_LWHPS2FPGA_MASK 0x10 +#define L3REGS_REMAP_HPS2FPGA_MASK 0x08 +#define L3REGS_REMAP_OCRAM_MASK 0x01 + +void socfpga_bridges_reset(int enable) +{ + const u32 l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | + L3REGS_REMAP_HPS2FPGA_MASK | + L3REGS_REMAP_OCRAM_MASK; + + if (enable) { + /* brdmodrst */ + writel(0xffffffff, &reset_manager_base->brg_mod_reset); + } else { + writel(0, &sysmgr_regs->iswgrp_handoff[0]); + writel(l3mask, &sysmgr_regs->iswgrp_handoff[1]); + + /* Check signal from FPGA. */ + if (!fpgamgr_test_fpga_ready()) { + /* FPGA not ready, do nothing. */ + printf("%s: FPGA not ready, aborting.\n", __func__); + return; + } + + /* brdmodrst */ + writel(0, &reset_manager_base->brg_mod_reset); + + /* Remap the bridges into memory map */ + writel(l3mask, SOCFPGA_L3REGS_ADDRESS); + } +} +#endif
Restructure misc driver in the preparation to support A10. Move the Gen5 specific code to _gen5 file. No functional change.
Change all uint32_t_to u32.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 3 +- arch/arm/mach-socfpga/include/mach/misc.h | 26 +++ arch/arm/mach-socfpga/misc.c | 361 ++---------------------------- arch/arm/mach-socfpga/misc_gen5.c | 355 +++++++++++++++++++++++++++++ 4 files changed, 398 insertions(+), 347 deletions(-) create mode 100644 arch/arm/mach-socfpga/include/mach/misc.h create mode 100755 arch/arm/mach-socfpga/misc_gen5.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 97819ac..5b09ea9 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -14,7 +14,8 @@ obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
# QTS-generated config file wrappers obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ - clock_manager_gen5.o reset_manager_gen5.o + clock_manager_gen5.o reset_manager_gen5.o \ + misc_gen5.o obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h new file mode 100644 index 0000000..64f9b86 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -0,0 +1,26 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _MISC_H_ +#define _MISC_H_ + +void dwmac_deassert_reset(const unsigned int of_reset_id, + const u32 phymode); + +struct bsel { + const char *mode; + const char *name; +}; + +extern struct bsel bsel_str[]; + +#ifdef CONFIG_FPGA +void socfpga_fpga_add(void); +#else +inline void socfpga_fpga_add(void) {} +#endif + +#endif /* _MISC_H_ */ diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index dd6b53b..cd250af 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -13,6 +13,7 @@ #include <miiphy.h> #include <netdev.h> #include <watchdog.h> +#include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/scan_manager.h> #include <asm/arch/system_manager.h> @@ -24,16 +25,19 @@
-static struct pl310_regs *const pl310 = +static const struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; -static struct socfpga_reset_manager *reset_manager_base = - (struct socfpga_reset_manager *)SOCFPGA_RSTMGR_ADDRESS; -static struct nic301_registers *nic301_regs = - (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; -static struct scu_registers *scu_regs = - (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; + +struct bsel bsel_str[] = { + { "rsvd", "Reserved", }, + { "fpga", "FPGA (HPS2FPGA Bridge)", }, + { "nand", "NAND Flash (1.8V)", }, + { "nand", "NAND Flash (3.0V)", }, + { "sd", "SD/MMC External Transceiver (1.8V)", }, + { "sd", "SD/MMC Internal Transceiver (3.0V)", }, + { "qspi", "QSPI Flash (1.8V)", }, + { "qspi", "QSPI Flash (3.0V)", }, +};
int dram_init(void) { @@ -72,207 +76,6 @@ void v7_outer_cache_disable(void) clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); }
-/* - * DesignWare Ethernet initialization - */ -#ifdef CONFIG_ETH_DESIGNWARE -static void dwmac_deassert_reset(const unsigned int of_reset_id, - const u32 phymode) -{ - u32 physhift, reset; - - if (of_reset_id == EMAC0_RESET) { - physhift = SYSMGR_EMACGRP_CTRL_PHYSEL0_LSB; - reset = SOCFPGA_RESET(EMAC0); - } else if (of_reset_id == EMAC1_RESET) { - physhift = SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB; - reset = SOCFPGA_RESET(EMAC1); - } else { - printf("GMAC: Invalid reset ID (%i)!\n", of_reset_id); - return; - } - - /* Clearing emac0 PHY interface select to 0 */ - clrbits_le32(&sysmgr_regs->emacgrp_ctrl, - SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << physhift); - - /* configure to PHY interface select choosed */ - setbits_le32(&sysmgr_regs->emacgrp_ctrl, - phymode << physhift); - - /* Release the EMAC controller from reset */ - socfpga_per_reset(reset, 0); -} - -static u32 dwmac_phymode_to_modereg(const char *phymode, u32 *modereg) -{ - if (!phymode) - return -EINVAL; - - if (!strcmp(phymode, "mii") || !strcmp(phymode, "gmii")) { - *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII; - return 0; - } - - if (!strcmp(phymode, "rgmii")) { - *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RGMII; - return 0; - } - - if (!strcmp(phymode, "rmii")) { - *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RMII; - return 0; - } - - return -EINVAL; -} - -static int socfpga_eth_reset(void) -{ - const void *fdt = gd->fdt_blob; - struct fdtdec_phandle_args args; - const char *phy_mode; - u32 phy_modereg; - int nodes[2]; /* Max. two GMACs */ - int ret, count; - int i, node; - - /* Put both GMACs into RESET state. */ - socfpga_per_reset(SOCFPGA_RESET(EMAC0), 1); - socfpga_per_reset(SOCFPGA_RESET(EMAC1), 1); - - count = fdtdec_find_aliases_for_id(fdt, "ethernet", - COMPAT_ALTERA_SOCFPGA_DWMAC, - nodes, ARRAY_SIZE(nodes)); - for (i = 0; i < count; i++) { - node = nodes[i]; - if (node <= 0) - continue; - - ret = fdtdec_parse_phandle_with_args(fdt, node, "resets", - "#reset-cells", 1, 0, - &args); - if (ret || (args.args_count != 1)) { - debug("GMAC%i: Failed to parse DT 'resets'!\n", i); - continue; - } - - phy_mode = fdt_getprop(fdt, node, "phy-mode", NULL); - ret = dwmac_phymode_to_modereg(phy_mode, &phy_modereg); - if (ret) { - debug("GMAC%i: Failed to parse DT 'phy-mode'!\n", i); - continue; - } - - dwmac_deassert_reset(args.args[0], phy_modereg); - } - - return 0; -} -#else -static int socfpga_eth_reset(void) -{ - return 0; -}; -#endif - -struct { - const char *mode; - const char *name; -} bsel_str[] = { - { "rsvd", "Reserved", }, - { "fpga", "FPGA (HPS2FPGA Bridge)", }, - { "nand", "NAND Flash (1.8V)", }, - { "nand", "NAND Flash (3.0V)", }, - { "sd", "SD/MMC External Transceiver (1.8V)", }, - { "sd", "SD/MMC Internal Transceiver (3.0V)", }, - { "qspi", "QSPI Flash (1.8V)", }, - { "qspi", "QSPI Flash (3.0V)", }, -}; - -static const struct { - const u16 pn; - const char *name; - const char *var; -} const socfpga_fpga_model[] = { - /* Cyclone V E */ - { 0x2b15, "Cyclone V, E/A2", "cv_e_a2" }, - { 0x2b05, "Cyclone V, E/A4", "cv_e_a4" }, - { 0x2b22, "Cyclone V, E/A5", "cv_e_a5" }, - { 0x2b13, "Cyclone V, E/A7", "cv_e_a7" }, - { 0x2b14, "Cyclone V, E/A9", "cv_e_a9" }, - /* Cyclone V GX/GT */ - { 0x2b01, "Cyclone V, GX/C3", "cv_gx_c3" }, - { 0x2b12, "Cyclone V, GX/C4", "cv_gx_c4" }, - { 0x2b02, "Cyclone V, GX/C5 or GT/D5", "cv_gx_c5" }, - { 0x2b03, "Cyclone V, GX/C7 or GT/D7", "cv_gx_c7" }, - { 0x2b04, "Cyclone V, GX/C9 or GT/D9", "cv_gx_c9" }, - /* Cyclone V SE/SX/ST */ - { 0x2d11, "Cyclone V, SE/A2 or SX/C2", "cv_se_a2" }, - { 0x2d01, "Cyclone V, SE/A4 or SX/C4", "cv_se_a4" }, - { 0x2d12, "Cyclone V, SE/A5 or SX/C5 or ST/D5", "cv_se_a5" }, - { 0x2d02, "Cyclone V, SE/A6 or SX/C6 or ST/D6", "cv_se_a6" }, - /* Arria V */ - { 0x2d03, "Arria V, D5", "av_d5" }, -}; - -static int socfpga_fpga_id(const bool print_id) -{ - const u32 altera_mi = 0x6e; - const u32 id = scan_mgr_get_fpga_id(); - - const u32 lsb = id & 0x00000001; - const u32 mi = (id >> 1) & 0x000007ff; - const u32 pn = (id >> 12) & 0x0000ffff; - const u32 version = (id >> 28) & 0x0000000f; - int i; - - if ((mi != altera_mi) || (lsb != 1)) { - printf("FPGA: Not Altera chip ID\n"); - return -EINVAL; - } - - for (i = 0; i < ARRAY_SIZE(socfpga_fpga_model); i++) - if (pn == socfpga_fpga_model[i].pn) - break; - - if (i == ARRAY_SIZE(socfpga_fpga_model)) { - printf("FPGA: Unknown Altera chip, ID 0x%08x\n", id); - return -EINVAL; - } - - if (print_id) - printf("FPGA: Altera %s, version 0x%01x\n", - socfpga_fpga_model[i].name, version); - return i; -} - -/* - * Print CPU information - */ -#if defined(CONFIG_DISPLAY_CPUINFO) -int print_cpuinfo(void) -{ - const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; - puts("CPU: Altera SoCFPGA Platform\n"); - socfpga_fpga_id(1); - printf("BOOT: %s\n", bsel_str[bsel].name); - return 0; -} -#endif - -#ifdef CONFIG_ARCH_MISC_INIT -int arch_misc_init(void) -{ - const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; - const int fpga_id = socfpga_fpga_id(0); - setenv("bootmode", bsel_str[bsel].mode); - if (fpga_id >= 0) - setenv("fpgatype", socfpga_fpga_model[fpga_id].var); - return socfpga_eth_reset(); -} -#endif - #if defined(CONFIG_SYS_CONSOLE_IS_IN_ENV) && \ defined(CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE) int overwrite_console(void) @@ -303,15 +106,13 @@ static Altera_desc altera_fpga[] = { };
/* add device descriptor to FPGA device table */ -static void socfpga_fpga_add(void) +void socfpga_fpga_add(void) { int i; fpga_init(); for (i = 0; i < ARRAY_SIZE(altera_fpga); i++) fpga_add(fpga_altera, &altera_fpga[i]); } -#else -static inline void socfpga_fpga_add(void) {} #endif
int arch_cpu_init(void) @@ -337,135 +138,3 @@ int arch_cpu_init(void)
return 0; } - -/* - * Convert all NIC-301 AMBA slaves from secure to non-secure - */ -static void socfpga_nic301_slave_ns(void) -{ - writel(0x1, &nic301_regs->lwhps2fpgaregs); - writel(0x1, &nic301_regs->hps2fpgaregs); - writel(0x1, &nic301_regs->acp); - writel(0x1, &nic301_regs->rom); - writel(0x1, &nic301_regs->ocram); - writel(0x1, &nic301_regs->sdrdata); -} - -static uint32_t iswgrp_handoff[8]; - -int arch_early_init_r(void) -{ - int i; - - /* - * Write magic value into magic register to unlock support for - * issuing warm reset. The ancient kernel code expects this - * value to be written into the register by the bootloader, so - * to support that old code, we write it here instead of in the - * reset_cpu() function just before resetting the CPU. - */ - writel(0xae9efebc, &sysmgr_regs->romcodegrp_warmramgrp_enable); - - for (i = 0; i < 8; i++) /* Cache initial SW setting regs */ - iswgrp_handoff[i] = readl(&sysmgr_regs->iswgrp_handoff[i]); - - socfpga_bridges_reset(1); - socfpga_nic301_slave_ns(); - - /* - * Private components security: - * U-Boot : configure private timer, global timer and cpu component - * access as non secure for kernel stage (as required by Linux) - */ - setbits_le32(&scu_regs->sacr, 0xfff); - - /* Configure the L2 controller to make SDRAM start at 0 */ -#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET - writel(0x2, &nic301_regs->remap); -#else - writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ - writel(0x1, &pl310->pl310_addr_filter_start); -#endif - - /* Add device descriptor to FPGA device table */ - socfpga_fpga_add(); - -#ifdef CONFIG_DESIGNWARE_SPI - /* Get Designware SPI controller out of reset */ - socfpga_per_reset(SOCFPGA_RESET(SPIM0), 0); - socfpga_per_reset(SOCFPGA_RESET(SPIM1), 0); -#endif - -#ifdef CONFIG_NAND_DENALI - socfpga_per_reset(SOCFPGA_RESET(NAND), 0); -#endif - - return 0; -} - -static void socfpga_sdram_apply_static_cfg(void) -{ - const uint32_t staticcfg = SOCFPGA_SDR_ADDRESS + 0x505c; - const uint32_t applymask = 0x8; - uint32_t val = readl(staticcfg) | applymask; - - /* - * SDRAM staticcfg register specific: - * When applying the register setting, the CPU must not access - * SDRAM. Luckily for us, we can abuse i-cache here to help us - * circumvent the SDRAM access issue. The idea is to make sure - * that the code is in one full i-cache line by branching past - * it and back. Once it is in the i-cache, we execute the core - * of the code and apply the register settings. - * - * The code below uses 7 instructions, while the Cortex-A9 has - * 32-byte cachelines, thus the limit is 8 instructions total. - */ - asm volatile( - ".align 5 \n" - " b 2f \n" - "1: str %0, [%1] \n" - " dsb \n" - " isb \n" - " b 3f \n" - "2: b 1b \n" - "3: nop \n" - : : "r"(val), "r"(staticcfg) : "memory", "cc"); -} - -int do_bridge(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - if (argc != 2) - return CMD_RET_USAGE; - - argv++; - - switch (*argv[0]) { - case 'e': /* Enable */ - writel(iswgrp_handoff[2], &sysmgr_regs->fpgaintfgrp_module); - socfpga_sdram_apply_static_cfg(); - writel(iswgrp_handoff[3], SOCFPGA_SDR_ADDRESS + 0x5080); - writel(iswgrp_handoff[0], &reset_manager_base->brg_mod_reset); - writel(iswgrp_handoff[1], &nic301_regs->remap); - break; - case 'd': /* Disable */ - writel(0, &sysmgr_regs->fpgaintfgrp_module); - writel(0, SOCFPGA_SDR_ADDRESS + 0x5080); - socfpga_sdram_apply_static_cfg(); - writel(0, &reset_manager_base->brg_mod_reset); - writel(1, &nic301_regs->remap); - break; - default: - return CMD_RET_USAGE; - } - - return 0; -} - -U_BOOT_CMD( - bridge, 2, 1, do_bridge, - "SoCFPGA HPS FPGA bridge control", - "enable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" - "bridge disable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" - "" -); diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c new file mode 100755 index 0000000..f870e1f --- /dev/null +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -0,0 +1,355 @@ +/* + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <fdtdec.h> +#include <libfdt.h> +#include <altera.h> +#include <miiphy.h> +#include <netdev.h> +#include <watchdog.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/scan_manager.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/nic301.h> +#include <asm/arch/scu.h> +#include <asm/pl310.h> + +#include <dt-bindings/reset/altr,rst-mgr.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct pl310_regs *const pl310 = + (struct pl310_regs *)CONFIG_SYS_PL310_BASE; +static struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; +static struct socfpga_reset_manager *reset_manager_base = + (struct socfpga_reset_manager *)SOCFPGA_RSTMGR_ADDRESS; +static struct nic301_registers *nic301_regs = + (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; +static struct scu_registers *scu_regs = + (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; + +/* + * DesignWare Ethernet initialization + */ +#ifdef CONFIG_ETH_DESIGNWARE +void dwmac_deassert_reset(const unsigned int of_reset_id, + const u32 phymode) +{ + u32 physhift, reset; + + if (of_reset_id == EMAC0_RESET) { + physhift = SYSMGR_EMACGRP_CTRL_PHYSEL0_LSB; + reset = SOCFPGA_RESET(EMAC0); + } else if (of_reset_id == EMAC1_RESET) { + physhift = SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB; + reset = SOCFPGA_RESET(EMAC1); + } else { + printf("GMAC: Invalid reset ID (%i)!\n", of_reset_id); + return; + } + + /* configure to PHY interface select choosed */ + clrsetbits_le32(&sysmgr_regs->emacgrp_ctrl, + SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << physhift, + phymode << physhift); + + /* Release the EMAC controller from reset */ + socfpga_per_reset(reset, 0); +} + +static u32 dwmac_phymode_to_modereg(const char *phymode, u32 *modereg) +{ + if (!phymode) + return -EINVAL; + + if (!strcmp(phymode, "mii") || !strcmp(phymode, "gmii")) { + *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII; + return 0; + } + + if (!strcmp(phymode, "rgmii")) { + *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RGMII; + return 0; + } + + if (!strcmp(phymode, "rmii")) { + *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RMII; + return 0; + } + + return -EINVAL; +} + +static int socfpga_eth_reset(void) +{ + const void *fdt = gd->fdt_blob; + struct fdtdec_phandle_args args; + const char *phy_mode; + u32 phy_modereg; + int nodes[2]; /* Max. two GMACs */ + int ret, count; + int i, node; + + /* Put both GMACs into RESET state. */ + socfpga_per_reset(SOCFPGA_RESET(EMAC0), 1); + socfpga_per_reset(SOCFPGA_RESET(EMAC1), 1); + + count = fdtdec_find_aliases_for_id(fdt, "ethernet", + COMPAT_ALTERA_SOCFPGA_DWMAC, + nodes, ARRAY_SIZE(nodes)); + for (i = 0; i < count; i++) { + node = nodes[i]; + if (node <= 0) + continue; + + ret = fdtdec_parse_phandle_with_args(fdt, node, "resets", + "#reset-cells", 1, 0, + &args); + if (ret || (args.args_count != 1)) { + debug("GMAC%i: Failed to parse DT 'resets'!\n", i); + continue; + } + + phy_mode = fdt_getprop(fdt, node, "phy-mode", NULL); + ret = dwmac_phymode_to_modereg(phy_mode, &phy_modereg); + if (ret) { + debug("GMAC%i: Failed to parse DT 'phy-mode'!\n", i); + continue; + } + + dwmac_deassert_reset(args.args[0], phy_modereg); + } + + return 0; +} +#else +static int socfpga_eth_reset(void) +{ + return 0; +}; +#endif + +static const struct { + const u16 pn; + const char *name; + const char *var; +} const socfpga_fpga_model[] = { + /* Cyclone V E */ + { 0x2b15, "Cyclone V, E/A2", "cv_e_a2" }, + { 0x2b05, "Cyclone V, E/A4", "cv_e_a4" }, + { 0x2b22, "Cyclone V, E/A5", "cv_e_a5" }, + { 0x2b13, "Cyclone V, E/A7", "cv_e_a7" }, + { 0x2b14, "Cyclone V, E/A9", "cv_e_a9" }, + /* Cyclone V GX/GT */ + { 0x2b01, "Cyclone V, GX/C3", "cv_gx_c3" }, + { 0x2b12, "Cyclone V, GX/C4", "cv_gx_c4" }, + { 0x2b02, "Cyclone V, GX/C5 or GT/D5", "cv_gx_c5" }, + { 0x2b03, "Cyclone V, GX/C7 or GT/D7", "cv_gx_c7" }, + { 0x2b04, "Cyclone V, GX/C9 or GT/D9", "cv_gx_c9" }, + /* Cyclone V SE/SX/ST */ + { 0x2d11, "Cyclone V, SE/A2 or SX/C2", "cv_se_a2" }, + { 0x2d01, "Cyclone V, SE/A4 or SX/C4", "cv_se_a4" }, + { 0x2d12, "Cyclone V, SE/A5 or SX/C5 or ST/D5", "cv_se_a5" }, + { 0x2d02, "Cyclone V, SE/A6 or SX/C6 or ST/D6", "cv_se_a6" }, + /* Arria V */ + { 0x2d03, "Arria V, D5", "av_d5" }, +}; + +static int socfpga_fpga_id(const bool print_id) +{ + const u32 altera_mi = 0x6e; + const u32 id = scan_mgr_get_fpga_id(); + + const u32 lsb = id & 0x00000001; + const u32 mi = (id >> 1) & 0x000007ff; + const u32 pn = (id >> 12) & 0x0000ffff; + const u32 version = (id >> 28) & 0x0000000f; + int i; + + if ((mi != altera_mi) || (lsb != 1)) { + printf("FPGA: Not Altera chip ID\n"); + return -EINVAL; + } + + for (i = 0; i < ARRAY_SIZE(socfpga_fpga_model); i++) + if (pn == socfpga_fpga_model[i].pn) + break; + + if (i == ARRAY_SIZE(socfpga_fpga_model)) { + printf("FPGA: Unknown Altera chip, ID 0x%08x\n", id); + return -EINVAL; + } + + if (print_id) + printf("FPGA: Altera %s, version 0x%01x\n", + socfpga_fpga_model[i].name, version); + return i; +} + +/* + * Print CPU information + */ +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; + + puts("CPU: Altera SoCFPGA Platform\n"); + socfpga_fpga_id(1); + + printf("BOOT: %s\n", bsel_str[bsel].name); + return 0; +} +#endif + +#ifdef CONFIG_ARCH_MISC_INIT +int arch_misc_init(void) +{ + const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; + const int fpga_id = socfpga_fpga_id(0); + setenv("bootmode", bsel_str[bsel].mode); + if (fpga_id >= 0) + setenv("fpgatype", socfpga_fpga_model[fpga_id].var); + return socfpga_eth_reset(); +} +#endif + +/* + * Convert all NIC-301 AMBA slaves from secure to non-secure + */ +static void socfpga_nic301_slave_ns(void) +{ + writel(0x1, &nic301_regs->lwhps2fpgaregs); + writel(0x1, &nic301_regs->hps2fpgaregs); + writel(0x1, &nic301_regs->acp); + writel(0x1, &nic301_regs->rom); + writel(0x1, &nic301_regs->ocram); + writel(0x1, &nic301_regs->sdrdata); +} + +static u32 iswgrp_handoff[8]; + +int arch_early_init_r(void) +{ + int i; + + /* + * Write magic value into magic register to unlock support for + * issuing warm reset. The ancient kernel code expects this + * value to be written into the register by the bootloader, so + * to support that old code, we write it here instead of in the + * reset_cpu() function just before resetting the CPU. + */ + writel(0xae9efebc, &sysmgr_regs->romcodegrp_warmramgrp_enable); + + for (i = 0; i < 8; i++) /* Cache initial SW setting regs */ + iswgrp_handoff[i] = readl(&sysmgr_regs->iswgrp_handoff[i]); + + socfpga_bridges_reset(1); + socfpga_nic301_slave_ns(); + + /* + * Private components security: + * U-Boot : configure private timer, global timer and cpu component + * access as non secure for kernel stage (as required by Linux) + */ + setbits_le32(&scu_regs->sacr, 0xfff); + + /* Configure the L2 controller to make SDRAM start at 0 */ +#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET + writel(0x2, &nic301_regs->remap); +#else + writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ + writel(0x1, &pl310->pl310_addr_filter_start); +#endif + + /* Add device descriptor to FPGA device table */ + socfpga_fpga_add(); + +#ifdef CONFIG_DESIGNWARE_SPI + /* Get Designware SPI controller out of reset */ + socfpga_per_reset(SOCFPGA_RESET(SPIM0), 0); + socfpga_per_reset(SOCFPGA_RESET(SPIM1), 0); +#endif + +#ifdef CONFIG_NAND_DENALI + socfpga_per_reset(SOCFPGA_RESET(NAND), 0); +#endif + + return 0; +} + +static void socfpga_sdram_apply_static_cfg(void) +{ + const u32 staticcfg = SOCFPGA_SDR_ADDRESS + 0x505c; + const u32 applymask = 0x8; + u32 val = readl(staticcfg) | applymask; + + /* + * SDRAM staticcfg register specific: + * When applying the register setting, the CPU must not access + * SDRAM. Luckily for us, we can abuse i-cache here to help us + * circumvent the SDRAM access issue. The idea is to make sure + * that the code is in one full i-cache line by branching past + * it and back. Once it is in the i-cache, we execute the core + * of the code and apply the register settings. + * + * The code below uses 7 instructions, while the Cortex-A9 has + * 32-byte cachelines, thus the limit is 8 instructions total. + */ + asm volatile( + ".align 5 \n" + " b 2f \n" + "1: str %0, [%1] \n" + " dsb \n" + " isb \n" + " b 3f \n" + "2: b 1b \n" + "3: nop \n" + : : "r"(val), "r"(staticcfg) : "memory", "cc"); +} + +int do_bridge(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + if (argc != 2) + return CMD_RET_USAGE; + + argv++; + + switch (*argv[0]) { + case 'e': /* Enable */ + writel(iswgrp_handoff[2], &sysmgr_regs->fpgaintfgrp_module); + socfpga_sdram_apply_static_cfg(); + writel(iswgrp_handoff[3], SOCFPGA_SDR_ADDRESS + 0x5080); + writel(iswgrp_handoff[0], &reset_manager_base->brg_mod_reset); + writel(iswgrp_handoff[1], &nic301_regs->remap); + break; + case 'd': /* Disable */ + writel(0, &sysmgr_regs->fpgaintfgrp_module); + writel(0, SOCFPGA_SDR_ADDRESS + 0x5080); + socfpga_sdram_apply_static_cfg(); + writel(0, &reset_manager_base->brg_mod_reset); + writel(1, &nic301_regs->remap); + break; + default: + return CMD_RET_USAGE; + } + + return 0; +} + +U_BOOT_CMD( + bridge, 2, 1, do_bridge, + "SoCFPGA HPS FPGA bridge control", + "enable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" + "bridge disable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" + "" +);
Restructure system manager in the preparation to support A10. No functional change.
