[U-Boot] [PATCH v3 0/3] board: at91sam9260ek/9g20ek: Convert to support DM and DT
The purpose of the patch set is to convert the boards to support the driver model and the device tree.
It is based on the patch set: [PATCH v8 0/2] pinctrl: at91: Add pinctrl driver https://lists.denx.de/pipermail/u-boot/2017-March/284577.html
Changes in v3: - Add the support of Atmel uart device be used in the board_init_f stage. - Remove unused LED feature. - Improve the commit log. - Move out [PATCH 1/3] ARM: dts: at91: add dts file for at91sam9g20/at91sam9260. - Add [PATCH]: board: at91sam9260ek/9g20ek: Enable early debug UART.
Changes in v2: - Add missing conversion default config files for at91sam9xeek. - Improve the commit log.
Wenyou Yang (3): configs: at91sam9260ek/9g20ek: Update for DT and DM board: at91sam9260ek: Clean up code board: at91sam9260ek/9g20ek: Enable early debug UART
board/atmel/at91sam9260ek/Makefile | 2 +- board/atmel/at91sam9260ek/at91sam9260ek.c | 79 +++----------------------- configs/at91sam9260ek_dataflash_cs0_defconfig | 21 ++++++- configs/at91sam9260ek_dataflash_cs1_defconfig | 21 ++++++- configs/at91sam9260ek_nandflash_defconfig | 21 ++++++- configs/at91sam9g20ek_2mmc_defconfig | 24 +++++++- configs/at91sam9g20ek_2mmc_nandflash_defconfig | 24 +++++++- configs/at91sam9g20ek_dataflash_cs0_defconfig | 21 ++++++- configs/at91sam9g20ek_dataflash_cs1_defconfig | 21 ++++++- configs/at91sam9g20ek_nandflash_defconfig | 21 ++++++- configs/at91sam9xeek_dataflash_cs0_defconfig | 21 ++++++- configs/at91sam9xeek_dataflash_cs1_defconfig | 21 ++++++- configs/at91sam9xeek_nandflash_defconfig | 21 ++++++- include/configs/at91sam9260ek.h | 29 +--------- 14 files changed, 238 insertions(+), 109 deletions(-)
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
board/atmel/at91sam9260ek/Makefile | 2 +- configs/at91sam9260ek_dataflash_cs0_defconfig | 15 ++++++++++++- configs/at91sam9260ek_dataflash_cs1_defconfig | 15 ++++++++++++- configs/at91sam9260ek_nandflash_defconfig | 15 ++++++++++++- configs/at91sam9g20ek_2mmc_defconfig | 18 +++++++++++++++- configs/at91sam9g20ek_2mmc_nandflash_defconfig | 18 +++++++++++++++- configs/at91sam9g20ek_dataflash_cs0_defconfig | 15 ++++++++++++- configs/at91sam9g20ek_dataflash_cs1_defconfig | 15 ++++++++++++- configs/at91sam9g20ek_nandflash_defconfig | 15 ++++++++++++- configs/at91sam9xeek_dataflash_cs0_defconfig | 15 ++++++++++++- configs/at91sam9xeek_dataflash_cs1_defconfig | 15 ++++++++++++- configs/at91sam9xeek_nandflash_defconfig | 15 ++++++++++++- include/configs/at91sam9260ek.h | 29 ++------------------------ 13 files changed, 163 insertions(+), 39 deletions(-)
diff --git a/board/atmel/at91sam9260ek/Makefile b/board/atmel/at91sam9260ek/Makefile index c6edbeee24..07c6184352 100644 --- a/board/atmel/at91sam9260ek/Makefile +++ b/board/atmel/at91sam9260ek/Makefile @@ -10,5 +10,5 @@ #
obj-y += at91sam9260ek.o -obj-y += led.o +obj-$(CONFIG_AT91_LED) += led.o obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index e00c4c4c1f..6d34e215ff 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,7 +19,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 7b81775255..85f01f34d2 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,7 +19,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index ca71891f35..d9a7a48e88 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,7 +19,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index 67c82326a4..ef7bd402c7 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek_2mmc" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +20,20 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 6d2bfa1d6b..398be7e60a 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek_2mmc" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +20,20 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 5bb0cb210e..b8105738aa 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,7 +19,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index