Change uint32_t to u32.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 4 +- .../arm/mach-socfpga/include/mach/system_manager.h | 125 ++------------------- .../include/mach/system_manager_gen5.h | 121 ++++++++++++++++++++ arch/arm/mach-socfpga/system_manager.c | 85 -------------- arch/arm/mach-socfpga/system_manager_gen5.c | 85 ++++++++++++++ 5 files changed, 215 insertions(+), 205 deletions(-) create mode 100755 arch/arm/mach-socfpga/include/mach/system_manager_gen5.h delete mode 100644 arch/arm/mach-socfpga/system_manager.c create mode 100644 arch/arm/mach-socfpga/system_manager_gen5.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 5b09ea9..e83da2e 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -7,7 +7,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ +obj-y += misc.o timer.o reset_manager.o clock_manager.o \ fpga_manager.o board.o
obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o @@ -15,7 +15,7 @@ obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o # QTS-generated config file wrappers obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ clock_manager_gen5.o reset_manager_gen5.o \ - misc_gen5.o + misc_gen5.o system_manager_gen5.o obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index c45edea..53ced81 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -1,120 +1,11 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef _SYSTEM_MANAGER_H_ -#define _SYSTEM_MANAGER_H_ - -#ifndef __ASSEMBLY__ - -void sysmgr_pinmux_init(void); -void sysmgr_config_warmrstcfgio(int enable); - -void sysmgr_get_pinmux_table(const u8 **table, unsigned int *table_len); -#endif - -struct socfpga_system_manager { - /* System Manager Module */ - u32 siliconid1; /* 0x00 */ - u32 siliconid2; - u32 _pad_0x8_0xf[2]; - u32 wddbg; /* 0x10 */ - u32 bootinfo; - u32 hpsinfo; - u32 parityinj; - /* FPGA Interface Group */ - u32 fpgaintfgrp_gbl; /* 0x20 */ - u32 fpgaintfgrp_indiv; - u32 fpgaintfgrp_module; - u32 _pad_0x2c_0x2f; - /* Scan Manager Group */ - u32 scanmgrgrp_ctrl; /* 0x30 */ - u32 _pad_0x34_0x3f[3]; - /* Freeze Control Group */ - u32 frzctrl_vioctrl; /* 0x40 */ - u32 _pad_0x44_0x4f[3]; - u32 frzctrl_hioctrl; /* 0x50 */ - u32 frzctrl_src; - u32 frzctrl_hwctrl; - u32 _pad_0x5c_0x5f; - /* EMAC Group */ - u32 emacgrp_ctrl; /* 0x60 */ - u32 emacgrp_l3master; - u32 _pad_0x68_0x6f[2]; - /* DMA Controller Group */ - u32 dmagrp_ctrl; /* 0x70 */ - u32 dmagrp_persecurity; - u32 _pad_0x78_0x7f[2]; - /* Preloader (initial software) Group */ - u32 iswgrp_handoff[8]; /* 0x80 */ - u32 _pad_0xa0_0xbf[8]; /* 0xa0 */ - /* Boot ROM Code Register Group */ - u32 romcodegrp_ctrl; /* 0xc0 */ - u32 romcodegrp_cpu1startaddr; - u32 romcodegrp_initswstate; - u32 romcodegrp_initswlastld; - u32 romcodegrp_bootromswstate; /* 0xd0 */ - u32 __pad_0xd4_0xdf[3]; - /* Warm Boot from On-Chip RAM Group */ - u32 romcodegrp_warmramgrp_enable; /* 0xe0 */ - u32 romcodegrp_warmramgrp_datastart; - u32 romcodegrp_warmramgrp_length; - u32 romcodegrp_warmramgrp_execution; - u32 romcodegrp_warmramgrp_crc; /* 0xf0 */ - u32 __pad_0xf4_0xff[3]; - /* Boot ROM Hardware Register Group */ - u32 romhwgrp_ctrl; /* 0x100 */ - u32 _pad_0x104_0x107; - /* SDMMC Controller Group */ - u32 sdmmcgrp_ctrl; - u32 sdmmcgrp_l3master; - /* NAND Flash Controller Register Group */ - u32 nandgrp_bootstrap; /* 0x110 */ - u32 nandgrp_l3master; - /* USB Controller Group */ - u32 usbgrp_l3master; - u32 _pad_0x11c_0x13f[9]; - /* ECC Management Register Group */ - u32 eccgrp_l2; /* 0x140 */ - u32 eccgrp_ocram; - u32 eccgrp_usb0; - u32 eccgrp_usb1; - u32 eccgrp_emac0; /* 0x150 */ - u32 eccgrp_emac1; - u32 eccgrp_dma; - u32 eccgrp_can0; - u32 eccgrp_can1; /* 0x160 */ - u32 eccgrp_nand; - u32 eccgrp_qspi; - u32 eccgrp_sdmmc; - u32 _pad_0x170_0x3ff[164]; - /* Pin Mux Control Group */ - u32 emacio[20]; /* 0x400 */ - u32 flashio[12]; /* 0x450 */ - u32 generalio[28]; /* 0x480 */ - u32 _pad_0x4f0_0x4ff[4]; - u32 mixed1io[22]; /* 0x500 */ - u32 mixed2io[8]; /* 0x558 */ - u32 gplinmux[23]; /* 0x578 */ - u32 gplmux[71]; /* 0x5d4 */ - u32 nandusefpga; /* 0x6f0 */ - u32 _pad_0x6f4; - u32 rgmii1usefpga; /* 0x6f8 */ - u32 _pad_0x6fc_0x700[2]; - u32 i2c0usefpga; /* 0x704 */ - u32 sdmmcusefpga; /* 0x708 */ - u32 _pad_0x70c_0x710[2]; - u32 rgmii0usefpga; /* 0x714 */ - u32 _pad_0x718_0x720[3]; - u32 i2c3usefpga; /* 0x724 */ - u32 i2c2usefpga; /* 0x728 */ - u32 i2c1usefpga; /* 0x72c */ - u32 spim1usefpga; /* 0x730 */ - u32 _pad_0x734; - u32 spim0usefpga; /* 0x738 */ -}; +#ifndef _SYSTEM_MANAGER_H_ +#define _SYSTEM_MANAGER_H_
#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX (1 << 0) #define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO (1 << 1) @@ -129,12 +20,6 @@ struct socfpga_system_manager { #define SYSMGR_FPGAINTF_NAND (1 << 4) #define SYSMGR_FPGAINTF_SDMMC (1 << 5)
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -#define SYSMGR_SDMMC_SMPLSEL_SHIFT 3 -#else -#define SYSMGR_SDMMC_SMPLSEL_SHIFT 4 -#endif - #define SYSMGR_SDMMC_DRVSEL_SHIFT 0
/* EMAC Group Bit definitions */ @@ -146,4 +31,8 @@ struct socfpga_system_manager { #define SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB 2 #define SYSMGR_EMACGRP_CTRL_PHYSEL_MASK 0x3
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#include <asm/arch/system_manager_gen5.h> +#endif + #endif /* _SYSTEM_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h new file mode 100755 index 0000000..3ad4ca1 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h @@ -0,0 +1,121 @@ +/* + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _SYSTEM_MANAGER_GEN5_H_ +#define _SYSTEM_MANAGER_GEN5_H_ + +#ifndef __ASSEMBLY__ + +void sysmgr_pinmux_init(void); +void sysmgr_config_warmrstcfgio(int enable); + +void sysmgr_get_pinmux_table(const u8 **table, unsigned int *table_len); + +struct socfpga_system_manager { + /* System Manager Module */ + u32 siliconid1; /* 0x00 */ + u32 siliconid2; + u32 _pad_0x8_0xf[2]; + u32 wddbg; /* 0x10 */ + u32 bootinfo; + u32 hpsinfo; + u32 parityinj; + /* FPGA Interface Group */ + u32 fpgaintfgrp_gbl; /* 0x20 */ + u32 fpgaintfgrp_indiv; + u32 fpgaintfgrp_module; + u32 _pad_0x2c_0x2f; + /* Scan Manager Group */ + u32 scanmgrgrp_ctrl; /* 0x30 */ + u32 _pad_0x34_0x3f[3]; + /* Freeze Control Group */ + u32 frzctrl_vioctrl; /* 0x40 */ + u32 _pad_0x44_0x4f[3]; + u32 frzctrl_hioctrl; /* 0x50 */ + u32 frzctrl_src; + u32 frzctrl_hwctrl; + u32 _pad_0x5c_0x5f; + /* EMAC Group */ + u32 emacgrp_ctrl; /* 0x60 */ + u32 emacgrp_l3master; + u32 _pad_0x68_0x6f[2]; + /* DMA Controller Group */ + u32 dmagrp_ctrl; /* 0x70 */ + u32 dmagrp_persecurity; + u32 _pad_0x78_0x7f[2]; + /* Preloader (initial software) Group */ + u32 iswgrp_handoff[8]; /* 0x80 */ + u32 _pad_0xa0_0xbf[8]; /* 0xa0 */ + /* Boot ROM Code Register Group */ + u32 romcodegrp_ctrl; /* 0xc0 */ + u32 romcodegrp_cpu1startaddr; + u32 romcodegrp_initswstate; + u32 romcodegrp_initswlastld; + u32 romcodegrp_bootromswstate; /* 0xd0 */ + u32 __pad_0xd4_0xdf[3]; + /* Warm Boot from On-Chip RAM Group */ + u32 romcodegrp_warmramgrp_enable; /* 0xe0 */ + u32 romcodegrp_warmramgrp_datastart; + u32 romcodegrp_warmramgrp_length; + u32 romcodegrp_warmramgrp_execution; + u32 romcodegrp_warmramgrp_crc; /* 0xf0 */ + u32 __pad_0xf4_0xff[3]; + /* Boot ROM Hardware Register Group */ + u32 romhwgrp_ctrl; /* 0x100 */ + u32 _pad_0x104_0x107; + /* SDMMC Controller Group */ + u32 sdmmcgrp_ctrl; + u32 sdmmcgrp_l3master; + /* NAND Flash Controller Register Group */ + u32 nandgrp_bootstrap; /* 0x110 */ + u32 nandgrp_l3master; + /* USB Controller Group */ + u32 usbgrp_l3master; + u32 _pad_0x11c_0x13f[9]; + /* ECC Management Register Group */ + u32 eccgrp_l2; /* 0x140 */ + u32 eccgrp_ocram; + u32 eccgrp_usb0; + u32 eccgrp_usb1; + u32 eccgrp_emac0; /* 0x150 */ + u32 eccgrp_emac1; + u32 eccgrp_dma; + u32 eccgrp_can0; + u32 eccgrp_can1; /* 0x160 */ + u32 eccgrp_nand; + u32 eccgrp_qspi; + u32 eccgrp_sdmmc; + u32 _pad_0x170_0x3ff[164]; + /* Pin Mux Control Group */ + u32 emacio[20]; /* 0x400 */ + u32 flashio[12]; /* 0x450 */ + u32 generalio[28]; /* 0x480 */ + u32 _pad_0x4f0_0x4ff[4]; + u32 mixed1io[22]; /* 0x500 */ + u32 mixed2io[8]; /* 0x558 */ + u32 gplinmux[23]; /* 0x578 */ + u32 gplmux[71]; /* 0x5d4 */ + u32 nandusefpga; /* 0x6f0 */ + u32 _pad_0x6f4; + u32 rgmii1usefpga; /* 0x6f8 */ + u32 _pad_0x6fc_0x700[2]; + u32 i2c0usefpga; /* 0x704 */ + u32 sdmmcusefpga; /* 0x708 */ + u32 _pad_0x70c_0x710[2]; + u32 rgmii0usefpga; /* 0x714 */ + u32 _pad_0x718_0x720[3]; + u32 i2c3usefpga; /* 0x724 */ + u32 i2c2usefpga; /* 0x728 */ + u32 i2c1usefpga; /* 0x72c */ + u32 spim1usefpga; /* 0x730 */ + u32 _pad_0x734; + u32 spim0usefpga; /* 0x738 */ +}; +#endif + +#define SYSMGR_SDMMC_SMPLSEL_SHIFT 3 + +#endif /* _SYSTEM_MANAGER_GEN5_H_ */ diff --git a/arch/arm/mach-socfpga/system_manager.c b/arch/arm/mach-socfpga/system_manager.c deleted file mode 100644 index 75a65f3..0000000 --- a/arch/arm/mach-socfpga/system_manager.c +++ /dev/null @@ -1,85 +0,0 @@ -/* - * Copyright (C) 2013 Altera Corporation <www.altera.com> - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/arch/system_manager.h> -#include <asm/arch/fpga_manager.h> - -DECLARE_GLOBAL_DATA_PTR; - -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - -/* - * Populate the value for SYSMGR.FPGAINTF.MODULE based on pinmux setting. - * The value is not wrote to SYSMGR.FPGAINTF.MODULE but - * CONFIG_SYSMGR_ISWGRP_HANDOFF. - */ -static void populate_sysmgr_fpgaintf_module(void) -{ - uint32_t handoff_val = 0; - - /* ISWGRP_HANDOFF_FPGAINTF */ - writel(0, &sysmgr_regs->iswgrp_handoff[2]); - - /* Enable the signal for those HPS peripherals that use FPGA. */ - if (readl(&sysmgr_regs->nandusefpga) == SYSMGR_FPGAINTF_USEFPGA) - handoff_val |= SYSMGR_FPGAINTF_NAND; - if (readl(&sysmgr_regs->rgmii1usefpga) == SYSMGR_FPGAINTF_USEFPGA) - handoff_val |= SYSMGR_FPGAINTF_EMAC1; - if (readl(&sysmgr_regs->sdmmcusefpga) == SYSMGR_FPGAINTF_USEFPGA) - handoff_val |= SYSMGR_FPGAINTF_SDMMC; - if (readl(&sysmgr_regs->rgmii0usefpga) == SYSMGR_FPGAINTF_USEFPGA) - handoff_val |= SYSMGR_FPGAINTF_EMAC0; - if (readl(&sysmgr_regs->spim0usefpga) == SYSMGR_FPGAINTF_USEFPGA) - handoff_val |= SYSMGR_FPGAINTF_SPIM0; - if (readl(&sysmgr_regs->spim1usefpga) == SYSMGR_FPGAINTF_USEFPGA) - handoff_val |= SYSMGR_FPGAINTF_SPIM1; - - /* populate (not writing) the value for SYSMGR.FPGAINTF.MODULE - based on pinmux setting */ - setbits_le32(&sysmgr_regs->iswgrp_handoff[2], handoff_val); - - handoff_val = readl(&sysmgr_regs->iswgrp_handoff[2]); - if (fpgamgr_test_fpga_ready()) { - /* Enable the required signals only */ - writel(handoff_val, &sysmgr_regs->fpgaintfgrp_module); - } -} - -/* - * Configure all the pin muxes - */ -void sysmgr_pinmux_init(void) -{ - uint32_t regs = (uint32_t)&sysmgr_regs->emacio[0]; - const u8 *sys_mgr_init_table; - unsigned int len; - int i; - - sysmgr_get_pinmux_table(&sys_mgr_init_table, &len); - - for (i = 0; i < len; i++) { - writel(sys_mgr_init_table[i], regs); - regs += sizeof(regs); - } - - populate_sysmgr_fpgaintf_module(); -} - -/* - * This bit allows the bootrom to configure the IOs after a warm reset. - */ -void sysmgr_config_warmrstcfgio(int enable) -{ - if (enable) - setbits_le32(&sysmgr_regs->romcodegrp_ctrl, - SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO); - else - clrbits_le32(&sysmgr_regs->romcodegrp_ctrl, - SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO); -} diff --git a/arch/arm/mach-socfpga/system_manager_gen5.c b/arch/arm/mach-socfpga/system_manager_gen5.c new file mode 100644 index 0000000..3588a57 --- /dev/null +++ b/arch/arm/mach-socfpga/system_manager_gen5.c @@ -0,0 +1,85 @@ +/* + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/fpga_manager.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +/* + * Populate the value for SYSMGR.FPGAINTF.MODULE based on pinmux setting. + * The value is not wrote to SYSMGR.FPGAINTF.MODULE but + * CONFIG_SYSMGR_ISWGRP_HANDOFF. + */ +static void populate_sysmgr_fpgaintf_module(void) +{ + u32 handoff_val = 0; + + /* ISWGRP_HANDOFF_FPGAINTF */ + writel(0, &sysmgr_regs->iswgrp_handoff[2]); + + /* Enable the signal for those HPS peripherals that use FPGA. */ + if (readl(&sysmgr_regs->nandusefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_NAND; + if (readl(&sysmgr_regs->rgmii1usefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_EMAC1; + if (readl(&sysmgr_regs->sdmmcusefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_SDMMC; + if (readl(&sysmgr_regs->rgmii0usefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_EMAC0; + if (readl(&sysmgr_regs->spim0usefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_SPIM0; + if (readl(&sysmgr_regs->spim1usefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_SPIM1; + + /* populate (not writing) the value for SYSMGR.FPGAINTF.MODULE + based on pinmux setting */ + setbits_le32(&sysmgr_regs->iswgrp_handoff[2], handoff_val); + + handoff_val = readl(&sysmgr_regs->iswgrp_handoff[2]); + if (fpgamgr_test_fpga_ready()) { + /* Enable the required signals only */ + writel(handoff_val, &sysmgr_regs->fpgaintfgrp_module); + } +} + +/* + * Configure all the pin muxes + */ +void sysmgr_pinmux_init(void) +{ + u32 regs = (u32)&sysmgr_regs->emacio[0]; + const u8 *sys_mgr_init_table; + unsigned int len; + int i; + + sysmgr_get_pinmux_table(&sys_mgr_init_table, &len); + + for (i = 0; i < len; i++) { + writel(sys_mgr_init_table[i], regs); + regs += sizeof(regs); + } + + populate_sysmgr_fpgaintf_module(); +} + +/* + * This bit allows the bootrom to configure the IOs after a warm reset. + */ +void sysmgr_config_warmrstcfgio(int enable) +{ + if (enable) + setbits_le32(&sysmgr_regs->romcodegrp_ctrl, + SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO); + else + clrbits_le32(&sysmgr_regs->romcodegrp_ctrl, + SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO); +}
add i2c, timer and other A10 defines.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/include/mach/base_addr_a10.h | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_a10.h b/arch/arm/mach-socfpga/include/mach/base_addr_a10.h index a7056d4..d3dea0b 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_a10.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_a10.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2014 Altera Corporation <www.altera.com> + * Copyright (C) 2014-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -29,14 +29,20 @@ #define SOCFPGA_MPUL2_ADDRESS 0xfffff000 #define SOCFPGA_I2C0_ADDRESS 0xffc02200 #define SOCFPGA_I2C1_ADDRESS 0xffc02300 +#define SOCFPGA_I2C2_ADDRESS 0xffc02400 +#define SOCFPGA_I2C3_ADDRESS 0xffc02500 +#define SOCFPGA_I2C4_ADDRESS 0xffc02600
#define SOCFPGA_ECC_OCRAM_ADDRESS 0xff8c3000 #define SOCFPGA_UART0_ADDRESS 0xffc02000 #define SOCFPGA_OSC1TIMER0_ADDRESS 0xffd00000 +#define SOCFPGA_OSC1TIMER1_ADDRESS 0xffd00100 #define SOCFPGA_CLKMGR_ADDRESS 0xffd04000 #define SOCFPGA_RSTMGR_ADDRESS 0xffd05000
#define SOCFPGA_SDR_ADDRESS 0xffcfb000 +#define SOCFPGA_NOC_L4_PRIV_FLT_OFST 0xffd11000 +#define SOCFPGA_NOC_FW_H2F_SCR_OFST 0xffd13500 #define SOCFPGA_SDR_SCHEDULER_ADDRESS 0xffd12400 #define SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS 0xffd13200 #define SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS 0xffd13300
Start with capital letter please.
- Copyright (C) 2014 Altera Corporation <www.altera.com>
- Copyright (C) 2014-2017 Altera Corporation <www.altera.com>
Shouldn't all this come from DT already ? What's the point of having those macros at all ?
Add reset driver support for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 2 + arch/arm/mach-socfpga/include/mach/reset_manager.h | 4 +- .../include/mach/reset_manager_arria10.h | 144 ++++++++ arch/arm/mach-socfpga/reset_manager_arria10.c | 406 +++++++++++++++++++++ include/dt-bindings/reset/altr,rst-mgr-a10.h | 103 ++++++ 5 files changed, 658 insertions(+), 1 deletion(-) create mode 100755 arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h create mode 100644 arch/arm/mach-socfpga/reset_manager_arria10.c create mode 100644 include/dt-bindings/reset/altr,rst-mgr-a10.h
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index e83da2e..d81f003 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -10,6 +10,8 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \ fpga_manager.o board.o
+obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o + obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
# QTS-generated config file wrappers diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 9e253bf..64526b6 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -43,7 +43,9 @@ void socfpga_per_reset_all(void); /* Create a human-readable reference to SoCFPGA reset. */ #define SOCFPGA_RESET(_name) RSTMGR_##_name
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/reset_manager_arria10.h> +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) #include <asm/arch/reset_manager_gen5.h> #endif
diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h new file mode 100755 index 0000000..2668a86 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h @@ -0,0 +1,144 @@ +/* + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _RESET_MANAGER_ARRIA10_H_ +#define _RESET_MANAGER_ARRIA10_H_ + +void watchdog_disable(void); +void reset_deassert_noc_ddr_scheduler(void); +int is_wdt_in_reset(void); +void emac_manage_reset(ulong emacbase, uint state); +int reset_deassert_bridges_handoff(void); +void reset_assert_fpga_connected_peripherals(void); +void reset_deassert_osc1wd0(void); +void reset_assert_uart(void); +void reset_deassert_uart(void); + +struct socfpga_reset_manager { + u32 stat; + u32 ramstat; + u32 miscstat; + u32 ctrl; + u32 hdsken; + u32 hdskreq; + u32 hdskack; + u32 counts; + u32 mpumodrst; + u32 per0modrst; + u32 per1modrst; + u32 brgmodrst; + u32 sysmodrst; + u32 coldmodrst; + u32 nrstmodrst; + u32 dbgmodrst; + u32 mpuwarmmask; + u32 per0warmmask; + u32 per1warmmask; + u32 brgwarmmask; + u32 syswarmmask; + u32 nrstwarmmask; + u32 l3warmmask; + u32 tststa; + u32 tstscratch; + u32 hdsktimeout; + u32 hmcintr; + u32 hmcintren; + u32 hmcintrens; + u32 hmcintrenr; + u32 hmcgpout; + u32 hmcgpin; +}; + +/* + * SocFPGA Arria10 reset IDs, bank mapping is as follows: + * 0 ... mpumodrst + * 1 ... per0modrst + * 2 ... per1modrst + * 3 ... brgmodrst + * 4 ... sysmodrst + */ +#define RSTMGR_EMAC0 RSTMGR_DEFINE(1, 0) +#define RSTMGR_EMAC1 RSTMGR_DEFINE(1, 1) +#define RSTMGR_EMAC2 RSTMGR_DEFINE(1, 2) +#define RSTMGR_L4WD0 RSTMGR_DEFINE(2, 0) +#define RSTMGR_L4WD1 RSTMGR_DEFINE(2, 1) +#define RSTMGR_L4SYSTIMER0 RSTMGR_DEFINE(2, 2) +#define RSTMGR_L4SYSTIMER1 RSTMGR_DEFINE(2, 3) +#define RSTMGR_SPTIMER0 RSTMGR_DEFINE(2, 4) +#define RSTMGR_SPTIMER1 RSTMGR_DEFINE(2, 5) +#define RSTMGR_UART0 RSTMGR_DEFINE(2, 16) +#define RSTMGR_UART1 RSTMGR_DEFINE(2, 17) +#define RSTMGR_SPIM0 RSTMGR_DEFINE(1, 17) +#define RSTMGR_SPIM1 RSTMGR_DEFINE(1, 18) +#define RSTMGR_QSPI RSTMGR_DEFINE(1, 6) +#define RSTMGR_SDMMC RSTMGR_DEFINE(1, 7) +#define RSTMGR_DMA RSTMGR_DEFINE(1, 16) +#define RSTMGR_DDRSCH RSTMGR_DEFINE(3, 6) + +#define ALT_RSTMGR_CTL_SWWARMRSTREQ_SET_MSK BIT(1) +#define ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK BIT(0) +#define ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK BIT(1) +#define ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK BIT(2) +#define ALT_RSTMGR_PER0MODRST_USB0_SET_MSK BIT(3) +#define ALT_RSTMGR_PER0MODRST_USB1_SET_MSK BIT(4) +#define ALT_RSTMGR_PER0MODRST_NAND_SET_MSK BIT(5) +#define ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK BIT(6) +#define ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK BIT(7) +#define ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK BIT(8) +#define ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK BIT(9) +#define ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK BIT(10) +#define ALT_RSTMGR_PER0MODRST_USBECC0_SET_MSK BIT(11) +#define ALT_RSTMGR_PER0MODRST_USBECC1_SET_MSK BIT(12) +#define ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK BIT(13) +#define ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK BIT(14) +#define ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK BIT(15) +#define ALT_RSTMGR_PER0MODRST_DMA_SET_MSK BIT(16) +#define ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK BIT(17) +#define ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK BIT(18) +#define ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK BIT(19) +#define ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK BIT(20) +#define ALT_RSTMGR_PER0MODRST_DMAECC_SET_MSK BIT(21) +#define ALT_RSTMGR_PER0MODRST_EMACPTP_SET_MSK BIT(22) +#define ALT_RSTMGR_PER0MODRST_DMAIF0_SET_MSK BIT(24) +#define ALT_RSTMGR_PER0MODRST_DMAIF1_SET_MSK BIT(25) +#define ALT_RSTMGR_PER0MODRST_DMAIF2_SET_MSK BIT(26) +#define ALT_RSTMGR_PER0MODRST_DMAIF3_SET_MSK BIT(27) +#define ALT_RSTMGR_PER0MODRST_DMAIF4_SET_MSK BIT(28) +#define ALT_RSTMGR_PER0MODRST_DMAIF5_SET_MSK BIT(29) +#define ALT_RSTMGR_PER0MODRST_DMAIF6_SET_MSK BIT(30) +#define ALT_RSTMGR_PER0MODRST_DMAIF7_SET_MSK BIT(31) + +#define ALT_RSTMGR_PER1MODRST_WD0_SET_MSK BIT(0) +#define ALT_RSTMGR_PER1MODRST_WD1_SET_MSK BIT(1) +#define ALT_RSTMGR_PER1MODRST_L4SYSTMR0_SET_MSK BIT(2) +#define ALT_RSTMGR_PER1MODRST_L4SYSTMR1_SET_MSK BIT(3) +#define ALT_RSTMGR_PER1MODRST_SPTMR0_SET_MSK BIT(4) +#define ALT_RSTMGR_PER1MODRST_SPTMR1_SET_MSK BIT(5) +#define ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK BIT(8) +#define ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK BIT(9) +#define ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK BIT(10) +#define ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK BIT(11) +#define ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK BIT(12) +#define ALT_RSTMGR_PER1MODRST_UART0_SET_MSK BIT(16) +#define ALT_RSTMGR_PER1MODRST_UART1_SET_MSK BIT(17) +#define ALT_RSTMGR_PER1MODRST_GPIO0_SET_MSK BIT(24) +#define ALT_RSTMGR_PER1MODRST_GPIO1_SET_MSK BIT(25) +#define ALT_RSTMGR_PER1MODRST_GPIO2_SET_MSK BIT(26) + +#define ALT_RSTMGR_BRGMODRST_H2F_SET_MSK BIT(0) +#define ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK BIT(1) +#define ALT_RSTMGR_BRGMODRST_F2H_SET_MSK BIT(2) +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK BIT(3) +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK BIT(4) +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK BIT(5) +#define ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK BIT(6) + +#define ALT_RSTMGR_HDSKEN_SDRSELFREFEN_SET_MSK BIT(0) +#define ALT_RSTMGR_HDSKEN_FPGAMGRHSEN_SET_MSK BIT(1) +#define ALT_RSTMGR_HDSKEN_FPGAHSEN_SET_MSK BIT(2) +#define ALT_RSTMGR_HDSKEN_ETRSTALLEN_SET_MSK BIT(3) + +#endif /* _RESET_MANAGER_ARRIA10_H_ */ diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c new file mode 100644 index 0000000..01156de --- /dev/null +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -0,0 +1,406 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/fpga_manager.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <fdtdec.h> +#include <errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_reset_manager *reset_manager_base = + (void *)SOCFPGA_RSTMGR_ADDRESS; +static const struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +static int get_bridge_init_val(const void *blob, int compat_id); + +#define ECC_MASK (ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK) + +void reset_assert_uart(void) +{ + u32 mask = 0; + unsigned int com_port; + + com_port = uart_com_port(gd->fdt_blob); + + if (SOCFPGA_UART1_ADDRESS == com_port) + mask |= ALT_RSTMGR_PER1MODRST_UART1_SET_MSK; + else if (SOCFPGA_UART0_ADDRESS == com_port) + mask |= ALT_RSTMGR_PER1MODRST_UART0_SET_MSK; + + setbits_le32(&reset_manager_base->per1modrst, mask); +} + +void reset_deassert_uart(void) +{ + u32 mask = 0; + unsigned int com_port; + + com_port = uart_com_port(gd->fdt_blob); + + if (SOCFPGA_UART1_ADDRESS == com_port) + mask |= ALT_RSTMGR_PER1MODRST_UART1_SET_MSK; + else if (SOCFPGA_UART0_ADDRESS == com_port) + mask |= ALT_RSTMGR_PER1MODRST_UART0_SET_MSK; + + clrbits_le32(&reset_manager_base->per1modrst, mask); +} + +static const u32 per0fpgamasks[] = { + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK, + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK, + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK, + 0, /* i2c0 per1mod */ + 0, /* i2c1 per1mod */ + 0, /* i2c0_emac */ + 0, /* i2c1_emac */ + 0, /* i2c2_emac */ + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_NAND_SET_MSK, + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK, + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK, + 0, /* uart0 per1mod */ + 0, /* uart1 per1mod */ +}; + +static const u32 per1fpgamasks[] = { + 0, /* emac0 per0mod */ + 0, /* emac1 per0mod */ + 0, /* emac2 per0mod */ + ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK, + ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK, + ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK, /* i2c0_emac */ + ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK, /* i2c1_emac */ + ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK, /* i2c2_emac */ + 0, /* nand per0mod */ + 0, /* qspi per0mod */ + 0, /* sdmmc per0mod */ + 0, /* spim0 per0mod */ + 0, /* spim1 per0mod */ + 0, /* spis0 per0mod */ + 0, /* spis1 per0mod */ + ALT_RSTMGR_PER1MODRST_UART0_SET_MSK, + ALT_RSTMGR_PER1MODRST_UART1_SET_MSK, +}; + +struct bridge_cfg { + int compat_id; + u32 mask_noc; + u32 mask_rstmgr; +}; + +static const struct bridge_cfg bridge_cfg_tbl[] = { + { + COMPAT_ALTERA_SOCFPGA_H2F_BRG, + ALT_SYSMGR_NOC_H2F_SET_MSK, + ALT_RSTMGR_BRGMODRST_H2F_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_LWH2F_BRG, + ALT_SYSMGR_NOC_LWH2F_SET_MSK, + ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2H_BRG, + ALT_SYSMGR_NOC_F2H_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2H_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR0, + ALT_SYSMGR_NOC_F2SDR0_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR1, + ALT_SYSMGR_NOC_F2SDR1_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR2, + ALT_SYSMGR_NOC_F2SDR2_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK, + }, +}; + +/* Disable the watchdog (toggle reset to watchdog) */ +void watchdog_disable(void) +{ + /* assert reset for watchdog */ + setbits_le32(&reset_manager_base->per1modrst, + ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); +} + +/* Release NOC ddr scheduler from reset */ +void reset_deassert_noc_ddr_scheduler(void) +{ + clrbits_le32(&reset_manager_base->brgmodrst, + ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK); +} + +/* Check whether Watchdog in reset state? */ +int is_wdt_in_reset(void) +{ + u32 val; + + val = readl(&reset_manager_base->per1modrst); + val &= ALT_RSTMGR_PER1MODRST_WD0_SET_MSK; + + /* return 0x1 if watchdog in reset */ + return val; +} + +/* emacbase: base address of emac to enable/disable reset + * state: 0 - disable reset, !0 - enable reset + */ +void emac_manage_reset(ulong emacbase, uint state) +{ + ulong eccmask; + ulong emacmask; + switch (emacbase) { + case SOCFPGA_EMAC0_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK; + break; + case SOCFPGA_EMAC1_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK; + break; + case SOCFPGA_EMAC2_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK; + break; + default: + error("emac base address unexpected! %lx", emacbase); + hang(); + break; + } + + if (state) { + /* Enable ECC OCP first */ + setbits_le32(&reset_manager_base->per0modrst, eccmask); + setbits_le32(&reset_manager_base->per0modrst, emacmask); + } else { + /* Disable ECC OCP first */ + clrbits_le32(&reset_manager_base->per0modrst, emacmask); + clrbits_le32(&reset_manager_base->per0modrst, eccmask); + } +} + +static int get_bridge_init_val(const void *blob, int compat_id) +{ + int rval = 0; + int node; + u32 val; + + node = fdtdec_next_compatible(blob, 0, compat_id); + if (node >= 0) { + if (!fdtdec_get_int_array(blob, node, "init-val", &val, 1)) { + if (val == 1) + rval = val; + } + } + return rval; +} + +/* Enable bridges (hps2fpga, lwhps2fpga, fpga2hps, fpga2sdram) per handoff */ +int reset_deassert_bridges_handoff(void) +{ + u32 mask_noc = 0, mask_rstmgr = 0; + int i; + unsigned start = get_timer(0); + + for (i = 0; i < ARRAY_SIZE(bridge_cfg_tbl); i++) { + if (get_bridge_init_val(gd->fdt_blob, + bridge_cfg_tbl[i].compat_id)) { + mask_noc |= bridge_cfg_tbl[i].mask_noc; + mask_rstmgr |= bridge_cfg_tbl[i].mask_rstmgr; + } + } + + /* clear idle request to all bridges */ + setbits_le32(&sysmgr_regs->noc_idlereq_clr, mask_noc); + + /* Release bridges from reset state per handoff value */ + clrbits_le32(&reset_manager_base->brgmodrst, mask_rstmgr); + + /* Poll until all idleack to 0, timeout at 1000ms */ + while (readl(&sysmgr_regs->noc_idleack) & mask_noc) { + if (get_timer(start) > 1000) { + printf("Fail: noc_idleack = 0x%08x mask_noc = 0x%08x\n", + readl(&sysmgr_regs->noc_idleack), + mask_noc); + return -ETIMEDOUT; + } + } + return 0; +} + +void reset_assert_fpga_connected_peripherals(void) +{ + u32 mask0 = 0; + u32 mask1 = 0; + u32 fpga_pinux_addr = SOCFPGA_PINMUX_FPGA_INTERFACE_ADDRESS; + int i; + + for (i = 0; i < ARRAY_SIZE(per1fpgamasks); i++) { + if (readl(fpga_pinux_addr)) { + mask0 |= per0fpgamasks[i]; + mask1 |= per1fpgamasks[i]; + } + fpga_pinux_addr += sizeof(u32); + } + + setbits_le32(&reset_manager_base->per0modrst, mask0 & ECC_MASK); + setbits_le32(&reset_manager_base->per1modrst, mask1); + setbits_le32(&reset_manager_base->per0modrst, mask0); +} + +/* Release L4 OSC1 Watchdog Timer 0 from reset through reset manager */ +void reset_deassert_osc1wd0(void) +{ + clrbits_le32(&reset_manager_base->per1modrst, + ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); +} + +/* + * Assert or de-assert SoCFPGA reset manager reset. + */ +void socfpga_per_reset(u32 reset, int set) +{ + const volatile u32 *reg; + u32 rstmgr_bank = RSTMGR_BANK(reset); + + switch (rstmgr_bank) { + case 0: + reg = &reset_manager_base->mpumodrst; + break; + case 1: + reg = &reset_manager_base->per0modrst; + break; + case 2: + reg = &reset_manager_base->per1modrst; + break; + case 3: + reg = &reset_manager_base->brgmodrst; + break; + case 4: + reg = &reset_manager_base->sysmodrst; + break; + + default: + return; + } + + if (set) + setbits_le32(reg, 1 << RSTMGR_RESET(reset)); + else + clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); +} + +/* + * Assert reset on every peripheral but L4WD0. + * Watchdog must be kept intact to prevent glitches + * and/or hangs. + * For the Arria10, we disable all the peripherals except L4 watchdog0, + * L4 Timer 0, and ECC. + */ +void socfpga_per_reset_all(void) +{ + const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | + (1 << RSTMGR_RESET(SOCFPGA_RESET(L4SYSTIMER0)))); + + unsigned mask_ecc_ocp = + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_USBECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_USBECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK; + + /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ + writel(~l4wd0, &reset_manager_base->per1modrst); + setbits_le32(&reset_manager_base->per0modrst, ~mask_ecc_ocp); + + /* Finally disable the ECC_OCP */ + setbits_le32(&reset_manager_base->per0modrst, mask_ecc_ocp); +} + +#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) +void socfpga_bridges_reset(int enable) +{ + /* For SoCFPGA-VT, this is NOP. */ +} +#else +void socfpga_bridges_reset(int enable) +{ +/* Disable all the bridges (hps2fpga, lwhps2fpga, fpga2hps, fpga2sdram) */ + /* set idle request to all bridges */ + writel(ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK, + &sysmgr_regs->noc_idlereq_set); + + /* Enable the NOC timeout */ + writel(ALT_SYSMGR_NOC_TMO_EN_SET_MSK, + &sysmgr_regs->noc_timeout); + + /* Poll until all idleack to 1 */ + while ((readl(&sysmgr_regs->noc_idleack) ^ + (ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK))) + ; + + /* Poll until all idlestatus to 1 */ + while ((readl(&sysmgr_regs->noc_idlestatus) ^ + (ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK))) + ; + + /* Put all bridges (except NOR DDR scheduler) into reset state */ + setbits_le32(&reset_manager_base->brgmodrst, + (ALT_RSTMGR_BRGMODRST_H2F_SET_MSK | + ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2H_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK)); + + /* Disable NOC timeout */ + writel(0, &sysmgr_regs->noc_timeout); +} +#endif diff --git a/include/dt-bindings/reset/altr,rst-mgr-a10.h b/include/dt-bindings/reset/altr,rst-mgr-a10.h new file mode 100644 index 0000000..99875de --- /dev/null +++ b/include/dt-bindings/reset/altr,rst-mgr-a10.h @@ -0,0 +1,103 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _DT_BINDINGS_RESET_ALTR_RST_MGR_A10_H +#define _DT_BINDINGS_RESET_ALTR_RST_MGR_A10_H + +/* MPUMODRST */ +#define CPU0_RESET 0 +#define CPU1_RESET 1 +#define WDS_RESET 2 +#define SCUPER_RESET 3 + +/* PER0MODRST */ +#define EMAC0_RESET 32 +#define EMAC1_RESET 33 +#define EMAC2_RESET 34 +#define USB0_RESET 35 +#define USB1_RESET 36 +#define NAND_RESET 37 +#define QSPI_RESET 38 +#define SDMMC_RESET 39 +#define EMAC0_OCP_RESET 40 +#define EMAC1_OCP_RESET 41 +#define EMAC2_OCP_RESET 42 +#define USB0_OCP_RESET 43 +#define USB1_OCP_RESET 44 +#define NAND_OCP_RESET 45 +#define QSPI_OCP_RESET 46 +#define SDMMC_OCP_RESET 47 +#define DMA_RESET 48 +#define SPIM0_RESET 49 +#define SPIM1_RESET 50 +#define SPIS0_RESET 51 +#define SPIS1_RESET 52 +#define DMA_OCP_RESET 53 +#define EMAC_PTP_RESET 54 +/* 55 is empty*/ +#define DMAIF0_RESET 56 +#define DMAIF1_RESET 57 +#define DMAIF2_RESET 58 +#define DMAIF3_RESET 59 +#define DMAIF4_RESET 60 +#define DMAIF5_RESET 61 +#define DMAIF6_RESET 62 +#define DMAIF7_RESET 63 + +/* PER1MODRST */ +#define L4WD0_RESET 64 +#define L4WD1_RESET 65 +#define L4SYSTIMER0_RESET 66 +#define L4SYSTIMER1_RESET 67 +#define SPTIMER0_RESET 68 +#define SPTIMER1_RESET 69 +/* 70-71 is reserved */ +#define I2C0_RESET 72 +#define I2C1_RESET 73 +#define I2C2_RESET 74 +#define I2C3_RESET 75 +#define I2C4_RESET 76 +/* 77-79 is reserved */ +#define UART0_RESET 80 +#define UART1_RESET 81 +/* 82-87 is reserved */ +#define GPIO0_RESET 88 +#define GPIO1_RESET 89 +#define GPIO2_RESET 90 + +/* BRGMODRST */ +#define HPS2FPGA_RESET 96 +#define LWHPS2FPGA_RESET 97 +#define FPGA2HPS_RESET 98 +#define F2SSDRAM0_RESET 99 +#define F2SSDRAM1_RESET 100 +#define F2SSDRAM2_RESET 101 +#define DDRSCH_RESET 102 + +/* SYSMODRST*/ +#define ROM_RESET 128 +#define OCRAM_RESET 129 +/* 130 is reserved */ +#define FPGAMGR_RESET 131 +#define S2F_RESET 132 +#define SYSDBG_RESET 133 +#define OCRAM_OCP_RESET 134 + +/* COLDMODRST */ +#define CLKMGRCOLD_RESET 160 +/* 161-162 is reserved */ +#define S2FCOLD_RESET 163 +#define TIMESTAMPCOLD_RESET 164 +#define TAPCOLD_RESET 165 +#define HMCCOLD_RESET 166 +#define IOMGRCOLD_RESET 167 + +/* NRSTMODRST */ +#define NRSTPINOE_RESET 192 + +/* DBGMODRST */ +#define DBG_RESET 224 +#endif
You can use #elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) instead to keep this list sorted.