fb6a0ac829..18e2a17664 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,7 +19,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 79ec2e446b..daa41dcba7 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,7 +19,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index e29b3cdfe5..e38b718129 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,7 +19,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 2e32ca8e17..bc7eb03f87 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,7 +19,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 2ef459bb64..7e59335756 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,7 +19,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 379f234463..4edaa32c33 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -45,19 +45,6 @@
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ -#define CONFIG_AT91_GPIO -#define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */ - -/* serial console */ -#define CONFIG_ATMEL_USART -#define CONFIG_USART_BASE ATMEL_BASE_DBGU -#define CONFIG_USART_ID ATMEL_ID_SYS - -/* LED */ -#define CONFIG_AT91_LED -#define CONFIG_RED_LED AT91_PIN_PA9 /* this is the power led */ -#define CONFIG_GREEN_LED AT91_PIN_PA6 /* this is the user led */ -
/* * BOOTP options @@ -87,10 +74,10 @@ */ #ifdef CONFIG_AT91SAM9XE # define CONFIG_SYS_INIT_SP_ADDR \ - (ATMEL_BASE_SRAM + 0x1000 - GENERATED_GBL_DATA_SIZE) + (ATMEL_BASE_SRAM + 16 * 1024 - GENERATED_GBL_DATA_SIZE) #else # define CONFIG_SYS_INIT_SP_ADDR \ - (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE) + (ATMEL_BASE_SRAM1 + 16 * 1024 - GENERATED_GBL_DATA_SIZE) #endif
/* @@ -142,18 +129,6 @@ #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 #endif
-/* MMC */ -#ifdef CONFIG_CMD_MMC -#define CONFIG_GENERIC_ATMEL_MCI -#endif - -/* Ethernet */ -#define CONFIG_MACB 1 -#define CONFIG_RMII 1 -#define CONFIG_NET_RETRY_COUNT 20 -#define CONFIG_RESET_PHY_R 1 -#define CONFIG_AT91_WANTS_COMMON_PHY - /* USB */ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB
Changes in v3:
Changes in v2:
You might be able to add some of these as defaults in your Kconfig for at91sam9g20 if you set things up correctly.
Since the introduction of the pinctrl and clk drivers and the device tree files, remove unneeded hard coded related code from the board file.
board/atmel/at91sam9260ek/at91sam9260ek.c | 74 ------------------------------- 1 file changed, 74 deletions(-)
diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index 98193bfdc6..e28242f034 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -13,12 +13,6 @@ #include <asm/arch/at91_common.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> -#include <atmel_mci.h> - -#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) -# include <net.h> -#endif -#include <netdev.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -67,63 +61,8 @@ static void at91sam9260ek_nand_hw_init(void) } #endif
-#ifdef CONFIG_MACB -static void at91sam9260ek_macb_hw_init(void) -{ - struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - - at91_periph_clk_enable(ATMEL_ID_EMAC0); - - /* - * Disable pull-up on: - * RXDV (PA17) => PHY normal mode (not Test mode) - * ERX0 (PA14) => PHY ADDR0 - * ERX1 (PA15) => PHY ADDR1 - * ERX2 (PA25) => PHY ADDR2 - * ERX3 (PA26) => PHY ADDR3 - * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 - * - * PHY has internal pull-down - */ - writel(pin_to_mask(AT91_PIN_PA14) | - pin_to_mask(AT91_PIN_PA15) | - pin_to_mask(AT91_PIN_PA17) | - pin_to_mask(AT91_PIN_PA25) | - pin_to_mask(AT91_PIN_PA26) | - pin_to_mask(AT91_PIN_PA28), - &pioa->pudr); - - at91_phy_reset(); - - /* Re-enable pull-up */ - writel(pin_to_mask(AT91_PIN_PA14) | - pin_to_mask(AT91_PIN_PA15) | - pin_to_mask(AT91_PIN_PA17) | - pin_to_mask(AT91_PIN_PA25) | - pin_to_mask(AT91_PIN_PA26) | - pin_to_mask(AT91_PIN_PA28), - &pioa->puer); - - /* Initialize EMAC=MACB hardware */ - at91_macb_hw_init(); -} -#endif - -#ifdef CONFIG_GENERIC_ATMEL_MCI -int board_mmc_init(bd_t *bd) -{ - at91_mci_hw_init(); - - return atmel_mci_init((void *)ATMEL_BASE_MCI); -} -#endif - int board_early_init_f(void) { - at91_periph_clk_enable(ATMEL_ID_PIOA); - at91_periph_clk_enable(ATMEL_ID_PIOB); - at91_periph_clk_enable(ATMEL_ID_PIOC); - return 0; }