- Copyright (C) 2012-2017 Altera Corporation <www.altera.com>
Use #ifdef[space]FOO and #define[space]FOO
- Copyright (C) 2016-2017 Intel Corporation
Use the tabs consistently, one or two, but pick one.
- ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK|\
- ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK|\
- ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK|\
- ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK|\
- ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK)
MSK | \
Keep the spacing please.
- u32 mask = 0;
- unsigned int com_port;
- com_port = uart_com_port(gd->fdt_blob);
What's this function , is it defined later in the patchset ?
- if (SOCFPGA_UART1_ADDRESS == com_port)
- else if (SOCFPGA_UART0_ADDRESS == com_port)
Use if (foo == VALUE) please, not the other way around. Fix globally.
- setbits_le32(&reset_manager_base->per1modrst, mask);
You can combine this with the deassert_uart() function and use clrsetbits instead to avoid duplication of the if () else () logic above.
- u32 mask = 0;
- clrbits_le32(&reset_manager_base->per1modrst, mask);
- int rval = 0;
- int node;
- u32 val;
- node = fdtdec_next_compatible(blob, 0, compat_id);
- if (node >= 0) {
Invert the conditions here to make the indent flat ...
if (val == 1)
rval = val;
- return rval;
- u32 mask_noc = 0, mask_rstmgr = 0;
- int i;
- unsigned start = get_timer(0);
- for (i = 0; i < ARRAY_SIZE(bridge_cfg_tbl); i++) {
- /* clear idle request to all bridges */
- setbits_le32(&sysmgr_regs->noc_idlereq_clr, mask_noc);
- /* Release bridges from reset state per handoff value */
- clrbits_le32(&reset_manager_base->brgmodrst, mask_rstmgr);
- /* Poll until all idleack to 0, timeout at 1000ms */
- while (readl(&sysmgr_regs->noc_idleack) & mask_noc) {
wait_for_bit() ?
mask_noc);
return -ETIMEDOUT;
arch/arm/mach-socfpga/Makefile | 2 + arch/arm/mach-socfpga/include/mach/reset_manager.h | 4 +- .../include/mach/reset_manager_arria10.h | 144 ++++++++ arch/arm/mach-socfpga/reset_manager_arria10.c | 406 +++++++++++++++++++++ include/dt-bindings/reset/altr,rst-mgr-a10.h | 103 ++++++ 5 files changed, 658 insertions(+), 1 deletion(-) create mode 100755 arch/arm/mach- socfpga/include/mach/reset_manager_arria10.h create mode 100644 arch/arm/mach-socfpga/reset_manager_arria10.c create mode 100644 include/dt-bindings/reset/altr,rst-mgr-a10.h
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach- socfpga/Makefile index e83da2e..d81f003 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -10,6 +10,8 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \ fpga_manager.o board.o +obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o
obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o # QTS-generated config file wrappers diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 9e253bf..64526b6 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -43,7 +43,9 @@ void socfpga_per_reset_all(void); /* Create a human-readable reference to SoCFPGA reset. */ #define SOCFPGA_RESET(_name) RSTMGR_##_name -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/reset_manager_arria10.h> +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5)
You want sort with GEN5, ARRIA10 or sorted alphanumerically ARRIA10 then GEN5?
#include <asm/arch/reset_manager_gen5.h> #endif diff --git a/arch/arm/mach- socfpga/include/mach/reset_manager_arria10.h b/arch/arm/mach- socfpga/include/mach/reset_manager_arria10.h new file mode 100755 index 0000000..2668a86 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h @@ -0,0 +1,144 @@ +/*
- * Copyright (C) 2012-2017 Altera Corporation <www.altera.com>
Okay
Okay.
MSK | \
Okay.
- u32 mask = 0;
Oh ya, it is in later patch [misc]. I will try to rearrange this.
Okay.
Okay.
- u32 mask = 0;
- int rval = 0;
- int node;
- u32 val;
- if (node >= 0) {
Okay.
&val, 1)) {
if (val == 1)
rval = val;
- return rval;
- int i;
d)) {
mask_rstmgr |=
wait_for_bit() ?
Yes, can use wait_for_bit()/
mask_noc);
return -ETIMEDOUT;
Thanks.
Regards Ley Foon
I'd opt for sorting this in the order in which those parts came out, but that might be just my personal preference ...
arch/arm/mach-socfpga/Makefile | 2 + arch/arm/mach-socfpga/include/mach/reset_manager.h | 4 +- .../include/mach/reset_manager_arria10.h | 144 ++++++++ arch/arm/mach-socfpga/reset_manager_arria10.c | 406 +++++++++++++++++++++ include/dt-bindings/reset/altr,rst-mgr-a10.h | 103 ++++++ 5 files changed, 658 insertions(+), 1 deletion(-) create mode 100755 arch/arm/mach- socfpga/include/mach/reset_manager_arria10.h create mode 100644 arch/arm/mach- socfpga/reset_manager_arria10.c create mode 100644 include/dt-bindings/reset/altr,rst-mgr- a10.h
Okay, will sorting it with GEN5, ARRIA10.
Thanks.
Regards Ley Foon
Okay
Okay.
MSK | \
Okay.
- u32 mask = 0;
Regarding this, can we keep this as is now since this reset_manager_arria10.c will not be compiled until we add TARGET_SOCFPGA_ARRIA10 in Kconfig in last patch.
Thanks.
Regards Ley Foon
Okay
Okay.
MSK | \
Okay.
- u32 mask = 0;
Can we git-bisect through this patchset ? That's the important question here.
Add clock driver support for Arria 10 and update Gen5 clock driver.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 3 +- arch/arm/mach-socfpga/clock_manager.c | 36 +- arch/arm/mach-socfpga/clock_manager_arria10.c | 1104 ++++++++++++++++++++ arch/arm/mach-socfpga/clock_manager_gen5.c | 132 ++- arch/arm/mach-socfpga/include/mach/clock_manager.h | 8 +- .../include/mach/clock_manager_arria10.h | 231 ++++ 6 files changed, 1455 insertions(+), 59 deletions(-) create mode 100644 arch/arm/mach-socfpga/clock_manager_arria10.c mode change 100755 => 100644 arch/arm/mach-socfpga/clock_manager_gen5.c create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index d81f003..c494930 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -10,7 +10,8 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \ fpga_manager.o board.o
-obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o +obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clock_manager_arria10.o \ + reset_manager_arria10.o
diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index d675973..7f48193 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -7,6 +7,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/clock_manager.h> +#include <fdtdec.h>
@@ -18,7 +19,12 @@ void cm_wait_for_lock(u32 mask) register u32 inter_val; u32 retry = 0; do { +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + inter_val = readl(&clock_manager_base->stat) & mask; +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) inter_val = readl(&clock_manager_base->inter) & mask; +#endif + /* Wait for stable lock */ if (inter_val == mask) retry++; else @@ -31,22 +37,39 @@ void cm_wait_for_lock(u32 mask) /* function to poll in the fsm busy bit */ void cm_wait_for_fsm(void) { - while (readl(&clock_manager_base->stat) & CLKMGR_STAT_BUSY) + while (readl(&clock_manager_base->stat) & + CLKMGR_CLKMGR_STAT_BUSY_SET_MSK) ; }
static void cm_print_clock_quick_summary(void) { printf("MPU %10ld kHz\n", cm_get_mpu_clk_hz() / 1000); + printf("MMC %8d kHz\n", cm_get_mmc_controller_clk_hz() / 1000); + printf("QSPI %8d kHz\n", + cm_get_qspi_controller_clk_hz() / 1000); + printf("SPI %8d kHz\n", cm_get_spi_controller_clk_hz() / 1000); +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + printf("EOSC1 %8d kHz\n", eosc1_hz / 1000); + printf("cb_intosc %8d kHz\n", cb_intosc_hz / 1000); + printf("f2s_free %8d kHz\n", f2s_free_hz / 1000); + printf("Main VCO %8d kHz\n", cm_get_main_vco_clk_hz()/1000); + printf("NOC %8d kHz\n", cm_get_noc_clk_hz()/1000); + printf("L4 Main %8d kHz\n", + cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB)/1000); + printf("L4 MP %8d kHz\n", + cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB)/1000); + printf("L4 SP %8d kHz\n", + cm_get_l4_sp_clk_hz()/1000); + printf("L4 sys free %8d kHz\n", cm_l4_sys_free_clk_hz/1000); +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) printf("DDR %10ld kHz\n", cm_get_sdram_clk_hz() / 1000); printf("EOSC1 %8d kHz\n", cm_get_osc_clk_hz(1) / 1000); printf("EOSC2 %8d kHz\n", cm_get_osc_clk_hz(2) / 1000); printf("F2S_SDR_REF %8d kHz\n", cm_get_f2s_sdr_ref_clk_hz() / 1000); printf("F2S_PER_REF %8d kHz\n", cm_get_f2s_per_ref_clk_hz() / 1000); - printf("MMC %8d kHz\n", cm_get_mmc_controller_clk_hz() / 1000); - printf("QSPI %8d kHz\n", cm_get_qspi_controller_clk_hz() / 1000); printf("UART %8d kHz\n", cm_get_l4_sp_clk_hz() / 1000); - printf("SPI %8d kHz\n", cm_get_spi_controller_clk_hz() / 1000); +#endif }
int set_cpu_clk_info(void) @@ -57,7 +80,12 @@ int set_cpu_clk_info(void)
gd->bd->bi_arm_freq = cm_get_mpu_clk_hz() / 1000000; gd->bd->bi_dsp_freq = 0; + +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + gd->bd->bi_ddr_freq = 0; +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) gd->bd->bi_ddr_freq = cm_get_sdram_clk_hz() / 1000000; +#endif
return 0; } diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c new file mode 100644 index 0000000..4fa841f --- /dev/null +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -0,0 +1,1104 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock_manager.h> +#include <fdtdec.h> + +DECLARE_GLOBAL_DATA_PTR; + +u32 eosc1_hz; +u32 cb_intosc_hz; +u32 f2s_free_hz; +u32 cm_l4_main_clk_hz; +u32 cm_l4_sp_clk_hz; +u32 cm_l4_mp_clk_hz; +u32 cm_l4_sys_free_clk_hz; + +struct strtopu32 { + const char *str; + u32 *p; +}; + +struct mainpll_cfg { + u32 vco0_psrc; + u32 vco1_denom; + u32 vco1_numer; + u32 mpuclk; + u32 mpuclk_cnt; + u32 mpuclk_src; + u32 nocclk; + u32 nocclk_cnt; + u32 nocclk_src; + u32 cntr2clk_cnt; + u32 cntr3clk_cnt; + u32 cntr4clk_cnt; + u32 cntr5clk_cnt; + u32 cntr6clk_cnt; + u32 cntr7clk_cnt; + u32 cntr7clk_src; + u32 cntr8clk_cnt; + u32 cntr9clk_cnt; + u32 cntr9clk_src; + u32 cntr15clk_cnt; + u32 nocdiv_l4mainclk; + u32 nocdiv_l4mpclk; + u32 nocdiv_l4spclk; + u32 nocdiv_csatclk; + u32 nocdiv_cstraceclk; + u32 nocdiv_cspdbclk; +}; + +struct perpll_cfg { + u32 vco0_psrc; + u32 vco1_denom; + u32 vco1_numer; + u32 cntr2clk_cnt; + u32 cntr2clk_src; + u32 cntr3clk_cnt; + u32 cntr3clk_src; + u32 cntr4clk_cnt; + u32 cntr4clk_src; + u32 cntr5clk_cnt; + u32 cntr5clk_src; + u32 cntr6clk_cnt; + u32 cntr6clk_src; + u32 cntr7clk_cnt; + u32 cntr8clk_cnt; + u32 cntr8clk_src; + u32 cntr9clk_cnt; + u32 emacctl_emac0sel; + u32 emacctl_emac1sel; + u32 emacctl_emac2sel; + u32 gpiodiv_gpiodbclk; +}; + +struct alteragrp_cfg { + u32 nocclk; + u32 mpuclk; +}; + +static const struct socfpga_clock_manager *clock_manager_base = + (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; + +static int of_to_struct(const void *blob, int node, int cfg_len, void *cfg) +{ + if (fdtdec_get_int_array(blob, node, "altr,of_reg_value", + (u32 *)cfg, cfg_len)) { + /* could not find required property */ + return 100; + } + + return 0; +} + +static int of_get_input_clks(const void *blob, int node, void *cfg) +{ + if (fdtdec_get_int_array(blob, node, "clock-frequency", + (u32 *)cfg, 1)) { + /* could not find required property */ + return 100; + } + + return 0; +} + +static int of_get_clk_cfg(const void *blob, struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + struct alteragrp_cfg *altrgrp_cfg) +{ + int node, child, len; + const char *node_name; + + node = fdtdec_next_compatible(blob, 0, COMPAT_ALTERA_SOCFPGA_CLK); + + if (node < 0) + return 1; + + child = fdt_first_subnode(blob, node); + + if (child < 0) + return 2; + + child = fdt_first_subnode(blob, child); + + if (child < 0) + return 3; + + node_name = fdt_get_name(blob, child, &len); + + while (node_name) { + if (!strcmp(node_name, "osc1")) { + if (of_get_input_clks(blob, child, &eosc1_hz)) + return 101; + } else if (!strcmp(node_name, "cb_intosc_ls_clk")) { + if (of_get_input_clks(blob, child, &cb_intosc_hz)) + return 102; + } else if (!strcmp(node_name, "f2s_free_clk")) { + if (of_get_input_clks(blob, child, &f2s_free_hz)) + return 103; + } else if (!strcmp(node_name, "main_pll")) { + if (of_to_struct(blob, child, + sizeof(*main_cfg)/sizeof(u32), + main_cfg)) + return 104; + } else if (!strcmp(node_name, "periph_pll")) { + if (of_to_struct(blob, child, + sizeof(*per_cfg)/sizeof(u32), + per_cfg)) + return 105; + } else if (!strcmp(node_name, "altera")) { + if (of_to_struct(blob, child, + sizeof(*altrgrp_cfg)/sizeof(u32), + altrgrp_cfg)) + return 106; + + main_cfg->mpuclk = altrgrp_cfg->mpuclk; + main_cfg->nocclk = altrgrp_cfg->nocclk; + } + child = fdt_next_subnode(blob, child); + + if (child < 0) + break; + + node_name = fdt_get_name(blob, child, &len); + } + + return 0; +} + +/* calculate the intended main VCO frequency based on handoff */ +static unsigned int cm_calc_handoff_main_vco_clk_hz + (struct mainpll_cfg *main_cfg) +{ + unsigned int clk_hz; + + /* Check main VCO clock source: eosc, intosc or f2s? */ + switch (main_cfg->vco0_psrc) { + case CLKMGR_MAINPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + + /* calculate the VCO frequency */ + clk_hz /= (1 + main_cfg->vco1_denom); + clk_hz *= (1 + main_cfg->vco1_numer); + + return clk_hz; +} + +/* calculate the intended periph VCO frequency based on handoff */ +static unsigned int cm_calc_handoff_periph_vco_clk_hz + (struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) +{ + unsigned int clk_hz; + + /* Check periph VCO clock source: eosc, intosc, f2s or mainpll? */ + switch (per_cfg->vco0_psrc) { + case CLKMGR_PERPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz(main_cfg); + clk_hz /= main_cfg->cntr15clk_cnt; + break; + default: + return 0; + } + + /* calculate the VCO frequency */ + clk_hz /= (1 + per_cfg->vco1_denom); + clk_hz *= (1 + per_cfg->vco1_numer); + + return clk_hz; +} + +/* calculate the intended MPU clock frequency based on handoff */ +static unsigned int cm_calc_handoff_mpu_clk_hz(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg) +{ + unsigned int clk_hz; + + /* Check MPU clock source: main, periph, osc1, intosc or f2s? */ + switch (main_cfg->mpuclk_src) { + case CLKMGR_MAINPLL_MPUCLK_SRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz(main_cfg); + clk_hz /= ((main_cfg->mpuclk & CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + + 1); + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_PERI: + clk_hz = cm_calc_handoff_periph_vco_clk_hz(main_cfg, per_cfg); + clk_hz /= (((main_cfg->mpuclk >> + CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1); + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_OSC1: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + + clk_hz /= (main_cfg->mpuclk_cnt + 1); + return clk_hz; +} + +/* calculate the intended NOC clock frequency based on handoff */ +static unsigned int cm_calc_handoff_noc_clk_hz(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg) +{ + unsigned int clk_hz; + + /* Check MPU clock source: main, periph, osc1, intosc or f2s? */ + switch (main_cfg->nocclk_src) { + case CLKMGR_MAINPLL_NOCCLK_SRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz(main_cfg); + clk_hz /= ((main_cfg->nocclk & CLKMGR_MAINPLL_NOCCLK_CNT_MSK) + + 1); + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_PERI: + clk_hz = cm_calc_handoff_periph_vco_clk_hz(main_cfg, per_cfg); + clk_hz /= (((main_cfg->nocclk >> + CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_NOCCLK_CNT_MSK) + 1); + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_OSC1: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + + clk_hz /= (main_cfg->nocclk_cnt + 1); + return clk_hz; +} + +/* return 1 if PLL ramp is required */ +static int cm_is_pll_ramp_required(int main0periph1, + struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg) +{ + /* Check for main PLL */ + if (main0periph1 == 0) { + /* + * PLL ramp is not required if both MPU clock and NOC clock are + * not sourced from main PLL + */ + if (main_cfg->mpuclk_src != CLKMGR_MAINPLL_MPUCLK_SRC_MAIN && + main_cfg->nocclk_src != CLKMGR_MAINPLL_NOCCLK_SRC_MAIN) + return 0; + + /* + * PLL ramp is required if MPU clock is sourced from main PLL + * and MPU clock is over 900MHz (as advised by HW team) + */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_MAIN && + (cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ)) + return 1; + + /* + * PLL ramp is required if NOC clock is sourced from main PLL + * and NOC clock is over 300MHz (as advised by HW team) + */ + if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_MAIN && + (cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ)) + return 2; + + } else if (main0periph1 == 1) { + /* + * PLL ramp is not required if both MPU clock and NOC clock are + * not sourced from periph PLL + */ + if (main_cfg->mpuclk_src != CLKMGR_MAINPLL_MPUCLK_SRC_PERI && + main_cfg->nocclk_src != CLKMGR_MAINPLL_NOCCLK_SRC_PERI) + return 0; + + /* + * PLL ramp is required if MPU clock are source from periph PLL + * and MPU clock is over 900MHz (as advised by HW team) + */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_PERI && + (cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ)) + return 1; + + /* + * PLL ramp is required if NOC clock are source from periph PLL + * and NOC clock is over 300MHz (as advised by HW team) + */ + if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_PERI && + (cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ)) + return 2; + } + return 0; +} + +/* + * Calculate the new PLL numerator which is based on existing DTS hand off and + * intended safe frequency (safe_hz). Note that PLL ramp is only modifying the + * numerator while maintaining denominator as denominator will influence the + * jitter condition. Please refer A10 HPS TRM for the jitter guide. Note final + * value for numerator is minus with 1 to cater our register value + * representation. + */ +static unsigned int cm_calc_safe_pll_numer(int main0periph1, + struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + unsigned int safe_hz) +{ + unsigned int clk_hz = 0; + + /* Check for main PLL */ + if (main0periph1 == 0) { + /* Check main VCO clock source: eosc, intosc or f2s? */ + switch (main_cfg->vco0_psrc) { + case CLKMGR_MAINPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + /* Applicable if MPU clock is from main PLL */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_MAIN) { + /* calculate the safe numer value */ + clk_hz = (safe_hz / clk_hz) * + (main_cfg->mpuclk_cnt + 1) * + ((main_cfg->mpuclk & + CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1) * + (1 + main_cfg->vco1_denom) - 1; + } + /* Reach here if MPU clk not from main PLL but NOC clk is */ + else if (main_cfg->nocclk_src == + CLKMGR_MAINPLL_NOCCLK_SRC_MAIN) { + /* calculate the safe numer value */ + clk_hz = (safe_hz / clk_hz) * + (main_cfg->nocclk_cnt + 1) * + ((main_cfg->nocclk & + CLKMGR_MAINPLL_NOCCLK_CNT_MSK) + 1) * + (1 + main_cfg->vco1_denom) - 1; + } else + clk_hz = 0; + + } else if (main0periph1 == 1) { + /* Check periph VCO clock source: eosc, intosc, f2s, mainpll */ + switch (per_cfg->vco0_psrc) { + case CLKMGR_PERPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz( + main_cfg); + clk_hz /= main_cfg->cntr15clk_cnt; + break; + default: + return 0; + } + /* Applicable if MPU clock is from periph PLL */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_PERI) { + /* calculate the safe numer value */ + clk_hz = (safe_hz / clk_hz) * + (main_cfg->mpuclk_cnt + 1) * + (((main_cfg->mpuclk >> + CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1) * + (1 + per_cfg->vco1_denom) - 1; + } + /* Reach here if MPU clk not from periph PLL but NOC clk is */ + else if (main_cfg->nocclk_src == + CLKMGR_MAINPLL_NOCCLK_SRC_PERI) { + /* calculate the safe numer value */ + clk_hz = (safe_hz / clk_hz) * + (main_cfg->nocclk_cnt + 1) * + (((main_cfg->nocclk >> + CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_NOCCLK_CNT_MSK) + 1) * + (1 + per_cfg->vco1_denom) - 1; + } else + clk_hz = 0; + } + return clk_hz; +} + +/* ramping the main PLL to final value */ +static void cm_pll_ramp_main(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + unsigned int pll_ramp_main_hz) +{ + unsigned int clk_hz = 0, clk_incr_hz = 0, clk_final_hz = 0; + + /* find out the increment value */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_MAIN) { + clk_incr_hz = CLKMGR_PLL_RAMP_MPUCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg); + } else if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_MAIN) { + clk_incr_hz = CLKMGR_PLL_RAMP_NOCCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg); + } + /* execute the ramping here */ + for (clk_hz = pll_ramp_main_hz + clk_incr_hz; + clk_hz < clk_final_hz; clk_hz += clk_incr_hz) { + writel((main_cfg->vco1_denom << + CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(0, main_cfg, per_cfg, clk_hz), + &clock_manager_base->main_pll.vco1); + udelay(1000); + cm_wait_for_lock(LOCKED_MASK); + } + writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + main_cfg->vco1_numer, + &clock_manager_base->main_pll.vco1); + udelay(1000); + cm_wait_for_lock(LOCKED_MASK); +} + +/* ramping the periph PLL to final value */ +static void cm_pll_ramp_periph(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + unsigned int pll_ramp_periph_hz) +{ + unsigned int clk_hz = 0, clk_incr_hz = 0, clk_final_hz = 0; + + /* find out the increment value */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_PERI) { + clk_incr_hz = CLKMGR_PLL_RAMP_MPUCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg); + } else if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_PERI) { + clk_incr_hz = CLKMGR_PLL_RAMP_NOCCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg); + } + /* execute the ramping here */ + for (clk_hz = pll_ramp_periph_hz + clk_incr_hz; + clk_hz < clk_final_hz; clk_hz += clk_incr_hz) { + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(1, main_cfg, per_cfg, clk_hz), + &clock_manager_base->per_pll.vco1); + udelay(1000); + cm_wait_for_lock(LOCKED_MASK); + } + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + per_cfg->vco1_numer, + &clock_manager_base->per_pll.vco1); + udelay(1000); + cm_wait_for_lock(LOCKED_MASK); +} + +/* + * Setup clocks while making no assumptions of the + * previous state of the clocks. + * + * Start by being paranoid and gate all sw managed clocks + * + * Put all plls in bypass + * + * Put all plls VCO registers back to reset value (bgpwr dwn). + * + * Put peripheral and main pll src to reset value to avoid glitch. + * + * Delay 5 us. + * + * Deassert bg pwr dn and set numerator and denominator + * + * Start 7 us timer. + * + * set internal dividers + * + * Wait for 7 us timer. + * + * Enable plls + * + * Set external dividers while plls are locking + * + * Wait for pll lock + * + * Assert/deassert outreset all. + * + * Take all pll's out of bypass + * + * Clear safe mode + * + * set source main and peripheral clocks + * + * Ungate clocks + */ + +static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) +{ + unsigned int pll_ramp_main_hz = 0, pll_ramp_periph_hz = 0, + ramp_required; + + /* gate off all mainpll clock excpet HW managed clock */ + writel(CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK | + CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK, + &clock_manager_base->main_pll.enr); + + /* now we can gate off the rest of the peripheral clocks */ + writel(0, &clock_manager_base->per_pll.en); + + /* Put all plls in external bypass */ + writel(CLKMGR_MAINPLL_BYPASS_RESET, + &clock_manager_base->main_pll.bypasss); + writel(CLKMGR_PERPLL_BYPASS_RESET, + &clock_manager_base->per_pll.bypasss); + + /* + * Put all plls VCO registers back to reset value. + * Some code might have messed with them. At same time set the + * desired clock source + */ + writel(CLKMGR_MAINPLL_VCO0_RESET | + CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK | + (main_cfg->vco0_psrc << + CLKMGR_MAINPLL_VCO0_PSRC_LSB), + &clock_manager_base->main_pll.vco0); + + writel(CLKMGR_PERPLL_VCO0_RESET | + CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK | + (per_cfg->vco0_psrc << + CLKMGR_PERPLL_VCO0_PSRC_LSB), + &clock_manager_base->per_pll.vco0); + + writel(CLKMGR_MAINPLL_VCO1_RESET, + &clock_manager_base->main_pll.vco1); + writel(CLKMGR_PERPLL_VCO1_RESET, + &clock_manager_base->per_pll.vco1); + + /* clear the interrupt register status register */ + writel(CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLFBSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLACHIEVED_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLACHIEVED_SET_MSK, + &clock_manager_base->intr); + + /* Program VCO Numerator and Denominator for main PLL */ + ramp_required = cm_is_pll_ramp_required(0, main_cfg, per_cfg); + if (ramp_required) { + /* set main PLL to safe starting threshold frequency */ + if (ramp_required == 1) + pll_ramp_main_hz = CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ; + else if (ramp_required == 2) + pll_ramp_main_hz = CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ; + + writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(0, main_cfg, per_cfg, + pll_ramp_main_hz), + &clock_manager_base->main_pll.vco1); + } else + writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + main_cfg->vco1_numer, + &clock_manager_base->main_pll.vco1); + + /* Program VCO Numerator and Denominator for periph PLL */ + ramp_required = cm_is_pll_ramp_required(1, main_cfg, per_cfg); + if (ramp_required) { + /* set periph PLL to safe starting threshold frequency */ + if (ramp_required == 1) + pll_ramp_periph_hz = + CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ; + else if (ramp_required == 2) + pll_ramp_periph_hz = + CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ; + + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(1, main_cfg, per_cfg, + pll_ramp_periph_hz), + &clock_manager_base->per_pll.vco1); + } else + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + per_cfg->vco1_numer, + &clock_manager_base->per_pll.vco1); + + /* Wait for at least 5 us */ + udelay(5); + + /* Now deassert BGPWRDN and PWRDN */ + clrbits_le32(&clock_manager_base->main_pll.vco0, + CLKMGR_MAINPLL_VCO0_BGPWRDN_SET_MSK | + CLKMGR_MAINPLL_VCO0_PWRDN_SET_MSK); + clrbits_le32(&clock_manager_base->per_pll.vco0, + CLKMGR_PERPLL_VCO0_BGPWRDN_SET_MSK | + CLKMGR_PERPLL_VCO0_PWRDN_SET_MSK); + + /* Wait for at least 7 us */ + udelay(7); + + /* enable the VCO and disable the external regulator to PLL */ + writel((readl(&clock_manager_base->main_pll.vco0) & + ~CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK) | + CLKMGR_MAINPLL_VCO0_EN_SET_MSK, + &clock_manager_base->main_pll.vco0); + writel((readl(&clock_manager_base->per_pll.vco0) & + ~CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK) | + CLKMGR_PERPLL_VCO0_EN_SET_MSK, + &clock_manager_base->per_pll.vco0); + + /* setup all the main PLL counter and clock source */ + writel(main_cfg->nocclk, + SOCFPGA_CLKMGR_ADDRESS + CLKMGR_MAINPLL_NOC_CLK_OFFSET); + writel(main_cfg->mpuclk, + SOCFPGA_CLKMGR_ADDRESS + CLKMGR_ALTERAGRP_MPU_CLK_OFFSET); + + /* main_emaca_clk divider */ + writel(main_cfg->cntr2clk_cnt, + &clock_manager_base->main_pll.cntr2clk); + /* main_emacb_clk divider */ + writel(main_cfg->cntr3clk_cnt, + &clock_manager_base->main_pll.cntr3clk); + /* main_emac_ptp_clk divider */ + writel(main_cfg->cntr4clk_cnt, + &clock_manager_base->main_pll.cntr4clk); + /* main_gpio_db_clk divider */ + writel(main_cfg->cntr5clk_cnt, + &clock_manager_base->main_pll.cntr5clk); + /* main_sdmmc_clk divider */ + writel(main_cfg->cntr6clk_cnt, + &clock_manager_base->main_pll.cntr6clk); + /* main_s2f_user0_clk divider */ + writel(main_cfg->cntr7clk_cnt | + (main_cfg->cntr7clk_src << + CLKMGR_MAINPLL_CNTR7CLK_SRC_LSB), + &clock_manager_base->main_pll.cntr7clk); + /* main_s2f_user1_clk divider */ + writel(main_cfg->cntr8clk_cnt, + &clock_manager_base->main_pll.cntr8clk); + /* main_hmc_pll_clk divider */ + writel(main_cfg->cntr9clk_cnt | + (main_cfg->cntr9clk_src << + CLKMGR_MAINPLL_CNTR9CLK_SRC_LSB), + &clock_manager_base->main_pll.cntr9clk); + /* main_periph_ref_clk divider */ + writel(main_cfg->cntr15clk_cnt, + &clock_manager_base->main_pll.cntr15clk); + + /* setup all the peripheral PLL counter and clock source */ + /* peri_emaca_clk divider */ + writel(per_cfg->cntr2clk_cnt | + (per_cfg->cntr2clk_src << CLKMGR_PERPLL_CNTR2CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr2clk); + /* peri_emacb_clk divider */ + writel(per_cfg->cntr3clk_cnt | + (per_cfg->cntr3clk_src << CLKMGR_PERPLL_CNTR3CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr3clk); + /* peri_emac_ptp_clk divider */ + writel(per_cfg->cntr4clk_cnt | + (per_cfg->cntr4clk_src << CLKMGR_PERPLL_CNTR4CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr4clk); + /* peri_gpio_db_clk divider */ + writel(per_cfg->cntr5clk_cnt | + (per_cfg->cntr5clk_src << CLKMGR_PERPLL_CNTR5CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr5clk); + /* peri_sdmmc_clk divider */ + writel(per_cfg->cntr6clk_cnt | + (per_cfg->cntr6clk_src << CLKMGR_PERPLL_CNTR6CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr6clk); + /* peri_s2f_user0_clk divider */ + writel(per_cfg->cntr7clk_cnt, + &clock_manager_base->per_pll.cntr7clk); + /* peri_s2f_user1_clk divider */ + writel(per_cfg->cntr8clk_cnt | + (per_cfg->cntr8clk_src << CLKMGR_PERPLL_CNTR8CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr8clk); + /* peri_hmc_pll_clk divider */ + writel(per_cfg->cntr9clk_cnt, + &clock_manager_base->per_pll.cntr9clk); + + /* setup all the external PLL counter */ + /* mpu wrapper / external divider */ + writel(main_cfg->mpuclk_cnt | + (main_cfg->mpuclk_src << + CLKMGR_MAINPLL_MPUCLK_SRC_LSB), + &clock_manager_base->main_pll.mpuclk); + /* NOC wrapper / external divider */ + writel(main_cfg->nocclk_cnt | + (main_cfg->nocclk_src << CLKMGR_MAINPLL_NOCCLK_SRC_LSB), + &clock_manager_base->main_pll.nocclk); + /* NOC subclock divider such as l4 */ + writel(main_cfg->nocdiv_l4mainclk | + (main_cfg->nocdiv_l4mpclk << + CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB) | + (main_cfg->nocdiv_l4spclk << + CLKMGR_MAINPLL_NOCDIV_L4SPCLK_LSB) | + (main_cfg->nocdiv_csatclk << + CLKMGR_MAINPLL_NOCDIV_CSATCLK_LSB) | + (main_cfg->nocdiv_cstraceclk << + CLKMGR_MAINPLL_NOCDIV_CSTRACECLK_LSB) | + (main_cfg->nocdiv_cspdbclk << + CLKMGR_MAINPLL_NOCDIV_CSPDBGCLK_LSB), + &clock_manager_base->main_pll.nocdiv); + /* gpio_db external divider */ + writel(per_cfg->gpiodiv_gpiodbclk, + &clock_manager_base->per_pll.gpiodiv); + + /* setup the EMAC clock mux select */ + writel((per_cfg->emacctl_emac0sel << + CLKMGR_PERPLL_EMACCTL_EMAC0SEL_LSB) | + (per_cfg->emacctl_emac1sel << + CLKMGR_PERPLL_EMACCTL_EMAC1SEL_LSB) | + (per_cfg->emacctl_emac2sel << + CLKMGR_PERPLL_EMACCTL_EMAC2SEL_LSB), + &clock_manager_base->per_pll.emacctl); + + /* at this stage, check for PLL lock status */ + cm_wait_for_lock(LOCKED_MASK); + + /* + * after locking, but before taking out of bypass, + * assert/deassert outresetall + */ + /* assert mainpll outresetall */ + setbits_le32(&clock_manager_base->main_pll.vco0, + CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK); + /* assert perpll outresetall */ + setbits_le32(&clock_manager_base->per_pll.vco0, + CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK); + /* de-assert mainpll outresetall */ + clrbits_le32(&clock_manager_base->main_pll.vco0, + CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK); + /* de-assert perpll outresetall */ + clrbits_le32(&clock_manager_base->per_pll.vco0, + CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK); + + /* Take all PLLs out of bypass when boot mode is cleared. */ + /* release mainpll from bypass */ + writel(CLKMGR_MAINPLL_BYPASS_RESET, + &clock_manager_base->main_pll.bypassr); + /* wait till Clock Manager is not busy */ + cm_wait_for_fsm(); + + /* release perpll from bypass */ + writel(CLKMGR_PERPLL_BYPASS_RESET, + &clock_manager_base->per_pll.bypassr); + /* wait till Clock Manager is not busy */ + cm_wait_for_fsm(); + + /* clear boot mode */ + clrbits_le32(&clock_manager_base->ctrl, + CLKMGR_CLKMGR_CTL_BOOTMOD_SET_MSK); + /* wait till Clock Manager is not busy */ + cm_wait_for_fsm(); + + /* At here, we need to ramp to final value if needed */ + if (pll_ramp_main_hz != 0) + cm_pll_ramp_main(main_cfg, per_cfg, pll_ramp_main_hz); + if (pll_ramp_periph_hz != 0) + cm_pll_ramp_periph(main_cfg, per_cfg, pll_ramp_periph_hz); + + /* Now ungate non-hw-managed clocks */ + writel(CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK | + CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK, + &clock_manager_base->main_pll.ens); + writel(CLKMGR_PERPLL_EN_RESET, + &clock_manager_base->per_pll.ens); + + /* Clear the loss lock and slip bits as they might set during + clock reconfiguration */ + writel(CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLFBSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK, + &clock_manager_base->intr); + + return 0; +} + +void cm_use_intosc(void) +{ + setbits_le32(&clock_manager_base->ctrl, + CLKMGR_CLKMGR_CTL_BOOTCLK_INTOSC_SET_MSK); +} + +unsigned int cm_get_noc_clk_hz(void) +{ + unsigned int clk_src, dividor, nocclk, src_hz; + + nocclk = readl(&clock_manager_base->main_pll.nocclk); + clk_src = (nocclk >> CLKMGR_MAINPLL_NOCCLK_SRC_LSB) & + CLKMGR_MAINPLL_NOCCLK_SRC_MSK; + + dividor = 1 + (nocclk & CLKMGR_MAINPLL_NOCDIV_MSK); + + if (clk_src == CLKMGR_PERPLLGRP_SRC_MAIN) { + src_hz = cm_get_main_vco_clk_hz(); + src_hz /= 1 + + (readl(SOCFPGA_CLKMGR_ADDRESS+CLKMGR_MAINPLL_NOC_CLK_OFFSET)& + CLKMGR_MAINPLL_NOCCLK_CNT_MSK); + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_PERI) { + src_hz = cm_get_per_vco_clk_hz(); + src_hz /= 1 + + ((readl(SOCFPGA_CLKMGR_ADDRESS+CLKMGR_MAINPLL_NOC_CLK_OFFSET)>> + CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB)& + CLKMGR_MAINPLL_NOCCLK_CNT_MSK); + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_OSC1) { + src_hz = eosc1_hz; + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_INTOSC) { + src_hz = cb_intosc_hz; + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_FPGA) { + src_hz = f2s_free_hz; + } else { + src_hz = 0; + } + return src_hz/dividor; +} + +unsigned int cm_get_l4_noc_hz(unsigned int nocdivshift) +{ + unsigned int dividor2 = 1 << + ((readl(&clock_manager_base->main_pll.nocdiv) >> + nocdivshift) & CLKMGR_MAINPLL_NOCDIV_MSK); + + return cm_get_noc_clk_hz()/dividor2; +} + +int cm_basic_init(const void *blob) +{ + struct mainpll_cfg main_cfg; + struct perpll_cfg per_cfg; + struct alteragrp_cfg altrgrp_cfg; + int rval; + + /* initialize to zero for use case of optional node */ + memset(&main_cfg, 0, sizeof(main_cfg)); + memset(&per_cfg, 0, sizeof(per_cfg)); + memset(&altrgrp_cfg, 0, sizeof(altrgrp_cfg)); + + if (of_get_clk_cfg(blob, &main_cfg, &per_cfg, &altrgrp_cfg)) + return 1; + + rval = cm_full_cfg(&main_cfg, &per_cfg); + + cm_l4_main_clk_hz = + cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB); + + cm_l4_mp_clk_hz = cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB); + + cm_l4_sp_clk_hz = cm_get_l4_sp_clk_hz(); + + cm_l4_sys_free_clk_hz = cm_get_noc_clk_hz()/4; + + return rval; +} + +unsigned long cm_get_mpu_clk_hz(void) +{ + u32 reg, clk_hz; + u32 clk_src, mainmpuclk_reg; + + mainmpuclk_reg = readl(&clock_manager_base->main_pll.mpuclk); + + clk_src = (mainmpuclk_reg >> CLKMGR_MAINPLL_MPUCLK_SRC_LSB) & + CLKMGR_MAINPLL_MPUCLK_SRC_MSK; + + reg = readl(&clock_manager_base->altera.mpuclk); + /* Check MPU clock source: main, periph, osc1, intosc or f2s? */ + switch (clk_src) { + case CLKMGR_MAINPLL_MPUCLK_SRC_MAIN: + clk_hz = cm_get_main_vco_clk_hz(); + clk_hz /= ((reg & CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + + 1); + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_PERI: + clk_hz = cm_get_per_vco_clk_hz(); + clk_hz /= (((reg >> CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1); + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_OSC1: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + default: + printf("cm_get_mpu_clk_hz invalid clk_src %d\n", clk_src); + return 0; + } + + clk_hz /= ((mainmpuclk_reg & CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1); + + return clk_hz; +} + +unsigned int cm_get_per_vco_clk_hz(void) +{ + u32 src_hz = 0; + u32 clk_src = 0; + u32 numer = 0; + u32 denom = 0; + u32 vco = 0; + + clk_src = readl(&clock_manager_base->per_pll.vco0); + + clk_src = (clk_src >> CLKMGR_PERPLL_VCO0_PSRC_LSB) & + CLKMGR_PERPLL_VCO0_PSRC_MSK; + + if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_EOSC) { + src_hz = eosc1_hz; + } else if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC) { + src_hz = cb_intosc_hz; + } else if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_F2S) { + src_hz = f2s_free_hz; + } else if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_MAIN) { + src_hz = cm_get_main_vco_clk_hz(); + src_hz /= (readl + (&clock_manager_base->main_pll.cntr15clk) & + CLKMGR_MAINPLL_CNTRCLK_MSK) + 1; + } else { + printf("cm_get_per_vco_clk_hz invalid clk_src %d\n", clk_src); + return 0; + } + + vco = readl(&clock_manager_base->per_pll.vco1); + + numer = vco & CLKMGR_PERPLL_VCO1_NUMER_MSK; + + denom = (vco >> CLKMGR_PERPLL_VCO1_DENOM_LSB) & + CLKMGR_PERPLL_VCO1_DENOM_MSK; + + vco = src_hz; + vco /= (1 + denom); + vco *= (1 + numer); + + return vco; +} + +unsigned int cm_get_main_vco_clk_hz(void) +{ + u32 src_hz, numer, denom, vco; + + u32 clk_src = readl(&clock_manager_base->main_pll.vco0); + + clk_src = (clk_src >> CLKMGR_MAINPLL_VCO0_PSRC_LSB) & + CLKMGR_MAINPLL_VCO0_PSRC_MSK; + + if (clk_src == CLKMGR_MAINPLL_VCO0_PSRC_EOSC) { + src_hz = eosc1_hz; + } else if (clk_src == CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC) { + src_hz = cb_intosc_hz; + } else if (clk_src == CLKMGR_MAINPLL_VCO0_PSRC_F2S) { + src_hz = f2s_free_hz; + } else { + printf("cm_get_main_vco_clk_hz invalid clk_src %d\n", clk_src); + return 0; + } + + vco = readl(&clock_manager_base->main_pll.vco1); + + numer = vco & CLKMGR_MAINPLL_VCO1_NUMER_MSK; + + denom = (vco >> CLKMGR_MAINPLL_VCO1_DENOM_LSB) & + CLKMGR_MAINPLL_VCO1_DENOM_MSK; + + vco = src_hz; + vco /= (1 + denom); + vco *= (1 + numer); + + return vco; +} + +unsigned int cm_get_l4_sp_clk_hz(void) +{ + return cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4SPCLK_LSB); +} + +unsigned int cm_get_mmc_controller_clk_hz(void) +{ + u32 clk_hz = 0; + u32 clk_input = 0; + + clk_input = readl(&clock_manager_base->per_pll.cntr6clk); + clk_input = (clk_input >> CLKMGR_PERPLL_CNTR6CLK_SRC_LSB) & + CLKMGR_PERPLLGRP_SRC_MSK; + + switch (clk_input) { + case CLKMGR_PERPLLGRP_SRC_MAIN: + clk_hz = cm_get_main_vco_clk_hz(); + clk_hz /= 1 + + (readl + (&clock_manager_base->main_pll.cntr6clk) & + CLKMGR_MAINPLL_CNTRCLK_MSK); + break; + + case CLKMGR_PERPLLGRP_SRC_PERI: + clk_hz = cm_get_per_vco_clk_hz(); + clk_hz /= 1 + (readl + (&clock_manager_base->per_pll.cntr6clk) & + CLKMGR_PERPLL_CNTRCLK_MSK); + break; + + case CLKMGR_PERPLLGRP_SRC_OSC1: + clk_hz = eosc1_hz; + break; + + case CLKMGR_PERPLLGRP_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + + case CLKMGR_PERPLLGRP_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + } + + return clk_hz/4; +} + +unsigned int cm_get_spi_controller_clk_hz(void) +{ + return cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB); +} + +unsigned int cm_get_qspi_controller_clk_hz(void) +{ + return cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB); +} diff --git a/arch/arm/mach-socfpga/clock_manager_gen5.c b/arch/arm/mach-socfpga/clock_manager_gen5.c old mode 100755 new mode 100644 index 1df2ed4..5632843 --- a/arch/arm/mach-socfpga/clock_manager_gen5.c +++ b/arch/arm/mach-socfpga/clock_manager_gen5.c @@ -1,7 +1,7 @@ /* - * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> + * Copyright (C) 2016-2017 Intel Corporation * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0 */
#include <common.h> @@ -65,7 +65,6 @@ static void cm_write_with_phase(u32 value, * set source main and peripheral clocks * Ungate clocks */ - void cm_basic_init(const struct cm_config * const cfg) { unsigned long end; @@ -304,58 +303,75 @@ void cm_basic_init(const struct cm_config * const cfg) &clock_manager_base->inter); }
-static unsigned int cm_get_main_vco_clk_hz(void) +unsigned int cm_get_main_vco_clk_hz(void) { - u32 reg, clock; + u32 src_hz, numer, denom, vco;
/* get the main VCO clock */ - reg = readl(&clock_manager_base->main_pll.vco); - clock = cm_get_osc_clk_hz(1); - clock /= ((reg & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_MAINPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET) + 1; + vco = readl(&clock_manager_base->main_pll.vco);
- return clock; + numer = ((vco & CLKMGR_MAINPLLGRP_VCO_NUMER_MASK) >> + CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET); + denom = ((vco & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >> + CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET); + + src_hz = cm_get_osc_clk_hz(1); + + vco = src_hz; + vco /= (1 + denom); + vco *= (1 + numer); + + return vco; }
-static unsigned int cm_get_per_vco_clk_hz(void) +unsigned int cm_get_per_vco_clk_hz(void) { - u32 reg, clock = 0; + u32 src_hz = 0; + u32 clk_src = 0; + u32 numer = 0; + u32 denom = 0; + u32 vco = 0;
/* identify PER PLL clock source */ - reg = readl(&clock_manager_base->per_pll.vco); - reg = (reg & CLKMGR_PERPLLGRP_VCO_SSRC_MASK) >> + clk_src = readl(&clock_manager_base->per_pll.vco); + clk_src = (clk_src & CLKMGR_PERPLLGRP_VCO_SSRC_MASK) >> CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET; - if (reg == CLKMGR_VCO_SSRC_EOSC1) - clock = cm_get_osc_clk_hz(1); - else if (reg == CLKMGR_VCO_SSRC_EOSC2) - clock = cm_get_osc_clk_hz(2); - else if (reg == CLKMGR_VCO_SSRC_F2S) - clock = cm_get_f2s_per_ref_clk_hz(); + if (clk_src == CLKMGR_VCO_SSRC_EOSC1) + src_hz = cm_get_osc_clk_hz(1); + else if (clk_src == CLKMGR_VCO_SSRC_EOSC2) + src_hz = cm_get_osc_clk_hz(2); + else if (clk_src == CLKMGR_VCO_SSRC_F2S) + src_hz = cm_get_f2s_per_ref_clk_hz();
/* get the PER VCO clock */ - reg = readl(&clock_manager_base->per_pll.vco); - clock /= ((reg & CLKMGR_PERPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_PERPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET) + 1; + vco = readl(&clock_manager_base->per_pll.vco);
- return clock; + numer = (vco & CLKMGR_PERPLLGRP_VCO_NUMER_MASK) >> + CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET; + + denom = (vco & CLKMGR_PERPLLGRP_VCO_DENOM_MASK) >> + CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET; + + vco = src_hz; + vco /= (1 + denom); + vco *= (1 + numer); + + return vco; }
unsigned long cm_get_mpu_clk_hz(void) { - u32 reg, clock; + u32 reg, clk_hz;
- clock = cm_get_main_vco_clk_hz(); + clk_hz = cm_get_main_vco_clk_hz();
/* get the MPU clock */ reg = readl(&clock_manager_base->altera.mpuclk); - clock /= (reg + 1); + clk_hz /= (reg + 1); reg = readl(&clock_manager_base->main_pll.mpuclk); - clock /= (reg + 1); - return clock; + clk_hz /= (reg + 1); + + return clk_hz; }
unsigned long cm_get_sdram_clk_hz(void) @@ -391,7 +407,8 @@ unsigned long cm_get_sdram_clk_hz(void)
unsigned int cm_get_l4_sp_clk_hz(void) { - u32 reg, clock = 0; + u32 clock = 0; + u32 reg;
/* identify the source of L4 SP clock */ reg = readl(&clock_manager_base->main_pll.l4src); @@ -425,37 +442,45 @@ unsigned int cm_get_l4_sp_clk_hz(void)
unsigned int cm_get_mmc_controller_clk_hz(void) { - u32 reg, clock = 0; + u32 clk_hz = 0; + u32 clk_input = 0;
- /* identify the source of MMC clock */ - reg = readl(&clock_manager_base->per_pll.src); - reg = (reg & CLKMGR_PERPLLGRP_SRC_SDMMC_MASK) >> + clk_input = readl(&clock_manager_base->per_pll.src); + clk_input = (clk_input & CLKMGR_PERPLLGRP_SRC_SDMMC_MASK) >> CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET;
- if (reg == CLKMGR_SDMMC_CLK_SRC_F2S) { - clock = cm_get_f2s_per_ref_clk_hz(); - } else if (reg == CLKMGR_SDMMC_CLK_SRC_MAIN) { - clock = cm_get_main_vco_clk_hz(); + switch (clk_input) { + case CLKMGR_SDMMC_CLK_SRC_F2S: + clk_hz = cm_get_f2s_per_ref_clk_hz(); + break; + + case CLKMGR_SDMMC_CLK_SRC_MAIN: + clk_hz = cm_get_main_vco_clk_hz();
/* get the SDMMC clock */ - reg = readl(&clock_manager_base->main_pll.mainnandsdmmcclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_SDMMC_CLK_SRC_PER) { - clock = cm_get_per_vco_clk_hz(); + clk_input = + readl(&clock_manager_base->main_pll.mainnandsdmmcclk); + clk_hz /= (clk_input + 1); + break; + + case CLKMGR_SDMMC_CLK_SRC_PER: + clk_hz = cm_get_per_vco_clk_hz();
/* get the SDMMC clock */ - reg = readl(&clock_manager_base->per_pll.pernandsdmmcclk); - clock /= (reg + 1); + clk_input = + readl(&clock_manager_base->per_pll.pernandsdmmcclk); + clk_hz /= (clk_input + 1); + break; }
- /* further divide by 4 as we have fixed divider at wrapper */ - clock /= 4; - return clock; + return clk_hz / 4; }
+ unsigned int cm_get_qspi_controller_clk_hz(void) { - u32 reg, clock = 0; + u32 clock = 0; + u32 reg;
/* identify the source of QSPI clock */ reg = readl(&clock_manager_base->per_pll.src); @@ -483,7 +508,8 @@ unsigned int cm_get_qspi_controller_clk_hz(void)
unsigned int cm_get_spi_controller_clk_hz(void) { - u32 reg, clock = 0; + u32 clock = 0; + u32 reg;
diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index 123f6e2..0b099ba 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -12,7 +12,13 @@ void cm_wait_for_lock(u32 mask); void cm_wait_for_fsm(void); #endif
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +/* Common mask */ +#define CLKMGR_CLKMGR_STAT_BUSY_SET_MSK 0x00000001 + +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/clock_manager_arria10.h> +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) #include <asm/arch/clock_manager_gen5.h> #endif + #endif /* _CLOCK_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h new file mode 100644 index 0000000..fc0bfe7 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h @@ -0,0 +1,231 @@ +/* + * Copyright (C) 2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef CLOCK_MANAGER_ARRIA10 +#define CLOCK_MANAGER_ARRIA10 + +#ifndef __ASSEMBLER__ + +struct socfpga_clock_manager_main_pll { + u32 vco0; + u32 vco1; + u32 en; + u32 ens; + u32 enr; + u32 bypass; + u32 bypasss; + u32 bypassr; + u32 mpuclk; + u32 nocclk; + u32 cntr2clk; + u32 cntr3clk; + u32 cntr4clk; + u32 cntr5clk; + u32 cntr6clk; + u32 cntr7clk; + u32 cntr8clk; + u32 cntr9clk; + u32 pad_0x48_0x5b[5]; + u32 cntr15clk; + u32 outrst; + u32 outrststat; + u32 nocdiv; + u32 pad_0x6c_0x80[5]; +}; + +struct socfpga_clock_manager_per_pll { + u32 vco0; + u32 vco1; + u32 en; + u32 ens; + u32 enr; + u32 bypass; + u32 bypasss; + u32 bypassr; + u32 pad_0x20_0x27[2]; + u32 cntr2clk; + u32 cntr3clk; + u32 cntr4clk; + u32 cntr5clk; + u32 cntr6clk; + u32 cntr7clk; + u32 cntr8clk; + u32 cntr9clk; + u32 pad_0x48_0x5f[6]; + u32 outrst; + u32 outrststat; + u32 emacctl; + u32 gpiodiv; + u32 pad_0x70_0x80[4]; +}; + +struct socfpga_clock_manager_altera { + u32 mpuclk; + u32 nocclk; + u32 mainmisc0; + u32 mainmisc1; + u32 perimisc0; + u32 perimisc1; +}; + +struct socfpga_clock_manager { + /* clkmgr */ + u32 ctrl; + u32 intr; + u32 intrs; + u32 intrr; + u32 intren; + u32 intrens; + u32 intrenr; + u32 stat; + u32 testioctrl; + u32 _pad_0x24_0x40[7]; + /* mainpllgrp */ + struct socfpga_clock_manager_main_pll main_pll; + /* perpllgrp */ + struct socfpga_clock_manager_per_pll per_pll; + struct socfpga_clock_manager_altera altera; +}; + +void cm_use_intosc(void); +unsigned int cm_get_noc_clk_hz(void); +unsigned int cm_get_l4_noc_hz(unsigned int nocdivshift); +int cm_basic_init(const void *blob); + +unsigned int cm_get_l4_sp_clk_hz(void); +unsigned int cm_get_main_vco_clk_hz(void); +unsigned int cm_get_per_vco_clk_hz(void); +unsigned long cm_get_mpu_clk_hz(void); + +unsigned int cm_get_qspi_controller_clk_hz(void); +unsigned int cm_get_mmc_controller_clk_hz(void); +unsigned int cm_get_spi_controller_clk_hz(void); + +extern u32 cm_l4_main_clk_hz; +extern u32 cm_l4_sp_clk_hz; +extern u32 cm_l4_mp_clk_hz; +extern u32 cm_l4_sys_free_clk_hz; +extern u32 eosc1_hz; +extern u32 cb_intosc_hz; +extern u32 f2s_free_hz; + +#endif /* __ASSEMBLER__ */ + +#define CLKMGR_ALTERAGRP_MPU_CLK_OFFSET 0x140 +#define CLKMGR_MAINPLL_NOC_CLK_OFFSET 0x144 +#define LOCKED_MASK \ + (CLKMGR_CLKMGR_STAT_MAINPLLLOCKED_SET_MSK | \ + CLKMGR_CLKMGR_STAT_PERPLLLOCKED_SET_MSK) + +/* value */ +#define CLKMGR_MAINPLL_BYPASS_RESET 0x0000003f +#define CLKMGR_PERPLL_BYPASS_RESET 0x000000ff +#define CLKMGR_MAINPLL_VCO0_RESET 0x00010053 +#define CLKMGR_MAINPLL_VCO1_RESET 0x00010001 +#define CLKMGR_PERPLL_VCO0_RESET 0x00010053 +#define CLKMGR_PERPLL_VCO1_RESET 0x00010001 +#define CLKMGR_MAINPLL_VCO0_PSRC_EOSC 0x0 +#define CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC 0x1 +#define CLKMGR_MAINPLL_VCO0_PSRC_F2S 0x2 +#define CLKMGR_PERPLL_VCO0_PSRC_EOSC 0x0 +#define CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC 0x1 +#define CLKMGR_PERPLL_VCO0_PSRC_F2S 0x2 +#define CLKMGR_PERPLL_VCO0_PSRC_MAIN 0x3 + +/* mask */ +#define CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK 0x00000040 +#define CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK 0x00000080 +#define CLKMGR_CLKMGR_STAT_MAINPLLLOCKED_SET_MSK 0x00000100 +#define CLKMGR_CLKMGR_STAT_PERPLLLOCKED_SET_MSK 0x00000200 +#define CLKMGR_CLKMGR_STAT_BOOTCLKSRC_SET_MSK 0x00020000 +#define CLKMGR_MAINPLL_VCO0_BGPWRDN_SET_MSK 0x00000001 +#define CLKMGR_MAINPLL_VCO0_PWRDN_SET_MSK 0x00000002 +#define CLKMGR_MAINPLL_VCO0_EN_SET_MSK 0x00000004 +#define CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK 0x00000008 +#define CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK 0x00000010 +#define CLKMGR_PERPLL_VCO0_BGPWRDN_SET_MSK 0x00000001 +#define CLKMGR_PERPLL_VCO0_PWRDN_SET_MSK 0x00000002 +#define CLKMGR_PERPLL_VCO0_EN_SET_MSK 0x00000004 +#define CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK 0x00000008 +#define CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK 0x00000010 +#define CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK 0x00000800 +#define CLKMGR_CLKMGR_INTR_MAINPLLFBSLIP_SET_MSK 0x00000400 +#define CLKMGR_CLKMGR_INTR_PERPLLRFSLIP_SET_MSK 0x00000200 +#define CLKMGR_CLKMGR_INTR_MAINPLLRFSLIP_SET_MSK 0x00000100 +#define CLKMGR_CLKMGR_INTR_PERPLLLOST_SET_MSK 0x00000008 +#define CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK 0x00000004 +#define CLKMGR_CLKMGR_INTR_MAINPLLACHIEVED_SET_MSK 0x00000001 +#define CLKMGR_CLKMGR_INTR_PERPLLACHIEVED_SET_MSK 0x00000002 +#define CLKMGR_CLKMGR_CTL_BOOTMOD_SET_MSK 0x00000001 +#define CLKMGR_CLKMGR_CTL_BOOTCLK_INTOSC_SET_MSK 0x00000300 +#define CLKMGR_PERPLL_EN_RESET 0x00000f7f +#define CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK 0x00000020 +#define CLKMGR_MAINPLL_VCO0_PSRC_MSK 0x00000003 +#define CLKMGR_MAINPLL_VCO1_NUMER_MSK 0x00001fff +#define CLKMGR_MAINPLL_VCO1_DENOM_MSK 0x0000003f +#define CLKMGR_MAINPLL_CNTRCLK_MSK 0x000003ff +#define CLKMGR_PERPLL_VCO0_PSRC_MSK 0x00000003 +#define CLKMGR_PERPLL_VCO1_NUMER_MSK 0x00001fff +#define CLKMGR_PERPLL_VCO1_DENOM_MSK 0x0000003f +#define CLKMGR_PERPLL_CNTRCLK_MSK 0x000003ff +#define CLKMGR_MAINPLL_MPUCLK_SRC_MSK 0x00000007 +#define CLKMGR_MAINPLL_MPUCLK_CNT_MSK 0x000003ff +#define CLKMGR_MAINPLL_MPUCLK_SRC_MAIN 0 +#define CLKMGR_MAINPLL_MPUCLK_SRC_PERI 1 +#define CLKMGR_MAINPLL_MPUCLK_SRC_OSC1 2 +#define CLKMGR_MAINPLL_MPUCLK_SRC_INTOSC 3 +#define CLKMGR_MAINPLL_MPUCLK_SRC_FPGA 4 +#define CLKMGR_MAINPLL_NOCDIV_MSK 0x00000003 +#define CLKMGR_MAINPLL_NOCCLK_CNT_MSK 0x000003ff +#define CLKMGR_MAINPLL_NOCCLK_SRC_MSK 0x00000007 +#define CLKMGR_MAINPLL_NOCCLK_SRC_MAIN 0 +#define CLKMGR_MAINPLL_NOCCLK_SRC_PERI 1 +#define CLKMGR_MAINPLL_NOCCLK_SRC_OSC1 2 +#define CLKMGR_MAINPLL_NOCCLK_SRC_INTOSC 3 +#define CLKMGR_MAINPLL_NOCCLK_SRC_FPGA 4 + +#define CLKMGR_PERPLLGRP_SRC_MSK 0x00000007 +#define CLKMGR_PERPLLGRP_SRC_MAIN 0 +#define CLKMGR_PERPLLGRP_SRC_PERI 1 +#define CLKMGR_PERPLLGRP_SRC_OSC1 2 +#define CLKMGR_PERPLLGRP_SRC_INTOSC 3 +#define CLKMGR_PERPLLGRP_SRC_FPGA 4 + +/* bit shifting macro */ +#define CLKMGR_MAINPLL_VCO0_PSRC_LSB 8 +#define CLKMGR_PERPLL_VCO0_PSRC_LSB 8 +#define CLKMGR_MAINPLL_VCO1_DENOM_LSB 16 +#define CLKMGR_PERPLL_VCO1_DENOM_LSB 16 +#define CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB 16 +#define CLKMGR_MAINPLL_NOCCLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB 0 +#define CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB 8 +#define CLKMGR_MAINPLL_NOCDIV_L4SPCLK_LSB 16 +#define CLKMGR_MAINPLL_NOCDIV_CSATCLK_LSB 24 +#define CLKMGR_MAINPLL_NOCDIV_CSTRACECLK_LSB 26 +#define CLKMGR_MAINPLL_NOCDIV_CSPDBGCLK_LSB 28 +#define CLKMGR_MAINPLL_MPUCLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB 16 +#define CLKMGR_MAINPLL_NOCCLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_CNTR7CLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_CNTR9CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR2CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR3CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR4CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR5CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR6CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR8CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_EMACCTL_EMAC0SEL_LSB 26 +#define CLKMGR_PERPLL_EMACCTL_EMAC1SEL_LSB 27 +#define CLKMGR_PERPLL_EMACCTL_EMAC2SEL_LSB 28 + +/* PLL ramping work around */ +#define CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ 900000000 +#define CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ 300000000 +#define CLKMGR_PLL_RAMP_MPUCLK_INCREMENT_HZ 100000000 +#define CLKMGR_PLL_RAMP_NOCCLK_INCREMENT_HZ 33000000 + +#endif /* CLOCK_MANAGER_ARRIA10 */
A10 should be below Gen5 to keep this sorted chronologically IMO.
if (inter_val == mask) retry++; else/* Wait for stable lock */
;CLKMGR_CLKMGR_STAT_BUSY_SET_MSK)
- printf("EOSC1 %8d kHz\n", eosc1_hz / 1000);
- printf("cb_intosc %8d kHz\n", cb_intosc_hz / 1000);
- printf("f2s_free %8d kHz\n", f2s_free_hz / 1000);
- printf("Main VCO %8d kHz\n", cm_get_main_vco_clk_hz()/1000);
- printf("NOC %8d kHz\n", cm_get_noc_clk_hz()/1000);
- printf("L4 Main %8d kHz\n",
- printf("L4 MP %8d kHz\n",
- printf("L4 SP %8d kHz\n",
- printf("L4 sys free %8d kHz\n", cm_l4_sys_free_clk_hz/1000);
+#endif }
- gd->bd->bi_ddr_freq = 0;
Shouldn't these values be static ? (if needed at all) ?
+struct strtopu32 {
- const char *str;
- u32 *p;
What is this ^ and is this needed ? Probably not ...
- u32 vco0_psrc;
- u32 vco1_denom;
- u32 vco1_numer;
- u32 mpuclk;
- u32 mpuclk_cnt;
- u32 mpuclk_src;
- u32 nocclk;
- u32 nocclk_cnt;
- u32 nocclk_src;
- u32 cntr2clk_cnt;
- u32 cntr3clk_cnt;
- u32 cntr4clk_cnt;
- u32 cntr5clk_cnt;
- u32 cntr6clk_cnt;
- u32 cntr7clk_cnt;
- u32 cntr7clk_src;
- u32 cntr8clk_cnt;
- u32 cntr9clk_cnt;
- u32 cntr9clk_src;
- u32 cntr15clk_cnt;
- u32 nocdiv_l4mainclk;
- u32 nocdiv_l4mpclk;
- u32 nocdiv_l4spclk;
- u32 nocdiv_csatclk;
- u32 nocdiv_cstraceclk;
- u32 nocdiv_cspdbclk;
- u32 vco0_psrc;
- u32 vco1_denom;
- u32 vco1_numer;
- u32 cntr2clk_cnt;
- u32 cntr2clk_src;
- u32 cntr3clk_cnt;
- u32 cntr3clk_src;
- u32 cntr4clk_cnt;
- u32 cntr4clk_src;
- u32 cntr5clk_cnt;
- u32 cntr5clk_src;
- u32 cntr6clk_cnt;
- u32 cntr6clk_src;
- u32 cntr7clk_cnt;
- u32 cntr8clk_cnt;
- u32 cntr8clk_src;
- u32 cntr9clk_cnt;
- u32 emacctl_emac0sel;
- u32 emacctl_emac1sel;
- u32 emacctl_emac2sel;
- u32 gpiodiv_gpiodbclk;
- u32 nocclk;
- u32 mpuclk;
- (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS;
- if (fdtdec_get_int_array(blob, node, "altr,of_reg_value",
return 100;
100 ? Why ?
- if (fdtdec_get_int_array(blob, node, "clock-frequency",
(u32 *)cfg, 1)) {
return 100;
DTTO
- int node, child, len;
- const char *node_name;
- node = fdtdec_next_compatible(blob, 0, COMPAT_ALTERA_SOCFPGA_CLK);
- if (node < 0)
return 1;
- child = fdt_first_subnode(blob, node);
Drop this extra space.
- if (child < 0)
return 2;
Use errno.h retvals ?
- child = fdt_first_subnode(blob, child);
- if (child < 0)
return 3;
- node_name = fdt_get_name(blob, child, &len);
- while (node_name) {
return 101;
return 102;
return 103;
main_cfg))
return 104;
per_cfg))
return 105;
altrgrp_cfg))
return 106;
if (child < 0)
break;
- unsigned int clk_hz = 0, clk_incr_hz = 0, clk_final_hz = 0;
- /* find out the increment value */
- if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_MAIN) {
- } else if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_MAIN) {
- /* execute the ramping here */
- for (clk_hz = pll_ramp_main_hz + clk_incr_hz;
udelay(1000);
mdelay(1);
- writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) |
- udelay(1000);
- cm_wait_for_lock(LOCKED_MASK);
- Copyright (C) 2013-2017 Altera Corporation <www.altera.com>
Keep the license, GPL-2.0+ ...
- set source main and peripheral clocks
- Ungate clocks
- u32 reg, clock;
- vco = readl(&clock_manager_base->main_pll.vco);
How many of the changes here are relevant ?
The changes to this file are total chaos and this really does need some splitting, it's unreviewable.
- return clock;
- numer = ((vco & CLKMGR_MAINPLLGRP_VCO_NUMER_MASK) >>
- denom = ((vco & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >>
- src_hz = cm_get_osc_clk_hz(1);
- vco = src_hz;
- vco /= (1 + denom);
- vco *= (1 + numer);
- return vco;
arch/arm/mach-socfpga/Makefile | 3 +- arch/arm/mach-socfpga/clock_manager.c | 36 +- arch/arm/mach-socfpga/clock_manager_arria10.c | 1104 ++++++++++++++++++++ arch/arm/mach-socfpga/clock_manager_gen5.c | 132 ++- arch/arm/mach-socfpga/include/mach/clock_manager.h | 8 +- .../include/mach/clock_manager_arria10.h | 231 ++++ 6 files changed, 1455 insertions(+), 59 deletions(-) create mode 100644 arch/arm/mach-socfpga/clock_manager_arria10.c mode change 100755 => 100644 arch/arm/mach- socfpga/clock_manager_gen5.c create mode 100644 arch/arm/mach- socfpga/include/mach/clock_manager_arria10.h
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach- socfpga/Makefile index d81f003..c494930 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -10,7 +10,8 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \ fpga_manager.o board.o -obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o +obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clock_manager_arria10.o \
obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach- socfpga/clock_manager.c index d675973..7f48193 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -7,6 +7,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/clock_manager.h> +#include <fdtdec.h> DECLARE_GLOBAL_DATA_PTR; @@ -18,7 +19,12 @@ void cm_wait_for_lock(u32 mask) register u32 inter_val; u32 retry = 0; do { +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10)
Okay.
CLKMGR_STAT_BUSY)
- CLKMGR_CLKMGR_STAT_BUSY_SET_MSK)
; } static void cm_print_clock_quick_summary(void) { printf("MPU %10ld kHz\n", cm_get_mpu_clk_hz() / 1000);
- cm_get_qspi_controller_clk_hz() / 1000);
- cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LS
B)/1000);
- cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB)
/1000);
- cm_get_l4_sp_clk_hz()/1000);
cm_get_spi_controller_clk_hz() / 1000); +#endif } int set_cpu_clk_info(void) @@ -57,7 +80,12 @@ int set_cpu_clk_info(void) gd->bd->bi_arm_freq = cm_get_mpu_clk_hz() / 1000000; gd->bd->bi_dsp_freq = 0;
+#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) gd->bd->bi_ddr_freq = cm_get_sdram_clk_hz() / 1000000; +#endif return 0; } diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c new file mode 100644 index 0000000..4fa841f --- /dev/null +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -0,0 +1,1104 @@ +/*
- Copyright (C) 2016-2017 Intel Corporation
- SPDX-License-Identifier: GPL-2.0
They are used in clock_manager.c clock info printing. But, I can restructure that part and keep all these static.
+struct strtopu32 {
- const char *str;
- u32 *p;
Will remove.
- u32 nocclk;
- u32 mpuclk;
return 100;
100 ? Why ?
Will change to -EINVAL.
(u32 *)cfg, 1)) {
return 100;
DTTO
Same here.
- if (node < 0)
return 1;
Noted.
- if (child < 0)
return 2;
Will change to -EINVAL. Same for error below.
- if (child < 0)
return 3;
&eosc1_hz))
return 101;
&cb_intosc_hz))
return 102;
&f2s_free_hz))
return 103;
u32),
main_cfg))
return 104;
32),
per_cfg))
return 105;
of(u32),
altrgrp_cfg))
return 106;
if (child < 0)
break;
0;
clk_final_hz =
clk_final_hz =
- clk_hz < clk_final_hz; clk_hz += clk_incr_hz) {
per_cfg, clk_hz),
udelay(1000);
mdelay(1);
Okay.
- udelay(1000);
Okay.
*/ #include <common.h> @@ -65,7 +65,6 @@ static void cm_write_with_phase(u32 value, * set source main and peripheral clocks * Ungate clocks */
void cm_basic_init(const struct cm_config * const cfg) { unsigned long end; @@ -304,58 +303,75 @@ void cm_basic_init(const struct cm_config * const cfg) &clock_manager_base->inter); } -static unsigned int cm_get_main_vco_clk_hz(void) +unsigned int cm_get_main_vco_clk_hz(void) {
- u32 reg, clock;
- u32 src_hz, numer, denom, vco;
This file mainly to rename of variables and minor fixes on some clock calculation. I will separate these changes from this patch and move to after "[PATCH 01/20] arm: socfpga: restructure clock manager driver".
- return clock;
- vco = src_hz;
- return vco;
Thanks
Regards Ley Foon
Yeah, either that or use accessors.
+struct strtopu32 {
- const char *str;
- u32 *p;
Will remove.
- u32 reg, clock;
Good, thanks.
- return clock;
- vco = src_hz;
- return vco;
Thanks
Regards Ley Foon
Add system manager support for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- .../arm/mach-socfpga/include/mach/system_manager.h | 54 ++++++++++++++- .../include/mach/system_manager_arria10.h | 81 ++++++++++++++++++++++ .../include/mach/system_manager_gen5.h | 1 + 3 files changed, 135 insertions(+), 1 deletion(-) create mode 100755 arch/arm/mach-socfpga/include/mach/system_manager_arria10.h
diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index 53ced81..324d13f 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -31,7 +31,59 @@ #define SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB 2 #define SYSMGR_EMACGRP_CTRL_PHYSEL_MASK 0x3
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +/* For dedicated IO configuration */ +/* Voltage select enums */ +#define VOLTAGE_SEL_3V 0x0 +#define VOLTAGE_SEL_1P8V 0x1 +#define VOLTAGE_SEL_2P5V 0x2 + +/* Input buffer enable */ +#define INPUT_BUF_DISABLE 0 +#define INPUT_BUF_1P8V 1 +#define INPUT_BUF_2P5V3V 2 + +/* Weak pull up enable */ +#define WK_PU_DISABLE 0 +#define WK_PU_ENABLE 1 + +/* Pull up slew rate control */ +#define PU_SLW_RT_SLOW 0 +#define PU_SLW_RT_FAST 1 +#define PU_SLW_RT_DEFAULT PU_SLW_RT_SLOW + +/* Pull down slew rate control */ +#define PD_SLW_RT_SLOW 0 +#define PD_SLW_RT_FAST 1 +#define PD_SLW_RT_DEFAULT PD_SLW_RT_SLOW + +/* Drive strength control */ +#define PU_DRV_STRG_DEFAULT 0x10 +#define PD_DRV_STRG_DEFAULT 0x10 + +/* bit position */ +#define PD_DRV_STRG_LSB 0 +#define PD_SLW_RT_LSB 5 +#define PU_DRV_STRG_LSB 8 +#define PU_SLW_RT_LSB 13 +#define WK_PU_LSB 16 +#define INPUT_BUF_LSB 17 +#define BIAS_TRIM_LSB 19 +#define VOLTAGE_SEL_LSB 0 + +#define ALT_SYSMGR_NOC_H2F_SET_MSK 0x00000001 +#define ALT_SYSMGR_NOC_LWH2F_SET_MSK 0x00000010 +#define ALT_SYSMGR_NOC_F2H_SET_MSK 0x00000100 +#define ALT_SYSMGR_NOC_F2SDR0_SET_MSK 0x00010000 +#define ALT_SYSMGR_NOC_F2SDR1_SET_MSK 0x00100000 +#define ALT_SYSMGR_NOC_F2SDR2_SET_MSK 0x01000000 +#define ALT_SYSMGR_NOC_TMO_EN_SET_MSK 0x00000001 + +#define ALT_SYSMGR_ECC_INTSTAT_SERR_OCRAM_SET_MSK 0x00000002 +#define ALT_SYSMGR_ECC_INTSTAT_DERR_OCRAM_SET_MSK 0x00000002 + +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/system_manager_arria10.h> +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) #include <asm/arch/system_manager_gen5.h> #endif
diff --git a/arch/arm/mach-socfpga/include/mach/system_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/system_manager_arria10.h new file mode 100755 index 0000000..78432ec --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/system_manager_arria10.h @@ -0,0 +1,81 @@ +/* + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _SYSTEM_MANAGER_ARRIA10_H_ +#define _SYSTEM_MANAGER_ARRIA10_H_ + +struct socfpga_system_manager { + u32 siliconid1; + u32 siliconid2; + u32 wddbg; + u32 bootinfo; + u32 mpu_ctrl_l2_ecc; + u32 _pad_0x14_0x1f[3]; + u32 dma; + u32 dma_periph; + u32 sdmmcgrp_ctrl; + u32 sdmmc_l3master; + u32 nand_bootstrap; + u32 nand_l3master; + u32 usb0_l3master; + u32 usb1_l3master; + u32 emac_global; + u32 emac[3]; + u32 _pad_0x50_0x5f[4]; + u32 fpgaintf_en_global; + u32 fpgaintf_en_0; + u32 fpgaintf_en_1; + u32 fpgaintf_en_2; + u32 fpgaintf_en_3; + u32 _pad_0x74_0x7f[3]; + u32 noc_addr_remap_value; + u32 noc_addr_remap_set; + u32 noc_addr_remap_clear; + u32 _pad_0x8c_0x8f; + u32 ecc_intmask_value; + u32 ecc_intmask_set; + u32 ecc_intmask_clr; + u32 ecc_intstatus_serr; + u32 ecc_intstatus_derr; + u32 mpu_status_l2_ecc; + u32 mpu_clear_l2_ecc; + u32 mpu_status_l1_parity; + u32 mpu_clear_l1_parity; + u32 mpu_set_l1_parity; + u32 _pad_0xb8_0xbf[2]; + u32 noc_timeout; + u32 noc_idlereq_set; + u32 noc_idlereq_clr; + u32 noc_idlereq_value; + u32 noc_idleack; + u32 noc_idlestatus; + u32 fpga2soc_ctrl; + u32 _pad_0xdc_0xff[9]; + u32 tsmc_tsel_0; + u32 tsmc_tsel_1; + u32 tsmc_tsel_2; + u32 tsmc_tsel_3; + u32 _pad_0x110_0x200[60]; + u32 romhw_ctrl; + u32 romcode_ctrl; + u32 romcode_cpu1startaddr; + u32 romcode_initswstate; + u32 romcode_initswlastld; + u32 _pad_0x214_0x217; + u32 warmram_enable; + u32 warmram_datastart; + u32 warmram_length; + u32 warmram_execution; + u32 warmram_crc; + u32 _pad_0x22c_0x22f; + u32 isw_handoff[8]; + u32 romcode_bootromswstate[8]; +}; + +#define SYSMGR_SDMMC_SMPLSEL_SHIFT 4 +#define SYSMGR_BOOTINFO_BSEL_SHIFT 12 + +#endif /* _SYSTEM_MANAGER_ARRIA10_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h index 3ad4ca1..285c1a2 100755 --- a/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h @@ -117,5 +117,6 @@ struct socfpga_system_manager { #endif
#define SYSMGR_SDMMC_SMPLSEL_SHIFT 3 +#define SYSMGR_BOOTINFO_BSEL_SHIFT 0
#endif /* _SYSTEM_MANAGER_GEN5_H_ */
But these are just headers, there's no system manager code here ?
- u32 siliconid1;
- u32 siliconid2;
- u32 wddbg;
- u32 bootinfo;
- u32 mpu_ctrl_l2_ecc;
- u32 _pad_0x14_0x1f[3];
- u32 dma;
- u32 dma_periph;
- u32 sdmmcgrp_ctrl;
- u32 sdmmc_l3master;
- u32 nand_bootstrap;
- u32 nand_l3master;
- u32 usb0_l3master;
- u32 usb1_l3master;
- u32 emac_global;
- u32 emac[3];
- u32 _pad_0x50_0x5f[4];
- u32 fpgaintf_en_global;
- u32 fpgaintf_en_0;
- u32 fpgaintf_en_1;
- u32 fpgaintf_en_2;
- u32 fpgaintf_en_3;
- u32 _pad_0x74_0x7f[3];
- u32 noc_addr_remap_value;
- u32 noc_addr_remap_set;
- u32 noc_addr_remap_clear;
- u32 _pad_0x8c_0x8f;
- u32 ecc_intmask_value;
- u32 ecc_intmask_set;
- u32 ecc_intmask_clr;
- u32 ecc_intstatus_serr;
- u32 ecc_intstatus_derr;
- u32 mpu_status_l2_ecc;
- u32 mpu_clear_l2_ecc;
- u32 mpu_status_l1_parity;
- u32 mpu_clear_l1_parity;
- u32 mpu_set_l1_parity;
- u32 _pad_0xb8_0xbf[2];
- u32 noc_timeout;
- u32 noc_idlereq_set;
- u32 noc_idlereq_clr;
- u32 noc_idlereq_value;
- u32 noc_idleack;
- u32 noc_idlestatus;
- u32 fpga2soc_ctrl;
- u32 _pad_0xdc_0xff[9];
- u32 tsmc_tsel_0;
- u32 tsmc_tsel_1;
- u32 tsmc_tsel_2;
- u32 tsmc_tsel_3;
- u32 _pad_0x110_0x200[60];
- u32 romhw_ctrl;
- u32 romcode_ctrl;
- u32 romcode_cpu1startaddr;
- u32 romcode_initswstate;
- u32 romcode_initswlastld;
- u32 _pad_0x214_0x217;
- u32 warmram_enable;
- u32 warmram_datastart;
- u32 warmram_length;
- u32 warmram_execution;
- u32 warmram_crc;
- u32 _pad_0x22c_0x22f;
- u32 isw_handoff[8];
- u32 romcode_bootromswstate[8];
Yes. Mainly for system manager's register struct and defines.
.../arm/mach-socfpga/include/mach/system_manager.h | 54 ++++++++++++++- .../include/mach/system_manager_arria10.h | 81 ++++++++++++++++++++++ .../include/mach/system_manager_gen5.h | 1 + 3 files changed, 135 insertions(+), 1 deletion(-) create mode 100755 arch/arm/mach- socfpga/include/mach/system_manager_arria10.h
Regards Ley Foon
So it's not adding any systemmanager support, so the commit message needs updating.
Regards Ley Foon
Okay, will update commit message.
Thanks.