@@ -132,16 +71,12 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- at91_seriald_hw_init(); #ifdef CONFIG_CMD_NAND at91sam9260ek_nand_hw_init(); #endif #ifdef CONFIG_HAS_DATAFLASH at91_spi0_hw_init((1 << 0) | (1 << 1)); #endif -#ifdef CONFIG_MACB - at91sam9260ek_macb_hw_init(); -#endif
return 0; } @@ -159,12 +94,3 @@ void reset_phy(void) { } #endif - -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x00); -#endif - return rc; -}
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available.
Changes in v3: - Move out [PATCH 1/3] ARM: dts: at91: add dts file for at91sam9g20/at91sam9260. - Add [PATCH]: board: at91sam9260ek/9g20ek: Enable early debug UART.
Changes in v2: None
board/atmel/at91sam9260ek/at91sam9260ek.c | 13 +++++++++++++ configs/at91sam9260ek_dataflash_cs0_defconfig | 6 ++++++ configs/at91sam9260ek_dataflash_cs1_defconfig | 6 ++++++ configs/at91sam9260ek_nandflash_defconfig | 6 ++++++ configs/at91sam9g20ek_2mmc_defconfig | 6 ++++++ configs/at91sam9g20ek_2mmc_nandflash_defconfig | 6 ++++++ configs/at91sam9g20ek_dataflash_cs0_defconfig | 6 ++++++ configs/at91sam9g20ek_dataflash_cs1_defconfig | 6 ++++++ configs/at91sam9g20ek_nandflash_defconfig | 6 ++++++ configs/at91sam9xeek_dataflash_cs0_defconfig | 6 ++++++ configs/at91sam9xeek_dataflash_cs1_defconfig | 6 ++++++ configs/at91sam9xeek_nandflash_defconfig | 6 ++++++ 12 files changed, 79 insertions(+)
diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index e28242f034..b087fce9b8 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <debug_uart.h> #include <asm/io.h> #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> @@ -61,10 +62,22 @@ static void at91sam9260ek_nand_hw_init(void) } #endif
+#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ + at91_seriald_hw_init(); +} +#endif + +#ifdef CONFIG_BOARD_EARLY_INIT_F int board_early_init_f(void) { +#ifdef CONFIG_DEBUG_UART + debug_uart_init(); +#endif return 0; } +#endif
int board_init(void) { diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 6d34e215ff..cc3f0a8b34 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -31,6 +31,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 85f01f34d2..cb621dfb9f 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -31,6 +31,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index d9a7a48e88..20d3565377 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -31,6 +31,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index ef7bd402c7..18e88a7445 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -33,6 +33,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 398be7e60a..fb0d87ab4b 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -33,6 +33,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index b8105738aa..27c1c10df1 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -31,6 +31,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index 18e2a17664..1826e6ca98 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -31,6 +31,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index daa41dcba7..1ac88631bc 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -31,6 +31,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index e38b718129..80673d2b63 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -31,6 +31,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index bc7eb03f87..8922065d38 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -31,6 +31,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 7e59335756..9c28a59fe3 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -31,6 +31,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y
Changes in v3:
Changes in v2: None
Wenyou Yang