Regards Ley Foon
Add sdram header file for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/include/mach/sdram_arria10.h | 380 +++++++++++++++++++++ 1 file changed, 380 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/sdram_arria10.h
diff --git a/arch/arm/mach-socfpga/include/mach/sdram_arria10.h b/arch/arm/mach-socfpga/include/mach/sdram_arria10.h new file mode 100644 index 0000000..964c80a --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/sdram_arria10.h @@ -0,0 +1,380 @@ +/* + * Copyright (C) 2015-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SOCFPGA_SDRAM_ARRIA10_H_ +#define _SOCFPGA_SDRAM_ARRIA10_H_ + +#ifndef __ASSEMBLY__ + +struct socfpga_ecc_hmc { + u32 ip_rev_id; + u32 _pad_0x4_0x7; + u32 ddrioctrl; + u32 ddrcalstat; + u32 mpr_0beat1; + u32 mpr_1beat1; + u32 mpr_2beat1; + u32 mpr_3beat1; + u32 mpr_4beat1; + u32 mpr_5beat1; + u32 mpr_6beat1; + u32 mpr_7beat1; + u32 mpr_8beat1; + u32 mpr_0beat2; + u32 mpr_1beat2; + u32 mpr_2beat2; + u32 mpr_3beat2; + u32 mpr_4beat2; + u32 mpr_5beat2; + u32 mpr_6beat2; + u32 mpr_7beat2; + u32 mpr_8beat2; + u32 _pad_0x58_0x5f[2]; + u32 auto_precharge; + u32 _pad_0x64_0xff[39]; + u32 eccctrl; + u32 eccctrl2; + u32 _pad_0x108_0x10f[2]; + u32 errinten; + u32 errintens; + u32 errintenr; + u32 intmode; + u32 intstat; + u32 diaginttest; + u32 modstat; + u32 derraddra; + u32 serraddra; + u32 _pad_0x134_0x137; + u32 autowb_corraddr; + u32 serrcntreg; + u32 autowb_drop_cntreg; + u32 _pad_0x144_0x147; + u32 ecc_reg2wreccdatabus; + u32 ecc_rdeccdata2regbus; + u32 ecc_reg2rdeccdatabus; + u32 _pad_0x154_0x15f[3]; + u32 ecc_diagon; + u32 ecc_decstat; + u32 _pad_0x168_0x16f[2]; + u32 ecc_errgenaddr_0; + u32 ecc_errgenaddr_1; + u32 ecc_errgenaddr_2; + u32 ecc_errgenaddr_3; +}; + +struct socfpga_noc_ddr_scheduler { + u32 ddr_t_main_scheduler_id_coreid; + u32 ddr_t_main_scheduler_id_revisionid; + u32 ddr_t_main_scheduler_ddrconf; + u32 ddr_t_main_scheduler_ddrtiming; + u32 ddr_t_main_scheduler_ddrmode; + u32 ddr_t_main_scheduler_readlatency; + u32 _pad_0x20_0x34[8]; + u32 ddr_t_main_scheduler_activate; + u32 ddr_t_main_scheduler_devtodev; +}; + +/* + * OCRAM firewall + */ +struct socfpga_noc_fw_ocram { + u32 enable; + u32 enable_set; + u32 enable_clear; + u32 region0; + u32 region1; + u32 region2; + u32 region3; + u32 region4; + u32 region5; +}; + +/* for master such as MPU and FPGA */ +struct socfpga_noc_fw_ddr_mpu_fpga2sdram { + u32 enable; + u32 enable_set; + u32 enable_clear; + u32 _pad_0xc_0xf; + u32 mpuregion0addr; + u32 mpuregion1addr; + u32 mpuregion2addr; + u32 mpuregion3addr; + u32 fpga2sdram0region0addr; + u32 fpga2sdram0region1addr; + u32 fpga2sdram0region2addr; + u32 fpga2sdram0region3addr; + u32 fpga2sdram1region0addr; + u32 fpga2sdram1region1addr; + u32 fpga2sdram1region2addr; + u32 fpga2sdram1region3addr; + u32 fpga2sdram2region0addr; + u32 fpga2sdram2region1addr; + u32 fpga2sdram2region2addr; + u32 fpga2sdram2region3addr; +}; + +/* for L3 master */ +struct socfpga_noc_fw_ddr_l3 { + u32 enable; + u32 enable_set; + u32 enable_clear; + u32 hpsregion0addr; + u32 hpsregion1addr; + u32 hpsregion2addr; + u32 hpsregion3addr; + u32 hpsregion4addr; + u32 hpsregion5addr; + u32 hpsregion6addr; + u32 hpsregion7addr; +}; + +struct socfpga_io48_mmr { + u32 dbgcfg0; + u32 dbgcfg1; + u32 dbgcfg2; + u32 dbgcfg3; + u32 dbgcfg4; + u32 dbgcfg5; + u32 dbgcfg6; + u32 reserve0; + u32 reserve1; + u32 reserve2; + u32 ctrlcfg0; + u32 ctrlcfg1; + u32 ctrlcfg2; + u32 ctrlcfg3; + u32 ctrlcfg4; + u32 ctrlcfg5; + u32 ctrlcfg6; + u32 ctrlcfg7; + u32 ctrlcfg8; + u32 ctrlcfg9; + u32 dramtiming0; + u32 dramodt0; + u32 dramodt1; + u32 sbcfg0; + u32 sbcfg1; + u32 sbcfg2; + u32 sbcfg3; + u32 sbcfg4; + u32 sbcfg5; + u32 sbcfg6; + u32 sbcfg7; + u32 caltiming0; + u32 caltiming1; + u32 caltiming2; + u32 caltiming3; + u32 caltiming4; + u32 caltiming5; + u32 caltiming6; + u32 caltiming7; + u32 caltiming8; + u32 caltiming9; + u32 caltiming10; + u32 dramaddrw; + u32 sideband0; + u32 sideband1; + u32 sideband2; + u32 sideband3; + u32 sideband4; + u32 sideband5; + u32 sideband6; + u32 sideband7; + u32 sideband8; + u32 sideband9; + u32 sideband10; + u32 sideband11; + u32 sideband12; + u32 sideband13; + u32 sideband14; + u32 sideband15; + u32 dramsts; + u32 dbgdone; + u32 dbgsignals; + u32 dbgreset; + u32 dbgmatch; + u32 counter0mask; + u32 counter1mask; + u32 counter0match; + u32 counter1match; + u32 niosreserve0; + u32 niosreserve1; + u32 niosreserve2; +}; +#endif /*__ASSEMBLY__*/ + +#define IO48_MMR_CTRLCFG0_DB2_BURST_LENGTH_MASK 0x1F000000 +#define IO48_MMR_CTRLCFG0_DB2_BURST_LENGTH_SHIFT 24 +#define IO48_MMR_CTRLCFG0_DB1_BURST_LENGTH_MASK 0x00F80000 +#define IO48_MMR_CTRLCFG0_DB1_BURST_LENGTH_SHIFT 19 +#define IO48_MMR_CTRLCFG0_DB0_BURST_LENGTH_MASK 0x0007C000 +#define IO48_MMR_CTRLCFG0_DB0_BURST_LENGTH_SHIFT 14 +#define IO48_MMR_CTRLCFG0_CTRL_BURST_LENGTH_MASK 0x00003E00 +#define IO48_MMR_CTRLCFG0_CTRL_BURST_LENGTH_SHIFT 9 +#define IO48_MMR_CTRLCFG0_AC_POS_MASK 0x00000180 +#define IO48_MMR_CTRLCFG0_AC_POS_SHIFT 7 +#define IO48_MMR_CTRLCFG0_DIMM_TYPE_MASK 0x00000070 +#define IO48_MMR_CTRLCFG0_DIM_TYPE_SHIFT 4 +#define IO48_MMR_CTRLCFG0_MEM_TYPE_MASK 0x0000000F +#define IO48_MMR_CTRLCFG0_MEM_TYPE_SHIFT 0 + +#define IO48_MMR_CTRLCFG1_DBC3_ENABLE_DM BIT(30) +#define IO48_MMR_CTRLCFG1_DBC2_ENABLE_DM BIT(29) +#define IO48_MMR_CTRLCFG1_DBC1_ENABLE_DM BIT(28) +#define IO48_MMR_CTRLCFG1_DBC0_ENABLE_DM BIT(27) +#define IO48_MMR_CTRLCFG1_CTRL_ENABLE_DM BIT(26) +#define IO48_MMR_CTRLCFG1_DQSTRK_EN BIT(25) +#define IO48_MMR_CTRLCFG1_STARVE_LIMIT_MASK 0x01F80000 +#define IO48_MMR_CTRLCFG1_STARVE_LIMIT_SHIFT 19 +#define IO48_MMR_CTRLCFG1_REORDER_READ BIT(18) +#define IO48_MMR_CTRLCFG1_DBC3_REORDER_RDATA BIT(17) +#define IO48_MMR_CTRLCFG1_DBC2_REORDER_RDATA BIT(16) +#define IO48_MMR_CTRLCFG1_DBC1_REORDER_RDATA BIT(15) +#define IO48_MMR_CTRLCFG1_DBC0_REORDER_RDATA BIT(14) +#define IO48_MMR_CTRLCFG1_CTRL_REORDER_RDATA BIT(13) +#define IO48_MMR_CTRLCFG1_REORDER_DATA BIT(12) +#define IO48_MMR_CTRLCFG1_DBC3_ENABLE_ECC BIT(11) +#define IO48_MMR_CTRLCFG1_DBC2_ENABLE_ECC BIT(10) +#define IO48_MMR_CTRLCFG1_DBC1_ENABLE_ECC BIT(9) +#define IO48_MMR_CTRLCFG1_DBC0_ENABLE_ECC BIT(8) +#define IO48_MMR_CTRLCFG1_CTRL_ENABLE_ECC BIT(7) +#define IO48_MMR_CTRLCFG1_ADDR_ORDER_MASK 0x00000060 +#define IO48_MMR_CTRLCFG1_ADDR_ORDER_SHIFT 5 +#define IO48_MMR_CTRLCFG1_DBC3_BURST_LENGTH_MASK 0x0000001F +#define IO48_MMR_CTRLCFG1_DBC3_BURST_LENGTH_SHIFT 0 + +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BG_MASK 0x3F000000 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BG_SHIFT 24 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BANK_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BANK_SHIFT 18 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_MASK 0x0003F000 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_SHIFT 12 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_PCH_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_PCH_SHIFT 6 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_RDWR_MASK 0x0000003F +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_RDWR_SHIFT 0 + +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_DIFF_CHIP_MASK 0x3F000000 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_DIFF_CHIP_SHIFT 24 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_SHIFT 18 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DB_MASK 0x0003F000 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DB_SHIFT 12 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DC_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DC_SHIFT 6 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_MASK 0x0000003F +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_SHIFT 0 + +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_DIFF_CHIP_MASK 0x3F000000 +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_DIFF_CHIP_SHIFT 24 +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_SHIFT 18 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_AP_VALID_MASK 0x0003F000 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_AP_VALID_SHIFT 12 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_PCH_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_PCH_SHIFT 6 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_WR_DIFF_BG_MASK 0x0000003F +#define IO48_MMR_CALTIMING2_CFG_RD_TO_WR_DIFF_BG_SHIFT 0 + +#define IO48_MMR_CALTIMING3_CFG_WR_TO_PCH_MASK 0x3F000000 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_PCH_SHIFT 24 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_BG_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_BG_SHIFT 18 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_CHIP_MASK 0x0003F000 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_CHIP_SHIFT 12 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_SHIFT 6 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_WR_DIFF_BG_MASK 0x0000003F +#define IO48_MMR_CALTIMING3_CFG_WR_TO_WR_DIFF_BG_SHIFT 0 + +#define IO48_MMR_CALTIMING4_CFG_PDN_TO_VALID_MASK 0xFC000000 +#define IO48_MMR_CALTIMING4_CFG_PDN_TO_VALID_SHIFT 26 +#define IO48_MMR_CALTIMING4_CFG_ARF_TO_VALID_MASK 0x03FC0000 +#define IO48_MMR_CALTIMING4_CFG_ARF_TO_VALID_SHIFT 18 +#define IO48_MMR_CALTIMING4_CFG_PCH_ALL_TO_VALID_MASK 0x0003F000 +#define IO48_MMR_CALTIMING4_CFG_PCH_ALL_TO_VALID_SHIFT 12 +#define IO48_MMR_CALTIMING4_CFG_PCH_TO_VALID_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING4_CFG_PCH_TO_VALID_SHIFT 6 +#define IO48_MMR_CALTIMING4_CFG_WR_AP_TO_VALID_MASK 0x0000003F +#define IO48_MMR_CALTIMING4_CFG_WR_AP_TO_VALID_SHIFT 0 + +#define IO48_MMR_CALTIMING9_CFG_WR_4_ACT_TO_ACT_MASK 0x000000FF +#define IO48_MMR_CALTIMING9_CFG_WR_4_ACT_TO_ACT_SHIFT 0 + +#define IO48_MMR_DRAMADDRW_CFG_CS_ADDR_WIDTH_MASK 0x00070000 +#define IO48_MMR_DRAMADDRW_CFG_CS_ADDR_WIDTH_SHIFT 16 +#define IO48_MMR_DRAMADDRW_CFG_BANK_GROUP_ADDR_WIDTH_MASK 0x0000C000 +#define IO48_MMR_DRAMADDRW_CFG_BANK_GROUP_ADDR_WIDTH_SHIFT 14 +#define IO48_MMR_DRAMADDRW_CFG_BANK_ADDR_WIDTH_MASK 0x00003C00 +#define IO48_MMR_DRAMADDRW_CFG_BANK_ADDR_WIDTH_SHIFT 10 +#define IO48_MMR_DRAMADDRW_CFG_ROW_ADDR_WIDTH_MASK 0x000003E0 +#define IO48_MMR_DRAMADDRW_CFG_ROW_ADDR_WIDTH_SHIFT 5 +#define IO48_MMR_DRAMADDRW_CFG_COL_ADDR_WIDTH_MASK 0x0000001F +#define IO48_MMR_DRAMADDRW_CFG_COL_ADDR_WIDTH_SHIFT 0 + +#define ALT_ECC_HMC_OCP_DDRIOCTRL_IO_SIZE_MSK 0x00000003 + +#define ALT_ECC_HMC_OCP_INTSTAT_SERRPENA_SET_MSK BIT(0) +#define ALT_ECC_HMC_OCP_INTSTAT_DERRPENA_SET_MSK BIT(1) +#define ALT_ECC_HMC_OCP_ERRINTEN_SERRINTEN_SET_MSK BIT(0) +#define ALT_ECC_HMC_OCP_ERRINTEN_DERRINTEN_SET_MSK BIT(1) +#define ALT_ECC_HMC_OCP_INTMOD_INTONCMP_SET_MSK BIT(16) +#define ALT_ECC_HMC_OCP_ECCCTL_AWB_CNT_RST_SET_MSK BIT(16) +#define ALT_ECC_HMC_OCP_ECCCTL_CNT_RST_SET_MSK BIT(8) +#define ALT_ECC_HMC_OCP_ECCCTL_ECC_EN_SET_MSK BIT(0) +#define ALT_ECC_HMC_OCP_ECCCTL2_RMW_EN_SET_MSK BIT(8) +#define ALT_ECC_HMC_OCP_ECCCTL2_AWB_EN_SET_MSK BIT(0) + +#define ALT_ECC_HMC_OCP_SERRCNTREG_VALUE 8 + +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_ACTTOACT_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_RDTOMISS_LSB 6 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_WRTOMISS_LSB 12 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_BURSTLEN_LSB 18 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_RDTOWR_LSB 21 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_WRTORD_LSB 26 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_BWRATIO_LSB 31 + +#define ALT_NOC_MPU_DDR_T_SCHED_DDRMOD_AUTOPRECHARGE_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRMOD_BWRATIOEXTENDED_LSB 1 + +#define ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_RRD_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_FAW_LSB 4 +#define ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_FAWBANK_LSB 10 + +#define ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSRDTORD_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSRDTOWR_LSB 2 +#define ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSWRTORD_LSB 4 + +#define ALT_NOC_FW_DDR_END_ADDR_LSB 16 +#define ALT_NOC_FW_DDR_ADDR_MASK 0xFFFF +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG0EN_SET_MSK BIT(0) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG1EN_SET_MSK BIT(1) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG2EN_SET_MSK BIT(2) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG3EN_SET_MSK BIT(3) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG4EN_SET_MSK BIT(4) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG5EN_SET_MSK BIT(5) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG6EN_SET_MSK BIT(6) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG7EN_SET_MSK BIT(7) +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG0EN_SET_MSK BIT(0) +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG1EN_SET_MSK BIT(1) +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG2EN_SET_MSK BIT(2) +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG3EN_SET_MSK BIT(3) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG0EN_SET_MSK BIT(4) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG1EN_SET_MSK BIT(5) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG2EN_SET_MSK BIT(6) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG3EN_SET_MSK BIT(7) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG0EN_SET_MSK BIT(8) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG1EN_SET_MSK BIT(9) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG2EN_SET_MSK BIT(10) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG3EN_SET_MSK BIT(11) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG0EN_SET_MSK BIT(12) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG1EN_SET_MSK BIT(13) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG2EN_SET_MSK BIT(14) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG3EN_SET_MSK BIT(15) + +#define ALT_IO48_DRAMTIME_MEM_READ_LATENCY_MASK 0x0000003F +#endif /* _SOCFPGA_SDRAM_ARRIA10_H_ */
Add misc support for Arria 10 and minor fix on misc Gen5.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/include/mach/misc.h | 6 + arch/arm/mach-socfpga/misc_arria10.c | 262 ++++++++++++++++++++++++++++++ arch/arm/mach-socfpga/misc_gen5.c | 3 +- 4 files changed, 271 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-socfpga/misc_arria10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index c494930..9c4617f 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -11,6 +11,7 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \ fpga_manager.o board.o
obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clock_manager_arria10.o \ + misc_arria10.o \ reset_manager_arria10.o
obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index 64f9b86..446ee0f 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -23,4 +23,10 @@ void socfpga_fpga_add(void); inline void socfpga_fpga_add(void) {} #endif
+#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +unsigned int dedicated_uart_com_port(const void *blob); +unsigned int shared_uart_com_port(const void *blob); +unsigned int uart_com_port(const void *blob); +#endif + #endif /* _MISC_H_ */ diff --git a/arch/arm/mach-socfpga/misc_arria10.c b/arch/arm/mach-socfpga/misc_arria10.c new file mode 100644 index 0000000..2e89067 --- /dev/null +++ b/arch/arm/mach-socfpga/misc_arria10.c @@ -0,0 +1,262 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <altera.h> +#include <miiphy.h> +#include <netdev.h> +#include <watchdog.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/sdram_arria10.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/nic301.h> +#include <asm/pl310.h> +#include <fdtdec.h> +#include <ns16550.h> + +#define PINMUX_UART0_TX_SHARED_IO_OFFSET_Q1_3 0x08 +#define PINMUX_UART0_TX_SHARED_IO_OFFSET_Q2_11 0x58 +#define PINMUX_UART0_TX_SHARED_IO_OFFSET_Q3_3 0x68 +#define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q1_7 0x18 +#define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q3_7 0x78 +#define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q4_3 0x98 + +DECLARE_GLOBAL_DATA_PTR; + +static int find_peripheral_uart(const void *blob, + int child, const char *node_name); +static int is_peripheral_uart_true(const void *blob, + int node, const char *child_name); + +static struct pl310_regs *const pl310 = + (struct pl310_regs *)CONFIG_SYS_PL310_BASE; +static struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; +static const struct socfpga_noc_fw_ocram *noc_fw_ocram_base = + (void *)SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS; +static const struct socfpga_noc_fw_ddr_l3 *noc_fw_ddr_l3_base = + (void *)SOCFPGA_SDR_FIREWALL_L3_ADDRESS; + +/* + * DesignWare Ethernet initialization + */ +#ifdef CONFIG_ETH_DESIGNWARE +void dwmac_deassert_reset(const unsigned int of_reset_id, + const u32 phymode) +{ + u32 reset; + + if (of_reset_id == EMAC0_RESET) { + reset = SOCFPGA_RESET(EMAC0); + } else if (of_reset_id == EMAC1_RESET) { + reset = SOCFPGA_RESET(EMAC1); + } else if (of_reset_id == EMAC2_RESET) { + reset = SOCFPGA_RESET(EMAC2); + } else { + printf("GMAC: Invalid reset ID (%i)!\n", of_reset_id); + return; + } + + clrsetbits_le32(&sysmgr_regs->emac[of_reset_id - EMAC0_RESET], + SYSMGR_EMACGRP_CTRL_PHYSEL_MASK, + phymode); + + /* Release the EMAC controller from reset */ + socfpga_per_reset(reset, 0); +} +#endif + +/* ++ * This function initializes security policies to be consistent across ++ * all logic units in the Arria 10. ++ * ++ * The idea is to set all security policies to be normal, nonsecure ++ * for all units. ++ */ +static void initialize_security_policies(void) +{ + /* Put OCRAM in non-secure */ + writel(0x003f0000, &noc_fw_ocram_base->region0); + writel(0x1, &noc_fw_ocram_base->enable); + + /* Put DDR in non-secure */ + writel(0xffff0000, &noc_fw_ddr_l3_base->hpsregion0addr); + writel(0x1, &noc_fw_ddr_l3_base->enable); +} + +int arch_early_init_r(void) +{ + initialize_security_policies(); + + /* Configure the L2 controller to make SDRAM start at 0 */ + writel(0x1, &pl310->pl310_addr_filter_start); + + /* assert reset to all except L4WD0 and L4TIMER0 */ + socfpga_per_reset_all(); + + /* configuring the clock based on handoff */ + /* TODO: Add call to cm_basic_init() */ + + /* Add device descriptor to FPGA device table */ + socfpga_fpga_add(); + return 0; +} + +/* + * This function looking the 1st encounter UART peripheral, + * and then return its offset of the dedicated/shared IO pin + * mux. offset value (zero and above). + */ +static int find_peripheral_uart(const void *blob, + int child, const char *node_name) +{ + int len; + fdt_addr_t base_addr = 0; + fdt_size_t size; + const u32 *cell; + u32 value, offset = 0; + + base_addr = fdtdec_get_addr_size(blob, child, "reg", &size); + if (base_addr != FDT_ADDR_T_NONE) { + cell = fdt_getprop(blob, child, "pinctrl-single,pins", + &len); + if (cell != NULL) { + for (; len > 0; len -= (2 * sizeof(u32))) { + offset = fdt32_to_cpu(*cell++); + value = fdt32_to_cpu(*cell++); + /* Found UART peripheral */ + if (0x0D == value) + return offset; + } + } + } + return -1; +} + +/* + * This function looking the 1st encounter UART peripheral, + * and then return its offset of the dedicated/shared IO pin + * mux. UART peripheral is found if the offset is not in negative + * value. + */ +static int is_peripheral_uart_true(const void *blob, + int node, const char *child_name) +{ + int child, len; + const char *node_name; + + child = fdt_first_subnode(blob, node); + + if (child < 0) + return -1; + + node_name = fdt_get_name(blob, child, &len); + + while (node_name) { + if (!strcmp(child_name, node_name)) + return find_peripheral_uart(blob, child, node_name); + + child = fdt_next_subnode(blob, child); + + if (child < 0) + break; + + node_name = fdt_get_name(blob, child, &len); + } + + return -1; +} + +/* + * This function looking the 1st encounter UART dedicated IO peripheral, + * and then return based address of the 1st encounter UART dedicated + * IO peripheral. + */ +unsigned int dedicated_uart_com_port(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + + if (node < 0) + return 0; + + if (0 <= is_peripheral_uart_true(blob, node, "dedicated")) + return SOCFPGA_UART1_ADDRESS; + else + return 0; +} + +/* + * This function looking the 1st encounter UART shared IO peripheral, and then + * return based address of the 1st encounter UART shared IO peripheral. + */ +unsigned int shared_uart_com_port(const void *blob) +{ + int node, ret; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + + if (node < 0) + return 0; + + ret = is_peripheral_uart_true(blob, node, "shared"); + + if (PINMUX_UART0_TX_SHARED_IO_OFFSET_Q1_3 == ret || + PINMUX_UART0_TX_SHARED_IO_OFFSET_Q2_11 == ret || + PINMUX_UART0_TX_SHARED_IO_OFFSET_Q3_3 == ret) + return SOCFPGA_UART0_ADDRESS; + else if (PINMUX_UART1_TX_SHARED_IO_OFFSET_Q1_7 == ret || + PINMUX_UART1_TX_SHARED_IO_OFFSET_Q3_7 == ret || + PINMUX_UART1_TX_SHARED_IO_OFFSET_Q4_3 == ret) + return SOCFPGA_UART1_ADDRESS; + else + return 0; +} + +/* + * This function looking the 1st encounter UART peripheral, and then return + * base address of the 1st encounter UART peripheral. + */ +unsigned int uart_com_port(const void *blob) +{ + unsigned int ret; + + ret = dedicated_uart_com_port(blob); + + if (ret) + return ret; + + return shared_uart_com_port(blob); +} + +/* + * Print CPU information + */ +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> + SYSMGR_BOOTINFO_BSEL_SHIFT) & 0x7; + + puts("CPU: Altera SoCFPGA Arria 10\n"); + + printf("BOOT: %s\n", bsel_str[bsel].name); + return 0; +} +#endif + +#ifdef CONFIG_ARCH_MISC_INIT +int arch_misc_init(void) +{ + return 0; +} +#endif diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index f870e1f..3b8ce11 100755 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -200,7 +200,8 @@ static int socfpga_fpga_id(const bool print_id) #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { - const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; + const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> + SYSMGR_BOOTINFO_BSEL_SHIFT) & 0x7;
puts("CPU: Altera SoCFPGA Platform\n"); socfpga_fpga_id(1);
- This function looking the 1st encounter UART peripheral,
- and then return its offset of the dedicated/shared IO pin
- mux. offset value (zero and above).
- int child, const char *node_name)
- int len;
- fdt_addr_t base_addr = 0;
- fdt_size_t size;
- const u32 *cell;
- u32 value, offset = 0;
- base_addr = fdtdec_get_addr_size(blob, child, "reg", &size);
- if (base_addr != FDT_ADDR_T_NONE) {
&len);
if (cell != NULL) {
len == 0 is not handled ?
if (0x0D == value)
return offset;
- return -1;
s/looking/looks up/ ?
- mux. UART peripheral is found if the offset is not in negative
- value.
- int node, const char *child_name)
- int child, len;
- if (child < 0)
return -1;
errno.h
if (child < 0)
break;
- return -1;
- This function looking the 1st encounter UART dedicated IO peripheral,
- and then return based address of the 1st encounter UART dedicated
- IO peripheral.
- int node;
- if (node < 0)
- if (0 <= is_peripheral_uart_true(blob, node, "dedicated"))
- else
- This function looking the 1st encounter UART shared IO peripheral, and then
- return based address of the 1st encounter UART shared IO peripheral.
- int node, ret;
- if (node < 0)
- ret = is_peripheral_uart_true(blob, node, "shared");
- if (PINMUX_UART0_TX_SHARED_IO_OFFSET_Q1_3 == ret ||
- else if (PINMUX_UART1_TX_SHARED_IO_OFFSET_Q1_7 == ret ||
- else
- This function looking the 1st encounter UART peripheral, and then return
- base address of the 1st encounter UART peripheral.
This is referenced earlier in the patchset , it should be added earlier if possible.
- unsigned int ret;
- ret = dedicated_uart_com_port(blob);
- if (ret)
return ret;
- return shared_uart_com_port(blob);
- Print CPU information
- const u32 bsel = (readl(&sysmgr_regs->bootinfo) >>
- puts("CPU: Altera SoCFPGA Arria 10\n");
- printf("BOOT: %s\n", bsel_str[bsel].name);
+} +#endif
- int len;
- fdt_size_t size;
- const u32 *cell;
&size);
single,pins",
&len);
if (cell != NULL) {
If len is 0, it should go to return -1 below. BTW, I will change the -1 below to -EINVAL.
if (0x0D == value)
return offset;
- return -1;
Okay.
- value.
- int child, len;
- if (child < 0)
return -1;
errno.h
Yes, will change to -EINVAL.
node_name);
if (child < 0)
break;
- return -1;
peripheral,
dedicated
- IO peripheral.
- int node;
- if (node < 0)
- else
peripheral.
- int node, ret;
- if (node < 0)
- PINMUX_UART0_TX_SHARED_IO_OFFSET_Q2_11 == ret ||
- PINMUX_UART0_TX_SHARED_IO_OFFSET_Q3_3 == ret)
- else
then return
Yes. Will change this.
Thanks.
Regards Ley Foon
- int len;
- fdt_size_t size;
- const u32 *cell;
&size);
single,pins",
&len);
if (cell != NULL) {
Ah, true. Brainfart, please ignore.
OK
if (0x0D == value)
return offset;
- return -1;
Add pinmux support for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/include/mach/pinmux.h | 15 +++++ arch/arm/mach-socfpga/pinmux_arria10.c | 98 +++++++++++++++++++++++++++++ 3 files changed, 114 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/pinmux.h create mode 100644 arch/arm/mach-socfpga/pinmux_arria10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 9c4617f..68d55e4 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -12,6 +12,7 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \
obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clock_manager_arria10.o \ misc_arria10.o \ + pinmux_arria10.o \ reset_manager_arria10.o
obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o diff --git a/arch/arm/mach-socfpga/include/mach/pinmux.h b/arch/arm/mach-socfpga/include/mach/pinmux.h new file mode 100644 index 0000000..c5d5dd6 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/pinmux.h @@ -0,0 +1,15 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _PINMUX_H_ +#define _PINMUX_H_ + +#ifndef __ASSEMBLY__ +int config_dedicated_pins(const void *blob); +int config_pins(const void *blob, const char *pin_grp); +#endif + +#endif /* _PINMUX_H_ */ diff --git a/arch/arm/mach-socfpga/pinmux_arria10.c b/arch/arm/mach-socfpga/pinmux_arria10.c new file mode 100644 index 0000000..04acaa2 --- /dev/null +++ b/arch/arm/mach-socfpga/pinmux_arria10.c @@ -0,0 +1,98 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <fdtdec.h> +#include <asm/arch/pinmux.h> + +static int do_pinctr_pin(const void *blob, int child, const char *node_name) +{ + int len; + fdt_addr_t base_addr; + fdt_size_t size; + const u32 *cell; + u32 offset, value; + + base_addr = fdtdec_get_addr_size(blob, child, "reg", &size); + if (base_addr != FDT_ADDR_T_NONE) { + cell = fdt_getprop(blob, child, "pinctrl-single,pins", + &len); + if (cell != NULL) { + debug("%p %d\n", cell, len); + for (; len > 0; len -= (2*sizeof(u32))) { + offset = fdt32_to_cpu(*cell++); + value = fdt32_to_cpu(*cell++); + debug("<0x%x 0x%x>\n", offset, value); + writel(value, base_addr + offset); + } + return 0; + } + } + return -EFAULT; +} + +static int do_pinctrl_pins(const void *blob, int node, const char *child_name) +{ + int child, len; + const char *node_name; + + child = fdt_first_subnode(blob, node); + + if (child < 0) + return -EINVAL; + + node_name = fdt_get_name(blob, child, &len); + + while (node_name) { + if (!strcmp(child_name, node_name)) + return do_pinctr_pin(blob, child, node_name); + + child = fdt_next_subnode(blob, child); + + if (child < 0) + break; + + node_name = fdt_get_name(blob, child, &len); + } + + return -EFAULT; +} + +int config_dedicated_pins(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + + if (node < 0) + return -EINVAL; + + if (do_pinctrl_pins(blob, node, "dedicated_cfg")) + return -EFAULT; + + if (do_pinctrl_pins(blob, node, "dedicated")) + return -EFAULT; + + return 0; +} + +int config_pins(const void *blob, const char *pin_grp) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + + if (node < 0) + return -EINVAL; + + if (do_pinctrl_pins(blob, node, pin_grp)) + return -EFAULT; + + return 0; +}
- Copyright (C) 2016-2017 Intel Corporation <www.intel.com>
Use [space] instead of [tab] after #ifdef/#define
- int len;
- fdt_addr_t base_addr;
- fdt_size_t size;
- const u32 *cell;
- u32 offset, value;
&len);
if (cell != NULL) {
2 * sizeof(u32) , spacing
What about len == 0 , not used ?
- return -EFAULT;
- int child, len;
- if (child < 0)
return -EINVAL;
if (child < 0)
break;
- return -EFAULT;
- int node;
- if (node < 0)
return -EINVAL;
- if (do_pinctrl_pins(blob, node, "dedicated_cfg"))
return -EFAULT;
- if (do_pinctrl_pins(blob, node, "dedicated"))
return -EFAULT;
- int node;
- if (node < 0)
return -EINVAL;
- if (do_pinctrl_pins(blob, node, pin_grp))
return -EFAULT;
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach- socfpga/Makefile index 9c4617f..68d55e4 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -12,6 +12,7 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \ obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clock_manager_arria10.o \ misc_arria10.o \
pinmux_arria10.o \
reset_manager_arria10.o obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o diff --git a/arch/arm/mach-socfpga/include/mach/pinmux.h b/arch/arm/mach-socfpga/include/mach/pinmux.h new file mode 100644 index 0000000..c5d5dd6 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/pinmux.h @@ -0,0 +1,15 @@ +/*
Okay.
- * Copyright (C) 2016-2017 Intel Corporation <www.intel.com>
- int len;
- fdt_size_t size;
- const u32 *cell;
&size);
single,pins",
&len);
if (cell != NULL) {
Okay.
Will add the checking for len > 0.
if (cell != NULL && len > 0) { }
value);
- return -EFAULT;
Regards Ley Foon
Add compatible strings for Intel Arria 10 SoCFPGA device.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- include/fdtdec.h | 8 ++++++++ lib/fdtdec.c | 8 ++++++++ 2 files changed, 16 insertions(+)
diff --git a/include/fdtdec.h b/include/fdtdec.h index d074478..2134701 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -155,6 +155,14 @@ enum fdt_compat_id { COMPAT_INTEL_BAYTRAIL_FSP_MDP, /* Intel FSP memory-down params */ COMPAT_INTEL_IVYBRIDGE_FSP, /* Intel Ivy Bridge FSP */ COMPAT_SUNXI_NAND, /* SUNXI NAND controller */ + COMPAT_ALTERA_SOCFPGA_CLK, /* SoCFPGA Clock initialization */ + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE, /* SoCFPGA pinctrl-single */ + COMPAT_ALTERA_SOCFPGA_H2F_BRG, /* SoCFPGA hps2fpga bridge */ + COMPAT_ALTERA_SOCFPGA_LWH2F_BRG, /* SoCFPGA lwhps2fpga bridge */ + COMPAT_ALTERA_SOCFPGA_F2H_BRG, /* SoCFPGA fpga2hps bridge */ + COMPAT_ALTERA_SOCFPGA_F2SDR0, /* SoCFPGA fpga2SDRAM0 bridge */ + COMPAT_ALTERA_SOCFPGA_F2SDR1, /* SoCFPGA fpga2SDRAM1 bridge */ + COMPAT_ALTERA_SOCFPGA_F2SDR2, /* SoCFPGA fpga2SDRAM2 bridge */
COMPAT_COUNT, }; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 81f47ef..ebe4a9a 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -66,6 +66,14 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(INTEL_BAYTRAIL_FSP_MDP, "intel,baytrail-fsp-mdp"), COMPAT(INTEL_IVYBRIDGE_FSP, "intel,ivybridge-fsp"), COMPAT(COMPAT_SUNXI_NAND, "allwinner,sun4i-a10-nand"), + COMPAT(ALTERA_SOCFPGA_CLK, "altr,clk-mgr"), + COMPAT(ALTERA_SOCFPGA_PINCTRL_SINGLE, "pinctrl-single"), + COMPAT(ALTERA_SOCFPGA_H2F_BRG, "altr,socfpga-hps2fpga-bridge"), + COMPAT(ALTERA_SOCFPGA_LWH2F_BRG, "altr,socfpga-lwhps2fpga-bridge"), + COMPAT(ALTERA_SOCFPGA_F2H_BRG, "altr,socfpga-fpga2hps-bridge"), + COMPAT(ALTERA_SOCFPGA_F2SDR0, "altr,socfpga-fpga2sdram0-bridge"), + COMPAT(ALTERA_SOCFPGA_F2SDR1, "altr,socfpga-fpga2sdram1-bridge"), + COMPAT(ALTERA_SOCFPGA_F2SDR2, "altr,socfpga-fpga2sdram2-bridge"), };
const char *fdtdec_get_compatible(enum fdt_compat_id id)
Device tree files for Arria 10
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_arria10.dtsi | 859 +++++++++++++++++++++ arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 30 + .../dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi | 479 ++++++++++++ 4 files changed, 1369 insertions(+) create mode 100644 arch/arm/dts/socfpga_arria10.dtsi create mode 100644 arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts create mode 100644 arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index eb68c20..25e08eb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -139,6 +139,7 @@ dtb-$(CONFIG_AM43XX) += am437x-gp-evm.dtb am437x-sk-evm.dtb \ dtb-$(CONFIG_THUNDERX) += thunderx-88xx.dtb
dtb-$(CONFIG_ARCH_SOCFPGA) += \ + socfpga_arria10_socdk_sdmmc.dtb \ socfpga_arria5_socdk.dtb \ socfpga_cyclone5_is1.dtb \ socfpga_cyclone5_mcvevk.dtb \ diff --git a/arch/arm/dts/socfpga_arria10.dtsi b/arch/arm/dts/socfpga_arria10.dtsi new file mode 100644 index 0000000..52ab7fe --- /dev/null +++ b/arch/arm/dts/socfpga_arria10.dtsi @@ -0,0 +1,859 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 X11 + */ + +#include "skeleton.dtsi" +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/altr,rst-mgr-a10.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + + aliases { + ethernet0 = &gmac0; + ethernet1 = &gmac1; + ethernet2 = &gmac2; + serial0 = &uart0; + serial1 = &uart1; + timer0 = &timer0; + timer1 = &timer1; + timer2 = &timer2; + timer3 = &timer3; + spi0 = &spi0; + spi1 = &spi1; + }; + + memory { + name = "memory"; + device_type = "memory"; + reg = <0x0 0x40000000>; /* 1GB */ + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <0>; + next-level-cache = <&L2>; + }; + cpu@1 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <1>; + next-level-cache = <&L2>; + }; + }; + + intc: intc@ffffd000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0xffffd000 0x1000>, + <0xffffc100 0x100>; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + device_type = "soc"; + interrupt-parent = <&intc>; + ranges; + + amba { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + pdma: pdma@ffda1000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xffda1000 0x1000>; + interrupts = <0 83 IRQ_TYPE_LEVEL_HIGH>, + <0 84 IRQ_TYPE_LEVEL_HIGH>, + <0 85 IRQ_TYPE_LEVEL_HIGH>, + <0 86 IRQ_TYPE_LEVEL_HIGH>, + <0 87 IRQ_TYPE_LEVEL_HIGH>, + <0 88 IRQ_TYPE_LEVEL_HIGH>, + <0 89 IRQ_TYPE_LEVEL_HIGH>, + <0 90 IRQ_TYPE_LEVEL_HIGH>, + <0 91 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + #dma-channels = <8>; + #dma-requests = <32>; + clocks = <&l4_main_clk>; + clock-names = "apb_pclk"; + }; + }; + + clkmgr@ffd04000 { + compatible = "altr,clk-mgr"; + reg = <0xffd04000 0x1000>; + reg-names = "soc_clock_manager_OCP_SLV"; + + clocks { + #address-cells = <1>; + #size-cells = <0>; + + cb_intosc_hs_div2_clk: cb_intosc_hs_div2_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + cb_intosc_ls_clk: cb_intosc_ls_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + f2s_free_clk: f2s_free_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + osc1: osc1 { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + main_pll: main_pll { + #address-cells = <1>; + #size-cells = <0>; + #clock-cells = <0>; + compatible = "altr,socfpga-a10-pll-clock"; + clocks = <&osc1>, <&cb_intosc_ls_clk>, + <&f2s_free_clk>; + reg = <0x40>; + + main_mpu_base_clk: main_mpu_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + div-reg = <0x140 0 11>; + }; + + main_noc_base_clk: main_noc_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + div-reg = <0x144 0 11>; + }; + + main_emaca_clk: main_emaca_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x68>; + }; + + main_emacb_clk: main_emacb_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x6C>; + }; + + main_emac_ptp_clk: main_emac_ptp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x70>; + }; + + main_gpio_db_clk: main_gpio_db_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x74>; + }; + + main_sdmmc_clk: main_sdmmc_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x78>; + }; + + main_s2f_usr0_clk: main_s2f_usr0_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x7C>; + }; + + main_s2f_usr1_clk: main_s2f_usr1_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x80>; + }; + + main_hmc_pll_ref_clk: main_hmc_pll_ref_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x84>; + }; + + main_periph_ref_clk: main_periph_ref_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x9C>; + }; + }; + + periph_pll: periph_pll { + #address-cells = <1>; + #size-cells = <0>; + #clock-cells = <0>; + compatible = "altr,socfpga-a10-pll-clock"; + clocks = <&osc1>, <&cb_intosc_ls_clk>, + <&f2s_free_clk>, <&main_periph_ref_clk>; + reg = <0xC0>; + + peri_mpu_base_clk: peri_mpu_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + div-reg = <0x140 16 11>; + }; + + peri_noc_base_clk: peri_noc_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + div-reg = <0x144 16 11>; + }; + + peri_emaca_clk: peri_emaca_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xE8>; + }; + + peri_emacb_clk: peri_emacb_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xEC>; + }; + + peri_emac_ptp_clk: peri_emac_ptp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xF0>; + }; + + peri_gpio_db_clk: peri_gpio_db_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xF4>; + }; + + peri_sdmmc_clk: peri_sdmmc_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xF8>; + }; + + peri_s2f_usr0_clk: peri_s2f_usr0_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xFC>; + }; + + peri_s2f_usr1_clk: peri_s2f_usr1_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0x100>; + }; + + peri_hmc_pll_ref_clk: peri_hmc_pll_ref_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0x104>; + }; + }; + + mpu_free_clk: mpu_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_mpu_base_clk>, <&peri_mpu_base_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + reg = <0x60>; + }; + + noc_free_clk: noc_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_noc_base_clk>, <&peri_noc_base_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + reg = <0x64>; + }; + + s2f_user1_free_clk: s2f_user1_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_s2f_usr1_clk>, <&peri_s2f_usr1_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + reg = <0x104>; + }; + + sdmmc_free_clk: sdmmc_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_sdmmc_clk>, <&peri_sdmmc_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + fixed-divider = <4>; + reg = <0xF8>; + }; + + l4_sys_free_clk: l4_sys_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&noc_free_clk>; + fixed-divider = <4>; + }; + + l4_main_clk: l4_main_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&noc_free_clk>; + div-reg = <0xA8 0 2>; + clk-gate = <0x48 1>; + }; + + l4_mp_clk: l4_mp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&noc_free_clk>; + div-reg = <0xA8 8 2>; + clk-gate = <0x48 2>; + }; + + l4_sp_clk: l4_sp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&noc_free_clk>; + div-reg = <0xA8 16 2>; + clk-gate = <0x48 3>; + }; + + mpu_periph_clk: mpu_periph_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&mpu_free_clk>; + fixed-divider = <4>; + clk-gate = <0x48 0>; + }; + + sdmmc_clk: sdmmc_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&sdmmc_free_clk>; + clk-gate = <0xC8 5>; + clk-phase = <0 135>; + }; + + qspi_clk: qspi_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_main_clk>; + clk-gate = <0xC8 11>; + }; + + nand_clk: nand_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_mp_clk>; + clk-gate = <0xC8 10>; + }; + + spi_m_clk: spi_m_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_main_clk>; + clk-gate = <0xC8 9>; + }; + + usb_clk: usb_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_mp_clk>; + clk-gate = <0xC8 8>; + }; + + s2f_usr1_clk: s2f_usr1_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&peri_s2f_usr1_clk>; + clk-gate = <0xC8 6>; + }; + }; + }; + + gmac0: ethernet@ff800000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.72a", "snps,dwmac"; + altr,sysmgr-syscon = <&sysmgr 0x44 0>; + reg = <0xff800000 0x2000>; + interrupts = <0 92 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + /* Filled in by bootloader */ + mac-address = [00 00 00 00 00 00]; + snps,multicast-filter-bins = <256>; + snps,perfect-filter-entries = <128>; + tx-fifo-depth = <4096>; + rx-fifo-depth = <16384>; + clocks = <&l4_mp_clk>; + clock-names = "stmmaceth"; + resets = <&rst EMAC0_RESET>; + reset-names = "stmmaceth"; + status = "disabled"; + }; + + gmac1: ethernet@ff802000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.72a", "snps,dwmac"; + altr,sysmgr-syscon = <&sysmgr 0x48 0>; + reg = <0xff802000 0x2000>; + interrupts = <0 93 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + /* Filled in by bootloader */ + mac-address = [00 00 00 00 00 00]; + snps,multicast-filter-bins = <256>; + snps,perfect-filter-entries = <128>; + tx-fifo-depth = <4096>; + rx-fifo-depth = <16384>; + clocks = <&l4_mp_clk>; + clock-names = "stmmaceth"; + resets = <&rst EMAC1_RESET>; + reset-names = "stmmaceth"; + status = "disabled"; + }; + + gmac2: ethernet@ff804000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.72a", "snps,dwmac"; + altr,sysmgr-syscon = <&sysmgr 0x4C 0>; + reg = <0xff804000 0x2000>; + interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + /* Filled in by bootloader */ + mac-address = [00 00 00 00 00 00]; + snps,multicast-filter-bins = <256>; + snps,perfect-filter-entries = <128>; + tx-fifo-depth = <4096>; + rx-fifo-depth = <16384>; + clocks = <&l4_mp_clk>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gpio0: gpio@ffc02900 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc02900 0x100>; + status = "disabled"; + + porta: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <29>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 112 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + gpio1: gpio@ffc02a00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc02a00 0x100>; + status = "disabled"; + + portb: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <29>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 113 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + gpio2: gpio@ffc02b00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc02b00 0x100>; + status = "disabled"; + + portc: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <27>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 114 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + fpga_mgr: fpga-mgr@ffd03000 { + compatible = "altr,socfpga-a10-fpga-mgr"; + reg = <0xffd03000 0x100 + 0xffcfe400 0x20>; + clocks = <&l4_mp_clk>; + resets = <&rst FPGAMGR_RESET>; + reset-names = "fpgamgr"; + }; + + i2c0: i2c@ffc02200 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02200 0x100>; + interrupts = <0 105 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c1: i2c@ffc02300 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02300 0x100>; + interrupts = <0 106 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c2: i2c@ffc02400 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02400 0x100>; + interrupts = <0 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c3: i2c@ffc02500 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02500 0x100>; + interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c4: i2c@ffc02600 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02600 0x100>; + interrupts = <0 109 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + sdr: sdr@0xffcfb100 { + compatible = "syscon"; + reg = <0xffcfb100 0x80>; + }; + + spi0: spi@ffda4000 { + compatible = "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xffda4000 0x100>; + interrupts = <0 101 IRQ_TYPE_LEVEL_HIGH>; + num-chipselect = <4>; + bus-num = <0>; + tx-dma-channel = <&pdma 16>; + rx-dma-channel = <&pdma 17>; + clocks = <&spi_m_clk>; + status = "disabled"; + }; + + spi1: spi@ffda5000 { + compatible = "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xffda5000 0x100>; + interrupts = <0 102 IRQ_TYPE_LEVEL_HIGH>; + num-chipselect = <4>; + bus-num = <0>; + tx-dma-channel = <&pdma 20>; + rx-dma-channel = <&pdma 21>; + clocks = <&spi_m_clk>; + status = "disabled"; + }; + + L2: l2-cache@fffff000 { + compatible = "arm,pl310-cache"; + reg = <0xfffff000 0x1000>; + interrupts = <0 18 IRQ_TYPE_LEVEL_HIGH>; + cache-unified; + cache-level = <2>; + }; + + mmc: dwmmc0@ff808000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "altr,socfpga-dw-mshc"; + reg = <0xff808000 0x1000>; + interrupts = <0 98 IRQ_TYPE_LEVEL_HIGH>; + fifo-depth = <0x400>; + bus-width = <4>; + clocks = <&l4_mp_clk>, <&sdmmc_clk>; + clock-names = "biu", "ciu"; + status = "disabled"; + }; + + ocram: sram@ffe00000 { + compatible = "mmio-sram"; + reg = <0xffe00000 0x40000>; + }; + + eccmgr: eccmgr@ffd06000 { + compatible = "altr,socfpga-a10-ecc-manager"; + altr,sysmgr-syscon = <&sysmgr>; + #address-cells = <1>; + #size-cells = <1>; + interrupts = <0 2 IRQ_TYPE_LEVEL_HIGH>, + <0 0 IRQ_TYPE_LEVEL_HIGH>; + interrupt-controller; + #interrupt-cells = <2>; + ranges; + + sdramedac { + compatible = "altr,sdram-edac-a10"; + altr,sdr-syscon = <&sdr>; + interrupts = <17 IRQ_TYPE_LEVEL_HIGH>, + <49 IRQ_TYPE_LEVEL_HIGH>; + }; + + l2-ecc@ffd06010 { + compatible = "altr,socfpga-a10-l2-ecc"; + reg = <0xffd06010 0x4>; + interrupts = <0 IRQ_TYPE_LEVEL_HIGH>, + <32 IRQ_TYPE_LEVEL_HIGH>; + }; + + ocram-ecc@ff8c3000 { + compatible = "altr,socfpga-a10-ocram-ecc"; + reg = <0xff8c3000 0x400>; + interrupts = <1 IRQ_TYPE_LEVEL_HIGH>, + <33 IRQ_TYPE_LEVEL_HIGH>; + }; + + sdmmca-ecc@ff8c2c00 { + compatible = "altr,socfpga-sdmmc-ecc"; + reg = <0xff8c2c00 0x400>; + altr,ecc-parent = <&mmc>; + interrupts = <15 IRQ_TYPE_LEVEL_HIGH>, + <47 IRQ_TYPE_LEVEL_HIGH>, + <16 IRQ_TYPE_LEVEL_HIGH>, + <48 IRQ_TYPE_LEVEL_HIGH>; + }; + + emac0-rx-ecc@ff8c0800 { + compatible = "altr,socfpga-eth-mac-ecc"; + reg = <0xff8c0800 0x400>; + altr,ecc-parent = <&gmac0>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH>, + <36 IRQ_TYPE_LEVEL_HIGH>; + }; + + emac0-tx-ecc@ff8c0c00 { + compatible = "altr,socfpga-eth-mac-ecc"; + reg = <0xff8c0c00 0x400>; + altr,ecc-parent = <&gmac0>; + interrupts = <5 IRQ_TYPE_LEVEL_HIGH>, + <37 IRQ_TYPE_LEVEL_HIGH>; + }; + + dma-ecc@ff8c8000 { + compatible = "altr,socfpga-dma-ecc"; + reg = <0xff8c8000 0x400>; + altr,ecc-parent = <&pdma>; + interrupts = <10 IRQ_TYPE_LEVEL_HIGH>, + <42 IRQ_TYPE_LEVEL_HIGH>; + }; + + usb0-ecc@ff8c8800 { + compatible = "altr,socfpga-usb-ecc"; + reg = <0xff8c8800 0x400>; + altr,ecc-parent = <&usb0>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH>, + <34 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + qspi: qspi@ff809000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "cadence,qspi"; + reg = <0xff809000 0x100>, + <0xffa00000 0x100000>; + interrupts = <0 100 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_main_clk>; + ext-decoder = <0>; /* external decoder */ + num-chipselect = <4>; + fifo-depth = <128>; + sram-size = <512>; + bus-num = <2>; + status = "disabled"; + }; + + rst: rstmgr@ffd05000 { + #reset-cells = <1>; + compatible = "altr,rst-mgr"; + reg = <0xffd05000 0x100>; + altr,modrst-offset = <0x20>; + }; + + scu: snoop-control-unit@ffffc000 { + compatible = "arm,cortex-a9-scu"; + reg = <0xffffc000 0x100>; + }; + + sysmgr: sysmgr@ffd06000 { + compatible = "altr,sys-mgr", "syscon"; + reg = <0xffd06000 0x300>; + cpu1-start-addr = <0xffd06230>; + }; + + /* Local timer */ + timer@ffffc600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0xffffc600 0x100>; + interrupts = <1 13 0xf04>; + clocks = <&mpu_periph_clk>; + }; + + timer0: timer0@ffc02700 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 115 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffc02700 0x100>; + clocks = <&l4_sp_clk>; + clock-names = "timer"; + }; + + timer1: timer1@ffc02800 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 116 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffc02800 0x100>; + clocks = <&l4_sp_clk>; + clock-names = "timer"; + }; + + timer2: timer2@ffd00000 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 117 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffd00000 0x100>; + clocks = <&l4_sys_free_clk>; + clock-names = "timer"; + }; + + timer3: timer3@ffd00100 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 118 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffd01000 0x100>; + clocks = <&l4_sys_free_clk>; + clock-names = "timer"; + }; + + uart0: serial0@ffc02000 { + compatible = "snps,dw-apb-uart"; + reg = <0xffc02000 0x100>; + interrupts = <0 110 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + uart1: serial1@ffc02100 { + compatible = "snps,dw-apb-uart"; + reg = <0xffc02100 0x100>; + interrupts = <0 111 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + usbphy0: usbphy@0 { + #phy-cells = <0>; + compatible = "usb-nop-xceiv"; + status = "okay"; + }; + + usb0: usb@ffb00000 { + compatible = "snps,dwc2"; + reg = <0xffb00000 0xffff>; + interrupts = <0 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&usb_clk>; + clock-names = "otg"; + resets = <&rst USB0_RESET>; + reset-names = "dwc2"; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + + usb1: usb@ffb40000 { + compatible = "snps,dwc2"; + reg = <0xffb40000 0xffff>; + interrupts = <0 96 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&usb_clk>; + clock-names = "otg"; + resets = <&rst USB1_RESET>; + reset-names = "dwc2"; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + + watchdog0: watchdog@ffd00200 { + compatible = "snps,dw-wdt"; + reg = <0xffd00200 0x100>; + interrupts = <0 119 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sys_free_clk>; + status = "disabled"; + }; + + watchdog1: watchdog@ffd00300 { + compatible = "snps,dw-wdt"; + reg = <0xffd00300 0x100>; + interrupts = <0 120 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sys_free_clk>; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts new file mode 100644 index 0000000..a4215ee --- /dev/null +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts @@ -0,0 +1,30 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 X11 + */ + +/dts-v1/; +#include "socfpga_arria10_socdk_sdmmc_handoff.dtsi" + +/ { + chosen { + bootargs = "console=ttyS0,115200"; + }; +}; + +&uart1 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&mmc { + u-boot,dm-pre-reloc; + status = "okay"; + num-slots = <1>; + cap-sd-highspeed; + broken-cd; + bus-width = <4>; + altr,dw-mshc-ciu-div = <3>; + altr,dw-mshc-sdr-timing = <0 3>; +}; diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi b/arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi new file mode 100644 index 0000000..e530f80 --- /dev/null +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi @@ -0,0 +1,479 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 X11 + * + *<auto-generated> + * This code was generated by a tool based on + * handoffs from both Qsys and Quartus. + * + * Changes to this file may be lost if + * the code is regenerated. + *</auto-generated> + */ + +#include "socfpga_arria10.dtsi" + +/ { + model = "Altera SOCFPGA Arria 10"; + compatible = "altr,socfpga-arria10", "altr,socfpga"; + + chosen { + /* Bootloader setting: uboot.rbf_filename */ + cff-file = "ghrd_10as066n2.periph.rbf"; + early-release-fpga-config; + }; + + soc { + u-boot,dm-pre-reloc; + clkmgr@ffd04000 { + u-boot,dm-pre-reloc; + clocks { + u-boot,dm-pre-reloc; + osc1 { + u-boot,dm-pre-reloc; + clock-frequency = <25000000>; + clock-output-names = "altera_arria10_hps_eosc1-clk"; + }; + + cb_intosc_ls_clk { + u-boot,dm-pre-reloc; + clock-frequency = <60000000>; + clock-output-names = "altera_arria10_hps_cb_intosc_ls-clk"; + }; + + f2s_free_clk { + u-boot,dm-pre-reloc; + clock-frequency = <200000000>; + clock-output-names = "altera_arria10_hps_f2h_free-clk"; + }; + + main_pll { + u-boot,dm-pre-reloc; + /* + * Address Block: soc_clock_manager_OCP_SLV. + * i_clk_mgr_mainpllgrp + */ + altr,of_reg_value = < + 0 /* Field: vco0.psrc */ + 1 /* Field: vco1.denom */ + 191 /* Field: vco1.numer */ + 0 /* Field: mpuclk */ + 0 /* Field: mpuclk.cnt */ + 0 /* Field: mpuclk.src */ + 0 /* Field: nocclk */ + 0 /* Field: nocclk.cnt */ + 0 /* Field: nocclk.src */ + 900 /* Field: cntr2clk.cnt */ + 900 /* Field: cntr3clk.cnt */ + 900 /* Field: cntr4clk.cnt */ + 900 /* Field: cntr5clk.cnt */ + 900 /* Field: cntr6clk.cnt */ + 900 /* Field: cntr7clk.cnt */ + 0 /* Field: cntr7clk.src */ + 900 /* Field: cntr8clk.cnt */ + 900 /* Field: cntr9clk.cnt */ + 0 /* Field: cntr9clk.src */ + 900 /* Field: cntr15clk.cnt */ + 0 /* Field: nocdiv.l4mainclk */ + 0 /* Field: nocdiv.l4mpclk */ + 2 /* Field: nocdiv.l4spclk */ + 0 /* Field: nocdiv.csatclk */ + 1 /* Field: nocdiv.cstraceclk */ + 1 /* Field: nocdiv.cspdbgclk */ + >; + }; + + periph_pll { + u-boot,dm-pre-reloc; + /* + * Address Block: soc_clock_manager_OCP_SLV. + * i_clk_mgr_perpllgrp + */ + altr,of_reg_value = < + 0 /* Field: vco0.psrc */ + 1 /* Field: vco1.denom */ + 159 /* Field: vco1.numer */ + 7 /* Field: cntr2clk.cnt */ + 1 /* Field: cntr2clk.src */ + 900 /* Field: cntr3clk.cnt */ + 1 /* Field: cntr3clk.src */ + 19 /* Field: cntr4clk.cnt */ + 1 /* Field: cntr4clk.src */ + 499 /* Field: cntr5clk.cnt */ + 1 /* Field: cntr5clk.src */ + 9 /* Field: cntr6clk.cnt */ + 1 /* Field: cntr6clk.src */ + 900 /* Field: cntr7clk.cnt */ + 900 /* Field: cntr8clk.cnt */ + 0 /* Field: cntr8clk.src */ + 900 /* Field: cntr9clk.cnt */ + 0 /* Field: emacctl.emac0sel */ + 0 /* Field: emacctl.emac1sel */ + 0 /* Field: emacctl.emac2sel */ + 32000 /* Field: gpiodiv.gpiodbclk */ + >; + }; + + altera { + u-boot,dm-pre-reloc; + /* + * Address Block: soc_clock_manager_OCP_SLV. + * i_clk_mgr_alteragrp + */ + altr,of_reg_value = < + 0x0384000b /* Register: nocclk */ + 0x03840001 /* Register: mpuclk */ + >; + }; + }; + }; + + /* + * Driver: altera_arria10_soc_3v_io48_pin_mux_arria10_uboot_driver + * Binding: pinmux + */ + i_io48_pin_mux: pinmux@0xffd07000 { + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + compatible = "pinctrl-single"; + reg = <0xffd07000 0x00000800>; + reg-names = "soc_3v_io48_pin_mux_OCP_SLV"; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_shared_3v_io_grp + */ + shared { + u-boot,dm-pre-reloc; + reg = <0xffd07000 0x00000200>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000f>; + pinctrl-single,pins = + /* Reg: pinmux_shared_io_q1_1 */ + <0x00000000 0x00000008>, + /* Reg: pinmux_shared_io_q1_2 */ + <0x00000004 0x00000008>, + /* Reg: pinmux_shared_io_q1_3 */ + <0x00000008 0x00000008>, + /* Reg: pinmux_shared_io_q1_4 */ + <0x0000000c 0x00000008>, + /* Reg: pinmux_shared_io_q1_5 */ + <0x00000010 0x00000008>, + /* Reg: pinmux_shared_io_q1_6 */ + <0x00000014 0x00000008>, + /* Reg: pinmux_shared_io_q1_7 */ + <0x00000018 0x00000008>, + /* Reg: pinmux_shared_io_q1_8 */ + <0x0000001c 0x00000008>, + /* Reg: pinmux_shared_io_q1_9 */ + <0x00000020 0x00000008>, + /* Reg: pinmux_shared_io_q1_10 */ + <0x00000024 0x00000008>, + /* Reg: pinmux_shared_io_q1_11 */ + <0x00000028 0x00000008>, + /* Reg: pinmux_shared_io_q1_12 */ + <0x0000002c 0x00000008>, + /* Reg: pinmux_shared_io_q2_1 */ + <0x00000030 0x00000004>, + /* Reg: pinmux_shared_io_q2_2 */ + <0x00000034 0x00000004>, + /* Reg: pinmux_shared_io_q2_3 */ + <0x00000038 0x00000004>, + /* Reg: pinmux_shared_io_q2_4 */ + <0x0000003c 0x00000004>, + /* Reg: pinmux_shared_io_q2_5 */ + <0x00000040 0x00000004>, + /* Reg: pinmux_shared_io_q2_6 */ + <0x00000044 0x00000004>, + /* Reg: pinmux_shared_io_q2_7 */ + <0x00000048 0x00000004>, + /* Reg: pinmux_shared_io_q2_8 */ + <0x0000004c 0x00000004>, + /* Reg: pinmux_shared_io_q2_9 */ + <0x00000050 0x00000004>, + /* Reg: pinmux_shared_io_q2_10 */ + <0x00000054 0x00000004>, + /* Reg: pinmux_shared_io_q2_11 */ + <0x00000058 0x00000004>, + /* Reg: pinmux_shared_io_q2_12 */ + <0x0000005c 0x00000004>, + /* Reg: pinmux_shared_io_q3_1 */ + <0x00000060 0x00000003>, + /* Reg: pinmux_shared_io_q3_2 */ + <0x00000064 0x00000003>, + /* Reg: pinmux_shared_io_q3_3 */ + <0x00000068 0x00000003>, + /* Reg: pinmux_shared_io_q3_4 */ + <0x0000006c 0x00000003>, + /* Reg: pinmux_shared_io_q3_5 */ + <0x00000070 0x00000003>, + /* Reg: pinmux_shared_io_q3_6 */ + <0x00000074 0x0000000f>, + /* Reg: pinmux_shared_io_q3_7 */ + <0x00000078 0x0000000a>, + /* Reg: pinmux_shared_io_q3_8 */ + <0x0000007c 0x0000000a>, + /* Reg: pinmux_shared_io_q3_9 */ + <0x00000080 0x0000000a>, + /* Reg: pinmux_shared_io_q3_10 */ + <0x00000084 0x0000000a>, + /* Reg: pinmux_shared_io_q3_11 */ + <0x00000088 0x00000001>, + /* Reg: pinmux_shared_io_q3_12 */ + <0x0000008c 0x00000001>, + /* Reg: pinmux_shared_io_q4_1 */ + <0x00000090 0x00000000>, + /* Reg: pinmux_shared_io_q4_2 */ + <0x00000094 0x00000000>, + /* Reg: pinmux_shared_io_q4_3 */ + <0x00000098 0x0000000f>, + /* Reg: pinmux_shared_io_q4_4 */ + <0x0000009c 0x0000000c>, + /* Reg: pinmux_shared_io_q4_5 */ + <0x000000a0 0x0000000f>, + /* Reg: pinmux_shared_io_q4_6 */ + <0x000000a4 0x0000000f>, + /* Reg: pinmux_shared_io_q4_7 */ + <0x000000a8 0x0000000a>, + /* Reg: pinmux_shared_io_q4_8 */ + <0x000000ac 0x0000000a>, + /* Reg: pinmux_shared_io_q4_9 */ + <0x000000b0 0x0000000c>, + /* Reg: pinmux_shared_io_q4_10 */ + <0x000000b4 0x0000000c>, + /* Reg: pinmux_shared_io_q4_11 */ + <0x000000b8 0x0000000c>, + /* Reg: pinmux_shared_io_q4_12 */ + <0x000000bc 0x0000000c>; + }; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_dedicated_io_grp + */ + dedicated { + u-boot,dm-pre-reloc; + reg = <0xffd07200 0x00000200>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000f>; + pinctrl-single,pins = + /* Reg: pinmux_dedicated_io_4 */ + <0x0000000c 0x00000008>, + /* Reg: pinmux_dedicated_io_5 */ + <0x00000010 0x00000008>, + /* Reg: pinmux_dedicated_io_6 */ + <0x00000014 0x00000008>, + /* Regi: pinmux_dedicated_io_7 */ + <0x00000018 0x00000008>, + /* Reg: pinmux_dedicated_io_8 */ + <0x0000001c 0x00000008>, + /* Reg: pinmux_dedicated_io_9 */ + <0x00000020 0x00000008>, + /* Reg: pinmux_dedicated_io_10 */ + <0x00000024 0x0000000a>, + /* Reg: pinmux_dedicated_io_11 */ + <0x00000028 0x0000000a>, + /* Reg: pinmux_dedicated_io_12 */ + <0x0000002c 0x00000008>, + /* Reg: pinmux_dedicated_io_13 */ + <0x00000030 0x00000008>, + /* Reg: pinmux_dedicated_io_14 */ + <0x00000034 0x00000008>, + /* Reg: pinmux_dedicated_io_15 */ + <0x00000038 0x00000008>, + /* Reg: pinmux_dedicated_io_16 */ + <0x0000003c 0x0000000d>, + /* Reg: pinmux_dedicated_io_17 */ + <0x00000040 0x0000000d>; + }; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_dedicated_io_grp + */ + dedicated_cfg { + u-boot,dm-pre-reloc; + reg = <0xffd07200 0x00000200>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x003f3f3f>; + pinctrl-single,pins = + /* Reg: cfg_dedicated_io_bank */ + <0x00000100 0x00000101>, + /* Reg: cfg_dedicated_io_1 */ + <0x00000104 0x000b080a>, + /* Reg: cfg_dedicated_io_2 */ + <0x00000108 0x000b080a>, + /* Reg: cfg_dedicated_io_3 */ + <0x0000010c 0x000b080a>, + /* Reg: cfg_dedicated_io_4 */ + <0x00000110 0x000a282a>, + /* Reg: cfg_dedicated_io_5 */ + <0x00000114 0x000a282a>, + /* Reg: cfg_dedicated_io_6 */ + <0x00000118 0x0008282a>, + /* Reg: cfg_dedicated_io_7 */ + <0x0000011c 0x000a282a>, + /* Reg: cfg_dedicated_io_8 */ + <0x00000120 0x000a282a>, + /* Reg: cfg_dedicated_io_9 */ + <0x00000124 0x000a282a>, + /* Reg: cfg_dedicated_io_10 */ + <0x00000128 0x00090000>, + /* Reg: cfg_dedicated_io_11 */ + <0x0000012c 0x00090000>, + /* Reg: cfg_dedicated_io_12 */ + <0x00000130 0x000b282a>, + /* Reg: cfg_dedicated_io_13 */ + <0x00000134 0x000b282a>, + /* Reg: cfg_dedicated_io_14 */ + <0x00000138 0x000b282a>, + /* Reg: cfg_dedicated_io_15 */ + <0x0000013c 0x000b282a>, + /* Reg: cfg_dedicated_io_16 */ + <0x00000140 0x0008282a>, + /* Reg: cfg_dedicated_io_17 */ + <0x00000144 0x000a282a>; + }; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_fpga_interface_grp + */ + fpga { + u-boot,dm-pre-reloc; + reg = <0xffd07400 0x00000100>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x00000001>; + pinctrl-single,pins = + /* Reg: pinmux_emac0_usefpga */ + <0x00000000 0x00000000>, + /* Reg: pinmux_emac1_usefpga */ + <0x00000004 0x00000000>, + /* Reg: pinmux_emac2_usefpga */ + <0x00000008 0x00000000>, + /* Reg: pinmux_i2c0_usefpga */ + <0x0000000c 0x00000000>, + /* Reg: pinmux_i2c1_usefpga */ + <0x00000010 0x00000000>, + /* Reg: pinmux_i2c_emac0_usefpga */ + <0x00000014 0x00000000>, + /* Reg: pinmux_i2c_emac1_usefpga */ + <0x00000018 0x00000000>, + /* Reg: pinmux_i2c_emac2_usefpga */ + <0x0000001c 0x00000000>, + /* Reg: pinmux_nand_usefpga */ + <0x00000020 0x00000000>, + /* Reg: pinmux_qspi_usefpga */ + <0x00000024 0x00000000>, + /* Reg: pinmux_sdmmc_usefpga */ + <0x00000028 0x00000000>, + /* Reg: pinmux_spim0_usefpga */ + <0x0000002c 0x00000000>, + /* Reg: pinmux_spim1_usefpga */ + <0x00000030 0x00000000>, + /* Reg: pinmux_spis0_usefpga */ + <0x00000034 0x00000000>, + /* Reg: pinmux_spis1_usefpga */ + <0x00000038 0x00000000>, + /* Reg: pinmux_uart0_usefpga */ + <0x0000003c 0x00000000>, + /* Reg: pinmux_uart1_usefpga */ + <0x00000040 0x00000000>; + }; + }; + + i_noc: noc@0xffd10000 { + compatible = "altr,socfpga-a10-noc"; + reg = <0xffd10000 0x00008000>; + reg-names = "mpu_m0"; + + firewall { + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * mpuregion0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * mpuregion0addr.limit + */ + altr,mpu0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0.noc_fw_ddr_l3_ddr_scr. + * hpsregion0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0.noc_fw_ddr_l3_ddr_scr. + * hpsregion0addr.limit + */ + altr,l3-0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram0region0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram0region0addr.limit + */ + altr,fpga2sdram0-0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram1region0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram1region0addr.limit + */ + altr,fpga2sdram1-0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram2region0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram2region0addr.limit + */ + altr,fpga2sdram2-0 = <0x00000000 0x0000ffff>; + }; + }; + + hps_fpgabridge0: fpgabridge@0 { + compatible = "altr,socfpga-hps2fpga-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge1: fpgabridge@1 { + compatible = "altr,socfpga-lwhps2fpga-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge2: fpgabridge@2 { + compatible = "altr,socfpga-fpga2hps-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge3: fpgabridge@3 { + compatible = "altr,socfpga-fpga2sdram0-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge4: fpgabridge@4 { + compatible = "altr,socfpga-fpga2sdram1-bridge"; + altr,init-val = <0>; + }; + + hps_fpgabridge5: fpgabridge@5 { + compatible = "altr,socfpga-fpga2sdram2-bridge"; + altr,init-val = <1>; + }; + }; +};
Add SPL support for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/spl.c | 92 ++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 90 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach-socfpga/spl.c index fec4c7a..1299e67 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl.c @@ -19,37 +19,55 @@ #include <asm/arch/sdram.h> #include <asm/arch/scu.h> #include <asm/arch/nic301.h> +#include <asm/sections.h> +#include <watchdog.h> +#include <fdtdec.h> +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/pinmux.h> +#endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#define BOOTINFO_BSEL_SHIFT 0 static struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define BOOTINFO_BSEL_SHIFT 12 +#endif + +static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
u32 spl_boot_device(void) { const u32 bsel = readl(&sysmgr_regs->bootinfo);
- switch (bsel & 0x7) { + switch ((bsel >> BOOTINFO_BSEL_SHIFT) & 0x7) { case 0x1: /* FPGA (HPS2FPGA Bridge) */ return BOOT_DEVICE_RAM; case 0x2: /* NAND Flash (1.8V) */ case 0x3: /* NAND Flash (3.0V) */ +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) socfpga_per_reset(SOCFPGA_RESET(NAND), 0); +#endif return BOOT_DEVICE_NAND; case 0x4: /* SD/MMC External Transceiver (1.8V) */ case 0x5: /* SD/MMC Internal Transceiver (3.0V) */ +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) socfpga_per_reset(SOCFPGA_RESET(SDMMC), 0); socfpga_per_reset(SOCFPGA_RESET(DMA), 0); +#endif return BOOT_DEVICE_MMC1; case 0x6: /* QSPI Flash (1.8V) */ case 0x7: /* QSPI Flash (3.0V) */ +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) socfpga_per_reset(SOCFPGA_RESET(QSPI), 0); +#endif return BOOT_DEVICE_SPI; default: printf("Invalid boot device (bsel=%08x)!\n", bsel); @@ -68,6 +86,7 @@ u32 spl_boot_mode(const u32 boot_device) } #endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static void socfpga_nic301_slave_ns(void) { writel(0x1, &nic301_regs->lwhps2fpgaregs); @@ -182,3 +201,72 @@ void board_init_f(ulong dummy) /* Configure simple malloc base pointer into RAM. */ gd->malloc_base = CONFIG_SYS_TEXT_BASE + (1024 * 1024); } +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#ifdef CONFIG_SPL_BOARD_INIT +void spl_board_init(void) +{ + /* configuring the clock based on handoff */ + cm_basic_init(gd->fdt_blob); + WATCHDOG_RESET(); + + config_dedicated_pins(gd->fdt_blob); + WATCHDOG_RESET(); + + /* Release UART from reset */ + reset_deassert_uart(); + + /* enable console uart printing */ + preloader_console_init(); +} +#endif + +void board_init_f(ulong dummy) +{ + memset(__bss_start, 0, __bss_end - __bss_start); + /* + * Configure Clock Manager to use intosc clock instead external osc to + * ensure success watchdog operation. We do it as early as possible. + */ + cm_use_intosc(); + + watchdog_disable(); + + arch_early_init_r(); + +#ifdef CONFIG_HW_WATCHDOG + /* release osc1 watchdog timer 0 from reset */ + reset_deassert_osc1wd0(); + + /* reconfigure and enable the watchdog */ + hw_watchdog_init(); + WATCHDOG_RESET(); +#endif /* CONFIG_HW_WATCHDOG */ + +#ifdef CONFIG_OF_CONTROL + /* We need to access to FDT as this stage */ + /* FDT is at end of image */ + gd->fdt_blob = (void *)(__bss_end); + /* Check whether we have a valid FDT or not. */ + if (fdtdec_prepare_fdt()) { + panic("** CONFIG_OF_CONTROL defined but no FDT - please see " + "doc/README.fdt-control"); + } +#endif /* CONFIG_OF_CONTROL */ + + /* Initialize the timer */ + timer_init(); + + /* configuring the clock based on handoff */ + cm_basic_init(gd->fdt_blob); + WATCHDOG_RESET(); + + config_dedicated_pins(gd->fdt_blob); + WATCHDOG_RESET(); + + /* Release UART from reset */ + reset_deassert_uart(); + + /* enable console uart printing */ + preloader_console_init(); +} +#endif
Wasn't this defined in the misc support patch already ?
- switch ((bsel >> BOOTINFO_BSEL_SHIFT) & 0x7) { case 0x1: /* FPGA (HPS2FPGA Bridge) */ return BOOT_DEVICE_RAM; case 0x2: /* NAND Flash (1.8V) */ case 0x3: /* NAND Flash (3.0V) */
This looks awful, you might want to split this function into A10-specific and Gen5 specific one(s) .
- /* configuring the clock based on handoff */
- cm_basic_init(gd->fdt_blob);
- WATCHDOG_RESET();
- config_dedicated_pins(gd->fdt_blob);
- WATCHDOG_RESET();
- /* Release UART from reset */
- reset_deassert_uart();
- /* enable console uart printing */
- preloader_console_init();
+} +#endif
- memset(__bss_start, 0, __bss_end - __bss_start);
Is this really needed ? Should be done by common code already ...
- cm_use_intosc();
- watchdog_disable();
- arch_early_init_r();
- /* release osc1 watchdog timer 0 from reset */
- reset_deassert_osc1wd0();
- /* reconfigure and enable the watchdog */
- hw_watchdog_init();
- WATCHDOG_RESET();
- /* We need to access to FDT as this stage */
- /* FDT is at end of image */
- gd->fdt_blob = (void *)(__bss_end);
This looks like common code too ?
- /* Check whether we have a valid FDT or not. */
- if (fdtdec_prepare_fdt()) {
- /* Initialize the timer */
- timer_init();
- WATCHDOG_RESET();
- WATCHDOG_RESET();
+} +#endif
diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach- socfpga/spl.c index fec4c7a..1299e67 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl.c @@ -19,37 +19,55 @@ #include <asm/arch/sdram.h> #include <asm/arch/scu.h> #include <asm/arch/nic301.h> +#include <asm/sections.h> +#include <watchdog.h> +#include <fdtdec.h> +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/pinmux.h> +#endif DECLARE_GLOBAL_DATA_PTR; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#define BOOTINFO_BSEL_SHIFT 0
+static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; u32 spl_boot_device(void) { const u32 bsel = readl(&sysmgr_regs->bootinfo);
#if defined(CONFIG_TARGET_SOCFPGA_GEN5) can be removed, Arria10 would use the same implementation as gen5.
return BOOT_DEVICE_SPI; default: printf("Invalid boot device (bsel=%08x)!\n", bsel); @@ -68,6 +86,7 @@ u32 spl_boot_mode(const u32 boot_device) } #endif +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static void socfpga_nic301_slave_ns(void) { writel(0x1, &nic301_regs->lwhps2fpgaregs); @@ -182,3 +201,72 @@ void board_init_f(ulong dummy) /* Configure simple malloc base pointer into RAM. */ gd->malloc_base = CONFIG_SYS_TEXT_BASE + (1024 * 1024); } +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#ifdef CONFIG_SPL_BOARD_INIT +void spl_board_init(void) +{
- WATCHDOG_RESET();
- WATCHDOG_RESET();
+} +#endif
- * Configure Clock Manager to use intosc clock instead
external osc to
- * ensure success watchdog operation. We do it as early as
possible.
- cm_use_intosc();
- WATCHDOG_RESET();
please see "
- timer_init();
- WATCHDOG_RESET();
- WATCHDOG_RESET();
+} +#endif
Good catch, will remove this.
Yes, will remove GEN5 switch here.
- WATCHDOG_RESET();
- WATCHDOG_RESET();
+} +#endif
Yes, common code will do memset after this function. Remove memset here.
external osc to
possible.
- cm_use_intosc();
- WATCHDOG_RESET();
Yes, will remove this.
please see "
- timer_init();
- WATCHDOG_RESET();
- WATCHDOG_RESET();
+} +#endif
Arria 10 SPL needs the drivers/fpga.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- drivers/Makefile | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/Makefile b/drivers/Makefile index 34c55bf..6e7a2c3 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -47,6 +47,7 @@ obj-$(CONFIG_OMAP_USB_PHY) += usb/phy/ obj-$(CONFIG_SPL_SATA_SUPPORT) += block/ obj-$(CONFIG_SPL_USB_HOST_SUPPORT) += block/ obj-$(CONFIG_SPL_MMC_SUPPORT) += block/ +obj-$(CONFIG_FPGA) += fpga/ endif
ifdef CONFIG_TPL_BUILD
+CC Michal and Moritz, they did some FPGA/SPL work too.
I prefer if you can separate these fpga stuff out of this huge series. This patch doesn't make sense without content.
I can't see that code which requires this. The biggest questions here are where are you calling fpga code and where are you taking bitstream from?
Thanks, Michal
diff --git a/drivers/Makefile b/drivers/Makefile index 34c55bf..6e7a2c3 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -47,6 +47,7 @@ obj-$(CONFIG_OMAP_USB_PHY) += usb/phy/ obj-$(CONFIG_SPL_SATA_SUPPORT) += block/ obj-$(CONFIG_SPL_USB_HOST_SUPPORT) += block/ obj-$(CONFIG_SPL_MMC_SUPPORT) += block/ +obj-$(CONFIG_FPGA) += fpga/ endif ifdef CONFIG_TPL_BUILD
Thanks, Michal
Okay, will drop this patch from this series.
Thanks.
Regards Ley Foon
These registers only available for Gen5 device, excludes them if for Arria 10 build.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- drivers/fpga/socfpga.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index f1b2f2c..3751574 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -19,8 +19,10 @@ DECLARE_GLOBAL_DATA_PTR;
static struct socfpga_fpga_manager *fpgamgr_regs = (struct socfpga_fpga_manager *)SOCFPGA_FPGAMGRREGS_ADDRESS; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; +#endif
/* Set CD ratio */ static void fpgamgr_set_cd_ratio(unsigned long ratio) @@ -268,8 +270,10 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size)
/* Prior programming the FPGA, all bridges need to be shut off */
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* Disable all signals from hps peripheral controller to fpga */ writel(0, &sysmgr_regs->fpgaintfgrp_module); +#endif
/* Disable all signals from FPGA to HPS SDRAM */ #define SDR_CTRLGRP_FPGAPORTRST_ADDRESS 0x5080 @@ -278,8 +282,10 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) /* Disable all axi bridge (hps2fpga, lwhps2fpga & fpga2hps) */ socfpga_bridges_reset(1);
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* Unmap the bridges from NIC-301 */ writel(0x1, SOCFPGA_L3REGS_ADDRESS); +#endif
/* Initialize the FPGA Manager */ status = fpgamgr_program_init();
Convert Altera ddr driver to use Kconfig method. Enable ALTERA_SDRAM by default it is on Gen5 target. Arria 10 will have different driver.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- drivers/Kconfig | 2 ++ drivers/ddr/Kconfig | 1 + drivers/ddr/altera/Kconfig | 6 ++++++ include/configs/socfpga_common.h | 5 ----- 4 files changed, 9 insertions(+), 5 deletions(-) create mode 100644 drivers/ddr/Kconfig create mode 100644 drivers/ddr/altera/Kconfig
diff --git a/drivers/Kconfig b/drivers/Kconfig index 0e5d97d..3e6bbac 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -14,6 +14,8 @@ source "drivers/cpu/Kconfig"
source "drivers/crypto/Kconfig"
+source "drivers/ddr/Kconfig" + source "drivers/demo/Kconfig"
source "drivers/ddr/fsl/Kconfig" diff --git a/drivers/ddr/Kconfig b/drivers/ddr/Kconfig new file mode 100644 index 0000000..b764add --- /dev/null +++ b/drivers/ddr/Kconfig @@ -0,0 +1 @@ +source "drivers/ddr/altera/Kconfig" diff --git a/drivers/ddr/altera/Kconfig b/drivers/ddr/altera/Kconfig new file mode 100644 index 0000000..9554da7 --- /dev/null +++ b/drivers/ddr/altera/Kconfig @@ -0,0 +1,6 @@ +config ALTERA_SDRAM + bool "SoCFPGA SDRAM for Arria5/Cyclone5 devices" + default y if TARGET_SOCFPGA_GEN5 + help + This is for building the SDRAM controller for the Arria5/Cyclone5 + devices. diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 55e0bf9..bc92a2c 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -77,11 +77,6 @@ #define CONFIG_SYS_PL310_BASE SOCFPGA_MPUL2_ADDRESS
/* - * SDRAM controller - */ -#define CONFIG_ALTERA_SDRAM - -/* * EPCS/EPCQx1 Serial Flash Controller */ #ifdef CONFIG_ALTERA_SPI
Add config and defconfig for the Arria10 and update socfpga_common.h.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- configs/socfpga_arria10_defconfig | 30 +++++++++++++++ include/configs/socfpga_arria10_socdk.h | 67 +++++++++++++++++++++++++++++++++ include/configs/socfpga_common.h | 25 ++++++++++-- 3 files changed, 119 insertions(+), 3 deletions(-) create mode 100644 configs/socfpga_arria10_defconfig create mode 100644 include/configs/socfpga_arria10_socdk.h
diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig new file mode 100644 index 0000000..9e6bc1e0 --- /dev/null +++ b/configs/socfpga_arria10_defconfig @@ -0,0 +1,30 @@ +CONFIG_ARM=y +CONFIG_ARCH_SOCFPGA=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_SOCFPGA_ARRIA10_SOCDK=y +CONFIG_IDENT_STRING="socfpga_arria10" +CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria10_socdk_sdmmc" +CONFIG_DEFAULT_FDT_FILE="socfpga_arria10_socdk_sdmmc.dtb" +CONFIG_SPL=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_DOS_PARTITION=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_GPIO=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_MMC=y +CONFIG_SYS_NS16550=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE=0xa2 diff --git a/include/configs/socfpga_arria10_socdk.h b/include/configs/socfpga_arria10_socdk.h new file mode 100644 index 0000000..5b7d572 --- /dev/null +++ b/include/configs/socfpga_arria10_socdk.h @@ -0,0 +1,67 @@ +/* + * Copyright (C) 2015-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIG_SOCFGPA_ARRIA10_H__ +#define __CONFIG_SOCFGPA_ARRIA10_H__ + +#include <asm/arch/base_addr_a10.h> +/* U-Boot Commands */ +#define CONFIG_FAT_WRITE +#define CONFIG_HW_WATCHDOG + + +/* Booting Linux */ +#define CONFIG_LOADADDR 0x01000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * U-Boot general configurations + */ +/* Cache options */ +#define CONFIG_SYS_DCACHE_OFF + +/* Memory configurations */ +#define PHYS_SDRAM_1_SIZE 0x80000000 + +/* Ethernet on SoC (EMAC) */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9031 +#endif + +/* + * U-Boot environment configurations + */ +#define CONFIG_ENV_IS_IN_MMC + +/* + * arguments passed to the bootz command. The value of + * CONFIG_BOOTARGS goes into the environment value "bootargs". + * Do note the value will overide also the chosen node in FDT blob. + */ +#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) + +/* + * Serial / UART configurations + */ +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, 115200} + +/* + * L4 OSC1 Timer 0 + */ +/* reload value when timer count to zero */ +#define TIMER_LOAD_VAL 0xFFFFFFFF + +/* + * Flash configurations + */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 + +/* The rest of the configuration is shared */ +#include <configs/socfpga_common.h> + +#endif /* __CONFIG_SOCFGPA_ARRIA10_H__ */ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index bc92a2c..d7eedc2 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -34,9 +34,13 @@ #define CONFIG_SYS_MALLOC_LEN (64 * 1024 * 1024) #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 #define CONFIG_SYS_MEMTEST_END PHYS_SDRAM_1_SIZE - +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define CONFIG_SYS_INIT_RAM_ADDR 0xFFFF0000 #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CONFIG_SYS_INIT_RAM_ADDR 0xFFE00000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x40000 /* 256KB */ +#endif #define CONFIG_SYS_INIT_SP_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR \ @@ -67,8 +71,10 @@ #define CONFIG_SYS_HOSTNAME CONFIG_SYS_BOARD #endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define CONFIG_CMD_PXE #define CONFIG_MENU +#endif
/* * Cache @@ -209,11 +215,14 @@ unsigned int cm_get_qspi_controller_clk_hz(void); */ #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE -4 -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS #ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET #define CONFIG_SYS_NS16550_CLK 1000000 -#else +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) +#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS #define CONFIG_SYS_NS16550_CLK 100000000 +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART1_ADDRESS +#define CONFIG_SYS_NS16550_CLK 50000000 #endif #define CONFIG_CONS_INDEX 1 #define CONFIG_BAUDRATE 115200 @@ -301,7 +310,12 @@ unsigned int cm_get_qspi_controller_clk_hz(void); */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE CONFIG_SYS_INIT_RAM_ADDR +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define CONFIG_SPL_MAX_SIZE (64 * 1024) +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE +#define CONFIG_SPL_BOARD_INIT +#endif
/* SPL SDMMC boot support */ #ifdef CONFIG_SPL_MMC_SUPPORT @@ -349,10 +363,15 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define BOOT_TARGET_DEVICES_MMC(func) #endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define BOOT_TARGET_DEVICES(func) \ BOOT_TARGET_DEVICES_MMC(func) \ BOOT_TARGET_DEVICES_PXE(func) \ func(DHCP, dhcp, na) +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_MMC(func) +#endif
#include <config_distro_bootcmd.h>
Add support for the Arria10 SoCDK.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- board/altera/arria10-socdk/Kconfig | 18 ++++++++++++++++++ board/altera/arria10-socdk/Makefile | 7 +++++++ board/altera/arria10-socdk/socfpga.c | 7 +++++++ 3 files changed, 32 insertions(+) create mode 100644 board/altera/arria10-socdk/Kconfig create mode 100644 board/altera/arria10-socdk/Makefile create mode 100644 board/altera/arria10-socdk/socfpga.c
diff --git a/board/altera/arria10-socdk/Kconfig b/board/altera/arria10-socdk/Kconfig new file mode 100644 index 0000000..b80cc6d --- /dev/null +++ b/board/altera/arria10-socdk/Kconfig @@ -0,0 +1,18 @@ +if TARGET_SOCFPGA_ARRIA10 + +config SYS_CPU + default "armv7" + +config SYS_BOARD + default "socfpga_arria10" + +config SYS_VENDOR + default "altera" + +config SYS_SOC + default "socfpga_arria10" + +config SYS_CONFIG_NAME + default "socfpga_arria10" + +endif diff --git a/board/altera/arria10-socdk/Makefile b/board/altera/arria10-socdk/Makefile new file mode 100644 index 0000000..1d885ce --- /dev/null +++ b/board/altera/arria10-socdk/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2015 Altera Corporation <www.altera.com> +# +# SPDX-License-Identifier: GPL-2.0 +# + +obj-y := socfpga.o diff --git a/board/altera/arria10-socdk/socfpga.c b/board/altera/arria10-socdk/socfpga.c new file mode 100644 index 0000000..8516633 --- /dev/null +++ b/board/altera/arria10-socdk/socfpga.c @@ -0,0 +1,7 @@ +/* + * Copyright (C) 2015 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h>
Update Kconfig and Makefile to enable Arria 10. Clean up Makefile and sorting *.o alphanumerically.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Kconfig | 9 +++++++++ arch/arm/mach-socfpga/Makefile | 46 ++++++++++++++++++++++++++++++------------ 2 files changed, 42 insertions(+), 13 deletions(-)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index e56b3db..e33adee 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -36,6 +36,8 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE config TARGET_SOCFPGA_ARRIA5 bool select TARGET_SOCFPGA_GEN5 +config TARGET_SOCFPGA_ARRIA10 + bool
config TARGET_SOCFPGA_CYCLONE5 bool @@ -48,6 +50,10 @@ choice prompt "Altera SOCFPGA board select" optional
+config TARGET_SOCFPGA_ARRIA10_SOCDK + bool "Altera SOCFPGA SoCDK (Arria 10)" + select TARGET_SOCFPGA_ARRIA10 + config TARGET_SOCFPGA_ARRIA5_SOCDK bool "Altera SOCFPGA SoCDK (Arria V)" select TARGET_SOCFPGA_ARRIA5 @@ -93,6 +99,7 @@ endchoice
config SYS_BOARD default "arria5-socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "arria10-socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK default "cyclone5-socdk" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "de0-nano-soc" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "de1-soc" if TARGET_SOCFPGA_TERASIC_DE1_SOC @@ -105,6 +112,7 @@ config SYS_BOARD
config SYS_VENDOR default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "altera" if TARGET_SOCFPGA_ARRIA10_SOCDK default "altera" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "denx" if TARGET_SOCFPGA_DENX_MCVEVK default "ebv" if TARGET_SOCFPGA_EBV_SOCRATES @@ -118,6 +126,7 @@ config SYS_SOC
config SYS_CONFIG_NAME default "socfpga_arria5_socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "socfpga_arria10_socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK default "socfpga_cyclone5_socdk" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "socfpga_de0_nano_soc" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "socfpga_de1_soc" if TARGET_SOCFPGA_TERASIC_DE1_SOC diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 68d55e4..7c7b471 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -2,28 +2,48 @@ # (C) Copyright 2000-2003 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # -# Copyright (C) 2012 Altera Corporation <www.altera.com> +# Copyright (C) 2012-2017 Altera Corporation <www.altera.com> # # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += misc.o timer.o reset_manager.o clock_manager.o \ - fpga_manager.o board.o +obj-y += board.o +obj-y += clock_manager.o +obj-y += fpga_manager.o +obj-y += misc.o +obj-y += reset_manager.o +obj-y += timer.o
-obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clock_manager_arria10.o \ - misc_arria10.o \ - pinmux_arria10.o \ - reset_manager_arria10.o +ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 +obj-y += clock_manager_arria10.o +obj-y += misc_arria10.o +obj-y += pinmux_arria10.o +obj-y += reset_manager_arria10.o +endif
-obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o +ifdef CONFIG_TARGET_SOCFPGA_GEN5 +obj-y += clock_manager_gen5.o +obj-y += misc_gen5.o +obj-y += reset_manager_gen5.o +obj-y += scan_manager.o +obj-y += system_manager_gen5.o +obj-y += wrap_pll_config.o +endif
+ifdef CONFIG_SPL_BUILD +obj-y += spl.o +ifdef CONFIG_TARGET_SOCFPGA_GEN5 +obj-y += freeze_controller.o +obj-y += wrap_iocsr_config.o +obj-y += wrap_pinmux_config.o +obj-y += wrap_sdram_config.o +endif +endif + +ifdef CONFIG_TARGET_SOCFPGA_GEN5 # QTS-generated config file wrappers -obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ - clock_manager_gen5.o reset_manager_gen5.o \ - misc_gen5.o system_manager_gen5.o -obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ - wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_pinmux_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_pll_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_sdram_config.o += -I$(srctree)/board/$(BOARDDIR) +endif
participants (5)
Chee, Tien Fong
Ley Foon Tan
Ley Foon Tan
Michal Simek
